TDA4VM: Access to On-the-fly eye curve diagramming data
Part Number: TDA4VM
Hi TI,
I have to  evaluate the signal integrity for LPDDR4 interface by using the supported On-the-fly eye curve diagramming data.
In the past TI provide a beta tool for LPDDR.
Link to e2e: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1085977/tda4vm-access-to-on-the-fly-eye-and-bathtub-curve-diagramming-data?ReplyFilter=Answers&ReplySortBy=Answers&ReplySortOrder=Descending
Is there any updated version of the tool exist?
Looking forward to hearing back from you.
Hasan
    We have moved the tool to a GUI composer application that runs from the web. If you are looking to integrate with PDK as it appears you were trying to do previously, that will not be supported with the new version and you will need to use what you had previously.
    Kevin
  • Hi Kevin,
    When I was using the ddr tools to generate the eye diagram from the logs collected, the tool is providing me error ("Illegal divison by 0").
    I have changed anything in the tool for logs.
    I am using the following configurations:
    vref_step_size = 4;
    dly_step_size = 16;
    How to get rid of this error?
    Hasan
  • Please provide the log file so that we can see if we can replicate the issue on our end.
    Kevin
  • Hi Kevin,
    Here are the logs:
    Jacinto7 DDRSS Tools
    Supported SOCs: J721E, J7200
    Revision: Beta Release - September 2020
    DDRSS Instance: 16
    0��A
            DRAM Type: LPDDR4
            Bus Width: 12
    32�A
            Rank Count: 13
    12�A
    Margin Analysis Input:
            Eye Type (Select '19' for read, '1' for write): 0' for read, '13' for write): 1' for write):
            Eye Precision (VREF / DLL Step Size; impacts test time):
                    VREF Step Size (enter decimal value; min value is 2):
                    Delay Step Size (enter decimal value; min value is 8):
            Pattern: wc_isi_sso
            Transfer Size (bytes): 24
    487872
    eye_type=write
    mr14_f6_cs0: 0x00000000
    0_cs3: 0x40a00000
    0: 0x00000004
    00000000
    mr14_f6_cs1: 0x00000000
    00000000_cs3: 0x40a00000
    10000000: 0x00000004
    00000000
    mr14_f6_cs2: 0x00000000
    20000000: 0x00000004
    00000000
    mr14_f6_cs3: 0x00000000
    30000000: 0x00000004
    00000000
    mr14_f6_cs0: 0x00000020
    10000000_cs3: 0x40a00000
    00000000: 0x00000004
    00000020
    mr14_f6_cs1: 0x00000021
    10000020_cs3: 0x40a00000
    10000020: 0x00000004
    00000021
    mr14_f6_cs2: 0x00000026
    10000021_cs3: 0x40a00000
    20000021: 0x00000004
    00000026
    mr14_f6_cs3: 0x00000021
    10000026_cs3: 0x40a00000
    30000026: 0x00000004
    00000021
    20000021_cs3: 0x40a00000
    00000021: 0x00000004
    00000020
    20000020_cs3: 0x40a00000
    00000021
    mr14_f6_cs2: 0x00000025
    00000025
    20000025_cs3: 0x40a00000
    30000025: 0x00000004
    00000021
    write_delay, f14_cs0_dq0 : 0x0
    10000021_cs3_dq1084227584 : 0x3
    00000021_dq3 : 0x40a00000
    00000021 : 0x5
    44800021
    write_delay, f14_cs0_dq1 : 0x0
    14800021_cs3_dq1084227584 : 0x3
    04800021_dq3 : 0x40a00000
    14800021 : 0x5
    44800021
    write_delay, f14_cs0_dq2 : 0x0
    24800021 : 0x5
    44800021
    write_delay, f14_cs0_dq3 : 0x0
    34800021 : 0x5
    44000021
    write_delay, f14_cs0_dq4 : 0x0
    14000021_cs3_dq1084227584 : 0x3
    04000021_dq3 : 0x40a00000
    44000021 : 0x5
    44800021
    write_delay, f14_cs0_dq5 : 0x0
    54800021 : 0x5
    44800021
    write_delay, f14_cs0_dq6 : 0x0
    64800021 : 0x5
    44000021
    write_delay, f14_cs0_dq7 : 0x0
    74000021 : 0x5
    44000021
    write_delay, f14_cs0_dq8 : 0x0
    84000021 : 0x5
    43600021
    write_delay, f14_cs0_dq9 : 0x0
    13600021_cs3_dq1084227584 : 0x3
    03600021_dq3 : 0x40a00000
    93600021 : 0x5
    43d00021
    write_delay, f14_cs0_dq10 : 0x0
    13d00021_cs3_dq1084227584 : 0x3
    03d00021_dq3 : 0x40a00000
    10d00021 : 0x5
    43d00021
    write_delay, f14_cs0_dq11 : 0x0
    11d00021 : 0x5
    44500021
    write_delay, f14_cs0_dq12 : 0x0
    14500021_cs3_dq1084227584 : 0x3
    04500021_dq3 : 0x40a00000
    12500021 : 0x5
    43d00021
    write_delay, f14_cs0_dq13 : 0x0
    13d00021 : 0x5
    43d00021
    write_delay, f14_cs0_dq14 : 0x0
    14d00021 : 0x5
    43600021
    write_delay, f14_cs0_dq15 : 0x0
    15600021 : 0x5
    43d00021
    write_delay, f14_cs0_dq16 : 0x0
    16d00021 : 0x5
    43d00021
    write_delay, f14_cs0_dq17 : 0x0
    17d00021 : 0x5
    43600021
    write_delay, f14_cs0_dq18 : 0x0
    18600021 : 0x5
    43d00021
    write_delay, f14_cs0_dq19 : 0x0
    19d00021 : 0x5
    43600021
    write_delay, f14_cs0_dq20 : 0x0
    20600021 : 0x5
    43600021
    write_delay, f14_cs0_dq21 : 0x0
    21600021 : 0x5
    43600021
    write_delay, f14_cs0_dq22 : 0x0
    22600021 : 0x5
    42e00021
    write_delay, f14_cs0_dq23 : 0x0
    12e00021_cs3_dq1084227584 : 0x3
    02e00021_dq3 : 0x40a00000
    23e00021 : 0x5
    42e00021
    write_delay, f14_cs0_dq24 : 0x0
    24e00021 : 0x5
    44b00021
    write_delay, f14_cs0_dq25 : 0x0
    14b00021_cs3_dq1084227584 : 0x3
    04b00021_dq3 : 0x40a00000
    25b00021 : 0x5
    42d00021
    write_delay, f14_cs0_dq26 : 0x0
    12d00021_cs3_dq1084227584 : 0x3
    02d00021_dq3 : 0x40a00000
    26d00021 : 0x5
    43c00021
    write_delay, f14_cs0_dq27 : 0x0
    13c00021_cs3_dq1084227584 : 0x3
    03c00021_dq3 : 0x40a00000
    27c00021 : 0x5
    45300021
    write_delay, f14_cs0_dq28 : 0x0
    15300021_cs3_dq1084227584 : 0x3
    05300021_dq3 : 0x40a00000
    28300021 : 0x5
    44b00021
    write_delay, f14_cs0_dq29 : 0x0
    29b00021 : 0x5
    45300021
    write_delay, f14_cs0_dq30 : 0x0
    30300021 : 0x5
    43c00021
    write_delay, f14_cs0_dq31 : 0x0
    31c00021 : 0x5
    44400021
    24400021_cs3_dq1084227584 : 0x3
    04400021_dq3 : 0x40a00000
    04400021 : 0x5
    44800021
    24800021_cs3_dq1084227584 : 0x3
    14800021 : 0x5
    44800021
    24800021 : 0x5
    44800021
    34800021 : 0x5
    44800021
    44800021 : 0x5
    44800021
    54800021 : 0x5
    44800021
    64800021 : 0x5
    44000021
    24000021_cs3_dq1084227584 : 0x3
    74000021 : 0x5
    44000021
    84000021 : 0x5
    43600021
    23600021_cs3_dq1084227584 : 0x3
    93600021 : 0x5
    44500021
    24500021_cs3_dq1084227584 : 0x3
    10500021 : 0x5
    43d00021
    23d00021_cs3_dq1084227584 : 0x3
    11d00021 : 0x5
    44500021
    12500021 : 0x5
    43d00021
    13d00021 : 0x5
    44500021
    14500021 : 0x5
    43600021
    15600021 : 0x5
    43d00021
    16d00021 : 0x5
    43d00021
    17d00021 : 0x5
    43600021
    18600021 : 0x5
    43600021
    19600021 : 0x5
    43600021
    20600021 : 0x5
    43600021
    21600021 : 0x5
    43600021
    22600021 : 0x5
    42e00021
    22e00021_cs3_dq1084227584 : 0x3
    23e00021 : 0x5
    42e00021
    24e00021 : 0x5
    43d00021
    25d00021 : 0x5
    42e00021
    26e00021 : 0x5
    42e00021
    27e00021 : 0x5
    43d00021
    28d00021 : 0x5
    43d00021
    29d00021 : 0x5
    43d00021
    30d00021 : 0x5
    42e00021
    31e00021 : 0x5
    43600021
    vref=5
    0
    wrdly=6
    829
    Hasan
  • That log looks completely invalid (nothing looks normal about it). For instance,
    • DDR instance cannot be 16, bus width cannot be 12, rank count cannot be 13.
    • I don't see any inputs for eye type, etc.
    • transfer size of 24 is not correct
    • output / formatting of trained values looks completely wrong
    • I don't see any actual data
    There should be a sample log illustrating how the output log should look.
    Also, can you please sync up with your colleague   who I believe was able to successfully use the tool?
    Kevin
  • Hi Kevin,
    I fixed the issues and the updates logs are as follows:
    DDRSS Instance: 0
            DRAM Type: LPDDR4
            Bus Width: 16
            Rank Count: 1
            Eye Type (Select '0' for read, '1' for write): 0
                    VREF Step Size (enter decimal value; min value is 2): 4
                    Delay Step Size (enter decimal value; min value is 8): 16
            Pattern: wc_isi_sso
            Transfer Size (bytes): 243936
    eye_type=read
    phy_vref_f1_bl0: 0x1f
    phy_vref_f1_bl1: 0x1f
    read_delay_fall, f1_cs0_dq0 : 0x84
    read_delay_rise, f1_cs0_dq0 : 0x8a
    read_delay_fall, f1_cs0_dq1 : 0x8a
    read_delay_rise, f1_cs0_dq1 : 0x84
    read_delay_fall, f1_cs0_dq2 : 0x84
    read_delay_rise, f1_cs0_dq2 : 0x8a
    read_delay_fall, f1_cs0_dq3 : 0x8a
    read_delay_rise, f1_cs0_dq3 : 0x8a
    read_delay_fall, f1_cs0_dq4 : 0x7e
    read_delay_rise, f1_cs0_dq4 : 0x84
    read_delay_fall, f1_cs0_dq5 : 0x84
    read_delay_rise, f1_cs0_dq5 : 0x8a
    read_delay_fall, f1_cs0_dq6 : 0x7e
    read_delay_rise, f1_cs0_dq6 : 0x7e
    read_delay_fall, f1_cs0_dq7 : 0x8a
    read_delay_rise, f1_cs0_dq7 : 0x8a
    read_delay_fall, f1_cs0_dq8 : 0x7e
    read_delay_rise, f1_cs0_dq8 : 0x7e
    read_delay_fall, f1_cs0_dq9 : 0x7e
    read_delay_rise, f1_cs0_dq9 : 0x7e
    read_delay_fall, f1_cs0_dq10 : 0x72
    read_delay_rise, f1_cs0_dq10 : 0x72
    read_delay_fall, f1_cs0_dq11 : 0x84
    read_delay_rise, f1_cs0_dq11 : 0x7e
    read_delay_fall, f1_cs0_dq12 : 0x7e
    read_delay_rise, f1_cs0_dq12 : 0x7e
    read_delay_fall, f1_cs0_dq13 : 0x84
    read_delay_rise, f1_cs0_dq13 : 0x7e
    read_delay_fall, f1_cs0_dq14 : 0x7e
    read_delay_rise, f1_cs0_dq14 : 0x7e
    read_delay_fall, f1_cs0_dq15 : 0x8a
    read_delay_rise, f1_cs0_dq15 : 0x8a
    phy_vref_f2_bl0: 0x1e
    phy_vref_f2_bl1: 0x1f
    read_delay_fall, f2_cs0_dq0 : 0x84
    read_delay_rise, f2_cs0_dq0 : 0x8a
    read_delay_fall, f2_cs0_dq1 : 0x84
    read_delay_rise, f2_cs0_dq1 : 0x7e
    read_delay_fall, f2_cs0_dq2 : 0x7e
    read_delay_rise, f2_cs0_dq2 : 0x8a
    read_delay_fall, f2_cs0_dq3 : 0x8a
    read_delay_rise, f2_cs0_dq3 : 0x8a
    read_delay_fall, f2_cs0_dq4 : 0x78
    read_delay_rise, f2_cs0_dq4 : 0x84
    read_delay_fall, f2_cs0_dq5 : 0x84
    read_delay_rise, f2_cs0_dq5 : 0x8a
    read_delay_fall, f2_cs0_dq6 : 0x7e
    read_delay_rise, f2_cs0_dq6 : 0x7e
    read_delay_fall, f2_cs0_dq7 : 0x8a
    read_delay_rise, f2_cs0_dq7 : 0x90
    read_delay_fall, f2_cs0_dq8 : 0x7e
    read_delay_rise, f2_cs0_dq8 : 0x7e
    read_delay_fall, f2_cs0_dq9 : 0x7e
    read_delay_rise, f2_cs0_dq9 : 0x7e
    read_delay_fall, f2_cs0_dq10 : 0x72
    read_delay_rise, f2_cs0_dq10 : 0x72
    read_delay_fall, f2_cs0_dq11 : 0x84
    read_delay_rise, f2_cs0_dq11 : 0x7e
    read_delay_fall, f2_cs0_dq12 : 0x7e
    read_delay_rise, f2_cs0_dq12 : 0x7e
    read_delay_fall, f2_cs0_dq13 : 0x84
    read_delay_rise, f2_cs0_dq13 : 0x7e
    read_delay_fall, f2_cs0_dq14 : 0x84
    read_delay_rise, f2_cs0_dq14 : 0x7e
    read_delay_fall, f2_cs0_dq15 : 0x8a
    read_delay_rise, f2_cs0_dq15 : 0x8a
    vref=0
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=4
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=8
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=12
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=16
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=20
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=24
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=28
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=32
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=36
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=40
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=44
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=48
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=52
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=56
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=60
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=64
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=68
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=72
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=76
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=80
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=84
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=88
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=92
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=96
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=100
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=104
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=108
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    vref=112
    rddly=0
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=16
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=32
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=48
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=64
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=80
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=96
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=112
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=128
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=144
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=160
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=176
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=192
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=208
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=224
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=240
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=256
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=272
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=288
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=304
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    rddly=320
    dqs_edge=0
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    30096
    dqs_edge=1
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    29568
    Error:
    C:\path\to\the \folder>perl jacinto7_ddrss_tools_marginAnalysis.pl teraterm.txt
    Processing input file teraterm.txt and converting to csv format
    Formatting the margin analysis output for dq_bit 15
    Illegal division by zero at jacinto7_ddrss_tools_marginAnalysis.pl line 132, <IN> line 21431.
    Hasan
    Regarding Perl Script Error
    There seems to be a lot of trailing white space on each line, and the trailing white space seems to be causing issues with the perl script (causing the error you have observed). I removed this trailing white space (attached below) and the error no longer occurs. You can diff the attached file below to compare to your existing file.
    tda4x_eye_tool_debug_log.txt
    Other Observations
    Although the perl script completes , it appears the DDR interface is non-functional as there is no passing region.
    Kevin
  • Hi Kevin,
    There was some issue in capturing the uart log, I fixed it.
    DDR memory connected to our target is initialized and using using the debugger I can read/write to it.
    Now, when I run the jacinto7_ddrss_tools_lp4_read_margin() function from the tool, it gives data abort exception after reading some amount of data from DDR and copying it the buf_result.
    Are the RAT configurations shown above correct for the DDR Tool?
    Looking forward to hearing back from you.
    Hasan
  • Hi TI,
    I am waiting for an update on the ticket.
    Thanks.
    Hasan
  • Hi TI,
    TI Tool (jacinto7_ddrss_tools_beta) is integrated in the developing environment for the extraction of on-chip measurement to create eye diagrams of LPDDR4 interface.
    The following observations are observed:
    1. Without TI Tool, the data can be read/write across DDR.
    2. WIth TI Tool, the data can be written to DDR but while reading data from DRR, TI tool is showing data abort errors.
    The screenshots are attached for reference.
    #   Starting Bootloader   #
    DrvQspi/QspiFlash Init: OK
    Loaded SYSFW from 0x00180000
    Board configuration:
    * PinMux: OK
    * PLL: OK
    * Clock Manager: OK
    * Power Manager: OK
    * DDR Init: OK
    DrvUDma Init: OK
    DrvGtc Init: OK
    DrvGpio Init: OK
    Jacinto7 DDRSS Tools
    Supported SOCs: J721E, J7200
    Revision: Beta Release - September 2020
    DDRSS Instance: 0
    	DRAM Type: LPDDR4
    	Bus Width: 32
    	Rank Count: 1
    Margin Analysis Input:
    	Eye Type (Select '0' for read, '1' for write): 0
    	Eye Precision (VREF / DLL Step Size; impacts test time):
    		VREF Step Size (enter decimal value; min value is 2): 4
    		Delay Step Size (enter decimal value; min value is 8): 16
    	Pattern: wc_isi_sso
    	Transfer Size (bytes): 487872
    eye_type=read
    phy_vref_f1_bl0: 0x1f
    phy_vref_f1_bl1: 0x21
    phy_vref_f1_bl2: 0x20
    phy_vref_f1_bl3: 0x20
    read_delay_fall, f1_cs0_dq0 : 0x7e
    read_delay_rise, f1_cs0_dq0 : 0x7e
    read_delay_fall, f1_cs0_dq1 : 0x8a
    read_delay_rise, f1_cs0_dq1 : 0x84
    read_delay_fall, f1_cs0_dq2 : 0x7e
    read_delay_rise, f1_cs0_dq2 : 0x84
    read_delay_fall, f1_cs0_dq3 : 0x8a
    read_delay_rise, f1_cs0_dq3 : 0x84
    read_delay_fall, f1_cs0_dq4 : 0x84
    read_delay_rise, f1_cs0_dq4 : 0x84
    read_delay_fall, f1_cs0_dq5 : 0x8a
    read_delay_rise, f1_cs0_dq5 : 0x84
    read_delay_fall, f1_cs0_dq6 : 0x7e
    read_delay_rise, f1_cs0_dq6 : 0x7e
    read_delay_fall, f1_cs0_dq7 : 0x8a
    read_delay_rise, f1_cs0_dq7 : 0x84
    read_delay_fall, f1_cs0_dq8 : 0x90
    read_delay_rise, f1_cs0_dq8 : 0x78
    read_delay_fall, f1_cs0_dq9 : 0x90
    read_delay_rise, f1_cs0_dq9 : 0x7e
    read_delay_fall, f1_cs0_dq10 : 0x8a
    read_delay_rise, f1_cs0_dq10 : 0x6c
    read_delay_fall, f1_cs0_dq11 : 0x90
    read_delay_rise, f1_cs0_dq11 : 0x72
    read_delay_fall, f1_cs0_dq12 : 0x8a
    read_delay_rise, f1_cs0_dq12 : 0x72
    read_delay_fall, f1_cs0_dq13 : 0x90
    read_delay_rise, f1_cs0_dq13 : 0x78
    read_delay_fall, f1_cs0_dq14 : 0x90
    read_delay_rise, f1_cs0_dq14 : 0x78
    read_delay_fall, f1_cs0_dq15 : 0x96
    read_delay_rise, f1_cs0_dq15 : 0x7e
    read_delay_fall, f1_cs0_dq16 : 0x90
    read_delay_rise, f1_cs0_dq16 : 0x78
    read_delay_fall, f1_cs0_dq17 : 0x96
    read_delay_rise, f1_cs0_dq17 : 0x7e
    read_delay_fall, f1_cs0_dq18 : 0x8a
    read_delay_rise, f1_cs0_dq18 : 0x78
    read_delay_fall, f1_cs0_dq19 : 0x90
    read_delay_rise, f1_cs0_dq19 : 0x7e
    read_delay_fall, f1_cs0_dq20 : 0x8a
    read_delay_rise, f1_cs0_dq20 : 0x78
    read_delay_fall, f1_cs0_dq21 : 0x8a
    read_delay_rise, f1_cs0_dq21 : 0x7e
    read_delay_fall, f1_cs0_dq22 : 0x8a
    read_delay_rise, f1_cs0_dq22 : 0x72
    read_delay_fall, f1_cs0_dq23 : 0x96
    read_delay_rise, f1_cs0_dq23 : 0x84
    read_delay_fall, f1_cs0_dq24 : 0x7e
    read_delay_rise, f1_cs0_dq24 : 0x60
    read_delay_fall, f1_cs0_dq25 : 0x7e
    read_delay_rise, f1_cs0_dq25 : 0x6c
    read_delay_fall, f1_cs0_dq26 : 0x7e
    read_delay_rise, f1_cs0_dq26 : 0x6c
    read_delay_fall, f1_cs0_dq27 : 0x84
    read_delay_rise, f1_cs0_dq27 : 0x6c
    read_delay_fall, f1_cs0_dq28 : 0x78
    read_delay_rise, f1_cs0_dq28 : 0x60
    read_delay_fall, f1_cs0_dq29 : 0x84
    read_delay_rise, f1_cs0_dq29 : 0x72
    read_delay_fall, f1_cs0_dq30 : 0x84
    read_delay_rise, f1_cs0_dq30 : 0x6c
    read_delay_fall, f1_cs0_dq31 : 0x90
    read_delay_rise, f1_cs0_dq31 : 0x78
    phy_vref_f2_bl0: 0x20
    phy_vref_f2_bl1: 0x21
    phy_vref_f2_bl2: 0x20
    phy_vref_f2_bl3: 0x1f
    read_delay_fall, f2_cs0_dq0 : 0x7e
    read_delay_rise, f2_cs0_dq0 : 0x7e
    read_delay_fall, f2_cs0_dq1 : 0x8a
    read_delay_rise, f2_cs0_dq1 : 0x84
    read_delay_fall, f2_cs0_dq2 : 0x8a
    read_delay_rise, f2_cs0_dq2 : 0x7e
    read_delay_fall, f2_cs0_dq3 : 0x8a
    read_delay_rise, f2_cs0_dq3 : 0x84
    read_delay_fall, f2_cs0_dq4 : 0x8a
    read_delay_rise, f2_cs0_dq4 : 0x84
    read_delay_fall, f2_cs0_dq5 : 0x8a
    read_delay_rise, f2_cs0_dq5 : 0x84
    read_delay_fall, f2_cs0_dq6 : 0x84
    read_delay_rise, f2_cs0_dq6 : 0x7e
    read_delay_fall, f2_cs0_dq7 : 0x8a
    read_delay_rise, f2_cs0_dq7 : 0x84
    read_delay_fall, f2_cs0_dq8 : 0x90
    read_delay_rise, f2_cs0_dq8 : 0x78
    read_delay_fall, f2_cs0_dq9 : 0x90
    read_delay_rise, f2_cs0_dq9 : 0x7e
    read_delay_fall, f2_cs0_dq10 : 0x8a
    read_delay_rise, f2_cs0_dq10 : 0x6c
    read_delay_fall, f2_cs0_dq11 : 0x90
    read_delay_rise, f2_cs0_dq11 : 0x78
    read_delay_fall, f2_cs0_dq12 : 0x8a
    read_delay_rise, f2_cs0_dq12 : 0x72
    read_delay_fall, f2_cs0_dq13 : 0x90
    read_delay_rise, f2_cs0_dq13 : 0x78
    read_delay_fall, f2_cs0_dq14 : 0x90
    read_delay_rise, f2_cs0_dq14 : 0x78
    read_delay_fall, f2_cs0_dq15 : 0x96
    read_delay_rise, f2_cs0_dq15 : 0x7e
    read_delay_fall, f2_cs0_dq16 : 0x90
    read_delay_rise, f2_cs0_dq16 : 0x78
    read_delay_fall, f2_cs0_dq17 : 0x96
    read_delay_rise, f2_cs0_dq17 : 0x84
    read_delay_fall, f2_cs0_dq18 : 0x8a
    read_delay_rise, f2_cs0_dq18 : 0x78
    read_delay_fall, f2_cs0_dq19 : 0x9c
    read_delay_rise, f2_cs0_dq19 : 0x7e
    read_delay_fall, f2_cs0_dq20 : 0x8a
    read_delay_rise, f2_cs0_dq20 : 0x78
    read_delay_fall, f2_cs0_dq21 : 0x8a
    read_delay_rise, f2_cs0_dq21 : 0x7e
    read_delay_fall, f2_cs0_dq22 : 0x8a
    read_delay_rise, f2_cs0_dq22 : 0x72
    read_delay_fall, f2_cs0_dq23 : 0x96
    read_delay_rise, f2_cs0_dq23 : 0x84
    read_delay_fall, f2_cs0_dq24 : 0x7e
    read_delay_rise, f2_cs0_dq24 : 0x60
    read_delay_fall, f2_cs0_dq25 : 0x7e
    read_delay_rise, f2_cs0_dq25 : 0x6c
    read_delay_fall, f2_cs0_dq26 : 0x7e
    read_delay_rise, f2_cs0_dq26 : 0x6c
    read_delay_fall, f2_cs0_dq27 : 0x84
    read_delay_rise, f2_cs0_dq27 : 0x6c
    read_delay_fall, f2_cs0_dq28 : 0x78
    read_delay_rise, f2_cs0_dq28 : 0x60
    read_delay_fall, f2_cs0_dq29 : 0x84
    read_delay_rise, f2_cs0_dq29 : 0x72
    read_delay_fall, f2_cs0_dq30 : 0x84
    read_delay_rise, f2_cs0_dq30 : 0x6c
    read_delay_fall, f2_cs0_dq31 : 0x90
    read_delay_rise, f2_cs0_dq31 : 0x78
    vref=0
    rddly=0
    Hasan
  • Hi Kevin,
    We have moved the tool to a GUI composer application that runs from the web.
    Also,
    can you tell me about this updated tool? We are not using PDK anymore. We have our own software and there we will try to integrate the TI tool.
    Hasan
  • Hi Hasan,
    I think that the tool kevin refers to is the below one:
    https://dev.ti.com/gallery/view/ProcessorTools/processors_ddr_margin_analysis_tool/ver/1.0.0/
    May be the the below App note at section 3 can help as well to check the DDR controller register config:
         Board bring up  https://www.ti.com/lit/pdf/spradc5
    Since your previous HW board version was passing the DDR test it could make sense to check about the context and what has changed between the two boards (is it the same DDR memory model and revision, delta PCB change compare to previous PCB, TDA4VM silcon rev SR2.0 or SR1.1, ..etc)?
    Anthony
