TDA4VM: Processor SDK RTOS v11.0.0.6 Display settings for both LINUX+RTOS mode in J721E SDK.
Part Number: TDA4VM
Dear All.
I am working J721E EVM and trying to run the TIDL demo but unable to get the display up and running. I have been using edp port with the display monitor.
What will happen if we use prebuilt binaries for vision apps use-cases.  If we run the vision useases with prebuilt binaries does the display enabled by default or any additional settings required?
How to debug on mcu side incase if kernel is already enabled for display on prebuilt binaries.
Thanks and Regards
Firdose
  • /u/somg01/linux/ti-processor-sdk-linux-adas-j721e-evm-11_00_00_08$ sudo ./setup.sh
    TISDK setup script
    This script will set up your development host for SDK development.
    Parts of this script require administrator priviliges (sudo access).
    Verifying Linux host distribution
    Ubuntu 22.04 LTS is being used, continuing..
    Starting with Ubuntu 12.04 serial devices are only accessible by members of the 'dialout' group.
    A user must be apart of this group to have the proper permissions to access a serial device.
    Are you running this script using sudo? The detected username is 'root'.
    Verify and enter your Linux username below
    [ root ]
    User 'root' is already apart of the 'dialout' group
    Do you wish to install required host packages (Press (Y) to run, (n) to skip)? Y
    setup package script
    This script will make sure you have the proper host support packages installed
    This script requires administrator priviliges (sudo access) if packages are to be installed.
    System has required packages!
    System has required python3 packages!
    Package verification and installation successfully completed
    Do you wish to run nfs setup (Press (Y) to run, (n) to skip) ? Y
    In which directory do you want to install the target filesystem?(if this directory does not exist it will be created)
    [ /u/somg01/linux/ti-processor-sdk-linux-adas-j721e-evm-11_00_00_08/targetNFS ]
    This step will extract the target filesystem to /u/somg01/linux/ti-processor-sdk-linux-adas-j721e-evm-11_00_00_08/targetNFS
    Note! This command requires you to have administrator priviliges (sudo access)
    on your host.
    Press return to continue
    Multiple filesystems found.
            1:tisdk-adas-image-j721e-evm.rootfs.tar.xz
            2:tisdk-tiny-image-j721e-evm.rootfs.tar.xz
    Enter Number of rootfs Tarball: [1, 2, ...] 1
    Successfully extracted tisdk-adas-image-j721e-evm.rootfs.tar.xz to /u/somg01/linux/ti-processor-sdk-linux-adas-j721e-evm-11_00_00_08/targetNFS
    This step will set up the SDK to install binaries in to:
        /u/somg01/linux/ti-processor-sdk-linux-adas-j721e-evm-11_00_00_08/targetNFS/home/root/j721e-evm
    The files will be available from /home/root/j721e-evm on the target.
    This setting can be changed later by editing Rules.make and changing the
    ROOTFS_PART variable.
    Rules.make edited successfully..
    This step will export your target filesystem for NFS access.
    on your host.
    Stopping nfs-kernel-server (via systemctl): nfs-kernel-server.service.
    Starting nfs-kernel-server (via systemctl): nfs-kernel-server.service.
    Do you wish to run tftp setup (Press (Y) to run, (n) to skip) ? Y
    Which directory do you want to be your tftp root directory?(if this directory does not exist it will be created for you)
    [ /tftpboot ]
    This step will set up the tftp server in the /tftpboot directory.
    on your host.
    /tftpboot already exists, not creating..
    /tftpboot/*Image-j721e-evm.bin already exists. The existing installed file can be renamed and saved under the new name.
    (r) rename (o) overwrite (s) skip copy
    [r] o
    Successfully overwritten *Image-j721e-evm.bin in tftp root directory /tftpboot
    Successfully copied k3-j721e-beagleboneai64--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtb to tftp root directory /tftpboot
    Successfully copied k3-j721e-beagleboneai64.dtb to tftp root directory /tftpboot
    Successfully copied k3-j721e-beagleboneai64-j721e-evm.dtb to tftp root directory /tftpboot
    Successfully copied k3-j721e-common-proc-board--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtb to tftp root directory /tftpboot
    Successfully copied k3-j721e-common-proc-board.dtb to tftp root directory /tftpboot
    Successfully copied k3-j721e-common-proc-board-j721e-evm.dtb to tftp root directory /tftpboot
    Successfully copied k3-j721e-sk--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtb to tftp root directory /tftpboot
    Successfully copied k3-j721e-sk.dtb to tftp root directory /tftpboot
    Successfully copied k3-j721e-sk-j721e-evm.dtb to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-cm-0-0--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-cm-0-0.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-cm-0-0-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-cm-0-1--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-cm-0-1.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-cm-0-1-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-0-0--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-0-0.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-0-0-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-0-1--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-0-1.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-0-1-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-0-2--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-0-2.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-0-2-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-0-3--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-0-3.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-0-3-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-1-0--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-1-0.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-1-0-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-1-1--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-1-1.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-1-1-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-1-2--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-1-2.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-1-2-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-1-3--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-1-3.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-1-3-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-2-0--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-2-0.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-2-0-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-2-1--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-2-1.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-2-1-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-2-2--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-2-2.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-2-2-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-2-3--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-2-3.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx390-rcm-2-3-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx728-rcm-0-0--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx728-rcm-0-0.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-imx728-rcm-0-0-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-ov2312-0-0--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-ov2312-0-0.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-ov2312-0-0-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-ov2312-0-1--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-ov2312-0-1.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-ov2312-0-1-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-ov2312-0-2--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-ov2312-0-2.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-ov2312-0-2-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-ov2312-0-3--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-ov2312-0-3.dtbo to tftp root directory /tftpboot
    Successfully copied k3-fpdlink-ov2312-0-3-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j7200-evm-mcspi-loopback--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j7200-evm-mcspi-loopback.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j7200-evm-mcspi-loopback-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-beagleboneai64-dsi-rpi-7inch-panel--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-beagleboneai64-dsi-rpi-7inch-panel.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-beagleboneai64-dsi-rpi-7inch-panel-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-beagleboneai64-microtips-mf070zima-lcd3--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-beagleboneai64-microtips-mf070zima-lcd3.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-beagleboneai64-microtips-mf070zima-lcd3-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-common-proc-board-infotainment--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-common-proc-board-infotainment.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-common-proc-board-infotainment-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-edgeai-apps--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-edgeai-apps.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-edgeai-apps-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-csi2-ov5640--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-csi2-ov5640.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-csi2-ov5640-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-ethfw--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-ethfw.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-ethfw-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-fusion--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-fusion.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-fusion-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-gesi-exp-board--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-gesi-exp-board.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-gesi-exp-board-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-pcie0-ep--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-pcie0-ep.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-pcie0-ep-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-pcie1-ep--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-pcie1-ep.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-pcie1-ep-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-pcie-ntb--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-pcie-ntb.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-pcie-ntb-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-quad-port-eth-exp--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-quad-port-eth-exp.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-quad-port-eth-exp-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-ub954--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-ub954.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-evm-ub954-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-sk-csi2-dual-imx219--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-sk-csi2-dual-imx219.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-sk-csi2-dual-imx219-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-sk-csi2-ov5640--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-sk-csi2-ov5640.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-sk-csi2-ov5640-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-sk-fpdlink-fusion--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-sk-fpdlink-fusion.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-sk-fpdlink-fusion-j721e-evm.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-vision-apps--6.12.17+git3+cdcaeac783-r0_tisdk_5_edgeai_0_edgeai_8.6-j721e-evm-20250515080953.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-vision-apps.dtbo to tftp root directory /tftpboot
    Successfully copied k3-j721e-vision-apps-j721e-evm.dtbo to tftp root directory /tftpboot
    /etc/xinetd.d/tftp already exists..
    /tftpboot already exported for TFTP, skipping..
    Restarting tftp server
    Stopping xinetd (via systemctl): xinetd.service.
    Starting xinetd (via systemctl): xinetd.service.
    Do you wish to run minicom setup (Press (Y) to run, (n) to skip) ? y
    This step will set up minicom (serial communication application) for
    SDK development
    For boards that contain a USB-to-Serial converter on the board such as:
    	* BeagleBone
    	* Beaglebone Black
    	* AM335x EVM-SK
    	* AM57xx EVM
    	* K2H, K2L, and K2E EVMs
    the port used for minicom will be automatically detected. By default Ubuntu
    will not recognize this device. Setup will add a udev rule to
    /etc/udev/ so that from now on it will be recognized as soon as the board is
    plugged in.
    For other boards, the serial will defualt to /dev/ttyUSB0. Please update based
    on your setup.
    NOTE: If your using any of the above boards simply hit enter
    and the correct port will be determined automatically at a
    later step.  For all other boards select the serial port
    that the board is connected to.
    Which serial port do you want to use with minicom?
    [ /dev/ttyUSB0 ]
    Copied existing /root/.minirc.dfl to /root/.minirc.dfl.old
    Configuration saved to /root/.minirc.dfl. You can change it further from inside
    minicom, see the Software Development Guide for more information.
    Do you wish to run uboot setup (Press (Y) to run, (n) to skip) ? Y
    This step will set up the u-boot variables for booting the EVM.
    Autodetected the following ip address of your host, correct it if necessary
    [ 10.1.138.235 ]
    Select Linux kernel location:
     1: TFTP
     2: SD card
    [ 1 ] 1
    Select root file system location:
     1: NFS
     2: SD card
    [ 1 ] 1
    Available kernel images in /tftpboot:
        Image-j721e-evm.bin
        *Image-j721e-evm.bin.07142025_11.40
        ti
    Which kernel image do you want to boot from TFTP?
    [ Image-j721e-evm.bin ]
    Successfully wrote minicom script with above parameters: /u/somg01/linux/ti-processor-sdk-linux-adas-j721e-evm-11_00_00_08/bin/setupBoard.minicom
    Would you like to run the minicom script and boot the board? (y/n)?
    [ y ]
    Board could not be detected. Please connect the board to the PC.
    Press any key to try checking again.
    I have attached the setup logs as well.
  • Firdose,
    Yes, display is enabled in this case.
    You can use CCS + JTAG.
    Brijesh
