PROCESSOR-SDK-AM62X: SDL DCC R5
Expert 2400 points
Part Number: PROCESSOR-SDK-AM62X
Other Parts Discussed in Thread: SK-AM62
MCU SDK version: mcu_plus_sdk_am62x_10_01_00_33
Test EVM: SK-AM62
CCS version: 12.8.1
I imported the example from C:\ti\mcu_plus_sdk_am62x_10_01_00_33\examples\sdl\dcc\dcc_modes\am62x-sk\r5fss0-0_freertos\
Then, I compiled the R5 projects and copied the generated appimage.hs_fs into the below path.
--file=sbl_prebuilt/am62x-sk/WZ_Debug/dcc_am62x-sk_r5fss0-0_freertos_ti-arm-clang.appimage.hs_fs --operation=flash --flash-offset=0xA00000
I use the file below to flash the test examples.
default_sbl_ospi_hs_fs-r5.cfg
Below is the UART log from SBL UART
SYSFW Firmware Version 10.1.8--v10.01.08 (Fiery Fox)
SYSFW Firmware revision 0xa
SYSFW ABI revision 4.0
[BOOTLOADER_PROFILE] Boot Media       : FLASH
[BOOTLOADER_PROFILE] Boot Media Clock : 166.667 MHz
[BOOTLOADER_PROFILE] Boot Image Size  : 175 KB
[BOOTLOADER_PROFILE] Cores present    :
m4f0-0
r5f0-0
[BOOTLOADER PROFILE] System_init                      :       5491us
[BOOTLOADER PROFILE] Board_init                       :          0us
[BOOTLOADER PROFILE] Drivers_open                     :        301us
[BOOTLOADER PROFILE] Board_driversOpen                :       1260us
[BOOTLOADER PROFILE] Sciclient Get Version            :      10202us
[BOOTLOADER PROFILE] App_waitForMcuPbist              :       8663us
[BOOTLOADER PROFILE] App_waitForMcuLbist              :       7689us
[BOOTLOADER PROFILE] App_loadImages                   :       3327us
[BOOTLOADER PROFILE] App_loadSelfcoreImage            :       4041us
[BOOTLOADER_PROFILE] SBL Total Time Taken             :      40979us
Image loading done, switching to application ...
Starting MCU-m4f and 2nd stage bootloader
[BOOTLOADER_PROFILE] Boot Image Size  : 408 KB
hsm-m4f0-0
r5f0-0
a530-0
[BOOTLOADER PROFILE] System_init                      :       2789us
[BOOTLOADER PROFILE] Board_init                       :          1us
[BOOTLOADER PROFILE] Drivers_open                     :        386us
[BOOTLOADER PROFILE] Board_driversOpen                :        139us
[BOOTLOADER PROFILE] Sciclient Get Version            :      10225us
[BOOTLOADER PROFILE] App_loadImages                   :       2690us
[BOOTLOADER PROFILE] App_loadSelfcoreImage            :       5349us
[BOOTLOADER PROFILE] App_loadA53Images                :       4116us
[BOOTLOADER_PROFILE] SBL Total Time Taken             :      25698us
Starting RTOS/Baremetal applications
NOTICE:  BL31: v2.11.0(release):REL.MCUSDK.K3.10.01.00.33
NOTICE:  BL31: Built : 04:57:09, Dec 19 2024
Below is the UART log from DM UART
[15:15:23.569]收←◆Sciserver Testapp Built On: Dec 19 2024 04:51:59
Sciserver Version: v2024.12.0.0-REL.MCUSDK.K3.10.01.00.33+
RM_PM_HAL Version: v10.01.08
Starting Sciserver..... PASSED
 DCC Example Test Application
DCC_Test_init: Init WKUP ESM complete
USECASE: 0
Source clock: HFOSC0
Test clock: SYSCLK0
SDL DCC EXAMPLE TEST: Seed values calculation done.
SDL DCC EXAMPLE TEST: Enabling DCC and waiting for Error interrupt
Question: How to make this DCC R5 example run?
I can run the DCC M4F successfully C:\ti\mcu_plus_sdk_am62x_10_01_00_33\examples\sdl\dcc\dcc_modes\am62x-sk\m4fss0-0_nortos\
Below is the log.
But it cannot run successfully in the DM core
[BLAZAR_Cortex_M4F_0]
USECASE: 0
Test clock: SYSCLK0
SDL DCC EXAMPLE TEST: DCC Generated Error interrupt
SDL DCC EXAMPLE TEST: Indicating clock drift/change
UC-0 Completed Successfully
USECASE: 1
Test clock: SYSCLK0
SDL DCC EXAMPLE TEST: DCC Generated completion interrupt
SDL DCC EXAMPLE TEST: No Clock Drift was observed
UC-1 Completed Successfully
USECASE: 2
Test clock: SYSCLK0
SDL DCC EXAMPLE TEST: Enabling DCC and running for some time
UC-2 Completed Successfully
USECASE: 3
Source clock: RC OSC
Test clock: SYSCLK0
UC-3 Completed Successfully
USECASE: 4
Test clock: SYSCLK0
UC-4 Completed Successfully
USECASE: 5
Test clock: SYSCLK0
UC-5 Completed Successfully
USECASE: 6
Test clock: SYSCLK0
UC-6 Completed Successfully
USECASE: 7
Test clock: MAIN_SYSCLK0
UC-7 Completed Successfully
USECASE: 8
UC-8 Completed Successfully
USECASE: 9
Test clock: FICLK
UC-9 Completed Successfully
USECASE: 10
Source clock: FICLK
UC-10 Completed Successfully
 All tests have passed.
