Part Number: AM625-Q1
Other Parts Discussed in Thread: BP-CC3301MOD, CC3300, SK-AM62-LP, , M2-CC3351, AM625, CC3301MOD
We're trying interface BP-CC3301MOD Booster Pack module in Shared SDIO mode. However we're getting timeout error "mmc_attach_sdio() mmc_send_io_op_cond FAILED, err=-110".
Below is the dts snippet
pinctrl-names = "default"; &main_pmx0 { main_mmc2_pins_default: main-mmc2-pins-default { &sdhci2 { broken-cd; #address-cells = <1>; // TI-BLE-SDIO interface |
We're able to see the reset happening and some data in MMC2_CMD line using Oscilloscope. But there is no data in data lines.
Attaching the dmesg logs.
Please help in resolving the issue.
[ 1.904397] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz [ 1.916355] sdhci-am654 fa10000.mmc: DEBUG: sdhci_am654_probe() started for fa10000.mmc [ 1.923738] pca953x 1-0022: supply vcc not found, using dummy regulator [ 1.924412] sdhci-am654 fa10000.mmc: DEBUG: matched compatible 'ti,am62-sdhci' [ 1.931197] pca953x 1-0022: using AI [ 1.938446] sdhci-am654 fa10000.mmc: DEBUG: sdhci_pltfm_init successful [ 1.941967] pca953x 1-0022: failed writing register: -121 [ 1.948389] sdhci-am654 fa10000.mmc: DEBUG: clk_xin clock obtained successfully [ 1.953974] pca953x 1-0022: probe with driver pca953x failed with error -121 [ 1.961182] sdhci-am654 fa10000.mmc: DEBUG: regmap initialized successfully [ 1.975071] sdhci-am654 fa10000.mmc: DEBUG: sdhci_am654_get_of_property() started [ 1.976257] sdhci-am654 fa20000.mmc: DEBUG: sdhci_am654_probe() started for fa20000.mmc [ 1.977997] clk: Disabling unused clocks [ 1.982590] sdhci-am654 fa10000.mmc: DEBUG: strobe-sel = 0, clkbuf-sel = 7 [ 1.982626] sdhci-am654 fa10000.mmc: DEBUG: sdhci_am654_get_of_property() completed [ 1.987795] PM: genpd: Disabling unused power domains [ 1.987922] ALSA device list: [ 1.987929] No soundcards found. [ 1.990758] sdhci-am654 fa20000.mmc: DEBUG: matched compatible 'ti,am62-sdhci' [ 1.994580] sdhci-am654 fa10000.mmc: DEBUG: mmc_of_parse completed successfully [ 2.001804] sdhci-am654 fa20000.mmc: DEBUG: sdhci_pltfm_init successful [ 2.009020] sdhci-am654 fa10000.mmc: DEBUG: MMC caps: 0x00001041, caps2: 0x00040020 [ 2.009027] sdhci-am654 fa10000.mmc: DEBUG: vmmc supply: found, vqmmc supply: found [ 2.014190] sdhci-am654 fa20000.mmc: DEBUG: clk_xin clock obtained successfully [ 2.017140] sdhci-am654 fa10000.mmc: DEBUG: clocks and power management setup complete [ 2.020534] sdhci-am654 fa20000.mmc: DEBUG: regmap initialized successfully [ 2.027640] sdhci-am654 fa10000.mmc: DEBUG: sdhci_am654_init() started [ 2.027653] sdhci-am654 fa10000.mmc: DEBUG: OTAP reset to default [ 2.035036] sdhci-am654 fa20000.mmc: DEBUG: sdhci_am654_get_of_property() started [ 2.041547] sdhci-am654 fa10000.mmc: DEBUG: IOMUX_PRESENT flag set, enabling pins [ 2.041554] sdhci-am654 fa10000.mmc: DEBUG: Setting slot type to REMOVABLE [ 2.049305] sdhci-am654 fa20000.mmc: DEBUG: strobe-sel = 0, clkbuf-sel = 7 [ 2.056837] sdhci-am654 fa10000.mmc: DEBUG: Tuning for SDR50 enabled [ 2.064227] sdhci-am654 fa20000.mmc: DEBUG: ti,fails-without-test-cd property found, enabling FORCE_CDTEST quirk [ 2.072041] sdhci-am654 fa10000.mmc: DEBUG: Calling sdhci_setup_host() [ 2.079099] sdhci-am654 fa20000.mmc: DEBUG: sdhci_am654_get_of_property() completed [ 2.085624] sdhci-am654 fa10000.mmc: DEBUG: sdhci_setup_host() completed successfully [ 2.091628] sdhci-am654 fa20000.mmc: DEBUG: mmc_of_parse completed successfully [ 2.099051] mmc0: CQHCI version 5.10 [ 2.099058] sdhci-am654 fa10000.mmc: DEBUG: CQE host added successfully [ 2.106635] sdhci-am654 fa20000.mmc: DEBUG: MMC caps: 0x00004101, caps2: 0x00040000 [ 2.113442] sdhci-am654 fa10000.mmc: DEBUG: OTAP delay configuration completed [ 2.120384] sdhci-am654 fa20000.mmc: DEBUG: vmmc supply: found, vqmmc supply: found [ 2.126623] sdhci-am654 fa10000.mmc: DEBUG: Calling __sdhci_add_host() [ 2.136990] sdhci-am654 fa20000.mmc: DEBUG: clocks and power management setup complete [ 2.213171] sdhci-am654 fa20000.mmc: DEBUG: sdhci_am654_init() started [ 2.213409] sdhci-am654 fa10000.mmc: DEBUG: mmc_power_up() starting, ocr=0x300080 [ 2.219722] sdhci-am654 fa20000.mmc: DEBUG: OTAP reset to default [ 2.233235] sdhci-am654 fa20000.mmc: DEBUG: IOMUX_PRESENT flag set, enabling pins [ 2.240719] sdhci-am654 fa20000.mmc: DEBUG: Setting slot type to EMBEDDED (non-removable) [ 2.248890] sdhci-am654 fa20000.mmc: DEBUG: Tuning for SDR50 enabled [ 2.255237] sdhci-am654 fa20000.mmc: DEBUG: Calling sdhci_setup_host() [ 2.259292] sdhci-am654 fa10000.mmc: DEBUG: mmc_power_up() completed successfully [ 2.262096] sdhci-am654 fa20000.mmc: DEBUG: sdhci_setup_host() completed successfully [ 2.269268] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 2.277045] mmc2: CQHCI version 5.10 [ 2.284516] sdhci-am654 fa10000.mmc: DEBUG: mmc_rescan() started, rescan_disable=0 [ 2.288070] sdhci-am654 fa20000.mmc: DEBUG: CQE host added successfully [ 2.295626] sdhci-am654 fa10000.mmc: DEBUG: mmc_rescan() proceeding with scan, removable=1 [ 2.295675] sdhci-am654 fa10000.mmc: DEBUG: __sdhci_add_host() completed successfully [ 2.295681] sdhci-am654 fa10000.mmc: DEBUG: sdhci_am654_init completed successfully [ 2.295689] sdhci-am654 fa10000.mmc: DEBUG: sdhci_am654_probe completed successfully for fa10000.mmc [ 2.302262] sdhci-am654 fa20000.mmc: DEBUG: OTAP delay configuration completed [ 2.310482] sdhci-am654 fa10000.mmc: DEBUG: mmc_rescan() no card detected, starting frequency scan [ 2.318300] sdhci-am654 fa20000.mmc: DEBUG: Calling __sdhci_add_host() [ 2.325945] sdhci-am654 fa10000.mmc: DEBUG: mmc_rescan() trying different frequencies [ 2.365548] sdhci-am654 fa10000.mmc: DEBUG: mmc_rescan() trying frequency 400000 Hz (attempt 0) [ 2.365682] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_up() starting, ocr=0x300000 [ 2.374246] sdhci-am654 fa10000.mmc: DEBUG: mmc_rescan_try_freq() starting, freq=400000 Hz [ 2.381737] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=0 [ 2.389972] sdhci-am654 fa10000.mmc: DEBUG: mmc_power_up() already powered on, skipping [ 2.399083] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 2.407069] sdio_reset: ENTER - starting SDIO reset sequence [ 2.417319] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: calling regulator_enable() [ 2.423363] mmc_io_rw_direct_host: Command failed with error -110 [ 2.437543] sdio_reset: Read SDIO_CCCR_ABORT failed with error -110, using default abort=0x08 [ 2.446058] sdio_reset: Writing SDIO_CCCR_ABORT with value=0x08 [ 2.452336] mmc_io_rw_direct_host: Command failed with error -110 [ 2.458427] sdio_reset: EXIT - returning ret=-110 [ 2.467502] sdhci-am654 fa10000.mmc: DEBUG: mmc_rescan_try_freq() trying SDIO attach [ 2.475241] sdhci-am654 fa10000.mmc: DEBUG: mmc_attach_sdio() starting [ 2.483215] sdhci-am654 fa10000.mmc: DEBUG: mmc_attach_sdio() mmc_send_io_op_cond FAILED, err=-110 [ 2.492167] sdhci-am654 fa10000.mmc: DEBUG: mmc_rescan_try_freq() SDIO attach FAILED [ 2.499901] sdhci-am654 fa10000.mmc: DEBUG: mmc_rescan_try_freq() trying SD attach [ 2.507478] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator_enable() SUCCESS [ 2.508917] sdhci-am654 fa10000.mmc: DEBUG: mmc_rescan_try_freq() SD attach FAILED [ 2.523551] sdhci-am654 fa10000.mmc: DEBUG: mmc_rescan_try_freq() trying MMC attach [ 2.589796] mmc0: new HS200 MMC card at address 0001 [ 2.595697] mmcblk0: mmc0:0001 EXA 15.0 GiB [ 2.603791] mmcblk0: p1 [ 2.607172] mmcblk0boot0: mmc0:0001 EXA 4.00 MiB [ 2.613838] mmcblk0boot1: mmc0:0001 EXA 4.00 MiB [ 2.620334] mmcblk0rpmb: mmc0:0001 EXA 4.00 MiB, chardev (239:0) [ 2.626720] sdhci-am654 fa10000.mmc: DEBUG: mmc_rescan_try_freq() MMC attach SUCCESS [ 2.634480] sdhci-am654 fa10000.mmc: DEBUG: mmc_rescan() completed, no polling scheduled [ 3.059342] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=1 [ 3.068512] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 3.078776] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator already enabled, skipping enable call [ 3.603296] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_up() completed successfully [ 3.610794] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan() started, rescan_disable=0 [ 3.611300] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit [ 3.618357] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan() proceeding with scan, removable=0 [ 3.625826] sdhci-am654 fa20000.mmc: DEBUG: __sdhci_add_host() completed successfully [ 3.634078] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan() no card detected, starting frequency scan [ 3.641885] sdhci-am654 fa20000.mmc: DEBUG: sdhci_am654_init completed successfully [ 3.650831] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan() trying different frequencies [ 3.658472] sdhci-am654 fa20000.mmc: DEBUG: sdhci_am654_probe completed successfully for fa20000.mmc [ 3.666284] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan() trying frequency 400000 Hz (attempt 0) [ 3.680723] EXT4-fs (mmcblk0p1): warning: mounting fs with errors, running e2fsck is recommended [ 3.684092] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() starting, freq=400000 Hz [ 3.684102] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_up() already powered on, skipping [ 3.684108] sdio_reset: ENTER - starting SDIO reset sequence [ 3.684979] mmc_io_rw_direct_host: Command failed with error -110 [ 3.720914] sdio_reset: Read SDIO_CCCR_ABORT failed with error -110, using default abort=0x08 [ 3.729455] sdio_reset: Writing SDIO_CCCR_ABORT with value=0x08 [ 3.736255] mmc_io_rw_direct_host: Command failed with error -110 [ 3.742385] sdio_reset: EXIT - returning ret=-110 [ 3.747115] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=1 [ 3.756280] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 3.766574] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator already enabled, skipping enable call [ 3.779668] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=1 [ 3.780938] EXT4-fs (mmcblk0p1): mounted filesystem 70efc7c8-e4e4-40fa-9ca3-842cb57eb774 r/w with ordered data mode. Quota mode: none. [ 3.788821] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 3.788838] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator already enabled, skipping enable call [ 3.801025] VFS: Mounted root (ext4 filesystem) on device 179:1. [ 3.813301] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() trying SDIO attach [ 3.821953] devtmpfs: mounted [ 3.827478] sdhci-am654 fa20000.mmc: DEBUG: mmc_attach_sdio() starting [ 3.830829] sdhci-am654 fa20000.mmc: DEBUG: mmc_attach_sdio() mmc_send_io_op_cond FAILED, err=-110 [ 3.837085] Freeing unused kernel memory: 2752K [ 3.838190] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() SDIO attach FAILED [ 3.844810] Run /sbin/init as init process [ 3.853635] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() trying SD attach [ 3.858155] with arguments: [ 3.858158] /sbin/init [ 3.869246] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() SD attach FAILED [ 3.869967] with environment: [ 3.877519] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() trying MMC attach [ 3.885067] HOME=/ [ 3.885071] TERM=linux [ 3.885074] mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) [ 3.892719] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=1 [ 3.901854] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 3.912160] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator already enabled, skipping enable call [ 3.923476] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() MMC attach FAILED [ 3.931190] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() ALL attach methods failed, powering off [ 3.940800] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_off() starting [ 3.947244] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x0, regulator_enabled=1 [ 3.956324] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: disabling regulator (vdd_bit=0) [ 3.965356] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator_disable() SUCCESS [ 3.975310] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_off() completed [ 3.981814] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan() trying frequency 300000 Hz (attempt 1) [ 3.990564] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() starting, freq=300000 Hz [ 3.998880] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_up() starting, ocr=0x300000 [ 4.006411] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=0 [ 4.015579] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 4.025885] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: calling regulator_enable() [ 4.032630] systemd[1]: System time before build time, advancing clock. [ 4.097077] NET: Registered PF_INET6 protocol family [ 4.103474] Segment Routing with IPv6 [ 4.107174] In-situ OAM (IOAM) with IPv6 [ 4.111139] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator_enable() SUCCESS [ 4.141001] systemd[1]: systemd 255.17^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 4.173018] systemd[1]: Detected architecture arm64. [ 4.189197] systemd[1]: Hostname set to <am62xx-lp-evm>. [ 4.432552] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway. [ 4.480052] systemd[1]: Configuration file /usr/lib/systemd/system/seva-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway. [ 4.568935] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 4.661100] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=1 [ 4.670337] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 4.680658] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator already enabled, skipping enable call [ 4.748963] systemd[1]: Queued start job for default target Graphical Interface. [ 4.795103] systemd[1]: Created slice Slice /system/getty. [ 4.814458] systemd[1]: Created slice Slice /system/modprobe. [ 4.834424] systemd[1]: Created slice Slice /system/serial-getty. [ 4.853767] systemd[1]: Created slice User and Session Slice. [ 4.871938] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 4.891808] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 4.911602] systemd[1]: Expecting device /dev/ttyS2... [ 4.923615] systemd[1]: Reached target Path Units. [ 4.935488] systemd[1]: Reached target Remote File Systems. [ 4.951475] systemd[1]: Reached target Slice Units. [ 4.963486] systemd[1]: Reached target Swaps. [ 5.028997] systemd[1]: Listening on RPCbind Server Activation Socket. [ 5.047688] systemd[1]: Reached target RPC Port Mapper. [ 5.072139] systemd[1]: Listening on Process Core Dump Socket. [ 5.092081] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 5.113460] systemd[1]: Listening on Journal Audit Socket. [ 5.132578] systemd[1]: Listening on Journal Socket (/dev/log). [ 5.152533] systemd[1]: Listening on Journal Socket. [ 5.173012] systemd[1]: Listening on Network Service Netlink Socket. [ 5.195242] systemd[1]: Listening on udev Control Socket. [ 5.203349] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_up() completed successfully [ 5.214008] sdio_reset: ENTER - starting SDIO reset sequence [ 5.221183] systemd[1]: Listening on udev Kernel Socket. [ 5.221234] mmc_io_rw_direct_host: Command failed with error -110 [ 5.232610] sdio_reset: Read SDIO_CCCR_ABORT failed with error -110, using default abort=0x08 [ 5.232615] sdio_reset: Writing SDIO_CCCR_ABORT with value=0x08 [ 5.233725] mmc_io_rw_direct_host: Command failed with error -110 [ 5.253123] sdio_reset: EXIT - returning ret=-110 [ 5.257832] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=1 [ 5.272480] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 5.283074] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator already enabled, skipping enable call [ 5.284249] systemd[1]: Listening on User Database Manager Socket. [ 5.296222] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=1 [ 5.308729] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 5.308743] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator already enabled, skipping enable call [ 5.331731] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() trying SDIO attach [ 5.342680] sdhci-am654 fa20000.mmc: DEBUG: mmc_attach_sdio() starting [ 5.354866] sdhci-am654 fa20000.mmc: DEBUG: mmc_attach_sdio() mmc_send_io_op_cond FAILED, err=-110 [ 5.363913] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() SDIO attach FAILED [ 5.371696] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() trying SD attach [ 5.383768] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() SD attach FAILED [ 5.391368] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() trying MMC attach [ 5.399020] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=1 [ 5.408142] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 5.418401] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator already enabled, skipping enable call [ 5.429903] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() MMC attach FAILED [ 5.437555] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() ALL attach methods failed, powering off [ 5.439856] systemd[1]: Mounting Huge Pages File System... [ 5.447164] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_off() starting [ 5.447228] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x0, regulator_enabled=1 [ 5.468090] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: disabling regulator (vdd_bit=0) [ 5.477070] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator_disable() SUCCESS [ 5.486955] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_off() completed [ 5.497242] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan() trying frequency 200000 Hz (attempt 2) [ 5.502893] systemd[1]: Mounting POSIX Message Queue File System... [ 5.505980] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() starting, freq=200000 Hz [ 5.520553] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_up() starting, ocr=0x300000 [ 5.520587] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=0 [ 5.537171] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 5.547432] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: calling regulator_enable() [ 5.556073] systemd[1]: Mounting Kernel Debug File System... [ 5.580211] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing). [ 5.599418] systemd[1]: Mounting Temporary Directory /tmp... [ 5.619740] systemd[1]: Starting Create List of Static Device Nodes... [ 5.635419] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator_enable() SUCCESS [ 5.650754] systemd[1]: Starting Load Kernel Module configfs... [ 5.673950] systemd[1]: Starting Load Kernel Module drm... [ 5.698375] systemd[1]: Starting Load Kernel Module fuse... [ 5.720309] systemd[1]: Starting Start psplash boot splash screen... [ 5.753697] systemd[1]: Starting RPC Bind... [ 5.765007] fuse: init (API version 7.41) [ 5.768986] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/). [ 5.793679] systemd[1]: Starting Journal Service... [ 5.818888] systemd[1]: Starting Load Kernel Modules... [ 5.840652] systemd[1]: Starting Generate network units from Kernel command line... [ 5.877892] systemd[1]: Starting Remount Root and Kernel File Systems... [ 5.909163] systemd[1]: Starting Coldplug All udev Devices... [ 5.917551] systemd-journald[124]: Collecting audit messages is enabled. [ 5.945817] systemd[1]: Started RPC Bind. [ 5.960925] systemd[1]: Mounted Huge Pages File System. [ 5.964390] EXT4-fs (mmcblk0p1): re-mounted 70efc7c8-e4e4-40fa-9ca3-842cb57eb774 r/w. Quota mode: none. [ 5.991868] systemd[1]: Mounted POSIX Message Queue File System. [ 6.012534] systemd[1]: Mounted Kernel Debug File System. [ 6.032711] systemd[1]: Mounted Temporary Directory /tmp. [ 6.053437] systemd[1]: Finished Create List of Static Device Nodes. [ 6.073319] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 6.081580] systemd[1]: Finished Load Kernel Module configfs. [ 6.101388] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 6.109247] systemd[1]: Finished Load Kernel Module drm. [ 6.128320] systemd[1]: Started Journal Service. [ 6.163389] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=1 [ 6.173577] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 6.185855] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator already enabled, skipping enable call [ 6.430021] systemd-journald[124]: Received client request to flush runtime journal. [ 6.707412] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_up() completed successfully [ 6.715004] sdio_reset: ENTER - starting SDIO reset sequence [ 6.720807] mmc_io_rw_direct_host: Command failed with error -110 [ 6.720823] sdio_reset: Read SDIO_CCCR_ABORT failed with error -110, using default abort=0x08 [ 6.720829] sdio_reset: Writing SDIO_CCCR_ABORT with value=0x08 [ 6.726975] mmc_io_rw_direct_host: Command failed with error -110 [ 6.726989] sdio_reset: EXIT - returning ret=-110 [ 6.727002] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=1 [ 6.727011] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 6.727032] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator already enabled, skipping enable call [ 6.747672] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=1 [ 6.747691] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 6.747707] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator already enabled, skipping enable call [ 6.761630] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() trying SDIO attach [ 6.761648] sdhci-am654 fa20000.mmc: DEBUG: mmc_attach_sdio() starting [ 6.776831] sdhci-am654 fa20000.mmc: DEBUG: mmc_attach_sdio() mmc_send_io_op_cond FAILED, err=-110 [ 6.839557] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() SDIO attach FAILED [ 6.847337] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() trying SD attach [ 6.847522] audit: type=1334 audit(1736360579.812:2): prog-id=6 op=LOAD [ 6.861785] audit: type=1334 audit(1736360579.816:3): prog-id=7 op=LOAD [ 6.870675] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() SD attach FAILED [ 6.878345] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() trying MMC attach [ 6.886032] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=1 [ 6.895191] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 6.905505] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator already enabled, skipping enable call [ 6.916404] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() MMC attach FAILED [ 6.929554] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() ALL attach methods failed, powering off [ 6.943214] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_off() starting [ 6.949717] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x0, regulator_enabled=1 [ 6.949736] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: disabling regulator (vdd_bit=0) [ 6.949766] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator_disable() SUCCESS [ 6.951085] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_off() completed [ 6.951104] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan() trying frequency 100000 Hz (attempt 3) [ 6.951112] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() starting, freq=100000 Hz [ 6.951118] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_up() starting, ocr=0x300000 [ 6.951138] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=0 [ 6.951145] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 6.951160] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: calling regulator_enable() [ 7.031414] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator_enable() SUCCESS [ 7.177919] audit: type=1334 audit(1736360580.140:4): prog-id=8 op=LOAD [ 7.184654] audit: type=1334 audit(1736360580.148:5): prog-id=9 op=LOAD [ 7.192156] audit: type=1334 audit(1736360580.156:6): prog-id=10 op=LOAD [ 7.280113] audit: type=1334 audit(1736360580.244:7): prog-id=11 op=LOAD [ 7.307442] audit: type=1334 audit(1736360580.268:8): prog-id=12 op=LOAD [ 7.571515] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=1 [ 7.584072] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 7.599412] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator already enabled, skipping enable call [ 8.078610] audit: type=1334 audit(1753981786.617:9): prog-id=13 op=LOAD [ 8.147549] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_up() completed successfully [ 8.163356] sdio_reset: ENTER - starting SDIO reset sequence [ 8.178600] mmc_io_rw_direct_host: Command failed with error -110 [ 8.191368] sdio_reset: Read SDIO_CCCR_ABORT failed with error -110, using default abort=0x08 [ 8.207378] sdio_reset: Writing SDIO_CCCR_ABORT with value=0x08 [ 8.222567] mmc_io_rw_direct_host: Command failed with error -110 [ 8.235351] sdio_reset: EXIT - returning ret=-110 [ 8.240186] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=1 [ 8.249450] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 8.261034] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator already enabled, skipping enable call [ 8.280331] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=1 [ 8.291403] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 8.301842] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator already enabled, skipping enable call [ 8.316946] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() trying SDIO attach [ 8.327373] sdhci-am654 fa20000.mmc: DEBUG: mmc_attach_sdio() starting [ 8.348354] sdhci-am654 fa20000.mmc: DEBUG: mmc_attach_sdio() mmc_send_io_op_cond FAILED, err=-110 [ 8.363368] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() SDIO attach FAILED [ 8.371317] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() trying SD attach [ 8.396254] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() SD attach FAILED [ 8.407374] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() trying MMC attach [ 8.423146] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x15, regulator_enabled=1 [ 8.436779] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: enabling regulator, voltage=3300000-3400000 uV [ 8.447572] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator already enabled, skipping enable call [ 8.466249] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() MMC attach FAILED [ 8.474058] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan_try_freq() ALL attach methods failed, powering off [ 8.484038] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_off() starting [ 8.495410] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: vdd_bit=0x0, regulator_enabled=1 [ 8.509012] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: disabling regulator (vdd_bit=0) [ 8.518122] sdhci-am654 fa20000.mmc: DEBUG: mmc_regulator_set_ocr: regulator_disable() SUCCESS [ 8.528374] sdhci-am654 fa20000.mmc: DEBUG: mmc_power_off() completed [ 8.534981] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan() FAILED to initialize non-removable card [ 8.535000] mmc2: Failed to initialize a non-removable card [ 8.535007] sdhci-am654 fa20000.mmc: DEBUG: mmc_rescan() completed, no polling scheduled
