TDA4VH-Q1: Using custom LDC algorithm with TI LDC hardware accelerator
Part Number: TDA4VH-Q1
Hello TI Experts,
We are working on TDA4VH-Q1 and using SDK RTOS version  :11.00.00.06.
Currently, we are using the standard LDC node provided in the TI SDK, which internally uses the TI LDC hardware accelerator.
Our requirement is to implement a custom LDC algorithm . We would like to know:
Is it possible to replace the TI-provided LDC algorithm with our own custom LDC code, while still using the same LDC hardware accelerator inside VPAC3?
Can you confirm the supported way of integrating a custom LDC algorithm with VPAC3 LDC.
Thank you.
