Dear all,
Our application is for NVR. So, I use the DM8168EVM to test the 6 channels H264 1080P files at video decode + video display demo on latest DVRRDK_01_09_00_16. Unfortunately, the frame rate only can get the 25fps not 30fps. Can TI provide any patch to reach this goal? The detail information is as following. Thanks in advance.
Run-Time Menu
1: Capture Settings
2: Encode Settings
3: Decode Settings
4: Display Settings
5: Audio Settings
i: Print detailed system information
e: Stop Demo
Enter Choice: i
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Statistics ***
[m3vpss ]
[m3vpss ] Elasped Time: 54 secs
[m3vpss ]
[m3vpss ] Output Request FPS : 31 fps (1702 frames)
[m3vpss ] Output Actual FPS : 31 fps (1702 frames)
[m3vpss ] Output Drop FPS : 0 fps (0 frames)
[m3vpss ] Output Reject FPS : 0 fps (0 frames)
[m3vpss ] Scaling Internal : 32 ms
[m3vpss ] Scaling Internal min : 31 ms
[m3vpss ] Scaling Internal max : 35 ms
[m3vpss ]
[m3vpss ] Win | Window Repeat Drop Recv Que FID Invlid Acc Event Invalid Que Reject Reject Latency
[m3vpss ] Num | FPS FPS FPS FPS FPS FPS Count (Max/Min) CH Frames Frames Frames Min / Max
[m3vpss ] ------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 24 6 0 24 24 0 0 ( 0/255) 0 0 0 255 / 83436
[m3vpss ] 1 | 24 6 0 24 24 0 0 ( 0/255) 0 0 0 255 / 83203
[m3vpss ] 2 | 25 6 0 25 25 0 0 ( 0/255) 0 0 0 255 / 83142
[m3vpss ] 3 | 24 6 0 24 24 0 0 ( 0/255) 0 0 0 255 / 83170
[m3vpss ] 4 | 24 6 0 24 24 0 0 ( 0/255) 0 0 0 255 / 83354
[m3vpss ] 5 | 24 6 0 24 24 0 0 ( 0/255) 0 0 0 255 / 83569
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Parameters ***
[m3vpss ]
[m3vpss ] Output FPS: 30
[m3vpss ]
[m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Low Cost | SWMS | Data |
[m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | ON / OFF | Inst | Format|
[m3vpss ] --------------------------------------------------------------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 0 | 0, 24 | 1920 x 1112 | 2048 / 2048 | NON-TILED | 0, 0 | 1280 x 720 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP |
[m3vpss ] 1 | 1 | 0, 12 | 1920 x 556 | 4096 / 4096 | NON-TILED | 1280, 0 | 640 x 360 | 3840 / 0 | NON-TILED | ON | 0 | 420SP |
[m3vpss ] 2 | 2 | 0, 12 | 1920 x 556 | 4096 / 4096 | NON-TILED | 1280, 360 | 640 x 360 | 3840 / 0 | NON-TILED | ON | 0 | 420SP |
[m3vpss ] 3 | 3 | 0, 12 | 1920 x 556 | 4096 / 4096 | NON-TILED | 0, 720 | 640 x 360 | 3840 / 0 | NON-TILED | ON | 0 | 420SP |
[m3vpss ] 4 | 4 | 0, 12 | 1920 x 556 | 4096 / 4096 | NON-TILED | 640, 720 | 640 x 360 | 3840 / 0 | NON-TILED | ON | 0 | 420SP |
[m3vpss ] 5 | 5 | 0, 12 | 1920 x 556 | 4096 / 4096 | NON-TILED | 1280, 720 | 640 x 360 | 3840 / 0 | NON-TILED | ON | 0 | 420SP |
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS1] Mosaic Statistics ***
[m3vpss ]
[m3vpss ]
[m3vpss ] Scaling Internal min : 30 ms
[m3vpss ] Scaling Internal max : 36 ms
[m3vpss ]
[m3vpss ] 0 | 24 6 0 24 24 0 0 ( 0/255) 0 0 0 255 / 83425
[m3vpss ] 1 | 24 6 0 24 24 0 0 ( 0/255) 0 0 0 255 / 83254
[m3vpss ] 2 | 25 6 0 25 25 0 0 ( 0/255) 0 0 0 255 / 83188
[m3vpss ] 3 | 24 6 0 24 24 0 0 ( 0/255) 0 0 0 255 / 83163
[m3vpss ] 4 | 24 6 0 24 24 0 0 ( 0/255) 0 0 0 255 / 83373
[m3vpss ] 5 | 24 6 0 24 24 0 0 ( 0/255) 0 0 0 255 / 83585
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS1] Mosaic Parameters ***
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 157283: DISPLAY: HDDAC(BP0) : 60 fps, Latency (Min / Max) = ( 31 / 53 ), Callback Interval (Min / Max) = ( 15 / 18 ) !!!
[m3vpss ] 157284: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 3329, HDDAC(BP0) 3329, DVO2(BP1) 3329, SDDAC(SEC1) 3330
[m3vpss ] 157284: SYSTEM : Heap Free Space (System = 20184 bytes, SR0 = 14614912 bytes, FrmBuf = 318815104 bytes,
[m3vpss ] BitBuf = 18673536 bytes, Mbx = 10236 msgs)
[m3vpss ] 157288: DISPLAY: DVO2(BP1) : 55 fps, Latency (Min / Max) = ( 31 / 71 ), Callback Interval (Min / Max) = ( 0 / 43 ) !!!
[m3video] 159462: HDVICP-ID:0
[m3video] totalAcquire2wait in msec: 6505390
[m3video] totalWait2Isr in msec: 70880
[m3video] totalIsr2Done in msec: 112
[m3video] totalWait2Done in msec: 70992
[m3video] totalDone2Release in msec: 0
[m3video] totalAcquire2Release in msec: 71936
[m3video] totalAcq2acqDelay in msec: 20124
[m3video] totalElapsedTime in msec: 92058
[m3video] numAccessCnt: 4593
[m3video] IVA-FPS : 49
[m3video] 159463: HDVICP-ID:1
[m3video] totalAcquire2wait in msec: 6510081
[m3video] totalWait2Isr in msec: 82807
[m3video] totalIsr2Done in msec: 143
[m3video] totalWait2Done in msec: 82950
[m3video] totalAcquire2Release in msec: 84785
[m3video] totalAcq2acqDelay in msec: 7279
[m3video] totalElapsedTime in msec: 92064
[m3video] numAccessCnt: 4596
[m3video] 159466: HDVICP-ID:2
[m3video] totalAcquire2wait in msec: 6498816
[m3video] totalWait2Isr in msec: 77181
[m3video] totalIsr2Done in msec: 203
[m3video] totalWait2Done in msec: 77384
[m3video] totalAcquire2Release in msec: 79345
[m3video] totalAcq2acqDelay in msec: 12731
[m3video] totalElapsedTime in msec: 92076
[m3video] numAccessCnt: 4588
[m3video]
[m3video] *** DECODE Statistics ***
[m3video]
[m3video] Elasped Time : 54 secs
[m3video]
[m3video]
[m3video] CH | In Recv In User Out
[m3video] Num | FPS Skip FPS FPS
[m3video] -----------------------------------
[m3video] 0 | 24 0 24
[m3video] 1 | 24 0 24
[m3video] 2 | 24 0 24
[m3video] 3 | 24 0 24
[m3video] 4 | 24 0 24
[m3video] 5 | 24 0 24
[m3video]
[m3vpss ]
[m3vpss ] 161446: LOAD: CPU: 27% HWI: 6%, SWI:1%
[m3vpss ]
[m3vpss ] 161447: LOAD: TSK: IPC_IN_M30: 3%
[m3vpss ] 161447: LOAD: TSK: DISPLAY0: 1%
[m3vpss ] 161447: LOAD: TSK: DISPLAY1: 1%
[m3vpss ] 161448: LOAD: TSK: DUP0: 2%
[m3vpss ] 161448: LOAD: TSK: SWMS0: 4%
[m3vpss ] 161448: LOAD: TSK: SWMS1: 4%
[m3vpss ]
[m3video]
[m3video] 161948: LOAD: CPU: 25% HWI: 2%, SWI:2%
[m3video]
[m3video] 161948: LOAD: TSK: IPC_OUT_M30: 3%
[m3video] 161948: LOAD: TSK: IPC_BITS_IN0: 2%
[m3video] 161950: LOAD: TSK: DEC0 : 6%
[m3video] 161950: LOAD: TSK: DEC_PROCESS_TSK_0 : 1%
[m3video] 161951: LOAD: TSK: DEC_PROCESS_TSK_1 : 2%
[m3video] 161951: LOAD: TSK: DEC_PROCESS_TSK_2 : 3%
[m3video]
[c6xdsp ]
[c6xdsp ] 164368: LOAD: CPU: 1% HWI: 0%, SWI:0%
[c6xdsp ]
[c6xdsp ]
B.R.
OC
