Hello All
When running the compile.sh script from the "Debian for AM62X 11_01_05_03" repo: https://github.com/TexasInstruments/armbian-build/tree/2025.07-release
I get an error for compiling atf "compile_atf()"
running the following script from TI Armbian documentation: https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/11_01_05_03_Debian/exports/docs/debian/Building_Debian_Image.html
./compile.sh build BOARD=sk-am62-sip BRANCH=current BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=trixie SKIP_ARMBIAN_REPO=yes
error produced
davidsober@davidsober-AORUS-16X-ASG ~/Desktop/armbian_sd_image_test/armbian-build [2025.07-release]$ ./compile.sh build BOARD=sk-am62-sip BRANCH=current BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=trixie SKIP_ARMBIAN_REPO=yes [🌿] Applying cmdline param [ 'BUILD_MINIMAL': '(unset)' --> 'yes' early ] [🌿] Applying cmdline param [ 'BRANCH': '(unset)' --> 'current' early ] [🌿] Applying cmdline param [ 'BOARD': '(unset)' --> 'sk-am62-sip' early ] [🌿] Applying cmdline param [ 'RELEASE': '(unset)' --> 'trixie' early ] [🌿] Applying cmdline param [ 'SKIP_ARMBIAN_REPO': '(unset)' --> 'yes' early ] [🌿] Applying cmdline param [ 'KERNEL_CONFIGURE': '(unset)' --> 'no' early ] [🌱] Using prebuilt Armbian image as base for 'ubuntu-noble' [ DOCKER_ARMBIAN_BASE_IMAGE: ghcr.io/armbian/docker-armbian-build:armbian-ubuntu-noble-latest ] [🌿] Docker info [ Docker 28.3.3 Kernel:6.8.0-79-generic RAM:31.01GiB CPUs:32 OS:'Ubuntu 22.04.5 LTS' hostname 'davidsober-AORUS-16X-ASG' under 'Linux' - buildx:yes - loop-hacks:yes static-loops:no ] [🌱] Creating [ .dockerignore ] [🌱] Docker launcher [ enabling all extensions looking for Docker dependencies ] [🌱] Extension manager [ processed 20 Extension Methods calls and 60 Extension Method implementations ] [🌱] Python2 not available on host release 'noble' [ ancient u-boot versions might/will fail to build ] [🌱] Extension: fs-cryptroot-support: Adding packages to host dependencies [ cryptsetup openssh-client ] [🌱] Preparing rkdevflash host-side dependencies [ rkdevflash ] [🌱] Creating [ Dockerfile; FROM ghcr.io/armbian/docker-armbian-build:armbian-ubuntu-noble-latest ] [🌱] Armbian docker image [ already exists: ghcr.io/armbian/docker-armbian-build:armbian-ubuntu-noble-latest ] [🌱] Building [ Dockerfile via 'buildx build --progress=plain --load' ] [🔨] #0 building with "default" instance using docker driver [🔨] [🔨] #1 [internal] load build definition from Dockerfile [🔨] #1 transferring dockerfile: 2.11kB done [🔨] #1 DONE 0.0s [🔨] [🔨] #2 [internal] load metadata for ghcr.io/armbian/docker-armbian-build:armbian-ubuntu-noble-latest [🔨] #2 DONE 0.0s [🔨] [🔨] #3 [internal] load .dockerignore [🔨] #3 transferring context: 441B done [🔨] #3 DONE 0.0s [🔨] [🔨] #4 [1/6] FROM ghcr.io/armbian/docker-armbian-build:armbian-ubuntu-noble-latest [🔨] #4 DONE 0.0s [🔨] [🔨] #5 [internal] load build context [🔨] #5 transferring context: 20.25kB 0.0s done [🔨] #5 DONE 0.0s [🔨] [🔨] #6 [3/6] RUN sed -i 's/# en_US.UTF-8/en_US.UTF-8/' /etc/locale.gen [🔨] #6 CACHED [🔨] [🔨] #7 [2/6] RUN echo "--> CACHE MISS IN DOCKERFILE: apt packages." && DEBIAN_FRONTEND=noninteractive apt-get -y update && DEBIAN_FRONTEND=noninteractive apt-get install -y --no-install-recommends bash git psmisc uuid-runtime bc binfmt-support bison bsdextrautils libc6-dev make dpkg-dev gcc ca-certificates ccache cpio device-tree-compiler dialog dirmngr dosfstools dwarves e2fsprogs flex gawk gnupg gpg imagemagick jq kmod libbison-dev libelf-dev libfdt-dev libfile-fcntllock-perl libmpc-dev libfl-dev lz4 libncurses-dev libssl-dev libusb-1.0-0-dev linux-base locales lsof ncurses-base ncurses-term ntpsec-ntpdate patchutils pkg-config pv qemu-user-static arch-test rsync swig u-boot-tools udev uuid-dev zlib1g-dev file tree expect colorized-logs unzip zip pigz xz-utils pbzip2 lzop zstd parted gdisk fdisk aria2 curl axel parallel rdfind python3 libpython3-dev libffi-dev libgnutls28-dev gcc-x86-64-linux-gnu gcc-aarch64-linux-gnu gcc-arm-linux-gnueabi gcc-arm-linux-gnueabihf gcc-riscv64-linux-gnu libc6-amd64-cross mkbootimg g++-aarch64-linux-gnu g++ btrfs-progs cryptsetup openssh-client f2fs-tools nilfs-tools xfsprogs zerofree lvm2 qemu-utils qemu-utils libudev-dev libusb-1.0-0-dev dh-autoreconf build-essential gcc-arm-linux-gnueabi gcc-or1k-elf qemu-utils qemu-utils [🔨] #7 CACHED [🔨] [🔨] #8 [5/6] WORKDIR /armbian [🔨] #8 CACHED [🔨] [🔨] #9 [4/6] RUN locale-gen [🔨] #9 CACHED [🔨] [🔨] #10 [6/6] ADD . /armbian/ [🔨] #10 CACHED [🔨] [🔨] #11 exporting to image [🔨] #11 exporting layers done [🔨] #11 writing image sha256:026e542a76d0a6c27fa68aa430dfd9d9d90b1130a26a85bd3fa5bec3c3f037d5 done [🔨] #11 naming to armbian.local.only/armbian-build:initial done [🔨] #11 DONE 0.0s [🌱] -----------------Relaunching in Docker after 2s------------------ [ here comes the 🐳 ] [🐳|🌿] Applying cmdline param [ 'PREFER_DOCKER': '(unset)' --> 'no' early ] [🐳|🌿] Applying cmdline param [ 'BUILD_MINIMAL': '(unset)' --> 'yes' early ] [🐳|🌿] Applying cmdline param [ 'ARMBIAN_BUILD_UUID': '(unset)' --> '6e6cebff-966b-4ef2-acd5-023eba1538e8' early ] [🐳|🌱] Skip cmdline param [ 'ARMBIAN_RELAUNCHED': already set to 'yes' early ] [🐳|🌿] Applying cmdline param [ 'BRANCH': '(unset)' --> 'current' early ] [🐳|🌿] Applying cmdline param [ 'BOARD': '(unset)' --> 'sk-am62-sip' early ] [🐳|🌿] Applying cmdline param [ 'SKIP_LOG_ARCHIVE': '(unset)' --> 'yes' early ] [🐳|🌿] Applying cmdline param [ 'SET_OWNER_TO_UID': '(unset)' --> '1000' early ] [🐳|🌿] Applying cmdline param [ 'DOCKER_NICE': '(unset)' --> '0' early ] [🐳|🌿] Applying cmdline param [ 'RELEASE': '(unset)' --> 'trixie' early ] [🐳|🌿] Applying cmdline param [ 'SKIP_ARMBIAN_REPO': '(unset)' --> 'yes' early ] [🐳|🌿] Applying cmdline param [ 'KERNEL_CONFIGURE': '(unset)' --> 'no' early ] [🐳|🌱] Starting single build process [ sk-am62-sip ] [🐳|🌱] Checking [ basic host setup ] [🐳|🌱] Build host OS release [ noble ] [🐳|🌱] Build host architecture [ amd64 ] [🐳|🌱] Sourcing board configuration [ /armbian/config/boards/sk-am62-sip.conf ] [🐳|✅] change-tracking: after sourcing board file config/boards/sk-am62-sip.conf [ BOARDFAMILY='k3' ] [🐳|✅] change-tracking: after sourcing board file config/boards/sk-am62-sip.conf [ BOOTCONFIG='am6254xxl_evm_a53_defconfig' ] [🐳|✅] change-tracking: after defaulting LINUXFAMILY to BOARDFAMILY [ LINUXFAMILY='k3' ] [🐳|🌱] Starting main configuration [🐳|🌱] Using REVISION from [ main VERSION file: '25.11.0-trunk' ] [🐳|🌿] Enabling extension [ armbian-config ] [🐳|🌱] Sourcing family configuration [ /armbian/config/sources/families/k3.conf ] [🐳|🌿] Enabling extension [ ti-debpkgs ] [🐳|🌿] Enabling extension [ apa ] [🐳|✅] change-tracking: after sourcing family config [ KERNELSOURCE='https://git.ti.com/cgit/ti-linux-kernel/ti-linux-kernel' ] [🐳|✅] change-tracking: after sourcing family config [ KERNEL_MAJOR_MINOR='6.12' ] [🐳|✅] change-tracking: after sourcing family config [ KERNELBRANCH='tag:11.01.13' ] [🐳|✅] change-tracking: after sourcing family config [ KERNEL_DESCRIPTION='Texas Instruments currently supported SDK (vendor) kernel' ] [🐳|✅] change-tracking: after sourcing family config [ BOOTSOURCE='https://git.ti.com/cgit/ti-u-boot/ti-u-boot' ] [🐳|✅] change-tracking: after sourcing family config [ BOOTBRANCH='tag:11.01.13' ] [🐳|✅] change-tracking: after sourcing family config [ ATFBRANCH='commit:e0c4d3903b382bf34f552af53e6d955fae5283ab' ] [🐳|✅] change-tracking: after sourcing family config [ NETWORKING_STACK='systemd-networkd' ] [🐳|🌱] Sourcing arch configuration [ arm64.conf ] [🐳|✅] change-tracking: after sourcing arm64 arch [ ATFDIR='arm-trusted-firmware' ] [🐳|🌱] Using NETWORKING_STACK [ NETWORKING_STACK: systemd-networkd ] [🐳|🌱] Adding networking extensions [ net-systemd-networkd, net-systemd-timesyncd ] [🐳|🌿] Enabling extension [ net-systemd-networkd ] [🐳|🌿] Enabling extension [ net-systemd-timesyncd ] [🐳|🌱] Extension manager [ processed 16 Extension Methods calls and 33 Extension Method implementations ] [🐳|✅] change-tracking: after user_config hooks [ BOOTPATCHDIR='u-boot-k3' ] [🐳|🌱] Target image will have Armbian Package Archive (APA) enabled by default [ apa ] [🐳|🌱] Extension: net-systemd-timesyncd: Adding extra packages to image [ systemd-timesyncd ] [🐳|🌱] Extension: net-systemd-networkd: Adding extra packages to image [ netplan.io ] [🐳|🌱] KERNELPATCHDIR is unset; using 'archive/k3-6.12' [ common_defaults_for_mainline ] [🐳|✅] change-tracking: after late_family_config hooks [ LINUXCONFIG='linux-k3-current' ] [🐳|✅] change-tracking: after late_family_config hooks [ KERNELPATCHDIR='archive/k3-6.12' ] [🐳|✅] change-tracking: after late_family_config hooks [ KERNEL_PATCH_ARCHIVE_BASE='k3' ] [🐳|✅] change-tracking: after late_family_config hooks [ BOOTDIR='u-boot' ] [🐳|✅] change-tracking: before handling KERNEL_MAJOR_MINOR in config_post_main [ BOOTSOURCEDIR='u-boot-worktree/u-boot/11.01.13' ] [🐳|✅] change-tracking: before handling KERNEL_MAJOR_MINOR in config_post_main [ ATFSOURCEDIR='arm-trusted-firmware/e0c4d3903b382bf34f552af53e6d955fae5283ab' ] [🐳|🚸] Not-installing software-properties-common [ For distro 'Debian' release 'trixie' ] [🐳|✅] change-tracking: before calling extension_finish_config [ LINUXSOURCEDIR='linux-kernel-worktree/6.12__k3__arm64' ] [🐳|🌱] Configuration prepared for BOARD build [ sk-am62-sip.conf ] [🐳|✨] Repeat Build Options (early) [ ./compile.sh build BOARD=sk-am62-sip BRANCH=current BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=trixie SKIP_ARMBIAN_REPO=yes ] [🐳|🌱] Checked directory OK for mount options [ /armbian/.tmp ('main temporary dir') ] [🐳|🌱] Preparing [ host ] [🐳|🌱] Running in container [ Adding provisions for container building ] [🐳|🌱] Python2 not available on host release 'noble' [ ancient u-boot versions might/will fail to build ] [🐳|🌱] Preparing K3 U-Boot host-side dependencies [🐳|🌱] Updating apt host-side for installing host-side packages [ 6 packages ] [🐳|🌱] Installing host-side packages [ python3-yaml python3-jsonschema yamllint python3-cryptography python3-pyelftools python3-setuptools ] [🐳|🔨] debconf: delaying package configuration, since apt-utils is not installed [🐳|🔨] Selecting previously unselected package python3-cffi-backend:amd64. [🐳|🔨] (Reading database ... 29166 files and directories currently installed.) [🐳|🔨] Preparing to unpack .../00-python3-cffi-backend_1.16.0-2build1_amd64.deb ... [🐳|🔨] Unpacking python3-cffi-backend:amd64 (1.16.0-2build1) ... [🐳|🔨] Selecting previously unselected package python3-pkg-resources. [🐳|🔨] Preparing to unpack .../01-python3-pkg-resources_68.1.2-2ubuntu1.2_all.deb ... [🐳|🔨] Unpacking python3-pkg-resources (68.1.2-2ubuntu1.2) ... [🐳|🔨] Selecting previously unselected package python3-yaml. [🐳|🔨] Preparing to unpack .../02-python3-yaml_6.0.1-2build2_amd64.deb ... [🐳|🔨] Unpacking python3-yaml (6.0.1-2build2) ... [🐳|🔨] Selecting previously unselected package python3-attr. [🐳|🔨] Preparing to unpack .../03-python3-attr_23.2.0-2_all.deb ... [🐳|🔨] Unpacking python3-attr (23.2.0-2) ... [🐳|🔨] Selecting previously unselected package python3-cryptography. [🐳|🔨] Preparing to unpack .../04-python3-cryptography_41.0.7-4ubuntu0.1_amd64.deb ... [🐳|🔨] Unpacking python3-cryptography (41.0.7-4ubuntu0.1) ... [🐳|🔨] Selecting previously unselected package python3-pyrsistent:amd64. [🐳|🔨] Preparing to unpack .../05-python3-pyrsistent_0.20.0-1build2_amd64.deb ... [🐳|🔨] Unpacking python3-pyrsistent:amd64 (0.20.0-1build2) ... [🐳|🔨] Selecting previously unselected package python3-jsonschema. [🐳|🔨] Preparing to unpack .../06-python3-jsonschema_4.10.3-2ubuntu1_all.deb ... [🐳|🔨] Unpacking python3-jsonschema (4.10.3-2ubuntu1) ... [🐳|🔨] Selecting previously unselected package python3-pathspec. [🐳|🔨] Preparing to unpack .../07-python3-pathspec_0.12.1-1_all.deb ... [🐳|🔨] Unpacking python3-pathspec (0.12.1-1) ... [🐳|🔨] Selecting previously unselected package python3-setuptools. [🐳|🔨] Preparing to unpack .../08-python3-setuptools_68.1.2-2ubuntu1.2_all.deb ... [🐳|🔨] Unpacking python3-setuptools (68.1.2-2ubuntu1.2) ... [🐳|🔨] Selecting previously unselected package yamllint. [🐳|🔨] Preparing to unpack .../09-yamllint_1.33.0-1_all.deb ... [🐳|🔨] Unpacking yamllint (1.33.0-1) ... [🐳|🔨] Selecting previously unselected package python3-pyelftools. [🐳|🔨] Preparing to unpack .../10-python3-pyelftools_0.30-1_all.deb ... [🐳|🔨] Unpacking python3-pyelftools (0.30-1) ... [🐳|🔨] Setting up python3-pkg-resources (68.1.2-2ubuntu1.2) ... [🐳|🔨] Setting up python3-attr (23.2.0-2) ... [🐳|🔨] Setting up python3-setuptools (68.1.2-2ubuntu1.2) ... [🐳|🔨] Setting up python3-pyelftools (0.30-1) ... [🐳|🔨] Setting up python3-yaml (6.0.1-2build2) ... [🐳|🔨] Setting up python3-pyrsistent:amd64 (0.20.0-1build2) ... [🐳|🔨] Setting up python3-pathspec (0.12.1-1) ... [🐳|🔨] Setting up python3-cffi-backend:amd64 (1.16.0-2build1) ... [🐳|🔨] Setting up yamllint (1.33.0-1) ... [🐳|🔨] Setting up python3-jsonschema (4.10.3-2ubuntu1) ... [🐳|🔨] Setting up python3-cryptography (41.0.7-4ubuntu0.1) ... [🐳|🌱] Ignoring toolchains [ SKIP_EXTERNAL_TOOLCHAINS: yes ] [🐳|🌱] Cross arch build [ target arm64 on host amd64 ] [🐳|🌱] checking [ arch-test for 'arm64' ] [🐳|🔨] arm64: ok [🐳|🌱] Aggregating packages [ rootfs ] [🐳|🌱] Python3 version [ 3.12.3 - 'Python 3.12.3' ] [🐳|🌱] pip3 version [ 25.2 ] [🐳|🌱] Using cached pip packages for Python tools [ 835830e139149e7c7739bbb62aff6d9829147e35b77f79761576fe3ad18a7390 ] [🐳|🔨] Summary: Aggregation: debootstrap: 5; rootfs: 65; image: 2; desktop: 0; apt-sources: 0; hash: 618b3433013acc54 [🐳|🌱] artifact [ uboot :: uboot() ] [🐳|🌱] Using cached [ GIT_INFO_UBOOT ] [🐳|🌱] Getting ORAS manifest [ ORAS manifest from ghcr.io/armbian/os/uboot-sk-am62-sip-current:2025.01-S3c06-P0000-He423-Vd534-Bb703-R448a ] Error response from registry: failed to fetch the content of "ghcr.io/armbian/os/uboot-sk-am62-sip-current:2025.01-S3c06-P0000-He423-Vd534-Bb703-R448a": GET "https://ghcr.io/v2/armbian/os/uboot-sk-am62-sip-current/manifests/2025.01-S3c06-P0000-He423-Vd534-Bb703-R448a": denied: requested access to the resource is denied [🐳|🌱] Artifact is not available in remote cache [ ghcr.io/armbian/os/uboot-sk-am62-sip-current:2025.01-S3c06-P0000-He423-Vd534-Bb703-R448a ] [🐳|🌱] Getting sources from Git [ arm-trusted-firmware e0c4d3903b382bf34f552af53e6d955fae5283ab ] [🐳|🌱] git: Fetch from remote completed, rev-parsing... [ 'arm-trusted-firmware' 'e0c4d3903b382bf34f552af53e6d955fae5283ab' 'HEAD' ] [🐳|✨] Updating submodules [🐳|💥] Error 1 occurred in SUBSHELL [ SUBSHELL at /armbian/lib/functions/general/git.sh:282 ] [🐳|💥] Error 1 occurred in main shell [ at /armbian/lib/functions/general/git.sh:282 fetch_from_repo() --> lib/functions/general/git.sh:282 compile_atf() --> lib/functions/compilation/atf.sh:13 do_with_logging() --> lib/functions/logging/section-logging.sh:81 artifact_uboot_build_from_sources() --> lib/functions/artifacts/artifact-uboot.sh:152 artifact_build_from_sources() --> lib/functions/artifacts/artifacts-obtain.sh:34 obtain_complete_artifact() --> lib/functions/artifacts/artifacts-obtain.sh:280 build_artifact_for_image() --> lib/functions/artifacts/artifacts-obtain.sh:392 main_default_build_packages() --> lib/functions/main/build-packages.sh:102 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:31 do_with_default_build() --> lib/functions/main/default-build.sh:42 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:208 main() --> compile.sh:50 ] [🐳|💥] Cleaning up [ please wait for cleanups to finish ] [🐳|🌿] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-6e6cebff-966b-4ef2-acd5-023eba1538e8.log.ans ] [🐳|🌱] Share log manually: [ use one of the commands below (or add SHARE_LOG=yes next time!) ] [🐳|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-6e6cebff-966b-4ef2-acd5-023eba1538e8.log.ans https://paste.armbian.com/log ] [🐳|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-6e6cebff-966b-4ef2-acd5-023eba1538e8.log.ans https://paste.armbian.de/log ] [🐳|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-6e6cebff-966b-4ef2-acd5-023eba1538e8.log.ans https://paste.next.armbian.com/log ] [🐳|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-6e6cebff-966b-4ef2-acd5-023eba1538e8.log.ans https://paste.armbian.eu/log ] [💥] -------------Docker run failed after 12s-------------------------- [ 🐳 failed ] [🌱] Cleaning up [ please wait for cleanups to finish ]
more detailed error log
# Armbian ANSI build logs for 6e6cebff-966b-4ef2-acd5-023eba1538e8 - use "less -SR" to view # Armbian build at Tue Sep 16 21:22:00 UTC 2025 on d2525a40b166 ------------------------------------------------------------------------------------------------------------ # Repeat build: ./compile.sh build BOARD=sk-am62-sip BRANCH=current BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=trixie SKIP_ARMBIAN_REPO=yes # ARGs: 'PREFER_DOCKER=no' 'BUILD_MINIMAL=yes' 'ARMBIAN_BUILD_UUID=6e6cebff-966b-4ef2-acd5-023eba1538e8' 'ARMBIAN_RELAUNCHED=yes' 'BRANCH=current' 'BOARD=sk-am62-sip' 'SKIP_LOG_ARCHIVE=yes' 'SET_OWNER_TO_UID=1000' 'DOCKER_NICE=0' 'RELEASE=trixie' 'SKIP_ARMBIAN_REPO=yes' 'KERNEL_CONFIGURE=no' 'build' ------------------------------------------------------------------------------------------------------------ # GIT revision commit 928bd6ecb99b397d8f5c562d23c66b59c451944e (HEAD -> 2025.07-release, origin/2025.07-release) Author: Jonas Wood <jw@ti.com> ti: configs: family: k3: Update SDK to 11.01.13 # GIT status On branch 2025.07-release Your branch is up to date with 'origin/2025.07-release'. nothing to commit, working tree clean ### config_early_init.log --> (0) INFO: Starting single build process [ sk-am62-sip ] --> (0) INFO: Checking [ basic host setup ] --> (0) INFO: Build host OS release [ noble ] --> (0) INFO: Build host architecture [ amd64 ] ------------------------------------------------------------------------------------------------------------ ### config_source_board_file.log --> (0) INFO: Sourcing board configuration [ /armbian/config/boards/sk-am62-sip.conf ] --> (0) CHANGE-TRACKING: change-tracking: after sourcing board file config/boards/sk-am62-sip.conf [ BOARDFAMILY='k3' ] --> (0) CHANGE-TRACKING: change-tracking: after sourcing board file config/boards/sk-am62-sip.conf [ BOOTCONFIG='am6254xxl_evm_a53_defconfig' ] --> (0) CHANGE-TRACKING: change-tracking: after defaulting LINUXFAMILY to BOARDFAMILY [ LINUXFAMILY='k3' ] ------------------------------------------------------------------------------------------------------------ ### do_main_configuration.log --> (0) INFO: Starting main configuration --> (0) INFO: Using REVISION from [ main VERSION file: '25.11.0-trunk' ] --> (0) INFO: Enabling extension [ armbian-config ] --> (0) INFO: Sourcing family configuration [ /armbian/config/sources/families/k3.conf ] --> (0) INFO: Enabling extension [ ti-debpkgs ] --> (0) INFO: Enabling extension [ apa ] --> (0) CHANGE-TRACKING: change-tracking: after sourcing family config [ KERNELSOURCE='https://git.ti.com/cgit/ti-linux-kernel/ti-linux-kernel' ] --> (0) CHANGE-TRACKING: change-tracking: after sourcing family config [ KERNEL_MAJOR_MINOR='6.12' ] --> (0) CHANGE-TRACKING: change-tracking: after sourcing family config [ KERNELBRANCH='tag:11.01.13' ] --> (0) CHANGE-TRACKING: change-tracking: after sourcing family config [ KERNEL_DESCRIPTION='Texas Instruments currently supported SDK (vendor) kernel' ] --> (0) CHANGE-TRACKING: change-tracking: after sourcing family config [ BOOTSOURCE='https://git.ti.com/cgit/ti-u-boot/ti-u-boot' ] --> (0) CHANGE-TRACKING: change-tracking: after sourcing family config [ BOOTBRANCH='tag:11.01.13' ] --> (0) CHANGE-TRACKING: change-tracking: after sourcing family config [ ATFBRANCH='commit:e0c4d3903b382bf34f552af53e6d955fae5283ab' ] --> (0) CHANGE-TRACKING: change-tracking: after sourcing family config [ NETWORKING_STACK='systemd-networkd' ] --> (0) INFO: Sourcing arch configuration [ arm64.conf ] --> (0) CHANGE-TRACKING: change-tracking: after sourcing arm64 arch [ ATFDIR='arm-trusted-firmware' ] --> (0) INFO: Using NETWORKING_STACK [ NETWORKING_STACK: systemd-networkd ] --> (0) INFO: Adding networking extensions [ net-systemd-networkd, net-systemd-timesyncd ] --> (0) INFO: Enabling extension [ net-systemd-networkd ] --> (0) INFO: Enabling extension [ net-systemd-timesyncd ] --> (1) INFO: Extension manager [ processed 16 Extension Methods calls and 33 Extension Method implementations ] ------------------------------------------------------------------------------------------------------------ ### do_extra_configuration.log --> (1) CHANGE-TRACKING: change-tracking: after user_config hooks [ BOOTPATCHDIR='u-boot-k3' ] --> (1) INFO: Target image will have Armbian Package Archive (APA) enabled by default [ apa ] --> (1) INFO: Extension: net-systemd-timesyncd: Adding extra packages to image [ systemd-timesyncd ] --> (1) INFO: Extension: net-systemd-networkd: Adding extra packages to image [ netplan.io ] ------------------------------------------------------------------------------------------------------------ ### config_post_main.log --> (1) INFO: KERNELPATCHDIR is unset; using 'archive/k3-6.12' [ common_defaults_for_mainline ] --> (1) CHANGE-TRACKING: change-tracking: after late_family_config hooks [ LINUXCONFIG='linux-k3-current' ] --> (1) CHANGE-TRACKING: change-tracking: after late_family_config hooks [ KERNELPATCHDIR='archive/k3-6.12' ] --> (1) CHANGE-TRACKING: change-tracking: after late_family_config hooks [ KERNEL_PATCH_ARCHIVE_BASE='k3' ] --> (1) CHANGE-TRACKING: change-tracking: after late_family_config hooks [ BOOTDIR='u-boot' ] --> (1) CHANGE-TRACKING: change-tracking: before handling KERNEL_MAJOR_MINOR in config_post_main [ BOOTSOURCEDIR='u-boot-worktree/u-boot/11.01.13' ] --> (1) CHANGE-TRACKING: change-tracking: before handling KERNEL_MAJOR_MINOR in config_post_main [ ATFSOURCEDIR='arm-trusted-firmware/e0c4d3903b382bf34f552af53e6d955fae5283ab' ] --> (1) WARNING: Not-installing software-properties-common [ For distro 'Debian' release 'trixie' ] --> (1) CHANGE-TRACKING: change-tracking: before calling extension_finish_config [ LINUXSOURCEDIR='linux-kernel-worktree/6.12__k3__arm64' ] --> (1) INFO: Configuration prepared for BOARD build [ sk-am62-sip.conf ] --> (1) EXT: Repeat Build Options (early) [ ./compile.sh build BOARD=sk-am62-sip BRANCH=current BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=trixie SKIP_ARMBIAN_REPO=yes ] ------------------------------------------------------------------------------------------------------------ ### check_dir_for_mount_options.log --> (1) INFO: Checked directory OK for mount options [ /armbian/.tmp ('main temporary dir') ] ------------------------------------------------------------------------------------------------------------ ### prepare_host_noninteractive.log --> (1) INFO: Preparing [ host ] --> (1) INFO: Running in container [ Adding provisions for container building ] --> (1) INFO: Python2 not available on host release 'noble' [ ancient u-boot versions might/will fail to build ] --> (1) INFO: Preparing K3 U-Boot host-side dependencies --> (1) INFO: Updating apt host-side for installing host-side packages [ 6 packages ] --> (1) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 update --> (3) INFO: Installing host-side packages [ python3-yaml python3-jsonschema yamllint python3-cryptography python3-pyelftools python3-setuptools ] --> (3) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 --no-install-recommends install python3-yaml python3-jsonschema yamllint python3-cryptography python3-pyelftools python3-setuptools debconf: delaying package configuration, since apt-utils is not installed Selecting previously unselected package python3-cffi-backend:amd64. (Reading database ... 29166 files and directories currently installed.) Preparing to unpack .../00-python3-cffi-backend_1.16.0-2build1_amd64.deb ... Unpacking python3-cffi-backend:amd64 (1.16.0-2build1) ... Selecting previously unselected package python3-pkg-resources. Preparing to unpack .../01-python3-pkg-resources_68.1.2-2ubuntu1.2_all.deb ... Unpacking python3-pkg-resources (68.1.2-2ubuntu1.2) ... Selecting previously unselected package python3-yaml. Preparing to unpack .../02-python3-yaml_6.0.1-2build2_amd64.deb ... Unpacking python3-yaml (6.0.1-2build2) ... Selecting previously unselected package python3-attr. Preparing to unpack .../03-python3-attr_23.2.0-2_all.deb ... Unpacking python3-attr (23.2.0-2) ... Selecting previously unselected package python3-cryptography. Preparing to unpack .../04-python3-cryptography_41.0.7-4ubuntu0.1_amd64.deb ... Unpacking python3-cryptography (41.0.7-4ubuntu0.1) ... Selecting previously unselected package python3-pyrsistent:amd64. Preparing to unpack .../05-python3-pyrsistent_0.20.0-1build2_amd64.deb ... Unpacking python3-pyrsistent:amd64 (0.20.0-1build2) ... Selecting previously unselected package python3-jsonschema. Preparing to unpack .../06-python3-jsonschema_4.10.3-2ubuntu1_all.deb ... Unpacking python3-jsonschema (4.10.3-2ubuntu1) ... Selecting previously unselected package python3-pathspec. Preparing to unpack .../07-python3-pathspec_0.12.1-1_all.deb ... Unpacking python3-pathspec (0.12.1-1) ... Selecting previously unselected package python3-setuptools. Preparing to unpack .../08-python3-setuptools_68.1.2-2ubuntu1.2_all.deb ... Unpacking python3-setuptools (68.1.2-2ubuntu1.2) ... Selecting previously unselected package yamllint. Preparing to unpack .../09-yamllint_1.33.0-1_all.deb ... Unpacking yamllint (1.33.0-1) ... Selecting previously unselected package python3-pyelftools. Preparing to unpack .../10-python3-pyelftools_0.30-1_all.deb ... Unpacking python3-pyelftools (0.30-1) ... Setting up python3-pkg-resources (68.1.2-2ubuntu1.2) ... Setting up python3-attr (23.2.0-2) ... Setting up python3-setuptools (68.1.2-2ubuntu1.2) ... Setting up python3-pyelftools (0.30-1) ... Setting up python3-yaml (6.0.1-2build2) ... Setting up python3-pyrsistent:amd64 (0.20.0-1build2) ... Setting up python3-pathspec (0.12.1-1) ... Setting up python3-cffi-backend:amd64 (1.16.0-2build1) ... Setting up yamllint (1.33.0-1) ... Setting up python3-jsonschema (4.10.3-2ubuntu1) ... Setting up python3-cryptography (41.0.7-4ubuntu0.1) ... --> (7) COMMAND: update-ccache-symlinks --> (7) INFO: Ignoring toolchains [ SKIP_EXTERNAL_TOOLCHAINS: yes ] --> (7) INFO: Cross arch build [ target arm64 on host amd64 ] --> (7) COMMAND: update-binfmts --enable qemu-arm &> /dev/null --> (7) COMMAND: update-binfmts --enable qemu-aarch64 &> /dev/null --> (7) COMMAND: update-binfmts --enable qemu-riscv64 &> /dev/null --> (7) INFO: checking [ arch-test for 'arm64' ] --> (7) COMMAND: arch-test arm64 arm64: ok ------------------------------------------------------------------------------------------------------------ ### aggregate_packages.log --> (7) INFO: Aggregating packages [ rootfs ] --> (7) INFO: Python3 version [ 3.12.3 - 'Python 3.12.3' ] --> (7) INFO: pip3 version [ 25.2 ] --> (7) INFO: Using cached pip packages for Python tools [ 835830e139149e7c7739bbb62aff6d9829147e35b77f79761576fe3ad18a7390 ] --> (7) COMMAND: [...shortened...] /usr/bin/python3 /armbian/lib/tools/aggregation.py Summary: Aggregation: debootstrap: 5; rootfs: 65; image: 2; desktop: 0; apt-sources: 0; hash: 618b3433013acc54 --> (7) COMMAND: rm -f /armbian/.tmp/work-6e6cebff-966b-4ef2-acd5-023eba1538e8/tmp.ESml6Ko5nz ------------------------------------------------------------------------------------------------------------ ### clean_deprecated_mountpoints.log --> (7) INFO: artifact [ uboot :: uboot() ] ------------------------------------------------------------------------------------------------------------ ### artifact_prepare_version.log --> (7) INFO: Using cached [ GIT_INFO_UBOOT ] ------------------------------------------------------------------------------------------------------------ ### artifact_is_available_in_remote_cache.log --> (8) INFO: Getting ORAS manifest [ ORAS manifest from ghcr.io/armbian/os/uboot-sk-am62-sip-current:2025.01-S3c06-P0000-He423-Vd534-Bb703-R448a ] --> (8) INFO: Artifact is not available in remote cache [ ghcr.io/armbian/os/uboot-sk-am62-sip-current:2025.01-S3c06-P0000-He423-Vd534-Bb703-R448a ] ------------------------------------------------------------------------------------------------------------ ### compile_atf.log --> (8) INFO: Getting sources from Git [ arm-trusted-firmware e0c4d3903b382bf34f552af53e6d955fae5283ab ] --> (8) COMMAND: git --no-pager config --global --add safe.directory /armbian/cache/sources/arm-trusted-firmware/e0c4d3903b382bf34f552af53e6d955fae5283ab --> (8) INFO: git: Fetch from remote completed, rev-parsing... [ 'arm-trusted-firmware' 'e0c4d3903b382bf34f552af53e6d955fae5283ab' 'HEAD' ] --> (8) COMMAND: git --no-pager checkout -f -q e0c4d3903b382bf34f552af53e6d955fae5283ab --> (8) COMMAND: git --no-pager clean -q -d -f --> (8) EXT: Updating submodules --> (8) ERROR: Error 1 occurred in SUBSHELL [ SUBSHELL at /armbian/lib/functions/general/git.sh:282 ] --> (8) ERROR: Error 1 occurred in main shell [ at /armbian/lib/functions/general/git.sh:282 fetch_from_repo() --> lib/functions/general/git.sh:282 compile_atf() --> lib/functions/compilation/atf.sh:13 do_with_logging() --> lib/functions/logging/section-logging.sh:81 artifact_uboot_build_from_sources() --> lib/functions/artifacts/artifact-uboot.sh:152 artifact_build_from_sources() --> lib/functions/artifacts/artifacts-obtain.sh:34 obtain_complete_artifact() --> lib/functions/artifacts/artifacts-obtain.sh:280 build_artifact_for_image() --> lib/functions/artifacts/artifacts-obtain.sh:392 main_default_build_packages() --> lib/functions/main/build-packages.sh:102 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:31 do_with_default_build() --> lib/functions/main/default-build.sh:42 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:208 main() --> compile.sh:50 ] --> (8) ERROR: Cleaning up [ please wait for cleanups to finish ] ------------------------------------------------------------------------------------------------------------
I am actively looking into fixing this error. But any assistance would be very appreciated
