Other Parts Discussed in Thread: DM3730, OMAP3530
Our customer is developing products based on DM3730, using Android 2.2 (TI_Android_DevKit 02_02_00), found the following problem when doing system power on/off testing.
Have tested two products with 100 times power on/off (power on---wait for Android GUI showing on LCD -->power off-->power on within 1 or 2 seconds-->...), and appeared 4 times of white screen display and 7 times of kernel collapse, and Other 89 times of normal boot.
For white screen display problem, it means LCD displays total white with flickering, and UART log shows:
omapdss DISPC error: SYNC_LOST, disabling LCD omapdss DISPC error: SYNC_LOST, disabling LCD omapdss DISPC error: SYNC_LOST, disabling LCD omapdss DISPC error: SYNC_LOST, disabling LCD
PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
PVR_K: EUR_CR_EVENT_STATUS: 20000000
PVR_K: EUR_CR_EVENT_STATUS2: 8
PVR_K: EUR_CR_BIF_CTRL: 0
PVR_K: EUR_CR_BIF_INT_STAT: 0
PVR_K: EUR_CR_BIF_FAULT: 0
PVR_K: EUR_CR_BIF_MEM_REQ_STAT: 0
PVR_K: EUR_CR_CLKGATECTL: 222220
PVR_K: EUR_CR_PDS_PC_BASE: 0
PVR_K: SGX Host control:
PVR_K: 0x0: 0x00000001 0x00000000 0x00000000 0x00000000
PVR_K: 0x10: 0x00000001 0x0000000A 0x00030D40 0x00000065
PVR_K: 0x20: 0x00000000 0x00000001 0x0000000C 0x00000000
PVR_K: 0x30: 0x000030DC 0xE59D0000 0xE8BD8FFE 0x00000000
PVR_K: SGX TA/3D control:
PVR_K: 0x0: 0x0F002000 0x0F002120 0x0F001000 0x0F0CCCC0
PVR_K: 0x10: 0x00000001 0x00000002 0x00000001 0x0F0BA4E0
PVR_K: 0x20: 0x00000000 0x00000000 0x00000018 0x00000000
PVR_K: 0x30: 0x00000002 0x00000000 0x00000000 0x00000000
PVR_K: 0x40: 0x00000000 0x00000000 0x00000000 0x00000000
PVR_K: 0x50: 0x00000000 0x00000000 0x00000000 0x00000000
PVR_K: 0x60: 0x00000000 0x00000000 0x0F097420 0x00000000
PVR_K: 0x70: 0x00000000 0x0F0BA4E0 0x00000000 0x00000000
PVR_K: 0x80: 0x00000000 0x00000000 0x00000000 0x0F000000
PVR_K: 0x90: 0x8B7AF000 0x0F0C4200 0x00000000 0x0F098A00
PVR_K: 0xA0: 0x0F0BA4E0 0x00000000 0x0F098420 0x00000000
PVR_K: 0xB0: 0x0F006880 0x00000003 0x00000000 0x00000000
PVR_K: 0xC0: 0x00000001 0x00000000 0x00000000 0x00000000
PVR_K: 0xD0: 0x00000000 0x00000000 0x00000000 0x00000000
PVR_K: 0xE0: 0x00000075 0x00000074 0x0F000000 0x80007000
PVR_K: 0xF0: 0x80047000 0x0F003000 0x00000000 0x00000000
PVR_K: 0x100: 0x00000000 0xE58B2024 0xE59F2110 0xE58B5018
PVR_K: Command Complete Data for display device 1:
PVR_K: SRC 0: (Not in use)
PVR_K: SRC 1: (Not in use)
For Kernel collapse, the detail log:
## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux-2.6.32 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2986476 Bytes = 2.8 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux............................................................................................................................................................................................... done, booting the kernel. Linux version 2.6.32 (xue@xue-desktop) (gcc version 4.4.0 (GCC) ) #903 Wed Dec 28 16:30:23 CST 2011 CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Machine: OMAP3 EVM Memory policy: ECC disabled, Data cache writeback OMAP3630/DM3730 ES1.0 (l2cache iva sgx neon isp 192mhz_clk ) SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x100000 Reserving 4194304 bytes SDRAM for VRAM Built 1 zonelists in Zone order, mobility grouping on. Total pages: 114688 Kernel command line: console=ttyS0,115200n8 androidboot.console=ttyS0 mem=68M@0x80000000 mem=384M@0x88000000 mpurate=1000 omap_vout.vid1_static_vrfb_alloc=y omap_vout.vid2_static_vrfb_alloc=y init=/init initrd=0x83000000,0x500000 ubi.mtd=5 root=/dev/ram ro PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory: 68MB 384MB = 452MB total Memory: 442496KB available (5308K code, 938K data, 188K init, 0K highmem) Hierarchical RCU implementation. NR_IRQS:402 Clocking rate (Crystal/Core/MPU): 26.0/400/600 MHz sys_clkout1 rate is 26.0 MHz Reprogramming SDRC clock to 400000000 Hz GPMC revision 5.0 IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts Total of 96 interrupts on 1 active controller OMAP GPIO hardware version 2.5 OMAP clockevent source: GPTIMER1 at 32768 Hz Console: colour dummy device 80x30 Calibrating delay loop... 597.64 BogoMIPS (lpj=2334720) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok regulator: core version 0.5 NET: Registered protocol family 16 Package is : 3 gpio_request ********* gpio=22, label=enable EHCI VBUS gpio_request ********* gpio=11, label=ADS7846 pendown gpio_request ********* gpio=139, label=SMSC911x irq gpio_request ********* gpio=162, label=lcd_panel_resb gpio_request ********* gpio=152, label=lcd_panel_ini gpio_request ********* gpio=154, label=lcd_panel_qvga gpio_request ********* gpio=2, label=lcd_panel_lr gpio_request ********* gpio=3, label=lcd_panel_ud gpio_request ********* gpio=167, label=lcd_panel_envdd gpio_request ********* gpio=177, label=handset-hook gpio_request ********* gpio=138, label=speaker-ctrl gpio_request ********* gpio=173, label=tiwlan-enable Target VDD1 OPP = 4, VDD2 OPP = 2 gpio_request ********* gpio=136, label=camera-on gpio_request ********* gpio=98, label=camera-reset gpio_request ********* gpio=26, label=camera-pwdn omap3evm-ov26xx: Driver registration complete OMAP DMA hardware revision 5.0 bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb omap_i2c_probe : mem is 48070000, irq = 56 i2c_omap i2c_omap.1: bus 1 rev4.0 at 250 kHz client [dummy] registered with bus id 1-0049 client [dummy] registered with bus id 1-004a client [dummy] registered with bus id 1-004b twl4030: PIH (irq 7) chaining IRQs 368..375 twl4030: power (irq 373) chaining IRQs 376..383 twl4030: gpio (irq 368) chaining IRQs 384..401 gpio_request ********* gpio=150, label=mmc_wp gpio_request ********* gpio=199, label=EN_DVI regulator: VUSB1V5: 1500 mV normal standby regulator: VUSB1V8: 1800 mV normal standby regulator: VUSB3V1: 3100 mV normal standby twl4030_usb twl4030_usb: Initialized TWL4030 USB module sts-boot is 0 CFG-boot is 1a CFG-boot is 9a regulator: VMMC1: 1850 <--> 3150 mV normal standby regulator: VDAC: 1800 mV normal standby regulator: VAUX2_4030: 1800 mV normal standby regulator: VPLL2: 1800 mV normal standby regulator: VSIM: 1800 <--> 3000 mV normal standby client [twl4030] registered with bus id 1-0048 client [tlv320aic3x] registered with bus id 1-0018 client [Goodix-TS] registered with bus id 1-0055 omap_i2c_probe : mem is 48072000, irq = 57 i2c_omap i2c_omap.2: bus 2 rev4.0 at 400 kHz omap_i2c_probe : mem is 48060000, irq = 61 i2c_omap i2c_omap.3: bus 3 rev4.0 at 400 kHz client [ov2659] registered with bus id 3-0030 Bluetooth: Core ver 2.15 NET: Registered protocol family 31 Bluetooth: HCI device and connection manager initialized Bluetooth: HCI socket layer initialized Switching to clocksource 32k_counter musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0 musb_hdrc: USB Host mode controller at fa0ab000 using DMA, IRQ 92 musb_hdrc musb_hdrc: MUSB HDRC host driver musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1 usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: MUSB HDRC host driver usb usb1: Manufacturer: Linux 2.6.32 musb-hcd usb usb1: SerialNumber: musb_hdrc hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 4, 65536 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Trying to unpack rootfs image as initramfs... rootfs image is not initramfs (junk in compressed archive); looks like an initrd Freeing initrd memory: 5120K omap-iommu omap-iommu.0: isp registered AM37x/DM37x Linux PSP version 03.00.01.06 (OMAP3EVM) NetWinder Floating Point Emulator V0.97 (double precision) ashmem: initialized VFS: Disk quotas dquot_6.5.2 Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) JFFS2 version 2.2. (NAND) 2001-2006 Red Hat, Inc. yaffs Dec 28 2011 16:07:04 Installing. msgmni has been set to 875 alg: No test for stdrng (krng) io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) gpio_request ********* gpio=182, label=lcd-backlight mux: Multiple signal paths (3) for gpt8_pwm_evt Generic Backlight Driver Initialized. OMAP DSS rev 2.0 OMAP DISPC rev 3.0 OMAP VENC rev 2 OMAP DSI rev 1.0 WL1271: BT_EN GPIO initialized Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654 console [ttyS0] enabled serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654 serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654 brd: module loaded loop: module loaded omap2-nand driver initializing info = df981000, gpmc_baseaddr=fe000000 NAND device: Manufacturer ID: 0x2c, Chip ID: 0xbc (Micron NAND 512MiB 1,8V 16-bit) Creating 12 MTD partitions on "omap2-nand.0": 0x000000000000-0x000000080000 : "xloader-nand" 0x000000080000-0x000000240000 : "uboot-nand" 0x000000240000-0x000000280000 : "params-nand" 0x000000280000-0x000000780000 : "kernel-nand" 0x000000780000-0x000001000000 : "cramfs-nand" 0x000001000000-0x00000a600000 : "system" 0x00000a600000-0x000010a00000 : "userdata" 0x000010a00000-0x000010b00000 : "misc" 0x000010b00000-0x000011a00000 : "cache" 0x000011a00000-0x000012a00000 : "recover" 0x000012a00000-0x000013a00000 : "reserved" 0x000013a00000-0x000020000000 : "sdcard" OneNAND driver initializing omap2-onenand omap2-onenand: Cannot request GPMC CS omap2-onenand: probe of omap2-onenand failed with error -16 UBI: attaching mtd5 to ubi0 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 126976 bytes UBI: smallest flash I/O unit: 2048 UBI: VID header offset: 2048 (aligned 2048) UBI: data offset: 4096 UBI: attached mtd5 to ubi0 UBI: MTD device name: "system" UBI: MTD device size: 150 MiB UBI: number of good PEBs: 1200 UBI: number of bad PEBs: 0 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 1 UBI: available PEBs: 0 UBI: total number of reserved PEBs: 1200 UBI: number of PEBs reserved for bad PEB handling: 12 UBI: max/mean erase counter: 2/0 UBI: image sequence number: 147480937 PPP generic driver version 2.4.2 UBI: background thread "ubi_bgt0d" started, PID 1044 PPP Deflate Compression module registered PPP BSD Compression module registered PPP MPPE Compression module registered NET: Registered protocol family 24 PPPoL2TP kernel driver, V1.0 smsc911x: Driver version 2008-10-21. smsc911x-mdio: probed eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=ffffffff:01, irq=-1) net eth0: MAC Address: 2a:d4:66:2f:0f:89 usbcore: registered new interface driver cdc_ether usbcore: registered new interface driver dm9601 ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver gpio_request ********* gpio=21, label=USB2 PHY reset ehci-omap ehci-omap.0: OMAP-EHCI Host Controller ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2 ehci-omap ehci-omap.0: irq 77, io mem 0x48064800 ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00 usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb2: Product: OMAP-EHCI Host Controller usb usb2: Manufacturer: Linux 2.6.32 ehci_hcd usb usb2: SerialNumber: ehci-omap.0 hub 2-0:1.0: USB hub found hub 2-0:1.0: 3 ports detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. usbcore: registered new interface driver usbtest android init android_probe pdata: c059bc74 f_adb init android_register_function adb f_mass_storage init android_register_function usb_mass_storage input: TWL4030 Keypad as /devices/platform/i2c_omap.1/i2c-1/1-004a/twl4030_keypad/input/input0 Goodix TouchScreen of GT80X is installing...--------------------------------- gpio_request ********* gpio=111, label=TS_SHUTDOWN input: Goodix TouchScreen of GT80X as /devices/virtual/input/input1 gpio_request ********* gpio=61, label=TS_INT Goodix-TS 1-0055: Guitar Version: GT801_1R07_2011081501_Goodix_Tech Goodix-TS 1-0055: Start Goodix TouchScreen of GT80X in Interrupt mode ads7846 spi4.0: touchscreen, irq 171 ads7846 spi4.0: no device detected, test read result was 0x00000FFF input: twl4030_pwrbutton as /devices/platform/i2c_omap.1/i2c-1/1-0049/twl4030_pwrbutton/input/input2 using rtc device, twl_rtc, for alarms twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0 Warning : battery charge 3.0V-1mA ----------------------------------------------------- i2c /dev entries driver Linux video capture interface: v2.00 ov2659 3-0030: Registered to v4l2 master omap34xxcam!! omap-iommu omap-iommu.0: isp: version 1.1 usbcore: registered new interface driver uvcvideo USB Video Class driver (v0.1.0) OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec Bluetooth: HCI UART driver ver 2.2 Bluetooth: HCI H4 protocol initialized Bluetooth: HCI BCSP protocol initialized Bluetooth: HCILL protocol initialized gpio_request ********* gpio=149, label=mmc_cd usbcore: registered new interface driver usbhid usbhid: USB HID core driver logger: created 64K log 'log_main' logger: created 256K log 'log_events' logger: created 64K log 'log_radio' logger: created 64K log 'log_system' Advanced Linux Sound Architecture Driver Version 1.0.21. usbcore: registered new interface driver snd-usb-audio No device for DAI AD73311 Asahi Kasei AK4104 ALSA SoC Codec Driver No device for DAI AK4535 Cirrus Logic CS4270 ALSA SoC Codec Driver No device for DAI PCM3008 HiFi No device for DAI SSM2602 No device for DAI tlv320aic23 aic3x_i2c_init : i2c_add_driver aic3x_i2c_probe: i2c name=tlv320aic3x, idname=tlv320aic3x aic3x I2C Codec 1-0018: Left-Channel Gain Applied by AGC Algorithm is 0x4 -- bias : 2 aic3x I2C Codec 1-0018: Right-Channel Gain Applied by AGC Algorithm is 0x0 aic3x I2C Codec 1-0018: Left-Channel Gain Applied by AGC Algorithm is 0x4 aic3x I2C Codec 1-0018: Right-Channel Gain Applied by AGC Algorithm is 0x0 No device for DAI tlv320aic3x twl4030_codec_enable = 0 twl4030_codec_enable = 1 twl4030_codec_enable = 0 twl4030_codec_enable = 1 dtmf_cdev add -- Dev id is 124:0 No device for DAI UDA134X No device for DAI wl1271bt No device for DAI WM8510 HiFi No device for DAI WM8728 No device for DAI WM8750 No device for DAI WM8971 No device for DAI WM8990 ADC/DAC Primary No device for DAI omap-mcbsp-dai-0 No device for DAI omap-mcbsp-dai-1 No device for DAI omap-mcbsp-dai-2 No device for DAI omap-mcbsp-dai-3 No device for DAI omap-mcbsp-dai-4 OMAP3 EVM SoC init asoc: tlv320aic3x <-> omap-mcbsp-dai-1 mapping ok am3517evm_aic23_init in -------------- Failed to add route IN1L->LINE1L dapm: tlv320aic3x: configuring unknown pin Line Out asoc: twl4030 <-> omap-mcbsp-dai-2 mapping ok ALSA device list: #0: omap3evm-aic (tlv320aic3x) #1: omap3evm (twl4030) Netfilter messages via NETLINK v0.30. nf_conntrack version 0.5.0 (7001 buckets, 28004 max) ip_tables: (C) 2000-2006 Netfilter Core Team arp_tables: (C) 2002 David S. Miller TCP cubic registered NET: Registered protocol family 17 NET: Registered protocol family 15 Bluetooth: L2CAP ver 2.14 Bluetooth: L2CAP socket layer initialized Bluetooth: SCO (Voice Link) ver 0.6 Bluetooth: SCO socket layer initialized Bluetooth: RFCOMM TTY layer initialized Bluetooth: RFCOMM socket layer initialized Bluetooth: RFCOMM ver 1.11 Bluetooth: BNEP (Ethernet Emulation) ver 1.3 Bluetooth: BNEP filters: protocol multicast Bluetooth: HIDP (Human Interface Emulation) ver 1.2 Power Management for TI OMAP3. Switched to new clocking rate (Crystal/Core/MPU): 26.0/400/1000 MHz--omap2_clk_set_freq(line:662) IVA2 clocking rate: 800 MHz SmartReflex driver initialized VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 twl_rtc twl_rtc: setting system clock to 2000-01-01 00:03:28 UTC (946685008) ov26xx_reset ov2659 3-0030: ov2659 found at 0x30 (OMAP I2C adapter) ov2659 3-0030: chip version 0x2656 detected ov26xx_ifparm p=df825f28 omapdss DPI error: display already enabled omap_vout omap_vout: 'lcd' Display already enabled omapdss DPI error: display already enabled omap_vout omap_vout: 'lcd' Display already enabled omap_vout omap_vout: Buffer Size = 3686400 omap_vout omap_vout: : registered and initialized video device 1 omap_vout omap_vout: Buffer Size = 3686400 omap_vout omap_vout: : registered and initialized video device 2 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 4096KiB [1 disk] into ram disk... done. VFS: Mounted root (ext2 filesystem) readonly on device 1:0. Freeing init memory: 188K Warning: unable to open an initial console. yaffs: dev is 32505864 name is "mtdblock8" yaffs: passed flags "" yaffs: Attempting MTD mount on 31.8, "mtdblock8" yaffs: restored from checkpoint yaffs_read_super: isCheckpointed 1 init: system mode is 'normal' init: open /cache/system-mode/mode.map failed :No such file or directory init: parse init file '/data/normal.rc' init: parse init file '/data/init.rc' init: cannot open '/initlogo.rle' UBIFS: recovery needed UBIFS: recovery completed UBIFS: mounted UBI device 0, volume 0, name "system" UBIFS: file system size: 145387520 bytes (141980 KiB, 138 MiB, 1145 LEBs) UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs) UBIFS: media format: w4/r0 (latest is w4/r0) UBIFS: default compressor: lzo UBIFS: reserved for root: 0 bytes (0 KiB) yaffs: dev is 32505862 name is "mtdblock6" yaffs: passed flags "" yaffs: Attempting MTD mount on 31.6, "mtdblock6" yaffs: restored from checkpoint yaffs_read_super: isCheckpointed 1 CMEMK module: built on Dec 1 2011 at 15:47:55 Reference Linux version 2.6.32 File /mnt/ti/android/rowboat-android/external/ti-dsp/ti-dvsdk_dm3730-evm_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c CMEM Range Overlaps Kernel Physical - allowing overlap CMEM phys_start (0x84700000) overlaps kernel (0x80000000 -> 0x9c400000) allocated heap buffer 0xe1000000 of size 0x1200000 heap fallback enabled - will try heap if pool buffer is not available cmemk initialized DSPLINK Module (1.65.00.02) created on Date: Dec 23 2011 Time: 12:06:25 SDMAK module: built on Dec 1 2011 at 15:47:57 Reference Linux version 2.6.32 File /mnt/ti/android/rowboat-android/external/ti-dsp/ti-dvsdk_dm3730-evm_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/sdma/src/module/sdmak.c TIWLAN: driver init gpio_request ********* gpio=173, label=PWR ENBL for WL1271 hPlatform_initInterrupt - wlanDrvIf_HandleInterrupt=bf0476a4 gpio_request ********* gpio=137, label=WLAN_IRQ input: handset-hook as /devices/platform/handset-hook/input/input3 gpio_request ********* gpio=171, label=fxo-oh gpio_request ********* gpio=179, label=fxo-cid gpio_request ********* gpio=180, label=fxo-ring fxo-drv - 0 : fxo_sethook ONHOOK' fxo-drvcdev add -- Dev id is 123:0 gpio_request ********* gpio=210, label=leda gpio_request ********* gpio=211, label=ledb yaffs: dev is 32505867 name is "mtdblock11" yaffs: passed flags "uid=1000,gid=1015,fmask=0002,dmask=0002" yaffs: Attempting MTD mount on 31.11, "mtdblock11" yaffs: restored from checkpoint yaffs_read_super: isCheckpointed 1 init: cannot find '/system/bin/normal', disabling 'normal' init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery' ov26xx_reset ov2659 3-0030: ov2659 found at 0x30 (OMAP I2C adapter) ov2659 3-0030: chip version 0x2656 detected Warning touch_atime dentry 1414, (null) (null)------------------ Unable to handle kernel NULL pointer dereference at virtual address 0000002c pgd = c3310000 [0000002c] *pgd=9f17c031, *pte=00000000, *ppte=00000000 Internal error: Oops: 17 [#1] last sysfs file: /sys/devices/virtual/mtd/mtd11/mtdblock11/uevent Modules linked in: omaplfb pvrsrvkm led fxo_drv handset_hook tiwlan_drv sdmak lpm_omap3530 dsplinkk cmemk CPU: 0 Not tainted (2.6.32 #903) PC is at touch_atime+0x30/0x1d0 LR is at touch_atime+0x2c/0x1d0 pc : [<c00c81f8>] lr : [<c00c81f4>] psr: 60000113 sp : c3331c68 ip : 00000002 fp : 00000000 r10: 000004ef r9 : 00000000 r8 : 0054c4ef r7 : 00000000 r6 : c33870c0 r5 : 00000000 r4 : 00000000 r3 : 00000000 r2 : c3331c5c r1 : c04e0c9e r0 : c04e0cdb Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 10c5387d Table: 83310019 DAC: 00000017 PC: 0xc00c8178: 8178 e0922000 e0a33001 e1c423f8 e3160002 e1a00004 1584805c e3a01001 15847058 8198 e3160001 15848054 15847050 eb0022b0 e5950008 e28dd008 e8bd41f0 ea000a90 81b8 e3866002 eaffffdd e28dd008 e8bd81f0 e3510000 1351000c e92d40f7 e1a05001 81d8 e1a04000 1a000007 e3001586 e59f0194 e1a02005 e1a03004 eb0c92ee e59f0188 81f8 e594102c eb0c92eb e59f0180 e2851058 eb03e2bb e595600c e3500000 13a02000 8218 1a00000a ea000003 e59f0164 e2871058 eb0c92e0 e1a05007 e5957018 e3570000 8238 0a000001 e1550007 1afffff6 e3a02001 e59f3140 e583202c e5963138 e3130002 8258 1a000046 e596109c e3003401 e5912034 e0023003 e3530000 1a000040 e3120b02 LR: 0xc00c8174: 8174 e3a01000 e0922000 e0a33001 e1c423f8 e3160002 e1a00004 1584805c e3a01001 8194 15847058 e3160001 15848054 15847050 eb0022b0 e5950008 e28dd008 e8bd41f0 81b4 ea000a90 e3866002 eaffffdd e28dd008 e8bd81f0 e3510000 1351000c e92d40f7 81d4 e1a05001 e1a04000 1a000007 e3001586 e59f0194 e1a02005 e1a03004 eb0c92ee 81f4 e59f0188 e594102c eb0c92eb e59f0180 e2851058 eb03e2bb e595600c e3500000 8214 13a02000 1a00000a ea000003 e59f0164 e2871058 eb0c92e0 e1a05007 e5957018 8234 e3570000 0a000001 e1550007 1afffff6 e3a02001 e59f3140 e583202c e5963138 8254 e3130002 1a000046 e596109c e3003401 e5912034 e0023003 e3530000 1a000040 SP: 0xc3331be8: 1be8 c3308000 c016e40c 00000001 00000000 0059960f 00000000 00000145 2000054b 1c08 c05e323c ffffffff c3331c54 c33870c0 00000000 c00379ec c04e0cdb c04e0c9e 1c28 c3331c5c 00000000 00000000 00000000 c33870c0 00000000 0054c4ef 00000000 1c48 000004ef 00000000 00000002 c3331c68 c00c81f4 c00c81f8 60000113 ffffffff 1c68 00000000 00000000 0054c4ef 0054c000 0054c000 c33870c0 00000000 c00936ec 1c88 00000002 00000001 00000008 c05e323c 00000000 00000000 00000000 00001000 1ca8 c3331db0 00000000 0054c000 00000000 0054c000 00000000 00000041 c3387100 1cc8 df654720 c3331d70 0000054d 00000001 c05e325c 000bc940 00000000 e34d5940 R0: 0xc04e0c5b: 0c58 6e693e37 735f7469 69636570 695f6c61 65646f6e 6f62203a 20737567 6f6d5f69 0c78 28206564 20296f25 20726f66 646f6e69 73252065 756c253a 6e49000a 2d65646f 0c98 68636163 363c0065 7261573e 676e696e 756f7420 615f6863 656d6974 6e656420 0cb8 20797274 202c6425 25207025 2d2d2d70 2d2d2d2d 2d2d2d2d 2d2d2d2d 0a2d2d2d 0cd8 3c000a0a 6e6d3e36 65642074 65636976 6d616e20 73252065 6d72000a 00646f6d 0cf8 703e363c 6e657261 203a2074 000a7325 6f6e6926 3e2d6564 746f6e69 5f796669 0d18 6574756d 69260078 65646f6e 5f693e2d 6574756d 69260078 65646f6e 5f693e2d 0d38 6f6c6c61 65735f63 7366006d 7474612f 00632e72 613e343c 636f6c6c 3a64665f 0d58 6f6c7320 64252074 746f6e20 4c554e20 000a214c 25097325 66000a73 69662f73 R1: 0xc04e0c1e: 0c1c 6e755b20 6e756f6d 666f2074 20732520 0a5d7325 3e343c00 3a534656 766f6d20 0c3c 20676e69 6167656e 65766974 61636420 20656863 72746e65 3c000a79 6e693e37 0c5c 735f7469 69636570 695f6c61 65646f6e 6f62203a 20737567 6f6d5f69 28206564 0c7c 20296f25 20726f66 646f6e69 73252065 756c253a 6e49000a 2d65646f 68636163 0c9c 363c0065 7261573e 676e696e 756f7420 615f6863 656d6974 6e656420 20797274 0cbc 202c6425 25207025 2d2d2d70 2d2d2d2d 2d2d2d2d 2d2d2d2d 0a2d2d2d 3c000a0a 0cdc 6e6d3e36 65642074 65636976 6d616e20 73252065 6d72000a 00646f6d 703e363c 0cfc 6e657261 203a2074 000a7325 6f6e6926 3e2d6564 746f6e69 5f796669 6574756d 0d1c 69260078 65646f6e 5f693e2d 6574756d 69260078 65646f6e 5f693e2d 6f6c6c61 R2: 0xc3331bdc: 1bdc c09a2120 60000113 00000036 c3308000 c016e40c 00000001 00000000 0059960f 1bfc 00000000 00000145 2000054b c05e323c ffffffff c3331c54 c33870c0 00000000 1c1c c00379ec c04e0cdb c04e0c9e c3331c5c 00000000 00000000 00000000 c33870c0 1c3c 00000000 0054c4ef 00000000 000004ef 00000000 00000002 c3331c68 c00c81f4 1c5c c00c81f8 60000113 ffffffff 00000000 00000000 0054c4ef 0054c000 0054c000 1c7c c33870c0 00000000 c00936ec 00000002 00000001 00000008 c05e323c 00000000 1c9c 00000000 00000000 00001000 c3331db0 00000000 0054c000 00000000 0054c000 1cbc 00000000 00000041 c3387100 df654720 c3331d70 0000054d 00000001 c05e325c R6: 0xc3387040: 7040 ffffffff 0000000b 0000000c 0000000d 0000000e 0000000f 00000010 00000011 7060 00000012 00000013 00000014 00000015 00000019 00000017 00000018 00000019 7080 0000001a 00000009 0000001c 0000001d ffffffff 00000000 00000000 00000000 70a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 70c0 df851190 c00b8258 00000000 00000000 c03fe9a4 00000000 00020000 0000001d 70e0 00000237 00000000 00000000 00000000 00000000 00000000 00000000 df8322c0 7100 00000000 00000000 00000000 00000000 00000000 00000000 0054c4ef 00000000 7120 00000000 00000000 00000000 c338712c c338712c df63f2d0 00000000 00000000 Process mediaserver (pid: 2141, stack limit = 0xc33302e8) Stack: (0xc3331c68 to 0xc3332000) 1c60: 00000000 00000000 0054c4ef 0054c000 0054c000 c33870c0 1c80: 00000000 c00936ec 00000002 00000001 00000008 c05e323c 00000000 00000000 1ca0: 00000000 00001000 c3331db0 00000000 0054c000 00000000 0054c000 00000000 1cc0: 00000041 c3387100 df654720 c3331d70 0000054d 00000001 c05e325c 000bc940 1ce0: 00000000 e34d5940 00000000 000bc940 00000018 c3331d20 c33870e0 c33870c0 1d00: fffffdee c3331db0 00008000 0048fbaf 00000000 c00b71e4 0048fbaf 00000000 1d20: 00000000 c009682c 00000000 00000001 ffffffff c33870c0 00000000 00000000 1d40: 00000000 00000000 df982ac0 c00ad20c 00000000 00000000 000bdfff df982ac0 1d60: c0076800 c3331d64 c3331d64 e34d5fff 0054c4ef 00000000 a0000113 c3331dbc 1d80: 000000bd 000000d2 000bc940 000002cf 00008000 df140c00 00000000 c00ad834 1da0: c3331dbc c00ad890 db58e140 c00ad998 e3419000 000bc940 e32f2000 bf000000 1dc0: e32ec010 00000000 e32ef000 00000000 0054c4ef bf01bf60 00000001 4c49464b 1de0: e32ec010 bf01a230 e32ec000 0048fbaf e32ec010 bf0190bc bf021d70 e3419000 1e00: e3419000 00010000 bee91b4c 00000000 bf0238bc e32ec000 80924900 c3331e78 1e20: 00008000 00000000 bee91b4c bf019fe0 00000000 e32ef000 00000000 e3095000 1e40: bf0238ac 00000008 bf0238b8 00000001 00000002 bf01db2c 100ffe4c e3102800 1e60: 85944880 e3102910 00000000 00000000 000008cc 100ffe4c 00000002 bf021d70 1e80: bf021d70 bf021d44 c3330000 100ffe48 c018e015 c018e015 0000000a c0038028 1ea0: c3330000 00000000 0000bac8 bf01eca8 c3311000 00000458 00000116 00000000 1ec0: 00000000 40116888 df982ac0 c3331fb0 c33241d8 c33241fc 40119000 00008000 1ee0: 00000000 80924900 00000001 bee91b4c 00070000 df9ba840 40119000 c320e8c0 1f00: 00000000 c018e015 0000000a c0038028 00000000 c00c30c8 100ffe48 c320e8c0 1f20: c018e015 c00c3790 c320e8c0 00085904 00000000 00000000 00071000 c320e8c0 1f40: 00000000 df161968 c3324230 4018a000 00000001 c332424c df982ac0 c320e8c0 1f60: c3330000 40119000 00000003 c320e8c0 100ffe48 c018e015 0000000a c0038028 1f80: c3330000 c00c3830 0000000a 00000001 100ffe48 100ffe48 0000c050 00000004 1fa0: 00000036 c0037e80 100ffe48 0000c050 0000000a c018e015 100ffe48 100ffdf4 1fc0: 100ffe48 0000c050 00000004 00000036 00000170 80917641 00000002 0000bac8 1fe0: 809300d4 100ffdd8 afd22edd afd0dcdc 00000010 0000000a 53525650 505f5652 [<c00c81f8>] (touch_atime+0x30/0x1d0) from [<c00936ec>] (generic_file_aio_read+0x5d8/0x654) [<c00936ec>] (generic_file_aio_read+0x5d8/0x654) from [<c00b71e4>] (do_sync_read+0xb8/0x104) [<c00b71e4>] (do_sync_read+0xb8/0x104) from [<bf01bf60>] (KFILEDEF_Read +0x88/0xe8 [dsplinkk]) [<bf01bf60>] (KFILEDEF_Read+0x88/0xe8 [dsplinkk]) from [<bf01a230>] (KFILE_Read+0x4c/0x68 [dsplinkk]) [<bf01a230>] (KFILE_Read+0x4c/0x68 [dsplinkk]) from [<bf0190bc>] (COFF_init+0x30c/0x52c [dsplinkk]) [<bf0190bc>] (COFF_init+0x30c/0x52c [dsplinkk]) from [<bf019fe0>] (COFFFILE_init+0x94/0xc4 [dsplinkk]) [<bf019fe0>] (COFFFILE_init+0x94/0xc4 [dsplinkk]) from [<bf01db2c>] (PMGR_PROC_load+0x170/0x264 [dsplinkk]) [<bf01db2c>] (PMGR_PROC_load+0x170/0x264 [dsplinkk]) from [<bf01eca8>] (DRV_Ioctl+0x330/0x7b8 [dsplinkk]) [<bf01eca8>] (DRV_Ioctl+0x330/0x7b8 [dsplinkk]) from [<c00c30c8>] (vfs_ioctl+0x5c/0x6c) [<c00c30c8>] (vfs_ioctl+0x5c/0x6c) from [<c00c3790>] (do_vfs_ioctl +0x4e4/0x550) [<c00c3790>] (do_vfs_ioctl+0x4e4/0x550) from [<c00c3830>] (sys_ioctl +0x34/0x54) [<c00c3830>] (sys_ioctl+0x34/0x54) from [<c0037e80>] (ret_fast_syscall +0x0/0x2c) Code: e1a02005 e1a03004 eb0c92ee e59f0188 (e594102c) ---[ end trace ec37e25889a61aea ]--- Kernel panic - not syncing: Fatal exception [<c003d97c>] (unwind_backtrace+0x0/0xd8) from [<c03ecce8>] (panic +0x40/0x108) [<c03ecce8>] (panic+0x40/0x108) from [<c003be64>] (die+0x250/0x28c) [<c003be64>] (die+0x250/0x28c) from [<c003e8a4>] (__do_kernel_fault +0x64/0x74) [<c003e8a4>] (__do_kernel_fault+0x64/0x74) from [<c003ea64>] (do_page_fault+0x1b0/0x1c4) [<c003ea64>] (do_page_fault+0x1b0/0x1c4) from [<c0037278>] (do_DataAbort +0x34/0x94) [<c0037278>] (do_DataAbort+0x34/0x94) from [<c00379ec>] (__dabt_svc +0x4c/0x60) Exception stack(0xc3331c20 to 0xc3331c68) 1c20: c04e0cdb c04e0c9e c3331c5c 00000000 00000000 00000000 c33870c0 00000000 1c40: 0054c4ef 00000000 000004ef 00000000 00000002 c3331c68 c00c81f4 c00c81f8 1c60: 60000113 ffffffff [<c00379ec>] (__dabt_svc+0x4c/0x60) from [<c00c81f8>] (touch_atime +0x30/0x1d0) [<c00c81f8>] (touch_atime+0x30/0x1d0) from [<c00936ec>] (generic_file_aio_read+0x5d8/0x654) [<c00936ec>] (generic_file_aio_read+0x5d8/0x654) from [<c00b71e4>] (do_sync_read+0xb8/0x104) [<c00b71e4>] (do_sync_read+0xb8/0x104) from [<bf01bf60>] (KFILEDEF_Read +0x88/0xe8 [dsplinkk]) [<bf01bf60>] (KFILEDEF_Read+0x88/0xe8 [dsplinkk]) from [<bf01a230>] (KFILE_Read+0x4c/0x68 [dsplinkk]) [<bf01a230>] (KFILE_Read+0x4c/0x68 [dsplinkk]) from [<bf0190bc>] (COFF_init+0x30c/0x52c [dsplinkk]) [<bf0190bc>] (COFF_init+0x30c/0x52c [dsplinkk]) from [<bf019fe0>] (COFFFILE_init+0x94/0xc4 [dsplinkk]) [<bf019fe0>] (COFFFILE_init+0x94/0xc4 [dsplinkk]) from [<bf01db2c>] (PMGR_PROC_load+0x170/0x264 [dsplinkk]) [<bf01db2c>] (PMGR_PROC_load+0x170/0x264 [dsplinkk]) from [<bf01eca8>] (DRV_Ioctl+0x330/0x7b8 [dsplinkk]) [<bf01eca8>] (DRV_Ioctl+0x330/0x7b8 [dsplinkk]) from [<c00c30c8>] (vfs_ioctl+0x5c/0x6c) [<c00c30c8>] (vfs_ioctl+0x5c/0x6c) from [<c00c3790>] (do_vfs_ioctl +0x4e4/0x550) [<c00c3790>] (do_vfs_ioctl+0x4e4/0x550) from [<c00c3830>] (sys_ioctl +0x34/0x54) [<c00c3830>] (sys_ioctl+0x34/0x54) from [<c0037e80>] (ret_fast_syscall +0x0/0x2c)
Please help to give some suggestions.
Vivian Sun
