Hi ,
Gstremer and tiovxmosaic is supporting different resolution inputs.
when using gst_wrapper function , it has only one input resolution parameter for all channel inputs.
in gst_wrapper.c file, plane size for all channels are configured as below.
int32_t appGstSrcInit(void* data_ptr[CODEC_MAX_BUFFER_DEPTH][CODEC_MAX_NUM_CHANNELS][CODEC_MAX_NUM_PLANES])
int32_t status = 0;
GstCaps* caps = NULL;
app_gst_wrapper_obj_t* p_gst_pipe_obj = &g_app_gst_wrapper_obj;
uint32_t plane_size = p_gst_pipe_obj->params.in_width * p_gst_pipe_obj->params.in_height;
/* Setup AppSrc Elements */
for (uint8_t ch = 0; ch < p_gst_pipe_obj->params.in_num_channels; ch++)
p_gst_pipe_obj->m_srcElemArr[ch] = findElementByName(p_gst_pipe_obj->m_pipeline,
p_gst_pipe_obj->params.m_AppSrcNameArr[ch]);
if (p_gst_pipe_obj->m_srcElemArr[ch] == NULL)
printf("gst_wrapper: findElementByName() FAILED! %s not found\n", p_gst_pipe_obj->params.m_AppSrcNameArr[ch]);
status = -1;
else
p_gst_pipe_obj->isAppSrc = GST_IS_APP_SRC(p_gst_pipe_obj->m_srcElemArr[ch]);
if (p_gst_pipe_obj->isAppSrc)
caps = gst_caps_new_simple("video/x-raw",
"width", G_TYPE_INT, p_gst_pipe_obj->params.in_width,
"height", G_TYPE_INT, p_gst_pipe_obj->params.in_height,
"format", G_TYPE_STRING, p_gst_pipe_obj->params.in_format,
NULL);
if (caps == NULL)
printf("gst_wrapper: gst_caps_new_simple() FAILED!\n");
status = -1;
gst_app_src_set_caps (GST_APP_SRC(p_gst_pipe_obj->m_srcElemArr[ch]), caps);
gst_caps_unref (caps);
else
printf("gst_wrapper: %s not an AppSrc element\n", p_gst_pipe_obj->params.m_AppSrcNameArr[ch]);
status = -1;
/* Setup GstBuffers to push to AppSrc Elements using given data_ptrs */
if (status==0)
for (uint8_t idx = 0; idx < p_gst_pipe_obj->params.in_buffer_depth && status==0; idx++)
for (uint8_t ch = 0; ch < p_gst_pipe_obj->params.in_num_channels && status==0; ch++)
p_gst_pipe_obj->buff[idx][ch] = gst_buffer_new();
p_gst_pipe_obj->mem[idx][ch][0] = gst_memory_new_wrapped (0, data_ptr[idx][ch][0], plane_size, 0, plane_size, NULL, NULL);
p_gst_pipe_obj->mem[idx][ch][1] = gst_memory_new_wrapped (0, data_ptr[idx][ch][1], plane_size/2, 0, plane_size/2, NULL, NULL);
gst_buffer_append_memory (p_gst_pipe_obj->buff[idx][ch], p_gst_pipe_obj->mem[idx][ch][0]);
gst_buffer_append_memory (p_gst_pipe_obj->buff[idx][ch], p_gst_pipe_obj->mem[idx][ch][1]);
p_gst_pipe_obj->mem[idx][ch][0] = gst_buffer_get_memory (p_gst_pipe_obj->buff[idx][ch], 0);
p_gst_pipe_obj->mem[idx][ch][1] = gst_buffer_get_memory (p_gst_pipe_obj->buff[idx][ch], 1);
gst_memory_map(p_gst_pipe_obj->mem[idx][ch][0],&p_gst_pipe_obj->map_info[idx][ch][0], GST_MAP_WRITE);
gst_memory_map(p_gst_pipe_obj->mem[idx][ch][1],&p_gst_pipe_obj->map_info[idx][ch][1], GST_MAP_WRITE);
if (status==0) p_gst_pipe_obj->push_count = 0;
return status;
as the above functions will support for single input resolutions for different channels of appsrc's , Please clarify how to proceed further if input resolutions are different for each channels of appsrc..
