Part Number: TDA4VM
Hii
I have successfully set up the Docker environment for edgeai_tidl_tools and am trying to build the example applications (e.g., object detection) in emulation mode. However, I am facing build failures.
The link steps i followed was from :- https://github.com/TexasInstruments/edgeai-tidl-tools/tree/master?tab=readme-ov-file
- Execute below to compile and run inference of the model in X86_PC
- Inference is validated with both Python and CPP APIs
mkdir build && cd build
cmake ../examples && make -j2 && cd ..
source ./scripts/run_python_examples.sh
python3 ./scripts/gen_test_report.py
In cmake step i m facing this issue .
And the error i m getting is as below ...
root@77f085414cce:/home/root# cd build/
root@77f085414cce:/home/root/build# cmake ../examples && make -j2 && cd ..
-- Detected processor: x86_64
-- TARGET_DEVICE setting to: j721e
-- TARGET_CPU not specicfied using x86
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = edgeai_tidl_examples
CMake Warning at cmake/common.cmake:33 (message):
TENSORFLOW_INSTALL_DIR is not set
Call Stack (most recent call first):
osrt_cpp/post_process/CMakeLists.txt:2 (include)
CMake Warning at cmake/common.cmake:43 (message):
ONNXRT_INSTALL_DIR is not set
CMake Warning at cmake/common.cmake:53 (message):
DLR_INSTALL_DIR is not set
CMake Warning at cmake/common.cmake:67 (message):
OPENCV_INSTALL_DIR is not set
-- Compiling for x86 with j721e config
osrt_cpp/pre_process/CMakeLists.txt:2 (include)
osrt_cpp/utils/CMakeLists.txt:2 (include)
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = tfl_main
osrt_cpp/tfl/CMakeLists.txt:6 (include)
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = tfl_priority_scheduling
osrt_cpp/advanced_examples/tfl/CMakeLists.txt:6 (include)
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = ort_priority_scheduling
osrt_cpp/advanced_examples/ort/CMakeLists.txt:7 (include)
osrt_cpp/advanced_examples/utils/CMakeLists.txt:2 (include)
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = tidlrt_clasification
tidlrt_cpp/CMakeLists.txt:7 (include)
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = dlr_main
osrt_cpp/dlr/CMakeLists.txt:7 (include)
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = tidlrt_priority_scheduling
tidlrt_cpp/advanced_examples/CMakeLists.txt:7 (include)
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = ort_main
osrt_cpp/ort/CMakeLists.txt:7 (include)
-- Configuring done
-- Generating done
-- Build files have been written to: /home/root/build
[ 6%] Building CXX object osrt_cpp/post_process/CMakeFiles/post_process.dir/post_process.cpp.o
[ 6%] Building CXX object osrt_cpp/pre_process/CMakeFiles/pre_process.dir/pre_process.cpp.o
/home/root/examples/osrt_cpp/pre_process/pre_process.cpp:67:10: fatal error: opencv2/core/core.hpp: No such file or directory
67 | #include <opencv2/core/core.hpp>
compilation terminated.
make[2]: *** [osrt_cpp/pre_process/CMakeFiles/pre_process.dir/build.make:76: osrt_cpp/pre_process/CMakeFiles/pre_process.dir/pre_process.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:304: osrt_cpp/pre_process/CMakeFiles/pre_process.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
In file included from /home/root/examples/osrt_cpp/post_process/post_process.cpp:64:
/home/root/examples/osrt_cpp/post_process/post_process.h:74:9: fatal error: opencv2/core.hpp: No such file or directory
74 | #include<opencv2/core.hpp>
make[2]: *** [osrt_cpp/post_process/CMakeFiles/post_process.dir/build.make:76: osrt_cpp/post_process/CMakeFiles/post_process.dir/post_process.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:278: osrt_cpp/post_process/CMakeFiles/post_process.dir/all] Error 2
make: *** [Makefile:136: all] Error 2
ThankYou .
