Hello Team,
Hello Team,
Hi Srikanth,
no, TDA4AEN does not support direct analog output. It supports digital output. but digital output can be converted into analog using external video encoder. What is the output resolution that you want to get from analog output?
Brijesh
Understood. Could you recommend external video encoder that can be interface to TDA4VEN SoC to convert Digital output to Analog Output. Standard resolution for analog PAL is typically 720x576 pixels, we are looking for. Please recommend external video encoder chipset.
Srikanth,
Any specific reason for enabling PAL interlaced output from AEN? It should work, but we have not really validated interlaced output.
Brijesh
Hello, Brijesh,
We were being using TDA4V Entry SoC in our design.
We have a customer request for Analog Video output channel i.e., PAL. Do you have an external video encoder chipset to interface TDA4V EN SoC, Please recommend.
Hi Srikanth,
We have not validated NTSC/PAL resolutions, so can't recommend here.
Brijesh
Hello Brijesh,
Does DPI Port (DPI (24-bit RGB parallel interface) can be generated to my target pixel clock 13.5MHz or 27MHz?
Hello Srikanth,
Yes, DPI can output data at 27MHz clock.
Brijesh
Thanks for letting.
Do we know Software configuration registers to set for 27Mhz for DPI port clock output?
Thanks in advance.
