AM625: AM62x Secure Boot Stuck at "Starting Keywriting" — VPP Hardware Toggle Issue
Part Number: AM625
Hello TI Support Team,
I am implementing secure boot on a custom AM62x-based board using dummy keys (HS‑FS variant) based on TI’s AM62x secure boot guide. I have followed all documentation steps, including:
  • Generating tiboot3.bin (with embedded certificate) via gen_keywr_cert.sh.
  • Flashing the OTP keywriter/SBL (tiboot3.bin) via DFU as described in the official guide.
  • Monitoring UART output during secure key provisioning.
    Upon flashing, the console output halts at:
    However, it never proceeds to:
    Starting Keywriting
    Enabled VPP
    keys Certificate found: ...
    Keywriter Debug Response: 0x0
    Success Programming Keys
    My Question:
    1) Is the hardware-level presence and assertion of the 1.8 V VPP rail on MSP_8 strictly required, even when using dummy keys, for the secure boot keywriting process to proceed? Or is there any software-based mechanism or alternative configuration that allows keywriting to continue without hardware VPP?
    Kapil
    The 1.8V VPP is a must for programming anything to OTP. Once you have taken care of this on your custom board, you should be able to run the keywriter successfully.
  • Hello Prashant,
    Thank you for your quick and helpful response regarding the “Starting Keywriting” behavior.
    I have applied the advice, enabled the VPP rail correctly (reading 1.8 V externally), and modified the software to reflect that change. Now, the R5 UART console log proceeds as follows:
    Starting Keywriting
    Enabled VPP
    keys Certificate found: 0x43c16800
    Keywriter Debug Response: 0x20
    Error occured
    From TI documentation (and the TISCI error codes), I understand that 0x20 corresponds to KEYWR_ERR_INTERNAL_OP — an internal operation error.
    Clarification Requested:
    • Whether Debug Response: 0x20 is definitively linked to a certificate validation failure, such as SMPK mismatch or an unsupported MSV?
    • Is the correct remedy to regenerate the certificate without MSV, and avoid MSV flags when calling gen_keywr_cert.sh (i.e. only include SMPK and SMEK)?
    • Are there additional steps or checks (e.g. OpenSSL version requirements, specific SDK version, platform compatibility) you recommend to resolve this error?
    Kapil
  • From TI documentation (and the TISCI error codes), I understand that 0x20 corresponds to KEYWR_ERR_INTERNAL_OP — an internal operation error.
    This error is mostly tied to the OpenSSL version. Please make sure you are using the OpenSSL v1.1.x as mentioned in the OTP Keywriter user guide.
  • Hii Prashant,
    Thank you for confirming the OpenSSL version requirement. We have switched to OpenSSL 1.1.1q and rebuilt the bootloader, but the R5 console still reports:
    Starting Keywriting
    Enabled VPP
    Error occured
    We have:
    - Generated the certificate using only SMPK/SMEK/BMPK/BMEK (no MSV, no OTP extension).
    - Verified hardware VPP is stable at 1.8 V.
    Could you please confirm:
    1. Does `0x20` definitively indicate SMPK/BMPK mismatch or other certificate field validation failures?
    2. Is certificate size itself (e.g. too large) a common cause of failures within OTP validation?
    3. Would it help to enable the M4/TIFS UART trace for debugging?
    4. Any known dummy-key workflows that cause 0x20 despite correct OpenSSL usage?
  • 3. Would it help to enable the M4/TIFS UART trace for debugging?
    Please share these TIFS logs captured from the MAIN_UART1 port. It should provide additional insights.
    On another note, have you really confirmed the VPP is at 1.8V?
  • Hii Prashant,
    As requested, I am ready to share the TIFS logs from the Cortex‑M4 MAIN_UART1 port, but I need assistance identifying how to capture them correctly.
    R5 UART Console Output:
    port is : /dev/ttyUSB0
    flowcontrol : none
    baudrate is : 115200
    parity is : none
    databits are : 8
    stopbits are : 1
    escape is : C-a
    local echo is : no
    noinit is : no
    noreset is : yes
    hangup is : no
    nolock is : yes
    send_cmd is : sz -vv
    receive_cmd is : rz -vv -E
    imap is :
    omap is :
    emap is : crcrlf,delbs,
    logfile is : none
    initstring : none
    exit_after is : not set
    exit is : no
    Type [C-a] [C-h] to see available commands
    Terminal ready
    Starting Keywriting
    Enabled VPP
    keys Certificate found: 0x43c15e00
    Keywriter Debug Response:0x20
    Error occured...
    I've verified that VPP is stable at 1.8 V via external source during keywriting.
    my question is How to Capture this UART M4 logs ? pls assist regarding that !!
    Once I can capture both UART outputs during the keywriting flow, I’ll share the complete logs in a combined text file for your review.
    Thank you for your continued support!
    regards,
    Kapli
    The TIFS logs are by default enabled. So, simply connect to all the four UART ports and the TIFS logs should come on one of them.
    The sample logs are shown here:
    dev.ti.com/.../node
  • 2. If MAIN_UART1 is not available externally, is there an alternative method to obtain TIFS logs (e.g. via SYSFW log buffers or JTAG)?
    The following resopnse has a function that can be used to dump the logs read from the memory buffer:
    e2e.ti.com/.../5766734
  • Hello ,
    Thank you for confirming that TIFS logs are enabled by default and accessible via MAIN_UART1.
    While I currently have only UART0 connected (R5 console), I need guidance on using UART1 for capturing the M4/TIFS logs on our custom board.
    To finalize our debug setup, could you please clarify the following?
    • Is MAIN_UART1 a SoC-level UART port used by the TIFS firmware?
    • Which physical pins or connectors (for example, E19/A20 as indicated in reference DTS patches) should be wired to get UART1 output?
    • Is any additional configuration required in the device tree or bootloader (e.g., enabling pinmux, status flags) to enable and receive logs from UART1?
    Once I connect our FTDI adapter correctly and configure UART1 if needed, I should be able to capture the detailed M4 debug trace.
  • As I conveyed in my previous response, you may not need the MAIN_UART1 for capturing the TIFS traces. These can be captured from the memory buffer as well which is sufficient in the context of the keywriter.
  •  I have captured the TIFS logs
    I have attached the trace log file for your review
    --TIFS_LOGS--
    0x4F8A0000
              0x4F8B0000
                        0x4F80001C
                                  0x4003007
                                           0x4400907
                                                    0x20800000
                                                              0x20800001
        0x4F8A00FF
        0x4F8B0001
        0x4F80001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
                  0x4C40001C
                            0x4C40001C
                                      0x4C40001C
                                                0x4C40001C
                                                          0x4C40001C
        0x4C40001C
        0x420021
        0x820024
        0x42000C
        0x820024
        0x4F8A00FF
        0x4F8B0001
        0x4
    Please let me know what the internal validation trace reveals and if there are any next steps to resolve the OTP keywriter internal error.
    These logs do not contain anything. The logs should look like the sample logs I shared previously.
    At which point in the code are you calling the function to dump the TIFS logs? Have you made sure the logs are captured correctly and not truncated?
    Can you shared your keywriter certificate generation command logs as well?
    Thanks!
    I’ve noticed that the logs here differ from the sample logs provided in the thread you shared previously. I have no additional output besides what’s shown above.
    Also inside main.c i add that function and inside main i m calling that function.
    Below is the certificate generation command I used and the full log output from the terminal:
    ti/mcu_plus_sdk_am62x_09_02_01_06/source/security/sbl_keywriter/scripts/cert_gen/am62x$
    ./gen_keywr_cert.sh -t tifek/ti_fek_public.pem --msv 0xC0FFE -b-def --bmek-def -s-def --smek-def --keycnt 2 --keyrev 1
    # Using MSV[19:0]: 0x000C0FFE
    INFO: Using default BMPK for programming
    INFO: Using default BMEK for programming
    INFO: Using default SMPK for programming
    INFO: Using default SMEK for programming
    # Using Key Count: 0x00000003
    # Using Key Rev: 0x00000001
    Generating Dual signed certificate!!
    GEN: AES256 key generated, since not provided
    # encrypt aes256 key with tifek public part
    The command rsautl was deprecated in version 3.0. Use 'pkeyutl' instead.
    # encrypt SMPK-priv signed aes256 key(hash) with tifek public part
    # encrypt smpk-pub hash using aes256 key
    writing RSA key
    # encrypt smek (sym key) using aes256 key
    # encrypt BMPK-priv signed aes256 key(hash) with tifek public part
    # encrypt bmpk-pub hash using aes256 key
    writing RSA key
    # encrypt bmek (sym key) using aes256 key
    1701	secondary_cert.bin
    5414	primary_cert.bin
    7115	../../x509cert/final_certificate.bin
    # SHA512 Hashes of keys are stored in verify_hash.csv for reference..
  • I should have asked for these command logs earlier only. I just assumed there should be no issue if you are actually using the OpenSSL v1.1.x
    This is the issue. The primary certificate size here is more than 5400 bytes which is not acceptable. From the logs, it seems you are actually using OpenSSL v3 not the v1.1.x
    Please use the correct OpenSSL version as mentioned previously.
  • Hello Prashant,
    Thank you for pointing out the OpenSSL 1.1, actually my  certificate generation path is using openssl v3.0 now i change it to 1.1
    this  is the certificate generation full log output from the terminal
    writing RSA key
    writing RSA key
    1668	secondary_cert.bin
    5383	primary_cert.bin
    7051	../../x509cert/final_certificate.bin
  • It still isn't working? If not, please share where exactly you added the function call to dump the TIFS logs.
    I ran the certificate generation with the following console log:
    This confirms that the certificate includes the MSV.
    For development purposes using dummy keys,
    As you can see, MSV is indeed being included  in this certificate. Since this may cause issues if MSV was already fused previously, please advise whether I should:
    • override the MSV value, or
    • Exclude the MSV flag entirely and focus only on key fields (SMPK/BMPK, key count, key revision)
    I can rebuild accordingly once confirmed.
  • Inside main.c file i've added dump_tifs_logs funtion and call that funtion inside int main ()
    keywriter_processKeyConfig();
    dump_tifs_logs();  ("here i call that function")
    Drivers_close();
    System_deinit();
    still got the same TIFS logs as previously uploaded for your review.
    Could you please make sure the UART logs are not truncated by the console, maybe minicom, you are using?
    Please share the full logs as well not just the TIFS logs.
    Thanks!
    Is this funtion call placed correctly? pls confirmed.
    I attempted to capture the full UART logs using picocom with logging enabled (picocom -b 115200 /dev/ttyUSB0 | tee full_uart_log.txt) .
    However, the generated log file is only around 600 bytes in size. It appears that either the logs are getting truncated or the early boot output is not being captured correctly.
    would you recommend switching to another UART tool (e.g., minicom or Tera Term) or using a serial logger to ensure complete capture?
    Please advise on how to best proceed to obtain the full logs you need.
  • Teraterm should be okay. Otherwise, this is a general issue. Please browse the internet on how to disable line wrapping in the tool you are using for capturing the UART logs.
  • Hi ,
    As per your suggestion, we have confirmed that line wrapping is disabled in the UART logging tool (we’re using picocom on Ubuntu in a VM). Despite this, we are still unable to capture the full TIFS logs. The logs appear truncated or stop shortly after minimal output (e.g., some hex values or an early error message like Keywriter Debug Response: 0x20).
    Any suggestions on how to proceed with getting the complete TIFS logs would be appreciated.
    Please apply the following patch and try again
    diff --git a/source/security/sbl_keywriter/am62x-sk/r5fss0-0_nortos/example.syscfg b/source/security/sbl_keywriter/am62x-sk/r5fss0-0_nortos/example.syscfg
    index c45c9bcbf..e04031b52 100644
    --- a/source/security/sbl_keywriter/am62x-sk/r5fss0-0_nortos/example.syscfg
    +++ b/source/security/sbl_keywriter/am62x-sk/r5fss0-0_nortos/example.syscfg
    @@ -38,6 +38,7 @@ debug_log.enableLogZoneInfo                  = true;
     debug_log.enableCssLog                       = false;
     debug_log.uartLog.$name                      = "CONFIG_UART0";
     debug_log.uartLog.useWakeupDomainPeripherals = false;
    +debug_log.uartLog.intrEnable                 = "DISABLE";
     debug_log.uartLog.UART.$assign               = "USART0";
    As per your suggestion, we added that patch and tried here is the response we get,
    also the function call we add in main.c [dump_tifs_logs()] if i call that function before  [keywriter_processKeyConfig();] then only i can see this log if i call that function after that on any line then only i can see the R5 logs
    Starting Keywriting
    Enabled VPP
    --TIFS_LOGS--
    0x4F8A0000
              0x4F8B0000
                        0x4F80001C
                                  0x4003007
                                           0x4400907
                                                    0x20800000
                                                              0x20800001
        0x4F8A00FF
        0x4F8B0001
        0x4F80001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C4C
        C
        C
        C
        C
        C
        C
        C
        1
        4
        C
        4
        F
        1
        C
        2
        4
        7
        7
    --TIFS_LOGS--
    keys Certificate found: 0x43c15e80
    Error occured...
  • Please call the function here:
    diff --git a/sbl_keywriter/am62x-sk/r5fss0-0_nortos/keywriter_utils.c b/sbl_keywriter/am62x-sk/r5fss0-0_nortos/keywriter_utils.c
    index 6f61ade..a94f7f7 100644
    --- a/sbl_keywriter/am62x-sk/r5fss0-0_nortos/keywriter_utils.c
    +++ b/sbl_keywriter/am62x-sk/r5fss0-0_nortos/keywriter_utils.c
    @@ -66,6 +66,7 @@ void keywriter_processKeyConfig()
         status = Sciclient_service(&reqParam, &respParam);
     	DebugP_log("Keywriter Debug Response:0x%x \r\n", (uint32_t) response.debug_response);
    +	dump_tifs_logs();
     	if (( status == SystemP_SUCCESS ) && ( response.debug_response == 0x0U ))
    The error is trapping the execution in infinite loop (DebugP_assertNoLog).
  • Hii,
    After calling that function, we got this output
    Starting Keywriting
    Enabled VPP
    --TIFS_LOGS--
    0x4F8A0000
              0x4F8B0000
                        0x4F80001C
                                  0x4003007
                                           0x4400907
                                                    0x20800000
                                                              0x20800001
        0x4F8A00FF
        0x4F8B0001
        0x4F80001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C4C
        C
        C
        C
        C
        C
        C
        C
        1
        4
        C
        4
        F
        1
        C
        2
        4
        7
        7
    --TIFS_LOGS--
    --TIFS_LOGS--
    0x4F8A0000
              0x4F8B0000
                        0x4F80001C
                                  0x4003007
                                           0x4400907
                                                    0x20800000
                                                              0x20800001
        0x4F8A00FF
        0x4F8B0001
        0x4F80001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C40001C
        0x4C4C
        C
        C
        C
        C
        C
        C
        C
        1
        4
        C
        4
        F
        1
        C
        2
        4
        7
        7
        1
        3
        1
        2
        r
        0
        r
        0
    --TIFS_LOGS--
    Error occured...
  • I don't think you have the correct UART console settings. The output seems truncated or something. Maybe use Teraterm on the Windows host machine itself. Otherwise, simply use the CCS to save the memory buffer.
  • We use Teraterm on windows, this are logs we get
    Starting Keywriting
    Enabled VPP
    --TIFS_LOGS--
    0x4F8A0000
    0x4F8B0000
    0x4F80001C
    0x4003007
    0x4400907
    0x20800000
    0x20800001
    0x4F8A00FF
    0x4F8B0001
    0x4F80001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x420021
    0x820024
    0x42000C
    0x820024
    0x4F8A00FF
    0x4F8B0001
    0x4F80001C
    0x420002
    0x820024
    0x4003007
    0x4400907
    --TIFS_LOGS--
    --TIFS_LOGS--
    0x4F8A0000
    0x4F8B0000
    0x4F80001C
    0x4003007
    0x4400907
    0x20800000
    0x20800001
    0x4F8A00FF
    0x4F8B0001
    0x4F80001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x4C40001C
    0x420021
    0x820024
    0x42000C
    0x820024
    0x4F8A00FF
    0x4F8B0001
    0x4F80001C
    0x420002
    0x820024
    0x4003007
    0x4400907
    0x409031
    0x800023
    0x20C00001
    0x20C00002
    Internal Operation Error
    debug_response:  0x20
    --TIFS_LOGS--
    Error occured...
  • What is the Keywriter and SDK version you are using? If you are using Keywriter v9.0, please note it must be used with SDK v9.0 only.
  • we are using MCU+SDK am62x_09_02_01_06 and processor_SDK_linux-am62xx-evm-09.02.01.10
    Just to confirm :- it mandatory that tispl.bin and u-boot.img be built and signed using the same SDK version and key set as tiboot3.bin?
    Can these binaries be taken from another machine or SDK or is version alignment strictly required?
    I’m writing to follow up on my earlier question, To move forward with testing and validation, I’d appreciate your confirmation on the  following point:
    •  it mandatory that tispl.bin and u-boot.img be built and signed using the same SDK version and key set as tiboot3.bin?
    This clarification will help determine whether the current issue we're seeing (Keywriter Debug Response: 0x20) is due to version mismatch or Anyother.
    Please let me know at your earliest convenience. If any further details are needed, I’d be happy to provide them.
    It is required only for the keywriter. You may use any SDK versions for your application development.
    It is unlikely the SDK version mismatch causing the issue you are seeing but just in case it is better to use the SDK version mentioned in the keywriter user guide.
    I am still highly suspecting the issue is very much related to the VPP only on your custom board.
    Please try out the expected SDK version once. If it still doesn't work, please share how you confirm the VPP is really at 1.8V on your custom board.
    Thanks!
    Thanks for the update. Regarding your note on VPP:
    I’ve re-verified the VPP rail on our custom board. We have a test point(VP) at the SoC’s VPP pin, and we are supplying external 1.8V directly to that TP. The voltage we get on TP is 1.79V/1.8V and has been confirmed with a multimeter while the process is running.
    Looking forward to your guidance.
  • Can you please share the generated certificate (final_certificate.bin) once?
  • 0��0���n���0�Bb�S� ���w�0
    	*�H��
     0��10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    "dqhGYAQ2Y4gFfCq0t1yABCYxex9eAxt71f10Ua87RB35W10Ux0FSqGTPWbGpuiV110/	*�H��
    	"kFp5uGcgWXxcfxi@vsHs9C9qQWGrBs.com0
    250806092450Z
    250905092450Z0��10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    	"kFp5uGcgWXxcfxi@vsHs9C9qQWGrBs.com0�"0
    	*�H��
     � 0�
    � �b��F�86�ሗJ��>�ok��ە)x#������9��ChPk,�C�o7!$xE���-���<�!W.�P��ǣE�:_�3���8��0����<�A��)I��s�'���  L���%����Ϻ5��
    8��n��_�M��S[y��5�"�,YVA�_��Oh�6���.�뀏��\$�,�b)\�H��eXș�����ma~�z��6[��%φw�!���=��B��s@g���25ʗ�?"�h�
    n�����g��c
    �Z~r�6�̌".�g�p����R��4��_��
    �i=��,���J�^���Q��<0��&�#�,���Sj�P��p�u
    ��Uf�Q�=g�8^��7`�T�NQ����RE���pq�xy��I� !�����F�<	5�{���0�8�)"�M�����m��d`�WS�D��e������8�Y�`j���8# �
    �FQ���T=R`t%P���S�-P-�"����]���lf���Я�k��� ���0��0U0�0`	+�&"S0Q	`�He@��T"p������tg�S�y��d�bg����\I��⁎�n�~J����'�-J��%�-h&0U�Ȳ:}[�����-Y�W0
    	*�H��
     �  ����^�RU
    rq{=����J��̓ H\�̐y,���;�� �
    8�95,t�p��s�} (u��n��_M?,�5ݻ���;�V�_�����mR�u&C-N2�ܝ���(�%��2o]G�0�]��/C��7��jaLW�3Wj2��I6�?ȫ|��J�2����ܷ�����i�v���zq0,��k������l	A��t� i�
    F�
    ƕ���]�G�#΄��/�֥x.�.�0�O�{������^���2:�#Q����W��8j�O�Z@(T^��=�S��y��lj��j_�H�y#+,���$�-D8��v������OW��UǗe�>EW���A�k3�
     3��e�T�H��i�B�@C����f7�,����HGxk�"r�sϵ�7����kz�4��b�`� '�a��;W��iX�,��UϜTK����#M�0t�Yo<뽀
    z�?zz+PV	�{r1�d��m'����O�A���v`�.�`Y���y�&S���aW ���0�"0�
    ��NY�J�O>�� R}�ݬFu0
    	*�H��
     0��10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    250806092450Z
    gQE843yQV0sag1+0)U
    	*�H��
     � 0�
    � ��I�r�k#��He�"M�O������|��nY�������ҕ������P��H�"P�L{��
    (&����UA�>['l���q�/r"�F%b�>����,�n�>妠�EAN�tքN�y����%���ѹ�h�3YK�}w�ќ�#��X������,u-�b��	n�p� 	�b����lmȂ P������_�ОϓT�_�]�7`��{e���EE|K�[�NƔ=�N�Ҕ<�����6|�
    �ZB7�*��n��g�� �sJh(1�������E~����;ǃ�!q��8�R�3��6�N��)�͛*�l_{��:y j}����X*�^�N��;O����4�� �Y-�^h�L���-v�X�P�7nfxo�0FM4��J���{Ů�2��l?��35�M��n`TP�~m���� ���+�7�Y�J�E�	��r3�^]�Z�!T����U�'�M	�@�.f�e�n��8N�a�t��_Q�B�����K�i��� ��0�0U0�0�	+�&@�0�� @/�l�V�Z�$��x�lV���Ϣy�FK��_R#�Z'����6�?���$�����p.�8�[��z�n6�vgJ���:B
    ���ߓ���| �s��dG�����y��X�Dd�[��mT���>�ŅNt,ǩ���
    �`~5i�P�Q��k�m{:<��ȶF �G�{E��pc���µ�6�<_�������9�Y��]�*��7��)���+Wj�~#I�3��H�*�y�����i�[�+YӛG�}|�X�νr�k���{�� �L�G���K�t���u�NqM�vx�:e�ӿ$&�ȑ�)� �v0�)�]���R��F��i���=�ꑃ:��w� �̚���w>��G��浦�8�rh�) qsk(�#>{�A�}����yP�Mp�I�%��;ɘ�:T��;2�\&��w� Y��|^�5kA/~QM� L�	���.,���L���η޷x�໽^�Ҍ��j�]�lL��U��+a��z�aE��!<�V �O��9�Ce 0�	+�&A�0�� 5B�WZ�q���>� �t��ty!K9�X����Yf\2.��ݢd�wP��>
    KY�ހ�z����i"(o���P�
    �vt/��,��!��j�� \�K��)0S�4��CAW��Vm~g��݅yd,e�-@��.��C�R"��+��V���Ls~��T���^'6	�`{�@���6K��a�������I&:A�iv�W�G���	�R)�9�����ͧ����b�4fUW�q�O�9�n'�L#s�Dia#�HA��<̔�Cg��{ğ�p��њ[�=��y�܋yxjM�|@�-8(�P�~ZE*VV�G-u1��U�
    ��1�Cތ�9c��ФFJBN@����UG��r�H:(�qB�z�B�lr�Ӑ�^_*���F��%kb���	1�Z��iR$k]��:XJ�ځ��N���ffHܺn�m*��������f�_@M�t�����������A>g�pq�� �����v9��&B���y��R��ڔJw��B��0�7���̺�Z�7�a�g	�L1�y��;�����$e�+�҂�!U�՗dqS�!��4����
    uut�9��M V��"�=�p����������!eo�[<-]��;�:�y6�'<�g��Z~�t��z�PI���)��$ �^9M��?�!��N\��X��~~�����f��Q�C�_"b�((4\�Ua	��������F��? �Y
    Ԇ����脨P'-||�x�`��Sb�A�ˇF��7+Q�[=&�7$a�x=tA �M��{��)n}������߃%
    &���OCB���<
    ��D���+��N��97�{ܗJ4li� �}�^	���ֶOż�QK�WC�g5A�Iȗ�7'
    �R`�5ͮ_�I��woI���|��B��3�A��PTZD ��\�<#?�̺L��G�@��熞���Q�:�f��d
    �7��6��7���A�dpg�/8�%�Õr�x�����6�O��&�¬�?��8j\�e��J�� 0�	+�&B�0�� q}�-Un���Ie:��7u�ܮ{�%��8=>��vP�p�#m`ݟ������
    �����p̎��Y�:"^��BN�;9����I�띴kN�i�g {sc�߶X�A�M>	��$M�RIT����a��U-��8�pS&G�4�-�Wz1f��ݰ?Uۀv?b1�>R)�`�|=���dŠ`3g;���:�"�E�_z\WcN�F���K���g.
    �m�����E(٦l�O�����ιxh�(��ou�X��P�#H��v0�!�~u�1����C�O�	��i�*r��������0�HQ=�ͱkdk�w�&+�d�I�\��>��pf"�����ٿ����a��1PV	hQ��A���Z	%Ƭ��8"r�ԄL��'�� �B�f��,W�Cs��;����—�K|{Z[�1�`��`ڻ�?[��M�@SƖܜ�-���������H�n�^�uuL��Q��pR�aBh���Y`
    �]rخșd� ��a.����ZO�%.���/iP��os�-�O������OF�����{�3�X��2���G�
    %|��h�N!�����y'}I~WV�,v��߭�v~޳�I2?l|/�-�k2|Sf������e��|��E�Q��" �F�s�K9�ki*�<�.��~KA��b�s���:�y�����$t�����#�g���*R�{f�ƛ0�g7|ǁuŶ��ݰz ��4g� ���,N�4`�f}�A���ӵdL{#�h[7	^D���&���6X���p(����3D$�]S�����nf}�>
    {�+��H�}� 6�ba��X����t� y_��KnV�!��>tK��Vѯ��h���6����P�/^�O�CV��s�\�o��u��S6��5�ĔQd
    ő��) 	��gT�M[@	<���߀lX}���D�T:��˚Ȣ<� �%�߹�����E���S�ǯ�;Mq�������WՑ�T�4rke{��ϻW�=k�O�?Ek�r�\��!��X�����@U0k�3�Yy�9X�z( 0��	+�&C��0��`�i��@1��(�n䢘G�:�����[�邏W��3�t��d���O�k�z�0p/��]"��ύI5ޅ���ѿ���}w�|�0���L&U<Ҫ�S���ǎ���� @ ڬ0[���M{��4�_�����1~�֢]R` ���Z0��	+�&D��0��@+�/�Lpe�B��$�nb܅T�k�ϓN��蟹J�lD�u�h�-6)hZ�:�{���<��%�П��@Q6��Z�h`0Sg�� I�DL��>��msF�΃��I��)|ݒx_.`�@ ���Z0	+�&E
    0   ����0��	+�&F��0��`�w�(� қ�цˣ�N>�N�"t��e0�rHN��.pԑ^�>���Dsx �n<E��آ��r��8�e����+�O�^x���
    �#c'�5�$n�j�y
    pM꤂���` aWIׇ�C�cp��/����󽋱uz4��g` ���Z0��	+�&G��0��@`&Ͽb��-�ҠA��[]q���LG�Utb\:��ݝL��	�jZ�n(���c���H����jsX�����R��������$ �ex'�J�t&�qG�iB������U1���ߞ�@ ���Z0	+�&H0
      ����0��	+�&I��0����        ����0	+�&J0
        ���Z0	+�&L0
         ����0	+�&M0
        ���Z0	+�&N0       ����0	+�&O0       ����0 	+�&P0         ����0	+�&Q0   0U߻��w%�.3�}M�Y��0
    	*�H��
     � /eTďZ��
    )��2����V�cFsR��zW�m��4���h�&M�^3TQ���[�m�l���{t�Oy����^�z�;:a$�
    :����'W�GZ/�;{���m��NPڹ�d^��~E��A%��k痆���T6T�+�]�GF��Ad�3��/��֯�=���m:�7Yb��po��Ui��"0#�n�X���G���+Bh�S�!m�������L@����	"�!j�� ��"ë� v٪��o���/��=teM�K�Ƹ~�@k��oT���EP��m�䷑���YK�m���R���BG�&��ځ��O�d�� ^�GY]kZU��A|�W&��%p!̽
    '�,��F"���k<�^�ɾ�Hdd@R��&����\|�\g�����'����F�U'_y�,�|�����H��
    ��3*g��D��������X�|�	�B�D4r�E���ֱ5�l�FT�by���)g��Y����~�	�#�1h
  • The primary certificate in this one is of length 5414 bytes which is incorrect.
    ❯ binwalk final_certificate.bin
    DECIMAL       HEXADECIMAL     DESCRIPTION
    0             0x0             Certificate in DER format (x509 v3), header length: 4, sequence length: 1697
    1701          0x6A5           Certificate in DER format (x509 v3), header length: 4, sequence length: 5410
    Can you please rectify your setup to create the correct certificate?
    Now we rectify our setup and recreate the certificate.
    I'm attaching generated certificate (final_certificate.bin) file for your review
    0��0�h�o��cׅ�G�5fm�H�Ո<0
    	*�H��
     0��10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    250814113420Z
    250913113420Z0��10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    	*�H��
     � 0�
    n�����g��c
    �FQ���T=R`t%P���S�-P-�"����]���lf���Я�k��� �r0p0U0�0`	+�&"S0Q	`�He@#�.(̼@#��X�m׆�X�.@C�&�g��a&d��UjU�ﷄ�&u�P�Q��/~����U� 0
    	*�H��
     � q^�2�
    �	�']�J[�#�e�Pn#�Z�_����؝�^��_a+��c5[dچ��!)4CVZɳ8n��Vi�$�M�{���/���c��GP��6!1,����o;d�P�ƍi]eF�6�K�c�qz7y��¶>�Ux�WL����N�p 6k�7��8�E'D�g	x���fV��L[�Ȩn���J���J�9$, J�F��7��o}bvt-O%�w��J��.q�}����<<�����P����j���j =�ɬ�=��q�5�|�ꛆp\U �wN���w?�Uq�Wm���
    �׷D�y�NnV����[<E'T�BwKa3��ѫ��1|�$?MKzL���J	�(�T5|rD�=Ϭ��X�����39��N-F�'@�=�����5��n��l���8�h��+��`R�$�.=��B�]�b�P0u��2\��h�N�6�9�u�B�u�@�B��RFJ��Y�Ł�pP�� ��~J>OP����+*�~0�0��
    47\�l�j0�����a��O0
    	*�H��
     0��10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    250814113420Z
    gQE843yQV0sag1+0)U
    	*�H��
     � 0�
    �ZB7�*��n��g�� �sJh(1�������E~����;ǃ�!q��8�R�3��6�N��)�͛*�l_{��:y j}����X*�^�N��;O����4�� �Y-�^h�L���-v�X�P�7nfxo�0FM4��J���{Ů�2��l?��35�M��n`TP�~m���� ���+�7�Y�J�E�	��r3�^]�Z�!T����U�'�M	�@�.f�e�n��8N�a�t��_Q�B�����K�i��� ���0��0U0�0�	+�&@�0�� �S?S�0� ��|��:�����(��~� ���GH�¦"��ј���ތ���6�ޝ`
    >��l��N@�F��b��]OX��֗
    D�}����:?N~��e�eD��hI�̖J��r|��	�~�T�0���{���Ҿ��J8�Ú}�g�g@� I��&�vU��g)��ቤw,�w1w����f��9���4=3b8v��Bj�.�T)�aW`2A�*� ���6)�]�}|>�'t�e[�	l���z���٣^�.�7�a���Ĕn�
    ;ljloP`��7�/��>���gJ�a�<�v�ߙT�Y��q1JN�����D�w
    %��^Y[:<4�U�]�Xٯ��%�@��k�~�{ن.�a{�����1�,��P���
    ���GdU��Hb�L��}�.�=�.���a(0_�70s�>nчŸp���
    c�!$$�}�v>��j������AQ��?h^8^���Z�n�J��@��M
    �޸ړ��2FN���px��:`'��rP& 0�	+�&A�0�� Wl�뱉3r����� �P?ذv��X�;�Ͷ��14��ʚaD^�-�����!B�K���� ݈�>� ;Nv0�n�
    ���ѓo�xA�N��ޏ��N�;�Xl�ˌ�b<Z�%�ꋯ�g�E�P�wn�+�)��‘^��0�f";�$��C#��;��X0�mW~��q�k#�\��)�v�K:�{]����"^ ��{؂��y�
    �o�{��A��)E����~w�ܞ��;d=�mտ��t�k����4�zt��pQ&lj�����_��C]�f�z���1@@�3͙2�y�y�V%��L��[7Q33�s�U��9�~�� t��
    ���e��r(M{Xt�}�R1w���A��c�[��z�G��Nm���>/:=�68��)���v��
    �7J��ٚ�p�ُ
    �!s�_�a��2�����/Ȣ�l�� jaZ�#�~��/?�=q��{��z��l�N��;�=�	�}p��ޘ���D��_E<���Q�sg�H®d�I�� �g���eF��D���+��S��ѕ!��ߎ�Ck�@��LH�O\��T�"-8L��4���"�&z(�y�**�8 ��#�NQ4�\ڎP�!�B��D;7o�jq��훖R/j&N��䧞�=��V�  $&��W)I�/,�.ѱ4�E0 �to�/�Ɛ]y�Y4�À��Фa{jJb�d7�l�u�n�ܾo�	��_�(�)�`S�:����`�X����TU%//}�%�
    /�O�v���O)��}����?^������y�]?����$!CE�b5�y� @�z]!�`�q:�/bXNR����jR�99H��wqS��0M#t�a2+O�|{Z�q�w.�C����Rp�Fꐃ���#�K��۷�����m���i>���҄�s���"t5¥�����J!<�r3Va��	`4�,/�r~>�./-t��n����n]�^��7�䋲��G��k߄�c�qLձs�O$���'�1S2dK� ��\<�0e&��ȷ��g۔�w���7i��RS 0�	+�&B�0�� 7&&��i��U�xX���:
    1	3X���>����Ǹ�C���qF���gY�l\�/��OT�U�Mp���xs�LŹy�}�/lk����Cu�k�^�v�ᛈ�_�
    :����zjF�
    a��W�� !{${VzZ�{��i3�g]'�W�O�0�M��hBj��6�s��a:��X�K�u�G�
    �0l��q�Wk+��A�,=6<a�f������&���0��-�ņ�l�y�7l����N�}y(lg���?~AL�|�r1= ��Xy{{��θۉ�̦h�?��ѫ,���>�:4J��uon���������8��)�$��d��ZUܧ�h���v�b��P��Ѵ��ju�t|���jjN�Ւ;qr(xq
    *�FUa^[�뭄5�G��A�����z� /��$��y�13�*��c��
    ��o/���p���C��y�E|]�i�y�"B����/���O
    ಾt���+�V�����݁1
    i���op��eP�?�e�B�ţ!�wW�(ޣ��W��Ã�LCF�57�H2(Z�b7����(�ʽY�aB��·Yt�WYRF��
    lRk�Xo�� ‘M���a��������.��\_�� �S�C����rXp�� k�)!Rk���]�$A��'�YQf���q=�wrP�4��]]�`����>��"�{p�6�9�",n3K	<�-��f����5+�u"S�$i�I'�@+�q�9V���\��Iz
    �	��m�0\�����` �.���(m���`�8]�̛u >(�Gc�=Z��>�;
    �A�����m���%�+�&��]m��s����Mߨ���<�i�.. l�++��o��e��N"�<j��۠��݆��G�PA=<��� P�9�� �i��{'O��+�R#�°{HW�Ӷ� ��~�s?����J
    �T�г�63E�a���m)�A����p��� +���6��ؿ���Fw vB���?㗟�&�]�ʡ3v�f�K���S���&�B�g�����uȭ墏=���n�� 0��	+�&C��0��`3�����$mH%N}����k���J�m�i#���n�@
    �����ɍ\�]1K��f�M ��+�����\���+�a���n'[���"��TΣ�G?|4�����.t x���V���e�	��O"}�
    7��թ�r���` ���Z0��	+�&D��0��@�.��g�.e��	�/��Sd>�x�p�n�(=�L�q@?*�/���q�#�K�:��;�_�K�Oa\j�)������ʆj��� ���.�jq�/����i�+Kqo��� �%@ ���Z0	+�&E
    0   ����0��	+�&F��0��`hG���֝@ },��7��ۦz�l�]���pMڞ�'R#�`j�
    9���7�R���q�fՓ��#|���v�1�%n=1�O��ES�RU�ʬ����~b�Q6�ѡ1���@ 34����&
    JHz<%��n	Ok���8%Xe`�m�` ���Z0��	+�&G��0��@=&�:�Gl��	�=eEc�}"L7f��	Bo���+���mfxa�WY�0���[c��+&֙EY��?B�Gu�����i/�6 ��������UkƔQ/�-���⺿1�N��@ ���Z0	+�&H0
        ���Z0	+�&L0
     � ���Z0	+�&M0
    	*�H��
     � �']��|cx��-�eM� ���4������8���ˤN��h�� S�{�L�#^�;�V��V���%�z?�_��U�3-O��W1,�9������(��gN@�m=���FϮ��&-j W��+�b�7�����j鿹�D��{eѠ���(b/l��f5snY`Z��a�ͮ�)�,�.y�ү�,�KS��9��F4# �;�i�
    lE�F�����x�;�d���5�?��^���P�<�h���4j&��{�I�c+�jh�1/H���B*A��i �JB�,ڤ�u���<
    �1;p���"������h�����s=INBoG���V�Η�r��k�z�鞫�����g�K��2��JG���:�#(u+J��ə^���rl蟨�=�_�I��&�CX:�7Ʋ�sܳ��[E8�u\WQ�ɗ9k���YF��q���.�L���$��]g�Ȓ�� �(J]�j��_�u��_�����ѭ��g��Zt�?��S�H�=�|�����S�>�
    The certificate looks incorrect as the OpenSSL is not able to parse the certificate successfully
    ❯ openssl asn1parse -in 8156.final_certificate.bin.txt -inform DER
        0:d=0  hl=4 l=1664 cons: SEQUENCE
        4:d=1  hl=4 l=1128 cons: SEQUENCE
        8:d=2  hl=2 l=   3 cons: cont [ 0 ]
       10:d=3  hl=2 l=   1 prim: INTEGER           :02
       13:d=2  hl=2 l=  20 prim: INTEGER           :056F829E63D785DF478435666DF648B0D588163C
       35:d=2  hl=2 l=  13 cons: SEQUENCE
       37:d=3  hl=2 l=   9 prim: OBJECT            :sha512WithRSAEncryption
    Error in encoding
    123329955494784:error:0D07209B:asn1 encoding routines:ASN1_get_object:too long:crypto/asn1/asn1_lib.c:91:
    There is definitely something wrong in the way the certificates are generated on your side. If the certificate is correct, the OpenSSL would parse it like so
    ❯ openssl asn1parse -in final_certificate.bin -inform DER
       13:d=2  hl=2 l=  20 prim: INTEGER           :3B56A13BD0121162D62B032C8A1C70C06BE52417
       48:d=3  hl=2 l=   0 prim: NULL
       50:d=2  hl=3 l= 191 cons: SEQUENCE
       53:d=3  hl=2 l=  11 cons: SET
       55:d=4  hl=2 l=   9 cons: SEQUENCE
       57:d=5  hl=2 l=   3 prim: OBJECT            :countryName
       62:d=5  hl=2 l=   2 prim: PRINTABLESTRING   :oR
       66:d=3  hl=2 l=  11 cons: SET
       68:d=4  hl=2 l=   9 cons: SEQUENCE
       70:d=5  hl=2 l=   3 prim: OBJECT            :stateOrProvinceName
       75:d=5  hl=2 l=   2 prim: UTF8STRING        :rx
       79:d=3  hl=2 l=  22 cons: SET
       81:d=4  hl=2 l=  20 cons: SEQUENCE
       83:d=5  hl=2 l=   3 prim: OBJECT            :localityName
       88:d=5  hl=2 l=  13 prim: UTF8STRING        :gQE843yQV0sag
      103:d=3  hl=2 l=  43 cons: SET
      105:d=4  hl=2 l=  41 cons: SEQUENCE
      107:d=5  hl=2 l=   3 prim: OBJECT            :organizationName
      112:d=5  hl=2 l=  34 prim: UTF8STRING        :dqhGYAQ2Y4gFfCq0t1yABCYxex9eAxt71f
      148:d=3  hl=2 l=  17 cons: SET
      150:d=4  hl=2 l=  15 cons: SEQUENCE
      152:d=5  hl=2 l=   3 prim: OBJECT            :organizationalUnitName
      157:d=5  hl=2 l=   8 prim: UTF8STRING        :a87RB35W
      167:d=3  hl=2 l=  24 cons: SET
      169:d=4  hl=2 l=  22 cons: SEQUENCE
      171:d=5  hl=2 l=   3 prim: OBJECT            :commonName
      176:d=5  hl=2 l=  15 prim: UTF8STRING        :x0FSqGTPWbGpuiV
      193:d=3  hl=2 l=  49 cons: SET
      195:d=4  hl=2 l=  47 cons: SEQUENCE
      197:d=5  hl=2 l=   9 prim: OBJECT            :emailAddress
      208:d=5  hl=2 l=  34 prim: IA5STRING         :kFp5uGcgWXxcfxi@vsHs9C9qQWGrBs.com
      244:d=2  hl=2 l=  30 cons: SEQUENCE
      246:d=3  hl=2 l=  13 prim: UTCTIME           :250816075009Z
      261:d=3  hl=2 l=  13 prim: UTCTIME           :250915075009Z
      276:d=2  hl=3 l= 191 cons: SEQUENCE
      279:d=3  hl=2 l=  11 cons: SET
      281:d=4  hl=2 l=   9 cons: SEQUENCE
      283:d=5  hl=2 l=   3 prim: OBJECT            :countryName
      288:d=5  hl=2 l=   2 prim: PRINTABLESTRING   :oR
      292:d=3  hl=2 l=  11 cons: SET
      294:d=4  hl=2 l=   9 cons: SEQUENCE
      296:d=5  hl=2 l=   3 prim: OBJECT            :stateOrProvinceName
      301:d=5  hl=2 l=   2 prim: UTF8STRING        :rx
      305:d=3  hl=2 l=  22 cons: SET
      307:d=4  hl=2 l=  20 cons: SEQUENCE
      309:d=5  hl=2 l=   3 prim: OBJECT            :localityName
      314:d=5  hl=2 l=  13 prim: UTF8STRING        :gQE843yQV0sag
      329:d=3  hl=2 l=  43 cons: SET
      331:d=4  hl=2 l=  41 cons: SEQUENCE
      333:d=5  hl=2 l=   3 prim: OBJECT            :organizationName
      338:d=5  hl=2 l=  34 prim: UTF8STRING        :dqhGYAQ2Y4gFfCq0t1yABCYxex9eAxt71f
      374:d=3  hl=2 l=  17 cons: SET
      376:d=4  hl=2 l=  15 cons: SEQUENCE
      378:d=5  hl=2 l=   3 prim: OBJECT            :organizationalUnitName
      383:d=5  hl=2 l=   8 prim: UTF8STRING        :a87RB35W
      393:d=3  hl=2 l=  24 cons: SET
      395:d=4  hl=2 l=  22 cons: SEQUENCE
      397:d=5  hl=2 l=   3 prim: OBJECT            :commonName
      402:d=5  hl=2 l=  15 prim: UTF8STRING        :x0FSqGTPWbGpuiV
      419:d=3  hl=2 l=  49 cons: SET
      421:d=4  hl=2 l=  47 cons: SEQUENCE
      423:d=5  hl=2 l=   9 prim: OBJECT            :emailAddress
      434:d=5  hl=2 l=  34 prim: IA5STRING         :kFp5uGcgWXxcfxi@vsHs9C9qQWGrBs.com
      470:d=2  hl=4 l= 546 cons: SEQUENCE
      474:d=3  hl=2 l=  13 cons: SEQUENCE
      476:d=4  hl=2 l=   9 prim: OBJECT            :rsaEncryption
      487:d=4  hl=2 l=   0 prim: NULL
      489:d=3  hl=4 l= 527 prim: BIT STRING
     1020:d=2  hl=2 l= 114 cons: cont [ 3 ]
     1022:d=3  hl=2 l= 112 cons: SEQUENCE
     1024:d=4  hl=2 l=  12 cons: SEQUENCE
     1026:d=5  hl=2 l=   3 prim: OBJECT            :X509v3 Basic Constraints
     1031:d=5  hl=2 l=   5 prim: OCTET STRING      [HEX DUMP]:30030101FF
     1038:d=4  hl=2 l=  96 cons: SEQUENCE
     1040:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.34
     1051:d=5  hl=2 l=  83 prim: OCTET STRING      [HEX DUMP]:30510609608648016503040203044052BA4D6365F47CBA2979E2F57B2DBE50ABC31E2957433DA9155E6753EE00836A33A6FC2BBE2C41BEF0CB407DC802D8AAEDDE91696C877F3F5F3D555F53818C6102021507
     1136:d=1  hl=2 l=  13 cons: SEQUENCE
     1138:d=2  hl=2 l=   9 prim: OBJECT            :sha512WithRSAEncryption
     1149:d=2  hl=2 l=   0 prim: NULL
     1151:d=1  hl=4 l= 513 prim: BIT STRING
     1668:d=0  hl=4 l=5379 cons: SEQUENCE
     1672:d=1  hl=4 l=4843 cons: SEQUENCE
     1676:d=2  hl=2 l=   3 cons: cont [ 0 ]
     1678:d=3  hl=2 l=   1 prim: INTEGER           :02
     1681:d=2  hl=2 l=  20 prim: INTEGER           :6EF825E45FAE8F8DA7329B40A92B3E1C55CCAA0F
     1703:d=2  hl=2 l=  13 cons: SEQUENCE
     1705:d=3  hl=2 l=   9 prim: OBJECT            :sha512WithRSAEncryption
     1716:d=3  hl=2 l=   0 prim: NULL
     1718:d=2  hl=3 l= 191 cons: SEQUENCE
     1721:d=3  hl=2 l=  11 cons: SET
     1723:d=4  hl=2 l=   9 cons: SEQUENCE
     1725:d=5  hl=2 l=   3 prim: OBJECT            :countryName
     1730:d=5  hl=2 l=   2 prim: PRINTABLESTRING   :oR
     1734:d=3  hl=2 l=  11 cons: SET
     1736:d=4  hl=2 l=   9 cons: SEQUENCE
     1738:d=5  hl=2 l=   3 prim: OBJECT            :stateOrProvinceName
     1743:d=5  hl=2 l=   2 prim: UTF8STRING        :rx
     1747:d=3  hl=2 l=  22 cons: SET
     1749:d=4  hl=2 l=  20 cons: SEQUENCE
     1751:d=5  hl=2 l=   3 prim: OBJECT            :localityName
     1756:d=5  hl=2 l=  13 prim: UTF8STRING        :gQE843yQV0sag
     1771:d=3  hl=2 l=  43 cons: SET
     1773:d=4  hl=2 l=  41 cons: SEQUENCE
     1775:d=5  hl=2 l=   3 prim: OBJECT            :organizationName
     1780:d=5  hl=2 l=  34 prim: UTF8STRING        :dqhGYAQ2Y4gFfCq0t1yABCYxex9eAxt71f
     1816:d=3  hl=2 l=  17 cons: SET
     1818:d=4  hl=2 l=  15 cons: SEQUENCE
     1820:d=5  hl=2 l=   3 prim: OBJECT            :organizationalUnitName
     1825:d=5  hl=2 l=   8 prim: UTF8STRING        :a87RB35W
     1835:d=3  hl=2 l=  24 cons: SET
     1837:d=4  hl=2 l=  22 cons: SEQUENCE
     1839:d=5  hl=2 l=   3 prim: OBJECT            :commonName
     1844:d=5  hl=2 l=  15 prim: UTF8STRING        :x0FSqGTPWbGpuiV
     1861:d=3  hl=2 l=  49 cons: SET
     1863:d=4  hl=2 l=  47 cons: SEQUENCE
     1865:d=5  hl=2 l=   9 prim: OBJECT            :emailAddress
     1876:d=5  hl=2 l=  34 prim: IA5STRING         :kFp5uGcgWXxcfxi@vsHs9C9qQWGrBs.com
     1912:d=2  hl=2 l=  30 cons: SEQUENCE
     1914:d=3  hl=2 l=  13 prim: UTCTIME           :250816075009Z
     1929:d=3  hl=2 l=  13 prim: UTCTIME           :250915075009Z
     1944:d=2  hl=3 l= 191 cons: SEQUENCE
     1947:d=3  hl=2 l=  11 cons: SET
     1949:d=4  hl=2 l=   9 cons: SEQUENCE
     1951:d=5  hl=2 l=   3 prim: OBJECT            :countryName
     1956:d=5  hl=2 l=   2 prim: PRINTABLESTRING   :oR
     1960:d=3  hl=2 l=  11 cons: SET
     1962:d=4  hl=2 l=   9 cons: SEQUENCE
     1964:d=5  hl=2 l=   3 prim: OBJECT            :stateOrProvinceName
     1969:d=5  hl=2 l=   2 prim: UTF8STRING        :rx
     1973:d=3  hl=2 l=  22 cons: SET
     1975:d=4  hl=2 l=  20 cons: SEQUENCE
     1977:d=5  hl=2 l=   3 prim: OBJECT            :localityName
     1982:d=5  hl=2 l=  13 prim: UTF8STRING        :gQE843yQV0sag
     1997:d=3  hl=2 l=  43 cons: SET
     1999:d=4  hl=2 l=  41 cons: SEQUENCE
     2001:d=5  hl=2 l=   3 prim: OBJECT            :organizationName
     2006:d=5  hl=2 l=  34 prim: UTF8STRING        :dqhGYAQ2Y4gFfCq0t1yABCYxex9eAxt71f
     2042:d=3  hl=2 l=  17 cons: SET
     2044:d=4  hl=2 l=  15 cons: SEQUENCE
     2046:d=5  hl=2 l=   3 prim: OBJECT            :organizationalUnitName
     2051:d=5  hl=2 l=   8 prim: UTF8STRING        :a87RB35W
     2061:d=3  hl=2 l=  24 cons: SET
     2063:d=4  hl=2 l=  22 cons: SEQUENCE
     2065:d=5  hl=2 l=   3 prim: OBJECT            :commonName
     2070:d=5  hl=2 l=  15 prim: UTF8STRING        :x0FSqGTPWbGpuiV
     2087:d=3  hl=2 l=  49 cons: SET
     2089:d=4  hl=2 l=  47 cons: SEQUENCE
     2091:d=5  hl=2 l=   9 prim: OBJECT            :emailAddress
     2102:d=5  hl=2 l=  34 prim: IA5STRING         :kFp5uGcgWXxcfxi@vsHs9C9qQWGrBs.com
     2138:d=2  hl=4 l= 546 cons: SEQUENCE
     2142:d=3  hl=2 l=  13 cons: SEQUENCE
     2144:d=4  hl=2 l=   9 prim: OBJECT            :rsaEncryption
     2155:d=4  hl=2 l=   0 prim: NULL
     2157:d=3  hl=4 l= 527 prim: BIT STRING
     2688:d=2  hl=4 l=3827 cons: cont [ 3 ]
     2692:d=3  hl=4 l=3823 cons: SEQUENCE
     2696:d=4  hl=2 l=  12 cons: SEQUENCE
     2698:d=5  hl=2 l=   3 prim: OBJECT            :X509v3 Basic Constraints
     2703:d=5  hl=2 l=   5 prim: OCTET STRING      [HEX DUMP]:30030101FF
     2710:d=4  hl=4 l= 539 cons: SEQUENCE
     2714:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.64
     2725:d=5  hl=4 l= 524 prim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
     3253:d=4  hl=4 l=1051 cons: SEQUENCE
     3257:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.65
     3268:d=5  hl=4 l=1036 prim: OCTET STRING      [HEX DUMP]:3082040804820400692D93507131C6051A525293451DB79CB896E365CF8408F4A07F8E2E8268BEF7174051A66BB6661788FACB5E4367416F485215EADBDB4A0569D23C0060D38F5903D8193D017902FF7B319C9D07A6B16A38C5CB9707BE6D3E689A7C7748426DB3322CC408190304EDC4DFDCC61F7BB333294A610F17660DC3FF2A5183DD545A23A9549415FD24C050D262929DE917C7B68421CFEA703B4B2C8CCC546EE12C9495407B1DF1F842CE35E6272816E8743DEDD3DCC25760CA891739FB6BCAE4E524E97A23A6DA083D5E77336CF2BA4B8ABD89DB2DB8671FBCB2ECC3FB36DC73C12BB22E59988F8238CD631AAC398C99C52CA330936569D1D14D1BF1A8AAA859435B8960BFD95F0231C07D4530D4B1B15631B152A00AACED303BA26E7C4A64321D10975E406D5C10A0E1FB05A53BEFF32A7B613D3DF6A8759D288CEB464E84D3BD81588196B29CB4E4247E6621340415ACE77D05E05B7AE6AAAC1D15EE059F8695E3BDEDF64BA58EE94B32A12833F1EEA8F8CD23CB9AE3532F2D0BCFD4A2117D79350FE488AEFB19EEB979A2B47DAD2622AEEDD3BC7BDBD0D1951FDE4736824A972BA5A4C3CB284EECCCEAA821BF43D90767F6994A099605AB2A859EA9A720B07E1B04AC323FC43AAC946803BC3C88B741E8794303786705FEBD7FD8305A8BCD6105819E07A4274BCFA9A507B42AF4CBCA439934724F3788A9ECA3625E5FD23E424D0F4E724DDFDB393E73B1E6093971DDDD372015A976D708D8A1A6B2133D5220B4E4DD5C9748A89B1D35933C2BF131B1F891ED35548D0242B35D9C0E3B9E59A91632863D5A34B6A699854BB12DD93F22AB385936CDFFE621F28C4C00AAD5E153493670789561AA48DFBECEC59A8D571C83585ACB6D4117F29542B111E9F896F15F9D15A36DED2EA307699BF668F63BFB066D2835F9704C51190B82A799E3AE580FC7DE8D5C18E0925B5166F7FFB6E17D0252B840F3F9B0F741E509DA6D709F3165BC6A212D0BA905312052FA1BB6D01A21EB3D77AFEFB0BDA6B71046602A59850982395DA7FED0610761B3865B38D91B53BF2901B12AF06F15883E5A2AC6CE1E40EEA9E39026CA395ECF6A9E5FBAF3C9B02E8AC2E885B559ECD85A9CF4A454D6C7FBA63EB63381BB1234E6099F74789E325C6C5743DD5984090943DA71758BFFD5EE0C79002F14ADC7D7FA98352F4D4AE521F5372966A815A00323D6E9DE1352647DD5FB140D2D5CAEE5AAD3605EE5B20F2B92670503F4BA4A1D70FF47C7DDFBB386616DC909897075EB48364108F14503344DB49F2EA2FE0A052F9AB23A1D4873E0735FE68607EE4E9FA260C10B8E199A19066BC822A98C2A021FDA4ED9A09AD756A25E75E95083320E85AE120B20BBADB0D8DB6F2A8FEC70F2F1018C514E821465112559824BDDF22211435010E7C104E7C0C4E66F1294401AFFF7EC508C41CDB102020400
     4308:d=4  hl=4 l=1051 cons: SEQUENCE
     4312:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.66
     4323:d=5  hl=4 l=1036 prim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
     5363:d=4  hl=3 l= 177 cons: SEQUENCE
     5366:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.67
     5377:d=5  hl=3 l= 163 prim: OCTET STRING      [HEX DUMP]:3081A0046091790E68FD11A5F7252F06AFB9979FF378EDAD55180945555CC1C424B4B5B51D006C981A3319D3BC68DE1DC30144CDFFC1F65EA1FF7E50CDEA92B82C6BF0937F9FD563E1A8471983BC71B0AD2BA120745A3D9F37213B4B2818F1CF86216E9B5A0410CAF899CBDC5E7D621F7B2952E22CD36604205DEC45686CB43B8399A4BF3A75E156109A9382B3497CBD7EBFDAF45B65F013A3020160020500A5A5A55A
     5543:d=4  hl=3 l= 145 cons: SEQUENCE
     5546:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.68
     5557:d=5  hl=3 l= 131 prim: OCTET STRING      [HEX DUMP]:308180044033022C4BB5DEC5C056CB2379C1564C4A871D871AD0E3A9C84DD868793C89A90262CEC697605AAB64087CDCE75363D4FFD350AFBF2249C2F75F2DF30B
    5EA1B7E504100883B080089EA53E0A12500D2492F40104209F277EB68287D74DC82FE73FE6B7507473436B2EB3D7F1F973D79487906CE61F020140020500A5A5A55A
     5691:d=4  hl=2 l=  26 cons: SEQUENCE
     5693:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.69
     5704:d=5  hl=2 l=  13 prim: OCTET STRING      [HEX DUMP]:300B04020000020500A5A5A5A5
     5719:d=4  hl=3 l= 177 cons: SEQUENCE
     5722:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.70
     5733:d=5  hl=3 l= 163 prim: OCTET STRING      [HEX DUMP]:3081A0046037839006320106B5822911635AB6DBABCA9396743850DB554D19783E9273B5DE1EB9A7DE7C1A04AEBC7713DDE30347255DE93DFCAA93FE48EB8532CB08BAD6C052B9B9601F4C5222920E50E537A122E505C33F68F028DCB76A705D56186DEA690410546D20FA7CEA15CAB0736080BFF2916504208FA1B3A9A02353677C2F79735B890C3D30D354B7DF9D50954691A3B4F86AC287020160020500A5A5A55A
     5899:d=4  hl=3 l= 145 cons: SEQUENCE
     5902:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.71
     5913:d=5  hl=3 l= 131 prim: OCTET STRING      [HEX DUMP]:308180044054BA8D354DC8DDE3D3B75A27139F87B47BE0AB0F44C39A6C80CD546CB2B43D2CCAA580682DEB368474E5CB8CFA6622CE394731ACC0CDD630A55744246D64840D0410D54514EFB96A29289073B5EA19CE212D0420673B90DD06CD0BA895EEB09635E46E274BB0CDCADCDB6BBE0240FD9BF1088B33020140020500A5A5A55A
     6047:d=4  hl=2 l=  25 cons: SEQUENCE
     6049:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.72
     6060:d=5  hl=2 l=  12 prim: OCTET STRING      [HEX DUMP]:300A040100020500A5A5A5A5
     6074:d=4  hl=3 l= 231 cons: SEQUENCE
     6077:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.73
     6088:d=5  hl=3 l= 217 prim: OCTET STRING      [HEX DUMP]:3081D6048180000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000004100000000000000000000000000000000004200000000000000000000000000000000000000000000000000000000000000000041000000000000000000000000000000000020100020100020500A5A5A5A5
     6308:d=4  hl=2 l=  28 cons: SEQUENCE
     6310:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.74
     6321:d=5  hl=2 l=  15 prim: OCTET STRING      [HEX DUMP]:300D040400000001020500A5A5A55A
     6338:d=4  hl=2 l=  28 cons: SEQUENCE
     6340:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.76
     6351:d=5  hl=2 l=  15 prim: OCTET STRING      [HEX DUMP]:300D0404000C0FFE020500A5A5A55A
     6368:d=4  hl=2 l=  28 cons: SEQUENCE
     6370:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.77
     6381:d=5  hl=2 l=  15 prim: OCTET STRING      [HEX DUMP]:300D040400000003020500A5A5A55A
     6398:d=4  hl=2 l=  30 cons: SEQUENCE
     6400:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.78
     6411:d=5  hl=2 l=  17 prim: OCTET STRING      [HEX DUMP]:300F0406000000000000020500A5A5A5A5
     6430:d=4  hl=2 l=  30 cons: SEQUENCE
     6432:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.79
     6443:d=5  hl=2 l=  17 prim: OCTET STRING      [HEX DUMP]:300F0406000000000000020500A5A5A5A5
     6462:d=4  hl=2 l=  32 cons: SEQUENCE
     6464:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.80
     6475:d=5  hl=2 l=  19 prim: OCTET STRING      [HEX DUMP]:301104080000000000000000020500A5A5A5A5
     6496:d=4  hl=2 l=  21 cons: SEQUENCE
     6498:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.81
     6509:d=5  hl=2 l=   8 prim: OCTET STRING      [HEX DUMP]:3006040400000200
     6519:d=1  hl=2 l=  13 cons: SEQUENCE
     6521:d=2  hl=2 l=   9 prim: OBJECT            :sha512WithRSAEncryption
     6532:d=2  hl=2 l=   0 prim: NULL
     6534:d=1  hl=4 l= 513 prim: BIT STRING
    Can you reinstall the keywriter package in a clean environment and regenerate the certificate?
    If the issue still occurs, please share the output of the following commands and share the certificate as well
    $ openssl version
    $ ./gen_keywr_cert.sh -t tifek/ti_fek_public.pem --msv 0xC0FFE -b-def --bmek-def -s-def --smek-def --keycnt 2 --keyrev 1
    We reinstall the keywriter package in a clean environment and regenerate the certificate
    $ openssl version
    OpenSSL 1.1.1q  5 Jul 2022
    writing RSA key
    writing RSA key
    0��0�h�eh��ٶ�JXr����~t�0
    	*�H��
     0��10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    250818050430Z
    250917050430Z0��10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    	*�H��
     � 0�
    n�����g��c
    �FQ���T=R`t%P���S�-P-�"����]���lf���Я�k��� �r0p0U0�0`	+�&"S0Q	`�He@���:��Y�~��6?b�p}q�tB�/ِZ�{�<��ߋT��	����*7���S���6I�x/�~� 0
    	*�H��
     � ��f>y�<A���ڢ�_'�}m����]gCN�ԹIP�s0�{S�')�ьWKϼ���Ԭ�z�� X
    OՍn�-=G%dl歁e�p��)K��C�� ����ћX�z�5���Ӡ~�|�|�T������
    ��S���B��
    ���Wԣ����Q!kE�%Ll�s�Y��}�Z{�p�=��I��41�~�{g�II:� ��G5�OV�����줈�F���	%v]��l��",*�Iv��'Հ������lp�%�Q�薒�z��2�}b
    %>��"�G����:��E15��0.��NЙ#��ؖ���c@T'|�4~#�`��[�nͼAn�ע���ݵ9<�Ó�
    !����]�`p	���q����pk��[ �S"���`_'���*`OKW�%@�&d�,��=�᳐��k�v �7x��X�̕3�4���Lw���H�%���~�4�]�:@+��6<�����6����^��ZD��4	%�'ԎkP��/ق#\�]�IK0�0��Ԃ-7���.y�k �V=_0
    	*�H��
     0��10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    250818050430Z
    gQE843yQV0sag1+0)U
    	*�H��
     � 0�
    �ZB7�*��n��g�� �sJh(1�������E~����;ǃ�!q��8�R�3��6�N��)�͛*�l_{��:y j}����X*�^�N��;O����4�� �Y-�^h�L���-v�X�P�7nfxo�0FM4��J���{Ů�2��l?��35�M��n`TP�~m���� ���+�7�Y�J�E�	��r3�^]�Z�!T����U�'�M	�@�.f�e�n��8N�a�t��_Q�B�����K�i��� ���0��0U0�0�	+�&@�0�� J (`��������D��[ek���Ҭ��Pp�H�F��cH�W��L/2�
    ��G\L��$�IC�pޯ>F+1�:��� ���ޠ�X+��Uӭ��)I�'�8Gk���l����~�ا�}�!�Y �h[y�/69����j�Rcq/��؃J��{t��Pb:c�I�|v�it�k���f���=� ���
    ��o��V��R#W�W6����(��
    !M�KA&y^E�w
    _�:i"'�	��1��1�8h.F0���?ow	"3���;��I��t'En�RL�����q���{�F�88^��޴���)�ZI�j��ݏZ�bS�M_���
    �0{Z3C�ur�U.�12P>���sl����
    E��5"�-ʜ�UC�=\N���:jj� i��oԹ��V��%����G�6�( :��@��𽞢P)�[�J�W/z�V��)�)	��޲��o�7�����%�	�1�n�FA�2C��S����R ��.�M��(9�C�W�1̚LH 0�	+�&A�0�� ;�D\��+LD" ;duH�\?-D���D��W�����-�4��)
    >4W��
    ��+��	60��诎B3L+PԂ�K �V�>��d�h�نX�6��E�?�SO]�ӟAP_�:N���i�=\o�(��. c�Y��'��$Xg�~�l2̣<L��b�$>jD��3x�T�:L}w�%�{z�	Es`�'�dg��j;�|�?�"U�]Oˠ^���jL��|t��T�'��Xf��;1�Wê^��D�ጩ@B�d�^��\�w����L��F8��|I�<_+M?�dS��0��{�eb�1Y�5�BZr����b�(�:�E��#�+i���������H��[I#TeAn�5�e�Qo�%���J�%�X?8?���S8�A�_���9�������24B4�|�А����w��[��۵�#�����t�q��r7��d��;�XY�,c"z-]@��@�%�ؚ�C�4��q�O"ijG�R>�z�ٲ��Y�׷���[!e>�=[XV�4���D��?u��;ܔ�l�`eG1� `Op}&�8&��,4�ck���p}
    �mXK�[��:������ tͲ+z��t�!]�h�+=�Z��'�f?R�$�]��D���a��*�P�-3
    	 � T���L�
    K>�h
    [h-����̹�b�T^a�&�e����7���Ϯ
    7��z�1�
    �S>
    +����p�x_0Ω��7��{Ӵ�/Զt������fǛ��ŀVx_�r���g��,y-�w����ºTT{��کt�e~=������A��5q=��Y���x�?�V�d���J@{�x���3�+��Q_}�q'R�y ���*Z��<��� ��6��!�� S�)����.�f�t輩cK�!+4�8
    ��t��-*K���u����,4L� +��6�_� �6��66
    4Q�{){̧O}�H��8=y����QHG&(36VW��?.�U�JS�`��J���	M�<y�i��7��ZF�
    &��e{�o�AޒL���,������ 0�	+�&B�0�� j8(e=�:P��33���^��&(�,�Ǟ��:~d���m����jG�<Oe��f�e���KE�.�F�
    7����9�ѓM�1NE� Z)��'�hL"���աi�hg�KD�� õ�S=���� ��B8Dub�}��qA1
    ��+j��[�����5,l]���s�r�^=S�oE��VER�u������
    `ĕ���E)f���zT<�����^�WĔ�g���r��E��Zd��$��	���ƻ����M����?1�<��n�<�FǧK�^��ma�U%ϴ3�4&�ࣰZ������N��v����Ef~��d���f�)����_ƝMЫR�����b��.X�q���|~?��DLJmO����QO�YA�("�!�;7!P�0@u�ö��a���yw�q�f�*���Y�w�Eʊ���a�㟚_8�Ǔ��1�x�K��;j�+Ы8�n����<
    �TGڥ�3���A�����9z�c�������&㝈m���q��3#����h5�Q�I��z���c鯀�J�P�
    NK�q��:�{����f���ɯ�@��}��5I#9�v�]i�Q�bS��{����
    �eWk����Uy�3$�H|	Jؕ�o=�i=�Oy�VX�č�AUR��rŁ���
    ��]������o��Z�e`c%�����DW�ʠ$C�w�t�z����C0h��k�c_��1x]� �q�C���BA7���^r7Jp�M�������Z2[�Y%�|�Q���{־T��n�^	a�
    ִZ�N@=c��_�u��П�Ff��X�œ.�ʇ?��c"8��ǟ��@��&C�Amk�� $��	�5]�ɣ��0�$5�W���#�^����M�W��2i(��D�t?���Ӳ�}�H�[��6δ<���ӳ�<���+%�QW��� ������!�ڈY����32G~�'��B}U5�`p����߆���w�>�Qp���2�ǁ� �C[��v����
    b ҹ��
    �% F͸p��B<��88�-V% 0��	+�&C��0��`�VŐ�juO����Hn�sA��:}B��"��ڪIߐ��C�d��\�;὞��M�\dTJ�����(�$�睠D�+��D��S�aG�$������	���Q��+�h� ����3ҐH�y��LE;�t�涃�
    ��3�R` ���Z0��	+�&D��0��@�B��VNd�+�𙹬t�A�x��Z]�*ՐB����ۭ�浸�v��
    �>�?T�<�ݽ�\A?Ov���o}*'� \�U�@ �7#$Q3,�A#��7���qo�f�0Vy����Y�@ ���Z0	+�&E
    0   ����0��	+�&F��0��`d&���rT%J�x��}��G"�(�
    ޅp�<����>0cm�d�XL�i?�.h���6�Z��
    ���x���U�a�=mV(ݛ –�FQn U�^�K�H�>��� �;���S�൏W+��H��В��x��f �wo�` ���Z0��	+�&G��0��@s��>.��/G!=ɒ�J���\���'Fwm�P�V��v���_��3D勇! �ʼQ� ����V\4*��j _�>G� &�tʥb�����wn���6z7��	��:GҦ��@ ���Z0	+�&H0
        ���Z0	+�&L0
     � ���Z0	+�&M0
    	*�H��
    vqu� �ܬIv��;��E �'P�sⵑ�xgxy�}� kzWe�u�v�O�\ɬX�,���I(�P�t�?��t m@Ax"��g�	9O��A1�t�r;;1�ܼG���� yN��iW_� e���e�6�y�'����-ێ��B�L_�d�
    �{�|��I1<ȇ���L2�.DN���[����f�i֭r��࿳��J��k�QrW���"P=k-Z&�l�\<<1	il�u�"�y��X)&�>F����:J�K�EuV����a���֣�1QVL�,���)\f�z�Yue��:
    �u�ä�%�#���\ߎv	�i��.��e$��y�UEJ$�hf�K����Gd=m���/�%���ʂ�_�;T�� ��\;zR����x�O��69�L����� ������:]���hӂ�ꁶ��y%�H���-0q���5�S��@4�:�V*�m��'��+z��Y�������9�{VLC�o[�_�f�b� }�~��g|�8
    The OpenSSL parse it like
       13:d=2  hl=2 l=  20 prim: INTEGER           :1165688B8BD9B61FCE4A587288AC8701887E74DD
      246:d=3  hl=2 l=  13 prim: UTCTIME           :250818050430Z
      261:d=3  hl=2 l=  13 prim: UTCTIME           :250917050430Z
     1051:d=5  hl=2 l=  83 prim: OCTET STRING      [HEX DUMP]:305106096086480165030402030440F3F9A13A8DAC597FEE7EC8D0363F629514707D71877442EF2FD9905ACB7BF73CEDE897DF8B5490FF0917A2B10C90D92A37CBF3D153C7FBC6364984782FA67EFB02021507
     1681:d=2  hl=2 l=  20 prim: INTEGER           :15D4822D0B0F37D2E1C12E79F86B20E882563D5F
     1914:d=3  hl=2 l=  13 prim: UTCTIME           :250818050430Z
     1929:d=3  hl=2 l=  13 prim: UTCTIME           :250917050430Z
     2725:d=5  hl=4 l= 524 prim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
     3268:d=5  hl=4 l=1036 prim: OCTET STRING      [HEX DUMP]:30820408048204003B86445C84DA2B064C4422203B647548A75C3F2D44BDE5FB448AA5579D84BBF3A71D1A822DCE3494C2290E0A3E3457CDCA0DE8C82B9EB9093630CEECE8AF8E0542334C2B50D482AA4B0084561DAE0F3E93B2641EFB6893D9865885368BE745833F1DC1534F5DDAD39F4112505FDF3A4E0181EE1F0C8169F7013D5C6F1CCB281EE7EB2E07631ECD5916B9C327AB9824586712D07EDB6C32CCA33C4CCD0C19169B62F224173E6A4497BE3378B454AF3A4C7D77EA25C37B7AF909451C731D60A8279F6467B4C96A3BF47CC03FFA2255FA5D014FCBA05E0FDBE6F76A4CD6ED7C74F515A954AB27FCEB58669B1CD13B31C057C3AA5EAFC744D2E18CA94013429264C65EDFF55CFB77FFE7DBE24CA9E5460138B9C27C49A43C5F2B4D3F10936453C117F2B230F8A97BD165026295183159EF35C6425A721498F3F803F9628728833A9445A0CC23CF2B69FCA68A90B6AADFFCB54817BCB65B49235465416EDD35DC140865F5516F1FAC25BAFC884A11E225BD583F383F8DB89C10531638E341B50C5FF1D9D539A5F6AD8F96C7D632344234D17CB6D090F9B48AE877B0C15BA2DEDBB5B723A8AE1D13A49AD974A371D4E816720F37F2EE6415A7933BE558590BE12C63227A2D061F5D40F784408925BBD89AA843A534ECCE71A24F22C4B347E4523EAE7AC21FD9B213B3BB59BAD7B7C2FEAF5B21653E873D5B5856AF349DA3A244809B3F758AC43BDC94E16CD26065021847318C0820604F707D26D138269DD90C2C3497636B9FE902AD707D140D8B6D584BA65BB2AF3AB3EEC0A817DBF02074CDB22B7AF1F27404A9215DEDAF68CE2B3DC25AD6E527D5663F52FD2413188A5DE0D50444CAFF0EE161E4CF2AB950F02D330D0C0907ED07541116B006F5A84CAB0D4B3E0EE6680F0A5B081D682D92AEF9ECCCB9D3100B62A1545E61D126D865E8D7DDF90F37F310B7C0CFAE0A3784F97AEF31DC0D951B533E020D2BB6A2A3D870DE17785F7F30CEA90B7FA2CB371C811C887B13D3B4872FD4B6741B91C7C1C5FEB566C79BC3C8C58056785FBB72A58E0680679CC02C792DB51877F8E30FE28EDBC2BA54547BD6CDDAA974D4657E3DCE08DFFEA09BCC41878535713D81CE5993EBEE78BA3F0ECB56C3641284B08E4A407BFD1578CCDA03C833DC2BFC83510C5F7DE1712752927900FE8AD62A5AEAEF3CE9FECA20BBB536FCF921928F0507539929A7AFDAF2882E9A66B574E8BCA9634BE521062B34A4380DD110DF7487C72D2A1E4B0BA382CD7506F5D2D1FD2C344CD0002BF9C036B65FB700C836F5AB3636160A3451DA7B297BCCA74F7DB648FBD2383D791EB0E9E9F451484726142833365657A5A63F2E8855964A1553D460FCB913084AC1F8BE094D8E16153C0F0479E31969F9BC37B7E45A46199E0A26A5EC657BFB6FB04111DE924CC4E3F0992C83A9B1B21F8BAF1002020400
     4323:d=5  hl=4 l=1036 prim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
     5377:d=5  hl=3 l= 163 prim: OCTET STRING      [HEX DUMP]:3081A004609D56C590F46A754F06A0CD11BDD7486ED173418A10EE3A1D7D42D2CA22D905D8DAAA49DF90D6DF43ED1264B6AC5CE43BE1BD9EA2D84DD15C64544A9FA480A5F828C40F1E24A5E79DA044037FE72BF4A7C744FDDB530BB66147C324A6A4F11BCD041002F91B068309B8B9905190802BC868D404209DFDF89333D29048C71879C9C54C16453BB074B3E6B68313BE0D8AE333F95208020160020500A5A5A55A
     5557:d=5  hl=3 l= 131 prim: OCTET STRING      [HEX DUMP]:3081800440B04291AD564E64E72B04EBF099B9AC749341D17893E05A5D8D2AD59042FCB195937FDBADCDE6B5B813C176E501BA0DE03EC21D3F5491053C94DDBD9F5C413F4F041076FFA8C76F7D2A27C6205CDA0855E8400420E237232451332C8D4123D6EB37A91E859F716FE6966680305679E3CAD0C959B6020140020500A5A5A55A
     5733:d=5  hl=3 l= 163 prim: OCTET STRING      [HEX DUMP]:3081A00460642617C5C3EB7254254A139E78CFCD7DA2049C124722A428D00F0D19DE8570F30B3C82BC8315E2953E30636DC90864B3584CEE693FE92E036816A8F3B8DF36EC885ABD921D0D8B84AB78EAF3E9559961DE3D6D5628DD9B0300C296ED9946516E04100755B25EBF4B06DD48AD3EDA0206B5CB0420D83BC9CDE853D9E0B58F572B83C3481EF1DAD092ABE4BB78BF88660091776FAD020160020500A5A5A55A
     5913:d=5  hl=3 l= 131 prim: OCTET STRING      [HEX DUMP]:30818004407394903E2E82B02F47213DC992C44A81AEA65C81E1FB271646776DEC8350F81D56B19E7614F9A5ED9B5FD6D93344E58B8721200C9FCABC0C51890220E90394CE0410E4565C342A9D860E1E6A005FF43E47D1042026C074CAA50862ADFD9E8C807F776EA4CDC8367A378DB209D9D73A47D2A6CEF3020140020500A5A5A55A
  • The latest attached certificate still has the issue
    ❯ md5sum 4278.final_certificate.bin.txt
    be8ff80ec8034efcf7d2a7d14a211695  4278.final_certificate.bin.txt
    ❯ openssl asn1parse -in 4278.final_certificate.bin.txt -inform DER
    Error in encoding
    125163078544256:error:0D07209B:asn1 encoding routines:ASN1_get_object:too long:crypto/asn1/asn1_lib.c:91:
    Could you check if you attached incorrect certificate or parsed some other certificate. Please list down the steps as well you are following from the certificate generation to building the keywriter binary.
  • I have checked the certificate I attached earlier, and it is the same as the one generated under <MCU_PLUS_SDK_INSTALL_DIR>/source/security/sbl_keywriter/scripts/x509cert/. However, I am reattaching the certificate here.
    	*�H��
     0��10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    250818050430Z
    gQE843yQV0sag1+0)U
    	*�H��
     � 0�
    n�����g��c
    	*�H��
    ��S���B��
    	*�H��
     0��10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    250818050430Z
    gQE843yQV0sag1+0)U
    	*�H��
     � 0�
    !M�KA&y^E�w
    >4W��
    	 � T���L�
    K>�h
    7��z�1�
    �S>
    b ҹ��
        ���Z0	+�&L0
     � ���Z0	+�&M0
    	*�H��
    This are the steps we are following to generate x509 certificate:-
    1. Go to directory <MCU_PLUS_SDK_INSTALL_DIR>/source/security/sbl_keywriter/scripts/cert_gen/am62x
    1. Run the following command to generate the x509 certificate
      This will generate the x509 certificate at <MCU_PLUS_SDK_INSTALL_DIR>/source/security/sbl_keywriter/scripts/x509cert/final_certificate.bin
    2. Convert certificate binary to .h format.
      • Go to directory: <MCU_PLUS_SDK_INSTALL_DIR>/source/security/sbl_keywriter/scripts/x509cert
      • Run the following command
        python3 ../../../../../tools/bin2c/bin2c.py final_certificate.bin keycert.h KEYCERT
    Steps to generate keywriter binary:-
    1. Go to directory <MCU_PLUS_SDK_INSTALL_DIR>/source/security/sbl_keywriter/am62x-sk/r5fss0-0_nortos/ti-arm-clang
    1. Clean the sbl_keywriter
      make -sj clean PROFILE=debug
    2. Build the sbl_keywriter
      make -sj PROFILE=debug
  • Can you do `md5sum` of the certificate before running the `openssl asn1parse` and share the output?
  • $ md5sum -b final_certificate.bin
    5062b1f7b56296f337dee960daf5e971 *final_certificate.bin
  • 5062b1f7b56296f337dee960daf5e971 *final_certificate.bin
    This is different certificate than the one you are attaching (it has different md5sum). Can you please correct your setup and share the correct information for me to proceed further with finding the cause of the issue.
  • We recreated final_certificate.bin and here is the terminal output we get
    writing RSA key
    writing RSA key
    402eb0eb26deb607368c388b32b4b5f2 *final_certificate.bin
    $ openssl asn1parse -in final_certificate.bin -inform DER
       13:d=2  hl=2 l=  20 prim: INTEGER           :4663719957B7DFE07CC2683B47296DF403D0E62A
      246:d=3  hl=2 l=  13 prim: UTCTIME           :250818095153Z
      261:d=3  hl=2 l=  13 prim: UTCTIME           :250917095153Z
     1051:d=5  hl=2 l=  83 prim: OCTET STRING      [HEX DUMP]:305106096086480165030402030440E147AC8EA279A681D6762D8C0AE0C1E62B4D9D9F4BDE3CA25C3FA0807574E05564115489D54AB824E265185E3415F25AF57D7E7171E78CDFFB316EA12F58077C02021507
     1681:d=2  hl=2 l=  20 prim: INTEGER           :173AC3B8667BEDAEE30167FB2E2305E85C4DBED2
     1914:d=3  hl=2 l=  13 prim: UTCTIME           :250818095153Z
     1929:d=3  hl=2 l=  13 prim: UTCTIME           :250917095153Z
     2725:d=5  hl=4 l= 524 prim: OCTET STRING      [HEX DUMP]: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
     3268:d=5  hl=4 l=1036 prim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
     4323:d=5  hl=4 l=1036 prim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
     5377:d=5  hl=3 l= 163 prim: OCTET STRING      [HEX DUMP]:3081A00460C110D2C65611095927B4EC4ED10939DE3AB50B9E6B67B9B2E9757517533B76B9DA47EEAB96F7BFC9406AE9666D540E597A3E296350D0F4BDA44B4764270519D7A43965A6B738791337ECBFB5B933ABD34D5FF74DD335B115B2CDEDB05186DA920410EBB0FEC6410E4C7DE947F2E2067A1DA7042083533DECBBB8DDEE0EB0113437CA4660358454343CD1AA28C71C67B6B306E39E020160020500A5A5A55A
     5557:d=5  hl=3 l= 131 prim: OCTET STRING      [HEX DUMP]:3081800440460B165E6CE645715809C97AEBDDEC1CA72ECDF45D5AB8285D93A0252AC9A10A49B2D0CBB9CE7040D2F6FA6B1151643B3CA3755B7E0E9AB3E28B64F8D3B5138C04100C875879B32B6D329C0D5B85C3709DD004200A870364D2A2CD4ABC119B55FEE86D8DD15156A0CE2B107004B8CDC6E1329852020140020500A5A5A55A
     5733:d=5  hl=3 l= 163 prim: OCTET STRING      [HEX DUMP]:3081A004607DD8973F070F8DA7CEC34EFB3881C3525A9AF2FF736D2592D4125EE391E134F7D5DA278DAA343B51C09D5BE8AF9FCF05B6167973BD0A3343C7FABADF8F87CAC9EE8A185229C68535FD12E09AA7DECC72B78A2191BE979965397E26E81C85587304103AE077A6E3E64AB32D7BC249DB93B13D04202E6B7D3DD0CD2714339923FC4B940F4E7AF4F912AD84A68B7B1DE79C241125F5020160020500A5A5A55A
     5913:d=5  hl=3 l= 131 prim: OCTET STRING      [HEX DUMP]:3081800440C5B0A595F2230E10159051DE10EF378E7D541DAC8BC275EA4B24F7F3EAD87008A4B0B7D52DA8F587A37709A23C4F99663CFF787F9FE78F9E1BFEBDEACF5633DD0410FB35062728481FA38237A0CED53428960420AAF409C5847244E3B0CF8B156C0F2D412CD5B47CCE7C33F973E7122A52E77725020140020500A5A5A55A
    0‚€0‚h Fcq™W·ßà|Âh;G)môÐæ*0
    	*†H†÷
     0¿10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    "dqhGYAQ2Y4gFfCq0t1yABCYxex9eAxt71f10Ua87RB35W10Ux0FSqGTPWbGpuiV110/	*†H†÷
    250818095153Z
    250917095153Z0¿10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    	"kFp5uGcgWXxcfxi@vsHs9C9qQWGrBs.com0‚"0
    	*†H†÷
     ‚ 0‚
    ‚ ôb‹FÎ86“ሗJŠÛ>Àok–ÊÛ•)x#ÅäÞ§¶¶9‘ãChPk,ÅCÝo7!$xEÅßÉ-—¦Ð<ö!W.¾PÃïÇ£E†:_†3¢œ—8Ëß0ÓÀÕò<AÁý)I Ùs¶'á‡È  Lšëè%šÿÓϺ5Ÿ¾
    8»è¡nðÜ_ýMÜÝS[y¼Å5³"à,YVAû_çÖOhÔ6­ŒÍ.Ë뀏ßû\$õ,â½b)\ÅHÍ…eXÈ™¢Ÿ¦õñ€ma~´z™À6[ÖÃ%φwß!Êíâ¥=´ÃB›“s@gÈéó25Ê—î?"ÏhÀ
    n¼Þôªgšc
    £Z~rÌ6áÌŒ".…gép¸¿¡‹R°æ4¼Ü_š·
    Äi=ƒ,€—•JÑ^ý‹þQÉ<0Üé&Å#ì,¬îþSjåP†ôpÙu
    ¸£Uf‚QÉ=gã8^€7`„TéNQ˜ÝôREâúŸpqµxyÞÔIŠ !‹¾½ª¢Fƒ<	5Ù{ûÁÅ0ò8Ë)"‘M³¾—ãõmü«d`úWSåD©çe€¦¼ µ¼8êYð`j配Þ8# ¹
    åFQëžúT=R`t%PÿSã-P-ˆ"­Ðáœç]šáúlf Œ®Ð¯¹k«®¿ £r0p0U0ÿ0`	+‚&"S0Q	`†He@áG¬Ž¢y¦Öv-Œ
    àÁæ+MŸKÞ<¢\? €utàUdT‰ÕJ¸$âe^4òZõ}~qqçŒßû1n¡/X | 0
    	*†H†÷
     ‚ <º»Ä	–A·`©c8W˜Xa·@'È~‘ùdzC‘]r›»¥ëjs,l.©ŽPj!ÔW‡Á9ºmïÝ”}Bw!°ô°hc×ûÚ½L¾d'£äÆÎ~ñ0'Í|"ÜÊÃÞZÕØ{ÞËZw^¯ñ©¢L#€úªRýuž“kEA¤èx‰xµxdIÞ)<«UÎ%œ•QR£ÊιÕY·I­»‘;×­°Û¤ØC<4Ð+Sk£+“ïM°Â˜öTIoiÀ{#8ÿ?¡lB”µ#™À˜­fîk?S·/Rq:Êär}rìÅ¡G+çŽ3Ey(ò½ó,nœ/¢6¾|Ðd‚Fã<]^áßfÉÙLQs–LÝ%ÖØÏXId•¤ñÂc?íäŸæóy¤¤«Ï0G<€ö#Ë3gŸs
    ÇZUÛ#a¢&DÿXµßñçÖ‘ÀâñJ#¡A´µpõÚQ_’hd÷ׄ˜ÒTónê8iâý=߉ï¦\{GD+ªèžáÅòxbòïιbfÑEÔjÍMïb¯OÁççâ=@ISÞD)/JѾ©UÑi¡ƒ›rGÌ´ðq®˜Ï'}‹	¶-rBÙ8uGw ­%a.„S¡Í×^¦òÏéNéU7´ÎHÓ3r!Â:òDo;ó¹)Ë0‚0‚ë :øf{í®ãgû.#è\M¾Ò0
    	*†H†÷
     0¿10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    250818095153Z
    gQE843yQV0sag1+0)U
    	*†H†÷
     ‚ 0‚
    ‚ ¿®IØrÓk#ÍëHeÜ"MòO‚öíµòÝÛ|‘únYÿÕ÷¶ÞŠÌÒ•ÙÑàÄÁøP¿ÿH‘"PšL{‹ó–
    (&³¤Ùà©UAû>['l¿ÊÀq¯/r"îF%b­>Çö±¶,Ànâ›>妠¨EAN©tÖ„NÖy§¸©’%ݱòѹòhØ3YK‚}wÌÑœú#´ûXˆòÍêÕò,u-úbÃÁ	nàpൠ	™bÙÖäçlmÈ‚ P“÷âØíÑ_ãОϓTÙ_Ý]Î7`ñ«Š{e§ºßEE|K¡[®NÆ”=ŒN‡Ò”<¤óŸÚüò6|ç
    ­ZB7ñ*Ðn¡§g‡í »sJh(1¢‚š£Áè‡ÿE~ªÁŸÔ;ǃý!qþ½8ÉRæ3É6ÍN‚)ˆÍ›*¾l_{²²:y j}õ­ÍX*Ï^ôN€«;OÝøÔÞ4¢Ä ÙY-…^h±L¹é-vµXŒP¨7nfxoƒ0FM4Ÿ´J¹»ú{Å®Ö2„„l?š€35üM¼Õn`TPÏ~m€—ú ý½˜+¡7½YýJìE¡	‹Ér3·^]âZÎ!TöáêÕUª'ëM	ß@‚.f‰eÙn³Ö8NaÖtÔÞ_QÕB¸ƒÒÈÞK©i—¶ £‚ó0‚ï0U0ÿ0‚	+‚&@‚0‚‚ 	æj{2I>(à9ùÝ:³ûÚ´n—OiIÕê%6}ã®×úÀ€mÞ7èLuÈ[¢üÓR¡¤Ø$SH¬áφ…9ÙðCÆpd¸§e™(„†î÷8ÿ,IÂê¨y@ˆ±ÔE)HÞý¦wr*{Ä#úž,?Òð¯î:6t»uÔG$}KZÎÉ-ôÁݽrÜ\iÄüˆ•nQߎ$xî4´¼2º£rí7¬ÛÉ»á
    M¿ŸÉLoÙÞê<÷”#89>aå„ÒÁ(ZØ–5¯iSÑÇD‘,,³¸>}a3óÕRçm’x«XÆÖCêàþýÝ)Xo搱§ñ–\;jnªž+ß³ökäÁN#H‡H¯ÔÁüíMÙ$¾ú ;Ôjæ<˜luÖqd¸Ðœ2îDc
    ¼ý¨°ŒÒ›Ìê/[‰·$0»çõ5“×V(6£¯áüRôò °'YÁþl×éãae[îС¥<m£½d®Œë™ê'HƒÀzÙÑÜÑÂB0ci«gÎԍ­J;Êø5h‹axÓž“´Z”l¥´#ù#°Æbá”—зY«)JK{w´pv” `B¶ðÿ\ê:Ç%7–Fq¥lª=€š—É ;›©ýýQF0à]E½sÉYÅ	ðra#ƒçÁ€3ÛÓ^|C.‹ÐÝ-æ1là+, 0‚	+‚&A‚0‚‚ Wþ>EÅn®-ñ¾ß±ÞRG]U´òM árzX{hŠ2ôxþl\‰Ÿ!Qüý™¿?úmU¹$a¾úÌDâoñNFúo³g-]SWÑk Ìæ&Šl39?¿K½¶^rÿ—ñÐù˜Å¥äé1æ å⛣V!"™Gù1ó˜VN)|Äo?T–/É •Å[/´ùÖ`fÛ£	æ³eÆþ׍º`WX»d,7ã2“ai?ÕWVÞ®˜XÿVŽ+Âѽ¡r浺£¥G÷¶±Ü+@N\î©/ÿ_™"0;¤ß+8—t¬Ö#¡4ï¡dñ9Í¢Oõw¥}ég^ê›ä°EEF–P~™8Øâ^Ž× Ã0úÞGýÿixð¸ñUª~ «¯ØNct·LêͤmǏwÍB—ÃQ<¡L½Øª­QæÍ÷#ëãaÚåµÀ±ßøÅÔž¡Z‘aó×"m~ðÅÜõ~Ë‘
    §Ë‹$ÄUÅÀ§ÉùÈ-ìPg+oŸ©w3\´¢qo/þÖáe¬ošàD´‰á\iÊþÕ [qÚáÍÔ©³œ	Þ@
    Äñ8Ãó¹øóI
    2áZ˜ÿžhƒ2áè|««d鯛Ö|®"U„ÜlS,˜eéì«Û&ˆ;Tî¸ö#ØN:Ïx¾ïO ø¥KQ&YéBûçIÌ-Zb¿;Ó¸í£›ÞæÙýY;KF
    [>-ùEYQ]cZû^ÉtÊ`éöù§*˜ÒÚá+óÉ–ÝÝsÏyÂìÏu3:•P~ßþ9K-…ýßÿ–„3K²ø¼–EZê¾9àýXmÌ«ñ©òþxj’*â<sXc	M»TÄüi3éii`=ûSͳÄ5¼¼›öpaÀ‡µ©a¶—g=ZÆ=ÄÛoþûúÀ˜”åÙ{N’¦ÒhwYÖî†\Оò]óhÙD¢&Æ•ûÍ]£¬»]“”¬Úd'N³3xxqúF‘ƒ„ª|%xXÉûâ6¶„!QJ°Ù7|"Ì#ŒTâØýÆ »‘Åd°áïß,ìÌz­B®š6b´å¨å´£86Ápp´¥r6Ú–žŒ_‹™K
    ԝh)–LagùG­‰V·¶|“³B8¦ SimZ
    ¤T4)Ž¸Ø‰DxÍR¤,¯|•ý3Ø"COãŽô¸ÚèÕ+kÏŒn.T³\ûjÑ£þæaXÐÅÊUÓë·©×ý€GsF¥}ÚÑèŒûÆ-&Û5@P õÝx¯Îä”ͭv²)å‘Ùe_ÊĸCGpÃÒ•óÏ¥àœIz*"ög{ó¹ñýÒ9,îD³hÒ²ÿ¤Ô¯/c9¬Â<~ځqZ+Êšÿn®ˆÊ 0‚	+‚&B‚0‚‚ ’E¢œ`a¼h–5p+檳Œ™#¹ãTD~x'¯дñÎ’BŸòíKDÿkWäN²2`S%Úî&‡
    8n8Ýn;–#Q‡ç›~ûúZñ-:Uƒ§n7Ž	ý™8TèÊ'†°A±></Ⱥ.¹
    ›Ž`Oûl=­nºn-Ól žüžß¹d§ñkTìé}`äWÈ¢‡Ì÷‘â?7D¨ýÜ$õàuhzÀ­¯üql§‘,²Œ»)âBþS¢¹t+ÿ’^
    ªÚÁ7·…S¦÷ßUWe?ê=yC-Ô4ÚD/¬$ú9w­Ûί²¯Ì²5.1Ž!N†¥°j/zI¦ìÂSô@ßµ¾Cû¡"KuKõœßÙ“@Ý^º\>íiÄãP´¹øF0tL	HaàLÄw¡¼³E˜9£&aÐ~£k¢ÈS8¾qT(çÓJÄîWf KÖÉEeÅF´æCðåf[@]-Z½ÔaÏvÔ	xPéÁ<.v‰ RV &ÛgŽwð,ô”´ZÜWs@UAÁ¾áHÙÂ: ¸+®E1ÞôR¹i*nS=ð5moJô² ö2õ6ÕOíŒþùŠÂQŒºŽm³ Ç$àHz4pœ®Èqª$ÑIՐŸc„Tm‚*@'*S¬ØgGzL©þb·aÁÑðŸÈʏ+$ÏÔ—a¡ø†³Ò×/žœflÎA˜}LF¡1Lª³d0Ç\4Õ%žü÷Na”Ö³Ýq)½IÐ|ß+'Gò^Ó(.RNš§j#W`MèÞƒ’®Àsÿ6Äšaè@v6ƒw(Ý•u<_o)¦£ЋÄíW7v.)¤UÂhu€=EH0¶Ç·]?¥\Y+ø›â¾HãO )®WÆMóiÿÑ.c8W€áýbë¨œžg £ÖÛþÃG!1,oüòLŒA„hϝídVnïµÍíÑýÿÓò{Xúq•S”
    ™ÅÌHSa”³¶÷ã5
    &”Ô–JÎäì5f¾1>~㟢n¾N°Îô‹ Üoœµ΢ÿðÖl¥k|ÐÿÿÔ¬ŠŠâèճх7V^=Ù %îœuÇjx÷æŒJü¬4qѻüõCrôŠûÕÀµ\‡®gýíA¥¢$›»Ûû¦Çìõ(_6SŽ|$d.´	‡o ´¾ªÝ_áîÊà{•¾°»hsé'|s}“a¢#{÷[Î-D„Š‚†lŸÀ ÅÆ~›óc>§JPRàÐXMÂ
    ʦeÈð‚>Äйê	÷9Õ¿b„[ñó`ÛS'§Ö$JßZ-ûW²mê¬*¦$/P‘•Û˜­³o1 €J¸- 0±	+‚&C£0 `ÁÒÆV	Y'´ìNÑ	9Þ:µžkg¹²éuuS;v¹ÚGî«–÷¿É@jéfmTYz>)cPÐô½¤KGd'פ9e¦·8y7쿵¹3«ÓM_÷MÓ5±²Íí°Q†Ú’ë°þÆAL}éGòâz§ ƒS=컸Ýî°47ÊF`5„T4<Ѫ(Çg¶³ãž` ¥¥¥Z0‘	+‚&Dƒ0€@F^læEqX	ÉzëÝì§.Íô]Z¸(]“ %*É¡
    I²Ð˹Îp@ÒöúkQd;<£u[~š³â‹døÓµŒ‡Xy³+m2œ
    […ÃpÐ
    ‡dÒ¢ÍJ¼›UþèmÑQV Î+p¸ÍÆá2˜R@ ¥¥¥Z0	+‚&E
    0   ¥¥¥¥0±	+‚&F£0 `}Ø—? §ÎÃNû8ÃRZšòÿsm%’Ô^ã‘á4÷ÕÚ'ª4;QÀ[诟϶ys½
    3CÇúºß‡ÊÉîŠR)Æ…5ýàš§ÞÌr·Š!‘¾—™e9~&è…Xs:àw¦ãæJ³-{ÂIÛ“±= .k}=ÐÍ'3™#üK”Nzôù­„¦‹{çœ$%õ` ¥¥¥Z0‘	+‚&Gƒ0€@Ű¥•ò#QÞï7Ž}T¬‹ÂuêK$÷óêØp¤°·Õ-¨õ‡£w	¢<O™f<ÿxŸçžþ½êÏV3Ýû5'(H£‚7 ÎÕ4(– ªô	Å„rDã°Ï‹l-A,Õ´|Î|3ùsç*Rçw%@ ¥¥¥Z0	+‚&H0
      ¥¥¥¥0ç	+‚&IÙ0Ö€        ¥¥¥¥0	+‚&J0
        ¥¥¥Z0	+‚&L0
     þ ¥¥¥Z0	+‚&M0
        ¥¥¥Z0	+‚&N0       ¥¥¥¥0	+‚&O0       ¥¥¥¥0 	+‚&P0         ¥¥¥¥0	+‚&Q0   0
    	*†H†÷
     ‚ lÓì¡:ñ­vX‹†è벝<ZÝ=EñõÁ £~QBúÑE'ôfkñt˜¯i °>v˺FO
    ô?ͯuÒmPäp©Éz!è’¢‘Çp->I±Eâç_Û¿	òãG!®Ö@K„~=Ç ¯«[tNײ ø'ÔŸÌÌ.C‹–¹tŸ¯‘âw؆f¶àa9-Š……©­{Áˆ rŒ¼;¹§ÿ±w’`Cà•ëB]•Áê§&ƒ€È¡lŸõk²àz2ŠÚ$GÔ‰K¶ÎWhËè"ƒµj’´4Zߪu#/t¢ôLkä5–‰> „Zc##¸Æ³¦$ïØ‘Ëð´&Ìæ1êfÀK/Óçar¥wý²q(nû–
    ﯗdä	¥Ðø³À6T´ Ã7	qЦ+ÝäµÎzú^¸ËߘTË^Q¬Äߏ ±IaÔ~—…f.Ø`@zëcÐÙ–~‹û]ˆØI€Z$TŽÓ„½g{ ¯_Ôþ·7}â&¼ý=òù™ptÇùõ,ì7DYÝxÞÕƒc?cìœZ–ûl"k‹žW	N݇A‰+¤¨Pe? ¬yå·Ö;¡œ†øÝõÓF`³sX/Â_Þìó{ÿv:ëOsØPÇ<™îD«Çg¹î7ì?ˆ…„1;W½ôñ°CØlñ¾Ö9–.pšJJ£
    this is final_certificate.bin file.
  • The certificate is attached as code block in text format. Please attach the file itself.
  • 0��0�h�Fcq�W���|�h;G)m���*0
    	*�H��
     0��10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    250818095153Z
    250917095153Z0��10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    	*�H��
     � 0�
    n�����g��c
    �FQ���T=R`t%P���S�-P-�"����]���lf����k��� �r0p0U0�0`	+�&"S0Q	`�He@�G���y���v-�
    ���+M��K�<�\?��ut�UdT��J�$�e^4�Z�}~qq���1n�/X | 0
    	*�H��
     � <���	�A�`�c8W�Xa�@'�~��dzC�]r����js,l.��Pj!�W��9�m�ݔ}Bw!��hc��ڽL�d'����~�0'�|"����Z��{��Zw^��L#���R�u��kEA��x�x�xdI�)<��U�%��QR��ι�Y�I���;׭��ۤ�C<4�+Sk��+��M��˜�TIoi�{#8�?�lB��#����f�k?S�/Rq:��r}r�šG+�3Ey(��,n��/�6�|�d�F�<]^��f��LQs�L�%���XId����c?����y����0G<��#�3g�s
    �ZU�#a�&D�X����֑���J#�A��p��Q_�hd�ׄ��T�n�8i��=߉�\{GD+�����xb��ιbf�E�j�M�b�O����=@IS�D)/JѾ�U�i���rG̴�q����'}�	�-rB�8uGw �%a.�S���^����N�U7��H�3r!�:�Do;�)�0�0��:øf{��g�.#�\M��0
    	*�H��
     0��10	UoR10	Urx10U 
    gQE843yQV0sag1+0)U
    250818095153Z
    gQE843yQV0sag1+0)U
    	*�H��
     � 0�
    �ZB7�*��n��g�� �sJh(1�������E~����;ǃ�!q��8�R�3��6�N��)�͛*�l_{��:y j}����X*�^�N��;O����4�� �Y-�^h�L���-v�X�P�7nfxo�0FM4��J���{Ů�2��l?��35�M��n`TP�~m���� ���+�7�Y�J�E�	��r3�^]�Z�!T����U�'�M	�@�.f�e�n��8N�a�t��_Q�B�����K�i��� ���0��0U0�0�	+�&@�0�� 	�j{2I>(��9��:��ڴn�OiI��%6}�����m�7�Lu�[���R���$SH�����9��C�pd��e�(����8�,I��y@���E)H���wr*{�#��,?����:�6t�u�G$}KZ��-��ݽr�\i����nQߎ$x�4��2��r�7��ɻ�
    M��ɍLo���<��#89>a����(Zؖ5�iS��D�,,��>}a�3��R�m�x��X��C������)Xo搱��\;jn��+߳�k��N#H�H�����M�$�� ;�j�<�lu�qd�М2�Dc
    ���������/[��$0���5��V(6����R��'Y��l���ae[�С�<m��d����'H��z�����B0ci�g�ԍ��J;��5h�ax����Z�l��#�#��b���зY�)JK{w�pv�� `B���\�:�%7�Fq��l�=���� ;����QF0�]E�s�Y�	�ra#����3��^|C.���-�1l�+, 0�	+�&A�0�� W�>E�n��-�߱�RG]U���M �rzX{h�2�x�l\��!Q����?�mU�$a���D��o�NF�o�g-]SW�k ��&�l39?�K��^r������ť��1� �⛣V!"�G�1�VN)|�o?T�/� ��[/���`fۣ	��e��׍�`WX�d,7�2�ai?�WVޮ�X�V�+�ѽ�r����G����+@N\�/�_�"0;��+8�t��#�4�d�9͢O�w�}�g^��EEF�P~�8��^�� �0��G��ix��U�~����Nct�L���mǏw�B��Q<�L�ت�Q���#��a�������Ԟ�Z�a��"m~����~ˑ
    �ˋ$�U������-�Pg+o��w3\��qo/���e�o��D����\i��� [q���ԩ��	�@
    ��8����I
    2�Z���h�2��|��d���|�"U��lS,�e���&�;T��#�N:�x��O ��KQ&Y�B��I�-Zb�;Ӹ�������Y;�KF
    [>-�EYQ]cZ�^�t�`����*����+�ɖ��s�y���u3:�P~��9K-������3K����EZ��9��Xm̫����xj�*�<sXc	M�T��i3�ii`=�Sͳ�5����pa����a��g=Z�=��o��������{N���hwY��\О�]�h�D�&ƕ��]���]����d'N�3xxq�F����|%xX���6��!QJ��7|"�#�T���� ���d����,��z�B��6b��崣86�pp��r6ږ��_��K
    ԝh)�Lag��G��V��|��B8��SimZ
    �T4)��؉Dx�R�,�|��3�"CO�����+kόn.T�\�jѣ��aX���U�뷩���GsF�}������-&�5@P ��x���ͭv�)���e_�ĸCGp�ҕ�ϥ�Iz*"�g{����9,�D�hҲ��ԯ/c9���<~ځqZ+ʚ�n��� 0�	+�&B�0�� �E��`a�h�5p+檳��#��TD~x'��д�ΒB���KD�kW�N�2`S%��&�
    �8n8�n;�#Q��~��Z��-:U��n7�	��8T��'���A�></Ⱥ.��
    ��`O�l=�n�n-�l �����d��kT��}`�WȢ�����?7D���$��uhz����ql���,���)�B�S��t+���^
    ���7��S���UWe?�=yC�-�4�D/�$�9w������̲5.1�!N����j/zI���S�@�����C��"K�uK���ٓ@�^�\>�i��P���F0tL	Ha�L�w���E�9�&a�~�k��S8�qT(��J��Wf�K��Ee�F��C��f[@]-Z��a�v�	xP��<.v� RV &�g�w�,��Z�Ws@UA���H��: �+�E1��R�i*nS=�5moJ� �2�6�O�����Q���m� �$�Hz4p���q�$�IՐ�c�T��m�*@'*S��gGzL��b�a����ʏ+$�ԗa������/��fl�A�}LF�1L��d0�\4�%���Na�ֳ�q)�I�|�+'G�^�(.RN��j#W`M�ރ���s�6Ěa�@v6�w(�ݕu<_o)��Ћ��W7v.)�U�hu�=EH0�Ƿ]?�\�Y+����H�O )�W�M�i��.c8W���b�먜�g �����G!1,o��L�A�hϝ�dVn���������{X�q�S�
    ���HSa�����5
    &�ԖJ���5f�1>~㟢n�N��� �o��΢����l�k|���Ԭ����ճх7V^=٠%�u�jx��J��4qѻü�Cr�����\��g��A��$��������(_6S�|$d�.�	�o ����_����{����hs�'|s�}�a�#{�[�-D����l�� ��~��c>�JPR��XM�
    �ʦe��>�й�	�9տb�[��`�S'��$J�Z-�W�m�*�$/P��ۘ��o1 �J�- 0��	+�&C��0��`���V	Y'��N�	9�:��kg���uuS;v��G���@j�fmTYz>)cP���KGd'פ9e��8y7쿵�3��M_�M�5����Q�ڒ���AL}�G��z� �S=컸���47�F`5�T4<Ѫ(�g���` ���Z0��	+�&D��0��@F^l�EqX	�z����.��]Z�(]��%*ɡ
    I��˹�p@���kQd;<�u[~���d�ӵ��Xy�+m2�
    [��p��
    �dҢ�J��U��m��QV��+p����2�R@ ���Z0	+�&E
    0   ����0��	+�&F��0��`}ؗ? ����N�8��RZ���sm%��^��4���'��4;Q��[诟��ys�
    3C���ߏ����R)ƅ5�����r��!����e9~&��Xs:�w���J�-{�Iۓ�= .k}=��'3�#�K�Nz������{�$%�` ���Z0��	+�&G��0��@Ű���#�Q��7�}T���u�K$����p����-����w	�<O�f<�x�珞����V3��5'(H��7���4(� ��	ńrD�ϋl-A,մ|�|3�s�*R�w%@ ���Z0	+�&H0
        ���Z0	+�&L0
     � ���Z0	+�&M0
    	*�H��
     � l���:�vX���벝<Z�=E��� ��~QB��E�'�fk�t��i �>v˺�FO
    �?ͯu�mP�p��z!蒢��p->I�E��_ۿ	��G!���@K�~=����[tNײ �'ԟ��.C���t����w؆f��a9-�����{�� r���;����w�`C��B]���&��ȡl��k��z2�ڝ$GԉK��Wh��"��j��4Zߪu#/t��Lk�5����> �Zc##�Ƴ�$�ؑ��&��1�f�K/��ar�w��q(n��
    ���d�	�����6T� �7	qЦ+���z�^��ߘT�^Q��ߏ �Ia�~��f.�`@z�c�ٖ~��]��I�Z$�T�ӄ�g{��_���7}�&��=���pt���,�7DY�x�Ճc?c�Z��l"k��W	N݇A�+��Pe? �y��;��������F`�sX/�_���{�v:�Os�P�<��D��g��7�?���1;W���C�l��9�.p�JJ�
