Part Number: J721S2XSOMXEVM
How to enable other uart for getting the boot logs?
HI Gokul,
WKUP UART
The below patch will help in enabling WKUP UART for the boot logs in SPL Boot flow:
NOTE: When using UART BOOT MODE, ensure that you are loading tiboot3.bin through MCU UART and tispl.bin and u-boot.img through WKUP UART.
J7200:
diff --git a/arch/arm/mach-k3/r5/j7200/clk-data.c b/arch/arm/mach-k3/r5/j7200/clk-data.c
index eb8436de..b95d4435 100644
--- a/arch/arm/mach-k3/r5/j7200/clk-data.c
+++ b/arch/arm/mach-k3/r5/j7200/clk-data.c
@@ -62,6 +62,17 @@ static const char * const wkup_i2c0_mcupll_bypass_clksel_out0_parents[] = {
"gluelogic_hfosc0_clkout",
+static const char * const wkupusart_clk_sel_out0_parents[] = {
+ "hsdiv4_16fft_mcu_1_hsdivout3_clk",
+ "postdiv2_16fft_main_1_hsdivout5_clk",
+static const char * const wkup_usart_mcupll_bypass_clksel_out0_parents[] = {
+ "wkupusart_clk_sel_out0",
+ "gluelogic_hfosc0_clkout",
static const char * const main_pll_hfosc_sel_out0_parents[] = {
"board_0_hfosc1_clk_out",
@@ -419,6 +430,8 @@ static const struct clk_data clk_list[] = {
CLK_DIV("osbclk0_div_out0", "obsclk0_mux_out0", 0x108000, 8, 8, 0, 0),
CLK_DIV("k3_pll_ctrl_wrap_main_0_chip_div24_clk_clk", "k3_pll_ctrl_wrap_main_0_sysclkout_clk", 0x41011c, 0, 5, 0, 0),
CLK_DIV("k3_pll_ctrl_wrap_wkup_0_chip_div24_clk_clk", "k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", 0x4201011c, 0, 5, 0, 0),
+CLK_MUX("wkupusart_clk_sel_out0", wkupusart_clk_sel_out0_parents, 2, 0x43008064, 0, 1, 0),
+ CLK_MUX("wkup_usart_mcupll_bypass_clksel_out0", wkup_usart_mcupll_bypass_clksel_out0_parents, 2, 0x43008060, 0, 1, 0),
static const struct dev_clk soc_dev_clk_data[] = {
@@ -554,6 +567,10 @@ static const struct dev_clk soc_dev_clk_data[] = {
DEV_CLK(323, 0, "main_pll8_sel_extwave_out0"),
DEV_CLK(323, 1, "pllfracf_ssmod_16fft_main_8_foutvcop_clk"),
DEV_CLK(323, 2, "hsdiv0_16fft_main_8_hsdivout0_clk"),
+ DEV_CLK(287, 2, "wkup_usart_mcupll_bypass_clksel_out0"),
+ DEV_CLK(287, 3, "wkupusart_clk_sel_out0"),
+ DEV_CLK(287, 4, "gluelogic_hfosc0_clkout"),
+ DEV_CLK(287, 5, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"),
const struct ti_k3_clk_platdata j7200_clk_platdata = {
diff --git a/arch/arm/mach-k3/r5/j7200/dev-data.c b/arch/arm/mach-k3/r5/j7200/dev-data.c
index 8ce6796f..ae24e573 100644
--- a/arch/arm/mach-k3/r5/j7200/dev-data.c
+++ b/arch/arm/mach-k3/r5/j7200/dev-data.c
@@ -69,6 +69,7 @@ static struct ti_dev soc_dev_list[] = {
PSC_DEV(103, &soc_lpsc_list[14]),
PSC_DEV(104, &soc_lpsc_list[15]),
PSC_DEV(102, &soc_lpsc_list[16]),
+ PSC_DEV(287, &soc_lpsc_list[13]),
const struct ti_k3_pd_platdata j7200_pd_platdata = {
diff --git a/dts/upstream/src/arm64/ti/k3-j7200-common-proc-board.dts b/dts/upstream/src/arm64/ti/k3-j7200-common-proc-board.dts
index 735ffd3f..2823ff13 100644
--- a/dts/upstream/src/arm64/ti/k3-j7200-common-proc-board.dts
+++ b/dts/upstream/src/arm64/ti/k3-j7200-common-proc-board.dts
@@ -18,9 +18,9 @@
model = "Texas Instruments J7200 EVM";
aliases {
- serial0 = &wkup_uart0;
+ serial0 = &main_uart0;
serial1 = &mcu_uart0;
- serial2 = &main_uart0;
+ serial2 = &wkup_uart0;
serial3 = &main_uart1;
serial5 = &main_uart3;
mmc0 = &main_sdhci0;
@@ -270,7 +270,7 @@
&wkup_uart0 {
/* Wakeup UART is used by System firmware */
- status = "reserved";
+ status = "okay";
pinctrl-names = "default";
pinctrl-0 = <&wkup_uart0_pins_default>;
bootph-all;
diff --git a/dts/upstream/src/arm64/ti/k3-j7200-mcu-wakeup.dtsi b/dts/upstream/src/arm64/ti/k3-j7200-mcu-wakeup.dtsi
index d9a40b48..c24b1c8f 100644
--- a/dts/upstream/src/arm64/ti/k3-j7200-mcu-wakeup.dtsi
+++ b/dts/upstream/src/arm64/ti/k3-j7200-mcu-wakeup.dtsi
@@ -274,11 +274,10 @@
compatible = "ti,j721e-uart", "ti,am654-uart";
reg = <0x00 0x42300000 0x00 0x100>;
interrupts = <GIC_SPI 897 IRQ_TYPE_LEVEL_HIGH>;
- clock-frequency = <48000000>;
+ clock-frequency = <96000000>;
power-domains = <&k3_pds 287 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 287 2>;
clock-names = "fclk";
- status = "disabled";
mcu_uart0: serial@40a00000 {
diff --git a/board/ti/j721e/j721e.env b/board/ti/j721e/j721e.env
index 54cffa52..37214c3c 100644
--- a/board/ti/j721e/j721e.env
+++ b/board/ti/j721e/j721e.env
@@ -14,7 +14,7 @@ defined(CONFIG_TARGET_J721E_R5_EVM)
name_kern=Image
console=ttyS2,115200n8
-args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x02800000
+args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x42300000
${mtdparts}
run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}
ATF changes
diff --git a/plat/ti/k3/include/platform_def.h b/plat/ti/k3/include/platform_def.h
index 6a05392ad..8a463ba05 100644
--- a/plat/ti/k3/include/platform_def.h
+++ b/plat/ti/k3/include/platform_def.h
@@ -90,14 +90,14 @@
/* Platform default console definitions */
#ifndef K3_USART_BASE
-#define K3_USART_BASE (0x02800000 + 0x10000 * K3_USART)
+#define K3_USART_BASE 0x42300000
#endif
/* USART has a default size for address space */
#define K3_USART_SIZE 0x1000
#ifndef K3_USART_CLK_SPEED
-#define K3_USART_CLK_SPEED 48000000
+#define K3_USART_CLK_SPEED 96000000
#endif
/* Crash console defaults */
OPTEE Changes
diff --git a/core/arch/arm/plat-k3/platform_config.h b/core/arch/arm/plat-k3/platform_config.h
index cffca0a07..d15f9a08f 100644
--- a/core/arch/arm/plat-k3/platform_config.h
+++ b/core/arch/arm/plat-k3/platform_config.h
@@ -9,11 +9,11 @@
#include <mm/generic_ram_layout.h>
-#define UART0_BASE 0x02800000
+#define UART0_BASE 0x42300000
-#define CONSOLE_UART_BASE (UART0_BASE + CFG_CONSOLE_UART * 0x10000)
+#define CONSOLE_UART_BASE UART0_BASE
#define CONSOLE_BAUDRATE 115200
-#define CONSOLE_UART_CLK_IN_HZ 48000000
+#define CONSOLE_UART_CLK_IN_HZ 96000000
#define DRAM0_BASE 0x80000000
#define DRAM0_SIZE 0x80000000
diff --git a/mk/clang.mk b/mk/clang.mk
index d08b26e6f..8a01cd9db 100644
--- a/mk/clang.mk
+++ b/mk/clang.mk
@@ -31,7 +31,7 @@ comp-cflags-warns-clang := -Wno-language-extension-token \
# Note, use the compiler runtime library (libclang_rt.builtins.*.a) instead of
# libgcc for clang
-libgcc$(sm) := $(shell $(CC$(sm)) $(CFLAGS$(arch-bits-$(sm))) \
+libgcc$(sm) := $(shell $(CC$(sm)) $(LIBGCC_LOCATE_CFLAGS) $(CFLAGS$(arch-bits-$(sm))) \
-rtlib=compiler-rt -print-libgcc-file-name 2> /dev/null)
# Core ASLR relies on the executable being ready to run from its preferred load
Kernel Changes
diff --git a/arch/arm64/boot/dts/ti/k3-j7200-common-proc-board.dts b/arch/arm64/boot/dts/ti/k3-j7200-common-proc-board.dts
index 735ffd3f3..2823ff137 100644
--- a/arch/arm64/boot/dts/ti/k3-j7200-common-proc-board.dts
+++ b/arch/arm64/boot/dts/ti/k3-j7200-common-proc-board.dts
@@ -18,9 +18,9 @@ / {
aliases {
@@ -270,7 +270,7 @@ J721E_IOPAD(0x04, PIN_OUTPUT, 0) /* (T4) USB0_DRVVBUS */
&wkup_uart0 {
+ status = "okay";
bootph-all;
diff --git a/arch/arm64/boot/dts/ti/k3-j7200-mcu-wakeup.dtsi b/arch/arm64/boot/dts/ti/k3-j7200-mcu-wakeup.dtsi
index d9a40b480..c24b1c8f2 100644
--- a/arch/arm64/boot/dts/ti/k3-j7200-mcu-wakeup.dtsi
+++ b/arch/arm64/boot/dts/ti/k3-j7200-mcu-wakeup.dtsi
@@ -274,11 +274,10 @@ wkup_uart0: serial@42300000 {
J721S2:
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/enable_5F00_wkupuart_5F00_j721s2.patch
J784S4:
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/wkup_5F00_uart_5F00_enable_5F00_j784s4.patch
J722S:
UBOOT CHANGES
From dd2971e89ff151de3eaf75361c02f1daa906ce8b Mon Sep 17 00:00:00 2001
Date: Thu, 13 Nov 2025 12:10:36 +0530
Subject: [PATCH] Enable wkup uart in j722s
arch/arm/dts/k3-am62p-wakeup.dtsi | 4 +++-
arch/arm/dts/k3-j722s-evm.dts | 9 +++++----
arch/arm/dts/k3-j722s-r5-evm.dts | 4 ++--
arch/arm/mach-k3/r5/j722s/clk-data.c | 5 +++++
arch/arm/mach-k3/r5/j722s/dev-data.c | 1 +
board/ti/j722s/j722s.env | 2 +-
6 files changed, 17 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/k3-am62p-wakeup.dtsi b/arch/arm/dts/k3-am62p-wakeup.dtsi
index c71d9624..05d20de6 100644
--- a/arch/arm/dts/k3-am62p-wakeup.dtsi
+++ b/arch/arm/dts/k3-am62p-wakeup.dtsi
@@ -37,7 +37,9 @@
power-domains = <&k3_pds 114 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 114 0>;
+ current-speed = <115200>;
+ status = "okay";
wkup_i2c0: i2c@2b200000 {
diff --git a/arch/arm/dts/k3-j722s-evm.dts b/arch/arm/dts/k3-j722s-evm.dts
index d799be55..0b8181db 100644
--- a/arch/arm/dts/k3-j722s-evm.dts
+++ b/arch/arm/dts/k3-j722s-evm.dts
@@ -19,8 +19,8 @@
model = "Texas Instruments J722S EVM";
aliases {
mmc0 = &sdhci0;
mmc1 = &sdhci1;
usb0 = &usb0;
@@ -28,7 +28,7 @@
chosen {
- stdout-path = &main_uart0;
+ stdout-path = &wkup_uart0;
memory@80000000 {
@@ -338,7 +338,8 @@
/* WKUP UART0 is used by Device Manager firmware */
+ status = "okay";
bootph-all;
diff --git a/arch/arm/dts/k3-j722s-r5-evm.dts b/arch/arm/dts/k3-j722s-r5-evm.dts
index b1788e40..b81b5a97 100644
--- a/arch/arm/dts/k3-j722s-r5-evm.dts
+++ b/arch/arm/dts/k3-j722s-r5-evm.dts
@@ -14,8 +14,8 @@
aliases {
remoteproc0 = &sysctrler;
remoteproc1 = &a53_0;
a53_0: a53@0 {
diff --git a/arch/arm/mach-k3/r5/j722s/clk-data.c b/arch/arm/mach-k3/r5/j722s/clk-data.c
index b4f27af3..ff1edbf3 100644
--- a/arch/arm/mach-k3/r5/j722s/clk-data.c
+++ b/arch/arm/mach-k3/r5/j722s/clk-data.c
@@ -206,6 +206,7 @@ static const struct clk_data clk_list[] = {
CLK_MUX("main_usart0_fclk_sel_out0", main_usart0_fclk_sel_out0_parents, 2, 0x108280, 0, 1, 0),
CLK_DIV("sam62_pll_ctrl_wrap_main_0_chip_div24_clk_clk", "sam62_pll_ctrl_wrap_main_0_sysclkout_clk", 0x41011c, 0, 5, 0, 0),
CLK_DIV("sam62_pll_ctrl_wrap_mcu_0_chip_div24_clk_clk", "sam62_pll_ctrl_wrap_mcu_0_sysclkout_clk", 0x402011c, 0, 5, 0, 0),
+ CLK_DIV("hsdiv4_16fft_mcu_0_hsdivout2_clk", "pllfracf2_ssmod_16fft_mcu_0_foutvcop_clk", 0x4040088, 0, 7, 0, 0),
@@ -302,6 +303,10 @@ static const struct dev_clk soc_dev_clk_data[] = {
DEV_CLK(170, 1, "hsdiv0_16fft_main_12_hsdivout0_clk"),
DEV_CLK(170, 2, "board_0_tck_out"),
DEV_CLK(170, 3, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"),
+ DEV_CLK(114, 0, "hsdiv4_16fft_mcu_0_hsdivout2_clk"),
+ DEV_CLK(114, 3, "wkup_clksel_out0"),
+ DEV_CLK(114, 4, "hsdiv3_16fft_main_15_hsdivout0_clk"),
+ DEV_CLK(114, 5, "hsdiv4_16fft_mcu_0_hsdivout0_clk"),
const struct ti_k3_clk_platdata j722s_clk_platdata = {
diff --git a/arch/arm/mach-k3/r5/j722s/dev-data.c b/arch/arm/mach-k3/r5/j722s/dev-data.c
index 59176c98..ea2a69b9 100644
--- a/arch/arm/mach-k3/r5/j722s/dev-data.c
+++ b/arch/arm/mach-k3/r5/j722s/dev-data.c
@@ -55,6 +55,7 @@ static struct ti_dev soc_dev_list[] = {
PSC_DEV(170, &soc_lpsc_list[10]),
PSC_DEV(177, &soc_lpsc_list[11]),
PSC_DEV(55, &soc_lpsc_list[12]),
+ PSC_DEV(114, &soc_lpsc_list[0]),
const struct ti_k3_pd_platdata j722s_pd_platdata = {
diff --git a/board/ti/j722s/j722s.env b/board/ti/j722s/j722s.env
index 4cc66e8d..a211277c 100644
--- a/board/ti/j722s/j722s.env
+++ b/board/ti/j722s/j722s.env
@@ -8,7 +8,7 @@
name_kern=Image
+args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x2B300000
${mtdparts}
2.34.1
KERNEL CHANGES
From d61b6a289604ae25811b03e1091b3e8cd07b3c0c Mon Sep 17 00:00:00 2001
Date: Tue, 30 Sep 2025 12:28:54 +0530
Subject: [PATCH] ENable wkup uart in Linux for J722S
arch/arm64/boot/dts/ti/k3-am62p-wakeup.dtsi | 1 +
arch/arm64/boot/dts/ti/k3-j722s-evm.dts | 8 ++++----
2 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/arch/arm64/boot/dts/ti/k3-am62p-wakeup.dtsi b/arch/arm64/boot/dts/ti/k3-am62p-wakeup.dtsi
index c105ea4e9..1afae4262 100644
--- a/arch/arm64/boot/dts/ti/k3-am62p-wakeup.dtsi
+++ b/arch/arm64/boot/dts/ti/k3-am62p-wakeup.dtsi
@@ -61,6 +61,7 @@ SYSC_OMAP2_SOFTRESET |
clock-names = "fck";
#address-cells = <1>;
#size-cells = <1>;
ranges = <0 0 0x2b300000 0x100000>;
diff --git a/arch/arm64/boot/dts/ti/k3-j722s-evm.dts b/arch/arm64/boot/dts/ti/k3-j722s-evm.dts
index 146c5580f..c51918b5d 100644
--- a/arch/arm64/boot/dts/ti/k3-j722s-evm.dts
+++ b/arch/arm64/boot/dts/ti/k3-j722s-evm.dts
@@ -18,15 +18,15 @@ / {
aliases {
+ serial0 = &main_uart0;;
serial3 = &main_uart5;
mmc0 = &sdhci0;
mmc1 = &sdhci1;
chosen {
memory@80000000 {
@@ -534,7 +534,7 @@ &wkup_uart0 {
+ status = "okay";
bootph-all;
2.34.1
Additional patch in Linux kernel for J722S to solve hang issue for wkup uart:
diff --git a/drivers/bus/ti-sysc.c b/drivers/bus/ti-sysc.c
index 9ed9239b1228..947df3fa6cdd 100644
--- a/drivers/bus/ti-sysc.c
+++ b/drivers/bus/ti-sysc.c
@@ -937,7 +937,7 @@ static int sysc_map_and_check_registers(struct sysc *ddata)
if (error)
return error;
- error = sysc_defer_non_critical(ddata);
+ // error = sysc_defer_non_critical(ddata);
if (error)
return error;
[ 13.204416]
This solves the issue platform 2b300050.target-module: deferred probe pending.
This issue has already been fixed upstream.
Commit no: 36305857b1ead8f6ca033a913162ebc09bee0b43
Reference E2E for the same:
Build Steps:
Building UBOOT:
Building ATF:
NOTE: Since, ATF AND OPTEE Prints will now come in wkup uart,the boot might hang some times due to system firmware using wkup uart for logging.
Hence, in case that happens, please remove the atf/optee related patches so that the ATF/OPTEE prints come in main uart itself.
Building OPTEE:
MAIN UART
This is an example of main uart 3 for j784s4. Similar approach can be followed for other main uarts in other boards as well:
make CROSS_COMPILE="$CROSS_COMPILE_64" ARCH=aarch64 PLAT=k3 TARGET_BOARD=generic SPD=opteed K3_USART=0x3
OPTEE Changes:
export CFG_CONSOLE_UART=0x3 make CROSS_COMPILE="$CROSS_COMPILE_32" CROSS_COMPILE64="$CROSS_COMPILE_64" PLATFORM=k3-j784s4 CFG_ARM64_core=y
UBOOT Changes:
Enable main uart 3 in the device tree for j784s4.
On top of that, the below patch also has to be applied in the u-boot directory.
diff --git a/board/ti/j784s4/j784s4.env b/board/ti/j784s4/j784s4.env
index e174fac8..c0567a40 100644
--- a/board/ti/j784s4/j784s4.env
+++ b/board/ti/j784s4/j784s4.env
@@ -9,7 +9,7 @@
name_kern=Image
-args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x02880000
+args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x02830000
${mtdparts}
Kernel changes:
The same changes you have done for enabling main uart 3 in uboot needs to be the device tree used in linux kernel as well.
Gokul
