TDA4VM: Want write rtos firmware for signal processing
Part Number: TDA4VM
Hello Team,
I am working with the TDA4VM EVM and want to develop an RTOS-based application for DSP signal processing.
I have a question regarding the use of DSP cores:
  • Can I use the C7x and C66x cores together?
  • For example, I want to perform FFT on C7x, and then pass the results to the C66x for further processing.
I am running Linux on the ARM cores and want to implement IPC-based RTOS firmware on the DSPs for signal processing. Any guidance or examples on how to coordinate processing across C7x and C66x cores would be very helpful.
Thanks & Regards,
Tamilselvan P
