Part Number: AM625
Hi Expert,
I am using below guide to boot from emmc UDA mode:
4.1.5. How to flash eMMC and boot from eMMC UDA — Processor SDK AM62x Documentation
I want to use the disk image to boot directly, it can boot to linux console, but it seem using the EFI fs, and it will run twice uboot as well, can you help explain it? how can I fix it?
boot log as below:
U-Boot SPL 2025.01-00527-gd2a72467939e (Jul 01 2025 - 21:23:47 +0000)
SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.2--v11.01.02 (Fancy Rat)')
Changed A53 CPU frequency to 1250000000Hz (T grade) in DT
SPL initial stack usage: 13392 bytes
Trying to boot from MMC1
Authentication passed
Starting ATF on ARM64 core...
NOTICE: BL31: v2.13.0(release):v2.13.0-240-gd90bb650fe-dirty
NOTICE: BL31: Built : 21:37:18, Jun 23 2025
SPL initial stack usage: 2032 bytes
MMC: no card present
** Bad device specification mmc 1 **
Couldn't find partition mmc 1:1
Error: could not access storage.
U-Boot 2025.01-00527-gd2a72467939e (Jul 01 2025 - 21:23:47 +0000)
SoC: AM62X SR1.0 HS-FS
Model: Texas Instruments AM625 SK
DRAM: 2 GiB
Core: 83 devices, 32 uclasses, devicetree: separate
MMC: mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@8000000port@1
Hit any key to stop autoboot: 2
Booting `boot'
EFI stub: Booting Linux Kernel...
EFI stub: EFI_RNG_PROTOCOL unavailable
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.12.35-ti-00915-ge3e551586dfa (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.4.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Tue Jul 1 21:17:52 UTC 2025
[ 0.000000] KASLR disabled due to lack of seed
[ 0.000000] Machine model: Texas Instruments AM625 SK
[ 0.000000] efi: EFI v2.10 by Das U-Boot
[ 0.000000] efi: ESRT=0xfce32040 RTPROP=0xfce34040 SMBIOS 3.0=0xfde90000 MEMRESERVE=0xfcd57040
[ 0.000000] esrt: Reserving ESRT space from 0x00000000fce32040 to 0x00000000fce320c8.
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000f0000000, size 128 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000f0000000..0x00000000f7ffffff (131072 KiB) map reusable linux,cma
[ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[ 0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
[ 0.000000] OF: reserved mem: 0x000000009c700000..0x000000009c7fffff (1024 KiB) map non-reusable ramoops@9c700000
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
[ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x000000009c800000..0x000000009cafffff (3072 KiB) nomap non-reusable ipc-memories@9c800000
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x000000009cb00000..0x000000009cbfffff (1024 KiB) nomap non-reusable m4f-dma-memory@9cb00000
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x000000009cc00000..0x000000009d9fffff (14336 KiB) nomap non-reusable m4f-memory@9cc00000
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x000000009da00000..0x000000009dafffff (1024 KiB) nomap non-reusable r5f-dma-memory@9da00000
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x000000009db00000..0x000000009e6fffff (12288 KiB) nomap non-reusable r5f-memory@9db00000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000008007ffff]
[ 0.000000] node 0: [mem 0x0000000080080000-0x000000009c7fffff]
[ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff]
[ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x000000009fffffff]
[ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000fce33fff]
[ 0.000000] node 0: [mem 0x00000000fce34000-0x00000000fce34fff]
[ 0.000000] node 0: [mem 0x00000000fce35000-0x00000000fce37fff]
[ 0.000000] node 0: [mem 0x00000000fce38000-0x00000000fce58fff]
[ 0.000000] node 0: [mem 0x00000000fce59000-0x00000000fce5afff]
[ 0.000000] node 0: [mem 0x00000000fce5b000-0x00000000fce5bfff]
[ 0.000000] node 0: [mem 0x00000000fce5c000-0x00000000fde8ffff]
[ 0.000000] node 0: [mem 0x00000000fde90000-0x00000000fde90fff]
[ 0.000000] node 0: [mem 0x00000000fde91000-0x00000000ffe8ffff]
[ 0.000000] node 0: [mem 0x00000000ffe90000-0x00000000ffe9ffff]
[ 0.000000] node 0: [mem 0x00000000ffea0000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.5
[ 0.000000] percpu: Embedded 22 pages/cpu s51672 r8192 d30248 u90112
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: BOOT_IMAGE=/Image root=PARTUUID=076c4a2a-02 rootwait rootfstype=ext4
[ 0.000000] Unknown kernel command line parameters "BOOT_IMAGE=/Image", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 524288
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 2MB
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000ff643000-0x00000000ff843000] (2MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80c00000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000080450000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080460000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000633] Console: colour dummy device 80x25
[ 0.000651] printk: legacy console [tty0] enabled
[ 0.001451] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.001478] pid_max: default: 32768 minimum: 301
[ 0.001587] LSM: initializing lsm=capability,selinux
[ 0.001659] SELinux: Initializing.
[ 0.002198] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.002233] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.004920] rcu: Hierarchical SRCU implementation.
[ 0.004962] rcu: Max phase no-delay instances is 1000.
[ 0.005188] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[ 0.005899] Remapping and enabling EFI services.
[ 0.006273] smp: Bringing up secondary CPUs ...
[ 0.007001] Detected VIPT I-cache on CPU1
[ 0.007104] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.007121] GICv3: CPU1: using allocated LPI pending table @0x0000000080470000
[ 0.007179] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.008077] Detected VIPT I-cache on CPU2
[ 0.008156] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[ 0.008170] GICv3: CPU2: using allocated LPI pending table @0x0000000080480000
[ 0.008208] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.009008] Detected VIPT I-cache on CPU3
[ 0.009078] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[ 0.009091] GICv3: CPU3: using allocated LPI pending table @0x0000000080490000
[ 0.009126] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.009387] smp: Brought up 1 node, 4 CPUs
[ 0.009507] SMP: Total of 4 processors activated.
[ 0.009517] CPU: All CPU(s) started at EL2
[ 0.009528] CPU features: detected: 32-bit EL0 Support
[ 0.009541] CPU features: detected: CRC32 instructions
[ 0.009600] alternatives: applying system-wide alternatives
[ 0.010284] Memory: 1833772K/2097152K available (12992K kernel code, 1256K rwdata, 4668K rodata, 2752K init, 642K bss, 123412K reserved, 131072K cma-reserved)
[ 0.011590] devtmpfs: initialized
[ 0.022710] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.022775] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.027233] 27136 pages in range for non-PLT usage
[ 0.027264] 518656 pages in range for PLT usage
[ 0.027650] pinctrl core: initialized pinctrl subsystem
[ 0.028490] SMBIOS 3.7.0 present.
[ 0.028533] DMI: ti Texas Instruments AM625 SK/Texas Instruments AM625 SK, BIOS 2025.01-00527-gd2a72467939e 01/01/2025
[ 0.028559] DMI: Memory slots populated: 0/0
[ 0.031083] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.032477] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.033161] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.033965] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.034065] audit: initializing netlink subsys (disabled)
[ 0.034405] audit: type=2000 audit(0.032:1): state=initialized audit_enabled=0 res=1
[ 0.034933] thermal_sys: Registered thermal governor 'step_wise'
[ 0.034941] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.035006] cpuidle: using governor menu
[ 0.035231] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.035357] ASID allocator initialised with 65536 entries
[ 0.041916] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
[ 0.042066] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
[ 0.042107] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[ 0.042184] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
[ 0.042260] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 0.047212] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
[ 0.047379] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[ 0.048293] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
[ 0.049217] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[ 0.049306] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 0.051808] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
[ 0.051906] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 0.053507] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.053543] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.053557] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.053569] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.053581] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.053593] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.053606] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.053617] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.055509] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[ 0.056433] iommu: Default domain type: Translated
[ 0.056472] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.057050] SCSI subsystem initialized
[ 0.057519] usbcore: registered new interface driver usbfs
[ 0.057564] usbcore: registered new interface driver hub
[ 0.057608] usbcore: registered new device driver usb
[ 0.058174] pps_core: LinuxPPS API ver. 1 registered
[ 0.058188] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.058214] PTP clock support registered
[ 0.058257] EDAC MC: Ver: 3.0.0
[ 0.058657] scmi_core: SCMI protocol bus registered
[ 0.058747] efivars: Registered efivars operations
[ 0.059166] FPGA manager framework
[ 0.059281] Advanced Linux Sound Architecture Driver Initialized.
[ 0.060467] vgaarb: loaded
[ 0.060967] clocksource: Switched to clocksource arch_sys_counter
[ 0.061310] VFS: Disk quotas dquot_6.6.0
[ 0.061345] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.068717] NET: Registered PF_INET protocol family
[ 0.069052] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.070812] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.070876] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.070900] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.071076] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.071615] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.071841] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.071911] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.072141] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.072768] RPC: Registered named UNIX socket transport module.
[ 0.072796] RPC: Registered udp transport module.
[ 0.072807] RPC: Registered tcp transport module.
[ 0.072817] RPC: Registered tcp-with-tls transport module.
[ 0.072828] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.072844] NET: Registered PF_XDP protocol family
[ 0.072878] PCI: CLS 0 bytes, default 64
[ 0.074483] Initialise system trusted keyrings
[ 0.074806] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.075175] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.075497] NFS: Registering the id_resolver key type
[ 0.075557] Key type id_resolver registered
[ 0.075569] Key type id_legacy registered
[ 0.075599] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.075614] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.128764] Key type asymmetric registered
[ 0.128809] Asymmetric key parser 'x509' registered
[ 0.128911] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.129172] io scheduler mq-deadline registered
[ 0.129188] io scheduler kyber registered
[ 0.129237] io scheduler bfq registered
[ 0.132531] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 0.133274] pinctrl-single f4000.pinctrl: 171 pins, size 684
[ 0.135172] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.141604] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.151705] loop: module loaded
[ 0.152928] megasas: 07.727.03.00-rc1
[ 0.157403] tun: Universal TUN/TAP device driver, 1.6
[ 0.158621] VFIO - User Level meta-driver version: 0.3
[ 0.160002] usbcore: registered new interface driver usb-storage
[ 0.160665] i2c_dev: i2c /dev entries driver
[ 0.162577] sdhci: Secure Digital Host Controller Interface driver
[ 0.162610] sdhci: Copyright(c) Pierre Ossman
[ 0.162841] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.163885] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.164880] usbcore: registered new interface driver usbhid
[ 0.164896] usbhid: USB HID core driver
[ 0.166596] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
[ 0.167378] optee: probing for conduit method.
[ 0.167426] optee: revision 4.6 (71785645fa6ce42d)
[ 0.167808] optee: dynamic shared memory is enabled
[ 0.168598] optee: initialized driver
[ 0.168714] random: crng init done
[ 0.171200] Initializing XFRM netlink socket
[ 0.171266] NET: Registered PF_PACKET protocol family
[ 0.171362] Key type dns_resolver registered
[ 0.180457] registered taskstats version 1
[ 0.180866] Loading compiled-in X.509 certificates
[ 0.194291] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.1.2--v11.01.02 (Fancy Rat)')
[ 0.264461] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
[ 0.264600] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.266142] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 0.266254] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 0.266327] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
[ 0.266395] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[ 0.266835] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.268375] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.268671] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[ 0.268995] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[ 0.271035] ti-udma 485c0100.dma-controller: Number of rings: 82
[ 0.273817] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[ 0.276540] ti-udma 485c0000.dma-controller: Number of rings: 150
[ 0.281670] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[ 0.285040] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 238, base_baud = 3000000) is a 8250
[ 0.285165] printk: legacy console [ttyS2] enabled
[ 2.009211] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[ 2.016235] Creating 7 MTD partitions on "fc40000.spi.0":
[ 2.021648] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 2.028682] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 2.035264] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 2.042072] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 2.048487] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[ 2.055424] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 2.062223] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 2.318926] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[ 2.332405] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[ 2.372977] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.384441] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[ 2.392566] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[ 2.400818] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 2.407960] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
[ 2.416110] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[ 2.435802] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 2.446918] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
[ 2.458859] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
[ 2.475974] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.481591] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 2.489413] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[ 2.495428] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000808020000010
[ 2.504901] xhci-hcd xhci-hcd.0.auto: irq 253, io mem 0x31100000
[ 2.512149] hub 1-0:1.0: USB hub found
[ 2.515973] hub 1-0:1.0: 1 port detected
[ 2.524049] mmc0: CQHCI version 5.10
[ 2.533798] pca953x 1-0022: supply vcc not found, using dummy regulator
[ 2.540626] pca953x 1-0022: using AI
[ 2.562103] clk: Disabling unused clocks
[ 2.566119] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[ 2.575319] PM: genpd: Disabling unused power domains
[ 2.580523] ALSA device list:
[ 2.580793] mmc1: CQHCI version 5.10
[ 2.583646] No soundcards found.
[ 2.666487] mmc0: Command Queue Engine enabled
[ 2.671005] mmc0: new HS200 MMC card at address 0001
[ 2.677770] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 2.684413] mmcblk0: p1 p2
[ 2.688577] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
[ 2.694842] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
[ 2.701213] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (239:0)
[ 4.103157] sdhci-am654 fa00000.mmc: Power on failed
[ 4.138764] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[ 4.152206] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 4.159566] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 4.275093] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[ 4.283228] EXT4-fs (mmcblk0p2): recovery complete
[ 4.289828] EXT4-fs (mmcblk0p2): mounted filesystem 8f366dbb-bdc2-49e9-ae1e-f28e6da9c3da ro with ordered data mode. Quota mode: none.
[ 4.301982] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 4.309327] devtmpfs: mounted
[ 4.314118] Freeing unused kernel memory: 2752K
[ 4.318758] Run /sbin/init as init process
[ 4.435768] systemd[1]: System time before build time, advancing clock.
[ 4.471924] NET: Registered PF_INET6 protocol family
[ 4.478071] Segment Routing with IPv6
[ 4.481853] In-situ OAM (IOAM) with IPv6
[ 4.510523] systemd[1]: systemd 255.21^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -)
[ 4.542505] systemd[1]: Detected architecture arm64.
Welcome to Arago 2025.01!
[ 4.558514] systemd[1]: Hostname set to <am62xx-evm>.
[ 4.781613] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.824908] systemd[1]: Configuration file /usr/lib/systemd/system/seva-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.904321] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the.
[ 5.063786] systemd[1]: Queued start job for default target Graphical Interface.
[ 5.119545] systemd[1]: Created slice Slice /system/getty.
[ OK ] Created slice Slice /system/getty.
[ 5.139801] systemd[1]: Created slice Slice /system/modprobe.
[ OK ] Created slice Slice /system/modprobe.
[ 5.159724] systemd[1]: Created slice Slice /system/serial-getty.
[ OK ] Created slice Slice /system/serial-getty.
[ 5.179048] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 5.197526] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 5.217388] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 5.237220] systemd[1]: Expecting device /dev/ttyS2...
[ 5.253281] systemd[1]: Reached target Path Units.
[ OK ] Reached target Path Units.
[ 5.269146] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 5.285124] systemd[1]: Reached target Slice Units.
[ OK ] Reached target Slice Units.
[ 5.301143] systemd[1]: Reached target Swaps.
[ OK ] Reached target Swaps.
[ 5.361018] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 5.381322] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 5.406322] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 5.425673] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 5.446579] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Listening on Journal Audit Socket.
[ 5.465987] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 5.486011] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 5.502173] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 5.526826] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 5.545866] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 5.565978] systemd[1]: Listening on User Database Manager Socket.
[ OK ] Listening on User Database Manager Socket.
[ 5.609591] systemd[1]: Mounting Huge Pages File System...
[ 5.620595] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.646993] systemd[1]: Mounting Kernel Debug File System...
[ 5.665803] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[ 5.684503] systemd[1]: Mounting Temporary Directory /tmp...
[ 5.708112] systemd[1]: Starting Create List of Static Device Nodes...
[ 5.730959] systemd[1]: Starting Load Kernel Module configfs...
[ 5.754947] systemd[1]: Starting Load Kernel Module drm...
[ 5.779013] systemd[1]: Starting Load Kernel Module fuse...
[ 5.805259] systemd[1]: Starting Start psplash boot splash screen...
[ 5.817885] fuse: init (API version 7.41)
[ 5.829921] systemd[1]: Starting RPC Bind...
[ 5.851301] systemd[1]: Starting File System Check on Root Device...
[ 5.881079] systemd[1]: Starting Journal Service...
[ 5.922114] systemd[1]: Starting Load Kernel Modules...
[ 5.936043] systemd[1]: Starting Generate network units from Kernel command line...
[ 5.954467] systemd[1]: Starting Coldplug All udev Devices...
[ 5.968386] cryptodev: loading out-of-tree module taints kernel.
[ 5.971556] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 5.980457] systemd[1]: Mounted Huge Pages File System.
[ 5.980926] sysctl table check failed: ioctl/(null) procname is null
[ 5.995424] sysctl table check failed: ioctl/(null) No proc_handler
[ 5.995449] cryptodev: driver 1.14 loaded.
[ OK ] Mounted Huge Pages File System.
[ 6.012256] systemd-journald[129]: Collecting audit messages is enabled.
[ 6.022675] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 6.042310] systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Debug File System.
[ 6.066251] systemd[1]: Mounted Temporary Directory /tmp.
[ OK ] Mounted Temporary Directory /tmp.
[ 6.089975] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Finished Create List of Static Device Nodes.
[ OK ] Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Start psplas…temd progress communication helper.
[ OK ] Finished File System Check on Root Device.
[ OK ] Finished Load Kernel Modules.
[ OK ] Finished Generate network units from Kernel command line.
Mounting FUSE Control File System...
Mounting Kernel Configuration File System...
Starting Remount Root and Kernel File Systems...
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev gracefully...
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File S[ 6.420312] EXT4-fs (mmcblk0p2): re-mounted 8f366dbb-bdc2-49e9-ae1e-f28e6da9c3da r/w.
ystem.
[ OK ] Finished Remount Root and Kernel File Systems.
[ OK ] Finished Apply Kernel Variables.
Starting Flush Journal to Persistent Storage...
[ OK ] Finished Create Static Device Nodes in /dev gracefully.
[ 6.562165] systemd-journald[129]: Received client request to flush runtime journal.
Starting Create Static Device Nodes in /dev...
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Preparation for Local File Systems.
Mounting /var/volatile...
[ 6.720299] audit: type=1334 audit(1748544504.280:2): prog-id=6 op=LOAD
[ 6.727070] audit: type=1334 audit(1748544504.288:3): prog-id=7 op=LOAD
Starting Rule-based Manager for Device Events and Files...
[ OK ] Finished Coldplug All udev Devices.
[ OK ] Mounted /var/volatile.
Starting Load/Save OS Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create System Files and Directories...
[ OK ] Finished Load/Save OS Random Seed.
[ 6.905378] audit: type=1334 audit(1748544504.468:4): prog-id=8 op=LOAD
[ 6.912175] audit: type=1334 audit(1748544504.472:5): prog-id=9 op=LOAD
[ 6.918937] audit: type=1334 audit(1748544504.480:6): prog-id=10 op=LOAD
Starting User Database Manager...
[ OK ] Finished Create System Files and Directories.
[ 6.976092] audit: type=1334 audit(1748544504.536:7): prog-id=11 op=LOAD
Starting Network Name Resolution...
[ 6.998540] audit: type=1334 audit(1748544504.560:8): prog-id=12 op=LOAD
Starting Network Time Synchronization...
Starting Record System Boot/Shutdown in UTMP...
[ OK ] Finished Record System Boot/Shutdown in UTMP.
[ OK ] Started User Database Manager.
[ OK ] Started Rule-based Manager for Device Events and Files.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Set.
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily rotation of log files.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timer Units.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Docker Socket for the API...
[ OK ] Listening on dropbear.socket.
[ OK ] Listening on PC/SC Smart Card Daemon Activation Socket.
[ 7.617390] audit: type=1334 audit(1748545775.580:9): prog-id=13 op=LOAD
Starting D-Bus System Message Bus...
Starting Reboot and dump vmcore via kexec...
[ OK ] Listening on Docker Socket for the API.
[ OK ] Found device /dev/ttyS2.
[ OK ] Reached target Socket Units.
[ OK ] Finished Reboot and dump vmcore via kexec.
[ OK ] Started D-Bus System Message Bus.
[ OK ] Reached target Basic System.
[ OK ] Started Job spooling tools.
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started Periodic Command Scheduler.
Starting Print notice about GPLv3 packages...
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
[ OK ] Started irqbalance daemon.
[ OK ] Started Multiple Spanning Tree Protocol Daemon.
Starting Telephony service...
Starting PulseAudio Sound System...
Starting Expand the rootfs partiti…to full size of the boot device....
[ OK ] Started Seva Launcher Service.
[ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[ 8.165830] audit: type=1334 audit(1748545776.128:10): prog-id=14 op=LOAD
[ 8.175845] audit: type=1334 audit(1748545776.128:11): prog-id=15 op=LOAD
Starting User Login Management...
Starting Telnet Server...
[ OK ] Finished IPv6 Packet Filtering Framework.
[ OK ] Finished IPv4 Packet Filtering Framework.
[ OK ] Started Telephony service.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Reached target Preparation for Network.
Starting Network Configuration...
[ OK ] Finished Telnet Server.
[ 8.400450] Bluetooth: Core ver 2.22
[ 8.404613] NET: Registered PF_BLUETOOTH protocol family
[ 8.410599] Bluetooth: HCI device and connection manager initialized
[ 8.418456] Bluetooth: HCI socket layer initialized
[ 8.424071] Bluetooth: L2CAP socket layer initialized
[ 8.429499] Bluetooth: SCO socket layer initialized
[ OK ] Started PulseAudio Sound System.
[ OK ] Finished Expand the rootfs partition to full size of the boot device..
[ 8.763163] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.798536] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 8.807339] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ OK ] Started User Login Management.
[ OK ] Started Network Configuration.
[ OK ] Reached target Network.
[ 8.961778] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[ 8.971288] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
Starting Enable and configure wl18xx bluetooth stack...
Starting containerd container runtime...
Starting LLDP daemon...
[ OK ] Started Netperf Benchmark Server.
Starting Simple Network Management Protocol (SNMP) Daemon....
Starting Permit User Sessions...
[ OK ] Finished Enable and configure wl18xx bluetooth stack.
[ OK ] Finished Permit User Sessions.
[ OK ] Started emptty display manager.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Reached target Login Prompts.
Starting ti-apps-launcher service...
[ OK ] Started LLDP daemon.
[ 9.461993] pstore: Using crash dump compression: deflate
[ 9.470373] pstore: Registered ramoops as persistent store backend
[ 9.478355] ramoops: using 0x100000@0x9c700000, ecc: 0
[ 9.547028] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[ 9.593491] at24 0-0051: supply vcc not found, using dummy regulator
[ 9.624921] at24 0-0051: 65536 byte 24c512 EEPROM, writable, 1 bytes/write
[ OK ] Started Simple Network Management Protocol (SNMP) Daemon..
[ 9.822317] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[ 9.860190] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 9.872620] platform 78000000.r5f: configured R5F for IPC-only mode
[ 9.894531] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000
[ 9.897801] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
[ 9.913612] remoteproc remoteproc0: 78000000.r5f is available
[ 9.917114] k3-m4-rproc 5000000.m4fss: configured M4F for remoteproc mode
[ 9.932762] remoteproc remoteproc0: attaching to 78000000.r5f
[ 9.948217] remoteproc remoteproc1: 5000000.m4fss is available
[ 9.950895] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node r5f-dma-memory@9da00000
[ 9.973833] remoteproc remoteproc1: powering up 5000000.m4fss
[ 9.975807] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 9.979914] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[ 9.990899] rproc-virtio rproc-virtio.2.auto: registered virtio0 (type 7)
[ 9.993433] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[ 10.000442] remoteproc remoteproc0: remote processor 78000000.r5f is now attached
[ 10.007554] remoteproc remoteproc1: Booting fw image am62-mcu-m4f0_0-fw, size 55100
[ 10.025033] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node m4f-dma-memory@9cb00000
[ 10.035584] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 10.041457] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[ 10.049488] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[ 10.057302] rproc-virtio rproc-virtio.3.auto: registered virtio1 (type 7)
[ 10.064414] remoteproc remoteproc1: remote processor 5000000.m4fss is now up
[ OK ] Reached target Hardware activated USB gadget.
[ 10.183766] sii902x 1-003b: supply iovcc not found, using dummy regulator
[ 10.197404] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
[ 10.210008] i2c i2c-1: Added multiplexed i2c bus 3
[ 10.225642] [drm] Initialized tidss 1.0.0 for 30200000.dss on minor 0
[ 10.237158] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[ 10.245109] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[ 10.304061] PVR_K: 197: Device: fd00000.gpu
[ 10.340213] PVR_K: 197: Read BVNC 33.15.11.3 from HW device registers
[ 10.348398] PVR_K: 197: RGX Device registered with BVNC 33.15.11.3
[ 10.383577] [drm] Initialized pvr 24.2.6643903 for fd00000.gpu on minor 1
[ OK ] Created slice Slice /system/tee-supplicant.
[ OK ] Started TEE Supplicant on teepriv0.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Starting Virtual Console Setup...
[ 10.832555] remoteproc remoteproc3: 30074000.pru is available
[ 10.839256] remoteproc remoteproc2: 30078000.pru is available
[ 10.882107] 30068000.serial: ttyS0 at MMIO 0x30068000 (irq = 432, base_baud = 12000000) is a 16550A
[ OK ] Finished Virtual Console Setup.
[ OK ] Started containerd container runtime.
Starting Save/Restore Sound Card State...
[ OK ] Finished Save/Restore Sound Card State.
[ OK ] Reached target Sound Card.
[ OK ] Created slice Slice /system/systemd-fsck.
Expecting device /dev/mmcblk0p1...
[ OK ] Found device /dev/mmcblk0p1.
Starting File System Check on /dev/mmcblk0p1...
[ OK ] Finished File System Check on /dev/mmcblk0p1.
Mounting /run/media/boot-mmcblk0p1...
[ OK ] Mounted /run/media/boot-mmcblk0p1.
NOTICE: This file system contains the following GPL-3.0 packages:
adwaita-icon-theme-symbolic
autoconf
bash-dev
bash
bc
binutils
cifs-utils
coreutils-stdbuf
coreutils
cpio
cpp-symlinks
cpp
dosfstools
elfutils-dev
elfutils
findutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbserver
gettext
glmark2
gnu-config
grub-common
grub-editenv
grub-efi
gzip
hidapi
kbd-dev
kbd-keymaps-pine
less
libasm1
libatomic-dev
libatomic1
libbfd
libdebuginfod1
libdw1
libelf1
libgcc-s-dev
libgcc1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgettextlib
libgettextsrc
libgmp-dev
libgmp10
libgmpxx4
libgnutls-dev
libgnutls-openssl27
libgomp1
libidn2-0
libidn2-dev
libmpc3
libmpfr6
libopcodes
libqt6core5compat-plugins
libqt6core5compat-qmlplugins
libqt6core5compat6
libqt6shadertools-dev
libqt6shadertools-plugins
libqt6shadertools-qmlplugins
libqt6shadertools6
libreadline-dev
libreadline8
libstdc++-dev
libstdc++6
libtasn1-dev
libunistring-dev
libunistring5
m4
make
nettle-dev
nettle
parted
piglit
qt3d-plugins
qt3d-qmlplugins
qt3d
qtbase-dev
qtbase-examples
qtbase-plugins
qtbase-qmlplugins
qtbase-staticdev
qtbase
qtdeclarative-dev
qtdeclarative-plugins
qtdeclarative-qmlplugins
qtdeclarative-staticdev
qtdeclarative-tools
qtdeclarative
qtlanguageserver-dev
qtlanguageserver-plugins
qtlanguageserver-qmlplugins
qtlanguageserver-staticdev
qtlanguageserver
qtmultimedia-plugins
qtmultimedia-qmlplugins
qtmultimedia
qtquick3d-plugins
qtquick3d-qmlplugins
qtquick3d
qtquicktimeline-plugins
qtquicktimeline-qmlplugins
qtquicktimeline
qtsvg-dev
qtsvg-plugins
qtsvg-qmlplugins
qtsvg
qttools-plugins
qttools-qmlplugins
qttools
qtwayland-dev
qtwayland-plugins
qtwayland-qmlplugins
qtwayland
tar
which
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Finished Print notice about GPLv3 packages.
[ 14.888397] kauditd_printk_skb: 2 callbacks suppressed
[ 14.888419] audit: type=1006 audit(1748545782.852:14): pid=986 uid=0 subj=kernel old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[ 14.907462] audit: type=1300 audit(1748545782.852:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffdea46348 a2=4 a3=1 items=0 ppid=1 pid=986 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egi)
[ 14.935340] audit: type=1327 audit(1748545782.852:14): proctitle="(systemd)"
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project am62xx-evm ttyS2
Arago 2025.01 am62xx-evm ttyS2
am62xx-evm login: [ 16.033957] PVR_K: 994: RGX Firmware image 'rgx.fw.33.15.11.3' loaded
[ 16.045371] PVR_K: 994: Shader binary image 'rgx.sh.33.15.11.3' loaded
am62xx-evm login: [ 21.216422] i2c 0-003f: deferred probe pending: (reason unknown)
BR,
Biao
