Hi TI experts,
We are conducting an experiment on the state switching of the gstreamer pipeline in the following environment:
1、 TDA4VEN EVM
2、10.01 EdgeAI SDK.https://www.ti.com.cn/tool/PROCESSOR-SDK-AM67A
3、HDMI monitor
4、imx219 camera
What we hope to achieve is to initialize the pipeline first, then set the pipeline status to PLAYING, set the pipeline status to READY after a few seconds, and then switch the pipeline status back to PLAYING after a few seconds. When using an imx219->tiovxisp ->tiovxmultiscaler ->kmssink pipeline and switching back from READY state to PLAYING state, the program reports the following error:
APP: Init ... !!! 43.156919 s: MEM: Init ... !!! 43.157022 s: MEM: Initialized DMA HEAP (fd=10) !!! 43.157350 s: MEM: Init ... Done !!! 43.157398 s: IPC: Init ... !!! 43.227239 s: IPC: Init ... Done !!! REMOTE_SERVICE: Init ... !!! REMOTE_SERVICE: Init ... Done !!! 43.239583 s: GTC Frequency = 200 MHz APP: Init ... Done !!! 43.243848 s: VX_ZONE_INFO: Globally Enabled VX_ZONE_ERROR 43.243908 s: VX_ZONE_INFO: Globally Enabled VX_ZONE_WARNING 43.243918 s: VX_ZONE_INFO: Globally Enabled VX_ZONE_INFO 43.245788 s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target MPU-0 43.246050 s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target MPU-1 43.246285 s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target MPU-2 43.246510 s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target MPU-3 43.246538 s: VX_ZONE_INFO: [tivxInitLocal:126] Initialization Done !!! 43.246600 s: VX_ZONE_INFO: Globally Disabled VX_ZONE_INFO 53.459114 s: VX_ZONE_ERROR: [vxGetStatus:1178] Reference is NULL ** (gst_test:1449): CRITICAL **: 17:55:56.763: gst_tiovx_get_size_from_exemplar: assertion 'VX_SUCCESS == vxGetStatus (exemplar)' failed
The phenomenon observed is that the monitor continues to display the last frame of the camera. If you use GST_DEBUG=3 to view the detailed error. The 21st line points out errors related to ISP:
0:00:00.210281570 3083 0x16139670 WARN kmssink gstkmssink.c:2101:_validate_and_set_external_fd:<kmssink0> Can't set fd... driver-name already set. 0:00:00.339272370 3083 0xffff90000b70 WARN v4l2src gstv4l2src.c:987:gst_v4l2src_query:<v4l2src0> Can't give latency since framerate isn't fixated ! 0:00:00.339396670 3083 0xffff90000b70 WARN aggregator gstaggregator.c:2159:gst_aggregator_query_latency_unlocked:<tiovxisp0> Latency query failed 0:00:00.340113440 3083 0xffff90000f70 WARN v4l2 gstv4l2object.c:4666:gst_v4l2_object_get_crop_rect:<v4l2src0:src> VIDIOC_CROPCAP failed 0:00:00.340265730 3083 0xffff90000b70 WARN v4l2src gstv4l2src.c:987:gst_v4l2src_query:<v4l2src0> Can't give latency since framerate isn't fixated ! 0:00:00.340329825 3083 0xffff90000b70 WARN aggregator gstaggregator.c:2159:gst_aggregator_query_latency_unlocked:<tiovxisp0> Latency query failed 0:00:00.342638440 3083 0xffff90000b70 WARN v4l2src gstv4l2src.c:987:gst_v4l2src_query:<v4l2src0> Can't give latency since framerate isn't fixated ! 0:00:00.342719370 3083 0xffff90000f70 WARN v4l2 gstv4l2object.c:4666:gst_v4l2_object_get_crop_rect:<v4l2src0:src> VIDIOC_CROPCAP failed 0:00:00.342742460 3083 0xffff90000b70 WARN aggregator gstaggregator.c:2159:gst_aggregator_query_latency_unlocked:<tiovxisp0> Latency query failed 0:00:00.417617115 3083 0xffff90000f70 WARN v4l2bufferpool gstv4l2bufferpool.c:1334:gst_v4l2_buffer_pool_dqbuf:<v4l2src0:pool0:src> Driver should never set v4l2_buffer.field to ANY 0:00:00.419119580 3083 0xffff90000b70 FIXME basesink gstbasesink.c:3399:gst_base_sink_default_event:<kmssink0> stream-start event without group-id. Consider implementing group-id handling in the upstream elements 0:00:00.448987640 3083 0xffff90000b70 WARN kmsallocator gstkmsallocator.c:526:gst_kms_allocator_dmabuf_import:<KMSMemory::allocator> Failed to close GEM handle: Invalid argument 22 0:00:00.451454290 3083 0xffff90000f70 WARN v4l2 gstv4l2object.c:4666:gst_v4l2_object_get_crop_rect:<v4l2src0:src> VIDIOC_CROPCAP failed 0:00:00.469899205 3083 0xffff90000b70 FIXME aggregator gstaggregator.c:1448:gst_aggregator_aggregate_func:<tiovxisp0> Subclass should call gst_aggregator_selected_samples() from its aggregate implementation. 0:00:00.481082960 3083 0xffff90000b70 WARN kmsallocator gstkmsallocator.c:526:gst_kms_allocator_dmabuf_import:<KMSMemory::allocator> Failed to close GEM handle: Invalid argument 22 0:00:05.345807770 3083 0xffff90000b70 WARN tiovxsimo gsttiovxsimo.c:1385:gst_tiovx_simo_push_buffers:<tiovxmultiscaler0> Error pushing to pad: <tiovxmultiscaler0:src_0> 0:00:10.408638685 3083 0xffff90000b70 WARN v4l2 gstv4l2object.c:4666:gst_v4l2_object_get_crop_rect:<v4l2src0:src> VIDIOC_CROPCAP failed 328.651388 s: VX_ZONE_ERROR: [vxGetStatus:1178] Reference is NULL ** (gst_test:3083): CRITICAL **: 18:00:31.955: gst_tiovx_get_size_from_exemplar: assertion 'VX_SUCCESS == vxGetStatus (exemplar)' failed 0:00:10.411360450 3083 0xffff90001170 ERROR tiovxmiso gsttiovxmiso.c:866:gst_tiovx_miso_propose_allocation:<tiovxisp0> Failed to get size from exemplar 0:00:10.411538560 3083 0xffff90000b70 WARN v4l2 gstv4l2object.c:4666:gst_v4l2_object_get_crop_rect:<v4l2src0:src> VIDIOC_CROPCAP failed 0:00:10.412045970 3083 0xffff90000b70 WARN v4l2 gstv4l2object.c:5471:gst_v4l2_object_decide_allocation:<v4l2src0> error: No downstream pool to import from. 0:00:10.412098380 3083 0xffff90000b70 WARN v4l2 gstv4l2object.c:5471:gst_v4l2_object_decide_allocation:<v4l2src0> error: When importing DMABUF or USERPTR, we need a pool to import from 0:00:10.412254215 3083 0xffff90000b70 WARN basesrc gstbasesrc.c:3354:gst_base_src_prepare_allocation:<v4l2src0> Subclass failed to decide allocation 0:00:10.412346040 3083 0xffff90000b70 WARN basesrc gstbasesrc.c:3134:gst_base_src_loop:<v4l2src0> error: Internal data stream error. 0:00:10.412378110 3083 0xffff90000b70 WARN basesrc gstbasesrc.c:3134:gst_base_src_loop:<v4l2src0> error: streaming stopped, reason not-negotiated (-4) 0:00:10.413021135 3083 0xffff90001170 FIXME basesink gstbasesink.c:3399:gst_base_sink_default_event:<kmssink0> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
If we do not use the imx219 camera and ISP and instead use testsrc, we can successfully switch the pipeline state.
Both gstreamer pipelines are included in the source code of the attachment. The attachment source code we provide can be compiled and run directly on the EVM board through cmake. When input parameter 1, the testsrc pipeline is executed, and when input parameter 2, the imx219 pipeline is executed. This way, TI experts can reproduce the problems we encountered on the EVM board. We want to know if the ISP plugin in the pipeline does not support such state switching.
best regards
yangtian
