Hi, Expert
I try to replace "ti_k3_m4_remoteproc.ko", and found some problems.
Error as below.
ti_k3_m4_remoteproc: version magic '6.6.58-ga7758da17c28-dirty SMP preempt mod_unload aarch64' should be '6.6.58-ti-01497-ga7758da17c28-dirty SMP preempt mod_unload aarch64'
root@am62xx-lp-evm:~# dmesg | grep m4 [ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009cb00000..0x000000009cbfffff (1024 KiB) nomap non-reusable m4f-dma-memory@9cb00000 [ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009cc00000..0x000000009d9fffff (14336 KiB) nomap non-reusable m4f-memory@9cc00000 [ 10.451908] ti_k3_m4_remoteproc: version magic '6.6.58-ga7758da17c28-dirty SMP preempt mod_unload aarch64' should be '6.6.58-ti-01497-ga7758da17c28-dirty SMP preempt mod_unload aarch64' [ 10.517300] ti_k3_m4_remoteproc: version magic '6.6.58-ga7758da17c28-dirty SMP preempt mod_unload aarch64' should be '6.6.58-ti-01497-ga7758da17c28-dirty SMP preempt mod_unload aarch64'
Here is driver location in SD w/ SD boot
/lib/modules/6.6.58-ti-01497-ga7758da17c28-dirty/kernel/drivers/remoteproc/ti_k3_m4_remoteproc.ko
Here is my build environment,
I install all driver under folder "SDK/targetNFS"
these are re-build drivers
gibbs@gibbs-HP-ZBook-15-G5:~/work/am62_lp/ti-processor-sdk-linux-am62xx-evm-10.01.10.04/targetNFS/lib/modules/6.6.58-ga7758da17c28-dirty/kernel/drivers/remoteproc$ ls -l
total 124
-rw-r--r-- 1 root root 29016 九 3 16:35 pru_rproc.ko
-rw-r--r-- 1 root root 26224 九 3 16:35 ti_k3_dsp_remoteproc.ko
-rw-r--r-- 1 root root 23344 九 3 16:35 ti_k3_m4_remoteproc.ko
-rw-r--r-- 1 root root 39752 九 3 16:35 ti_k3_r5_remoteproc.ko
Here is my kernel version.
root@am62xx-lp-evm:/lib/modules/6.6.58-ti-01497-ga7758da17c28-dirty/kernel/drivers/remoteproc# uname -r
I download SDK source code, and direct buld it w/o Yocto
How to solve this problem?
Thank You.
Gibbs
