AM62A7: VPAC-related GStreamer plugins in SBL boot mode
Part Number: AM62A7
SDK ver: 10_00_00_08
Our project utilizes SBL boot mode, employing the binary located at mcu_plus_sdk_am62ax_10_00_00_14/examples/drivers/ipc/ipc_rpmsg_echo_linux/am62ax-sk/r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo_linux.release.appimage. After kernel initialization, errors occurred during GStreamer loading with the following log:
APP: Init ... !!!
   221.509553 s: MEM: Init ... !!!
   221.509677 s: MEM: Initialized DMA HEAP (fd=11) !!!
   221.509998 s: MEM: Init ... Done !!!
   221.510038 s: IPC: Init ... !!!
_rpmsg_char_find_rproc: 78000000.r5f does not have any virtio devices!
_rpmsg_char_find_rproc: 7e000000.dsp does not have any virtio devices!
   221.525868 s: IPC: ERROR: Unable to create TX channels for CPU [mcu1_0] !!!
   221.525885 s: IPC: ERROR: Unable to create TX channels for CPU [c7x_1] !!!
   221.525895 s: IPC: Init ... Done !!!
APP: ERROR: IPC init failed !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
   221.529153 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
   221.532074 s:  VX_ZONE_INIT:Enabled
   221.532115 s:  VX_ZONE_ERROR:Enabled
   221.532125 s:  VX_ZONE_WARNING:Enabled
   221.534339 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-0
   221.534580 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-1
HeatController::HeatController Loaded heater config: Disabled
sv_dvr_media_get_state op_code: 42
   221.867377 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-2
 msg.c>msg_HandleResponse:#462,  response: [1] -> [2] OP=0x806b
   221.867814 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-3
   221.867842 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
   221.869494 s:  VX_ZONE_INIT:[tivxHostInitLocal:106] Initialization Done for HOST !!!
   222.069454 s:  VX_ZONE_ERROR:[ownIpcSendMsg:141] OpenVX send notification failed
   222.069503 s:  VX_ZONE_ERROR:[ownObjDescSend:315] ownIpcSendMsg failed
   222.069516 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node tidl_node
   222.069528 s:  VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core
   222.069539 s:  [  108.399095] max96714 2-002a: stream on!!!!
VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
   222.069555 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 1, kernel com.ti.tidl:1:3 ... failed !!!
   222.069582 s:  VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed
   222.069593 s:  VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed
[TIOVX_MODULES][ERROR] 791: tiovx_modules_verify_graph: Graph Verify failed
   222.120190 s:  VX_ZONE_ERROR:[ownIpcSendMsg:141] OpenVX send notification failed
   222.120239 s:  VX_ZONE_ERROR:[ownObjDescSend:315] ownIpcSendMsg failed
   222.120251 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node scaler_node
   222.120263 s:  VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core
   222.120274 s:  VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
   222.120289 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.hwa.vpac_msc_multi_scale ... failed !!!
   222.120305 s:  VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed
   222.120315 s:  VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed
   222.120613 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:594] Invalid reference
   222.123473 s:  VX_ZONE_ERROR:[ownIpcSendMsg:141] OpenVX send notification failed
   222.123520 s:  VX_ZONE_ERROR:[ownObjDescSend:315] ownIpcSendMsg failed
   222.123532 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node scaler_node
   222.123543 s:  VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core
   222.123554 s:  VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
   222.123568 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.hwa.vpac_msc_multi_scale ... failed !!!
   222.123604 s:  VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed
   222.123615 s:  VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed
   222.123784 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:594] Invalid reference
   222.216106 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
** (media_main:288): CRITICAL **: 01:18:37.947: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
   222.236883 s:  VX_ZONE_ERROR:[ownIpcSendMsg:141] OpenVX send notification failed
   222.236933 s:  VX_ZONE_ERROR:[ownObjDescSend:315] ownIpcSendMsg failed
   222.236945 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node scaler_node
   222.236957 s:  VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core
   222.236969 s:  VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
   222.236983 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.hwa.vpac_msc_multi_scale ... failed !!!
   222.236999 s:  VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed
   222.237009 s:  VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed
   222.237192 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:594] Invalid reference
  • Hi Jason,
    Can you please explain what you did to utilize SBL boot, instead of the normal boot flow as illustrated here: software-dl.ti.com/.../UG-General-Info.html
    Jianzhong
  • First, we incorporated the modifications for the ROI issue in ti-firmware-builder-am62axx-evm-10_00_00_05/imaging/kernels/hwa/vpac_msc/vx_vpac_msc_multi_scale_output_target.c within the firmware builder. Following the documentation, we ultimately compiled the following files.
    DMR5 firmware -> vision_apps/out/AM62A/R5F/FREERTOS/release/vx_app_rtos_linux_mcu1_0_strip.out
    c7x firmware -> vision_apps/out/AM62A/C7504/FREERTOS/release/vx_app_rtos_linux_c7x_1.out
    tispl.bin -> ${LINUX_INSTALL_PATH}/board-support/ti-u-boot-*/am62a-arm64-linux/tispl.bin
    Then, to optimize boot time, we trimmed down uboot and spl, replacing them with SBL boot. Following the SBL boot process manual, we compiled several appimages and flashed them using the following commands. Among them, dm_r5.appimage was compiled using mcu_plus_sdk_am62ax_10_00_00_14/examples/drivers/ipc/ipc_rpmsg_echo_linux/am62ax-sk/r5fss0-0_freertos.
    echo 0 > /sys/block/mmcblk0boot0/force_ro
    dd if=/mnt/sbl_emmc/sbl_emmc_linux_stage1.tiimage of=/dev/mmcblk0boot0 seek=0
    dd if=/mnt/sbl_emmc/sbl_emmc_linux_stage2.appimage of=/dev/mmcblk0boot0 seek=1024
    dd if=/mnt/sbl_emmc/dm_r5.appimage of=/dev/mmcblk0boot0 seek=1536
    dd if=/mnt/sbl_emmc/hsm_m4.appimage of=/dev/mmcblk0boot0 seek=4608
    dd if=/mnt/sbl_emmc/mcu_r5.appimage of=/dev/mmcblk0boot0 seek=8192
    dd if=/mnt/sbl_emmc/linux.appimage.hs_fs of=/dev/mmcblk0boot0 seek=20480
    However, we found that directly using this appimage caused GStreamer in the Linux system to fail and report errors related to mcu1_0 and c7x. To resolve these two issues, we made the following modifications.
    1. Through documentation, we discovered that VPAC is loaded via dm r5f. The reason for the inability to use VPAC-related plugins was suspected to be that the ipc_rpmsg_echo_linux demo was not linked to VPAC-related content. Therefore, we modified the demo's Makefile, copied over vx_app_rtos_linux_mcu1_0.out, and linked this .out file, ultimately compiling an ipc_rpmsg_echo_linux.release.appimage. After flashing this dm_r5f.appimage, the mcu1_0 error disappeared.
    2. Next was the c7x issue. We initially intended to follow the same approach used to fix mcu1_0 by modifying and linking vx_app_rtos_linux_c7x_1.out into ipc_rpmsg_echo_linux.release.appimage. However, we encountered a new problem: vx_app_rtos_linux_c7x_1.out was too large, at a full 20MB, and our Linux Image was already 20MB. Our eMMC's boot0 partition is only 32MB in size, making it impossible to fit both files simultaneously. In the end, we removed the dsp_c75 allocation from the boot0 partition and found that we could still load the c75 firmware after Linux booted.
    With these changes, GStreamer could start normally without any mcu1_0 or c7x errors.
  • However, after this migration, a new issue emerged. When I tested the following GStreamer command, everything worked normally:
    # normal
    gst-launch-1.0 videotestsrc is-live=true pattern=0 ! \
    video/x-raw,width=1920,height=1536,format=NV12,framerate=60/1 ! \
    queue ! \
    tiovxmultiscaler name=multi \
    src_0::roi-startx=0 src_0::roi-starty=0 src_0::roi-width=1920 src_0::roi-height=1280 \
    src_1::roi-startx=0 src_1::roi-starty=0 src_1::roi-width=1920 src_1::roi-height=1080 \
    multi.src_0 ! video/x-raw, width=1280,height=720,format=NV12 ! queue ! mosaic.sink_0 \
    multi.src_1 ! video/x-raw, width=640,height=720,format=NV12 ! queue ! mosaic.sink_1 \
    tiovxmosaic name=mosaic \
    sink_0::startx="<0>" sink_0::starty="<0>" \
    sink_1::startx="<1280>" sink_1::starty="<0>" ! \
    kmssink driver-name=tidss sync=false skip-vsync=true
    But when I added an additional output after ​msc, the entire screen turned green.
    # bug
    queue ! \
    multi.src_2 ! video/x-raw, width=1280,height=720,format=NV12 ! queue ! fakesink \
  • But when I added an additional output after ​msc, the entire screen turned green.
    Sorry about that. I forgot to disable the parallel Y&UV processing. Now is work perfect!
    I will conduct further testing on the performance of this VPAC modification, and will communicate with you if any new issues arise. Thank you and SW teams for your efforts.
    BR,
    Jason
  • Hi Jianzhong
    AM62A7: Gstreamer color format error when splitting video stream - Processors forum - Processors - TI E2E support forums
    After testing, I found that the issue I mentioned earlier still persists and has been successfully reproduced on the EVM as well. Here are the test commands:
    gst-launch-1.0 videotestsrc is-live=true pattern=blue ! \
    queue ! \
    BR,
    Jason
  • Hi Jason,
    Thanks for the update. Your SBL boot procedure looks good.
    I'll look into the ROI issue with our SW team.
    Jianzhong
  • Hi Jianzhong
    Is there any update with this ROI issue?
    I've noticed that the color erro issue occurring after integrating VPAC is more severe than the previous color problem caused by modifying the multiscaler  plugin to enable parallel Y&UV processing. The previous color issue only appeared when the MSC was connected to two outputs - it would disappear with three or more MSC outputs. But this time, any configuration with more than two outputs is abnormal.
    queue ! \
    src_2::roi-startx=0 src_2::roi-starty=0 src_2::roi-width=1920 src_2::roi-height=1080 \
    src_3::roi-startx=0 src_3::roi-starty=0 src_3::roi-width=1920 src_3::roi-height=1080 \
    src_4::roi-startx=0 src_4::roi-starty=0 src_4::roi-width=1920 src_4::roi-height=1080 \
    multi.src_2 ! video/x-raw, width=640,height=720,format=NV12 ! queue ! fakesink \
    multi.src_3 ! video/x-raw, width=640,height=720,format=NV12 ! queue ! fakesink \
    multi.src_4 ! video/x-raw, width=640,height=720,format=NV12 ! queue ! fakesink \
    BR,
    Jason
  • Hi Jason,
    This issue may be caused by tiovxmosaic. Can you try to use a single image as input and dump each ROI output to a file and check if the output files look good?
    Thank you.
    Jianzhong
