hi:
1、MCU SDK version :11.0.0.06
2、Start using the ospi quick-start function,Use this scenario to package:default_sbl_ospi_linux_hs_fs.cfg
3、OSPI Partition:
&ospi0 {
	pinctrl-names = "default";
	pinctrl-0 = <&ospi0_pins_default>;
	status = "okay";
	flash@0 {
		compatible = "jedec,spi-nor";
		reg = <0x0>;
		spi-tx-bus-width = <8>;
		spi-rx-bus-width = <8>;
		spi-max-frequency = <25000000>;
		cdns,tshsl-ns = <60>;
		cdns,tsd2d-ns = <60>;
		cdns,tchsh-ns = <60>;
		cdns,tslch-ns = <60>;
		cdns,read-delay = <4>;
		cdns,phy-mode;
		bootph-all;
		partitions {
			compatible = "fixed-partitions";
			#address-cells = <1>;
			#size-cells = <1>;
			partition@0 {
				label = "ospi.tiboot3";
				reg = <0x00 0x80000>;
			partition@80000 {
				label = "ospi.app0";
				reg = <0x80000 0x1600000>;
			partition@3fc0000 {
				bootph-all;
				label = "ospi.phypattern";
				reg = <0x3fc0000 0x40000>;
4、LOG:
root@j722s-evm:~# NOTICE:  BL31: v2.12.0(release):11.00.09-dirty
NOTICE:  BL31: Built : 12:35:58, Mar 24 2025
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.12.17-ti (cd7475193@216975fffc66) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #9 SMP PREEMPT Thu Aug  7 02:57:16 UTC 2025
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Texas Instruments J722S EVM
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: legacy bootconsole [ns16550a0] enabled
set eth config Start
work partition is /dev/mmcblk0p2
set eth config OK
mount: /log_data: wrong fs type, bad option, bad superblock on /dev/mmcblk0p10, missing codepage or helper program, or other error.
       dmesg(1) may have more information after failed mount system call.
mount: /data: special device /dev/mmcblk0p12 does not exist.
mount_system_A
Run App Ok!!!
Welcome to Arago 2025.01!
[  OK  ] Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/serial-getty.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
         Expecting device /dev/ttyS2...
[  OK  ] Reached target Path Units.
[  OK  ] Reached target Remote File Systems.
[  OK  ] Reached target Slice Units.
[  OK  ] Reached target Swaps.
[  OK  ] Listening on RPCbind Server Activation Socket.
[  OK  ] Reached target RPC Port Mapper.
[  OK  ] Listening on Process Core Dump Socket.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Listening on User Database Manager Socket.
         Mounting Huge Pages File System...
         Mounting POSIX Message Queue File System...
         Mounting Kernel Debug File System...
         Mounting Temporary Directory /tmp...
         Starting Create List of Static Device Nodes...
         Starting Load Kernel Module configfs...
         Starting Load Kernel Module drm...
         Starting Load Kernel Module fuse...
         Starting Start psplash boot splash screen...
         Starting RPC Bind...
         Starting Journal Service...
         Starting Load Kernel Modules...
         Starting Remount Root and Kernel File Systems...
         Starting Coldplug All udev Devices...
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Started RPC Bind.
[  OK  ] Mounted Temporary Directory /tmp.
[  OK  ] Finished Create List of Static Device Nodes.
[  OK  ] Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Start psplas…temd progress communication helper.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
         Starting Create Static Device Nodes in /dev gracefully...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Finished Load Kernel Modules.
[  OK  ] Finished Remount Root and Kernel File Systems.
[  OK  ] Mounted Kernel Configuration File System.
         Starting Apply Kernel Variables...
[  OK  ] Finished Create Static Device Nodes in /dev gracefully.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Started Journal Service.
         Starting Flush Journal to Persistent Storage...
[  OK  ] Finished Apply Kernel Variables.
insmod libcomposite.ko
[  OK  ] Finished Create Static Device Nodes in /dev.
insmod: ERROR: could not insert module /system/driver/libcomposite.ko: File exists
[  OK  ] Reached target Preparation for Local File Systems.
mkdir: cannot create directory '/config/usb_gadget/g1': File exists
mkdir: cannot create directory '/config/usb_gadget/g1/strings/0x409': File exists
         Starting Rule-based Manager for Device Events and Files...
mkdir: cannot create directory '/config/usb_gadget/g1/configs/b.1': File exists
[  OK  ] Finished Flush Journal to Persistent Storage.
mkdir: cannot create directory '/config/usb_gadget/g1/configs/b.1/strings/0x409': File exists
mkdir: cannot create directory '/config/usb_gadget/g1/functions/ffs.adb': File exists
ln: failed to create symbolic link '/config/usb_gadget/g1/configs/b.1/ffs.adb/ffs.adb': Operation not permitted
mkdir: cannot create directory '/dev/usb-ffs': File exists
mkdir: cannot create directory '/dev/usb-ffs/adb': File exists
mount: /dev/usb-ffs/adb: adb already mounted on /dev/usb-ffs/adb.
sleep for run adbd
adbd done
adbd E 03-05 15:13:30   230   230 adbd_auth.cpp:183] Failed to get adbd socket: No such file or directory
adbd E 03-05 15:13:30   230   230 adbd_auth.cpp:192] Failed to get adbd socket: No such file or directory
adbd I 03-05 15:13:30   230   232 usb.cpp:250] initializing functionfs
adbd I 03-05 15:13:30   230   232 usb.cpp:271] opening control endpoint /dev/usb-ffs/adb/ep0
libc: Using old property service protocol ("ro.property_service.version" is not set)
adbd I 03-05 15:13:30   230   232 usb.cpp:356] functionfs successfully initialized
adbd I 03-05 15:13:30   230   232 usb.cpp:362] registering usb transport
         Starting User Database Manager...
[  OK  ] Started User Database Manager.
[  OK  ] Started Rule-based Manager for Device Events and Files.
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Found device /dev/ttyS2.
         Mounting /var/volatile...
[  OK  ] Mounted /var/volatile.
         Starting Load/Save OS Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create System Files and Directories...
[  OK  ] Finished Load/Save OS Random Seed.
[  OK  ] Finished Create System Files and Directories.
[FAILED] Failed to start Network Name Resolution.
See 'systemctl status systemd-resolved.service' for details.
[  OK  ] Reached target Host and Network Name Lookups.
[FAILED] Failed to start Network Time Synchronization.
See 'systemctl status systemd-timesyncd.service' for details.
[  OK  ] Reached target System Time Set.
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timer Units.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on dropbear.socket.
[  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
[  OK  ] Reached target Socket Units.
[FAILED] Failed to start D-Bus System Message Bus.
See 'systemctl status dbus-broker.service' for details.
[  OK  ] Reached target Basic System.
[  OK  ] Started Job spooling tools.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Enable and configure wl18xx bluetooth stack...
         Starting containerd container runtime...
[  OK  ] Started Periodic Command Scheduler.
         Starting Print notice about GPLv3 packages...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
[  OK  ] Started irqbalance daemon.
         Starting Reboot and dump vmcore via kexec...
grep: /var/lib/opkg/info/*.control: No such file or directory
[FAILED] Failed to start LLDP daemon.
See 'systemctl status lldpd.service' for details.
[  OK  ] Started Multiple Spanning Tree Protocol Daemon.
[  OK  ] Started Netperf Benchmark Server.
         Starting Telephony service...
         Starting Expand the rootfs partiti…to full size of the boot device....
         Starting Simple Network Management Protocol (SNMP) Daemon....
[  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[FAILED] Failed to start User Login Management.
See 'systemctl status systemd-logind.service' for details.
         Starting Permit User Sessions...
         Starting Telnet Server...
[FAILED] Failed to start Avahi mDNS/DNS-SD Stack.
See 'systemctl status avahi-daemon.service' for details.
[FAILED] Failed to start Enable and configure wl18xx bluetooth stack.
See 'systemctl status bt-enable.service' for details.
[  OK  ] Finished Print notice about GPLv3 packages.
[FAILED] Failed to start IPv6 Packet Filtering Framework.
See 'systemctl status ip6tables.service' for details.
[FAILED] Failed to start IPv4 Packet Filtering Framework.
See 'systemctl status iptables.service' for details.
[  OK  ] Finished Reboot and dump vmcore via kexec.
[FAILED] Failed to start Telephony service.
See 'systemctl status ofono.service' for details.
[FAILED] Failed to start Simple Network Management Protocol (SNMP) Daemon..
See 'systemctl status snmpd.service' for details.
[  OK  ] Finished Permit User Sessions.
[  OK  ] Finished Telnet Server.
[FAILED] Failed to start containerd container runtime.
See 'systemctl status containerd.service' for details.
[  OK  ] Reached target Preparation for Network.
[  OK  ] Started emptty display manager.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
[  OK  ] Finished Expand the rootfs partition to full size of the boot device..
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Record Runlevel Change in UTMP...
[  OK  ] Finished Record Runlevel Change in UTMP.
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project j722s-evm ttyS2
Arago 2025.01 j722s-evm ttyS2
j722s-evm login:
j722s-evm login:
j722s-evm login:
j722s-evm login: root
root@j722s-evm:~# dmesg
[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a0000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a0100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a1000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a1100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a2000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a3ffffff (31744 KiB) nomap non-reusable vision-apps-r5f-memory@a2100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@a5000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a5000000..0x00000000a6ffffff (32768 KiB) nomap non-reusable vision-apps-rtos-ipc-memory-region@a5000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 96 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a7000000..0x00000000acffffff (98304 KiB) nomap non-reusable vision-apps-dma-memory@a7000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ad000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@ad000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000ad000000..0x00000000ad0fffff (1024 KiB) nomap non-reusable vision-apps-c71-dma-memory@ad000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ad100000, size 63 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@ad100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000ad100000..0x00000000b0ffffff (64512 KiB) nomap non-reusable vision-apps-c71_0-memory@ad100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b1000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000b1000000..0x00000000b10fffff (1024 KiB) nomap non-reusable vision-apps-c71_1-dma-memory@b1000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b1100000, size 63 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b1100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000b1100000..0x00000000b4ffffff (64512 KiB) nomap non-reusable vision-apps-c71_1-memory@b1100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b5000000, size 40 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@b5000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000b5000000..0x00000000b77fffff (40960 KiB) nomap non-reusable vision-apps-core-heap-memory-lo@b5000000
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node c7x-ddr-heaps-hi@880000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000880000000..0x000000089fffffff (524288 KiB) nomap non-reusable c7x-ddr-heaps-hi@880000000
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[    0.000000] OF: reserved mem: 0x0000000900000000..0x000000091fffffff (524288 KiB) map non-reusable vision_apps_shared-memories
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000980000000, size 896 MiB
[    0.000000] OF: reserved mem: initialized node linux-cma-buffers@980000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000980000000..0x00000009b7ffffff (917504 KiB) map reusable linux-cma-buffers@980000000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000009ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000a3ffffff]
[    0.000000]   node   0: [mem 0x00000000a4000000-0x00000000a4ffffff]
[    0.000000]   node   0: [mem 0x00000000a5000000-0x00000000b77fffff]
[    0.000000]   node   0: [mem 0x00000000b7800000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x000000089fffffff]
[    0.000000]   node   0: [mem 0x00000008a0000000-0x00000009ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.5
[    0.000000] percpu: Embedded 22 pages/cpu s51672 r8192 d30248 u90112
[    0.000000] pcpu-alloc: s51672 r8192 d30248 u90112 alloc=22*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait  init=/home/root/init-byd.sh loglevel=3
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2097152
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a0800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008a0050000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a0060000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.000516] Console: colour dummy device 80x25
[    0.000578] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.000592] pid_max: default: 32768 minimum: 301
[    0.000688] LSM: initializing lsm=capability,selinux
[    0.000750] SELinux:  Initializing.
[    0.001240] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.001274] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.024009] rcu: Hierarchical SRCU implementation.
[    0.024027] rcu:     Max phase no-delay instances is 1000.
[    0.024234] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.024764] EFI services will not be available.
[    0.028037] smp: Bringing up secondary CPUs ...
[    0.036370] Detected VIPT I-cache on CPU1
[    0.036452] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.036471] GICv3: CPU1: using allocated LPI pending table @0x00000008a0070000
[    0.036518] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.040343] Detected VIPT I-cache on CPU2
[    0.040401] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.040417] GICv3: CPU2: using allocated LPI pending table @0x00000008a0080000
[    0.040449] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.048353] Detected VIPT I-cache on CPU3
[    0.048413] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.048426] GICv3: CPU3: using allocated LPI pending table @0x00000008a0090000
[    0.048460] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.048588] smp: Brought up 1 node, 4 CPUs
[    0.048608] SMP: Total of 4 processors activated.
[    0.048614] CPU: All CPU(s) started at EL2
[    0.048618] CPU features: detected: 32-bit EL0 Support
[    0.048625] CPU features: detected: CRC32 instructions
[    0.048666] alternatives: applying system-wide alternatives
[    0.049272] Memory: 5797244K/8388608K available (12928K kernel code, 1254K rwdata, 4644K rodata, 2752K init, 639K bss, 1664812K reserved, 917504K cma-reserved)
[    0.050345] devtmpfs: initialized
[    0.062523] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.062556] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.086368] 27152 pages in range for non-PLT usage
[    0.086394] 518672 pages in range for PLT usage
[    0.086709] pinctrl core: initialized pinctrl subsystem
[    0.087159] DMI not present or invalid.
[    0.089416] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.090672] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.090820] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.090944] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.091412] audit: initializing netlink subsys (disabled)
[    0.091692] audit: type=2000 audit(0.088:1): state=initialized audit_enabled=0 res=1
[    0.092121] thermal_sys: Registered thermal governor 'step_wise'
[    0.092127] thermal_sys: Registered thermal governor 'power_allocator'
[    0.092173] cpuidle: using governor menu
[    0.092401] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.092510] ASID allocator initialised with 65536 entries
[    0.099656] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
[    0.099800] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30220000
[    0.099966] /bus@f0000/dss@30220000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.106208] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30220000
[    0.109026] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30220000
[    0.109107] /bus@f0000/dss@30220000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.111500] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
[    0.111586] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.112394] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.112410] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.112417] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.112422] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.112429] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.112433] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.112440] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.112444] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.114280] k3-chipinfo 43000014.chipid: Family:J722S rev:SR1.0 JTAGID[0x0bba002f] Detected
[    0.116637] iommu: Default domain type: Translated
[    0.116658] iommu: DMA domain TLB invalidation policy: strict mode
[    0.117142] SCSI subsystem initialized
[    0.117350] libata version 3.00 loaded.
[    0.117518] usbcore: registered new interface driver usbfs
[    0.117547] usbcore: registered new interface driver hub
[    0.117575] usbcore: registered new device driver usb
[    0.118161] pps_core: LinuxPPS API ver. 1 registered
[    0.118168] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.118183] PTP clock support registered
[    0.118217] EDAC MC: Ver: 3.0.0
[    0.118554] scmi_core: SCMI protocol bus registered
[    0.118839] FPGA manager framework
[    0.118928] Advanced Linux Sound Architecture Driver Initialized.
[    0.119840] vgaarb: loaded
[    0.120190] clocksource: Switched to clocksource arch_sys_counter
[    0.120450] VFS: Disk quotas dquot_6.6.0
[    0.120472] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.127555] Carveout Heap: Exported 512 MiB at 0x0000000900000000
[    0.127663] NET: Registered PF_INET protocol family
[    0.127950] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.133256] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.133337] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.133357] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.133810] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.135603] TCP: Hash tables configured (established 65536 bind 65536)
[    0.135776] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.135936] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.136330] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.136816] RPC: Registered named UNIX socket transport module.
[    0.136829] RPC: Registered udp transport module.
[    0.136833] RPC: Registered tcp transport module.
[    0.136838] RPC: Registered tcp-with-tls transport module.
[    0.136842] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.136853] NET: Registered PF_XDP protocol family
[    0.136875] PCI: CLS 0 bytes, default 64
[    0.138311] Initialise system trusted keyrings
[    0.138560] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    0.138867] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.139145] NFS: Registering the id_resolver key type
[    0.139175] Key type id_resolver registered
[    0.139181] Key type id_legacy registered
[    0.139202] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.139210] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.191978] Key type asymmetric registered
[    0.192000] Asymmetric key parser 'x509' registered
[    0.192077] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.192287] io scheduler mq-deadline registered
[    0.192296] io scheduler kyber registered
[    0.192330] io scheduler bfq registered
[    0.195646] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.196626] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    0.198457] ledtrig-cpu: registered to indicate activity on CPUs
[    0.204684] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.213763] loop: module loaded
[    0.214872] megasas: 07.727.03.00-rc1
[    0.218796] tun: Universal TUN/TAP device driver, 1.6
[    0.219883] VFIO - User Level meta-driver version: 0.3
[    0.221162] usbcore: registered new interface driver usb-storage
[    0.221828] i2c_dev: i2c /dev entries driver
[    0.222957] sdhci: Secure Digital Host Controller Interface driver
[    0.222965] sdhci: Copyright(c) Pierre Ossman
[    0.223188] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.223875] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.224559] usbcore: registered new interface driver usbhid
[    0.224567] usbhid: USB HID core driver
[    0.225819] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
[    0.226559] optee: probing for conduit method.
[    0.226590] optee: revision 4.5 (ef1ebdc23034a804)
[    0.226974] optee: dynamic shared memory is enabled
[    0.227666] optee: initialized driver
[    0.227782] random: crng init done
[    0.229846] Initializing XFRM netlink socket
[    0.229888] NET: Registered PF_PACKET protocol family
[    0.229961] Key type dns_resolver registered
[    0.238339] registered taskstats version 1
[    0.238556] Loading compiled-in X.509 certificates
[    0.250442] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)')
[    0.305411] omap_i2c 4900000.i2c: bus 0 rev0.12 at 400 kHz
[    0.306937] omap_i2c 2b200000.i2c: bus 1 rev0.12 at 400 kHz
[    0.308622] pca953x 2-0023: supply vcc not found, using dummy regulator
[    0.308743] pca953x 2-0023: using AI
[    0.326432] omap_i2c 20000000.i2c: bus 2 rev0.12 at 400 kHz
[    0.327819] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.327887] /bus@f0000/dss@30220000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.327954] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
[    0.328008] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30220000
[    0.328237] omap_i2c 20010000.i2c: bus 3 rev0.12 at 100 kHz
[    0.329621] pca954x 4-0070: supply vdd not found, using dummy regulator
[    0.344501] i2c i2c-4: Added multiplexed i2c bus 5
[    0.344672] i2c i2c-4: Added multiplexed i2c bus 6
[    0.344684] pca954x 4-0070: registered 2 multiplexed busses for I2C switch pca9543
[    0.344913] pca954x 4-0071: supply vdd not found, using dummy regulator
[    0.345303] i2c i2c-4: Added multiplexed i2c bus 7
[    0.345456] i2c i2c-4: Added multiplexed i2c bus 8
[    0.345466] pca954x 4-0071: registered 2 multiplexed busses for I2C switch pca9543
[    0.345513] omap_i2c 20020000.i2c: bus 4 rev0.12 at 400 kHz
[    0.345740] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[    0.345878] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    0.346111] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    0.346379] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
[    0.352147] ti-udma 485c0100.dma-controller: Number of rings: 82
[    0.354511] ti-udma 485c0100.dma-controller: Channels: 44 (bchan: 16, tchan: 12, rchan: 16)
[    0.356927] ti-udma 485c0000.dma-controller: Number of rings: 150
[    0.361561] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    0.363525] ti-udma 4e230000.dma-controller: Number of rings: 40
[    0.365063] ti-udma 4e230000.dma-controller: Channels: 20 (bchan: 0, tchan: 8, rchan: 12)
[    0.367017] printk: legacy console [ttyS2] disabled
[    0.367337] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 271, base_baud = 3000000) is a 8250
[    0.367435] printk: legacy console [ttyS2] enabled
[    0.367442] printk: legacy bootconsole [ns16550a0] disabled
[    0.370397] [drivers/mtd/spi-nor/core.c:3732:spi_nor_probe()] Debugging information here
[    0.370415] [drivers/mtd/spi-nor/core.c:3741:spi_nor_probe()] Debugging information here
[    0.370424] [drivers/mtd/spi-nor/core.c:3749:spi_nor_probe()] Debugging information here
[    0.370429] [drivers/mtd/spi-nor/core.c:3751:spi_nor_probe()] Debugging information here
[    0.370435] [drivers/mtd/spi-nor/core.c:3770:spi_nor_probe()] Debugging information here
[    0.371339] spi-nor spi0.0: probe with driver spi-nor failed with error -22
[    0.371398] spi spi0.0: chipselect 0 already in use
[    0.371407] spi_master spi0: spi_device register error /bus@f0000/bus@fc00000/spi@fc40000/nand@0
[    0.371426] spi_master spi0: Failed to create SPI device for /bus@f0000/bus@fc00000/spi@fc40000/nand@0
[    0.412199] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
[    0.415784] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[    0.415834] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
[    0.416283] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    0.416297] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
[    0.417092] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
[    0.426403] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    0.434446] mmc0: CQHCI version 5.10
[    0.472240] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    0.506826] pca953x 3-0020: supply vcc not found, using dummy regulator
[    0.506991] pca953x 3-0020: using no AI
[    0.529122] j721e-pcie f102000.pcie: host bridge /bus@f0000/pcie@f102000 ranges:
[    0.529176] j721e-pcie f102000.pcie:       IO 0x0068001000..0x0068010fff -> 0x0068001000
[    0.529197] j721e-pcie f102000.pcie:      MEM 0x0068011000..0x006fffffff -> 0x0068011000
[    0.529216] j721e-pcie f102000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    0.557777] mmc0: Command Queue Engine enabled
[    0.557811] mmc0: new HS200 MMC card at address 0001
[    0.558993] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    0.562329]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[    0.563764] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[    0.565054] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[    0.565975] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
[    1.637187] j721e-pcie f102000.pcie: PCI host bridge to bus 0000:00
[    1.637213] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.637226] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x68001000-0x68010fff])
[    1.637235] pci_bus 0000:00: root bus resource [mem 0x68011000-0x6fffffff]
[    1.637273] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400 PCIe Root Port
[    1.637297] pci 0000:00:00.0: PCI bridge to [bus 00]
[    1.637307] pci 0000:00:00.0:   bridge window [io  0x0000-0x0fff]
[    1.637316] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    1.637329] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    1.637399] pci 0000:00:00.0: supports D1
[    1.637406] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    1.639858] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.640012] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    1.640039] pci 0000:00:00.0: PCI bridge to [bus 01]
[    1.640053] pci_bus 0000:00: resource 4 [io  0x0000-0xffff]
[    1.640062] pci_bus 0000:00: resource 5 [mem 0x68011000-0x6fffffff]
[    1.640283] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[    1.640664] pcieport 0000:00:00.0: PME: Signaling with IRQ 527
[    1.641004] pcieport 0000:00:00.0: AER: enabled with IRQ 527
[    1.642873] mmc1: CQHCI version 5.10
[    1.642959] clk: Disabling unused clocks
[    1.649630] PM: genpd: Disabling unused power domains
[    1.649752] ALSA device list:
[    1.649759]   No soundcards found.
[    1.690909] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[    1.730139] EXT4-fs (mmcblk0p2): recovery complete
[    1.730611] EXT4-fs (mmcblk0p2): mounted filesystem 6da57929-6db6-45c0-830c-3ca8b94a6dee r/w with ordered data mode. Quota mode: none.
[    1.730696] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.731064] devtmpfs: mounted
[    1.731896] Freeing unused kernel memory: 2752K
[    1.731999] Run /home/root/init-byd.sh as init process
[    1.732005]   with arguments:
[    1.732008]     /home/root/init-byd.sh
[    1.732012]   with environment:
[    1.732015]     HOME=/
[    1.732020]     TERM=linux
[    1.786589] mmc1: new ultra high speed SDR104 SDXC card at address 59b4
[    1.787529] mmcblk1: mmc1:59b4 SD64G 59.4 GiB
[    1.789659]  mmcblk1: p1 p2 p3
[    1.840601] NET: Registered PF_INET6 protocol family
[    1.841845] Segment Routing with IPv6
[    1.841890] In-situ OAM (IOAM) with IPv6
[    1.871471] EXT4-fs (mmcblk0p4): recovery complete
[    1.871648] EXT4-fs (mmcblk0p4): mounted filesystem a762c763-b8fc-4569-a237-1d8ee98966d6 r/w with ordered data mode. Quota mode: none.
[    1.873754] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[    1.873788] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[    1.897359] EXT4-fs (mmcblk0p6): recovery complete
[    1.897523] EXT4-fs (mmcblk0p6): mounted filesystem dcf44be5-5d66-4d1e-b170-d23f3992d14d r/w with ordered data mode. Quota mode: none.
[    1.916054] EXT4-fs (mmcblk0p10): VFS: Can't find ext4 filesystem
[    1.916631] EXT4-fs (mmcblk0p10): VFS: Can't find ext4 filesystem
[    1.916891] EXT4-fs (mmcblk0p10): VFS: Can't find ext4 filesystem
[    1.917328] FAT-fs (mmcblk0p10): bogus number of reserved sectors
[    1.917339] FAT-fs (mmcblk0p10): Can't find a valid FAT filesystem
[    1.953891] EXT4-fs (mmcblk0p8): recovery complete
[    1.954060] EXT4-fs (mmcblk0p8): mounted filesystem 01f5ccd2-a823-45bc-ba3a-c21658b3eca6 r/w with ordered data mode. Quota mode: none.
[    2.015450] file system registered
[    2.038594] systemd[1]: System time before build time, advancing clock.
[    2.058700] systemd[1]: systemd 255.18^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    2.058741] systemd[1]: Detected architecture arm64.
[    2.062602] systemd[1]: Hostname set to <j722s-evm>.
[    2.344364] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    2.503095] systemd[1]: Queued start job for default target Graphical Interface.
[    2.542795] systemd[1]: Created slice Slice /system/getty.
[    2.545706] systemd[1]: Created slice Slice /system/modprobe.
[    2.548251] systemd[1]: Created slice Slice /system/serial-getty.
[    2.550212] systemd[1]: Created slice User and Session Slice.
[    2.550675] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    2.550945] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.551115] systemd[1]: Expecting device /dev/ttyS2...
[    2.551342] systemd[1]: Reached target Path Units.
[    2.551443] systemd[1]: Reached target Remote File Systems.
[    2.551544] systemd[1]: Reached target Slice Units.
[    2.551674] systemd[1]: Reached target Swaps.
[    2.570833] systemd[1]: Listening on RPCbind Server Activation Socket.
[    2.571247] systemd[1]: Reached target RPC Port Mapper.
[    2.578954] systemd[1]: Listening on Process Core Dump Socket.
[    2.579539] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    2.581030] systemd[1]: Listening on Journal Audit Socket.
[    2.581931] systemd[1]: Listening on Journal Socket (/dev/log).
[    2.582778] systemd[1]: Listening on Journal Socket.
[    2.583723] systemd[1]: Listening on udev Control Socket.
[    2.584476] systemd[1]: Listening on udev Kernel Socket.
[    2.585258] systemd[1]: Listening on User Database Manager Socket.
[    2.591058] systemd[1]: Mounting Huge Pages File System...
[    2.596451] systemd[1]: Mounting POSIX Message Queue File System...
[    2.602501] systemd[1]: Mounting Kernel Debug File System...
[    2.603348] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[    2.612926] systemd[1]: Mounting Temporary Directory /tmp...
[    2.625315] systemd[1]: Starting Create List of Static Device Nodes...
[    2.633031] systemd[1]: Starting Load Kernel Module configfs...
[    2.639305] systemd[1]: Starting Load Kernel Module drm...
[    2.649634] systemd[1]: Starting Load Kernel Module fuse...
[    2.657194] systemd[1]: Starting Start psplash boot splash screen...
[    2.669251] systemd[1]: Starting RPC Bind...
[    2.669851] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[    2.685676] systemd[1]: Starting Journal Service...
[    2.697581] systemd[1]: Starting Load Kernel Modules...
[    2.709464] systemd[1]: Starting Remount Root and Kernel File Systems...
[    2.721445] systemd[1]: Starting Coldplug All udev Devices...
[    2.733772] fuse: init (API version 7.41)
[    2.735694] systemd[1]: Mounted Huge Pages File System.
[    2.737131] systemd[1]: Mounted POSIX Message Queue File System.
[    2.738368] systemd[1]: Mounted Kernel Debug File System.
[    2.739790] systemd[1]: Started RPC Bind.
[    2.741431] systemd[1]: Mounted Temporary Directory /tmp.
[    2.743658] systemd[1]: Finished Create List of Static Device Nodes.
[    2.745557] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    2.746456] systemd[1]: Finished Load Kernel Module configfs.
[    2.748669] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    2.749613] systemd[1]: Finished Load Kernel Module drm.
[    2.751716] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    2.752897] systemd[1]: Finished Load Kernel Module fuse.
[    2.754374] systemd[1]: psplash-start.service: Main process exited, code=exited, status=255/EXCEPTION
[    2.755232] systemd[1]: psplash-start.service: Failed with result 'exit-code'.
[    2.756453] systemd[1]: Failed to start Start psplash boot splash screen.
[    2.756758] systemd[1]: Dependency failed for Start psplash-systemd progress communication helper.
[    2.756858] systemd[1]: psplash-systemd.service: Job psplash-systemd.service/start failed with result 'dependency'.
[    2.765239] systemd[1]: Mounting FUSE Control File System...
[    2.778994] systemd[1]: Mounting Kernel Configuration File System...
[    2.792769] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[    2.804890] EXT4-fs (mmcblk0p2): re-mounted 6da57929-6db6-45c0-830c-3ca8b94a6dee r/w. Quota mode: none.
[    2.815413] cryptodev: loading out-of-tree module taints kernel.
[    2.819257] systemd[1]: Mounted FUSE Control File System.
[    2.821144] sysctl table check failed: ioctl/(null) procname is null
[    2.821172] sysctl table check failed: ioctl/(null) No proc_handler
[    2.821181] cryptodev: driver 1.14 loaded.
[    2.832817] systemd[1]: Finished Load Kernel Modules.
[    2.834884] systemd[1]: Finished Remount Root and Kernel File Systems.
[    2.840652] systemd[1]: Mounted Kernel Configuration File System.
[    2.843463] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[    2.845981] systemd-journald[180]: Collecting audit messages is enabled.
[    2.897134] systemd[1]: Starting Apply Kernel Variables...
[    2.900490] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[    2.901614] systemd[1]: Create System Users was skipped because no trigger condition checks were met.
[    2.909091] systemd[1]: Starting Create Static Device Nodes in /dev...
[    2.937889] systemd[1]: Started Journal Service.
[    3.007145] systemd-journald[180]: Received client request to flush runtime journal.
[    3.011003] audit: type=1334 audit(1741187609.968:2): prog-id=6 op=LOAD
[    3.011580] audit: type=1334 audit(1741187609.968:3): prog-id=7 op=LOAD
[    3.043821] udc 31000000.usb: failed to start g1: -19
[    3.044100] UDC core: g1: couldn't find an available UDC or it's busy
[    3.047892] ffs_data_put(): freeing
[    3.060932] read descriptors
[    3.060959] bcdVersion must be 0x0100, stored in Little Endian order. Userspace driver should be fixed, accepting 0x0001 for compatibility.
[    3.060971] read strings
[    3.271639] audit: type=1334 audit(1741187610.228:4): prog-id=8 op=LOAD
[    3.272374] audit: type=1334 audit(1741187610.232:5): prog-id=9 op=LOAD
[    3.272767] audit: type=1334 audit(1741187610.232:6): prog-id=10 op=LOAD
[    3.914838] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[    4.294165] audit: type=1334 audit(1741187611.252:7): prog-id=11 op=LOAD
[    4.309645] audit: type=1334 audit(1741187611.268:8): prog-id=12 op=LOAD
[    4.316593] audit: type=1334 audit(1741187611.276:9): prog-id=11 op=UNLOAD
[    4.384677] audit: type=1334 audit(1741187611.344:10): prog-id=12 op=UNLOAD
[    5.276467] kauditd_printk_skb: 18 callbacks suppressed
[    5.276487] audit: type=1334 audit(1741187612.236:29): prog-id=23 op=LOAD
[    5.294911] audit: type=1334 audit(1741187612.252:30): prog-id=24 op=LOAD
[    5.336641] audit: type=1334 audit(1741187612.296:31): prog-id=23 op=UNLOAD
[    5.337590] audit: type=1334 audit(1741187612.296:32): prog-id=24 op=UNLOAD
[    5.423107] audit: type=1334 audit(1741187612.380:33): prog-id=25 op=LOAD
[    5.424061] audit: type=1334 audit(1741187612.380:34): prog-id=26 op=LOAD
[    5.424853] audit: type=1334 audit(1741187612.384:35): prog-id=27 op=LOAD
[    5.424990] audit: type=1334 audit(1741187612.384:36): prog-id=21 op=UNLOAD
[    5.425057] audit: type=1334 audit(1741187612.384:37): prog-id=22 op=UNLOAD
[    5.469347] audit: type=1334 audit(1741187612.428:38): prog-id=25 op=UNLOAD
[    5.491423] CAN device driver interface
[    5.497112] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
[    5.499343] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
[    5.501111] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
[    5.502158] omap-mailbox 29030000.mailbox: omap mailbox rev 0x66fca100
[    5.548061] mc: Linux media interface: v0.10
[    5.563809] videodev: Linux video capture interface: v2.00
[    5.692419] vdec 30210000.video-codec: Direct firmware load for cnm/wave521c_k3_codec_fw.bin failed with error -2
[    5.692461] vdec 30210000.video-codec: request_firmware, fail: -2
[    5.692469] vdec 30210000.video-codec: wave5_vpu_load_firmware, fail: -2
[    5.753742] vdec 30210000.video-codec: probe with driver vdec failed with error -2
[    6.180434] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    6.182209] platform 78000000.r5f: configured R5F for IPC-only mode
[    6.182419] platform 78000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[    6.183139] rtc-ti-k3 2b1f0000.rtc: Clock rate 32552 is not 32768! Could misbehave!
[    6.183939] remoteproc remoteproc0: 78000000.r5f is available
[    6.188850] remoteproc remoteproc0: attaching to 78000000.r5f
[    6.188894] remoteproc remoteproc0: remote processor 78000000.r5f is now attached
[    6.192938] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[    6.444114] sii902x 3-003b: supply iovcc not found, using dummy regulator
[    6.444474] sii902x 3-003b: supply cvcc12 not found, using dummy regulator
[    6.449363] i2c i2c-3: Added multiplexed i2c bus 9
[    6.495762] [drm] Initialized tidss 1.0.0 for 30220000.dss on minor 0
[    6.496384] tidss 30220000.dss: [drm] Cannot find any crtc or sizes
[    6.497370] tidss 30220000.dss: [drm] Cannot find any crtc or sizes
[    6.499664] m_can_platform 4e08000.can: m_can device registered (irq=546, version=32)
[    6.504992] m_can_platform 4e18000.can: m_can device registered (irq=547, version=32)
[    6.514813] m_can_platform 20701000.can: m_can device registered (irq=548, version=32)
[    6.534477] PVR_K:  240: Device: fd80000.gpu
[    6.569475] PVR_K:  240: Read BVNC 36.53.104.796 from HW device registers
[    6.569642] PVR_K:  240: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
[    6.625573] [drm] Initialized pvr 24.2.6643903 for fd80000.gpu on minor 1
[    7.251500] EXT4-fs (mmcblk0p7): mounted filesystem 714acfe9-fa04-47fc-8f9f-44ef47dc8e3a r/w with ordered data mode. Quota mode: none.
[    7.538963] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[    7.539018] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 1
[    7.539348] xhci-hcd xhci-hcd.6.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000008010
[    7.539440] xhci-hcd xhci-hcd.6.auto: irq 550, io mem 0x31210000
[    7.539697] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[    7.539730] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 2
[    7.539756] xhci-hcd xhci-hcd.6.auto: Host supports USB 3.0 SuperSpeed
[    7.551886] hub 1-0:1.0: USB hub found
[    7.564504] hub 1-0:1.0: 1 port detected
[    7.565964] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.663887] m_can_platform 4e08000.can mcu_mcan0: renamed from can0
[    7.700036] m_can_platform 4e18000.can mcu_mcan1: renamed from can1
[    7.720771] hub 2-0:1.0: USB hub found
[    7.724377] hub 2-0:1.0: 1 port detected
[    7.748786] m_can_platform 20701000.can main_mcan0: renamed from can2
[    7.812510] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    7.987662] hub 1-1:1.0: USB hub found
[    7.987794] hub 1-1:1.0: 4 ports detected
[    8.076353] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[    8.093732] hub 2-1:1.0: USB hub found
[    8.093825] hub 2-1:1.0: 4 ports detected
[    8.247590] usbcore: registered new device driver onboard-usb-dev
[    8.330189] EXT4-fs (mmcblk0p3): mounted filesystem 6da57929-6db6-45c0-830c-3ca8b94a6dee r/w with ordered data mode. Quota mode: none.
[    8.605569] EXT4-fs (mmcblk0p9): mounted filesystem 34bc73be-f5b7-419e-b2fb-054e18021532 r/w with ordered data mode. Quota mode: none.
[    8.703707] EXT4-fs (mmcblk0p5): mounted filesystem d11f1d2f-b7a6-48df-81bc-0f15ce66f788 r/w with ordered data mode. Quota mode: none.
[    9.026766] EXT4-fs (mmcblk1p2): mounted filesystem 91d3c75a-02aa-42ea-a9b1-661abffd4238 r/w with ordered data mode. Quota mode: none.
[    9.059183] EXT4-fs (mmcblk1p3): mounted filesystem e11591ad-32b5-4cc5-9c76-bb3acb346b23 r/w with ordered data mode. Quota mode: none.
5、DEVICE TREE:
// SPDX-License-Identifier: GPL-2.0-only OR MIT
 * Device Tree file for the J722S EVM
 * Copyright (C) 2024 Texas Instruments Incorporated - https://www.ti.com/
 * Schematics: https://www.ti.com/lit/zip/sprr495
#include <dt-bindings/net/ti-dp83867.h>
#include <dt-bindings/phy/phy.h>
#include "k3-j722s.dtsi"
#include "k3-serdes.h"
	aliases {
		serial0 = &wkup_uart0;
		serial2 = &main_uart0;
		serial3 = &main_uart5;
		mmc0 = &sdhci0;
		mmc1 = &sdhci1;
	memory@80000000 {
		/* 8G RAM */
		reg = <0x00000000 0x80000000 0x00000000 0x80000000>,
		      <0x00000008 0x80000000 0x00000001 0x80000000>;
		device_type = "memory";
		bootph-pre-ram;
	reserved_memory: reserved-memory {
		#address-cells = <2>;
		#size-cells = <2>;
 		ranges;
		vision_apps_wkup_r5fss0_core0_dma_memory_region: vision-apps-r5f-dma-memory@a0000000 {
			compatible = "shared-dma-pool";
			reg = <0x00 0xa0000000 0x00 0x00100000>;
			no-map;
		vision_apps_wkup_r5fss0_core0_memory_region: vision-apps-r5f-memory@a0100000 {
			reg = <0x00 0xa0100000 0x00 0x00f00000>;
			no-map;
		vision_apps_mcu_r5fss0_core0_dma_memory_region: vision-apps-r5f-dma-memory@a1000000 {
			reg = <0x00 0xa1000000 0x00 0x00100000>;
			no-map;
		vision_apps_mcu_r5fss0_core0_memory_region: vision-apps-r5f-memory@a1100000 {
			reg = <0x00 0xa1100000 0x00 0x00f00000>;
			no-map;
		vision_apps_main_r5fss0_core0_dma_memory_region: vision-apps-r5f-dma-memory@a2000000 {
			reg = <0x00 0xa2000000 0x00 0x00100000>;
			no-map;
		vision_apps_main_r5fss0_core0_memory_region: vision-apps-r5f-memory@a2100000 {
			reg = <0x00 0xa2100000 0x00 0x01f00000>;
			no-map;
		vision_apps_rtos_ipc_memory_region: vision-apps-rtos-ipc-memory-region@a5000000 {
			reg = <0x00 0xa5000000 0x00 0x02000000>;
			no-map;
		vision_apps_memory_region: vision-apps-dma-memory@a7000000 {
			reg = <0x00 0xa7000000 0x00 0x06000000>;
			no-map;
		vision_apps_c71_0_dma_memory_region: vision-apps-c71-dma-memory@ad000000 {
			reg = <0x00 0xad000000 0x00 0x00100000>;
			no-map;
		vision_apps_c71_0_memory_region: vision-apps-c71_0-memory@ad100000 {
			reg = <0x00 0xad100000 0x00 0x03f00000>;
			no-map;
		vision_apps_c71_1_dma_memory_region: vision-apps-c71_1-dma-memory@b1000000 {
			reg = <0x00 0xb1000000 0x00 0x00100000>;
			no-map;
		vision_apps_c71_1_memory_region: vision-apps-c71_1-memory@b1100000 {
			reg = <0x00 0xb1100000 0x00 0x03f00000>;
			no-map;
		vision_apps_core_heaps_lo: vision-apps-core-heap-memory-lo@b5000000 {
			reg = <0x00 0xb5000000 0x00 0x02800000>;
			no-map;
		c7x_ddr_heaps_hi: c7x-ddr-heaps-hi@880000000 {
			reg = <0x08 0x80000000 0x00 0x20000000>;
			no-map;
		vision_apps_shared_region: vision_apps_shared-memories {
			compatible = "dma-heap-carveout";
			reg = <0x09 0x00000000 0x00 0x20000000>;
		linux,cma {
			status = "disabled";
		linux_cma_region: linux-cma-buffers@980000000 {
			reusable;
			reg = <0x09 0x80000000 0x00 0x38000000>;
			linux,cma-default;
	vmain_pd: regulator-0 {
		/* TPS65988 PD CONTROLLER OUTPUT */
		compatible = "regulator-fixed";
		regulator-name = "vmain_pd";
		regulator-min-microvolt = <5000000>;
		regulator-max-microvolt = <5000000>;
		regulator-always-on;
		regulator-boot-on;
		bootph-all;
	vsys_5v0: regulator-vsys5v0 {
		/* Output of LM5140 */
		regulator-name = "vsys_5v0";
		vin-supply = <&vmain_pd>;
		regulator-boot-on;
	vdd_mmc1: regulator-mmc1 {
		/* TPS22918DBVR */
		regulator-name = "vdd_mmc1";
		regulator-min-microvolt = <3300000>;
		regulator-max-microvolt = <3300000>;
		regulator-boot-on;
		enable-active-high;
		gpio = <&exp1 15 GPIO_ACTIVE_HIGH>;
		bootph-all;
	vdd_sd_dv: regulator-TLV71033 {
		compatible = "regulator-gpio";
		regulator-name = "tlv71033";
		pinctrl-0 = <&vdd_sd_dv_pins_default>;
		regulator-min-microvolt = <1800000>;
		regulator-boot-on;
		vin-supply = <&vsys_5v0>;
		gpios = <&main_gpio0 70 GPIO_ACTIVE_HIGH>;
		states = <1800000 0x0>,
			 <3300000 0x1>;
	vsys_io_3v3: regulator-vsys-io-3v3 {
		regulator-name = "vsys_io_3v3";
		regulator-boot-on;
	vsys_io_1v8: regulator-vsys-io-1v8 {
		regulator-name = "vsys_io_1v8";
		regulator-max-microvolt = <1800000>;
		regulator-boot-on;
	vsys_io_1v2: regulator-vsys-io-1v2 {
		regulator-name = "vsys_io_1v2";
		regulator-min-microvolt = <1200000>;
		regulator-max-microvolt = <1200000>;
		regulator-boot-on;
	codec_audio: sound {
		compatible = "simple-audio-card";
		simple-audio-card,name = "J722S-EVM";
		simple-audio-card,widgets =
			"Headphone",	"Headphone Jack",
			"Line",		"Line In",
			"Microphone",	"Microphone Jack";
		simple-audio-card,routing =
			"Headphone Jack",	"HPLOUT",
			"Headphone Jack",	"HPROUT",
			"LINE1L",		"Line In",
			"LINE1R",		"Line In",
			"MIC3R",		"Microphone Jack",
			"Microphone Jack",	"Mic Bias";
		simple-audio-card,format = "dsp_b";
		simple-audio-card,bitclock-master = <&sound_master>;
		simple-audio-card,frame-master = <&sound_master>;
		simple-audio-card,bitclock-inversion;
		simple-audio-card,cpu {
			sound-dai = <&mcasp1>;
		sound_master: simple-audio-card,codec {
			sound-dai = <&tlv320aic3106>;
			clocks = <&audio_refclk1>;
	transceiver0: can-phy0 {
		compatible = "ti,tcan1042";
		#phy-cells = <0>;
		max-bitrate = <5000000>;
		pinctrl-0 = <&mcu_mcan0_gpio_pins_default>;
		standby-gpios = <&mcu_gpio0 12 GPIO_ACTIVE_HIGH>;
	transceiver1: can-phy1 {
		#phy-cells = <0>;
	transceiver2: can-phy2 {
		#phy-cells = <0>;
		standby-gpios = <&exp1 17 GPIO_ACTIVE_HIGH>;
	hdmi0: connector-hdmi {
		compatible = "hdmi-connector";
		label = "hdmi";
		type = "a";
		port {
			hdmi_connector_in: endpoint {
				remote-endpoint = <&sii9022_out>;
&main_pmx0 {
	main_mcan0_pins_default: main-mcan0-default-pins {
		pinctrl-single,pins = <
			J722S_IOPAD(0x1dc, PIN_INPUT, 0) /* (C22) MCAN0_RX */
			J722S_IOPAD(0x1d8, PIN_OUTPUT, 0) /*(D22) MCAN0_TX */
	main_i2c0_pins_default: main-i2c0-default-pins {
			J722S_IOPAD(0x01e0, PIN_INPUT_PULLUP, 0) /* (D23) I2C0_SCL */
			J722S_IOPAD(0x01e4, PIN_INPUT_PULLUP, 0) /* (B22) I2C0_SDA */
		bootph-all;
	main_i2c1_pins_default: main-i2c1-default-pins {
			J722S_IOPAD(0x01e8, PIN_INPUT_PULLUP, 0) /* (C24) I2C1_SCL */
			J722S_IOPAD(0x01ec, PIN_INPUT_PULLUP, 0) /* (A22) I2C1_SDA */
		bootph-all;
	main_i2c2_pins_default: main-i2c2-default-pins {
			J722S_IOPAD(0x00b0, PIN_INPUT_PULLUP, 1) /* (P22) GPMC0_CSn2.I2C2_SCL */
			J722S_IOPAD(0x00b4, PIN_INPUT_PULLUP, 1) /* (P23) GPMC0_CSn3.I2C2_SDA */
	main_uart0_pins_default: main-uart0-default-pins {
			J722S_IOPAD(0x01c8, PIN_INPUT, 0)	/* (A22) UART0_RXD */
			J722S_IOPAD(0x01cc, PIN_OUTPUT, 0)	/* (B22) UART0_TXD */
		bootph-all;
	main_uart5_pins_default: main-uart5-default-pins {
			J722S_IOPAD(0x0108, PIN_INPUT, 3)       /* (J27) UART5_RXD */
			J722S_IOPAD(0x010c, PIN_OUTPUT, 3)      /* (H27) UART5_TXD */
	vdd_sd_dv_pins_default: vdd-sd-dv-default-pins {
			J722S_IOPAD(0x0120, PIN_INPUT, 7) /* (F27) MMC2_CMD.GPIO0_70 */
		bootph-all;
	main_mmc1_pins_default: main-mmc1-default-pins {
			J722S_IOPAD(0x023c, PIN_INPUT, 0) /* (H22) MMC1_CMD */
			J722S_IOPAD(0x0234, PIN_OUTPUT, 0) /* (H24) MMC1_CLK */
			J722S_IOPAD(0x0230, PIN_INPUT, 0) /* (H23) MMC1_DAT0 */
			J722S_IOPAD(0x022c, PIN_INPUT_PULLUP, 0) /* (H20) MMC1_DAT1 */
			J722S_IOPAD(0x0228, PIN_INPUT_PULLUP, 0) /* (J23) MMC1_DAT2 */
			J722S_IOPAD(0x0224, PIN_INPUT_PULLUP, 0) /* (H25) MMC1_DAT3 */
			J722S_IOPAD(0x0240, PIN_INPUT, 0) /* (B24) MMC1_SDCD */
		bootph-all;
	mdio_pins_default: mdio-default-pins {
			J722S_IOPAD(0x0160, PIN_OUTPUT, 0) /* (AC24) MDIO0_MDC */
			J722S_IOPAD(0x015c, PIN_INPUT, 0) /* (AD25) MDIO0_MDIO */
		bootph-all;
	ospi0_pins_default: ospi0-default-pins {
			J722S_IOPAD(0x0000, PIN_OUTPUT, 0) /* (L24) OSPI0_CLK */
			J722S_IOPAD(0x002c, PIN_OUTPUT, 0) /* (K26) OSPI0_CSn0 */
			J722S_IOPAD(0x000c, PIN_INPUT, 0) /* (K27) OSPI0_D0 */
			J722S_IOPAD(0x0010, PIN_INPUT, 0) /* (L27) OSPI0_D1 */
			J722S_IOPAD(0x0014, PIN_INPUT, 0) /* (L26) OSPI0_D2 */
			J722S_IOPAD(0x0018, PIN_INPUT, 0) /* (L25) OSPI0_D3 */
			J722S_IOPAD(0x001c, PIN_INPUT, 0) /* (L21) OSPI0_D4 */
			J722S_IOPAD(0x0020, PIN_INPUT, 0) /* (M26) OSPI0_D5 */
			J722S_IOPAD(0x0024, PIN_INPUT, 0) /* (N27) OSPI0_D6 */
			J722S_IOPAD(0x0028, PIN_INPUT, 0) /* (M27) OSPI0_D7 */
			J722S_IOPAD(0x0008, PIN_INPUT, 0) /* (L22) OSPI0_DQS */
		bootph-all;
	rgmii1_pins_default: rgmii1-default-pins {
			J722S_IOPAD(0x014c, PIN_INPUT, 0) /* (AC25) RGMII1_RD0 */
			J722S_IOPAD(0x0150, PIN_INPUT, 0) /* (AD27) RGMII1_RD1 */
			J722S_IOPAD(0x0154, PIN_INPUT, 0) /* (AE24) RGMII1_RD2 */
			J722S_IOPAD(0x0158, PIN_INPUT, 0) /* (AE26) RGMII1_RD3 */
			J722S_IOPAD(0x0148, PIN_INPUT, 0) /* (AE27) RGMII1_RXC */
			J722S_IOPAD(0x0144, PIN_INPUT, 0) /* (AD23) RGMII1_RX_CTL */
			J722S_IOPAD(0x0134, PIN_OUTPUT, 0) /* (AF27) RGMII1_TD0 */
			J722S_IOPAD(0x0138, PIN_OUTPUT, 0) /* (AE23) RGMII1_TD1 */
			J722S_IOPAD(0x013c, PIN_OUTPUT, 0) /* (AG25) RGMII1_TD2 */
			J722S_IOPAD(0x0140, PIN_OUTPUT, 0) /* (AF24) RGMII1_TD3 */
			J722S_IOPAD(0x0130, PIN_OUTPUT, 0) /* (AG26) RGMII1_TXC */
			J722S_IOPAD(0x012c, PIN_OUTPUT, 0) /* (AF25) RGMII1_TX_CTL */
		bootph-all;
	main_usb1_pins_default: main-usb1-default-pins {
			J722S_IOPAD(0x0258, PIN_INPUT, 0) /* (B27) USB1_DRVVBUS */
	main_mcasp1_pins_default: main-mcasp1-default-pins {
			J722S_IOPAD(0x0090, PIN_INPUT, 2) /* (P27) GPMC0_BE0n_CLE.MCASP1_ACLKX */
			J722S_IOPAD(0x0098, PIN_INPUT, 2) /* (V21) GPMC0_WAIT0.MCASP1_AFSX */
			J722S_IOPAD(0x008c, PIN_OUTPUT, 2) /* (N23) GPMC0_WEn.MCASP1_AXR0 */
			J722S_IOPAD(0x0084, PIN_INPUT, 2) /* (N21) GPMC0_ADVn_ALE.MCASP1_AXR2 */
	audio_ext_refclk1_pins_default: audio-ext-refclk1-default-pins {
			J722S_IOPAD(0x00a0, PIN_OUTPUT, 1) /* (N24) GPMC0_WPn.AUDIO_EXT_REFCLK1 */
	pmic_irq_pins_default: pmic-irq-default-pins {
			J722S_IOPAD(0x030, PIN_INPUT, 7) /* (K23) GPIO0_12 */
	main_gpio0_ioexp_intr_pins_default: main-gpio0-ioexp-intr-default-pins {
			J722S_IOPAD(0x0110, PIN_INPUT, 7) /* (G27) MMC2_DAT1.GPIO0_67 */
	main_dpi_pins_default: main-dpi-default-pins {
			J722S_IOPAD(0x0100, PIN_OUTPUT, 0) /* (AB23) VOUT0_VSYNC */
			J722S_IOPAD(0x00f8, PIN_OUTPUT, 0) /* (AB24) VOUT0_HSYNC */
			J722S_IOPAD(0x0104, PIN_OUTPUT, 0) /* (AC26) VOUT0_PCLK */
			J722S_IOPAD(0x00fc, PIN_OUTPUT, 0) /* (AC27) VOUT0_DE */
			J722S_IOPAD(0x00b8, PIN_OUTPUT, 0) /* (W27) VOUT0_DATA0 */
			J722S_IOPAD(0x00bc, PIN_OUTPUT, 0) /* (W25) VOUT0_DATA1 */
			J722S_IOPAD(0x00c0, PIN_OUTPUT, 0) /* (W24) VOUT0_DATA2 */
			J722S_IOPAD(0x00c4, PIN_OUTPUT, 0) /* (W23) VOUT0_DATA3 */
			J722S_IOPAD(0x00c8, PIN_OUTPUT, 0) /* (W22) VOUT0_DATA4 */
			J722S_IOPAD(0x00cc, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA5 */
			J722S_IOPAD(0x00d0, PIN_OUTPUT, 0) /* (Y26) VOUT0_DATA6 */
			J722S_IOPAD(0x00d4, PIN_OUTPUT, 0) /* (Y27) VOUT0_DATA7 */
			J722S_IOPAD(0x00d8, PIN_OUTPUT, 0) /* (AA24) VOUT0_DATA8 */
			J722S_IOPAD(0x00dc, PIN_OUTPUT, 0) /* (AA27) VOUT0_DATA9 */
			J722S_IOPAD(0x00e0, PIN_OUTPUT, 0) /* (AA25) VOUT0_DATA10 */
			J722S_IOPAD(0x00e4, PIN_OUTPUT, 0) /* (AB25) VOUT0_DATA11 */
			J722S_IOPAD(0x00e8, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA12 */
			J722S_IOPAD(0x00ec, PIN_OUTPUT, 0) /* (AA22) VOUT0_DATA13 */
			J722S_IOPAD(0x00f0, PIN_OUTPUT, 0) /* (AB26) VOUT0_DATA14 */
			J722S_IOPAD(0x00f4, PIN_OUTPUT, 0) /* (AB27) VOUT0_DATA15 */
			J722S_IOPAD(0x005c, PIN_OUTPUT, 1) /* (U27) GPMC0_AD8.VOUT0_DATA16 */
			J722S_IOPAD(0x0060, PIN_OUTPUT, 1) /* (U26) GPMC0_AD9.VOUT0_DATA17 */
			J722S_IOPAD(0x0064, PIN_OUTPUT, 1) /* (V27) GPMC0_AD10.VOUT0_DATA18 */
			J722S_IOPAD(0x0068, PIN_OUTPUT, 1) /* (V25) GPMC0_AD11.VOUT0_DATA19 */
			J722S_IOPAD(0x006c, PIN_OUTPUT, 1) /* (V26) GPMC0_AD12.VOUT0_DATA20 */
			J722S_IOPAD(0x0070, PIN_OUTPUT, 1) /* (V24) GPMC0_AD13.VOUT0_DATA21 */
			J722S_IOPAD(0x0074, PIN_OUTPUT, 1) /* (V22) GPMC0_AD14.VOUT0_DATA22 */
			J722S_IOPAD(0x0078, PIN_OUTPUT, 1) /* (V23) GPMC0_AD15.VOUT0_DATA23 */
			J722S_IOPAD(0x009c, PIN_OUTPUT, 1) /* (W26) GPMC0_WAIT1.VOUT0_EXTPCLKIN */
&cpsw3g {
	status = "okay";
	pinctrl-names = "default";
	pinctrl-0 = <&rgmii1_pins_default>;
&cpsw3g_mdio {
	status = "okay";
	pinctrl-0 = <&mdio_pins_default>;
	cpsw3g_phy0: ethernet-phy@0 {
		reg = <0>;
		bootph-all;
		ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
		ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
		ti,min-output-impedance;
&cpsw_port1 {
	phy-mode = "rgmii-rxid";
	phy-handle = <&cpsw3g_phy0>;
	status = "okay";
&main_gpio1 {
	status = "okay";
&main_uart0 {
	pinctrl-0 = <&main_uart0_pins_default>;
	status = "okay";
	bootph-all;
&main_uart5 {
	/* MAIN UART 5 is used by System firmware */
	pinctrl-0 = <&main_uart5_pins_default>;
	status = "reserved";
&mcu_pmx0 {
	mcu_i2c0_pins_default: mcu-i2c0-default-pins {
			J722S_MCU_IOPAD(0x048, PIN_INPUT, 0) /* (E11) MCU_I2C0_SDA */
			J722S_MCU_IOPAD(0x044, PIN_INPUT, 0) /* (B13) MCU_I2C0_SCL */
	mcu_mcan0_pins_default: mcu-mcan0-default-pins {
			J722S_MCU_IOPAD(0x038, PIN_INPUT, 0) /* (D8) MCU_MCAN0_RX */
			J722S_MCU_IOPAD(0x034, PIN_OUTPUT, 0) /* (B2) MCU_MCAN0_TX */
	mcu_mcan1_pins_default: mcu-mcan1-default-pins {
			J722S_MCU_IOPAD(0x040, PIN_INPUT, 0) /* (B1) MCU_MCAN1_RX */
			J722S_MCU_IOPAD(0x03C, PIN_OUTPUT, 0) /*(C1) MCU_MCAN1_TX */
	mcu_mcan0_gpio_pins_default: mcu-mcan0-gpio-default-pins {
			J722S_MCU_IOPAD(0x0030, PIN_OUTPUT, 7) /* (C3) MCU_GPIO0_12 */
	wkup_uart0_pins_default: wkup-uart0-default-pins {
			J722S_MCU_IOPAD(0x02c, PIN_INPUT, 0)	/* (C7) WKUP_UART0_CTSn */
			J722S_MCU_IOPAD(0x030, PIN_OUTPUT, 0)	/* (C6) WKUP_UART0_RTSn */
			J722S_MCU_IOPAD(0x024, PIN_INPUT, 0)	/* (D8) WKUP_UART0_RXD */
			J722S_MCU_IOPAD(0x028, PIN_OUTPUT, 0)	/* (D7) WKUP_UART0_TXD */
		bootph-all;
	wkup_i2c0_pins_default: wkup-i2c0-default-pins {
			J722S_MCU_IOPAD(0x04c, PIN_INPUT_PULLUP, 0)	/* (C7) WKUP_I2C0_SCL */
			J722S_MCU_IOPAD(0x050, PIN_INPUT_PULLUP, 0)	/* (C6) WKUP_I2C1_SDA */
		bootph-all;
&wkup_uart0 {
	/* WKUP UART0 is used by Device Manager firmware */
	pinctrl-0 = <&wkup_uart0_pins_default>;
	bootph-all;
&wkup_i2c0 {
	pinctrl-0 = <&wkup_i2c0_pins_default>;
	clock-frequency = <400000>;
	status = "okay";
	bootph-all;
	tps65224: pmic@48 {
		compatible = "ti,tps65224-q1";
		reg = <0x48>;
		pinctrl-0 = <&pmic_irq_pins_default>;
		interrupt-parent = <&main_gpio0>;
		interrupts = <0 IRQ_TYPE_EDGE_FALLING>;
		ti,primary-pmic;
		gpio-controller;
		#gpio-cells = <2>;
		buck12-supply = <&vsys_io_3v3>;
		buck3-supply = <&vsys_io_3v3>;
		buck4-supply = <&vsys_io_3v3>;
		ldo1-supply = <&vsys_io_3v3>;
		ldo2-supply = <&vsys_io_3v3>;
		ldo3-supply = <&vsys_io_3v3>;
		regulators {
			buck1: buck1 {
				regulator-name = "vcc1v8_io_buck1";
				regulator-boot-on;
				bootph-all;
			buck2: buck2 {
				regulator-name = "vcc1v1_ddr_buck2";
				regulator-min-microvolt = <1100000>;
				regulator-max-microvolt = <1100000>;
				regulator-boot-on;
			buck3: buck3 {
				regulator-name = "vcc0v85_ram_buck3";
				regulator-min-microvolt = <850000>;
				regulator-max-microvolt = <850000>;
				regulator-boot-on;
			buck4: buck4 {
				regulator-name = "vcc0v75_ioret_buck4";
				regulator-min-microvolt = <750000>;
				regulator-max-microvolt = <750000>;
				regulator-boot-on;
			ldo1: ldo1 {
				regulator-name = "vdda1v8_pll_ldo1";
				regulator-boot-on;
			ldo2: ldo2 {
				regulator-name = "dvdd3v3_ldo2";
				regulator-boot-on;
			ldo3: ldo3 {
				regulator-name = "vdd1v85_phy_ldo3";
				regulator-boot-on;
&k3_clks {
	/* Configure AUDIO_EXT_REFCLK1 pin as output */
	pinctrl-0 = <&audio_ext_refclk1_pins_default>;
&main_i2c0 {
	pinctrl-0 = <&main_i2c0_pins_default>;
	status = "okay";
	bootph-all;
	exp1: gpio@23 {
		compatible = "ti,tca6424";
		reg = <0x23>;
		gpio-controller;
		#gpio-cells = <2>;
		gpio-line-names = "TRC_MUX_SEL", "OSPI/ONAND_MUX_SEL",
				  "MCASP1_FET_SEL", "CTRL_PM_I2C_OE#",
				  "CSI_VIO_SEL", "USB2.0_MUX_SEL",
				  "CSI01_MUX_SEL_2", "CSI23_MUX_SEL_2",
				  "LMK1_OE1", "LMK1_OE0",
				  "LMK2_OE0", "LMK2_OE1",
				  "GPIO_RGMII1_RST#", "GPIO_AUD_RSTn",
				  "GPIO_eMMC_RSTn", "GPIO_uSD_PWR_EN",
				  "USER_LED2", "MCAN0_STB",
				  "PCIe0_1L_RC_RSTz", "PCIe0_1L_PRSNT#",
				  "ENET1_EXP_SPARE2", "ENET1_EXP_PWRDN",
				  "PD_I2ENET1_I2CMUX_SELC_IRQ", "ENET1_EXP_RESETZ";
		bootph-all;
		p05-hog {
			/* P05 - USB2.0_MUX_SEL */
			gpio-hog;
			gpios = <5 GPIO_ACTIVE_LOW>;
			output-high;
		p01_hog: p01-hog {
			/* P01 - TRC_MUX_SEL */
			gpio-hog;
			gpios = <0 GPIO_ACTIVE_HIGH>;
			output-low;
			line-name = "TRC_MUX_SEL";
		p02_hog: p02-hog {
			/* P02 - MCASP1_FET_SEL */
			gpio-hog;
			gpios = <2 GPIO_ACTIVE_HIGH>;
			output-high;
			line-name = "MCASP1_FET_SEL";
		p13_hog: p13-hog {
			/* P13 - GPIO_AUD_RSTn */
			gpio-hog;
			gpios = <13 GPIO_ACTIVE_HIGH>;
			output-high;
			line-name = "GPIO_AUD_RSTn";
	tlv320aic3106: audio-codec@1b {
		#sound-dai-cells = <0>;
		compatible = "ti,tlv320aic3106";
		reg = <0x1b>;
		ai3x-micbias-vg = <1>;  /* 2.0V */
		AVDD-supply = <&vsys_io_3v3>;
		IOVDD-supply = <&vsys_io_3v3>;
		DRVDD-supply = <&vsys_io_3v3>;
		DVDD-supply = <&vsys_io_1v8>;
&main_i2c1 {
	status = "okay";
	pinctrl-0 = <&main_i2c1_pins_default>;
	clock-frequency = <100000>;
	exp2: gpio@20 {
		compatible = "ti,tca6416";
		reg = <0x20>;
		gpio-controller;
		#gpio-cells = <2>;
		gpio-line-names = "DSI_Mux_SEL_2", "GPIO_eDP_ENABLE",
				  "DP0_PWR_SW_EN", "GPIO_OLDI_RSTn",
				  "GPIO_HDMI_RSTn", "HDMI_LS_OE",
				  "DSI_GPIO0", "DSI_GPIO1",
				  "DSI_EDID", "IO_eDP_IRQ",
				  "OLDI_INT#", "HDMI_INTn",
		interrupts = <67 IRQ_TYPE_EDGE_FALLING>;
		interrupt-controller;
		#interrupt-cells = <2>;
		pinctrl-0 = <&main_gpio0_ioexp_intr_pins_default>;
		bootph-all;
		p04-hog {
			/* P04 - GPIO_HDMI_RSTn */
			gpio-hog;
			gpios = <4 GPIO_ACTIVE_LOW>;
			output-low;
			line-name = "GPIO_HDMI_RSTn";
		p03-hog {
			/* P03 - GPIO_OLDI_RSTn */
			gpio-hog;
			gpios = <3 GPIO_ACTIVE_LOW>;
			output-low;
			line-name = "GPIO_OLDI_RSTn";
		p05-hog {
			/* P05 - HDMI_LS_OE */
			gpio-hog;
			gpios = <5 GPIO_ACTIVE_HIGH>;
			output-high;
			line-name = "HDMI_LS_OE";
	sii9022: bridge-hdmi@3b {
		compatible = "sil,sii9022";
		reg = <0x3b>;
		interrupt-parent = <&exp2>;
		interrupts = <13 IRQ_TYPE_EDGE_FALLING>;
		sil,i2s-data-lanes = < 0 >;
		hdmi_tx_ports: ports {
			#address-cells = <1>;
			#size-cells = <0>;
			 * HDMI can be serviced with 3 potential VPs -
			 * (DSS0 VP1 / DSS1 VP0 / DSS1 VP1).
			 * For now, we will service it with DSS1 VP0.
			port@0 {
				reg = <0>;
				sii9022_in: endpoint {
					remote-endpoint = <&dss1_dpi0_out>;
			port@1 {
				reg = <1>;
				sii9022_out: endpoint {
					remote-endpoint = <&hdmi_connector_in>;
&main_i2c2 {
	status = "okay";
	pinctrl-0 = <&main_i2c2_pins_default>;
	pca9543_0: i2c-mux@70 {
		compatible = "nxp,pca9543";
		#size-cells = <0>;
		reg = <0x70>;
	pca9543_1: i2c-mux@71 {
		#size-cells = <0>;
		reg = <0x71>;
&ospi0 {
	pinctrl-0 = <&ospi0_pins_default>;
	status = "okay";
	flash@0 {
		compatible = "jedec,spi-nor";
		reg = <0x0>;
		spi-tx-bus-width = <8>;
		spi-rx-bus-width = <8>;
		spi-max-frequency = <25000000>;
		cdns,tshsl-ns = <60>;
		cdns,tsd2d-ns = <60>;
		cdns,tchsh-ns = <60>;
		cdns,tslch-ns = <60>;
		cdns,read-delay = <4>;
		cdns,phy-mode;
		bootph-all;
		partitions {
			compatible = "fixed-partitions";
			#size-cells = <1>;
			partition@0 {
				label = "ospi.tiboot3";
				reg = <0x00 0x80000>;
			partition@80000 {
				label = "ospi.app0";
				reg = <0x80000 0x1600000>;
			partition@3fc0000 {
				bootph-all;
				label = "ospi.phypattern";
				reg = <0x3fc0000 0x40000>;
	ospi0_nand: nand@0 {
		compatible = "spi-nand";
		reg = <0x0>;
		cdns,read-delay = <2>;
		#size-cells = <1>;
		bootph-all;
		cdns,phy-mode;
		partitions {
			#size-cells = <1>;
			partition@0 {
				label = "ospi_nand.tiboot3";
				reg = <0x0 0x80000>;
			partition@80000 {
				label = "ospi_nand.tispl";
				reg = <0x80000 0x200000>;
			partition@280000 {
				label = "ospi_nand.u-boot";
				reg = <0x280000 0x400000>;
			partition@680000 {
				label = "ospi_nand.env";
				reg = <0x680000 0x40000>;
			partition@6c0000 {
				label = "ospi_nand.env.backup";
				reg = <0x6c0000 0x40000>;
			partition@2000000 {
				label = "ospi_nand.rootfs";
				reg = <0x2000000 0x5fc0000>;
			partition@7fc0000 {
				bootph-all;
				label = "ospi_nand.phypattern";
				reg = <0x7fc0000 0x40000>;
&sdhci0 {
	disable-wp;
	bootph-all;
	ti,driver-strength-ohm = <50>;
	status = "okay";
&sdhci1 {
	/* SD/MMC */
	vmmc-supply = <&vdd_mmc1>;
	vqmmc-supply = <&vdd_sd_dv>;
	pinctrl-0 = <&main_mmc1_pins_default>;
	disable-wp;
	status = "okay";
	bootph-all;
&mailbox0_cluster0 {
	status = "okay";
	mbox_wkup_r5_0: mbox-wkup-r5-0 {
		ti,mbox-rx = <0 0 0>;
		ti,mbox-tx = <1 0 0>;
&mailbox0_cluster1 {
	status = "okay";
	mbox_mcu_r5_0: mbox-mcu-r5-0 {
&mailbox0_cluster2 {
	status = "okay";
	mbox_c7x_0: mbox-c7x-0 {
&mailbox0_cluster3 {
	status = "okay";
	mbox_main_r5_0: mbox-main-r5-0 {
	mbox_c7x_1: mbox-c7x-1 {
		ti,mbox-rx = <2 0 0>;
		ti,mbox-tx = <3 0 0>;
/* Timers are used by Remoteproc firmware */
&main_timer0 {
&main_timer1 {
&main_timer2 {
&wkup_r5fss0 {
	status = "okay";
&wkup_r5fss0_core0 {
	mboxes = <&mailbox0_cluster0 &mbox_wkup_r5_0>;
	memory-region = <&vision_apps_wkup_r5fss0_core0_dma_memory_region>,
			<&vision_apps_wkup_r5fss0_core0_memory_region>;
&mcu_r5fss0_core0 {
	mboxes = <&mailbox0_cluster1 &mbox_mcu_r5_0>;
	memory-region = <&vision_apps_mcu_r5fss0_core0_dma_memory_region>,
			<&vision_apps_mcu_r5fss0_core0_memory_region>;
&main_r5fss0_core0 {
	mboxes = <&mailbox0_cluster3 &mbox_main_r5_0>;
	memory-region = <&vision_apps_main_r5fss0_core0_dma_memory_region>,
			<&vision_apps_main_r5fss0_core0_memory_region>;
&c7x_0 {
	mboxes = <&mailbox0_cluster2 &mbox_c7x_0>;
	memory-region = <&vision_apps_c71_0_dma_memory_region>,
			<&vision_apps_c71_0_memory_region>;
&c7x_1 {
	mboxes = <&mailbox0_cluster3 &mbox_c7x_1>;
	memory-region = <&vision_apps_c71_1_dma_memory_region>,
			<&vision_apps_c71_1_memory_region>;
&serdes_ln_ctrl {
	idle-states = <J722S_SERDES0_LANE0_USB>,
		      <J722S_SERDES1_LANE0_PCIE0_LANE0>;
&serdes0 {
	serdes0_usb_link: phy@0 {
		reg = <0>;
		cdns,num-lanes = <1>;
		#phy-cells = <0>;
		cdns,phy-type = <PHY_TYPE_USB3>;
		resets = <&serdes_wiz0 1>;
&serdes1 {
	status = "okay";
	serdes1_pcie_link: phy@0 {
		reg = <0>;
		#phy-cells = <0>;
		cdns,phy-type = <PHY_TYPE_PCIE>;
		resets = <&serdes_wiz1 1>;
&pcie0_rc {
	reset-gpios = <&exp1 18 GPIO_ACTIVE_HIGH>;
	phys = <&serdes1_pcie_link>;
	phy-names = "pcie-phy";
&usbss0 {
	ti,vbus-divider;
	ti,usb2-only;
	status = "okay";
&usb0 {
	dr_mode = "otg";
	usb-role-switch;
&usbss1 {
	pinctrl-0 = <&main_usb1_pins_default>;
	ti,vbus-divider;
	ti,usb2-only;
	status = "okay";
&usb1 {
	dr_mode = "otg";
	usb-role-switch;
&mcasp1 {
	status = "okay";
	pinctrl-0 = <&main_mcasp1_pins_default>;
	op-mode = <0>; /* MCASP_IIS_MODE */
	tdm-slots = <2>;
	serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
	       1 0 2 0
	       0 0 0 0
	       0 0 0 0
	       0 0 0 0
&mcu_mcan0 {
	pinctrl-0 = <&mcu_mcan0_pins_default>;
	phys = <&transceiver0>;
	status = "okay";
&mcu_mcan1 {
	pinctrl-0 = <&mcu_mcan1_pins_default>;
	phys = <&transceiver1>;
	status = "okay";
&main_mcan0 {
	pinctrl-0 = <&main_mcan0_pins_default>;
	phys = <&transceiver2>;
	status = "okay";
&mcu_gpio0 {
	status = "okay";
&mcu_i2c0 {
	pinctrl-0 = <&mcu_i2c0_pins_default>;
	status = "okay";
&dss1 {
	status = "okay";
	pinctrl-0 = <&main_dpi_pins_default>;
	clocks = <&k3_clks 232 8>,
		 <&k3_clks 232 0>,
		 <&k3_clks 232 4>;
	assigned-clocks = <&k3_clks 241 0>,	/* DSS1-VP0 */
			  <&k3_clks 240 0>,	/* DSS1-VP1 */
			  <&k3_clks 245 0>;	/* DPI Output */
	assigned-clock-parents = <&k3_clks 241 2>,	/* PLL 17 HDMI */
				 <&k3_clks 240 1>,	/* PLL 18 DSI */
				 <&k3_clks 245 2>;	/* DSS1-DPI0 */
&dss1_ports {
	/* DSS1-VP0: DPI/HDMI Output */
	port@0 {
		reg = <0>;
		dss1_dpi0_out: endpoint {
			remote-endpoint = <&sii9022_in>;
&mcu_rti0 {
	assigned-clock-parents = <&k3_clks 131 4>;
&main_rti0 {
	assigned-clock-parents = <&k3_clks 125 4>;
&main_rti1 {
	assigned-clock-parents = <&k3_clks 126 4>;
&main_rti2 {
	assigned-clock-parents = <&k3_clks 127 4>;
&main_rti3 {
	assigned-clock-parents = <&k3_clks 128 4>;
6、Use vision_apps_init.There is no log in sh view,But the spl startup mcu of the sd card can be started normally
Please help me to see what the reason is.
thank!
