AM625: AM62x Secure Boot Stuck at "Starting Keywriting" — VPP Hardware Toggle Issue
Part Number: AM625
Hello TI Support Team,
I am implementing secure boot on a custom AM62x-based board using dummy keys (HS‑FS variant) based on TI’s AM62x secure boot guide. I have followed all documentation steps, including:
  • Generating tiboot3.bin (with embedded certificate) via gen_keywr_cert.sh.
  • Flashing the OTP keywriter/SBL (tiboot3.bin) via DFU as described in the official guide.
  • Monitoring UART output during secure key provisioning.
    Upon flashing, the console output halts at:
    However, it never proceeds to:
    Starting Keywriting
    Enabled VPP
    keys Certificate found: ...
    Keywriter Debug Response: 0x0
    Success Programming Keys
    My Question:
    1) Is the hardware-level presence and assertion of the 1.8 V VPP rail on MSP_8 strictly required, even when using dummy keys, for the secure boot keywriting process to proceed? Or is there any software-based mechanism or alternative configuration that allows keywriting to continue without hardware VPP?
    Kapil
  • This is again not the correct certificate as the md5sum differs from the md5sum you shared in your previous response
    ❯ md5sum 2860.final_certificate.bin.txt
    c3d93114b0694851d8fa52b19b27b41e  2860.final_certificate.bin.txt
    ❯ openssl asn1parse -in 2860.final_certificate.bin.txt -inform DER
        0:d=0  hl=4 l=1664 cons: SEQUENCE
        4:d=1  hl=4 l=1128 cons: SEQUENCE
        8:d=2  hl=2 l=   3 cons: cont [ 0 ]
       10:d=3  hl=2 l=   1 prim: INTEGER           :02
       13:d=2  hl=2 l=  20 prim: INTEGER           :4663719957B7DFE07CC2683B47296DF403D0E62A
       35:d=2  hl=2 l=  13 cons: SEQUENCE
       37:d=3  hl=2 l=   9 prim: OBJECT            :sha512WithRSAEncryption
    Error in encoding
    133043991890816:error:0D07209B:asn1 encoding routines:ASN1_get_object:too long:crypto/asn1/asn1_lib.c:91:
    I am not sure what is going on.
    Please generate the certificate, run those md5sum & openssl commands, and share the same certificate to me for cross verifying. In fact, please share the generated certificate and the built keywriter binary as well (tiboot3.bin).
  • we regenrate final_certificate.bin file
    $ ./gen_keywr_cert.sh -t tifek/ti_fek_public.pem --msv 0xC0FFE -b-def --bmek-def -s-def --smek-def --keycnt 2 --keyrev 1
    # Using MSV[19:0]: 0x000C0FFE
    INFO: Using default BMPK for programming
    INFO: Using default BMEK for programming
    INFO: Using default SMPK for programming
    INFO: Using default SMEK for programming
    # Using Key Count: 0x00000003
    # Using Key Rev: 0x00000001
    Generating Dual signed certificate!!
    GEN: AES256 key generated, since not provided
    # encrypt aes256 key with tifek public part
    # encrypt SMPK-priv signed aes256 key(hash) with tifek public part
    # encrypt smpk-pub hash using aes256 key
    writing RSA key
    # encrypt smek (sym key) using aes256 key
    # encrypt BMPK-priv signed aes256 key(hash) with tifek public part
    # encrypt bmpk-pub hash using aes256 key
    writing RSA key
    # encrypt bmek (sym key) using aes256 key
    1668	secondary_cert.bin
    5383	primary_cert.bin
    7051	../../x509cert/final_certificate.bin
    # SHA512 Hashes of keys are stored in verify_hash.csv for reference..
    This is the md5sum terminal output
    $ md5sum -b  final_certificate.bin
    689992a645b1185d42d1ff29fcce0015 *final_certificate.bin
    This is the openssl command terminal output
    $ openssl asn1parse -in final_certificate.bin -inform DER
       13:d=2  hl=2 l=  20 prim: INTEGER           :542CE09F3418A456448717DB05C2C8C14DFF2786
       48:d=3  hl=2 l=   0 prim: NULL
       50:d=2  hl=3 l= 191 cons: SEQUENCE
       53:d=3  hl=2 l=  11 cons: SET
       55:d=4  hl=2 l=   9 cons: SEQUENCE
       57:d=5  hl=2 l=   3 prim: OBJECT            :countryName
       62:d=5  hl=2 l=   2 prim: PRINTABLESTRING   :oR
       66:d=3  hl=2 l=  11 cons: SET
       68:d=4  hl=2 l=   9 cons: SEQUENCE
       70:d=5  hl=2 l=   3 prim: OBJECT            :stateOrProvinceName
       75:d=5  hl=2 l=   2 prim: UTF8STRING        :rx
       79:d=3  hl=2 l=  22 cons: SET
       81:d=4  hl=2 l=  20 cons: SEQUENCE
       83:d=5  hl=2 l=   3 prim: OBJECT            :localityName
       88:d=5  hl=2 l=  13 prim: UTF8STRING        :gQE843yQV0sag
      103:d=3  hl=2 l=  43 cons: SET
      105:d=4  hl=2 l=  41 cons: SEQUENCE
      107:d=5  hl=2 l=   3 prim: OBJECT            :organizationName
      112:d=5  hl=2 l=  34 prim: UTF8STRING        :dqhGYAQ2Y4gFfCq0t1yABCYxex9eAxt71f
      148:d=3  hl=2 l=  17 cons: SET
      150:d=4  hl=2 l=  15 cons: SEQUENCE
      152:d=5  hl=2 l=   3 prim: OBJECT            :organizationalUnitName
      157:d=5  hl=2 l=   8 prim: UTF8STRING        :a87RB35W
      167:d=3  hl=2 l=  24 cons: SET
      169:d=4  hl=2 l=  22 cons: SEQUENCE
      171:d=5  hl=2 l=   3 prim: OBJECT            :commonName
      176:d=5  hl=2 l=  15 prim: UTF8STRING        :x0FSqGTPWbGpuiV
      193:d=3  hl=2 l=  49 cons: SET
      195:d=4  hl=2 l=  47 cons: SEQUENCE
      197:d=5  hl=2 l=   9 prim: OBJECT            :emailAddress
      208:d=5  hl=2 l=  34 prim: IA5STRING         :kFp5uGcgWXxcfxi@vsHs9C9qQWGrBs.com
      244:d=2  hl=2 l=  30 cons: SEQUENCE
      246:d=3  hl=2 l=  13 prim: UTCTIME           :250818135242Z
      261:d=3  hl=2 l=  13 prim: UTCTIME           :250917135242Z
      276:d=2  hl=3 l= 191 cons: SEQUENCE
      279:d=3  hl=2 l=  11 cons: SET
      281:d=4  hl=2 l=   9 cons: SEQUENCE
      283:d=5  hl=2 l=   3 prim: OBJECT            :countryName
      288:d=5  hl=2 l=   2 prim: PRINTABLESTRING   :oR
      292:d=3  hl=2 l=  11 cons: SET
      294:d=4  hl=2 l=   9 cons: SEQUENCE
      296:d=5  hl=2 l=   3 prim: OBJECT            :stateOrProvinceName
      301:d=5  hl=2 l=   2 prim: UTF8STRING        :rx
      305:d=3  hl=2 l=  22 cons: SET
      307:d=4  hl=2 l=  20 cons: SEQUENCE
      309:d=5  hl=2 l=   3 prim: OBJECT            :localityName
      314:d=5  hl=2 l=  13 prim: UTF8STRING        :gQE843yQV0sag
      329:d=3  hl=2 l=  43 cons: SET
      331:d=4  hl=2 l=  41 cons: SEQUENCE
      333:d=5  hl=2 l=   3 prim: OBJECT            :organizationName
      338:d=5  hl=2 l=  34 prim: UTF8STRING        :dqhGYAQ2Y4gFfCq0t1yABCYxex9eAxt71f
      374:d=3  hl=2 l=  17 cons: SET
      376:d=4  hl=2 l=  15 cons: SEQUENCE
      378:d=5  hl=2 l=   3 prim: OBJECT            :organizationalUnitName
      383:d=5  hl=2 l=   8 prim: UTF8STRING        :a87RB35W
      393:d=3  hl=2 l=  24 cons: SET
      395:d=4  hl=2 l=  22 cons: SEQUENCE
      397:d=5  hl=2 l=   3 prim: OBJECT            :commonName
      402:d=5  hl=2 l=  15 prim: UTF8STRING        :x0FSqGTPWbGpuiV
      419:d=3  hl=2 l=  49 cons: SET
      421:d=4  hl=2 l=  47 cons: SEQUENCE
      423:d=5  hl=2 l=   9 prim: OBJECT            :emailAddress
      434:d=5  hl=2 l=  34 prim: IA5STRING         :kFp5uGcgWXxcfxi@vsHs9C9qQWGrBs.com
      470:d=2  hl=4 l= 546 cons: SEQUENCE
      474:d=3  hl=2 l=  13 cons: SEQUENCE
      476:d=4  hl=2 l=   9 prim: OBJECT            :rsaEncryption
      487:d=4  hl=2 l=   0 prim: NULL
      489:d=3  hl=4 l= 527 prim: BIT STRING
     1020:d=2  hl=2 l= 114 cons: cont [ 3 ]
     1022:d=3  hl=2 l= 112 cons: SEQUENCE
     1024:d=4  hl=2 l=  12 cons: SEQUENCE
     1026:d=5  hl=2 l=   3 prim: OBJECT            :X509v3 Basic Constraints
     1031:d=5  hl=2 l=   5 prim: OCTET STRING      [HEX DUMP]:30030101FF
     1038:d=4  hl=2 l=  96 cons: SEQUENCE
     1040:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.34
     1051:d=5  hl=2 l=  83 prim: OCTET STRING      [HEX DUMP]:3051060960864801650304020304407C5EBAB71944C51EA737CAF93B26295B20F54FE6E5A191B4F8FDF5CE39293D1CDCF3CE600D6D08A384F44F96FF97E98076081B93465FF392779986EF5289828302021507
     1136:d=1  hl=2 l=  13 cons: SEQUENCE
     1138:d=2  hl=2 l=   9 prim: OBJECT            :sha512WithRSAEncryption
     1149:d=2  hl=2 l=   0 prim: NULL
     1151:d=1  hl=4 l= 513 prim: BIT STRING
     1668:d=0  hl=4 l=5379 cons: SEQUENCE
     1672:d=1  hl=4 l=4843 cons: SEQUENCE
     1676:d=2  hl=2 l=   3 cons: cont [ 0 ]
     1678:d=3  hl=2 l=   1 prim: INTEGER           :02
     1681:d=2  hl=2 l=  20 prim: INTEGER           :7B6A018CB5B1AB5F23EEDE76F75896FB953CAF56
     1703:d=2  hl=2 l=  13 cons: SEQUENCE
     1705:d=3  hl=2 l=   9 prim: OBJECT            :sha512WithRSAEncryption
     1716:d=3  hl=2 l=   0 prim: NULL
     1718:d=2  hl=3 l= 191 cons: SEQUENCE
     1721:d=3  hl=2 l=  11 cons: SET
     1723:d=4  hl=2 l=   9 cons: SEQUENCE
     1725:d=5  hl=2 l=   3 prim: OBJECT            :countryName
     1730:d=5  hl=2 l=   2 prim: PRINTABLESTRING   :oR
     1734:d=3  hl=2 l=  11 cons: SET
     1736:d=4  hl=2 l=   9 cons: SEQUENCE
     1738:d=5  hl=2 l=   3 prim: OBJECT            :stateOrProvinceName
     1743:d=5  hl=2 l=   2 prim: UTF8STRING        :rx
     1747:d=3  hl=2 l=  22 cons: SET
     1749:d=4  hl=2 l=  20 cons: SEQUENCE
     1751:d=5  hl=2 l=   3 prim: OBJECT            :localityName
     1756:d=5  hl=2 l=  13 prim: UTF8STRING        :gQE843yQV0sag
     1771:d=3  hl=2 l=  43 cons: SET
     1773:d=4  hl=2 l=  41 cons: SEQUENCE
     1775:d=5  hl=2 l=   3 prim: OBJECT            :organizationName
     1780:d=5  hl=2 l=  34 prim: UTF8STRING        :dqhGYAQ2Y4gFfCq0t1yABCYxex9eAxt71f
     1816:d=3  hl=2 l=  17 cons: SET
     1818:d=4  hl=2 l=  15 cons: SEQUENCE
     1820:d=5  hl=2 l=   3 prim: OBJECT            :organizationalUnitName
     1825:d=5  hl=2 l=   8 prim: UTF8STRING        :a87RB35W
     1835:d=3  hl=2 l=  24 cons: SET
     1837:d=4  hl=2 l=  22 cons: SEQUENCE
     1839:d=5  hl=2 l=   3 prim: OBJECT            :commonName
     1844:d=5  hl=2 l=  15 prim: UTF8STRING        :x0FSqGTPWbGpuiV
     1861:d=3  hl=2 l=  49 cons: SET
     1863:d=4  hl=2 l=  47 cons: SEQUENCE
     1865:d=5  hl=2 l=   9 prim: OBJECT            :emailAddress
     1876:d=5  hl=2 l=  34 prim: IA5STRING         :kFp5uGcgWXxcfxi@vsHs9C9qQWGrBs.com
     1912:d=2  hl=2 l=  30 cons: SEQUENCE
     1914:d=3  hl=2 l=  13 prim: UTCTIME           :250818135242Z
     1929:d=3  hl=2 l=  13 prim: UTCTIME           :250917135242Z
     1944:d=2  hl=3 l= 191 cons: SEQUENCE
     1947:d=3  hl=2 l=  11 cons: SET
     1949:d=4  hl=2 l=   9 cons: SEQUENCE
     1951:d=5  hl=2 l=   3 prim: OBJECT            :countryName
     1956:d=5  hl=2 l=   2 prim: PRINTABLESTRING   :oR
     1960:d=3  hl=2 l=  11 cons: SET
     1962:d=4  hl=2 l=   9 cons: SEQUENCE
     1964:d=5  hl=2 l=   3 prim: OBJECT            :stateOrProvinceName
     1969:d=5  hl=2 l=   2 prim: UTF8STRING        :rx
     1973:d=3  hl=2 l=  22 cons: SET
     1975:d=4  hl=2 l=  20 cons: SEQUENCE
     1977:d=5  hl=2 l=   3 prim: OBJECT            :localityName
     1982:d=5  hl=2 l=  13 prim: UTF8STRING        :gQE843yQV0sag
     1997:d=3  hl=2 l=  43 cons: SET
     1999:d=4  hl=2 l=  41 cons: SEQUENCE
     2001:d=5  hl=2 l=   3 prim: OBJECT            :organizationName
     2006:d=5  hl=2 l=  34 prim: UTF8STRING        :dqhGYAQ2Y4gFfCq0t1yABCYxex9eAxt71f
     2042:d=3  hl=2 l=  17 cons: SET
     2044:d=4  hl=2 l=  15 cons: SEQUENCE
     2046:d=5  hl=2 l=   3 prim: OBJECT            :organizationalUnitName
     2051:d=5  hl=2 l=   8 prim: UTF8STRING        :a87RB35W
     2061:d=3  hl=2 l=  24 cons: SET
     2063:d=4  hl=2 l=  22 cons: SEQUENCE
     2065:d=5  hl=2 l=   3 prim: OBJECT            :commonName
     2070:d=5  hl=2 l=  15 prim: UTF8STRING        :x0FSqGTPWbGpuiV
     2087:d=3  hl=2 l=  49 cons: SET
     2089:d=4  hl=2 l=  47 cons: SEQUENCE
     2091:d=5  hl=2 l=   9 prim: OBJECT            :emailAddress
     2102:d=5  hl=2 l=  34 prim: IA5STRING         :kFp5uGcgWXxcfxi@vsHs9C9qQWGrBs.com
     2138:d=2  hl=4 l= 546 cons: SEQUENCE
     2142:d=3  hl=2 l=  13 cons: SEQUENCE
     2144:d=4  hl=2 l=   9 prim: OBJECT            :rsaEncryption
     2155:d=4  hl=2 l=   0 prim: NULL
     2157:d=3  hl=4 l= 527 prim: BIT STRING
     2688:d=2  hl=4 l=3827 cons: cont [ 3 ]
     2692:d=3  hl=4 l=3823 cons: SEQUENCE
     2696:d=4  hl=2 l=  12 cons: SEQUENCE
     2698:d=5  hl=2 l=   3 prim: OBJECT            :X509v3 Basic Constraints
     2703:d=5  hl=2 l=   5 prim: OCTET STRING      [HEX DUMP]:30030101FF
     2710:d=4  hl=4 l= 539 cons: SEQUENCE
     2714:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.64
     2725:d=5  hl=4 l= 524 prim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
     3253:d=4  hl=4 l=1051 cons: SEQUENCE
     3257:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.65
     3268:d=5  hl=4 l=1036 prim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
     4308:d=4  hl=4 l=1051 cons: SEQUENCE
     4312:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.66
     4323:d=5  hl=4 l=1036 prim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
     5363:d=4  hl=3 l= 177 cons: SEQUENCE
     5366:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.67
     5377:d=5  hl=3 l= 163 prim: OCTET STRING      [HEX DUMP]:3081A004603343CC7D7FDE2C78BB9CBDC1F9B398C9743E1CA14512E84A00A9445AF598111BE190D0A569A343BB211F88685F092097D1A6B8D814633B01796663DA54CAF42757BFC22593D812389EC4C18F64FB03EE8FE40E58D496FD9FF3D6031119E796310410263DC569E6C1BC594C0B1B2B2E6C21EC0420ECE1ABC5B40A002FFEEBA37D4F819EFEB4B105FCA592C471F916FC40F8E27377020160020500A5A5A55A
     5543:d=4  hl=3 l= 145 cons: SEQUENCE
     5546:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.68
     5557:d=5  hl=3 l= 131 prim: OCTET STRING      [HEX DUMP]:30818004409A7497A3DD6DDDD6FA39E22EAB262895A4E26C2F5ABF5150689B3574BD1DB60B956D1266A3BF5A39D110347D8E8A57408229C31548D3578DCAE38833B0DD6766041087C61B414E8D404713A9543058C4921C04204C89456A80F5507A81366F4FF29801E210679C4B67B4FB682FFC13CC9706C03A020140020500A5A5A55A
     5691:d=4  hl=2 l=  26 cons: SEQUENCE
     5693:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.69
     5704:d=5  hl=2 l=  13 prim: OCTET STRING      [HEX DUMP]:300B04020000020500A5A5A5A5
     5719:d=4  hl=3 l= 177 cons: SEQUENCE
     5722:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.70
     5733:d=5  hl=3 l= 163 prim: OCTET STRING      [HEX DUMP]:3081A0046040B1D972294FB832B526EFF9708E1A98BAC91F014198CB2F84C03B5667BB0BB8E4BDD24742258ED33DA9EE933394D7F9B4F5001B16D4E79B91FEE6ADC746D75A1EF6B6A680E233D33ADEA9DA39C92804C50A31293F56FC7ADFF84909722F348D0410EED36D0BC216657DA346FB2692B7459B04200AC83FEC07D3CAC63D190B5104854D0B07F3E714DD0C08808C289A79E5BE9121020160020500A5A5A55A
     5899:d=4  hl=3 l= 145 cons: SEQUENCE
     5902:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.71
     5913:d=5  hl=3 l= 131 prim: OCTET STRING      [HEX DUMP]:30818004406B26C3F5985B1E945A554BD004EC538E6DA28AA7D137B113A888AD6046F06E5BE766AFD00EBF00AA4588A5659DD30BBB50306A515B7603B323BDEE4D925EDAC204106C0C9374510CC8CFEB4761DB74BA1E600420EBFDFCA8C98E3D39D80C0E74D3CB2EC0CBAF2CB399085C1F864BDD112E828943020140020500A5A5A55A
     6047:d=4  hl=2 l=  25 cons: SEQUENCE
     6049:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.72
     6060:d=5  hl=2 l=  12 prim: OCTET STRING      [HEX DUMP]:300A040100020500A5A5A5A5
     6074:d=4  hl=3 l= 231 cons: SEQUENCE
     6077:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.73
     6088:d=5  hl=3 l= 217 prim: OCTET STRING      [HEX DUMP]:3081D6048180000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000004100000000000000000000000000000000004200000000000000000000000000000000000000000000000000000000000000000041000000000000000000000000000000000020100020100020500A5A5A5A5
     6308:d=4  hl=2 l=  28 cons: SEQUENCE
     6310:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.74
     6321:d=5  hl=2 l=  15 prim: OCTET STRING      [HEX DUMP]:300D040400000001020500A5A5A55A
     6338:d=4  hl=2 l=  28 cons: SEQUENCE
     6340:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.76
     6351:d=5  hl=2 l=  15 prim: OCTET STRING      [HEX DUMP]:300D0404000C0FFE020500A5A5A55A
     6368:d=4  hl=2 l=  28 cons: SEQUENCE
     6370:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.77
     6381:d=5  hl=2 l=  15 prim: OCTET STRING      [HEX DUMP]:300D040400000003020500A5A5A55A
     6398:d=4  hl=2 l=  30 cons: SEQUENCE
     6400:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.78
     6411:d=5  hl=2 l=  17 prim: OCTET STRING      [HEX DUMP]:300F0406000000000000020500A5A5A5A5
     6430:d=4  hl=2 l=  30 cons: SEQUENCE
     6432:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.79
     6443:d=5  hl=2 l=  17 prim: OCTET STRING      [HEX DUMP]:300F0406000000000000020500A5A5A5A5
     6462:d=4  hl=2 l=  32 cons: SEQUENCE
     6464:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.80
     6475:d=5  hl=2 l=  19 prim: OCTET STRING      [HEX DUMP]:301104080000000000000000020500A5A5A5A5
     6496:d=4  hl=2 l=  21 cons: SEQUENCE
     6498:d=5  hl=2 l=   9 prim: OBJECT            :1.3.6.1.4.1.294.1.81
     6509:d=5  hl=2 l=   8 prim: OCTET STRING      [HEX DUMP]:3006040400000200
     6519:d=1  hl=2 l=  13 cons: SEQUENCE
     6521:d=2  hl=2 l=   9 prim: OBJECT            :sha512WithRSAEncryption
     6532:d=2  hl=2 l=   0 prim: NULL
     6534:d=1  hl=4 l= 513 prim: BIT STRING
    and this are the generated certificate and the built keywriter binary (tiboot3.bin).
    tiboot3+final_certificate.zip
  • Now, the certificate looks good.
    Is it still not working? Please share the logs including the TIFS ones.
    After flashing ti-boot3.bin, we observed the following output on the R5 UART console:
    Starting Keywriting
    Enabled VPP
    keys Certificate found: 0x43c16f00
    This seems to confirm that the keywriting step was successful using dummy keys.
    Issue:
    After this, we powered off the SoC, changed the boot mode switch, and powered the board back on. However, we are not seeing any UART output from the SoC at this stage.
    Questions:
    1. Is this the expected behavior immediately after programming dummy keys?
    2. What should be the next step after this keywriting step to proceed with the secure boot flow using dummy keys?
    3. At this point, what output is expected on the UART
  • What should be the next step after this keywriting step to proceed with the secure boot flow using dummy keys?
    You would need to flash the HSSE images.
    If you are booting SPL from SD card then you would need to replace the `tiboot3.bin` with `tiboot3-am62x-hs-evm.bin`.
    Thank you for the clarification.
    We are not using SD card boot; instead, we are using DFU (dfu-util) to flash images to the target storage .
    Could you please confirm:
    1.Whether it's correct to flash the tiboot3-am62x-hs-evm.bin (signed with dummy keys) via DFU using dfu-util?
    2.What is the correct flash offset or DFU alt setting to use when flashing this HS-SE signed SPL via DFU?
    3.Are there any other bootloader components (e.g., u-boot.img, tispl.bin) that also need to be signed with dummy keys and flashed accordingly?
    We want to ensure the entire boot chain is signed and flashed properly now that the keywriting step has succeeded.
    Thanks and looking forward to your guidance.
  • Please continue with the flow you have for flashing and booting the device. The only change required is flashing the HSSE tiboot3.bin instead of the HSFS one at the same offset. The `tispl.bin` and `u-boot.img` are already signed with the dummy keys.
    After flashing tiboot3-am62x-hs-evm.bin this is the R5 terminal output we got :-
    U-Boot SPL 2023.04 (Aug 25 2025 - 15:25:36 +0530)
    SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
    SPL initial stack usage: 13384 bytes
    SPL: failed to boot from all boot devices
    ### ERROR ### Please RESET the board ###
    we use "sudo dfu-util -c 1 -i 0 -a bootloader -D <path_to_tiboot3.bin>" this command to flash tiboot3-am62x-hs-evm.bin & this is terminal output we get :-
    $ sudo dfu-util -c 1 -i 0 -a bootloader -D /home/renu/my_boot/tiboot3.bin
    dfu-util 0.9
    Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
    Copyright 2010-2016 Tormod Volden and Stefan Schmidt
    This program is Free Software and has ABSOLUTELY NO WARRANTY
    Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
    dfu-util: Invalid DFU suffix signature
    dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
    Opening DFU capable USB device...
    ID 0451:6165
    Run-time device DFU version 0110
    Claiming USB DFU Interface...
    Setting Alternate Setting #0 ...
    Determining device status: state = dfuIDLE, status = 0
    dfuIDLE, continuing
    DFU mode device DFU version 0110
    Device returned transfer size 512
    Copying data from PC to DFU device
    Download	[=========================] 100%       294274 bytes
    Download done.
    state(6) = dfuMANIFEST-SYNC, status(0) = No error condition is present
    state(2) = dfuIDLE, status(0) = No error condition is present
    Done!
  • Could you please explain the steps you have been following to boot the HSFS device till now? If you did have a working setup then all that's required is using the HSSE tiboot3.bin instead of the HSFS one.
    1. As requested, here are the steps we followed to boot the device in HS-FS mode.
    # FOR FLASHING BOOTLOADER
    sudo dfu-util -R -a bootloader -D bootloader.bin
    sudo dfu-util -R -a tispl.bin -D tispl.bin
    sudo dfu-util -R -a u-boot.img -D u-boot.img
    stop autoboot, enter below commands -
    setenv dfu_alt_info ${dfu_alt_info_emmc}
    dfu 0 mmc 0
    # FOR FLASHING FILESYSTEM USE BELOW COMMANDS
    sudo dfu-util -a tiboot3.bin.raw -D tiboot3-raw.bin
    sudo dfu-util -a tispl.bin.raw -D tispl.bin
    sudo dfu-util -a u-boot.img.raw -D u-boot.img
    sudo dfu-util -a rootfs -D /PATH/TO/EXT4
    enter ctrl-C and enter below commands -
    mmc partconf 0 1 1 1
    mmc bootbus 0 2 0 0
    change the switch mode and set the environment
    setenv mmcdev 0
    setenv bootpart 0
    saveenv
            2.yes we have working setup. and we only flash the HSSE tiboot3.bin.
    also attaching the HSSE tiboot3.bin file
    5826.tiboot3.zip
  • # FOR FLASHING BOOTLOADER
    How do you generate this "bootloader.bin"? In those steps, all you need is to use the corresponding HSSE images for the "bootloader.bin" and "tiboot3-raw.bin".
  • Regarding the bootloader.bin,
    • The one i have been using so far was a GP image.
    • This steps i followed to generate it:
    Defcofig for tiboot3.bin :
    make ARCH=arm CROSS_COMPILE=/home/renu/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/arm-none-linux-gnueabihf- am62x_evm_r5_usbdfu_defconfig O=/home/renu/ti-processor-sdk-linux-am62xx-evm-09.00.00.03/board-support/build/out/r5
    build tiboot3.bin : dfu-usb
    make ARCH=arm CROSS_COMPILE=/home/renu/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/arm-none-linux-gnueabihf- O=/home/renu/ti-processor-sdk-linux-am62xx-evm-09.00.00.03/board-support/build/out/r5/ BINMAN_INDIRS=/home/renu/ti-processor-sdk-linux-am62xx-evm-09.00.00.03/board-support/prebuilt-images/am62xx-evm/
    my question is :- For moving to HSSE, do i need to regenrate a new bootloader.bin specifically for HSSE(using the HSSE signing process) or can i continue using the GP generated bootloader.bin together with the HSSE tiboot3.bin?
  • The build automatically generates "tiboot3.bin" for all the device types (GP, HSFS, HSSE) so you just need to pick the HSSE one. More specifically, after your build completes, you need to pick the "board-support/u-boot-build/r5/tiboot3-am62x-hs-evm.bin" binary.
  • Thank you for the clarification. I understand now that the build process already generates all tiboot3 variants, including the HSSE one. for HSSE boot , i should specifically use: "board-support/u-boot-build/r5/tiboot3-am62x-hs-evm.bin" binary.
    please confirm if my existing bootloader.bin also needs to be rebuilt/signed specifically for HSSE, or if only replacing tiboot3.bin with the HSSE version is sufficient for boot.
  • please confirm if my existing bootloader.bin also needs to be rebuilt/signed specifically for HSSE
    There is no file generated in the build by the name "bootloader.bin". You might have just renamed sometime the "tiboot3.bin" to "bootloader.bin".
    we flashed the HSSE tiboot3-am62x-hs-evm.bin from this path : "board-support/u-boot-build/r5/tiboot3-am62x-hs-evm.bin"
    and on the terminal i see the following output:
    Terminal ready
    From my understanding this idicates that tiboot3 was successfully executed and SYSFW was loaded, but it is not finding the next stage bootloader.
    could you please confirm:
    1. Does this log confirm that the HSSE tiboot3 was successfully flashed and executed?
    2. for the next steps, should i flash the HSSE version "board-support/u-boot-build/a53/ tispl.bin and u-boot".
  • I believe you are not exactly following the working HSFS setup. The R5 SPL (tiboot3.bin) is built separately for DFU and eMMC support. You would have separately generated these when you were working with HSFS. The same you just need to do for HSSE.
    In any case, the point is you need to build the R5 SPL separately for booting from DFU and eMMC.
    software-dl.ti.com/.../UG-General-Info.html
    I've successfully provisioned the device and now I see the device is now in HS-SE mode.
    SoC:   AM62X SR1.0 HS-SE
    Model: Texas Instruments AM625 SK
    this two output lines after flashing the u-boot from this i verify the device state.
    However, I'm currently facing an issue when trying to verify the device type (SoC ID) over UART.
    As per the documentation, after setting the appropriate boot mode switches (e.g., UART mode), I expect to see Boot ROM output (SoC ID, etc.) on the terminal. But I’m not seeing any output at all on the UART terminal — it stays completely blank.
  • As per the documentation, after setting the appropriate boot mode switches (e.g., UART mode),
    Please make sure you have set the bootmode pins correctly for the UART bootmode.
    And what is the output of the following commands run from the A53 U-Boot?
    => mw 0x43000030 0x3b 0x1;reset;
  • I attempted to boot the board using DFU mode as follows
    $sudo dfu-util -c 1 -i 0 -a bootloader -D /home/ti/board-support/u-boot-build/r5/tiboot3-am62x-hs-evm.bin
    $sudo dfu-util -R -a tispl.bin -D tispl.bin
    $sudo dfu-util -R -a u-boot.img -D u-boot.img
    Here is the output I received from these commands
    Terminal ready
    U-Boot SPL 2023.04 (Aug 28 2025 - 11:48:42 +0530)
    Trying to boot from DFU
    ##########################################################DOWNLOAD ... OK
    Ctrl+C to exit ...
    Authentication passed
    Loading Environment from nowhere... OK
    init_env from device 10 not supported!
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.9(release):v2.9.0-614-gd7a7135d32-dirty
    NOTICE:  BL31: Built : 09:34:15, Aug 24 2023
    U-Boot SPL 2023.04 (Aug 28 2025 - 12:07:43 +0530)
    SPL initial stack usage: 1856 bytes
    MMC: no card present
    ** Bad device specification mmc 1 **
    Couldn't find partition mmc 1:1
    Error: could not access storage.
    ####DOWNLOAD ... OK
    Ctrl+C to exit ...
    U-Boot 2023.04 (Aug 28 2025 - 12:07:43 +0530)
    EEPROM not available at 80, trying to read at 81
    Reading on-board EEPROM at 0x51 failed -1
    DRAM:  2 GiB
    Core:  72 devices, 32 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    In:    serial
    Out:   serial
    Err:   serial
    Net:   Could not get PHY for ethernet@8000000port@1: addr 0
    am65_cpsw_nuss_port ethernet@8000000port@1: phy_connect() failed
    No ethernet found.
    Hit any key to stop autoboot:  0
    => setenv dfu_alt_info ${dfu_alt_info_emmc}
    => dfu 0 mmc 0
    generic_phy_get_bulk : no phys property
  • I don't see those commands. You are just running dfu commands.
  • Hit any key to stop autoboot:  0
    resetting ...
    02000000011a0000616d3632780000000000000048535345010001000100010002a6000001000200d68ecb2c055dff11ade95bd927e837d2a53bc23b0a2800cebce4f106bcf309df2213912d77a157a8b7c2df40672a06a918034aa4c7d603e462481475225d49b81f6002b07cd9b0b7c47d9ca8d1aae57b8e8784a12f636b2b760d7d98a18f189760dfd0f23e2b0cb10ec7edc7c6edac3d9bdfefe0eddc3fff7fe9ad875195527d74b24aed316cea6820016d5ff184fbcf2fedcff26f288a6108d9c320a0e784a0CCCCCCCCCCCC
  • This shows that the warm reset to UART bootmode is working and you got the SoC ID dump from the ROM.
    So, this must be caused by the incorrect settings for the UART bootmode. Please rectify those and then you should see expected output.
    Facing a boot failure after flashing the bootloader components to eMMC.
    1.Booted the board in USB DFU mode and flashed to RAM using
    sudo dfu-util -R -a bootloader -D tiboot3-am62x-hs-evm.bin
    2. Stopped at U-Boot prompt and executed:
    dfu 0 mmc 0
    3.Then, I flashed to eMMC using:
    sudo dfu-util -a tiboot3.bin.raw -D tiboot3-am62x-hs-evm.bin
    4.In U-Boot, I configured the eMMC boot settings:
    mmc bootbus 0 2 0 0
    Then I powered off the board, changed the boot mode switches to eMMC boot, and powered it back on.
     Issue:
    After reboot, I consistently get the following error:
  • In any case, the point is you need to build the R5 SPL separately for booting from DFU and eMMC.
    Again, you need to have separate tiboot3.bin for booting from DFU and eMMC.
    e2e.ti.com/.../5980741
    We generated  separate tiboot3.bin for booting from DFU and eMMC
    Booted the board in USB DFU mode and flashed to RAM using:
    dfu 0 mmc 0
    Couldn't find part #1 on mmc device #0
    DFU entities configuration failed!
    (partition table does not match dfu_alt_info?)
    dfu - Device Firmware Upgrade
    Usage:
    dfu <USB_controller> [<interface> <dev>] [list]
      - device firmware upgrade via <USB_controller>
        on device <dev>, attached to interface
        <interface>
        [list] - list available alt settings
  • 2. Stopped at U-Boot prompt and executed:
    In your second last response, it was working but not now. So, you must have changed something. Do you recall doing something?
    Please share the output of the following commands
    => printenv dfu_alt_info_emmc
    => mmc dev 0
    => mmc part
    dfu_alt_info_emmc=rawemmc raw 0 0x800000 mmcpart 1; rootfs part 0 1; tiboot3.bin.raw raw 0x0 0x400 mmcpart 1; tispl.bin.raw raw 0x400 0x1000 mmcpart 1; u-boot.img.raw raw 0x1400 0x2000 mmcpart 1; u-env.raw raw 0x3400 0x100 mmcpart 1; sysfw.itb.raw raw 0x3600 0x800 mmcpart 1
    => mmc dev 0
    switch to partitions #0, OK
    mmc0(part 0) is current device
    => mmc part
    ## Unknown partition table type 0
  • There is no partition table in the eMMC. Since, the command was working, you have likely erased the partition table unknowingly. Please partition the eMMC again following the steps you must have followed in the past for the same.
    eMMC partition was successfully created.
    I'm encountering an issue while flashing the rootfs.
    mmc part shows that partition 1 exists and is ~15 GB.
    • It's a custom generated ext4 image ,
    • Size is around 8.6GB
    Isuue:
    When attempting to flash the rootfs image via DFU, I receive the following error:
    dfu-util: File size is too big: Success
    • The U-Boot command mmc part shows a valid GPT partition with a single rootfs partition (rootfs1), starting at LBA 0x22 and ending at 0x1da3fde, approximately 15.95 GB in size.
    • The rootfs image size is about 8.6 GB, well within the partition boundaries.
    • My dfu_alt_info_emmc environment variable is configured to use the rootfs partition via rootfs part 0 1.
    • After upgrading to the latest dfu-util version, the previous error "File size is too big: Success" no longer appears.
    • However, I am encountering a error during DFU flashing:
      dfu-util 0.11
      Copyright 2010-2021 Tormod Volden and Stefan Schmidt
      libusb version 1.0.25 (11696)
      dfu-util: Cannot allocate memory of size 0 bytes
    • U-Boot recognizes the partition, but the DFU process seems to fail with this allocation error
    The "dfu-util" tool is not owned by TI. It's an open source tool so any issues with it should be discussed on its specific forum. I can only suggest to try flashing a smaller size rootfs just to see if the "dfu-util" just fails for big file sizes.
    The ext4 filesystem flashing issue has been resolved — the ext4 gets flashed properly now. However, after this fix, The device boots successfully once, then reboots again. After 2-3 automatic reboots, the terminal output hangs midway during boot, and the system becomes unresponsive.
  • Please create new thread for this issue.
