The kernel is being interrupted by the bootloader while intilializing the drivers.
The kernel cannot load at all since the BL is interrupting it and restarting the whole boot process endlessly.
I tried disabling the driver cdns-mhdp8546 which show initialization issues, but still shows up in the logs.
Sometimes it reaches systemd initialization but still gets interrupted. Can this be a ROM bootloader issue ?
Here is a discussion about this topic.
U-Boot 2024.10-00001-gbf0e9d0b7274 (Nov 14 2024 - 23:19:39 +0000)
SoC: J721E SR1.1 GP
Model: BeagleBoard.org BeagleBone AI-64
DRAM: 2 GiB (effective 4 GiB)
Core: 128 devices, 33 uclasses, devicetree: separate
MMC: mmc@4f80000: 0, mmc@4fb0000: 1
Loading Environment from nowhere... OK
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293901
Net: Could not get PHY for mdio@f00: addr 0
am65_cpsw_nuss_port ethernet@46000000port@1: phy_connect() failed
No ethernet found.
Press SPACE to abort autoboot in 2 seconds
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'uEnv.txt'
Scanning for bootflows in all bootdevs
Seq Method State Uclass Part Name Filename
Scanning bootdev 'mmc@4fb0000.bootdev':
0 efi ready mmc 1 mmc@4fb0000.bootdev.part_ /EFI/BOOT/BOOTAA64.EFI
** Booting bootflow 'mmc@4fb0000.bootdev.part_1' with efi
No EFI system partition
Failed to persist EFI variables
am65_cpsw_nuss_port ethernet@46000000ethernet@46000: phy_connect() failed
Booting /\EFI\BOOT\BOOTAA64.EFI
error: no such device: ((hd0,msdos1)/EFI/BOOT)/EFI/BOOT/grub.cfg.
error: serial port `com0' isn't found.
GNU GRUB version 2.12
│*boot │
Use the ▲ and ▼ keys to select which entry is highlighted.
Press enter to boot the selected OS, `e' to edit the commands before booting or `c' for a
command-line.
The highlighted entry will be executed automatically in 0s.
Booting `boot'
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 6.6.58-ti (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 13.3.0, GNU ld (4
[ 0.000000] Machine model: BeagleBoard.org BeagleBone AI-64
[ 0.000000] efi: EFI v2.10 by Das U-Boot
[ 0.000000] efi: ESRT=0xfce48040 RTPROP=0xfce4a040 SMBIOS 3.0=0xfdeb2000 MEMRESERVE=0xfcd66040
[ 0.000000] esrt: Reserving ESRT space from 0x00000000fce48040 to 0x00000000fce480f0.
[ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable 0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable r0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable 0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable r0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable 0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable r0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a2ffffff (15360 KiB) nomap non-reusable 0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000a30fffff (1024 KiB) nomap non-reusable r0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a3100000..0x00000000a3ffffff (15360 KiB) nomap non-reusable 0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a40fffff (1024 KiB) nomap non-reusable r0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a4100000..0x00000000a4ffffff (15360 KiB) nomap non-reusable 0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a5000000..0x00000000a50fffff (1024 KiB) nomap non-reusable r0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a5100000..0x00000000a5ffffff (15360 KiB) nomap non-reusable 0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a6000000..0x00000000a60fffff (1024 KiB) nomap non-reusable c0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a6100000..0x00000000a6ffffff (15360 KiB) nomap non-reusable 0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a7000000..0x00000000a70fffff (1024 KiB) nomap non-reusable c0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a7100000..0x00000000a7ffffff (15360 KiB) nomap non-reusable 0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a8000000..0x00000000a80fffff (1024 KiB) nomap non-reusable c0
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a8100000..0x00000000a8ffffff (15360 KiB) nomap non-reusable 0
[ 0.000000] OF: reserved mem: 0x00000000aa000000..0x00000000abbfffff (28672 KiB) nomap non-reusable 0
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a8ffffff]
[ 0.000000] node 0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[ 0.000000] node 0: [mem 0x00000000aa000000-0x00000000abbfffff]
[ 0.000000] node 0: [mem 0x00000000abc00000-0x00000000fce49fff]
[ 0.000000] node 0: [mem 0x00000000fce4a000-0x00000000fce4afff]
[ 0.000000] node 0: [mem 0x00000000fce4b000-0x00000000fce4dfff]
[ 0.000000] node 0: [mem 0x00000000fce4e000-0x00000000fce6ffff]
[ 0.000000] node 0: [mem 0x00000000fce70000-0x00000000fdeb1fff]
[ 0.000000] node 0: [mem 0x00000000fdeb2000-0x00000000fdeb2fff]
[ 0.000000] node 0: [mem 0x00000000fdeb3000-0x00000000ffeaffff]
[ 0.000000] node 0: [mem 0x00000000ffeb0000-0x00000000ffebffff]
[ 0.000000] node 0: [mem 0x00000000ffec0000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] cma: Reserved 144 MiB at 0x00000000eb200000 on node -1
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.5
[ 0.000000] percpu: Embedded 31 pages/cpu s87784 r8192 d31000 u126976
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: BOOT_IMAGE=/Image root=PARTUUID=076c4a2a-02 rootwait rootfstype=ext4
[ 0.000000] Unknown kernel command line parameters "BOOT_IMAGE=/Image", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.000000] software IO TLB: area num 2.
[ 0.000000] software IO TLB: mapped [mem 0x00000000e7200000-0x00000000eb200000] (64MB)
[ 0.000000] Memory: 131072K/2097152K available (18880K kernel code, 2930K rwdata, 5592K rodata, 6784)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] ftrace: allocating 58742 entries in 230 pages
[ 0.000000] ftrace: allocated 230 pages with 5 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] Dynamic Preempt: voluntary
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000080210000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080220000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idls
[ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000260] Console: colour dummy device 80x25
[ 0.000267] printk: console [tty0] enabled
[ 0.000719] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMI)
[ 0.000730] pid_max: default: 32768 minimum: 301
[ 0.002073] LSM: initializing lsm=capability,landlock,yama,apparmor,tomoyo,bpf,integrity
[ 0.002498] landlock: Up and running.
[ 0.002503] Yama: becoming mindful.
[ 0.002564] AppArmor: AppArmor initialized
[ 0.002573] TOMOYO Linux initialized
[ 0.002597] LSM support for eBPF active
[ 0.002987] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.003002] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.005141] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[ 0.005204] RCU Tasks Rude: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[ 0.005260] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[ 0.005422] rcu: Hierarchical SRCU implementation.
[ 0.005429] rcu: Max phase no-delay instances is 1000.
[ 0.006103] Platform MSI: msi-controller@1820000 domain created
[ 0.006346] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.006550] Remapping and enabling EFI services.
[ 0.006780] smp: Bringing up secondary CPUs ...
[ 0.015479] Detected PIPT I-cache on CPU1
[ 0.015528] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.015541] GICv3: CPU1: using allocated LPI pending table @0x0000000080230000
[ 0.015574] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.015666] smp: Brought up 1 node, 2 CPUs
[ 0.015689] SMP: Total of 2 processors activated.
[ 0.015694] CPU features: detected: 32-bit EL0 Support
[ 0.015699] CPU features: detected: 32-bit EL1 Support
[ 0.015704] CPU features: detected: CRC32 instructions
[ 0.015792] CPU: All CPU(s) started at EL2
[ 0.015804] alternatives: applying system-wide alternatives
[ 0.036601] node 0 deferred pages initialised in 20ms
[ 0.037624] devtmpfs: initialized
[ 0.045920] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 764504178510s
[ 0.045957] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.048413] pinctrl core: initialized pinctrl subsystem
[ 0.048718] SMBIOS 3.7.0 present.
[ 0.048736] DMI: beagle BeagleBoard.org BeagleBone AI-64/BeagleBoard.org BeagleBone AI-64, BIOS 20244
[ 0.049291] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.050077] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.050217] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.050373] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.050876] audit: initializing netlink subsys (disabled)
[ 0.051020] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
[ 0.051295] thermal_sys: Registered thermal governor 'fair_share'
[ 0.051299] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.051305] thermal_sys: Registered thermal governor 'step_wise'
[ 0.051310] thermal_sys: Registered thermal governor 'user_space'
[ 0.051315] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.051412] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.051458] ASID allocator initialised with 65536 entries
[ 0.056452] /bus@100000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@100000/int0
[ 0.056851] /bus@100000/dp-bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[ 0.056879] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/dp-bridge@a000000
[ 0.063621] /bus@100000/dp-bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[ 0.063873] /bus@100000/dp-bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[ 0.063913] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/dp-bridge@a000000
[ 0.065772] /bus@100000/dp-bridge@a000000: Fixed dependency cycle(s) with /connector
[ 0.065820] /connector: Fixed dependency cycle(s) with /bus@100000/dp-bridge@a000000
[ 0.066034] Modules: 23952 pages in range for non-PLT usage
[ 0.066038] Modules: 515472 pages in range for PLT usage
[ 0.066716] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.066732] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.066738] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.066743] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.066748] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.066753] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.066758] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.066763] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.068218] raid6: skipped pq benchmark and selected neonx8
[ 0.068231] raid6: using neon recovery algorithm
[ 0.068547] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.1 JTAGID[0x1bb6402f] Detected
[ 0.069138] iommu: Default domain type: Translated
[ 0.069147] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.069372] SCSI subsystem initialized
[ 0.070080] usbcore: registered new interface driver usbfs
[ 0.070101] usbcore: registered new interface driver hub
[ 0.070129] usbcore: registered new device driver usb
[ 0.070476] pps_core: LinuxPPS API ver. 1 registered
[ 0.070483] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.070492] PTP clock support registered
[ 0.070569] scmi_core: SCMI protocol bus registered
[ 0.070622] efivars: Registered efivars operations
[ 0.071279] NetLabel: Initializing
[ 0.071289] NetLabel: domain hash size = 128
[ 0.071294] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.071325] NetLabel: unlabeled traffic allowed by default
[ 0.071519] vgaarb: loaded
[ 0.071760] clocksource: Switched to clocksource arch_sys_counter
[ 0.072801] VFS: Disk quotas dquot_6.6.0
[ 0.072872] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.073020] FS-Cache: Loaded
[ 0.075909] CacheFiles: Loaded
[ 0.076213] AppArmor: AppArmor Filesystem Enabled
[ 0.080292] NET: Registered PF_INET protocol family
[ 0.080426] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.081905] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.081973] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.082008] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.082147] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.082753] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.083030] MPTCP token hash table entries: 2048 (order: 3, 49152 bytes, linear)
[ 0.083151] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.083188] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.083395] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.083946] RPC: Registered named UNIX socket transport module.
[ 0.083959] RPC: Registered udp transport module.
[ 0.083964] RPC: Registered tcp transport module.
[ 0.083969] RPC: Registered tcp-with-tls transport module.
[ 0.083974] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.083983] NET: Registered PF_XDP protocol family
[ 0.083999] PCI: CLS 0 bytes, default 64
[ 0.087961] kvm [1]: IPA Size Limit: 44 bits
[ 0.088568] kvm [1]: vgic-v2@6f020000
[ 0.088592] kvm [1]: GIC system register CPU interface enabled
[ 0.088615] kvm [1]: vgic interrupt IRQ9
[ 0.088635] kvm [1]: Hyp mode initialized successfully
[ 0.392738] Initialise system trusted keyrings
[ 0.392941] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.392995] zbud: loaded
[ 0.396966] NFS: Registering the id_resolver key type
[ 0.396997] Key type id_resolver registered
[ 0.397003] Key type id_legacy registered
[ 0.397056] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.397063] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.397196] fuse: init (API version 7.39)
[ 0.412927] NET: Registered PF_ALG protocol family
[ 0.412955] xor: measuring software checksum speed
[ 0.413328] 8regs : 8924 MB/sec
[ 0.413673] 32regs : 9662 MB/sec
[ 0.414098] arm64_neon : 7800 MB/sec
[ 0.414103] xor: using function: 32regs (9662 MB/sec)
[ 0.414115] Key type asymmetric registered
[ 0.414120] Asymmetric key parser 'x509' registered
[ 0.414126] Asymmetric key parser 'pkcs8' registered
[ 0.414186] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.414351] io scheduler mq-deadline registered
[ 0.416322] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.416747] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.417287] pinctrl-single 104200.pinctrl: 20 pins, size 80
[ 0.417377] pinctrl-single 104280.pinctrl: 8 pins, size 32
[ 0.420198] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.422901] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.423300] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 0.423812] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 0.424875] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.426203] SPI driver tps6594 has no spi_device_id for ti,tps6594-q1
[ 0.426216] SPI driver tps6594 has no spi_device_id for ti,tps6593-q1
[ 0.426222] SPI driver tps6594 has no spi_device_id for ti,lp8764-q1
[ 0.426227] SPI driver tps6594 has no spi_device_id for ti,tps65224-q1
[ 0.426544] megasas: 07.725.01.00-rc1
[ 0.429588] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.429608] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.429628] sky2: driver version 1.30
[ 0.430252] VFIO - User Level meta-driver version: 0.3
[ 0.430868] usbcore: registered new device driver onboard-usb-hub
[ 0.431988] i2c_dev: i2c /dev entries driver
[ 0.432133] Driver for 1-wire Dallas network protocol.
[ 0.432902] sdhci: Secure Digital Host Controller Interface driver
[ 0.432909] sdhci: Copyright(c) Pierre Ossman
[ 0.433039] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.433640] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.434068] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.434520] hid: raw HID events driver (C) Jiri Kosina
[ 0.434735] usbcore: registered new interface driver usbhid
[ 0.434742] usbhid: USB HID core driver
[ 0.435658] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.435995] watchdog: Delayed init of the lockup detector failed: -19
[ 0.436002] watchdog: Hard watchdog permanently disabled
[ 0.436109] optee: probing for conduit method.
[ 0.436130] optee: revision 4.5 (ef1ebdc23034a804)
[ 0.452585] optee: dynamic shared memory is enabled
[ 0.452828] optee: initialized driver
[ 0.453775] NET: Registered PF_INET6 protocol family
[ 0.455381] Segment Routing with IPv6
[ 0.455425] In-situ OAM (IOAM) with IPv6
[ 0.455483] mip6: Mobile IPv6
[ 0.455499] NET: Registered PF_PACKET protocol family
[ 0.455630] Key type dns_resolver registered
[ 0.455639] mpls_gso: MPLS GSO support
[ 0.460252] registered taskstats version 1
[ 0.460562] Loading compiled-in X.509 certificates
[ 0.466092] Key type .fscrypt registered
[ 0.466112] Key type fscrypt-provisioning registered
[ 0.468362] Btrfs loaded, zoned=yes, fsverity=yes
[ 0.468471] Key type encrypted registered
[ 0.468480] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.468538] ima: secureboot mode disabled
[ 0.468549] ima: No TPM chip found, activating TPM-bypass!
[ 0.468564] ima: Allocated hash algorithm: sha256
[ 0.468591] ima: No architecture policies found
[ 0.468634] evm: Initialising EVM extended attributes:
[ 0.468640] evm: security.selinux
[ 0.468644] evm: security.SMACK64 (disabled)
[ 0.468649] evm: security.SMACK64EXEC (disabled)
[ 0.468653] evm: security.SMACK64TRANSMUTE (disabled)
[ 0.468658] evm: security.SMACK64MMAP (disabled)
[ 0.468662] evm: security.apparmor
[ 0.468666] evm: security.ima
[ 0.468670] evm: security.capability
[ 0.468674] evm: HMAC attrs: 0x1
[ 0.471722] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fa)
[ 0.605471] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.606086] omap_i2c 2000000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.606611] omap_i2c 2010000.i2c: bus 5 rev0.12 at 400 kHz
[ 0.607143] omap_i2c 2020000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.607677] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[ 0.608252] omap_i2c 2040000.i2c: bus 3 rev0.12 at 100 kHz
[ 0.608827] omap_i2c 2050000.i2c: bus 7 rev0.12 at 400 kHz
[ 0.609385] omap_i2c 2060000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.609550] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
[ 0.609656] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
[ 0.609778] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
[ 0.609968] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 0.619786] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-5
[ 0.619809] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 0.619815] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 0.622462] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-d1
[ 0.622482] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 0.622488] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 0.623291] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 216, base_baud = 3000000) is a 8250
[ 0.623346] printk: console [ttyS2] enabled
[ 2.904853] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 2.916073] mmc0: CQHCI version 5.10
[ 2.931366] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.938922] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.947054] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.955154] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.962367] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 3.020410] mmc0: Command Queue Engine enabled
[ 3.024862] mmc0: new HS200 MMC card at address 0001
[ 3.030368] mmcblk0: mmc0:0001 TB2916 14.6 GiB
[ 3.035992] mmcblk0boot0: mmc0:0001 TB2916 4.00 MiB
[ 3.041599] mmcblk0boot1: mmc0:0001 TB2916 4.00 MiB
[ 3.047127] mmcblk0rpmb: mmc0:0001 TB2916 4.00 MiB, chardev (237:0)
[ 4.072368] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
[ 4.078690] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 4.084170] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x18001000-0x18010f)
[ 4.093633] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 4.100517] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 4.106515] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1s
[ 4.116218] pci 0000:00:00.0: supports D1
[ 4.120220] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 4.127948] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.136075] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 4.142690] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 4.147726] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[ 4.154522] pcieport 0000:00:00.0: PME: Signaling with IRQ 485
[ 4.160585] pcieport 0000:00:00.0: AER: enabled with IRQ 485
[ 4.167318] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 4.179168] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[ 4.192135] cdns-mhdp8546 a000000.dp-bridge: invalid resource (null)
[ 4.198501] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 4.214958] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 4.220465] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 4.228220] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x00000020000080
[ 4.237615] xhci-hcd xhci-hcd.0.auto: irq 635, io mem 0x06410000
[ 4.243740] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 4.249219] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 4.256864] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 4.263469] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 4.271726] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.278938] usb usb1: Product: xHCI Host Controller
[ 4.283806] usb usb1: Manufacturer: Linux 6.6.58-ti xhci-hcd
[ 4.289457] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 4.294641] hub 1-0:1.0: USB hub found
[ 4.298404] hub 1-0:1.0: 1 port detected
[ 4.302507] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 4.310633] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 4.318886] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.326098] usb usb2: Product: xHCI Host Controller
[ 4.330966] usb usb2: Manufacturer: Linux 6.6.58-ti xhci-hcd
[ 4.336614] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 4.341745] hub 2-0:1.0: USB hub found
[ 4.345502] hub 2-0:1.0: 1 port detected
[ 4.350155] leds-gpio leds: Led :disk-activity renamed to :disk-activity_1 due to name collision
[ 4.364672] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[ 4.364789] random: crng init done
[ 4.375640] mmc1: CQHCI version 5.10
[ 4.418323] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 4.456317] mmc1: new high speed SDHC card at address 59b4
[ 4.462285] mmcblk1: mmc1:59b4 LX32G 29.5 GiB
[ 4.468248] mmcblk1: p1 p2
[ 4.847770] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[ 5.000068] usb 1-1: not running at top speed; connect to a high speed hub
[ 5.007258] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[ 5.015426] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 5.022549] usb 1-1: SerialNumber: C60508615FC1
[ 5.027587] hub 1-1:1.0: USB hub found
[ 5.031425] hub 1-1:1.0: 4 ports detected
[ 5.091004] hub 1-1:1.0: USB hub found
[ 5.094878] hub 1-1:1.0: 4 ports detected
[ 5.102549] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 5.109773] clk: Disabling unused clocks
[ 5.131808] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 5.156067] usb 2-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 1.00
[ 5.164255] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.167003] EXT4-fs (mmcblk1p2): orphan cleanup on readonly fs
[ 5.177463] EXT4-fs (mmcblk1p2): mounted filesystem 1d3f444c-6480-4aaa-950c-b8e12bb5e73c ro with ord.
[ 5.177511] hub 2-1:1.0: USB hub found
[ 5.189497] VFS: Mounted root (ext4 filesystem) readonly on device 179:770.
[ 5.200153] hub 2-1:1.0: 4 ports detected
[ 5.201136] devtmpfs: mounted
[ 5.208511] hub 2-1:1.0: USB hub found
[ 5.211628] Freeing unused kernel memory: 6784K
[ 5.216843] hub 2-1:1.0: 4 ports detected
[ 5.229548] Checked W+X mappings: passed, no W+X pages found
[ 5.235227] Run /sbin/init as init process
[ 5.272413] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[ 5.732264] systemd[1]: System time before build time, advancing clock.
[ 5.796171] systemd[1]: systemd 255.17^ running in system mode (-PAM -AUDIT -SELINUX -APPARMOR +IMA )
[ 5.828126] systemd[1]: Detected architecture arm64.
Welcome to Poky (Yocto Project Reference Distro) 5.0.7 (scarthgap)!
[ 5.856383] systemd[1]: Hostname set to <beaglebone-ai64>.
[ 5.873409] systemd[1]: Initializing machine ID from random generator.
[ 5.880052] systemd[1]: Installed transient /etc/machine-id file.
U-Boot SPL 2024.10-00001-gbf0e9d0b7274 (Nov 14 2024 - 23:19:39 +0000)
SYSFW ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE: BL31: v2.12.0(release):11.00.11-dirty
NOTICE: BL31: Built : 12:14:11, Apr 16 2025
