Part Number: TDA4VH-Q1
Other Parts Discussed in Thread: TDA4VH
Hi Experts ,
i am working with AR0233 on the TDA4VH platform SDK RTOS version :11.00.00.06
I’d like to understand:
1. Is it possible to change FPS at runtime by writing AR0233 registers directly (e.g., FRAME_LENGTH_LINES, LINE_LENGTH_PCK) from the sensor driver while single_cam_app is running?
2. For FPS change from 30 to 60FPS, is a brief stream off/on sequence required to keep CSI-2 timings stable?
3. Any precautions with UB960/UB9702 deserializers when line/frame timings change mid-stream?
Kindly request your suggestions on this topic and whether the VISS / Capture nodes etc.. can tolerate runtime FPS changes without needing graph teardown?
Thank you..
