SK-AM62P-LP: Why Altia boot start times need 3S at AM62P SKEVM
Part Number: SK-AM62P-LP
Other Parts Discussed in Thread: AM62P
Hi  Ti
I can start AM62P SKEVM  board , then I copy Altia demo into board ,
I run the cmd , ./HyperCluster
the altia demo need 3s display image  in the lcd
There are the Altia demo boot log
you can check it
root@am62pxx-evm:/usr/bin/altia-hmi# ./HyperCluster
HyperCluster Demo 1920x720!
driverGetPrecompiledProgram() -> failed to load shader program!
Start time of demo: 3039 ms
Frame Time: 15.600000 ms
Frame Time: 16.650000 ms
Frame Time: 16.666666 ms
  • Hi Expert,
    customers want to know why there is errors print, and normally the Altia app can display within 1.6s. but now it need 3s.
    BR,
    Biao
  • Hi Biao,
    Please replace the HyperCluster binary with the attached binary.
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/6874.out.7z
    Suren
  • Hi
    I use 6874.out.7z , but  There is same errors
    there is log  you can check it
    Start time of demo: 3016 ms
    Frame Time: 15.333333 ms
    Frame Time: 14.183333 ms
    Frame Time: 16.383333 ms
    I use SDK  SDK version is 11_01_05_03
    SUI
  • Hi Pengfei,
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/TI_5F00_AM62pxx_5F00_HyperCluster_2D00_1920x720_5F00_demo_2D00_latest.7z
    There is a build folder in the zip file. Please modify the Makefile to use the 11.1 SDK sysroot to compile and generate the newer binaries.
    Let me know how it goes.
    Suren
  • Hi
    Now I use TI_AM62pxx_HyperCluster-1920x720_demo-latest.7z  and rebuild it in my 11.1 SDK sysroot , generate the newer binaries
    there is build log , you can check it
    [linux-devkit]:~/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03> cd TI_AM62pxx_HyperCluster-1920x720_demo-latest/
    [linux-devkit]:~/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/TI_AM62pxx_HyperCluster-1920x720_demo-latest> ls
    build  out
    [linux-devkit]:~/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/TI_AM62pxx_HyperCluster-1920x720_demo-latest> cd build/
    [linux-devkit]:~/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/TI_AM62pxx_HyperCluster-1920x720_demo-latest/build> ls
    13030201.o    246123d.sdf   39a504d9.o    59f20481.sdf  6f9d01aa.o    72ec01f7.sdf  91860207.o    a4ab1030.sdf  b84e01b0.o    cb260de9.sdf  e27404a0.o    f8460ca1.sdf  shader_binary.c
    13030201.sdf  369522c6.o    39a504d9.sdf  62390387.o    6f9d01aa.sdf  7b490168.o    91860207.sdf  aca604f8.o    b84e01b0.sdf  ccb037f.o     e27404a0.sdf  f8611205.o    shader_binary.o
    154c01ac.o    369522c6.sdf  3a15070d.o    62390387.sdf  70680ded.o    7b490168.sdf  95910212.o    aca604f8.sdf  be080207.o    ccb037f.sdf   e8b805d4.o    f8611205.sdf
    154c01ac.sdf  3762096a.o    3a15070d.sdf  6cda0283.o    70680ded.sdf  8bff01b0.o    95910212.sdf  b45e0500.o    be080207.sdf  d29004da.o    e8b805d4.sdf  main.c
    21140319.o    3762096a.sdf  549b03e0.o    6cda0283.sdf  720e01cc.o    8bff01b0.sdf  9ff81222.o    b45e0500.sdf  c05204f3.o    d29004da.sdf  f15b00e7.o    main.o
    21140319.sdf  390804e2.o    549b03e0.sdf  6f150584.o    720e01cc.sdf  910403be.o    9ff81222.sdf  b6950682.o    c05204f3.sdf  d2f4019c.o    f15b00e7.sdf  Makefile
    246123d.o     390804e2.sdf  59f20481.o    6f150584.sdf  72ec01f7.o    910403be.sdf  a4ab1030.o    b6950682.sdf  cb260de9.o    d2f4019c.sdf  f8460ca1.o    output.map
    [linux-devkit]:~/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/TI_AM62pxx_HyperCluster-1920x720_demo-latest/build> make clean
    13030201.sdf  369522c6.sdf  3a15070d.sdf  6cda0283.sdf  720e01cc.sdf  910403be.sdf  a4ab1030.sdf  b84e01b0.sdf  ccb037f.sdf   e8b805d4.sdf  main.c
    154c01ac.sdf  3762096a.sdf  549b03e0.sdf  6f150584.sdf  72ec01f7.sdf  91860207.sdf  aca604f8.sdf  be080207.sdf  d29004da.sdf  f15b00e7.sdf  Makefile
    21140319.sdf  390804e2.sdf  59f20481.sdf  6f9d01aa.sdf  7b490168.sdf  95910212.sdf  b45e0500.sdf  c05204f3.sdf  d2f4019c.sdf  f8460ca1.sdf  output.map
    246123d.sdf   39a504d9.sdf  62390387.sdf  70680ded.sdf  8bff01b0.sdf  9ff81222.sdf  b6950682.sdf  cb260de9.sdf  e27404a0.sdf  f8611205.sdf  shader_binary.c
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-gcc  --sysroot=/home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/aarch64-oe-linux -c -o main.o main.c -DEGL_NO_X11 -DGLPROGRAMBINARY=0x9130 -DGL_GLEXT_PROTOTYPES  -DALTIAUNICODEAPI -DUNICODE -D_UNICODE -I../include -I../out/include/api/float -I../out/include -DDEEPSCREEN
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 13030201.o 13030201.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 154c01ac.o 154c01ac.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 21140319.o 21140319.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 246123d.o 246123d.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 369522c6.o 369522c6.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 3762096a.o 3762096a.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 390804e2.o 390804e2.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 39a504d9.o 39a504d9.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 3a15070d.o 3a15070d.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 549b03e0.o 549b03e0.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 59f20481.o 59f20481.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 62390387.o 62390387.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 6cda0283.o 6cda0283.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 6f150584.o 6f150584.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 6f9d01aa.o 6f9d01aa.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 70680ded.o 70680ded.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 720e01cc.o 720e01cc.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 72ec01f7.o 72ec01f7.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 7b490168.o 7b490168.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 8bff01b0.o 8bff01b0.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 910403be.o 910403be.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 91860207.o 91860207.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 95910212.o 95910212.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o 9ff81222.o 9ff81222.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o a4ab1030.o a4ab1030.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o aca604f8.o aca604f8.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o b45e0500.o b45e0500.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o b6950682.o b6950682.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o b84e01b0.o b84e01b0.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o be080207.o be080207.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o c05204f3.o c05204f3.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o cb260de9.o cb260de9.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o ccb037f.o ccb037f.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o d29004da.o d29004da.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o d2f4019c.o d2f4019c.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o e27404a0.o e27404a0.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o e8b805d4.o e8b805d4.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o f15b00e7.o f15b00e7.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o f8460ca1.o f8460ca1.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-ld -r -b binary -o f8611205.o f8611205.sdf
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-gcc  --sysroot=/home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/aarch64-oe-linux -c -o shader_binary.o shader_binary.c -DEGL_NO_X11 -DGLPROGRAMBINARY=0x9130 -DGL_GLEXT_PROTOTYPES  -DALTIAUNICODEAPI -DUNICODE -D_UNICODE -I../include -I../out/include/api/float -I../out/include -DDEEPSCREEN
    /home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-g++  --sysroot=/home/tisdk/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/linux-devkit/sysroots/aarch64-oe-linux -o ../out/HyperCluster main.o 13030201.o 154c01ac.o 21140319.o 246123d.o 369522c6.o 3762096a.o 390804e2.o 39a504d9.o 3a15070d.o 549b03e0.o 59f20481.o 62390387.o 6cda0283.o 6f150584.o 6f9d01aa.o 70680ded.o 720e01cc.o 72ec01f7.o 7b490168.o 8bff01b0.o 910403be.o 91860207.o 95910212.o 9ff81222.o a4ab1030.o aca604f8.o b45e0500.o b6950682.o b84e01b0.o be080207.o c05204f3.o cb260de9.o ccb037f.o d29004da.o d2f4019c.o e27404a0.o e8b805d4.o f15b00e7.o f8460ca1.o f8611205.o shader_binary.o ../out/libs/api/float/libaltiaAPIlibfloat.a ../out/libs/libaltiaWinLib.a ../out/libs/libaltiaPort.a -lpthread -lGLESv2 -lEGL -lgbm -ldrm -lpng -lz -lm -Xlinker -Map=output.map
    Done.
    Done.
    [linux-devkit]:~/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/TI_AM62pxx_HyperCluster-1920x720_demo-latest/build> cd ../
    build  out
    [linux-devkit]:~/ti-processor-sdk-linux-am62pxx-evm-11.01.05.03/TI_AM62pxx_HyperCluster-1920x720_demo-latest> tar -czvf out.tar.gz out/
    Then I run it in  AM62P SKEVM  board
    there some errors , there is the run log , you can check it
    root@am62pxx-evm:/usr/bin# cd altia-hmi/
    root@am62pxx-evm:/usr/bin/altia-hmi# ls
    HyperCluster  reflash
    Start time of demo: 3033 ms
    Frame Time: 14.483334 ms
    ^C
    root@am62pxx-evm:/usr/bin/altia-hmi# ^C
    SUI
    I have been able to reproduce the issue. Please allow me a day or two to respond back. Checking with Altia on the issue.
    Suren
    Please use the below package to compile with 11.1 SDK:
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/TI_5F00_AM62pxx_5F00_HyperCluster_2D00_1920x720_5F00_demo_5F00_buildInShaders_5F00_SDK11.01.7z
    Extract and you should see build folder.
    Issue the below commands.
    make clean
    make -f Makefile_buildshaders
    make
    Copy the contents of the out folder on /usr/bin directory on the rootfs and run ./Hypercluster.
    Hope this helps
    Suren
  • Hi
    I use the new code
    reslove my issue
    Now there is no  failed to load shader program!
    There are the altia  boot log
    root@am62pxx-evm:/out# ./HyperCluster
    Start time of demo: 435 ms
    Frame Time: 13.733334 ms
    Thank you
