PROCESSOR-SDK-AM64X: AM64x GP EVM not booting even after renaming tiboot3.bin file
Part Number: PROCESSOR-SDK-AM64X
We are using prebuilt image from "ti-processor-sdk-linux-am64xx-evm-11.01.05.03" which is "tisdk-default-image-am64xx-evm.rootfs.tar.xz".
SD card is created using create_sdcard.sh and we are keeping the boot mode switches as specified in "AM64x EVM Quick Start Guide".
When we power on the device we are seeing following prints in the console. We are using Sandisk Ultra 16 gb SD card.
We have tried flashing the SD card using Balena etcher and the "tisdk-default-image-am64xx-evm-11.01.05.03.rootfs.wic.xz" and We always observing flash failure.
Following is the error reported when using prebuilt image from SDK flashed using create_sdcard.sh:
U-Boot SPL 2025.01-00527-gd2a72467939e (Jul 01 2025 - 21:23:47 +0000)
Resetting on cold boot to workaround ErrataID:i2331
Please resend tiboot3.bin in case of UART/DFU boot
resetting ...
SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.2--v11.01.02 (Fancy Rat)')
SPL initial stack usage: 13504 bytes
Trying to boot from MMC2
Skipping authentication on GP device
Loading Environment from nowhere... OK
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.13.0(release):v2.13.0-240-gd90bb650fe-dirty
NOTICE:  BL31: Built : 21:37:18, Jun 23 2025
I/TC:
I/TC: OP-TEE version: 4.6.0-dev (gcc version 13.4.0 (GCC)) #1 Fri Apr 25 11:17:53 UTC 2025 aa4
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: Primary CPU initializing
I/TC: GIC redistributor base address not provided
I/TC: Assuming default GIC group status and modifier
I/TC: SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.2--v11.01.02 (Fancy Rat)')
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: HUK Initialized
I/TC: Primary CPU switching to normal world boot
Timed out in wait_for_bb: status=1000
pca953x gpio@22: Error reading output register
Card did not respond to voltage select! : -110
spl: mmc init failed with error: -95
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
Mohan
  • Hi Mohan,
    Could you try with different SD cards to check if it's an issue with this SD card?
    Johnson
  • Hi Johnson,
    Thanks for the reply.
    After couple of retries with different SD cards we were able to move forward but again ran into different issue.
    resetting ...
    I/TC:
    I/TC: OP-TEE version: 4.6.0-dev (gcc version 13.4.0 (GCC)) #1 Fri Apr 25 11:17:53 UTC 2025 aarch64
    I/TC: WARNING: Please check optee.readthedocs.io/.../porting_guidelines.html
    U-Boot 2025.01-00527-gd2a72467939e (Jul 01 2025 - 21:23:47 +0000)
    SoC:   AM64X SR1.0 GP
    Model: Texas Instruments AM642 EVM
    Board: AM64-GPEVM rev B
    DRAM:  2 GiB
    Core:  105 devices, 33 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   eth0: ethernet@8000000port@1, eth2: icssg1-eth-port@0
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    574 bytes read in 1 ms (560.5 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    22323712 bytes read in 877 ms (24.3 MiB/s)
    65547 bytes read in 5 ms (12.5 MiB/s)
    Working FDT set to 88000000
       Loading Device Tree to 000000008feec000, end 000000008fffffff ... OK
    Working FDT set to 8feec000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.12.35-ti-00915-ge3e551586dfa (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.4.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Tue Jul  1 21:17:52 U5
    [    0.000000] KASLR disabled due to lack of seed
    [    0.000000] Machine model: Texas Instruments AM642 EVM
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: legacy bootconsole [ns16550a0] enabled
    [    0.000000] efi: UEFI not found.
    [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a0000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable r5f-memory@a0100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a1000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable r5f-memory@a1100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a2000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a2ffffff (15360 KiB) nomap non-reusable r5f-memory@a2100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000a30fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a3000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a3100000..0x00000000a3ffffff (15360 KiB) nomap non-reusable r5f-memory@a3100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a40fffff (1024 KiB) nomap non-reusable m4f-dma-memory@a4000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a4100000..0x00000000a4ffffff (15360 KiB) nomap non-reusable m4f-memory@a4100000
    [    0.000000] OF: reserved mem: 0x00000000a5000000..0x00000000a57fffff (8192 KiB) nomap non-reusable ipc-memories@a5000000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a57fffff]
    [    0.000000]   node   0: [mem 0x00000000a5800000-0x00000000ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000] cma: Reserved 32 MiB at 0x00000000fba00000 on node -1
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.5
    [    0.000000] percpu: Embedded 22 pages/cpu s51672 r8192 d30248 u90112
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=076c4a2a-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 524288
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [    0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 2MB
    [    0.000000] software IO TLB: area num 2.
    [    0.000000] software IO TLB: mapped [mem 0x00000000fb600000-0x00000000fb800000] (2MB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=2.
    [    0.000000] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=2.
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001840000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080040000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008822] Console: colour dummy device 80x25
    [    0.013441] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.024122] pid_max: default: 32768 minimum: 301
    [    0.028963] LSM: initializing lsm=capability,selinux
    [    0.034111] SELinux:  Initializing.
    [    0.038253] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.045837] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.056797] rcu: Hierarchical SRCU implementation.
    [    0.061777] rcu:     Max phase no-delay instances is 1000.
    [    0.067384] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.076314] EFI services will not be available.
    [    0.081282] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.094954] Detected VIPT I-cache on CPU1
    [    0.095071] GICv3: CPU1: found redistributor 1 region 0:0x0000000001860000
    [    0.095090] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000
    [    0.095150] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.095377] smp: Brought up 1 node, 2 CPUs
    [    0.124766] SMP: Total of 2 processors activated.
    [    0.129577] CPU: All CPU(s) started at EL2
    [    0.133786] CPU features: detected: 32-bit EL0 Support
    [    0.139043] CPU features: detected: CRC32 instructions
    [    0.144345] alternatives: applying system-wide alternatives
    [    0.150788] Memory: 1876864K/2097152K available (12992K kernel code, 1256K rwdata, 4668K rodata, 2752K init, 642K bss, 179548K reserved, 32768K cma-reserved)
    [    0.166615] devtmpfs: initialized
    [    0.181347] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.191360] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.199515] 27136 pages in range for non-PLT usage
    [    0.199542] 518656 pages in range for PLT usage
    [    0.204924] pinctrl core: initialized pinctrl subsystem
    [    0.215620] DMI not present or invalid.
    [    0.222279] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.230171] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.238403] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.247626] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.255866] audit: initializing netlink subsys (disabled)
    [    0.261929] audit: type=2000 audit(0.196:1): state=initialized audit_enabled=0 res=1
    [    0.262602] thermal_sys: Registered thermal governor 'step_wise'
    [    0.269864] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.276088] cpuidle: using governor menu
    [    0.287044] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.294088] ASID allocator initialised with 65536 entries
    [    0.307731] /bus@f4000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f4000/interrupt-controller@1800000
    [    0.332404] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.339384] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.345795] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.352733] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.359140] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.366078] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.372484] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.379422] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.389080] k3-chipinfo 43000014.chipid: Family:AM64X rev:SR1.0 JTAGID[0x0bb3802f] Detected
    [    0.398586] iommu: Default domain type: Translated
    [    0.403551] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.410672] SCSI subsystem initialized
    [    0.415239] usbcore: registered new interface driver usbfs
    [    0.420880] usbcore: registered new interface driver hub
    [    0.426384] usbcore: registered new device driver usb
    [    0.432231] pps_core: LinuxPPS API ver. 1 registered
    [    0.437321] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.446680] PTP clock support registered
    [    0.450732] EDAC MC: Ver: 3.0.0
    [    0.454484] scmi_core: SCMI protocol bus registered
    [    0.460011] FPGA manager framework
    [    0.463652] Advanced Linux Sound Architecture Driver Initialized.
    [    0.471167] vgaarb: loaded
    [    0.474528] clocksource: Switched to clocksource arch_sys_counter
    [    0.481245] VFS: Disk quotas dquot_6.6.0
    [    0.485324] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.501752] NET: Registered PF_INET protocol family
    [    0.507116] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.516783] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.525645] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.533598] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.541828] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.549857] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.556823] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.563806] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.571350] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.577852] RPC: Registered named UNIX socket transport module.
    [    0.583961] RPC: Registered udp transport module.
    [    0.588774] RPC: Registered tcp transport module.
    [    0.593584] RPC: Registered tcp-with-tls transport module.
    [    0.599193] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.605787] NET: Registered PF_XDP protocol family
    [    0.610711] PCI: CLS 0 bytes, default 64
    [    0.616358] Initialise system trusted keyrings
    [    0.621341] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.628442] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.634942] NFS: Registering the id_resolver key type
    [    0.640180] Key type id_resolver registered
    [    0.644463] Key type id_legacy registered
    [    0.648598] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.655455] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.729659] Key type asymmetric registered
    [    0.733890] Asymmetric key parser 'x509' registered
    [    0.738999] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.746866] io scheduler mq-deadline registered
    [    0.751550] io scheduler kyber registered
    [    0.755710] io scheduler bfq registered
    [    0.763648] pinctrl-single 4084000.pinctrl: 33 pins, size 132
    [    0.770162] pinctrl-single f4000.pinctrl: 180 pins, size 720
    [    0.778280] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.792516] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.811133] loop: module loaded
    [    0.815871] megasas: 07.727.03.00-rc1
    [    0.825506] tun: Universal TUN/TAP device driver, 1.6
    [    0.832435] VFIO - User Level meta-driver version: 0.3
    [    0.839471] usbcore: registered new interface driver usb-storage
    [    0.846483] i2c_dev: i2c /dev entries driver
    [    0.852395] sdhci: Secure Digital Host Controller Interface driver
    [    0.858827] sdhci: Copyright(c) Pierre Ossman
    [    0.863600] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.870320] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.878139] usbcore: registered new interface driver usbhid
    [    0.883934] usbhid: USB HID core driver
    [    0.889833] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
    [    0.900317] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.904934] optee: revision 4.6 (71785645fa6ce42d)
    [    0.921769] optee: dynamic shared memory is enabled
    [    0.932853] optee: initialized driver
    [    0.936618] random: crng init done
    [    0.943440] Initializing XFRM netlink socket
    [    0.947935] NET: Registered PF_PACKET protocol family
    [    0.953213] Key type dns_resolver registered
    [    0.968659] registered taskstats version 1
    [    0.973084] Loading compiled-in X.509 certificates
    [    0.994591] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.1.2--v11.01.02 (Fancy Rat)')
    [    1.129813] pca953x 0-0038: supply vcc not found, using dummy regulator
    [    1.136821] pca953x 0-0038: using no AI
    [    1.155498] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.163966] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.170949] pca953x 1-0022: using AI
    [    2.182714] pca953x 1-0022: failed writing register: -16
    [    2.188403] pca953x 1-0022: probe with driver pca953x failed with error -16
    [    2.196223] omap_i2c 20010000.i2c: bus 1 rev0.12 at 400 kHz
    [    2.202494] ti-sci-intr bus@f4000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    2.212034] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    2.225127] ti-udma 485c0100.dma-controller: Number of rings: 68
    [    2.233200] ti-udma 485c0100.dma-controller: Channels: 24 (bchan: 12, tchan: 6, rchan: 6)
    [    2.243713] ti-udma 485c0000.dma-controller: Number of rings: 288
    [    2.261750] ti-udma 485c0000.dma-controller: Channels: 44 (tchan: 29, rchan: 15)
    [    2.273449] printk: legacy console [ttyS2] disabled
    [    2.279215] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 310, base_baud = 3000000) is a 8250
    [    2.288170] printk: legacy console [ttyS2] enabled
    [    2.297878] printk: legacy bootconsole [ns16550a0] disabled
    [    2.315306] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    2.322326] Creating 7 MTD partitions on "fc40000.spi.0":
    [    2.327739] 0x000000000000-0x000000100000 : "ospi.tiboot3"
    [    2.335132] 0x000000100000-0x000000300000 : "ospi.tispl"
    [    2.342108] 0x000000300000-0x000000700000 : "ospi.u-boot"
    [    2.349197] 0x000000700000-0x000000740000 : "ospi.env"
    [    2.356122] 0x000000740000-0x000000780000 : "ospi.env.backup"
    [    2.363679] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    2.370899] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    2.385252] cadence-qspi fc40000.spi: PHY calibration failed: -2
    [    2.392764] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00903, cpsw version 0x6BA80903 Ports: 3 quirks:00000006
    [    2.406634] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    2.446542] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.456585] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    2.464910] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.4
    [    2.472054] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
    [    2.480544] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    2.507471] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 16
    [    2.521917] am65-cpts 39000000.cpts: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    2.532697] mmc0: CQHCI version 5.10
    [    2.552548] clk: Disabling unused clocks
    [    2.575121] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    2.587458] PM: genpd: Disabling unused power domains
    [    2.592662] ALSA device list:
    [    2.595725]   No soundcards found.
    [    2.599597] Waiting for root device PARTUUID=076c4a2a-02...
    [    2.662416] mmc0: Command Queue Engine enabled
    [    2.666934] mmc0: new HS200 MMC card at address 0001
    [    2.673949] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    2.680599] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
    [    2.687118] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
    [    2.693517] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (239:0)
    [   12.612093] platform leds: deferred probe pending: leds-gpio: Failed to get GPIO '/leds/led-0'
    [   12.620833] platform f102000.pcie: deferred probe pending: platform: supplier 1-0022 not ready
    [   12.629466] platform mdio-mux-1: deferred probe pending: mdio-mux-multiplexer: Failed to get mux
    [   12.638259] platform fa00000.mmc: deferred probe pending: platform: supplier regulator-3 not ready
    And the kernel was stuck here. We tried reflashing and changing the kernel image and we were unable to get out of this error.
    Please let us know if there are any known changes which are around this.
    Thank you.
    Mohan.
  • Hi Mohan,
    Thanks for sharing the update. I'm looping in an expert. Please allow him some time to get back to you with a response.
    Johnson
  • Hi Johnson,
    Please note that HS EVM boots perfectly. We are facing issue only with GP EVM that to REV1 with latest SDK even after changing the tiboot3.bin.
    Mohan.
    The GP EVMs are not supported and tested anymore. Is there a reason you are still using the GP EVM?
  • Hi Prashant,
    We have procured one GP EVM couple of years back to get familiar to AM64x and using it for a while and now we are testing Linux on it.
    Any SDK version you suggest where it was supported?
    Mohan.
  • Any SDK version you suggest where it was supported?
    I will have to check. However, if you are just using the EVM for development or testing then you should be able to use the latest SDK by reducing the SD card speed as one of the workarounds mentioned in the following guide:
    https://software-dl.ti.com/processor-sdk-linux/esd/AM64X/11_01_05_03/exports/docs/linux/Foundational_Components/Kernel/Kernel_Drivers/Storage/MMC-SD.html#steps-for-working-around-sd-card-issues-in-linux
    Try "sdhci-caps-mask = <0x00000007 0x00000000>" for SD HS mode in the Kernel DTS.
  • Hi Prashant,
    Thanks for the help. We will check and get back to you in this forum.
    Mohan.
