Where is "OMX.TI.VPSSM3.VFPC.NF" sample source?
Hi.
I would like to use "OMX.TI.VPSSM3.VFPC.NF" on ti-ezsdk_dm816x-evm_5_03_01_15.
Input video format is OMX_COLOR_FormatYCbYCr (YUV422).
Input video resolution is 1920x1080.
Output video format is OMX_COLOR_FormatYUV420SemiPlanar (YUV420).
Where is sample source?
  • Shinji,
    EZSDK does not have sample app code for NF, you can follow similar to scalar code from decode_display. Let us know if you face issues.
    Vimal
  • Vimal, Thank you for reply.
    I try to use "OMX.TI.VPSSM3.VFPC.NF".
    NF modules is call backed CallBack_EmptyBufferDone().
    NF modules is complete video input.
    NF modules isn't call backed CallBack_FillBufferDone().
    NF modules is NOT complete video output.
    OMX_FillThisBuffer() is called by IL_ClientConnInConnOutTask().
     IL_ClientUseInitialOutputResources(NF ): OMX_FillThisBuffer() buf[0]=0x45d90000
     IL_ClientUseInitialOutputResources(NF ): OMX_FillThisBuffer() buf[1]=0x46087800
     IL_ClientUseInitialOutputResources(NF ): OMX_FillThisBuffer() buf[2]=0x4637f000
     IL_ClientUseInitialOutputResources(NF ): OMX_FillThisBuffer() buf[3]=0x46676800
     IL_ClientUseInitialOutputResources(NF ): OMX_FillThisBuffer() buf[4]=0x4696e000
     IL_ClientUseInitialOutputResources(NF ): OMX_FillThisBuffer() buf[5]=0x46c65800
    Am I doing a wrong setup parameters ?
    Setup NF modules parameters is -
    OMX_ERRORTYPE
    IL_ClientSetNfParams(
        IL_Client   *pAppData
        OMX_ERRORTYPE eError = OMX_ErrorNone;
    #define     OMX_NF_INPUT_PORT_START_INDEX   0
    #define     OMX_NF_OUTPUT_PORT_START_INDEX  1
        //  OMX_IndexParamPortDefinition
            OMX_PARAM_PORTDEFINITIONTYPE        paramPort;
            OMX_INIT_PARAM (&paramPort);
            // --- Input Port
            paramPort.nPortIndex                = OMX_NF_INPUT_PORT_START_INDEX;    // 0
            eError = OMX_GetParameter (pAppData->pNfHandle, OMX_IndexParamPortDefinition, &paramPort);
            if (eError != OMX_ErrorNone)  {
                printf("IL_ClientSetNfParams(): OMX_GetParameter() Error\n");
            paramPort.eDir                      = OMX_DirInput;
            paramPort.format.video.nFrameWidth  = pAppData->nWidth;     // 1920
            paramPort.format.video.nFrameHeight = pAppData->nHeight;    // 1080
            paramPort.nBufferCountActual        = IL_CLIENT_CAPTURE_OUTPUT_BUFFER_COUNT;    // 6
            paramPort.format.video.eCompressionFormat = OMX_VIDEO_CodingUnused;
            /* Capture output in 422 format */
            paramPort.format.video.nStride      = pAppData->nWidth * 2;
            paramPort.format.video.eColorFormat = OMX_COLOR_FormatYCbYCr;
            paramPort.nBufferSize               = paramPort.format.video.nStride * pAppData->nHeight;
            printf ("Buffer Size computed: %d\n", (int)paramPort.nBufferSize);
            eError = OMX_SetParameter (pAppData->pNfHandle, OMX_IndexParamPortDefinition, &paramPort);
                printf("IL_ClientSetNfParams(): OMX_SetParameter() Error\n");
                printf("IL_ClientSetNfParams(): OMX_GetParameter() Error %s\n", IL_ClientErrorToStr(eError));
            disp_OMX_PARAM_PORTDEFINITIONTYPE("Nf Input Port", &paramPort);
            // --- out port
            /* set input height/width and color format */
            paramPort.nPortIndex                = OMX_NF_OUTPUT_PORT_START_INDEX;   // 1
            paramPort.eDir                      = OMX_DirOutput;
            /* nf output is 420 format */
            paramPort.format.video.nStride      = pAppData->nWidth;
            paramPort.format.video.eColorFormat = OMX_COLOR_FormatYUV420SemiPlanar;
            paramPort.nBufferSize               = (paramPort.format.video.nStride * pAppData->nHeight * 3) >> 1;
                printf("IL_ClientSetNfParams(): OMX_SetParameter() Error %s\n", IL_ClientErrorToStr(eError));
            disp_OMX_PARAM_PORTDEFINITIONTYPE("Nf Output Port", &paramPort);
        //  OMX_TI_IndexParamVFPCNumChPerHandle
            OMX_PARAM_VFPC_NUMCHANNELPERHANDLE sNumChPerHandle;
            /* set number of channles */
            OMX_INIT_PARAM (&sNumChPerHandle);
            sNumChPerHandle.nNumChannelsPerHandle = 1;
            eError = OMX_SetParameter (pAppData->pNfHandle, (OMX_INDEXTYPE) OMX_TI_IndexParamVFPCNumChPerHandle, &sNumChPerHandle);
                ERROR ("failed to set num of channels\n");
        //  OMX_TI_IndexConfigVidChResolution
            OMX_CONFIG_VIDCHANNEL_RESOLUTION chResolution;
            printf ("set input resolution\n");
            OMX_INIT_PARAM (&chResolution);
            chResolution.Frm0Width      = pAppData->nWidth;
            chResolution.Frm0Height     = pAppData->nHeight;
            chResolution.Frm0Pitch      = pAppData->nWidth * 2;     // YUV422
            chResolution.Frm1Width      = 0;
            chResolution.Frm1Height     = 0;
            chResolution.Frm1Pitch      = 0;
            chResolution.FrmStartX      = 0;
            chResolution.FrmStartY      = 0;
            chResolution.FrmCropWidth   = pAppData->nWidth;
            chResolution.FrmCropHeight  = pAppData->nHeight;
            chResolution.eDir           = OMX_DirInput;
            chResolution.nChId          = 0;
    #if 1
    #endif
            disp_OMX_CONFIG_VIDCHANNEL_RESOLUTION("Set Input resolution", &chResolution);
            eError = OMX_SetConfig (pAppData->pNfHandle, (OMX_INDEXTYPE) OMX_TI_IndexConfigVidChResolution, &chResolution);
                ERROR ("failed to set input channel resolution %s\n", IL_ClientErrorToStr(eError));
    #if 0 // Can't OMX_GetConfig() : result is OMX_ErrorUnsupportedIndex
            eError = OMX_GetConfig (pAppData->pNfHandle, (OMX_INDEXTYPE) OMX_TI_IndexConfigVidChResolution, &chResolution);
                ERROR ("failed to get input channel resolution %s\n", IL_ClientErrorToStr(eError));
            disp_OMX_CONFIG_VIDCHANNEL_RESOLUTION("Read Input ch", &chResolution);
    #endif
            printf ("set output resolution\n");
            /* first output to display */
            chResolution.Frm0Pitch      = pAppData->nWidth;         // YUV420
    #if 1
    #endif
            chResolution.eDir           = OMX_DirOutput;
            disp_OMX_CONFIG_VIDCHANNEL_RESOLUTION("Set Output resolution", &chResolution);
                ERROR ("failed to set output channel resolution %s\n", IL_ClientErrorToStr(eError));
                ERROR ("failed to get output channel resolution %s\n", IL_ClientErrorToStr(eError));
            disp_OMX_CONFIG_VIDCHANNEL_RESOLUTION("Read Output ch", &chResolution);
    #endif
        //  OMX_TI_IndexConfigAlgEnable
            OMX_CONFIG_ALG_ENABLE algEnable;
            /* disable algo bypass mode */
            OMX_INIT_PARAM (&algEnable);
            algEnable.nPortIndex    = 0;
            algEnable.nChId         = 0;
            algEnable.bAlgBypass    = 0;
            eError = OMX_SetConfig (pAppData->pNfHandle, (OMX_INDEXTYPE) OMX_TI_IndexConfigAlgEnable, &algEnable);
                ERROR ("failed to disable algo by pass mode\n");
        //  OMX_TI_IndexConfigSubSamplingFactor
            OMX_CONFIG_SUBSAMPLING_FACTOR   para;
            OMX_INIT_PARAM (&para);
            para.nPortIndex          = OMX_NF_OUTPUT_PORT_START_INDEX;   /**< Index of the port */
            para. nSubSamplingFactor = 1;                                /**< Video frame rate sub sampling factor */
            eError = OMX_SetConfig (pAppData->pNfHandle, (OMX_INDEXTYPE) OMX_TI_IndexConfigSubSamplingFactor, &para);
                ERROR ("failed to (Nf) OMX_TI_IndexConfigSubSamplingFactor\n");
        return (OMX_ErrorNone);
    IL_ClientSetNfParams LOG is
    ----------- IL_ClientSetNfParams() -------------
    Buffer Size computed: 4147200
    set input port params (width = 1920, height = 1080)
    ------ OMX_PARAM_PORTDEFINITIONTYPE ----
    Nf Input Port
     nSize              = 96
     nVersion           = 0x20101
     nPortIndex         = 0
     eDir               = 0(OMX_DirInput)
     nBufferCountActual = 6
     nBufferCountMin    = 1
     nBufferSize        = 4147200
     bEnabled           = 0
     bPopulated         = 0
     eDomain            = 1[OMX_PortDomainVideo]
      format.video.cMIMEType             = (null)
      format.video.pNativeRender         = (nil)
      format.video.nFrameWidth           = 1920
      format.video.nFrameHeight          = 1080
      format.video.nStride               = 3840
      format.video.nSliceHeight          = 0
      format.video.nBitrate              = 0
      format.video.xFramerate            = 30
      format.video.bFlagErrorConcealment = 0
      format.video.eCompressionFormat    = 0x0
      format.video.eColorFormat          = 0x19
      format.video.pNativeWindow         = (nil)
     bBuffersContiguous = 0
     nBufferAlignment   = 128
    ------ end of OMX_PARAM_PORTDEFINITIONTYPE ----
    Buffer Size computed: 3110400
    Nf Output Port
     nSize              = 96
     nVersion           = 0x20101
     nPortIndex         = 1
     nBufferCountMin    = 1
     nBufferSize        = 3110400
     bEnabled           = 0
     bPopulated         = 0
      format.video.nStride               = 1920
      format.video.eColorFormat          = 0x15
    set number of channels
    ------ OMX_CONFIG_VIDCHANNEL_RESOLUTION ----
     nSize         = 60
     nVersion      = 0x101
     nPortIndex    = 0
     nChId         = 0
     Frm0Width     = 1920
     Frm0Height    = 1080
     Frm0Pitch     = 3840
     Frm1Width     = 0
     Frm1Height    = 0
     Frm1Pitch     = 0
     FrmStartX     = 0
     FrmStartY     = 0
     FrmCropWidth  = 1920
     FrmCropHeight = 1080
    ------ end of OMX_CONFIG_VIDCHANNEL_RESOLUTION ----
     nSize         = 60
     nVersion      = 0x101
     nPortIndex    = 0
     eDir          = 1(OMX_DirOutput)
     nChId         = 0
     Frm0Width     = 1920
     Frm0Height    = 1080
     Frm0Pitch     = 1920
     Frm1Width     = 0
     Frm1Height    = 0
     Frm1Pitch     = 0
     FrmStartX     = 0
     FrmStartY     = 0
     FrmCropWidth  = 1920
    Shinji Miki
  • Shinji,
    Please use port index definitions as defined by vfpc header file, o/p port index is not 1 for VFPC modules. Use OMX_VFPC_OUTPUT_PORT_START for o/p ports.
    Vimal
  • Hi.
    Vimal,
    I tryed use OMX_VFPC_OUTPUT_PORT_START_INDEX for o/p ports.
    But, can't return function 'OMX_AllocateBuffer()' for allocate outputBuffer.
    Am I doing a wrong OMX_AllocateBuffer() parameters ?
    #define        OMX_NF_INPUT_PORT_START_INDEX    OMX_VFPC_INPUT_PORT_START_INDEX
    #define        OMX_NF_OUTPUT_PORT_START_INDEX    OMX_VFPC_OUTPUT_PORT_START_INDEX
        {   // --- Nf
            eError = OMX_SendCommand (pAppData->pNfHandle, OMX_CommandStateSet, OMX_StateIdle, NULL);
                printf ("Error in SendCommand()-OMX_StateIdle State set : %s \n", IL_ClientErrorToStr (eError));
                goto EXIT;
            // input buffer
            for (i = 0; i < pAppData->NfILComp->inPortParams->nBufferCountActual; i++)  {
                eError = OMX_UseBuffer(
                                &pAppData->NfILComp->inPortParams->pInBuff[i],
                                OMX_NF_INPUT_PORT_START_INDEX,
                                pAppData->NfILComp,
                                pAppData->capILComp->outPortParams->nBufferSize,
                                pAppData->capILComp->outPortParams->pOutBuff[i]->pBuffer
                    printf ("Error in OMX_UseBuffer()-input Port State set : %s \n", IL_ClientErrorToStr (eError));
                    goto EXIT;
            printf (" Nf input port use buffer done \n ");
            // output buffer
            for (i = 0; i < pAppData->NfILComp->outPortParams->nBufferCountActual; i++) {
                printf("OMX_AllocateBuffer(%d)\n", i);
                eError = OMX_AllocateBuffer (
                                &pAppData->NfILComp->outPortParams->pOutBuff[i],
                                OMX_NF_OUTPUT_PORT_START_INDEX,
                                pAppData,
                                pAppData->NfILComp->outPortParams->nBufferSize
                printf("OMX_AllocateBuffer(%d)...done.\n", i);
                    printf ("Error in OMX_AllocateBuffer()-Output Port State set : %s \n", IL_ClientErrorToStr (eError));
                    goto EXIT;
            printf (" Nf outport buffers allocated \n ");
            semp_pend(pAppData->NfILComp->done_sem);
            printf (" Nf is in state IDLE \n ");
    Shinji Miki
  • Shinji,
    Have you enabled both the ports  as well ? Parameters seems to be ok. Where is NF output going, can yo try allocating buffers there and using (OMX_USEBuffers at NF o/p port as well) them ? I will try NF in our setup and let you know If there is any limitation..
    Vimal
  • Vimal.
    My test application is
     422 +--------+
    +--> | disVGA |
    | | 422 | | 420 | | -+[0]
    | cap | ---> | nf | ---> | dei |
    | | | | | | -+[1]
    +--> | enc | ---> | file|
    420 +-----+ +-----+
    Please check my execution flow.
    // cap open, setup
    OMX_GetHandle (&pAppData->pCapHandle, (OMX_STRING) "OMX.TI.VPSSM3.VFCC", pAppData->capILComp, &pAppData->pCb);
    OMX_GetHandle (&pAppData->pTvpHandle,(OMX_STRING) "OMX.TI.VPSSM3.CTRL.TVP", pAppData->capILComp, &pAppData->pCb);
    IL_ClientSetCaptureParams(pAppData);
    OMX_SendCommand(pAppData->pCapHandle, OMX_CommandPortEnable, OMX_VFCC_OUTPUT_PORT_START_INDEX, NULL);
    // nf open, setup
    OMX_GetHandle (&pAppData->pNfHandle, (OMX_STRING) "OMX.TI.VPSSM3.VFPC.NF", pAppData->NfILComp, &pAppData->pCb);
    IL_ClientSetNfParams (pAppData);
    OMX_SendCommand (pAppData->pNfHandle, OMX_CommandPortEnable, OMX_NF_INPUT_PORT_START_INDEX, NULL);
    OMX_SendCommand (pAppData->pNfHandle, OMX_CommandPortEnable, OMX_NF_OUTPUT_PORT_START_INDEX, NULL);
    // dei open, setup
    OMX_GetHandle (&pAppData->pDeiHandle, (OMX_STRING) "OMX.TI.VPSSM3.VFPC.DEIHDUALOUT", pAppData->deiILComp, &pAppData->pCb);
    IL_ClientSetDeiParams (pAppData);
    OMX_SendCommand (pAppData->pDeiHandle, OMX_CommandPortEnable, OMX_VFPC_INPUT_PORT_START_INDEX, NULL);
    OMX_SendCommand (pAppData->pDeiHandle, OMX_CommandPortEnable, OMX_VFPC_OUTPUT_PORT_START_INDEX, NULL);
    OMX_SendCommand (pAppData->pDeiHandle, OMX_CommandPortEnable, OMX_VFPC_OUTPUT_PORT_START_INDEX + 1, NULL);
    // enc open, setup
    OMX_GetHandle (&pAppData->pEncHandle, (OMX_STRING) "OMX.TI.DUCATI.VIDENC", pAppData->encILComp, &pAppData->pCb);
    IL_ClientSetEncodeParams (pAppData);
    // disVGA open, setup
    OMX_GetHandle (&pAppData->pDisVGAHandle, "OMX.TI.VPSSM3.VFDC", pAppData->disVGAILComp, &pAppData->pCb);
    OMX_GetHandle (&pAppData->pctrlVGAHandle, "OMX.TI.VPSSM3.CTRL.DC", pAppData->disVGAILComp, &pAppData->pCb);
    IL_ClientSetDisplayLiveParams (pAppData);
    OMX_SendCommand (pAppData->pDisVGAHandle, OMX_CommandPortEnable, OMX_VFDC_INPUT_PORT_START_INDEX, NULL);
    // --- Connect modules
    printf (" connect call for capture-Nf \n ");
    IL_ClientConnectComponents(
    pAppData->capILComp, OMX_VFCC_OUTPUT_PORT_START_INDEX,
    pAppData->NfILComp, OMX_NF_INPUT_PORT_START_INDEX
    printf (" connect call for Nf-Dei \n ");
    pAppData->NfILComp, OMX_NF_OUTPUT_PORT_START_INDEX,
    pAppData->deiILComp, OMX_VFPC_INPUT_PORT_START_INDEX
    printf (" connect call for dei- encoder \n ");
    pAppData->deiILComp, OMX_VFPC_OUTPUT_PORT_START_INDEX + 1,
    pAppData->encILComp, OMX_VIDENC_INPUT_PORT
    printf (" connect call for dei-display \n ");
    /* Connect the dei to display, even ports are concted to encoder, while odd ports would be connected to display */
    pAppData->deiILComp, OMX_VFPC_OUTPUT_PORT_START_INDEX,
    pAppData->disVGAILComp, OMX_VFDC_INPUT_PORT_START_INDEX
    // -- capture set to IDLE state, and buffer serup
    OMX_SendCommand (pAppData->pTvpHandle, OMX_CommandStateSet, OMX_StateIdle, NULL);
    OMX_SendCommand (pAppData->pCapHandle, OMX_CommandStateSet, OMX_StateIdle, NULL);
    for (...) {
    OMX_AllocateBuffer(... capILComp->outPortParams->pOutBuff[i], ...)
    // -- nf set to IDLE state, and buffer serup
    for (/* input buffers */) {
    OMX_UseBuffer(... pAppData->NfILComp->inPortParams->pInBuff[i], ...);
    for (/* output buffers */) {
        OMX_AllocateBuffer (... pAppData->NfILComp->outPortParams->pOutBuff[i], ...);
    // control is can't return
    // -- dei set to IDLE state, and buffer serup
    OMX_SendCommand (pAppData->pDeiHandle, OMX_CommandStateSet, OMX_StateIdle, NULL);
    Shinji Miki
  • Hi
    My test application Fig format is broke.
    pdf format was used.
    4478.my_app_modules.pdf
    Shinji Miki
  • Shinji,
    Can you try getting input buffers allocated at DEI and providing them to NF ? Also in NF  chResolution.FrmCropWidth   = pAppData->nWidth;
            chResolution.FrmCropHeight  = pAppData->nHeight can be made '0'.
    Also Could you please run
    /usr/share/ti/ti-uia/.loggerSMdump.out 0x9e400000 vpss ?
    It will give some prints from media controller to see the issue.
    Vimal
  • Vimal,
    I try
    Dei input buffer : OMX_AllocateBuffer()
    Nf output buffer : OMX_UseBuffer()
    Nf OMX_UseBuffer() is can't return
    // NF outport chResolution is
    chResolution.FrmCropHeight = 0;
    //Dei inport buffer :
    for (...) {
    &pAppData->deiILComp->inPortParams->pInBuff[i],
    pAppData,
    pAppData->deiILComp->inPortParams->nBufferSize
    //Nf outport buffer :
    // at output ch chResolution.FrmCropWidth = pAppData->nWidth; chResolution.FrmCropHeight = 0;
    for (...) {
    OMX_UseBuffer(
    pAppData->NfILComp,
    pAppData->deiILComp->inPortParams->nBufferSize,
    pAppData->deiILComp->inPortParams->pInBuff[i]->pBuffer
    root@dm816x-evm:/usr/share/ti/ti-uia# ./loggerSMDump.out 0x9e400000 vpss
    Remote LoggerSM Client Utility, (c) Texas Instruments 2011
    ./loggerSMDump.out <addr> <size> <core name> [<filename>]
    addr: Remote debug shared memory physical address in Hex
    The shared memory physical address MUST be 4KB aligned.
    size: Size of hte remote debug shared memory
    core name: Name of the cores that are processed.
    valid names are: dsp, video, vpss, m3 or all
    m3 denotes to process both video and vpss.
    all denotes to process all 3 targets.
    filename: If target has encoded records, name of the file to store
    the encoded records. They can be decoded by System Analyzer.
    This parameter is optional. If no filename is specified and encoded
    events are found, the default file name "loggerSM.bin" is used.
    Examples: ./loggerSMDump.out 0x8f000000 0x20000 video myBinaryFile
    ./loggerSMDump.out 0x8f000000 0x20000 m3 myBinaryFile
    ./loggerSMDump.out 0x8f000000 0x20000 all
    root@dm816x-evm:/usr/share/ti/ti-uia# ./loggerSMDump.out 0x9e400000 0x1000 vpss
    pened loggerSM.bin to store encoded records
    // can't return
    Shinji Miki
  • Shinji,
    I meant
    chResolution.FrmCropWidth = 0 ; &&  chResolution.FrmCropHeight = 0;
    For loggerSMDump.out
    please try
    ./loggerSMDump.out 0x9E400000 0x100000 vpss
    Vimal
  • Vimal
    I try outport chResolution.FrmCropWidth = 0 ; &&  chResolution.FrmCropHeight = 0;
    It stopped in the same place.
    root@dm816x-evm:/usr/share/ti/ti-uia# ./loggerSMDump.out 0x9E400000 0x100000 vpss
    Opened loggerSM.bin to store encoded records
    N:VPSS P:2 #:00000 T:000000000a1e7c0b S:Enabling Status Logger
    N:VPSS P:2 #:00001 T:000000000a1eaf5b S:Enabling User1 Logs
    N:VPSS P:2 #:00002 T:000000000a1efdd9 S:Disabling User1 Logs
    N:VPSS P:2 #:00003 T:000000000a1f42af S:Disabling User1 Logs
    N:VPSS P:2 #:00004 T:000000000a1f8627 S:Disabling User1 Logs
    N:VPSS P:2 #:00005 T:000000000a1fc9ed S:Disabling User1 Logs
    N:VPSS P:2 #:00006 T:000000000a201095 S:Enabling Analysis Logs
    N:VPSS P:2 #:00007 T:000000000a37e479 S:=== HDVPSS Clocks are enabled ===
    N:VPSS P:2 #:00008 T:000000000a384b23 S:=== HDVPSS is fully functional ===
    N:VPSS P:2 #:00009 T:000000000a38a08b S:=== HDVPSS module is not in standby ===
    N:VPSS P:2 #:00010 T:000000000a471c0b S:=== I2C1 Clk is active ===
    N:VPSS P:2 #:00011 T:000000000ae056ed S:*** VPDMA Firmware Loading... ***
    N:VPSS P:2 #:00012 T:000000000ae0d277 S:VPDMA Firmware Address = 0x9f3a78c0
    N:VPSS P:2 #:00013 T:000000000ae137e5 S:VPDMA Load Address = 0x4810d004
    N:VPSS P:2 #:00014 T:000000000ae78771 S:VPDMA Firmware Version = 0x4d00018d
    N:VPSS P:2 #:00015 T:000000000ae7ef01 S:VPDMA List Busy Status = 0x00000000
    N:VPSS P:2 #:00016 T:000000000ae8437d S:*** VPDMA Firmware Load Success ***
    N:VPSS P:2 #:00017 T:000000000e4fe875 S:Module<ti.omx> Entering<DomxCore_procInit> @line<116>
    N:VPSS P:2 #:00018 T:000000000ea46563 S:Module<ti.omx> @<DomxCore_procInit> @line<156> msg<Before Ipc_attach>
    N:VPSS P:2 #:00019 T:0000000014a6261f S:Module<ti.omx> @<DomxCore_procInit> @line<163> msg<After Ipc_attach>
    N:VPSS P:2 #:00020 T:0000000014a69025 S:Module<ti.omx> @<DomxCore_procInit> @line<165> msg<Ipc_attach successful>
    N:VPSS P:2 #:00021 T:0000000014a73f8f S:Module<ti.omx> @<OmxRpc_moduleRegisterMsgqHeap> @line<927> msg<Before MessageQ_registerHeap>
    N:VPSS P:2 #:00022 T:0000000014a7a3a3 S:Module<ti.omx> @<OmxRpc_moduleRegisterMsgqHeap> @line<932> msg<After MessageQ_registerHeap>
    N:VPSS P:2 #:00023 T:0000000014a7ff8b S:Module<ti.omx> Leaving<DomxCore_procInit> @line<207> with error<0:ErrorNone>
    N:VPSS P:2 #:00024 T:0000000014a87c41 S:@ omxrpc_rcm_server_create: rcmServerName OmxRpcRcmServer_2, priority 14
    N:VPSS P:2 #:00025 T:0000000014a8ce2d S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<225> msg<Before RcmServer_Params_init>
    N:VPSS P:2 #:00026 T:0000000014a92b9d S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<229> msg<After RcmServer_Params_init>
    N:VPSS P:2 #:00027 T:0000000014a98657 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<232> msg<Before RcmServer_create>
    N:VPSS P:2 #:00028 T:0000000014af5a45 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<240> msg<After RcmServer_create>
    N:VPSS P:2 #:00029 T:0000000014afb92d S:@ omxrpc_rcm_server_remote_fxn_register regFxnCategory 0
    N:VPSS P:2 #:00030 T:0000000014b0038b S:Calling RcmServer_addSymbol(OmxRpcGetHandle)
    N:VPSS P:2 #:00031 T:0000000014b07b73 S:Calling RcmServer_addSymbol(OmxRpcFreeHandle)
    N:VPSS P:2 #:00032 T:0000000014b0d50f S:Calling RcmServer_addSymbol(OmxRpcCreateProxyLite)
    N:VPSS P:2 #:00033 T:0000000014b131fb S:Calling RcmServer_addSymbol(OmxRpcGetHeapMemStats)
    N:VPSS P:2 #:00034 T:0000000014b188bf S:Calling RcmServer_addSymbol(OmxRpcDeleteProxyLite)
    N:VPSS P:2 #:00035 T:0000000014b1dfe9 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<256> msg<Before RcmServer_start>
    N:VPSS P:2 #:00036 T:0000000014b26a8d S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<258> msg<After RcmServer_start>
    N:VPSS P:2 #:00037 T:0000000014b76ef4 S:edma3init() Passed
    N:VPSS P:2 #:00038 T:0000000706a17559 S:Enabling Status Logger
    N:VPSS P:2 #:00039 T:0000000706a1ba3d S:Enabling User1 Logs
    N:VPSS P:2 #:00040 T:0000000706a20e79 S:Disabling User1 Logs
    N:VPSS P:2 #:00041 T:0000000706a2529d S:Disabling User1 Logs
    N:VPSS P:2 #:00042 T:0000000706a29627 S:Disabling User1 Logs
    N:VPSS P:2 #:00043 T:0000000706a2d8f9 S:Disabling User1 Logs
    N:VPSS P:2 #:00044 T:0000000706a31f4b S:Disabling Analysis Logs
    N:VPSS P:2 #:00045 T:0000000707069e2b S:OmxRpc_rcmIfGetHandle:ComponentName:OMX.TI.VPSSM3.VFCC
    N:VPSS P:2 #:00046 T:0000000707073ed7 S:Entered function:omxrpc_module_init_client (3)
    N:VPSS P:2 #:00047 T:000000070707c353 S:Entered function:OmxRpc_rcmClientCreate (0x9f386bf4, OmxRpcRcmServer_3, 5)
    N:VPSS P:2 #:00048 T:0000000707081b33 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<983> msg<Before RcmClient_Params_init>
    N:VPSS P:2 #:00049 T:00000007070875ef S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<985> msg<After RcmClient_Params_init>
    N:VPSS P:2 #:00050 T:000000070708ca6b S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<990> msg<Before RcmClient_create>
    N:VPSS P:2 #:00051 T:00000007070d567f S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<992> msg<After RcmClient_create>
    N:VPSS P:2 #:00052 T:00000007070db2b7 S:omxrpc_module_init_client: Located the remoteCoreRcmServer
    N:VPSS P:2 #:00053 T:00000007070e0baf S:main: calling RcmClient_getSymbolIndex(OmxRpcGetHandle)
    N:VPSS P:2 #:00054 T:000000070710b677 S:main: calling RcmClient_getSymbolIndex(OmxRpcFreeHandle)
    N:VPSS P:2 #:00055 T:0000000707130d09 S:main: calling RcmClient_getSymbolIndex(OmxRpcCreateProxyLite)
    N:VPSS P:2 #:00056 T:0000000707152fc3 S:main: calling RcmClient_getSymbolIndex(OmxRpcGetHeapMemStats)
    N:VPSS P:2 #:00057 T:0000000707175fdf S:main: calling RcmClient_getSymbolIndex(OmxRpcDeleteProxyLite)
    N:VPSS P:2 #:00058 T:00000007071982fb S:LayerId: 2
    N:VPSS P:2 #:00059 T:00000007071a3359 S:@ omxrpc_rcm_server_create: rcmServerName OmxRpcRcmServer_OMX.TI.VPSSM3.VFCC_Ctrl_2_0, priority 14
    N:VPSS P:2 #:00060 T:00000007071a9627 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<225> msg<Before RcmServer_Params_init>
    N:VPSS P:2 #:00061 T:00000007071af293 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<229> msg<After RcmServer_Params_init>
    N:VPSS P:2 #:00062 T:00000007071b4c2f S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<232> msg<Before RcmServer_create>
    N:VPSS P:2 #:00063 T:000000070720f333 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<240> msg<After RcmServer_create>
    N:VPSS P:2 #:00064 T:0000000707215755 S:@ omxrpc_rcm_server_remote_fxn_register regFxnCategory 1
    N:VPSS P:2 #:00065 T:000000070721ccb9 S:Calling RcmServer_addSymbol(OmxRpcSetParameter)
    N:VPSS P:2 #:00066 T:0000000707224f6f S:Calling RcmServer_addSymbol(OmxRpcGetParameter)
    N:VPSS P:2 #:00067 T:000000070722a673 S:Calling RcmServer_addSymbol(OmxRpcSetConfig)
    N:VPSS P:2 #:00068 T:000000070722f7ad S:Calling RcmServer_addSymbol(OmxRpcGetConfig)
    N:VPSS P:2 #:00069 T:0000000707234823 S:Calling RcmServer_addSymbol(OmxRpcGetComponentVersion)
    N:VPSS P:2 #:00070 T:000000070723a017 S:Calling RcmServer_addSymbol(OmxRpcGetExtensionIndex)
    N:VPSS P:2 #:00071 T:000000070723f727 S:Calling RcmServer_addSymbol(OmxRpcGetState)
    N:VPSS P:2 #:00072 T:000000070724474b S:Calling RcmServer_addSymbol(OmxRpcSendCommand)
    N:VPSS P:2 #:00073 T:0000000707249c51 S:Calling RcmServer_addSymbol(OmxRpcUseBuffer)
    N:VPSS P:2 #:00074 T:000000070724f143 S:Calling RcmServer_addSymbol(OmxRpcAllocBuffer)
    N:VPSS P:2 #:00075 T:0000000707254dc9 S:Calling RcmServer_addSymbol(OmxRpcFreeBuffer)
    N:VPSS P:2 #:00076 T:000000070725a413 S:Calling RcmServer_addSymbol(OmxRpcEmptyThisBuffer)
    N:VPSS P:2 #:00077 T:000000070725fb15 S:Calling RcmServer_addSymbol(OmxRpcFillThisBuffer)
    N:VPSS P:2 #:00078 T:00000007072650e9 S:Calling RcmServer_addSymbol(OmxRpcTunnelRequest)
    N:VPSS P:2 #:00079 T:000000070726ad97 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<256> msg<Before RcmServer_start>
    N:VPSS P:2 #:00080 T:0000000707271413 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<258> msg<After RcmServer_start>
    N:VPSS P:2 #:00081 T:0000000707276ddf S:Instance Register with omxRpc Module.Cnt = 1
    N:VPSS P:2 #:00082 T:000000070727a831 S:L_create: OmxRpc create: Component:OMX.TI.VPSSM3.VFCC, Layer:2
    N:VPSS P:2 #:00083 T:0000000707280039 S:Component OMX.TI.VPSSM3.VFCC In table OMX.TI.VPSSM3.VFCC idx 0
    N:VPSS P:2 #:00084 T:0000000707284b0b S:Component OMX.TI.VPSSM3.VFCC found idx: 0
    N:VPSS P:2 #:00085 T:0000000707289c37 S:In OMX_GetHandle, component OMX.TI.VPSSM3.VFCC, omxhandle 0x9f0bf1a8
    N:VPSS P:2 #:00086 T:00000007072c941f S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_SetDefaultProperties> @line<1237>
    N:VPSS P:2 #:00087 T:00000007072d0f57 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_SetDefaultProperties> @line<1279> with error<0:ErrorNone>
    N:VPSS P:2 #:00088 T:00000007072d76bb S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_ComponentInit> @line<107>
    N:VPSS P:2 #:00089 T:00000007072f3ab9 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_InitializePorts> @line<115>
    N:VPSS P:2 #:00090 T:00000007073aaaae S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_InitializePorts> @line<217> with error<0:ErrorNone>
    N:VPSS P:2 #:00091 T:0000000707638bdf S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_ComponentInit> @line<221> with error<0:ErrorNone>
    N:VPSS P:2 #:00092 T:000000070764740b S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00093 T:000000070764c42b S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00094 T:0000000707652a25 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00095 T:0000000707658f07 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00096 T:000000070765f91b S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00097 T:0000000707665a91 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00098 T:000000070766b7fb S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00099 T:0000000707671b83 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00100 T:00000007076787b3 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00101 T:000000070767d15f S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00102 T:0000000707682dfd S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00103 T:0000000707689175 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00104 T:000000070768f95f S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00105 T:00000007076942c7 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00106 T:000000070769a0df S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00107 T:00000007076a076d S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00108 T:00000007076a70b9 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00109 T:00000007076abaa3 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00110 T:00000007076b1865 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00111 T:00000007076b7bdd S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00112 T:00000007076be3af S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00113 T:00000007076c2cf3 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00114 T:00000007076c8985 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00115 T:00000007076ced09 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00116 T:00000007076d5433 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00117 T:00000007076d9d83 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00118 T:00000007076e16ed S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00119 T:00000007076e7c61 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00120 T:00000007076ee7a7 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00121 T:00000007076f31ed S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00122 T:00000007076f8f77 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00123 T:00000007076ff311 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00124 T:0000000707705a17 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00125 T:000000070770a393 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00126 T:000000070771001d S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00127 T:000000070771bd93 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00128 T:0000000707722b31 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00129 T:000000070772769b S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00130 T:000000070772d577 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00131 T:000000070773390b S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00132 T:000000070773a05f S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00133 T:000000070773e9b5 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00134 T:0000000707744645 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00135 T:000000070774a9c5 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00136 T:00000007077510b1 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00137 T:0000000707755a15 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00138 T:000000070775cf85 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00139 T:00000007077633df S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00140 T:0000000707769d93 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00141 T:000000070776e7d5 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00142 T:00000007077744bf S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00143 T:000000070777a8c5 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00144 T:00000007077810a5 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00145 T:0000000707785a0b S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00146 T:000000070778b6bd S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00147 T:0000000707791ecb S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00148 T:0000000707798761 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00149 T:000000070779d1af S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00150 T:00000007077a3093 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00151 T:00000007077a9413 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00152 T:00000007077afbcb S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00153 T:00000007077b454d S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00154 T:00000007077ba28d S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00155 T:00000007077c062f S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00156 T:00000007077c6815 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_SetCallbacks> @line<241>
    N:VPSS P:2 #:00157 T:00000007077cbf5d S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_SetCallbacks> @line<282> with error<0:ErrorNone>
    N:VPSS P:2 #:00158 T:00000007077d1c75 S:Result of pComponentInit: ErrorNone
    N:VPSS P:2 #:00159 T:00000007077d7243 S:Registering the component OMX.TI.VPSSM3.VFCC with TunnelMgr
    N:VPSS P:2 #:00160 T:00000007077db4da S:Entered: DomxTunnelMgr_registerHandle (0x9f0bf1a8, 0x9f704f54)
    N:VPSS P:2 #:00161 T:00000007077e5053 S:Entered function:OmxRpc_rcmClientCreate (0x9f0ba348, OmxRpcRcmServer_OMX.TI.VPSSM3.VFCC_Cb_3_0, 5)
    N:VPSS P:2 #:00162 T:00000007077eb615 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<983> msg<Before RcmClient_Params_init>
    N:VPSS P:2 #:00163 T:00000007077f1133 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<985> msg<After RcmClient_Params_init>
    N:VPSS P:2 #:00164 T:00000007077f65ab S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<990> msg<Before RcmClient_create>
    N:VPSS P:2 #:00165 T:0000000707859fb3 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<992> msg<After RcmClient_create>
    N:VPSS P:2 #:00166 T:00000007078617ed S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEventHandler)
    N:VPSS P:2 #:00167 T:00000007078d9989 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEmptyBufferDone)
    N:VPSS P:2 #:00168 T:00000007078ff239 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbFillBufferDone)
    N:VPSS P:2 #:00169 T:0000000707924353 S:Module<ti.omx> @<domxtmgr_register_skelinfo> @line<417> msg<OmxRpcRcmServer_OMX.TI.VPSSM3.VFCC_Ctrl_2_0>
    N:VPSS P:2 #:00170 T:000000070792d7fc S:OmxRpc_rcmIfGetHandle:ComponentName:OmxRpcRcmServer_OMX.TI.VPSSM3.VFCC_Ctrl_2_0.Exiting..
    N:VPSS P:2 #:00171 T:0000000707e3ee83 S:OmxRpc_rcmIfGetHandle:ComponentName:OMX.TI.VPSSM3.CTRL.TVP
    N:VPSS P:2 #:00172 T:0000000707e48be3 S:Entered function:omxrpc_module_init_client (3)
    N:VPSS P:2 #:00173 T:0000000707e4d559 S:LayerId: 2
    N:VPSS P:2 #:00174 T:0000000707e5603f S:@ omxrpc_rcm_server_create: rcmServerName OmxRpcRcmServer_OMX.TI.VPSSM3.CTRL.TVP_Ctrl_2_1, priority 14
    N:VPSS P:2 #:00175 T:0000000707e5c429 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<225> msg<Before RcmServer_Params_init>
    N:VPSS P:2 #:00176 T:0000000707e6211b S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<229> msg<After RcmServer_Params_init>
    N:VPSS P:2 #:00177 T:0000000707e67b07 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<232> msg<Before RcmServer_create>
    N:VPSS P:2 #:00178 T:0000000707ec5483 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<240> msg<After RcmServer_create>
    N:VPSS P:2 #:00179 T:0000000707ecb8fb S:@ omxrpc_rcm_server_remote_fxn_register regFxnCategory 1
    N:VPSS P:2 #:00180 T:0000000707ed02fd S:Calling RcmServer_addSymbol(OmxRpcSetParameter)
    N:VPSS P:2 #:00181 T:0000000707ed7b71 S:Calling RcmServer_addSymbol(OmxRpcGetParameter)
    N:VPSS P:2 #:00182 T:0000000707edd43f S:Calling RcmServer_addSymbol(OmxRpcSetConfig)
    N:VPSS P:2 #:00183 T:0000000707ee261b S:Calling RcmServer_addSymbol(OmxRpcGetConfig)
    N:VPSS P:2 #:00184 T:0000000707ee76d5 S:Calling RcmServer_addSymbol(OmxRpcGetComponentVersion)
    N:VPSS P:2 #:00185 T:0000000707ef28eb S:Calling RcmServer_addSymbol(OmxRpcGetExtensionIndex)
    N:VPSS P:2 #:00186 T:0000000707ef8899 S:Calling RcmServer_addSymbol(OmxRpcGetState)
    N:VPSS P:2 #:00187 T:0000000707effe21 S:Calling RcmServer_addSymbol(OmxRpcSendCommand)
    N:VPSS P:2 #:00188 T:0000000707f055bb S:Calling RcmServer_addSymbol(OmxRpcUseBuffer)
    N:VPSS P:2 #:00189 T:0000000707f0a8d7 S:Calling RcmServer_addSymbol(OmxRpcAllocBuffer)
    N:VPSS P:2 #:00190 T:0000000707f0fde5 S:Calling RcmServer_addSymbol(OmxRpcFreeBuffer)
    N:VPSS P:2 #:00191 T:0000000707f15269 S:Calling RcmServer_addSymbol(OmxRpcEmptyThisBuffer)
    N:VPSS P:2 #:00192 T:0000000707f1a81b S:Calling RcmServer_addSymbol(OmxRpcFillThisBuffer)
    N:VPSS P:2 #:00193 T:0000000707f1fe23 S:Calling RcmServer_addSymbol(OmxRpcTunnelRequest)
    N:VPSS P:2 #:00194 T:0000000707f25c1f S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<256> msg<Before RcmServer_start>
    N:VPSS P:2 #:00195 T:0000000707f2c411 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<258> msg<After RcmServer_start>
    N:VPSS P:2 #:00196 T:0000000707f322b7 S:Instance Register with omxRpc Module.Cnt = 2
    N:VPSS P:2 #:00197 T:0000000707f35e01 S:L_create: OmxRpc create: Component:OMX.TI.VPSSM3.CTRL.TVP, Layer:2
    N:VPSS P:2 #:00198 T:0000000707f3b7df S:Component OMX.TI.VPSSM3.CTRL.TVP In table OMX.TI.VPSSM3.VFCC idx 0
    N:VPSS P:2 #:00199 T:0000000707f40389 S:Component OMX.TI.VPSSM3.CTRL.TVP In table OMX.TI.VPSSM3.VFDC idx 1
    N:VPSS P:2 #:00200 T:0000000707f44e0d S:Component OMX.TI.VPSSM3.CTRL.TVP In table OMX.TI.VPSSM3.VFPC.DEIHDUALOUT idx 2
    N:VPSS P:2 #:00201 T:0000000707f49ee3 S:Component OMX.TI.VPSSM3.CTRL.TVP In table OMX.TI.VPSSM3.VFPC.DEIMDUALOUT idx 3
    N:VPSS P:2 #:00202 T:0000000707f4ef4f S:Component OMX.TI.VPSSM3.CTRL.TVP In table OMX.TI.VPSSM3.VFPC.NF idx 4
    N:VPSS P:2 #:00203 T:0000000707f53baf S:Component OMX.TI.VPSSM3.CTRL.TVP In table OMX.TI.VPSSM3.VFPC.INDTXSCWB idx 5
    N:VPSS P:2 #:00204 T:0000000707f58f81 S:Component OMX.TI.VPSSM3.CTRL.TVP In table OMX.TI.VPSSM3.CTRL.TVP idx 6
    N:VPSS P:2 #:00205 T:0000000707f5e10d S:Component OMX.TI.VPSSM3.CTRL.TVP found idx: 6
    N:VPSS P:2 #:00206 T:0000000707f63ac9 S:In OMX_GetHandle, component OMX.TI.VPSSM3.CTRL.TVP, omxhandle 0x9f0ecef0
    N:VPSS P:2 #:00207 T:0000000707f76285 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_SetDefaultProperties> @line<1237>
    N:VPSS P:2 #:00208 T:0000000707f7bfed S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<OMX_BASE_SetDefaultProperties> @line<1279> with error<0:ErrorNone>
    N:VPSS P:2 #:00209 T:0000000707f84fd9 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_ComponentInit> @line<107>
    N:VPSS P:2 #:00210 T:0000000707fa149b S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<_OMX_BASE_InitializePorts> @line<115>
    N:VPSS P:2 #:00211 T:0000000707fa9619 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<_OMX_BASE_InitializePorts> @line<217> with error<0:ErrorNone>
    N:VPSS P:2 #:00212 T:0000000708000bb7 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<OMX_BASE_ComponentInit> @line<221> with error<0:ErrorNone>
    N:VPSS P:2 #:00213 T:0000000708056a21 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_SetCallbacks> @line<241>
    N:VPSS P:2 #:00214 T:000000070805c58b S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<OMX_BASE_SetCallbacks> @line<282> with error<0:ErrorNone>
    N:VPSS P:2 #:00215 T:00000007080628cb S:Result of pComponentInit: ErrorNone
    N:VPSS P:2 #:00216 T:000000070806605d S:Registering the component OMX.TI.VPSSM3.CTRL.TVP with TunnelMgr
    N:VPSS P:2 #:00217 T:000000070806cc7b S:Entered: DomxTunnelMgr_registerHandle (0x9f0ecef0, 0x9f704f54)
    N:VPSS P:2 #:00218 T:000000070807744f S:Entered function:OmxRpc_rcmClientCreate (0x9f0e8280, OmxRpcRcmServer_OMX.TI.VPSSM3.CTRL.TVP_Cb_3_1, 5)
    N:VPSS P:2 #:00219 T:000000070807d8c1 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<983> msg<Before RcmClient_Params_init>
    N:VPSS P:2 #:00220 T:00000007080831ab S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<985> msg<After RcmClient_Params_init>
    N:VPSS P:2 #:00221 T:0000000708088a55 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<990> msg<Before RcmClient_create>
    N:VPSS P:2 #:00222 T:0000000708259661 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<992> msg<After RcmClient_create>
    N:VPSS P:2 #:00223 T:0000000708261781 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEventHandler)
    N:VPSS P:2 #:00224 T:000000070829840f S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEmptyBufferDone)
    N:VPSS P:2 #:00225 T:00000007082bd357 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbFillBufferDone)
    N:VPSS P:2 #:00226 T:00000007082e2971 S:Module<ti.omx> @<domxtmgr_register_skelinfo> @line<417> msg<OmxRpcRcmServer_OMX.TI.VPSSM3.CTRL.TVP_Ctrl_2_1>
    N:VPSS P:2 #:00227 T:00000007082ec1eb S:OmxRpc_rcmIfGetHandle:ComponentName:OmxRpcRcmServer_OMX.TI.VPSSM3.CTRL.TVP_Ctrl_2_1.Exiting..
    N:VPSS P:2 #:00228 T:00000007087f254f S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_GetParameter> @line<664>
    N:VPSS P:2 #:00229 T:00000007087f9921 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_GetParameter> @line<827> with error<0:ErrorNone>
    N:VPSS P:2 #:00230 T:0000000708829ac1 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_SetParameter> @line<859>
    N:VPSS P:2 #:00231 T:00000007088300b9 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_SetParameter> @line<1132> with error<0:ErrorNone>
    N:VPSS P:2 #:00232 T:0000000708855375 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_SetParameter> @line<859>
    N:VPSS P:2 #:00233 T:000000070885b9af S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_SetParameter> @line<1132> with error<0:ErrorNone>
    N:VPSS P:2 #:00234 T:000000070890b0ef S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_SendCommand> @line<472>
    N:VPSS P:2 #:00235 T:00000007089142ed S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_SendCommand> @line<638> with error<0:ErrorNone>
    N:VPSS P:2 #:00236 T:0000000708923609 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00237 T:000000070892b489 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:00238 T:0000000708930ccb S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_PROCESS_CmdEvent> @line<631> msg<Processing OMX_CommandPortEnable>
    N:VPSS P:2 #:00239 T:0000000708937a5b S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_EnablePort> @line<776>
    N:VPSS P:2 #:00240 T:000000070893cb8d S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_EnablePort> @line<814> with error<0:ErrorNone>
    N:VPSS P:2 #:00241 T:0000000708943a6d S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:00242 T:0000000708949237 S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_CB_ReturnEventNotify> @line<121> msg<Notify client for port enable>
    N:VPSS P:2 #:00243 T:0000000708950117 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<222> with error<0:ErrorNone>
    N:VPSS P:2 #:00244 T:0000000708956333 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:00245 T:000000070895c14f S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00246 T:0000000708962dab S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:00247 T:00000007089684e7 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:00248 T:000000070896dbae S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<869> msg<Processing OMX_CommandPortEnable>
    N:VPSS P:2 #:00249 T:000000070897430d S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_EventNotifyToClient> @line<880>
    N:VPSS P:2 #:00250 T:00000007089ad177 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1171> with error<0:ErrorNone>
    N:VPSS P:2 #:00251 T:00000007089b486d S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:00252 T:00000007089bb0cd S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:00253 T:00000007089c196b S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00254 T:00000007089c733d S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00255 T:0000000708aa143d S:OmxRpc_rcmIfGetHandle:ComponentName:OMX.TI.VPSSM3.VFPC.NF
    N:VPSS P:2 #:00256 T:0000000708aaa5e5 S:Entered function:omxrpc_module_init_client (3)
    N:VPSS P:2 #:00257 T:0000000708aaef1b S:LayerId: 2
    N:VPSS P:2 #:00258 T:0000000708ab7a17 S:@ omxrpc_rcm_server_create: rcmServerName OmxRpcRcmServer_OMX.TI.VPSSM3.VFPC.NF_Ctrl_2_2, priority 14
    N:VPSS P:2 #:00259 T:0000000708abdf5b S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<225> msg<Before RcmServer_Params_init>
    N:VPSS P:2 #:00260 T:0000000708ac3e65 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<229> msg<After RcmServer_Params_init>
    N:VPSS P:2 #:00261 T:0000000708ac95b5 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<232> msg<Before RcmServer_create>
    N:VPSS P:2 #:00262 T:0000000708b23d29 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<240> msg<After RcmServer_create>
    N:VPSS P:2 #:00263 T:0000000708b2a33f S:@ omxrpc_rcm_server_remote_fxn_register regFxnCategory 1
    N:VPSS P:2 #:00264 T:0000000708b2eff3 S:Calling RcmServer_addSymbol(OmxRpcSetParameter)
    N:VPSS P:2 #:00265 T:0000000708b36b8b S:Calling RcmServer_addSymbol(OmxRpcGetParameter)
    N:VPSS P:2 #:00266 T:0000000708b3bf13 S:Calling RcmServer_addSymbol(OmxRpcSetConfig)
    N:VPSS P:2 #:00267 T:0000000708b40f8d S:Calling RcmServer_addSymbol(OmxRpcGetConfig)
    N:VPSS P:2 #:00268 T:0000000708b46101 S:Calling RcmServer_addSymbol(OmxRpcGetComponentVersion)
    N:VPSS P:2 #:00269 T:0000000708b4b94d S:Calling RcmServer_addSymbol(OmxRpcGetExtensionIndex)
    N:VPSS P:2 #:00270 T:0000000708b51021 S:Calling RcmServer_addSymbol(OmxRpcGetState)
    N:VPSS P:2 #:00271 T:0000000708b560b1 S:Calling RcmServer_addSymbol(OmxRpcSendCommand)
    N:VPSS P:2 #:00272 T:0000000708b5b163 S:Calling RcmServer_addSymbol(OmxRpcUseBuffer)
    N:VPSS P:2 #:00273 T:0000000708b62a6f S:Calling RcmServer_addSymbol(OmxRpcAllocBuffer)
    N:VPSS P:2 #:00274 T:0000000708b681ff S:Calling RcmServer_addSymbol(OmxRpcFreeBuffer)
    N:VPSS P:2 #:00275 T:0000000708b6d41d S:Calling RcmServer_addSymbol(OmxRpcEmptyThisBuffer)
    N:VPSS P:2 #:00276 T:0000000708b72a45 S:Calling RcmServer_addSymbol(OmxRpcFillThisBuffer)
    N:VPSS P:2 #:00277 T:0000000708b77fd3 S:Calling RcmServer_addSymbol(OmxRpcTunnelRequest)
    N:VPSS P:2 #:00278 T:0000000708b7d889 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<256> msg<Before RcmServer_start>
    N:VPSS P:2 #:00279 T:0000000708b83adb S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<258> msg<After RcmServer_start>
    N:VPSS P:2 #:00280 T:0000000708b8900f S:Instance Register with omxRpc Module.Cnt = 3
    N:VPSS P:2 #:00281 T:0000000708b8ccd3 S:L_create: OmxRpc create: Component:OMX.TI.VPSSM3.VFPC.NF, Layer:2
    N:VPSS P:2 #:00282 T:0000000708b929c7 S:Component OMX.TI.VPSSM3.VFPC.NF In table OMX.TI.VPSSM3.VFCC idx 0
    N:VPSS P:2 #:00283 T:0000000708b97b2f S:Component OMX.TI.VPSSM3.VFPC.NF In table OMX.TI.VPSSM3.VFDC idx 1
    N:VPSS P:2 #:00284 T:0000000708b9c9a7 S:Component OMX.TI.VPSSM3.VFPC.NF In table OMX.TI.VPSSM3.VFPC.DEIHDUALOUT idx 2
    N:VPSS P:2 #:00285 T:0000000708ba1ae5 S:Component OMX.TI.VPSSM3.VFPC.NF In table OMX.TI.VPSSM3.VFPC.DEIMDUALOUT idx 3
    N:VPSS P:2 #:00286 T:0000000708ba6f77 S:Component OMX.TI.VPSSM3.VFPC.NF In table OMX.TI.VPSSM3.VFPC.NF idx 4
    N:VPSS P:2 #:00287 T:0000000708babddd S:Component OMX.TI.VPSSM3.VFPC.NF found idx: 4
    N:VPSS P:2 #:00288 T:0000000708bb1345 S:In OMX_GetHandle, component OMX.TI.VPSSM3.VFPC.NF, omxhandle 0x9f0f81f0
    N:VPSS P:2 #:00289 T:0000000708bfec83 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_SetDefaultProperties> @line<1237>
    N:VPSS P:2 #:00290 T:0000000708c07e25 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_SetDefaultProperties> @line<1279> with error<0:ErrorNone>
    N:VPSS P:2 #:00291 T:0000000708c11c37 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_ComponentInit> @line<107>
    N:VPSS P:2 #:00292 T:0000000708c2d435 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_InitializePorts> @line<115>
    N:VPSS P:2 #:00293 T:0000000708d71f2f S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_InitializePorts> @line<217> with error<0:ErrorNone>
    N:VPSS P:2 #:00294 T:0000000708ec9e6d S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_ComponentInit> @line<221> with error<0:ErrorNone>
    N:VPSS P:2 #:00295 T:00000007090d84d2 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00296 T:00000007090de885 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00297 T:00000007090e53df S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00298 T:00000007090eb977 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00299 T:00000007090f26f9 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00300 T:00000007090f72d1 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00301 T:00000007090fd52d S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00302 T:00000007091037fb S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00303 T:000000070910a055 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00304 T:000000070910eb83 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00305 T:0000000709114e71 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00306 T:000000070911d0e9 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00307 T:0000000709123ea9 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00308 T:00000007091289cf S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00309 T:000000070912ec8d S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00310 T:0000000709134fbd S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00311 T:000000070913b8b5 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00312 T:00000007091403d3 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00313 T:0000000709146665 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00314 T:000000070914c955 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00315 T:000000070915395f S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00316 T:0000000709158567 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00317 T:000000070915e97f S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00318 T:0000000709164c65 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00319 T:000000070916b641 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00320 T:00000007091702ab S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00321 T:0000000709176557 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00322 T:000000070917c89f S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00323 T:000000070918318d S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00324 T:0000000709187cbf S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00325 T:000000070918df37 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00326 T:0000000709195b91 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00327 T:000000070919c8a5 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00328 T:00000007091a152f S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00329 T:00000007091a7813 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00330 T:00000007091adafb S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00331 T:00000007091b43c1 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00332 T:00000007091b8ef9 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00333 T:00000007091bf167 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00334 T:00000007091c546d S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00335 T:00000007091cc2d5 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00336 T:00000007091d0f43 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00337 T:00000007091d7283 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00338 T:00000007091dd565 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00339 T:00000007091e3dc7 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00340 T:00000007091e88f7 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00341 T:00000007091eeb65 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00342 T:00000007091f4e23 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00343 T:00000007091fb817 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00344 T:0000000709200331 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00345 T:0000000709206583 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00346 T:000000070920e1fb S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00347 T:0000000709215009 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00348 T:0000000709219bd7 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00349 T:000000070921fecf S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00350 T:00000007092261b1 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00351 T:000000070922cbef S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00352 T:00000007092316f1 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00353 T:00000007092379bb S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00354 T:000000070923dcaf S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00355 T:0000000709244b25 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00356 T:0000000709249829 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00357 T:000000070924fbe9 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00358 T:0000000709255f5b S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00359 T:000000070925cb77 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00360 T:00000007092616b1 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00361 T:0000000709267983 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00362 T:000000070926dc71 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00363 T:000000070927454f S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00364 T:0000000709279051 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00365 T:000000070927f35a S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00366 T:00000007092856ab S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00367 T:000000070928dc2d S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00368 T:0000000709292841 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00369 T:0000000709298b2d S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00370 T:000000070929ee31 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00371 T:00000007092a569f S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00372 T:00000007092aa201 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00373 T:00000007092b0465 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00374 T:00000007092b67af S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00375 T:00000007092bd5a9 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00376 T:00000007092c23bd S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00377 T:00000007092c86fb S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00378 T:00000007092ceabd S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00379 T:00000007092d549d S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00380 T:00000007092d9feb S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00381 T:00000007092e0247 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00382 T:00000007092e6515 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00383 T:00000007092ecf09 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00384 T:00000007092f1afd S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00385 T:00000007092f7d77 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00386 T:00000007092fe06d S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00387 T:0000000709306733 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00388 T:000000070930b425 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00389 T:0000000709311777 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00390 T:0000000709317a2d S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00391 T:000000070931e449 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00392 T:0000000709322feb S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00393 T:000000070932926d S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00394 T:000000070932f559 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00395 T:0000000709335f33 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00396 T:000000070933ad4b S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00397 T:00000007093410c9 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00398 T:00000007093473b1 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00399 T:000000070934dfa2 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00400 T:0000000709352aeb S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00401 T:0000000709358da5 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00402 T:000000070935f07d S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00403 T:000000070936595f S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00404 T:000000070936a485 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00405 T:00000007093706cd S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00406 T:0000000709376999 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00407 T:000000070937ebfd S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00408 T:00000007093838fb S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00409 T:0000000709389c21 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00410 T:000000070938ff09 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00411 T:0000000709396859 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00412 T:000000070939b39d S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00413 T:00000007093a1603 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00414 T:00000007093a78d7 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00415 T:00000007093ae1ff S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00416 T:00000007093b32a7 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00417 T:00000007093b9703 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00418 T:00000007093bf9c7 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00419 T:00000007093c6401 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00420 T:00000007093caf89 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00421 T:00000007093d128d S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00422 T:00000007093d75b9 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00423 T:00000007093dddf3 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_SetCallbacks> @line<241>
    N:VPSS P:2 #:00424 T:00000007093e449f S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_SetCallbacks> @line<282> with error<0:ErrorNone>
    N:VPSS P:2 #:00425 T:00000007093ea8cb S:Result of pComponentInit: ErrorNone
    N:VPSS P:2 #:00426 T:00000007093edf39 S:Registering the component OMX.TI.VPSSM3.VFPC.NF with TunnelMgr
    N:VPSS P:2 #:00427 T:00000007093f25c9 S:Entered: DomxTunnelMgr_registerHandle (0x9f0f81f0, 0x9f704f54)
    N:VPSS P:2 #:00428 T:0000000709400773 S:Entered function:OmxRpc_rcmClientCreate (0x9f0f3580, OmxRpcRcmServer_OMX.TI.VPSSM3.VFPC.NF_Cb_3_2, 5)
    N:VPSS P:2 #:00429 T:0000000709406df7 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<983> msg<Before RcmClient_Params_init>
    N:VPSS P:2 #:00430 T:000000070940c915 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<985> msg<After RcmClient_Params_init>
    N:VPSS P:2 #:00431 T:0000000709411d71 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<990> msg<Before RcmClient_create>
    N:VPSS P:2 #:00432 T:0000000709485d37 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<992> msg<After RcmClient_create>
    N:VPSS P:2 #:00433 T:000000070948dd63 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEventHandler)
    N:VPSS P:2 #:00434 T:00000007094b6033 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEmptyBufferDone)
    N:VPSS P:2 #:00435 T:00000007094ee213 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbFillBufferDone)
    N:VPSS P:2 #:00436 T:0000000709539e47 S:Module<ti.omx> @<domxtmgr_register_skelinfo> @line<417> msg<OmxRpcRcmServer_OMX.TI.VPSSM3.VFPC.NF_Ctrl_2_2>
    N:VPSS P:2 #:00437 T:00000007095436f5 S:OmxRpc_rcmIfGetHandle:ComponentName:OmxRpcRcmServer_OMX.TI.VPSSM3.VFPC.NF_Ctrl_2_2.Exiting..
    N:VPSS P:2 #:00438 T:0000000709aceedb S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_GetParameter> @line<664>
    N:VPSS P:2 #:00439 T:0000000709ae30ed S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_GetParameter> @line<827> with error<0:ErrorNone>
    N:VPSS P:2 #:00440 T:0000000709b28669 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_SetParameter> @line<859>
    N:VPSS P:2 #:00441 T:0000000709b30221 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_SetParameter> @line<1132> with error<0:ErrorNone>
    N:VPSS P:2 #:00442 T:0000000709b5efef S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_GetParameter> @line<664>
    N:VPSS P:2 #:00443 T:0000000709b654ab S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_GetParameter> @line<827> with error<0:ErrorNone>
    N:VPSS P:2 #:00444 T:0000000709bba2d5 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_GetParameter> @line<664>
    N:VPSS P:2 #:00445 T:0000000709bccc65 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_GetParameter> @line<827> with error<0:ErrorNone>
    N:VPSS P:2 #:00446 T:0000000709c047bd S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_SetParameter> @line<859>
    N:VPSS P:2 #:00447 T:0000000709c0b52f S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_SetParameter> @line<1132> with error<0:ErrorNone>
    N:VPSS P:2 #:00448 T:0000000709c39809 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_GetParameter> @line<664>
    N:VPSS P:2 #:00449 T:0000000709c3fc5b S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_GetParameter> @line<827> with error<0:ErrorNone>
    N:VPSS P:2 #:00450 T:0000000709f6de6d S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_SendCommand> @line<472>
    N:VPSS P:2 #:00451 T:0000000709f77e53 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_SendCommand> @line<638> with error<0:ErrorNone>
    N:VPSS P:2 #:00452 T:0000000709f877b1 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00453 T:0000000709f8fb1b S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:00454 T:0000000709f9520b S:Module<OMX.TI.VPSSM3.VFPC.NF> @<OMX_BASE_PROCESS_CmdEvent> @line<631> msg<Processing OMX_CommandPortEnable>
    N:VPSS P:2 #:00455 T:0000000709f9b763 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_EnablePort> @line<776>
    N:VPSS P:2 #:00456 T:0000000709fa0f87 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_EnablePort> @line<814> with error<0:ErrorNone>
    N:VPSS P:2 #:00457 T:0000000709fa82c1 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:00458 T:0000000709fae311 S:Module<OMX.TI.VPSSM3.VFPC.NF> @<OMX_BASE_CB_ReturnEventNotify> @line<121> msg<Notify client for port enable>
    N:VPSS P:2 #:00459 T:0000000709fb50c3 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<222> with error<0:ErrorNone>
    N:VPSS P:2 #:00460 T:0000000709fbb14d S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:00461 T:0000000709fc1527 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00462 T:0000000709fc8157 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:00463 T:0000000709fcd7eb S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:00464 T:0000000709fd2f55 S:Module<OMX.TI.VPSSM3.VFPC.NF> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<869> msg<Processing OMX_CommandPortEnable>
    N:VPSS P:2 #:00465 T:0000000709fd9aad S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_EventNotifyToClient> @line<880>
    N:VPSS P:2 #:00466 T:000000070a0106ef S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_SendCommand> @line<472>
    N:VPSS P:2 #:00467 T:000000070a0198a5 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_SendCommand> @line<638> with error<0:ErrorNone>
    N:VPSS P:2 #:00468 T:000000070a02fd8b S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_EventNotifyToClient> @line<1171> with error<0:ErrorNone>
    N:VPSS P:2 #:00469 T:000000070a036de1 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:00470 T:000000070a03d777 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:00471 T:000000070a043b95 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00472 T:000000070a04b245 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:00473 T:000000070a050685 S:Module<OMX.TI.VPSSM3.VFPC.NF> @<OMX_BASE_PROCESS_CmdEvent> @line<631> msg<Processing OMX_CommandPortEnable>
    N:VPSS P:2 #:00474 T:000000070a056f65 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_EnablePort> @line<776>
    N:VPSS P:2 #:00475 T:000000070a05edd7 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_EnablePort> @line<814> with error<0:ErrorNone>
    N:VPSS P:2 #:00476 T:000000070a06586b S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:00477 T:000000070a06b30d S:Module<OMX.TI.VPSSM3.VFPC.NF> @<OMX_BASE_CB_ReturnEventNotify> @line<121> msg<Notify client for port enable>
    N:VPSS P:2 #:00478 T:000000070a072651 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<222> with error<0:ErrorNone>
    N:VPSS P:2 #:00479 T:000000070a078b0b S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:00480 T:000000070a07eee5 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00481 T:000000070a085ed9 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:00482 T:000000070a08b6c9 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:00483 T:000000070a09112f S:Module<OMX.TI.VPSSM3.VFPC.NF> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<869> msg<Processing OMX_CommandPortEnable>
    N:VPSS P:2 #:00484 T:000000070a097bcd S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_EventNotifyToClient> @line<880>
    N:VPSS P:2 #:00485 T:000000070a0c611f S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_EventNotifyToClient> @line<1171> with error<0:ErrorNone>
    N:VPSS P:2 #:00486 T:000000070a0cd233 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:00487 T:000000070a0d381b S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:00488 T:000000070a0dc9ef S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00489 T:000000070a0e29b5 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00490 T:000000070a0e9755 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00491 T:000000070a0eed91 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00492 T:000000070a1c665d S:OmxRpc_rcmIfGetHandle:ComponentName:OMX.TI.VPSSM3.VFPC.DEIHDUALOUT
    N:VPSS P:2 #:00493 T:000000070a1d1be5 S:Entered function:omxrpc_module_init_client (3)
    N:VPSS P:2 #:00494 T:000000070a1d66ff S:LayerId: 2
    N:VPSS P:2 #:00495 T:000000070a1df79b S:@ omxrpc_rcm_server_create: rcmServerName OmxRpcRcmServer_OMX.TI.VPSSM3.VFPC.DEIHDUALOUT_Ctrl_2_3, priority 14
    N:VPSS P:2 #:00496 T:000000070a1e5b63 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<225> msg<Before RcmServer_Params_init>
    N:VPSS P:2 #:00497 T:000000070a1eb735 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<229> msg<After RcmServer_Params_init>
    N:VPSS P:2 #:00498 T:000000070a1f1147 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<232> msg<Before RcmServer_create>
    N:VPSS P:2 #:00499 T:000000070a24fbeb S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<240> msg<After RcmServer_create>
    N:VPSS P:2 #:00500 T:000000070a25602f S:@ omxrpc_rcm_server_remote_fxn_register regFxnCategory 1
    N:VPSS P:2 #:00501 T:000000070a25a91b S:Calling RcmServer_addSymbol(OmxRpcSetParameter)
    N:VPSS P:2 #:00502 T:000000070a262241 S:Calling RcmServer_addSymbol(OmxRpcGetParameter)
    N:VPSS P:2 #:00503 T:000000070a2679e5 S:Calling RcmServer_addSymbol(OmxRpcSetConfig)
    N:VPSS P:2 #:00504 T:000000070a26c991 S:Calling RcmServer_addSymbol(OmxRpcGetConfig)
    N:VPSS P:2 #:00505 T:000000070a271b57 S:Calling RcmServer_addSymbol(OmxRpcGetComponentVersion)
    N:VPSS P:2 #:00506 T:000000070a27726f S:Calling RcmServer_addSymbol(OmxRpcGetExtensionIndex)
    N:VPSS P:2 #:00507 T:000000070a27d395 S:Calling RcmServer_addSymbol(OmxRpcGetState)
    N:VPSS P:2 #:00508 T:000000070a28261c S:Calling RcmServer_addSymbol(OmxRpcSendCommand)
    N:VPSS P:2 #:00509 T:000000070a287b6b S:Calling RcmServer_addSymbol(OmxRpcUseBuffer)
    N:VPSS P:2 #:00510 T:000000070a28cdd3 S:Calling RcmServer_addSymbol(OmxRpcAllocBuffer)
    N:VPSS P:2 #:00511 T:000000070a2922eb S:Calling RcmServer_addSymbol(OmxRpcFreeBuffer)
    N:VPSS P:2 #:00512 T:000000070a2977e5 S:Calling RcmServer_addSymbol(OmxRpcEmptyThisBuffer)
    N:VPSS P:2 #:00513 T:000000070a29cc89 S:Calling RcmServer_addSymbol(OmxRpcFillThisBuffer)
    N:VPSS P:2 #:00514 T:000000070a2a2183 S:Calling RcmServer_addSymbol(OmxRpcTunnelRequest)
    N:VPSS P:2 #:00515 T:000000070a2a7fd5 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<256> msg<Before RcmServer_start>
    N:VPSS P:2 #:00516 T:000000070a2ae515 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<258> msg<After RcmServer_start>
    N:VPSS P:2 #:00517 T:000000070a2b3e27 S:Instance Register with omxRpc Module.Cnt = 4
    N:VPSS P:2 #:00518 T:000000070a2b7769 S:L_create: OmxRpc create: Component:OMX.TI.VPSSM3.VFPC.DEIHDUALOUT, Layer:2
    N:VPSS P:2 #:00519 T:000000070a2bfa49 S:Component OMX.TI.VPSSM3.VFPC.DEIHDUALOUT In table OMX.TI.VPSSM3.VFCC idx 0
    N:VPSS P:2 #:00520 T:000000070a2c4ca1 S:Component OMX.TI.VPSSM3.VFPC.DEIHDUALOUT In table OMX.TI.VPSSM3.VFDC idx 1
    N:VPSS P:2 #:00521 T:000000070a2c9d4b S:Component OMX.TI.VPSSM3.VFPC.DEIHDUALOUT In table OMX.TI.VPSSM3.VFPC.DEIHDUALOUT idx 2
    N:VPSS P:2 #:00522 T:000000070a2cf6b5 S:Component OMX.TI.VPSSM3.VFPC.DEIHDUALOUT found idx: 2
    N:VPSS P:2 #:00523 T:000000070a2d572d S:In OMX_GetHandle, component OMX.TI.VPSSM3.VFPC.DEIHDUALOUT, omxhandle 0x9f122c30
    N:VPSS P:2 #:00524 T:000000070a326ddf S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_SetDefaultProperties> @line<1237>
    N:VPSS P:2 #:00525 T:000000070a3300d2 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_SetDefaultProperties> @line<1279> with error<0:ErrorNone>
    N:VPSS P:2 #:00526 T:000000070a33d4a7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_ComponentInit> @line<107>
    N:VPSS P:2 #:00527 T:000000070a35a845 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_InitializePorts> @line<115>
    N:VPSS P:2 #:00528 T:000000070a4c3295 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_InitializePorts> @line<217> with error<0:ErrorNone>
    N:VPSS P:2 #:00529 T:000000070a61846f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_ComponentInit> @line<221> with error<0:ErrorNone>
    N:VPSS P:2 #:00530 T:000000070a77d0cf S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00531 T:000000070a784b89 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00532 T:000000070a78bba3 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00533 T:000000070a792651 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00534 T:000000070a799987 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00535 T:000000070a79eb21 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00536 T:000000070a7a4fe5 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00537 T:000000070a7ab723 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00538 T:000000070a7b227b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00539 T:000000070a7b73e5 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00540 T:000000070a7bdd17 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00541 T:000000070a7c44dd S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00542 T:000000070a7cb14b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00543 T:000000070a7d0339 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00544 T:000000070a7d68a5 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00545 T:000000070a7dcfcf S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00546 T:000000070a7e39d5 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00547 T:000000070a7e8b33 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00548 T:000000070a7eefdd S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00549 T:000000070a7f5703 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00550 T:000000070a7fe231 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00551 T:000000070a8035b3 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00552 T:000000070a809a65 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00553 T:000000070a810207 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00554 T:000000070a816e87 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00555 T:000000070a81bfe5 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00556 T:000000070a8224b9 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00557 T:000000070a828be9 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00558 T:000000070a82f635 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00559 T:000000070a834ba1 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00560 T:000000070a83b2b5 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00561 T:000000070a8419ed S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00562 T:000000070a8485bb S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00563 T:000000070a84d75d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00564 T:000000070a853c33 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00565 T:000000070a85a38d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00566 T:000000070a860ec5 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00567 T:000000070a866019 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00568 T:000000070a86c517 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00569 T:000000070a872c5b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00570 T:000000070a87b3a5 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00571 T:000000070a880645 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00572 T:000000070a886b4b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00573 T:000000070a88d275 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00574 T:000000070a894037 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00575 T:000000070a899209 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00576 T:000000070a89f711 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00577 T:000000070a8a5e3d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00578 T:000000070a8acc19 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00579 T:000000070a8b1fcb S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00580 T:000000070a8b8555 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00581 T:000000070a8becab S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00582 T:000000070a8c57bb S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00583 T:000000070a8ca91b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00584 T:000000070a8d0de7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00585 T:000000070a8d7519 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00586 T:000000070a8ddff7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00587 T:000000070a8e31d1 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00588 T:000000070a8e96d1 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00589 T:000000070a8f1893 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00590 T:000000070a8f8965 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00591 T:000000070a8fdbd7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00592 T:000000070a9040ab S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00593 T:000000070a90a7cf S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00594 T:000000070a9114d1 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00595 T:000000070a916631 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00596 T:000000070a91caf5 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00597 T:000000070a92322b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00598 T:000000070a92a1bd S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00599 T:000000070a92f3fb S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00600 T:000000070a935a8f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00601 T:000000070a93c1a1 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00602 T:000000070a942b7f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00603 T:000000070a947cf9 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00604 T:000000070a94e1ad S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00605 T:000000070a9548e3 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00606 T:000000070a95b335 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00607 T:000000070a960495 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00608 T:000000070a966a0b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00609 T:000000070a96ebb5 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00610 T:000000070a975c85 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00611 T:000000070a97aea1 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00612 T:000000070a98137b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00613 T:000000070a987a99 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00614 T:000000070a98e5eb S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00615 T:000000070a993739 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00616 T:000000070a999c35 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00617 T:000000070a9a059b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00618 T:000000070a9a73c9 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00619 T:000000070a9ac65f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00620 T:000000070a9b2c23 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00621 T:000000070a9b93f7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00622 T:000000070a9c008b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00623 T:000000070a9c51cd S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00624 T:000000070a9cb6ad S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00625 T:000000070a9d1dd3 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00626 T:000000070a9d8851 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00627 T:000000070a9dd9c7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00628 T:000000070a9e5913 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00629 T:000000070a9ec0b7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00630 T:000000070a9f31c5 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00631 T:000000070a9f840f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00632 T:000000070a9fe8e1 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00633 T:000000070aa05007 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00634 T:000000070aa0bbb9 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00635 T:000000070aa10cfd S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00636 T:000000070aa17203 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00637 T:000000070aa1dd9d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00638 T:000000070aa24aa9 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00639 T:000000070aa29d0b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00640 T:000000070aa3039f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00641 T:000000070aa36af7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00642 T:000000070aa3d563 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00643 T:000000070aa426d7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00644 T:000000070aa48bcd S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00645 T:000000070aa4f303 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00646 T:000000070aa55ced S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00647 T:000000070aa5ae65 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00648 T:000000070aa62de3 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00649 T:000000070aa69655 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00650 T:000000070aa705c3 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00651 T:000000070aa7589d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00652 T:000000070aa7be31 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00653 T:000000070aa8260d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00654 T:000000070aa8918b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00655 T:000000070aa8e30f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00656 T:000000070aa949f9 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00657 T:000000070aa9b341 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00658 T:000000070aaa1907 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_SetCallbacks> @line<241>
    N:VPSS P:2 #:00659 T:000000070aaa8275 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_SetCallbacks> @line<282> with error<0:ErrorNone>
    N:VPSS P:2 #:00660 T:000000070aaae93d S:Result of pComponentInit: ErrorNone
    N:VPSS P:2 #:00661 T:000000070aab1ea1 S:Registering the component OMX.TI.VPSSM3.VFPC.DEIHDUALOUT with TunnelMgr
    N:VPSS P:2 #:00662 T:000000070aab68f3 S:Entered: DomxTunnelMgr_registerHandle (0x9f122c30, 0x9f704f54)
    N:VPSS P:2 #:00663 T:000000070aac0eb5 S:Entered function:OmxRpc_rcmClientCreate (0x9f11dfc0, OmxRpcRcmServer_OMX.TI.VPSSM3.VFPC.DEIHDUALOUT_Cb_3_3, 5)
    N:VPSS P:2 #:00664 T:000000070aac7b3d S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<983> msg<Before RcmClient_Params_init>
    N:VPSS P:2 #:00665 T:000000070aacd6c5 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<985> msg<After RcmClient_Params_init>
    N:VPSS P:2 #:00666 T:000000070aad2d25 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<990> msg<Before RcmClient_create>
    N:VPSS P:2 #:00667 T:000000070ac179e5 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<992> msg<After RcmClient_create>
    N:VPSS P:2 #:00668 T:000000070ac1fa2d S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEventHandler)
    N:VPSS P:2 #:00669 T:000000070ac4e727 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEmptyBufferDone)
    N:VPSS P:2 #:00670 T:000000070ac71571 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbFillBufferDone)
    N:VPSS P:2 #:00671 T:000000070aebec51 S:Module<ti.omx> @<domxtmgr_register_skelinfo> @line<417> msg<OmxRpcRcmServer_OMX.TI.VPSSM3.VFPC.DEIHDUALOUT_Ctrl_2_3>
    N:VPSS P:2 #:00672 T:000000070aec9159 S:OmxRpc_rcmIfGetHandle:ComponentName:OmxRpcRcmServer_OMX.TI.VPSSM3.VFPC.DEIHDUALOUT_Ctrl_2_3.Exiting..
    N:VPSS P:2 #:00673 T:000000070b54faf1 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_SetParameter> @line<859>
    N:VPSS P:2 #:00674 T:000000070b559e2f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_SetParameter> @line<1132> with error<0:ErrorNone>
    N:VPSS P:2 #:00675 T:000000070b57fb8d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_SetParameter> @line<859>
    N:VPSS P:2 #:00676 T:000000070b586329 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_SetParameter> @line<1132> with error<0:ErrorNone>
    N:VPSS P:2 #:00677 T:000000070b5aa393 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_SetParameter> @line<859>
    N:VPSS P:2 #:00678 T:000000070b5b12f1 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_SetParameter> @line<1132> with error<0:ErrorNone>
    N:VPSS P:2 #:00679 T:000000070b5d6927 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_GetParameter> @line<664>
    N:VPSS P:2 #:00680 T:000000070b5e192f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_GetParameter> @line<827> with error<0:ErrorNone>
    N:VPSS P:2 #:00681 T:000000070b6e5a87 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_SetParameter> @line<859>
    N:VPSS P:2 #:00682 T:000000070b6eca6d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_SetParameter> @line<1132> with error<0:ErrorNone>
    N:VPSS P:2 #:00683 T:000000070b7138c5 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_GetParameter> @line<664>
    N:VPSS P:2 #:00684 T:000000070b71a1eb S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_GetParameter> @line<827> with error<0:ErrorNone>
    N:VPSS P:2 #:00685 T:000000070b742f03 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_SetParameter> @line<859>
    N:VPSS P:2 #:00686 T:000000070b749b8b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_SetParameter> @line<1132> with error<0:ErrorNone>
    N:VPSS P:2 #:00687 T:000000070b76cc2b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_GetParameter> @line<664>
    N:VPSS P:2 #:00688 T:000000070b772e0d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_GetParameter> @line<827> with error<0:ErrorNone>
    N:VPSS P:2 #:00689 T:000000070b79933d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_SetParameter> @line<859>
    N:VPSS P:2 #:00690 T:000000070b79ffb1 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_SetParameter> @line<1132> with error<0:ErrorNone>
    N:VPSS P:2 #:00691 T:000000070b83d161 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_SendCommand> @line<472>
    N:VPSS P:2 #:00692 T:000000070b846bd1 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_SendCommand> @line<638> with error<0:ErrorNone>
    N:VPSS P:2 #:00693 T:000000070b85674f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00694 T:000000070b85e9df S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:00695 T:000000070b864615 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> @<OMX_BASE_PROCESS_CmdEvent> @line<631> msg<Processing OMX_CommandPortEnable>
    N:VPSS P:2 #:00696 T:000000070b86b851 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_EnablePort> @line<776>
    N:VPSS P:2 #:00697 T:000000070b870cef S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_EnablePort> @line<814> with error<0:ErrorNone>
    N:VPSS P:2 #:00698 T:000000070b8783f3 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:00699 T:000000070b87e495 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> @<OMX_BASE_CB_ReturnEventNotify> @line<121> msg<Notify client for port enable>
    N:VPSS P:2 #:00700 T:000000070b8854cd S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<222> with error<0:ErrorNone>
    N:VPSS P:2 #:00701 T:000000070b88c083 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:00702 T:000000070b892a83 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00703 T:000000070b899fa7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:00704 T:000000070b89f90d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:00705 T:000000070b8a578d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<869> msg<Processing OMX_CommandPortEnable>
    N:VPSS P:2 #:00706 T:000000070b8aff9b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_EventNotifyToClient> @line<880>
    N:VPSS P:2 #:00707 T:000000070b8e3911 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_SendCommand> @line<472>
    N:VPSS P:2 #:00708 T:000000070b8ed1ad S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_SendCommand> @line<638> with error<0:ErrorNone>
    N:VPSS P:2 #:00709 T:000000070b903b53 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_EventNotifyToClient> @line<1171> with error<0:ErrorNone>
    N:VPSS P:2 #:00710 T:000000070b90af09 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:00711 T:000000070b9117cb S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:00712 T:000000070b918347 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00713 T:000000070b91ff67 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:00714 T:000000070b928d3b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> @<OMX_BASE_PROCESS_CmdEvent> @line<631> msg<Processing OMX_CommandPortEnable>
    N:VPSS P:2 #:00715 T:000000070b92fc35 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_EnablePort> @line<776>
    N:VPSS P:2 #:00716 T:000000070b93504b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_EnablePort> @line<814> with error<0:ErrorNone>
    N:VPSS P:2 #:00717 T:000000070b93bfb5 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:00718 T:000000070b941ba7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> @<OMX_BASE_CB_ReturnEventNotify> @line<121> msg<Notify client for port enable>
    N:VPSS P:2 #:00719 T:000000070b948acb S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<222> with error<0:ErrorNone>
    N:VPSS P:2 #:00720 T:000000070b94f529 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:00721 T:000000070b956001 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00722 T:000000070b95dab9 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:00723 T:000000070b96371f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:00724 T:000000070b969583 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<869> msg<Processing OMX_CommandPortEnable>
    N:VPSS P:2 #:00725 T:000000070b970699 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_EventNotifyToClient> @line<880>
    N:VPSS P:2 #:00726 T:000000070b99f75f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_SendCommand> @line<472>
    N:VPSS P:2 #:00727 T:000000070b9aab0d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_SendCommand> @line<638> with error<0:ErrorNone>
    N:VPSS P:2 #:00728 T:000000070b9c1831 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_EventNotifyToClient> @line<1171> with error<0:ErrorNone>
    N:VPSS P:2 #:00729 T:000000070b9c8989 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:00730 T:000000070b9cf265 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:00731 T:000000070b9d5f4b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00732 T:000000070b9de6e7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:00733 T:000000070b9e40ed S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> @<OMX_BASE_PROCESS_CmdEvent> @line<631> msg<Processing OMX_CommandPortEnable>
    N:VPSS P:2 #:00734 T:000000070b9eadc9 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_EnablePort> @line<776>
    N:VPSS P:2 #:00735 T:000000070b9f0081 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_EnablePort> @line<814> with error<0:ErrorNone>
    N:VPSS P:2 #:00736 T:000000070b9f7235 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:00737 T:000000070b9fce5f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> @<OMX_BASE_CB_ReturnEventNotify> @line<121> msg<Notify client for port enable>
    N:VPSS P:2 #:00738 T:000000070ba03df7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<222> with error<0:ErrorNone>
    N:VPSS P:2 #:00739 T:000000070ba0a7bf S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:00740 T:000000070ba11255 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00741 T:000000070ba187c7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:00742 T:000000070ba21831 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:00743 T:000000070ba2793f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<869> msg<Processing OMX_CommandPortEnable>
    N:VPSS P:2 #:00744 T:000000070ba2eaa1 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_EventNotifyToClient> @line<880>
    N:VPSS P:2 #:00745 T:000000070ba5c741 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_EventNotifyToClient> @line<1171> with error<0:ErrorNone>
    N:VPSS P:2 #:00746 T:000000070ba6439f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:00747 T:000000070ba6ab5d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:00748 T:000000070ba715ed S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00749 T:000000070ba77e6d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00750 T:000000070ba7eef7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00751 T:000000070ba84bc7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00752 T:000000070d63f03b S:OmxRpc_rcmIfGetHandle:ComponentName:OMX.TI.VPSSM3.VFDC
    N:VPSS P:2 #:00753 T:000000070d649223 S:Entered function:omxrpc_module_init_client (3)
    N:VPSS P:2 #:00754 T:000000070d64da39 S:LayerId: 2
    N:VPSS P:2 #:00755 T:000000070d656407 S:@ omxrpc_rcm_server_create: rcmServerName OmxRpcRcmServer_OMX.TI.VPSSM3.VFDC_Ctrl_2_4, priority 14
    N:VPSS P:2 #:00756 T:000000070d65c3a1 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<225> msg<Before RcmServer_Params_init>
    N:VPSS P:2 #:00757 T:000000070d661f07 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<229> msg<After RcmServer_Params_init>
    N:VPSS P:2 #:00758 T:000000070d6678ab S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<232> msg<Before RcmServer_create>
    N:VPSS P:2 #:00759 T:000000070d6c6917 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<240> msg<After RcmServer_create>
    N:VPSS P:2 #:00760 T:000000070d6ccc5d S:@ omxrpc_rcm_server_remote_fxn_register regFxnCategory 1
    N:VPSS P:2 #:00761 T:000000070d6d1657 S:Calling RcmServer_addSymbol(OmxRpcSetParameter)
    N:VPSS P:2 #:00762 T:000000070d6d9089 S:Calling RcmServer_addSymbol(OmxRpcGetParameter)
    N:VPSS P:2 #:00763 T:000000070d6de7bd S:Calling RcmServer_addSymbol(OmxRpcSetConfig)
    N:VPSS P:2 #:00764 T:000000070d6e3781 S:Calling RcmServer_addSymbol(OmxRpcGetConfig)
    N:VPSS P:2 #:00765 T:000000070d6e88c7 S:Calling RcmServer_addSymbol(OmxRpcGetComponentVersion)
    N:VPSS P:2 #:00766 T:000000070d6ee931 S:Calling RcmServer_addSymbol(OmxRpcGetExtensionIndex)
    N:VPSS P:2 #:00767 T:000000070d6f4203 S:Calling RcmServer_addSymbol(OmxRpcGetState)
    N:VPSS P:2 #:00768 T:000000070d6f92db S:Calling RcmServer_addSymbol(OmxRpcSendCommand)
    N:VPSS P:2 #:00769 T:000000070d6fe7cd S:Calling RcmServer_addSymbol(OmxRpcUseBuffer)
    N:VPSS P:2 #:00770 T:000000070d703aaf S:Calling RcmServer_addSymbol(OmxRpcAllocBuffer)
    N:VPSS P:2 #:00771 T:000000070d708fe7 S:Calling RcmServer_addSymbol(OmxRpcFreeBuffer)
    N:VPSS P:2 #:00772 T:000000070d70e3a9 S:Calling RcmServer_addSymbol(OmxRpcEmptyThisBuffer)
    N:VPSS P:2 #:00773 T:000000070d713905 S:Calling RcmServer_addSymbol(OmxRpcFillThisBuffer)
    N:VPSS P:2 #:00774 T:000000070d718d8d S:Calling RcmServer_addSymbol(OmxRpcTunnelRequest)
    N:VPSS P:2 #:00775 T:000000070d71eb95 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<256> msg<Before RcmServer_start>
    N:VPSS P:2 #:00776 T:000000070d72531d S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<258> msg<After RcmServer_start>
    N:VPSS P:2 #:00777 T:000000070d72ac23 S:Instance Register with omxRpc Module.Cnt = 5
    N:VPSS P:2 #:00778 T:000000070d72e57f S:L_create: OmxRpc create: Component:OMX.TI.VPSSM3.VFDC, Layer:2
    N:VPSS P:2 #:00779 T:000000070d735c4b S:Component OMX.TI.VPSSM3.VFDC In table OMX.TI.VPSSM3.VFCC idx 0
    N:VPSS P:2 #:00780 T:000000070d73a829 S:Component OMX.TI.VPSSM3.VFDC In table OMX.TI.VPSSM3.VFDC idx 1
    N:VPSS P:2 #:00781 T:000000070d73f2a9 S:Component OMX.TI.VPSSM3.VFDC found idx: 1
    N:VPSS P:2 #:00782 T:000000070d744b0d S:In OMX_GetHandle, component OMX.TI.VPSSM3.VFDC, omxhandle 0x9f14fbd8
    N:VPSS P:2 #:00783 T:000000070d79564b S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_SetDefaultProperties> @line<1237>
    N:VPSS P:2 #:00784 T:000000070d79d265 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_SetDefaultProperties> @line<1279> with error<0:ErrorNone>
    N:VPSS P:2 #:00785 T:000000070d7a380d S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_ComponentInit> @line<107>
    N:VPSS P:2 #:00786 T:000000070d7c2ab1 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_InitializePorts> @line<115>
    N:VPSS P:2 #:00787 T:000000070d8a4751 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_InitializePorts> @line<217> with error<0:ErrorNone>
    N:VPSS P:2 #:00788 T:000000070d9f70f5 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_ComponentInit> @line<221> with error<0:ErrorNone>
    N:VPSS P:2 #:00789 T:000000070da02cdd S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00790 T:000000070da0804d S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00791 T:000000070da1060f S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00792 T:000000070da16b29 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00793 T:000000070da1d705 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00794 T:000000070da2236d S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00795 T:000000070da2820f S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00796 T:000000070da2e349 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00797 T:000000070da34911 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00798 T:000000070da39497 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00799 T:000000070da3f36b S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00800 T:000000070da4581d S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00801 T:000000070da4c213 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00802 T:000000070da50dd3 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00803 T:000000070da56e1b S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00804 T:000000070da5cf4b S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00805 T:000000070da6356d S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00806 T:000000070da680f9 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00807 T:000000070da6dfa7 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00808 T:000000070da740e1 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00809 T:000000070da7a647 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00810 T:000000070da7f21f S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00811 T:000000070da85073 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00812 T:000000070da8ce41 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00813 T:000000070da9392f S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00814 T:000000070da98529 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00815 T:000000070da9e4a3 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00816 T:000000070daa464f S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00817 T:000000070daaac09 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00818 T:000000070daaf73b S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00819 T:000000070dab55c9 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00820 T:000000070dabb703 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00821 T:000000070dac2061 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00822 T:000000070dac6c6d S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00823 T:000000070daccbbf S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00824 T:000000070dad2cf9 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00825 T:000000070dad9259 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00826 T:000000070dadde55 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00827 T:000000070dae3cf9 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00828 T:000000070dae9dfb S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00829 T:000000070daf0259 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00830 T:000000070daf4db7 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00831 T:000000070dafac41 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00832 T:000000070db0279d S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00833 T:000000070db090c5 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00834 T:000000070db0dc9f S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00835 T:000000070db13bf3 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00836 T:000000070db19d29 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00837 T:000000070db202f1 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00838 T:000000070db24dcf S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00839 T:000000070db2ac41 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00840 T:000000070db30d5f S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00841 T:000000070db373fd S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00842 T:000000070db3c19f S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00843 T:000000070db4217d S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00844 T:000000070db482cf S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00845 T:000000070db4e957 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00846 T:000000070db53483 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00847 T:000000070db592f1 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00848 T:000000070db5f3f1 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00849 T:000000070db658ab S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00850 T:000000070db6a3b5 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00851 T:000000070db7027b S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00852 T:000000070db763dd S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00853 T:000000070db7e59b S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00854 T:000000070db831e5 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00855 T:000000070db891d9 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00856 T:000000070db8f2e9 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00857 T:000000070db958c7 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00858 T:000000070db9a3ed S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00859 T:000000070dba02a7 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00860 T:000000070dba63a9 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00861 T:000000070dbac8e3 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00862 T:000000070dbb15d5 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00863 T:000000070dbb76cf S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00864 T:000000070dbbd805 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00865 T:000000070dbc400f S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<535>
    N:VPSS P:2 #:00866 T:000000070dbc8b0b S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<615>
    N:VPSS P:2 #:00867 T:000000070dbce9e7 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<679> with error<0:ErrorNone>
    N:VPSS P:2 #:00868 T:000000070dbd4b0b S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<563> with error<0:ErrorNone>
    N:VPSS P:2 #:00869 T:000000070e5e5fd3 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_SetCallbacks> @line<241>
    N:VPSS P:2 #:00870 T:000000070e5ebe8d S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_SetCallbacks> @line<282> with error<0:ErrorNone>
    N:VPSS P:2 #:00871 T:000000070e5f1eaf S:Result of pComponentInit: ErrorNone
    N:VPSS P:2 #:00872 T:000000070e5f550d S:Registering the component OMX.TI.VPSSM3.VFDC with TunnelMgr
    N:VPSS P:2 #:00873 T:000000070e5fb449 S:Entered: DomxTunnelMgr_registerHandle (0x9f14fbd8, 0x9f704f54)
    N:VPSS P:2 #:00874 T:000000070e60576d S:Entered function:OmxRpc_rcmClientCreate (0x9f14af68, OmxRpcRcmServer_OMX.TI.VPSSM3.VFDC_Cb_3_5, 5)
    N:VPSS P:2 #:00875 T:000000070e60bc6b S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<983> msg<Before RcmClient_Params_init>
    N:VPSS P:2 #:00876 T:000000070e611783 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<985> msg<After RcmClient_Params_init>
    N:VPSS P:2 #:00877 T:000000070e616e07 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<990> msg<Before RcmClient_create>
    N:VPSS P:2 #:00878 T:000000070e703f7d S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<992> msg<After RcmClient_create>
    N:VPSS P:2 #:00879 T:000000070e70ba75 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEventHandler)
    N:VPSS P:2 #:00880 T:000000070e73af3b S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEmptyBufferDone)
    N:VPSS P:2 #:00881 T:000000070e75ed5b S:main: calling RcmClient_getSymbolIndex(OmxRpcCbFillBufferDone)
    N:VPSS P:2 #:00882 T:000000070e784605 S:Module<ti.omx> @<domxtmgr_register_skelinfo> @line<417> msg<OmxRpcRcmServer_OMX.TI.VPSSM3.VFDC_Ctrl_2_4>
    N:VPSS P:2 #:00883 T:000000070e78d867 S:OmxRpc_rcmIfGetHandle:ComponentName:OmxRpcRcmServer_OMX.TI.VPSSM3.VFDC_Ctrl_2_4.Exiting..
    N:VPSS P:2 #:00884 T:000000070ef38b15 S:OmxRpc_rcmIfGetHandle:ComponentName:OMX.TI.VPSSM3.CTRL.DC
    N:VPSS P:2 #:00885 T:000000070ef42a4d S:Entered function:omxrpc_module_init_client (3)
    N:VPSS P:2 #:00886 T:000000070ef4733d S:LayerId: 2
    N:VPSS P:2 #:00887 T:000000070ef4fd39 S:@ omxrpc_rcm_server_create: rcmServerName OmxRpcRcmServer_OMX.TI.VPSSM3.CTRL.DC_Ctrl_2_5, priority 14
    N:VPSS P:2 #:00888 T:000000070ef563f3 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<225> msg<Before RcmServer_Params_init>
    N:VPSS P:2 #:00889 T:000000070ef5c0ff S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<229> msg<After RcmServer_Params_init>
    N:VPSS P:2 #:00890 T:000000070ef61b21 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<232> msg<Before RcmServer_create>
    N:VPSS P:2 #:00891 T:000000070efc0733 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<240> msg<After RcmServer_create>
    N:VPSS P:2 #:00892 T:000000070efc6e67 S:@ omxrpc_rcm_server_remote_fxn_register regFxnCategory 1
    N:VPSS P:2 #:00893 T:000000070efcb8df S:Calling RcmServer_addSymbol(OmxRpcSetParameter)
    N:VPSS P:2 #:00894 T:000000070efd3379 S:Calling RcmServer_addSymbol(OmxRpcGetParameter)
    N:VPSS P:2 #:00895 T:000000070efd8a5d S:Calling RcmServer_addSymbol(OmxRpcSetConfig)
    N:VPSS P:2 #:00896 T:000000070efddb35 S:Calling RcmServer_addSymbol(OmxRpcGetConfig)
    N:VPSS P:2 #:00897 T:000000070efe2c31 S:Calling RcmServer_addSymbol(OmxRpcGetComponentVersion)
    N:VPSS P:2 #:00898 T:000000070efe84cb S:Calling RcmServer_addSymbol(OmxRpcGetExtensionIndex)
    N:VPSS P:2 #:00899 T:000000070efedc03 S:Calling RcmServer_addSymbol(OmxRpcGetState)
    N:VPSS P:2 #:00900 T:000000070eff2c4b S:Calling RcmServer_addSymbol(OmxRpcSendCommand)
    N:VPSS P:2 #:00901 T:000000070eff80f1 S:Calling RcmServer_addSymbol(OmxRpcUseBuffer)
    N:VPSS P:2 #:00902 T:000000070efffc9f S:Calling RcmServer_addSymbol(OmxRpcAllocBuffer)
    N:VPSS P:2 #:00903 T:000000070f0058bd S:Calling RcmServer_addSymbol(OmxRpcFreeBuffer)
    N:VPSS P:2 #:00904 T:000000070f00ad41 S:Calling RcmServer_addSymbol(OmxRpcEmptyThisBuffer)
    N:VPSS P:2 #:00905 T:000000070f0104c3 S:Calling RcmServer_addSymbol(OmxRpcFillThisBuffer)
    N:VPSS P:2 #:00906 T:000000070f015adb S:Calling RcmServer_addSymbol(OmxRpcTunnelRequest)
    N:VPSS P:2 #:00907 T:000000070f01b7fb S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<256> msg<Before RcmServer_start>
    N:VPSS P:2 #:00908 T:000000070f021d57 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<258> msg<After RcmServer_start>
    N:VPSS P:2 #:00909 T:000000070f02778f S:Instance Register with omxRpc Module.Cnt = 6
    N:VPSS P:2 #:00910 T:000000070f02b1e5 S:L_create: OmxRpc create: Component:OMX.TI.VPSSM3.CTRL.DC, Layer:2
    N:VPSS P:2 #:00911 T:000000070f0309c7 S:Component OMX.TI.VPSSM3.CTRL.DC In table OMX.TI.VPSSM3.VFCC idx 0
    N:VPSS P:2 #:00912 T:000000070f035cf7 S:Component OMX.TI.VPSSM3.CTRL.DC In table OMX.TI.VPSSM3.VFDC idx 1
    N:VPSS P:2 #:00913 T:000000070f03a97b S:Component OMX.TI.VPSSM3.CTRL.DC In table OMX.TI.VPSSM3.VFPC.DEIHDUALOUT idx 2
    N:VPSS P:2 #:00914 T:000000070f03fde5 S:Component OMX.TI.VPSSM3.CTRL.DC In table OMX.TI.VPSSM3.VFPC.DEIMDUALOUT idx 3
    N:VPSS P:2 #:00915 T:000000070f044e55 S:Component OMX.TI.VPSSM3.CTRL.DC In table OMX.TI.VPSSM3.VFPC.NF idx 4
    N:VPSS P:2 #:00916 T:000000070f049dad S:Component OMX.TI.VPSSM3.CTRL.DC In table OMX.TI.VPSSM3.VFPC.INDTXSCWB idx 5
    N:VPSS P:2 #:00917 T:000000070f04f0e7 S:Component OMX.TI.VPSSM3.CTRL.DC In table OMX.TI.VPSSM3.CTRL.TVP idx 6
    N:VPSS P:2 #:00918 T:000000070f053fb9 S:Component OMX.TI.VPSSM3.CTRL.DC In table OMX.TI.VPSSM3.CTRL.DC idx 7
    N:VPSS P:2 #:00919 T:000000070f058fdf S:Component OMX.TI.VPSSM3.CTRL.DC found idx: 7
    N:VPSS P:2 #:00920 T:000000070f05e99b S:In OMX_GetHandle, component OMX.TI.VPSSM3.CTRL.DC, omxhandle 0x9f178440
    N:VPSS P:2 #:00921 T:000000070f06e869 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_SetDefaultProperties> @line<1237>
    N:VPSS P:2 #:00922 T:000000070f07456d S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_SetDefaultProperties> @line<1279> with error<0:ErrorNone>
    N:VPSS P:2 #:00923 T:000000070f080197 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_ComponentInit> @line<107>
    N:VPSS P:2 #:00924 T:000000070f09c7d1 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_InitializePorts> @line<115>
    N:VPSS P:2 #:00925 T:000000070f0a4bef S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_InitializePorts> @line<217> with error<0:ErrorNone>
    N:VPSS P:2 #:00926 T:000000070f0fbb57 S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_ComponentInit> @line<221> with error<0:ErrorNone>
    N:VPSS P:2 #:00927 T:000000070f152711 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_SetCallbacks> @line<241>
    N:VPSS P:2 #:00928 T:000000070f1581b9 S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_SetCallbacks> @line<282> with error<0:ErrorNone>
    N:VPSS P:2 #:00929 T:000000070f15e1fd S:Result of pComponentInit: ErrorNone
    N:VPSS P:2 #:00930 T:000000070f16198b S:Registering the component OMX.TI.VPSSM3.CTRL.DC with TunnelMgr
    N:VPSS P:2 #:00931 T:000000070f165ff9 S:Entered: DomxTunnelMgr_registerHandle (0x9f178440, 0x9f704f54)
    N:VPSS P:2 #:00932 T:000000070f173441 S:Entered function:OmxRpc_rcmClientCreate (0x9f1737d0, OmxRpcRcmServer_OMX.TI.VPSSM3.CTRL.DC_Cb_3_6, 5)
    N:VPSS P:2 #:00933 T:000000070f179bdf S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<983> msg<Before RcmClient_Params_init>
    N:VPSS P:2 #:00934 T:000000070f17f36e S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<985> msg<After RcmClient_Params_init>
    N:VPSS P:2 #:00935 T:000000070f184c3f S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<990> msg<Before RcmClient_create>
    N:VPSS P:2 #:00936 T:000000070f1ebc05 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<992> msg<After RcmClient_create>
    N:VPSS P:2 #:00937 T:000000070f1f3f19 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEventHandler)
    N:VPSS P:2 #:00938 T:000000070f21e387 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEmptyBufferDone)
    N:VPSS P:2 #:00939 T:000000070f241a0d S:main: calling RcmClient_getSymbolIndex(OmxRpcCbFillBufferDone)
    N:VPSS P:2 #:00940 T:000000070f26880d S:Module<ti.omx> @<domxtmgr_register_skelinfo> @line<417> msg<OmxRpcRcmServer_OMX.TI.VPSSM3.CTRL.DC_Ctrl_2_5>
    N:VPSS P:2 #:00941 T:000000070f272245 S:OmxRpc_rcmIfGetHandle:ComponentName:OmxRpcRcmServer_OMX.TI.VPSSM3.CTRL.DC_Ctrl_2_5.Exiting..
    N:VPSS P:2 #:00942 T:000000070fe57243 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_GetParameter> @line<664>
    N:VPSS P:2 #:00943 T:000000070fe5e98d S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_GetParameter> @line<827> with error<0:ErrorNone>
    N:VPSS P:2 #:00944 T:000000070fe8a6d1 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_SetParameter> @line<859>
    N:VPSS P:2 #:00945 T:000000070fe90c2b S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_SetParameter> @line<1132> with error<0:ErrorNone>
    N:VPSS P:2 #:00946 T:000000070ff2d05d S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_SetParameter> @line<859>
    N:VPSS P:2 #:00947 T:000000070ff33a87 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_SetParameter> @line<1132> with error<0:ErrorNone>
    N:VPSS P:2 #:00948 T:000000070ff5a24d S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_SendCommand> @line<472>
    N:VPSS P:2 #:00949 T:000000070ff63029 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_SendCommand> @line<638> with error<0:ErrorNone>
    N:VPSS P:2 #:00950 T:000000070ff72b8d S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00951 T:000000070ff7b015 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:00952 T:000000070ff807d9 S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_PROCESS_CmdEvent> @line<631> msg<Processing OMX_CommandPortEnable>
    N:VPSS P:2 #:00953 T:000000070ff87081 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_EnablePort> @line<776>
    N:VPSS P:2 #:00954 T:000000070ff8c2a1 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_EnablePort> @line<814> with error<0:ErrorNone>
    N:VPSS P:2 #:00955 T:000000070ff92d3d S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:00956 T:000000070ff98503 S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_CB_ReturnEventNotify> @line<121> msg<Notify client for port enable>
    N:VPSS P:2 #:00957 T:000000070ff9f29f S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<222> with error<0:ErrorNone>
    N:VPSS P:2 #:00958 T:000000070ffa5523 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:00959 T:000000070ffab2e5 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00960 T:000000070ffb1c73 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:00961 T:000000070ffb747b S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:00962 T:000000070ffbfcbf S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<869> msg<Processing OMX_CommandPortEnable>
    N:VPSS P:2 #:00963 T:000000070ffc65f7 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_EventNotifyToClient> @line<880>
    N:VPSS P:2 #:00964 T:000000070fffc6f5 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_SendCommand> @line<472>
    N:VPSS P:2 #:00965 T:0000000710006a19 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<OMX_BASE_SendCommand> @line<638> with error<0:ErrorNone>
    N:VPSS P:2 #:00966 T:000000071001be99 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1171> with error<0:ErrorNone>
    N:VPSS P:2 #:00967 T:00000007100228df S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:00968 T:000000071002916b S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:00969 T:000000071002f8dd S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00970 T:00000007100382b1 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00971 T:0000000710041403 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00972 T:00000007100486b7 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:00973 T:000000071004dfd3 S:Module<OMX.TI.VPSSM3.CTRL.TVP> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:00974 T:0000000710054717 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS P:2 #:00975 T:000000071005a16b S:Module<OMX.TI.VPSSM3.CTRL.TVP> @<_OMX_BASE_HandleStateTransition> @line<338> msg<Loaded to Idle Transition>
    N:VPSS P:2 #:00976 T:00000007100613f3 S:Entered _OMX_CTRLTvpDrvCreate: 569
    N:VPSS P:2 #:00977 T:000000071eea9af3 S:Created Driver Video DecoderId: 1025
    N:VPSS P:2 #:00978 T:000000071eec654d S:FVID Control GetChipId Success:
    N:VPSS P:2 #:00979 T:000000071eed21cd S: OMXCTRL_TVP: VIP 0: VID DEC 0401 (0x5d): 7002:0002:0000
    N:VPSS P:2 #:00980 T:000000073cd9de99 S:FVID Control SetVideoMode Success:
    N:VPSS P:2 #:00981 T:000000073cda29f7 S: OMX_CTRL_DriverCreate - DONE !!!
    N:VPSS P:2 #:00982 T:000000073cda6785 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:00983 T:000000073cdac249 S:Module<OMX.TI.VPSSM3.CTRL.TVP> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS P:2 #:00984 T:000000073cdb372f S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<222> with error<0:ErrorNone>
    N:VPSS P:2 #:00985 T:000000073cdb9a51 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<_OMX_BASE_HandleStateTransition> @line<482> with error<0:ErrorNone>
    N:VPSS P:2 #:00986 T:000000073cdc00cb S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:00987 T:000000073cdc6711 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00988 T:000000073cdcd48f S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:00989 T:000000073cdd2d47 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:00990 T:000000073cdda3a1 S:Module<OMX.TI.VPSSM3.CTRL.TVP> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:00991 T:000000073cde09b1 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<505>
    N:VPSS P:2 #:00992 T:000000073cde64a9 S:Module<OMX.TI.VPSSM3.CTRL.TVP> @<_OMX_BASE_HandleStateTransitionComplete> @line<534> msg<Loaded to Idle Transition>
    N:VPSS P:2 #:00993 T:000000073cdece39 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_RestoreDioGroupInfo> @line<1397>
    N:VPSS P:2 #:00994 T:000000073cdf2fe5 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<OMX_BASE_RestoreDioGroupInfo> @line<1452> with error<0:ErrorNone>
    N:VPSS P:2 #:00995 T:000000073cdf96c1 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<703> with error<0:ErrorNone>
    N:VPSS P:2 #:00996 T:000000073ce00301 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<_OMX_BASE_EventNotifyToClient> @line<880>
    N:VPSS P:2 #:00997 T:000000073ce37b69 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_SendCommand> @line<472>
    N:VPSS P:2 #:00998 T:000000073ce41c5f S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_SendCommand> @line<638> with error<0:ErrorNone>
    N:VPSS P:2 #:00999 T:000000073ce53ee3 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:01000 T:000000073ce5bb5f S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:01002 T:000000073ce704e7 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01003 T:000000073ce8b3fb S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Init> @line<120>
    N:VPSS P:2 #:01004 T:000000073ce911b9 S:Entered: OMX_BASE_DIO_Init (0x9f0bf1a8, 0, OMX.DIO.NONTUNNEL, 0x9f0beb34)
    N:VPSS P:2 #:01005 T:000000073ce9c195 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:VPSS P:2 #:01006 T:000000073cea1da5 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Open> @line<252>
    N:VPSS P:2 #:01007 T:000000073cf64305 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Open> @line<257> with error<0:ErrorNone>
    N:VPSS P:2 #:01001 T:000000073ce60e7f S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:01008 T:000000073cf78fff S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS P:2 #:01010 T:000000073cf90d57 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01009 T:000000073cf7f361 S:Module<OMX.TI.VPSSM3.VFCC> @<_OMX_BASE_HandleStateTransition> @line<338> msg<Loaded to Idle Transition>
    N:VPSS P:2 #:01011 T:000000073cfc78f3 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01012 T:000000073cffcc31 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01013 T:000000073d031b69 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01014 T:000000073d067eb3 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01015 T:000000073d0953d1 S: OMX_VFCC_DriverCreate - DONE !!!
    N:VPSS P:2 #:01016 T:000000073d0997bf S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:01017 T:000000073d09f5ed S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS P:2 #:01018 T:000000073d0a6e7b S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<222> with error<0:ErrorNone>
    N:VPSS P:2 #:01019 T:000000073d0ad66d S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_HandleStateTransition> @line<482> with error<0:ErrorNone>
    N:VPSS P:2 #:01020 T:000000073d0b7145 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:01021 T:000000073d0bd9ff S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:01022 T:000000073d0c4ee5 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:01023 T:000000073d0ca1f5 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:01024 T:000000073d0cfb17 S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:01025 T:000000073d0d639b S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<505>
    N:VPSS P:2 #:01026 T:000000073d0dc1b3 S:Module<OMX.TI.VPSSM3.VFCC> @<_OMX_BASE_HandleStateTransitionComplete> @line<534> msg<Loaded to Idle Transition>
    N:VPSS P:2 #:01027 T:000000073d0e36f5 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_RestoreDioGroupInfo> @line<1397>
    N:VPSS P:2 #:01028 T:000000073d0e932d S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_RestoreDioGroupInfo> @line<1452> with error<0:ErrorNone>
    N:VPSS P:2 #:01029 T:000000073d0eff7b S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<703> with error<0:ErrorNone>
    N:VPSS P:2 #:01030 T:000000073d0f65f3 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_EventNotifyToClient> @line<880>
    N:VPSS P:2 #:01031 T:000000073d1319a9 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_SendCommand> @line<472>
    N:VPSS P:2 #:01032 T:000000073d13c015 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_SendCommand> @line<638> with error<0:ErrorNone>
    N:VPSS P:2 #:01034 T:000000073d1642bf S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01035 T:000000073d17a6a5 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Init> @line<120>
    N:VPSS P:2 #:01036 T:000000073d180843 S:Entered: OMX_BASE_DIO_Init (0x9f122c30, 0, OMX.DIO.NONTUNNEL, 0x9f1225bc)
    N:VPSS P:2 #:01037 T:000000073d18b969 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:VPSS P:2 #:01038 T:000000073d191c8b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Open> @line<252>
    N:VPSS P:2 #:01039 T:000000073d23168b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Open> @line<257> with error<0:ErrorNone>
    N:VPSS P:2 #:01033 T:000000073d15332d S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1171> with error<0:ErrorNone>
    N:VPSS P:2 #:01040 T:000000073d24736f S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:01042 T:000000073d260695 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01041 T:000000073d24e481 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:01043 T:000000073d2814ad S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:01045 T:000000073d2988dd S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01044 T:000000073d288287 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:01047 T:000000073d2ce805 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01046 T:000000073d2bcb71 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<_OMX_BASE_EventNotifyToClient> @line<1171> with error<0:ErrorNone>
    N:VPSS P:2 #:01048 T:000000073d2f0189 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:01050 T:000000073d304a4d S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01049 T:000000073d2f74ab S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:01052 T:000000073d33a795 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01051 T:000000073d32b541 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:01053 T:000000073d35cb65 S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:01055 T:000000073d374439 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01056 T:000000073d3898fd S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Init> @line<120>
    N:VPSS P:2 #:01057 T:000000073d391bd3 S:Entered: OMX_BASE_DIO_Init (0x9f122c30, 16, OMX.DIO.NONTUNNEL, 0x9f1225bc)
    N:VPSS P:2 #:01058 T:000000073d39cb9d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:VPSS P:2 #:01059 T:000000073d3a2c0f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Open> @line<252>
    N:VPSS P:2 #:01060 T:000000073d4481a9 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Open> @line<257> with error<0:ErrorNone>
    N:VPSS P:2 #:01054 T:000000073d365eb5 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:01062 T:000000073d473bd1 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01061 T:000000073d46316d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:01063 T:000000073d496f27 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:01065 T:000000073d4ab171 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01064 T:000000073d49e579 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS P:2 #:01067 T:000000073d4dfbc1 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01066 T:000000073d4ceadd S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> @<_OMX_BASE_HandleStateTransition> @line<338> msg<Loaded to Idle Transition>
    N:VPSS P:2 #:01068 T:000000073d5130cb S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01069 T:000000073d54b95e S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01070 T:000000073d5618b9 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Init> @line<120>
    N:VPSS P:2 #:01071 T:000000073d567801 S:Entered: OMX_BASE_DIO_Init (0x9f122c30, 17, OMX.DIO.NONTUNNEL, 0x9f1225bc)
    N:VPSS P:2 #:01072 T:000000073d572821 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:VPSS P:2 #:01073 T:000000073d57bf69 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_DIO_Open> @line<252>
    N:VPSS P:2 #:01074 T:000000073d60eb0b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_DIO_Open> @line<257> with error<0:ErrorNone>
    N:VPSS P:2 #:01075 T:000000073d639507 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01076 T:000000073d67c2f1 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01077 T:000000073d6c3a8b S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS P:2 #:01078 T:000000073d722b21 S:M2M Driver DEI-DualOut Opened!!
    N:VPSS P:2 #:01079 T:000000073d727f8c S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:01080 T:000000073d72e0eb S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS P:2 #:01081 T:000000073d735caf S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<222> with error<0:ErrorNone>
    N:VPSS P:2 #:01082 T:000000073d73c551 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_HandleStateTransition> @line<482> with error<0:ErrorNone>
    N:VPSS P:2 #:01083 T:000000073d743687 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:01084 T:000000073d74a1a7 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:01085 T:000000073d7516cd S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:01086 T:000000073d7574ff S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:01087 T:000000073d75d04f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:01088 T:000000073d76742f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<505>
    N:VPSS P:2 #:01089 T:000000073d76d511 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> @<_OMX_BASE_HandleStateTransitionComplete> @line<534> msg<Loaded to Idle Transition>
    N:VPSS P:2 #:01090 T:000000073d775ac1 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_RestoreDioGroupInfo> @line<1397>
    N:VPSS P:2 #:01091 T:000000073d77bff1 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_RestoreDioGroupInfo> @line<1452> with error<0:ErrorNone>
    N:VPSS P:2 #:01092 T:000000073d783623 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<703> with error<0:ErrorNone>
    N:VPSS P:2 #:01093 T:000000073d78a77f S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<_OMX_BASE_EventNotifyToClient> @line<880>
    N:VPSS P:2 #:01094 T:000000073d7c1291 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_SendCommand> @line<472>
    N:VPSS P:2 #:01095 T:000000073d7cb4f9 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_SendCommand> @line<638> with error<0:ErrorNone>
    N:VPSS P:2 #:01097 T:000000073d7f449d S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS P:2 #:01098 T:000000073d80982f S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Init> @line<120>
    N:VPSS P:2 #:01099 T:000000073d80f191 S:Entered: OMX_BASE_DIO_Init (0x9f0f81f0, 0, OMX.DIO.NONTUNNEL, 0x9f0f7b8c)
    N:VPSS P:2 #:01100 T:000000073d81afdf S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:VPSS P:2 #:01101 T:000000073d820dab S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Open> @line<252>
    N:VPSS P:2 #:01102 T:000000073d848b51 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Open> @line<257> with error<0:ErrorNone>
    N:VPSS P:2 #:01096 T:000000073d7e4fe1 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<_OMX_BASE_EventNotifyToClient> @line<1171> with error<0:ErrorNone>
    N:VPSS P:2 #:01103 T:000000073d85fb9b S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:01105 T:000000073d873a07 S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS P:2 #:01104 T:000000073d866fa3 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:01107 T:000000073d8a6cab S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS P:2 #:01106 T:000000073d89792d S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:01108 T:000000073d8c5006 S:Module<OMX.TI.VPSSM3.VFPC.DEIHDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:01109 T:000000073d8db079 S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS P:2 #:01110 T:000000073d8f7c45 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:01112 T:000000073d90f131 S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS P:2 #:01111 T:000000073d8ff7cf S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:01113 T:000000073d92d67f S:Module<OMX.TI.VPSSM3.VFPC.NF> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:01115 T:000000073d943523 S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS P:2 #:01114 T:000000073d9343a7 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS P:2 #:01116 T:000000073d96353b S:Module<OMX.TI.VPSSM3.VFPC.NF> @<_OMX_BASE_HandleStateTransition> @line<338> msg<Loaded to Idle Transition>
    N:VPSS P:2 #:01117 T:000000073d97c92b S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS P:2 #:01118 T:000000073d991111 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Init> @line<120>
    N:VPSS P:2 #:01119 T:000000073d9966ff S:Entered: OMX_BASE_DIO_Init (0x9f0f81f0, 16, OMX.DIO.NONTUNNEL, 0x9f0f7b8c)
    N:VPSS P:2 #:01120 T:000000073d9a1801 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:VPSS P:2 #:01121 T:000000073d9a75a7 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_DIO_Open> @line<252>
    N:VPSS P:2 #:01122 T:000000073d9e9691 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01123 T:000000073da2bca1 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01124 T:000000073da6e46b S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01125 T:000000073dab1e8f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01126 T:000000073daf03d3 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01127 T:000000073db389c9 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01128 T:000000073db7818b S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01129 T:000000073dbb60e3 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01131 T:000000073dbf431d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01132 T:000000073dc318e9 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01130 T:000000073dbe8229 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:01134 T:000000073dc70cc9 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01133 T:000000073dc6183b S:Module<OMX.TI.VPSSM3.VFPC.NF> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS P:2 #:01135 T:000000073dcad489 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01137 T:000000073dceac05 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01136 T:000000073dcdbc4d S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<222> with error<0:ErrorNone>
    N:VPSS P:2 #:01138 T:000000073dd27917 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01140 T:000000073dd65539 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01139 T:000000073dd562cb S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_HandleStateTransition> @line<482> with error<0:ErrorNone>
    N:VPSS P:2 #:01141 T:000000073dda0567 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01143 T:000000073ddddae3 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01142 T:000000073ddcebaf S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:01144 T:000000073de1964b S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01146 T:000000073de60fb9 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01145 T:000000073de5161d S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:01148 T:000000073dea0489 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01147 T:000000073de9547d S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:01149 T:000000073deddd07 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01151 T:000000073df1c441 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01150 T:000000073df0ebd9 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:01153 T:000000073df5b477 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01152 T:000000073df4be37 S:Module<OMX.TI.VPSSM3.VFPC.NF> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:01155 T:000000073df9ccc9 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01154 T:000000073df8ebf1 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<505>
    N:VPSS P:2 #:01156 T:000000073dfcd185 S:Module<OMX.TI.VPSSM3.VFPC.NF> @<_OMX_BASE_HandleStateTransitionComplete> @line<534> msg<Loaded to Idle Transition>
    N:VPSS P:2 #:01157 T:000000073dfddf07 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01159 T:000000073e01f733 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01158 T:000000073e011769 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<OMX_BASE_RestoreDioGroupInfo> @line<1397>
    N:VPSS P:2 #:01161 T:000000073e06068b S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01160 T:000000073e051367 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<OMX_BASE_RestoreDioGroupInfo> @line<1452> with error<0:ErrorNone>
    N:VPSS P:2 #:01163 T:000000073e0a35cb S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01162 T:000000073e094187 S:Module<OMX.TI.VPSSM3.VFPC.NF> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<703> with error<0:ErrorNone>
    N:VPSS P:2 #:01165 T:000000073e0e3a19 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01164 T:000000073e0d5bc1 S:Module<OMX.TI.VPSSM3.VFPC.NF> Entering<_OMX_BASE_EventNotifyToClient> @line<880>
    N:VPSS P:2 #:01166 T:000000073e12305f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01167 T:000000073e161b5f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01168 T:000000073e1a0949 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01169 T:000000073e1e0767 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01170 T:000000073e21dc8d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01171 T:000000073e25e007 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01172 T:000000073e29a9e1 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01173 T:000000073e2d99d5 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01174 T:000000073e315c7f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01175 T:000000073e354251 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01176 T:000000073e390159 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01177 T:000000073e3ce915 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01178 T:000000073e40a963 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01179 T:000000073e44923d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01180 T:000000073e4895e9 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01181 T:000000073e4c75b7 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01182 T:000000073e50497d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01183 T:000000073e5410bb S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01184 T:000000073e57df0d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01185 T:000000073e5baaf1 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01186 T:000000073e5f6c21 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01187 T:000000073e63c023 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01188 T:000000073e67a591 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01189 T:000000073e6b8ebd S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01190 T:000000073e6f5c71 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01191 T:000000073e73396b S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01192 T:000000073e770a4b S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01193 T:000000073e7aeb5b S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01194 T:000000073e7ec2d1 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01195 T:000000073e82aec5 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01196 T:000000073e8679b7 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01197 T:000000073e8a693d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01198 T:000000073e8e3a33 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01199 T:000000073e922364 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01200 T:000000073e9697a5 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01201 T:000000073e9a8fc3 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01202 T:000000073e9e751f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01203 T:000000073ea25ef3 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01204 T:000000073ea63863 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01205 T:000000073eaa233d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01206 T:000000073eadf82b S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01207 T:000000073eb1dfa1 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01208 T:000000073eb5af75 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01209 T:000000073eb9893b S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01210 T:000000073ebd5bed S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01211 T:000000073ec134f7 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01212 T:000000073ec5054d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01213 T:000000073ec8de8d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01214 T:000000073eccaef5 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01215 T:000000073ed08663 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01216 T:000000073ed4534d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01217 T:000000073ed82f6f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01218 T:000000073edbfd3d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01219 T:000000073ee16845 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01220 T:000000073ee677ff S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01221 T:000000073eea8b8e S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01222 T:000000073eef271b S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01223 T:000000073ef3d5e9 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01224 T:000000073ef80769 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01225 T:000000073efca4bf S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01226 T:000000073f011bb1 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01227 T:000000073f05bb67 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01228 T:000000073f09ef19 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01229 T:000000073f0e78f1 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01230 T:000000073f12fc51 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01231 T:000000073f17811f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01232 T:000000073f1c50fb S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01233 T:000000073f20834f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01234 T:000000073f25454b S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01235 T:000000073f2a071f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01236 T:000000073f3e9b4b S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01237 T:000000073f4314b7 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01238 T:000000073f47db89 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01239 T:000000073f4c8129 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01240 T:000000073f50d0cb S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01241 T:000000073f55f5ad S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01242 T:000000073f5a4c23 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01243 T:000000073f5f6055 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01244 T:000000073f6370e7 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01245 T:000000073f6824cb S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01246 T:000000073f6cbd2f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01247 T:000000073f7110ad S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01248 T:000000073f7607a9 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01249 T:000000073f7ac48d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01250 T:000000073f7f8377 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01251 T:000000073f84338b S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01252 T:000000073f892ba3 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01253 T:000000073f97dd67 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01254 T:000000073f9c1dad S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01255 T:000000073fa0c86f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01256 T:000000073fa4f1bd S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01257 T:000000073fa97a0b S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01258 T:000000073fae4c53 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01259 T:000000073fb33a7d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01260 T:000000073fb77b95 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01261 T:000000073fbc329d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01262 T:000000073fc0e573 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01263 T:000000073fc5e031 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01264 T:000000073fca0293 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01265 T:000000073fce828d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01266 T:000000073fd2a8f1 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01267 T:000000073fd74241 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01268 T:000000073fdbd403 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01269 T:000000073fe09403 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01270 T:000000073ff12ebd S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01271 T:000000073ff59015 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01272 T:000000073ffa50cb S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01273 T:000000073fff0eb7 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01274 T:00000007400338fb S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01275 T:000000074007d37f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01276 T:00000007400c8629 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01277 T:000000074010c2e5 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01278 T:0000000740149b77 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01279 T:0000000740187c67 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01280 T:00000007401c4f49 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01281 T:0000000740202909 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01282 T:000000074023f819 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01283 T:000000074027d7ef S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01284 T:00000007402ba7cf S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01285 T:00000007402f8297 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01286 T:00000007403351bf S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01287 T:00000007403728b5 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01288 T:00000007403af82b S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01289 T:00000007404b34d9 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01290 T:00000007404f14ab S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01291 T:000000074052f65f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01292 T:000000074056f52b S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01293 T:00000007405af935 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01294 T:00000007405ec47f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01295 T:0000000740628f6f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01296 T:0000000740664f3d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01297 T:00000007406a1033 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01298 T:00000007406dce9d S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01299 T:00000007407192ed S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01300 T:0000000740754f85 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01301 T:0000000740793561 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01302 T:00000007407cf607 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01303 T:000000074080d4d1 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01304 T:000000074084938f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01305 T:000000074088766f S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01306 T:00000007408c38a3 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01307 T:0000000740901732 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01308 T:000000074093d5c7 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01309 T:0000000740a2f837 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01310 T:0000000740a6fbdd S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01311 T:0000000740aac1ff S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01312 T:0000000740ae9e73 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01313 T:0000000740b26283 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01314 T:0000000740b63edb S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01315 T:0000000740b9fdcf S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01316 T:0000000740bddfa9 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01317 T:0000000740c1a059 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01318 T:0000000740c581a1 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01319 T:0000000740c93eaf S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01320 T:0000000740cd22fd S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01321 T:0000000740d0e117 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01322 T:0000000740d4ff71 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01323 T:0000000740d8d8d1 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    N:VPSS P:2 #:01324 T:0000000740dc9ef5 S:ERROR: "RcmClient.c", line 382: RcmClient_Instance_init: given server not found, server=0x9f48e9d8
    shinji miki
  • Shinji,
    I noticed you have not setup memory type for NF. It appears as something is corrupted in memory for NF. Could you setup memory type as default , it is same as DEI in the example. SetDeiParams code has this example.
    Vimal
  • Vimal
    Thank you for reply.
    I add setup memory type for NF.
    Then, all modules executed.(success to allocate memory)
    But, video out is black screen...
    I checked another application.
    capt(YUV422) --> DisVGA (Direct live display) OK.
    NF modules is can't convert video format ?
    I need only convert video format (YUV422 to YUV420)
    Input video YUV422(1920x1080)
    Output video YUV420(1920x1080)
    Please check my NF setup parameter.
    ----------- IL_ClientSetNfParams() -------------
    ------ OMX_PARAM_BUFFER_MEMORYTYPE ----
    Nf Input Port
    nSize = 16
    nVersion = 0x101
    nPortIndex = 0
    eBufMemoryType = 1 [OMX_BUFFER_MEMORY_DEFAULT ]
    ------ end of OMX_PARAM_BUFFER_MEMORYTYPE ----
    Nf Output Port
    nSize = 16
    nVersion = 0x101
    nPortIndex = 16
    Buffer Size computed: 4147200
    set input port params (width = 1920, height = 1080)
    ------ OMX_PARAM_PORTDEFINITIONTYPE ----
    Nf Input Port
    nSize = 96
    nVersion = 0x20101
    nPortIndex = 0
    eDir = 0(OMX_DirInput)
    nBufferCountActual = 6
    nBufferCountMin = 1
    nBufferSize = 4147200
    bEnabled = 0
    bPopulated = 0
    eDomain = 1[OMX_PortDomainVideo]
    format.video.cMIMEType = (null)
    format.video.pNativeRender = (nil)
    format.video.nFrameWidth = 1920
    format.video.nFrameHeight = 1080
    format.video.nStride = 3840
    format.video.nSliceHeight = 0
    format.video.nBitrate = 0
    format.video.xFramerate = 30
    format.video.bFlagErrorConcealment = 0
    format.video.eCompressionFormat = 0x0
    format.video.eColorFormat = 0x19
    format.video.pNativeWindow = (nil)
    bBuffersContiguous = 0
    nBufferAlignment = 128
    ------ end of OMX_PARAM_PORTDEFINITIONTYPE ----
    Buffer Size computed: 3110400
    Nf Output Port
    nSize = 96
    nVersion = 0x20101
    nPortIndex = 16
    eDir = 1(OMX_DirOutput)
    nBufferCountMin = 4
    nBufferSize = 3110400
    bEnabled = 0
    bPopulated = 0
    format.video.nStride = 1920
    format.video.eColorFormat = 0x15
    set number of channels
    set input resolution
    ------ OMX_CONFIG_VIDCHANNEL_RESOLUTION ----
    Set Input resolution
    nSize = 60
    nVersion = 0x101
    nPortIndex = 0
    nChId = 0
    Frm0Width = 1920
    Frm0Height = 1080
    Frm0Pitch = 3840
    Frm1Width = 0
    Frm1Height = 0
    Frm1Pitch = 0
    FrmStartX = 0
    FrmStartY = 0
    FrmCropWidth = 1920
    FrmCropHeight = 1080
    ------ end of OMX_CONFIG_VIDCHANNEL_RESOLUTION ----
    set output resolution
    Set Output resolution
    nSize = 60
    nVersion = 0x101
    nPortIndex = 0
    nChId = 0
    Frm0Width = 1920
    Frm0Height = 1080
    Frm0Pitch = 1920
    Frm1Width = 0
    Frm1Height = 0
    Frm1Pitch = 0
    FrmStartX = 0
    FrmStartY = 0
    FrmCropWidth = 1920
    ------- OMX_CONFIG_ALG_ENABLE ----
    algEnable.nPortIndex = 0;
    algEnable.nChId = 0;
    algEnable.bAlgBypass = 0;
    ------- OMX_CONFIG_SUBSAMPLING_FACTOR ----
    para.nPortIndex = OMX_NF_OUTPUT_PORT_START_INDEX;
    para. nSubSamplingFactor = 1;
    shinji miki
  • Vimal
    I'm sorry
    The NF module is operating normally.
    It has displayed normally.
    I forgot display setup.
    echo 0 > /sys/devices/platform/vpss/graphics0/enabled
    echo 0 > /sys/devices/platform/vpss/graphics1/enabled
    Thank you
    Shinji Miki
  • Shinji,
    Thanks for confirming !
    Vimal
  • Hi, can you help me?
    I used EZSDK505, omtb is as following:
    omx setp 0 vfcc data_opmode file
    omx setp 0 vfcc outfile /usr/share/ti/ti-omtb/cap.yuv
    why the size of cap.yuv is zero?
  • Hi.
    I can't help you.
    I have not tried the output of a yuv file on OMTB.
    I do not know whether the vfcc module has the capability which a yuv file outputs.
    How about you modify omx demo application for outputting a yuv file?
    (ex.capture_encode)
    Miki Shinji
  • Hi,MiKi
    I need your help.  Can you help me?
    you added the NF component in your program, is right? your display is normal in screen?
    I used cap-nf-dei-display, but there is a gray rectangle in the bottom of screen. (I used omx program: caputer-encode,EZSDK505,8168)
  • Hi Shinji,
        I know that you have successfully made use of NF component to convert colorformat from 422 to 420SP. Now I need to do the same thing to match the input format of the DUCATI.VIDENC component. So, could you kindly share your sample with me?
       Thanks so much! Appreciate for your reply!
