SK-TDA4VM: How do I run edgeai-gst-apps once I have updated firmware for TIDL-TOOLS?
Part Number: SK-TDA4VM
Is there a way to use the optiflow examples by calling
python3 optiflow/optiflow.py configs/object_detection.yaml
from edgeai-gst-apps after updating the target from edgeai-tidl-tools using the update_target.sh script?
When I try to run optiflow code after the update I get
root@tda4vm-sk:/opt/edgeai-gst-apps# python3 optiflow/optiflow.py configs/object_detection.yaml
APP: Init ... !!!
  1463.382156 s: MEM: Init ... !!!
  1463.382196 s: MEM: Initialized DMA HEAP (fd=17) !!!
  1463.382324 s: MEM: Init ... Done !!!
  1463.382338 s: IPC: Init ... !!!
  1463.443016 s: IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
  1463.452600 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
  1463.455651 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_ERROR
  1463.455685 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_WARNING
  1463.455696 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_INFO
  1463.461501 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MPU-0
  1463.461777 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MPU-1
  1463.461917 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MPU-2
  1463.462084 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MPU-3
  1463.462163 s:  VX_ZONE_INFO: [tivxInitLocal:202] Initialization Done !!!
  1463.462185 s:  VX_ZONE_INFO: Globally Disabled VX_ZONE_INFO
APP: Deinit ... !!!
REMOTE_SERVICE: Deinit ... !!!
REMOTE_SERVICE: Deinit ... Done !!!
  1463.516900 s: IPC: Deinit ... !!!
  1463.517612 s: IPC: DeInit ... Done !!!
  1463.517779 s: MEM: Deinit ... !!!
  1463.517808 s: DDR_SHARED_MEM: Alloc's: 14 alloc's of 20643840 bytes
  1463.517827 s: DDR_SHARED_MEM: Free's : 14 free's  of 20643840 bytes
  1463.517843 s: DDR_SHARED_MEM: Open's : 0 allocs  of 0 bytes
  1463.517865 s: MEM: Deinit ... Done !!!
APP: Deinit ... Done !!!
APP: Init ... !!!
  1463.525691 s: MEM: Init ... !!!
  1463.525775 s: MEM: Initialized DMA HEAP (fd=8) !!!
  1463.525904 s: MEM: Init ... Done !!!
  1463.525932 s: IPC: Init ... !!!
  1463.585073 s: IPC: Init ... Done !!!
  1463.591699 s: GTC Frequency = 200 MHz
  1463.591875 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_ERROR
  1463.591894 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_WARNING
  1463.591959 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_INFO
  1463.592231 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MPU-0
  1463.592401 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MPU-1
  1463.592526 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MPU-2
  1463.592641 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MPU-3
  1463.592712 s:  VX_ZONE_INFO: [tivxInitLocal:202] Initialization Done !!!
  1463.592764 s:  VX_ZONE_INFO: Globally Disabled VX_ZONE_INFO
libtidl_onnxrt_EP loaded 0x2f3d53b0
Final number of subgraphs created are : 1, - Offloaded Nodes - 283, Total Nodes - 283
  1464.592055 s:  VX_ZONE_ERROR: [ownContextSendCmd:1001] Command ack message returned failure cmd_status: -1
  1464.592088 s:  VX_ZONE_ERROR: [ownNodeKernelInit:704] Target kernel, TIVX_CMD_NODE_CREATE failed for node node_113
  1464.592100 s:  VX_ZONE_ERROR: [ownNodeKernelInit:705] Please be sure the target callbacks have been registered for this core
  1464.592110 s:  VX_ZONE_ERROR: [ownNodeKernelInit:706] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
  1464.592120 s:  VX_ZONE_ERROR: [ownGraphNodeKernelInit:793] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
  1464.592128 s:  VX_ZONE_ERROR: [ TIDL subgraph dets ] Node kernel init failed
  1464.592134 s:  VX_ZONE_ERROR: [ TIDL subgraph dets ] Graph verify failed
terminate called after throwing an instance of 'Ort::Exception'
  what():  Create state function failed. Return value:-1
Aborted (core dumped)
root@tda4vm-sk:/opt/edgeai-gst-apps# exit
logout
Connection to tda4vm closed.
Charanjit Singh
