TDA4VM: Need LUT table for Multi Cam App for subsampled Resolution (960 * 608)
Part Number: TDA4VM
Platform Details:
  • Processor: TDA4VM (Custom Board)
  • Linux SDK: ti-processor-sdk-linux-j7-evm-08_01_00_07
  • RTOS SDK: ti-processor-sdk-rtos-j721e-evm-08_01_00_13
    We are working with a TDA4VM-based custom board and implementing a multi-camera application using a producer-consumer architecture.
    Our goal is to optimize performance by subsampling the image resolution before writing it to shared memory. However, we still require fisheye correction using the LDC node, which previously worked when using full-resolution data.
    pipeline Details:
    Working Pipeline (with LDC and full resolution):
    capture --> VISS (1936x1220) --> Shared Memory (1936 * 1220 Producer) --> Shared Memory (1936 * 1220 Consumer) --> LDC (1920x1080) --> Scaler (480x320) --> Mosaic
    This pipeline works correctly and applies fisheye correction using the default TI SDK LUT (for input: 1936x1220, output: 1920x1080).
    Modified Pipeline (subsampled, without LDC):
    capture --> VISS (1936x1220) --> Shared Memory (960 * 608 Producer) --> Shared Memory (960 * 608 Consumer) -->  Scaler (480x320) --> Mosaic.
    We perform  2x subsampling by dropping alternate pixels before writing to shared memory. This pipeline also works, but as expected, the output exhibits fisheye distortion, since no LDC correction is applied. please find the output here:
    Target Pipeline (subsampled with LDC):
    capture --> VISS (1936x1220) --> Shared Memory (960 * 608 Producer) --> Shared Memory (960 * 608 Consumer) --> LDC (1920x1080 or 960*608) --> Scaler (480x320) --> Mosaic.
    In this version, we want to maintain the performance benefits of subsampling, but apply fisheye correction via LDC.
    Questions:
  • Is it necessary to regenerate a new LDC LUT specifically for the subsampled resolution (960x608)?
  • What are the recommended tools or workflows to generate a custom LDC LUT for a new resolution such as 960x608 input → 960x608 output or 960x608 input → 1920x1080 output?
    We would appreciate your guidance on how to resolve this issue and ensure correct distortion correction at the subsampled resolution.
    Thank you.
  • Hi Sesha,
    Yes, you would have to create a new LUT for 960x608 LDC input.
    You may take your current LUT and (1) convert it back to (x,y) coordinates for 1920x1080 input image size, (2) convert (x,y) to 960x608 input image size, and (3) create a new LUT for 960x608 input image size.
  • Hi Gang Hua,
    Thanks for the quick response.
     * Copyright (c) 2018 Texas Instruments Incorporated
     * All rights reserved not granted herein.
     * Limited License.
     * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
     * license under copyrights and patents it now or hereafter owns or controls to make,
     * have made, use, import, offer to sell and sell ("Utilize") this software subject to the
     * terms herein.  With respect to the foregoing patent license, such license is granted
     * solely to the extent that any such patent is necessary to Utilize the software alone.
     * The patent license shall not apply to any combinations which include this software,
     * other than combinations with devices manufactured by or for TI ("TI Devices").
     * No hardware patent is licensed hereunder.
     * Redistributions must preserve existing copyright notices and reproduce this license
     * (including the above copyright notice and the disclaimer and (if applicable) source
     * code license limitations below) in the documentation and/or other materials provided
     * with the distribution
     * Redistribution and use in binary form, without modification, are permitted provided
     * that the following conditions are met:
     * *       No reverse engineering, decompilation, or disassembly of this software is
     * permitted with respect to any software provided in binary form.
     * *       any redistribution and use are licensed by TI for use only with TI Devices.
     * *       Nothing shall obligate TI to provide you with source code for the software
     * licensed and provided to you in object code.
     * If software source code is provided to you, modification and redistribution of the
     * source code are permitted provided that the following conditions are met:
     * *       any redistribution and use of the source code, including any resulting derivative
     * works, are licensed by TI for use only with TI Devices.
     * *       any redistribution and use of any object code compiled from the source code
     * and any resulting derivative works, are licensed by TI for use only with TI Devices.
     * Neither the name of Texas Instruments Incorporated nor the names of its suppliers
     * may be used to endorse or promote products derived from this software without
     * specific prior written permission.
     * DISCLAIMER.
     * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS
     * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
     * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
     * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
     * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
     * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
     * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
     * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
     * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
     * OF THE POSSIBILITY OF SUCH DAMAGE.
    #ifndef LDC_LUT_1920_1080_H_
    #define LDC_LUT_1920_1080_H_
    #define LDC_LUT_1920_1080                                                      \
    0xba,0x06,0xe1,0x12,0xb7,0x06,0xc5,0x12,0xb3,0x06,0xaa,0x12,0xb0,0x06,0x8f,0x12,0xac,0x06,0x74,0x12,0xa8,0x06,0x59,0x12,0xa4,0x06,0x3e,0x12,0xa0,0x06,0x23,0x12,0x9c,0x06,0x09,0x12,0x97,0x06,0xee,0x11,0x93,0x06,0xd4,0x11,0x8f,0x06,0xba,0x11,0x8a,0x06,0xa0,0x11,0x86,0x06,0x86,0x11,0x81,0x06,0x6d,0x11,0x7c,0x06,0x53,0x11,0x77,0x06,0x3a,0x11,0x73,0x06,0x20,0x11,0x6e,0x06,0x07,0x11,0x69,0x06,0xee,0x10,0x63,0x06,0xd6,0x10,0x5d,0x06,0xbe,0x10,0x57,0x06,  \
    0xa6,0x10,0x51,0x06,0x8f,0x10,0x4b,0x06,0x78,0x10,0x45,0x06,0x60,0x10,0x3e,0x06,0x49,0x10,0x38,0x06,0x33,0x10,0x32,0x06,0x1c,0x10,0x2b,0x06,0x05,0x10,0x25,0x06,0xee,0x0f,0x1f,0x06,0xd8,0x0f,0x18,0x06,0xc2,0x0f,0x12,0x06,0xab,0x0f,0x0b,0x06,0x95,0x0f,0x04,0x06,0x7f,0x0f,0xfe,0x05,0x69,0x0f,0xf7,0x05,0x54,0x0f,0xf0,0x05,0x3e,0x0f,0xea,0x05,0x28,0x0f,0xe2,0x05,0x14,0x0f,0xda,0x05,0x00,0x0f,0xd3,0x05,0xed,0x0e,0xcb,0x05,0xd9,0x0e,0xc3,0x05,0xc6,0x0e,  \
    0xbb,0x05,0xb3,0x0e,0xb3,0x05,0xa0,0x0e,0xab,0x05,0x8d,0x0e,0xa3,0x05,0x7a,0x0e,0x9b,0x05,0x67,0x0e,0x93,0x05,0x55,0x0e,0x8b,0x05,0x42,0x0e,0x84,0x05,0x30,0x0e,0x7c,0x05,0x1d,0x0e,0x74,0x05,0x0b,0x0e,0x6c,0x05,0xf9,0x0d,0x64,0x05,0xe7,0x0d,0x5d,0x05,0xd4,0x0d,0x58,0x05,0xbd,0x0d,0x53,0x05,0xa6,0x0d,0x4e,0x05,0x8f,0x0d,0x49,0x05,0x79,0x0d,0x44,0x05,0x62,0x0d,0x3f,0x05,0x4b,0x0d,0x3a,0x05,0x34,0x0d,0x35,0x05,0x1e,0x0d,0x30,0x05,0x07,0x0d,0x2b,0x05,  \
    0xf0,0x0c,0x26,0x05,0xda,0x0c,0x21,0x05,0xc3,0x0c,0x1c,0x05,0xad,0x0c,0x17,0x05,0x97,0x0c,0x12,0x05,0x80,0x0c,0x0d,0x05,0x6a,0x0c,0x08,0x05,0x54,0x0c,0x04,0x05,0x3d,0x0c,0xff,0x04,0x27,0x0c,0xfa,0x04,0x11,0x0c,0xf5,0x04,0xfb,0x0b,0xf0,0x04,0xe4,0x0b,0xeb,0x04,0xce,0x0b,0xe7,0x04,0xb8,0x0b,0xe2,0x04,0xa2,0x0b,0xdd,0x04,0x8c,0x0b,0xd8,0x04,0x76,0x0b,0xd4,0x04,0x60,0x0b,0xcf,0x04,0x4a,0x0b,0xca,0x04,0x34,0x0b,0xc5,0x04,0x1f,0x0b,0xc1,0x04,0x09,0x0b,  \
    0xbc,0x04,0xf3,0x0a,0xb7,0x04,0xdd,0x0a,0xb3,0x04,0xc8,0x0a,0xae,0x04,0xb3,0x0a,0xa7,0x04,0xa1,0x0a,0xa1,0x04,0x90,0x0a,0x9b,0x04,0x7e,0x0a,0x95,0x04,0x6d,0x0a,0x8e,0x04,0x5b,0x0a,0x88,0x04,0x4a,0x0a,0x82,0x04,0x38,0x0a,0x7c,0x04,0x27,0x0a,0x76,0x04,0x15,0x0a,0x70,0x04,0x04,0x0a,0x6a,0x04,0xf3,0x09,0x64,0x04,0xe1,0x09,0x5f,0x04,0xd0,0x09,0x59,0x04,0xbe,0x09,0x53,0x04,0xad,0x09,0x4e,0x04,0x9c,0x09,0x48,0x04,0x8a,0x09,0x43,0x04,0x79,0x09,0x3d,0x04,  \
    0x67,0x09,0x38,0x04,0x56,0x09,0x33,0x04,0x44,0x09,0x2e,0x04,0x32,0x09,0x29,0x04,0x20,0x09,0x24,0x04,0x0e,0x09,0x1f,0x04,0xfc,0x08,0x1a,0x04,0xea,0x08,0x15,0x04,0xd8,0x08,0x10,0x04,0xc6,0x08,0x0c,0x04,0xb4,0x08,0x07,0x04,0xa2,0x08,0x03,0x04,0x90,0x08,0xfe,0x03,0x7e,0x08,0xfa,0x03,0x6c,0x08,0xf5,0x03,0x5a,0x08,0xf1,0x03,0x48,0x08,0xec,0x03,0x36,0x08,0xe8,0x03,0x24,0x08,0xe4,0x03,0x11,0x08,0xe0,0x03,0xff,0x07,0xdb,0x03,0xed,0x07,0xd7,0x03,0xdb,0x07,  \
    0xd3,0x03,0xc9,0x07,0xcf,0x03,0xb7,0x07,0xcc,0x03,0xa2,0x07,0xc9,0x03,0x8e,0x07,0xc6,0x03,0x79,0x07,0xc2,0x03,0x65,0x07,0xbf,0x03,0x51,0x07,0xbc,0x03,0x3c,0x07,0xb9,0x03,0x28,0x07,0xb6,0x03,0x13,0x07,0xb3,0x03,0xff,0x06,0xb0,0x03,0xeb,0x06,0xad,0x03,0xd7,0x06,0xaa,0x03,0xc2,0x06,0xa7,0x03,0xae,0x06,0xa4,0x03,0x9a,0x06,0xa1,0x03,0x86,0x06,0x9e,0x03,0x71,0x06,0x9b,0x03,0x5d,0x06,0x98,0x03,0x49,0x06,0x95,0x03,0x35,0x06,0x92,0x03,0x21,0x06,0x90,0x03,  \
    0x0d,0x06,0x8d,0x03,0xf9,0x05,0x8a,0x03,0xe5,0x05,0x87,0x03,0xd1,0x05,0x85,0x03,0xbe,0x05,0x82,0x03,0xac,0x05,0x7f,0x03,0x99,0x05,0x7c,0x03,0x87,0x05,0x79,0x03,0x74,0x05,0x76,0x03,0x62,0x05,0x73,0x03,0x4f,0x05,0x71,0x03,0x3c,0x05,0x6e,0x03,0x2a,0x05,0x6c,0x03,0x17,0x05,0x69,0x03,0x05,0x05,0x66,0x03,0xf2,0x04,0x64,0x03,0xdf,0x04,0x61,0x03,0xcd,0x04,0x5f,0x03,0xba,0x04,0x5d,0x03,0xa7,0x04,0x5a,0x03,0x95,0x04,0x58,0x03,0x82,0x04,0x56,0x03,0x6f,0x04,  \
    0x54,0x03,0x5c,0x04,0x51,0x03,0x4a,0x04,0x4f,0x03,0x37,0x04,0x4d,0x03,0x24,0x04,0x4b,0x03,0x12,0x04,0x49,0x03,0xff,0x03,0x47,0x03,0xec,0x03,0x45,0x03,0xdb,0x03,0x43,0x03,0xc9,0x03,0x41,0x03,0xb7,0x03,0x3f,0x03,0xa6,0x03,0x3d,0x03,0x94,0x03,0x3b,0x03,0x82,0x03,0x39,0x03,0x70,0x03,0x37,0x03,0x5e,0x03,0x36,0x03,0x4d,0x03,0x34,0x03,0x3b,0x03,0x32,0x03,0x29,0x03,0x31,0x03,0x16,0x03,0x2f,0x03,0x04,0x03,0x2e,0x03,0xf2,0x02,0x2c,0x03,0xe0,0x02,0x2b,0x03,  \
    0xce,0x02,0x29,0x03,0xbb,0x02,0x28,0x03,0xa9,0x02,0x27,0x03,0x97,0x02,0x26,0x03,0x84,0x02,0x24,0x03,0x72,0x02,0x23,0x03,0x5f,0x02,0x22,0x03,0x4d,0x02,0x21,0x03,0x3a,0x02,0x20,0x03,0x27,0x02,0x1f,0x03,0x14,0x02,0x1e,0x03,0x02,0x02,0x1d,0x03,0xee,0x01,0x1c,0x03,0xdb,0x01,0x1b,0x03,0xc7,0x01,0x1b,0x03,0xb3,0x01,0x1a,0x03,0xa0,0x01,0x19,0x03,0x8c,0x01,0x18,0x03,0x79,0x01,0x18,0x03,0x65,0x01,0x17,0x03,0x51,0x01,0x16,0x03,0x3e,0x01,0x16,0x03,0x2a,0x01,  \
    0x15,0x03,0x16,0x01,0x15,0x03,0x03,0x01,0x14,0x03,0xef,0x00,0x14,0x03,0xdc,0x00,0x13,0x03,0xc8,0x00,0x13,0x03,0xb4,0x00,0x13,0x03,0xa1,0x00,0x12,0x03,0x8d,0x00,0x12,0x03,0x79,0x00,0x12,0x03,0x66,0x00,0x12,0x03,0x52,0x00,0x11,0x03,0x3e,0x00,0x11,0x03,0x2b,0x00,0x11,0x03,0x17,0x00,0x11,0x03,0x03,0x00,0x11,0x03,0xf0,0xff,0x11,0x03,0xdc,0xff,0x11,0x03,0xc8,0xff,0x11,0x03,0xb5,0xff,0x11,0x03,0xa1,0xff,0x11,0x03,0x8d,0xff,0x11,0x03,0x7a,0xff,0x11,0x03,  \
    0x66,0xff,0x11,0x03,0x52,0xff,0x11,0x03,0x3f,0xff,0x12,0x03,0x2b,0xff,0x12,0x03,0x17,0xff,0x12,0x03,0x04,0xff,0x12,0x03,0xf0,0xfe,0x13,0x03,0xdd,0xfe,0x13,0x03,0xc9,0xfe,0x14,0x03,0xb5,0xfe,0x14,0x03,0xa2,0xfe,0x14,0x03,0x8e,0xfe,0x15,0x03,0x7a,0xfe,0x16,0x03,0x67,0xfe,0x16,0x03,0x53,0xfe,0x17,0x03,0x40,0xfe,0x17,0x03,0x2c,0xfe,0x18,0x03,0x18,0xfe,0x19,0x03,0x05,0xfe,0x19,0x03,0xf1,0xfd,0x1a,0x03,0xde,0xfd,0x1b,0x03,0xca,0xfd,0x1c,0x03,0xb6,0xfd,  \
    0x1c,0x03,0xa3,0xfd,0x1d,0x03,0x8f,0xfd,0x1e,0x03,0x7b,0xfd,0x1f,0x03,0x67,0xfd,0x20,0x03,0x53,0xfd,0x21,0x03,0x3f,0xfd,0x22,0x03,0x2b,0xfd,0x23,0x03,0x17,0xfd,0x24,0x03,0x03,0xfd,0x25,0x03,0xef,0xfc,0x26,0x03,0xda,0xfc,0x27,0x03,0xc6,0xfc,0x28,0x03,0xb2,0xfc,0x29,0x03,0x9e,0xfc,0x2b,0x03,0x8a,0xfc,0x2c,0x03,0x76,0xfc,0x2d,0x03,0x62,0xfc,0x2e,0x03,0x4d,0xfc,0x30,0x03,0x39,0xfc,0x31,0x03,0x25,0xfc,0x32,0x03,0x11,0xfc,0x34,0x03,0xfc,0xfb,0x35,0x03,  \
    0xe8,0xfb,0x37,0x03,0xd4,0xfb,0x38,0x03,0xbf,0xfb,0x3a,0x03,0xab,0xfb,0x3b,0x03,0x97,0xfb,0x3d,0x03,0x82,0xfb,0x3e,0x03,0x6f,0xfb,0x40,0x03,0x5c,0xfb,0x42,0x03,0x49,0xfb,0x44,0x03,0x35,0xfb,0x46,0x03,0x22,0xfb,0x47,0x03,0x0f,0xfb,0x49,0x03,0xfc,0xfa,0x4b,0x03,0xe9,0xfa,0x4d,0x03,0xd6,0xfa,0x4f,0x03,0xc3,0xfa,0x52,0x03,0xb0,0xfa,0x54,0x03,0x9d,0xfa,0x56,0x03,0x8a,0xfa,0x58,0x03,0x77,0xfa,0x5a,0x03,0x64,0xfa,0x5d,0x03,0x51,0xfa,0x5f,0x03,0x3e,0xfa,  \
    0x61,0x03,0x2b,0xfa,0x64,0x03,0x19,0xfa,0x66,0x03,0x06,0xfa,0x69,0x03,0xf3,0xf9,0x6b,0x03,0xe0,0xf9,0x6e,0x03,0xce,0xf9,0x70,0x03,0xbb,0xf9,0x73,0x03,0xa8,0xf9,0x76,0x03,0x96,0xf9,0x79,0x03,0x83,0xf9,0x7b,0x03,0x6f,0xf9,0x7e,0x03,0x5b,0xf9,0x80,0x03,0x47,0xf9,0x83,0x03,0x34,0xf9,0x86,0x03,0x20,0xf9,0x88,0x03,0x0c,0xf9,0x8b,0x03,0xf8,0xf8,0x8e,0x03,0xe5,0xf8,0x91,0x03,0xd1,0xf8,0x94,0x03,0xbd,0xf8,0x97,0x03,0xaa,0xf8,0x9a,0x03,0x96,0xf8,0x9d,0x03,  \
    0x82,0xf8,0xa0,0x03,0x6f,0xf8,0xa3,0x03,0x5b,0xf8,0xa6,0x03,0x47,0xf8,0xa9,0x03,0x33,0xf8,0xac,0x03,0x20,0xf8,0xaf,0x03,0x0c,0xf8,0xb2,0x03,0xf8,0xf7,0xb6,0x03,0xe5,0xf7,0xb9,0x03,0xd1,0xf7,0xbc,0x03,0xbd,0xf7,0xc0,0x03,0xaa,0xf7,0xc3,0x03,0x97,0xf7,0xc7,0x03,0x84,0xf7,0xca,0x03,0x71,0xf7,0xce,0x03,0x5e,0xf7,0xd2,0x03,0x4b,0xf7,0xd6,0x03,0x38,0xf7,0xda,0x03,0x25,0xf7,0xde,0x03,0x12,0xf7,0xe1,0x03,0x00,0xf7,0xe5,0x03,0xed,0xf6,0xea,0x03,0xda,0xf6,  \
    0xee,0x03,0xc7,0xf6,0xf2,0x03,0xb4,0xf6,0xf6,0x03,0xa2,0xf6,0xfa,0x03,0x8f,0xf6,0xfe,0x03,0x7c,0xf6,0x03,0x04,0x69,0xf6,0x07,0x04,0x57,0xf6,0x0b,0x04,0x44,0xf6,0x10,0x04,0x31,0xf6,0x14,0x04,0x1e,0xf6,0x19,0x04,0x0c,0xf6,0x1e,0x04,0xf9,0xf5,0x22,0x04,0xe6,0xf5,0x26,0x04,0xd2,0xf5,0x2b,0x04,0xbe,0xf5,0x2f,0x04,0xaa,0xf5,0x33,0x04,0x96,0xf5,0x38,0x04,0x83,0xf5,0x3c,0x04,0x6f,0xf5,0x41,0x04,0x5b,0xf5,0x45,0x04,0x47,0xf5,0x4a,0x04,0x33,0xf5,0x4f,0x04,  \
    0x20,0xf5,0x53,0x04,0x0c,0xf5,0x58,0x04,0xf8,0xf4,0x5d,0x04,0xe4,0xf4,0x61,0x04,0xd0,0xf4,0x66,0x04,0xbc,0xf4,0x6b,0x04,0xa8,0xf4,0x70,0x04,0x95,0xf4,0x75,0x04,0x81,0xf4,0x7a,0x04,0x6d,0xf4,0x7f,0x04,0x59,0xf4,0x84,0x04,0x45,0xf4,0x8a,0x04,0x32,0xf4,0x8f,0x04,0x1f,0xf4,0x95,0x04,0x0c,0xf4,0x9a,0x04,0xf9,0xf3,0xa0,0x04,0xe6,0xf3,0xa5,0x04,0xd3,0xf3,0xab,0x04,0xc0,0xf3,0xb1,0x04,0xac,0xf3,0xb6,0x04,0x99,0xf3,0xbc,0x04,0x86,0xf3,0xc2,0x04,0x73,0xf3,  \
    0xc8,0x04,0x60,0xf3,0xce,0x04,0x4c,0xf3,0xd4,0x04,0x39,0xf3,0xda,0x04,0x26,0xf3,0xe0,0x04,0x12,0xf3,0xe6,0x04,0xff,0xf2,0xec,0x04,0xec,0xf2,0xf2,0x04,0xd8,0xf2,0xf7,0x04,0xc2,0xf2,0xfc,0x04,0xac,0xf2,0x00,0x05,0x95,0xf2,0x05,0x05,0x7f,0xf2,0x0a,0x05,0x68,0xf2,0x0f,0x05,0x52,0xf2,0x13,0x05,0x3b,0xf2,0x18,0x05,0x24,0xf2,0x1d,0x05,0x0e,0xf2,0x22,0x05,0xf7,0xf1,0x27,0x05,0xe0,0xf1,0x2b,0x05,0xca,0xf1,0x30,0x05,0xb3,0xf1,0x35,0x05,0x9c,0xf1,0x3a,0x05,  \
    0x85,0xf1,0x3f,0x05,0x6e,0xf1,0x44,0x05,0x57,0xf1,0x48,0x05,0x40,0xf1,0x4e,0x05,0x2a,0xf1,0x54,0x05,0x15,0xf1,0x5b,0x05,0x01,0xf1,0x61,0x05,0xec,0xf0,0x68,0x05,0xd8,0xf0,0x6e,0x05,0xc3,0xf0,0x74,0x05,0xaf,0xf0,0x7b,0x05,0x9a,0xf0,0x81,0x05,0x85,0xf0,0x88,0x05,0x70,0xf0,0x8e,0x05,0x5b,0xf0,0x95,0x05,0x46,0xf0,0x9b,0x05,0x31,0xf0,0xa1,0x05,0x1c,0xf0,0xa8,0x05,0x07,0xf0,0xae,0x05,0xf1,0xef,0xb5,0x05,0xdc,0xef,0xbb,0x05,0xc6,0xef,0xc1,0x05,0xb0,0xef,  \
    0xc8,0x05,0x9b,0xef,0xce,0x05,0x85,0xef,0xd5,0x05,0x70,0xef,0xdb,0x05,0x5a,0xef,0xe2,0x05,0x44,0xef,0xe8,0x05,0x2e,0xef,0xef,0x05,0x18,0xef,0xf5,0x05,0x02,0xef,0xfb,0x05,0xec,0xee,0x01,0x06,0xd5,0xee,0x08,0x06,0xbe,0xee,0x0e,0x06,0xa7,0xee,0x14,0x06,0x90,0xee,0x1a,0x06,0x79,0xee,0x1f,0x06,0x62,0xee,0x25,0x06,0x4b,0xee,0x2b,0x06,0x33,0xee,0x31,0x06,0x1b,0xee,0x36,0x06,0x03,0xee,0x3c,0x06,0xeb,0xed,0x40,0x06,0xd2,0xed,0x44,0x06,0xb8,0xed,0x48,0x06,  \
    0x9d,0xed,0x4c,0x06,0x83,0xed,0x50,0x06,0x68,0xed,0x54,0x06,0x4d,0xed,0x57,0x06,0x32,0xed,0x5b,0x06,0x17,0xed,0x5e,0x06,0xfc,0xec,0x61,0x06,0xe1,0xec,0x65,0x06,0xc5,0xec,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0xab,0x06,0xd6,0x12,0xa7,0x06,0xbb,0x12,0xa4,0x06,0x9f,0x12,0xa0,0x06,0x84,0x12,0x9c,0x06,0x69,0x12,0x98,0x06,0x4e,0x12,0x94,0x06,0x34,0x12,0x90,0x06,0x19,0x12,0x8c,0x06,0xff,0x11,0x87,0x06,0xe4,0x11,0x83,0x06,0xca,0x11,0x7e,0x06,0xb0,0x11,0x7a,0x06,0x96,0x11,0x75,0x06,0x7c,0x11,0x71,0x06,0x63,0x11,0x6c,0x06,0x49,0x11,0x67,0x06,0x30,0x11,0x62,0x06,0x16,0x11,0x5d,0x06,0xfd,0x10,0x58,0x06,0xe4,0x10,0x52,0x06,0xcc,0x10,0x4c,0x06,  \
    0xb4,0x10,0x46,0x06,0x9d,0x10,0x40,0x06,0x85,0x10,0x3a,0x06,0x6e,0x10,0x34,0x06,0x57,0x10,0x2d,0x06,0x40,0x10,0x27,0x06,0x29,0x10,0x20,0x06,0x12,0x10,0x1a,0x06,0xfb,0x0f,0x13,0x06,0xe5,0x0f,0x0d,0x06,0xcf,0x0f,0x06,0x06,0xb8,0x0f,0x00,0x06,0xa2,0x0f,0xf9,0x05,0x8c,0x0f,0xf2,0x05,0x76,0x0f,0xec,0x05,0x60,0x0f,0xe5,0x05,0x4a,0x0f,0xde,0x05,0x35,0x0f,0xd7,0x05,0x1f,0x0f,0xd0,0x05,0x0b,0x0f,0xc8,0x05,0xf7,0x0e,0xc0,0x05,0xe4,0x0e,0xb8,0x05,0xd0,0x0e,  \
    0xb0,0x05,0xbd,0x0e,0xa8,0x05,0xaa,0x0e,0xa0,0x05,0x97,0x0e,0x98,0x05,0x84,0x0e,0x90,0x05,0x71,0x0e,0x88,0x05,0x5e,0x0e,0x80,0x05,0x4b,0x0e,0x78,0x05,0x39,0x0e,0x70,0x05,0x26,0x0e,0x68,0x05,0x14,0x0e,0x61,0x05,0x02,0x0e,0x59,0x05,0xf0,0x0d,0x51,0x05,0xde,0x0d,0x49,0x05,0xcb,0x0d,0x44,0x05,0xb4,0x0d,0x3f,0x05,0x9d,0x0d,0x3a,0x05,0x87,0x0d,0x35,0x05,0x70,0x0d,0x30,0x05,0x59,0x0d,0x2b,0x05,0x42,0x0d,0x26,0x05,0x2c,0x0d,0x21,0x05,0x15,0x0d,0x1c,0x05,  \
    0xff,0x0c,0x17,0x05,0xe8,0x0c,0x12,0x05,0xd2,0x0c,0x0d,0x05,0xbb,0x0c,0x08,0x05,0xa5,0x0c,0x03,0x05,0x8f,0x0c,0xfe,0x04,0x78,0x0c,0xf9,0x04,0x62,0x0c,0xf4,0x04,0x4c,0x0c,0xef,0x04,0x36,0x0c,0xea,0x04,0x1f,0x0c,0xe5,0x04,0x09,0x0c,0xe0,0x04,0xf3,0x0b,0xdb,0x04,0xdd,0x0b,0xd6,0x04,0xc7,0x0b,0xd1,0x04,0xb1,0x0b,0xcc,0x04,0x9b,0x0b,0xc8,0x04,0x85,0x0b,0xc3,0x04,0x6f,0x0b,0xbe,0x04,0x59,0x0b,0xb9,0x04,0x43,0x0b,0xb4,0x04,0x2e,0x0b,0xb0,0x04,0x18,0x0b,  \
    0xab,0x04,0x02,0x0b,0xa6,0x04,0xed,0x0a,0xa2,0x04,0xd7,0x0a,0x9d,0x04,0xc1,0x0a,0x98,0x04,0xac,0x0a,0x91,0x04,0x9b,0x0a,0x8b,0x04,0x89,0x0a,0x85,0x04,0x78,0x0a,0x7e,0x04,0x66,0x0a,0x78,0x04,0x55,0x0a,0x72,0x04,0x44,0x0a,0x6c,0x04,0x32,0x0a,0x66,0x04,0x21,0x0a,0x60,0x04,0x0f,0x0a,0x5a,0x04,0xfe,0x09,0x54,0x04,0xed,0x09,0x4e,0x04,0xdb,0x09,0x48,0x04,0xca,0x09,0x42,0x04,0xb8,0x09,0x3d,0x04,0xa7,0x09,0x37,0x04,0x96,0x09,0x31,0x04,0x84,0x09,0x2c,0x04,  \
    0x73,0x09,0x26,0x04,0x62,0x09,0x21,0x04,0x50,0x09,0x1c,0x04,0x3f,0x09,0x17,0x04,0x2d,0x09,0x12,0x04,0x1b,0x09,0x0d,0x04,0x09,0x09,0x08,0x04,0xf7,0x08,0x03,0x04,0xe5,0x08,0xfe,0x03,0xd3,0x08,0xf9,0x03,0xc1,0x08,0xf4,0x03,0xaf,0x08,0xf0,0x03,0x9d,0x08,0xeb,0x03,0x8b,0x08,0xe7,0x03,0x79,0x08,0xe2,0x03,0x67,0x08,0xde,0x03,0x55,0x08,0xd9,0x03,0x43,0x08,0xd5,0x03,0x31,0x08,0xd0,0x03,0x1f,0x08,0xcc,0x03,0x0d,0x08,0xc8,0x03,0xfa,0x07,0xc4,0x03,0xe8,0x07,  \
    0xc0,0x03,0xd6,0x07,0xbc,0x03,0xc4,0x07,0xb8,0x03,0xb2,0x07,0xb4,0x03,0x9e,0x07,0xb1,0x03,0x89,0x07,0xae,0x03,0x75,0x07,0xaa,0x03,0x60,0x07,0xa7,0x03,0x4c,0x07,0xa4,0x03,0x38,0x07,0xa1,0x03,0x23,0x07,0x9e,0x03,0x0f,0x07,0x9b,0x03,0xfb,0x06,0x97,0x03,0xe7,0x06,0x94,0x03,0xd2,0x06,0x91,0x03,0xbe,0x06,0x8e,0x03,0xaa,0x06,0x8b,0x03,0x96,0x06,0x88,0x03,0x82,0x06,0x85,0x03,0x6e,0x06,0x83,0x03,0x59,0x06,0x80,0x03,0x45,0x06,0x7d,0x03,0x31,0x06,0x7a,0x03,  \
    0x1d,0x06,0x77,0x03,0x09,0x06,0x74,0x03,0xf5,0x05,0x72,0x03,0xe1,0x05,0x6f,0x03,0xce,0x05,0x6c,0x03,0xbb,0x05,0x69,0x03,0xa9,0x05,0x66,0x03,0x96,0x05,0x63,0x03,0x83,0x05,0x60,0x03,0x71,0x05,0x5e,0x03,0x5e,0x05,0x5b,0x03,0x4c,0x05,0x58,0x03,0x39,0x05,0x55,0x03,0x27,0x05,0x53,0x03,0x14,0x05,0x50,0x03,0x02,0x05,0x4e,0x03,0xef,0x04,0x4b,0x03,0xdc,0x04,0x49,0x03,0xca,0x04,0x46,0x03,0xb7,0x04,0x44,0x03,0xa5,0x04,0x41,0x03,0x92,0x04,0x3f,0x03,0x7f,0x04,  \
    0x3d,0x03,0x6d,0x04,0x3b,0x03,0x5a,0x04,0x38,0x03,0x47,0x04,0x36,0x03,0x35,0x04,0x34,0x03,0x22,0x04,0x32,0x03,0x0f,0x04,0x30,0x03,0xfc,0x03,0x2e,0x03,0xea,0x03,0x2c,0x03,0xd8,0x03,0x2a,0x03,0xc7,0x03,0x28,0x03,0xb5,0x03,0x26,0x03,0xa4,0x03,0x24,0x03,0x92,0x03,0x22,0x03,0x80,0x03,0x20,0x03,0x6e,0x03,0x1e,0x03,0x5c,0x03,0x1d,0x03,0x4a,0x03,0x1b,0x03,0x39,0x03,0x19,0x03,0x27,0x03,0x18,0x03,0x15,0x03,0x16,0x03,0x02,0x03,0x14,0x03,0xf0,0x02,0x13,0x03,  \
    0xde,0x02,0x12,0x03,0xcc,0x02,0x10,0x03,0xba,0x02,0x0f,0x03,0xa7,0x02,0x0d,0x03,0x95,0x02,0x0c,0x03,0x83,0x02,0x0b,0x03,0x70,0x02,0x0a,0x03,0x5e,0x02,0x09,0x03,0x4b,0x02,0x08,0x03,0x38,0x02,0x07,0x03,0x26,0x02,0x06,0x03,0x13,0x02,0x05,0x03,0x00,0x02,0x04,0x03,0xed,0x01,0x03,0x03,0xd9,0x01,0x02,0x03,0xc6,0x01,0x01,0x03,0xb2,0x01,0x00,0x03,0x9f,0x01,0x00,0x03,0x8b,0x01,0xff,0x02,0x78,0x01,0xfe,0x02,0x64,0x01,0xfe,0x02,0x50,0x01,0xfd,0x02,0x3d,0x01,  \
    0xfc,0x02,0x29,0x01,0xfc,0x02,0x16,0x01,0xfb,0x02,0x02,0x01,0xfb,0x02,0xee,0x00,0xfa,0x02,0xdb,0x00,0xfa,0x02,0xc7,0x00,0xfa,0x02,0xb4,0x00,0xf9,0x02,0xa0,0x00,0xf9,0x02,0x8c,0x00,0xf9,0x02,0x79,0x00,0xf8,0x02,0x65,0x00,0xf8,0x02,0x52,0x00,0xf8,0x02,0x3e,0x00,0xf8,0x02,0x2a,0x00,0xf8,0x02,0x17,0x00,0xf7,0x02,0x03,0x00,0xf7,0x02,0xf0,0xff,0xf7,0x02,0xdc,0xff,0xf7,0x02,0xc8,0xff,0xf7,0x02,0xb5,0xff,0xf7,0x02,0xa1,0xff,0xf7,0x02,0x8e,0xff,0xf7,0x02,  \
    0x7a,0xff,0xf8,0x02,0x66,0xff,0xf8,0x02,0x53,0xff,0xf8,0x02,0x3f,0xff,0xf8,0x02,0x2b,0xff,0xf8,0x02,0x18,0xff,0xf9,0x02,0x04,0xff,0xf9,0x02,0xf1,0xfe,0xf9,0x02,0xdd,0xfe,0xfa,0x02,0xca,0xfe,0xfa,0x02,0xb6,0xfe,0xfb,0x02,0xa2,0xfe,0xfb,0x02,0x8f,0xfe,0xfc,0x02,0x7b,0xfe,0xfc,0x02,0x68,0xfe,0xfd,0x02,0x54,0xfe,0xfd,0x02,0x41,0xfe,0xfe,0x02,0x2d,0xfe,0xff,0x02,0x19,0xfe,0xff,0x02,0x06,0xfe,0x00,0x03,0xf2,0xfd,0x01,0x03,0xdf,0xfd,0x01,0x03,0xcb,0xfd,  \
    0x02,0x03,0xb8,0xfd,0x03,0x03,0xa4,0xfd,0x04,0x03,0x90,0xfd,0x05,0x03,0x7c,0xfd,0x06,0x03,0x68,0xfd,0x07,0x03,0x54,0xfd,0x08,0x03,0x40,0xfd,0x09,0x03,0x2c,0xfd,0x0a,0x03,0x18,0xfd,0x0b,0x03,0x04,0xfd,0x0c,0x03,0xf0,0xfc,0x0d,0x03,0xdc,0xfc,0x0e,0x03,0xc8,0xfc,0x0f,0x03,0xb4,0xfc,0x10,0x03,0xa0,0xfc,0x12,0x03,0x8c,0xfc,0x13,0x03,0x78,0xfc,0x14,0x03,0x64,0xfc,0x15,0x03,0x50,0xfc,0x17,0x03,0x3b,0xfc,0x18,0x03,0x27,0xfc,0x19,0x03,0x13,0xfc,0x1b,0x03,  \
    0xff,0xfb,0x1c,0x03,0xea,0xfb,0x1e,0x03,0xd6,0xfb,0x1f,0x03,0xc2,0xfb,0x21,0x03,0xae,0xfb,0x22,0x03,0x99,0xfb,0x24,0x03,0x85,0xfb,0x26,0x03,0x72,0xfb,0x27,0x03,0x5f,0xfb,0x29,0x03,0x4c,0xfb,0x2b,0x03,0x38,0xfb,0x2d,0x03,0x25,0xfb,0x2f,0x03,0x12,0xfb,0x31,0x03,0xff,0xfa,0x33,0x03,0xec,0xfa,0x35,0x03,0xd9,0xfa,0x37,0x03,0xc6,0xfa,0x39,0x03,0xb3,0xfa,0x3b,0x03,0xa0,0xfa,0x3d,0x03,0x8d,0xfa,0x40,0x03,0x7b,0xfa,0x42,0x03,0x68,0xfa,0x44,0x03,0x55,0xfa,  \
    0x47,0x03,0x42,0xfa,0x49,0x03,0x2f,0xfa,0x4c,0x03,0x1c,0xfa,0x4e,0x03,0x0a,0xfa,0x51,0x03,0xf7,0xf9,0x53,0x03,0xe4,0xf9,0x56,0x03,0xd2,0xf9,0x58,0x03,0xbf,0xf9,0x5b,0x03,0xac,0xf9,0x5e,0x03,0x9a,0xf9,0x61,0x03,0x87,0xf9,0x63,0x03,0x73,0xf9,0x66,0x03,0x5f,0xf9,0x69,0x03,0x4c,0xf9,0x6b,0x03,0x38,0xf9,0x6e,0x03,0x24,0xf9,0x71,0x03,0x11,0xf9,0x74,0x03,0xfd,0xf8,0x76,0x03,0xea,0xf8,0x79,0x03,0xd6,0xf8,0x7c,0x03,0xc2,0xf8,0x7f,0x03,0xaf,0xf8,0x82,0x03,  \
    0x9b,0xf8,0x85,0x03,0x87,0xf8,0x88,0x03,0x74,0xf8,0x8b,0x03,0x60,0xf8,0x8f,0x03,0x4d,0xf8,0x92,0x03,0x39,0xf8,0x95,0x03,0x25,0xf8,0x98,0x03,0x12,0xf8,0x9b,0x03,0xfe,0xf7,0x9f,0x03,0xeb,0xf7,0xa2,0x03,0xd7,0xf7,0xa6,0x03,0xc3,0xf7,0xa9,0x03,0xb0,0xf7,0xad,0x03,0x9d,0xf7,0xb0,0x03,0x8a,0xf7,0xb4,0x03,0x77,0xf7,0xb8,0x03,0x64,0xf7,0xbc,0x03,0x51,0xf7,0xc0,0x03,0x3f,0xf7,0xc3,0x03,0x2c,0xf7,0xc7,0x03,0x19,0xf7,0xcb,0x03,0x06,0xf7,0xd0,0x03,0xf4,0xf6,  \
    0xd4,0x03,0xe1,0xf6,0xd8,0x03,0xce,0xf6,0xdc,0x03,0xbb,0xf6,0xe0,0x03,0xa9,0xf6,0xe5,0x03,0x96,0xf6,0xe9,0x03,0x83,0xf6,0xed,0x03,0x71,0xf6,0xf2,0x03,0x5e,0xf6,0xf6,0x03,0x4b,0xf6,0xfb,0x03,0x39,0xf6,0xff,0x03,0x26,0xf6,0x04,0x04,0x13,0xf6,0x09,0x04,0x01,0xf6,0x0d,0x04,0xee,0xf5,0x12,0x04,0xda,0xf5,0x16,0x04,0xc6,0xf5,0x1a,0x04,0xb2,0xf5,0x1f,0x04,0x9f,0xf5,0x23,0x04,0x8b,0xf5,0x28,0x04,0x77,0xf5,0x2d,0x04,0x64,0xf5,0x31,0x04,0x50,0xf5,0x36,0x04,  \
    0x3c,0xf5,0x3b,0x04,0x28,0xf5,0x40,0x04,0x15,0xf5,0x44,0x04,0x01,0xf5,0x49,0x04,0xed,0xf4,0x4e,0x04,0xd9,0xf4,0x53,0x04,0xc6,0xf4,0x58,0x04,0xb2,0xf4,0x5d,0x04,0x9e,0xf4,0x62,0x04,0x8a,0xf4,0x67,0x04,0x77,0xf4,0x6c,0x04,0x63,0xf4,0x72,0x04,0x4f,0xf4,0x77,0x04,0x3d,0xf4,0x7d,0x04,0x2a,0xf4,0x82,0x04,0x17,0xf4,0x88,0x04,0x04,0xf4,0x8e,0x04,0xf1,0xf3,0x93,0x04,0xdd,0xf3,0x99,0x04,0xca,0xf3,0x9f,0x04,0xb7,0xf3,0xa5,0x04,0xa4,0xf3,0xab,0x04,0x91,0xf3,  \
    0xb1,0x04,0x7e,0xf3,0xb7,0x04,0x6b,0xf3,0xbd,0x04,0x58,0xf3,0xc3,0x04,0x45,0xf3,0xc9,0x04,0x31,0xf3,0xcf,0x04,0x1e,0xf3,0xd6,0x04,0x0b,0xf3,0xdc,0x04,0xf8,0xf2,0xe2,0x04,0xe4,0xf2,0xe7,0x04,0xce,0xf2,0xec,0x04,0xb8,0xf2,0xf1,0x04,0xa2,0xf2,0xf6,0x04,0x8b,0xf2,0xfb,0x04,0x75,0xf2,0x00,0x05,0x5f,0xf2,0x05,0x05,0x48,0xf2,0x0a,0x05,0x32,0xf2,0x0e,0x05,0x1b,0xf2,0x13,0x05,0x05,0xf2,0x18,0x05,0xee,0xf1,0x1d,0x05,0xd7,0xf1,0x22,0x05,0xc1,0xf1,0x27,0x05,  \
    0xaa,0xf1,0x2c,0x05,0x93,0xf1,0x31,0x05,0x7c,0xf1,0x36,0x05,0x66,0xf1,0x3b,0x05,0x4f,0xf1,0x41,0x05,0x39,0xf1,0x47,0x05,0x24,0xf1,0x4e,0x05,0x10,0xf1,0x55,0x05,0xfc,0xf0,0x5b,0x05,0xe8,0xf0,0x62,0x05,0xd3,0xf0,0x69,0x05,0xbf,0xf0,0x6f,0x05,0xaa,0xf0,0x76,0x05,0x95,0xf0,0x7d,0x05,0x81,0xf0,0x83,0x05,0x6c,0xf0,0x8a,0x05,0x57,0xf0,0x90,0x05,0x42,0xf0,0x97,0x05,0x2d,0xf0,0x9e,0x05,0x17,0xf0,0xa4,0x05,0x02,0xf0,0xab,0x05,0xed,0xef,0xb1,0x05,0xd7,0xef,  \
    0xb8,0x05,0xc1,0xef,0xbf,0x05,0xac,0xef,0xc5,0x05,0x97,0xef,0xcc,0x05,0x81,0xef,0xd3,0x05,0x6c,0xef,0xd9,0x05,0x56,0xef,0xe0,0x05,0x40,0xef,0xe7,0x05,0x2a,0xef,0xed,0x05,0x14,0xef,0xf4,0x05,0xfe,0xee,0xfa,0x05,0xe7,0xee,0x00,0x06,0xd1,0xee,0x07,0x06,0xba,0xee,0x0d,0x06,0xa3,0xee,0x13,0x06,0x8c,0xee,0x19,0x06,0x75,0xee,0x1f,0x06,0x5d,0xee,0x25,0x06,0x46,0xee,0x2b,0x06,0x2e,0xee,0x30,0x06,0x16,0xee,0x36,0x06,0xfe,0xed,0x3b,0x06,0xe5,0xed,0x3f,0x06,  \
    0xcb,0xed,0x43,0x06,0xb1,0xed,0x47,0x06,0x96,0xed,0x4b,0x06,0x7c,0xed,0x4f,0x06,0x61,0xed,0x53,0x06,0x46,0xed,0x56,0x06,0x2b,0xed,0x5a,0x06,0x10,0xed,0x5d,0x06,0xf5,0xec,0x61,0x06,0xd9,0xec,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x9c,0x06,0xcb,0x12,0x99,0x06,0xb0,0x12,0x95,0x06,0x94,0x12,0x91,0x06,0x79,0x12,0x8d,0x06,0x5e,0x12,0x89,0x06,0x43,0x12,0x85,0x06,0x29,0x12,0x81,0x06,0x0e,0x12,0x7d,0x06,0xf4,0x11,0x78,0x06,0xd9,0x11,0x74,0x06,0xbf,0x11,0x6f,0x06,0xa5,0x11,0x6b,0x06,0x8b,0x11,0x66,0x06,0x72,0x11,0x61,0x06,0x58,0x11,0x5c,0x06,0x3e,0x11,0x57,0x06,0x25,0x11,0x52,0x06,0x0c,0x11,0x4d,0x06,0xf3,0x10,0x48,0x06,0xda,0x10,0x42,0x06,  \
    0xc1,0x10,0x3c,0x06,0xaa,0x10,0x36,0x06,0x92,0x10,0x30,0x06,0x7b,0x10,0x2a,0x06,0x64,0x10,0x23,0x06,0x4d,0x10,0x1d,0x06,0x36,0x10,0x16,0x06,0x1f,0x10,0x10,0x06,0x08,0x10,0x09,0x06,0xf1,0x0f,0x03,0x06,0xdb,0x0f,0xfc,0x05,0xc4,0x0f,0xf6,0x05,0xae,0x0f,0xef,0x05,0x98,0x0f,0xe8,0x05,0x82,0x0f,0xe1,0x05,0x6c,0x0f,0xdb,0x05,0x56,0x0f,0xd4,0x05,0x41,0x0f,0xcd,0x05,0x2b,0x0f,0xc6,0x05,0x15,0x0f,0xbe,0x05,0x01,0x0f,0xb7,0x05,0xed,0x0e,0xaf,0x05,0xda,0x0e,  \
    0xa7,0x05,0xc6,0x0e,0x9e,0x05,0xb3,0x0e,0x96,0x05,0xa0,0x0e,0x8e,0x05,0x8d,0x0e,0x86,0x05,0x7a,0x0e,0x7e,0x05,0x67,0x0e,0x76,0x05,0x54,0x0e,0x6e,0x05,0x42,0x0e,0x66,0x05,0x2f,0x0e,0x5e,0x05,0x1d,0x0e,0x56,0x05,0x0b,0x0e,0x4e,0x05,0xf8,0x0d,0x46,0x05,0xe6,0x0d,0x3e,0x05,0xd4,0x0d,0x37,0x05,0xc2,0x0d,0x31,0x05,0xab,0x0d,0x2c,0x05,0x94,0x0d,0x27,0x05,0x7d,0x0d,0x22,0x05,0x67,0x0d,0x1d,0x05,0x50,0x0d,0x18,0x05,0x39,0x0d,0x12,0x05,0x23,0x0d,0x0d,0x05,  \
    0x0c,0x0d,0x08,0x05,0xf6,0x0c,0x03,0x05,0xe0,0x0c,0xfe,0x04,0xc9,0x0c,0xf9,0x04,0xb3,0x0c,0xf4,0x04,0x9c,0x0c,0xef,0x04,0x86,0x0c,0xea,0x04,0x70,0x0c,0xe5,0x04,0x5a,0x0c,0xe0,0x04,0x44,0x0c,0xdb,0x04,0x2e,0x0c,0xd6,0x04,0x17,0x0c,0xd1,0x04,0x01,0x0c,0xcc,0x04,0xeb,0x0b,0xc7,0x04,0xd5,0x0b,0xc2,0x04,0xbf,0x0b,0xbd,0x04,0xa9,0x0b,0xb8,0x04,0x94,0x0b,0xb3,0x04,0x7e,0x0b,0xae,0x04,0x68,0x0b,0xa9,0x04,0x52,0x0b,0xa4,0x04,0x3c,0x0b,0x9f,0x04,0x27,0x0b,  \
    0x9b,0x04,0x11,0x0b,0x96,0x04,0xfb,0x0a,0x91,0x04,0xe6,0x0a,0x8c,0x04,0xd0,0x0a,0x87,0x04,0xbb,0x0a,0x82,0x04,0xa6,0x0a,0x7c,0x04,0x94,0x0a,0x75,0x04,0x83,0x0a,0x6f,0x04,0x71,0x0a,0x69,0x04,0x60,0x0a,0x62,0x04,0x4e,0x0a,0x5c,0x04,0x3d,0x0a,0x56,0x04,0x2c,0x0a,0x50,0x04,0x1a,0x0a,0x4a,0x04,0x09,0x0a,0x44,0x04,0xf8,0x09,0x3e,0x04,0xe6,0x09,0x38,0x04,0xd5,0x09,0x32,0x04,0xc4,0x09,0x2c,0x04,0xb2,0x09,0x26,0x04,0xa1,0x09,0x21,0x04,0x90,0x09,0x1b,0x04,  \
    0x7e,0x09,0x16,0x04,0x6d,0x09,0x10,0x04,0x5c,0x09,0x0b,0x04,0x4a,0x09,0x05,0x04,0x39,0x09,0x00,0x04,0x27,0x09,0xfb,0x03,0x15,0x09,0xf6,0x03,0x03,0x09,0xf1,0x03,0xf1,0x08,0xec,0x03,0xdf,0x08,0xe7,0x03,0xcd,0x08,0xe2,0x03,0xbb,0x08,0xde,0x03,0xa9,0x08,0xd9,0x03,0x97,0x08,0xd4,0x03,0x85,0x08,0xd0,0x03,0x73,0x08,0xcb,0x03,0x61,0x08,0xc7,0x03,0x4f,0x08,0xc2,0x03,0x3d,0x08,0xbe,0x03,0x2b,0x08,0xb9,0x03,0x19,0x08,0xb5,0x03,0x07,0x08,0xb1,0x03,0xf5,0x07,  \
    0xad,0x03,0xe3,0x07,0xa8,0x03,0xd1,0x07,0xa4,0x03,0xbf,0x07,0xa0,0x03,0xad,0x07,0x9d,0x03,0x99,0x07,0x9a,0x03,0x84,0x07,0x96,0x03,0x70,0x07,0x93,0x03,0x5c,0x07,0x90,0x03,0x47,0x07,0x8c,0x03,0x33,0x07,0x89,0x03,0x1f,0x07,0x86,0x03,0x0b,0x07,0x83,0x03,0xf6,0x06,0x80,0x03,0xe2,0x06,0x7d,0x03,0xce,0x06,0x7a,0x03,0xba,0x06,0x77,0x03,0xa6,0x06,0x74,0x03,0x92,0x06,0x71,0x03,0x7e,0x06,0x6e,0x03,0x69,0x06,0x6b,0x03,0x55,0x06,0x68,0x03,0x41,0x06,0x65,0x03,  \
    0x2d,0x06,0x62,0x03,0x19,0x06,0x5f,0x03,0x05,0x06,0x5c,0x03,0xf2,0x05,0x5a,0x03,0xde,0x05,0x57,0x03,0xca,0x05,0x54,0x03,0xb7,0x05,0x51,0x03,0xa5,0x05,0x4e,0x03,0x93,0x05,0x4b,0x03,0x80,0x05,0x48,0x03,0x6e,0x05,0x45,0x03,0x5b,0x05,0x43,0x03,0x49,0x05,0x40,0x03,0x36,0x05,0x3d,0x03,0x24,0x05,0x3a,0x03,0x11,0x05,0x38,0x03,0xfe,0x04,0x35,0x03,0xec,0x04,0x33,0x03,0xd9,0x04,0x30,0x03,0xc7,0x04,0x2e,0x03,0xb4,0x04,0x2b,0x03,0xa2,0x04,0x29,0x03,0x8f,0x04,  \
    0x27,0x03,0x7c,0x04,0x24,0x03,0x6a,0x04,0x22,0x03,0x57,0x04,0x20,0x03,0x45,0x04,0x1e,0x03,0x32,0x04,0x1c,0x03,0x1f,0x04,0x1a,0x03,0x0d,0x04,0x17,0x03,0xfa,0x03,0x15,0x03,0xe8,0x03,0x13,0x03,0xd6,0x03,0x11,0x03,0xc4,0x03,0x0f,0x03,0xb3,0x03,0x0d,0x03,0xa1,0x03,0x0b,0x03,0x90,0x03,0x09,0x03,0x7e,0x03,0x07,0x03,0x6c,0x03,0x06,0x03,0x5a,0x03,0x04,0x03,0x48,0x03,0x02,0x03,0x36,0x03,0x00,0x03,0x24,0x03,0xff,0x02,0x13,0x03,0xfd,0x02,0x00,0x03,0xfc,0x02,  \
    0xee,0x02,0xfa,0x02,0xdc,0x02,0xf9,0x02,0xca,0x02,0xf7,0x02,0xb8,0x02,0xf6,0x02,0xa6,0x02,0xf5,0x02,0x93,0x02,0xf3,0x02,0x81,0x02,0xf2,0x02,0x6e,0x02,0xf1,0x02,0x5c,0x02,0xf0,0x02,0x49,0x02,0xef,0x02,0x37,0x02,0xee,0x02,0x24,0x02,0xed,0x02,0x12,0x02,0xec,0x02,0xff,0x01,0xeb,0x02,0xec,0x01,0xea,0x02,0xd8,0x01,0xe9,0x02,0xc5,0x01,0xe8,0x02,0xb1,0x01,0xe7,0x02,0x9d,0x01,0xe7,0x02,0x8a,0x01,0xe6,0x02,0x76,0x01,0xe5,0x02,0x63,0x01,0xe5,0x02,0x4f,0x01,  \
    0xe4,0x02,0x3c,0x01,0xe3,0x02,0x28,0x01,0xe3,0x02,0x15,0x01,0xe2,0x02,0x01,0x01,0xe2,0x02,0xee,0x00,0xe1,0x02,0xda,0x00,0xe1,0x02,0xc7,0x00,0xe1,0x02,0xb3,0x00,0xe0,0x02,0x9f,0x00,0xe0,0x02,0x8c,0x00,0xe0,0x02,0x78,0x00,0xdf,0x02,0x65,0x00,0xdf,0x02,0x51,0x00,0xdf,0x02,0x3e,0x00,0xdf,0x02,0x2a,0x00,0xdf,0x02,0x17,0x00,0xde,0x02,0x03,0x00,0xde,0x02,0xef,0xff,0xde,0x02,0xdc,0xff,0xde,0x02,0xc8,0xff,0xde,0x02,0xb5,0xff,0xde,0x02,0xa1,0xff,0xde,0x02,  \
    0x8e,0xff,0xde,0x02,0x7a,0xff,0xdf,0x02,0x67,0xff,0xdf,0x02,0x53,0xff,0xdf,0x02,0x3f,0xff,0xdf,0x02,0x2c,0xff,0xdf,0x02,0x18,0xff,0xe0,0x02,0x05,0xff,0xe0,0x02,0xf1,0xfe,0xe0,0x02,0xde,0xfe,0xe1,0x02,0xca,0xfe,0xe1,0x02,0xb7,0xfe,0xe2,0x02,0xa3,0xfe,0xe2,0x02,0x90,0xfe,0xe3,0x02,0x7c,0xfe,0xe3,0x02,0x68,0xfe,0xe4,0x02,0x55,0xfe,0xe4,0x02,0x41,0xfe,0xe5,0x02,0x2e,0xfe,0xe6,0x02,0x1a,0xfe,0xe6,0x02,0x07,0xfe,0xe7,0x02,0xf3,0xfd,0xe8,0x02,0xe0,0xfd,  \
    0xe9,0x02,0xcd,0xfd,0xe9,0x02,0xb9,0xfd,0xea,0x02,0xa5,0xfd,0xeb,0x02,0x91,0xfd,0xec,0x02,0x7e,0xfd,0xed,0x02,0x6a,0xfd,0xee,0x02,0x56,0xfd,0xef,0x02,0x42,0xfd,0xf0,0x02,0x2e,0xfd,0xf1,0x02,0x1a,0xfd,0xf2,0x02,0x06,0xfd,0xf3,0x02,0xf2,0xfc,0xf4,0x02,0xde,0xfc,0xf5,0x02,0xca,0xfc,0xf6,0x02,0xb6,0xfc,0xf8,0x02,0xa2,0xfc,0xf9,0x02,0x8e,0xfc,0xfa,0x02,0x7a,0xfc,0xfb,0x02,0x66,0xfc,0xfd,0x02,0x52,0xfc,0xfe,0x02,0x3e,0xfc,0xff,0x02,0x2a,0xfc,0x01,0x03,  \
    0x15,0xfc,0x02,0x03,0x01,0xfc,0x04,0x03,0xed,0xfb,0x05,0x03,0xd9,0xfb,0x07,0x03,0xc5,0xfb,0x08,0x03,0xb0,0xfb,0x0a,0x03,0x9c,0xfb,0x0b,0x03,0x88,0xfb,0x0d,0x03,0x75,0xfb,0x0f,0x03,0x62,0xfb,0x11,0x03,0x4f,0xfb,0x13,0x03,0x3c,0xfb,0x15,0x03,0x29,0xfb,0x17,0x03,0x16,0xfb,0x19,0x03,0x03,0xfb,0x1b,0x03,0xf0,0xfa,0x1d,0x03,0xdd,0xfa,0x1f,0x03,0xca,0xfa,0x21,0x03,0xb7,0xfa,0x23,0x03,0xa4,0xfa,0x25,0x03,0x91,0xfa,0x28,0x03,0x7e,0xfa,0x2a,0x03,0x6b,0xfa,  \
    0x2c,0x03,0x59,0xfa,0x2f,0x03,0x46,0xfa,0x31,0x03,0x33,0xfa,0x34,0x03,0x20,0xfa,0x36,0x03,0x0e,0xfa,0x39,0x03,0xfb,0xf9,0x3c,0x03,0xe9,0xf9,0x3e,0x03,0xd6,0xf9,0x41,0x03,0xc3,0xf9,0x44,0x03,0xb1,0xf9,0x47,0x03,0x9e,0xf9,0x49,0x03,0x8b,0xf9,0x4c,0x03,0x78,0xf9,0x4f,0x03,0x64,0xf9,0x51,0x03,0x50,0xf9,0x54,0x03,0x3d,0xf9,0x57,0x03,0x29,0xf9,0x5a,0x03,0x16,0xf9,0x5d,0x03,0x02,0xf9,0x60,0x03,0xef,0xf8,0x62,0x03,0xdb,0xf8,0x65,0x03,0xc7,0xf8,0x68,0x03,  \
    0xb4,0xf8,0x6b,0x03,0xa0,0xf8,0x6f,0x03,0x8d,0xf8,0x72,0x03,0x79,0xf8,0x75,0x03,0x66,0xf8,0x78,0x03,0x52,0xf8,0x7b,0x03,0x3f,0xf8,0x7f,0x03,0x2b,0xf8,0x82,0x03,0x18,0xf8,0x85,0x03,0x04,0xf8,0x89,0x03,0xf1,0xf7,0x8c,0x03,0xdd,0xf7,0x8f,0x03,0xca,0xf7,0x93,0x03,0xb6,0xf7,0x97,0x03,0xa3,0xf7,0x9a,0x03,0x90,0xf7,0x9e,0x03,0x7e,0xf7,0xa2,0x03,0x6b,0xf7,0xa6,0x03,0x58,0xf7,0xaa,0x03,0x45,0xf7,0xae,0x03,0x33,0xf7,0xb2,0x03,0x20,0xf7,0xb6,0x03,0x0d,0xf7,  \
    0xba,0x03,0xfb,0xf6,0xbe,0x03,0xe8,0xf6,0xc3,0x03,0xd5,0xf6,0xc7,0x03,0xc3,0xf6,0xcb,0x03,0xb0,0xf6,0xd0,0x03,0x9e,0xf6,0xd4,0x03,0x8b,0xf6,0xd9,0x03,0x78,0xf6,0xdd,0x03,0x66,0xf6,0xe2,0x03,0x53,0xf6,0xe6,0x03,0x41,0xf6,0xeb,0x03,0x2e,0xf6,0xf0,0x03,0x1c,0xf6,0xf5,0x03,0x09,0xf6,0xf9,0x03,0xf6,0xf5,0xfe,0x03,0xe2,0xf5,0x02,0x04,0xcf,0xf5,0x07,0x04,0xbb,0xf5,0x0b,0x04,0xa7,0xf5,0x10,0x04,0x94,0xf5,0x15,0x04,0x80,0xf5,0x19,0x04,0x6d,0xf5,0x1e,0x04,  \
    0x59,0xf5,0x23,0x04,0x45,0xf5,0x28,0x04,0x32,0xf5,0x2d,0x04,0x1e,0xf5,0x32,0x04,0x0b,0xf5,0x37,0x04,0xf7,0xf4,0x3c,0x04,0xe3,0xf4,0x41,0x04,0xd0,0xf4,0x46,0x04,0xbc,0xf4,0x4b,0x04,0xa8,0xf4,0x50,0x04,0x95,0xf4,0x55,0x04,0x81,0xf4,0x5a,0x04,0x6d,0xf4,0x60,0x04,0x5a,0xf4,0x66,0x04,0x47,0xf4,0x6b,0x04,0x34,0xf4,0x71,0x04,0x22,0xf4,0x77,0x04,0x0f,0xf4,0x7d,0x04,0xfc,0xf3,0x83,0x04,0xe9,0xf3,0x89,0x04,0xd6,0xf3,0x8f,0x04,0xc3,0xf3,0x95,0x04,0xb0,0xf3,  \
    0x9b,0x04,0x9d,0xf3,0xa1,0x04,0x8a,0xf3,0xa7,0x04,0x77,0xf3,0xad,0x04,0x64,0xf3,0xb3,0x04,0x51,0xf3,0xba,0x04,0x3e,0xf3,0xc0,0x04,0x2b,0xf3,0xc6,0x04,0x18,0xf3,0xcd,0x04,0x04,0xf3,0xd3,0x04,0xf1,0xf2,0xd8,0x04,0xdb,0xf2,0xde,0x04,0xc5,0xf2,0xe3,0x04,0xaf,0xf2,0xe8,0x04,0x99,0xf2,0xed,0x04,0x83,0xf2,0xf2,0x04,0x6d,0xf2,0xf7,0x04,0x56,0xf2,0xfc,0x04,0x40,0xf2,0x01,0x05,0x2a,0xf2,0x06,0x05,0x13,0xf2,0x0c,0x05,0xfd,0xf1,0x11,0x05,0xe6,0xf1,0x16,0x05,  \
    0xd0,0xf1,0x1b,0x05,0xb9,0xf1,0x20,0x05,0xa3,0xf1,0x25,0x05,0x8c,0xf1,0x2b,0x05,0x75,0xf1,0x30,0x05,0x5f,0xf1,0x36,0x05,0x49,0xf1,0x3c,0x05,0x35,0xf1,0x43,0x05,0x21,0xf1,0x4a,0x05,0x0c,0xf1,0x51,0x05,0xf8,0xf0,0x58,0x05,0xe4,0xf0,0x5f,0x05,0xcf,0xf0,0x65,0x05,0xbb,0xf0,0x6c,0x05,0xa6,0xf0,0x73,0x05,0x92,0xf0,0x7a,0x05,0x7d,0xf0,0x81,0x05,0x68,0xf0,0x88,0x05,0x53,0xf0,0x8e,0x05,0x3e,0xf0,0x95,0x05,0x29,0xf0,0x9c,0x05,0x14,0xf0,0xa3,0x05,0xff,0xef,  \
    0xa9,0x05,0xe9,0xef,0xb0,0x05,0xd4,0xef,0xb7,0x05,0xbf,0xef,0xbe,0x05,0xa9,0xef,0xc5,0x05,0x94,0xef,0xcc,0x05,0x7f,0xef,0xd3,0x05,0x69,0xef,0xda,0x05,0x53,0xef,0xe1,0x05,0x3d,0xef,0xe7,0x05,0x27,0xef,0xee,0x05,0x11,0xef,0xf5,0x05,0xfb,0xee,0xfb,0x05,0xe4,0xee,0x02,0x06,0xce,0xee,0x08,0x06,0xb7,0xee,0x0e,0x06,0xa0,0xee,0x15,0x06,0x89,0xee,0x1b,0x06,0x71,0xee,0x21,0x06,0x5a,0xee,0x27,0x06,0x42,0xee,0x2d,0x06,0x2a,0xee,0x32,0x06,0x13,0xee,0x38,0x06,  \
    0xfa,0xed,0x3c,0x06,0xe0,0xed,0x40,0x06,0xc6,0xed,0x45,0x06,0xab,0xed,0x49,0x06,0x91,0xed,0x4d,0x06,0x76,0xed,0x51,0x06,0x5b,0xed,0x54,0x06,0x41,0xed,0x58,0x06,0x26,0xed,0x5c,0x06,0x0a,0xed,0x5f,0x06,0xef,0xec,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x8e,0x06,0xc0,0x12,0x8b,0x06,0xa4,0x12,0x87,0x06,0x89,0x12,0x83,0x06,0x6e,0x12,0x7f,0x06,0x53,0x12,0x7b,0x06,0x38,0x12,0x77,0x06,0x1e,0x12,0x73,0x06,0x03,0x12,0x6e,0x06,0xe9,0x11,0x6a,0x06,0xce,0x11,0x65,0x06,0xb4,0x11,0x61,0x06,0x9a,0x11,0x5c,0x06,0x80,0x11,0x57,0x06,0x67,0x11,0x52,0x06,0x4d,0x11,0x4d,0x06,0x34,0x11,0x48,0x06,0x1a,0x11,0x43,0x06,0x01,0x11,0x3e,0x06,0xe8,0x10,0x39,0x06,  \
    0xcf,0x10,0x33,0x06,0xb7,0x10,0x2d,0x06,0x9f,0x10,0x27,0x06,0x88,0x10,0x20,0x06,0x70,0x10,0x1a,0x06,0x59,0x10,0x14,0x06,0x42,0x10,0x0d,0x06,0x2b,0x10,0x07,0x06,0x14,0x10,0x00,0x06,0xfe,0x0f,0xf9,0x05,0xe7,0x0f,0xf3,0x05,0xd1,0x0f,0xec,0x05,0xba,0x0f,0xe5,0x05,0xa4,0x0f,0xdf,0x05,0x8e,0x0f,0xd8,0x05,0x78,0x0f,0xd1,0x05,0x62,0x0f,0xca,0x05,0x4c,0x0f,0xc3,0x05,0x36,0x0f,0xbc,0x05,0x21,0x0f,0xb5,0x05,0x0b,0x0f,0xae,0x05,0xf7,0x0e,0xa6,0x05,0xe3,0x0e,  \
    0x9d,0x05,0xd0,0x0e,0x95,0x05,0xbc,0x0e,0x8d,0x05,0xa9,0x0e,0x85,0x05,0x96,0x0e,0x7d,0x05,0x83,0x0e,0x75,0x05,0x70,0x0e,0x6d,0x05,0x5d,0x0e,0x65,0x05,0x4a,0x0e,0x5d,0x05,0x38,0x0e,0x54,0x05,0x25,0x0e,0x4c,0x05,0x13,0x0e,0x44,0x05,0x01,0x0e,0x3c,0x05,0xef,0x0d,0x34,0x05,0xdc,0x0d,0x2c,0x05,0xcb,0x0d,0x24,0x05,0xb8,0x0d,0x1f,0x05,0xa1,0x0d,0x1a,0x05,0x8a,0x0d,0x15,0x05,0x74,0x0d,0x0f,0x05,0x5d,0x0d,0x0a,0x05,0x47,0x0d,0x05,0x05,0x30,0x0d,0x00,0x05,  \
    0x1a,0x0d,0xfa,0x04,0x03,0x0d,0xf5,0x04,0xed,0x0c,0xf0,0x04,0xd7,0x0c,0xeb,0x04,0xc0,0x0c,0xe6,0x04,0xaa,0x0c,0xe0,0x04,0x94,0x0c,0xdb,0x04,0x7e,0x0c,0xd6,0x04,0x67,0x0c,0xd1,0x04,0x51,0x0c,0xcc,0x04,0x3b,0x0c,0xc7,0x04,0x25,0x0c,0xc2,0x04,0x0f,0x0c,0xbd,0x04,0xf9,0x0b,0xb8,0x04,0xe3,0x0b,0xb3,0x04,0xcd,0x0b,0xae,0x04,0xb7,0x0b,0xa9,0x04,0xa2,0x0b,0xa4,0x04,0x8c,0x0b,0x9f,0x04,0x76,0x0b,0x9a,0x04,0x60,0x0b,0x95,0x04,0x4b,0x0b,0x90,0x04,0x35,0x0b,  \
    0x8b,0x04,0x1f,0x0b,0x86,0x04,0x0a,0x0b,0x81,0x04,0xf4,0x0a,0x7c,0x04,0xdf,0x0a,0x77,0x04,0xc9,0x0a,0x73,0x04,0xb4,0x0a,0x6d,0x04,0x9f,0x0a,0x67,0x04,0x8d,0x0a,0x60,0x04,0x7c,0x0a,0x5a,0x04,0x6b,0x0a,0x54,0x04,0x59,0x0a,0x4d,0x04,0x48,0x0a,0x47,0x04,0x36,0x0a,0x41,0x04,0x25,0x0a,0x3a,0x04,0x14,0x0a,0x34,0x04,0x02,0x0a,0x2e,0x04,0xf1,0x09,0x28,0x04,0xe0,0x09,0x22,0x04,0xce,0x09,0x1c,0x04,0xbd,0x09,0x17,0x04,0xac,0x09,0x11,0x04,0x9a,0x09,0x0b,0x04,  \
    0x89,0x09,0x05,0x04,0x78,0x09,0x00,0x04,0x67,0x09,0xfa,0x03,0x55,0x09,0xf5,0x03,0x44,0x09,0xef,0x03,0x32,0x09,0xea,0x03,0x21,0x09,0xe5,0x03,0x0f,0x09,0xe0,0x03,0xfd,0x08,0xdb,0x03,0xeb,0x08,0xd6,0x03,0xd9,0x08,0xd1,0x03,0xc7,0x08,0xcc,0x03,0xb5,0x08,0xc7,0x03,0xa3,0x08,0xc3,0x03,0x91,0x08,0xbe,0x03,0x7f,0x08,0xb9,0x03,0x6e,0x08,0xb5,0x03,0x5c,0x08,0xb0,0x03,0x4a,0x08,0xac,0x03,0x38,0x08,0xa7,0x03,0x26,0x08,0xa3,0x03,0x14,0x08,0x9e,0x03,0x02,0x08,  \
    0x9a,0x03,0xf0,0x07,0x96,0x03,0xde,0x07,0x92,0x03,0xcc,0x07,0x8d,0x03,0xba,0x07,0x89,0x03,0xa8,0x07,0x86,0x03,0x93,0x07,0x83,0x03,0x7f,0x07,0x7f,0x03,0x6b,0x07,0x7c,0x03,0x57,0x07,0x79,0x03,0x42,0x07,0x75,0x03,0x2e,0x07,0x72,0x03,0x1a,0x07,0x6f,0x03,0x06,0x07,0x6c,0x03,0xf2,0x06,0x69,0x03,0xde,0x06,0x65,0x03,0xc9,0x06,0x62,0x03,0xb5,0x06,0x5f,0x03,0xa1,0x06,0x5c,0x03,0x8d,0x06,0x59,0x03,0x79,0x06,0x56,0x03,0x65,0x06,0x53,0x03,0x51,0x06,0x50,0x03,  \
    0x3d,0x06,0x4d,0x03,0x29,0x06,0x4b,0x03,0x15,0x06,0x48,0x03,0x02,0x06,0x45,0x03,0xee,0x05,0x42,0x03,0xda,0x05,0x3f,0x03,0xc6,0x05,0x3c,0x03,0xb4,0x05,0x39,0x03,0xa1,0x05,0x36,0x03,0x8f,0x05,0x33,0x03,0x7c,0x05,0x30,0x03,0x6a,0x05,0x2e,0x03,0x58,0x05,0x2b,0x03,0x45,0x05,0x28,0x03,0x33,0x05,0x25,0x03,0x20,0x05,0x23,0x03,0x0e,0x05,0x20,0x03,0xfb,0x04,0x1d,0x03,0xe9,0x04,0x1b,0x03,0xd6,0x04,0x18,0x03,0xc4,0x04,0x16,0x03,0xb1,0x04,0x13,0x03,0x9f,0x04,  \
    0x11,0x03,0x8c,0x04,0x0f,0x03,0x79,0x04,0x0c,0x03,0x67,0x04,0x0a,0x03,0x54,0x04,0x08,0x03,0x42,0x04,0x06,0x03,0x2f,0x04,0x03,0x03,0x1d,0x04,0x01,0x03,0x0a,0x04,0xff,0x02,0xf7,0x03,0xfd,0x02,0xe5,0x03,0xfb,0x02,0xd4,0x03,0xf9,0x02,0xc2,0x03,0xf7,0x02,0xb0,0x03,0xf5,0x02,0x9f,0x03,0xf3,0x02,0x8d,0x03,0xf1,0x02,0x7b,0x03,0xef,0x02,0x6a,0x03,0xed,0x02,0x58,0x03,0xeb,0x02,0x46,0x03,0xea,0x02,0x34,0x03,0xe8,0x02,0x22,0x03,0xe6,0x02,0x10,0x03,0xe5,0x02,  \
    0xfe,0x02,0xe3,0x02,0xec,0x02,0xe2,0x02,0xda,0x02,0xe0,0x02,0xc8,0x02,0xdf,0x02,0xb6,0x02,0xde,0x02,0xa4,0x02,0xdc,0x02,0x91,0x02,0xdb,0x02,0x7f,0x02,0xda,0x02,0x6d,0x02,0xd8,0x02,0x5a,0x02,0xd7,0x02,0x48,0x02,0xd6,0x02,0x35,0x02,0xd5,0x02,0x23,0x02,0xd4,0x02,0x10,0x02,0xd3,0x02,0xfd,0x01,0xd2,0x02,0xea,0x01,0xd1,0x02,0xd7,0x01,0xd0,0x02,0xc3,0x01,0xd0,0x02,0xb0,0x01,0xcf,0x02,0x9c,0x01,0xce,0x02,0x89,0x01,0xcd,0x02,0x75,0x01,0xcd,0x02,0x62,0x01,  \
    0xcc,0x02,0x4e,0x01,0xcb,0x02,0x3b,0x01,0xcb,0x02,0x27,0x01,0xca,0x02,0x14,0x01,0xca,0x02,0x00,0x01,0xc9,0x02,0xed,0x00,0xc9,0x02,0xd9,0x00,0xc8,0x02,0xc6,0x00,0xc8,0x02,0xb2,0x00,0xc8,0x02,0x9f,0x00,0xc7,0x02,0x8b,0x00,0xc7,0x02,0x78,0x00,0xc7,0x02,0x64,0x00,0xc6,0x02,0x51,0x00,0xc6,0x02,0x3d,0x00,0xc6,0x02,0x2a,0x00,0xc6,0x02,0x16,0x00,0xc6,0x02,0x03,0x00,0xc6,0x02,0xef,0xff,0xc6,0x02,0xdc,0xff,0xc6,0x02,0xc8,0xff,0xc6,0x02,0xb5,0xff,0xc6,0x02,  \
    0xa1,0xff,0xc6,0x02,0x8e,0xff,0xc6,0x02,0x7a,0xff,0xc6,0x02,0x67,0xff,0xc6,0x02,0x53,0xff,0xc6,0x02,0x40,0xff,0xc7,0x02,0x2c,0xff,0xc7,0x02,0x19,0xff,0xc7,0x02,0x05,0xff,0xc7,0x02,0xf2,0xfe,0xc8,0x02,0xde,0xfe,0xc8,0x02,0xcb,0xfe,0xc9,0x02,0xb7,0xfe,0xc9,0x02,0xa4,0xfe,0xc9,0x02,0x90,0xfe,0xca,0x02,0x7d,0xfe,0xcb,0x02,0x69,0xfe,0xcb,0x02,0x56,0xfe,0xcc,0x02,0x42,0xfe,0xcc,0x02,0x2f,0xfe,0xcd,0x02,0x1c,0xfe,0xce,0x02,0x08,0xfe,0xce,0x02,0xf5,0xfd,  \
    0xcf,0x02,0xe1,0xfd,0xd0,0x02,0xce,0xfd,0xd1,0x02,0xba,0xfd,0xd2,0x02,0xa7,0xfd,0xd3,0x02,0x93,0xfd,0xd4,0x02,0x7f,0xfd,0xd4,0x02,0x6b,0xfd,0xd5,0x02,0x58,0xfd,0xd6,0x02,0x44,0xfd,0xd7,0x02,0x30,0xfd,0xd8,0x02,0x1c,0xfd,0xda,0x02,0x08,0xfd,0xdb,0x02,0xf4,0xfc,0xdc,0x02,0xe0,0xfc,0xdd,0x02,0xcc,0xfc,0xde,0x02,0xb8,0xfc,0xdf,0x02,0xa4,0xfc,0xe1,0x02,0x90,0xfc,0xe2,0x02,0x7c,0xfc,0xe3,0x02,0x68,0xfc,0xe5,0x02,0x54,0xfc,0xe6,0x02,0x40,0xfc,0xe7,0x02,  \
    0x2c,0xfc,0xe9,0x02,0x18,0xfc,0xea,0x02,0x04,0xfc,0xec,0x02,0xf0,0xfb,0xed,0x02,0xdc,0xfb,0xef,0x02,0xc8,0xfb,0xf0,0x02,0xb3,0xfb,0xf2,0x02,0x9f,0xfb,0xf3,0x02,0x8b,0xfb,0xf5,0x02,0x78,0xfb,0xf7,0x02,0x65,0xfb,0xf9,0x02,0x52,0xfb,0xfb,0x02,0x3f,0xfb,0xfd,0x02,0x2c,0xfb,0xff,0x02,0x19,0xfb,0x01,0x03,0x06,0xfb,0x03,0x03,0xf3,0xfa,0x05,0x03,0xe0,0xfa,0x07,0x03,0xcd,0xfa,0x09,0x03,0xba,0xfa,0x0c,0x03,0xa8,0xfa,0x0e,0x03,0x95,0xfa,0x10,0x03,0x82,0xfa,  \
    0x13,0x03,0x6f,0xfa,0x15,0x03,0x5d,0xfa,0x17,0x03,0x4a,0xfa,0x1a,0x03,0x37,0xfa,0x1c,0x03,0x25,0xfa,0x1f,0x03,0x12,0xfa,0x22,0x03,0xff,0xf9,0x24,0x03,0xed,0xf9,0x27,0x03,0xda,0xf9,0x2a,0x03,0xc8,0xf9,0x2d,0x03,0xb5,0xf9,0x2f,0x03,0xa3,0xf9,0x32,0x03,0x90,0xf9,0x35,0x03,0x7c,0xf9,0x38,0x03,0x69,0xf9,0x3a,0x03,0x55,0xf9,0x3d,0x03,0x42,0xf9,0x40,0x03,0x2e,0xf9,0x43,0x03,0x1b,0xf9,0x46,0x03,0x07,0xf9,0x49,0x03,0xf4,0xf8,0x4c,0x03,0xe0,0xf8,0x4f,0x03,  \
    0xcd,0xf8,0x52,0x03,0xb9,0xf8,0x55,0x03,0xa6,0xf8,0x58,0x03,0x92,0xf8,0x5b,0x03,0x7f,0xf8,0x5f,0x03,0x6b,0xf8,0x62,0x03,0x58,0xf8,0x65,0x03,0x45,0xf8,0x68,0x03,0x31,0xf8,0x6c,0x03,0x1e,0xf8,0x6f,0x03,0x0a,0xf8,0x73,0x03,0xf7,0xf7,0x76,0x03,0xe3,0xf7,0x7a,0x03,0xd0,0xf7,0x7d,0x03,0xbd,0xf7,0x81,0x03,0xaa,0xf7,0x85,0x03,0x97,0xf7,0x89,0x03,0x84,0xf7,0x8d,0x03,0x72,0xf7,0x91,0x03,0x5f,0xf7,0x95,0x03,0x4c,0xf7,0x99,0x03,0x3a,0xf7,0x9d,0x03,0x27,0xf7,  \
    0xa1,0x03,0x14,0xf7,0xa5,0x03,0x02,0xf7,0xa9,0x03,0xef,0xf6,0xae,0x03,0xdd,0xf6,0xb2,0x03,0xca,0xf6,0xb7,0x03,0xb8,0xf6,0xbb,0x03,0xa5,0xf6,0xc0,0x03,0x93,0xf6,0xc4,0x03,0x80,0xf6,0xc9,0x03,0x6e,0xf6,0xcd,0x03,0x5b,0xf6,0xd2,0x03,0x49,0xf6,0xd7,0x03,0x36,0xf6,0xdc,0x03,0x24,0xf6,0xe1,0x03,0x11,0xf6,0xe5,0x03,0xfe,0xf5,0xea,0x03,0xeb,0xf5,0xee,0x03,0xd7,0xf5,0xf3,0x03,0xc4,0xf5,0xf8,0x03,0xb0,0xf5,0xfd,0x03,0x9d,0xf5,0x01,0x04,0x89,0xf5,0x06,0x04,  \
    0x76,0xf5,0x0b,0x04,0x62,0xf5,0x10,0x04,0x4f,0xf5,0x15,0x04,0x3b,0xf5,0x1a,0x04,0x28,0xf5,0x1f,0x04,0x14,0xf5,0x24,0x04,0x01,0xf5,0x29,0x04,0xed,0xf4,0x2e,0x04,0xda,0xf4,0x33,0x04,0xc6,0xf4,0x39,0x04,0xb3,0xf4,0x3e,0x04,0x9f,0xf4,0x43,0x04,0x8b,0xf4,0x49,0x04,0x78,0xf4,0x4e,0x04,0x65,0xf4,0x54,0x04,0x52,0xf4,0x5a,0x04,0x3f,0xf4,0x60,0x04,0x2c,0xf4,0x66,0x04,0x1a,0xf4,0x6c,0x04,0x07,0xf4,0x72,0x04,0xf4,0xf3,0x78,0x04,0xe1,0xf3,0x7e,0x04,0xce,0xf3,  \
    0x84,0x04,0xbb,0xf3,0x8a,0x04,0xa9,0xf3,0x91,0x04,0x96,0xf3,0x97,0x04,0x83,0xf3,0x9d,0x04,0x70,0xf3,0xa4,0x04,0x5d,0xf3,0xaa,0x04,0x4a,0xf3,0xb1,0x04,0x37,0xf3,0xb7,0x04,0x24,0xf3,0xbe,0x04,0x11,0xf3,0xc4,0x04,0xfe,0xf2,0xca,0x04,0xe8,0xf2,0xcf,0x04,0xd2,0xf2,0xd4,0x04,0xbc,0xf2,0xd9,0x04,0xa6,0xf2,0xde,0x04,0x90,0xf2,0xe4,0x04,0x7a,0xf2,0xe9,0x04,0x64,0xf2,0xee,0x04,0x4e,0xf2,0xf4,0x04,0x37,0xf2,0xf9,0x04,0x21,0xf2,0xfe,0x04,0x0b,0xf2,0x04,0x05,  \
    0xf5,0xf1,0x09,0x05,0xde,0xf1,0x0e,0x05,0xc8,0xf1,0x14,0x05,0xb1,0xf1,0x19,0x05,0x9b,0xf1,0x1e,0x05,0x84,0xf1,0x24,0x05,0x6e,0xf1,0x2a,0x05,0x58,0xf1,0x31,0x05,0x44,0xf1,0x38,0x05,0x30,0xf1,0x3f,0x05,0x1c,0xf1,0x46,0x05,0x08,0xf1,0x4d,0x05,0xf4,0xf0,0x54,0x05,0xe0,0xf0,0x5b,0x05,0xcb,0xf0,0x62,0x05,0xb7,0xf0,0x69,0x05,0xa2,0xf0,0x70,0x05,0x8e,0xf0,0x77,0x05,0x79,0xf0,0x7e,0x05,0x64,0xf0,0x85,0x05,0x4f,0xf0,0x8c,0x05,0x3a,0xf0,0x93,0x05,0x25,0xf0,  \
    0x9a,0x05,0x10,0xf0,0xa1,0x05,0xfb,0xef,0xa8,0x05,0xe5,0xef,0xaf,0x05,0xd0,0xef,0xb6,0x05,0xbb,0xef,0xbd,0x05,0xa6,0xef,0xc4,0x05,0x90,0xef,0xcb,0x05,0x7b,0xef,0xd3,0x05,0x65,0xef,0xd9,0x05,0x4f,0xef,0xe0,0x05,0x39,0xef,0xe7,0x05,0x23,0xef,0xee,0x05,0x0d,0xef,0xf5,0x05,0xf7,0xee,0xfb,0x05,0xe0,0xee,0x02,0x06,0xc9,0xee,0x09,0x06,0xb2,0xee,0x0f,0x06,0x9b,0xee,0x15,0x06,0x84,0xee,0x1c,0x06,0x6d,0xee,0x22,0x06,0x55,0xee,0x28,0x06,0x3e,0xee,0x2e,0x06,  \
    0x26,0xee,0x33,0x06,0x0d,0xee,0x38,0x06,0xf3,0xed,0x3c,0x06,0xd9,0xed,0x41,0x06,0xbf,0xed,0x45,0x06,0xa4,0xed,0x49,0x06,0x8a,0xed,0x4d,0x06,0x6f,0xed,0x51,0x06,0x55,0xed,0x55,0x06,0x3a,0xed,0x59,0x06,0x1f,0xed,0x5c,0x06,0x03,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7f,0x06,0xb6,0x12,0x7b,0x06,0x9a,0x12,0x77,0x06,0x7f,0x12,0x73,0x06,0x64,0x12,0x6f,0x06,0x49,0x12,0x6b,0x06,0x2e,0x12,0x67,0x06,0x14,0x12,0x62,0x06,0xf9,0x11,0x5e,0x06,0xdf,0x11,0x5a,0x06,0xc5,0x11,0x55,0x06,0xaa,0x11,0x50,0x06,0x91,0x11,0x4b,0x06,0x77,0x11,0x47,0x06,0x5d,0x11,0x42,0x06,0x43,0x11,0x3d,0x06,0x2a,0x11,0x38,0x06,0x11,0x11,0x32,0x06,0xf8,0x10,0x2d,0x06,  \
    0xdf,0x10,0x28,0x06,0xc6,0x10,0x22,0x06,0xad,0x10,0x1c,0x06,0x96,0x10,0x16,0x06,0x7e,0x10,0x0f,0x06,0x67,0x10,0x09,0x06,0x50,0x10,0x02,0x06,0x39,0x10,0xfc,0x05,0x22,0x10,0xf5,0x05,0x0b,0x10,0xef,0x05,0xf4,0x0f,0xe8,0x05,0xde,0x0f,0xe1,0x05,0xc7,0x0f,0xda,0x05,0xb1,0x0f,0xd4,0x05,0x9b,0x0f,0xcd,0x05,0x85,0x0f,0xc6,0x05,0x6f,0x0f,0xbf,0x05,0x59,0x0f,0xb8,0x05,0x43,0x0f,0xb1,0x05,0x2d,0x0f,0xaa,0x05,0x18,0x0f,0xa3,0x05,0x02,0x0f,0x9c,0x05,0xee,0x0e,  \
    0x93,0x05,0xda,0x0e,0x8b,0x05,0xc7,0x0e,0x83,0x05,0xb3,0x0e,0x7b,0x05,0xa0,0x0e,0x73,0x05,0x8d,0x0e,0x6b,0x05,0x7a,0x0e,0x63,0x05,0x67,0x0e,0x5a,0x05,0x54,0x0e,0x52,0x05,0x41,0x0e,0x4a,0x05,0x2f,0x0e,0x42,0x05,0x1c,0x0e,0x3a,0x05,0x0a,0x0e,0x32,0x05,0xf8,0x0d,0x29,0x05,0xe5,0x0d,0x21,0x05,0xd3,0x0d,0x19,0x05,0xc1,0x0d,0x11,0x05,0xaf,0x0d,0x0c,0x05,0x98,0x0d,0x07,0x05,0x81,0x0d,0x01,0x05,0x6b,0x0d,0xfc,0x04,0x54,0x0d,0xf7,0x04,0x3e,0x0d,0xf2,0x04,  \
    0x27,0x0d,0xec,0x04,0x11,0x0d,0xe7,0x04,0xfb,0x0c,0xe2,0x04,0xe4,0x0c,0xdc,0x04,0xce,0x0c,0xd7,0x04,0xb8,0x0c,0xd2,0x04,0xa2,0x0c,0xcd,0x04,0x8b,0x0c,0xc7,0x04,0x75,0x0c,0xc2,0x04,0x5f,0x0c,0xbd,0x04,0x49,0x0c,0xb8,0x04,0x33,0x0c,0xb3,0x04,0x1d,0x0c,0xae,0x04,0x07,0x0c,0xa8,0x04,0xf1,0x0b,0xa3,0x04,0xdc,0x0b,0x9e,0x04,0xc6,0x0b,0x99,0x04,0xb0,0x0b,0x94,0x04,0x9a,0x0b,0x8f,0x04,0x84,0x0b,0x8a,0x04,0x6f,0x0b,0x85,0x04,0x59,0x0b,0x80,0x04,0x43,0x0b,  \
    0x7b,0x04,0x2e,0x0b,0x76,0x04,0x18,0x0b,0x71,0x04,0x03,0x0b,0x6c,0x04,0xed,0x0a,0x67,0x04,0xd8,0x0a,0x62,0x04,0xc2,0x0a,0x5e,0x04,0xad,0x0a,0x58,0x04,0x98,0x0a,0x52,0x04,0x87,0x0a,0x4b,0x04,0x75,0x0a,0x45,0x04,0x64,0x0a,0x3e,0x04,0x52,0x0a,0x38,0x04,0x41,0x0a,0x32,0x04,0x30,0x0a,0x2b,0x04,0x1e,0x0a,0x25,0x04,0x0d,0x0a,0x1f,0x04,0xfc,0x09,0x19,0x04,0xeb,0x09,0x13,0x04,0xd9,0x09,0x0d,0x04,0xc8,0x09,0x07,0x04,0xb7,0x09,0x01,0x04,0xa5,0x09,0xfb,0x03,  \
    0x94,0x09,0xf5,0x03,0x83,0x09,0xef,0x03,0x72,0x09,0xea,0x03,0x60,0x09,0xe4,0x03,0x4f,0x09,0xdf,0x03,0x3e,0x09,0xd9,0x03,0x2c,0x09,0xd4,0x03,0x1a,0x09,0xcf,0x03,0x09,0x09,0xca,0x03,0xf7,0x08,0xc5,0x03,0xe5,0x08,0xc0,0x03,0xd3,0x08,0xbb,0x03,0xc1,0x08,0xb6,0x03,0xaf,0x08,0xb1,0x03,0x9d,0x08,0xac,0x03,0x8c,0x08,0xa8,0x03,0x7a,0x08,0xa3,0x03,0x68,0x08,0x9e,0x03,0x56,0x08,0x9a,0x03,0x44,0x08,0x95,0x03,0x32,0x08,0x91,0x03,0x20,0x08,0x8c,0x03,0x0e,0x08,  \
    0x88,0x03,0xfc,0x07,0x83,0x03,0xea,0x07,0x7f,0x03,0xd8,0x07,0x7b,0x03,0xc6,0x07,0x77,0x03,0xb4,0x07,0x73,0x03,0xa2,0x07,0x6f,0x03,0x8e,0x07,0x6c,0x03,0x7a,0x07,0x68,0x03,0x66,0x07,0x65,0x03,0x52,0x07,0x62,0x03,0x3d,0x07,0x5e,0x03,0x29,0x07,0x5b,0x03,0x15,0x07,0x58,0x03,0x01,0x07,0x55,0x03,0xed,0x06,0x52,0x03,0xd9,0x06,0x4e,0x03,0xc5,0x06,0x4b,0x03,0xb1,0x06,0x48,0x03,0x9d,0x06,0x45,0x03,0x89,0x06,0x42,0x03,0x75,0x06,0x3f,0x03,0x61,0x06,0x3c,0x03,  \
    0x4d,0x06,0x39,0x03,0x39,0x06,0x36,0x03,0x25,0x06,0x33,0x03,0x11,0x06,0x30,0x03,0xfd,0x05,0x2d,0x03,0xea,0x05,0x2b,0x03,0xd6,0x05,0x28,0x03,0xc2,0x05,0x25,0x03,0xb0,0x05,0x22,0x03,0x9e,0x05,0x1f,0x03,0x8b,0x05,0x1c,0x03,0x79,0x05,0x19,0x03,0x66,0x05,0x16,0x03,0x54,0x05,0x13,0x03,0x42,0x05,0x10,0x03,0x2f,0x05,0x0e,0x03,0x1d,0x05,0x0b,0x03,0x0a,0x05,0x08,0x03,0xf8,0x04,0x06,0x03,0xe5,0x04,0x03,0x03,0xd3,0x04,0x01,0x03,0xc0,0x04,0xfe,0x02,0xae,0x04,  \
    0xfc,0x02,0x9b,0x04,0xf9,0x02,0x89,0x04,0xf7,0x02,0x76,0x04,0xf5,0x02,0x64,0x04,0xf2,0x02,0x51,0x04,0xf0,0x02,0x3f,0x04,0xee,0x02,0x2c,0x04,0xec,0x02,0x1a,0x04,0xea,0x02,0x07,0x04,0xe7,0x02,0xf5,0x03,0xe5,0x02,0xe2,0x03,0xe3,0x02,0xd1,0x03,0xe1,0x02,0xbf,0x03,0xdf,0x02,0xae,0x03,0xdd,0x02,0x9c,0x03,0xdb,0x02,0x8b,0x03,0xd9,0x02,0x79,0x03,0xd7,0x02,0x67,0x03,0xd5,0x02,0x56,0x03,0xd3,0x02,0x44,0x03,0xd2,0x02,0x32,0x03,0xd0,0x02,0x20,0x03,0xce,0x02,  \
    0x0e,0x03,0xcd,0x02,0xfc,0x02,0xcb,0x02,0xea,0x02,0xca,0x02,0xd8,0x02,0xc8,0x02,0xc6,0x02,0xc7,0x02,0xb4,0x02,0xc5,0x02,0xa2,0x02,0xc4,0x02,0x8f,0x02,0xc3,0x02,0x7d,0x02,0xc2,0x02,0x6b,0x02,0xc0,0x02,0x58,0x02,0xbf,0x02,0x46,0x02,0xbe,0x02,0x34,0x02,0xbd,0x02,0x21,0x02,0xbc,0x02,0x0e,0x02,0xbb,0x02,0xfc,0x01,0xba,0x02,0xe9,0x01,0xb9,0x02,0xd5,0x01,0xb8,0x02,0xc2,0x01,0xb7,0x02,0xae,0x01,0xb7,0x02,0x9b,0x01,0xb6,0x02,0x88,0x01,0xb5,0x02,0x74,0x01,  \
    0xb4,0x02,0x61,0x01,0xb4,0x02,0x4d,0x01,0xb3,0x02,0x3a,0x01,0xb3,0x02,0x26,0x01,0xb2,0x02,0x13,0x01,0xb2,0x02,0x00,0x01,0xb1,0x02,0xec,0x00,0xb1,0x02,0xd9,0x00,0xb0,0x02,0xc5,0x00,0xb0,0x02,0xb2,0x00,0xaf,0x02,0x9e,0x00,0xaf,0x02,0x8b,0x00,0xaf,0x02,0x77,0x00,0xae,0x02,0x64,0x00,0xae,0x02,0x50,0x00,0xae,0x02,0x3d,0x00,0xae,0x02,0x2a,0x00,0xae,0x02,0x16,0x00,0xad,0x02,0x03,0x00,0xad,0x02,0xef,0xff,0xad,0x02,0xdc,0xff,0xad,0x02,0xc8,0xff,0xad,0x02,  \
    0xb5,0xff,0xad,0x02,0xa1,0xff,0xad,0x02,0x8e,0xff,0xae,0x02,0x7a,0xff,0xae,0x02,0x67,0xff,0xae,0x02,0x54,0xff,0xae,0x02,0x40,0xff,0xae,0x02,0x2d,0xff,0xaf,0x02,0x19,0xff,0xaf,0x02,0x06,0xff,0xaf,0x02,0xf2,0xfe,0xaf,0x02,0xdf,0xfe,0xb0,0x02,0xcb,0xfe,0xb0,0x02,0xb8,0xfe,0xb1,0x02,0xa5,0xfe,0xb1,0x02,0x91,0xfe,0xb2,0x02,0x7e,0xfe,0xb2,0x02,0x6a,0xfe,0xb3,0x02,0x57,0xfe,0xb3,0x02,0x44,0xfe,0xb4,0x02,0x30,0xfe,0xb5,0x02,0x1d,0xfe,0xb6,0x02,0x09,0xfe,  \
    0xb6,0x02,0xf6,0xfd,0xb7,0x02,0xe3,0xfd,0xb8,0x02,0xcf,0xfd,0xb9,0x02,0xbc,0xfd,0xba,0x02,0xa8,0xfd,0xba,0x02,0x94,0xfd,0xbb,0x02,0x81,0xfd,0xbc,0x02,0x6d,0xfd,0xbd,0x02,0x59,0xfd,0xbe,0x02,0x45,0xfd,0xbf,0x02,0x32,0xfd,0xc0,0x02,0x1e,0xfd,0xc1,0x02,0x0a,0xfd,0xc3,0x02,0xf6,0xfc,0xc4,0x02,0xe2,0xfc,0xc5,0x02,0xce,0xfc,0xc6,0x02,0xba,0xfc,0xc7,0x02,0xa7,0xfc,0xc9,0x02,0x93,0xfc,0xca,0x02,0x7f,0xfc,0xcb,0x02,0x6b,0xfc,0xcc,0x02,0x57,0xfc,0xce,0x02,  \
    0x43,0xfc,0xcf,0x02,0x2f,0xfc,0xd1,0x02,0x1b,0xfc,0xd2,0x02,0x07,0xfc,0xd4,0x02,0xf3,0xfb,0xd5,0x02,0xde,0xfb,0xd7,0x02,0xca,0xfb,0xd8,0x02,0xb6,0xfb,0xda,0x02,0xa2,0xfb,0xdb,0x02,0x8e,0xfb,0xdd,0x02,0x7b,0xfb,0xdf,0x02,0x68,0xfb,0xe1,0x02,0x55,0xfb,0xe3,0x02,0x42,0xfb,0xe5,0x02,0x2f,0xfb,0xe7,0x02,0x1c,0xfb,0xe9,0x02,0x09,0xfb,0xeb,0x02,0xf6,0xfa,0xed,0x02,0xe4,0xfa,0xef,0x02,0xd1,0xfa,0xf2,0x02,0xbe,0xfa,0xf4,0x02,0xab,0xfa,0xf6,0x02,0x98,0xfa,  \
    0xf8,0x02,0x86,0xfa,0xfb,0x02,0x73,0xfa,0xfd,0x02,0x60,0xfa,0x00,0x03,0x4e,0xfa,0x02,0x03,0x3b,0xfa,0x05,0x03,0x29,0xfa,0x07,0x03,0x16,0xfa,0x0a,0x03,0x03,0xfa,0x0d,0x03,0xf1,0xf9,0x0f,0x03,0xde,0xf9,0x12,0x03,0xcc,0xf9,0x15,0x03,0xb9,0xf9,0x18,0x03,0xa7,0xf9,0x1b,0x03,0x94,0xf9,0x1d,0x03,0x81,0xf9,0x20,0x03,0x6d,0xf9,0x23,0x03,0x5a,0xf9,0x26,0x03,0x46,0xf9,0x28,0x03,0x33,0xf9,0x2b,0x03,0x1f,0xf9,0x2e,0x03,0x0c,0xf9,0x31,0x03,0xf8,0xf8,0x34,0x03,  \
    0xe5,0xf8,0x37,0x03,0xd2,0xf8,0x3a,0x03,0xbe,0xf8,0x3e,0x03,0xab,0xf8,0x41,0x03,0x97,0xf8,0x44,0x03,0x84,0xf8,0x47,0x03,0x70,0xf8,0x4a,0x03,0x5d,0xf8,0x4e,0x03,0x4a,0xf8,0x51,0x03,0x36,0xf8,0x54,0x03,0x23,0xf8,0x58,0x03,0x0f,0xf8,0x5b,0x03,0xfc,0xf7,0x5f,0x03,0xe9,0xf7,0x62,0x03,0xd5,0xf7,0x66,0x03,0xc2,0xf7,0x6a,0x03,0xaf,0xf7,0x6d,0x03,0x9c,0xf7,0x71,0x03,0x8a,0xf7,0x75,0x03,0x77,0xf7,0x79,0x03,0x65,0xf7,0x7d,0x03,0x52,0xf7,0x81,0x03,0x3f,0xf7,  \
    0x86,0x03,0x2d,0xf7,0x8a,0x03,0x1a,0xf7,0x8e,0x03,0x08,0xf7,0x92,0x03,0xf5,0xf6,0x97,0x03,0xe3,0xf6,0x9b,0x03,0xd0,0xf6,0x9f,0x03,0xbe,0xf6,0xa4,0x03,0xab,0xf6,0xa8,0x03,0x99,0xf6,0xad,0x03,0x86,0xf6,0xb2,0x03,0x74,0xf6,0xb6,0x03,0x61,0xf6,0xbb,0x03,0x4f,0xf6,0xc0,0x03,0x3c,0xf6,0xc5,0x03,0x2a,0xf6,0xca,0x03,0x18,0xf6,0xce,0x03,0x04,0xf6,0xd3,0x03,0xf1,0xf5,0xd8,0x03,0xdd,0xf5,0xdc,0x03,0xca,0xf5,0xe1,0x03,0xb7,0xf5,0xe6,0x03,0xa3,0xf5,0xeb,0x03,  \
    0x90,0xf5,0xef,0x03,0x7c,0xf5,0xf4,0x03,0x69,0xf5,0xf9,0x03,0x55,0xf5,0xfe,0x03,0x42,0xf5,0x03,0x04,0x2e,0xf5,0x08,0x04,0x1b,0xf5,0x0d,0x04,0x07,0xf5,0x12,0x04,0xf4,0xf4,0x18,0x04,0xe0,0xf4,0x1d,0x04,0xcd,0xf4,0x22,0x04,0xb9,0xf4,0x27,0x04,0xa6,0xf4,0x2d,0x04,0x92,0xf4,0x32,0x04,0x7f,0xf4,0x38,0x04,0x6c,0xf4,0x3d,0x04,0x59,0xf4,0x43,0x04,0x46,0xf4,0x49,0x04,0x33,0xf4,0x4f,0x04,0x21,0xf4,0x55,0x04,0x0e,0xf4,0x5b,0x04,0xfb,0xf3,0x61,0x04,0xe8,0xf3,  \
    0x67,0x04,0xd5,0xf3,0x6e,0x04,0xc2,0xf3,0x74,0x04,0xb0,0xf3,0x7a,0x04,0x9d,0xf3,0x80,0x04,0x8a,0xf3,0x87,0x04,0x77,0xf3,0x8d,0x04,0x64,0xf3,0x94,0x04,0x51,0xf3,0x9a,0x04,0x3e,0xf3,0xa1,0x04,0x2b,0xf3,0xa7,0x04,0x18,0xf3,0xae,0x04,0x05,0xf3,0xb3,0x04,0xef,0xf2,0xb8,0x04,0xd9,0xf2,0xbe,0x04,0xc3,0xf2,0xc3,0x04,0xad,0xf2,0xc8,0x04,0x97,0xf2,0xce,0x04,0x81,0xf2,0xd3,0x04,0x6b,0xf2,0xd8,0x04,0x55,0xf2,0xdd,0x04,0x3f,0xf2,0xe3,0x04,0x29,0xf2,0xe8,0x04,  \
    0x12,0xf2,0xee,0x04,0xfc,0xf1,0xf3,0x04,0xe6,0xf1,0xf8,0x04,0xcf,0xf1,0xfe,0x04,0xb9,0xf1,0x03,0x05,0xa3,0xf1,0x08,0x05,0x8c,0xf1,0x0e,0x05,0x76,0xf1,0x14,0x05,0x60,0xf1,0x1b,0x05,0x4c,0xf1,0x22,0x05,0x38,0xf1,0x29,0x05,0x24,0xf1,0x30,0x05,0x10,0xf1,0x37,0x05,0xfc,0xf0,0x3e,0x05,0xe7,0xf0,0x45,0x05,0xd3,0xf0,0x4c,0x05,0xbe,0xf0,0x53,0x05,0xaa,0xf0,0x5a,0x05,0x95,0xf0,0x61,0x05,0x80,0xf0,0x68,0x05,0x6c,0xf0,0x6f,0x05,0x57,0xf0,0x76,0x05,0x42,0xf0,  \
    0x7d,0x05,0x2d,0xf0,0x84,0x05,0x17,0xf0,0x8b,0x05,0x02,0xf0,0x92,0x05,0xed,0xef,0x99,0x05,0xd7,0xef,0xa0,0x05,0xc2,0xef,0xa7,0x05,0xad,0xef,0xae,0x05,0x98,0xef,0xb5,0x05,0x82,0xef,0xbd,0x05,0x6c,0xef,0xc3,0x05,0x56,0xef,0xca,0x05,0x41,0xef,0xd1,0x05,0x2a,0xef,0xd8,0x05,0x14,0xef,0xdf,0x05,0xfe,0xee,0xe5,0x05,0xe7,0xee,0xec,0x05,0xd0,0xee,0xf2,0x05,0xb9,0xee,0xf9,0x05,0xa2,0xee,0xff,0x05,0x8b,0xee,0x05,0x06,0x74,0xee,0x0c,0x06,0x5c,0xee,0x12,0x06,  \
    0x44,0xee,0x18,0x06,0x2c,0xee,0x1d,0x06,0x14,0xee,0x22,0x06,0xfa,0xed,0x26,0x06,0xe0,0xed,0x2a,0x06,0xc6,0xed,0x2f,0x06,0xab,0xed,0x33,0x06,0x91,0xed,0x37,0x06,0x76,0xed,0x3b,0x06,0x5b,0xed,0x3f,0x06,0x40,0xed,0x43,0x06,0x25,0xed,0x46,0x06,0x0a,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6f,0x06,0xab,0x12,0x6c,0x06,0x90,0x12,0x68,0x06,0x75,0x12,0x64,0x06,0x5a,0x12,0x60,0x06,0x3f,0x12,0x5c,0x06,0x24,0x12,0x57,0x06,0x09,0x12,0x53,0x06,0xef,0x11,0x4f,0x06,0xd5,0x11,0x4a,0x06,0xba,0x11,0x45,0x06,0xa0,0x11,0x41,0x06,0x86,0x11,0x3c,0x06,0x6d,0x11,0x37,0x06,0x53,0x11,0x32,0x06,0x39,0x11,0x2d,0x06,0x20,0x11,0x28,0x06,0x07,0x11,0x22,0x06,  \
    0xee,0x10,0x1d,0x06,0xd5,0x10,0x18,0x06,0xbc,0x10,0x12,0x06,0xa4,0x10,0x0c,0x06,0x8c,0x10,0x05,0x06,0x74,0x10,0xff,0x05,0x5d,0x10,0xf8,0x05,0x46,0x10,0xf2,0x05,0x2f,0x10,0xeb,0x05,0x18,0x10,0xe5,0x05,0x01,0x10,0xde,0x05,0xea,0x0f,0xd7,0x05,0xd4,0x0f,0xd0,0x05,0xbd,0x0f,0xca,0x05,0xa7,0x0f,0xc3,0x05,0x91,0x0f,0xbc,0x05,0x7b,0x0f,0xb5,0x05,0x65,0x0f,0xae,0x05,0x4f,0x0f,0xa7,0x05,0x39,0x0f,0xa0,0x05,0x24,0x0f,0x99,0x05,0x0e,0x0f,0x92,0x05,0xf9,0x0e,  \
    0x8a,0x05,0xe4,0x0e,0x82,0x05,0xd1,0x0e,0x7a,0x05,0xbd,0x0e,0x72,0x05,0xaa,0x0e,0x69,0x05,0x96,0x0e,0x61,0x05,0x83,0x0e,0x59,0x05,0x70,0x0e,0x51,0x05,0x5d,0x0e,0x49,0x05,0x4a,0x0e,0x40,0x05,0x38,0x0e,0x38,0x05,0x25,0x0e,0x30,0x05,0x13,0x0e,0x28,0x05,0x00,0x0e,0x1f,0x05,0xee,0x0d,0x17,0x05,0xdc,0x0d,0x0f,0x05,0xca,0x0d,0x07,0x05,0xb8,0x0d,0xff,0x04,0xa5,0x0d,0xfa,0x04,0x8e,0x0d,0xf4,0x04,0x78,0x0d,0xef,0x04,0x61,0x0d,0xea,0x04,0x4b,0x0d,0xe4,0x04,  \
    0x35,0x0d,0xdf,0x04,0x1e,0x0d,0xda,0x04,0x08,0x0d,0xd4,0x04,0xf2,0x0c,0xcf,0x04,0xdb,0x0c,0xc9,0x04,0xc5,0x0c,0xc4,0x04,0xaf,0x0c,0xbf,0x04,0x99,0x0c,0xba,0x04,0x83,0x0c,0xb4,0x04,0x6d,0x0c,0xaf,0x04,0x57,0x0c,0xaa,0x04,0x41,0x0c,0xa4,0x04,0x2b,0x0c,0x9f,0x04,0x15,0x0c,0x9a,0x04,0xff,0x0b,0x95,0x04,0xe9,0x0b,0x90,0x04,0xd3,0x0b,0x8b,0x04,0xbe,0x0b,0x85,0x04,0xa8,0x0b,0x80,0x04,0x92,0x0b,0x7b,0x04,0x7d,0x0b,0x76,0x04,0x67,0x0b,0x71,0x04,0x51,0x0b,  \
    0x6c,0x04,0x3c,0x0b,0x67,0x04,0x26,0x0b,0x62,0x04,0x11,0x0b,0x5d,0x04,0xfb,0x0a,0x58,0x04,0xe6,0x0a,0x53,0x04,0xd0,0x0a,0x4e,0x04,0xbb,0x0a,0x49,0x04,0xa6,0x0a,0x44,0x04,0x91,0x0a,0x3d,0x04,0x80,0x0a,0x36,0x04,0x6e,0x0a,0x30,0x04,0x5d,0x0a,0x29,0x04,0x4c,0x0a,0x23,0x04,0x3a,0x0a,0x1d,0x04,0x29,0x0a,0x16,0x04,0x18,0x0a,0x10,0x04,0x06,0x0a,0x0a,0x04,0xf5,0x09,0x04,0x04,0xe4,0x09,0xfe,0x03,0xd2,0x09,0xf8,0x03,0xc1,0x09,0xf2,0x03,0xb0,0x09,0xec,0x03,  \
    0x9f,0x09,0xe6,0x03,0x8e,0x09,0xe0,0x03,0x7c,0x09,0xda,0x03,0x6b,0x09,0xd5,0x03,0x5a,0x09,0xcf,0x03,0x49,0x09,0xc9,0x03,0x37,0x09,0xc4,0x03,0x26,0x09,0xbf,0x03,0x14,0x09,0xb9,0x03,0x02,0x09,0xb4,0x03,0xf0,0x08,0xaf,0x03,0xdf,0x08,0xaa,0x03,0xcd,0x08,0xa5,0x03,0xbb,0x08,0xa0,0x03,0xa9,0x08,0x9b,0x03,0x97,0x08,0x97,0x03,0x85,0x08,0x92,0x03,0x74,0x08,0x8d,0x03,0x62,0x08,0x88,0x03,0x50,0x08,0x84,0x03,0x3e,0x08,0x7f,0x03,0x2c,0x08,0x7b,0x03,0x1a,0x08,  \
    0x76,0x03,0x08,0x08,0x72,0x03,0xf6,0x07,0x6d,0x03,0xe5,0x07,0x69,0x03,0xd3,0x07,0x65,0x03,0xc1,0x07,0x61,0x03,0xaf,0x07,0x5c,0x03,0x9d,0x07,0x59,0x03,0x89,0x07,0x56,0x03,0x74,0x07,0x52,0x03,0x60,0x07,0x4f,0x03,0x4c,0x07,0x4b,0x03,0x38,0x07,0x48,0x03,0x24,0x07,0x45,0x03,0x10,0x07,0x41,0x03,0xfc,0x06,0x3e,0x03,0xe8,0x06,0x3b,0x03,0xd4,0x06,0x38,0x03,0xc0,0x06,0x35,0x03,0xac,0x06,0x32,0x03,0x98,0x06,0x2e,0x03,0x84,0x06,0x2b,0x03,0x70,0x06,0x28,0x03,  \
    0x5c,0x06,0x25,0x03,0x49,0x06,0x22,0x03,0x35,0x06,0x1f,0x03,0x21,0x06,0x1c,0x03,0x0d,0x06,0x19,0x03,0xf9,0x05,0x17,0x03,0xe6,0x05,0x14,0x03,0xd2,0x05,0x11,0x03,0xbe,0x05,0x0e,0x03,0xac,0x05,0x0b,0x03,0x9a,0x05,0x08,0x03,0x87,0x05,0x05,0x03,0x75,0x05,0x02,0x03,0x63,0x05,0xff,0x02,0x50,0x05,0xfc,0x02,0x3e,0x05,0xf9,0x02,0x2b,0x05,0xf7,0x02,0x19,0x05,0xf4,0x02,0x07,0x05,0xf1,0x02,0xf4,0x04,0xef,0x02,0xe2,0x04,0xec,0x02,0xcf,0x04,0xe9,0x02,0xbd,0x04,  \
    0xe7,0x02,0xab,0x04,0xe4,0x02,0x98,0x04,0xe2,0x02,0x86,0x04,0xe0,0x02,0x73,0x04,0xdd,0x02,0x61,0x04,0xdb,0x02,0x4e,0x04,0xd9,0x02,0x3c,0x04,0xd6,0x02,0x29,0x04,0xd4,0x02,0x17,0x04,0xd2,0x02,0x04,0x04,0xd0,0x02,0xf2,0x03,0xce,0x02,0xdf,0x03,0xcc,0x02,0xce,0x03,0xca,0x02,0xbd,0x03,0xc7,0x02,0xab,0x03,0xc5,0x02,0x9a,0x03,0xc3,0x02,0x88,0x03,0xc1,0x02,0x76,0x03,0xc0,0x02,0x65,0x03,0xbe,0x02,0x53,0x03,0xbc,0x02,0x41,0x03,0xba,0x02,0x30,0x03,0xb8,0x02,  \
    0x1e,0x03,0xb7,0x02,0x0c,0x03,0xb5,0x02,0xfa,0x02,0xb4,0x02,0xe8,0x02,0xb2,0x02,0xd6,0x02,0xb1,0x02,0xc4,0x02,0xaf,0x02,0xb2,0x02,0xae,0x02,0xa0,0x02,0xac,0x02,0x8d,0x02,0xab,0x02,0x7b,0x02,0xaa,0x02,0x69,0x02,0xa9,0x02,0x57,0x02,0xa7,0x02,0x44,0x02,0xa6,0x02,0x32,0x02,0xa5,0x02,0x1f,0x02,0xa4,0x02,0x0d,0x02,0xa3,0x02,0xfa,0x01,0xa2,0x02,0xe7,0x01,0xa1,0x02,0xd4,0x01,0xa1,0x02,0xc0,0x01,0xa0,0x02,0xad,0x01,0x9f,0x02,0x9a,0x01,0x9e,0x02,0x86,0x01,  \
    0x9d,0x02,0x73,0x01,0x9d,0x02,0x60,0x01,0x9c,0x02,0x4c,0x01,0x9b,0x02,0x39,0x01,0x9b,0x02,0x25,0x01,0x9a,0x02,0x12,0x01,0x9a,0x02,0xff,0x00,0x99,0x02,0xeb,0x00,0x99,0x02,0xd8,0x00,0x98,0x02,0xc4,0x00,0x98,0x02,0xb1,0x00,0x98,0x02,0x9e,0x00,0x97,0x02,0x8a,0x00,0x97,0x02,0x77,0x00,0x97,0x02,0x63,0x00,0x96,0x02,0x50,0x00,0x96,0x02,0x3d,0x00,0x96,0x02,0x29,0x00,0x96,0x02,0x16,0x00,0x96,0x02,0x02,0x00,0x96,0x02,0xef,0xff,0x95,0x02,0xdc,0xff,0x95,0x02,  \
    0xc8,0xff,0x95,0x02,0xb5,0xff,0x96,0x02,0xa1,0xff,0x96,0x02,0x8e,0xff,0x96,0x02,0x7b,0xff,0x96,0x02,0x67,0xff,0x96,0x02,0x54,0xff,0x96,0x02,0x40,0xff,0x96,0x02,0x2d,0xff,0x97,0x02,0x1a,0xff,0x97,0x02,0x06,0xff,0x97,0x02,0xf3,0xfe,0x98,0x02,0xe0,0xfe,0x98,0x02,0xcc,0xfe,0x98,0x02,0xb9,0xfe,0x99,0x02,0xa5,0xfe,0x99,0x02,0x92,0xfe,0x9a,0x02,0x7f,0xfe,0x9a,0x02,0x6b,0xfe,0x9b,0x02,0x58,0xfe,0x9c,0x02,0x45,0xfe,0x9c,0x02,0x31,0xfe,0x9d,0x02,0x1e,0xfe,  \
    0x9e,0x02,0x0b,0xfe,0x9e,0x02,0xf7,0xfd,0x9f,0x02,0xe4,0xfd,0xa0,0x02,0xd1,0xfd,0xa1,0x02,0xbd,0xfd,0xa2,0x02,0xaa,0xfd,0xa3,0x02,0x96,0xfd,0xa4,0x02,0x82,0xfd,0xa5,0x02,0x6f,0xfd,0xa5,0x02,0x5b,0xfd,0xa7,0x02,0x47,0xfd,0xa8,0x02,0x34,0xfd,0xa9,0x02,0x20,0xfd,0xaa,0x02,0x0c,0xfd,0xab,0x02,0xf8,0xfc,0xac,0x02,0xe4,0xfc,0xad,0x02,0xd1,0xfc,0xae,0x02,0xbd,0xfc,0xb0,0x02,0xa9,0xfc,0xb1,0x02,0x95,0xfc,0xb2,0x02,0x81,0xfc,0xb3,0x02,0x6d,0xfc,0xb5,0x02,  \
    0x59,0xfc,0xb6,0x02,0x45,0xfc,0xb8,0x02,0x31,0xfc,0xb9,0x02,0x1d,0xfc,0xbb,0x02,0x09,0xfc,0xbc,0x02,0xf5,0xfb,0xbe,0x02,0xe1,0xfb,0xbf,0x02,0xcd,0xfb,0xc1,0x02,0xb9,0xfb,0xc2,0x02,0xa5,0xfb,0xc4,0x02,0x91,0xfb,0xc6,0x02,0x7e,0xfb,0xc8,0x02,0x6b,0xfb,0xc9,0x02,0x58,0xfb,0xcb,0x02,0x45,0xfb,0xcd,0x02,0x33,0xfb,0xcf,0x02,0x20,0xfb,0xd1,0x02,0x0d,0xfb,0xd4,0x02,0xfa,0xfa,0xd6,0x02,0xe7,0xfa,0xd8,0x02,0xd4,0xfa,0xda,0x02,0xc2,0xfa,0xdc,0x02,0xaf,0xfa,  \
    0xdf,0x02,0x9c,0xfa,0xe1,0x02,0x8a,0xfa,0xe3,0x02,0x77,0xfa,0xe6,0x02,0x64,0xfa,0xe8,0x02,0x52,0xfa,0xeb,0x02,0x3f,0xfa,0xed,0x02,0x2d,0xfa,0xf0,0x02,0x1a,0xfa,0xf3,0x02,0x08,0xfa,0xf5,0x02,0xf5,0xf9,0xf8,0x02,0xe3,0xf9,0xfb,0x02,0xd0,0xf9,0xfe,0x02,0xbe,0xf9,0x00,0x03,0xab,0xf9,0x03,0x03,0x99,0xf9,0x06,0x03,0x85,0xf9,0x09,0x03,0x72,0xf9,0x0c,0x03,0x5e,0xf9,0x0e,0x03,0x4b,0xf9,0x11,0x03,0x37,0xf9,0x14,0x03,0x24,0xf9,0x17,0x03,0x11,0xf9,0x1a,0x03,  \
    0xfd,0xf8,0x1d,0x03,0xea,0xf8,0x20,0x03,0xd6,0xf8,0x23,0x03,0xc3,0xf8,0x26,0x03,0xb0,0xf8,0x2a,0x03,0x9c,0xf8,0x2d,0x03,0x89,0xf8,0x30,0x03,0x76,0xf8,0x33,0x03,0x62,0xf8,0x37,0x03,0x4f,0xf8,0x3a,0x03,0x3c,0xf8,0x3d,0x03,0x28,0xf8,0x41,0x03,0x15,0xf8,0x44,0x03,0x02,0xf8,0x48,0x03,0xee,0xf7,0x4b,0x03,0xdb,0xf7,0x4f,0x03,0xc8,0xf7,0x53,0x03,0xb5,0xf7,0x57,0x03,0xa2,0xf7,0x5b,0x03,0x90,0xf7,0x5e,0x03,0x7d,0xf7,0x63,0x03,0x6a,0xf7,0x67,0x03,0x58,0xf7,  \
    0x6b,0x03,0x45,0xf7,0x6f,0x03,0x33,0xf7,0x73,0x03,0x20,0xf7,0x77,0x03,0x0e,0xf7,0x7c,0x03,0xfb,0xf6,0x80,0x03,0xe9,0xf6,0x84,0x03,0xd6,0xf6,0x89,0x03,0xc4,0xf6,0x8d,0x03,0xb1,0xf6,0x92,0x03,0x9f,0xf6,0x96,0x03,0x8c,0xf6,0x9b,0x03,0x7a,0xf6,0xa0,0x03,0x68,0xf6,0xa5,0x03,0x55,0xf6,0xa9,0x03,0x43,0xf6,0xae,0x03,0x30,0xf6,0xb3,0x03,0x1e,0xf6,0xb8,0x03,0x0b,0xf6,0xbc,0x03,0xf7,0xf5,0xc1,0x03,0xe4,0xf5,0xc6,0x03,0xd1,0xf5,0xcb,0x03,0xbd,0xf5,0xcf,0x03,  \
    0xaa,0xf5,0xd4,0x03,0x96,0xf5,0xd9,0x03,0x83,0xf5,0xde,0x03,0x6f,0xf5,0xe3,0x03,0x5c,0xf5,0xe8,0x03,0x49,0xf5,0xed,0x03,0x35,0xf5,0xf2,0x03,0x22,0xf5,0xf7,0x03,0x0e,0xf5,0xfc,0x03,0xfb,0xf4,0x01,0x04,0xe7,0xf4,0x07,0x04,0xd4,0xf4,0x0c,0x04,0xc0,0xf4,0x11,0x04,0xad,0xf4,0x17,0x04,0x99,0xf4,0x1c,0x04,0x86,0xf4,0x22,0x04,0x73,0xf4,0x27,0x04,0x60,0xf4,0x2d,0x04,0x4d,0xf4,0x33,0x04,0x3b,0xf4,0x39,0x04,0x28,0xf4,0x3f,0x04,0x15,0xf4,0x45,0x04,0x02,0xf4,  \
    0x4b,0x04,0xef,0xf3,0x51,0x04,0xdd,0xf3,0x58,0x04,0xca,0xf3,0x5e,0x04,0xb7,0xf3,0x64,0x04,0xa4,0xf3,0x6b,0x04,0x91,0xf3,0x71,0x04,0x7e,0xf3,0x77,0x04,0x6b,0xf3,0x7e,0x04,0x58,0xf3,0x84,0x04,0x45,0xf3,0x8b,0x04,0x32,0xf3,0x91,0x04,0x1f,0xf3,0x98,0x04,0x0c,0xf3,0x9d,0x04,0xf7,0xf2,0xa3,0x04,0xe1,0xf2,0xa8,0x04,0xcb,0xf2,0xad,0x04,0xb5,0xf2,0xb2,0x04,0x9f,0xf2,0xb8,0x04,0x89,0xf2,0xbd,0x04,0x73,0xf2,0xc2,0x04,0x5d,0xf2,0xc8,0x04,0x47,0xf2,0xcd,0x04,  \
    0x30,0xf2,0xd3,0x04,0x1a,0xf2,0xd8,0x04,0x04,0xf2,0xdd,0x04,0xee,0xf1,0xe3,0x04,0xd7,0xf1,0xe8,0x04,0xc1,0xf1,0xee,0x04,0xab,0xf1,0xf3,0x04,0x94,0xf1,0xf8,0x04,0x7e,0xf1,0xfe,0x04,0x68,0xf1,0x05,0x05,0x54,0xf1,0x0c,0x05,0x40,0xf1,0x13,0x05,0x2c,0xf1,0x1a,0x05,0x18,0xf1,0x21,0x05,0x03,0xf1,0x28,0x05,0xef,0xf0,0x30,0x05,0xdb,0xf0,0x37,0x05,0xc6,0xf0,0x3e,0x05,0xb2,0xf0,0x45,0x05,0x9d,0xf0,0x4c,0x05,0x88,0xf0,0x53,0x05,0x73,0xf0,0x5a,0x05,0x5e,0xf0,  \
    0x61,0x05,0x49,0xf0,0x68,0x05,0x34,0xf0,0x6f,0x05,0x1f,0xf0,0x75,0x05,0x0a,0xf0,0x7c,0x05,0xf4,0xef,0x84,0x05,0xdf,0xef,0x8b,0x05,0xca,0xef,0x92,0x05,0xb5,0xef,0x99,0x05,0x9f,0xef,0xa0,0x05,0x8a,0xef,0xa7,0x05,0x74,0xef,0xae,0x05,0x5e,0xef,0xb5,0x05,0x48,0xef,0xbc,0x05,0x32,0xef,0xc2,0x05,0x1b,0xef,0xc9,0x05,0x05,0xef,0xd0,0x05,0xee,0xee,0xd6,0x05,0xd8,0xee,0xdd,0x05,0xc1,0xee,0xe3,0x05,0xa9,0xee,0xe9,0x05,0x92,0xee,0xf0,0x05,0x7b,0xee,0xf6,0x05,  \
    0x63,0xee,0xfc,0x05,0x4b,0xee,0x02,0x06,0x33,0xee,0x07,0x06,0x1b,0xee,0x0c,0x06,0x01,0xee,0x10,0x06,0xe7,0xed,0x15,0x06,0xcc,0xed,0x19,0x06,0xb2,0xed,0x1d,0x06,0x98,0xed,0x21,0x06,0x7d,0xed,0x25,0x06,0x62,0xed,0x29,0x06,0x47,0xed,0x2d,0x06,0x2c,0xed,0x30,0x06,0x11,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x61,0x06,0xa1,0x12,0x5d,0x06,0x85,0x12,0x59,0x06,0x6a,0x12,0x55,0x06,0x4f,0x12,0x51,0x06,0x34,0x12,0x4d,0x06,0x19,0x12,0x49,0x06,0xff,0x11,0x44,0x06,0xe4,0x11,0x40,0x06,0xca,0x11,0x3b,0x06,0xb0,0x11,0x36,0x06,0x96,0x11,0x32,0x06,0x7c,0x11,0x2d,0x06,0x62,0x11,0x28,0x06,0x49,0x11,0x23,0x06,0x2f,0x11,0x1e,0x06,0x16,0x11,0x18,0x06,  \
    0xfc,0x10,0x13,0x06,0xe3,0x10,0x0e,0x06,0xca,0x10,0x08,0x06,0xb1,0x10,0x02,0x06,0x99,0x10,0xfc,0x05,0x82,0x10,0xf6,0x05,0x6a,0x10,0xef,0x05,0x53,0x10,0xe9,0x05,0x3c,0x10,0xe2,0x05,0x25,0x10,0xdc,0x05,0x0e,0x10,0xd5,0x05,0xf7,0x0f,0xce,0x05,0xe0,0x0f,0xc7,0x05,0xca,0x0f,0xc0,0x05,0xb3,0x0f,0xba,0x05,0x9d,0x0f,0xb3,0x05,0x87,0x0f,0xac,0x05,0x71,0x0f,0xa5,0x05,0x5b,0x0f,0x9e,0x05,0x45,0x0f,0x97,0x05,0x2f,0x0f,0x90,0x05,0x1a,0x0f,0x88,0x05,0x04,0x0f,  \
    0x81,0x05,0xef,0x0e,0x79,0x05,0xda,0x0e,0x71,0x05,0xc7,0x0e,0x69,0x05,0xb3,0x0e,0x61,0x05,0xa0,0x0e,0x59,0x05,0x8c,0x0e,0x50,0x05,0x79,0x0e,0x48,0x05,0x66,0x0e,0x40,0x05,0x53,0x0e,0x38,0x05,0x40,0x0e,0x2f,0x05,0x2e,0x0e,0x27,0x05,0x1b,0x0e,0x1f,0x05,0x09,0x0e,0x16,0x05,0xf6,0x0d,0x0e,0x05,0xe4,0x0d,0x06,0x05,0xd2,0x0d,0xfe,0x04,0xc0,0x0d,0xf5,0x04,0xae,0x0d,0xee,0x04,0x9b,0x0d,0xe8,0x04,0x85,0x0d,0xe3,0x04,0x6e,0x0d,0xdd,0x04,0x58,0x0d,0xd8,0x04,  \
    0x41,0x0d,0xd2,0x04,0x2b,0x0d,0xcd,0x04,0x15,0x0d,0xc7,0x04,0xfe,0x0c,0xc2,0x04,0xe8,0x0c,0xbd,0x04,0xd2,0x0c,0xb7,0x04,0xbc,0x0c,0xb2,0x04,0xa6,0x0c,0xac,0x04,0x90,0x0c,0xa7,0x04,0x7a,0x0c,0xa2,0x04,0x64,0x0c,0x9c,0x04,0x4e,0x0c,0x97,0x04,0x38,0x0c,0x92,0x04,0x22,0x0c,0x8c,0x04,0x0c,0x0c,0x87,0x04,0xf7,0x0b,0x82,0x04,0xe1,0x0b,0x7d,0x04,0xcb,0x0b,0x77,0x04,0xb5,0x0b,0x72,0x04,0xa0,0x0b,0x6d,0x04,0x8a,0x0b,0x68,0x04,0x74,0x0b,0x63,0x04,0x5f,0x0b,  \
    0x5d,0x04,0x49,0x0b,0x58,0x04,0x34,0x0b,0x53,0x04,0x1e,0x0b,0x4e,0x04,0x09,0x0b,0x49,0x04,0xf4,0x0a,0x44,0x04,0xde,0x0a,0x3f,0x04,0xc9,0x0a,0x3a,0x04,0xb4,0x0a,0x35,0x04,0x9e,0x0a,0x30,0x04,0x8a,0x0a,0x29,0x04,0x78,0x0a,0x22,0x04,0x67,0x0a,0x1c,0x04,0x56,0x0a,0x15,0x04,0x44,0x0a,0x0f,0x04,0x33,0x0a,0x08,0x04,0x22,0x0a,0x02,0x04,0x10,0x0a,0xfc,0x03,0xff,0x09,0xf5,0x03,0xee,0x09,0xef,0x03,0xdd,0x09,0xe9,0x03,0xcb,0x09,0xe3,0x03,0xba,0x09,0xdd,0x03,  \
    0xa9,0x09,0xd7,0x03,0x98,0x09,0xd1,0x03,0x87,0x09,0xcb,0x03,0x75,0x09,0xc5,0x03,0x64,0x09,0xc0,0x03,0x53,0x09,0xba,0x03,0x42,0x09,0xb4,0x03,0x31,0x09,0xaf,0x03,0x1f,0x09,0xaa,0x03,0x0d,0x09,0xa4,0x03,0xfc,0x08,0x9f,0x03,0xea,0x08,0x9a,0x03,0xd8,0x08,0x95,0x03,0xc6,0x08,0x90,0x03,0xb4,0x08,0x8b,0x03,0xa3,0x08,0x86,0x03,0x91,0x08,0x81,0x03,0x7f,0x08,0x7c,0x03,0x6d,0x08,0x78,0x03,0x5b,0x08,0x73,0x03,0x4a,0x08,0x6e,0x03,0x38,0x08,0x6a,0x03,0x26,0x08,  \
    0x65,0x03,0x14,0x08,0x61,0x03,0x02,0x08,0x5c,0x03,0xf0,0x07,0x58,0x03,0xdf,0x07,0x53,0x03,0xcd,0x07,0x4f,0x03,0xbb,0x07,0x4b,0x03,0xa9,0x07,0x47,0x03,0x97,0x07,0x43,0x03,0x83,0x07,0x40,0x03,0x6f,0x07,0x3c,0x03,0x5b,0x07,0x39,0x03,0x47,0x07,0x35,0x03,0x33,0x07,0x32,0x03,0x1f,0x07,0x2f,0x03,0x0b,0x07,0x2b,0x03,0xf7,0x06,0x28,0x03,0xe3,0x06,0x25,0x03,0xcf,0x06,0x22,0x03,0xbb,0x06,0x1f,0x03,0xa7,0x06,0x1b,0x03,0x93,0x06,0x18,0x03,0x7f,0x06,0x15,0x03,  \
    0x6b,0x06,0x12,0x03,0x58,0x06,0x0f,0x03,0x44,0x06,0x0c,0x03,0x30,0x06,0x09,0x03,0x1c,0x06,0x06,0x03,0x09,0x06,0x03,0x03,0xf5,0x05,0x00,0x03,0xe1,0x05,0xfd,0x02,0xcd,0x05,0xfa,0x02,0xba,0x05,0xf7,0x02,0xa8,0x05,0xf4,0x02,0x95,0x05,0xf1,0x02,0x83,0x05,0xee,0x02,0x71,0x05,0xeb,0x02,0x5f,0x05,0xe8,0x02,0x4c,0x05,0xe5,0x02,0x3a,0x05,0xe3,0x02,0x28,0x05,0xe0,0x02,0x15,0x05,0xdd,0x02,0x03,0x05,0xda,0x02,0xf1,0x04,0xd8,0x02,0xde,0x04,0xd5,0x02,0xcc,0x04,  \
    0xd3,0x02,0xb9,0x04,0xd0,0x02,0xa7,0x04,0xce,0x02,0x95,0x04,0xcb,0x02,0x82,0x04,0xc9,0x02,0x70,0x04,0xc6,0x02,0x5d,0x04,0xc4,0x02,0x4b,0x04,0xc2,0x02,0x39,0x04,0xc0,0x02,0x26,0x04,0xbd,0x02,0x14,0x04,0xbb,0x02,0x01,0x04,0xb9,0x02,0xef,0x03,0xb7,0x02,0xdd,0x03,0xb5,0x02,0xcb,0x03,0xb3,0x02,0xba,0x03,0xb0,0x02,0xa8,0x03,0xae,0x02,0x97,0x03,0xac,0x02,0x85,0x03,0xaa,0x02,0x74,0x03,0xa8,0x02,0x62,0x03,0xa7,0x02,0x50,0x03,0xa5,0x02,0x3f,0x03,0xa3,0x02,  \
    0x2d,0x03,0xa1,0x02,0x1b,0x03,0xa0,0x02,0x09,0x03,0x9e,0x02,0xf8,0x02,0x9c,0x02,0xe6,0x02,0x9b,0x02,0xd4,0x02,0x99,0x02,0xc2,0x02,0x98,0x02,0xb0,0x02,0x97,0x02,0x9d,0x02,0x95,0x02,0x8b,0x02,0x94,0x02,0x79,0x02,0x93,0x02,0x67,0x02,0x91,0x02,0x55,0x02,0x90,0x02,0x42,0x02,0x8f,0x02,0x30,0x02,0x8e,0x02,0x1e,0x02,0x8d,0x02,0x0b,0x02,0x8c,0x02,0xf9,0x01,0x8b,0x02,0xe5,0x01,0x8a,0x02,0xd2,0x01,0x89,0x02,0xbf,0x01,0x88,0x02,0xab,0x01,0x88,0x02,0x98,0x01,  \
    0x87,0x02,0x85,0x01,0x86,0x02,0x72,0x01,0x85,0x02,0x5e,0x01,0x85,0x02,0x4b,0x01,0x84,0x02,0x38,0x01,0x83,0x02,0x24,0x01,0x83,0x02,0x11,0x01,0x82,0x02,0xfe,0x00,0x82,0x02,0xea,0x00,0x81,0x02,0xd7,0x00,0x81,0x02,0xc4,0x00,0x80,0x02,0xb0,0x00,0x80,0x02,0x9d,0x00,0x80,0x02,0x8a,0x00,0x7f,0x02,0x76,0x00,0x7f,0x02,0x63,0x00,0x7f,0x02,0x50,0x00,0x7f,0x02,0x3c,0x00,0x7e,0x02,0x29,0x00,0x7e,0x02,0x16,0x00,0x7e,0x02,0x02,0x00,0x7e,0x02,0xef,0xff,0x7e,0x02,  \
    0xdc,0xff,0x7e,0x02,0xc8,0xff,0x7e,0x02,0xb5,0xff,0x7e,0x02,0xa2,0xff,0x7e,0x02,0x8e,0xff,0x7e,0x02,0x7b,0xff,0x7e,0x02,0x68,0xff,0x7f,0x02,0x54,0xff,0x7f,0x02,0x41,0xff,0x7f,0x02,0x2e,0xff,0x7f,0x02,0x1a,0xff,0x80,0x02,0x07,0xff,0x80,0x02,0xf4,0xfe,0x80,0x02,0xe0,0xfe,0x81,0x02,0xcd,0xfe,0x81,0x02,0xba,0xfe,0x81,0x02,0xa6,0xfe,0x82,0x02,0x93,0xfe,0x82,0x02,0x80,0xfe,0x83,0x02,0x6c,0xfe,0x84,0x02,0x59,0xfe,0x84,0x02,0x46,0xfe,0x85,0x02,0x32,0xfe,  \
    0x86,0x02,0x1f,0xfe,0x86,0x02,0x0c,0xfe,0x87,0x02,0xf9,0xfd,0x88,0x02,0xe5,0xfd,0x89,0x02,0xd2,0xfd,0x8a,0x02,0xbf,0xfd,0x8a,0x02,0xab,0xfd,0x8b,0x02,0x98,0xfd,0x8c,0x02,0x84,0xfd,0x8d,0x02,0x71,0xfd,0x8e,0x02,0x5d,0xfd,0x8f,0x02,0x49,0xfd,0x90,0x02,0x36,0xfd,0x91,0x02,0x22,0xfd,0x92,0x02,0x0e,0xfd,0x93,0x02,0xfa,0xfc,0x95,0x02,0xe7,0xfc,0x96,0x02,0xd3,0xfc,0x97,0x02,0xbf,0xfc,0x98,0x02,0xab,0xfc,0x9a,0x02,0x97,0xfc,0x9b,0x02,0x84,0xfc,0x9c,0x02,  \
    0x70,0xfc,0x9e,0x02,0x5c,0xfc,0x9f,0x02,0x48,0xfc,0xa0,0x02,0x34,0xfc,0xa2,0x02,0x20,0xfc,0xa3,0x02,0x0c,0xfc,0xa5,0x02,0xf8,0xfb,0xa6,0x02,0xe4,0xfb,0xa8,0x02,0xd0,0xfb,0xa9,0x02,0xbd,0xfb,0xab,0x02,0xa9,0xfb,0xad,0x02,0x95,0xfb,0xaf,0x02,0x82,0xfb,0xb0,0x02,0x6f,0xfb,0xb2,0x02,0x5c,0xfb,0xb4,0x02,0x49,0xfb,0xb6,0x02,0x36,0xfb,0xb8,0x02,0x23,0xfb,0xba,0x02,0x11,0xfb,0xbc,0x02,0xfe,0xfa,0xbf,0x02,0xeb,0xfa,0xc1,0x02,0xd8,0xfa,0xc3,0x02,0xc6,0xfa,  \
    0xc5,0x02,0xb3,0xfa,0xc8,0x02,0xa0,0xfa,0xca,0x02,0x8e,0xfa,0xcc,0x02,0x7b,0xfa,0xcf,0x02,0x68,0xfa,0xd1,0x02,0x56,0xfa,0xd4,0x02,0x43,0xfa,0xd6,0x02,0x31,0xfa,0xd9,0x02,0x1e,0xfa,0xdc,0x02,0x0c,0xfa,0xde,0x02,0xf9,0xf9,0xe1,0x02,0xe7,0xf9,0xe4,0x02,0xd5,0xf9,0xe7,0x02,0xc2,0xf9,0xea,0x02,0xb0,0xf9,0xec,0x02,0x9d,0xf9,0xef,0x02,0x8a,0xf9,0xf2,0x02,0x76,0xf9,0xf5,0x02,0x63,0xf9,0xf8,0x02,0x50,0xf9,0xfa,0x02,0x3c,0xf9,0xfd,0x02,0x29,0xf9,0x00,0x03,  \
    0x16,0xf9,0x03,0x03,0x02,0xf9,0x06,0x03,0xef,0xf8,0x09,0x03,0xdc,0xf8,0x0d,0x03,0xc8,0xf8,0x10,0x03,0xb5,0xf8,0x13,0x03,0xa2,0xf8,0x16,0x03,0x8e,0xf8,0x19,0x03,0x7b,0xf8,0x1d,0x03,0x68,0xf8,0x20,0x03,0x54,0xf8,0x23,0x03,0x41,0xf8,0x27,0x03,0x2e,0xf8,0x2a,0x03,0x1b,0xf8,0x2e,0x03,0x07,0xf8,0x31,0x03,0xf4,0xf7,0x35,0x03,0xe1,0xf7,0x39,0x03,0xcd,0xf7,0x3c,0x03,0xbb,0xf7,0x40,0x03,0xa8,0xf7,0x44,0x03,0x96,0xf7,0x48,0x03,0x83,0xf7,0x4c,0x03,0x70,0xf7,  \
    0x50,0x03,0x5e,0xf7,0x54,0x03,0x4b,0xf7,0x59,0x03,0x39,0xf7,0x5d,0x03,0x26,0xf7,0x61,0x03,0x14,0xf7,0x65,0x03,0x01,0xf7,0x6a,0x03,0xef,0xf6,0x6e,0x03,0xdd,0xf6,0x73,0x03,0xca,0xf6,0x77,0x03,0xb8,0xf6,0x7c,0x03,0xa5,0xf6,0x80,0x03,0x93,0xf6,0x85,0x03,0x80,0xf6,0x8a,0x03,0x6e,0xf6,0x8e,0x03,0x5c,0xf6,0x93,0x03,0x49,0xf6,0x98,0x03,0x37,0xf6,0x9d,0x03,0x25,0xf6,0xa2,0x03,0x12,0xf6,0xa6,0x03,0xfe,0xf5,0xab,0x03,0xeb,0xf5,0xb0,0x03,0xd7,0xf5,0xb5,0x03,  \
    0xc4,0xf5,0xb9,0x03,0xb1,0xf5,0xbe,0x03,0x9d,0xf5,0xc3,0x03,0x8a,0xf5,0xc8,0x03,0x76,0xf5,0xcd,0x03,0x63,0xf5,0xd2,0x03,0x50,0xf5,0xd7,0x03,0x3c,0xf5,0xdc,0x03,0x29,0xf5,0xe1,0x03,0x15,0xf5,0xe6,0x03,0x02,0xf5,0xec,0x03,0xef,0xf4,0xf1,0x03,0xdb,0xf4,0xf6,0x03,0xc8,0xf4,0xfb,0x03,0xb4,0xf4,0x01,0x04,0xa1,0xf4,0x06,0x04,0x8d,0xf4,0x0c,0x04,0x7a,0xf4,0x12,0x04,0x67,0xf4,0x18,0x04,0x55,0xf4,0x1e,0x04,0x42,0xf4,0x24,0x04,0x2f,0xf4,0x2a,0x04,0x1d,0xf4,  \
    0x30,0x04,0x0a,0xf4,0x36,0x04,0xf7,0xf3,0x3c,0x04,0xe4,0xf3,0x42,0x04,0xd1,0xf3,0x48,0x04,0xbe,0xf3,0x4f,0x04,0xac,0xf3,0x55,0x04,0x99,0xf3,0x5b,0x04,0x86,0xf3,0x62,0x04,0x73,0xf3,0x68,0x04,0x60,0xf3,0x6f,0x04,0x4d,0xf3,0x75,0x04,0x3a,0xf3,0x7c,0x04,0x27,0xf3,0x83,0x04,0x14,0xf3,0x88,0x04,0xfe,0xf2,0x8d,0x04,0xe8,0xf2,0x93,0x04,0xd2,0xf2,0x98,0x04,0xbd,0xf2,0x9d,0x04,0xa7,0xf2,0xa2,0x04,0x91,0xf2,0xa8,0x04,0x7b,0xf2,0xad,0x04,0x65,0xf2,0xb3,0x04,  \
    0x4f,0xf2,0xb8,0x04,0x38,0xf2,0xbd,0x04,0x22,0xf2,0xc3,0x04,0x0c,0xf2,0xc8,0x04,0xf6,0xf1,0xce,0x04,0xdf,0xf1,0xd3,0x04,0xc9,0xf1,0xd9,0x04,0xb3,0xf1,0xde,0x04,0x9c,0xf1,0xe3,0x04,0x86,0xf1,0xe9,0x04,0x70,0xf1,0xf0,0x04,0x5c,0xf1,0xf7,0x04,0x48,0xf1,0xfe,0x04,0x34,0xf1,0x05,0x05,0x20,0xf1,0x0c,0x05,0x0c,0xf1,0x13,0x05,0xf7,0xf0,0x1b,0x05,0xe3,0xf0,0x22,0x05,0xce,0xf0,0x29,0x05,0xba,0xf0,0x30,0x05,0xa5,0xf0,0x37,0x05,0x90,0xf0,0x3e,0x05,0x7b,0xf0,  \
    0x45,0x05,0x67,0xf0,0x4c,0x05,0x51,0xf0,0x53,0x05,0x3c,0xf0,0x59,0x05,0x27,0xf0,0x60,0x05,0x12,0xf0,0x67,0x05,0xfc,0xef,0x6e,0x05,0xe7,0xef,0x76,0x05,0xd2,0xef,0x7d,0x05,0xbc,0xef,0x84,0x05,0xa7,0xef,0x8b,0x05,0x91,0xef,0x92,0x05,0x7b,0xef,0x99,0x05,0x66,0xef,0xa0,0x05,0x50,0xef,0xa6,0x05,0x39,0xef,0xad,0x05,0x23,0xef,0xb4,0x05,0x0c,0xef,0xba,0x05,0xf6,0xee,0xc1,0x05,0xdf,0xee,0xc7,0x05,0xc8,0xee,0xce,0x05,0xb1,0xee,0xd4,0x05,0x9a,0xee,0xda,0x05,  \
    0x82,0xee,0xe0,0x05,0x6a,0xee,0xe6,0x05,0x53,0xee,0xec,0x05,0x3b,0xee,0xf2,0x05,0x22,0xee,0xf6,0x05,0x08,0xee,0xfb,0x05,0xee,0xed,0xff,0x05,0xd4,0xed,0x03,0x06,0xb9,0xed,0x08,0x06,0x9f,0xed,0x0c,0x06,0x84,0xed,0x10,0x06,0x69,0xed,0x13,0x06,0x4e,0xed,0x17,0x06,0x33,0xed,0x1b,0x06,0x18,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x54,0x06,0x96,0x12,0x50,0x06,0x7a,0x12,0x4c,0x06,0x5f,0x12,0x48,0x06,0x44,0x12,0x44,0x06,0x29,0x12,0x3f,0x06,0x0e,0x12,0x3b,0x06,0xf4,0x11,0x36,0x06,0xd9,0x11,0x32,0x06,0xbf,0x11,0x2d,0x06,0xa5,0x11,0x28,0x06,0x8b,0x11,0x24,0x06,0x71,0x11,0x1f,0x06,0x57,0x11,0x1a,0x06,0x3e,0x11,0x14,0x06,0x24,0x11,0x0f,0x06,  \
    0x0b,0x11,0x0a,0x06,0xf2,0x10,0x05,0x06,0xd9,0x10,0xff,0x05,0xc0,0x10,0xfa,0x05,0xa7,0x10,0xf4,0x05,0x8f,0x10,0xed,0x05,0x77,0x10,0xe7,0x05,0x60,0x10,0xe0,0x05,0x48,0x10,0xda,0x05,0x31,0x10,0xd3,0x05,0x1a,0x10,0xcc,0x05,0x03,0x10,0xc6,0x05,0xed,0x0f,0xbf,0x05,0xd6,0x0f,0xb8,0x05,0xbf,0x0f,0xb1,0x05,0xa9,0x0f,0xaa,0x05,0x93,0x0f,0xa3,0x05,0x7c,0x0f,0x9c,0x05,0x66,0x0f,0x95,0x05,0x51,0x0f,0x8e,0x05,0x3b,0x0f,0x87,0x05,0x25,0x0f,0x80,0x05,0x0f,0x0f,  \
    0x79,0x05,0xfa,0x0e,0x71,0x05,0xe4,0x0e,0x6a,0x05,0xd0,0x0e,0x61,0x05,0xbc,0x0e,0x59,0x05,0xa9,0x0e,0x51,0x05,0x95,0x0e,0x48,0x05,0x82,0x0e,0x40,0x05,0x6f,0x0e,0x38,0x05,0x5c,0x0e,0x2f,0x05,0x49,0x0e,0x27,0x05,0x36,0x0e,0x1f,0x05,0x23,0x0e,0x16,0x05,0x11,0x0e,0x0e,0x05,0xfe,0x0d,0x06,0x05,0xec,0x0d,0xfd,0x04,0xda,0x0d,0xf5,0x04,0xc7,0x0d,0xed,0x04,0xb5,0x0d,0xe5,0x04,0xa3,0x0d,0xdd,0x04,0x91,0x0d,0xd7,0x04,0x7a,0x0d,0xd2,0x04,0x64,0x0d,0xcc,0x04,  \
    0x4e,0x0d,0xc7,0x04,0x37,0x0d,0xc1,0x04,0x21,0x0d,0xbb,0x04,0x0b,0x0d,0xb6,0x04,0xf5,0x0c,0xb0,0x04,0xdf,0x0c,0xab,0x04,0xc8,0x0c,0xa5,0x04,0xb2,0x0c,0xa0,0x04,0x9c,0x0c,0x9a,0x04,0x86,0x0c,0x95,0x04,0x71,0x0c,0x90,0x04,0x5b,0x0c,0x8a,0x04,0x45,0x0c,0x85,0x04,0x2f,0x0c,0x7f,0x04,0x19,0x0c,0x7a,0x04,0x03,0x0c,0x75,0x04,0xee,0x0b,0x6f,0x04,0xd8,0x0b,0x6a,0x04,0xc2,0x0b,0x65,0x04,0xad,0x0b,0x5f,0x04,0x97,0x0b,0x5a,0x04,0x82,0x0b,0x55,0x04,0x6c,0x0b,  \
    0x50,0x04,0x57,0x0b,0x4b,0x04,0x41,0x0b,0x45,0x04,0x2c,0x0b,0x40,0x04,0x16,0x0b,0x3b,0x04,0x01,0x0b,0x36,0x04,0xec,0x0a,0x31,0x04,0xd6,0x0a,0x2c,0x04,0xc1,0x0a,0x27,0x04,0xac,0x0a,0x22,0x04,0x97,0x0a,0x1c,0x04,0x82,0x0a,0x15,0x04,0x71,0x0a,0x0f,0x04,0x60,0x0a,0x08,0x04,0x4e,0x0a,0x02,0x04,0x3d,0x0a,0xfb,0x03,0x2c,0x0a,0xf5,0x03,0x1a,0x0a,0xee,0x03,0x09,0x0a,0xe8,0x03,0xf8,0x09,0xe2,0x03,0xe7,0x09,0xdb,0x03,0xd5,0x09,0xd5,0x03,0xc4,0x09,0xcf,0x03,  \
    0xb3,0x09,0xc9,0x03,0xa2,0x09,0xc3,0x03,0x91,0x09,0xbd,0x03,0x7f,0x09,0xb7,0x03,0x6e,0x09,0xb1,0x03,0x5d,0x09,0xab,0x03,0x4c,0x09,0xa6,0x03,0x3b,0x09,0xa0,0x03,0x2a,0x09,0x9b,0x03,0x18,0x09,0x95,0x03,0x06,0x09,0x90,0x03,0xf5,0x08,0x8b,0x03,0xe3,0x08,0x86,0x03,0xd1,0x08,0x80,0x03,0xbf,0x08,0x7b,0x03,0xae,0x08,0x76,0x03,0x9c,0x08,0x71,0x03,0x8a,0x08,0x6c,0x03,0x79,0x08,0x68,0x03,0x67,0x08,0x63,0x03,0x55,0x08,0x5e,0x03,0x43,0x08,0x59,0x03,0x31,0x08,  \
    0x55,0x03,0x20,0x08,0x50,0x03,0x0e,0x08,0x4c,0x03,0xfc,0x07,0x47,0x03,0xea,0x07,0x43,0x03,0xd8,0x07,0x3e,0x03,0xc7,0x07,0x3a,0x03,0xb5,0x07,0x36,0x03,0xa3,0x07,0x31,0x03,0x91,0x07,0x2e,0x03,0x7d,0x07,0x2a,0x03,0x69,0x07,0x27,0x03,0x55,0x07,0x23,0x03,0x41,0x07,0x20,0x03,0x2d,0x07,0x1d,0x03,0x19,0x07,0x19,0x03,0x05,0x07,0x16,0x03,0xf1,0x06,0x13,0x03,0xdd,0x06,0x0f,0x03,0xca,0x06,0x0c,0x03,0xb6,0x06,0x09,0x03,0xa2,0x06,0x06,0x03,0x8e,0x06,0x02,0x03,  \
    0x7a,0x06,0xff,0x02,0x66,0x06,0xfc,0x02,0x53,0x06,0xf9,0x02,0x3f,0x06,0xf6,0x02,0x2b,0x06,0xf3,0x02,0x18,0x06,0xf0,0x02,0x04,0x06,0xed,0x02,0xf0,0x05,0xea,0x02,0xdd,0x05,0xe7,0x02,0xc9,0x05,0xe4,0x02,0xb6,0x05,0xe1,0x02,0xa3,0x05,0xde,0x02,0x91,0x05,0xdb,0x02,0x7f,0x05,0xd8,0x02,0x6d,0x05,0xd5,0x02,0x5a,0x05,0xd2,0x02,0x48,0x05,0xcf,0x02,0x36,0x05,0xcc,0x02,0x24,0x05,0xca,0x02,0x11,0x05,0xc7,0x02,0xff,0x04,0xc4,0x02,0xed,0x04,0xc1,0x02,0xda,0x04,  \
    0xbf,0x02,0xc8,0x04,0xbc,0x02,0xb6,0x04,0xba,0x02,0xa3,0x04,0xb7,0x02,0x91,0x04,0xb5,0x02,0x7f,0x04,0xb2,0x02,0x6c,0x04,0xb0,0x02,0x5a,0x04,0xae,0x02,0x48,0x04,0xab,0x02,0x35,0x04,0xa9,0x02,0x23,0x04,0xa7,0x02,0x10,0x04,0xa5,0x02,0xfe,0x03,0xa2,0x02,0xec,0x03,0xa0,0x02,0xda,0x03,0x9e,0x02,0xc8,0x03,0x9c,0x02,0xb7,0x03,0x9a,0x02,0xa5,0x03,0x98,0x02,0x94,0x03,0x96,0x02,0x82,0x03,0x94,0x02,0x71,0x03,0x92,0x02,0x5f,0x03,0x90,0x02,0x4e,0x03,0x8e,0x02,  \
    0x3c,0x03,0x8c,0x02,0x2a,0x03,0x8b,0x02,0x19,0x03,0x89,0x02,0x07,0x03,0x87,0x02,0xf5,0x02,0x86,0x02,0xe3,0x02,0x84,0x02,0xd1,0x02,0x83,0x02,0xbf,0x02,0x81,0x02,0xad,0x02,0x80,0x02,0x9b,0x02,0x7e,0x02,0x89,0x02,0x7d,0x02,0x77,0x02,0x7c,0x02,0x65,0x02,0x7b,0x02,0x53,0x02,0x79,0x02,0x40,0x02,0x78,0x02,0x2e,0x02,0x77,0x02,0x1c,0x02,0x76,0x02,0x09,0x02,0x75,0x02,0xf7,0x01,0x74,0x02,0xe4,0x01,0x73,0x02,0xd0,0x01,0x72,0x02,0xbd,0x01,0x71,0x02,0xaa,0x01,  \
    0x71,0x02,0x97,0x01,0x70,0x02,0x83,0x01,0x6f,0x02,0x70,0x01,0x6e,0x02,0x5d,0x01,0x6e,0x02,0x4a,0x01,0x6d,0x02,0x36,0x01,0x6c,0x02,0x23,0x01,0x6c,0x02,0x10,0x01,0x6b,0x02,0xfd,0x00,0x6b,0x02,0xe9,0x00,0x6a,0x02,0xd6,0x00,0x6a,0x02,0xc3,0x00,0x69,0x02,0xb0,0x00,0x69,0x02,0x9c,0x00,0x69,0x02,0x89,0x00,0x68,0x02,0x76,0x00,0x68,0x02,0x62,0x00,0x68,0x02,0x4f,0x00,0x68,0x02,0x3c,0x00,0x67,0x02,0x29,0x00,0x67,0x02,0x15,0x00,0x67,0x02,0x02,0x00,0x67,0x02,  \
    0xef,0xff,0x67,0x02,0xdc,0xff,0x67,0x02,0xc8,0xff,0x67,0x02,0xb5,0xff,0x67,0x02,0xa2,0xff,0x67,0x02,0x8e,0xff,0x67,0x02,0x7b,0xff,0x67,0x02,0x68,0xff,0x67,0x02,0x55,0xff,0x68,0x02,0x41,0xff,0x68,0x02,0x2e,0xff,0x68,0x02,0x1b,0xff,0x68,0x02,0x07,0xff,0x69,0x02,0xf4,0xfe,0x69,0x02,0xe1,0xfe,0x6a,0x02,0xce,0xfe,0x6a,0x02,0xba,0xfe,0x6a,0x02,0xa7,0xfe,0x6b,0x02,0x94,0xfe,0x6b,0x02,0x81,0xfe,0x6c,0x02,0x6d,0xfe,0x6d,0x02,0x5a,0xfe,0x6d,0x02,0x47,0xfe,  \
    0x6e,0x02,0x34,0xfe,0x6f,0x02,0x20,0xfe,0x6f,0x02,0x0d,0xfe,0x70,0x02,0xfa,0xfd,0x71,0x02,0xe7,0xfd,0x72,0x02,0xd4,0xfd,0x73,0x02,0xc0,0xfd,0x73,0x02,0xad,0xfd,0x74,0x02,0x99,0xfd,0x75,0x02,0x86,0xfd,0x76,0x02,0x72,0xfd,0x77,0x02,0x5f,0xfd,0x78,0x02,0x4b,0xfd,0x79,0x02,0x38,0xfd,0x7a,0x02,0x24,0xfd,0x7b,0x02,0x10,0xfd,0x7d,0x02,0xfd,0xfc,0x7e,0x02,0xe9,0xfc,0x7f,0x02,0xd5,0xfc,0x80,0x02,0xc1,0xfc,0x81,0x02,0xae,0xfc,0x83,0x02,0x9a,0xfc,0x84,0x02,  \
    0x86,0xfc,0x85,0x02,0x72,0xfc,0x87,0x02,0x5f,0xfc,0x88,0x02,0x4b,0xfc,0x8a,0x02,0x37,0xfc,0x8b,0x02,0x23,0xfc,0x8c,0x02,0x0f,0xfc,0x8e,0x02,0xfb,0xfb,0x90,0x02,0xe8,0xfb,0x91,0x02,0xd4,0xfb,0x93,0x02,0xc0,0xfb,0x94,0x02,0xac,0xfb,0x96,0x02,0x98,0xfb,0x98,0x02,0x85,0xfb,0x9a,0x02,0x72,0xfb,0x9c,0x02,0x5f,0xfb,0x9e,0x02,0x4d,0xfb,0xa0,0x02,0x3a,0xfb,0xa2,0x02,0x27,0xfb,0xa4,0x02,0x14,0xfb,0xa6,0x02,0x02,0xfb,0xa8,0x02,0xef,0xfa,0xaa,0x02,0xdc,0xfa,  \
    0xac,0x02,0xca,0xfa,0xaf,0x02,0xb7,0xfa,0xb1,0x02,0xa4,0xfa,0xb3,0x02,0x92,0xfa,0xb6,0x02,0x7f,0xfa,0xb8,0x02,0x6d,0xfa,0xbb,0x02,0x5a,0xfa,0xbd,0x02,0x48,0xfa,0xc0,0x02,0x35,0xfa,0xc2,0x02,0x23,0xfa,0xc5,0x02,0x10,0xfa,0xc8,0x02,0xfe,0xf9,0xcb,0x02,0xec,0xf9,0xcd,0x02,0xd9,0xf9,0xd0,0x02,0xc7,0xf9,0xd3,0x02,0xb5,0xf9,0xd6,0x02,0xa2,0xf9,0xd9,0x02,0x8f,0xf9,0xdc,0x02,0x7b,0xf9,0xde,0x02,0x68,0xf9,0xe1,0x02,0x55,0xf9,0xe4,0x02,0x41,0xf9,0xe7,0x02,  \
    0x2e,0xf9,0xea,0x02,0x1b,0xf9,0xed,0x02,0x08,0xf9,0xf0,0x02,0xf4,0xf8,0xf3,0x02,0xe1,0xf8,0xf6,0x02,0xce,0xf8,0xfa,0x02,0xba,0xf8,0xfd,0x02,0xa7,0xf8,0x00,0x03,0x94,0xf8,0x03,0x03,0x81,0xf8,0x07,0x03,0x6d,0xf8,0x0a,0x03,0x5a,0xf8,0x0d,0x03,0x47,0xf8,0x11,0x03,0x34,0xf8,0x14,0x03,0x20,0xf8,0x18,0x03,0x0d,0xf8,0x1b,0x03,0xfa,0xf7,0x1f,0x03,0xe7,0xf7,0x22,0x03,0xd4,0xf7,0x26,0x03,0xc1,0xf7,0x2a,0x03,0xae,0xf7,0x2e,0x03,0x9c,0xf7,0x32,0x03,0x89,0xf7,  \
    0x36,0x03,0x77,0xf7,0x3a,0x03,0x64,0xf7,0x3e,0x03,0x52,0xf7,0x43,0x03,0x3f,0xf7,0x47,0x03,0x2d,0xf7,0x4b,0x03,0x1a,0xf7,0x50,0x03,0x08,0xf7,0x54,0x03,0xf6,0xf6,0x58,0x03,0xe3,0xf6,0x5d,0x03,0xd1,0xf6,0x61,0x03,0xbe,0xf6,0x66,0x03,0xac,0xf6,0x6b,0x03,0x9a,0xf6,0x6f,0x03,0x87,0xf6,0x74,0x03,0x75,0xf6,0x79,0x03,0x63,0xf6,0x7e,0x03,0x50,0xf6,0x82,0x03,0x3e,0xf6,0x87,0x03,0x2c,0xf6,0x8c,0x03,0x19,0xf6,0x91,0x03,0x05,0xf6,0x95,0x03,0xf2,0xf5,0x9a,0x03,  \
    0xdf,0xf5,0x9f,0x03,0xcb,0xf5,0xa4,0x03,0xb8,0xf5,0xa9,0x03,0xa4,0xf5,0xae,0x03,0x91,0xf5,0xb3,0x03,0x7e,0xf5,0xb8,0x03,0x6a,0xf5,0xbd,0x03,0x57,0xf5,0xc2,0x03,0x44,0xf5,0xc7,0x03,0x30,0xf5,0xcc,0x03,0x1d,0xf5,0xd1,0x03,0x09,0xf5,0xd6,0x03,0xf6,0xf4,0xdc,0x03,0xe3,0xf4,0xe1,0x03,0xcf,0xf4,0xe6,0x03,0xbc,0xf4,0xec,0x03,0xa8,0xf4,0xf1,0x03,0x95,0xf4,0xf7,0x03,0x82,0xf4,0xfd,0x03,0x6f,0xf4,0x02,0x04,0x5c,0xf4,0x08,0x04,0x4a,0xf4,0x0e,0x04,0x37,0xf4,  \
    0x14,0x04,0x24,0xf4,0x1b,0x04,0x12,0xf4,0x21,0x04,0xff,0xf3,0x27,0x04,0xec,0xf3,0x2d,0x04,0xd9,0xf3,0x33,0x04,0xc6,0xf3,0x3a,0x04,0xb3,0xf3,0x40,0x04,0xa1,0xf3,0x46,0x04,0x8e,0xf3,0x4d,0x04,0x7b,0xf3,0x53,0x04,0x68,0xf3,0x5a,0x04,0x55,0xf3,0x60,0x04,0x42,0xf3,0x67,0x04,0x2f,0xf3,0x6e,0x04,0x1c,0xf3,0x73,0x04,0x06,0xf3,0x78,0x04,0xf0,0xf2,0x7e,0x04,0xda,0xf2,0x83,0x04,0xc5,0xf2,0x88,0x04,0xaf,0xf2,0x8e,0x04,0x99,0xf2,0x93,0x04,0x83,0xf2,0x98,0x04,  \
    0x6d,0xf2,0x9e,0x04,0x57,0xf2,0xa3,0x04,0x41,0xf2,0xa9,0x04,0x2b,0xf2,0xae,0x04,0x14,0xf2,0xb4,0x04,0xfe,0xf1,0xb9,0x04,0xe8,0xf1,0xbe,0x04,0xd2,0xf1,0xc4,0x04,0xbb,0xf1,0xc9,0x04,0xa5,0xf1,0xcf,0x04,0x8e,0xf1,0xd5,0x04,0x79,0xf1,0xdc,0x04,0x65,0xf1,0xe3,0x04,0x51,0xf1,0xea,0x04,0x3d,0xf1,0xf1,0x04,0x28,0xf1,0xf8,0x04,0x14,0xf1,0xff,0x04,0x00,0xf1,0x06,0x05,0xeb,0xf0,0x0d,0x05,0xd7,0xf0,0x14,0x05,0xc2,0xf0,0x1b,0x05,0xad,0xf0,0x22,0x05,0x99,0xf0,  \
    0x29,0x05,0x84,0xf0,0x30,0x05,0x6f,0xf0,0x37,0x05,0x5a,0xf0,0x3e,0x05,0x44,0xf0,0x45,0x05,0x2f,0xf0,0x4c,0x05,0x1a,0xf0,0x53,0x05,0x04,0xf0,0x5a,0x05,0xef,0xef,0x61,0x05,0xda,0xef,0x68,0x05,0xc4,0xef,0x6f,0x05,0xaf,0xef,0x76,0x05,0x99,0xef,0x7d,0x05,0x83,0xef,0x84,0x05,0x6d,0xef,0x8b,0x05,0x57,0xef,0x92,0x05,0x41,0xef,0x98,0x05,0x2b,0xef,0x9f,0x05,0x14,0xef,0xa6,0x05,0xfe,0xee,0xac,0x05,0xe7,0xee,0xb3,0x05,0xd0,0xee,0xb9,0x05,0xb8,0xee,0xbf,0x05,  \
    0xa1,0xee,0xc5,0x05,0x8a,0xee,0xcb,0x05,0x72,0xee,0xd1,0x05,0x5a,0xee,0xd7,0x05,0x42,0xee,0xdd,0x05,0x29,0xee,0xe1,0x05,0x0f,0xee,0xe6,0x05,0xf5,0xed,0xea,0x05,0xdb,0xed,0xee,0x05,0xc1,0xed,0xf2,0x05,0xa6,0xed,0xf7,0x05,0x8c,0xed,0xfb,0x05,0x71,0xed,0xfe,0x05,0x56,0xed,0x02,0x06,0x3b,0xed,0x06,0x06,0x1f,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x47,0x06,0x8a,0x12,0x43,0x06,0x6f,0x12,0x3f,0x06,0x54,0x12,0x3b,0x06,0x39,0x12,0x37,0x06,0x1e,0x12,0x32,0x06,0x03,0x12,0x2e,0x06,0xe9,0x11,0x29,0x06,0xce,0x11,0x25,0x06,0xb4,0x11,0x20,0x06,0x9a,0x11,0x1b,0x06,0x80,0x11,0x16,0x06,0x66,0x11,0x11,0x06,0x4c,0x11,0x0c,0x06,0x33,0x11,0x07,0x06,  \
    0x19,0x11,0x02,0x06,0x00,0x11,0xfc,0x05,0xe7,0x10,0xf7,0x05,0xce,0x10,0xf1,0x05,0xb5,0x10,0xec,0x05,0x9c,0x10,0xe6,0x05,0x84,0x10,0xdf,0x05,0x6c,0x10,0xd9,0x05,0x55,0x10,0xd2,0x05,0x3d,0x10,0xcc,0x05,0x26,0x10,0xc5,0x05,0x0f,0x10,0xbe,0x05,0xf8,0x0f,0xb7,0x05,0xe2,0x0f,0xb0,0x05,0xcb,0x0f,0xaa,0x05,0xb5,0x0f,0xa3,0x05,0x9e,0x0f,0x9c,0x05,0x88,0x0f,0x94,0x05,0x72,0x0f,0x8d,0x05,0x5c,0x0f,0x86,0x05,0x46,0x0f,0x7f,0x05,0x30,0x0f,0x78,0x05,0x1a,0x0f,  \
    0x71,0x05,0x05,0x0f,0x69,0x05,0xef,0x0e,0x62,0x05,0xda,0x0e,0x5a,0x05,0xc5,0x0e,0x52,0x05,0xb2,0x0e,0x4a,0x05,0x9e,0x0e,0x41,0x05,0x8b,0x0e,0x39,0x05,0x78,0x0e,0x31,0x05,0x64,0x0e,0x28,0x05,0x51,0x0e,0x20,0x05,0x3e,0x0e,0x17,0x05,0x2c,0x0e,0x0f,0x05,0x19,0x0e,0x07,0x05,0x06,0x0e,0xfe,0x04,0xf4,0x0d,0xf6,0x04,0xe1,0x0d,0xed,0x04,0xcf,0x0d,0xe5,0x04,0xbd,0x0d,0xdd,0x04,0xab,0x0d,0xd4,0x04,0x99,0x0d,0xcc,0x04,0x86,0x0d,0xc7,0x04,0x70,0x0d,0xc1,0x04,  \
    0x59,0x0d,0xbc,0x04,0x43,0x0d,0xb6,0x04,0x2d,0x0d,0xb0,0x04,0x17,0x0d,0xab,0x04,0x01,0x0d,0xa5,0x04,0xeb,0x0c,0x9f,0x04,0xd4,0x0c,0x9a,0x04,0xbe,0x0c,0x94,0x04,0xa9,0x0c,0x8f,0x04,0x93,0x0c,0x89,0x04,0x7d,0x0c,0x84,0x04,0x67,0x0c,0x7e,0x04,0x51,0x0c,0x79,0x04,0x3b,0x0c,0x73,0x04,0x26,0x0c,0x6e,0x04,0x10,0x0c,0x68,0x04,0xfa,0x0b,0x63,0x04,0xe5,0x0b,0x5d,0x04,0xcf,0x0b,0x58,0x04,0xb9,0x0b,0x53,0x04,0xa4,0x0b,0x4d,0x04,0x8e,0x0b,0x48,0x04,0x79,0x0b,  \
    0x43,0x04,0x63,0x0b,0x3d,0x04,0x4e,0x0b,0x38,0x04,0x39,0x0b,0x33,0x04,0x23,0x0b,0x2e,0x04,0x0e,0x0b,0x28,0x04,0xf9,0x0a,0x23,0x04,0xe3,0x0a,0x1e,0x04,0xce,0x0a,0x19,0x04,0xb9,0x0a,0x14,0x04,0xa4,0x0a,0x0f,0x04,0x8f,0x0a,0x09,0x04,0x7a,0x0a,0x02,0x04,0x69,0x0a,0xfc,0x03,0x58,0x0a,0xf5,0x03,0x46,0x0a,0xee,0x03,0x35,0x0a,0xe8,0x03,0x24,0x0a,0xe1,0x03,0x13,0x0a,0xdb,0x03,0x01,0x0a,0xd4,0x03,0xf0,0x09,0xce,0x03,0xdf,0x09,0xc8,0x03,0xce,0x09,0xc2,0x03,  \
    0xbd,0x09,0xbb,0x03,0xab,0x09,0xb5,0x03,0x9a,0x09,0xaf,0x03,0x89,0x09,0xa9,0x03,0x78,0x09,0xa3,0x03,0x67,0x09,0x9d,0x03,0x56,0x09,0x98,0x03,0x45,0x09,0x92,0x03,0x34,0x09,0x8c,0x03,0x22,0x09,0x87,0x03,0x11,0x09,0x81,0x03,0xff,0x08,0x7c,0x03,0xee,0x08,0x77,0x03,0xdc,0x08,0x71,0x03,0xca,0x08,0x6c,0x03,0xb8,0x08,0x67,0x03,0xa7,0x08,0x62,0x03,0x95,0x08,0x5d,0x03,0x83,0x08,0x58,0x03,0x72,0x08,0x53,0x03,0x60,0x08,0x4e,0x03,0x4e,0x08,0x4a,0x03,0x3d,0x08,  \
    0x45,0x03,0x2b,0x08,0x40,0x03,0x19,0x08,0x3c,0x03,0x07,0x08,0x37,0x03,0xf6,0x07,0x32,0x03,0xe4,0x07,0x2e,0x03,0xd2,0x07,0x2a,0x03,0xc0,0x07,0x25,0x03,0xae,0x07,0x21,0x03,0x9d,0x07,0x1d,0x03,0x8b,0x07,0x19,0x03,0x77,0x07,0x16,0x03,0x63,0x07,0x12,0x03,0x4f,0x07,0x0e,0x03,0x3b,0x07,0x0b,0x03,0x27,0x07,0x08,0x03,0x13,0x07,0x04,0x03,0xff,0x06,0x01,0x03,0xec,0x06,0xfd,0x02,0xd8,0x06,0xfa,0x02,0xc4,0x06,0xf7,0x02,0xb0,0x06,0xf4,0x02,0x9c,0x06,0xf0,0x02,  \
    0x89,0x06,0xed,0x02,0x75,0x06,0xea,0x02,0x61,0x06,0xe7,0x02,0x4e,0x06,0xe4,0x02,0x3a,0x06,0xe1,0x02,0x26,0x06,0xde,0x02,0x13,0x06,0xdb,0x02,0xff,0x05,0xd8,0x02,0xec,0x05,0xd5,0x02,0xd8,0x05,0xd2,0x02,0xc4,0x05,0xcf,0x02,0xb1,0x05,0xcc,0x02,0x9f,0x05,0xc8,0x02,0x8d,0x05,0xc5,0x02,0x7b,0x05,0xc2,0x02,0x68,0x05,0xbf,0x02,0x56,0x05,0xbc,0x02,0x44,0x05,0xb9,0x02,0x32,0x05,0xb7,0x02,0x20,0x05,0xb4,0x02,0x0d,0x05,0xb1,0x02,0xfb,0x04,0xae,0x02,0xe9,0x04,  \
    0xac,0x02,0xd7,0x04,0xa9,0x02,0xc4,0x04,0xa6,0x02,0xb2,0x04,0xa4,0x02,0xa0,0x04,0xa1,0x02,0x8d,0x04,0x9f,0x02,0x7b,0x04,0x9c,0x02,0x69,0x04,0x9a,0x02,0x56,0x04,0x98,0x02,0x44,0x04,0x95,0x02,0x32,0x04,0x93,0x02,0x1f,0x04,0x91,0x02,0x0d,0x04,0x8e,0x02,0xfb,0x03,0x8c,0x02,0xe8,0x03,0x8a,0x02,0xd6,0x03,0x88,0x02,0xc5,0x03,0x86,0x02,0xb4,0x03,0x84,0x02,0xa2,0x03,0x81,0x02,0x91,0x03,0x7f,0x02,0x80,0x03,0x7d,0x02,0x6e,0x03,0x7c,0x02,0x5d,0x03,0x7a,0x02,  \
    0x4b,0x03,0x78,0x02,0x39,0x03,0x76,0x02,0x28,0x03,0x74,0x02,0x16,0x03,0x73,0x02,0x04,0x03,0x71,0x02,0xf2,0x02,0x6f,0x02,0xe1,0x02,0x6e,0x02,0xcf,0x02,0x6c,0x02,0xbd,0x02,0x6b,0x02,0xab,0x02,0x69,0x02,0x99,0x02,0x68,0x02,0x87,0x02,0x67,0x02,0x75,0x02,0x65,0x02,0x63,0x02,0x64,0x02,0x51,0x02,0x63,0x02,0x3e,0x02,0x62,0x02,0x2c,0x02,0x61,0x02,0x1a,0x02,0x5f,0x02,0x07,0x02,0x5e,0x02,0xf5,0x01,0x5d,0x02,0xe2,0x01,0x5d,0x02,0xcf,0x01,0x5c,0x02,0xbc,0x01,  \
    0x5b,0x02,0xa8,0x01,0x5a,0x02,0x95,0x01,0x59,0x02,0x82,0x01,0x58,0x02,0x6f,0x01,0x58,0x02,0x5c,0x01,0x57,0x02,0x48,0x01,0x56,0x02,0x35,0x01,0x56,0x02,0x22,0x01,0x55,0x02,0x0f,0x01,0x55,0x02,0xfc,0x00,0x54,0x02,0xe8,0x00,0x54,0x02,0xd5,0x00,0x53,0x02,0xc2,0x00,0x53,0x02,0xaf,0x00,0x52,0x02,0x9c,0x00,0x52,0x02,0x88,0x00,0x52,0x02,0x75,0x00,0x51,0x02,0x62,0x00,0x51,0x02,0x4f,0x00,0x51,0x02,0x3c,0x00,0x51,0x02,0x28,0x00,0x51,0x02,0x15,0x00,0x50,0x02,  \
    0x02,0x00,0x50,0x02,0xef,0xff,0x50,0x02,0xdb,0xff,0x50,0x02,0xc8,0xff,0x50,0x02,0xb5,0xff,0x50,0x02,0xa2,0xff,0x50,0x02,0x8f,0xff,0x51,0x02,0x7b,0xff,0x51,0x02,0x68,0xff,0x51,0x02,0x55,0xff,0x51,0x02,0x42,0xff,0x51,0x02,0x2e,0xff,0x52,0x02,0x1b,0xff,0x52,0x02,0x08,0xff,0x52,0x02,0xf5,0xfe,0x53,0x02,0xe2,0xfe,0x53,0x02,0xce,0xfe,0x53,0x02,0xbb,0xfe,0x54,0x02,0xa8,0xfe,0x54,0x02,0x95,0xfe,0x55,0x02,0x82,0xfe,0x55,0x02,0x6f,0xfe,0x56,0x02,0x5b,0xfe,  \
    0x57,0x02,0x48,0xfe,0x57,0x02,0x35,0xfe,0x58,0x02,0x22,0xfe,0x59,0x02,0x0f,0xfe,0x59,0x02,0xfc,0xfd,0x5a,0x02,0xe8,0xfd,0x5b,0x02,0xd5,0xfd,0x5c,0x02,0xc2,0xfd,0x5d,0x02,0xaf,0xfd,0x5e,0x02,0x9b,0xfd,0x5f,0x02,0x88,0xfd,0x60,0x02,0x74,0xfd,0x61,0x02,0x61,0xfd,0x62,0x02,0x4d,0xfd,0x63,0x02,0x3a,0xfd,0x64,0x02,0x26,0xfd,0x65,0x02,0x13,0xfd,0x66,0x02,0xff,0xfc,0x67,0x02,0xeb,0xfc,0x68,0x02,0xd8,0xfc,0x6a,0x02,0xc4,0xfc,0x6b,0x02,0xb0,0xfc,0x6c,0x02,  \
    0x9d,0xfc,0x6e,0x02,0x89,0xfc,0x6f,0x02,0x75,0xfc,0x70,0x02,0x62,0xfc,0x72,0x02,0x4e,0xfc,0x73,0x02,0x3a,0xfc,0x75,0x02,0x26,0xfc,0x76,0x02,0x12,0xfc,0x78,0x02,0xff,0xfb,0x79,0x02,0xeb,0xfb,0x7b,0x02,0xd7,0xfb,0x7c,0x02,0xc3,0xfb,0x7e,0x02,0xaf,0xfb,0x80,0x02,0x9c,0xfb,0x81,0x02,0x89,0xfb,0x83,0x02,0x76,0xfb,0x85,0x02,0x63,0xfb,0x87,0x02,0x50,0xfb,0x89,0x02,0x3e,0xfb,0x8b,0x02,0x2b,0xfb,0x8d,0x02,0x18,0xfb,0x90,0x02,0x06,0xfb,0x92,0x02,0xf3,0xfa,  \
    0x94,0x02,0xe0,0xfa,0x96,0x02,0xce,0xfa,0x98,0x02,0xbb,0xfa,0x9b,0x02,0xa9,0xfa,0x9d,0x02,0x96,0xfa,0xa0,0x02,0x84,0xfa,0xa2,0x02,0x71,0xfa,0xa5,0x02,0x5f,0xfa,0xa7,0x02,0x4c,0xfa,0xaa,0x02,0x3a,0xfa,0xac,0x02,0x27,0xfa,0xaf,0x02,0x15,0xfa,0xb2,0x02,0x03,0xfa,0xb5,0x02,0xf0,0xf9,0xb7,0x02,0xde,0xf9,0xba,0x02,0xcc,0xf9,0xbd,0x02,0xba,0xf9,0xc0,0x02,0xa7,0xf9,0xc3,0x02,0x94,0xf9,0xc6,0x02,0x80,0xf9,0xc8,0x02,0x6d,0xf9,0xcb,0x02,0x5a,0xf9,0xce,0x02,  \
    0x47,0xf9,0xd1,0x02,0x33,0xf9,0xd4,0x02,0x20,0xf9,0xd7,0x02,0x0d,0xf9,0xda,0x02,0xfa,0xf8,0xdd,0x02,0xe7,0xf8,0xe1,0x02,0xd3,0xf8,0xe4,0x02,0xc0,0xf8,0xe7,0x02,0xad,0xf8,0xea,0x02,0x9a,0xf8,0xed,0x02,0x86,0xf8,0xf1,0x02,0x73,0xf8,0xf4,0x02,0x60,0xf8,0xf8,0x02,0x4d,0xf8,0xfb,0x02,0x3a,0xf8,0xff,0x02,0x27,0xf8,0x02,0x03,0x13,0xf8,0x06,0x03,0x00,0xf8,0x09,0x03,0xed,0xf7,0x0d,0x03,0xda,0xf7,0x11,0x03,0xc7,0xf7,0x15,0x03,0xb5,0xf7,0x19,0x03,0xa2,0xf7,  \
    0x1d,0x03,0x90,0xf7,0x21,0x03,0x7d,0xf7,0x25,0x03,0x6b,0xf7,0x29,0x03,0x58,0xf7,0x2d,0x03,0x46,0xf7,0x31,0x03,0x34,0xf7,0x36,0x03,0x21,0xf7,0x3a,0x03,0x0f,0xf7,0x3e,0x03,0xfc,0xf6,0x43,0x03,0xea,0xf6,0x47,0x03,0xd8,0xf6,0x4c,0x03,0xc5,0xf6,0x51,0x03,0xb3,0xf6,0x55,0x03,0xa1,0xf6,0x5a,0x03,0x8e,0xf6,0x5f,0x03,0x7c,0xf6,0x63,0x03,0x6a,0xf6,0x68,0x03,0x57,0xf6,0x6d,0x03,0x45,0xf6,0x72,0x03,0x33,0xf6,0x77,0x03,0x20,0xf6,0x7c,0x03,0x0c,0xf6,0x80,0x03,  \
    0xf9,0xf5,0x85,0x03,0xe6,0xf5,0x8a,0x03,0xd3,0xf5,0x8f,0x03,0xbf,0xf5,0x94,0x03,0xac,0xf5,0x99,0x03,0x99,0xf5,0x9d,0x03,0x85,0xf5,0xa2,0x03,0x72,0xf5,0xa8,0x03,0x5f,0xf5,0xad,0x03,0x4b,0xf5,0xb2,0x03,0x38,0xf5,0xb7,0x03,0x25,0xf5,0xbc,0x03,0x11,0xf5,0xc1,0x03,0xfe,0xf4,0xc7,0x03,0xea,0xf4,0xcc,0x03,0xd7,0xf4,0xd1,0x03,0xc4,0xf4,0xd7,0x03,0xb0,0xf4,0xdc,0x03,0x9d,0xf4,0xe2,0x03,0x8a,0xf4,0xe8,0x03,0x77,0xf4,0xee,0x03,0x64,0xf4,0xf4,0x03,0x52,0xf4,  \
    0xfa,0x03,0x3f,0xf4,0x00,0x04,0x2c,0xf4,0x06,0x04,0x1a,0xf4,0x0c,0x04,0x07,0xf4,0x12,0x04,0xf4,0xf3,0x18,0x04,0xe1,0xf3,0x1f,0x04,0xce,0xf3,0x25,0x04,0xbc,0xf3,0x2b,0x04,0xa9,0xf3,0x32,0x04,0x96,0xf3,0x38,0x04,0x83,0xf3,0x3f,0x04,0x70,0xf3,0x45,0x04,0x5d,0xf3,0x4c,0x04,0x4a,0xf3,0x52,0x04,0x37,0xf3,0x59,0x04,0x24,0xf3,0x5e,0x04,0x0e,0xf3,0x64,0x04,0xf9,0xf2,0x69,0x04,0xe3,0xf2,0x6e,0x04,0xcd,0xf2,0x74,0x04,0xb7,0xf2,0x79,0x04,0xa1,0xf2,0x7f,0x04,  \
    0x8b,0xf2,0x84,0x04,0x75,0xf2,0x89,0x04,0x5f,0xf2,0x8f,0x04,0x49,0xf2,0x94,0x04,0x33,0xf2,0x9a,0x04,0x1d,0xf2,0x9f,0x04,0x07,0xf2,0xa5,0x04,0xf0,0xf1,0xaa,0x04,0xda,0xf1,0xb0,0x04,0xc4,0xf1,0xb5,0x04,0xad,0xf1,0xbb,0x04,0x97,0xf1,0xc1,0x04,0x81,0xf1,0xc8,0x04,0x6d,0xf1,0xcf,0x04,0x59,0xf1,0xd6,0x04,0x45,0xf1,0xdd,0x04,0x31,0xf1,0xe4,0x04,0x1d,0xf1,0xeb,0x04,0x08,0xf1,0xf2,0x04,0xf4,0xf0,0xf9,0x04,0xdf,0xf0,0x00,0x05,0xcb,0xf0,0x07,0x05,0xb6,0xf0,  \
    0x0e,0x05,0xa1,0xf0,0x15,0x05,0x8c,0xf0,0x1c,0x05,0x77,0xf0,0x23,0x05,0x62,0xf0,0x2a,0x05,0x4d,0xf0,0x31,0x05,0x38,0xf0,0x38,0x05,0x22,0xf0,0x3e,0x05,0x0d,0xf0,0x46,0x05,0xf7,0xef,0x4d,0x05,0xe2,0xef,0x54,0x05,0xcd,0xef,0x5b,0x05,0xb7,0xef,0x62,0x05,0xa1,0xef,0x69,0x05,0x8c,0xef,0x70,0x05,0x76,0xef,0x76,0x05,0x5f,0xef,0x7d,0x05,0x49,0xef,0x84,0x05,0x33,0xef,0x8b,0x05,0x1c,0xef,0x91,0x05,0x05,0xef,0x98,0x05,0xef,0xee,0x9e,0x05,0xd8,0xee,0xa4,0x05,  \
    0xc0,0xee,0xab,0x05,0xa9,0xee,0xb1,0x05,0x91,0xee,0xb7,0x05,0x7a,0xee,0xbd,0x05,0x62,0xee,0xc3,0x05,0x4a,0xee,0xc8,0x05,0x31,0xee,0xcd,0x05,0x17,0xee,0xd1,0x05,0xfd,0xed,0xd5,0x05,0xe3,0xed,0xda,0x05,0xc8,0xed,0xde,0x05,0xae,0xed,0xe2,0x05,0x93,0xed,0xe6,0x05,0x78,0xed,0xea,0x05,0x5d,0xed,0xed,0x05,0x42,0xed,0xf1,0x05,0x27,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3b,0x06,0x7e,0x12,0x37,0x06,0x63,0x12,0x33,0x06,0x48,0x12,0x2f,0x06,0x2d,0x12,0x2b,0x06,0x12,0x12,0x26,0x06,0xf7,0x11,0x22,0x06,0xdd,0x11,0x1d,0x06,0xc3,0x11,0x18,0x06,0xa8,0x11,0x14,0x06,0x8e,0x11,0x0f,0x06,0x74,0x11,0x0a,0x06,0x5a,0x11,0x05,0x06,0x41,0x11,0xff,0x05,  \
    0x27,0x11,0xfa,0x05,0x0e,0x11,0xf5,0x05,0xf4,0x10,0xef,0x05,0xdb,0x10,0xea,0x05,0xc2,0x10,0xe4,0x05,0xa9,0x10,0xdf,0x05,0x91,0x10,0xd9,0x05,0x79,0x10,0xd2,0x05,0x61,0x10,0xcc,0x05,0x4a,0x10,0xc5,0x05,0x32,0x10,0xbe,0x05,0x1b,0x10,0xb7,0x05,0x04,0x10,0xb1,0x05,0xed,0x0f,0xaa,0x05,0xd7,0x0f,0xa3,0x05,0xc0,0x0f,0x9c,0x05,0xa9,0x0f,0x95,0x05,0x93,0x0f,0x8e,0x05,0x7d,0x0f,0x86,0x05,0x67,0x0f,0x7f,0x05,0x51,0x0f,0x78,0x05,0x3b,0x0f,0x71,0x05,0x25,0x0f,  \
    0x6a,0x05,0x0f,0x0f,0x62,0x05,0xfa,0x0e,0x5b,0x05,0xe4,0x0e,0x54,0x05,0xcf,0x0e,0x4c,0x05,0xbb,0x0e,0x43,0x05,0xa7,0x0e,0x3b,0x05,0x93,0x0e,0x32,0x05,0x80,0x0e,0x2a,0x05,0x6d,0x0e,0x22,0x05,0x59,0x0e,0x19,0x05,0x46,0x0e,0x11,0x05,0x33,0x0e,0x08,0x05,0x21,0x0e,0x00,0x05,0x0e,0x0e,0xf7,0x04,0xfb,0x0d,0xef,0x04,0xe9,0x0d,0xe6,0x04,0xd6,0x0d,0xde,0x04,0xc4,0x0d,0xd6,0x04,0xb2,0x0d,0xcd,0x04,0xa0,0x0d,0xc5,0x04,0x8e,0x0d,0xbd,0x04,0x7b,0x0d,0xb7,0x04,  \
    0x65,0x0d,0xb1,0x04,0x4f,0x0d,0xac,0x04,0x38,0x0d,0xa6,0x04,0x22,0x0d,0xa0,0x04,0x0c,0x0d,0x9b,0x04,0xf6,0x0c,0x95,0x04,0xe0,0x0c,0x8f,0x04,0xca,0x0c,0x89,0x04,0xb4,0x0c,0x84,0x04,0x9e,0x0c,0x7e,0x04,0x89,0x0c,0x79,0x04,0x73,0x0c,0x73,0x04,0x5d,0x0c,0x6d,0x04,0x47,0x0c,0x68,0x04,0x32,0x0c,0x62,0x04,0x1c,0x0c,0x5d,0x04,0x06,0x0c,0x57,0x04,0xf1,0x0b,0x52,0x04,0xdb,0x0b,0x4c,0x04,0xc6,0x0b,0x47,0x04,0xb0,0x0b,0x41,0x04,0x9b,0x0b,0x3c,0x04,0x85,0x0b,  \
    0x36,0x04,0x70,0x0b,0x31,0x04,0x5a,0x0b,0x2c,0x04,0x45,0x0b,0x26,0x04,0x30,0x0b,0x21,0x04,0x1a,0x0b,0x1c,0x04,0x05,0x0b,0x16,0x04,0xf0,0x0a,0x11,0x04,0xdb,0x0a,0x0c,0x04,0xc6,0x0a,0x07,0x04,0xb1,0x0a,0x01,0x04,0x9c,0x0a,0xfc,0x03,0x87,0x0a,0xf7,0x03,0x72,0x0a,0xf0,0x03,0x61,0x0a,0xe9,0x03,0x50,0x0a,0xe2,0x03,0x3e,0x0a,0xdc,0x03,0x2d,0x0a,0xd5,0x03,0x1c,0x0a,0xcf,0x03,0x0b,0x0a,0xc8,0x03,0xf9,0x09,0xc2,0x03,0xe8,0x09,0xbb,0x03,0xd7,0x09,0xb5,0x03,  \
    0xc6,0x09,0xaf,0x03,0xb5,0x09,0xa8,0x03,0xa4,0x09,0xa2,0x03,0x93,0x09,0x9c,0x03,0x81,0x09,0x96,0x03,0x70,0x09,0x90,0x03,0x5f,0x09,0x8a,0x03,0x4e,0x09,0x84,0x03,0x3d,0x09,0x7f,0x03,0x2c,0x09,0x79,0x03,0x1b,0x09,0x73,0x03,0x09,0x09,0x6e,0x03,0xf8,0x08,0x68,0x03,0xe6,0x08,0x63,0x03,0xd5,0x08,0x5e,0x03,0xc3,0x08,0x59,0x03,0xb1,0x08,0x53,0x03,0xa0,0x08,0x4e,0x03,0x8e,0x08,0x49,0x03,0x7c,0x08,0x44,0x03,0x6b,0x08,0x3f,0x03,0x59,0x08,0x3b,0x03,0x47,0x08,  \
    0x36,0x03,0x36,0x08,0x31,0x03,0x24,0x08,0x2c,0x03,0x12,0x08,0x28,0x03,0x01,0x08,0x23,0x03,0xef,0x07,0x1e,0x03,0xdd,0x07,0x1a,0x03,0xcb,0x07,0x15,0x03,0xba,0x07,0x11,0x03,0xa8,0x07,0x0d,0x03,0x96,0x07,0x08,0x03,0x84,0x07,0x05,0x03,0x70,0x07,0x01,0x03,0x5d,0x07,0xfe,0x02,0x49,0x07,0xfa,0x02,0x35,0x07,0xf6,0x02,0x21,0x07,0xf3,0x02,0x0d,0x07,0xf0,0x02,0xfa,0x06,0xec,0x02,0xe6,0x06,0xe9,0x02,0xd2,0x06,0xe5,0x02,0xbe,0x06,0xe2,0x02,0xab,0x06,0xdf,0x02,  \
    0x97,0x06,0xdc,0x02,0x83,0x06,0xd8,0x02,0x70,0x06,0xd5,0x02,0x5c,0x06,0xd2,0x02,0x48,0x06,0xcf,0x02,0x35,0x06,0xcc,0x02,0x21,0x06,0xc9,0x02,0x0e,0x06,0xc6,0x02,0xfa,0x05,0xc3,0x02,0xe7,0x05,0xc0,0x02,0xd3,0x05,0xbd,0x02,0xc0,0x05,0xba,0x02,0xac,0x05,0xb6,0x02,0x9a,0x05,0xb3,0x02,0x88,0x05,0xb0,0x02,0x76,0x05,0xad,0x02,0x64,0x05,0xaa,0x02,0x52,0x05,0xa7,0x02,0x40,0x05,0xa4,0x02,0x2d,0x05,0xa1,0x02,0x1b,0x05,0x9e,0x02,0x09,0x05,0x9c,0x02,0xf7,0x04,  \
    0x99,0x02,0xe5,0x04,0x96,0x02,0xd2,0x04,0x93,0x02,0xc0,0x04,0x91,0x02,0xae,0x04,0x8e,0x02,0x9c,0x04,0x8c,0x02,0x8a,0x04,0x89,0x02,0x77,0x04,0x87,0x02,0x65,0x04,0x84,0x02,0x53,0x04,0x82,0x02,0x41,0x04,0x80,0x02,0x2e,0x04,0x7d,0x02,0x1c,0x04,0x7b,0x02,0x0a,0x04,0x79,0x02,0xf7,0x03,0x77,0x02,0xe5,0x03,0x74,0x02,0xd3,0x03,0x72,0x02,0xc2,0x03,0x70,0x02,0xb1,0x03,0x6e,0x02,0x9f,0x03,0x6c,0x02,0x8e,0x03,0x6a,0x02,0x7c,0x03,0x68,0x02,0x6b,0x03,0x66,0x02,  \
    0x5a,0x03,0x64,0x02,0x48,0x03,0x62,0x02,0x37,0x03,0x60,0x02,0x25,0x03,0x5e,0x02,0x13,0x03,0x5d,0x02,0x02,0x03,0x5b,0x02,0xf0,0x02,0x59,0x02,0xde,0x02,0x58,0x02,0xcc,0x02,0x56,0x02,0xba,0x02,0x55,0x02,0xa9,0x02,0x53,0x02,0x97,0x02,0x52,0x02,0x85,0x02,0x51,0x02,0x73,0x02,0x4f,0x02,0x60,0x02,0x4e,0x02,0x4e,0x02,0x4d,0x02,0x3c,0x02,0x4c,0x02,0x2a,0x02,0x4a,0x02,0x18,0x02,0x49,0x02,0x05,0x02,0x48,0x02,0xf3,0x01,0x47,0x02,0xe0,0x01,0x46,0x02,0xcd,0x01,  \
    0x46,0x02,0xba,0x01,0x45,0x02,0xa7,0x01,0x44,0x02,0x94,0x01,0x43,0x02,0x80,0x01,0x42,0x02,0x6d,0x01,0x42,0x02,0x5a,0x01,0x41,0x02,0x47,0x01,0x40,0x02,0x34,0x01,0x40,0x02,0x21,0x01,0x3f,0x02,0x0e,0x01,0x3e,0x02,0xfb,0x00,0x3e,0x02,0xe7,0x00,0x3d,0x02,0xd4,0x00,0x3d,0x02,0xc1,0x00,0x3d,0x02,0xae,0x00,0x3c,0x02,0x9b,0x00,0x3c,0x02,0x88,0x00,0x3c,0x02,0x75,0x00,0x3b,0x02,0x61,0x00,0x3b,0x02,0x4e,0x00,0x3b,0x02,0x3b,0x00,0x3b,0x02,0x28,0x00,0x3a,0x02,  \
    0x15,0x00,0x3a,0x02,0x02,0x00,0x3a,0x02,0xee,0xff,0x3a,0x02,0xdb,0xff,0x3a,0x02,0xc8,0xff,0x3a,0x02,0xb5,0xff,0x3a,0x02,0xa2,0xff,0x3a,0x02,0x8f,0xff,0x3a,0x02,0x7c,0xff,0x3a,0x02,0x68,0xff,0x3b,0x02,0x55,0xff,0x3b,0x02,0x42,0xff,0x3b,0x02,0x2f,0xff,0x3b,0x02,0x1c,0xff,0x3c,0x02,0x09,0xff,0x3c,0x02,0xf6,0xfe,0x3c,0x02,0xe2,0xfe,0x3d,0x02,0xcf,0xfe,0x3d,0x02,0xbc,0xfe,0x3e,0x02,0xa9,0xfe,0x3e,0x02,0x96,0xfe,0x3f,0x02,0x83,0xfe,0x3f,0x02,0x70,0xfe,  \
    0x40,0x02,0x5d,0xfe,0x40,0x02,0x49,0xfe,0x41,0x02,0x36,0xfe,0x42,0x02,0x23,0xfe,0x43,0x02,0x10,0xfe,0x43,0x02,0xfd,0xfd,0x44,0x02,0xea,0xfd,0x45,0x02,0xd7,0xfd,0x46,0x02,0xc4,0xfd,0x47,0x02,0xb1,0xfd,0x48,0x02,0x9d,0xfd,0x49,0x02,0x8a,0xfd,0x49,0x02,0x76,0xfd,0x4a,0x02,0x63,0xfd,0x4c,0x02,0x4f,0xfd,0x4d,0x02,0x3c,0xfd,0x4e,0x02,0x28,0xfd,0x4f,0x02,0x15,0xfd,0x50,0x02,0x01,0xfd,0x51,0x02,0xee,0xfc,0x52,0x02,0xda,0xfc,0x54,0x02,0xc7,0xfc,0x55,0x02,  \
    0xb3,0xfc,0x56,0x02,0x9f,0xfc,0x57,0x02,0x8c,0xfc,0x59,0x02,0x78,0xfc,0x5a,0x02,0x64,0xfc,0x5c,0x02,0x51,0xfc,0x5d,0x02,0x3d,0xfc,0x5f,0x02,0x29,0xfc,0x60,0x02,0x16,0xfc,0x62,0x02,0x02,0xfc,0x63,0x02,0xee,0xfb,0x65,0x02,0xdb,0xfb,0x66,0x02,0xc7,0xfb,0x68,0x02,0xb3,0xfb,0x6a,0x02,0x9f,0xfb,0x6c,0x02,0x8c,0xfb,0x6d,0x02,0x7a,0xfb,0x6f,0x02,0x67,0xfb,0x71,0x02,0x54,0xfb,0x73,0x02,0x42,0xfb,0x75,0x02,0x2f,0xfb,0x78,0x02,0x1c,0xfb,0x7a,0x02,0x0a,0xfb,  \
    0x7c,0x02,0xf7,0xfa,0x7e,0x02,0xe5,0xfa,0x80,0x02,0xd2,0xfa,0x83,0x02,0xc0,0xfa,0x85,0x02,0xad,0xfa,0x87,0x02,0x9b,0xfa,0x8a,0x02,0x88,0xfa,0x8c,0x02,0x76,0xfa,0x8f,0x02,0x63,0xfa,0x91,0x02,0x51,0xfa,0x94,0x02,0x3f,0xfa,0x97,0x02,0x2c,0xfa,0x99,0x02,0x1a,0xfa,0x9c,0x02,0x08,0xfa,0x9f,0x02,0xf5,0xf9,0xa2,0x02,0xe3,0xf9,0xa5,0x02,0xd1,0xf9,0xa7,0x02,0xbf,0xf9,0xaa,0x02,0xac,0xf9,0xad,0x02,0x99,0xf9,0xb0,0x02,0x86,0xf9,0xb3,0x02,0x72,0xf9,0xb6,0x02,  \
    0x5f,0xf9,0xb9,0x02,0x4c,0xf9,0xbc,0x02,0x39,0xf9,0xbf,0x02,0x26,0xf9,0xc2,0x02,0x13,0xf9,0xc5,0x02,0xff,0xf8,0xc8,0x02,0xec,0xf8,0xcb,0x02,0xd9,0xf8,0xce,0x02,0xc6,0xf8,0xd2,0x02,0xb3,0xf8,0xd5,0x02,0xa0,0xf8,0xd8,0x02,0x8c,0xf8,0xdb,0x02,0x79,0xf8,0xdf,0x02,0x66,0xf8,0xe2,0x02,0x53,0xf8,0xe6,0x02,0x40,0xf8,0xe9,0x02,0x2d,0xf8,0xed,0x02,0x1a,0xf8,0xf0,0x02,0x07,0xf8,0xf4,0x02,0xf3,0xf7,0xf8,0x02,0xe0,0xf7,0xfc,0x02,0xce,0xf7,0xff,0x02,0xbb,0xf7,  \
    0x03,0x03,0xa9,0xf7,0x08,0x03,0x96,0xf7,0x0c,0x03,0x84,0xf7,0x10,0x03,0x72,0xf7,0x14,0x03,0x5f,0xf7,0x18,0x03,0x4d,0xf7,0x1c,0x03,0x3a,0xf7,0x21,0x03,0x28,0xf7,0x25,0x03,0x16,0xf7,0x2a,0x03,0x03,0xf7,0x2e,0x03,0xf1,0xf6,0x33,0x03,0xdf,0xf6,0x37,0x03,0xcc,0xf6,0x3c,0x03,0xba,0xf6,0x40,0x03,0xa8,0xf6,0x45,0x03,0x95,0xf6,0x4a,0x03,0x83,0xf6,0x4f,0x03,0x71,0xf6,0x54,0x03,0x5f,0xf6,0x58,0x03,0x4c,0xf6,0x5d,0x03,0x3a,0xf6,0x62,0x03,0x27,0xf6,0x67,0x03,  \
    0x14,0xf6,0x6c,0x03,0x01,0xf6,0x70,0x03,0xed,0xf5,0x75,0x03,0xda,0xf5,0x7a,0x03,0xc7,0xf5,0x7f,0x03,0xb4,0xf5,0x84,0x03,0xa0,0xf5,0x89,0x03,0x8d,0xf5,0x8e,0x03,0x7a,0xf5,0x93,0x03,0x66,0xf5,0x98,0x03,0x53,0xf5,0x9d,0x03,0x40,0xf5,0xa2,0x03,0x2d,0xf5,0xa8,0x03,0x19,0xf5,0xad,0x03,0x06,0xf5,0xb2,0x03,0xf3,0xf4,0xb8,0x03,0xdf,0xf4,0xbd,0x03,0xcc,0xf4,0xc2,0x03,0xb8,0xf4,0xc8,0x03,0xa5,0xf4,0xce,0x03,0x92,0xf4,0xd3,0x03,0x7f,0xf4,0xd9,0x03,0x6d,0xf4,  \
    0xdf,0x03,0x5a,0xf4,0xe5,0x03,0x47,0xf4,0xeb,0x03,0x35,0xf4,0xf2,0x03,0x22,0xf4,0xf8,0x03,0x0f,0xf4,0xfe,0x03,0xfc,0xf3,0x04,0x04,0xea,0xf3,0x0a,0x04,0xd7,0xf3,0x11,0x04,0xc4,0xf3,0x17,0x04,0xb1,0xf3,0x1e,0x04,0x9e,0xf3,0x24,0x04,0x8b,0xf3,0x2a,0x04,0x78,0xf3,0x31,0x04,0x65,0xf3,0x38,0x04,0x52,0xf3,0x3e,0x04,0x3f,0xf3,0x45,0x04,0x2c,0xf3,0x4a,0x04,0x17,0xf3,0x50,0x04,0x01,0xf3,0x55,0x04,0xeb,0xf2,0x5a,0x04,0xd5,0xf2,0x60,0x04,0xc0,0xf2,0x65,0x04,  \
    0xaa,0xf2,0x6b,0x04,0x94,0xf2,0x70,0x04,0x7e,0xf2,0x76,0x04,0x68,0xf2,0x7b,0x04,0x52,0xf2,0x80,0x04,0x3c,0xf2,0x86,0x04,0x26,0xf2,0x8b,0x04,0x10,0xf2,0x91,0x04,0xf9,0xf1,0x96,0x04,0xe3,0xf1,0x9c,0x04,0xcd,0xf1,0xa2,0x04,0xb6,0xf1,0xa7,0x04,0xa0,0xf1,0xad,0x04,0x8a,0xf1,0xb4,0x04,0x76,0xf1,0xbb,0x04,0x62,0xf1,0xc2,0x04,0x4e,0xf1,0xc9,0x04,0x3a,0xf1,0xd0,0x04,0x26,0xf1,0xd7,0x04,0x11,0xf1,0xde,0x04,0xfd,0xf0,0xe5,0x04,0xe8,0xf0,0xec,0x04,0xd4,0xf0,  \
    0xf3,0x04,0xbf,0xf0,0xfa,0x04,0xaa,0xf0,0x01,0x05,0x95,0xf0,0x08,0x05,0x80,0xf0,0x0f,0x05,0x6b,0xf0,0x16,0x05,0x56,0xf0,0x1d,0x05,0x40,0xf0,0x24,0x05,0x2b,0xf0,0x2b,0x05,0x15,0xf0,0x32,0x05,0x00,0xf0,0x39,0x05,0xeb,0xef,0x40,0x05,0xd5,0xef,0x47,0x05,0xc0,0xef,0x4e,0x05,0xaa,0xef,0x55,0x05,0x94,0xef,0x5c,0x05,0x7e,0xef,0x62,0x05,0x68,0xef,0x69,0x05,0x51,0xef,0x70,0x05,0x3b,0xef,0x76,0x05,0x24,0xef,0x7d,0x05,0x0e,0xef,0x84,0x05,0xf7,0xee,0x8a,0x05,  \
    0xe0,0xee,0x90,0x05,0xc8,0xee,0x96,0x05,0xb1,0xee,0x9d,0x05,0x99,0xee,0xa3,0x05,0x82,0xee,0xa9,0x05,0x6a,0xee,0xae,0x05,0x52,0xee,0xb4,0x05,0x39,0xee,0xb8,0x05,0x1f,0xee,0xbd,0x05,0x05,0xee,0xc1,0x05,0xea,0xed,0xc5,0x05,0xd0,0xed,0xc9,0x05,0xb6,0xed,0xce,0x05,0x9b,0xed,0xd2,0x05,0x80,0xed,0xd5,0x05,0x65,0xed,0xd9,0x05,0x4a,0xed,0xdd,0x05,0x2f,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x06,0x72,0x12,0x2c,0x06,0x57,0x12,0x28,0x06,0x3c,0x12,0x23,0x06,0x21,0x12,0x1f,0x06,0x06,0x12,0x1b,0x06,0xeb,0x11,0x16,0x06,0xd1,0x11,0x11,0x06,0xb7,0x11,0x0d,0x06,0x9c,0x11,0x08,0x06,0x82,0x11,0x03,0x06,0x68,0x11,0xfe,0x05,0x4f,0x11,0xf9,0x05,  \
    0x35,0x11,0xf3,0x05,0x1b,0x11,0xee,0x05,0x02,0x11,0xe9,0x05,0xe9,0x10,0xe3,0x05,0xd0,0x10,0xde,0x05,0xb7,0x10,0xd8,0x05,0x9e,0x10,0xd2,0x05,0x85,0x10,0xcc,0x05,0x6d,0x10,0xc6,0x05,0x55,0x10,0xbf,0x05,0x3e,0x10,0xb8,0x05,0x27,0x10,0xb1,0x05,0x10,0x10,0xab,0x05,0xf9,0x0f,0xa4,0x05,0xe2,0x0f,0x9d,0x05,0xcb,0x0f,0x96,0x05,0xb4,0x0f,0x8f,0x05,0x9e,0x0f,0x87,0x05,0x88,0x0f,0x80,0x05,0x71,0x0f,0x79,0x05,0x5b,0x0f,0x72,0x05,0x45,0x0f,0x6b,0x05,0x2f,0x0f,  \
    0x63,0x05,0x1a,0x0f,0x5c,0x05,0x04,0x0f,0x55,0x05,0xef,0x0e,0x4d,0x05,0xd9,0x0e,0x46,0x05,0xc4,0x0e,0x3e,0x05,0xaf,0x0e,0x35,0x05,0x9c,0x0e,0x2d,0x05,0x88,0x0e,0x24,0x05,0x75,0x0e,0x1c,0x05,0x61,0x0e,0x13,0x05,0x4e,0x0e,0x0b,0x05,0x3b,0x0e,0x02,0x05,0x28,0x0e,0xfa,0x04,0x15,0x0e,0xf1,0x04,0x03,0x0e,0xe9,0x04,0xf0,0x0d,0xe0,0x04,0xdd,0x0d,0xd8,0x04,0xcb,0x0d,0xcf,0x04,0xb9,0x0d,0xc7,0x04,0xa7,0x0d,0xbe,0x04,0x94,0x0d,0xb6,0x04,0x82,0x0d,0xae,0x04,  \
    0x70,0x0d,0xa8,0x04,0x5a,0x0d,0xa2,0x04,0x43,0x0d,0x9c,0x04,0x2d,0x0d,0x97,0x04,0x17,0x0d,0x91,0x04,0x01,0x0d,0x8b,0x04,0xeb,0x0c,0x85,0x04,0xd5,0x0c,0x7f,0x04,0xc0,0x0c,0x7a,0x04,0xaa,0x0c,0x74,0x04,0x94,0x0c,0x6e,0x04,0x7e,0x0c,0x69,0x04,0x68,0x0c,0x63,0x04,0x53,0x0c,0x5d,0x04,0x3d,0x0c,0x57,0x04,0x27,0x0c,0x52,0x04,0x12,0x0c,0x4c,0x04,0xfc,0x0b,0x47,0x04,0xe7,0x0b,0x41,0x04,0xd1,0x0b,0x3b,0x04,0xbc,0x0b,0x36,0x04,0xa6,0x0b,0x30,0x04,0x91,0x0b,  \
    0x2b,0x04,0x7c,0x0b,0x25,0x04,0x66,0x0b,0x20,0x04,0x51,0x0b,0x1b,0x04,0x3c,0x0b,0x15,0x04,0x27,0x0b,0x10,0x04,0x12,0x0b,0x0a,0x04,0xfc,0x0a,0x05,0x04,0xe7,0x0a,0x00,0x04,0xd2,0x0a,0xfa,0x03,0xbd,0x0a,0xf5,0x03,0xa8,0x0a,0xf0,0x03,0x93,0x0a,0xea,0x03,0x7e,0x0a,0xe5,0x03,0x6a,0x0a,0xde,0x03,0x59,0x0a,0xd7,0x03,0x47,0x0a,0xd0,0x03,0x36,0x0a,0xca,0x03,0x25,0x0a,0xc3,0x03,0x14,0x0a,0xbc,0x03,0x03,0x0a,0xb6,0x03,0xf1,0x09,0xaf,0x03,0xe0,0x09,0xa9,0x03,  \
    0xcf,0x09,0xa3,0x03,0xbe,0x09,0x9c,0x03,0xad,0x09,0x96,0x03,0x9c,0x09,0x90,0x03,0x8b,0x09,0x8a,0x03,0x7a,0x09,0x83,0x03,0x68,0x09,0x7d,0x03,0x57,0x09,0x77,0x03,0x46,0x09,0x72,0x03,0x35,0x09,0x6c,0x03,0x24,0x09,0x66,0x03,0x13,0x09,0x60,0x03,0x02,0x09,0x5b,0x03,0xf0,0x08,0x55,0x03,0xdf,0x08,0x50,0x03,0xcd,0x08,0x4b,0x03,0xbb,0x08,0x45,0x03,0xaa,0x08,0x40,0x03,0x98,0x08,0x3b,0x03,0x87,0x08,0x36,0x03,0x75,0x08,0x31,0x03,0x63,0x08,0x2c,0x03,0x52,0x08,  \
    0x27,0x03,0x40,0x08,0x22,0x03,0x2e,0x08,0x1d,0x03,0x1d,0x08,0x19,0x03,0x0b,0x08,0x14,0x03,0xfa,0x07,0x0f,0x03,0xe8,0x07,0x0b,0x03,0xd6,0x07,0x06,0x03,0xc5,0x07,0x02,0x03,0xb3,0x07,0xfd,0x02,0xa1,0x07,0xf9,0x02,0x8f,0x07,0xf4,0x02,0x7e,0x07,0xf1,0x02,0x6a,0x07,0xed,0x02,0x56,0x07,0xea,0x02,0x42,0x07,0xe6,0x02,0x2f,0x07,0xe2,0x02,0x1b,0x07,0xdf,0x02,0x07,0x07,0xdb,0x02,0xf3,0x06,0xd8,0x02,0xe0,0x06,0xd5,0x02,0xcc,0x06,0xd1,0x02,0xb8,0x06,0xce,0x02,  \
    0xa5,0x06,0xca,0x02,0x91,0x06,0xc7,0x02,0x7e,0x06,0xc4,0x02,0x6a,0x06,0xc1,0x02,0x56,0x06,0xbd,0x02,0x43,0x06,0xba,0x02,0x2f,0x06,0xb7,0x02,0x1c,0x06,0xb4,0x02,0x08,0x06,0xb1,0x02,0xf5,0x05,0xae,0x02,0xe2,0x05,0xab,0x02,0xce,0x05,0xa8,0x02,0xbb,0x05,0xa5,0x02,0xa7,0x05,0xa2,0x02,0x95,0x05,0x9e,0x02,0x83,0x05,0x9b,0x02,0x71,0x05,0x98,0x02,0x5f,0x05,0x95,0x02,0x4d,0x05,0x92,0x02,0x3b,0x05,0x8f,0x02,0x29,0x05,0x8c,0x02,0x17,0x05,0x89,0x02,0x05,0x05,  \
    0x87,0x02,0xf3,0x04,0x84,0x02,0xe0,0x04,0x81,0x02,0xce,0x04,0x7e,0x02,0xbc,0x04,0x7c,0x02,0xaa,0x04,0x79,0x02,0x98,0x04,0x77,0x02,0x86,0x04,0x74,0x02,0x73,0x04,0x72,0x02,0x61,0x04,0x6f,0x02,0x4f,0x04,0x6d,0x02,0x3d,0x04,0x6a,0x02,0x2b,0x04,0x68,0x02,0x18,0x04,0x66,0x02,0x06,0x04,0x63,0x02,0xf4,0x03,0x61,0x02,0xe2,0x03,0x5f,0x02,0xd0,0x03,0x5d,0x02,0xbf,0x03,0x5b,0x02,0xad,0x03,0x58,0x02,0x9c,0x03,0x56,0x02,0x8b,0x03,0x54,0x02,0x79,0x03,0x52,0x02,  \
    0x68,0x03,0x50,0x02,0x57,0x03,0x4e,0x02,0x45,0x03,0x4c,0x02,0x34,0x03,0x4b,0x02,0x22,0x03,0x49,0x02,0x10,0x03,0x47,0x02,0xff,0x02,0x45,0x02,0xed,0x02,0x44,0x02,0xdb,0x02,0x42,0x02,0xca,0x02,0x41,0x02,0xb8,0x02,0x3f,0x02,0xa6,0x02,0x3e,0x02,0x94,0x02,0x3c,0x02,0x82,0x02,0x3b,0x02,0x70,0x02,0x3a,0x02,0x5e,0x02,0x38,0x02,0x4c,0x02,0x37,0x02,0x3a,0x02,0x36,0x02,0x28,0x02,0x35,0x02,0x16,0x02,0x34,0x02,0x03,0x02,0x33,0x02,0xf1,0x01,0x32,0x02,0xde,0x01,  \
    0x31,0x02,0xcb,0x01,0x30,0x02,0xb8,0x01,0x2f,0x02,0xa5,0x01,0x2e,0x02,0x92,0x01,0x2d,0x02,0x7f,0x01,0x2d,0x02,0x6c,0x01,0x2c,0x02,0x59,0x01,0x2b,0x02,0x46,0x01,0x2a,0x02,0x33,0x01,0x2a,0x02,0x20,0x01,0x29,0x02,0x0d,0x01,0x29,0x02,0xfa,0x00,0x28,0x02,0xe6,0x00,0x28,0x02,0xd3,0x00,0x27,0x02,0xc0,0x00,0x27,0x02,0xad,0x00,0x26,0x02,0x9a,0x00,0x26,0x02,0x87,0x00,0x26,0x02,0x74,0x00,0x25,0x02,0x61,0x00,0x25,0x02,0x4e,0x00,0x25,0x02,0x3b,0x00,0x25,0x02,  \
    0x28,0x00,0x25,0x02,0x15,0x00,0x24,0x02,0x01,0x00,0x24,0x02,0xee,0xff,0x24,0x02,0xdb,0xff,0x24,0x02,0xc8,0xff,0x24,0x02,0xb5,0xff,0x24,0x02,0xa2,0xff,0x24,0x02,0x8f,0xff,0x24,0x02,0x7c,0xff,0x25,0x02,0x69,0xff,0x25,0x02,0x56,0xff,0x25,0x02,0x43,0xff,0x25,0x02,0x2f,0xff,0x25,0x02,0x1c,0xff,0x26,0x02,0x09,0xff,0x26,0x02,0xf6,0xfe,0x26,0x02,0xe3,0xfe,0x27,0x02,0xd0,0xfe,0x27,0x02,0xbd,0xfe,0x28,0x02,0xaa,0xfe,0x28,0x02,0x97,0xfe,0x29,0x02,0x84,0xfe,  \
    0x29,0x02,0x71,0xfe,0x2a,0x02,0x5e,0xfe,0x2b,0x02,0x4b,0xfe,0x2b,0x02,0x38,0xfe,0x2c,0x02,0x25,0xfe,0x2d,0x02,0x12,0xfe,0x2d,0x02,0xff,0xfd,0x2e,0x02,0xec,0xfd,0x2f,0x02,0xd9,0xfd,0x30,0x02,0xc6,0xfd,0x31,0x02,0xb2,0xfd,0x32,0x02,0x9f,0xfd,0x33,0x02,0x8c,0xfd,0x34,0x02,0x78,0xfd,0x35,0x02,0x65,0xfd,0x36,0x02,0x52,0xfd,0x37,0x02,0x3e,0xfd,0x38,0x02,0x2b,0xfd,0x39,0x02,0x17,0xfd,0x3a,0x02,0x04,0xfd,0x3b,0x02,0xf0,0xfc,0x3d,0x02,0xdd,0xfc,0x3e,0x02,  \
    0xc9,0xfc,0x3f,0x02,0xb6,0xfc,0x40,0x02,0xa2,0xfc,0x42,0x02,0x8f,0xfc,0x43,0x02,0x7b,0xfc,0x45,0x02,0x68,0xfc,0x46,0x02,0x54,0xfc,0x47,0x02,0x40,0xfc,0x49,0x02,0x2d,0xfc,0x4a,0x02,0x19,0xfc,0x4c,0x02,0x05,0xfc,0x4e,0x02,0xf2,0xfb,0x4f,0x02,0xde,0xfb,0x51,0x02,0xca,0xfb,0x52,0x02,0xb7,0xfb,0x54,0x02,0xa3,0xfb,0x56,0x02,0x90,0xfb,0x58,0x02,0x7e,0xfb,0x5a,0x02,0x6b,0xfb,0x5c,0x02,0x58,0xfb,0x5e,0x02,0x46,0xfb,0x60,0x02,0x33,0xfb,0x62,0x02,0x21,0xfb,  \
    0x64,0x02,0x0e,0xfb,0x66,0x02,0xfb,0xfa,0x69,0x02,0xe9,0xfa,0x6b,0x02,0xd6,0xfa,0x6d,0x02,0xc4,0xfa,0x70,0x02,0xb2,0xfa,0x72,0x02,0x9f,0xfa,0x74,0x02,0x8d,0xfa,0x77,0x02,0x7a,0xfa,0x79,0x02,0x68,0xfa,0x7c,0x02,0x56,0xfa,0x7f,0x02,0x43,0xfa,0x81,0x02,0x31,0xfa,0x84,0x02,0x1f,0xfa,0x87,0x02,0x0d,0xfa,0x8a,0x02,0xfa,0xf9,0x8c,0x02,0xe8,0xf9,0x8f,0x02,0xd6,0xf9,0x92,0x02,0xc4,0xf9,0x95,0x02,0xb1,0xf9,0x98,0x02,0x9e,0xf9,0x9b,0x02,0x8b,0xf9,0x9e,0x02,  \
    0x78,0xf9,0xa1,0x02,0x65,0xf9,0xa4,0x02,0x52,0xf9,0xa7,0x02,0x3f,0xf9,0xaa,0x02,0x2b,0xf9,0xad,0x02,0x18,0xf9,0xb0,0x02,0x05,0xf9,0xb3,0x02,0xf2,0xf8,0xb6,0x02,0xdf,0xf8,0xb9,0x02,0xcc,0xf8,0xbd,0x02,0xb9,0xf8,0xc0,0x02,0xa6,0xf8,0xc3,0x02,0x93,0xf8,0xc7,0x02,0x80,0xf8,0xca,0x02,0x6d,0xf8,0xcd,0x02,0x59,0xf8,0xd1,0x02,0x46,0xf8,0xd4,0x02,0x33,0xf8,0xd8,0x02,0x20,0xf8,0xdc,0x02,0x0d,0xf8,0xdf,0x02,0xfa,0xf7,0xe3,0x02,0xe7,0xf7,0xe7,0x02,0xd4,0xf7,  \
    0xeb,0x02,0xc2,0xf7,0xef,0x02,0xb0,0xf7,0xf3,0x02,0x9d,0xf7,0xf7,0x02,0x8b,0xf7,0xfb,0x02,0x79,0xf7,0xff,0x02,0x66,0xf7,0x04,0x03,0x54,0xf7,0x08,0x03,0x42,0xf7,0x0c,0x03,0x2f,0xf7,0x11,0x03,0x1d,0xf7,0x15,0x03,0x0b,0xf7,0x19,0x03,0xf8,0xf6,0x1e,0x03,0xe6,0xf6,0x23,0x03,0xd4,0xf6,0x27,0x03,0xc1,0xf6,0x2c,0x03,0xaf,0xf6,0x31,0x03,0x9d,0xf6,0x35,0x03,0x8b,0xf6,0x3a,0x03,0x78,0xf6,0x3f,0x03,0x66,0xf6,0x44,0x03,0x54,0xf6,0x49,0x03,0x42,0xf6,0x4e,0x03,  \
    0x2f,0xf6,0x53,0x03,0x1c,0xf6,0x57,0x03,0x08,0xf6,0x5c,0x03,0xf5,0xf5,0x61,0x03,0xe2,0xf5,0x66,0x03,0xcf,0xf5,0x6b,0x03,0xbb,0xf5,0x70,0x03,0xa8,0xf5,0x75,0x03,0x95,0xf5,0x7a,0x03,0x82,0xf5,0x7f,0x03,0x6e,0xf5,0x84,0x03,0x5b,0xf5,0x89,0x03,0x48,0xf5,0x8e,0x03,0x35,0xf5,0x94,0x03,0x21,0xf5,0x99,0x03,0x0e,0xf5,0x9e,0x03,0xfb,0xf4,0xa4,0x03,0xe7,0xf4,0xa9,0x03,0xd4,0xf4,0xae,0x03,0xc1,0xf4,0xb4,0x03,0xad,0xf4,0xba,0x03,0x9a,0xf4,0xc0,0x03,0x88,0xf4,  \
    0xc5,0x03,0x75,0xf4,0xcb,0x03,0x62,0xf4,0xd1,0x03,0x50,0xf4,0xd8,0x03,0x3d,0xf4,0xde,0x03,0x2a,0xf4,0xe4,0x03,0x18,0xf4,0xea,0x03,0x05,0xf4,0xf0,0x03,0xf2,0xf3,0xf7,0x03,0xdf,0xf3,0xfd,0x03,0xcc,0xf3,0x03,0x04,0xba,0xf3,0x0a,0x04,0xa7,0xf3,0x10,0x04,0x94,0xf3,0x17,0x04,0x81,0xf3,0x1d,0x04,0x6e,0xf3,0x24,0x04,0x5b,0xf3,0x2a,0x04,0x48,0xf3,0x31,0x04,0x35,0xf3,0x37,0x04,0x1f,0xf3,0x3c,0x04,0x0a,0xf3,0x41,0x04,0xf4,0xf2,0x47,0x04,0xde,0xf2,0x4c,0x04,  \
    0xc8,0xf2,0x52,0x04,0xb3,0xf2,0x57,0x04,0x9d,0xf2,0x5d,0x04,0x87,0xf2,0x62,0x04,0x71,0xf2,0x68,0x04,0x5b,0xf2,0x6d,0x04,0x45,0xf2,0x73,0x04,0x2f,0xf2,0x78,0x04,0x19,0xf2,0x7e,0x04,0x02,0xf2,0x83,0x04,0xec,0xf1,0x89,0x04,0xd6,0xf1,0x8e,0x04,0xc0,0xf1,0x94,0x04,0xa9,0xf1,0x9a,0x04,0x94,0xf1,0xa1,0x04,0x80,0xf1,0xa8,0x04,0x6c,0xf1,0xaf,0x04,0x57,0xf1,0xb6,0x04,0x43,0xf1,0xbd,0x04,0x2f,0xf1,0xc4,0x04,0x1a,0xf1,0xcb,0x04,0x06,0xf1,0xd2,0x04,0xf1,0xf0,  \
    0xd9,0x04,0xdd,0xf0,0xe0,0x04,0xc8,0xf0,0xe7,0x04,0xb3,0xf0,0xee,0x04,0x9e,0xf0,0xf5,0x04,0x89,0xf0,0xfc,0x04,0x74,0xf0,0x03,0x05,0x5f,0xf0,0x09,0x05,0x49,0xf0,0x10,0x05,0x34,0xf0,0x17,0x05,0x1e,0xf0,0x1e,0x05,0x09,0xf0,0x25,0x05,0xf3,0xef,0x2c,0x05,0xde,0xef,0x33,0x05,0xc8,0xef,0x3a,0x05,0xb2,0xef,0x41,0x05,0x9d,0xef,0x48,0x05,0x86,0xef,0x4f,0x05,0x70,0xef,0x56,0x05,0x5a,0xef,0x5c,0x05,0x43,0xef,0x63,0x05,0x2d,0xef,0x69,0x05,0x16,0xef,0x70,0x05,  \
    0xff,0xee,0x76,0x05,0xe8,0xee,0x7c,0x05,0xd1,0xee,0x83,0x05,0xb9,0xee,0x89,0x05,0xa1,0xee,0x8f,0x05,0x8a,0xee,0x95,0x05,0x72,0xee,0x9b,0x05,0x5a,0xee,0xa0,0x05,0x41,0xee,0xa4,0x05,0x27,0xee,0xa9,0x05,0x0d,0xee,0xad,0x05,0xf2,0xed,0xb1,0x05,0xd8,0xed,0xb6,0x05,0xbe,0xed,0xba,0x05,0xa3,0xed,0xbe,0x05,0x88,0xed,0xc1,0x05,0x6d,0xed,0xc5,0x05,0x52,0xed,0xc9,0x05,0x37,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x25,0x06,0x66,0x12,0x21,0x06,0x4b,0x12,0x1d,0x06,0x30,0x12,0x19,0x06,0x15,0x12,0x15,0x06,0xfa,0x11,0x10,0x06,0xdf,0x11,0x0b,0x06,0xc5,0x11,0x07,0x06,0xaa,0x11,0x02,0x06,0x90,0x11,0xfd,0x05,0x76,0x11,0xf8,0x05,0x5c,0x11,0xf3,0x05,  \
    0x42,0x11,0xee,0x05,0x29,0x11,0xe8,0x05,0x0f,0x11,0xe3,0x05,0xf6,0x10,0xdd,0x05,0xdd,0x10,0xd8,0x05,0xc4,0x10,0xd2,0x05,0xab,0x10,0xcc,0x05,0x92,0x10,0xc7,0x05,0x79,0x10,0xc0,0x05,0x61,0x10,0xba,0x05,0x4a,0x10,0xb3,0x05,0x32,0x10,0xac,0x05,0x1b,0x10,0xa5,0x05,0x04,0x10,0x9e,0x05,0xed,0x0f,0x97,0x05,0xd6,0x0f,0x90,0x05,0xbf,0x0f,0x89,0x05,0xa9,0x0f,0x82,0x05,0x92,0x0f,0x7b,0x05,0x7c,0x0f,0x74,0x05,0x66,0x0f,0x6c,0x05,0x50,0x0f,0x65,0x05,0x3a,0x0f,  \
    0x5e,0x05,0x24,0x0f,0x56,0x05,0x0e,0x0f,0x4f,0x05,0xf8,0x0e,0x48,0x05,0xe3,0x0e,0x40,0x05,0xce,0x0e,0x39,0x05,0xb8,0x0e,0x31,0x05,0xa4,0x0e,0x28,0x05,0x90,0x0e,0x1f,0x05,0x7d,0x0e,0x17,0x05,0x69,0x0e,0x0e,0x05,0x56,0x0e,0x06,0x05,0x43,0x0e,0xfd,0x04,0x30,0x0e,0xf5,0x04,0x1d,0x0e,0xec,0x04,0x0a,0x0e,0xe4,0x04,0xf7,0x0d,0xdb,0x04,0xe4,0x0d,0xd2,0x04,0xd2,0x0d,0xca,0x04,0xbf,0x0d,0xc1,0x04,0xad,0x0d,0xb9,0x04,0x9b,0x0d,0xb0,0x04,0x89,0x0d,0xa8,0x04,  \
    0x77,0x0d,0x9f,0x04,0x64,0x0d,0x9a,0x04,0x4e,0x0d,0x94,0x04,0x38,0x0d,0x8e,0x04,0x22,0x0d,0x88,0x04,0x0c,0x0d,0x82,0x04,0xf6,0x0c,0x7c,0x04,0xe0,0x0c,0x76,0x04,0xca,0x0c,0x70,0x04,0xb5,0x0c,0x6a,0x04,0x9f,0x0c,0x65,0x04,0x89,0x0c,0x5f,0x04,0x73,0x0c,0x59,0x04,0x5e,0x0c,0x53,0x04,0x48,0x0c,0x4d,0x04,0x33,0x0c,0x48,0x04,0x1d,0x0c,0x42,0x04,0x08,0x0c,0x3c,0x04,0xf2,0x0b,0x37,0x04,0xdd,0x0b,0x31,0x04,0xc7,0x0b,0x2b,0x04,0xb2,0x0b,0x26,0x04,0x9d,0x0b,  \
    0x20,0x04,0x87,0x0b,0x1b,0x04,0x72,0x0b,0x15,0x04,0x5d,0x0b,0x0f,0x04,0x48,0x0b,0x0a,0x04,0x32,0x0b,0x04,0x04,0x1d,0x0b,0xff,0x03,0x08,0x0b,0xf9,0x03,0xf3,0x0a,0xf4,0x03,0xde,0x0a,0xef,0x03,0xc9,0x0a,0xe9,0x03,0xb4,0x0a,0xe4,0x03,0x9f,0x0a,0xde,0x03,0x8a,0x0a,0xd9,0x03,0x75,0x0a,0xd4,0x03,0x61,0x0a,0xcd,0x03,0x50,0x0a,0xc6,0x03,0x3f,0x0a,0xbf,0x03,0x2e,0x0a,0xb8,0x03,0x1c,0x0a,0xb1,0x03,0x0b,0x0a,0xab,0x03,0xfa,0x09,0xa4,0x03,0xe9,0x09,0x9e,0x03,  \
    0xd8,0x09,0x97,0x03,0xc7,0x09,0x91,0x03,0xb6,0x09,0x8a,0x03,0xa5,0x09,0x84,0x03,0x93,0x09,0x7e,0x03,0x82,0x09,0x77,0x03,0x71,0x09,0x71,0x03,0x60,0x09,0x6b,0x03,0x4f,0x09,0x65,0x03,0x3e,0x09,0x5f,0x03,0x2d,0x09,0x59,0x03,0x1c,0x09,0x54,0x03,0x0b,0x09,0x4e,0x03,0xfa,0x08,0x48,0x03,0xe8,0x08,0x43,0x03,0xd7,0x08,0x3d,0x03,0xc5,0x08,0x38,0x03,0xb4,0x08,0x33,0x03,0xa2,0x08,0x2e,0x03,0x91,0x08,0x28,0x03,0x7f,0x08,0x23,0x03,0x6d,0x08,0x1e,0x03,0x5c,0x08,  \
    0x19,0x03,0x4a,0x08,0x14,0x03,0x39,0x08,0x0f,0x03,0x27,0x08,0x0a,0x03,0x16,0x08,0x06,0x03,0x04,0x08,0x01,0x03,0xf2,0x07,0xfc,0x02,0xe1,0x07,0xf8,0x02,0xcf,0x07,0xf3,0x02,0xbd,0x07,0xee,0x02,0xac,0x07,0xea,0x02,0x9a,0x07,0xe5,0x02,0x89,0x07,0xe1,0x02,0x77,0x07,0xdd,0x02,0x63,0x07,0xda,0x02,0x4f,0x07,0xd6,0x02,0x3c,0x07,0xd2,0x02,0x28,0x07,0xcf,0x02,0x14,0x07,0xcb,0x02,0x01,0x07,0xc8,0x02,0xed,0x06,0xc4,0x02,0xda,0x06,0xc1,0x02,0xc6,0x06,0xbd,0x02,  \
    0xb2,0x06,0xba,0x02,0x9f,0x06,0xb7,0x02,0x8b,0x06,0xb3,0x02,0x78,0x06,0xb0,0x02,0x64,0x06,0xad,0x02,0x51,0x06,0xa9,0x02,0x3d,0x06,0xa6,0x02,0x2a,0x06,0xa3,0x02,0x16,0x06,0xa0,0x02,0x03,0x06,0x9d,0x02,0xf0,0x05,0x9a,0x02,0xdc,0x05,0x97,0x02,0xc9,0x05,0x94,0x02,0xb6,0x05,0x91,0x02,0xa2,0x05,0x8d,0x02,0x90,0x05,0x8a,0x02,0x7e,0x05,0x87,0x02,0x6c,0x05,0x84,0x02,0x5a,0x05,0x81,0x02,0x48,0x05,0x7e,0x02,0x36,0x05,0x7b,0x02,0x24,0x05,0x78,0x02,0x12,0x05,  \
    0x75,0x02,0x00,0x05,0x72,0x02,0xee,0x04,0x6f,0x02,0xdc,0x04,0x6c,0x02,0xca,0x04,0x6a,0x02,0xb8,0x04,0x67,0x02,0xa6,0x04,0x64,0x02,0x94,0x04,0x62,0x02,0x82,0x04,0x5f,0x02,0x6f,0x04,0x5d,0x02,0x5d,0x04,0x5a,0x02,0x4b,0x04,0x58,0x02,0x39,0x04,0x55,0x02,0x27,0x04,0x53,0x02,0x15,0x04,0x51,0x02,0x02,0x04,0x4f,0x02,0xf0,0x03,0x4c,0x02,0xde,0x03,0x4a,0x02,0xcc,0x03,0x48,0x02,0xbb,0x03,0x46,0x02,0xaa,0x03,0x43,0x02,0x99,0x03,0x41,0x02,0x87,0x03,0x3f,0x02,  \
    0x76,0x03,0x3d,0x02,0x65,0x03,0x3b,0x02,0x53,0x03,0x39,0x02,0x42,0x03,0x37,0x02,0x31,0x03,0x35,0x02,0x1f,0x03,0x34,0x02,0x0d,0x03,0x32,0x02,0xfc,0x02,0x30,0x02,0xea,0x02,0x2f,0x02,0xd9,0x02,0x2d,0x02,0xc7,0x02,0x2b,0x02,0xb5,0x02,0x2a,0x02,0xa3,0x02,0x28,0x02,0x92,0x02,0x27,0x02,0x80,0x02,0x26,0x02,0x6e,0x02,0x24,0x02,0x5c,0x02,0x23,0x02,0x4a,0x02,0x22,0x02,0x38,0x02,0x21,0x02,0x26,0x02,0x1f,0x02,0x13,0x02,0x1e,0x02,0x01,0x02,0x1d,0x02,0xef,0x01,  \
    0x1c,0x02,0xdc,0x01,0x1b,0x02,0xc9,0x01,0x1a,0x02,0xb6,0x01,0x1a,0x02,0xa3,0x01,0x19,0x02,0x90,0x01,0x18,0x02,0x7d,0x01,0x17,0x02,0x6a,0x01,0x16,0x02,0x57,0x01,0x16,0x02,0x44,0x01,0x15,0x02,0x31,0x01,0x14,0x02,0x1e,0x01,0x14,0x02,0x0b,0x01,0x13,0x02,0xf8,0x00,0x13,0x02,0xe5,0x00,0x12,0x02,0xd2,0x00,0x12,0x02,0xbf,0x00,0x11,0x02,0xac,0x00,0x11,0x02,0x99,0x00,0x11,0x02,0x86,0x00,0x10,0x02,0x73,0x00,0x10,0x02,0x60,0x00,0x10,0x02,0x4d,0x00,0x0f,0x02,  \
    0x3a,0x00,0x0f,0x02,0x27,0x00,0x0f,0x02,0x14,0x00,0x0f,0x02,0x01,0x00,0x0f,0x02,0xee,0xff,0x0f,0x02,0xdb,0xff,0x0f,0x02,0xc8,0xff,0x0f,0x02,0xb5,0xff,0x0f,0x02,0xa2,0xff,0x0f,0x02,0x8f,0xff,0x0f,0x02,0x7c,0xff,0x0f,0x02,0x69,0xff,0x0f,0x02,0x56,0xff,0x0f,0x02,0x43,0xff,0x10,0x02,0x30,0xff,0x10,0x02,0x1d,0xff,0x10,0x02,0x0a,0xff,0x11,0x02,0xf7,0xfe,0x11,0x02,0xe4,0xfe,0x11,0x02,0xd1,0xfe,0x12,0x02,0xbe,0xfe,0x12,0x02,0xab,0xfe,0x13,0x02,0x98,0xfe,  \
    0x13,0x02,0x85,0xfe,0x14,0x02,0x72,0xfe,0x15,0x02,0x5f,0xfe,0x15,0x02,0x4c,0xfe,0x16,0x02,0x39,0xfe,0x17,0x02,0x26,0xfe,0x17,0x02,0x13,0xfe,0x18,0x02,0x00,0xfe,0x19,0x02,0xed,0xfd,0x1a,0x02,0xda,0xfd,0x1b,0x02,0xc7,0xfd,0x1b,0x02,0xb4,0xfd,0x1c,0x02,0xa1,0xfd,0x1d,0x02,0x8e,0xfd,0x1e,0x02,0x7a,0xfd,0x1f,0x02,0x67,0xfd,0x20,0x02,0x54,0xfd,0x21,0x02,0x40,0xfd,0x23,0x02,0x2d,0xfd,0x24,0x02,0x1a,0xfd,0x25,0x02,0x06,0xfd,0x26,0x02,0xf3,0xfc,0x27,0x02,  \
    0xe0,0xfc,0x29,0x02,0xcc,0xfc,0x2a,0x02,0xb9,0xfc,0x2b,0x02,0xa5,0xfc,0x2d,0x02,0x92,0xfc,0x2e,0x02,0x7e,0xfc,0x2f,0x02,0x6b,0xfc,0x31,0x02,0x57,0xfc,0x32,0x02,0x44,0xfc,0x34,0x02,0x30,0xfc,0x35,0x02,0x1c,0xfc,0x37,0x02,0x09,0xfc,0x38,0x02,0xf5,0xfb,0x3a,0x02,0xe2,0xfb,0x3c,0x02,0xce,0xfb,0x3d,0x02,0xba,0xfb,0x3f,0x02,0xa7,0xfb,0x41,0x02,0x94,0xfb,0x43,0x02,0x82,0xfb,0x45,0x02,0x6f,0xfb,0x47,0x02,0x5c,0xfb,0x49,0x02,0x4a,0xfb,0x4b,0x02,0x37,0xfb,  \
    0x4d,0x02,0x25,0xfb,0x4f,0x02,0x12,0xfb,0x51,0x02,0x00,0xfb,0x54,0x02,0xed,0xfa,0x56,0x02,0xdb,0xfa,0x58,0x02,0xc9,0xfa,0x5b,0x02,0xb6,0xfa,0x5d,0x02,0xa4,0xfa,0x5f,0x02,0x92,0xfa,0x62,0x02,0x7f,0xfa,0x65,0x02,0x6d,0xfa,0x67,0x02,0x5b,0xfa,0x6a,0x02,0x48,0xfa,0x6c,0x02,0x36,0xfa,0x6f,0x02,0x24,0xfa,0x72,0x02,0x12,0xfa,0x75,0x02,0x00,0xfa,0x78,0x02,0xed,0xf9,0x7b,0x02,0xdb,0xf9,0x7d,0x02,0xc9,0xf9,0x80,0x02,0xb7,0xf9,0x83,0x02,0xa4,0xf9,0x86,0x02,  \
    0x91,0xf9,0x89,0x02,0x7e,0xf9,0x8c,0x02,0x6a,0xf9,0x8f,0x02,0x57,0xf9,0x92,0x02,0x44,0xf9,0x95,0x02,0x31,0xf9,0x98,0x02,0x1e,0xf9,0x9b,0x02,0x0b,0xf9,0x9e,0x02,0xf8,0xf8,0xa1,0x02,0xe5,0xf8,0xa5,0x02,0xd2,0xf8,0xa8,0x02,0xbf,0xf8,0xab,0x02,0xac,0xf8,0xaf,0x02,0x99,0xf8,0xb2,0x02,0x86,0xf8,0xb5,0x02,0x73,0xf8,0xb9,0x02,0x60,0xf8,0xbc,0x02,0x4d,0xf8,0xc0,0x02,0x3a,0xf8,0xc4,0x02,0x27,0xf8,0xc7,0x02,0x14,0xf8,0xcb,0x02,0x01,0xf8,0xcf,0x02,0xee,0xf7,  \
    0xd2,0x02,0xdb,0xf7,0xd6,0x02,0xc9,0xf7,0xda,0x02,0xb7,0xf7,0xdf,0x02,0xa4,0xf7,0xe3,0x02,0x92,0xf7,0xe7,0x02,0x80,0xf7,0xeb,0x02,0x6d,0xf7,0xef,0x02,0x5b,0xf7,0xf4,0x02,0x49,0xf7,0xf8,0x02,0x37,0xf7,0xfc,0x02,0x24,0xf7,0x01,0x03,0x12,0xf7,0x05,0x03,0x00,0xf7,0x0a,0x03,0xed,0xf6,0x0e,0x03,0xdb,0xf6,0x13,0x03,0xc9,0xf6,0x18,0x03,0xb7,0xf6,0x1d,0x03,0xa5,0xf6,0x21,0x03,0x92,0xf6,0x26,0x03,0x80,0xf6,0x2b,0x03,0x6e,0xf6,0x30,0x03,0x5c,0xf6,0x35,0x03,  \
    0x49,0xf6,0x3a,0x03,0x37,0xf6,0x3f,0x03,0x23,0xf6,0x43,0x03,0x10,0xf6,0x48,0x03,0xfd,0xf5,0x4d,0x03,0xea,0xf5,0x52,0x03,0xd7,0xf5,0x57,0x03,0xc4,0xf5,0x5c,0x03,0xb0,0xf5,0x61,0x03,0x9d,0xf5,0x66,0x03,0x8a,0xf5,0x6b,0x03,0x77,0xf5,0x70,0x03,0x64,0xf5,0x75,0x03,0x50,0xf5,0x7b,0x03,0x3d,0xf5,0x80,0x03,0x2a,0xf5,0x85,0x03,0x17,0xf5,0x8b,0x03,0x03,0xf5,0x90,0x03,0xf0,0xf4,0x95,0x03,0xdd,0xf4,0x9b,0x03,0xc9,0xf4,0xa0,0x03,0xb6,0xf4,0xa6,0x03,0xa3,0xf4,  \
    0xac,0x03,0x90,0xf4,0xb2,0x03,0x7e,0xf4,0xb8,0x03,0x6b,0xf4,0xbe,0x03,0x58,0xf4,0xc4,0x03,0x46,0xf4,0xca,0x03,0x33,0xf4,0xd0,0x03,0x20,0xf4,0xd7,0x03,0x0e,0xf4,0xdd,0x03,0xfb,0xf3,0xe3,0x03,0xe8,0xf3,0xea,0x03,0xd5,0xf3,0xf0,0x03,0xc2,0xf3,0xf6,0x03,0xaf,0xf3,0xfd,0x03,0x9d,0xf3,0x03,0x04,0x8a,0xf3,0x0a,0x04,0x77,0xf3,0x10,0x04,0x64,0xf3,0x17,0x04,0x51,0xf3,0x1e,0x04,0x3d,0xf3,0x23,0x04,0x28,0xf3,0x29,0x04,0x13,0xf3,0x2e,0x04,0xfd,0xf2,0x34,0x04,  \
    0xe7,0xf2,0x39,0x04,0xd1,0xf2,0x3e,0x04,0xbc,0xf2,0x44,0x04,0xa6,0xf2,0x49,0x04,0x90,0xf2,0x4f,0x04,0x7a,0xf2,0x54,0x04,0x64,0xf2,0x5a,0x04,0x4e,0xf2,0x5f,0x04,0x38,0xf2,0x65,0x04,0x22,0xf2,0x6b,0x04,0x0c,0xf2,0x70,0x04,0xf6,0xf1,0x76,0x04,0xdf,0xf1,0x7b,0x04,0xc9,0xf1,0x81,0x04,0xb3,0xf1,0x87,0x04,0x9d,0xf1,0x8e,0x04,0x89,0xf1,0x95,0x04,0x75,0xf1,0x9c,0x04,0x61,0xf1,0xa3,0x04,0x4c,0xf1,0xaa,0x04,0x38,0xf1,0xb1,0x04,0x24,0xf1,0xb8,0x04,0x0f,0xf1,  \
    0xbf,0x04,0xfb,0xf0,0xc6,0x04,0xe6,0xf0,0xcd,0x04,0xd1,0xf0,0xd4,0x04,0xbc,0xf0,0xdb,0x04,0xa7,0xf0,0xe2,0x04,0x92,0xf0,0xe9,0x04,0x7d,0xf0,0xf0,0x04,0x68,0xf0,0xf6,0x04,0x52,0xf0,0xfd,0x04,0x3d,0xf0,0x04,0x05,0x27,0xf0,0x0b,0x05,0x12,0xf0,0x12,0x05,0xfc,0xef,0x19,0x05,0xe7,0xef,0x20,0x05,0xd1,0xef,0x27,0x05,0xbb,0xef,0x2e,0x05,0xa5,0xef,0x35,0x05,0x8f,0xef,0x3c,0x05,0x79,0xef,0x42,0x05,0x63,0xef,0x49,0x05,0x4c,0xef,0x4f,0x05,0x35,0xef,0x56,0x05,  \
    0x1e,0xef,0x5c,0x05,0x07,0xef,0x63,0x05,0xf0,0xee,0x69,0x05,0xd9,0xee,0x6f,0x05,0xc1,0xee,0x75,0x05,0xaa,0xee,0x7b,0x05,0x92,0xee,0x81,0x05,0x7a,0xee,0x87,0x05,0x62,0xee,0x8c,0x05,0x49,0xee,0x91,0x05,0x2f,0xee,0x95,0x05,0x15,0xee,0x9a,0x05,0xfb,0xed,0x9e,0x05,0xe0,0xed,0xa2,0x05,0xc6,0xed,0xa6,0x05,0xab,0xed,0xaa,0x05,0x90,0xed,0xae,0x05,0x75,0xed,0xb2,0x05,0x5a,0xed,0xb5,0x05,0x3f,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1c,0x06,0x59,0x12,0x18,0x06,0x3e,0x12,0x14,0x06,0x23,0x12,0x0f,0x06,0x08,0x12,0x0b,0x06,0xed,0x11,0x06,0x06,0xd3,0x11,0x01,0x06,0xb8,0x11,0xfd,0x05,0x9e,0x11,0xf8,0x05,0x84,0x11,0xf3,0x05,0x6a,0x11,0xee,0x05,  \
    0x50,0x11,0xe8,0x05,0x36,0x11,0xe3,0x05,0x1c,0x11,0xde,0x05,0x03,0x11,0xd8,0x05,0xea,0x10,0xd3,0x05,0xd1,0x10,0xcd,0x05,0xb7,0x10,0xc7,0x05,0x9f,0x10,0xc2,0x05,0x86,0x10,0xbc,0x05,0x6d,0x10,0xb5,0x05,0x55,0x10,0xaf,0x05,0x3e,0x10,0xa8,0x05,0x26,0x10,0xa1,0x05,0x0f,0x10,0x9a,0x05,0xf8,0x0f,0x93,0x05,0xe1,0x0f,0x8c,0x05,0xca,0x0f,0x85,0x05,0xb3,0x0f,0x7e,0x05,0x9d,0x0f,0x76,0x05,0x86,0x0f,0x6f,0x05,0x70,0x0f,0x68,0x05,0x5a,0x0f,0x61,0x05,0x44,0x0f,  \
    0x59,0x05,0x2e,0x0f,0x52,0x05,0x18,0x0f,0x4a,0x05,0x02,0x0f,0x43,0x05,0xed,0x0e,0x3b,0x05,0xd7,0x0e,0x34,0x05,0xc2,0x0e,0x2c,0x05,0xac,0x0e,0x24,0x05,0x98,0x0e,0x1b,0x05,0x84,0x0e,0x13,0x05,0x71,0x0e,0x0a,0x05,0x5d,0x0e,0x02,0x05,0x4a,0x0e,0xf9,0x04,0x37,0x0e,0xf0,0x04,0x24,0x0e,0xe8,0x04,0x11,0x0e,0xdf,0x04,0xfe,0x0d,0xd6,0x04,0xeb,0x0d,0xce,0x04,0xd9,0x0d,0xc5,0x04,0xc6,0x0d,0xbc,0x04,0xb4,0x0d,0xb4,0x04,0xa1,0x0d,0xab,0x04,0x8f,0x0d,0xa3,0x04,  \
    0x7d,0x0d,0x9a,0x04,0x6b,0x0d,0x92,0x04,0x58,0x0d,0x8c,0x04,0x42,0x0d,0x86,0x04,0x2c,0x0d,0x80,0x04,0x16,0x0d,0x7a,0x04,0x01,0x0d,0x74,0x04,0xeb,0x0c,0x6e,0x04,0xd5,0x0c,0x68,0x04,0xbf,0x0c,0x62,0x04,0xa9,0x0c,0x5c,0x04,0x94,0x0c,0x56,0x04,0x7e,0x0c,0x50,0x04,0x69,0x0c,0x4a,0x04,0x53,0x0c,0x44,0x04,0x3d,0x0c,0x3e,0x04,0x28,0x0c,0x39,0x04,0x13,0x0c,0x33,0x04,0xfd,0x0b,0x2d,0x04,0xe8,0x0b,0x27,0x04,0xd2,0x0b,0x21,0x04,0xbd,0x0b,0x1c,0x04,0xa8,0x0b,  \
    0x16,0x04,0x93,0x0b,0x10,0x04,0x7d,0x0b,0x0b,0x04,0x68,0x0b,0x05,0x04,0x53,0x0b,0xff,0x03,0x3e,0x0b,0xfa,0x03,0x29,0x0b,0xf4,0x03,0x14,0x0b,0xef,0x03,0xff,0x0a,0xe9,0x03,0xea,0x0a,0xe4,0x03,0xd5,0x0a,0xde,0x03,0xc0,0x0a,0xd9,0x03,0xab,0x0a,0xd3,0x03,0x96,0x0a,0xce,0x03,0x81,0x0a,0xc8,0x03,0x6d,0x0a,0xc3,0x03,0x59,0x0a,0xbc,0x03,0x47,0x0a,0xb5,0x03,0x36,0x0a,0xae,0x03,0x25,0x0a,0xa7,0x03,0x14,0x0a,0xa0,0x03,0x03,0x0a,0x9a,0x03,0xf1,0x09,0x93,0x03,  \
    0xe0,0x09,0x8c,0x03,0xcf,0x09,0x86,0x03,0xbe,0x09,0x7f,0x03,0xad,0x09,0x79,0x03,0x9c,0x09,0x72,0x03,0x8b,0x09,0x6c,0x03,0x7a,0x09,0x66,0x03,0x69,0x09,0x60,0x03,0x58,0x09,0x5a,0x03,0x47,0x09,0x54,0x03,0x36,0x09,0x4e,0x03,0x25,0x09,0x48,0x03,0x14,0x09,0x42,0x03,0x03,0x09,0x3c,0x03,0xf2,0x08,0x36,0x03,0xe0,0x08,0x31,0x03,0xcf,0x08,0x2b,0x03,0xbd,0x08,0x26,0x03,0xac,0x08,0x21,0x03,0x9a,0x08,0x1b,0x03,0x89,0x08,0x16,0x03,0x77,0x08,0x11,0x03,0x66,0x08,  \
    0x0c,0x03,0x54,0x08,0x07,0x03,0x43,0x08,0x02,0x03,0x31,0x08,0xfd,0x02,0x20,0x08,0xf8,0x02,0x0e,0x08,0xf3,0x02,0xfc,0x07,0xee,0x02,0xeb,0x07,0xe9,0x02,0xd9,0x07,0xe5,0x02,0xc8,0x07,0xe0,0x02,0xb6,0x07,0xdc,0x02,0xa5,0x07,0xd7,0x02,0x93,0x07,0xd3,0x02,0x81,0x07,0xce,0x02,0x70,0x07,0xca,0x02,0x5c,0x07,0xc7,0x02,0x49,0x07,0xc3,0x02,0x35,0x07,0xbf,0x02,0x21,0x07,0xbc,0x02,0x0e,0x07,0xb8,0x02,0xfa,0x06,0xb5,0x02,0xe7,0x06,0xb1,0x02,0xd3,0x06,0xad,0x02,  \
    0xc0,0x06,0xaa,0x02,0xac,0x06,0xa7,0x02,0x99,0x06,0xa3,0x02,0x85,0x06,0xa0,0x02,0x72,0x06,0x9c,0x02,0x5e,0x06,0x99,0x02,0x4b,0x06,0x96,0x02,0x38,0x06,0x93,0x02,0x24,0x06,0x8f,0x02,0x11,0x06,0x8c,0x02,0xfe,0x05,0x89,0x02,0xea,0x05,0x86,0x02,0xd7,0x05,0x83,0x02,0xc4,0x05,0x80,0x02,0xb0,0x05,0x7d,0x02,0x9d,0x05,0x79,0x02,0x8b,0x05,0x76,0x02,0x79,0x05,0x73,0x02,0x67,0x05,0x70,0x02,0x56,0x05,0x6d,0x02,0x44,0x05,0x6a,0x02,0x32,0x05,0x67,0x02,0x20,0x05,  \
    0x64,0x02,0x0e,0x05,0x61,0x02,0xfc,0x04,0x5e,0x02,0xea,0x04,0x5b,0x02,0xd8,0x04,0x58,0x02,0xc6,0x04,0x56,0x02,0xb4,0x04,0x53,0x02,0xa1,0x04,0x50,0x02,0x8f,0x04,0x4e,0x02,0x7d,0x04,0x4b,0x02,0x6b,0x04,0x48,0x02,0x59,0x04,0x46,0x02,0x47,0x04,0x43,0x02,0x35,0x04,0x41,0x02,0x23,0x04,0x3f,0x02,0x11,0x04,0x3c,0x02,0xff,0x03,0x3a,0x02,0xed,0x03,0x38,0x02,0xda,0x03,0x36,0x02,0xc9,0x03,0x33,0x02,0xb8,0x03,0x31,0x02,0xa6,0x03,0x2f,0x02,0x95,0x03,0x2d,0x02,  \
    0x84,0x03,0x2b,0x02,0x73,0x03,0x29,0x02,0x61,0x03,0x27,0x02,0x50,0x03,0x25,0x02,0x3f,0x03,0x23,0x02,0x2d,0x03,0x21,0x02,0x1c,0x03,0x1f,0x02,0x0a,0x03,0x1d,0x02,0xf9,0x02,0x1c,0x02,0xe7,0x02,0x1a,0x02,0xd6,0x02,0x18,0x02,0xc4,0x02,0x17,0x02,0xb2,0x02,0x15,0x02,0xa1,0x02,0x14,0x02,0x8f,0x02,0x12,0x02,0x7d,0x02,0x11,0x02,0x6b,0x02,0x10,0x02,0x59,0x02,0x0e,0x02,0x47,0x02,0x0d,0x02,0x35,0x02,0x0c,0x02,0x23,0x02,0x0b,0x02,0x11,0x02,0x09,0x02,0xff,0x01,  \
    0x08,0x02,0xed,0x01,0x07,0x02,0xda,0x01,0x06,0x02,0xc7,0x01,0x06,0x02,0xb4,0x01,0x05,0x02,0xa1,0x01,0x04,0x02,0x8f,0x01,0x03,0x02,0x7c,0x01,0x02,0x02,0x69,0x01,0x01,0x02,0x56,0x01,0x01,0x02,0x43,0x01,0x00,0x02,0x30,0x01,0xff,0x01,0x1d,0x01,0xff,0x01,0x0a,0x01,0xfe,0x01,0xf7,0x00,0xfe,0x01,0xe4,0x00,0xfd,0x01,0xd1,0x00,0xfd,0x01,0xbe,0x00,0xfc,0x01,0xab,0x00,0xfc,0x01,0x99,0x00,0xfb,0x01,0x86,0x00,0xfb,0x01,0x73,0x00,0xfb,0x01,0x60,0x00,0xfb,0x01,  \
    0x4d,0x00,0xfa,0x01,0x3a,0x00,0xfa,0x01,0x27,0x00,0xfa,0x01,0x14,0x00,0xfa,0x01,0x01,0x00,0xfa,0x01,0xee,0xff,0xfa,0x01,0xdb,0xff,0xfa,0x01,0xc8,0xff,0xfa,0x01,0xb5,0xff,0xfa,0x01,0xa2,0xff,0xfa,0x01,0x8f,0xff,0xfa,0x01,0x7c,0xff,0xfa,0x01,0x69,0xff,0xfa,0x01,0x56,0xff,0xfa,0x01,0x43,0xff,0xfb,0x01,0x31,0xff,0xfb,0x01,0x1e,0xff,0xfb,0x01,0x0b,0xff,0xfc,0x01,0xf8,0xfe,0xfc,0x01,0xe5,0xfe,0xfc,0x01,0xd2,0xfe,0xfd,0x01,0xbf,0xfe,0xfd,0x01,0xac,0xfe,  \
    0xfe,0x01,0x99,0xfe,0xfe,0x01,0x86,0xfe,0xff,0x01,0x73,0xfe,0x00,0x02,0x60,0xfe,0x00,0x02,0x4e,0xfe,0x01,0x02,0x3b,0xfe,0x02,0x02,0x28,0xfe,0x02,0x02,0x15,0xfe,0x03,0x02,0x02,0xfe,0x04,0x02,0xef,0xfd,0x05,0x02,0xdc,0xfd,0x06,0x02,0xc9,0xfd,0x07,0x02,0xb6,0xfd,0x07,0x02,0xa3,0xfd,0x08,0x02,0x90,0xfd,0x09,0x02,0x7d,0xfd,0x0a,0x02,0x69,0xfd,0x0b,0x02,0x56,0xfd,0x0d,0x02,0x43,0xfd,0x0e,0x02,0x30,0xfd,0x0f,0x02,0x1c,0xfd,0x10,0x02,0x09,0xfd,0x11,0x02,  \
    0xf6,0xfc,0x12,0x02,0xe2,0xfc,0x14,0x02,0xcf,0xfc,0x15,0x02,0xbc,0xfc,0x16,0x02,0xa8,0xfc,0x18,0x02,0x95,0xfc,0x19,0x02,0x81,0xfc,0x1a,0x02,0x6e,0xfc,0x1c,0x02,0x5a,0xfc,0x1d,0x02,0x47,0xfc,0x1f,0x02,0x34,0xfc,0x20,0x02,0x20,0xfc,0x22,0x02,0x0d,0xfc,0x24,0x02,0xf9,0xfb,0x25,0x02,0xe5,0xfb,0x27,0x02,0xd2,0xfb,0x29,0x02,0xbe,0xfb,0x2a,0x02,0xab,0xfb,0x2c,0x02,0x98,0xfb,0x2e,0x02,0x86,0xfb,0x30,0x02,0x73,0xfb,0x32,0x02,0x61,0xfb,0x34,0x02,0x4e,0xfb,  \
    0x36,0x02,0x3c,0xfb,0x38,0x02,0x29,0xfb,0x3b,0x02,0x17,0xfb,0x3d,0x02,0x04,0xfb,0x3f,0x02,0xf2,0xfa,0x41,0x02,0xe0,0xfa,0x44,0x02,0xcd,0xfa,0x46,0x02,0xbb,0xfa,0x48,0x02,0xa9,0xfa,0x4b,0x02,0x96,0xfa,0x4d,0x02,0x84,0xfa,0x50,0x02,0x72,0xfa,0x53,0x02,0x60,0xfa,0x55,0x02,0x4e,0xfa,0x58,0x02,0x3b,0xfa,0x5b,0x02,0x29,0xfa,0x5d,0x02,0x17,0xfa,0x60,0x02,0x05,0xfa,0x63,0x02,0xf3,0xf9,0x66,0x02,0xe1,0xf9,0x69,0x02,0xcf,0xf9,0x6c,0x02,0xbc,0xf9,0x6f,0x02,  \
    0xa9,0xf9,0x72,0x02,0x96,0xf9,0x75,0x02,0x83,0xf9,0x78,0x02,0x70,0xf9,0x7b,0x02,0x5d,0xf9,0x7e,0x02,0x4a,0xf9,0x81,0x02,0x37,0xf9,0x84,0x02,0x24,0xf9,0x87,0x02,0x11,0xf9,0x8a,0x02,0xfe,0xf8,0x8d,0x02,0xeb,0xf8,0x91,0x02,0xd8,0xf8,0x94,0x02,0xc5,0xf8,0x97,0x02,0xb3,0xf8,0x9b,0x02,0xa0,0xf8,0x9e,0x02,0x8d,0xf8,0xa1,0x02,0x7a,0xf8,0xa5,0x02,0x67,0xf8,0xa8,0x02,0x54,0xf8,0xac,0x02,0x41,0xf8,0xb0,0x02,0x2e,0xf8,0xb3,0x02,0x1b,0xf8,0xb7,0x02,0x08,0xf8,  \
    0xbb,0x02,0xf5,0xf7,0xbf,0x02,0xe2,0xf7,0xc3,0x02,0xd0,0xf7,0xc7,0x02,0xbe,0xf7,0xcb,0x02,0xac,0xf7,0xcf,0x02,0x99,0xf7,0xd3,0x02,0x87,0xf7,0xd7,0x02,0x75,0xf7,0xdb,0x02,0x63,0xf7,0xe0,0x02,0x50,0xf7,0xe4,0x02,0x3e,0xf7,0xe9,0x02,0x2c,0xf7,0xed,0x02,0x1a,0xf7,0xf2,0x02,0x07,0xf7,0xf6,0x02,0xf5,0xf6,0xfb,0x02,0xe3,0xf6,0xff,0x02,0xd1,0xf6,0x04,0x03,0xbf,0xf6,0x09,0x03,0xac,0xf6,0x0e,0x03,0x9a,0xf6,0x13,0x03,0x88,0xf6,0x18,0x03,0x76,0xf6,0x1c,0x03,  \
    0x64,0xf6,0x22,0x03,0x51,0xf6,0x26,0x03,0x3f,0xf6,0x2b,0x03,0x2c,0xf6,0x30,0x03,0x18,0xf6,0x35,0x03,0x05,0xf6,0x3a,0x03,0xf2,0xf5,0x3f,0x03,0xdf,0xf5,0x44,0x03,0xcc,0xf5,0x49,0x03,0xb9,0xf5,0x4e,0x03,0xa6,0xf5,0x53,0x03,0x92,0xf5,0x58,0x03,0x7f,0xf5,0x5d,0x03,0x6c,0xf5,0x62,0x03,0x59,0xf5,0x67,0x03,0x46,0xf5,0x6d,0x03,0x32,0xf5,0x72,0x03,0x1f,0xf5,0x77,0x03,0x0c,0xf5,0x7d,0x03,0xf9,0xf4,0x82,0x03,0xe5,0xf4,0x88,0x03,0xd2,0xf4,0x8d,0x03,0xbf,0xf4,  \
    0x93,0x03,0xac,0xf4,0x99,0x03,0x99,0xf4,0x9f,0x03,0x87,0xf4,0xa5,0x03,0x74,0xf4,0xab,0x03,0x61,0xf4,0xb1,0x03,0x4f,0xf4,0xb7,0x03,0x3c,0xf4,0xbd,0x03,0x29,0xf4,0xc4,0x03,0x17,0xf4,0xca,0x03,0x04,0xf4,0xd0,0x03,0xf1,0xf3,0xd7,0x03,0xde,0xf3,0xdd,0x03,0xcb,0xf3,0xe3,0x03,0xb8,0xf3,0xea,0x03,0xa6,0xf3,0xf0,0x03,0x93,0xf3,0xf7,0x03,0x80,0xf3,0xfd,0x03,0x6d,0xf3,0x04,0x04,0x5a,0xf3,0x0b,0x04,0x46,0xf3,0x10,0x04,0x31,0xf3,0x16,0x04,0x1c,0xf3,0x1b,0x04,  \
    0x06,0xf3,0x21,0x04,0xf0,0xf2,0x26,0x04,0xdb,0xf2,0x2c,0x04,0xc5,0xf2,0x31,0x04,0xaf,0xf2,0x37,0x04,0x99,0xf2,0x3c,0x04,0x83,0xf2,0x42,0x04,0x6d,0xf2,0x47,0x04,0x57,0xf2,0x4d,0x04,0x41,0xf2,0x52,0x04,0x2b,0xf2,0x58,0x04,0x15,0xf2,0x5e,0x04,0xff,0xf1,0x63,0x04,0xe9,0xf1,0x69,0x04,0xd3,0xf1,0x6e,0x04,0xbc,0xf1,0x74,0x04,0xa7,0xf1,0x7b,0x04,0x93,0xf1,0x82,0x04,0x7f,0xf1,0x89,0x04,0x6a,0xf1,0x90,0x04,0x56,0xf1,0x97,0x04,0x42,0xf1,0x9e,0x04,0x2d,0xf1,  \
    0xa5,0x04,0x19,0xf1,0xac,0x04,0x04,0xf1,0xb3,0x04,0xef,0xf0,0xba,0x04,0xda,0xf0,0xc1,0x04,0xc6,0xf0,0xc8,0x04,0xb1,0xf0,0xcf,0x04,0x9b,0xf0,0xd6,0x04,0x86,0xf0,0xdd,0x04,0x71,0xf0,0xe4,0x04,0x5b,0xf0,0xeb,0x04,0x46,0xf0,0xf1,0x04,0x30,0xf0,0xf8,0x04,0x1b,0xf0,0xff,0x04,0x05,0xf0,0x06,0x05,0xf0,0xef,0x0d,0x05,0xda,0xef,0x14,0x05,0xc4,0xef,0x1b,0x05,0xae,0xef,0x22,0x05,0x98,0xef,0x29,0x05,0x82,0xef,0x2f,0x05,0x6b,0xef,0x36,0x05,0x55,0xef,0x3c,0x05,  \
    0x3e,0xef,0x43,0x05,0x27,0xef,0x49,0x05,0x10,0xef,0x50,0x05,0xf9,0xee,0x56,0x05,0xe1,0xee,0x5c,0x05,0xca,0xee,0x62,0x05,0xb2,0xee,0x68,0x05,0x9a,0xee,0x6e,0x05,0x82,0xee,0x74,0x05,0x6a,0xee,0x79,0x05,0x51,0xee,0x7e,0x05,0x37,0xee,0x82,0x05,0x1d,0xee,0x86,0x05,0x03,0xee,0x8b,0x05,0xe8,0xed,0x8f,0x05,0xce,0xed,0x93,0x05,0xb3,0xed,0x97,0x05,0x98,0xed,0x9a,0x05,0x7d,0xed,0x9e,0x05,0x62,0xed,0xa2,0x05,0x47,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x13,0x06,0x4c,0x12,0x0f,0x06,0x31,0x12,0x0b,0x06,0x16,0x12,0x06,0x06,0xfb,0x11,0x02,0x06,0xe0,0x11,0xfd,0x05,0xc6,0x11,0xf8,0x05,0xab,0x11,0xf3,0x05,0x91,0x11,0xee,0x05,0x77,0x11,0xe9,0x05,  \
    0x5d,0x11,0xe4,0x05,0x43,0x11,0xdf,0x05,0x29,0x11,0xd9,0x05,0x10,0x11,0xd4,0x05,0xf6,0x10,0xce,0x05,0xdd,0x10,0xc9,0x05,0xc4,0x10,0xc3,0x05,0xab,0x10,0xbd,0x05,0x92,0x10,0xb7,0x05,0x79,0x10,0xb1,0x05,0x61,0x10,0xab,0x05,0x49,0x10,0xa4,0x05,0x31,0x10,0x9d,0x05,0x1a,0x10,0x96,0x05,0x03,0x10,0x8f,0x05,0xec,0x0f,0x88,0x05,0xd5,0x0f,0x81,0x05,0xbe,0x0f,0x7a,0x05,0xa7,0x0f,0x73,0x05,0x91,0x0f,0x6b,0x05,0x7a,0x0f,0x64,0x05,0x64,0x0f,0x5d,0x05,0x4e,0x0f,  \
    0x55,0x05,0x38,0x0f,0x4e,0x05,0x22,0x0f,0x46,0x05,0x0c,0x0f,0x3f,0x05,0xf6,0x0e,0x37,0x05,0xe1,0x0e,0x30,0x05,0xcb,0x0e,0x28,0x05,0xb6,0x0e,0x20,0x05,0xa0,0x0e,0x18,0x05,0x8c,0x0e,0x0f,0x05,0x78,0x0e,0x07,0x05,0x65,0x0e,0xfe,0x04,0x51,0x0e,0xf5,0x04,0x3e,0x0e,0xed,0x04,0x2b,0x0e,0xe4,0x04,0x18,0x0e,0xdb,0x04,0x05,0x0e,0xd3,0x04,0xf2,0x0d,0xca,0x04,0xdf,0x0d,0xc1,0x04,0xcc,0x0d,0xb8,0x04,0xba,0x0d,0xb0,0x04,0xa8,0x0d,0xa7,0x04,0x95,0x0d,0x9e,0x04,  \
    0x83,0x0d,0x96,0x04,0x71,0x0d,0x8d,0x04,0x5f,0x0d,0x85,0x04,0x4c,0x0d,0x7e,0x04,0x36,0x0d,0x78,0x04,0x20,0x0d,0x72,0x04,0x0b,0x0d,0x6c,0x04,0xf5,0x0c,0x66,0x04,0xdf,0x0c,0x60,0x04,0xc9,0x0c,0x5a,0x04,0xb4,0x0c,0x54,0x04,0x9e,0x0c,0x4e,0x04,0x88,0x0c,0x48,0x04,0x73,0x0c,0x42,0x04,0x5d,0x0c,0x3c,0x04,0x48,0x0c,0x36,0x04,0x32,0x0c,0x30,0x04,0x1d,0x0c,0x2a,0x04,0x08,0x0c,0x24,0x04,0xf2,0x0b,0x1e,0x04,0xdd,0x0b,0x18,0x04,0xc8,0x0b,0x13,0x04,0xb3,0x0b,  \
    0x0d,0x04,0x9d,0x0b,0x07,0x04,0x88,0x0b,0x01,0x04,0x73,0x0b,0xfb,0x03,0x5e,0x0b,0xf6,0x03,0x49,0x0b,0xf0,0x03,0x34,0x0b,0xea,0x03,0x1f,0x0b,0xe5,0x03,0x0a,0x0b,0xdf,0x03,0xf5,0x0a,0xd9,0x03,0xe0,0x0a,0xd4,0x03,0xcb,0x0a,0xce,0x03,0xb6,0x0a,0xc9,0x03,0xa2,0x0a,0xc3,0x03,0x8d,0x0a,0xbe,0x03,0x78,0x0a,0xb8,0x03,0x63,0x0a,0xb2,0x03,0x4f,0x0a,0xab,0x03,0x3e,0x0a,0xa4,0x03,0x2d,0x0a,0x9d,0x03,0x1c,0x0a,0x97,0x03,0x0b,0x0a,0x90,0x03,0xfa,0x09,0x89,0x03,  \
    0xe9,0x09,0x82,0x03,0xd8,0x09,0x7c,0x03,0xc6,0x09,0x75,0x03,0xb5,0x09,0x6e,0x03,0xa4,0x09,0x68,0x03,0x93,0x09,0x62,0x03,0x82,0x09,0x5b,0x03,0x71,0x09,0x55,0x03,0x60,0x09,0x4f,0x03,0x4f,0x09,0x48,0x03,0x3e,0x09,0x42,0x03,0x2e,0x09,0x3c,0x03,0x1d,0x09,0x36,0x03,0x0c,0x09,0x30,0x03,0xfb,0x08,0x2b,0x03,0xe9,0x08,0x25,0x03,0xd8,0x08,0x1f,0x03,0xc7,0x08,0x1a,0x03,0xb5,0x08,0x14,0x03,0xa4,0x08,0x0f,0x03,0x92,0x08,0x0a,0x03,0x81,0x08,0x04,0x03,0x6f,0x08,  \
    0xff,0x02,0x5e,0x08,0xfa,0x02,0x4c,0x08,0xf5,0x02,0x3b,0x08,0xf0,0x02,0x29,0x08,0xeb,0x02,0x18,0x08,0xe6,0x02,0x06,0x08,0xe1,0x02,0xf5,0x07,0xdc,0x02,0xe3,0x07,0xd7,0x02,0xd2,0x07,0xd3,0x02,0xc0,0x07,0xce,0x02,0xaf,0x07,0xc9,0x02,0x9d,0x07,0xc5,0x02,0x8c,0x07,0xc0,0x02,0x7a,0x07,0xbc,0x02,0x69,0x07,0xb8,0x02,0x55,0x07,0xb4,0x02,0x42,0x07,0xb0,0x02,0x2e,0x07,0xad,0x02,0x1a,0x07,0xa9,0x02,0x07,0x07,0xa5,0x02,0xf4,0x06,0xa2,0x02,0xe0,0x06,0x9e,0x02,  \
    0xcd,0x06,0x9b,0x02,0xb9,0x06,0x97,0x02,0xa6,0x06,0x94,0x02,0x92,0x06,0x90,0x02,0x7f,0x06,0x8d,0x02,0x6c,0x06,0x89,0x02,0x58,0x06,0x86,0x02,0x45,0x06,0x83,0x02,0x32,0x06,0x7f,0x02,0x1e,0x06,0x7c,0x02,0x0b,0x06,0x79,0x02,0xf8,0x05,0x76,0x02,0xe5,0x05,0x73,0x02,0xd1,0x05,0x6f,0x02,0xbe,0x05,0x6c,0x02,0xab,0x05,0x69,0x02,0x98,0x05,0x66,0x02,0x86,0x05,0x63,0x02,0x74,0x05,0x5f,0x02,0x62,0x05,0x5c,0x02,0x50,0x05,0x59,0x02,0x3f,0x05,0x56,0x02,0x2d,0x05,  \
    0x53,0x02,0x1b,0x05,0x50,0x02,0x09,0x05,0x4d,0x02,0xf7,0x04,0x4a,0x02,0xe5,0x04,0x47,0x02,0xd3,0x04,0x44,0x02,0xc1,0x04,0x42,0x02,0xaf,0x04,0x3f,0x02,0x9d,0x04,0x3c,0x02,0x8b,0x04,0x3a,0x02,0x79,0x04,0x37,0x02,0x67,0x04,0x34,0x02,0x55,0x04,0x32,0x02,0x43,0x04,0x30,0x02,0x31,0x04,0x2d,0x02,0x1f,0x04,0x2b,0x02,0x0d,0x04,0x28,0x02,0xfb,0x03,0x26,0x02,0xe9,0x03,0x24,0x02,0xd7,0x03,0x22,0x02,0xc5,0x03,0x1f,0x02,0xb4,0x03,0x1d,0x02,0xa3,0x03,0x1b,0x02,  \
    0x92,0x03,0x19,0x02,0x81,0x03,0x16,0x02,0x6f,0x03,0x14,0x02,0x5e,0x03,0x12,0x02,0x4d,0x03,0x10,0x02,0x3c,0x03,0x0e,0x02,0x2a,0x03,0x0d,0x02,0x19,0x03,0x0b,0x02,0x07,0x03,0x09,0x02,0xf6,0x02,0x07,0x02,0xe4,0x02,0x06,0x02,0xd3,0x02,0x04,0x02,0xc1,0x02,0x02,0x02,0xb0,0x02,0x01,0x02,0x9e,0x02,0xff,0x01,0x8c,0x02,0xfe,0x01,0x7a,0x02,0xfc,0x01,0x69,0x02,0xfb,0x01,0x57,0x02,0xfa,0x01,0x45,0x02,0xf9,0x01,0x33,0x02,0xf7,0x01,0x21,0x02,0xf6,0x01,0x0f,0x02,  \
    0xf5,0x01,0xfd,0x01,0xf4,0x01,0xeb,0x01,0xf3,0x01,0xd8,0x01,0xf2,0x01,0xc5,0x01,0xf1,0x01,0xb2,0x01,0xf0,0x01,0xa0,0x01,0xef,0x01,0x8d,0x01,0xee,0x01,0x7a,0x01,0xee,0x01,0x67,0x01,0xed,0x01,0x54,0x01,0xec,0x01,0x41,0x01,0xeb,0x01,0x2f,0x01,0xeb,0x01,0x1c,0x01,0xea,0x01,0x09,0x01,0xea,0x01,0xf6,0x00,0xe9,0x01,0xe3,0x00,0xe9,0x01,0xd0,0x00,0xe8,0x01,0xbd,0x00,0xe8,0x01,0xab,0x00,0xe7,0x01,0x98,0x00,0xe7,0x01,0x85,0x00,0xe7,0x01,0x72,0x00,0xe6,0x01,  \
    0x5f,0x00,0xe6,0x01,0x4c,0x00,0xe6,0x01,0x39,0x00,0xe5,0x01,0x26,0x00,0xe5,0x01,0x14,0x00,0xe5,0x01,0x01,0x00,0xe5,0x01,0xee,0xff,0xe5,0x01,0xdb,0xff,0xe5,0x01,0xc8,0xff,0xe5,0x01,0xb5,0xff,0xe5,0x01,0xa2,0xff,0xe5,0x01,0x8f,0xff,0xe5,0x01,0x7d,0xff,0xe5,0x01,0x6a,0xff,0xe6,0x01,0x57,0xff,0xe6,0x01,0x44,0xff,0xe6,0x01,0x31,0xff,0xe6,0x01,0x1e,0xff,0xe7,0x01,0x0b,0xff,0xe7,0x01,0xf9,0xfe,0xe7,0x01,0xe6,0xfe,0xe8,0x01,0xd3,0xfe,0xe8,0x01,0xc0,0xfe,  \
    0xe9,0x01,0xad,0xfe,0xe9,0x01,0x9a,0xfe,0xea,0x01,0x87,0xfe,0xea,0x01,0x75,0xfe,0xeb,0x01,0x62,0xfe,0xec,0x01,0x4f,0xfe,0xec,0x01,0x3c,0xfe,0xed,0x01,0x29,0xfe,0xee,0x01,0x16,0xfe,0xee,0x01,0x04,0xfe,0xef,0x01,0xf1,0xfd,0xf0,0x01,0xde,0xfd,0xf1,0x01,0xcb,0xfd,0xf2,0x01,0xb8,0xfd,0xf3,0x01,0xa5,0xfd,0xf4,0x01,0x92,0xfd,0xf5,0x01,0x7f,0xfd,0xf6,0x01,0x6c,0xfd,0xf7,0x01,0x59,0xfd,0xf8,0x01,0x45,0xfd,0xf9,0x01,0x32,0xfd,0xfa,0x01,0x1f,0xfd,0xfb,0x01,  \
    0x0c,0xfd,0xfd,0x01,0xf8,0xfc,0xfe,0x01,0xe5,0xfc,0xff,0x01,0xd2,0xfc,0x00,0x02,0xbf,0xfc,0x02,0x02,0xab,0xfc,0x03,0x02,0x98,0xfc,0x05,0x02,0x85,0xfc,0x06,0x02,0x71,0xfc,0x07,0x02,0x5e,0xfc,0x09,0x02,0x4a,0xfc,0x0a,0x02,0x37,0xfc,0x0c,0x02,0x24,0xfc,0x0e,0x02,0x10,0xfc,0x0f,0x02,0xfd,0xfb,0x11,0x02,0xe9,0xfb,0x13,0x02,0xd6,0xfb,0x14,0x02,0xc2,0xfb,0x16,0x02,0xaf,0xfb,0x18,0x02,0x9c,0xfb,0x1a,0x02,0x8a,0xfb,0x1c,0x02,0x78,0xfb,0x1e,0x02,0x65,0xfb,  \
    0x20,0x02,0x53,0xfb,0x22,0x02,0x40,0xfb,0x24,0x02,0x2e,0xfb,0x26,0x02,0x1b,0xfb,0x29,0x02,0x09,0xfb,0x2b,0x02,0xf7,0xfa,0x2d,0x02,0xe4,0xfa,0x2f,0x02,0xd2,0xfa,0x32,0x02,0xc0,0xfa,0x34,0x02,0xae,0xfa,0x37,0x02,0x9b,0xfa,0x39,0x02,0x89,0xfa,0x3c,0x02,0x77,0xfa,0x3f,0x02,0x65,0xfa,0x41,0x02,0x53,0xfa,0x44,0x02,0x41,0xfa,0x47,0x02,0x2f,0xfa,0x49,0x02,0x1d,0xfa,0x4c,0x02,0x0b,0xfa,0x4f,0x02,0xf8,0xf9,0x52,0x02,0xe6,0xf9,0x55,0x02,0xd4,0xf9,0x58,0x02,  \
    0xc2,0xf9,0x5b,0x02,0xaf,0xf9,0x5e,0x02,0x9c,0xf9,0x61,0x02,0x89,0xf9,0x64,0x02,0x76,0xf9,0x67,0x02,0x63,0xf9,0x6a,0x02,0x50,0xf9,0x6d,0x02,0x3e,0xf9,0x70,0x02,0x2b,0xf9,0x73,0x02,0x18,0xf9,0x76,0x02,0x05,0xf9,0x79,0x02,0xf2,0xf8,0x7d,0x02,0xdf,0xf8,0x80,0x02,0xcc,0xf8,0x83,0x02,0xb9,0xf8,0x87,0x02,0xa6,0xf8,0x8a,0x02,0x93,0xf8,0x8e,0x02,0x80,0xf8,0x91,0x02,0x6e,0xf8,0x95,0x02,0x5b,0xf8,0x98,0x02,0x48,0xf8,0x9c,0x02,0x35,0xf8,0xa0,0x02,0x22,0xf8,  \
    0xa3,0x02,0x0f,0xf8,0xa7,0x02,0xfc,0xf7,0xab,0x02,0xea,0xf7,0xaf,0x02,0xd7,0xf7,0xb3,0x02,0xc5,0xf7,0xb7,0x02,0xb3,0xf7,0xbb,0x02,0xa1,0xf7,0xc0,0x02,0x8f,0xf7,0xc4,0x02,0x7c,0xf7,0xc8,0x02,0x6a,0xf7,0xcc,0x02,0x58,0xf7,0xd1,0x02,0x46,0xf7,0xd5,0x02,0x34,0xf7,0xda,0x02,0x21,0xf7,0xde,0x02,0x0f,0xf7,0xe3,0x02,0xfd,0xf6,0xe8,0x02,0xeb,0xf6,0xec,0x02,0xd9,0xf6,0xf1,0x02,0xc7,0xf6,0xf6,0x02,0xb4,0xf6,0xfb,0x02,0xa2,0xf6,0xff,0x02,0x90,0xf6,0x04,0x03,  \
    0x7e,0xf6,0x09,0x03,0x6c,0xf6,0x0e,0x03,0x5a,0xf6,0x13,0x03,0x47,0xf6,0x18,0x03,0x34,0xf6,0x1d,0x03,0x21,0xf6,0x22,0x03,0x0e,0xf6,0x27,0x03,0xfb,0xf5,0x2c,0x03,0xe7,0xf5,0x30,0x03,0xd4,0xf5,0x36,0x03,0xc1,0xf5,0x3b,0x03,0xae,0xf5,0x40,0x03,0x9b,0xf5,0x45,0x03,0x88,0xf5,0x4a,0x03,0x75,0xf5,0x4f,0x03,0x62,0xf5,0x55,0x03,0x4e,0xf5,0x5a,0x03,0x3b,0xf5,0x5f,0x03,0x28,0xf5,0x65,0x03,0x15,0xf5,0x6a,0x03,0x02,0xf5,0x6f,0x03,0xee,0xf4,0x75,0x03,0xdb,0xf4,  \
    0x7b,0x03,0xc8,0xf4,0x80,0x03,0xb5,0xf4,0x86,0x03,0xa2,0xf4,0x8c,0x03,0x90,0xf4,0x92,0x03,0x7d,0xf4,0x98,0x03,0x6a,0xf4,0x9e,0x03,0x58,0xf4,0xa5,0x03,0x45,0xf4,0xab,0x03,0x32,0xf4,0xb1,0x03,0x20,0xf4,0xb7,0x03,0x0d,0xf4,0xbe,0x03,0xfa,0xf3,0xc4,0x03,0xe7,0xf3,0xca,0x03,0xd4,0xf3,0xd1,0x03,0xc2,0xf3,0xd7,0x03,0xaf,0xf3,0xde,0x03,0x9c,0xf3,0xe4,0x03,0x89,0xf3,0xeb,0x03,0x76,0xf3,0xf2,0x03,0x63,0xf3,0xf8,0x03,0x50,0xf3,0xfe,0x03,0x3a,0xf3,0x03,0x04,  \
    0x25,0xf3,0x09,0x04,0x0f,0xf3,0x0e,0x04,0xfa,0xf2,0x14,0x04,0xe4,0xf2,0x19,0x04,0xce,0xf2,0x1f,0x04,0xb9,0xf2,0x24,0x04,0xa3,0xf2,0x2a,0x04,0x8d,0xf2,0x2f,0x04,0x77,0xf2,0x35,0x04,0x61,0xf2,0x3b,0x04,0x4b,0xf2,0x40,0x04,0x35,0xf2,0x46,0x04,0x1f,0xf2,0x4b,0x04,0x09,0xf2,0x51,0x04,0xf3,0xf1,0x57,0x04,0xdc,0xf1,0x5c,0x04,0xc6,0xf1,0x62,0x04,0xb1,0xf1,0x69,0x04,0x9c,0xf1,0x70,0x04,0x88,0xf1,0x77,0x04,0x74,0xf1,0x7e,0x04,0x60,0xf1,0x85,0x04,0x4b,0xf1,  \
    0x8c,0x04,0x37,0xf1,0x93,0x04,0x22,0xf1,0x9a,0x04,0x0e,0xf1,0xa1,0x04,0xf9,0xf0,0xa8,0x04,0xe4,0xf0,0xaf,0x04,0xcf,0xf0,0xb6,0x04,0xba,0xf0,0xbd,0x04,0xa5,0xf0,0xc4,0x04,0x90,0xf0,0xcb,0x04,0x7a,0xf0,0xd1,0x04,0x65,0xf0,0xd8,0x04,0x4f,0xf0,0xdf,0x04,0x3a,0xf0,0xe6,0x04,0x24,0xf0,0xed,0x04,0x0f,0xf0,0xf4,0x04,0xf9,0xef,0xfb,0x04,0xe3,0xef,0x02,0x05,0xcd,0xef,0x09,0x05,0xb7,0xef,0x0f,0x05,0xa1,0xef,0x16,0x05,0x8b,0xef,0x1d,0x05,0x74,0xef,0x23,0x05,  \
    0x5e,0xef,0x2a,0x05,0x47,0xef,0x30,0x05,0x30,0xef,0x37,0x05,0x19,0xef,0x3d,0x05,0x02,0xef,0x43,0x05,0xea,0xee,0x49,0x05,0xd3,0xee,0x4f,0x05,0xbb,0xee,0x55,0x05,0xa3,0xee,0x5b,0x05,0x8b,0xee,0x61,0x05,0x73,0xee,0x66,0x05,0x5a,0xee,0x6b,0x05,0x40,0xee,0x6f,0x05,0x26,0xee,0x73,0x05,0x0b,0xee,0x78,0x05,0xf1,0xed,0x7c,0x05,0xd6,0xed,0x80,0x05,0xbc,0xed,0x84,0x05,0xa1,0xed,0x87,0x05,0x86,0xed,0x8b,0x05,0x6b,0xed,0x8f,0x05,0x4f,0xed,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0b,0x06,0x3f,0x12,0x07,0x06,0x24,0x12,0x02,0x06,0x09,0x12,0xfe,0x05,0xee,0x11,0xf9,0x05,0xd3,0x11,0xf5,0x05,0xb9,0x11,0xf0,0x05,0x9e,0x11,0xeb,0x05,0x84,0x11,0xe6,0x05,  \
    0x6a,0x11,0xe1,0x05,0x50,0x11,0xdb,0x05,0x36,0x11,0xd6,0x05,0x1d,0x11,0xd1,0x05,0x03,0x11,0xcb,0x05,0xea,0x10,0xc5,0x05,0xd0,0x10,0xc0,0x05,0xb7,0x10,0xba,0x05,0x9e,0x10,0xb4,0x05,0x85,0x10,0xae,0x05,0x6d,0x10,0xa8,0x05,0x54,0x10,0xa1,0x05,0x3c,0x10,0x9b,0x05,0x25,0x10,0x94,0x05,0x0d,0x10,0x8d,0x05,0xf6,0x0f,0x85,0x05,0xdf,0x0f,0x7e,0x05,0xc8,0x0f,0x77,0x05,0xb1,0x0f,0x70,0x05,0x9b,0x0f,0x68,0x05,0x84,0x0f,0x61,0x05,0x6e,0x0f,0x5a,0x05,0x57,0x0f,  \
    0x52,0x05,0x41,0x0f,0x4b,0x05,0x2b,0x0f,0x43,0x05,0x15,0x0f,0x3c,0x05,0xff,0x0e,0x34,0x05,0xea,0x0e,0x2c,0x05,0xd4,0x0e,0x25,0x05,0xbf,0x0e,0x1d,0x05,0xa9,0x0e,0x15,0x05,0x94,0x0e,0x0d,0x05,0x80,0x0e,0x04,0x05,0x6c,0x0e,0xfb,0x04,0x58,0x0e,0xf3,0x04,0x45,0x0e,0xea,0x04,0x32,0x0e,0xe1,0x04,0x1e,0x0e,0xd8,0x04,0x0b,0x0e,0xcf,0x04,0xf8,0x0d,0xc7,0x04,0xe6,0x0d,0xbe,0x04,0xd3,0x0d,0xb5,0x04,0xc0,0x0d,0xac,0x04,0xae,0x0d,0xa3,0x04,0x9b,0x0d,0x9b,0x04,  \
    0x89,0x0d,0x92,0x04,0x77,0x0d,0x89,0x04,0x65,0x0d,0x80,0x04,0x53,0x0d,0x78,0x04,0x40,0x0d,0x72,0x04,0x2a,0x0d,0x6c,0x04,0x14,0x0d,0x65,0x04,0xff,0x0c,0x5f,0x04,0xe9,0x0c,0x59,0x04,0xd3,0x0c,0x53,0x04,0xbd,0x0c,0x4d,0x04,0xa8,0x0c,0x47,0x04,0x92,0x0c,0x40,0x04,0x7d,0x0c,0x3a,0x04,0x67,0x0c,0x34,0x04,0x52,0x0c,0x2e,0x04,0x3d,0x0c,0x28,0x04,0x27,0x0c,0x22,0x04,0x12,0x0c,0x1c,0x04,0xfd,0x0b,0x16,0x04,0xe7,0x0b,0x10,0x04,0xd2,0x0b,0x0a,0x04,0xbd,0x0b,  \
    0x04,0x04,0xa8,0x0b,0xfe,0x03,0x93,0x0b,0xf8,0x03,0x7e,0x0b,0xf3,0x03,0x69,0x0b,0xed,0x03,0x54,0x0b,0xe7,0x03,0x3f,0x0b,0xe1,0x03,0x2a,0x0b,0xdb,0x03,0x15,0x0b,0xd6,0x03,0x00,0x0b,0xd0,0x03,0xeb,0x0a,0xca,0x03,0xd6,0x0a,0xc4,0x03,0xc2,0x0a,0xbf,0x03,0xad,0x0a,0xb9,0x03,0x98,0x0a,0xb4,0x03,0x83,0x0a,0xae,0x03,0x6f,0x0a,0xa8,0x03,0x5a,0x0a,0xa3,0x03,0x46,0x0a,0x9c,0x03,0x35,0x0a,0x94,0x03,0x24,0x0a,0x8d,0x03,0x13,0x0a,0x87,0x03,0x02,0x0a,0x80,0x03,  \
    0xf1,0x09,0x79,0x03,0xe0,0x09,0x72,0x03,0xce,0x09,0x6b,0x03,0xbd,0x09,0x65,0x03,0xac,0x09,0x5e,0x03,0x9b,0x09,0x58,0x03,0x8a,0x09,0x51,0x03,0x7a,0x09,0x4b,0x03,0x69,0x09,0x44,0x03,0x58,0x09,0x3e,0x03,0x47,0x09,0x38,0x03,0x36,0x09,0x32,0x03,0x25,0x09,0x2b,0x03,0x14,0x09,0x25,0x03,0x03,0x09,0x1f,0x03,0xf2,0x08,0x1a,0x03,0xe1,0x08,0x14,0x03,0xd0,0x08,0x0e,0x03,0xbe,0x08,0x09,0x03,0xad,0x08,0x03,0x03,0x9b,0x08,0xfe,0x02,0x8a,0x08,0xf8,0x02,0x78,0x08,  \
    0xf3,0x02,0x67,0x08,0xee,0x02,0x56,0x08,0xe9,0x02,0x44,0x08,0xe3,0x02,0x33,0x08,0xde,0x02,0x21,0x08,0xd9,0x02,0x10,0x08,0xd4,0x02,0xfe,0x07,0xcf,0x02,0xed,0x07,0xca,0x02,0xdc,0x07,0xc6,0x02,0xca,0x07,0xc1,0x02,0xb9,0x07,0xbc,0x02,0xa7,0x07,0xb7,0x02,0x96,0x07,0xb3,0x02,0x84,0x07,0xae,0x02,0x73,0x07,0xaa,0x02,0x61,0x07,0xa6,0x02,0x4e,0x07,0xa2,0x02,0x3a,0x07,0x9e,0x02,0x27,0x07,0x9a,0x02,0x13,0x07,0x97,0x02,0x00,0x07,0x93,0x02,0xed,0x06,0x8f,0x02,  \
    0xd9,0x06,0x8c,0x02,0xc6,0x06,0x88,0x02,0xb3,0x06,0x85,0x02,0x9f,0x06,0x81,0x02,0x8c,0x06,0x7e,0x02,0x79,0x06,0x7a,0x02,0x65,0x06,0x77,0x02,0x52,0x06,0x73,0x02,0x3f,0x06,0x70,0x02,0x2c,0x06,0x6d,0x02,0x18,0x06,0x69,0x02,0x05,0x06,0x66,0x02,0xf2,0x05,0x63,0x02,0xdf,0x05,0x60,0x02,0xcc,0x05,0x5d,0x02,0xb9,0x05,0x59,0x02,0xa6,0x05,0x56,0x02,0x93,0x05,0x53,0x02,0x81,0x05,0x50,0x02,0x6f,0x05,0x4c,0x02,0x5d,0x05,0x49,0x02,0x4b,0x05,0x46,0x02,0x39,0x05,  \
    0x43,0x02,0x28,0x05,0x40,0x02,0x16,0x05,0x3d,0x02,0x04,0x05,0x3a,0x02,0xf2,0x04,0x37,0x02,0xe0,0x04,0x34,0x02,0xce,0x04,0x31,0x02,0xbc,0x04,0x2e,0x02,0xaa,0x04,0x2c,0x02,0x98,0x04,0x29,0x02,0x87,0x04,0x26,0x02,0x75,0x04,0x24,0x02,0x63,0x04,0x21,0x02,0x51,0x04,0x1e,0x02,0x3f,0x04,0x1c,0x02,0x2d,0x04,0x19,0x02,0x1b,0x04,0x17,0x02,0x09,0x04,0x15,0x02,0xf7,0x03,0x12,0x02,0xe5,0x03,0x10,0x02,0xd3,0x03,0x0e,0x02,0xc1,0x03,0x0b,0x02,0xb0,0x03,0x09,0x02,  \
    0x9f,0x03,0x07,0x02,0x8e,0x03,0x05,0x02,0x7d,0x03,0x03,0x02,0x6c,0x03,0x01,0x02,0x5b,0x03,0xfe,0x01,0x49,0x03,0xfc,0x01,0x38,0x03,0xfb,0x01,0x27,0x03,0xf9,0x01,0x16,0x03,0xf7,0x01,0x04,0x03,0xf5,0x01,0xf3,0x02,0xf3,0x01,0xe1,0x02,0xf2,0x01,0xd0,0x02,0xf0,0x01,0xbe,0x02,0xee,0x01,0xad,0x02,0xed,0x01,0x9b,0x02,0xeb,0x01,0x89,0x02,0xea,0x01,0x78,0x02,0xe8,0x01,0x66,0x02,0xe7,0x01,0x54,0x02,0xe6,0x01,0x42,0x02,0xe4,0x01,0x31,0x02,0xe3,0x01,0x1f,0x02,  \
    0xe2,0x01,0x0d,0x02,0xe1,0x01,0xfb,0x01,0xe0,0x01,0xe9,0x01,0xdf,0x01,0xd6,0x01,0xde,0x01,0xc3,0x01,0xdd,0x01,0xb0,0x01,0xdc,0x01,0x9e,0x01,0xdb,0x01,0x8b,0x01,0xda,0x01,0x78,0x01,0xd9,0x01,0x65,0x01,0xd9,0x01,0x53,0x01,0xd8,0x01,0x40,0x01,0xd7,0x01,0x2d,0x01,0xd7,0x01,0x1a,0x01,0xd6,0x01,0x08,0x01,0xd5,0x01,0xf5,0x00,0xd5,0x01,0xe2,0x00,0xd4,0x01,0xcf,0x00,0xd4,0x01,0xbc,0x00,0xd3,0x01,0xaa,0x00,0xd3,0x01,0x97,0x00,0xd3,0x01,0x84,0x00,0xd2,0x01,  \
    0x71,0x00,0xd2,0x01,0x5e,0x00,0xd2,0x01,0x4c,0x00,0xd1,0x01,0x39,0x00,0xd1,0x01,0x26,0x00,0xd1,0x01,0x13,0x00,0xd1,0x01,0x00,0x00,0xd1,0x01,0xee,0xff,0xd1,0x01,0xdb,0xff,0xd1,0x01,0xc8,0xff,0xd1,0x01,0xb5,0xff,0xd1,0x01,0xa2,0xff,0xd1,0x01,0x90,0xff,0xd1,0x01,0x7d,0xff,0xd1,0x01,0x6a,0xff,0xd1,0x01,0x57,0xff,0xd1,0x01,0x44,0xff,0xd2,0x01,0x32,0xff,0xd2,0x01,0x1f,0xff,0xd2,0x01,0x0c,0xff,0xd3,0x01,0xf9,0xfe,0xd3,0x01,0xe7,0xfe,0xd3,0x01,0xd4,0xfe,  \
    0xd4,0x01,0xc1,0xfe,0xd4,0x01,0xae,0xfe,0xd5,0x01,0x9b,0xfe,0xd5,0x01,0x89,0xfe,0xd6,0x01,0x76,0xfe,0xd7,0x01,0x63,0xfe,0xd7,0x01,0x50,0xfe,0xd8,0x01,0x3e,0xfe,0xd9,0x01,0x2b,0xfe,0xd9,0x01,0x18,0xfe,0xda,0x01,0x05,0xfe,0xdb,0x01,0xf3,0xfd,0xdc,0x01,0xe0,0xfd,0xdd,0x01,0xcd,0xfd,0xde,0x01,0xba,0xfd,0xdf,0x01,0xa7,0xfd,0xe0,0x01,0x94,0xfd,0xe1,0x01,0x81,0xfd,0xe2,0x01,0x6e,0xfd,0xe3,0x01,0x5b,0xfd,0xe4,0x01,0x48,0xfd,0xe5,0x01,0x35,0xfd,0xe6,0x01,  \
    0x22,0xfd,0xe7,0x01,0x0e,0xfd,0xe9,0x01,0xfb,0xfc,0xea,0x01,0xe8,0xfc,0xeb,0x01,0xd5,0xfc,0xec,0x01,0xc2,0xfc,0xee,0x01,0xae,0xfc,0xef,0x01,0x9b,0xfc,0xf1,0x01,0x88,0xfc,0xf2,0x01,0x75,0xfc,0xf3,0x01,0x61,0xfc,0xf5,0x01,0x4e,0xfc,0xf6,0x01,0x3b,0xfc,0xf8,0x01,0x27,0xfc,0xfa,0x01,0x14,0xfc,0xfb,0x01,0x01,0xfc,0xfd,0x01,0xed,0xfb,0xff,0x01,0xda,0xfb,0x00,0x02,0xc7,0xfb,0x02,0x02,0xb3,0xfb,0x04,0x02,0xa1,0xfb,0x06,0x02,0x8e,0xfb,0x08,0x02,0x7c,0xfb,  \
    0x0a,0x02,0x6a,0xfb,0x0c,0x02,0x57,0xfb,0x0e,0x02,0x45,0xfb,0x10,0x02,0x32,0xfb,0x12,0x02,0x20,0xfb,0x15,0x02,0x0e,0xfb,0x17,0x02,0xfc,0xfa,0x19,0x02,0xe9,0xfa,0x1c,0x02,0xd7,0xfa,0x1e,0x02,0xc5,0xfa,0x21,0x02,0xb3,0xfa,0x23,0x02,0xa1,0xfa,0x26,0x02,0x8f,0xfa,0x28,0x02,0x7c,0xfa,0x2b,0x02,0x6a,0xfa,0x2d,0x02,0x58,0xfa,0x30,0x02,0x46,0xfa,0x33,0x02,0x34,0xfa,0x36,0x02,0x22,0xfa,0x39,0x02,0x10,0xfa,0x3c,0x02,0xfe,0xf9,0x3e,0x02,0xec,0xf9,0x41,0x02,  \
    0xda,0xf9,0x44,0x02,0xc8,0xf9,0x47,0x02,0xb5,0xf9,0x4a,0x02,0xa2,0xf9,0x4d,0x02,0x8f,0xf9,0x50,0x02,0x7c,0xf9,0x53,0x02,0x6a,0xf9,0x56,0x02,0x57,0xf9,0x59,0x02,0x44,0xf9,0x5c,0x02,0x31,0xf9,0x60,0x02,0x1e,0xf9,0x63,0x02,0x0b,0xf9,0x66,0x02,0xf8,0xf8,0x69,0x02,0xe6,0xf8,0x6d,0x02,0xd3,0xf8,0x70,0x02,0xc0,0xf8,0x73,0x02,0xad,0xf8,0x77,0x02,0x9a,0xf8,0x7a,0x02,0x87,0xf8,0x7e,0x02,0x75,0xf8,0x82,0x02,0x62,0xf8,0x85,0x02,0x4f,0xf8,0x89,0x02,0x3c,0xf8,  \
    0x8c,0x02,0x29,0xf8,0x90,0x02,0x16,0xf8,0x94,0x02,0x04,0xf8,0x98,0x02,0xf1,0xf7,0x9c,0x02,0xdf,0xf7,0xa0,0x02,0xcd,0xf7,0xa4,0x02,0xbb,0xf7,0xa8,0x02,0xa8,0xf7,0xad,0x02,0x96,0xf7,0xb1,0x02,0x84,0xf7,0xb5,0x02,0x72,0xf7,0xb9,0x02,0x60,0xf7,0xbe,0x02,0x4e,0xf7,0xc2,0x02,0x3b,0xf7,0xc7,0x02,0x29,0xf7,0xcb,0x02,0x17,0xf7,0xd0,0x02,0x05,0xf7,0xd5,0x02,0xf3,0xf6,0xd9,0x02,0xe1,0xf6,0xde,0x02,0xcf,0xf6,0xe3,0x02,0xbd,0xf6,0xe8,0x02,0xaa,0xf6,0xed,0x02,  \
    0x98,0xf6,0xf2,0x02,0x86,0xf6,0xf7,0x02,0x74,0xf6,0xfc,0x02,0x62,0xf6,0x00,0x03,0x4f,0xf6,0x05,0x03,0x3c,0xf6,0x0a,0x03,0x29,0xf6,0x0f,0x03,0x16,0xf6,0x14,0x03,0x03,0xf6,0x19,0x03,0xf0,0xf5,0x1e,0x03,0xdd,0xf5,0x23,0x03,0xca,0xf5,0x28,0x03,0xb7,0xf5,0x2d,0x03,0xa4,0xf5,0x32,0x03,0x91,0xf5,0x38,0x03,0x7e,0xf5,0x3d,0x03,0x6a,0xf5,0x42,0x03,0x57,0xf5,0x47,0x03,0x44,0xf5,0x4d,0x03,0x31,0xf5,0x52,0x03,0x1e,0xf5,0x58,0x03,0x0b,0xf5,0x5d,0x03,0xf7,0xf4,  \
    0x63,0x03,0xe4,0xf4,0x68,0x03,0xd1,0xf4,0x6e,0x03,0xbe,0xf4,0x74,0x03,0xac,0xf4,0x7a,0x03,0x99,0xf4,0x80,0x03,0x86,0xf4,0x86,0x03,0x74,0xf4,0x8c,0x03,0x61,0xf4,0x92,0x03,0x4e,0xf4,0x98,0x03,0x3c,0xf4,0x9f,0x03,0x29,0xf4,0xa5,0x03,0x16,0xf4,0xab,0x03,0x03,0xf4,0xb2,0x03,0xf1,0xf3,0xb8,0x03,0xde,0xf3,0xbf,0x03,0xcb,0xf3,0xc5,0x03,0xb8,0xf3,0xcc,0x03,0xa5,0xf3,0xd2,0x03,0x92,0xf3,0xd9,0x03,0x7f,0xf3,0xdf,0x03,0x6c,0xf3,0xe6,0x03,0x59,0xf3,0xec,0x03,  \
    0x44,0xf3,0xf1,0x03,0x2e,0xf3,0xf7,0x03,0x19,0xf3,0xfc,0x03,0x03,0xf3,0x02,0x04,0xee,0xf2,0x07,0x04,0xd8,0xf2,0x0d,0x04,0xc2,0xf2,0x12,0x04,0xac,0xf2,0x18,0x04,0x97,0xf2,0x1d,0x04,0x81,0xf2,0x23,0x04,0x6b,0xf2,0x29,0x04,0x55,0xf2,0x2e,0x04,0x3f,0xf2,0x34,0x04,0x29,0xf2,0x39,0x04,0x13,0xf2,0x3f,0x04,0xfd,0xf1,0x45,0x04,0xe6,0xf1,0x4a,0x04,0xd0,0xf1,0x50,0x04,0xbb,0xf1,0x57,0x04,0xa6,0xf1,0x5e,0x04,0x92,0xf1,0x65,0x04,0x7e,0xf1,0x6c,0x04,0x6a,0xf1,  \
    0x73,0x04,0x55,0xf1,0x7a,0x04,0x41,0xf1,0x81,0x04,0x2c,0xf1,0x88,0x04,0x17,0xf1,0x8f,0x04,0x03,0xf1,0x96,0x04,0xee,0xf0,0x9d,0x04,0xd9,0xf0,0xa4,0x04,0xc4,0xf0,0xab,0x04,0xaf,0xf0,0xb2,0x04,0x99,0xf0,0xb9,0x04,0x84,0xf0,0xbf,0x04,0x6e,0xf0,0xc6,0x04,0x59,0xf0,0xcd,0x04,0x43,0xf0,0xd4,0x04,0x2e,0xf0,0xdb,0x04,0x18,0xf0,0xe2,0x04,0x02,0xf0,0xe9,0x04,0xed,0xef,0xf0,0x04,0xd7,0xef,0xf6,0x04,0xc0,0xef,0xfd,0x04,0xaa,0xef,0x04,0x05,0x94,0xef,0x0a,0x05,  \
    0x7d,0xef,0x11,0x05,0x67,0xef,0x18,0x05,0x50,0xef,0x1e,0x05,0x39,0xef,0x24,0x05,0x22,0xef,0x2b,0x05,0x0a,0xef,0x31,0x05,0xf3,0xee,0x37,0x05,0xdb,0xee,0x3d,0x05,0xc4,0xee,0x43,0x05,0xac,0xee,0x49,0x05,0x94,0xee,0x4e,0x05,0x7b,0xee,0x53,0x05,0x62,0xee,0x58,0x05,0x48,0xee,0x5c,0x05,0x2e,0xee,0x61,0x05,0x14,0xee,0x65,0x05,0xf9,0xed,0x69,0x05,0xdf,0xed,0x6d,0x05,0xc4,0xed,0x71,0x05,0xa9,0xed,0x75,0x05,0x8e,0xed,0x79,0x05,0x73,0xed,0x7c,0x05,0x58,0xed,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x06,0x33,0x12,0xfe,0x05,0x17,0x12,0xfa,0x05,0xfc,0x11,0xf5,0x05,0xe1,0x11,0xf1,0x05,0xc7,0x11,0xec,0x05,0xac,0x11,0xe7,0x05,0x92,0x11,0xe2,0x05,  \
    0x78,0x11,0xdd,0x05,0x5d,0x11,0xd8,0x05,0x44,0x11,0xd2,0x05,0x2a,0x11,0xcd,0x05,0x10,0x11,0xc7,0x05,0xf7,0x10,0xc2,0x05,0xdd,0x10,0xbc,0x05,0xc4,0x10,0xb6,0x05,0xab,0x10,0xb0,0x05,0x92,0x10,0xaa,0x05,0x79,0x10,0xa4,0x05,0x60,0x10,0x9e,0x05,0x48,0x10,0x97,0x05,0x30,0x10,0x91,0x05,0x18,0x10,0x8a,0x05,0x01,0x10,0x82,0x05,0xea,0x0f,0x7b,0x05,0xd3,0x0f,0x74,0x05,0xbc,0x0f,0x6d,0x05,0xa5,0x0f,0x65,0x05,0x8e,0x0f,0x5e,0x05,0x78,0x0f,0x57,0x05,0x61,0x0f,  \
    0x4f,0x05,0x4b,0x0f,0x47,0x05,0x35,0x0f,0x40,0x05,0x1f,0x0f,0x38,0x05,0x09,0x0f,0x31,0x05,0xf3,0x0e,0x29,0x05,0xde,0x0e,0x21,0x05,0xc8,0x0e,0x19,0x05,0xb3,0x0e,0x12,0x05,0x9d,0x0e,0x0a,0x05,0x88,0x0e,0x01,0x05,0x74,0x0e,0xf9,0x04,0x60,0x0e,0xf0,0x04,0x4c,0x0e,0xe7,0x04,0x39,0x0e,0xde,0x04,0x26,0x0e,0xd5,0x04,0x12,0x0e,0xcd,0x04,0xff,0x0d,0xc4,0x04,0xec,0x0d,0xbb,0x04,0xd9,0x0d,0xb2,0x04,0xc7,0x0d,0xa9,0x04,0xb4,0x0d,0xa0,0x04,0xa1,0x0d,0x97,0x04,  \
    0x8f,0x0d,0x8f,0x04,0x7d,0x0d,0x86,0x04,0x6a,0x0d,0x7d,0x04,0x58,0x0d,0x74,0x04,0x46,0x0d,0x6c,0x04,0x34,0x0d,0x65,0x04,0x1e,0x0d,0x5f,0x04,0x08,0x0d,0x59,0x04,0xf3,0x0c,0x52,0x04,0xdd,0x0c,0x4c,0x04,0xc7,0x0c,0x46,0x04,0xb2,0x0c,0x40,0x04,0x9c,0x0c,0x39,0x04,0x87,0x0c,0x33,0x04,0x71,0x0c,0x2d,0x04,0x5c,0x0c,0x27,0x04,0x47,0x0c,0x21,0x04,0x31,0x0c,0x1a,0x04,0x1c,0x0c,0x14,0x04,0x07,0x0c,0x0e,0x04,0xf2,0x0b,0x08,0x04,0xdd,0x0b,0x02,0x04,0xc7,0x0b,  \
    0xfc,0x03,0xb2,0x0b,0xf6,0x03,0x9d,0x0b,0xf0,0x03,0x88,0x0b,0xea,0x03,0x73,0x0b,0xe4,0x03,0x5e,0x0b,0xde,0x03,0x49,0x0b,0xd8,0x03,0x34,0x0b,0xd2,0x03,0x20,0x0b,0xcd,0x03,0x0b,0x0b,0xc7,0x03,0xf6,0x0a,0xc1,0x03,0xe1,0x0a,0xbb,0x03,0xcc,0x0a,0xb5,0x03,0xb8,0x0a,0xb0,0x03,0xa3,0x0a,0xaa,0x03,0x8f,0x0a,0xa4,0x03,0x7a,0x0a,0x9f,0x03,0x65,0x0a,0x99,0x03,0x51,0x0a,0x93,0x03,0x3d,0x0a,0x8c,0x03,0x2c,0x0a,0x85,0x03,0x1b,0x0a,0x7e,0x03,0x0a,0x0a,0x77,0x03,  \
    0xf9,0x09,0x70,0x03,0xe7,0x09,0x69,0x03,0xd6,0x09,0x62,0x03,0xc5,0x09,0x5b,0x03,0xb4,0x09,0x55,0x03,0xa3,0x09,0x4e,0x03,0x92,0x09,0x47,0x03,0x82,0x09,0x41,0x03,0x71,0x09,0x3a,0x03,0x60,0x09,0x34,0x03,0x4f,0x09,0x2e,0x03,0x3e,0x09,0x27,0x03,0x2d,0x09,0x21,0x03,0x1c,0x09,0x1b,0x03,0x0b,0x09,0x15,0x03,0xfa,0x08,0x0f,0x03,0xea,0x08,0x09,0x03,0xd8,0x08,0x03,0x03,0xc7,0x08,0xfe,0x02,0xb6,0x08,0xf8,0x02,0xa4,0x08,0xf2,0x02,0x93,0x08,0xed,0x02,0x81,0x08,  \
    0xe7,0x02,0x70,0x08,0xe2,0x02,0x5f,0x08,0xdd,0x02,0x4d,0x08,0xd7,0x02,0x3c,0x08,0xd2,0x02,0x2b,0x08,0xcd,0x02,0x19,0x08,0xc8,0x02,0x08,0x08,0xc3,0x02,0xf6,0x07,0xbe,0x02,0xe5,0x07,0xb9,0x02,0xd4,0x07,0xb4,0x02,0xc2,0x07,0xaf,0x02,0xb1,0x07,0xab,0x02,0x9f,0x07,0xa6,0x02,0x8e,0x07,0xa1,0x02,0x7d,0x07,0x9d,0x02,0x6b,0x07,0x98,0x02,0x5a,0x07,0x94,0x02,0x46,0x07,0x90,0x02,0x33,0x07,0x8c,0x02,0x20,0x07,0x89,0x02,0x0c,0x07,0x85,0x02,0xf9,0x06,0x81,0x02,  \
    0xe6,0x06,0x7d,0x02,0xd2,0x06,0x7a,0x02,0xbf,0x06,0x76,0x02,0xac,0x06,0x73,0x02,0x99,0x06,0x6f,0x02,0x85,0x06,0x6b,0x02,0x72,0x06,0x68,0x02,0x5f,0x06,0x64,0x02,0x4c,0x06,0x61,0x02,0x39,0x06,0x5e,0x02,0x25,0x06,0x5a,0x02,0x12,0x06,0x57,0x02,0xff,0x05,0x54,0x02,0xec,0x05,0x50,0x02,0xd9,0x05,0x4d,0x02,0xc6,0x05,0x4a,0x02,0xb3,0x05,0x47,0x02,0xa0,0x05,0x44,0x02,0x8d,0x05,0x40,0x02,0x7b,0x05,0x3d,0x02,0x6a,0x05,0x3a,0x02,0x58,0x05,0x36,0x02,0x46,0x05,  \
    0x33,0x02,0x34,0x05,0x30,0x02,0x22,0x05,0x2d,0x02,0x11,0x05,0x2a,0x02,0xff,0x04,0x27,0x02,0xed,0x04,0x24,0x02,0xdb,0x04,0x21,0x02,0xc9,0x04,0x1e,0x02,0xb8,0x04,0x1b,0x02,0xa6,0x04,0x19,0x02,0x94,0x04,0x16,0x02,0x82,0x04,0x13,0x02,0x70,0x04,0x10,0x02,0x5e,0x04,0x0e,0x02,0x4c,0x04,0x0b,0x02,0x3a,0x04,0x09,0x02,0x29,0x04,0x06,0x02,0x17,0x04,0x04,0x02,0x05,0x04,0x01,0x02,0xf3,0x03,0xff,0x01,0xe1,0x03,0xfd,0x01,0xcf,0x03,0xfb,0x01,0xbd,0x03,0xf8,0x01,  \
    0xac,0x03,0xf6,0x01,0x9b,0x03,0xf4,0x01,0x8a,0x03,0xf1,0x01,0x79,0x03,0xef,0x01,0x68,0x03,0xed,0x01,0x57,0x03,0xeb,0x01,0x46,0x03,0xe9,0x01,0x35,0x03,0xe7,0x01,0x24,0x03,0xe5,0x01,0x12,0x03,0xe3,0x01,0x01,0x03,0xe1,0x01,0xf0,0x02,0xe0,0x01,0xde,0x02,0xde,0x01,0xcd,0x02,0xdc,0x01,0xbb,0x02,0xdb,0x01,0xaa,0x02,0xd9,0x01,0x98,0x02,0xd8,0x01,0x87,0x02,0xd6,0x01,0x75,0x02,0xd5,0x01,0x63,0x02,0xd3,0x01,0x52,0x02,0xd2,0x01,0x40,0x02,0xd1,0x01,0x2e,0x02,  \
    0xd0,0x01,0x1c,0x02,0xce,0x01,0x0a,0x02,0xcd,0x01,0xf8,0x01,0xcc,0x01,0xe6,0x01,0xcb,0x01,0xd4,0x01,0xca,0x01,0xc1,0x01,0xc9,0x01,0xae,0x01,0xc8,0x01,0x9c,0x01,0xc7,0x01,0x89,0x01,0xc6,0x01,0x76,0x01,0xc6,0x01,0x64,0x01,0xc5,0x01,0x51,0x01,0xc4,0x01,0x3e,0x01,0xc3,0x01,0x2c,0x01,0xc3,0x01,0x19,0x01,0xc2,0x01,0x06,0x01,0xc2,0x01,0xf4,0x00,0xc1,0x01,0xe1,0x00,0xc0,0x01,0xce,0x00,0xc0,0x01,0xbb,0x00,0xc0,0x01,0xa9,0x00,0xbf,0x01,0x96,0x00,0xbf,0x01,  \
    0x83,0x00,0xbe,0x01,0x71,0x00,0xbe,0x01,0x5e,0x00,0xbe,0x01,0x4b,0x00,0xbe,0x01,0x38,0x00,0xbd,0x01,0x26,0x00,0xbd,0x01,0x13,0x00,0xbd,0x01,0x00,0x00,0xbd,0x01,0xed,0xff,0xbd,0x01,0xdb,0xff,0xbd,0x01,0xc8,0xff,0xbd,0x01,0xb5,0xff,0xbd,0x01,0xa3,0xff,0xbd,0x01,0x90,0xff,0xbd,0x01,0x7d,0xff,0xbd,0x01,0x6a,0xff,0xbd,0x01,0x58,0xff,0xbe,0x01,0x45,0xff,0xbe,0x01,0x32,0xff,0xbe,0x01,0x20,0xff,0xbe,0x01,0x0d,0xff,0xbf,0x01,0xfa,0xfe,0xbf,0x01,0xe7,0xfe,  \
    0xc0,0x01,0xd5,0xfe,0xc0,0x01,0xc2,0xfe,0xc0,0x01,0xaf,0xfe,0xc1,0x01,0x9d,0xfe,0xc2,0x01,0x8a,0xfe,0xc2,0x01,0x77,0xfe,0xc3,0x01,0x65,0xfe,0xc3,0x01,0x52,0xfe,0xc4,0x01,0x3f,0xfe,0xc5,0x01,0x2d,0xfe,0xc6,0x01,0x1a,0xfe,0xc6,0x01,0x07,0xfe,0xc7,0x01,0xf5,0xfd,0xc8,0x01,0xe2,0xfd,0xc9,0x01,0xcf,0xfd,0xca,0x01,0xbc,0xfd,0xcb,0x01,0xa9,0xfd,0xcc,0x01,0x96,0xfd,0xcd,0x01,0x84,0xfd,0xce,0x01,0x71,0xfd,0xcf,0x01,0x5d,0xfd,0xd0,0x01,0x4a,0xfd,0xd1,0x01,  \
    0x37,0xfd,0xd2,0x01,0x24,0xfd,0xd4,0x01,0x11,0xfd,0xd5,0x01,0xfe,0xfc,0xd6,0x01,0xeb,0xfc,0xd7,0x01,0xd8,0xfc,0xd9,0x01,0xc5,0xfc,0xda,0x01,0xb2,0xfc,0xdb,0x01,0x9e,0xfc,0xdd,0x01,0x8b,0xfc,0xde,0x01,0x78,0xfc,0xe0,0x01,0x65,0xfc,0xe1,0x01,0x52,0xfc,0xe3,0x01,0x3e,0xfc,0xe4,0x01,0x2b,0xfc,0xe6,0x01,0x18,0xfc,0xe8,0x01,0x05,0xfc,0xe9,0x01,0xf1,0xfb,0xeb,0x01,0xde,0xfb,0xed,0x01,0xcb,0xfb,0xee,0x01,0xb7,0xfb,0xf0,0x01,0xa5,0xfb,0xf2,0x01,0x93,0xfb,  \
    0xf4,0x01,0x80,0xfb,0xf6,0x01,0x6e,0xfb,0xf8,0x01,0x5c,0xfb,0xfb,0x01,0x4a,0xfb,0xfd,0x01,0x37,0xfb,0xff,0x01,0x25,0xfb,0x01,0x02,0x13,0xfb,0x04,0x02,0x01,0xfb,0x06,0x02,0xee,0xfa,0x08,0x02,0xdc,0xfa,0x0b,0x02,0xca,0xfa,0x0d,0x02,0xb8,0xfa,0x10,0x02,0xa6,0xfa,0x12,0x02,0x94,0xfa,0x15,0x02,0x82,0xfa,0x17,0x02,0x70,0xfa,0x1a,0x02,0x5e,0xfa,0x1d,0x02,0x4c,0xfa,0x20,0x02,0x3a,0xfa,0x22,0x02,0x28,0xfa,0x25,0x02,0x16,0xfa,0x28,0x02,0x04,0xfa,0x2b,0x02,  \
    0xf2,0xf9,0x2e,0x02,0xe0,0xf9,0x31,0x02,0xce,0xf9,0x34,0x02,0xbb,0xf9,0x37,0x02,0xa8,0xf9,0x3a,0x02,0x96,0xf9,0x3d,0x02,0x83,0xf9,0x40,0x02,0x70,0xf9,0x43,0x02,0x5d,0xf9,0x46,0x02,0x4a,0xf9,0x49,0x02,0x38,0xf9,0x4d,0x02,0x25,0xf9,0x50,0x02,0x12,0xf9,0x53,0x02,0xff,0xf8,0x56,0x02,0xec,0xf8,0x5a,0x02,0xda,0xf8,0x5d,0x02,0xc7,0xf8,0x61,0x02,0xb4,0xf8,0x64,0x02,0xa1,0xf8,0x68,0x02,0x8f,0xf8,0x6b,0x02,0x7c,0xf8,0x6f,0x02,0x69,0xf8,0x72,0x02,0x56,0xf8,  \
    0x76,0x02,0x43,0xf8,0x7a,0x02,0x31,0xf8,0x7d,0x02,0x1e,0xf8,0x81,0x02,0x0b,0xf8,0x85,0x02,0xf9,0xf7,0x89,0x02,0xe7,0xf7,0x8d,0x02,0xd4,0xf7,0x91,0x02,0xc2,0xf7,0x96,0x02,0xb0,0xf7,0x9a,0x02,0x9e,0xf7,0x9e,0x02,0x8c,0xf7,0xa2,0x02,0x7a,0xf7,0xa7,0x02,0x68,0xf7,0xab,0x02,0x56,0xf7,0xb0,0x02,0x44,0xf7,0xb4,0x02,0x31,0xf7,0xb9,0x02,0x1f,0xf7,0xbd,0x02,0x0d,0xf7,0xc2,0x02,0xfb,0xf6,0xc7,0x02,0xe9,0xf6,0xcc,0x02,0xd7,0xf6,0xd0,0x02,0xc5,0xf6,0xd5,0x02,  \
    0xb3,0xf6,0xda,0x02,0xa1,0xf6,0xdf,0x02,0x8f,0xf6,0xe4,0x02,0x7d,0xf6,0xe9,0x02,0x6b,0xf6,0xee,0x02,0x58,0xf6,0xf3,0x02,0x45,0xf6,0xf8,0x02,0x32,0xf6,0xfd,0x02,0x1f,0xf6,0x02,0x03,0x0c,0xf6,0x07,0x03,0xf9,0xf5,0x0c,0x03,0xe6,0xf5,0x11,0x03,0xd3,0xf5,0x16,0x03,0xc0,0xf5,0x1b,0x03,0xad,0xf5,0x20,0x03,0x9a,0xf5,0x25,0x03,0x87,0xf5,0x2b,0x03,0x74,0xf5,0x30,0x03,0x60,0xf5,0x35,0x03,0x4d,0xf5,0x3b,0x03,0x3a,0xf5,0x40,0x03,0x27,0xf5,0x46,0x03,0x14,0xf5,  \
    0x4b,0x03,0x01,0xf5,0x51,0x03,0xee,0xf4,0x56,0x03,0xda,0xf4,0x5c,0x03,0xc7,0xf4,0x62,0x03,0xb5,0xf4,0x68,0x03,0xa2,0xf4,0x6e,0x03,0x90,0xf4,0x74,0x03,0x7d,0xf4,0x7a,0x03,0x6a,0xf4,0x80,0x03,0x58,0xf4,0x87,0x03,0x45,0xf4,0x8d,0x03,0x32,0xf4,0x93,0x03,0x20,0xf4,0x99,0x03,0x0d,0xf4,0xa0,0x03,0xfa,0xf3,0xa6,0x03,0xe7,0xf3,0xad,0x03,0xd4,0xf3,0xb3,0x03,0xc2,0xf3,0xba,0x03,0xaf,0xf3,0xc0,0x03,0x9c,0xf3,0xc7,0x03,0x89,0xf3,0xcd,0x03,0x76,0xf3,0xd4,0x03,  \
    0x62,0xf3,0xda,0x03,0x4d,0xf3,0xdf,0x03,0x38,0xf3,0xe5,0x03,0x22,0xf3,0xea,0x03,0x0d,0xf3,0xf0,0x03,0xf7,0xf2,0xf5,0x03,0xe2,0xf2,0xfb,0x03,0xcc,0xf2,0x01,0x04,0xb6,0xf2,0x06,0x04,0xa0,0xf2,0x0c,0x04,0x8b,0xf2,0x11,0x04,0x75,0xf2,0x17,0x04,0x5f,0xf2,0x1d,0x04,0x49,0xf2,0x22,0x04,0x33,0xf2,0x28,0x04,0x1d,0xf2,0x2e,0x04,0x07,0xf2,0x33,0x04,0xf0,0xf1,0x39,0x04,0xda,0xf1,0x3f,0x04,0xc5,0xf1,0x46,0x04,0xb0,0xf1,0x4d,0x04,0x9c,0xf1,0x54,0x04,0x88,0xf1,  \
    0x5b,0x04,0x74,0xf1,0x62,0x04,0x5f,0xf1,0x69,0x04,0x4b,0xf1,0x70,0x04,0x36,0xf1,0x77,0x04,0x21,0xf1,0x7e,0x04,0x0c,0xf1,0x84,0x04,0xf8,0xf0,0x8b,0x04,0xe3,0xf0,0x92,0x04,0xcd,0xf0,0x99,0x04,0xb8,0xf0,0xa0,0x04,0xa3,0xf0,0xa7,0x04,0x8d,0xf0,0xae,0x04,0x78,0xf0,0xb4,0x04,0x62,0xf0,0xbb,0x04,0x4d,0xf0,0xc2,0x04,0x37,0xf0,0xc9,0x04,0x21,0xf0,0xd0,0x04,0x0c,0xf0,0xd7,0x04,0xf6,0xef,0xde,0x04,0xe0,0xef,0xe4,0x04,0xca,0xef,0xeb,0x04,0xb3,0xef,0xf2,0x04,  \
    0x9d,0xef,0xf8,0x04,0x86,0xef,0xff,0x04,0x70,0xef,0x05,0x05,0x59,0xef,0x0c,0x05,0x42,0xef,0x12,0x05,0x2b,0xef,0x18,0x05,0x13,0xef,0x1e,0x05,0xfc,0xee,0x24,0x05,0xe4,0xee,0x2a,0x05,0xcc,0xee,0x30,0x05,0xb4,0xee,0x36,0x05,0x9c,0xee,0x3c,0x05,0x84,0xee,0x41,0x05,0x6b,0xee,0x45,0x05,0x51,0xee,0x4a,0x05,0x37,0xee,0x4e,0x05,0x1c,0xee,0x52,0x05,0x02,0xee,0x56,0x05,0xe7,0xed,0x5a,0x05,0xcd,0xed,0x5e,0x05,0xb2,0xed,0x62,0x05,0x97,0xed,0x66,0x05,0x7c,0xed,  \
    0x69,0x05,0x60,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xef,0x05,0x2c,0x12,0xeb,0x05,0x11,0x12,0xe6,0x05,0xf6,0x11,0xe2,0x05,0xdb,0x11,0xdd,0x05,0xc0,0x11,0xd8,0x05,0xa5,0x11,0xd3,0x05,  \
    0x8b,0x11,0xce,0x05,0x71,0x11,0xc9,0x05,0x57,0x11,0xc4,0x05,0x3d,0x11,0xbf,0x05,0x23,0x11,0xb9,0x05,0x09,0x11,0xb4,0x05,0xf0,0x10,0xae,0x05,0xd6,0x10,0xa9,0x05,0xbd,0x10,0xa3,0x05,0xa4,0x10,0x9d,0x05,0x8b,0x10,0x97,0x05,0x72,0x10,0x91,0x05,0x59,0x10,0x8b,0x05,0x41,0x10,0x84,0x05,0x29,0x10,0x7e,0x05,0x11,0x10,0x77,0x05,0xfa,0x0f,0x70,0x05,0xe3,0x0f,0x68,0x05,0xcb,0x0f,0x61,0x05,0xb5,0x0f,0x5a,0x05,0x9e,0x0f,0x53,0x05,0x87,0x0f,0x4b,0x05,0x70,0x0f,  \
    0x44,0x05,0x5a,0x0f,0x3c,0x05,0x44,0x0f,0x35,0x05,0x2e,0x0f,0x2d,0x05,0x17,0x0f,0x26,0x05,0x02,0x0f,0x1e,0x05,0xec,0x0e,0x16,0x05,0xd6,0x0e,0x0f,0x05,0xc0,0x0e,0x07,0x05,0xab,0x0e,0xff,0x04,0x96,0x0e,0xf7,0x04,0x80,0x0e,0xef,0x04,0x6c,0x0e,0xe6,0x04,0x58,0x0e,0xde,0x04,0x44,0x0e,0xd5,0x04,0x31,0x0e,0xcc,0x04,0x1d,0x0e,0xc3,0x04,0x0a,0x0e,0xba,0x04,0xf7,0x0d,0xb2,0x04,0xe4,0x0d,0xa9,0x04,0xd1,0x0d,0xa0,0x04,0xbe,0x0d,0x97,0x04,0xab,0x0d,0x8e,0x04,  \
    0x99,0x0d,0x86,0x04,0x86,0x0d,0x7d,0x04,0x74,0x0d,0x74,0x04,0x62,0x0d,0x6b,0x04,0x50,0x0d,0x62,0x04,0x3d,0x0d,0x5a,0x04,0x2b,0x0d,0x54,0x04,0x15,0x0d,0x4d,0x04,0xff,0x0c,0x47,0x04,0xea,0x0c,0x41,0x04,0xd4,0x0c,0x3a,0x04,0xbe,0x0c,0x34,0x04,0xa9,0x0c,0x2e,0x04,0x93,0x0c,0x28,0x04,0x7e,0x0c,0x21,0x04,0x69,0x0c,0x1b,0x04,0x53,0x0c,0x15,0x04,0x3e,0x0c,0x0f,0x04,0x29,0x0c,0x09,0x04,0x13,0x0c,0x02,0x04,0xfe,0x0b,0xfc,0x03,0xe9,0x0b,0xf6,0x03,0xd4,0x0b,  \
    0xf0,0x03,0xbf,0x0b,0xea,0x03,0xaa,0x0b,0xe4,0x03,0x95,0x0b,0xde,0x03,0x80,0x0b,0xd8,0x03,0x6b,0x0b,0xd2,0x03,0x56,0x0b,0xcc,0x03,0x41,0x0b,0xc6,0x03,0x2c,0x0b,0xc0,0x03,0x17,0x0b,0xba,0x03,0x03,0x0b,0xb5,0x03,0xee,0x0a,0xaf,0x03,0xd9,0x0a,0xa9,0x03,0xc5,0x0a,0xa3,0x03,0xb0,0x0a,0x9d,0x03,0x9b,0x0a,0x98,0x03,0x87,0x0a,0x92,0x03,0x72,0x0a,0x8c,0x03,0x5e,0x0a,0x87,0x03,0x49,0x0a,0x81,0x03,0x35,0x0a,0x7a,0x03,0x24,0x0a,0x73,0x03,0x13,0x0a,0x6c,0x03,  \
    0x02,0x0a,0x65,0x03,0xf1,0x09,0x5e,0x03,0xe0,0x09,0x57,0x03,0xcf,0x09,0x50,0x03,0xbe,0x09,0x49,0x03,0xad,0x09,0x42,0x03,0x9c,0x09,0x3c,0x03,0x8b,0x09,0x35,0x03,0x7a,0x09,0x2f,0x03,0x69,0x09,0x28,0x03,0x58,0x09,0x22,0x03,0x47,0x09,0x1b,0x03,0x36,0x09,0x15,0x03,0x25,0x09,0x0f,0x03,0x14,0x09,0x09,0x03,0x04,0x09,0x03,0x03,0xf3,0x08,0xfd,0x02,0xe2,0x08,0xf7,0x02,0xd1,0x08,0xf1,0x02,0xbf,0x08,0xeb,0x02,0xae,0x08,0xe6,0x02,0x9d,0x08,0xe0,0x02,0x8b,0x08,  \
    0xdb,0x02,0x7a,0x08,0xd5,0x02,0x69,0x08,0xd0,0x02,0x57,0x08,0xca,0x02,0x46,0x08,0xc5,0x02,0x35,0x08,0xc0,0x02,0x23,0x08,0xbb,0x02,0x12,0x08,0xb6,0x02,0x01,0x08,0xb1,0x02,0xef,0x07,0xac,0x02,0xde,0x07,0xa7,0x02,0xcc,0x07,0xa2,0x02,0xbb,0x07,0x9d,0x02,0xaa,0x07,0x98,0x02,0x98,0x07,0x93,0x02,0x87,0x07,0x8f,0x02,0x76,0x07,0x8a,0x02,0x64,0x07,0x86,0x02,0x53,0x07,0x82,0x02,0x3f,0x07,0x7e,0x02,0x2c,0x07,0x7a,0x02,0x19,0x07,0x76,0x02,0x06,0x07,0x72,0x02,  \
    0xf2,0x06,0x6f,0x02,0xdf,0x06,0x6b,0x02,0xcc,0x06,0x67,0x02,0xb9,0x06,0x63,0x02,0xa5,0x06,0x60,0x02,0x92,0x06,0x5c,0x02,0x7f,0x06,0x59,0x02,0x6c,0x06,0x55,0x02,0x59,0x06,0x52,0x02,0x46,0x06,0x4e,0x02,0x33,0x06,0x4b,0x02,0x20,0x06,0x47,0x02,0x0c,0x06,0x44,0x02,0xf9,0x05,0x41,0x02,0xe6,0x05,0x3e,0x02,0xd3,0x05,0x3a,0x02,0xc0,0x05,0x37,0x02,0xad,0x05,0x34,0x02,0x9a,0x05,0x31,0x02,0x88,0x05,0x2d,0x02,0x76,0x05,0x2a,0x02,0x64,0x05,0x27,0x02,0x53,0x05,  \
    0x23,0x02,0x41,0x05,0x20,0x02,0x2f,0x05,0x1d,0x02,0x1d,0x05,0x1a,0x02,0x0c,0x05,0x17,0x02,0xfa,0x04,0x14,0x02,0xe8,0x04,0x11,0x02,0xd6,0x04,0x0e,0x02,0xc5,0x04,0x0b,0x02,0xb3,0x04,0x08,0x02,0xa1,0x04,0x05,0x02,0x8f,0x04,0x03,0x02,0x7d,0x04,0x00,0x02,0x6c,0x04,0xfd,0x01,0x5a,0x04,0xfb,0x01,0x48,0x04,0xf8,0x01,0x36,0x04,0xf6,0x01,0x24,0x04,0xf3,0x01,0x13,0x04,0xf1,0x01,0x01,0x04,0xee,0x01,0xef,0x03,0xec,0x01,0xdd,0x03,0xea,0x01,0xcb,0x03,0xe7,0x01,  \
    0xb9,0x03,0xe5,0x01,0xa9,0x03,0xe3,0x01,0x98,0x03,0xe0,0x01,0x87,0x03,0xde,0x01,0x76,0x03,0xdc,0x01,0x65,0x03,0xda,0x01,0x54,0x03,0xd8,0x01,0x42,0x03,0xd6,0x01,0x31,0x03,0xd4,0x01,0x20,0x03,0xd2,0x01,0x0f,0x03,0xd0,0x01,0xfe,0x02,0xce,0x01,0xec,0x02,0xcc,0x01,0xdb,0x02,0xcb,0x01,0xca,0x02,0xc9,0x01,0xb8,0x02,0xc7,0x01,0xa7,0x02,0xc6,0x01,0x95,0x02,0xc4,0x01,0x84,0x02,0xc3,0x01,0x72,0x02,0xc1,0x01,0x61,0x02,0xc0,0x01,0x4f,0x02,0xbf,0x01,0x3d,0x02,  \
    0xbd,0x01,0x2c,0x02,0xbc,0x01,0x1a,0x02,0xbb,0x01,0x08,0x02,0xba,0x01,0xf6,0x01,0xb9,0x01,0xe4,0x01,0xb8,0x01,0xd2,0x01,0xb7,0x01,0xbf,0x01,0xb6,0x01,0xac,0x01,0xb5,0x01,0x9a,0x01,0xb4,0x01,0x87,0x01,0xb3,0x01,0x75,0x01,0xb2,0x01,0x62,0x01,0xb1,0x01,0x4f,0x01,0xb1,0x01,0x3d,0x01,0xb0,0x01,0x2a,0x01,0xaf,0x01,0x18,0x01,0xaf,0x01,0x05,0x01,0xae,0x01,0xf2,0x00,0xad,0x01,0xe0,0x00,0xad,0x01,0xcd,0x00,0xac,0x01,0xba,0x00,0xac,0x01,0xa8,0x00,0xac,0x01,  \
    0x95,0x00,0xab,0x01,0x82,0x00,0xab,0x01,0x70,0x00,0xab,0x01,0x5d,0x00,0xaa,0x01,0x4b,0x00,0xaa,0x01,0x38,0x00,0xaa,0x01,0x25,0x00,0xaa,0x01,0x13,0x00,0xaa,0x01,0x00,0x00,0xa9,0x01,0xed,0xff,0xa9,0x01,0xdb,0xff,0xa9,0x01,0xc8,0xff,0xa9,0x01,0xb5,0xff,0xa9,0x01,0xa3,0xff,0xa9,0x01,0x90,0xff,0xaa,0x01,0x7d,0xff,0xaa,0x01,0x6b,0xff,0xaa,0x01,0x58,0xff,0xaa,0x01,0x46,0xff,0xaa,0x01,0x33,0xff,0xab,0x01,0x20,0xff,0xab,0x01,0x0e,0xff,0xab,0x01,0xfb,0xfe,  \
    0xac,0x01,0xe8,0xfe,0xac,0x01,0xd6,0xfe,0xad,0x01,0xc3,0xfe,0xad,0x01,0xb0,0xfe,0xae,0x01,0x9e,0xfe,0xae,0x01,0x8b,0xfe,0xaf,0x01,0x79,0xfe,0xaf,0x01,0x66,0xfe,0xb0,0x01,0x53,0xfe,0xb1,0x01,0x41,0xfe,0xb1,0x01,0x2e,0xfe,0xb2,0x01,0x1c,0xfe,0xb3,0x01,0x09,0xfe,0xb4,0x01,0xf7,0xfd,0xb5,0x01,0xe4,0xfd,0xb6,0x01,0xd1,0xfd,0xb6,0x01,0xbf,0xfd,0xb7,0x01,0xac,0xfd,0xb8,0x01,0x99,0xfd,0xb9,0x01,0x86,0xfd,0xba,0x01,0x73,0xfd,0xbc,0x01,0x60,0xfd,0xbd,0x01,  \
    0x4d,0xfd,0xbe,0x01,0x3a,0xfd,0xbf,0x01,0x27,0xfd,0xc0,0x01,0x14,0xfd,0xc1,0x01,0x01,0xfd,0xc3,0x01,0xee,0xfc,0xc4,0x01,0xdb,0xfc,0xc5,0x01,0xc8,0xfc,0xc7,0x01,0xb5,0xfc,0xc8,0x01,0xa2,0xfc,0xc9,0x01,0x8f,0xfc,0xcb,0x01,0x7c,0xfc,0xcc,0x01,0x68,0xfc,0xce,0x01,0x55,0xfc,0xd0,0x01,0x42,0xfc,0xd1,0x01,0x2f,0xfc,0xd3,0x01,0x1c,0xfc,0xd4,0x01,0x09,0xfc,0xd6,0x01,0xf5,0xfb,0xd8,0x01,0xe2,0xfb,0xd9,0x01,0xcf,0xfb,0xdb,0x01,0xbc,0xfb,0xdd,0x01,0xaa,0xfb,  \
    0xdf,0x01,0x97,0xfb,0xe1,0x01,0x85,0xfb,0xe3,0x01,0x73,0xfb,0xe5,0x01,0x60,0xfb,0xe7,0x01,0x4e,0xfb,0xea,0x01,0x3c,0xfb,0xec,0x01,0x2a,0xfb,0xee,0x01,0x18,0xfb,0xf0,0x01,0x06,0xfb,0xf3,0x01,0xf4,0xfa,0xf5,0x01,0xe1,0xfa,0xf8,0x01,0xcf,0xfa,0xfa,0x01,0xbd,0xfa,0xfd,0x01,0xab,0xfa,0xff,0x01,0x99,0xfa,0x02,0x02,0x87,0xfa,0x04,0x02,0x75,0xfa,0x07,0x02,0x63,0xfa,0x0a,0x02,0x51,0xfa,0x0d,0x02,0x40,0xfa,0x0f,0x02,0x2e,0xfa,0x12,0x02,0x1c,0xfa,0x15,0x02,  \
    0x0a,0xfa,0x18,0x02,0xf8,0xf9,0x1b,0x02,0xe6,0xf9,0x1e,0x02,0xd4,0xf9,0x21,0x02,0xc1,0xf9,0x24,0x02,0xae,0xf9,0x27,0x02,0x9c,0xf9,0x2a,0x02,0x89,0xf9,0x2d,0x02,0x76,0xf9,0x30,0x02,0x64,0xf9,0x33,0x02,0x51,0xf9,0x37,0x02,0x3e,0xf9,0x3a,0x02,0x2b,0xf9,0x3d,0x02,0x19,0xf9,0x40,0x02,0x06,0xf9,0x44,0x02,0xf3,0xf8,0x47,0x02,0xe1,0xf8,0x4a,0x02,0xce,0xf8,0x4e,0x02,0xbb,0xf8,0x51,0x02,0xa8,0xf8,0x55,0x02,0x96,0xf8,0x58,0x02,0x83,0xf8,0x5c,0x02,0x70,0xf8,  \
    0x60,0x02,0x5e,0xf8,0x63,0x02,0x4b,0xf8,0x67,0x02,0x38,0xf8,0x6b,0x02,0x25,0xf8,0x6f,0x02,0x13,0xf8,0x73,0x02,0x00,0xf8,0x77,0x02,0xee,0xf7,0x7b,0x02,0xdc,0xf7,0x7f,0x02,0xca,0xf7,0x83,0x02,0xb8,0xf7,0x87,0x02,0xa6,0xf7,0x8c,0x02,0x94,0xf7,0x90,0x02,0x82,0xf7,0x94,0x02,0x70,0xf7,0x99,0x02,0x5e,0xf7,0x9d,0x02,0x4c,0xf7,0xa2,0x02,0x39,0xf7,0xa6,0x02,0x27,0xf7,0xab,0x02,0x15,0xf7,0xb0,0x02,0x03,0xf7,0xb4,0x02,0xf1,0xf6,0xb9,0x02,0xdf,0xf6,0xbe,0x02,  \
    0xcd,0xf6,0xc3,0x02,0xbb,0xf6,0xc8,0x02,0xa9,0xf6,0xcd,0x02,0x97,0xf6,0xd2,0x02,0x85,0xf6,0xd7,0x02,0x73,0xf6,0xdc,0x02,0x60,0xf6,0xe1,0x02,0x4d,0xf6,0xe5,0x02,0x3a,0xf6,0xea,0x02,0x27,0xf6,0xef,0x02,0x15,0xf6,0xf4,0x02,0x02,0xf6,0xf9,0x02,0xef,0xf5,0xfe,0x02,0xdc,0xf5,0x03,0x03,0xc9,0xf5,0x09,0x03,0xb6,0xf5,0x0e,0x03,0xa2,0xf5,0x13,0x03,0x8f,0xf5,0x18,0x03,0x7c,0xf5,0x1e,0x03,0x69,0xf5,0x23,0x03,0x56,0xf5,0x28,0x03,0x43,0xf5,0x2e,0x03,0x30,0xf5,  \
    0x33,0x03,0x1d,0xf5,0x39,0x03,0x0a,0xf5,0x3e,0x03,0xf7,0xf4,0x44,0x03,0xe3,0xf4,0x4a,0x03,0xd1,0xf4,0x50,0x03,0xbe,0xf4,0x56,0x03,0xab,0xf4,0x5c,0x03,0x99,0xf4,0x62,0x03,0x86,0xf4,0x68,0x03,0x74,0xf4,0x6e,0x03,0x61,0xf4,0x74,0x03,0x4e,0xf4,0x7b,0x03,0x3c,0xf4,0x81,0x03,0x29,0xf4,0x87,0x03,0x16,0xf4,0x8e,0x03,0x03,0xf4,0x94,0x03,0xf0,0xf3,0x9a,0x03,0xde,0xf3,0xa1,0x03,0xcb,0xf3,0xa7,0x03,0xb8,0xf3,0xae,0x03,0xa5,0xf3,0xb4,0x03,0x92,0xf3,0xbb,0x03,  \
    0x7f,0xf3,0xc2,0x03,0x6c,0xf3,0xc7,0x03,0x56,0xf3,0xcd,0x03,0x41,0xf3,0xd2,0x03,0x2b,0xf3,0xd8,0x03,0x16,0xf3,0xde,0x03,0x00,0xf3,0xe3,0x03,0xeb,0xf2,0xe9,0x03,0xd5,0xf2,0xee,0x03,0xbf,0xf2,0xf4,0x03,0xaa,0xf2,0xf9,0x03,0x94,0xf2,0xff,0x03,0x7e,0xf2,0x05,0x04,0x68,0xf2,0x0a,0x04,0x52,0xf2,0x10,0x04,0x3c,0xf2,0x16,0x04,0x26,0xf2,0x1b,0x04,0x10,0xf2,0x21,0x04,0xfa,0xf1,0x27,0x04,0xe4,0xf1,0x2d,0x04,0xce,0xf1,0x34,0x04,0xba,0xf1,0x3a,0x04,0xa6,0xf1,  \
    0x41,0x04,0x91,0xf1,0x48,0x04,0x7d,0xf1,0x4f,0x04,0x68,0xf1,0x56,0x04,0x54,0xf1,0x5d,0x04,0x3f,0xf1,0x64,0x04,0x2a,0xf1,0x6b,0x04,0x16,0xf1,0x72,0x04,0x01,0xf1,0x79,0x04,0xec,0xf0,0x80,0x04,0xd6,0xf0,0x86,0x04,0xc1,0xf0,0x8d,0x04,0xac,0xf0,0x94,0x04,0x96,0xf0,0x9b,0x04,0x81,0xf0,0xa2,0x04,0x6b,0xf0,0xa8,0x04,0x55,0xf0,0xaf,0x04,0x40,0xf0,0xb6,0x04,0x2a,0xf0,0xbd,0x04,0x14,0xf0,0xc4,0x04,0xfe,0xef,0xca,0x04,0xe8,0xef,0xd1,0x04,0xd2,0xef,0xd8,0x04,  \
    0xbc,0xef,0xde,0x04,0xa5,0xef,0xe5,0x04,0x8f,0xef,0xeb,0x04,0x78,0xef,0xf2,0x04,0x61,0xef,0xf8,0x04,0x4a,0xef,0xfe,0x04,0x33,0xef,0x05,0x05,0x1b,0xef,0x0b,0x05,0x04,0xef,0x11,0x05,0xec,0xee,0x17,0x05,0xd4,0xee,0x1c,0x05,0xbc,0xee,0x22,0x05,0xa4,0xee,0x28,0x05,0x8b,0xee,0x2d,0x05,0x72,0xee,0x31,0x05,0x58,0xee,0x36,0x05,0x3e,0xee,0x3a,0x05,0x24,0xee,0x3e,0x05,0x09,0xee,0x42,0x05,0xef,0xed,0x46,0x05,0xd4,0xed,0x4a,0x05,0xb9,0xed,0x4e,0x05,0x9e,0xed,  \
    0x52,0x05,0x83,0xed,0x55,0x05,0x68,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xdc,0x05,0x25,0x12,0xd7,0x05,0x0a,0x12,0xd3,0x05,0xef,0x11,0xcf,0x05,0xd4,0x11,0xca,0x05,0xb9,0x11,0xc5,0x05,  \
    0x9f,0x11,0xc0,0x05,0x84,0x11,0xbb,0x05,0x6a,0x11,0xb6,0x05,0x50,0x11,0xb1,0x05,0x36,0x11,0xac,0x05,0x1c,0x11,0xa6,0x05,0x02,0x11,0xa1,0x05,0xe9,0x10,0x9b,0x05,0xcf,0x10,0x96,0x05,0xb6,0x10,0x90,0x05,0x9d,0x10,0x8a,0x05,0x84,0x10,0x84,0x05,0x6b,0x10,0x7e,0x05,0x52,0x10,0x78,0x05,0x3a,0x10,0x72,0x05,0x21,0x10,0x6b,0x05,0x0a,0x10,0x64,0x05,0xf3,0x0f,0x5d,0x05,0xdb,0x0f,0x56,0x05,0xc4,0x0f,0x4f,0x05,0xad,0x0f,0x47,0x05,0x96,0x0f,0x40,0x05,0x7f,0x0f,  \
    0x39,0x05,0x69,0x0f,0x31,0x05,0x52,0x0f,0x2a,0x05,0x3c,0x0f,0x23,0x05,0x26,0x0f,0x1b,0x05,0x10,0x0f,0x13,0x05,0xfa,0x0e,0x0c,0x05,0xe4,0x0e,0x04,0x05,0xce,0x0e,0xfd,0x04,0xb9,0x0e,0xf5,0x04,0xa3,0x0e,0xed,0x04,0x8e,0x0e,0xe5,0x04,0x78,0x0e,0xdd,0x04,0x64,0x0e,0xd4,0x04,0x50,0x0e,0xcc,0x04,0x3c,0x0e,0xc3,0x04,0x29,0x0e,0xba,0x04,0x15,0x0e,0xb2,0x04,0x02,0x0e,0xa9,0x04,0xef,0x0d,0xa0,0x04,0xdb,0x0d,0x97,0x04,0xc8,0x0d,0x8e,0x04,0xb6,0x0d,0x86,0x04,  \
    0xa3,0x0d,0x7d,0x04,0x90,0x0d,0x74,0x04,0x7e,0x0d,0x6b,0x04,0x6b,0x0d,0x63,0x04,0x59,0x0d,0x5a,0x04,0x47,0x0d,0x51,0x04,0x34,0x0d,0x49,0x04,0x22,0x0d,0x42,0x04,0x0c,0x0d,0x3c,0x04,0xf6,0x0c,0x36,0x04,0xe1,0x0c,0x2f,0x04,0xcb,0x0c,0x29,0x04,0xb6,0x0c,0x23,0x04,0xa0,0x0c,0x1d,0x04,0x8b,0x0c,0x16,0x04,0x75,0x0c,0x10,0x04,0x60,0x0c,0x0a,0x04,0x4a,0x0c,0x04,0x04,0x35,0x0c,0xfd,0x03,0x20,0x0c,0xf7,0x03,0x0b,0x0c,0xf1,0x03,0xf6,0x0b,0xeb,0x03,0xe0,0x0b,  \
    0xe5,0x03,0xcb,0x0b,0xdf,0x03,0xb6,0x0b,0xd9,0x03,0xa1,0x0b,0xd2,0x03,0x8c,0x0b,0xcc,0x03,0x77,0x0b,0xc6,0x03,0x62,0x0b,0xc0,0x03,0x4e,0x0b,0xbb,0x03,0x39,0x0b,0xb5,0x03,0x24,0x0b,0xaf,0x03,0x0f,0x0b,0xa9,0x03,0xfa,0x0a,0xa3,0x03,0xe6,0x0a,0x9d,0x03,0xd1,0x0a,0x97,0x03,0xbc,0x0a,0x91,0x03,0xa8,0x0a,0x8c,0x03,0x93,0x0a,0x86,0x03,0x7f,0x0a,0x80,0x03,0x6a,0x0a,0x7b,0x03,0x56,0x0a,0x75,0x03,0x41,0x0a,0x6f,0x03,0x2d,0x0a,0x68,0x03,0x1c,0x0a,0x61,0x03,  \
    0x0b,0x0a,0x5a,0x03,0xfa,0x09,0x53,0x03,0xe9,0x09,0x4c,0x03,0xd8,0x09,0x45,0x03,0xc7,0x09,0x3e,0x03,0xb6,0x09,0x37,0x03,0xa5,0x09,0x31,0x03,0x94,0x09,0x2a,0x03,0x83,0x09,0x23,0x03,0x72,0x09,0x1d,0x03,0x61,0x09,0x16,0x03,0x50,0x09,0x10,0x03,0x3f,0x09,0x0a,0x03,0x2e,0x09,0x03,0x03,0x1d,0x09,0xfd,0x02,0x0d,0x09,0xf7,0x02,0xfc,0x08,0xf1,0x02,0xeb,0x08,0xeb,0x02,0xda,0x08,0xe5,0x02,0xc9,0x08,0xdf,0x02,0xb8,0x08,0xd9,0x02,0xa6,0x08,0xd4,0x02,0x95,0x08,  \
    0xce,0x02,0x84,0x08,0xc9,0x02,0x72,0x08,0xc3,0x02,0x61,0x08,0xbe,0x02,0x50,0x08,0xb8,0x02,0x3e,0x08,0xb3,0x02,0x2d,0x08,0xae,0x02,0x1c,0x08,0xa9,0x02,0x0a,0x08,0xa4,0x02,0xf9,0x07,0x9f,0x02,0xe8,0x07,0x9a,0x02,0xd6,0x07,0x95,0x02,0xc5,0x07,0x90,0x02,0xb4,0x07,0x8b,0x02,0xa2,0x07,0x86,0x02,0x91,0x07,0x81,0x02,0x80,0x07,0x7d,0x02,0x6e,0x07,0x78,0x02,0x5d,0x07,0x73,0x02,0x4c,0x07,0x70,0x02,0x38,0x07,0x6c,0x02,0x25,0x07,0x68,0x02,0x12,0x07,0x64,0x02,  \
    0xff,0x06,0x60,0x02,0xeb,0x06,0x5c,0x02,0xd8,0x06,0x59,0x02,0xc5,0x06,0x55,0x02,0xb2,0x06,0x51,0x02,0x9f,0x06,0x4e,0x02,0x8c,0x06,0x4a,0x02,0x79,0x06,0x46,0x02,0x66,0x06,0x43,0x02,0x53,0x06,0x3f,0x02,0x40,0x06,0x3c,0x02,0x2c,0x06,0x38,0x02,0x19,0x06,0x35,0x02,0x06,0x06,0x32,0x02,0xf4,0x05,0x2e,0x02,0xe1,0x05,0x2b,0x02,0xce,0x05,0x28,0x02,0xbb,0x05,0x25,0x02,0xa8,0x05,0x21,0x02,0x95,0x05,0x1e,0x02,0x82,0x05,0x1b,0x02,0x71,0x05,0x17,0x02,0x5f,0x05,  \
    0x14,0x02,0x4d,0x05,0x11,0x02,0x3c,0x05,0x0e,0x02,0x2a,0x05,0x0a,0x02,0x18,0x05,0x07,0x02,0x07,0x05,0x04,0x02,0xf5,0x04,0x01,0x02,0xe3,0x04,0xfe,0x01,0xd1,0x04,0xfb,0x01,0xc0,0x04,0xf8,0x01,0xae,0x04,0xf6,0x01,0x9c,0x04,0xf3,0x01,0x8b,0x04,0xf0,0x01,0x79,0x04,0xed,0x01,0x67,0x04,0xeb,0x01,0x55,0x04,0xe8,0x01,0x44,0x04,0xe5,0x01,0x32,0x04,0xe3,0x01,0x20,0x04,0xe0,0x01,0x0e,0x04,0xde,0x01,0xfc,0x03,0xdc,0x01,0xeb,0x03,0xd9,0x01,0xd9,0x03,0xd7,0x01,  \
    0xc7,0x03,0xd4,0x01,0xb6,0x03,0xd2,0x01,0xa5,0x03,0xd0,0x01,0x94,0x03,0xcd,0x01,0x83,0x03,0xcb,0x01,0x72,0x03,0xc9,0x01,0x61,0x03,0xc7,0x01,0x50,0x03,0xc5,0x01,0x3f,0x03,0xc3,0x01,0x2e,0x03,0xc1,0x01,0x1d,0x03,0xbf,0x01,0x0c,0x03,0xbd,0x01,0xfa,0x02,0xbb,0x01,0xe9,0x02,0xba,0x01,0xd8,0x02,0xb8,0x01,0xc7,0x02,0xb6,0x01,0xb5,0x02,0xb4,0x01,0xa4,0x02,0xb3,0x01,0x92,0x02,0xb1,0x01,0x81,0x02,0xb0,0x01,0x6f,0x02,0xae,0x01,0x5e,0x02,0xad,0x01,0x4c,0x02,  \
    0xac,0x01,0x3b,0x02,0xaa,0x01,0x29,0x02,0xa9,0x01,0x17,0x02,0xa8,0x01,0x05,0x02,0xa7,0x01,0xf4,0x01,0xa6,0x01,0xe2,0x01,0xa5,0x01,0xcf,0x01,0xa4,0x01,0xbd,0x01,0xa3,0x01,0xaa,0x01,0xa2,0x01,0x98,0x01,0xa1,0x01,0x85,0x01,0xa0,0x01,0x73,0x01,0x9f,0x01,0x60,0x01,0x9e,0x01,0x4e,0x01,0x9e,0x01,0x3b,0x01,0x9d,0x01,0x29,0x01,0x9c,0x01,0x16,0x01,0x9c,0x01,0x04,0x01,0x9b,0x01,0xf1,0x00,0x9a,0x01,0xde,0x00,0x9a,0x01,0xcc,0x00,0x99,0x01,0xb9,0x00,0x99,0x01,  \
    0xa7,0x00,0x99,0x01,0x94,0x00,0x98,0x01,0x82,0x00,0x98,0x01,0x6f,0x00,0x97,0x01,0x5d,0x00,0x97,0x01,0x4a,0x00,0x97,0x01,0x37,0x00,0x97,0x01,0x25,0x00,0x97,0x01,0x12,0x00,0x96,0x01,0x00,0x00,0x96,0x01,0xed,0xff,0x96,0x01,0xdb,0xff,0x96,0x01,0xc8,0xff,0x96,0x01,0xb5,0xff,0x96,0x01,0xa3,0xff,0x96,0x01,0x90,0xff,0x96,0x01,0x7e,0xff,0x97,0x01,0x6b,0xff,0x97,0x01,0x59,0xff,0x97,0x01,0x46,0xff,0x97,0x01,0x33,0xff,0x98,0x01,0x21,0xff,0x98,0x01,0x0e,0xff,  \
    0x98,0x01,0xfc,0xfe,0x99,0x01,0xe9,0xfe,0x99,0x01,0xd7,0xfe,0x99,0x01,0xc4,0xfe,0x9a,0x01,0xb2,0xfe,0x9a,0x01,0x9f,0xfe,0x9b,0x01,0x8d,0xfe,0x9c,0x01,0x7a,0xfe,0x9c,0x01,0x68,0xfe,0x9d,0x01,0x55,0xfe,0x9e,0x01,0x42,0xfe,0x9e,0x01,0x30,0xfe,0x9f,0x01,0x1d,0xfe,0xa0,0x01,0x0b,0xfe,0xa1,0x01,0xf8,0xfd,0xa2,0x01,0xe6,0xfd,0xa2,0x01,0xd3,0xfd,0xa3,0x01,0xc1,0xfd,0xa4,0x01,0xae,0xfd,0xa5,0x01,0x9b,0xfd,0xa6,0x01,0x88,0xfd,0xa7,0x01,0x76,0xfd,0xa9,0x01,  \
    0x63,0xfd,0xaa,0x01,0x50,0xfd,0xab,0x01,0x3d,0xfd,0xac,0x01,0x2a,0xfd,0xad,0x01,0x17,0xfd,0xae,0x01,0x04,0xfd,0xb0,0x01,0xf1,0xfc,0xb1,0x01,0xde,0xfc,0xb2,0x01,0xcb,0xfc,0xb4,0x01,0xb8,0xfc,0xb5,0x01,0xa5,0xfc,0xb7,0x01,0x92,0xfc,0xb8,0x01,0x7f,0xfc,0xba,0x01,0x6c,0xfc,0xbb,0x01,0x59,0xfc,0xbd,0x01,0x46,0xfc,0xbe,0x01,0x33,0xfc,0xc0,0x01,0x20,0xfc,0xc1,0x01,0x0d,0xfc,0xc3,0x01,0xfa,0xfb,0xc5,0x01,0xe7,0xfb,0xc7,0x01,0xd3,0xfb,0xc8,0x01,0xc0,0xfb,  \
    0xca,0x01,0xae,0xfb,0xcc,0x01,0x9c,0xfb,0xce,0x01,0x8a,0xfb,0xd0,0x01,0x77,0xfb,0xd3,0x01,0x65,0xfb,0xd5,0x01,0x53,0xfb,0xd7,0x01,0x41,0xfb,0xd9,0x01,0x2f,0xfb,0xdb,0x01,0x1d,0xfb,0xde,0x01,0x0b,0xfb,0xe0,0x01,0xf9,0xfa,0xe2,0x01,0xe7,0xfa,0xe5,0x01,0xd5,0xfa,0xe7,0x01,0xc3,0xfa,0xea,0x01,0xb1,0xfa,0xec,0x01,0x9f,0xfa,0xef,0x01,0x8d,0xfa,0xf2,0x01,0x7b,0xfa,0xf4,0x01,0x69,0xfa,0xf7,0x01,0x57,0xfa,0xfa,0x01,0x45,0xfa,0xfd,0x01,0x33,0xfa,0x00,0x02,  \
    0x22,0xfa,0x03,0x02,0x10,0xfa,0x06,0x02,0xfe,0xf9,0x09,0x02,0xec,0xf9,0x0c,0x02,0xda,0xf9,0x0f,0x02,0xc7,0xf9,0x12,0x02,0xb5,0xf9,0x15,0x02,0xa2,0xf9,0x18,0x02,0x8f,0xf9,0x1b,0x02,0x7d,0xf9,0x1e,0x02,0x6a,0xf9,0x21,0x02,0x58,0xf9,0x24,0x02,0x45,0xf9,0x27,0x02,0x32,0xf9,0x2b,0x02,0x20,0xf9,0x2e,0x02,0x0d,0xf9,0x31,0x02,0xfa,0xf8,0x35,0x02,0xe8,0xf8,0x38,0x02,0xd5,0xf8,0x3b,0x02,0xc2,0xf8,0x3f,0x02,0xb0,0xf8,0x42,0x02,0x9d,0xf8,0x46,0x02,0x8a,0xf8,  \
    0x4a,0x02,0x78,0xf8,0x4d,0x02,0x65,0xf8,0x51,0x02,0x52,0xf8,0x55,0x02,0x40,0xf8,0x59,0x02,0x2d,0xf8,0x5c,0x02,0x1a,0xf8,0x60,0x02,0x08,0xf8,0x64,0x02,0xf6,0xf7,0x69,0x02,0xe4,0xf7,0x6d,0x02,0xd2,0xf7,0x71,0x02,0xc0,0xf7,0x75,0x02,0xae,0xf7,0x79,0x02,0x9c,0xf7,0x7e,0x02,0x8a,0xf7,0x82,0x02,0x78,0xf7,0x87,0x02,0x66,0xf7,0x8b,0x02,0x54,0xf7,0x90,0x02,0x42,0xf7,0x94,0x02,0x30,0xf7,0x99,0x02,0x1e,0xf7,0x9e,0x02,0x0c,0xf7,0xa2,0x02,0xfa,0xf6,0xa7,0x02,  \
    0xe8,0xf6,0xac,0x02,0xd6,0xf6,0xb1,0x02,0xc4,0xf6,0xb6,0x02,0xb2,0xf6,0xbb,0x02,0xa0,0xf6,0xc0,0x02,0x8e,0xf6,0xc5,0x02,0x7c,0xf6,0xca,0x02,0x69,0xf6,0xcf,0x02,0x56,0xf6,0xd3,0x02,0x43,0xf6,0xd8,0x02,0x30,0xf6,0xdd,0x02,0x1d,0xf6,0xe2,0x02,0x0a,0xf6,0xe7,0x02,0xf7,0xf5,0xec,0x02,0xe4,0xf5,0xf2,0x02,0xd1,0xf5,0xf7,0x02,0xbe,0xf5,0xfc,0x02,0xab,0xf5,0x01,0x03,0x98,0xf5,0x06,0x03,0x85,0xf5,0x0c,0x03,0x72,0xf5,0x11,0x03,0x5f,0xf5,0x17,0x03,0x4c,0xf5,  \
    0x1c,0x03,0x39,0xf5,0x21,0x03,0x26,0xf5,0x27,0x03,0x13,0xf5,0x2c,0x03,0x00,0xf5,0x32,0x03,0xed,0xf4,0x38,0x03,0xda,0xf4,0x3e,0x03,0xc7,0xf4,0x44,0x03,0xb5,0xf4,0x4a,0x03,0xa2,0xf4,0x50,0x03,0x90,0xf4,0x56,0x03,0x7d,0xf4,0x5c,0x03,0x6a,0xf4,0x62,0x03,0x58,0xf4,0x69,0x03,0x45,0xf4,0x6f,0x03,0x32,0xf4,0x75,0x03,0x1f,0xf4,0x7c,0x03,0x0d,0xf4,0x82,0x03,0xfa,0xf3,0x88,0x03,0xe7,0xf3,0x8f,0x03,0xd4,0xf3,0x95,0x03,0xc1,0xf3,0x9c,0x03,0xae,0xf3,0xa2,0x03,  \
    0x9b,0xf3,0xa9,0x03,0x88,0xf3,0xb0,0x03,0x75,0xf3,0xb5,0x03,0x60,0xf3,0xbb,0x03,0x4a,0xf3,0xc0,0x03,0x35,0xf3,0xc6,0x03,0x1f,0xf3,0xcb,0x03,0x0a,0xf3,0xd1,0x03,0xf4,0xf2,0xd7,0x03,0xde,0xf2,0xdc,0x03,0xc9,0xf2,0xe2,0x03,0xb3,0xf2,0xe7,0x03,0x9d,0xf2,0xed,0x03,0x87,0xf2,0xf3,0x03,0x72,0xf2,0xf8,0x03,0x5c,0xf2,0xfe,0x03,0x46,0xf2,0x04,0x04,0x30,0xf2,0x09,0x04,0x1a,0xf2,0x0f,0x04,0x03,0xf2,0x15,0x04,0xed,0xf1,0x1b,0x04,0xd8,0xf1,0x22,0x04,0xc3,0xf1,  \
    0x28,0x04,0xaf,0xf1,0x2f,0x04,0x9b,0xf1,0x36,0x04,0x86,0xf1,0x3d,0x04,0x72,0xf1,0x44,0x04,0x5d,0xf1,0x4b,0x04,0x48,0xf1,0x52,0x04,0x34,0xf1,0x59,0x04,0x1f,0xf1,0x60,0x04,0x0a,0xf1,0x66,0x04,0xf5,0xf0,0x6d,0x04,0xdf,0xf0,0x74,0x04,0xca,0xf0,0x7b,0x04,0xb5,0xf0,0x81,0x04,0x9f,0xf0,0x88,0x04,0x8a,0xf0,0x8f,0x04,0x74,0xf0,0x96,0x04,0x5e,0xf0,0x9c,0x04,0x48,0xf0,0xa3,0x04,0x33,0xf0,0xaa,0x04,0x1d,0xf0,0xb1,0x04,0x07,0xf0,0xb8,0x04,0xf1,0xef,0xbe,0x04,  \
    0xdb,0xef,0xc5,0x04,0xc4,0xef,0xcb,0x04,0xae,0xef,0xd2,0x04,0x97,0xef,0xd8,0x04,0x80,0xef,0xdf,0x04,0x69,0xef,0xe5,0x04,0x52,0xef,0xeb,0x04,0x3b,0xef,0xf1,0x04,0x23,0xef,0xf7,0x04,0x0c,0xef,0xfd,0x04,0xf4,0xee,0x03,0x05,0xdc,0xee,0x09,0x05,0xc4,0xee,0x0e,0x05,0xac,0xee,0x14,0x05,0x93,0xee,0x19,0x05,0x7a,0xee,0x1e,0x05,0x60,0xee,0x22,0x05,0x46,0xee,0x26,0x05,0x2b,0xee,0x2a,0x05,0x11,0xee,0x2e,0x05,0xf6,0xed,0x32,0x05,0xdc,0xed,0x36,0x05,0xc1,0xed,  \
    0x3a,0x05,0xa6,0xed,0x3e,0x05,0x8a,0xed,0x41,0x05,0x6f,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc9,0x05,0x1e,0x12,0xc4,0x05,0x03,0x12,0xc0,0x05,0xe8,0x11,0xbc,0x05,0xcd,0x11,0xb7,0x05,  \
    0xb2,0x11,0xb2,0x05,0x98,0x11,0xad,0x05,0x7d,0x11,0xa9,0x05,0x63,0x11,0xa3,0x05,0x49,0x11,0x9e,0x05,0x2f,0x11,0x99,0x05,0x15,0x11,0x94,0x05,0xfb,0x10,0x8e,0x05,0xe2,0x10,0x89,0x05,0xc8,0x10,0x83,0x05,0xaf,0x10,0x7d,0x05,0x96,0x10,0x78,0x05,0x7d,0x10,0x72,0x05,0x64,0x10,0x6c,0x05,0x4b,0x10,0x66,0x05,0x32,0x10,0x5f,0x05,0x1a,0x10,0x58,0x05,0x03,0x10,0x51,0x05,0xeb,0x0f,0x4b,0x05,0xd4,0x0f,0x43,0x05,0xbd,0x0f,0x3c,0x05,0xa6,0x0f,0x35,0x05,0x8f,0x0f,  \
    0x2e,0x05,0x78,0x0f,0x27,0x05,0x61,0x0f,0x1f,0x05,0x4b,0x0f,0x18,0x05,0x34,0x0f,0x10,0x05,0x1e,0x0f,0x09,0x05,0x08,0x0f,0x01,0x05,0xf2,0x0e,0xfa,0x04,0xdc,0x0e,0xf2,0x04,0xc6,0x0e,0xeb,0x04,0xb1,0x0e,0xe3,0x04,0x9b,0x0e,0xdb,0x04,0x86,0x0e,0xd4,0x04,0x70,0x0e,0xcb,0x04,0x5c,0x0e,0xc3,0x04,0x48,0x0e,0xba,0x04,0x34,0x0e,0xb1,0x04,0x20,0x0e,0xa9,0x04,0x0d,0x0e,0xa0,0x04,0xf9,0x0d,0x97,0x04,0xe6,0x0d,0x8f,0x04,0xd3,0x0d,0x86,0x04,0xc0,0x0d,0x7d,0x04,  \
    0xad,0x0d,0x74,0x04,0x9a,0x0d,0x6c,0x04,0x87,0x0d,0x63,0x04,0x75,0x0d,0x5a,0x04,0x62,0x0d,0x52,0x04,0x50,0x0d,0x49,0x04,0x3e,0x0d,0x40,0x04,0x2b,0x0d,0x38,0x04,0x19,0x0d,0x31,0x04,0x03,0x0d,0x2b,0x04,0xed,0x0c,0x25,0x04,0xd8,0x0c,0x1e,0x04,0xc2,0x0c,0x18,0x04,0xac,0x0c,0x12,0x04,0x97,0x0c,0x0b,0x04,0x82,0x0c,0x05,0x04,0x6c,0x0c,0xff,0x03,0x57,0x0c,0xf9,0x03,0x42,0x0c,0xf2,0x03,0x2c,0x0c,0xec,0x03,0x17,0x0c,0xe6,0x03,0x02,0x0c,0xe0,0x03,0xed,0x0b,  \
    0xda,0x03,0xd8,0x0b,0xd4,0x03,0xc3,0x0b,0xcd,0x03,0xae,0x0b,0xc7,0x03,0x99,0x0b,0xc1,0x03,0x84,0x0b,0xbb,0x03,0x6f,0x0b,0xb5,0x03,0x5a,0x0b,0xaf,0x03,0x45,0x0b,0xa9,0x03,0x30,0x0b,0xa3,0x03,0x1b,0x0b,0x9d,0x03,0x07,0x0b,0x97,0x03,0xf2,0x0a,0x92,0x03,0xdd,0x0a,0x8c,0x03,0xc9,0x0a,0x86,0x03,0xb4,0x0a,0x80,0x03,0xa0,0x0a,0x7a,0x03,0x8b,0x0a,0x74,0x03,0x77,0x0a,0x6f,0x03,0x62,0x0a,0x69,0x03,0x4e,0x0a,0x63,0x03,0x39,0x0a,0x5d,0x03,0x25,0x0a,0x56,0x03,  \
    0x14,0x0a,0x4f,0x03,0x03,0x0a,0x48,0x03,0xf2,0x09,0x41,0x03,0xe1,0x09,0x3a,0x03,0xd0,0x09,0x33,0x03,0xbf,0x09,0x2d,0x03,0xae,0x09,0x26,0x03,0x9d,0x09,0x1f,0x03,0x8c,0x09,0x18,0x03,0x7b,0x09,0x12,0x03,0x6a,0x09,0x0b,0x03,0x59,0x09,0x05,0x03,0x48,0x09,0xfe,0x02,0x37,0x09,0xf8,0x02,0x26,0x09,0xf2,0x02,0x15,0x09,0xec,0x02,0x05,0x09,0xe5,0x02,0xf4,0x08,0xdf,0x02,0xe3,0x08,0xd9,0x02,0xd2,0x08,0xd3,0x02,0xc1,0x08,0xce,0x02,0xb0,0x08,0xc8,0x02,0x9e,0x08,  \
    0xc2,0x02,0x8d,0x08,0xbd,0x02,0x7c,0x08,0xb7,0x02,0x6a,0x08,0xb2,0x02,0x59,0x08,0xac,0x02,0x48,0x08,0xa7,0x02,0x37,0x08,0xa2,0x02,0x25,0x08,0x9c,0x02,0x14,0x08,0x97,0x02,0x03,0x08,0x92,0x02,0xf1,0x07,0x8d,0x02,0xe0,0x07,0x88,0x02,0xcf,0x07,0x83,0x02,0xbe,0x07,0x7e,0x02,0xac,0x07,0x79,0x02,0x9b,0x07,0x74,0x02,0x8a,0x07,0x70,0x02,0x78,0x07,0x6b,0x02,0x67,0x07,0x66,0x02,0x56,0x07,0x62,0x02,0x44,0x07,0x5e,0x02,0x31,0x07,0x5a,0x02,0x1e,0x07,0x56,0x02,  \
    0x0b,0x07,0x52,0x02,0xf8,0x06,0x4e,0x02,0xe5,0x06,0x4a,0x02,0xd1,0x06,0x47,0x02,0xbe,0x06,0x43,0x02,0xab,0x06,0x3f,0x02,0x98,0x06,0x3c,0x02,0x85,0x06,0x38,0x02,0x72,0x06,0x34,0x02,0x5f,0x06,0x31,0x02,0x4c,0x06,0x2d,0x02,0x39,0x06,0x2a,0x02,0x26,0x06,0x26,0x02,0x13,0x06,0x23,0x02,0x00,0x06,0x20,0x02,0xee,0x05,0x1c,0x02,0xdb,0x05,0x19,0x02,0xc8,0x05,0x16,0x02,0xb5,0x05,0x12,0x02,0xa2,0x05,0x0f,0x02,0x8f,0x05,0x0c,0x02,0x7d,0x05,0x09,0x02,0x6b,0x05,  \
    0x05,0x02,0x59,0x05,0x02,0x02,0x48,0x05,0xff,0x01,0x36,0x05,0xfb,0x01,0x25,0x05,0xf8,0x01,0x13,0x05,0xf5,0x01,0x01,0x05,0xf2,0x01,0xf0,0x04,0xef,0x01,0xde,0x04,0xec,0x01,0xcc,0x04,0xe9,0x01,0xbb,0x04,0xe6,0x01,0xa9,0x04,0xe3,0x01,0x97,0x04,0xe0,0x01,0x86,0x04,0xde,0x01,0x74,0x04,0xdb,0x01,0x62,0x04,0xd8,0x01,0x51,0x04,0xd6,0x01,0x3f,0x04,0xd3,0x01,0x2d,0x04,0xd0,0x01,0x1c,0x04,0xce,0x01,0x0a,0x04,0xcc,0x01,0xf8,0x03,0xc9,0x01,0xe6,0x03,0xc7,0x01,  \
    0xd5,0x03,0xc4,0x01,0xc3,0x03,0xc2,0x01,0xb2,0x03,0xc0,0x01,0xa1,0x03,0xbd,0x01,0x90,0x03,0xbb,0x01,0x7f,0x03,0xb9,0x01,0x6e,0x03,0xb7,0x01,0x5d,0x03,0xb4,0x01,0x4c,0x03,0xb2,0x01,0x3b,0x03,0xb0,0x01,0x2a,0x03,0xae,0x01,0x19,0x03,0xac,0x01,0x08,0x03,0xab,0x01,0xf7,0x02,0xa9,0x01,0xe6,0x02,0xa7,0x01,0xd5,0x02,0xa5,0x01,0xc3,0x02,0xa4,0x01,0xb2,0x02,0xa2,0x01,0xa1,0x02,0xa0,0x01,0x8f,0x02,0x9f,0x01,0x7e,0x02,0x9d,0x01,0x6c,0x02,0x9c,0x01,0x5b,0x02,  \
    0x9a,0x01,0x49,0x02,0x99,0x01,0x38,0x02,0x98,0x01,0x26,0x02,0x97,0x01,0x15,0x02,0x95,0x01,0x03,0x02,0x94,0x01,0xf1,0x01,0x93,0x01,0xdf,0x01,0x92,0x01,0xcd,0x01,0x91,0x01,0xbb,0x01,0x90,0x01,0xa8,0x01,0x8f,0x01,0x96,0x01,0x8e,0x01,0x83,0x01,0x8d,0x01,0x71,0x01,0x8c,0x01,0x5e,0x01,0x8c,0x01,0x4c,0x01,0x8b,0x01,0x3a,0x01,0x8a,0x01,0x27,0x01,0x8a,0x01,0x15,0x01,0x89,0x01,0x02,0x01,0x88,0x01,0xf0,0x00,0x88,0x01,0xdd,0x00,0x87,0x01,0xcb,0x00,0x87,0x01,  \
    0xb8,0x00,0x86,0x01,0xa6,0x00,0x86,0x01,0x93,0x00,0x85,0x01,0x81,0x00,0x85,0x01,0x6e,0x00,0x85,0x01,0x5c,0x00,0x84,0x01,0x49,0x00,0x84,0x01,0x37,0x00,0x84,0x01,0x24,0x00,0x84,0x01,0x12,0x00,0x84,0x01,0xff,0xff,0x84,0x01,0xed,0xff,0x84,0x01,0xda,0xff,0x83,0x01,0xc8,0xff,0x83,0x01,0xb5,0xff,0x84,0x01,0xa3,0xff,0x84,0x01,0x91,0xff,0x84,0x01,0x7e,0xff,0x84,0x01,0x6c,0xff,0x84,0x01,0x59,0xff,0x84,0x01,0x47,0xff,0x84,0x01,0x34,0xff,0x85,0x01,0x22,0xff,  \
    0x85,0x01,0x0f,0xff,0x85,0x01,0xfd,0xfe,0x86,0x01,0xea,0xfe,0x86,0x01,0xd8,0xfe,0x87,0x01,0xc5,0xfe,0x87,0x01,0xb3,0xfe,0x88,0x01,0xa0,0xfe,0x88,0x01,0x8e,0xfe,0x89,0x01,0x7b,0xfe,0x8a,0x01,0x69,0xfe,0x8a,0x01,0x57,0xfe,0x8b,0x01,0x44,0xfe,0x8c,0x01,0x32,0xfe,0x8c,0x01,0x1f,0xfe,0x8d,0x01,0x0d,0xfe,0x8e,0x01,0xfa,0xfd,0x8f,0x01,0xe8,0xfd,0x90,0x01,0xd6,0xfd,0x91,0x01,0xc3,0xfd,0x92,0x01,0xb0,0xfd,0x93,0x01,0x9e,0xfd,0x94,0x01,0x8b,0xfd,0x95,0x01,  \
    0x78,0xfd,0x96,0x01,0x65,0xfd,0x97,0x01,0x53,0xfd,0x98,0x01,0x40,0xfd,0x99,0x01,0x2d,0xfd,0x9b,0x01,0x1a,0xfd,0x9c,0x01,0x07,0xfd,0x9d,0x01,0xf4,0xfc,0x9e,0x01,0xe1,0xfc,0xa0,0x01,0xcf,0xfc,0xa1,0x01,0xbc,0xfc,0xa3,0x01,0xa9,0xfc,0xa4,0x01,0x96,0xfc,0xa5,0x01,0x83,0xfc,0xa7,0x01,0x70,0xfc,0xa9,0x01,0x5d,0xfc,0xaa,0x01,0x4a,0xfc,0xac,0x01,0x37,0xfc,0xad,0x01,0x24,0xfc,0xaf,0x01,0x11,0xfc,0xb1,0x01,0xfe,0xfb,0xb2,0x01,0xeb,0xfb,0xb4,0x01,0xd8,0xfb,  \
    0xb6,0x01,0xc5,0xfb,0xb8,0x01,0xb3,0xfb,0xba,0x01,0xa1,0xfb,0xbc,0x01,0x8e,0xfb,0xbe,0x01,0x7c,0xfb,0xc0,0x01,0x6a,0xfb,0xc2,0x01,0x58,0xfb,0xc5,0x01,0x46,0xfb,0xc7,0x01,0x34,0xfb,0xc9,0x01,0x22,0xfb,0xcb,0x01,0x10,0xfb,0xce,0x01,0xfe,0xfa,0xd0,0x01,0xec,0xfa,0xd3,0x01,0xda,0xfa,0xd5,0x01,0xc8,0xfa,0xd8,0x01,0xb6,0xfa,0xda,0x01,0xa4,0xfa,0xdd,0x01,0x93,0xfa,0xe0,0x01,0x81,0xfa,0xe2,0x01,0x6f,0xfa,0xe5,0x01,0x5d,0xfa,0xe8,0x01,0x4b,0xfa,0xeb,0x01,  \
    0x39,0xfa,0xee,0x01,0x28,0xfa,0xf1,0x01,0x16,0xfa,0xf3,0x01,0x04,0xfa,0xf7,0x01,0xf3,0xf9,0xfa,0x01,0xe0,0xf9,0xfc,0x01,0xce,0xf9,0xff,0x01,0xbb,0xf9,0x02,0x02,0xa9,0xf9,0x05,0x02,0x96,0xf9,0x09,0x02,0x83,0xf9,0x0c,0x02,0x71,0xf9,0x0f,0x02,0x5e,0xf9,0x12,0x02,0x4c,0xf9,0x15,0x02,0x39,0xf9,0x19,0x02,0x27,0xf9,0x1c,0x02,0x14,0xf9,0x1f,0x02,0x01,0xf9,0x23,0x02,0xef,0xf8,0x26,0x02,0xdc,0xf8,0x29,0x02,0xca,0xf8,0x2d,0x02,0xb7,0xf8,0x31,0x02,0xa4,0xf8,  \
    0x34,0x02,0x92,0xf8,0x38,0x02,0x7f,0xf8,0x3b,0x02,0x6d,0xf8,0x3f,0x02,0x5a,0xf8,0x43,0x02,0x47,0xf8,0x47,0x02,0x35,0xf8,0x4b,0x02,0x22,0xf8,0x4f,0x02,0x10,0xf8,0x53,0x02,0xfe,0xf7,0x57,0x02,0xec,0xf7,0x5b,0x02,0xda,0xf7,0x5f,0x02,0xc8,0xf7,0x63,0x02,0xb6,0xf7,0x68,0x02,0xa4,0xf7,0x6c,0x02,0x92,0xf7,0x70,0x02,0x80,0xf7,0x75,0x02,0x6e,0xf7,0x79,0x02,0x5c,0xf7,0x7e,0x02,0x4a,0xf7,0x83,0x02,0x38,0xf7,0x87,0x02,0x26,0xf7,0x8c,0x02,0x14,0xf7,0x91,0x02,  \
    0x02,0xf7,0x95,0x02,0xf0,0xf6,0x9a,0x02,0xde,0xf6,0x9f,0x02,0xcc,0xf6,0xa4,0x02,0xba,0xf6,0xa9,0x02,0xa8,0xf6,0xae,0x02,0x96,0xf6,0xb3,0x02,0x84,0xf6,0xb8,0x02,0x72,0xf6,0xbd,0x02,0x5f,0xf6,0xc2,0x02,0x4c,0xf6,0xc7,0x02,0x39,0xf6,0xcc,0x02,0x26,0xf6,0xd1,0x02,0x13,0xf6,0xd6,0x02,0x00,0xf6,0xdb,0x02,0xed,0xf5,0xe0,0x02,0xdb,0xf5,0xe5,0x02,0xc8,0xf5,0xea,0x02,0xb5,0xf5,0xf0,0x02,0xa2,0xf5,0xf5,0x02,0x8f,0xf5,0xfa,0x02,0x7c,0xf5,0x00,0x03,0x69,0xf5,  \
    0x05,0x03,0x56,0xf5,0x0a,0x03,0x42,0xf5,0x10,0x03,0x2f,0xf5,0x15,0x03,0x1c,0xf5,0x1b,0x03,0x09,0xf5,0x21,0x03,0xf6,0xf4,0x26,0x03,0xe3,0xf4,0x2c,0x03,0xd1,0xf4,0x32,0x03,0xbe,0xf4,0x38,0x03,0xac,0xf4,0x3e,0x03,0x99,0xf4,0x45,0x03,0x86,0xf4,0x4b,0x03,0x74,0xf4,0x51,0x03,0x61,0xf4,0x57,0x03,0x4e,0xf4,0x5d,0x03,0x3c,0xf4,0x64,0x03,0x29,0xf4,0x6a,0x03,0x16,0xf4,0x70,0x03,0x03,0xf4,0x77,0x03,0xf0,0xf3,0x7d,0x03,0xdd,0xf3,0x84,0x03,0xca,0xf3,0x8a,0x03,  \
    0xb7,0xf3,0x91,0x03,0xa4,0xf3,0x97,0x03,0x91,0xf3,0x9e,0x03,0x7e,0xf3,0xa4,0x03,0x69,0xf3,0xa9,0x03,0x54,0xf3,0xaf,0x03,0x3e,0xf3,0xb4,0x03,0x29,0xf3,0xba,0x03,0x13,0xf3,0xbf,0x03,0xfe,0xf2,0xc5,0x03,0xe8,0xf2,0xcb,0x03,0xd2,0xf2,0xd0,0x03,0xbd,0xf2,0xd6,0x03,0xa7,0xf2,0xdb,0x03,0x91,0xf2,0xe1,0x03,0x7b,0xf2,0xe7,0x03,0x65,0xf2,0xec,0x03,0x4f,0xf2,0xf2,0x03,0x39,0xf2,0xf8,0x03,0x23,0xf2,0xfd,0x03,0x0d,0xf2,0x03,0x04,0xf7,0xf1,0x09,0x04,0xe1,0xf1,  \
    0x10,0x04,0xcd,0xf1,0x17,0x04,0xb9,0xf1,0x1e,0x04,0xa4,0xf1,0x24,0x04,0x90,0xf1,0x2b,0x04,0x7b,0xf1,0x32,0x04,0x67,0xf1,0x39,0x04,0x52,0xf1,0x40,0x04,0x3d,0xf1,0x47,0x04,0x28,0xf1,0x4d,0x04,0x13,0xf1,0x54,0x04,0xfe,0xf0,0x5b,0x04,0xe9,0xf0,0x62,0x04,0xd3,0xf0,0x69,0x04,0xbe,0xf0,0x6f,0x04,0xa8,0xf0,0x76,0x04,0x93,0xf0,0x7d,0x04,0x7d,0xf0,0x83,0x04,0x67,0xf0,0x8a,0x04,0x51,0xf0,0x91,0x04,0x3b,0xf0,0x98,0x04,0x26,0xf0,0x9e,0x04,0x10,0xf0,0xa5,0x04,  \
    0xf9,0xef,0xab,0x04,0xe3,0xef,0xb2,0x04,0xcd,0xef,0xb8,0x04,0xb6,0xef,0xbf,0x04,0x9f,0xef,0xc5,0x04,0x88,0xef,0xcc,0x04,0x71,0xef,0xd2,0x04,0x5a,0xef,0xd8,0x04,0x43,0xef,0xde,0x04,0x2b,0xef,0xe4,0x04,0x14,0xef,0xea,0x04,0xfc,0xee,0xf0,0x04,0xe4,0xee,0xf5,0x04,0xcc,0xee,0xfb,0x04,0xb3,0xee,0x00,0x05,0x9b,0xee,0x06,0x05,0x82,0xee,0x0a,0x05,0x68,0xee,0x0e,0x05,0x4d,0xee,0x12,0x05,0x33,0xee,0x17,0x05,0x19,0xee,0x1b,0x05,0xfe,0xed,0x1f,0x05,0xe3,0xed,  \
    0x22,0x05,0xc8,0xed,0x26,0x05,0xad,0xed,0x2a,0x05,0x92,0xed,0x2d,0x05,0x76,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xb6,0x05,0x17,0x12,0xb2,0x05,0xfc,0x11,0xad,0x05,0xe1,0x11,0xa9,0x05,  \
    0xc6,0x11,0xa4,0x05,0xab,0x11,0xa0,0x05,0x91,0x11,0x9b,0x05,0x76,0x11,0x96,0x05,0x5c,0x11,0x91,0x05,0x42,0x11,0x8c,0x05,0x28,0x11,0x87,0x05,0x0e,0x11,0x81,0x05,0xf4,0x10,0x7c,0x05,0xda,0x10,0x76,0x05,0xc1,0x10,0x71,0x05,0xa8,0x10,0x6b,0x05,0x8e,0x10,0x65,0x05,0x75,0x10,0x5f,0x05,0x5c,0x10,0x59,0x05,0x44,0x10,0x53,0x05,0x2b,0x10,0x4d,0x05,0x13,0x10,0x46,0x05,0xfb,0x0f,0x3f,0x05,0xe4,0x0f,0x38,0x05,0xcc,0x0f,0x31,0x05,0xb5,0x0f,0x2a,0x05,0x9e,0x0f,  \
    0x23,0x05,0x87,0x0f,0x1c,0x05,0x70,0x0f,0x15,0x05,0x5a,0x0f,0x0d,0x05,0x43,0x0f,0x06,0x05,0x2d,0x0f,0xff,0x04,0x16,0x0f,0xf7,0x04,0x00,0x0f,0xf0,0x04,0xea,0x0e,0xe8,0x04,0xd4,0x0e,0xe1,0x04,0xbe,0x0e,0xd9,0x04,0xa9,0x0e,0xd1,0x04,0x93,0x0e,0xca,0x04,0x7d,0x0e,0xc2,0x04,0x68,0x0e,0xba,0x04,0x53,0x0e,0xb1,0x04,0x40,0x0e,0xa9,0x04,0x2c,0x0e,0xa0,0x04,0x18,0x0e,0x98,0x04,0x04,0x0e,0x8f,0x04,0xf1,0x0d,0x86,0x04,0xde,0x0d,0x7e,0x04,0xca,0x0d,0x75,0x04,  \
    0xb7,0x0d,0x6c,0x04,0xa4,0x0d,0x63,0x04,0x91,0x0d,0x5b,0x04,0x7e,0x0d,0x52,0x04,0x6c,0x0d,0x49,0x04,0x59,0x0d,0x41,0x04,0x47,0x0d,0x38,0x04,0x34,0x0d,0x2f,0x04,0x22,0x0d,0x27,0x04,0x0f,0x0d,0x21,0x04,0xfa,0x0c,0x1a,0x04,0xe4,0x0c,0x14,0x04,0xce,0x0c,0x0e,0x04,0xb9,0x0c,0x07,0x04,0xa3,0x0c,0x01,0x04,0x8e,0x0c,0xfb,0x03,0x78,0x0c,0xf4,0x03,0x63,0x0c,0xee,0x03,0x4e,0x0c,0xe8,0x03,0x39,0x0c,0xe2,0x03,0x23,0x0c,0xdb,0x03,0x0e,0x0c,0xd5,0x03,0xf9,0x0b,  \
    0xcf,0x03,0xe4,0x0b,0xc9,0x03,0xcf,0x0b,0xc3,0x03,0xba,0x0b,0xbd,0x03,0xa5,0x0b,0xb6,0x03,0x90,0x0b,0xb0,0x03,0x7b,0x0b,0xaa,0x03,0x66,0x0b,0xa4,0x03,0x51,0x0b,0x9e,0x03,0x3c,0x0b,0x98,0x03,0x28,0x0b,0x92,0x03,0x13,0x0b,0x8c,0x03,0xfe,0x0a,0x86,0x03,0xea,0x0a,0x81,0x03,0xd5,0x0a,0x7b,0x03,0xc0,0x0a,0x75,0x03,0xac,0x0a,0x6f,0x03,0x97,0x0a,0x69,0x03,0x83,0x0a,0x63,0x03,0x6e,0x0a,0x5e,0x03,0x5a,0x0a,0x58,0x03,0x45,0x0a,0x52,0x03,0x31,0x0a,0x4c,0x03,  \
    0x1d,0x0a,0x45,0x03,0x0c,0x0a,0x3e,0x03,0xfb,0x09,0x37,0x03,0xea,0x09,0x30,0x03,0xd9,0x09,0x29,0x03,0xc8,0x09,0x22,0x03,0xb7,0x09,0x1b,0x03,0xa6,0x09,0x15,0x03,0x95,0x09,0x0e,0x03,0x84,0x09,0x07,0x03,0x73,0x09,0x01,0x03,0x62,0x09,0xfa,0x02,0x51,0x09,0xf4,0x02,0x40,0x09,0xed,0x02,0x2f,0x09,0xe7,0x02,0x1e,0x09,0xe1,0x02,0x0d,0x09,0xda,0x02,0xfd,0x08,0xd4,0x02,0xec,0x08,0xce,0x02,0xdb,0x08,0xc8,0x02,0xca,0x08,0xc2,0x02,0xb9,0x08,0xbd,0x02,0xa8,0x08,  \
    0xb7,0x02,0x96,0x08,0xb1,0x02,0x85,0x08,0xac,0x02,0x74,0x08,0xa6,0x02,0x63,0x08,0xa1,0x02,0x51,0x08,0x9b,0x02,0x40,0x08,0x96,0x02,0x2f,0x08,0x90,0x02,0x1d,0x08,0x8b,0x02,0x0c,0x08,0x86,0x02,0xfb,0x07,0x81,0x02,0xea,0x07,0x7c,0x02,0xd8,0x07,0x77,0x02,0xc7,0x07,0x72,0x02,0xb6,0x07,0x6d,0x02,0xa5,0x07,0x68,0x02,0x93,0x07,0x63,0x02,0x82,0x07,0x5e,0x02,0x71,0x07,0x5a,0x02,0x60,0x07,0x55,0x02,0x4e,0x07,0x50,0x02,0x3d,0x07,0x4c,0x02,0x2a,0x07,0x49,0x02,  \
    0x17,0x07,0x45,0x02,0x04,0x07,0x41,0x02,0xf1,0x06,0x3d,0x02,0xde,0x06,0x39,0x02,0xca,0x06,0x35,0x02,0xb7,0x06,0x32,0x02,0xa4,0x06,0x2e,0x02,0x91,0x06,0x2a,0x02,0x7f,0x06,0x26,0x02,0x6c,0x06,0x23,0x02,0x59,0x06,0x1f,0x02,0x46,0x06,0x1c,0x02,0x33,0x06,0x18,0x02,0x20,0x06,0x15,0x02,0x0d,0x06,0x11,0x02,0xfa,0x05,0x0e,0x02,0xe7,0x05,0x0b,0x02,0xd5,0x05,0x07,0x02,0xc2,0x05,0x04,0x02,0xaf,0x05,0x01,0x02,0x9c,0x05,0xfe,0x01,0x8a,0x05,0xfa,0x01,0x77,0x05,  \
    0xf7,0x01,0x65,0x05,0xf3,0x01,0x54,0x05,0xf0,0x01,0x42,0x05,0xed,0x01,0x31,0x05,0xea,0x01,0x1f,0x05,0xe6,0x01,0x0e,0x05,0xe3,0x01,0xfc,0x04,0xe0,0x01,0xeb,0x04,0xdd,0x01,0xd9,0x04,0xda,0x01,0xc7,0x04,0xd7,0x01,0xb6,0x04,0xd4,0x01,0xa4,0x04,0xd1,0x01,0x93,0x04,0xcf,0x01,0x81,0x04,0xcc,0x01,0x6f,0x04,0xc9,0x01,0x5e,0x04,0xc6,0x01,0x4c,0x04,0xc4,0x01,0x3a,0x04,0xc1,0x01,0x29,0x04,0xbe,0x01,0x17,0x04,0xbc,0x01,0x06,0x04,0xb9,0x01,0xf4,0x03,0xb7,0x01,  \
    0xe2,0x03,0xb5,0x01,0xd1,0x03,0xb2,0x01,0xbf,0x03,0xb0,0x01,0xad,0x03,0xae,0x01,0x9d,0x03,0xab,0x01,0x8c,0x03,0xa9,0x01,0x7b,0x03,0xa7,0x01,0x6a,0x03,0xa5,0x01,0x59,0x03,0xa2,0x01,0x49,0x03,0xa0,0x01,0x38,0x03,0x9e,0x01,0x27,0x03,0x9c,0x01,0x16,0x03,0x9a,0x01,0x05,0x03,0x98,0x01,0xf3,0x02,0x97,0x01,0xe2,0x02,0x95,0x01,0xd1,0x02,0x93,0x01,0xc0,0x02,0x91,0x01,0xaf,0x02,0x90,0x01,0x9e,0x02,0x8e,0x01,0x8c,0x02,0x8d,0x01,0x7b,0x02,0x8b,0x01,0x69,0x02,  \
    0x8a,0x01,0x58,0x02,0x88,0x01,0x47,0x02,0x87,0x01,0x35,0x02,0x86,0x01,0x24,0x02,0x84,0x01,0x12,0x02,0x83,0x01,0x00,0x02,0x82,0x01,0xef,0x01,0x81,0x01,0xdd,0x01,0x80,0x01,0xcb,0x01,0x7f,0x01,0xb8,0x01,0x7e,0x01,0xa6,0x01,0x7d,0x01,0x94,0x01,0x7c,0x01,0x81,0x01,0x7b,0x01,0x6f,0x01,0x7a,0x01,0x5d,0x01,0x79,0x01,0x4a,0x01,0x79,0x01,0x38,0x01,0x78,0x01,0x25,0x01,0x77,0x01,0x13,0x01,0x77,0x01,0x01,0x01,0x76,0x01,0xee,0x00,0x75,0x01,0xdc,0x00,0x75,0x01,  \
    0xca,0x00,0x74,0x01,0xb7,0x00,0x74,0x01,0xa5,0x00,0x73,0x01,0x92,0x00,0x73,0x01,0x80,0x00,0x73,0x01,0x6e,0x00,0x72,0x01,0x5b,0x00,0x72,0x01,0x49,0x00,0x72,0x01,0x36,0x00,0x72,0x01,0x24,0x00,0x71,0x01,0x12,0x00,0x71,0x01,0xff,0xff,0x71,0x01,0xed,0xff,0x71,0x01,0xda,0xff,0x71,0x01,0xc8,0xff,0x71,0x01,0xb6,0xff,0x71,0x01,0xa3,0xff,0x71,0x01,0x91,0xff,0x71,0x01,0x7e,0xff,0x72,0x01,0x6c,0xff,0x72,0x01,0x5a,0xff,0x72,0x01,0x47,0xff,0x72,0x01,0x35,0xff,  \
    0x72,0x01,0x22,0xff,0x73,0x01,0x10,0xff,0x73,0x01,0xfe,0xfe,0x73,0x01,0xeb,0xfe,0x74,0x01,0xd9,0xfe,0x74,0x01,0xc6,0xfe,0x75,0x01,0xb4,0xfe,0x75,0x01,0xa2,0xfe,0x76,0x01,0x8f,0xfe,0x77,0x01,0x7d,0xfe,0x77,0x01,0x6b,0xfe,0x78,0x01,0x58,0xfe,0x79,0x01,0x46,0xfe,0x79,0x01,0x34,0xfe,0x7a,0x01,0x21,0xfe,0x7b,0x01,0x0f,0xfe,0x7c,0x01,0xfd,0xfd,0x7d,0x01,0xea,0xfd,0x7e,0x01,0xd8,0xfd,0x7e,0x01,0xc5,0xfd,0x7f,0x01,0xb3,0xfd,0x80,0x01,0xa0,0xfd,0x81,0x01,  \
    0x8d,0xfd,0x83,0x01,0x7b,0xfd,0x84,0x01,0x68,0xfd,0x85,0x01,0x55,0xfd,0x86,0x01,0x43,0xfd,0x87,0x01,0x30,0xfd,0x88,0x01,0x1d,0xfd,0x8a,0x01,0x0a,0xfd,0x8b,0x01,0xf8,0xfc,0x8c,0x01,0xe5,0xfc,0x8e,0x01,0xd2,0xfc,0x8f,0x01,0xbf,0xfc,0x90,0x01,0xac,0xfc,0x92,0x01,0x9a,0xfc,0x93,0x01,0x87,0xfc,0x95,0x01,0x74,0xfc,0x96,0x01,0x61,0xfc,0x98,0x01,0x4e,0xfc,0x9a,0x01,0x3b,0xfc,0x9b,0x01,0x28,0xfc,0x9d,0x01,0x15,0xfc,0x9f,0x01,0x02,0xfc,0xa0,0x01,0xef,0xfb,  \
    0xa2,0x01,0xdc,0xfb,0xa4,0x01,0xc9,0xfb,0xa6,0x01,0xb7,0xfb,0xa8,0x01,0xa5,0xfb,0xaa,0x01,0x93,0xfb,0xac,0x01,0x81,0xfb,0xae,0x01,0x6f,0xfb,0xb0,0x01,0x5d,0xfb,0xb3,0x01,0x4b,0xfb,0xb5,0x01,0x39,0xfb,0xb7,0x01,0x27,0xfb,0xb9,0x01,0x15,0xfb,0xbc,0x01,0x03,0xfb,0xbe,0x01,0xf2,0xfa,0xc1,0x01,0xe0,0xfa,0xc3,0x01,0xce,0xfa,0xc6,0x01,0xbc,0xfa,0xc8,0x01,0xaa,0xfa,0xcb,0x01,0x98,0xfa,0xce,0x01,0x87,0xfa,0xd0,0x01,0x75,0xfa,0xd3,0x01,0x63,0xfa,0xd6,0x01,  \
    0x51,0xfa,0xd9,0x01,0x40,0xfa,0xdc,0x01,0x2e,0xfa,0xdf,0x01,0x1c,0xfa,0xe2,0x01,0x0b,0xfa,0xe5,0x01,0xf9,0xf9,0xe8,0x01,0xe7,0xf9,0xeb,0x01,0xd4,0xf9,0xee,0x01,0xc2,0xf9,0xf1,0x01,0xaf,0xf9,0xf4,0x01,0x9d,0xf9,0xf7,0x01,0x8a,0xf9,0xfa,0x01,0x78,0xf9,0xfd,0x01,0x65,0xf9,0x00,0x02,0x53,0xf9,0x04,0x02,0x40,0xf9,0x07,0x02,0x2e,0xf9,0x0a,0x02,0x1b,0xf9,0x0e,0x02,0x09,0xf9,0x11,0x02,0xf6,0xf8,0x14,0x02,0xe3,0xf8,0x18,0x02,0xd1,0xf8,0x1b,0x02,0xbe,0xf8,  \
    0x1f,0x02,0xac,0xf8,0x23,0x02,0x99,0xf8,0x26,0x02,0x87,0xf8,0x2a,0x02,0x74,0xf8,0x2e,0x02,0x62,0xf8,0x31,0x02,0x4f,0xf8,0x35,0x02,0x3d,0xf8,0x39,0x02,0x2a,0xf8,0x3d,0x02,0x18,0xf8,0x41,0x02,0x06,0xf8,0x45,0x02,0xf4,0xf7,0x49,0x02,0xe2,0xf7,0x4e,0x02,0xd0,0xf7,0x52,0x02,0xbe,0xf7,0x56,0x02,0xac,0xf7,0x5b,0x02,0x9a,0xf7,0x5f,0x02,0x88,0xf7,0x64,0x02,0x76,0xf7,0x68,0x02,0x64,0xf7,0x6d,0x02,0x53,0xf7,0x71,0x02,0x41,0xf7,0x76,0x02,0x2f,0xf7,0x7b,0x02,  \
    0x1d,0xf7,0x7f,0x02,0x0b,0xf7,0x84,0x02,0xf9,0xf6,0x89,0x02,0xe7,0xf6,0x8e,0x02,0xd5,0xf6,0x93,0x02,0xc3,0xf6,0x98,0x02,0xb1,0xf6,0x9d,0x02,0x9f,0xf6,0xa2,0x02,0x8d,0xf6,0xa7,0x02,0x7b,0xf6,0xac,0x02,0x68,0xf6,0xb1,0x02,0x55,0xf6,0xb5,0x02,0x42,0xf6,0xba,0x02,0x2f,0xf6,0xbf,0x02,0x1c,0xf6,0xc5,0x02,0x09,0xf6,0xca,0x02,0xf7,0xf5,0xcf,0x02,0xe4,0xf5,0xd4,0x02,0xd1,0xf5,0xd9,0x02,0xbe,0xf5,0xde,0x02,0xab,0xf5,0xe4,0x02,0x98,0xf5,0xe9,0x02,0x85,0xf5,  \
    0xee,0x02,0x72,0xf5,0xf4,0x02,0x5f,0xf5,0xf9,0x02,0x4c,0xf5,0xff,0x02,0x39,0xf5,0x04,0x03,0x26,0xf5,0x0a,0x03,0x13,0xf5,0x0f,0x03,0x00,0xf5,0x15,0x03,0xed,0xf4,0x1b,0x03,0xda,0xf4,0x21,0x03,0xc8,0xf4,0x27,0x03,0xb5,0xf4,0x2d,0x03,0xa2,0xf4,0x33,0x03,0x90,0xf4,0x39,0x03,0x7d,0xf4,0x40,0x03,0x6b,0xf4,0x46,0x03,0x58,0xf4,0x4c,0x03,0x45,0xf4,0x52,0x03,0x32,0xf4,0x59,0x03,0x1f,0xf4,0x5f,0x03,0x0d,0xf4,0x66,0x03,0xfa,0xf3,0x6c,0x03,0xe7,0xf3,0x72,0x03,  \
    0xd4,0xf3,0x79,0x03,0xc1,0xf3,0x7f,0x03,0xae,0xf3,0x86,0x03,0x9b,0xf3,0x8d,0x03,0x88,0xf3,0x92,0x03,0x72,0xf3,0x98,0x03,0x5d,0xf3,0x9d,0x03,0x48,0xf3,0xa3,0x03,0x32,0xf3,0xa8,0x03,0x1d,0xf3,0xae,0x03,0x07,0xf3,0xb4,0x03,0xf2,0xf2,0xb9,0x03,0xdc,0xf2,0xbf,0x03,0xc6,0xf2,0xc4,0x03,0xb1,0xf2,0xca,0x03,0x9b,0xf2,0xd0,0x03,0x85,0xf2,0xd5,0x03,0x6f,0xf2,0xdb,0x03,0x59,0xf2,0xe1,0x03,0x43,0xf2,0xe6,0x03,0x2d,0xf2,0xec,0x03,0x17,0xf2,0xf1,0x03,0x01,0xf2,  \
    0xf7,0x03,0xeb,0xf1,0xfe,0x03,0xd7,0xf1,0x05,0x04,0xc2,0xf1,0x0c,0x04,0xae,0xf1,0x13,0x04,0x99,0xf1,0x1a,0x04,0x85,0xf1,0x20,0x04,0x70,0xf1,0x27,0x04,0x5b,0xf1,0x2e,0x04,0x46,0xf1,0x35,0x04,0x31,0xf1,0x3c,0x04,0x1c,0xf1,0x42,0x04,0x07,0xf1,0x49,0x04,0xf2,0xf0,0x50,0x04,0xdd,0xf0,0x57,0x04,0xc7,0xf0,0x5d,0x04,0xb1,0xf0,0x64,0x04,0x9c,0xf0,0x6a,0x04,0x86,0xf0,0x71,0x04,0x70,0xf0,0x78,0x04,0x5a,0xf0,0x7e,0x04,0x44,0xf0,0x85,0x04,0x2e,0xf0,0x8c,0x04,  \
    0x18,0xf0,0x92,0x04,0x02,0xf0,0x99,0x04,0xec,0xef,0x9f,0x04,0xd5,0xef,0xa6,0x04,0xbf,0xef,0xac,0x04,0xa8,0xef,0xb3,0x04,0x91,0xef,0xb9,0x04,0x7a,0xef,0xbf,0x04,0x62,0xef,0xc5,0x04,0x4b,0xef,0xcb,0x04,0x34,0xef,0xd1,0x04,0x1c,0xef,0xd7,0x04,0x04,0xef,0xdd,0x04,0xec,0xee,0xe2,0x04,0xd4,0xee,0xe8,0x04,0xbb,0xee,0xed,0x04,0xa3,0xee,0xf2,0x04,0x8a,0xee,0xf7,0x04,0x6f,0xee,0xfb,0x04,0x55,0xee,0xff,0x04,0x3b,0xee,0x03,0x05,0x20,0xee,0x07,0x05,0x06,0xee,  \
    0x0b,0x05,0xeb,0xed,0x0f,0x05,0xd0,0xed,0x13,0x05,0xb5,0xed,0x16,0x05,0x99,0xed,0x1a,0x05,0x7e,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa3,0x05,0x10,0x12,0x9f,0x05,0xf5,0x11,0x9b,0x05,  \
    0xda,0x11,0x96,0x05,0xbf,0x11,0x92,0x05,0xa4,0x11,0x8d,0x05,0x8a,0x11,0x88,0x05,0x6f,0x11,0x84,0x05,0x55,0x11,0x7f,0x05,0x3b,0x11,0x79,0x05,0x20,0x11,0x74,0x05,0x07,0x11,0x6f,0x05,0xed,0x10,0x6a,0x05,0xd3,0x10,0x64,0x05,0xba,0x10,0x5f,0x05,0xa0,0x10,0x59,0x05,0x87,0x10,0x53,0x05,0x6e,0x10,0x4d,0x05,0x55,0x10,0x47,0x05,0x3c,0x10,0x41,0x05,0x23,0x10,0x3b,0x05,0x0b,0x10,0x34,0x05,0xf4,0x0f,0x2d,0x05,0xdc,0x0f,0x27,0x05,0xc5,0x0f,0x20,0x05,0xad,0x0f,  \
    0x19,0x05,0x96,0x0f,0x11,0x05,0x7f,0x0f,0x0a,0x05,0x69,0x0f,0x03,0x05,0x52,0x0f,0xfc,0x04,0x3b,0x0f,0xf5,0x04,0x25,0x0f,0xed,0x04,0x0e,0x0f,0xe6,0x04,0xf8,0x0e,0xde,0x04,0xe2,0x0e,0xd7,0x04,0xcc,0x0e,0xcf,0x04,0xb6,0x0e,0xc8,0x04,0xa0,0x0e,0xc0,0x04,0x8b,0x0e,0xb9,0x04,0x75,0x0e,0xb1,0x04,0x60,0x0e,0xa9,0x04,0x4b,0x0e,0xa0,0x04,0x37,0x0e,0x98,0x04,0x23,0x0e,0x8f,0x04,0x0f,0x0e,0x87,0x04,0xfc,0x0d,0x7e,0x04,0xe8,0x0d,0x75,0x04,0xd5,0x0d,0x6d,0x04,  \
    0xc2,0x0d,0x64,0x04,0xae,0x0d,0x5b,0x04,0x9b,0x0d,0x53,0x04,0x88,0x0d,0x4a,0x04,0x75,0x0d,0x42,0x04,0x63,0x0d,0x39,0x04,0x50,0x0d,0x30,0x04,0x3e,0x0d,0x28,0x04,0x2b,0x0d,0x1f,0x04,0x19,0x0d,0x17,0x04,0x06,0x0d,0x10,0x04,0xf0,0x0c,0x0a,0x04,0xdb,0x0c,0x04,0x04,0xc5,0x0c,0xfd,0x03,0xb0,0x0c,0xf7,0x03,0x9a,0x0c,0xf1,0x03,0x85,0x0c,0xea,0x03,0x6f,0x0c,0xe4,0x03,0x5a,0x0c,0xde,0x03,0x45,0x0c,0xd7,0x03,0x2f,0x0c,0xd1,0x03,0x1a,0x0c,0xcb,0x03,0x05,0x0c,  \
    0xc5,0x03,0xf0,0x0b,0xbf,0x03,0xdb,0x0b,0xb8,0x03,0xc6,0x0b,0xb2,0x03,0xb1,0x0b,0xac,0x03,0x9c,0x0b,0xa6,0x03,0x87,0x0b,0xa0,0x03,0x72,0x0b,0x9a,0x03,0x5d,0x0b,0x94,0x03,0x48,0x0b,0x8e,0x03,0x34,0x0b,0x88,0x03,0x1f,0x0b,0x82,0x03,0x0a,0x0b,0x7c,0x03,0xf6,0x0a,0x76,0x03,0xe1,0x0a,0x70,0x03,0xcc,0x0a,0x6a,0x03,0xb8,0x0a,0x64,0x03,0xa3,0x0a,0x5e,0x03,0x8f,0x0a,0x58,0x03,0x7a,0x0a,0x53,0x03,0x66,0x0a,0x4d,0x03,0x52,0x0a,0x47,0x03,0x3d,0x0a,0x41,0x03,  \
    0x29,0x0a,0x3b,0x03,0x15,0x0a,0x34,0x03,0x04,0x0a,0x2d,0x03,0xf3,0x09,0x26,0x03,0xe2,0x09,0x1f,0x03,0xd1,0x09,0x18,0x03,0xc0,0x09,0x11,0x03,0xaf,0x09,0x0b,0x03,0x9e,0x09,0x04,0x03,0x8d,0x09,0xfd,0x02,0x7c,0x09,0xf7,0x02,0x6b,0x09,0xf0,0x02,0x5a,0x09,0xe9,0x02,0x49,0x09,0xe3,0x02,0x38,0x09,0xdd,0x02,0x27,0x09,0xd6,0x02,0x16,0x09,0xd0,0x02,0x05,0x09,0xca,0x02,0xf4,0x08,0xc4,0x02,0xe4,0x08,0xbd,0x02,0xd3,0x08,0xb7,0x02,0xc2,0x08,0xb1,0x02,0xb1,0x08,  \
    0xac,0x02,0x9f,0x08,0xa6,0x02,0x8e,0x08,0xa0,0x02,0x7d,0x08,0x9b,0x02,0x6c,0x08,0x95,0x02,0x5a,0x08,0x90,0x02,0x49,0x08,0x8a,0x02,0x38,0x08,0x85,0x02,0x27,0x08,0x80,0x02,0x16,0x08,0x7a,0x02,0x04,0x08,0x75,0x02,0xf3,0x07,0x70,0x02,0xe2,0x07,0x6b,0x02,0xd1,0x07,0x66,0x02,0xbf,0x07,0x61,0x02,0xae,0x07,0x5c,0x02,0x9d,0x07,0x57,0x02,0x8c,0x07,0x52,0x02,0x7a,0x07,0x4d,0x02,0x69,0x07,0x49,0x02,0x58,0x07,0x44,0x02,0x47,0x07,0x3f,0x02,0x35,0x07,0x3b,0x02,  \
    0x22,0x07,0x38,0x02,0x0f,0x07,0x34,0x02,0xfc,0x06,0x30,0x02,0xe9,0x06,0x2c,0x02,0xd6,0x06,0x28,0x02,0xc3,0x06,0x24,0x02,0xb0,0x06,0x20,0x02,0x9e,0x06,0x1d,0x02,0x8b,0x06,0x19,0x02,0x78,0x06,0x15,0x02,0x65,0x06,0x12,0x02,0x52,0x06,0x0e,0x02,0x3f,0x06,0x0b,0x02,0x2c,0x06,0x07,0x02,0x19,0x06,0x04,0x02,0x07,0x06,0x00,0x02,0xf4,0x05,0xfd,0x01,0xe1,0x05,0xf9,0x01,0xce,0x05,0xf6,0x01,0xbc,0x05,0xf3,0x01,0xa9,0x05,0xef,0x01,0x96,0x05,0xec,0x01,0x84,0x05,  \
    0xe9,0x01,0x71,0x05,0xe5,0x01,0x60,0x05,0xe2,0x01,0x4e,0x05,0xdf,0x01,0x3d,0x05,0xdb,0x01,0x2b,0x05,0xd8,0x01,0x1a,0x05,0xd5,0x01,0x08,0x05,0xd2,0x01,0xf7,0x04,0xcf,0x01,0xe5,0x04,0xcc,0x01,0xd4,0x04,0xc9,0x01,0xc2,0x04,0xc6,0x01,0xb1,0x04,0xc3,0x01,0x9f,0x04,0xc0,0x01,0x8e,0x04,0xbd,0x01,0x7c,0x04,0xba,0x01,0x6a,0x04,0xb7,0x01,0x59,0x04,0xb5,0x01,0x47,0x04,0xb2,0x01,0x36,0x04,0xaf,0x01,0x24,0x04,0xad,0x01,0x13,0x04,0xaa,0x01,0x01,0x04,0xa8,0x01,  \
    0xef,0x03,0xa5,0x01,0xde,0x03,0xa3,0x01,0xcc,0x03,0xa1,0x01,0xbb,0x03,0x9e,0x01,0xa9,0x03,0x9c,0x01,0x99,0x03,0x9a,0x01,0x88,0x03,0x97,0x01,0x77,0x03,0x95,0x01,0x66,0x03,0x93,0x01,0x56,0x03,0x91,0x01,0x45,0x03,0x8f,0x01,0x34,0x03,0x8d,0x01,0x23,0x03,0x8b,0x01,0x12,0x03,0x89,0x01,0x01,0x03,0x87,0x01,0xf0,0x02,0x85,0x01,0xdf,0x02,0x83,0x01,0xce,0x02,0x81,0x01,0xbd,0x02,0x80,0x01,0xac,0x02,0x7e,0x01,0x9a,0x02,0x7c,0x01,0x89,0x02,0x7b,0x01,0x78,0x02,  \
    0x79,0x01,0x66,0x02,0x78,0x01,0x55,0x02,0x76,0x01,0x44,0x02,0x75,0x01,0x32,0x02,0x74,0x01,0x21,0x02,0x72,0x01,0x0f,0x02,0x71,0x01,0xfe,0x01,0x70,0x01,0xec,0x01,0x6f,0x01,0xdb,0x01,0x6e,0x01,0xc8,0x01,0x6d,0x01,0xb6,0x01,0x6c,0x01,0xa4,0x01,0x6b,0x01,0x92,0x01,0x6a,0x01,0x7f,0x01,0x69,0x01,0x6d,0x01,0x68,0x01,0x5b,0x01,0x67,0x01,0x48,0x01,0x67,0x01,0x36,0x01,0x66,0x01,0x24,0x01,0x65,0x01,0x12,0x01,0x65,0x01,0xff,0x00,0x64,0x01,0xed,0x00,0x63,0x01,  \
    0xdb,0x00,0x63,0x01,0xc8,0x00,0x62,0x01,0xb6,0x00,0x62,0x01,0xa4,0x00,0x61,0x01,0x91,0x00,0x61,0x01,0x7f,0x00,0x61,0x01,0x6d,0x00,0x60,0x01,0x5a,0x00,0x60,0x01,0x48,0x00,0x60,0x01,0x36,0x00,0x60,0x01,0x23,0x00,0x60,0x01,0x11,0x00,0x5f,0x01,0xff,0xff,0x5f,0x01,0xed,0xff,0x5f,0x01,0xda,0xff,0x5f,0x01,0xc8,0xff,0x5f,0x01,0xb6,0xff,0x5f,0x01,0xa3,0xff,0x5f,0x01,0x91,0xff,0x5f,0x01,0x7f,0xff,0x60,0x01,0x6c,0xff,0x60,0x01,0x5a,0xff,0x60,0x01,0x48,0xff,  \
    0x60,0x01,0x35,0xff,0x60,0x01,0x23,0xff,0x61,0x01,0x11,0xff,0x61,0x01,0xfe,0xfe,0x62,0x01,0xec,0xfe,0x62,0x01,0xda,0xfe,0x62,0x01,0xc8,0xfe,0x63,0x01,0xb5,0xfe,0x63,0x01,0xa3,0xfe,0x64,0x01,0x91,0xfe,0x65,0x01,0x7e,0xfe,0x65,0x01,0x6c,0xfe,0x66,0x01,0x5a,0xfe,0x67,0x01,0x48,0xfe,0x67,0x01,0x35,0xfe,0x68,0x01,0x23,0xfe,0x69,0x01,0x11,0xfe,0x6a,0x01,0xff,0xfd,0x6b,0x01,0xec,0xfd,0x6c,0x01,0xda,0xfd,0x6d,0x01,0xc8,0xfd,0x6e,0x01,0xb5,0xfd,0x6f,0x01,  \
    0xa3,0xfd,0x70,0x01,0x90,0xfd,0x71,0x01,0x7d,0xfd,0x72,0x01,0x6b,0xfd,0x73,0x01,0x58,0xfd,0x74,0x01,0x46,0xfd,0x75,0x01,0x33,0xfd,0x77,0x01,0x20,0xfd,0x78,0x01,0x0e,0xfd,0x79,0x01,0xfb,0xfc,0x7a,0x01,0xe8,0xfc,0x7c,0x01,0xd5,0xfc,0x7d,0x01,0xc3,0xfc,0x7f,0x01,0xb0,0xfc,0x80,0x01,0x9d,0xfc,0x82,0x01,0x8a,0xfc,0x83,0x01,0x78,0xfc,0x85,0x01,0x65,0xfc,0x86,0x01,0x52,0xfc,0x88,0x01,0x3f,0xfc,0x89,0x01,0x2c,0xfc,0x8b,0x01,0x1a,0xfc,0x8d,0x01,0x07,0xfc,  \
    0x8f,0x01,0xf4,0xfb,0x90,0x01,0xe1,0xfb,0x92,0x01,0xce,0xfb,0x94,0x01,0xbc,0xfb,0x96,0x01,0xaa,0xfb,0x98,0x01,0x98,0xfb,0x9a,0x01,0x86,0xfb,0x9c,0x01,0x74,0xfb,0x9f,0x01,0x62,0xfb,0xa1,0x01,0x50,0xfb,0xa3,0x01,0x3e,0xfb,0xa5,0x01,0x2d,0xfb,0xa8,0x01,0x1b,0xfb,0xaa,0x01,0x09,0xfb,0xad,0x01,0xf7,0xfa,0xaf,0x01,0xe5,0xfa,0xb2,0x01,0xd3,0xfa,0xb4,0x01,0xc2,0xfa,0xb7,0x01,0xb0,0xfa,0xb9,0x01,0x9e,0xfa,0xbc,0x01,0x8c,0xfa,0xbf,0x01,0x7b,0xfa,0xc2,0x01,  \
    0x69,0xfa,0xc4,0x01,0x57,0xfa,0xc7,0x01,0x46,0xfa,0xca,0x01,0x34,0xfa,0xcd,0x01,0x22,0xfa,0xd0,0x01,0x11,0xfa,0xd3,0x01,0xff,0xf9,0xd6,0x01,0xed,0xf9,0xd9,0x01,0xdb,0xf9,0xdc,0x01,0xc8,0xf9,0xdf,0x01,0xb6,0xf9,0xe2,0x01,0xa4,0xf9,0xe5,0x01,0x91,0xf9,0xe9,0x01,0x7f,0xf9,0xec,0x01,0x6c,0xf9,0xef,0x01,0x5a,0xf9,0xf2,0x01,0x47,0xf9,0xf6,0x01,0x35,0xf9,0xf9,0x01,0x22,0xf9,0xfc,0x01,0x10,0xf9,0x00,0x02,0xfd,0xf8,0x03,0x02,0xeb,0xf8,0x07,0x02,0xd8,0xf8,  \
    0x0a,0x02,0xc6,0xf8,0x0e,0x02,0xb4,0xf8,0x11,0x02,0xa1,0xf8,0x15,0x02,0x8f,0xf8,0x19,0x02,0x7c,0xf8,0x1c,0x02,0x6a,0xf8,0x20,0x02,0x57,0xf8,0x24,0x02,0x45,0xf8,0x28,0x02,0x32,0xf8,0x2c,0x02,0x20,0xf8,0x30,0x02,0x0e,0xf8,0x34,0x02,0xfc,0xf7,0x38,0x02,0xea,0xf7,0x3d,0x02,0xd8,0xf7,0x41,0x02,0xc7,0xf7,0x45,0x02,0xb5,0xf7,0x4a,0x02,0xa3,0xf7,0x4e,0x02,0x91,0xf7,0x53,0x02,0x7f,0xf7,0x57,0x02,0x6d,0xf7,0x5c,0x02,0x5b,0xf7,0x60,0x02,0x49,0xf7,0x65,0x02,  \
    0x37,0xf7,0x6a,0x02,0x25,0xf7,0x6e,0x02,0x14,0xf7,0x73,0x02,0x02,0xf7,0x78,0x02,0xf0,0xf6,0x7d,0x02,0xde,0xf6,0x82,0x02,0xcc,0xf6,0x87,0x02,0xba,0xf6,0x8c,0x02,0xa8,0xf6,0x91,0x02,0x96,0xf6,0x96,0x02,0x84,0xf6,0x9b,0x02,0x71,0xf6,0xa0,0x02,0x5e,0xf6,0xa5,0x02,0x4b,0xf6,0xaa,0x02,0x38,0xf6,0xaf,0x02,0x26,0xf6,0xb4,0x02,0x13,0xf6,0xb9,0x02,0x00,0xf6,0xbe,0x02,0xed,0xf5,0xc3,0x02,0xda,0xf5,0xc8,0x02,0xc7,0xf5,0xce,0x02,0xb4,0xf5,0xd3,0x02,0xa1,0xf5,  \
    0xd8,0x02,0x8e,0xf5,0xde,0x02,0x7b,0xf5,0xe3,0x02,0x68,0xf5,0xe8,0x02,0x55,0xf5,0xee,0x02,0x42,0xf5,0xf3,0x02,0x2f,0xf5,0xf9,0x02,0x1c,0xf5,0xff,0x02,0x09,0xf5,0x04,0x03,0xf6,0xf4,0x0a,0x03,0xe4,0xf4,0x10,0x03,0xd1,0xf4,0x16,0x03,0xbf,0xf4,0x1c,0x03,0xac,0xf4,0x22,0x03,0x9a,0xf4,0x29,0x03,0x87,0xf4,0x2f,0x03,0x74,0xf4,0x35,0x03,0x61,0xf4,0x3b,0x03,0x4f,0xf4,0x41,0x03,0x3c,0xf4,0x48,0x03,0x29,0xf4,0x4e,0x03,0x16,0xf4,0x55,0x03,0x03,0xf4,0x5b,0x03,  \
    0xf0,0xf3,0x61,0x03,0xdd,0xf3,0x68,0x03,0xca,0xf3,0x6e,0x03,0xb7,0xf3,0x75,0x03,0xa4,0xf3,0x7b,0x03,0x91,0xf3,0x81,0x03,0x7c,0xf3,0x87,0x03,0x67,0xf3,0x8c,0x03,0x51,0xf3,0x92,0x03,0x3c,0xf3,0x97,0x03,0x26,0xf3,0x9d,0x03,0x11,0xf3,0xa2,0x03,0xfb,0xf2,0xa8,0x03,0xe6,0xf2,0xae,0x03,0xd0,0xf2,0xb3,0x03,0xba,0xf2,0xb9,0x03,0xa5,0xf2,0xbf,0x03,0x8f,0xf2,0xc4,0x03,0x79,0xf2,0xca,0x03,0x63,0xf2,0xcf,0x03,0x4d,0xf2,0xd5,0x03,0x37,0xf2,0xdb,0x03,0x21,0xf2,  \
    0xe0,0x03,0x0a,0xf2,0xe6,0x03,0xf5,0xf1,0xed,0x03,0xe1,0xf1,0xf4,0x03,0xcc,0xf1,0xfb,0x03,0xb8,0xf1,0x02,0x04,0xa3,0xf1,0x08,0x04,0x8f,0xf1,0x0f,0x04,0x7a,0xf1,0x16,0x04,0x65,0xf1,0x1d,0x04,0x50,0xf1,0x23,0x04,0x3b,0xf1,0x2a,0x04,0x26,0xf1,0x31,0x04,0x11,0xf1,0x38,0x04,0xfb,0xf0,0x3e,0x04,0xe6,0xf0,0x45,0x04,0xd0,0xf0,0x4b,0x04,0xbb,0xf0,0x52,0x04,0xa5,0xf0,0x59,0x04,0x8f,0xf0,0x5f,0x04,0x79,0xf0,0x66,0x04,0x63,0xf0,0x6c,0x04,0x4d,0xf0,0x73,0x04,  \
    0x37,0xf0,0x7a,0x04,0x21,0xf0,0x80,0x04,0x0b,0xf0,0x87,0x04,0xf4,0xef,0x8d,0x04,0xde,0xef,0x94,0x04,0xc7,0xef,0x9a,0x04,0xb0,0xef,0xa0,0x04,0x99,0xef,0xa6,0x04,0x82,0xef,0xac,0x04,0x6b,0xef,0xb2,0x04,0x53,0xef,0xb8,0x04,0x3c,0xef,0xbe,0x04,0x24,0xef,0xc4,0x04,0x0c,0xef,0xca,0x04,0xf4,0xee,0xcf,0x04,0xdc,0xee,0xd5,0x04,0xc3,0xee,0xda,0x04,0xab,0xee,0xdf,0x04,0x91,0xee,0xe3,0x04,0x77,0xee,0xe8,0x04,0x5d,0xee,0xec,0x04,0x43,0xee,0xf0,0x04,0x28,0xee,  \
    0xf4,0x04,0x0d,0xee,0xf8,0x04,0xf3,0xed,0xfc,0x04,0xd8,0xed,0xff,0x04,0xbc,0xed,0x03,0x05,0xa1,0xed,0x06,0x05,0x86,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x91,0x05,0x09,0x12,0x8d,0x05,  \
    0xee,0x11,0x88,0x05,0xd3,0x11,0x84,0x05,0xb8,0x11,0x80,0x05,0x9d,0x11,0x7b,0x05,0x82,0x11,0x76,0x05,0x68,0x11,0x71,0x05,0x4e,0x11,0x6c,0x05,0x33,0x11,0x67,0x05,0x19,0x11,0x62,0x05,0xff,0x10,0x5d,0x05,0xe5,0x10,0x58,0x05,0xcc,0x10,0x52,0x05,0xb2,0x10,0x4d,0x05,0x99,0x10,0x47,0x05,0x80,0x10,0x41,0x05,0x67,0x10,0x3b,0x05,0x4e,0x10,0x36,0x05,0x35,0x10,0x30,0x05,0x1c,0x10,0x29,0x05,0x04,0x10,0x23,0x05,0xec,0x0f,0x1c,0x05,0xd5,0x0f,0x15,0x05,0xbd,0x0f,  \
    0x0e,0x05,0xa6,0x0f,0x07,0x05,0x8f,0x0f,0x00,0x05,0x78,0x0f,0xf9,0x04,0x61,0x0f,0xf2,0x04,0x4a,0x0f,0xeb,0x04,0x33,0x0f,0xe3,0x04,0x1d,0x0f,0xdc,0x04,0x06,0x0f,0xd5,0x04,0xf0,0x0e,0xcd,0x04,0xda,0x0e,0xc6,0x04,0xc4,0x0e,0xbe,0x04,0xae,0x0e,0xb7,0x04,0x98,0x0e,0xaf,0x04,0x83,0x0e,0xa8,0x04,0x6d,0x0e,0xa0,0x04,0x58,0x0e,0x98,0x04,0x43,0x0e,0x8f,0x04,0x2f,0x0e,0x87,0x04,0x1b,0x0e,0x7e,0x04,0x07,0x0e,0x76,0x04,0xf3,0x0d,0x6d,0x04,0xe0,0x0d,0x65,0x04,  \
    0xcc,0x0d,0x5c,0x04,0xb9,0x0d,0x54,0x04,0xa5,0x0d,0x4b,0x04,0x92,0x0d,0x42,0x04,0x7f,0x0d,0x3a,0x04,0x6c,0x0d,0x31,0x04,0x5a,0x0d,0x29,0x04,0x47,0x0d,0x20,0x04,0x34,0x0d,0x18,0x04,0x22,0x0d,0x0f,0x04,0x0f,0x0d,0x07,0x04,0xfd,0x0c,0x00,0x04,0xe7,0x0c,0xfa,0x03,0xd1,0x0c,0xf4,0x03,0xbc,0x0c,0xed,0x03,0xa6,0x0c,0xe7,0x03,0x91,0x0c,0xe1,0x03,0x7b,0x0c,0xda,0x03,0x66,0x0c,0xd4,0x03,0x51,0x0c,0xce,0x03,0x3b,0x0c,0xc7,0x03,0x26,0x0c,0xc1,0x03,0x11,0x0c,  \
    0xbb,0x03,0xfc,0x0b,0xb5,0x03,0xe7,0x0b,0xae,0x03,0xd2,0x0b,0xa8,0x03,0xbd,0x0b,0xa2,0x03,0xa8,0x0b,0x9c,0x03,0x93,0x0b,0x96,0x03,0x7e,0x0b,0x90,0x03,0x69,0x0b,0x89,0x03,0x54,0x0b,0x83,0x03,0x40,0x0b,0x7d,0x03,0x2b,0x0b,0x77,0x03,0x16,0x0b,0x71,0x03,0x01,0x0b,0x6b,0x03,0xed,0x0a,0x65,0x03,0xd8,0x0a,0x5f,0x03,0xc4,0x0a,0x5a,0x03,0xaf,0x0a,0x54,0x03,0x9b,0x0a,0x4e,0x03,0x86,0x0a,0x48,0x03,0x72,0x0a,0x42,0x03,0x5d,0x0a,0x3c,0x03,0x49,0x0a,0x37,0x03,  \
    0x35,0x0a,0x31,0x03,0x21,0x0a,0x2b,0x03,0x0d,0x0a,0x24,0x03,0xfc,0x09,0x1d,0x03,0xeb,0x09,0x16,0x03,0xd9,0x09,0x0f,0x03,0xc8,0x09,0x08,0x03,0xb7,0x09,0x01,0x03,0xa6,0x09,0xfa,0x02,0x95,0x09,0xf3,0x02,0x84,0x09,0xed,0x02,0x73,0x09,0xe6,0x02,0x62,0x09,0xe0,0x02,0x51,0x09,0xd9,0x02,0x40,0x09,0xd3,0x02,0x2f,0x09,0xcc,0x02,0x1f,0x09,0xc6,0x02,0x0e,0x09,0xc0,0x02,0xfd,0x08,0xb9,0x02,0xec,0x08,0xb3,0x02,0xdb,0x08,0xad,0x02,0xca,0x08,0xa7,0x02,0xba,0x08,  \
    0xa1,0x02,0xa9,0x08,0x9b,0x02,0x97,0x08,0x96,0x02,0x86,0x08,0x90,0x02,0x75,0x08,0x8a,0x02,0x64,0x08,0x85,0x02,0x52,0x08,0x7f,0x02,0x41,0x08,0x7a,0x02,0x30,0x08,0x75,0x02,0x1f,0x08,0x6f,0x02,0x0d,0x08,0x6a,0x02,0xfc,0x07,0x65,0x02,0xeb,0x07,0x60,0x02,0xda,0x07,0x5a,0x02,0xc9,0x07,0x55,0x02,0xb7,0x07,0x50,0x02,0xa6,0x07,0x4b,0x02,0x95,0x07,0x47,0x02,0x84,0x07,0x42,0x02,0x73,0x07,0x3d,0x02,0x61,0x07,0x38,0x02,0x50,0x07,0x34,0x02,0x3f,0x07,0x2f,0x02,  \
    0x2e,0x07,0x2b,0x02,0x1b,0x07,0x27,0x02,0x08,0x07,0x23,0x02,0xf5,0x06,0x1f,0x02,0xe2,0x06,0x1b,0x02,0xcf,0x06,0x17,0x02,0xbc,0x06,0x13,0x02,0xa9,0x06,0x10,0x02,0x96,0x06,0x0c,0x02,0x84,0x06,0x08,0x02,0x71,0x06,0x05,0x02,0x5e,0x06,0x01,0x02,0x4b,0x06,0xfd,0x01,0x38,0x06,0xfa,0x01,0x26,0x06,0xf6,0x01,0x13,0x06,0xf3,0x01,0x00,0x06,0xef,0x01,0xee,0x05,0xec,0x01,0xdb,0x05,0xe8,0x01,0xc8,0x05,0xe5,0x01,0xb6,0x05,0xe2,0x01,0xa3,0x05,0xde,0x01,0x90,0x05,  \
    0xdb,0x01,0x7e,0x05,0xd8,0x01,0x6b,0x05,0xd4,0x01,0x5a,0x05,0xd1,0x01,0x48,0x05,0xce,0x01,0x37,0x05,0xca,0x01,0x26,0x05,0xc7,0x01,0x14,0x05,0xc4,0x01,0x03,0x05,0xc1,0x01,0xf1,0x04,0xbe,0x01,0xe0,0x04,0xba,0x01,0xce,0x04,0xb7,0x01,0xbd,0x04,0xb4,0x01,0xab,0x04,0xb2,0x01,0x9a,0x04,0xaf,0x01,0x88,0x04,0xac,0x01,0x77,0x04,0xa9,0x01,0x65,0x04,0xa6,0x01,0x54,0x04,0xa4,0x01,0x42,0x04,0xa1,0x01,0x31,0x04,0x9e,0x01,0x1f,0x04,0x9c,0x01,0x0e,0x04,0x99,0x01,  \
    0xfc,0x03,0x97,0x01,0xeb,0x03,0x94,0x01,0xd9,0x03,0x92,0x01,0xc8,0x03,0x8f,0x01,0xb6,0x03,0x8d,0x01,0xa5,0x03,0x8b,0x01,0x94,0x03,0x88,0x01,0x84,0x03,0x86,0x01,0x73,0x03,0x84,0x01,0x62,0x03,0x81,0x01,0x52,0x03,0x7f,0x01,0x41,0x03,0x7d,0x01,0x30,0x03,0x7b,0x01,0x1f,0x03,0x79,0x01,0x0e,0x03,0x77,0x01,0xfd,0x02,0x75,0x01,0xec,0x02,0x73,0x01,0xdb,0x02,0x72,0x01,0xca,0x02,0x70,0x01,0xb9,0x02,0x6e,0x01,0xa8,0x02,0x6d,0x01,0x97,0x02,0x6b,0x01,0x86,0x02,  \
    0x69,0x01,0x75,0x02,0x68,0x01,0x63,0x02,0x66,0x01,0x52,0x02,0x65,0x01,0x41,0x02,0x64,0x01,0x2f,0x02,0x62,0x01,0x1e,0x02,0x61,0x01,0x0d,0x02,0x60,0x01,0xfb,0x01,0x5f,0x01,0xea,0x01,0x5d,0x01,0xd8,0x01,0x5c,0x01,0xc6,0x01,0x5b,0x01,0xb4,0x01,0x5a,0x01,0xa2,0x01,0x59,0x01,0x8f,0x01,0x58,0x01,0x7d,0x01,0x58,0x01,0x6b,0x01,0x57,0x01,0x59,0x01,0x56,0x01,0x47,0x01,0x55,0x01,0x34,0x01,0x54,0x01,0x22,0x01,0x54,0x01,0x10,0x01,0x53,0x01,0xfe,0x00,0x52,0x01,  \
    0xec,0x00,0x52,0x01,0xd9,0x00,0x51,0x01,0xc7,0x00,0x51,0x01,0xb5,0x00,0x50,0x01,0xa3,0x00,0x50,0x01,0x90,0x00,0x50,0x01,0x7e,0x00,0x4f,0x01,0x6c,0x00,0x4f,0x01,0x5a,0x00,0x4f,0x01,0x47,0x00,0x4e,0x01,0x35,0x00,0x4e,0x01,0x23,0x00,0x4e,0x01,0x11,0x00,0x4e,0x01,0xff,0xff,0x4e,0x01,0xec,0xff,0x4e,0x01,0xda,0xff,0x4e,0x01,0xc8,0xff,0x4e,0x01,0xb6,0xff,0x4e,0x01,0xa3,0xff,0x4e,0x01,0x91,0xff,0x4e,0x01,0x7f,0xff,0x4e,0x01,0x6d,0xff,0x4e,0x01,0x5a,0xff,  \
    0x4e,0x01,0x48,0xff,0x4f,0x01,0x36,0xff,0x4f,0x01,0x24,0xff,0x4f,0x01,0x12,0xff,0x50,0x01,0xff,0xfe,0x50,0x01,0xed,0xfe,0x50,0x01,0xdb,0xfe,0x51,0x01,0xc9,0xfe,0x51,0x01,0xb7,0xfe,0x52,0x01,0xa4,0xfe,0x52,0x01,0x92,0xfe,0x53,0x01,0x80,0xfe,0x54,0x01,0x6e,0xfe,0x54,0x01,0x5c,0xfe,0x55,0x01,0x49,0xfe,0x56,0x01,0x37,0xfe,0x57,0x01,0x25,0xfe,0x57,0x01,0x13,0xfe,0x58,0x01,0x01,0xfe,0x59,0x01,0xef,0xfd,0x5a,0x01,0xdc,0xfd,0x5b,0x01,0xca,0xfd,0x5c,0x01,  \
    0xb8,0xfd,0x5d,0x01,0xa5,0xfd,0x5e,0x01,0x93,0xfd,0x5f,0x01,0x80,0xfd,0x60,0x01,0x6e,0xfd,0x61,0x01,0x5b,0xfd,0x63,0x01,0x49,0xfd,0x64,0x01,0x36,0xfd,0x65,0x01,0x23,0xfd,0x66,0x01,0x11,0xfd,0x68,0x01,0xfe,0xfc,0x69,0x01,0xec,0xfc,0x6a,0x01,0xd9,0xfc,0x6c,0x01,0xc6,0xfc,0x6d,0x01,0xb4,0xfc,0x6f,0x01,0xa1,0xfc,0x70,0x01,0x8e,0xfc,0x72,0x01,0x7c,0xfc,0x73,0x01,0x69,0xfc,0x75,0x01,0x56,0xfc,0x76,0x01,0x43,0xfc,0x78,0x01,0x31,0xfc,0x7a,0x01,0x1e,0xfc,  \
    0x7c,0x01,0x0b,0xfc,0x7d,0x01,0xf8,0xfb,0x7f,0x01,0xe6,0xfb,0x81,0x01,0xd3,0xfb,0x83,0x01,0xc1,0xfb,0x85,0x01,0xaf,0xfb,0x87,0x01,0x9d,0xfb,0x89,0x01,0x8b,0xfb,0x8b,0x01,0x79,0xfb,0x8d,0x01,0x67,0xfb,0x90,0x01,0x56,0xfb,0x92,0x01,0x44,0xfb,0x94,0x01,0x32,0xfb,0x97,0x01,0x20,0xfb,0x99,0x01,0x0e,0xfb,0x9b,0x01,0xfd,0xfa,0x9e,0x01,0xeb,0xfa,0xa0,0x01,0xd9,0xfa,0xa3,0x01,0xc8,0xfa,0xa6,0x01,0xb6,0xfa,0xa8,0x01,0xa4,0xfa,0xab,0x01,0x93,0xfa,0xae,0x01,  \
    0x81,0xfa,0xb1,0x01,0x6f,0xfa,0xb3,0x01,0x5e,0xfa,0xb6,0x01,0x4c,0xfa,0xb9,0x01,0x3a,0xfa,0xbc,0x01,0x29,0xfa,0xbf,0x01,0x17,0xfa,0xc2,0x01,0x06,0xfa,0xc5,0x01,0xf4,0xf9,0xc8,0x01,0xe2,0xf9,0xcb,0x01,0xcf,0xf9,0xce,0x01,0xbd,0xf9,0xd1,0x01,0xaa,0xf9,0xd4,0x01,0x98,0xf9,0xd8,0x01,0x86,0xf9,0xdb,0x01,0x73,0xf9,0xde,0x01,0x61,0xf9,0xe1,0x01,0x4e,0xf9,0xe5,0x01,0x3c,0xf9,0xe8,0x01,0x2a,0xf9,0xeb,0x01,0x17,0xf9,0xef,0x01,0x05,0xf9,0xf2,0x01,0xf3,0xf8,  \
    0xf6,0x01,0xe0,0xf8,0xf9,0x01,0xce,0xf8,0xfd,0x01,0xbb,0xf8,0x01,0x02,0xa9,0xf8,0x04,0x02,0x97,0xf8,0x08,0x02,0x84,0xf8,0x0c,0x02,0x72,0xf8,0x0f,0x02,0x5f,0xf8,0x13,0x02,0x4d,0xf8,0x17,0x02,0x3a,0xf8,0x1b,0x02,0x28,0xf8,0x1f,0x02,0x17,0xf8,0x23,0x02,0x05,0xf8,0x28,0x02,0xf3,0xf7,0x2c,0x02,0xe1,0xf7,0x30,0x02,0xcf,0xf7,0x35,0x02,0xbd,0xf7,0x39,0x02,0xab,0xf7,0x3d,0x02,0x99,0xf7,0x42,0x02,0x88,0xf7,0x46,0x02,0x76,0xf7,0x4b,0x02,0x64,0xf7,0x50,0x02,  \
    0x52,0xf7,0x54,0x02,0x40,0xf7,0x59,0x02,0x2e,0xf7,0x5e,0x02,0x1c,0xf7,0x62,0x02,0x0a,0xf7,0x67,0x02,0xf9,0xf6,0x6c,0x02,0xe7,0xf6,0x71,0x02,0xd5,0xf6,0x76,0x02,0xc3,0xf6,0x7b,0x02,0xb1,0xf6,0x80,0x02,0x9f,0xf6,0x85,0x02,0x8d,0xf6,0x8a,0x02,0x7a,0xf6,0x8f,0x02,0x67,0xf6,0x94,0x02,0x54,0xf6,0x99,0x02,0x42,0xf6,0x9e,0x02,0x2f,0xf6,0xa3,0x02,0x1c,0xf6,0xa8,0x02,0x09,0xf6,0xad,0x02,0xf6,0xf5,0xb2,0x02,0xe4,0xf5,0xb8,0x02,0xd1,0xf5,0xbd,0x02,0xbe,0xf5,  \
    0xc2,0x02,0xab,0xf5,0xc8,0x02,0x98,0xf5,0xcd,0x02,0x85,0xf5,0xd2,0x02,0x72,0xf5,0xd8,0x02,0x5f,0xf5,0xdd,0x02,0x4c,0xf5,0xe3,0x02,0x39,0xf5,0xe8,0x02,0x26,0xf5,0xee,0x02,0x13,0xf5,0xf4,0x02,0x00,0xf5,0xfa,0x02,0xee,0xf4,0x00,0x03,0xdb,0xf4,0x06,0x03,0xc8,0xf4,0x0c,0x03,0xb6,0xf4,0x12,0x03,0xa3,0xf4,0x18,0x03,0x91,0xf4,0x1e,0x03,0x7e,0xf4,0x24,0x03,0x6b,0xf4,0x2b,0x03,0x58,0xf4,0x31,0x03,0x46,0xf4,0x37,0x03,0x33,0xf4,0x3d,0x03,0x20,0xf4,0x44,0x03,  \
    0x0d,0xf4,0x4a,0x03,0xfa,0xf3,0x51,0x03,0xe7,0xf3,0x57,0x03,0xd4,0xf3,0x5e,0x03,0xc1,0xf3,0x64,0x03,0xae,0xf3,0x6b,0x03,0x9b,0xf3,0x70,0x03,0x86,0xf3,0x76,0x03,0x70,0xf3,0x7b,0x03,0x5b,0xf3,0x81,0x03,0x46,0xf3,0x87,0x03,0x30,0xf3,0x8c,0x03,0x1b,0xf3,0x92,0x03,0x05,0xf3,0x97,0x03,0xf0,0xf2,0x9d,0x03,0xda,0xf2,0xa2,0x03,0xc4,0xf2,0xa8,0x03,0xae,0xf2,0xae,0x03,0x99,0xf2,0xb3,0x03,0x83,0xf2,0xb9,0x03,0x6d,0xf2,0xbf,0x03,0x57,0xf2,0xc4,0x03,0x41,0xf2,  \
    0xca,0x03,0x2b,0xf2,0xcf,0x03,0x14,0xf2,0xd5,0x03,0xff,0xf1,0xdc,0x03,0xea,0xf1,0xe3,0x03,0xd6,0xf1,0xea,0x03,0xc2,0xf1,0xf1,0x03,0xad,0xf1,0xf7,0x03,0x98,0xf1,0xfe,0x03,0x83,0xf1,0x05,0x04,0x6f,0xf1,0x0b,0x04,0x5a,0xf1,0x12,0x04,0x45,0xf1,0x19,0x04,0x2f,0xf1,0x1f,0x04,0x1a,0xf1,0x26,0x04,0x05,0xf1,0x2d,0x04,0xef,0xf0,0x33,0x04,0xda,0xf0,0x3a,0x04,0xc4,0xf0,0x40,0x04,0xae,0xf0,0x47,0x04,0x98,0xf0,0x4d,0x04,0x82,0xf0,0x54,0x04,0x6c,0xf0,0x5b,0x04,  \
    0x56,0xf0,0x61,0x04,0x40,0xf0,0x68,0x04,0x2a,0xf0,0x6e,0x04,0x14,0xf0,0x75,0x04,0xfd,0xef,0x7b,0x04,0xe7,0xef,0x81,0x04,0xd0,0xef,0x88,0x04,0xb9,0xef,0x8e,0x04,0xa2,0xef,0x94,0x04,0x8b,0xef,0x9a,0x04,0x73,0xef,0xa0,0x04,0x5c,0xef,0xa6,0x04,0x44,0xef,0xac,0x04,0x2c,0xef,0xb1,0x04,0x14,0xef,0xb7,0x04,0xfc,0xee,0xbc,0x04,0xe4,0xee,0xc2,0x04,0xcb,0xee,0xc7,0x04,0xb3,0xee,0xcc,0x04,0x99,0xee,0xd1,0x04,0x7f,0xee,0xd5,0x04,0x65,0xee,0xd9,0x04,0x4b,0xee,  \
    0xdd,0x04,0x30,0xee,0xe1,0x04,0x15,0xee,0xe5,0x04,0xfa,0xed,0xe8,0x04,0xdf,0xed,0xec,0x04,0xc4,0xed,0xf0,0x04,0xa9,0xed,0xf3,0x04,0x8d,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7f,0x05,  \
    0x02,0x12,0x7b,0x05,0xe7,0x11,0x76,0x05,0xcc,0x11,0x72,0x05,0xb1,0x11,0x6e,0x05,0x96,0x11,0x69,0x05,0x7b,0x11,0x64,0x05,0x61,0x11,0x5f,0x05,0x46,0x11,0x5a,0x05,0x2c,0x11,0x55,0x05,0x12,0x11,0x50,0x05,0xf8,0x10,0x4b,0x05,0xde,0x10,0x46,0x05,0xc4,0x10,0x40,0x05,0xab,0x10,0x3b,0x05,0x92,0x10,0x35,0x05,0x78,0x10,0x30,0x05,0x5f,0x10,0x2a,0x05,0x46,0x10,0x24,0x05,0x2d,0x10,0x1e,0x05,0x14,0x10,0x18,0x05,0xfc,0x0f,0x11,0x05,0xe5,0x0f,0x0a,0x05,0xcd,0x0f,  \
    0x04,0x05,0xb5,0x0f,0xfd,0x04,0x9e,0x0f,0xf6,0x04,0x87,0x0f,0xef,0x04,0x70,0x0f,0xe8,0x04,0x59,0x0f,0xe1,0x04,0x42,0x0f,0xd9,0x04,0x2b,0x0f,0xd2,0x04,0x15,0x0f,0xcb,0x04,0xfe,0x0e,0xc4,0x04,0xe8,0x0e,0xbc,0x04,0xd2,0x0e,0xb5,0x04,0xbc,0x0e,0xad,0x04,0xa6,0x0e,0xa6,0x04,0x90,0x0e,0x9e,0x04,0x7a,0x0e,0x97,0x04,0x65,0x0e,0x8f,0x04,0x4f,0x0e,0x87,0x04,0x3a,0x0e,0x7f,0x04,0x26,0x0e,0x76,0x04,0x12,0x0e,0x6e,0x04,0xfe,0x0d,0x65,0x04,0xeb,0x0d,0x5d,0x04,  \
    0xd7,0x0d,0x54,0x04,0xc3,0x0d,0x4c,0x04,0xb0,0x0d,0x43,0x04,0x9d,0x0d,0x3b,0x04,0x89,0x0d,0x32,0x04,0x76,0x0d,0x2a,0x04,0x63,0x0d,0x21,0x04,0x50,0x0d,0x19,0x04,0x3e,0x0d,0x10,0x04,0x2b,0x0d,0x08,0x04,0x18,0x0d,0xff,0x03,0x06,0x0d,0xf7,0x03,0xf3,0x0c,0xf1,0x03,0xdd,0x0c,0xea,0x03,0xc8,0x0c,0xe4,0x03,0xb2,0x0c,0xdd,0x03,0x9d,0x0c,0xd7,0x03,0x87,0x0c,0xd1,0x03,0x72,0x0c,0xca,0x03,0x5d,0x0c,0xc4,0x03,0x47,0x0c,0xbe,0x03,0x32,0x0c,0xb7,0x03,0x1d,0x0c,  \
    0xb1,0x03,0x08,0x0c,0xab,0x03,0xf3,0x0b,0xa5,0x03,0xde,0x0b,0x9e,0x03,0xc9,0x0b,0x98,0x03,0xb4,0x0b,0x92,0x03,0x9f,0x0b,0x8c,0x03,0x8a,0x0b,0x86,0x03,0x75,0x0b,0x80,0x03,0x60,0x0b,0x7a,0x03,0x4b,0x0b,0x73,0x03,0x37,0x0b,0x6d,0x03,0x22,0x0b,0x67,0x03,0x0d,0x0b,0x61,0x03,0xf9,0x0a,0x5b,0x03,0xe4,0x0a,0x55,0x03,0xcf,0x0a,0x4f,0x03,0xbb,0x0a,0x49,0x03,0xa6,0x0a,0x44,0x03,0x92,0x0a,0x3e,0x03,0x7e,0x0a,0x38,0x03,0x69,0x0a,0x32,0x03,0x55,0x0a,0x2c,0x03,  \
    0x41,0x0a,0x26,0x03,0x2c,0x0a,0x21,0x03,0x18,0x0a,0x1b,0x03,0x05,0x0a,0x14,0x03,0xf3,0x09,0x0d,0x03,0xe2,0x09,0x06,0x03,0xd1,0x09,0xff,0x02,0xc0,0x09,0xf8,0x02,0xaf,0x09,0xf1,0x02,0x9e,0x09,0xea,0x02,0x8d,0x09,0xe3,0x02,0x7c,0x09,0xdd,0x02,0x6b,0x09,0xd6,0x02,0x5a,0x09,0xd0,0x02,0x49,0x09,0xc9,0x02,0x38,0x09,0xc3,0x02,0x27,0x09,0xbc,0x02,0x16,0x09,0xb6,0x02,0x05,0x09,0xb0,0x02,0xf4,0x08,0xa9,0x02,0xe4,0x08,0xa3,0x02,0xd3,0x08,0x9d,0x02,0xc2,0x08,  \
    0x97,0x02,0xb1,0x08,0x91,0x02,0xa0,0x08,0x8b,0x02,0x8f,0x08,0x86,0x02,0x7e,0x08,0x80,0x02,0x6c,0x08,0x7a,0x02,0x5b,0x08,0x75,0x02,0x4a,0x08,0x6f,0x02,0x39,0x08,0x6a,0x02,0x28,0x08,0x64,0x02,0x16,0x08,0x5f,0x02,0x05,0x08,0x5a,0x02,0xf4,0x07,0x55,0x02,0xe3,0x07,0x4f,0x02,0xd2,0x07,0x4a,0x02,0xc1,0x07,0x45,0x02,0xaf,0x07,0x40,0x02,0x9e,0x07,0x3b,0x02,0x8d,0x07,0x36,0x02,0x7c,0x07,0x32,0x02,0x6b,0x07,0x2d,0x02,0x5a,0x07,0x28,0x02,0x48,0x07,0x23,0x02,  \
    0x37,0x07,0x1f,0x02,0x26,0x07,0x1b,0x02,0x13,0x07,0x17,0x02,0x00,0x07,0x13,0x02,0xed,0x06,0x0f,0x02,0xdb,0x06,0x0b,0x02,0xc8,0x06,0x07,0x02,0xb5,0x06,0x03,0x02,0xa2,0x06,0xff,0x01,0x8f,0x06,0xfc,0x01,0x7d,0x06,0xf8,0x01,0x6a,0x06,0xf4,0x01,0x57,0x06,0xf0,0x01,0x44,0x06,0xed,0x01,0x32,0x06,0xe9,0x01,0x1f,0x06,0xe6,0x01,0x0c,0x06,0xe2,0x01,0xfa,0x05,0xdf,0x01,0xe7,0x05,0xdb,0x01,0xd4,0x05,0xd8,0x01,0xc2,0x05,0xd4,0x01,0xaf,0x05,0xd1,0x01,0x9d,0x05,  \
    0xce,0x01,0x8a,0x05,0xca,0x01,0x78,0x05,0xc7,0x01,0x65,0x05,0xc4,0x01,0x54,0x05,0xc0,0x01,0x43,0x05,0xbd,0x01,0x31,0x05,0xba,0x01,0x20,0x05,0xb6,0x01,0x0e,0x05,0xb3,0x01,0xfd,0x04,0xb0,0x01,0xec,0x04,0xad,0x01,0xda,0x04,0xaa,0x01,0xc9,0x04,0xa7,0x01,0xb8,0x04,0xa4,0x01,0xa6,0x04,0xa1,0x01,0x95,0x04,0x9e,0x01,0x83,0x04,0x9b,0x01,0x72,0x04,0x98,0x01,0x60,0x04,0x95,0x01,0x4f,0x04,0x93,0x01,0x3e,0x04,0x90,0x01,0x2c,0x04,0x8d,0x01,0x1b,0x04,0x8b,0x01,  \
    0x09,0x04,0x88,0x01,0xf8,0x03,0x86,0x01,0xe6,0x03,0x83,0x01,0xd5,0x03,0x81,0x01,0xc3,0x03,0x7e,0x01,0xb2,0x03,0x7c,0x01,0xa1,0x03,0x7a,0x01,0x90,0x03,0x77,0x01,0x80,0x03,0x75,0x01,0x6f,0x03,0x73,0x01,0x5e,0x03,0x71,0x01,0x4e,0x03,0x6e,0x01,0x3d,0x03,0x6c,0x01,0x2c,0x03,0x6a,0x01,0x1b,0x03,0x68,0x01,0x0a,0x03,0x66,0x01,0xfa,0x02,0x64,0x01,0xe9,0x02,0x62,0x01,0xd8,0x02,0x61,0x01,0xc7,0x02,0x5f,0x01,0xb6,0x02,0x5d,0x01,0xa5,0x02,0x5c,0x01,0x94,0x02,  \
    0x5a,0x01,0x83,0x02,0x58,0x01,0x71,0x02,0x57,0x01,0x60,0x02,0x55,0x01,0x4f,0x02,0x54,0x01,0x3e,0x02,0x53,0x01,0x2d,0x02,0x51,0x01,0x1b,0x02,0x50,0x01,0x0a,0x02,0x4f,0x01,0xf8,0x01,0x4d,0x01,0xe7,0x01,0x4c,0x01,0xd6,0x01,0x4b,0x01,0xc4,0x01,0x4a,0x01,0xb1,0x01,0x49,0x01,0x9f,0x01,0x48,0x01,0x8d,0x01,0x47,0x01,0x7b,0x01,0x46,0x01,0x69,0x01,0x46,0x01,0x57,0x01,0x45,0x01,0x45,0x01,0x44,0x01,0x33,0x01,0x43,0x01,0x20,0x01,0x43,0x01,0x0e,0x01,0x42,0x01,  \
    0xfc,0x00,0x41,0x01,0xea,0x00,0x41,0x01,0xd8,0x00,0x40,0x01,0xc6,0x00,0x40,0x01,0xb4,0x00,0x3f,0x01,0xa2,0x00,0x3f,0x01,0x8f,0x00,0x3e,0x01,0x7d,0x00,0x3e,0x01,0x6b,0x00,0x3e,0x01,0x59,0x00,0x3d,0x01,0x47,0x00,0x3d,0x01,0x35,0x00,0x3d,0x01,0x23,0x00,0x3d,0x01,0x10,0x00,0x3d,0x01,0xfe,0xff,0x3c,0x01,0xec,0xff,0x3c,0x01,0xda,0xff,0x3c,0x01,0xc8,0xff,0x3c,0x01,0xb6,0xff,0x3c,0x01,0xa4,0xff,0x3c,0x01,0x91,0xff,0x3d,0x01,0x7f,0xff,0x3d,0x01,0x6d,0xff,  \
    0x3d,0x01,0x5b,0xff,0x3d,0x01,0x49,0xff,0x3d,0x01,0x37,0xff,0x3e,0x01,0x25,0xff,0x3e,0x01,0x12,0xff,0x3e,0x01,0x00,0xff,0x3f,0x01,0xee,0xfe,0x3f,0x01,0xdc,0xfe,0x40,0x01,0xca,0xfe,0x40,0x01,0xb8,0xfe,0x41,0x01,0xa6,0xfe,0x41,0x01,0x94,0xfe,0x42,0x01,0x81,0xfe,0x43,0x01,0x6f,0xfe,0x43,0x01,0x5d,0xfe,0x44,0x01,0x4b,0xfe,0x45,0x01,0x39,0xfe,0x45,0x01,0x27,0xfe,0x46,0x01,0x15,0xfe,0x47,0x01,0x03,0xfe,0x48,0x01,0xf1,0xfd,0x49,0x01,0xdf,0xfd,0x4a,0x01,  \
    0xcc,0xfd,0x4b,0x01,0xba,0xfd,0x4c,0x01,0xa8,0xfd,0x4d,0x01,0x95,0xfd,0x4e,0x01,0x83,0xfd,0x4f,0x01,0x70,0xfd,0x50,0x01,0x5e,0xfd,0x51,0x01,0x4c,0xfd,0x53,0x01,0x39,0xfd,0x54,0x01,0x27,0xfd,0x55,0x01,0x14,0xfd,0x57,0x01,0x02,0xfd,0x58,0x01,0xef,0xfc,0x59,0x01,0xdd,0xfc,0x5b,0x01,0xca,0xfc,0x5c,0x01,0xb7,0xfc,0x5e,0x01,0xa5,0xfc,0x5f,0x01,0x92,0xfc,0x61,0x01,0x80,0xfc,0x62,0x01,0x6d,0xfc,0x64,0x01,0x5a,0xfc,0x65,0x01,0x48,0xfc,0x67,0x01,0x35,0xfc,  \
    0x69,0x01,0x22,0xfc,0x6b,0x01,0x10,0xfc,0x6c,0x01,0xfd,0xfb,0x6e,0x01,0xea,0xfb,0x70,0x01,0xd8,0xfb,0x72,0x01,0xc6,0xfb,0x74,0x01,0xb4,0xfb,0x76,0x01,0xa2,0xfb,0x78,0x01,0x90,0xfb,0x7a,0x01,0x7f,0xfb,0x7d,0x01,0x6d,0xfb,0x7f,0x01,0x5b,0xfb,0x81,0x01,0x49,0xfb,0x83,0x01,0x38,0xfb,0x86,0x01,0x26,0xfb,0x88,0x01,0x14,0xfb,0x8b,0x01,0x02,0xfb,0x8d,0x01,0xf1,0xfa,0x90,0x01,0xdf,0xfa,0x92,0x01,0xcd,0xfa,0x95,0x01,0xbc,0xfa,0x98,0x01,0xaa,0xfa,0x9a,0x01,  \
    0x99,0xfa,0x9d,0x01,0x87,0xfa,0xa0,0x01,0x75,0xfa,0xa3,0x01,0x64,0xfa,0xa6,0x01,0x52,0xfa,0xa8,0x01,0x41,0xfa,0xab,0x01,0x2f,0xfa,0xae,0x01,0x1e,0xfa,0xb2,0x01,0x0c,0xfa,0xb5,0x01,0xfb,0xf9,0xb8,0x01,0xe8,0xf9,0xbb,0x01,0xd6,0xf9,0xbe,0x01,0xc4,0xf9,0xc1,0x01,0xb1,0xf9,0xc4,0x01,0x9f,0xf9,0xc7,0x01,0x8d,0xf9,0xca,0x01,0x7a,0xf9,0xcd,0x01,0x68,0xf9,0xd1,0x01,0x56,0xf9,0xd4,0x01,0x43,0xf9,0xd7,0x01,0x31,0xf9,0xdb,0x01,0x1f,0xf9,0xde,0x01,0x0c,0xf9,  \
    0xe2,0x01,0xfa,0xf8,0xe5,0x01,0xe8,0xf8,0xe9,0x01,0xd6,0xf8,0xec,0x01,0xc3,0xf8,0xf0,0x01,0xb1,0xf8,0xf4,0x01,0x9e,0xf8,0xf7,0x01,0x8c,0xf8,0xfb,0x01,0x7a,0xf8,0xff,0x01,0x67,0xf8,0x03,0x02,0x55,0xf8,0x07,0x02,0x43,0xf8,0x0b,0x02,0x31,0xf8,0x0f,0x02,0x1f,0xf8,0x13,0x02,0x0d,0xf8,0x17,0x02,0xfb,0xf7,0x1c,0x02,0xe9,0xf7,0x20,0x02,0xd8,0xf7,0x24,0x02,0xc6,0xf7,0x29,0x02,0xb4,0xf7,0x2d,0x02,0xa2,0xf7,0x32,0x02,0x90,0xf7,0x36,0x02,0x7e,0xf7,0x3b,0x02,  \
    0x6d,0xf7,0x3f,0x02,0x5b,0xf7,0x44,0x02,0x49,0xf7,0x49,0x02,0x37,0xf7,0x4d,0x02,0x25,0xf7,0x52,0x02,0x13,0xf7,0x57,0x02,0x02,0xf7,0x5c,0x02,0xf0,0xf6,0x61,0x02,0xde,0xf6,0x66,0x02,0xcc,0xf6,0x6b,0x02,0xba,0xf6,0x70,0x02,0xa8,0xf6,0x75,0x02,0x96,0xf6,0x7a,0x02,0x83,0xf6,0x7f,0x02,0x70,0xf6,0x84,0x02,0x5e,0xf6,0x89,0x02,0x4b,0xf6,0x8e,0x02,0x38,0xf6,0x93,0x02,0x25,0xf6,0x98,0x02,0x13,0xf6,0x9d,0x02,0x00,0xf6,0xa2,0x02,0xed,0xf5,0xa7,0x02,0xda,0xf5,  \
    0xad,0x02,0xc7,0xf5,0xb2,0x02,0xb4,0xf5,0xb7,0x02,0xa2,0xf5,0xbd,0x02,0x8f,0xf5,0xc2,0x02,0x7c,0xf5,0xc8,0x02,0x69,0xf5,0xcd,0x02,0x56,0xf5,0xd3,0x02,0x43,0xf5,0xd8,0x02,0x30,0xf5,0xde,0x02,0x1d,0xf5,0xe4,0x02,0x0a,0xf5,0xe9,0x02,0xf7,0xf4,0xef,0x02,0xe5,0xf4,0xf5,0x02,0xd2,0xf4,0xfb,0x02,0xc0,0xf4,0x02,0x03,0xad,0xf4,0x08,0x03,0x9a,0xf4,0x0e,0x03,0x88,0xf4,0x14,0x03,0x75,0xf4,0x1a,0x03,0x62,0xf4,0x20,0x03,0x50,0xf4,0x27,0x03,0x3d,0xf4,0x2d,0x03,  \
    0x2a,0xf4,0x33,0x03,0x17,0xf4,0x3a,0x03,0x04,0xf4,0x40,0x03,0xf1,0xf3,0x47,0x03,0xde,0xf3,0x4d,0x03,0xcb,0xf3,0x54,0x03,0xb8,0xf3,0x5a,0x03,0xa4,0xf3,0x60,0x03,0x8f,0xf3,0x65,0x03,0x7a,0xf3,0x6b,0x03,0x65,0xf3,0x70,0x03,0x4f,0xf3,0x76,0x03,0x3a,0xf3,0x7c,0x03,0x25,0xf3,0x81,0x03,0x0f,0xf3,0x87,0x03,0xf9,0xf2,0x8c,0x03,0xe4,0xf2,0x92,0x03,0xce,0xf2,0x98,0x03,0xb8,0xf2,0x9d,0x03,0xa3,0xf2,0xa3,0x03,0x8d,0xf2,0xa8,0x03,0x77,0xf2,0xae,0x03,0x61,0xf2,  \
    0xb4,0x03,0x4b,0xf2,0xb9,0x03,0x35,0xf2,0xbf,0x03,0x1e,0xf2,0xc5,0x03,0x09,0xf2,0xcc,0x03,0xf4,0xf1,0xd2,0x03,0xe0,0xf1,0xd9,0x03,0xcb,0xf1,0xe0,0x03,0xb7,0xf1,0xe6,0x03,0xa2,0xf1,0xed,0x03,0x8d,0xf1,0xf4,0x03,0x78,0xf1,0xfa,0x03,0x63,0xf1,0x01,0x04,0x4e,0xf1,0x08,0x04,0x39,0xf1,0x0e,0x04,0x24,0xf1,0x15,0x04,0x0e,0xf1,0x1c,0x04,0xf9,0xf0,0x22,0x04,0xe3,0xf0,0x29,0x04,0xcd,0xf0,0x2f,0x04,0xb7,0xf0,0x36,0x04,0xa1,0xf0,0x3c,0x04,0x8b,0xf0,0x43,0x04,  \
    0x75,0xf0,0x49,0x04,0x5f,0xf0,0x50,0x04,0x49,0xf0,0x56,0x04,0x33,0xf0,0x5d,0x04,0x1d,0xf0,0x63,0x04,0x06,0xf0,0x69,0x04,0xef,0xef,0x6f,0x04,0xd9,0xef,0x76,0x04,0xc2,0xef,0x7c,0x04,0xaa,0xef,0x82,0x04,0x93,0xef,0x88,0x04,0x7c,0xef,0x8e,0x04,0x64,0xef,0x94,0x04,0x4d,0xef,0x99,0x04,0x35,0xef,0x9f,0x04,0x1d,0xef,0xa5,0x04,0x04,0xef,0xaa,0x04,0xec,0xee,0xaf,0x04,0xd3,0xee,0xb5,0x04,0xbb,0xee,0xba,0x04,0xa1,0xee,0xbe,0x04,0x87,0xee,0xc2,0x04,0x6d,0xee,  \
    0xc6,0x04,0x53,0xee,0xca,0x04,0x38,0xee,0xce,0x04,0x1d,0xee,0xd2,0x04,0x02,0xee,0xd5,0x04,0xe7,0xed,0xd9,0x04,0xcc,0xed,0xdd,0x04,0xb1,0xed,0xe0,0x04,0x95,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x6d,0x05,0xfb,0x11,0x69,0x05,0xe0,0x11,0x64,0x05,0xc5,0x11,0x60,0x05,0xaa,0x11,0x5c,0x05,0x8f,0x11,0x57,0x05,0x74,0x11,0x52,0x05,0x5a,0x11,0x4e,0x05,0x3f,0x11,0x49,0x05,0x25,0x11,0x44,0x05,0x0b,0x11,0x3f,0x05,0xf1,0x10,0x39,0x05,0xd7,0x10,0x34,0x05,0xbd,0x10,0x2f,0x05,0xa4,0x10,0x29,0x05,0x8a,0x10,0x24,0x05,0x71,0x10,0x1e,0x05,0x58,0x10,0x18,0x05,0x3f,0x10,0x13,0x05,0x26,0x10,0x0d,0x05,0x0d,0x10,0x06,0x05,0xf5,0x0f,0x00,0x05,0xdd,0x0f,  \
    0xf9,0x04,0xc5,0x0f,0xf2,0x04,0xae,0x0f,0xec,0x04,0x96,0x0f,0xe5,0x04,0x7f,0x0f,0xde,0x04,0x68,0x0f,0xd7,0x04,0x51,0x0f,0xd0,0x04,0x3a,0x0f,0xc9,0x04,0x23,0x0f,0xc1,0x04,0x0d,0x0f,0xba,0x04,0xf6,0x0e,0xb3,0x04,0xe0,0x0e,0xac,0x04,0xca,0x0e,0xa4,0x04,0xb4,0x0e,0x9d,0x04,0x9e,0x0e,0x95,0x04,0x88,0x0e,0x8e,0x04,0x72,0x0e,0x86,0x04,0x5c,0x0e,0x7f,0x04,0x47,0x0e,0x77,0x04,0x32,0x0e,0x6f,0x04,0x1e,0x0e,0x66,0x04,0x0a,0x0e,0x5e,0x04,0xf6,0x0d,0x55,0x04,  \
    0xe2,0x0d,0x4d,0x04,0xce,0x0d,0x44,0x04,0xba,0x0d,0x3c,0x04,0xa7,0x0d,0x34,0x04,0x94,0x0d,0x2b,0x04,0x80,0x0d,0x23,0x04,0x6d,0x0d,0x1a,0x04,0x5a,0x0d,0x12,0x04,0x47,0x0d,0x09,0x04,0x34,0x0d,0x01,0x04,0x22,0x0d,0xf8,0x03,0x0f,0x0d,0xf0,0x03,0xfd,0x0c,0xe7,0x03,0xea,0x0c,0xe1,0x03,0xd4,0x0c,0xdb,0x03,0xbe,0x0c,0xd4,0x03,0xa9,0x0c,0xce,0x03,0x93,0x0c,0xc8,0x03,0x7e,0x0c,0xc1,0x03,0x69,0x0c,0xbb,0x03,0x53,0x0c,0xb5,0x03,0x3e,0x0c,0xae,0x03,0x29,0x0c,  \
    0xa8,0x03,0x14,0x0c,0xa2,0x03,0xfe,0x0b,0x9b,0x03,0xe9,0x0b,0x95,0x03,0xd4,0x0b,0x8f,0x03,0xbf,0x0b,0x89,0x03,0xaa,0x0b,0x82,0x03,0x95,0x0b,0x7c,0x03,0x81,0x0b,0x76,0x03,0x6c,0x0b,0x70,0x03,0x57,0x0b,0x6a,0x03,0x42,0x0b,0x64,0x03,0x2e,0x0b,0x5e,0x03,0x19,0x0b,0x58,0x03,0x04,0x0b,0x52,0x03,0xf0,0x0a,0x4c,0x03,0xdb,0x0a,0x46,0x03,0xc7,0x0a,0x40,0x03,0xb2,0x0a,0x3a,0x03,0x9e,0x0a,0x34,0x03,0x89,0x0a,0x2e,0x03,0x75,0x0a,0x28,0x03,0x61,0x0a,0x22,0x03,  \
    0x4c,0x0a,0x1c,0x03,0x38,0x0a,0x17,0x03,0x24,0x0a,0x11,0x03,0x10,0x0a,0x0b,0x03,0xfc,0x09,0x04,0x03,0xeb,0x09,0xfd,0x02,0xda,0x09,0xf6,0x02,0xc9,0x09,0xef,0x02,0xb7,0x09,0xe8,0x02,0xa6,0x09,0xe1,0x02,0x95,0x09,0xda,0x02,0x84,0x09,0xd4,0x02,0x73,0x09,0xcd,0x02,0x62,0x09,0xc6,0x02,0x51,0x09,0xc0,0x02,0x40,0x09,0xb9,0x02,0x2f,0x09,0xb3,0x02,0x1f,0x09,0xac,0x02,0x0e,0x09,0xa6,0x02,0xfd,0x08,0xa0,0x02,0xec,0x08,0x9a,0x02,0xdb,0x08,0x93,0x02,0xca,0x08,  \
    0x8d,0x02,0xba,0x08,0x87,0x02,0xa9,0x08,0x81,0x02,0x98,0x08,0x7c,0x02,0x86,0x08,0x76,0x02,0x75,0x08,0x70,0x02,0x64,0x08,0x6b,0x02,0x53,0x08,0x65,0x02,0x42,0x08,0x60,0x02,0x31,0x08,0x5a,0x02,0x1f,0x08,0x55,0x02,0x0e,0x08,0x4f,0x02,0xfd,0x07,0x4a,0x02,0xec,0x07,0x45,0x02,0xdb,0x07,0x40,0x02,0xca,0x07,0x3b,0x02,0xb9,0x07,0x35,0x02,0xa7,0x07,0x30,0x02,0x96,0x07,0x2b,0x02,0x85,0x07,0x27,0x02,0x74,0x07,0x22,0x02,0x63,0x07,0x1d,0x02,0x52,0x07,0x18,0x02,  \
    0x41,0x07,0x13,0x02,0x2f,0x07,0x0f,0x02,0x1e,0x07,0x0b,0x02,0x0b,0x07,0x07,0x02,0xf9,0x06,0x03,0x02,0xe6,0x06,0xff,0x01,0xd3,0x06,0xfb,0x01,0xc0,0x06,0xf7,0x01,0xae,0x06,0xf3,0x01,0x9b,0x06,0xef,0x01,0x88,0x06,0xeb,0x01,0x75,0x06,0xe8,0x01,0x63,0x06,0xe4,0x01,0x50,0x06,0xe0,0x01,0x3d,0x06,0xdd,0x01,0x2b,0x06,0xd9,0x01,0x18,0x06,0xd6,0x01,0x06,0x06,0xd2,0x01,0xf3,0x05,0xce,0x01,0xe1,0x05,0xcb,0x01,0xce,0x05,0xc8,0x01,0xbb,0x05,0xc4,0x01,0xa9,0x05,  \
    0xc1,0x01,0x97,0x05,0xbe,0x01,0x84,0x05,0xba,0x01,0x72,0x05,0xb7,0x01,0x5f,0x05,0xb3,0x01,0x4e,0x05,0xb0,0x01,0x3d,0x05,0xad,0x01,0x2b,0x05,0xa9,0x01,0x1a,0x05,0xa6,0x01,0x09,0x05,0xa3,0x01,0xf7,0x04,0xa0,0x01,0xe6,0x04,0x9c,0x01,0xd5,0x04,0x99,0x01,0xc3,0x04,0x96,0x01,0xb2,0x04,0x93,0x01,0xa1,0x04,0x90,0x01,0x8f,0x04,0x8d,0x01,0x7e,0x04,0x8b,0x01,0x6d,0x04,0x88,0x01,0x5b,0x04,0x85,0x01,0x4a,0x04,0x82,0x01,0x39,0x04,0x80,0x01,0x27,0x04,0x7d,0x01,  \
    0x16,0x04,0x7a,0x01,0x04,0x04,0x78,0x01,0xf3,0x03,0x75,0x01,0xe2,0x03,0x73,0x01,0xd0,0x03,0x70,0x01,0xbf,0x03,0x6e,0x01,0xae,0x03,0x6c,0x01,0x9c,0x03,0x69,0x01,0x8c,0x03,0x67,0x01,0x7b,0x03,0x64,0x01,0x6b,0x03,0x62,0x01,0x5a,0x03,0x60,0x01,0x49,0x03,0x5e,0x01,0x39,0x03,0x5c,0x01,0x28,0x03,0x5a,0x01,0x17,0x03,0x58,0x01,0x07,0x03,0x56,0x01,0xf6,0x02,0x54,0x01,0xe5,0x02,0x52,0x01,0xd4,0x02,0x50,0x01,0xc3,0x02,0x4e,0x01,0xb2,0x02,0x4d,0x01,0xa1,0x02,  \
    0x4b,0x01,0x90,0x02,0x49,0x01,0x7f,0x02,0x48,0x01,0x6e,0x02,0x46,0x01,0x5d,0x02,0x45,0x01,0x4c,0x02,0x43,0x01,0x3b,0x02,0x42,0x01,0x2a,0x02,0x40,0x01,0x18,0x02,0x3f,0x01,0x07,0x02,0x3e,0x01,0xf6,0x01,0x3d,0x01,0xe4,0x01,0x3c,0x01,0xd3,0x01,0x3a,0x01,0xc1,0x01,0x39,0x01,0xaf,0x01,0x38,0x01,0x9d,0x01,0x37,0x01,0x8b,0x01,0x37,0x01,0x79,0x01,0x36,0x01,0x67,0x01,0x35,0x01,0x55,0x01,0x34,0x01,0x43,0x01,0x33,0x01,0x31,0x01,0x32,0x01,0x1f,0x01,0x32,0x01,  \
    0x0d,0x01,0x31,0x01,0xfb,0x00,0x30,0x01,0xe9,0x00,0x30,0x01,0xd7,0x00,0x2f,0x01,0xc5,0x00,0x2f,0x01,0xb3,0x00,0x2e,0x01,0xa0,0x00,0x2e,0x01,0x8e,0x00,0x2e,0x01,0x7c,0x00,0x2d,0x01,0x6a,0x00,0x2d,0x01,0x58,0x00,0x2d,0x01,0x46,0x00,0x2c,0x01,0x34,0x00,0x2c,0x01,0x22,0x00,0x2c,0x01,0x10,0x00,0x2c,0x01,0xfe,0xff,0x2c,0x01,0xec,0xff,0x2c,0x01,0xda,0xff,0x2c,0x01,0xc8,0xff,0x2c,0x01,0xb6,0xff,0x2c,0x01,0xa4,0xff,0x2c,0x01,0x92,0xff,0x2c,0x01,0x80,0xff,  \
    0x2c,0x01,0x6e,0xff,0x2c,0x01,0x5b,0xff,0x2c,0x01,0x49,0xff,0x2d,0x01,0x37,0xff,0x2d,0x01,0x25,0xff,0x2d,0x01,0x13,0xff,0x2e,0x01,0x01,0xff,0x2e,0x01,0xef,0xfe,0x2e,0x01,0xdd,0xfe,0x2f,0x01,0xcb,0xfe,0x2f,0x01,0xb9,0xfe,0x30,0x01,0xa7,0xfe,0x30,0x01,0x95,0xfe,0x31,0x01,0x83,0xfe,0x32,0x01,0x71,0xfe,0x32,0x01,0x5f,0xfe,0x33,0x01,0x4d,0xfe,0x34,0x01,0x3b,0xfe,0x35,0x01,0x29,0xfe,0x35,0x01,0x17,0xfe,0x36,0x01,0x05,0xfe,0x37,0x01,0xf3,0xfd,0x38,0x01,  \
    0xe1,0xfd,0x39,0x01,0xcf,0xfd,0x3a,0x01,0xbd,0xfd,0x3b,0x01,0xaa,0xfd,0x3c,0x01,0x98,0xfd,0x3d,0x01,0x86,0xfd,0x3e,0x01,0x73,0xfd,0x40,0x01,0x61,0xfd,0x41,0x01,0x4f,0xfd,0x42,0x01,0x3c,0xfd,0x43,0x01,0x2a,0xfd,0x45,0x01,0x17,0xfd,0x46,0x01,0x05,0xfd,0x47,0x01,0xf3,0xfc,0x49,0x01,0xe0,0xfc,0x4a,0x01,0xce,0xfc,0x4b,0x01,0xbb,0xfc,0x4d,0x01,0xa9,0xfc,0x4e,0x01,0x96,0xfc,0x50,0x01,0x84,0xfc,0x52,0x01,0x71,0xfc,0x53,0x01,0x5f,0xfc,0x55,0x01,0x4c,0xfc,  \
    0x57,0x01,0x3a,0xfc,0x58,0x01,0x27,0xfc,0x5a,0x01,0x14,0xfc,0x5c,0x01,0x02,0xfc,0x5e,0x01,0xef,0xfb,0x5f,0x01,0xdd,0xfb,0x61,0x01,0xcb,0xfb,0x63,0x01,0xb9,0xfb,0x66,0x01,0xa7,0xfb,0x68,0x01,0x96,0xfb,0x6a,0x01,0x84,0xfb,0x6c,0x01,0x72,0xfb,0x6e,0x01,0x60,0xfb,0x71,0x01,0x4f,0xfb,0x73,0x01,0x3d,0xfb,0x75,0x01,0x2b,0xfb,0x78,0x01,0x1a,0xfb,0x7a,0x01,0x08,0xfb,0x7d,0x01,0xf7,0xfa,0x7f,0x01,0xe5,0xfa,0x82,0x01,0xd3,0xfa,0x84,0x01,0xc2,0xfa,0x87,0x01,  \
    0xb0,0xfa,0x8a,0x01,0x9f,0xfa,0x8d,0x01,0x8d,0xfa,0x8f,0x01,0x7c,0xfa,0x92,0x01,0x6a,0xfa,0x95,0x01,0x59,0xfa,0x98,0x01,0x47,0xfa,0x9b,0x01,0x36,0xfa,0x9e,0x01,0x25,0xfa,0xa1,0x01,0x13,0xfa,0xa4,0x01,0x01,0xfa,0xa7,0x01,0xef,0xf9,0xaa,0x01,0xdd,0xf9,0xad,0x01,0xcb,0xf9,0xb0,0x01,0xb8,0xf9,0xb4,0x01,0xa6,0xf9,0xb7,0x01,0x94,0xf9,0xba,0x01,0x82,0xf9,0xbd,0x01,0x6f,0xf9,0xc1,0x01,0x5d,0xf9,0xc4,0x01,0x4b,0xf9,0xc7,0x01,0x39,0xf9,0xcb,0x01,0x26,0xf9,  \
    0xce,0x01,0x14,0xf9,0xd2,0x01,0x02,0xf9,0xd5,0x01,0xf0,0xf8,0xd9,0x01,0xdd,0xf8,0xdc,0x01,0xcb,0xf8,0xe0,0x01,0xb9,0xf8,0xe4,0x01,0xa7,0xf8,0xe7,0x01,0x94,0xf8,0xeb,0x01,0x82,0xf8,0xef,0x01,0x70,0xf8,0xf3,0x01,0x5d,0xf8,0xf7,0x01,0x4b,0xf8,0xfb,0x01,0x39,0xf8,0xff,0x01,0x27,0xf8,0x03,0x02,0x16,0xf8,0x07,0x02,0x04,0xf8,0x0c,0x02,0xf2,0xf7,0x10,0x02,0xe0,0xf7,0x14,0x02,0xcf,0xf7,0x19,0x02,0xbd,0xf7,0x1d,0x02,0xab,0xf7,0x22,0x02,0x99,0xf7,0x26,0x02,  \
    0x87,0xf7,0x2b,0x02,0x76,0xf7,0x2f,0x02,0x64,0xf7,0x34,0x02,0x52,0xf7,0x39,0x02,0x40,0xf7,0x3d,0x02,0x2e,0xf7,0x42,0x02,0x1d,0xf7,0x47,0x02,0x0b,0xf7,0x4c,0x02,0xf9,0xf6,0x51,0x02,0xe7,0xf6,0x56,0x02,0xd5,0xf6,0x5b,0x02,0xc3,0xf6,0x60,0x02,0xb2,0xf6,0x65,0x02,0x9f,0xf6,0x6a,0x02,0x8d,0xf6,0x6f,0x02,0x7a,0xf6,0x74,0x02,0x67,0xf6,0x79,0x02,0x54,0xf6,0x7e,0x02,0x42,0xf6,0x83,0x02,0x2f,0xf6,0x88,0x02,0x1c,0xf6,0x8d,0x02,0x09,0xf6,0x92,0x02,0xf7,0xf5,  \
    0x98,0x02,0xe4,0xf5,0x9d,0x02,0xd1,0xf5,0xa2,0x02,0xbe,0xf5,0xa7,0x02,0xab,0xf5,0xad,0x02,0x98,0xf5,0xb2,0x02,0x86,0xf5,0xb8,0x02,0x73,0xf5,0xbd,0x02,0x60,0xf5,0xc3,0x02,0x4d,0xf5,0xc8,0x02,0x3a,0xf5,0xce,0x02,0x27,0xf5,0xd4,0x02,0x14,0xf5,0xda,0x02,0x01,0xf5,0xdf,0x02,0xef,0xf4,0xe5,0x02,0xdc,0xf4,0xec,0x02,0xca,0xf4,0xf2,0x02,0xb7,0xf4,0xf8,0x02,0xa4,0xf4,0xfe,0x02,0x92,0xf4,0x04,0x03,0x7f,0xf4,0x0a,0x03,0x6c,0xf4,0x10,0x03,0x59,0xf4,0x17,0x03,  \
    0x47,0xf4,0x1d,0x03,0x34,0xf4,0x23,0x03,0x21,0xf4,0x2a,0x03,0x0e,0xf4,0x30,0x03,0xfb,0xf3,0x36,0x03,0xe8,0xf3,0x3d,0x03,0xd5,0xf3,0x43,0x03,0xc1,0xf3,0x4a,0x03,0xae,0xf3,0x50,0x03,0x99,0xf3,0x55,0x03,0x84,0xf3,0x5b,0x03,0x6f,0xf3,0x60,0x03,0x59,0xf3,0x66,0x03,0x44,0xf3,0x6b,0x03,0x2e,0xf3,0x71,0x03,0x19,0xf3,0x76,0x03,0x03,0xf3,0x7c,0x03,0xee,0xf2,0x82,0x03,0xd8,0xf2,0x87,0x03,0xc2,0xf2,0x8d,0x03,0xad,0xf2,0x92,0x03,0x97,0xf2,0x98,0x03,0x81,0xf2,  \
    0x9e,0x03,0x6b,0xf2,0xa3,0x03,0x55,0xf2,0xa9,0x03,0x3f,0xf2,0xaf,0x03,0x29,0xf2,0xb4,0x03,0x13,0xf2,0xbb,0x03,0xff,0xf1,0xc2,0x03,0xea,0xf1,0xc9,0x03,0xd5,0xf1,0xcf,0x03,0xc1,0xf1,0xd6,0x03,0xac,0xf1,0xdd,0x03,0x97,0xf1,0xe3,0x03,0x82,0xf1,0xea,0x03,0x6d,0xf1,0xf0,0x03,0x58,0xf1,0xf7,0x03,0x43,0xf1,0xfe,0x03,0x2d,0xf1,0x04,0x04,0x18,0xf1,0x0b,0x04,0x02,0xf1,0x11,0x04,0xec,0xf0,0x18,0x04,0xd7,0xf0,0x1e,0x04,0xc1,0xf0,0x24,0x04,0xab,0xf0,0x2b,0x04,  \
    0x95,0xf0,0x31,0x04,0x7f,0xf0,0x38,0x04,0x69,0xf0,0x3e,0x04,0x52,0xf0,0x45,0x04,0x3c,0xf0,0x4b,0x04,0x26,0xf0,0x51,0x04,0x0f,0xf0,0x58,0x04,0xf8,0xef,0x5e,0x04,0xe1,0xef,0x64,0x04,0xca,0xef,0x6a,0x04,0xb3,0xef,0x70,0x04,0x9c,0xef,0x76,0x04,0x84,0xef,0x7c,0x04,0x6d,0xef,0x81,0x04,0x55,0xef,0x87,0x04,0x3d,0xef,0x8d,0x04,0x25,0xef,0x92,0x04,0x0d,0xef,0x98,0x04,0xf4,0xee,0x9d,0x04,0xdc,0xee,0xa2,0x04,0xc3,0xee,0xa7,0x04,0xaa,0xee,0xab,0x04,0x8f,0xee,  \
    0xaf,0x04,0x75,0xee,0xb4,0x04,0x5b,0xee,0xb7,0x04,0x40,0xee,0xbb,0x04,0x25,0xee,0xbf,0x04,0x0a,0xee,0xc3,0x04,0xef,0xed,0xc6,0x04,0xd4,0xed,0xca,0x04,0xb9,0xed,0xcd,0x04,0x9d,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x5b,0x05,0xf4,0x11,0x57,0x05,0xd9,0x11,0x53,0x05,0xbe,0x11,0x4e,0x05,0xa3,0x11,0x4a,0x05,0x88,0x11,0x46,0x05,0x6d,0x11,0x41,0x05,0x52,0x11,0x3c,0x05,0x38,0x11,0x37,0x05,0x1d,0x11,0x32,0x05,0x03,0x11,0x2d,0x05,0xe9,0x10,0x28,0x05,0xcf,0x10,0x23,0x05,0xb6,0x10,0x1d,0x05,0x9c,0x10,0x18,0x05,0x83,0x10,0x12,0x05,0x69,0x10,0x0d,0x05,0x50,0x10,0x07,0x05,0x37,0x10,0x01,0x05,0x1e,0x10,0xfc,0x04,0x05,0x10,0xf5,0x04,0xed,0x0f,  \
    0xef,0x04,0xd5,0x0f,0xe8,0x04,0xbd,0x0f,0xe1,0x04,0xa6,0x0f,0xdb,0x04,0x8e,0x0f,0xd4,0x04,0x77,0x0f,0xcd,0x04,0x60,0x0f,0xc6,0x04,0x49,0x0f,0xbf,0x04,0x32,0x0f,0xb8,0x04,0x1b,0x0f,0xb1,0x04,0x05,0x0f,0xaa,0x04,0xee,0x0e,0xa2,0x04,0xd8,0x0e,0x9b,0x04,0xc1,0x0e,0x94,0x04,0xab,0x0e,0x8c,0x04,0x95,0x0e,0x85,0x04,0x7f,0x0e,0x7e,0x04,0x6a,0x0e,0x76,0x04,0x54,0x0e,0x6f,0x04,0x3e,0x0e,0x67,0x04,0x29,0x0e,0x5e,0x04,0x15,0x0e,0x56,0x04,0x01,0x0e,0x4e,0x04,  \
    0xed,0x0d,0x45,0x04,0xd9,0x0d,0x3d,0x04,0xc5,0x0d,0x35,0x04,0xb1,0x0d,0x2c,0x04,0x9e,0x0d,0x24,0x04,0x8a,0x0d,0x1b,0x04,0x77,0x0d,0x13,0x04,0x64,0x0d,0x0b,0x04,0x51,0x0d,0x02,0x04,0x3e,0x0d,0xfa,0x03,0x2b,0x0d,0xf1,0x03,0x18,0x0d,0xe9,0x03,0x06,0x0d,0xe0,0x03,0xf3,0x0c,0xd8,0x03,0xe0,0x0c,0xd2,0x03,0xca,0x0c,0xcb,0x03,0xb5,0x0c,0xc5,0x03,0x9f,0x0c,0xbf,0x03,0x8a,0x0c,0xb8,0x03,0x74,0x0c,0xb2,0x03,0x5f,0x0c,0xac,0x03,0x4a,0x0c,0xa5,0x03,0x34,0x0c,  \
    0x9f,0x03,0x1f,0x0c,0x99,0x03,0x0a,0x0c,0x92,0x03,0xf5,0x0b,0x8c,0x03,0xe0,0x0b,0x86,0x03,0xcb,0x0b,0x80,0x03,0xb6,0x0b,0x79,0x03,0xa1,0x0b,0x73,0x03,0x8c,0x0b,0x6d,0x03,0x77,0x0b,0x67,0x03,0x63,0x0b,0x61,0x03,0x4e,0x0b,0x5a,0x03,0x39,0x0b,0x54,0x03,0x24,0x0b,0x4e,0x03,0x10,0x0b,0x48,0x03,0xfb,0x0a,0x42,0x03,0xe7,0x0a,0x3c,0x03,0xd2,0x0a,0x36,0x03,0xbe,0x0a,0x30,0x03,0xa9,0x0a,0x2a,0x03,0x95,0x0a,0x24,0x03,0x80,0x0a,0x1e,0x03,0x6c,0x0a,0x19,0x03,  \
    0x58,0x0a,0x13,0x03,0x44,0x0a,0x0d,0x03,0x2f,0x0a,0x07,0x03,0x1b,0x0a,0x01,0x03,0x07,0x0a,0xfb,0x02,0xf4,0x09,0xf4,0x02,0xe2,0x09,0xed,0x02,0xd1,0x09,0xe6,0x02,0xc0,0x09,0xdf,0x02,0xaf,0x09,0xd8,0x02,0x9e,0x09,0xd2,0x02,0x8d,0x09,0xcb,0x02,0x7c,0x09,0xc4,0x02,0x6b,0x09,0xbe,0x02,0x5a,0x09,0xb7,0x02,0x49,0x09,0xb0,0x02,0x38,0x09,0xaa,0x02,0x27,0x09,0xa3,0x02,0x16,0x09,0x9d,0x02,0x05,0x09,0x97,0x02,0xf4,0x08,0x90,0x02,0xe3,0x08,0x8a,0x02,0xd3,0x08,  \
    0x84,0x02,0xc2,0x08,0x7e,0x02,0xb1,0x08,0x78,0x02,0xa0,0x08,0x72,0x02,0x8f,0x08,0x6c,0x02,0x7e,0x08,0x66,0x02,0x6d,0x08,0x61,0x02,0x5c,0x08,0x5b,0x02,0x4a,0x08,0x56,0x02,0x39,0x08,0x50,0x02,0x28,0x08,0x4b,0x02,0x17,0x08,0x45,0x02,0x06,0x08,0x40,0x02,0xf5,0x07,0x3b,0x02,0xe4,0x07,0x35,0x02,0xd2,0x07,0x30,0x02,0xc1,0x07,0x2b,0x02,0xb0,0x07,0x26,0x02,0x9f,0x07,0x21,0x02,0x8e,0x07,0x1c,0x02,0x7d,0x07,0x17,0x02,0x6c,0x07,0x12,0x02,0x5b,0x07,0x0d,0x02,  \
    0x4a,0x07,0x09,0x02,0x39,0x07,0x04,0x02,0x28,0x07,0xff,0x01,0x16,0x07,0xfb,0x01,0x04,0x07,0xf7,0x01,0xf1,0x06,0xf3,0x01,0xde,0x06,0xef,0x01,0xcb,0x06,0xeb,0x01,0xb9,0x06,0xe7,0x01,0xa6,0x06,0xe3,0x01,0x93,0x06,0xe0,0x01,0x81,0x06,0xdc,0x01,0x6e,0x06,0xd8,0x01,0x5c,0x06,0xd4,0x01,0x49,0x06,0xd1,0x01,0x36,0x06,0xcd,0x01,0x24,0x06,0xc9,0x01,0x11,0x06,0xc6,0x01,0xff,0x05,0xc2,0x01,0xec,0x05,0xbf,0x01,0xda,0x05,0xbb,0x01,0xc7,0x05,0xb8,0x01,0xb5,0x05,  \
    0xb4,0x01,0xa3,0x05,0xb1,0x01,0x90,0x05,0xae,0x01,0x7e,0x05,0xaa,0x01,0x6b,0x05,0xa7,0x01,0x59,0x05,0xa4,0x01,0x48,0x05,0xa0,0x01,0x37,0x05,0x9d,0x01,0x25,0x05,0x99,0x01,0x14,0x05,0x96,0x01,0x03,0x05,0x93,0x01,0xf2,0x04,0x90,0x01,0xe0,0x04,0x8c,0x01,0xcf,0x04,0x89,0x01,0xbe,0x04,0x86,0x01,0xad,0x04,0x83,0x01,0x9b,0x04,0x80,0x01,0x8a,0x04,0x7d,0x01,0x79,0x04,0x7a,0x01,0x67,0x04,0x78,0x01,0x56,0x04,0x75,0x01,0x45,0x04,0x72,0x01,0x34,0x04,0x6f,0x01,  \
    0x22,0x04,0x6d,0x01,0x11,0x04,0x6a,0x01,0x00,0x04,0x68,0x01,0xee,0x03,0x65,0x01,0xdd,0x03,0x63,0x01,0xcc,0x03,0x60,0x01,0xba,0x03,0x5e,0x01,0xa9,0x03,0x5b,0x01,0x98,0x03,0x59,0x01,0x87,0x03,0x57,0x01,0x77,0x03,0x54,0x01,0x66,0x03,0x52,0x01,0x56,0x03,0x50,0x01,0x45,0x03,0x4e,0x01,0x35,0x03,0x4b,0x01,0x24,0x03,0x49,0x01,0x13,0x03,0x47,0x01,0x03,0x03,0x45,0x01,0xf2,0x02,0x43,0x01,0xe1,0x02,0x42,0x01,0xd0,0x02,0x40,0x01,0xc0,0x02,0x3e,0x01,0xaf,0x02,  \
    0x3c,0x01,0x9e,0x02,0x3b,0x01,0x8d,0x02,0x39,0x01,0x7c,0x02,0x37,0x01,0x6b,0x02,0x36,0x01,0x5a,0x02,0x34,0x01,0x49,0x02,0x33,0x01,0x38,0x02,0x31,0x01,0x27,0x02,0x30,0x01,0x15,0x02,0x2f,0x01,0x04,0x02,0x2e,0x01,0xf3,0x01,0x2c,0x01,0xe2,0x01,0x2b,0x01,0xd0,0x01,0x2a,0x01,0xbf,0x01,0x29,0x01,0xad,0x01,0x28,0x01,0x9b,0x01,0x27,0x01,0x89,0x01,0x26,0x01,0x77,0x01,0x25,0x01,0x65,0x01,0x24,0x01,0x53,0x01,0x24,0x01,0x41,0x01,0x23,0x01,0x2f,0x01,0x22,0x01,  \
    0x1d,0x01,0x21,0x01,0x0b,0x01,0x21,0x01,0xf9,0x00,0x20,0x01,0xe7,0x00,0x1f,0x01,0xd5,0x00,0x1f,0x01,0xc3,0x00,0x1e,0x01,0xb1,0x00,0x1e,0x01,0x9f,0x00,0x1d,0x01,0x8d,0x00,0x1d,0x01,0x7b,0x00,0x1d,0x01,0x69,0x00,0x1c,0x01,0x58,0x00,0x1c,0x01,0x46,0x00,0x1c,0x01,0x34,0x00,0x1c,0x01,0x22,0x00,0x1b,0x01,0x10,0x00,0x1b,0x01,0xfe,0xff,0x1b,0x01,0xec,0xff,0x1b,0x01,0xda,0xff,0x1b,0x01,0xc8,0xff,0x1b,0x01,0xb6,0xff,0x1b,0x01,0xa4,0xff,0x1b,0x01,0x92,0xff,  \
    0x1b,0x01,0x80,0xff,0x1b,0x01,0x6e,0xff,0x1c,0x01,0x5c,0xff,0x1c,0x01,0x4a,0xff,0x1c,0x01,0x38,0xff,0x1c,0x01,0x26,0xff,0x1d,0x01,0x14,0xff,0x1d,0x01,0x02,0xff,0x1d,0x01,0xf0,0xfe,0x1e,0x01,0xde,0xfe,0x1e,0x01,0xcc,0xfe,0x1f,0x01,0xba,0xfe,0x1f,0x01,0xa9,0xfe,0x20,0x01,0x97,0xfe,0x21,0x01,0x85,0xfe,0x21,0x01,0x73,0xfe,0x22,0x01,0x61,0xfe,0x23,0x01,0x4f,0xfe,0x23,0x01,0x3d,0xfe,0x24,0x01,0x2b,0xfe,0x25,0x01,0x19,0xfe,0x26,0x01,0x07,0xfe,0x27,0x01,  \
    0xf5,0xfd,0x28,0x01,0xe3,0xfd,0x29,0x01,0xd1,0xfd,0x2a,0x01,0xbf,0xfd,0x2b,0x01,0xad,0xfd,0x2c,0x01,0x9b,0xfd,0x2d,0x01,0x88,0xfd,0x2e,0x01,0x76,0xfd,0x2f,0x01,0x64,0xfd,0x30,0x01,0x52,0xfd,0x32,0x01,0x3f,0xfd,0x33,0x01,0x2d,0xfd,0x34,0x01,0x1b,0xfd,0x36,0x01,0x08,0xfd,0x37,0x01,0xf6,0xfc,0x38,0x01,0xe4,0xfc,0x3a,0x01,0xd1,0xfc,0x3b,0x01,0xbf,0xfc,0x3d,0x01,0xad,0xfc,0x3e,0x01,0x9a,0xfc,0x40,0x01,0x88,0xfc,0x41,0x01,0x75,0xfc,0x43,0x01,0x63,0xfc,  \
    0x45,0x01,0x51,0xfc,0x46,0x01,0x3e,0xfc,0x48,0x01,0x2c,0xfc,0x4a,0x01,0x19,0xfc,0x4c,0x01,0x07,0xfc,0x4d,0x01,0xf4,0xfb,0x4f,0x01,0xe2,0xfb,0x51,0x01,0xd0,0xfb,0x53,0x01,0xbe,0xfb,0x55,0x01,0xac,0xfb,0x58,0x01,0x9b,0xfb,0x5a,0x01,0x89,0xfb,0x5c,0x01,0x78,0xfb,0x5e,0x01,0x66,0xfb,0x60,0x01,0x54,0xfb,0x63,0x01,0x43,0xfb,0x65,0x01,0x31,0xfb,0x68,0x01,0x20,0xfb,0x6a,0x01,0x0e,0xfb,0x6d,0x01,0xfd,0xfa,0x6f,0x01,0xeb,0xfa,0x72,0x01,0xda,0xfa,0x74,0x01,  \
    0xc8,0xfa,0x77,0x01,0xb7,0xfa,0x7a,0x01,0xa5,0xfa,0x7d,0x01,0x94,0xfa,0x7f,0x01,0x82,0xfa,0x82,0x01,0x71,0xfa,0x85,0x01,0x5f,0xfa,0x88,0x01,0x4e,0xfa,0x8b,0x01,0x3d,0xfa,0x8e,0x01,0x2b,0xfa,0x91,0x01,0x1a,0xfa,0x94,0x01,0x08,0xfa,0x97,0x01,0xf6,0xf9,0x9a,0x01,0xe4,0xf9,0x9d,0x01,0xd2,0xf9,0xa1,0x01,0xc0,0xf9,0xa4,0x01,0xad,0xf9,0xa7,0x01,0x9b,0xf9,0xaa,0x01,0x89,0xf9,0xad,0x01,0x77,0xf9,0xb1,0x01,0x65,0xf9,0xb4,0x01,0x53,0xf9,0xb7,0x01,0x40,0xf9,  \
    0xbb,0x01,0x2e,0xf9,0xbe,0x01,0x1c,0xf9,0xc2,0x01,0x0a,0xf9,0xc5,0x01,0xf8,0xf8,0xc9,0x01,0xe5,0xf8,0xcd,0x01,0xd3,0xf8,0xd0,0x01,0xc1,0xf8,0xd4,0x01,0xaf,0xf8,0xd8,0x01,0x9d,0xf8,0xdb,0x01,0x8a,0xf8,0xdf,0x01,0x78,0xf8,0xe3,0x01,0x66,0xf8,0xe7,0x01,0x54,0xf8,0xeb,0x01,0x42,0xf8,0xef,0x01,0x30,0xf8,0xf3,0x01,0x1e,0xf8,0xf8,0x01,0x0d,0xf8,0xfc,0x01,0xfb,0xf7,0x00,0x02,0xe9,0xf7,0x05,0x02,0xd7,0xf7,0x09,0x02,0xc6,0xf7,0x0d,0x02,0xb4,0xf7,0x12,0x02,  \
    0xa2,0xf7,0x16,0x02,0x90,0xf7,0x1b,0x02,0x7f,0xf7,0x20,0x02,0x6d,0xf7,0x24,0x02,0x5b,0xf7,0x29,0x02,0x49,0xf7,0x2e,0x02,0x38,0xf7,0x33,0x02,0x26,0xf7,0x37,0x02,0x14,0xf7,0x3c,0x02,0x02,0xf7,0x41,0x02,0xf0,0xf6,0x46,0x02,0xdf,0xf6,0x4b,0x02,0xcd,0xf6,0x50,0x02,0xbb,0xf6,0x55,0x02,0xa9,0xf6,0x5a,0x02,0x96,0xf6,0x5f,0x02,0x83,0xf6,0x64,0x02,0x71,0xf6,0x69,0x02,0x5e,0xf6,0x6e,0x02,0x4b,0xf6,0x73,0x02,0x39,0xf6,0x78,0x02,0x26,0xf6,0x7e,0x02,0x13,0xf6,  \
    0x83,0x02,0x00,0xf6,0x88,0x02,0xee,0xf5,0x8d,0x02,0xdb,0xf5,0x93,0x02,0xc8,0xf5,0x98,0x02,0xb5,0xf5,0x9d,0x02,0xa2,0xf5,0xa3,0x02,0x8f,0xf5,0xa8,0x02,0x7d,0xf5,0xae,0x02,0x6a,0xf5,0xb3,0x02,0x57,0xf5,0xb9,0x02,0x44,0xf5,0xbe,0x02,0x31,0xf5,0xc4,0x02,0x1e,0xf5,0xca,0x02,0x0b,0xf5,0xd0,0x02,0xf9,0xf4,0xd6,0x02,0xe6,0xf4,0xdc,0x02,0xd4,0xf4,0xe2,0x02,0xc1,0xf4,0xe8,0x02,0xae,0xf4,0xee,0x02,0x9c,0xf4,0xf4,0x02,0x89,0xf4,0xfa,0x02,0x76,0xf4,0x01,0x03,  \
    0x63,0xf4,0x07,0x03,0x51,0xf4,0x0d,0x03,0x3e,0xf4,0x14,0x03,0x2b,0xf4,0x1a,0x03,0x18,0xf4,0x20,0x03,0x05,0xf4,0x27,0x03,0xf2,0xf3,0x2d,0x03,0xdf,0xf3,0x33,0x03,0xcb,0xf3,0x3a,0x03,0xb8,0xf3,0x40,0x03,0xa3,0xf3,0x45,0x03,0x8e,0xf3,0x4b,0x03,0x79,0xf3,0x50,0x03,0x63,0xf3,0x56,0x03,0x4e,0xf3,0x5b,0x03,0x38,0xf3,0x61,0x03,0x23,0xf3,0x66,0x03,0x0d,0xf3,0x6c,0x03,0xf8,0xf2,0x72,0x03,0xe2,0xf2,0x77,0x03,0xcc,0xf2,0x7d,0x03,0xb7,0xf2,0x82,0x03,0xa1,0xf2,  \
    0x88,0x03,0x8b,0xf2,0x8e,0x03,0x75,0xf2,0x93,0x03,0x5f,0xf2,0x99,0x03,0x49,0xf2,0x9e,0x03,0x33,0xf2,0xa4,0x03,0x1d,0xf2,0xab,0x03,0x09,0xf2,0xb2,0x03,0xf4,0xf1,0xb8,0x03,0xdf,0xf1,0xbf,0x03,0xcb,0xf1,0xc6,0x03,0xb6,0xf1,0xcc,0x03,0xa1,0xf1,0xd3,0x03,0x8c,0xf1,0xd9,0x03,0x77,0xf1,0xe0,0x03,0x62,0xf1,0xe6,0x03,0x4c,0xf1,0xed,0x03,0x37,0xf1,0xf3,0x03,0x21,0xf1,0xfa,0x03,0x0c,0xf1,0x00,0x04,0xf6,0xf0,0x07,0x04,0xe0,0xf0,0x0d,0x04,0xca,0xf0,0x13,0x04,  \
    0xb4,0xf0,0x1a,0x04,0x9e,0xf0,0x20,0x04,0x88,0xf0,0x27,0x04,0x72,0xf0,0x2d,0x04,0x5c,0xf0,0x33,0x04,0x45,0xf0,0x3a,0x04,0x2f,0xf0,0x40,0x04,0x18,0xf0,0x46,0x04,0x01,0xf0,0x4c,0x04,0xea,0xef,0x52,0x04,0xd3,0xef,0x58,0x04,0xbc,0xef,0x5e,0x04,0xa5,0xef,0x64,0x04,0x8d,0xef,0x6a,0x04,0x75,0xef,0x70,0x04,0x5d,0xef,0x75,0x04,0x45,0xef,0x7b,0x04,0x2d,0xef,0x80,0x04,0x15,0xef,0x86,0x04,0xfd,0xee,0x8b,0x04,0xe4,0xee,0x90,0x04,0xcb,0xee,0x95,0x04,0xb2,0xee,  \
    0x99,0x04,0x97,0xee,0x9d,0x04,0x7d,0xee,0xa1,0x04,0x63,0xee,0xa5,0x04,0x48,0xee,0xa9,0x04,0x2d,0xee,0xad,0x04,0x12,0xee,0xb0,0x04,0xf7,0xed,0xb4,0x04,0xdc,0xed,0xb7,0x04,0xc1,0xed,0xbb,0x04,0xa5,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x49,0x05,0xed,0x11,0x45,0x05,0xd2,0x11,0x41,0x05,0xb6,0x11,0x3d,0x05,0x9b,0x11,0x39,0x05,0x80,0x11,0x34,0x05,0x66,0x11,0x2f,0x05,0x4b,0x11,0x2b,0x05,0x30,0x11,0x26,0x05,0x16,0x11,0x21,0x05,0xfc,0x10,0x1c,0x05,0xe2,0x10,0x17,0x05,0xc8,0x10,0x12,0x05,0xae,0x10,0x0c,0x05,0x95,0x10,0x07,0x05,0x7b,0x10,0x01,0x05,0x62,0x10,0xfc,0x04,0x49,0x10,0xf6,0x04,0x2f,0x10,0xf0,0x04,0x16,0x10,0xeb,0x04,0xfe,0x0f,  \
    0xe4,0x04,0xe5,0x0f,0xde,0x04,0xcd,0x0f,0xd7,0x04,0xb6,0x0f,0xd1,0x04,0x9e,0x0f,0xca,0x04,0x87,0x0f,0xc3,0x04,0x6f,0x0f,0xbc,0x04,0x58,0x0f,0xb5,0x04,0x41,0x0f,0xae,0x04,0x2a,0x0f,0xa7,0x04,0x13,0x0f,0xa0,0x04,0xfd,0x0e,0x99,0x04,0xe6,0x0e,0x92,0x04,0xd0,0x0e,0x8b,0x04,0xb9,0x0e,0x84,0x04,0xa3,0x0e,0x7c,0x04,0x8d,0x0e,0x75,0x04,0x77,0x0e,0x6e,0x04,0x61,0x0e,0x66,0x04,0x4b,0x0e,0x5f,0x04,0x36,0x0e,0x57,0x04,0x21,0x0e,0x4f,0x04,0x0c,0x0e,0x46,0x04,  \
    0xf8,0x0d,0x3e,0x04,0xe4,0x0d,0x36,0x04,0xd0,0x0d,0x2d,0x04,0xbc,0x0d,0x25,0x04,0xa9,0x0d,0x1d,0x04,0x95,0x0d,0x14,0x04,0x81,0x0d,0x0c,0x04,0x6e,0x0d,0x04,0x04,0x5b,0x0d,0xfb,0x03,0x48,0x0d,0xf3,0x03,0x35,0x0d,0xea,0x03,0x22,0x0d,0xe2,0x03,0x0f,0x0d,0xda,0x03,0xfc,0x0c,0xd1,0x03,0xe9,0x0c,0xc9,0x03,0xd6,0x0c,0xc3,0x03,0xc1,0x0c,0xbc,0x03,0xab,0x0c,0xb6,0x03,0x96,0x0c,0xb0,0x03,0x80,0x0c,0xa9,0x03,0x6b,0x0c,0xa3,0x03,0x55,0x0c,0x9d,0x03,0x40,0x0c,  \
    0x96,0x03,0x2b,0x0c,0x90,0x03,0x16,0x0c,0x8a,0x03,0x01,0x0c,0x83,0x03,0xeb,0x0b,0x7d,0x03,0xd6,0x0b,0x77,0x03,0xc1,0x0b,0x71,0x03,0xad,0x0b,0x6a,0x03,0x98,0x0b,0x64,0x03,0x83,0x0b,0x5e,0x03,0x6e,0x0b,0x58,0x03,0x59,0x0b,0x52,0x03,0x45,0x0b,0x4b,0x03,0x30,0x0b,0x45,0x03,0x1b,0x0b,0x3f,0x03,0x07,0x0b,0x39,0x03,0xf2,0x0a,0x33,0x03,0xde,0x0a,0x2d,0x03,0xc9,0x0a,0x27,0x03,0xb5,0x0a,0x21,0x03,0xa0,0x0a,0x1b,0x03,0x8c,0x0a,0x15,0x03,0x78,0x0a,0x0f,0x03,  \
    0x63,0x0a,0x09,0x03,0x4f,0x0a,0x04,0x03,0x3b,0x0a,0xfe,0x02,0x27,0x0a,0xf8,0x02,0x13,0x0a,0xf2,0x02,0xfe,0x09,0xec,0x02,0xeb,0x09,0xe5,0x02,0xda,0x09,0xde,0x02,0xc8,0x09,0xd7,0x02,0xb7,0x09,0xd0,0x02,0xa6,0x09,0xc9,0x02,0x95,0x09,0xc3,0x02,0x84,0x09,0xbc,0x02,0x73,0x09,0xb5,0x02,0x62,0x09,0xae,0x02,0x51,0x09,0xa8,0x02,0x40,0x09,0xa1,0x02,0x2f,0x09,0x9b,0x02,0x1e,0x09,0x94,0x02,0x0d,0x09,0x8e,0x02,0xfc,0x08,0x88,0x02,0xeb,0x08,0x81,0x02,0xdb,0x08,  \
    0x7b,0x02,0xca,0x08,0x75,0x02,0xb9,0x08,0x6f,0x02,0xa8,0x08,0x69,0x02,0x98,0x08,0x63,0x02,0x86,0x08,0x5d,0x02,0x75,0x08,0x57,0x02,0x64,0x08,0x52,0x02,0x53,0x08,0x4c,0x02,0x42,0x08,0x47,0x02,0x31,0x08,0x41,0x02,0x20,0x08,0x3c,0x02,0x0f,0x08,0x36,0x02,0xfd,0x07,0x31,0x02,0xec,0x07,0x2c,0x02,0xdb,0x07,0x26,0x02,0xca,0x07,0x21,0x02,0xb9,0x07,0x1c,0x02,0xa8,0x07,0x17,0x02,0x97,0x07,0x12,0x02,0x86,0x07,0x0d,0x02,0x75,0x07,0x08,0x02,0x64,0x07,0x03,0x02,  \
    0x53,0x07,0xfe,0x01,0x42,0x07,0xfa,0x01,0x31,0x07,0xf5,0x01,0x1f,0x07,0xf0,0x01,0x0e,0x07,0xec,0x01,0xfc,0x06,0xe8,0x01,0xe9,0x06,0xe4,0x01,0xd6,0x06,0xe0,0x01,0xc4,0x06,0xdc,0x01,0xb1,0x06,0xd8,0x01,0x9f,0x06,0xd4,0x01,0x8c,0x06,0xd0,0x01,0x79,0x06,0xcc,0x01,0x67,0x06,0xc9,0x01,0x54,0x06,0xc5,0x01,0x42,0x06,0xc1,0x01,0x2f,0x06,0xbe,0x01,0x1d,0x06,0xba,0x01,0x0a,0x06,0xb6,0x01,0xf8,0x05,0xb3,0x01,0xe6,0x05,0xaf,0x01,0xd3,0x05,0xac,0x01,0xc1,0x05,  \
    0xa8,0x01,0xae,0x05,0xa5,0x01,0x9c,0x05,0xa1,0x01,0x8a,0x05,0x9e,0x01,0x77,0x05,0x9b,0x01,0x65,0x05,0x97,0x01,0x53,0x05,0x94,0x01,0x42,0x05,0x91,0x01,0x31,0x05,0x8d,0x01,0x1f,0x05,0x8a,0x01,0x0e,0x05,0x86,0x01,0xfd,0x04,0x83,0x01,0xec,0x04,0x80,0x01,0xdb,0x04,0x7d,0x01,0xc9,0x04,0x7a,0x01,0xb8,0x04,0x77,0x01,0xa7,0x04,0x74,0x01,0x96,0x04,0x71,0x01,0x85,0x04,0x6e,0x01,0x73,0x04,0x6b,0x01,0x62,0x04,0x68,0x01,0x51,0x04,0x65,0x01,0x40,0x04,0x62,0x01,  \
    0x2e,0x04,0x60,0x01,0x1d,0x04,0x5d,0x01,0x0c,0x04,0x5a,0x01,0xfb,0x03,0x58,0x01,0xea,0x03,0x55,0x01,0xd8,0x03,0x53,0x01,0xc7,0x03,0x50,0x01,0xb6,0x03,0x4e,0x01,0xa4,0x03,0x4c,0x01,0x93,0x03,0x49,0x01,0x83,0x03,0x47,0x01,0x73,0x03,0x44,0x01,0x62,0x03,0x42,0x01,0x52,0x03,0x40,0x01,0x41,0x03,0x3e,0x01,0x31,0x03,0x3c,0x01,0x20,0x03,0x39,0x01,0x0f,0x03,0x37,0x01,0xff,0x02,0x35,0x01,0xee,0x02,0x34,0x01,0xdd,0x02,0x32,0x01,0xcd,0x02,0x30,0x01,0xbc,0x02,  \
    0x2e,0x01,0xab,0x02,0x2c,0x01,0x9a,0x02,0x2b,0x01,0x8a,0x02,0x29,0x01,0x79,0x02,0x27,0x01,0x68,0x02,0x26,0x01,0x57,0x02,0x24,0x01,0x46,0x02,0x23,0x01,0x35,0x02,0x22,0x01,0x24,0x02,0x20,0x01,0x13,0x02,0x1f,0x01,0x01,0x02,0x1e,0x01,0xf0,0x01,0x1c,0x01,0xdf,0x01,0x1b,0x01,0xce,0x01,0x1a,0x01,0xbc,0x01,0x19,0x01,0xaa,0x01,0x18,0x01,0x98,0x01,0x17,0x01,0x86,0x01,0x16,0x01,0x75,0x01,0x15,0x01,0x63,0x01,0x14,0x01,0x51,0x01,0x14,0x01,0x3f,0x01,0x13,0x01,  \
    0x2d,0x01,0x12,0x01,0x1b,0x01,0x11,0x01,0x09,0x01,0x11,0x01,0xf8,0x00,0x10,0x01,0xe6,0x00,0x0f,0x01,0xd4,0x00,0x0f,0x01,0xc2,0x00,0x0e,0x01,0xb0,0x00,0x0e,0x01,0x9e,0x00,0x0d,0x01,0x8c,0x00,0x0d,0x01,0x7b,0x00,0x0d,0x01,0x69,0x00,0x0c,0x01,0x57,0x00,0x0c,0x01,0x45,0x00,0x0c,0x01,0x33,0x00,0x0c,0x01,0x21,0x00,0x0b,0x01,0x0f,0x00,0x0b,0x01,0xfd,0xff,0x0b,0x01,0xeb,0xff,0x0b,0x01,0xda,0xff,0x0b,0x01,0xc8,0xff,0x0b,0x01,0xb6,0xff,0x0b,0x01,0xa4,0xff,  \
    0x0b,0x01,0x92,0xff,0x0b,0x01,0x80,0xff,0x0b,0x01,0x6e,0xff,0x0c,0x01,0x5d,0xff,0x0c,0x01,0x4b,0xff,0x0c,0x01,0x39,0xff,0x0c,0x01,0x27,0xff,0x0d,0x01,0x15,0xff,0x0d,0x01,0x03,0xff,0x0d,0x01,0xf1,0xfe,0x0e,0x01,0xdf,0xfe,0x0e,0x01,0xce,0xfe,0x0f,0x01,0xbc,0xfe,0x0f,0x01,0xaa,0xfe,0x10,0x01,0x98,0xfe,0x11,0x01,0x86,0xfe,0x11,0x01,0x74,0xfe,0x12,0x01,0x63,0xfe,0x13,0x01,0x51,0xfe,0x13,0x01,0x3f,0xfe,0x14,0x01,0x2d,0xfe,0x15,0x01,0x1b,0xfe,0x16,0x01,  \
    0x09,0xfe,0x17,0x01,0xf8,0xfd,0x18,0x01,0xe6,0xfd,0x19,0x01,0xd4,0xfd,0x1a,0x01,0xc2,0xfd,0x1b,0x01,0xb0,0xfd,0x1c,0x01,0x9d,0xfd,0x1d,0x01,0x8b,0xfd,0x1e,0x01,0x79,0xfd,0x1f,0x01,0x67,0xfd,0x20,0x01,0x55,0xfd,0x22,0x01,0x43,0xfd,0x23,0x01,0x30,0xfd,0x24,0x01,0x1e,0xfd,0x26,0x01,0x0c,0xfd,0x27,0x01,0xfa,0xfc,0x28,0x01,0xe7,0xfc,0x2a,0x01,0xd5,0xfc,0x2b,0x01,0xc3,0xfc,0x2d,0x01,0xb1,0xfc,0x2e,0x01,0x9e,0xfc,0x30,0x01,0x8c,0xfc,0x31,0x01,0x7a,0xfc,  \
    0x33,0x01,0x67,0xfc,0x35,0x01,0x55,0xfc,0x36,0x01,0x43,0xfc,0x38,0x01,0x30,0xfc,0x3a,0x01,0x1e,0xfc,0x3c,0x01,0x0b,0xfc,0x3e,0x01,0xf9,0xfb,0x3f,0x01,0xe7,0xfb,0x41,0x01,0xd5,0xfb,0x43,0x01,0xc3,0xfb,0x46,0x01,0xb2,0xfb,0x48,0x01,0xa0,0xfb,0x4a,0x01,0x8f,0xfb,0x4c,0x01,0x7d,0xfb,0x4e,0x01,0x6b,0xfb,0x51,0x01,0x5a,0xfb,0x53,0x01,0x48,0xfb,0x55,0x01,0x37,0xfb,0x58,0x01,0x25,0xfb,0x5a,0x01,0x14,0xfb,0x5d,0x01,0x03,0xfb,0x5f,0x01,0xf1,0xfa,0x62,0x01,  \
    0xe0,0xfa,0x65,0x01,0xce,0xfa,0x67,0x01,0xbd,0xfa,0x6a,0x01,0xab,0xfa,0x6d,0x01,0x9a,0xfa,0x70,0x01,0x89,0xfa,0x73,0x01,0x77,0xfa,0x75,0x01,0x66,0xfa,0x78,0x01,0x55,0xfa,0x7b,0x01,0x43,0xfa,0x7f,0x01,0x32,0xfa,0x82,0x01,0x21,0xfa,0x85,0x01,0x0f,0xfa,0x88,0x01,0xfd,0xf9,0x8b,0x01,0xeb,0xf9,0x8e,0x01,0xd9,0xf9,0x91,0x01,0xc7,0xf9,0x94,0x01,0xb5,0xf9,0x97,0x01,0xa3,0xf9,0x9b,0x01,0x90,0xf9,0x9e,0x01,0x7e,0xf9,0xa1,0x01,0x6c,0xf9,0xa5,0x01,0x5a,0xf9,  \
    0xa8,0x01,0x48,0xf9,0xab,0x01,0x36,0xf9,0xaf,0x01,0x24,0xf9,0xb2,0x01,0x12,0xf9,0xb6,0x01,0x00,0xf9,0xb9,0x01,0xed,0xf8,0xbd,0x01,0xdb,0xf8,0xc1,0x01,0xc9,0xf8,0xc4,0x01,0xb7,0xf8,0xc8,0x01,0xa5,0xf8,0xcc,0x01,0x93,0xf8,0xd0,0x01,0x80,0xf8,0xd4,0x01,0x6e,0xf8,0xd8,0x01,0x5c,0xf8,0xdc,0x01,0x4a,0xf8,0xe0,0x01,0x39,0xf8,0xe4,0x01,0x27,0xf8,0xe8,0x01,0x15,0xf8,0xed,0x01,0x04,0xf8,0xf1,0x01,0xf2,0xf7,0xf5,0x01,0xe0,0xf7,0xfa,0x01,0xce,0xf7,0xfe,0x01,  \
    0xbd,0xf7,0x03,0x02,0xab,0xf7,0x07,0x02,0x99,0xf7,0x0c,0x02,0x88,0xf7,0x10,0x02,0x76,0xf7,0x15,0x02,0x64,0xf7,0x1a,0x02,0x53,0xf7,0x1e,0x02,0x41,0xf7,0x23,0x02,0x2f,0xf7,0x28,0x02,0x1d,0xf7,0x2d,0x02,0x0c,0xf7,0x32,0x02,0xfa,0xf6,0x37,0x02,0xe8,0xf6,0x3c,0x02,0xd6,0xf6,0x41,0x02,0xc4,0xf6,0x46,0x02,0xb2,0xf6,0x4b,0x02,0x9f,0xf6,0x50,0x02,0x8d,0xf6,0x55,0x02,0x7a,0xf6,0x5a,0x02,0x68,0xf6,0x5f,0x02,0x55,0xf6,0x64,0x02,0x42,0xf6,0x69,0x02,0x30,0xf6,  \
    0x6e,0x02,0x1d,0xf6,0x73,0x02,0x0a,0xf6,0x79,0x02,0xf7,0xf5,0x7e,0x02,0xe5,0xf5,0x83,0x02,0xd2,0xf5,0x89,0x02,0xbf,0xf5,0x8e,0x02,0xac,0xf5,0x93,0x02,0x99,0xf5,0x99,0x02,0x87,0xf5,0x9e,0x02,0x74,0xf5,0xa4,0x02,0x61,0xf5,0xa9,0x02,0x4e,0xf5,0xaf,0x02,0x3b,0xf5,0xb5,0x02,0x28,0xf5,0xbb,0x02,0x15,0xf5,0xc1,0x02,0x03,0xf5,0xc6,0x02,0xf0,0xf4,0xcc,0x02,0xde,0xf4,0xd3,0x02,0xcb,0xf4,0xd9,0x02,0xb9,0xf4,0xdf,0x02,0xa6,0xf4,0xe5,0x02,0x93,0xf4,0xeb,0x02,  \
    0x80,0xf4,0xf1,0x02,0x6d,0xf4,0xf7,0x02,0x5b,0xf4,0xfe,0x02,0x48,0xf4,0x04,0x03,0x35,0xf4,0x0a,0x03,0x22,0xf4,0x11,0x03,0x0f,0xf4,0x17,0x03,0xfc,0xf3,0x1d,0x03,0xe9,0xf3,0x24,0x03,0xd5,0xf3,0x2a,0x03,0xc2,0xf3,0x30,0x03,0xad,0xf3,0x35,0x03,0x98,0xf3,0x3b,0x03,0x83,0xf3,0x40,0x03,0x6d,0xf3,0x46,0x03,0x58,0xf3,0x4c,0x03,0x43,0xf3,0x51,0x03,0x2d,0xf3,0x57,0x03,0x18,0xf3,0x5c,0x03,0x02,0xf3,0x62,0x03,0xec,0xf2,0x67,0x03,0xd7,0xf2,0x6d,0x03,0xc1,0xf2,  \
    0x73,0x03,0xab,0xf2,0x78,0x03,0x95,0xf2,0x7e,0x03,0x7f,0xf2,0x83,0x03,0x69,0xf2,0x89,0x03,0x53,0xf2,0x8f,0x03,0x3d,0xf2,0x94,0x03,0x27,0xf2,0x9b,0x03,0x13,0xf2,0xa2,0x03,0xfe,0xf1,0xa8,0x03,0xe9,0xf1,0xaf,0x03,0xd5,0xf1,0xb5,0x03,0xc0,0xf1,0xbc,0x03,0xab,0xf1,0xc3,0x03,0x96,0xf1,0xc9,0x03,0x81,0xf1,0xd0,0x03,0x6b,0xf1,0xd6,0x03,0x56,0xf1,0xdd,0x03,0x41,0xf1,0xe3,0x03,0x2b,0xf1,0xe9,0x03,0x15,0xf1,0xf0,0x03,0x00,0xf1,0xf6,0x03,0xea,0xf0,0xfc,0x03,  \
    0xd4,0xf0,0x03,0x04,0xbd,0xf0,0x09,0x04,0xa7,0xf0,0x0f,0x04,0x91,0xf0,0x16,0x04,0x7b,0xf0,0x1c,0x04,0x65,0xf0,0x22,0x04,0x4e,0xf0,0x29,0x04,0x38,0xf0,0x2f,0x04,0x21,0xf0,0x35,0x04,0x0a,0xf0,0x3b,0x04,0xf3,0xef,0x41,0x04,0xdc,0xef,0x47,0x04,0xc5,0xef,0x4d,0x04,0xad,0xef,0x53,0x04,0x96,0xef,0x58,0x04,0x7e,0xef,0x5e,0x04,0x66,0xef,0x64,0x04,0x4e,0xef,0x69,0x04,0x36,0xef,0x6e,0x04,0x1d,0xef,0x74,0x04,0x05,0xef,0x79,0x04,0xec,0xee,0x7e,0x04,0xd3,0xee,  \
    0x83,0x04,0xba,0xee,0x87,0x04,0xa0,0xee,0x8b,0x04,0x85,0xee,0x8f,0x04,0x6b,0xee,0x93,0x04,0x50,0xee,0x97,0x04,0x35,0xee,0x9a,0x04,0x1a,0xee,0x9e,0x04,0xff,0xed,0xa1,0x04,0xe4,0xed,0xa5,0x04,0xc8,0xed,0xa8,0x04,0xad,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x39,0x05,0xe6,0x11,0x35,0x05,0xca,0x11,0x31,0x05,0xaf,0x11,0x2c,0x05,0x94,0x11,0x28,0x05,0x79,0x11,0x23,0x05,0x5e,0x11,0x1f,0x05,0x43,0x11,0x1a,0x05,0x29,0x11,0x15,0x05,0x0e,0x11,0x11,0x05,0xf4,0x10,0x0c,0x05,0xda,0x10,0x06,0x05,0xc0,0x10,0x01,0x05,0xa6,0x10,0xfc,0x04,0x8d,0x10,0xf7,0x04,0x73,0x10,0xf1,0x04,0x5a,0x10,0xec,0x04,0x41,0x10,0xe6,0x04,0x28,0x10,0xe0,0x04,0x0f,0x10,  \
    0xda,0x04,0xf6,0x0f,0xd4,0x04,0xdd,0x0f,0xce,0x04,0xc5,0x0f,0xc7,0x04,0xae,0x0f,0xc1,0x04,0x96,0x0f,0xba,0x04,0x7e,0x0f,0xb3,0x04,0x67,0x0f,0xac,0x04,0x50,0x0f,0xa6,0x04,0x39,0x0f,0x9f,0x04,0x22,0x0f,0x98,0x04,0x0b,0x0f,0x91,0x04,0xf4,0x0e,0x8a,0x04,0xde,0x0e,0x82,0x04,0xc7,0x0e,0x7b,0x04,0xb1,0x0e,0x74,0x04,0x9a,0x0e,0x6d,0x04,0x84,0x0e,0x65,0x04,0x6e,0x0e,0x5e,0x04,0x58,0x0e,0x57,0x04,0x43,0x0e,0x4f,0x04,0x2d,0x0e,0x48,0x04,0x18,0x0e,0x3f,0x04,  \
    0x04,0x0e,0x37,0x04,0xef,0x0d,0x2f,0x04,0xdb,0x0d,0x27,0x04,0xc7,0x0d,0x1e,0x04,0xb3,0x0d,0x16,0x04,0x9f,0x0d,0x0e,0x04,0x8c,0x0d,0x06,0x04,0x78,0x0d,0xfd,0x03,0x65,0x0d,0xf5,0x03,0x51,0x0d,0xed,0x03,0x3e,0x0d,0xe4,0x03,0x2b,0x0d,0xdc,0x03,0x18,0x0d,0xd4,0x03,0x05,0x0d,0xcb,0x03,0xf2,0x0c,0xc3,0x03,0xe0,0x0c,0xbb,0x03,0xcc,0x0c,0xb4,0x03,0xb7,0x0c,0xae,0x03,0xa1,0x0c,0xa8,0x03,0x8c,0x0c,0xa1,0x03,0x76,0x0c,0x9b,0x03,0x61,0x0c,0x95,0x03,0x4c,0x0c,  \
    0x8e,0x03,0x36,0x0c,0x88,0x03,0x21,0x0c,0x82,0x03,0x0c,0x0c,0x7b,0x03,0xf7,0x0b,0x75,0x03,0xe2,0x0b,0x6f,0x03,0xcd,0x0b,0x68,0x03,0xb8,0x0b,0x62,0x03,0xa3,0x0b,0x5c,0x03,0x8e,0x0b,0x56,0x03,0x79,0x0b,0x4f,0x03,0x65,0x0b,0x49,0x03,0x50,0x0b,0x43,0x03,0x3b,0x0b,0x3d,0x03,0x26,0x0b,0x37,0x03,0x12,0x0b,0x31,0x03,0xfd,0x0a,0x2b,0x03,0xe9,0x0a,0x25,0x03,0xd4,0x0a,0x1e,0x03,0xc0,0x0a,0x18,0x03,0xab,0x0a,0x12,0x03,0x97,0x0a,0x0c,0x03,0x83,0x0a,0x07,0x03,  \
    0x6e,0x0a,0x01,0x03,0x5a,0x0a,0xfb,0x02,0x46,0x0a,0xf5,0x02,0x32,0x0a,0xef,0x02,0x1e,0x0a,0xe9,0x02,0x0a,0x0a,0xe3,0x02,0xf6,0x09,0xdd,0x02,0xe2,0x09,0xd6,0x02,0xd1,0x09,0xcf,0x02,0xc0,0x09,0xc8,0x02,0xae,0x09,0xc1,0x02,0x9d,0x09,0xbb,0x02,0x8c,0x09,0xb4,0x02,0x7b,0x09,0xad,0x02,0x6a,0x09,0xa6,0x02,0x59,0x09,0xa0,0x02,0x48,0x09,0x99,0x02,0x37,0x09,0x93,0x02,0x26,0x09,0x8c,0x02,0x15,0x09,0x86,0x02,0x04,0x09,0x7f,0x02,0xf4,0x08,0x79,0x02,0xe3,0x08,  \
    0x73,0x02,0xd2,0x08,0x6d,0x02,0xc1,0x08,0x66,0x02,0xb0,0x08,0x60,0x02,0x9f,0x08,0x5a,0x02,0x8f,0x08,0x54,0x02,0x7e,0x08,0x4f,0x02,0x6d,0x08,0x49,0x02,0x5b,0x08,0x43,0x02,0x4a,0x08,0x3e,0x02,0x39,0x08,0x38,0x02,0x28,0x08,0x32,0x02,0x17,0x08,0x2d,0x02,0x06,0x08,0x28,0x02,0xf5,0x07,0x22,0x02,0xe4,0x07,0x1d,0x02,0xd3,0x07,0x18,0x02,0xc2,0x07,0x12,0x02,0xb1,0x07,0x0d,0x02,0xa0,0x07,0x08,0x02,0x8f,0x07,0x03,0x02,0x7e,0x07,0xfe,0x01,0x6c,0x07,0xf9,0x01,  \
    0x5b,0x07,0xf4,0x01,0x4a,0x07,0xf0,0x01,0x39,0x07,0xeb,0x01,0x28,0x07,0xe6,0x01,0x17,0x07,0xe1,0x01,0x06,0x07,0xdd,0x01,0xf4,0x06,0xd9,0x01,0xe1,0x06,0xd5,0x01,0xcf,0x06,0xd1,0x01,0xbc,0x06,0xcd,0x01,0xa9,0x06,0xc9,0x01,0x97,0x06,0xc5,0x01,0x84,0x06,0xc1,0x01,0x72,0x06,0xbe,0x01,0x5f,0x06,0xba,0x01,0x4d,0x06,0xb6,0x01,0x3b,0x06,0xb2,0x01,0x28,0x06,0xaf,0x01,0x16,0x06,0xab,0x01,0x03,0x06,0xa7,0x01,0xf1,0x05,0xa4,0x01,0xdf,0x05,0xa0,0x01,0xcc,0x05,  \
    0x9d,0x01,0xba,0x05,0x99,0x01,0xa8,0x05,0x96,0x01,0x95,0x05,0x92,0x01,0x83,0x05,0x8f,0x01,0x71,0x05,0x8c,0x01,0x5f,0x05,0x88,0x01,0x4d,0x05,0x85,0x01,0x3c,0x05,0x81,0x01,0x2a,0x05,0x7e,0x01,0x19,0x05,0x7b,0x01,0x08,0x05,0x77,0x01,0xf7,0x04,0x74,0x01,0xe6,0x04,0x71,0x01,0xd5,0x04,0x6e,0x01,0xc4,0x04,0x6a,0x01,0xb3,0x04,0x67,0x01,0xa1,0x04,0x64,0x01,0x90,0x04,0x61,0x01,0x7f,0x04,0x5e,0x01,0x6e,0x04,0x5b,0x01,0x5d,0x04,0x59,0x01,0x4c,0x04,0x56,0x01,  \
    0x3a,0x04,0x53,0x01,0x29,0x04,0x50,0x01,0x18,0x04,0x4e,0x01,0x07,0x04,0x4b,0x01,0xf6,0x03,0x48,0x01,0xe5,0x03,0x46,0x01,0xd3,0x03,0x43,0x01,0xc2,0x03,0x41,0x01,0xb1,0x03,0x3f,0x01,0xa0,0x03,0x3c,0x01,0x8f,0x03,0x3a,0x01,0x7f,0x03,0x37,0x01,0x6e,0x03,0x35,0x01,0x5e,0x03,0x33,0x01,0x4d,0x03,0x30,0x01,0x3d,0x03,0x2e,0x01,0x2c,0x03,0x2c,0x01,0x1c,0x03,0x2a,0x01,0x0b,0x03,0x28,0x01,0xfb,0x02,0x26,0x01,0xea,0x02,0x24,0x01,0xda,0x02,0x22,0x01,0xc9,0x02,  \
    0x20,0x01,0xb8,0x02,0x1f,0x01,0xa8,0x02,0x1d,0x01,0x97,0x02,0x1b,0x01,0x86,0x02,0x19,0x01,0x75,0x02,0x18,0x01,0x64,0x02,0x16,0x01,0x53,0x02,0x15,0x01,0x43,0x02,0x13,0x01,0x32,0x02,0x12,0x01,0x21,0x02,0x11,0x01,0x10,0x02,0x0f,0x01,0xfe,0x01,0x0e,0x01,0xed,0x01,0x0d,0x01,0xdc,0x01,0x0c,0x01,0xcb,0x01,0x0a,0x01,0xb9,0x01,0x09,0x01,0xa8,0x01,0x08,0x01,0x96,0x01,0x07,0x01,0x84,0x01,0x06,0x01,0x72,0x01,0x06,0x01,0x61,0x01,0x05,0x01,0x4f,0x01,0x04,0x01,  \
    0x3d,0x01,0x03,0x01,0x2b,0x01,0x02,0x01,0x1a,0x01,0x02,0x01,0x08,0x01,0x01,0x01,0xf6,0x00,0x00,0x01,0xe4,0x00,0x00,0x01,0xd2,0x00,0xff,0x00,0xc1,0x00,0xff,0x00,0xaf,0x00,0xfe,0x00,0x9d,0x00,0xfe,0x00,0x8b,0x00,0xfd,0x00,0x7a,0x00,0xfd,0x00,0x68,0x00,0xfd,0x00,0x56,0x00,0xfc,0x00,0x44,0x00,0xfc,0x00,0x32,0x00,0xfc,0x00,0x21,0x00,0xfc,0x00,0x0f,0x00,0xfb,0x00,0xfd,0xff,0xfb,0x00,0xeb,0xff,0xfb,0x00,0xd9,0xff,0xfb,0x00,0xc8,0xff,0xfb,0x00,0xb6,0xff,  \
    0xfb,0x00,0xa4,0xff,0xfb,0x00,0x92,0xff,0xfc,0x00,0x81,0xff,0xfc,0x00,0x6f,0xff,0xfc,0x00,0x5d,0xff,0xfc,0x00,0x4b,0xff,0xfc,0x00,0x39,0xff,0xfd,0x00,0x28,0xff,0xfd,0x00,0x16,0xff,0xfd,0x00,0x04,0xff,0xfe,0x00,0xf2,0xfe,0xfe,0x00,0xe1,0xfe,0xff,0x00,0xcf,0xfe,0xff,0x00,0xbd,0xfe,0x00,0x01,0xab,0xfe,0x00,0x01,0x9a,0xfe,0x01,0x01,0x88,0xfe,0x02,0x01,0x76,0xfe,0x02,0x01,0x64,0xfe,0x03,0x01,0x53,0xfe,0x04,0x01,0x41,0xfe,0x05,0x01,0x2f,0xfe,0x05,0x01,  \
    0x1d,0xfe,0x06,0x01,0x0c,0xfe,0x07,0x01,0xfa,0xfd,0x08,0x01,0xe8,0xfd,0x09,0x01,0xd6,0xfd,0x0a,0x01,0xc4,0xfd,0x0b,0x01,0xb2,0xfd,0x0c,0x01,0xa0,0xfd,0x0d,0x01,0x8e,0xfd,0x0e,0x01,0x7c,0xfd,0x10,0x01,0x6a,0xfd,0x11,0x01,0x58,0xfd,0x12,0x01,0x46,0xfd,0x13,0x01,0x34,0xfd,0x15,0x01,0x22,0xfd,0x16,0x01,0x10,0xfd,0x17,0x01,0xfd,0xfc,0x19,0x01,0xeb,0xfc,0x1a,0x01,0xd9,0xfc,0x1c,0x01,0xc7,0xfc,0x1d,0x01,0xb5,0xfc,0x1f,0x01,0xa2,0xfc,0x20,0x01,0x90,0xfc,  \
    0x22,0x01,0x7e,0xfc,0x24,0x01,0x6c,0xfc,0x25,0x01,0x59,0xfc,0x27,0x01,0x47,0xfc,0x29,0x01,0x35,0xfc,0x2b,0x01,0x23,0xfc,0x2c,0x01,0x10,0xfc,0x2e,0x01,0xfe,0xfb,0x30,0x01,0xec,0xfb,0x32,0x01,0xda,0xfb,0x34,0x01,0xc9,0xfb,0x36,0x01,0xb7,0xfb,0x38,0x01,0xa6,0xfb,0x3b,0x01,0x94,0xfb,0x3d,0x01,0x83,0xfb,0x3f,0x01,0x71,0xfb,0x41,0x01,0x60,0xfb,0x44,0x01,0x4e,0xfb,0x46,0x01,0x3d,0xfb,0x49,0x01,0x2b,0xfb,0x4b,0x01,0x1a,0xfb,0x4e,0x01,0x09,0xfb,0x50,0x01,  \
    0xf7,0xfa,0x53,0x01,0xe6,0xfa,0x56,0x01,0xd5,0xfa,0x58,0x01,0xc3,0xfa,0x5b,0x01,0xb2,0xfa,0x5e,0x01,0xa1,0xfa,0x61,0x01,0x8f,0xfa,0x64,0x01,0x7e,0xfa,0x66,0x01,0x6d,0xfa,0x69,0x01,0x5c,0xfa,0x6c,0x01,0x4a,0xfa,0x70,0x01,0x39,0xfa,0x73,0x01,0x28,0xfa,0x76,0x01,0x16,0xfa,0x79,0x01,0x04,0xfa,0x7c,0x01,0xf2,0xf9,0x7f,0x01,0xe0,0xf9,0x82,0x01,0xce,0xf9,0x85,0x01,0xbc,0xf9,0x88,0x01,0xaa,0xf9,0x8c,0x01,0x98,0xf9,0x8f,0x01,0x86,0xf9,0x92,0x01,0x74,0xf9,  \
    0x96,0x01,0x62,0xf9,0x99,0x01,0x50,0xf9,0x9d,0x01,0x3e,0xf9,0xa0,0x01,0x2c,0xf9,0xa4,0x01,0x1a,0xf9,0xa7,0x01,0x08,0xf9,0xab,0x01,0xf6,0xf8,0xae,0x01,0xe4,0xf8,0xb2,0x01,0xd2,0xf8,0xb6,0x01,0xc0,0xf8,0xba,0x01,0xad,0xf8,0xbd,0x01,0x9b,0xf8,0xc1,0x01,0x89,0xf8,0xc5,0x01,0x77,0xf8,0xc9,0x01,0x65,0xf8,0xcd,0x01,0x53,0xf8,0xd1,0x01,0x42,0xf8,0xd6,0x01,0x30,0xf8,0xda,0x01,0x1e,0xf8,0xde,0x01,0x0d,0xf8,0xe2,0x01,0xfb,0xf7,0xe7,0x01,0xe9,0xf7,0xeb,0x01,  \
    0xd8,0xf7,0xf0,0x01,0xc6,0xf7,0xf4,0x01,0xb5,0xf7,0xf9,0x01,0xa3,0xf7,0xfd,0x01,0x91,0xf7,0x02,0x02,0x80,0xf7,0x07,0x02,0x6e,0xf7,0x0c,0x02,0x5c,0xf7,0x10,0x02,0x4a,0xf7,0x15,0x02,0x39,0xf7,0x1a,0x02,0x27,0xf7,0x1f,0x02,0x15,0xf7,0x24,0x02,0x04,0xf7,0x29,0x02,0xf2,0xf6,0x2e,0x02,0xe0,0xf6,0x33,0x02,0xce,0xf6,0x38,0x02,0xbc,0xf6,0x3d,0x02,0xaa,0xf6,0x42,0x02,0x97,0xf6,0x47,0x02,0x84,0xf6,0x4c,0x02,0x72,0xf6,0x51,0x02,0x5f,0xf6,0x56,0x02,0x4d,0xf6,  \
    0x5b,0x02,0x3a,0xf6,0x60,0x02,0x27,0xf6,0x66,0x02,0x15,0xf6,0x6b,0x02,0x02,0xf6,0x70,0x02,0xef,0xf5,0x75,0x02,0xdd,0xf5,0x7b,0x02,0xca,0xf5,0x80,0x02,0xb7,0xf5,0x86,0x02,0xa4,0xf5,0x8b,0x02,0x91,0xf5,0x91,0x02,0x7e,0xf5,0x96,0x02,0x6c,0xf5,0x9c,0x02,0x59,0xf5,0xa1,0x02,0x46,0xf5,0xa7,0x02,0x33,0xf5,0xad,0x02,0x20,0xf5,0xb3,0x02,0x0e,0xf5,0xb9,0x02,0xfb,0xf4,0xbf,0x02,0xe9,0xf4,0xc5,0x02,0xd6,0xf4,0xcb,0x02,0xc4,0xf4,0xd1,0x02,0xb1,0xf4,0xd7,0x02,  \
    0x9e,0xf4,0xdd,0x02,0x8b,0xf4,0xe4,0x02,0x79,0xf4,0xea,0x02,0x66,0xf4,0xf0,0x02,0x53,0xf4,0xf6,0x02,0x40,0xf4,0xfd,0x02,0x2d,0xf4,0x03,0x03,0x1a,0xf4,0x09,0x03,0x07,0xf4,0x10,0x03,0xf4,0xf3,0x16,0x03,0xe0,0xf3,0x1d,0x03,0xcd,0xf3,0x22,0x03,0xb8,0xf3,0x28,0x03,0xa3,0xf3,0x2d,0x03,0x8e,0xf3,0x33,0x03,0x79,0xf3,0x39,0x03,0x63,0xf3,0x3e,0x03,0x4e,0xf3,0x44,0x03,0x38,0xf3,0x49,0x03,0x23,0xf3,0x4f,0x03,0x0d,0xf3,0x55,0x03,0xf8,0xf2,0x5a,0x03,0xe2,0xf2,  \
    0x60,0x03,0xcc,0xf2,0x65,0x03,0xb7,0xf2,0x6b,0x03,0xa1,0xf2,0x71,0x03,0x8b,0xf2,0x76,0x03,0x75,0xf2,0x7c,0x03,0x5f,0xf2,0x81,0x03,0x49,0xf2,0x87,0x03,0x33,0xf2,0x8e,0x03,0x1f,0xf2,0x95,0x03,0x0a,0xf2,0x9b,0x03,0xf5,0xf1,0xa2,0x03,0xe0,0xf1,0xa8,0x03,0xcc,0xf1,0xaf,0x03,0xb7,0xf1,0xb5,0x03,0xa1,0xf1,0xbc,0x03,0x8c,0xf1,0xc2,0x03,0x77,0xf1,0xc9,0x03,0x62,0xf1,0xcf,0x03,0x4c,0xf1,0xd6,0x03,0x37,0xf1,0xdc,0x03,0x21,0xf1,0xe2,0x03,0x0b,0xf1,0xe9,0x03,  \
    0xf5,0xf0,0xef,0x03,0xdf,0xf0,0xf5,0x03,0xc9,0xf0,0xfc,0x03,0xb3,0xf0,0x02,0x04,0x9c,0xf0,0x08,0x04,0x86,0xf0,0x0f,0x04,0x70,0xf0,0x15,0x04,0x59,0xf0,0x1b,0x04,0x43,0xf0,0x21,0x04,0x2c,0xf0,0x27,0x04,0x15,0xf0,0x2d,0x04,0xfe,0xef,0x33,0x04,0xe7,0xef,0x39,0x04,0xd0,0xef,0x3f,0x04,0xb8,0xef,0x45,0x04,0xa0,0xef,0x4b,0x04,0x89,0xef,0x50,0x04,0x71,0xef,0x56,0x04,0x59,0xef,0x5b,0x04,0x40,0xef,0x61,0x04,0x28,0xef,0x66,0x04,0x0f,0xef,0x6b,0x04,0xf7,0xee,  \
    0x70,0x04,0xde,0xee,0x75,0x04,0xc4,0xee,0x79,0x04,0xaa,0xee,0x7d,0x04,0x90,0xee,0x81,0x04,0x75,0xee,0x85,0x04,0x5b,0xee,0x89,0x04,0x40,0xee,0x8c,0x04,0x25,0xee,0x90,0x04,0x0a,0xee,0x94,0x04,0xee,0xed,0x97,0x04,0xd3,0xed,0x9a,0x04,0xb7,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x28,0x05,0xde,0x11,0x24,0x05,0xc2,0x11,0x20,0x05,0xa7,0x11,0x1c,0x05,0x8c,0x11,0x18,0x05,0x71,0x11,0x13,0x05,0x56,0x11,0x0f,0x05,0x3c,0x11,0x0a,0x05,0x21,0x11,0x05,0x05,0x07,0x11,0x01,0x05,0xec,0x10,0xfc,0x04,0xd2,0x10,0xf6,0x04,0xb8,0x10,0xf1,0x04,0x9f,0x10,0xec,0x04,0x85,0x10,0xe7,0x04,0x6b,0x10,0xe1,0x04,0x52,0x10,0xdc,0x04,0x39,0x10,0xd6,0x04,0x1f,0x10,  \
    0xd1,0x04,0x06,0x10,0xcb,0x04,0xee,0x0f,0xc5,0x04,0xd5,0x0f,0xbe,0x04,0xbd,0x0f,0xb8,0x04,0xa5,0x0f,0xb1,0x04,0x8e,0x0f,0xab,0x04,0x76,0x0f,0xa4,0x04,0x5f,0x0f,0x9d,0x04,0x47,0x0f,0x96,0x04,0x30,0x0f,0x8f,0x04,0x19,0x0f,0x88,0x04,0x02,0x0f,0x81,0x04,0xec,0x0e,0x7a,0x04,0xd5,0x0e,0x73,0x04,0xbe,0x0e,0x6c,0x04,0xa8,0x0e,0x65,0x04,0x92,0x0e,0x5e,0x04,0x7c,0x0e,0x57,0x04,0x65,0x0e,0x4f,0x04,0x50,0x0e,0x48,0x04,0x3a,0x0e,0x41,0x04,0x24,0x0e,0x39,0x04,  \
    0x0f,0x0e,0x31,0x04,0xfb,0x0d,0x28,0x04,0xe6,0x0d,0x20,0x04,0xd2,0x0d,0x18,0x04,0xbe,0x0d,0x10,0x04,0xaa,0x0d,0x08,0x04,0x96,0x0d,0xff,0x03,0x82,0x0d,0xf7,0x03,0x6f,0x0d,0xef,0x03,0x5b,0x0d,0xe7,0x03,0x48,0x0d,0xde,0x03,0x34,0x0d,0xd6,0x03,0x21,0x0d,0xce,0x03,0x0e,0x0d,0xc5,0x03,0xfb,0x0c,0xbd,0x03,0xe8,0x0c,0xb5,0x03,0xd6,0x0c,0xad,0x03,0xc2,0x0c,0xa7,0x03,0xad,0x0c,0xa0,0x03,0x97,0x0c,0x9a,0x03,0x82,0x0c,0x93,0x03,0x6c,0x0c,0x8d,0x03,0x57,0x0c,  \
    0x87,0x03,0x42,0x0c,0x80,0x03,0x2c,0x0c,0x7a,0x03,0x17,0x0c,0x74,0x03,0x02,0x0c,0x6d,0x03,0xed,0x0b,0x67,0x03,0xd8,0x0b,0x61,0x03,0xc3,0x0b,0x5a,0x03,0xae,0x0b,0x54,0x03,0x99,0x0b,0x4e,0x03,0x84,0x0b,0x47,0x03,0x70,0x0b,0x41,0x03,0x5b,0x0b,0x3b,0x03,0x46,0x0b,0x35,0x03,0x32,0x0b,0x2f,0x03,0x1d,0x0b,0x29,0x03,0x08,0x0b,0x23,0x03,0xf4,0x0a,0x1c,0x03,0xdf,0x0a,0x16,0x03,0xcb,0x0a,0x10,0x03,0xb6,0x0a,0x0a,0x03,0xa2,0x0a,0x04,0x03,0x8e,0x0a,0xfe,0x02,  \
    0x79,0x0a,0xf8,0x02,0x65,0x0a,0xf2,0x02,0x51,0x0a,0xec,0x02,0x3d,0x0a,0xe7,0x02,0x29,0x0a,0xe1,0x02,0x15,0x0a,0xdb,0x02,0x01,0x0a,0xd5,0x02,0xed,0x09,0xcf,0x02,0xd9,0x09,0xc8,0x02,0xc8,0x09,0xc1,0x02,0xb7,0x09,0xba,0x02,0xa6,0x09,0xb3,0x02,0x94,0x09,0xac,0x02,0x83,0x09,0xa6,0x02,0x72,0x09,0x9f,0x02,0x61,0x09,0x98,0x02,0x50,0x09,0x92,0x02,0x3f,0x09,0x8b,0x02,0x2e,0x09,0x84,0x02,0x1d,0x09,0x7e,0x02,0x0c,0x09,0x77,0x02,0xfb,0x08,0x71,0x02,0xeb,0x08,  \
    0x6b,0x02,0xda,0x08,0x65,0x02,0xc9,0x08,0x5e,0x02,0xb8,0x08,0x58,0x02,0xa7,0x08,0x52,0x02,0x97,0x08,0x4c,0x02,0x86,0x08,0x46,0x02,0x75,0x08,0x40,0x02,0x64,0x08,0x3b,0x02,0x53,0x08,0x35,0x02,0x41,0x08,0x2f,0x02,0x30,0x08,0x2a,0x02,0x1f,0x08,0x24,0x02,0x0e,0x08,0x1f,0x02,0xfd,0x07,0x19,0x02,0xec,0x07,0x14,0x02,0xdb,0x07,0x0f,0x02,0xca,0x07,0x09,0x02,0xb9,0x07,0x04,0x02,0xa8,0x07,0xff,0x01,0x97,0x07,0xfa,0x01,0x86,0x07,0xf5,0x01,0x75,0x07,0xf0,0x01,  \
    0x64,0x07,0xeb,0x01,0x53,0x07,0xe6,0x01,0x42,0x07,0xe1,0x01,0x31,0x07,0xdc,0x01,0x20,0x07,0xd8,0x01,0x0f,0x07,0xd3,0x01,0xfe,0x06,0xcf,0x01,0xec,0x06,0xcb,0x01,0xd9,0x06,0xc7,0x01,0xc7,0x06,0xc3,0x01,0xb4,0x06,0xbf,0x01,0xa2,0x06,0xbb,0x01,0x8f,0x06,0xb7,0x01,0x7d,0x06,0xb3,0x01,0x6a,0x06,0xaf,0x01,0x58,0x06,0xab,0x01,0x46,0x06,0xa7,0x01,0x33,0x06,0xa4,0x01,0x21,0x06,0xa0,0x01,0x0f,0x06,0x9c,0x01,0xfc,0x05,0x99,0x01,0xea,0x05,0x95,0x01,0xd8,0x05,  \
    0x91,0x01,0xc5,0x05,0x8e,0x01,0xb3,0x05,0x8a,0x01,0xa1,0x05,0x87,0x01,0x8f,0x05,0x84,0x01,0x7d,0x05,0x80,0x01,0x6b,0x05,0x7d,0x01,0x58,0x05,0x7a,0x01,0x46,0x05,0x76,0x01,0x35,0x05,0x73,0x01,0x24,0x05,0x6f,0x01,0x13,0x05,0x6c,0x01,0x02,0x05,0x68,0x01,0xf1,0x04,0x65,0x01,0xe0,0x04,0x62,0x01,0xcf,0x04,0x5f,0x01,0xbe,0x04,0x5c,0x01,0xad,0x04,0x58,0x01,0x9c,0x04,0x55,0x01,0x8b,0x04,0x52,0x01,0x7a,0x04,0x4f,0x01,0x68,0x04,0x4d,0x01,0x57,0x04,0x4a,0x01,  \
    0x46,0x04,0x47,0x01,0x35,0x04,0x44,0x01,0x24,0x04,0x41,0x01,0x13,0x04,0x3f,0x01,0x02,0x04,0x3c,0x01,0xf1,0x03,0x39,0x01,0xe0,0x03,0x37,0x01,0xcf,0x03,0x34,0x01,0xbd,0x03,0x32,0x01,0xac,0x03,0x2f,0x01,0x9b,0x03,0x2d,0x01,0x8a,0x03,0x2b,0x01,0x7a,0x03,0x28,0x01,0x6a,0x03,0x26,0x01,0x59,0x03,0x24,0x01,0x49,0x03,0x21,0x01,0x39,0x03,0x1f,0x01,0x28,0x03,0x1d,0x01,0x18,0x03,0x1b,0x01,0x07,0x03,0x19,0x01,0xf7,0x02,0x17,0x01,0xe6,0x02,0x15,0x01,0xd6,0x02,  \
    0x13,0x01,0xc5,0x02,0x11,0x01,0xb5,0x02,0x0f,0x01,0xa4,0x02,0x0e,0x01,0x93,0x02,0x0c,0x01,0x82,0x02,0x0a,0x01,0x72,0x02,0x09,0x01,0x61,0x02,0x07,0x01,0x50,0x02,0x06,0x01,0x3f,0x02,0x04,0x01,0x2e,0x02,0x03,0x01,0x1d,0x02,0x01,0x01,0x0d,0x02,0x00,0x01,0xfc,0x01,0xff,0x00,0xeb,0x01,0xfe,0x00,0xd9,0x01,0xfc,0x00,0xc8,0x01,0xfb,0x00,0xb7,0x01,0xfa,0x00,0xa5,0x01,0xf9,0x00,0x93,0x01,0xf8,0x00,0x82,0x01,0xf7,0x00,0x70,0x01,0xf6,0x00,0x5e,0x01,0xf5,0x00,  \
    0x4d,0x01,0xf5,0x00,0x3b,0x01,0xf4,0x00,0x29,0x01,0xf3,0x00,0x18,0x01,0xf2,0x00,0x06,0x01,0xf2,0x00,0xf4,0x00,0xf1,0x00,0xe3,0x00,0xf0,0x00,0xd1,0x00,0xf0,0x00,0xbf,0x00,0xef,0x00,0xae,0x00,0xef,0x00,0x9c,0x00,0xee,0x00,0x8a,0x00,0xee,0x00,0x79,0x00,0xee,0x00,0x67,0x00,0xed,0x00,0x55,0x00,0xed,0x00,0x44,0x00,0xed,0x00,0x32,0x00,0xec,0x00,0x20,0x00,0xec,0x00,0x0e,0x00,0xec,0x00,0xfd,0xff,0xec,0x00,0xeb,0xff,0xec,0x00,0xd9,0xff,0xec,0x00,0xc8,0xff,  \
    0xec,0x00,0xb6,0xff,0xec,0x00,0xa4,0xff,0xec,0x00,0x93,0xff,0xec,0x00,0x81,0xff,0xec,0x00,0x6f,0xff,0xec,0x00,0x5e,0xff,0xed,0x00,0x4c,0xff,0xed,0x00,0x3a,0xff,0xed,0x00,0x29,0xff,0xee,0x00,0x17,0xff,0xee,0x00,0x05,0xff,0xee,0x00,0xf3,0xfe,0xef,0x00,0xe2,0xfe,0xef,0x00,0xd0,0xfe,0xf0,0x00,0xbe,0xfe,0xf0,0x00,0xad,0xfe,0xf1,0x00,0x9b,0xfe,0xf2,0x00,0x89,0xfe,0xf2,0x00,0x78,0xfe,0xf3,0x00,0x66,0xfe,0xf4,0x00,0x55,0xfe,0xf4,0x00,0x43,0xfe,0xf5,0x00,  \
    0x31,0xfe,0xf6,0x00,0x20,0xfe,0xf7,0x00,0x0e,0xfe,0xf8,0x00,0xfc,0xfd,0xf9,0x00,0xeb,0xfd,0xfa,0x00,0xd9,0xfd,0xfb,0x00,0xc7,0xfd,0xfc,0x00,0xb5,0xfd,0xfd,0x00,0xa3,0xfd,0xfe,0x00,0x91,0xfd,0xff,0x00,0x7f,0xfd,0x00,0x01,0x6d,0xfd,0x02,0x01,0x5b,0xfd,0x03,0x01,0x49,0xfd,0x04,0x01,0x37,0xfd,0x06,0x01,0x25,0xfd,0x07,0x01,0x13,0xfd,0x08,0x01,0x01,0xfd,0x0a,0x01,0xef,0xfc,0x0b,0x01,0xdd,0xfc,0x0d,0x01,0xcb,0xfc,0x0e,0x01,0xb9,0xfc,0x10,0x01,0xa7,0xfc,  \
    0x11,0x01,0x95,0xfc,0x13,0x01,0x82,0xfc,0x15,0x01,0x70,0xfc,0x16,0x01,0x5e,0xfc,0x18,0x01,0x4c,0xfc,0x1a,0x01,0x3a,0xfc,0x1c,0x01,0x27,0xfc,0x1d,0x01,0x15,0xfc,0x1f,0x01,0x03,0xfc,0x21,0x01,0xf1,0xfb,0x23,0x01,0xdf,0xfb,0x25,0x01,0xce,0xfb,0x27,0x01,0xbc,0xfb,0x2a,0x01,0xab,0xfb,0x2c,0x01,0x9a,0xfb,0x2e,0x01,0x88,0xfb,0x30,0x01,0x77,0xfb,0x33,0x01,0x66,0xfb,0x35,0x01,0x54,0xfb,0x37,0x01,0x43,0xfb,0x3a,0x01,0x31,0xfb,0x3c,0x01,0x20,0xfb,0x3f,0x01,  \
    0x0f,0xfb,0x42,0x01,0xfe,0xfa,0x44,0x01,0xec,0xfa,0x47,0x01,0xdb,0xfa,0x4a,0x01,0xca,0xfa,0x4c,0x01,0xb9,0xfa,0x4f,0x01,0xa7,0xfa,0x52,0x01,0x96,0xfa,0x55,0x01,0x85,0xfa,0x58,0x01,0x74,0xfa,0x5b,0x01,0x62,0xfa,0x5e,0x01,0x51,0xfa,0x61,0x01,0x40,0xfa,0x64,0x01,0x2f,0xfa,0x67,0x01,0x1d,0xfa,0x6a,0x01,0x0c,0xfa,0x6d,0x01,0xfa,0xf9,0x71,0x01,0xe8,0xf9,0x74,0x01,0xd6,0xf9,0x77,0x01,0xc4,0xf9,0x7a,0x01,0xb2,0xf9,0x7d,0x01,0xa0,0xf9,0x81,0x01,0x8e,0xf9,  \
    0x84,0x01,0x7c,0xf9,0x88,0x01,0x6a,0xf9,0x8b,0x01,0x58,0xf9,0x8e,0x01,0x46,0xf9,0x92,0x01,0x34,0xf9,0x96,0x01,0x22,0xf9,0x99,0x01,0x10,0xf9,0x9d,0x01,0xfe,0xf8,0xa0,0x01,0xec,0xf8,0xa4,0x01,0xda,0xf8,0xa8,0x01,0xc8,0xf8,0xac,0x01,0xb6,0xf8,0xb0,0x01,0xa4,0xf8,0xb3,0x01,0x92,0xf8,0xb7,0x01,0x80,0xf8,0xbb,0x01,0x6e,0xf8,0xbf,0x01,0x5c,0xf8,0xc4,0x01,0x4b,0xf8,0xc8,0x01,0x39,0xf8,0xcc,0x01,0x28,0xf8,0xd0,0x01,0x16,0xf8,0xd5,0x01,0x05,0xf8,0xd9,0x01,  \
    0xf3,0xf7,0xde,0x01,0xe1,0xf7,0xe2,0x01,0xd0,0xf7,0xe7,0x01,0xbe,0xf7,0xeb,0x01,0xad,0xf7,0xf0,0x01,0x9b,0xf7,0xf5,0x01,0x89,0xf7,0xf9,0x01,0x78,0xf7,0xfe,0x01,0x66,0xf7,0x03,0x02,0x55,0xf7,0x08,0x02,0x43,0xf7,0x0d,0x02,0x31,0xf7,0x12,0x02,0x20,0xf7,0x17,0x02,0x0e,0xf7,0x1c,0x02,0xfc,0xf6,0x21,0x02,0xea,0xf6,0x26,0x02,0xd9,0xf6,0x2b,0x02,0xc7,0xf6,0x30,0x02,0xb4,0xf6,0x35,0x02,0xa2,0xf6,0x3a,0x02,0x8f,0xf6,0x3f,0x02,0x7d,0xf6,0x44,0x02,0x6a,0xf6,  \
    0x49,0x02,0x57,0xf6,0x4e,0x02,0x45,0xf6,0x53,0x02,0x32,0xf6,0x59,0x02,0x20,0xf6,0x5e,0x02,0x0d,0xf6,0x63,0x02,0xfa,0xf5,0x69,0x02,0xe8,0xf5,0x6e,0x02,0xd5,0xf5,0x73,0x02,0xc2,0xf5,0x79,0x02,0xaf,0xf5,0x7e,0x02,0x9d,0xf5,0x84,0x02,0x8a,0xf5,0x89,0x02,0x77,0xf5,0x8f,0x02,0x64,0xf5,0x95,0x02,0x51,0xf5,0x9a,0x02,0x3e,0xf5,0xa0,0x02,0x2c,0xf5,0xa6,0x02,0x19,0xf5,0xac,0x02,0x07,0xf5,0xb2,0x02,0xf4,0xf4,0xb8,0x02,0xe2,0xf4,0xbf,0x02,0xcf,0xf4,0xc5,0x02,  \
    0xbd,0xf4,0xcb,0x02,0xaa,0xf4,0xd1,0x02,0x97,0xf4,0xd7,0x02,0x84,0xf4,0xde,0x02,0x71,0xf4,0xe4,0x02,0x5f,0xf4,0xea,0x02,0x4c,0xf4,0xf0,0x02,0x39,0xf4,0xf7,0x02,0x26,0xf4,0xfd,0x02,0x13,0xf4,0x04,0x03,0xff,0xf3,0x0a,0x03,0xec,0xf3,0x11,0x03,0xd9,0xf3,0x16,0x03,0xc4,0xf3,0x1c,0x03,0xaf,0xf3,0x21,0x03,0x9a,0xf3,0x27,0x03,0x85,0xf3,0x2d,0x03,0x6f,0xf3,0x32,0x03,0x5a,0xf3,0x38,0x03,0x45,0xf3,0x3d,0x03,0x2f,0xf3,0x43,0x03,0x1a,0xf3,0x49,0x03,0x04,0xf3,  \
    0x4e,0x03,0xef,0xf2,0x54,0x03,0xd9,0xf2,0x5a,0x03,0xc3,0xf2,0x5f,0x03,0xad,0xf2,0x65,0x03,0x97,0xf2,0x6b,0x03,0x81,0xf2,0x70,0x03,0x6b,0xf2,0x76,0x03,0x55,0xf2,0x7c,0x03,0x40,0xf2,0x82,0x03,0x2b,0xf2,0x89,0x03,0x17,0xf2,0x90,0x03,0x02,0xf2,0x96,0x03,0xed,0xf1,0x9d,0x03,0xd8,0xf1,0xa3,0x03,0xc3,0xf1,0xaa,0x03,0xae,0xf1,0xb0,0x03,0x99,0xf1,0xb7,0x03,0x84,0xf1,0xbd,0x03,0x6e,0xf1,0xc4,0x03,0x59,0xf1,0xca,0x03,0x43,0xf1,0xd1,0x03,0x2d,0xf1,0xd7,0x03,  \
    0x17,0xf1,0xde,0x03,0x02,0xf1,0xe4,0x03,0xeb,0xf0,0xea,0x03,0xd5,0xf0,0xf0,0x03,0xbf,0xf0,0xf7,0x03,0xa9,0xf0,0xfd,0x03,0x93,0xf0,0x03,0x04,0x7c,0xf0,0x0a,0x04,0x66,0xf0,0x10,0x04,0x4f,0xf0,0x16,0x04,0x38,0xf0,0x1c,0x04,0x21,0xf0,0x22,0x04,0x0a,0xf0,0x28,0x04,0xf3,0xef,0x2e,0x04,0xdc,0xef,0x34,0x04,0xc4,0xef,0x3a,0x04,0xad,0xef,0x3f,0x04,0x95,0xef,0x45,0x04,0x7d,0xef,0x4a,0x04,0x65,0xef,0x50,0x04,0x4c,0xef,0x55,0x04,0x34,0xef,0x5a,0x04,0x1b,0xef,  \
    0x60,0x04,0x03,0xef,0x65,0x04,0xea,0xee,0x69,0x04,0xd0,0xee,0x6e,0x04,0xb6,0xee,0x72,0x04,0x9c,0xee,0x76,0x04,0x81,0xee,0x7a,0x04,0x66,0xee,0x7d,0x04,0x4c,0xee,0x81,0x04,0x31,0xee,0x85,0x04,0x15,0xee,0x88,0x04,0xfa,0xed,0x8c,0x04,0xdf,0xed,0x8f,0x04,0xc3,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x05,0xd6,0x11,0x14,0x05,0xbb,0x11,0x10,0x05,0x9f,0x11,0x0c,0x05,0x84,0x11,0x08,0x05,0x69,0x11,0x03,0x05,0x4e,0x11,0xff,0x04,0x34,0x11,0xfa,0x04,0x19,0x11,0xf6,0x04,0xff,0x10,0xf1,0x04,0xe4,0x10,0xec,0x04,0xca,0x10,0xe7,0x04,0xb0,0x10,0xe2,0x04,0x97,0x10,0xdc,0x04,0x7d,0x10,0xd7,0x04,0x63,0x10,0xd2,0x04,0x4a,0x10,0xcc,0x04,0x31,0x10,  \
    0xc7,0x04,0x17,0x10,0xc1,0x04,0xfe,0x0f,0xbb,0x04,0xe5,0x0f,0xb5,0x04,0xcd,0x0f,0xaf,0x04,0xb5,0x0f,0xa8,0x04,0x9d,0x0f,0xa2,0x04,0x85,0x0f,0x9b,0x04,0x6e,0x0f,0x95,0x04,0x56,0x0f,0x8e,0x04,0x3f,0x0f,0x87,0x04,0x28,0x0f,0x80,0x04,0x11,0x0f,0x79,0x04,0xfa,0x0e,0x72,0x04,0xe3,0x0e,0x6b,0x04,0xcc,0x0e,0x64,0x04,0xb6,0x0e,0x5d,0x04,0x9f,0x0e,0x56,0x04,0x89,0x0e,0x4f,0x04,0x73,0x0e,0x48,0x04,0x5d,0x0e,0x41,0x04,0x47,0x0e,0x39,0x04,0x31,0x0e,0x32,0x04,  \
    0x1b,0x0e,0x2a,0x04,0x06,0x0e,0x22,0x04,0xf1,0x0d,0x1a,0x04,0xdd,0x0d,0x12,0x04,0xc9,0x0d,0x0a,0x04,0xb5,0x0d,0x02,0x04,0xa1,0x0d,0xf9,0x03,0x8d,0x0d,0xf1,0x03,0x79,0x0d,0xe9,0x03,0x65,0x0d,0xe1,0x03,0x51,0x0d,0xd9,0x03,0x3e,0x0d,0xd0,0x03,0x2b,0x0d,0xc8,0x03,0x17,0x0d,0xc0,0x03,0x04,0x0d,0xb8,0x03,0xf1,0x0c,0xaf,0x03,0xde,0x0c,0xa7,0x03,0xcc,0x0c,0x9f,0x03,0xb8,0x0c,0x99,0x03,0xa3,0x0c,0x92,0x03,0x8d,0x0c,0x8c,0x03,0x78,0x0c,0x86,0x03,0x62,0x0c,  \
    0x7f,0x03,0x4d,0x0c,0x79,0x03,0x38,0x0c,0x72,0x03,0x23,0x0c,0x6c,0x03,0x0d,0x0c,0x66,0x03,0xf8,0x0b,0x5f,0x03,0xe3,0x0b,0x59,0x03,0xce,0x0b,0x53,0x03,0xb9,0x0b,0x4c,0x03,0xa4,0x0b,0x46,0x03,0x8f,0x0b,0x40,0x03,0x7b,0x0b,0x3a,0x03,0x66,0x0b,0x33,0x03,0x51,0x0b,0x2d,0x03,0x3d,0x0b,0x27,0x03,0x28,0x0b,0x21,0x03,0x13,0x0b,0x1b,0x03,0xff,0x0a,0x15,0x03,0xea,0x0a,0x0f,0x03,0xd6,0x0a,0x08,0x03,0xc1,0x0a,0x02,0x03,0xad,0x0a,0xfc,0x02,0x99,0x0a,0xf6,0x02,  \
    0x84,0x0a,0xf0,0x02,0x70,0x0a,0xea,0x02,0x5c,0x0a,0xe4,0x02,0x48,0x0a,0xde,0x02,0x34,0x0a,0xd9,0x02,0x20,0x0a,0xd3,0x02,0x0c,0x0a,0xcd,0x02,0xf8,0x09,0xc7,0x02,0xe4,0x09,0xc1,0x02,0xd0,0x09,0xba,0x02,0xbf,0x09,0xb3,0x02,0xae,0x09,0xac,0x02,0x9d,0x09,0xa5,0x02,0x8b,0x09,0x9e,0x02,0x7a,0x09,0x98,0x02,0x69,0x09,0x91,0x02,0x58,0x09,0x8a,0x02,0x47,0x09,0x84,0x02,0x36,0x09,0x7d,0x02,0x25,0x09,0x76,0x02,0x14,0x09,0x70,0x02,0x03,0x09,0x6a,0x02,0xf2,0x08,  \
    0x63,0x02,0xe2,0x08,0x5d,0x02,0xd1,0x08,0x57,0x02,0xc0,0x08,0x50,0x02,0xaf,0x08,0x4a,0x02,0x9e,0x08,0x44,0x02,0x8e,0x08,0x3e,0x02,0x7d,0x08,0x38,0x02,0x6c,0x08,0x32,0x02,0x5b,0x08,0x2d,0x02,0x4a,0x08,0x27,0x02,0x39,0x08,0x21,0x02,0x28,0x08,0x1c,0x02,0x17,0x08,0x16,0x02,0x05,0x08,0x11,0x02,0xf4,0x07,0x0b,0x02,0xe3,0x07,0x06,0x02,0xd2,0x07,0x01,0x02,0xc1,0x07,0xfb,0x01,0xb0,0x07,0xf6,0x01,0x9f,0x07,0xf1,0x01,0x8e,0x07,0xec,0x01,0x7e,0x07,0xe7,0x01,  \
    0x6d,0x07,0xe2,0x01,0x5c,0x07,0xdd,0x01,0x4b,0x07,0xd8,0x01,0x3a,0x07,0xd3,0x01,0x29,0x07,0xce,0x01,0x18,0x07,0xca,0x01,0x07,0x07,0xc5,0x01,0xf6,0x06,0xc1,0x01,0xe3,0x06,0xbd,0x01,0xd1,0x06,0xb9,0x01,0xbf,0x06,0xb5,0x01,0xac,0x06,0xb1,0x01,0x9a,0x06,0xad,0x01,0x87,0x06,0xa9,0x01,0x75,0x06,0xa5,0x01,0x63,0x06,0xa1,0x01,0x50,0x06,0x9d,0x01,0x3e,0x06,0x99,0x01,0x2c,0x06,0x95,0x01,0x1a,0x06,0x92,0x01,0x07,0x06,0x8e,0x01,0xf5,0x05,0x8a,0x01,0xe3,0x05,  \
    0x87,0x01,0xd1,0x05,0x83,0x01,0xbe,0x05,0x80,0x01,0xac,0x05,0x7c,0x01,0x9a,0x05,0x79,0x01,0x88,0x05,0x75,0x01,0x76,0x05,0x72,0x01,0x64,0x05,0x6e,0x01,0x52,0x05,0x6b,0x01,0x40,0x05,0x68,0x01,0x2f,0x05,0x64,0x01,0x1e,0x05,0x61,0x01,0x0d,0x05,0x5d,0x01,0xfc,0x04,0x5a,0x01,0xeb,0x04,0x57,0x01,0xda,0x04,0x53,0x01,0xc9,0x04,0x50,0x01,0xb8,0x04,0x4d,0x01,0xa7,0x04,0x4a,0x01,0x96,0x04,0x47,0x01,0x85,0x04,0x44,0x01,0x74,0x04,0x41,0x01,0x63,0x04,0x3e,0x01,  \
    0x52,0x04,0x3b,0x01,0x41,0x04,0x38,0x01,0x30,0x04,0x35,0x01,0x1f,0x04,0x33,0x01,0x0e,0x04,0x30,0x01,0xfd,0x03,0x2d,0x01,0xec,0x03,0x2b,0x01,0xdb,0x03,0x28,0x01,0xca,0x03,0x26,0x01,0xb9,0x03,0x23,0x01,0xa8,0x03,0x21,0x01,0x97,0x03,0x1e,0x01,0x86,0x03,0x1c,0x01,0x76,0x03,0x1a,0x01,0x65,0x03,0x17,0x01,0x55,0x03,0x15,0x01,0x45,0x03,0x13,0x01,0x34,0x03,0x10,0x01,0x24,0x03,0x0e,0x01,0x14,0x03,0x0c,0x01,0x03,0x03,0x0a,0x01,0xf3,0x02,0x08,0x01,0xe2,0x02,  \
    0x06,0x01,0xd2,0x02,0x04,0x01,0xc1,0x02,0x02,0x01,0xb1,0x02,0x01,0x01,0xa0,0x02,0xff,0x00,0x90,0x02,0xfd,0x00,0x7f,0x02,0xfb,0x00,0x6e,0x02,0xfa,0x00,0x5e,0x02,0xf8,0x00,0x4d,0x02,0xf7,0x00,0x3c,0x02,0xf5,0x00,0x2b,0x02,0xf4,0x00,0x1a,0x02,0xf2,0x00,0x09,0x02,0xf1,0x00,0xf9,0x01,0xf0,0x00,0xe8,0x01,0xef,0x00,0xd7,0x01,0xed,0x00,0xc6,0x01,0xec,0x00,0xb4,0x01,0xeb,0x00,0xa3,0x01,0xea,0x00,0x91,0x01,0xe9,0x00,0x7f,0x01,0xe8,0x00,0x6e,0x01,0xe7,0x00,  \
    0x5c,0x01,0xe6,0x00,0x4b,0x01,0xe6,0x00,0x39,0x01,0xe5,0x00,0x28,0x01,0xe4,0x00,0x16,0x01,0xe3,0x00,0x04,0x01,0xe3,0x00,0xf3,0x00,0xe2,0x00,0xe1,0x00,0xe1,0x00,0xd0,0x00,0xe1,0x00,0xbe,0x00,0xe0,0x00,0xac,0x00,0xe0,0x00,0x9b,0x00,0xdf,0x00,0x89,0x00,0xdf,0x00,0x78,0x00,0xdf,0x00,0x66,0x00,0xde,0x00,0x54,0x00,0xde,0x00,0x43,0x00,0xde,0x00,0x31,0x00,0xdd,0x00,0x20,0x00,0xdd,0x00,0x0e,0x00,0xdd,0x00,0xfc,0xff,0xdd,0x00,0xeb,0xff,0xdd,0x00,0xd9,0xff,  \
    0xdd,0x00,0xc8,0xff,0xdd,0x00,0xb6,0xff,0xdd,0x00,0xa4,0xff,0xdd,0x00,0x93,0xff,0xdd,0x00,0x81,0xff,0xdd,0x00,0x70,0xff,0xde,0x00,0x5e,0xff,0xde,0x00,0x4d,0xff,0xde,0x00,0x3b,0xff,0xde,0x00,0x29,0xff,0xdf,0x00,0x18,0xff,0xdf,0x00,0x06,0xff,0xdf,0x00,0xf5,0xfe,0xe0,0x00,0xe3,0xfe,0xe0,0x00,0xd1,0xfe,0xe1,0x00,0xc0,0xfe,0xe1,0x00,0xae,0xfe,0xe2,0x00,0x9d,0xfe,0xe3,0x00,0x8b,0xfe,0xe3,0x00,0x7a,0xfe,0xe4,0x00,0x68,0xfe,0xe5,0x00,0x56,0xfe,0xe6,0x00,  \
    0x45,0xfe,0xe6,0x00,0x33,0xfe,0xe7,0x00,0x22,0xfe,0xe8,0x00,0x10,0xfe,0xe9,0x00,0xff,0xfd,0xea,0x00,0xed,0xfd,0xeb,0x00,0xdb,0xfd,0xec,0x00,0xca,0xfd,0xed,0x00,0xb8,0xfd,0xee,0x00,0xa6,0xfd,0xef,0x00,0x94,0xfd,0xf0,0x00,0x82,0xfd,0xf2,0x00,0x70,0xfd,0xf3,0x00,0x5e,0xfd,0xf4,0x00,0x4d,0xfd,0xf5,0x00,0x3b,0xfd,0xf7,0x00,0x29,0xfd,0xf8,0x00,0x17,0xfd,0xfa,0x00,0x05,0xfd,0xfb,0x00,0xf3,0xfc,0xfc,0x00,0xe1,0xfc,0xfe,0x00,0xcf,0xfc,0xff,0x00,0xbd,0xfc,  \
    0x01,0x01,0xab,0xfc,0x03,0x01,0x99,0xfc,0x04,0x01,0x87,0xfc,0x06,0x01,0x75,0xfc,0x08,0x01,0x63,0xfc,0x09,0x01,0x51,0xfc,0x0b,0x01,0x3f,0xfc,0x0d,0x01,0x2c,0xfc,0x0f,0x01,0x1a,0xfc,0x11,0x01,0x08,0xfc,0x13,0x01,0xf6,0xfb,0x15,0x01,0xe5,0xfb,0x17,0x01,0xd3,0xfb,0x19,0x01,0xc2,0xfb,0x1b,0x01,0xb1,0xfb,0x1d,0x01,0x9f,0xfb,0x20,0x01,0x8e,0xfb,0x22,0x01,0x7d,0xfb,0x24,0x01,0x6b,0xfb,0x27,0x01,0x5a,0xfb,0x29,0x01,0x49,0xfb,0x2c,0x01,0x38,0xfb,0x2e,0x01,  \
    0x26,0xfb,0x31,0x01,0x15,0xfb,0x33,0x01,0x04,0xfb,0x36,0x01,0xf3,0xfa,0x39,0x01,0xe2,0xfa,0x3b,0x01,0xd0,0xfa,0x3e,0x01,0xbf,0xfa,0x41,0x01,0xae,0xfa,0x44,0x01,0x9d,0xfa,0x47,0x01,0x8c,0xfa,0x4a,0x01,0x7b,0xfa,0x4d,0x01,0x69,0xfa,0x50,0x01,0x58,0xfa,0x53,0x01,0x47,0xfa,0x56,0x01,0x36,0xfa,0x59,0x01,0x25,0xfa,0x5c,0x01,0x13,0xfa,0x5f,0x01,0x01,0xfa,0x63,0x01,0xef,0xf9,0x66,0x01,0xdd,0xf9,0x69,0x01,0xcc,0xf9,0x6c,0x01,0xba,0xf9,0x70,0x01,0xa8,0xf9,  \
    0x73,0x01,0x96,0xf9,0x76,0x01,0x84,0xf9,0x7a,0x01,0x72,0xf9,0x7d,0x01,0x60,0xf9,0x81,0x01,0x4e,0xf9,0x84,0x01,0x3d,0xf9,0x88,0x01,0x2b,0xf9,0x8b,0x01,0x19,0xf9,0x8f,0x01,0x07,0xf9,0x93,0x01,0xf5,0xf8,0x97,0x01,0xe3,0xf8,0x9a,0x01,0xd1,0xf8,0x9e,0x01,0xbf,0xf8,0xa2,0x01,0xad,0xf8,0xa6,0x01,0x9b,0xf8,0xaa,0x01,0x89,0xf8,0xae,0x01,0x77,0xf8,0xb2,0x01,0x66,0xf8,0xb6,0x01,0x54,0xf8,0xba,0x01,0x43,0xf8,0xbf,0x01,0x31,0xf8,0xc3,0x01,0x20,0xf8,0xc7,0x01,  \
    0x0e,0xf8,0xcc,0x01,0xfd,0xf7,0xd0,0x01,0xeb,0xf7,0xd5,0x01,0xda,0xf7,0xd9,0x01,0xc8,0xf7,0xde,0x01,0xb6,0xf7,0xe3,0x01,0xa5,0xf7,0xe7,0x01,0x93,0xf7,0xec,0x01,0x82,0xf7,0xf1,0x01,0x70,0xf7,0xf6,0x01,0x5f,0xf7,0xfb,0x01,0x4d,0xf7,0x00,0x02,0x3b,0xf7,0x05,0x02,0x2a,0xf7,0x0a,0x02,0x18,0xf7,0x0f,0x02,0x07,0xf7,0x14,0x02,0xf5,0xf6,0x19,0x02,0xe3,0xf6,0x1e,0x02,0xd1,0xf6,0x23,0x02,0xbf,0xf6,0x28,0x02,0xac,0xf6,0x2d,0x02,0x9a,0xf6,0x32,0x02,0x87,0xf6,  \
    0x37,0x02,0x75,0xf6,0x3c,0x02,0x62,0xf6,0x42,0x02,0x50,0xf6,0x47,0x02,0x3d,0xf6,0x4c,0x02,0x2b,0xf6,0x51,0x02,0x18,0xf6,0x57,0x02,0x05,0xf6,0x5c,0x02,0xf3,0xf5,0x62,0x02,0xe0,0xf5,0x67,0x02,0xcd,0xf5,0x6c,0x02,0xbb,0xf5,0x72,0x02,0xa8,0xf5,0x78,0x02,0x95,0xf5,0x7d,0x02,0x82,0xf5,0x83,0x02,0x6f,0xf5,0x88,0x02,0x5d,0xf5,0x8e,0x02,0x4a,0xf5,0x94,0x02,0x37,0xf5,0x9a,0x02,0x25,0xf5,0xa0,0x02,0x13,0xf5,0xa6,0x02,0x00,0xf5,0xac,0x02,0xed,0xf4,0xb2,0x02,  \
    0xdb,0xf4,0xb9,0x02,0xc8,0xf4,0xbf,0x02,0xb6,0xf4,0xc5,0x02,0xa3,0xf4,0xcb,0x02,0x90,0xf4,0xd1,0x02,0x7d,0xf4,0xd8,0x02,0x6a,0xf4,0xde,0x02,0x57,0xf4,0xe4,0x02,0x45,0xf4,0xeb,0x02,0x31,0xf4,0xf1,0x02,0x1e,0xf4,0xf8,0x02,0x0b,0xf4,0xfe,0x02,0xf8,0xf3,0x05,0x03,0xe5,0xf3,0x0a,0x03,0xd0,0xf3,0x10,0x03,0xbb,0xf3,0x16,0x03,0xa6,0xf3,0x1b,0x03,0x91,0xf3,0x21,0x03,0x7c,0xf3,0x27,0x03,0x66,0xf3,0x2c,0x03,0x51,0xf3,0x32,0x03,0x3b,0xf3,0x38,0x03,0x26,0xf3,  \
    0x3d,0x03,0x10,0xf3,0x43,0x03,0xfb,0xf2,0x49,0x03,0xe5,0xf2,0x4e,0x03,0xd0,0xf2,0x54,0x03,0xba,0xf2,0x5a,0x03,0xa4,0xf2,0x5f,0x03,0x8e,0xf2,0x65,0x03,0x78,0xf2,0x6b,0x03,0x62,0xf2,0x71,0x03,0x4c,0xf2,0x77,0x03,0x38,0xf2,0x7e,0x03,0x23,0xf2,0x85,0x03,0x0f,0xf2,0x8b,0x03,0xfa,0xf1,0x92,0x03,0xe5,0xf1,0x98,0x03,0xd0,0xf1,0x9f,0x03,0xbb,0xf1,0xa5,0x03,0xa5,0xf1,0xac,0x03,0x90,0xf1,0xb2,0x03,0x7b,0xf1,0xb9,0x03,0x65,0xf1,0xbf,0x03,0x50,0xf1,0xc6,0x03,  \
    0x3a,0xf1,0xcc,0x03,0x24,0xf1,0xd2,0x03,0x0e,0xf1,0xd9,0x03,0xf8,0xf0,0xdf,0x03,0xe2,0xf0,0xe5,0x03,0xcb,0xf0,0xec,0x03,0xb5,0xf0,0xf2,0x03,0x9f,0xf0,0xf8,0x03,0x89,0xf0,0xff,0x03,0x72,0xf0,0x05,0x04,0x5b,0xf0,0x0b,0x04,0x45,0xf0,0x11,0x04,0x2e,0xf0,0x17,0x04,0x16,0xf0,0x1d,0x04,0xff,0xef,0x23,0x04,0xe8,0xef,0x29,0x04,0xd0,0xef,0x2e,0x04,0xb9,0xef,0x34,0x04,0xa1,0xef,0x3a,0x04,0x89,0xef,0x3f,0x04,0x71,0xef,0x45,0x04,0x58,0xef,0x4a,0x04,0x40,0xef,  \
    0x4f,0x04,0x27,0xef,0x54,0x04,0x0e,0xef,0x5a,0x04,0xf5,0xee,0x5e,0x04,0xdc,0xee,0x62,0x04,0xc2,0xee,0x66,0x04,0xa7,0xee,0x6a,0x04,0x8d,0xee,0x6e,0x04,0x72,0xee,0x72,0x04,0x57,0xee,0x76,0x04,0x3c,0xee,0x7a,0x04,0x21,0xee,0x7d,0x04,0x06,0xee,0x80,0x04,0xeb,0xed,0x84,0x04,0xcf,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x05,0xcf,0x11,0x05,0x05,0xb3,0x11,0x00,0x05,0x98,0x11,0xfc,0x04,0x7d,0x11,0xf8,0x04,0x62,0x11,0xf4,0x04,0x47,0x11,0xef,0x04,0x2c,0x11,0xeb,0x04,0x11,0x11,0xe6,0x04,0xf7,0x10,0xe1,0x04,0xdd,0x10,0xdc,0x04,0xc2,0x10,0xd7,0x04,0xa8,0x10,0xd2,0x04,0x8f,0x10,0xcd,0x04,0x75,0x10,0xc8,0x04,0x5b,0x10,0xc2,0x04,0x42,0x10,  \
    0xbd,0x04,0x28,0x10,0xb7,0x04,0x0f,0x10,0xb2,0x04,0xf6,0x0f,0xac,0x04,0xdd,0x0f,0xa6,0x04,0xc5,0x0f,0xa0,0x04,0xad,0x0f,0x99,0x04,0x95,0x0f,0x93,0x04,0x7d,0x0f,0x8c,0x04,0x65,0x0f,0x86,0x04,0x4e,0x0f,0x7f,0x04,0x37,0x0f,0x78,0x04,0x1f,0x0f,0x71,0x04,0x08,0x0f,0x6b,0x04,0xf1,0x0e,0x64,0x04,0xda,0x0e,0x5d,0x04,0xc4,0x0e,0x56,0x04,0xad,0x0e,0x4f,0x04,0x97,0x0e,0x48,0x04,0x80,0x0e,0x40,0x04,0x6a,0x0e,0x39,0x04,0x54,0x0e,0x32,0x04,0x3e,0x0e,0x2b,0x04,  \
    0x28,0x0e,0x23,0x04,0x12,0x0e,0x1c,0x04,0xfd,0x0d,0x14,0x04,0xe8,0x0d,0x0c,0x04,0xd4,0x0d,0x04,0x04,0xc0,0x0d,0xfc,0x03,0xab,0x0d,0xf4,0x03,0x97,0x0d,0xeb,0x03,0x83,0x0d,0xe3,0x03,0x6f,0x0d,0xdb,0x03,0x5c,0x0d,0xd3,0x03,0x48,0x0d,0xcb,0x03,0x34,0x0d,0xc3,0x03,0x21,0x0d,0xba,0x03,0x0e,0x0d,0xb2,0x03,0xfa,0x0c,0xaa,0x03,0xe7,0x0c,0xa2,0x03,0xd4,0x0c,0x9a,0x03,0xc2,0x0c,0x92,0x03,0xae,0x0c,0x8b,0x03,0x99,0x0c,0x85,0x03,0x83,0x0c,0x7e,0x03,0x6e,0x0c,  \
    0x78,0x03,0x58,0x0c,0x72,0x03,0x43,0x0c,0x6b,0x03,0x2e,0x0c,0x65,0x03,0x19,0x0c,0x5f,0x03,0x03,0x0c,0x58,0x03,0xee,0x0b,0x52,0x03,0xd9,0x0b,0x4c,0x03,0xc4,0x0b,0x45,0x03,0xaf,0x0b,0x3f,0x03,0x9b,0x0b,0x39,0x03,0x86,0x0b,0x32,0x03,0x71,0x0b,0x2c,0x03,0x5c,0x0b,0x26,0x03,0x48,0x0b,0x20,0x03,0x33,0x0b,0x19,0x03,0x1e,0x0b,0x13,0x03,0x0a,0x0b,0x0d,0x03,0xf5,0x0a,0x07,0x03,0xe1,0x0a,0x01,0x03,0xcc,0x0a,0xfb,0x02,0xb8,0x0a,0xf5,0x02,0xa4,0x0a,0xef,0x02,  \
    0x8f,0x0a,0xe9,0x02,0x7b,0x0a,0xe3,0x02,0x67,0x0a,0xdd,0x02,0x53,0x0a,0xd7,0x02,0x3f,0x0a,0xd1,0x02,0x2b,0x0a,0xcb,0x02,0x17,0x0a,0xc5,0x02,0x03,0x0a,0xbf,0x02,0xef,0x09,0xb9,0x02,0xdb,0x09,0xb3,0x02,0xc7,0x09,0xac,0x02,0xb6,0x09,0xa5,0x02,0xa5,0x09,0x9e,0x02,0x94,0x09,0x97,0x02,0x82,0x09,0x91,0x02,0x71,0x09,0x8a,0x02,0x60,0x09,0x83,0x02,0x4f,0x09,0x7d,0x02,0x3e,0x09,0x76,0x02,0x2d,0x09,0x6f,0x02,0x1c,0x09,0x69,0x02,0x0b,0x09,0x62,0x02,0xfa,0x08,  \
    0x5c,0x02,0xe9,0x08,0x56,0x02,0xd9,0x08,0x4f,0x02,0xc8,0x08,0x49,0x02,0xb7,0x08,0x43,0x02,0xa6,0x08,0x3d,0x02,0x95,0x08,0x37,0x02,0x85,0x08,0x31,0x02,0x74,0x08,0x2b,0x02,0x63,0x08,0x25,0x02,0x52,0x08,0x1f,0x02,0x41,0x08,0x19,0x02,0x30,0x08,0x14,0x02,0x1f,0x08,0x0e,0x02,0x0e,0x08,0x09,0x02,0xfd,0x07,0x03,0x02,0xec,0x07,0xfe,0x01,0xdb,0x07,0xf8,0x01,0xca,0x07,0xf3,0x01,0xb9,0x07,0xee,0x01,0xa8,0x07,0xe9,0x01,0x97,0x07,0xe3,0x01,0x86,0x07,0xde,0x01,  \
    0x75,0x07,0xd9,0x01,0x64,0x07,0xd4,0x01,0x53,0x07,0xcf,0x01,0x42,0x07,0xca,0x01,0x31,0x07,0xc6,0x01,0x20,0x07,0xc1,0x01,0x0f,0x07,0xbc,0x01,0xff,0x06,0xb7,0x01,0xee,0x06,0xb3,0x01,0xdb,0x06,0xaf,0x01,0xc9,0x06,0xab,0x01,0xb7,0x06,0xa7,0x01,0xa4,0x06,0xa3,0x01,0x92,0x06,0x9f,0x01,0x80,0x06,0x9b,0x01,0x6d,0x06,0x97,0x01,0x5b,0x06,0x93,0x01,0x49,0x06,0x8f,0x01,0x37,0x06,0x8b,0x01,0x24,0x06,0x88,0x01,0x12,0x06,0x84,0x01,0x00,0x06,0x80,0x01,0xee,0x05,  \
    0x7c,0x01,0xdc,0x05,0x79,0x01,0xca,0x05,0x75,0x01,0xb7,0x05,0x72,0x01,0xa5,0x05,0x6e,0x01,0x93,0x05,0x6b,0x01,0x81,0x05,0x67,0x01,0x6f,0x05,0x64,0x01,0x5d,0x05,0x60,0x01,0x4b,0x05,0x5d,0x01,0x3a,0x05,0x59,0x01,0x29,0x05,0x56,0x01,0x18,0x05,0x53,0x01,0x07,0x05,0x4f,0x01,0xf6,0x04,0x4c,0x01,0xe5,0x04,0x48,0x01,0xd4,0x04,0x45,0x01,0xc3,0x04,0x42,0x01,0xb2,0x04,0x3f,0x01,0xa1,0x04,0x3c,0x01,0x90,0x04,0x39,0x01,0x7f,0x04,0x36,0x01,0x6e,0x04,0x33,0x01,  \
    0x5d,0x04,0x30,0x01,0x4c,0x04,0x2d,0x01,0x3b,0x04,0x2a,0x01,0x2a,0x04,0x27,0x01,0x19,0x04,0x24,0x01,0x09,0x04,0x22,0x01,0xf8,0x03,0x1f,0x01,0xe7,0x03,0x1c,0x01,0xd6,0x03,0x1a,0x01,0xc5,0x03,0x17,0x01,0xb4,0x03,0x15,0x01,0xa3,0x03,0x12,0x01,0x92,0x03,0x10,0x01,0x81,0x03,0x0e,0x01,0x71,0x03,0x0b,0x01,0x61,0x03,0x09,0x01,0x50,0x03,0x06,0x01,0x40,0x03,0x04,0x01,0x30,0x03,0x02,0x01,0x20,0x03,0x00,0x01,0x0f,0x03,0xfe,0x00,0xff,0x02,0xfc,0x00,0xef,0x02,  \
    0xfa,0x00,0xde,0x02,0xf8,0x00,0xce,0x02,0xf6,0x00,0xbd,0x02,0xf4,0x00,0xad,0x02,0xf2,0x00,0x9c,0x02,0xf0,0x00,0x8c,0x02,0xef,0x00,0x7b,0x02,0xed,0x00,0x6b,0x02,0xeb,0x00,0x5a,0x02,0xea,0x00,0x49,0x02,0xe8,0x00,0x39,0x02,0xe7,0x00,0x28,0x02,0xe5,0x00,0x17,0x02,0xe4,0x00,0x06,0x02,0xe3,0x00,0xf6,0x01,0xe1,0x00,0xe5,0x01,0xe0,0x00,0xd4,0x01,0xdf,0x00,0xc3,0x01,0xde,0x00,0xb1,0x01,0xdd,0x00,0xa0,0x01,0xdc,0x00,0x8f,0x01,0xdb,0x00,0x7d,0x01,0xda,0x00,  \
    0x6c,0x01,0xd9,0x00,0x5a,0x01,0xd8,0x00,0x49,0x01,0xd7,0x00,0x37,0x01,0xd6,0x00,0x26,0x01,0xd6,0x00,0x14,0x01,0xd5,0x00,0x03,0x01,0xd4,0x00,0xf1,0x00,0xd3,0x00,0xe0,0x00,0xd3,0x00,0xce,0x00,0xd2,0x00,0xbd,0x00,0xd2,0x00,0xab,0x00,0xd1,0x00,0x9a,0x00,0xd1,0x00,0x88,0x00,0xd0,0x00,0x77,0x00,0xd0,0x00,0x65,0x00,0xd0,0x00,0x54,0x00,0xcf,0x00,0x42,0x00,0xcf,0x00,0x31,0x00,0xcf,0x00,0x1f,0x00,0xcf,0x00,0x0e,0x00,0xcf,0x00,0xfc,0xff,0xce,0x00,0xeb,0xff,  \
    0xce,0x00,0xd9,0xff,0xce,0x00,0xc8,0xff,0xce,0x00,0xb6,0xff,0xce,0x00,0xa5,0xff,0xce,0x00,0x93,0xff,0xcf,0x00,0x82,0xff,0xcf,0x00,0x70,0xff,0xcf,0x00,0x5f,0xff,0xcf,0x00,0x4d,0xff,0xcf,0x00,0x3c,0xff,0xd0,0x00,0x2a,0xff,0xd0,0x00,0x19,0xff,0xd0,0x00,0x07,0xff,0xd1,0x00,0xf6,0xfe,0xd1,0x00,0xe4,0xfe,0xd2,0x00,0xd3,0xfe,0xd2,0x00,0xc1,0xfe,0xd3,0x00,0xb0,0xfe,0xd3,0x00,0x9e,0xfe,0xd4,0x00,0x8d,0xfe,0xd5,0x00,0x7b,0xfe,0xd5,0x00,0x6a,0xfe,0xd6,0x00,  \
    0x58,0xfe,0xd7,0x00,0x47,0xfe,0xd8,0x00,0x35,0xfe,0xd9,0x00,0x24,0xfe,0xda,0x00,0x13,0xfe,0xda,0x00,0x01,0xfe,0xdb,0x00,0xf0,0xfd,0xdc,0x00,0xde,0xfd,0xdd,0x00,0xcc,0xfd,0xdf,0x00,0xbb,0xfd,0xe0,0x00,0xa9,0xfd,0xe1,0x00,0x97,0xfd,0xe2,0x00,0x85,0xfd,0xe3,0x00,0x74,0xfd,0xe4,0x00,0x62,0xfd,0xe6,0x00,0x50,0xfd,0xe7,0x00,0x3e,0xfd,0xe8,0x00,0x2c,0xfd,0xea,0x00,0x1a,0xfd,0xeb,0x00,0x09,0xfd,0xed,0x00,0xf7,0xfc,0xee,0x00,0xe5,0xfc,0xf0,0x00,0xd3,0xfc,  \
    0xf1,0x00,0xc1,0xfc,0xf3,0x00,0xaf,0xfc,0xf4,0x00,0x9d,0xfc,0xf6,0x00,0x8b,0xfc,0xf8,0x00,0x79,0xfc,0xf9,0x00,0x67,0xfc,0xfb,0x00,0x55,0xfc,0xfd,0x00,0x43,0xfc,0xff,0x00,0x31,0xfc,0x01,0x01,0x1f,0xfc,0x03,0x01,0x0d,0xfc,0x04,0x01,0xfb,0xfb,0x07,0x01,0xea,0xfb,0x09,0x01,0xd9,0xfb,0x0b,0x01,0xc7,0xfb,0x0d,0x01,0xb6,0xfb,0x0f,0x01,0xa5,0xfb,0x12,0x01,0x94,0xfb,0x14,0x01,0x83,0xfb,0x16,0x01,0x71,0xfb,0x19,0x01,0x60,0xfb,0x1b,0x01,0x4f,0xfb,0x1e,0x01,  \
    0x3e,0xfb,0x20,0x01,0x2d,0xfb,0x23,0x01,0x1b,0xfb,0x25,0x01,0x0a,0xfb,0x28,0x01,0xf9,0xfa,0x2b,0x01,0xe8,0xfa,0x2d,0x01,0xd7,0xfa,0x30,0x01,0xc6,0xfa,0x33,0x01,0xb5,0xfa,0x36,0x01,0xa4,0xfa,0x39,0x01,0x93,0xfa,0x3c,0x01,0x82,0xfa,0x3f,0x01,0x71,0xfa,0x42,0x01,0x60,0xfa,0x45,0x01,0x4f,0xfa,0x48,0x01,0x3d,0xfa,0x4c,0x01,0x2c,0xfa,0x4f,0x01,0x1a,0xfa,0x52,0x01,0x09,0xfa,0x55,0x01,0xf7,0xf9,0x58,0x01,0xe5,0xf9,0x5b,0x01,0xd3,0xf9,0x5f,0x01,0xc2,0xf9,  \
    0x62,0x01,0xb0,0xf9,0x65,0x01,0x9e,0xf9,0x69,0x01,0x8c,0xf9,0x6c,0x01,0x7a,0xf9,0x70,0x01,0x69,0xf9,0x73,0x01,0x57,0xf9,0x77,0x01,0x45,0xf9,0x7a,0x01,0x33,0xf9,0x7e,0x01,0x21,0xf9,0x82,0x01,0x10,0xf9,0x86,0x01,0xfe,0xf8,0x89,0x01,0xec,0xf8,0x8d,0x01,0xda,0xf8,0x91,0x01,0xc8,0xf8,0x95,0x01,0xb6,0xf8,0x99,0x01,0xa4,0xf8,0x9d,0x01,0x92,0xf8,0xa1,0x01,0x81,0xf8,0xa5,0x01,0x6f,0xf8,0xa9,0x01,0x5e,0xf8,0xad,0x01,0x4c,0xf8,0xb2,0x01,0x3b,0xf8,0xb6,0x01,  \
    0x29,0xf8,0xbb,0x01,0x18,0xf8,0xbf,0x01,0x06,0xf8,0xc3,0x01,0xf5,0xf7,0xc8,0x01,0xe3,0xf7,0xcd,0x01,0xd2,0xf7,0xd1,0x01,0xc0,0xf7,0xd6,0x01,0xaf,0xf7,0xdb,0x01,0x9d,0xf7,0xdf,0x01,0x8c,0xf7,0xe4,0x01,0x7a,0xf7,0xe9,0x01,0x69,0xf7,0xee,0x01,0x57,0xf7,0xf3,0x01,0x46,0xf7,0xf8,0x01,0x34,0xf7,0xfd,0x01,0x22,0xf7,0x02,0x02,0x11,0xf7,0x07,0x02,0xff,0xf6,0x0c,0x02,0xee,0xf6,0x11,0x02,0xdc,0xf6,0x16,0x02,0xc9,0xf6,0x1b,0x02,0xb7,0xf6,0x21,0x02,0xa4,0xf6,  \
    0x26,0x02,0x92,0xf6,0x2b,0x02,0x80,0xf6,0x30,0x02,0x6d,0xf6,0x35,0x02,0x5b,0xf6,0x3a,0x02,0x48,0xf6,0x40,0x02,0x36,0xf6,0x45,0x02,0x23,0xf6,0x4a,0x02,0x10,0xf6,0x50,0x02,0xfe,0xf5,0x55,0x02,0xeb,0xf5,0x5b,0x02,0xd9,0xf5,0x60,0x02,0xc6,0xf5,0x66,0x02,0xb3,0xf5,0x6b,0x02,0xa0,0xf5,0x71,0x02,0x8e,0xf5,0x77,0x02,0x7b,0xf5,0x7c,0x02,0x68,0xf5,0x82,0x02,0x55,0xf5,0x88,0x02,0x43,0xf5,0x8e,0x02,0x31,0xf5,0x94,0x02,0x1e,0xf5,0x9a,0x02,0x0c,0xf5,0xa0,0x02,  \
    0xf9,0xf4,0xa7,0x02,0xe7,0xf4,0xad,0x02,0xd4,0xf4,0xb3,0x02,0xc1,0xf4,0xb9,0x02,0xaf,0xf4,0xbf,0x02,0x9c,0xf4,0xc6,0x02,0x89,0xf4,0xcc,0x02,0x76,0xf4,0xd2,0x02,0x63,0xf4,0xd9,0x02,0x50,0xf4,0xdf,0x02,0x3d,0xf4,0xe6,0x02,0x2a,0xf4,0xec,0x02,0x17,0xf4,0xf3,0x02,0x04,0xf4,0xf9,0x02,0xf1,0xf3,0xff,0x02,0xdc,0xf3,0x04,0x03,0xc7,0xf3,0x0a,0x03,0xb2,0xf3,0x10,0x03,0x9d,0xf3,0x16,0x03,0x88,0xf3,0x1b,0x03,0x72,0xf3,0x21,0x03,0x5d,0xf3,0x27,0x03,0x48,0xf3,  \
    0x2c,0x03,0x32,0xf3,0x32,0x03,0x1d,0xf3,0x38,0x03,0x07,0xf3,0x3d,0x03,0xf2,0xf2,0x43,0x03,0xdc,0xf2,0x49,0x03,0xc6,0xf2,0x4f,0x03,0xb0,0xf2,0x54,0x03,0x9b,0xf2,0x5a,0x03,0x85,0xf2,0x60,0x03,0x6f,0xf2,0x66,0x03,0x59,0xf2,0x6c,0x03,0x45,0xf2,0x73,0x03,0x30,0xf2,0x7a,0x03,0x1b,0xf2,0x80,0x03,0x06,0xf2,0x87,0x03,0xf1,0xf1,0x8d,0x03,0xdc,0xf1,0x94,0x03,0xc7,0xf1,0x9a,0x03,0xb2,0xf1,0xa1,0x03,0x9d,0xf1,0xa8,0x03,0x87,0xf1,0xae,0x03,0x72,0xf1,0xb4,0x03,  \
    0x5c,0xf1,0xbb,0x03,0x46,0xf1,0xc1,0x03,0x30,0xf1,0xc8,0x03,0x1a,0xf1,0xce,0x03,0x04,0xf1,0xd4,0x03,0xee,0xf0,0xda,0x03,0xd8,0xf0,0xe1,0x03,0xc2,0xf0,0xe7,0x03,0xab,0xf0,0xed,0x03,0x95,0xf0,0xf4,0x03,0x7e,0xf0,0xfa,0x03,0x68,0xf0,0x00,0x04,0x51,0xf0,0x06,0x04,0x3a,0xf0,0x0c,0x04,0x23,0xf0,0x12,0x04,0x0b,0xf0,0x18,0x04,0xf4,0xef,0x1e,0x04,0xdc,0xef,0x24,0x04,0xc5,0xef,0x29,0x04,0xad,0xef,0x2f,0x04,0x95,0xef,0x34,0x04,0x7d,0xef,0x3a,0x04,0x64,0xef,  \
    0x3f,0x04,0x4c,0xef,0x44,0x04,0x33,0xef,0x49,0x04,0x1a,0xef,0x4f,0x04,0x01,0xef,0x53,0x04,0xe8,0xee,0x57,0x04,0xcd,0xee,0x5b,0x04,0xb3,0xee,0x60,0x04,0x99,0xee,0x63,0x04,0x7e,0xee,0x67,0x04,0x63,0xee,0x6b,0x04,0x48,0xee,0x6f,0x04,0x2d,0xee,0x72,0x04,0x12,0xee,0x76,0x04,0xf6,0xed,0x79,0x04,0xdb,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf9,0x04,0xc7,0x11,0xf5,0x04,0xab,0x11,0xf1,0x04,0x90,0x11,0xed,0x04,0x75,0x11,0xe8,0x04,0x5a,0x11,0xe4,0x04,0x3f,0x11,0xe0,0x04,0x24,0x11,0xdb,0x04,0x09,0x11,0xd6,0x04,0xef,0x10,0xd2,0x04,0xd5,0x10,0xcd,0x04,0xbb,0x10,0xc8,0x04,0xa1,0x10,0xc3,0x04,0x87,0x10,0xbe,0x04,0x6d,0x10,0xb8,0x04,0x53,0x10,  \
    0xb3,0x04,0x3a,0x10,0xae,0x04,0x20,0x10,0xa8,0x04,0x07,0x10,0xa2,0x04,0xee,0x0f,0x9d,0x04,0xd5,0x0f,0x97,0x04,0xbd,0x0f,0x91,0x04,0xa5,0x0f,0x8a,0x04,0x8d,0x0f,0x84,0x04,0x75,0x0f,0x7d,0x04,0x5d,0x0f,0x77,0x04,0x46,0x0f,0x70,0x04,0x2e,0x0f,0x69,0x04,0x17,0x0f,0x63,0x04,0x00,0x0f,0x5c,0x04,0xe9,0x0e,0x55,0x04,0xd2,0x0e,0x4e,0x04,0xbb,0x0e,0x47,0x04,0xa4,0x0e,0x40,0x04,0x8e,0x0e,0x39,0x04,0x77,0x0e,0x32,0x04,0x61,0x0e,0x2b,0x04,0x4b,0x0e,0x24,0x04,  \
    0x35,0x0e,0x1c,0x04,0x1f,0x0e,0x15,0x04,0x09,0x0e,0x0e,0x04,0xf4,0x0d,0x06,0x04,0xdf,0x0d,0xfe,0x03,0xcb,0x0d,0xf6,0x03,0xb6,0x0d,0xee,0x03,0xa2,0x0d,0xe6,0x03,0x8e,0x0d,0xde,0x03,0x7a,0x0d,0xd5,0x03,0x66,0x0d,0xcd,0x03,0x52,0x0d,0xc5,0x03,0x3e,0x0d,0xbd,0x03,0x2b,0x0d,0xb5,0x03,0x17,0x0d,0xad,0x03,0x04,0x0d,0xa5,0x03,0xf1,0x0c,0x9d,0x03,0xde,0x0c,0x94,0x03,0xca,0x0c,0x8c,0x03,0xb8,0x0c,0x84,0x03,0xa4,0x0c,0x7e,0x03,0x8f,0x0c,0x78,0x03,0x79,0x0c,  \
    0x71,0x03,0x64,0x0c,0x6b,0x03,0x4e,0x0c,0x64,0x03,0x39,0x0c,0x5e,0x03,0x24,0x0c,0x58,0x03,0x0f,0x0c,0x51,0x03,0xfa,0x0b,0x4b,0x03,0xe4,0x0b,0x45,0x03,0xcf,0x0b,0x3e,0x03,0xba,0x0b,0x38,0x03,0xa6,0x0b,0x32,0x03,0x91,0x0b,0x2b,0x03,0x7c,0x0b,0x25,0x03,0x67,0x0b,0x1f,0x03,0x52,0x0b,0x19,0x03,0x3e,0x0b,0x12,0x03,0x29,0x0b,0x0c,0x03,0x15,0x0b,0x06,0x03,0x00,0x0b,0x00,0x03,0xec,0x0a,0xfa,0x02,0xd7,0x0a,0xf4,0x02,0xc3,0x0a,0xed,0x02,0xae,0x0a,0xe7,0x02,  \
    0x9a,0x0a,0xe1,0x02,0x86,0x0a,0xdb,0x02,0x72,0x0a,0xd5,0x02,0x5e,0x0a,0xcf,0x02,0x49,0x0a,0xc9,0x02,0x35,0x0a,0xc3,0x02,0x21,0x0a,0xbd,0x02,0x0d,0x0a,0xb7,0x02,0xf9,0x09,0xb2,0x02,0xe5,0x09,0xac,0x02,0xd2,0x09,0xa6,0x02,0xbe,0x09,0x9f,0x02,0xad,0x09,0x98,0x02,0x9c,0x09,0x91,0x02,0x8a,0x09,0x8a,0x02,0x79,0x09,0x83,0x02,0x68,0x09,0x7d,0x02,0x57,0x09,0x76,0x02,0x46,0x09,0x6f,0x02,0x35,0x09,0x69,0x02,0x24,0x09,0x62,0x02,0x13,0x09,0x5c,0x02,0x02,0x09,  \
    0x55,0x02,0xf1,0x08,0x4f,0x02,0xe0,0x08,0x48,0x02,0xcf,0x08,0x42,0x02,0xbf,0x08,0x3c,0x02,0xae,0x08,0x36,0x02,0x9d,0x08,0x2f,0x02,0x8c,0x08,0x29,0x02,0x7c,0x08,0x23,0x02,0x6b,0x08,0x1d,0x02,0x5a,0x08,0x18,0x02,0x49,0x08,0x12,0x02,0x38,0x08,0x0c,0x02,0x27,0x08,0x07,0x02,0x16,0x08,0x01,0x02,0x05,0x08,0xfb,0x01,0xf4,0x07,0xf6,0x01,0xe3,0x07,0xf1,0x01,0xd2,0x07,0xeb,0x01,0xc1,0x07,0xe6,0x01,0xb0,0x07,0xe1,0x01,0x9f,0x07,0xdb,0x01,0x8e,0x07,0xd6,0x01,  \
    0x7d,0x07,0xd1,0x01,0x6c,0x07,0xcc,0x01,0x5b,0x07,0xc7,0x01,0x4a,0x07,0xc2,0x01,0x3a,0x07,0xbd,0x01,0x29,0x07,0xb8,0x01,0x18,0x07,0xb3,0x01,0x07,0x07,0xaf,0x01,0xf6,0x06,0xaa,0x01,0xe5,0x06,0xa6,0x01,0xd3,0x06,0xa2,0x01,0xc1,0x06,0x9d,0x01,0xae,0x06,0x99,0x01,0x9c,0x06,0x95,0x01,0x8a,0x06,0x91,0x01,0x78,0x06,0x8d,0x01,0x65,0x06,0x89,0x01,0x53,0x06,0x85,0x01,0x41,0x06,0x82,0x01,0x2f,0x06,0x7e,0x01,0x1d,0x06,0x7a,0x01,0x0b,0x06,0x76,0x01,0xf9,0x05,  \
    0x72,0x01,0xe7,0x05,0x6f,0x01,0xd4,0x05,0x6b,0x01,0xc2,0x05,0x68,0x01,0xb0,0x05,0x64,0x01,0x9e,0x05,0x60,0x01,0x8c,0x05,0x5d,0x01,0x7b,0x05,0x59,0x01,0x69,0x05,0x56,0x01,0x57,0x05,0x53,0x01,0x45,0x05,0x4f,0x01,0x33,0x05,0x4c,0x01,0x22,0x05,0x48,0x01,0x11,0x05,0x45,0x01,0x00,0x05,0x41,0x01,0xf0,0x04,0x3e,0x01,0xdf,0x04,0x3b,0x01,0xce,0x04,0x37,0x01,0xbd,0x04,0x34,0x01,0xac,0x04,0x31,0x01,0x9b,0x04,0x2e,0x01,0x8a,0x04,0x2b,0x01,0x79,0x04,0x28,0x01,  \
    0x69,0x04,0x25,0x01,0x58,0x04,0x22,0x01,0x47,0x04,0x1f,0x01,0x36,0x04,0x1c,0x01,0x25,0x04,0x19,0x01,0x14,0x04,0x17,0x01,0x03,0x04,0x14,0x01,0xf2,0x03,0x11,0x01,0xe1,0x03,0x0f,0x01,0xd1,0x03,0x0c,0x01,0xc0,0x03,0x09,0x01,0xaf,0x03,0x07,0x01,0x9e,0x03,0x04,0x01,0x8d,0x03,0x02,0x01,0x7c,0x03,0x00,0x01,0x6c,0x03,0xfd,0x00,0x5c,0x03,0xfb,0x00,0x4c,0x03,0xf8,0x00,0x3c,0x03,0xf6,0x00,0x2c,0x03,0xf4,0x00,0x1b,0x03,0xf2,0x00,0x0b,0x03,0xf0,0x00,0xfb,0x02,  \
    0xee,0x00,0xeb,0x02,0xec,0x00,0xda,0x02,0xea,0x00,0xca,0x02,0xe8,0x00,0xba,0x02,0xe6,0x00,0xa9,0x02,0xe4,0x00,0x99,0x02,0xe2,0x00,0x88,0x02,0xe1,0x00,0x78,0x02,0xdf,0x00,0x67,0x02,0xdd,0x00,0x57,0x02,0xdc,0x00,0x46,0x02,0xda,0x00,0x35,0x02,0xd9,0x00,0x25,0x02,0xd7,0x00,0x14,0x02,0xd6,0x00,0x03,0x02,0xd5,0x00,0xf3,0x01,0xd3,0x00,0xe2,0x01,0xd2,0x00,0xd1,0x01,0xd1,0x00,0xc0,0x01,0xd0,0x00,0xaf,0x01,0xcf,0x00,0x9d,0x01,0xcd,0x00,0x8c,0x01,0xcc,0x00,  \
    0x7b,0x01,0xcc,0x00,0x69,0x01,0xcb,0x00,0x58,0x01,0xca,0x00,0x46,0x01,0xc9,0x00,0x35,0x01,0xc8,0x00,0x24,0x01,0xc7,0x00,0x12,0x01,0xc7,0x00,0x01,0x01,0xc6,0x00,0xf0,0x00,0xc5,0x00,0xde,0x00,0xc5,0x00,0xcd,0x00,0xc4,0x00,0xbb,0x00,0xc3,0x00,0xaa,0x00,0xc3,0x00,0x98,0x00,0xc3,0x00,0x87,0x00,0xc2,0x00,0x76,0x00,0xc2,0x00,0x64,0x00,0xc1,0x00,0x53,0x00,0xc1,0x00,0x41,0x00,0xc1,0x00,0x30,0x00,0xc1,0x00,0x1f,0x00,0xc0,0x00,0x0d,0x00,0xc0,0x00,0xfc,0xff,  \
    0xc0,0x00,0xea,0xff,0xc0,0x00,0xd9,0xff,0xc0,0x00,0xc8,0xff,0xc0,0x00,0xb6,0xff,0xc0,0x00,0xa5,0xff,0xc0,0x00,0x93,0xff,0xc0,0x00,0x82,0xff,0xc0,0x00,0x71,0xff,0xc1,0x00,0x5f,0xff,0xc1,0x00,0x4e,0xff,0xc1,0x00,0x3c,0xff,0xc1,0x00,0x2b,0xff,0xc2,0x00,0x1a,0xff,0xc2,0x00,0x08,0xff,0xc3,0x00,0xf7,0xfe,0xc3,0x00,0xe5,0xfe,0xc4,0x00,0xd4,0xfe,0xc4,0x00,0xc3,0xfe,0xc5,0x00,0xb1,0xfe,0xc5,0x00,0xa0,0xfe,0xc6,0x00,0x8e,0xfe,0xc7,0x00,0x7d,0xfe,0xc7,0x00,  \
    0x6c,0xfe,0xc8,0x00,0x5a,0xfe,0xc9,0x00,0x49,0xfe,0xca,0x00,0x38,0xfe,0xca,0x00,0x26,0xfe,0xcb,0x00,0x15,0xfe,0xcc,0x00,0x04,0xfe,0xcd,0x00,0xf2,0xfd,0xce,0x00,0xe1,0xfd,0xcf,0x00,0xcf,0xfd,0xd0,0x00,0xbd,0xfd,0xd2,0x00,0xac,0xfd,0xd3,0x00,0x9a,0xfd,0xd4,0x00,0x88,0xfd,0xd5,0x00,0x77,0xfd,0xd6,0x00,0x65,0xfd,0xd8,0x00,0x53,0xfd,0xd9,0x00,0x42,0xfd,0xda,0x00,0x30,0xfd,0xdc,0x00,0x1e,0xfd,0xdd,0x00,0x0c,0xfd,0xdf,0x00,0xfb,0xfc,0xe0,0x00,0xe9,0xfc,  \
    0xe2,0x00,0xd7,0xfc,0xe3,0x00,0xc5,0xfc,0xe5,0x00,0xb3,0xfc,0xe6,0x00,0xa2,0xfc,0xe8,0x00,0x90,0xfc,0xea,0x00,0x7e,0xfc,0xeb,0x00,0x6c,0xfc,0xed,0x00,0x5a,0xfc,0xef,0x00,0x48,0xfc,0xf1,0x00,0x36,0xfc,0xf3,0x00,0x24,0xfc,0xf5,0x00,0x13,0xfc,0xf7,0x00,0x01,0xfc,0xf9,0x00,0xef,0xfb,0xfb,0x00,0xde,0xfb,0xfd,0x00,0xcd,0xfb,0xff,0x00,0xbc,0xfb,0x01,0x01,0xab,0xfb,0x04,0x01,0x9a,0xfb,0x06,0x01,0x88,0xfb,0x09,0x01,0x77,0xfb,0x0b,0x01,0x66,0xfb,0x0d,0x01,  \
    0x55,0xfb,0x10,0x01,0x44,0xfb,0x12,0x01,0x33,0xfb,0x15,0x01,0x22,0xfb,0x18,0x01,0x11,0xfb,0x1a,0x01,0x00,0xfb,0x1d,0x01,0xef,0xfa,0x20,0x01,0xde,0xfa,0x23,0x01,0xcd,0xfa,0x26,0x01,0xbc,0xfa,0x29,0x01,0xab,0xfa,0x2c,0x01,0x9a,0xfa,0x2f,0x01,0x89,0xfa,0x32,0x01,0x78,0xfa,0x35,0x01,0x67,0xfa,0x38,0x01,0x56,0xfa,0x3b,0x01,0x45,0xfa,0x3e,0x01,0x34,0xfa,0x41,0x01,0x22,0xfa,0x44,0x01,0x10,0xfa,0x48,0x01,0xff,0xf9,0x4b,0x01,0xed,0xf9,0x4e,0x01,0xdb,0xf9,  \
    0x51,0x01,0xc9,0xf9,0x55,0x01,0xb8,0xf9,0x58,0x01,0xa6,0xf9,0x5c,0x01,0x94,0xf9,0x5f,0x01,0x83,0xf9,0x63,0x01,0x71,0xf9,0x66,0x01,0x5f,0xf9,0x6a,0x01,0x4d,0xf9,0x6d,0x01,0x3c,0xf9,0x71,0x01,0x2a,0xf9,0x75,0x01,0x18,0xf9,0x79,0x01,0x06,0xf9,0x7c,0x01,0xf5,0xf8,0x80,0x01,0xe3,0xf8,0x84,0x01,0xd1,0xf8,0x88,0x01,0xbf,0xf8,0x8c,0x01,0xae,0xf8,0x90,0x01,0x9c,0xf8,0x94,0x01,0x8a,0xf8,0x98,0x01,0x78,0xf8,0x9c,0x01,0x67,0xf8,0xa1,0x01,0x56,0xf8,0xa5,0x01,  \
    0x44,0xf8,0xa9,0x01,0x33,0xf8,0xae,0x01,0x21,0xf8,0xb2,0x01,0x10,0xf8,0xb7,0x01,0xff,0xf7,0xbb,0x01,0xed,0xf7,0xc0,0x01,0xdc,0xf7,0xc5,0x01,0xca,0xf7,0xc9,0x01,0xb9,0xf7,0xce,0x01,0xa7,0xf7,0xd3,0x01,0x96,0xf7,0xd8,0x01,0x84,0xf7,0xdd,0x01,0x73,0xf7,0xe2,0x01,0x61,0xf7,0xe7,0x01,0x50,0xf7,0xec,0x01,0x3e,0xf7,0xf1,0x01,0x2d,0xf7,0xf6,0x01,0x1b,0xf7,0xfb,0x01,0x0a,0xf7,0x00,0x02,0xf8,0xf6,0x05,0x02,0xe6,0xf6,0x0a,0x02,0xd4,0xf6,0x0f,0x02,0xc2,0xf6,  \
    0x14,0x02,0xaf,0xf6,0x1a,0x02,0x9d,0xf6,0x1f,0x02,0x8a,0xf6,0x24,0x02,0x78,0xf6,0x29,0x02,0x66,0xf6,0x2e,0x02,0x53,0xf6,0x34,0x02,0x41,0xf6,0x39,0x02,0x2e,0xf6,0x3f,0x02,0x1c,0xf6,0x44,0x02,0x09,0xf6,0x49,0x02,0xf7,0xf5,0x4f,0x02,0xe4,0xf5,0x55,0x02,0xd1,0xf5,0x5a,0x02,0xbf,0xf5,0x60,0x02,0xac,0xf5,0x65,0x02,0x99,0xf5,0x6b,0x02,0x86,0xf5,0x71,0x02,0x74,0xf5,0x77,0x02,0x61,0xf5,0x7d,0x02,0x4f,0xf5,0x83,0x02,0x3c,0xf5,0x89,0x02,0x2a,0xf5,0x8f,0x02,  \
    0x17,0xf5,0x95,0x02,0x05,0xf5,0x9b,0x02,0xf2,0xf4,0xa1,0x02,0xe0,0xf4,0xa8,0x02,0xcd,0xf4,0xae,0x02,0xba,0xf4,0xb4,0x02,0xa8,0xf4,0xba,0x02,0x95,0xf4,0xc1,0x02,0x82,0xf4,0xc7,0x02,0x6f,0xf4,0xcd,0x02,0x5c,0xf4,0xd4,0x02,0x49,0xf4,0xda,0x02,0x36,0xf4,0xe1,0x02,0x23,0xf4,0xe7,0x02,0x10,0xf4,0xee,0x02,0xfd,0xf3,0xf4,0x02,0xe8,0xf3,0xf9,0x02,0xd3,0xf3,0xff,0x02,0xbe,0xf3,0x05,0x03,0xa9,0xf3,0x0a,0x03,0x94,0xf3,0x10,0x03,0x7f,0xf3,0x16,0x03,0x69,0xf3,  \
    0x1c,0x03,0x54,0xf3,0x21,0x03,0x3f,0xf3,0x27,0x03,0x29,0xf3,0x2d,0x03,0x14,0xf3,0x33,0x03,0xfe,0xf2,0x38,0x03,0xe8,0xf2,0x3e,0x03,0xd3,0xf2,0x44,0x03,0xbd,0xf2,0x4a,0x03,0xa7,0xf2,0x4f,0x03,0x91,0xf2,0x55,0x03,0x7b,0xf2,0x5b,0x03,0x66,0xf2,0x62,0x03,0x51,0xf2,0x68,0x03,0x3d,0xf2,0x6f,0x03,0x28,0xf2,0x76,0x03,0x13,0xf2,0x7c,0x03,0xfe,0xf1,0x83,0x03,0xe9,0xf1,0x89,0x03,0xd4,0xf1,0x90,0x03,0xbf,0xf1,0x96,0x03,0xa9,0xf1,0x9d,0x03,0x94,0xf1,0xa3,0x03,  \
    0x7e,0xf1,0xaa,0x03,0x69,0xf1,0xb0,0x03,0x53,0xf1,0xb7,0x03,0x3d,0xf1,0xbd,0x03,0x27,0xf1,0xc3,0x03,0x11,0xf1,0xca,0x03,0xfa,0xf0,0xd0,0x03,0xe4,0xf0,0xd6,0x03,0xce,0xf0,0xdd,0x03,0xb8,0xf0,0xe3,0x03,0xa1,0xf0,0xe9,0x03,0x8a,0xf0,0xef,0x03,0x74,0xf0,0xf5,0x03,0x5d,0xf0,0xfb,0x03,0x46,0xf0,0x01,0x04,0x2f,0xf0,0x07,0x04,0x17,0xf0,0x0d,0x04,0x00,0xf0,0x13,0x04,0xe8,0xef,0x19,0x04,0xd1,0xef,0x1e,0x04,0xb9,0xef,0x24,0x04,0xa1,0xef,0x2a,0x04,0x88,0xef,  \
    0x2f,0x04,0x70,0xef,0x34,0x04,0x58,0xef,0x3a,0x04,0x3f,0xef,0x3f,0x04,0x26,0xef,0x44,0x04,0x0d,0xef,0x48,0x04,0xf3,0xee,0x4d,0x04,0xd9,0xee,0x51,0x04,0xbf,0xee,0x55,0x04,0xa4,0xee,0x59,0x04,0x8a,0xee,0x5c,0x04,0x6f,0xee,0x60,0x04,0x54,0xee,0x64,0x04,0x39,0xee,0x67,0x04,0x1d,0xee,0x6b,0x04,0x02,0xee,0x6e,0x04,0xe6,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe9,0x04,0xbf,0x11,0xe5,0x04,0xa4,0x11,0xe1,0x04,0x88,0x11,0xdd,0x04,0x6d,0x11,0xd9,0x04,0x52,0x11,0xd5,0x04,0x37,0x11,0xd0,0x04,0x1c,0x11,0xcc,0x04,0x02,0x11,0xc7,0x04,0xe7,0x10,0xc2,0x04,0xcd,0x10,0xbd,0x04,0xb3,0x10,0xb8,0x04,0x99,0x10,0xb3,0x04,0x7f,0x10,0xae,0x04,0x65,0x10,  \
    0xa9,0x04,0x4b,0x10,0xa4,0x04,0x32,0x10,0x9e,0x04,0x18,0x10,0x99,0x04,0xff,0x0f,0x93,0x04,0xe6,0x0f,0x8e,0x04,0xcd,0x0f,0x88,0x04,0xb5,0x0f,0x82,0x04,0x9c,0x0f,0x7b,0x04,0x84,0x0f,0x75,0x04,0x6d,0x0f,0x6f,0x04,0x55,0x0f,0x68,0x04,0x3d,0x0f,0x61,0x04,0x26,0x0f,0x5b,0x04,0x0e,0x0f,0x54,0x04,0xf7,0x0e,0x4d,0x04,0xe0,0x0e,0x47,0x04,0xc9,0x0e,0x40,0x04,0xb2,0x0e,0x39,0x04,0x9c,0x0e,0x32,0x04,0x85,0x0e,0x2b,0x04,0x6f,0x0e,0x24,0x04,0x58,0x0e,0x1d,0x04,  \
    0x42,0x0e,0x16,0x04,0x2c,0x0e,0x0e,0x04,0x16,0x0e,0x07,0x04,0x00,0x0e,0x00,0x04,0xeb,0x0d,0xf8,0x03,0xd6,0x0d,0xf0,0x03,0xc2,0x0d,0xe8,0x03,0xad,0x0d,0xe0,0x03,0x99,0x0d,0xd8,0x03,0x85,0x0d,0xd0,0x03,0x70,0x0d,0xc8,0x03,0x5c,0x0d,0xc0,0x03,0x49,0x0d,0xb8,0x03,0x35,0x0d,0xb0,0x03,0x21,0x0d,0xa8,0x03,0x0e,0x0d,0xa0,0x03,0xfa,0x0c,0x97,0x03,0xe7,0x0c,0x8f,0x03,0xd4,0x0c,0x87,0x03,0xc1,0x0c,0x7f,0x03,0xae,0x0c,0x77,0x03,0x9a,0x0c,0x71,0x03,0x85,0x0c,  \
    0x6b,0x03,0x6f,0x0c,0x64,0x03,0x5a,0x0c,0x5e,0x03,0x44,0x0c,0x57,0x03,0x2f,0x0c,0x51,0x03,0x1a,0x0c,0x4b,0x03,0x05,0x0c,0x44,0x03,0xf0,0x0b,0x3e,0x03,0xdb,0x0b,0x38,0x03,0xc6,0x0b,0x31,0x03,0xb1,0x0b,0x2b,0x03,0x9c,0x0b,0x25,0x03,0x87,0x0b,0x1e,0x03,0x72,0x0b,0x18,0x03,0x5d,0x0b,0x12,0x03,0x49,0x0b,0x0b,0x03,0x34,0x0b,0x05,0x03,0x1f,0x0b,0xff,0x02,0x0b,0x0b,0xf9,0x02,0xf6,0x0a,0xf3,0x02,0xe2,0x0a,0xed,0x02,0xce,0x0a,0xe6,0x02,0xb9,0x0a,0xe0,0x02,  \
    0xa5,0x0a,0xda,0x02,0x91,0x0a,0xd4,0x02,0x7c,0x0a,0xce,0x02,0x68,0x0a,0xc8,0x02,0x54,0x0a,0xc2,0x02,0x40,0x0a,0xbc,0x02,0x2c,0x0a,0xb6,0x02,0x18,0x0a,0xb0,0x02,0x04,0x0a,0xaa,0x02,0xf0,0x09,0xa4,0x02,0xdc,0x09,0x9f,0x02,0xc8,0x09,0x99,0x02,0xb5,0x09,0x92,0x02,0xa4,0x09,0x8b,0x02,0x93,0x09,0x84,0x02,0x81,0x09,0x7d,0x02,0x70,0x09,0x76,0x02,0x5f,0x09,0x6f,0x02,0x4e,0x09,0x69,0x02,0x3d,0x09,0x62,0x02,0x2c,0x09,0x5c,0x02,0x1b,0x09,0x55,0x02,0x0a,0x09,  \
    0x4e,0x02,0xf9,0x08,0x48,0x02,0xe8,0x08,0x42,0x02,0xd7,0x08,0x3b,0x02,0xc6,0x08,0x35,0x02,0xb6,0x08,0x2f,0x02,0xa5,0x08,0x29,0x02,0x94,0x08,0x22,0x02,0x83,0x08,0x1c,0x02,0x72,0x08,0x16,0x02,0x62,0x08,0x10,0x02,0x51,0x08,0x0b,0x02,0x40,0x08,0x05,0x02,0x2f,0x08,0xff,0x01,0x1e,0x08,0xfa,0x01,0x0d,0x08,0xf4,0x01,0xfc,0x07,0xee,0x01,0xeb,0x07,0xe9,0x01,0xda,0x07,0xe4,0x01,0xc9,0x07,0xde,0x01,0xb8,0x07,0xd9,0x01,0xa7,0x07,0xd4,0x01,0x96,0x07,0xce,0x01,  \
    0x85,0x07,0xc9,0x01,0x74,0x07,0xc4,0x01,0x64,0x07,0xbf,0x01,0x53,0x07,0xba,0x01,0x42,0x07,0xb5,0x01,0x31,0x07,0xb0,0x01,0x20,0x07,0xab,0x01,0x0f,0x07,0xa6,0x01,0xff,0x06,0xa2,0x01,0xee,0x06,0x9d,0x01,0xdd,0x06,0x99,0x01,0xcb,0x06,0x95,0x01,0xb8,0x06,0x90,0x01,0xa6,0x06,0x8c,0x01,0x94,0x06,0x88,0x01,0x82,0x06,0x84,0x01,0x70,0x06,0x80,0x01,0x5e,0x06,0x7c,0x01,0x4b,0x06,0x78,0x01,0x39,0x06,0x74,0x01,0x27,0x06,0x71,0x01,0x15,0x06,0x6d,0x01,0x03,0x06,  \
    0x69,0x01,0xf1,0x05,0x65,0x01,0xdf,0x05,0x62,0x01,0xcd,0x05,0x5e,0x01,0xbb,0x05,0x5a,0x01,0xa9,0x05,0x57,0x01,0x97,0x05,0x53,0x01,0x86,0x05,0x50,0x01,0x74,0x05,0x4c,0x01,0x62,0x05,0x49,0x01,0x50,0x05,0x45,0x01,0x3e,0x05,0x42,0x01,0x2c,0x05,0x3e,0x01,0x1c,0x05,0x3b,0x01,0x0b,0x05,0x37,0x01,0xfa,0x04,0x34,0x01,0xe9,0x04,0x31,0x01,0xd8,0x04,0x2d,0x01,0xc8,0x04,0x2a,0x01,0xb7,0x04,0x27,0x01,0xa6,0x04,0x24,0x01,0x95,0x04,0x20,0x01,0x84,0x04,0x1d,0x01,  \
    0x74,0x04,0x1a,0x01,0x63,0x04,0x17,0x01,0x52,0x04,0x14,0x01,0x41,0x04,0x11,0x01,0x30,0x04,0x0f,0x01,0x20,0x04,0x0c,0x01,0x0f,0x04,0x09,0x01,0xfe,0x03,0x06,0x01,0xed,0x03,0x04,0x01,0xdc,0x03,0x01,0x01,0xcb,0x03,0xfe,0x00,0xbb,0x03,0xfc,0x00,0xaa,0x03,0xf9,0x00,0x99,0x03,0xf7,0x00,0x88,0x03,0xf4,0x00,0x78,0x03,0xf2,0x00,0x68,0x03,0xf0,0x00,0x57,0x03,0xed,0x00,0x47,0x03,0xeb,0x00,0x37,0x03,0xe9,0x00,0x27,0x03,0xe6,0x00,0x17,0x03,0xe4,0x00,0x07,0x03,  \
    0xe2,0x00,0xf7,0x02,0xe0,0x00,0xe6,0x02,0xde,0x00,0xd6,0x02,0xdc,0x00,0xc6,0x02,0xda,0x00,0xb6,0x02,0xd8,0x00,0xa5,0x02,0xd6,0x00,0x95,0x02,0xd5,0x00,0x84,0x02,0xd3,0x00,0x74,0x02,0xd1,0x00,0x64,0x02,0xd0,0x00,0x53,0x02,0xce,0x00,0x43,0x02,0xcc,0x00,0x32,0x02,0xcb,0x00,0x21,0x02,0xc9,0x00,0x11,0x02,0xc8,0x00,0x00,0x02,0xc7,0x00,0xf0,0x01,0xc5,0x00,0xdf,0x01,0xc4,0x00,0xce,0x01,0xc3,0x00,0xbd,0x01,0xc2,0x00,0xac,0x01,0xc1,0x00,0x9b,0x01,0xc0,0x00,  \
    0x8a,0x01,0xbf,0x00,0x78,0x01,0xbe,0x00,0x67,0x01,0xbd,0x00,0x56,0x01,0xbc,0x00,0x44,0x01,0xbb,0x00,0x33,0x01,0xba,0x00,0x22,0x01,0xb9,0x00,0x10,0x01,0xb9,0x00,0xff,0x00,0xb8,0x00,0xee,0x00,0xb7,0x00,0xdd,0x00,0xb7,0x00,0xcb,0x00,0xb6,0x00,0xba,0x00,0xb6,0x00,0xa9,0x00,0xb5,0x00,0x97,0x00,0xb5,0x00,0x86,0x00,0xb4,0x00,0x75,0x00,0xb4,0x00,0x63,0x00,0xb3,0x00,0x52,0x00,0xb3,0x00,0x41,0x00,0xb3,0x00,0x2f,0x00,0xb3,0x00,0x1e,0x00,0xb3,0x00,0x0d,0x00,  \
    0xb2,0x00,0xfb,0xff,0xb2,0x00,0xea,0xff,0xb2,0x00,0xd9,0xff,0xb2,0x00,0xc8,0xff,0xb2,0x00,0xb6,0xff,0xb2,0x00,0xa5,0xff,0xb2,0x00,0x94,0xff,0xb2,0x00,0x82,0xff,0xb3,0x00,0x71,0xff,0xb3,0x00,0x60,0xff,0xb3,0x00,0x4e,0xff,0xb3,0x00,0x3d,0xff,0xb4,0x00,0x2c,0xff,0xb4,0x00,0x1b,0xff,0xb4,0x00,0x09,0xff,0xb5,0x00,0xf8,0xfe,0xb5,0x00,0xe7,0xfe,0xb6,0x00,0xd5,0xfe,0xb6,0x00,0xc4,0xfe,0xb7,0x00,0xb3,0xfe,0xb7,0x00,0xa1,0xfe,0xb8,0x00,0x90,0xfe,0xb9,0x00,  \
    0x7f,0xfe,0xb9,0x00,0x6e,0xfe,0xba,0x00,0x5c,0xfe,0xbb,0x00,0x4b,0xfe,0xbc,0x00,0x3a,0xfe,0xbd,0x00,0x29,0xfe,0xbe,0x00,0x17,0xfe,0xbf,0x00,0x06,0xfe,0xbf,0x00,0xf5,0xfd,0xc1,0x00,0xe3,0xfd,0xc2,0x00,0xd2,0xfd,0xc3,0x00,0xc0,0xfd,0xc4,0x00,0xaf,0xfd,0xc5,0x00,0x9d,0xfd,0xc6,0x00,0x8c,0xfd,0xc7,0x00,0x7a,0xfd,0xc9,0x00,0x68,0xfd,0xca,0x00,0x57,0xfd,0xcb,0x00,0x45,0xfd,0xcd,0x00,0x34,0xfd,0xce,0x00,0x22,0xfd,0xcf,0x00,0x10,0xfd,0xd1,0x00,0xff,0xfc,  \
    0xd2,0x00,0xed,0xfc,0xd4,0x00,0xdb,0xfc,0xd5,0x00,0xca,0xfc,0xd7,0x00,0xb8,0xfc,0xd9,0x00,0xa6,0xfc,0xda,0x00,0x94,0xfc,0xdc,0x00,0x83,0xfc,0xde,0x00,0x71,0xfc,0xe0,0x00,0x5f,0xfc,0xe2,0x00,0x4d,0xfc,0xe3,0x00,0x3b,0xfc,0xe5,0x00,0x2a,0xfc,0xe7,0x00,0x18,0xfc,0xe9,0x00,0x06,0xfc,0xeb,0x00,0xf5,0xfb,0xed,0x00,0xe4,0xfb,0xf0,0x00,0xd3,0xfb,0xf2,0x00,0xc2,0xfb,0xf4,0x00,0xb0,0xfb,0xf6,0x00,0x9f,0xfb,0xf9,0x00,0x8e,0xfb,0xfb,0x00,0x7d,0xfb,0xfe,0x00,  \
    0x6c,0xfb,0x00,0x01,0x5b,0xfb,0x03,0x01,0x4a,0xfb,0x05,0x01,0x39,0xfb,0x08,0x01,0x28,0xfb,0x0a,0x01,0x17,0xfb,0x0d,0x01,0x06,0xfb,0x10,0x01,0xf5,0xfa,0x13,0x01,0xe4,0xfa,0x16,0x01,0xd3,0xfa,0x18,0x01,0xc2,0xfa,0x1b,0x01,0xb2,0xfa,0x1e,0x01,0xa1,0xfa,0x21,0x01,0x90,0xfa,0x24,0x01,0x7f,0xfa,0x28,0x01,0x6e,0xfa,0x2b,0x01,0x5d,0xfa,0x2e,0x01,0x4c,0xfa,0x31,0x01,0x3b,0xfa,0x34,0x01,0x29,0xfa,0x37,0x01,0x18,0xfa,0x3b,0x01,0x06,0xfa,0x3e,0x01,0xf5,0xf9,  \
    0x41,0x01,0xe3,0xf9,0x45,0x01,0xd1,0xf9,0x48,0x01,0xc0,0xf9,0x4b,0x01,0xae,0xf9,0x4f,0x01,0x9d,0xf9,0x52,0x01,0x8b,0xf9,0x56,0x01,0x79,0xf9,0x59,0x01,0x68,0xf9,0x5d,0x01,0x56,0xf9,0x61,0x01,0x44,0xf9,0x64,0x01,0x33,0xf9,0x68,0x01,0x21,0xf9,0x6c,0x01,0x0f,0xf9,0x70,0x01,0xfe,0xf8,0x74,0x01,0xec,0xf8,0x78,0x01,0xda,0xf8,0x7b,0x01,0xc8,0xf8,0x7f,0x01,0xb7,0xf8,0x83,0x01,0xa5,0xf8,0x88,0x01,0x93,0xf8,0x8c,0x01,0x82,0xf8,0x90,0x01,0x70,0xf8,0x94,0x01,  \
    0x5f,0xf8,0x99,0x01,0x4e,0xf8,0x9d,0x01,0x3c,0xf8,0xa2,0x01,0x2b,0xf8,0xa6,0x01,0x1a,0xf8,0xab,0x01,0x08,0xf8,0xaf,0x01,0xf7,0xf7,0xb4,0x01,0xe6,0xf7,0xb9,0x01,0xd4,0xf7,0xbd,0x01,0xc3,0xf7,0xc2,0x01,0xb2,0xf7,0xc7,0x01,0xa0,0xf7,0xcc,0x01,0x8f,0xf7,0xd1,0x01,0x7d,0xf7,0xd6,0x01,0x6c,0xf7,0xdb,0x01,0x5a,0xf7,0xe0,0x01,0x49,0xf7,0xe5,0x01,0x37,0xf7,0xea,0x01,0x26,0xf7,0xef,0x01,0x14,0xf7,0xf4,0x01,0x03,0xf7,0xf9,0x01,0xf1,0xf6,0xfe,0x01,0xde,0xf6,  \
    0x03,0x02,0xcc,0xf6,0x09,0x02,0xba,0xf6,0x0e,0x02,0xa8,0xf6,0x13,0x02,0x95,0xf6,0x18,0x02,0x83,0xf6,0x1d,0x02,0x71,0xf6,0x23,0x02,0x5e,0xf6,0x28,0x02,0x4c,0xf6,0x2e,0x02,0x39,0xf6,0x33,0x02,0x27,0xf6,0x38,0x02,0x14,0xf6,0x3e,0x02,0x02,0xf6,0x43,0x02,0xef,0xf5,0x49,0x02,0xdd,0xf5,0x4f,0x02,0xca,0xf5,0x54,0x02,0xb7,0xf5,0x5a,0x02,0xa5,0xf5,0x60,0x02,0x92,0xf5,0x65,0x02,0x7f,0xf5,0x6b,0x02,0x6d,0xf5,0x71,0x02,0x5a,0xf5,0x77,0x02,0x48,0xf5,0x7d,0x02,  \
    0x35,0xf5,0x84,0x02,0x23,0xf5,0x8a,0x02,0x11,0xf5,0x90,0x02,0xfe,0xf4,0x96,0x02,0xeb,0xf4,0x9c,0x02,0xd9,0xf4,0xa3,0x02,0xc6,0xf4,0xa9,0x02,0xb3,0xf4,0xaf,0x02,0xa1,0xf4,0xb6,0x02,0x8e,0xf4,0xbc,0x02,0x7b,0xf4,0xc2,0x02,0x68,0xf4,0xc9,0x02,0x55,0xf4,0xcf,0x02,0x42,0xf4,0xd6,0x02,0x2f,0xf4,0xdc,0x02,0x1c,0xf4,0xe3,0x02,0x09,0xf4,0xe9,0x02,0xf4,0xf3,0xee,0x02,0xdf,0xf3,0xf4,0x02,0xca,0xf3,0xfa,0x02,0xb5,0xf3,0x00,0x03,0xa0,0xf3,0x05,0x03,0x8b,0xf3,  \
    0x0b,0x03,0x76,0xf3,0x11,0x03,0x60,0xf3,0x17,0x03,0x4b,0xf3,0x1c,0x03,0x35,0xf3,0x22,0x03,0x20,0xf3,0x28,0x03,0x0b,0xf3,0x2e,0x03,0xf5,0xf2,0x34,0x03,0xdf,0xf2,0x39,0x03,0xca,0xf2,0x3f,0x03,0xb4,0xf2,0x45,0x03,0x9e,0xf2,0x4b,0x03,0x88,0xf2,0x51,0x03,0x72,0xf2,0x57,0x03,0x5e,0xf2,0x5e,0x03,0x49,0xf2,0x65,0x03,0x34,0xf2,0x6b,0x03,0x20,0xf2,0x72,0x03,0x0b,0xf2,0x78,0x03,0xf6,0xf1,0x7f,0x03,0xe0,0xf1,0x85,0x03,0xcb,0xf1,0x8c,0x03,0xb6,0xf1,0x92,0x03,  \
    0xa0,0xf1,0x99,0x03,0x8b,0xf1,0x9f,0x03,0x75,0xf1,0xa6,0x03,0x5f,0xf1,0xac,0x03,0x49,0xf1,0xb3,0x03,0x33,0xf1,0xb9,0x03,0x1d,0xf1,0xbf,0x03,0x07,0xf1,0xc5,0x03,0xf0,0xf0,0xcc,0x03,0xda,0xf0,0xd2,0x03,0xc4,0xf0,0xd8,0x03,0xad,0xf0,0xdf,0x03,0x97,0xf0,0xe5,0x03,0x80,0xf0,0xeb,0x03,0x69,0xf0,0xf1,0x03,0x52,0xf0,0xf7,0x03,0x3b,0xf0,0xfd,0x03,0x23,0xf0,0x03,0x04,0x0c,0xf0,0x09,0x04,0xf4,0xef,0x0e,0x04,0xdd,0xef,0x14,0x04,0xc5,0xef,0x1a,0x04,0xac,0xef,  \
    0x1f,0x04,0x94,0xef,0x24,0x04,0x7c,0xef,0x2a,0x04,0x63,0xef,0x2f,0x04,0x4b,0xef,0x34,0x04,0x32,0xef,0x39,0x04,0x19,0xef,0x3e,0x04,0xff,0xee,0x42,0x04,0xe5,0xee,0x46,0x04,0xca,0xee,0x4a,0x04,0xb0,0xee,0x4e,0x04,0x95,0xee,0x52,0x04,0x7a,0xee,0x56,0x04,0x5f,0xee,0x59,0x04,0x44,0xee,0x5d,0x04,0x29,0xee,0x60,0x04,0x0e,0xee,0x64,0x04,0xf2,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xda,0x04,0xb8,0x11,0xd6,0x04,0x9c,0x11,0xd2,0x04,0x81,0x11,0xce,0x04,0x65,0x11,0xca,0x04,0x4a,0x11,0xc5,0x04,0x2f,0x11,0xc1,0x04,0x15,0x11,0xbc,0x04,0xfa,0x10,0xb8,0x04,0xdf,0x10,0xb3,0x04,0xc5,0x10,0xae,0x04,0xab,0x10,0xa9,0x04,0x91,0x10,0xa4,0x04,0x77,0x10,  \
    0x9f,0x04,0x5d,0x10,0x9a,0x04,0x43,0x10,0x95,0x04,0x2a,0x10,0x90,0x04,0x10,0x10,0x8a,0x04,0xf7,0x0f,0x85,0x04,0xde,0x0f,0x7f,0x04,0xc5,0x0f,0x79,0x04,0xac,0x0f,0x73,0x04,0x94,0x0f,0x6d,0x04,0x7c,0x0f,0x66,0x04,0x64,0x0f,0x60,0x04,0x4c,0x0f,0x59,0x04,0x35,0x0f,0x53,0x04,0x1d,0x0f,0x4c,0x04,0x06,0x0f,0x46,0x04,0xef,0x0e,0x3f,0x04,0xd8,0x0e,0x38,0x04,0xc1,0x0e,0x31,0x04,0xaa,0x0e,0x2b,0x04,0x93,0x0e,0x24,0x04,0x7c,0x0e,0x1d,0x04,0x66,0x0e,0x16,0x04,  \
    0x50,0x0e,0x0f,0x04,0x39,0x0e,0x08,0x04,0x23,0x0e,0x00,0x04,0x0d,0x0e,0xf9,0x03,0xf7,0x0d,0xf2,0x03,0xe2,0x0d,0xea,0x03,0xcd,0x0d,0xe2,0x03,0xb9,0x0d,0xda,0x03,0xa4,0x0d,0xd2,0x03,0x90,0x0d,0xca,0x03,0x7b,0x0d,0xc2,0x03,0x67,0x0d,0xba,0x03,0x53,0x0d,0xb3,0x03,0x3f,0x0d,0xab,0x03,0x2b,0x0d,0xa3,0x03,0x17,0x0d,0x9a,0x03,0x04,0x0d,0x92,0x03,0xf0,0x0c,0x8a,0x03,0xdd,0x0c,0x82,0x03,0xca,0x0c,0x7a,0x03,0xb7,0x0c,0x72,0x03,0xa4,0x0c,0x6b,0x03,0x90,0x0c,  \
    0x64,0x03,0x7b,0x0c,0x5e,0x03,0x65,0x0c,0x57,0x03,0x50,0x0c,0x51,0x03,0x3a,0x0c,0x4b,0x03,0x25,0x0c,0x44,0x03,0x10,0x0c,0x3e,0x03,0xfb,0x0b,0x37,0x03,0xe6,0x0b,0x31,0x03,0xd1,0x0b,0x2b,0x03,0xbc,0x0b,0x24,0x03,0xa7,0x0b,0x1e,0x03,0x92,0x0b,0x18,0x03,0x7d,0x0b,0x11,0x03,0x68,0x0b,0x0b,0x03,0x54,0x0b,0x05,0x03,0x3f,0x0b,0xff,0x02,0x2a,0x0b,0xf8,0x02,0x16,0x0b,0xf2,0x02,0x01,0x0b,0xec,0x02,0xed,0x0a,0xe6,0x02,0xd8,0x0a,0xe0,0x02,0xc4,0x0a,0xda,0x02,  \
    0xb0,0x0a,0xd3,0x02,0x9b,0x0a,0xcd,0x02,0x87,0x0a,0xc7,0x02,0x73,0x0a,0xc1,0x02,0x5f,0x0a,0xbb,0x02,0x4b,0x0a,0xb5,0x02,0x37,0x0a,0xaf,0x02,0x23,0x0a,0xa9,0x02,0x0f,0x0a,0xa3,0x02,0xfb,0x09,0x9d,0x02,0xe7,0x09,0x98,0x02,0xd3,0x09,0x92,0x02,0xbf,0x09,0x8c,0x02,0xac,0x09,0x85,0x02,0x9b,0x09,0x7e,0x02,0x89,0x09,0x77,0x02,0x78,0x09,0x70,0x02,0x67,0x09,0x69,0x02,0x56,0x09,0x63,0x02,0x45,0x09,0x5c,0x02,0x34,0x09,0x55,0x02,0x23,0x09,0x4f,0x02,0x12,0x09,  \
    0x48,0x02,0x01,0x09,0x42,0x02,0xf0,0x08,0x3b,0x02,0xdf,0x08,0x35,0x02,0xce,0x08,0x2f,0x02,0xbd,0x08,0x28,0x02,0xac,0x08,0x22,0x02,0x9c,0x08,0x1c,0x02,0x8b,0x08,0x16,0x02,0x7a,0x08,0x10,0x02,0x69,0x08,0x0a,0x02,0x59,0x08,0x04,0x02,0x48,0x08,0xfe,0x01,0x37,0x08,0xf8,0x01,0x26,0x08,0xf3,0x01,0x15,0x08,0xed,0x01,0x04,0x08,0xe7,0x01,0xf3,0x07,0xe2,0x01,0xe2,0x07,0xdc,0x01,0xd1,0x07,0xd7,0x01,0xc0,0x07,0xd2,0x01,0xaf,0x07,0xcc,0x01,0x9e,0x07,0xc7,0x01,  \
    0x8d,0x07,0xc2,0x01,0x7d,0x07,0xbd,0x01,0x6c,0x07,0xb7,0x01,0x5b,0x07,0xb2,0x01,0x4a,0x07,0xad,0x01,0x39,0x07,0xa8,0x01,0x28,0x07,0xa3,0x01,0x18,0x07,0x9f,0x01,0x07,0x07,0x9a,0x01,0xf6,0x06,0x95,0x01,0xe5,0x06,0x90,0x01,0xd5,0x06,0x8c,0x01,0xc2,0x06,0x88,0x01,0xb0,0x06,0x84,0x01,0x9e,0x06,0x80,0x01,0x8c,0x06,0x7b,0x01,0x7a,0x06,0x77,0x01,0x68,0x06,0x73,0x01,0x56,0x06,0x6f,0x01,0x44,0x06,0x6b,0x01,0x32,0x06,0x68,0x01,0x20,0x06,0x64,0x01,0x0e,0x06,  \
    0x60,0x01,0xfc,0x05,0x5c,0x01,0xea,0x05,0x58,0x01,0xd8,0x05,0x55,0x01,0xc6,0x05,0x51,0x01,0xb4,0x05,0x4d,0x01,0xa2,0x05,0x4a,0x01,0x90,0x05,0x46,0x01,0x7f,0x05,0x43,0x01,0x6d,0x05,0x3f,0x01,0x5b,0x05,0x3c,0x01,0x49,0x05,0x38,0x01,0x38,0x05,0x35,0x01,0x26,0x05,0x31,0x01,0x15,0x05,0x2e,0x01,0x04,0x05,0x2a,0x01,0xf4,0x04,0x27,0x01,0xe3,0x04,0x23,0x01,0xd2,0x04,0x20,0x01,0xc1,0x04,0x1d,0x01,0xb1,0x04,0x1a,0x01,0xa0,0x04,0x16,0x01,0x8f,0x04,0x13,0x01,  \
    0x7e,0x04,0x10,0x01,0x6e,0x04,0x0d,0x01,0x5d,0x04,0x0a,0x01,0x4c,0x04,0x07,0x01,0x3b,0x04,0x04,0x01,0x2b,0x04,0x01,0x01,0x1a,0x04,0xff,0x00,0x09,0x04,0xfc,0x00,0xf9,0x03,0xf9,0x00,0xe8,0x03,0xf6,0x00,0xd7,0x03,0xf4,0x00,0xc6,0x03,0xf1,0x00,0xb6,0x03,0xef,0x00,0xa5,0x03,0xec,0x00,0x94,0x03,0xea,0x00,0x83,0x03,0xe7,0x00,0x73,0x03,0xe5,0x00,0x63,0x03,0xe2,0x00,0x53,0x03,0xe0,0x00,0x43,0x03,0xdd,0x00,0x33,0x03,0xdb,0x00,0x23,0x03,0xd9,0x00,0x13,0x03,  \
    0xd7,0x00,0x03,0x03,0xd5,0x00,0xf2,0x02,0xd3,0x00,0xe2,0x02,0xd1,0x00,0xd2,0x02,0xcf,0x00,0xc2,0x02,0xcd,0x00,0xb2,0x02,0xcb,0x00,0xa1,0x02,0xc9,0x00,0x91,0x02,0xc7,0x00,0x81,0x02,0xc5,0x00,0x70,0x02,0xc4,0x00,0x60,0x02,0xc2,0x00,0x50,0x02,0xc1,0x00,0x3f,0x02,0xbf,0x00,0x2f,0x02,0xbd,0x00,0x1e,0x02,0xbc,0x00,0x0e,0x02,0xbb,0x00,0xfd,0x01,0xb9,0x00,0xec,0x01,0xb8,0x00,0xdc,0x01,0xb7,0x00,0xcb,0x01,0xb5,0x00,0xbb,0x01,0xb4,0x00,0xa9,0x01,0xb3,0x00,  \
    0x98,0x01,0xb2,0x00,0x87,0x01,0xb1,0x00,0x76,0x01,0xb0,0x00,0x65,0x01,0xaf,0x00,0x53,0x01,0xae,0x00,0x42,0x01,0xae,0x00,0x31,0x01,0xad,0x00,0x20,0x01,0xac,0x00,0x0f,0x01,0xab,0x00,0xfd,0x00,0xaa,0x00,0xec,0x00,0xaa,0x00,0xdb,0x00,0xa9,0x00,0xca,0x00,0xa9,0x00,0xb9,0x00,0xa8,0x00,0xa7,0x00,0xa8,0x00,0x96,0x00,0xa7,0x00,0x85,0x00,0xa7,0x00,0x74,0x00,0xa6,0x00,0x62,0x00,0xa6,0x00,0x51,0x00,0xa6,0x00,0x40,0x00,0xa5,0x00,0x2f,0x00,0xa5,0x00,0x1e,0x00,  \
    0xa5,0x00,0x0c,0x00,0xa5,0x00,0xfb,0xff,0xa5,0x00,0xea,0xff,0xa5,0x00,0xd9,0xff,0xa5,0x00,0xc8,0xff,0xa5,0x00,0xb6,0xff,0xa5,0x00,0xa5,0xff,0xa5,0x00,0x94,0xff,0xa5,0x00,0x83,0xff,0xa5,0x00,0x71,0xff,0xa5,0x00,0x60,0xff,0xa5,0x00,0x4f,0xff,0xa6,0x00,0x3e,0xff,0xa6,0x00,0x2d,0xff,0xa6,0x00,0x1b,0xff,0xa7,0x00,0x0a,0xff,0xa7,0x00,0xf9,0xfe,0xa8,0x00,0xe8,0xfe,0xa8,0x00,0xd7,0xfe,0xa9,0x00,0xc5,0xfe,0xa9,0x00,0xb4,0xfe,0xaa,0x00,0xa3,0xfe,0xaa,0x00,  \
    0x92,0xfe,0xab,0x00,0x81,0xfe,0xac,0x00,0x70,0xfe,0xad,0x00,0x5e,0xfe,0xad,0x00,0x4d,0xfe,0xae,0x00,0x3c,0xfe,0xaf,0x00,0x2b,0xfe,0xb0,0x00,0x1a,0xfe,0xb1,0x00,0x08,0xfe,0xb2,0x00,0xf7,0xfd,0xb3,0x00,0xe6,0xfd,0xb4,0x00,0xd5,0xfd,0xb5,0x00,0xc3,0xfd,0xb6,0x00,0xb2,0xfd,0xb7,0x00,0xa0,0xfd,0xb9,0x00,0x8f,0xfd,0xba,0x00,0x7d,0xfd,0xbb,0x00,0x6c,0xfd,0xbc,0x00,0x5a,0xfd,0xbe,0x00,0x49,0xfd,0xbf,0x00,0x37,0xfd,0xc1,0x00,0x26,0xfd,0xc2,0x00,0x14,0xfd,  \
    0xc4,0x00,0x03,0xfd,0xc5,0x00,0xf1,0xfc,0xc7,0x00,0xdf,0xfc,0xc8,0x00,0xce,0xfc,0xca,0x00,0xbc,0xfc,0xcc,0x00,0xab,0xfc,0xcd,0x00,0x99,0xfc,0xcf,0x00,0x87,0xfc,0xd1,0x00,0x76,0xfc,0xd2,0x00,0x64,0xfc,0xd4,0x00,0x52,0xfc,0xd6,0x00,0x40,0xfc,0xd8,0x00,0x2f,0xfc,0xda,0x00,0x1d,0xfc,0xdc,0x00,0x0b,0xfc,0xde,0x00,0xfa,0xfb,0xe0,0x00,0xe9,0xfb,0xe3,0x00,0xd8,0xfb,0xe5,0x00,0xc7,0xfb,0xe7,0x00,0xb6,0xfb,0xe9,0x00,0xa5,0xfb,0xec,0x00,0x94,0xfb,0xee,0x00,  \
    0x83,0xfb,0xf1,0x00,0x72,0xfb,0xf3,0x00,0x61,0xfb,0xf6,0x00,0x51,0xfb,0xf8,0x00,0x40,0xfb,0xfb,0x00,0x2f,0xfb,0xfe,0x00,0x1e,0xfb,0x00,0x01,0x0d,0xfb,0x03,0x01,0xfc,0xfa,0x06,0x01,0xeb,0xfa,0x09,0x01,0xda,0xfa,0x0c,0x01,0xc9,0xfa,0x0f,0x01,0xb9,0xfa,0x12,0x01,0xa8,0xfa,0x15,0x01,0x97,0xfa,0x18,0x01,0x86,0xfa,0x1b,0x01,0x75,0xfa,0x1e,0x01,0x64,0xfa,0x21,0x01,0x54,0xfa,0x24,0x01,0x43,0xfa,0x28,0x01,0x31,0xfa,0x2b,0x01,0x20,0xfa,0x2e,0x01,0x0e,0xfa,  \
    0x31,0x01,0xfc,0xf9,0x35,0x01,0xeb,0xf9,0x38,0x01,0xd9,0xf9,0x3b,0x01,0xc8,0xf9,0x3f,0x01,0xb6,0xf9,0x42,0x01,0xa5,0xf9,0x46,0x01,0x93,0xf9,0x49,0x01,0x82,0xf9,0x4d,0x01,0x70,0xf9,0x51,0x01,0x5f,0xf9,0x54,0x01,0x4d,0xf9,0x58,0x01,0x3b,0xf9,0x5c,0x01,0x2a,0xf9,0x60,0x01,0x18,0xf9,0x64,0x01,0x07,0xf9,0x67,0x01,0xf5,0xf8,0x6b,0x01,0xe3,0xf8,0x6f,0x01,0xd2,0xf8,0x73,0x01,0xc0,0xf8,0x77,0x01,0xae,0xf8,0x7b,0x01,0x9d,0xf8,0x80,0x01,0x8b,0xf8,0x84,0x01,  \
    0x7a,0xf8,0x88,0x01,0x69,0xf8,0x8d,0x01,0x57,0xf8,0x91,0x01,0x46,0xf8,0x96,0x01,0x35,0xf8,0x9a,0x01,0x24,0xf8,0x9f,0x01,0x12,0xf8,0xa3,0x01,0x01,0xf8,0xa8,0x01,0xf0,0xf7,0xad,0x01,0xde,0xf7,0xb1,0x01,0xcd,0xf7,0xb6,0x01,0xbc,0xf7,0xbb,0x01,0xaa,0xf7,0xc0,0x01,0x99,0xf7,0xc5,0x01,0x87,0xf7,0xca,0x01,0x76,0xf7,0xcf,0x01,0x65,0xf7,0xd4,0x01,0x53,0xf7,0xd9,0x01,0x42,0xf7,0xde,0x01,0x30,0xf7,0xe3,0x01,0x1f,0xf7,0xe9,0x01,0x0d,0xf7,0xee,0x01,0xfb,0xf6,  \
    0xf3,0x01,0xe9,0xf6,0xf8,0x01,0xd7,0xf6,0xfd,0x01,0xc5,0xf6,0x02,0x02,0xb2,0xf6,0x08,0x02,0xa0,0xf6,0x0d,0x02,0x8e,0xf6,0x12,0x02,0x7c,0xf6,0x17,0x02,0x69,0xf6,0x1d,0x02,0x57,0xf6,0x22,0x02,0x44,0xf6,0x28,0x02,0x32,0xf6,0x2d,0x02,0x20,0xf6,0x33,0x02,0x0d,0xf6,0x38,0x02,0xfb,0xf5,0x3e,0x02,0xe8,0xf5,0x43,0x02,0xd5,0xf5,0x49,0x02,0xc3,0xf5,0x4f,0x02,0xb0,0xf5,0x55,0x02,0x9d,0xf5,0x5a,0x02,0x8b,0xf5,0x60,0x02,0x78,0xf5,0x66,0x02,0x66,0xf5,0x6c,0x02,  \
    0x54,0xf5,0x72,0x02,0x41,0xf5,0x79,0x02,0x2f,0xf5,0x7f,0x02,0x1c,0xf5,0x85,0x02,0x0a,0xf5,0x8b,0x02,0xf7,0xf4,0x91,0x02,0xe5,0xf4,0x98,0x02,0xd2,0xf4,0x9e,0x02,0xbf,0xf4,0xa4,0x02,0xac,0xf4,0xab,0x02,0x9a,0xf4,0xb1,0x02,0x87,0xf4,0xb8,0x02,0x74,0xf4,0xbe,0x02,0x61,0xf4,0xc4,0x02,0x4e,0xf4,0xcb,0x02,0x3b,0xf4,0xd1,0x02,0x28,0xf4,0xd8,0x02,0x14,0xf4,0xde,0x02,0x00,0xf4,0xe4,0x02,0xeb,0xf3,0xe9,0x02,0xd6,0xf3,0xef,0x02,0xc1,0xf3,0xf5,0x02,0xac,0xf3,  \
    0xfb,0x02,0x97,0xf3,0x01,0x03,0x82,0xf3,0x06,0x03,0x6c,0xf3,0x0c,0x03,0x57,0xf3,0x12,0x03,0x42,0xf3,0x18,0x03,0x2c,0xf3,0x1e,0x03,0x17,0xf3,0x23,0x03,0x01,0xf3,0x29,0x03,0xec,0xf2,0x2f,0x03,0xd6,0xf2,0x35,0x03,0xc0,0xf2,0x3b,0x03,0xaa,0xf2,0x40,0x03,0x94,0xf2,0x46,0x03,0x7f,0xf2,0x4d,0x03,0x6a,0xf2,0x54,0x03,0x56,0xf2,0x5a,0x03,0x41,0xf2,0x61,0x03,0x2c,0xf2,0x68,0x03,0x17,0xf2,0x6e,0x03,0x02,0xf2,0x75,0x03,0xed,0xf1,0x7b,0x03,0xd8,0xf1,0x82,0x03,  \
    0xc2,0xf1,0x88,0x03,0xad,0xf1,0x8f,0x03,0x97,0xf1,0x95,0x03,0x81,0xf1,0x9c,0x03,0x6c,0xf1,0xa2,0x03,0x56,0xf1,0xa8,0x03,0x40,0xf1,0xaf,0x03,0x29,0xf1,0xb5,0x03,0x13,0xf1,0xbb,0x03,0xfd,0xf0,0xc2,0x03,0xe6,0xf0,0xc8,0x03,0xd0,0xf0,0xce,0x03,0xb9,0xf0,0xd4,0x03,0xa3,0xf0,0xdb,0x03,0x8c,0xf0,0xe1,0x03,0x75,0xf0,0xe7,0x03,0x5e,0xf0,0xed,0x03,0x47,0xf0,0xf3,0x03,0x2f,0xf0,0xf9,0x03,0x18,0xf0,0xfe,0x03,0x00,0xf0,0x04,0x04,0xe8,0xef,0x0a,0x04,0xd0,0xef,  \
    0x0f,0x04,0xb8,0xef,0x15,0x04,0xa0,0xef,0x1a,0x04,0x88,0xef,0x1f,0x04,0x6f,0xef,0x25,0x04,0x56,0xef,0x2a,0x04,0x3d,0xef,0x2f,0x04,0x24,0xef,0x33,0x04,0x0b,0xef,0x38,0x04,0xf0,0xee,0x3c,0x04,0xd6,0xee,0x40,0x04,0xbc,0xee,0x44,0x04,0xa1,0xee,0x48,0x04,0x86,0xee,0x4b,0x04,0x6b,0xee,0x4f,0x04,0x50,0xee,0x52,0x04,0x35,0xee,0x56,0x04,0x19,0xee,0x59,0x04,0xfe,0xed,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xca,0x04,0xb0,0x11,0xc6,0x04,0x94,0x11,0xc3,0x04,0x79,0x11,0xbe,0x04,0x5e,0x11,0xba,0x04,0x43,0x11,0xb6,0x04,0x28,0x11,0xb2,0x04,0x0d,0x11,0xad,0x04,0xf2,0x10,0xa9,0x04,0xd8,0x10,0xa4,0x04,0xbd,0x10,0x9f,0x04,0xa3,0x10,0x9a,0x04,0x89,0x10,  \
    0x95,0x04,0x6f,0x10,0x90,0x04,0x55,0x10,0x8b,0x04,0x3b,0x10,0x86,0x04,0x22,0x10,0x81,0x04,0x08,0x10,0x7b,0x04,0xef,0x0f,0x76,0x04,0xd6,0x0f,0x70,0x04,0xbd,0x0f,0x6a,0x04,0xa4,0x0f,0x64,0x04,0x8c,0x0f,0x5e,0x04,0x74,0x0f,0x58,0x04,0x5c,0x0f,0x52,0x04,0x44,0x0f,0x4b,0x04,0x2c,0x0f,0x45,0x04,0x15,0x0f,0x3e,0x04,0xfe,0x0e,0x37,0x04,0xe6,0x0e,0x31,0x04,0xcf,0x0e,0x2a,0x04,0xb8,0x0e,0x23,0x04,0xa1,0x0e,0x1d,0x04,0x8a,0x0e,0x16,0x04,0x74,0x0e,0x0f,0x04,  \
    0x5d,0x0e,0x08,0x04,0x47,0x0e,0x01,0x04,0x31,0x0e,0xfa,0x03,0x1a,0x0e,0xf3,0x03,0x04,0x0e,0xec,0x03,0xee,0x0d,0xe4,0x03,0xd9,0x0d,0xdc,0x03,0xc4,0x0d,0xd5,0x03,0xaf,0x0d,0xcd,0x03,0x9b,0x0d,0xc5,0x03,0x86,0x0d,0xbd,0x03,0x72,0x0d,0xb5,0x03,0x5e,0x0d,0xad,0x03,0x4a,0x0d,0xa5,0x03,0x36,0x0d,0x9d,0x03,0x22,0x0d,0x95,0x03,0x0e,0x0d,0x8e,0x03,0xfa,0x0c,0x86,0x03,0xe7,0x0c,0x7e,0x03,0xd3,0x0c,0x76,0x03,0xc0,0x0c,0x6e,0x03,0xad,0x0c,0x66,0x03,0x9a,0x0c,  \
    0x5e,0x03,0x86,0x0c,0x57,0x03,0x71,0x0c,0x51,0x03,0x5b,0x0c,0x4b,0x03,0x46,0x0c,0x44,0x03,0x30,0x0c,0x3e,0x03,0x1b,0x0c,0x38,0x03,0x06,0x0c,0x31,0x03,0xf1,0x0b,0x2b,0x03,0xdc,0x0b,0x24,0x03,0xc7,0x0b,0x1e,0x03,0xb2,0x0b,0x18,0x03,0x9d,0x0b,0x11,0x03,0x88,0x0b,0x0b,0x03,0x73,0x0b,0x05,0x03,0x5e,0x0b,0xff,0x02,0x4a,0x0b,0xf8,0x02,0x35,0x0b,0xf2,0x02,0x21,0x0b,0xec,0x02,0x0c,0x0b,0xe6,0x02,0xf8,0x0a,0xdf,0x02,0xe3,0x0a,0xd9,0x02,0xcf,0x0a,0xd3,0x02,  \
    0xba,0x0a,0xcd,0x02,0xa6,0x0a,0xc7,0x02,0x92,0x0a,0xc1,0x02,0x7e,0x0a,0xbb,0x02,0x69,0x0a,0xb5,0x02,0x55,0x0a,0xaf,0x02,0x41,0x0a,0xa9,0x02,0x2d,0x0a,0xa3,0x02,0x19,0x0a,0x9d,0x02,0x05,0x0a,0x97,0x02,0xf2,0x09,0x91,0x02,0xde,0x09,0x8b,0x02,0xca,0x09,0x85,0x02,0xb6,0x09,0x7f,0x02,0xa3,0x09,0x78,0x02,0x92,0x09,0x71,0x02,0x80,0x09,0x6a,0x02,0x6f,0x09,0x63,0x02,0x5e,0x09,0x5d,0x02,0x4d,0x09,0x56,0x02,0x3c,0x09,0x4f,0x02,0x2b,0x09,0x49,0x02,0x1a,0x09,  \
    0x42,0x02,0x09,0x09,0x3c,0x02,0xf8,0x08,0x35,0x02,0xe7,0x08,0x2f,0x02,0xd6,0x08,0x28,0x02,0xc5,0x08,0x22,0x02,0xb4,0x08,0x1c,0x02,0xa3,0x08,0x16,0x02,0x92,0x08,0x0f,0x02,0x82,0x08,0x09,0x02,0x71,0x08,0x03,0x02,0x60,0x08,0xfd,0x01,0x50,0x08,0xf7,0x01,0x3f,0x08,0xf2,0x01,0x2e,0x08,0xec,0x01,0x1d,0x08,0xe6,0x01,0x0c,0x08,0xe1,0x01,0xfb,0x07,0xdb,0x01,0xea,0x07,0xd5,0x01,0xd9,0x07,0xd0,0x01,0xc8,0x07,0xcb,0x01,0xb7,0x07,0xc5,0x01,0xa6,0x07,0xc0,0x01,  \
    0x95,0x07,0xbb,0x01,0x85,0x07,0xb5,0x01,0x74,0x07,0xb0,0x01,0x63,0x07,0xab,0x01,0x52,0x07,0xa6,0x01,0x41,0x07,0xa1,0x01,0x31,0x07,0x9c,0x01,0x20,0x07,0x97,0x01,0x0f,0x07,0x92,0x01,0xfe,0x06,0x8d,0x01,0xee,0x06,0x89,0x01,0xdd,0x06,0x84,0x01,0xcc,0x06,0x80,0x01,0xba,0x06,0x7b,0x01,0xa8,0x06,0x77,0x01,0x96,0x06,0x73,0x01,0x84,0x06,0x6f,0x01,0x72,0x06,0x6b,0x01,0x60,0x06,0x67,0x01,0x4e,0x06,0x63,0x01,0x3c,0x06,0x5f,0x01,0x2a,0x06,0x5b,0x01,0x18,0x06,  \
    0x57,0x01,0x06,0x06,0x53,0x01,0xf4,0x05,0x4f,0x01,0xe2,0x05,0x4c,0x01,0xd0,0x05,0x48,0x01,0xbf,0x05,0x44,0x01,0xad,0x05,0x41,0x01,0x9b,0x05,0x3d,0x01,0x89,0x05,0x39,0x01,0x78,0x05,0x36,0x01,0x66,0x05,0x32,0x01,0x54,0x05,0x2f,0x01,0x42,0x05,0x2b,0x01,0x31,0x05,0x28,0x01,0x1f,0x05,0x24,0x01,0x0f,0x05,0x21,0x01,0xfe,0x04,0x1d,0x01,0xed,0x04,0x1a,0x01,0xdd,0x04,0x17,0x01,0xcc,0x04,0x13,0x01,0xbb,0x04,0x10,0x01,0xaa,0x04,0x0d,0x01,0x9a,0x04,0x0a,0x01,  \
    0x89,0x04,0x06,0x01,0x78,0x04,0x03,0x01,0x68,0x04,0x00,0x01,0x57,0x04,0xfd,0x00,0x46,0x04,0xfa,0x00,0x36,0x04,0xf7,0x00,0x25,0x04,0xf4,0x00,0x14,0x04,0xf2,0x00,0x04,0x04,0xef,0x00,0xf3,0x03,0xec,0x00,0xe2,0x03,0xe9,0x00,0xd2,0x03,0xe7,0x00,0xc1,0x03,0xe4,0x00,0xb0,0x03,0xe2,0x00,0xa0,0x03,0xdf,0x00,0x8f,0x03,0xdd,0x00,0x7e,0x03,0xda,0x00,0x6e,0x03,0xd8,0x00,0x5e,0x03,0xd5,0x00,0x4e,0x03,0xd3,0x00,0x3e,0x03,0xd1,0x00,0x2e,0x03,0xce,0x00,0x1e,0x03,  \
    0xcc,0x00,0x0e,0x03,0xca,0x00,0xfe,0x02,0xc8,0x00,0xee,0x02,0xc6,0x00,0xde,0x02,0xc4,0x00,0xce,0x02,0xc2,0x00,0xbe,0x02,0xc0,0x00,0xae,0x02,0xbe,0x00,0x9d,0x02,0xbc,0x00,0x8d,0x02,0xba,0x00,0x7d,0x02,0xb8,0x00,0x6d,0x02,0xb7,0x00,0x5c,0x02,0xb5,0x00,0x4c,0x02,0xb3,0x00,0x3c,0x02,0xb2,0x00,0x2b,0x02,0xb0,0x00,0x1b,0x02,0xaf,0x00,0x0a,0x02,0xae,0x00,0xfa,0x01,0xac,0x00,0xe9,0x01,0xab,0x00,0xd9,0x01,0xaa,0x00,0xc8,0x01,0xa8,0x00,0xb8,0x01,0xa7,0x00,  \
    0xa7,0x01,0xa6,0x00,0x96,0x01,0xa5,0x00,0x84,0x01,0xa4,0x00,0x73,0x01,0xa3,0x00,0x62,0x01,0xa2,0x00,0x51,0x01,0xa1,0x00,0x40,0x01,0xa0,0x00,0x2f,0x01,0xa0,0x00,0x1e,0x01,0x9f,0x00,0x0d,0x01,0x9e,0x00,0xfc,0x00,0x9d,0x00,0xea,0x00,0x9d,0x00,0xd9,0x00,0x9c,0x00,0xc8,0x00,0x9b,0x00,0xb7,0x00,0x9b,0x00,0xa6,0x00,0x9a,0x00,0x95,0x00,0x9a,0x00,0x84,0x00,0x9a,0x00,0x73,0x00,0x99,0x00,0x62,0x00,0x99,0x00,0x50,0x00,0x98,0x00,0x3f,0x00,0x98,0x00,0x2e,0x00,  \
    0x98,0x00,0x1d,0x00,0x98,0x00,0x0c,0x00,0x98,0x00,0xfb,0xff,0x98,0x00,0xea,0xff,0x97,0x00,0xd9,0xff,0x97,0x00,0xc7,0xff,0x97,0x00,0xb6,0xff,0x97,0x00,0xa5,0xff,0x98,0x00,0x94,0xff,0x98,0x00,0x83,0xff,0x98,0x00,0x72,0xff,0x98,0x00,0x61,0xff,0x98,0x00,0x50,0xff,0x99,0x00,0x3f,0xff,0x99,0x00,0x2d,0xff,0x99,0x00,0x1c,0xff,0x9a,0x00,0x0b,0xff,0x9a,0x00,0xfa,0xfe,0x9a,0x00,0xe9,0xfe,0x9b,0x00,0xd8,0xfe,0x9b,0x00,0xc7,0xfe,0x9c,0x00,0xb6,0xfe,0x9d,0x00,  \
    0xa5,0xfe,0x9d,0x00,0x94,0xfe,0x9e,0x00,0x83,0xfe,0x9f,0x00,0x71,0xfe,0xa0,0x00,0x60,0xfe,0xa0,0x00,0x4f,0xfe,0xa1,0x00,0x3e,0xfe,0xa2,0x00,0x2d,0xfe,0xa3,0x00,0x1c,0xfe,0xa4,0x00,0x0b,0xfe,0xa5,0x00,0xfa,0xfd,0xa6,0x00,0xe9,0xfd,0xa7,0x00,0xd7,0xfd,0xa8,0x00,0xc6,0xfd,0xa9,0x00,0xb5,0xfd,0xaa,0x00,0xa3,0xfd,0xac,0x00,0x92,0xfd,0xad,0x00,0x81,0xfd,0xae,0x00,0x6f,0xfd,0xaf,0x00,0x5e,0xfd,0xb1,0x00,0x4c,0xfd,0xb2,0x00,0x3b,0xfd,0xb4,0x00,0x29,0xfd,  \
    0xb5,0x00,0x18,0xfd,0xb7,0x00,0x07,0xfd,0xb8,0x00,0xf5,0xfc,0xba,0x00,0xe4,0xfc,0xbb,0x00,0xd2,0xfc,0xbd,0x00,0xc1,0xfc,0xbf,0x00,0xaf,0xfc,0xc0,0x00,0x9d,0xfc,0xc2,0x00,0x8c,0xfc,0xc4,0x00,0x7a,0xfc,0xc6,0x00,0x69,0xfc,0xc8,0x00,0x57,0xfc,0xc9,0x00,0x46,0xfc,0xcb,0x00,0x34,0xfc,0xcd,0x00,0x22,0xfc,0xcf,0x00,0x11,0xfc,0xd1,0x00,0x00,0xfc,0xd4,0x00,0xef,0xfb,0xd6,0x00,0xde,0xfb,0xd8,0x00,0xcd,0xfb,0xda,0x00,0xbc,0xfb,0xdd,0x00,0xab,0xfb,0xdf,0x00,  \
    0x9a,0xfb,0xe2,0x00,0x89,0xfb,0xe4,0x00,0x79,0xfb,0xe7,0x00,0x68,0xfb,0xe9,0x00,0x57,0xfb,0xec,0x00,0x46,0xfb,0xee,0x00,0x35,0xfb,0xf1,0x00,0x24,0xfb,0xf4,0x00,0x14,0xfb,0xf7,0x00,0x03,0xfb,0xf9,0x00,0xf2,0xfa,0xfc,0x00,0xe1,0xfa,0xff,0x00,0xd0,0xfa,0x02,0x01,0xc0,0xfa,0x05,0x01,0xaf,0xfa,0x08,0x01,0x9e,0xfa,0x0b,0x01,0x8d,0xfa,0x0e,0x01,0x7d,0xfa,0x12,0x01,0x6c,0xfa,0x15,0x01,0x5b,0xfa,0x18,0x01,0x4a,0xfa,0x1b,0x01,0x39,0xfa,0x1f,0x01,0x27,0xfa,  \
    0x22,0x01,0x16,0xfa,0x25,0x01,0x04,0xfa,0x28,0x01,0xf3,0xf9,0x2c,0x01,0xe1,0xf9,0x2f,0x01,0xd0,0xf9,0x33,0x01,0xbf,0xf9,0x36,0x01,0xad,0xf9,0x3a,0x01,0x9c,0xf9,0x3d,0x01,0x8a,0xf9,0x41,0x01,0x79,0xf9,0x45,0x01,0x67,0xf9,0x48,0x01,0x56,0xf9,0x4c,0x01,0x44,0xf9,0x50,0x01,0x33,0xf9,0x54,0x01,0x21,0xf9,0x58,0x01,0x0f,0xf9,0x5b,0x01,0xfe,0xf8,0x5f,0x01,0xec,0xf8,0x63,0x01,0xdb,0xf8,0x67,0x01,0xc9,0xf8,0x6c,0x01,0xb8,0xf8,0x70,0x01,0xa6,0xf8,0x74,0x01,  \
    0x95,0xf8,0x78,0x01,0x84,0xf8,0x7d,0x01,0x72,0xf8,0x81,0x01,0x61,0xf8,0x85,0x01,0x50,0xf8,0x8a,0x01,0x3f,0xf8,0x8e,0x01,0x2d,0xf8,0x93,0x01,0x1c,0xf8,0x98,0x01,0x0b,0xf8,0x9c,0x01,0xfa,0xf7,0xa1,0x01,0xe8,0xf7,0xa6,0x01,0xd7,0xf7,0xab,0x01,0xc6,0xf7,0xb0,0x01,0xb4,0xf7,0xb4,0x01,0xa3,0xf7,0xb9,0x01,0x92,0xf7,0xbe,0x01,0x80,0xf7,0xc3,0x01,0x6f,0xf7,0xc9,0x01,0x5e,0xf7,0xce,0x01,0x4c,0xf7,0xd3,0x01,0x3b,0xf7,0xd8,0x01,0x29,0xf7,0xdd,0x01,0x18,0xf7,  \
    0xe2,0x01,0x06,0xf7,0xe8,0x01,0xf4,0xf6,0xed,0x01,0xe2,0xf6,0xf2,0x01,0xd0,0xf6,0xf7,0x01,0xbd,0xf6,0xfc,0x01,0xab,0xf6,0x02,0x02,0x99,0xf6,0x07,0x02,0x87,0xf6,0x0c,0x02,0x74,0xf6,0x12,0x02,0x62,0xf6,0x17,0x02,0x50,0xf6,0x1d,0x02,0x3d,0xf6,0x22,0x02,0x2b,0xf6,0x28,0x02,0x18,0xf6,0x2d,0x02,0x06,0xf6,0x33,0x02,0xf3,0xf5,0x39,0x02,0xe1,0xf5,0x3e,0x02,0xce,0xf5,0x44,0x02,0xbc,0xf5,0x4a,0x02,0xa9,0xf5,0x50,0x02,0x96,0xf5,0x55,0x02,0x84,0xf5,0x5b,0x02,  \
    0x72,0xf5,0x62,0x02,0x5f,0xf5,0x68,0x02,0x4d,0xf5,0x6e,0x02,0x3a,0xf5,0x74,0x02,0x28,0xf5,0x7a,0x02,0x15,0xf5,0x80,0x02,0x03,0xf5,0x87,0x02,0xf0,0xf4,0x8d,0x02,0xde,0xf4,0x93,0x02,0xcb,0xf4,0x9a,0x02,0xb8,0xf4,0xa0,0x02,0xa5,0xf4,0xa7,0x02,0x93,0xf4,0xad,0x02,0x80,0xf4,0xb3,0x02,0x6d,0xf4,0xba,0x02,0x5a,0xf4,0xc0,0x02,0x47,0xf4,0xc7,0x02,0x34,0xf4,0xce,0x02,0x20,0xf4,0xd3,0x02,0x0c,0xf4,0xd9,0x02,0xf7,0xf3,0xdf,0x02,0xe2,0xf3,0xe5,0x02,0xcd,0xf3,  \
    0xeb,0x02,0xb8,0xf3,0xf0,0x02,0xa3,0xf3,0xf6,0x02,0x8e,0xf3,0xfc,0x02,0x79,0xf3,0x02,0x03,0x63,0xf3,0x08,0x03,0x4e,0xf3,0x0e,0x03,0x39,0xf3,0x13,0x03,0x23,0xf3,0x19,0x03,0x0e,0xf3,0x1f,0x03,0xf8,0xf2,0x25,0x03,0xe2,0xf2,0x2b,0x03,0xcd,0xf2,0x31,0x03,0xb7,0xf2,0x36,0x03,0xa1,0xf2,0x3c,0x03,0x8c,0xf2,0x43,0x03,0x77,0xf2,0x4a,0x03,0x62,0xf2,0x50,0x03,0x4d,0xf2,0x57,0x03,0x39,0xf2,0x5e,0x03,0x24,0xf2,0x64,0x03,0x0e,0xf2,0x6b,0x03,0xf9,0xf1,0x71,0x03,  \
    0xe4,0xf1,0x78,0x03,0xcf,0xf1,0x7e,0x03,0xb9,0xf1,0x85,0x03,0xa3,0xf1,0x8b,0x03,0x8e,0xf1,0x92,0x03,0x78,0xf1,0x98,0x03,0x62,0xf1,0x9e,0x03,0x4c,0xf1,0xa5,0x03,0x36,0xf1,0xab,0x03,0x1f,0xf1,0xb1,0x03,0x09,0xf1,0xb8,0x03,0xf3,0xf0,0xbe,0x03,0xdc,0xf0,0xc4,0x03,0xc6,0xf0,0xca,0x03,0xaf,0xf0,0xd1,0x03,0x98,0xf0,0xd7,0x03,0x81,0xf0,0xdd,0x03,0x6a,0xf0,0xe3,0x03,0x53,0xf0,0xe9,0x03,0x3b,0xf0,0xee,0x03,0x24,0xf0,0xf4,0x03,0x0c,0xf0,0xfa,0x03,0xf4,0xef,  \
    0xff,0x03,0xdc,0xef,0x05,0x04,0xc4,0xef,0x0a,0x04,0xac,0xef,0x10,0x04,0x93,0xef,0x15,0x04,0x7b,0xef,0x1a,0x04,0x62,0xef,0x1f,0x04,0x49,0xef,0x24,0x04,0x30,0xef,0x29,0x04,0x16,0xef,0x2d,0x04,0xfc,0xee,0x31,0x04,0xe2,0xee,0x35,0x04,0xc7,0xee,0x39,0x04,0xac,0xee,0x3d,0x04,0x91,0xee,0x41,0x04,0x77,0xee,0x45,0x04,0x5b,0xee,0x48,0x04,0x40,0xee,0x4c,0x04,0x25,0xee,0x4f,0x04,0x09,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xbb,0x04,0xa8,0x11,0xb7,0x04,0x8d,0x11,0xb3,0x04,0x71,0x11,0xaf,0x04,0x56,0x11,0xab,0x04,0x3b,0x11,0xa7,0x04,0x20,0x11,0xa3,0x04,0x05,0x11,0x9e,0x04,0xea,0x10,0x9a,0x04,0xd0,0x10,0x95,0x04,0xb5,0x10,0x90,0x04,0x9b,0x10,  \
    0x8c,0x04,0x81,0x10,0x87,0x04,0x67,0x10,0x82,0x04,0x4d,0x10,0x7d,0x04,0x33,0x10,0x77,0x04,0x1a,0x10,0x72,0x04,0x00,0x10,0x6d,0x04,0xe7,0x0f,0x67,0x04,0xce,0x0f,0x62,0x04,0xb5,0x0f,0x5c,0x04,0x9c,0x0f,0x56,0x04,0x84,0x0f,0x50,0x04,0x6c,0x0f,0x4a,0x04,0x54,0x0f,0x43,0x04,0x3c,0x0f,0x3d,0x04,0x24,0x0f,0x36,0x04,0x0d,0x0f,0x30,0x04,0xf5,0x0e,0x29,0x04,0xde,0x0e,0x23,0x04,0xc7,0x0e,0x1c,0x04,0xb0,0x0e,0x15,0x04,0x99,0x0e,0x0f,0x04,0x82,0x0e,0x08,0x04,  \
    0x6b,0x0e,0x01,0x04,0x55,0x0e,0xfa,0x03,0x3e,0x0e,0xf3,0x03,0x28,0x0e,0xec,0x03,0x12,0x0e,0xe5,0x03,0xfb,0x0d,0xde,0x03,0xe5,0x0d,0xd7,0x03,0xd0,0x0d,0xcf,0x03,0xbb,0x0d,0xc7,0x03,0xa6,0x0d,0xbf,0x03,0x92,0x0d,0xb8,0x03,0x7d,0x0d,0xb0,0x03,0x69,0x0d,0xa8,0x03,0x54,0x0d,0xa0,0x03,0x40,0x0d,0x98,0x03,0x2c,0x0d,0x91,0x03,0x18,0x0d,0x89,0x03,0x04,0x0d,0x81,0x03,0xf1,0x0c,0x79,0x03,0xdd,0x0c,0x71,0x03,0xc9,0x0c,0x69,0x03,0xb6,0x0c,0x61,0x03,0xa3,0x0c,  \
    0x59,0x03,0x90,0x0c,0x51,0x03,0x7c,0x0c,0x4b,0x03,0x67,0x0c,0x45,0x03,0x51,0x0c,0x3e,0x03,0x3c,0x0c,0x38,0x03,0x26,0x0c,0x32,0x03,0x11,0x0c,0x2b,0x03,0xfc,0x0b,0x25,0x03,0xe7,0x0b,0x1e,0x03,0xd2,0x0b,0x18,0x03,0xbd,0x0b,0x12,0x03,0xa8,0x0b,0x0b,0x03,0x93,0x0b,0x05,0x03,0x7e,0x0b,0xff,0x02,0x69,0x0b,0xf8,0x02,0x55,0x0b,0xf2,0x02,0x40,0x0b,0xec,0x02,0x2b,0x0b,0xe6,0x02,0x17,0x0b,0xdf,0x02,0x02,0x0b,0xd9,0x02,0xee,0x0a,0xd3,0x02,0xd9,0x0a,0xcd,0x02,  \
    0xc5,0x0a,0xc7,0x02,0xb1,0x0a,0xc1,0x02,0x9c,0x0a,0xba,0x02,0x88,0x0a,0xb4,0x02,0x74,0x0a,0xae,0x02,0x60,0x0a,0xa8,0x02,0x4c,0x0a,0xa2,0x02,0x38,0x0a,0x9c,0x02,0x24,0x0a,0x96,0x02,0x10,0x0a,0x90,0x02,0xfc,0x09,0x8a,0x02,0xe8,0x09,0x84,0x02,0xd4,0x09,0x7e,0x02,0xc1,0x09,0x79,0x02,0xad,0x09,0x72,0x02,0x9a,0x09,0x6c,0x02,0x88,0x09,0x65,0x02,0x77,0x09,0x5e,0x02,0x66,0x09,0x57,0x02,0x55,0x09,0x50,0x02,0x44,0x09,0x4a,0x02,0x32,0x09,0x43,0x02,0x21,0x09,  \
    0x3d,0x02,0x10,0x09,0x36,0x02,0xff,0x08,0x2f,0x02,0xee,0x08,0x29,0x02,0xdd,0x08,0x23,0x02,0xcd,0x08,0x1c,0x02,0xbc,0x08,0x16,0x02,0xab,0x08,0x10,0x02,0x9a,0x08,0x09,0x02,0x89,0x08,0x03,0x02,0x78,0x08,0xfd,0x01,0x68,0x08,0xf7,0x01,0x57,0x08,0xf1,0x01,0x46,0x08,0xeb,0x01,0x35,0x08,0xe5,0x01,0x24,0x08,0xe0,0x01,0x14,0x08,0xda,0x01,0x03,0x08,0xd4,0x01,0xf2,0x07,0xcf,0x01,0xe1,0x07,0xc9,0x01,0xd0,0x07,0xc4,0x01,0xbf,0x07,0xbe,0x01,0xae,0x07,0xb9,0x01,  \
    0x9d,0x07,0xb4,0x01,0x8c,0x07,0xae,0x01,0x7c,0x07,0xa9,0x01,0x6b,0x07,0xa4,0x01,0x5a,0x07,0x9f,0x01,0x49,0x07,0x9a,0x01,0x39,0x07,0x95,0x01,0x28,0x07,0x90,0x01,0x17,0x07,0x8b,0x01,0x06,0x07,0x86,0x01,0xf6,0x06,0x81,0x01,0xe5,0x06,0x7c,0x01,0xd4,0x06,0x78,0x01,0xc4,0x06,0x73,0x01,0xb2,0x06,0x6f,0x01,0x9f,0x06,0x6b,0x01,0x8d,0x06,0x67,0x01,0x7c,0x06,0x63,0x01,0x6a,0x06,0x5f,0x01,0x58,0x06,0x5b,0x01,0x46,0x06,0x57,0x01,0x34,0x06,0x53,0x01,0x22,0x06,  \
    0x4f,0x01,0x10,0x06,0x4b,0x01,0xfe,0x05,0x47,0x01,0xec,0x05,0x43,0x01,0xdb,0x05,0x3f,0x01,0xc9,0x05,0x3c,0x01,0xb7,0x05,0x38,0x01,0xa5,0x05,0x34,0x01,0x94,0x05,0x31,0x01,0x82,0x05,0x2d,0x01,0x70,0x05,0x29,0x01,0x5f,0x05,0x26,0x01,0x4d,0x05,0x22,0x01,0x3c,0x05,0x1f,0x01,0x2a,0x05,0x1c,0x01,0x19,0x05,0x18,0x01,0x08,0x05,0x14,0x01,0xf7,0x04,0x11,0x01,0xe7,0x04,0x0e,0x01,0xd6,0x04,0x0a,0x01,0xc5,0x04,0x07,0x01,0xb5,0x04,0x04,0x01,0xa4,0x04,0x00,0x01,  \
    0x94,0x04,0xfd,0x00,0x83,0x04,0xfa,0x00,0x72,0x04,0xf7,0x00,0x62,0x04,0xf4,0x00,0x51,0x04,0xf1,0x00,0x41,0x04,0xee,0x00,0x30,0x04,0xeb,0x00,0x1f,0x04,0xe8,0x00,0x0f,0x04,0xe5,0x00,0xfe,0x03,0xe2,0x00,0xee,0x03,0xe0,0x00,0xdd,0x03,0xdd,0x00,0xcc,0x03,0xda,0x00,0xbc,0x03,0xd8,0x00,0xab,0x03,0xd5,0x00,0x9b,0x03,0xd3,0x00,0x8a,0x03,0xd0,0x00,0x7a,0x03,0xce,0x00,0x69,0x03,0xcb,0x00,0x59,0x03,0xc9,0x00,0x49,0x03,0xc6,0x00,0x3a,0x03,0xc4,0x00,0x2a,0x03,  \
    0xc2,0x00,0x1a,0x03,0xbf,0x00,0x0a,0x03,0xbd,0x00,0xfa,0x02,0xbb,0x00,0xea,0x02,0xb9,0x00,0xda,0x02,0xb7,0x00,0xca,0x02,0xb5,0x00,0xba,0x02,0xb3,0x00,0xaa,0x02,0xb1,0x00,0x99,0x02,0xaf,0x00,0x89,0x02,0xad,0x00,0x79,0x02,0xac,0x00,0x69,0x02,0xaa,0x00,0x59,0x02,0xa8,0x00,0x48,0x02,0xa7,0x00,0x38,0x02,0xa5,0x00,0x28,0x02,0xa4,0x00,0x18,0x02,0xa2,0x00,0x07,0x02,0xa1,0x00,0xf7,0x01,0x9f,0x00,0xe6,0x01,0x9e,0x00,0xd6,0x01,0x9d,0x00,0xc5,0x01,0x9c,0x00,  \
    0xb5,0x01,0x9a,0x00,0xa4,0x01,0x99,0x00,0x93,0x01,0x98,0x00,0x82,0x01,0x97,0x00,0x71,0x01,0x96,0x00,0x60,0x01,0x95,0x00,0x4f,0x01,0x94,0x00,0x3e,0x01,0x94,0x00,0x2d,0x01,0x93,0x00,0x1c,0x01,0x92,0x00,0x0b,0x01,0x91,0x00,0xfa,0x00,0x91,0x00,0xe9,0x00,0x90,0x00,0xd8,0x00,0x8f,0x00,0xc7,0x00,0x8f,0x00,0xb6,0x00,0x8e,0x00,0xa5,0x00,0x8e,0x00,0x94,0x00,0x8d,0x00,0x83,0x00,0x8d,0x00,0x72,0x00,0x8c,0x00,0x61,0x00,0x8c,0x00,0x50,0x00,0x8c,0x00,0x3f,0x00,  \
    0x8b,0x00,0x2e,0x00,0x8b,0x00,0x1d,0x00,0x8b,0x00,0x0c,0x00,0x8b,0x00,0xfb,0xff,0x8b,0x00,0xe9,0xff,0x8b,0x00,0xd8,0xff,0x8b,0x00,0xc7,0xff,0x8b,0x00,0xb6,0xff,0x8b,0x00,0xa5,0xff,0x8b,0x00,0x94,0xff,0x8b,0x00,0x83,0xff,0x8b,0x00,0x72,0xff,0x8b,0x00,0x61,0xff,0x8b,0x00,0x50,0xff,0x8c,0x00,0x3f,0xff,0x8c,0x00,0x2e,0xff,0x8c,0x00,0x1d,0xff,0x8d,0x00,0x0c,0xff,0x8d,0x00,0xfb,0xfe,0x8e,0x00,0xea,0xfe,0x8e,0x00,0xd9,0xfe,0x8f,0x00,0xc8,0xfe,0x8f,0x00,  \
    0xb7,0xfe,0x90,0x00,0xa6,0xfe,0x91,0x00,0x95,0xfe,0x91,0x00,0x84,0xfe,0x92,0x00,0x73,0xfe,0x93,0x00,0x62,0xfe,0x94,0x00,0x51,0xfe,0x94,0x00,0x40,0xfe,0x95,0x00,0x2f,0xfe,0x96,0x00,0x1e,0xfe,0x97,0x00,0x0d,0xfe,0x98,0x00,0xfc,0xfd,0x99,0x00,0xeb,0xfd,0x9a,0x00,0xda,0xfd,0x9b,0x00,0xc9,0xfd,0x9d,0x00,0xb8,0xfd,0x9e,0x00,0xa6,0xfd,0x9f,0x00,0x95,0xfd,0xa0,0x00,0x84,0xfd,0xa1,0x00,0x73,0xfd,0xa3,0x00,0x61,0xfd,0xa4,0x00,0x50,0xfd,0xa6,0x00,0x3f,0xfd,  \
    0xa7,0x00,0x2d,0xfd,0xa8,0x00,0x1c,0xfd,0xaa,0x00,0x0b,0xfd,0xac,0x00,0xf9,0xfc,0xad,0x00,0xe8,0xfc,0xaf,0x00,0xd6,0xfc,0xb0,0x00,0xc5,0xfc,0xb2,0x00,0xb4,0xfc,0xb4,0x00,0xa2,0xfc,0xb6,0x00,0x91,0xfc,0xb7,0x00,0x7f,0xfc,0xb9,0x00,0x6e,0xfc,0xbb,0x00,0x5c,0xfc,0xbd,0x00,0x4b,0xfc,0xbf,0x00,0x39,0xfc,0xc1,0x00,0x28,0xfc,0xc3,0x00,0x16,0xfc,0xc5,0x00,0x05,0xfc,0xc7,0x00,0xf4,0xfb,0xc9,0x00,0xe4,0xfb,0xcc,0x00,0xd3,0xfb,0xce,0x00,0xc2,0xfb,0xd0,0x00,  \
    0xb1,0xfb,0xd3,0x00,0xa0,0xfb,0xd5,0x00,0x90,0xfb,0xd8,0x00,0x7f,0xfb,0xda,0x00,0x6e,0xfb,0xdd,0x00,0x5d,0xfb,0xdf,0x00,0x4c,0xfb,0xe2,0x00,0x3c,0xfb,0xe5,0x00,0x2b,0xfb,0xe8,0x00,0x1a,0xfb,0xea,0x00,0x09,0xfb,0xed,0x00,0xf9,0xfa,0xf0,0x00,0xe8,0xfa,0xf3,0x00,0xd7,0xfa,0xf6,0x00,0xc7,0xfa,0xf9,0x00,0xb6,0xfa,0xfc,0x00,0xa5,0xfa,0xff,0x00,0x95,0xfa,0x02,0x01,0x84,0xfa,0x06,0x01,0x73,0xfa,0x09,0x01,0x63,0xfa,0x0c,0x01,0x52,0xfa,0x0f,0x01,0x40,0xfa,  \
    0x13,0x01,0x2f,0xfa,0x16,0x01,0x1e,0xfa,0x19,0x01,0x0c,0xfa,0x1d,0x01,0xfb,0xf9,0x20,0x01,0xea,0xf9,0x23,0x01,0xd8,0xf9,0x27,0x01,0xc7,0xf9,0x2a,0x01,0xb5,0xf9,0x2e,0x01,0xa4,0xf9,0x32,0x01,0x93,0xf9,0x35,0x01,0x81,0xf9,0x39,0x01,0x70,0xf9,0x3d,0x01,0x5e,0xf9,0x40,0x01,0x4d,0xf9,0x44,0x01,0x3b,0xf9,0x48,0x01,0x2a,0xf9,0x4c,0x01,0x18,0xf9,0x50,0x01,0x07,0xf9,0x54,0x01,0xf6,0xf8,0x58,0x01,0xe4,0xf8,0x5c,0x01,0xd3,0xf8,0x60,0x01,0xc1,0xf8,0x64,0x01,  \
    0xaf,0xf8,0x68,0x01,0x9e,0xf8,0x6d,0x01,0x8d,0xf8,0x71,0x01,0x7c,0xf8,0x76,0x01,0x6b,0xf8,0x7a,0x01,0x5a,0xf8,0x7f,0x01,0x48,0xf8,0x83,0x01,0x37,0xf8,0x88,0x01,0x26,0xf8,0x8c,0x01,0x15,0xf8,0x91,0x01,0x04,0xf8,0x96,0x01,0xf2,0xf7,0x9b,0x01,0xe1,0xf7,0xa0,0x01,0xd0,0xf7,0xa4,0x01,0xbf,0xf7,0xa9,0x01,0xad,0xf7,0xae,0x01,0x9c,0xf7,0xb3,0x01,0x8b,0xf7,0xb8,0x01,0x79,0xf7,0xbd,0x01,0x68,0xf7,0xc3,0x01,0x57,0xf7,0xc8,0x01,0x45,0xf7,0xcd,0x01,0x34,0xf7,  \
    0xd2,0x01,0x23,0xf7,0xd7,0x01,0x11,0xf7,0xdd,0x01,0xff,0xf6,0xe2,0x01,0xed,0xf6,0xe7,0x01,0xda,0xf6,0xec,0x01,0xc8,0xf6,0xf2,0x01,0xb6,0xf6,0xf7,0x01,0xa4,0xf6,0xfc,0x01,0x92,0xf6,0x02,0x02,0x7f,0xf6,0x07,0x02,0x6d,0xf6,0x0c,0x02,0x5b,0xf6,0x12,0x02,0x48,0xf6,0x17,0x02,0x36,0xf6,0x1d,0x02,0x24,0xf6,0x23,0x02,0x11,0xf6,0x28,0x02,0xff,0xf5,0x2e,0x02,0xec,0xf5,0x34,0x02,0xda,0xf5,0x39,0x02,0xc7,0xf5,0x3f,0x02,0xb5,0xf5,0x45,0x02,0xa2,0xf5,0x4b,0x02,  \
    0x8f,0xf5,0x51,0x02,0x7d,0xf5,0x57,0x02,0x6b,0xf5,0x5d,0x02,0x59,0xf5,0x63,0x02,0x46,0xf5,0x6a,0x02,0x34,0xf5,0x70,0x02,0x21,0xf5,0x76,0x02,0x0f,0xf5,0x7c,0x02,0xfc,0xf4,0x83,0x02,0xe9,0xf4,0x89,0x02,0xd7,0xf4,0x8f,0x02,0xc4,0xf4,0x96,0x02,0xb1,0xf4,0x9c,0x02,0x9e,0xf4,0xa3,0x02,0x8c,0xf4,0xa9,0x02,0x79,0xf4,0xb0,0x02,0x66,0xf4,0xb6,0x02,0x53,0xf4,0xbd,0x02,0x3f,0xf4,0xc3,0x02,0x2c,0xf4,0xc9,0x02,0x18,0xf4,0xcf,0x02,0x03,0xf4,0xd5,0x02,0xee,0xf3,  \
    0xdb,0x02,0xd9,0xf3,0xe0,0x02,0xc4,0xf3,0xe6,0x02,0xaf,0xf3,0xec,0x02,0x9a,0xf3,0xf2,0x02,0x85,0xf3,0xf8,0x02,0x70,0xf3,0xfe,0x02,0x5a,0xf3,0x04,0x03,0x45,0xf3,0x09,0x03,0x30,0xf3,0x0f,0x03,0x1a,0xf3,0x15,0x03,0x04,0xf3,0x1b,0x03,0xef,0xf2,0x21,0x03,0xd9,0xf2,0x27,0x03,0xc3,0xf2,0x2d,0x03,0xae,0xf2,0x33,0x03,0x98,0xf2,0x39,0x03,0x83,0xf2,0x40,0x03,0x6f,0xf2,0x47,0x03,0x5a,0xf2,0x4d,0x03,0x45,0xf2,0x54,0x03,0x30,0xf2,0x5a,0x03,0x1b,0xf2,0x61,0x03,  \
    0x06,0xf2,0x68,0x03,0xf0,0xf1,0x6e,0x03,0xdb,0xf1,0x75,0x03,0xc5,0xf1,0x7b,0x03,0xb0,0xf1,0x81,0x03,0x9a,0xf1,0x88,0x03,0x84,0xf1,0x8e,0x03,0x6e,0xf1,0x95,0x03,0x58,0xf1,0x9b,0x03,0x42,0xf1,0xa1,0x03,0x2b,0xf1,0xa7,0x03,0x15,0xf1,0xae,0x03,0xff,0xf0,0xb4,0x03,0xe8,0xf0,0xba,0x03,0xd2,0xf0,0xc1,0x03,0xbb,0xf0,0xc7,0x03,0xa4,0xf0,0xcd,0x03,0x8d,0xf0,0xd3,0x03,0x76,0xf0,0xd9,0x03,0x5f,0xf0,0xdf,0x03,0x47,0xf0,0xe4,0x03,0x30,0xf0,0xea,0x03,0x18,0xf0,  \
    0xf0,0x03,0x00,0xf0,0xf5,0x03,0xe8,0xef,0xfb,0x03,0xd0,0xef,0x00,0x04,0xb7,0xef,0x06,0x04,0x9f,0xef,0x0b,0x04,0x86,0xef,0x10,0x04,0x6d,0xef,0x15,0x04,0x54,0xef,0x1a,0x04,0x3b,0xef,0x1f,0x04,0x22,0xef,0x23,0x04,0x07,0xef,0x27,0x04,0xed,0xee,0x2b,0x04,0xd2,0xee,0x2f,0x04,0xb8,0xee,0x33,0x04,0x9d,0xee,0x37,0x04,0x82,0xee,0x3b,0x04,0x67,0xee,0x3e,0x04,0x4c,0xee,0x42,0x04,0x30,0xee,0x45,0x04,0x14,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xac,0x04,0xa1,0x11,0xa8,0x04,0x85,0x11,0xa4,0x04,0x6a,0x11,0xa0,0x04,0x4e,0x11,0x9c,0x04,0x33,0x11,0x98,0x04,0x18,0x11,0x94,0x04,0xfd,0x10,0x8f,0x04,0xe3,0x10,0x8b,0x04,0xc8,0x10,0x86,0x04,0xae,0x10,  \
    0x82,0x04,0x93,0x10,0x7d,0x04,0x79,0x10,0x78,0x04,0x5f,0x10,0x73,0x04,0x45,0x10,0x6e,0x04,0x2b,0x10,0x69,0x04,0x12,0x10,0x64,0x04,0xf8,0x0f,0x5e,0x04,0xdf,0x0f,0x59,0x04,0xc6,0x0f,0x53,0x04,0xad,0x0f,0x4e,0x04,0x94,0x0f,0x48,0x04,0x7c,0x0f,0x41,0x04,0x64,0x0f,0x3b,0x04,0x4c,0x0f,0x35,0x04,0x34,0x0f,0x2f,0x04,0x1c,0x0f,0x28,0x04,0x04,0x0f,0x22,0x04,0xed,0x0e,0x1b,0x04,0xd5,0x0e,0x15,0x04,0xbe,0x0e,0x0e,0x04,0xa7,0x0e,0x08,0x04,0x90,0x0e,0x01,0x04,  \
    0x79,0x0e,0xfa,0x03,0x62,0x0e,0xf3,0x03,0x4c,0x0e,0xed,0x03,0x35,0x0e,0xe6,0x03,0x1f,0x0e,0xdf,0x03,0x09,0x0e,0xd8,0x03,0xf3,0x0d,0xd1,0x03,0xdd,0x0d,0xc9,0x03,0xc7,0x0d,0xc2,0x03,0xb2,0x0d,0xba,0x03,0x9d,0x0d,0xb2,0x03,0x89,0x0d,0xab,0x03,0x74,0x0d,0xa3,0x03,0x5f,0x0d,0x9b,0x03,0x4b,0x0d,0x93,0x03,0x37,0x0d,0x8c,0x03,0x23,0x0d,0x84,0x03,0x0f,0x0d,0x7c,0x03,0xfb,0x0c,0x74,0x03,0xe7,0x0c,0x6c,0x03,0xd3,0x0c,0x64,0x03,0xc0,0x0c,0x5d,0x03,0xac,0x0c,  \
    0x55,0x03,0x99,0x0c,0x4d,0x03,0x86,0x0c,0x45,0x03,0x72,0x0c,0x3f,0x03,0x5d,0x0c,0x38,0x03,0x47,0x0c,0x32,0x03,0x32,0x0c,0x2c,0x03,0x1c,0x0c,0x25,0x03,0x07,0x0c,0x1f,0x03,0xf2,0x0b,0x19,0x03,0xdd,0x0b,0x12,0x03,0xc8,0x0b,0x0c,0x03,0xb3,0x0b,0x06,0x03,0x9e,0x0b,0xff,0x02,0x89,0x0b,0xf9,0x02,0x74,0x0b,0xf3,0x02,0x5f,0x0b,0xec,0x02,0x4b,0x0b,0xe6,0x02,0x36,0x0b,0xe0,0x02,0x22,0x0b,0xda,0x02,0x0d,0x0b,0xd3,0x02,0xf9,0x0a,0xcd,0x02,0xe4,0x0a,0xc7,0x02,  \
    0xd0,0x0a,0xc1,0x02,0xbb,0x0a,0xbb,0x02,0xa7,0x0a,0xb4,0x02,0x93,0x0a,0xae,0x02,0x7f,0x0a,0xa8,0x02,0x6b,0x0a,0xa2,0x02,0x56,0x0a,0x9c,0x02,0x42,0x0a,0x96,0x02,0x2e,0x0a,0x90,0x02,0x1b,0x0a,0x8a,0x02,0x07,0x0a,0x84,0x02,0xf3,0x09,0x7e,0x02,0xdf,0x09,0x78,0x02,0xcb,0x09,0x72,0x02,0xb8,0x09,0x6c,0x02,0xa4,0x09,0x66,0x02,0x91,0x09,0x5f,0x02,0x7f,0x09,0x59,0x02,0x6e,0x09,0x52,0x02,0x5d,0x09,0x4b,0x02,0x4c,0x09,0x44,0x02,0x3a,0x09,0x3e,0x02,0x29,0x09,  \
    0x37,0x02,0x18,0x09,0x31,0x02,0x07,0x09,0x2a,0x02,0xf6,0x08,0x23,0x02,0xe5,0x08,0x1d,0x02,0xd4,0x08,0x17,0x02,0xc3,0x08,0x10,0x02,0xb2,0x08,0x0a,0x02,0xa2,0x08,0x04,0x02,0x91,0x08,0xfe,0x01,0x80,0x08,0xf7,0x01,0x6f,0x08,0xf1,0x01,0x5f,0x08,0xeb,0x01,0x4e,0x08,0xe5,0x01,0x3d,0x08,0xdf,0x01,0x2c,0x08,0xda,0x01,0x1b,0x08,0xd4,0x01,0x0a,0x08,0xce,0x01,0xf9,0x07,0xc9,0x01,0xe9,0x07,0xc3,0x01,0xd8,0x07,0xbe,0x01,0xc7,0x07,0xb8,0x01,0xb6,0x07,0xb3,0x01,  \
    0xa5,0x07,0xad,0x01,0x94,0x07,0xa8,0x01,0x84,0x07,0xa3,0x01,0x73,0x07,0x9d,0x01,0x62,0x07,0x98,0x01,0x51,0x07,0x93,0x01,0x40,0x07,0x8e,0x01,0x30,0x07,0x89,0x01,0x1f,0x07,0x84,0x01,0x0e,0x07,0x7f,0x01,0xfe,0x06,0x7a,0x01,0xed,0x06,0x75,0x01,0xdc,0x06,0x71,0x01,0xcc,0x06,0x6c,0x01,0xbb,0x06,0x68,0x01,0xa9,0x06,0x63,0x01,0x97,0x06,0x5f,0x01,0x85,0x06,0x5b,0x01,0x73,0x06,0x57,0x01,0x61,0x06,0x53,0x01,0x50,0x06,0x4f,0x01,0x3e,0x06,0x4b,0x01,0x2c,0x06,  \
    0x47,0x01,0x1a,0x06,0x43,0x01,0x08,0x06,0x3f,0x01,0xf7,0x05,0x3b,0x01,0xe5,0x05,0x37,0x01,0xd3,0x05,0x33,0x01,0xc1,0x05,0x30,0x01,0xb0,0x05,0x2c,0x01,0x9e,0x05,0x28,0x01,0x8d,0x05,0x25,0x01,0x7b,0x05,0x21,0x01,0x69,0x05,0x1d,0x01,0x58,0x05,0x1a,0x01,0x46,0x05,0x16,0x01,0x35,0x05,0x13,0x01,0x23,0x05,0x0f,0x01,0x12,0x05,0x0c,0x01,0x01,0x05,0x08,0x01,0xf1,0x04,0x05,0x01,0xe0,0x04,0x01,0x01,0xd0,0x04,0xfe,0x00,0xbf,0x04,0xfb,0x00,0xaf,0x04,0xf7,0x00,  \
    0x9e,0x04,0xf4,0x00,0x8d,0x04,0xf1,0x00,0x7d,0x04,0xee,0x00,0x6c,0x04,0xeb,0x00,0x5c,0x04,0xe8,0x00,0x4b,0x04,0xe5,0x00,0x3b,0x04,0xe2,0x00,0x2a,0x04,0xdf,0x00,0x1a,0x04,0xdc,0x00,0x09,0x04,0xd9,0x00,0xf9,0x03,0xd6,0x00,0xe8,0x03,0xd3,0x00,0xd8,0x03,0xd1,0x00,0xc7,0x03,0xce,0x00,0xb7,0x03,0xcb,0x00,0xa6,0x03,0xc9,0x00,0x96,0x03,0xc6,0x00,0x85,0x03,0xc4,0x00,0x75,0x03,0xc1,0x00,0x64,0x03,0xbf,0x00,0x54,0x03,0xbc,0x00,0x45,0x03,0xba,0x00,0x35,0x03,  \
    0xb8,0x00,0x25,0x03,0xb5,0x00,0x15,0x03,0xb3,0x00,0x05,0x03,0xb1,0x00,0xf5,0x02,0xaf,0x00,0xe5,0x02,0xad,0x00,0xd5,0x02,0xab,0x00,0xc6,0x02,0xa9,0x00,0xb6,0x02,0xa7,0x00,0xa5,0x02,0xa5,0x00,0x95,0x02,0xa3,0x00,0x85,0x02,0xa1,0x00,0x75,0x02,0x9f,0x00,0x65,0x02,0x9e,0x00,0x55,0x02,0x9c,0x00,0x45,0x02,0x9a,0x00,0x35,0x02,0x99,0x00,0x24,0x02,0x97,0x00,0x14,0x02,0x96,0x00,0x04,0x02,0x94,0x00,0xf4,0x01,0x93,0x00,0xe3,0x01,0x92,0x00,0xd3,0x01,0x90,0x00,  \
    0xc2,0x01,0x8f,0x00,0xb2,0x01,0x8e,0x00,0xa1,0x01,0x8d,0x00,0x90,0x01,0x8c,0x00,0x7f,0x01,0x8b,0x00,0x6e,0x01,0x8a,0x00,0x5e,0x01,0x89,0x00,0x4d,0x01,0x88,0x00,0x3c,0x01,0x87,0x00,0x2b,0x01,0x86,0x00,0x1a,0x01,0x86,0x00,0x09,0x01,0x85,0x00,0xf8,0x00,0x84,0x00,0xe7,0x00,0x83,0x00,0xd6,0x00,0x83,0x00,0xc5,0x00,0x82,0x00,0xb4,0x00,0x82,0x00,0xa3,0x00,0x81,0x00,0x92,0x00,0x81,0x00,0x82,0x00,0x80,0x00,0x71,0x00,0x80,0x00,0x60,0x00,0x7f,0x00,0x4f,0x00,  \
    0x7f,0x00,0x3e,0x00,0x7f,0x00,0x2d,0x00,0x7f,0x00,0x1c,0x00,0x7e,0x00,0x0b,0x00,0x7e,0x00,0xfa,0xff,0x7e,0x00,0xe9,0xff,0x7e,0x00,0xd8,0xff,0x7e,0x00,0xc7,0xff,0x7e,0x00,0xb7,0xff,0x7e,0x00,0xa6,0xff,0x7e,0x00,0x95,0xff,0x7e,0x00,0x84,0xff,0x7e,0x00,0x73,0xff,0x7f,0x00,0x62,0xff,0x7f,0x00,0x51,0xff,0x7f,0x00,0x40,0xff,0x80,0x00,0x2f,0xff,0x80,0x00,0x1e,0xff,0x80,0x00,0x0d,0xff,0x81,0x00,0xfc,0xfe,0x81,0x00,0xec,0xfe,0x82,0x00,0xdb,0xfe,0x82,0x00,  \
    0xca,0xfe,0x83,0x00,0xb9,0xfe,0x83,0x00,0xa8,0xfe,0x84,0x00,0x97,0xfe,0x85,0x00,0x86,0xfe,0x86,0x00,0x75,0xfe,0x86,0x00,0x64,0xfe,0x87,0x00,0x53,0xfe,0x88,0x00,0x43,0xfe,0x89,0x00,0x32,0xfe,0x8a,0x00,0x21,0xfe,0x8b,0x00,0x10,0xfe,0x8c,0x00,0xff,0xfd,0x8d,0x00,0xee,0xfd,0x8e,0x00,0xdd,0xfd,0x8f,0x00,0xcc,0xfd,0x90,0x00,0xbb,0xfd,0x91,0x00,0xa9,0xfd,0x93,0x00,0x98,0xfd,0x94,0x00,0x87,0xfd,0x95,0x00,0x76,0xfd,0x96,0x00,0x65,0xfd,0x98,0x00,0x54,0xfd,  \
    0x99,0x00,0x42,0xfd,0x9b,0x00,0x31,0xfd,0x9c,0x00,0x20,0xfd,0x9e,0x00,0x0f,0xfd,0x9f,0x00,0xfd,0xfc,0xa1,0x00,0xec,0xfc,0xa2,0x00,0xdb,0xfc,0xa4,0x00,0xc9,0xfc,0xa6,0x00,0xb8,0xfc,0xa8,0x00,0xa7,0xfc,0xa9,0x00,0x95,0xfc,0xab,0x00,0x84,0xfc,0xad,0x00,0x73,0xfc,0xaf,0x00,0x61,0xfc,0xb1,0x00,0x50,0xfc,0xb3,0x00,0x3e,0xfc,0xb5,0x00,0x2d,0xfc,0xb7,0x00,0x1c,0xfc,0xb9,0x00,0x0b,0xfc,0xbb,0x00,0xfa,0xfb,0xbd,0x00,0xe9,0xfb,0xc0,0x00,0xd9,0xfb,0xc2,0x00,  \
    0xc8,0xfb,0xc4,0x00,0xb7,0xfb,0xc7,0x00,0xa6,0xfb,0xc9,0x00,0x96,0xfb,0xcc,0x00,0x85,0xfb,0xce,0x00,0x74,0xfb,0xd1,0x00,0x64,0xfb,0xd4,0x00,0x53,0xfb,0xd6,0x00,0x42,0xfb,0xd9,0x00,0x32,0xfb,0xdc,0x00,0x21,0xfb,0xdf,0x00,0x10,0xfb,0xe1,0x00,0x00,0xfb,0xe4,0x00,0xef,0xfa,0xe7,0x00,0xde,0xfa,0xea,0x00,0xce,0xfa,0xed,0x00,0xbd,0xfa,0xf0,0x00,0xac,0xfa,0xf4,0x00,0x9c,0xfa,0xf7,0x00,0x8b,0xfa,0xfa,0x00,0x7b,0xfa,0xfd,0x00,0x6a,0xfa,0x00,0x01,0x59,0xfa,  \
    0x04,0x01,0x48,0xfa,0x07,0x01,0x37,0xfa,0x0a,0x01,0x25,0xfa,0x0e,0x01,0x14,0xfa,0x11,0x01,0x03,0xfa,0x14,0x01,0xf2,0xf9,0x18,0x01,0xe0,0xf9,0x1b,0x01,0xcf,0xf9,0x1f,0x01,0xbe,0xf9,0x23,0x01,0xac,0xf9,0x26,0x01,0x9b,0xf9,0x2a,0x01,0x8a,0xf9,0x2e,0x01,0x78,0xf9,0x31,0x01,0x67,0xf9,0x35,0x01,0x56,0xf9,0x39,0x01,0x44,0xf9,0x3d,0x01,0x33,0xf9,0x41,0x01,0x22,0xf9,0x45,0x01,0x10,0xf9,0x49,0x01,0xff,0xf8,0x4d,0x01,0xed,0xf8,0x51,0x01,0xdc,0xf8,0x55,0x01,  \
    0xca,0xf8,0x59,0x01,0xb9,0xf8,0x5d,0x01,0xa8,0xf8,0x62,0x01,0x97,0xf8,0x66,0x01,0x86,0xf8,0x6b,0x01,0x74,0xf8,0x6f,0x01,0x63,0xf8,0x74,0x01,0x52,0xf8,0x78,0x01,0x41,0xf8,0x7d,0x01,0x30,0xf8,0x81,0x01,0x1f,0xf8,0x86,0x01,0x0e,0xf8,0x8b,0x01,0xfc,0xf7,0x90,0x01,0xeb,0xf7,0x95,0x01,0xda,0xf7,0x9a,0x01,0xc9,0xf7,0x9e,0x01,0xb8,0xf7,0xa3,0x01,0xa6,0xf7,0xa8,0x01,0x95,0xf7,0xae,0x01,0x84,0xf7,0xb3,0x01,0x73,0xf7,0xb8,0x01,0x61,0xf7,0xbd,0x01,0x50,0xf7,  \
    0xc2,0x01,0x3f,0xf7,0xc8,0x01,0x2d,0xf7,0xcd,0x01,0x1b,0xf7,0xd2,0x01,0x09,0xf7,0xd7,0x01,0xf7,0xf6,0xdc,0x01,0xe5,0xf6,0xe2,0x01,0xd3,0xf6,0xe7,0x01,0xc1,0xf6,0xec,0x01,0xaf,0xf6,0xf2,0x01,0x9d,0xf6,0xf7,0x01,0x8a,0xf6,0xfd,0x01,0x78,0xf6,0x02,0x02,0x66,0xf6,0x08,0x02,0x54,0xf6,0x0d,0x02,0x41,0xf6,0x13,0x02,0x2f,0xf6,0x18,0x02,0x1d,0xf6,0x1e,0x02,0x0a,0xf6,0x24,0x02,0xf8,0xf5,0x29,0x02,0xe5,0xf5,0x2f,0x02,0xd3,0xf5,0x35,0x02,0xc0,0xf5,0x3b,0x02,  \
    0xad,0xf5,0x41,0x02,0x9b,0xf5,0x47,0x02,0x89,0xf5,0x4d,0x02,0x76,0xf5,0x53,0x02,0x64,0xf5,0x59,0x02,0x52,0xf5,0x5f,0x02,0x3f,0xf5,0x66,0x02,0x2d,0xf5,0x6c,0x02,0x1a,0xf5,0x72,0x02,0x08,0xf5,0x79,0x02,0xf5,0xf4,0x7f,0x02,0xe3,0xf4,0x85,0x02,0xd0,0xf4,0x8c,0x02,0xbd,0xf4,0x92,0x02,0xaa,0xf4,0x99,0x02,0x97,0xf4,0x9f,0x02,0x84,0xf4,0xa6,0x02,0x71,0xf4,0xac,0x02,0x5e,0xf4,0xb3,0x02,0x4b,0xf4,0xb9,0x02,0x38,0xf4,0xbf,0x02,0x23,0xf4,0xc5,0x02,0x0f,0xf4,  \
    0xcb,0x02,0xfa,0xf3,0xd1,0x02,0xe5,0xf3,0xd7,0x02,0xd0,0xf3,0xdc,0x02,0xbb,0xf3,0xe2,0x02,0xa6,0xf3,0xe8,0x02,0x91,0xf3,0xee,0x02,0x7c,0xf3,0xf4,0x02,0x66,0xf3,0xfa,0x02,0x51,0xf3,0x00,0x03,0x3c,0xf3,0x06,0x03,0x26,0xf3,0x0c,0x03,0x11,0xf3,0x11,0x03,0xfb,0xf2,0x17,0x03,0xe6,0xf2,0x1d,0x03,0xd0,0xf2,0x23,0x03,0xba,0xf2,0x29,0x03,0xa4,0xf2,0x30,0x03,0x90,0xf2,0x36,0x03,0x7b,0xf2,0x3d,0x03,0x66,0xf2,0x44,0x03,0x51,0xf2,0x4a,0x03,0x3c,0xf2,0x51,0x03,  \
    0x27,0xf2,0x57,0x03,0x12,0xf2,0x5e,0x03,0xfd,0xf1,0x64,0x03,0xe7,0xf1,0x6b,0x03,0xd2,0xf1,0x71,0x03,0xbc,0xf1,0x78,0x03,0xa6,0xf1,0x7e,0x03,0x90,0xf1,0x85,0x03,0x7a,0xf1,0x8b,0x03,0x64,0xf1,0x91,0x03,0x4e,0xf1,0x98,0x03,0x38,0xf1,0x9e,0x03,0x21,0xf1,0xa4,0x03,0x0b,0xf1,0xaa,0x03,0xf4,0xf0,0xb1,0x03,0xde,0xf0,0xb7,0x03,0xc7,0xf0,0xbd,0x03,0xb0,0xf0,0xc3,0x03,0x99,0xf0,0xc9,0x03,0x82,0xf0,0xcf,0x03,0x6a,0xf0,0xd5,0x03,0x53,0xf0,0xdb,0x03,0x3b,0xf0,  \
    0xe0,0x03,0x23,0xf0,0xe6,0x03,0x0c,0xf0,0xec,0x03,0xf3,0xef,0xf1,0x03,0xdb,0xef,0xf7,0x03,0xc3,0xef,0xfc,0x03,0xaa,0xef,0x01,0x04,0x92,0xef,0x06,0x04,0x79,0xef,0x0b,0x04,0x60,0xef,0x10,0x04,0x47,0xef,0x15,0x04,0x2d,0xef,0x19,0x04,0x13,0xef,0x1d,0x04,0xf8,0xee,0x21,0x04,0xde,0xee,0x25,0x04,0xc3,0xee,0x29,0x04,0xa8,0xee,0x2d,0x04,0x8d,0xee,0x31,0x04,0x72,0xee,0x34,0x04,0x57,0xee,0x38,0x04,0x3b,0xee,0x3b,0x04,0x20,0xee,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x9d,0x04,0x99,0x11,0x99,0x04,0x7d,0x11,0x96,0x04,0x62,0x11,0x92,0x04,0x47,0x11,0x8e,0x04,0x2b,0x11,0x89,0x04,0x10,0x11,0x85,0x04,0xf6,0x10,0x81,0x04,0xdb,0x10,0x7c,0x04,0xc0,0x10,  \
    0x78,0x04,0xa6,0x10,0x73,0x04,0x8b,0x10,0x6e,0x04,0x71,0x10,0x6a,0x04,0x57,0x10,0x65,0x04,0x3d,0x10,0x60,0x04,0x23,0x10,0x5b,0x04,0x0a,0x10,0x55,0x04,0xf0,0x0f,0x50,0x04,0xd7,0x0f,0x4b,0x04,0xbe,0x0f,0x45,0x04,0xa5,0x0f,0x40,0x04,0x8c,0x0f,0x3a,0x04,0x74,0x0f,0x34,0x04,0x5b,0x0f,0x2d,0x04,0x43,0x0f,0x27,0x04,0x2b,0x0f,0x21,0x04,0x14,0x0f,0x1b,0x04,0xfc,0x0e,0x14,0x04,0xe4,0x0e,0x0e,0x04,0xcd,0x0e,0x07,0x04,0xb6,0x0e,0x01,0x04,0x9e,0x0e,0xfa,0x03,  \
    0x87,0x0e,0xf4,0x03,0x71,0x0e,0xed,0x03,0x5a,0x0e,0xe6,0x03,0x43,0x0e,0xdf,0x03,0x2d,0x0e,0xd8,0x03,0x16,0x0e,0xd2,0x03,0x00,0x0e,0xcb,0x03,0xea,0x0d,0xc4,0x03,0xd4,0x0d,0xbc,0x03,0xbe,0x0d,0xb5,0x03,0xa9,0x0d,0xad,0x03,0x94,0x0d,0xa6,0x03,0x7f,0x0d,0x9e,0x03,0x6b,0x0d,0x96,0x03,0x56,0x0d,0x8f,0x03,0x42,0x0d,0x87,0x03,0x2d,0x0d,0x7f,0x03,0x19,0x0d,0x77,0x03,0x05,0x0d,0x70,0x03,0xf1,0x0c,0x68,0x03,0xdd,0x0c,0x60,0x03,0xca,0x0c,0x58,0x03,0xb6,0x0c,  \
    0x50,0x03,0xa2,0x0c,0x49,0x03,0x8f,0x0c,0x41,0x03,0x7c,0x0c,0x39,0x03,0x68,0x0c,0x33,0x03,0x53,0x0c,0x2c,0x03,0x3d,0x0c,0x26,0x03,0x28,0x0c,0x20,0x03,0x12,0x0c,0x19,0x03,0xfd,0x0b,0x13,0x03,0xe8,0x0b,0x0d,0x03,0xd3,0x0b,0x06,0x03,0xbe,0x0b,0x00,0x03,0xa9,0x0b,0xfa,0x02,0x94,0x0b,0xf3,0x02,0x7f,0x0b,0xed,0x02,0x6a,0x0b,0xe7,0x02,0x56,0x0b,0xe0,0x02,0x41,0x0b,0xda,0x02,0x2c,0x0b,0xd4,0x02,0x18,0x0b,0xce,0x02,0x03,0x0b,0xc7,0x02,0xef,0x0a,0xc1,0x02,  \
    0xda,0x0a,0xbb,0x02,0xc6,0x0a,0xb5,0x02,0xb2,0x0a,0xaf,0x02,0x9d,0x0a,0xa9,0x02,0x89,0x0a,0xa2,0x02,0x75,0x0a,0x9c,0x02,0x61,0x0a,0x96,0x02,0x4d,0x0a,0x90,0x02,0x39,0x0a,0x8a,0x02,0x25,0x0a,0x84,0x02,0x11,0x0a,0x7e,0x02,0xfd,0x09,0x78,0x02,0xe9,0x09,0x72,0x02,0xd6,0x09,0x6c,0x02,0xc2,0x09,0x66,0x02,0xae,0x09,0x61,0x02,0x9b,0x09,0x5a,0x02,0x87,0x09,0x54,0x02,0x76,0x09,0x4d,0x02,0x65,0x09,0x46,0x02,0x54,0x09,0x3f,0x02,0x42,0x09,0x39,0x02,0x31,0x09,  \
    0x32,0x02,0x20,0x09,0x2b,0x02,0x0f,0x09,0x25,0x02,0xfe,0x08,0x1e,0x02,0xed,0x08,0x18,0x02,0xdc,0x08,0x11,0x02,0xcb,0x08,0x0b,0x02,0xba,0x08,0x05,0x02,0xa9,0x08,0xfe,0x01,0x98,0x08,0xf8,0x01,0x88,0x08,0xf2,0x01,0x77,0x08,0xec,0x01,0x66,0x08,0xe6,0x01,0x55,0x08,0xe0,0x01,0x45,0x08,0xda,0x01,0x34,0x08,0xd4,0x01,0x23,0x08,0xce,0x01,0x12,0x08,0xc8,0x01,0x01,0x08,0xc3,0x01,0xf0,0x07,0xbd,0x01,0xdf,0x07,0xb8,0x01,0xcf,0x07,0xb2,0x01,0xbe,0x07,0xad,0x01,  \
    0xad,0x07,0xa7,0x01,0x9c,0x07,0xa2,0x01,0x8b,0x07,0x9c,0x01,0x7b,0x07,0x97,0x01,0x6a,0x07,0x92,0x01,0x59,0x07,0x8d,0x01,0x48,0x07,0x88,0x01,0x38,0x07,0x83,0x01,0x27,0x07,0x7e,0x01,0x16,0x07,0x79,0x01,0x06,0x07,0x74,0x01,0xf5,0x06,0x6f,0x01,0xe4,0x06,0x6a,0x01,0xd4,0x06,0x65,0x01,0xc3,0x06,0x60,0x01,0xb3,0x06,0x5c,0x01,0xa1,0x06,0x58,0x01,0x8f,0x06,0x54,0x01,0x7d,0x06,0x4f,0x01,0x6b,0x06,0x4b,0x01,0x59,0x06,0x47,0x01,0x47,0x06,0x43,0x01,0x36,0x06,  \
    0x3f,0x01,0x24,0x06,0x3b,0x01,0x12,0x06,0x37,0x01,0x01,0x06,0x33,0x01,0xef,0x05,0x2f,0x01,0xdd,0x05,0x2c,0x01,0xcc,0x05,0x28,0x01,0xba,0x05,0x24,0x01,0xa8,0x05,0x20,0x01,0x97,0x05,0x1d,0x01,0x85,0x05,0x19,0x01,0x74,0x05,0x15,0x01,0x62,0x05,0x12,0x01,0x51,0x05,0x0e,0x01,0x3f,0x05,0x0b,0x01,0x2e,0x05,0x07,0x01,0x1c,0x05,0x04,0x01,0x0b,0x05,0x00,0x01,0xfb,0x04,0xfd,0x00,0xea,0x04,0xf9,0x00,0xda,0x04,0xf6,0x00,0xc9,0x04,0xf2,0x00,0xb9,0x04,0xef,0x00,  \
    0xa8,0x04,0xec,0x00,0x98,0x04,0xe8,0x00,0x87,0x04,0xe5,0x00,0x77,0x04,0xe2,0x00,0x66,0x04,0xdf,0x00,0x56,0x04,0xdc,0x00,0x45,0x04,0xd9,0x00,0x35,0x04,0xd6,0x00,0x24,0x04,0xd3,0x00,0x14,0x04,0xd0,0x00,0x04,0x04,0xcd,0x00,0xf3,0x03,0xca,0x00,0xe3,0x03,0xc7,0x00,0xd2,0x03,0xc5,0x00,0xc2,0x03,0xc2,0x00,0xb1,0x03,0xbf,0x00,0xa1,0x03,0xbd,0x00,0x90,0x03,0xba,0x00,0x80,0x03,0xb8,0x00,0x70,0x03,0xb5,0x00,0x5f,0x03,0xb3,0x00,0x50,0x03,0xb0,0x00,0x40,0x03,  \
    0xae,0x00,0x30,0x03,0xac,0x00,0x20,0x03,0xa9,0x00,0x11,0x03,0xa7,0x00,0x01,0x03,0xa5,0x00,0xf1,0x02,0xa3,0x00,0xe1,0x02,0xa1,0x00,0xd1,0x02,0x9f,0x00,0xc1,0x02,0x9d,0x00,0xb1,0x02,0x9b,0x00,0xa1,0x02,0x99,0x00,0x91,0x02,0x97,0x00,0x81,0x02,0x95,0x00,0x71,0x02,0x93,0x00,0x61,0x02,0x92,0x00,0x51,0x02,0x90,0x00,0x41,0x02,0x8e,0x00,0x31,0x02,0x8d,0x00,0x21,0x02,0x8b,0x00,0x11,0x02,0x8a,0x00,0x01,0x02,0x88,0x00,0xf0,0x01,0x87,0x00,0xe0,0x01,0x86,0x00,  \
    0xd0,0x01,0x84,0x00,0xbf,0x01,0x83,0x00,0xaf,0x01,0x82,0x00,0x9e,0x01,0x81,0x00,0x8e,0x01,0x80,0x00,0x7d,0x01,0x7f,0x00,0x6c,0x01,0x7e,0x00,0x5b,0x01,0x7d,0x00,0x4a,0x01,0x7c,0x00,0x39,0x01,0x7b,0x00,0x29,0x01,0x7a,0x00,0x18,0x01,0x79,0x00,0x07,0x01,0x79,0x00,0xf6,0x00,0x78,0x00,0xe5,0x00,0x77,0x00,0xd5,0x00,0x77,0x00,0xc4,0x00,0x76,0x00,0xb3,0x00,0x75,0x00,0xa2,0x00,0x75,0x00,0x91,0x00,0x75,0x00,0x80,0x00,0x74,0x00,0x70,0x00,0x74,0x00,0x5f,0x00,  \
    0x73,0x00,0x4e,0x00,0x73,0x00,0x3d,0x00,0x73,0x00,0x2c,0x00,0x73,0x00,0x1b,0x00,0x72,0x00,0x0b,0x00,0x72,0x00,0xfa,0xff,0x72,0x00,0xe9,0xff,0x72,0x00,0xd8,0xff,0x72,0x00,0xc7,0xff,0x72,0x00,0xb7,0xff,0x72,0x00,0xa6,0xff,0x72,0x00,0x95,0xff,0x72,0x00,0x84,0xff,0x72,0x00,0x73,0xff,0x73,0x00,0x62,0xff,0x73,0x00,0x52,0xff,0x73,0x00,0x41,0xff,0x73,0x00,0x30,0xff,0x74,0x00,0x1f,0xff,0x74,0x00,0x0e,0xff,0x75,0x00,0xfe,0xfe,0x75,0x00,0xed,0xfe,0x76,0x00,  \
    0xdc,0xfe,0x76,0x00,0xcb,0xfe,0x77,0x00,0xba,0xfe,0x77,0x00,0xaa,0xfe,0x78,0x00,0x99,0xfe,0x79,0x00,0x88,0xfe,0x79,0x00,0x77,0xfe,0x7a,0x00,0x66,0xfe,0x7b,0x00,0x56,0xfe,0x7c,0x00,0x45,0xfe,0x7d,0x00,0x34,0xfe,0x7e,0x00,0x23,0xfe,0x7f,0x00,0x12,0xfe,0x80,0x00,0x02,0xfe,0x81,0x00,0xf1,0xfd,0x82,0x00,0xe0,0xfd,0x83,0x00,0xcf,0xfd,0x84,0x00,0xbe,0xfd,0x85,0x00,0xad,0xfd,0x87,0x00,0x9c,0xfd,0x88,0x00,0x8a,0xfd,0x89,0x00,0x79,0xfd,0x8b,0x00,0x68,0xfd,  \
    0x8c,0x00,0x57,0xfd,0x8d,0x00,0x46,0xfd,0x8f,0x00,0x35,0xfd,0x90,0x00,0x24,0xfd,0x92,0x00,0x13,0xfd,0x93,0x00,0x01,0xfd,0x95,0x00,0xf0,0xfc,0x97,0x00,0xdf,0xfc,0x98,0x00,0xce,0xfc,0x9a,0x00,0xbd,0xfc,0x9c,0x00,0xab,0xfc,0x9d,0x00,0x9a,0xfc,0x9f,0x00,0x89,0xfc,0xa1,0x00,0x78,0xfc,0xa3,0x00,0x66,0xfc,0xa5,0x00,0x55,0xfc,0xa7,0x00,0x44,0xfc,0xa9,0x00,0x32,0xfc,0xab,0x00,0x21,0xfc,0xad,0x00,0x10,0xfc,0xaf,0x00,0x00,0xfc,0xb2,0x00,0xef,0xfb,0xb4,0x00,  \
    0xde,0xfb,0xb6,0x00,0xce,0xfb,0xb9,0x00,0xbd,0xfb,0xbb,0x00,0xac,0xfb,0xbe,0x00,0x9c,0xfb,0xc0,0x00,0x8b,0xfb,0xc3,0x00,0x7b,0xfb,0xc5,0x00,0x6a,0xfb,0xc8,0x00,0x59,0xfb,0xcb,0x00,0x49,0xfb,0xcd,0x00,0x38,0xfb,0xd0,0x00,0x28,0xfb,0xd3,0x00,0x17,0xfb,0xd6,0x00,0x06,0xfb,0xd9,0x00,0xf6,0xfa,0xdc,0x00,0xe5,0xfa,0xdf,0x00,0xd5,0xfa,0xe2,0x00,0xc4,0xfa,0xe5,0x00,0xb4,0xfa,0xe8,0x00,0xa3,0xfa,0xeb,0x00,0x93,0xfa,0xef,0x00,0x82,0xfa,0xf2,0x00,0x72,0xfa,  \
    0xf5,0x00,0x61,0xfa,0xf8,0x00,0x50,0xfa,0xfc,0x00,0x3e,0xfa,0xff,0x00,0x2d,0xfa,0x02,0x01,0x1c,0xfa,0x06,0x01,0x0b,0xfa,0x09,0x01,0xfa,0xf9,0x0d,0x01,0xe8,0xf9,0x10,0x01,0xd7,0xf9,0x14,0x01,0xc6,0xf9,0x17,0x01,0xb5,0xf9,0x1b,0x01,0xa4,0xf9,0x1f,0x01,0x92,0xf9,0x22,0x01,0x81,0xf9,0x26,0x01,0x70,0xf9,0x2a,0x01,0x5e,0xf9,0x2e,0x01,0x4d,0xf9,0x32,0x01,0x3c,0xf9,0x36,0x01,0x2b,0xf9,0x3a,0x01,0x19,0xf9,0x3e,0x01,0x08,0xf9,0x42,0x01,0xf6,0xf8,0x46,0x01,  \
    0xe5,0xf8,0x4a,0x01,0xd4,0xf8,0x4e,0x01,0xc2,0xf8,0x52,0x01,0xb1,0xf8,0x57,0x01,0xa0,0xf8,0x5b,0x01,0x8f,0xf8,0x60,0x01,0x7e,0xf8,0x64,0x01,0x6d,0xf8,0x69,0x01,0x5c,0xf8,0x6d,0x01,0x4b,0xf8,0x72,0x01,0x3a,0xf8,0x77,0x01,0x29,0xf8,0x7b,0x01,0x18,0xf8,0x80,0x01,0x07,0xf8,0x85,0x01,0xf5,0xf7,0x8a,0x01,0xe4,0xf7,0x8f,0x01,0xd3,0xf7,0x94,0x01,0xc2,0xf7,0x99,0x01,0xb1,0xf7,0x9e,0x01,0x9f,0xf7,0xa3,0x01,0x8e,0xf7,0xa8,0x01,0x7d,0xf7,0xad,0x01,0x6c,0xf7,  \
    0xb2,0x01,0x5a,0xf7,0xb8,0x01,0x49,0xf7,0xbd,0x01,0x38,0xf7,0xc2,0x01,0x26,0xf7,0xc7,0x01,0x14,0xf7,0xcd,0x01,0x02,0xf7,0xd2,0x01,0xf0,0xf6,0xd7,0x01,0xde,0xf6,0xdd,0x01,0xcc,0xf6,0xe2,0x01,0xba,0xf6,0xe7,0x01,0xa8,0xf6,0xed,0x01,0x95,0xf6,0xf2,0x01,0x83,0xf6,0xf8,0x01,0x71,0xf6,0xfd,0x01,0x5f,0xf6,0x03,0x02,0x4c,0xf6,0x08,0x02,0x3a,0xf6,0x0e,0x02,0x28,0xf6,0x14,0x02,0x15,0xf6,0x19,0x02,0x03,0xf6,0x1f,0x02,0xf1,0xf5,0x25,0x02,0xde,0xf5,0x2b,0x02,  \
    0xcb,0xf5,0x31,0x02,0xb9,0xf5,0x37,0x02,0xa6,0xf5,0x3d,0x02,0x94,0xf5,0x43,0x02,0x82,0xf5,0x49,0x02,0x70,0xf5,0x4f,0x02,0x5d,0xf5,0x55,0x02,0x4b,0xf5,0x5c,0x02,0x38,0xf5,0x62,0x02,0x26,0xf5,0x68,0x02,0x13,0xf5,0x6e,0x02,0x01,0xf5,0x75,0x02,0xee,0xf4,0x7b,0x02,0xdb,0xf4,0x82,0x02,0xc9,0xf4,0x88,0x02,0xb6,0xf4,0x8f,0x02,0xa3,0xf4,0x95,0x02,0x90,0xf4,0x9c,0x02,0x7d,0xf4,0xa2,0x02,0x6a,0xf4,0xa9,0x02,0x57,0xf4,0xaf,0x02,0x44,0xf4,0xb5,0x02,0x2f,0xf4,  \
    0xbb,0x02,0x1a,0xf4,0xc1,0x02,0x06,0xf4,0xc7,0x02,0xf1,0xf3,0xcd,0x02,0xdc,0xf3,0xd3,0x02,0xc7,0xf3,0xd8,0x02,0xb2,0xf3,0xde,0x02,0x9d,0xf3,0xe4,0x02,0x88,0xf3,0xea,0x02,0x72,0xf3,0xf0,0x02,0x5d,0xf3,0xf6,0x02,0x48,0xf3,0xfc,0x02,0x32,0xf3,0x02,0x03,0x1d,0xf3,0x08,0x03,0x07,0xf3,0x0e,0x03,0xf2,0xf2,0x13,0x03,0xdc,0xf2,0x19,0x03,0xc6,0xf2,0x1f,0x03,0xb1,0xf2,0x26,0x03,0x9c,0xf2,0x2d,0x03,0x87,0xf2,0x33,0x03,0x72,0xf2,0x3a,0x03,0x5d,0xf2,0x41,0x03,  \
    0x48,0xf2,0x47,0x03,0x33,0xf2,0x4e,0x03,0x1e,0xf2,0x54,0x03,0x09,0xf2,0x5b,0x03,0xf3,0xf1,0x61,0x03,0xde,0xf1,0x68,0x03,0xc8,0xf1,0x6e,0x03,0xb2,0xf1,0x74,0x03,0x9c,0xf1,0x7b,0x03,0x86,0xf1,0x81,0x03,0x70,0xf1,0x87,0x03,0x5a,0xf1,0x8e,0x03,0x43,0xf1,0x94,0x03,0x2d,0xf1,0x9a,0x03,0x16,0xf1,0xa0,0x03,0x00,0xf1,0xa7,0x03,0xe9,0xf0,0xad,0x03,0xd2,0xf0,0xb3,0x03,0xbb,0xf0,0xb9,0x03,0xa4,0xf0,0xbf,0x03,0x8d,0xf0,0xc5,0x03,0x76,0xf0,0xcb,0x03,0x5e,0xf0,  \
    0xd1,0x03,0x47,0xf0,0xd6,0x03,0x2f,0xf0,0xdc,0x03,0x17,0xf0,0xe1,0x03,0xff,0xef,0xe7,0x03,0xe7,0xef,0xec,0x03,0xce,0xef,0xf2,0x03,0xb6,0xef,0xf7,0x03,0x9d,0xef,0xfc,0x03,0x84,0xef,0x01,0x04,0x6b,0xef,0x06,0x04,0x52,0xef,0x0b,0x04,0x38,0xef,0x0f,0x04,0x1e,0xef,0x13,0x04,0x03,0xef,0x17,0x04,0xe9,0xee,0x1b,0x04,0xce,0xee,0x1f,0x04,0xb3,0xee,0x23,0x04,0x98,0xee,0x26,0x04,0x7d,0xee,0x2a,0x04,0x62,0xee,0x2d,0x04,0x46,0xee,0x31,0x04,0x2b,0xee,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x8f,0x04,0x91,0x11,0x8c,0x04,0x75,0x11,0x88,0x04,0x5a,0x11,0x84,0x04,0x3f,0x11,0x80,0x04,0x23,0x11,0x7c,0x04,0x08,0x11,0x78,0x04,0xed,0x10,0x73,0x04,0xd3,0x10,  \
    0x6f,0x04,0xb8,0x10,0x6a,0x04,0x9e,0x10,0x66,0x04,0x83,0x10,0x61,0x04,0x69,0x10,0x5c,0x04,0x4f,0x10,0x57,0x04,0x35,0x10,0x52,0x04,0x1b,0x10,0x4d,0x04,0x02,0x10,0x48,0x04,0xe8,0x0f,0x43,0x04,0xcf,0x0f,0x3d,0x04,0xb5,0x0f,0x38,0x04,0x9c,0x0f,0x32,0x04,0x83,0x0f,0x2c,0x04,0x6b,0x0f,0x26,0x04,0x53,0x0f,0x20,0x04,0x3b,0x0f,0x1a,0x04,0x23,0x0f,0x14,0x04,0x0b,0x0f,0x0e,0x04,0xf3,0x0e,0x07,0x04,0xdc,0x0e,0x01,0x04,0xc4,0x0e,0xfb,0x03,0xad,0x0e,0xf4,0x03,  \
    0x96,0x0e,0xed,0x03,0x7f,0x0e,0xe7,0x03,0x68,0x0e,0xe0,0x03,0x51,0x0e,0xd9,0x03,0x3a,0x0e,0xd3,0x03,0x24,0x0e,0xcc,0x03,0x0d,0x0e,0xc5,0x03,0xf7,0x0d,0xbe,0x03,0xe1,0x0d,0xb7,0x03,0xca,0x0d,0xb0,0x03,0xb5,0x0d,0xa9,0x03,0xa0,0x0d,0xa1,0x03,0x8b,0x0d,0x99,0x03,0x76,0x0d,0x92,0x03,0x61,0x0d,0x8a,0x03,0x4d,0x0d,0x83,0x03,0x38,0x0d,0x7b,0x03,0x24,0x0d,0x73,0x03,0x0f,0x0d,0x6c,0x03,0xfb,0x0c,0x64,0x03,0xe7,0x0c,0x5c,0x03,0xd3,0x0c,0x54,0x03,0xc0,0x0c,  \
    0x4d,0x03,0xac,0x0c,0x45,0x03,0x98,0x0c,0x3d,0x03,0x85,0x0c,0x35,0x03,0x71,0x0c,0x2e,0x03,0x5e,0x0c,0x27,0x03,0x48,0x0c,0x21,0x03,0x33,0x0c,0x1b,0x03,0x1e,0x0c,0x14,0x03,0x08,0x0c,0x0e,0x03,0xf3,0x0b,0x08,0x03,0xde,0x0b,0x01,0x03,0xc9,0x0b,0xfb,0x02,0xb4,0x0b,0xf5,0x02,0x9f,0x0b,0xee,0x02,0x8a,0x0b,0xe8,0x02,0x75,0x0b,0xe2,0x02,0x60,0x0b,0xdb,0x02,0x4c,0x0b,0xd5,0x02,0x37,0x0b,0xcf,0x02,0x22,0x0b,0xc9,0x02,0x0e,0x0b,0xc2,0x02,0xf9,0x0a,0xbc,0x02,  \
    0xe5,0x0a,0xb6,0x02,0xd1,0x0a,0xb0,0x02,0xbc,0x0a,0xaa,0x02,0xa8,0x0a,0xa3,0x02,0x94,0x0a,0x9d,0x02,0x80,0x0a,0x97,0x02,0x6b,0x0a,0x91,0x02,0x57,0x0a,0x8b,0x02,0x43,0x0a,0x85,0x02,0x2f,0x0a,0x7f,0x02,0x1b,0x0a,0x79,0x02,0x08,0x0a,0x73,0x02,0xf4,0x09,0x6d,0x02,0xe0,0x09,0x67,0x02,0xcc,0x09,0x61,0x02,0xb9,0x09,0x5b,0x02,0xa5,0x09,0x55,0x02,0x91,0x09,0x4f,0x02,0x7e,0x09,0x48,0x02,0x6d,0x09,0x41,0x02,0x5c,0x09,0x3b,0x02,0x4a,0x09,0x34,0x02,0x39,0x09,  \
    0x2d,0x02,0x28,0x09,0x27,0x02,0x17,0x09,0x20,0x02,0x06,0x09,0x1a,0x02,0xf5,0x08,0x13,0x02,0xe4,0x08,0x0d,0x02,0xd3,0x08,0x06,0x02,0xc2,0x08,0x00,0x02,0xb1,0x08,0xfa,0x01,0xa0,0x08,0xf3,0x01,0x8f,0x08,0xed,0x01,0x7e,0x08,0xe7,0x01,0x6d,0x08,0xe1,0x01,0x5d,0x08,0xdb,0x01,0x4c,0x08,0xd5,0x01,0x3b,0x08,0xcf,0x01,0x2b,0x08,0xc9,0x01,0x1a,0x08,0xc3,0x01,0x09,0x08,0xbd,0x01,0xf8,0x07,0xb8,0x01,0xe7,0x07,0xb2,0x01,0xd6,0x07,0xad,0x01,0xc5,0x07,0xa7,0x01,  \
    0xb5,0x07,0xa2,0x01,0xa4,0x07,0x9c,0x01,0x93,0x07,0x97,0x01,0x82,0x07,0x91,0x01,0x72,0x07,0x8c,0x01,0x61,0x07,0x87,0x01,0x50,0x07,0x82,0x01,0x3f,0x07,0x7d,0x01,0x2f,0x07,0x78,0x01,0x1e,0x07,0x73,0x01,0x0d,0x07,0x6e,0x01,0xfd,0x06,0x69,0x01,0xec,0x06,0x64,0x01,0xdc,0x06,0x5f,0x01,0xcb,0x06,0x5a,0x01,0xba,0x06,0x55,0x01,0xaa,0x06,0x51,0x01,0x98,0x06,0x4d,0x01,0x86,0x06,0x49,0x01,0x74,0x06,0x44,0x01,0x63,0x06,0x40,0x01,0x51,0x06,0x3c,0x01,0x3f,0x06,  \
    0x38,0x01,0x2e,0x06,0x34,0x01,0x1c,0x06,0x30,0x01,0x0a,0x06,0x2c,0x01,0xf9,0x05,0x28,0x01,0xe7,0x05,0x24,0x01,0xd5,0x05,0x20,0x01,0xc4,0x05,0x1c,0x01,0xb2,0x05,0x19,0x01,0xa1,0x05,0x15,0x01,0x8f,0x05,0x11,0x01,0x7e,0x05,0x0e,0x01,0x6c,0x05,0x0a,0x01,0x5b,0x05,0x06,0x01,0x4a,0x05,0x03,0x01,0x38,0x05,0xff,0x00,0x27,0x05,0xfc,0x00,0x16,0x05,0xf8,0x00,0x04,0x05,0xf5,0x00,0xf4,0x04,0xf1,0x00,0xe4,0x04,0xee,0x00,0xd3,0x04,0xea,0x00,0xc3,0x04,0xe7,0x00,  \
    0xb2,0x04,0xe3,0x00,0xa2,0x04,0xe0,0x00,0x91,0x04,0xdd,0x00,0x81,0x04,0xda,0x00,0x71,0x04,0xd6,0x00,0x60,0x04,0xd3,0x00,0x50,0x04,0xd0,0x00,0x3f,0x04,0xcd,0x00,0x2f,0x04,0xca,0x00,0x1f,0x04,0xc7,0x00,0x0e,0x04,0xc4,0x00,0xfe,0x03,0xc2,0x00,0xee,0x03,0xbf,0x00,0xdd,0x03,0xbc,0x00,0xcd,0x03,0xb9,0x00,0xbc,0x03,0xb7,0x00,0xac,0x03,0xb4,0x00,0x9c,0x03,0xb1,0x00,0x8b,0x03,0xaf,0x00,0x7b,0x03,0xac,0x00,0x6b,0x03,0xaa,0x00,0x5a,0x03,0xa7,0x00,0x4b,0x03,  \
    0xa5,0x00,0x3b,0x03,0xa2,0x00,0x2b,0x03,0xa0,0x00,0x1c,0x03,0x9e,0x00,0x0c,0x03,0x9b,0x00,0xfc,0x02,0x99,0x00,0xec,0x02,0x97,0x00,0xdd,0x02,0x95,0x00,0xcd,0x02,0x93,0x00,0xbd,0x02,0x91,0x00,0xad,0x02,0x8f,0x00,0x9d,0x02,0x8d,0x00,0x8d,0x02,0x8b,0x00,0x7e,0x02,0x89,0x00,0x6e,0x02,0x88,0x00,0x5e,0x02,0x86,0x00,0x4e,0x02,0x84,0x00,0x3e,0x02,0x83,0x00,0x2e,0x02,0x81,0x00,0x1d,0x02,0x80,0x00,0x0d,0x02,0x7e,0x00,0xfd,0x01,0x7d,0x00,0xed,0x01,0x7b,0x00,  \
    0xdd,0x01,0x7a,0x00,0xcd,0x01,0x79,0x00,0xbd,0x01,0x77,0x00,0xac,0x01,0x76,0x00,0x9c,0x01,0x75,0x00,0x8b,0x01,0x74,0x00,0x7a,0x01,0x73,0x00,0x69,0x01,0x72,0x00,0x59,0x01,0x71,0x00,0x48,0x01,0x70,0x00,0x37,0x01,0x6f,0x00,0x27,0x01,0x6e,0x00,0x16,0x01,0x6e,0x00,0x05,0x01,0x6d,0x00,0xf4,0x00,0x6c,0x00,0xe4,0x00,0x6c,0x00,0xd3,0x00,0x6b,0x00,0xc2,0x00,0x6a,0x00,0xb1,0x00,0x6a,0x00,0xa1,0x00,0x69,0x00,0x90,0x00,0x69,0x00,0x7f,0x00,0x68,0x00,0x6f,0x00,  \
    0x68,0x00,0x5e,0x00,0x68,0x00,0x4d,0x00,0x67,0x00,0x3c,0x00,0x67,0x00,0x2c,0x00,0x67,0x00,0x1b,0x00,0x67,0x00,0x0a,0x00,0x66,0x00,0xfa,0xff,0x66,0x00,0xe9,0xff,0x66,0x00,0xd8,0xff,0x66,0x00,0xc7,0xff,0x66,0x00,0xb7,0xff,0x66,0x00,0xa6,0xff,0x66,0x00,0x95,0xff,0x66,0x00,0x84,0xff,0x67,0x00,0x74,0xff,0x67,0x00,0x63,0xff,0x67,0x00,0x52,0xff,0x67,0x00,0x42,0xff,0x68,0x00,0x31,0xff,0x68,0x00,0x20,0xff,0x68,0x00,0x0f,0xff,0x69,0x00,0xff,0xfe,0x69,0x00,  \
    0xee,0xfe,0x6a,0x00,0xdd,0xfe,0x6a,0x00,0xcd,0xfe,0x6b,0x00,0xbc,0xfe,0x6c,0x00,0xab,0xfe,0x6c,0x00,0x9b,0xfe,0x6d,0x00,0x8a,0xfe,0x6e,0x00,0x79,0xfe,0x6e,0x00,0x68,0xfe,0x6f,0x00,0x58,0xfe,0x70,0x00,0x47,0xfe,0x71,0x00,0x36,0xfe,0x72,0x00,0x26,0xfe,0x73,0x00,0x15,0xfe,0x74,0x00,0x04,0xfe,0x75,0x00,0xf3,0xfd,0x76,0x00,0xe3,0xfd,0x77,0x00,0xd2,0xfd,0x78,0x00,0xc1,0xfd,0x7a,0x00,0xb0,0xfd,0x7b,0x00,0x9f,0xfd,0x7c,0x00,0x8e,0xfd,0x7d,0x00,0x7d,0xfd,  \
    0x7f,0x00,0x6c,0xfd,0x80,0x00,0x5b,0xfd,0x82,0x00,0x4a,0xfd,0x83,0x00,0x39,0xfd,0x85,0x00,0x28,0xfd,0x86,0x00,0x17,0xfd,0x88,0x00,0x06,0xfd,0x89,0x00,0xf4,0xfc,0x8b,0x00,0xe3,0xfc,0x8d,0x00,0xd2,0xfc,0x8e,0x00,0xc1,0xfc,0x90,0x00,0xb0,0xfc,0x92,0x00,0x9f,0xfc,0x94,0x00,0x8e,0xfc,0x96,0x00,0x7d,0xfc,0x98,0x00,0x6b,0xfc,0x99,0x00,0x5a,0xfc,0x9b,0x00,0x49,0xfc,0x9d,0x00,0x38,0xfc,0xa0,0x00,0x26,0xfc,0xa2,0x00,0x16,0xfc,0xa4,0x00,0x05,0xfc,0xa6,0x00,  \
    0xf5,0xfb,0xa8,0x00,0xe4,0xfb,0xab,0x00,0xd4,0xfb,0xad,0x00,0xc3,0xfb,0xb0,0x00,0xb2,0xfb,0xb2,0x00,0xa2,0xfb,0xb5,0x00,0x91,0xfb,0xb7,0x00,0x81,0xfb,0xba,0x00,0x70,0xfb,0xbd,0x00,0x60,0xfb,0xbf,0x00,0x4f,0xfb,0xc2,0x00,0x3f,0xfb,0xc5,0x00,0x2e,0xfb,0xc8,0x00,0x1e,0xfb,0xcb,0x00,0x0d,0xfb,0xcd,0x00,0xfd,0xfa,0xd0,0x00,0xec,0xfa,0xd3,0x00,0xdc,0xfa,0xd7,0x00,0xcb,0xfa,0xda,0x00,0xbb,0xfa,0xdd,0x00,0xaa,0xfa,0xe0,0x00,0x9a,0xfa,0xe3,0x00,0x8a,0xfa,  \
    0xe7,0x00,0x79,0xfa,0xea,0x00,0x68,0xfa,0xed,0x00,0x57,0xfa,0xf0,0x00,0x46,0xfa,0xf4,0x00,0x35,0xfa,0xf7,0x00,0x24,0xfa,0xfb,0x00,0x13,0xfa,0xfe,0x00,0x02,0xfa,0x02,0x01,0xf1,0xf9,0x05,0x01,0xdf,0xf9,0x09,0x01,0xce,0xf9,0x0c,0x01,0xbd,0xf9,0x10,0x01,0xac,0xf9,0x14,0x01,0x9b,0xf9,0x17,0x01,0x8a,0xf9,0x1b,0x01,0x78,0xf9,0x1f,0x01,0x67,0xf9,0x23,0x01,0x56,0xf9,0x27,0x01,0x45,0xf9,0x2b,0x01,0x33,0xf9,0x2f,0x01,0x22,0xf9,0x33,0x01,0x11,0xf9,0x37,0x01,  \
    0x00,0xf9,0x3b,0x01,0xee,0xf8,0x3f,0x01,0xdd,0xf8,0x43,0x01,0xcc,0xf8,0x48,0x01,0xbb,0xf8,0x4c,0x01,0xaa,0xf8,0x50,0x01,0x99,0xf8,0x55,0x01,0x88,0xf8,0x59,0x01,0x77,0xf8,0x5e,0x01,0x66,0xf8,0x63,0x01,0x55,0xf8,0x67,0x01,0x44,0xf8,0x6c,0x01,0x33,0xf8,0x71,0x01,0x22,0xf8,0x75,0x01,0x10,0xf8,0x7a,0x01,0xff,0xf7,0x7f,0x01,0xee,0xf7,0x84,0x01,0xdd,0xf7,0x89,0x01,0xcc,0xf7,0x8e,0x01,0xbb,0xf7,0x93,0x01,0xaa,0xf7,0x98,0x01,0x98,0xf7,0x9d,0x01,0x87,0xf7,  \
    0xa3,0x01,0x76,0xf7,0xa8,0x01,0x65,0xf7,0xad,0x01,0x53,0xf7,0xb2,0x01,0x42,0xf7,0xb8,0x01,0x30,0xf7,0xbd,0x01,0x1e,0xf7,0xc2,0x01,0x0c,0xf7,0xc7,0x01,0xfb,0xf6,0xcd,0x01,0xe9,0xf6,0xd2,0x01,0xd6,0xf6,0xd7,0x01,0xc4,0xf6,0xdd,0x01,0xb2,0xf6,0xe2,0x01,0xa0,0xf6,0xe8,0x01,0x8e,0xf6,0xed,0x01,0x7c,0xf6,0xf3,0x01,0x6a,0xf6,0xf8,0x01,0x57,0xf6,0xfe,0x01,0x45,0xf6,0x03,0x02,0x33,0xf6,0x09,0x02,0x20,0xf6,0x0f,0x02,0x0e,0xf6,0x15,0x02,0xfc,0xf5,0x1a,0x02,  \
    0xe9,0xf5,0x20,0x02,0xd7,0xf5,0x26,0x02,0xc4,0xf5,0x2c,0x02,0xb2,0xf5,0x32,0x02,0x9f,0xf5,0x38,0x02,0x8d,0xf5,0x3e,0x02,0x7b,0xf5,0x45,0x02,0x68,0xf5,0x4b,0x02,0x56,0xf5,0x51,0x02,0x44,0xf5,0x57,0x02,0x31,0xf5,0x5e,0x02,0x1f,0xf5,0x64,0x02,0x0c,0xf5,0x6a,0x02,0xf9,0xf4,0x71,0x02,0xe7,0xf4,0x77,0x02,0xd4,0xf4,0x7d,0x02,0xc1,0xf4,0x84,0x02,0xae,0xf4,0x8a,0x02,0x9b,0xf4,0x91,0x02,0x88,0xf4,0x97,0x02,0x75,0xf4,0x9e,0x02,0x62,0xf4,0xa4,0x02,0x4f,0xf4,  \
    0xaa,0x02,0x3a,0xf4,0xb0,0x02,0x26,0xf4,0xb6,0x02,0x11,0xf4,0xbc,0x02,0xfc,0xf3,0xc2,0x02,0xe7,0xf3,0xc8,0x02,0xd2,0xf3,0xce,0x02,0xbd,0xf3,0xd4,0x02,0xa8,0xf3,0xda,0x02,0x93,0xf3,0xdf,0x02,0x7e,0xf3,0xe5,0x02,0x69,0xf3,0xeb,0x02,0x53,0xf3,0xf1,0x02,0x3e,0xf3,0xf7,0x02,0x28,0xf3,0xfd,0x02,0x13,0xf3,0x03,0x03,0xfd,0xf2,0x09,0x03,0xe7,0xf2,0x0f,0x03,0xd2,0xf2,0x15,0x03,0xbc,0xf2,0x1b,0x03,0xa7,0xf2,0x22,0x03,0x93,0xf2,0x29,0x03,0x7e,0xf2,0x2f,0x03,  \
    0x69,0xf2,0x36,0x03,0x54,0xf2,0x3c,0x03,0x3f,0xf2,0x43,0x03,0x29,0xf2,0x49,0x03,0x14,0xf2,0x50,0x03,0xfe,0xf1,0x56,0x03,0xe9,0xf1,0x5d,0x03,0xd3,0xf1,0x63,0x03,0xbd,0xf1,0x69,0x03,0xa7,0xf1,0x70,0x03,0x91,0xf1,0x76,0x03,0x7b,0xf1,0x7c,0x03,0x65,0xf1,0x83,0x03,0x4e,0xf1,0x89,0x03,0x38,0xf1,0x8f,0x03,0x21,0xf1,0x95,0x03,0x0b,0xf1,0x9b,0x03,0xf4,0xf0,0xa1,0x03,0xdd,0xf0,0xa8,0x03,0xc6,0xf0,0xae,0x03,0xaf,0xf0,0xb3,0x03,0x98,0xf0,0xb9,0x03,0x80,0xf0,  \
    0xbf,0x03,0x69,0xf0,0xc5,0x03,0x51,0xf0,0xcb,0x03,0x39,0xf0,0xd0,0x03,0x21,0xf0,0xd6,0x03,0x09,0xf0,0xdb,0x03,0xf1,0xef,0xe1,0x03,0xd8,0xef,0xe6,0x03,0xc0,0xef,0xeb,0x03,0xa7,0xef,0xf0,0x03,0x8e,0xef,0xf5,0x03,0x75,0xef,0xfa,0x03,0x5c,0xef,0xff,0x03,0x42,0xef,0x03,0x04,0x28,0xef,0x07,0x04,0x0d,0xef,0x0b,0x04,0xf3,0xee,0x0f,0x04,0xd8,0xee,0x13,0x04,0xbd,0xee,0x16,0x04,0xa2,0xee,0x1a,0x04,0x87,0xee,0x1e,0x04,0x6c,0xee,0x21,0x04,0x50,0xee,0x24,0x04,  \
    0x35,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x82,0x04,0x89,0x11,0x7e,0x04,0x6e,0x11,0x7a,0x04,0x52,0x11,0x76,0x04,0x37,0x11,0x72,0x04,0x1b,0x11,0x6e,0x04,0x00,0x11,0x6a,0x04,0xe5,0x10,  \
    0x66,0x04,0xcb,0x10,0x61,0x04,0xb0,0x10,0x5d,0x04,0x95,0x10,0x58,0x04,0x7b,0x10,0x54,0x04,0x61,0x10,0x4f,0x04,0x47,0x10,0x4a,0x04,0x2d,0x10,0x45,0x04,0x13,0x10,0x40,0x04,0xf9,0x0f,0x3b,0x04,0xe0,0x0f,0x36,0x04,0xc6,0x0f,0x30,0x04,0xad,0x0f,0x2b,0x04,0x94,0x0f,0x25,0x04,0x7b,0x0f,0x1f,0x04,0x63,0x0f,0x19,0x04,0x4a,0x0f,0x13,0x04,0x32,0x0f,0x0d,0x04,0x1a,0x0f,0x07,0x04,0x02,0x0f,0x01,0x04,0xeb,0x0e,0xfb,0x03,0xd3,0x0e,0xf4,0x03,0xbb,0x0e,0xee,0x03,  \
    0xa4,0x0e,0xe7,0x03,0x8d,0x0e,0xe1,0x03,0x76,0x0e,0xda,0x03,0x5f,0x0e,0xd4,0x03,0x48,0x0e,0xcd,0x03,0x31,0x0e,0xc6,0x03,0x1b,0x0e,0xc0,0x03,0x04,0x0e,0xb9,0x03,0xee,0x0d,0xb2,0x03,0xd7,0x0d,0xab,0x03,0xc1,0x0d,0xa4,0x03,0xac,0x0d,0x9c,0x03,0x97,0x0d,0x95,0x03,0x82,0x0d,0x8d,0x03,0x6d,0x0d,0x86,0x03,0x58,0x0d,0x7e,0x03,0x43,0x0d,0x77,0x03,0x2f,0x0d,0x6f,0x03,0x1a,0x0d,0x68,0x03,0x06,0x0d,0x60,0x03,0xf2,0x0c,0x58,0x03,0xde,0x0c,0x51,0x03,0xca,0x0c,  \
    0x49,0x03,0xb6,0x0c,0x41,0x03,0xa2,0x0c,0x3a,0x03,0x8e,0x0c,0x32,0x03,0x7b,0x0c,0x2a,0x03,0x67,0x0c,0x23,0x03,0x54,0x0c,0x1c,0x03,0x3e,0x0c,0x16,0x03,0x29,0x0c,0x10,0x03,0x13,0x0c,0x09,0x03,0xfe,0x0b,0x03,0x03,0xe9,0x0b,0xfd,0x02,0xd4,0x0b,0xf6,0x02,0xbf,0x0b,0xf0,0x02,0xaa,0x0b,0xea,0x02,0x95,0x0b,0xe3,0x02,0x80,0x0b,0xdd,0x02,0x6b,0x0b,0xd7,0x02,0x56,0x0b,0xd0,0x02,0x42,0x0b,0xca,0x02,0x2d,0x0b,0xc4,0x02,0x18,0x0b,0xbd,0x02,0x04,0x0b,0xb7,0x02,  \
    0xef,0x0a,0xb1,0x02,0xdb,0x0a,0xab,0x02,0xc7,0x0a,0xa5,0x02,0xb2,0x0a,0x9e,0x02,0x9e,0x0a,0x98,0x02,0x8a,0x0a,0x92,0x02,0x76,0x0a,0x8c,0x02,0x62,0x0a,0x86,0x02,0x4e,0x0a,0x80,0x02,0x3a,0x0a,0x7a,0x02,0x26,0x0a,0x74,0x02,0x12,0x0a,0x6e,0x02,0xfe,0x09,0x68,0x02,0xea,0x09,0x62,0x02,0xd6,0x09,0x5c,0x02,0xc3,0x09,0x56,0x02,0xaf,0x09,0x50,0x02,0x9c,0x09,0x4a,0x02,0x88,0x09,0x44,0x02,0x75,0x09,0x3d,0x02,0x64,0x09,0x36,0x02,0x52,0x09,0x30,0x02,0x41,0x09,  \
    0x29,0x02,0x30,0x09,0x22,0x02,0x1e,0x09,0x1c,0x02,0x0d,0x09,0x15,0x02,0xfc,0x08,0x0f,0x02,0xeb,0x08,0x08,0x02,0xda,0x08,0x02,0x02,0xc9,0x08,0xfb,0x01,0xb8,0x08,0xf5,0x01,0xa7,0x08,0xef,0x01,0x96,0x08,0xe8,0x01,0x86,0x08,0xe2,0x01,0x75,0x08,0xdc,0x01,0x64,0x08,0xd6,0x01,0x53,0x08,0xd0,0x01,0x43,0x08,0xca,0x01,0x32,0x08,0xc4,0x01,0x21,0x08,0xbe,0x01,0x11,0x08,0xb8,0x01,0x00,0x08,0xb3,0x01,0xef,0x07,0xad,0x01,0xde,0x07,0xa7,0x01,0xcd,0x07,0xa2,0x01,  \
    0xbc,0x07,0x9c,0x01,0xab,0x07,0x97,0x01,0x9b,0x07,0x91,0x01,0x8a,0x07,0x8c,0x01,0x79,0x07,0x87,0x01,0x68,0x07,0x81,0x01,0x58,0x07,0x7c,0x01,0x47,0x07,0x77,0x01,0x36,0x07,0x72,0x01,0x26,0x07,0x6d,0x01,0x15,0x07,0x68,0x01,0x05,0x07,0x63,0x01,0xf4,0x06,0x5e,0x01,0xe3,0x06,0x59,0x01,0xd3,0x06,0x54,0x01,0xc2,0x06,0x4f,0x01,0xb2,0x06,0x4b,0x01,0xa1,0x06,0x46,0x01,0x90,0x06,0x42,0x01,0x7e,0x06,0x3e,0x01,0x6c,0x06,0x3a,0x01,0x5a,0x06,0x35,0x01,0x49,0x06,  \
    0x31,0x01,0x37,0x06,0x2d,0x01,0x25,0x06,0x29,0x01,0x14,0x06,0x25,0x01,0x02,0x06,0x21,0x01,0xf1,0x05,0x1d,0x01,0xdf,0x05,0x19,0x01,0xce,0x05,0x15,0x01,0xbc,0x05,0x12,0x01,0xab,0x05,0x0e,0x01,0x99,0x05,0x0a,0x01,0x88,0x05,0x06,0x01,0x77,0x05,0x03,0x01,0x65,0x05,0xff,0x00,0x54,0x05,0xfb,0x00,0x43,0x05,0xf8,0x00,0x31,0x05,0xf4,0x00,0x20,0x05,0xf1,0x00,0x0f,0x05,0xed,0x00,0xfe,0x04,0xea,0x00,0xed,0x04,0xe6,0x00,0xdd,0x04,0xe3,0x00,0xcd,0x04,0xdf,0x00,  \
    0xbc,0x04,0xdc,0x00,0xac,0x04,0xd8,0x00,0x9b,0x04,0xd5,0x00,0x8b,0x04,0xd2,0x00,0x7b,0x04,0xcf,0x00,0x6a,0x04,0xcb,0x00,0x5a,0x04,0xc8,0x00,0x4a,0x04,0xc5,0x00,0x39,0x04,0xc2,0x00,0x29,0x04,0xbf,0x00,0x19,0x04,0xbc,0x00,0x09,0x04,0xb9,0x00,0xf8,0x03,0xb6,0x00,0xe8,0x03,0xb4,0x00,0xd8,0x03,0xb1,0x00,0xc7,0x03,0xae,0x00,0xb7,0x03,0xab,0x00,0xa7,0x03,0xa9,0x00,0x96,0x03,0xa6,0x00,0x86,0x03,0xa4,0x00,0x76,0x03,0xa1,0x00,0x66,0x03,0x9f,0x00,0x56,0x03,  \
    0x9c,0x00,0x46,0x03,0x9a,0x00,0x36,0x03,0x97,0x00,0x27,0x03,0x95,0x00,0x17,0x03,0x92,0x00,0x07,0x03,0x90,0x00,0xf8,0x02,0x8e,0x00,0xe8,0x02,0x8c,0x00,0xd8,0x02,0x8a,0x00,0xc9,0x02,0x88,0x00,0xb9,0x02,0x86,0x00,0xa9,0x02,0x84,0x00,0x99,0x02,0x82,0x00,0x89,0x02,0x80,0x00,0x7a,0x02,0x7e,0x00,0x6a,0x02,0x7c,0x00,0x5a,0x02,0x7b,0x00,0x4a,0x02,0x79,0x00,0x3a,0x02,0x77,0x00,0x2a,0x02,0x76,0x00,0x1a,0x02,0x74,0x00,0x0a,0x02,0x73,0x00,0xfa,0x01,0x71,0x00,  \
    0xea,0x01,0x70,0x00,0xda,0x01,0x6f,0x00,0xca,0x01,0x6d,0x00,0xba,0x01,0x6c,0x00,0xa9,0x01,0x6b,0x00,0x99,0x01,0x6a,0x00,0x88,0x01,0x69,0x00,0x78,0x01,0x68,0x00,0x67,0x01,0x67,0x00,0x56,0x01,0x66,0x00,0x46,0x01,0x65,0x00,0x35,0x01,0x64,0x00,0x24,0x01,0x63,0x00,0x14,0x01,0x62,0x00,0x03,0x01,0x61,0x00,0xf3,0x00,0x61,0x00,0xe2,0x00,0x60,0x00,0xd1,0x00,0x5f,0x00,0xc1,0x00,0x5f,0x00,0xb0,0x00,0x5e,0x00,0x9f,0x00,0x5e,0x00,0x8f,0x00,0x5d,0x00,0x7e,0x00,  \
    0x5d,0x00,0x6e,0x00,0x5c,0x00,0x5d,0x00,0x5c,0x00,0x4c,0x00,0x5c,0x00,0x3c,0x00,0x5b,0x00,0x2b,0x00,0x5b,0x00,0x1a,0x00,0x5b,0x00,0x0a,0x00,0x5b,0x00,0xf9,0xff,0x5b,0x00,0xe9,0xff,0x5b,0x00,0xd8,0xff,0x5b,0x00,0xc7,0xff,0x5b,0x00,0xb7,0xff,0x5b,0x00,0xa6,0xff,0x5b,0x00,0x95,0xff,0x5b,0x00,0x85,0xff,0x5b,0x00,0x74,0xff,0x5b,0x00,0x64,0xff,0x5c,0x00,0x53,0xff,0x5c,0x00,0x42,0xff,0x5c,0x00,0x32,0xff,0x5d,0x00,0x21,0xff,0x5d,0x00,0x11,0xff,0x5d,0x00,  \
    0x00,0xff,0x5e,0x00,0xef,0xfe,0x5e,0x00,0xdf,0xfe,0x5f,0x00,0xce,0xfe,0x5f,0x00,0xbe,0xfe,0x60,0x00,0xad,0xfe,0x61,0x00,0x9c,0xfe,0x62,0x00,0x8c,0xfe,0x62,0x00,0x7b,0xfe,0x63,0x00,0x6b,0xfe,0x64,0x00,0x5a,0xfe,0x65,0x00,0x49,0xfe,0x66,0x00,0x39,0xfe,0x67,0x00,0x28,0xfe,0x68,0x00,0x18,0xfe,0x69,0x00,0x07,0xfe,0x6a,0x00,0xf6,0xfd,0x6b,0x00,0xe5,0xfd,0x6c,0x00,0xd5,0xfd,0x6d,0x00,0xc4,0xfd,0x6e,0x00,0xb3,0xfd,0x70,0x00,0xa2,0xfd,0x71,0x00,0x91,0xfd,  \
    0x72,0x00,0x80,0xfd,0x73,0x00,0x6f,0xfd,0x75,0x00,0x5e,0xfd,0x76,0x00,0x4e,0xfd,0x78,0x00,0x3d,0xfd,0x79,0x00,0x2c,0xfd,0x7b,0x00,0x1b,0xfd,0x7c,0x00,0x0a,0xfd,0x7e,0x00,0xf9,0xfc,0x80,0x00,0xe8,0xfc,0x81,0x00,0xd7,0xfc,0x83,0x00,0xc6,0xfc,0x85,0x00,0xb5,0xfc,0x87,0x00,0xa4,0xfc,0x89,0x00,0x93,0xfc,0x8a,0x00,0x81,0xfc,0x8c,0x00,0x70,0xfc,0x8e,0x00,0x5f,0xfc,0x90,0x00,0x4e,0xfc,0x92,0x00,0x3d,0xfc,0x94,0x00,0x2c,0xfc,0x97,0x00,0x1b,0xfc,0x99,0x00,  \
    0x0b,0xfc,0x9b,0x00,0xfa,0xfb,0x9d,0x00,0xea,0xfb,0xa0,0x00,0xd9,0xfb,0xa2,0x00,0xc9,0xfb,0xa5,0x00,0xb9,0xfb,0xa7,0x00,0xa8,0xfb,0xaa,0x00,0x98,0xfb,0xac,0x00,0x87,0xfb,0xaf,0x00,0x77,0xfb,0xb2,0x00,0x66,0xfb,0xb4,0x00,0x56,0xfb,0xb7,0x00,0x45,0xfb,0xba,0x00,0x35,0xfb,0xbd,0x00,0x25,0xfb,0xc0,0x00,0x14,0xfb,0xc2,0x00,0x04,0xfb,0xc5,0x00,0xf3,0xfa,0xc9,0x00,0xe3,0xfa,0xcc,0x00,0xd3,0xfa,0xcf,0x00,0xc2,0xfa,0xd2,0x00,0xb2,0xfa,0xd5,0x00,0xa1,0xfa,  \
    0xd8,0x00,0x91,0xfa,0xdc,0x00,0x81,0xfa,0xdf,0x00,0x70,0xfa,0xe2,0x00,0x5f,0xfa,0xe6,0x00,0x4e,0xfa,0xe9,0x00,0x3d,0xfa,0xec,0x00,0x2c,0xfa,0xf0,0x00,0x1b,0xfa,0xf3,0x00,0x0a,0xfa,0xf7,0x00,0xf9,0xf9,0xfa,0x00,0xe8,0xf9,0xfe,0x00,0xd7,0xf9,0x01,0x01,0xc5,0xf9,0x05,0x01,0xb4,0xf9,0x09,0x01,0xa3,0xf9,0x0d,0x01,0x92,0xf9,0x10,0x01,0x81,0xf9,0x14,0x01,0x70,0xf9,0x18,0x01,0x5f,0xf9,0x1c,0x01,0x4e,0xf9,0x20,0x01,0x3c,0xf9,0x24,0x01,0x2b,0xf9,0x28,0x01,  \
    0x1a,0xf9,0x2c,0x01,0x09,0xf9,0x30,0x01,0xf8,0xf8,0x34,0x01,0xe6,0xf8,0x39,0x01,0xd5,0xf8,0x3d,0x01,0xc4,0xf8,0x41,0x01,0xb3,0xf8,0x46,0x01,0xa2,0xf8,0x4a,0x01,0x91,0xf8,0x4f,0x01,0x80,0xf8,0x53,0x01,0x6f,0xf8,0x58,0x01,0x5e,0xf8,0x5d,0x01,0x4d,0xf8,0x61,0x01,0x3c,0xf8,0x66,0x01,0x2b,0xf8,0x6b,0x01,0x1a,0xf8,0x70,0x01,0x09,0xf8,0x75,0x01,0xf8,0xf7,0x7a,0x01,0xe7,0xf7,0x7f,0x01,0xd6,0xf7,0x84,0x01,0xc5,0xf7,0x89,0x01,0xb4,0xf7,0x8e,0x01,0xa3,0xf7,  \
    0x93,0x01,0x91,0xf7,0x98,0x01,0x80,0xf7,0x9d,0x01,0x6f,0xf7,0xa3,0x01,0x5e,0xf7,0xa8,0x01,0x4c,0xf7,0xad,0x01,0x3b,0xf7,0xb2,0x01,0x29,0xf7,0xb8,0x01,0x17,0xf7,0xbd,0x01,0x05,0xf7,0xc2,0x01,0xf3,0xf6,0xc7,0x01,0xe1,0xf6,0xcd,0x01,0xcf,0xf6,0xd2,0x01,0xbd,0xf6,0xd8,0x01,0xab,0xf6,0xdd,0x01,0x99,0xf6,0xe3,0x01,0x87,0xf6,0xe8,0x01,0x74,0xf6,0xee,0x01,0x62,0xf6,0xf3,0x01,0x50,0xf6,0xf9,0x01,0x3e,0xf6,0xff,0x01,0x2b,0xf6,0x05,0x02,0x19,0xf6,0x0a,0x02,  \
    0x07,0xf6,0x10,0x02,0xf4,0xf5,0x16,0x02,0xe2,0xf5,0x1c,0x02,0xcf,0xf5,0x22,0x02,0xbd,0xf5,0x28,0x02,0xaa,0xf5,0x2e,0x02,0x98,0xf5,0x34,0x02,0x86,0xf5,0x3a,0x02,0x74,0xf5,0x40,0x02,0x61,0xf5,0x47,0x02,0x4f,0xf5,0x4d,0x02,0x3c,0xf5,0x53,0x02,0x2a,0xf5,0x59,0x02,0x17,0xf5,0x60,0x02,0x04,0xf5,0x66,0x02,0xf2,0xf4,0x6d,0x02,0xdf,0xf4,0x73,0x02,0xcc,0xf4,0x79,0x02,0xb9,0xf4,0x80,0x02,0xa6,0xf4,0x86,0x02,0x93,0xf4,0x8d,0x02,0x80,0xf4,0x93,0x02,0x6d,0xf4,  \
    0x9a,0x02,0x5a,0xf4,0xa0,0x02,0x45,0xf4,0xa6,0x02,0x31,0xf4,0xac,0x02,0x1c,0xf4,0xb2,0x02,0x07,0xf4,0xb7,0x02,0xf2,0xf3,0xbd,0x02,0xde,0xf3,0xc3,0x02,0xc9,0xf3,0xc9,0x02,0xb3,0xf3,0xcf,0x02,0x9e,0xf3,0xd5,0x02,0x89,0xf3,0xdb,0x02,0x74,0xf3,0xe1,0x02,0x5f,0xf3,0xe7,0x02,0x49,0xf3,0xed,0x02,0x34,0xf3,0xf3,0x02,0x1e,0xf3,0xf8,0x02,0x09,0xf3,0xfe,0x02,0xf3,0xf2,0x04,0x03,0xdd,0xf2,0x0a,0x03,0xc8,0xf2,0x11,0x03,0xb3,0xf2,0x17,0x03,0x9e,0xf2,0x1e,0x03,  \
    0x89,0xf2,0x25,0x03,0x74,0xf2,0x2b,0x03,0x5f,0xf2,0x32,0x03,0x4a,0xf2,0x38,0x03,0x35,0xf2,0x3f,0x03,0x1f,0xf2,0x45,0x03,0x0a,0xf2,0x4b,0x03,0xf4,0xf1,0x52,0x03,0xde,0xf1,0x58,0x03,0xc8,0xf1,0x5f,0x03,0xb2,0xf1,0x65,0x03,0x9c,0xf1,0x6b,0x03,0x86,0xf1,0x71,0x03,0x70,0xf1,0x77,0x03,0x59,0xf1,0x7e,0x03,0x43,0xf1,0x84,0x03,0x2c,0xf1,0x8a,0x03,0x15,0xf1,0x90,0x03,0xff,0xf0,0x96,0x03,0xe8,0xf0,0x9c,0x03,0xd1,0xf0,0xa2,0x03,0xba,0xf0,0xa8,0x03,0xa2,0xf0,  \
    0xae,0x03,0x8b,0xf0,0xb4,0x03,0x73,0xf0,0xb9,0x03,0x5b,0xf0,0xbf,0x03,0x44,0xf0,0xc5,0x03,0x2c,0xf0,0xca,0x03,0x13,0xf0,0xd0,0x03,0xfb,0xef,0xd5,0x03,0xe3,0xef,0xda,0x03,0xca,0xef,0xdf,0x03,0xb1,0xef,0xe4,0x03,0x98,0xef,0xe9,0x03,0x7f,0xef,0xee,0x03,0x66,0xef,0xf3,0x03,0x4c,0xef,0xf7,0x03,0x32,0xef,0xfb,0x03,0x17,0xef,0xff,0x03,0xfd,0xee,0x03,0x04,0xe2,0xee,0x07,0x04,0xc7,0xee,0x0a,0x04,0xac,0xee,0x0e,0x04,0x91,0xee,0x12,0x04,0x76,0xee,0x15,0x04,  \
    0x5a,0xee,0x18,0x04,0x3e,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x74,0x04,0x81,0x11,0x70,0x04,0x66,0x11,0x6d,0x04,0x4a,0x11,0x69,0x04,0x2f,0x11,0x65,0x04,0x14,0x11,0x61,0x04,0xf8,0x10,  \
    0x5d,0x04,0xdd,0x10,0x58,0x04,0xc3,0x10,0x54,0x04,0xa8,0x10,0x4f,0x04,0x8d,0x10,0x4b,0x04,0x73,0x10,0x46,0x04,0x59,0x10,0x41,0x04,0x3f,0x10,0x3d,0x04,0x25,0x10,0x38,0x04,0x0b,0x10,0x33,0x04,0xf1,0x0f,0x2e,0x04,0xd8,0x0f,0x28,0x04,0xbe,0x0f,0x23,0x04,0xa5,0x0f,0x1e,0x04,0x8c,0x0f,0x18,0x04,0x73,0x0f,0x12,0x04,0x5a,0x0f,0x0d,0x04,0x42,0x0f,0x07,0x04,0x2a,0x0f,0x01,0x04,0x12,0x0f,0xfa,0x03,0xfa,0x0e,0xf4,0x03,0xe2,0x0e,0xee,0x03,0xca,0x0e,0xe8,0x03,  \
    0xb3,0x0e,0xe1,0x03,0x9b,0x0e,0xdb,0x03,0x84,0x0e,0xd4,0x03,0x6d,0x0e,0xce,0x03,0x56,0x0e,0xc7,0x03,0x3f,0x0e,0xc1,0x03,0x28,0x0e,0xba,0x03,0x12,0x0e,0xb3,0x03,0xfb,0x0d,0xad,0x03,0xe5,0x0d,0xa6,0x03,0xce,0x0d,0x9f,0x03,0xb8,0x0d,0x98,0x03,0xa3,0x0d,0x91,0x03,0x8d,0x0d,0x89,0x03,0x78,0x0d,0x82,0x03,0x63,0x0d,0x7a,0x03,0x4e,0x0d,0x73,0x03,0x3a,0x0d,0x6b,0x03,0x25,0x0d,0x64,0x03,0x11,0x0d,0x5c,0x03,0xfc,0x0c,0x54,0x03,0xe8,0x0c,0x4d,0x03,0xd4,0x0c,  \
    0x45,0x03,0xc0,0x0c,0x3e,0x03,0xac,0x0c,0x36,0x03,0x98,0x0c,0x2e,0x03,0x84,0x0c,0x27,0x03,0x71,0x0c,0x1f,0x03,0x5d,0x0c,0x18,0x03,0x4a,0x0c,0x11,0x03,0x34,0x0c,0x0b,0x03,0x1f,0x0c,0x05,0x03,0x09,0x0c,0xfe,0x02,0xf4,0x0b,0xf8,0x02,0xdf,0x0b,0xf2,0x02,0xca,0x0b,0xeb,0x02,0xb5,0x0b,0xe5,0x02,0xa0,0x0b,0xdf,0x02,0x8b,0x0b,0xd8,0x02,0x76,0x0b,0xd2,0x02,0x61,0x0b,0xcc,0x02,0x4c,0x0b,0xc5,0x02,0x38,0x0b,0xbf,0x02,0x23,0x0b,0xb9,0x02,0x0f,0x0b,0xb3,0x02,  \
    0xfa,0x0a,0xac,0x02,0xe6,0x0a,0xa6,0x02,0xd1,0x0a,0xa0,0x02,0xbd,0x0a,0x9a,0x02,0xa9,0x0a,0x94,0x02,0x94,0x0a,0x8d,0x02,0x80,0x0a,0x87,0x02,0x6c,0x0a,0x81,0x02,0x58,0x0a,0x7b,0x02,0x44,0x0a,0x75,0x02,0x30,0x0a,0x6f,0x02,0x1c,0x0a,0x69,0x02,0x08,0x0a,0x63,0x02,0xf4,0x09,0x5d,0x02,0xe1,0x09,0x57,0x02,0xcd,0x09,0x51,0x02,0xb9,0x09,0x4b,0x02,0xa6,0x09,0x45,0x02,0x92,0x09,0x3f,0x02,0x7f,0x09,0x39,0x02,0x6c,0x09,0x32,0x02,0x5a,0x09,0x2c,0x02,0x49,0x09,  \
    0x25,0x02,0x38,0x09,0x1e,0x02,0x26,0x09,0x18,0x02,0x15,0x09,0x11,0x02,0x04,0x09,0x0a,0x02,0xf3,0x08,0x04,0x02,0xe2,0x08,0xfd,0x01,0xd1,0x08,0xf7,0x01,0xc0,0x08,0xf1,0x01,0xaf,0x08,0xea,0x01,0x9e,0x08,0xe4,0x01,0x8d,0x08,0xde,0x01,0x7c,0x08,0xd8,0x01,0x6c,0x08,0xd1,0x01,0x5b,0x08,0xcb,0x01,0x4a,0x08,0xc5,0x01,0x39,0x08,0xbf,0x01,0x29,0x08,0xb9,0x01,0x18,0x08,0xb4,0x01,0x07,0x08,0xae,0x01,0xf6,0x07,0xa8,0x01,0xe5,0x07,0xa2,0x01,0xd5,0x07,0x9d,0x01,  \
    0xc4,0x07,0x97,0x01,0xb3,0x07,0x92,0x01,0xa2,0x07,0x8c,0x01,0x92,0x07,0x87,0x01,0x81,0x07,0x82,0x01,0x70,0x07,0x7c,0x01,0x5f,0x07,0x77,0x01,0x4f,0x07,0x72,0x01,0x3e,0x07,0x6d,0x01,0x2e,0x07,0x67,0x01,0x1d,0x07,0x62,0x01,0x0c,0x07,0x5d,0x01,0xfc,0x06,0x58,0x01,0xeb,0x06,0x53,0x01,0xdb,0x06,0x4e,0x01,0xca,0x06,0x4a,0x01,0xba,0x06,0x45,0x01,0xa9,0x06,0x40,0x01,0x99,0x06,0x3c,0x01,0x87,0x06,0x37,0x01,0x75,0x06,0x33,0x01,0x64,0x06,0x2f,0x01,0x52,0x06,  \
    0x2b,0x01,0x40,0x06,0x27,0x01,0x2f,0x06,0x23,0x01,0x1d,0x06,0x1e,0x01,0x0c,0x06,0x1a,0x01,0xfa,0x05,0x16,0x01,0xe9,0x05,0x13,0x01,0xd7,0x05,0x0f,0x01,0xc6,0x05,0x0b,0x01,0xb5,0x05,0x07,0x01,0xa3,0x05,0x03,0x01,0x92,0x05,0xff,0x00,0x81,0x05,0xfc,0x00,0x6f,0x05,0xf8,0x00,0x5e,0x05,0xf4,0x00,0x4d,0x05,0xf1,0x00,0x3b,0x05,0xed,0x00,0x2a,0x05,0xe9,0x00,0x19,0x05,0xe6,0x00,0x08,0x05,0xe3,0x00,0xf7,0x04,0xdf,0x00,0xe7,0x04,0xdb,0x00,0xd6,0x04,0xd8,0x00,  \
    0xc6,0x04,0xd4,0x00,0xb6,0x04,0xd1,0x00,0xa5,0x04,0xce,0x00,0x95,0x04,0xca,0x00,0x85,0x04,0xc7,0x00,0x74,0x04,0xc4,0x00,0x64,0x04,0xc1,0x00,0x54,0x04,0xbd,0x00,0x44,0x04,0xba,0x00,0x33,0x04,0xb7,0x00,0x23,0x04,0xb4,0x00,0x13,0x04,0xb1,0x00,0x03,0x04,0xae,0x00,0xf3,0x03,0xab,0x00,0xe2,0x03,0xa9,0x00,0xd2,0x03,0xa6,0x00,0xc2,0x03,0xa3,0x00,0xb2,0x03,0xa0,0x00,0xa1,0x03,0x9e,0x00,0x91,0x03,0x9b,0x00,0x81,0x03,0x99,0x00,0x71,0x03,0x96,0x00,0x61,0x03,  \
    0x94,0x00,0x51,0x03,0x91,0x00,0x41,0x03,0x8f,0x00,0x32,0x03,0x8c,0x00,0x22,0x03,0x8a,0x00,0x12,0x03,0x88,0x00,0x03,0x03,0x85,0x00,0xf3,0x02,0x83,0x00,0xe4,0x02,0x81,0x00,0xd4,0x02,0x7f,0x00,0xc4,0x02,0x7d,0x00,0xb5,0x02,0x7b,0x00,0xa5,0x02,0x79,0x00,0x95,0x02,0x77,0x00,0x85,0x02,0x75,0x00,0x76,0x02,0x73,0x00,0x66,0x02,0x71,0x00,0x56,0x02,0x70,0x00,0x46,0x02,0x6e,0x00,0x36,0x02,0x6c,0x00,0x26,0x02,0x6b,0x00,0x17,0x02,0x69,0x00,0x07,0x02,0x68,0x00,  \
    0xf7,0x01,0x66,0x00,0xe7,0x01,0x65,0x00,0xd7,0x01,0x64,0x00,0xc7,0x01,0x62,0x00,0xb7,0x01,0x61,0x00,0xa6,0x01,0x60,0x00,0x96,0x01,0x5f,0x00,0x85,0x01,0x5e,0x00,0x75,0x01,0x5d,0x00,0x64,0x01,0x5c,0x00,0x54,0x01,0x5b,0x00,0x43,0x01,0x5a,0x00,0x33,0x01,0x59,0x00,0x22,0x01,0x58,0x00,0x12,0x01,0x57,0x00,0x01,0x01,0x56,0x00,0xf1,0x00,0x56,0x00,0xe0,0x00,0x55,0x00,0xd0,0x00,0x54,0x00,0xbf,0x00,0x54,0x00,0xaf,0x00,0x53,0x00,0x9e,0x00,0x53,0x00,0x8e,0x00,  \
    0x52,0x00,0x7d,0x00,0x52,0x00,0x6d,0x00,0x51,0x00,0x5c,0x00,0x51,0x00,0x4b,0x00,0x51,0x00,0x3b,0x00,0x50,0x00,0x2a,0x00,0x50,0x00,0x1a,0x00,0x50,0x00,0x09,0x00,0x50,0x00,0xf9,0xff,0x50,0x00,0xe8,0xff,0x50,0x00,0xd8,0xff,0x50,0x00,0xc7,0xff,0x50,0x00,0xb7,0xff,0x50,0x00,0xa6,0xff,0x50,0x00,0x96,0xff,0x50,0x00,0x85,0xff,0x50,0x00,0x75,0xff,0x50,0x00,0x64,0xff,0x50,0x00,0x54,0xff,0x51,0x00,0x43,0xff,0x51,0x00,0x33,0xff,0x51,0x00,0x22,0xff,0x52,0x00,  \
    0x12,0xff,0x52,0x00,0x01,0xff,0x53,0x00,0xf1,0xfe,0x53,0x00,0xe0,0xfe,0x54,0x00,0xd0,0xfe,0x54,0x00,0xbf,0xfe,0x55,0x00,0xaf,0xfe,0x56,0x00,0x9e,0xfe,0x56,0x00,0x8e,0xfe,0x57,0x00,0x7d,0xfe,0x58,0x00,0x6d,0xfe,0x59,0x00,0x5c,0xfe,0x5a,0x00,0x4c,0xfe,0x5b,0x00,0x3b,0xfe,0x5c,0x00,0x2b,0xfe,0x5d,0x00,0x1a,0xfe,0x5e,0x00,0x0a,0xfe,0x5f,0x00,0xf9,0xfd,0x60,0x00,0xe8,0xfd,0x61,0x00,0xd8,0xfd,0x62,0x00,0xc7,0xfd,0x63,0x00,0xb6,0xfd,0x65,0x00,0xa5,0xfd,  \
    0x66,0x00,0x95,0xfd,0x67,0x00,0x84,0xfd,0x68,0x00,0x73,0xfd,0x6a,0x00,0x62,0xfd,0x6b,0x00,0x51,0xfd,0x6d,0x00,0x40,0xfd,0x6e,0x00,0x30,0xfd,0x70,0x00,0x1f,0xfd,0x71,0x00,0x0e,0xfd,0x73,0x00,0xfd,0xfc,0x75,0x00,0xec,0xfc,0x76,0x00,0xdb,0xfc,0x78,0x00,0xca,0xfc,0x7a,0x00,0xb9,0xfc,0x7c,0x00,0xa8,0xfc,0x7e,0x00,0x97,0xfc,0x80,0x00,0x86,0xfc,0x81,0x00,0x75,0xfc,0x83,0x00,0x64,0xfc,0x85,0x00,0x53,0xfc,0x87,0x00,0x42,0xfc,0x8a,0x00,0x31,0xfc,0x8c,0x00,  \
    0x21,0xfc,0x8e,0x00,0x11,0xfc,0x90,0x00,0x00,0xfc,0x93,0x00,0xf0,0xfb,0x95,0x00,0xdf,0xfb,0x97,0x00,0xcf,0xfb,0x9a,0x00,0xbf,0xfb,0x9c,0x00,0xae,0xfb,0x9f,0x00,0x9e,0xfb,0xa1,0x00,0x8d,0xfb,0xa4,0x00,0x7d,0xfb,0xa7,0x00,0x6d,0xfb,0xaa,0x00,0x5c,0xfb,0xac,0x00,0x4c,0xfb,0xaf,0x00,0x3c,0xfb,0xb2,0x00,0x2b,0xfb,0xb5,0x00,0x1b,0xfb,0xb8,0x00,0x0b,0xfb,0xbb,0x00,0xfa,0xfa,0xbe,0x00,0xea,0xfa,0xc1,0x00,0xda,0xfa,0xc4,0x00,0xc9,0xfa,0xc7,0x00,0xb9,0xfa,  \
    0xcb,0x00,0xa9,0xfa,0xce,0x00,0x98,0xfa,0xd1,0x00,0x88,0xfa,0xd4,0x00,0x78,0xfa,0xd8,0x00,0x67,0xfa,0xdb,0x00,0x56,0xfa,0xde,0x00,0x45,0xfa,0xe2,0x00,0x34,0xfa,0xe5,0x00,0x23,0xfa,0xe9,0x00,0x12,0xfa,0xec,0x00,0x01,0xfa,0xf0,0x00,0xf0,0xf9,0xf3,0x00,0xdf,0xf9,0xf7,0x00,0xce,0xf9,0xfb,0x00,0xbd,0xf9,0xfe,0x00,0xac,0xf9,0x02,0x01,0x9b,0xf9,0x06,0x01,0x8a,0xf9,0x0a,0x01,0x79,0xf9,0x0e,0x01,0x68,0xf9,0x12,0x01,0x56,0xf9,0x16,0x01,0x45,0xf9,0x1a,0x01,  \
    0x34,0xf9,0x1e,0x01,0x23,0xf9,0x22,0x01,0x12,0xf9,0x26,0x01,0x01,0xf9,0x2a,0x01,0xf0,0xf8,0x2e,0x01,0xde,0xf8,0x33,0x01,0xcd,0xf8,0x37,0x01,0xbd,0xf8,0x3c,0x01,0xac,0xf8,0x40,0x01,0x9b,0xf8,0x45,0x01,0x8a,0xf8,0x49,0x01,0x79,0xf8,0x4e,0x01,0x68,0xf8,0x52,0x01,0x57,0xf8,0x57,0x01,0x46,0xf8,0x5c,0x01,0x35,0xf8,0x61,0x01,0x24,0xf8,0x66,0x01,0x13,0xf8,0x6a,0x01,0x02,0xf8,0x6f,0x01,0xf1,0xf7,0x74,0x01,0xe0,0xf7,0x79,0x01,0xcf,0xf7,0x7e,0x01,0xbe,0xf7,  \
    0x84,0x01,0xad,0xf7,0x89,0x01,0x9c,0xf7,0x8e,0x01,0x8a,0xf7,0x93,0x01,0x79,0xf7,0x98,0x01,0x68,0xf7,0x9e,0x01,0x57,0xf7,0xa3,0x01,0x45,0xf7,0xa8,0x01,0x33,0xf7,0xad,0x01,0x21,0xf7,0xb3,0x01,0x10,0xf7,0xb8,0x01,0xfe,0xf6,0xbd,0x01,0xec,0xf6,0xc3,0x01,0xda,0xf6,0xc8,0x01,0xc8,0xf6,0xce,0x01,0xb6,0xf6,0xd3,0x01,0xa3,0xf6,0xd9,0x01,0x91,0xf6,0xde,0x01,0x7f,0xf6,0xe4,0x01,0x6d,0xf6,0xe9,0x01,0x5b,0xf6,0xef,0x01,0x49,0xf6,0xf5,0x01,0x36,0xf6,0xfa,0x01,  \
    0x24,0xf6,0x00,0x02,0x11,0xf6,0x06,0x02,0xff,0xf5,0x0c,0x02,0xed,0xf5,0x12,0x02,0xda,0xf5,0x18,0x02,0xc8,0xf5,0x1e,0x02,0xb6,0xf5,0x24,0x02,0xa3,0xf5,0x2a,0x02,0x91,0xf5,0x30,0x02,0x7f,0xf5,0x36,0x02,0x6c,0xf5,0x3c,0x02,0x5a,0xf5,0x43,0x02,0x47,0xf5,0x49,0x02,0x35,0xf5,0x4f,0x02,0x22,0xf5,0x56,0x02,0x10,0xf5,0x5c,0x02,0xfd,0xf4,0x62,0x02,0xea,0xf4,0x69,0x02,0xd7,0xf4,0x6f,0x02,0xc4,0xf4,0x76,0x02,0xb1,0xf4,0x7c,0x02,0x9e,0xf4,0x83,0x02,0x8b,0xf4,  \
    0x89,0x02,0x78,0xf4,0x90,0x02,0x65,0xf4,0x96,0x02,0x51,0xf4,0x9b,0x02,0x3c,0xf4,0xa1,0x02,0x27,0xf4,0xa7,0x02,0x12,0xf4,0xad,0x02,0xfe,0xf3,0xb3,0x02,0xe9,0xf3,0xb9,0x02,0xd4,0xf3,0xbf,0x02,0xbf,0xf3,0xc5,0x02,0xaa,0xf3,0xcb,0x02,0x94,0xf3,0xd1,0x02,0x7f,0xf3,0xd6,0x02,0x6a,0xf3,0xdc,0x02,0x54,0xf3,0xe2,0x02,0x3f,0xf3,0xe8,0x02,0x29,0xf3,0xee,0x02,0x14,0xf3,0xf4,0x02,0xfe,0xf2,0xfa,0x02,0xe8,0xf2,0x00,0x03,0xd3,0xf2,0x06,0x03,0xbe,0xf2,0x0d,0x03,  \
    0xa9,0xf2,0x14,0x03,0x94,0xf2,0x1a,0x03,0x7f,0xf2,0x21,0x03,0x6a,0xf2,0x27,0x03,0x55,0xf2,0x2e,0x03,0x40,0xf2,0x34,0x03,0x2a,0xf2,0x3a,0x03,0x15,0xf2,0x41,0x03,0xff,0xf1,0x47,0x03,0xe9,0xf1,0x4d,0x03,0xd3,0xf1,0x54,0x03,0xbd,0xf1,0x5a,0x03,0xa7,0xf1,0x60,0x03,0x91,0xf1,0x66,0x03,0x7a,0xf1,0x6d,0x03,0x64,0xf1,0x73,0x03,0x4d,0xf1,0x79,0x03,0x37,0xf1,0x7f,0x03,0x20,0xf1,0x85,0x03,0x09,0xf1,0x8b,0x03,0xf2,0xf0,0x91,0x03,0xdb,0xf0,0x97,0x03,0xc4,0xf0,  \
    0x9d,0x03,0xad,0xf0,0xa3,0x03,0x95,0xf0,0xa8,0x03,0x7e,0xf0,0xae,0x03,0x66,0xf0,0xb4,0x03,0x4e,0xf0,0xb9,0x03,0x36,0xf0,0xbf,0x03,0x1e,0xf0,0xc4,0x03,0x05,0xf0,0xc9,0x03,0xed,0xef,0xce,0x03,0xd4,0xef,0xd4,0x03,0xbb,0xef,0xd9,0x03,0xa2,0xef,0xde,0x03,0x89,0xef,0xe2,0x03,0x70,0xef,0xe7,0x03,0x56,0xef,0xeb,0x03,0x3c,0xef,0xef,0x03,0x21,0xef,0xf3,0x03,0x07,0xef,0xf7,0x03,0xec,0xee,0xfb,0x03,0xd1,0xee,0xfe,0x03,0xb6,0xee,0x02,0x04,0x9b,0xee,0x06,0x04,  \
    0x7f,0xee,0x09,0x04,0x64,0xee,0x0c,0x04,0x48,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x66,0x04,0x7a,0x11,0x63,0x04,0x5e,0x11,0x5f,0x04,0x42,0x11,0x5b,0x04,0x27,0x11,0x57,0x04,0x0c,0x11,  \
    0x53,0x04,0xf0,0x10,0x4f,0x04,0xd6,0x10,0x4b,0x04,0xbb,0x10,0x47,0x04,0xa0,0x10,0x42,0x04,0x85,0x10,0x3e,0x04,0x6b,0x10,0x39,0x04,0x51,0x10,0x34,0x04,0x37,0x10,0x30,0x04,0x1d,0x10,0x2b,0x04,0x03,0x10,0x26,0x04,0xe9,0x0f,0x21,0x04,0xcf,0x0f,0x1b,0x04,0xb6,0x0f,0x16,0x04,0x9d,0x0f,0x11,0x04,0x83,0x0f,0x0b,0x04,0x6b,0x0f,0x06,0x04,0x52,0x0f,0x00,0x04,0x3a,0x0f,0xfa,0x03,0x21,0x0f,0xf4,0x03,0x09,0x0f,0xee,0x03,0xf1,0x0e,0xe8,0x03,0xda,0x0e,0xe1,0x03,  \
    0xc2,0x0e,0xdb,0x03,0xaa,0x0e,0xd5,0x03,0x93,0x0e,0xcf,0x03,0x7c,0x0e,0xc8,0x03,0x64,0x0e,0xc2,0x03,0x4d,0x0e,0xbb,0x03,0x36,0x0e,0xb5,0x03,0x20,0x0e,0xae,0x03,0x09,0x0e,0xa7,0x03,0xf2,0x0d,0xa1,0x03,0xdc,0x0d,0x9a,0x03,0xc5,0x0d,0x93,0x03,0xaf,0x0d,0x8c,0x03,0x9a,0x0d,0x85,0x03,0x84,0x0d,0x7d,0x03,0x6f,0x0d,0x76,0x03,0x5a,0x0d,0x6f,0x03,0x45,0x0d,0x67,0x03,0x30,0x0d,0x60,0x03,0x1c,0x0d,0x58,0x03,0x07,0x0d,0x51,0x03,0xf3,0x0c,0x49,0x03,0xde,0x0c,  \
    0x42,0x03,0xca,0x0c,0x3a,0x03,0xb6,0x0c,0x32,0x03,0xa2,0x0c,0x2b,0x03,0x8e,0x0c,0x23,0x03,0x7b,0x0c,0x1c,0x03,0x67,0x0c,0x14,0x03,0x53,0x0c,0x0d,0x03,0x40,0x0c,0x06,0x03,0x2a,0x0c,0x00,0x03,0x15,0x0c,0xfa,0x02,0xff,0x0b,0xf3,0x02,0xea,0x0b,0xed,0x02,0xd5,0x0b,0xe7,0x02,0xc0,0x0b,0xe0,0x02,0xab,0x0b,0xda,0x02,0x96,0x0b,0xd4,0x02,0x81,0x0b,0xcd,0x02,0x6c,0x0b,0xc7,0x02,0x57,0x0b,0xc1,0x02,0x42,0x0b,0xbb,0x02,0x2e,0x0b,0xb4,0x02,0x19,0x0b,0xae,0x02,  \
    0x05,0x0b,0xa8,0x02,0xf0,0x0a,0xa2,0x02,0xdc,0x0a,0x9b,0x02,0xc7,0x0a,0x95,0x02,0xb3,0x0a,0x8f,0x02,0x9f,0x0a,0x89,0x02,0x8b,0x0a,0x83,0x02,0x76,0x0a,0x7d,0x02,0x62,0x0a,0x76,0x02,0x4e,0x0a,0x70,0x02,0x3a,0x0a,0x6a,0x02,0x26,0x0a,0x64,0x02,0x13,0x0a,0x5e,0x02,0xff,0x09,0x58,0x02,0xeb,0x09,0x52,0x02,0xd7,0x09,0x4c,0x02,0xc4,0x09,0x46,0x02,0xb0,0x09,0x40,0x02,0x9c,0x09,0x3a,0x02,0x89,0x09,0x34,0x02,0x75,0x09,0x2e,0x02,0x62,0x09,0x28,0x02,0x51,0x09,  \
    0x21,0x02,0x40,0x09,0x1a,0x02,0x2e,0x09,0x14,0x02,0x1d,0x09,0x0d,0x02,0x0c,0x09,0x06,0x02,0xfb,0x08,0x00,0x02,0xea,0x08,0xf9,0x01,0xd9,0x08,0xf3,0x01,0xc8,0x08,0xed,0x01,0xb7,0x08,0xe6,0x01,0xa6,0x08,0xe0,0x01,0x95,0x08,0xda,0x01,0x84,0x08,0xd3,0x01,0x73,0x08,0xcd,0x01,0x62,0x08,0xc7,0x01,0x51,0x08,0xc1,0x01,0x41,0x08,0xbb,0x01,0x30,0x08,0xb5,0x01,0x1f,0x08,0xaf,0x01,0x0f,0x08,0xa9,0x01,0xfe,0x07,0xa3,0x01,0xed,0x07,0x9e,0x01,0xdc,0x07,0x98,0x01,  \
    0xcb,0x07,0x93,0x01,0xbb,0x07,0x8d,0x01,0xaa,0x07,0x88,0x01,0x99,0x07,0x82,0x01,0x88,0x07,0x7d,0x01,0x78,0x07,0x77,0x01,0x67,0x07,0x72,0x01,0x56,0x07,0x6d,0x01,0x46,0x07,0x67,0x01,0x35,0x07,0x62,0x01,0x25,0x07,0x5d,0x01,0x14,0x07,0x58,0x01,0x03,0x07,0x53,0x01,0xf3,0x06,0x4e,0x01,0xe2,0x06,0x49,0x01,0xd2,0x06,0x44,0x01,0xc1,0x06,0x3f,0x01,0xb1,0x06,0x3b,0x01,0xa1,0x06,0x36,0x01,0x90,0x06,0x32,0x01,0x7e,0x06,0x2d,0x01,0x6d,0x06,0x29,0x01,0x5b,0x06,  \
    0x25,0x01,0x4a,0x06,0x21,0x01,0x38,0x06,0x1c,0x01,0x27,0x06,0x18,0x01,0x15,0x06,0x14,0x01,0x04,0x06,0x10,0x01,0xf2,0x05,0x0c,0x01,0xe1,0x05,0x08,0x01,0xd0,0x05,0x04,0x01,0xbe,0x05,0x00,0x01,0xad,0x05,0xfd,0x00,0x9c,0x05,0xf9,0x00,0x8a,0x05,0xf5,0x00,0x79,0x05,0xf1,0x00,0x68,0x05,0xed,0x00,0x57,0x05,0xea,0x00,0x46,0x05,0xe6,0x00,0x34,0x05,0xe3,0x00,0x23,0x05,0xdf,0x00,0x12,0x05,0xdc,0x00,0x01,0x05,0xd8,0x00,0xf0,0x04,0xd4,0x00,0xe0,0x04,0xd1,0x00,  \
    0xd0,0x04,0xcd,0x00,0xbf,0x04,0xca,0x00,0xaf,0x04,0xc6,0x00,0x9f,0x04,0xc3,0x00,0x8f,0x04,0xc0,0x00,0x7e,0x04,0xbc,0x00,0x6e,0x04,0xb9,0x00,0x5e,0x04,0xb6,0x00,0x4e,0x04,0xb3,0x00,0x3e,0x04,0xb0,0x00,0x2d,0x04,0xad,0x00,0x1d,0x04,0xaa,0x00,0x0d,0x04,0xa7,0x00,0xfd,0x03,0xa4,0x00,0xed,0x03,0xa1,0x00,0xdd,0x03,0x9e,0x00,0xcc,0x03,0x9b,0x00,0xbc,0x03,0x99,0x00,0xac,0x03,0x96,0x00,0x9c,0x03,0x93,0x00,0x8c,0x03,0x91,0x00,0x7c,0x03,0x8e,0x00,0x6c,0x03,  \
    0x8c,0x00,0x5c,0x03,0x89,0x00,0x4c,0x03,0x87,0x00,0x3c,0x03,0x84,0x00,0x2d,0x03,0x82,0x00,0x1d,0x03,0x7f,0x00,0x0e,0x03,0x7d,0x00,0xfe,0x02,0x7b,0x00,0xef,0x02,0x78,0x00,0xdf,0x02,0x76,0x00,0xcf,0x02,0x74,0x00,0xc0,0x02,0x72,0x00,0xb0,0x02,0x70,0x00,0xa1,0x02,0x6e,0x00,0x91,0x02,0x6c,0x00,0x81,0x02,0x6a,0x00,0x72,0x02,0x69,0x00,0x62,0x02,0x67,0x00,0x52,0x02,0x65,0x00,0x42,0x02,0x63,0x00,0x33,0x02,0x62,0x00,0x23,0x02,0x60,0x00,0x13,0x02,0x5f,0x00,  \
    0x03,0x02,0x5d,0x00,0xf3,0x01,0x5c,0x00,0xe3,0x01,0x5a,0x00,0xd3,0x01,0x59,0x00,0xc4,0x01,0x58,0x00,0xb4,0x01,0x56,0x00,0xa4,0x01,0x55,0x00,0x93,0x01,0x54,0x00,0x83,0x01,0x53,0x00,0x72,0x01,0x52,0x00,0x62,0x01,0x51,0x00,0x51,0x01,0x50,0x00,0x41,0x01,0x4f,0x00,0x31,0x01,0x4e,0x00,0x20,0x01,0x4d,0x00,0x10,0x01,0x4c,0x00,0xff,0x00,0x4c,0x00,0xef,0x00,0x4b,0x00,0xde,0x00,0x4a,0x00,0xce,0x00,0x4a,0x00,0xbe,0x00,0x49,0x00,0xad,0x00,0x48,0x00,0x9d,0x00,  \
    0x48,0x00,0x8c,0x00,0x47,0x00,0x7c,0x00,0x47,0x00,0x6b,0x00,0x47,0x00,0x5b,0x00,0x46,0x00,0x4b,0x00,0x46,0x00,0x3a,0x00,0x46,0x00,0x2a,0x00,0x45,0x00,0x19,0x00,0x45,0x00,0x09,0x00,0x45,0x00,0xf9,0xff,0x45,0x00,0xe8,0xff,0x45,0x00,0xd8,0xff,0x45,0x00,0xc7,0xff,0x45,0x00,0xb7,0xff,0x45,0x00,0xa6,0xff,0x45,0x00,0x96,0xff,0x45,0x00,0x86,0xff,0x45,0x00,0x75,0xff,0x45,0x00,0x65,0xff,0x46,0x00,0x54,0xff,0x46,0x00,0x44,0xff,0x46,0x00,0x34,0xff,0x47,0x00,  \
    0x23,0xff,0x47,0x00,0x13,0xff,0x47,0x00,0x02,0xff,0x48,0x00,0xf2,0xfe,0x48,0x00,0xe1,0xfe,0x49,0x00,0xd1,0xfe,0x4a,0x00,0xc1,0xfe,0x4a,0x00,0xb0,0xfe,0x4b,0x00,0xa0,0xfe,0x4c,0x00,0x8f,0xfe,0x4c,0x00,0x7f,0xfe,0x4d,0x00,0x6f,0xfe,0x4e,0x00,0x5e,0xfe,0x4f,0x00,0x4e,0xfe,0x50,0x00,0x3d,0xfe,0x51,0x00,0x2d,0xfe,0x52,0x00,0x1d,0xfe,0x53,0x00,0x0c,0xfe,0x54,0x00,0xfc,0xfd,0x55,0x00,0xeb,0xfd,0x56,0x00,0xda,0xfd,0x57,0x00,0xca,0xfd,0x59,0x00,0xb9,0xfd,  \
    0x5a,0x00,0xa9,0xfd,0x5b,0x00,0x98,0xfd,0x5c,0x00,0x87,0xfd,0x5e,0x00,0x77,0xfd,0x5f,0x00,0x66,0xfd,0x61,0x00,0x55,0xfd,0x62,0x00,0x44,0xfd,0x64,0x00,0x34,0xfd,0x65,0x00,0x23,0xfd,0x67,0x00,0x12,0xfd,0x68,0x00,0x01,0xfd,0x6a,0x00,0xf0,0xfc,0x6c,0x00,0xe0,0xfc,0x6e,0x00,0xcf,0xfc,0x6f,0x00,0xbe,0xfc,0x71,0x00,0xad,0xfc,0x73,0x00,0x9c,0xfc,0x75,0x00,0x8b,0xfc,0x77,0x00,0x7b,0xfc,0x79,0x00,0x6a,0xfc,0x7b,0x00,0x59,0xfc,0x7d,0x00,0x48,0xfc,0x7f,0x00,  \
    0x37,0xfc,0x81,0x00,0x27,0xfc,0x83,0x00,0x16,0xfc,0x86,0x00,0x06,0xfc,0x88,0x00,0xf6,0xfb,0x8a,0x00,0xe5,0xfb,0x8d,0x00,0xd5,0xfb,0x8f,0x00,0xc5,0xfb,0x92,0x00,0xb4,0xfb,0x94,0x00,0xa4,0xfb,0x97,0x00,0x94,0xfb,0x9a,0x00,0x83,0xfb,0x9c,0x00,0x73,0xfb,0x9f,0x00,0x63,0xfb,0xa2,0x00,0x53,0xfb,0xa5,0x00,0x42,0xfb,0xa8,0x00,0x32,0xfb,0xab,0x00,0x22,0xfb,0xad,0x00,0x12,0xfb,0xb0,0x00,0x01,0xfb,0xb4,0x00,0xf1,0xfa,0xb7,0x00,0xe1,0xfa,0xba,0x00,0xd1,0xfa,  \
    0xbd,0x00,0xc0,0xfa,0xc0,0x00,0xb0,0xfa,0xc3,0x00,0xa0,0xfa,0xc7,0x00,0x90,0xfa,0xca,0x00,0x7f,0xfa,0xcd,0x00,0x6e,0xfa,0xd1,0x00,0x5d,0xfa,0xd4,0x00,0x4d,0xfa,0xd8,0x00,0x3c,0xfa,0xdb,0x00,0x2b,0xfa,0xde,0x00,0x1a,0xfa,0xe2,0x00,0x09,0xfa,0xe6,0x00,0xf8,0xf9,0xe9,0x00,0xe7,0xf9,0xed,0x00,0xd6,0xf9,0xf1,0x00,0xc5,0xf9,0xf4,0x00,0xb4,0xf9,0xf8,0x00,0xa3,0xf9,0xfc,0x00,0x92,0xf9,0x00,0x01,0x81,0xf9,0x04,0x01,0x70,0xf9,0x08,0x01,0x5f,0xf9,0x0c,0x01,  \
    0x4e,0xf9,0x10,0x01,0x3d,0xf9,0x14,0x01,0x2c,0xf9,0x18,0x01,0x1b,0xf9,0x1c,0x01,0x0a,0xf9,0x20,0x01,0xf9,0xf8,0x24,0x01,0xe8,0xf8,0x29,0x01,0xd7,0xf8,0x2d,0x01,0xc6,0xf8,0x32,0x01,0xb5,0xf8,0x36,0x01,0xa4,0xf8,0x3b,0x01,0x93,0xf8,0x3f,0x01,0x83,0xf8,0x44,0x01,0x72,0xf8,0x48,0x01,0x61,0xf8,0x4d,0x01,0x50,0xf8,0x52,0x01,0x3f,0xf8,0x57,0x01,0x2e,0xf8,0x5c,0x01,0x1d,0xf8,0x61,0x01,0x0c,0xf8,0x65,0x01,0xfb,0xf7,0x6a,0x01,0xea,0xf7,0x6f,0x01,0xd9,0xf7,  \
    0x75,0x01,0xc8,0xf7,0x7a,0x01,0xb7,0xf7,0x7f,0x01,0xa6,0xf7,0x84,0x01,0x95,0xf7,0x89,0x01,0x83,0xf7,0x8f,0x01,0x72,0xf7,0x94,0x01,0x61,0xf7,0x99,0x01,0x4f,0xf7,0x9e,0x01,0x3e,0xf7,0xa3,0x01,0x2c,0xf7,0xa9,0x01,0x1a,0xf7,0xae,0x01,0x08,0xf7,0xb3,0x01,0xf6,0xf6,0xb9,0x01,0xe4,0xf6,0xbe,0x01,0xd2,0xf6,0xc4,0x01,0xc0,0xf6,0xc9,0x01,0xae,0xf6,0xcf,0x01,0x9c,0xf6,0xd4,0x01,0x8a,0xf6,0xda,0x01,0x78,0xf6,0xdf,0x01,0x66,0xf6,0xe5,0x01,0x53,0xf6,0xeb,0x01,  \
    0x41,0xf6,0xf1,0x01,0x2f,0xf6,0xf6,0x01,0x1c,0xf6,0xfc,0x01,0x0a,0xf6,0x02,0x02,0xf8,0xf5,0x08,0x02,0xe5,0xf5,0x0e,0x02,0xd3,0xf5,0x14,0x02,0xc1,0xf5,0x1a,0x02,0xae,0xf5,0x20,0x02,0x9c,0xf5,0x26,0x02,0x8a,0xf5,0x2c,0x02,0x77,0xf5,0x33,0x02,0x65,0xf5,0x39,0x02,0x52,0xf5,0x3f,0x02,0x40,0xf5,0x45,0x02,0x2d,0xf5,0x4c,0x02,0x1b,0xf5,0x52,0x02,0x08,0xf5,0x58,0x02,0xf5,0xf4,0x5f,0x02,0xe2,0xf4,0x65,0x02,0xcf,0xf4,0x6c,0x02,0xbc,0xf4,0x72,0x02,0xa9,0xf4,  \
    0x78,0x02,0x96,0xf4,0x7f,0x02,0x83,0xf4,0x85,0x02,0x70,0xf4,0x8b,0x02,0x5c,0xf4,0x91,0x02,0x47,0xf4,0x97,0x02,0x32,0xf4,0x9d,0x02,0x1e,0xf4,0xa3,0x02,0x09,0xf4,0xa9,0x02,0xf4,0xf3,0xaf,0x02,0xdf,0xf3,0xb5,0x02,0xca,0xf3,0xbb,0x02,0xb5,0xf3,0xc0,0x02,0xa0,0xf3,0xc6,0x02,0x8a,0xf3,0xcc,0x02,0x75,0xf3,0xd2,0x02,0x60,0xf3,0xd8,0x02,0x4a,0xf3,0xde,0x02,0x35,0xf3,0xe4,0x02,0x1f,0xf3,0xea,0x02,0x09,0xf3,0xf0,0x02,0xf4,0xf2,0xf6,0x02,0xde,0xf2,0xfc,0x02,  \
    0xc9,0xf2,0x03,0x03,0xb5,0xf2,0x09,0x03,0xa0,0xf2,0x10,0x03,0x8b,0xf2,0x16,0x03,0x75,0xf2,0x1d,0x03,0x60,0xf2,0x23,0x03,0x4b,0xf2,0x29,0x03,0x35,0xf2,0x30,0x03,0x20,0xf2,0x36,0x03,0x0a,0xf2,0x3d,0x03,0xf4,0xf1,0x43,0x03,0xde,0xf1,0x49,0x03,0xc8,0xf1,0x4f,0x03,0xb2,0xf1,0x55,0x03,0x9c,0xf1,0x5c,0x03,0x85,0xf1,0x62,0x03,0x6f,0xf1,0x68,0x03,0x58,0xf1,0x6e,0x03,0x41,0xf1,0x74,0x03,0x2b,0xf1,0x7a,0x03,0x14,0xf1,0x80,0x03,0xfd,0xf0,0x86,0x03,0xe6,0xf0,  \
    0x8c,0x03,0xce,0xf0,0x92,0x03,0xb7,0xf0,0x97,0x03,0xa0,0xf0,0x9d,0x03,0x88,0xf0,0xa3,0x03,0x70,0xf0,0xa8,0x03,0x58,0xf0,0xae,0x03,0x40,0xf0,0xb3,0x03,0x28,0xf0,0xb9,0x03,0x0f,0xf0,0xbe,0x03,0xf7,0xef,0xc3,0x03,0xde,0xef,0xc8,0x03,0xc5,0xef,0xcd,0x03,0xac,0xef,0xd2,0x03,0x93,0xef,0xd7,0x03,0x79,0xef,0xdb,0x03,0x60,0xef,0xdf,0x03,0x45,0xef,0xe3,0x03,0x2b,0xef,0xe7,0x03,0x10,0xef,0xeb,0x03,0xf6,0xee,0xef,0x03,0xdb,0xee,0xf3,0x03,0xc0,0xee,0xf6,0x03,  \
    0xa4,0xee,0xfa,0x03,0x89,0xee,0xfd,0x03,0x6d,0xee,0x00,0x04,0x52,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x59,0x04,0x72,0x11,0x55,0x04,0x56,0x11,0x52,0x04,0x3b,0x11,0x4e,0x04,0x1f,0x11,  \
    0x4a,0x04,0x04,0x11,0x46,0x04,0xe9,0x10,0x42,0x04,0xce,0x10,0x3e,0x04,0xb3,0x10,0x39,0x04,0x98,0x10,0x35,0x04,0x7d,0x10,0x30,0x04,0x63,0x10,0x2c,0x04,0x49,0x10,0x27,0x04,0x2f,0x10,0x22,0x04,0x15,0x10,0x1e,0x04,0xfb,0x0f,0x19,0x04,0xe1,0x0f,0x14,0x04,0xc7,0x0f,0x0f,0x04,0xae,0x0f,0x09,0x04,0x94,0x0f,0x04,0x04,0x7b,0x0f,0xff,0x03,0x62,0x0f,0xf9,0x03,0x4a,0x0f,0xf3,0x03,0x31,0x0f,0xed,0x03,0x19,0x0f,0xe7,0x03,0x01,0x0f,0xe1,0x03,0xe9,0x0e,0xdb,0x03,  \
    0xd1,0x0e,0xd5,0x03,0xb9,0x0e,0xcf,0x03,0xa2,0x0e,0xc9,0x03,0x8a,0x0e,0xc2,0x03,0x73,0x0e,0xbc,0x03,0x5c,0x0e,0xb6,0x03,0x45,0x0e,0xaf,0x03,0x2e,0x0e,0xa9,0x03,0x17,0x0e,0xa2,0x03,0x00,0x0e,0x9b,0x03,0xe9,0x0d,0x95,0x03,0xd3,0x0d,0x8e,0x03,0xbd,0x0d,0x87,0x03,0xa6,0x0d,0x80,0x03,0x91,0x0d,0x79,0x03,0x7b,0x0d,0x72,0x03,0x66,0x0d,0x6a,0x03,0x51,0x0d,0x63,0x03,0x3c,0x0d,0x5c,0x03,0x27,0x0d,0x54,0x03,0x12,0x0d,0x4d,0x03,0xfe,0x0c,0x45,0x03,0xe9,0x0c,  \
    0x3e,0x03,0xd5,0x0c,0x36,0x03,0xc1,0x0c,0x2f,0x03,0xac,0x0c,0x27,0x03,0x98,0x0c,0x20,0x03,0x85,0x0c,0x18,0x03,0x71,0x0c,0x11,0x03,0x5d,0x0c,0x09,0x03,0x49,0x0c,0x02,0x03,0x36,0x0c,0xfc,0x02,0x20,0x0c,0xf5,0x02,0x0b,0x0c,0xef,0x02,0xf5,0x0b,0xe9,0x02,0xe0,0x0b,0xe2,0x02,0xcb,0x0b,0xdc,0x02,0xb6,0x0b,0xd6,0x02,0xa1,0x0b,0xcf,0x02,0x8c,0x0b,0xc9,0x02,0x77,0x0b,0xc3,0x02,0x62,0x0b,0xbd,0x02,0x4d,0x0b,0xb6,0x02,0x39,0x0b,0xb0,0x02,0x24,0x0b,0xaa,0x02,  \
    0x0f,0x0b,0xa4,0x02,0xfb,0x0a,0x9d,0x02,0xe6,0x0a,0x97,0x02,0xd2,0x0a,0x91,0x02,0xbe,0x0a,0x8b,0x02,0xa9,0x0a,0x84,0x02,0x95,0x0a,0x7e,0x02,0x81,0x0a,0x78,0x02,0x6d,0x0a,0x72,0x02,0x59,0x0a,0x6c,0x02,0x45,0x0a,0x66,0x02,0x31,0x0a,0x60,0x02,0x1d,0x0a,0x5a,0x02,0x09,0x0a,0x54,0x02,0xf5,0x09,0x4e,0x02,0xe2,0x09,0x48,0x02,0xce,0x09,0x42,0x02,0xba,0x09,0x3c,0x02,0xa7,0x09,0x36,0x02,0x93,0x09,0x30,0x02,0x80,0x09,0x2a,0x02,0x6c,0x09,0x24,0x02,0x59,0x09,  \
    0x1d,0x02,0x48,0x09,0x17,0x02,0x36,0x09,0x10,0x02,0x25,0x09,0x09,0x02,0x14,0x09,0x03,0x02,0x03,0x09,0xfc,0x01,0xf1,0x08,0xf6,0x01,0xe0,0x08,0xef,0x01,0xcf,0x08,0xe9,0x01,0xbe,0x08,0xe2,0x01,0xad,0x08,0xdc,0x01,0x9c,0x08,0xd6,0x01,0x8b,0x08,0xcf,0x01,0x7b,0x08,0xc9,0x01,0x6a,0x08,0xc3,0x01,0x59,0x08,0xbd,0x01,0x48,0x08,0xb7,0x01,0x37,0x08,0xb1,0x01,0x27,0x08,0xab,0x01,0x16,0x08,0xa5,0x01,0x06,0x08,0x9f,0x01,0xf5,0x07,0x99,0x01,0xe4,0x07,0x94,0x01,  \
    0xd3,0x07,0x8e,0x01,0xc2,0x07,0x89,0x01,0xb1,0x07,0x83,0x01,0xa1,0x07,0x7e,0x01,0x90,0x07,0x78,0x01,0x7f,0x07,0x73,0x01,0x6f,0x07,0x6d,0x01,0x5e,0x07,0x68,0x01,0x4d,0x07,0x63,0x01,0x3d,0x07,0x5d,0x01,0x2c,0x07,0x58,0x01,0x1c,0x07,0x53,0x01,0x0b,0x07,0x4e,0x01,0xfb,0x06,0x49,0x01,0xea,0x06,0x44,0x01,0xda,0x06,0x3f,0x01,0xc9,0x06,0x3a,0x01,0xb9,0x06,0x35,0x01,0xa8,0x06,0x31,0x01,0x98,0x06,0x2c,0x01,0x87,0x06,0x28,0x01,0x76,0x06,0x23,0x01,0x64,0x06,  \
    0x1f,0x01,0x53,0x06,0x1b,0x01,0x41,0x06,0x17,0x01,0x30,0x06,0x12,0x01,0x1f,0x06,0x0e,0x01,0x0d,0x06,0x0a,0x01,0xfc,0x05,0x06,0x01,0xea,0x05,0x02,0x01,0xd9,0x05,0xfe,0x00,0xc8,0x05,0xfa,0x00,0xb7,0x05,0xf6,0x00,0xa5,0x05,0xf2,0x00,0x94,0x05,0xef,0x00,0x83,0x05,0xeb,0x00,0x72,0x05,0xe7,0x00,0x61,0x05,0xe3,0x00,0x4f,0x05,0xe0,0x00,0x3e,0x05,0xdc,0x00,0x2d,0x05,0xd8,0x00,0x1c,0x05,0xd5,0x00,0x0b,0x05,0xd1,0x00,0xfa,0x04,0xce,0x00,0xe9,0x04,0xca,0x00,  \
    0xd9,0x04,0xc7,0x00,0xc9,0x04,0xc3,0x00,0xb9,0x04,0xc0,0x00,0xa9,0x04,0xbc,0x00,0x98,0x04,0xb9,0x00,0x88,0x04,0xb6,0x00,0x78,0x04,0xb2,0x00,0x68,0x04,0xaf,0x00,0x58,0x04,0xac,0x00,0x48,0x04,0xa9,0x00,0x38,0x04,0xa6,0x00,0x27,0x04,0xa2,0x00,0x17,0x04,0x9f,0x00,0x07,0x04,0x9c,0x00,0xf7,0x03,0x9a,0x00,0xe7,0x03,0x97,0x00,0xd7,0x03,0x94,0x00,0xc7,0x03,0x91,0x00,0xb7,0x03,0x8e,0x00,0xa7,0x03,0x8c,0x00,0x97,0x03,0x89,0x00,0x87,0x03,0x86,0x00,0x77,0x03,  \
    0x84,0x00,0x67,0x03,0x81,0x00,0x57,0x03,0x7f,0x00,0x47,0x03,0x7c,0x00,0x37,0x03,0x7a,0x00,0x28,0x03,0x77,0x00,0x18,0x03,0x75,0x00,0x09,0x03,0x73,0x00,0xfa,0x02,0x70,0x00,0xea,0x02,0x6e,0x00,0xdb,0x02,0x6c,0x00,0xcb,0x02,0x6a,0x00,0xbc,0x02,0x68,0x00,0xac,0x02,0x66,0x00,0x9c,0x02,0x64,0x00,0x8d,0x02,0x62,0x00,0x7d,0x02,0x60,0x00,0x6e,0x02,0x5e,0x00,0x5e,0x02,0x5c,0x00,0x4e,0x02,0x5b,0x00,0x3f,0x02,0x59,0x00,0x2f,0x02,0x57,0x00,0x1f,0x02,0x56,0x00,  \
    0x10,0x02,0x54,0x00,0x00,0x02,0x53,0x00,0xf0,0x01,0x51,0x00,0xe0,0x01,0x50,0x00,0xd0,0x01,0x4f,0x00,0xc0,0x01,0x4d,0x00,0xb1,0x01,0x4c,0x00,0xa1,0x01,0x4b,0x00,0x90,0x01,0x4a,0x00,0x80,0x01,0x49,0x00,0x70,0x01,0x47,0x00,0x5f,0x01,0x46,0x00,0x4f,0x01,0x45,0x00,0x3f,0x01,0x45,0x00,0x2e,0x01,0x44,0x00,0x1e,0x01,0x43,0x00,0x0e,0x01,0x42,0x00,0xfd,0x00,0x41,0x00,0xed,0x00,0x40,0x00,0xdd,0x00,0x40,0x00,0xcc,0x00,0x3f,0x00,0xbc,0x00,0x3f,0x00,0xac,0x00,  \
    0x3e,0x00,0x9b,0x00,0x3d,0x00,0x8b,0x00,0x3d,0x00,0x7b,0x00,0x3d,0x00,0x6a,0x00,0x3c,0x00,0x5a,0x00,0x3c,0x00,0x4a,0x00,0x3b,0x00,0x39,0x00,0x3b,0x00,0x29,0x00,0x3b,0x00,0x19,0x00,0x3b,0x00,0x09,0x00,0x3b,0x00,0xf8,0xff,0x3a,0x00,0xe8,0xff,0x3a,0x00,0xd8,0xff,0x3a,0x00,0xc7,0xff,0x3a,0x00,0xb7,0xff,0x3a,0x00,0xa7,0xff,0x3a,0x00,0x96,0xff,0x3b,0x00,0x86,0xff,0x3b,0x00,0x76,0xff,0x3b,0x00,0x65,0xff,0x3b,0x00,0x55,0xff,0x3b,0x00,0x45,0xff,0x3c,0x00,  \
    0x34,0xff,0x3c,0x00,0x24,0xff,0x3d,0x00,0x14,0xff,0x3d,0x00,0x03,0xff,0x3e,0x00,0xf3,0xfe,0x3e,0x00,0xe3,0xfe,0x3f,0x00,0xd3,0xfe,0x3f,0x00,0xc2,0xfe,0x40,0x00,0xb2,0xfe,0x41,0x00,0xa2,0xfe,0x41,0x00,0x91,0xfe,0x42,0x00,0x81,0xfe,0x43,0x00,0x71,0xfe,0x44,0x00,0x60,0xfe,0x45,0x00,0x50,0xfe,0x45,0x00,0x40,0xfe,0x46,0x00,0x2f,0xfe,0x47,0x00,0x1f,0xfe,0x48,0x00,0x0f,0xfe,0x4a,0x00,0xfe,0xfd,0x4b,0x00,0xee,0xfd,0x4c,0x00,0xdd,0xfd,0x4d,0x00,0xcd,0xfd,  \
    0x4e,0x00,0xbc,0xfd,0x4f,0x00,0xac,0xfd,0x51,0x00,0x9b,0xfd,0x52,0x00,0x8b,0xfd,0x53,0x00,0x7a,0xfd,0x55,0x00,0x69,0xfd,0x56,0x00,0x59,0xfd,0x58,0x00,0x48,0xfd,0x59,0x00,0x38,0xfd,0x5b,0x00,0x27,0xfd,0x5d,0x00,0x16,0xfd,0x5e,0x00,0x06,0xfd,0x60,0x00,0xf5,0xfc,0x62,0x00,0xe4,0xfc,0x63,0x00,0xd3,0xfc,0x65,0x00,0xc3,0xfc,0x67,0x00,0xb2,0xfc,0x69,0x00,0xa1,0xfc,0x6b,0x00,0x90,0xfc,0x6d,0x00,0x80,0xfc,0x6f,0x00,0x6f,0xfc,0x71,0x00,0x5e,0xfc,0x73,0x00,  \
    0x4d,0xfc,0x75,0x00,0x3c,0xfc,0x77,0x00,0x2c,0xfc,0x79,0x00,0x1c,0xfc,0x7c,0x00,0x0c,0xfc,0x7e,0x00,0xfb,0xfb,0x80,0x00,0xeb,0xfb,0x83,0x00,0xdb,0xfb,0x85,0x00,0xcb,0xfb,0x88,0x00,0xbb,0xfb,0x8a,0x00,0xaa,0xfb,0x8d,0x00,0x9a,0xfb,0x90,0x00,0x8a,0xfb,0x92,0x00,0x7a,0xfb,0x95,0x00,0x69,0xfb,0x98,0x00,0x59,0xfb,0x9b,0x00,0x49,0xfb,0x9e,0x00,0x39,0xfb,0xa0,0x00,0x29,0xfb,0xa3,0x00,0x19,0xfb,0xa6,0x00,0x08,0xfb,0xaa,0x00,0xf8,0xfa,0xad,0x00,0xe8,0xfa,  \
    0xb0,0x00,0xd8,0xfa,0xb3,0x00,0xc8,0xfa,0xb6,0x00,0xb7,0xfa,0xb9,0x00,0xa7,0xfa,0xbd,0x00,0x97,0xfa,0xc0,0x00,0x87,0xfa,0xc3,0x00,0x76,0xfa,0xc7,0x00,0x65,0xfa,0xca,0x00,0x54,0xfa,0xce,0x00,0x44,0xfa,0xd1,0x00,0x33,0xfa,0xd5,0x00,0x22,0xfa,0xd8,0x00,0x11,0xfa,0xdc,0x00,0x00,0xfa,0xdf,0x00,0xef,0xf9,0xe3,0x00,0xdf,0xf9,0xe7,0x00,0xce,0xf9,0xea,0x00,0xbd,0xf9,0xee,0x00,0xac,0xf9,0xf2,0x00,0x9b,0xf9,0xf6,0x00,0x8a,0xf9,0xfa,0x00,0x79,0xf9,0xfe,0x00,  \
    0x68,0xf9,0x02,0x01,0x57,0xf9,0x06,0x01,0x46,0xf9,0x0a,0x01,0x35,0xf9,0x0e,0x01,0x24,0xf9,0x12,0x01,0x13,0xf9,0x16,0x01,0x02,0xf9,0x1b,0x01,0xf1,0xf8,0x1f,0x01,0xe0,0xf8,0x23,0x01,0xcf,0xf8,0x28,0x01,0xbf,0xf8,0x2c,0x01,0xae,0xf8,0x31,0x01,0x9d,0xf8,0x35,0x01,0x8c,0xf8,0x3a,0x01,0x7b,0xf8,0x3f,0x01,0x6b,0xf8,0x44,0x01,0x5a,0xf8,0x48,0x01,0x49,0xf8,0x4d,0x01,0x38,0xf8,0x52,0x01,0x27,0xf8,0x57,0x01,0x16,0xf8,0x5c,0x01,0x05,0xf8,0x61,0x01,0xf4,0xf7,  \
    0x66,0x01,0xe3,0xf7,0x6b,0x01,0xd2,0xf7,0x70,0x01,0xc1,0xf7,0x75,0x01,0xb0,0xf7,0x7a,0x01,0x9f,0xf7,0x80,0x01,0x8e,0xf7,0x85,0x01,0x7d,0xf7,0x8a,0x01,0x6b,0xf7,0x8f,0x01,0x5a,0xf7,0x95,0x01,0x48,0xf7,0x9a,0x01,0x36,0xf7,0x9f,0x01,0x24,0xf7,0xa4,0x01,0x13,0xf7,0xaa,0x01,0x01,0xf7,0xaf,0x01,0xef,0xf6,0xb5,0x01,0xdd,0xf6,0xba,0x01,0xcb,0xf6,0xc0,0x01,0xb9,0xf6,0xc5,0x01,0xa7,0xf6,0xcb,0x01,0x95,0xf6,0xd0,0x01,0x83,0xf6,0xd6,0x01,0x70,0xf6,0xdb,0x01,  \
    0x5e,0xf6,0xe1,0x01,0x4c,0xf6,0xe7,0x01,0x3a,0xf6,0xed,0x01,0x27,0xf6,0xf2,0x01,0x15,0xf6,0xf8,0x01,0x02,0xf6,0xfe,0x01,0xf0,0xf5,0x04,0x02,0xde,0xf5,0x0a,0x02,0xcc,0xf5,0x10,0x02,0xb9,0xf5,0x16,0x02,0xa7,0xf5,0x1c,0x02,0x95,0xf5,0x23,0x02,0x82,0xf5,0x29,0x02,0x70,0xf5,0x2f,0x02,0x5d,0xf5,0x35,0x02,0x4b,0xf5,0x3c,0x02,0x38,0xf5,0x42,0x02,0x26,0xf5,0x48,0x02,0x13,0xf5,0x4e,0x02,0x00,0xf5,0x55,0x02,0xed,0xf4,0x5b,0x02,0xda,0xf4,0x62,0x02,0xc7,0xf4,  \
    0x68,0x02,0xb4,0xf4,0x6f,0x02,0xa1,0xf4,0x75,0x02,0x8e,0xf4,0x7b,0x02,0x7b,0xf4,0x81,0x02,0x66,0xf4,0x87,0x02,0x52,0xf4,0x8d,0x02,0x3d,0xf4,0x93,0x02,0x29,0xf4,0x99,0x02,0x14,0xf4,0x9f,0x02,0xff,0xf3,0xa5,0x02,0xea,0xf3,0xab,0x02,0xd5,0xf3,0xb1,0x02,0xc0,0xf3,0xb6,0x02,0xab,0xf3,0xbc,0x02,0x96,0xf3,0xc2,0x02,0x80,0xf3,0xc8,0x02,0x6b,0xf3,0xce,0x02,0x55,0xf3,0xd4,0x02,0x40,0xf3,0xda,0x02,0x2a,0xf3,0xe0,0x02,0x15,0xf3,0xe6,0x02,0xff,0xf2,0xec,0x02,  \
    0xe9,0xf2,0xf2,0x02,0xd5,0xf2,0xf9,0x02,0xc0,0xf2,0xff,0x02,0xab,0xf2,0x05,0x03,0x96,0xf2,0x0c,0x03,0x80,0xf2,0x12,0x03,0x6b,0xf2,0x19,0x03,0x56,0xf2,0x1f,0x03,0x40,0xf2,0x25,0x03,0x2b,0xf2,0x2c,0x03,0x15,0xf2,0x32,0x03,0xff,0xf1,0x38,0x03,0xe9,0xf1,0x3f,0x03,0xd3,0xf1,0x45,0x03,0xbd,0xf1,0x4b,0x03,0xa6,0xf1,0x51,0x03,0x90,0xf1,0x57,0x03,0x79,0xf1,0x5d,0x03,0x63,0xf1,0x63,0x03,0x4c,0xf1,0x69,0x03,0x35,0xf1,0x6f,0x03,0x1e,0xf1,0x75,0x03,0x07,0xf1,  \
    0x7b,0x03,0xf0,0xf0,0x81,0x03,0xd9,0xf0,0x87,0x03,0xc1,0xf0,0x8c,0x03,0xaa,0xf0,0x92,0x03,0x92,0xf0,0x98,0x03,0x7a,0xf0,0x9d,0x03,0x62,0xf0,0xa3,0x03,0x4a,0xf0,0xa8,0x03,0x32,0xf0,0xad,0x03,0x19,0xf0,0xb2,0x03,0x01,0xf0,0xb8,0x03,0xe8,0xef,0xbd,0x03,0xcf,0xef,0xc1,0x03,0xb6,0xef,0xc6,0x03,0x9d,0xef,0xcb,0x03,0x83,0xef,0xd0,0x03,0x69,0xef,0xd4,0x03,0x4f,0xef,0xd8,0x03,0x35,0xef,0xdc,0x03,0x1a,0xef,0xdf,0x03,0xff,0xee,0xe3,0x03,0xe4,0xee,0xe7,0x03,  \
    0xc9,0xee,0xea,0x03,0xae,0xee,0xee,0x03,0x93,0xee,0xf1,0x03,0x77,0xee,0xf4,0x03,0x5b,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x4b,0x04,0x6a,0x11,0x48,0x04,0x4e,0x11,0x44,0x04,0x33,0x11,  \
    0x41,0x04,0x17,0x11,0x3d,0x04,0xfc,0x10,0x39,0x04,0xe1,0x10,0x35,0x04,0xc6,0x10,0x30,0x04,0xab,0x10,0x2c,0x04,0x90,0x10,0x28,0x04,0x76,0x10,0x23,0x04,0x5b,0x10,0x1f,0x04,0x41,0x10,0x1a,0x04,0x27,0x10,0x16,0x04,0x0d,0x10,0x11,0x04,0xf3,0x0f,0x0c,0x04,0xd9,0x0f,0x07,0x04,0xbf,0x0f,0x02,0x04,0xa6,0x0f,0xfd,0x03,0x8c,0x0f,0xf7,0x03,0x73,0x0f,0xf2,0x03,0x5a,0x0f,0xec,0x03,0x42,0x0f,0xe7,0x03,0x29,0x0f,0xe1,0x03,0x11,0x0f,0xdb,0x03,0xf9,0x0e,0xd5,0x03,  \
    0xe1,0x0e,0xcf,0x03,0xc9,0x0e,0xc9,0x03,0xb1,0x0e,0xc3,0x03,0x99,0x0e,0xbc,0x03,0x82,0x0e,0xb6,0x03,0x6a,0x0e,0xb0,0x03,0x53,0x0e,0xa9,0x03,0x3c,0x0e,0xa3,0x03,0x25,0x0e,0x9d,0x03,0x0e,0x0e,0x96,0x03,0xf7,0x0d,0x90,0x03,0xe1,0x0d,0x89,0x03,0xca,0x0d,0x82,0x03,0xb4,0x0d,0x7c,0x03,0x9d,0x0d,0x75,0x03,0x88,0x0d,0x6d,0x03,0x72,0x0d,0x66,0x03,0x5d,0x0d,0x5f,0x03,0x48,0x0d,0x58,0x03,0x33,0x0d,0x50,0x03,0x1e,0x0d,0x49,0x03,0x09,0x0d,0x42,0x03,0xf4,0x0c,  \
    0x3a,0x03,0xe0,0x0c,0x33,0x03,0xcb,0x0c,0x2b,0x03,0xb7,0x0c,0x24,0x03,0xa3,0x0c,0x1d,0x03,0x8f,0x0c,0x15,0x03,0x7b,0x0c,0x0e,0x03,0x67,0x0c,0x06,0x03,0x53,0x0c,0xff,0x02,0x40,0x0c,0xf7,0x02,0x2c,0x0c,0xf1,0x02,0x16,0x0c,0xeb,0x02,0x01,0x0c,0xe4,0x02,0xeb,0x0b,0xde,0x02,0xd6,0x0b,0xd8,0x02,0xc1,0x0b,0xd2,0x02,0xac,0x0b,0xcb,0x02,0x97,0x0b,0xc5,0x02,0x82,0x0b,0xbf,0x02,0x6d,0x0b,0xb8,0x02,0x58,0x0b,0xb2,0x02,0x43,0x0b,0xac,0x02,0x2f,0x0b,0xa6,0x02,  \
    0x1a,0x0b,0x9f,0x02,0x06,0x0b,0x99,0x02,0xf1,0x0a,0x93,0x02,0xdd,0x0a,0x8d,0x02,0xc8,0x0a,0x87,0x02,0xb4,0x0a,0x80,0x02,0xa0,0x0a,0x7a,0x02,0x8b,0x0a,0x74,0x02,0x77,0x0a,0x6e,0x02,0x63,0x0a,0x68,0x02,0x4f,0x0a,0x62,0x02,0x3b,0x0a,0x5c,0x02,0x27,0x0a,0x55,0x02,0x13,0x0a,0x4f,0x02,0x00,0x0a,0x49,0x02,0xec,0x09,0x43,0x02,0xd8,0x09,0x3d,0x02,0xc4,0x09,0x37,0x02,0xb1,0x09,0x31,0x02,0x9d,0x09,0x2c,0x02,0x8a,0x09,0x26,0x02,0x76,0x09,0x20,0x02,0x63,0x09,  \
    0x1a,0x02,0x50,0x09,0x13,0x02,0x3f,0x09,0x0c,0x02,0x2d,0x09,0x06,0x02,0x1c,0x09,0xff,0x01,0x0b,0x09,0xf9,0x01,0xf9,0x08,0xf2,0x01,0xe8,0x08,0xec,0x01,0xd7,0x08,0xe5,0x01,0xc6,0x08,0xdf,0x01,0xb5,0x08,0xd8,0x01,0xa4,0x08,0xd2,0x01,0x93,0x08,0xcc,0x01,0x82,0x08,0xc6,0x01,0x71,0x08,0xbf,0x01,0x60,0x08,0xb9,0x01,0x50,0x08,0xb3,0x01,0x3f,0x08,0xad,0x01,0x2e,0x08,0xa7,0x01,0x1e,0x08,0xa1,0x01,0x0d,0x08,0x9b,0x01,0xfc,0x07,0x95,0x01,0xec,0x07,0x90,0x01,  \
    0xdb,0x07,0x8a,0x01,0xca,0x07,0x84,0x01,0xb9,0x07,0x7f,0x01,0xa8,0x07,0x79,0x01,0x98,0x07,0x74,0x01,0x87,0x07,0x6e,0x01,0x76,0x07,0x69,0x01,0x66,0x07,0x64,0x01,0x55,0x07,0x5e,0x01,0x44,0x07,0x59,0x01,0x34,0x07,0x54,0x01,0x23,0x07,0x4f,0x01,0x13,0x07,0x4a,0x01,0x02,0x07,0x44,0x01,0xf2,0x06,0x3f,0x01,0xe1,0x06,0x3a,0x01,0xd1,0x06,0x35,0x01,0xc0,0x06,0x31,0x01,0xb0,0x06,0x2c,0x01,0xa0,0x06,0x27,0x01,0x8f,0x06,0x22,0x01,0x7f,0x06,0x1e,0x01,0x6d,0x06,  \
    0x1a,0x01,0x5c,0x06,0x15,0x01,0x4a,0x06,0x11,0x01,0x39,0x06,0x0d,0x01,0x28,0x06,0x09,0x01,0x16,0x06,0x05,0x01,0x05,0x06,0x00,0x01,0xf4,0x05,0xfc,0x00,0xe2,0x05,0xf8,0x00,0xd1,0x05,0xf4,0x00,0xc0,0x05,0xf0,0x00,0xaf,0x05,0xed,0x00,0x9e,0x05,0xe9,0x00,0x8c,0x05,0xe5,0x00,0x7b,0x05,0xe1,0x00,0x6a,0x05,0xdd,0x00,0x59,0x05,0xda,0x00,0x48,0x05,0xd6,0x00,0x37,0x05,0xd2,0x00,0x26,0x05,0xcf,0x00,0x15,0x05,0xcb,0x00,0x04,0x05,0xc8,0x00,0xf3,0x04,0xc4,0x00,  \
    0xe2,0x04,0xc0,0x00,0xd2,0x04,0xbd,0x00,0xc2,0x04,0xb9,0x00,0xb2,0x04,0xb6,0x00,0xa2,0x04,0xb2,0x00,0x92,0x04,0xaf,0x00,0x82,0x04,0xac,0x00,0x72,0x04,0xa8,0x00,0x62,0x04,0xa5,0x00,0x52,0x04,0xa2,0x00,0x42,0x04,0x9f,0x00,0x31,0x04,0x9c,0x00,0x21,0x04,0x99,0x00,0x11,0x04,0x96,0x00,0x01,0x04,0x93,0x00,0xf1,0x03,0x90,0x00,0xe1,0x03,0x8d,0x00,0xd1,0x03,0x8a,0x00,0xc1,0x03,0x87,0x00,0xb1,0x03,0x84,0x00,0xa1,0x03,0x82,0x00,0x91,0x03,0x7f,0x00,0x81,0x03,  \
    0x7c,0x00,0x71,0x03,0x7a,0x00,0x61,0x03,0x77,0x00,0x51,0x03,0x75,0x00,0x42,0x03,0x72,0x00,0x32,0x03,0x70,0x00,0x23,0x03,0x6d,0x00,0x14,0x03,0x6b,0x00,0x04,0x03,0x69,0x00,0xf5,0x02,0x66,0x00,0xe5,0x02,0x64,0x00,0xd6,0x02,0x62,0x00,0xc7,0x02,0x60,0x00,0xb7,0x02,0x5e,0x00,0xa8,0x02,0x5c,0x00,0x98,0x02,0x5a,0x00,0x89,0x02,0x58,0x00,0x79,0x02,0x56,0x00,0x6a,0x02,0x54,0x00,0x5a,0x02,0x52,0x00,0x4b,0x02,0x51,0x00,0x3b,0x02,0x4f,0x00,0x2b,0x02,0x4d,0x00,  \
    0x1c,0x02,0x4c,0x00,0x0c,0x02,0x4a,0x00,0xfc,0x01,0x49,0x00,0xed,0x01,0x47,0x00,0xdd,0x01,0x46,0x00,0xcd,0x01,0x44,0x00,0xbd,0x01,0x43,0x00,0xae,0x01,0x42,0x00,0x9e,0x01,0x41,0x00,0x8e,0x01,0x40,0x00,0x7d,0x01,0x3e,0x00,0x6d,0x01,0x3d,0x00,0x5d,0x01,0x3c,0x00,0x4d,0x01,0x3b,0x00,0x3c,0x01,0x3a,0x00,0x2c,0x01,0x3a,0x00,0x1c,0x01,0x39,0x00,0x0c,0x01,0x38,0x00,0xfb,0x00,0x37,0x00,0xeb,0x00,0x36,0x00,0xdb,0x00,0x36,0x00,0xcb,0x00,0x35,0x00,0xbb,0x00,  \
    0x34,0x00,0xaa,0x00,0x34,0x00,0x9a,0x00,0x33,0x00,0x8a,0x00,0x33,0x00,0x7a,0x00,0x32,0x00,0x69,0x00,0x32,0x00,0x59,0x00,0x32,0x00,0x49,0x00,0x31,0x00,0x39,0x00,0x31,0x00,0x29,0x00,0x31,0x00,0x18,0x00,0x31,0x00,0x08,0x00,0x30,0x00,0xf8,0xff,0x30,0x00,0xe8,0xff,0x30,0x00,0xd7,0xff,0x30,0x00,0xc7,0xff,0x30,0x00,0xb7,0xff,0x30,0x00,0xa7,0xff,0x30,0x00,0x97,0xff,0x30,0x00,0x86,0xff,0x31,0x00,0x76,0xff,0x31,0x00,0x66,0xff,0x31,0x00,0x56,0xff,0x31,0x00,  \
    0x45,0xff,0x32,0x00,0x35,0xff,0x32,0x00,0x25,0xff,0x32,0x00,0x15,0xff,0x33,0x00,0x05,0xff,0x33,0x00,0xf4,0xfe,0x34,0x00,0xe4,0xfe,0x34,0x00,0xd4,0xfe,0x35,0x00,0xc4,0xfe,0x36,0x00,0xb4,0xfe,0x36,0x00,0xa3,0xfe,0x37,0x00,0x93,0xfe,0x38,0x00,0x83,0xfe,0x39,0x00,0x73,0xfe,0x3a,0x00,0x63,0xfe,0x3a,0x00,0x52,0xfe,0x3b,0x00,0x42,0xfe,0x3c,0x00,0x32,0xfe,0x3d,0x00,0x22,0xfe,0x3e,0x00,0x12,0xfe,0x3f,0x00,0x01,0xfe,0x41,0x00,0xf1,0xfd,0x42,0x00,0xe0,0xfd,  \
    0x43,0x00,0xd0,0xfd,0x44,0x00,0xc0,0xfd,0x45,0x00,0xaf,0xfd,0x47,0x00,0x9f,0xfd,0x48,0x00,0x8e,0xfd,0x49,0x00,0x7e,0xfd,0x4b,0x00,0x6d,0xfd,0x4c,0x00,0x5d,0xfd,0x4e,0x00,0x4c,0xfd,0x4f,0x00,0x3c,0xfd,0x51,0x00,0x2b,0xfd,0x53,0x00,0x1a,0xfd,0x54,0x00,0x0a,0xfd,0x56,0x00,0xf9,0xfc,0x58,0x00,0xe9,0xfc,0x59,0x00,0xd8,0xfc,0x5b,0x00,0xc7,0xfc,0x5d,0x00,0xb7,0xfc,0x5f,0x00,0xa6,0xfc,0x61,0x00,0x95,0xfc,0x63,0x00,0x85,0xfc,0x65,0x00,0x74,0xfc,0x67,0x00,  \
    0x63,0xfc,0x69,0x00,0x53,0xfc,0x6b,0x00,0x42,0xfc,0x6d,0x00,0x32,0xfc,0x6f,0x00,0x22,0xfc,0x72,0x00,0x11,0xfc,0x74,0x00,0x01,0xfc,0x76,0x00,0xf1,0xfb,0x79,0x00,0xe1,0xfb,0x7b,0x00,0xd1,0xfb,0x7e,0x00,0xc1,0xfb,0x81,0x00,0xb1,0xfb,0x83,0x00,0xa0,0xfb,0x86,0x00,0x90,0xfb,0x89,0x00,0x80,0xfb,0x8b,0x00,0x70,0xfb,0x8e,0x00,0x60,0xfb,0x91,0x00,0x50,0xfb,0x94,0x00,0x40,0xfb,0x97,0x00,0x30,0xfb,0x9a,0x00,0x1f,0xfb,0x9d,0x00,0x0f,0xfb,0xa0,0x00,0xff,0xfa,  \
    0xa3,0x00,0xef,0xfa,0xa6,0x00,0xdf,0xfa,0xa9,0x00,0xcf,0xfa,0xac,0x00,0xbf,0xfa,0xb0,0x00,0xaf,0xfa,0xb3,0x00,0x9f,0xfa,0xb6,0x00,0x8e,0xfa,0xba,0x00,0x7e,0xfa,0xbd,0x00,0x6d,0xfa,0xc1,0x00,0x5c,0xfa,0xc4,0x00,0x4b,0xfa,0xc7,0x00,0x3b,0xfa,0xcb,0x00,0x2a,0xfa,0xce,0x00,0x19,0xfa,0xd2,0x00,0x08,0xfa,0xd6,0x00,0xf8,0xf9,0xd9,0x00,0xe7,0xf9,0xdd,0x00,0xd6,0xf9,0xe1,0x00,0xc5,0xf9,0xe5,0x00,0xb4,0xf9,0xe8,0x00,0xa4,0xf9,0xec,0x00,0x93,0xf9,0xf0,0x00,  \
    0x82,0xf9,0xf4,0x00,0x71,0xf9,0xf8,0x00,0x60,0xf9,0xfc,0x00,0x4f,0xf9,0x00,0x01,0x3e,0xf9,0x04,0x01,0x2d,0xf9,0x09,0x01,0x1c,0xf9,0x0d,0x01,0x0b,0xf9,0x11,0x01,0xfa,0xf8,0x15,0x01,0xe9,0xf8,0x1a,0x01,0xd9,0xf8,0x1e,0x01,0xc8,0xf8,0x23,0x01,0xb7,0xf8,0x27,0x01,0xa7,0xf8,0x2c,0x01,0x96,0xf8,0x31,0x01,0x85,0xf8,0x35,0x01,0x74,0xf8,0x3a,0x01,0x63,0xf8,0x3f,0x01,0x53,0xf8,0x44,0x01,0x42,0xf8,0x49,0x01,0x31,0xf8,0x4d,0x01,0x20,0xf8,0x52,0x01,0x0f,0xf8,  \
    0x57,0x01,0xfe,0xf7,0x5c,0x01,0xed,0xf7,0x61,0x01,0xdc,0xf7,0x67,0x01,0xcb,0xf7,0x6c,0x01,0xba,0xf7,0x71,0x01,0xa9,0xf7,0x76,0x01,0x98,0xf7,0x7b,0x01,0x87,0xf7,0x81,0x01,0x76,0xf7,0x86,0x01,0x64,0xf7,0x8b,0x01,0x52,0xf7,0x90,0x01,0x41,0xf7,0x96,0x01,0x2f,0xf7,0x9b,0x01,0x1d,0xf7,0xa0,0x01,0x0b,0xf7,0xa6,0x01,0xf9,0xf6,0xab,0x01,0xe7,0xf6,0xb1,0x01,0xd5,0xf6,0xb6,0x01,0xc3,0xf6,0xbc,0x01,0xb1,0xf6,0xc1,0x01,0x9f,0xf6,0xc7,0x01,0x8d,0xf6,0xcc,0x01,  \
    0x7b,0xf6,0xd2,0x01,0x69,0xf6,0xd8,0x01,0x57,0xf6,0xdd,0x01,0x44,0xf6,0xe3,0x01,0x32,0xf6,0xe9,0x01,0x20,0xf6,0xef,0x01,0x0d,0xf6,0xf5,0x01,0xfb,0xf5,0xfa,0x01,0xe9,0xf5,0x01,0x02,0xd6,0xf5,0x07,0x02,0xc4,0xf5,0x0d,0x02,0xb2,0xf5,0x13,0x02,0xa0,0xf5,0x19,0x02,0x8d,0xf5,0x1f,0x02,0x7b,0xf5,0x25,0x02,0x68,0xf5,0x2c,0x02,0x56,0xf5,0x32,0x02,0x43,0xf5,0x38,0x02,0x31,0xf5,0x3f,0x02,0x1e,0xf5,0x45,0x02,0x0b,0xf5,0x4b,0x02,0xf8,0xf4,0x52,0x02,0xe5,0xf4,  \
    0x58,0x02,0xd2,0xf4,0x5e,0x02,0xbf,0xf4,0x65,0x02,0xac,0xf4,0x6b,0x02,0x99,0xf4,0x72,0x02,0x86,0xf4,0x78,0x02,0x71,0xf4,0x7d,0x02,0x5d,0xf4,0x83,0x02,0x48,0xf4,0x89,0x02,0x33,0xf4,0x8f,0x02,0x1f,0xf4,0x95,0x02,0x0a,0xf4,0x9b,0x02,0xf5,0xf3,0xa1,0x02,0xe0,0xf3,0xa7,0x02,0xcb,0xf3,0xad,0x02,0xb6,0xf3,0xb2,0x02,0xa1,0xf3,0xb8,0x02,0x8b,0xf3,0xbe,0x02,0x76,0xf3,0xc4,0x02,0x61,0xf3,0xca,0x02,0x4b,0xf3,0xd0,0x02,0x35,0xf3,0xd6,0x02,0x20,0xf3,0xdc,0x02,  \
    0x0a,0xf3,0xe2,0x02,0xf5,0xf2,0xe8,0x02,0xe0,0xf2,0xef,0x02,0xcb,0xf2,0xf5,0x02,0xb6,0xf2,0xfb,0x02,0xa1,0xf2,0x02,0x03,0x8b,0xf2,0x08,0x03,0x76,0xf2,0x0f,0x03,0x61,0xf2,0x15,0x03,0x4b,0xf2,0x1b,0x03,0x35,0xf2,0x21,0x03,0x20,0xf2,0x28,0x03,0x0a,0xf2,0x2e,0x03,0xf4,0xf1,0x34,0x03,0xdd,0xf1,0x3a,0x03,0xc7,0xf1,0x40,0x03,0xb1,0xf1,0x46,0x03,0x9a,0xf1,0x4c,0x03,0x84,0xf1,0x52,0x03,0x6d,0xf1,0x58,0x03,0x56,0xf1,0x5e,0x03,0x40,0xf1,0x64,0x03,0x29,0xf1,  \
    0x6a,0x03,0x12,0xf1,0x70,0x03,0xfa,0xf0,0x76,0x03,0xe3,0xf0,0x7c,0x03,0xcc,0xf0,0x81,0x03,0xb4,0xf0,0x87,0x03,0x9c,0xf0,0x8d,0x03,0x84,0xf0,0x92,0x03,0x6c,0xf0,0x97,0x03,0x54,0xf0,0x9d,0x03,0x3c,0xf0,0xa2,0x03,0x23,0xf0,0xa7,0x03,0x0a,0xf0,0xac,0x03,0xf2,0xef,0xb1,0x03,0xd9,0xef,0xb6,0x03,0xc0,0xef,0xbb,0x03,0xa6,0xef,0xc0,0x03,0x8d,0xef,0xc4,0x03,0x73,0xef,0xc8,0x03,0x59,0xef,0xcc,0x03,0x3e,0xef,0xd0,0x03,0x24,0xef,0xd4,0x03,0x09,0xef,0xd8,0x03,  \
    0xee,0xee,0xdb,0x03,0xd3,0xee,0xdf,0x03,0xb7,0xee,0xe2,0x03,0x9c,0xee,0xe5,0x03,0x81,0xee,0xe9,0x03,0x65,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3e,0x04,0x63,0x11,0x3b,0x04,0x47,0x11,  \
    0x37,0x04,0x2b,0x11,0x33,0x04,0x10,0x11,0x2f,0x04,0xf4,0x10,0x2c,0x04,0xd9,0x10,0x28,0x04,0xbe,0x10,0x23,0x04,0xa3,0x10,0x1f,0x04,0x88,0x10,0x1b,0x04,0x6e,0x10,0x16,0x04,0x53,0x10,0x12,0x04,0x39,0x10,0x0d,0x04,0x1f,0x10,0x09,0x04,0x05,0x10,0x04,0x04,0xeb,0x0f,0xff,0x03,0xd1,0x0f,0xfa,0x03,0xb7,0x0f,0xf5,0x03,0x9e,0x0f,0xf0,0x03,0x84,0x0f,0xeb,0x03,0x6b,0x0f,0xe5,0x03,0x52,0x0f,0xe0,0x03,0x39,0x0f,0xda,0x03,0x21,0x0f,0xd4,0x03,0x09,0x0f,0xce,0x03,  \
    0xf0,0x0e,0xc9,0x03,0xd8,0x0e,0xc3,0x03,0xc0,0x0e,0xbd,0x03,0xa9,0x0e,0xb6,0x03,0x91,0x0e,0xb0,0x03,0x79,0x0e,0xaa,0x03,0x62,0x0e,0xa4,0x03,0x4b,0x0e,0x9e,0x03,0x33,0x0e,0x97,0x03,0x1c,0x0e,0x91,0x03,0x05,0x0e,0x8a,0x03,0xef,0x0d,0x84,0x03,0xd8,0x0d,0x7d,0x03,0xc1,0x0d,0x77,0x03,0xab,0x0d,0x70,0x03,0x95,0x0d,0x69,0x03,0x7f,0x0d,0x62,0x03,0x69,0x0d,0x5b,0x03,0x54,0x0d,0x54,0x03,0x3f,0x0d,0x4c,0x03,0x2a,0x0d,0x45,0x03,0x15,0x0d,0x3e,0x03,0x00,0x0d,  \
    0x37,0x03,0xeb,0x0c,0x2f,0x03,0xd6,0x0c,0x28,0x03,0xc2,0x0c,0x21,0x03,0xae,0x0c,0x19,0x03,0x99,0x0c,0x12,0x03,0x85,0x0c,0x0a,0x03,0x71,0x0c,0x03,0x03,0x5d,0x0c,0xfc,0x02,0x49,0x0c,0xf4,0x02,0x36,0x0c,0xed,0x02,0x22,0x0c,0xe7,0x02,0x0c,0x0c,0xe0,0x02,0xf7,0x0b,0xda,0x02,0xe2,0x0b,0xd4,0x02,0xcc,0x0b,0xce,0x02,0xb7,0x0b,0xc7,0x02,0xa2,0x0b,0xc1,0x02,0x8d,0x0b,0xbb,0x02,0x78,0x0b,0xb4,0x02,0x63,0x0b,0xae,0x02,0x4e,0x0b,0xa8,0x02,0x3a,0x0b,0xa2,0x02,  \
    0x25,0x0b,0x9b,0x02,0x10,0x0b,0x95,0x02,0xfc,0x0a,0x8f,0x02,0xe7,0x0a,0x89,0x02,0xd3,0x0a,0x83,0x02,0xbf,0x0a,0x7c,0x02,0xaa,0x0a,0x76,0x02,0x96,0x0a,0x70,0x02,0x82,0x0a,0x6a,0x02,0x6e,0x0a,0x64,0x02,0x5a,0x0a,0x5e,0x02,0x46,0x0a,0x58,0x02,0x32,0x0a,0x51,0x02,0x1e,0x0a,0x4b,0x02,0x0a,0x0a,0x45,0x02,0xf6,0x09,0x3f,0x02,0xe2,0x09,0x39,0x02,0xcf,0x09,0x33,0x02,0xbb,0x09,0x2d,0x02,0xa7,0x09,0x27,0x02,0x94,0x09,0x21,0x02,0x81,0x09,0x1c,0x02,0x6d,0x09,  \
    0x16,0x02,0x5a,0x09,0x10,0x02,0x47,0x09,0x09,0x02,0x35,0x09,0x02,0x02,0x24,0x09,0xfc,0x01,0x13,0x09,0xf5,0x01,0x01,0x09,0xef,0x01,0xf0,0x08,0xe8,0x01,0xdf,0x08,0xe2,0x01,0xce,0x08,0xdb,0x01,0xbd,0x08,0xd5,0x01,0xac,0x08,0xcf,0x01,0x9b,0x08,0xc8,0x01,0x8a,0x08,0xc2,0x01,0x79,0x08,0xbc,0x01,0x68,0x08,0xb6,0x01,0x57,0x08,0xb0,0x01,0x46,0x08,0xa9,0x01,0x36,0x08,0xa3,0x01,0x25,0x08,0x9d,0x01,0x14,0x08,0x98,0x01,0x04,0x08,0x92,0x01,0xf3,0x07,0x8c,0x01,  \
    0xe2,0x07,0x86,0x01,0xd1,0x07,0x80,0x01,0xc1,0x07,0x7b,0x01,0xb0,0x07,0x75,0x01,0x9f,0x07,0x70,0x01,0x8e,0x07,0x6a,0x01,0x7e,0x07,0x65,0x01,0x6d,0x07,0x5f,0x01,0x5d,0x07,0x5a,0x01,0x4c,0x07,0x55,0x01,0x3b,0x07,0x50,0x01,0x2b,0x07,0x4a,0x01,0x1a,0x07,0x45,0x01,0x0a,0x07,0x40,0x01,0xf9,0x06,0x3b,0x01,0xe9,0x06,0x36,0x01,0xd8,0x06,0x31,0x01,0xc8,0x06,0x2c,0x01,0xb8,0x06,0x27,0x01,0xa7,0x06,0x22,0x01,0x97,0x06,0x1e,0x01,0x87,0x06,0x19,0x01,0x76,0x06,  \
    0x14,0x01,0x65,0x06,0x10,0x01,0x53,0x06,0x0c,0x01,0x42,0x06,0x08,0x01,0x31,0x06,0x03,0x01,0x1f,0x06,0xff,0x00,0x0e,0x06,0xfb,0x00,0xfd,0x05,0xf7,0x00,0xec,0x05,0xf3,0x00,0xdb,0x05,0xef,0x00,0xc9,0x05,0xeb,0x00,0xb8,0x05,0xe7,0x00,0xa7,0x05,0xe3,0x00,0x96,0x05,0xdf,0x00,0x85,0x05,0xdb,0x00,0x74,0x05,0xd8,0x00,0x63,0x05,0xd4,0x00,0x52,0x05,0xd0,0x00,0x41,0x05,0xcc,0x00,0x30,0x05,0xc9,0x00,0x1f,0x05,0xc5,0x00,0x0e,0x05,0xc2,0x00,0xfd,0x04,0xbe,0x00,  \
    0xec,0x04,0xba,0x00,0xdc,0x04,0xb7,0x00,0xcc,0x04,0xb3,0x00,0xbb,0x04,0xb0,0x00,0xab,0x04,0xac,0x00,0x9b,0x04,0xa9,0x00,0x8b,0x04,0xa5,0x00,0x7b,0x04,0xa2,0x00,0x6b,0x04,0x9f,0x00,0x5b,0x04,0x9c,0x00,0x4b,0x04,0x98,0x00,0x3b,0x04,0x95,0x00,0x2b,0x04,0x92,0x00,0x1b,0x04,0x8f,0x00,0x0b,0x04,0x8c,0x00,0xfb,0x03,0x89,0x00,0xec,0x03,0x86,0x00,0xdc,0x03,0x83,0x00,0xcc,0x03,0x80,0x00,0xbc,0x03,0x7e,0x00,0xac,0x03,0x7b,0x00,0x9c,0x03,0x78,0x00,0x8c,0x03,  \
    0x75,0x00,0x7c,0x03,0x73,0x00,0x6c,0x03,0x70,0x00,0x5c,0x03,0x6e,0x00,0x4c,0x03,0x6b,0x00,0x3d,0x03,0x69,0x00,0x2d,0x03,0x66,0x00,0x1e,0x03,0x64,0x00,0x0f,0x03,0x61,0x00,0x00,0x03,0x5f,0x00,0xf0,0x02,0x5d,0x00,0xe1,0x02,0x5b,0x00,0xd2,0x02,0x58,0x00,0xc2,0x02,0x56,0x00,0xb3,0x02,0x54,0x00,0xa3,0x02,0x52,0x00,0x94,0x02,0x50,0x00,0x85,0x02,0x4e,0x00,0x75,0x02,0x4c,0x00,0x66,0x02,0x4a,0x00,0x56,0x02,0x49,0x00,0x47,0x02,0x47,0x00,0x37,0x02,0x45,0x00,  \
    0x28,0x02,0x44,0x00,0x18,0x02,0x42,0x00,0x09,0x02,0x40,0x00,0xf9,0x01,0x3f,0x00,0xe9,0x01,0x3e,0x00,0xda,0x01,0x3c,0x00,0xca,0x01,0x3b,0x00,0xba,0x01,0x39,0x00,0xab,0x01,0x38,0x00,0x9b,0x01,0x37,0x00,0x8b,0x01,0x36,0x00,0x7b,0x01,0x35,0x00,0x6a,0x01,0x34,0x00,0x5a,0x01,0x33,0x00,0x4a,0x01,0x32,0x00,0x3a,0x01,0x31,0x00,0x2a,0x01,0x30,0x00,0x1a,0x01,0x2f,0x00,0x0a,0x01,0x2e,0x00,0xfa,0x00,0x2d,0x00,0xe9,0x00,0x2d,0x00,0xd9,0x00,0x2c,0x00,0xc9,0x00,  \
    0x2b,0x00,0xb9,0x00,0x2b,0x00,0xa9,0x00,0x2a,0x00,0x99,0x00,0x2a,0x00,0x89,0x00,0x29,0x00,0x79,0x00,0x29,0x00,0x68,0x00,0x28,0x00,0x58,0x00,0x28,0x00,0x48,0x00,0x28,0x00,0x38,0x00,0x27,0x00,0x28,0x00,0x27,0x00,0x18,0x00,0x27,0x00,0x08,0x00,0x27,0x00,0xf8,0xff,0x27,0x00,0xe7,0xff,0x26,0x00,0xd7,0xff,0x26,0x00,0xc7,0xff,0x26,0x00,0xb7,0xff,0x26,0x00,0xa7,0xff,0x27,0x00,0x97,0xff,0x27,0x00,0x87,0xff,0x27,0x00,0x77,0xff,0x27,0x00,0x66,0xff,0x27,0x00,  \
    0x56,0xff,0x28,0x00,0x46,0xff,0x28,0x00,0x36,0xff,0x28,0x00,0x26,0xff,0x29,0x00,0x16,0xff,0x29,0x00,0x06,0xff,0x2a,0x00,0xf6,0xfe,0x2a,0x00,0xe6,0xfe,0x2b,0x00,0xd5,0xfe,0x2b,0x00,0xc5,0xfe,0x2c,0x00,0xb5,0xfe,0x2d,0x00,0xa5,0xfe,0x2d,0x00,0x95,0xfe,0x2e,0x00,0x85,0xfe,0x2f,0x00,0x75,0xfe,0x30,0x00,0x65,0xfe,0x31,0x00,0x55,0xfe,0x32,0x00,0x45,0xfe,0x33,0x00,0x34,0xfe,0x34,0x00,0x24,0xfe,0x35,0x00,0x14,0xfe,0x36,0x00,0x04,0xfe,0x37,0x00,0xf4,0xfd,  \
    0x38,0x00,0xe3,0xfd,0x39,0x00,0xd3,0xfd,0x3a,0x00,0xc3,0xfd,0x3c,0x00,0xb2,0xfd,0x3d,0x00,0xa2,0xfd,0x3e,0x00,0x92,0xfd,0x40,0x00,0x81,0xfd,0x41,0x00,0x71,0xfd,0x43,0x00,0x60,0xfd,0x44,0x00,0x50,0xfd,0x46,0x00,0x40,0xfd,0x47,0x00,0x2f,0xfd,0x49,0x00,0x1f,0xfd,0x4b,0x00,0x0e,0xfd,0x4c,0x00,0xfe,0xfc,0x4e,0x00,0xed,0xfc,0x50,0x00,0xdd,0xfc,0x52,0x00,0xcc,0xfc,0x53,0x00,0xbc,0xfc,0x55,0x00,0xab,0xfc,0x57,0x00,0x9a,0xfc,0x59,0x00,0x8a,0xfc,0x5b,0x00,  \
    0x79,0xfc,0x5d,0x00,0x69,0xfc,0x5f,0x00,0x58,0xfc,0x61,0x00,0x47,0xfc,0x64,0x00,0x37,0xfc,0x66,0x00,0x27,0xfc,0x68,0x00,0x17,0xfc,0x6b,0x00,0x07,0xfc,0x6d,0x00,0xf7,0xfb,0x6f,0x00,0xe7,0xfb,0x72,0x00,0xd7,0xfb,0x74,0x00,0xc7,0xfb,0x77,0x00,0xb7,0xfb,0x7a,0x00,0xa7,0xfb,0x7c,0x00,0x97,0xfb,0x7f,0x00,0x87,0xfb,0x82,0x00,0x77,0xfb,0x85,0x00,0x67,0xfb,0x87,0x00,0x57,0xfb,0x8a,0x00,0x47,0xfb,0x8d,0x00,0x36,0xfb,0x90,0x00,0x26,0xfb,0x93,0x00,0x16,0xfb,  \
    0x96,0x00,0x06,0xfb,0x99,0x00,0xf6,0xfa,0x9d,0x00,0xe6,0xfa,0xa0,0x00,0xd6,0xfa,0xa3,0x00,0xc6,0xfa,0xa6,0x00,0xb6,0xfa,0xaa,0x00,0xa6,0xfa,0xad,0x00,0x96,0xfa,0xb0,0x00,0x85,0xfa,0xb4,0x00,0x75,0xfa,0xb7,0x00,0x64,0xfa,0xbb,0x00,0x53,0xfa,0xbe,0x00,0x43,0xfa,0xc2,0x00,0x32,0xfa,0xc5,0x00,0x21,0xfa,0xc9,0x00,0x11,0xfa,0xcc,0x00,0x00,0xfa,0xd0,0x00,0xef,0xf9,0xd4,0x00,0xde,0xf9,0xd8,0x00,0xce,0xf9,0xdb,0x00,0xbd,0xf9,0xdf,0x00,0xac,0xf9,0xe3,0x00,  \
    0x9b,0xf9,0xe7,0x00,0x8b,0xf9,0xeb,0x00,0x7a,0xf9,0xef,0x00,0x69,0xf9,0xf3,0x00,0x58,0xf9,0xf7,0x00,0x47,0xf9,0xfb,0x00,0x36,0xf9,0xff,0x00,0x25,0xf9,0x04,0x01,0x14,0xf9,0x08,0x01,0x04,0xf9,0x0c,0x01,0xf3,0xf8,0x11,0x01,0xe2,0xf8,0x15,0x01,0xd1,0xf8,0x1a,0x01,0xc1,0xf8,0x1e,0x01,0xb0,0xf8,0x23,0x01,0x9f,0xf8,0x27,0x01,0x8f,0xf8,0x2c,0x01,0x7e,0xf8,0x31,0x01,0x6d,0xf8,0x36,0x01,0x5c,0xf8,0x3a,0x01,0x4b,0xf8,0x3f,0x01,0x3b,0xf8,0x44,0x01,0x2a,0xf8,  \
    0x49,0x01,0x19,0xf8,0x4e,0x01,0x08,0xf8,0x53,0x01,0xf7,0xf7,0x58,0x01,0xe6,0xf7,0x5d,0x01,0xd5,0xf7,0x63,0x01,0xc4,0xf7,0x68,0x01,0xb3,0xf7,0x6d,0x01,0xa2,0xf7,0x72,0x01,0x91,0xf7,0x78,0x01,0x80,0xf7,0x7d,0x01,0x6e,0xf7,0x82,0x01,0x5d,0xf7,0x87,0x01,0x4b,0xf7,0x8c,0x01,0x39,0xf7,0x92,0x01,0x27,0xf7,0x97,0x01,0x16,0xf7,0x9d,0x01,0x04,0xf7,0xa2,0x01,0xf2,0xf6,0xa7,0x01,0xe0,0xf6,0xad,0x01,0xce,0xf6,0xb2,0x01,0xbc,0xf6,0xb8,0x01,0xaa,0xf6,0xbe,0x01,  \
    0x98,0xf6,0xc3,0x01,0x86,0xf6,0xc9,0x01,0x74,0xf6,0xce,0x01,0x61,0xf6,0xd4,0x01,0x4f,0xf6,0xda,0x01,0x3d,0xf6,0xe0,0x01,0x2b,0xf6,0xe5,0x01,0x18,0xf6,0xeb,0x01,0x06,0xf6,0xf1,0x01,0xf3,0xf5,0xf7,0x01,0xe1,0xf5,0xfd,0x01,0xcf,0xf5,0x03,0x02,0xbd,0xf5,0x0a,0x02,0xaa,0xf5,0x10,0x02,0x98,0xf5,0x16,0x02,0x86,0xf5,0x1c,0x02,0x73,0xf5,0x22,0x02,0x61,0xf5,0x28,0x02,0x4e,0xf5,0x2f,0x02,0x3b,0xf5,0x35,0x02,0x29,0xf5,0x3b,0x02,0x16,0xf5,0x42,0x02,0x03,0xf5,  \
    0x48,0x02,0xf0,0xf4,0x4e,0x02,0xdd,0xf4,0x55,0x02,0xca,0xf4,0x5b,0x02,0xb7,0xf4,0x62,0x02,0xa4,0xf4,0x68,0x02,0x91,0xf4,0x6e,0x02,0x7c,0xf4,0x74,0x02,0x68,0xf4,0x7a,0x02,0x53,0xf4,0x80,0x02,0x3e,0xf4,0x85,0x02,0x2a,0xf4,0x8b,0x02,0x15,0xf4,0x91,0x02,0x00,0xf4,0x97,0x02,0xeb,0xf3,0x9d,0x02,0xd6,0xf3,0xa3,0x02,0xc1,0xf3,0xa9,0x02,0xac,0xf3,0xaf,0x02,0x96,0xf3,0xb4,0x02,0x81,0xf3,0xba,0x02,0x6c,0xf3,0xc0,0x02,0x56,0xf3,0xc6,0x02,0x40,0xf3,0xcc,0x02,  \
    0x2b,0xf3,0xd2,0x02,0x15,0xf3,0xd8,0x02,0x00,0xf3,0xde,0x02,0xeb,0xf2,0xe5,0x02,0xd6,0xf2,0xeb,0x02,0xc1,0xf2,0xf1,0x02,0xab,0xf2,0xf8,0x02,0x96,0xf2,0xfe,0x02,0x81,0xf2,0x04,0x03,0x6b,0xf2,0x0b,0x03,0x56,0xf2,0x11,0x03,0x40,0xf2,0x17,0x03,0x2a,0xf2,0x1d,0x03,0x14,0xf2,0x24,0x03,0xfe,0xf1,0x2a,0x03,0xe8,0xf1,0x30,0x03,0xd2,0xf1,0x36,0x03,0xbb,0xf1,0x3c,0x03,0xa5,0xf1,0x42,0x03,0x8e,0xf1,0x48,0x03,0x77,0xf1,0x4e,0x03,0x61,0xf1,0x54,0x03,0x4a,0xf1,  \
    0x5a,0x03,0x33,0xf1,0x60,0x03,0x1c,0xf1,0x65,0x03,0x05,0xf1,0x6b,0x03,0xed,0xf0,0x71,0x03,0xd6,0xf0,0x76,0x03,0xbe,0xf0,0x7c,0x03,0xa6,0xf0,0x82,0x03,0x8e,0xf0,0x87,0x03,0x76,0xf0,0x8c,0x03,0x5e,0xf0,0x92,0x03,0x45,0xf0,0x97,0x03,0x2d,0xf0,0x9c,0x03,0x14,0xf0,0xa1,0x03,0xfb,0xef,0xa6,0x03,0xe2,0xef,0xab,0x03,0xc9,0xef,0xaf,0x03,0xb0,0xef,0xb4,0x03,0x96,0xef,0xb9,0x03,0x7d,0xef,0xbd,0x03,0x62,0xef,0xc1,0x03,0x48,0xef,0xc4,0x03,0x2d,0xef,0xc8,0x03,  \
    0x12,0xef,0xcc,0x03,0xf7,0xee,0xd0,0x03,0xdc,0xee,0xd3,0x03,0xc1,0xee,0xd6,0x03,0xa5,0xee,0xda,0x03,0x8a,0xee,0xdd,0x03,0x6e,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x31,0x04,0x5b,0x11,  \
    0x2d,0x04,0x3f,0x11,0x2a,0x04,0x24,0x11,0x26,0x04,0x08,0x11,0x22,0x04,0xed,0x10,0x1e,0x04,0xd1,0x10,0x1a,0x04,0xb6,0x10,0x16,0x04,0x9b,0x10,0x12,0x04,0x81,0x10,0x0e,0x04,0x66,0x10,0x0a,0x04,0x4c,0x10,0x05,0x04,0x31,0x10,0x01,0x04,0x17,0x10,0xfc,0x03,0xfd,0x0f,0xf7,0x03,0xe3,0x0f,0xf2,0x03,0xc9,0x0f,0xed,0x03,0xaf,0x0f,0xe8,0x03,0x96,0x0f,0xe3,0x03,0x7c,0x0f,0xde,0x03,0x63,0x0f,0xd9,0x03,0x4a,0x0f,0xd3,0x03,0x31,0x0f,0xce,0x03,0x19,0x0f,0xc8,0x03,  \
    0x00,0x0f,0xc2,0x03,0xe8,0x0e,0xbc,0x03,0xd0,0x0e,0xb6,0x03,0xb8,0x0e,0xb0,0x03,0xa0,0x0e,0xaa,0x03,0x89,0x0e,0xa4,0x03,0x71,0x0e,0x9e,0x03,0x59,0x0e,0x98,0x03,0x42,0x0e,0x92,0x03,0x2b,0x0e,0x8b,0x03,0x14,0x0e,0x85,0x03,0xfd,0x0d,0x7f,0x03,0xe6,0x0d,0x78,0x03,0xcf,0x0d,0x72,0x03,0xb9,0x0d,0x6b,0x03,0xa2,0x0d,0x65,0x03,0x8c,0x0d,0x5e,0x03,0x76,0x0d,0x57,0x03,0x60,0x0d,0x50,0x03,0x4b,0x0d,0x48,0x03,0x36,0x0d,0x41,0x03,0x21,0x0d,0x3a,0x03,0x0c,0x0d,  \
    0x33,0x03,0xf7,0x0c,0x2c,0x03,0xe2,0x0c,0x24,0x03,0xcd,0x0c,0x1d,0x03,0xb9,0x0c,0x16,0x03,0xa4,0x0c,0x0f,0x03,0x90,0x0c,0x07,0x03,0x7c,0x0c,0x00,0x03,0x68,0x0c,0xf9,0x02,0x54,0x0c,0xf1,0x02,0x40,0x0c,0xea,0x02,0x2c,0x0c,0xe3,0x02,0x18,0x0c,0xdc,0x02,0x03,0x0c,0xd6,0x02,0xed,0x0b,0xd0,0x02,0xd8,0x0b,0xca,0x02,0xc3,0x0b,0xc3,0x02,0xad,0x0b,0xbd,0x02,0x98,0x0b,0xb7,0x02,0x83,0x0b,0xb1,0x02,0x6e,0x0b,0xaa,0x02,0x5a,0x0b,0xa4,0x02,0x45,0x0b,0x9e,0x02,  \
    0x30,0x0b,0x98,0x02,0x1b,0x0b,0x91,0x02,0x07,0x0b,0x8b,0x02,0xf2,0x0a,0x85,0x02,0xde,0x0a,0x7f,0x02,0xc9,0x0a,0x78,0x02,0xb5,0x0a,0x72,0x02,0xa1,0x0a,0x6c,0x02,0x8c,0x0a,0x66,0x02,0x78,0x0a,0x60,0x02,0x64,0x0a,0x5a,0x02,0x50,0x0a,0x54,0x02,0x3c,0x0a,0x4e,0x02,0x28,0x0a,0x47,0x02,0x14,0x0a,0x41,0x02,0x00,0x0a,0x3b,0x02,0xed,0x09,0x35,0x02,0xd9,0x09,0x2f,0x02,0xc5,0x09,0x29,0x02,0xb2,0x09,0x23,0x02,0x9e,0x09,0x1e,0x02,0x8b,0x09,0x18,0x02,0x77,0x09,  \
    0x12,0x02,0x64,0x09,0x0c,0x02,0x51,0x09,0x06,0x02,0x3e,0x09,0xff,0x01,0x2c,0x09,0xf9,0x01,0x1b,0x09,0xf2,0x01,0x09,0x09,0xeb,0x01,0xf8,0x08,0xe5,0x01,0xe7,0x08,0xde,0x01,0xd6,0x08,0xd8,0x01,0xc5,0x08,0xd2,0x01,0xb4,0x08,0xcb,0x01,0xa2,0x08,0xc5,0x01,0x91,0x08,0xbf,0x01,0x81,0x08,0xb9,0x01,0x70,0x08,0xb2,0x01,0x5f,0x08,0xac,0x01,0x4e,0x08,0xa6,0x01,0x3d,0x08,0xa0,0x01,0x2c,0x08,0x9a,0x01,0x1c,0x08,0x94,0x01,0x0b,0x08,0x8e,0x01,0xfa,0x07,0x88,0x01,  \
    0xea,0x07,0x83,0x01,0xd9,0x07,0x7d,0x01,0xc8,0x07,0x77,0x01,0xb8,0x07,0x72,0x01,0xa7,0x07,0x6c,0x01,0x96,0x07,0x66,0x01,0x85,0x07,0x61,0x01,0x75,0x07,0x5c,0x01,0x64,0x07,0x56,0x01,0x54,0x07,0x51,0x01,0x43,0x07,0x4c,0x01,0x32,0x07,0x46,0x01,0x22,0x07,0x41,0x01,0x11,0x07,0x3c,0x01,0x01,0x07,0x37,0x01,0xf1,0x06,0x32,0x01,0xe0,0x06,0x2d,0x01,0xd0,0x06,0x28,0x01,0xbf,0x06,0x23,0x01,0xaf,0x06,0x1e,0x01,0x9f,0x06,0x19,0x01,0x8e,0x06,0x14,0x01,0x7e,0x06,  \
    0x10,0x01,0x6e,0x06,0x0b,0x01,0x5c,0x06,0x07,0x01,0x4b,0x06,0x03,0x01,0x3a,0x06,0xfe,0x00,0x28,0x06,0xfa,0x00,0x17,0x06,0xf6,0x00,0x06,0x06,0xf2,0x00,0xf5,0x05,0xee,0x00,0xe4,0x05,0xea,0x00,0xd3,0x05,0xe6,0x00,0xc1,0x05,0xe2,0x00,0xb0,0x05,0xde,0x00,0x9f,0x05,0xda,0x00,0x8e,0x05,0xd6,0x00,0x7d,0x05,0xd2,0x00,0x6c,0x05,0xce,0x00,0x5b,0x05,0xcb,0x00,0x4a,0x05,0xc7,0x00,0x3a,0x05,0xc3,0x00,0x29,0x05,0xbf,0x00,0x18,0x05,0xbc,0x00,0x07,0x05,0xb8,0x00,  \
    0xf6,0x04,0xb5,0x00,0xe5,0x04,0xb1,0x00,0xd5,0x04,0xae,0x00,0xc5,0x04,0xaa,0x00,0xb5,0x04,0xa6,0x00,0xa5,0x04,0xa3,0x00,0x95,0x04,0xa0,0x00,0x85,0x04,0x9c,0x00,0x75,0x04,0x99,0x00,0x65,0x04,0x96,0x00,0x55,0x04,0x92,0x00,0x45,0x04,0x8f,0x00,0x35,0x04,0x8c,0x00,0x25,0x04,0x89,0x00,0x15,0x04,0x86,0x00,0x05,0x04,0x83,0x00,0xf6,0x03,0x80,0x00,0xe6,0x03,0x7d,0x00,0xd6,0x03,0x7a,0x00,0xc6,0x03,0x77,0x00,0xb6,0x03,0x74,0x00,0xa6,0x03,0x71,0x00,0x96,0x03,  \
    0x6f,0x00,0x87,0x03,0x6c,0x00,0x77,0x03,0x69,0x00,0x67,0x03,0x67,0x00,0x57,0x03,0x64,0x00,0x47,0x03,0x62,0x00,0x38,0x03,0x5f,0x00,0x29,0x03,0x5d,0x00,0x19,0x03,0x5a,0x00,0x0a,0x03,0x58,0x00,0xfb,0x02,0x56,0x00,0xec,0x02,0x53,0x00,0xdc,0x02,0x51,0x00,0xcd,0x02,0x4f,0x00,0xbe,0x02,0x4d,0x00,0xae,0x02,0x4b,0x00,0x9f,0x02,0x49,0x00,0x90,0x02,0x47,0x00,0x80,0x02,0x45,0x00,0x71,0x02,0x43,0x00,0x62,0x02,0x41,0x00,0x52,0x02,0x3f,0x00,0x43,0x02,0x3e,0x00,  \
    0x33,0x02,0x3c,0x00,0x24,0x02,0x3a,0x00,0x14,0x02,0x39,0x00,0x05,0x02,0x37,0x00,0xf5,0x01,0x36,0x00,0xe6,0x01,0x34,0x00,0xd6,0x01,0x33,0x00,0xc7,0x01,0x31,0x00,0xb7,0x01,0x30,0x00,0xa8,0x01,0x2f,0x00,0x98,0x01,0x2e,0x00,0x88,0x01,0x2c,0x00,0x78,0x01,0x2b,0x00,0x68,0x01,0x2a,0x00,0x58,0x01,0x29,0x00,0x48,0x01,0x28,0x00,0x38,0x01,0x27,0x00,0x28,0x01,0x26,0x00,0x18,0x01,0x26,0x00,0x08,0x01,0x25,0x00,0xf8,0x00,0x24,0x00,0xe8,0x00,0x23,0x00,0xd8,0x00,  \
    0x22,0x00,0xc8,0x00,0x22,0x00,0xb7,0x00,0x21,0x00,0xa7,0x00,0x21,0x00,0x97,0x00,0x20,0x00,0x87,0x00,0x20,0x00,0x77,0x00,0x1f,0x00,0x67,0x00,0x1f,0x00,0x57,0x00,0x1e,0x00,0x47,0x00,0x1e,0x00,0x37,0x00,0x1e,0x00,0x27,0x00,0x1e,0x00,0x17,0x00,0x1d,0x00,0x07,0x00,0x1d,0x00,0xf7,0xff,0x1d,0x00,0xe7,0xff,0x1d,0x00,0xd7,0xff,0x1d,0x00,0xc7,0xff,0x1d,0x00,0xb7,0xff,0x1d,0x00,0xa7,0xff,0x1d,0x00,0x97,0xff,0x1d,0x00,0x87,0xff,0x1d,0x00,0x77,0xff,0x1e,0x00,  \
    0x67,0xff,0x1e,0x00,0x57,0xff,0x1e,0x00,0x47,0xff,0x1e,0x00,0x37,0xff,0x1f,0x00,0x27,0xff,0x1f,0x00,0x17,0xff,0x20,0x00,0x07,0xff,0x20,0x00,0xf7,0xfe,0x21,0x00,0xe7,0xfe,0x21,0x00,0xd7,0xfe,0x22,0x00,0xc7,0xfe,0x23,0x00,0xb7,0xfe,0x23,0x00,0xa7,0xfe,0x24,0x00,0x97,0xfe,0x25,0x00,0x87,0xfe,0x26,0x00,0x77,0xfe,0x26,0x00,0x67,0xfe,0x27,0x00,0x57,0xfe,0x28,0x00,0x47,0xfe,0x29,0x00,0x37,0xfe,0x2a,0x00,0x27,0xfe,0x2b,0x00,0x17,0xfe,0x2c,0x00,0x07,0xfe,  \
    0x2d,0x00,0xf7,0xfd,0x2f,0x00,0xe6,0xfd,0x30,0x00,0xd6,0xfd,0x31,0x00,0xc6,0xfd,0x32,0x00,0xb6,0xfd,0x34,0x00,0xa5,0xfd,0x35,0x00,0x95,0xfd,0x36,0x00,0x85,0xfd,0x38,0x00,0x74,0xfd,0x39,0x00,0x64,0xfd,0x3b,0x00,0x54,0xfd,0x3c,0x00,0x44,0xfd,0x3e,0x00,0x33,0xfd,0x40,0x00,0x23,0xfd,0x41,0x00,0x12,0xfd,0x43,0x00,0x02,0xfd,0x45,0x00,0xf2,0xfc,0x46,0x00,0xe1,0xfc,0x48,0x00,0xd1,0xfc,0x4a,0x00,0xc0,0xfc,0x4c,0x00,0xb0,0xfc,0x4e,0x00,0x9f,0xfc,0x50,0x00,  \
    0x8f,0xfc,0x52,0x00,0x7e,0xfc,0x54,0x00,0x6e,0xfc,0x56,0x00,0x5d,0xfc,0x58,0x00,0x4d,0xfc,0x5a,0x00,0x3d,0xfc,0x5d,0x00,0x2d,0xfc,0x5f,0x00,0x1d,0xfc,0x61,0x00,0x0d,0xfc,0x64,0x00,0xfd,0xfb,0x66,0x00,0xed,0xfb,0x69,0x00,0xdd,0xfb,0x6b,0x00,0xcd,0xfb,0x6e,0x00,0xbd,0xfb,0x70,0x00,0xad,0xfb,0x73,0x00,0x9d,0xfb,0x76,0x00,0x8d,0xfb,0x79,0x00,0x7d,0xfb,0x7b,0x00,0x6d,0xfb,0x7e,0x00,0x5d,0xfb,0x81,0x00,0x4d,0xfb,0x84,0x00,0x3d,0xfb,0x87,0x00,0x2d,0xfb,  \
    0x8a,0x00,0x1d,0xfb,0x8d,0x00,0x0d,0xfb,0x90,0x00,0xfd,0xfa,0x94,0x00,0xee,0xfa,0x97,0x00,0xde,0xfa,0x9a,0x00,0xce,0xfa,0x9d,0x00,0xbe,0xfa,0xa1,0x00,0xae,0xfa,0xa4,0x00,0x9d,0xfa,0xa7,0x00,0x8d,0xfa,0xab,0x00,0x7c,0xfa,0xae,0x00,0x6c,0xfa,0xb2,0x00,0x5b,0xfa,0xb5,0x00,0x4b,0xfa,0xb9,0x00,0x3a,0xfa,0xbc,0x00,0x29,0xfa,0xc0,0x00,0x19,0xfa,0xc3,0x00,0x08,0xfa,0xc7,0x00,0xf8,0xf9,0xcb,0x00,0xe7,0xf9,0xcf,0x00,0xd6,0xf9,0xd2,0x00,0xc6,0xf9,0xd6,0x00,  \
    0xb5,0xf9,0xda,0x00,0xa4,0xf9,0xde,0x00,0x93,0xf9,0xe2,0x00,0x83,0xf9,0xe6,0x00,0x72,0xf9,0xea,0x00,0x61,0xf9,0xee,0x00,0x50,0xf9,0xf2,0x00,0x3f,0xf9,0xf6,0x00,0x2f,0xf9,0xfb,0x00,0x1e,0xf9,0xff,0x00,0x0d,0xf9,0x03,0x01,0xfc,0xf8,0x08,0x01,0xeb,0xf8,0x0c,0x01,0xdb,0xf8,0x11,0x01,0xca,0xf8,0x15,0x01,0xba,0xf8,0x1a,0x01,0xa9,0xf8,0x1f,0x01,0x98,0xf8,0x23,0x01,0x88,0xf8,0x28,0x01,0x77,0xf8,0x2d,0x01,0x66,0xf8,0x32,0x01,0x55,0xf8,0x36,0x01,0x44,0xf8,  \
    0x3b,0x01,0x34,0xf8,0x40,0x01,0x23,0xf8,0x45,0x01,0x12,0xf8,0x4a,0x01,0x01,0xf8,0x4f,0x01,0xf0,0xf7,0x54,0x01,0xdf,0xf7,0x5a,0x01,0xce,0xf7,0x5f,0x01,0xbd,0xf7,0x64,0x01,0xac,0xf7,0x69,0x01,0x9b,0xf7,0x6f,0x01,0x8a,0xf7,0x74,0x01,0x79,0xf7,0x79,0x01,0x67,0xf7,0x7e,0x01,0x55,0xf7,0x83,0x01,0x44,0xf7,0x89,0x01,0x32,0xf7,0x8e,0x01,0x20,0xf7,0x94,0x01,0x0e,0xf7,0x99,0x01,0xfc,0xf6,0x9e,0x01,0xea,0xf6,0xa4,0x01,0xd9,0xf6,0xa9,0x01,0xc7,0xf6,0xaf,0x01,  \
    0xb5,0xf6,0xb5,0x01,0xa2,0xf6,0xba,0x01,0x90,0xf6,0xc0,0x01,0x7e,0xf6,0xc5,0x01,0x6c,0xf6,0xcb,0x01,0x5a,0xf6,0xd1,0x01,0x48,0xf6,0xd7,0x01,0x35,0xf6,0xdc,0x01,0x23,0xf6,0xe2,0x01,0x11,0xf6,0xe8,0x01,0xfe,0xf5,0xee,0x01,0xec,0xf5,0xf4,0x01,0xda,0xf5,0xfa,0x01,0xc8,0xf5,0x00,0x02,0xb5,0xf5,0x06,0x02,0xa3,0xf5,0x0d,0x02,0x91,0xf5,0x13,0x02,0x7e,0xf5,0x19,0x02,0x6b,0xf5,0x1f,0x02,0x59,0xf5,0x26,0x02,0x46,0xf5,0x2c,0x02,0x33,0xf5,0x32,0x02,0x21,0xf5,  \
    0x38,0x02,0x0e,0xf5,0x3f,0x02,0xfb,0xf4,0x45,0x02,0xe8,0xf4,0x4b,0x02,0xd5,0xf4,0x52,0x02,0xc2,0xf4,0x58,0x02,0xaf,0xf4,0x5f,0x02,0x9b,0xf4,0x64,0x02,0x87,0xf4,0x6a,0x02,0x72,0xf4,0x70,0x02,0x5e,0xf4,0x76,0x02,0x49,0xf4,0x7c,0x02,0x34,0xf4,0x82,0x02,0x20,0xf4,0x88,0x02,0x0b,0xf4,0x8e,0x02,0xf6,0xf3,0x93,0x02,0xe1,0xf3,0x99,0x02,0xcc,0xf3,0x9f,0x02,0xb6,0xf3,0xa5,0x02,0xa1,0xf3,0xab,0x02,0x8c,0xf3,0xb1,0x02,0x76,0xf3,0xb7,0x02,0x61,0xf3,0xbc,0x02,  \
    0x4b,0xf3,0xc2,0x02,0x36,0xf3,0xc8,0x02,0x20,0xf3,0xce,0x02,0x0a,0xf3,0xd4,0x02,0xf6,0xf2,0xdb,0x02,0xe1,0xf2,0xe1,0x02,0xcb,0xf2,0xe8,0x02,0xb6,0xf2,0xee,0x02,0xa1,0xf2,0xf4,0x02,0x8c,0xf2,0xfa,0x02,0x76,0xf2,0x01,0x03,0x60,0xf2,0x07,0x03,0x4b,0xf2,0x0d,0x03,0x35,0xf2,0x13,0x03,0x1f,0xf2,0x19,0x03,0x09,0xf2,0x20,0x03,0xf3,0xf1,0x26,0x03,0xdc,0xf1,0x2c,0x03,0xc6,0xf1,0x32,0x03,0xaf,0xf1,0x38,0x03,0x99,0xf1,0x3d,0x03,0x82,0xf1,0x43,0x03,0x6b,0xf1,  \
    0x49,0x03,0x54,0xf1,0x4f,0x03,0x3d,0xf1,0x55,0x03,0x26,0xf1,0x5b,0x03,0x0f,0xf1,0x60,0x03,0xf7,0xf0,0x66,0x03,0xe0,0xf0,0x6c,0x03,0xc8,0xf0,0x71,0x03,0xb0,0xf0,0x77,0x03,0x98,0xf0,0x7c,0x03,0x80,0xf0,0x81,0x03,0x68,0xf0,0x86,0x03,0x4f,0xf0,0x8c,0x03,0x37,0xf0,0x91,0x03,0x1e,0xf0,0x96,0x03,0x05,0xf0,0x9b,0x03,0xec,0xef,0x9f,0x03,0xd3,0xef,0xa4,0x03,0xb9,0xef,0xa9,0x03,0xa0,0xef,0xad,0x03,0x86,0xef,0xb1,0x03,0x6c,0xef,0xb5,0x03,0x51,0xef,0xb9,0x03,  \
    0x36,0xef,0xbd,0x03,0x1c,0xef,0xc0,0x03,0x01,0xef,0xc4,0x03,0xe5,0xee,0xc7,0x03,0xca,0xee,0xcb,0x03,0xaf,0xee,0xce,0x03,0x93,0xee,0xd1,0x03,0x77,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x24,0x04,0x54,0x11,0x20,0x04,0x38,0x11,0x1d,0x04,0x1c,0x11,0x19,0x04,0x01,0x11,0x15,0x04,0xe5,0x10,0x11,0x04,0xca,0x10,0x0d,0x04,0xaf,0x10,0x09,0x04,0x94,0x10,0x05,0x04,0x79,0x10,0x01,0x04,0x5e,0x10,0xfd,0x03,0x44,0x10,0xf8,0x03,0x29,0x10,0xf4,0x03,0x0f,0x10,0xef,0x03,0xf5,0x0f,0xea,0x03,0xdb,0x0f,0xe6,0x03,0xc1,0x0f,0xe1,0x03,0xa7,0x0f,0xdc,0x03,0x8e,0x0f,0xd7,0x03,0x74,0x0f,0xd2,0x03,0x5b,0x0f,0xcd,0x03,0x42,0x0f,0xc7,0x03,0x29,0x0f,0xc1,0x03,  \
    0x11,0x0f,0xbc,0x03,0xf8,0x0e,0xb6,0x03,0xe0,0x0e,0xb0,0x03,0xc8,0x0e,0xaa,0x03,0xb0,0x0e,0xa4,0x03,0x98,0x0e,0x9e,0x03,0x80,0x0e,0x98,0x03,0x69,0x0e,0x92,0x03,0x51,0x0e,0x8c,0x03,0x3a,0x0e,0x86,0x03,0x23,0x0e,0x80,0x03,0x0b,0x0e,0x79,0x03,0xf4,0x0d,0x73,0x03,0xdd,0x0d,0x6d,0x03,0xc7,0x0d,0x66,0x03,0xb0,0x0d,0x60,0x03,0x9a,0x0d,0x59,0x03,0x83,0x0d,0x52,0x03,0x6d,0x0d,0x4b,0x03,0x58,0x0d,0x44,0x03,0x42,0x0d,0x3d,0x03,0x2d,0x0d,0x36,0x03,0x18,0x0d,  \
    0x2f,0x03,0x03,0x0d,0x28,0x03,0xee,0x0c,0x21,0x03,0xd9,0x0c,0x1a,0x03,0xc4,0x0c,0x12,0x03,0xaf,0x0c,0x0b,0x03,0x9b,0x0c,0x04,0x03,0x87,0x0c,0xfd,0x02,0x72,0x0c,0xf5,0x02,0x5e,0x0c,0xee,0x02,0x4a,0x0c,0xe7,0x02,0x36,0x0c,0xe0,0x02,0x22,0x0c,0xd8,0x02,0x0e,0x0c,0xd2,0x02,0xf9,0x0b,0xcc,0x02,0xe3,0x0b,0xc6,0x02,0xce,0x0b,0xbf,0x02,0xb9,0x0b,0xb9,0x02,0xa4,0x0b,0xb3,0x02,0x8f,0x0b,0xad,0x02,0x7a,0x0b,0xa6,0x02,0x65,0x0b,0xa0,0x02,0x50,0x0b,0x9a,0x02,  \
    0x3b,0x0b,0x94,0x02,0x26,0x0b,0x8e,0x02,0x12,0x0b,0x87,0x02,0xfd,0x0a,0x81,0x02,0xe9,0x0a,0x7b,0x02,0xd4,0x0a,0x75,0x02,0xc0,0x0a,0x6f,0x02,0xab,0x0a,0x68,0x02,0x97,0x0a,0x62,0x02,0x83,0x0a,0x5c,0x02,0x6f,0x0a,0x56,0x02,0x5b,0x0a,0x50,0x02,0x47,0x0a,0x4a,0x02,0x33,0x0a,0x44,0x02,0x1f,0x0a,0x3e,0x02,0x0b,0x0a,0x38,0x02,0xf7,0x09,0x32,0x02,0xe3,0x09,0x2c,0x02,0xd0,0x09,0x26,0x02,0xbc,0x09,0x20,0x02,0xa8,0x09,0x1a,0x02,0x95,0x09,0x14,0x02,0x82,0x09,  \
    0x0e,0x02,0x6e,0x09,0x08,0x02,0x5b,0x09,0x02,0x02,0x47,0x09,0xfc,0x01,0x35,0x09,0xf6,0x01,0x23,0x09,0xef,0x01,0x12,0x09,0xe8,0x01,0x00,0x09,0xe2,0x01,0xef,0x08,0xdb,0x01,0xde,0x08,0xd5,0x01,0xcd,0x08,0xcf,0x01,0xbb,0x08,0xc8,0x01,0xaa,0x08,0xc2,0x01,0x99,0x08,0xbc,0x01,0x88,0x08,0xb5,0x01,0x77,0x08,0xaf,0x01,0x66,0x08,0xa9,0x01,0x56,0x08,0xa3,0x01,0x45,0x08,0x9d,0x01,0x34,0x08,0x97,0x01,0x23,0x08,0x91,0x01,0x13,0x08,0x8b,0x01,0x02,0x08,0x85,0x01,  \
    0xf1,0x07,0x7f,0x01,0xe1,0x07,0x79,0x01,0xd0,0x07,0x74,0x01,0xbf,0x07,0x6e,0x01,0xae,0x07,0x69,0x01,0x9e,0x07,0x63,0x01,0x8d,0x07,0x5d,0x01,0x7c,0x07,0x58,0x01,0x6c,0x07,0x53,0x01,0x5b,0x07,0x4d,0x01,0x4b,0x07,0x48,0x01,0x3a,0x07,0x43,0x01,0x29,0x07,0x3d,0x01,0x19,0x07,0x38,0x01,0x09,0x07,0x33,0x01,0xf8,0x06,0x2e,0x01,0xe8,0x06,0x29,0x01,0xd7,0x06,0x24,0x01,0xc7,0x06,0x1f,0x01,0xb7,0x06,0x1a,0x01,0xa6,0x06,0x15,0x01,0x96,0x06,0x10,0x01,0x86,0x06,  \
    0x0c,0x01,0x75,0x06,0x07,0x01,0x65,0x06,0x02,0x01,0x54,0x06,0xfe,0x00,0x43,0x06,0xfa,0x00,0x31,0x06,0xf6,0x00,0x20,0x06,0xf1,0x00,0x0f,0x06,0xed,0x00,0xfe,0x05,0xe9,0x00,0xed,0x05,0xe5,0x00,0xdc,0x05,0xe1,0x00,0xcb,0x05,0xdd,0x00,0xba,0x05,0xd9,0x00,0xa9,0x05,0xd5,0x00,0x98,0x05,0xd1,0x00,0x87,0x05,0xcd,0x00,0x76,0x05,0xc9,0x00,0x65,0x05,0xc5,0x00,0x54,0x05,0xc2,0x00,0x43,0x05,0xbe,0x00,0x32,0x05,0xba,0x00,0x21,0x05,0xb6,0x00,0x11,0x05,0xb3,0x00,  \
    0x00,0x05,0xaf,0x00,0xef,0x04,0xac,0x00,0xdf,0x04,0xa8,0x00,0xce,0x04,0xa5,0x00,0xbe,0x04,0xa1,0x00,0xae,0x04,0x9d,0x00,0x9e,0x04,0x9a,0x00,0x8e,0x04,0x97,0x00,0x7e,0x04,0x93,0x00,0x6e,0x04,0x90,0x00,0x5f,0x04,0x8d,0x00,0x4f,0x04,0x89,0x00,0x3f,0x04,0x86,0x00,0x2f,0x04,0x83,0x00,0x1f,0x04,0x80,0x00,0x0f,0x04,0x7d,0x00,0x00,0x04,0x7a,0x00,0xf0,0x03,0x77,0x00,0xe0,0x03,0x74,0x00,0xd0,0x03,0x71,0x00,0xc0,0x03,0x6e,0x00,0xb1,0x03,0x6b,0x00,0xa1,0x03,  \
    0x68,0x00,0x91,0x03,0x66,0x00,0x81,0x03,0x63,0x00,0x72,0x03,0x60,0x00,0x62,0x03,0x5e,0x00,0x52,0x03,0x5b,0x00,0x42,0x03,0x59,0x00,0x33,0x03,0x56,0x00,0x24,0x03,0x54,0x00,0x14,0x03,0x51,0x00,0x05,0x03,0x4f,0x00,0xf6,0x02,0x4d,0x00,0xe7,0x02,0x4a,0x00,0xd8,0x02,0x48,0x00,0xc9,0x02,0x46,0x00,0xb9,0x02,0x44,0x00,0xaa,0x02,0x42,0x00,0x9b,0x02,0x40,0x00,0x8c,0x02,0x3e,0x00,0x7c,0x02,0x3c,0x00,0x6d,0x02,0x3a,0x00,0x5e,0x02,0x38,0x00,0x4e,0x02,0x36,0x00,  \
    0x3f,0x02,0x35,0x00,0x30,0x02,0x33,0x00,0x20,0x02,0x31,0x00,0x11,0x02,0x30,0x00,0x01,0x02,0x2e,0x00,0xf2,0x01,0x2d,0x00,0xe3,0x01,0x2b,0x00,0xd3,0x01,0x2a,0x00,0xc4,0x01,0x28,0x00,0xb4,0x01,0x27,0x00,0xa5,0x01,0x26,0x00,0x95,0x01,0x25,0x00,0x85,0x01,0x23,0x00,0x75,0x01,0x22,0x00,0x65,0x01,0x21,0x00,0x55,0x01,0x20,0x00,0x45,0x01,0x1f,0x00,0x35,0x01,0x1e,0x00,0x25,0x01,0x1d,0x00,0x16,0x01,0x1c,0x00,0x06,0x01,0x1c,0x00,0xf6,0x00,0x1b,0x00,0xe6,0x00,  \
    0x1a,0x00,0xd6,0x00,0x19,0x00,0xc6,0x00,0x19,0x00,0xb6,0x00,0x18,0x00,0xa6,0x00,0x18,0x00,0x96,0x00,0x17,0x00,0x86,0x00,0x16,0x00,0x76,0x00,0x16,0x00,0x66,0x00,0x16,0x00,0x56,0x00,0x15,0x00,0x46,0x00,0x15,0x00,0x37,0x00,0x15,0x00,0x27,0x00,0x14,0x00,0x17,0x00,0x14,0x00,0x07,0x00,0x14,0x00,0xf7,0xff,0x14,0x00,0xe7,0xff,0x14,0x00,0xd7,0xff,0x14,0x00,0xc7,0xff,0x14,0x00,0xb7,0xff,0x14,0x00,0xa7,0xff,0x14,0x00,0x97,0xff,0x14,0x00,0x87,0xff,0x14,0x00,  \
    0x78,0xff,0x14,0x00,0x68,0xff,0x15,0x00,0x58,0xff,0x15,0x00,0x48,0xff,0x15,0x00,0x38,0xff,0x16,0x00,0x28,0xff,0x16,0x00,0x18,0xff,0x17,0x00,0x08,0xff,0x17,0x00,0xf8,0xfe,0x18,0x00,0xe8,0xfe,0x18,0x00,0xd8,0xfe,0x19,0x00,0xc9,0xfe,0x19,0x00,0xb9,0xfe,0x1a,0x00,0xa9,0xfe,0x1b,0x00,0x99,0xfe,0x1c,0x00,0x89,0xfe,0x1c,0x00,0x79,0xfe,0x1d,0x00,0x69,0xfe,0x1e,0x00,0x59,0xfe,0x1f,0x00,0x49,0xfe,0x20,0x00,0x39,0xfe,0x21,0x00,0x29,0xfe,0x22,0x00,0x1a,0xfe,  \
    0x23,0x00,0x09,0xfe,0x24,0x00,0xf9,0xfd,0x26,0x00,0xe9,0xfd,0x27,0x00,0xd9,0xfd,0x28,0x00,0xc9,0xfd,0x29,0x00,0xb9,0xfd,0x2b,0x00,0xa9,0xfd,0x2c,0x00,0x99,0xfd,0x2d,0x00,0x88,0xfd,0x2f,0x00,0x78,0xfd,0x30,0x00,0x68,0xfd,0x32,0x00,0x58,0xfd,0x33,0x00,0x47,0xfd,0x35,0x00,0x37,0xfd,0x37,0x00,0x27,0xfd,0x38,0x00,0x17,0xfd,0x3a,0x00,0x06,0xfd,0x3c,0x00,0xf6,0xfc,0x3d,0x00,0xe6,0xfc,0x3f,0x00,0xd5,0xfc,0x41,0x00,0xc5,0xfc,0x43,0x00,0xb5,0xfc,0x45,0x00,  \
    0xa4,0xfc,0x47,0x00,0x94,0xfc,0x49,0x00,0x84,0xfc,0x4b,0x00,0x73,0xfc,0x4d,0x00,0x63,0xfc,0x4f,0x00,0x52,0xfc,0x51,0x00,0x42,0xfc,0x54,0x00,0x33,0xfc,0x56,0x00,0x23,0xfc,0x58,0x00,0x13,0xfc,0x5b,0x00,0x03,0xfc,0x5d,0x00,0xf3,0xfb,0x60,0x00,0xe3,0xfb,0x62,0x00,0xd3,0xfb,0x65,0x00,0xc3,0xfb,0x68,0x00,0xb3,0xfb,0x6a,0x00,0xa3,0xfb,0x6d,0x00,0x94,0xfb,0x70,0x00,0x84,0xfb,0x73,0x00,0x74,0xfb,0x75,0x00,0x64,0xfb,0x78,0x00,0x54,0xfb,0x7b,0x00,0x44,0xfb,  \
    0x7e,0x00,0x34,0xfb,0x81,0x00,0x24,0xfb,0x84,0x00,0x15,0xfb,0x88,0x00,0x05,0xfb,0x8b,0x00,0xf5,0xfa,0x8e,0x00,0xe5,0xfa,0x91,0x00,0xd5,0xfa,0x94,0x00,0xc5,0xfa,0x98,0x00,0xb5,0xfa,0x9b,0x00,0xa5,0xfa,0x9e,0x00,0x94,0xfa,0xa2,0x00,0x84,0xfa,0xa5,0x00,0x74,0xfa,0xa9,0x00,0x63,0xfa,0xac,0x00,0x53,0xfa,0xb0,0x00,0x42,0xfa,0xb3,0x00,0x32,0xfa,0xb7,0x00,0x21,0xfa,0xbb,0x00,0x10,0xfa,0xbe,0x00,0x00,0xfa,0xc2,0x00,0xef,0xf9,0xc6,0x00,0xdf,0xf9,0xca,0x00,  \
    0xce,0xf9,0xcd,0x00,0xbd,0xf9,0xd1,0x00,0xad,0xf9,0xd5,0x00,0x9c,0xf9,0xd9,0x00,0x8b,0xf9,0xdd,0x00,0x7b,0xf9,0xe1,0x00,0x6a,0xf9,0xe5,0x00,0x59,0xf9,0xea,0x00,0x48,0xf9,0xee,0x00,0x38,0xf9,0xf2,0x00,0x27,0xf9,0xf6,0x00,0x16,0xf9,0xfb,0x00,0x05,0xf9,0xff,0x00,0xf5,0xf8,0x04,0x01,0xe4,0xf8,0x08,0x01,0xd4,0xf8,0x0d,0x01,0xc3,0xf8,0x11,0x01,0xb2,0xf8,0x16,0x01,0xa2,0xf8,0x1b,0x01,0x91,0xf8,0x1f,0x01,0x80,0xf8,0x24,0x01,0x70,0xf8,0x29,0x01,0x5f,0xf8,  \
    0x2e,0x01,0x4e,0xf8,0x33,0x01,0x3d,0xf8,0x38,0x01,0x2d,0xf8,0x3d,0x01,0x1c,0xf8,0x42,0x01,0x0b,0xf8,0x47,0x01,0xfa,0xf7,0x4c,0x01,0xe9,0xf7,0x51,0x01,0xd8,0xf7,0x56,0x01,0xc7,0xf7,0x5b,0x01,0xb6,0xf7,0x60,0x01,0xa5,0xf7,0x66,0x01,0x94,0xf7,0x6b,0x01,0x83,0xf7,0x70,0x01,0x71,0xf7,0x75,0x01,0x5f,0xf7,0x7b,0x01,0x4e,0xf7,0x80,0x01,0x3c,0xf7,0x85,0x01,0x2a,0xf7,0x8b,0x01,0x19,0xf7,0x90,0x01,0x07,0xf7,0x96,0x01,0xf5,0xf6,0x9b,0x01,0xe3,0xf6,0xa1,0x01,  \
    0xd1,0xf6,0xa6,0x01,0xbf,0xf6,0xac,0x01,0xad,0xf6,0xb1,0x01,0x9b,0xf6,0xb7,0x01,0x89,0xf6,0xbd,0x01,0x77,0xf6,0xc2,0x01,0x65,0xf6,0xc8,0x01,0x52,0xf6,0xce,0x01,0x40,0xf6,0xd4,0x01,0x2e,0xf6,0xd9,0x01,0x1b,0xf6,0xdf,0x01,0x09,0xf6,0xe5,0x01,0xf7,0xf5,0xeb,0x01,0xe5,0xf5,0xf1,0x01,0xd2,0xf5,0xf7,0x01,0xc0,0xf5,0xfe,0x01,0xae,0xf5,0x04,0x02,0x9b,0xf5,0x0a,0x02,0x89,0xf5,0x10,0x02,0x76,0xf5,0x16,0x02,0x64,0xf5,0x1c,0x02,0x51,0xf5,0x23,0x02,0x3e,0xf5,  \
    0x29,0x02,0x2b,0xf5,0x2f,0x02,0x19,0xf5,0x35,0x02,0x06,0xf5,0x3c,0x02,0xf3,0xf4,0x42,0x02,0xe0,0xf4,0x48,0x02,0xcc,0xf4,0x4f,0x02,0xb9,0xf4,0x55,0x02,0xa6,0xf4,0x5b,0x02,0x92,0xf4,0x61,0x02,0x7d,0xf4,0x67,0x02,0x69,0xf4,0x6d,0x02,0x54,0xf4,0x73,0x02,0x3f,0xf4,0x78,0x02,0x2a,0xf4,0x7e,0x02,0x15,0xf4,0x84,0x02,0x01,0xf4,0x8a,0x02,0xeb,0xf3,0x90,0x02,0xd6,0xf3,0x96,0x02,0xc1,0xf3,0x9c,0x02,0xac,0xf3,0xa1,0x02,0x97,0xf3,0xa7,0x02,0x81,0xf3,0xad,0x02,  \
    0x6c,0xf3,0xb3,0x02,0x56,0xf3,0xb9,0x02,0x41,0xf3,0xbe,0x02,0x2b,0xf3,0xc4,0x02,0x15,0xf3,0xcb,0x02,0x00,0xf3,0xd1,0x02,0xeb,0xf2,0xd7,0x02,0xd6,0xf2,0xde,0x02,0xc1,0xf2,0xe4,0x02,0xac,0xf2,0xea,0x02,0x96,0xf2,0xf1,0x02,0x81,0xf2,0xf7,0x02,0x6b,0xf2,0xfd,0x02,0x55,0xf2,0x03,0x03,0x3f,0xf2,0x09,0x03,0x29,0xf2,0x0f,0x03,0x13,0xf2,0x15,0x03,0xfd,0xf1,0x1b,0x03,0xe7,0xf1,0x21,0x03,0xd0,0xf1,0x27,0x03,0xb9,0xf1,0x2d,0x03,0xa3,0xf1,0x33,0x03,0x8c,0xf1,  \
    0x39,0x03,0x75,0xf1,0x3f,0x03,0x5e,0xf1,0x45,0x03,0x47,0xf1,0x4a,0x03,0x30,0xf1,0x50,0x03,0x19,0xf1,0x56,0x03,0x01,0xf1,0x5b,0x03,0xe9,0xf0,0x61,0x03,0xd2,0xf0,0x66,0x03,0xba,0xf0,0x6c,0x03,0xa2,0xf0,0x71,0x03,0x8a,0xf0,0x76,0x03,0x71,0xf0,0x7b,0x03,0x59,0xf0,0x81,0x03,0x40,0xf0,0x86,0x03,0x27,0xf0,0x8b,0x03,0x0e,0xf0,0x8f,0x03,0xf5,0xef,0x94,0x03,0xdc,0xef,0x99,0x03,0xc3,0xef,0x9d,0x03,0xa9,0xef,0xa2,0x03,0x8f,0xef,0xa6,0x03,0x75,0xef,0xaa,0x03,  \
    0x5a,0xef,0xad,0x03,0x40,0xef,0xb1,0x03,0x25,0xef,0xb5,0x03,0x0a,0xef,0xb8,0x03,0xef,0xee,0xbc,0x03,0xd3,0xee,0xbf,0x03,0xb8,0xee,0xc2,0x03,0x9c,0xee,0xc6,0x03,0x81,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x17,0x04,0x4c,0x11,0x13,0x04,0x30,0x11,0x10,0x04,0x15,0x11,0x0c,0x04,0xf9,0x10,0x08,0x04,0xde,0x10,0x04,0x04,0xc2,0x10,0x01,0x04,0xa7,0x10,0xfd,0x03,0x8c,0x10,0xf8,0x03,0x71,0x10,0xf4,0x03,0x57,0x10,0xf0,0x03,0x3c,0x10,0xec,0x03,0x22,0x10,0xe7,0x03,0x07,0x10,0xe3,0x03,0xed,0x0f,0xde,0x03,0xd3,0x0f,0xd9,0x03,0xb9,0x0f,0xd4,0x03,0xa0,0x0f,0xcf,0x03,0x86,0x0f,0xca,0x03,0x6d,0x0f,0xc5,0x03,0x53,0x0f,0xc0,0x03,0x3a,0x0f,0xbb,0x03,  \
    0x21,0x0f,0xb5,0x03,0x09,0x0f,0xb0,0x03,0xf0,0x0e,0xaa,0x03,0xd8,0x0e,0xa4,0x03,0xc0,0x0e,0x9e,0x03,0xa8,0x0e,0x98,0x03,0x90,0x0e,0x93,0x03,0x78,0x0e,0x8d,0x03,0x60,0x0e,0x87,0x03,0x49,0x0e,0x80,0x03,0x31,0x0e,0x7a,0x03,0x1a,0x0e,0x74,0x03,0x03,0x0e,0x6e,0x03,0xec,0x0d,0x68,0x03,0xd5,0x0d,0x61,0x03,0xbe,0x0d,0x5b,0x03,0xa8,0x0d,0x54,0x03,0x91,0x0d,0x4e,0x03,0x7b,0x0d,0x47,0x03,0x65,0x0d,0x40,0x03,0x4f,0x0d,0x39,0x03,0x39,0x0d,0x32,0x03,0x24,0x0d,  \
    0x2b,0x03,0x0f,0x0d,0x24,0x03,0xfa,0x0c,0x1d,0x03,0xe5,0x0c,0x16,0x03,0xd0,0x0c,0x0f,0x03,0xbb,0x0c,0x08,0x03,0xa6,0x0c,0x01,0x03,0x92,0x0c,0xfa,0x02,0x7d,0x0c,0xf2,0x02,0x69,0x0c,0xeb,0x02,0x55,0x0c,0xe4,0x02,0x41,0x0c,0xdd,0x02,0x2d,0x0c,0xd5,0x02,0x19,0x0c,0xce,0x02,0x05,0x0c,0xc8,0x02,0xef,0x0b,0xc2,0x02,0xda,0x0b,0xbc,0x02,0xc5,0x0b,0xb5,0x02,0xaf,0x0b,0xaf,0x02,0x9a,0x0b,0xa9,0x02,0x85,0x0b,0xa3,0x02,0x70,0x0b,0x9d,0x02,0x5b,0x0b,0x96,0x02,  \
    0x46,0x0b,0x90,0x02,0x32,0x0b,0x8a,0x02,0x1d,0x0b,0x84,0x02,0x08,0x0b,0x7e,0x02,0xf4,0x0a,0x77,0x02,0xdf,0x0a,0x71,0x02,0xcb,0x0a,0x6b,0x02,0xb6,0x0a,0x65,0x02,0xa2,0x0a,0x5f,0x02,0x8e,0x0a,0x59,0x02,0x79,0x0a,0x53,0x02,0x65,0x0a,0x4c,0x02,0x51,0x0a,0x46,0x02,0x3d,0x0a,0x40,0x02,0x29,0x0a,0x3a,0x02,0x15,0x0a,0x34,0x02,0x02,0x0a,0x2e,0x02,0xee,0x09,0x28,0x02,0xda,0x09,0x22,0x02,0xc6,0x09,0x1c,0x02,0xb3,0x09,0x16,0x02,0x9f,0x09,0x10,0x02,0x8c,0x09,  \
    0x0a,0x02,0x78,0x09,0x04,0x02,0x65,0x09,0xff,0x01,0x52,0x09,0xf9,0x01,0x3e,0x09,0xf3,0x01,0x2b,0x09,0xec,0x01,0x1a,0x09,0xe6,0x01,0x09,0x09,0xdf,0x01,0xf7,0x08,0xd9,0x01,0xe6,0x08,0xd2,0x01,0xd5,0x08,0xcc,0x01,0xc3,0x08,0xc5,0x01,0xb2,0x08,0xbf,0x01,0xa1,0x08,0xb9,0x01,0x90,0x08,0xb3,0x01,0x7f,0x08,0xac,0x01,0x6e,0x08,0xa6,0x01,0x5d,0x08,0xa0,0x01,0x4c,0x08,0x9a,0x01,0x3c,0x08,0x94,0x01,0x2b,0x08,0x8e,0x01,0x1a,0x08,0x88,0x01,0x09,0x08,0x82,0x01,  \
    0xf9,0x07,0x7c,0x01,0xe8,0x07,0x76,0x01,0xd8,0x07,0x71,0x01,0xc7,0x07,0x6b,0x01,0xb6,0x07,0x65,0x01,0xa5,0x07,0x60,0x01,0x95,0x07,0x5a,0x01,0x84,0x07,0x55,0x01,0x73,0x07,0x4f,0x01,0x63,0x07,0x4a,0x01,0x52,0x07,0x44,0x01,0x42,0x07,0x3f,0x01,0x31,0x07,0x3a,0x01,0x21,0x07,0x35,0x01,0x10,0x07,0x2f,0x01,0x00,0x07,0x2a,0x01,0xef,0x06,0x25,0x01,0xdf,0x06,0x20,0x01,0xcf,0x06,0x1b,0x01,0xbe,0x06,0x16,0x01,0xae,0x06,0x11,0x01,0x9e,0x06,0x0c,0x01,0x8d,0x06,  \
    0x08,0x01,0x7d,0x06,0x03,0x01,0x6d,0x06,0xfe,0x00,0x5d,0x06,0xfa,0x00,0x4b,0x06,0xf5,0x00,0x3a,0x06,0xf1,0x00,0x29,0x06,0xed,0x00,0x18,0x06,0xe9,0x00,0x07,0x06,0xe4,0x00,0xf6,0x05,0xe0,0x00,0xe5,0x05,0xdc,0x00,0xd4,0x05,0xd8,0x00,0xc3,0x05,0xd4,0x00,0xb2,0x05,0xd0,0x00,0xa1,0x05,0xcc,0x00,0x90,0x05,0xc8,0x00,0x7f,0x05,0xc4,0x00,0x6e,0x05,0xc0,0x00,0x5d,0x05,0xbd,0x00,0x4d,0x05,0xb9,0x00,0x3c,0x05,0xb5,0x00,0x2b,0x05,0xb1,0x00,0x1a,0x05,0xae,0x00,  \
    0x0a,0x05,0xaa,0x00,0xf9,0x04,0xa7,0x00,0xe8,0x04,0xa3,0x00,0xd8,0x04,0xa0,0x00,0xc7,0x04,0x9c,0x00,0xb7,0x04,0x98,0x00,0xa7,0x04,0x95,0x00,0x98,0x04,0x91,0x00,0x88,0x04,0x8e,0x00,0x78,0x04,0x8a,0x00,0x68,0x04,0x87,0x00,0x58,0x04,0x84,0x00,0x48,0x04,0x81,0x00,0x39,0x04,0x7d,0x00,0x29,0x04,0x7a,0x00,0x19,0x04,0x77,0x00,0x09,0x04,0x74,0x00,0xfa,0x03,0x71,0x00,0xea,0x03,0x6e,0x00,0xda,0x03,0x6b,0x00,0xca,0x03,0x68,0x00,0xbb,0x03,0x65,0x00,0xab,0x03,  \
    0x62,0x00,0x9b,0x03,0x60,0x00,0x8c,0x03,0x5d,0x00,0x7c,0x03,0x5a,0x00,0x6c,0x03,0x58,0x00,0x5d,0x03,0x55,0x00,0x4d,0x03,0x53,0x00,0x3d,0x03,0x50,0x00,0x2e,0x03,0x4e,0x00,0x1f,0x03,0x4b,0x00,0x10,0x03,0x49,0x00,0x01,0x03,0x46,0x00,0xf1,0x02,0x44,0x00,0xe2,0x02,0x42,0x00,0xd3,0x02,0x3f,0x00,0xc4,0x02,0x3d,0x00,0xb5,0x02,0x3b,0x00,0xa6,0x02,0x39,0x00,0x97,0x02,0x37,0x00,0x87,0x02,0x35,0x00,0x78,0x02,0x33,0x00,0x69,0x02,0x31,0x00,0x5a,0x02,0x2f,0x00,  \
    0x4a,0x02,0x2e,0x00,0x3b,0x02,0x2c,0x00,0x2c,0x02,0x2a,0x00,0x1d,0x02,0x28,0x00,0x0d,0x02,0x27,0x00,0xfe,0x01,0x25,0x00,0xef,0x01,0x24,0x00,0xdf,0x01,0x22,0x00,0xd0,0x01,0x21,0x00,0xc0,0x01,0x20,0x00,0xb1,0x01,0x1e,0x00,0xa2,0x01,0x1d,0x00,0x92,0x01,0x1c,0x00,0x82,0x01,0x1b,0x00,0x72,0x01,0x19,0x00,0x63,0x01,0x18,0x00,0x53,0x01,0x17,0x00,0x43,0x01,0x16,0x00,0x33,0x01,0x15,0x00,0x23,0x01,0x14,0x00,0x13,0x01,0x14,0x00,0x04,0x01,0x13,0x00,0xf4,0x00,  \
    0x12,0x00,0xe4,0x00,0x11,0x00,0xd4,0x00,0x11,0x00,0xc4,0x00,0x10,0x00,0xb4,0x00,0x0f,0x00,0xa5,0x00,0x0f,0x00,0x95,0x00,0x0e,0x00,0x85,0x00,0x0e,0x00,0x75,0x00,0x0d,0x00,0x65,0x00,0x0d,0x00,0x55,0x00,0x0c,0x00,0x46,0x00,0x0c,0x00,0x36,0x00,0x0c,0x00,0x26,0x00,0x0c,0x00,0x16,0x00,0x0b,0x00,0x06,0x00,0x0b,0x00,0xf7,0xff,0x0b,0x00,0xe7,0xff,0x0b,0x00,0xd7,0xff,0x0b,0x00,0xc7,0xff,0x0b,0x00,0xb7,0xff,0x0b,0x00,0xa7,0xff,0x0b,0x00,0x98,0xff,0x0b,0x00,  \
    0x88,0xff,0x0b,0x00,0x78,0xff,0x0c,0x00,0x68,0xff,0x0c,0x00,0x58,0xff,0x0c,0x00,0x49,0xff,0x0d,0x00,0x39,0xff,0x0d,0x00,0x29,0xff,0x0d,0x00,0x19,0xff,0x0e,0x00,0x09,0xff,0x0e,0x00,0xf9,0xfe,0x0f,0x00,0xea,0xfe,0x0f,0x00,0xda,0xfe,0x10,0x00,0xca,0xfe,0x11,0x00,0xba,0xfe,0x11,0x00,0xaa,0xfe,0x12,0x00,0x9b,0xfe,0x13,0x00,0x8b,0xfe,0x14,0x00,0x7b,0xfe,0x14,0x00,0x6b,0xfe,0x15,0x00,0x5b,0xfe,0x16,0x00,0x4c,0xfe,0x17,0x00,0x3c,0xfe,0x18,0x00,0x2c,0xfe,  \
    0x19,0x00,0x1c,0xfe,0x1a,0x00,0x0c,0xfe,0x1c,0x00,0xfc,0xfd,0x1d,0x00,0xec,0xfd,0x1e,0x00,0xdc,0xfd,0x1f,0x00,0xcc,0xfd,0x20,0x00,0xbc,0xfd,0x22,0x00,0xac,0xfd,0x23,0x00,0x9c,0xfd,0x25,0x00,0x8c,0xfd,0x26,0x00,0x7c,0xfd,0x28,0x00,0x6c,0xfd,0x29,0x00,0x5c,0xfd,0x2b,0x00,0x4b,0xfd,0x2c,0x00,0x3b,0xfd,0x2e,0x00,0x2b,0xfd,0x2f,0x00,0x1b,0xfd,0x31,0x00,0x0b,0xfd,0x33,0x00,0xfb,0xfc,0x35,0x00,0xea,0xfc,0x37,0x00,0xda,0xfc,0x38,0x00,0xca,0xfc,0x3a,0x00,  \
    0xba,0xfc,0x3c,0x00,0xa9,0xfc,0x3e,0x00,0x99,0xfc,0x40,0x00,0x89,0xfc,0x42,0x00,0x78,0xfc,0x44,0x00,0x68,0xfc,0x47,0x00,0x58,0xfc,0x49,0x00,0x48,0xfc,0x4b,0x00,0x38,0xfc,0x4d,0x00,0x28,0xfc,0x50,0x00,0x19,0xfc,0x52,0x00,0x09,0xfc,0x55,0x00,0xf9,0xfb,0x57,0x00,0xe9,0xfb,0x5a,0x00,0xd9,0xfb,0x5c,0x00,0xc9,0xfb,0x5f,0x00,0xba,0xfb,0x62,0x00,0xaa,0xfb,0x64,0x00,0x9a,0xfb,0x67,0x00,0x8a,0xfb,0x6a,0x00,0x7a,0xfb,0x6d,0x00,0x6b,0xfb,0x70,0x00,0x5b,0xfb,  \
    0x73,0x00,0x4b,0xfb,0x76,0x00,0x3b,0xfb,0x79,0x00,0x2b,0xfb,0x7c,0x00,0x1c,0xfb,0x7f,0x00,0x0c,0xfb,0x82,0x00,0xfc,0xfa,0x85,0x00,0xec,0xfa,0x89,0x00,0xdc,0xfa,0x8c,0x00,0xcc,0xfa,0x8f,0x00,0xbd,0xfa,0x93,0x00,0xac,0xfa,0x96,0x00,0x9c,0xfa,0x99,0x00,0x8c,0xfa,0x9d,0x00,0x7b,0xfa,0xa0,0x00,0x6b,0xfa,0xa4,0x00,0x5a,0xfa,0xa7,0x00,0x4a,0xfa,0xab,0x00,0x3a,0xfa,0xae,0x00,0x29,0xfa,0xb2,0x00,0x19,0xfa,0xb6,0x00,0x08,0xfa,0xba,0x00,0xf8,0xf9,0xbd,0x00,  \
    0xe7,0xf9,0xc1,0x00,0xd6,0xf9,0xc5,0x00,0xc6,0xf9,0xc9,0x00,0xb5,0xf9,0xcd,0x00,0xa5,0xf9,0xd1,0x00,0x94,0xf9,0xd5,0x00,0x83,0xf9,0xd9,0x00,0x73,0xf9,0xdd,0x00,0x62,0xf9,0xe1,0x00,0x51,0xf9,0xe5,0x00,0x41,0xf9,0xea,0x00,0x30,0xf9,0xee,0x00,0x1f,0xf9,0xf2,0x00,0x0f,0xf9,0xf7,0x00,0xfe,0xf8,0xfb,0x00,0xee,0xf8,0x00,0x01,0xdd,0xf8,0x04,0x01,0xcc,0xf8,0x09,0x01,0xbc,0xf8,0x0d,0x01,0xab,0xf8,0x12,0x01,0x9b,0xf8,0x17,0x01,0x8a,0xf8,0x1c,0x01,0x79,0xf8,  \
    0x20,0x01,0x69,0xf8,0x25,0x01,0x58,0xf8,0x2a,0x01,0x47,0xf8,0x2f,0x01,0x36,0xf8,0x34,0x01,0x26,0xf8,0x39,0x01,0x15,0xf8,0x3e,0x01,0x04,0xf8,0x43,0x01,0xf3,0xf7,0x48,0x01,0xe2,0xf7,0x4e,0x01,0xd1,0xf7,0x53,0x01,0xc0,0xf7,0x58,0x01,0xaf,0xf7,0x5d,0x01,0x9e,0xf7,0x62,0x01,0x8d,0xf7,0x68,0x01,0x7b,0xf7,0x6d,0x01,0x6a,0xf7,0x72,0x01,0x58,0xf7,0x77,0x01,0x46,0xf7,0x7d,0x01,0x35,0xf7,0x82,0x01,0x23,0xf7,0x88,0x01,0x11,0xf7,0x8d,0x01,0xff,0xf6,0x93,0x01,  \
    0xed,0xf6,0x98,0x01,0xdb,0xf6,0x9e,0x01,0xca,0xf6,0xa3,0x01,0xb8,0xf6,0xa9,0x01,0xa5,0xf6,0xae,0x01,0x93,0xf6,0xb4,0x01,0x81,0xf6,0xba,0x01,0x6f,0xf6,0xbf,0x01,0x5d,0xf6,0xc5,0x01,0x4b,0xf6,0xcb,0x01,0x38,0xf6,0xd1,0x01,0x26,0xf6,0xd7,0x01,0x14,0xf6,0xdc,0x01,0x01,0xf6,0xe3,0x01,0xef,0xf5,0xe9,0x01,0xdd,0xf5,0xef,0x01,0xcb,0xf5,0xf5,0x01,0xb8,0xf5,0xfb,0x01,0xa6,0xf5,0x01,0x02,0x93,0xf5,0x07,0x02,0x81,0xf5,0x0d,0x02,0x6e,0xf5,0x13,0x02,0x5c,0xf5,  \
    0x1a,0x02,0x49,0xf5,0x20,0x02,0x36,0xf5,0x26,0x02,0x23,0xf5,0x2c,0x02,0x10,0xf5,0x33,0x02,0xfd,0xf4,0x39,0x02,0xea,0xf4,0x3f,0x02,0xd7,0xf4,0x46,0x02,0xc4,0xf4,0x4c,0x02,0xb1,0xf4,0x52,0x02,0x9c,0xf4,0x58,0x02,0x88,0xf4,0x5e,0x02,0x73,0xf4,0x63,0x02,0x5e,0xf4,0x69,0x02,0x4a,0xf4,0x6f,0x02,0x35,0xf4,0x75,0x02,0x20,0xf4,0x7b,0x02,0x0b,0xf4,0x81,0x02,0xf6,0xf3,0x86,0x02,0xe1,0xf3,0x8c,0x02,0xcc,0xf3,0x92,0x02,0xb7,0xf3,0x98,0x02,0xa1,0xf3,0x9e,0x02,  \
    0x8c,0xf3,0xa4,0x02,0x76,0xf3,0xa9,0x02,0x61,0xf3,0xaf,0x02,0x4b,0xf3,0xb5,0x02,0x35,0xf3,0xbb,0x02,0x20,0xf3,0xc1,0x02,0x0b,0xf3,0xc8,0x02,0xf6,0xf2,0xce,0x02,0xe1,0xf2,0xd4,0x02,0xcc,0xf2,0xda,0x02,0xb6,0xf2,0xe1,0x02,0xa1,0xf2,0xe7,0x02,0x8b,0xf2,0xed,0x02,0x75,0xf2,0xf3,0x02,0x60,0xf2,0xf9,0x02,0x4a,0xf2,0xff,0x02,0x34,0xf2,0x05,0x03,0x1d,0xf2,0x0b,0x03,0x07,0xf2,0x11,0x03,0xf1,0xf1,0x17,0x03,0xda,0xf1,0x1d,0x03,0xc4,0xf1,0x23,0x03,0xad,0xf1,  \
    0x29,0x03,0x96,0xf1,0x2f,0x03,0x7f,0xf1,0x34,0x03,0x68,0xf1,0x3a,0x03,0x51,0xf1,0x40,0x03,0x3a,0xf1,0x46,0x03,0x22,0xf1,0x4b,0x03,0x0b,0xf1,0x51,0x03,0xf3,0xf0,0x56,0x03,0xdb,0xf0,0x5c,0x03,0xc4,0xf0,0x61,0x03,0xab,0xf0,0x66,0x03,0x93,0xf0,0x6b,0x03,0x7b,0xf0,0x71,0x03,0x62,0xf0,0x76,0x03,0x4a,0xf0,0x7b,0x03,0x31,0xf0,0x7f,0x03,0x18,0xf0,0x84,0x03,0xff,0xef,0x89,0x03,0xe6,0xef,0x8e,0x03,0xcc,0xef,0x92,0x03,0xb3,0xef,0x96,0x03,0x99,0xef,0x9a,0x03,  \
    0x7e,0xef,0x9e,0x03,0x64,0xef,0xa2,0x03,0x49,0xef,0xa6,0x03,0x2e,0xef,0xa9,0x03,0x13,0xef,0xad,0x03,0xf8,0xee,0xb0,0x03,0xdc,0xee,0xb4,0x03,0xc1,0xee,0xb7,0x03,0xa5,0xee,0xba,0x03,0x8a,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x09,0x04,0x45,0x11,0x06,0x04,0x29,0x11,0x03,0x04,0x0d,0x11,0xff,0x03,0xf2,0x10,0xfb,0x03,0xd6,0x10,0xf8,0x03,0xbb,0x10,0xf4,0x03,0xa0,0x10,0xf0,0x03,0x85,0x10,0xec,0x03,0x6a,0x10,0xe7,0x03,0x4f,0x10,0xe3,0x03,0x35,0x10,0xdf,0x03,0x1a,0x10,0xda,0x03,0x00,0x10,0xd6,0x03,0xe6,0x0f,0xd1,0x03,0xcc,0x0f,0xcd,0x03,0xb2,0x0f,0xc8,0x03,0x98,0x0f,0xc3,0x03,0x7e,0x0f,0xbe,0x03,0x65,0x0f,0xb9,0x03,0x4b,0x0f,0xb4,0x03,  \
    0x32,0x0f,0xaf,0x03,0x1a,0x0f,0xa9,0x03,0x01,0x0f,0xa3,0x03,0xe8,0x0e,0x9e,0x03,0xd0,0x0e,0x98,0x03,0xb8,0x0e,0x92,0x03,0xa0,0x0e,0x8d,0x03,0x88,0x0e,0x87,0x03,0x70,0x0e,0x81,0x03,0x58,0x0e,0x7b,0x03,0x41,0x0e,0x75,0x03,0x29,0x0e,0x6f,0x03,0x12,0x0e,0x69,0x03,0xfb,0x0d,0x62,0x03,0xe4,0x0d,0x5c,0x03,0xcd,0x0d,0x56,0x03,0xb6,0x0d,0x50,0x03,0x9f,0x0d,0x49,0x03,0x88,0x0d,0x43,0x03,0x72,0x0d,0x3c,0x03,0x5c,0x0d,0x35,0x03,0x46,0x0d,0x2e,0x03,0x31,0x0d,  \
    0x27,0x03,0x1b,0x0d,0x21,0x03,0x06,0x0d,0x1a,0x03,0xf1,0x0c,0x13,0x03,0xdc,0x0c,0x0b,0x03,0xc7,0x0c,0x04,0x03,0xb2,0x0c,0xfd,0x02,0x9d,0x0c,0xf6,0x02,0x89,0x0c,0xef,0x02,0x74,0x0c,0xe8,0x02,0x60,0x0c,0xe1,0x02,0x4b,0x0c,0xda,0x02,0x37,0x0c,0xd3,0x02,0x23,0x0c,0xcb,0x02,0x0f,0x0c,0xc4,0x02,0xfb,0x0b,0xbe,0x02,0xe6,0x0b,0xb8,0x02,0xd0,0x0b,0xb2,0x02,0xbb,0x0b,0xac,0x02,0xa6,0x0b,0xa5,0x02,0x91,0x0b,0x9f,0x02,0x7c,0x0b,0x99,0x02,0x67,0x0b,0x93,0x02,  \
    0x52,0x0b,0x8d,0x02,0x3d,0x0b,0x86,0x02,0x28,0x0b,0x80,0x02,0x13,0x0b,0x7a,0x02,0xff,0x0a,0x74,0x02,0xea,0x0a,0x6e,0x02,0xd6,0x0a,0x68,0x02,0xc1,0x0a,0x61,0x02,0xad,0x0a,0x5b,0x02,0x98,0x0a,0x55,0x02,0x84,0x0a,0x4f,0x02,0x70,0x0a,0x49,0x02,0x5c,0x0a,0x43,0x02,0x48,0x0a,0x3d,0x02,0x34,0x0a,0x37,0x02,0x20,0x0a,0x31,0x02,0x0c,0x0a,0x2b,0x02,0xf8,0x09,0x25,0x02,0xe5,0x09,0x1f,0x02,0xd1,0x09,0x19,0x02,0xbd,0x09,0x13,0x02,0xaa,0x09,0x0d,0x02,0x96,0x09,  \
    0x07,0x02,0x83,0x09,0x01,0x02,0x6f,0x09,0xfb,0x01,0x5c,0x09,0xf5,0x01,0x49,0x09,0xef,0x01,0x35,0x09,0xe9,0x01,0x22,0x09,0xe3,0x01,0x11,0x09,0xdc,0x01,0x00,0x09,0xd6,0x01,0xee,0x08,0xcf,0x01,0xdd,0x08,0xc9,0x01,0xcc,0x08,0xc3,0x01,0xba,0x08,0xbc,0x01,0xa9,0x08,0xb6,0x01,0x98,0x08,0xb0,0x01,0x87,0x08,0xaa,0x01,0x76,0x08,0xa3,0x01,0x65,0x08,0x9d,0x01,0x54,0x08,0x97,0x01,0x43,0x08,0x91,0x01,0x33,0x08,0x8b,0x01,0x22,0x08,0x85,0x01,0x11,0x08,0x7f,0x01,  \
    0x00,0x08,0x79,0x01,0xf0,0x07,0x73,0x01,0xdf,0x07,0x6e,0x01,0xce,0x07,0x68,0x01,0xbe,0x07,0x62,0x01,0xad,0x07,0x5d,0x01,0x9c,0x07,0x57,0x01,0x8c,0x07,0x52,0x01,0x7b,0x07,0x4c,0x01,0x6a,0x07,0x47,0x01,0x5a,0x07,0x41,0x01,0x49,0x07,0x3c,0x01,0x39,0x07,0x37,0x01,0x28,0x07,0x31,0x01,0x18,0x07,0x2c,0x01,0x07,0x07,0x27,0x01,0xf7,0x06,0x22,0x01,0xe6,0x06,0x1d,0x01,0xd6,0x06,0x18,0x01,0xc6,0x06,0x13,0x01,0xb5,0x06,0x0e,0x01,0xa5,0x06,0x09,0x01,0x95,0x06,  \
    0x04,0x01,0x85,0x06,0xff,0x00,0x75,0x06,0xfb,0x00,0x64,0x06,0xf6,0x00,0x54,0x06,0xf1,0x00,0x43,0x06,0xed,0x00,0x32,0x06,0xe9,0x00,0x21,0x06,0xe5,0x00,0x10,0x06,0xe0,0x00,0xff,0x05,0xdc,0x00,0xee,0x05,0xd8,0x00,0xdd,0x05,0xd4,0x00,0xcc,0x05,0xd0,0x00,0xbb,0x05,0xcc,0x00,0xaa,0x05,0xc8,0x00,0x99,0x05,0xc4,0x00,0x88,0x05,0xc0,0x00,0x77,0x05,0xbc,0x00,0x67,0x05,0xb8,0x00,0x56,0x05,0xb4,0x00,0x45,0x05,0xb0,0x00,0x34,0x05,0xad,0x00,0x24,0x05,0xa9,0x00,  \
    0x13,0x05,0xa5,0x00,0x03,0x05,0xa2,0x00,0xf2,0x04,0x9e,0x00,0xe1,0x04,0x9b,0x00,0xd1,0x04,0x97,0x00,0xc0,0x04,0x93,0x00,0xb1,0x04,0x90,0x00,0xa1,0x04,0x8c,0x00,0x91,0x04,0x89,0x00,0x81,0x04,0x85,0x00,0x71,0x04,0x82,0x00,0x62,0x04,0x7f,0x00,0x52,0x04,0x7b,0x00,0x42,0x04,0x78,0x00,0x32,0x04,0x75,0x00,0x23,0x04,0x72,0x00,0x13,0x04,0x6f,0x00,0x03,0x04,0x6c,0x00,0xf4,0x03,0x69,0x00,0xe4,0x03,0x66,0x00,0xd4,0x03,0x63,0x00,0xc5,0x03,0x60,0x00,0xb5,0x03,  \
    0x5d,0x00,0xa5,0x03,0x5a,0x00,0x96,0x03,0x57,0x00,0x86,0x03,0x55,0x00,0x77,0x03,0x52,0x00,0x67,0x03,0x4f,0x00,0x57,0x03,0x4d,0x00,0x48,0x03,0x4a,0x00,0x38,0x03,0x48,0x00,0x29,0x03,0x45,0x00,0x1a,0x03,0x43,0x00,0x0b,0x03,0x40,0x00,0xfc,0x02,0x3e,0x00,0xed,0x02,0x3b,0x00,0xde,0x02,0x39,0x00,0xcf,0x02,0x37,0x00,0xc0,0x02,0x35,0x00,0xb0,0x02,0x33,0x00,0xa1,0x02,0x31,0x00,0x92,0x02,0x2f,0x00,0x83,0x02,0x2d,0x00,0x74,0x02,0x2b,0x00,0x65,0x02,0x29,0x00,  \
    0x56,0x02,0x27,0x00,0x47,0x02,0x25,0x00,0x37,0x02,0x23,0x00,0x28,0x02,0x22,0x00,0x19,0x02,0x20,0x00,0x0a,0x02,0x1e,0x00,0xfa,0x01,0x1d,0x00,0xeb,0x01,0x1b,0x00,0xdc,0x01,0x1a,0x00,0xcd,0x01,0x18,0x00,0xbd,0x01,0x17,0x00,0xae,0x01,0x16,0x00,0x9f,0x01,0x14,0x00,0x8f,0x01,0x13,0x00,0x7f,0x01,0x12,0x00,0x70,0x01,0x11,0x00,0x60,0x01,0x10,0x00,0x50,0x01,0x0f,0x00,0x40,0x01,0x0e,0x00,0x31,0x01,0x0d,0x00,0x21,0x01,0x0c,0x00,0x11,0x01,0x0b,0x00,0x02,0x01,  \
    0x0a,0x00,0xf2,0x00,0x0a,0x00,0xe2,0x00,0x09,0x00,0xd2,0x00,0x08,0x00,0xc3,0x00,0x07,0x00,0xb3,0x00,0x07,0x00,0xa3,0x00,0x06,0x00,0x93,0x00,0x06,0x00,0x84,0x00,0x05,0x00,0x74,0x00,0x05,0x00,0x64,0x00,0x04,0x00,0x54,0x00,0x04,0x00,0x45,0x00,0x04,0x00,0x35,0x00,0x03,0x00,0x25,0x00,0x03,0x00,0x16,0x00,0x03,0x00,0x06,0x00,0x03,0x00,0xf6,0xff,0x03,0x00,0xe6,0xff,0x03,0x00,0xd7,0xff,0x02,0x00,0xc7,0xff,0x03,0x00,0xb7,0xff,0x03,0x00,0xa8,0xff,0x03,0x00,  \
    0x98,0xff,0x03,0x00,0x88,0xff,0x03,0x00,0x78,0xff,0x03,0x00,0x69,0xff,0x03,0x00,0x59,0xff,0x04,0x00,0x49,0xff,0x04,0x00,0x3a,0xff,0x04,0x00,0x2a,0xff,0x05,0x00,0x1a,0xff,0x05,0x00,0x0a,0xff,0x06,0x00,0xfb,0xfe,0x06,0x00,0xeb,0xfe,0x07,0x00,0xdb,0xfe,0x07,0x00,0xcc,0xfe,0x08,0x00,0xbc,0xfe,0x09,0x00,0xac,0xfe,0x0a,0x00,0x9d,0xfe,0x0a,0x00,0x8d,0xfe,0x0b,0x00,0x7d,0xfe,0x0c,0x00,0x6d,0xfe,0x0d,0x00,0x5e,0xfe,0x0e,0x00,0x4e,0xfe,0x0f,0x00,0x3e,0xfe,  \
    0x10,0x00,0x2f,0xfe,0x11,0x00,0x1f,0xfe,0x12,0x00,0x0f,0xfe,0x13,0x00,0xff,0xfd,0x14,0x00,0xef,0xfd,0x16,0x00,0xdf,0xfd,0x17,0x00,0xcf,0xfd,0x18,0x00,0xbf,0xfd,0x19,0x00,0xaf,0xfd,0x1b,0x00,0x9f,0xfd,0x1c,0x00,0x90,0xfd,0x1e,0x00,0x80,0xfd,0x1f,0x00,0x6f,0xfd,0x21,0x00,0x5f,0xfd,0x22,0x00,0x4f,0xfd,0x24,0x00,0x3f,0xfd,0x25,0x00,0x2f,0xfd,0x27,0x00,0x1f,0xfd,0x29,0x00,0x0f,0xfd,0x2b,0x00,0xff,0xfc,0x2c,0x00,0xef,0xfc,0x2e,0x00,0xdf,0xfc,0x30,0x00,  \
    0xcf,0xfc,0x32,0x00,0xbf,0xfc,0x34,0x00,0xae,0xfc,0x36,0x00,0x9e,0xfc,0x38,0x00,0x8e,0xfc,0x3a,0x00,0x7e,0xfc,0x3c,0x00,0x6e,0xfc,0x3e,0x00,0x5d,0xfc,0x40,0x00,0x4e,0xfc,0x43,0x00,0x3e,0xfc,0x45,0x00,0x2e,0xfc,0x47,0x00,0x1e,0xfc,0x4a,0x00,0x0f,0xfc,0x4c,0x00,0xff,0xfb,0x4f,0x00,0xef,0xfb,0x51,0x00,0xdf,0xfb,0x54,0x00,0xd0,0xfb,0x57,0x00,0xc0,0xfb,0x59,0x00,0xb0,0xfb,0x5c,0x00,0xa1,0xfb,0x5f,0x00,0x91,0xfb,0x62,0x00,0x81,0xfb,0x65,0x00,0x71,0xfb,  \
    0x67,0x00,0x62,0xfb,0x6a,0x00,0x52,0xfb,0x6d,0x00,0x42,0xfb,0x70,0x00,0x32,0xfb,0x74,0x00,0x23,0xfb,0x77,0x00,0x13,0xfb,0x7a,0x00,0x03,0xfb,0x7d,0x00,0xf3,0xfa,0x80,0x00,0xe4,0xfa,0x84,0x00,0xd4,0xfa,0x87,0x00,0xc4,0xfa,0x8a,0x00,0xb4,0xfa,0x8e,0x00,0xa4,0xfa,0x91,0x00,0x93,0xfa,0x95,0x00,0x83,0xfa,0x98,0x00,0x73,0xfa,0x9b,0x00,0x62,0xfa,0x9f,0x00,0x52,0xfa,0xa3,0x00,0x42,0xfa,0xa6,0x00,0x31,0xfa,0xaa,0x00,0x21,0xfa,0xae,0x00,0x10,0xfa,0xb1,0x00,  \
    0x00,0xfa,0xb5,0x00,0xef,0xf9,0xb9,0x00,0xdf,0xf9,0xbd,0x00,0xce,0xf9,0xc1,0x00,0xbe,0xf9,0xc5,0x00,0xad,0xf9,0xc9,0x00,0x9d,0xf9,0xcd,0x00,0x8c,0xf9,0xd1,0x00,0x7c,0xf9,0xd5,0x00,0x6b,0xf9,0xd9,0x00,0x5a,0xf9,0xdd,0x00,0x4a,0xf9,0xe1,0x00,0x39,0xf9,0xe6,0x00,0x28,0xf9,0xea,0x00,0x18,0xf9,0xee,0x00,0x07,0xf9,0xf3,0x00,0xf7,0xf8,0xf7,0x00,0xe6,0xf8,0xfc,0x00,0xd6,0xf8,0x01,0x01,0xc5,0xf8,0x05,0x01,0xb5,0xf8,0x0a,0x01,0xa4,0xf8,0x0f,0x01,0x94,0xf8,  \
    0x13,0x01,0x83,0xf8,0x18,0x01,0x72,0xf8,0x1d,0x01,0x62,0xf8,0x22,0x01,0x51,0xf8,0x27,0x01,0x40,0xf8,0x2c,0x01,0x2f,0xf8,0x31,0x01,0x1f,0xf8,0x36,0x01,0x0e,0xf8,0x3b,0x01,0xfd,0xf7,0x40,0x01,0xec,0xf7,0x45,0x01,0xdb,0xf7,0x4a,0x01,0xca,0xf7,0x50,0x01,0xb9,0xf7,0x55,0x01,0xa8,0xf7,0x5a,0x01,0x97,0xf7,0x5f,0x01,0x85,0xf7,0x65,0x01,0x74,0xf7,0x6a,0x01,0x62,0xf7,0x6f,0x01,0x51,0xf7,0x74,0x01,0x3f,0xf7,0x7a,0x01,0x2d,0xf7,0x7f,0x01,0x1b,0xf7,0x85,0x01,  \
    0x0a,0xf7,0x8a,0x01,0xf8,0xf6,0x90,0x01,0xe6,0xf6,0x95,0x01,0xd4,0xf6,0x9b,0x01,0xc2,0xf6,0xa0,0x01,0xb0,0xf6,0xa6,0x01,0x9e,0xf6,0xab,0x01,0x8c,0xf6,0xb1,0x01,0x7a,0xf6,0xb7,0x01,0x67,0xf6,0xbd,0x01,0x55,0xf6,0xc2,0x01,0x43,0xf6,0xc8,0x01,0x30,0xf6,0xce,0x01,0x1e,0xf6,0xd4,0x01,0x0c,0xf6,0xda,0x01,0xfa,0xf5,0xe0,0x01,0xe8,0xf5,0xe6,0x01,0xd5,0xf5,0xec,0x01,0xc3,0xf5,0xf2,0x01,0xb1,0xf5,0xf8,0x01,0x9e,0xf5,0xfe,0x01,0x8b,0xf5,0x05,0x02,0x79,0xf5,  \
    0x0b,0x02,0x66,0xf5,0x11,0x02,0x53,0xf5,0x17,0x02,0x41,0xf5,0x1d,0x02,0x2e,0xf5,0x24,0x02,0x1b,0xf5,0x2a,0x02,0x08,0xf5,0x30,0x02,0xf5,0xf4,0x36,0x02,0xe2,0xf4,0x3d,0x02,0xce,0xf4,0x43,0x02,0xbb,0xf4,0x49,0x02,0xa7,0xf4,0x4f,0x02,0x92,0xf4,0x55,0x02,0x7e,0xf4,0x5a,0x02,0x69,0xf4,0x60,0x02,0x54,0xf4,0x66,0x02,0x40,0xf4,0x6c,0x02,0x2b,0xf4,0x72,0x02,0x16,0xf4,0x77,0x02,0x01,0xf4,0x7d,0x02,0xec,0xf3,0x83,0x02,0xd7,0xf3,0x89,0x02,0xc1,0xf3,0x8f,0x02,  \
    0xac,0xf3,0x95,0x02,0x97,0xf3,0x9a,0x02,0x81,0xf3,0xa0,0x02,0x6c,0xf3,0xa6,0x02,0x56,0xf3,0xac,0x02,0x40,0xf3,0xb2,0x02,0x2b,0xf3,0xb8,0x02,0x16,0xf3,0xbe,0x02,0x01,0xf3,0xc4,0x02,0xeb,0xf2,0xcb,0x02,0xd6,0xf2,0xd1,0x02,0xc1,0xf2,0xd7,0x02,0xab,0xf2,0xdd,0x02,0x95,0xf2,0xe3,0x02,0x80,0xf2,0xe9,0x02,0x6a,0xf2,0xef,0x02,0x54,0xf2,0xf5,0x02,0x3e,0xf2,0xfb,0x02,0x28,0xf2,0x01,0x03,0x11,0xf2,0x07,0x03,0xfb,0xf1,0x0d,0x03,0xe4,0xf1,0x13,0x03,0xce,0xf1,  \
    0x19,0x03,0xb7,0xf1,0x1f,0x03,0xa0,0xf1,0x24,0x03,0x89,0xf1,0x2a,0x03,0x72,0xf1,0x30,0x03,0x5b,0xf1,0x36,0x03,0x44,0xf1,0x3b,0x03,0x2c,0xf1,0x41,0x03,0x15,0xf1,0x46,0x03,0xfd,0xf0,0x4c,0x03,0xe5,0xf0,0x51,0x03,0xcd,0xf0,0x56,0x03,0xb5,0xf0,0x5b,0x03,0x9d,0xf0,0x61,0x03,0x84,0xf0,0x66,0x03,0x6c,0xf0,0x6b,0x03,0x53,0xf0,0x70,0x03,0x3a,0xf0,0x74,0x03,0x21,0xf0,0x79,0x03,0x08,0xf0,0x7e,0x03,0xef,0xef,0x82,0x03,0xd5,0xef,0x87,0x03,0xbc,0xef,0x8b,0x03,  \
    0xa2,0xef,0x8f,0x03,0x87,0xef,0x93,0x03,0x6d,0xef,0x97,0x03,0x52,0xef,0x9a,0x03,0x37,0xef,0x9e,0x03,0x1c,0xef,0xa2,0x03,0x01,0xef,0xa5,0x03,0xe5,0xee,0xa8,0x03,0xca,0xee,0xab,0x03,0xae,0xee,0xaf,0x03,0x93,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfd,0x03,0x3d,0x11,0xf9,0x03,0x21,0x11,0xf6,0x03,0x06,0x11,0xf2,0x03,0xea,0x10,0xef,0x03,0xcf,0x10,0xeb,0x03,0xb3,0x10,0xe7,0x03,0x98,0x10,0xe3,0x03,0x7d,0x10,0xdf,0x03,0x62,0x10,0xdb,0x03,0x48,0x10,0xd7,0x03,0x2d,0x10,0xd3,0x03,0x13,0x10,0xce,0x03,0xf8,0x0f,0xca,0x03,0xde,0x0f,0xc5,0x03,0xc4,0x0f,0xc1,0x03,0xaa,0x0f,0xbc,0x03,0x90,0x0f,0xb7,0x03,0x77,0x0f,0xb2,0x03,0x5d,0x0f,0xad,0x03,  \
    0x44,0x0f,0xa8,0x03,0x2b,0x0f,0xa3,0x03,0x12,0x0f,0x9d,0x03,0xf9,0x0e,0x98,0x03,0xe1,0x0e,0x92,0x03,0xc8,0x0e,0x8d,0x03,0xb0,0x0e,0x87,0x03,0x98,0x0e,0x81,0x03,0x80,0x0e,0x7b,0x03,0x68,0x0e,0x75,0x03,0x50,0x0e,0x6f,0x03,0x38,0x0e,0x6a,0x03,0x21,0x0e,0x63,0x03,0x0a,0x0e,0x5d,0x03,0xf2,0x0d,0x57,0x03,0xdb,0x0d,0x51,0x03,0xc4,0x0d,0x4b,0x03,0xad,0x0d,0x45,0x03,0x97,0x0d,0x3e,0x03,0x80,0x0d,0x38,0x03,0x69,0x0d,0x31,0x03,0x53,0x0d,0x2b,0x03,0x3e,0x0d,  \
    0x24,0x03,0x28,0x0d,0x1d,0x03,0x12,0x0d,0x16,0x03,0xfd,0x0c,0x0f,0x03,0xe8,0x0c,0x08,0x03,0xd3,0x0c,0x01,0x03,0xbe,0x0c,0xfa,0x02,0xa9,0x0c,0xf3,0x02,0x94,0x0c,0xec,0x02,0x7f,0x0c,0xe5,0x02,0x6b,0x0c,0xde,0x02,0x56,0x0c,0xd7,0x02,0x42,0x0c,0xd0,0x02,0x2e,0x0c,0xc9,0x02,0x1a,0x0c,0xc2,0x02,0x06,0x0c,0xbb,0x02,0xf2,0x0b,0xb5,0x02,0xdc,0x0b,0xae,0x02,0xc7,0x0b,0xa8,0x02,0xb1,0x0b,0xa2,0x02,0x9c,0x0b,0x9c,0x02,0x87,0x0b,0x96,0x02,0x72,0x0b,0x90,0x02,  \
    0x5d,0x0b,0x89,0x02,0x48,0x0b,0x83,0x02,0x33,0x0b,0x7d,0x02,0x1e,0x0b,0x77,0x02,0x0a,0x0b,0x71,0x02,0xf5,0x0a,0x6b,0x02,0xe1,0x0a,0x64,0x02,0xcc,0x0a,0x5e,0x02,0xb8,0x0a,0x58,0x02,0xa3,0x0a,0x52,0x02,0x8f,0x0a,0x4c,0x02,0x7b,0x0a,0x46,0x02,0x67,0x0a,0x40,0x02,0x53,0x0a,0x3a,0x02,0x3e,0x0a,0x34,0x02,0x2b,0x0a,0x2e,0x02,0x17,0x0a,0x28,0x02,0x03,0x0a,0x22,0x02,0xef,0x09,0x1c,0x02,0xdb,0x09,0x16,0x02,0xc8,0x09,0x10,0x02,0xb4,0x09,0x0a,0x02,0xa0,0x09,  \
    0x04,0x02,0x8d,0x09,0xfe,0x01,0x79,0x09,0xf8,0x01,0x66,0x09,0xf2,0x01,0x53,0x09,0xec,0x01,0x40,0x09,0xe6,0x01,0x2c,0x09,0xe0,0x01,0x19,0x09,0xda,0x01,0x08,0x09,0xd4,0x01,0xf7,0x08,0xcd,0x01,0xe5,0x08,0xc7,0x01,0xd4,0x08,0xc0,0x01,0xc3,0x08,0xba,0x01,0xb1,0x08,0xb4,0x01,0xa0,0x08,0xad,0x01,0x8f,0x08,0xa7,0x01,0x7e,0x08,0xa1,0x01,0x6d,0x08,0x9b,0x01,0x5c,0x08,0x95,0x01,0x4b,0x08,0x8f,0x01,0x3a,0x08,0x89,0x01,0x29,0x08,0x83,0x01,0x19,0x08,0x7d,0x01,  \
    0x08,0x08,0x77,0x01,0xf7,0x07,0x71,0x01,0xe7,0x07,0x6b,0x01,0xd6,0x07,0x65,0x01,0xc5,0x07,0x5f,0x01,0xb5,0x07,0x5a,0x01,0xa4,0x07,0x54,0x01,0x93,0x07,0x4f,0x01,0x83,0x07,0x49,0x01,0x72,0x07,0x44,0x01,0x61,0x07,0x3e,0x01,0x51,0x07,0x39,0x01,0x40,0x07,0x34,0x01,0x30,0x07,0x2e,0x01,0x1f,0x07,0x29,0x01,0x0f,0x07,0x24,0x01,0xfe,0x06,0x1f,0x01,0xee,0x06,0x1a,0x01,0xde,0x06,0x15,0x01,0xcd,0x06,0x10,0x01,0xbd,0x06,0x0b,0x01,0xad,0x06,0x06,0x01,0x9d,0x06,  \
    0x01,0x01,0x8c,0x06,0xfc,0x00,0x7c,0x06,0xf7,0x00,0x6c,0x06,0xf2,0x00,0x5c,0x06,0xee,0x00,0x4c,0x06,0xe9,0x00,0x3b,0x06,0xe5,0x00,0x2a,0x06,0xe1,0x00,0x19,0x06,0xdc,0x00,0x08,0x06,0xd8,0x00,0xf7,0x05,0xd4,0x00,0xe6,0x05,0xd0,0x00,0xd5,0x05,0xcc,0x00,0xc4,0x05,0xc8,0x00,0xb3,0x05,0xc4,0x00,0xa2,0x05,0xc0,0x00,0x91,0x05,0xbc,0x00,0x81,0x05,0xb8,0x00,0x70,0x05,0xb4,0x00,0x5f,0x05,0xb0,0x00,0x4e,0x05,0xac,0x00,0x3e,0x05,0xa8,0x00,0x2d,0x05,0xa5,0x00,  \
    0x1d,0x05,0xa1,0x00,0x0c,0x05,0x9d,0x00,0xfb,0x04,0x9a,0x00,0xeb,0x04,0x96,0x00,0xda,0x04,0x92,0x00,0xca,0x04,0x8f,0x00,0xba,0x04,0x8b,0x00,0xaa,0x04,0x88,0x00,0x9a,0x04,0x84,0x00,0x8a,0x04,0x81,0x00,0x7b,0x04,0x7d,0x00,0x6b,0x04,0x7a,0x00,0x5b,0x04,0x77,0x00,0x4c,0x04,0x73,0x00,0x3c,0x04,0x70,0x00,0x2c,0x04,0x6d,0x00,0x1d,0x04,0x6a,0x00,0x0d,0x04,0x67,0x00,0xfd,0x03,0x63,0x00,0xee,0x03,0x60,0x00,0xde,0x03,0x5d,0x00,0xcf,0x03,0x5a,0x00,0xbf,0x03,  \
    0x58,0x00,0xaf,0x03,0x55,0x00,0xa0,0x03,0x52,0x00,0x90,0x03,0x4f,0x00,0x81,0x03,0x4c,0x00,0x71,0x03,0x4a,0x00,0x62,0x03,0x47,0x00,0x52,0x03,0x45,0x00,0x43,0x03,0x42,0x00,0x33,0x03,0x40,0x00,0x24,0x03,0x3d,0x00,0x15,0x03,0x3a,0x00,0x06,0x03,0x38,0x00,0xf7,0x02,0x36,0x00,0xe8,0x02,0x33,0x00,0xd9,0x02,0x31,0x00,0xca,0x02,0x2f,0x00,0xbb,0x02,0x2d,0x00,0xac,0x02,0x2b,0x00,0x9d,0x02,0x28,0x00,0x8e,0x02,0x26,0x00,0x7f,0x02,0x24,0x00,0x70,0x02,0x22,0x00,  \
    0x61,0x02,0x21,0x00,0x52,0x02,0x1f,0x00,0x43,0x02,0x1d,0x00,0x34,0x02,0x1b,0x00,0x24,0x02,0x1a,0x00,0x15,0x02,0x18,0x00,0x06,0x02,0x16,0x00,0xf7,0x01,0x15,0x00,0xe8,0x01,0x13,0x00,0xd9,0x01,0x12,0x00,0xc9,0x01,0x10,0x00,0xba,0x01,0x0f,0x00,0xab,0x01,0x0e,0x00,0x9c,0x01,0x0c,0x00,0x8c,0x01,0x0b,0x00,0x7d,0x01,0x0a,0x00,0x6d,0x01,0x09,0x00,0x5d,0x01,0x08,0x00,0x4e,0x01,0x07,0x00,0x3e,0x01,0x06,0x00,0x2e,0x01,0x05,0x00,0x1f,0x01,0x04,0x00,0x0f,0x01,  \
    0x03,0x00,0x00,0x01,0x02,0x00,0xf0,0x00,0x01,0x00,0xe0,0x00,0x01,0x00,0xd1,0x00,0x00,0x00,0xc1,0x00,0xff,0xff,0xb1,0x00,0xff,0xff,0xa2,0x00,0xfe,0xff,0x92,0x00,0xfd,0xff,0x82,0x00,0xfd,0xff,0x73,0x00,0xfd,0xff,0x63,0x00,0xfc,0xff,0x54,0x00,0xfc,0xff,0x44,0x00,0xfb,0xff,0x34,0x00,0xfb,0xff,0x25,0x00,0xfb,0xff,0x15,0x00,0xfb,0xff,0x05,0x00,0xfb,0xff,0xf6,0xff,0xfa,0xff,0xe6,0xff,0xfa,0xff,0xd7,0xff,0xfa,0xff,0xc7,0xff,0xfa,0xff,0xb7,0xff,0xfa,0xff,  \
    0xa8,0xff,0xfa,0xff,0x98,0xff,0xfb,0xff,0x89,0xff,0xfb,0xff,0x79,0xff,0xfb,0xff,0x69,0xff,0xfb,0xff,0x5a,0xff,0xfb,0xff,0x4a,0xff,0xfc,0xff,0x3a,0xff,0xfc,0xff,0x2b,0xff,0xfd,0xff,0x1b,0xff,0xfd,0xff,0x0c,0xff,0xfe,0xff,0xfc,0xfe,0xfe,0xff,0xec,0xfe,0xff,0xff,0xdd,0xfe,0xff,0xff,0xcd,0xfe,0x00,0x00,0xbe,0xfe,0x01,0x00,0xae,0xfe,0x01,0x00,0x9e,0xfe,0x02,0x00,0x8f,0xfe,0x03,0x00,0x7f,0xfe,0x04,0x00,0x70,0xfe,0x05,0x00,0x60,0xfe,0x06,0x00,0x50,0xfe,  \
    0x07,0x00,0x41,0xfe,0x08,0x00,0x31,0xfe,0x09,0x00,0x21,0xfe,0x0a,0x00,0x12,0xfe,0x0b,0x00,0x02,0xfe,0x0c,0x00,0xf2,0xfd,0x0d,0x00,0xe2,0xfd,0x0f,0x00,0xd3,0xfd,0x10,0x00,0xc3,0xfd,0x11,0x00,0xb3,0xfd,0x13,0x00,0xa3,0xfd,0x14,0x00,0x93,0xfd,0x15,0x00,0x83,0xfd,0x17,0x00,0x73,0xfd,0x19,0x00,0x63,0xfd,0x1a,0x00,0x53,0xfd,0x1c,0x00,0x43,0xfd,0x1d,0x00,0x33,0xfd,0x1f,0x00,0x24,0xfd,0x21,0x00,0x14,0xfd,0x22,0x00,0x04,0xfd,0x24,0x00,0xf4,0xfc,0x26,0x00,  \
    0xe3,0xfc,0x28,0x00,0xd3,0xfc,0x2a,0x00,0xc3,0xfc,0x2c,0x00,0xb3,0xfc,0x2e,0x00,0xa3,0xfc,0x30,0x00,0x93,0xfc,0x32,0x00,0x83,0xfc,0x34,0x00,0x73,0xfc,0x36,0x00,0x63,0xfc,0x39,0x00,0x53,0xfc,0x3b,0x00,0x43,0xfc,0x3d,0x00,0x34,0xfc,0x40,0x00,0x24,0xfc,0x42,0x00,0x15,0xfc,0x44,0x00,0x05,0xfc,0x47,0x00,0xf5,0xfb,0x4a,0x00,0xe6,0xfb,0x4c,0x00,0xd6,0xfb,0x4f,0x00,0xc6,0xfb,0x51,0x00,0xb7,0xfb,0x54,0x00,0xa7,0xfb,0x57,0x00,0x97,0xfb,0x5a,0x00,0x88,0xfb,  \
    0x5d,0x00,0x78,0xfb,0x60,0x00,0x68,0xfb,0x63,0x00,0x59,0xfb,0x66,0x00,0x49,0xfb,0x69,0x00,0x39,0xfb,0x6c,0x00,0x2a,0xfb,0x6f,0x00,0x1a,0xfb,0x72,0x00,0x0a,0xfb,0x75,0x00,0xfb,0xfa,0x79,0x00,0xeb,0xfa,0x7c,0x00,0xdb,0xfa,0x7f,0x00,0xcb,0xfa,0x83,0x00,0xbc,0xfa,0x86,0x00,0xab,0xfa,0x89,0x00,0x9b,0xfa,0x8d,0x00,0x8b,0xfa,0x90,0x00,0x7b,0xfa,0x94,0x00,0x6a,0xfa,0x97,0x00,0x5a,0xfa,0x9b,0x00,0x4a,0xfa,0x9e,0x00,0x39,0xfa,0xa2,0x00,0x29,0xfa,0xa6,0x00,  \
    0x19,0xfa,0xaa,0x00,0x08,0xfa,0xad,0x00,0xf8,0xf9,0xb1,0x00,0xe7,0xf9,0xb5,0x00,0xd7,0xf9,0xb9,0x00,0xc7,0xf9,0xbd,0x00,0xb6,0xf9,0xc1,0x00,0xa6,0xf9,0xc5,0x00,0x95,0xf9,0xc9,0x00,0x85,0xf9,0xcd,0x00,0x74,0xf9,0xd1,0x00,0x63,0xf9,0xd6,0x00,0x53,0xf9,0xda,0x00,0x42,0xf9,0xde,0x00,0x32,0xf9,0xe2,0x00,0x21,0xf9,0xe7,0x00,0x11,0xf9,0xeb,0x00,0x00,0xf9,0xf0,0x00,0xf0,0xf8,0xf4,0x00,0xdf,0xf8,0xf9,0x00,0xcf,0xf8,0xfe,0x00,0xbe,0xf8,0x02,0x01,0xae,0xf8,  \
    0x07,0x01,0x9d,0xf8,0x0c,0x01,0x8d,0xf8,0x11,0x01,0x7c,0xf8,0x15,0x01,0x6b,0xf8,0x1a,0x01,0x5b,0xf8,0x1f,0x01,0x4a,0xf8,0x24,0x01,0x39,0xf8,0x29,0x01,0x29,0xf8,0x2e,0x01,0x18,0xf8,0x33,0x01,0x07,0xf8,0x39,0x01,0xf6,0xf7,0x3e,0x01,0xe5,0xf7,0x43,0x01,0xd4,0xf7,0x48,0x01,0xc3,0xf7,0x4d,0x01,0xb2,0xf7,0x53,0x01,0xa1,0xf7,0x58,0x01,0x90,0xf7,0x5d,0x01,0x7e,0xf7,0x62,0x01,0x6d,0xf7,0x68,0x01,0x5b,0xf7,0x6d,0x01,0x49,0xf7,0x72,0x01,0x38,0xf7,0x78,0x01,  \
    0x26,0xf7,0x7d,0x01,0x14,0xf7,0x83,0x01,0x02,0xf7,0x88,0x01,0xf0,0xf6,0x8e,0x01,0xdf,0xf6,0x93,0x01,0xcd,0xf6,0x99,0x01,0xbb,0xf6,0x9e,0x01,0xa9,0xf6,0xa4,0x01,0x96,0xf6,0xaa,0x01,0x84,0xf6,0xaf,0x01,0x72,0xf6,0xb5,0x01,0x60,0xf6,0xbb,0x01,0x4e,0xf6,0xc1,0x01,0x3b,0xf6,0xc6,0x01,0x29,0xf6,0xcc,0x01,0x17,0xf6,0xd2,0x01,0x05,0xf6,0xd8,0x01,0xf3,0xf5,0xde,0x01,0xe0,0xf5,0xe4,0x01,0xce,0xf5,0xeb,0x01,0xbb,0xf5,0xf1,0x01,0xa9,0xf5,0xf7,0x01,0x96,0xf5,  \
    0xfd,0x01,0x84,0xf5,0x03,0x02,0x71,0xf5,0x09,0x02,0x5e,0xf5,0x0f,0x02,0x4c,0xf5,0x16,0x02,0x39,0xf5,0x1c,0x02,0x26,0xf5,0x22,0x02,0x13,0xf5,0x28,0x02,0x00,0xf5,0x2f,0x02,0xec,0xf4,0x35,0x02,0xd9,0xf4,0x3b,0x02,0xc6,0xf4,0x41,0x02,0xb2,0xf4,0x47,0x02,0x9d,0xf4,0x4d,0x02,0x89,0xf4,0x53,0x02,0x74,0xf4,0x58,0x02,0x5f,0xf4,0x5e,0x02,0x4b,0xf4,0x64,0x02,0x36,0xf4,0x6a,0x02,0x21,0xf4,0x70,0x02,0x0c,0xf4,0x75,0x02,0xf7,0xf3,0x7b,0x02,0xe2,0xf3,0x81,0x02,  \
    0xcc,0xf3,0x87,0x02,0xb7,0xf3,0x8d,0x02,0xa2,0xf3,0x92,0x02,0x8c,0xf3,0x98,0x02,0x77,0xf3,0x9e,0x02,0x61,0xf3,0xa4,0x02,0x4b,0xf3,0xaa,0x02,0x36,0xf3,0xb0,0x02,0x21,0xf3,0xb6,0x02,0x0c,0xf3,0xbc,0x02,0xf6,0xf2,0xc3,0x02,0xe1,0xf2,0xc9,0x02,0xcc,0xf2,0xcf,0x02,0xb6,0xf2,0xd5,0x02,0xa0,0xf2,0xdb,0x02,0x8b,0xf2,0xe1,0x02,0x75,0xf2,0xe7,0x02,0x5f,0xf2,0xed,0x02,0x49,0xf2,0xf3,0x02,0x33,0xf2,0xf9,0x02,0x1c,0xf2,0xff,0x02,0x06,0xf2,0x05,0x03,0xef,0xf1,  \
    0x0b,0x03,0xd8,0xf1,0x10,0x03,0xc2,0xf1,0x16,0x03,0xab,0xf1,0x1c,0x03,0x94,0xf1,0x22,0x03,0x7d,0xf1,0x27,0x03,0x65,0xf1,0x2d,0x03,0x4e,0xf1,0x33,0x03,0x37,0xf1,0x38,0x03,0x1f,0xf1,0x3e,0x03,0x07,0xf1,0x43,0x03,0xef,0xf0,0x48,0x03,0xd7,0xf0,0x4e,0x03,0xbf,0xf0,0x53,0x03,0xa7,0xf0,0x58,0x03,0x8f,0xf0,0x5d,0x03,0x76,0xf0,0x62,0x03,0x5d,0xf0,0x67,0x03,0x44,0xf0,0x6c,0x03,0x2b,0xf0,0x70,0x03,0x12,0xf0,0x75,0x03,0xf9,0xef,0x79,0x03,0xdf,0xef,0x7e,0x03,  \
    0xc6,0xef,0x82,0x03,0xac,0xef,0x86,0x03,0x91,0xef,0x8a,0x03,0x77,0xef,0x8e,0x03,0x5c,0xef,0x91,0x03,0x41,0xef,0x95,0x03,0x26,0xef,0x98,0x03,0x0b,0xef,0x9c,0x03,0xef,0xee,0x9f,0x03,0xd4,0xee,0xa2,0x03,0xb8,0xee,0xa5,0x03,0x9c,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf0,0x03,0x36,0x11,0xed,0x03,0x1a,0x11,0xea,0x03,0xfe,0x10,0xe6,0x03,0xe3,0x10,0xe2,0x03,0xc7,0x10,0xdf,0x03,0xac,0x10,0xdb,0x03,0x91,0x10,0xd7,0x03,0x76,0x10,0xd3,0x03,0x5b,0x10,0xcf,0x03,0x40,0x10,0xcb,0x03,0x25,0x10,0xc6,0x03,0x0b,0x10,0xc2,0x03,0xf1,0x0f,0xbe,0x03,0xd6,0x0f,0xb9,0x03,0xbc,0x0f,0xb5,0x03,0xa2,0x0f,0xb0,0x03,0x89,0x0f,0xab,0x03,0x6f,0x0f,0xa6,0x03,  \
    0x55,0x0f,0xa1,0x03,0x3c,0x0f,0x9c,0x03,0x23,0x0f,0x97,0x03,0x0a,0x0f,0x92,0x03,0xf1,0x0e,0x8c,0x03,0xd9,0x0e,0x87,0x03,0xc0,0x0e,0x81,0x03,0xa8,0x0e,0x7b,0x03,0x90,0x0e,0x76,0x03,0x78,0x0e,0x70,0x03,0x60,0x0e,0x6a,0x03,0x48,0x0e,0x64,0x03,0x30,0x0e,0x5e,0x03,0x19,0x0e,0x58,0x03,0x01,0x0e,0x52,0x03,0xea,0x0d,0x4c,0x03,0xd3,0x0d,0x46,0x03,0xbc,0x0d,0x40,0x03,0xa5,0x0d,0x3a,0x03,0x8e,0x0d,0x34,0x03,0x77,0x0d,0x2d,0x03,0x61,0x0d,0x27,0x03,0x4b,0x0d,  \
    0x20,0x03,0x35,0x0d,0x19,0x03,0x1f,0x0d,0x12,0x03,0x0a,0x0d,0x0c,0x03,0xf4,0x0c,0x05,0x03,0xdf,0x0c,0xfe,0x02,0xca,0x0c,0xf7,0x02,0xb5,0x0c,0xf0,0x02,0xa0,0x0c,0xe9,0x02,0x8b,0x0c,0xe2,0x02,0x76,0x0c,0xdb,0x02,0x62,0x0c,0xd4,0x02,0x4d,0x0c,0xcd,0x02,0x39,0x0c,0xc6,0x02,0x25,0x0c,0xbf,0x02,0x10,0x0c,0xb8,0x02,0xfc,0x0b,0xb1,0x02,0xe8,0x0b,0xab,0x02,0xd3,0x0b,0xa5,0x02,0xbd,0x0b,0x9f,0x02,0xa8,0x0b,0x99,0x02,0x93,0x0b,0x92,0x02,0x7e,0x0b,0x8c,0x02,  \
    0x69,0x0b,0x86,0x02,0x54,0x0b,0x80,0x02,0x3f,0x0b,0x7a,0x02,0x2a,0x0b,0x74,0x02,0x15,0x0b,0x6e,0x02,0x00,0x0b,0x68,0x02,0xec,0x0a,0x61,0x02,0xd7,0x0a,0x5b,0x02,0xc3,0x0a,0x55,0x02,0xae,0x0a,0x4f,0x02,0x9a,0x0a,0x49,0x02,0x86,0x0a,0x43,0x02,0x71,0x0a,0x3d,0x02,0x5d,0x0a,0x37,0x02,0x49,0x0a,0x31,0x02,0x35,0x0a,0x2b,0x02,0x21,0x0a,0x25,0x02,0x0d,0x0a,0x1f,0x02,0xfa,0x09,0x19,0x02,0xe6,0x09,0x13,0x02,0xd2,0x09,0x0d,0x02,0xbe,0x09,0x07,0x02,0xab,0x09,  \
    0x01,0x02,0x97,0x09,0xfb,0x01,0x84,0x09,0xf5,0x01,0x70,0x09,0xef,0x01,0x5d,0x09,0xe9,0x01,0x4a,0x09,0xe3,0x01,0x37,0x09,0xde,0x01,0x23,0x09,0xd8,0x01,0x11,0x09,0xd1,0x01,0xff,0x08,0xcb,0x01,0xee,0x08,0xc4,0x01,0xdc,0x08,0xbe,0x01,0xcb,0x08,0xb8,0x01,0xba,0x08,0xb1,0x01,0xa8,0x08,0xab,0x01,0x97,0x08,0xa5,0x01,0x86,0x08,0x9f,0x01,0x75,0x08,0x99,0x01,0x64,0x08,0x92,0x01,0x53,0x08,0x8c,0x01,0x42,0x08,0x86,0x01,0x31,0x08,0x80,0x01,0x20,0x08,0x7a,0x01,  \
    0x10,0x08,0x74,0x01,0xff,0x07,0x6e,0x01,0xee,0x07,0x69,0x01,0xde,0x07,0x63,0x01,0xcd,0x07,0x5d,0x01,0xbc,0x07,0x57,0x01,0xac,0x07,0x52,0x01,0x9b,0x07,0x4c,0x01,0x8a,0x07,0x47,0x01,0x7a,0x07,0x41,0x01,0x69,0x07,0x3c,0x01,0x58,0x07,0x36,0x01,0x48,0x07,0x31,0x01,0x37,0x07,0x2c,0x01,0x27,0x07,0x26,0x01,0x16,0x07,0x21,0x01,0x06,0x07,0x1c,0x01,0xf6,0x06,0x17,0x01,0xe5,0x06,0x12,0x01,0xd5,0x06,0x0d,0x01,0xc5,0x06,0x08,0x01,0xb4,0x06,0x03,0x01,0xa4,0x06,  \
    0xfe,0x00,0x94,0x06,0xf9,0x00,0x84,0x06,0xf4,0x00,0x74,0x06,0xef,0x00,0x63,0x06,0xeb,0x00,0x53,0x06,0xe6,0x00,0x43,0x06,0xe2,0x00,0x32,0x06,0xdd,0x00,0x21,0x06,0xd9,0x00,0x10,0x06,0xd5,0x00,0xff,0x05,0xd0,0x00,0xee,0x05,0xcc,0x00,0xde,0x05,0xc8,0x00,0xcd,0x05,0xc4,0x00,0xbc,0x05,0xc0,0x00,0xab,0x05,0xbc,0x00,0x9a,0x05,0xb8,0x00,0x8a,0x05,0xb4,0x00,0x79,0x05,0xb0,0x00,0x68,0x05,0xac,0x00,0x58,0x05,0xa8,0x00,0x47,0x05,0xa4,0x00,0x36,0x05,0xa0,0x00,  \
    0x26,0x05,0x9d,0x00,0x15,0x05,0x99,0x00,0x05,0x05,0x95,0x00,0xf4,0x04,0x92,0x00,0xe4,0x04,0x8e,0x00,0xd4,0x04,0x8b,0x00,0xc3,0x04,0x87,0x00,0xb3,0x04,0x83,0x00,0xa3,0x04,0x80,0x00,0x93,0x04,0x7c,0x00,0x84,0x04,0x79,0x00,0x74,0x04,0x75,0x00,0x65,0x04,0x72,0x00,0x55,0x04,0x6f,0x00,0x45,0x04,0x6b,0x00,0x36,0x04,0x68,0x00,0x26,0x04,0x65,0x00,0x17,0x04,0x62,0x00,0x07,0x04,0x5f,0x00,0xf7,0x03,0x5c,0x00,0xe8,0x03,0x59,0x00,0xd8,0x03,0x56,0x00,0xc9,0x03,  \
    0x53,0x00,0xb9,0x03,0x50,0x00,0xaa,0x03,0x4d,0x00,0x9a,0x03,0x4a,0x00,0x8b,0x03,0x47,0x00,0x7b,0x03,0x45,0x00,0x6c,0x03,0x42,0x00,0x5c,0x03,0x3f,0x00,0x4d,0x03,0x3d,0x00,0x3e,0x03,0x3a,0x00,0x2e,0x03,0x38,0x00,0x1f,0x03,0x35,0x00,0x10,0x03,0x33,0x00,0x01,0x03,0x30,0x00,0xf2,0x02,0x2e,0x00,0xe3,0x02,0x2c,0x00,0xd4,0x02,0x29,0x00,0xc5,0x02,0x27,0x00,0xb7,0x02,0x25,0x00,0xa8,0x02,0x23,0x00,0x99,0x02,0x21,0x00,0x8a,0x02,0x1f,0x00,0x7b,0x02,0x1d,0x00,  \
    0x6c,0x02,0x1b,0x00,0x5d,0x02,0x19,0x00,0x4e,0x02,0x17,0x00,0x3f,0x02,0x15,0x00,0x30,0x02,0x13,0x00,0x21,0x02,0x12,0x00,0x12,0x02,0x10,0x00,0x03,0x02,0x0e,0x00,0xf3,0x01,0x0d,0x00,0xe4,0x01,0x0b,0x00,0xd5,0x01,0x0a,0x00,0xc6,0x01,0x08,0x00,0xb7,0x01,0x07,0x00,0xa8,0x01,0x06,0x00,0x99,0x01,0x04,0x00,0x89,0x01,0x03,0x00,0x7a,0x01,0x02,0x00,0x6a,0x01,0x01,0x00,0x5b,0x01,0x00,0x00,0x4b,0x01,0xff,0xff,0x3c,0x01,0xfe,0xff,0x2c,0x01,0xfd,0xff,0x1d,0x01,  \
    0xfc,0xff,0x0d,0x01,0xfb,0xff,0xfd,0x00,0xfa,0xff,0xee,0x00,0xf9,0xff,0xde,0x00,0xf9,0xff,0xcf,0x00,0xf8,0xff,0xbf,0x00,0xf7,0xff,0xb0,0x00,0xf7,0xff,0xa0,0x00,0xf6,0xff,0x91,0x00,0xf6,0xff,0x81,0x00,0xf5,0xff,0x72,0x00,0xf5,0xff,0x62,0x00,0xf4,0xff,0x53,0x00,0xf4,0xff,0x43,0x00,0xf4,0xff,0x34,0x00,0xf3,0xff,0x24,0x00,0xf3,0xff,0x15,0x00,0xf3,0xff,0x05,0x00,0xf3,0xff,0xf5,0xff,0xf3,0xff,0xe6,0xff,0xf2,0xff,0xd6,0xff,0xf2,0xff,0xc7,0xff,0xf2,0xff,  \
    0xb7,0xff,0xf2,0xff,0xa8,0xff,0xf3,0xff,0x98,0xff,0xf3,0xff,0x89,0xff,0xf3,0xff,0x79,0xff,0xf3,0xff,0x6a,0xff,0xf3,0xff,0x5a,0xff,0xf4,0xff,0x4b,0xff,0xf4,0xff,0x3b,0xff,0xf4,0xff,0x2c,0xff,0xf5,0xff,0x1c,0xff,0xf5,0xff,0x0d,0xff,0xf6,0xff,0xfd,0xfe,0xf6,0xff,0xee,0xfe,0xf7,0xff,0xde,0xfe,0xf7,0xff,0xcf,0xfe,0xf8,0xff,0xbf,0xfe,0xf9,0xff,0xb0,0xfe,0xfa,0xff,0xa0,0xfe,0xfa,0xff,0x91,0xfe,0xfb,0xff,0x81,0xfe,0xfc,0xff,0x72,0xfe,0xfd,0xff,0x62,0xfe,  \
    0xfe,0xff,0x53,0xfe,0xff,0xff,0x43,0xfe,0x00,0x00,0x34,0xfe,0x01,0x00,0x24,0xfe,0x02,0x00,0x15,0xfe,0x03,0x00,0x05,0xfe,0x04,0x00,0xf5,0xfd,0x06,0x00,0xe5,0xfd,0x07,0x00,0xd6,0xfd,0x08,0x00,0xc6,0xfd,0x09,0x00,0xb6,0xfd,0x0b,0x00,0xa6,0xfd,0x0c,0x00,0x97,0xfd,0x0e,0x00,0x87,0xfd,0x0f,0x00,0x77,0xfd,0x11,0x00,0x67,0xfd,0x12,0x00,0x57,0xfd,0x14,0x00,0x48,0xfd,0x16,0x00,0x38,0xfd,0x17,0x00,0x28,0xfd,0x19,0x00,0x18,0xfd,0x1b,0x00,0x08,0xfd,0x1d,0x00,  \
    0xf8,0xfc,0x1e,0x00,0xe8,0xfc,0x20,0x00,0xd8,0xfc,0x22,0x00,0xc8,0xfc,0x24,0x00,0xb8,0xfc,0x26,0x00,0xa8,0xfc,0x28,0x00,0x98,0xfc,0x2a,0x00,0x88,0xfc,0x2c,0x00,0x78,0xfc,0x2f,0x00,0x68,0xfc,0x31,0x00,0x59,0xfc,0x33,0x00,0x49,0xfc,0x36,0x00,0x3a,0xfc,0x38,0x00,0x2a,0xfc,0x3a,0x00,0x1a,0xfc,0x3d,0x00,0x0b,0xfc,0x3f,0x00,0xfb,0xfb,0x42,0x00,0xec,0xfb,0x45,0x00,0xdc,0xfb,0x47,0x00,0xcd,0xfb,0x4a,0x00,0xbd,0xfb,0x4d,0x00,0xad,0xfb,0x4f,0x00,0x9e,0xfb,  \
    0x52,0x00,0x8e,0xfb,0x55,0x00,0x7f,0xfb,0x58,0x00,0x6f,0xfb,0x5b,0x00,0x5f,0xfb,0x5e,0x00,0x50,0xfb,0x61,0x00,0x40,0xfb,0x64,0x00,0x31,0xfb,0x67,0x00,0x21,0xfb,0x6b,0x00,0x11,0xfb,0x6e,0x00,0x02,0xfb,0x71,0x00,0xf2,0xfa,0x74,0x00,0xe3,0xfa,0x78,0x00,0xd3,0xfa,0x7b,0x00,0xc3,0xfa,0x7e,0x00,0xb3,0xfa,0x82,0x00,0xa3,0xfa,0x85,0x00,0x93,0xfa,0x89,0x00,0x82,0xfa,0x8c,0x00,0x72,0xfa,0x90,0x00,0x62,0xfa,0x93,0x00,0x52,0xfa,0x97,0x00,0x42,0xfa,0x9b,0x00,  \
    0x31,0xfa,0x9e,0x00,0x21,0xfa,0xa2,0x00,0x11,0xfa,0xa6,0x00,0x00,0xfa,0xaa,0x00,0xf0,0xf9,0xae,0x00,0xe0,0xf9,0xb2,0x00,0xcf,0xf9,0xb6,0x00,0xbf,0xf9,0xba,0x00,0xae,0xf9,0xbe,0x00,0x9e,0xf9,0xc2,0x00,0x8d,0xf9,0xc6,0x00,0x7d,0xf9,0xca,0x00,0x6c,0xf9,0xce,0x00,0x5c,0xf9,0xd2,0x00,0x4b,0xf9,0xd7,0x00,0x3b,0xf9,0xdb,0x00,0x2a,0xf9,0xe0,0x00,0x1a,0xf9,0xe4,0x00,0x0a,0xf9,0xe9,0x00,0xf9,0xf8,0xed,0x00,0xe9,0xf8,0xf2,0x00,0xd8,0xf8,0xf6,0x00,0xc8,0xf8,  \
    0xfb,0x00,0xb7,0xf8,0x00,0x01,0xa7,0xf8,0x05,0x01,0x96,0xf8,0x09,0x01,0x86,0xf8,0x0e,0x01,0x75,0xf8,0x13,0x01,0x65,0xf8,0x18,0x01,0x54,0xf8,0x1d,0x01,0x43,0xf8,0x22,0x01,0x33,0xf8,0x27,0x01,0x22,0xf8,0x2c,0x01,0x11,0xf8,0x31,0x01,0x00,0xf8,0x36,0x01,0xef,0xf7,0x3c,0x01,0xde,0xf7,0x41,0x01,0xce,0xf7,0x46,0x01,0xbd,0xf7,0x4b,0x01,0xab,0xf7,0x51,0x01,0x9a,0xf7,0x56,0x01,0x88,0xf7,0x5b,0x01,0x77,0xf7,0x60,0x01,0x65,0xf7,0x66,0x01,0x54,0xf7,0x6b,0x01,  \
    0x42,0xf7,0x70,0x01,0x30,0xf7,0x76,0x01,0x1f,0xf7,0x7b,0x01,0x0d,0xf7,0x81,0x01,0xfb,0xf6,0x86,0x01,0xe9,0xf6,0x8c,0x01,0xd7,0xf6,0x91,0x01,0xc5,0xf6,0x97,0x01,0xb3,0xf6,0x9d,0x01,0xa1,0xf6,0xa2,0x01,0x8f,0xf6,0xa8,0x01,0x7d,0xf6,0xae,0x01,0x6b,0xf6,0xb4,0x01,0x58,0xf6,0xb9,0x01,0x46,0xf6,0xbf,0x01,0x34,0xf6,0xc5,0x01,0x22,0xf6,0xcb,0x01,0x10,0xf6,0xd1,0x01,0xfd,0xf5,0xd7,0x01,0xeb,0xf5,0xdd,0x01,0xd9,0xf5,0xe3,0x01,0xc6,0xf5,0xe9,0x01,0xb4,0xf5,  \
    0xef,0x01,0xa1,0xf5,0xf6,0x01,0x8f,0xf5,0xfc,0x01,0x7c,0xf5,0x02,0x02,0x69,0xf5,0x08,0x02,0x56,0xf5,0x0e,0x02,0x44,0xf5,0x14,0x02,0x31,0xf5,0x1b,0x02,0x1e,0xf5,0x21,0x02,0x0a,0xf5,0x27,0x02,0xf7,0xf4,0x2d,0x02,0xe4,0xf4,0x34,0x02,0xd1,0xf4,0x3a,0x02,0xbc,0xf4,0x3f,0x02,0xa8,0xf4,0x45,0x02,0x94,0xf4,0x4b,0x02,0x7f,0xf4,0x51,0x02,0x6a,0xf4,0x57,0x02,0x56,0xf4,0x5c,0x02,0x41,0xf4,0x62,0x02,0x2c,0xf4,0x68,0x02,0x17,0xf4,0x6e,0x02,0x02,0xf4,0x74,0x02,  \
    0xed,0xf3,0x7a,0x02,0xd7,0xf3,0x7f,0x02,0xc2,0xf3,0x85,0x02,0xad,0xf3,0x8b,0x02,0x97,0xf3,0x91,0x02,0x82,0xf3,0x96,0x02,0x6c,0xf3,0x9c,0x02,0x56,0xf3,0xa2,0x02,0x41,0xf3,0xa8,0x02,0x2c,0xf3,0xaf,0x02,0x17,0xf3,0xb5,0x02,0x01,0xf3,0xbb,0x02,0xec,0xf2,0xc1,0x02,0xd7,0xf2,0xc7,0x02,0xc1,0xf2,0xcd,0x02,0xab,0xf2,0xd3,0x02,0x96,0xf2,0xd9,0x02,0x80,0xf2,0xdf,0x02,0x6a,0xf2,0xe5,0x02,0x54,0xf2,0xeb,0x02,0x3d,0xf2,0xf1,0x02,0x27,0xf2,0xf7,0x02,0x10,0xf2,  \
    0xfd,0x02,0xfa,0xf1,0x03,0x03,0xe3,0xf1,0x08,0x03,0xcc,0xf1,0x0e,0x03,0xb5,0xf1,0x14,0x03,0x9e,0xf1,0x1a,0x03,0x87,0xf1,0x1f,0x03,0x70,0xf1,0x25,0x03,0x59,0xf1,0x2a,0x03,0x41,0xf1,0x30,0x03,0x2a,0xf1,0x35,0x03,0x12,0xf1,0x3b,0x03,0xfa,0xf0,0x40,0x03,0xe2,0xf0,0x45,0x03,0xca,0xf0,0x4a,0x03,0xb1,0xf0,0x4f,0x03,0x99,0xf0,0x54,0x03,0x80,0xf0,0x59,0x03,0x67,0xf0,0x5e,0x03,0x4e,0xf0,0x63,0x03,0x35,0xf0,0x68,0x03,0x1c,0xf0,0x6c,0x03,0x03,0xf0,0x71,0x03,  \
    0xe9,0xef,0x75,0x03,0xd0,0xef,0x79,0x03,0xb6,0xef,0x7d,0x03,0x9b,0xef,0x81,0x03,0x81,0xef,0x85,0x03,0x66,0xef,0x89,0x03,0x4b,0xef,0x8c,0x03,0x30,0xef,0x90,0x03,0x15,0xef,0x93,0x03,0xf9,0xee,0x96,0x03,0xde,0xee,0x99,0x03,0xc2,0xee,0x9c,0x03,0xa6,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe4,0x03,0x2f,0x11,0xe0,0x03,0x13,0x11,0xdd,0x03,0xf7,0x10,0xda,0x03,0xdb,0x10,0xd6,0x03,0xc0,0x10,0xd2,0x03,0xa5,0x10,0xcf,0x03,0x89,0x10,0xcb,0x03,0x6e,0x10,0xc7,0x03,0x53,0x10,0xc3,0x03,0x39,0x10,0xbf,0x03,0x1e,0x10,0xba,0x03,0x03,0x10,0xb6,0x03,0xe9,0x0f,0xb2,0x03,0xcf,0x0f,0xad,0x03,0xb5,0x0f,0xa9,0x03,0x9b,0x0f,0xa4,0x03,0x81,0x0f,0x9f,0x03,  \
    0x67,0x0f,0x9b,0x03,0x4e,0x0f,0x96,0x03,0x34,0x0f,0x91,0x03,0x1b,0x0f,0x8b,0x03,0x02,0x0f,0x86,0x03,0xe9,0x0e,0x81,0x03,0xd1,0x0e,0x7b,0x03,0xb8,0x0e,0x76,0x03,0xa0,0x0e,0x70,0x03,0x88,0x0e,0x6a,0x03,0x70,0x0e,0x65,0x03,0x58,0x0e,0x5f,0x03,0x40,0x0e,0x59,0x03,0x28,0x0e,0x53,0x03,0x11,0x0e,0x4d,0x03,0xf9,0x0d,0x47,0x03,0xe2,0x0d,0x41,0x03,0xcb,0x0d,0x3b,0x03,0xb4,0x0d,0x35,0x03,0x9d,0x0d,0x2f,0x03,0x86,0x0d,0x29,0x03,0x6f,0x0d,0x23,0x03,0x58,0x0d,  \
    0x1c,0x03,0x42,0x0d,0x16,0x03,0x2c,0x0d,0x0f,0x03,0x17,0x0d,0x08,0x03,0x01,0x0d,0x01,0x03,0xec,0x0c,0xfb,0x02,0xd6,0x0c,0xf4,0x02,0xc1,0x0c,0xed,0x02,0xac,0x0c,0xe6,0x02,0x97,0x0c,0xdf,0x02,0x82,0x0c,0xd8,0x02,0x6d,0x0c,0xd1,0x02,0x59,0x0c,0xcb,0x02,0x44,0x0c,0xc4,0x02,0x30,0x0c,0xbd,0x02,0x1b,0x0c,0xb6,0x02,0x07,0x0c,0xaf,0x02,0xf3,0x0b,0xa8,0x02,0xdf,0x0b,0xa2,0x02,0xc9,0x0b,0x9c,0x02,0xb4,0x0b,0x95,0x02,0x9f,0x0b,0x8f,0x02,0x89,0x0b,0x89,0x02,  \
    0x74,0x0b,0x83,0x02,0x5f,0x0b,0x7d,0x02,0x4a,0x0b,0x77,0x02,0x35,0x0b,0x71,0x02,0x20,0x0b,0x6b,0x02,0x0c,0x0b,0x65,0x02,0xf7,0x0a,0x5e,0x02,0xe2,0x0a,0x58,0x02,0xce,0x0a,0x52,0x02,0xb9,0x0a,0x4c,0x02,0xa5,0x0a,0x46,0x02,0x91,0x0a,0x40,0x02,0x7c,0x0a,0x3a,0x02,0x68,0x0a,0x34,0x02,0x54,0x0a,0x2e,0x02,0x40,0x0a,0x28,0x02,0x2c,0x0a,0x22,0x02,0x18,0x0a,0x1c,0x02,0x04,0x0a,0x16,0x02,0xf0,0x09,0x10,0x02,0xdd,0x09,0x0a,0x02,0xc9,0x09,0x04,0x02,0xb5,0x09,  \
    0xfe,0x01,0xa2,0x09,0xf8,0x01,0x8e,0x09,0xf2,0x01,0x7b,0x09,0xec,0x01,0x67,0x09,0xe7,0x01,0x54,0x09,0xe1,0x01,0x41,0x09,0xdb,0x01,0x2e,0x09,0xd5,0x01,0x1a,0x09,0xcf,0x01,0x08,0x09,0xc9,0x01,0xf6,0x08,0xc2,0x01,0xe5,0x08,0xbc,0x01,0xd3,0x08,0xb6,0x01,0xc2,0x08,0xaf,0x01,0xb1,0x08,0xa9,0x01,0x9f,0x08,0xa3,0x01,0x8e,0x08,0x9d,0x01,0x7d,0x08,0x96,0x01,0x6c,0x08,0x90,0x01,0x5b,0x08,0x8a,0x01,0x4a,0x08,0x84,0x01,0x39,0x08,0x7e,0x01,0x28,0x08,0x78,0x01,  \
    0x17,0x08,0x72,0x01,0x07,0x08,0x6c,0x01,0xf6,0x07,0x66,0x01,0xe5,0x07,0x61,0x01,0xd5,0x07,0x5b,0x01,0xc4,0x07,0x55,0x01,0xb3,0x07,0x4f,0x01,0xa3,0x07,0x4a,0x01,0x92,0x07,0x44,0x01,0x81,0x07,0x3f,0x01,0x71,0x07,0x39,0x01,0x60,0x07,0x34,0x01,0x50,0x07,0x2f,0x01,0x3f,0x07,0x29,0x01,0x2f,0x07,0x24,0x01,0x1e,0x07,0x1f,0x01,0x0e,0x07,0x19,0x01,0xfd,0x06,0x14,0x01,0xed,0x06,0x0f,0x01,0xdd,0x06,0x0a,0x01,0xcc,0x06,0x05,0x01,0xbc,0x06,0x00,0x01,0xac,0x06,  \
    0xfb,0x00,0x9c,0x06,0xf6,0x00,0x8b,0x06,0xf1,0x00,0x7b,0x06,0xec,0x00,0x6b,0x06,0xe8,0x00,0x5b,0x06,0xe3,0x00,0x4b,0x06,0xde,0x00,0x3b,0x06,0xda,0x00,0x2a,0x06,0xd6,0x00,0x19,0x06,0xd1,0x00,0x08,0x06,0xcd,0x00,0xf7,0x05,0xc9,0x00,0xe6,0x05,0xc5,0x00,0xd6,0x05,0xc0,0x00,0xc5,0x05,0xbc,0x00,0xb4,0x05,0xb8,0x00,0xa3,0x05,0xb4,0x00,0x93,0x05,0xb0,0x00,0x82,0x05,0xac,0x00,0x71,0x05,0xa8,0x00,0x61,0x05,0xa4,0x00,0x50,0x05,0xa1,0x00,0x40,0x05,0x9d,0x00,  \
    0x2f,0x05,0x99,0x00,0x1f,0x05,0x95,0x00,0x0e,0x05,0x91,0x00,0xfe,0x04,0x8e,0x00,0xed,0x04,0x8a,0x00,0xdd,0x04,0x87,0x00,0xcd,0x04,0x83,0x00,0xbc,0x04,0x7f,0x00,0xac,0x04,0x7c,0x00,0x9c,0x04,0x78,0x00,0x8d,0x04,0x75,0x00,0x7d,0x04,0x71,0x00,0x6e,0x04,0x6e,0x00,0x5e,0x04,0x6a,0x00,0x4f,0x04,0x67,0x00,0x3f,0x04,0x64,0x00,0x2f,0x04,0x61,0x00,0x20,0x04,0x5d,0x00,0x10,0x04,0x5a,0x00,0x01,0x04,0x57,0x00,0xf1,0x03,0x54,0x00,0xe2,0x03,0x51,0x00,0xd2,0x03,  \
    0x4e,0x00,0xc3,0x03,0x4b,0x00,0xb4,0x03,0x48,0x00,0xa4,0x03,0x45,0x00,0x95,0x03,0x43,0x00,0x85,0x03,0x40,0x00,0x76,0x03,0x3d,0x00,0x67,0x03,0x3a,0x00,0x57,0x03,0x38,0x00,0x48,0x03,0x35,0x00,0x38,0x03,0x33,0x00,0x29,0x03,0x30,0x00,0x1a,0x03,0x2e,0x00,0x0b,0x03,0x2b,0x00,0xfc,0x02,0x29,0x00,0xed,0x02,0x26,0x00,0xdf,0x02,0x24,0x00,0xd0,0x02,0x22,0x00,0xc1,0x02,0x1f,0x00,0xb2,0x02,0x1d,0x00,0xa3,0x02,0x1b,0x00,0x94,0x02,0x19,0x00,0x85,0x02,0x17,0x00,  \
    0x77,0x02,0x15,0x00,0x68,0x02,0x13,0x00,0x59,0x02,0x11,0x00,0x4a,0x02,0x0f,0x00,0x3b,0x02,0x0e,0x00,0x2c,0x02,0x0c,0x00,0x1d,0x02,0x0a,0x00,0x0e,0x02,0x08,0x00,0xff,0x01,0x07,0x00,0xf0,0x01,0x05,0x00,0xe1,0x01,0x04,0x00,0xd2,0x01,0x02,0x00,0xc3,0x01,0x01,0x00,0xb4,0x01,0x00,0x00,0xa5,0x01,0xfe,0xff,0x96,0x01,0xfd,0xff,0x86,0x01,0xfc,0xff,0x77,0x01,0xfb,0xff,0x68,0x01,0xf9,0xff,0x58,0x01,0xf8,0xff,0x49,0x01,0xf7,0xff,0x39,0x01,0xf6,0xff,0x2a,0x01,  \
    0xf5,0xff,0x1a,0x01,0xf4,0xff,0x0b,0x01,0xf4,0xff,0xfb,0x00,0xf3,0xff,0xec,0x00,0xf2,0xff,0xdd,0x00,0xf1,0xff,0xcd,0x00,0xf0,0xff,0xbe,0x00,0xf0,0xff,0xae,0x00,0xef,0xff,0x9f,0x00,0xef,0xff,0x8f,0x00,0xee,0xff,0x80,0x00,0xee,0xff,0x71,0x00,0xed,0xff,0x61,0x00,0xed,0xff,0x52,0x00,0xec,0xff,0x42,0x00,0xec,0xff,0x33,0x00,0xec,0xff,0x23,0x00,0xeb,0xff,0x14,0x00,0xeb,0xff,0x05,0x00,0xeb,0xff,0xf5,0xff,0xeb,0xff,0xe6,0xff,0xeb,0xff,0xd6,0xff,0xeb,0xff,  \
    0xc7,0xff,0xeb,0xff,0xb8,0xff,0xeb,0xff,0xa8,0xff,0xeb,0xff,0x99,0xff,0xeb,0xff,0x89,0xff,0xeb,0xff,0x7a,0xff,0xec,0xff,0x6a,0xff,0xec,0xff,0x5b,0xff,0xec,0xff,0x4c,0xff,0xec,0xff,0x3c,0xff,0xed,0xff,0x2d,0xff,0xed,0xff,0x1d,0xff,0xee,0xff,0x0e,0xff,0xee,0xff,0xff,0xfe,0xef,0xff,0xef,0xfe,0xef,0xff,0xe0,0xfe,0xf0,0xff,0xd0,0xfe,0xf1,0xff,0xc1,0xfe,0xf1,0xff,0xb2,0xfe,0xf2,0xff,0xa2,0xfe,0xf3,0xff,0x93,0xfe,0xf4,0xff,0x83,0xfe,0xf4,0xff,0x74,0xfe,  \
    0xf5,0xff,0x64,0xfe,0xf6,0xff,0x55,0xfe,0xf7,0xff,0x46,0xfe,0xf8,0xff,0x36,0xfe,0xf9,0xff,0x27,0xfe,0xfb,0xff,0x17,0xfe,0xfc,0xff,0x08,0xfe,0xfd,0xff,0xf8,0xfd,0xfe,0xff,0xe8,0xfd,0xff,0xff,0xd9,0xfd,0x01,0x00,0xc9,0xfd,0x02,0x00,0xba,0xfd,0x03,0x00,0xaa,0xfd,0x05,0x00,0x9a,0xfd,0x06,0x00,0x8a,0xfd,0x08,0x00,0x7b,0xfd,0x09,0x00,0x6b,0xfd,0x0b,0x00,0x5b,0xfd,0x0c,0x00,0x4c,0xfd,0x0e,0x00,0x3c,0xfd,0x10,0x00,0x2c,0xfd,0x12,0x00,0x1c,0xfd,0x13,0x00,  \
    0x0c,0xfd,0x15,0x00,0xfd,0xfc,0x17,0x00,0xed,0xfc,0x19,0x00,0xdd,0xfc,0x1b,0x00,0xcd,0xfc,0x1d,0x00,0xbd,0xfc,0x1f,0x00,0xad,0xfc,0x21,0x00,0x9d,0xfc,0x23,0x00,0x8e,0xfc,0x25,0x00,0x7e,0xfc,0x27,0x00,0x6e,0xfc,0x29,0x00,0x5e,0xfc,0x2c,0x00,0x4f,0xfc,0x2e,0x00,0x3f,0xfc,0x31,0x00,0x30,0xfc,0x33,0x00,0x20,0xfc,0x35,0x00,0x11,0xfc,0x38,0x00,0x01,0xfc,0x3b,0x00,0xf2,0xfb,0x3d,0x00,0xe2,0xfb,0x40,0x00,0xd3,0xfb,0x43,0x00,0xc3,0xfb,0x45,0x00,0xb4,0xfb,  \
    0x48,0x00,0xa4,0xfb,0x4b,0x00,0x95,0xfb,0x4e,0x00,0x85,0xfb,0x51,0x00,0x76,0xfb,0x54,0x00,0x66,0xfb,0x57,0x00,0x57,0xfb,0x5a,0x00,0x47,0xfb,0x5d,0x00,0x38,0xfb,0x60,0x00,0x28,0xfb,0x63,0x00,0x19,0xfb,0x67,0x00,0x09,0xfb,0x6a,0x00,0xfa,0xfa,0x6d,0x00,0xea,0xfa,0x71,0x00,0xda,0xfa,0x74,0x00,0xcb,0xfa,0x77,0x00,0xbb,0xfa,0x7b,0x00,0xaa,0xfa,0x7e,0x00,0x9a,0xfa,0x82,0x00,0x8a,0xfa,0x85,0x00,0x7a,0xfa,0x89,0x00,0x6a,0xfa,0x8c,0x00,0x5a,0xfa,0x90,0x00,  \
    0x4a,0xfa,0x94,0x00,0x39,0xfa,0x97,0x00,0x29,0xfa,0x9b,0x00,0x19,0xfa,0x9f,0x00,0x09,0xfa,0xa3,0x00,0xf8,0xf9,0xa7,0x00,0xe8,0xf9,0xab,0x00,0xd8,0xf9,0xaf,0x00,0xc7,0xf9,0xb3,0x00,0xb7,0xf9,0xb7,0x00,0xa7,0xf9,0xbb,0x00,0x96,0xf9,0xbf,0x00,0x86,0xf9,0xc3,0x00,0x75,0xf9,0xc7,0x00,0x65,0xf9,0xcb,0x00,0x54,0xf9,0xd0,0x00,0x44,0xf9,0xd4,0x00,0x34,0xf9,0xd9,0x00,0x23,0xf9,0xdd,0x00,0x13,0xf9,0xe2,0x00,0x03,0xf9,0xe6,0x00,0xf2,0xf8,0xeb,0x00,0xe2,0xf8,  \
    0xef,0x00,0xd1,0xf8,0xf4,0x00,0xc1,0xf8,0xf9,0x00,0xb1,0xf8,0xfe,0x00,0xa0,0xf8,0x02,0x01,0x8f,0xf8,0x07,0x01,0x7f,0xf8,0x0c,0x01,0x6e,0xf8,0x11,0x01,0x5e,0xf8,0x16,0x01,0x4d,0xf8,0x1b,0x01,0x3c,0xf8,0x20,0x01,0x2c,0xf8,0x25,0x01,0x1b,0xf8,0x2a,0x01,0x0a,0xf8,0x2f,0x01,0xf9,0xf7,0x35,0x01,0xe8,0xf7,0x3a,0x01,0xd8,0xf7,0x3f,0x01,0xc7,0xf7,0x44,0x01,0xb5,0xf7,0x4a,0x01,0xa4,0xf7,0x4f,0x01,0x93,0xf7,0x54,0x01,0x81,0xf7,0x59,0x01,0x70,0xf7,0x5f,0x01,  \
    0x5e,0xf7,0x64,0x01,0x4c,0xf7,0x69,0x01,0x3b,0xf7,0x6f,0x01,0x29,0xf7,0x74,0x01,0x17,0xf7,0x7a,0x01,0x05,0xf7,0x7f,0x01,0xf4,0xf6,0x85,0x01,0xe2,0xf6,0x8a,0x01,0xd0,0xf6,0x90,0x01,0xbe,0xf6,0x96,0x01,0xac,0xf6,0x9b,0x01,0x9a,0xf6,0xa1,0x01,0x88,0xf6,0xa7,0x01,0x75,0xf6,0xac,0x01,0x63,0xf6,0xb2,0x01,0x51,0xf6,0xb8,0x01,0x3f,0xf6,0xbe,0x01,0x2d,0xf6,0xc4,0x01,0x1a,0xf6,0xca,0x01,0x08,0xf6,0xd0,0x01,0xf6,0xf5,0xd6,0x01,0xe4,0xf5,0xdc,0x01,0xd1,0xf5,  \
    0xe2,0x01,0xbf,0xf5,0xe8,0x01,0xac,0xf5,0xee,0x01,0x99,0xf5,0xf4,0x01,0x87,0xf5,0xfb,0x01,0x74,0xf5,0x01,0x02,0x61,0xf5,0x07,0x02,0x4e,0xf5,0x0d,0x02,0x3b,0xf5,0x13,0x02,0x28,0xf5,0x1a,0x02,0x15,0xf5,0x20,0x02,0x02,0xf5,0x26,0x02,0xef,0xf4,0x2c,0x02,0xdc,0xf4,0x32,0x02,0xc7,0xf4,0x38,0x02,0xb3,0xf4,0x3e,0x02,0x9e,0xf4,0x44,0x02,0x8a,0xf4,0x49,0x02,0x75,0xf4,0x4f,0x02,0x60,0xf4,0x55,0x02,0x4c,0xf4,0x5b,0x02,0x37,0xf4,0x61,0x02,0x22,0xf4,0x67,0x02,  \
    0x0d,0xf4,0x6c,0x02,0xf8,0xf3,0x72,0x02,0xe2,0xf3,0x78,0x02,0xcd,0xf3,0x7e,0x02,0xb8,0xf3,0x84,0x02,0xa2,0xf3,0x89,0x02,0x8d,0xf3,0x8f,0x02,0x77,0xf3,0x95,0x02,0x61,0xf3,0x9b,0x02,0x4c,0xf3,0xa1,0x02,0x37,0xf3,0xa7,0x02,0x22,0xf3,0xad,0x02,0x0c,0xf3,0xb3,0x02,0xf7,0xf2,0xb9,0x02,0xe2,0xf2,0xc0,0x02,0xcc,0xf2,0xc6,0x02,0xb6,0xf2,0xcc,0x02,0xa0,0xf2,0xd2,0x02,0x8b,0xf2,0xd8,0x02,0x74,0xf2,0xde,0x02,0x5e,0xf2,0xe4,0x02,0x48,0xf2,0xe9,0x02,0x32,0xf2,  \
    0xef,0x02,0x1b,0xf2,0xf5,0x02,0x04,0xf2,0xfb,0x02,0xee,0xf1,0x01,0x03,0xd7,0xf1,0x06,0x03,0xc0,0xf1,0x0c,0x03,0xa9,0xf1,0x12,0x03,0x92,0xf1,0x17,0x03,0x7a,0xf1,0x1d,0x03,0x63,0xf1,0x22,0x03,0x4c,0xf1,0x28,0x03,0x34,0xf1,0x2d,0x03,0x1c,0xf1,0x32,0x03,0x04,0xf1,0x38,0x03,0xec,0xf0,0x3d,0x03,0xd4,0xf0,0x42,0x03,0xbb,0xf0,0x47,0x03,0xa3,0xf0,0x4c,0x03,0x8a,0xf0,0x51,0x03,0x71,0xf0,0x56,0x03,0x59,0xf0,0x5b,0x03,0x3f,0xf0,0x5f,0x03,0x26,0xf0,0x64,0x03,  \
    0x0d,0xf0,0x68,0x03,0xf3,0xef,0x6d,0x03,0xd9,0xef,0x71,0x03,0xbf,0xef,0x75,0x03,0xa5,0xef,0x79,0x03,0x8a,0xef,0x7c,0x03,0x70,0xef,0x80,0x03,0x55,0xef,0x83,0x03,0x3a,0xef,0x87,0x03,0x1e,0xef,0x8a,0x03,0x03,0xef,0x8d,0x03,0xe7,0xee,0x91,0x03,0xcc,0xee,0x94,0x03,0xb0,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xd7,0x03,0x28,0x11,0xd4,0x03,0x0c,0x11,0xd1,0x03,0xf0,0x10,0xcd,0x03,0xd4,0x10,0xca,0x03,0xb9,0x10,0xc6,0x03,0x9d,0x10,0xc2,0x03,0x82,0x10,0xbf,0x03,0x67,0x10,0xbb,0x03,0x4c,0x10,0xb7,0x03,0x31,0x10,0xb3,0x03,0x17,0x10,0xae,0x03,0xfc,0x0f,0xaa,0x03,0xe2,0x0f,0xa6,0x03,0xc7,0x0f,0xa1,0x03,0xad,0x0f,0x9d,0x03,0x93,0x0f,0x98,0x03,  \
    0x79,0x0f,0x94,0x03,0x60,0x0f,0x8f,0x03,0x46,0x0f,0x8a,0x03,0x2d,0x0f,0x85,0x03,0x13,0x0f,0x80,0x03,0xfa,0x0e,0x7b,0x03,0xe2,0x0e,0x75,0x03,0xc9,0x0e,0x70,0x03,0xb1,0x0e,0x6a,0x03,0x98,0x0e,0x65,0x03,0x80,0x0e,0x5f,0x03,0x68,0x0e,0x5a,0x03,0x50,0x0e,0x54,0x03,0x38,0x0e,0x4e,0x03,0x20,0x0e,0x48,0x03,0x09,0x0e,0x42,0x03,0xf1,0x0d,0x3d,0x03,0xda,0x0d,0x37,0x03,0xc3,0x0d,0x31,0x03,0xab,0x0d,0x2b,0x03,0x94,0x0d,0x24,0x03,0x7e,0x0d,0x1e,0x03,0x67,0x0d,  \
    0x18,0x03,0x50,0x0d,0x12,0x03,0x3a,0x0d,0x0b,0x03,0x24,0x0d,0x05,0x03,0x0e,0x0d,0xfe,0x02,0xf9,0x0c,0xf7,0x02,0xe3,0x0c,0xf1,0x02,0xce,0x0c,0xea,0x02,0xb8,0x0c,0xe3,0x02,0xa3,0x0c,0xdc,0x02,0x8e,0x0c,0xd5,0x02,0x79,0x0c,0xcf,0x02,0x64,0x0c,0xc8,0x02,0x50,0x0c,0xc1,0x02,0x3b,0x0c,0xba,0x02,0x27,0x0c,0xb3,0x02,0x12,0x0c,0xac,0x02,0xfe,0x0b,0xa5,0x02,0xea,0x0b,0x9e,0x02,0xd6,0x0b,0x98,0x02,0xc0,0x0b,0x92,0x02,0xab,0x0b,0x8c,0x02,0x95,0x0b,0x86,0x02,  \
    0x80,0x0b,0x80,0x02,0x6b,0x0b,0x7a,0x02,0x56,0x0b,0x74,0x02,0x41,0x0b,0x6e,0x02,0x2c,0x0b,0x68,0x02,0x17,0x0b,0x62,0x02,0x02,0x0b,0x5c,0x02,0xee,0x0a,0x55,0x02,0xd9,0x0a,0x4f,0x02,0xc5,0x0a,0x49,0x02,0xb0,0x0a,0x43,0x02,0x9c,0x0a,0x3d,0x02,0x87,0x0a,0x37,0x02,0x73,0x0a,0x31,0x02,0x5f,0x0a,0x2b,0x02,0x4b,0x0a,0x25,0x02,0x37,0x0a,0x1f,0x02,0x23,0x0a,0x19,0x02,0x0f,0x0a,0x13,0x02,0xfb,0x09,0x0d,0x02,0xe7,0x09,0x07,0x02,0xd3,0x09,0x01,0x02,0xc0,0x09,  \
    0xfb,0x01,0xac,0x09,0xf5,0x01,0x99,0x09,0xf0,0x01,0x85,0x09,0xea,0x01,0x72,0x09,0xe4,0x01,0x5e,0x09,0xde,0x01,0x4b,0x09,0xd8,0x01,0x38,0x09,0xd2,0x01,0x25,0x09,0xcd,0x01,0x12,0x09,0xc7,0x01,0xff,0x08,0xc0,0x01,0xed,0x08,0xba,0x01,0xdc,0x08,0xb4,0x01,0xca,0x08,0xad,0x01,0xb9,0x08,0xa7,0x01,0xa8,0x08,0xa1,0x01,0x96,0x08,0x9b,0x01,0x85,0x08,0x94,0x01,0x74,0x08,0x8e,0x01,0x63,0x08,0x88,0x01,0x52,0x08,0x82,0x01,0x41,0x08,0x7c,0x01,0x30,0x08,0x76,0x01,  \
    0x1f,0x08,0x70,0x01,0x0e,0x08,0x6a,0x01,0xfe,0x07,0x64,0x01,0xed,0x07,0x5f,0x01,0xdc,0x07,0x59,0x01,0xcc,0x07,0x53,0x01,0xbb,0x07,0x4d,0x01,0xab,0x07,0x48,0x01,0x9a,0x07,0x42,0x01,0x89,0x07,0x3d,0x01,0x78,0x07,0x37,0x01,0x68,0x07,0x32,0x01,0x57,0x07,0x2c,0x01,0x47,0x07,0x27,0x01,0x36,0x07,0x22,0x01,0x26,0x07,0x1c,0x01,0x15,0x07,0x17,0x01,0x05,0x07,0x12,0x01,0xf5,0x06,0x0d,0x01,0xe4,0x06,0x08,0x01,0xd4,0x06,0x03,0x01,0xc4,0x06,0xfe,0x00,0xb3,0x06,  \
    0xf9,0x00,0xa3,0x06,0xf4,0x00,0x93,0x06,0xef,0x00,0x83,0x06,0xea,0x00,0x73,0x06,0xe5,0x00,0x63,0x06,0xe0,0x00,0x53,0x06,0xdc,0x00,0x43,0x06,0xd7,0x00,0x32,0x06,0xd3,0x00,0x22,0x06,0xce,0x00,0x11,0x06,0xca,0x00,0x00,0x06,0xc6,0x00,0xef,0x05,0xc1,0x00,0xde,0x05,0xbd,0x00,0xce,0x05,0xb9,0x00,0xbd,0x05,0xb5,0x00,0xac,0x05,0xb1,0x00,0x9c,0x05,0xad,0x00,0x8b,0x05,0xa9,0x00,0x7a,0x05,0xa5,0x00,0x6a,0x05,0xa1,0x00,0x59,0x05,0x9d,0x00,0x49,0x05,0x99,0x00,  \
    0x38,0x05,0x95,0x00,0x28,0x05,0x92,0x00,0x17,0x05,0x8e,0x00,0x07,0x05,0x8a,0x00,0xf7,0x04,0x86,0x00,0xe6,0x04,0x83,0x00,0xd6,0x04,0x7f,0x00,0xc6,0x04,0x7c,0x00,0xb6,0x04,0x78,0x00,0xa5,0x04,0x75,0x00,0x96,0x04,0x71,0x00,0x86,0x04,0x6d,0x00,0x77,0x04,0x6a,0x00,0x67,0x04,0x67,0x00,0x58,0x04,0x63,0x00,0x48,0x04,0x60,0x00,0x39,0x04,0x5d,0x00,0x29,0x04,0x59,0x00,0x1a,0x04,0x56,0x00,0x0a,0x04,0x53,0x00,0xfb,0x03,0x50,0x00,0xeb,0x03,0x4d,0x00,0xdc,0x03,  \
    0x4a,0x00,0xcd,0x03,0x47,0x00,0xbd,0x03,0x44,0x00,0xae,0x03,0x41,0x00,0x9f,0x03,0x3e,0x00,0x8f,0x03,0x3b,0x00,0x80,0x03,0x39,0x00,0x71,0x03,0x36,0x00,0x61,0x03,0x33,0x00,0x52,0x03,0x30,0x00,0x43,0x03,0x2e,0x00,0x33,0x03,0x2b,0x00,0x24,0x03,0x29,0x00,0x15,0x03,0x26,0x00,0x06,0x03,0x24,0x00,0xf7,0x02,0x21,0x00,0xe9,0x02,0x1f,0x00,0xda,0x02,0x1d,0x00,0xcb,0x02,0x1a,0x00,0xbc,0x02,0x18,0x00,0xae,0x02,0x16,0x00,0x9f,0x02,0x14,0x00,0x90,0x02,0x12,0x00,  \
    0x81,0x02,0x10,0x00,0x72,0x02,0x0e,0x00,0x64,0x02,0x0c,0x00,0x55,0x02,0x0a,0x00,0x46,0x02,0x08,0x00,0x37,0x02,0x06,0x00,0x28,0x02,0x05,0x00,0x19,0x02,0x03,0x00,0x0a,0x02,0x01,0x00,0xfb,0x01,0x00,0x00,0xed,0x01,0xfe,0xff,0xde,0x01,0xfd,0xff,0xcf,0x01,0xfb,0xff,0xc0,0x01,0xfa,0xff,0xb1,0x01,0xf8,0xff,0xa2,0x01,0xf7,0xff,0x93,0x01,0xf6,0xff,0x84,0x01,0xf4,0xff,0x74,0x01,0xf3,0xff,0x65,0x01,0xf2,0xff,0x56,0x01,0xf1,0xff,0x46,0x01,0xf0,0xff,0x37,0x01,  \
    0xef,0xff,0x27,0x01,0xee,0xff,0x18,0x01,0xed,0xff,0x09,0x01,0xec,0xff,0xf9,0x00,0xeb,0xff,0xea,0x00,0xeb,0xff,0xdb,0x00,0xea,0xff,0xcb,0x00,0xe9,0xff,0xbc,0x00,0xe9,0xff,0xad,0x00,0xe8,0xff,0x9d,0x00,0xe7,0xff,0x8e,0x00,0xe7,0xff,0x7f,0x00,0xe6,0xff,0x6f,0x00,0xe6,0xff,0x60,0x00,0xe5,0xff,0x51,0x00,0xe5,0xff,0x41,0x00,0xe5,0xff,0x32,0x00,0xe4,0xff,0x23,0x00,0xe4,0xff,0x13,0x00,0xe4,0xff,0x04,0x00,0xe4,0xff,0xf5,0xff,0xe4,0xff,0xe6,0xff,0xe4,0xff,  \
    0xd6,0xff,0xe4,0xff,0xc7,0xff,0xe4,0xff,0xb8,0xff,0xe4,0xff,0xa8,0xff,0xe4,0xff,0x99,0xff,0xe4,0xff,0x8a,0xff,0xe4,0xff,0x7a,0xff,0xe4,0xff,0x6b,0xff,0xe4,0xff,0x5c,0xff,0xe5,0xff,0x4c,0xff,0xe5,0xff,0x3d,0xff,0xe5,0xff,0x2e,0xff,0xe6,0xff,0x1e,0xff,0xe6,0xff,0x0f,0xff,0xe7,0xff,0x00,0xff,0xe7,0xff,0xf1,0xfe,0xe8,0xff,0xe1,0xfe,0xe9,0xff,0xd2,0xfe,0xe9,0xff,0xc3,0xfe,0xea,0xff,0xb3,0xfe,0xeb,0xff,0xa4,0xfe,0xec,0xff,0x95,0xfe,0xec,0xff,0x85,0xfe,  \
    0xed,0xff,0x76,0xfe,0xee,0xff,0x67,0xfe,0xef,0xff,0x57,0xfe,0xf0,0xff,0x48,0xfe,0xf1,0xff,0x39,0xfe,0xf2,0xff,0x29,0xfe,0xf3,0xff,0x1a,0xfe,0xf4,0xff,0x0a,0xfe,0xf6,0xff,0xfb,0xfd,0xf7,0xff,0xeb,0xfd,0xf8,0xff,0xdc,0xfd,0xf9,0xff,0xcc,0xfd,0xfb,0xff,0xbd,0xfd,0xfc,0xff,0xad,0xfd,0xfe,0xff,0x9e,0xfd,0xff,0xff,0x8e,0xfd,0x01,0x00,0x7f,0xfd,0x02,0x00,0x6f,0xfd,0x04,0x00,0x5f,0xfd,0x05,0x00,0x50,0xfd,0x07,0x00,0x40,0xfd,0x09,0x00,0x30,0xfd,0x0a,0x00,  \
    0x21,0xfd,0x0c,0x00,0x11,0xfd,0x0e,0x00,0x01,0xfd,0x10,0x00,0xf1,0xfc,0x12,0x00,0xe2,0xfc,0x14,0x00,0xd2,0xfc,0x16,0x00,0xc2,0xfc,0x18,0x00,0xb2,0xfc,0x1a,0x00,0xa3,0xfc,0x1c,0x00,0x93,0xfc,0x1e,0x00,0x83,0xfc,0x20,0x00,0x73,0xfc,0x22,0x00,0x64,0xfc,0x25,0x00,0x54,0xfc,0x27,0x00,0x45,0xfc,0x2a,0x00,0x35,0xfc,0x2c,0x00,0x26,0xfc,0x2e,0x00,0x17,0xfc,0x31,0x00,0x07,0xfc,0x34,0x00,0xf8,0xfb,0x36,0x00,0xe8,0xfb,0x39,0x00,0xd9,0xfb,0x3c,0x00,0xca,0xfb,  \
    0x3e,0x00,0xba,0xfb,0x41,0x00,0xab,0xfb,0x44,0x00,0x9b,0xfb,0x47,0x00,0x8c,0xfb,0x4a,0x00,0x7d,0xfb,0x4d,0x00,0x6d,0xfb,0x50,0x00,0x5e,0xfb,0x53,0x00,0x4e,0xfb,0x56,0x00,0x3f,0xfb,0x59,0x00,0x2f,0xfb,0x5c,0x00,0x20,0xfb,0x60,0x00,0x10,0xfb,0x63,0x00,0x01,0xfb,0x66,0x00,0xf1,0xfa,0x6a,0x00,0xe2,0xfa,0x6d,0x00,0xd2,0xfa,0x70,0x00,0xc2,0xfa,0x74,0x00,0xb2,0xfa,0x77,0x00,0xa2,0xfa,0x7b,0x00,0x92,0xfa,0x7e,0x00,0x82,0xfa,0x82,0x00,0x72,0xfa,0x85,0x00,  \
    0x62,0xfa,0x89,0x00,0x52,0xfa,0x8d,0x00,0x42,0xfa,0x90,0x00,0x31,0xfa,0x94,0x00,0x21,0xfa,0x98,0x00,0x11,0xfa,0x9c,0x00,0x01,0xfa,0xa0,0x00,0xf1,0xf9,0xa4,0x00,0xe0,0xf9,0xa8,0x00,0xd0,0xf9,0xac,0x00,0xc0,0xf9,0xb0,0x00,0xaf,0xf9,0xb4,0x00,0x9f,0xf9,0xb8,0x00,0x8f,0xf9,0xbc,0x00,0x7e,0xf9,0xc0,0x00,0x6e,0xf9,0xc5,0x00,0x5d,0xf9,0xc9,0x00,0x4d,0xf9,0xcd,0x00,0x3d,0xf9,0xd2,0x00,0x2c,0xf9,0xd6,0x00,0x1c,0xf9,0xdb,0x00,0x0c,0xf9,0xdf,0x00,0xfc,0xf8,  \
    0xe4,0x00,0xeb,0xf8,0xe9,0x00,0xdb,0xf8,0xed,0x00,0xca,0xf8,0xf2,0x00,0xba,0xf8,0xf7,0x00,0xaa,0xf8,0xfc,0x00,0x99,0xf8,0x00,0x01,0x89,0xf8,0x05,0x01,0x78,0xf8,0x0a,0x01,0x67,0xf8,0x0f,0x01,0x57,0xf8,0x14,0x01,0x46,0xf8,0x19,0x01,0x36,0xf8,0x1e,0x01,0x25,0xf8,0x23,0x01,0x14,0xf8,0x29,0x01,0x03,0xf8,0x2e,0x01,0xf2,0xf7,0x33,0x01,0xe2,0xf7,0x38,0x01,0xd1,0xf7,0x3e,0x01,0xbf,0xf7,0x43,0x01,0xae,0xf7,0x48,0x01,0x9d,0xf7,0x4d,0x01,0x8b,0xf7,0x53,0x01,  \
    0x7a,0xf7,0x58,0x01,0x68,0xf7,0x5d,0x01,0x57,0xf7,0x63,0x01,0x45,0xf7,0x68,0x01,0x33,0xf7,0x6d,0x01,0x22,0xf7,0x73,0x01,0x10,0xf7,0x78,0x01,0xfe,0xf6,0x7e,0x01,0xec,0xf6,0x84,0x01,0xda,0xf6,0x89,0x01,0xc8,0xf6,0x8f,0x01,0xb6,0xf6,0x94,0x01,0xa4,0xf6,0x9a,0x01,0x92,0xf6,0xa0,0x01,0x80,0xf6,0xa6,0x01,0x6e,0xf6,0xab,0x01,0x5c,0xf6,0xb1,0x01,0x49,0xf6,0xb7,0x01,0x37,0xf6,0xbd,0x01,0x25,0xf6,0xc3,0x01,0x13,0xf6,0xc9,0x01,0x01,0xf6,0xcf,0x01,0xee,0xf5,  \
    0xd5,0x01,0xdc,0xf5,0xdb,0x01,0xc9,0xf5,0xe1,0x01,0xb7,0xf5,0xe7,0x01,0xa4,0xf5,0xed,0x01,0x91,0xf5,0xf4,0x01,0x7f,0xf5,0xfa,0x01,0x6c,0xf5,0x00,0x02,0x59,0xf5,0x06,0x02,0x46,0xf5,0x0c,0x02,0x33,0xf5,0x12,0x02,0x20,0xf5,0x19,0x02,0x0d,0xf5,0x1f,0x02,0xf9,0xf4,0x25,0x02,0xe6,0xf4,0x2b,0x02,0xd2,0xf4,0x31,0x02,0xbe,0xf4,0x37,0x02,0xa9,0xf4,0x3c,0x02,0x95,0xf4,0x42,0x02,0x80,0xf4,0x48,0x02,0x6b,0xf4,0x4e,0x02,0x56,0xf4,0x54,0x02,0x42,0xf4,0x59,0x02,  \
    0x2d,0xf4,0x5f,0x02,0x18,0xf4,0x65,0x02,0x02,0xf4,0x6b,0x02,0xed,0xf3,0x71,0x02,0xd8,0xf3,0x76,0x02,0xc3,0xf3,0x7c,0x02,0xad,0xf3,0x82,0x02,0x98,0xf3,0x88,0x02,0x82,0xf3,0x8d,0x02,0x6c,0xf3,0x93,0x02,0x57,0xf3,0x99,0x02,0x42,0xf3,0xa0,0x02,0x2c,0xf3,0xa6,0x02,0x17,0xf3,0xac,0x02,0x02,0xf3,0xb2,0x02,0xec,0xf2,0xb8,0x02,0xd7,0xf2,0xbe,0x02,0xc1,0xf2,0xc4,0x02,0xab,0xf2,0xca,0x02,0x95,0xf2,0xd0,0x02,0x7f,0xf2,0xd6,0x02,0x69,0xf2,0xdc,0x02,0x53,0xf2,  \
    0xe2,0x02,0x3c,0xf2,0xe7,0x02,0x26,0xf2,0xed,0x02,0x0f,0xf2,0xf3,0x02,0xf8,0xf1,0xf9,0x02,0xe1,0xf1,0xfe,0x02,0xca,0xf1,0x04,0x03,0xb3,0xf1,0x0a,0x03,0x9c,0xf1,0x0f,0x03,0x85,0xf1,0x15,0x03,0x6d,0xf1,0x1a,0x03,0x56,0xf1,0x20,0x03,0x3e,0xf1,0x25,0x03,0x26,0xf1,0x2a,0x03,0x0e,0xf1,0x2f,0x03,0xf6,0xf0,0x35,0x03,0xde,0xf0,0x3a,0x03,0xc5,0xf0,0x3f,0x03,0xad,0xf0,0x44,0x03,0x94,0xf0,0x49,0x03,0x7b,0xf0,0x4d,0x03,0x62,0xf0,0x52,0x03,0x49,0xf0,0x57,0x03,  \
    0x30,0xf0,0x5b,0x03,0x17,0xf0,0x60,0x03,0xfd,0xef,0x64,0x03,0xe3,0xef,0x68,0x03,0xc9,0xef,0x6c,0x03,0xaf,0xef,0x70,0x03,0x94,0xef,0x74,0x03,0x79,0xef,0x77,0x03,0x5e,0xef,0x7b,0x03,0x43,0xef,0x7e,0x03,0x28,0xef,0x81,0x03,0x0d,0xef,0x85,0x03,0xf1,0xee,0x88,0x03,0xd5,0xee,0x8b,0x03,0xba,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcb,0x03,0x20,0x11,0xc8,0x03,0x05,0x11,0xc4,0x03,0xe9,0x10,0xc1,0x03,0xcd,0x10,0xbd,0x03,0xb2,0x10,0xba,0x03,0x96,0x10,0xb6,0x03,0x7b,0x10,0xb2,0x03,0x60,0x10,0xaf,0x03,0x45,0x10,0xab,0x03,0x2a,0x10,0xa7,0x03,0x0f,0x10,0xa2,0x03,0xf5,0x0f,0x9e,0x03,0xda,0x0f,0x9a,0x03,0xc0,0x0f,0x95,0x03,0xa6,0x0f,0x91,0x03,  \
    0x8c,0x0f,0x8c,0x03,0x72,0x0f,0x88,0x03,0x58,0x0f,0x83,0x03,0x3e,0x0f,0x7e,0x03,0x25,0x0f,0x79,0x03,0x0c,0x0f,0x74,0x03,0xf3,0x0e,0x6f,0x03,0xda,0x0e,0x6a,0x03,0xc1,0x0e,0x64,0x03,0xa9,0x0e,0x5f,0x03,0x90,0x0e,0x5a,0x03,0x78,0x0e,0x54,0x03,0x60,0x0e,0x4e,0x03,0x48,0x0e,0x49,0x03,0x30,0x0e,0x43,0x03,0x18,0x0e,0x3d,0x03,0x01,0x0e,0x38,0x03,0xe9,0x0d,0x32,0x03,0xd2,0x0d,0x2c,0x03,0xba,0x0d,0x26,0x03,0xa3,0x0d,0x20,0x03,0x8c,0x0d,0x1a,0x03,0x75,0x0d,  \
    0x14,0x03,0x5f,0x0d,0x0e,0x03,0x48,0x0d,0x07,0x03,0x32,0x0d,0x01,0x03,0x1c,0x0d,0xfa,0x02,0x06,0x0d,0xf4,0x02,0xf0,0x0c,0xed,0x02,0xda,0x0c,0xe6,0x02,0xc5,0x0c,0xe0,0x02,0xb0,0x0c,0xd9,0x02,0x9a,0x0c,0xd2,0x02,0x85,0x0c,0xcc,0x02,0x70,0x0c,0xc5,0x02,0x5b,0x0c,0xbe,0x02,0x47,0x0c,0xb7,0x02,0x32,0x0c,0xb0,0x02,0x1e,0x0c,0xaa,0x02,0x09,0x0c,0xa3,0x02,0xf5,0x0b,0x9c,0x02,0xe1,0x0b,0x95,0x02,0xcc,0x0b,0x8f,0x02,0xb7,0x0b,0x89,0x02,0xa1,0x0b,0x83,0x02,  \
    0x8c,0x0b,0x7d,0x02,0x77,0x0b,0x77,0x02,0x62,0x0b,0x71,0x02,0x4d,0x0b,0x6b,0x02,0x38,0x0b,0x65,0x02,0x23,0x0b,0x5f,0x02,0x0e,0x0b,0x59,0x02,0xf9,0x0a,0x53,0x02,0xe5,0x0a,0x4d,0x02,0xd0,0x0a,0x47,0x02,0xbb,0x0a,0x41,0x02,0xa7,0x0a,0x3b,0x02,0x93,0x0a,0x34,0x02,0x7e,0x0a,0x2e,0x02,0x6a,0x0a,0x28,0x02,0x56,0x0a,0x22,0x02,0x42,0x0a,0x1c,0x02,0x2e,0x0a,0x17,0x02,0x1a,0x0a,0x11,0x02,0x06,0x0a,0x0b,0x02,0xf2,0x09,0x05,0x02,0xde,0x09,0xff,0x01,0xca,0x09,  \
    0xf9,0x01,0xb7,0x09,0xf3,0x01,0xa3,0x09,0xed,0x01,0x90,0x09,0xe7,0x01,0x7c,0x09,0xe1,0x01,0x69,0x09,0xdb,0x01,0x56,0x09,0xd6,0x01,0x42,0x09,0xd0,0x01,0x2f,0x09,0xca,0x01,0x1c,0x09,0xc4,0x01,0x09,0x09,0xbe,0x01,0xf6,0x08,0xb8,0x01,0xe4,0x08,0xb2,0x01,0xd3,0x08,0xab,0x01,0xc2,0x08,0xa5,0x01,0xb0,0x08,0x9f,0x01,0x9f,0x08,0x99,0x01,0x8e,0x08,0x93,0x01,0x7c,0x08,0x8d,0x01,0x6b,0x08,0x86,0x01,0x5a,0x08,0x80,0x01,0x49,0x08,0x7a,0x01,0x38,0x08,0x74,0x01,  \
    0x27,0x08,0x6e,0x01,0x16,0x08,0x68,0x01,0x06,0x08,0x63,0x01,0xf5,0x07,0x5d,0x01,0xe4,0x07,0x57,0x01,0xd3,0x07,0x51,0x01,0xc3,0x07,0x4b,0x01,0xb2,0x07,0x46,0x01,0xa2,0x07,0x40,0x01,0x91,0x07,0x3b,0x01,0x80,0x07,0x35,0x01,0x70,0x07,0x30,0x01,0x5f,0x07,0x2a,0x01,0x4e,0x07,0x25,0x01,0x3e,0x07,0x20,0x01,0x2d,0x07,0x1a,0x01,0x1d,0x07,0x15,0x01,0x0d,0x07,0x10,0x01,0xfc,0x06,0x0b,0x01,0xec,0x06,0x05,0x01,0xdc,0x06,0x00,0x01,0xcb,0x06,0xfb,0x00,0xbb,0x06,  \
    0xf6,0x00,0xab,0x06,0xf1,0x00,0x9b,0x06,0xec,0x00,0x8b,0x06,0xe8,0x00,0x7a,0x06,0xe3,0x00,0x6a,0x06,0xde,0x00,0x5a,0x06,0xd9,0x00,0x4a,0x06,0xd4,0x00,0x3a,0x06,0xd0,0x00,0x2a,0x06,0xcb,0x00,0x19,0x06,0xc7,0x00,0x09,0x06,0xc3,0x00,0xf8,0x05,0xbf,0x00,0xe7,0x05,0xba,0x00,0xd6,0x05,0xb6,0x00,0xc6,0x05,0xb2,0x00,0xb5,0x05,0xae,0x00,0xa4,0x05,0xaa,0x00,0x94,0x05,0xa6,0x00,0x83,0x05,0xa2,0x00,0x73,0x05,0x9e,0x00,0x62,0x05,0x9a,0x00,0x52,0x05,0x96,0x00,  \
    0x41,0x05,0x92,0x00,0x31,0x05,0x8e,0x00,0x21,0x05,0x8a,0x00,0x10,0x05,0x87,0x00,0x00,0x05,0x83,0x00,0xf0,0x04,0x7f,0x00,0xdf,0x04,0x7c,0x00,0xcf,0x04,0x78,0x00,0xbf,0x04,0x75,0x00,0xaf,0x04,0x71,0x00,0x9f,0x04,0x6d,0x00,0x8f,0x04,0x6a,0x00,0x80,0x04,0x66,0x00,0x70,0x04,0x63,0x00,0x61,0x04,0x60,0x00,0x51,0x04,0x5c,0x00,0x42,0x04,0x59,0x00,0x32,0x04,0x56,0x00,0x23,0x04,0x52,0x00,0x14,0x04,0x4f,0x00,0x04,0x04,0x4c,0x00,0xf5,0x03,0x49,0x00,0xe6,0x03,  \
    0x46,0x00,0xd6,0x03,0x43,0x00,0xc7,0x03,0x40,0x00,0xb8,0x03,0x3d,0x00,0xa8,0x03,0x3a,0x00,0x99,0x03,0x37,0x00,0x8a,0x03,0x34,0x00,0x7a,0x03,0x32,0x00,0x6b,0x03,0x2f,0x00,0x5c,0x03,0x2c,0x00,0x4d,0x03,0x2a,0x00,0x3e,0x03,0x27,0x00,0x2e,0x03,0x24,0x00,0x1f,0x03,0x22,0x00,0x10,0x03,0x1f,0x00,0x01,0x03,0x1d,0x00,0xf3,0x02,0x1a,0x00,0xe4,0x02,0x18,0x00,0xd5,0x02,0x16,0x00,0xc7,0x02,0x14,0x00,0xb8,0x02,0x11,0x00,0xa9,0x02,0x0f,0x00,0x9a,0x02,0x0d,0x00,  \
    0x8c,0x02,0x0b,0x00,0x7d,0x02,0x09,0x00,0x6e,0x02,0x07,0x00,0x5f,0x02,0x05,0x00,0x51,0x02,0x03,0x00,0x42,0x02,0x01,0x00,0x33,0x02,0xff,0xff,0x24,0x02,0xfe,0xff,0x16,0x02,0xfc,0xff,0x07,0x02,0xfa,0xff,0xf8,0x01,0xf9,0xff,0xe9,0x01,0xf7,0xff,0xda,0x01,0xf6,0xff,0xcb,0x01,0xf4,0xff,0xbc,0x01,0xf3,0xff,0xae,0x01,0xf1,0xff,0x9f,0x01,0xf0,0xff,0x90,0x01,0xef,0xff,0x81,0x01,0xee,0xff,0x72,0x01,0xec,0xff,0x62,0x01,0xeb,0xff,0x53,0x01,0xea,0xff,0x44,0x01,  \
    0xe9,0xff,0x34,0x01,0xe8,0xff,0x25,0x01,0xe7,0xff,0x16,0x01,0xe6,0xff,0x07,0x01,0xe5,0xff,0xf7,0x00,0xe4,0xff,0xe8,0x00,0xe4,0xff,0xd9,0x00,0xe3,0xff,0xca,0x00,0xe2,0xff,0xba,0x00,0xe2,0xff,0xab,0x00,0xe1,0xff,0x9c,0x00,0xe0,0xff,0x8d,0x00,0xe0,0xff,0x7e,0x00,0xdf,0xff,0x6e,0x00,0xdf,0xff,0x5f,0x00,0xde,0xff,0x50,0x00,0xde,0xff,0x41,0x00,0xde,0xff,0x31,0x00,0xdd,0xff,0x22,0x00,0xdd,0xff,0x13,0x00,0xdd,0xff,0x04,0x00,0xdd,0xff,0xf4,0xff,0xdd,0xff,  \
    0xe5,0xff,0xdd,0xff,0xd6,0xff,0xdd,0xff,0xc7,0xff,0xdd,0xff,0xb8,0xff,0xdd,0xff,0xa8,0xff,0xdd,0xff,0x99,0xff,0xdd,0xff,0x8a,0xff,0xdd,0xff,0x7b,0xff,0xdd,0xff,0x6c,0xff,0xde,0xff,0x5c,0xff,0xde,0xff,0x4d,0xff,0xde,0xff,0x3e,0xff,0xdf,0xff,0x2f,0xff,0xdf,0xff,0x20,0xff,0xdf,0xff,0x10,0xff,0xe0,0xff,0x01,0xff,0xe0,0xff,0xf2,0xfe,0xe1,0xff,0xe3,0xfe,0xe2,0xff,0xd3,0xfe,0xe2,0xff,0xc4,0xfe,0xe3,0xff,0xb5,0xfe,0xe4,0xff,0xa6,0xfe,0xe5,0xff,0x97,0xfe,  \
    0xe5,0xff,0x87,0xfe,0xe6,0xff,0x78,0xfe,0xe7,0xff,0x69,0xfe,0xe8,0xff,0x5a,0xfe,0xe9,0xff,0x4b,0xfe,0xea,0xff,0x3b,0xfe,0xeb,0xff,0x2c,0xfe,0xec,0xff,0x1d,0xfe,0xee,0xff,0x0d,0xfe,0xef,0xff,0xfe,0xfd,0xf0,0xff,0xef,0xfd,0xf1,0xff,0xdf,0xfd,0xf3,0xff,0xd0,0xfd,0xf4,0xff,0xc0,0xfd,0xf5,0xff,0xb1,0xfd,0xf7,0xff,0xa1,0xfd,0xf8,0xff,0x92,0xfd,0xfa,0xff,0x82,0xfd,0xfb,0xff,0x73,0xfd,0xfd,0xff,0x63,0xfd,0xfe,0xff,0x54,0xfd,0x00,0x00,0x44,0xfd,0x02,0x00,  \
    0x34,0xfd,0x04,0x00,0x25,0xfd,0x05,0x00,0x15,0xfd,0x07,0x00,0x06,0xfd,0x09,0x00,0xf6,0xfc,0x0b,0x00,0xe6,0xfc,0x0d,0x00,0xd7,0xfc,0x0f,0x00,0xc7,0xfc,0x11,0x00,0xb7,0xfc,0x13,0x00,0xa8,0xfc,0x15,0x00,0x98,0xfc,0x17,0x00,0x88,0xfc,0x19,0x00,0x78,0xfc,0x1c,0x00,0x69,0xfc,0x1e,0x00,0x5a,0xfc,0x20,0x00,0x4b,0xfc,0x23,0x00,0x3b,0xfc,0x25,0x00,0x2c,0xfc,0x28,0x00,0x1d,0xfc,0x2a,0x00,0x0d,0xfc,0x2d,0x00,0xfe,0xfb,0x2f,0x00,0xef,0xfb,0x32,0x00,0xdf,0xfb,  \
    0x35,0x00,0xd0,0xfb,0x38,0x00,0xc1,0xfb,0x3a,0x00,0xb1,0xfb,0x3d,0x00,0xa2,0xfb,0x40,0x00,0x93,0xfb,0x43,0x00,0x83,0xfb,0x46,0x00,0x74,0xfb,0x49,0x00,0x64,0xfb,0x4c,0x00,0x55,0xfb,0x4f,0x00,0x46,0xfb,0x52,0x00,0x36,0xfb,0x56,0x00,0x27,0xfb,0x59,0x00,0x17,0xfb,0x5c,0x00,0x08,0xfb,0x5f,0x00,0xf9,0xfa,0x63,0x00,0xe9,0xfa,0x66,0x00,0xd9,0xfa,0x6a,0x00,0xca,0xfa,0x6d,0x00,0xba,0xfa,0x71,0x00,0xaa,0xfa,0x74,0x00,0x9a,0xfa,0x78,0x00,0x8a,0xfa,0x7b,0x00,  \
    0x7a,0xfa,0x7f,0x00,0x6a,0xfa,0x82,0x00,0x5a,0xfa,0x86,0x00,0x4a,0xfa,0x8a,0x00,0x3a,0xfa,0x8e,0x00,0x29,0xfa,0x91,0x00,0x19,0xfa,0x95,0x00,0x09,0xfa,0x99,0x00,0xf9,0xf9,0x9d,0x00,0xe9,0xf9,0xa1,0x00,0xd9,0xf9,0xa5,0x00,0xc8,0xf9,0xa9,0x00,0xb8,0xf9,0xad,0x00,0xa8,0xf9,0xb1,0x00,0x98,0xf9,0xb6,0x00,0x87,0xf9,0xba,0x00,0x77,0xf9,0xbe,0x00,0x66,0xf9,0xc2,0x00,0x56,0xf9,0xc7,0x00,0x46,0xf9,0xcb,0x00,0x36,0xf9,0xd0,0x00,0x25,0xf9,0xd4,0x00,0x15,0xf9,  \
    0xd9,0x00,0x05,0xf9,0xdd,0x00,0xf5,0xf8,0xe2,0x00,0xe4,0xf8,0xe7,0x00,0xd4,0xf8,0xeb,0x00,0xc4,0xf8,0xf0,0x00,0xb3,0xf8,0xf5,0x00,0xa3,0xf8,0xfa,0x00,0x92,0xf8,0xff,0x00,0x82,0xf8,0x04,0x01,0x71,0xf8,0x09,0x01,0x61,0xf8,0x0e,0x01,0x50,0xf8,0x13,0x01,0x3f,0xf8,0x18,0x01,0x2f,0xf8,0x1d,0x01,0x1e,0xf8,0x22,0x01,0x0d,0xf8,0x27,0x01,0xfc,0xf7,0x2c,0x01,0xec,0xf7,0x32,0x01,0xdb,0xf7,0x37,0x01,0xc9,0xf7,0x3c,0x01,0xb8,0xf7,0x41,0x01,0xa7,0xf7,0x47,0x01,  \
    0x95,0xf7,0x4c,0x01,0x84,0xf7,0x51,0x01,0x72,0xf7,0x57,0x01,0x61,0xf7,0x5c,0x01,0x4f,0xf7,0x61,0x01,0x3e,0xf7,0x67,0x01,0x2c,0xf7,0x6c,0x01,0x1a,0xf7,0x72,0x01,0x08,0xf7,0x77,0x01,0xf7,0xf6,0x7d,0x01,0xe5,0xf6,0x82,0x01,0xd3,0xf6,0x88,0x01,0xc1,0xf6,0x8e,0x01,0xaf,0xf6,0x93,0x01,0x9d,0xf6,0x99,0x01,0x8b,0xf6,0x9f,0x01,0x78,0xf6,0xa5,0x01,0x66,0xf6,0xaa,0x01,0x54,0xf6,0xb0,0x01,0x42,0xf6,0xb6,0x01,0x30,0xf6,0xbc,0x01,0x1d,0xf6,0xc2,0x01,0x0b,0xf6,  \
    0xc8,0x01,0xf9,0xf5,0xce,0x01,0xe6,0xf5,0xd4,0x01,0xd4,0xf5,0xda,0x01,0xc1,0xf5,0xe0,0x01,0xaf,0xf5,0xe7,0x01,0x9c,0xf5,0xed,0x01,0x89,0xf5,0xf3,0x01,0x77,0xf5,0xf9,0x01,0x64,0xf5,0xff,0x01,0x51,0xf5,0x05,0x02,0x3e,0xf5,0x0b,0x02,0x2b,0xf5,0x12,0x02,0x17,0xf5,0x18,0x02,0x04,0xf5,0x1e,0x02,0xf1,0xf4,0x24,0x02,0xdc,0xf4,0x2a,0x02,0xc8,0xf4,0x30,0x02,0xb4,0xf4,0x35,0x02,0x9f,0xf4,0x3b,0x02,0x8a,0xf4,0x41,0x02,0x76,0xf4,0x47,0x02,0x61,0xf4,0x4d,0x02,  \
    0x4c,0xf4,0x52,0x02,0x37,0xf4,0x58,0x02,0x22,0xf4,0x5e,0x02,0x0d,0xf4,0x64,0x02,0xf8,0xf3,0x69,0x02,0xe3,0xf3,0x6f,0x02,0xcd,0xf3,0x75,0x02,0xb8,0xf3,0x7b,0x02,0xa2,0xf3,0x80,0x02,0x8d,0xf3,0x86,0x02,0x77,0xf3,0x8c,0x02,0x61,0xf3,0x92,0x02,0x4c,0xf3,0x98,0x02,0x37,0xf3,0x9e,0x02,0x22,0xf3,0xa4,0x02,0x0c,0xf3,0xab,0x02,0xf7,0xf2,0xb1,0x02,0xe1,0xf2,0xb7,0x02,0xcc,0xf2,0xbd,0x02,0xb6,0xf2,0xc3,0x02,0xa0,0xf2,0xc8,0x02,0x8a,0xf2,0xce,0x02,0x73,0xf2,  \
    0xd4,0x02,0x5d,0xf2,0xda,0x02,0x47,0xf2,0xe0,0x02,0x30,0xf2,0xe6,0x02,0x19,0xf2,0xeb,0x02,0x02,0xf2,0xf1,0x02,0xeb,0xf1,0xf6,0x02,0xd4,0xf1,0xfc,0x02,0xbd,0xf1,0x02,0x03,0xa6,0xf1,0x07,0x03,0x8f,0xf1,0x0d,0x03,0x77,0xf1,0x12,0x03,0x60,0xf1,0x18,0x03,0x48,0xf1,0x1d,0x03,0x30,0xf1,0x22,0x03,0x18,0xf1,0x27,0x03,0x00,0xf1,0x2c,0x03,0xe8,0xf0,0x31,0x03,0xcf,0xf0,0x36,0x03,0xb7,0xf0,0x3b,0x03,0x9e,0xf0,0x40,0x03,0x85,0xf0,0x45,0x03,0x6c,0xf0,0x4a,0x03,  \
    0x53,0xf0,0x4e,0x03,0x3a,0xf0,0x53,0x03,0x20,0xf0,0x57,0x03,0x07,0xf0,0x5c,0x03,0xed,0xef,0x60,0x03,0xd3,0xef,0x64,0x03,0xb8,0xef,0x67,0x03,0x9d,0xef,0x6b,0x03,0x83,0xef,0x6f,0x03,0x68,0xef,0x72,0x03,0x4d,0xef,0x75,0x03,0x31,0xef,0x79,0x03,0x16,0xef,0x7c,0x03,0xfa,0xee,0x7f,0x03,0xdf,0xee,0x82,0x03,0xc3,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xbf,0x03,0x19,0x11,0xbb,0x03,0xfd,0x10,0xb8,0x03,0xe2,0x10,0xb5,0x03,0xc6,0x10,0xb1,0x03,0xaa,0x10,0xae,0x03,0x8f,0x10,0xaa,0x03,0x74,0x10,0xa6,0x03,0x59,0x10,0xa2,0x03,0x3e,0x10,0x9f,0x03,0x23,0x10,0x9b,0x03,0x08,0x10,0x96,0x03,0xed,0x0f,0x92,0x03,0xd3,0x0f,0x8e,0x03,0xb9,0x0f,0x8a,0x03,  \
    0x9f,0x0f,0x85,0x03,0x84,0x0f,0x81,0x03,0x6b,0x0f,0x7c,0x03,0x51,0x0f,0x78,0x03,0x37,0x0f,0x73,0x03,0x1e,0x0f,0x6e,0x03,0x04,0x0f,0x69,0x03,0xeb,0x0e,0x64,0x03,0xd2,0x0e,0x5e,0x03,0xba,0x0e,0x59,0x03,0xa1,0x0e,0x54,0x03,0x89,0x0e,0x4e,0x03,0x70,0x0e,0x49,0x03,0x58,0x0e,0x43,0x03,0x40,0x0e,0x3e,0x03,0x28,0x0e,0x38,0x03,0x10,0x0e,0x33,0x03,0xf9,0x0d,0x2d,0x03,0xe1,0x0d,0x27,0x03,0xca,0x0d,0x21,0x03,0xb2,0x0d,0x1b,0x03,0x9b,0x0d,0x15,0x03,0x84,0x0d,  \
    0x0f,0x03,0x6d,0x0d,0x09,0x03,0x56,0x0d,0x03,0x03,0x40,0x0d,0xfd,0x02,0x29,0x0d,0xf7,0x02,0x13,0x0d,0xf0,0x02,0xfd,0x0c,0xea,0x02,0xe8,0x0c,0xe3,0x02,0xd2,0x0c,0xdd,0x02,0xbd,0x0c,0xd6,0x02,0xa7,0x0c,0xcf,0x02,0x92,0x0c,0xc9,0x02,0x7d,0x0c,0xc2,0x02,0x68,0x0c,0xbb,0x02,0x53,0x0c,0xb5,0x02,0x3e,0x0c,0xae,0x02,0x29,0x0c,0xa7,0x02,0x15,0x0c,0xa0,0x02,0x00,0x0c,0x9a,0x02,0xec,0x0b,0x93,0x02,0xd8,0x0b,0x8c,0x02,0xc3,0x0b,0x86,0x02,0xae,0x0b,0x80,0x02,  \
    0x98,0x0b,0x7a,0x02,0x83,0x0b,0x74,0x02,0x6e,0x0b,0x6e,0x02,0x59,0x0b,0x68,0x02,0x44,0x0b,0x62,0x02,0x2f,0x0b,0x5c,0x02,0x1a,0x0b,0x56,0x02,0x05,0x0b,0x50,0x02,0xf0,0x0a,0x4a,0x02,0xdb,0x0a,0x44,0x02,0xc7,0x0a,0x3e,0x02,0xb2,0x0a,0x38,0x02,0x9e,0x0a,0x32,0x02,0x8a,0x0a,0x2c,0x02,0x75,0x0a,0x26,0x02,0x61,0x0a,0x20,0x02,0x4d,0x0a,0x1a,0x02,0x39,0x0a,0x14,0x02,0x25,0x0a,0x0e,0x02,0x11,0x0a,0x08,0x02,0xfd,0x09,0x02,0x02,0xe9,0x09,0xfc,0x01,0xd5,0x09,  \
    0xf6,0x01,0xc2,0x09,0xf0,0x01,0xae,0x09,0xeb,0x01,0x9a,0x09,0xe5,0x01,0x87,0x09,0xdf,0x01,0x73,0x09,0xd9,0x01,0x60,0x09,0xd3,0x01,0x4d,0x09,0xcd,0x01,0x39,0x09,0xc8,0x01,0x26,0x09,0xc2,0x01,0x13,0x09,0xbc,0x01,0x00,0x09,0xb6,0x01,0xed,0x08,0xb0,0x01,0xdc,0x08,0xaa,0x01,0xca,0x08,0xa4,0x01,0xb9,0x08,0x9d,0x01,0xa7,0x08,0x97,0x01,0x96,0x08,0x91,0x01,0x85,0x08,0x8b,0x01,0x74,0x08,0x85,0x01,0x63,0x08,0x7f,0x01,0x51,0x08,0x79,0x01,0x40,0x08,0x73,0x01,  \
    0x2f,0x08,0x6d,0x01,0x1e,0x08,0x67,0x01,0x0e,0x08,0x61,0x01,0xfd,0x07,0x5b,0x01,0xec,0x07,0x55,0x01,0xdb,0x07,0x4f,0x01,0xcb,0x07,0x4a,0x01,0xba,0x07,0x44,0x01,0xa9,0x07,0x3e,0x01,0x99,0x07,0x39,0x01,0x88,0x07,0x33,0x01,0x78,0x07,0x2e,0x01,0x67,0x07,0x28,0x01,0x56,0x07,0x23,0x01,0x46,0x07,0x1e,0x01,0x35,0x07,0x18,0x01,0x25,0x07,0x13,0x01,0x14,0x07,0x0e,0x01,0x04,0x07,0x09,0x01,0xf4,0x06,0x03,0x01,0xe3,0x06,0xfe,0x00,0xd3,0x06,0xf9,0x00,0xc3,0x06,  \
    0xf4,0x00,0xb3,0x06,0xef,0x00,0xa2,0x06,0xea,0x00,0x92,0x06,0xe5,0x00,0x82,0x06,0xe1,0x00,0x72,0x06,0xdc,0x00,0x62,0x06,0xd7,0x00,0x52,0x06,0xd2,0x00,0x42,0x06,0xcd,0x00,0x32,0x06,0xc9,0x00,0x22,0x06,0xc4,0x00,0x11,0x06,0xc0,0x00,0x00,0x06,0xbc,0x00,0xf0,0x05,0xb8,0x00,0xdf,0x05,0xb3,0x00,0xce,0x05,0xaf,0x00,0xbe,0x05,0xab,0x00,0xad,0x05,0xa7,0x00,0x9d,0x05,0xa3,0x00,0x8c,0x05,0x9f,0x00,0x7c,0x05,0x9b,0x00,0x6b,0x05,0x97,0x00,0x5b,0x05,0x93,0x00,  \
    0x4a,0x05,0x8f,0x00,0x3a,0x05,0x8b,0x00,0x2a,0x05,0x87,0x00,0x19,0x05,0x84,0x00,0x09,0x05,0x80,0x00,0xf9,0x04,0x7c,0x00,0xe9,0x04,0x79,0x00,0xd8,0x04,0x75,0x00,0xc8,0x04,0x71,0x00,0xb8,0x04,0x6e,0x00,0xa8,0x04,0x6a,0x00,0x98,0x04,0x67,0x00,0x89,0x04,0x63,0x00,0x79,0x04,0x60,0x00,0x6a,0x04,0x5c,0x00,0x5a,0x04,0x59,0x00,0x4b,0x04,0x55,0x00,0x3c,0x04,0x52,0x00,0x2c,0x04,0x4f,0x00,0x1d,0x04,0x4c,0x00,0x0e,0x04,0x48,0x00,0xfe,0x03,0x45,0x00,0xef,0x03,  \
    0x42,0x00,0xe0,0x03,0x3f,0x00,0xd0,0x03,0x3c,0x00,0xc1,0x03,0x39,0x00,0xb2,0x03,0x36,0x00,0xa3,0x03,0x33,0x00,0x93,0x03,0x30,0x00,0x84,0x03,0x2e,0x00,0x75,0x03,0x2b,0x00,0x66,0x03,0x28,0x00,0x57,0x03,0x25,0x00,0x48,0x03,0x23,0x00,0x38,0x03,0x20,0x00,0x29,0x03,0x1e,0x00,0x1a,0x03,0x1b,0x00,0x0b,0x03,0x19,0x00,0xfd,0x02,0x16,0x00,0xee,0x02,0x14,0x00,0xdf,0x02,0x11,0x00,0xd1,0x02,0x0f,0x00,0xc2,0x02,0x0d,0x00,0xb3,0x02,0x0b,0x00,0xa5,0x02,0x08,0x00,  \
    0x96,0x02,0x06,0x00,0x87,0x02,0x04,0x00,0x79,0x02,0x02,0x00,0x6a,0x02,0x00,0x00,0x5b,0x02,0xfe,0xff,0x4d,0x02,0xfc,0xff,0x3e,0x02,0xfb,0xff,0x2f,0x02,0xf9,0xff,0x21,0x02,0xf7,0xff,0x12,0x02,0xf5,0xff,0x03,0x02,0xf4,0xff,0xf4,0x01,0xf2,0xff,0xe6,0x01,0xf0,0xff,0xd7,0x01,0xef,0xff,0xc8,0x01,0xee,0xff,0xb9,0x01,0xec,0xff,0xaa,0x01,0xeb,0xff,0x9c,0x01,0xe9,0xff,0x8d,0x01,0xe8,0xff,0x7e,0x01,0xe7,0xff,0x6f,0x01,0xe6,0xff,0x60,0x01,0xe5,0xff,0x50,0x01,  \
    0xe3,0xff,0x41,0x01,0xe2,0xff,0x32,0x01,0xe1,0xff,0x23,0x01,0xe0,0xff,0x14,0x01,0xe0,0xff,0x05,0x01,0xdf,0xff,0xf5,0x00,0xde,0xff,0xe6,0x00,0xdd,0xff,0xd7,0x00,0xdc,0xff,0xc8,0x00,0xdc,0xff,0xb9,0x00,0xdb,0xff,0xaa,0x00,0xda,0xff,0x9b,0x00,0xda,0xff,0x8b,0x00,0xd9,0xff,0x7c,0x00,0xd9,0xff,0x6d,0x00,0xd8,0xff,0x5e,0x00,0xd8,0xff,0x4f,0x00,0xd7,0xff,0x40,0x00,0xd7,0xff,0x31,0x00,0xd7,0xff,0x22,0x00,0xd7,0xff,0x12,0x00,0xd6,0xff,0x03,0x00,0xd6,0xff,  \
    0xf4,0xff,0xd6,0xff,0xe5,0xff,0xd6,0xff,0xd6,0xff,0xd6,0xff,0xc7,0xff,0xd6,0xff,0xb8,0xff,0xd6,0xff,0xa9,0xff,0xd6,0xff,0x99,0xff,0xd6,0xff,0x8a,0xff,0xd6,0xff,0x7b,0xff,0xd7,0xff,0x6c,0xff,0xd7,0xff,0x5d,0xff,0xd7,0xff,0x4e,0xff,0xd7,0xff,0x3f,0xff,0xd8,0xff,0x30,0xff,0xd8,0xff,0x21,0xff,0xd9,0xff,0x11,0xff,0xd9,0xff,0x02,0xff,0xda,0xff,0xf3,0xfe,0xda,0xff,0xe4,0xfe,0xdb,0xff,0xd5,0xfe,0xdc,0xff,0xc6,0xfe,0xdc,0xff,0xb7,0xfe,0xdd,0xff,0xa8,0xfe,  \
    0xde,0xff,0x99,0xfe,0xdf,0xff,0x89,0xfe,0xe0,0xff,0x7a,0xfe,0xe1,0xff,0x6b,0xfe,0xe1,0xff,0x5c,0xfe,0xe2,0xff,0x4d,0xfe,0xe4,0xff,0x3e,0xfe,0xe5,0xff,0x2f,0xfe,0xe6,0xff,0x1f,0xfe,0xe7,0xff,0x10,0xfe,0xe8,0xff,0x01,0xfe,0xe9,0xff,0xf2,0xfd,0xeb,0xff,0xe2,0xfd,0xec,0xff,0xd3,0xfd,0xed,0xff,0xc3,0xfd,0xef,0xff,0xb4,0xfd,0xf0,0xff,0xa5,0xfd,0xf2,0xff,0x95,0xfd,0xf3,0xff,0x86,0xfd,0xf5,0xff,0x77,0xfd,0xf6,0xff,0x67,0xfd,0xf8,0xff,0x58,0xfd,0xfa,0xff,  \
    0x48,0xfd,0xfb,0xff,0x39,0xfd,0xfd,0xff,0x29,0xfd,0xff,0xff,0x1a,0xfd,0x01,0x00,0x0a,0xfd,0x02,0x00,0xfb,0xfc,0x04,0x00,0xeb,0xfc,0x06,0x00,0xdc,0xfc,0x08,0x00,0xcc,0xfc,0x0a,0x00,0xbc,0xfc,0x0c,0x00,0xad,0xfc,0x0f,0x00,0x9d,0xfc,0x11,0x00,0x8d,0xfc,0x13,0x00,0x7e,0xfc,0x15,0x00,0x6f,0xfc,0x17,0x00,0x5f,0xfc,0x1a,0x00,0x50,0xfc,0x1c,0x00,0x41,0xfc,0x1f,0x00,0x32,0xfc,0x21,0x00,0x22,0xfc,0x24,0x00,0x13,0xfc,0x26,0x00,0x04,0xfc,0x29,0x00,0xf5,0xfb,  \
    0x2c,0x00,0xe5,0xfb,0x2e,0x00,0xd6,0xfb,0x31,0x00,0xc7,0xfb,0x34,0x00,0xb8,0xfb,0x37,0x00,0xa8,0xfb,0x3a,0x00,0x99,0xfb,0x3d,0x00,0x8a,0xfb,0x40,0x00,0x7b,0xfb,0x43,0x00,0x6b,0xfb,0x46,0x00,0x5c,0xfb,0x49,0x00,0x4d,0xfb,0x4c,0x00,0x3d,0xfb,0x4f,0x00,0x2e,0xfb,0x52,0x00,0x1f,0xfb,0x56,0x00,0x0f,0xfb,0x59,0x00,0x00,0xfb,0x5c,0x00,0xf0,0xfa,0x60,0x00,0xe1,0xfa,0x63,0x00,0xd1,0xfa,0x67,0x00,0xc1,0xfa,0x6a,0x00,0xb1,0xfa,0x6e,0x00,0xa1,0xfa,0x71,0x00,  \
    0x92,0xfa,0x75,0x00,0x82,0xfa,0x78,0x00,0x72,0xfa,0x7c,0x00,0x62,0xfa,0x80,0x00,0x52,0xfa,0x83,0x00,0x42,0xfa,0x87,0x00,0x32,0xfa,0x8b,0x00,0x22,0xfa,0x8f,0x00,0x11,0xfa,0x93,0x00,0x01,0xfa,0x97,0x00,0xf1,0xf9,0x9b,0x00,0xe1,0xf9,0x9f,0x00,0xd1,0xf9,0xa3,0x00,0xc1,0xf9,0xa7,0x00,0xb1,0xf9,0xab,0x00,0xa0,0xf9,0xaf,0x00,0x90,0xf9,0xb3,0x00,0x80,0xf9,0xb8,0x00,0x6f,0xf9,0xbc,0x00,0x5f,0xf9,0xc0,0x00,0x4f,0xf9,0xc5,0x00,0x3f,0xf9,0xc9,0x00,0x2f,0xf9,  \
    0xce,0x00,0x1e,0xf9,0xd2,0x00,0x0e,0xf9,0xd7,0x00,0xfe,0xf8,0xdc,0x00,0xee,0xf8,0xe0,0x00,0xdd,0xf8,0xe5,0x00,0xcd,0xf8,0xea,0x00,0xbd,0xf8,0xef,0x00,0xac,0xf8,0xf3,0x00,0x9c,0xf8,0xf8,0x00,0x8b,0xf8,0xfd,0x00,0x7b,0xf8,0x02,0x01,0x6a,0xf8,0x07,0x01,0x5a,0xf8,0x0c,0x01,0x49,0xf8,0x11,0x01,0x38,0xf8,0x16,0x01,0x28,0xf8,0x1c,0x01,0x17,0xf8,0x21,0x01,0x06,0xf8,0x26,0x01,0xf5,0xf7,0x2b,0x01,0xe5,0xf7,0x30,0x01,0xd3,0xf7,0x36,0x01,0xc2,0xf7,0x3b,0x01,  \
    0xb1,0xf7,0x40,0x01,0x9f,0xf7,0x45,0x01,0x8e,0xf7,0x4b,0x01,0x7c,0xf7,0x50,0x01,0x6b,0xf7,0x55,0x01,0x59,0xf7,0x5b,0x01,0x48,0xf7,0x60,0x01,0x36,0xf7,0x66,0x01,0x24,0xf7,0x6b,0x01,0x13,0xf7,0x71,0x01,0x01,0xf7,0x76,0x01,0xef,0xf6,0x7c,0x01,0xdd,0xf6,0x82,0x01,0xcb,0xf6,0x87,0x01,0xb9,0xf6,0x8d,0x01,0xa7,0xf6,0x93,0x01,0x95,0xf6,0x98,0x01,0x83,0xf6,0x9e,0x01,0x71,0xf6,0xa4,0x01,0x5e,0xf6,0xaa,0x01,0x4c,0xf6,0xb0,0x01,0x3a,0xf6,0xb6,0x01,0x28,0xf6,  \
    0xbc,0x01,0x16,0xf6,0xc2,0x01,0x03,0xf6,0xc8,0x01,0xf1,0xf5,0xce,0x01,0xde,0xf5,0xd4,0x01,0xcc,0xf5,0xda,0x01,0xb9,0xf5,0xe0,0x01,0xa7,0xf5,0xe6,0x01,0x94,0xf5,0xec,0x01,0x81,0xf5,0xf2,0x01,0x6e,0xf5,0xf8,0x01,0x5b,0xf5,0xfe,0x01,0x48,0xf5,0x05,0x02,0x35,0xf5,0x0b,0x02,0x22,0xf5,0x11,0x02,0x0e,0xf5,0x17,0x02,0xfb,0xf4,0x1d,0x02,0xe7,0xf4,0x23,0x02,0xd3,0xf4,0x29,0x02,0xbe,0xf4,0x2e,0x02,0xaa,0xf4,0x34,0x02,0x95,0xf4,0x3a,0x02,0x80,0xf4,0x40,0x02,  \
    0x6c,0xf4,0x45,0x02,0x57,0xf4,0x4b,0x02,0x42,0xf4,0x51,0x02,0x2d,0xf4,0x57,0x02,0x18,0xf4,0x5d,0x02,0x03,0xf4,0x62,0x02,0xed,0xf3,0x68,0x02,0xd8,0xf3,0x6e,0x02,0xc2,0xf3,0x74,0x02,0xad,0xf3,0x79,0x02,0x97,0xf3,0x7f,0x02,0x82,0xf3,0x85,0x02,0x6c,0xf3,0x8b,0x02,0x57,0xf3,0x91,0x02,0x42,0xf3,0x97,0x02,0x2c,0xf3,0x9d,0x02,0x17,0xf3,0xa3,0x02,0x01,0xf3,0xa9,0x02,0xec,0xf2,0xaf,0x02,0xd6,0xf2,0xb5,0x02,0xc0,0xf2,0xbb,0x02,0xaa,0xf2,0xc1,0x02,0x94,0xf2,  \
    0xc7,0x02,0x7e,0xf2,0xcd,0x02,0x67,0xf2,0xd2,0x02,0x51,0xf2,0xd8,0x02,0x3a,0xf2,0xde,0x02,0x23,0xf2,0xe3,0x02,0x0d,0xf2,0xe9,0x02,0xf6,0xf1,0xef,0x02,0xde,0xf1,0xf4,0x02,0xc7,0xf1,0xfa,0x02,0xb0,0xf1,0xff,0x02,0x99,0xf1,0x05,0x03,0x81,0xf1,0x0a,0x03,0x6a,0xf1,0x10,0x03,0x52,0xf1,0x15,0x03,0x3a,0xf1,0x1a,0x03,0x22,0xf1,0x1f,0x03,0x0a,0xf1,0x24,0x03,0xf1,0xf0,0x29,0x03,0xd9,0xf0,0x2e,0x03,0xc0,0xf0,0x33,0x03,0xa8,0xf0,0x38,0x03,0x8f,0xf0,0x3d,0x03,  \
    0x76,0xf0,0x41,0x03,0x5c,0xf0,0x46,0x03,0x43,0xf0,0x4a,0x03,0x2a,0xf0,0x4f,0x03,0x10,0xf0,0x53,0x03,0xf6,0xef,0x57,0x03,0xdc,0xef,0x5b,0x03,0xc2,0xef,0x5f,0x03,0xa7,0xef,0x62,0x03,0x8c,0xef,0x66,0x03,0x71,0xef,0x69,0x03,0x56,0xef,0x6d,0x03,0x3b,0xef,0x70,0x03,0x1f,0xef,0x73,0x03,0x04,0xef,0x76,0x03,0xe8,0xee,0x79,0x03,0xcc,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xb2,0x03,0x12,0x11,0xaf,0x03,0xf7,0x10,0xac,0x03,0xdb,0x10,0xa8,0x03,0xbf,0x10,0xa5,0x03,0xa3,0x10,0xa2,0x03,0x88,0x10,0x9e,0x03,0x6d,0x10,0x9a,0x03,0x52,0x10,0x96,0x03,0x37,0x10,0x93,0x03,0x1c,0x10,0x8f,0x03,0x01,0x10,0x8b,0x03,0xe6,0x0f,0x86,0x03,0xcc,0x0f,0x82,0x03,  \
    0xb1,0x0f,0x7e,0x03,0x97,0x0f,0x7a,0x03,0x7d,0x0f,0x75,0x03,0x63,0x0f,0x71,0x03,0x49,0x0f,0x6c,0x03,0x30,0x0f,0x67,0x03,0x16,0x0f,0x62,0x03,0xfd,0x0e,0x5d,0x03,0xe4,0x0e,0x58,0x03,0xcb,0x0e,0x53,0x03,0xb2,0x0e,0x4e,0x03,0x9a,0x0e,0x49,0x03,0x81,0x0e,0x43,0x03,0x69,0x0e,0x3e,0x03,0x51,0x0e,0x38,0x03,0x39,0x0e,0x33,0x03,0x21,0x0e,0x2d,0x03,0x09,0x0e,0x28,0x03,0xf1,0x0d,0x22,0x03,0xd9,0x0d,0x1c,0x03,0xc2,0x0d,0x16,0x03,0xab,0x0d,0x11,0x03,0x93,0x0d,  \
    0x0b,0x03,0x7c,0x0d,0x05,0x03,0x65,0x0d,0xff,0x02,0x4e,0x0d,0xf9,0x02,0x38,0x0d,0xf3,0x02,0x21,0x0d,0xec,0x02,0x0b,0x0d,0xe6,0x02,0xf5,0x0c,0xe0,0x02,0xdf,0x0c,0xd9,0x02,0xca,0x0c,0xd3,0x02,0xb4,0x0c,0xcc,0x02,0x9f,0x0c,0xc6,0x02,0x89,0x0c,0xbf,0x02,0x74,0x0c,0xb8,0x02,0x5f,0x0c,0xb2,0x02,0x4a,0x0c,0xab,0x02,0x35,0x0c,0xa4,0x02,0x21,0x0c,0x9e,0x02,0x0c,0x0c,0x97,0x02,0xf7,0x0b,0x90,0x02,0xe3,0x0b,0x8a,0x02,0xcf,0x0b,0x83,0x02,0xba,0x0b,0x7d,0x02,  \
    0xa5,0x0b,0x77,0x02,0x8f,0x0b,0x71,0x02,0x7a,0x0b,0x6b,0x02,0x65,0x0b,0x65,0x02,0x50,0x0b,0x5f,0x02,0x3b,0x0b,0x59,0x02,0x26,0x0b,0x53,0x02,0x11,0x0b,0x4d,0x02,0xfc,0x0a,0x47,0x02,0xe7,0x0a,0x41,0x02,0xd2,0x0a,0x3b,0x02,0xbe,0x0a,0x35,0x02,0xa9,0x0a,0x2f,0x02,0x95,0x0a,0x29,0x02,0x81,0x0a,0x23,0x02,0x6c,0x0a,0x1d,0x02,0x58,0x0a,0x17,0x02,0x44,0x0a,0x12,0x02,0x30,0x0a,0x0c,0x02,0x1c,0x0a,0x06,0x02,0x08,0x0a,0x00,0x02,0xf4,0x09,0xfa,0x01,0xe0,0x09,  \
    0xf4,0x01,0xcc,0x09,0xee,0x01,0xb9,0x09,0xe8,0x01,0xa5,0x09,0xe2,0x01,0x92,0x09,0xdd,0x01,0x7e,0x09,0xd7,0x01,0x6b,0x09,0xd1,0x01,0x57,0x09,0xcb,0x01,0x44,0x09,0xc5,0x01,0x31,0x09,0xc0,0x01,0x1e,0x09,0xba,0x01,0x0a,0x09,0xb4,0x01,0xf7,0x08,0xae,0x01,0xe5,0x08,0xa8,0x01,0xd3,0x08,0xa2,0x01,0xc2,0x08,0x9c,0x01,0xb0,0x08,0x96,0x01,0x9f,0x08,0x8f,0x01,0x8d,0x08,0x89,0x01,0x7c,0x08,0x83,0x01,0x6b,0x08,0x7d,0x01,0x5a,0x08,0x77,0x01,0x49,0x08,0x71,0x01,  \
    0x38,0x08,0x6b,0x01,0x27,0x08,0x65,0x01,0x16,0x08,0x5f,0x01,0x05,0x08,0x59,0x01,0xf4,0x07,0x54,0x01,0xe3,0x07,0x4e,0x01,0xd3,0x07,0x48,0x01,0xc2,0x07,0x42,0x01,0xb1,0x07,0x3d,0x01,0xa1,0x07,0x37,0x01,0x90,0x07,0x32,0x01,0x7f,0x07,0x2c,0x01,0x6f,0x07,0x27,0x01,0x5e,0x07,0x21,0x01,0x4e,0x07,0x1c,0x01,0x3d,0x07,0x17,0x01,0x2d,0x07,0x11,0x01,0x1c,0x07,0x0c,0x01,0x0c,0x07,0x07,0x01,0xfb,0x06,0x02,0x01,0xeb,0x06,0xfd,0x00,0xdb,0x06,0xf7,0x00,0xca,0x06,  \
    0xf2,0x00,0xba,0x06,0xed,0x00,0xaa,0x06,0xe8,0x00,0x9a,0x06,0xe3,0x00,0x8a,0x06,0xdf,0x00,0x7a,0x06,0xda,0x00,0x6a,0x06,0xd5,0x00,0x5a,0x06,0xd0,0x00,0x4a,0x06,0xcb,0x00,0x3a,0x06,0xc7,0x00,0x2a,0x06,0xc2,0x00,0x1a,0x06,0xbe,0x00,0x09,0x06,0xb9,0x00,0xf8,0x05,0xb5,0x00,0xe8,0x05,0xb1,0x00,0xd7,0x05,0xad,0x00,0xc6,0x05,0xa9,0x00,0xb6,0x05,0xa4,0x00,0xa5,0x05,0xa0,0x00,0x95,0x05,0x9c,0x00,0x84,0x05,0x98,0x00,0x74,0x05,0x94,0x00,0x64,0x05,0x90,0x00,  \
    0x53,0x05,0x8c,0x00,0x43,0x05,0x88,0x00,0x33,0x05,0x85,0x00,0x22,0x05,0x81,0x00,0x12,0x05,0x7d,0x00,0x02,0x05,0x79,0x00,0xf2,0x04,0x76,0x00,0xe2,0x04,0x72,0x00,0xd2,0x04,0x6e,0x00,0xc1,0x04,0x6b,0x00,0xb1,0x04,0x67,0x00,0xa1,0x04,0x64,0x00,0x91,0x04,0x60,0x00,0x82,0x04,0x5d,0x00,0x73,0x04,0x59,0x00,0x63,0x04,0x56,0x00,0x54,0x04,0x52,0x00,0x45,0x04,0x4f,0x00,0x35,0x04,0x4c,0x00,0x26,0x04,0x48,0x00,0x17,0x04,0x45,0x00,0x07,0x04,0x42,0x00,0xf8,0x03,  \
    0x3f,0x00,0xe9,0x03,0x3c,0x00,0xda,0x03,0x39,0x00,0xcb,0x03,0x36,0x00,0xbb,0x03,0x33,0x00,0xac,0x03,0x30,0x00,0x9d,0x03,0x2d,0x00,0x8e,0x03,0x2a,0x00,0x7f,0x03,0x27,0x00,0x70,0x03,0x24,0x00,0x61,0x03,0x22,0x00,0x51,0x03,0x1f,0x00,0x42,0x03,0x1c,0x00,0x33,0x03,0x1a,0x00,0x24,0x03,0x17,0x00,0x15,0x03,0x15,0x00,0x06,0x03,0x12,0x00,0xf8,0x02,0x10,0x00,0xe9,0x02,0x0d,0x00,0xdb,0x02,0x0b,0x00,0xcc,0x02,0x09,0x00,0xbd,0x02,0x06,0x00,0xaf,0x02,0x04,0x00,  \
    0xa0,0x02,0x02,0x00,0x92,0x02,0x00,0x00,0x83,0x02,0xfe,0xff,0x75,0x02,0xfc,0xff,0x66,0x02,0xfa,0xff,0x57,0x02,0xf8,0xff,0x49,0x02,0xf6,0xff,0x3a,0x02,0xf4,0xff,0x2b,0x02,0xf2,0xff,0x1d,0x02,0xf1,0xff,0x0e,0x02,0xef,0xff,0x00,0x02,0xed,0xff,0xf1,0x01,0xec,0xff,0xe2,0x01,0xea,0xff,0xd3,0x01,0xe9,0xff,0xc5,0x01,0xe7,0xff,0xb6,0x01,0xe6,0xff,0xa7,0x01,0xe4,0xff,0x99,0x01,0xe3,0xff,0x8a,0x01,0xe2,0xff,0x7b,0x01,0xe1,0xff,0x6c,0x01,0xdf,0xff,0x5d,0x01,  \
    0xde,0xff,0x4e,0x01,0xdd,0xff,0x3f,0x01,0xdc,0xff,0x30,0x01,0xdb,0xff,0x21,0x01,0xda,0xff,0x12,0x01,0xd9,0xff,0x02,0x01,0xd8,0xff,0xf3,0x00,0xd7,0xff,0xe4,0x00,0xd7,0xff,0xd5,0x00,0xd6,0xff,0xc6,0x00,0xd5,0xff,0xb7,0x00,0xd5,0xff,0xa8,0x00,0xd4,0xff,0x99,0x00,0xd3,0xff,0x8a,0x00,0xd3,0xff,0x7b,0x00,0xd2,0xff,0x6c,0x00,0xd2,0xff,0x5d,0x00,0xd1,0xff,0x4e,0x00,0xd1,0xff,0x3f,0x00,0xd1,0xff,0x30,0x00,0xd0,0xff,0x21,0x00,0xd0,0xff,0x12,0x00,0xd0,0xff,  \
    0x03,0x00,0xd0,0xff,0xf4,0xff,0xd0,0xff,0xe5,0xff,0xd0,0xff,0xd6,0xff,0xd0,0xff,0xc7,0xff,0xd0,0xff,0xb8,0xff,0xd0,0xff,0xa9,0xff,0xd0,0xff,0x9a,0xff,0xd0,0xff,0x8b,0xff,0xd0,0xff,0x7c,0xff,0xd0,0xff,0x6d,0xff,0xd0,0xff,0x5e,0xff,0xd1,0xff,0x4f,0xff,0xd1,0xff,0x40,0xff,0xd2,0xff,0x31,0xff,0xd2,0xff,0x22,0xff,0xd2,0xff,0x13,0xff,0xd3,0xff,0x04,0xff,0xd3,0xff,0xf5,0xfe,0xd4,0xff,0xe6,0xfe,0xd5,0xff,0xd7,0xfe,0xd5,0xff,0xc8,0xfe,0xd6,0xff,0xb9,0xfe,  \
    0xd7,0xff,0xa9,0xfe,0xd8,0xff,0x9a,0xfe,0xd8,0xff,0x8b,0xfe,0xd9,0xff,0x7c,0xfe,0xda,0xff,0x6d,0xfe,0xdb,0xff,0x5e,0xfe,0xdc,0xff,0x4f,0xfe,0xdd,0xff,0x40,0xfe,0xde,0xff,0x31,0xfe,0xdf,0xff,0x22,0xfe,0xe1,0xff,0x13,0xfe,0xe2,0xff,0x04,0xfe,0xe3,0xff,0xf5,0xfd,0xe4,0xff,0xe5,0xfd,0xe6,0xff,0xd6,0xfd,0xe7,0xff,0xc7,0xfd,0xe8,0xff,0xb8,0xfd,0xea,0xff,0xa8,0xfd,0xeb,0xff,0x99,0xfd,0xed,0xff,0x8a,0xfd,0xee,0xff,0x7a,0xfd,0xf0,0xff,0x6b,0xfd,0xf2,0xff,  \
    0x5c,0xfd,0xf3,0xff,0x4c,0xfd,0xf5,0xff,0x3d,0xfd,0xf7,0xff,0x2d,0xfd,0xf8,0xff,0x1e,0xfd,0xfa,0xff,0x0f,0xfd,0xfc,0xff,0xff,0xfc,0xfe,0xff,0xf0,0xfc,0x00,0x00,0xe0,0xfc,0x02,0x00,0xd1,0xfc,0x04,0x00,0xc1,0xfc,0x06,0x00,0xb2,0xfc,0x08,0x00,0xa2,0xfc,0x0a,0x00,0x93,0xfc,0x0d,0x00,0x83,0xfc,0x0f,0x00,0x74,0xfc,0x11,0x00,0x65,0xfc,0x14,0x00,0x56,0xfc,0x16,0x00,0x47,0xfc,0x18,0x00,0x37,0xfc,0x1b,0x00,0x28,0xfc,0x1e,0x00,0x19,0xfc,0x20,0x00,0x0a,0xfc,  \
    0x23,0x00,0xfb,0xfb,0x25,0x00,0xec,0xfb,0x28,0x00,0xdc,0xfb,0x2b,0x00,0xcd,0xfb,0x2e,0x00,0xbe,0xfb,0x31,0x00,0xaf,0xfb,0x33,0x00,0xa0,0xfb,0x36,0x00,0x90,0xfb,0x39,0x00,0x81,0xfb,0x3c,0x00,0x72,0xfb,0x40,0x00,0x63,0xfb,0x43,0x00,0x53,0xfb,0x46,0x00,0x44,0xfb,0x49,0x00,0x35,0xfb,0x4c,0x00,0x26,0xfb,0x50,0x00,0x16,0xfb,0x53,0x00,0x07,0xfb,0x56,0x00,0xf8,0xfa,0x5a,0x00,0xe8,0xfa,0x5d,0x00,0xd8,0xfa,0x60,0x00,0xc9,0xfa,0x64,0x00,0xb9,0xfa,0x67,0x00,  \
    0xa9,0xfa,0x6b,0x00,0x99,0xfa,0x6f,0x00,0x89,0xfa,0x72,0x00,0x79,0xfa,0x76,0x00,0x6a,0xfa,0x7a,0x00,0x5a,0xfa,0x7d,0x00,0x4a,0xfa,0x81,0x00,0x3a,0xfa,0x85,0x00,0x2a,0xfa,0x89,0x00,0x1a,0xfa,0x8d,0x00,0x0a,0xfa,0x91,0x00,0xfa,0xf9,0x95,0x00,0xea,0xf9,0x99,0x00,0xd9,0xf9,0x9d,0x00,0xc9,0xf9,0xa1,0x00,0xb9,0xf9,0xa5,0x00,0xa9,0xf9,0xa9,0x00,0x99,0xf9,0xad,0x00,0x89,0xf9,0xb2,0x00,0x78,0xf9,0xb6,0x00,0x68,0xf9,0xba,0x00,0x58,0xf9,0xbf,0x00,0x48,0xf9,  \
    0xc3,0x00,0x38,0xf9,0xc8,0x00,0x27,0xf9,0xcc,0x00,0x17,0xf9,0xd1,0x00,0x07,0xf9,0xd5,0x00,0xf7,0xf8,0xda,0x00,0xe7,0xf8,0xdf,0x00,0xd6,0xf8,0xe4,0x00,0xc6,0xf8,0xe8,0x00,0xb6,0xf8,0xed,0x00,0xa5,0xf8,0xf2,0x00,0x95,0xf8,0xf7,0x00,0x84,0xf8,0xfc,0x00,0x74,0xf8,0x01,0x01,0x63,0xf8,0x06,0x01,0x53,0xf8,0x0b,0x01,0x42,0xf8,0x10,0x01,0x31,0xf8,0x15,0x01,0x21,0xf8,0x1b,0x01,0x10,0xf8,0x20,0x01,0xff,0xf7,0x25,0x01,0xee,0xf7,0x2a,0x01,0xdd,0xf7,0x2f,0x01,  \
    0xcc,0xf7,0x35,0x01,0xbb,0xf7,0x3a,0x01,0xa9,0xf7,0x3f,0x01,0x98,0xf7,0x44,0x01,0x86,0xf7,0x4a,0x01,0x75,0xf7,0x4f,0x01,0x63,0xf7,0x55,0x01,0x52,0xf7,0x5a,0x01,0x40,0xf7,0x5f,0x01,0x2f,0xf7,0x65,0x01,0x1d,0xf7,0x6a,0x01,0x0b,0xf7,0x70,0x01,0xf9,0xf6,0x76,0x01,0xe7,0xf6,0x7b,0x01,0xd5,0xf6,0x81,0x01,0xc3,0xf6,0x86,0x01,0xb1,0xf6,0x8c,0x01,0x9f,0xf6,0x92,0x01,0x8d,0xf6,0x98,0x01,0x7b,0xf6,0x9d,0x01,0x69,0xf6,0xa3,0x01,0x57,0xf6,0xa9,0x01,0x44,0xf6,  \
    0xaf,0x01,0x32,0xf6,0xb5,0x01,0x20,0xf6,0xbb,0x01,0x0e,0xf6,0xc1,0x01,0xfb,0xf5,0xc7,0x01,0xe9,0xf5,0xcd,0x01,0xd6,0xf5,0xd3,0x01,0xc4,0xf5,0xd9,0x01,0xb1,0xf5,0xdf,0x01,0x9e,0xf5,0xe5,0x01,0x8b,0xf5,0xeb,0x01,0x78,0xf5,0xf1,0x01,0x65,0xf5,0xf8,0x01,0x52,0xf5,0xfe,0x01,0x3f,0xf5,0x04,0x02,0x2c,0xf5,0x0a,0x02,0x19,0xf5,0x10,0x02,0x05,0xf5,0x16,0x02,0xf1,0xf4,0x1c,0x02,0xdd,0xf4,0x22,0x02,0xc8,0xf4,0x27,0x02,0xb4,0xf4,0x2d,0x02,0x9f,0xf4,0x33,0x02,  \
    0x8b,0xf4,0x39,0x02,0x76,0xf4,0x3e,0x02,0x61,0xf4,0x44,0x02,0x4c,0xf4,0x4a,0x02,0x37,0xf4,0x50,0x02,0x22,0xf4,0x56,0x02,0x0d,0xf4,0x5b,0x02,0xf8,0xf3,0x61,0x02,0xe2,0xf3,0x67,0x02,0xcd,0xf3,0x6c,0x02,0xb7,0xf3,0x72,0x02,0xa2,0xf3,0x78,0x02,0x8c,0xf3,0x7e,0x02,0x77,0xf3,0x84,0x02,0x61,0xf3,0x8a,0x02,0x4c,0xf3,0x90,0x02,0x37,0xf3,0x96,0x02,0x21,0xf3,0x9c,0x02,0x0c,0xf3,0xa2,0x02,0xf6,0xf2,0xa8,0x02,0xe0,0xf2,0xae,0x02,0xca,0xf2,0xb4,0x02,0xb4,0xf2,  \
    0xb9,0x02,0x9e,0xf2,0xbf,0x02,0x88,0xf2,0xc5,0x02,0x71,0xf2,0xcb,0x02,0x5b,0xf2,0xd0,0x02,0x44,0xf2,0xd6,0x02,0x2d,0xf2,0xdc,0x02,0x17,0xf2,0xe1,0x02,0x00,0xf2,0xe7,0x02,0xe8,0xf1,0xec,0x02,0xd1,0xf1,0xf2,0x02,0xba,0xf1,0xf7,0x02,0xa3,0xf1,0xfd,0x02,0x8b,0xf1,0x02,0x03,0x73,0xf1,0x08,0x03,0x5c,0xf1,0x0d,0x03,0x44,0xf1,0x12,0x03,0x2c,0xf1,0x17,0x03,0x13,0xf1,0x1c,0x03,0xfb,0xf0,0x21,0x03,0xe3,0xf0,0x26,0x03,0xca,0xf0,0x2b,0x03,0xb1,0xf0,0x30,0x03,  \
    0x98,0xf0,0x34,0x03,0x7f,0xf0,0x39,0x03,0x66,0xf0,0x3d,0x03,0x4c,0xf0,0x42,0x03,0x33,0xf0,0x46,0x03,0x19,0xf0,0x4a,0x03,0xff,0xef,0x4f,0x03,0xe5,0xef,0x52,0x03,0xcb,0xef,0x56,0x03,0xb0,0xef,0x5a,0x03,0x95,0xef,0x5d,0x03,0x7a,0xef,0x61,0x03,0x5f,0xef,0x64,0x03,0x44,0xef,0x67,0x03,0x28,0xef,0x6b,0x03,0x0d,0xef,0x6e,0x03,0xf1,0xee,0x71,0x03,0xd5,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa6,0x03,0x0c,0x11,0xa3,0x03,0xf0,0x10,0xa0,0x03,0xd4,0x10,0x9c,0x03,0xb8,0x10,0x99,0x03,0x9c,0x10,0x95,0x03,0x81,0x10,0x92,0x03,0x66,0x10,0x8e,0x03,0x4b,0x10,0x8a,0x03,0x30,0x10,0x87,0x03,0x15,0x10,0x83,0x03,0xfa,0x0f,0x7f,0x03,0xdf,0x0f,0x7b,0x03,  \
    0xc5,0x0f,0x76,0x03,0xaa,0x0f,0x72,0x03,0x90,0x0f,0x6e,0x03,0x76,0x0f,0x69,0x03,0x5c,0x0f,0x65,0x03,0x42,0x0f,0x60,0x03,0x29,0x0f,0x5c,0x03,0x0f,0x0f,0x57,0x03,0xf6,0x0e,0x52,0x03,0xdd,0x0e,0x4d,0x03,0xc4,0x0e,0x48,0x03,0xab,0x0e,0x43,0x03,0x92,0x0e,0x3e,0x03,0x7a,0x0e,0x38,0x03,0x61,0x0e,0x33,0x03,0x49,0x0e,0x2d,0x03,0x31,0x0e,0x28,0x03,0x19,0x0e,0x22,0x03,0x01,0x0e,0x1d,0x03,0xe9,0x0d,0x17,0x03,0xd2,0x0d,0x12,0x03,0xba,0x0d,0x0c,0x03,0xa3,0x0d,  \
    0x06,0x03,0x8c,0x0d,0x00,0x03,0x74,0x0d,0xfa,0x02,0x5d,0x0d,0xf5,0x02,0x46,0x0d,0xef,0x02,0x30,0x0d,0xe9,0x02,0x19,0x0d,0xe2,0x02,0x03,0x0d,0xdc,0x02,0xed,0x0c,0xd6,0x02,0xd7,0x0c,0xcf,0x02,0xc2,0x0c,0xc9,0x02,0xac,0x0c,0xc2,0x02,0x96,0x0c,0xbc,0x02,0x81,0x0c,0xb5,0x02,0x6c,0x0c,0xaf,0x02,0x57,0x0c,0xa8,0x02,0x42,0x0c,0xa2,0x02,0x2d,0x0c,0x9b,0x02,0x18,0x0c,0x95,0x02,0x03,0x0c,0x8e,0x02,0xef,0x0b,0x87,0x02,0xda,0x0b,0x81,0x02,0xc6,0x0b,0x7a,0x02,  \
    0xb1,0x0b,0x74,0x02,0x9c,0x0b,0x6e,0x02,0x86,0x0b,0x68,0x02,0x71,0x0b,0x62,0x02,0x5c,0x0b,0x5c,0x02,0x47,0x0b,0x56,0x02,0x32,0x0b,0x51,0x02,0x1d,0x0b,0x4b,0x02,0x08,0x0b,0x45,0x02,0xf3,0x0a,0x3f,0x02,0xde,0x0a,0x39,0x02,0xca,0x0a,0x33,0x02,0xb5,0x0a,0x2d,0x02,0xa0,0x0a,0x27,0x02,0x8c,0x0a,0x21,0x02,0x78,0x0a,0x1b,0x02,0x63,0x0a,0x15,0x02,0x4f,0x0a,0x0f,0x02,0x3b,0x0a,0x09,0x02,0x27,0x0a,0x03,0x02,0x13,0x0a,0xfd,0x01,0xff,0x09,0xf8,0x01,0xeb,0x09,  \
    0xf2,0x01,0xd7,0x09,0xec,0x01,0xc4,0x09,0xe6,0x01,0xb0,0x09,0xe0,0x01,0x9c,0x09,0xda,0x01,0x89,0x09,0xd5,0x01,0x75,0x09,0xcf,0x01,0x62,0x09,0xc9,0x01,0x4f,0x09,0xc3,0x01,0x3b,0x09,0xbd,0x01,0x28,0x09,0xb8,0x01,0x15,0x09,0xb2,0x01,0x02,0x09,0xac,0x01,0xef,0x08,0xa7,0x01,0xdc,0x08,0xa0,0x01,0xcb,0x08,0x9a,0x01,0xb9,0x08,0x94,0x01,0xa8,0x08,0x8e,0x01,0x96,0x08,0x88,0x01,0x85,0x08,0x82,0x01,0x74,0x08,0x7c,0x01,0x62,0x08,0x76,0x01,0x51,0x08,0x70,0x01,  \
    0x40,0x08,0x6a,0x01,0x2f,0x08,0x64,0x01,0x1e,0x08,0x5e,0x01,0x0d,0x08,0x58,0x01,0xfc,0x07,0x52,0x01,0xeb,0x07,0x4c,0x01,0xdb,0x07,0x47,0x01,0xca,0x07,0x41,0x01,0xb9,0x07,0x3b,0x01,0xa9,0x07,0x36,0x01,0x98,0x07,0x30,0x01,0x87,0x07,0x2b,0x01,0x77,0x07,0x25,0x01,0x66,0x07,0x20,0x01,0x56,0x07,0x1a,0x01,0x45,0x07,0x15,0x01,0x35,0x07,0x10,0x01,0x24,0x07,0x0a,0x01,0x14,0x07,0x05,0x01,0x03,0x07,0x00,0x01,0xf3,0x06,0xfb,0x00,0xe3,0x06,0xf6,0x00,0xd2,0x06,  \
    0xf1,0x00,0xc2,0x06,0xec,0x00,0xb2,0x06,0xe7,0x00,0xa2,0x06,0xe2,0x00,0x91,0x06,0xdd,0x00,0x81,0x06,0xd8,0x00,0x71,0x06,0xd3,0x00,0x61,0x06,0xce,0x00,0x51,0x06,0xca,0x00,0x41,0x06,0xc5,0x00,0x31,0x06,0xc0,0x00,0x21,0x06,0xbc,0x00,0x12,0x06,0xb7,0x00,0x01,0x06,0xb3,0x00,0xf0,0x05,0xaf,0x00,0xe0,0x05,0xaa,0x00,0xcf,0x05,0xa6,0x00,0xbf,0x05,0xa2,0x00,0xae,0x05,0x9e,0x00,0x9e,0x05,0x9a,0x00,0x8d,0x05,0x96,0x00,0x7d,0x05,0x92,0x00,0x6c,0x05,0x8e,0x00,  \
    0x5c,0x05,0x8a,0x00,0x4c,0x05,0x86,0x00,0x3c,0x05,0x82,0x00,0x2b,0x05,0x7e,0x00,0x1b,0x05,0x7a,0x00,0x0b,0x05,0x77,0x00,0xfb,0x04,0x73,0x00,0xeb,0x04,0x6f,0x00,0xdb,0x04,0x6c,0x00,0xcb,0x04,0x68,0x00,0xbb,0x04,0x64,0x00,0xab,0x04,0x61,0x00,0x9b,0x04,0x5d,0x00,0x8b,0x04,0x5a,0x00,0x7c,0x04,0x56,0x00,0x6c,0x04,0x53,0x00,0x5d,0x04,0x4f,0x00,0x4e,0x04,0x4c,0x00,0x3e,0x04,0x49,0x00,0x2f,0x04,0x45,0x00,0x20,0x04,0x42,0x00,0x11,0x04,0x3f,0x00,0x01,0x04,  \
    0x3c,0x00,0xf2,0x03,0x38,0x00,0xe3,0x03,0x35,0x00,0xd4,0x03,0x32,0x00,0xc5,0x03,0x2f,0x00,0xb6,0x03,0x2c,0x00,0xa7,0x03,0x29,0x00,0x97,0x03,0x27,0x00,0x88,0x03,0x24,0x00,0x79,0x03,0x21,0x00,0x6a,0x03,0x1e,0x00,0x5b,0x03,0x1b,0x00,0x4c,0x03,0x19,0x00,0x3d,0x03,0x16,0x00,0x2e,0x03,0x14,0x00,0x1f,0x03,0x11,0x00,0x10,0x03,0x0f,0x00,0x01,0x03,0x0c,0x00,0xf3,0x02,0x0a,0x00,0xe4,0x02,0x07,0x00,0xd6,0x02,0x05,0x00,0xc7,0x02,0x03,0x00,0xb9,0x02,0x00,0x00,  \
    0xaa,0x02,0xfe,0xff,0x9c,0x02,0xfc,0xff,0x8d,0x02,0xfa,0xff,0x7f,0x02,0xf8,0xff,0x70,0x02,0xf6,0xff,0x62,0x02,0xf4,0xff,0x53,0x02,0xf2,0xff,0x45,0x02,0xf0,0xff,0x36,0x02,0xee,0xff,0x28,0x02,0xec,0xff,0x19,0x02,0xeb,0xff,0x0b,0x02,0xe9,0xff,0xfc,0x01,0xe7,0xff,0xed,0x01,0xe6,0xff,0xdf,0x01,0xe4,0xff,0xd0,0x01,0xe3,0xff,0xc2,0x01,0xe1,0xff,0xb3,0x01,0xe0,0xff,0xa4,0x01,0xde,0xff,0x96,0x01,0xdd,0xff,0x87,0x01,0xdc,0xff,0x78,0x01,0xda,0xff,0x69,0x01,  \
    0xd9,0xff,0x5a,0x01,0xd8,0xff,0x4b,0x01,0xd7,0xff,0x3c,0x01,0xd6,0xff,0x2d,0x01,0xd5,0xff,0x1e,0x01,0xd4,0xff,0x0f,0x01,0xd3,0xff,0x00,0x01,0xd2,0xff,0xf1,0x00,0xd1,0xff,0xe2,0x00,0xd1,0xff,0xd4,0x00,0xd0,0xff,0xc5,0x00,0xcf,0xff,0xb6,0x00,0xce,0xff,0xa7,0x00,0xce,0xff,0x98,0x00,0xcd,0xff,0x89,0x00,0xcd,0xff,0x7a,0x00,0xcc,0xff,0x6b,0x00,0xcc,0xff,0x5c,0x00,0xcb,0xff,0x4d,0x00,0xcb,0xff,0x3e,0x00,0xcb,0xff,0x2f,0x00,0xca,0xff,0x20,0x00,0xca,0xff,  \
    0x11,0x00,0xca,0xff,0x02,0x00,0xca,0xff,0xf4,0xff,0xca,0xff,0xe5,0xff,0xca,0xff,0xd6,0xff,0xc9,0xff,0xc7,0xff,0xca,0xff,0xb8,0xff,0xca,0xff,0xa9,0xff,0xca,0xff,0x9a,0xff,0xca,0xff,0x8b,0xff,0xca,0xff,0x7c,0xff,0xca,0xff,0x6d,0xff,0xca,0xff,0x5e,0xff,0xcb,0xff,0x4f,0xff,0xcb,0xff,0x41,0xff,0xcb,0xff,0x32,0xff,0xcc,0xff,0x23,0xff,0xcc,0xff,0x14,0xff,0xcd,0xff,0x05,0xff,0xcd,0xff,0xf6,0xfe,0xce,0xff,0xe7,0xfe,0xcf,0xff,0xd8,0xfe,0xcf,0xff,0xc9,0xfe,  \
    0xd0,0xff,0xba,0xfe,0xd1,0xff,0xab,0xfe,0xd1,0xff,0x9c,0xfe,0xd2,0xff,0x8d,0xfe,0xd3,0xff,0x7f,0xfe,0xd4,0xff,0x70,0xfe,0xd5,0xff,0x61,0xfe,0xd6,0xff,0x52,0xfe,0xd7,0xff,0x43,0xfe,0xd8,0xff,0x34,0xfe,0xd9,0xff,0x25,0xfe,0xda,0xff,0x16,0xfe,0xdc,0xff,0x07,0xfe,0xdd,0xff,0xf8,0xfd,0xde,0xff,0xe8,0xfd,0xe0,0xff,0xd9,0xfd,0xe1,0xff,0xca,0xfd,0xe2,0xff,0xbb,0xfd,0xe4,0xff,0xac,0xfd,0xe5,0xff,0x9d,0xfd,0xe7,0xff,0x8d,0xfd,0xe8,0xff,0x7e,0xfd,0xea,0xff,  \
    0x6f,0xfd,0xec,0xff,0x60,0xfd,0xed,0xff,0x50,0xfd,0xef,0xff,0x41,0xfd,0xf1,0xff,0x32,0xfd,0xf2,0xff,0x22,0xfd,0xf4,0xff,0x13,0xfd,0xf6,0xff,0x04,0xfd,0xf8,0xff,0xf4,0xfc,0xfa,0xff,0xe5,0xfc,0xfc,0xff,0xd6,0xfc,0xfe,0xff,0xc6,0xfc,0x00,0x00,0xb7,0xfc,0x02,0x00,0xa7,0xfc,0x04,0x00,0x98,0xfc,0x07,0x00,0x89,0xfc,0x09,0x00,0x79,0xfc,0x0b,0x00,0x6a,0xfc,0x0e,0x00,0x5b,0xfc,0x10,0x00,0x4c,0xfc,0x13,0x00,0x3d,0xfc,0x15,0x00,0x2e,0xfc,0x18,0x00,0x1f,0xfc,  \
    0x1a,0x00,0x10,0xfc,0x1d,0x00,0x01,0xfc,0x1f,0x00,0xf2,0xfb,0x22,0x00,0xe3,0xfb,0x25,0x00,0xd3,0xfb,0x28,0x00,0xc4,0xfb,0x2b,0x00,0xb5,0xfb,0x2e,0x00,0xa6,0xfb,0x30,0x00,0x97,0xfb,0x33,0x00,0x88,0xfb,0x37,0x00,0x79,0xfb,0x3a,0x00,0x69,0xfb,0x3d,0x00,0x5a,0xfb,0x40,0x00,0x4b,0xfb,0x43,0x00,0x3c,0xfb,0x46,0x00,0x2d,0xfb,0x4a,0x00,0x1d,0xfb,0x4d,0x00,0x0e,0xfb,0x50,0x00,0xff,0xfa,0x54,0x00,0xf0,0xfa,0x57,0x00,0xe0,0xfa,0x5b,0x00,0xd0,0xfa,0x5e,0x00,  \
    0xc0,0xfa,0x61,0x00,0xb1,0xfa,0x65,0x00,0xa1,0xfa,0x69,0x00,0x91,0xfa,0x6c,0x00,0x81,0xfa,0x70,0x00,0x71,0xfa,0x74,0x00,0x62,0xfa,0x77,0x00,0x52,0xfa,0x7b,0x00,0x42,0xfa,0x7f,0x00,0x32,0xfa,0x83,0x00,0x22,0xfa,0x87,0x00,0x12,0xfa,0x8b,0x00,0x02,0xfa,0x8f,0x00,0xf2,0xf9,0x93,0x00,0xe2,0xf9,0x97,0x00,0xd2,0xf9,0x9b,0x00,0xc2,0xf9,0x9f,0x00,0xb2,0xf9,0xa3,0x00,0xa1,0xf9,0xa7,0x00,0x91,0xf9,0xac,0x00,0x81,0xf9,0xb0,0x00,0x71,0xf9,0xb4,0x00,0x61,0xf9,  \
    0xb9,0x00,0x51,0xf9,0xbd,0x00,0x41,0xf9,0xc2,0x00,0x30,0xf9,0xc6,0x00,0x20,0xf9,0xcb,0x00,0x10,0xf9,0xd0,0x00,0x00,0xf9,0xd4,0x00,0xf0,0xf8,0xd9,0x00,0xdf,0xf8,0xde,0x00,0xcf,0xf8,0xe2,0x00,0xbf,0xf8,0xe7,0x00,0xae,0xf8,0xec,0x00,0x9e,0xf8,0xf1,0x00,0x8e,0xf8,0xf6,0x00,0x7d,0xf8,0xfb,0x00,0x6d,0xf8,0x00,0x01,0x5c,0xf8,0x05,0x01,0x4c,0xf8,0x0a,0x01,0x3b,0xf8,0x0f,0x01,0x2a,0xf8,0x14,0x01,0x1a,0xf8,0x1a,0x01,0x09,0xf8,0x1f,0x01,0xf8,0xf7,0x24,0x01,  \
    0xe7,0xf7,0x29,0x01,0xd6,0xf7,0x2e,0x01,0xc4,0xf7,0x34,0x01,0xb3,0xf7,0x39,0x01,0xa2,0xf7,0x3e,0x01,0x90,0xf7,0x44,0x01,0x7f,0xf7,0x49,0x01,0x6d,0xf7,0x4e,0x01,0x5c,0xf7,0x54,0x01,0x4a,0xf7,0x59,0x01,0x39,0xf7,0x5f,0x01,0x27,0xf7,0x64,0x01,0x15,0xf7,0x6a,0x01,0x03,0xf7,0x6f,0x01,0xf1,0xf6,0x75,0x01,0xe0,0xf6,0x7b,0x01,0xce,0xf6,0x80,0x01,0xbc,0xf6,0x86,0x01,0xa9,0xf6,0x8c,0x01,0x97,0xf6,0x91,0x01,0x85,0xf6,0x97,0x01,0x73,0xf6,0x9d,0x01,0x61,0xf6,  \
    0xa3,0x01,0x4f,0xf6,0xa9,0x01,0x3c,0xf6,0xaf,0x01,0x2a,0xf6,0xb5,0x01,0x18,0xf6,0xba,0x01,0x05,0xf6,0xc0,0x01,0xf3,0xf5,0xc6,0x01,0xe0,0xf5,0xcd,0x01,0xce,0xf5,0xd3,0x01,0xbb,0xf5,0xd9,0x01,0xa8,0xf5,0xdf,0x01,0x96,0xf5,0xe5,0x01,0x83,0xf5,0xeb,0x01,0x70,0xf5,0xf1,0x01,0x5d,0xf5,0xf7,0x01,0x49,0xf5,0xfd,0x01,0x36,0xf5,0x03,0x02,0x23,0xf5,0x09,0x02,0x10,0xf5,0x0f,0x02,0xfb,0xf4,0x15,0x02,0xe7,0xf4,0x1b,0x02,0xd3,0xf4,0x21,0x02,0xbe,0xf4,0x26,0x02,  \
    0xaa,0xf4,0x2c,0x02,0x95,0xf4,0x32,0x02,0x80,0xf4,0x38,0x02,0x6b,0xf4,0x3d,0x02,0x56,0xf4,0x43,0x02,0x41,0xf4,0x49,0x02,0x2c,0xf4,0x4f,0x02,0x17,0xf4,0x54,0x02,0x02,0xf4,0x5a,0x02,0xed,0xf3,0x60,0x02,0xd7,0xf3,0x65,0x02,0xc2,0xf3,0x6b,0x02,0xac,0xf3,0x71,0x02,0x96,0xf3,0x77,0x02,0x81,0xf3,0x7d,0x02,0x6c,0xf3,0x83,0x02,0x56,0xf3,0x89,0x02,0x41,0xf3,0x8f,0x02,0x2b,0xf3,0x95,0x02,0x16,0xf3,0x9b,0x02,0x00,0xf3,0xa0,0x02,0xea,0xf2,0xa6,0x02,0xd4,0xf2,  \
    0xac,0x02,0xbe,0xf2,0xb2,0x02,0xa8,0xf2,0xb8,0x02,0x92,0xf2,0xbd,0x02,0x7b,0xf2,0xc3,0x02,0x65,0xf2,0xc9,0x02,0x4e,0xf2,0xcf,0x02,0x37,0xf2,0xd4,0x02,0x20,0xf2,0xda,0x02,0x09,0xf2,0xdf,0x02,0xf2,0xf1,0xe5,0x02,0xdb,0xf1,0xea,0x02,0xc4,0xf1,0xf0,0x02,0xac,0xf1,0xf5,0x02,0x95,0xf1,0xfa,0x02,0x7d,0xf1,0x00,0x03,0x65,0xf1,0x05,0x03,0x4d,0xf1,0x0a,0x03,0x35,0xf1,0x0f,0x03,0x1d,0xf1,0x14,0x03,0x04,0xf1,0x19,0x03,0xec,0xf0,0x1e,0x03,0xd3,0xf0,0x23,0x03,  \
    0xba,0xf0,0x27,0x03,0xa1,0xf0,0x2c,0x03,0x88,0xf0,0x30,0x03,0x6f,0xf0,0x35,0x03,0x56,0xf0,0x39,0x03,0x3c,0xf0,0x3e,0x03,0x22,0xf0,0x42,0x03,0x09,0xf0,0x46,0x03,0xee,0xef,0x4a,0x03,0xd4,0xef,0x4e,0x03,0xb9,0xef,0x51,0x03,0x9e,0xef,0x55,0x03,0x83,0xef,0x58,0x03,0x68,0xef,0x5b,0x03,0x4d,0xef,0x5f,0x03,0x31,0xef,0x62,0x03,0x16,0xef,0x65,0x03,0xfa,0xee,0x68,0x03,0xde,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x9a,0x03,0x05,0x11,0x97,0x03,0xe9,0x10,0x93,0x03,0xcd,0x10,0x90,0x03,0xb1,0x10,0x8d,0x03,0x96,0x10,0x89,0x03,0x7a,0x10,0x86,0x03,0x5f,0x10,0x82,0x03,0x44,0x10,0x7f,0x03,0x29,0x10,0x7b,0x03,0x0e,0x10,0x77,0x03,0xf3,0x0f,0x73,0x03,  \
    0xd8,0x0f,0x6f,0x03,0xbe,0x0f,0x6b,0x03,0xa3,0x0f,0x67,0x03,0x89,0x0f,0x62,0x03,0x6f,0x0f,0x5e,0x03,0x55,0x0f,0x59,0x03,0x3b,0x0f,0x55,0x03,0x21,0x0f,0x50,0x03,0x08,0x0f,0x4c,0x03,0xee,0x0e,0x47,0x03,0xd5,0x0e,0x42,0x03,0xbc,0x0e,0x3d,0x03,0xa4,0x0e,0x38,0x03,0x8b,0x0e,0x32,0x03,0x72,0x0e,0x2d,0x03,0x5a,0x0e,0x28,0x03,0x42,0x0e,0x23,0x03,0x29,0x0e,0x1d,0x03,0x11,0x0e,0x18,0x03,0xfa,0x0d,0x12,0x03,0xe2,0x0d,0x0d,0x03,0xca,0x0d,0x07,0x03,0xb3,0x0d,  \
    0x01,0x03,0x9b,0x0d,0xfc,0x02,0x84,0x0d,0xf6,0x02,0x6d,0x0d,0xf0,0x02,0x56,0x0d,0xea,0x02,0x3f,0x0d,0xe4,0x02,0x28,0x0d,0xde,0x02,0x11,0x0d,0xd8,0x02,0xfb,0x0c,0xd2,0x02,0xe5,0x0c,0xcc,0x02,0xcf,0x0c,0xc5,0x02,0xb9,0x0c,0xbf,0x02,0xa4,0x0c,0xb9,0x02,0x8e,0x0c,0xb2,0x02,0x79,0x0c,0xac,0x02,0x63,0x0c,0xa5,0x02,0x4e,0x0c,0x9f,0x02,0x39,0x0c,0x98,0x02,0x24,0x0c,0x92,0x02,0x0f,0x0c,0x8b,0x02,0xfb,0x0b,0x85,0x02,0xe6,0x0b,0x7e,0x02,0xd1,0x0b,0x78,0x02,  \
    0xbd,0x0b,0x71,0x02,0xa9,0x0b,0x6b,0x02,0x93,0x0b,0x65,0x02,0x7e,0x0b,0x60,0x02,0x68,0x0b,0x5a,0x02,0x53,0x0b,0x54,0x02,0x3e,0x0b,0x4e,0x02,0x29,0x0b,0x48,0x02,0x14,0x0b,0x42,0x02,0xff,0x0a,0x3c,0x02,0xea,0x0a,0x36,0x02,0xd5,0x0a,0x30,0x02,0xc1,0x0a,0x2a,0x02,0xac,0x0a,0x24,0x02,0x98,0x0a,0x1f,0x02,0x83,0x0a,0x19,0x02,0x6f,0x0a,0x13,0x02,0x5b,0x0a,0x0d,0x02,0x46,0x0a,0x07,0x02,0x32,0x0a,0x01,0x02,0x1e,0x0a,0xfb,0x01,0x0a,0x0a,0xf5,0x01,0xf6,0x09,  \
    0xf0,0x01,0xe2,0x09,0xea,0x01,0xcf,0x09,0xe4,0x01,0xbb,0x09,0xde,0x01,0xa7,0x09,0xd8,0x01,0x94,0x09,0xd2,0x01,0x80,0x09,0xcd,0x01,0x6d,0x09,0xc7,0x01,0x59,0x09,0xc1,0x01,0x46,0x09,0xbb,0x01,0x33,0x09,0xb6,0x01,0x20,0x09,0xb0,0x01,0x0c,0x09,0xaa,0x01,0xf9,0x08,0xa5,0x01,0xe6,0x08,0x9f,0x01,0xd4,0x08,0x99,0x01,0xc2,0x08,0x93,0x01,0xb1,0x08,0x8c,0x01,0x9f,0x08,0x86,0x01,0x8e,0x08,0x80,0x01,0x7c,0x08,0x7a,0x01,0x6b,0x08,0x74,0x01,0x5a,0x08,0x6e,0x01,  \
    0x49,0x08,0x68,0x01,0x37,0x08,0x63,0x01,0x26,0x08,0x5d,0x01,0x15,0x08,0x57,0x01,0x04,0x08,0x51,0x01,0xf4,0x07,0x4b,0x01,0xe3,0x07,0x45,0x01,0xd2,0x07,0x40,0x01,0xc1,0x07,0x3a,0x01,0xb1,0x07,0x34,0x01,0xa0,0x07,0x2f,0x01,0x8f,0x07,0x29,0x01,0x7f,0x07,0x24,0x01,0x6e,0x07,0x1e,0x01,0x5e,0x07,0x19,0x01,0x4d,0x07,0x14,0x01,0x3c,0x07,0x0e,0x01,0x2c,0x07,0x09,0x01,0x1c,0x07,0x04,0x01,0x0b,0x07,0xff,0x00,0xfb,0x06,0xf9,0x00,0xea,0x06,0xf4,0x00,0xda,0x06,  \
    0xef,0x00,0xca,0x06,0xea,0x00,0xba,0x06,0xe5,0x00,0xa9,0x06,0xe0,0x00,0x99,0x06,0xdb,0x00,0x89,0x06,0xd6,0x00,0x79,0x06,0xd2,0x00,0x69,0x06,0xcd,0x00,0x59,0x06,0xc8,0x00,0x49,0x06,0xc3,0x00,0x39,0x06,0xbf,0x00,0x29,0x06,0xba,0x00,0x19,0x06,0xb5,0x00,0x09,0x06,0xb1,0x00,0xf9,0x05,0xad,0x00,0xe8,0x05,0xa8,0x00,0xd8,0x05,0xa4,0x00,0xc7,0x05,0xa0,0x00,0xb7,0x05,0x9c,0x00,0xa6,0x05,0x98,0x00,0x96,0x05,0x94,0x00,0x86,0x05,0x90,0x00,0x75,0x05,0x8c,0x00,  \
    0x65,0x05,0x88,0x00,0x55,0x05,0x84,0x00,0x45,0x05,0x80,0x00,0x34,0x05,0x7c,0x00,0x24,0x05,0x78,0x00,0x14,0x05,0x74,0x00,0x04,0x05,0x71,0x00,0xf4,0x04,0x6d,0x00,0xe4,0x04,0x69,0x00,0xd4,0x04,0x66,0x00,0xc4,0x04,0x62,0x00,0xb4,0x04,0x5e,0x00,0xa4,0x04,0x5b,0x00,0x94,0x04,0x57,0x00,0x84,0x04,0x54,0x00,0x75,0x04,0x50,0x00,0x66,0x04,0x4d,0x00,0x57,0x04,0x49,0x00,0x47,0x04,0x46,0x00,0x38,0x04,0x43,0x00,0x29,0x04,0x3f,0x00,0x1a,0x04,0x3c,0x00,0x0b,0x04,  \
    0x39,0x00,0xfb,0x03,0x36,0x00,0xec,0x03,0x32,0x00,0xdd,0x03,0x2f,0x00,0xce,0x03,0x2c,0x00,0xbf,0x03,0x29,0x00,0xb0,0x03,0x26,0x00,0xa1,0x03,0x23,0x00,0x92,0x03,0x21,0x00,0x83,0x03,0x1e,0x00,0x74,0x03,0x1b,0x00,0x65,0x03,0x18,0x00,0x56,0x03,0x16,0x00,0x47,0x03,0x13,0x00,0x38,0x03,0x10,0x00,0x29,0x03,0x0e,0x00,0x1a,0x03,0x0b,0x00,0x0b,0x03,0x09,0x00,0xfd,0x02,0x06,0x00,0xee,0x02,0x04,0x00,0xe0,0x02,0x01,0x00,0xd1,0x02,0xff,0xff,0xc3,0x02,0xfd,0xff,  \
    0xb4,0x02,0xfa,0xff,0xa6,0x02,0xf8,0xff,0x98,0x02,0xf6,0xff,0x89,0x02,0xf4,0xff,0x7b,0x02,0xf2,0xff,0x6c,0x02,0xf0,0xff,0x5e,0x02,0xee,0xff,0x4f,0x02,0xec,0xff,0x41,0x02,0xea,0xff,0x32,0x02,0xe8,0xff,0x24,0x02,0xe6,0xff,0x15,0x02,0xe5,0xff,0x07,0x02,0xe3,0xff,0xf8,0x01,0xe1,0xff,0xea,0x01,0xe0,0xff,0xdb,0x01,0xde,0xff,0xcd,0x01,0xdd,0xff,0xbe,0x01,0xdb,0xff,0xb0,0x01,0xda,0xff,0xa1,0x01,0xd8,0xff,0x93,0x01,0xd7,0xff,0x84,0x01,0xd6,0xff,0x75,0x01,  \
    0xd5,0xff,0x66,0x01,0xd3,0xff,0x58,0x01,0xd2,0xff,0x49,0x01,0xd1,0xff,0x3a,0x01,0xd0,0xff,0x2b,0x01,0xcf,0xff,0x1c,0x01,0xce,0xff,0x0d,0x01,0xcd,0xff,0xfe,0x00,0xcc,0xff,0xef,0x00,0xcc,0xff,0xe1,0x00,0xcb,0xff,0xd2,0x00,0xca,0xff,0xc3,0x00,0xc9,0xff,0xb4,0x00,0xc9,0xff,0xa5,0x00,0xc8,0xff,0x96,0x00,0xc7,0xff,0x87,0x00,0xc7,0xff,0x79,0x00,0xc6,0xff,0x6a,0x00,0xc6,0xff,0x5b,0x00,0xc6,0xff,0x4c,0x00,0xc5,0xff,0x3d,0x00,0xc5,0xff,0x2e,0x00,0xc5,0xff,  \
    0x20,0x00,0xc4,0xff,0x11,0x00,0xc4,0xff,0x02,0x00,0xc4,0xff,0xf3,0xff,0xc4,0xff,0xe4,0xff,0xc4,0xff,0xd6,0xff,0xc4,0xff,0xc7,0xff,0xc4,0xff,0xb8,0xff,0xc4,0xff,0xa9,0xff,0xc4,0xff,0x9a,0xff,0xc4,0xff,0x8b,0xff,0xc4,0xff,0x7d,0xff,0xc4,0xff,0x6e,0xff,0xc5,0xff,0x5f,0xff,0xc5,0xff,0x50,0xff,0xc5,0xff,0x41,0xff,0xc6,0xff,0x33,0xff,0xc6,0xff,0x24,0xff,0xc7,0xff,0x15,0xff,0xc7,0xff,0x06,0xff,0xc8,0xff,0xf7,0xfe,0xc8,0xff,0xe8,0xfe,0xc9,0xff,0xda,0xfe,  \
    0xc9,0xff,0xcb,0xfe,0xca,0xff,0xbc,0xfe,0xcb,0xff,0xad,0xfe,0xcc,0xff,0x9e,0xfe,0xcd,0xff,0x8f,0xfe,0xcd,0xff,0x81,0xfe,0xce,0xff,0x72,0xfe,0xcf,0xff,0x63,0xfe,0xd0,0xff,0x54,0xfe,0xd1,0xff,0x45,0xfe,0xd2,0xff,0x36,0xfe,0xd4,0xff,0x28,0xfe,0xd5,0xff,0x19,0xfe,0xd6,0xff,0x0a,0xfe,0xd7,0xff,0xfa,0xfd,0xd8,0xff,0xeb,0xfd,0xda,0xff,0xdc,0xfd,0xdb,0xff,0xcd,0xfd,0xdd,0xff,0xbe,0xfd,0xde,0xff,0xaf,0xfd,0xdf,0xff,0xa0,0xfd,0xe1,0xff,0x91,0xfd,0xe3,0xff,  \
    0x82,0xfd,0xe4,0xff,0x73,0xfd,0xe6,0xff,0x64,0xfd,0xe7,0xff,0x54,0xfd,0xe9,0xff,0x45,0xfd,0xeb,0xff,0x36,0xfd,0xed,0xff,0x27,0xfd,0xef,0xff,0x18,0xfd,0xf0,0xff,0x08,0xfd,0xf2,0xff,0xf9,0xfc,0xf4,0xff,0xea,0xfc,0xf6,0xff,0xda,0xfc,0xf8,0xff,0xcb,0xfc,0xfa,0xff,0xbc,0xfc,0xfd,0xff,0xad,0xfc,0xff,0xff,0x9d,0xfc,0x01,0x00,0x8e,0xfc,0x03,0x00,0x7f,0xfc,0x06,0x00,0x70,0xfc,0x08,0x00,0x61,0xfc,0x0a,0x00,0x52,0xfc,0x0d,0x00,0x43,0xfc,0x0f,0x00,0x34,0xfc,  \
    0x12,0x00,0x25,0xfc,0x14,0x00,0x16,0xfc,0x17,0x00,0x07,0xfc,0x1a,0x00,0xf8,0xfb,0x1d,0x00,0xe9,0xfb,0x1f,0x00,0xda,0xfb,0x22,0x00,0xcb,0xfb,0x25,0x00,0xbc,0xfb,0x28,0x00,0xad,0xfb,0x2b,0x00,0x9d,0xfb,0x2e,0x00,0x8e,0xfb,0x31,0x00,0x7f,0xfb,0x34,0x00,0x70,0xfb,0x37,0x00,0x61,0xfb,0x3a,0x00,0x52,0xfb,0x3d,0x00,0x43,0xfb,0x41,0x00,0x34,0xfb,0x44,0x00,0x25,0xfb,0x47,0x00,0x15,0xfb,0x4b,0x00,0x06,0xfb,0x4e,0x00,0xf7,0xfa,0x51,0x00,0xe7,0xfa,0x55,0x00,  \
    0xd8,0xfa,0x58,0x00,0xc8,0xfa,0x5c,0x00,0xb8,0xfa,0x5f,0x00,0xa8,0xfa,0x63,0x00,0x99,0xfa,0x67,0x00,0x89,0xfa,0x6a,0x00,0x79,0xfa,0x6e,0x00,0x69,0xfa,0x72,0x00,0x5a,0xfa,0x75,0x00,0x4a,0xfa,0x79,0x00,0x3a,0xfa,0x7d,0x00,0x2a,0xfa,0x81,0x00,0x1a,0xfa,0x85,0x00,0x0a,0xfa,0x89,0x00,0xfa,0xf9,0x8d,0x00,0xea,0xf9,0x91,0x00,0xda,0xf9,0x95,0x00,0xca,0xf9,0x99,0x00,0xba,0xf9,0x9d,0x00,0xaa,0xf9,0xa2,0x00,0x9a,0xf9,0xa6,0x00,0x8a,0xf9,0xaa,0x00,0x7a,0xf9,  \
    0xaf,0x00,0x6a,0xf9,0xb3,0x00,0x5a,0xf9,0xb8,0x00,0x4a,0xf9,0xbc,0x00,0x39,0xf9,0xc1,0x00,0x29,0xf9,0xc5,0x00,0x19,0xf9,0xca,0x00,0x09,0xf9,0xce,0x00,0xf9,0xf8,0xd3,0x00,0xe9,0xf8,0xd8,0x00,0xd8,0xf8,0xdd,0x00,0xc8,0xf8,0xe2,0x00,0xb8,0xf8,0xe6,0x00,0xa7,0xf8,0xeb,0x00,0x97,0xf8,0xf0,0x00,0x87,0xf8,0xf5,0x00,0x76,0xf8,0xfa,0x00,0x66,0xf8,0xff,0x00,0x55,0xf8,0x04,0x01,0x44,0xf8,0x09,0x01,0x34,0xf8,0x0f,0x01,0x23,0xf8,0x14,0x01,0x12,0xf8,0x19,0x01,  \
    0x02,0xf8,0x1e,0x01,0xf1,0xf7,0x23,0x01,0xdf,0xf7,0x29,0x01,0xce,0xf7,0x2e,0x01,0xbd,0xf7,0x33,0x01,0xac,0xf7,0x38,0x01,0x9a,0xf7,0x3e,0x01,0x89,0xf7,0x43,0x01,0x77,0xf7,0x48,0x01,0x66,0xf7,0x4e,0x01,0x54,0xf7,0x53,0x01,0x43,0xf7,0x59,0x01,0x31,0xf7,0x5e,0x01,0x1f,0xf7,0x64,0x01,0x0d,0xf7,0x69,0x01,0xfb,0xf6,0x6f,0x01,0xea,0xf6,0x74,0x01,0xd8,0xf6,0x7a,0x01,0xc6,0xf6,0x80,0x01,0xb4,0xf6,0x85,0x01,0xa1,0xf6,0x8b,0x01,0x8f,0xf6,0x91,0x01,0x7d,0xf6,  \
    0x97,0x01,0x6b,0xf6,0x9d,0x01,0x59,0xf6,0xa2,0x01,0x47,0xf6,0xa8,0x01,0x34,0xf6,0xae,0x01,0x22,0xf6,0xb4,0x01,0x10,0xf6,0xba,0x01,0xfd,0xf5,0xc0,0x01,0xeb,0xf5,0xc6,0x01,0xd8,0xf5,0xcc,0x01,0xc5,0xf5,0xd2,0x01,0xb3,0xf5,0xd8,0x01,0xa0,0xf5,0xde,0x01,0x8d,0xf5,0xe4,0x01,0x7a,0xf5,0xea,0x01,0x67,0xf5,0xf0,0x01,0x54,0xf5,0xf7,0x01,0x40,0xf5,0xfd,0x01,0x2d,0xf5,0x03,0x02,0x1a,0xf5,0x09,0x02,0x05,0xf5,0x0e,0x02,0xf1,0xf4,0x14,0x02,0xdd,0xf4,0x1a,0x02,  \
    0xc8,0xf4,0x20,0x02,0xb4,0xf4,0x25,0x02,0x9f,0xf4,0x2b,0x02,0x8a,0xf4,0x31,0x02,0x76,0xf4,0x37,0x02,0x61,0xf4,0x3c,0x02,0x4c,0xf4,0x42,0x02,0x37,0xf4,0x48,0x02,0x21,0xf4,0x4d,0x02,0x0c,0xf4,0x53,0x02,0xf7,0xf3,0x59,0x02,0xe1,0xf3,0x5e,0x02,0xcc,0xf3,0x64,0x02,0xb6,0xf3,0x6a,0x02,0xa1,0xf3,0x70,0x02,0x8b,0xf3,0x76,0x02,0x76,0xf3,0x7c,0x02,0x60,0xf3,0x82,0x02,0x4b,0xf3,0x87,0x02,0x36,0xf3,0x8d,0x02,0x20,0xf3,0x93,0x02,0x0a,0xf3,0x99,0x02,0xf4,0xf2,  \
    0x9f,0x02,0xde,0xf2,0xa5,0x02,0xc8,0xf2,0xab,0x02,0xb2,0xf2,0xb0,0x02,0x9c,0xf2,0xb6,0x02,0x85,0xf2,0xbc,0x02,0x6f,0xf2,0xc1,0x02,0x58,0xf2,0xc7,0x02,0x41,0xf2,0xcc,0x02,0x2a,0xf2,0xd2,0x02,0x13,0xf2,0xd7,0x02,0xfc,0xf1,0xdd,0x02,0xe5,0xf1,0xe2,0x02,0xcd,0xf1,0xe8,0x02,0xb6,0xf1,0xed,0x02,0x9e,0xf1,0xf2,0x02,0x87,0xf1,0xf8,0x02,0x6f,0xf1,0xfd,0x02,0x57,0xf1,0x02,0x03,0x3e,0xf1,0x07,0x03,0x26,0xf1,0x0c,0x03,0x0e,0xf1,0x11,0x03,0xf5,0xf0,0x16,0x03,  \
    0xdc,0xf0,0x1a,0x03,0xc4,0xf0,0x1f,0x03,0xab,0xf0,0x24,0x03,0x91,0xf0,0x28,0x03,0x78,0xf0,0x2d,0x03,0x5f,0xf0,0x31,0x03,0x45,0xf0,0x35,0x03,0x2b,0xf0,0x39,0x03,0x12,0xf0,0x3d,0x03,0xf7,0xef,0x41,0x03,0xdd,0xef,0x45,0x03,0xc2,0xef,0x49,0x03,0xa7,0xef,0x4c,0x03,0x8c,0xef,0x4f,0x03,0x71,0xef,0x53,0x03,0x56,0xef,0x56,0x03,0x3a,0xef,0x59,0x03,0x1f,0xef,0x5c,0x03,0x03,0xef,0x5f,0x03,0xe7,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x8d,0x03,0xfe,0x10,0x8a,0x03,0xe2,0x10,0x87,0x03,0xc6,0x10,0x84,0x03,0xaa,0x10,0x81,0x03,0x8f,0x10,0x7d,0x03,0x73,0x10,0x7a,0x03,0x58,0x10,0x76,0x03,0x3d,0x10,0x73,0x03,0x22,0x10,0x6f,0x03,0x07,0x10,0x6b,0x03,  \
    0xec,0x0f,0x67,0x03,0xd1,0x0f,0x63,0x03,0xb7,0x0f,0x5f,0x03,0x9c,0x0f,0x5b,0x03,0x82,0x0f,0x57,0x03,0x68,0x0f,0x52,0x03,0x4e,0x0f,0x4e,0x03,0x34,0x0f,0x49,0x03,0x1a,0x0f,0x45,0x03,0x01,0x0f,0x40,0x03,0xe7,0x0e,0x3b,0x03,0xce,0x0e,0x37,0x03,0xb5,0x0e,0x32,0x03,0x9c,0x0e,0x2d,0x03,0x84,0x0e,0x27,0x03,0x6b,0x0e,0x22,0x03,0x53,0x0e,0x1d,0x03,0x3a,0x0e,0x18,0x03,0x22,0x0e,0x12,0x03,0x0a,0x0e,0x0d,0x03,0xf2,0x0d,0x08,0x03,0xda,0x0d,0x02,0x03,0xc3,0x0d,  \
    0xfd,0x02,0xab,0x0d,0xf7,0x02,0x93,0x0d,0xf1,0x02,0x7c,0x0d,0xec,0x02,0x65,0x0d,0xe6,0x02,0x4e,0x0d,0xe0,0x02,0x37,0x0d,0xda,0x02,0x20,0x0d,0xd4,0x02,0x0a,0x0d,0xce,0x02,0xf3,0x0c,0xc8,0x02,0xdd,0x0c,0xc2,0x02,0xc7,0x0c,0xbc,0x02,0xb1,0x0c,0xb5,0x02,0x9c,0x0c,0xaf,0x02,0x86,0x0c,0xa9,0x02,0x71,0x0c,0xa2,0x02,0x5b,0x0c,0x9c,0x02,0x46,0x0c,0x96,0x02,0x31,0x0c,0x8f,0x02,0x1c,0x0c,0x89,0x02,0x07,0x0c,0x82,0x02,0xf2,0x0b,0x7c,0x02,0xdd,0x0b,0x75,0x02,  \
    0xc9,0x0b,0x6f,0x02,0xb4,0x0b,0x68,0x02,0xa0,0x0b,0x63,0x02,0x8a,0x0b,0x5d,0x02,0x75,0x0b,0x57,0x02,0x60,0x0b,0x51,0x02,0x4a,0x0b,0x4b,0x02,0x35,0x0b,0x45,0x02,0x20,0x0b,0x3f,0x02,0x0b,0x0b,0x3a,0x02,0xf6,0x0a,0x34,0x02,0xe1,0x0a,0x2e,0x02,0xcd,0x0a,0x28,0x02,0xb8,0x0a,0x22,0x02,0xa3,0x0a,0x1c,0x02,0x8f,0x0a,0x16,0x02,0x7b,0x0a,0x10,0x02,0x66,0x0a,0x0b,0x02,0x52,0x0a,0x05,0x02,0x3e,0x0a,0xff,0x01,0x2a,0x0a,0xf9,0x01,0x16,0x0a,0xf3,0x01,0x02,0x0a,  \
    0xed,0x01,0xee,0x09,0xe8,0x01,0xda,0x09,0xe2,0x01,0xc6,0x09,0xdc,0x01,0xb2,0x09,0xd6,0x01,0x9f,0x09,0xd0,0x01,0x8b,0x09,0xcb,0x01,0x78,0x09,0xc5,0x01,0x64,0x09,0xbf,0x01,0x51,0x09,0xb9,0x01,0x3d,0x09,0xb4,0x01,0x2a,0x09,0xae,0x01,0x17,0x09,0xa8,0x01,0x04,0x09,0xa3,0x01,0xf1,0x08,0x9d,0x01,0xde,0x08,0x97,0x01,0xcb,0x08,0x91,0x01,0xba,0x08,0x8b,0x01,0xa8,0x08,0x85,0x01,0x97,0x08,0x7f,0x01,0x85,0x08,0x79,0x01,0x74,0x08,0x73,0x01,0x63,0x08,0x6d,0x01,  \
    0x51,0x08,0x67,0x01,0x40,0x08,0x61,0x01,0x2f,0x08,0x5b,0x01,0x1e,0x08,0x56,0x01,0x0d,0x08,0x50,0x01,0xfc,0x07,0x4a,0x01,0xeb,0x07,0x44,0x01,0xda,0x07,0x3f,0x01,0xc9,0x07,0x39,0x01,0xb9,0x07,0x33,0x01,0xa8,0x07,0x2e,0x01,0x97,0x07,0x28,0x01,0x87,0x07,0x23,0x01,0x76,0x07,0x1d,0x01,0x66,0x07,0x18,0x01,0x55,0x07,0x12,0x01,0x45,0x07,0x0d,0x01,0x34,0x07,0x08,0x01,0x24,0x07,0x03,0x01,0x13,0x07,0xfd,0x00,0x03,0x07,0xf8,0x00,0xf2,0x06,0xf3,0x00,0xe2,0x06,  \
    0xee,0x00,0xd2,0x06,0xe9,0x00,0xc1,0x06,0xe4,0x00,0xb1,0x06,0xdf,0x00,0xa1,0x06,0xda,0x00,0x91,0x06,0xd5,0x00,0x81,0x06,0xd0,0x00,0x71,0x06,0xcb,0x00,0x61,0x06,0xc7,0x00,0x51,0x06,0xc2,0x00,0x41,0x06,0xbd,0x00,0x31,0x06,0xb8,0x00,0x21,0x06,0xb4,0x00,0x11,0x06,0xaf,0x00,0x01,0x06,0xab,0x00,0xf1,0x05,0xa7,0x00,0xe0,0x05,0xa2,0x00,0xd0,0x05,0x9e,0x00,0xbf,0x05,0x9a,0x00,0xaf,0x05,0x96,0x00,0x9f,0x05,0x92,0x00,0x8e,0x05,0x8e,0x00,0x7e,0x05,0x8a,0x00,  \
    0x6e,0x05,0x86,0x00,0x5e,0x05,0x82,0x00,0x4d,0x05,0x7e,0x00,0x3d,0x05,0x7a,0x00,0x2d,0x05,0x76,0x00,0x1d,0x05,0x72,0x00,0x0d,0x05,0x6e,0x00,0xfd,0x04,0x6b,0x00,0xed,0x04,0x67,0x00,0xdd,0x04,0x63,0x00,0xcd,0x04,0x60,0x00,0xbd,0x04,0x5c,0x00,0xad,0x04,0x58,0x00,0x9d,0x04,0x55,0x00,0x8e,0x04,0x51,0x00,0x7e,0x04,0x4e,0x00,0x6f,0x04,0x4a,0x00,0x5f,0x04,0x47,0x00,0x50,0x04,0x44,0x00,0x41,0x04,0x40,0x00,0x32,0x04,0x3d,0x00,0x23,0x04,0x39,0x00,0x14,0x04,  \
    0x36,0x00,0x05,0x04,0x33,0x00,0xf5,0x03,0x30,0x00,0xe6,0x03,0x2d,0x00,0xd7,0x03,0x2a,0x00,0xc8,0x03,0x27,0x00,0xb9,0x03,0x24,0x00,0xaa,0x03,0x21,0x00,0x9b,0x03,0x1e,0x00,0x8c,0x03,0x1b,0x00,0x7d,0x03,0x18,0x00,0x6f,0x03,0x15,0x00,0x60,0x03,0x13,0x00,0x51,0x03,0x10,0x00,0x42,0x03,0x0d,0x00,0x33,0x03,0x0b,0x00,0x24,0x03,0x08,0x00,0x15,0x03,0x06,0x00,0x06,0x03,0x03,0x00,0xf8,0x02,0x01,0x00,0xe9,0x02,0xfe,0xff,0xdb,0x02,0xfc,0xff,0xcd,0x02,0xf9,0xff,  \
    0xbe,0x02,0xf7,0xff,0xb0,0x02,0xf5,0xff,0xa2,0x02,0xf3,0xff,0x93,0x02,0xf1,0xff,0x85,0x02,0xee,0xff,0x76,0x02,0xec,0xff,0x68,0x02,0xea,0xff,0x5a,0x02,0xe8,0xff,0x4b,0x02,0xe6,0xff,0x3d,0x02,0xe5,0xff,0x2f,0x02,0xe3,0xff,0x20,0x02,0xe1,0xff,0x12,0x02,0xdf,0xff,0x03,0x02,0xde,0xff,0xf5,0x01,0xdc,0xff,0xe6,0x01,0xda,0xff,0xd8,0x01,0xd9,0xff,0xc9,0x01,0xd7,0xff,0xbb,0x01,0xd6,0xff,0xad,0x01,0xd4,0xff,0x9e,0x01,0xd3,0xff,0x90,0x01,0xd2,0xff,0x81,0x01,  \
    0xd0,0xff,0x73,0x01,0xcf,0xff,0x64,0x01,0xce,0xff,0x55,0x01,0xcd,0xff,0x46,0x01,0xcc,0xff,0x37,0x01,0xcb,0xff,0x29,0x01,0xca,0xff,0x1a,0x01,0xc9,0xff,0x0b,0x01,0xc8,0xff,0xfc,0x00,0xc7,0xff,0xed,0x00,0xc6,0xff,0xdf,0x00,0xc5,0xff,0xd0,0x00,0xc5,0xff,0xc1,0x00,0xc4,0xff,0xb2,0x00,0xc3,0xff,0xa4,0x00,0xc3,0xff,0x95,0x00,0xc2,0xff,0x86,0x00,0xc1,0xff,0x77,0x00,0xc1,0xff,0x69,0x00,0xc0,0xff,0x5a,0x00,0xc0,0xff,0x4b,0x00,0xc0,0xff,0x3d,0x00,0xbf,0xff,  \
    0x2e,0x00,0xbf,0xff,0x1f,0x00,0xbf,0xff,0x10,0x00,0xbf,0xff,0x02,0x00,0xbe,0xff,0xf3,0xff,0xbe,0xff,0xe4,0xff,0xbe,0xff,0xd5,0xff,0xbe,0xff,0xc7,0xff,0xbe,0xff,0xb8,0xff,0xbe,0xff,0xa9,0xff,0xbe,0xff,0x9b,0xff,0xbe,0xff,0x8c,0xff,0xbf,0xff,0x7d,0xff,0xbf,0xff,0x6e,0xff,0xbf,0xff,0x60,0xff,0xbf,0xff,0x51,0xff,0xc0,0xff,0x42,0xff,0xc0,0xff,0x33,0xff,0xc1,0xff,0x25,0xff,0xc1,0xff,0x16,0xff,0xc2,0xff,0x07,0xff,0xc2,0xff,0xf9,0xfe,0xc3,0xff,0xea,0xfe,  \
    0xc3,0xff,0xdb,0xfe,0xc4,0xff,0xcc,0xfe,0xc5,0xff,0xbe,0xfe,0xc5,0xff,0xaf,0xfe,0xc6,0xff,0xa0,0xfe,0xc7,0xff,0x91,0xfe,0xc8,0xff,0x83,0xfe,0xc9,0xff,0x74,0xfe,0xca,0xff,0x65,0xfe,0xcb,0xff,0x57,0xfe,0xcc,0xff,0x48,0xfe,0xcd,0xff,0x39,0xfe,0xce,0xff,0x2a,0xfe,0xcf,0xff,0x1b,0xfe,0xd0,0xff,0x0c,0xfe,0xd2,0xff,0xfd,0xfd,0xd3,0xff,0xef,0xfd,0xd4,0xff,0xe0,0xfd,0xd6,0xff,0xd1,0xfd,0xd7,0xff,0xc2,0xfd,0xd8,0xff,0xb3,0xfd,0xda,0xff,0xa4,0xfd,0xdb,0xff,  \
    0x95,0xfd,0xdd,0xff,0x86,0xfd,0xdf,0xff,0x77,0xfd,0xe0,0xff,0x67,0xfd,0xe2,0xff,0x58,0xfd,0xe4,0xff,0x49,0xfd,0xe5,0xff,0x3a,0xfd,0xe7,0xff,0x2b,0xfd,0xe9,0xff,0x1c,0xfd,0xeb,0xff,0x0d,0xfd,0xed,0xff,0xfe,0xfc,0xef,0xff,0xee,0xfc,0xf1,0xff,0xdf,0xfc,0xf3,0xff,0xd0,0xfc,0xf5,0xff,0xc1,0xfc,0xf7,0xff,0xb2,0xfc,0xf9,0xff,0xa2,0xfc,0xfb,0xff,0x93,0xfc,0xfe,0xff,0x84,0xfc,0x00,0x00,0x75,0xfc,0x02,0x00,0x66,0xfc,0x05,0x00,0x57,0xfc,0x07,0x00,0x49,0xfc,  \
    0x0a,0x00,0x3a,0xfc,0x0c,0x00,0x2b,0xfc,0x0f,0x00,0x1c,0xfc,0x12,0x00,0x0d,0xfc,0x14,0x00,0xfe,0xfb,0x17,0x00,0xef,0xfb,0x1a,0x00,0xe0,0xfb,0x1d,0x00,0xd1,0xfb,0x20,0x00,0xc2,0xfb,0x22,0x00,0xb3,0xfb,0x25,0x00,0xa4,0xfb,0x28,0x00,0x95,0xfb,0x2b,0x00,0x86,0xfb,0x2e,0x00,0x77,0xfb,0x32,0x00,0x68,0xfb,0x35,0x00,0x59,0xfb,0x38,0x00,0x4a,0xfb,0x3b,0x00,0x3b,0xfb,0x3e,0x00,0x2c,0xfb,0x42,0x00,0x1c,0xfb,0x45,0x00,0x0d,0xfb,0x49,0x00,0xfe,0xfa,0x4c,0x00,  \
    0xee,0xfa,0x4f,0x00,0xdf,0xfa,0x53,0x00,0xcf,0xfa,0x56,0x00,0xc0,0xfa,0x5a,0x00,0xb0,0xfa,0x5d,0x00,0xa0,0xfa,0x61,0x00,0x91,0xfa,0x65,0x00,0x81,0xfa,0x68,0x00,0x71,0xfa,0x6c,0x00,0x62,0xfa,0x70,0x00,0x52,0xfa,0x74,0x00,0x42,0xfa,0x78,0x00,0x32,0xfa,0x7c,0x00,0x22,0xfa,0x80,0x00,0x12,0xfa,0x84,0x00,0x03,0xfa,0x88,0x00,0xf3,0xf9,0x8c,0x00,0xe3,0xf9,0x90,0x00,0xd3,0xf9,0x94,0x00,0xc3,0xf9,0x98,0x00,0xb3,0xf9,0x9c,0x00,0xa3,0xf9,0xa0,0x00,0x92,0xf9,  \
    0xa5,0x00,0x82,0xf9,0xa9,0x00,0x72,0xf9,0xae,0x00,0x62,0xf9,0xb2,0x00,0x52,0xf9,0xb6,0x00,0x42,0xf9,0xbb,0x00,0x32,0xf9,0xc0,0x00,0x22,0xf9,0xc4,0x00,0x12,0xf9,0xc9,0x00,0x02,0xf9,0xce,0x00,0xf2,0xf8,0xd2,0x00,0xe2,0xf8,0xd7,0x00,0xd1,0xf8,0xdc,0x00,0xc1,0xf8,0xe1,0x00,0xb1,0xf8,0xe6,0x00,0xa0,0xf8,0xeb,0x00,0x90,0xf8,0xf0,0x00,0x7f,0xf8,0xf5,0x00,0x6f,0xf8,0xfa,0x00,0x5e,0xf8,0xff,0x00,0x4e,0xf8,0x04,0x01,0x3d,0xf8,0x09,0x01,0x2d,0xf8,0x0e,0x01,  \
    0x1c,0xf8,0x13,0x01,0x0b,0xf8,0x18,0x01,0xfa,0xf7,0x1e,0x01,0xe9,0xf7,0x23,0x01,0xd8,0xf7,0x28,0x01,0xc7,0xf7,0x2d,0x01,0xb5,0xf7,0x33,0x01,0xa4,0xf7,0x38,0x01,0x92,0xf7,0x3d,0x01,0x81,0xf7,0x43,0x01,0x70,0xf7,0x48,0x01,0x5e,0xf7,0x4d,0x01,0x4c,0xf7,0x53,0x01,0x3b,0xf7,0x58,0x01,0x29,0xf7,0x5e,0x01,0x17,0xf7,0x63,0x01,0x05,0xf7,0x69,0x01,0xf3,0xf6,0x6e,0x01,0xe2,0xf6,0x74,0x01,0xd0,0xf6,0x7a,0x01,0xbd,0xf6,0x7f,0x01,0xab,0xf6,0x85,0x01,0x99,0xf6,  \
    0x8b,0x01,0x87,0xf6,0x91,0x01,0x75,0xf6,0x96,0x01,0x63,0xf6,0x9c,0x01,0x51,0xf6,0xa2,0x01,0x3e,0xf6,0xa8,0x01,0x2c,0xf6,0xae,0x01,0x1a,0xf6,0xb4,0x01,0x07,0xf6,0xba,0x01,0xf5,0xf5,0xc0,0x01,0xe2,0xf5,0xc6,0x01,0xcf,0xf5,0xcc,0x01,0xbd,0xf5,0xd2,0x01,0xaa,0xf5,0xd8,0x01,0x97,0xf5,0xde,0x01,0x84,0xf5,0xe4,0x01,0x71,0xf5,0xea,0x01,0x5e,0xf5,0xf0,0x01,0x4a,0xf5,0xf6,0x01,0x37,0xf5,0xfc,0x01,0x24,0xf5,0x02,0x02,0x0f,0xf5,0x08,0x02,0xfb,0xf4,0x0d,0x02,  \
    0xe7,0xf4,0x13,0x02,0xd2,0xf4,0x19,0x02,0xbe,0xf4,0x1f,0x02,0xa9,0xf4,0x24,0x02,0x94,0xf4,0x2a,0x02,0x80,0xf4,0x30,0x02,0x6b,0xf4,0x35,0x02,0x56,0xf4,0x3b,0x02,0x41,0xf4,0x41,0x02,0x2b,0xf4,0x47,0x02,0x16,0xf4,0x4c,0x02,0x01,0xf4,0x52,0x02,0xeb,0xf3,0x58,0x02,0xd6,0xf3,0x5d,0x02,0xc0,0xf3,0x63,0x02,0xab,0xf3,0x69,0x02,0x95,0xf3,0x6f,0x02,0x80,0xf3,0x74,0x02,0x6a,0xf3,0x7a,0x02,0x55,0xf3,0x80,0x02,0x3f,0xf3,0x86,0x02,0x2a,0xf3,0x8c,0x02,0x14,0xf3,  \
    0x92,0x02,0xfe,0xf2,0x98,0x02,0xe8,0xf2,0x9d,0x02,0xd2,0xf2,0xa3,0x02,0xbc,0xf2,0xa9,0x02,0xa5,0xf2,0xaf,0x02,0x8f,0xf2,0xb4,0x02,0x78,0xf2,0xba,0x02,0x62,0xf2,0xbf,0x02,0x4b,0xf2,0xc5,0x02,0x34,0xf2,0xca,0x02,0x1d,0xf2,0xd0,0x02,0x05,0xf2,0xd5,0x02,0xee,0xf1,0xdb,0x02,0xd7,0xf1,0xe0,0x02,0xbf,0xf1,0xe5,0x02,0xa8,0xf1,0xea,0x02,0x90,0xf1,0xf0,0x02,0x78,0xf1,0xf5,0x02,0x60,0xf1,0xfa,0x02,0x48,0xf1,0xff,0x02,0x2f,0xf1,0x04,0x03,0x17,0xf1,0x09,0x03,  \
    0xfe,0xf0,0x0d,0x03,0xe6,0xf0,0x12,0x03,0xcd,0xf0,0x17,0x03,0xb4,0xf0,0x1b,0x03,0x9a,0xf0,0x20,0x03,0x81,0xf0,0x24,0x03,0x68,0xf0,0x29,0x03,0x4e,0xf0,0x2d,0x03,0x34,0xf0,0x31,0x03,0x1a,0xf0,0x35,0x03,0x00,0xf0,0x39,0x03,0xe6,0xef,0x3c,0x03,0xcb,0xef,0x40,0x03,0xb0,0xef,0x43,0x03,0x95,0xef,0x47,0x03,0x7a,0xef,0x4a,0x03,0x5e,0xef,0x4d,0x03,0x43,0xef,0x50,0x03,0x27,0xef,0x53,0x03,0x0c,0xef,0x56,0x03,0xf0,0xee,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x81,0x03,0xf8,0x10,0x7e,0x03,0xdc,0x10,0x7b,0x03,0xc0,0x10,0x78,0x03,0xa4,0x10,0x75,0x03,0x88,0x10,0x71,0x03,0x6d,0x10,0x6e,0x03,0x51,0x10,0x6a,0x03,0x36,0x10,0x67,0x03,0x1b,0x10,0x63,0x03,  \
    0x00,0x10,0x5f,0x03,0xe5,0x0f,0x5b,0x03,0xcb,0x0f,0x57,0x03,0xb0,0x0f,0x53,0x03,0x96,0x0f,0x4f,0x03,0x7b,0x0f,0x4b,0x03,0x61,0x0f,0x47,0x03,0x47,0x0f,0x42,0x03,0x2d,0x0f,0x3e,0x03,0x13,0x0f,0x3a,0x03,0xfa,0x0e,0x35,0x03,0xe0,0x0e,0x30,0x03,0xc7,0x0e,0x2b,0x03,0xae,0x0e,0x26,0x03,0x95,0x0e,0x21,0x03,0x7c,0x0e,0x1c,0x03,0x64,0x0e,0x17,0x03,0x4b,0x0e,0x12,0x03,0x33,0x0e,0x0d,0x03,0x1b,0x0e,0x08,0x03,0x03,0x0e,0x02,0x03,0xeb,0x0d,0xfd,0x02,0xd3,0x0d,  \
    0xf8,0x02,0xbb,0x0d,0xf2,0x02,0xa3,0x0d,0xed,0x02,0x8c,0x0d,0xe7,0x02,0x75,0x0d,0xe1,0x02,0x5d,0x0d,0xdc,0x02,0x46,0x0d,0xd6,0x02,0x2f,0x0d,0xd0,0x02,0x18,0x0d,0xca,0x02,0x02,0x0d,0xc4,0x02,0xec,0x0c,0xbe,0x02,0xd5,0x0c,0xb8,0x02,0xbf,0x0c,0xb2,0x02,0xa9,0x0c,0xac,0x02,0x94,0x0c,0xa5,0x02,0x7e,0x0c,0x9f,0x02,0x69,0x0c,0x99,0x02,0x53,0x0c,0x93,0x02,0x3e,0x0c,0x8c,0x02,0x29,0x0c,0x86,0x02,0x14,0x0c,0x80,0x02,0xff,0x0b,0x79,0x02,0xea,0x0b,0x73,0x02,  \
    0xd5,0x0b,0x6c,0x02,0xc0,0x0b,0x66,0x02,0xac,0x0b,0x60,0x02,0x97,0x0b,0x5a,0x02,0x82,0x0b,0x54,0x02,0x6c,0x0b,0x4e,0x02,0x57,0x0b,0x48,0x02,0x42,0x0b,0x43,0x02,0x2d,0x0b,0x3d,0x02,0x18,0x0b,0x37,0x02,0x03,0x0b,0x31,0x02,0xee,0x0a,0x2b,0x02,0xd9,0x0a,0x25,0x02,0xc4,0x0a,0x20,0x02,0xaf,0x0a,0x1a,0x02,0x9b,0x0a,0x14,0x02,0x86,0x0a,0x0e,0x02,0x72,0x0a,0x08,0x02,0x5e,0x0a,0x02,0x02,0x49,0x0a,0xfd,0x01,0x35,0x0a,0xf7,0x01,0x21,0x0a,0xf1,0x01,0x0d,0x0a,  \
    0xeb,0x01,0xf9,0x09,0xe5,0x01,0xe5,0x09,0xe0,0x01,0xd1,0x09,0xda,0x01,0xbd,0x09,0xd4,0x01,0xaa,0x09,0xce,0x01,0x96,0x09,0xc9,0x01,0x83,0x09,0xc3,0x01,0x6f,0x09,0xbd,0x01,0x5c,0x09,0xb8,0x01,0x48,0x09,0xb2,0x01,0x35,0x09,0xac,0x01,0x22,0x09,0xa7,0x01,0x0f,0x09,0xa1,0x01,0xfc,0x08,0x9b,0x01,0xe9,0x08,0x96,0x01,0xd6,0x08,0x90,0x01,0xc3,0x08,0x8a,0x01,0xb1,0x08,0x84,0x01,0xa0,0x08,0x7e,0x01,0x8e,0x08,0x78,0x01,0x7d,0x08,0x72,0x01,0x6b,0x08,0x6c,0x01,  \
    0x5a,0x08,0x66,0x01,0x49,0x08,0x60,0x01,0x38,0x08,0x5a,0x01,0x27,0x08,0x55,0x01,0x15,0x08,0x4f,0x01,0x04,0x08,0x49,0x01,0xf4,0x07,0x43,0x01,0xe3,0x07,0x3e,0x01,0xd2,0x07,0x38,0x01,0xc1,0x07,0x32,0x01,0xb0,0x07,0x2d,0x01,0xa0,0x07,0x27,0x01,0x8f,0x07,0x22,0x01,0x7e,0x07,0x1c,0x01,0x6e,0x07,0x17,0x01,0x5d,0x07,0x11,0x01,0x4d,0x07,0x0c,0x01,0x3c,0x07,0x07,0x01,0x2c,0x07,0x01,0x01,0x1b,0x07,0xfc,0x00,0x0b,0x07,0xf7,0x00,0xfa,0x06,0xf2,0x00,0xea,0x06,  \
    0xed,0x00,0xda,0x06,0xe8,0x00,0xc9,0x06,0xe3,0x00,0xb9,0x06,0xde,0x00,0xa9,0x06,0xd9,0x00,0x99,0x06,0xd4,0x00,0x89,0x06,0xcf,0x00,0x79,0x06,0xca,0x00,0x69,0x06,0xc5,0x00,0x59,0x06,0xc1,0x00,0x49,0x06,0xbc,0x00,0x39,0x06,0xb7,0x00,0x29,0x06,0xb3,0x00,0x19,0x06,0xae,0x00,0x09,0x06,0xa9,0x00,0xf9,0x05,0xa5,0x00,0xe9,0x05,0xa1,0x00,0xd9,0x05,0x9d,0x00,0xc8,0x05,0x98,0x00,0xb8,0x05,0x94,0x00,0xa7,0x05,0x90,0x00,0x97,0x05,0x8c,0x00,0x87,0x05,0x88,0x00,  \
    0x77,0x05,0x84,0x00,0x66,0x05,0x80,0x00,0x56,0x05,0x7c,0x00,0x46,0x05,0x78,0x00,0x36,0x05,0x74,0x00,0x26,0x05,0x70,0x00,0x16,0x05,0x6c,0x00,0x06,0x05,0x69,0x00,0xf6,0x04,0x65,0x00,0xe6,0x04,0x61,0x00,0xd6,0x04,0x5e,0x00,0xc6,0x04,0x5a,0x00,0xb6,0x04,0x56,0x00,0xa7,0x04,0x53,0x00,0x97,0x04,0x4f,0x00,0x87,0x04,0x4c,0x00,0x77,0x04,0x48,0x00,0x68,0x04,0x45,0x00,0x59,0x04,0x41,0x00,0x4a,0x04,0x3e,0x00,0x3b,0x04,0x3b,0x00,0x2c,0x04,0x37,0x00,0x1d,0x04,  \
    0x34,0x00,0x0e,0x04,0x31,0x00,0xff,0x03,0x2e,0x00,0xf0,0x03,0x2a,0x00,0xe1,0x03,0x27,0x00,0xd2,0x03,0x24,0x00,0xc3,0x03,0x21,0x00,0xb4,0x03,0x1e,0x00,0xa5,0x03,0x1b,0x00,0x96,0x03,0x18,0x00,0x87,0x03,0x15,0x00,0x78,0x03,0x13,0x00,0x69,0x03,0x10,0x00,0x5a,0x03,0x0d,0x00,0x4c,0x03,0x0b,0x00,0x3d,0x03,0x08,0x00,0x2e,0x03,0x05,0x00,0x1f,0x03,0x03,0x00,0x10,0x03,0x00,0x00,0x02,0x03,0xfe,0xff,0xf3,0x02,0xfb,0xff,0xe5,0x02,0xf9,0xff,0xd6,0x02,0xf6,0xff,  \
    0xc8,0x02,0xf4,0xff,0xba,0x02,0xf2,0xff,0xab,0x02,0xf0,0xff,0x9d,0x02,0xed,0xff,0x8f,0x02,0xeb,0xff,0x81,0x02,0xe9,0xff,0x72,0x02,0xe7,0xff,0x64,0x02,0xe5,0xff,0x56,0x02,0xe3,0xff,0x47,0x02,0xe1,0xff,0x39,0x02,0xdf,0xff,0x2b,0x02,0xdd,0xff,0x1c,0x02,0xdc,0xff,0x0e,0x02,0xda,0xff,0x00,0x02,0xd8,0xff,0xf1,0x01,0xd7,0xff,0xe3,0x01,0xd5,0xff,0xd5,0x01,0xd3,0xff,0xc6,0x01,0xd2,0xff,0xb8,0x01,0xd1,0xff,0xa9,0x01,0xcf,0xff,0x9b,0x01,0xce,0xff,0x8d,0x01,  \
    0xcc,0xff,0x7e,0x01,0xcb,0xff,0x70,0x01,0xca,0xff,0x61,0x01,0xc9,0xff,0x52,0x01,0xc8,0xff,0x44,0x01,0xc7,0xff,0x35,0x01,0xc5,0xff,0x26,0x01,0xc4,0xff,0x18,0x01,0xc3,0xff,0x09,0x01,0xc3,0xff,0xfa,0x00,0xc2,0xff,0xec,0x00,0xc1,0xff,0xdd,0x00,0xc0,0xff,0xce,0x00,0xbf,0xff,0xc0,0x00,0xbf,0xff,0xb1,0x00,0xbe,0xff,0xa2,0x00,0xbd,0xff,0x94,0x00,0xbd,0xff,0x85,0x00,0xbc,0xff,0x76,0x00,0xbc,0xff,0x68,0x00,0xbb,0xff,0x59,0x00,0xbb,0xff,0x4a,0x00,0xba,0xff,  \
    0x3c,0x00,0xba,0xff,0x2d,0x00,0xba,0xff,0x1e,0x00,0xba,0xff,0x10,0x00,0xb9,0xff,0x01,0x00,0xb9,0xff,0xf3,0xff,0xb9,0xff,0xe4,0xff,0xb9,0xff,0xd5,0xff,0xb9,0xff,0xc7,0xff,0xb9,0xff,0xb8,0xff,0xb9,0xff,0xa9,0xff,0xb9,0xff,0x9b,0xff,0xb9,0xff,0x8c,0xff,0xb9,0xff,0x7e,0xff,0xba,0xff,0x6f,0xff,0xba,0xff,0x60,0xff,0xba,0xff,0x52,0xff,0xbb,0xff,0x43,0xff,0xbb,0xff,0x34,0xff,0xbb,0xff,0x26,0xff,0xbc,0xff,0x17,0xff,0xbc,0xff,0x09,0xff,0xbd,0xff,0xfa,0xfe,  \
    0xbd,0xff,0xeb,0xfe,0xbe,0xff,0xdd,0xfe,0xbf,0xff,0xce,0xfe,0xbf,0xff,0xbf,0xfe,0xc0,0xff,0xb1,0xfe,0xc1,0xff,0xa2,0xfe,0xc2,0xff,0x93,0xfe,0xc3,0xff,0x85,0xfe,0xc4,0xff,0x76,0xfe,0xc5,0xff,0x68,0xfe,0xc6,0xff,0x59,0xfe,0xc7,0xff,0x4a,0xfe,0xc8,0xff,0x3c,0xfe,0xc9,0xff,0x2d,0xfe,0xca,0xff,0x1e,0xfe,0xcb,0xff,0x0f,0xfe,0xcc,0xff,0x00,0xfe,0xce,0xff,0xf2,0xfd,0xcf,0xff,0xe3,0xfd,0xd0,0xff,0xd4,0xfd,0xd2,0xff,0xc5,0xfd,0xd3,0xff,0xb6,0xfd,0xd5,0xff,  \
    0xa7,0xfd,0xd6,0xff,0x98,0xfd,0xd8,0xff,0x89,0xfd,0xd9,0xff,0x7a,0xfd,0xdb,0xff,0x6b,0xfd,0xdd,0xff,0x5c,0xfd,0xdf,0xff,0x4d,0xfd,0xe0,0xff,0x3e,0xfd,0xe2,0xff,0x2f,0xfd,0xe4,0xff,0x20,0xfd,0xe6,0xff,0x11,0xfd,0xe8,0xff,0x02,0xfd,0xea,0xff,0xf3,0xfc,0xec,0xff,0xe4,0xfc,0xee,0xff,0xd5,0xfc,0xf0,0xff,0xc6,0xfc,0xf2,0xff,0xb7,0xfc,0xf4,0xff,0xa7,0xfc,0xf6,0xff,0x98,0xfc,0xf9,0xff,0x89,0xfc,0xfb,0xff,0x7b,0xfc,0xfd,0xff,0x6c,0xfc,0x00,0x00,0x5d,0xfc,  \
    0x02,0x00,0x4e,0xfc,0x05,0x00,0x3f,0xfc,0x07,0x00,0x30,0xfc,0x0a,0x00,0x22,0xfc,0x0d,0x00,0x13,0xfc,0x0f,0x00,0x04,0xfc,0x12,0x00,0xf5,0xfb,0x15,0x00,0xe6,0xfb,0x17,0x00,0xd7,0xfb,0x1a,0x00,0xc8,0xfb,0x1d,0x00,0xb9,0xfb,0x20,0x00,0xaa,0xfb,0x23,0x00,0x9b,0xfb,0x26,0x00,0x8c,0xfb,0x29,0x00,0x7e,0xfb,0x2c,0x00,0x6f,0xfb,0x30,0x00,0x60,0xfb,0x33,0x00,0x51,0xfb,0x36,0x00,0x42,0xfb,0x39,0x00,0x32,0xfb,0x3d,0x00,0x23,0xfb,0x40,0x00,0x14,0xfb,0x43,0x00,  \
    0x05,0xfb,0x47,0x00,0xf6,0xfa,0x4a,0x00,0xe6,0xfa,0x4e,0x00,0xd7,0xfa,0x51,0x00,0xc7,0xfa,0x55,0x00,0xb8,0xfa,0x58,0x00,0xa8,0xfa,0x5c,0x00,0x98,0xfa,0x60,0x00,0x89,0xfa,0x63,0x00,0x79,0xfa,0x67,0x00,0x69,0xfa,0x6b,0x00,0x5a,0xfa,0x6f,0x00,0x4a,0xfa,0x72,0x00,0x3a,0xfa,0x76,0x00,0x2a,0xfa,0x7a,0x00,0x1b,0xfa,0x7e,0x00,0x0b,0xfa,0x82,0x00,0xfb,0xf9,0x86,0x00,0xeb,0xf9,0x8a,0x00,0xdb,0xf9,0x8f,0x00,0xcb,0xf9,0x93,0x00,0xbb,0xf9,0x97,0x00,0xab,0xf9,  \
    0x9b,0x00,0x9b,0xf9,0x9f,0x00,0x8b,0xf9,0xa4,0x00,0x7b,0xf9,0xa8,0x00,0x6b,0xf9,0xad,0x00,0x5b,0xf9,0xb1,0x00,0x4b,0xf9,0xb6,0x00,0x3b,0xf9,0xba,0x00,0x2b,0xf9,0xbf,0x00,0x1b,0xf9,0xc4,0x00,0x0b,0xf9,0xc8,0x00,0xfb,0xf8,0xcd,0x00,0xeb,0xf8,0xd2,0x00,0xda,0xf8,0xd6,0x00,0xca,0xf8,0xdb,0x00,0xba,0xf8,0xe0,0x00,0xa9,0xf8,0xe5,0x00,0x99,0xf8,0xea,0x00,0x89,0xf8,0xef,0x00,0x78,0xf8,0xf4,0x00,0x68,0xf8,0xf9,0x00,0x57,0xf8,0xfe,0x00,0x47,0xf8,0x03,0x01,  \
    0x36,0xf8,0x08,0x01,0x25,0xf8,0x0e,0x01,0x15,0xf8,0x13,0x01,0x04,0xf8,0x18,0x01,0xf2,0xf7,0x1d,0x01,0xe1,0xf7,0x22,0x01,0xd0,0xf7,0x28,0x01,0xbf,0xf7,0x2d,0x01,0xad,0xf7,0x32,0x01,0x9c,0xf7,0x37,0x01,0x8b,0xf7,0x3d,0x01,0x79,0xf7,0x42,0x01,0x68,0xf7,0x48,0x01,0x56,0xf7,0x4d,0x01,0x44,0xf7,0x53,0x01,0x33,0xf7,0x58,0x01,0x21,0xf7,0x5e,0x01,0x0f,0xf7,0x63,0x01,0xfd,0xf6,0x69,0x01,0xeb,0xf6,0x6e,0x01,0xd9,0xf6,0x74,0x01,0xc7,0xf6,0x79,0x01,0xb5,0xf6,  \
    0x7f,0x01,0xa3,0xf6,0x85,0x01,0x91,0xf6,0x8b,0x01,0x7f,0xf6,0x90,0x01,0x6d,0xf6,0x96,0x01,0x5b,0xf6,0x9c,0x01,0x48,0xf6,0xa2,0x01,0x36,0xf6,0xa8,0x01,0x24,0xf6,0xae,0x01,0x11,0xf6,0xb4,0x01,0xfe,0xf5,0xba,0x01,0xec,0xf5,0xc0,0x01,0xd9,0xf5,0xc6,0x01,0xc6,0xf5,0xcc,0x01,0xb4,0xf5,0xd2,0x01,0xa1,0xf5,0xd8,0x01,0x8e,0xf5,0xde,0x01,0x7b,0xf5,0xe4,0x01,0x67,0xf5,0xea,0x01,0x54,0xf5,0xf0,0x01,0x41,0xf5,0xf6,0x01,0x2d,0xf5,0xfb,0x01,0x19,0xf5,0x01,0x02,  \
    0x05,0xf5,0x07,0x02,0xf1,0xf4,0x0d,0x02,0xdc,0xf4,0x12,0x02,0xc8,0xf4,0x18,0x02,0xb3,0xf4,0x1e,0x02,0x9e,0xf4,0x23,0x02,0x89,0xf4,0x29,0x02,0x74,0xf4,0x2f,0x02,0x60,0xf4,0x34,0x02,0x4a,0xf4,0x3a,0x02,0x35,0xf4,0x40,0x02,0x20,0xf4,0x45,0x02,0x0b,0xf4,0x4b,0x02,0xf5,0xf3,0x51,0x02,0xe0,0xf3,0x56,0x02,0xca,0xf3,0x5c,0x02,0xb4,0xf3,0x62,0x02,0x9f,0xf3,0x68,0x02,0x8a,0xf3,0x6d,0x02,0x74,0xf3,0x73,0x02,0x5f,0xf3,0x79,0x02,0x49,0xf3,0x7f,0x02,0x34,0xf3,  \
    0x85,0x02,0x1e,0xf3,0x8b,0x02,0x08,0xf3,0x90,0x02,0xf2,0xf2,0x96,0x02,0xdc,0xf2,0x9c,0x02,0xc5,0xf2,0xa2,0x02,0xaf,0xf2,0xa7,0x02,0x98,0xf2,0xad,0x02,0x82,0xf2,0xb2,0x02,0x6b,0xf2,0xb8,0x02,0x54,0xf2,0xbd,0x02,0x3d,0xf2,0xc3,0x02,0x26,0xf2,0xc8,0x02,0x0f,0xf2,0xcd,0x02,0xf7,0xf1,0xd3,0x02,0xe0,0xf1,0xd8,0x02,0xc8,0xf1,0xdd,0x02,0xb1,0xf1,0xe3,0x02,0x99,0xf1,0xe8,0x02,0x81,0xf1,0xed,0x02,0x69,0xf1,0xf2,0x02,0x51,0xf1,0xf7,0x02,0x38,0xf1,0xfc,0x02,  \
    0x20,0xf1,0x00,0x03,0x07,0xf1,0x05,0x03,0xef,0xf0,0x0a,0x03,0xd6,0xf0,0x0e,0x03,0xbd,0xf0,0x13,0x03,0xa3,0xf0,0x17,0x03,0x8a,0xf0,0x1c,0x03,0x70,0xf0,0x20,0x03,0x57,0xf0,0x24,0x03,0x3d,0xf0,0x28,0x03,0x23,0xf0,0x2c,0x03,0x09,0xf0,0x30,0x03,0xee,0xef,0x34,0x03,0xd3,0xef,0x37,0x03,0xb9,0xef,0x3b,0x03,0x9e,0xef,0x3e,0x03,0x82,0xef,0x41,0x03,0x67,0xef,0x45,0x03,0x4c,0xef,0x48,0x03,0x30,0xef,0x4b,0x03,0x14,0xef,0x4e,0x03,0xf8,0xee,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x75,0x03,0xf1,0x10,0x72,0x03,0xd5,0x10,0x6f,0x03,0xb9,0x10,0x6c,0x03,0x9d,0x10,0x69,0x03,0x82,0x10,0x65,0x03,0x66,0x10,0x62,0x03,0x4b,0x10,0x5e,0x03,0x2f,0x10,0x5b,0x03,  \
    0x14,0x10,0x57,0x03,0xf9,0x0f,0x53,0x03,0xdf,0x0f,0x50,0x03,0xc4,0x0f,0x4c,0x03,0xa9,0x0f,0x48,0x03,0x8f,0x0f,0x44,0x03,0x74,0x0f,0x40,0x03,0x5a,0x0f,0x3b,0x03,0x40,0x0f,0x37,0x03,0x26,0x0f,0x33,0x03,0x0c,0x0f,0x2e,0x03,0xf3,0x0e,0x2a,0x03,0xd9,0x0e,0x25,0x03,0xc0,0x0e,0x20,0x03,0xa7,0x0e,0x1b,0x03,0x8e,0x0e,0x16,0x03,0x75,0x0e,0x11,0x03,0x5d,0x0e,0x0c,0x03,0x44,0x0e,0x07,0x03,0x2c,0x0e,0x02,0x03,0x14,0x0e,0xfd,0x02,0xfb,0x0d,0xf8,0x02,0xe3,0x0d,  \
    0xf2,0x02,0xcb,0x0d,0xed,0x02,0xb4,0x0d,0xe8,0x02,0x9c,0x0d,0xe2,0x02,0x85,0x0d,0xdd,0x02,0x6d,0x0d,0xd7,0x02,0x56,0x0d,0xd1,0x02,0x3f,0x0d,0xcc,0x02,0x28,0x0d,0xc6,0x02,0x11,0x0d,0xc0,0x02,0xfa,0x0c,0xba,0x02,0xe4,0x0c,0xb4,0x02,0xce,0x0c,0xae,0x02,0xb8,0x0c,0xa8,0x02,0xa2,0x0c,0xa2,0x02,0x8c,0x0c,0x9c,0x02,0x76,0x0c,0x96,0x02,0x61,0x0c,0x90,0x02,0x4b,0x0c,0x89,0x02,0x36,0x0c,0x83,0x02,0x20,0x0c,0x7d,0x02,0x0b,0x0c,0x77,0x02,0xf6,0x0b,0x70,0x02,  \
    0xe1,0x0b,0x6a,0x02,0xcd,0x0b,0x64,0x02,0xb8,0x0b,0x5d,0x02,0xa4,0x0b,0x57,0x02,0x8f,0x0b,0x51,0x02,0x79,0x0b,0x4b,0x02,0x64,0x0b,0x46,0x02,0x4f,0x0b,0x40,0x02,0x39,0x0b,0x3a,0x02,0x24,0x0b,0x34,0x02,0x0f,0x0b,0x2f,0x02,0xfa,0x0a,0x29,0x02,0xe5,0x0a,0x23,0x02,0xd0,0x0a,0x1d,0x02,0xbc,0x0a,0x17,0x02,0xa7,0x0a,0x12,0x02,0x92,0x0a,0x0c,0x02,0x7e,0x0a,0x06,0x02,0x69,0x0a,0x00,0x02,0x55,0x0a,0xfa,0x01,0x41,0x0a,0xf5,0x01,0x2d,0x0a,0xef,0x01,0x19,0x0a,  \
    0xe9,0x01,0x04,0x0a,0xe3,0x01,0xf0,0x09,0xde,0x01,0xdd,0x09,0xd8,0x01,0xc9,0x09,0xd2,0x01,0xb5,0x09,0xcc,0x01,0xa1,0x09,0xc7,0x01,0x8e,0x09,0xc1,0x01,0x7a,0x09,0xbb,0x01,0x67,0x09,0xb6,0x01,0x53,0x09,0xb0,0x01,0x40,0x09,0xaa,0x01,0x2d,0x09,0xa5,0x01,0x19,0x09,0x9f,0x01,0x06,0x09,0x9a,0x01,0xf3,0x08,0x94,0x01,0xe0,0x08,0x8e,0x01,0xcd,0x08,0x89,0x01,0xbb,0x08,0x83,0x01,0xa9,0x08,0x7d,0x01,0x97,0x08,0x77,0x01,0x86,0x08,0x71,0x01,0x74,0x08,0x6b,0x01,  \
    0x63,0x08,0x65,0x01,0x52,0x08,0x5f,0x01,0x41,0x08,0x59,0x01,0x2f,0x08,0x54,0x01,0x1e,0x08,0x4e,0x01,0x0d,0x08,0x48,0x01,0xfc,0x07,0x42,0x01,0xeb,0x07,0x3d,0x01,0xda,0x07,0x37,0x01,0xc9,0x07,0x31,0x01,0xb9,0x07,0x2c,0x01,0xa8,0x07,0x26,0x01,0x97,0x07,0x21,0x01,0x87,0x07,0x1b,0x01,0x76,0x07,0x16,0x01,0x66,0x07,0x10,0x01,0x55,0x07,0x0b,0x01,0x44,0x07,0x06,0x01,0x34,0x07,0x00,0x01,0x23,0x07,0xfb,0x00,0x13,0x07,0xf6,0x00,0x02,0x07,0xf1,0x00,0xf2,0x06,  \
    0xec,0x00,0xe2,0x06,0xe7,0x00,0xd1,0x06,0xe2,0x00,0xc1,0x06,0xdd,0x00,0xb1,0x06,0xd8,0x00,0xa1,0x06,0xd3,0x00,0x91,0x06,0xce,0x00,0x81,0x06,0xc9,0x00,0x71,0x06,0xc4,0x00,0x61,0x06,0xc0,0x00,0x51,0x06,0xbb,0x00,0x41,0x06,0xb6,0x00,0x31,0x06,0xb1,0x00,0x21,0x06,0xad,0x00,0x11,0x06,0xa8,0x00,0x01,0x06,0xa4,0x00,0xf2,0x05,0x9f,0x00,0xe1,0x05,0x9b,0x00,0xd1,0x05,0x97,0x00,0xc0,0x05,0x93,0x00,0xb0,0x05,0x8f,0x00,0xa0,0x05,0x8a,0x00,0x8f,0x05,0x86,0x00,  \
    0x7f,0x05,0x82,0x00,0x6f,0x05,0x7e,0x00,0x5f,0x05,0x7a,0x00,0x4f,0x05,0x76,0x00,0x3f,0x05,0x73,0x00,0x2f,0x05,0x6f,0x00,0x1f,0x05,0x6b,0x00,0x0f,0x05,0x67,0x00,0xff,0x04,0x63,0x00,0xef,0x04,0x60,0x00,0xdf,0x04,0x5c,0x00,0xcf,0x04,0x58,0x00,0xbf,0x04,0x55,0x00,0xb0,0x04,0x51,0x00,0xa0,0x04,0x4d,0x00,0x90,0x04,0x4a,0x00,0x81,0x04,0x46,0x00,0x71,0x04,0x43,0x00,0x62,0x04,0x3f,0x00,0x53,0x04,0x3c,0x00,0x44,0x04,0x39,0x00,0x35,0x04,0x35,0x00,0x26,0x04,  \
    0x32,0x00,0x17,0x04,0x2f,0x00,0x08,0x04,0x2b,0x00,0xf9,0x03,0x28,0x00,0xea,0x03,0x25,0x00,0xdb,0x03,0x22,0x00,0xcc,0x03,0x1f,0x00,0xbd,0x03,0x1c,0x00,0xae,0x03,0x19,0x00,0x9f,0x03,0x16,0x00,0x90,0x03,0x13,0x00,0x81,0x03,0x10,0x00,0x73,0x03,0x0d,0x00,0x64,0x03,0x0b,0x00,0x55,0x03,0x08,0x00,0x46,0x03,0x05,0x00,0x38,0x03,0x03,0x00,0x29,0x03,0x00,0x00,0x1a,0x03,0xfe,0xff,0x0b,0x03,0xfb,0xff,0xfd,0x02,0xf9,0xff,0xee,0x02,0xf6,0xff,0xe0,0x02,0xf4,0xff,  \
    0xd2,0x02,0xf1,0xff,0xc4,0x02,0xef,0xff,0xb5,0x02,0xed,0xff,0xa7,0x02,0xea,0xff,0x99,0x02,0xe8,0xff,0x8b,0x02,0xe6,0xff,0x7c,0x02,0xe4,0xff,0x6e,0x02,0xe2,0xff,0x60,0x02,0xe0,0xff,0x52,0x02,0xde,0xff,0x43,0x02,0xdc,0xff,0x35,0x02,0xda,0xff,0x27,0x02,0xd8,0xff,0x19,0x02,0xd7,0xff,0x0a,0x02,0xd5,0xff,0xfc,0x01,0xd3,0xff,0xee,0x01,0xd2,0xff,0xe0,0x01,0xd0,0xff,0xd1,0x01,0xce,0xff,0xc3,0x01,0xcd,0xff,0xb5,0x01,0xcc,0xff,0xa6,0x01,0xca,0xff,0x98,0x01,  \
    0xc9,0xff,0x8a,0x01,0xc7,0xff,0x7b,0x01,0xc6,0xff,0x6d,0x01,0xc5,0xff,0x5e,0x01,0xc4,0xff,0x50,0x01,0xc3,0xff,0x41,0x01,0xc2,0xff,0x33,0x01,0xc0,0xff,0x24,0x01,0xbf,0xff,0x15,0x01,0xbf,0xff,0x07,0x01,0xbe,0xff,0xf8,0x00,0xbd,0xff,0xea,0x00,0xbc,0xff,0xdb,0x00,0xbb,0xff,0xcc,0x00,0xba,0xff,0xbe,0x00,0xba,0xff,0xaf,0x00,0xb9,0xff,0xa1,0x00,0xb8,0xff,0x92,0x00,0xb8,0xff,0x84,0x00,0xb7,0xff,0x75,0x00,0xb7,0xff,0x67,0x00,0xb6,0xff,0x58,0x00,0xb6,0xff,  \
    0x49,0x00,0xb5,0xff,0x3b,0x00,0xb5,0xff,0x2c,0x00,0xb5,0xff,0x1e,0x00,0xb5,0xff,0x0f,0x00,0xb4,0xff,0x01,0x00,0xb4,0xff,0xf2,0xff,0xb4,0xff,0xe4,0xff,0xb4,0xff,0xd5,0xff,0xb4,0xff,0xc7,0xff,0xb4,0xff,0xb8,0xff,0xb4,0xff,0xaa,0xff,0xb4,0xff,0x9b,0xff,0xb4,0xff,0x8d,0xff,0xb4,0xff,0x7e,0xff,0xb5,0xff,0x6f,0xff,0xb5,0xff,0x61,0xff,0xb5,0xff,0x52,0xff,0xb6,0xff,0x44,0xff,0xb6,0xff,0x35,0xff,0xb6,0xff,0x27,0xff,0xb7,0xff,0x18,0xff,0xb7,0xff,0x0a,0xff,  \
    0xb8,0xff,0xfb,0xfe,0xb8,0xff,0xed,0xfe,0xb9,0xff,0xde,0xfe,0xba,0xff,0xd0,0xfe,0xbb,0xff,0xc1,0xfe,0xbb,0xff,0xb3,0xfe,0xbc,0xff,0xa4,0xfe,0xbd,0xff,0x95,0xfe,0xbe,0xff,0x87,0xfe,0xbf,0xff,0x78,0xfe,0xc0,0xff,0x6a,0xfe,0xc1,0xff,0x5b,0xfe,0xc2,0xff,0x4d,0xfe,0xc3,0xff,0x3e,0xfe,0xc4,0xff,0x2f,0xfe,0xc5,0xff,0x21,0xfe,0xc6,0xff,0x12,0xfe,0xc8,0xff,0x03,0xfe,0xc9,0xff,0xf5,0xfd,0xca,0xff,0xe6,0xfd,0xcb,0xff,0xd7,0xfd,0xcd,0xff,0xc8,0xfd,0xce,0xff,  \
    0xb9,0xfd,0xd0,0xff,0xab,0xfd,0xd1,0xff,0x9c,0xfd,0xd3,0xff,0x8d,0xfd,0xd5,0xff,0x7e,0xfd,0xd6,0xff,0x6f,0xfd,0xd8,0xff,0x60,0xfd,0xda,0xff,0x51,0xfd,0xdb,0xff,0x43,0xfd,0xdd,0xff,0x34,0xfd,0xdf,0xff,0x25,0xfd,0xe1,0xff,0x16,0xfd,0xe3,0xff,0x07,0xfd,0xe5,0xff,0xf8,0xfc,0xe7,0xff,0xe9,0xfc,0xe9,0xff,0xda,0xfc,0xeb,0xff,0xcb,0xfc,0xed,0xff,0xbc,0xfc,0xef,0xff,0xad,0xfc,0xf1,0xff,0x9d,0xfc,0xf4,0xff,0x8f,0xfc,0xf6,0xff,0x80,0xfc,0xf8,0xff,0x71,0xfc,  \
    0xfb,0xff,0x62,0xfc,0xfd,0xff,0x54,0xfc,0x00,0x00,0x45,0xfc,0x02,0x00,0x36,0xfc,0x05,0x00,0x27,0xfc,0x08,0x00,0x19,0xfc,0x0a,0x00,0x0a,0xfc,0x0d,0x00,0xfb,0xfb,0x10,0x00,0xec,0xfb,0x13,0x00,0xdd,0xfb,0x15,0x00,0xce,0xfb,0x18,0x00,0xc0,0xfb,0x1b,0x00,0xb1,0xfb,0x1e,0x00,0xa2,0xfb,0x21,0x00,0x93,0xfb,0x24,0x00,0x84,0xfb,0x27,0x00,0x75,0xfb,0x2b,0x00,0x66,0xfb,0x2e,0x00,0x57,0xfb,0x31,0x00,0x48,0xfb,0x34,0x00,0x39,0xfb,0x38,0x00,0x2a,0xfb,0x3b,0x00,  \
    0x1b,0xfb,0x3e,0x00,0x0c,0xfb,0x42,0x00,0xfd,0xfa,0x45,0x00,0xed,0xfa,0x49,0x00,0xde,0xfa,0x4c,0x00,0xce,0xfa,0x50,0x00,0xbf,0xfa,0x53,0x00,0xaf,0xfa,0x57,0x00,0xa0,0xfa,0x5b,0x00,0x90,0xfa,0x5e,0x00,0x81,0xfa,0x62,0x00,0x71,0xfa,0x66,0x00,0x61,0xfa,0x6a,0x00,0x52,0xfa,0x6d,0x00,0x42,0xfa,0x71,0x00,0x32,0xfa,0x75,0x00,0x23,0xfa,0x79,0x00,0x13,0xfa,0x7d,0x00,0x03,0xfa,0x81,0x00,0xf3,0xf9,0x85,0x00,0xe3,0xf9,0x89,0x00,0xd3,0xf9,0x8e,0x00,0xc4,0xf9,  \
    0x92,0x00,0xb4,0xf9,0x96,0x00,0xa4,0xf9,0x9a,0x00,0x94,0xf9,0x9f,0x00,0x84,0xf9,0xa3,0x00,0x74,0xf9,0xa8,0x00,0x64,0xf9,0xac,0x00,0x54,0xf9,0xb1,0x00,0x44,0xf9,0xb5,0x00,0x34,0xf9,0xba,0x00,0x24,0xf9,0xbe,0x00,0x14,0xf9,0xc3,0x00,0x04,0xf9,0xc8,0x00,0xf4,0xf8,0xcc,0x00,0xe3,0xf8,0xd1,0x00,0xd3,0xf8,0xd6,0x00,0xc3,0xf8,0xdb,0x00,0xb3,0xf8,0xe0,0x00,0xa2,0xf8,0xe5,0x00,0x92,0xf8,0xea,0x00,0x81,0xf8,0xef,0x00,0x71,0xf8,0xf4,0x00,0x60,0xf8,0xf9,0x00,  \
    0x50,0xf8,0xfe,0x00,0x3f,0xf8,0x03,0x01,0x2f,0xf8,0x08,0x01,0x1e,0xf8,0x0d,0x01,0x0d,0xf8,0x13,0x01,0xfc,0xf7,0x18,0x01,0xeb,0xf7,0x1d,0x01,0xd9,0xf7,0x22,0x01,0xc8,0xf7,0x27,0x01,0xb7,0xf7,0x2d,0x01,0xa6,0xf7,0x32,0x01,0x94,0xf7,0x37,0x01,0x83,0xf7,0x3d,0x01,0x71,0xf7,0x42,0x01,0x60,0xf7,0x47,0x01,0x4e,0xf7,0x4d,0x01,0x3c,0xf7,0x52,0x01,0x2b,0xf7,0x58,0x01,0x19,0xf7,0x5d,0x01,0x07,0xf7,0x63,0x01,0xf5,0xf6,0x68,0x01,0xe3,0xf6,0x6e,0x01,0xd1,0xf6,  \
    0x74,0x01,0xbf,0xf6,0x79,0x01,0xad,0xf6,0x7f,0x01,0x9b,0xf6,0x85,0x01,0x89,0xf6,0x8b,0x01,0x77,0xf6,0x90,0x01,0x64,0xf6,0x96,0x01,0x52,0xf6,0x9c,0x01,0x40,0xf6,0xa2,0x01,0x2d,0xf6,0xa8,0x01,0x1b,0xf6,0xae,0x01,0x08,0xf6,0xb4,0x01,0xf6,0xf5,0xb9,0x01,0xe3,0xf5,0xbf,0x01,0xd0,0xf5,0xc5,0x01,0xbd,0xf5,0xcb,0x01,0xaa,0xf5,0xd1,0x01,0x97,0xf5,0xd7,0x01,0x84,0xf5,0xdd,0x01,0x71,0xf5,0xe3,0x01,0x5e,0xf5,0xe9,0x01,0x4a,0xf5,0xef,0x01,0x37,0xf5,0xf5,0x01,  \
    0x23,0xf5,0xfb,0x01,0x0f,0xf5,0x00,0x02,0xfa,0xf4,0x06,0x02,0xe6,0xf4,0x0c,0x02,0xd1,0xf4,0x11,0x02,0xbd,0xf4,0x17,0x02,0xa8,0xf4,0x1d,0x02,0x93,0xf4,0x22,0x02,0x7e,0xf4,0x28,0x02,0x69,0xf4,0x2e,0x02,0x54,0xf4,0x33,0x02,0x3f,0xf4,0x39,0x02,0x2a,0xf4,0x3f,0x02,0x14,0xf4,0x44,0x02,0xff,0xf3,0x4a,0x02,0xea,0xf3,0x50,0x02,0xd4,0xf3,0x55,0x02,0xbe,0xf3,0x5b,0x02,0xa9,0xf3,0x61,0x02,0x93,0xf3,0x67,0x02,0x7e,0xf3,0x6c,0x02,0x68,0xf3,0x72,0x02,0x53,0xf3,  \
    0x78,0x02,0x3d,0xf3,0x7e,0x02,0x27,0xf3,0x83,0x02,0x11,0xf3,0x89,0x02,0xfb,0xf2,0x8f,0x02,0xe5,0xf2,0x95,0x02,0xcf,0xf2,0x9a,0x02,0xb8,0xf2,0xa0,0x02,0xa2,0xf2,0xa5,0x02,0x8b,0xf2,0xab,0x02,0x74,0xf2,0xb0,0x02,0x5d,0xf2,0xb6,0x02,0x46,0xf2,0xbb,0x02,0x2f,0xf2,0xc0,0x02,0x18,0xf2,0xc6,0x02,0x01,0xf2,0xcb,0x02,0xe9,0xf1,0xd0,0x02,0xd2,0xf1,0xd6,0x02,0xba,0xf1,0xdb,0x02,0xa2,0xf1,0xe0,0x02,0x8a,0xf1,0xe5,0x02,0x72,0xf1,0xea,0x02,0x5a,0xf1,0xef,0x02,  \
    0x41,0xf1,0xf3,0x02,0x29,0xf1,0xf8,0x02,0x10,0xf1,0xfd,0x02,0xf7,0xf0,0x02,0x03,0xde,0xf0,0x06,0x03,0xc5,0xf0,0x0b,0x03,0xac,0xf0,0x0f,0x03,0x93,0xf0,0x13,0x03,0x79,0xf0,0x18,0x03,0x5f,0xf0,0x1c,0x03,0x46,0xf0,0x20,0x03,0x2c,0xf0,0x24,0x03,0x11,0xf0,0x28,0x03,0xf7,0xef,0x2b,0x03,0xdc,0xef,0x2f,0x03,0xc1,0xef,0x32,0x03,0xa6,0xef,0x35,0x03,0x8b,0xef,0x39,0x03,0x6f,0xef,0x3c,0x03,0x54,0xef,0x3f,0x03,0x38,0xef,0x42,0x03,0x1d,0xef,0x45,0x03,0x01,0xef,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6c,0x03,0xea,0x10,0x69,0x03,0xce,0x10,0x66,0x03,0xb2,0x10,0x63,0x03,0x96,0x10,0x60,0x03,0x7a,0x10,0x5c,0x03,0x5f,0x10,0x59,0x03,0x43,0x10,0x56,0x03,  \
    0x28,0x10,0x52,0x03,0x0d,0x10,0x4e,0x03,0xf2,0x0f,0x4b,0x03,0xd7,0x0f,0x47,0x03,0xbc,0x0f,0x43,0x03,0xa2,0x0f,0x3f,0x03,0x87,0x0f,0x3b,0x03,0x6d,0x0f,0x37,0x03,0x53,0x0f,0x33,0x03,0x38,0x0f,0x2f,0x03,0x1f,0x0f,0x2a,0x03,0x05,0x0f,0x26,0x03,0xeb,0x0e,0x21,0x03,0xd2,0x0e,0x1d,0x03,0xb8,0x0e,0x18,0x03,0x9f,0x0e,0x13,0x03,0x86,0x0e,0x0e,0x03,0x6e,0x0e,0x09,0x03,0x55,0x0e,0x04,0x03,0x3c,0x0e,0xff,0x02,0x24,0x0e,0xfa,0x02,0x0c,0x0e,0xf5,0x02,0xf3,0x0d,  \
    0xf0,0x02,0xdb,0x0d,0xea,0x02,0xc3,0x0d,0xe5,0x02,0xac,0x0d,0xe0,0x02,0x94,0x0d,0xda,0x02,0x7c,0x0d,0xd5,0x02,0x65,0x0d,0xcf,0x02,0x4e,0x0d,0xca,0x02,0x36,0x0d,0xc4,0x02,0x1f,0x0d,0xbf,0x02,0x08,0x0d,0xb9,0x02,0xf2,0x0c,0xb3,0x02,0xdb,0x0c,0xad,0x02,0xc5,0x0c,0xa7,0x02,0xaf,0x0c,0xa1,0x02,0x99,0x0c,0x9b,0x02,0x83,0x0c,0x95,0x02,0x6e,0x0c,0x8f,0x02,0x58,0x0c,0x88,0x02,0x42,0x0c,0x82,0x02,0x2d,0x0c,0x7c,0x02,0x18,0x0c,0x76,0x02,0x03,0x0c,0x70,0x02,  \
    0xee,0x0b,0x69,0x02,0xd9,0x0b,0x63,0x02,0xc4,0x0b,0x5d,0x02,0xaf,0x0b,0x56,0x02,0x9b,0x0b,0x50,0x02,0x86,0x0b,0x4b,0x02,0x70,0x0b,0x45,0x02,0x5b,0x0b,0x3f,0x02,0x46,0x0b,0x39,0x02,0x30,0x0b,0x34,0x02,0x1b,0x0b,0x2e,0x02,0x06,0x0b,0x28,0x02,0xf1,0x0a,0x22,0x02,0xdc,0x0a,0x1d,0x02,0xc7,0x0a,0x17,0x02,0xb3,0x0a,0x11,0x02,0x9e,0x0a,0x0b,0x02,0x89,0x0a,0x05,0x02,0x75,0x0a,0x00,0x02,0x60,0x0a,0xfa,0x01,0x4c,0x0a,0xf4,0x01,0x38,0x0a,0xee,0x01,0x24,0x0a,  \
    0xe9,0x01,0x10,0x0a,0xe3,0x01,0xfc,0x09,0xdd,0x01,0xe8,0x09,0xd7,0x01,0xd4,0x09,0xd2,0x01,0xc0,0x09,0xcc,0x01,0xac,0x09,0xc6,0x01,0x98,0x09,0xc1,0x01,0x85,0x09,0xbb,0x01,0x71,0x09,0xb5,0x01,0x5e,0x09,0xb0,0x01,0x4b,0x09,0xaa,0x01,0x37,0x09,0xa4,0x01,0x24,0x09,0x9f,0x01,0x11,0x09,0x99,0x01,0xfe,0x08,0x94,0x01,0xeb,0x08,0x8e,0x01,0xd8,0x08,0x88,0x01,0xc5,0x08,0x83,0x01,0xb2,0x08,0x7d,0x01,0xa0,0x08,0x77,0x01,0x8f,0x08,0x71,0x01,0x7d,0x08,0x6b,0x01,  \
    0x6c,0x08,0x65,0x01,0x5b,0x08,0x5f,0x01,0x49,0x08,0x59,0x01,0x38,0x08,0x54,0x01,0x27,0x08,0x4e,0x01,0x16,0x08,0x48,0x01,0x05,0x08,0x42,0x01,0xf4,0x07,0x3d,0x01,0xe3,0x07,0x37,0x01,0xd2,0x07,0x31,0x01,0xc1,0x07,0x2c,0x01,0xb0,0x07,0x26,0x01,0x9f,0x07,0x21,0x01,0x8f,0x07,0x1b,0x01,0x7e,0x07,0x16,0x01,0x6d,0x07,0x10,0x01,0x5d,0x07,0x0b,0x01,0x4c,0x07,0x06,0x01,0x3c,0x07,0x00,0x01,0x2b,0x07,0xfb,0x00,0x1b,0x07,0xf6,0x00,0x0a,0x07,0xf1,0x00,0xfa,0x06,  \
    0xec,0x00,0xea,0x06,0xe7,0x00,0xd9,0x06,0xe2,0x00,0xc9,0x06,0xdd,0x00,0xb9,0x06,0xd8,0x00,0xa9,0x06,0xd3,0x00,0x98,0x06,0xce,0x00,0x88,0x06,0xc9,0x00,0x78,0x06,0xc4,0x00,0x68,0x06,0xbf,0x00,0x58,0x06,0xba,0x00,0x48,0x06,0xb6,0x00,0x39,0x06,0xb1,0x00,0x29,0x06,0xac,0x00,0x19,0x06,0xa8,0x00,0x09,0x06,0xa3,0x00,0xf9,0x05,0x9f,0x00,0xea,0x05,0x9a,0x00,0xd9,0x05,0x96,0x00,0xc9,0x05,0x92,0x00,0xb9,0x05,0x8e,0x00,0xa8,0x05,0x8a,0x00,0x98,0x05,0x86,0x00,  \
    0x88,0x05,0x81,0x00,0x78,0x05,0x7d,0x00,0x68,0x05,0x79,0x00,0x57,0x05,0x75,0x00,0x47,0x05,0x72,0x00,0x37,0x05,0x6e,0x00,0x27,0x05,0x6a,0x00,0x18,0x05,0x66,0x00,0x08,0x05,0x62,0x00,0xf8,0x04,0x5e,0x00,0xe8,0x04,0x5b,0x00,0xd8,0x04,0x57,0x00,0xc8,0x04,0x53,0x00,0xb9,0x04,0x50,0x00,0xa9,0x04,0x4c,0x00,0x99,0x04,0x49,0x00,0x8a,0x04,0x45,0x00,0x7a,0x04,0x42,0x00,0x6a,0x04,0x3e,0x00,0x5b,0x04,0x3b,0x00,0x4c,0x04,0x37,0x00,0x3d,0x04,0x34,0x00,0x2e,0x04,  \
    0x30,0x00,0x1f,0x04,0x2d,0x00,0x10,0x04,0x2a,0x00,0x02,0x04,0x27,0x00,0xf3,0x03,0x23,0x00,0xe4,0x03,0x20,0x00,0xd5,0x03,0x1d,0x00,0xc6,0x03,0x1a,0x00,0xb7,0x03,0x17,0x00,0xa8,0x03,0x14,0x00,0x9a,0x03,0x11,0x00,0x8b,0x03,0x0e,0x00,0x7c,0x03,0x0c,0x00,0x6d,0x03,0x09,0x00,0x5f,0x03,0x06,0x00,0x50,0x03,0x03,0x00,0x41,0x03,0x01,0x00,0x33,0x03,0xfe,0xff,0x24,0x03,0xfb,0xff,0x15,0x03,0xf9,0xff,0x07,0x03,0xf6,0xff,0xf8,0x02,0xf4,0xff,0xea,0x02,0xf1,0xff,  \
    0xdb,0x02,0xef,0xff,0xcd,0x02,0xed,0xff,0xbf,0x02,0xea,0xff,0xb1,0x02,0xe8,0xff,0xa3,0x02,0xe6,0xff,0x94,0x02,0xe4,0xff,0x86,0x02,0xe1,0xff,0x78,0x02,0xdf,0xff,0x6a,0x02,0xdd,0xff,0x5c,0x02,0xdb,0xff,0x4e,0x02,0xd9,0xff,0x3f,0x02,0xd7,0xff,0x31,0x02,0xd6,0xff,0x23,0x02,0xd4,0xff,0x15,0x02,0xd2,0xff,0x07,0x02,0xd0,0xff,0xf9,0x01,0xcf,0xff,0xea,0x01,0xcd,0xff,0xdc,0x01,0xcb,0xff,0xce,0x01,0xca,0xff,0xc0,0x01,0xc8,0xff,0xb1,0x01,0xc7,0xff,0xa3,0x01,  \
    0xc5,0xff,0x95,0x01,0xc4,0xff,0x87,0x01,0xc3,0xff,0x78,0x01,0xc1,0xff,0x6a,0x01,0xc0,0xff,0x5c,0x01,0xbf,0xff,0x4d,0x01,0xbe,0xff,0x3f,0x01,0xbd,0xff,0x30,0x01,0xbc,0xff,0x22,0x01,0xbb,0xff,0x13,0x01,0xba,0xff,0x05,0x01,0xb9,0xff,0xf6,0x00,0xb8,0xff,0xe8,0x00,0xb7,0xff,0xd9,0x00,0xb6,0xff,0xcb,0x00,0xb6,0xff,0xbc,0x00,0xb5,0xff,0xae,0x00,0xb4,0xff,0x9f,0x00,0xb4,0xff,0x91,0x00,0xb3,0xff,0x82,0x00,0xb3,0xff,0x74,0x00,0xb2,0xff,0x65,0x00,0xb2,0xff,  \
    0x57,0x00,0xb1,0xff,0x49,0x00,0xb1,0xff,0x3a,0x00,0xb1,0xff,0x2c,0x00,0xb0,0xff,0x1d,0x00,0xb0,0xff,0x0f,0x00,0xb0,0xff,0x00,0x00,0xb0,0xff,0xf2,0xff,0xaf,0xff,0xe3,0xff,0xaf,0xff,0xd5,0xff,0xaf,0xff,0xc7,0xff,0xaf,0xff,0xb8,0xff,0xaf,0xff,0xaa,0xff,0xb0,0xff,0x9b,0xff,0xb0,0xff,0x8d,0xff,0xb0,0xff,0x7e,0xff,0xb0,0xff,0x70,0xff,0xb0,0xff,0x62,0xff,0xb1,0xff,0x53,0xff,0xb1,0xff,0x45,0xff,0xb1,0xff,0x36,0xff,0xb2,0xff,0x28,0xff,0xb2,0xff,0x19,0xff,  \
    0xb3,0xff,0x0b,0xff,0xb3,0xff,0xfd,0xfe,0xb4,0xff,0xee,0xfe,0xb4,0xff,0xe0,0xfe,0xb5,0xff,0xd1,0xfe,0xb6,0xff,0xc3,0xfe,0xb7,0xff,0xb4,0xfe,0xb7,0xff,0xa6,0xfe,0xb8,0xff,0x97,0xfe,0xb9,0xff,0x89,0xfe,0xba,0xff,0x7b,0xfe,0xbb,0xff,0x6c,0xfe,0xbc,0xff,0x5e,0xfe,0xbd,0xff,0x4f,0xfe,0xbe,0xff,0x41,0xfe,0xbf,0xff,0x32,0xfe,0xc0,0xff,0x23,0xfe,0xc2,0xff,0x15,0xfe,0xc3,0xff,0x06,0xfe,0xc4,0xff,0xf8,0xfd,0xc5,0xff,0xe9,0xfd,0xc7,0xff,0xda,0xfd,0xc8,0xff,  \
    0xcc,0xfd,0xca,0xff,0xbd,0xfd,0xcb,0xff,0xae,0xfd,0xcd,0xff,0x9f,0xfd,0xce,0xff,0x91,0xfd,0xd0,0xff,0x82,0xfd,0xd2,0xff,0x73,0xfd,0xd3,0xff,0x64,0xfd,0xd5,0xff,0x56,0xfd,0xd7,0xff,0x47,0xfd,0xd8,0xff,0x38,0xfd,0xda,0xff,0x29,0xfd,0xdc,0xff,0x1a,0xfd,0xde,0xff,0x0b,0xfd,0xe0,0xff,0xfc,0xfc,0xe2,0xff,0xed,0xfc,0xe4,0xff,0xde,0xfc,0xe6,0xff,0xd0,0xfc,0xe8,0xff,0xc1,0xfc,0xeb,0xff,0xb2,0xfc,0xed,0xff,0xa3,0xfc,0xef,0xff,0x94,0xfc,0xf1,0xff,0x85,0xfc,  \
    0xf4,0xff,0x77,0xfc,0xf6,0xff,0x68,0xfc,0xf9,0xff,0x59,0xfc,0xfb,0xff,0x4b,0xfc,0xfe,0xff,0x3c,0xfc,0x00,0x00,0x2d,0xfc,0x03,0x00,0x1e,0xfc,0x06,0x00,0x10,0xfc,0x08,0x00,0x01,0xfc,0x0b,0x00,0xf2,0xfb,0x0e,0x00,0xe3,0xfb,0x11,0x00,0xd5,0xfb,0x14,0x00,0xc6,0xfb,0x17,0x00,0xb7,0xfb,0x1a,0x00,0xa8,0xfb,0x1d,0x00,0x99,0xfb,0x20,0x00,0x8b,0xfb,0x23,0x00,0x7c,0xfb,0x26,0x00,0x6d,0xfb,0x29,0x00,0x5e,0xfb,0x2c,0x00,0x4f,0xfb,0x30,0x00,0x40,0xfb,0x33,0x00,  \
    0x31,0xfb,0x36,0x00,0x22,0xfb,0x3a,0x00,0x13,0xfb,0x3d,0x00,0x04,0xfb,0x40,0x00,0xf5,0xfa,0x44,0x00,0xe5,0xfa,0x47,0x00,0xd6,0xfa,0x4b,0x00,0xc6,0xfa,0x4e,0x00,0xb7,0xfa,0x52,0x00,0xa7,0xfa,0x56,0x00,0x98,0xfa,0x59,0x00,0x88,0xfa,0x5d,0x00,0x79,0xfa,0x61,0x00,0x69,0xfa,0x65,0x00,0x5a,0xfa,0x69,0x00,0x4a,0xfa,0x6c,0x00,0x3a,0xfa,0x70,0x00,0x2b,0xfa,0x74,0x00,0x1b,0xfa,0x78,0x00,0x0b,0xfa,0x7c,0x00,0xfb,0xf9,0x80,0x00,0xec,0xf9,0x85,0x00,0xdc,0xf9,  \
    0x89,0x00,0xcc,0xf9,0x8d,0x00,0xbc,0xf9,0x91,0x00,0xac,0xf9,0x95,0x00,0x9c,0xf9,0x9a,0x00,0x8c,0xf9,0x9e,0x00,0x7c,0xf9,0xa3,0x00,0x6c,0xf9,0xa7,0x00,0x5d,0xf9,0xac,0x00,0x4d,0xf9,0xb0,0x00,0x3d,0xf9,0xb5,0x00,0x2d,0xf9,0xb9,0x00,0x1d,0xf9,0xbe,0x00,0x0d,0xf9,0xc3,0x00,0xfc,0xf8,0xc7,0x00,0xec,0xf8,0xcc,0x00,0xdc,0xf8,0xd1,0x00,0xcc,0xf8,0xd6,0x00,0xbc,0xf8,0xdb,0x00,0xab,0xf8,0xe0,0x00,0x9b,0xf8,0xe5,0x00,0x8a,0xf8,0xea,0x00,0x7a,0xf8,0xef,0x00,  \
    0x6a,0xf8,0xf4,0x00,0x59,0xf8,0xf9,0x00,0x48,0xf8,0xfe,0x00,0x38,0xf8,0x03,0x01,0x27,0xf8,0x08,0x01,0x16,0xf8,0x0d,0x01,0x05,0xf8,0x12,0x01,0xf4,0xf7,0x18,0x01,0xe3,0xf7,0x1d,0x01,0xd2,0xf7,0x22,0x01,0xc0,0xf7,0x27,0x01,0xaf,0xf7,0x2d,0x01,0x9e,0xf7,0x32,0x01,0x8c,0xf7,0x37,0x01,0x7b,0xf7,0x3d,0x01,0x69,0xf7,0x42,0x01,0x58,0xf7,0x47,0x01,0x46,0xf7,0x4d,0x01,0x34,0xf7,0x52,0x01,0x22,0xf7,0x58,0x01,0x11,0xf7,0x5d,0x01,0xff,0xf6,0x63,0x01,0xed,0xf6,  \
    0x68,0x01,0xdb,0xf6,0x6e,0x01,0xc9,0xf6,0x74,0x01,0xb6,0xf6,0x79,0x01,0xa4,0xf6,0x7f,0x01,0x92,0xf6,0x85,0x01,0x80,0xf6,0x8b,0x01,0x6e,0xf6,0x90,0x01,0x5c,0xf6,0x96,0x01,0x49,0xf6,0x9c,0x01,0x37,0xf6,0xa2,0x01,0x24,0xf6,0xa8,0x01,0x12,0xf6,0xae,0x01,0xff,0xf5,0xb3,0x01,0xed,0xf5,0xb9,0x01,0xda,0xf5,0xbf,0x01,0xc7,0xf5,0xc5,0x01,0xb4,0xf5,0xcb,0x01,0xa1,0xf5,0xd1,0x01,0x8e,0xf5,0xd7,0x01,0x7b,0xf5,0xdd,0x01,0x67,0xf5,0xe3,0x01,0x54,0xf5,0xe9,0x01,  \
    0x41,0xf5,0xef,0x01,0x2c,0xf5,0xf4,0x01,0x18,0xf5,0xfa,0x01,0x04,0xf5,0x00,0x02,0xef,0xf4,0x05,0x02,0xdb,0xf4,0x0b,0x02,0xc6,0xf4,0x11,0x02,0xb1,0xf4,0x16,0x02,0x9d,0xf4,0x1c,0x02,0x88,0xf4,0x22,0x02,0x73,0xf4,0x27,0x02,0x5e,0xf4,0x2d,0x02,0x49,0xf4,0x32,0x02,0x33,0xf4,0x38,0x02,0x1e,0xf4,0x3e,0x02,0x09,0xf4,0x43,0x02,0xf3,0xf3,0x49,0x02,0xde,0xf3,0x4e,0x02,0xc8,0xf3,0x54,0x02,0xb2,0xf3,0x5a,0x02,0x9d,0xf3,0x60,0x02,0x87,0xf3,0x65,0x02,0x72,0xf3,  \
    0x6b,0x02,0x5c,0xf3,0x71,0x02,0x47,0xf3,0x77,0x02,0x31,0xf3,0x7c,0x02,0x1b,0xf3,0x82,0x02,0x05,0xf3,0x88,0x02,0xee,0xf2,0x8d,0x02,0xd8,0xf2,0x93,0x02,0xc2,0xf2,0x98,0x02,0xab,0xf2,0x9e,0x02,0x94,0xf2,0xa3,0x02,0x7d,0xf2,0xa9,0x02,0x67,0xf2,0xae,0x02,0x4f,0xf2,0xb3,0x02,0x38,0xf2,0xb9,0x02,0x21,0xf2,0xbe,0x02,0x0a,0xf2,0xc3,0x02,0xf2,0xf1,0xc9,0x02,0xdb,0xf1,0xce,0x02,0xc3,0xf1,0xd3,0x02,0xab,0xf1,0xd8,0x02,0x93,0xf1,0xdd,0x02,0x7b,0xf1,0xe2,0x02,  \
    0x62,0xf1,0xe7,0x02,0x4a,0xf1,0xeb,0x02,0x31,0xf1,0xf0,0x02,0x19,0xf1,0xf5,0x02,0x00,0xf1,0xf9,0x02,0xe7,0xf0,0xfe,0x02,0xce,0xf0,0x02,0x03,0xb5,0xf0,0x07,0x03,0x9b,0xf0,0x0b,0x03,0x82,0xf0,0x0f,0x03,0x68,0xf0,0x13,0x03,0x4e,0xf0,0x17,0x03,0x34,0xf0,0x1b,0x03,0x1a,0xf0,0x1f,0x03,0xff,0xef,0x23,0x03,0xe4,0xef,0x26,0x03,0xc9,0xef,0x29,0x03,0xae,0xef,0x2d,0x03,0x93,0xef,0x30,0x03,0x78,0xef,0x33,0x03,0x5c,0xef,0x36,0x03,0x41,0xef,0x39,0x03,0x25,0xef,  \
    0x3c,0x03,0x09,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x64,0x03,0xe2,0x10,0x61,0x03,0xc6,0x10,0x5e,0x03,0xaa,0x10,0x5b,0x03,0x8e,0x10,0x58,0x03,0x72,0x10,0x55,0x03,0x57,0x10,0x51,0x03,  \
    0x3b,0x10,0x4e,0x03,0x20,0x10,0x4a,0x03,0x05,0x10,0x47,0x03,0xea,0x0f,0x43,0x03,0xcf,0x0f,0x3f,0x03,0xb4,0x0f,0x3b,0x03,0x9a,0x0f,0x37,0x03,0x7f,0x0f,0x33,0x03,0x65,0x0f,0x2f,0x03,0x4b,0x0f,0x2b,0x03,0x31,0x0f,0x27,0x03,0x17,0x0f,0x23,0x03,0xfd,0x0e,0x1e,0x03,0xe3,0x0e,0x1a,0x03,0xca,0x0e,0x15,0x03,0xb0,0x0e,0x10,0x03,0x97,0x0e,0x0c,0x03,0x7e,0x0e,0x07,0x03,0x65,0x0e,0x02,0x03,0x4d,0x0e,0xfd,0x02,0x34,0x0e,0xf8,0x02,0x1c,0x0e,0xf3,0x02,0x03,0x0e,  \
    0xee,0x02,0xeb,0x0d,0xe9,0x02,0xd3,0x0d,0xe3,0x02,0xbb,0x0d,0xde,0x02,0xa3,0x0d,0xd9,0x02,0x8c,0x0d,0xd3,0x02,0x74,0x0d,0xce,0x02,0x5d,0x0d,0xc8,0x02,0x45,0x0d,0xc3,0x02,0x2e,0x0d,0xbd,0x02,0x17,0x0d,0xb8,0x02,0x00,0x0d,0xb2,0x02,0xe9,0x0c,0xac,0x02,0xd3,0x0c,0xa6,0x02,0xbd,0x0c,0xa0,0x02,0xa7,0x0c,0x9a,0x02,0x91,0x0c,0x94,0x02,0x7b,0x0c,0x8e,0x02,0x65,0x0c,0x88,0x02,0x4f,0x0c,0x82,0x02,0x3a,0x0c,0x7c,0x02,0x24,0x0c,0x76,0x02,0x0f,0x0c,0x70,0x02,  \
    0xfa,0x0b,0x69,0x02,0xe5,0x0b,0x63,0x02,0xd0,0x0b,0x5d,0x02,0xbb,0x0b,0x57,0x02,0xa6,0x0b,0x50,0x02,0x91,0x0b,0x4a,0x02,0x7d,0x0b,0x45,0x02,0x67,0x0b,0x3f,0x02,0x52,0x0b,0x39,0x02,0x3c,0x0b,0x33,0x02,0x27,0x0b,0x2e,0x02,0x12,0x0b,0x28,0x02,0xfd,0x0a,0x22,0x02,0xe8,0x0a,0x1c,0x02,0xd3,0x0a,0x17,0x02,0xbe,0x0a,0x11,0x02,0xaa,0x0a,0x0b,0x02,0x95,0x0a,0x05,0x02,0x80,0x0a,0x00,0x02,0x6c,0x0a,0xfa,0x01,0x57,0x0a,0xf4,0x01,0x43,0x0a,0xee,0x01,0x2f,0x0a,  \
    0xe9,0x01,0x1b,0x0a,0xe3,0x01,0x07,0x0a,0xdd,0x01,0xf3,0x09,0xd8,0x01,0xdf,0x09,0xd2,0x01,0xcb,0x09,0xcc,0x01,0xb7,0x09,0xc6,0x01,0xa3,0x09,0xc1,0x01,0x90,0x09,0xbb,0x01,0x7c,0x09,0xb5,0x01,0x69,0x09,0xb0,0x01,0x55,0x09,0xaa,0x01,0x42,0x09,0xa4,0x01,0x2e,0x09,0x9f,0x01,0x1b,0x09,0x99,0x01,0x08,0x09,0x94,0x01,0xf5,0x08,0x8e,0x01,0xe2,0x08,0x89,0x01,0xcf,0x08,0x83,0x01,0xbc,0x08,0x7d,0x01,0xaa,0x08,0x77,0x01,0x98,0x08,0x72,0x01,0x86,0x08,0x6c,0x01,  \
    0x75,0x08,0x66,0x01,0x63,0x08,0x60,0x01,0x52,0x08,0x5a,0x01,0x41,0x08,0x54,0x01,0x2f,0x08,0x4e,0x01,0x1e,0x08,0x49,0x01,0x0d,0x08,0x43,0x01,0xfc,0x07,0x3d,0x01,0xeb,0x07,0x38,0x01,0xda,0x07,0x32,0x01,0xc9,0x07,0x2c,0x01,0xb8,0x07,0x27,0x01,0xa7,0x07,0x21,0x01,0x97,0x07,0x1c,0x01,0x86,0x07,0x16,0x01,0x75,0x07,0x11,0x01,0x65,0x07,0x0b,0x01,0x54,0x07,0x06,0x01,0x44,0x07,0x01,0x01,0x33,0x07,0xfc,0x00,0x23,0x07,0xf6,0x00,0x12,0x07,0xf1,0x00,0x02,0x07,  \
    0xec,0x00,0xf1,0x06,0xe7,0x00,0xe1,0x06,0xe2,0x00,0xd1,0x06,0xdd,0x00,0xc1,0x06,0xd8,0x00,0xb0,0x06,0xd3,0x00,0xa0,0x06,0xce,0x00,0x90,0x06,0xc9,0x00,0x80,0x06,0xc4,0x00,0x70,0x06,0xbf,0x00,0x60,0x06,0xbb,0x00,0x50,0x06,0xb6,0x00,0x40,0x06,0xb1,0x00,0x30,0x06,0xac,0x00,0x21,0x06,0xa8,0x00,0x11,0x06,0xa3,0x00,0x01,0x06,0x9f,0x00,0xf1,0x05,0x9a,0x00,0xe2,0x05,0x96,0x00,0xd1,0x05,0x92,0x00,0xc1,0x05,0x8d,0x00,0xb1,0x05,0x89,0x00,0xa1,0x05,0x85,0x00,  \
    0x90,0x05,0x81,0x00,0x80,0x05,0x7d,0x00,0x70,0x05,0x79,0x00,0x60,0x05,0x75,0x00,0x50,0x05,0x71,0x00,0x40,0x05,0x6d,0x00,0x30,0x05,0x69,0x00,0x20,0x05,0x65,0x00,0x10,0x05,0x61,0x00,0x01,0x05,0x5e,0x00,0xf1,0x04,0x5a,0x00,0xe1,0x04,0x56,0x00,0xd1,0x04,0x52,0x00,0xc2,0x04,0x4f,0x00,0xb2,0x04,0x4b,0x00,0xa2,0x04,0x48,0x00,0x93,0x04,0x44,0x00,0x83,0x04,0x41,0x00,0x74,0x04,0x3d,0x00,0x64,0x04,0x3a,0x00,0x55,0x04,0x36,0x00,0x46,0x04,0x33,0x00,0x37,0x04,  \
    0x2f,0x00,0x28,0x04,0x2c,0x00,0x19,0x04,0x29,0x00,0x0a,0x04,0x25,0x00,0xfc,0x03,0x22,0x00,0xed,0x03,0x1f,0x00,0xde,0x03,0x1c,0x00,0xcf,0x03,0x19,0x00,0xc0,0x03,0x16,0x00,0xb1,0x03,0x13,0x00,0xa3,0x03,0x10,0x00,0x94,0x03,0x0d,0x00,0x85,0x03,0x0a,0x00,0x77,0x03,0x07,0x00,0x68,0x03,0x04,0x00,0x59,0x03,0x02,0x00,0x4b,0x03,0xff,0xff,0x3c,0x03,0xfc,0xff,0x2d,0x03,0xfa,0xff,0x1f,0x03,0xf7,0xff,0x10,0x03,0xf4,0xff,0x02,0x03,0xf2,0xff,0xf3,0x02,0xef,0xff,  \
    0xe5,0x02,0xed,0xff,0xd7,0x02,0xeb,0xff,0xc9,0x02,0xe8,0xff,0xba,0x02,0xe6,0xff,0xac,0x02,0xe4,0xff,0x9e,0x02,0xe1,0xff,0x90,0x02,0xdf,0xff,0x82,0x02,0xdd,0xff,0x74,0x02,0xdb,0xff,0x66,0x02,0xd9,0xff,0x58,0x02,0xd7,0xff,0x4a,0x02,0xd5,0xff,0x3c,0x02,0xd3,0xff,0x2d,0x02,0xd1,0xff,0x1f,0x02,0xcf,0xff,0x11,0x02,0xce,0xff,0x03,0x02,0xcc,0xff,0xf5,0x01,0xca,0xff,0xe7,0x01,0xc9,0xff,0xd9,0x01,0xc7,0xff,0xcb,0x01,0xc5,0xff,0xbc,0x01,0xc4,0xff,0xae,0x01,  \
    0xc2,0xff,0xa0,0x01,0xc1,0xff,0x92,0x01,0xc0,0xff,0x84,0x01,0xbe,0xff,0x76,0x01,0xbd,0xff,0x67,0x01,0xbc,0xff,0x59,0x01,0xbb,0xff,0x4b,0x01,0xba,0xff,0x3c,0x01,0xb8,0xff,0x2e,0x01,0xb7,0xff,0x1f,0x01,0xb6,0xff,0x11,0x01,0xb5,0xff,0x03,0x01,0xb5,0xff,0xf4,0x00,0xb4,0xff,0xe6,0x00,0xb3,0xff,0xd7,0x00,0xb2,0xff,0xc9,0x00,0xb1,0xff,0xbb,0x00,0xb1,0xff,0xac,0x00,0xb0,0xff,0x9e,0x00,0xaf,0xff,0x8f,0x00,0xaf,0xff,0x81,0x00,0xae,0xff,0x73,0x00,0xae,0xff,  \
    0x64,0x00,0xad,0xff,0x56,0x00,0xad,0xff,0x48,0x00,0xac,0xff,0x39,0x00,0xac,0xff,0x2b,0x00,0xac,0xff,0x1d,0x00,0xac,0xff,0x0e,0x00,0xab,0xff,0x00,0x00,0xab,0xff,0xf2,0xff,0xab,0xff,0xe3,0xff,0xab,0xff,0xd5,0xff,0xab,0xff,0xc7,0xff,0xab,0xff,0xb8,0xff,0xab,0xff,0xaa,0xff,0xab,0xff,0x9c,0xff,0xab,0xff,0x8d,0xff,0xab,0xff,0x7f,0xff,0xac,0xff,0x71,0xff,0xac,0xff,0x62,0xff,0xac,0xff,0x54,0xff,0xad,0xff,0x46,0xff,0xad,0xff,0x37,0xff,0xad,0xff,0x29,0xff,  \
    0xae,0xff,0x1b,0xff,0xae,0xff,0x0c,0xff,0xaf,0xff,0xfe,0xfe,0xaf,0xff,0xef,0xfe,0xb0,0xff,0xe1,0xfe,0xb1,0xff,0xd3,0xfe,0xb1,0xff,0xc4,0xfe,0xb2,0xff,0xb6,0xfe,0xb3,0xff,0xa8,0xfe,0xb4,0xff,0x99,0xfe,0xb5,0xff,0x8b,0xfe,0xb6,0xff,0x7d,0xfe,0xb7,0xff,0x6e,0xfe,0xb8,0xff,0x60,0xfe,0xb9,0xff,0x52,0xfe,0xba,0xff,0x43,0xfe,0xbb,0xff,0x35,0xfe,0xbc,0xff,0x26,0xfe,0xbd,0xff,0x18,0xfe,0xbe,0xff,0x09,0xfe,0xc0,0xff,0xfb,0xfd,0xc1,0xff,0xec,0xfd,0xc2,0xff,  \
    0xdd,0xfd,0xc4,0xff,0xcf,0xfd,0xc5,0xff,0xc0,0xfd,0xc7,0xff,0xb2,0xfd,0xc8,0xff,0xa3,0xfd,0xca,0xff,0x94,0xfd,0xcb,0xff,0x86,0xfd,0xcd,0xff,0x77,0xfd,0xcf,0xff,0x68,0xfd,0xd1,0xff,0x5a,0xfd,0xd2,0xff,0x4b,0xfd,0xd4,0xff,0x3c,0xfd,0xd6,0xff,0x2d,0xfd,0xd8,0xff,0x1f,0xfd,0xda,0xff,0x10,0xfd,0xdc,0xff,0x01,0xfd,0xde,0xff,0xf2,0xfc,0xe0,0xff,0xe3,0xfc,0xe2,0xff,0xd4,0xfc,0xe4,0xff,0xc5,0xfc,0xe6,0xff,0xb7,0xfc,0xe8,0xff,0xa8,0xfc,0xeb,0xff,0x99,0xfc,  \
    0xed,0xff,0x8b,0xfc,0xef,0xff,0x7c,0xfc,0xf2,0xff,0x6d,0xfc,0xf4,0xff,0x5f,0xfc,0xf7,0xff,0x50,0xfc,0xf9,0xff,0x41,0xfc,0xfc,0xff,0x33,0xfc,0xfe,0xff,0x24,0xfc,0x01,0x00,0x16,0xfc,0x04,0x00,0x07,0xfc,0x07,0x00,0xf8,0xfb,0x09,0x00,0xea,0xfb,0x0c,0x00,0xdb,0xfb,0x0f,0x00,0xcc,0xfb,0x12,0x00,0xbd,0xfb,0x15,0x00,0xaf,0xfb,0x18,0x00,0xa0,0xfb,0x1b,0x00,0x91,0xfb,0x1e,0x00,0x82,0xfb,0x21,0x00,0x74,0xfb,0x25,0x00,0x65,0xfb,0x28,0x00,0x56,0xfb,0x2b,0x00,  \
    0x47,0xfb,0x2e,0x00,0x38,0xfb,0x32,0x00,0x29,0xfb,0x35,0x00,0x1a,0xfb,0x38,0x00,0x0b,0xfb,0x3c,0x00,0xfc,0xfa,0x3f,0x00,0xec,0xfa,0x43,0x00,0xdd,0xfa,0x46,0x00,0xce,0xfa,0x4a,0x00,0xbe,0xfa,0x4d,0x00,0xaf,0xfa,0x51,0x00,0x9f,0xfa,0x55,0x00,0x90,0xfa,0x59,0x00,0x80,0xfa,0x5c,0x00,0x71,0xfa,0x60,0x00,0x61,0xfa,0x64,0x00,0x52,0xfa,0x68,0x00,0x42,0xfa,0x6c,0x00,0x33,0xfa,0x70,0x00,0x23,0xfa,0x74,0x00,0x13,0xfa,0x78,0x00,0x03,0xfa,0x7c,0x00,0xf4,0xf9,  \
    0x80,0x00,0xe4,0xf9,0x84,0x00,0xd4,0xf9,0x88,0x00,0xc4,0xf9,0x8c,0x00,0xb4,0xf9,0x91,0x00,0xa4,0xf9,0x95,0x00,0x95,0xf9,0x99,0x00,0x85,0xf9,0x9e,0x00,0x75,0xf9,0xa2,0x00,0x65,0xf9,0xa7,0x00,0x55,0xf9,0xab,0x00,0x45,0xf9,0xb0,0x00,0x35,0xf9,0xb4,0x00,0x25,0xf9,0xb9,0x00,0x15,0xf9,0xbe,0x00,0x05,0xf9,0xc3,0x00,0xf5,0xf8,0xc7,0x00,0xe5,0xf8,0xcc,0x00,0xd5,0xf8,0xd1,0x00,0xc4,0xf8,0xd6,0x00,0xb4,0xf8,0xdb,0x00,0xa4,0xf8,0xe0,0x00,0x93,0xf8,0xe5,0x00,  \
    0x83,0xf8,0xea,0x00,0x73,0xf8,0xef,0x00,0x62,0xf8,0xf4,0x00,0x51,0xf8,0xf9,0x00,0x41,0xf8,0xfe,0x00,0x30,0xf8,0x03,0x01,0x1f,0xf8,0x08,0x01,0x0e,0xf8,0x0d,0x01,0xfd,0xf7,0x12,0x01,0xec,0xf7,0x18,0x01,0xdb,0xf7,0x1d,0x01,0xca,0xf7,0x22,0x01,0xb8,0xf7,0x27,0x01,0xa7,0xf7,0x2d,0x01,0x96,0xf7,0x32,0x01,0x84,0xf7,0x37,0x01,0x73,0xf7,0x3d,0x01,0x61,0xf7,0x42,0x01,0x4f,0xf7,0x47,0x01,0x3e,0xf7,0x4d,0x01,0x2c,0xf7,0x52,0x01,0x1a,0xf7,0x58,0x01,0x08,0xf7,  \
    0x5d,0x01,0xf6,0xf6,0x63,0x01,0xe4,0xf6,0x68,0x01,0xd2,0xf6,0x6e,0x01,0xc0,0xf6,0x74,0x01,0xae,0xf6,0x79,0x01,0x9c,0xf6,0x7f,0x01,0x8a,0xf6,0x85,0x01,0x78,0xf6,0x8b,0x01,0x65,0xf6,0x90,0x01,0x53,0xf6,0x96,0x01,0x40,0xf6,0x9c,0x01,0x2e,0xf6,0xa2,0x01,0x1b,0xf6,0xa8,0x01,0x09,0xf6,0xae,0x01,0xf6,0xf5,0xb3,0x01,0xe3,0xf5,0xb9,0x01,0xd0,0xf5,0xbf,0x01,0xbd,0xf5,0xc5,0x01,0xaa,0xf5,0xcb,0x01,0x97,0xf5,0xd1,0x01,0x84,0xf5,0xd7,0x01,0x71,0xf5,0xdd,0x01,  \
    0x5d,0xf5,0xe3,0x01,0x4a,0xf5,0xe8,0x01,0x36,0xf5,0xee,0x01,0x22,0xf5,0xf4,0x01,0x0d,0xf5,0xf9,0x01,0xf9,0xf4,0xff,0x01,0xe4,0xf4,0x04,0x02,0xd0,0xf4,0x0a,0x02,0xbb,0xf4,0x10,0x02,0xa6,0xf4,0x15,0x02,0x91,0xf4,0x1b,0x02,0x7c,0xf4,0x21,0x02,0x67,0xf4,0x26,0x02,0x52,0xf4,0x2c,0x02,0x3d,0xf4,0x31,0x02,0x28,0xf4,0x37,0x02,0x12,0xf4,0x3c,0x02,0xfd,0xf3,0x42,0x02,0xe7,0xf3,0x48,0x02,0xd1,0xf3,0x4d,0x02,0xbc,0xf3,0x53,0x02,0xa6,0xf3,0x59,0x02,0x91,0xf3,  \
    0x5e,0x02,0x7b,0xf3,0x64,0x02,0x66,0xf3,0x6a,0x02,0x50,0xf3,0x70,0x02,0x3a,0xf3,0x75,0x02,0x24,0xf3,0x7b,0x02,0x0e,0xf3,0x80,0x02,0xf8,0xf2,0x86,0x02,0xe1,0xf2,0x8c,0x02,0xcb,0xf2,0x91,0x02,0xb4,0xf2,0x96,0x02,0x9d,0xf2,0x9c,0x02,0x86,0xf2,0xa1,0x02,0x70,0xf2,0xa7,0x02,0x58,0xf2,0xac,0x02,0x41,0xf2,0xb1,0x02,0x2a,0xf2,0xb6,0x02,0x12,0xf2,0xbc,0x02,0xfb,0xf1,0xc1,0x02,0xe3,0xf1,0xc6,0x02,0xcc,0xf1,0xcb,0x02,0xb4,0xf1,0xd0,0x02,0x9c,0xf1,0xd5,0x02,  \
    0x83,0xf1,0xda,0x02,0x6b,0xf1,0xdf,0x02,0x53,0xf1,0xe3,0x02,0x3a,0xf1,0xe8,0x02,0x21,0xf1,0xed,0x02,0x08,0xf1,0xf1,0x02,0xef,0xf0,0xf6,0x02,0xd6,0xf0,0xfa,0x02,0xbd,0xf0,0xfe,0x02,0xa3,0xf0,0x03,0x03,0x8a,0xf0,0x07,0x03,0x70,0xf0,0x0b,0x03,0x56,0xf0,0x0f,0x03,0x3c,0xf0,0x13,0x03,0x22,0xf0,0x16,0x03,0x07,0xf0,0x1a,0x03,0xec,0xef,0x1d,0x03,0xd2,0xef,0x21,0x03,0xb6,0xef,0x24,0x03,0x9b,0xef,0x27,0x03,0x80,0xef,0x2a,0x03,0x64,0xef,0x2d,0x03,0x49,0xef,  \
    0x30,0x03,0x2d,0xef,0x33,0x03,0x11,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x5c,0x03,0xdb,0x10,0x59,0x03,0xbe,0x10,0x56,0x03,0xa2,0x10,0x53,0x03,0x87,0x10,0x50,0x03,0x6b,0x10,0x4d,0x03,  \
    0x4f,0x10,0x49,0x03,0x34,0x10,0x46,0x03,0x19,0x10,0x43,0x03,0xfd,0x0f,0x3f,0x03,0xe2,0x0f,0x3b,0x03,0xc7,0x0f,0x38,0x03,0xad,0x0f,0x34,0x03,0x92,0x0f,0x30,0x03,0x78,0x0f,0x2c,0x03,0x5d,0x0f,0x28,0x03,0x43,0x0f,0x24,0x03,0x29,0x0f,0x1f,0x03,0x0f,0x0f,0x1b,0x03,0xf5,0x0e,0x17,0x03,0xdb,0x0e,0x12,0x03,0xc2,0x0e,0x0e,0x03,0xa9,0x0e,0x09,0x03,0x8f,0x0e,0x04,0x03,0x76,0x0e,0xff,0x02,0x5e,0x0e,0xfb,0x02,0x45,0x0e,0xf6,0x02,0x2c,0x0e,0xf1,0x02,0x14,0x0e,  \
    0xec,0x02,0xfb,0x0d,0xe7,0x02,0xe3,0x0d,0xe1,0x02,0xcb,0x0d,0xdc,0x02,0xb3,0x0d,0xd7,0x02,0x9b,0x0d,0xd2,0x02,0x84,0x0d,0xcc,0x02,0x6c,0x0d,0xc7,0x02,0x54,0x0d,0xc1,0x02,0x3d,0x0d,0xbc,0x02,0x26,0x0d,0xb6,0x02,0x0f,0x0d,0xb1,0x02,0xf8,0x0c,0xab,0x02,0xe1,0x0c,0xa5,0x02,0xcb,0x0c,0xa0,0x02,0xb4,0x0c,0x9a,0x02,0x9e,0x0c,0x94,0x02,0x88,0x0c,0x8e,0x02,0x72,0x0c,0x88,0x02,0x5c,0x0c,0x82,0x02,0x47,0x0c,0x7c,0x02,0x31,0x0c,0x76,0x02,0x1c,0x0c,0x6f,0x02,  \
    0x06,0x0c,0x69,0x02,0xf1,0x0b,0x63,0x02,0xdc,0x0b,0x5d,0x02,0xc7,0x0b,0x57,0x02,0xb2,0x0b,0x51,0x02,0x9d,0x0b,0x4a,0x02,0x89,0x0b,0x44,0x02,0x74,0x0b,0x3f,0x02,0x5e,0x0b,0x39,0x02,0x49,0x0b,0x33,0x02,0x34,0x0b,0x2d,0x02,0x1e,0x0b,0x28,0x02,0x09,0x0b,0x22,0x02,0xf4,0x0a,0x1c,0x02,0xdf,0x0a,0x17,0x02,0xca,0x0a,0x11,0x02,0xb5,0x0a,0x0b,0x02,0xa1,0x0a,0x05,0x02,0x8c,0x0a,0x00,0x02,0x77,0x0a,0xfa,0x01,0x63,0x0a,0xf4,0x01,0x4f,0x0a,0xee,0x01,0x3a,0x0a,  \
    0xe9,0x01,0x26,0x0a,0xe3,0x01,0x12,0x0a,0xdd,0x01,0xfe,0x09,0xd8,0x01,0xea,0x09,0xd2,0x01,0xd6,0x09,0xcc,0x01,0xc2,0x09,0xc7,0x01,0xae,0x09,0xc1,0x01,0x9b,0x09,0xbb,0x01,0x87,0x09,0xb6,0x01,0x73,0x09,0xb0,0x01,0x60,0x09,0xaa,0x01,0x4c,0x09,0xa5,0x01,0x39,0x09,0x9f,0x01,0x26,0x09,0x99,0x01,0x13,0x09,0x94,0x01,0x00,0x09,0x8e,0x01,0xec,0x08,0x89,0x01,0xda,0x08,0x83,0x01,0xc7,0x08,0x7e,0x01,0xb4,0x08,0x78,0x01,0xa1,0x08,0x72,0x01,0x8f,0x08,0x6c,0x01,  \
    0x7e,0x08,0x66,0x01,0x6c,0x08,0x61,0x01,0x5b,0x08,0x5b,0x01,0x49,0x08,0x55,0x01,0x38,0x08,0x4f,0x01,0x27,0x08,0x49,0x01,0x16,0x08,0x44,0x01,0x05,0x08,0x3e,0x01,0xf3,0x07,0x38,0x01,0xe2,0x07,0x33,0x01,0xd1,0x07,0x2d,0x01,0xc1,0x07,0x27,0x01,0xb0,0x07,0x22,0x01,0x9f,0x07,0x1c,0x01,0x8e,0x07,0x17,0x01,0x7e,0x07,0x11,0x01,0x6d,0x07,0x0c,0x01,0x5c,0x07,0x07,0x01,0x4c,0x07,0x01,0x01,0x3b,0x07,0xfc,0x00,0x2b,0x07,0xf7,0x00,0x1a,0x07,0xf2,0x00,0x0a,0x07,  \
    0xed,0x00,0xfa,0x06,0xe7,0x00,0xe9,0x06,0xe2,0x00,0xd9,0x06,0xdd,0x00,0xc9,0x06,0xd8,0x00,0xb8,0x06,0xd3,0x00,0xa8,0x06,0xce,0x00,0x98,0x06,0xc9,0x00,0x88,0x06,0xc4,0x00,0x78,0x06,0xc0,0x00,0x68,0x06,0xbb,0x00,0x58,0x06,0xb6,0x00,0x48,0x06,0xb1,0x00,0x38,0x06,0xad,0x00,0x28,0x06,0xa8,0x00,0x19,0x06,0xa3,0x00,0x09,0x06,0x9f,0x00,0xf9,0x05,0x9a,0x00,0xe9,0x05,0x96,0x00,0xda,0x05,0x92,0x00,0xc9,0x05,0x8d,0x00,0xb9,0x05,0x89,0x00,0xa9,0x05,0x85,0x00,  \
    0x99,0x05,0x81,0x00,0x89,0x05,0x7d,0x00,0x79,0x05,0x79,0x00,0x69,0x05,0x75,0x00,0x59,0x05,0x71,0x00,0x49,0x05,0x6d,0x00,0x39,0x05,0x69,0x00,0x29,0x05,0x65,0x00,0x19,0x05,0x61,0x00,0x09,0x05,0x5d,0x00,0xf9,0x04,0x59,0x00,0xea,0x04,0x56,0x00,0xda,0x04,0x52,0x00,0xca,0x04,0x4e,0x00,0xbb,0x04,0x4a,0x00,0xab,0x04,0x47,0x00,0x9c,0x04,0x43,0x00,0x8c,0x04,0x40,0x00,0x7d,0x04,0x3c,0x00,0x6d,0x04,0x39,0x00,0x5e,0x04,0x35,0x00,0x4f,0x04,0x32,0x00,0x40,0x04,  \
    0x2e,0x00,0x31,0x04,0x2b,0x00,0x22,0x04,0x28,0x00,0x13,0x04,0x24,0x00,0x04,0x04,0x21,0x00,0xf6,0x03,0x1e,0x00,0xe7,0x03,0x1b,0x00,0xd8,0x03,0x18,0x00,0xc9,0x03,0x15,0x00,0xbb,0x03,0x11,0x00,0xac,0x03,0x0e,0x00,0x9d,0x03,0x0c,0x00,0x8f,0x03,0x09,0x00,0x80,0x03,0x06,0x00,0x71,0x03,0x03,0x00,0x63,0x03,0x00,0x00,0x54,0x03,0xfd,0xff,0x45,0x03,0xfb,0xff,0x37,0x03,0xf8,0xff,0x28,0x03,0xf5,0xff,0x1a,0x03,0xf3,0xff,0x0b,0x03,0xf0,0xff,0xfd,0x02,0xee,0xff,  \
    0xee,0x02,0xeb,0xff,0xe0,0x02,0xe9,0xff,0xd2,0x02,0xe6,0xff,0xc4,0x02,0xe4,0xff,0xb6,0x02,0xe2,0xff,0xa8,0x02,0xdf,0xff,0x9a,0x02,0xdd,0xff,0x8c,0x02,0xdb,0xff,0x7e,0x02,0xd9,0xff,0x70,0x02,0xd7,0xff,0x62,0x02,0xd5,0xff,0x54,0x02,0xd3,0xff,0x46,0x02,0xd1,0xff,0x38,0x02,0xcf,0xff,0x2a,0x02,0xcd,0xff,0x1c,0x02,0xcb,0xff,0x0e,0x02,0xc9,0xff,0xff,0x01,0xc8,0xff,0xf1,0x01,0xc6,0xff,0xe3,0x01,0xc4,0xff,0xd5,0x01,0xc3,0xff,0xc7,0x01,0xc1,0xff,0xb9,0x01,  \
    0xc0,0xff,0xab,0x01,0xbe,0xff,0x9d,0x01,0xbd,0xff,0x8f,0x01,0xbc,0xff,0x81,0x01,0xba,0xff,0x73,0x01,0xb9,0xff,0x65,0x01,0xb8,0xff,0x56,0x01,0xb7,0xff,0x48,0x01,0xb5,0xff,0x3a,0x01,0xb4,0xff,0x2b,0x01,0xb3,0xff,0x1d,0x01,0xb2,0xff,0x0f,0x01,0xb1,0xff,0x00,0x01,0xb0,0xff,0xf2,0x00,0xb0,0xff,0xe4,0x00,0xaf,0xff,0xd6,0x00,0xae,0xff,0xc7,0x00,0xad,0xff,0xb9,0x00,0xac,0xff,0xab,0x00,0xac,0xff,0x9c,0x00,0xab,0xff,0x8e,0x00,0xab,0xff,0x80,0x00,0xaa,0xff,  \
    0x72,0x00,0xaa,0xff,0x63,0x00,0xa9,0xff,0x55,0x00,0xa9,0xff,0x47,0x00,0xa8,0xff,0x39,0x00,0xa8,0xff,0x2a,0x00,0xa8,0xff,0x1c,0x00,0xa7,0xff,0x0e,0x00,0xa7,0xff,0x00,0x00,0xa7,0xff,0xf1,0xff,0xa7,0xff,0xe3,0xff,0xa7,0xff,0xd5,0xff,0xa7,0xff,0xc7,0xff,0xa7,0xff,0xb8,0xff,0xa7,0xff,0xaa,0xff,0xa7,0xff,0x9c,0xff,0xa7,0xff,0x8e,0xff,0xa7,0xff,0x7f,0xff,0xa8,0xff,0x71,0xff,0xa8,0xff,0x63,0xff,0xa8,0xff,0x55,0xff,0xa8,0xff,0x46,0xff,0xa9,0xff,0x38,0xff,  \
    0xa9,0xff,0x2a,0xff,0xaa,0xff,0x1c,0xff,0xaa,0xff,0x0d,0xff,0xab,0xff,0xff,0xfe,0xab,0xff,0xf1,0xfe,0xac,0xff,0xe3,0xfe,0xad,0xff,0xd4,0xfe,0xad,0xff,0xc6,0xfe,0xae,0xff,0xb8,0xfe,0xaf,0xff,0xaa,0xfe,0xb0,0xff,0x9b,0xfe,0xb1,0xff,0x8d,0xfe,0xb1,0xff,0x7f,0xfe,0xb2,0xff,0x70,0xfe,0xb3,0xff,0x62,0xfe,0xb5,0xff,0x54,0xfe,0xb6,0xff,0x46,0xfe,0xb7,0xff,0x37,0xfe,0xb8,0xff,0x29,0xfe,0xb9,0xff,0x1a,0xfe,0xba,0xff,0x0c,0xfe,0xbc,0xff,0xfd,0xfd,0xbd,0xff,  \
    0xef,0xfd,0xbe,0xff,0xe1,0xfd,0xc0,0xff,0xd2,0xfd,0xc1,0xff,0xc4,0xfd,0xc3,0xff,0xb5,0xfd,0xc4,0xff,0xa6,0xfd,0xc6,0xff,0x98,0xfd,0xc7,0xff,0x89,0xfd,0xc9,0xff,0x7b,0xfd,0xcb,0xff,0x6c,0xfd,0xcc,0xff,0x5d,0xfd,0xce,0xff,0x4f,0xfd,0xd0,0xff,0x40,0xfd,0xd2,0xff,0x32,0xfd,0xd4,0xff,0x23,0xfd,0xd6,0xff,0x14,0xfd,0xd8,0xff,0x05,0xfd,0xda,0xff,0xf7,0xfc,0xdc,0xff,0xe8,0xfc,0xde,0xff,0xd9,0xfc,0xe0,0xff,0xca,0xfc,0xe2,0xff,0xbc,0xfc,0xe4,0xff,0xad,0xfc,  \
    0xe6,0xff,0x9e,0xfc,0xe9,0xff,0x90,0xfc,0xeb,0xff,0x81,0xfc,0xee,0xff,0x73,0xfc,0xf0,0xff,0x64,0xfc,0xf3,0xff,0x56,0xfc,0xf5,0xff,0x47,0xfc,0xf8,0xff,0x39,0xfc,0xfa,0xff,0x2a,0xfc,0xfd,0xff,0x1b,0xfc,0x00,0x00,0x0d,0xfc,0x02,0x00,0xfe,0xfb,0x05,0x00,0xf0,0xfb,0x08,0x00,0xe1,0xfb,0x0b,0x00,0xd2,0xfb,0x0e,0x00,0xc4,0xfb,0x11,0x00,0xb5,0xfb,0x14,0x00,0xa6,0xfb,0x17,0x00,0x98,0xfb,0x1a,0x00,0x89,0xfb,0x1d,0x00,0x7a,0xfb,0x20,0x00,0x6b,0xfb,0x23,0x00,  \
    0x5d,0xfb,0x27,0x00,0x4e,0xfb,0x2a,0x00,0x3f,0xfb,0x2d,0x00,0x30,0xfb,0x31,0x00,0x21,0xfb,0x34,0x00,0x12,0xfb,0x38,0x00,0x03,0xfb,0x3b,0x00,0xf3,0xfa,0x3e,0x00,0xe4,0xfa,0x42,0x00,0xd5,0xfa,0x46,0x00,0xc6,0xfa,0x49,0x00,0xb6,0xfa,0x4d,0x00,0xa7,0xfa,0x50,0x00,0x97,0xfa,0x54,0x00,0x88,0xfa,0x58,0x00,0x79,0xfa,0x5c,0x00,0x69,0xfa,0x60,0x00,0x5a,0xfa,0x63,0x00,0x4a,0xfa,0x67,0x00,0x3a,0xfa,0x6b,0x00,0x2b,0xfa,0x6f,0x00,0x1b,0xfa,0x73,0x00,0x0b,0xfa,  \
    0x77,0x00,0xfc,0xf9,0x7b,0x00,0xec,0xf9,0x80,0x00,0xdc,0xf9,0x84,0x00,0xcc,0xf9,0x88,0x00,0xbd,0xf9,0x8c,0x00,0xad,0xf9,0x90,0x00,0x9d,0xf9,0x95,0x00,0x8d,0xf9,0x99,0x00,0x7d,0xf9,0x9e,0x00,0x6e,0xf9,0xa2,0x00,0x5e,0xf9,0xa7,0x00,0x4e,0xf9,0xab,0x00,0x3e,0xf9,0xb0,0x00,0x2e,0xf9,0xb4,0x00,0x1e,0xf9,0xb9,0x00,0x0e,0xf9,0xbe,0x00,0xfe,0xf8,0xc3,0x00,0xee,0xf8,0xc7,0x00,0xdd,0xf8,0xcc,0x00,0xcd,0xf8,0xd1,0x00,0xbd,0xf8,0xd6,0x00,0xad,0xf8,0xdb,0x00,  \
    0x9c,0xf8,0xe0,0x00,0x8c,0xf8,0xe5,0x00,0x7b,0xf8,0xea,0x00,0x6b,0xf8,0xef,0x00,0x5a,0xf8,0xf4,0x00,0x4a,0xf8,0xf9,0x00,0x39,0xf8,0xfe,0x00,0x28,0xf8,0x03,0x01,0x17,0xf8,0x08,0x01,0x06,0xf8,0x0d,0x01,0xf5,0xf7,0x12,0x01,0xe4,0xf7,0x18,0x01,0xd3,0xf7,0x1d,0x01,0xc1,0xf7,0x22,0x01,0xb0,0xf7,0x27,0x01,0x9f,0xf7,0x2d,0x01,0x8d,0xf7,0x32,0x01,0x7c,0xf7,0x37,0x01,0x6a,0xf7,0x3d,0x01,0x59,0xf7,0x42,0x01,0x47,0xf7,0x48,0x01,0x35,0xf7,0x4d,0x01,0x23,0xf7,  \
    0x52,0x01,0x12,0xf7,0x58,0x01,0x00,0xf7,0x5d,0x01,0xee,0xf6,0x63,0x01,0xdc,0xf6,0x69,0x01,0xc9,0xf6,0x6e,0x01,0xb7,0xf6,0x74,0x01,0xa5,0xf6,0x7a,0x01,0x93,0xf6,0x7f,0x01,0x81,0xf6,0x85,0x01,0x6f,0xf6,0x8b,0x01,0x5c,0xf6,0x90,0x01,0x4a,0xf6,0x96,0x01,0x37,0xf6,0x9c,0x01,0x25,0xf6,0xa2,0x01,0x12,0xf6,0xa8,0x01,0xff,0xf5,0xad,0x01,0xed,0xf5,0xb3,0x01,0xda,0xf5,0xb9,0x01,0xc7,0xf5,0xbf,0x01,0xb4,0xf5,0xc5,0x01,0xa1,0xf5,0xcb,0x01,0x8d,0xf5,0xd1,0x01,  \
    0x7a,0xf5,0xd7,0x01,0x67,0xf5,0xdc,0x01,0x53,0xf5,0xe2,0x01,0x3f,0xf5,0xe8,0x01,0x2b,0xf5,0xed,0x01,0x16,0xf5,0xf3,0x01,0x02,0xf5,0xf9,0x01,0xee,0xf4,0xfe,0x01,0xd9,0xf4,0x04,0x02,0xc4,0xf4,0x09,0x02,0xaf,0xf4,0x0f,0x02,0x9b,0xf4,0x14,0x02,0x86,0xf4,0x1a,0x02,0x71,0xf4,0x20,0x02,0x5b,0xf4,0x25,0x02,0x46,0xf4,0x2b,0x02,0x31,0xf4,0x30,0x02,0x1b,0xf4,0x36,0x02,0x06,0xf4,0x3b,0x02,0xf0,0xf3,0x41,0x02,0xdb,0xf3,0x46,0x02,0xc5,0xf3,0x4c,0x02,0xb0,0xf3,  \
    0x52,0x02,0x9a,0xf3,0x58,0x02,0x84,0xf3,0x5d,0x02,0x6f,0xf3,0x63,0x02,0x59,0xf3,0x69,0x02,0x43,0xf3,0x6e,0x02,0x2d,0xf3,0x74,0x02,0x17,0xf3,0x79,0x02,0x01,0xf3,0x7f,0x02,0xea,0xf2,0x84,0x02,0xd4,0xf2,0x8a,0x02,0xbd,0xf2,0x8f,0x02,0xa6,0xf2,0x94,0x02,0x8f,0xf2,0x9a,0x02,0x78,0xf2,0x9f,0x02,0x61,0xf2,0xa4,0x02,0x4a,0xf2,0xaa,0x02,0x33,0xf2,0xaf,0x02,0x1b,0xf2,0xb4,0x02,0x04,0xf2,0xb9,0x02,0xec,0xf1,0xbe,0x02,0xd4,0xf1,0xc3,0x02,0xbc,0xf1,0xc8,0x02,  \
    0xa4,0xf1,0xcd,0x02,0x8c,0xf1,0xd2,0x02,0x74,0xf1,0xd6,0x02,0x5b,0xf1,0xdb,0x02,0x42,0xf1,0xe0,0x02,0x2a,0xf1,0xe4,0x02,0x11,0xf1,0xe9,0x02,0xf8,0xf0,0xed,0x02,0xdf,0xf0,0xf2,0x02,0xc5,0xf0,0xf6,0x02,0xac,0xf0,0xfa,0x02,0x92,0xf0,0xfe,0x02,0x78,0xf0,0x02,0x03,0x5e,0xf0,0x06,0x03,0x44,0xf0,0x0a,0x03,0x2a,0xf0,0x0e,0x03,0x0f,0xf0,0x11,0x03,0xf5,0xef,0x15,0x03,0xda,0xef,0x18,0x03,0xbe,0xef,0x1b,0x03,0xa3,0xef,0x1f,0x03,0x88,0xef,0x22,0x03,0x6c,0xef,  \
    0x25,0x03,0x51,0xef,0x28,0x03,0x35,0xef,0x2a,0x03,0x19,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x54,0x03,0xd3,0x10,0x51,0x03,0xb7,0x10,0x4e,0x03,0x9b,0x10,0x4b,0x03,0x7f,0x10,0x48,0x03,  \
    0x63,0x10,0x45,0x03,0x48,0x10,0x42,0x03,0x2c,0x10,0x3e,0x03,0x11,0x10,0x3b,0x03,0xf6,0x0f,0x37,0x03,0xdb,0x0f,0x33,0x03,0xc0,0x0f,0x30,0x03,0xa5,0x0f,0x2c,0x03,0x8b,0x0f,0x28,0x03,0x70,0x0f,0x24,0x03,0x56,0x0f,0x20,0x03,0x3b,0x0f,0x1c,0x03,0x21,0x0f,0x18,0x03,0x07,0x0f,0x14,0x03,0xed,0x0e,0x0f,0x03,0xd4,0x0e,0x0b,0x03,0xba,0x0e,0x06,0x03,0xa1,0x0e,0x02,0x03,0x88,0x0e,0xfd,0x02,0x6f,0x0e,0xf8,0x02,0x56,0x0e,0xf3,0x02,0x3d,0x0e,0xee,0x02,0x24,0x0e,  \
    0xe9,0x02,0x0c,0x0e,0xe4,0x02,0xf4,0x0d,0xdf,0x02,0xdb,0x0d,0xda,0x02,0xc3,0x0d,0xd5,0x02,0xab,0x0d,0xd0,0x02,0x93,0x0d,0xcb,0x02,0x7c,0x0d,0xc5,0x02,0x64,0x0d,0xc0,0x02,0x4c,0x0d,0xbb,0x02,0x35,0x0d,0xb5,0x02,0x1e,0x0d,0xb0,0x02,0x07,0x0d,0xaa,0x02,0xf0,0x0c,0xa4,0x02,0xd9,0x0c,0x9f,0x02,0xc2,0x0c,0x99,0x02,0xac,0x0c,0x93,0x02,0x96,0x0c,0x8d,0x02,0x80,0x0c,0x87,0x02,0x6a,0x0c,0x81,0x02,0x54,0x0c,0x7b,0x02,0x3e,0x0c,0x75,0x02,0x29,0x0c,0x6f,0x02,  \
    0x13,0x0c,0x69,0x02,0xfe,0x0b,0x63,0x02,0xe8,0x0b,0x5d,0x02,0xd3,0x0b,0x57,0x02,0xbe,0x0b,0x51,0x02,0xa9,0x0b,0x4b,0x02,0x94,0x0b,0x44,0x02,0x80,0x0b,0x3e,0x02,0x6b,0x0b,0x39,0x02,0x55,0x0b,0x33,0x02,0x40,0x0b,0x2d,0x02,0x2b,0x0b,0x28,0x02,0x15,0x0b,0x22,0x02,0x00,0x0b,0x1c,0x02,0xeb,0x0a,0x17,0x02,0xd6,0x0a,0x11,0x02,0xc1,0x0a,0x0b,0x02,0xad,0x0a,0x05,0x02,0x98,0x0a,0x00,0x02,0x83,0x0a,0xfa,0x01,0x6f,0x0a,0xf4,0x01,0x5a,0x0a,0xef,0x01,0x46,0x0a,  \
    0xe9,0x01,0x32,0x0a,0xe3,0x01,0x1d,0x0a,0xdd,0x01,0x09,0x0a,0xd8,0x01,0xf5,0x09,0xd2,0x01,0xe1,0x09,0xcc,0x01,0xcd,0x09,0xc7,0x01,0xb9,0x09,0xc1,0x01,0xa6,0x09,0xbb,0x01,0x92,0x09,0xb6,0x01,0x7e,0x09,0xb0,0x01,0x6b,0x09,0xaa,0x01,0x57,0x09,0xa5,0x01,0x44,0x09,0x9f,0x01,0x31,0x09,0x9a,0x01,0x1d,0x09,0x94,0x01,0x0a,0x09,0x8f,0x01,0xf7,0x08,0x89,0x01,0xe4,0x08,0x83,0x01,0xd1,0x08,0x7e,0x01,0xbe,0x08,0x78,0x01,0xab,0x08,0x73,0x01,0x99,0x08,0x6d,0x01,  \
    0x87,0x08,0x67,0x01,0x76,0x08,0x61,0x01,0x64,0x08,0x5b,0x01,0x52,0x08,0x56,0x01,0x41,0x08,0x50,0x01,0x30,0x08,0x4a,0x01,0x1e,0x08,0x44,0x01,0x0d,0x08,0x3f,0x01,0xfc,0x07,0x39,0x01,0xeb,0x07,0x33,0x01,0xda,0x07,0x2e,0x01,0xc9,0x07,0x28,0x01,0xb8,0x07,0x23,0x01,0xa7,0x07,0x1d,0x01,0x97,0x07,0x18,0x01,0x86,0x07,0x12,0x01,0x75,0x07,0x0d,0x01,0x65,0x07,0x07,0x01,0x54,0x07,0x02,0x01,0x44,0x07,0xfd,0x00,0x33,0x07,0xf7,0x00,0x23,0x07,0xf2,0x00,0x12,0x07,  \
    0xed,0x00,0x02,0x07,0xe8,0x00,0xf1,0x06,0xe3,0x00,0xe1,0x06,0xde,0x00,0xd1,0x06,0xd9,0x00,0xc0,0x06,0xd4,0x00,0xb0,0x06,0xcf,0x00,0xa0,0x06,0xca,0x00,0x90,0x06,0xc5,0x00,0x80,0x06,0xc0,0x00,0x70,0x06,0xbb,0x00,0x60,0x06,0xb6,0x00,0x50,0x06,0xb2,0x00,0x40,0x06,0xad,0x00,0x30,0x06,0xa8,0x00,0x20,0x06,0xa4,0x00,0x11,0x06,0x9f,0x00,0x01,0x06,0x9b,0x00,0xf1,0x05,0x96,0x00,0xe2,0x05,0x92,0x00,0xd2,0x05,0x8d,0x00,0xc2,0x05,0x89,0x00,0xb2,0x05,0x85,0x00,  \
    0xa1,0x05,0x81,0x00,0x91,0x05,0x7d,0x00,0x81,0x05,0x78,0x00,0x71,0x05,0x74,0x00,0x61,0x05,0x70,0x00,0x51,0x05,0x6c,0x00,0x41,0x05,0x68,0x00,0x32,0x05,0x64,0x00,0x22,0x05,0x61,0x00,0x12,0x05,0x5d,0x00,0x02,0x05,0x59,0x00,0xf3,0x04,0x55,0x00,0xe3,0x04,0x51,0x00,0xd3,0x04,0x4e,0x00,0xc4,0x04,0x4a,0x00,0xb4,0x04,0x46,0x00,0xa4,0x04,0x43,0x00,0x95,0x04,0x3f,0x00,0x86,0x04,0x3c,0x00,0x76,0x04,0x38,0x00,0x67,0x04,0x35,0x00,0x57,0x04,0x31,0x00,0x48,0x04,  \
    0x2e,0x00,0x3a,0x04,0x2a,0x00,0x2b,0x04,0x27,0x00,0x1c,0x04,0x24,0x00,0x0d,0x04,0x20,0x00,0xfe,0x03,0x1d,0x00,0xf0,0x03,0x1a,0x00,0xe1,0x03,0x17,0x00,0xd2,0x03,0x14,0x00,0xc4,0x03,0x11,0x00,0xb5,0x03,0x0d,0x00,0xa6,0x03,0x0a,0x00,0x98,0x03,0x08,0x00,0x89,0x03,0x05,0x00,0x7a,0x03,0x02,0x00,0x6c,0x03,0xff,0xff,0x5d,0x03,0xfc,0xff,0x4f,0x03,0xf9,0xff,0x40,0x03,0xf7,0xff,0x32,0x03,0xf4,0xff,0x23,0x03,0xf1,0xff,0x15,0x03,0xef,0xff,0x07,0x03,0xec,0xff,  \
    0xf8,0x02,0xea,0xff,0xea,0x02,0xe7,0xff,0xdb,0x02,0xe5,0xff,0xcd,0x02,0xe3,0xff,0xbf,0x02,0xe0,0xff,0xb2,0x02,0xde,0xff,0xa4,0x02,0xdc,0xff,0x96,0x02,0xd9,0xff,0x88,0x02,0xd7,0xff,0x7a,0x02,0xd5,0xff,0x6c,0x02,0xd3,0xff,0x5e,0x02,0xd1,0xff,0x50,0x02,0xcf,0xff,0x42,0x02,0xcd,0xff,0x34,0x02,0xcb,0xff,0x26,0x02,0xc9,0xff,0x18,0x02,0xc7,0xff,0x0a,0x02,0xc6,0xff,0xfc,0x01,0xc4,0xff,0xee,0x01,0xc2,0xff,0xe0,0x01,0xc1,0xff,0xd2,0x01,0xbf,0xff,0xc4,0x01,  \
    0xbd,0xff,0xb6,0x01,0xbc,0xff,0xa8,0x01,0xba,0xff,0x9a,0x01,0xb9,0xff,0x8c,0x01,0xb8,0xff,0x7e,0x01,0xb6,0xff,0x70,0x01,0xb5,0xff,0x62,0x01,0xb4,0xff,0x54,0x01,0xb3,0xff,0x46,0x01,0xb2,0xff,0x37,0x01,0xb1,0xff,0x29,0x01,0xaf,0xff,0x1b,0x01,0xae,0xff,0x0d,0x01,0xae,0xff,0xfe,0x00,0xad,0xff,0xf0,0x00,0xac,0xff,0xe2,0x00,0xab,0xff,0xd4,0x00,0xaa,0xff,0xc6,0x00,0xa9,0xff,0xb7,0x00,0xa9,0xff,0xa9,0x00,0xa8,0xff,0x9b,0x00,0xa7,0xff,0x8d,0x00,0xa7,0xff,  \
    0x7f,0x00,0xa6,0xff,0x70,0x00,0xa6,0xff,0x62,0x00,0xa5,0xff,0x54,0x00,0xa5,0xff,0x46,0x00,0xa4,0xff,0x38,0x00,0xa4,0xff,0x2a,0x00,0xa4,0xff,0x1b,0x00,0xa4,0xff,0x0d,0x00,0xa3,0xff,0xff,0xff,0xa3,0xff,0xf1,0xff,0xa3,0xff,0xe3,0xff,0xa3,0xff,0xd5,0xff,0xa3,0xff,0xc6,0xff,0xa3,0xff,0xb8,0xff,0xa3,0xff,0xaa,0xff,0xa3,0xff,0x9c,0xff,0xa3,0xff,0x8e,0xff,0xa3,0xff,0x80,0xff,0xa4,0xff,0x72,0xff,0xa4,0xff,0x63,0xff,0xa4,0xff,0x55,0xff,0xa5,0xff,0x47,0xff,  \
    0xa5,0xff,0x39,0xff,0xa5,0xff,0x2b,0xff,0xa6,0xff,0x1d,0xff,0xa6,0xff,0x0f,0xff,0xa7,0xff,0x00,0xff,0xa7,0xff,0xf2,0xfe,0xa8,0xff,0xe4,0xfe,0xa9,0xff,0xd6,0xfe,0xa9,0xff,0xc8,0xfe,0xaa,0xff,0xba,0xfe,0xab,0xff,0xab,0xfe,0xac,0xff,0x9d,0xfe,0xad,0xff,0x8f,0xfe,0xae,0xff,0x81,0xfe,0xaf,0xff,0x73,0xfe,0xb0,0xff,0x65,0xfe,0xb1,0xff,0x56,0xfe,0xb2,0xff,0x48,0xfe,0xb3,0xff,0x3a,0xfe,0xb4,0xff,0x2b,0xfe,0xb5,0xff,0x1d,0xfe,0xb6,0xff,0x0f,0xfe,0xb8,0xff,  \
    0x00,0xfe,0xb9,0xff,0xf2,0xfd,0xba,0xff,0xe4,0xfd,0xbc,0xff,0xd5,0xfd,0xbd,0xff,0xc7,0xfd,0xbf,0xff,0xb8,0xfd,0xc0,0xff,0xaa,0xfd,0xc2,0xff,0x9b,0xfd,0xc3,0xff,0x8d,0xfd,0xc5,0xff,0x7e,0xfd,0xc7,0xff,0x70,0xfd,0xc8,0xff,0x61,0xfd,0xca,0xff,0x53,0xfd,0xcc,0xff,0x44,0xfd,0xce,0xff,0x36,0xfd,0xd0,0xff,0x27,0xfd,0xd2,0xff,0x19,0xfd,0xd4,0xff,0x0a,0xfd,0xd6,0xff,0xfb,0xfc,0xd8,0xff,0xed,0xfc,0xda,0xff,0xde,0xfc,0xdc,0xff,0xcf,0xfc,0xde,0xff,0xc1,0xfc,  \
    0xe0,0xff,0xb2,0xfc,0xe3,0xff,0xa3,0xfc,0xe5,0xff,0x95,0xfc,0xe7,0xff,0x87,0xfc,0xea,0xff,0x78,0xfc,0xec,0xff,0x6a,0xfc,0xef,0xff,0x5b,0xfc,0xf1,0xff,0x4d,0xfc,0xf4,0xff,0x3e,0xfc,0xf6,0xff,0x30,0xfc,0xf9,0xff,0x21,0xfc,0xfc,0xff,0x13,0xfc,0xfe,0xff,0x04,0xfc,0x01,0x00,0xf6,0xfb,0x04,0x00,0xe7,0xfb,0x07,0x00,0xd8,0xfb,0x0a,0x00,0xca,0xfb,0x0d,0x00,0xbb,0xfb,0x10,0x00,0xad,0xfb,0x13,0x00,0x9e,0xfb,0x16,0x00,0x8f,0xfb,0x19,0x00,0x81,0xfb,0x1c,0x00,  \
    0x72,0xfb,0x1f,0x00,0x63,0xfb,0x23,0x00,0x54,0xfb,0x26,0x00,0x46,0xfb,0x29,0x00,0x37,0xfb,0x2d,0x00,0x28,0xfb,0x30,0x00,0x19,0xfb,0x33,0x00,0x0a,0xfb,0x37,0x00,0xfb,0xfa,0x3a,0x00,0xeb,0xfa,0x3e,0x00,0xdc,0xfa,0x41,0x00,0xcd,0xfa,0x45,0x00,0xbe,0xfa,0x49,0x00,0xae,0xfa,0x4c,0x00,0x9f,0xfa,0x50,0x00,0x8f,0xfa,0x54,0x00,0x80,0xfa,0x57,0x00,0x71,0xfa,0x5b,0x00,0x61,0xfa,0x5f,0x00,0x52,0xfa,0x63,0x00,0x42,0xfa,0x67,0x00,0x33,0xfa,0x6b,0x00,0x23,0xfa,  \
    0x6f,0x00,0x13,0xfa,0x73,0x00,0x04,0xfa,0x77,0x00,0xf4,0xf9,0x7b,0x00,0xe4,0xf9,0x7f,0x00,0xd5,0xf9,0x84,0x00,0xc5,0xf9,0x88,0x00,0xb5,0xf9,0x8c,0x00,0xa5,0xf9,0x90,0x00,0x95,0xf9,0x95,0x00,0x86,0xf9,0x99,0x00,0x76,0xf9,0x9e,0x00,0x66,0xf9,0xa2,0x00,0x56,0xf9,0xa7,0x00,0x46,0xf9,0xab,0x00,0x36,0xf9,0xb0,0x00,0x26,0xf9,0xb5,0x00,0x16,0xf9,0xb9,0x00,0x06,0xf9,0xbe,0x00,0xf6,0xf8,0xc3,0x00,0xe6,0xf8,0xc8,0x00,0xd6,0xf8,0xcc,0x00,0xc6,0xf8,0xd1,0x00,  \
    0xb5,0xf8,0xd6,0x00,0xa5,0xf8,0xdb,0x00,0x95,0xf8,0xe0,0x00,0x84,0xf8,0xe5,0x00,0x74,0xf8,0xea,0x00,0x63,0xf8,0xef,0x00,0x53,0xf8,0xf4,0x00,0x42,0xf8,0xf9,0x00,0x31,0xf8,0xfe,0x00,0x20,0xf8,0x03,0x01,0x0f,0xf8,0x08,0x01,0xfe,0xf7,0x0e,0x01,0xed,0xf7,0x13,0x01,0xdc,0xf7,0x18,0x01,0xcb,0xf7,0x1d,0x01,0xb9,0xf7,0x22,0x01,0xa8,0xf7,0x28,0x01,0x96,0xf7,0x2d,0x01,0x85,0xf7,0x32,0x01,0x73,0xf7,0x38,0x01,0x62,0xf7,0x3d,0x01,0x50,0xf7,0x42,0x01,0x3e,0xf7,  \
    0x48,0x01,0x2d,0xf7,0x4d,0x01,0x1b,0xf7,0x53,0x01,0x09,0xf7,0x58,0x01,0xf7,0xf6,0x5e,0x01,0xe5,0xf6,0x63,0x01,0xd3,0xf6,0x69,0x01,0xc1,0xf6,0x6e,0x01,0xaf,0xf6,0x74,0x01,0x9c,0xf6,0x7a,0x01,0x8a,0xf6,0x7f,0x01,0x78,0xf6,0x85,0x01,0x66,0xf6,0x8b,0x01,0x53,0xf6,0x91,0x01,0x41,0xf6,0x96,0x01,0x2e,0xf6,0x9c,0x01,0x1b,0xf6,0xa2,0x01,0x09,0xf6,0xa8,0x01,0xf6,0xf5,0xad,0x01,0xe3,0xf5,0xb3,0x01,0xd0,0xf5,0xb9,0x01,0xbd,0xf5,0xbf,0x01,0xaa,0xf5,0xc5,0x01,  \
    0x97,0xf5,0xcb,0x01,0x83,0xf5,0xd0,0x01,0x70,0xf5,0xd6,0x01,0x5c,0xf5,0xdc,0x01,0x48,0xf5,0xe2,0x01,0x34,0xf5,0xe7,0x01,0x20,0xf5,0xed,0x01,0x0b,0xf5,0xf2,0x01,0xf7,0xf4,0xf8,0x01,0xe2,0xf4,0xfd,0x01,0xcd,0xf4,0x03,0x02,0xb9,0xf4,0x08,0x02,0xa4,0xf4,0x0e,0x02,0x8f,0xf4,0x14,0x02,0x7a,0xf4,0x19,0x02,0x65,0xf4,0x1f,0x02,0x4f,0xf4,0x24,0x02,0x3a,0xf4,0x2a,0x02,0x25,0xf4,0x2f,0x02,0x0f,0xf4,0x35,0x02,0xf9,0xf3,0x3a,0x02,0xe4,0xf3,0x40,0x02,0xce,0xf3,  \
    0x45,0x02,0xb9,0xf3,0x4b,0x02,0xa3,0xf3,0x51,0x02,0x8d,0xf3,0x56,0x02,0x78,0xf3,0x5c,0x02,0x62,0xf3,0x61,0x02,0x4c,0xf3,0x67,0x02,0x36,0xf3,0x6d,0x02,0x20,0xf3,0x72,0x02,0x09,0xf3,0x78,0x02,0xf3,0xf2,0x7d,0x02,0xdc,0xf2,0x82,0x02,0xc6,0xf2,0x88,0x02,0xaf,0xf2,0x8d,0x02,0x98,0xf2,0x92,0x02,0x81,0xf2,0x98,0x02,0x6a,0xf2,0x9d,0x02,0x53,0xf2,0xa2,0x02,0x3b,0xf2,0xa7,0x02,0x24,0xf2,0xac,0x02,0x0c,0xf2,0xb1,0x02,0xf4,0xf1,0xb6,0x02,0xdd,0xf1,0xbb,0x02,  \
    0xc5,0xf1,0xc0,0x02,0xac,0xf1,0xc5,0x02,0x94,0xf1,0xca,0x02,0x7c,0xf1,0xce,0x02,0x63,0xf1,0xd3,0x02,0x4b,0xf1,0xd8,0x02,0x32,0xf1,0xdc,0x02,0x19,0xf1,0xe1,0x02,0x00,0xf1,0xe5,0x02,0xe7,0xf0,0xe9,0x02,0xcd,0xf0,0xee,0x02,0xb4,0xf0,0xf2,0x02,0x9a,0xf0,0xf6,0x02,0x80,0xf0,0xfa,0x02,0x66,0xf0,0xfe,0x02,0x4c,0xf0,0x02,0x03,0x32,0xf0,0x05,0x03,0x17,0xf0,0x09,0x03,0xfc,0xef,0x0c,0x03,0xe1,0xef,0x0f,0x03,0xc6,0xef,0x13,0x03,0xab,0xef,0x16,0x03,0x90,0xef,  \
    0x19,0x03,0x74,0xef,0x1c,0x03,0x59,0xef,0x1f,0x03,0x3d,0xef,0x21,0x03,0x21,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x4c,0x03,0xcc,0x10,0x49,0x03,0xb0,0x10,0x46,0x03,0x94,0x10,0x43,0x03,  \
    0x78,0x10,0x40,0x03,0x5c,0x10,0x3d,0x03,0x41,0x10,0x3a,0x03,0x25,0x10,0x36,0x03,0x0a,0x10,0x33,0x03,0xef,0x0f,0x2f,0x03,0xd4,0x0f,0x2c,0x03,0xb9,0x0f,0x28,0x03,0x9e,0x0f,0x24,0x03,0x83,0x0f,0x20,0x03,0x69,0x0f,0x1c,0x03,0x4e,0x0f,0x18,0x03,0x34,0x0f,0x14,0x03,0x1a,0x0f,0x10,0x03,0x00,0x0f,0x0c,0x03,0xe6,0x0e,0x08,0x03,0xcc,0x0e,0x03,0x03,0xb3,0x0e,0xff,0x02,0x99,0x0e,0xfa,0x02,0x80,0x0e,0xf5,0x02,0x67,0x0e,0xf1,0x02,0x4e,0x0e,0xec,0x02,0x35,0x0e,  \
    0xe7,0x02,0x1d,0x0e,0xe2,0x02,0x04,0x0e,0xdd,0x02,0xec,0x0d,0xd8,0x02,0xd4,0x0d,0xd3,0x02,0xbb,0x0d,0xce,0x02,0xa3,0x0d,0xc9,0x02,0x8c,0x0d,0xc4,0x02,0x74,0x0d,0xbe,0x02,0x5c,0x0d,0xb9,0x02,0x45,0x0d,0xb4,0x02,0x2d,0x0d,0xae,0x02,0x16,0x0d,0xa9,0x02,0xff,0x0c,0xa3,0x02,0xe8,0x0c,0x9e,0x02,0xd1,0x0c,0x98,0x02,0xba,0x0c,0x92,0x02,0xa4,0x0c,0x8c,0x02,0x8e,0x0c,0x87,0x02,0x78,0x0c,0x81,0x02,0x62,0x0c,0x7b,0x02,0x4c,0x0c,0x75,0x02,0x36,0x0c,0x6f,0x02,  \
    0x20,0x0c,0x69,0x02,0x0b,0x0c,0x63,0x02,0xf5,0x0b,0x5d,0x02,0xe0,0x0b,0x57,0x02,0xcb,0x0b,0x51,0x02,0xb6,0x0b,0x4b,0x02,0xa1,0x0b,0x45,0x02,0x8c,0x0b,0x3e,0x02,0x77,0x0b,0x38,0x02,0x62,0x0b,0x33,0x02,0x4d,0x0b,0x2d,0x02,0x37,0x0b,0x27,0x02,0x22,0x0b,0x22,0x02,0x0d,0x0b,0x1c,0x02,0xf8,0x0a,0x16,0x02,0xe3,0x0a,0x11,0x02,0xce,0x0a,0x0b,0x02,0xb9,0x0a,0x05,0x02,0xa4,0x0a,0x00,0x02,0x8f,0x0a,0xfa,0x01,0x7b,0x0a,0xf4,0x01,0x66,0x0a,0xef,0x01,0x52,0x0a,  \
    0xe9,0x01,0x3d,0x0a,0xe3,0x01,0x29,0x0a,0xde,0x01,0x15,0x0a,0xd8,0x01,0x01,0x0a,0xd2,0x01,0xed,0x09,0xcd,0x01,0xd9,0x09,0xc7,0x01,0xc5,0x09,0xc1,0x01,0xb1,0x09,0xbc,0x01,0x9d,0x09,0xb6,0x01,0x89,0x09,0xb0,0x01,0x76,0x09,0xab,0x01,0x62,0x09,0xa5,0x01,0x4f,0x09,0xa0,0x01,0x3b,0x09,0x9a,0x01,0x28,0x09,0x94,0x01,0x15,0x09,0x8f,0x01,0x02,0x09,0x89,0x01,0xef,0x08,0x84,0x01,0xdc,0x08,0x7e,0x01,0xc9,0x08,0x79,0x01,0xb6,0x08,0x73,0x01,0xa3,0x08,0x6e,0x01,  \
    0x91,0x08,0x68,0x01,0x7f,0x08,0x62,0x01,0x6d,0x08,0x5c,0x01,0x5c,0x08,0x56,0x01,0x4a,0x08,0x51,0x01,0x39,0x08,0x4b,0x01,0x27,0x08,0x45,0x01,0x16,0x08,0x40,0x01,0x05,0x08,0x3a,0x01,0xf4,0x07,0x34,0x01,0xe3,0x07,0x2f,0x01,0xd2,0x07,0x29,0x01,0xc1,0x07,0x24,0x01,0xb0,0x07,0x1e,0x01,0x9f,0x07,0x19,0x01,0x8e,0x07,0x13,0x01,0x7e,0x07,0x0e,0x01,0x6d,0x07,0x08,0x01,0x5c,0x07,0x03,0x01,0x4c,0x07,0xfe,0x00,0x3b,0x07,0xf8,0x00,0x2b,0x07,0xf3,0x00,0x1a,0x07,  \
    0xee,0x00,0x0a,0x07,0xe9,0x00,0xf9,0x06,0xe4,0x00,0xe9,0x06,0xdf,0x00,0xd9,0x06,0xd9,0x00,0xc8,0x06,0xd4,0x00,0xb8,0x06,0xcf,0x00,0xa8,0x06,0xcb,0x00,0x98,0x06,0xc6,0x00,0x88,0x06,0xc1,0x00,0x78,0x06,0xbc,0x00,0x68,0x06,0xb7,0x00,0x58,0x06,0xb2,0x00,0x48,0x06,0xae,0x00,0x38,0x06,0xa9,0x00,0x28,0x06,0xa4,0x00,0x19,0x06,0xa0,0x00,0x09,0x06,0x9b,0x00,0xf9,0x05,0x96,0x00,0xe9,0x05,0x92,0x00,0xda,0x05,0x8e,0x00,0xca,0x05,0x89,0x00,0xba,0x05,0x85,0x00,  \
    0xaa,0x05,0x81,0x00,0x9a,0x05,0x7d,0x00,0x8a,0x05,0x79,0x00,0x7a,0x05,0x74,0x00,0x6a,0x05,0x70,0x00,0x5a,0x05,0x6c,0x00,0x4a,0x05,0x68,0x00,0x3a,0x05,0x64,0x00,0x2a,0x05,0x61,0x00,0x1b,0x05,0x5d,0x00,0x0b,0x05,0x59,0x00,0xfb,0x04,0x55,0x00,0xec,0x04,0x51,0x00,0xdc,0x04,0x4d,0x00,0xcc,0x04,0x4a,0x00,0xbd,0x04,0x46,0x00,0xad,0x04,0x42,0x00,0x9e,0x04,0x3f,0x00,0x8e,0x04,0x3b,0x00,0x7f,0x04,0x38,0x00,0x70,0x04,0x34,0x00,0x60,0x04,0x31,0x00,0x51,0x04,  \
    0x2d,0x00,0x42,0x04,0x2a,0x00,0x33,0x04,0x27,0x00,0x25,0x04,0x23,0x00,0x16,0x04,0x20,0x00,0x07,0x04,0x1d,0x00,0xf8,0x03,0x19,0x00,0xea,0x03,0x16,0x00,0xdb,0x03,0x13,0x00,0xcd,0x03,0x10,0x00,0xbe,0x03,0x0d,0x00,0xaf,0x03,0x0a,0x00,0xa1,0x03,0x07,0x00,0x92,0x03,0x04,0x00,0x84,0x03,0x01,0x00,0x75,0x03,0xfe,0xff,0x67,0x03,0xfb,0xff,0x58,0x03,0xf8,0xff,0x4a,0x03,0xf6,0xff,0x3b,0x03,0xf3,0xff,0x2d,0x03,0xf0,0xff,0x1e,0x03,0xee,0xff,0x10,0x03,0xeb,0xff,  \
    0x02,0x03,0xe9,0xff,0xf3,0x02,0xe6,0xff,0xe5,0x02,0xe4,0xff,0xd7,0x02,0xe1,0xff,0xc9,0x02,0xdf,0xff,0xbb,0x02,0xdc,0xff,0xad,0x02,0xda,0xff,0x9f,0x02,0xd8,0xff,0x91,0x02,0xd6,0xff,0x83,0x02,0xd3,0xff,0x75,0x02,0xd1,0xff,0x68,0x02,0xcf,0xff,0x5a,0x02,0xcd,0xff,0x4c,0x02,0xcb,0xff,0x3e,0x02,0xc9,0xff,0x30,0x02,0xc7,0xff,0x22,0x02,0xc6,0xff,0x14,0x02,0xc4,0xff,0x06,0x02,0xc2,0xff,0xf8,0x01,0xc0,0xff,0xea,0x01,0xbf,0xff,0xdd,0x01,0xbd,0xff,0xcf,0x01,  \
    0xbb,0xff,0xc1,0x01,0xba,0xff,0xb3,0x01,0xb8,0xff,0xa5,0x01,0xb7,0xff,0x97,0x01,0xb5,0xff,0x89,0x01,0xb4,0xff,0x7b,0x01,0xb3,0xff,0x6d,0x01,0xb2,0xff,0x5f,0x01,0xb0,0xff,0x51,0x01,0xaf,0xff,0x43,0x01,0xae,0xff,0x35,0x01,0xad,0xff,0x27,0x01,0xac,0xff,0x19,0x01,0xab,0xff,0x0a,0x01,0xaa,0xff,0xfc,0x00,0xa9,0xff,0xee,0x00,0xa8,0xff,0xe0,0x00,0xa7,0xff,0xd2,0x00,0xa6,0xff,0xc4,0x00,0xa6,0xff,0xb6,0x00,0xa5,0xff,0xa8,0x00,0xa4,0xff,0x9a,0x00,0xa4,0xff,  \
    0x8b,0x00,0xa3,0xff,0x7d,0x00,0xa3,0xff,0x6f,0x00,0xa2,0xff,0x61,0x00,0xa2,0xff,0x53,0x00,0xa1,0xff,0x45,0x00,0xa1,0xff,0x37,0x00,0xa1,0xff,0x29,0x00,0xa0,0xff,0x1b,0x00,0xa0,0xff,0x0d,0x00,0xa0,0xff,0xff,0xff,0xa0,0xff,0xf1,0xff,0xa0,0xff,0xe3,0xff,0x9f,0xff,0xd5,0xff,0x9f,0xff,0xc6,0xff,0x9f,0xff,0xb8,0xff,0x9f,0xff,0xaa,0xff,0xa0,0xff,0x9c,0xff,0xa0,0xff,0x8e,0xff,0xa0,0xff,0x80,0xff,0xa0,0xff,0x72,0xff,0xa0,0xff,0x64,0xff,0xa1,0xff,0x56,0xff,  \
    0xa1,0xff,0x48,0xff,0xa1,0xff,0x3a,0xff,0xa2,0xff,0x2c,0xff,0xa2,0xff,0x1e,0xff,0xa3,0xff,0x10,0xff,0xa3,0xff,0x02,0xff,0xa4,0xff,0xf4,0xfe,0xa4,0xff,0xe6,0xfe,0xa5,0xff,0xd7,0xfe,0xa6,0xff,0xc9,0xfe,0xa7,0xff,0xbb,0xfe,0xa7,0xff,0xad,0xfe,0xa8,0xff,0x9f,0xfe,0xa9,0xff,0x91,0xfe,0xaa,0xff,0x83,0xfe,0xab,0xff,0x75,0xfe,0xac,0xff,0x67,0xfe,0xad,0xff,0x59,0xfe,0xae,0xff,0x4b,0xfe,0xaf,0xff,0x3c,0xfe,0xb0,0xff,0x2e,0xfe,0xb2,0xff,0x20,0xfe,0xb3,0xff,  \
    0x12,0xfe,0xb4,0xff,0x03,0xfe,0xb5,0xff,0xf5,0xfd,0xb7,0xff,0xe7,0xfd,0xb8,0xff,0xd8,0xfd,0xba,0xff,0xca,0xfd,0xbb,0xff,0xbc,0xfd,0xbd,0xff,0xad,0xfd,0xbe,0xff,0x9f,0xfd,0xc0,0xff,0x91,0xfd,0xc1,0xff,0x82,0xfd,0xc3,0xff,0x74,0xfd,0xc5,0xff,0x65,0xfd,0xc7,0xff,0x57,0xfd,0xc8,0xff,0x48,0xfd,0xca,0xff,0x3a,0xfd,0xcc,0xff,0x2b,0xfd,0xce,0xff,0x1d,0xfd,0xd0,0xff,0x0e,0xfd,0xd2,0xff,0x00,0xfd,0xd4,0xff,0xf1,0xfc,0xd6,0xff,0xe3,0xfc,0xd8,0xff,0xd4,0xfc,  \
    0xda,0xff,0xc5,0xfc,0xdd,0xff,0xb7,0xfc,0xdf,0xff,0xa8,0xfc,0xe1,0xff,0x9a,0xfc,0xe4,0xff,0x8c,0xfc,0xe6,0xff,0x7d,0xfc,0xe8,0xff,0x6f,0xfc,0xeb,0xff,0x61,0xfc,0xed,0xff,0x52,0xfc,0xf0,0xff,0x44,0xfc,0xf3,0xff,0x35,0xfc,0xf5,0xff,0x27,0xfc,0xf8,0xff,0x18,0xfc,0xfb,0xff,0x0a,0xfc,0xfd,0xff,0xfb,0xfb,0x00,0x00,0xed,0xfb,0x03,0x00,0xde,0xfb,0x06,0x00,0xd0,0xfb,0x09,0x00,0xc1,0xfb,0x0c,0x00,0xb3,0xfb,0x0f,0x00,0xa4,0xfb,0x12,0x00,0x96,0xfb,0x15,0x00,  \
    0x87,0xfb,0x18,0x00,0x78,0xfb,0x1c,0x00,0x6a,0xfb,0x1f,0x00,0x5b,0xfb,0x22,0x00,0x4c,0xfb,0x25,0x00,0x3e,0xfb,0x29,0x00,0x2f,0xfb,0x2c,0x00,0x20,0xfb,0x2f,0x00,0x11,0xfb,0x33,0x00,0x01,0xfb,0x36,0x00,0xf2,0xfa,0x3a,0x00,0xe3,0xfa,0x3d,0x00,0xd4,0xfa,0x41,0x00,0xc5,0xfa,0x45,0x00,0xb5,0xfa,0x48,0x00,0xa6,0xfa,0x4c,0x00,0x97,0xfa,0x50,0x00,0x88,0xfa,0x53,0x00,0x78,0xfa,0x57,0x00,0x69,0xfa,0x5b,0x00,0x59,0xfa,0x5f,0x00,0x4a,0xfa,0x63,0x00,0x3a,0xfa,  \
    0x67,0x00,0x2b,0xfa,0x6b,0x00,0x1b,0xfa,0x6f,0x00,0x0c,0xfa,0x73,0x00,0xfc,0xf9,0x77,0x00,0xec,0xf9,0x7b,0x00,0xdd,0xf9,0x7f,0x00,0xcd,0xf9,0x84,0x00,0xbd,0xf9,0x88,0x00,0xad,0xf9,0x8c,0x00,0x9e,0xf9,0x91,0x00,0x8e,0xf9,0x95,0x00,0x7e,0xf9,0x99,0x00,0x6e,0xf9,0x9e,0x00,0x5f,0xf9,0xa2,0x00,0x4f,0xf9,0xa7,0x00,0x3f,0xf9,0xac,0x00,0x2f,0xf9,0xb0,0x00,0x1f,0xf9,0xb5,0x00,0x0f,0xf9,0xba,0x00,0xff,0xf8,0xbe,0x00,0xef,0xf8,0xc3,0x00,0xdf,0xf8,0xc8,0x00,  \
    0xce,0xf8,0xcd,0x00,0xbe,0xf8,0xd2,0x00,0xae,0xf8,0xd6,0x00,0x9d,0xf8,0xdb,0x00,0x8d,0xf8,0xe0,0x00,0x7d,0xf8,0xe5,0x00,0x6c,0xf8,0xea,0x00,0x5c,0xf8,0xef,0x00,0x4b,0xf8,0xf4,0x00,0x3a,0xf8,0xf9,0x00,0x29,0xf8,0xff,0x00,0x18,0xf8,0x04,0x01,0x07,0xf8,0x09,0x01,0xf6,0xf7,0x0e,0x01,0xe5,0xf7,0x13,0x01,0xd4,0xf7,0x18,0x01,0xc2,0xf7,0x1d,0x01,0xb1,0xf7,0x23,0x01,0x9f,0xf7,0x28,0x01,0x8e,0xf7,0x2d,0x01,0x7c,0xf7,0x33,0x01,0x6b,0xf7,0x38,0x01,0x59,0xf7,  \
    0x3d,0x01,0x48,0xf7,0x43,0x01,0x36,0xf7,0x48,0x01,0x24,0xf7,0x4e,0x01,0x12,0xf7,0x53,0x01,0x00,0xf7,0x58,0x01,0xee,0xf6,0x5e,0x01,0xdc,0xf6,0x63,0x01,0xca,0xf6,0x69,0x01,0xb8,0xf6,0x6f,0x01,0xa6,0xf6,0x74,0x01,0x93,0xf6,0x7a,0x01,0x81,0xf6,0x80,0x01,0x6f,0xf6,0x85,0x01,0x5c,0xf6,0x8b,0x01,0x4a,0xf6,0x91,0x01,0x37,0xf6,0x96,0x01,0x25,0xf6,0x9c,0x01,0x12,0xf6,0xa2,0x01,0xff,0xf5,0xa8,0x01,0xec,0xf5,0xad,0x01,0xd9,0xf5,0xb3,0x01,0xc6,0xf5,0xb9,0x01,  \
    0xb3,0xf5,0xbf,0x01,0xa0,0xf5,0xc5,0x01,0x8c,0xf5,0xca,0x01,0x79,0xf5,0xd0,0x01,0x65,0xf5,0xd6,0x01,0x51,0xf5,0xdb,0x01,0x3d,0xf5,0xe1,0x01,0x29,0xf5,0xe6,0x01,0x14,0xf5,0xec,0x01,0x00,0xf5,0xf2,0x01,0xeb,0xf4,0xf7,0x01,0xd6,0xf4,0xfd,0x01,0xc2,0xf4,0x02,0x02,0xad,0xf4,0x08,0x02,0x98,0xf4,0x0d,0x02,0x83,0xf4,0x13,0x02,0x6e,0xf4,0x18,0x02,0x58,0xf4,0x1e,0x02,0x43,0xf4,0x23,0x02,0x2e,0xf4,0x29,0x02,0x18,0xf4,0x2e,0x02,0x02,0xf4,0x33,0x02,0xed,0xf3,  \
    0x39,0x02,0xd7,0xf3,0x3e,0x02,0xc2,0xf3,0x44,0x02,0xac,0xf3,0x4a,0x02,0x96,0xf3,0x4f,0x02,0x81,0xf3,0x55,0x02,0x6b,0xf3,0x5a,0x02,0x55,0xf3,0x60,0x02,0x3f,0xf3,0x65,0x02,0x28,0xf3,0x6b,0x02,0x12,0xf3,0x70,0x02,0xfc,0xf2,0x76,0x02,0xe5,0xf2,0x7b,0x02,0xce,0xf2,0x80,0x02,0xb8,0xf2,0x86,0x02,0xa1,0xf2,0x8b,0x02,0x8a,0xf2,0x90,0x02,0x72,0xf2,0x95,0x02,0x5b,0xf2,0x9a,0x02,0x44,0xf2,0x9f,0x02,0x2c,0xf2,0xa4,0x02,0x15,0xf2,0xa9,0x02,0xfd,0xf1,0xae,0x02,  \
    0xe5,0xf1,0xb3,0x02,0xcd,0xf1,0xb8,0x02,0xb5,0xf1,0xbd,0x02,0x9c,0xf1,0xc2,0x02,0x84,0xf1,0xc6,0x02,0x6b,0xf1,0xcb,0x02,0x53,0xf1,0xcf,0x02,0x3a,0xf1,0xd4,0x02,0x21,0xf1,0xd8,0x02,0x08,0xf1,0xdd,0x02,0xef,0xf0,0xe1,0x02,0xd5,0xf0,0xe5,0x02,0xbc,0xf0,0xe9,0x02,0xa2,0xf0,0xed,0x02,0x88,0xf0,0xf1,0x02,0x6e,0xf0,0xf5,0x02,0x54,0xf0,0xf9,0x02,0x3a,0xf0,0xfc,0x02,0x1f,0xf0,0x00,0x03,0x04,0xf0,0x03,0x03,0xe9,0xef,0x07,0x03,0xce,0xef,0x0a,0x03,0xb3,0xef,  \
    0x0d,0x03,0x97,0xef,0x10,0x03,0x7c,0xef,0x13,0x03,0x60,0xef,0x16,0x03,0x44,0xef,0x19,0x03,0x28,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x44,0x03,0xc5,0x10,0x41,0x03,0xa9,0x10,0x3e,0x03,  \
    0x8d,0x10,0x3b,0x03,0x71,0x10,0x38,0x03,0x55,0x10,0x35,0x03,0x3a,0x10,0x32,0x03,0x1e,0x10,0x2e,0x03,0x03,0x10,0x2b,0x03,0xe8,0x0f,0x27,0x03,0xcc,0x0f,0x24,0x03,0xb1,0x0f,0x20,0x03,0x97,0x0f,0x1c,0x03,0x7c,0x0f,0x19,0x03,0x61,0x0f,0x15,0x03,0x47,0x0f,0x11,0x03,0x2d,0x0f,0x0d,0x03,0x13,0x0f,0x09,0x03,0xf9,0x0e,0x04,0x03,0xdf,0x0e,0x00,0x03,0xc5,0x0e,0xfc,0x02,0xab,0x0e,0xf7,0x02,0x92,0x0e,0xf3,0x02,0x79,0x0e,0xee,0x02,0x60,0x0e,0xe9,0x02,0x47,0x0e,  \
    0xe5,0x02,0x2e,0x0e,0xe0,0x02,0x15,0x0e,0xdb,0x02,0xfd,0x0d,0xd6,0x02,0xe4,0x0d,0xd1,0x02,0xcc,0x0d,0xcc,0x02,0xb4,0x0d,0xc7,0x02,0x9c,0x0d,0xc2,0x02,0x84,0x0d,0xbd,0x02,0x6c,0x0d,0xb7,0x02,0x54,0x0d,0xb2,0x02,0x3d,0x0d,0xad,0x02,0x25,0x0d,0xa7,0x02,0x0e,0x0d,0xa2,0x02,0xf7,0x0c,0x9d,0x02,0xe0,0x0c,0x97,0x02,0xc9,0x0c,0x91,0x02,0xb2,0x0c,0x8c,0x02,0x9c,0x0c,0x86,0x02,0x86,0x0c,0x80,0x02,0x70,0x0c,0x7a,0x02,0x59,0x0c,0x74,0x02,0x44,0x0c,0x6e,0x02,  \
    0x2e,0x0c,0x69,0x02,0x18,0x0c,0x63,0x02,0x02,0x0c,0x5d,0x02,0xed,0x0b,0x57,0x02,0xd8,0x0b,0x51,0x02,0xc2,0x0b,0x4b,0x02,0xad,0x0b,0x45,0x02,0x98,0x0b,0x3f,0x02,0x83,0x0b,0x38,0x02,0x6f,0x0b,0x32,0x02,0x5a,0x0b,0x2d,0x02,0x44,0x0b,0x27,0x02,0x2f,0x0b,0x22,0x02,0x19,0x0b,0x1c,0x02,0x04,0x0b,0x16,0x02,0xef,0x0a,0x11,0x02,0xda,0x0a,0x0b,0x02,0xc5,0x0a,0x05,0x02,0xb0,0x0a,0x00,0x02,0x9b,0x0a,0xfa,0x01,0x87,0x0a,0xf4,0x01,0x72,0x0a,0xef,0x01,0x5e,0x0a,  \
    0xe9,0x01,0x49,0x0a,0xe3,0x01,0x35,0x0a,0xde,0x01,0x20,0x0a,0xd8,0x01,0x0c,0x0a,0xd3,0x01,0xf8,0x09,0xcd,0x01,0xe4,0x09,0xc7,0x01,0xd0,0x09,0xc2,0x01,0xbc,0x09,0xbc,0x01,0xa8,0x09,0xb6,0x01,0x95,0x09,0xb1,0x01,0x81,0x09,0xab,0x01,0x6d,0x09,0xa6,0x01,0x5a,0x09,0xa0,0x01,0x47,0x09,0x9a,0x01,0x33,0x09,0x95,0x01,0x20,0x09,0x8f,0x01,0x0d,0x09,0x8a,0x01,0xfa,0x08,0x84,0x01,0xe7,0x08,0x7f,0x01,0xd4,0x08,0x79,0x01,0xc1,0x08,0x74,0x01,0xae,0x08,0x6e,0x01,  \
    0x9b,0x08,0x69,0x01,0x88,0x08,0x63,0x01,0x77,0x08,0x5d,0x01,0x65,0x08,0x57,0x01,0x54,0x08,0x52,0x01,0x42,0x08,0x4c,0x01,0x31,0x08,0x46,0x01,0x1f,0x08,0x40,0x01,0x0e,0x08,0x3b,0x01,0xfd,0x07,0x35,0x01,0xec,0x07,0x30,0x01,0xdb,0x07,0x2a,0x01,0xca,0x07,0x24,0x01,0xb9,0x07,0x1f,0x01,0xa8,0x07,0x19,0x01,0x97,0x07,0x14,0x01,0x86,0x07,0x0f,0x01,0x75,0x07,0x09,0x01,0x65,0x07,0x04,0x01,0x54,0x07,0xfe,0x00,0x44,0x07,0xf9,0x00,0x33,0x07,0xf4,0x00,0x23,0x07,  \
    0xef,0x00,0x12,0x07,0xea,0x00,0x02,0x07,0xe4,0x00,0xf1,0x06,0xdf,0x00,0xe1,0x06,0xda,0x00,0xd1,0x06,0xd5,0x00,0xc0,0x06,0xd0,0x00,0xb0,0x06,0xcb,0x00,0xa0,0x06,0xc6,0x00,0x90,0x06,0xc2,0x00,0x80,0x06,0xbd,0x00,0x70,0x06,0xb8,0x00,0x60,0x06,0xb3,0x00,0x50,0x06,0xae,0x00,0x40,0x06,0xaa,0x00,0x30,0x06,0xa5,0x00,0x20,0x06,0xa0,0x00,0x11,0x06,0x9c,0x00,0x01,0x06,0x97,0x00,0xf1,0x05,0x93,0x00,0xe2,0x05,0x8e,0x00,0xd2,0x05,0x8a,0x00,0xc3,0x05,0x85,0x00,  \
    0xb2,0x05,0x81,0x00,0xa2,0x05,0x7d,0x00,0x92,0x05,0x79,0x00,0x82,0x05,0x75,0x00,0x72,0x05,0x71,0x00,0x63,0x05,0x6d,0x00,0x53,0x05,0x69,0x00,0x43,0x05,0x65,0x00,0x33,0x05,0x61,0x00,0x23,0x05,0x5d,0x00,0x14,0x05,0x59,0x00,0x04,0x05,0x55,0x00,0xf4,0x04,0x51,0x00,0xe5,0x04,0x4d,0x00,0xd5,0x04,0x4a,0x00,0xc6,0x04,0x46,0x00,0xb6,0x04,0x42,0x00,0xa7,0x04,0x3f,0x00,0x97,0x04,0x3b,0x00,0x88,0x04,0x38,0x00,0x79,0x04,0x34,0x00,0x69,0x04,0x31,0x00,0x5a,0x04,  \
    0x2d,0x00,0x4b,0x04,0x2a,0x00,0x3c,0x04,0x26,0x00,0x2d,0x04,0x23,0x00,0x1f,0x04,0x20,0x00,0x10,0x04,0x1c,0x00,0x01,0x04,0x19,0x00,0xf3,0x03,0x16,0x00,0xe4,0x03,0x13,0x00,0xd5,0x03,0x0f,0x00,0xc7,0x03,0x0c,0x00,0xb8,0x03,0x09,0x00,0xaa,0x03,0x06,0x00,0x9b,0x03,0x03,0x00,0x8d,0x03,0x00,0x00,0x7e,0x03,0xfd,0xff,0x70,0x03,0xfa,0xff,0x61,0x03,0xf8,0xff,0x53,0x03,0xf5,0xff,0x45,0x03,0xf2,0xff,0x36,0x03,0xef,0xff,0x28,0x03,0xed,0xff,0x1a,0x03,0xea,0xff,  \
    0x0b,0x03,0xe8,0xff,0xfd,0x02,0xe5,0xff,0xef,0x02,0xe3,0xff,0xe0,0x02,0xe0,0xff,0xd2,0x02,0xde,0xff,0xc4,0x02,0xdb,0xff,0xb7,0x02,0xd9,0xff,0xa9,0x02,0xd7,0xff,0x9b,0x02,0xd4,0xff,0x8d,0x02,0xd2,0xff,0x7f,0x02,0xd0,0xff,0x71,0x02,0xce,0xff,0x63,0x02,0xcc,0xff,0x56,0x02,0xca,0xff,0x48,0x02,0xc8,0xff,0x3a,0x02,0xc6,0xff,0x2c,0x02,0xc4,0xff,0x1e,0x02,0xc2,0xff,0x11,0x02,0xc0,0xff,0x03,0x02,0xbf,0xff,0xf5,0x01,0xbd,0xff,0xe7,0x01,0xbb,0xff,0xd9,0x01,  \
    0xba,0xff,0xcb,0x01,0xb8,0xff,0xbe,0x01,0xb6,0xff,0xb0,0x01,0xb5,0xff,0xa2,0x01,0xb4,0xff,0x94,0x01,0xb2,0xff,0x86,0x01,0xb1,0xff,0x78,0x01,0xaf,0xff,0x6b,0x01,0xae,0xff,0x5d,0x01,0xad,0xff,0x4f,0x01,0xac,0xff,0x41,0x01,0xab,0xff,0x32,0x01,0xaa,0xff,0x24,0x01,0xa9,0xff,0x16,0x01,0xa8,0xff,0x08,0x01,0xa7,0xff,0xfa,0x00,0xa6,0xff,0xec,0x00,0xa5,0xff,0xde,0x00,0xa4,0xff,0xd0,0x00,0xa3,0xff,0xc2,0x00,0xa2,0xff,0xb4,0x00,0xa2,0xff,0xa6,0x00,0xa1,0xff,  \
    0x98,0x00,0xa0,0xff,0x8a,0x00,0xa0,0xff,0x7c,0x00,0x9f,0xff,0x6e,0x00,0x9f,0xff,0x60,0x00,0x9e,0xff,0x52,0x00,0x9e,0xff,0x44,0x00,0x9e,0xff,0x36,0x00,0x9d,0xff,0x28,0x00,0x9d,0xff,0x1a,0x00,0x9d,0xff,0x0c,0x00,0x9c,0xff,0xfe,0xff,0x9c,0xff,0xf0,0xff,0x9c,0xff,0xe2,0xff,0x9c,0xff,0xd4,0xff,0x9c,0xff,0xc6,0xff,0x9c,0xff,0xb8,0xff,0x9c,0xff,0xab,0xff,0x9c,0xff,0x9d,0xff,0x9c,0xff,0x8f,0xff,0x9d,0xff,0x81,0xff,0x9d,0xff,0x73,0xff,0x9d,0xff,0x65,0xff,  \
    0x9d,0xff,0x57,0xff,0x9e,0xff,0x49,0xff,0x9e,0xff,0x3b,0xff,0x9e,0xff,0x2d,0xff,0x9f,0xff,0x1f,0xff,0x9f,0xff,0x11,0xff,0xa0,0xff,0x03,0xff,0xa0,0xff,0xf5,0xfe,0xa1,0xff,0xe7,0xfe,0xa2,0xff,0xd9,0xfe,0xa2,0xff,0xcb,0xfe,0xa3,0xff,0xbd,0xfe,0xa4,0xff,0xaf,0xfe,0xa5,0xff,0xa1,0xfe,0xa6,0xff,0x93,0xfe,0xa7,0xff,0x85,0xfe,0xa8,0xff,0x77,0xfe,0xa9,0xff,0x69,0xfe,0xaa,0xff,0x5b,0xfe,0xab,0xff,0x4d,0xfe,0xac,0xff,0x3f,0xfe,0xad,0xff,0x31,0xfe,0xae,0xff,  \
    0x23,0xfe,0xaf,0xff,0x14,0xfe,0xb1,0xff,0x06,0xfe,0xb2,0xff,0xf8,0xfd,0xb3,0xff,0xea,0xfd,0xb5,0xff,0xdc,0xfd,0xb6,0xff,0xcd,0xfd,0xb8,0xff,0xbf,0xfd,0xb9,0xff,0xb1,0xfd,0xbb,0xff,0xa3,0xfd,0xbc,0xff,0x94,0xfd,0xbe,0xff,0x86,0xfd,0xc0,0xff,0x78,0xfd,0xc1,0xff,0x69,0xfd,0xc3,0xff,0x5b,0xfd,0xc5,0xff,0x4c,0xfd,0xc7,0xff,0x3e,0xfd,0xc9,0xff,0x30,0xfd,0xcb,0xff,0x21,0xfd,0xcd,0xff,0x13,0xfd,0xcf,0xff,0x04,0xfd,0xd1,0xff,0xf6,0xfc,0xd3,0xff,0xe7,0xfc,  \
    0xd5,0xff,0xd9,0xfc,0xd7,0xff,0xca,0xfc,0xd9,0xff,0xbc,0xfc,0xdb,0xff,0xad,0xfc,0xde,0xff,0x9f,0xfc,0xe0,0xff,0x91,0xfc,0xe2,0xff,0x83,0xfc,0xe5,0xff,0x74,0xfc,0xe7,0xff,0x66,0xfc,0xea,0xff,0x58,0xfc,0xec,0xff,0x49,0xfc,0xef,0xff,0x3b,0xfc,0xf2,0xff,0x2d,0xfc,0xf4,0xff,0x1e,0xfc,0xf7,0xff,0x10,0xfc,0xfa,0xff,0x01,0xfc,0xfd,0xff,0xf3,0xfb,0x00,0x00,0xe4,0xfb,0x02,0x00,0xd6,0xfb,0x05,0x00,0xc7,0xfb,0x08,0x00,0xb9,0xfb,0x0b,0x00,0xaa,0xfb,0x0e,0x00,  \
    0x9c,0xfb,0x12,0x00,0x8d,0xfb,0x15,0x00,0x7f,0xfb,0x18,0x00,0x70,0xfb,0x1b,0x00,0x62,0xfb,0x1e,0x00,0x53,0xfb,0x22,0x00,0x44,0xfb,0x25,0x00,0x35,0xfb,0x28,0x00,0x26,0xfb,0x2c,0x00,0x17,0xfb,0x2f,0x00,0x08,0xfb,0x33,0x00,0xf9,0xfa,0x36,0x00,0xea,0xfa,0x3a,0x00,0xdb,0xfa,0x3d,0x00,0xcc,0xfa,0x41,0x00,0xbd,0xfa,0x44,0x00,0xad,0xfa,0x48,0x00,0x9e,0xfa,0x4c,0x00,0x8f,0xfa,0x50,0x00,0x80,0xfa,0x53,0x00,0x70,0xfa,0x57,0x00,0x61,0xfa,0x5b,0x00,0x51,0xfa,  \
    0x5f,0x00,0x42,0xfa,0x63,0x00,0x33,0xfa,0x67,0x00,0x23,0xfa,0x6b,0x00,0x13,0xfa,0x6f,0x00,0x04,0xfa,0x73,0x00,0xf4,0xf9,0x77,0x00,0xe5,0xf9,0x7b,0x00,0xd5,0xf9,0x80,0x00,0xc5,0xf9,0x84,0x00,0xb5,0xf9,0x88,0x00,0xa6,0xf9,0x8d,0x00,0x96,0xf9,0x91,0x00,0x86,0xf9,0x95,0x00,0x77,0xf9,0x9a,0x00,0x67,0xf9,0x9e,0x00,0x57,0xf9,0xa3,0x00,0x47,0xf9,0xa7,0x00,0x37,0xf9,0xac,0x00,0x27,0xf9,0xb1,0x00,0x17,0xf9,0xb5,0x00,0x07,0xf9,0xba,0x00,0xf7,0xf8,0xbf,0x00,  \
    0xe7,0xf8,0xc4,0x00,0xd7,0xf8,0xc8,0x00,0xc7,0xf8,0xcd,0x00,0xb6,0xf8,0xd2,0x00,0xa6,0xf8,0xd7,0x00,0x96,0xf8,0xdc,0x00,0x85,0xf8,0xe1,0x00,0x75,0xf8,0xe6,0x00,0x64,0xf8,0xeb,0x00,0x54,0xf8,0xf0,0x00,0x43,0xf8,0xf5,0x00,0x32,0xf8,0xfa,0x00,0x21,0xf8,0xff,0x00,0x10,0xf8,0x04,0x01,0xff,0xf7,0x09,0x01,0xee,0xf7,0x0e,0x01,0xdc,0xf7,0x13,0x01,0xcb,0xf7,0x19,0x01,0xba,0xf7,0x1e,0x01,0xa8,0xf7,0x23,0x01,0x97,0xf7,0x28,0x01,0x85,0xf7,0x2e,0x01,0x74,0xf7,  \
    0x33,0x01,0x62,0xf7,0x38,0x01,0x50,0xf7,0x3e,0x01,0x3f,0xf7,0x43,0x01,0x2d,0xf7,0x48,0x01,0x1b,0xf7,0x4e,0x01,0x09,0xf7,0x53,0x01,0xf7,0xf6,0x59,0x01,0xe5,0xf6,0x5e,0x01,0xd3,0xf6,0x64,0x01,0xc1,0xf6,0x69,0x01,0xaf,0xf6,0x6f,0x01,0x9c,0xf6,0x75,0x01,0x8a,0xf6,0x7a,0x01,0x78,0xf6,0x80,0x01,0x65,0xf6,0x86,0x01,0x53,0xf6,0x8b,0x01,0x40,0xf6,0x91,0x01,0x2d,0xf6,0x97,0x01,0x1b,0xf6,0x9c,0x01,0x08,0xf6,0xa2,0x01,0xf5,0xf5,0xa8,0x01,0xe2,0xf5,0xad,0x01,  \
    0xcf,0xf5,0xb3,0x01,0xbc,0xf5,0xb9,0x01,0xa8,0xf5,0xbf,0x01,0x95,0xf5,0xc5,0x01,0x82,0xf5,0xca,0x01,0x6e,0xf5,0xd0,0x01,0x5a,0xf5,0xd5,0x01,0x46,0xf5,0xdb,0x01,0x31,0xf5,0xe0,0x01,0x1d,0xf5,0xe6,0x01,0x09,0xf5,0xeb,0x01,0xf4,0xf4,0xf1,0x01,0xdf,0xf4,0xf6,0x01,0xca,0xf4,0xfc,0x01,0xb6,0xf4,0x01,0x02,0xa1,0xf4,0x07,0x02,0x8c,0xf4,0x0c,0x02,0x76,0xf4,0x12,0x02,0x61,0xf4,0x17,0x02,0x4c,0xf4,0x1d,0x02,0x36,0xf4,0x22,0x02,0x21,0xf4,0x27,0x02,0x0b,0xf4,  \
    0x2d,0x02,0xf5,0xf3,0x32,0x02,0xe0,0xf3,0x38,0x02,0xca,0xf3,0x3d,0x02,0xb5,0xf3,0x43,0x02,0x9f,0xf3,0x48,0x02,0x89,0xf3,0x4e,0x02,0x73,0xf3,0x53,0x02,0x5d,0xf3,0x59,0x02,0x47,0xf3,0x5e,0x02,0x31,0xf3,0x64,0x02,0x1b,0xf3,0x69,0x02,0x04,0xf3,0x6e,0x02,0xee,0xf2,0x74,0x02,0xd7,0xf2,0x79,0x02,0xc0,0xf2,0x7e,0x02,0xa9,0xf2,0x83,0x02,0x92,0xf2,0x88,0x02,0x7b,0xf2,0x8e,0x02,0x63,0xf2,0x93,0x02,0x4c,0xf2,0x98,0x02,0x34,0xf2,0x9d,0x02,0x1d,0xf2,0xa2,0x02,  \
    0x05,0xf2,0xa7,0x02,0xed,0xf1,0xab,0x02,0xd5,0xf1,0xb0,0x02,0xbd,0xf1,0xb5,0x02,0xa5,0xf1,0xba,0x02,0x8c,0xf1,0xbe,0x02,0x73,0xf1,0xc3,0x02,0x5b,0xf1,0xc7,0x02,0x42,0xf1,0xcc,0x02,0x29,0xf1,0xd0,0x02,0x10,0xf1,0xd4,0x02,0xf6,0xf0,0xd9,0x02,0xdd,0xf0,0xdd,0x02,0xc3,0xf0,0xe1,0x02,0xaa,0xf0,0xe5,0x02,0x90,0xf0,0xe9,0x02,0x76,0xf0,0xed,0x02,0x5c,0xf0,0xf0,0x02,0x41,0xf0,0xf4,0x02,0x27,0xf0,0xf7,0x02,0x0c,0xf0,0xfb,0x02,0xf1,0xef,0xfe,0x02,0xd6,0xef,  \
    0x01,0x03,0xba,0xef,0x04,0x03,0x9f,0xef,0x07,0x03,0x83,0xef,0x0a,0x03,0x68,0xef,0x0d,0x03,0x4c,0xef,0x10,0x03,0x30,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3c,0x03,0xbe,0x10,0x39,0x03,  \
    0xa2,0x10,0x36,0x03,0x86,0x10,0x33,0x03,0x6a,0x10,0x30,0x03,0x4e,0x10,0x2d,0x03,0x33,0x10,0x2a,0x03,0x17,0x10,0x26,0x03,0xfc,0x0f,0x23,0x03,0xe0,0x0f,0x20,0x03,0xc5,0x0f,0x1c,0x03,0xaa,0x0f,0x18,0x03,0x90,0x0f,0x15,0x03,0x75,0x0f,0x11,0x03,0x5a,0x0f,0x0d,0x03,0x40,0x0f,0x09,0x03,0x26,0x0f,0x05,0x03,0x0b,0x0f,0x01,0x03,0xf1,0x0e,0xfd,0x02,0xd8,0x0e,0xf9,0x02,0xbe,0x0e,0xf4,0x02,0xa4,0x0e,0xf0,0x02,0x8b,0x0e,0xeb,0x02,0x72,0x0e,0xe7,0x02,0x58,0x0e,  \
    0xe2,0x02,0x40,0x0e,0xdd,0x02,0x27,0x0e,0xd8,0x02,0x0e,0x0e,0xd4,0x02,0xf5,0x0d,0xcf,0x02,0xdd,0x0d,0xca,0x02,0xc5,0x0d,0xc5,0x02,0xac,0x0d,0xc0,0x02,0x94,0x0d,0xbb,0x02,0x7c,0x0d,0xb5,0x02,0x65,0x0d,0xb0,0x02,0x4d,0x0d,0xab,0x02,0x35,0x0d,0xa6,0x02,0x1e,0x0d,0xa0,0x02,0x06,0x0d,0x9b,0x02,0xef,0x0c,0x96,0x02,0xd8,0x0c,0x90,0x02,0xc1,0x0c,0x8b,0x02,0xab,0x0c,0x85,0x02,0x94,0x0c,0x7f,0x02,0x7e,0x0c,0x79,0x02,0x68,0x0c,0x74,0x02,0x52,0x0c,0x6e,0x02,  \
    0x3c,0x0c,0x68,0x02,0x26,0x0c,0x62,0x02,0x10,0x0c,0x5c,0x02,0xfa,0x0b,0x56,0x02,0xe5,0x0b,0x50,0x02,0xcf,0x0b,0x4b,0x02,0xba,0x0b,0x45,0x02,0xa5,0x0b,0x3f,0x02,0x90,0x0b,0x39,0x02,0x7b,0x0b,0x33,0x02,0x66,0x0b,0x2d,0x02,0x51,0x0b,0x27,0x02,0x3c,0x0b,0x21,0x02,0x26,0x0b,0x1c,0x02,0x11,0x0b,0x16,0x02,0xfc,0x0a,0x11,0x02,0xe7,0x0a,0x0b,0x02,0xd2,0x0a,0x05,0x02,0xbd,0x0a,0x00,0x02,0xa8,0x0a,0xfa,0x01,0x93,0x0a,0xf5,0x01,0x7e,0x0a,0xef,0x01,0x6a,0x0a,  \
    0xe9,0x01,0x55,0x0a,0xe4,0x01,0x41,0x0a,0xde,0x01,0x2c,0x0a,0xd8,0x01,0x18,0x0a,0xd3,0x01,0x04,0x0a,0xcd,0x01,0xf0,0x09,0xc7,0x01,0xdc,0x09,0xc2,0x01,0xc8,0x09,0xbc,0x01,0xb4,0x09,0xb7,0x01,0xa0,0x09,0xb1,0x01,0x8c,0x09,0xab,0x01,0x79,0x09,0xa6,0x01,0x65,0x09,0xa0,0x01,0x52,0x09,0x9b,0x01,0x3e,0x09,0x95,0x01,0x2b,0x09,0x90,0x01,0x18,0x09,0x8a,0x01,0x05,0x09,0x85,0x01,0xf1,0x08,0x7f,0x01,0xde,0x08,0x7a,0x01,0xcb,0x08,0x74,0x01,0xb9,0x08,0x6f,0x01,  \
    0xa6,0x08,0x69,0x01,0x93,0x08,0x64,0x01,0x80,0x08,0x5e,0x01,0x6f,0x08,0x58,0x01,0x5d,0x08,0x53,0x01,0x4c,0x08,0x4d,0x01,0x3a,0x08,0x47,0x01,0x29,0x08,0x41,0x01,0x17,0x08,0x3c,0x01,0x06,0x08,0x36,0x01,0xf5,0x07,0x31,0x01,0xe4,0x07,0x2b,0x01,0xd3,0x07,0x26,0x01,0xc2,0x07,0x20,0x01,0xb1,0x07,0x1b,0x01,0xa0,0x07,0x15,0x01,0x8f,0x07,0x10,0x01,0x7e,0x07,0x0a,0x01,0x6d,0x07,0x05,0x01,0x5d,0x07,0x00,0x01,0x4c,0x07,0xfa,0x00,0x3c,0x07,0xf5,0x00,0x2b,0x07,  \
    0xf0,0x00,0x1b,0x07,0xeb,0x00,0x0a,0x07,0xe5,0x00,0xfa,0x06,0xe0,0x00,0xe9,0x06,0xdb,0x00,0xd9,0x06,0xd6,0x00,0xc9,0x06,0xd1,0x00,0xb8,0x06,0xcc,0x00,0xa8,0x06,0xc7,0x00,0x98,0x06,0xc2,0x00,0x88,0x06,0xbe,0x00,0x78,0x06,0xb9,0x00,0x68,0x06,0xb4,0x00,0x58,0x06,0xaf,0x00,0x48,0x06,0xaa,0x00,0x38,0x06,0xa6,0x00,0x29,0x06,0xa1,0x00,0x19,0x06,0x9c,0x00,0x09,0x06,0x98,0x00,0xf9,0x05,0x93,0x00,0xea,0x05,0x8f,0x00,0xda,0x05,0x8a,0x00,0xcb,0x05,0x86,0x00,  \
    0xbb,0x05,0x82,0x00,0xab,0x05,0x7d,0x00,0x9b,0x05,0x79,0x00,0x8b,0x05,0x75,0x00,0x7b,0x05,0x71,0x00,0x6b,0x05,0x6d,0x00,0x5b,0x05,0x69,0x00,0x4c,0x05,0x65,0x00,0x3c,0x05,0x61,0x00,0x2c,0x05,0x5d,0x00,0x1c,0x05,0x59,0x00,0x0d,0x05,0x55,0x00,0xfd,0x04,0x51,0x00,0xee,0x04,0x4e,0x00,0xde,0x04,0x4a,0x00,0xcf,0x04,0x46,0x00,0xbf,0x04,0x43,0x00,0xb0,0x04,0x3f,0x00,0xa0,0x04,0x3b,0x00,0x91,0x04,0x38,0x00,0x82,0x04,0x34,0x00,0x72,0x04,0x31,0x00,0x63,0x04,  \
    0x2d,0x00,0x54,0x04,0x2a,0x00,0x45,0x04,0x26,0x00,0x36,0x04,0x23,0x00,0x27,0x04,0x1f,0x00,0x19,0x04,0x1c,0x00,0x0a,0x04,0x19,0x00,0xfb,0x03,0x16,0x00,0xed,0x03,0x12,0x00,0xde,0x03,0x0f,0x00,0xd0,0x03,0x0c,0x00,0xc1,0x03,0x09,0x00,0xb3,0x03,0x06,0x00,0xa4,0x03,0x03,0x00,0x96,0x03,0x00,0x00,0x87,0x03,0xfd,0xff,0x79,0x03,0xfa,0xff,0x6b,0x03,0xf7,0xff,0x5c,0x03,0xf4,0xff,0x4e,0x03,0xf2,0xff,0x40,0x03,0xef,0xff,0x31,0x03,0xec,0xff,0x23,0x03,0xea,0xff,  \
    0x15,0x03,0xe7,0xff,0x06,0x03,0xe4,0xff,0xf8,0x02,0xe2,0xff,0xea,0x02,0xdf,0xff,0xdc,0x02,0xdd,0xff,0xce,0x02,0xdb,0xff,0xc0,0x02,0xd8,0xff,0xb2,0x02,0xd6,0xff,0xa4,0x02,0xd4,0xff,0x97,0x02,0xd1,0xff,0x89,0x02,0xcf,0xff,0x7b,0x02,0xcd,0xff,0x6d,0x02,0xcb,0xff,0x5f,0x02,0xc9,0xff,0x52,0x02,0xc7,0xff,0x44,0x02,0xc5,0xff,0x36,0x02,0xc3,0xff,0x28,0x02,0xc1,0xff,0x1b,0x02,0xbf,0xff,0x0d,0x02,0xbd,0xff,0xff,0x01,0xbb,0xff,0xf1,0x01,0xba,0xff,0xe4,0x01,  \
    0xb8,0xff,0xd6,0x01,0xb6,0xff,0xc8,0x01,0xb5,0xff,0xba,0x01,0xb3,0xff,0xad,0x01,0xb2,0xff,0x9f,0x01,0xb0,0xff,0x91,0x01,0xaf,0xff,0x83,0x01,0xae,0xff,0x76,0x01,0xac,0xff,0x68,0x01,0xab,0xff,0x5a,0x01,0xaa,0xff,0x4c,0x01,0xa9,0xff,0x3e,0x01,0xa8,0xff,0x30,0x01,0xa6,0xff,0x22,0x01,0xa5,0xff,0x14,0x01,0xa4,0xff,0x06,0x01,0xa3,0xff,0xf8,0x00,0xa3,0xff,0xea,0x00,0xa2,0xff,0xdc,0x00,0xa1,0xff,0xce,0x00,0xa0,0xff,0xc0,0x00,0x9f,0xff,0xb3,0x00,0x9f,0xff,  \
    0xa5,0x00,0x9e,0xff,0x97,0x00,0x9d,0xff,0x89,0x00,0x9d,0xff,0x7b,0x00,0x9c,0xff,0x6d,0x00,0x9c,0xff,0x5f,0x00,0x9b,0xff,0x51,0x00,0x9b,0xff,0x43,0x00,0x9a,0xff,0x35,0x00,0x9a,0xff,0x28,0x00,0x9a,0xff,0x1a,0x00,0x9a,0xff,0x0c,0x00,0x99,0xff,0xfe,0xff,0x99,0xff,0xf0,0xff,0x99,0xff,0xe2,0xff,0x99,0xff,0xd4,0xff,0x99,0xff,0xc6,0xff,0x99,0xff,0xb9,0xff,0x99,0xff,0xab,0xff,0x99,0xff,0x9d,0xff,0x99,0xff,0x8f,0xff,0x99,0xff,0x81,0xff,0x9a,0xff,0x73,0xff,  \
    0x9a,0xff,0x65,0xff,0x9a,0xff,0x57,0xff,0x9b,0xff,0x4a,0xff,0x9b,0xff,0x3c,0xff,0x9b,0xff,0x2e,0xff,0x9c,0xff,0x20,0xff,0x9c,0xff,0x12,0xff,0x9d,0xff,0x04,0xff,0x9d,0xff,0xf6,0xfe,0x9e,0xff,0xe8,0xfe,0x9f,0xff,0xdb,0xfe,0x9f,0xff,0xcd,0xfe,0xa0,0xff,0xbf,0xfe,0xa1,0xff,0xb1,0xfe,0xa2,0xff,0xa3,0xfe,0xa3,0xff,0x95,0xfe,0xa4,0xff,0x87,0xfe,0xa4,0xff,0x79,0xfe,0xa5,0xff,0x6b,0xfe,0xa7,0xff,0x5d,0xfe,0xa8,0xff,0x4f,0xfe,0xa9,0xff,0x41,0xfe,0xaa,0xff,  \
    0x33,0xfe,0xab,0xff,0x25,0xfe,0xac,0xff,0x17,0xfe,0xae,0xff,0x09,0xfe,0xaf,0xff,0xfb,0xfd,0xb0,0xff,0xed,0xfd,0xb2,0xff,0xdf,0xfd,0xb3,0xff,0xd1,0xfd,0xb5,0xff,0xc2,0xfd,0xb6,0xff,0xb4,0xfd,0xb8,0xff,0xa6,0xfd,0xb9,0xff,0x98,0xfd,0xbb,0xff,0x8a,0xfd,0xbd,0xff,0x7b,0xfd,0xbe,0xff,0x6d,0xfd,0xc0,0xff,0x5f,0xfd,0xc2,0xff,0x51,0xfd,0xc4,0xff,0x42,0xfd,0xc5,0xff,0x34,0xfd,0xc7,0xff,0x26,0xfd,0xc9,0xff,0x17,0xfd,0xcb,0xff,0x09,0xfd,0xcd,0xff,0xfa,0xfc,  \
    0xcf,0xff,0xec,0xfc,0xd2,0xff,0xde,0xfc,0xd4,0xff,0xcf,0xfc,0xd6,0xff,0xc1,0xfc,0xd8,0xff,0xb2,0xfc,0xda,0xff,0xa4,0xfc,0xdd,0xff,0x96,0xfc,0xdf,0xff,0x88,0xfc,0xe2,0xff,0x7a,0xfc,0xe4,0xff,0x6b,0xfc,0xe7,0xff,0x5d,0xfc,0xe9,0xff,0x4f,0xfc,0xec,0xff,0x40,0xfc,0xee,0xff,0x32,0xfc,0xf1,0xff,0x24,0xfc,0xf4,0xff,0x15,0xfc,0xf7,0xff,0x07,0xfc,0xf9,0xff,0xf9,0xfb,0xfc,0xff,0xea,0xfb,0xff,0xff,0xdc,0xfb,0x02,0x00,0xce,0xfb,0x05,0x00,0xbf,0xfb,0x08,0x00,  \
    0xb1,0xfb,0x0b,0x00,0xa2,0xfb,0x0e,0x00,0x94,0xfb,0x11,0x00,0x85,0xfb,0x14,0x00,0x77,0xfb,0x18,0x00,0x68,0xfb,0x1b,0x00,0x59,0xfb,0x1e,0x00,0x4b,0xfb,0x22,0x00,0x3c,0xfb,0x25,0x00,0x2d,0xfb,0x28,0x00,0x1e,0xfb,0x2c,0x00,0x0f,0xfb,0x2f,0x00,0x00,0xfb,0x33,0x00,0xf1,0xfa,0x36,0x00,0xe2,0xfa,0x3a,0x00,0xd3,0xfa,0x3d,0x00,0xc4,0xfa,0x41,0x00,0xb5,0xfa,0x45,0x00,0xa5,0xfa,0x48,0x00,0x96,0xfa,0x4c,0x00,0x87,0xfa,0x50,0x00,0x78,0xfa,0x54,0x00,0x68,0xfa,  \
    0x57,0x00,0x59,0xfa,0x5b,0x00,0x4a,0xfa,0x5f,0x00,0x3a,0xfa,0x63,0x00,0x2b,0xfa,0x67,0x00,0x1b,0xfa,0x6b,0x00,0x0c,0xfa,0x6f,0x00,0xfc,0xf9,0x73,0x00,0xec,0xf9,0x78,0x00,0xdd,0xf9,0x7c,0x00,0xcd,0xf9,0x80,0x00,0xbd,0xf9,0x84,0x00,0xae,0xf9,0x89,0x00,0x9e,0xf9,0x8d,0x00,0x8f,0xf9,0x91,0x00,0x7f,0xf9,0x96,0x00,0x6f,0xf9,0x9a,0x00,0x5f,0xf9,0x9f,0x00,0x4f,0xf9,0xa3,0x00,0x40,0xf9,0xa8,0x00,0x30,0xf9,0xad,0x00,0x20,0xf9,0xb1,0x00,0x10,0xf9,0xb6,0x00,  \
    0x00,0xf9,0xbb,0x00,0xef,0xf8,0xbf,0x00,0xdf,0xf8,0xc4,0x00,0xcf,0xf8,0xc9,0x00,0xbf,0xf8,0xce,0x00,0xaf,0xf8,0xd3,0x00,0x9e,0xf8,0xd8,0x00,0x8e,0xf8,0xdc,0x00,0x7d,0xf8,0xe1,0x00,0x6d,0xf8,0xe6,0x00,0x5c,0xf8,0xeb,0x00,0x4b,0xf8,0xf0,0x00,0x3b,0xf8,0xf5,0x00,0x2a,0xf8,0xfa,0x00,0x19,0xf8,0xff,0x00,0x07,0xf8,0x05,0x01,0xf6,0xf7,0x0a,0x01,0xe5,0xf7,0x0f,0x01,0xd4,0xf7,0x14,0x01,0xc3,0xf7,0x19,0x01,0xb1,0xf7,0x1e,0x01,0xa0,0xf7,0x24,0x01,0x8e,0xf7,  \
    0x29,0x01,0x7d,0xf7,0x2e,0x01,0x6b,0xf7,0x33,0x01,0x59,0xf7,0x39,0x01,0x48,0xf7,0x3e,0x01,0x36,0xf7,0x43,0x01,0x24,0xf7,0x49,0x01,0x12,0xf7,0x4e,0x01,0x00,0xf7,0x54,0x01,0xee,0xf6,0x59,0x01,0xdc,0xf6,0x5f,0x01,0xca,0xf6,0x64,0x01,0xb7,0xf6,0x6a,0x01,0xa5,0xf6,0x6f,0x01,0x93,0xf6,0x75,0x01,0x81,0xf6,0x7b,0x01,0x6e,0xf6,0x80,0x01,0x5c,0xf6,0x86,0x01,0x49,0xf6,0x8b,0x01,0x36,0xf6,0x91,0x01,0x24,0xf6,0x97,0x01,0x11,0xf6,0x9c,0x01,0xfe,0xf5,0xa2,0x01,  \
    0xeb,0xf5,0xa8,0x01,0xd8,0xf5,0xad,0x01,0xc5,0xf5,0xb3,0x01,0xb1,0xf5,0xb9,0x01,0x9e,0xf5,0xbf,0x01,0x8a,0xf5,0xc4,0x01,0x77,0xf5,0xca,0x01,0x63,0xf5,0xcf,0x01,0x4f,0xf5,0xd5,0x01,0x3a,0xf5,0xda,0x01,0x26,0xf5,0xe0,0x01,0x11,0xf5,0xe5,0x01,0xfd,0xf4,0xeb,0x01,0xe8,0xf4,0xf0,0x01,0xd3,0xf4,0xf5,0x01,0xbe,0xf4,0xfb,0x01,0xa9,0xf4,0x00,0x02,0x94,0xf4,0x06,0x02,0x7f,0xf4,0x0b,0x02,0x6a,0xf4,0x11,0x02,0x55,0xf4,0x16,0x02,0x3f,0xf4,0x1b,0x02,0x2a,0xf4,  \
    0x21,0x02,0x14,0xf4,0x26,0x02,0xfe,0xf3,0x2b,0x02,0xe8,0xf3,0x31,0x02,0xd3,0xf3,0x37,0x02,0xbd,0xf3,0x3c,0x02,0xa8,0xf3,0x42,0x02,0x92,0xf3,0x47,0x02,0x7c,0xf3,0x4c,0x02,0x66,0xf3,0x52,0x02,0x50,0xf3,0x57,0x02,0x39,0xf3,0x5d,0x02,0x23,0xf3,0x62,0x02,0x0d,0xf3,0x67,0x02,0xf6,0xf2,0x6c,0x02,0xdf,0xf2,0x72,0x02,0xc8,0xf2,0x77,0x02,0xb1,0xf2,0x7c,0x02,0x9a,0xf2,0x81,0x02,0x83,0xf2,0x86,0x02,0x6c,0xf2,0x8b,0x02,0x54,0xf2,0x90,0x02,0x3c,0xf2,0x95,0x02,  \
    0x25,0xf2,0x9a,0x02,0x0d,0xf2,0x9f,0x02,0xf5,0xf1,0xa4,0x02,0xdd,0xf1,0xa8,0x02,0xc5,0xf1,0xad,0x02,0xac,0xf1,0xb2,0x02,0x94,0xf1,0xb6,0x02,0x7b,0xf1,0xbb,0x02,0x63,0xf1,0xbf,0x02,0x4a,0xf1,0xc3,0x02,0x31,0xf1,0xc8,0x02,0x17,0xf1,0xcc,0x02,0xfe,0xf0,0xd0,0x02,0xe5,0xf0,0xd4,0x02,0xcb,0xf0,0xd8,0x02,0xb1,0xf0,0xdc,0x02,0x97,0xf0,0xe0,0x02,0x7d,0xf0,0xe4,0x02,0x63,0xf0,0xe8,0x02,0x49,0xf0,0xeb,0x02,0x2e,0xf0,0xee,0x02,0x13,0xf0,0xf2,0x02,0xf8,0xef,  \
    0xf5,0x02,0xdd,0xef,0xf8,0x02,0xc2,0xef,0xfb,0x02,0xa6,0xef,0xfe,0x02,0x8b,0xef,0x01,0x03,0x6f,0xef,0x04,0x03,0x53,0xef,0x07,0x03,0x37,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0x03,  \
    0xb7,0x10,0x31,0x03,0x9b,0x10,0x2e,0x03,0x7f,0x10,0x2b,0x03,0x63,0x10,0x28,0x03,0x47,0x10,0x25,0x03,0x2c,0x10,0x22,0x03,0x10,0x10,0x1e,0x03,0xf5,0x0f,0x1b,0x03,0xda,0x0f,0x18,0x03,0xbf,0x0f,0x14,0x03,0xa4,0x0f,0x10,0x03,0x89,0x0f,0x0d,0x03,0x6e,0x0f,0x09,0x03,0x53,0x0f,0x05,0x03,0x39,0x0f,0x01,0x03,0x1f,0x0f,0xfd,0x02,0x04,0x0f,0xf9,0x02,0xea,0x0e,0xf5,0x02,0xd0,0x0e,0xf1,0x02,0xb7,0x0e,0xed,0x02,0x9d,0x0e,0xe8,0x02,0x84,0x0e,0xe4,0x02,0x6a,0x0e,  \
    0xdf,0x02,0x51,0x0e,0xda,0x02,0x38,0x0e,0xd6,0x02,0x20,0x0e,0xd1,0x02,0x07,0x0e,0xcc,0x02,0xee,0x0d,0xc7,0x02,0xd6,0x0d,0xc2,0x02,0xbd,0x0d,0xbe,0x02,0xa5,0x0d,0xb9,0x02,0x8d,0x0d,0xb3,0x02,0x75,0x0d,0xae,0x02,0x5d,0x0d,0xa9,0x02,0x45,0x0d,0xa4,0x02,0x2e,0x0d,0x9f,0x02,0x16,0x0d,0x9a,0x02,0xff,0x0c,0x94,0x02,0xe8,0x0c,0x8f,0x02,0xd1,0x0c,0x89,0x02,0xba,0x0c,0x84,0x02,0xa3,0x0c,0x7e,0x02,0x8d,0x0c,0x79,0x02,0x76,0x0c,0x73,0x02,0x60,0x0c,0x6d,0x02,  \
    0x4a,0x0c,0x67,0x02,0x34,0x0c,0x62,0x02,0x1e,0x0c,0x5c,0x02,0x08,0x0c,0x56,0x02,0xf2,0x0b,0x50,0x02,0xdd,0x0b,0x4a,0x02,0xc7,0x0b,0x44,0x02,0xb2,0x0b,0x3e,0x02,0x9d,0x0b,0x39,0x02,0x88,0x0b,0x33,0x02,0x73,0x0b,0x2d,0x02,0x5e,0x0b,0x27,0x02,0x49,0x0b,0x21,0x02,0x34,0x0b,0x1c,0x02,0x1e,0x0b,0x16,0x02,0x09,0x0b,0x11,0x02,0xf4,0x0a,0x0b,0x02,0xdf,0x0a,0x05,0x02,0xc9,0x0a,0x00,0x02,0xb4,0x0a,0xfa,0x01,0xa0,0x0a,0xf5,0x01,0x8b,0x0a,0xef,0x01,0x76,0x0a,  \
    0xe9,0x01,0x62,0x0a,0xe4,0x01,0x4d,0x0a,0xde,0x01,0x39,0x0a,0xd9,0x01,0x24,0x0a,0xd3,0x01,0x10,0x0a,0xcd,0x01,0xfc,0x09,0xc8,0x01,0xe8,0x09,0xc2,0x01,0xd4,0x09,0xbd,0x01,0xc0,0x09,0xb7,0x01,0xac,0x09,0xb1,0x01,0x98,0x09,0xac,0x01,0x84,0x09,0xa6,0x01,0x71,0x09,0xa1,0x01,0x5d,0x09,0x9b,0x01,0x4a,0x09,0x96,0x01,0x36,0x09,0x90,0x01,0x23,0x09,0x8b,0x01,0x10,0x09,0x85,0x01,0xfd,0x08,0x80,0x01,0xe9,0x08,0x7a,0x01,0xd6,0x08,0x75,0x01,0xc3,0x08,0x6f,0x01,  \
    0xb1,0x08,0x6a,0x01,0x9e,0x08,0x64,0x01,0x8b,0x08,0x5f,0x01,0x79,0x08,0x59,0x01,0x67,0x08,0x54,0x01,0x55,0x08,0x4e,0x01,0x44,0x08,0x48,0x01,0x32,0x08,0x42,0x01,0x21,0x08,0x3d,0x01,0x0f,0x08,0x37,0x01,0xfe,0x07,0x32,0x01,0xed,0x07,0x2c,0x01,0xdc,0x07,0x27,0x01,0xcb,0x07,0x21,0x01,0xba,0x07,0x1c,0x01,0xa9,0x07,0x16,0x01,0x98,0x07,0x11,0x01,0x87,0x07,0x0b,0x01,0x76,0x07,0x06,0x01,0x65,0x07,0x01,0x01,0x55,0x07,0xfb,0x00,0x44,0x07,0xf6,0x00,0x34,0x07,  \
    0xf1,0x00,0x23,0x07,0xec,0x00,0x13,0x07,0xe7,0x00,0x02,0x07,0xe1,0x00,0xf2,0x06,0xdc,0x00,0xe1,0x06,0xd7,0x00,0xd1,0x06,0xd2,0x00,0xc1,0x06,0xcd,0x00,0xb1,0x06,0xc8,0x00,0xa0,0x06,0xc3,0x00,0x90,0x06,0xbf,0x00,0x80,0x06,0xba,0x00,0x70,0x06,0xb5,0x00,0x60,0x06,0xb0,0x00,0x50,0x06,0xab,0x00,0x40,0x06,0xa7,0x00,0x31,0x06,0xa2,0x00,0x21,0x06,0x9d,0x00,0x11,0x06,0x99,0x00,0x01,0x06,0x94,0x00,0xf2,0x05,0x90,0x00,0xe2,0x05,0x8b,0x00,0xd3,0x05,0x87,0x00,  \
    0xc3,0x05,0x82,0x00,0xb4,0x05,0x7e,0x00,0xa4,0x05,0x7a,0x00,0x94,0x05,0x76,0x00,0x84,0x05,0x72,0x00,0x74,0x05,0x6e,0x00,0x64,0x05,0x6a,0x00,0x54,0x05,0x65,0x00,0x44,0x05,0x62,0x00,0x35,0x05,0x5e,0x00,0x25,0x05,0x5a,0x00,0x15,0x05,0x56,0x00,0x06,0x05,0x52,0x00,0xf6,0x04,0x4e,0x00,0xe7,0x04,0x4a,0x00,0xd7,0x04,0x47,0x00,0xc8,0x04,0x43,0x00,0xb9,0x04,0x3f,0x00,0xa9,0x04,0x3c,0x00,0x9a,0x04,0x38,0x00,0x8b,0x04,0x34,0x00,0x7b,0x04,0x31,0x00,0x6c,0x04,  \
    0x2d,0x00,0x5d,0x04,0x2a,0x00,0x4e,0x04,0x26,0x00,0x3f,0x04,0x23,0x00,0x30,0x04,0x20,0x00,0x21,0x04,0x1c,0x00,0x13,0x04,0x19,0x00,0x04,0x04,0x16,0x00,0xf6,0x03,0x12,0x00,0xe7,0x03,0x0f,0x00,0xd9,0x03,0x0c,0x00,0xca,0x03,0x09,0x00,0xbc,0x03,0x06,0x00,0xad,0x03,0x03,0x00,0x9f,0x03,0x00,0x00,0x90,0x03,0xfd,0xff,0x82,0x03,0xfa,0xff,0x74,0x03,0xf7,0xff,0x65,0x03,0xf4,0xff,0x57,0x03,0xf1,0xff,0x49,0x03,0xef,0xff,0x3b,0x03,0xec,0xff,0x2c,0x03,0xe9,0xff,  \
    0x1e,0x03,0xe7,0xff,0x10,0x03,0xe4,0xff,0x02,0x03,0xe1,0xff,0xf4,0x02,0xdf,0xff,0xe5,0x02,0xdc,0xff,0xd7,0x02,0xda,0xff,0xc9,0x02,0xd8,0xff,0xbc,0x02,0xd5,0xff,0xae,0x02,0xd3,0xff,0xa0,0x02,0xd1,0xff,0x92,0x02,0xce,0xff,0x85,0x02,0xcc,0xff,0x77,0x02,0xca,0xff,0x69,0x02,0xc8,0xff,0x5b,0x02,0xc6,0xff,0x4e,0x02,0xc4,0xff,0x40,0x02,0xc2,0xff,0x32,0x02,0xc0,0xff,0x25,0x02,0xbe,0xff,0x17,0x02,0xbc,0xff,0x09,0x02,0xba,0xff,0xfc,0x01,0xb9,0xff,0xee,0x01,  \
    0xb7,0xff,0xe0,0x01,0xb5,0xff,0xd3,0x01,0xb4,0xff,0xc5,0x01,0xb2,0xff,0xb7,0x01,0xb0,0xff,0xaa,0x01,0xaf,0xff,0x9c,0x01,0xae,0xff,0x8e,0x01,0xac,0xff,0x81,0x01,0xab,0xff,0x73,0x01,0xa9,0xff,0x65,0x01,0xa8,0xff,0x57,0x01,0xa7,0xff,0x4a,0x01,0xa6,0xff,0x3c,0x01,0xa5,0xff,0x2e,0x01,0xa4,0xff,0x20,0x01,0xa3,0xff,0x12,0x01,0xa2,0xff,0x04,0x01,0xa1,0xff,0xf6,0x00,0xa0,0xff,0xe8,0x00,0x9f,0xff,0xdb,0x00,0x9e,0xff,0xcd,0x00,0x9d,0xff,0xbf,0x00,0x9c,0xff,  \
    0xb1,0x00,0x9c,0xff,0xa3,0x00,0x9b,0xff,0x95,0x00,0x9a,0xff,0x88,0x00,0x9a,0xff,0x7a,0x00,0x99,0xff,0x6c,0x00,0x99,0xff,0x5e,0x00,0x98,0xff,0x50,0x00,0x98,0xff,0x42,0x00,0x98,0xff,0x35,0x00,0x97,0xff,0x27,0x00,0x97,0xff,0x19,0x00,0x97,0xff,0x0b,0x00,0x97,0xff,0xfe,0xff,0x96,0xff,0xf0,0xff,0x96,0xff,0xe2,0xff,0x96,0xff,0xd4,0xff,0x96,0xff,0xc6,0xff,0x96,0xff,0xb9,0xff,0x96,0xff,0xab,0xff,0x96,0xff,0x9d,0xff,0x96,0xff,0x8f,0xff,0x97,0xff,0x81,0xff,  \
    0x97,0xff,0x74,0xff,0x97,0xff,0x66,0xff,0x97,0xff,0x58,0xff,0x98,0xff,0x4a,0xff,0x98,0xff,0x3d,0xff,0x98,0xff,0x2f,0xff,0x99,0xff,0x21,0xff,0x99,0xff,0x13,0xff,0x9a,0xff,0x05,0xff,0x9b,0xff,0xf8,0xfe,0x9b,0xff,0xea,0xfe,0x9c,0xff,0xdc,0xfe,0x9d,0xff,0xce,0xfe,0x9d,0xff,0xc0,0xfe,0x9e,0xff,0xb3,0xfe,0x9f,0xff,0xa5,0xfe,0xa0,0xff,0x97,0xfe,0xa1,0xff,0x89,0xfe,0xa2,0xff,0x7b,0xfe,0xa3,0xff,0x6d,0xfe,0xa4,0xff,0x60,0xfe,0xa5,0xff,0x52,0xfe,0xa6,0xff,  \
    0x44,0xfe,0xa7,0xff,0x36,0xfe,0xa8,0xff,0x28,0xfe,0xa9,0xff,0x1a,0xfe,0xab,0xff,0x0c,0xfe,0xac,0xff,0xfe,0xfd,0xad,0xff,0xf0,0xfd,0xaf,0xff,0xe2,0xfd,0xb0,0xff,0xd4,0xfd,0xb2,0xff,0xc6,0xfd,0xb3,0xff,0xb8,0xfd,0xb5,0xff,0xa9,0xfd,0xb6,0xff,0x9b,0xfd,0xb8,0xff,0x8d,0xfd,0xba,0xff,0x7f,0xfd,0xbb,0xff,0x71,0xfd,0xbd,0xff,0x63,0xfd,0xbf,0xff,0x54,0xfd,0xc1,0xff,0x46,0xfd,0xc3,0xff,0x38,0xfd,0xc4,0xff,0x2a,0xfd,0xc6,0xff,0x1b,0xfd,0xc8,0xff,0x0d,0xfd,  \
    0xca,0xff,0xff,0xfc,0xcc,0xff,0xf1,0xfc,0xcf,0xff,0xe2,0xfc,0xd1,0xff,0xd4,0xfc,0xd3,0xff,0xc5,0xfc,0xd5,0xff,0xb7,0xfc,0xd7,0xff,0xa9,0xfc,0xda,0xff,0x9b,0xfc,0xdc,0xff,0x8d,0xfc,0xdf,0xff,0x7f,0xfc,0xe1,0xff,0x71,0xfc,0xe4,0xff,0x62,0xfc,0xe6,0xff,0x54,0xfc,0xe9,0xff,0x46,0xfc,0xeb,0xff,0x38,0xfc,0xee,0xff,0x29,0xfc,0xf1,0xff,0x1b,0xfc,0xf3,0xff,0x0d,0xfc,0xf6,0xff,0xff,0xfb,0xf9,0xff,0xf0,0xfb,0xfc,0xff,0xe2,0xfb,0xff,0xff,0xd4,0xfb,0x02,0x00,  \
    0xc5,0xfb,0x05,0x00,0xb7,0xfb,0x08,0x00,0xa8,0xfb,0x0b,0x00,0x9a,0xfb,0x0e,0x00,0x8b,0xfb,0x11,0x00,0x7d,0xfb,0x14,0x00,0x6e,0xfb,0x18,0x00,0x60,0xfb,0x1b,0x00,0x51,0xfb,0x1e,0x00,0x43,0xfb,0x22,0x00,0x34,0xfb,0x25,0x00,0x25,0xfb,0x28,0x00,0x16,0xfb,0x2c,0x00,0x07,0xfb,0x2f,0x00,0xf8,0xfa,0x33,0x00,0xe9,0xfa,0x36,0x00,0xda,0xfa,0x3a,0x00,0xcb,0xfa,0x3d,0x00,0xbc,0xfa,0x41,0x00,0xad,0xfa,0x45,0x00,0x9d,0xfa,0x49,0x00,0x8e,0xfa,0x4c,0x00,0x7f,0xfa,  \
    0x50,0x00,0x70,0xfa,0x54,0x00,0x60,0xfa,0x58,0x00,0x51,0xfa,0x5c,0x00,0x42,0xfa,0x60,0x00,0x32,0xfa,0x64,0x00,0x23,0xfa,0x68,0x00,0x13,0xfa,0x6c,0x00,0x04,0xfa,0x70,0x00,0xf4,0xf9,0x74,0x00,0xe5,0xf9,0x78,0x00,0xd5,0xf9,0x7c,0x00,0xc5,0xf9,0x81,0x00,0xb6,0xf9,0x85,0x00,0xa6,0xf9,0x89,0x00,0x97,0xf9,0x8e,0x00,0x87,0xf9,0x92,0x00,0x77,0xf9,0x96,0x00,0x67,0xf9,0x9b,0x00,0x58,0xf9,0x9f,0x00,0x48,0xf9,0xa4,0x00,0x38,0xf9,0xa9,0x00,0x28,0xf9,0xad,0x00,  \
    0x18,0xf9,0xb2,0x00,0x08,0xf9,0xb7,0x00,0xf8,0xf8,0xbb,0x00,0xe8,0xf8,0xc0,0x00,0xd7,0xf8,0xc5,0x00,0xc7,0xf8,0xca,0x00,0xb7,0xf8,0xce,0x00,0xa7,0xf8,0xd3,0x00,0x96,0xf8,0xd8,0x00,0x86,0xf8,0xdd,0x00,0x75,0xf8,0xe2,0x00,0x65,0xf8,0xe7,0x00,0x54,0xf8,0xec,0x00,0x43,0xf8,0xf1,0x00,0x32,0xf8,0xf6,0x00,0x21,0xf8,0xfb,0x00,0x10,0xf8,0x00,0x01,0xff,0xf7,0x05,0x01,0xee,0xf7,0x0a,0x01,0xdc,0xf7,0x0f,0x01,0xcb,0xf7,0x15,0x01,0xba,0xf7,0x1a,0x01,0xa8,0xf7,  \
    0x1f,0x01,0x97,0xf7,0x24,0x01,0x85,0xf7,0x29,0x01,0x74,0xf7,0x2f,0x01,0x62,0xf7,0x34,0x01,0x50,0xf7,0x39,0x01,0x3e,0xf7,0x3f,0x01,0x2d,0xf7,0x44,0x01,0x1b,0xf7,0x49,0x01,0x09,0xf7,0x4f,0x01,0xf7,0xf6,0x54,0x01,0xe4,0xf6,0x5a,0x01,0xd2,0xf6,0x5f,0x01,0xc0,0xf6,0x65,0x01,0xae,0xf6,0x6a,0x01,0x9c,0xf6,0x70,0x01,0x89,0xf6,0x75,0x01,0x77,0xf6,0x7b,0x01,0x64,0xf6,0x80,0x01,0x52,0xf6,0x86,0x01,0x3f,0xf6,0x8c,0x01,0x2c,0xf6,0x91,0x01,0x19,0xf6,0x97,0x01,  \
    0x06,0xf6,0x9c,0x01,0xf3,0xf5,0xa2,0x01,0xe0,0xf5,0xa8,0x01,0xcd,0xf5,0xad,0x01,0xba,0xf5,0xb3,0x01,0xa7,0xf5,0xb9,0x01,0x93,0xf5,0xbe,0x01,0x7f,0xf5,0xc4,0x01,0x6b,0xf5,0xc9,0x01,0x57,0xf5,0xcf,0x01,0x43,0xf5,0xd4,0x01,0x2e,0xf5,0xda,0x01,0x1a,0xf5,0xdf,0x01,0x05,0xf5,0xe4,0x01,0xf1,0xf4,0xea,0x01,0xdc,0xf4,0xef,0x01,0xc7,0xf4,0xf5,0x01,0xb2,0xf4,0xfa,0x01,0x9d,0xf4,0xff,0x01,0x88,0xf4,0x05,0x02,0x72,0xf4,0x0a,0x02,0x5d,0xf4,0x0f,0x02,0x48,0xf4,  \
    0x15,0x02,0x32,0xf4,0x1a,0x02,0x1c,0xf4,0x1f,0x02,0x07,0xf4,0x25,0x02,0xf1,0xf3,0x2a,0x02,0xdb,0xf3,0x30,0x02,0xc6,0xf3,0x35,0x02,0xb0,0xf3,0x3b,0x02,0x9a,0xf3,0x40,0x02,0x84,0xf3,0x45,0x02,0x6e,0xf3,0x4b,0x02,0x58,0xf3,0x50,0x02,0x42,0xf3,0x55,0x02,0x2b,0xf3,0x5b,0x02,0x15,0xf3,0x60,0x02,0xfe,0xf2,0x65,0x02,0xe7,0xf2,0x6a,0x02,0xd0,0xf2,0x6f,0x02,0xb9,0xf2,0x74,0x02,0xa2,0xf2,0x79,0x02,0x8b,0xf2,0x7e,0x02,0x74,0xf2,0x83,0x02,0x5c,0xf2,0x88,0x02,  \
    0x44,0xf2,0x8d,0x02,0x2d,0xf2,0x92,0x02,0x15,0xf2,0x97,0x02,0xfd,0xf1,0x9c,0x02,0xe5,0xf1,0xa0,0x02,0xcd,0xf1,0xa5,0x02,0xb4,0xf1,0xa9,0x02,0x9c,0xf1,0xae,0x02,0x83,0xf1,0xb2,0x02,0x6a,0xf1,0xb7,0x02,0x51,0xf1,0xbb,0x02,0x38,0xf1,0xbf,0x02,0x1f,0xf1,0xc4,0x02,0x06,0xf1,0xc8,0x02,0xec,0xf0,0xcc,0x02,0xd3,0xf0,0xd0,0x02,0xb9,0xf0,0xd4,0x02,0x9f,0xf0,0xd8,0x02,0x85,0xf0,0xdb,0x02,0x6b,0xf0,0xdf,0x02,0x50,0xf0,0xe2,0x02,0x35,0xf0,0xe6,0x02,0x1b,0xf0,  \
    0xe9,0x02,0x00,0xf0,0xec,0x02,0xe4,0xef,0xef,0x02,0xc9,0xef,0xf2,0x02,0xae,0xef,0xf5,0x02,0x92,0xef,0xf8,0x02,0x76,0xef,0xfb,0x02,0x5a,0xef,0xfe,0x02,0x3e,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x2b,0x03,0xb1,0x10,0x29,0x03,0x94,0x10,0x26,0x03,0x78,0x10,0x23,0x03,0x5c,0x10,0x20,0x03,0x41,0x10,0x1d,0x03,0x25,0x10,0x1a,0x03,0x0a,0x10,0x16,0x03,0xee,0x0f,0x13,0x03,0xd3,0x0f,0x10,0x03,0xb8,0x0f,0x0c,0x03,0x9d,0x0f,0x08,0x03,0x82,0x0f,0x05,0x03,0x67,0x0f,0x01,0x03,0x4d,0x0f,0xfd,0x02,0x32,0x0f,0xf9,0x02,0x18,0x0f,0xf5,0x02,0xfe,0x0e,0xf1,0x02,0xe4,0x0e,0xed,0x02,0xca,0x0e,0xe9,0x02,0xb0,0x0e,0xe5,0x02,0x96,0x0e,0xe0,0x02,0x7d,0x0e,  \
    0xdc,0x02,0x64,0x0e,0xd8,0x02,0x4a,0x0e,0xd3,0x02,0x31,0x0e,0xce,0x02,0x18,0x0e,0xca,0x02,0x00,0x0e,0xc5,0x02,0xe7,0x0d,0xc0,0x02,0xcf,0x0d,0xbb,0x02,0xb6,0x0d,0xb6,0x02,0x9e,0x0d,0xb1,0x02,0x86,0x0d,0xac,0x02,0x6e,0x0d,0xa7,0x02,0x56,0x0d,0xa2,0x02,0x3e,0x0d,0x9d,0x02,0x27,0x0d,0x98,0x02,0x0f,0x0d,0x93,0x02,0xf8,0x0c,0x8d,0x02,0xe0,0x0c,0x88,0x02,0xc9,0x0c,0x83,0x02,0xb2,0x0c,0x7d,0x02,0x9c,0x0c,0x78,0x02,0x85,0x0c,0x72,0x02,0x6f,0x0c,0x6c,0x02,  \
    0x58,0x0c,0x67,0x02,0x42,0x0c,0x61,0x02,0x2c,0x0c,0x5b,0x02,0x16,0x0c,0x56,0x02,0x00,0x0c,0x50,0x02,0xeb,0x0b,0x4a,0x02,0xd5,0x0b,0x44,0x02,0xc0,0x0b,0x3e,0x02,0xaa,0x0b,0x38,0x02,0x95,0x0b,0x33,0x02,0x80,0x0b,0x2d,0x02,0x6b,0x0b,0x27,0x02,0x56,0x0b,0x21,0x02,0x41,0x0b,0x1b,0x02,0x2c,0x0b,0x16,0x02,0x16,0x0b,0x10,0x02,0x01,0x0b,0x0b,0x02,0xec,0x0a,0x05,0x02,0xd6,0x0a,0x00,0x02,0xc1,0x0a,0xfa,0x01,0xac,0x0a,0xf5,0x01,0x98,0x0a,0xef,0x01,0x83,0x0a,  \
    0xe9,0x01,0x6e,0x0a,0xe4,0x01,0x59,0x0a,0xde,0x01,0x45,0x0a,0xd9,0x01,0x30,0x0a,0xd3,0x01,0x1c,0x0a,0xce,0x01,0x08,0x0a,0xc8,0x01,0xf4,0x09,0xc2,0x01,0xe0,0x09,0xbd,0x01,0xcc,0x09,0xb7,0x01,0xb8,0x09,0xb2,0x01,0xa4,0x09,0xac,0x01,0x90,0x09,0xa7,0x01,0x7c,0x09,0xa1,0x01,0x69,0x09,0x9c,0x01,0x55,0x09,0x96,0x01,0x42,0x09,0x91,0x01,0x2e,0x09,0x8b,0x01,0x1b,0x09,0x86,0x01,0x08,0x09,0x80,0x01,0xf5,0x08,0x7b,0x01,0xe2,0x08,0x75,0x01,0xcf,0x08,0x70,0x01,  \
    0xbc,0x08,0x6a,0x01,0xa9,0x08,0x65,0x01,0x96,0x08,0x60,0x01,0x83,0x08,0x5a,0x01,0x71,0x08,0x55,0x01,0x5f,0x08,0x4f,0x01,0x4d,0x08,0x49,0x01,0x3c,0x08,0x44,0x01,0x2a,0x08,0x3e,0x01,0x19,0x08,0x38,0x01,0x07,0x08,0x33,0x01,0xf6,0x07,0x2d,0x01,0xe5,0x07,0x28,0x01,0xd4,0x07,0x22,0x01,0xc3,0x07,0x1d,0x01,0xb2,0x07,0x17,0x01,0xa1,0x07,0x12,0x01,0x90,0x07,0x0d,0x01,0x7f,0x07,0x07,0x01,0x6e,0x07,0x02,0x01,0x5e,0x07,0xfd,0x00,0x4d,0x07,0xf7,0x00,0x3c,0x07,  \
    0xf2,0x00,0x2c,0x07,0xed,0x00,0x1b,0x07,0xe8,0x00,0x0b,0x07,0xe3,0x00,0xfa,0x06,0xde,0x00,0xea,0x06,0xd8,0x00,0xda,0x06,0xd3,0x00,0xc9,0x06,0xce,0x00,0xb9,0x06,0xca,0x00,0xa9,0x06,0xc5,0x00,0x99,0x06,0xc0,0x00,0x89,0x06,0xbb,0x00,0x79,0x06,0xb6,0x00,0x69,0x06,0xb1,0x00,0x59,0x06,0xad,0x00,0x49,0x06,0xa8,0x00,0x39,0x06,0xa3,0x00,0x29,0x06,0x9e,0x00,0x19,0x06,0x9a,0x00,0x0a,0x06,0x95,0x00,0xfa,0x05,0x91,0x00,0xea,0x05,0x8c,0x00,0xdb,0x05,0x88,0x00,  \
    0xcb,0x05,0x83,0x00,0xbc,0x05,0x7f,0x00,0xac,0x05,0x7b,0x00,0x9c,0x05,0x77,0x00,0x8c,0x05,0x72,0x00,0x7c,0x05,0x6e,0x00,0x6d,0x05,0x6a,0x00,0x5d,0x05,0x66,0x00,0x4d,0x05,0x62,0x00,0x3d,0x05,0x5e,0x00,0x2e,0x05,0x5a,0x00,0x1e,0x05,0x56,0x00,0x0f,0x05,0x53,0x00,0xff,0x04,0x4f,0x00,0xf0,0x04,0x4b,0x00,0xe0,0x04,0x47,0x00,0xd1,0x04,0x43,0x00,0xc1,0x04,0x40,0x00,0xb2,0x04,0x3c,0x00,0xa3,0x04,0x38,0x00,0x93,0x04,0x35,0x00,0x84,0x04,0x31,0x00,0x75,0x04,  \
    0x2e,0x00,0x66,0x04,0x2a,0x00,0x57,0x04,0x27,0x00,0x48,0x04,0x23,0x00,0x39,0x04,0x20,0x00,0x2a,0x04,0x1d,0x00,0x1c,0x04,0x19,0x00,0x0d,0x04,0x16,0x00,0xfe,0x03,0x13,0x00,0xf0,0x03,0x0f,0x00,0xe1,0x03,0x0c,0x00,0xd3,0x03,0x09,0x00,0xc5,0x03,0x06,0x00,0xb6,0x03,0x03,0x00,0xa8,0x03,0x00,0x00,0x99,0x03,0xfd,0xff,0x8b,0x03,0xfa,0xff,0x7d,0x03,0xf7,0xff,0x6e,0x03,0xf4,0xff,0x60,0x03,0xf1,0xff,0x52,0x03,0xee,0xff,0x44,0x03,0xec,0xff,0x36,0x03,0xe9,0xff,  \
    0x27,0x03,0xe6,0xff,0x19,0x03,0xe4,0xff,0x0b,0x03,0xe1,0xff,0xfd,0x02,0xdf,0xff,0xef,0x02,0xdc,0xff,0xe1,0x02,0xda,0xff,0xd3,0x02,0xd7,0xff,0xc5,0x02,0xd5,0xff,0xb7,0x02,0xd2,0xff,0xa9,0x02,0xd0,0xff,0x9c,0x02,0xce,0xff,0x8e,0x02,0xcc,0xff,0x80,0x02,0xc9,0xff,0x73,0x02,0xc7,0xff,0x65,0x02,0xc5,0xff,0x58,0x02,0xc3,0xff,0x4a,0x02,0xc1,0xff,0x3c,0x02,0xbf,0xff,0x2f,0x02,0xbd,0xff,0x21,0x02,0xbb,0xff,0x13,0x02,0xb9,0xff,0x06,0x02,0xb8,0xff,0xf8,0x01,  \
    0xb6,0xff,0xeb,0x01,0xb4,0xff,0xdd,0x01,0xb3,0xff,0xcf,0x01,0xb1,0xff,0xc2,0x01,0xaf,0xff,0xb4,0x01,0xae,0xff,0xa7,0x01,0xac,0xff,0x99,0x01,0xab,0xff,0x8b,0x01,0xaa,0xff,0x7e,0x01,0xa8,0xff,0x70,0x01,0xa7,0xff,0x62,0x01,0xa6,0xff,0x55,0x01,0xa4,0xff,0x47,0x01,0xa3,0xff,0x39,0x01,0xa2,0xff,0x2b,0x01,0xa1,0xff,0x1e,0x01,0xa0,0xff,0x10,0x01,0x9f,0xff,0x02,0x01,0x9e,0xff,0xf4,0x00,0x9d,0xff,0xe6,0x00,0x9c,0xff,0xd9,0x00,0x9b,0xff,0xcb,0x00,0x9b,0xff,  \
    0xbd,0x00,0x9a,0xff,0xaf,0x00,0x99,0xff,0xa2,0x00,0x98,0xff,0x94,0x00,0x98,0xff,0x86,0x00,0x97,0xff,0x79,0x00,0x97,0xff,0x6b,0x00,0x96,0xff,0x5d,0x00,0x96,0xff,0x4f,0x00,0x95,0xff,0x42,0x00,0x95,0xff,0x34,0x00,0x95,0xff,0x26,0x00,0x94,0xff,0x19,0x00,0x94,0xff,0x0b,0x00,0x94,0xff,0xfd,0xff,0x94,0xff,0xef,0xff,0x94,0xff,0xe2,0xff,0x94,0xff,0xd4,0xff,0x94,0xff,0xc6,0xff,0x94,0xff,0xb9,0xff,0x94,0xff,0xab,0xff,0x94,0xff,0x9d,0xff,0x94,0xff,0x90,0xff,  \
    0x94,0xff,0x82,0xff,0x94,0xff,0x74,0xff,0x94,0xff,0x67,0xff,0x95,0xff,0x59,0xff,0x95,0xff,0x4b,0xff,0x95,0xff,0x3d,0xff,0x96,0xff,0x30,0xff,0x96,0xff,0x22,0xff,0x97,0xff,0x14,0xff,0x97,0xff,0x07,0xff,0x98,0xff,0xf9,0xfe,0x99,0xff,0xeb,0xfe,0x99,0xff,0xdd,0xfe,0x9a,0xff,0xd0,0xfe,0x9b,0xff,0xc2,0xfe,0x9b,0xff,0xb4,0xfe,0x9c,0xff,0xa7,0xfe,0x9d,0xff,0x99,0xfe,0x9e,0xff,0x8b,0xfe,0x9f,0xff,0x7d,0xfe,0xa0,0xff,0x70,0xfe,0xa1,0xff,0x62,0xfe,0xa2,0xff,  \
    0x54,0xfe,0xa3,0xff,0x46,0xfe,0xa4,0xff,0x38,0xfe,0xa6,0xff,0x2b,0xfe,0xa7,0xff,0x1d,0xfe,0xa8,0xff,0x0f,0xfe,0xa9,0xff,0x01,0xfe,0xab,0xff,0xf3,0xfd,0xac,0xff,0xe5,0xfd,0xae,0xff,0xd7,0xfd,0xaf,0xff,0xc9,0xfd,0xb0,0xff,0xbb,0xfd,0xb2,0xff,0xad,0xfd,0xb4,0xff,0x9f,0xfd,0xb5,0xff,0x91,0xfd,0xb7,0xff,0x83,0xfd,0xb9,0xff,0x75,0xfd,0xba,0xff,0x67,0xfd,0xbc,0xff,0x58,0xfd,0xbe,0xff,0x4a,0xfd,0xc0,0xff,0x3c,0xfd,0xc2,0xff,0x2e,0xfd,0xc4,0xff,0x20,0xfd,  \
    0xc6,0xff,0x12,0xfd,0xc8,0xff,0x03,0xfd,0xca,0xff,0xf5,0xfc,0xcc,0xff,0xe7,0xfc,0xce,0xff,0xd9,0xfc,0xd0,0xff,0xca,0xfc,0xd2,0xff,0xbc,0xfc,0xd5,0xff,0xae,0xfc,0xd7,0xff,0xa0,0xfc,0xd9,0xff,0x92,0xfc,0xdc,0xff,0x84,0xfc,0xde,0xff,0x76,0xfc,0xe1,0xff,0x68,0xfc,0xe3,0xff,0x59,0xfc,0xe6,0xff,0x4b,0xfc,0xe8,0xff,0x3d,0xfc,0xeb,0xff,0x2f,0xfc,0xee,0xff,0x21,0xfc,0xf1,0xff,0x13,0xfc,0xf3,0xff,0x04,0xfc,0xf6,0xff,0xf6,0xfb,0xf9,0xff,0xe8,0xfb,0xfc,0xff,  \
    0xd9,0xfb,0xff,0xff,0xcb,0xfb,0x02,0x00,0xbd,0xfb,0x05,0x00,0xae,0xfb,0x08,0x00,0xa0,0xfb,0x0b,0x00,0x92,0xfb,0x0e,0x00,0x83,0xfb,0x11,0x00,0x75,0xfb,0x15,0x00,0x66,0xfb,0x18,0x00,0x58,0xfb,0x1b,0x00,0x49,0xfb,0x1e,0x00,0x3a,0xfb,0x22,0x00,0x2c,0xfb,0x25,0x00,0x1d,0xfb,0x29,0x00,0x0e,0xfb,0x2c,0x00,0xff,0xfa,0x30,0x00,0xf0,0xfa,0x33,0x00,0xe1,0xfa,0x37,0x00,0xd2,0xfa,0x3a,0x00,0xc3,0xfa,0x3e,0x00,0xb4,0xfa,0x42,0x00,0xa5,0xfa,0x45,0x00,0x95,0xfa,  \
    0x49,0x00,0x86,0xfa,0x4d,0x00,0x77,0xfa,0x51,0x00,0x68,0xfa,0x54,0x00,0x58,0xfa,0x58,0x00,0x49,0xfa,0x5c,0x00,0x3a,0xfa,0x60,0x00,0x2a,0xfa,0x64,0x00,0x1b,0xfa,0x68,0x00,0x0b,0xfa,0x6c,0x00,0xfc,0xf9,0x70,0x00,0xec,0xf9,0x75,0x00,0xdd,0xf9,0x79,0x00,0xcd,0xf9,0x7d,0x00,0xbe,0xf9,0x81,0x00,0xae,0xf9,0x86,0x00,0x9e,0xf9,0x8a,0x00,0x8f,0xf9,0x8e,0x00,0x7f,0xf9,0x93,0x00,0x6f,0xf9,0x97,0x00,0x60,0xf9,0x9c,0x00,0x50,0xf9,0xa0,0x00,0x40,0xf9,0xa5,0x00,  \
    0x30,0xf9,0xa9,0x00,0x20,0xf9,0xae,0x00,0x10,0xf9,0xb3,0x00,0x00,0xf9,0xb7,0x00,0xf0,0xf8,0xbc,0x00,0xe0,0xf8,0xc1,0x00,0xcf,0xf8,0xc6,0x00,0xbf,0xf8,0xca,0x00,0xaf,0xf8,0xcf,0x00,0x9e,0xf8,0xd4,0x00,0x8e,0xf8,0xd9,0x00,0x7e,0xf8,0xde,0x00,0x6d,0xf8,0xe3,0x00,0x5c,0xf8,0xe8,0x00,0x4b,0xf8,0xed,0x00,0x3b,0xf8,0xf2,0x00,0x2a,0xf8,0xf7,0x00,0x18,0xf8,0xfc,0x00,0x07,0xf8,0x01,0x01,0xf6,0xf7,0x06,0x01,0xe5,0xf7,0x0b,0x01,0xd4,0xf7,0x10,0x01,0xc2,0xf7,  \
    0x15,0x01,0xb1,0xf7,0x1a,0x01,0x9f,0xf7,0x1f,0x01,0x8e,0xf7,0x25,0x01,0x7c,0xf7,0x2a,0x01,0x6b,0xf7,0x2f,0x01,0x59,0xf7,0x34,0x01,0x47,0xf7,0x3a,0x01,0x35,0xf7,0x3f,0x01,0x23,0xf7,0x44,0x01,0x11,0xf7,0x4a,0x01,0xff,0xf6,0x4f,0x01,0xed,0xf6,0x55,0x01,0xdb,0xf6,0x5a,0x01,0xc9,0xf6,0x5f,0x01,0xb7,0xf6,0x65,0x01,0xa4,0xf6,0x6a,0x01,0x92,0xf6,0x70,0x01,0x7f,0xf6,0x75,0x01,0x6d,0xf6,0x7b,0x01,0x5a,0xf6,0x81,0x01,0x48,0xf6,0x86,0x01,0x35,0xf6,0x8c,0x01,  \
    0x22,0xf6,0x91,0x01,0x0f,0xf6,0x97,0x01,0xfc,0xf5,0x9c,0x01,0xe9,0xf5,0xa2,0x01,0xd6,0xf5,0xa8,0x01,0xc2,0xf5,0xad,0x01,0xaf,0xf5,0xb3,0x01,0x9b,0xf5,0xb9,0x01,0x88,0xf5,0xbe,0x01,0x74,0xf5,0xc3,0x01,0x60,0xf5,0xc9,0x01,0x4b,0xf5,0xce,0x01,0x37,0xf5,0xd4,0x01,0x22,0xf5,0xd9,0x01,0x0e,0xf5,0xde,0x01,0xf9,0xf4,0xe4,0x01,0xe4,0xf4,0xe9,0x01,0xcf,0xf4,0xee,0x01,0xba,0xf4,0xf4,0x01,0xa5,0xf4,0xf9,0x01,0x90,0xf4,0xfe,0x01,0x7b,0xf4,0x04,0x02,0x65,0xf4,  \
    0x09,0x02,0x50,0xf4,0x0e,0x02,0x3a,0xf4,0x14,0x02,0x25,0xf4,0x19,0x02,0x0f,0xf4,0x1e,0x02,0xf9,0xf3,0x24,0x02,0xe4,0xf3,0x29,0x02,0xce,0xf3,0x2e,0x02,0xb8,0xf3,0x34,0x02,0xa3,0xf3,0x39,0x02,0x8d,0xf3,0x3e,0x02,0x76,0xf3,0x44,0x02,0x60,0xf3,0x49,0x02,0x4a,0xf3,0x4e,0x02,0x33,0xf3,0x53,0x02,0x1d,0xf3,0x59,0x02,0x06,0xf3,0x5e,0x02,0xef,0xf2,0x63,0x02,0xd8,0xf2,0x68,0x02,0xc1,0xf2,0x6d,0x02,0xaa,0xf2,0x72,0x02,0x93,0xf2,0x77,0x02,0x7b,0xf2,0x7c,0x02,  \
    0x64,0xf2,0x81,0x02,0x4c,0xf2,0x85,0x02,0x34,0xf2,0x8a,0x02,0x1d,0xf2,0x8f,0x02,0x05,0xf2,0x94,0x02,0xec,0xf1,0x98,0x02,0xd4,0xf1,0x9d,0x02,0xbc,0xf1,0xa1,0x02,0xa3,0xf1,0xa6,0x02,0x8b,0xf1,0xaa,0x02,0x72,0xf1,0xaf,0x02,0x59,0xf1,0xb3,0x02,0x40,0xf1,0xb7,0x02,0x26,0xf1,0xbb,0x02,0x0d,0xf1,0xbf,0x02,0xf4,0xf0,0xc3,0x02,0xda,0xf0,0xc7,0x02,0xc0,0xf0,0xcb,0x02,0xa6,0xf0,0xcf,0x02,0x8c,0xf0,0xd3,0x02,0x72,0xf0,0xd6,0x02,0x57,0xf0,0xda,0x02,0x3d,0xf0,  \
    0xdd,0x02,0x22,0xf0,0xe0,0x02,0x07,0xf0,0xe3,0x02,0xec,0xef,0xe6,0x02,0xd0,0xef,0xe9,0x02,0xb5,0xef,0xec,0x02,0x99,0xef,0xef,0x02,0x7d,0xef,0xf2,0x02,0x62,0xef,0xf5,0x02,0x45,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x23,0x03,0xaa,0x10,0x20,0x03,0x8e,0x10,0x1e,0x03,0x72,0x10,0x1b,0x03,0x56,0x10,0x18,0x03,0x3a,0x10,0x15,0x03,0x1f,0x10,0x11,0x03,0x03,0x10,0x0e,0x03,0xe8,0x0f,0x0b,0x03,0xcc,0x0f,0x07,0x03,0xb1,0x0f,0x04,0x03,0x96,0x0f,0x00,0x03,0x7b,0x0f,0xfd,0x02,0x61,0x0f,0xf9,0x02,0x46,0x0f,0xf5,0x02,0x2b,0x0f,0xf2,0x02,0x11,0x0f,0xee,0x02,0xf7,0x0e,0xea,0x02,0xdd,0x0e,0xe6,0x02,0xc3,0x0e,0xe1,0x02,0xa9,0x0e,0xdd,0x02,0x8f,0x0e,  \
    0xd9,0x02,0x76,0x0e,0xd4,0x02,0x5d,0x0e,0xd0,0x02,0x44,0x0e,0xcb,0x02,0x2a,0x0e,0xc7,0x02,0x12,0x0e,0xc2,0x02,0xf9,0x0d,0xbd,0x02,0xe0,0x0d,0xb9,0x02,0xc8,0x0d,0xb4,0x02,0xaf,0x0d,0xaf,0x02,0x97,0x0d,0xaa,0x02,0x7f,0x0d,0xa5,0x02,0x67,0x0d,0xa0,0x02,0x4f,0x0d,0x9b,0x02,0x37,0x0d,0x96,0x02,0x1f,0x0d,0x91,0x02,0x08,0x0d,0x8c,0x02,0xf0,0x0c,0x87,0x02,0xd9,0x0c,0x81,0x02,0xc2,0x0c,0x7c,0x02,0xab,0x0c,0x76,0x02,0x94,0x0c,0x71,0x02,0x7e,0x0c,0x6b,0x02,  \
    0x67,0x0c,0x66,0x02,0x51,0x0c,0x60,0x02,0x3b,0x0c,0x5b,0x02,0x25,0x0c,0x55,0x02,0x0f,0x0c,0x4f,0x02,0xf9,0x0b,0x49,0x02,0xe3,0x0b,0x44,0x02,0xcd,0x0b,0x3e,0x02,0xb8,0x0b,0x38,0x02,0xa3,0x0b,0x32,0x02,0x8d,0x0b,0x2d,0x02,0x78,0x0b,0x27,0x02,0x63,0x0b,0x21,0x02,0x4e,0x0b,0x1b,0x02,0x39,0x0b,0x16,0x02,0x24,0x0b,0x10,0x02,0x0e,0x0b,0x0b,0x02,0xf9,0x0a,0x05,0x02,0xe4,0x0a,0x00,0x02,0xce,0x0a,0xfa,0x01,0xb9,0x0a,0xf5,0x01,0xa4,0x0a,0xef,0x01,0x90,0x0a,  \
    0xea,0x01,0x7b,0x0a,0xe4,0x01,0x66,0x0a,0xde,0x01,0x52,0x0a,0xd9,0x01,0x3d,0x0a,0xd3,0x01,0x29,0x0a,0xce,0x01,0x14,0x0a,0xc8,0x01,0x00,0x0a,0xc3,0x01,0xec,0x09,0xbd,0x01,0xd8,0x09,0xb8,0x01,0xc4,0x09,0xb2,0x01,0xb0,0x09,0xad,0x01,0x9c,0x09,0xa7,0x01,0x88,0x09,0xa2,0x01,0x74,0x09,0x9c,0x01,0x61,0x09,0x97,0x01,0x4d,0x09,0x91,0x01,0x3a,0x09,0x8c,0x01,0x26,0x09,0x86,0x01,0x13,0x09,0x81,0x01,0x00,0x09,0x7b,0x01,0xed,0x08,0x76,0x01,0xda,0x08,0x71,0x01,  \
    0xc7,0x08,0x6b,0x01,0xb4,0x08,0x66,0x01,0xa1,0x08,0x60,0x01,0x8e,0x08,0x5b,0x01,0x7c,0x08,0x56,0x01,0x69,0x08,0x50,0x01,0x57,0x08,0x4a,0x01,0x46,0x08,0x45,0x01,0x34,0x08,0x3f,0x01,0x23,0x08,0x3a,0x01,0x11,0x08,0x34,0x01,0x00,0x08,0x2e,0x01,0xee,0x07,0x29,0x01,0xdd,0x07,0x23,0x01,0xcc,0x07,0x1e,0x01,0xbb,0x07,0x19,0x01,0xaa,0x07,0x13,0x01,0x99,0x07,0x0e,0x01,0x88,0x07,0x08,0x01,0x77,0x07,0x03,0x01,0x67,0x07,0xfe,0x00,0x56,0x07,0xf9,0x00,0x45,0x07,  \
    0xf3,0x00,0x35,0x07,0xee,0x00,0x24,0x07,0xe9,0x00,0x14,0x07,0xe4,0x00,0x03,0x07,0xdf,0x00,0xf3,0x06,0xda,0x00,0xe2,0x06,0xd5,0x00,0xd2,0x06,0xd0,0x00,0xc2,0x06,0xcb,0x00,0xb1,0x06,0xc6,0x00,0xa1,0x06,0xc1,0x00,0x91,0x06,0xbc,0x00,0x81,0x06,0xb7,0x00,0x71,0x06,0xb3,0x00,0x61,0x06,0xae,0x00,0x51,0x06,0xa9,0x00,0x41,0x06,0xa4,0x00,0x31,0x06,0xa0,0x00,0x22,0x06,0x9b,0x00,0x12,0x06,0x97,0x00,0x02,0x06,0x92,0x00,0xf3,0x05,0x8d,0x00,0xe3,0x05,0x89,0x00,  \
    0xd3,0x05,0x85,0x00,0xc4,0x05,0x80,0x00,0xb4,0x05,0x7c,0x00,0xa5,0x05,0x78,0x00,0x95,0x05,0x73,0x00,0x85,0x05,0x6f,0x00,0x75,0x05,0x6b,0x00,0x66,0x05,0x67,0x00,0x56,0x05,0x63,0x00,0x46,0x05,0x5f,0x00,0x37,0x05,0x5b,0x00,0x27,0x05,0x57,0x00,0x17,0x05,0x53,0x00,0x08,0x05,0x4f,0x00,0xf8,0x04,0x4c,0x00,0xe9,0x04,0x48,0x00,0xda,0x04,0x44,0x00,0xca,0x04,0x40,0x00,0xbb,0x04,0x3d,0x00,0xac,0x04,0x39,0x00,0x9c,0x04,0x35,0x00,0x8d,0x04,0x32,0x00,0x7e,0x04,  \
    0x2e,0x00,0x6f,0x04,0x2b,0x00,0x60,0x04,0x27,0x00,0x51,0x04,0x24,0x00,0x42,0x04,0x21,0x00,0x33,0x04,0x1d,0x00,0x24,0x04,0x1a,0x00,0x16,0x04,0x16,0x00,0x07,0x04,0x13,0x00,0xf9,0x03,0x10,0x00,0xea,0x03,0x0d,0x00,0xdc,0x03,0x09,0x00,0xcd,0x03,0x06,0x00,0xbf,0x03,0x03,0x00,0xb1,0x03,0x00,0x00,0xa2,0x03,0xfd,0xff,0x94,0x03,0xfa,0xff,0x86,0x03,0xf7,0xff,0x78,0x03,0xf4,0xff,0x69,0x03,0xf1,0xff,0x5b,0x03,0xef,0xff,0x4d,0x03,0xec,0xff,0x3f,0x03,0xe9,0xff,  \
    0x31,0x03,0xe6,0xff,0x23,0x03,0xe4,0xff,0x14,0x03,0xe1,0xff,0x06,0x03,0xde,0xff,0xf8,0x02,0xdc,0xff,0xea,0x02,0xd9,0xff,0xdc,0x02,0xd7,0xff,0xce,0x02,0xd5,0xff,0xc0,0x02,0xd2,0xff,0xb3,0x02,0xd0,0xff,0xa5,0x02,0xce,0xff,0x98,0x02,0xcb,0xff,0x8a,0x02,0xc9,0xff,0x7c,0x02,0xc7,0xff,0x6f,0x02,0xc5,0xff,0x61,0x02,0xc3,0xff,0x54,0x02,0xc1,0xff,0x46,0x02,0xbf,0xff,0x38,0x02,0xbd,0xff,0x2b,0x02,0xbb,0xff,0x1d,0x02,0xb9,0xff,0x10,0x02,0xb7,0xff,0x02,0x02,  \
    0xb5,0xff,0xf5,0x01,0xb3,0xff,0xe7,0x01,0xb2,0xff,0xda,0x01,0xb0,0xff,0xcc,0x01,0xaf,0xff,0xbf,0x01,0xad,0xff,0xb1,0x01,0xab,0xff,0xa3,0x01,0xaa,0xff,0x96,0x01,0xa9,0xff,0x88,0x01,0xa7,0xff,0x7b,0x01,0xa6,0xff,0x6d,0x01,0xa4,0xff,0x60,0x01,0xa3,0xff,0x52,0x01,0xa2,0xff,0x45,0x01,0xa1,0xff,0x37,0x01,0xa0,0xff,0x29,0x01,0x9f,0xff,0x1b,0x01,0x9e,0xff,0x0e,0x01,0x9d,0xff,0x00,0x01,0x9c,0xff,0xf2,0x00,0x9b,0xff,0xe5,0x00,0x9a,0xff,0xd7,0x00,0x99,0xff,  \
    0xc9,0x00,0x98,0xff,0xbc,0x00,0x98,0xff,0xae,0x00,0x97,0xff,0xa0,0x00,0x96,0xff,0x93,0x00,0x96,0xff,0x85,0x00,0x95,0xff,0x77,0x00,0x94,0xff,0x6a,0x00,0x94,0xff,0x5c,0x00,0x93,0xff,0x4e,0x00,0x93,0xff,0x41,0x00,0x93,0xff,0x33,0x00,0x92,0xff,0x26,0x00,0x92,0xff,0x18,0x00,0x92,0xff,0x0a,0x00,0x92,0xff,0xfd,0xff,0x91,0xff,0xef,0xff,0x91,0xff,0xe2,0xff,0x91,0xff,0xd4,0xff,0x91,0xff,0xc6,0xff,0x91,0xff,0xb9,0xff,0x91,0xff,0xab,0xff,0x91,0xff,0x9d,0xff,  \
    0x91,0xff,0x90,0xff,0x92,0xff,0x82,0xff,0x92,0xff,0x75,0xff,0x92,0xff,0x67,0xff,0x92,0xff,0x59,0xff,0x93,0xff,0x4c,0xff,0x93,0xff,0x3e,0xff,0x94,0xff,0x31,0xff,0x94,0xff,0x23,0xff,0x94,0xff,0x15,0xff,0x95,0xff,0x08,0xff,0x96,0xff,0xfa,0xfe,0x96,0xff,0xed,0xfe,0x97,0xff,0xdf,0xfe,0x98,0xff,0xd1,0xfe,0x98,0xff,0xc4,0xfe,0x99,0xff,0xb6,0xfe,0x9a,0xff,0xa8,0xfe,0x9b,0xff,0x9b,0xfe,0x9c,0xff,0x8d,0xfe,0x9d,0xff,0x7f,0xfe,0x9e,0xff,0x72,0xfe,0x9f,0xff,  \
    0x64,0xfe,0xa0,0xff,0x56,0xfe,0xa1,0xff,0x49,0xfe,0xa2,0xff,0x3b,0xfe,0xa3,0xff,0x2d,0xfe,0xa4,0xff,0x1f,0xfe,0xa6,0xff,0x12,0xfe,0xa7,0xff,0x04,0xfe,0xa8,0xff,0xf6,0xfd,0xaa,0xff,0xe8,0xfd,0xab,0xff,0xda,0xfd,0xad,0xff,0xcc,0xfd,0xae,0xff,0xbe,0xfd,0xb0,0xff,0xb0,0xfd,0xb1,0xff,0xa2,0xfd,0xb3,0xff,0x94,0xfd,0xb4,0xff,0x86,0xfd,0xb6,0xff,0x78,0xfd,0xb8,0xff,0x6a,0xfd,0xba,0xff,0x5c,0xfd,0xbb,0xff,0x4e,0xfd,0xbd,0xff,0x40,0xfd,0xbf,0xff,0x32,0xfd,  \
    0xc1,0xff,0x24,0xfd,0xc3,0xff,0x16,0xfd,0xc5,0xff,0x08,0xfd,0xc7,0xff,0xfa,0xfc,0xc9,0xff,0xeb,0xfc,0xcb,0xff,0xdd,0xfc,0xce,0xff,0xcf,0xfc,0xd0,0xff,0xc1,0xfc,0xd2,0xff,0xb3,0xfc,0xd4,0xff,0xa5,0xfc,0xd7,0xff,0x97,0xfc,0xd9,0xff,0x89,0xfc,0xdc,0xff,0x7b,0xfc,0xde,0xff,0x6d,0xfc,0xe1,0xff,0x5f,0xfc,0xe3,0xff,0x51,0xfc,0xe6,0xff,0x43,0xfc,0xe8,0xff,0x34,0xfc,0xeb,0xff,0x26,0xfc,0xee,0xff,0x18,0xfc,0xf1,0xff,0x0a,0xfc,0xf3,0xff,0xfc,0xfb,0xf6,0xff,  \
    0xee,0xfb,0xf9,0xff,0xdf,0xfb,0xfc,0xff,0xd1,0xfb,0xff,0xff,0xc3,0xfb,0x02,0x00,0xb5,0xfb,0x05,0x00,0xa6,0xfb,0x08,0x00,0x98,0xfb,0x0b,0x00,0x89,0xfb,0x0f,0x00,0x7b,0xfb,0x12,0x00,0x6d,0xfb,0x15,0x00,0x5e,0xfb,0x18,0x00,0x50,0xfb,0x1c,0x00,0x41,0xfb,0x1f,0x00,0x32,0xfb,0x22,0x00,0x23,0xfb,0x26,0x00,0x14,0xfb,0x29,0x00,0x06,0xfb,0x2d,0x00,0xf7,0xfa,0x30,0x00,0xe8,0xfa,0x34,0x00,0xd9,0xfa,0x37,0x00,0xca,0xfa,0x3b,0x00,0xbb,0xfa,0x3e,0x00,0xac,0xfa,  \
    0x42,0x00,0x9d,0xfa,0x46,0x00,0x8d,0xfa,0x4a,0x00,0x7e,0xfa,0x4d,0x00,0x6f,0xfa,0x51,0x00,0x60,0xfa,0x55,0x00,0x50,0xfa,0x59,0x00,0x41,0xfa,0x5d,0x00,0x32,0xfa,0x61,0x00,0x22,0xfa,0x65,0x00,0x13,0xfa,0x69,0x00,0x03,0xfa,0x6d,0x00,0xf4,0xf9,0x71,0x00,0xe4,0xf9,0x75,0x00,0xd5,0xf9,0x7a,0x00,0xc5,0xf9,0x7e,0x00,0xb6,0xf9,0x82,0x00,0xa6,0xf9,0x86,0x00,0x97,0xf9,0x8b,0x00,0x87,0xf9,0x8f,0x00,0x77,0xf9,0x94,0x00,0x67,0xf9,0x98,0x00,0x58,0xf9,0x9d,0x00,  \
    0x48,0xf9,0xa1,0x00,0x38,0xf9,0xa6,0x00,0x28,0xf9,0xaa,0x00,0x18,0xf9,0xaf,0x00,0x08,0xf9,0xb4,0x00,0xf8,0xf8,0xb8,0x00,0xe8,0xf8,0xbd,0x00,0xd8,0xf8,0xc2,0x00,0xc7,0xf8,0xc6,0x00,0xb7,0xf8,0xcb,0x00,0xa7,0xf8,0xd0,0x00,0x96,0xf8,0xd5,0x00,0x86,0xf8,0xda,0x00,0x75,0xf8,0xdf,0x00,0x65,0xf8,0xe4,0x00,0x54,0xf8,0xe9,0x00,0x43,0xf8,0xed,0x00,0x32,0xf8,0xf2,0x00,0x21,0xf8,0xf7,0x00,0x10,0xf8,0xfc,0x00,0xff,0xf7,0x01,0x01,0xed,0xf7,0x07,0x01,0xdc,0xf7,  \
    0x0c,0x01,0xcb,0xf7,0x11,0x01,0xb9,0xf7,0x16,0x01,0xa8,0xf7,0x1b,0x01,0x96,0xf7,0x20,0x01,0x85,0xf7,0x25,0x01,0x73,0xf7,0x2b,0x01,0x61,0xf7,0x30,0x01,0x50,0xf7,0x35,0x01,0x3e,0xf7,0x3a,0x01,0x2c,0xf7,0x40,0x01,0x1a,0xf7,0x45,0x01,0x08,0xf7,0x4a,0x01,0xf6,0xf6,0x50,0x01,0xe3,0xf6,0x55,0x01,0xd1,0xf6,0x5a,0x01,0xbf,0xf6,0x60,0x01,0xad,0xf6,0x65,0x01,0x9a,0xf6,0x6b,0x01,0x88,0xf6,0x70,0x01,0x75,0xf6,0x76,0x01,0x63,0xf6,0x7b,0x01,0x50,0xf6,0x81,0x01,  \
    0x3d,0xf6,0x86,0x01,0x2a,0xf6,0x8c,0x01,0x17,0xf6,0x91,0x01,0x04,0xf6,0x97,0x01,0xf1,0xf5,0x9c,0x01,0xde,0xf5,0xa2,0x01,0xcb,0xf5,0xa8,0x01,0xb7,0xf5,0xad,0x01,0xa4,0xf5,0xb3,0x01,0x90,0xf5,0xb8,0x01,0x7c,0xf5,0xbd,0x01,0x68,0xf5,0xc3,0x01,0x54,0xf5,0xc8,0x01,0x3f,0xf5,0xcd,0x01,0x2b,0xf5,0xd3,0x01,0x16,0xf5,0xd8,0x01,0x01,0xf5,0xdd,0x01,0xed,0xf4,0xe3,0x01,0xd8,0xf4,0xe8,0x01,0xc3,0xf4,0xed,0x01,0xae,0xf4,0xf3,0x01,0x98,0xf4,0xf8,0x01,0x83,0xf4,  \
    0xfd,0x01,0x6e,0xf4,0x02,0x02,0x58,0xf4,0x08,0x02,0x43,0xf4,0x0d,0x02,0x2d,0xf4,0x12,0x02,0x17,0xf4,0x17,0x02,0x02,0xf4,0x1d,0x02,0xec,0xf3,0x22,0x02,0xd6,0xf3,0x27,0x02,0xc1,0xf3,0x2d,0x02,0xab,0xf3,0x32,0x02,0x95,0xf3,0x37,0x02,0x7e,0xf3,0x3d,0x02,0x68,0xf3,0x42,0x02,0x52,0xf3,0x47,0x02,0x3b,0xf3,0x4c,0x02,0x25,0xf3,0x51,0x02,0x0e,0xf3,0x56,0x02,0xf7,0xf2,0x5b,0x02,0xe0,0xf2,0x60,0x02,0xc9,0xf2,0x65,0x02,0xb2,0xf2,0x6a,0x02,0x9b,0xf2,0x6f,0x02,  \
    0x83,0xf2,0x74,0x02,0x6c,0xf2,0x79,0x02,0x54,0xf2,0x7e,0x02,0x3c,0xf2,0x82,0x02,0x24,0xf2,0x87,0x02,0x0c,0xf2,0x8c,0x02,0xf4,0xf1,0x90,0x02,0xdc,0xf1,0x95,0x02,0xc3,0xf1,0x99,0x02,0xab,0xf1,0x9e,0x02,0x92,0xf1,0xa2,0x02,0x79,0xf1,0xa6,0x02,0x60,0xf1,0xab,0x02,0x47,0xf1,0xaf,0x02,0x2e,0xf1,0xb3,0x02,0x14,0xf1,0xb7,0x02,0xfb,0xf0,0xbb,0x02,0xe1,0xf0,0xbf,0x02,0xc7,0xf0,0xc2,0x02,0xad,0xf0,0xc6,0x02,0x93,0xf0,0xca,0x02,0x79,0xf0,0xcd,0x02,0x5e,0xf0,  \
    0xd1,0x02,0x44,0xf0,0xd4,0x02,0x29,0xf0,0xd7,0x02,0x0e,0xf0,0xda,0x02,0xf3,0xef,0xdd,0x02,0xd7,0xef,0xe0,0x02,0xbc,0xef,0xe3,0x02,0xa0,0xef,0xe6,0x02,0x84,0xef,0xe9,0x02,0x68,0xef,0xeb,0x02,0x4c,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1b,0x03,0xa4,0x10,0x18,0x03,0x88,0x10,0x15,0x03,0x6c,0x10,0x12,0x03,0x50,0x10,0x0f,0x03,0x34,0x10,0x0c,0x03,0x18,0x10,0x09,0x03,0xfd,0x0f,0x06,0x03,0xe1,0x0f,0x03,0x03,0xc6,0x0f,0xff,0x02,0xab,0x0f,0xfc,0x02,0x90,0x0f,0xf8,0x02,0x75,0x0f,0xf5,0x02,0x5a,0x0f,0xf1,0x02,0x3f,0x0f,0xed,0x02,0x25,0x0f,0xea,0x02,0x0b,0x0f,0xe6,0x02,0xf0,0x0e,0xe2,0x02,0xd6,0x0e,0xde,0x02,0xbc,0x0e,0xda,0x02,0xa2,0x0e,  \
    0xd5,0x02,0x89,0x0e,0xd1,0x02,0x6f,0x0e,0xcd,0x02,0x56,0x0e,0xc8,0x02,0x3d,0x0e,0xc4,0x02,0x24,0x0e,0xbf,0x02,0x0b,0x0e,0xbb,0x02,0xf2,0x0d,0xb6,0x02,0xd9,0x0d,0xb1,0x02,0xc1,0x0d,0xad,0x02,0xa8,0x0d,0xa8,0x02,0x90,0x0d,0xa3,0x02,0x78,0x0d,0x9e,0x02,0x60,0x0d,0x99,0x02,0x48,0x0d,0x94,0x02,0x30,0x0d,0x8f,0x02,0x18,0x0d,0x8a,0x02,0x01,0x0d,0x85,0x02,0xe9,0x0c,0x80,0x02,0xd2,0x0c,0x7a,0x02,0xbb,0x0c,0x75,0x02,0xa4,0x0c,0x70,0x02,0x8d,0x0c,0x6a,0x02,  \
    0x76,0x0c,0x65,0x02,0x60,0x0c,0x5f,0x02,0x4a,0x0c,0x5a,0x02,0x33,0x0c,0x54,0x02,0x1d,0x0c,0x4e,0x02,0x07,0x0c,0x49,0x02,0xf1,0x0b,0x43,0x02,0xdc,0x0b,0x3d,0x02,0xc6,0x0b,0x38,0x02,0xb0,0x0b,0x32,0x02,0x9b,0x0b,0x2c,0x02,0x86,0x0b,0x27,0x02,0x70,0x0b,0x21,0x02,0x5b,0x0b,0x1b,0x02,0x46,0x0b,0x15,0x02,0x31,0x0b,0x10,0x02,0x1c,0x0b,0x0a,0x02,0x06,0x0b,0x05,0x02,0xf1,0x0a,0xff,0x01,0xdc,0x0a,0xfa,0x01,0xc7,0x0a,0xf4,0x01,0xb2,0x0a,0xef,0x01,0x9d,0x0a,  \
    0xe9,0x01,0x88,0x0a,0xe4,0x01,0x73,0x0a,0xdf,0x01,0x5e,0x0a,0xd9,0x01,0x4a,0x0a,0xd4,0x01,0x35,0x0a,0xce,0x01,0x21,0x0a,0xc9,0x01,0x0c,0x0a,0xc3,0x01,0xf8,0x09,0xbe,0x01,0xe4,0x09,0xb8,0x01,0xd0,0x09,0xb3,0x01,0xbc,0x09,0xad,0x01,0xa8,0x09,0xa8,0x01,0x94,0x09,0xa2,0x01,0x80,0x09,0x9d,0x01,0x6d,0x09,0x97,0x01,0x59,0x09,0x92,0x01,0x46,0x09,0x8c,0x01,0x32,0x09,0x87,0x01,0x1f,0x09,0x81,0x01,0x0c,0x09,0x7c,0x01,0xf8,0x08,0x77,0x01,0xe5,0x08,0x71,0x01,  \
    0xd2,0x08,0x6c,0x01,0xbf,0x08,0x66,0x01,0xac,0x08,0x61,0x01,0x99,0x08,0x5c,0x01,0x87,0x08,0x56,0x01,0x74,0x08,0x51,0x01,0x62,0x08,0x4b,0x01,0x50,0x08,0x46,0x01,0x3e,0x08,0x40,0x01,0x2d,0x08,0x3b,0x01,0x1b,0x08,0x35,0x01,0x0a,0x08,0x30,0x01,0xf8,0x07,0x2a,0x01,0xe7,0x07,0x25,0x01,0xd6,0x07,0x1f,0x01,0xc4,0x07,0x1a,0x01,0xb3,0x07,0x14,0x01,0xa2,0x07,0x0f,0x01,0x91,0x07,0x0a,0x01,0x81,0x07,0x04,0x01,0x70,0x07,0xff,0x00,0x5f,0x07,0xfa,0x00,0x4e,0x07,  \
    0xf5,0x00,0x3e,0x07,0xf0,0x00,0x2d,0x07,0xea,0x00,0x1d,0x07,0xe5,0x00,0x0c,0x07,0xe0,0x00,0xfc,0x06,0xdb,0x00,0xeb,0x06,0xd6,0x00,0xdb,0x06,0xd1,0x00,0xca,0x06,0xcc,0x00,0xba,0x06,0xc7,0x00,0xaa,0x06,0xc2,0x00,0x9a,0x06,0xbd,0x00,0x8a,0x06,0xb9,0x00,0x7a,0x06,0xb4,0x00,0x6a,0x06,0xaf,0x00,0x5a,0x06,0xaa,0x00,0x4a,0x06,0xa6,0x00,0x3a,0x06,0xa1,0x00,0x2a,0x06,0x9c,0x00,0x1a,0x06,0x98,0x00,0x0a,0x06,0x93,0x00,0xfb,0x05,0x8f,0x00,0xeb,0x05,0x8a,0x00,  \
    0xdc,0x05,0x86,0x00,0xcc,0x05,0x81,0x00,0xbd,0x05,0x7d,0x00,0xad,0x05,0x79,0x00,0x9e,0x05,0x75,0x00,0x8e,0x05,0x70,0x00,0x7e,0x05,0x6c,0x00,0x6e,0x05,0x68,0x00,0x5f,0x05,0x64,0x00,0x4f,0x05,0x60,0x00,0x3f,0x05,0x5c,0x00,0x30,0x05,0x58,0x00,0x20,0x05,0x54,0x00,0x11,0x05,0x50,0x00,0x01,0x05,0x4d,0x00,0xf2,0x04,0x49,0x00,0xe2,0x04,0x45,0x00,0xd3,0x04,0x41,0x00,0xc4,0x04,0x3e,0x00,0xb4,0x04,0x3a,0x00,0xa5,0x04,0x36,0x00,0x96,0x04,0x33,0x00,0x87,0x04,  \
    0x2f,0x00,0x78,0x04,0x2c,0x00,0x69,0x04,0x28,0x00,0x5a,0x04,0x25,0x00,0x4b,0x04,0x21,0x00,0x3c,0x04,0x1e,0x00,0x2d,0x04,0x1a,0x00,0x1e,0x04,0x17,0x00,0x10,0x04,0x14,0x00,0x01,0x04,0x10,0x00,0xf3,0x03,0x0d,0x00,0xe5,0x03,0x0a,0x00,0xd6,0x03,0x07,0x00,0xc8,0x03,0x04,0x00,0xba,0x03,0x01,0x00,0xab,0x03,0xfe,0xff,0x9d,0x03,0xfb,0xff,0x8f,0x03,0xf8,0xff,0x81,0x03,0xf5,0xff,0x72,0x03,0xf2,0xff,0x64,0x03,0xef,0xff,0x56,0x03,0xec,0xff,0x48,0x03,0xe9,0xff,  \
    0x3a,0x03,0xe7,0xff,0x2c,0x03,0xe4,0xff,0x1e,0x03,0xe1,0xff,0x10,0x03,0xdf,0xff,0x02,0x03,0xdc,0xff,0xf4,0x02,0xda,0xff,0xe6,0x02,0xd7,0xff,0xd8,0x02,0xd5,0xff,0xca,0x02,0xd2,0xff,0xbc,0x02,0xd0,0xff,0xaf,0x02,0xce,0xff,0xa1,0x02,0xcb,0xff,0x93,0x02,0xc9,0xff,0x86,0x02,0xc7,0xff,0x78,0x02,0xc5,0xff,0x6b,0x02,0xc2,0xff,0x5d,0x02,0xc0,0xff,0x50,0x02,0xbe,0xff,0x42,0x02,0xbc,0xff,0x35,0x02,0xba,0xff,0x27,0x02,0xb8,0xff,0x1a,0x02,0xb7,0xff,0x0c,0x02,  \
    0xb5,0xff,0xff,0x01,0xb3,0xff,0xf1,0x01,0xb1,0xff,0xe4,0x01,0xb0,0xff,0xd6,0x01,0xae,0xff,0xc9,0x01,0xac,0xff,0xbb,0x01,0xab,0xff,0xae,0x01,0xa9,0xff,0xa1,0x01,0xa8,0xff,0x93,0x01,0xa6,0xff,0x86,0x01,0xa5,0xff,0x78,0x01,0xa4,0xff,0x6b,0x01,0xa2,0xff,0x5d,0x01,0xa1,0xff,0x50,0x01,0xa0,0xff,0x42,0x01,0x9f,0xff,0x34,0x01,0x9e,0xff,0x27,0x01,0x9d,0xff,0x19,0x01,0x9b,0xff,0x0c,0x01,0x9a,0xff,0xfe,0x00,0x9a,0xff,0xf0,0x00,0x99,0xff,0xe3,0x00,0x98,0xff,  \
    0xd5,0x00,0x97,0xff,0xc8,0x00,0x96,0xff,0xba,0x00,0x95,0xff,0xac,0x00,0x95,0xff,0x9f,0x00,0x94,0xff,0x91,0x00,0x93,0xff,0x84,0x00,0x93,0xff,0x76,0x00,0x92,0xff,0x69,0x00,0x92,0xff,0x5b,0x00,0x91,0xff,0x4e,0x00,0x91,0xff,0x40,0x00,0x91,0xff,0x32,0x00,0x90,0xff,0x25,0x00,0x90,0xff,0x17,0x00,0x90,0xff,0x0a,0x00,0x90,0xff,0xfc,0xff,0x8f,0xff,0xef,0xff,0x8f,0xff,0xe1,0xff,0x8f,0xff,0xd4,0xff,0x8f,0xff,0xc6,0xff,0x8f,0xff,0xb9,0xff,0x8f,0xff,0xab,0xff,  \
    0x8f,0xff,0x9e,0xff,0x8f,0xff,0x90,0xff,0x90,0xff,0x83,0xff,0x90,0xff,0x75,0xff,0x90,0xff,0x68,0xff,0x90,0xff,0x5a,0xff,0x91,0xff,0x4d,0xff,0x91,0xff,0x3f,0xff,0x91,0xff,0x32,0xff,0x92,0xff,0x24,0xff,0x92,0xff,0x17,0xff,0x93,0xff,0x09,0xff,0x93,0xff,0xfc,0xfe,0x94,0xff,0xee,0xfe,0x95,0xff,0xe0,0xfe,0x95,0xff,0xd3,0xfe,0x96,0xff,0xc5,0xfe,0x97,0xff,0xb8,0xfe,0x98,0xff,0xaa,0xfe,0x99,0xff,0x9d,0xfe,0x9a,0xff,0x8f,0xfe,0x9a,0xff,0x82,0xfe,0x9b,0xff,  \
    0x74,0xfe,0x9d,0xff,0x66,0xfe,0x9e,0xff,0x59,0xfe,0x9f,0xff,0x4b,0xfe,0xa0,0xff,0x3d,0xfe,0xa1,0xff,0x30,0xfe,0xa2,0xff,0x22,0xfe,0xa3,0xff,0x14,0xfe,0xa5,0xff,0x07,0xfe,0xa6,0xff,0xf9,0xfd,0xa7,0xff,0xeb,0xfd,0xa9,0xff,0xdd,0xfd,0xaa,0xff,0xcf,0xfd,0xac,0xff,0xc2,0xfd,0xad,0xff,0xb4,0xfd,0xaf,0xff,0xa6,0xfd,0xb1,0xff,0x98,0xfd,0xb2,0xff,0x8a,0xfd,0xb4,0xff,0x7c,0xfd,0xb6,0xff,0x6e,0xfd,0xb7,0xff,0x60,0xfd,0xb9,0xff,0x52,0xfd,0xbb,0xff,0x44,0xfd,  \
    0xbd,0xff,0x36,0xfd,0xbf,0xff,0x28,0xfd,0xc1,0xff,0x1a,0xfd,0xc3,0xff,0x0c,0xfd,0xc5,0xff,0xfe,0xfc,0xc7,0xff,0xf0,0xfc,0xc9,0xff,0xe2,0xfc,0xcb,0xff,0xd4,0xfc,0xcd,0xff,0xc6,0xfc,0xd0,0xff,0xb8,0xfc,0xd2,0xff,0xaa,0xfc,0xd4,0xff,0x9c,0xfc,0xd7,0xff,0x8e,0xfc,0xd9,0xff,0x80,0xfc,0xdc,0xff,0x72,0xfc,0xde,0xff,0x64,0xfc,0xe1,0xff,0x56,0xfc,0xe3,0xff,0x48,0xfc,0xe6,0xff,0x3a,0xfc,0xe9,0xff,0x2c,0xfc,0xeb,0xff,0x1e,0xfc,0xee,0xff,0x10,0xfc,0xf1,0xff,  \
    0x01,0xfc,0xf4,0xff,0xf3,0xfb,0xf7,0xff,0xe5,0xfb,0xfa,0xff,0xd7,0xfb,0xfd,0xff,0xc9,0xfb,0xff,0xff,0xba,0xfb,0x03,0x00,0xac,0xfb,0x06,0x00,0x9e,0xfb,0x09,0x00,0x90,0xfb,0x0c,0x00,0x81,0xfb,0x0f,0x00,0x73,0xfb,0x12,0x00,0x65,0xfb,0x16,0x00,0x56,0xfb,0x19,0x00,0x47,0xfb,0x1c,0x00,0x39,0xfb,0x1f,0x00,0x2a,0xfb,0x23,0x00,0x1b,0xfb,0x26,0x00,0x0c,0xfb,0x2a,0x00,0xfd,0xfa,0x2d,0x00,0xee,0xfa,0x31,0x00,0xe0,0xfa,0x34,0x00,0xd1,0xfa,0x38,0x00,0xc2,0xfa,  \
    0x3c,0x00,0xb3,0xfa,0x3f,0x00,0xa4,0xfa,0x43,0x00,0x94,0xfa,0x47,0x00,0x85,0xfa,0x4a,0x00,0x76,0xfa,0x4e,0x00,0x67,0xfa,0x52,0x00,0x58,0xfa,0x56,0x00,0x48,0xfa,0x5a,0x00,0x39,0xfa,0x5e,0x00,0x2a,0xfa,0x62,0x00,0x1a,0xfa,0x66,0x00,0x0b,0xfa,0x6a,0x00,0xfb,0xf9,0x6e,0x00,0xec,0xf9,0x72,0x00,0xdc,0xf9,0x76,0x00,0xcd,0xf9,0x7b,0x00,0xbd,0xf9,0x7f,0x00,0xae,0xf9,0x83,0x00,0x9e,0xf9,0x87,0x00,0x8f,0xf9,0x8c,0x00,0x7f,0xf9,0x90,0x00,0x6f,0xf9,0x95,0x00,  \
    0x60,0xf9,0x99,0x00,0x50,0xf9,0x9e,0x00,0x40,0xf9,0xa2,0x00,0x30,0xf9,0xa7,0x00,0x20,0xf9,0xab,0x00,0x10,0xf9,0xb0,0x00,0x00,0xf9,0xb5,0x00,0xf0,0xf8,0xb9,0x00,0xe0,0xf8,0xbe,0x00,0xcf,0xf8,0xc3,0x00,0xbf,0xf8,0xc7,0x00,0xaf,0xf8,0xcc,0x00,0x9e,0xf8,0xd1,0x00,0x8e,0xf8,0xd6,0x00,0x7d,0xf8,0xdb,0x00,0x6d,0xf8,0xe0,0x00,0x5c,0xf8,0xe4,0x00,0x4b,0xf8,0xe9,0x00,0x3a,0xf8,0xee,0x00,0x29,0xf8,0xf3,0x00,0x18,0xf8,0xf8,0x00,0x07,0xf8,0xfd,0x00,0xf6,0xf7,  \
    0x02,0x01,0xe4,0xf7,0x07,0x01,0xd3,0xf7,0x0c,0x01,0xc2,0xf7,0x11,0x01,0xb0,0xf7,0x17,0x01,0x9f,0xf7,0x1c,0x01,0x8d,0xf7,0x21,0x01,0x7b,0xf7,0x26,0x01,0x6a,0xf7,0x2b,0x01,0x58,0xf7,0x30,0x01,0x46,0xf7,0x36,0x01,0x34,0xf7,0x3b,0x01,0x22,0xf7,0x40,0x01,0x10,0xf7,0x45,0x01,0xfe,0xf6,0x4b,0x01,0xec,0xf6,0x50,0x01,0xda,0xf6,0x55,0x01,0xc7,0xf6,0x5b,0x01,0xb5,0xf6,0x60,0x01,0xa3,0xf6,0x66,0x01,0x90,0xf6,0x6b,0x01,0x7e,0xf6,0x71,0x01,0x6b,0xf6,0x76,0x01,  \
    0x58,0xf6,0x7b,0x01,0x46,0xf6,0x81,0x01,0x33,0xf6,0x86,0x01,0x20,0xf6,0x8c,0x01,0x0d,0xf6,0x91,0x01,0xf9,0xf5,0x97,0x01,0xe6,0xf5,0x9c,0x01,0xd3,0xf5,0xa2,0x01,0xbf,0xf5,0xa7,0x01,0xac,0xf5,0xad,0x01,0x98,0xf5,0xb2,0x01,0x84,0xf5,0xb8,0x01,0x70,0xf5,0xbd,0x01,0x5c,0xf5,0xc2,0x01,0x47,0xf5,0xc7,0x01,0x33,0xf5,0xcd,0x01,0x1e,0xf5,0xd2,0x01,0x09,0xf5,0xd7,0x01,0xf5,0xf4,0xdd,0x01,0xe0,0xf4,0xe2,0x01,0xcb,0xf4,0xe7,0x01,0xb6,0xf4,0xec,0x01,0xa1,0xf4,  \
    0xf2,0x01,0x8b,0xf4,0xf7,0x01,0x76,0xf4,0xfc,0x01,0x60,0xf4,0x01,0x02,0x4b,0xf4,0x06,0x02,0x35,0xf4,0x0c,0x02,0x1f,0xf4,0x11,0x02,0x0a,0xf4,0x16,0x02,0xf4,0xf3,0x1b,0x02,0xde,0xf3,0x21,0x02,0xc8,0xf3,0x26,0x02,0xb3,0xf3,0x2b,0x02,0x9d,0xf3,0x30,0x02,0x86,0xf3,0x36,0x02,0x70,0xf3,0x3b,0x02,0x5a,0xf3,0x40,0x02,0x43,0xf3,0x45,0x02,0x2d,0xf3,0x4a,0x02,0x16,0xf3,0x4f,0x02,0xff,0xf2,0x54,0x02,0xe8,0xf2,0x59,0x02,0xd1,0xf2,0x5e,0x02,0xba,0xf2,0x63,0x02,  \
    0xa2,0xf2,0x68,0x02,0x8b,0xf2,0x6c,0x02,0x73,0xf2,0x71,0x02,0x5b,0xf2,0x76,0x02,0x44,0xf2,0x7a,0x02,0x2c,0xf2,0x7f,0x02,0x14,0xf2,0x84,0x02,0xfb,0xf1,0x88,0x02,0xe3,0xf1,0x8d,0x02,0xcb,0xf1,0x91,0x02,0xb2,0xf1,0x95,0x02,0x99,0xf1,0x9a,0x02,0x80,0xf1,0x9e,0x02,0x67,0xf1,0xa2,0x02,0x4e,0xf1,0xa6,0x02,0x35,0xf1,0xaa,0x02,0x1b,0xf1,0xae,0x02,0x02,0xf1,0xb2,0x02,0xe8,0xf0,0xb6,0x02,0xce,0xf0,0xba,0x02,0xb4,0xf0,0xbd,0x02,0x9a,0xf0,0xc1,0x02,0x80,0xf0,  \
    0xc5,0x02,0x65,0xf0,0xc8,0x02,0x4b,0xf0,0xcb,0x02,0x30,0xf0,0xce,0x02,0x15,0xf0,0xd1,0x02,0xf9,0xef,0xd4,0x02,0xde,0xef,0xd7,0x02,0xc3,0xef,0xda,0x02,0xa7,0xef,0xdd,0x02,0x8b,0xef,0xe0,0x02,0x6f,0xef,0xe2,0x02,0x53,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x12,0x03,0x9e,0x10,0x10,0x03,0x81,0x10,0x0d,0x03,0x65,0x10,0x0a,0x03,0x49,0x10,0x07,0x03,0x2e,0x10,0x04,0x03,0x12,0x10,0x01,0x03,0xf6,0x0f,0xfe,0x02,0xdb,0x0f,0xfb,0x02,0xc0,0x0f,0xf7,0x02,0xa4,0x0f,0xf4,0x02,0x89,0x0f,0xf0,0x02,0x6f,0x0f,0xed,0x02,0x54,0x0f,0xe9,0x02,0x39,0x0f,0xe5,0x02,0x1f,0x0f,0xe2,0x02,0x04,0x0f,0xde,0x02,0xea,0x0e,0xda,0x02,0xd0,0x0e,0xd6,0x02,0xb6,0x0e,  \
    0xd2,0x02,0x9c,0x0e,0xce,0x02,0x82,0x0e,0xc9,0x02,0x69,0x0e,0xc5,0x02,0x4f,0x0e,0xc1,0x02,0x36,0x0e,0xbc,0x02,0x1d,0x0e,0xb8,0x02,0x04,0x0e,0xb3,0x02,0xeb,0x0d,0xaf,0x02,0xd3,0x0d,0xaa,0x02,0xba,0x0d,0xa5,0x02,0xa2,0x0d,0xa0,0x02,0x89,0x0d,0x9c,0x02,0x71,0x0d,0x97,0x02,0x59,0x0d,0x92,0x02,0x41,0x0d,0x8d,0x02,0x29,0x0d,0x88,0x02,0x11,0x0d,0x83,0x02,0xfa,0x0c,0x7e,0x02,0xe2,0x0c,0x79,0x02,0xcb,0x0c,0x74,0x02,0xb4,0x0c,0x6e,0x02,0x9d,0x0c,0x69,0x02,  \
    0x86,0x0c,0x63,0x02,0x6f,0x0c,0x5e,0x02,0x59,0x0c,0x59,0x02,0x42,0x0c,0x53,0x02,0x2c,0x0c,0x4e,0x02,0x16,0x0c,0x48,0x02,0x00,0x0c,0x42,0x02,0xea,0x0b,0x3d,0x02,0xd4,0x0b,0x37,0x02,0xbf,0x0b,0x32,0x02,0xa9,0x0b,0x2c,0x02,0x94,0x0b,0x26,0x02,0x7e,0x0b,0x20,0x02,0x69,0x0b,0x1b,0x02,0x54,0x0b,0x15,0x02,0x3f,0x0b,0x0f,0x02,0x2a,0x0b,0x0a,0x02,0x14,0x0b,0x05,0x02,0xff,0x0a,0xff,0x01,0xe9,0x0a,0xfa,0x01,0xd4,0x0a,0xf4,0x01,0xbf,0x0a,0xef,0x01,0xaa,0x0a,  \
    0xe9,0x01,0x95,0x0a,0xe4,0x01,0x80,0x0a,0xdf,0x01,0x6b,0x0a,0xd9,0x01,0x57,0x0a,0xd4,0x01,0x42,0x0a,0xce,0x01,0x2e,0x0a,0xc9,0x01,0x19,0x0a,0xc3,0x01,0x05,0x0a,0xbe,0x01,0xf1,0x09,0xb8,0x01,0xdc,0x09,0xb3,0x01,0xc8,0x09,0xad,0x01,0xb4,0x09,0xa8,0x01,0xa0,0x09,0xa2,0x01,0x8d,0x09,0x9d,0x01,0x79,0x09,0x98,0x01,0x65,0x09,0x92,0x01,0x52,0x09,0x8d,0x01,0x3e,0x09,0x87,0x01,0x2b,0x09,0x82,0x01,0x17,0x09,0x7d,0x01,0x04,0x09,0x77,0x01,0xf1,0x08,0x72,0x01,  \
    0xde,0x08,0x6c,0x01,0xcb,0x08,0x67,0x01,0xb8,0x08,0x62,0x01,0xa5,0x08,0x5c,0x01,0x92,0x08,0x57,0x01,0x7f,0x08,0x52,0x01,0x6d,0x08,0x4c,0x01,0x5a,0x08,0x47,0x01,0x48,0x08,0x41,0x01,0x37,0x08,0x3c,0x01,0x25,0x08,0x36,0x01,0x14,0x08,0x31,0x01,0x02,0x08,0x2b,0x01,0xf1,0x07,0x26,0x01,0xdf,0x07,0x21,0x01,0xce,0x07,0x1b,0x01,0xbd,0x07,0x16,0x01,0xac,0x07,0x10,0x01,0x9b,0x07,0x0b,0x01,0x8a,0x07,0x06,0x01,0x79,0x07,0x01,0x01,0x68,0x07,0xfb,0x00,0x57,0x07,  \
    0xf6,0x00,0x47,0x07,0xf1,0x00,0x36,0x07,0xec,0x00,0x26,0x07,0xe7,0x00,0x15,0x07,0xe2,0x00,0x05,0x07,0xdd,0x00,0xf4,0x06,0xd7,0x00,0xe4,0x06,0xd3,0x00,0xd3,0x06,0xce,0x00,0xc3,0x06,0xc9,0x00,0xb3,0x06,0xc4,0x00,0xa2,0x06,0xbf,0x00,0x92,0x06,0xba,0x00,0x82,0x06,0xb5,0x00,0x72,0x06,0xb1,0x00,0x62,0x06,0xac,0x00,0x52,0x06,0xa7,0x00,0x42,0x06,0xa2,0x00,0x32,0x06,0x9e,0x00,0x23,0x06,0x99,0x00,0x13,0x06,0x95,0x00,0x03,0x06,0x90,0x00,0xf4,0x05,0x8c,0x00,  \
    0xe4,0x05,0x87,0x00,0xd4,0x05,0x83,0x00,0xc5,0x05,0x7e,0x00,0xb5,0x05,0x7a,0x00,0xa6,0x05,0x76,0x00,0x97,0x05,0x72,0x00,0x87,0x05,0x6d,0x00,0x77,0x05,0x69,0x00,0x67,0x05,0x65,0x00,0x58,0x05,0x61,0x00,0x48,0x05,0x5d,0x00,0x38,0x05,0x59,0x00,0x29,0x05,0x55,0x00,0x19,0x05,0x52,0x00,0x0a,0x05,0x4e,0x00,0xfb,0x04,0x4a,0x00,0xeb,0x04,0x46,0x00,0xdc,0x04,0x42,0x00,0xcd,0x04,0x3f,0x00,0xbd,0x04,0x3b,0x00,0xae,0x04,0x37,0x00,0x9f,0x04,0x34,0x00,0x90,0x04,  \
    0x30,0x00,0x81,0x04,0x2d,0x00,0x72,0x04,0x29,0x00,0x63,0x04,0x26,0x00,0x54,0x04,0x22,0x00,0x45,0x04,0x1f,0x00,0x36,0x04,0x1b,0x00,0x27,0x04,0x18,0x00,0x19,0x04,0x15,0x00,0x0a,0x04,0x11,0x00,0xfc,0x03,0x0e,0x00,0xed,0x03,0x0b,0x00,0xdf,0x03,0x08,0x00,0xd1,0x03,0x04,0x00,0xc2,0x03,0x01,0x00,0xb4,0x03,0xfe,0xff,0xa6,0x03,0xfb,0xff,0x98,0x03,0xf8,0xff,0x8a,0x03,0xf5,0xff,0x7b,0x03,0xf2,0xff,0x6d,0x03,0xef,0xff,0x5f,0x03,0xed,0xff,0x51,0x03,0xea,0xff,  \
    0x43,0x03,0xe7,0xff,0x35,0x03,0xe4,0xff,0x27,0x03,0xe2,0xff,0x19,0x03,0xdf,0xff,0x0b,0x03,0xdc,0xff,0xfd,0x02,0xda,0xff,0xef,0x02,0xd7,0xff,0xe1,0x02,0xd5,0xff,0xd3,0x02,0xd3,0xff,0xc6,0x02,0xd0,0xff,0xb8,0x02,0xce,0xff,0xaa,0x02,0xcb,0xff,0x9d,0x02,0xc9,0xff,0x8f,0x02,0xc7,0xff,0x82,0x02,0xc5,0xff,0x74,0x02,0xc3,0xff,0x67,0x02,0xc0,0xff,0x59,0x02,0xbe,0xff,0x4c,0x02,0xbc,0xff,0x3e,0x02,0xba,0xff,0x31,0x02,0xb8,0xff,0x24,0x02,0xb6,0xff,0x16,0x02,  \
    0xb5,0xff,0x09,0x02,0xb3,0xff,0xfb,0x01,0xb1,0xff,0xee,0x01,0xaf,0xff,0xe1,0x01,0xae,0xff,0xd3,0x01,0xac,0xff,0xc6,0x01,0xaa,0xff,0xb8,0x01,0xa9,0xff,0xab,0x01,0xa7,0xff,0x9e,0x01,0xa6,0xff,0x90,0x01,0xa4,0xff,0x83,0x01,0xa3,0xff,0x75,0x01,0xa2,0xff,0x68,0x01,0xa0,0xff,0x5b,0x01,0x9f,0xff,0x4d,0x01,0x9e,0xff,0x40,0x01,0x9d,0xff,0x32,0x01,0x9c,0xff,0x25,0x01,0x9b,0xff,0x17,0x01,0x9a,0xff,0x09,0x01,0x99,0xff,0xfc,0x00,0x98,0xff,0xee,0x00,0x97,0xff,  \
    0xe1,0x00,0x96,0xff,0xd3,0x00,0x95,0xff,0xc6,0x00,0x94,0xff,0xb8,0x00,0x94,0xff,0xab,0x00,0x93,0xff,0x9d,0x00,0x92,0xff,0x90,0x00,0x92,0xff,0x82,0x00,0x91,0xff,0x75,0x00,0x90,0xff,0x68,0x00,0x90,0xff,0x5a,0x00,0x8f,0xff,0x4d,0x00,0x8f,0xff,0x3f,0x00,0x8f,0xff,0x32,0x00,0x8e,0xff,0x24,0x00,0x8e,0xff,0x17,0x00,0x8e,0xff,0x09,0x00,0x8e,0xff,0xfc,0xff,0x8e,0xff,0xef,0xff,0x8d,0xff,0xe1,0xff,0x8d,0xff,0xd4,0xff,0x8d,0xff,0xc6,0xff,0x8d,0xff,0xb9,0xff,  \
    0x8d,0xff,0xab,0xff,0x8d,0xff,0x9e,0xff,0x8e,0xff,0x91,0xff,0x8e,0xff,0x83,0xff,0x8e,0xff,0x76,0xff,0x8e,0xff,0x68,0xff,0x8e,0xff,0x5b,0xff,0x8f,0xff,0x4d,0xff,0x8f,0xff,0x40,0xff,0x90,0xff,0x33,0xff,0x90,0xff,0x25,0xff,0x91,0xff,0x18,0xff,0x91,0xff,0x0a,0xff,0x92,0xff,0xfd,0xfe,0x92,0xff,0xef,0xfe,0x93,0xff,0xe2,0xfe,0x94,0xff,0xd4,0xfe,0x94,0xff,0xc7,0xfe,0x95,0xff,0xba,0xfe,0x96,0xff,0xac,0xfe,0x97,0xff,0x9f,0xfe,0x98,0xff,0x91,0xfe,0x99,0xff,  \
    0x84,0xfe,0x9a,0xff,0x76,0xfe,0x9b,0xff,0x69,0xfe,0x9c,0xff,0x5b,0xfe,0x9d,0xff,0x4e,0xfe,0x9e,0xff,0x40,0xfe,0x9f,0xff,0x32,0xfe,0xa0,0xff,0x25,0xfe,0xa2,0xff,0x17,0xfe,0xa3,0xff,0x09,0xfe,0xa4,0xff,0xfc,0xfd,0xa6,0xff,0xee,0xfd,0xa7,0xff,0xe0,0xfd,0xa8,0xff,0xd2,0xfd,0xaa,0xff,0xc5,0xfd,0xab,0xff,0xb7,0xfd,0xad,0xff,0xa9,0xfd,0xaf,0xff,0x9b,0xfd,0xb0,0xff,0x8e,0xfd,0xb2,0xff,0x80,0xfd,0xb4,0xff,0x72,0xfd,0xb5,0xff,0x64,0xfd,0xb7,0xff,0x56,0xfd,  \
    0xb9,0xff,0x48,0xfd,0xbb,0xff,0x3a,0xfd,0xbd,0xff,0x2c,0xfd,0xbf,0xff,0x1e,0xfd,0xc1,0xff,0x10,0xfd,0xc3,0xff,0x02,0xfd,0xc5,0xff,0xf4,0xfc,0xc7,0xff,0xe6,0xfc,0xc9,0xff,0xd8,0xfc,0xcb,0xff,0xca,0xfc,0xce,0xff,0xbd,0xfc,0xd0,0xff,0xaf,0xfc,0xd2,0xff,0xa1,0xfc,0xd5,0xff,0x93,0xfc,0xd7,0xff,0x85,0xfc,0xd9,0xff,0x77,0xfc,0xdc,0xff,0x69,0xfc,0xdf,0xff,0x5b,0xfc,0xe1,0xff,0x4d,0xfc,0xe4,0xff,0x3f,0xfc,0xe6,0xff,0x31,0xfc,0xe9,0xff,0x23,0xfc,0xec,0xff,  \
    0x15,0xfc,0xef,0xff,0x07,0xfc,0xf1,0xff,0xf9,0xfb,0xf4,0xff,0xeb,0xfb,0xf7,0xff,0xdd,0xfb,0xfa,0xff,0xcf,0xfb,0xfd,0xff,0xc0,0xfb,0x00,0x00,0xb2,0xfb,0x03,0x00,0xa4,0xfb,0x06,0x00,0x96,0xfb,0x09,0x00,0x87,0xfb,0x0d,0x00,0x79,0xfb,0x10,0x00,0x6b,0xfb,0x13,0x00,0x5c,0xfb,0x16,0x00,0x4e,0xfb,0x1a,0x00,0x3f,0xfb,0x1d,0x00,0x30,0xfb,0x20,0x00,0x22,0xfb,0x24,0x00,0x13,0xfb,0x27,0x00,0x04,0xfb,0x2b,0x00,0xf5,0xfa,0x2e,0x00,0xe6,0xfa,0x32,0x00,0xd7,0xfa,  \
    0x35,0x00,0xc8,0xfa,0x39,0x00,0xb9,0xfa,0x3c,0x00,0xaa,0xfa,0x40,0x00,0x9b,0xfa,0x44,0x00,0x8c,0xfa,0x48,0x00,0x7d,0xfa,0x4b,0x00,0x6e,0xfa,0x4f,0x00,0x5f,0xfa,0x53,0x00,0x50,0xfa,0x57,0x00,0x40,0xfa,0x5b,0x00,0x31,0xfa,0x5f,0x00,0x22,0xfa,0x63,0x00,0x12,0xfa,0x67,0x00,0x03,0xfa,0x6b,0x00,0xf3,0xf9,0x6f,0x00,0xe4,0xf9,0x73,0x00,0xd4,0xf9,0x77,0x00,0xc5,0xf9,0x7c,0x00,0xb6,0xf9,0x80,0x00,0xa6,0xf9,0x84,0x00,0x96,0xf9,0x89,0x00,0x87,0xf9,0x8d,0x00,  \
    0x77,0xf9,0x91,0x00,0x67,0xf9,0x96,0x00,0x57,0xf9,0x9a,0x00,0x48,0xf9,0x9f,0x00,0x38,0xf9,0xa3,0x00,0x28,0xf9,0xa8,0x00,0x18,0xf9,0xac,0x00,0x08,0xf9,0xb1,0x00,0xf8,0xf8,0xb6,0x00,0xe7,0xf8,0xba,0x00,0xd7,0xf8,0xbf,0x00,0xc7,0xf8,0xc4,0x00,0xb7,0xf8,0xc8,0x00,0xa6,0xf8,0xcd,0x00,0x96,0xf8,0xd2,0x00,0x85,0xf8,0xd7,0x00,0x75,0xf8,0xdc,0x00,0x64,0xf8,0xe1,0x00,0x53,0xf8,0xe5,0x00,0x42,0xf8,0xea,0x00,0x31,0xf8,0xef,0x00,0x20,0xf8,0xf4,0x00,0x0f,0xf8,  \
    0xf9,0x00,0xfe,0xf7,0xfe,0x00,0xed,0xf7,0x03,0x01,0xdb,0xf7,0x08,0x01,0xca,0xf7,0x0d,0x01,0xb8,0xf7,0x12,0x01,0xa7,0xf7,0x17,0x01,0x95,0xf7,0x1c,0x01,0x84,0xf7,0x21,0x01,0x72,0xf7,0x27,0x01,0x60,0xf7,0x2c,0x01,0x4e,0xf7,0x31,0x01,0x3c,0xf7,0x36,0x01,0x2a,0xf7,0x3b,0x01,0x18,0xf7,0x41,0x01,0x06,0xf7,0x46,0x01,0xf4,0xf6,0x4b,0x01,0xe2,0xf6,0x51,0x01,0xd0,0xf6,0x56,0x01,0xbd,0xf6,0x5b,0x01,0xab,0xf6,0x61,0x01,0x98,0xf6,0x66,0x01,0x86,0xf6,0x6b,0x01,  \
    0x73,0xf6,0x71,0x01,0x61,0xf6,0x76,0x01,0x4e,0xf6,0x7c,0x01,0x3b,0xf6,0x81,0x01,0x28,0xf6,0x86,0x01,0x15,0xf6,0x8c,0x01,0x02,0xf6,0x91,0x01,0xee,0xf5,0x97,0x01,0xdb,0xf5,0x9c,0x01,0xc8,0xf5,0xa2,0x01,0xb4,0xf5,0xa7,0x01,0xa0,0xf5,0xac,0x01,0x8c,0xf5,0xb2,0x01,0x78,0xf5,0xb7,0x01,0x64,0xf5,0xbc,0x01,0x4f,0xf5,0xc1,0x01,0x3b,0xf5,0xc7,0x01,0x26,0xf5,0xcc,0x01,0x11,0xf5,0xd1,0x01,0xfd,0xf4,0xd6,0x01,0xe8,0xf4,0xdc,0x01,0xd3,0xf4,0xe1,0x01,0xbe,0xf4,  \
    0xe6,0x01,0xa8,0xf4,0xeb,0x01,0x93,0xf4,0xf0,0x01,0x7e,0xf4,0xf6,0x01,0x68,0xf4,0xfb,0x01,0x53,0xf4,0x00,0x02,0x3d,0xf4,0x05,0x02,0x27,0xf4,0x0a,0x02,0x11,0xf4,0x0f,0x02,0xfc,0xf3,0x15,0x02,0xe6,0xf3,0x1a,0x02,0xd0,0xf3,0x1f,0x02,0xba,0xf3,0x24,0x02,0xa4,0xf3,0x29,0x02,0x8e,0xf3,0x2e,0x02,0x78,0xf3,0x34,0x02,0x61,0xf3,0x39,0x02,0x4b,0xf3,0x3e,0x02,0x34,0xf3,0x43,0x02,0x1d,0xf3,0x48,0x02,0x06,0xf3,0x4d,0x02,0xef,0xf2,0x51,0x02,0xd8,0xf2,0x56,0x02,  \
    0xc1,0xf2,0x5b,0x02,0xaa,0xf2,0x60,0x02,0x92,0xf2,0x65,0x02,0x7a,0xf2,0x69,0x02,0x63,0xf2,0x6e,0x02,0x4b,0xf2,0x73,0x02,0x33,0xf2,0x77,0x02,0x1b,0xf2,0x7c,0x02,0x03,0xf2,0x80,0x02,0xea,0xf1,0x85,0x02,0xd2,0xf1,0x89,0x02,0xb9,0xf1,0x8d,0x02,0xa0,0xf1,0x91,0x02,0x87,0xf1,0x96,0x02,0x6e,0xf1,0x9a,0x02,0x55,0xf1,0x9e,0x02,0x3c,0xf1,0xa2,0x02,0x22,0xf1,0xa6,0x02,0x09,0xf1,0xaa,0x02,0xef,0xf0,0xad,0x02,0xd5,0xf0,0xb1,0x02,0xbb,0xf0,0xb5,0x02,0xa1,0xf0,  \
    0xb8,0x02,0x87,0xf0,0xbc,0x02,0x6c,0xf0,0xbf,0x02,0x51,0xf0,0xc2,0x02,0x36,0xf0,0xc5,0x02,0x1b,0xf0,0xc8,0x02,0x00,0xf0,0xcb,0x02,0xe5,0xef,0xce,0x02,0xc9,0xef,0xd1,0x02,0xae,0xef,0xd4,0x02,0x92,0xef,0xd7,0x02,0x76,0xef,0xd9,0x02,0x5a,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0a,0x03,0x98,0x10,0x07,0x03,0x7b,0x10,0x04,0x03,0x5f,0x10,0x02,0x03,0x43,0x10,0xff,0x02,0x27,0x10,0xfc,0x02,0x0c,0x10,0xf9,0x02,0xf0,0x0f,0xf6,0x02,0xd5,0x0f,0xf2,0x02,0xb9,0x0f,0xef,0x02,0x9e,0x0f,0xec,0x02,0x83,0x0f,0xe8,0x02,0x68,0x0f,0xe5,0x02,0x4e,0x0f,0xe1,0x02,0x33,0x0f,0xdd,0x02,0x18,0x0f,0xda,0x02,0xfe,0x0e,0xd6,0x02,0xe4,0x0e,0xd2,0x02,0xca,0x0e,  \
    0xce,0x02,0xb0,0x0e,0xca,0x02,0x96,0x0e,0xc6,0x02,0x7c,0x0e,0xc2,0x02,0x62,0x0e,0xbd,0x02,0x49,0x0e,0xb9,0x02,0x30,0x0e,0xb5,0x02,0x17,0x0e,0xb0,0x02,0xfe,0x0d,0xac,0x02,0xe5,0x0d,0xa7,0x02,0xcc,0x0d,0xa2,0x02,0xb4,0x0d,0x9e,0x02,0x9b,0x0d,0x99,0x02,0x83,0x0d,0x94,0x02,0x6a,0x0d,0x8f,0x02,0x52,0x0d,0x8b,0x02,0x3a,0x0d,0x86,0x02,0x23,0x0d,0x81,0x02,0x0b,0x0d,0x7c,0x02,0xf3,0x0c,0x77,0x02,0xdc,0x0c,0x72,0x02,0xc4,0x0c,0x6d,0x02,0xad,0x0c,0x67,0x02,  \
    0x96,0x0c,0x62,0x02,0x7f,0x0c,0x5d,0x02,0x68,0x0c,0x57,0x02,0x52,0x0c,0x52,0x02,0x3b,0x0c,0x4d,0x02,0x25,0x0c,0x47,0x02,0x0f,0x0c,0x42,0x02,0xf9,0x0b,0x3c,0x02,0xe3,0x0b,0x37,0x02,0xcd,0x0b,0x31,0x02,0xb7,0x0b,0x2b,0x02,0xa2,0x0b,0x26,0x02,0x8c,0x0b,0x20,0x02,0x77,0x0b,0x1a,0x02,0x62,0x0b,0x15,0x02,0x4c,0x0b,0x0f,0x02,0x37,0x0b,0x09,0x02,0x22,0x0b,0x04,0x02,0x0d,0x0b,0xff,0x01,0xf7,0x0a,0xf9,0x01,0xe2,0x0a,0xf4,0x01,0xcd,0x0a,0xef,0x01,0xb8,0x0a,  \
    0xe9,0x01,0xa2,0x0a,0xe4,0x01,0x8e,0x0a,0xde,0x01,0x79,0x0a,0xd9,0x01,0x64,0x0a,0xd4,0x01,0x4f,0x0a,0xce,0x01,0x3b,0x0a,0xc9,0x01,0x26,0x0a,0xc3,0x01,0x12,0x0a,0xbe,0x01,0xfd,0x09,0xb9,0x01,0xe9,0x09,0xb3,0x01,0xd5,0x09,0xae,0x01,0xc1,0x09,0xa8,0x01,0xad,0x09,0xa3,0x01,0x99,0x09,0x9d,0x01,0x85,0x09,0x98,0x01,0x71,0x09,0x93,0x01,0x5e,0x09,0x8d,0x01,0x4a,0x09,0x88,0x01,0x37,0x09,0x83,0x01,0x23,0x09,0x7d,0x01,0x10,0x09,0x78,0x01,0xfd,0x08,0x72,0x01,  \
    0xe9,0x08,0x6d,0x01,0xd6,0x08,0x68,0x01,0xc3,0x08,0x62,0x01,0xb0,0x08,0x5d,0x01,0x9d,0x08,0x58,0x01,0x8b,0x08,0x53,0x01,0x78,0x08,0x4d,0x01,0x65,0x08,0x48,0x01,0x53,0x08,0x43,0x01,0x41,0x08,0x3d,0x01,0x2f,0x08,0x38,0x01,0x1e,0x08,0x32,0x01,0x0c,0x08,0x2d,0x01,0xfb,0x07,0x27,0x01,0xe9,0x07,0x22,0x01,0xd8,0x07,0x1d,0x01,0xc7,0x07,0x17,0x01,0xb6,0x07,0x12,0x01,0xa5,0x07,0x0d,0x01,0x93,0x07,0x07,0x01,0x83,0x07,0x02,0x01,0x72,0x07,0xfd,0x00,0x61,0x07,  \
    0xf8,0x00,0x50,0x07,0xf2,0x00,0x3f,0x07,0xed,0x00,0x2f,0x07,0xe8,0x00,0x1e,0x07,0xe3,0x00,0x0e,0x07,0xde,0x00,0xfd,0x06,0xd9,0x00,0xed,0x06,0xd4,0x00,0xdc,0x06,0xcf,0x00,0xcc,0x06,0xca,0x00,0xbc,0x06,0xc5,0x00,0xab,0x06,0xc0,0x00,0x9b,0x06,0xbc,0x00,0x8b,0x06,0xb7,0x00,0x7b,0x06,0xb2,0x00,0x6b,0x06,0xad,0x00,0x5b,0x06,0xa9,0x00,0x4b,0x06,0xa4,0x00,0x3b,0x06,0x9f,0x00,0x2b,0x06,0x9b,0x00,0x1b,0x06,0x96,0x00,0x0c,0x06,0x92,0x00,0xfc,0x05,0x8d,0x00,  \
    0xec,0x05,0x89,0x00,0xdd,0x05,0x84,0x00,0xcd,0x05,0x80,0x00,0xbe,0x05,0x7c,0x00,0xae,0x05,0x77,0x00,0x9f,0x05,0x73,0x00,0x90,0x05,0x6f,0x00,0x80,0x05,0x6b,0x00,0x70,0x05,0x67,0x00,0x61,0x05,0x63,0x00,0x51,0x05,0x5f,0x00,0x41,0x05,0x5b,0x00,0x32,0x05,0x57,0x00,0x22,0x05,0x53,0x00,0x13,0x05,0x4f,0x00,0x03,0x05,0x4b,0x00,0xf4,0x04,0x47,0x00,0xe5,0x04,0x44,0x00,0xd5,0x04,0x40,0x00,0xc6,0x04,0x3c,0x00,0xb7,0x04,0x38,0x00,0xa8,0x04,0x35,0x00,0x99,0x04,  \
    0x31,0x00,0x8a,0x04,0x2e,0x00,0x7b,0x04,0x2a,0x00,0x6c,0x04,0x27,0x00,0x5d,0x04,0x23,0x00,0x4e,0x04,0x20,0x00,0x3f,0x04,0x1c,0x00,0x30,0x04,0x19,0x00,0x21,0x04,0x16,0x00,0x13,0x04,0x12,0x00,0x05,0x04,0x0f,0x00,0xf6,0x03,0x0c,0x00,0xe8,0x03,0x09,0x00,0xda,0x03,0x05,0x00,0xcb,0x03,0x02,0x00,0xbd,0x03,0xff,0xff,0xaf,0x03,0xfc,0xff,0xa1,0x03,0xf9,0xff,0x93,0x03,0xf6,0xff,0x84,0x03,0xf3,0xff,0x76,0x03,0xf0,0xff,0x68,0x03,0xed,0xff,0x5a,0x03,0xeb,0xff,  \
    0x4c,0x03,0xe8,0xff,0x3e,0x03,0xe5,0xff,0x30,0x03,0xe2,0xff,0x22,0x03,0xe0,0xff,0x14,0x03,0xdd,0xff,0x06,0x03,0xda,0xff,0xf9,0x02,0xd8,0xff,0xeb,0x02,0xd5,0xff,0xdd,0x02,0xd3,0xff,0xcf,0x02,0xd1,0xff,0xc1,0x02,0xce,0xff,0xb4,0x02,0xcc,0xff,0xa6,0x02,0xca,0xff,0x99,0x02,0xc7,0xff,0x8b,0x02,0xc5,0xff,0x7e,0x02,0xc3,0xff,0x70,0x02,0xc1,0xff,0x63,0x02,0xbf,0xff,0x56,0x02,0xbc,0xff,0x48,0x02,0xba,0xff,0x3b,0x02,0xb8,0xff,0x2d,0x02,0xb7,0xff,0x20,0x02,  \
    0xb5,0xff,0x13,0x02,0xb3,0xff,0x05,0x02,0xb1,0xff,0xf8,0x01,0xaf,0xff,0xeb,0x01,0xae,0xff,0xdd,0x01,0xac,0xff,0xd0,0x01,0xaa,0xff,0xc3,0x01,0xa9,0xff,0xb5,0x01,0xa7,0xff,0xa8,0x01,0xa6,0xff,0x9b,0x01,0xa4,0xff,0x8d,0x01,0xa3,0xff,0x80,0x01,0xa1,0xff,0x73,0x01,0xa0,0xff,0x65,0x01,0x9f,0xff,0x58,0x01,0x9d,0xff,0x4b,0x01,0x9c,0xff,0x3d,0x01,0x9b,0xff,0x30,0x01,0x9a,0xff,0x22,0x01,0x99,0xff,0x15,0x01,0x98,0xff,0x07,0x01,0x97,0xff,0xfa,0x00,0x96,0xff,  \
    0xed,0x00,0x95,0xff,0xdf,0x00,0x94,0xff,0xd2,0x00,0x93,0xff,0xc4,0x00,0x93,0xff,0xb7,0x00,0x92,0xff,0xa9,0x00,0x91,0xff,0x9c,0x00,0x91,0xff,0x8f,0x00,0x90,0xff,0x81,0x00,0x8f,0xff,0x74,0x00,0x8f,0xff,0x66,0x00,0x8e,0xff,0x59,0x00,0x8e,0xff,0x4c,0x00,0x8d,0xff,0x3e,0x00,0x8d,0xff,0x31,0x00,0x8d,0xff,0x24,0x00,0x8c,0xff,0x16,0x00,0x8c,0xff,0x09,0x00,0x8c,0xff,0xfc,0xff,0x8c,0xff,0xee,0xff,0x8c,0xff,0xe1,0xff,0x8c,0xff,0xd4,0xff,0x8c,0xff,0xc6,0xff,  \
    0x8c,0xff,0xb9,0xff,0x8c,0xff,0xac,0xff,0x8c,0xff,0x9e,0xff,0x8c,0xff,0x91,0xff,0x8c,0xff,0x84,0xff,0x8c,0xff,0x76,0xff,0x8d,0xff,0x69,0xff,0x8d,0xff,0x5b,0xff,0x8d,0xff,0x4e,0xff,0x8e,0xff,0x41,0xff,0x8e,0xff,0x33,0xff,0x8e,0xff,0x26,0xff,0x8f,0xff,0x19,0xff,0x8f,0xff,0x0b,0xff,0x90,0xff,0xfe,0xfe,0x91,0xff,0xf1,0xfe,0x91,0xff,0xe3,0xfe,0x92,0xff,0xd6,0xfe,0x93,0xff,0xc9,0xfe,0x93,0xff,0xbb,0xfe,0x94,0xff,0xae,0xfe,0x95,0xff,0xa0,0xfe,0x96,0xff,  \
    0x93,0xfe,0x97,0xff,0x86,0xfe,0x98,0xff,0x78,0xfe,0x99,0xff,0x6b,0xfe,0x9a,0xff,0x5d,0xfe,0x9b,0xff,0x50,0xfe,0x9c,0xff,0x42,0xfe,0x9d,0xff,0x35,0xfe,0x9f,0xff,0x27,0xfe,0xa0,0xff,0x1a,0xfe,0xa1,0xff,0x0c,0xfe,0xa2,0xff,0xfe,0xfd,0xa4,0xff,0xf1,0xfd,0xa5,0xff,0xe3,0xfd,0xa7,0xff,0xd6,0xfd,0xa8,0xff,0xc8,0xfd,0xaa,0xff,0xba,0xfd,0xab,0xff,0xad,0xfd,0xad,0xff,0x9f,0xfd,0xae,0xff,0x91,0xfd,0xb0,0xff,0x83,0xfd,0xb2,0xff,0x76,0xfd,0xb4,0xff,0x68,0xfd,  \
    0xb5,0xff,0x5a,0xfd,0xb7,0xff,0x4c,0xfd,0xb9,0xff,0x3e,0xfd,0xbb,0xff,0x30,0xfd,0xbd,0xff,0x23,0xfd,0xbf,0xff,0x15,0xfd,0xc1,0xff,0x07,0xfd,0xc3,0xff,0xf9,0xfc,0xc5,0xff,0xeb,0xfc,0xc7,0xff,0xdd,0xfc,0xc9,0xff,0xcf,0xfc,0xcc,0xff,0xc1,0xfc,0xce,0xff,0xb4,0xfc,0xd0,0xff,0xa6,0xfc,0xd3,0xff,0x98,0xfc,0xd5,0xff,0x8a,0xfc,0xd7,0xff,0x7c,0xfc,0xda,0xff,0x6e,0xfc,0xdc,0xff,0x60,0xfc,0xdf,0xff,0x52,0xfc,0xe2,0xff,0x45,0xfc,0xe4,0xff,0x37,0xfc,0xe7,0xff,  \
    0x29,0xfc,0xea,0xff,0x1b,0xfc,0xec,0xff,0x0d,0xfc,0xef,0xff,0xff,0xfb,0xf2,0xff,0xf1,0xfb,0xf5,0xff,0xe2,0xfb,0xf8,0xff,0xd4,0xfb,0xfb,0xff,0xc6,0xfb,0xfe,0xff,0xb8,0xfb,0x01,0x00,0xaa,0xfb,0x04,0x00,0x9c,0xfb,0x07,0x00,0x8d,0xfb,0x0a,0x00,0x7f,0xfb,0x0d,0x00,0x71,0xfb,0x11,0x00,0x62,0xfb,0x14,0x00,0x54,0xfb,0x17,0x00,0x45,0xfb,0x1a,0x00,0x37,0xfb,0x1e,0x00,0x28,0xfb,0x21,0x00,0x19,0xfb,0x25,0x00,0x0b,0xfb,0x28,0x00,0xfc,0xfa,0x2c,0x00,0xed,0xfa,  \
    0x2f,0x00,0xde,0xfa,0x33,0x00,0xcf,0xfa,0x36,0x00,0xc0,0xfa,0x3a,0x00,0xb1,0xfa,0x3d,0x00,0xa2,0xfa,0x41,0x00,0x93,0xfa,0x45,0x00,0x84,0xfa,0x49,0x00,0x75,0xfa,0x4c,0x00,0x66,0xfa,0x50,0x00,0x57,0xfa,0x54,0x00,0x47,0xfa,0x58,0x00,0x38,0xfa,0x5c,0x00,0x29,0xfa,0x60,0x00,0x1a,0xfa,0x64,0x00,0x0a,0xfa,0x68,0x00,0xfb,0xf9,0x6c,0x00,0xeb,0xf9,0x70,0x00,0xdc,0xf9,0x74,0x00,0xcc,0xf9,0x79,0x00,0xbd,0xf9,0x7d,0x00,0xad,0xf9,0x81,0x00,0x9e,0xf9,0x85,0x00,  \
    0x8e,0xf9,0x8a,0x00,0x7f,0xf9,0x8e,0x00,0x6f,0xf9,0x92,0x00,0x5f,0xf9,0x97,0x00,0x4f,0xf9,0x9b,0x00,0x3f,0xf9,0xa0,0x00,0x2f,0xf9,0xa4,0x00,0x20,0xf9,0xa9,0x00,0x0f,0xf9,0xad,0x00,0xff,0xf8,0xb2,0x00,0xef,0xf8,0xb7,0x00,0xdf,0xf8,0xbb,0x00,0xcf,0xf8,0xc0,0x00,0xbf,0xf8,0xc5,0x00,0xae,0xf8,0xca,0x00,0x9e,0xf8,0xce,0x00,0x8d,0xf8,0xd3,0x00,0x7d,0xf8,0xd8,0x00,0x6c,0xf8,0xdd,0x00,0x5b,0xf8,0xe1,0x00,0x4a,0xf8,0xe6,0x00,0x39,0xf8,0xeb,0x00,0x28,0xf8,  \
    0xf0,0x00,0x17,0xf8,0xf5,0x00,0x06,0xf8,0xfa,0x00,0xf5,0xf7,0xff,0x00,0xe3,0xf7,0x04,0x01,0xd2,0xf7,0x09,0x01,0xc0,0xf7,0x0e,0x01,0xaf,0xf7,0x13,0x01,0x9d,0xf7,0x18,0x01,0x8c,0xf7,0x1d,0x01,0x7a,0xf7,0x22,0x01,0x68,0xf7,0x27,0x01,0x56,0xf7,0x2c,0x01,0x44,0xf7,0x32,0x01,0x32,0xf7,0x37,0x01,0x20,0xf7,0x3c,0x01,0x0e,0xf7,0x41,0x01,0xfc,0xf6,0x46,0x01,0xea,0xf6,0x4c,0x01,0xd8,0xf6,0x51,0x01,0xc5,0xf6,0x56,0x01,0xb3,0xf6,0x5c,0x01,0xa1,0xf6,0x61,0x01,  \
    0x8e,0xf6,0x66,0x01,0x7b,0xf6,0x6c,0x01,0x69,0xf6,0x71,0x01,0x56,0xf6,0x76,0x01,0x43,0xf6,0x7c,0x01,0x30,0xf6,0x81,0x01,0x1d,0xf6,0x86,0x01,0x0a,0xf6,0x8c,0x01,0xf6,0xf5,0x91,0x01,0xe3,0xf5,0x97,0x01,0xcf,0xf5,0x9c,0x01,0xbc,0xf5,0xa1,0x01,0xa8,0xf5,0xa7,0x01,0x94,0xf5,0xac,0x01,0x80,0xf5,0xb1,0x01,0x6c,0xf5,0xb6,0x01,0x57,0xf5,0xbc,0x01,0x43,0xf5,0xc1,0x01,0x2e,0xf5,0xc6,0x01,0x19,0xf5,0xcb,0x01,0x05,0xf5,0xd0,0x01,0xf0,0xf4,0xd5,0x01,0xdb,0xf4,  \
    0xdb,0x01,0xc6,0xf4,0xe0,0x01,0xb0,0xf4,0xe5,0x01,0x9b,0xf4,0xea,0x01,0x86,0xf4,0xef,0x01,0x70,0xf4,0xf4,0x01,0x5b,0xf4,0xf9,0x01,0x45,0xf4,0xfe,0x01,0x2f,0xf4,0x03,0x02,0x19,0xf4,0x09,0x02,0x04,0xf4,0x0e,0x02,0xee,0xf3,0x13,0x02,0xd8,0xf3,0x18,0x02,0xc2,0xf3,0x1d,0x02,0xac,0xf3,0x22,0x02,0x96,0xf3,0x27,0x02,0x7f,0xf3,0x2c,0x02,0x69,0xf3,0x31,0x02,0x52,0xf3,0x36,0x02,0x3c,0xf3,0x3b,0x02,0x25,0xf3,0x40,0x02,0x0e,0xf3,0x45,0x02,0xf7,0xf2,0x4a,0x02,  \
    0xe0,0xf2,0x4f,0x02,0xc8,0xf2,0x53,0x02,0xb1,0xf2,0x58,0x02,0x99,0xf2,0x5d,0x02,0x82,0xf2,0x61,0x02,0x6a,0xf2,0x66,0x02,0x52,0xf2,0x6b,0x02,0x3a,0xf2,0x6f,0x02,0x22,0xf2,0x74,0x02,0x0a,0xf2,0x78,0x02,0xf1,0xf1,0x7c,0x02,0xd9,0xf1,0x81,0x02,0xc0,0xf1,0x85,0x02,0xa7,0xf1,0x89,0x02,0x8e,0xf1,0x8d,0x02,0x75,0xf1,0x91,0x02,0x5c,0xf1,0x95,0x02,0x43,0xf1,0x99,0x02,0x29,0xf1,0x9d,0x02,0x10,0xf1,0xa1,0x02,0xf6,0xf0,0xa5,0x02,0xdc,0xf0,0xa8,0x02,0xc2,0xf0,  \
    0xac,0x02,0xa8,0xf0,0xaf,0x02,0x8d,0xf0,0xb3,0x02,0x73,0xf0,0xb6,0x02,0x58,0xf0,0xb9,0x02,0x3d,0xf0,0xbc,0x02,0x22,0xf0,0xbf,0x02,0x07,0xf0,0xc2,0x02,0xeb,0xef,0xc5,0x02,0xd0,0xef,0xc8,0x02,0xb4,0xef,0xcb,0x02,0x98,0xef,0xcd,0x02,0x7c,0xef,0xd0,0x02,0x60,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xff,0x02,0x92,0x10,0xfc,0x02,0x76,0x10,0xfa,0x02,0x5a,0x10,0xf7,0x02,0x3e,0x10,0xf4,0x02,0x22,0x10,0xf1,0x02,0x06,0x10,0xee,0x02,0xeb,0x0f,0xeb,0x02,0xcf,0x0f,0xe8,0x02,0xb4,0x0f,0xe4,0x02,0x99,0x0f,0xe1,0x02,0x7e,0x0f,0xde,0x02,0x63,0x0f,0xda,0x02,0x48,0x0f,0xd7,0x02,0x2d,0x0f,0xd3,0x02,0x13,0x0f,0xcf,0x02,0xf8,0x0e,0xcc,0x02,0xde,0x0e,  \
    0xc8,0x02,0xc4,0x0e,0xc4,0x02,0xaa,0x0e,0xc0,0x02,0x90,0x0e,0xbc,0x02,0x76,0x0e,0xb8,0x02,0x5d,0x0e,0xb3,0x02,0x43,0x0e,0xaf,0x02,0x2a,0x0e,0xab,0x02,0x11,0x0e,0xa6,0x02,0xf8,0x0d,0xa2,0x02,0xdf,0x0d,0x9d,0x02,0xc6,0x0d,0x99,0x02,0xae,0x0d,0x94,0x02,0x95,0x0d,0x90,0x02,0x7d,0x0d,0x8b,0x02,0x65,0x0d,0x86,0x02,0x4c,0x0d,0x81,0x02,0x34,0x0d,0x7d,0x02,0x1c,0x0d,0x78,0x02,0x05,0x0d,0x73,0x02,0xed,0x0c,0x6e,0x02,0xd5,0x0c,0x69,0x02,0xbe,0x0c,0x64,0x02,  \
    0xa7,0x0c,0x5f,0x02,0x90,0x0c,0x59,0x02,0x79,0x0c,0x54,0x02,0x62,0x0c,0x4f,0x02,0x4c,0x0c,0x4a,0x02,0x35,0x0c,0x44,0x02,0x1f,0x0c,0x3f,0x02,0x08,0x0c,0x39,0x02,0xf2,0x0b,0x34,0x02,0xdc,0x0b,0x2f,0x02,0xc6,0x0b,0x29,0x02,0xb1,0x0b,0x24,0x02,0x9b,0x0b,0x1e,0x02,0x86,0x0b,0x18,0x02,0x70,0x0b,0x13,0x02,0x5b,0x0b,0x0d,0x02,0x46,0x0b,0x08,0x02,0x30,0x0b,0x02,0x02,0x1b,0x0b,0xfd,0x01,0x06,0x0b,0xf8,0x01,0xf0,0x0a,0xf2,0x01,0xdb,0x0a,0xed,0x01,0xc6,0x0a,  \
    0xe8,0x01,0xb1,0x0a,0xe2,0x01,0x9c,0x0a,0xdd,0x01,0x87,0x0a,0xd8,0x01,0x72,0x0a,0xd2,0x01,0x5d,0x0a,0xcd,0x01,0x48,0x0a,0xc8,0x01,0x34,0x0a,0xc2,0x01,0x1f,0x0a,0xbd,0x01,0x0b,0x0a,0xb7,0x01,0xf6,0x09,0xb2,0x01,0xe2,0x09,0xad,0x01,0xce,0x09,0xa7,0x01,0xba,0x09,0xa2,0x01,0xa6,0x09,0x9d,0x01,0x92,0x09,0x97,0x01,0x7e,0x09,0x92,0x01,0x6a,0x09,0x8d,0x01,0x57,0x09,0x87,0x01,0x43,0x09,0x82,0x01,0x30,0x09,0x7d,0x01,0x1c,0x09,0x77,0x01,0x09,0x09,0x72,0x01,  \
    0xf6,0x08,0x6d,0x01,0xe2,0x08,0x67,0x01,0xcf,0x08,0x62,0x01,0xbc,0x08,0x5d,0x01,0xa9,0x08,0x58,0x01,0x96,0x08,0x52,0x01,0x84,0x08,0x4d,0x01,0x71,0x08,0x48,0x01,0x5e,0x08,0x43,0x01,0x4c,0x08,0x3d,0x01,0x3a,0x08,0x38,0x01,0x28,0x08,0x32,0x01,0x17,0x08,0x2d,0x01,0x05,0x08,0x28,0x01,0xf4,0x07,0x22,0x01,0xe2,0x07,0x1d,0x01,0xd1,0x07,0x18,0x01,0xc0,0x07,0x12,0x01,0xaf,0x07,0x0d,0x01,0x9d,0x07,0x08,0x01,0x8c,0x07,0x03,0x01,0x7b,0x07,0xfd,0x00,0x6b,0x07,  \
    0xf8,0x00,0x5a,0x07,0xf3,0x00,0x49,0x07,0xee,0x00,0x38,0x07,0xe9,0x00,0x28,0x07,0xe4,0x00,0x17,0x07,0xdf,0x00,0x07,0x07,0xda,0x00,0xf6,0x06,0xd5,0x00,0xe6,0x06,0xd0,0x00,0xd5,0x06,0xcb,0x00,0xc5,0x06,0xc6,0x00,0xb5,0x06,0xc1,0x00,0xa4,0x06,0xbd,0x00,0x94,0x06,0xb8,0x00,0x84,0x06,0xb3,0x00,0x74,0x06,0xae,0x00,0x64,0x06,0xaa,0x00,0x54,0x06,0xa5,0x00,0x44,0x06,0xa0,0x00,0x34,0x06,0x9c,0x00,0x24,0x06,0x97,0x00,0x15,0x06,0x93,0x00,0x05,0x06,0x8e,0x00,  \
    0xf5,0x05,0x8a,0x00,0xe6,0x05,0x85,0x00,0xd6,0x05,0x81,0x00,0xc6,0x05,0x7d,0x00,0xb7,0x05,0x78,0x00,0xa8,0x05,0x74,0x00,0x98,0x05,0x70,0x00,0x89,0x05,0x6c,0x00,0x79,0x05,0x68,0x00,0x6a,0x05,0x64,0x00,0x5a,0x05,0x60,0x00,0x4a,0x05,0x5c,0x00,0x3b,0x05,0x58,0x00,0x2b,0x05,0x54,0x00,0x1c,0x05,0x50,0x00,0x0c,0x05,0x4c,0x00,0xfd,0x04,0x48,0x00,0xee,0x04,0x45,0x00,0xde,0x04,0x41,0x00,0xcf,0x04,0x3d,0x00,0xc0,0x04,0x39,0x00,0xb1,0x04,0x36,0x00,0xa2,0x04,  \
    0x32,0x00,0x93,0x04,0x2f,0x00,0x84,0x04,0x2b,0x00,0x75,0x04,0x28,0x00,0x66,0x04,0x24,0x00,0x57,0x04,0x21,0x00,0x48,0x04,0x1d,0x00,0x39,0x04,0x1a,0x00,0x2b,0x04,0x17,0x00,0x1c,0x04,0x13,0x00,0x0d,0x04,0x10,0x00,0xff,0x03,0x0d,0x00,0xf1,0x03,0x09,0x00,0xe2,0x03,0x06,0x00,0xd4,0x03,0x03,0x00,0xc6,0x03,0x00,0x00,0xb8,0x03,0xfd,0xff,0xaa,0x03,0xfa,0xff,0x9c,0x03,0xf7,0xff,0x8d,0x03,0xf4,0xff,0x7f,0x03,0xf1,0xff,0x71,0x03,0xee,0xff,0x63,0x03,0xeb,0xff,  \
    0x55,0x03,0xe8,0xff,0x47,0x03,0xe6,0xff,0x39,0x03,0xe3,0xff,0x2b,0x03,0xe0,0xff,0x1e,0x03,0xde,0xff,0x10,0x03,0xdb,0xff,0x02,0x03,0xd9,0xff,0xf4,0x02,0xd6,0xff,0xe6,0x02,0xd4,0xff,0xd8,0x02,0xd1,0xff,0xcb,0x02,0xcf,0xff,0xbd,0x02,0xcc,0xff,0xaf,0x02,0xca,0xff,0xa2,0x02,0xc8,0xff,0x95,0x02,0xc5,0xff,0x87,0x02,0xc3,0xff,0x7a,0x02,0xc1,0xff,0x6c,0x02,0xbf,0xff,0x5f,0x02,0xbd,0xff,0x52,0x02,0xbb,0xff,0x44,0x02,0xb9,0xff,0x37,0x02,0xb7,0xff,0x2a,0x02,  \
    0xb5,0xff,0x1c,0x02,0xb3,0xff,0x0f,0x02,0xb1,0xff,0x02,0x02,0xaf,0xff,0xf5,0x01,0xae,0xff,0xe7,0x01,0xac,0xff,0xda,0x01,0xaa,0xff,0xcd,0x01,0xa9,0xff,0xc0,0x01,0xa7,0xff,0xb2,0x01,0xa6,0xff,0xa5,0x01,0xa4,0xff,0x98,0x01,0xa3,0xff,0x8a,0x01,0xa1,0xff,0x7d,0x01,0xa0,0xff,0x70,0x01,0x9e,0xff,0x63,0x01,0x9d,0xff,0x56,0x01,0x9c,0xff,0x48,0x01,0x9b,0xff,0x3b,0x01,0x9a,0xff,0x2d,0x01,0x99,0xff,0x20,0x01,0x97,0xff,0x13,0x01,0x96,0xff,0x05,0x01,0x95,0xff,  \
    0xf8,0x00,0x95,0xff,0xeb,0x00,0x94,0xff,0xdd,0x00,0x93,0xff,0xd0,0x00,0x92,0xff,0xc3,0x00,0x91,0xff,0xb5,0x00,0x90,0xff,0xa8,0x00,0x90,0xff,0x9b,0x00,0x8f,0xff,0x8d,0x00,0x8e,0xff,0x80,0x00,0x8e,0xff,0x73,0x00,0x8d,0xff,0x65,0x00,0x8d,0xff,0x58,0x00,0x8c,0xff,0x4b,0x00,0x8c,0xff,0x3e,0x00,0x8c,0xff,0x30,0x00,0x8b,0xff,0x23,0x00,0x8b,0xff,0x16,0x00,0x8b,0xff,0x08,0x00,0x8b,0xff,0xfb,0xff,0x8a,0xff,0xee,0xff,0x8a,0xff,0xe1,0xff,0x8a,0xff,0xd3,0xff,  \
    0x8a,0xff,0xc6,0xff,0x8a,0xff,0xb9,0xff,0x8a,0xff,0xac,0xff,0x8a,0xff,0x9e,0xff,0x8b,0xff,0x91,0xff,0x8b,0xff,0x84,0xff,0x8b,0xff,0x77,0xff,0x8b,0xff,0x69,0xff,0x8b,0xff,0x5c,0xff,0x8c,0xff,0x4f,0xff,0x8c,0xff,0x42,0xff,0x8d,0xff,0x34,0xff,0x8d,0xff,0x27,0xff,0x8d,0xff,0x1a,0xff,0x8e,0xff,0x0d,0xff,0x8f,0xff,0xff,0xfe,0x8f,0xff,0xf2,0xfe,0x90,0xff,0xe5,0xfe,0x90,0xff,0xd7,0xfe,0x91,0xff,0xca,0xfe,0x92,0xff,0xbd,0xfe,0x93,0xff,0xb0,0xfe,0x94,0xff,  \
    0xa2,0xfe,0x95,0xff,0x95,0xfe,0x95,0xff,0x88,0xfe,0x96,0xff,0x7a,0xfe,0x97,0xff,0x6d,0xfe,0x98,0xff,0x60,0xfe,0x9a,0xff,0x52,0xfe,0x9b,0xff,0x45,0xfe,0x9c,0xff,0x37,0xfe,0x9d,0xff,0x2a,0xfe,0x9e,0xff,0x1c,0xfe,0xa0,0xff,0x0f,0xfe,0xa1,0xff,0x01,0xfe,0xa2,0xff,0xf4,0xfd,0xa4,0xff,0xe6,0xfd,0xa5,0xff,0xd9,0xfd,0xa7,0xff,0xcb,0xfd,0xa8,0xff,0xbd,0xfd,0xaa,0xff,0xb0,0xfd,0xab,0xff,0xa2,0xfd,0xad,0xff,0x95,0xfd,0xae,0xff,0x87,0xfd,0xb0,0xff,0x79,0xfd,  \
    0xb2,0xff,0x6c,0xfd,0xb4,0xff,0x5e,0xfd,0xb6,0xff,0x50,0xfd,0xb7,0xff,0x42,0xfd,0xb9,0xff,0x35,0xfd,0xbb,0xff,0x27,0xfd,0xbd,0xff,0x19,0xfd,0xbf,0xff,0x0b,0xfd,0xc1,0xff,0xfd,0xfc,0xc3,0xff,0xef,0xfc,0xc5,0xff,0xe1,0xfc,0xc8,0xff,0xd4,0xfc,0xca,0xff,0xc6,0xfc,0xcc,0xff,0xb8,0xfc,0xce,0xff,0xaa,0xfc,0xd1,0xff,0x9d,0xfc,0xd3,0xff,0x8f,0xfc,0xd6,0xff,0x81,0xfc,0xd8,0xff,0x73,0xfc,0xdb,0xff,0x66,0xfc,0xdd,0xff,0x58,0xfc,0xe0,0xff,0x4a,0xfc,0xe2,0xff,  \
    0x3c,0xfc,0xe5,0xff,0x2e,0xfc,0xe8,0xff,0x20,0xfc,0xea,0xff,0x12,0xfc,0xed,0xff,0x04,0xfc,0xf0,0xff,0xf6,0xfb,0xf3,0xff,0xe8,0xfb,0xf6,0xff,0xda,0xfb,0xf9,0xff,0xcc,0xfb,0xfc,0xff,0xbe,0xfb,0xff,0xff,0xb0,0xfb,0x02,0x00,0xa2,0xfb,0x05,0x00,0x93,0xfb,0x08,0x00,0x85,0xfb,0x0b,0x00,0x77,0xfb,0x0e,0x00,0x69,0xfb,0x12,0x00,0x5a,0xfb,0x15,0x00,0x4b,0xfb,0x18,0x00,0x3d,0xfb,0x1b,0x00,0x2e,0xfb,0x1f,0x00,0x20,0xfb,0x22,0x00,0x11,0xfb,0x26,0x00,0x02,0xfb,  \
    0x29,0x00,0xf3,0xfa,0x2c,0x00,0xe5,0xfa,0x30,0x00,0xd6,0xfa,0x34,0x00,0xc7,0xfa,0x37,0x00,0xb8,0xfa,0x3b,0x00,0xa9,0xfa,0x3e,0x00,0x9a,0xfa,0x42,0x00,0x8b,0xfa,0x46,0x00,0x7c,0xfa,0x4a,0x00,0x6d,0xfa,0x4d,0x00,0x5e,0xfa,0x51,0x00,0x4f,0xfa,0x55,0x00,0x3f,0xfa,0x59,0x00,0x30,0xfa,0x5d,0x00,0x21,0xfa,0x61,0x00,0x11,0xfa,0x65,0x00,0x02,0xfa,0x69,0x00,0xf3,0xf9,0x6d,0x00,0xe3,0xf9,0x71,0x00,0xd4,0xf9,0x75,0x00,0xc4,0xf9,0x7a,0x00,0xb5,0xf9,0x7e,0x00,  \
    0xa5,0xf9,0x82,0x00,0x96,0xf9,0x86,0x00,0x86,0xf9,0x8b,0x00,0x76,0xf9,0x8f,0x00,0x67,0xf9,0x93,0x00,0x57,0xf9,0x98,0x00,0x47,0xf9,0x9c,0x00,0x37,0xf9,0xa1,0x00,0x27,0xf9,0xa5,0x00,0x17,0xf9,0xaa,0x00,0x07,0xf9,0xae,0x00,0xf7,0xf8,0xb3,0x00,0xe7,0xf8,0xb8,0x00,0xd6,0xf8,0xbc,0x00,0xc6,0xf8,0xc1,0x00,0xb6,0xf8,0xc6,0x00,0xa5,0xf8,0xca,0x00,0x95,0xf8,0xcf,0x00,0x84,0xf8,0xd4,0x00,0x74,0xf8,0xd9,0x00,0x63,0xf8,0xdd,0x00,0x52,0xf8,0xe2,0x00,0x41,0xf8,  \
    0xe7,0x00,0x30,0xf8,0xec,0x00,0x1f,0xf8,0xf1,0x00,0x0e,0xf8,0xf6,0x00,0xfc,0xf7,0xfa,0x00,0xeb,0xf7,0xff,0x00,0xda,0xf7,0x04,0x01,0xc8,0xf7,0x09,0x01,0xb7,0xf7,0x0e,0x01,0xa5,0xf7,0x13,0x01,0x94,0xf7,0x18,0x01,0x82,0xf7,0x1d,0x01,0x70,0xf7,0x22,0x01,0x5e,0xf7,0x28,0x01,0x4c,0xf7,0x2d,0x01,0x3a,0xf7,0x32,0x01,0x28,0xf7,0x37,0x01,0x16,0xf7,0x3c,0x01,0x04,0xf7,0x41,0x01,0xf2,0xf6,0x47,0x01,0xe0,0xf6,0x4c,0x01,0xcd,0xf6,0x51,0x01,0xbb,0xf6,0x56,0x01,  \
    0xa8,0xf6,0x5b,0x01,0x96,0xf6,0x61,0x01,0x83,0xf6,0x66,0x01,0x70,0xf6,0x6b,0x01,0x5d,0xf6,0x71,0x01,0x4b,0xf6,0x76,0x01,0x37,0xf6,0x7b,0x01,0x24,0xf6,0x81,0x01,0x11,0xf6,0x86,0x01,0xfe,0xf5,0x8b,0x01,0xeb,0xf5,0x91,0x01,0xd7,0xf5,0x96,0x01,0xc4,0xf5,0x9b,0x01,0xb0,0xf5,0xa0,0x01,0x9c,0xf5,0xa6,0x01,0x87,0xf5,0xab,0x01,0x73,0xf5,0xb0,0x01,0x5f,0xf5,0xb5,0x01,0x4a,0xf5,0xba,0x01,0x36,0xf5,0xbf,0x01,0x21,0xf5,0xc4,0x01,0x0c,0xf5,0xc9,0x01,0xf7,0xf4,  \
    0xcf,0x01,0xe2,0xf4,0xd4,0x01,0xcd,0xf4,0xd9,0x01,0xb8,0xf4,0xde,0x01,0xa2,0xf4,0xe3,0x01,0x8d,0xf4,0xe8,0x01,0x78,0xf4,0xed,0x01,0x62,0xf4,0xf2,0x01,0x4c,0xf4,0xf7,0x01,0x36,0xf4,0xfc,0x01,0x21,0xf4,0x01,0x02,0x0b,0xf4,0x06,0x02,0xf5,0xf3,0x0b,0x02,0xdf,0xf3,0x10,0x02,0xc9,0xf3,0x15,0x02,0xb3,0xf3,0x1b,0x02,0x9d,0xf3,0x20,0x02,0x87,0xf3,0x24,0x02,0x70,0xf3,0x29,0x02,0x59,0xf3,0x2e,0x02,0x43,0xf3,0x33,0x02,0x2c,0xf3,0x38,0x02,0x15,0xf3,0x3d,0x02,  \
    0xfe,0xf2,0x42,0x02,0xe7,0xf2,0x46,0x02,0xcf,0xf2,0x4b,0x02,0xb8,0xf2,0x50,0x02,0xa0,0xf2,0x54,0x02,0x89,0xf2,0x59,0x02,0x71,0xf2,0x5d,0x02,0x59,0xf2,0x62,0x02,0x41,0xf2,0x66,0x02,0x29,0xf2,0x6b,0x02,0x10,0xf2,0x6f,0x02,0xf8,0xf1,0x73,0x02,0xdf,0xf1,0x78,0x02,0xc7,0xf1,0x7c,0x02,0xae,0xf1,0x80,0x02,0x95,0xf1,0x84,0x02,0x7c,0xf1,0x88,0x02,0x63,0xf1,0x8c,0x02,0x49,0xf1,0x90,0x02,0x30,0xf1,0x94,0x02,0x16,0xf1,0x97,0x02,0xfc,0xf0,0x9b,0x02,0xe2,0xf0,  \
    0x9f,0x02,0xc8,0xf0,0xa2,0x02,0xae,0xf0,0xa6,0x02,0x94,0xf0,0xa9,0x02,0x79,0xf0,0xac,0x02,0x5e,0xf0,0xaf,0x02,0x43,0xf0,0xb2,0x02,0x28,0xf0,0xb5,0x02,0x0d,0xf0,0xb8,0x02,0xf1,0xef,0xbb,0x02,0xd6,0xef,0xbe,0x02,0xba,0xef,0xc0,0x02,0x9e,0xef,0xc3,0x02,0x82,0xef,0xc6,0x02,0x66,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf3,0x02,0x8d,0x10,0xf0,0x02,0x71,0x10,0xee,0x02,0x55,0x10,0xeb,0x02,0x39,0x10,0xe8,0x02,0x1d,0x10,0xe5,0x02,0x01,0x10,0xe2,0x02,0xe6,0x0f,0xdf,0x02,0xca,0x0f,0xdc,0x02,0xaf,0x0f,0xd9,0x02,0x94,0x0f,0xd6,0x02,0x79,0x0f,0xd2,0x02,0x5e,0x0f,0xcf,0x02,0x43,0x0f,0xcb,0x02,0x28,0x0f,0xc8,0x02,0x0e,0x0f,0xc4,0x02,0xf3,0x0e,  \
    0xc0,0x02,0xd9,0x0e,0xbd,0x02,0xbf,0x0e,0xb9,0x02,0xa5,0x0e,0xb5,0x02,0x8b,0x0e,0xb1,0x02,0x71,0x0e,0xad,0x02,0x57,0x0e,0xa9,0x02,0x3e,0x0e,0xa4,0x02,0x25,0x0e,0xa0,0x02,0x0c,0x0e,0x9c,0x02,0xf2,0x0d,0x97,0x02,0xda,0x0d,0x93,0x02,0xc1,0x0d,0x8f,0x02,0xa8,0x0d,0x8a,0x02,0x90,0x0d,0x85,0x02,0x77,0x0d,0x81,0x02,0x5f,0x0d,0x7c,0x02,0x47,0x0d,0x77,0x02,0x2f,0x0d,0x73,0x02,0x17,0x0d,0x6e,0x02,0xff,0x0c,0x69,0x02,0xe7,0x0c,0x64,0x02,0xd0,0x0c,0x5f,0x02,  \
    0xb8,0x0c,0x5a,0x02,0xa1,0x0c,0x55,0x02,0x8a,0x0c,0x50,0x02,0x73,0x0c,0x4b,0x02,0x5c,0x0c,0x46,0x02,0x46,0x0c,0x41,0x02,0x2f,0x0c,0x3b,0x02,0x19,0x0c,0x36,0x02,0x02,0x0c,0x31,0x02,0xec,0x0b,0x2b,0x02,0xd6,0x0b,0x26,0x02,0xc0,0x0b,0x21,0x02,0xaa,0x0b,0x1b,0x02,0x95,0x0b,0x16,0x02,0x7f,0x0b,0x10,0x02,0x6a,0x0b,0x0b,0x02,0x54,0x0b,0x05,0x02,0x3f,0x0b,0x00,0x02,0x2a,0x0b,0xfa,0x01,0x15,0x0b,0xf5,0x01,0xff,0x0a,0xf0,0x01,0xea,0x0a,0xeb,0x01,0xd4,0x0a,  \
    0xe5,0x01,0xbf,0x0a,0xe0,0x01,0xaa,0x0a,0xdb,0x01,0x95,0x0a,0xd5,0x01,0x80,0x0a,0xd0,0x01,0x6b,0x0a,0xcb,0x01,0x56,0x0a,0xc6,0x01,0x41,0x0a,0xc0,0x01,0x2d,0x0a,0xbb,0x01,0x18,0x0a,0xb6,0x01,0x04,0x0a,0xb0,0x01,0xef,0x09,0xab,0x01,0xdb,0x09,0xa6,0x01,0xc7,0x09,0xa1,0x01,0xb3,0x09,0x9b,0x01,0x9f,0x09,0x96,0x01,0x8b,0x09,0x91,0x01,0x77,0x09,0x8b,0x01,0x63,0x09,0x86,0x01,0x50,0x09,0x81,0x01,0x3c,0x09,0x7c,0x01,0x29,0x09,0x76,0x01,0x15,0x09,0x71,0x01,  \
    0x02,0x09,0x6c,0x01,0xef,0x08,0x67,0x01,0xdc,0x08,0x61,0x01,0xc8,0x08,0x5c,0x01,0xb5,0x08,0x57,0x01,0xa3,0x08,0x52,0x01,0x90,0x08,0x4d,0x01,0x7d,0x08,0x47,0x01,0x6a,0x08,0x42,0x01,0x58,0x08,0x3d,0x01,0x45,0x08,0x38,0x01,0x33,0x08,0x32,0x01,0x22,0x08,0x2d,0x01,0x10,0x08,0x28,0x01,0xfe,0x07,0x22,0x01,0xed,0x07,0x1d,0x01,0xdc,0x07,0x18,0x01,0xca,0x07,0x13,0x01,0xb9,0x07,0x0d,0x01,0xa8,0x07,0x08,0x01,0x97,0x07,0x03,0x01,0x86,0x07,0xfe,0x00,0x75,0x07,  \
    0xf9,0x00,0x64,0x07,0xf4,0x00,0x53,0x07,0xef,0x00,0x42,0x07,0xea,0x00,0x31,0x07,0xe5,0x00,0x21,0x07,0xe0,0x00,0x10,0x07,0xdb,0x00,0x00,0x07,0xd6,0x00,0xef,0x06,0xd1,0x00,0xdf,0x06,0xcc,0x00,0xce,0x06,0xc7,0x00,0xbe,0x06,0xc2,0x00,0xae,0x06,0xbd,0x00,0x9d,0x06,0xb9,0x00,0x8d,0x06,0xb4,0x00,0x7d,0x06,0xaf,0x00,0x6d,0x06,0xab,0x00,0x5d,0x06,0xa6,0x00,0x4d,0x06,0xa1,0x00,0x3d,0x06,0x9d,0x00,0x2d,0x06,0x98,0x00,0x1d,0x06,0x94,0x00,0x0e,0x06,0x8f,0x00,  \
    0xfe,0x05,0x8b,0x00,0xee,0x05,0x86,0x00,0xdf,0x05,0x82,0x00,0xcf,0x05,0x7e,0x00,0xc0,0x05,0x79,0x00,0xb0,0x05,0x75,0x00,0xa1,0x05,0x71,0x00,0x92,0x05,0x6d,0x00,0x82,0x05,0x69,0x00,0x73,0x05,0x65,0x00,0x63,0x05,0x61,0x00,0x53,0x05,0x5d,0x00,0x44,0x05,0x59,0x00,0x34,0x05,0x55,0x00,0x25,0x05,0x51,0x00,0x15,0x05,0x4d,0x00,0x06,0x05,0x49,0x00,0xf7,0x04,0x46,0x00,0xe8,0x04,0x42,0x00,0xd8,0x04,0x3e,0x00,0xc9,0x04,0x3a,0x00,0xba,0x04,0x37,0x00,0xab,0x04,  \
    0x33,0x00,0x9c,0x04,0x30,0x00,0x8d,0x04,0x2c,0x00,0x7e,0x04,0x29,0x00,0x6f,0x04,0x25,0x00,0x60,0x04,0x22,0x00,0x51,0x04,0x1e,0x00,0x42,0x04,0x1b,0x00,0x34,0x04,0x18,0x00,0x25,0x04,0x14,0x00,0x16,0x04,0x11,0x00,0x08,0x04,0x0e,0x00,0xfa,0x03,0x0a,0x00,0xeb,0x03,0x07,0x00,0xdd,0x03,0x04,0x00,0xcf,0x03,0x01,0x00,0xc1,0x03,0xfe,0xff,0xb3,0x03,0xfb,0xff,0xa5,0x03,0xf8,0xff,0x96,0x03,0xf5,0xff,0x88,0x03,0xf2,0xff,0x7a,0x03,0xef,0xff,0x6c,0x03,0xec,0xff,  \
    0x5e,0x03,0xe9,0xff,0x50,0x03,0xe7,0xff,0x43,0x03,0xe4,0xff,0x35,0x03,0xe1,0xff,0x27,0x03,0xde,0xff,0x19,0x03,0xdc,0xff,0x0b,0x03,0xd9,0xff,0xfd,0x02,0xd7,0xff,0xf0,0x02,0xd4,0xff,0xe2,0x02,0xd2,0xff,0xd4,0x02,0xcf,0xff,0xc6,0x02,0xcd,0xff,0xb9,0x02,0xcb,0xff,0xab,0x02,0xc8,0xff,0x9e,0x02,0xc6,0xff,0x91,0x02,0xc4,0xff,0x83,0x02,0xc2,0xff,0x76,0x02,0xbf,0xff,0x69,0x02,0xbd,0xff,0x5b,0x02,0xbb,0xff,0x4e,0x02,0xb9,0xff,0x41,0x02,0xb7,0xff,0x33,0x02,  \
    0xb5,0xff,0x26,0x02,0xb3,0xff,0x19,0x02,0xb2,0xff,0x0c,0x02,0xb0,0xff,0xfe,0x01,0xae,0xff,0xf1,0x01,0xac,0xff,0xe4,0x01,0xab,0xff,0xd7,0x01,0xa9,0xff,0xca,0x01,0xa7,0xff,0xbc,0x01,0xa6,0xff,0xaf,0x01,0xa4,0xff,0xa2,0x01,0xa3,0xff,0x95,0x01,0xa1,0xff,0x88,0x01,0xa0,0xff,0x7b,0x01,0x9e,0xff,0x6d,0x01,0x9d,0xff,0x60,0x01,0x9c,0xff,0x53,0x01,0x9b,0xff,0x46,0x01,0x99,0xff,0x39,0x01,0x98,0xff,0x2b,0x01,0x97,0xff,0x1e,0x01,0x96,0xff,0x11,0x01,0x95,0xff,  \
    0x03,0x01,0x94,0xff,0xf6,0x00,0x93,0xff,0xe9,0x00,0x92,0xff,0xdb,0x00,0x92,0xff,0xce,0x00,0x91,0xff,0xc1,0x00,0x90,0xff,0xb4,0x00,0x8f,0xff,0xa6,0x00,0x8f,0xff,0x99,0x00,0x8e,0xff,0x8c,0x00,0x8d,0xff,0x7f,0x00,0x8d,0xff,0x72,0x00,0x8c,0xff,0x64,0x00,0x8c,0xff,0x57,0x00,0x8b,0xff,0x4a,0x00,0x8b,0xff,0x3d,0x00,0x8b,0xff,0x30,0x00,0x8a,0xff,0x22,0x00,0x8a,0xff,0x15,0x00,0x8a,0xff,0x08,0x00,0x89,0xff,0xfb,0xff,0x89,0xff,0xee,0xff,0x89,0xff,0xe1,0xff,  \
    0x89,0xff,0xd3,0xff,0x89,0xff,0xc6,0xff,0x89,0xff,0xb9,0xff,0x89,0xff,0xac,0xff,0x89,0xff,0x9f,0xff,0x89,0xff,0x91,0xff,0x8a,0xff,0x84,0xff,0x8a,0xff,0x77,0xff,0x8a,0xff,0x6a,0xff,0x8a,0xff,0x5d,0xff,0x8b,0xff,0x50,0xff,0x8b,0xff,0x42,0xff,0x8b,0xff,0x35,0xff,0x8c,0xff,0x28,0xff,0x8c,0xff,0x1b,0xff,0x8d,0xff,0x0e,0xff,0x8d,0xff,0x01,0xff,0x8e,0xff,0xf3,0xfe,0x8f,0xff,0xe6,0xfe,0x8f,0xff,0xd9,0xfe,0x90,0xff,0xcc,0xfe,0x91,0xff,0xbe,0xfe,0x92,0xff,  \
    0xb1,0xfe,0x92,0xff,0xa4,0xfe,0x93,0xff,0x97,0xfe,0x94,0xff,0x8a,0xfe,0x95,0xff,0x7c,0xfe,0x96,0xff,0x6f,0xfe,0x97,0xff,0x62,0xfe,0x98,0xff,0x54,0xfe,0x99,0xff,0x47,0xfe,0x9b,0xff,0x3a,0xfe,0x9c,0xff,0x2c,0xfe,0x9d,0xff,0x1f,0xfe,0x9e,0xff,0x12,0xfe,0xa0,0xff,0x04,0xfe,0xa1,0xff,0xf7,0xfd,0xa2,0xff,0xe9,0xfd,0xa4,0xff,0xdc,0xfd,0xa5,0xff,0xce,0xfd,0xa7,0xff,0xc1,0xfd,0xa8,0xff,0xb3,0xfd,0xaa,0xff,0xa6,0xfd,0xab,0xff,0x98,0xfd,0xad,0xff,0x8a,0xfd,  \
    0xaf,0xff,0x7d,0xfd,0xb0,0xff,0x6f,0xfd,0xb2,0xff,0x62,0xfd,0xb4,0xff,0x54,0xfd,0xb6,0xff,0x46,0xfd,0xb8,0xff,0x38,0xfd,0xba,0xff,0x2b,0xfd,0xbc,0xff,0x1d,0xfd,0xbe,0xff,0x0f,0xfd,0xc0,0xff,0x01,0xfd,0xc2,0xff,0xf4,0xfc,0xc4,0xff,0xe6,0xfc,0xc6,0xff,0xd8,0xfc,0xc8,0xff,0xcb,0xfc,0xca,0xff,0xbd,0xfc,0xcd,0xff,0xaf,0xfc,0xcf,0xff,0xa2,0xfc,0xd1,0xff,0x94,0xfc,0xd4,0xff,0x86,0xfc,0xd6,0xff,0x78,0xfc,0xd9,0xff,0x6b,0xfc,0xdb,0xff,0x5d,0xfc,0xde,0xff,  \
    0x4f,0xfc,0xe1,0xff,0x41,0xfc,0xe3,0xff,0x33,0xfc,0xe6,0xff,0x25,0xfc,0xe9,0xff,0x17,0xfc,0xeb,0xff,0x0a,0xfc,0xee,0xff,0xfc,0xfb,0xf1,0xff,0xee,0xfb,0xf4,0xff,0xe0,0xfb,0xf7,0xff,0xd2,0xfb,0xfa,0xff,0xc4,0xfb,0xfd,0xff,0xb5,0xfb,0x00,0x00,0xa7,0xfb,0x03,0x00,0x99,0xfb,0x06,0x00,0x8b,0xfb,0x09,0x00,0x7d,0xfb,0x0c,0x00,0x6f,0xfb,0x0f,0x00,0x60,0xfb,0x13,0x00,0x52,0xfb,0x16,0x00,0x43,0xfb,0x19,0x00,0x34,0xfb,0x1c,0x00,0x26,0xfb,0x20,0x00,0x17,0xfb,  \
    0x23,0x00,0x09,0xfb,0x27,0x00,0xfa,0xfa,0x2a,0x00,0xeb,0xfa,0x2e,0x00,0xdc,0xfa,0x31,0x00,0xcd,0xfa,0x35,0x00,0xbf,0xfa,0x38,0x00,0xb0,0xfa,0x3c,0x00,0xa1,0xfa,0x40,0x00,0x92,0xfa,0x43,0x00,0x83,0xfa,0x47,0x00,0x74,0xfa,0x4b,0x00,0x65,0xfa,0x4f,0x00,0x55,0xfa,0x52,0x00,0x46,0xfa,0x56,0x00,0x37,0xfa,0x5a,0x00,0x28,0xfa,0x5e,0x00,0x18,0xfa,0x62,0x00,0x09,0xfa,0x66,0x00,0xfa,0xf9,0x6a,0x00,0xea,0xf9,0x6e,0x00,0xdb,0xf9,0x72,0x00,0xcc,0xf9,0x76,0x00,  \
    0xbc,0xf9,0x7b,0x00,0xac,0xf9,0x7f,0x00,0x9d,0xf9,0x83,0x00,0x8d,0xf9,0x87,0x00,0x7e,0xf9,0x8c,0x00,0x6e,0xf9,0x90,0x00,0x5e,0xf9,0x94,0x00,0x4e,0xf9,0x99,0x00,0x3e,0xf9,0x9d,0x00,0x2e,0xf9,0xa2,0x00,0x1e,0xf9,0xa6,0x00,0x0e,0xf9,0xab,0x00,0xfe,0xf8,0xaf,0x00,0xee,0xf8,0xb4,0x00,0xde,0xf8,0xb8,0x00,0xce,0xf8,0xbd,0x00,0xbd,0xf8,0xc2,0x00,0xad,0xf8,0xc6,0x00,0x9c,0xf8,0xcb,0x00,0x8c,0xf8,0xd0,0x00,0x7b,0xf8,0xd4,0x00,0x6a,0xf8,0xd9,0x00,0x59,0xf8,  \
    0xde,0x00,0x48,0xf8,0xe3,0x00,0x37,0xf8,0xe8,0x00,0x26,0xf8,0xec,0x00,0x15,0xf8,0xf1,0x00,0x04,0xf8,0xf6,0x00,0xf3,0xf7,0xfb,0x00,0xe1,0xf7,0x00,0x01,0xd0,0xf7,0x05,0x01,0xbe,0xf7,0x0a,0x01,0xad,0xf7,0x0f,0x01,0x9b,0xf7,0x14,0x01,0x89,0xf7,0x19,0x01,0x78,0xf7,0x1e,0x01,0x66,0xf7,0x23,0x01,0x54,0xf7,0x28,0x01,0x42,0xf7,0x2d,0x01,0x30,0xf7,0x32,0x01,0x1e,0xf7,0x37,0x01,0x0c,0xf7,0x3c,0x01,0xf9,0xf6,0x41,0x01,0xe7,0xf6,0x46,0x01,0xd5,0xf6,0x4c,0x01,  \
    0xc2,0xf6,0x51,0x01,0xb0,0xf6,0x56,0x01,0x9d,0xf6,0x5b,0x01,0x8b,0xf6,0x60,0x01,0x78,0xf6,0x66,0x01,0x65,0xf6,0x6b,0x01,0x52,0xf6,0x70,0x01,0x3f,0xf6,0x75,0x01,0x2c,0xf6,0x7b,0x01,0x19,0xf6,0x80,0x01,0x05,0xf6,0x85,0x01,0xf2,0xf5,0x8a,0x01,0xde,0xf5,0x90,0x01,0xcb,0xf5,0x95,0x01,0xb7,0xf5,0x9a,0x01,0xa3,0xf5,0x9f,0x01,0x8f,0xf5,0xa4,0x01,0x7b,0xf5,0xa9,0x01,0x66,0xf5,0xae,0x01,0x52,0xf5,0xb3,0x01,0x3d,0xf5,0xb8,0x01,0x28,0xf5,0xbd,0x01,0x13,0xf5,  \
    0xc3,0x01,0xfe,0xf4,0xc8,0x01,0xe9,0xf4,0xcd,0x01,0xd4,0xf4,0xd2,0x01,0xbf,0xf4,0xd7,0x01,0xaa,0xf4,0xdc,0x01,0x94,0xf4,0xe1,0x01,0x7f,0xf4,0xe6,0x01,0x69,0xf4,0xeb,0x01,0x53,0xf4,0xef,0x01,0x3e,0xf4,0xf4,0x01,0x28,0xf4,0xf9,0x01,0x12,0xf4,0xff,0x01,0xfc,0xf3,0x04,0x02,0xe6,0xf3,0x09,0x02,0xd0,0xf3,0x0e,0x02,0xba,0xf3,0x12,0x02,0xa4,0xf3,0x17,0x02,0x8d,0xf3,0x1c,0x02,0x77,0xf3,0x21,0x02,0x60,0xf3,0x26,0x02,0x4a,0xf3,0x2b,0x02,0x33,0xf3,0x2f,0x02,  \
    0x1c,0xf3,0x34,0x02,0x05,0xf3,0x39,0x02,0xed,0xf2,0x3e,0x02,0xd6,0xf2,0x42,0x02,0xbf,0xf2,0x47,0x02,0xa7,0xf2,0x4b,0x02,0x8f,0xf2,0x50,0x02,0x77,0xf2,0x54,0x02,0x5f,0xf2,0x59,0x02,0x47,0xf2,0x5d,0x02,0x2f,0xf2,0x61,0x02,0x17,0xf2,0x66,0x02,0xfe,0xf1,0x6a,0x02,0xe6,0xf1,0x6e,0x02,0xcd,0xf1,0x72,0x02,0xb4,0xf1,0x76,0x02,0x9b,0xf1,0x7a,0x02,0x82,0xf1,0x7e,0x02,0x69,0xf1,0x82,0x02,0x4f,0xf1,0x86,0x02,0x36,0xf1,0x8a,0x02,0x1c,0xf1,0x8d,0x02,0x02,0xf1,  \
    0x91,0x02,0xe8,0xf0,0x94,0x02,0xce,0xf0,0x98,0x02,0xb4,0xf0,0x9b,0x02,0x9a,0xf0,0x9f,0x02,0x7f,0xf0,0xa2,0x02,0x64,0xf0,0xa5,0x02,0x49,0xf0,0xa8,0x02,0x2e,0xf0,0xab,0x02,0x13,0xf0,0xae,0x02,0xf7,0xef,0xb0,0x02,0xdc,0xef,0xb3,0x02,0xc0,0xef,0xb6,0x02,0xa4,0xef,0xb8,0x02,0x88,0xef,0xbb,0x02,0x6c,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe7,0x02,0x89,0x10,0xe4,0x02,0x6c,0x10,0xe2,0x02,0x50,0x10,0xdf,0x02,0x34,0x10,0xdc,0x02,0x18,0x10,0xd9,0x02,0xfc,0x0f,0xd6,0x02,0xe1,0x0f,0xd3,0x02,0xc5,0x0f,0xd0,0x02,0xaa,0x0f,0xcd,0x02,0x8f,0x0f,0xca,0x02,0x74,0x0f,0xc7,0x02,0x59,0x0f,0xc3,0x02,0x3e,0x0f,0xc0,0x02,0x23,0x0f,0xbc,0x02,0x09,0x0f,  \
    0xb9,0x02,0xee,0x0e,0xb5,0x02,0xd4,0x0e,0xb2,0x02,0xba,0x0e,0xae,0x02,0x9f,0x0e,0xaa,0x02,0x85,0x0e,0xa6,0x02,0x6c,0x0e,0xa2,0x02,0x52,0x0e,0x9e,0x02,0x39,0x0e,0x9a,0x02,0x1f,0x0e,0x96,0x02,0x06,0x0e,0x91,0x02,0xed,0x0d,0x8d,0x02,0xd4,0x0d,0x89,0x02,0xbb,0x0d,0x84,0x02,0xa3,0x0d,0x80,0x02,0x8a,0x0d,0x7b,0x02,0x72,0x0d,0x77,0x02,0x59,0x0d,0x72,0x02,0x41,0x0d,0x6e,0x02,0x29,0x0d,0x69,0x02,0x11,0x0d,0x64,0x02,0xf9,0x0c,0x5f,0x02,0xe2,0x0c,0x5b,0x02,  \
    0xca,0x0c,0x56,0x02,0xb2,0x0c,0x51,0x02,0x9b,0x0c,0x4c,0x02,0x84,0x0c,0x47,0x02,0x6d,0x0c,0x42,0x02,0x56,0x0c,0x3d,0x02,0x40,0x0c,0x37,0x02,0x29,0x0c,0x32,0x02,0x13,0x0c,0x2d,0x02,0xfc,0x0b,0x28,0x02,0xe6,0x0b,0x23,0x02,0xd0,0x0b,0x1d,0x02,0xba,0x0b,0x18,0x02,0xa4,0x0b,0x13,0x02,0x8e,0x0b,0x0d,0x02,0x79,0x0b,0x08,0x02,0x63,0x0b,0x03,0x02,0x4e,0x0b,0xfd,0x01,0x39,0x0b,0xf8,0x01,0x23,0x0b,0xf2,0x01,0x0e,0x0b,0xed,0x01,0xf9,0x0a,0xe8,0x01,0xe3,0x0a,  \
    0xe3,0x01,0xce,0x0a,0xde,0x01,0xb9,0x0a,0xd8,0x01,0xa3,0x0a,0xd3,0x01,0x8e,0x0a,0xce,0x01,0x79,0x0a,0xc9,0x01,0x64,0x0a,0xc4,0x01,0x50,0x0a,0xbe,0x01,0x3b,0x0a,0xb9,0x01,0x26,0x0a,0xb4,0x01,0x12,0x0a,0xaf,0x01,0xfd,0x09,0xaa,0x01,0xe9,0x09,0xa4,0x01,0xd5,0x09,0x9f,0x01,0xc0,0x09,0x9a,0x01,0xac,0x09,0x95,0x01,0x98,0x09,0x8f,0x01,0x84,0x09,0x8a,0x01,0x71,0x09,0x85,0x01,0x5d,0x09,0x80,0x01,0x49,0x09,0x7b,0x01,0x36,0x09,0x75,0x01,0x22,0x09,0x70,0x01,  \
    0x0f,0x09,0x6b,0x01,0xfb,0x08,0x66,0x01,0xe8,0x08,0x61,0x01,0xd5,0x08,0x5b,0x01,0xc2,0x08,0x56,0x01,0xaf,0x08,0x51,0x01,0x9c,0x08,0x4c,0x01,0x89,0x08,0x47,0x01,0x76,0x08,0x42,0x01,0x64,0x08,0x3d,0x01,0x51,0x08,0x38,0x01,0x3f,0x08,0x32,0x01,0x2d,0x08,0x2d,0x01,0x1b,0x08,0x28,0x01,0x09,0x08,0x23,0x01,0xf8,0x07,0x1d,0x01,0xe6,0x07,0x18,0x01,0xd5,0x07,0x13,0x01,0xc3,0x07,0x0e,0x01,0xb2,0x07,0x09,0x01,0xa1,0x07,0x03,0x01,0x90,0x07,0xfe,0x00,0x7f,0x07,  \
    0xf9,0x00,0x6e,0x07,0xf4,0x00,0x5d,0x07,0xef,0x00,0x4c,0x07,0xea,0x00,0x3b,0x07,0xe5,0x00,0x2b,0x07,0xe0,0x00,0x1a,0x07,0xdb,0x00,0x09,0x07,0xd6,0x00,0xf9,0x06,0xd1,0x00,0xe8,0x06,0xcd,0x00,0xd8,0x06,0xc8,0x00,0xc7,0x06,0xc3,0x00,0xb7,0x06,0xbe,0x00,0xa7,0x06,0xba,0x00,0x97,0x06,0xb5,0x00,0x86,0x06,0xb0,0x00,0x76,0x06,0xac,0x00,0x66,0x06,0xa7,0x00,0x56,0x06,0xa2,0x00,0x46,0x06,0x9e,0x00,0x36,0x06,0x99,0x00,0x26,0x06,0x95,0x00,0x17,0x06,0x90,0x00,  \
    0x07,0x06,0x8c,0x00,0xf7,0x05,0x88,0x00,0xe8,0x05,0x83,0x00,0xd8,0x05,0x7f,0x00,0xc9,0x05,0x7b,0x00,0xb9,0x05,0x76,0x00,0xaa,0x05,0x72,0x00,0x9a,0x05,0x6e,0x00,0x8b,0x05,0x6a,0x00,0x7c,0x05,0x66,0x00,0x6c,0x05,0x62,0x00,0x5c,0x05,0x5e,0x00,0x4d,0x05,0x5a,0x00,0x3d,0x05,0x56,0x00,0x2e,0x05,0x52,0x00,0x1f,0x05,0x4e,0x00,0x0f,0x05,0x4a,0x00,0x00,0x05,0x47,0x00,0xf1,0x04,0x43,0x00,0xe1,0x04,0x3f,0x00,0xd2,0x04,0x3c,0x00,0xc3,0x04,0x38,0x00,0xb4,0x04,  \
    0x34,0x00,0xa5,0x04,0x31,0x00,0x96,0x04,0x2d,0x00,0x87,0x04,0x2a,0x00,0x78,0x04,0x26,0x00,0x69,0x04,0x23,0x00,0x5a,0x04,0x1f,0x00,0x4c,0x04,0x1c,0x00,0x3d,0x04,0x19,0x00,0x2e,0x04,0x15,0x00,0x1f,0x04,0x12,0x00,0x11,0x04,0x0f,0x00,0x03,0x04,0x0c,0x00,0xf4,0x03,0x08,0x00,0xe6,0x03,0x05,0x00,0xd8,0x03,0x02,0x00,0xca,0x03,0xff,0xff,0xbc,0x03,0xfc,0xff,0xae,0x03,0xf9,0xff,0x9f,0x03,0xf6,0xff,0x91,0x03,0xf3,0xff,0x83,0x03,0xf0,0xff,0x75,0x03,0xed,0xff,  \
    0x68,0x03,0xea,0xff,0x5a,0x03,0xe8,0xff,0x4c,0x03,0xe5,0xff,0x3e,0x03,0xe2,0xff,0x30,0x03,0xdf,0xff,0x22,0x03,0xdd,0xff,0x14,0x03,0xda,0xff,0x07,0x03,0xd8,0xff,0xf9,0x02,0xd5,0xff,0xeb,0x02,0xd3,0xff,0xde,0x02,0xd0,0xff,0xd0,0x02,0xce,0xff,0xc2,0x02,0xcc,0xff,0xb5,0x02,0xc9,0xff,0xa7,0x02,0xc7,0xff,0x9a,0x02,0xc5,0xff,0x8d,0x02,0xc2,0xff,0x7f,0x02,0xc0,0xff,0x72,0x02,0xbe,0xff,0x65,0x02,0xbc,0xff,0x58,0x02,0xba,0xff,0x4a,0x02,0xb8,0xff,0x3d,0x02,  \
    0xb6,0xff,0x30,0x02,0xb4,0xff,0x23,0x02,0xb2,0xff,0x15,0x02,0xb0,0xff,0x08,0x02,0xae,0xff,0xfb,0x01,0xad,0xff,0xee,0x01,0xab,0xff,0xe1,0x01,0xa9,0xff,0xd4,0x01,0xa8,0xff,0xc7,0x01,0xa6,0xff,0xb9,0x01,0xa5,0xff,0xac,0x01,0xa3,0xff,0x9f,0x01,0xa2,0xff,0x92,0x01,0xa0,0xff,0x85,0x01,0x9f,0xff,0x78,0x01,0x9d,0xff,0x6b,0x01,0x9c,0xff,0x5e,0x01,0x9b,0xff,0x51,0x01,0x9a,0xff,0x43,0x01,0x98,0xff,0x36,0x01,0x97,0xff,0x29,0x01,0x96,0xff,0x1c,0x01,0x95,0xff,  \
    0x0f,0x01,0x94,0xff,0x01,0x01,0x93,0xff,0xf4,0x00,0x92,0xff,0xe7,0x00,0x91,0xff,0xda,0x00,0x91,0xff,0xcd,0x00,0x90,0xff,0xbf,0x00,0x8f,0xff,0xb2,0x00,0x8e,0xff,0xa5,0x00,0x8e,0xff,0x98,0x00,0x8d,0xff,0x8b,0x00,0x8c,0xff,0x7e,0x00,0x8c,0xff,0x70,0x00,0x8b,0xff,0x63,0x00,0x8b,0xff,0x56,0x00,0x8a,0xff,0x49,0x00,0x8a,0xff,0x3c,0x00,0x8a,0xff,0x2f,0x00,0x89,0xff,0x22,0x00,0x89,0xff,0x15,0x00,0x89,0xff,0x08,0x00,0x89,0xff,0xfa,0xff,0x88,0xff,0xed,0xff,  \
    0x88,0xff,0xe0,0xff,0x88,0xff,0xd3,0xff,0x88,0xff,0xc6,0xff,0x88,0xff,0xb9,0xff,0x88,0xff,0xac,0xff,0x88,0xff,0x9f,0xff,0x88,0xff,0x92,0xff,0x89,0xff,0x85,0xff,0x89,0xff,0x78,0xff,0x89,0xff,0x6b,0xff,0x89,0xff,0x5d,0xff,0x8a,0xff,0x50,0xff,0x8a,0xff,0x43,0xff,0x8a,0xff,0x36,0xff,0x8b,0xff,0x29,0xff,0x8b,0xff,0x1c,0xff,0x8c,0xff,0x0f,0xff,0x8c,0xff,0x02,0xff,0x8d,0xff,0xf5,0xfe,0x8e,0xff,0xe8,0xfe,0x8e,0xff,0xda,0xfe,0x8f,0xff,0xcd,0xfe,0x90,0xff,  \
    0xc0,0xfe,0x91,0xff,0xb3,0xfe,0x91,0xff,0xa6,0xfe,0x92,0xff,0x99,0xfe,0x93,0xff,0x8c,0xfe,0x94,0xff,0x7e,0xfe,0x95,0xff,0x71,0xfe,0x96,0xff,0x64,0xfe,0x97,0xff,0x57,0xfe,0x98,0xff,0x49,0xfe,0x99,0xff,0x3c,0xfe,0x9b,0xff,0x2f,0xfe,0x9c,0xff,0x22,0xfe,0x9d,0xff,0x14,0xfe,0x9e,0xff,0x07,0xfe,0xa0,0xff,0xf9,0xfd,0xa1,0xff,0xec,0xfd,0xa3,0xff,0xdf,0xfd,0xa4,0xff,0xd1,0xfd,0xa6,0xff,0xc4,0xfd,0xa7,0xff,0xb6,0xfd,0xa9,0xff,0xa9,0xfd,0xaa,0xff,0x9b,0xfd,  \
    0xac,0xff,0x8e,0xfd,0xae,0xff,0x80,0xfd,0xaf,0xff,0x73,0xfd,0xb1,0xff,0x65,0xfd,0xb3,0xff,0x58,0xfd,0xb5,0xff,0x4a,0xfd,0xb6,0xff,0x3c,0xfd,0xb8,0xff,0x2f,0xfd,0xba,0xff,0x21,0xfd,0xbc,0xff,0x13,0xfd,0xbe,0xff,0x06,0xfd,0xc0,0xff,0xf8,0xfc,0xc2,0xff,0xea,0xfc,0xc5,0xff,0xdd,0xfc,0xc7,0xff,0xcf,0xfc,0xc9,0xff,0xc1,0xfc,0xcb,0xff,0xb4,0xfc,0xce,0xff,0xa6,0xfc,0xd0,0xff,0x99,0xfc,0xd2,0xff,0x8b,0xfc,0xd5,0xff,0x7d,0xfc,0xd7,0xff,0x70,0xfc,0xda,0xff,  \
    0x62,0xfc,0xdc,0xff,0x54,0xfc,0xdf,0xff,0x46,0xfc,0xe2,0xff,0x38,0xfc,0xe4,0xff,0x2b,0xfc,0xe7,0xff,0x1d,0xfc,0xea,0xff,0x0f,0xfc,0xec,0xff,0x01,0xfc,0xef,0xff,0xf3,0xfb,0xf2,0xff,0xe5,0xfb,0xf5,0xff,0xd7,0xfb,0xf8,0xff,0xc9,0xfb,0xfb,0xff,0xbb,0xfb,0xfe,0xff,0xad,0xfb,0x01,0x00,0x9f,0xfb,0x04,0x00,0x91,0xfb,0x07,0x00,0x83,0xfb,0x0a,0x00,0x74,0xfb,0x0d,0x00,0x66,0xfb,0x11,0x00,0x58,0xfb,0x14,0x00,0x49,0xfb,0x17,0x00,0x3b,0xfb,0x1a,0x00,0x2c,0xfb,  \
    0x1e,0x00,0x1d,0xfb,0x21,0x00,0x0f,0xfb,0x24,0x00,0x00,0xfb,0x28,0x00,0xf1,0xfa,0x2b,0x00,0xe3,0xfa,0x2f,0x00,0xd4,0xfa,0x32,0x00,0xc5,0xfa,0x36,0x00,0xb6,0xfa,0x39,0x00,0xa7,0xfa,0x3d,0x00,0x98,0xfa,0x41,0x00,0x89,0xfa,0x44,0x00,0x7a,0xfa,0x48,0x00,0x6b,0xfa,0x4c,0x00,0x5c,0xfa,0x50,0x00,0x4d,0xfa,0x54,0x00,0x3e,0xfa,0x57,0x00,0x2f,0xfa,0x5b,0x00,0x1f,0xfa,0x5f,0x00,0x10,0xfa,0x63,0x00,0x01,0xfa,0x67,0x00,0xf1,0xf9,0x6b,0x00,0xe2,0xf9,0x6f,0x00,  \
    0xd3,0xf9,0x74,0x00,0xc3,0xf9,0x78,0x00,0xb4,0xf9,0x7c,0x00,0xa4,0xf9,0x80,0x00,0x94,0xf9,0x84,0x00,0x85,0xf9,0x89,0x00,0x75,0xf9,0x8d,0x00,0x65,0xf9,0x91,0x00,0x56,0xf9,0x96,0x00,0x46,0xf9,0x9a,0x00,0x36,0xf9,0x9e,0x00,0x26,0xf9,0xa3,0x00,0x16,0xf9,0xa7,0x00,0x06,0xf9,0xac,0x00,0xf6,0xf8,0xb0,0x00,0xe5,0xf8,0xb5,0x00,0xd5,0xf8,0xb9,0x00,0xc5,0xf8,0xbe,0x00,0xb4,0xf8,0xc3,0x00,0xa4,0xf8,0xc7,0x00,0x93,0xf8,0xcc,0x00,0x83,0xf8,0xd0,0x00,0x72,0xf8,  \
    0xd5,0x00,0x61,0xf8,0xda,0x00,0x50,0xf8,0xdf,0x00,0x3f,0xf8,0xe3,0x00,0x2e,0xf8,0xe8,0x00,0x1d,0xf8,0xed,0x00,0x0b,0xf8,0xf2,0x00,0xfa,0xf7,0xf6,0x00,0xe9,0xf7,0xfb,0x00,0xd7,0xf7,0x00,0x01,0xc6,0xf7,0x05,0x01,0xb4,0xf7,0x0a,0x01,0xa3,0xf7,0x0f,0x01,0x91,0xf7,0x14,0x01,0x7f,0xf7,0x19,0x01,0x6d,0xf7,0x1e,0x01,0x5b,0xf7,0x23,0x01,0x49,0xf7,0x28,0x01,0x37,0xf7,0x2d,0x01,0x25,0xf7,0x32,0x01,0x13,0xf7,0x37,0x01,0x01,0xf7,0x3c,0x01,0xef,0xf6,0x41,0x01,  \
    0xdc,0xf6,0x46,0x01,0xca,0xf6,0x4b,0x01,0xb7,0xf6,0x50,0x01,0xa5,0xf6,0x55,0x01,0x92,0xf6,0x5b,0x01,0x7f,0xf6,0x60,0x01,0x6c,0xf6,0x65,0x01,0x59,0xf6,0x6a,0x01,0x46,0xf6,0x6f,0x01,0x33,0xf6,0x74,0x01,0x20,0xf6,0x7a,0x01,0x0d,0xf6,0x7f,0x01,0xf9,0xf5,0x84,0x01,0xe6,0xf5,0x89,0x01,0xd2,0xf5,0x8e,0x01,0xbe,0xf5,0x93,0x01,0xaa,0xf5,0x99,0x01,0x96,0xf5,0x9e,0x01,0x82,0xf5,0xa3,0x01,0x6d,0xf5,0xa8,0x01,0x59,0xf5,0xad,0x01,0x44,0xf5,0xb2,0x01,0x2f,0xf5,  \
    0xb7,0x01,0x1b,0xf5,0xbc,0x01,0x06,0xf5,0xc1,0x01,0xf1,0xf4,0xc5,0x01,0xdb,0xf4,0xca,0x01,0xc6,0xf4,0xcf,0x01,0xb1,0xf4,0xd4,0x01,0x9b,0xf4,0xd9,0x01,0x86,0xf4,0xde,0x01,0x70,0xf4,0xe3,0x01,0x5b,0xf4,0xe8,0x01,0x45,0xf4,0xed,0x01,0x2f,0xf4,0xf2,0x01,0x19,0xf4,0xf7,0x01,0x03,0xf4,0xfc,0x01,0xed,0xf3,0x01,0x02,0xd7,0xf3,0x06,0x02,0xc1,0xf3,0x0a,0x02,0xab,0xf3,0x0f,0x02,0x94,0xf3,0x14,0x02,0x7e,0xf3,0x19,0x02,0x67,0xf3,0x1e,0x02,0x50,0xf3,0x22,0x02,  \
    0x39,0xf3,0x27,0x02,0x22,0xf3,0x2c,0x02,0x0b,0xf3,0x30,0x02,0xf4,0xf2,0x35,0x02,0xdd,0xf2,0x39,0x02,0xc5,0xf2,0x3e,0x02,0xad,0xf2,0x42,0x02,0x96,0xf2,0x47,0x02,0x7e,0xf2,0x4b,0x02,0x66,0xf2,0x50,0x02,0x4e,0xf2,0x54,0x02,0x36,0xf2,0x58,0x02,0x1d,0xf2,0x5c,0x02,0x05,0xf2,0x60,0x02,0xec,0xf1,0x65,0x02,0xd3,0xf1,0x69,0x02,0xba,0xf1,0x6d,0x02,0xa1,0xf1,0x71,0x02,0x88,0xf1,0x74,0x02,0x6f,0xf1,0x78,0x02,0x55,0xf1,0x7c,0x02,0x3c,0xf1,0x80,0x02,0x22,0xf1,  \
    0x83,0x02,0x08,0xf1,0x87,0x02,0xee,0xf0,0x8a,0x02,0xd4,0xf0,0x8e,0x02,0xba,0xf0,0x91,0x02,0xa0,0xf0,0x94,0x02,0x85,0xf0,0x97,0x02,0x6a,0xf0,0x9a,0x02,0x4f,0xf0,0x9d,0x02,0x34,0xf0,0xa0,0x02,0x19,0xf0,0xa3,0x02,0xfd,0xef,0xa6,0x02,0xe2,0xef,0xa9,0x02,0xc6,0xef,0xab,0x02,0xaa,0xef,0xae,0x02,0x8e,0xef,0xb0,0x02,0x72,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xdb,0x02,0x84,0x10,0xd8,0x02,0x67,0x10,0xd6,0x02,0x4b,0x10,0xd3,0x02,0x2f,0x10,0xd0,0x02,0x13,0x10,0xce,0x02,0xf8,0x0f,0xcb,0x02,0xdc,0x0f,0xc8,0x02,0xc0,0x0f,0xc5,0x02,0xa5,0x0f,0xc2,0x02,0x8a,0x0f,0xbf,0x02,0x6f,0x0f,0xbb,0x02,0x54,0x0f,0xb8,0x02,0x39,0x0f,0xb5,0x02,0x1e,0x0f,  \
    0xb1,0x02,0x04,0x0f,0xae,0x02,0xe9,0x0e,0xaa,0x02,0xcf,0x0e,0xa6,0x02,0xb4,0x0e,0xa3,0x02,0x9a,0x0e,0x9f,0x02,0x80,0x0e,0x9b,0x02,0x67,0x0e,0x97,0x02,0x4d,0x0e,0x93,0x02,0x34,0x0e,0x8f,0x02,0x1a,0x0e,0x8b,0x02,0x01,0x0e,0x87,0x02,0xe8,0x0d,0x83,0x02,0xcf,0x0d,0x7e,0x02,0xb6,0x0d,0x7a,0x02,0x9d,0x0d,0x76,0x02,0x85,0x0d,0x71,0x02,0x6c,0x0d,0x6d,0x02,0x54,0x0d,0x68,0x02,0x3c,0x0d,0x64,0x02,0x24,0x0d,0x5f,0x02,0x0c,0x0d,0x5a,0x02,0xf4,0x0c,0x56,0x02,  \
    0xdc,0x0c,0x51,0x02,0xc4,0x0c,0x4c,0x02,0xad,0x0c,0x47,0x02,0x95,0x0c,0x43,0x02,0x7e,0x0c,0x3e,0x02,0x67,0x0c,0x39,0x02,0x50,0x0c,0x34,0x02,0x3a,0x0c,0x2e,0x02,0x23,0x0c,0x29,0x02,0x0d,0x0c,0x24,0x02,0xf6,0x0b,0x1f,0x02,0xe0,0x0b,0x1a,0x02,0xca,0x0b,0x15,0x02,0xb4,0x0b,0x10,0x02,0x9e,0x0b,0x0a,0x02,0x88,0x0b,0x05,0x02,0x73,0x0b,0x00,0x02,0x5d,0x0b,0xfa,0x01,0x48,0x0b,0xf5,0x01,0x32,0x0b,0xf0,0x01,0x1d,0x0b,0xea,0x01,0x08,0x0b,0xe5,0x01,0xf2,0x0a,  \
    0xe0,0x01,0xdd,0x0a,0xdb,0x01,0xc7,0x0a,0xd6,0x01,0xb2,0x0a,0xd1,0x01,0x9d,0x0a,0xcc,0x01,0x88,0x0a,0xc7,0x01,0x73,0x0a,0xc2,0x01,0x5e,0x0a,0xbc,0x01,0x49,0x0a,0xb7,0x01,0x34,0x0a,0xb2,0x01,0x20,0x0a,0xad,0x01,0x0b,0x0a,0xa8,0x01,0xf7,0x09,0xa3,0x01,0xe2,0x09,0x9d,0x01,0xce,0x09,0x98,0x01,0xba,0x09,0x93,0x01,0xa6,0x09,0x8e,0x01,0x92,0x09,0x89,0x01,0x7e,0x09,0x84,0x01,0x6a,0x09,0x7f,0x01,0x56,0x09,0x79,0x01,0x43,0x09,0x74,0x01,0x2f,0x09,0x6f,0x01,  \
    0x1b,0x09,0x6a,0x01,0x08,0x09,0x65,0x01,0xf5,0x08,0x60,0x01,0xe1,0x08,0x5b,0x01,0xce,0x08,0x56,0x01,0xbb,0x08,0x51,0x01,0xa8,0x08,0x4b,0x01,0x95,0x08,0x46,0x01,0x82,0x08,0x41,0x01,0x70,0x08,0x3c,0x01,0x5d,0x08,0x37,0x01,0x4a,0x08,0x32,0x01,0x38,0x08,0x2d,0x01,0x26,0x08,0x28,0x01,0x14,0x08,0x23,0x01,0x03,0x08,0x1d,0x01,0xf1,0x07,0x18,0x01,0xe0,0x07,0x13,0x01,0xce,0x07,0x0e,0x01,0xbd,0x07,0x09,0x01,0xac,0x07,0x04,0x01,0x9a,0x07,0xff,0x00,0x89,0x07,  \
    0xfa,0x00,0x78,0x07,0xf5,0x00,0x67,0x07,0xf0,0x00,0x56,0x07,0xeb,0x00,0x45,0x07,0xe6,0x00,0x35,0x07,0xe1,0x00,0x24,0x07,0xdc,0x00,0x13,0x07,0xd7,0x00,0x03,0x07,0xd2,0x00,0xf2,0x06,0xcd,0x00,0xe2,0x06,0xc9,0x00,0xd1,0x06,0xc4,0x00,0xc1,0x06,0xbf,0x00,0xb0,0x06,0xba,0x00,0xa0,0x06,0xb6,0x00,0x90,0x06,0xb1,0x00,0x80,0x06,0xad,0x00,0x70,0x06,0xa8,0x00,0x60,0x06,0xa3,0x00,0x50,0x06,0x9f,0x00,0x40,0x06,0x9a,0x00,0x30,0x06,0x96,0x00,0x20,0x06,0x91,0x00,  \
    0x10,0x06,0x8d,0x00,0x00,0x06,0x89,0x00,0xf1,0x05,0x84,0x00,0xe1,0x05,0x80,0x00,0xd2,0x05,0x7c,0x00,0xc2,0x05,0x78,0x00,0xb3,0x05,0x73,0x00,0xa3,0x05,0x6f,0x00,0x94,0x05,0x6b,0x00,0x85,0x05,0x67,0x00,0x75,0x05,0x63,0x00,0x66,0x05,0x5f,0x00,0x56,0x05,0x5b,0x00,0x47,0x05,0x57,0x00,0x37,0x05,0x53,0x00,0x28,0x05,0x4f,0x00,0x18,0x05,0x4c,0x00,0x09,0x05,0x48,0x00,0xfa,0x04,0x44,0x00,0xeb,0x04,0x40,0x00,0xdb,0x04,0x3d,0x00,0xcc,0x04,0x39,0x00,0xbd,0x04,  \
    0x36,0x00,0xae,0x04,0x32,0x00,0x9f,0x04,0x2e,0x00,0x90,0x04,0x2b,0x00,0x81,0x04,0x27,0x00,0x72,0x04,0x24,0x00,0x64,0x04,0x21,0x00,0x55,0x04,0x1d,0x00,0x46,0x04,0x1a,0x00,0x37,0x04,0x17,0x00,0x29,0x04,0x13,0x00,0x1a,0x04,0x10,0x00,0x0c,0x04,0x0d,0x00,0xfd,0x03,0x0a,0x00,0xef,0x03,0x06,0x00,0xe1,0x03,0x03,0x00,0xd3,0x03,0x00,0x00,0xc5,0x03,0xfd,0xff,0xb7,0x03,0xfa,0xff,0xa8,0x03,0xf7,0xff,0x9a,0x03,0xf4,0xff,0x8c,0x03,0xf1,0xff,0x7f,0x03,0xee,0xff,  \
    0x71,0x03,0xec,0xff,0x63,0x03,0xe9,0xff,0x55,0x03,0xe6,0xff,0x47,0x03,0xe3,0xff,0x39,0x03,0xe1,0xff,0x2b,0x03,0xde,0xff,0x1e,0x03,0xdb,0xff,0x10,0x03,0xd9,0xff,0x02,0x03,0xd6,0xff,0xf5,0x02,0xd4,0xff,0xe7,0x02,0xd1,0xff,0xd9,0x02,0xcf,0xff,0xcc,0x02,0xcd,0xff,0xbe,0x02,0xca,0xff,0xb1,0x02,0xc8,0xff,0xa3,0x02,0xc6,0xff,0x96,0x02,0xc3,0xff,0x89,0x02,0xc1,0xff,0x7b,0x02,0xbf,0xff,0x6e,0x02,0xbd,0xff,0x61,0x02,0xbb,0xff,0x54,0x02,0xb9,0xff,0x47,0x02,  \
    0xb7,0xff,0x39,0x02,0xb5,0xff,0x2c,0x02,0xb3,0xff,0x1f,0x02,0xb1,0xff,0x12,0x02,0xaf,0xff,0x05,0x02,0xad,0xff,0xf8,0x01,0xac,0xff,0xeb,0x01,0xaa,0xff,0xde,0x01,0xa8,0xff,0xd1,0x01,0xa7,0xff,0xc4,0x01,0xa5,0xff,0xb6,0x01,0xa4,0xff,0xa9,0x01,0xa2,0xff,0x9c,0x01,0xa1,0xff,0x8f,0x01,0x9f,0xff,0x82,0x01,0x9e,0xff,0x75,0x01,0x9c,0xff,0x68,0x01,0x9b,0xff,0x5b,0x01,0x9a,0xff,0x4e,0x01,0x99,0xff,0x41,0x01,0x98,0xff,0x34,0x01,0x96,0xff,0x27,0x01,0x95,0xff,  \
    0x1a,0x01,0x94,0xff,0x0c,0x01,0x93,0xff,0xff,0x00,0x92,0xff,0xf2,0x00,0x91,0xff,0xe5,0x00,0x91,0xff,0xd8,0x00,0x90,0xff,0xcb,0x00,0x8f,0xff,0xbe,0x00,0x8e,0xff,0xb1,0x00,0x8d,0xff,0xa4,0x00,0x8d,0xff,0x97,0x00,0x8c,0xff,0x8a,0x00,0x8c,0xff,0x7c,0x00,0x8b,0xff,0x6f,0x00,0x8b,0xff,0x62,0x00,0x8a,0xff,0x55,0x00,0x8a,0xff,0x48,0x00,0x89,0xff,0x3b,0x00,0x89,0xff,0x2e,0x00,0x89,0xff,0x21,0x00,0x88,0xff,0x14,0x00,0x88,0xff,0x07,0x00,0x88,0xff,0xfa,0xff,  \
    0x88,0xff,0xed,0xff,0x88,0xff,0xe0,0xff,0x87,0xff,0xd3,0xff,0x87,0xff,0xc6,0xff,0x87,0xff,0xb9,0xff,0x87,0xff,0xac,0xff,0x88,0xff,0x9f,0xff,0x88,0xff,0x92,0xff,0x88,0xff,0x85,0xff,0x88,0xff,0x78,0xff,0x88,0xff,0x6b,0xff,0x89,0xff,0x5e,0xff,0x89,0xff,0x51,0xff,0x89,0xff,0x44,0xff,0x8a,0xff,0x37,0xff,0x8a,0xff,0x2a,0xff,0x8b,0xff,0x1d,0xff,0x8b,0xff,0x10,0xff,0x8c,0xff,0x03,0xff,0x8c,0xff,0xf6,0xfe,0x8d,0xff,0xe9,0xfe,0x8e,0xff,0xdc,0xfe,0x8e,0xff,  \
    0xcf,0xfe,0x8f,0xff,0xc2,0xfe,0x90,0xff,0xb5,0xfe,0x91,0xff,0xa8,0xfe,0x91,0xff,0x9b,0xfe,0x92,0xff,0x8d,0xfe,0x93,0xff,0x80,0xfe,0x94,0xff,0x73,0xfe,0x95,0xff,0x66,0xfe,0x96,0xff,0x59,0xfe,0x97,0xff,0x4c,0xfe,0x99,0xff,0x3f,0xfe,0x9a,0xff,0x31,0xfe,0x9b,0xff,0x24,0xfe,0x9c,0xff,0x17,0xfe,0x9e,0xff,0x0a,0xfe,0x9f,0xff,0xfc,0xfd,0xa0,0xff,0xef,0xfd,0xa2,0xff,0xe2,0xfd,0xa3,0xff,0xd4,0xfd,0xa5,0xff,0xc7,0xfd,0xa6,0xff,0xba,0xfd,0xa8,0xff,0xac,0xfd,  \
    0xa9,0xff,0x9f,0xfd,0xab,0xff,0x91,0xfd,0xad,0xff,0x84,0xfd,0xae,0xff,0x76,0xfd,0xb0,0xff,0x69,0xfd,0xb2,0xff,0x5b,0xfd,0xb4,0xff,0x4e,0xfd,0xb5,0xff,0x40,0xfd,0xb7,0xff,0x33,0xfd,0xb9,0xff,0x25,0xfd,0xbb,0xff,0x18,0xfd,0xbd,0xff,0x0a,0xfd,0xbf,0xff,0xfc,0xfc,0xc1,0xff,0xef,0xfc,0xc3,0xff,0xe1,0xfc,0xc6,0xff,0xd4,0xfc,0xc8,0xff,0xc6,0xfc,0xca,0xff,0xb8,0xfc,0xcc,0xff,0xab,0xfc,0xcf,0xff,0x9d,0xfc,0xd1,0xff,0x90,0xfc,0xd3,0xff,0x82,0xfc,0xd6,0xff,  \
    0x74,0xfc,0xd8,0xff,0x67,0xfc,0xdb,0xff,0x59,0xfc,0xdd,0xff,0x4b,0xfc,0xe0,0xff,0x3e,0xfc,0xe3,0xff,0x30,0xfc,0xe5,0xff,0x22,0xfc,0xe8,0xff,0x14,0xfc,0xeb,0xff,0x06,0xfc,0xee,0xff,0xf8,0xfb,0xf0,0xff,0xeb,0xfb,0xf3,0xff,0xdd,0xfb,0xf6,0xff,0xcf,0xfb,0xf9,0xff,0xc1,0xfb,0xfc,0xff,0xb3,0xfb,0xff,0xff,0xa5,0xfb,0x02,0x00,0x97,0xfb,0x05,0x00,0x89,0xfb,0x08,0x00,0x7a,0xfb,0x0b,0x00,0x6c,0xfb,0x0f,0x00,0x5e,0xfb,0x12,0x00,0x4f,0xfb,0x15,0x00,0x41,0xfb,  \
    0x18,0x00,0x32,0xfb,0x1c,0x00,0x24,0xfb,0x1f,0x00,0x15,0xfb,0x22,0x00,0x06,0xfb,0x26,0x00,0xf8,0xfa,0x29,0x00,0xe9,0xfa,0x2d,0x00,0xda,0xfa,0x30,0x00,0xcc,0xfa,0x34,0x00,0xbd,0xfa,0x37,0x00,0xae,0xfa,0x3b,0x00,0x9f,0xfa,0x3e,0x00,0x90,0xfa,0x42,0x00,0x81,0xfa,0x46,0x00,0x72,0xfa,0x49,0x00,0x63,0xfa,0x4d,0x00,0x54,0xfa,0x51,0x00,0x45,0xfa,0x55,0x00,0x35,0xfa,0x59,0x00,0x26,0xfa,0x5d,0x00,0x17,0xfa,0x61,0x00,0x08,0xfa,0x65,0x00,0xf8,0xf9,0x69,0x00,  \
    0xe9,0xf9,0x6d,0x00,0xda,0xf9,0x71,0x00,0xca,0xf9,0x75,0x00,0xbb,0xf9,0x79,0x00,0xab,0xf9,0x7d,0x00,0x9c,0xf9,0x81,0x00,0x8c,0xf9,0x85,0x00,0x7c,0xf9,0x8a,0x00,0x6c,0xf9,0x8e,0x00,0x5d,0xf9,0x92,0x00,0x4d,0xf9,0x97,0x00,0x3d,0xf9,0x9b,0x00,0x2d,0xf9,0x9f,0x00,0x1d,0xf9,0xa4,0x00,0x0d,0xf9,0xa8,0x00,0xfd,0xf8,0xad,0x00,0xed,0xf8,0xb1,0x00,0xdc,0xf8,0xb6,0x00,0xcc,0xf8,0xba,0x00,0xbc,0xf8,0xbf,0x00,0xab,0xf8,0xc3,0x00,0x9b,0xf8,0xc8,0x00,0x8a,0xf8,  \
    0xcd,0x00,0x79,0xf8,0xd1,0x00,0x68,0xf8,0xd6,0x00,0x57,0xf8,0xda,0x00,0x46,0xf8,0xdf,0x00,0x35,0xf8,0xe4,0x00,0x24,0xf8,0xe9,0x00,0x13,0xf8,0xed,0x00,0x02,0xf8,0xf2,0x00,0xf0,0xf7,0xf7,0x00,0xdf,0xf7,0xfc,0x00,0xcd,0xf7,0x00,0x01,0xbc,0xf7,0x05,0x01,0xaa,0xf7,0x0a,0x01,0x98,0xf7,0x0f,0x01,0x87,0xf7,0x14,0x01,0x75,0xf7,0x19,0x01,0x63,0xf7,0x1e,0x01,0x51,0xf7,0x23,0x01,0x3f,0xf7,0x28,0x01,0x2d,0xf7,0x2d,0x01,0x1b,0xf7,0x32,0x01,0x08,0xf7,0x37,0x01,  \
    0xf6,0xf6,0x3c,0x01,0xe4,0xf6,0x41,0x01,0xd1,0xf6,0x46,0x01,0xbf,0xf6,0x4b,0x01,0xac,0xf6,0x50,0x01,0x99,0xf6,0x55,0x01,0x87,0xf6,0x5a,0x01,0x74,0xf6,0x5f,0x01,0x61,0xf6,0x64,0x01,0x4e,0xf6,0x69,0x01,0x3a,0xf6,0x6f,0x01,0x27,0xf6,0x74,0x01,0x14,0xf6,0x79,0x01,0x00,0xf6,0x7e,0x01,0xed,0xf5,0x83,0x01,0xd9,0xf5,0x88,0x01,0xc6,0xf5,0x8d,0x01,0xb1,0xf5,0x92,0x01,0x9d,0xf5,0x97,0x01,0x89,0xf5,0x9c,0x01,0x74,0xf5,0xa1,0x01,0x60,0xf5,0xa6,0x01,0x4b,0xf5,  \
    0xab,0x01,0x36,0xf5,0xb0,0x01,0x22,0xf5,0xb5,0x01,0x0d,0xf5,0xba,0x01,0xf8,0xf4,0xbe,0x01,0xe2,0xf4,0xc3,0x01,0xcd,0xf4,0xc8,0x01,0xb8,0xf4,0xcd,0x01,0xa2,0xf4,0xd2,0x01,0x8d,0xf4,0xd7,0x01,0x77,0xf4,0xdc,0x01,0x62,0xf4,0xe0,0x01,0x4c,0xf4,0xe5,0x01,0x36,0xf4,0xea,0x01,0x20,0xf4,0xef,0x01,0x0a,0xf4,0xf4,0x01,0xf4,0xf3,0xf9,0x01,0xde,0xf3,0xfe,0x01,0xc8,0xf3,0x02,0x02,0xb1,0xf3,0x07,0x02,0x9b,0xf3,0x0c,0x02,0x84,0xf3,0x11,0x02,0x6e,0xf3,0x15,0x02,  \
    0x57,0xf3,0x1a,0x02,0x40,0xf3,0x1e,0x02,0x29,0xf3,0x23,0x02,0x12,0xf3,0x28,0x02,0xfa,0xf2,0x2c,0x02,0xe3,0xf2,0x31,0x02,0xcc,0xf2,0x35,0x02,0xb4,0xf2,0x39,0x02,0x9c,0xf2,0x3e,0x02,0x84,0xf2,0x42,0x02,0x6c,0xf2,0x46,0x02,0x54,0xf2,0x4b,0x02,0x3c,0xf2,0x4f,0x02,0x23,0xf2,0x53,0x02,0x0b,0xf2,0x57,0x02,0xf2,0xf1,0x5b,0x02,0xd9,0xf1,0x5f,0x02,0xc0,0xf1,0x63,0x02,0xa7,0xf1,0x67,0x02,0x8e,0xf1,0x6b,0x02,0x75,0xf1,0x6e,0x02,0x5b,0xf1,0x72,0x02,0x42,0xf1,  \
    0x76,0x02,0x28,0xf1,0x79,0x02,0x0e,0xf1,0x7d,0x02,0xf4,0xf0,0x80,0x02,0xda,0xf0,0x84,0x02,0xc0,0xf0,0x87,0x02,0xa5,0xf0,0x8a,0x02,0x8b,0xf0,0x8d,0x02,0x70,0xf0,0x90,0x02,0x55,0xf0,0x93,0x02,0x3a,0xf0,0x96,0x02,0x1e,0xf0,0x99,0x02,0x03,0xf0,0x9b,0x02,0xe7,0xef,0x9e,0x02,0xcc,0xef,0xa0,0x02,0xb0,0xef,0xa3,0x02,0x94,0xef,0xa5,0x02,0x78,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcf,0x02,0x7f,0x10,0xcc,0x02,0x63,0x10,0xca,0x02,0x47,0x10,0xc7,0x02,0x2b,0x10,0xc5,0x02,0x0f,0x10,0xc2,0x02,0xf3,0x0f,0xbf,0x02,0xd7,0x0f,0xbc,0x02,0xbc,0x0f,0xb9,0x02,0xa0,0x0f,0xb6,0x02,0x85,0x0f,0xb3,0x02,0x6a,0x0f,0xb0,0x02,0x4f,0x0f,0xad,0x02,0x34,0x0f,  \
    0xa9,0x02,0x19,0x0f,0xa6,0x02,0xff,0x0e,0xa2,0x02,0xe4,0x0e,0x9f,0x02,0xca,0x0e,0x9b,0x02,0xaf,0x0e,0x98,0x02,0x95,0x0e,0x94,0x02,0x7b,0x0e,0x90,0x02,0x62,0x0e,0x8c,0x02,0x48,0x0e,0x88,0x02,0x2e,0x0e,0x84,0x02,0x15,0x0e,0x80,0x02,0xfc,0x0d,0x7c,0x02,0xe3,0x0d,0x78,0x02,0xca,0x0d,0x74,0x02,0xb1,0x0d,0x70,0x02,0x98,0x0d,0x6b,0x02,0x7f,0x0d,0x67,0x02,0x67,0x0d,0x63,0x02,0x4f,0x0d,0x5e,0x02,0x36,0x0d,0x5a,0x02,0x1e,0x0d,0x55,0x02,0x06,0x0d,0x51,0x02,  \
    0xee,0x0c,0x4c,0x02,0xd6,0x0c,0x47,0x02,0xbf,0x0c,0x43,0x02,0xa7,0x0c,0x3e,0x02,0x90,0x0c,0x39,0x02,0x79,0x0c,0x34,0x02,0x62,0x0c,0x2f,0x02,0x4b,0x0c,0x2a,0x02,0x34,0x0c,0x25,0x02,0x1d,0x0c,0x20,0x02,0x07,0x0c,0x1b,0x02,0xf0,0x0b,0x16,0x02,0xda,0x0b,0x11,0x02,0xc4,0x0b,0x0c,0x02,0xae,0x0b,0x07,0x02,0x98,0x0b,0x02,0x02,0x82,0x0b,0xfd,0x01,0x6d,0x0b,0xf7,0x01,0x57,0x0b,0xf2,0x01,0x41,0x0b,0xed,0x01,0x2c,0x0b,0xe8,0x01,0x17,0x0b,0xe3,0x01,0x02,0x0b,  \
    0xde,0x01,0xec,0x0a,0xd9,0x01,0xd6,0x0a,0xd4,0x01,0xc1,0x0a,0xcf,0x01,0xac,0x0a,0xc9,0x01,0x97,0x0a,0xc4,0x01,0x81,0x0a,0xbf,0x01,0x6c,0x0a,0xba,0x01,0x57,0x0a,0xb5,0x01,0x43,0x0a,0xb0,0x01,0x2e,0x0a,0xab,0x01,0x19,0x0a,0xa6,0x01,0x05,0x0a,0xa1,0x01,0xf0,0x09,0x9c,0x01,0xdc,0x09,0x97,0x01,0xc8,0x09,0x92,0x01,0xb3,0x09,0x8d,0x01,0x9f,0x09,0x87,0x01,0x8b,0x09,0x82,0x01,0x77,0x09,0x7d,0x01,0x64,0x09,0x78,0x01,0x50,0x09,0x73,0x01,0x3c,0x09,0x6e,0x01,  \
    0x29,0x09,0x69,0x01,0x15,0x09,0x64,0x01,0x02,0x09,0x5f,0x01,0xee,0x08,0x5a,0x01,0xdb,0x08,0x55,0x01,0xc8,0x08,0x50,0x01,0xb5,0x08,0x4b,0x01,0xa2,0x08,0x46,0x01,0x8f,0x08,0x41,0x01,0x7c,0x08,0x3c,0x01,0x69,0x08,0x37,0x01,0x57,0x08,0x32,0x01,0x44,0x08,0x2d,0x01,0x32,0x08,0x28,0x01,0x20,0x08,0x23,0x01,0x0e,0x08,0x1d,0x01,0xfc,0x07,0x18,0x01,0xeb,0x07,0x13,0x01,0xd9,0x07,0x0e,0x01,0xc8,0x07,0x09,0x01,0xb6,0x07,0x04,0x01,0xa5,0x07,0xff,0x00,0x94,0x07,  \
    0xfa,0x00,0x83,0x07,0xf5,0x00,0x72,0x07,0xf0,0x00,0x61,0x07,0xeb,0x00,0x50,0x07,0xe6,0x00,0x3f,0x07,0xe1,0x00,0x2e,0x07,0xdd,0x00,0x1d,0x07,0xd8,0x00,0x0d,0x07,0xd3,0x00,0xfc,0x06,0xce,0x00,0xeb,0x06,0xc9,0x00,0xdb,0x06,0xc5,0x00,0xcb,0x06,0xc0,0x00,0xba,0x06,0xbb,0x00,0xaa,0x06,0xb7,0x00,0x99,0x06,0xb2,0x00,0x89,0x06,0xad,0x00,0x79,0x06,0xa9,0x00,0x69,0x06,0xa4,0x00,0x59,0x06,0xa0,0x00,0x49,0x06,0x9b,0x00,0x39,0x06,0x97,0x00,0x29,0x06,0x93,0x00,  \
    0x19,0x06,0x8e,0x00,0x0a,0x06,0x8a,0x00,0xfa,0x05,0x86,0x00,0xea,0x05,0x81,0x00,0xdb,0x05,0x7d,0x00,0xcb,0x05,0x79,0x00,0xbc,0x05,0x75,0x00,0xac,0x05,0x70,0x00,0x9d,0x05,0x6c,0x00,0x8d,0x05,0x68,0x00,0x7e,0x05,0x64,0x00,0x6f,0x05,0x60,0x00,0x5f,0x05,0x5c,0x00,0x50,0x05,0x58,0x00,0x40,0x05,0x55,0x00,0x31,0x05,0x51,0x00,0x22,0x05,0x4d,0x00,0x12,0x05,0x49,0x00,0x03,0x05,0x45,0x00,0xf4,0x04,0x42,0x00,0xe5,0x04,0x3e,0x00,0xd5,0x04,0x3a,0x00,0xc6,0x04,  \
    0x37,0x00,0xb7,0x04,0x33,0x00,0xa8,0x04,0x30,0x00,0x99,0x04,0x2c,0x00,0x8a,0x04,0x29,0x00,0x7c,0x04,0x25,0x00,0x6d,0x04,0x22,0x00,0x5e,0x04,0x1f,0x00,0x4f,0x04,0x1b,0x00,0x41,0x04,0x18,0x00,0x32,0x04,0x15,0x00,0x23,0x04,0x11,0x00,0x15,0x04,0x0e,0x00,0x06,0x04,0x0b,0x00,0xf8,0x03,0x08,0x00,0xea,0x03,0x05,0x00,0xdc,0x03,0x02,0x00,0xce,0x03,0xff,0xff,0xc0,0x03,0xfc,0xff,0xb1,0x03,0xf9,0xff,0xa3,0x03,0xf6,0xff,0x96,0x03,0xf3,0xff,0x88,0x03,0xf0,0xff,  \
    0x7a,0x03,0xed,0xff,0x6c,0x03,0xea,0xff,0x5e,0x03,0xe7,0xff,0x50,0x03,0xe5,0xff,0x42,0x03,0xe2,0xff,0x35,0x03,0xdf,0xff,0x27,0x03,0xdd,0xff,0x19,0x03,0xda,0xff,0x0c,0x03,0xd8,0xff,0xfe,0x02,0xd5,0xff,0xf0,0x02,0xd3,0xff,0xe3,0x02,0xd0,0xff,0xd5,0x02,0xce,0xff,0xc8,0x02,0xcb,0xff,0xba,0x02,0xc9,0xff,0xad,0x02,0xc7,0xff,0x9f,0x02,0xc5,0xff,0x92,0x02,0xc2,0xff,0x85,0x02,0xc0,0xff,0x78,0x02,0xbe,0xff,0x6a,0x02,0xbc,0xff,0x5d,0x02,0xba,0xff,0x50,0x02,  \
    0xb8,0xff,0x43,0x02,0xb6,0xff,0x36,0x02,0xb4,0xff,0x29,0x02,0xb2,0xff,0x1c,0x02,0xb0,0xff,0x0f,0x02,0xae,0xff,0x02,0x02,0xad,0xff,0xf5,0x01,0xab,0xff,0xe8,0x01,0xa9,0xff,0xdb,0x01,0xa8,0xff,0xce,0x01,0xa6,0xff,0xc1,0x01,0xa4,0xff,0xb4,0x01,0xa3,0xff,0xa7,0x01,0xa1,0xff,0x9a,0x01,0xa0,0xff,0x8d,0x01,0x9e,0xff,0x80,0x01,0x9d,0xff,0x73,0x01,0x9c,0xff,0x66,0x01,0x9b,0xff,0x59,0x01,0x99,0xff,0x4c,0x01,0x98,0xff,0x3f,0x01,0x97,0xff,0x32,0x01,0x96,0xff,  \
    0x25,0x01,0x95,0xff,0x18,0x01,0x94,0xff,0x0a,0x01,0x93,0xff,0xfd,0x00,0x92,0xff,0xf0,0x00,0x91,0xff,0xe3,0x00,0x90,0xff,0xd6,0x00,0x8f,0xff,0xc9,0x00,0x8e,0xff,0xbc,0x00,0x8e,0xff,0xaf,0x00,0x8d,0xff,0xa2,0x00,0x8c,0xff,0x95,0x00,0x8c,0xff,0x88,0x00,0x8b,0xff,0x7b,0x00,0x8a,0xff,0x6e,0x00,0x8a,0xff,0x61,0x00,0x89,0xff,0x54,0x00,0x89,0xff,0x47,0x00,0x89,0xff,0x3a,0x00,0x88,0xff,0x2e,0x00,0x88,0xff,0x21,0x00,0x88,0xff,0x14,0x00,0x87,0xff,0x07,0x00,  \
    0x87,0xff,0xfa,0xff,0x87,0xff,0xed,0xff,0x87,0xff,0xe0,0xff,0x87,0xff,0xd3,0xff,0x87,0xff,0xc6,0xff,0x87,0xff,0xb9,0xff,0x87,0xff,0xac,0xff,0x87,0xff,0x9f,0xff,0x87,0xff,0x92,0xff,0x87,0xff,0x85,0xff,0x88,0xff,0x79,0xff,0x88,0xff,0x6c,0xff,0x88,0xff,0x5f,0xff,0x88,0xff,0x52,0xff,0x89,0xff,0x45,0xff,0x89,0xff,0x38,0xff,0x8a,0xff,0x2b,0xff,0x8a,0xff,0x1e,0xff,0x8b,0xff,0x11,0xff,0x8b,0xff,0x04,0xff,0x8c,0xff,0xf7,0xfe,0x8c,0xff,0xea,0xfe,0x8d,0xff,  \
    0xdd,0xfe,0x8e,0xff,0xd0,0xfe,0x8e,0xff,0xc3,0xfe,0x8f,0xff,0xb6,0xfe,0x90,0xff,0xa9,0xfe,0x91,0xff,0x9c,0xfe,0x92,0xff,0x8f,0xfe,0x93,0xff,0x82,0xfe,0x94,0xff,0x75,0xfe,0x95,0xff,0x68,0xfe,0x96,0xff,0x5b,0xfe,0x97,0xff,0x4e,0xfe,0x98,0xff,0x41,0xfe,0x99,0xff,0x34,0xfe,0x9a,0xff,0x27,0xfe,0x9c,0xff,0x19,0xfe,0x9d,0xff,0x0c,0xfe,0x9e,0xff,0xff,0xfd,0xa0,0xff,0xf2,0xfd,0xa1,0xff,0xe5,0xfd,0xa2,0xff,0xd7,0xfd,0xa4,0xff,0xca,0xfd,0xa5,0xff,0xbd,0xfd,  \
    0xa7,0xff,0xaf,0xfd,0xa8,0xff,0xa2,0xfd,0xaa,0xff,0x95,0xfd,0xac,0xff,0x87,0xfd,0xad,0xff,0x7a,0xfd,0xaf,0xff,0x6d,0xfd,0xb1,0xff,0x5f,0xfd,0xb3,0xff,0x52,0xfd,0xb5,0xff,0x44,0xfd,0xb6,0xff,0x37,0xfd,0xb8,0xff,0x29,0xfd,0xba,0xff,0x1c,0xfd,0xbc,0xff,0x0e,0xfd,0xbe,0xff,0x00,0xfd,0xc0,0xff,0xf3,0xfc,0xc2,0xff,0xe5,0xfc,0xc5,0xff,0xd8,0xfc,0xc7,0xff,0xca,0xfc,0xc9,0xff,0xbd,0xfc,0xcb,0xff,0xaf,0xfc,0xce,0xff,0xa2,0xfc,0xd0,0xff,0x94,0xfc,0xd2,0xff,  \
    0x87,0xfc,0xd5,0xff,0x79,0xfc,0xd7,0xff,0x6c,0xfc,0xda,0xff,0x5e,0xfc,0xdc,0xff,0x50,0xfc,0xdf,0xff,0x43,0xfc,0xe1,0xff,0x35,0xfc,0xe4,0xff,0x27,0xfc,0xe7,0xff,0x19,0xfc,0xe9,0xff,0x0c,0xfc,0xec,0xff,0xfe,0xfb,0xef,0xff,0xf0,0xfb,0xf2,0xff,0xe2,0xfb,0xf5,0xff,0xd4,0xfb,0xf8,0xff,0xc6,0xfb,0xfb,0xff,0xb8,0xfb,0xfe,0xff,0xaa,0xfb,0x01,0x00,0x9c,0xfb,0x04,0x00,0x8e,0xfb,0x07,0x00,0x80,0xfb,0x0a,0x00,0x72,0xfb,0x0d,0x00,0x63,0xfb,0x10,0x00,0x55,0xfb,  \
    0x13,0x00,0x47,0xfb,0x16,0x00,0x38,0xfb,0x1a,0x00,0x2a,0xfb,0x1d,0x00,0x1b,0xfb,0x20,0x00,0x0d,0xfb,0x24,0x00,0xfe,0xfa,0x27,0x00,0xef,0xfa,0x2b,0x00,0xe1,0xfa,0x2e,0x00,0xd2,0xfa,0x32,0x00,0xc3,0xfa,0x35,0x00,0xb4,0xfa,0x39,0x00,0xa5,0xfa,0x3c,0x00,0x96,0xfa,0x40,0x00,0x88,0xfa,0x43,0x00,0x79,0xfa,0x47,0x00,0x69,0xfa,0x4b,0x00,0x5a,0xfa,0x4f,0x00,0x4b,0xfa,0x52,0x00,0x3c,0xfa,0x56,0x00,0x2d,0xfa,0x5a,0x00,0x1e,0xfa,0x5e,0x00,0x0e,0xfa,0x62,0x00,  \
    0xff,0xf9,0x66,0x00,0xf0,0xf9,0x6a,0x00,0xe0,0xf9,0x6e,0x00,0xd1,0xf9,0x72,0x00,0xc2,0xf9,0x76,0x00,0xb2,0xf9,0x7a,0x00,0xa3,0xf9,0x7e,0x00,0x93,0xf9,0x82,0x00,0x83,0xf9,0x87,0x00,0x74,0xf9,0x8b,0x00,0x64,0xf9,0x8f,0x00,0x54,0xf9,0x93,0x00,0x44,0xf9,0x98,0x00,0x34,0xf9,0x9c,0x00,0x24,0xf9,0xa0,0x00,0x14,0xf9,0xa5,0x00,0x04,0xf9,0xa9,0x00,0xf4,0xf8,0xae,0x00,0xe3,0xf8,0xb2,0x00,0xd3,0xf8,0xb7,0x00,0xc3,0xf8,0xbb,0x00,0xb2,0xf8,0xc0,0x00,0xa2,0xf8,  \
    0xc4,0x00,0x91,0xf8,0xc9,0x00,0x80,0xf8,0xcd,0x00,0x6f,0xf8,0xd2,0x00,0x5e,0xf8,0xd6,0x00,0x4d,0xf8,0xdb,0x00,0x3c,0xf8,0xe0,0x00,0x2b,0xf8,0xe4,0x00,0x1a,0xf8,0xe9,0x00,0x09,0xf8,0xee,0x00,0xf7,0xf7,0xf3,0x00,0xe6,0xf7,0xf7,0x00,0xd5,0xf7,0xfc,0x00,0xc3,0xf7,0x01,0x01,0xb1,0xf7,0x06,0x01,0xa0,0xf7,0x0a,0x01,0x8e,0xf7,0x0f,0x01,0x7c,0xf7,0x14,0x01,0x6a,0xf7,0x19,0x01,0x58,0xf7,0x1e,0x01,0x46,0xf7,0x23,0x01,0x34,0xf7,0x28,0x01,0x22,0xf7,0x2d,0x01,  \
    0x10,0xf7,0x32,0x01,0xfd,0xf6,0x36,0x01,0xeb,0xf6,0x3b,0x01,0xd8,0xf6,0x40,0x01,0xc6,0xf6,0x45,0x01,0xb3,0xf6,0x4a,0x01,0xa1,0xf6,0x4f,0x01,0x8e,0xf6,0x54,0x01,0x7b,0xf6,0x59,0x01,0x68,0xf6,0x5f,0x01,0x55,0xf6,0x64,0x01,0x42,0xf6,0x69,0x01,0x2e,0xf6,0x6e,0x01,0x1b,0xf6,0x73,0x01,0x08,0xf6,0x78,0x01,0xf4,0xf5,0x7d,0x01,0xe0,0xf5,0x82,0x01,0xcd,0xf5,0x87,0x01,0xb8,0xf5,0x8c,0x01,0xa4,0xf5,0x90,0x01,0x90,0xf5,0x95,0x01,0x7b,0xf5,0x9a,0x01,0x67,0xf5,  \
    0x9f,0x01,0x52,0xf5,0xa4,0x01,0x3d,0xf5,0xa9,0x01,0x29,0xf5,0xae,0x01,0x14,0xf5,0xb3,0x01,0xff,0xf4,0xb7,0x01,0xe9,0xf4,0xbc,0x01,0xd4,0xf4,0xc1,0x01,0xbf,0xf4,0xc6,0x01,0xa9,0xf4,0xcb,0x01,0x94,0xf4,0xcf,0x01,0x7e,0xf4,0xd4,0x01,0x68,0xf4,0xd9,0x01,0x52,0xf4,0xde,0x01,0x3d,0xf4,0xe2,0x01,0x27,0xf4,0xe7,0x01,0x11,0xf4,0xec,0x01,0xfb,0xf3,0xf1,0x01,0xe5,0xf3,0xf6,0x01,0xce,0xf3,0xfa,0x01,0xb8,0xf3,0xff,0x01,0xa2,0xf3,0x04,0x02,0x8b,0xf3,0x08,0x02,  \
    0x74,0xf3,0x0d,0x02,0x5d,0xf3,0x11,0x02,0x46,0xf3,0x16,0x02,0x2f,0xf3,0x1a,0x02,0x18,0xf3,0x1f,0x02,0x01,0xf3,0x23,0x02,0xe9,0xf2,0x28,0x02,0xd2,0xf2,0x2c,0x02,0xba,0xf2,0x30,0x02,0xa2,0xf2,0x35,0x02,0x8a,0xf2,0x39,0x02,0x72,0xf2,0x3d,0x02,0x5a,0xf2,0x41,0x02,0x42,0xf2,0x45,0x02,0x29,0xf2,0x4a,0x02,0x11,0xf2,0x4e,0x02,0xf8,0xf1,0x51,0x02,0xdf,0xf1,0x55,0x02,0xc6,0xf1,0x59,0x02,0xad,0xf1,0x5d,0x02,0x94,0xf1,0x61,0x02,0x7b,0xf1,0x64,0x02,0x61,0xf1,  \
    0x68,0x02,0x48,0xf1,0x6c,0x02,0x2e,0xf1,0x6f,0x02,0x14,0xf1,0x73,0x02,0xfa,0xf0,0x76,0x02,0xe0,0xf0,0x79,0x02,0xc5,0xf0,0x7d,0x02,0xab,0xf0,0x80,0x02,0x90,0xf0,0x83,0x02,0x75,0xf0,0x86,0x02,0x5a,0xf0,0x88,0x02,0x3f,0xf0,0x8b,0x02,0x24,0xf0,0x8e,0x02,0x08,0xf0,0x91,0x02,0xed,0xef,0x93,0x02,0xd1,0xef,0x96,0x02,0xb5,0xef,0x98,0x02,0x99,0xef,0x9a,0x02,0x7d,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0x02,0x7b,0x10,0xc0,0x02,0x5e,0x10,0xbe,0x02,0x42,0x10,0xbb,0x02,0x26,0x10,0xb9,0x02,0x0a,0x10,0xb6,0x02,0xee,0x0f,0xb3,0x02,0xd3,0x0f,0xb0,0x02,0xb7,0x0f,0xae,0x02,0x9c,0x0f,0xab,0x02,0x80,0x0f,0xa8,0x02,0x65,0x0f,0xa4,0x02,0x4a,0x0f,  \
    0xa1,0x02,0x2f,0x0f,0x9e,0x02,0x14,0x0f,0x9b,0x02,0xfa,0x0e,0x97,0x02,0xdf,0x0e,0x94,0x02,0xc5,0x0e,0x90,0x02,0xab,0x0e,0x8d,0x02,0x90,0x0e,0x89,0x02,0x76,0x0e,0x85,0x02,0x5d,0x0e,0x82,0x02,0x43,0x0e,0x7e,0x02,0x29,0x0e,0x7a,0x02,0x10,0x0e,0x76,0x02,0xf7,0x0d,0x72,0x02,0xde,0x0d,0x6e,0x02,0xc5,0x0d,0x6a,0x02,0xac,0x0d,0x65,0x02,0x93,0x0d,0x61,0x02,0x7a,0x0d,0x5d,0x02,0x62,0x0d,0x59,0x02,0x49,0x0d,0x54,0x02,0x31,0x0d,0x50,0x02,0x19,0x0d,0x4b,0x02,  \
    0x01,0x0d,0x47,0x02,0xe9,0x0c,0x42,0x02,0xd1,0x0c,0x3e,0x02,0xb9,0x0c,0x39,0x02,0xa2,0x0c,0x35,0x02,0x8a,0x0c,0x30,0x02,0x73,0x0c,0x2b,0x02,0x5c,0x0c,0x26,0x02,0x45,0x0c,0x21,0x02,0x2e,0x0c,0x1c,0x02,0x18,0x0c,0x18,0x02,0x01,0x0c,0x13,0x02,0xeb,0x0b,0x0e,0x02,0xd4,0x0b,0x09,0x02,0xbe,0x0b,0x04,0x02,0xa8,0x0b,0xff,0x01,0x92,0x0b,0xf9,0x01,0x7c,0x0b,0xf4,0x01,0x67,0x0b,0xef,0x01,0x51,0x0b,0xea,0x01,0x3b,0x0b,0xe5,0x01,0x26,0x0b,0xe0,0x01,0x11,0x0b,  \
    0xdb,0x01,0xfb,0x0a,0xd6,0x01,0xe6,0x0a,0xd1,0x01,0xd0,0x0a,0xcc,0x01,0xbb,0x0a,0xc7,0x01,0xa6,0x0a,0xc2,0x01,0x90,0x0a,0xbd,0x01,0x7b,0x0a,0xb8,0x01,0x66,0x0a,0xb3,0x01,0x51,0x0a,0xae,0x01,0x3c,0x0a,0xa9,0x01,0x28,0x0a,0xa4,0x01,0x13,0x0a,0x9f,0x01,0xfe,0x09,0x9a,0x01,0xea,0x09,0x95,0x01,0xd6,0x09,0x90,0x01,0xc1,0x09,0x8b,0x01,0xad,0x09,0x86,0x01,0x99,0x09,0x81,0x01,0x85,0x09,0x7c,0x01,0x71,0x09,0x77,0x01,0x5d,0x09,0x72,0x01,0x49,0x09,0x6d,0x01,  \
    0x36,0x09,0x68,0x01,0x22,0x09,0x63,0x01,0x0f,0x09,0x5e,0x01,0xfb,0x08,0x59,0x01,0xe8,0x08,0x54,0x01,0xd5,0x08,0x4f,0x01,0xc2,0x08,0x4a,0x01,0xae,0x08,0x45,0x01,0x9b,0x08,0x40,0x01,0x89,0x08,0x3b,0x01,0x76,0x08,0x36,0x01,0x63,0x08,0x31,0x01,0x50,0x08,0x2c,0x01,0x3e,0x08,0x28,0x01,0x2b,0x08,0x22,0x01,0x19,0x08,0x1d,0x01,0x08,0x08,0x18,0x01,0xf6,0x07,0x13,0x01,0xe4,0x07,0x0e,0x01,0xd3,0x07,0x09,0x01,0xc1,0x07,0x04,0x01,0xb0,0x07,0xff,0x00,0x9f,0x07,  \
    0xfa,0x00,0x8d,0x07,0xf5,0x00,0x7c,0x07,0xf1,0x00,0x6b,0x07,0xec,0x00,0x5a,0x07,0xe7,0x00,0x49,0x07,0xe2,0x00,0x38,0x07,0xdd,0x00,0x27,0x07,0xd8,0x00,0x17,0x07,0xd4,0x00,0x06,0x07,0xcf,0x00,0xf5,0x06,0xca,0x00,0xe5,0x06,0xc5,0x00,0xd5,0x06,0xc1,0x00,0xc4,0x06,0xbc,0x00,0xb4,0x06,0xb8,0x00,0xa3,0x06,0xb3,0x00,0x93,0x06,0xae,0x00,0x83,0x06,0xaa,0x00,0x73,0x06,0xa5,0x00,0x63,0x06,0xa1,0x00,0x52,0x06,0x9d,0x00,0x42,0x06,0x98,0x00,0x33,0x06,0x94,0x00,  \
    0x23,0x06,0x8f,0x00,0x13,0x06,0x8b,0x00,0x03,0x06,0x87,0x00,0xf3,0x05,0x83,0x00,0xe4,0x05,0x7e,0x00,0xd4,0x05,0x7a,0x00,0xc5,0x05,0x76,0x00,0xb5,0x05,0x72,0x00,0xa6,0x05,0x6e,0x00,0x96,0x05,0x6a,0x00,0x87,0x05,0x66,0x00,0x78,0x05,0x62,0x00,0x69,0x05,0x5e,0x00,0x59,0x05,0x5a,0x00,0x4a,0x05,0x56,0x00,0x3a,0x05,0x52,0x00,0x2b,0x05,0x4e,0x00,0x1b,0x05,0x4b,0x00,0x0c,0x05,0x47,0x00,0xfd,0x04,0x43,0x00,0xee,0x04,0x40,0x00,0xdf,0x04,0x3c,0x00,0xd0,0x04,  \
    0x38,0x00,0xc0,0x04,0x35,0x00,0xb1,0x04,0x31,0x00,0xa3,0x04,0x2e,0x00,0x94,0x04,0x2a,0x00,0x85,0x04,0x27,0x00,0x76,0x04,0x23,0x00,0x67,0x04,0x20,0x00,0x58,0x04,0x1d,0x00,0x4a,0x04,0x19,0x00,0x3b,0x04,0x16,0x00,0x2d,0x04,0x13,0x00,0x1e,0x04,0x10,0x00,0x0f,0x04,0x0d,0x00,0x01,0x04,0x09,0x00,0xf3,0x03,0x06,0x00,0xe5,0x03,0x03,0x00,0xd7,0x03,0x00,0x00,0xc9,0x03,0xfd,0xff,0xbb,0x03,0xfa,0xff,0xad,0x03,0xf7,0xff,0x9f,0x03,0xf4,0xff,0x91,0x03,0xf1,0xff,  \
    0x83,0x03,0xee,0xff,0x75,0x03,0xec,0xff,0x67,0x03,0xe9,0xff,0x59,0x03,0xe6,0xff,0x4c,0x03,0xe3,0xff,0x3e,0x03,0xe1,0xff,0x30,0x03,0xde,0xff,0x22,0x03,0xdb,0xff,0x15,0x03,0xd9,0xff,0x07,0x03,0xd6,0xff,0xfa,0x02,0xd4,0xff,0xec,0x02,0xd2,0xff,0xde,0x02,0xcf,0xff,0xd1,0x02,0xcd,0xff,0xc3,0x02,0xca,0xff,0xb6,0x02,0xc8,0xff,0xa9,0x02,0xc6,0xff,0x9b,0x02,0xc4,0xff,0x8e,0x02,0xc1,0xff,0x81,0x02,0xbf,0xff,0x74,0x02,0xbd,0xff,0x67,0x02,0xbb,0xff,0x5a,0x02,  \
    0xb9,0xff,0x4d,0x02,0xb7,0xff,0x3f,0x02,0xb5,0xff,0x32,0x02,0xb3,0xff,0x25,0x02,0xb1,0xff,0x18,0x02,0xaf,0xff,0x0b,0x02,0xae,0xff,0xfe,0x01,0xac,0xff,0xf1,0x01,0xaa,0xff,0xe4,0x01,0xa9,0xff,0xd7,0x01,0xa7,0xff,0xcb,0x01,0xa5,0xff,0xbe,0x01,0xa4,0xff,0xb1,0x01,0xa2,0xff,0xa4,0x01,0xa1,0xff,0x97,0x01,0x9f,0xff,0x8a,0x01,0x9e,0xff,0x7d,0x01,0x9d,0xff,0x70,0x01,0x9b,0xff,0x63,0x01,0x9a,0xff,0x56,0x01,0x99,0xff,0x49,0x01,0x98,0xff,0x3c,0x01,0x97,0xff,  \
    0x2f,0x01,0x95,0xff,0x22,0x01,0x94,0xff,0x15,0x01,0x93,0xff,0x08,0x01,0x92,0xff,0xfb,0x00,0x91,0xff,0xef,0x00,0x91,0xff,0xe2,0x00,0x90,0xff,0xd5,0x00,0x8f,0xff,0xc8,0x00,0x8e,0xff,0xbb,0x00,0x8d,0xff,0xae,0x00,0x8d,0xff,0xa1,0x00,0x8c,0xff,0x94,0x00,0x8b,0xff,0x87,0x00,0x8b,0xff,0x7a,0x00,0x8a,0xff,0x6d,0x00,0x8a,0xff,0x60,0x00,0x89,0xff,0x53,0x00,0x89,0xff,0x47,0x00,0x88,0xff,0x3a,0x00,0x88,0xff,0x2d,0x00,0x88,0xff,0x20,0x00,0x87,0xff,0x13,0x00,  \
    0x87,0xff,0x06,0x00,0x87,0xff,0xf9,0xff,0x87,0xff,0xed,0xff,0x87,0xff,0xe0,0xff,0x87,0xff,0xd3,0xff,0x87,0xff,0xc6,0xff,0x87,0xff,0xb9,0xff,0x87,0xff,0xac,0xff,0x87,0xff,0xa0,0xff,0x87,0xff,0x93,0xff,0x87,0xff,0x86,0xff,0x87,0xff,0x79,0xff,0x87,0xff,0x6c,0xff,0x88,0xff,0x5f,0xff,0x88,0xff,0x52,0xff,0x88,0xff,0x46,0xff,0x89,0xff,0x39,0xff,0x89,0xff,0x2c,0xff,0x8a,0xff,0x1f,0xff,0x8a,0xff,0x12,0xff,0x8b,0xff,0x05,0xff,0x8b,0xff,0xf8,0xfe,0x8c,0xff,  \
    0xec,0xfe,0x8d,0xff,0xdf,0xfe,0x8d,0xff,0xd2,0xfe,0x8e,0xff,0xc5,0xfe,0x8f,0xff,0xb8,0xfe,0x90,0xff,0xab,0xfe,0x91,0xff,0x9e,0xfe,0x91,0xff,0x91,0xfe,0x92,0xff,0x84,0xfe,0x93,0xff,0x77,0xfe,0x94,0xff,0x6a,0xfe,0x95,0xff,0x5d,0xfe,0x96,0xff,0x50,0xfe,0x98,0xff,0x43,0xfe,0x99,0xff,0x36,0xfe,0x9a,0xff,0x29,0xfe,0x9b,0xff,0x1c,0xfe,0x9c,0xff,0x0f,0xfe,0x9e,0xff,0x02,0xfe,0x9f,0xff,0xf5,0xfd,0xa0,0xff,0xe7,0xfd,0xa2,0xff,0xda,0xfd,0xa3,0xff,0xcd,0xfd,  \
    0xa5,0xff,0xc0,0xfd,0xa6,0xff,0xb3,0xfd,0xa8,0xff,0xa5,0xfd,0xa9,0xff,0x98,0xfd,0xab,0xff,0x8b,0xfd,0xad,0xff,0x7d,0xfd,0xae,0xff,0x70,0xfd,0xb0,0xff,0x63,0xfd,0xb2,0xff,0x55,0xfd,0xb4,0xff,0x48,0xfd,0xb6,0xff,0x3b,0xfd,0xb8,0xff,0x2d,0xfd,0xb9,0xff,0x20,0xfd,0xbb,0xff,0x12,0xfd,0xbd,0xff,0x05,0xfd,0xbf,0xff,0xf7,0xfc,0xc2,0xff,0xea,0xfc,0xc4,0xff,0xdc,0xfc,0xc6,0xff,0xcf,0xfc,0xc8,0xff,0xc1,0xfc,0xca,0xff,0xb4,0xfc,0xcd,0xff,0xa7,0xfc,0xcf,0xff,  \
    0x99,0xfc,0xd1,0xff,0x8c,0xfc,0xd4,0xff,0x7e,0xfc,0xd6,0xff,0x70,0xfc,0xd9,0xff,0x63,0xfc,0xdb,0xff,0x55,0xfc,0xde,0xff,0x48,0xfc,0xe0,0xff,0x3a,0xfc,0xe3,0xff,0x2c,0xfc,0xe6,0xff,0x1f,0xfc,0xe8,0xff,0x11,0xfc,0xeb,0xff,0x03,0xfc,0xee,0xff,0xf5,0xfb,0xf1,0xff,0xe7,0xfb,0xf3,0xff,0xda,0xfb,0xf6,0xff,0xcc,0xfb,0xf9,0xff,0xbe,0xfb,0xfc,0xff,0xb0,0xfb,0xff,0xff,0xa2,0xfb,0x02,0x00,0x94,0xfb,0x05,0x00,0x86,0xfb,0x08,0x00,0x77,0xfb,0x0b,0x00,0x69,0xfb,  \
    0x0e,0x00,0x5b,0xfb,0x12,0x00,0x4c,0xfb,0x15,0x00,0x3e,0xfb,0x18,0x00,0x30,0xfb,0x1b,0x00,0x21,0xfb,0x1f,0x00,0x13,0xfb,0x22,0x00,0x04,0xfb,0x25,0x00,0xf5,0xfa,0x29,0x00,0xe7,0xfa,0x2c,0x00,0xd8,0xfa,0x30,0x00,0xc9,0xfa,0x33,0x00,0xbb,0xfa,0x37,0x00,0xac,0xfa,0x3a,0x00,0x9d,0xfa,0x3e,0x00,0x8e,0xfa,0x41,0x00,0x7f,0xfa,0x45,0x00,0x70,0xfa,0x49,0x00,0x61,0xfa,0x4c,0x00,0x52,0xfa,0x50,0x00,0x43,0xfa,0x54,0x00,0x33,0xfa,0x58,0x00,0x24,0xfa,0x5c,0x00,  \
    0x15,0xfa,0x5f,0x00,0x06,0xfa,0x63,0x00,0xf7,0xf9,0x67,0x00,0xe7,0xf9,0x6b,0x00,0xd8,0xf9,0x6f,0x00,0xc8,0xf9,0x73,0x00,0xb9,0xf9,0x77,0x00,0xa9,0xf9,0x7b,0x00,0x9a,0xf9,0x80,0x00,0x8a,0xf9,0x84,0x00,0x7a,0xf9,0x88,0x00,0x6b,0xf9,0x8c,0x00,0x5b,0xf9,0x90,0x00,0x4b,0xf9,0x95,0x00,0x3b,0xf9,0x99,0x00,0x2b,0xf9,0x9d,0x00,0x1b,0xf9,0xa2,0x00,0x0b,0xf9,0xa6,0x00,0xfb,0xf8,0xaa,0x00,0xea,0xf8,0xaf,0x00,0xda,0xf8,0xb3,0x00,0xca,0xf8,0xb8,0x00,0xb9,0xf8,  \
    0xbc,0x00,0xa9,0xf8,0xc1,0x00,0x98,0xf8,0xc5,0x00,0x87,0xf8,0xc9,0x00,0x76,0xf8,0xce,0x00,0x66,0xf8,0xd3,0x00,0x55,0xf8,0xd7,0x00,0x44,0xf8,0xdc,0x00,0x32,0xf8,0xe0,0x00,0x21,0xf8,0xe5,0x00,0x10,0xf8,0xea,0x00,0xff,0xf7,0xee,0x00,0xed,0xf7,0xf3,0x00,0xdc,0xf7,0xf8,0x00,0xca,0xf7,0xfc,0x00,0xb9,0xf7,0x01,0x01,0xa7,0xf7,0x06,0x01,0x95,0xf7,0x0b,0x01,0x83,0xf7,0x0f,0x01,0x71,0xf7,0x14,0x01,0x5f,0xf7,0x19,0x01,0x4d,0xf7,0x1e,0x01,0x3b,0xf7,0x23,0x01,  \
    0x29,0xf7,0x28,0x01,0x17,0xf7,0x2c,0x01,0x04,0xf7,0x31,0x01,0xf2,0xf6,0x36,0x01,0xe0,0xf6,0x3b,0x01,0xcd,0xf6,0x40,0x01,0xba,0xf6,0x45,0x01,0xa8,0xf6,0x4a,0x01,0x95,0xf6,0x4f,0x01,0x82,0xf6,0x54,0x01,0x6f,0xf6,0x59,0x01,0x5c,0xf6,0x5e,0x01,0x49,0xf6,0x63,0x01,0x35,0xf6,0x68,0x01,0x22,0xf6,0x6d,0x01,0x0e,0xf6,0x72,0x01,0xfb,0xf5,0x77,0x01,0xe7,0xf5,0x7c,0x01,0xd3,0xf5,0x80,0x01,0xbf,0xf5,0x85,0x01,0xab,0xf5,0x8a,0x01,0x97,0xf5,0x8f,0x01,0x82,0xf5,  \
    0x94,0x01,0x6e,0xf5,0x98,0x01,0x59,0xf5,0x9d,0x01,0x44,0xf5,0xa2,0x01,0x2f,0xf5,0xa7,0x01,0x1a,0xf5,0xac,0x01,0x05,0xf5,0xb0,0x01,0xf0,0xf4,0xb5,0x01,0xdb,0xf4,0xba,0x01,0xc6,0xf4,0xbf,0x01,0xb0,0xf4,0xc3,0x01,0x9a,0xf4,0xc8,0x01,0x85,0xf4,0xcd,0x01,0x6f,0xf4,0xd1,0x01,0x59,0xf4,0xd6,0x01,0x43,0xf4,0xdb,0x01,0x2d,0xf4,0xe0,0x01,0x17,0xf4,0xe4,0x01,0x01,0xf4,0xe9,0x01,0xeb,0xf3,0xee,0x01,0xd5,0xf3,0xf2,0x01,0xbf,0xf3,0xf7,0x01,0xa8,0xf3,0xfb,0x01,  \
    0x91,0xf3,0x00,0x02,0x7b,0xf3,0x05,0x02,0x64,0xf3,0x09,0x02,0x4d,0xf3,0x0d,0x02,0x36,0xf3,0x12,0x02,0x1e,0xf3,0x16,0x02,0x07,0xf3,0x1b,0x02,0xf0,0xf2,0x1f,0x02,0xd8,0xf2,0x23,0x02,0xc0,0xf2,0x27,0x02,0xa8,0xf2,0x2c,0x02,0x90,0xf2,0x30,0x02,0x78,0xf2,0x34,0x02,0x60,0xf2,0x38,0x02,0x48,0xf2,0x3c,0x02,0x2f,0xf2,0x40,0x02,0x17,0xf2,0x44,0x02,0xfe,0xf1,0x48,0x02,0xe5,0xf1,0x4c,0x02,0xcc,0xf1,0x50,0x02,0xb3,0xf1,0x53,0x02,0x9a,0xf1,0x57,0x02,0x81,0xf1,  \
    0x5b,0x02,0x67,0xf1,0x5e,0x02,0x4d,0xf1,0x62,0x02,0x34,0xf1,0x65,0x02,0x1a,0xf1,0x68,0x02,0x00,0xf1,0x6c,0x02,0xe5,0xf0,0x6f,0x02,0xcb,0xf0,0x72,0x02,0xb1,0xf0,0x75,0x02,0x96,0xf0,0x78,0x02,0x7b,0xf0,0x7b,0x02,0x60,0xf0,0x7e,0x02,0x45,0xf0,0x81,0x02,0x29,0xf0,0x83,0x02,0x0e,0xf0,0x86,0x02,0xf2,0xef,0x88,0x02,0xd7,0xef,0x8b,0x02,0xbb,0xef,0x8d,0x02,0x9f,0xef,0x90,0x02,0x82,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xb7,0x02,0x76,0x10,0xb5,0x02,0x5a,0x10,0xb2,0x02,0x3d,0x10,0xb0,0x02,0x21,0x10,0xad,0x02,0x05,0x10,0xaa,0x02,0xea,0x0f,0xa8,0x02,0xce,0x0f,0xa5,0x02,0xb2,0x0f,0xa2,0x02,0x97,0x0f,0x9f,0x02,0x7c,0x0f,0x9c,0x02,0x60,0x0f,  \
    0x99,0x02,0x45,0x0f,0x96,0x02,0x2a,0x0f,0x93,0x02,0x10,0x0f,0x8f,0x02,0xf5,0x0e,0x8c,0x02,0xda,0x0e,0x89,0x02,0xc0,0x0e,0x85,0x02,0xa6,0x0e,0x82,0x02,0x8c,0x0e,0x7e,0x02,0x72,0x0e,0x7a,0x02,0x58,0x0e,0x77,0x02,0x3e,0x0e,0x73,0x02,0x24,0x0e,0x6f,0x02,0x0b,0x0e,0x6b,0x02,0xf2,0x0d,0x67,0x02,0xd9,0x0d,0x63,0x02,0xc0,0x0d,0x5f,0x02,0xa7,0x0d,0x5b,0x02,0x8e,0x0d,0x57,0x02,0x75,0x0d,0x53,0x02,0x5d,0x0d,0x4e,0x02,0x44,0x0d,0x4a,0x02,0x2c,0x0d,0x46,0x02,  \
    0x14,0x0d,0x41,0x02,0xfc,0x0c,0x3d,0x02,0xe4,0x0c,0x39,0x02,0xcc,0x0c,0x34,0x02,0xb4,0x0c,0x30,0x02,0x9c,0x0c,0x2b,0x02,0x85,0x0c,0x26,0x02,0x6e,0x0c,0x22,0x02,0x57,0x0c,0x1d,0x02,0x40,0x0c,0x18,0x02,0x29,0x0c,0x13,0x02,0x12,0x0c,0x0f,0x02,0xfc,0x0b,0x0a,0x02,0xe5,0x0b,0x05,0x02,0xcf,0x0b,0x00,0x02,0xb8,0x0b,0xfb,0x01,0xa2,0x0b,0xf6,0x01,0x8c,0x0b,0xf1,0x01,0x76,0x0b,0xec,0x01,0x61,0x0b,0xe7,0x01,0x4b,0x0b,0xe2,0x01,0x35,0x0b,0xdd,0x01,0x20,0x0b,  \
    0xd8,0x01,0x0b,0x0b,0xd3,0x01,0xf5,0x0a,0xce,0x01,0xe0,0x0a,0xc9,0x01,0xca,0x0a,0xc4,0x01,0xb5,0x0a,0xbf,0x01,0x9f,0x0a,0xbb,0x01,0x8a,0x0a,0xb6,0x01,0x75,0x0a,0xb1,0x01,0x60,0x0a,0xac,0x01,0x4b,0x0a,0xa7,0x01,0x36,0x0a,0xa2,0x01,0x21,0x0a,0x9d,0x01,0x0d,0x0a,0x98,0x01,0xf8,0x09,0x93,0x01,0xe4,0x09,0x8e,0x01,0xcf,0x09,0x89,0x01,0xbb,0x09,0x84,0x01,0xa7,0x09,0x7f,0x01,0x93,0x09,0x7a,0x01,0x7f,0x09,0x75,0x01,0x6b,0x09,0x71,0x01,0x57,0x09,0x6c,0x01,  \
    0x43,0x09,0x67,0x01,0x30,0x09,0x62,0x01,0x1c,0x09,0x5d,0x01,0x08,0x09,0x58,0x01,0xf5,0x08,0x53,0x01,0xe2,0x08,0x4e,0x01,0xce,0x08,0x49,0x01,0xbb,0x08,0x44,0x01,0xa8,0x08,0x3f,0x01,0x95,0x08,0x3b,0x01,0x82,0x08,0x36,0x01,0x6f,0x08,0x31,0x01,0x5d,0x08,0x2c,0x01,0x4a,0x08,0x27,0x01,0x37,0x08,0x22,0x01,0x25,0x08,0x1d,0x01,0x13,0x08,0x18,0x01,0x01,0x08,0x13,0x01,0xf0,0x07,0x0e,0x01,0xde,0x07,0x09,0x01,0xcc,0x07,0x05,0x01,0xbb,0x07,0x00,0x01,0xaa,0x07,  \
    0xfb,0x00,0x98,0x07,0xf6,0x00,0x87,0x07,0xf1,0x00,0x76,0x07,0xec,0x00,0x65,0x07,0xe7,0x00,0x54,0x07,0xe3,0x00,0x43,0x07,0xde,0x00,0x32,0x07,0xd9,0x00,0x21,0x07,0xd4,0x00,0x10,0x07,0xd0,0x00,0x00,0x07,0xcb,0x00,0xef,0x06,0xc6,0x00,0xdf,0x06,0xc2,0x00,0xce,0x06,0xbd,0x00,0xbe,0x06,0xb9,0x00,0xad,0x06,0xb4,0x00,0x9d,0x06,0xaf,0x00,0x8d,0x06,0xab,0x00,0x7c,0x06,0xa7,0x00,0x6c,0x06,0xa2,0x00,0x5c,0x06,0x9e,0x00,0x4c,0x06,0x99,0x00,0x3c,0x06,0x95,0x00,  \
    0x2c,0x06,0x91,0x00,0x1c,0x06,0x8c,0x00,0x0d,0x06,0x88,0x00,0xfd,0x05,0x84,0x00,0xed,0x05,0x80,0x00,0xde,0x05,0x7b,0x00,0xce,0x05,0x77,0x00,0xbe,0x05,0x73,0x00,0xaf,0x05,0x6f,0x00,0xa0,0x05,0x6b,0x00,0x90,0x05,0x67,0x00,0x81,0x05,0x63,0x00,0x72,0x05,0x5f,0x00,0x62,0x05,0x5b,0x00,0x53,0x05,0x57,0x00,0x44,0x05,0x54,0x00,0x34,0x05,0x50,0x00,0x25,0x05,0x4c,0x00,0x15,0x05,0x48,0x00,0x06,0x05,0x45,0x00,0xf7,0x04,0x41,0x00,0xe8,0x04,0x3d,0x00,0xd9,0x04,  \
    0x3a,0x00,0xca,0x04,0x36,0x00,0xbb,0x04,0x33,0x00,0xac,0x04,0x2f,0x00,0x9d,0x04,0x2c,0x00,0x8e,0x04,0x28,0x00,0x7f,0x04,0x25,0x00,0x70,0x04,0x22,0x00,0x62,0x04,0x1e,0x00,0x53,0x04,0x1b,0x00,0x44,0x04,0x18,0x00,0x36,0x04,0x15,0x00,0x27,0x04,0x11,0x00,0x19,0x04,0x0e,0x00,0x0a,0x04,0x0b,0x00,0xfc,0x03,0x08,0x00,0xee,0x03,0x05,0x00,0xe0,0x03,0x02,0x00,0xd2,0x03,0xff,0xff,0xc4,0x03,0xfc,0xff,0xb6,0x03,0xf9,0xff,0xa8,0x03,0xf6,0xff,0x9a,0x03,0xf3,0xff,  \
    0x8c,0x03,0xf0,0xff,0x7e,0x03,0xed,0xff,0x70,0x03,0xea,0xff,0x62,0x03,0xe8,0xff,0x55,0x03,0xe5,0xff,0x47,0x03,0xe2,0xff,0x39,0x03,0xe0,0xff,0x2c,0x03,0xdd,0xff,0x1e,0x03,0xdb,0xff,0x10,0x03,0xd8,0xff,0x03,0x03,0xd6,0xff,0xf5,0x02,0xd3,0xff,0xe8,0x02,0xd1,0xff,0xda,0x02,0xce,0xff,0xcd,0x02,0xcc,0xff,0xbf,0x02,0xca,0xff,0xb2,0x02,0xc7,0xff,0xa5,0x02,0xc5,0xff,0x97,0x02,0xc3,0xff,0x8a,0x02,0xc1,0xff,0x7d,0x02,0xbf,0xff,0x70,0x02,0xbd,0xff,0x63,0x02,  \
    0xba,0xff,0x56,0x02,0xb8,0xff,0x49,0x02,0xb6,0xff,0x3c,0x02,0xb5,0xff,0x2f,0x02,0xb3,0xff,0x22,0x02,0xb1,0xff,0x15,0x02,0xaf,0xff,0x08,0x02,0xad,0xff,0xfb,0x01,0xab,0xff,0xee,0x01,0xaa,0xff,0xe1,0x01,0xa8,0xff,0xd4,0x01,0xa7,0xff,0xc8,0x01,0xa5,0xff,0xbb,0x01,0xa3,0xff,0xae,0x01,0xa2,0xff,0xa1,0x01,0xa0,0xff,0x94,0x01,0x9f,0xff,0x87,0x01,0x9e,0xff,0x7a,0x01,0x9c,0xff,0x6e,0x01,0x9b,0xff,0x61,0x01,0x9a,0xff,0x54,0x01,0x99,0xff,0x47,0x01,0x97,0xff,  \
    0x3a,0x01,0x96,0xff,0x2d,0x01,0x95,0xff,0x20,0x01,0x94,0xff,0x13,0x01,0x93,0xff,0x06,0x01,0x92,0xff,0xfa,0x00,0x91,0xff,0xed,0x00,0x90,0xff,0xe0,0x00,0x8f,0xff,0xd3,0x00,0x8f,0xff,0xc6,0x00,0x8e,0xff,0xb9,0x00,0x8d,0xff,0xac,0x00,0x8c,0xff,0xa0,0x00,0x8c,0xff,0x93,0x00,0x8b,0xff,0x86,0x00,0x8b,0xff,0x79,0x00,0x8a,0xff,0x6c,0x00,0x8a,0xff,0x5f,0x00,0x89,0xff,0x53,0x00,0x89,0xff,0x46,0x00,0x88,0xff,0x39,0x00,0x88,0xff,0x2c,0x00,0x88,0xff,0x1f,0x00,  \
    0x87,0xff,0x13,0x00,0x87,0xff,0x06,0x00,0x87,0xff,0xf9,0xff,0x87,0xff,0xec,0xff,0x87,0xff,0xe0,0xff,0x87,0xff,0xd3,0xff,0x87,0xff,0xc6,0xff,0x87,0xff,0xb9,0xff,0x87,0xff,0xac,0xff,0x87,0xff,0xa0,0xff,0x87,0xff,0x93,0xff,0x87,0xff,0x86,0xff,0x87,0xff,0x79,0xff,0x87,0xff,0x6d,0xff,0x88,0xff,0x60,0xff,0x88,0xff,0x53,0xff,0x88,0xff,0x46,0xff,0x89,0xff,0x3a,0xff,0x89,0xff,0x2d,0xff,0x8a,0xff,0x20,0xff,0x8a,0xff,0x13,0xff,0x8b,0xff,0x06,0xff,0x8b,0xff,  \
    0xfa,0xfe,0x8c,0xff,0xed,0xfe,0x8c,0xff,0xe0,0xfe,0x8d,0xff,0xd3,0xfe,0x8e,0xff,0xc6,0xfe,0x8f,0xff,0xba,0xfe,0x8f,0xff,0xad,0xfe,0x90,0xff,0xa0,0xfe,0x91,0xff,0x93,0xfe,0x92,0xff,0x86,0xfe,0x93,0xff,0x79,0xfe,0x94,0xff,0x6c,0xfe,0x95,0xff,0x60,0xfe,0x96,0xff,0x53,0xfe,0x97,0xff,0x46,0xfe,0x98,0xff,0x39,0xfe,0x9a,0xff,0x2c,0xfe,0x9b,0xff,0x1f,0xfe,0x9c,0xff,0x12,0xfe,0x9d,0xff,0x04,0xfe,0x9f,0xff,0xf7,0xfd,0xa0,0xff,0xea,0xfd,0xa1,0xff,0xdd,0xfd,  \
    0xa3,0xff,0xd0,0xfd,0xa4,0xff,0xc3,0xfd,0xa6,0xff,0xb6,0xfd,0xa7,0xff,0xa9,0xfd,0xa9,0xff,0x9b,0xfd,0xab,0xff,0x8e,0xfd,0xac,0xff,0x81,0xfd,0xae,0xff,0x74,0xfd,0xb0,0xff,0x66,0xfd,0xb1,0xff,0x59,0xfd,0xb3,0xff,0x4c,0xfd,0xb5,0xff,0x3e,0xfd,0xb7,0xff,0x31,0xfd,0xb9,0xff,0x24,0xfd,0xbb,0xff,0x16,0xfd,0xbd,0xff,0x09,0xfd,0xbf,0xff,0xfb,0xfc,0xc1,0xff,0xee,0xfc,0xc3,0xff,0xe1,0xfc,0xc5,0xff,0xd3,0xfc,0xc7,0xff,0xc6,0xfc,0xca,0xff,0xb8,0xfc,0xcc,0xff,  \
    0xab,0xfc,0xce,0xff,0x9e,0xfc,0xd1,0xff,0x90,0xfc,0xd3,0xff,0x83,0xfc,0xd5,0xff,0x75,0xfc,0xd8,0xff,0x68,0xfc,0xda,0xff,0x5a,0xfc,0xdd,0xff,0x4d,0xfc,0xdf,0xff,0x3f,0xfc,0xe2,0xff,0x31,0xfc,0xe5,0xff,0x24,0xfc,0xe7,0xff,0x16,0xfc,0xea,0xff,0x08,0xfc,0xed,0xff,0xfa,0xfb,0xef,0xff,0xed,0xfb,0xf2,0xff,0xdf,0xfb,0xf5,0xff,0xd1,0xfb,0xf8,0xff,0xc3,0xfb,0xfb,0xff,0xb5,0xfb,0xfe,0xff,0xa7,0xfb,0x01,0x00,0x99,0xfb,0x04,0x00,0x8b,0xfb,0x07,0x00,0x7d,0xfb,  \
    0x0a,0x00,0x6f,0xfb,0x0d,0x00,0x61,0xfb,0x10,0x00,0x52,0xfb,0x13,0x00,0x44,0xfb,0x16,0x00,0x35,0xfb,0x1a,0x00,0x27,0xfb,0x1d,0x00,0x19,0xfb,0x20,0x00,0x0a,0xfb,0x24,0x00,0xfb,0xfa,0x27,0x00,0xed,0xfa,0x2a,0x00,0xde,0xfa,0x2e,0x00,0xcf,0xfa,0x31,0x00,0xc1,0xfa,0x35,0x00,0xb2,0xfa,0x38,0x00,0xa3,0xfa,0x3c,0x00,0x94,0xfa,0x3f,0x00,0x85,0xfa,0x43,0x00,0x76,0xfa,0x47,0x00,0x67,0xfa,0x4a,0x00,0x58,0xfa,0x4e,0x00,0x49,0xfa,0x52,0x00,0x3a,0xfa,0x55,0x00,  \
    0x2b,0xfa,0x59,0x00,0x1c,0xfa,0x5d,0x00,0x0c,0xfa,0x61,0x00,0xfd,0xf9,0x65,0x00,0xee,0xf9,0x69,0x00,0xde,0xf9,0x6d,0x00,0xcf,0xf9,0x71,0x00,0xc0,0xf9,0x75,0x00,0xb0,0xf9,0x79,0x00,0xa1,0xf9,0x7d,0x00,0x91,0xf9,0x81,0x00,0x81,0xf9,0x85,0x00,0x71,0xf9,0x89,0x00,0x62,0xf9,0x8d,0x00,0x52,0xf9,0x92,0x00,0x42,0xf9,0x96,0x00,0x32,0xf9,0x9a,0x00,0x22,0xf9,0x9e,0x00,0x12,0xf9,0xa3,0x00,0x02,0xf9,0xa7,0x00,0xf1,0xf8,0xab,0x00,0xe1,0xf8,0xb0,0x00,0xd1,0xf8,  \
    0xb4,0x00,0xc0,0xf8,0xb8,0x00,0xb0,0xf8,0xbd,0x00,0x9f,0xf8,0xc1,0x00,0x8e,0xf8,0xc6,0x00,0x7d,0xf8,0xca,0x00,0x6d,0xf8,0xcf,0x00,0x5c,0xf8,0xd3,0x00,0x4b,0xf8,0xd8,0x00,0x39,0xf8,0xdc,0x00,0x28,0xf8,0xe1,0x00,0x17,0xf8,0xe5,0x00,0x06,0xf8,0xea,0x00,0xf4,0xf7,0xef,0x00,0xe3,0xf7,0xf3,0x00,0xd1,0xf7,0xf8,0x00,0xc0,0xf7,0xfd,0x00,0xae,0xf7,0x01,0x01,0x9c,0xf7,0x06,0x01,0x8a,0xf7,0x0b,0x01,0x78,0xf7,0x0f,0x01,0x66,0xf7,0x14,0x01,0x54,0xf7,0x19,0x01,  \
    0x42,0xf7,0x1e,0x01,0x30,0xf7,0x23,0x01,0x1e,0xf7,0x27,0x01,0x0b,0xf7,0x2c,0x01,0xf9,0xf6,0x31,0x01,0xe7,0xf6,0x36,0x01,0xd4,0xf6,0x3b,0x01,0xc1,0xf6,0x40,0x01,0xaf,0xf6,0x44,0x01,0x9c,0xf6,0x49,0x01,0x89,0xf6,0x4e,0x01,0x76,0xf6,0x53,0x01,0x63,0xf6,0x58,0x01,0x4f,0xf6,0x5d,0x01,0x3c,0xf6,0x62,0x01,0x29,0xf6,0x67,0x01,0x15,0xf6,0x6c,0x01,0x02,0xf6,0x70,0x01,0xee,0xf5,0x75,0x01,0xda,0xf5,0x7a,0x01,0xc6,0xf5,0x7f,0x01,0xb2,0xf5,0x84,0x01,0x9d,0xf5,  \
    0x88,0x01,0x89,0xf5,0x8d,0x01,0x74,0xf5,0x92,0x01,0x60,0xf5,0x97,0x01,0x4b,0xf5,0x9b,0x01,0x36,0xf5,0xa0,0x01,0x21,0xf5,0xa5,0x01,0x0c,0xf5,0xa9,0x01,0xf7,0xf4,0xae,0x01,0xe2,0xf4,0xb3,0x01,0xcc,0xf4,0xb7,0x01,0xb7,0xf4,0xbc,0x01,0xa1,0xf4,0xc1,0x01,0x8b,0xf4,0xc5,0x01,0x76,0xf4,0xca,0x01,0x60,0xf4,0xce,0x01,0x4a,0xf4,0xd3,0x01,0x34,0xf4,0xd8,0x01,0x1e,0xf4,0xdc,0x01,0x08,0xf4,0xe1,0x01,0xf2,0xf3,0xe6,0x01,0xdb,0xf3,0xea,0x01,0xc5,0xf3,0xef,0x01,  \
    0xae,0xf3,0xf3,0x01,0x98,0xf3,0xf8,0x01,0x81,0xf3,0xfc,0x01,0x6a,0xf3,0x01,0x02,0x53,0xf3,0x05,0x02,0x3c,0xf3,0x09,0x02,0x25,0xf3,0x0e,0x02,0x0d,0xf3,0x12,0x02,0xf6,0xf2,0x16,0x02,0xde,0xf2,0x1a,0x02,0xc6,0xf2,0x1f,0x02,0xae,0xf2,0x23,0x02,0x96,0xf2,0x27,0x02,0x7e,0xf2,0x2b,0x02,0x66,0xf2,0x2f,0x02,0x4e,0xf2,0x33,0x02,0x35,0xf2,0x37,0x02,0x1d,0xf2,0x3b,0x02,0x04,0xf2,0x3e,0x02,0xeb,0xf1,0x42,0x02,0xd2,0xf1,0x46,0x02,0xb9,0xf1,0x4a,0x02,0xa0,0xf1,  \
    0x4d,0x02,0x86,0xf1,0x51,0x02,0x6d,0xf1,0x54,0x02,0x53,0xf1,0x58,0x02,0x39,0xf1,0x5b,0x02,0x1f,0xf1,0x5e,0x02,0x05,0xf1,0x62,0x02,0xeb,0xf0,0x65,0x02,0xd1,0xf0,0x68,0x02,0xb6,0xf0,0x6b,0x02,0x9b,0xf0,0x6e,0x02,0x80,0xf0,0x71,0x02,0x65,0xf0,0x73,0x02,0x4a,0xf0,0x76,0x02,0x2f,0xf0,0x79,0x02,0x13,0xf0,0x7b,0x02,0xf8,0xef,0x7e,0x02,0xdc,0xef,0x80,0x02,0xc0,0xef,0x83,0x02,0xa4,0xef,0x85,0x02,0x88,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xab,0x02,0x72,0x10,0xa9,0x02,0x55,0x10,0xa6,0x02,0x39,0x10,0xa4,0x02,0x1d,0x10,0xa1,0x02,0x01,0x10,0x9f,0x02,0xe5,0x0f,0x9c,0x02,0xc9,0x0f,0x99,0x02,0xae,0x0f,0x96,0x02,0x92,0x0f,0x93,0x02,0x77,0x0f,  \
    0x91,0x02,0x5c,0x0f,0x8e,0x02,0x41,0x0f,0x8a,0x02,0x26,0x0f,0x87,0x02,0x0b,0x0f,0x84,0x02,0xf0,0x0e,0x81,0x02,0xd6,0x0e,0x7d,0x02,0xbb,0x0e,0x7a,0x02,0xa1,0x0e,0x77,0x02,0x87,0x0e,0x73,0x02,0x6d,0x0e,0x70,0x02,0x53,0x0e,0x6c,0x02,0x39,0x0e,0x68,0x02,0x20,0x0e,0x64,0x02,0x06,0x0e,0x61,0x02,0xed,0x0d,0x5d,0x02,0xd4,0x0d,0x59,0x02,0xbb,0x0d,0x55,0x02,0xa2,0x0d,0x51,0x02,0x89,0x0d,0x4d,0x02,0x70,0x0d,0x49,0x02,0x58,0x0d,0x44,0x02,0x3f,0x0d,0x40,0x02,  \
    0x27,0x0d,0x3c,0x02,0x0f,0x0d,0x38,0x02,0xf6,0x0c,0x33,0x02,0xde,0x0c,0x2f,0x02,0xc7,0x0c,0x2b,0x02,0xaf,0x0c,0x26,0x02,0x97,0x0c,0x22,0x02,0x80,0x0c,0x1d,0x02,0x68,0x0c,0x19,0x02,0x51,0x0c,0x14,0x02,0x3a,0x0c,0x0f,0x02,0x23,0x0c,0x0a,0x02,0x0d,0x0c,0x06,0x02,0xf6,0x0b,0x01,0x02,0xe0,0x0b,0xfc,0x01,0xc9,0x0b,0xf7,0x01,0xb3,0x0b,0xf3,0x01,0x9d,0x0b,0xee,0x01,0x87,0x0b,0xe9,0x01,0x71,0x0b,0xe4,0x01,0x5b,0x0b,0xdf,0x01,0x45,0x0b,0xda,0x01,0x30,0x0b,  \
    0xd5,0x01,0x1a,0x0b,0xd0,0x01,0x05,0x0b,0xcb,0x01,0xf0,0x0a,0xc6,0x01,0xda,0x0a,0xc2,0x01,0xc4,0x0a,0xbd,0x01,0xaf,0x0a,0xb8,0x01,0x99,0x0a,0xb3,0x01,0x84,0x0a,0xae,0x01,0x6f,0x0a,0xa9,0x01,0x5a,0x0a,0xa5,0x01,0x45,0x0a,0xa0,0x01,0x30,0x0a,0x9b,0x01,0x1b,0x0a,0x96,0x01,0x07,0x0a,0x91,0x01,0xf2,0x09,0x8c,0x01,0xde,0x09,0x87,0x01,0xc9,0x09,0x83,0x01,0xb5,0x09,0x7e,0x01,0xa1,0x09,0x79,0x01,0x8d,0x09,0x74,0x01,0x79,0x09,0x6f,0x01,0x65,0x09,0x6a,0x01,  \
    0x51,0x09,0x65,0x01,0x3d,0x09,0x61,0x01,0x29,0x09,0x5c,0x01,0x16,0x09,0x57,0x01,0x02,0x09,0x52,0x01,0xef,0x08,0x4d,0x01,0xdc,0x08,0x48,0x01,0xc8,0x08,0x43,0x01,0xb5,0x08,0x3f,0x01,0xa2,0x08,0x3a,0x01,0x8f,0x08,0x35,0x01,0x7c,0x08,0x30,0x01,0x69,0x08,0x2b,0x01,0x57,0x08,0x27,0x01,0x44,0x08,0x22,0x01,0x31,0x08,0x1d,0x01,0x1f,0x08,0x18,0x01,0x0d,0x08,0x13,0x01,0xfb,0x07,0x0e,0x01,0xea,0x07,0x0a,0x01,0xd8,0x07,0x05,0x01,0xc6,0x07,0x00,0x01,0xb5,0x07,  \
    0xfb,0x00,0xa3,0x07,0xf6,0x00,0x92,0x07,0xf1,0x00,0x81,0x07,0xed,0x00,0x70,0x07,0xe8,0x00,0x5f,0x07,0xe3,0x00,0x4d,0x07,0xde,0x00,0x3d,0x07,0xda,0x00,0x2c,0x07,0xd5,0x00,0x1b,0x07,0xd0,0x00,0x0a,0x07,0xcc,0x00,0xf9,0x06,0xc7,0x00,0xe9,0x06,0xc3,0x00,0xd8,0x06,0xbe,0x00,0xc8,0x06,0xb9,0x00,0xb7,0x06,0xb5,0x00,0xa7,0x06,0xb0,0x00,0x97,0x06,0xac,0x00,0x86,0x06,0xa8,0x00,0x76,0x06,0xa3,0x00,0x66,0x06,0x9f,0x00,0x56,0x06,0x9a,0x00,0x46,0x06,0x96,0x00,  \
    0x36,0x06,0x92,0x00,0x26,0x06,0x8e,0x00,0x16,0x06,0x89,0x00,0x06,0x06,0x85,0x00,0xf7,0x05,0x81,0x00,0xe7,0x05,0x7d,0x00,0xd7,0x05,0x79,0x00,0xc8,0x05,0x75,0x00,0xb8,0x05,0x71,0x00,0xa9,0x05,0x6d,0x00,0x99,0x05,0x69,0x00,0x8a,0x05,0x65,0x00,0x7b,0x05,0x61,0x00,0x6c,0x05,0x5d,0x00,0x5c,0x05,0x59,0x00,0x4d,0x05,0x55,0x00,0x3e,0x05,0x51,0x00,0x2e,0x05,0x4e,0x00,0x1f,0x05,0x4a,0x00,0x10,0x05,0x46,0x00,0x00,0x05,0x43,0x00,0xf1,0x04,0x3f,0x00,0xe2,0x04,  \
    0x3b,0x00,0xd3,0x04,0x38,0x00,0xc4,0x04,0x34,0x00,0xb5,0x04,0x31,0x00,0xa6,0x04,0x2e,0x00,0x97,0x04,0x2a,0x00,0x88,0x04,0x27,0x00,0x7a,0x04,0x23,0x00,0x6b,0x04,0x20,0x00,0x5c,0x04,0x1d,0x00,0x4e,0x04,0x19,0x00,0x3f,0x04,0x16,0x00,0x31,0x04,0x13,0x00,0x22,0x04,0x10,0x00,0x14,0x04,0x0d,0x00,0x05,0x04,0x0a,0x00,0xf7,0x03,0x07,0x00,0xe9,0x03,0x04,0x00,0xdb,0x03,0x00,0x00,0xcd,0x03,0xfd,0xff,0xbf,0x03,0xfb,0xff,0xb1,0x03,0xf8,0xff,0xa3,0x03,0xf5,0xff,  \
    0x95,0x03,0xf2,0xff,0x87,0x03,0xef,0xff,0x79,0x03,0xec,0xff,0x6c,0x03,0xe9,0xff,0x5e,0x03,0xe7,0xff,0x50,0x03,0xe4,0xff,0x42,0x03,0xe1,0xff,0x35,0x03,0xdf,0xff,0x27,0x03,0xdc,0xff,0x1a,0x03,0xda,0xff,0x0c,0x03,0xd7,0xff,0xff,0x02,0xd5,0xff,0xf1,0x02,0xd2,0xff,0xe4,0x02,0xd0,0xff,0xd6,0x02,0xce,0xff,0xc9,0x02,0xcb,0xff,0xbb,0x02,0xc9,0xff,0xae,0x02,0xc7,0xff,0xa1,0x02,0xc5,0xff,0x94,0x02,0xc2,0xff,0x87,0x02,0xc0,0xff,0x79,0x02,0xbe,0xff,0x6c,0x02,  \
    0xbc,0xff,0x5f,0x02,0xba,0xff,0x52,0x02,0xb8,0xff,0x45,0x02,0xb6,0xff,0x39,0x02,0xb4,0xff,0x2c,0x02,0xb2,0xff,0x1f,0x02,0xb0,0xff,0x12,0x02,0xaf,0xff,0x05,0x02,0xad,0xff,0xf8,0x01,0xab,0xff,0xeb,0x01,0xaa,0xff,0xde,0x01,0xa8,0xff,0xd1,0x01,0xa6,0xff,0xc5,0x01,0xa5,0xff,0xb8,0x01,0xa3,0xff,0xab,0x01,0xa2,0xff,0x9e,0x01,0xa0,0xff,0x91,0x01,0x9f,0xff,0x85,0x01,0x9e,0xff,0x78,0x01,0x9c,0xff,0x6b,0x01,0x9b,0xff,0x5e,0x01,0x9a,0xff,0x51,0x01,0x99,0xff,  \
    0x45,0x01,0x97,0xff,0x38,0x01,0x96,0xff,0x2b,0x01,0x95,0xff,0x1e,0x01,0x94,0xff,0x11,0x01,0x93,0xff,0x05,0x01,0x92,0xff,0xf8,0x00,0x91,0xff,0xeb,0x00,0x90,0xff,0xde,0x00,0x90,0xff,0xd1,0x00,0x8f,0xff,0xc4,0x00,0x8e,0xff,0xb8,0x00,0x8d,0xff,0xab,0x00,0x8d,0xff,0x9e,0x00,0x8c,0xff,0x91,0x00,0x8b,0xff,0x85,0x00,0x8b,0xff,0x78,0x00,0x8a,0xff,0x6b,0x00,0x8a,0xff,0x5e,0x00,0x89,0xff,0x52,0x00,0x89,0xff,0x45,0x00,0x88,0xff,0x38,0x00,0x88,0xff,0x2c,0x00,  \
    0x88,0xff,0x1f,0x00,0x87,0xff,0x12,0x00,0x87,0xff,0x05,0x00,0x87,0xff,0xf9,0xff,0x87,0xff,0xec,0xff,0x87,0xff,0xdf,0xff,0x87,0xff,0xd3,0xff,0x87,0xff,0xc6,0xff,0x87,0xff,0xb9,0xff,0x87,0xff,0xad,0xff,0x87,0xff,0xa0,0xff,0x87,0xff,0x93,0xff,0x87,0xff,0x87,0xff,0x87,0xff,0x7a,0xff,0x88,0xff,0x6d,0xff,0x88,0xff,0x60,0xff,0x88,0xff,0x54,0xff,0x88,0xff,0x47,0xff,0x89,0xff,0x3a,0xff,0x89,0xff,0x2e,0xff,0x8a,0xff,0x21,0xff,0x8a,0xff,0x14,0xff,0x8b,0xff,  \
    0x08,0xff,0x8b,0xff,0xfb,0xfe,0x8c,0xff,0xee,0xfe,0x8d,0xff,0xe1,0xfe,0x8d,0xff,0xd5,0xfe,0x8e,0xff,0xc8,0xfe,0x8f,0xff,0xbb,0xfe,0x90,0xff,0xae,0xfe,0x90,0xff,0xa2,0xfe,0x91,0xff,0x95,0xfe,0x92,0xff,0x88,0xfe,0x93,0xff,0x7b,0xfe,0x94,0xff,0x6f,0xfe,0x95,0xff,0x62,0xfe,0x96,0xff,0x55,0xfe,0x97,0xff,0x48,0xfe,0x98,0xff,0x3b,0xfe,0x9a,0xff,0x2e,0xfe,0x9b,0xff,0x21,0xfe,0x9c,0xff,0x14,0xfe,0x9d,0xff,0x07,0xfe,0x9f,0xff,0xfa,0xfd,0xa0,0xff,0xed,0xfd,  \
    0xa1,0xff,0xe0,0xfd,0xa3,0xff,0xd3,0xfd,0xa4,0xff,0xc6,0xfd,0xa6,0xff,0xb9,0xfd,0xa7,0xff,0xac,0xfd,0xa9,0xff,0x9f,0xfd,0xaa,0xff,0x91,0xfd,0xac,0xff,0x84,0xfd,0xae,0xff,0x77,0xfd,0xaf,0xff,0x6a,0xfd,0xb1,0xff,0x5d,0xfd,0xb3,0xff,0x4f,0xfd,0xb5,0xff,0x42,0xfd,0xb7,0xff,0x35,0xfd,0xb9,0xff,0x27,0xfd,0xba,0xff,0x1a,0xfd,0xbc,0xff,0x0d,0xfd,0xbe,0xff,0xff,0xfc,0xc0,0xff,0xf2,0xfc,0xc3,0xff,0xe5,0xfc,0xc5,0xff,0xd7,0xfc,0xc7,0xff,0xca,0xfc,0xc9,0xff,  \
    0xbd,0xfc,0xcb,0xff,0xaf,0xfc,0xce,0xff,0xa2,0xfc,0xd0,0xff,0x95,0xfc,0xd2,0xff,0x87,0xfc,0xd5,0xff,0x7a,0xfc,0xd7,0xff,0x6c,0xfc,0xda,0xff,0x5f,0xfc,0xdc,0xff,0x51,0xfc,0xdf,0xff,0x44,0xfc,0xe1,0xff,0x36,0xfc,0xe4,0xff,0x29,0xfc,0xe6,0xff,0x1b,0xfc,0xe9,0xff,0x0d,0xfc,0xec,0xff,0x00,0xfc,0xee,0xff,0xf2,0xfb,0xf1,0xff,0xe4,0xfb,0xf4,0xff,0xd6,0xfb,0xf7,0xff,0xc9,0xfb,0xfa,0xff,0xbb,0xfb,0xfd,0xff,0xad,0xfb,0x00,0x00,0x9f,0xfb,0x03,0x00,0x91,0xfb,  \
    0x06,0x00,0x83,0xfb,0x09,0x00,0x74,0xfb,0x0c,0x00,0x66,0xfb,0x0f,0x00,0x58,0xfb,0x12,0x00,0x4a,0xfb,0x15,0x00,0x3b,0xfb,0x18,0x00,0x2d,0xfb,0x1b,0x00,0x1e,0xfb,0x1f,0x00,0x10,0xfb,0x22,0x00,0x01,0xfb,0x25,0x00,0xf3,0xfa,0x29,0x00,0xe4,0xfa,0x2c,0x00,0xd6,0xfa,0x2f,0x00,0xc7,0xfa,0x33,0x00,0xb8,0xfa,0x36,0x00,0xa9,0xfa,0x3a,0x00,0x9a,0xfa,0x3d,0x00,0x8c,0xfa,0x41,0x00,0x7d,0xfa,0x45,0x00,0x6e,0xfa,0x48,0x00,0x5f,0xfa,0x4c,0x00,0x50,0xfa,0x50,0x00,  \
    0x40,0xfa,0x53,0x00,0x31,0xfa,0x57,0x00,0x22,0xfa,0x5b,0x00,0x13,0xfa,0x5f,0x00,0x04,0xfa,0x62,0x00,0xf4,0xf9,0x66,0x00,0xe5,0xf9,0x6a,0x00,0xd6,0xf9,0x6e,0x00,0xc6,0xf9,0x72,0x00,0xb7,0xf9,0x76,0x00,0xa7,0xf9,0x7a,0x00,0x98,0xf9,0x7e,0x00,0x88,0xf9,0x82,0x00,0x78,0xf9,0x86,0x00,0x68,0xf9,0x8a,0x00,0x59,0xf9,0x8f,0x00,0x49,0xf9,0x93,0x00,0x39,0xf9,0x97,0x00,0x29,0xf9,0x9b,0x00,0x19,0xf9,0x9f,0x00,0x08,0xf9,0xa4,0x00,0xf8,0xf8,0xa8,0x00,0xe8,0xf8,  \
    0xac,0x00,0xd8,0xf8,0xb1,0x00,0xc7,0xf8,0xb5,0x00,0xb7,0xf8,0xb9,0x00,0xa6,0xf8,0xbe,0x00,0x95,0xf8,0xc2,0x00,0x84,0xf8,0xc7,0x00,0x73,0xf8,0xcb,0x00,0x62,0xf8,0xcf,0x00,0x51,0xf8,0xd4,0x00,0x40,0xf8,0xd8,0x00,0x2f,0xf8,0xdd,0x00,0x1e,0xf8,0xe1,0x00,0x0d,0xf8,0xe6,0x00,0xfb,0xf7,0xea,0x00,0xea,0xf7,0xef,0x00,0xd8,0xf7,0xf4,0x00,0xc7,0xf7,0xf8,0x00,0xb5,0xf7,0xfd,0x00,0xa3,0xf7,0x01,0x01,0x91,0xf7,0x06,0x01,0x7f,0xf7,0x0b,0x01,0x6d,0xf7,0x0f,0x01,  \
    0x5b,0xf7,0x14,0x01,0x49,0xf7,0x19,0x01,0x37,0xf7,0x1e,0x01,0x25,0xf7,0x22,0x01,0x12,0xf7,0x27,0x01,0x00,0xf7,0x2c,0x01,0xed,0xf6,0x31,0x01,0xdb,0xf6,0x35,0x01,0xc8,0xf6,0x3a,0x01,0xb5,0xf6,0x3f,0x01,0xa2,0xf6,0x44,0x01,0x90,0xf6,0x49,0x01,0x7c,0xf6,0x4d,0x01,0x69,0xf6,0x52,0x01,0x56,0xf6,0x57,0x01,0x43,0xf6,0x5c,0x01,0x2f,0xf6,0x61,0x01,0x1c,0xf6,0x65,0x01,0x08,0xf6,0x6a,0x01,0xf5,0xf5,0x6f,0x01,0xe1,0xf5,0x74,0x01,0xcd,0xf5,0x78,0x01,0xb8,0xf5,  \
    0x7d,0x01,0xa4,0xf5,0x82,0x01,0x8f,0xf5,0x87,0x01,0x7b,0xf5,0x8b,0x01,0x66,0xf5,0x90,0x01,0x51,0xf5,0x94,0x01,0x3d,0xf5,0x99,0x01,0x28,0xf5,0x9e,0x01,0x12,0xf5,0xa2,0x01,0xfd,0xf4,0xa7,0x01,0xe8,0xf4,0xac,0x01,0xd3,0xf4,0xb0,0x01,0xbd,0xf4,0xb5,0x01,0xa8,0xf4,0xb9,0x01,0x92,0xf4,0xbe,0x01,0x7c,0xf4,0xc2,0x01,0x66,0xf4,0xc7,0x01,0x50,0xf4,0xcb,0x01,0x3a,0xf4,0xd0,0x01,0x24,0xf4,0xd5,0x01,0x0e,0xf4,0xd9,0x01,0xf8,0xf3,0xde,0x01,0xe2,0xf3,0xe2,0x01,  \
    0xcb,0xf3,0xe7,0x01,0xb5,0xf3,0xeb,0x01,0x9e,0xf3,0xef,0x01,0x87,0xf3,0xf4,0x01,0x70,0xf3,0xf8,0x01,0x59,0xf3,0xfc,0x01,0x42,0xf3,0x01,0x02,0x2b,0xf3,0x05,0x02,0x13,0xf3,0x09,0x02,0xfc,0xf2,0x0d,0x02,0xe4,0xf2,0x11,0x02,0xcc,0xf2,0x16,0x02,0xb4,0xf2,0x1a,0x02,0x9c,0xf2,0x1e,0x02,0x84,0xf2,0x22,0x02,0x6c,0xf2,0x26,0x02,0x54,0xf2,0x29,0x02,0x3b,0xf2,0x2d,0x02,0x22,0xf2,0x31,0x02,0x0a,0xf2,0x35,0x02,0xf1,0xf1,0x39,0x02,0xd8,0xf1,0x3c,0x02,0xbf,0xf1,  \
    0x40,0x02,0xa5,0xf1,0x43,0x02,0x8c,0xf1,0x47,0x02,0x72,0xf1,0x4a,0x02,0x58,0xf1,0x4e,0x02,0x3f,0xf1,0x51,0x02,0x25,0xf1,0x54,0x02,0x0b,0xf1,0x57,0x02,0xf0,0xf0,0x5b,0x02,0xd6,0xf0,0x5e,0x02,0xbb,0xf0,0x61,0x02,0xa1,0xf0,0x63,0x02,0x86,0xf0,0x66,0x02,0x6b,0xf0,0x69,0x02,0x4f,0xf0,0x6c,0x02,0x34,0xf0,0x6e,0x02,0x18,0xf0,0x71,0x02,0xfd,0xef,0x73,0x02,0xe1,0xef,0x75,0x02,0xc5,0xef,0x78,0x02,0xa9,0xef,0x7a,0x02,0x8d,0xef,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x9f,0x02,0x6d,0x10,0x9d,0x02,0x51,0x10,0x9a,0x02,0x35,0x10,0x98,0x02,0x19,0x10,0x95,0x02,0xfd,0x0f,0x93,0x02,0xe1,0x0f,0x90,0x02,0xc5,0x0f,0x8e,0x02,0xa9,0x0f,0x8b,0x02,0x8e,0x0f,  \
    0x88,0x02,0x73,0x0f,0x85,0x02,0x57,0x0f,0x82,0x02,0x3c,0x0f,0x7f,0x02,0x21,0x0f,0x7c,0x02,0x07,0x0f,0x79,0x02,0xec,0x0e,0x76,0x02,0xd1,0x0e,0x72,0x02,0xb7,0x0e,0x6f,0x02,0x9c,0x0e,0x6c,0x02,0x82,0x0e,0x68,0x02,0x68,0x0e,0x65,0x02,0x4e,0x0e,0x61,0x02,0x35,0x0e,0x5d,0x02,0x1b,0x0e,0x5a,0x02,0x01,0x0e,0x56,0x02,0xe8,0x0d,0x52,0x02,0xcf,0x0d,0x4e,0x02,0xb6,0x0d,0x4a,0x02,0x9d,0x0d,0x46,0x02,0x84,0x0d,0x42,0x02,0x6b,0x0d,0x3e,0x02,0x53,0x0d,0x3a,0x02,  \
    0x3a,0x0d,0x36,0x02,0x22,0x0d,0x32,0x02,0x0a,0x0d,0x2e,0x02,0xf1,0x0c,0x2a,0x02,0xd9,0x0c,0x25,0x02,0xc1,0x0c,0x21,0x02,0xaa,0x0c,0x1d,0x02,0x92,0x0c,0x18,0x02,0x7b,0x0c,0x14,0x02,0x63,0x0c,0x0f,0x02,0x4c,0x0c,0x0b,0x02,0x35,0x0c,0x06,0x02,0x1e,0x0c,0x02,0x02,0x07,0x0c,0xfd,0x01,0xf1,0x0b,0xf8,0x01,0xda,0x0b,0xf4,0x01,0xc4,0x0b,0xef,0x01,0xad,0x0b,0xea,0x01,0x97,0x0b,0xe5,0x01,0x81,0x0b,0xe0,0x01,0x6b,0x0b,0xdc,0x01,0x55,0x0b,0xd7,0x01,0x40,0x0b,  \
    0xd2,0x01,0x2a,0x0b,0xcd,0x01,0x14,0x0b,0xc8,0x01,0xff,0x0a,0xc3,0x01,0xea,0x0a,0xbf,0x01,0xd4,0x0a,0xba,0x01,0xbe,0x0a,0xb5,0x01,0xa9,0x0a,0xb0,0x01,0x94,0x0a,0xac,0x01,0x7e,0x0a,0xa7,0x01,0x69,0x0a,0xa2,0x01,0x54,0x0a,0x9d,0x01,0x3f,0x0a,0x99,0x01,0x2a,0x0a,0x94,0x01,0x16,0x0a,0x8f,0x01,0x01,0x0a,0x8a,0x01,0xec,0x09,0x86,0x01,0xd8,0x09,0x81,0x01,0xc3,0x09,0x7c,0x01,0xaf,0x09,0x77,0x01,0x9b,0x09,0x72,0x01,0x87,0x09,0x6e,0x01,0x73,0x09,0x69,0x01,  \
    0x5f,0x09,0x64,0x01,0x4b,0x09,0x5f,0x01,0x37,0x09,0x5a,0x01,0x23,0x09,0x56,0x01,0x10,0x09,0x51,0x01,0xfc,0x08,0x4c,0x01,0xe9,0x08,0x47,0x01,0xd6,0x08,0x43,0x01,0xc2,0x08,0x3e,0x01,0xaf,0x08,0x39,0x01,0x9c,0x08,0x34,0x01,0x89,0x08,0x30,0x01,0x76,0x08,0x2b,0x01,0x63,0x08,0x26,0x01,0x51,0x08,0x21,0x01,0x3e,0x08,0x1d,0x01,0x2b,0x08,0x18,0x01,0x19,0x08,0x13,0x01,0x07,0x08,0x0e,0x01,0xf5,0x07,0x0a,0x01,0xe4,0x07,0x05,0x01,0xd2,0x07,0x00,0x01,0xc0,0x07,  \
    0xfb,0x00,0xaf,0x07,0xf6,0x00,0x9d,0x07,0xf2,0x00,0x8c,0x07,0xed,0x00,0x7b,0x07,0xe8,0x00,0x6a,0x07,0xe4,0x00,0x58,0x07,0xdf,0x00,0x47,0x07,0xda,0x00,0x36,0x07,0xd6,0x00,0x26,0x07,0xd1,0x00,0x15,0x07,0xcc,0x00,0x04,0x07,0xc8,0x00,0xf3,0x06,0xc3,0x00,0xe3,0x06,0xbf,0x00,0xd2,0x06,0xba,0x00,0xc2,0x06,0xb6,0x00,0xb1,0x06,0xb1,0x00,0xa1,0x06,0xad,0x00,0x90,0x06,0xa9,0x00,0x80,0x06,0xa4,0x00,0x70,0x06,0xa0,0x00,0x60,0x06,0x9c,0x00,0x50,0x06,0x97,0x00,  \
    0x40,0x06,0x93,0x00,0x30,0x06,0x8f,0x00,0x20,0x06,0x8b,0x00,0x10,0x06,0x87,0x00,0x00,0x06,0x82,0x00,0xf1,0x05,0x7e,0x00,0xe1,0x05,0x7a,0x00,0xd1,0x05,0x76,0x00,0xc2,0x05,0x72,0x00,0xb2,0x05,0x6e,0x00,0xa3,0x05,0x6a,0x00,0x93,0x05,0x66,0x00,0x84,0x05,0x62,0x00,0x75,0x05,0x5e,0x00,0x66,0x05,0x5a,0x00,0x56,0x05,0x57,0x00,0x47,0x05,0x53,0x00,0x38,0x05,0x4f,0x00,0x28,0x05,0x4c,0x00,0x19,0x05,0x48,0x00,0x0a,0x05,0x44,0x00,0xfb,0x04,0x41,0x00,0xec,0x04,  \
    0x3d,0x00,0xdc,0x04,0x3a,0x00,0xcd,0x04,0x36,0x00,0xbe,0x04,0x33,0x00,0xb0,0x04,0x2f,0x00,0xa1,0x04,0x2c,0x00,0x92,0x04,0x28,0x00,0x83,0x04,0x25,0x00,0x74,0x04,0x22,0x00,0x66,0x04,0x1f,0x00,0x57,0x04,0x1b,0x00,0x48,0x04,0x18,0x00,0x3a,0x04,0x15,0x00,0x2b,0x04,0x12,0x00,0x1d,0x04,0x0f,0x00,0x0f,0x04,0x0c,0x00,0x00,0x04,0x08,0x00,0xf2,0x03,0x05,0x00,0xe4,0x03,0x02,0x00,0xd6,0x03,0xff,0xff,0xc8,0x03,0xfc,0xff,0xba,0x03,0xf9,0xff,0xac,0x03,0xf7,0xff,  \
    0x9e,0x03,0xf4,0xff,0x90,0x03,0xf1,0xff,0x83,0x03,0xee,0xff,0x75,0x03,0xeb,0xff,0x67,0x03,0xe9,0xff,0x59,0x03,0xe6,0xff,0x4c,0x03,0xe3,0xff,0x3e,0x03,0xe1,0xff,0x30,0x03,0xde,0xff,0x23,0x03,0xdc,0xff,0x15,0x03,0xd9,0xff,0x08,0x03,0xd7,0xff,0xfa,0x02,0xd4,0xff,0xed,0x02,0xd2,0xff,0xe0,0x02,0xcf,0xff,0xd2,0x02,0xcd,0xff,0xc5,0x02,0xcb,0xff,0xb8,0x02,0xc9,0xff,0xaa,0x02,0xc6,0xff,0x9d,0x02,0xc4,0xff,0x90,0x02,0xc2,0xff,0x83,0x02,0xc0,0xff,0x76,0x02,  \
    0xbe,0xff,0x69,0x02,0xbc,0xff,0x5c,0x02,0xba,0xff,0x4f,0x02,0xb8,0xff,0x42,0x02,0xb6,0xff,0x35,0x02,0xb4,0xff,0x28,0x02,0xb2,0xff,0x1b,0x02,0xb0,0xff,0x0f,0x02,0xaf,0xff,0x02,0x02,0xad,0xff,0xf5,0x01,0xab,0xff,0xe8,0x01,0xa9,0xff,0xdb,0x01,0xa8,0xff,0xce,0x01,0xa6,0xff,0xc2,0x01,0xa5,0xff,0xb5,0x01,0xa3,0xff,0xa8,0x01,0xa2,0xff,0x9b,0x01,0xa0,0xff,0x8f,0x01,0x9f,0xff,0x82,0x01,0x9e,0xff,0x75,0x01,0x9c,0xff,0x69,0x01,0x9b,0xff,0x5c,0x01,0x9a,0xff,  \
    0x4f,0x01,0x99,0xff,0x42,0x01,0x98,0xff,0x36,0x01,0x96,0xff,0x29,0x01,0x95,0xff,0x1c,0x01,0x94,0xff,0x0f,0x01,0x93,0xff,0x03,0x01,0x92,0xff,0xf6,0x00,0x91,0xff,0xe9,0x00,0x91,0xff,0xdc,0x00,0x90,0xff,0xd0,0x00,0x8f,0xff,0xc3,0x00,0x8e,0xff,0xb6,0x00,0x8d,0xff,0xaa,0x00,0x8d,0xff,0x9d,0x00,0x8c,0xff,0x90,0x00,0x8c,0xff,0x83,0x00,0x8b,0xff,0x77,0x00,0x8a,0xff,0x6a,0x00,0x8a,0xff,0x5e,0x00,0x89,0xff,0x51,0x00,0x89,0xff,0x44,0x00,0x89,0xff,0x38,0x00,  \
    0x88,0xff,0x2b,0x00,0x88,0xff,0x1e,0x00,0x88,0xff,0x12,0x00,0x88,0xff,0x05,0x00,0x87,0xff,0xf8,0xff,0x87,0xff,0xec,0xff,0x87,0xff,0xdf,0xff,0x87,0xff,0xd3,0xff,0x87,0xff,0xc6,0xff,0x87,0xff,0xb9,0xff,0x87,0xff,0xad,0xff,0x87,0xff,0xa0,0xff,0x87,0xff,0x94,0xff,0x87,0xff,0x87,0xff,0x88,0xff,0x7a,0xff,0x88,0xff,0x6e,0xff,0x88,0xff,0x61,0xff,0x88,0xff,0x54,0xff,0x89,0xff,0x48,0xff,0x89,0xff,0x3b,0xff,0x8a,0xff,0x2f,0xff,0x8a,0xff,0x22,0xff,0x8a,0xff,  \
    0x15,0xff,0x8b,0xff,0x09,0xff,0x8c,0xff,0xfc,0xfe,0x8c,0xff,0xef,0xfe,0x8d,0xff,0xe3,0xfe,0x8d,0xff,0xd6,0xfe,0x8e,0xff,0xc9,0xfe,0x8f,0xff,0xbd,0xfe,0x90,0xff,0xb0,0xfe,0x91,0xff,0xa3,0xfe,0x91,0xff,0x97,0xfe,0x92,0xff,0x8a,0xfe,0x93,0xff,0x7d,0xfe,0x94,0xff,0x71,0xfe,0x95,0xff,0x64,0xfe,0x96,0xff,0x57,0xfe,0x97,0xff,0x4a,0xfe,0x99,0xff,0x3d,0xfe,0x9a,0xff,0x30,0xfe,0x9b,0xff,0x24,0xfe,0x9c,0xff,0x17,0xfe,0x9d,0xff,0x0a,0xfe,0x9f,0xff,0xfd,0xfd,  \
    0xa0,0xff,0xf0,0xfd,0xa1,0xff,0xe3,0xfd,0xa3,0xff,0xd6,0xfd,0xa4,0xff,0xc9,0xfd,0xa6,0xff,0xbc,0xfd,0xa7,0xff,0xaf,0xfd,0xa9,0xff,0xa2,0xfd,0xaa,0xff,0x95,0xfd,0xac,0xff,0x88,0xfd,0xae,0xff,0x7a,0xfd,0xaf,0xff,0x6d,0xfd,0xb1,0xff,0x60,0xfd,0xb3,0xff,0x53,0xfd,0xb5,0xff,0x46,0xfd,0xb6,0xff,0x39,0xfd,0xb8,0xff,0x2b,0xfd,0xba,0xff,0x1e,0xfd,0xbc,0xff,0x11,0xfd,0xbe,0xff,0x03,0xfd,0xc0,0xff,0xf6,0xfc,0xc2,0xff,0xe9,0xfc,0xc4,0xff,0xdc,0xfc,0xc7,0xff,  \
    0xce,0xfc,0xc9,0xff,0xc1,0xfc,0xcb,0xff,0xb4,0xfc,0xcd,0xff,0xa7,0xfc,0xcf,0xff,0x99,0xfc,0xd2,0xff,0x8c,0xfc,0xd4,0xff,0x7e,0xfc,0xd7,0xff,0x71,0xfc,0xd9,0xff,0x64,0xfc,0xdb,0xff,0x56,0xfc,0xde,0xff,0x49,0xfc,0xe0,0xff,0x3b,0xfc,0xe3,0xff,0x2e,0xfc,0xe6,0xff,0x20,0xfc,0xe8,0xff,0x12,0xfc,0xeb,0xff,0x05,0xfc,0xee,0xff,0xf7,0xfb,0xf0,0xff,0xe9,0xfb,0xf3,0xff,0xdc,0xfb,0xf6,0xff,0xce,0xfb,0xf9,0xff,0xc0,0xfb,0xfc,0xff,0xb2,0xfb,0xff,0xff,0xa4,0xfb,  \
    0x02,0x00,0x96,0xfb,0x05,0x00,0x88,0xfb,0x07,0x00,0x7a,0xfb,0x0b,0x00,0x6c,0xfb,0x0e,0x00,0x5e,0xfb,0x11,0x00,0x4f,0xfb,0x14,0x00,0x41,0xfb,0x17,0x00,0x33,0xfb,0x1a,0x00,0x24,0xfb,0x1d,0x00,0x16,0xfb,0x21,0x00,0x07,0xfb,0x24,0x00,0xf9,0xfa,0x27,0x00,0xea,0xfa,0x2a,0x00,0xdb,0xfa,0x2e,0x00,0xcd,0xfa,0x31,0x00,0xbe,0xfa,0x35,0x00,0xaf,0xfa,0x38,0x00,0xa1,0xfa,0x3c,0x00,0x92,0xfa,0x3f,0x00,0x83,0xfa,0x43,0x00,0x74,0xfa,0x46,0x00,0x65,0xfa,0x4a,0x00,  \
    0x56,0xfa,0x4e,0x00,0x47,0xfa,0x51,0x00,0x38,0xfa,0x55,0x00,0x28,0xfa,0x59,0x00,0x19,0xfa,0x5c,0x00,0x0a,0xfa,0x60,0x00,0xfb,0xf9,0x64,0x00,0xeb,0xf9,0x68,0x00,0xdc,0xf9,0x6c,0x00,0xcd,0xf9,0x70,0x00,0xbd,0xf9,0x74,0x00,0xae,0xf9,0x78,0x00,0x9e,0xf9,0x7c,0x00,0x8e,0xf9,0x80,0x00,0x7f,0xf9,0x84,0x00,0x6f,0xf9,0x88,0x00,0x5f,0xf9,0x8c,0x00,0x4f,0xf9,0x90,0x00,0x3f,0xf9,0x94,0x00,0x2f,0xf9,0x98,0x00,0x1f,0xf9,0x9c,0x00,0x0f,0xf9,0xa1,0x00,0xff,0xf8,  \
    0xa5,0x00,0xef,0xf8,0xa9,0x00,0xde,0xf8,0xad,0x00,0xce,0xf8,0xb2,0x00,0xbd,0xf8,0xb6,0x00,0xad,0xf8,0xba,0x00,0x9c,0xf8,0xbf,0x00,0x8b,0xf8,0xc3,0x00,0x7a,0xf8,0xc7,0x00,0x69,0xf8,0xcc,0x00,0x58,0xf8,0xd0,0x00,0x47,0xf8,0xd4,0x00,0x36,0xf8,0xd9,0x00,0x25,0xf8,0xdd,0x00,0x13,0xf8,0xe2,0x00,0x02,0xf8,0xe6,0x00,0xf0,0xf7,0xeb,0x00,0xdf,0xf7,0xef,0x00,0xcd,0xf7,0xf4,0x00,0xbc,0xf7,0xf8,0x00,0xaa,0xf7,0xfd,0x00,0x98,0xf7,0x02,0x01,0x86,0xf7,0x06,0x01,  \
    0x74,0xf7,0x0b,0x01,0x62,0xf7,0x0f,0x01,0x50,0xf7,0x14,0x01,0x3e,0xf7,0x19,0x01,0x2b,0xf7,0x1d,0x01,0x19,0xf7,0x22,0x01,0x07,0xf7,0x27,0x01,0xf4,0xf6,0x2b,0x01,0xe1,0xf6,0x30,0x01,0xcf,0xf6,0x35,0x01,0xbc,0xf6,0x3a,0x01,0xa9,0xf6,0x3e,0x01,0x96,0xf6,0x43,0x01,0x83,0xf6,0x48,0x01,0x70,0xf6,0x4c,0x01,0x5d,0xf6,0x51,0x01,0x49,0xf6,0x56,0x01,0x36,0xf6,0x5b,0x01,0x22,0xf6,0x5f,0x01,0x0f,0xf6,0x64,0x01,0xfb,0xf5,0x69,0x01,0xe7,0xf5,0x6e,0x01,0xd3,0xf5,  \
    0x72,0x01,0xbf,0xf5,0x77,0x01,0xaa,0xf5,0x7b,0x01,0x96,0xf5,0x80,0x01,0x81,0xf5,0x85,0x01,0x6d,0xf5,0x89,0x01,0x58,0xf5,0x8e,0x01,0x43,0xf5,0x92,0x01,0x2e,0xf5,0x97,0x01,0x19,0xf5,0x9b,0x01,0x04,0xf5,0xa0,0x01,0xee,0xf4,0xa4,0x01,0xd9,0xf4,0xa9,0x01,0xc3,0xf4,0xad,0x01,0xae,0xf4,0xb2,0x01,0x98,0xf4,0xb6,0x01,0x82,0xf4,0xbb,0x01,0x6c,0xf4,0xbf,0x01,0x56,0xf4,0xc4,0x01,0x40,0xf4,0xc8,0x01,0x2a,0xf4,0xcd,0x01,0x14,0xf4,0xd1,0x01,0xfe,0xf3,0xd6,0x01,  \
    0xe8,0xf3,0xda,0x01,0xd1,0xf3,0xde,0x01,0xbb,0xf3,0xe3,0x01,0xa4,0xf3,0xe7,0x01,0x8d,0xf3,0xeb,0x01,0x76,0xf3,0xf0,0x01,0x5f,0xf3,0xf4,0x01,0x48,0xf3,0xf8,0x01,0x31,0xf3,0xfc,0x01,0x19,0xf3,0x00,0x02,0x02,0xf3,0x05,0x02,0xea,0xf2,0x09,0x02,0xd2,0xf2,0x0d,0x02,0xba,0xf2,0x11,0x02,0xa2,0xf2,0x15,0x02,0x8a,0xf2,0x18,0x02,0x72,0xf2,0x1c,0x02,0x59,0xf2,0x20,0x02,0x41,0xf2,0x24,0x02,0x28,0xf2,0x28,0x02,0x0f,0xf2,0x2b,0x02,0xf6,0xf1,0x2f,0x02,0xdd,0xf1,  \
    0x33,0x02,0xc4,0xf1,0x36,0x02,0xab,0xf1,0x3a,0x02,0x91,0xf1,0x3d,0x02,0x78,0xf1,0x40,0x02,0x5e,0xf1,0x44,0x02,0x44,0xf1,0x47,0x02,0x2a,0xf1,0x4a,0x02,0x10,0xf1,0x4d,0x02,0xf6,0xf0,0x50,0x02,0xdb,0xf0,0x53,0x02,0xc1,0xf0,0x56,0x02,0xa6,0xf0,0x59,0x02,0x8b,0xf0,0x5c,0x02,0x70,0xf0,0x5e,0x02,0x55,0xf0,0x61,0x02,0x39,0xf0,0x64,0x02,0x1e,0xf0,0x66,0x02,0x02,0xf0,0x68,0x02,0xe6,0xef,0x6b,0x02,0xca,0xef,0x6d,0x02,0xae,0xef,0x6f,0x02,0x92,0xef,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x93,0x02,0x69,0x10,0x91,0x02,0x4d,0x10,0x8e,0x02,0x30,0x10,0x8c,0x02,0x14,0x10,0x8a,0x02,0xf8,0x0f,0x87,0x02,0xdc,0x0f,0x84,0x02,0xc1,0x0f,0x82,0x02,0xa5,0x0f,  \
    0x7f,0x02,0x8a,0x0f,0x7c,0x02,0x6e,0x0f,0x7a,0x02,0x53,0x0f,0x77,0x02,0x38,0x0f,0x74,0x02,0x1d,0x0f,0x71,0x02,0x02,0x0f,0x6e,0x02,0xe7,0x0e,0x6a,0x02,0xcd,0x0e,0x67,0x02,0xb2,0x0e,0x64,0x02,0x98,0x0e,0x61,0x02,0x7e,0x0e,0x5d,0x02,0x64,0x0e,0x5a,0x02,0x4a,0x0e,0x56,0x02,0x30,0x0e,0x53,0x02,0x16,0x0e,0x4f,0x02,0xfd,0x0d,0x4b,0x02,0xe3,0x0d,0x48,0x02,0xca,0x0d,0x44,0x02,0xb1,0x0d,0x40,0x02,0x98,0x0d,0x3c,0x02,0x7f,0x0d,0x38,0x02,0x66,0x0d,0x34,0x02,  \
    0x4e,0x0d,0x30,0x02,0x35,0x0d,0x2c,0x02,0x1d,0x0d,0x28,0x02,0x05,0x0d,0x24,0x02,0xec,0x0c,0x20,0x02,0xd4,0x0c,0x1c,0x02,0xbc,0x0c,0x17,0x02,0xa5,0x0c,0x13,0x02,0x8d,0x0c,0x0f,0x02,0x75,0x0c,0x0b,0x02,0x5e,0x0c,0x06,0x02,0x47,0x0c,0x02,0x02,0x30,0x0c,0xfd,0x01,0x19,0x0c,0xf9,0x01,0x02,0x0c,0xf4,0x01,0xeb,0x0b,0xef,0x01,0xd5,0x0b,0xeb,0x01,0xbe,0x0b,0xe6,0x01,0xa8,0x0b,0xe2,0x01,0x92,0x0b,0xdd,0x01,0x7c,0x0b,0xd8,0x01,0x66,0x0b,0xd3,0x01,0x50,0x0b,  \
    0xcf,0x01,0x3a,0x0b,0xca,0x01,0x24,0x0b,0xc5,0x01,0x0f,0x0b,0xc0,0x01,0xf9,0x0a,0xbc,0x01,0xe4,0x0a,0xb7,0x01,0xce,0x0a,0xb2,0x01,0xb9,0x0a,0xae,0x01,0xa3,0x0a,0xa9,0x01,0x8e,0x0a,0xa4,0x01,0x79,0x0a,0xa0,0x01,0x63,0x0a,0x9b,0x01,0x4e,0x0a,0x96,0x01,0x39,0x0a,0x92,0x01,0x24,0x0a,0x8d,0x01,0x10,0x0a,0x88,0x01,0xfb,0x09,0x84,0x01,0xe6,0x09,0x7f,0x01,0xd2,0x09,0x7a,0x01,0xbe,0x09,0x75,0x01,0xa9,0x09,0x71,0x01,0x95,0x09,0x6c,0x01,0x81,0x09,0x67,0x01,  \
    0x6d,0x09,0x63,0x01,0x59,0x09,0x5e,0x01,0x45,0x09,0x59,0x01,0x31,0x09,0x54,0x01,0x1e,0x09,0x50,0x01,0x0a,0x09,0x4b,0x01,0xf6,0x08,0x46,0x01,0xe3,0x08,0x42,0x01,0xd0,0x08,0x3d,0x01,0xbc,0x08,0x38,0x01,0xa9,0x08,0x34,0x01,0x96,0x08,0x2f,0x01,0x83,0x08,0x2a,0x01,0x70,0x08,0x26,0x01,0x5d,0x08,0x21,0x01,0x4b,0x08,0x1c,0x01,0x38,0x08,0x18,0x01,0x26,0x08,0x13,0x01,0x13,0x08,0x0e,0x01,0x01,0x08,0x09,0x01,0xef,0x07,0x05,0x01,0xde,0x07,0x00,0x01,0xcc,0x07,  \
    0xfb,0x00,0xba,0x07,0xf7,0x00,0xa9,0x07,0xf2,0x00,0x97,0x07,0xed,0x00,0x86,0x07,0xe9,0x00,0x75,0x07,0xe4,0x00,0x64,0x07,0xdf,0x00,0x52,0x07,0xdb,0x00,0x41,0x07,0xd6,0x00,0x30,0x07,0xd2,0x00,0x1f,0x07,0xcd,0x00,0x0f,0x07,0xc9,0x00,0xfe,0x06,0xc4,0x00,0xed,0x06,0xc0,0x00,0xdd,0x06,0xbb,0x00,0xcc,0x06,0xb7,0x00,0xbc,0x06,0xb2,0x00,0xab,0x06,0xae,0x00,0x9b,0x06,0xaa,0x00,0x8a,0x06,0xa5,0x00,0x7a,0x06,0xa1,0x00,0x6a,0x06,0x9d,0x00,0x5a,0x06,0x99,0x00,  \
    0x4a,0x06,0x94,0x00,0x3a,0x06,0x90,0x00,0x2a,0x06,0x8c,0x00,0x1a,0x06,0x88,0x00,0x0a,0x06,0x84,0x00,0xfa,0x05,0x80,0x00,0xeb,0x05,0x7c,0x00,0xdb,0x05,0x78,0x00,0xcb,0x05,0x74,0x00,0xbc,0x05,0x70,0x00,0xac,0x05,0x6c,0x00,0x9d,0x05,0x68,0x00,0x8e,0x05,0x64,0x00,0x7e,0x05,0x60,0x00,0x6f,0x05,0x5c,0x00,0x60,0x05,0x58,0x00,0x51,0x05,0x55,0x00,0x41,0x05,0x51,0x00,0x32,0x05,0x4d,0x00,0x23,0x05,0x4a,0x00,0x13,0x05,0x46,0x00,0x04,0x05,0x42,0x00,0xf5,0x04,  \
    0x3f,0x00,0xe6,0x04,0x3b,0x00,0xd7,0x04,0x38,0x00,0xc8,0x04,0x35,0x00,0xb9,0x04,0x31,0x00,0xaa,0x04,0x2e,0x00,0x9b,0x04,0x2a,0x00,0x8c,0x04,0x27,0x00,0x7e,0x04,0x24,0x00,0x6f,0x04,0x20,0x00,0x60,0x04,0x1d,0x00,0x52,0x04,0x1a,0x00,0x43,0x04,0x17,0x00,0x35,0x04,0x14,0x00,0x26,0x04,0x11,0x00,0x18,0x04,0x0d,0x00,0x0a,0x04,0x0a,0x00,0xfb,0x03,0x07,0x00,0xed,0x03,0x04,0x00,0xdf,0x03,0x01,0x00,0xd1,0x03,0xfe,0xff,0xc3,0x03,0xfb,0xff,0xb5,0x03,0xf9,0xff,  \
    0xa7,0x03,0xf6,0xff,0x99,0x03,0xf3,0xff,0x8c,0x03,0xf0,0xff,0x7e,0x03,0xed,0xff,0x70,0x03,0xeb,0xff,0x63,0x03,0xe8,0xff,0x55,0x03,0xe5,0xff,0x47,0x03,0xe3,0xff,0x3a,0x03,0xe0,0xff,0x2c,0x03,0xde,0xff,0x1f,0x03,0xdb,0xff,0x11,0x03,0xd9,0xff,0x04,0x03,0xd6,0xff,0xf6,0x02,0xd4,0xff,0xe9,0x02,0xd1,0xff,0xdc,0x02,0xcf,0xff,0xce,0x02,0xcd,0xff,0xc1,0x02,0xcb,0xff,0xb4,0x02,0xc8,0xff,0xa6,0x02,0xc6,0xff,0x99,0x02,0xc4,0xff,0x8c,0x02,0xc2,0xff,0x7f,0x02,  \
    0xc0,0xff,0x72,0x02,0xbe,0xff,0x65,0x02,0xbc,0xff,0x58,0x02,0xba,0xff,0x4c,0x02,0xb8,0xff,0x3f,0x02,0xb6,0xff,0x32,0x02,0xb4,0xff,0x25,0x02,0xb2,0xff,0x18,0x02,0xb0,0xff,0x0b,0x02,0xaf,0xff,0xff,0x01,0xad,0xff,0xf2,0x01,0xab,0xff,0xe5,0x01,0xaa,0xff,0xd8,0x01,0xa8,0xff,0xcc,0x01,0xa6,0xff,0xbf,0x01,0xa5,0xff,0xb2,0x01,0xa3,0xff,0xa5,0x01,0xa2,0xff,0x99,0x01,0xa1,0xff,0x8c,0x01,0x9f,0xff,0x7f,0x01,0x9e,0xff,0x73,0x01,0x9d,0xff,0x66,0x01,0x9b,0xff,  \
    0x59,0x01,0x9a,0xff,0x4d,0x01,0x99,0xff,0x40,0x01,0x98,0xff,0x34,0x01,0x97,0xff,0x27,0x01,0x96,0xff,0x1a,0x01,0x95,0xff,0x0d,0x01,0x94,0xff,0x01,0x01,0x93,0xff,0xf4,0x00,0x92,0xff,0xe7,0x00,0x91,0xff,0xdb,0x00,0x90,0xff,0xce,0x00,0x8f,0xff,0xc1,0x00,0x8f,0xff,0xb5,0x00,0x8e,0xff,0xa8,0x00,0x8d,0xff,0x9c,0x00,0x8d,0xff,0x8f,0x00,0x8c,0xff,0x82,0x00,0x8b,0xff,0x76,0x00,0x8b,0xff,0x69,0x00,0x8a,0xff,0x5d,0x00,0x8a,0xff,0x50,0x00,0x8a,0xff,0x43,0x00,  \
    0x89,0xff,0x37,0x00,0x89,0xff,0x2a,0x00,0x89,0xff,0x1e,0x00,0x88,0xff,0x11,0x00,0x88,0xff,0x05,0x00,0x88,0xff,0xf8,0xff,0x88,0xff,0xec,0xff,0x88,0xff,0xdf,0xff,0x88,0xff,0xd2,0xff,0x88,0xff,0xc6,0xff,0x88,0xff,0xb9,0xff,0x88,0xff,0xad,0xff,0x88,0xff,0xa0,0xff,0x88,0xff,0x94,0xff,0x88,0xff,0x87,0xff,0x88,0xff,0x7b,0xff,0x88,0xff,0x6e,0xff,0x89,0xff,0x62,0xff,0x89,0xff,0x55,0xff,0x89,0xff,0x49,0xff,0x8a,0xff,0x3c,0xff,0x8a,0xff,0x2f,0xff,0x8a,0xff,  \
    0x23,0xff,0x8b,0xff,0x16,0xff,0x8b,0xff,0x0a,0xff,0x8c,0xff,0xfd,0xfe,0x8d,0xff,0xf1,0xfe,0x8d,0xff,0xe4,0xfe,0x8e,0xff,0xd7,0xfe,0x8f,0xff,0xcb,0xfe,0x8f,0xff,0xbe,0xfe,0x90,0xff,0xb2,0xfe,0x91,0xff,0xa5,0xfe,0x92,0xff,0x98,0xfe,0x93,0xff,0x8c,0xfe,0x94,0xff,0x7f,0xfe,0x95,0xff,0x73,0xfe,0x96,0xff,0x66,0xfe,0x97,0xff,0x59,0xfe,0x98,0xff,0x4c,0xfe,0x99,0xff,0x40,0xfe,0x9a,0xff,0x33,0xfe,0x9b,0xff,0x26,0xfe,0x9c,0xff,0x19,0xfe,0x9e,0xff,0x0c,0xfe,  \
    0x9f,0xff,0xff,0xfd,0xa0,0xff,0xf3,0xfd,0xa2,0xff,0xe6,0xfd,0xa3,0xff,0xd9,0xfd,0xa4,0xff,0xcc,0xfd,0xa6,0xff,0xbf,0xfd,0xa7,0xff,0xb2,0xfd,0xa9,0xff,0xa5,0xfd,0xaa,0xff,0x98,0xfd,0xac,0xff,0x8b,0xfd,0xae,0xff,0x7e,0xfd,0xaf,0xff,0x71,0xfd,0xb1,0xff,0x64,0xfd,0xb3,0xff,0x57,0xfd,0xb5,0xff,0x49,0xfd,0xb6,0xff,0x3c,0xfd,0xb8,0xff,0x2f,0xfd,0xba,0xff,0x22,0xfd,0xbc,0xff,0x15,0xfd,0xbe,0xff,0x07,0xfd,0xc0,0xff,0xfa,0xfc,0xc2,0xff,0xed,0xfc,0xc4,0xff,  \
    0xe0,0xfc,0xc6,0xff,0xd3,0xfc,0xc8,0xff,0xc5,0xfc,0xcb,0xff,0xb8,0xfc,0xcd,0xff,0xab,0xfc,0xcf,0xff,0x9e,0xfc,0xd1,0xff,0x90,0xfc,0xd4,0xff,0x83,0xfc,0xd6,0xff,0x76,0xfc,0xd9,0xff,0x68,0xfc,0xdb,0xff,0x5b,0xfc,0xdd,0xff,0x4d,0xfc,0xe0,0xff,0x40,0xfc,0xe2,0xff,0x32,0xfc,0xe5,0xff,0x25,0xfc,0xe8,0xff,0x17,0xfc,0xea,0xff,0x0a,0xfc,0xed,0xff,0xfc,0xfb,0xf0,0xff,0xee,0xfb,0xf2,0xff,0xe1,0xfb,0xf5,0xff,0xd3,0xfb,0xf8,0xff,0xc5,0xfb,0xfb,0xff,0xb7,0xfb,  \
    0xfe,0xff,0xa9,0xfb,0x01,0x00,0x9c,0xfb,0x04,0x00,0x8d,0xfb,0x07,0x00,0x7f,0xfb,0x09,0x00,0x71,0xfb,0x0d,0x00,0x63,0xfb,0x10,0x00,0x55,0xfb,0x13,0x00,0x46,0xfb,0x16,0x00,0x38,0xfb,0x19,0x00,0x2a,0xfb,0x1c,0x00,0x1b,0xfb,0x1f,0x00,0x0d,0xfb,0x22,0x00,0xfe,0xfa,0x26,0x00,0xf0,0xfa,0x29,0x00,0xe1,0xfa,0x2c,0x00,0xd3,0xfa,0x30,0x00,0xc4,0xfa,0x33,0x00,0xb5,0xfa,0x37,0x00,0xa7,0xfa,0x3a,0x00,0x98,0xfa,0x3d,0x00,0x89,0xfa,0x41,0x00,0x7a,0xfa,0x44,0x00,  \
    0x6b,0xfa,0x48,0x00,0x5c,0xfa,0x4c,0x00,0x4d,0xfa,0x4f,0x00,0x3e,0xfa,0x53,0x00,0x2f,0xfa,0x57,0x00,0x20,0xfa,0x5a,0x00,0x10,0xfa,0x5e,0x00,0x01,0xfa,0x62,0x00,0xf2,0xf9,0x66,0x00,0xe2,0xf9,0x69,0x00,0xd3,0xf9,0x6d,0x00,0xc4,0xf9,0x71,0x00,0xb4,0xf9,0x75,0x00,0xa5,0xf9,0x79,0x00,0x95,0xf9,0x7d,0x00,0x85,0xf9,0x81,0x00,0x75,0xf9,0x85,0x00,0x66,0xf9,0x89,0x00,0x56,0xf9,0x8d,0x00,0x46,0xf9,0x91,0x00,0x36,0xf9,0x95,0x00,0x26,0xf9,0x99,0x00,0x16,0xf9,  \
    0x9e,0x00,0x05,0xf9,0xa2,0x00,0xf5,0xf8,0xa6,0x00,0xe5,0xf8,0xaa,0x00,0xd4,0xf8,0xae,0x00,0xc4,0xf8,0xb3,0x00,0xb3,0xf8,0xb7,0x00,0xa2,0xf8,0xbb,0x00,0x92,0xf8,0xbf,0x00,0x81,0xf8,0xc4,0x00,0x70,0xf8,0xc8,0x00,0x5f,0xf8,0xcc,0x00,0x4e,0xf8,0xd1,0x00,0x3d,0xf8,0xd5,0x00,0x2b,0xf8,0xd9,0x00,0x1a,0xf8,0xde,0x00,0x09,0xf8,0xe2,0x00,0xf7,0xf7,0xe7,0x00,0xe6,0xf7,0xeb,0x00,0xd4,0xf7,0xf0,0x00,0xc2,0xf7,0xf4,0x00,0xb0,0xf7,0xf9,0x00,0x9f,0xf7,0xfd,0x00,  \
    0x8d,0xf7,0x02,0x01,0x7b,0xf7,0x06,0x01,0x69,0xf7,0x0b,0x01,0x56,0xf7,0x0f,0x01,0x44,0xf7,0x14,0x01,0x32,0xf7,0x18,0x01,0x20,0xf7,0x1d,0x01,0x0d,0xf7,0x22,0x01,0xfb,0xf6,0x26,0x01,0xe8,0xf6,0x2b,0x01,0xd5,0xf6,0x30,0x01,0xc3,0xf6,0x34,0x01,0xb0,0xf6,0x39,0x01,0x9d,0xf6,0x3e,0x01,0x8a,0xf6,0x42,0x01,0x76,0xf6,0x47,0x01,0x63,0xf6,0x4b,0x01,0x50,0xf6,0x50,0x01,0x3c,0xf6,0x55,0x01,0x29,0xf6,0x59,0x01,0x15,0xf6,0x5e,0x01,0x01,0xf6,0x63,0x01,0xee,0xf5,  \
    0x67,0x01,0xd9,0xf5,0x6c,0x01,0xc5,0xf5,0x70,0x01,0xb1,0xf5,0x75,0x01,0x9c,0xf5,0x79,0x01,0x88,0xf5,0x7e,0x01,0x73,0xf5,0x82,0x01,0x5e,0xf5,0x87,0x01,0x49,0xf5,0x8b,0x01,0x34,0xf5,0x90,0x01,0x1f,0xf5,0x94,0x01,0x0a,0xf5,0x99,0x01,0xf5,0xf4,0x9d,0x01,0xdf,0xf4,0xa2,0x01,0xca,0xf4,0xa6,0x01,0xb4,0xf4,0xab,0x01,0x9e,0xf4,0xaf,0x01,0x88,0xf4,0xb3,0x01,0x73,0xf4,0xb8,0x01,0x5d,0xf4,0xbc,0x01,0x47,0xf4,0xc1,0x01,0x31,0xf4,0xc5,0x01,0x1a,0xf4,0xc9,0x01,  \
    0x04,0xf4,0xce,0x01,0xee,0xf3,0xd2,0x01,0xd7,0xf3,0xd6,0x01,0xc1,0xf3,0xdb,0x01,0xaa,0xf3,0xdf,0x01,0x93,0xf3,0xe3,0x01,0x7c,0xf3,0xe7,0x01,0x65,0xf3,0xeb,0x01,0x4e,0xf3,0xf0,0x01,0x36,0xf3,0xf4,0x01,0x1f,0xf3,0xf8,0x01,0x07,0xf3,0xfc,0x01,0xf0,0xf2,0x00,0x02,0xd8,0xf2,0x04,0x02,0xc0,0xf2,0x08,0x02,0xa8,0xf2,0x0b,0x02,0x90,0xf2,0x0f,0x02,0x77,0xf2,0x13,0x02,0x5f,0xf2,0x17,0x02,0x46,0xf2,0x1b,0x02,0x2d,0xf2,0x1e,0x02,0x15,0xf2,0x22,0x02,0xfc,0xf1,  \
    0x25,0x02,0xe3,0xf1,0x29,0x02,0xc9,0xf1,0x2c,0x02,0xb0,0xf1,0x30,0x02,0x97,0xf1,0x33,0x02,0x7d,0xf1,0x36,0x02,0x63,0xf1,0x3a,0x02,0x49,0xf1,0x3d,0x02,0x2f,0xf1,0x40,0x02,0x15,0xf1,0x43,0x02,0xfb,0xf0,0x46,0x02,0xe0,0xf0,0x49,0x02,0xc6,0xf0,0x4c,0x02,0xab,0xf0,0x4f,0x02,0x90,0xf0,0x51,0x02,0x75,0xf0,0x54,0x02,0x5a,0xf0,0x56,0x02,0x3e,0xf0,0x59,0x02,0x23,0xf0,0x5b,0x02,0x07,0xf0,0x5e,0x02,0xeb,0xef,0x60,0x02,0xcf,0xef,0x62,0x02,0xb3,0xef,0x64,0x02,  \
    0x97,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x87,0x02,0x65,0x10,0x85,0x02,0x48,0x10,0x82,0x02,0x2c,0x10,0x80,0x02,0x10,0x10,0x7e,0x02,0xf4,0x0f,0x7b,0x02,0xd8,0x0f,0x79,0x02,0xbc,0x0f,  \
    0x76,0x02,0xa1,0x0f,0x74,0x02,0x85,0x0f,0x71,0x02,0x6a,0x0f,0x6e,0x02,0x4f,0x0f,0x6b,0x02,0x34,0x0f,0x68,0x02,0x19,0x0f,0x65,0x02,0xfe,0x0e,0x62,0x02,0xe3,0x0e,0x5f,0x02,0xc8,0x0e,0x5c,0x02,0xae,0x0e,0x59,0x02,0x94,0x0e,0x56,0x02,0x79,0x0e,0x52,0x02,0x5f,0x0e,0x4f,0x02,0x45,0x0e,0x4c,0x02,0x2b,0x0e,0x48,0x02,0x12,0x0e,0x44,0x02,0xf8,0x0d,0x41,0x02,0xdf,0x0d,0x3d,0x02,0xc6,0x0d,0x39,0x02,0xac,0x0d,0x36,0x02,0x93,0x0d,0x32,0x02,0x7b,0x0d,0x2e,0x02,  \
    0x62,0x0d,0x2a,0x02,0x49,0x0d,0x26,0x02,0x31,0x0d,0x22,0x02,0x18,0x0d,0x1e,0x02,0x00,0x0d,0x1a,0x02,0xe8,0x0c,0x16,0x02,0xd0,0x0c,0x12,0x02,0xb8,0x0c,0x0e,0x02,0xa0,0x0c,0x0a,0x02,0x88,0x0c,0x06,0x02,0x71,0x0c,0x01,0x02,0x59,0x0c,0xfd,0x01,0x42,0x0c,0xf8,0x01,0x2b,0x0c,0xf4,0x01,0x14,0x0c,0xf0,0x01,0xfd,0x0b,0xeb,0x01,0xe6,0x0b,0xe7,0x01,0xd0,0x0b,0xe2,0x01,0xb9,0x0b,0xde,0x01,0xa3,0x0b,0xd9,0x01,0x8d,0x0b,0xd4,0x01,0x76,0x0b,0xd0,0x01,0x60,0x0b,  \
    0xcb,0x01,0x4a,0x0b,0xc7,0x01,0x35,0x0b,0xc2,0x01,0x1f,0x0b,0xbd,0x01,0x09,0x0b,0xb9,0x01,0xf4,0x0a,0xb4,0x01,0xde,0x0a,0xaf,0x01,0xc9,0x0a,0xab,0x01,0xb3,0x0a,0xa6,0x01,0x9e,0x0a,0xa2,0x01,0x88,0x0a,0x9d,0x01,0x73,0x0a,0x98,0x01,0x5e,0x0a,0x94,0x01,0x49,0x0a,0x8f,0x01,0x34,0x0a,0x8b,0x01,0x1f,0x0a,0x86,0x01,0x0a,0x0a,0x81,0x01,0xf5,0x09,0x7d,0x01,0xe1,0x09,0x78,0x01,0xcc,0x09,0x73,0x01,0xb8,0x09,0x6f,0x01,0xa3,0x09,0x6a,0x01,0x8f,0x09,0x66,0x01,  \
    0x7b,0x09,0x61,0x01,0x67,0x09,0x5c,0x01,0x53,0x09,0x58,0x01,0x3f,0x09,0x53,0x01,0x2b,0x09,0x4e,0x01,0x18,0x09,0x4a,0x01,0x04,0x09,0x45,0x01,0xf1,0x08,0x40,0x01,0xdd,0x08,0x3c,0x01,0xca,0x08,0x37,0x01,0xb7,0x08,0x33,0x01,0xa4,0x08,0x2e,0x01,0x90,0x08,0x29,0x01,0x7d,0x08,0x25,0x01,0x6b,0x08,0x20,0x01,0x58,0x08,0x1c,0x01,0x45,0x08,0x17,0x01,0x32,0x08,0x13,0x01,0x20,0x08,0x0e,0x01,0x0d,0x08,0x09,0x01,0xfb,0x07,0x05,0x01,0xea,0x07,0x00,0x01,0xd8,0x07,  \
    0xfb,0x00,0xc6,0x07,0xf7,0x00,0xb4,0x07,0xf2,0x00,0xa3,0x07,0xed,0x00,0x91,0x07,0xe9,0x00,0x80,0x07,0xe4,0x00,0x6f,0x07,0xe0,0x00,0x5e,0x07,0xdb,0x00,0x4c,0x07,0xd7,0x00,0x3b,0x07,0xd2,0x00,0x2a,0x07,0xce,0x00,0x1a,0x07,0xc9,0x00,0x09,0x07,0xc5,0x00,0xf8,0x06,0xc0,0x00,0xe7,0x06,0xbc,0x00,0xd7,0x06,0xb8,0x00,0xc6,0x06,0xb3,0x00,0xb6,0x06,0xaf,0x00,0xa5,0x06,0xab,0x00,0x95,0x06,0xa6,0x00,0x84,0x06,0xa2,0x00,0x74,0x06,0x9e,0x00,0x64,0x06,0x9a,0x00,  \
    0x54,0x06,0x96,0x00,0x44,0x06,0x91,0x00,0x34,0x06,0x8d,0x00,0x24,0x06,0x89,0x00,0x14,0x06,0x85,0x00,0x04,0x06,0x81,0x00,0xf4,0x05,0x7d,0x00,0xe5,0x05,0x79,0x00,0xd5,0x05,0x75,0x00,0xc5,0x05,0x71,0x00,0xb6,0x05,0x6d,0x00,0xa6,0x05,0x69,0x00,0x97,0x05,0x65,0x00,0x88,0x05,0x62,0x00,0x78,0x05,0x5e,0x00,0x69,0x05,0x5a,0x00,0x5a,0x05,0x56,0x00,0x4b,0x05,0x53,0x00,0x3c,0x05,0x4f,0x00,0x2c,0x05,0x4b,0x00,0x1d,0x05,0x48,0x00,0x0e,0x05,0x44,0x00,0xff,0x04,  \
    0x41,0x00,0xef,0x04,0x3d,0x00,0xe0,0x04,0x3a,0x00,0xd1,0x04,0x36,0x00,0xc2,0x04,0x33,0x00,0xb4,0x04,0x30,0x00,0xa5,0x04,0x2c,0x00,0x96,0x04,0x29,0x00,0x87,0x04,0x26,0x00,0x78,0x04,0x22,0x00,0x6a,0x04,0x1f,0x00,0x5b,0x04,0x1c,0x00,0x4d,0x04,0x19,0x00,0x3e,0x04,0x16,0x00,0x30,0x04,0x13,0x00,0x21,0x04,0x0f,0x00,0x13,0x04,0x0c,0x00,0x05,0x04,0x09,0x00,0xf6,0x03,0x06,0x00,0xe8,0x03,0x03,0x00,0xda,0x03,0x01,0x00,0xcc,0x03,0xfe,0xff,0xbe,0x03,0xfb,0xff,  \
    0xb0,0x03,0xf8,0xff,0xa3,0x03,0xf5,0xff,0x95,0x03,0xf2,0xff,0x87,0x03,0xf0,0xff,0x79,0x03,0xed,0xff,0x6c,0x03,0xea,0xff,0x5e,0x03,0xe7,0xff,0x51,0x03,0xe5,0xff,0x43,0x03,0xe2,0xff,0x35,0x03,0xe0,0xff,0x28,0x03,0xdd,0xff,0x1b,0x03,0xdb,0xff,0x0d,0x03,0xd8,0xff,0x00,0x03,0xd6,0xff,0xf2,0x02,0xd4,0xff,0xe5,0x02,0xd1,0xff,0xd8,0x02,0xcf,0xff,0xca,0x02,0xcd,0xff,0xbd,0x02,0xca,0xff,0xb0,0x02,0xc8,0xff,0xa3,0x02,0xc6,0xff,0x96,0x02,0xc4,0xff,0x89,0x02,  \
    0xc2,0xff,0x7c,0x02,0xc0,0xff,0x6f,0x02,0xbe,0xff,0x62,0x02,0xbc,0xff,0x55,0x02,0xba,0xff,0x48,0x02,0xb8,0xff,0x3b,0x02,0xb6,0xff,0x2f,0x02,0xb4,0xff,0x22,0x02,0xb2,0xff,0x15,0x02,0xb1,0xff,0x08,0x02,0xaf,0xff,0xfb,0x01,0xad,0xff,0xef,0x01,0xac,0xff,0xe2,0x01,0xaa,0xff,0xd5,0x01,0xa8,0xff,0xc9,0x01,0xa7,0xff,0xbc,0x01,0xa5,0xff,0xaf,0x01,0xa4,0xff,0xa3,0x01,0xa2,0xff,0x96,0x01,0xa1,0xff,0x8a,0x01,0xa0,0xff,0x7d,0x01,0x9e,0xff,0x70,0x01,0x9d,0xff,  \
    0x64,0x01,0x9c,0xff,0x57,0x01,0x9b,0xff,0x4b,0x01,0x99,0xff,0x3e,0x01,0x98,0xff,0x31,0x01,0x97,0xff,0x25,0x01,0x96,0xff,0x18,0x01,0x95,0xff,0x0c,0x01,0x94,0xff,0xff,0x00,0x93,0xff,0xf2,0x00,0x92,0xff,0xe6,0x00,0x92,0xff,0xd9,0x00,0x91,0xff,0xcd,0x00,0x90,0xff,0xc0,0x00,0x8f,0xff,0xb3,0x00,0x8f,0xff,0xa7,0x00,0x8e,0xff,0x9a,0x00,0x8d,0xff,0x8e,0x00,0x8d,0xff,0x81,0x00,0x8c,0xff,0x75,0x00,0x8c,0xff,0x68,0x00,0x8b,0xff,0x5c,0x00,0x8b,0xff,0x4f,0x00,  \
    0x8a,0xff,0x43,0x00,0x8a,0xff,0x36,0x00,0x8a,0xff,0x2a,0x00,0x89,0xff,0x1d,0x00,0x89,0xff,0x11,0x00,0x89,0xff,0x04,0x00,0x89,0xff,0xf8,0xff,0x88,0xff,0xeb,0xff,0x88,0xff,0xdf,0xff,0x88,0xff,0xd2,0xff,0x88,0xff,0xc6,0xff,0x88,0xff,0xb9,0xff,0x88,0xff,0xad,0xff,0x88,0xff,0xa1,0xff,0x88,0xff,0x94,0xff,0x89,0xff,0x88,0xff,0x89,0xff,0x7b,0xff,0x89,0xff,0x6f,0xff,0x89,0xff,0x62,0xff,0x8a,0xff,0x56,0xff,0x8a,0xff,0x49,0xff,0x8a,0xff,0x3d,0xff,0x8b,0xff,  \
    0x30,0xff,0x8b,0xff,0x24,0xff,0x8c,0xff,0x17,0xff,0x8c,0xff,0x0b,0xff,0x8d,0xff,0xfe,0xfe,0x8d,0xff,0xf2,0xfe,0x8e,0xff,0xe5,0xfe,0x8f,0xff,0xd9,0xfe,0x8f,0xff,0xcc,0xfe,0x90,0xff,0xc0,0xfe,0x91,0xff,0xb3,0xfe,0x92,0xff,0xa7,0xfe,0x92,0xff,0x9a,0xfe,0x93,0xff,0x8e,0xfe,0x94,0xff,0x81,0xfe,0x95,0xff,0x74,0xfe,0x96,0xff,0x68,0xfe,0x97,0xff,0x5b,0xfe,0x98,0xff,0x4e,0xfe,0x99,0xff,0x42,0xfe,0x9a,0xff,0x35,0xfe,0x9c,0xff,0x28,0xfe,0x9d,0xff,0x1c,0xfe,  \
    0x9e,0xff,0x0f,0xfe,0x9f,0xff,0x02,0xfe,0xa1,0xff,0xf5,0xfd,0xa2,0xff,0xe8,0xfd,0xa3,0xff,0xdc,0xfd,0xa5,0xff,0xcf,0xfd,0xa6,0xff,0xc2,0xfd,0xa8,0xff,0xb5,0xfd,0xa9,0xff,0xa8,0xfd,0xab,0xff,0x9b,0xfd,0xac,0xff,0x8e,0xfd,0xae,0xff,0x81,0xfd,0xb0,0xff,0x74,0xfd,0xb1,0xff,0x67,0xfd,0xb3,0xff,0x5a,0xfd,0xb5,0xff,0x4d,0xfd,0xb7,0xff,0x40,0xfd,0xb8,0xff,0x33,0xfd,0xba,0xff,0x26,0xfd,0xbc,0xff,0x18,0xfd,0xbe,0xff,0x0b,0xfd,0xc0,0xff,0xfe,0xfc,0xc2,0xff,  \
    0xf1,0xfc,0xc4,0xff,0xe4,0xfc,0xc6,0xff,0xd7,0xfc,0xc8,0xff,0xca,0xfc,0xcb,0xff,0xbc,0xfc,0xcd,0xff,0xaf,0xfc,0xcf,0xff,0xa2,0xfc,0xd1,0xff,0x95,0xfc,0xd4,0xff,0x87,0xfc,0xd6,0xff,0x7a,0xfc,0xd8,0xff,0x6d,0xfc,0xdb,0xff,0x5f,0xfc,0xdd,0xff,0x52,0xfc,0xe0,0xff,0x45,0xfc,0xe2,0xff,0x37,0xfc,0xe5,0xff,0x2a,0xfc,0xe7,0xff,0x1c,0xfc,0xea,0xff,0x0f,0xfc,0xec,0xff,0x01,0xfc,0xef,0xff,0xf3,0xfb,0xf2,0xff,0xe6,0xfb,0xf5,0xff,0xd8,0xfb,0xf7,0xff,0xca,0xfb,  \
    0xfa,0xff,0xbc,0xfb,0xfd,0xff,0xaf,0xfb,0x00,0x00,0xa1,0xfb,0x03,0x00,0x93,0xfb,0x06,0x00,0x85,0xfb,0x09,0x00,0x77,0xfb,0x0c,0x00,0x68,0xfb,0x0f,0x00,0x5a,0xfb,0x12,0x00,0x4c,0xfb,0x15,0x00,0x3e,0xfb,0x18,0x00,0x2f,0xfb,0x1b,0x00,0x21,0xfb,0x1e,0x00,0x13,0xfb,0x21,0x00,0x04,0xfb,0x24,0x00,0xf6,0xfa,0x28,0x00,0xe7,0xfa,0x2b,0x00,0xd9,0xfa,0x2e,0x00,0xca,0xfa,0x32,0x00,0xbb,0xfa,0x35,0x00,0xac,0xfa,0x38,0x00,0x9e,0xfa,0x3c,0x00,0x8f,0xfa,0x3f,0x00,  \
    0x80,0xfa,0x43,0x00,0x71,0xfa,0x46,0x00,0x62,0xfa,0x4a,0x00,0x53,0xfa,0x4d,0x00,0x44,0xfa,0x51,0x00,0x35,0xfa,0x55,0x00,0x26,0xfa,0x58,0x00,0x17,0xfa,0x5c,0x00,0x07,0xfa,0x60,0x00,0xf8,0xf9,0x63,0x00,0xe9,0xf9,0x67,0x00,0xd9,0xf9,0x6b,0x00,0xca,0xf9,0x6f,0x00,0xba,0xf9,0x73,0x00,0xab,0xf9,0x77,0x00,0x9b,0xf9,0x7b,0x00,0x8c,0xf9,0x7e,0x00,0x7c,0xf9,0x82,0x00,0x6c,0xf9,0x86,0x00,0x5c,0xf9,0x8a,0x00,0x4c,0xf9,0x8e,0x00,0x3c,0xf9,0x92,0x00,0x2c,0xf9,  \
    0x97,0x00,0x1c,0xf9,0x9b,0x00,0x0c,0xf9,0x9f,0x00,0xfc,0xf8,0xa3,0x00,0xeb,0xf8,0xa7,0x00,0xdb,0xf8,0xab,0x00,0xca,0xf8,0xaf,0x00,0xba,0xf8,0xb3,0x00,0xa9,0xf8,0xb8,0x00,0x98,0xf8,0xbc,0x00,0x87,0xf8,0xc0,0x00,0x76,0xf8,0xc4,0x00,0x65,0xf8,0xc9,0x00,0x54,0xf8,0xcd,0x00,0x43,0xf8,0xd1,0x00,0x32,0xf8,0xd6,0x00,0x20,0xf8,0xda,0x00,0x0f,0xf8,0xde,0x00,0xfe,0xf7,0xe3,0x00,0xec,0xf7,0xe7,0x00,0xda,0xf7,0xeb,0x00,0xc9,0xf7,0xf0,0x00,0xb7,0xf7,0xf4,0x00,  \
    0xa5,0xf7,0xf9,0x00,0x93,0xf7,0xfd,0x00,0x81,0xf7,0x02,0x01,0x6f,0xf7,0x06,0x01,0x5d,0xf7,0x0b,0x01,0x4b,0xf7,0x0f,0x01,0x38,0xf7,0x14,0x01,0x26,0xf7,0x18,0x01,0x14,0xf7,0x1d,0x01,0x01,0xf7,0x21,0x01,0xee,0xf6,0x26,0x01,0xdc,0xf6,0x2a,0x01,0xc9,0xf6,0x2f,0x01,0xb6,0xf6,0x33,0x01,0xa3,0xf6,0x38,0x01,0x90,0xf6,0x3d,0x01,0x7d,0xf6,0x41,0x01,0x6a,0xf6,0x46,0x01,0x56,0xf6,0x4a,0x01,0x43,0xf6,0x4f,0x01,0x2f,0xf6,0x53,0x01,0x1b,0xf6,0x58,0x01,0x08,0xf6,  \
    0x5d,0x01,0xf4,0xf5,0x61,0x01,0xe0,0xf5,0x66,0x01,0xcb,0xf5,0x6a,0x01,0xb7,0xf5,0x6f,0x01,0xa2,0xf5,0x73,0x01,0x8e,0xf5,0x77,0x01,0x79,0xf5,0x7c,0x01,0x64,0xf5,0x80,0x01,0x4f,0xf5,0x85,0x01,0x3a,0xf5,0x89,0x01,0x25,0xf5,0x8e,0x01,0x10,0xf5,0x92,0x01,0xfb,0xf4,0x96,0x01,0xe5,0xf4,0x9b,0x01,0xd0,0xf4,0x9f,0x01,0xba,0xf4,0xa3,0x01,0xa4,0xf4,0xa8,0x01,0x8e,0xf4,0xac,0x01,0x79,0xf4,0xb0,0x01,0x63,0xf4,0xb5,0x01,0x4d,0xf4,0xb9,0x01,0x37,0xf4,0xbd,0x01,  \
    0x20,0xf4,0xc2,0x01,0x0a,0xf4,0xc6,0x01,0xf4,0xf3,0xca,0x01,0xdd,0xf3,0xce,0x01,0xc6,0xf3,0xd2,0x01,0xb0,0xf3,0xd7,0x01,0x99,0xf3,0xdb,0x01,0x82,0xf3,0xdf,0x01,0x6b,0xf3,0xe3,0x01,0x53,0xf3,0xe7,0x01,0x3c,0xf3,0xeb,0x01,0x25,0xf3,0xef,0x01,0x0d,0xf3,0xf3,0x01,0xf5,0xf2,0xf7,0x01,0xdd,0xf2,0xfb,0x01,0xc5,0xf2,0xff,0x01,0xad,0xf2,0x02,0x02,0x95,0xf2,0x06,0x02,0x7d,0xf2,0x0a,0x02,0x64,0xf2,0x0d,0x02,0x4c,0xf2,0x11,0x02,0x33,0xf2,0x15,0x02,0x1a,0xf2,  \
    0x18,0x02,0x01,0xf2,0x1c,0x02,0xe8,0xf1,0x1f,0x02,0xcf,0xf1,0x23,0x02,0xb5,0xf1,0x26,0x02,0x9c,0xf1,0x29,0x02,0x82,0xf1,0x2c,0x02,0x68,0xf1,0x30,0x02,0x4e,0xf1,0x33,0x02,0x34,0xf1,0x36,0x02,0x1a,0xf1,0x39,0x02,0x00,0xf1,0x3c,0x02,0xe5,0xf0,0x3f,0x02,0xcb,0xf0,0x41,0x02,0xb0,0xf0,0x44,0x02,0x95,0xf0,0x47,0x02,0x7a,0xf0,0x49,0x02,0x5f,0xf0,0x4c,0x02,0x43,0xf0,0x4e,0x02,0x28,0xf0,0x51,0x02,0x0c,0xf0,0x53,0x02,0xf0,0xef,0x55,0x02,0xd4,0xef,0x57,0x02,  \
    0xb8,0xef,0x59,0x02,0x9c,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7b,0x02,0x61,0x10,0x79,0x02,0x44,0x10,0x77,0x02,0x28,0x10,0x74,0x02,0x0c,0x10,0x72,0x02,0xf0,0x0f,0x70,0x02,0xd4,0x0f,  \
    0x6d,0x02,0xb8,0x0f,0x6b,0x02,0x9d,0x0f,0x68,0x02,0x81,0x0f,0x65,0x02,0x66,0x0f,0x63,0x02,0x4a,0x0f,0x60,0x02,0x2f,0x0f,0x5d,0x02,0x14,0x0f,0x5a,0x02,0xf9,0x0e,0x57,0x02,0xdf,0x0e,0x54,0x02,0xc4,0x0e,0x51,0x02,0xaa,0x0e,0x4e,0x02,0x8f,0x0e,0x4b,0x02,0x75,0x0e,0x47,0x02,0x5b,0x0e,0x44,0x02,0x41,0x0e,0x41,0x02,0x27,0x0e,0x3d,0x02,0x0d,0x0e,0x3a,0x02,0xf4,0x0d,0x36,0x02,0xda,0x0d,0x33,0x02,0xc1,0x0d,0x2f,0x02,0xa8,0x0d,0x2b,0x02,0x8f,0x0d,0x28,0x02,  \
    0x76,0x0d,0x24,0x02,0x5d,0x0d,0x20,0x02,0x44,0x0d,0x1c,0x02,0x2c,0x0d,0x18,0x02,0x13,0x0d,0x14,0x02,0xfb,0x0c,0x10,0x02,0xe3,0x0c,0x0c,0x02,0xcb,0x0c,0x08,0x02,0xb3,0x0c,0x04,0x02,0x9b,0x0c,0x00,0x02,0x83,0x0c,0xfc,0x01,0x6c,0x0c,0xf8,0x01,0x54,0x0c,0xf4,0x01,0x3d,0x0c,0xef,0x01,0x26,0x0c,0xeb,0x01,0x0f,0x0c,0xe7,0x01,0xf8,0x0b,0xe2,0x01,0xe1,0x0b,0xde,0x01,0xcb,0x0b,0xd9,0x01,0xb4,0x0b,0xd5,0x01,0x9e,0x0b,0xd1,0x01,0x87,0x0b,0xcc,0x01,0x71,0x0b,  \
    0xc8,0x01,0x5b,0x0b,0xc3,0x01,0x45,0x0b,0xbe,0x01,0x2f,0x0b,0xba,0x01,0x1a,0x0b,0xb5,0x01,0x04,0x0b,0xb1,0x01,0xee,0x0a,0xac,0x01,0xd9,0x0a,0xa8,0x01,0xc3,0x0a,0xa3,0x01,0xae,0x0a,0x9f,0x01,0x98,0x0a,0x9a,0x01,0x83,0x0a,0x96,0x01,0x6d,0x0a,0x91,0x01,0x58,0x0a,0x8d,0x01,0x43,0x0a,0x88,0x01,0x2e,0x0a,0x84,0x01,0x19,0x0a,0x7f,0x01,0x04,0x0a,0x7b,0x01,0xf0,0x09,0x76,0x01,0xdb,0x09,0x71,0x01,0xc7,0x09,0x6d,0x01,0xb2,0x09,0x68,0x01,0x9e,0x09,0x64,0x01,  \
    0x8a,0x09,0x5f,0x01,0x75,0x09,0x5b,0x01,0x61,0x09,0x56,0x01,0x4d,0x09,0x51,0x01,0x3a,0x09,0x4d,0x01,0x26,0x09,0x48,0x01,0x12,0x09,0x44,0x01,0xff,0x08,0x3f,0x01,0xeb,0x08,0x3b,0x01,0xd8,0x08,0x36,0x01,0xc4,0x08,0x32,0x01,0xb1,0x08,0x2d,0x01,0x9e,0x08,0x29,0x01,0x8b,0x08,0x24,0x01,0x78,0x08,0x20,0x01,0x65,0x08,0x1b,0x01,0x52,0x08,0x17,0x01,0x3f,0x08,0x12,0x01,0x2d,0x08,0x0e,0x01,0x1a,0x08,0x09,0x01,0x08,0x08,0x04,0x01,0xf6,0x07,0x00,0x01,0xe4,0x07,  \
    0xfb,0x00,0xd2,0x07,0xf7,0x00,0xc0,0x07,0xf2,0x00,0xaf,0x07,0xee,0x00,0x9d,0x07,0xe9,0x00,0x8c,0x07,0xe5,0x00,0x7a,0x07,0xe0,0x00,0x69,0x07,0xdc,0x00,0x58,0x07,0xd7,0x00,0x47,0x07,0xd3,0x00,0x36,0x07,0xce,0x00,0x25,0x07,0xca,0x00,0x14,0x07,0xc6,0x00,0x03,0x07,0xc1,0x00,0xf2,0x06,0xbd,0x00,0xe1,0x06,0xb9,0x00,0xd1,0x06,0xb4,0x00,0xc0,0x06,0xb0,0x00,0xb0,0x06,0xac,0x00,0x9f,0x06,0xa7,0x00,0x8f,0x06,0xa3,0x00,0x7f,0x06,0x9f,0x00,0x6e,0x06,0x9b,0x00,  \
    0x5e,0x06,0x97,0x00,0x4e,0x06,0x93,0x00,0x3e,0x06,0x8f,0x00,0x2e,0x06,0x8b,0x00,0x1e,0x06,0x87,0x00,0x0e,0x06,0x83,0x00,0xfe,0x05,0x7f,0x00,0xef,0x05,0x7b,0x00,0xdf,0x05,0x77,0x00,0xcf,0x05,0x73,0x00,0xc0,0x05,0x6f,0x00,0xb0,0x05,0x6b,0x00,0xa1,0x05,0x67,0x00,0x91,0x05,0x63,0x00,0x82,0x05,0x60,0x00,0x73,0x05,0x5c,0x00,0x64,0x05,0x58,0x00,0x54,0x05,0x54,0x00,0x45,0x05,0x51,0x00,0x36,0x05,0x4d,0x00,0x27,0x05,0x4a,0x00,0x17,0x05,0x46,0x00,0x08,0x05,  \
    0x43,0x00,0xf9,0x04,0x3f,0x00,0xea,0x04,0x3c,0x00,0xdb,0x04,0x38,0x00,0xcc,0x04,0x35,0x00,0xbd,0x04,0x32,0x00,0xae,0x04,0x2e,0x00,0x9f,0x04,0x2b,0x00,0x91,0x04,0x28,0x00,0x82,0x04,0x24,0x00,0x73,0x04,0x21,0x00,0x65,0x04,0x1e,0x00,0x56,0x04,0x1b,0x00,0x48,0x04,0x18,0x00,0x39,0x04,0x15,0x00,0x2b,0x04,0x12,0x00,0x1c,0x04,0x0f,0x00,0x0e,0x04,0x0c,0x00,0x00,0x04,0x09,0x00,0xf2,0x03,0x06,0x00,0xe3,0x03,0x03,0x00,0xd5,0x03,0x00,0x00,0xc8,0x03,0xfd,0xff,  \
    0xba,0x03,0xfa,0xff,0xac,0x03,0xf7,0xff,0x9e,0x03,0xf4,0xff,0x90,0x03,0xf2,0xff,0x83,0x03,0xef,0xff,0x75,0x03,0xec,0xff,0x67,0x03,0xea,0xff,0x5a,0x03,0xe7,0xff,0x4c,0x03,0xe5,0xff,0x3f,0x03,0xe2,0xff,0x31,0x03,0xdf,0xff,0x24,0x03,0xdd,0xff,0x16,0x03,0xdb,0xff,0x09,0x03,0xd8,0xff,0xfc,0x02,0xd6,0xff,0xee,0x02,0xd3,0xff,0xe1,0x02,0xd1,0xff,0xd4,0x02,0xcf,0xff,0xc7,0x02,0xcd,0xff,0xb9,0x02,0xca,0xff,0xac,0x02,0xc8,0xff,0x9f,0x02,0xc6,0xff,0x92,0x02,  \
    0xc4,0xff,0x85,0x02,0xc2,0xff,0x78,0x02,0xc0,0xff,0x6b,0x02,0xbe,0xff,0x5e,0x02,0xbc,0xff,0x52,0x02,0xba,0xff,0x45,0x02,0xb8,0xff,0x38,0x02,0xb6,0xff,0x2b,0x02,0xb5,0xff,0x1f,0x02,0xb3,0xff,0x12,0x02,0xb1,0xff,0x05,0x02,0xaf,0xff,0xf8,0x01,0xae,0xff,0xec,0x01,0xac,0xff,0xdf,0x01,0xaa,0xff,0xd3,0x01,0xa9,0xff,0xc6,0x01,0xa7,0xff,0xb9,0x01,0xa6,0xff,0xad,0x01,0xa4,0xff,0xa0,0x01,0xa3,0xff,0x94,0x01,0xa2,0xff,0x87,0x01,0xa0,0xff,0x7a,0x01,0x9f,0xff,  \
    0x6e,0x01,0x9e,0xff,0x61,0x01,0x9d,0xff,0x55,0x01,0x9b,0xff,0x48,0x01,0x9a,0xff,0x3c,0x01,0x99,0xff,0x2f,0x01,0x98,0xff,0x23,0x01,0x97,0xff,0x16,0x01,0x96,0xff,0x0a,0x01,0x95,0xff,0xfd,0x00,0x94,0xff,0xf1,0x00,0x93,0xff,0xe4,0x00,0x92,0xff,0xd7,0x00,0x92,0xff,0xcb,0x00,0x91,0xff,0xbe,0x00,0x90,0xff,0xb2,0x00,0x8f,0xff,0xa5,0x00,0x8f,0xff,0x99,0x00,0x8e,0xff,0x8d,0x00,0x8e,0xff,0x80,0x00,0x8d,0xff,0x74,0x00,0x8c,0xff,0x67,0x00,0x8c,0xff,0x5b,0x00,  \
    0x8c,0xff,0x4e,0x00,0x8b,0xff,0x42,0x00,0x8b,0xff,0x35,0x00,0x8a,0xff,0x29,0x00,0x8a,0xff,0x1d,0x00,0x8a,0xff,0x10,0x00,0x8a,0xff,0x04,0x00,0x89,0xff,0xf7,0xff,0x89,0xff,0xeb,0xff,0x89,0xff,0xdf,0xff,0x89,0xff,0xd2,0xff,0x89,0xff,0xc6,0xff,0x89,0xff,0xba,0xff,0x89,0xff,0xad,0xff,0x89,0xff,0xa1,0xff,0x89,0xff,0x94,0xff,0x8a,0xff,0x88,0xff,0x8a,0xff,0x7c,0xff,0x8a,0xff,0x6f,0xff,0x8a,0xff,0x63,0xff,0x8a,0xff,0x56,0xff,0x8b,0xff,0x4a,0xff,0x8b,0xff,  \
    0x3e,0xff,0x8c,0xff,0x31,0xff,0x8c,0xff,0x25,0xff,0x8d,0xff,0x18,0xff,0x8d,0xff,0x0c,0xff,0x8e,0xff,0x00,0xff,0x8e,0xff,0xf3,0xfe,0x8f,0xff,0xe7,0xfe,0x8f,0xff,0xda,0xfe,0x90,0xff,0xce,0xfe,0x91,0xff,0xc1,0xfe,0x92,0xff,0xb5,0xfe,0x92,0xff,0xa8,0xfe,0x93,0xff,0x9c,0xfe,0x94,0xff,0x8f,0xfe,0x95,0xff,0x83,0xfe,0x96,0xff,0x76,0xfe,0x97,0xff,0x6a,0xfe,0x98,0xff,0x5d,0xfe,0x99,0xff,0x51,0xfe,0x9a,0xff,0x44,0xfe,0x9b,0xff,0x37,0xfe,0x9c,0xff,0x2b,0xfe,  \
    0x9d,0xff,0x1e,0xfe,0x9f,0xff,0x11,0xfe,0xa0,0xff,0x05,0xfe,0xa1,0xff,0xf8,0xfd,0xa3,0xff,0xeb,0xfd,0xa4,0xff,0xde,0xfd,0xa5,0xff,0xd2,0xfd,0xa7,0xff,0xc5,0xfd,0xa8,0xff,0xb8,0xfd,0xaa,0xff,0xab,0xfd,0xab,0xff,0x9e,0xfd,0xad,0xff,0x91,0xfd,0xae,0xff,0x84,0xfd,0xb0,0xff,0x77,0xfd,0xb2,0xff,0x6a,0xfd,0xb3,0xff,0x5d,0xfd,0xb5,0xff,0x50,0xfd,0xb7,0xff,0x43,0xfd,0xb9,0xff,0x36,0xfd,0xbb,0xff,0x29,0xfd,0xbc,0xff,0x1c,0xfd,0xbe,0xff,0x0f,0xfd,0xc0,0xff,  \
    0x02,0xfd,0xc2,0xff,0xf5,0xfc,0xc4,0xff,0xe8,0xfc,0xc6,0xff,0xdb,0xfc,0xc9,0xff,0xce,0xfc,0xcb,0xff,0xc1,0xfc,0xcd,0xff,0xb3,0xfc,0xcf,0xff,0xa6,0xfc,0xd1,0xff,0x99,0xfc,0xd4,0xff,0x8c,0xfc,0xd6,0xff,0x7f,0xfc,0xd8,0xff,0x71,0xfc,0xdb,0xff,0x64,0xfc,0xdd,0xff,0x57,0xfc,0xdf,0xff,0x49,0xfc,0xe2,0xff,0x3c,0xfc,0xe4,0xff,0x2e,0xfc,0xe7,0xff,0x21,0xfc,0xe9,0xff,0x13,0xfc,0xec,0xff,0x06,0xfc,0xef,0xff,0xf8,0xfb,0xf1,0xff,0xeb,0xfb,0xf4,0xff,0xdd,0xfb,  \
    0xf7,0xff,0xcf,0xfb,0xfa,0xff,0xc2,0xfb,0xfc,0xff,0xb4,0xfb,0xff,0xff,0xa6,0xfb,0x02,0x00,0x98,0xfb,0x05,0x00,0x8a,0xfb,0x08,0x00,0x7c,0xfb,0x0b,0x00,0x6e,0xfb,0x0e,0x00,0x60,0xfb,0x11,0x00,0x51,0xfb,0x14,0x00,0x43,0xfb,0x17,0x00,0x35,0xfb,0x1a,0x00,0x27,0xfb,0x1d,0x00,0x18,0xfb,0x20,0x00,0x0a,0xfb,0x23,0x00,0xfb,0xfa,0x27,0x00,0xed,0xfa,0x2a,0x00,0xde,0xfa,0x2d,0x00,0xd0,0xfa,0x30,0x00,0xc1,0xfa,0x34,0x00,0xb2,0xfa,0x37,0x00,0xa3,0xfa,0x3a,0x00,  \
    0x95,0xfa,0x3e,0x00,0x86,0xfa,0x41,0x00,0x77,0xfa,0x45,0x00,0x68,0xfa,0x48,0x00,0x59,0xfa,0x4c,0x00,0x4a,0xfa,0x4f,0x00,0x3b,0xfa,0x53,0x00,0x2c,0xfa,0x56,0x00,0x1d,0xfa,0x5a,0x00,0x0d,0xfa,0x5e,0x00,0xfe,0xf9,0x61,0x00,0xef,0xf9,0x65,0x00,0xdf,0xf9,0x69,0x00,0xd0,0xf9,0x6d,0x00,0xc1,0xf9,0x70,0x00,0xb1,0xf9,0x74,0x00,0xa1,0xf9,0x78,0x00,0x92,0xf9,0x7c,0x00,0x82,0xf9,0x80,0x00,0x72,0xf9,0x84,0x00,0x62,0xf9,0x88,0x00,0x52,0xf9,0x8c,0x00,0x42,0xf9,  \
    0x90,0x00,0x32,0xf9,0x94,0x00,0x22,0xf9,0x98,0x00,0x12,0xf9,0x9c,0x00,0x02,0xf9,0xa0,0x00,0xf2,0xf8,0xa4,0x00,0xe1,0xf8,0xa8,0x00,0xd1,0xf8,0xac,0x00,0xc0,0xf8,0xb0,0x00,0xaf,0xf8,0xb4,0x00,0x9e,0xf8,0xb9,0x00,0x8e,0xf8,0xbd,0x00,0x7d,0xf8,0xc1,0x00,0x6c,0xf8,0xc5,0x00,0x5b,0xf8,0xc9,0x00,0x49,0xf8,0xce,0x00,0x38,0xf8,0xd2,0x00,0x27,0xf8,0xd6,0x00,0x15,0xf8,0xda,0x00,0x04,0xf8,0xdf,0x00,0xf2,0xf7,0xe3,0x00,0xe1,0xf7,0xe7,0x00,0xcf,0xf7,0xec,0x00,  \
    0xbd,0xf7,0xf0,0x00,0xab,0xf7,0xf4,0x00,0x9a,0xf7,0xf9,0x00,0x88,0xf7,0xfd,0x00,0x75,0xf7,0x01,0x01,0x63,0xf7,0x06,0x01,0x51,0xf7,0x0a,0x01,0x3f,0xf7,0x0f,0x01,0x2c,0xf7,0x13,0x01,0x1a,0xf7,0x18,0x01,0x07,0xf7,0x1c,0x01,0xf5,0xf6,0x21,0x01,0xe2,0xf6,0x25,0x01,0xcf,0xf6,0x2a,0x01,0xbc,0xf6,0x2e,0x01,0xa9,0xf6,0x33,0x01,0x96,0xf6,0x37,0x01,0x83,0xf6,0x3c,0x01,0x70,0xf6,0x40,0x01,0x5c,0xf6,0x45,0x01,0x49,0xf6,0x49,0x01,0x35,0xf6,0x4e,0x01,0x22,0xf6,  \
    0x52,0x01,0x0e,0xf6,0x57,0x01,0xfa,0xf5,0x5b,0x01,0xe6,0xf5,0x5f,0x01,0xd1,0xf5,0x64,0x01,0xbd,0xf5,0x68,0x01,0xa9,0xf5,0x6d,0x01,0x94,0xf5,0x71,0x01,0x7f,0xf5,0x75,0x01,0x6a,0xf5,0x7a,0x01,0x55,0xf5,0x7e,0x01,0x40,0xf5,0x82,0x01,0x2b,0xf5,0x87,0x01,0x16,0xf5,0x8b,0x01,0x01,0xf5,0x8f,0x01,0xeb,0xf4,0x93,0x01,0xd6,0xf4,0x98,0x01,0xc0,0xf4,0x9c,0x01,0xaa,0xf4,0xa0,0x01,0x94,0xf4,0xa4,0x01,0x7e,0xf4,0xa9,0x01,0x68,0xf4,0xad,0x01,0x52,0xf4,0xb1,0x01,  \
    0x3c,0xf4,0xb5,0x01,0x26,0xf4,0xba,0x01,0x10,0xf4,0xbe,0x01,0xf9,0xf3,0xc2,0x01,0xe3,0xf3,0xc6,0x01,0xcc,0xf3,0xca,0x01,0xb5,0xf3,0xce,0x01,0x9e,0xf3,0xd2,0x01,0x87,0xf3,0xd6,0x01,0x70,0xf3,0xda,0x01,0x59,0xf3,0xde,0x01,0x42,0xf3,0xe2,0x01,0x2a,0xf3,0xe6,0x01,0x12,0xf3,0xea,0x01,0xfb,0xf2,0xee,0x01,0xe3,0xf2,0xf2,0x01,0xcb,0xf2,0xf5,0x01,0xb3,0xf2,0xf9,0x01,0x9a,0xf2,0xfd,0x01,0x82,0xf2,0x01,0x02,0x69,0xf2,0x04,0x02,0x51,0xf2,0x08,0x02,0x38,0xf2,  \
    0x0b,0x02,0x1f,0xf2,0x0f,0x02,0x06,0xf2,0x12,0x02,0xed,0xf1,0x15,0x02,0xd4,0xf1,0x19,0x02,0xba,0xf1,0x1c,0x02,0xa1,0xf1,0x1f,0x02,0x87,0xf1,0x22,0x02,0x6d,0xf1,0x26,0x02,0x53,0xf1,0x29,0x02,0x39,0xf1,0x2c,0x02,0x1f,0xf1,0x2f,0x02,0x05,0xf1,0x31,0x02,0xea,0xf0,0x34,0x02,0xd0,0xf0,0x37,0x02,0xb5,0xf0,0x3a,0x02,0x9a,0xf0,0x3c,0x02,0x7f,0xf0,0x3f,0x02,0x63,0xf0,0x41,0x02,0x48,0xf0,0x44,0x02,0x2c,0xf0,0x46,0x02,0x11,0xf0,0x48,0x02,0xf5,0xef,0x4a,0x02,  \
    0xd9,0xef,0x4c,0x02,0xbd,0xef,0x4f,0x02,0xa1,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6f,0x02,0x5d,0x10,0x6d,0x02,0x40,0x10,0x6b,0x02,0x24,0x10,0x68,0x02,0x08,0x10,0x66,0x02,0xec,0x0f,  \
    0x64,0x02,0xd0,0x0f,0x61,0x02,0xb4,0x0f,0x5f,0x02,0x99,0x0f,0x5c,0x02,0x7d,0x0f,0x5a,0x02,0x62,0x0f,0x57,0x02,0x46,0x0f,0x54,0x02,0x2b,0x0f,0x52,0x02,0x10,0x0f,0x4f,0x02,0xf5,0x0e,0x4c,0x02,0xdb,0x0e,0x49,0x02,0xc0,0x0e,0x46,0x02,0xa5,0x0e,0x43,0x02,0x8b,0x0e,0x40,0x02,0x71,0x0e,0x3d,0x02,0x57,0x0e,0x39,0x02,0x3d,0x0e,0x36,0x02,0x23,0x0e,0x33,0x02,0x09,0x0e,0x2f,0x02,0xef,0x0d,0x2c,0x02,0xd6,0x0d,0x28,0x02,0xbd,0x0d,0x25,0x02,0xa3,0x0d,0x21,0x02,  \
    0x8a,0x0d,0x1d,0x02,0x71,0x0d,0x1a,0x02,0x59,0x0d,0x16,0x02,0x40,0x0d,0x12,0x02,0x27,0x0d,0x0e,0x02,0x0f,0x0d,0x0b,0x02,0xf6,0x0c,0x07,0x02,0xde,0x0c,0x03,0x02,0xc6,0x0c,0xff,0x01,0xae,0x0c,0xfb,0x01,0x96,0x0c,0xf7,0x01,0x7f,0x0c,0xf3,0x01,0x67,0x0c,0xef,0x01,0x4f,0x0c,0xea,0x01,0x38,0x0c,0xe6,0x01,0x21,0x0c,0xe2,0x01,0x0a,0x0c,0xde,0x01,0xf3,0x0b,0xda,0x01,0xdc,0x0b,0xd5,0x01,0xc6,0x0b,0xd1,0x01,0xaf,0x0b,0xcc,0x01,0x99,0x0b,0xc8,0x01,0x82,0x0b,  \
    0xc4,0x01,0x6c,0x0b,0xbf,0x01,0x56,0x0b,0xbb,0x01,0x40,0x0b,0xb6,0x01,0x2a,0x0b,0xb2,0x01,0x14,0x0b,0xad,0x01,0xff,0x0a,0xa9,0x01,0xe9,0x0a,0xa4,0x01,0xd4,0x0a,0xa0,0x01,0xbe,0x0a,0x9c,0x01,0xa8,0x0a,0x97,0x01,0x93,0x0a,0x93,0x01,0x7d,0x0a,0x8e,0x01,0x68,0x0a,0x8a,0x01,0x53,0x0a,0x86,0x01,0x3e,0x0a,0x81,0x01,0x29,0x0a,0x7d,0x01,0x14,0x0a,0x78,0x01,0xff,0x09,0x74,0x01,0xea,0x09,0x6f,0x01,0xd6,0x09,0x6b,0x01,0xc1,0x09,0x66,0x01,0xad,0x09,0x62,0x01,  \
    0x98,0x09,0x5d,0x01,0x84,0x09,0x59,0x01,0x70,0x09,0x54,0x01,0x5c,0x09,0x50,0x01,0x48,0x09,0x4b,0x01,0x34,0x09,0x47,0x01,0x20,0x09,0x42,0x01,0x0d,0x09,0x3e,0x01,0xf9,0x08,0x39,0x01,0xe5,0x08,0x35,0x01,0xd2,0x08,0x31,0x01,0xbf,0x08,0x2c,0x01,0xab,0x08,0x28,0x01,0x98,0x08,0x23,0x01,0x85,0x08,0x1f,0x01,0x72,0x08,0x1a,0x01,0x5f,0x08,0x16,0x01,0x4d,0x08,0x11,0x01,0x3a,0x08,0x0d,0x01,0x27,0x08,0x09,0x01,0x15,0x08,0x04,0x01,0x02,0x08,0x00,0x01,0xf0,0x07,  \
    0xfb,0x00,0xde,0x07,0xf7,0x00,0xcd,0x07,0xf2,0x00,0xbb,0x07,0xee,0x00,0xa9,0x07,0xe9,0x00,0x98,0x07,0xe5,0x00,0x86,0x07,0xe0,0x00,0x75,0x07,0xdc,0x00,0x63,0x07,0xd8,0x00,0x52,0x07,0xd3,0x00,0x41,0x07,0xcf,0x00,0x30,0x07,0xcb,0x00,0x1f,0x07,0xc6,0x00,0x0e,0x07,0xc2,0x00,0xfd,0x06,0xbe,0x00,0xec,0x06,0xb9,0x00,0xdc,0x06,0xb5,0x00,0xcb,0x06,0xb1,0x00,0xbb,0x06,0xad,0x00,0xaa,0x06,0xa8,0x00,0x9a,0x06,0xa4,0x00,0x89,0x06,0xa0,0x00,0x79,0x06,0x9c,0x00,  \
    0x69,0x06,0x98,0x00,0x58,0x06,0x94,0x00,0x48,0x06,0x90,0x00,0x38,0x06,0x8c,0x00,0x28,0x06,0x88,0x00,0x18,0x06,0x84,0x00,0x08,0x06,0x80,0x00,0xf9,0x05,0x7c,0x00,0xe9,0x05,0x78,0x00,0xd9,0x05,0x74,0x00,0xca,0x05,0x70,0x00,0xba,0x05,0x6d,0x00,0xab,0x05,0x69,0x00,0x9b,0x05,0x65,0x00,0x8c,0x05,0x61,0x00,0x7c,0x05,0x5e,0x00,0x6d,0x05,0x5a,0x00,0x5e,0x05,0x56,0x00,0x4f,0x05,0x53,0x00,0x40,0x05,0x4f,0x00,0x30,0x05,0x4b,0x00,0x21,0x05,0x48,0x00,0x12,0x05,  \
    0x45,0x00,0x03,0x05,0x41,0x00,0xf4,0x04,0x3e,0x00,0xe5,0x04,0x3a,0x00,0xd6,0x04,0x37,0x00,0xc7,0x04,0x34,0x00,0xb8,0x04,0x30,0x00,0xa9,0x04,0x2d,0x00,0x9a,0x04,0x2a,0x00,0x8c,0x04,0x27,0x00,0x7d,0x04,0x23,0x00,0x6e,0x04,0x20,0x00,0x60,0x04,0x1d,0x00,0x51,0x04,0x1a,0x00,0x43,0x04,0x17,0x00,0x34,0x04,0x14,0x00,0x26,0x04,0x11,0x00,0x18,0x04,0x0e,0x00,0x09,0x04,0x0b,0x00,0xfb,0x03,0x08,0x00,0xed,0x03,0x05,0x00,0xdf,0x03,0x02,0x00,0xd1,0x03,0xff,0xff,  \
    0xc3,0x03,0xfc,0xff,0xb5,0x03,0xfa,0xff,0xa7,0x03,0xf7,0xff,0x9a,0x03,0xf4,0xff,0x8c,0x03,0xf1,0xff,0x7e,0x03,0xef,0xff,0x71,0x03,0xec,0xff,0x63,0x03,0xe9,0xff,0x56,0x03,0xe7,0xff,0x48,0x03,0xe4,0xff,0x3b,0x03,0xe2,0xff,0x2d,0x03,0xdf,0xff,0x20,0x03,0xdd,0xff,0x12,0x03,0xdb,0xff,0x05,0x03,0xd8,0xff,0xf8,0x02,0xd6,0xff,0xea,0x02,0xd4,0xff,0xdd,0x02,0xd1,0xff,0xd0,0x02,0xcf,0xff,0xc3,0x02,0xcd,0xff,0xb6,0x02,0xcb,0xff,0xa9,0x02,0xc9,0xff,0x9b,0x02,  \
    0xc6,0xff,0x8e,0x02,0xc4,0xff,0x81,0x02,0xc2,0xff,0x75,0x02,0xc0,0xff,0x68,0x02,0xbe,0xff,0x5b,0x02,0xbc,0xff,0x4e,0x02,0xbb,0xff,0x42,0x02,0xb9,0xff,0x35,0x02,0xb7,0xff,0x28,0x02,0xb5,0xff,0x1b,0x02,0xb3,0xff,0x0f,0x02,0xb2,0xff,0x02,0x02,0xb0,0xff,0xf5,0x01,0xae,0xff,0xe9,0x01,0xad,0xff,0xdc,0x01,0xab,0xff,0xd0,0x01,0xaa,0xff,0xc3,0x01,0xa8,0xff,0xb7,0x01,0xa7,0xff,0xaa,0x01,0xa5,0xff,0x9e,0x01,0xa4,0xff,0x91,0x01,0xa2,0xff,0x85,0x01,0xa1,0xff,  \
    0x78,0x01,0xa0,0xff,0x6c,0x01,0x9f,0xff,0x5f,0x01,0x9d,0xff,0x53,0x01,0x9c,0xff,0x46,0x01,0x9b,0xff,0x3a,0x01,0x9a,0xff,0x2d,0x01,0x99,0xff,0x21,0x01,0x98,0xff,0x14,0x01,0x97,0xff,0x08,0x01,0x96,0xff,0xfb,0x00,0x95,0xff,0xef,0x00,0x94,0xff,0xe2,0x00,0x93,0xff,0xd6,0x00,0x93,0xff,0xc9,0x00,0x92,0xff,0xbd,0x00,0x91,0xff,0xb1,0x00,0x90,0xff,0xa4,0x00,0x90,0xff,0x98,0x00,0x8f,0xff,0x8b,0x00,0x8f,0xff,0x7f,0x00,0x8e,0xff,0x73,0x00,0x8d,0xff,0x66,0x00,  \
    0x8d,0xff,0x5a,0x00,0x8d,0xff,0x4e,0x00,0x8c,0xff,0x41,0x00,0x8c,0xff,0x35,0x00,0x8c,0xff,0x28,0x00,0x8b,0xff,0x1c,0x00,0x8b,0xff,0x10,0x00,0x8b,0xff,0x03,0x00,0x8b,0xff,0xf7,0xff,0x8a,0xff,0xeb,0xff,0x8a,0xff,0xdf,0xff,0x8a,0xff,0xd2,0xff,0x8a,0xff,0xc6,0xff,0x8a,0xff,0xba,0xff,0x8a,0xff,0xad,0xff,0x8a,0xff,0xa1,0xff,0x8a,0xff,0x95,0xff,0x8b,0xff,0x88,0xff,0x8b,0xff,0x7c,0xff,0x8b,0xff,0x70,0xff,0x8b,0xff,0x63,0xff,0x8c,0xff,0x57,0xff,0x8c,0xff,  \
    0x4b,0xff,0x8c,0xff,0x3e,0xff,0x8d,0xff,0x32,0xff,0x8d,0xff,0x26,0xff,0x8e,0xff,0x19,0xff,0x8e,0xff,0x0d,0xff,0x8f,0xff,0x01,0xff,0x8f,0xff,0xf4,0xfe,0x90,0xff,0xe8,0xfe,0x90,0xff,0xdc,0xfe,0x91,0xff,0xcf,0xfe,0x92,0xff,0xc3,0xfe,0x93,0xff,0xb6,0xfe,0x93,0xff,0xaa,0xfe,0x94,0xff,0x9e,0xfe,0x95,0xff,0x91,0xfe,0x96,0xff,0x85,0xfe,0x97,0xff,0x78,0xfe,0x98,0xff,0x6c,0xfe,0x99,0xff,0x5f,0xfe,0x9a,0xff,0x53,0xfe,0x9b,0xff,0x46,0xfe,0x9c,0xff,0x3a,0xfe,  \
    0x9d,0xff,0x2d,0xfe,0x9e,0xff,0x20,0xfe,0xa0,0xff,0x14,0xfe,0xa1,0xff,0x07,0xfe,0xa2,0xff,0xfa,0xfd,0xa3,0xff,0xee,0xfd,0xa5,0xff,0xe1,0xfd,0xa6,0xff,0xd4,0xfd,0xa7,0xff,0xc8,0xfd,0xa9,0xff,0xbb,0xfd,0xaa,0xff,0xae,0xfd,0xac,0xff,0xa1,0xfd,0xad,0xff,0x94,0xfd,0xaf,0xff,0x88,0xfd,0xb1,0xff,0x7b,0xfd,0xb2,0xff,0x6e,0xfd,0xb4,0xff,0x61,0xfd,0xb6,0xff,0x54,0xfd,0xb7,0xff,0x47,0xfd,0xb9,0xff,0x3a,0xfd,0xbb,0xff,0x2d,0xfd,0xbd,0xff,0x20,0xfd,0xbf,0xff,  \
    0x13,0xfd,0xc1,0xff,0x06,0xfd,0xc3,0xff,0xf9,0xfc,0xc5,0xff,0xec,0xfc,0xc7,0xff,0xdf,0xfc,0xc9,0xff,0xd2,0xfc,0xcb,0xff,0xc5,0xfc,0xcd,0xff,0xb8,0xfc,0xcf,0xff,0xaa,0xfc,0xd1,0xff,0x9d,0xfc,0xd4,0xff,0x90,0xfc,0xd6,0xff,0x83,0xfc,0xd8,0xff,0x76,0xfc,0xdb,0xff,0x68,0xfc,0xdd,0xff,0x5b,0xfc,0xdf,0xff,0x4e,0xfc,0xe2,0xff,0x40,0xfc,0xe4,0xff,0x33,0xfc,0xe7,0xff,0x25,0xfc,0xe9,0xff,0x18,0xfc,0xec,0xff,0x0b,0xfc,0xee,0xff,0xfd,0xfb,0xf1,0xff,0xef,0xfb,  \
    0xf4,0xff,0xe2,0xfb,0xf6,0xff,0xd4,0xfb,0xf9,0xff,0xc6,0xfb,0xfc,0xff,0xb9,0xfb,0xff,0xff,0xab,0xfb,0x02,0x00,0x9d,0xfb,0x04,0x00,0x8f,0xfb,0x07,0x00,0x81,0xfb,0x0a,0x00,0x73,0xfb,0x0d,0x00,0x65,0xfb,0x10,0x00,0x57,0xfb,0x13,0x00,0x48,0xfb,0x16,0x00,0x3a,0xfb,0x19,0x00,0x2c,0xfb,0x1c,0x00,0x1e,0xfb,0x1f,0x00,0x0f,0xfb,0x22,0x00,0x01,0xfb,0x25,0x00,0xf2,0xfa,0x29,0x00,0xe4,0xfa,0x2c,0x00,0xd5,0xfa,0x2f,0x00,0xc7,0xfa,0x32,0x00,0xb8,0xfa,0x36,0x00,  \
    0xa9,0xfa,0x39,0x00,0x9a,0xfa,0x3c,0x00,0x8c,0xfa,0x40,0x00,0x7d,0xfa,0x43,0x00,0x6e,0xfa,0x47,0x00,0x5f,0xfa,0x4a,0x00,0x50,0xfa,0x4e,0x00,0x41,0xfa,0x51,0x00,0x32,0xfa,0x55,0x00,0x23,0xfa,0x58,0x00,0x13,0xfa,0x5c,0x00,0x04,0xfa,0x60,0x00,0xf5,0xf9,0x63,0x00,0xe5,0xf9,0x67,0x00,0xd6,0xf9,0x6b,0x00,0xc7,0xf9,0x6e,0x00,0xb7,0xf9,0x72,0x00,0xa7,0xf9,0x76,0x00,0x98,0xf9,0x7a,0x00,0x88,0xf9,0x7d,0x00,0x78,0xf9,0x81,0x00,0x68,0xf9,0x85,0x00,0x59,0xf9,  \
    0x89,0x00,0x49,0xf9,0x8d,0x00,0x39,0xf9,0x91,0x00,0x28,0xf9,0x95,0x00,0x18,0xf9,0x99,0x00,0x08,0xf9,0x9d,0x00,0xf8,0xf8,0xa1,0x00,0xe7,0xf8,0xa5,0x00,0xd7,0xf8,0xa9,0x00,0xc6,0xf8,0xad,0x00,0xb5,0xf8,0xb1,0x00,0xa5,0xf8,0xb5,0x00,0x94,0xf8,0xb9,0x00,0x83,0xf8,0xbd,0x00,0x72,0xf8,0xc2,0x00,0x61,0xf8,0xc6,0x00,0x50,0xf8,0xca,0x00,0x3e,0xf8,0xce,0x00,0x2d,0xf8,0xd2,0x00,0x1c,0xf8,0xd6,0x00,0x0a,0xf8,0xdb,0x00,0xf9,0xf7,0xdf,0x00,0xe7,0xf7,0xe3,0x00,  \
    0xd5,0xf7,0xe7,0x00,0xc4,0xf7,0xec,0x00,0xb2,0xf7,0xf0,0x00,0xa0,0xf7,0xf4,0x00,0x8e,0xf7,0xf9,0x00,0x7c,0xf7,0xfd,0x00,0x69,0xf7,0x01,0x01,0x57,0xf7,0x06,0x01,0x45,0xf7,0x0a,0x01,0x33,0xf7,0x0e,0x01,0x20,0xf7,0x13,0x01,0x0e,0xf7,0x17,0x01,0xfb,0xf6,0x1c,0x01,0xe8,0xf6,0x20,0x01,0xd5,0xf6,0x24,0x01,0xc2,0xf6,0x29,0x01,0xaf,0xf6,0x2d,0x01,0x9c,0xf6,0x32,0x01,0x89,0xf6,0x36,0x01,0x76,0xf6,0x3a,0x01,0x62,0xf6,0x3f,0x01,0x4f,0xf6,0x43,0x01,0x3b,0xf6,  \
    0x48,0x01,0x28,0xf6,0x4c,0x01,0x14,0xf6,0x51,0x01,0x00,0xf6,0x55,0x01,0xec,0xf5,0x59,0x01,0xd7,0xf5,0x5d,0x01,0xc3,0xf5,0x62,0x01,0xae,0xf5,0x66,0x01,0x9a,0xf5,0x6a,0x01,0x85,0xf5,0x6f,0x01,0x70,0xf5,0x73,0x01,0x5b,0xf5,0x77,0x01,0x46,0xf5,0x7b,0x01,0x31,0xf5,0x80,0x01,0x1c,0xf5,0x84,0x01,0x07,0xf5,0x88,0x01,0xf1,0xf4,0x8c,0x01,0xdc,0xf4,0x91,0x01,0xc6,0xf4,0x95,0x01,0xb0,0xf4,0x99,0x01,0x9a,0xf4,0x9d,0x01,0x84,0xf4,0xa1,0x01,0x6e,0xf4,0xa5,0x01,  \
    0x58,0xf4,0xaa,0x01,0x42,0xf4,0xae,0x01,0x2c,0xf4,0xb2,0x01,0x15,0xf4,0xb6,0x01,0xff,0xf3,0xba,0x01,0xe8,0xf3,0xbe,0x01,0xd2,0xf3,0xc2,0x01,0xbb,0xf3,0xc6,0x01,0xa4,0xf3,0xca,0x01,0x8d,0xf3,0xce,0x01,0x76,0xf3,0xd2,0x01,0x5e,0xf3,0xd6,0x01,0x47,0xf3,0xda,0x01,0x2f,0xf3,0xde,0x01,0x18,0xf3,0xe1,0x01,0x00,0xf3,0xe5,0x01,0xe8,0xf2,0xe9,0x01,0xd0,0xf2,0xec,0x01,0xb8,0xf2,0xf0,0x01,0xa0,0xf2,0xf4,0x01,0x87,0xf2,0xf7,0x01,0x6f,0xf2,0xfb,0x01,0x56,0xf2,  \
    0xfe,0x01,0x3d,0xf2,0x02,0x02,0x24,0xf2,0x05,0x02,0x0b,0xf2,0x08,0x02,0xf2,0xf1,0x0c,0x02,0xd9,0xf1,0x0f,0x02,0xbf,0xf1,0x12,0x02,0xa6,0xf1,0x15,0x02,0x8c,0xf1,0x18,0x02,0x72,0xf1,0x1c,0x02,0x58,0xf1,0x1f,0x02,0x3e,0xf1,0x21,0x02,0x24,0xf1,0x24,0x02,0x0a,0xf1,0x27,0x02,0xef,0xf0,0x2a,0x02,0xd4,0xf0,0x2d,0x02,0xba,0xf0,0x2f,0x02,0x9f,0xf0,0x32,0x02,0x83,0xf0,0x34,0x02,0x68,0xf0,0x37,0x02,0x4d,0xf0,0x39,0x02,0x31,0xf0,0x3b,0x02,0x15,0xf0,0x3d,0x02,  \
    0xfa,0xef,0x40,0x02,0xde,0xef,0x42,0x02,0xc1,0xef,0x44,0x02,0xa5,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x63,0x02,0x59,0x10,0x61,0x02,0x3c,0x10,0x5f,0x02,0x20,0x10,0x5d,0x02,0x04,0x10,  \
    0x5a,0x02,0xe8,0x0f,0x58,0x02,0xcc,0x0f,0x56,0x02,0xb0,0x0f,0x53,0x02,0x95,0x0f,0x51,0x02,0x79,0x0f,0x4e,0x02,0x5e,0x0f,0x4c,0x02,0x42,0x0f,0x49,0x02,0x27,0x0f,0x46,0x02,0x0c,0x0f,0x43,0x02,0xf1,0x0e,0x41,0x02,0xd6,0x0e,0x3e,0x02,0xbc,0x0e,0x3b,0x02,0xa1,0x0e,0x38,0x02,0x87,0x0e,0x35,0x02,0x6d,0x0e,0x32,0x02,0x52,0x0e,0x2e,0x02,0x38,0x0e,0x2b,0x02,0x1e,0x0e,0x28,0x02,0x05,0x0e,0x25,0x02,0xeb,0x0d,0x21,0x02,0xd2,0x0d,0x1e,0x02,0xb8,0x0d,0x1a,0x02,  \
    0x9f,0x0d,0x17,0x02,0x86,0x0d,0x13,0x02,0x6d,0x0d,0x10,0x02,0x54,0x0d,0x0c,0x02,0x3b,0x0d,0x08,0x02,0x23,0x0d,0x05,0x02,0x0a,0x0d,0x01,0x02,0xf2,0x0c,0xfd,0x01,0xda,0x0c,0xf9,0x01,0xc2,0x0c,0xf5,0x01,0xaa,0x0c,0xf1,0x01,0x92,0x0c,0xed,0x01,0x7a,0x0c,0xe9,0x01,0x62,0x0c,0xe5,0x01,0x4b,0x0c,0xe1,0x01,0x33,0x0c,0xdd,0x01,0x1c,0x0c,0xd9,0x01,0x05,0x0c,0xd5,0x01,0xee,0x0b,0xd1,0x01,0xd7,0x0b,0xcc,0x01,0xc1,0x0b,0xc8,0x01,0xaa,0x0b,0xc4,0x01,0x94,0x0b,  \
    0xc0,0x01,0x7d,0x0b,0xbb,0x01,0x67,0x0b,0xb7,0x01,0x51,0x0b,0xb3,0x01,0x3b,0x0b,0xae,0x01,0x25,0x0b,0xaa,0x01,0x0f,0x0b,0xa5,0x01,0xfa,0x0a,0xa1,0x01,0xe4,0x0a,0x9d,0x01,0xce,0x0a,0x98,0x01,0xb9,0x0a,0x94,0x01,0xa3,0x0a,0x90,0x01,0x8e,0x0a,0x8b,0x01,0x78,0x0a,0x87,0x01,0x63,0x0a,0x83,0x01,0x4e,0x0a,0x7e,0x01,0x38,0x0a,0x7a,0x01,0x23,0x0a,0x76,0x01,0x0e,0x0a,0x71,0x01,0xfa,0x09,0x6d,0x01,0xe5,0x09,0x69,0x01,0xd0,0x09,0x64,0x01,0xbc,0x09,0x60,0x01,  \
    0xa7,0x09,0x5b,0x01,0x93,0x09,0x57,0x01,0x7f,0x09,0x53,0x01,0x6b,0x09,0x4e,0x01,0x56,0x09,0x4a,0x01,0x43,0x09,0x45,0x01,0x2f,0x09,0x41,0x01,0x1b,0x09,0x3d,0x01,0x07,0x09,0x38,0x01,0xf4,0x08,0x34,0x01,0xe0,0x08,0x2f,0x01,0xcd,0x08,0x2b,0x01,0xb9,0x08,0x27,0x01,0xa6,0x08,0x22,0x01,0x93,0x08,0x1e,0x01,0x80,0x08,0x19,0x01,0x6d,0x08,0x15,0x01,0x5a,0x08,0x11,0x01,0x47,0x08,0x0c,0x01,0x34,0x08,0x08,0x01,0x22,0x08,0x04,0x01,0x0f,0x08,0xff,0x00,0xfd,0x07,  \
    0xfb,0x00,0xeb,0x07,0xf7,0x00,0xd9,0x07,0xf2,0x00,0xc7,0x07,0xee,0x00,0xb5,0x07,0xe9,0x00,0xa4,0x07,0xe5,0x00,0x92,0x07,0xe1,0x00,0x81,0x07,0xdc,0x00,0x6f,0x07,0xd8,0x00,0x5e,0x07,0xd4,0x00,0x4d,0x07,0xcf,0x00,0x3b,0x07,0xcb,0x00,0x2a,0x07,0xc7,0x00,0x19,0x07,0xc3,0x00,0x08,0x07,0xbe,0x00,0xf8,0x06,0xba,0x00,0xe7,0x06,0xb6,0x00,0xd6,0x06,0xb2,0x00,0xc5,0x06,0xae,0x00,0xb5,0x06,0xa9,0x00,0xa4,0x06,0xa5,0x00,0x94,0x06,0xa1,0x00,0x84,0x06,0x9d,0x00,  \
    0x73,0x06,0x99,0x00,0x63,0x06,0x95,0x00,0x53,0x06,0x91,0x00,0x43,0x06,0x8d,0x00,0x33,0x06,0x89,0x00,0x23,0x06,0x85,0x00,0x13,0x06,0x81,0x00,0x03,0x06,0x7e,0x00,0xf3,0x05,0x7a,0x00,0xe3,0x05,0x76,0x00,0xd4,0x05,0x72,0x00,0xc4,0x05,0x6e,0x00,0xb4,0x05,0x6a,0x00,0xa5,0x05,0x67,0x00,0x96,0x05,0x63,0x00,0x86,0x05,0x5f,0x00,0x77,0x05,0x5c,0x00,0x68,0x05,0x58,0x00,0x58,0x05,0x54,0x00,0x49,0x05,0x51,0x00,0x3a,0x05,0x4d,0x00,0x2b,0x05,0x4a,0x00,0x1c,0x05,  \
    0x46,0x00,0x0d,0x05,0x43,0x00,0xfd,0x04,0x40,0x00,0xee,0x04,0x3c,0x00,0xdf,0x04,0x39,0x00,0xd0,0x04,0x36,0x00,0xc2,0x04,0x32,0x00,0xb3,0x04,0x2f,0x00,0xa4,0x04,0x2c,0x00,0x95,0x04,0x29,0x00,0x87,0x04,0x25,0x00,0x78,0x04,0x22,0x00,0x69,0x04,0x1f,0x00,0x5b,0x04,0x1c,0x00,0x4c,0x04,0x19,0x00,0x3e,0x04,0x16,0x00,0x2f,0x04,0x13,0x00,0x21,0x04,0x10,0x00,0x13,0x04,0x0d,0x00,0x05,0x04,0x0a,0x00,0xf6,0x03,0x07,0x00,0xe8,0x03,0x04,0x00,0xda,0x03,0x02,0x00,  \
    0xcc,0x03,0xff,0xff,0xbf,0x03,0xfc,0xff,0xb1,0x03,0xf9,0xff,0xa3,0x03,0xf7,0xff,0x95,0x03,0xf4,0xff,0x88,0x03,0xf1,0xff,0x7a,0x03,0xef,0xff,0x6c,0x03,0xec,0xff,0x5f,0x03,0xe9,0xff,0x51,0x03,0xe7,0xff,0x44,0x03,0xe4,0xff,0x36,0x03,0xe2,0xff,0x29,0x03,0xdf,0xff,0x1c,0x03,0xdd,0xff,0x0e,0x03,0xdb,0xff,0x01,0x03,0xd8,0xff,0xf4,0x02,0xd6,0xff,0xe7,0x02,0xd4,0xff,0xd9,0x02,0xd2,0xff,0xcc,0x02,0xcf,0xff,0xbf,0x02,0xcd,0xff,0xb2,0x02,0xcb,0xff,0xa5,0x02,  \
    0xc9,0xff,0x98,0x02,0xc7,0xff,0x8b,0x02,0xc5,0xff,0x7e,0x02,0xc3,0xff,0x71,0x02,0xc1,0xff,0x64,0x02,0xbf,0xff,0x58,0x02,0xbd,0xff,0x4b,0x02,0xbb,0xff,0x3e,0x02,0xb9,0xff,0x32,0x02,0xb7,0xff,0x25,0x02,0xb6,0xff,0x18,0x02,0xb4,0xff,0x0c,0x02,0xb2,0xff,0xff,0x01,0xb1,0xff,0xf3,0x01,0xaf,0xff,0xe6,0x01,0xad,0xff,0xd9,0x01,0xac,0xff,0xcd,0x01,0xaa,0xff,0xc0,0x01,0xa9,0xff,0xb4,0x01,0xa7,0xff,0xa7,0x01,0xa6,0xff,0x9b,0x01,0xa5,0xff,0x8f,0x01,0xa3,0xff,  \
    0x82,0x01,0xa2,0xff,0x76,0x01,0xa1,0xff,0x69,0x01,0xa0,0xff,0x5d,0x01,0x9e,0xff,0x50,0x01,0x9d,0xff,0x44,0x01,0x9c,0xff,0x38,0x01,0x9b,0xff,0x2b,0x01,0x9a,0xff,0x1f,0x01,0x99,0xff,0x12,0x01,0x98,0xff,0x06,0x01,0x97,0xff,0xfa,0x00,0x96,0xff,0xed,0x00,0x95,0xff,0xe1,0x00,0x95,0xff,0xd4,0x00,0x94,0xff,0xc8,0x00,0x93,0xff,0xbc,0x00,0x92,0xff,0xaf,0x00,0x92,0xff,0xa3,0x00,0x91,0xff,0x97,0x00,0x90,0xff,0x8a,0x00,0x90,0xff,0x7e,0x00,0x8f,0xff,0x72,0x00,  \
    0x8f,0xff,0x65,0x00,0x8e,0xff,0x59,0x00,0x8e,0xff,0x4d,0x00,0x8d,0xff,0x40,0x00,0x8d,0xff,0x34,0x00,0x8d,0xff,0x28,0x00,0x8c,0xff,0x1c,0x00,0x8c,0xff,0x0f,0x00,0x8c,0xff,0x03,0x00,0x8c,0xff,0xf7,0xff,0x8c,0xff,0xeb,0xff,0x8c,0xff,0xde,0xff,0x8c,0xff,0xd2,0xff,0x8c,0xff,0xc6,0xff,0x8c,0xff,0xba,0xff,0x8c,0xff,0xad,0xff,0x8c,0xff,0xa1,0xff,0x8c,0xff,0x95,0xff,0x8c,0xff,0x89,0xff,0x8c,0xff,0x7c,0xff,0x8c,0xff,0x70,0xff,0x8d,0xff,0x64,0xff,0x8d,0xff,  \
    0x58,0xff,0x8d,0xff,0x4b,0xff,0x8e,0xff,0x3f,0xff,0x8e,0xff,0x33,0xff,0x8e,0xff,0x27,0xff,0x8f,0xff,0x1a,0xff,0x8f,0xff,0x0e,0xff,0x90,0xff,0x02,0xff,0x90,0xff,0xf5,0xfe,0x91,0xff,0xe9,0xfe,0x92,0xff,0xdd,0xfe,0x92,0xff,0xd1,0xfe,0x93,0xff,0xc4,0xfe,0x94,0xff,0xb8,0xfe,0x95,0xff,0xac,0xfe,0x95,0xff,0x9f,0xfe,0x96,0xff,0x93,0xfe,0x97,0xff,0x86,0xfe,0x98,0xff,0x7a,0xfe,0x99,0xff,0x6e,0xfe,0x9a,0xff,0x61,0xfe,0x9b,0xff,0x55,0xfe,0x9c,0xff,0x48,0xfe,  \
    0x9d,0xff,0x3c,0xfe,0x9e,0xff,0x2f,0xfe,0x9f,0xff,0x23,0xfe,0xa1,0xff,0x16,0xfe,0xa2,0xff,0x0a,0xfe,0xa3,0xff,0xfd,0xfd,0xa4,0xff,0xf0,0xfd,0xa6,0xff,0xe4,0xfd,0xa7,0xff,0xd7,0xfd,0xa8,0xff,0xca,0xfd,0xaa,0xff,0xbe,0xfd,0xab,0xff,0xb1,0xfd,0xad,0xff,0xa4,0xfd,0xae,0xff,0x97,0xfd,0xb0,0xff,0x8b,0xfd,0xb1,0xff,0x7e,0xfd,0xb3,0xff,0x71,0xfd,0xb5,0xff,0x64,0xfd,0xb6,0xff,0x57,0xfd,0xb8,0xff,0x4a,0xfd,0xba,0xff,0x3d,0xfd,0xbc,0xff,0x30,0xfd,0xbd,0xff,  \
    0x23,0xfd,0xbf,0xff,0x16,0xfd,0xc1,0xff,0x0a,0xfd,0xc3,0xff,0xfd,0xfc,0xc5,0xff,0xf0,0xfc,0xc7,0xff,0xe3,0xfc,0xc9,0xff,0xd6,0xfc,0xcb,0xff,0xc9,0xfc,0xcd,0xff,0xbc,0xfc,0xd0,0xff,0xaf,0xfc,0xd2,0xff,0xa1,0xfc,0xd4,0xff,0x94,0xfc,0xd6,0xff,0x87,0xfc,0xd8,0xff,0x7a,0xfc,0xdb,0xff,0x6d,0xfc,0xdd,0xff,0x5f,0xfc,0xdf,0xff,0x52,0xfc,0xe2,0xff,0x45,0xfc,0xe4,0xff,0x37,0xfc,0xe7,0xff,0x2a,0xfc,0xe9,0xff,0x1d,0xfc,0xec,0xff,0x0f,0xfc,0xee,0xff,0x02,0xfc,  \
    0xf1,0xff,0xf4,0xfb,0xf4,0xff,0xe7,0xfb,0xf6,0xff,0xd9,0xfb,0xf9,0xff,0xcb,0xfb,0xfc,0xff,0xbe,0xfb,0xfe,0xff,0xb0,0xfb,0x01,0x00,0xa2,0xfb,0x04,0x00,0x94,0xfb,0x07,0x00,0x86,0xfb,0x0a,0x00,0x78,0xfb,0x0c,0x00,0x6a,0xfb,0x0f,0x00,0x5c,0xfb,0x12,0x00,0x4e,0xfb,0x15,0x00,0x3f,0xfb,0x18,0x00,0x31,0xfb,0x1b,0x00,0x23,0xfb,0x1e,0x00,0x15,0xfb,0x21,0x00,0x06,0xfb,0x25,0x00,0xf8,0xfa,0x28,0x00,0xe9,0xfa,0x2b,0x00,0xdb,0xfa,0x2e,0x00,0xcc,0xfa,0x31,0x00,  \
    0xbd,0xfa,0x35,0x00,0xaf,0xfa,0x38,0x00,0xa0,0xfa,0x3b,0x00,0x91,0xfa,0x3e,0x00,0x82,0xfa,0x42,0x00,0x73,0xfa,0x45,0x00,0x65,0xfa,0x49,0x00,0x56,0xfa,0x4c,0x00,0x47,0xfa,0x4f,0x00,0x37,0xfa,0x53,0x00,0x28,0xfa,0x57,0x00,0x19,0xfa,0x5a,0x00,0x0a,0xfa,0x5e,0x00,0xfb,0xf9,0x61,0x00,0xeb,0xf9,0x65,0x00,0xdc,0xf9,0x69,0x00,0xcd,0xf9,0x6c,0x00,0xbd,0xf9,0x70,0x00,0xad,0xf9,0x74,0x00,0x9e,0xf9,0x77,0x00,0x8e,0xf9,0x7b,0x00,0x7e,0xf9,0x7f,0x00,0x6e,0xf9,  \
    0x83,0x00,0x5f,0xf9,0x87,0x00,0x4f,0xf9,0x8a,0x00,0x3f,0xf9,0x8e,0x00,0x2e,0xf9,0x92,0x00,0x1e,0xf9,0x96,0x00,0x0e,0xf9,0x9a,0x00,0xfe,0xf8,0x9e,0x00,0xed,0xf8,0xa2,0x00,0xdd,0xf8,0xa6,0x00,0xcc,0xf8,0xaa,0x00,0xbc,0xf8,0xae,0x00,0xab,0xf8,0xb2,0x00,0x9a,0xf8,0xb6,0x00,0x89,0xf8,0xba,0x00,0x78,0xf8,0xbe,0x00,0x67,0xf8,0xc2,0x00,0x56,0xf8,0xc6,0x00,0x45,0xf8,0xca,0x00,0x33,0xf8,0xce,0x00,0x22,0xf8,0xd3,0x00,0x10,0xf8,0xd7,0x00,0xff,0xf7,0xdb,0x00,  \
    0xed,0xf7,0xdf,0x00,0xdc,0xf7,0xe3,0x00,0xca,0xf7,0xe8,0x00,0xb8,0xf7,0xec,0x00,0xa6,0xf7,0xf0,0x00,0x94,0xf7,0xf4,0x00,0x82,0xf7,0xf8,0x00,0x70,0xf7,0xfd,0x00,0x5d,0xf7,0x01,0x01,0x4b,0xf7,0x05,0x01,0x39,0xf7,0x0a,0x01,0x26,0xf7,0x0e,0x01,0x14,0xf7,0x12,0x01,0x01,0xf7,0x16,0x01,0xee,0xf6,0x1b,0x01,0xdb,0xf6,0x1f,0x01,0xc8,0xf6,0x23,0x01,0xb5,0xf6,0x28,0x01,0xa2,0xf6,0x2c,0x01,0x8f,0xf6,0x30,0x01,0x7c,0xf6,0x35,0x01,0x68,0xf6,0x39,0x01,0x55,0xf6,  \
    0x3d,0x01,0x41,0xf6,0x42,0x01,0x2d,0xf6,0x46,0x01,0x1a,0xf6,0x4a,0x01,0x06,0xf6,0x4f,0x01,0xf2,0xf5,0x53,0x01,0xdd,0xf5,0x57,0x01,0xc9,0xf5,0x5b,0x01,0xb4,0xf5,0x60,0x01,0xa0,0xf5,0x64,0x01,0x8b,0xf5,0x68,0x01,0x76,0xf5,0x6c,0x01,0x61,0xf5,0x70,0x01,0x4c,0xf5,0x75,0x01,0x37,0xf5,0x79,0x01,0x22,0xf5,0x7d,0x01,0x0c,0xf5,0x81,0x01,0xf7,0xf4,0x85,0x01,0xe1,0xf4,0x89,0x01,0xcc,0xf4,0x8d,0x01,0xb6,0xf4,0x92,0x01,0xa0,0xf4,0x96,0x01,0x8a,0xf4,0x9a,0x01,  \
    0x74,0xf4,0x9e,0x01,0x5e,0xf4,0xa2,0x01,0x48,0xf4,0xa6,0x01,0x31,0xf4,0xaa,0x01,0x1b,0xf4,0xae,0x01,0x04,0xf4,0xb2,0x01,0xee,0xf3,0xb6,0x01,0xd7,0xf3,0xba,0x01,0xc0,0xf3,0xbe,0x01,0xa9,0xf3,0xc2,0x01,0x92,0xf3,0xc6,0x01,0x7b,0xf3,0xc9,0x01,0x64,0xf3,0xcd,0x01,0x4c,0xf3,0xd1,0x01,0x35,0xf3,0xd5,0x01,0x1d,0xf3,0xd8,0x01,0x05,0xf3,0xdc,0x01,0xed,0xf2,0xe0,0x01,0xd5,0xf2,0xe3,0x01,0xbd,0xf2,0xe7,0x01,0xa5,0xf2,0xeb,0x01,0x8c,0xf2,0xee,0x01,0x74,0xf2,  \
    0xf1,0x01,0x5b,0xf2,0xf5,0x01,0x42,0xf2,0xf8,0x01,0x29,0xf2,0xfc,0x01,0x10,0xf2,0xff,0x01,0xf7,0xf1,0x02,0x02,0xde,0xf1,0x05,0x02,0xc4,0xf1,0x08,0x02,0xab,0xf1,0x0b,0x02,0x91,0xf1,0x0f,0x02,0x77,0xf1,0x11,0x02,0x5d,0xf1,0x14,0x02,0x43,0xf1,0x17,0x02,0x29,0xf1,0x1a,0x02,0x0e,0xf1,0x1d,0x02,0xf4,0xf0,0x20,0x02,0xd9,0xf0,0x22,0x02,0xbe,0xf0,0x25,0x02,0xa3,0xf0,0x27,0x02,0x88,0xf0,0x2a,0x02,0x6d,0xf0,0x2c,0x02,0x51,0xf0,0x2e,0x02,0x36,0xf0,0x30,0x02,  \
    0x1a,0xf0,0x33,0x02,0xfe,0xef,0x35,0x02,0xe2,0xef,0x37,0x02,0xc6,0xef,0x39,0x02,0xaa,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x57,0x02,0x55,0x10,0x55,0x02,0x39,0x10,0x53,0x02,0x1c,0x10,  \
    0x50,0x02,0x00,0x10,0x4e,0x02,0xe4,0x0f,0x4c,0x02,0xc8,0x0f,0x4a,0x02,0xac,0x0f,0x47,0x02,0x91,0x0f,0x45,0x02,0x75,0x0f,0x42,0x02,0x5a,0x0f,0x40,0x02,0x3e,0x0f,0x3d,0x02,0x23,0x0f,0x3b,0x02,0x08,0x0f,0x38,0x02,0xed,0x0e,0x35,0x02,0xd2,0x0e,0x32,0x02,0xb8,0x0e,0x2f,0x02,0x9d,0x0e,0x2c,0x02,0x83,0x0e,0x29,0x02,0x68,0x0e,0x26,0x02,0x4e,0x0e,0x23,0x02,0x34,0x0e,0x20,0x02,0x1a,0x0e,0x1d,0x02,0x01,0x0e,0x1a,0x02,0xe7,0x0d,0x16,0x02,0xce,0x0d,0x13,0x02,  \
    0xb4,0x0d,0x10,0x02,0x9b,0x0d,0x0c,0x02,0x82,0x0d,0x09,0x02,0x69,0x0d,0x05,0x02,0x50,0x0d,0x02,0x02,0x37,0x0d,0xfe,0x01,0x1f,0x0d,0xfa,0x01,0x06,0x0d,0xf7,0x01,0xee,0x0c,0xf3,0x01,0xd5,0x0c,0xef,0x01,0xbd,0x0c,0xeb,0x01,0xa5,0x0c,0xe8,0x01,0x8d,0x0c,0xe4,0x01,0x75,0x0c,0xe0,0x01,0x5e,0x0c,0xdc,0x01,0x46,0x0c,0xd8,0x01,0x2f,0x0c,0xd4,0x01,0x18,0x0c,0xd0,0x01,0x01,0x0c,0xcc,0x01,0xea,0x0b,0xc8,0x01,0xd3,0x0b,0xc4,0x01,0xbc,0x0b,0xbf,0x01,0xa5,0x0b,  \
    0xbb,0x01,0x8f,0x0b,0xb7,0x01,0x78,0x0b,0xb3,0x01,0x62,0x0b,0xaf,0x01,0x4c,0x0b,0xaa,0x01,0x36,0x0b,0xa6,0x01,0x20,0x0b,0xa2,0x01,0x0a,0x0b,0x9d,0x01,0xf5,0x0a,0x99,0x01,0xdf,0x0a,0x95,0x01,0xc9,0x0a,0x91,0x01,0xb4,0x0a,0x8c,0x01,0x9e,0x0a,0x88,0x01,0x88,0x0a,0x84,0x01,0x73,0x0a,0x80,0x01,0x5e,0x0a,0x7b,0x01,0x48,0x0a,0x77,0x01,0x33,0x0a,0x73,0x01,0x1e,0x0a,0x6f,0x01,0x09,0x0a,0x6a,0x01,0xf4,0x09,0x66,0x01,0xe0,0x09,0x62,0x01,0xcb,0x09,0x5d,0x01,  \
    0xb7,0x09,0x59,0x01,0xa2,0x09,0x55,0x01,0x8e,0x09,0x50,0x01,0x79,0x09,0x4c,0x01,0x65,0x09,0x48,0x01,0x51,0x09,0x43,0x01,0x3d,0x09,0x3f,0x01,0x29,0x09,0x3b,0x01,0x16,0x09,0x37,0x01,0x02,0x09,0x32,0x01,0xee,0x08,0x2e,0x01,0xdb,0x08,0x2a,0x01,0xc7,0x08,0x25,0x01,0xb4,0x08,0x21,0x01,0xa1,0x08,0x1d,0x01,0x8e,0x08,0x18,0x01,0x7a,0x08,0x14,0x01,0x67,0x08,0x10,0x01,0x55,0x08,0x0c,0x01,0x42,0x08,0x07,0x01,0x2f,0x08,0x03,0x01,0x1c,0x08,0xff,0x00,0x0a,0x08,  \
    0xfb,0x00,0xf7,0x07,0xf6,0x00,0xe5,0x07,0xf2,0x00,0xd4,0x07,0xee,0x00,0xc2,0x07,0xe9,0x00,0xb0,0x07,0xe5,0x00,0x9e,0x07,0xe1,0x00,0x8d,0x07,0xdc,0x00,0x7b,0x07,0xd8,0x00,0x6a,0x07,0xd4,0x00,0x58,0x07,0xd0,0x00,0x47,0x07,0xcb,0x00,0x36,0x07,0xc7,0x00,0x25,0x07,0xc3,0x00,0x14,0x07,0xbf,0x00,0x03,0x07,0xbb,0x00,0xf2,0x06,0xb7,0x00,0xe1,0x06,0xb2,0x00,0xd1,0x06,0xae,0x00,0xc0,0x06,0xaa,0x00,0xaf,0x06,0xa6,0x00,0x9f,0x06,0xa2,0x00,0x8f,0x06,0x9e,0x00,  \
    0x7e,0x06,0x9a,0x00,0x6e,0x06,0x96,0x00,0x5e,0x06,0x92,0x00,0x4d,0x06,0x8e,0x00,0x3d,0x06,0x8a,0x00,0x2d,0x06,0x87,0x00,0x1d,0x06,0x83,0x00,0x0d,0x06,0x7f,0x00,0xfd,0x05,0x7b,0x00,0xee,0x05,0x77,0x00,0xde,0x05,0x73,0x00,0xce,0x05,0x70,0x00,0xbf,0x05,0x6c,0x00,0xaf,0x05,0x68,0x00,0xa0,0x05,0x65,0x00,0x90,0x05,0x61,0x00,0x81,0x05,0x5d,0x00,0x72,0x05,0x5a,0x00,0x62,0x05,0x56,0x00,0x53,0x05,0x53,0x00,0x44,0x05,0x4f,0x00,0x35,0x05,0x4c,0x00,0x26,0x05,  \
    0x48,0x00,0x16,0x05,0x45,0x00,0x07,0x05,0x42,0x00,0xf8,0x04,0x3e,0x00,0xe9,0x04,0x3b,0x00,0xda,0x04,0x38,0x00,0xcb,0x04,0x34,0x00,0xbc,0x04,0x31,0x00,0xae,0x04,0x2e,0x00,0x9f,0x04,0x2b,0x00,0x90,0x04,0x28,0x00,0x82,0x04,0x25,0x00,0x73,0x04,0x21,0x00,0x64,0x04,0x1e,0x00,0x56,0x04,0x1b,0x00,0x47,0x04,0x18,0x00,0x39,0x04,0x15,0x00,0x2b,0x04,0x12,0x00,0x1c,0x04,0x0f,0x00,0x0e,0x04,0x0d,0x00,0x00,0x04,0x0a,0x00,0xf2,0x03,0x07,0x00,0xe4,0x03,0x04,0x00,  \
    0xd6,0x03,0x01,0x00,0xc8,0x03,0xfe,0xff,0xba,0x03,0xfc,0xff,0xac,0x03,0xf9,0xff,0x9f,0x03,0xf6,0xff,0x91,0x03,0xf4,0xff,0x83,0x03,0xf1,0xff,0x76,0x03,0xee,0xff,0x68,0x03,0xec,0xff,0x5b,0x03,0xe9,0xff,0x4d,0x03,0xe7,0xff,0x40,0x03,0xe4,0xff,0x32,0x03,0xe2,0xff,0x25,0x03,0xe0,0xff,0x18,0x03,0xdd,0xff,0x0b,0x03,0xdb,0xff,0xfd,0x02,0xd9,0xff,0xf0,0x02,0xd6,0xff,0xe3,0x02,0xd4,0xff,0xd6,0x02,0xd2,0xff,0xc9,0x02,0xd0,0xff,0xbc,0x02,0xce,0xff,0xae,0x02,  \
    0xcb,0xff,0xa1,0x02,0xc9,0xff,0x94,0x02,0xc7,0xff,0x88,0x02,0xc5,0xff,0x7b,0x02,0xc3,0xff,0x6e,0x02,0xc1,0xff,0x61,0x02,0xc0,0xff,0x54,0x02,0xbe,0xff,0x48,0x02,0xbc,0xff,0x3b,0x02,0xba,0xff,0x2f,0x02,0xb8,0xff,0x22,0x02,0xb7,0xff,0x15,0x02,0xb5,0xff,0x09,0x02,0xb3,0xff,0xfc,0x01,0xb2,0xff,0xf0,0x01,0xb0,0xff,0xe3,0x01,0xae,0xff,0xd7,0x01,0xad,0xff,0xca,0x01,0xab,0xff,0xbe,0x01,0xaa,0xff,0xb1,0x01,0xa8,0xff,0xa5,0x01,0xa7,0xff,0x98,0x01,0xa6,0xff,  \
    0x8c,0x01,0xa4,0xff,0x80,0x01,0xa3,0xff,0x73,0x01,0xa2,0xff,0x67,0x01,0xa1,0xff,0x5b,0x01,0xa0,0xff,0x4e,0x01,0x9e,0xff,0x42,0x01,0x9d,0xff,0x36,0x01,0x9c,0xff,0x29,0x01,0x9b,0xff,0x1d,0x01,0x9a,0xff,0x11,0x01,0x99,0xff,0x04,0x01,0x98,0xff,0xf8,0x00,0x97,0xff,0xeb,0x00,0x97,0xff,0xdf,0x00,0x96,0xff,0xd3,0x00,0x95,0xff,0xc7,0x00,0x94,0xff,0xba,0x00,0x94,0xff,0xae,0x00,0x93,0xff,0xa2,0x00,0x92,0xff,0x95,0x00,0x92,0xff,0x89,0x00,0x91,0xff,0x7d,0x00,  \
    0x91,0xff,0x71,0x00,0x90,0xff,0x64,0x00,0x90,0xff,0x58,0x00,0x8f,0xff,0x4c,0x00,0x8f,0xff,0x40,0x00,0x8f,0xff,0x34,0x00,0x8e,0xff,0x27,0x00,0x8e,0xff,0x1b,0x00,0x8e,0xff,0x0f,0x00,0x8d,0xff,0x03,0x00,0x8d,0xff,0xf7,0xff,0x8d,0xff,0xea,0xff,0x8d,0xff,0xde,0xff,0x8d,0xff,0xd2,0xff,0x8d,0xff,0xc6,0xff,0x8d,0xff,0xba,0xff,0x8d,0xff,0xad,0xff,0x8d,0xff,0xa1,0xff,0x8d,0xff,0x95,0xff,0x8d,0xff,0x89,0xff,0x8e,0xff,0x7d,0xff,0x8e,0xff,0x71,0xff,0x8e,0xff,  \
    0x64,0xff,0x8e,0xff,0x58,0xff,0x8f,0xff,0x4c,0xff,0x8f,0xff,0x40,0xff,0x8f,0xff,0x34,0xff,0x90,0xff,0x27,0xff,0x90,0xff,0x1b,0xff,0x91,0xff,0x0f,0xff,0x91,0xff,0x03,0xff,0x92,0xff,0xf7,0xfe,0x92,0xff,0xea,0xfe,0x93,0xff,0xde,0xfe,0x94,0xff,0xd2,0xfe,0x94,0xff,0xc6,0xfe,0x95,0xff,0xb9,0xfe,0x96,0xff,0xad,0xfe,0x97,0xff,0xa1,0xfe,0x97,0xff,0x95,0xfe,0x98,0xff,0x88,0xfe,0x99,0xff,0x7c,0xfe,0x9a,0xff,0x70,0xfe,0x9b,0xff,0x63,0xfe,0x9c,0xff,0x57,0xfe,  \
    0x9d,0xff,0x4a,0xfe,0x9e,0xff,0x3e,0xfe,0x9f,0xff,0x31,0xfe,0xa0,0xff,0x25,0xfe,0xa2,0xff,0x18,0xfe,0xa3,0xff,0x0c,0xfe,0xa4,0xff,0xff,0xfd,0xa5,0xff,0xf3,0xfd,0xa7,0xff,0xe6,0xfd,0xa8,0xff,0xda,0xfd,0xa9,0xff,0xcd,0xfd,0xab,0xff,0xc1,0xfd,0xac,0xff,0xb4,0xfd,0xae,0xff,0xa7,0xfd,0xaf,0xff,0x9a,0xfd,0xb1,0xff,0x8e,0xfd,0xb2,0xff,0x81,0xfd,0xb4,0xff,0x74,0xfd,0xb6,0xff,0x67,0xfd,0xb7,0xff,0x5b,0xfd,0xb9,0xff,0x4e,0xfd,0xbb,0xff,0x41,0xfd,0xbc,0xff,  \
    0x34,0xfd,0xbe,0xff,0x27,0xfd,0xc0,0xff,0x1a,0xfd,0xc2,0xff,0x0d,0xfd,0xc4,0xff,0x00,0xfd,0xc6,0xff,0xf3,0xfc,0xc8,0xff,0xe7,0xfc,0xca,0xff,0xda,0xfc,0xcc,0xff,0xcd,0xfc,0xce,0xff,0xc0,0xfc,0xd0,0xff,0xb3,0xfc,0xd2,0xff,0xa6,0xfc,0xd4,0xff,0x98,0xfc,0xd7,0xff,0x8b,0xfc,0xd9,0xff,0x7e,0xfc,0xdb,0xff,0x71,0xfc,0xdd,0xff,0x64,0xfc,0xe0,0xff,0x57,0xfc,0xe2,0xff,0x49,0xfc,0xe4,0xff,0x3c,0xfc,0xe7,0xff,0x2f,0xfc,0xe9,0xff,0x21,0xfc,0xec,0xff,0x14,0xfc,  \
    0xee,0xff,0x06,0xfc,0xf1,0xff,0xf9,0xfb,0xf3,0xff,0xeb,0xfb,0xf6,0xff,0xde,0xfb,0xf9,0xff,0xd0,0xfb,0xfb,0xff,0xc2,0xfb,0xfe,0xff,0xb5,0xfb,0x01,0x00,0xa7,0xfb,0x04,0x00,0x99,0xfb,0x06,0x00,0x8b,0xfb,0x09,0x00,0x7d,0xfb,0x0c,0x00,0x6f,0xfb,0x0f,0x00,0x61,0xfb,0x12,0x00,0x53,0xfb,0x15,0x00,0x45,0xfb,0x18,0x00,0x36,0xfb,0x1b,0x00,0x28,0xfb,0x1e,0x00,0x1a,0xfb,0x21,0x00,0x0b,0xfb,0x24,0x00,0xfd,0xfa,0x27,0x00,0xef,0xfa,0x2a,0x00,0xe0,0xfa,0x2d,0x00,  \
    0xd2,0xfa,0x30,0x00,0xc3,0xfa,0x33,0x00,0xb4,0xfa,0x37,0x00,0xa6,0xfa,0x3a,0x00,0x97,0xfa,0x3d,0x00,0x88,0xfa,0x40,0x00,0x79,0xfa,0x44,0x00,0x6a,0xfa,0x47,0x00,0x5b,0xfa,0x4b,0x00,0x4c,0xfa,0x4e,0x00,0x3d,0xfa,0x51,0x00,0x2e,0xfa,0x55,0x00,0x1f,0xfa,0x58,0x00,0x10,0xfa,0x5c,0x00,0x00,0xfa,0x5f,0x00,0xf1,0xf9,0x63,0x00,0xe2,0xf9,0x67,0x00,0xd2,0xf9,0x6a,0x00,0xc3,0xf9,0x6e,0x00,0xb3,0xf9,0x72,0x00,0xa4,0xf9,0x75,0x00,0x94,0xf9,0x79,0x00,0x84,0xf9,  \
    0x7d,0x00,0x74,0xf9,0x80,0x00,0x64,0xf9,0x84,0x00,0x55,0xf9,0x88,0x00,0x44,0xf9,0x8c,0x00,0x34,0xf9,0x90,0x00,0x24,0xf9,0x93,0x00,0x14,0xf9,0x97,0x00,0x04,0xf9,0x9b,0x00,0xf3,0xf8,0x9f,0x00,0xe3,0xf8,0xa3,0x00,0xd2,0xf8,0xa7,0x00,0xc2,0xf8,0xab,0x00,0xb1,0xf8,0xaf,0x00,0xa0,0xf8,0xb3,0x00,0x8f,0xf8,0xb7,0x00,0x7e,0xf8,0xbb,0x00,0x6d,0xf8,0xbf,0x00,0x5c,0xf8,0xc3,0x00,0x4b,0xf8,0xc7,0x00,0x39,0xf8,0xcb,0x00,0x28,0xf8,0xcf,0x00,0x16,0xf8,0xd3,0x00,  \
    0x05,0xf8,0xd7,0x00,0xf3,0xf7,0xdb,0x00,0xe2,0xf7,0xdf,0x00,0xd0,0xf7,0xe3,0x00,0xbe,0xf7,0xe7,0x00,0xac,0xf7,0xec,0x00,0x9a,0xf7,0xf0,0x00,0x88,0xf7,0xf4,0x00,0x76,0xf7,0xf8,0x00,0x63,0xf7,0xfc,0x00,0x51,0xf7,0x01,0x01,0x3f,0xf7,0x05,0x01,0x2c,0xf7,0x09,0x01,0x1a,0xf7,0x0d,0x01,0x07,0xf7,0x11,0x01,0xf4,0xf6,0x16,0x01,0xe1,0xf6,0x1a,0x01,0xce,0xf6,0x1e,0x01,0xbb,0xf6,0x22,0x01,0xa8,0xf6,0x27,0x01,0x95,0xf6,0x2b,0x01,0x82,0xf6,0x2f,0x01,0x6e,0xf6,  \
    0x33,0x01,0x5b,0xf6,0x38,0x01,0x47,0xf6,0x3c,0x01,0x33,0xf6,0x40,0x01,0x1f,0xf6,0x44,0x01,0x0b,0xf6,0x49,0x01,0xf7,0xf5,0x4d,0x01,0xe3,0xf5,0x51,0x01,0xce,0xf5,0x55,0x01,0xba,0xf5,0x59,0x01,0xa5,0xf5,0x5d,0x01,0x91,0xf5,0x62,0x01,0x7c,0xf5,0x66,0x01,0x67,0xf5,0x6a,0x01,0x52,0xf5,0x6e,0x01,0x3d,0xf5,0x72,0x01,0x27,0xf5,0x76,0x01,0x12,0xf5,0x7a,0x01,0xfc,0xf4,0x7e,0x01,0xe7,0xf4,0x82,0x01,0xd1,0xf4,0x86,0x01,0xbb,0xf4,0x8a,0x01,0xa5,0xf4,0x8e,0x01,  \
    0x8f,0xf4,0x92,0x01,0x79,0xf4,0x96,0x01,0x63,0xf4,0x9a,0x01,0x4d,0xf4,0x9e,0x01,0x37,0xf4,0xa2,0x01,0x20,0xf4,0xa6,0x01,0x0a,0xf4,0xaa,0x01,0xf3,0xf3,0xae,0x01,0xdc,0xf3,0xb2,0x01,0xc6,0xf3,0xb6,0x01,0xaf,0xf3,0xb9,0x01,0x98,0xf3,0xbd,0x01,0x80,0xf3,0xc1,0x01,0x69,0xf3,0xc5,0x01,0x51,0xf3,0xc8,0x01,0x3a,0xf3,0xcc,0x01,0x22,0xf3,0xd0,0x01,0x0a,0xf3,0xd3,0x01,0xf2,0xf2,0xd7,0x01,0xda,0xf2,0xda,0x01,0xc2,0xf2,0xde,0x01,0xaa,0xf2,0xe1,0x01,0x91,0xf2,  \
    0xe5,0x01,0x79,0xf2,0xe8,0x01,0x60,0xf2,0xeb,0x01,0x47,0xf2,0xef,0x01,0x2e,0xf2,0xf2,0x01,0x15,0xf2,0xf5,0x01,0xfc,0xf1,0xf8,0x01,0xe3,0xf1,0xfc,0x01,0xc9,0xf1,0xff,0x01,0xaf,0xf1,0x02,0x02,0x96,0xf1,0x05,0x02,0x7c,0xf1,0x07,0x02,0x62,0xf1,0x0a,0x02,0x48,0xf1,0x0d,0x02,0x2d,0xf1,0x10,0x02,0x13,0xf1,0x13,0x02,0xf8,0xf0,0x15,0x02,0xde,0xf0,0x18,0x02,0xc3,0xf0,0x1a,0x02,0xa8,0xf0,0x1d,0x02,0x8d,0xf0,0x1f,0x02,0x71,0xf0,0x21,0x02,0x56,0xf0,0x24,0x02,  \
    0x3a,0xf0,0x26,0x02,0x1e,0xf0,0x28,0x02,0x03,0xf0,0x2a,0x02,0xe7,0xef,0x2c,0x02,0xca,0xef,0x2e,0x02,0xae,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x49,0x02,0x52,0x10,0x47,0x02,0x35,0x10,  \
    0x45,0x02,0x19,0x10,0x43,0x02,0xfd,0x0f,0x40,0x02,0xe1,0x0f,0x3e,0x02,0xc5,0x0f,0x3c,0x02,0xa9,0x0f,0x3a,0x02,0x8d,0x0f,0x37,0x02,0x72,0x0f,0x35,0x02,0x56,0x0f,0x32,0x02,0x3b,0x0f,0x30,0x02,0x20,0x0f,0x2d,0x02,0x05,0x0f,0x2b,0x02,0xea,0x0e,0x28,0x02,0xcf,0x0e,0x25,0x02,0xb4,0x0e,0x22,0x02,0x9a,0x0e,0x20,0x02,0x7f,0x0e,0x1d,0x02,0x65,0x0e,0x1a,0x02,0x4b,0x0e,0x17,0x02,0x31,0x0e,0x14,0x02,0x17,0x0e,0x10,0x02,0xfd,0x0d,0x0d,0x02,0xe3,0x0d,0x0a,0x02,  \
    0xca,0x0d,0x07,0x02,0xb0,0x0d,0x03,0x02,0x97,0x0d,0x00,0x02,0x7e,0x0d,0xfd,0x01,0x65,0x0d,0xf9,0x01,0x4c,0x0d,0xf6,0x01,0x33,0x0d,0xf2,0x01,0x1b,0x0d,0xef,0x01,0x02,0x0d,0xeb,0x01,0xea,0x0c,0xe8,0x01,0xd1,0x0c,0xe4,0x01,0xb9,0x0c,0xe0,0x01,0xa1,0x0c,0xdd,0x01,0x89,0x0c,0xd9,0x01,0x71,0x0c,0xd5,0x01,0x5a,0x0c,0xd1,0x01,0x42,0x0c,0xcd,0x01,0x2b,0x0c,0xc9,0x01,0x13,0x0c,0xc5,0x01,0xfc,0x0b,0xc1,0x01,0xe5,0x0b,0xbd,0x01,0xce,0x0b,0xb9,0x01,0xb8,0x0b,  \
    0xb5,0x01,0xa1,0x0b,0xb1,0x01,0x8a,0x0b,0xad,0x01,0x74,0x0b,0xa9,0x01,0x5e,0x0b,0xa5,0x01,0x47,0x0b,0xa1,0x01,0x31,0x0b,0x9d,0x01,0x1b,0x0b,0x98,0x01,0x06,0x0b,0x94,0x01,0xf0,0x0a,0x90,0x01,0xda,0x0a,0x8c,0x01,0xc5,0x0a,0x88,0x01,0xaf,0x0a,0x84,0x01,0x99,0x0a,0x7f,0x01,0x84,0x0a,0x7b,0x01,0x6e,0x0a,0x77,0x01,0x59,0x0a,0x73,0x01,0x44,0x0a,0x6f,0x01,0x2e,0x0a,0x6b,0x01,0x19,0x0a,0x66,0x01,0x04,0x0a,0x62,0x01,0xf0,0x09,0x5e,0x01,0xdb,0x09,0x5a,0x01,  \
    0xc6,0x09,0x56,0x01,0xb2,0x09,0x51,0x01,0x9d,0x09,0x4d,0x01,0x89,0x09,0x49,0x01,0x74,0x09,0x45,0x01,0x60,0x09,0x41,0x01,0x4c,0x09,0x3c,0x01,0x38,0x09,0x38,0x01,0x24,0x09,0x34,0x01,0x11,0x09,0x30,0x01,0xfd,0x08,0x2b,0x01,0xe9,0x08,0x27,0x01,0xd6,0x08,0x23,0x01,0xc2,0x08,0x1f,0x01,0xaf,0x08,0x1b,0x01,0x9c,0x08,0x16,0x01,0x89,0x08,0x12,0x01,0x75,0x08,0x0e,0x01,0x62,0x08,0x0a,0x01,0x50,0x08,0x06,0x01,0x3d,0x08,0x01,0x01,0x2a,0x08,0xfd,0x00,0x17,0x08,  \
    0xf9,0x00,0x05,0x08,0xf5,0x00,0xf2,0x07,0xf1,0x00,0xe0,0x07,0xed,0x00,0xce,0x07,0xe8,0x00,0xbd,0x07,0xe4,0x00,0xab,0x07,0xe0,0x00,0x99,0x07,0xdc,0x00,0x88,0x07,0xd7,0x00,0x76,0x07,0xd3,0x00,0x65,0x07,0xcf,0x00,0x53,0x07,0xcb,0x00,0x42,0x07,0xc7,0x00,0x31,0x07,0xc3,0x00,0x20,0x07,0xbf,0x00,0x0f,0x07,0xbb,0x00,0xfe,0x06,0xb7,0x00,0xed,0x06,0xb2,0x00,0xdc,0x06,0xae,0x00,0xcb,0x06,0xaa,0x00,0xbb,0x06,0xa6,0x00,0xaa,0x06,0xa2,0x00,0x9a,0x06,0x9f,0x00,  \
    0x89,0x06,0x9b,0x00,0x79,0x06,0x97,0x00,0x68,0x06,0x93,0x00,0x58,0x06,0x8f,0x00,0x48,0x06,0x8b,0x00,0x38,0x06,0x87,0x00,0x28,0x06,0x84,0x00,0x18,0x06,0x80,0x00,0x08,0x06,0x7c,0x00,0xf8,0x05,0x78,0x00,0xe8,0x05,0x75,0x00,0xd9,0x05,0x71,0x00,0xc9,0x05,0x6d,0x00,0xb9,0x05,0x6a,0x00,0xaa,0x05,0x66,0x00,0x9a,0x05,0x62,0x00,0x8b,0x05,0x5f,0x00,0x7c,0x05,0x5b,0x00,0x6c,0x05,0x58,0x00,0x5d,0x05,0x54,0x00,0x4e,0x05,0x51,0x00,0x3f,0x05,0x4d,0x00,0x30,0x05,  \
    0x4a,0x00,0x21,0x05,0x47,0x00,0x11,0x05,0x43,0x00,0x02,0x05,0x40,0x00,0xf3,0x04,0x3d,0x00,0xe4,0x04,0x39,0x00,0xd5,0x04,0x36,0x00,0xc6,0x04,0x33,0x00,0xb8,0x04,0x30,0x00,0xa9,0x04,0x2d,0x00,0x9a,0x04,0x2a,0x00,0x8b,0x04,0x26,0x00,0x7d,0x04,0x23,0x00,0x6e,0x04,0x20,0x00,0x60,0x04,0x1d,0x00,0x51,0x04,0x1a,0x00,0x43,0x04,0x17,0x00,0x34,0x04,0x15,0x00,0x26,0x04,0x12,0x00,0x18,0x04,0x0f,0x00,0x0a,0x04,0x0c,0x00,0xfc,0x03,0x09,0x00,0xed,0x03,0x06,0x00,  \
    0xdf,0x03,0x04,0x00,0xd1,0x03,0x01,0x00,0xc4,0x03,0xfe,0xff,0xb6,0x03,0xfb,0xff,0xa8,0x03,0xf9,0xff,0x9a,0x03,0xf6,0xff,0x8d,0x03,0xf3,0xff,0x7f,0x03,0xf1,0xff,0x72,0x03,0xee,0xff,0x64,0x03,0xec,0xff,0x57,0x03,0xe9,0xff,0x49,0x03,0xe7,0xff,0x3c,0x03,0xe4,0xff,0x2f,0x03,0xe2,0xff,0x21,0x03,0xe0,0xff,0x14,0x03,0xdd,0xff,0x07,0x03,0xdb,0xff,0xf9,0x02,0xd9,0xff,0xec,0x02,0xd7,0xff,0xdf,0x02,0xd4,0xff,0xd2,0x02,0xd2,0xff,0xc5,0x02,0xd0,0xff,0xb8,0x02,  \
    0xce,0xff,0xab,0x02,0xcc,0xff,0x9e,0x02,0xca,0xff,0x91,0x02,0xc8,0xff,0x84,0x02,0xc6,0xff,0x77,0x02,0xc4,0xff,0x6b,0x02,0xc2,0xff,0x5e,0x02,0xc0,0xff,0x51,0x02,0xbe,0xff,0x45,0x02,0xbd,0xff,0x38,0x02,0xbb,0xff,0x2b,0x02,0xb9,0xff,0x1f,0x02,0xb7,0xff,0x12,0x02,0xb6,0xff,0x06,0x02,0xb4,0xff,0xf9,0x01,0xb3,0xff,0xed,0x01,0xb1,0xff,0xe0,0x01,0xaf,0xff,0xd4,0x01,0xae,0xff,0xc8,0x01,0xac,0xff,0xbb,0x01,0xab,0xff,0xaf,0x01,0xaa,0xff,0xa2,0x01,0xa8,0xff,  \
    0x96,0x01,0xa7,0xff,0x8a,0x01,0xa6,0xff,0x7d,0x01,0xa4,0xff,0x71,0x01,0xa3,0xff,0x65,0x01,0xa2,0xff,0x58,0x01,0xa1,0xff,0x4c,0x01,0xa0,0xff,0x40,0x01,0x9f,0xff,0x34,0x01,0x9e,0xff,0x27,0x01,0x9d,0xff,0x1b,0x01,0x9c,0xff,0x0f,0x01,0x9b,0xff,0x02,0x01,0x9a,0xff,0xf6,0x00,0x99,0xff,0xea,0x00,0x98,0xff,0xde,0x00,0x97,0xff,0xd1,0x00,0x97,0xff,0xc5,0x00,0x96,0xff,0xb9,0x00,0x95,0xff,0xad,0x00,0x94,0xff,0xa0,0x00,0x94,0xff,0x94,0x00,0x93,0xff,0x88,0x00,  \
    0x93,0xff,0x7c,0x00,0x92,0xff,0x70,0x00,0x92,0xff,0x63,0x00,0x91,0xff,0x57,0x00,0x91,0xff,0x4b,0x00,0x90,0xff,0x3f,0x00,0x90,0xff,0x33,0x00,0x90,0xff,0x27,0x00,0x90,0xff,0x1b,0x00,0x8f,0xff,0x0e,0x00,0x8f,0xff,0x02,0x00,0x8f,0xff,0xf6,0xff,0x8f,0xff,0xea,0xff,0x8f,0xff,0xde,0xff,0x8f,0xff,0xd2,0xff,0x8f,0xff,0xc6,0xff,0x8f,0xff,0xba,0xff,0x8f,0xff,0xae,0xff,0x8f,0xff,0xa1,0xff,0x8f,0xff,0x95,0xff,0x8f,0xff,0x89,0xff,0x8f,0xff,0x7d,0xff,0x8f,0xff,  \
    0x71,0xff,0x90,0xff,0x65,0xff,0x90,0xff,0x59,0xff,0x90,0xff,0x4d,0xff,0x91,0xff,0x41,0xff,0x91,0xff,0x34,0xff,0x91,0xff,0x28,0xff,0x92,0xff,0x1c,0xff,0x92,0xff,0x10,0xff,0x93,0xff,0x04,0xff,0x93,0xff,0xf8,0xfe,0x94,0xff,0xec,0xfe,0x95,0xff,0xdf,0xfe,0x95,0xff,0xd3,0xfe,0x96,0xff,0xc7,0xfe,0x97,0xff,0xbb,0xfe,0x97,0xff,0xaf,0xfe,0x98,0xff,0xa2,0xfe,0x99,0xff,0x96,0xfe,0x9a,0xff,0x8a,0xfe,0x9b,0xff,0x7e,0xfe,0x9c,0xff,0x71,0xfe,0x9d,0xff,0x65,0xfe,  \
    0x9e,0xff,0x59,0xfe,0x9f,0xff,0x4c,0xfe,0xa0,0xff,0x40,0xfe,0xa1,0xff,0x34,0xfe,0xa2,0xff,0x27,0xfe,0xa3,0xff,0x1b,0xfe,0xa4,0xff,0x0e,0xfe,0xa5,0xff,0x02,0xfe,0xa7,0xff,0xf5,0xfd,0xa8,0xff,0xe9,0xfd,0xa9,0xff,0xdc,0xfd,0xab,0xff,0xd0,0xfd,0xac,0xff,0xc3,0xfd,0xad,0xff,0xb7,0xfd,0xaf,0xff,0xaa,0xfd,0xb0,0xff,0x9d,0xfd,0xb2,0xff,0x91,0xfd,0xb3,0xff,0x84,0xfd,0xb5,0xff,0x77,0xfd,0xb7,0xff,0x6b,0xfd,0xb8,0xff,0x5e,0xfd,0xba,0xff,0x51,0xfd,0xbc,0xff,  \
    0x44,0xfd,0xbd,0xff,0x37,0xfd,0xbf,0xff,0x2b,0xfd,0xc1,0xff,0x1e,0xfd,0xc3,0xff,0x11,0xfd,0xc5,0xff,0x04,0xfd,0xc7,0xff,0xf7,0xfc,0xc9,0xff,0xea,0xfc,0xcb,0xff,0xdd,0xfc,0xcd,0xff,0xd0,0xfc,0xcf,0xff,0xc4,0xfc,0xd1,0xff,0xb7,0xfc,0xd3,0xff,0xaa,0xfc,0xd5,0xff,0x9c,0xfc,0xd7,0xff,0x8f,0xfc,0xd9,0xff,0x82,0xfc,0xdb,0xff,0x75,0xfc,0xde,0xff,0x68,0xfc,0xe0,0xff,0x5b,0xfc,0xe2,0xff,0x4e,0xfc,0xe5,0xff,0x40,0xfc,0xe7,0xff,0x33,0xfc,0xea,0xff,0x26,0xfc,  \
    0xec,0xff,0x18,0xfc,0xee,0xff,0x0b,0xfc,0xf1,0xff,0xfd,0xfb,0xf4,0xff,0xf0,0xfb,0xf6,0xff,0xe2,0xfb,0xf9,0xff,0xd5,0xfb,0xfb,0xff,0xc7,0xfb,0xfe,0xff,0xb9,0xfb,0x01,0x00,0xac,0xfb,0x03,0x00,0x9e,0xfb,0x06,0x00,0x90,0xfb,0x09,0x00,0x82,0xfb,0x0c,0x00,0x74,0xfb,0x0e,0x00,0x66,0xfb,0x11,0x00,0x58,0xfb,0x14,0x00,0x4a,0xfb,0x17,0x00,0x3c,0xfb,0x1a,0x00,0x2d,0xfb,0x1d,0x00,0x1f,0xfb,0x20,0x00,0x11,0xfb,0x23,0x00,0x02,0xfb,0x26,0x00,0xf4,0xfa,0x29,0x00,  \
    0xe5,0xfa,0x2c,0x00,0xd7,0xfa,0x2f,0x00,0xc8,0xfa,0x32,0x00,0xba,0xfa,0x36,0x00,0xab,0xfa,0x39,0x00,0x9c,0xfa,0x3c,0x00,0x8d,0xfa,0x3f,0x00,0x7f,0xfa,0x43,0x00,0x70,0xfa,0x46,0x00,0x61,0xfa,0x49,0x00,0x52,0xfa,0x4d,0x00,0x43,0xfa,0x50,0x00,0x34,0xfa,0x53,0x00,0x25,0xfa,0x57,0x00,0x15,0xfa,0x5a,0x00,0x06,0xfa,0x5e,0x00,0xf7,0xf9,0x61,0x00,0xe7,0xf9,0x65,0x00,0xd8,0xf9,0x68,0x00,0xc9,0xf9,0x6c,0x00,0xb9,0xf9,0x6f,0x00,0xa9,0xf9,0x73,0x00,0x9a,0xf9,  \
    0x77,0x00,0x8a,0xf9,0x7a,0x00,0x7a,0xf9,0x7e,0x00,0x6a,0xf9,0x82,0x00,0x5a,0xf9,0x86,0x00,0x4a,0xf9,0x89,0x00,0x3a,0xf9,0x8d,0x00,0x2a,0xf9,0x91,0x00,0x1a,0xf9,0x95,0x00,0x0a,0xf9,0x98,0x00,0xf9,0xf8,0x9c,0x00,0xe9,0xf8,0xa0,0x00,0xd8,0xf8,0xa4,0x00,0xc7,0xf8,0xa8,0x00,0xb7,0xf8,0xac,0x00,0xa6,0xf8,0xb0,0x00,0x95,0xf8,0xb3,0x00,0x84,0xf8,0xb7,0x00,0x73,0xf8,0xbb,0x00,0x62,0xf8,0xbf,0x00,0x50,0xf8,0xc3,0x00,0x3f,0xf8,0xc7,0x00,0x2e,0xf8,0xcb,0x00,  \
    0x1c,0xf8,0xcf,0x00,0x0b,0xf8,0xd3,0x00,0xf9,0xf7,0xd7,0x00,0xe7,0xf7,0xdb,0x00,0xd6,0xf7,0xdf,0x00,0xc4,0xf7,0xe3,0x00,0xb2,0xf7,0xe7,0x00,0xa0,0xf7,0xec,0x00,0x8e,0xf7,0xf0,0x00,0x7b,0xf7,0xf4,0x00,0x69,0xf7,0xf8,0x00,0x57,0xf7,0xfc,0x00,0x44,0xf7,0x00,0x01,0x32,0xf7,0x04,0x01,0x1f,0xf7,0x08,0x01,0x0d,0xf7,0x0d,0x01,0xfa,0xf6,0x11,0x01,0xe7,0xf6,0x15,0x01,0xd4,0xf6,0x19,0x01,0xc1,0xf6,0x1d,0x01,0xae,0xf6,0x21,0x01,0x9b,0xf6,0x26,0x01,0x87,0xf6,  \
    0x2a,0x01,0x74,0xf6,0x2e,0x01,0x60,0xf6,0x32,0x01,0x4d,0xf6,0x36,0x01,0x39,0xf6,0x3a,0x01,0x25,0xf6,0x3f,0x01,0x11,0xf6,0x43,0x01,0xfd,0xf5,0x47,0x01,0xe9,0xf5,0x4b,0x01,0xd4,0xf5,0x4f,0x01,0xc0,0xf5,0x53,0x01,0xab,0xf5,0x57,0x01,0x96,0xf5,0x5b,0x01,0x81,0xf5,0x5f,0x01,0x6c,0xf5,0x63,0x01,0x57,0xf5,0x67,0x01,0x42,0xf5,0x6b,0x01,0x2d,0xf5,0x6f,0x01,0x17,0xf5,0x73,0x01,0x02,0xf5,0x77,0x01,0xec,0xf4,0x7b,0x01,0xd7,0xf4,0x7f,0x01,0xc1,0xf4,0x83,0x01,  \
    0xab,0xf4,0x87,0x01,0x95,0xf4,0x8b,0x01,0x7f,0xf4,0x8f,0x01,0x69,0xf4,0x93,0x01,0x52,0xf4,0x97,0x01,0x3c,0xf4,0x9a,0x01,0x26,0xf4,0x9e,0x01,0x0f,0xf4,0xa2,0x01,0xf8,0xf3,0xa6,0x01,0xe2,0xf3,0xaa,0x01,0xcb,0xf3,0xad,0x01,0xb4,0xf3,0xb1,0x01,0x9d,0xf3,0xb5,0x01,0x85,0xf3,0xb9,0x01,0x6e,0xf3,0xbc,0x01,0x57,0xf3,0xc0,0x01,0x3f,0xf3,0xc3,0x01,0x27,0xf3,0xc7,0x01,0x0f,0xf3,0xca,0x01,0xf7,0xf2,0xce,0x01,0xdf,0xf2,0xd1,0x01,0xc7,0xf2,0xd5,0x01,0xaf,0xf2,  \
    0xd8,0x01,0x96,0xf2,0xdc,0x01,0x7e,0xf2,0xdf,0x01,0x65,0xf2,0xe2,0x01,0x4c,0xf2,0xe5,0x01,0x33,0xf2,0xe9,0x01,0x1a,0xf2,0xec,0x01,0x01,0xf2,0xef,0x01,0xe7,0xf1,0xf2,0x01,0xce,0xf1,0xf5,0x01,0xb4,0xf1,0xf8,0x01,0x9a,0xf1,0xfb,0x01,0x80,0xf1,0xfe,0x01,0x66,0xf1,0x00,0x02,0x4c,0xf1,0x03,0x02,0x32,0xf1,0x06,0x02,0x18,0xf1,0x08,0x02,0xfd,0xf0,0x0b,0x02,0xe2,0xf0,0x0e,0x02,0xc7,0xf0,0x10,0x02,0xac,0xf0,0x12,0x02,0x91,0xf0,0x15,0x02,0x76,0xf0,0x17,0x02,  \
    0x5a,0xf0,0x19,0x02,0x3f,0xf0,0x1b,0x02,0x23,0xf0,0x1d,0x02,0x07,0xf0,0x1f,0x02,0xeb,0xef,0x21,0x02,0xcf,0xef,0x23,0x02,0xb3,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3b,0x02,0x4f,0x10,  \
    0x39,0x02,0x32,0x10,0x37,0x02,0x16,0x10,0x35,0x02,0xf9,0x0f,0x33,0x02,0xdd,0x0f,0x31,0x02,0xc1,0x0f,0x2e,0x02,0xa6,0x0f,0x2c,0x02,0x8a,0x0f,0x2a,0x02,0x6e,0x0f,0x28,0x02,0x53,0x0f,0x25,0x02,0x37,0x0f,0x23,0x02,0x1c,0x0f,0x20,0x02,0x01,0x0f,0x1e,0x02,0xe6,0x0e,0x1b,0x02,0xcb,0x0e,0x18,0x02,0xb1,0x0e,0x16,0x02,0x96,0x0e,0x13,0x02,0x7c,0x0e,0x10,0x02,0x61,0x0e,0x0d,0x02,0x47,0x0e,0x0a,0x02,0x2d,0x0e,0x07,0x02,0x13,0x0e,0x04,0x02,0xf9,0x0d,0x01,0x02,  \
    0xe0,0x0d,0xfe,0x01,0xc6,0x0d,0xfb,0x01,0xad,0x0d,0xf7,0x01,0x93,0x0d,0xf4,0x01,0x7a,0x0d,0xf1,0x01,0x61,0x0d,0xee,0x01,0x48,0x0d,0xea,0x01,0x2f,0x0d,0xe7,0x01,0x17,0x0d,0xe3,0x01,0xfe,0x0c,0xe0,0x01,0xe6,0x0c,0xdc,0x01,0xcd,0x0c,0xd9,0x01,0xb5,0x0c,0xd5,0x01,0x9d,0x0c,0xd2,0x01,0x85,0x0c,0xce,0x01,0x6d,0x0c,0xca,0x01,0x55,0x0c,0xc6,0x01,0x3e,0x0c,0xc3,0x01,0x27,0x0c,0xbf,0x01,0x0f,0x0c,0xbb,0x01,0xf8,0x0b,0xb7,0x01,0xe1,0x0b,0xb3,0x01,0xca,0x0b,  \
    0xaf,0x01,0xb3,0x0b,0xab,0x01,0x9d,0x0b,0xa7,0x01,0x86,0x0b,0xa3,0x01,0x70,0x0b,0x9f,0x01,0x59,0x0b,0x9b,0x01,0x43,0x0b,0x97,0x01,0x2d,0x0b,0x93,0x01,0x17,0x0b,0x8f,0x01,0x01,0x0b,0x8b,0x01,0xeb,0x0a,0x87,0x01,0xd6,0x0a,0x83,0x01,0xc0,0x0a,0x7f,0x01,0xaa,0x0a,0x7b,0x01,0x95,0x0a,0x77,0x01,0x7f,0x0a,0x73,0x01,0x69,0x0a,0x6f,0x01,0x54,0x0a,0x6b,0x01,0x3f,0x0a,0x67,0x01,0x2a,0x0a,0x63,0x01,0x15,0x0a,0x5e,0x01,0x00,0x0a,0x5a,0x01,0xeb,0x09,0x56,0x01,  \
    0xd6,0x09,0x52,0x01,0xc1,0x09,0x4e,0x01,0xad,0x09,0x4a,0x01,0x98,0x09,0x46,0x01,0x84,0x09,0x42,0x01,0x70,0x09,0x3e,0x01,0x5b,0x09,0x39,0x01,0x47,0x09,0x35,0x01,0x33,0x09,0x31,0x01,0x1f,0x09,0x2d,0x01,0x0c,0x09,0x29,0x01,0xf8,0x08,0x25,0x01,0xe4,0x08,0x21,0x01,0xd1,0x08,0x1d,0x01,0xbd,0x08,0x18,0x01,0xaa,0x08,0x14,0x01,0x97,0x08,0x10,0x01,0x84,0x08,0x0c,0x01,0x70,0x08,0x08,0x01,0x5d,0x08,0x04,0x01,0x4b,0x08,0x00,0x01,0x38,0x08,0xfc,0x00,0x25,0x08,  \
    0xf8,0x00,0x12,0x08,0xf4,0x00,0x00,0x08,0xf0,0x00,0xed,0x07,0xeb,0x00,0xdb,0x07,0xe7,0x00,0xc9,0x07,0xe3,0x00,0xb8,0x07,0xdf,0x00,0xa6,0x07,0xdb,0x00,0x94,0x07,0xd7,0x00,0x83,0x07,0xd3,0x00,0x71,0x07,0xcf,0x00,0x60,0x07,0xcb,0x00,0x4e,0x07,0xc7,0x00,0x3d,0x07,0xc2,0x00,0x2c,0x07,0xbe,0x00,0x1b,0x07,0xba,0x00,0x0a,0x07,0xb6,0x00,0xf9,0x06,0xb3,0x00,0xe8,0x06,0xaf,0x00,0xd7,0x06,0xab,0x00,0xc6,0x06,0xa7,0x00,0xb6,0x06,0xa3,0x00,0xa5,0x06,0x9f,0x00,  \
    0x95,0x06,0x9b,0x00,0x84,0x06,0x97,0x00,0x74,0x06,0x93,0x00,0x63,0x06,0x90,0x00,0x53,0x06,0x8c,0x00,0x43,0x06,0x88,0x00,0x33,0x06,0x84,0x00,0x23,0x06,0x81,0x00,0x13,0x06,0x7d,0x00,0x03,0x06,0x79,0x00,0xf3,0x05,0x76,0x00,0xe3,0x05,0x72,0x00,0xd3,0x05,0x6e,0x00,0xc4,0x05,0x6b,0x00,0xb4,0x05,0x67,0x00,0xa5,0x05,0x64,0x00,0x95,0x05,0x60,0x00,0x86,0x05,0x5d,0x00,0x76,0x05,0x59,0x00,0x67,0x05,0x56,0x00,0x58,0x05,0x52,0x00,0x49,0x05,0x4f,0x00,0x3a,0x05,  \
    0x4b,0x00,0x2b,0x05,0x48,0x00,0x1c,0x05,0x45,0x00,0x0c,0x05,0x42,0x00,0xfd,0x04,0x3e,0x00,0xee,0x04,0x3b,0x00,0xdf,0x04,0x38,0x00,0xd0,0x04,0x35,0x00,0xc2,0x04,0x32,0x00,0xb3,0x04,0x2f,0x00,0xa4,0x04,0x2c,0x00,0x95,0x04,0x28,0x00,0x87,0x04,0x25,0x00,0x78,0x04,0x22,0x00,0x6a,0x04,0x1f,0x00,0x5b,0x04,0x1d,0x00,0x4d,0x04,0x1a,0x00,0x3e,0x04,0x17,0x00,0x30,0x04,0x14,0x00,0x22,0x04,0x11,0x00,0x13,0x04,0x0e,0x00,0x05,0x04,0x0b,0x00,0xf7,0x03,0x09,0x00,  \
    0xe9,0x03,0x06,0x00,0xdb,0x03,0x03,0x00,0xcd,0x03,0x00,0x00,0xbf,0x03,0xfe,0xff,0xb2,0x03,0xfb,0xff,0xa4,0x03,0xf9,0xff,0x96,0x03,0xf6,0xff,0x89,0x03,0xf3,0xff,0x7b,0x03,0xf1,0xff,0x6e,0x03,0xee,0xff,0x60,0x03,0xec,0xff,0x53,0x03,0xe9,0xff,0x45,0x03,0xe7,0xff,0x38,0x03,0xe5,0xff,0x2b,0x03,0xe2,0xff,0x1d,0x03,0xe0,0xff,0x10,0x03,0xde,0xff,0x03,0x03,0xdc,0xff,0xf6,0x02,0xd9,0xff,0xe9,0x02,0xd7,0xff,0xdc,0x02,0xd5,0xff,0xcf,0x02,0xd3,0xff,0xc2,0x02,  \
    0xd1,0xff,0xb5,0x02,0xcf,0xff,0xa8,0x02,0xcd,0xff,0x9b,0x02,0xcb,0xff,0x8e,0x02,0xc9,0xff,0x81,0x02,0xc7,0xff,0x74,0x02,0xc5,0xff,0x67,0x02,0xc3,0xff,0x5b,0x02,0xc1,0xff,0x4e,0x02,0xbf,0xff,0x42,0x02,0xbe,0xff,0x35,0x02,0xbc,0xff,0x28,0x02,0xba,0xff,0x1c,0x02,0xb8,0xff,0x0f,0x02,0xb7,0xff,0x03,0x02,0xb5,0xff,0xf7,0x01,0xb4,0xff,0xea,0x01,0xb2,0xff,0xde,0x01,0xb1,0xff,0xd1,0x01,0xaf,0xff,0xc5,0x01,0xae,0xff,0xb9,0x01,0xac,0xff,0xac,0x01,0xab,0xff,  \
    0xa0,0x01,0xaa,0xff,0x94,0x01,0xa8,0xff,0x87,0x01,0xa7,0xff,0x7b,0x01,0xa6,0xff,0x6f,0x01,0xa5,0xff,0x63,0x01,0xa3,0xff,0x56,0x01,0xa2,0xff,0x4a,0x01,0xa1,0xff,0x3e,0x01,0xa0,0xff,0x32,0x01,0x9f,0xff,0x25,0x01,0x9e,0xff,0x19,0x01,0x9d,0xff,0x0d,0x01,0x9c,0xff,0x01,0x01,0x9b,0xff,0xf4,0x00,0x9b,0xff,0xe8,0x00,0x9a,0xff,0xdc,0x00,0x99,0xff,0xd0,0x00,0x98,0xff,0xc4,0x00,0x97,0xff,0xb7,0x00,0x97,0xff,0xab,0x00,0x96,0xff,0x9f,0x00,0x96,0xff,0x93,0x00,  \
    0x95,0xff,0x87,0x00,0x94,0xff,0x7b,0x00,0x94,0xff,0x6f,0x00,0x93,0xff,0x63,0x00,0x93,0xff,0x57,0x00,0x93,0xff,0x4a,0x00,0x92,0xff,0x3e,0x00,0x92,0xff,0x32,0x00,0x92,0xff,0x26,0x00,0x91,0xff,0x1a,0x00,0x91,0xff,0x0e,0x00,0x91,0xff,0x02,0x00,0x91,0xff,0xf6,0xff,0x91,0xff,0xea,0xff,0x90,0xff,0xde,0xff,0x90,0xff,0xd2,0xff,0x90,0xff,0xc6,0xff,0x90,0xff,0xba,0xff,0x90,0xff,0xae,0xff,0x91,0xff,0xa2,0xff,0x91,0xff,0x96,0xff,0x91,0xff,0x8a,0xff,0x91,0xff,  \
    0x7e,0xff,0x91,0xff,0x71,0xff,0x91,0xff,0x65,0xff,0x92,0xff,0x59,0xff,0x92,0xff,0x4d,0xff,0x92,0xff,0x41,0xff,0x93,0xff,0x35,0xff,0x93,0xff,0x29,0xff,0x94,0xff,0x1d,0xff,0x94,0xff,0x11,0xff,0x94,0xff,0x05,0xff,0x95,0xff,0xf9,0xfe,0x96,0xff,0xed,0xfe,0x96,0xff,0xe1,0xfe,0x97,0xff,0xd5,0xfe,0x98,0xff,0xc8,0xfe,0x98,0xff,0xbc,0xfe,0x99,0xff,0xb0,0xfe,0x9a,0xff,0xa4,0xfe,0x9b,0xff,0x98,0xfe,0x9b,0xff,0x8c,0xfe,0x9c,0xff,0x7f,0xfe,0x9d,0xff,0x73,0xfe,  \
    0x9e,0xff,0x67,0xfe,0x9f,0xff,0x5b,0xfe,0xa0,0xff,0x4e,0xfe,0xa1,0xff,0x42,0xfe,0xa2,0xff,0x36,0xfe,0xa3,0xff,0x29,0xfe,0xa4,0xff,0x1d,0xfe,0xa6,0xff,0x11,0xfe,0xa7,0xff,0x04,0xfe,0xa8,0xff,0xf8,0xfd,0xa9,0xff,0xeb,0xfd,0xab,0xff,0xdf,0xfd,0xac,0xff,0xd2,0xfd,0xad,0xff,0xc6,0xfd,0xaf,0xff,0xb9,0xfd,0xb0,0xff,0xad,0xfd,0xb2,0xff,0xa0,0xfd,0xb3,0xff,0x94,0xfd,0xb5,0xff,0x87,0xfd,0xb6,0xff,0x7a,0xfd,0xb8,0xff,0x6e,0xfd,0xb9,0xff,0x61,0xfd,0xbb,0xff,  \
    0x54,0xfd,0xbd,0xff,0x48,0xfd,0xbe,0xff,0x3b,0xfd,0xc0,0xff,0x2e,0xfd,0xc2,0xff,0x21,0xfd,0xc4,0xff,0x14,0xfd,0xc6,0xff,0x08,0xfd,0xc8,0xff,0xfb,0xfc,0xc9,0xff,0xee,0xfc,0xcb,0xff,0xe1,0xfc,0xcd,0xff,0xd4,0xfc,0xcf,0xff,0xc7,0xfc,0xd1,0xff,0xba,0xfc,0xd3,0xff,0xad,0xfc,0xd6,0xff,0xa0,0xfc,0xd8,0xff,0x93,0xfc,0xda,0xff,0x86,0xfc,0xdc,0xff,0x79,0xfc,0xde,0xff,0x6c,0xfc,0xe1,0xff,0x5f,0xfc,0xe3,0xff,0x52,0xfc,0xe5,0xff,0x45,0xfc,0xe8,0xff,0x37,0xfc,  \
    0xea,0xff,0x2a,0xfc,0xec,0xff,0x1d,0xfc,0xef,0xff,0x0f,0xfc,0xf1,0xff,0x02,0xfc,0xf4,0xff,0xf4,0xfb,0xf6,0xff,0xe7,0xfb,0xf9,0xff,0xd9,0xfb,0xfb,0xff,0xcc,0xfb,0xfe,0xff,0xbe,0xfb,0x01,0x00,0xb0,0xfb,0x03,0x00,0xa3,0xfb,0x06,0x00,0x95,0xfb,0x09,0x00,0x87,0xfb,0x0b,0x00,0x79,0xfb,0x0e,0x00,0x6b,0xfb,0x11,0x00,0x5d,0xfb,0x14,0x00,0x4f,0xfb,0x17,0x00,0x41,0xfb,0x1a,0x00,0x32,0xfb,0x1d,0x00,0x24,0xfb,0x1f,0x00,0x16,0xfb,0x22,0x00,0x07,0xfb,0x25,0x00,  \
    0xf9,0xfa,0x28,0x00,0xeb,0xfa,0x2b,0x00,0xdc,0xfa,0x2f,0x00,0xce,0xfa,0x32,0x00,0xbf,0xfa,0x35,0x00,0xb0,0xfa,0x38,0x00,0xa2,0xfa,0x3b,0x00,0x93,0xfa,0x3e,0x00,0x84,0xfa,0x41,0x00,0x75,0xfa,0x45,0x00,0x66,0xfa,0x48,0x00,0x57,0xfa,0x4b,0x00,0x48,0xfa,0x4f,0x00,0x39,0xfa,0x52,0x00,0x2a,0xfa,0x55,0x00,0x1b,0xfa,0x59,0x00,0x0c,0xfa,0x5c,0x00,0xfc,0xf9,0x60,0x00,0xed,0xf9,0x63,0x00,0xde,0xf9,0x67,0x00,0xce,0xf9,0x6a,0x00,0xbf,0xf9,0x6e,0x00,0xaf,0xf9,  \
    0x71,0x00,0x9f,0xf9,0x75,0x00,0x90,0xf9,0x78,0x00,0x80,0xf9,0x7c,0x00,0x70,0xf9,0x80,0x00,0x60,0xf9,0x83,0x00,0x50,0xf9,0x87,0x00,0x40,0xf9,0x8b,0x00,0x30,0xf9,0x8e,0x00,0x20,0xf9,0x92,0x00,0x0f,0xf9,0x96,0x00,0xff,0xf8,0x99,0x00,0xee,0xf8,0x9d,0x00,0xde,0xf8,0xa1,0x00,0xcd,0xf8,0xa5,0x00,0xbc,0xf8,0xa9,0x00,0xab,0xf8,0xac,0x00,0x9b,0xf8,0xb0,0x00,0x8a,0xf8,0xb4,0x00,0x79,0xf8,0xb8,0x00,0x67,0xf8,0xbc,0x00,0x56,0xf8,0xc0,0x00,0x45,0xf8,0xc4,0x00,  \
    0x33,0xf8,0xc8,0x00,0x22,0xf8,0xcb,0x00,0x10,0xf8,0xcf,0x00,0xff,0xf7,0xd3,0x00,0xed,0xf7,0xd7,0x00,0xdb,0xf7,0xdb,0x00,0xc9,0xf7,0xdf,0x00,0xb8,0xf7,0xe3,0x00,0xa5,0xf7,0xe7,0x00,0x93,0xf7,0xeb,0x00,0x81,0xf7,0xef,0x00,0x6f,0xf7,0xf3,0x00,0x5d,0xf7,0xf7,0x00,0x4a,0xf7,0xfb,0x00,0x38,0xf7,0x00,0x01,0x25,0xf7,0x04,0x01,0x12,0xf7,0x08,0x01,0x00,0xf7,0x0c,0x01,0xed,0xf6,0x10,0x01,0xda,0xf6,0x14,0x01,0xc7,0xf6,0x18,0x01,0xb3,0xf6,0x1c,0x01,0xa0,0xf6,  \
    0x20,0x01,0x8d,0xf6,0x24,0x01,0x79,0xf6,0x28,0x01,0x66,0xf6,0x2c,0x01,0x52,0xf6,0x31,0x01,0x3e,0xf6,0x35,0x01,0x2b,0xf6,0x39,0x01,0x17,0xf6,0x3d,0x01,0x02,0xf6,0x41,0x01,0xee,0xf5,0x45,0x01,0xda,0xf5,0x49,0x01,0xc5,0xf5,0x4d,0x01,0xb0,0xf5,0x51,0x01,0x9c,0xf5,0x55,0x01,0x87,0xf5,0x59,0x01,0x72,0xf5,0x5d,0x01,0x5d,0xf5,0x60,0x01,0x47,0xf5,0x64,0x01,0x32,0xf5,0x68,0x01,0x1d,0xf5,0x6c,0x01,0x07,0xf5,0x70,0x01,0xf2,0xf4,0x74,0x01,0xdc,0xf4,0x78,0x01,  \
    0xc6,0xf4,0x7c,0x01,0xb0,0xf4,0x7f,0x01,0x9a,0xf4,0x83,0x01,0x84,0xf4,0x87,0x01,0x6e,0xf4,0x8b,0x01,0x58,0xf4,0x8f,0x01,0x41,0xf4,0x93,0x01,0x2b,0xf4,0x96,0x01,0x14,0xf4,0x9a,0x01,0xfe,0xf3,0x9e,0x01,0xe7,0xf3,0xa2,0x01,0xd0,0xf3,0xa5,0x01,0xb9,0xf3,0xa9,0x01,0xa2,0xf3,0xad,0x01,0x8a,0xf3,0xb0,0x01,0x73,0xf3,0xb4,0x01,0x5b,0xf3,0xb7,0x01,0x44,0xf3,0xbb,0x01,0x2c,0xf3,0xbe,0x01,0x14,0xf3,0xc2,0x01,0xfc,0xf2,0xc5,0x01,0xe4,0xf2,0xc8,0x01,0xcc,0xf2,  \
    0xcc,0x01,0xb3,0xf2,0xcf,0x01,0x9b,0xf2,0xd2,0x01,0x82,0xf2,0xd6,0x01,0x6a,0xf2,0xd9,0x01,0x51,0xf2,0xdc,0x01,0x38,0xf2,0xdf,0x01,0x1f,0xf2,0xe2,0x01,0x05,0xf2,0xe5,0x01,0xec,0xf1,0xe8,0x01,0xd2,0xf1,0xeb,0x01,0xb9,0xf1,0xee,0x01,0x9f,0xf1,0xf1,0x01,0x85,0xf1,0xf4,0x01,0x6b,0xf1,0xf6,0x01,0x51,0xf1,0xf9,0x01,0x36,0xf1,0xfc,0x01,0x1c,0xf1,0xfe,0x01,0x01,0xf1,0x01,0x02,0xe7,0xf0,0x03,0x02,0xcc,0xf0,0x06,0x02,0xb1,0xf0,0x08,0x02,0x95,0xf0,0x0a,0x02,  \
    0x7a,0xf0,0x0c,0x02,0x5f,0xf0,0x0f,0x02,0x43,0xf0,0x11,0x02,0x27,0xf0,0x13,0x02,0x0b,0xf0,0x15,0x02,0xef,0xef,0x17,0x02,0xd3,0xef,0x18,0x02,0xb7,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x2d,0x02,0x4b,0x10,0x2b,0x02,0x2f,0x10,0x29,0x02,0x12,0x10,0x27,0x02,0xf6,0x0f,0x25,0x02,0xda,0x0f,0x23,0x02,0xbe,0x0f,0x21,0x02,0xa2,0x0f,0x1f,0x02,0x86,0x0f,0x1d,0x02,0x6b,0x0f,0x1a,0x02,0x4f,0x0f,0x18,0x02,0x34,0x0f,0x16,0x02,0x19,0x0f,0x13,0x02,0xfe,0x0e,0x11,0x02,0xe3,0x0e,0x0e,0x02,0xc8,0x0e,0x0b,0x02,0xad,0x0e,0x09,0x02,0x93,0x0e,0x06,0x02,0x78,0x0e,0x03,0x02,0x5e,0x0e,0x01,0x02,0x43,0x0e,0xfe,0x01,0x29,0x0e,0xfb,0x01,0x0f,0x0e,0xf8,0x01,  \
    0xf6,0x0d,0xf5,0x01,0xdc,0x0d,0xf2,0x01,0xc2,0x0d,0xef,0x01,0xa9,0x0d,0xec,0x01,0x90,0x0d,0xe8,0x01,0x76,0x0d,0xe5,0x01,0x5d,0x0d,0xe2,0x01,0x44,0x0d,0xdf,0x01,0x2c,0x0d,0xdb,0x01,0x13,0x0d,0xd8,0x01,0xfa,0x0c,0xd5,0x01,0xe2,0x0c,0xd1,0x01,0xc9,0x0c,0xce,0x01,0xb1,0x0c,0xca,0x01,0x99,0x0c,0xc7,0x01,0x81,0x0c,0xc3,0x01,0x69,0x0c,0xbf,0x01,0x51,0x0c,0xbc,0x01,0x3a,0x0c,0xb8,0x01,0x22,0x0c,0xb4,0x01,0x0b,0x0c,0xb1,0x01,0xf4,0x0b,0xad,0x01,0xdd,0x0b,  \
    0xa9,0x01,0xc6,0x0b,0xa5,0x01,0xaf,0x0b,0xa2,0x01,0x98,0x0b,0x9e,0x01,0x82,0x0b,0x9a,0x01,0x6b,0x0b,0x96,0x01,0x55,0x0b,0x92,0x01,0x3f,0x0b,0x8e,0x01,0x29,0x0b,0x8a,0x01,0x12,0x0b,0x86,0x01,0xfd,0x0a,0x82,0x01,0xe7,0x0a,0x7e,0x01,0xd1,0x0a,0x7a,0x01,0xbb,0x0a,0x76,0x01,0xa6,0x0a,0x72,0x01,0x90,0x0a,0x6e,0x01,0x7a,0x0a,0x6a,0x01,0x65,0x0a,0x66,0x01,0x4f,0x0a,0x62,0x01,0x3a,0x0a,0x5f,0x01,0x25,0x0a,0x5b,0x01,0x10,0x0a,0x57,0x01,0xfb,0x09,0x53,0x01,  \
    0xe6,0x09,0x4f,0x01,0xd1,0x09,0x4b,0x01,0xbd,0x09,0x47,0x01,0xa8,0x09,0x42,0x01,0x94,0x09,0x3e,0x01,0x7f,0x09,0x3a,0x01,0x6b,0x09,0x36,0x01,0x57,0x09,0x32,0x01,0x43,0x09,0x2e,0x01,0x2f,0x09,0x2a,0x01,0x1b,0x09,0x26,0x01,0x07,0x09,0x22,0x01,0xf3,0x08,0x1e,0x01,0xe0,0x08,0x1a,0x01,0xcc,0x08,0x16,0x01,0xb9,0x08,0x12,0x01,0xa5,0x08,0x0e,0x01,0x92,0x08,0x0a,0x01,0x7f,0x08,0x06,0x01,0x6c,0x08,0x02,0x01,0x59,0x08,0xfe,0x00,0x46,0x08,0xfa,0x00,0x33,0x08,  \
    0xf6,0x00,0x20,0x08,0xf2,0x00,0x0e,0x08,0xee,0x00,0xfb,0x07,0xea,0x00,0xe9,0x07,0xe6,0x00,0xd7,0x07,0xe2,0x00,0xc5,0x07,0xde,0x00,0xb3,0x07,0xda,0x00,0xa1,0x07,0xd6,0x00,0x8f,0x07,0xd2,0x00,0x7e,0x07,0xce,0x00,0x6c,0x07,0xca,0x00,0x5b,0x07,0xc6,0x00,0x49,0x07,0xc2,0x00,0x38,0x07,0xbe,0x00,0x27,0x07,0xba,0x00,0x16,0x07,0xb6,0x00,0x05,0x07,0xb2,0x00,0xf4,0x06,0xaf,0x00,0xe3,0x06,0xab,0x00,0xd2,0x06,0xa7,0x00,0xc1,0x06,0xa3,0x00,0xb1,0x06,0x9f,0x00,  \
    0xa0,0x06,0x9b,0x00,0x8f,0x06,0x98,0x00,0x7f,0x06,0x94,0x00,0x6f,0x06,0x90,0x00,0x5e,0x06,0x8c,0x00,0x4e,0x06,0x89,0x00,0x3e,0x06,0x85,0x00,0x2e,0x06,0x81,0x00,0x1e,0x06,0x7e,0x00,0x0e,0x06,0x7a,0x00,0xfe,0x05,0x77,0x00,0xee,0x05,0x73,0x00,0xde,0x05,0x6f,0x00,0xce,0x05,0x6c,0x00,0xbf,0x05,0x68,0x00,0xaf,0x05,0x65,0x00,0xa0,0x05,0x61,0x00,0x90,0x05,0x5e,0x00,0x81,0x05,0x5b,0x00,0x71,0x05,0x57,0x00,0x62,0x05,0x54,0x00,0x53,0x05,0x50,0x00,0x44,0x05,  \
    0x4d,0x00,0x35,0x05,0x4a,0x00,0x26,0x05,0x47,0x00,0x17,0x05,0x43,0x00,0x08,0x05,0x40,0x00,0xf8,0x04,0x3d,0x00,0xe9,0x04,0x3a,0x00,0xda,0x04,0x37,0x00,0xcc,0x04,0x34,0x00,0xbd,0x04,0x31,0x00,0xae,0x04,0x2e,0x00,0x9f,0x04,0x2a,0x00,0x91,0x04,0x27,0x00,0x82,0x04,0x25,0x00,0x73,0x04,0x22,0x00,0x65,0x04,0x1f,0x00,0x57,0x04,0x1c,0x00,0x48,0x04,0x19,0x00,0x3a,0x04,0x16,0x00,0x2c,0x04,0x13,0x00,0x1d,0x04,0x10,0x00,0x0f,0x04,0x0e,0x00,0x01,0x04,0x0b,0x00,  \
    0xf3,0x03,0x08,0x00,0xe5,0x03,0x06,0x00,0xd7,0x03,0x03,0x00,0xc9,0x03,0x00,0x00,0xbb,0x03,0xfe,0xff,0xad,0x03,0xfb,0xff,0xa0,0x03,0xf8,0xff,0x92,0x03,0xf6,0xff,0x85,0x03,0xf3,0xff,0x77,0x03,0xf1,0xff,0x6a,0x03,0xef,0xff,0x5c,0x03,0xec,0xff,0x4f,0x03,0xea,0xff,0x42,0x03,0xe7,0xff,0x34,0x03,0xe5,0xff,0x27,0x03,0xe3,0xff,0x1a,0x03,0xe1,0xff,0x0c,0x03,0xde,0xff,0xff,0x02,0xdc,0xff,0xf2,0x02,0xda,0xff,0xe5,0x02,0xd8,0xff,0xd8,0x02,0xd6,0xff,0xcb,0x02,  \
    0xd4,0xff,0xbe,0x02,0xd2,0xff,0xb1,0x02,0xd0,0xff,0xa4,0x02,0xce,0xff,0x97,0x02,0xcc,0xff,0x8a,0x02,0xca,0xff,0x7e,0x02,0xc8,0xff,0x71,0x02,0xc6,0xff,0x64,0x02,0xc4,0xff,0x58,0x02,0xc2,0xff,0x4b,0x02,0xc0,0xff,0x3f,0x02,0xbf,0xff,0x32,0x02,0xbd,0xff,0x26,0x02,0xbb,0xff,0x19,0x02,0xba,0xff,0x0d,0x02,0xb8,0xff,0x00,0x02,0xb7,0xff,0xf4,0x01,0xb5,0xff,0xe7,0x01,0xb3,0xff,0xdb,0x01,0xb2,0xff,0xcf,0x01,0xb1,0xff,0xc2,0x01,0xaf,0xff,0xb6,0x01,0xae,0xff,  \
    0xaa,0x01,0xac,0xff,0x9e,0x01,0xab,0xff,0x91,0x01,0xaa,0xff,0x85,0x01,0xa9,0xff,0x79,0x01,0xa7,0xff,0x6d,0x01,0xa6,0xff,0x60,0x01,0xa5,0xff,0x54,0x01,0xa4,0xff,0x48,0x01,0xa3,0xff,0x3c,0x01,0xa2,0xff,0x30,0x01,0xa1,0xff,0x24,0x01,0xa0,0xff,0x17,0x01,0x9f,0xff,0x0b,0x01,0x9e,0xff,0xff,0x00,0x9d,0xff,0xf3,0x00,0x9c,0xff,0xe7,0x00,0x9c,0xff,0xdb,0x00,0x9b,0xff,0xce,0x00,0x9a,0xff,0xc2,0x00,0x99,0xff,0xb6,0x00,0x99,0xff,0xaa,0x00,0x98,0xff,0x9e,0x00,  \
    0x97,0xff,0x92,0x00,0x97,0xff,0x86,0x00,0x96,0xff,0x7a,0x00,0x96,0xff,0x6e,0x00,0x95,0xff,0x62,0x00,0x95,0xff,0x56,0x00,0x95,0xff,0x4a,0x00,0x94,0xff,0x3e,0x00,0x94,0xff,0x32,0x00,0x94,0xff,0x26,0x00,0x93,0xff,0x1a,0x00,0x93,0xff,0x0e,0x00,0x93,0xff,0x02,0x00,0x93,0xff,0xf6,0xff,0x93,0xff,0xea,0xff,0x92,0xff,0xde,0xff,0x92,0xff,0xd2,0xff,0x92,0xff,0xc6,0xff,0x92,0xff,0xba,0xff,0x92,0xff,0xae,0xff,0x92,0xff,0xa2,0xff,0x93,0xff,0x96,0xff,0x93,0xff,  \
    0x8a,0xff,0x93,0xff,0x7e,0xff,0x93,0xff,0x72,0xff,0x93,0xff,0x66,0xff,0x94,0xff,0x5a,0xff,0x94,0xff,0x4e,0xff,0x94,0xff,0x42,0xff,0x95,0xff,0x36,0xff,0x95,0xff,0x2a,0xff,0x95,0xff,0x1e,0xff,0x96,0xff,0x12,0xff,0x96,0xff,0x06,0xff,0x97,0xff,0xfa,0xfe,0x97,0xff,0xee,0xfe,0x98,0xff,0xe2,0xfe,0x99,0xff,0xd6,0xfe,0x99,0xff,0xca,0xfe,0x9a,0xff,0xbe,0xfe,0x9b,0xff,0xb2,0xfe,0x9c,0xff,0xa6,0xfe,0x9c,0xff,0x99,0xfe,0x9d,0xff,0x8d,0xfe,0x9e,0xff,0x81,0xfe,  \
    0x9f,0xff,0x75,0xfe,0xa0,0xff,0x69,0xfe,0xa1,0xff,0x5d,0xfe,0xa2,0xff,0x50,0xfe,0xa3,0xff,0x44,0xfe,0xa4,0xff,0x38,0xfe,0xa5,0xff,0x2c,0xfe,0xa6,0xff,0x1f,0xfe,0xa7,0xff,0x13,0xfe,0xa8,0xff,0x07,0xfe,0xaa,0xff,0xfa,0xfd,0xab,0xff,0xee,0xfd,0xac,0xff,0xe1,0xfd,0xad,0xff,0xd5,0xfd,0xaf,0xff,0xc9,0xfd,0xb0,0xff,0xbc,0xfd,0xb2,0xff,0xb0,0xfd,0xb3,0xff,0xa3,0xfd,0xb5,0xff,0x97,0xfd,0xb6,0xff,0x8a,0xfd,0xb8,0xff,0x7d,0xfd,0xb9,0xff,0x71,0xfd,0xbb,0xff,  \
    0x64,0xfd,0xbc,0xff,0x58,0xfd,0xbe,0xff,0x4b,0xfd,0xc0,0xff,0x3e,0xfd,0xc1,0xff,0x31,0xfd,0xc3,0xff,0x25,0xfd,0xc5,0xff,0x18,0xfd,0xc7,0xff,0x0b,0xfd,0xc9,0xff,0xfe,0xfc,0xca,0xff,0xf2,0xfc,0xcc,0xff,0xe5,0xfc,0xce,0xff,0xd8,0xfc,0xd0,0xff,0xcb,0xfc,0xd2,0xff,0xbe,0xfc,0xd4,0xff,0xb1,0xfc,0xd6,0xff,0xa4,0xfc,0xd9,0xff,0x97,0xfc,0xdb,0xff,0x8a,0xfc,0xdd,0xff,0x7d,0xfc,0xdf,0xff,0x70,0xfc,0xe1,0xff,0x63,0xfc,0xe3,0xff,0x56,0xfc,0xe6,0xff,0x49,0xfc,  \
    0xe8,0xff,0x3c,0xfc,0xea,0xff,0x2e,0xfc,0xed,0xff,0x21,0xfc,0xef,0xff,0x14,0xfc,0xf2,0xff,0x06,0xfc,0xf4,0xff,0xf9,0xfb,0xf7,0xff,0xeb,0xfb,0xf9,0xff,0xde,0xfb,0xfc,0xff,0xd0,0xfb,0xfe,0xff,0xc3,0xfb,0x01,0x00,0xb5,0xfb,0x03,0x00,0xa7,0xfb,0x06,0x00,0x99,0xfb,0x09,0x00,0x8b,0xfb,0x0b,0x00,0x7e,0xfb,0x0e,0x00,0x70,0xfb,0x11,0x00,0x62,0xfb,0x14,0x00,0x54,0xfb,0x16,0x00,0x45,0xfb,0x19,0x00,0x37,0xfb,0x1c,0x00,0x29,0xfb,0x1f,0x00,0x1b,0xfb,0x22,0x00,  \
    0x0c,0xfb,0x25,0x00,0xfe,0xfa,0x28,0x00,0xf0,0xfa,0x2b,0x00,0xe1,0xfa,0x2e,0x00,0xd3,0xfa,0x31,0x00,0xc4,0xfa,0x34,0x00,0xb5,0xfa,0x37,0x00,0xa7,0xfa,0x3a,0x00,0x98,0xfa,0x3d,0x00,0x89,0xfa,0x40,0x00,0x7a,0xfa,0x44,0x00,0x6b,0xfa,0x47,0x00,0x5d,0xfa,0x4a,0x00,0x4e,0xfa,0x4d,0x00,0x3f,0xfa,0x51,0x00,0x2f,0xfa,0x54,0x00,0x20,0xfa,0x57,0x00,0x11,0xfa,0x5b,0x00,0x02,0xfa,0x5e,0x00,0xf2,0xf9,0x61,0x00,0xe3,0xf9,0x65,0x00,0xd4,0xf9,0x68,0x00,0xc4,0xf9,  \
    0x6c,0x00,0xb4,0xf9,0x6f,0x00,0xa5,0xf9,0x73,0x00,0x95,0xf9,0x76,0x00,0x85,0xf9,0x7a,0x00,0x75,0xf9,0x7d,0x00,0x66,0xf9,0x81,0x00,0x56,0xf9,0x85,0x00,0x45,0xf9,0x88,0x00,0x35,0xf9,0x8c,0x00,0x25,0xf9,0x8f,0x00,0x15,0xf9,0x93,0x00,0x04,0xf9,0x97,0x00,0xf4,0xf8,0x9a,0x00,0xe3,0xf8,0x9e,0x00,0xd3,0xf8,0xa2,0x00,0xc2,0xf8,0xa6,0x00,0xb1,0xf8,0xa9,0x00,0xa0,0xf8,0xad,0x00,0x8f,0xf8,0xb1,0x00,0x7e,0xf8,0xb5,0x00,0x6d,0xf8,0xb8,0x00,0x5c,0xf8,0xbc,0x00,  \
    0x4a,0xf8,0xc0,0x00,0x39,0xf8,0xc4,0x00,0x28,0xf8,0xc8,0x00,0x16,0xf8,0xcc,0x00,0x04,0xf8,0xd0,0x00,0xf3,0xf7,0xd3,0x00,0xe1,0xf7,0xd7,0x00,0xcf,0xf7,0xdb,0x00,0xbd,0xf7,0xdf,0x00,0xab,0xf7,0xe3,0x00,0x99,0xf7,0xe7,0x00,0x87,0xf7,0xeb,0x00,0x74,0xf7,0xef,0x00,0x62,0xf7,0xf3,0x00,0x50,0xf7,0xf7,0x00,0x3d,0xf7,0xfb,0x00,0x2b,0xf7,0xff,0x00,0x18,0xf7,0x03,0x01,0x05,0xf7,0x07,0x01,0xf2,0xf6,0x0b,0x01,0xdf,0xf6,0x0f,0x01,0xcc,0xf6,0x13,0x01,0xb9,0xf6,  \
    0x17,0x01,0xa6,0xf6,0x1b,0x01,0x92,0xf6,0x1f,0x01,0x7f,0xf6,0x23,0x01,0x6b,0xf6,0x27,0x01,0x58,0xf6,0x2b,0x01,0x44,0xf6,0x2f,0x01,0x30,0xf6,0x33,0x01,0x1c,0xf6,0x37,0x01,0x08,0xf6,0x3b,0x01,0xf3,0xf5,0x3f,0x01,0xdf,0xf5,0x42,0x01,0xca,0xf5,0x46,0x01,0xb6,0xf5,0x4a,0x01,0xa1,0xf5,0x4e,0x01,0x8c,0xf5,0x52,0x01,0x77,0xf5,0x56,0x01,0x62,0xf5,0x5a,0x01,0x4d,0xf5,0x5e,0x01,0x37,0xf5,0x61,0x01,0x22,0xf5,0x65,0x01,0x0c,0xf5,0x69,0x01,0xf7,0xf4,0x6d,0x01,  \
    0xe1,0xf4,0x71,0x01,0xcb,0xf4,0x74,0x01,0xb5,0xf4,0x78,0x01,0x9f,0xf4,0x7c,0x01,0x89,0xf4,0x80,0x01,0x73,0xf4,0x83,0x01,0x5d,0xf4,0x87,0x01,0x46,0xf4,0x8b,0x01,0x30,0xf4,0x8f,0x01,0x19,0xf4,0x92,0x01,0x03,0xf4,0x96,0x01,0xec,0xf3,0x9a,0x01,0xd5,0xf3,0x9d,0x01,0xbe,0xf3,0xa1,0x01,0xa7,0xf3,0xa4,0x01,0x8f,0xf3,0xa8,0x01,0x78,0xf3,0xab,0x01,0x60,0xf3,0xaf,0x01,0x49,0xf3,0xb2,0x01,0x31,0xf3,0xb6,0x01,0x19,0xf3,0xb9,0x01,0x01,0xf3,0xbc,0x01,0xe9,0xf2,  \
    0xc0,0x01,0xd0,0xf2,0xc3,0x01,0xb8,0xf2,0xc6,0x01,0xa0,0xf2,0xc9,0x01,0x87,0xf2,0xcc,0x01,0x6e,0xf2,0xd0,0x01,0x55,0xf2,0xd3,0x01,0x3c,0xf2,0xd6,0x01,0x23,0xf2,0xd9,0x01,0x0a,0xf2,0xdc,0x01,0xf0,0xf1,0xdf,0x01,0xd7,0xf1,0xe1,0x01,0xbd,0xf1,0xe4,0x01,0xa3,0xf1,0xe7,0x01,0x89,0xf1,0xea,0x01,0x6f,0xf1,0xec,0x01,0x55,0xf1,0xef,0x01,0x3b,0xf1,0xf2,0x01,0x20,0xf1,0xf4,0x01,0x06,0xf1,0xf7,0x01,0xeb,0xf0,0xf9,0x01,0xd0,0xf0,0xfb,0x01,0xb5,0xf0,0xfd,0x01,  \
    0x9a,0xf0,0x00,0x02,0x7e,0xf0,0x02,0x02,0x63,0xf0,0x04,0x02,0x47,0xf0,0x06,0x02,0x2b,0xf0,0x08,0x02,0x10,0xf0,0x0a,0x02,0xf3,0xef,0x0c,0x02,0xd7,0xef,0x0e,0x02,0xbb,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x1f,0x02,0x48,0x10,0x1d,0x02,0x2c,0x10,0x1c,0x02,0x0f,0x10,0x1a,0x02,0xf3,0x0f,0x18,0x02,0xd7,0x0f,0x16,0x02,0xbb,0x0f,0x14,0x02,0x9f,0x0f,0x12,0x02,0x83,0x0f,0x0f,0x02,0x68,0x0f,0x0d,0x02,0x4c,0x0f,0x0b,0x02,0x31,0x0f,0x09,0x02,0x15,0x0f,0x06,0x02,0xfa,0x0e,0x04,0x02,0xdf,0x0e,0x01,0x02,0xc4,0x0e,0xff,0x01,0xaa,0x0e,0xfc,0x01,0x8f,0x0e,0xfa,0x01,0x75,0x0e,0xf7,0x01,0x5a,0x0e,0xf4,0x01,0x40,0x0e,0xf1,0x01,0x26,0x0e,0xef,0x01,  \
    0x0c,0x0e,0xec,0x01,0xf2,0x0d,0xe9,0x01,0xd8,0x0d,0xe6,0x01,0xbf,0x0d,0xe3,0x01,0xa5,0x0d,0xe0,0x01,0x8c,0x0d,0xdd,0x01,0x73,0x0d,0xda,0x01,0x5a,0x0d,0xd6,0x01,0x41,0x0d,0xd3,0x01,0x28,0x0d,0xd0,0x01,0x0f,0x0d,0xcd,0x01,0xf7,0x0c,0xc9,0x01,0xde,0x0c,0xc6,0x01,0xc6,0x0c,0xc3,0x01,0xad,0x0c,0xbf,0x01,0x95,0x0c,0xbc,0x01,0x7d,0x0c,0xb8,0x01,0x65,0x0c,0xb5,0x01,0x4e,0x0c,0xb1,0x01,0x36,0x0c,0xae,0x01,0x1e,0x0c,0xaa,0x01,0x07,0x0c,0xa7,0x01,0xf0,0x0b,  \
    0xa3,0x01,0xd9,0x0b,0x9f,0x01,0xc2,0x0b,0x9b,0x01,0xab,0x0b,0x98,0x01,0x94,0x0b,0x94,0x01,0x7e,0x0b,0x90,0x01,0x67,0x0b,0x8c,0x01,0x51,0x0b,0x89,0x01,0x3a,0x0b,0x85,0x01,0x24,0x0b,0x81,0x01,0x0e,0x0b,0x7d,0x01,0xf8,0x0a,0x79,0x01,0xe2,0x0a,0x75,0x01,0xcd,0x0a,0x71,0x01,0xb7,0x0a,0x6e,0x01,0xa1,0x0a,0x6a,0x01,0x8b,0x0a,0x66,0x01,0x76,0x0a,0x62,0x01,0x60,0x0a,0x5e,0x01,0x4b,0x0a,0x5a,0x01,0x36,0x0a,0x56,0x01,0x20,0x0a,0x53,0x01,0x0b,0x0a,0x4f,0x01,  \
    0xf6,0x09,0x4b,0x01,0xe1,0x09,0x47,0x01,0xcd,0x09,0x43,0x01,0xb8,0x09,0x3f,0x01,0xa3,0x09,0x3b,0x01,0x8f,0x09,0x37,0x01,0x7b,0x09,0x33,0x01,0x66,0x09,0x2f,0x01,0x52,0x09,0x2b,0x01,0x3e,0x09,0x27,0x01,0x2a,0x09,0x24,0x01,0x16,0x09,0x20,0x01,0x02,0x09,0x1c,0x01,0xee,0x08,0x18,0x01,0xdb,0x08,0x14,0x01,0xc7,0x08,0x10,0x01,0xb4,0x08,0x0c,0x01,0xa0,0x08,0x08,0x01,0x8d,0x08,0x04,0x01,0x7a,0x08,0x00,0x01,0x67,0x08,0xfc,0x00,0x54,0x08,0xf8,0x00,0x41,0x08,  \
    0xf5,0x00,0x2e,0x08,0xf1,0x00,0x1b,0x08,0xed,0x00,0x09,0x08,0xe9,0x00,0xf6,0x07,0xe5,0x00,0xe4,0x07,0xe1,0x00,0xd2,0x07,0xdd,0x00,0xc0,0x07,0xd9,0x00,0xae,0x07,0xd5,0x00,0x9c,0x07,0xd1,0x00,0x8a,0x07,0xcd,0x00,0x79,0x07,0xc9,0x00,0x67,0x07,0xc6,0x00,0x56,0x07,0xc2,0x00,0x44,0x07,0xbe,0x00,0x33,0x07,0xba,0x00,0x22,0x07,0xb6,0x00,0x11,0x07,0xb2,0x00,0x00,0x07,0xaf,0x00,0xef,0x06,0xab,0x00,0xde,0x06,0xa7,0x00,0xcd,0x06,0xa3,0x00,0xbc,0x06,0x9f,0x00,  \
    0xac,0x06,0x9c,0x00,0x9b,0x06,0x98,0x00,0x8a,0x06,0x94,0x00,0x7a,0x06,0x91,0x00,0x6a,0x06,0x8d,0x00,0x59,0x06,0x89,0x00,0x49,0x06,0x86,0x00,0x39,0x06,0x82,0x00,0x29,0x06,0x7f,0x00,0x19,0x06,0x7b,0x00,0x09,0x06,0x78,0x00,0xf9,0x05,0x74,0x00,0xe9,0x05,0x70,0x00,0xd9,0x05,0x6d,0x00,0xc9,0x05,0x6a,0x00,0xba,0x05,0x66,0x00,0xaa,0x05,0x63,0x00,0x9b,0x05,0x5f,0x00,0x8b,0x05,0x5c,0x00,0x7c,0x05,0x59,0x00,0x6d,0x05,0x55,0x00,0x5d,0x05,0x52,0x00,0x4e,0x05,  \
    0x4f,0x00,0x3f,0x05,0x4b,0x00,0x30,0x05,0x48,0x00,0x21,0x05,0x45,0x00,0x12,0x05,0x42,0x00,0x03,0x05,0x3f,0x00,0xf4,0x04,0x3c,0x00,0xe5,0x04,0x39,0x00,0xd6,0x04,0x36,0x00,0xc7,0x04,0x33,0x00,0xb8,0x04,0x2f,0x00,0xa9,0x04,0x2d,0x00,0x9b,0x04,0x2a,0x00,0x8c,0x04,0x27,0x00,0x7d,0x04,0x24,0x00,0x6f,0x04,0x21,0x00,0x60,0x04,0x1e,0x00,0x52,0x04,0x1b,0x00,0x44,0x04,0x18,0x00,0x35,0x04,0x16,0x00,0x27,0x04,0x13,0x00,0x19,0x04,0x10,0x00,0x0b,0x04,0x0d,0x00,  \
    0xfd,0x03,0x0b,0x00,0xef,0x03,0x08,0x00,0xe1,0x03,0x05,0x00,0xd3,0x03,0x03,0x00,0xc5,0x03,0x00,0x00,0xb7,0x03,0xfe,0xff,0xa9,0x03,0xfb,0xff,0x9c,0x03,0xf9,0xff,0x8e,0x03,0xf6,0xff,0x81,0x03,0xf4,0xff,0x73,0x03,0xf1,0xff,0x66,0x03,0xef,0xff,0x58,0x03,0xec,0xff,0x4b,0x03,0xea,0xff,0x3e,0x03,0xe8,0xff,0x30,0x03,0xe6,0xff,0x23,0x03,0xe3,0xff,0x16,0x03,0xe1,0xff,0x09,0x03,0xdf,0xff,0xfc,0x02,0xdd,0xff,0xef,0x02,0xdb,0xff,0xe2,0x02,0xd9,0xff,0xd5,0x02,  \
    0xd6,0xff,0xc8,0x02,0xd4,0xff,0xbb,0x02,0xd2,0xff,0xae,0x02,0xd0,0xff,0xa1,0x02,0xcf,0xff,0x94,0x02,0xcd,0xff,0x87,0x02,0xcb,0xff,0x7a,0x02,0xc9,0xff,0x6e,0x02,0xc7,0xff,0x61,0x02,0xc5,0xff,0x55,0x02,0xc3,0xff,0x48,0x02,0xc2,0xff,0x3c,0x02,0xc0,0xff,0x2f,0x02,0xbe,0xff,0x23,0x02,0xbd,0xff,0x16,0x02,0xbb,0xff,0x0a,0x02,0xba,0xff,0xfd,0x01,0xb8,0xff,0xf1,0x01,0xb6,0xff,0xe5,0x01,0xb5,0xff,0xd8,0x01,0xb4,0xff,0xcc,0x01,0xb2,0xff,0xc0,0x01,0xb1,0xff,  \
    0xb4,0x01,0xaf,0xff,0xa7,0x01,0xae,0xff,0x9b,0x01,0xad,0xff,0x8f,0x01,0xac,0xff,0x83,0x01,0xaa,0xff,0x77,0x01,0xa9,0xff,0x6a,0x01,0xa8,0xff,0x5e,0x01,0xa7,0xff,0x52,0x01,0xa6,0xff,0x46,0x01,0xa5,0xff,0x3a,0x01,0xa4,0xff,0x2e,0x01,0xa3,0xff,0x22,0x01,0xa2,0xff,0x16,0x01,0xa1,0xff,0x09,0x01,0xa0,0xff,0xfd,0x00,0x9f,0xff,0xf1,0x00,0x9e,0xff,0xe5,0x00,0x9d,0xff,0xd9,0x00,0x9d,0xff,0xcd,0x00,0x9c,0xff,0xc1,0x00,0x9b,0xff,0xb5,0x00,0x9b,0xff,0xa9,0x00,  \
    0x9a,0xff,0x9d,0x00,0x99,0xff,0x91,0x00,0x99,0xff,0x85,0x00,0x98,0xff,0x79,0x00,0x98,0xff,0x6d,0x00,0x97,0xff,0x61,0x00,0x97,0xff,0x55,0x00,0x97,0xff,0x49,0x00,0x96,0xff,0x3d,0x00,0x96,0xff,0x31,0x00,0x96,0xff,0x25,0x00,0x95,0xff,0x19,0x00,0x95,0xff,0x0d,0x00,0x95,0xff,0x01,0x00,0x95,0xff,0xf5,0xff,0x95,0xff,0xe9,0xff,0x95,0xff,0xde,0xff,0x95,0xff,0xd2,0xff,0x94,0xff,0xc6,0xff,0x94,0xff,0xba,0xff,0x95,0xff,0xae,0xff,0x95,0xff,0xa2,0xff,0x95,0xff,  \
    0x96,0xff,0x95,0xff,0x8a,0xff,0x95,0xff,0x7e,0xff,0x95,0xff,0x72,0xff,0x95,0xff,0x66,0xff,0x96,0xff,0x5b,0xff,0x96,0xff,0x4f,0xff,0x96,0xff,0x43,0xff,0x97,0xff,0x37,0xff,0x97,0xff,0x2b,0xff,0x98,0xff,0x1f,0xff,0x98,0xff,0x13,0xff,0x98,0xff,0x07,0xff,0x99,0xff,0xfb,0xfe,0x9a,0xff,0xef,0xfe,0x9a,0xff,0xe3,0xfe,0x9b,0xff,0xd7,0xfe,0x9b,0xff,0xcb,0xfe,0x9c,0xff,0xbf,0xfe,0x9d,0xff,0xb3,0xfe,0x9e,0xff,0xa7,0xfe,0x9e,0xff,0x9b,0xfe,0x9f,0xff,0x8f,0xfe,  \
    0xa0,0xff,0x83,0xfe,0xa1,0xff,0x77,0xfe,0xa2,0xff,0x6b,0xfe,0xa3,0xff,0x5e,0xfe,0xa4,0xff,0x52,0xfe,0xa5,0xff,0x46,0xfe,0xa6,0xff,0x3a,0xfe,0xa7,0xff,0x2e,0xfe,0xa8,0xff,0x21,0xfe,0xa9,0xff,0x15,0xfe,0xaa,0xff,0x09,0xfe,0xab,0xff,0xfd,0xfd,0xad,0xff,0xf0,0xfd,0xae,0xff,0xe4,0xfd,0xaf,0xff,0xd8,0xfd,0xb0,0xff,0xcb,0xfd,0xb2,0xff,0xbf,0xfd,0xb3,0xff,0xb2,0xfd,0xb5,0xff,0xa6,0xfd,0xb6,0xff,0x99,0xfd,0xb8,0xff,0x8d,0xfd,0xb9,0xff,0x80,0xfd,0xbb,0xff,  \
    0x74,0xfd,0xbc,0xff,0x67,0xfd,0xbe,0xff,0x5b,0xfd,0xbf,0xff,0x4e,0xfd,0xc1,0xff,0x41,0xfd,0xc3,0xff,0x35,0xfd,0xc4,0xff,0x28,0xfd,0xc6,0xff,0x1b,0xfd,0xc8,0xff,0x0f,0xfd,0xca,0xff,0x02,0xfd,0xcc,0xff,0xf5,0xfc,0xce,0xff,0xe8,0xfc,0xcf,0xff,0xdc,0xfc,0xd1,0xff,0xcf,0xfc,0xd3,0xff,0xc2,0xfc,0xd5,0xff,0xb5,0xfc,0xd7,0xff,0xa8,0xfc,0xd9,0xff,0x9b,0xfc,0xdc,0xff,0x8e,0xfc,0xde,0xff,0x81,0xfc,0xe0,0xff,0x74,0xfc,0xe2,0xff,0x67,0xfc,0xe4,0xff,0x5a,0xfc,  \
    0xe6,0xff,0x4d,0xfc,0xe9,0xff,0x40,0xfc,0xeb,0xff,0x32,0xfc,0xed,0xff,0x25,0xfc,0xf0,0xff,0x18,0xfc,0xf2,0xff,0x0b,0xfc,0xf4,0xff,0xfd,0xfb,0xf7,0xff,0xf0,0xfb,0xf9,0xff,0xe2,0xfb,0xfc,0xff,0xd5,0xfb,0xfe,0xff,0xc7,0xfb,0x01,0x00,0xb9,0xfb,0x04,0x00,0xac,0xfb,0x06,0x00,0x9e,0xfb,0x09,0x00,0x90,0xfb,0x0b,0x00,0x82,0xfb,0x0e,0x00,0x74,0xfb,0x11,0x00,0x66,0xfb,0x13,0x00,0x58,0xfb,0x16,0x00,0x4a,0xfb,0x19,0x00,0x3c,0xfb,0x1c,0x00,0x2e,0xfb,0x1f,0x00,  \
    0x20,0xfb,0x22,0x00,0x11,0xfb,0x24,0x00,0x03,0xfb,0x27,0x00,0xf5,0xfa,0x2a,0x00,0xe6,0xfa,0x2d,0x00,0xd8,0xfa,0x30,0x00,0xc9,0xfa,0x33,0x00,0xbb,0xfa,0x36,0x00,0xac,0xfa,0x39,0x00,0x9d,0xfa,0x3c,0x00,0x8e,0xfa,0x3f,0x00,0x80,0xfa,0x43,0x00,0x71,0xfa,0x46,0x00,0x62,0xfa,0x49,0x00,0x53,0xfa,0x4c,0x00,0x44,0xfa,0x4f,0x00,0x35,0xfa,0x53,0x00,0x26,0xfa,0x56,0x00,0x16,0xfa,0x59,0x00,0x07,0xfa,0x5c,0x00,0xf8,0xf9,0x60,0x00,0xe8,0xf9,0x63,0x00,0xd9,0xf9,  \
    0x67,0x00,0xc9,0xf9,0x6a,0x00,0xba,0xf9,0x6d,0x00,0xaa,0xf9,0x71,0x00,0x9a,0xf9,0x74,0x00,0x8b,0xf9,0x78,0x00,0x7b,0xf9,0x7b,0x00,0x6b,0xf9,0x7f,0x00,0x5b,0xf9,0x82,0x00,0x4b,0xf9,0x86,0x00,0x3b,0xf9,0x89,0x00,0x2b,0xf9,0x8d,0x00,0x1a,0xf9,0x91,0x00,0x0a,0xf9,0x94,0x00,0xf9,0xf8,0x98,0x00,0xe9,0xf8,0x9b,0x00,0xd8,0xf8,0x9f,0x00,0xc7,0xf8,0xa3,0x00,0xb7,0xf8,0xa6,0x00,0xa6,0xf8,0xaa,0x00,0x95,0xf8,0xae,0x00,0x84,0xf8,0xb1,0x00,0x72,0xf8,0xb5,0x00,  \
    0x61,0xf8,0xb9,0x00,0x50,0xf8,0xbd,0x00,0x3f,0xf8,0xc0,0x00,0x2d,0xf8,0xc4,0x00,0x1c,0xf8,0xc8,0x00,0x0a,0xf8,0xcc,0x00,0xf8,0xf7,0xd0,0x00,0xe6,0xf7,0xd3,0x00,0xd5,0xf7,0xd7,0x00,0xc3,0xf7,0xdb,0x00,0xb1,0xf7,0xdf,0x00,0x9e,0xf7,0xe3,0x00,0x8c,0xf7,0xe7,0x00,0x7a,0xf7,0xeb,0x00,0x68,0xf7,0xee,0x00,0x55,0xf7,0xf2,0x00,0x43,0xf7,0xf6,0x00,0x30,0xf7,0xfa,0x00,0x1d,0xf7,0xfe,0x00,0x0a,0xf7,0x02,0x01,0xf8,0xf6,0x06,0x01,0xe5,0xf6,0x0a,0x01,0xd1,0xf6,  \
    0x0e,0x01,0xbe,0xf6,0x12,0x01,0xab,0xf6,0x15,0x01,0x98,0xf6,0x19,0x01,0x84,0xf6,0x1d,0x01,0x70,0xf6,0x21,0x01,0x5d,0xf6,0x25,0x01,0x49,0xf6,0x29,0x01,0x35,0xf6,0x2d,0x01,0x21,0xf6,0x31,0x01,0x0d,0xf6,0x35,0x01,0xf9,0xf5,0x38,0x01,0xe4,0xf5,0x3c,0x01,0xcf,0xf5,0x40,0x01,0xbb,0xf5,0x44,0x01,0xa6,0xf5,0x48,0x01,0x91,0xf5,0x4c,0x01,0x7c,0xf5,0x4f,0x01,0x67,0xf5,0x53,0x01,0x52,0xf5,0x57,0x01,0x3c,0xf5,0x5b,0x01,0x27,0xf5,0x5e,0x01,0x12,0xf5,0x62,0x01,  \
    0xfc,0xf4,0x66,0x01,0xe6,0xf4,0x69,0x01,0xd0,0xf4,0x6d,0x01,0xba,0xf4,0x71,0x01,0xa4,0xf4,0x75,0x01,0x8e,0xf4,0x78,0x01,0x78,0xf4,0x7c,0x01,0x62,0xf4,0x80,0x01,0x4b,0xf4,0x83,0x01,0x35,0xf4,0x87,0x01,0x1e,0xf4,0x8a,0x01,0x07,0xf4,0x8e,0x01,0xf1,0xf3,0x91,0x01,0xda,0xf3,0x95,0x01,0xc3,0xf3,0x98,0x01,0xab,0xf3,0x9c,0x01,0x94,0xf3,0x9f,0x01,0x7d,0xf3,0xa3,0x01,0x65,0xf3,0xa6,0x01,0x4d,0xf3,0xaa,0x01,0x36,0xf3,0xad,0x01,0x1e,0xf3,0xb0,0x01,0x06,0xf3,  \
    0xb3,0x01,0xed,0xf2,0xb7,0x01,0xd5,0xf2,0xba,0x01,0xbd,0xf2,0xbd,0x01,0xa4,0xf2,0xc0,0x01,0x8b,0xf2,0xc3,0x01,0x73,0xf2,0xc6,0x01,0x5a,0xf2,0xc9,0x01,0x41,0xf2,0xcc,0x01,0x28,0xf2,0xcf,0x01,0x0e,0xf2,0xd2,0x01,0xf5,0xf1,0xd5,0x01,0xdb,0xf1,0xd8,0x01,0xc2,0xf1,0xda,0x01,0xa8,0xf1,0xdd,0x01,0x8e,0xf1,0xe0,0x01,0x74,0xf1,0xe2,0x01,0x59,0xf1,0xe5,0x01,0x3f,0xf1,0xe7,0x01,0x25,0xf1,0xea,0x01,0x0a,0xf1,0xec,0x01,0xef,0xf0,0xef,0x01,0xd4,0xf0,0xf1,0x01,  \
    0xb9,0xf0,0xf3,0x01,0x9e,0xf0,0xf5,0x01,0x82,0xf0,0xf7,0x01,0x67,0xf0,0xf9,0x01,0x4b,0xf0,0xfb,0x01,0x30,0xf0,0xfd,0x01,0x14,0xf0,0xff,0x01,0xf8,0xef,0x01,0x02,0xdb,0xef,0x03,0x02,0xbf,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x12,0x02,0x45,0x10,0x10,0x02,0x28,0x10,0x0e,0x02,0x0c,0x10,0x0c,0x02,0xf0,0x0f,0x0a,0x02,0xd4,0x0f,0x08,0x02,0xb8,0x0f,0x06,0x02,0x9c,0x0f,0x04,0x02,0x80,0x0f,0x02,0x02,0x64,0x0f,0x00,0x02,0x49,0x0f,0xfe,0x01,0x2d,0x0f,0xfc,0x01,0x12,0x0f,0xf9,0x01,0xf7,0x0e,0xf7,0x01,0xdc,0x0e,0xf5,0x01,0xc1,0x0e,0xf2,0x01,0xa6,0x0e,0xf0,0x01,0x8c,0x0e,0xed,0x01,0x71,0x0e,0xea,0x01,0x57,0x0e,0xe8,0x01,0x3d,0x0e,0xe5,0x01,  \
    0x22,0x0e,0xe2,0x01,0x08,0x0e,0xe0,0x01,0xef,0x0d,0xdd,0x01,0xd5,0x0d,0xda,0x01,0xbb,0x0d,0xd7,0x01,0xa2,0x0d,0xd4,0x01,0x88,0x0d,0xd1,0x01,0x6f,0x0d,0xce,0x01,0x56,0x0d,0xcb,0x01,0x3d,0x0d,0xc8,0x01,0x24,0x0d,0xc5,0x01,0x0b,0x0d,0xc1,0x01,0xf3,0x0c,0xbe,0x01,0xda,0x0c,0xbb,0x01,0xc2,0x0c,0xb8,0x01,0xaa,0x0c,0xb4,0x01,0x91,0x0c,0xb1,0x01,0x79,0x0c,0xae,0x01,0x61,0x0c,0xaa,0x01,0x4a,0x0c,0xa7,0x01,0x32,0x0c,0xa3,0x01,0x1b,0x0c,0xa0,0x01,0x03,0x0c,  \
    0x9c,0x01,0xec,0x0b,0x99,0x01,0xd5,0x0b,0x95,0x01,0xbe,0x0b,0x92,0x01,0xa7,0x0b,0x8e,0x01,0x90,0x0b,0x8a,0x01,0x79,0x0b,0x87,0x01,0x63,0x0b,0x83,0x01,0x4c,0x0b,0x7f,0x01,0x36,0x0b,0x7c,0x01,0x20,0x0b,0x78,0x01,0x0a,0x0b,0x74,0x01,0xf4,0x0a,0x70,0x01,0xde,0x0a,0x6c,0x01,0xc8,0x0a,0x69,0x01,0xb3,0x0a,0x65,0x01,0x9d,0x0a,0x61,0x01,0x87,0x0a,0x5e,0x01,0x71,0x0a,0x5a,0x01,0x5c,0x0a,0x56,0x01,0x46,0x0a,0x52,0x01,0x31,0x0a,0x4e,0x01,0x1c,0x0a,0x4b,0x01,  \
    0x07,0x0a,0x47,0x01,0xf2,0x09,0x43,0x01,0xdd,0x09,0x3f,0x01,0xc8,0x09,0x3b,0x01,0xb3,0x09,0x38,0x01,0x9f,0x09,0x34,0x01,0x8a,0x09,0x30,0x01,0x76,0x09,0x2c,0x01,0x62,0x09,0x28,0x01,0x4d,0x09,0x25,0x01,0x39,0x09,0x21,0x01,0x25,0x09,0x1d,0x01,0x11,0x09,0x19,0x01,0xfe,0x08,0x15,0x01,0xea,0x08,0x11,0x01,0xd6,0x08,0x0e,0x01,0xc3,0x08,0x0a,0x01,0xaf,0x08,0x06,0x01,0x9c,0x08,0x02,0x01,0x89,0x08,0xfe,0x00,0x75,0x08,0xfa,0x00,0x62,0x08,0xf7,0x00,0x4f,0x08,  \
    0xf3,0x00,0x3c,0x08,0xef,0x00,0x2a,0x08,0xeb,0x00,0x17,0x08,0xe7,0x00,0x04,0x08,0xe4,0x00,0xf2,0x07,0xe0,0x00,0xdf,0x07,0xdc,0x00,0xcd,0x07,0xd8,0x00,0xbb,0x07,0xd4,0x00,0xa9,0x07,0xd0,0x00,0x97,0x07,0xcd,0x00,0x86,0x07,0xc9,0x00,0x74,0x07,0xc5,0x00,0x62,0x07,0xc1,0x00,0x51,0x07,0xbd,0x00,0x40,0x07,0xba,0x00,0x2e,0x07,0xb6,0x00,0x1d,0x07,0xb2,0x00,0x0c,0x07,0xae,0x00,0xfb,0x06,0xab,0x00,0xea,0x06,0xa7,0x00,0xd9,0x06,0xa3,0x00,0xc8,0x06,0xa0,0x00,  \
    0xb7,0x06,0x9c,0x00,0xa7,0x06,0x98,0x00,0x96,0x06,0x95,0x00,0x86,0x06,0x91,0x00,0x75,0x06,0x8e,0x00,0x65,0x06,0x8a,0x00,0x54,0x06,0x86,0x00,0x44,0x06,0x83,0x00,0x34,0x06,0x7f,0x00,0x24,0x06,0x7c,0x00,0x14,0x06,0x78,0x00,0x04,0x06,0x75,0x00,0xf4,0x05,0x72,0x00,0xe4,0x05,0x6e,0x00,0xd4,0x05,0x6b,0x00,0xc5,0x05,0x67,0x00,0xb5,0x05,0x64,0x00,0xa5,0x05,0x61,0x00,0x96,0x05,0x5d,0x00,0x86,0x05,0x5a,0x00,0x77,0x05,0x57,0x00,0x68,0x05,0x54,0x00,0x59,0x05,  \
    0x50,0x00,0x49,0x05,0x4d,0x00,0x3a,0x05,0x4a,0x00,0x2b,0x05,0x47,0x00,0x1c,0x05,0x44,0x00,0x0d,0x05,0x41,0x00,0xfe,0x04,0x3d,0x00,0xef,0x04,0x3a,0x00,0xe0,0x04,0x37,0x00,0xd1,0x04,0x34,0x00,0xc2,0x04,0x31,0x00,0xb4,0x04,0x2f,0x00,0xa5,0x04,0x2c,0x00,0x96,0x04,0x29,0x00,0x88,0x04,0x26,0x00,0x79,0x04,0x23,0x00,0x6b,0x04,0x20,0x00,0x5c,0x04,0x1d,0x00,0x4e,0x04,0x1b,0x00,0x3f,0x04,0x18,0x00,0x31,0x04,0x15,0x00,0x23,0x04,0x12,0x00,0x15,0x04,0x10,0x00,  \
    0x07,0x04,0x0d,0x00,0xf9,0x03,0x0b,0x00,0xeb,0x03,0x08,0x00,0xdd,0x03,0x05,0x00,0xcf,0x03,0x03,0x00,0xc1,0x03,0x00,0x00,0xb3,0x03,0xfe,0xff,0xa5,0x03,0xfb,0xff,0x98,0x03,0xf9,0xff,0x8a,0x03,0xf6,0xff,0x7d,0x03,0xf4,0xff,0x6f,0x03,0xf2,0xff,0x62,0x03,0xef,0xff,0x55,0x03,0xed,0xff,0x47,0x03,0xeb,0xff,0x3a,0x03,0xe8,0xff,0x2d,0x03,0xe6,0xff,0x20,0x03,0xe4,0xff,0x12,0x03,0xe2,0xff,0x05,0x03,0xe0,0xff,0xf8,0x02,0xde,0xff,0xeb,0x02,0xdb,0xff,0xde,0x02,  \
    0xd9,0xff,0xd1,0x02,0xd7,0xff,0xc4,0x02,0xd5,0xff,0xb7,0x02,0xd3,0xff,0xab,0x02,0xd2,0xff,0x9e,0x02,0xd0,0xff,0x91,0x02,0xce,0xff,0x84,0x02,0xcc,0xff,0x77,0x02,0xca,0xff,0x6b,0x02,0xc8,0xff,0x5e,0x02,0xc7,0xff,0x52,0x02,0xc5,0xff,0x45,0x02,0xc3,0xff,0x39,0x02,0xc1,0xff,0x2c,0x02,0xc0,0xff,0x20,0x02,0xbe,0xff,0x13,0x02,0xbd,0xff,0x07,0x02,0xbb,0xff,0xfb,0x01,0xba,0xff,0xee,0x01,0xb8,0xff,0xe2,0x01,0xb7,0xff,0xd6,0x01,0xb5,0xff,0xca,0x01,0xb4,0xff,  \
    0xbd,0x01,0xb2,0xff,0xb1,0x01,0xb1,0xff,0xa5,0x01,0xb0,0xff,0x99,0x01,0xaf,0xff,0x8d,0x01,0xad,0xff,0x81,0x01,0xac,0xff,0x74,0x01,0xab,0xff,0x68,0x01,0xaa,0xff,0x5c,0x01,0xa9,0xff,0x50,0x01,0xa8,0xff,0x44,0x01,0xa7,0xff,0x38,0x01,0xa6,0xff,0x2c,0x01,0xa5,0xff,0x20,0x01,0xa4,0xff,0x14,0x01,0xa3,0xff,0x08,0x01,0xa2,0xff,0xfc,0x00,0xa1,0xff,0xf0,0x00,0xa0,0xff,0xe4,0x00,0xa0,0xff,0xd8,0x00,0x9f,0xff,0xcc,0x00,0x9e,0xff,0xc0,0x00,0x9d,0xff,0xb4,0x00,  \
    0x9d,0xff,0xa8,0x00,0x9c,0xff,0x9c,0x00,0x9c,0xff,0x90,0x00,0x9b,0xff,0x84,0x00,0x9b,0xff,0x78,0x00,0x9a,0xff,0x6c,0x00,0x9a,0xff,0x60,0x00,0x99,0xff,0x54,0x00,0x99,0xff,0x48,0x00,0x99,0xff,0x3c,0x00,0x98,0xff,0x30,0x00,0x98,0xff,0x25,0x00,0x98,0xff,0x19,0x00,0x97,0xff,0x0d,0x00,0x97,0xff,0x01,0x00,0x97,0xff,0xf5,0xff,0x97,0xff,0xe9,0xff,0x97,0xff,0xdd,0xff,0x97,0xff,0xd2,0xff,0x97,0xff,0xc6,0xff,0x97,0xff,0xba,0xff,0x97,0xff,0xae,0xff,0x97,0xff,  \
    0xa2,0xff,0x97,0xff,0x96,0xff,0x97,0xff,0x8a,0xff,0x97,0xff,0x7f,0xff,0x97,0xff,0x73,0xff,0x98,0xff,0x67,0xff,0x98,0xff,0x5b,0xff,0x98,0xff,0x4f,0xff,0x99,0xff,0x43,0xff,0x99,0xff,0x37,0xff,0x99,0xff,0x2c,0xff,0x9a,0xff,0x20,0xff,0x9a,0xff,0x14,0xff,0x9b,0xff,0x08,0xff,0x9b,0xff,0xfc,0xfe,0x9c,0xff,0xf0,0xfe,0x9c,0xff,0xe4,0xfe,0x9d,0xff,0xd8,0xfe,0x9e,0xff,0xcc,0xfe,0x9e,0xff,0xc0,0xfe,0x9f,0xff,0xb4,0xfe,0xa0,0xff,0xa8,0xfe,0xa0,0xff,0x9c,0xfe,  \
    0xa1,0xff,0x90,0xfe,0xa2,0xff,0x84,0xfe,0xa3,0xff,0x78,0xfe,0xa4,0xff,0x6c,0xfe,0xa5,0xff,0x60,0xfe,0xa6,0xff,0x54,0xfe,0xa7,0xff,0x48,0xfe,0xa8,0xff,0x3c,0xfe,0xa9,0xff,0x30,0xfe,0xaa,0xff,0x24,0xfe,0xab,0xff,0x17,0xfe,0xac,0xff,0x0b,0xfe,0xad,0xff,0xff,0xfd,0xae,0xff,0xf3,0xfd,0xb0,0xff,0xe6,0xfd,0xb1,0xff,0xda,0xfd,0xb2,0xff,0xce,0xfd,0xb4,0xff,0xc1,0xfd,0xb5,0xff,0xb5,0xfd,0xb6,0xff,0xa9,0xfd,0xb8,0xff,0x9c,0xfd,0xb9,0xff,0x90,0xfd,0xbb,0xff,  \
    0x83,0xfd,0xbc,0xff,0x77,0xfd,0xbe,0xff,0x6a,0xfd,0xbf,0xff,0x5e,0xfd,0xc1,0xff,0x51,0xfd,0xc3,0xff,0x45,0xfd,0xc4,0xff,0x38,0xfd,0xc6,0xff,0x2b,0xfd,0xc8,0xff,0x1f,0xfd,0xc9,0xff,0x12,0xfd,0xcb,0xff,0x05,0xfd,0xcd,0xff,0xf9,0xfc,0xcf,0xff,0xec,0xfc,0xd1,0xff,0xdf,0xfc,0xd3,0xff,0xd2,0xfc,0xd5,0xff,0xc6,0xfc,0xd6,0xff,0xb9,0xfc,0xd8,0xff,0xac,0xfc,0xda,0xff,0x9f,0xfc,0xdd,0xff,0x92,0xfc,0xdf,0xff,0x85,0xfc,0xe1,0xff,0x78,0xfc,0xe3,0xff,0x6b,0xfc,  \
    0xe5,0xff,0x5e,0xfc,0xe7,0xff,0x51,0xfc,0xe9,0xff,0x44,0xfc,0xec,0xff,0x37,0xfc,0xee,0xff,0x29,0xfc,0xf0,0xff,0x1c,0xfc,0xf3,0xff,0x0f,0xfc,0xf5,0xff,0x01,0xfc,0xf7,0xff,0xf4,0xfb,0xfa,0xff,0xe7,0xfb,0xfc,0xff,0xd9,0xfb,0xff,0xff,0xcc,0xfb,0x01,0x00,0xbe,0xfb,0x04,0x00,0xb0,0xfb,0x06,0x00,0xa2,0xfb,0x09,0x00,0x95,0xfb,0x0c,0x00,0x87,0xfb,0x0e,0x00,0x79,0xfb,0x11,0x00,0x6b,0xfb,0x13,0x00,0x5d,0xfb,0x16,0x00,0x4f,0xfb,0x19,0x00,0x41,0xfb,0x1c,0x00,  \
    0x33,0xfb,0x1e,0x00,0x24,0xfb,0x21,0x00,0x16,0xfb,0x24,0x00,0x08,0xfb,0x27,0x00,0xf9,0xfa,0x2a,0x00,0xeb,0xfa,0x2d,0x00,0xdd,0xfa,0x30,0x00,0xce,0xfa,0x33,0x00,0xbf,0xfa,0x36,0x00,0xb1,0xfa,0x39,0x00,0xa2,0xfa,0x3c,0x00,0x93,0xfa,0x3f,0x00,0x85,0xfa,0x42,0x00,0x76,0xfa,0x45,0x00,0x67,0xfa,0x48,0x00,0x58,0xfa,0x4b,0x00,0x49,0xfa,0x4e,0x00,0x3a,0xfa,0x51,0x00,0x2b,0xfa,0x55,0x00,0x1c,0xfa,0x58,0x00,0x0c,0xfa,0x5b,0x00,0xfd,0xf9,0x5e,0x00,0xee,0xf9,  \
    0x62,0x00,0xde,0xf9,0x65,0x00,0xcf,0xf9,0x68,0x00,0xbf,0xf9,0x6c,0x00,0xaf,0xf9,0x6f,0x00,0xa0,0xf9,0x72,0x00,0x90,0xf9,0x76,0x00,0x80,0xf9,0x79,0x00,0x70,0xf9,0x7d,0x00,0x60,0xf9,0x80,0x00,0x50,0xf9,0x84,0x00,0x40,0xf9,0x87,0x00,0x30,0xf9,0x8b,0x00,0x20,0xf9,0x8e,0x00,0x0f,0xf9,0x92,0x00,0xff,0xf8,0x95,0x00,0xee,0xf8,0x99,0x00,0xdd,0xf8,0x9c,0x00,0xcd,0xf8,0xa0,0x00,0xbc,0xf8,0xa3,0x00,0xab,0xf8,0xa7,0x00,0x9a,0xf8,0xab,0x00,0x89,0xf8,0xae,0x00,  \
    0x78,0xf8,0xb2,0x00,0x67,0xf8,0xb6,0x00,0x55,0xf8,0xb9,0x00,0x44,0xf8,0xbd,0x00,0x33,0xf8,0xc1,0x00,0x21,0xf8,0xc4,0x00,0x0f,0xf8,0xc8,0x00,0xfe,0xf7,0xcc,0x00,0xec,0xf7,0xd0,0x00,0xda,0xf7,0xd3,0x00,0xc8,0xf7,0xd7,0x00,0xb6,0xf7,0xdb,0x00,0xa4,0xf7,0xdf,0x00,0x92,0xf7,0xe2,0x00,0x7f,0xf7,0xe6,0x00,0x6d,0xf7,0xea,0x00,0x5a,0xf7,0xee,0x00,0x48,0xf7,0xf2,0x00,0x35,0xf7,0xf5,0x00,0x23,0xf7,0xf9,0x00,0x10,0xf7,0xfd,0x00,0xfd,0xf6,0x01,0x01,0xea,0xf6,  \
    0x05,0x01,0xd7,0xf6,0x09,0x01,0xc3,0xf6,0x0c,0x01,0xb0,0xf6,0x10,0x01,0x9d,0xf6,0x14,0x01,0x89,0xf6,0x18,0x01,0x76,0xf6,0x1c,0x01,0x62,0xf6,0x1f,0x01,0x4e,0xf6,0x23,0x01,0x3a,0xf6,0x27,0x01,0x26,0xf6,0x2b,0x01,0x12,0xf6,0x2f,0x01,0xfe,0xf5,0x32,0x01,0xe9,0xf5,0x36,0x01,0xd5,0xf5,0x3a,0x01,0xc0,0xf5,0x3e,0x01,0xab,0xf5,0x41,0x01,0x96,0xf5,0x45,0x01,0x81,0xf5,0x49,0x01,0x6c,0xf5,0x4c,0x01,0x57,0xf5,0x50,0x01,0x41,0xf5,0x54,0x01,0x2c,0xf5,0x57,0x01,  \
    0x16,0xf5,0x5b,0x01,0x01,0xf5,0x5f,0x01,0xeb,0xf4,0x62,0x01,0xd5,0xf4,0x66,0x01,0xbf,0xf4,0x6a,0x01,0xa9,0xf4,0x6d,0x01,0x93,0xf4,0x71,0x01,0x7d,0xf4,0x74,0x01,0x67,0xf4,0x78,0x01,0x50,0xf4,0x7b,0x01,0x3a,0xf4,0x7f,0x01,0x23,0xf4,0x82,0x01,0x0c,0xf4,0x86,0x01,0xf5,0xf3,0x89,0x01,0xde,0xf3,0x8d,0x01,0xc7,0xf3,0x90,0x01,0xb0,0xf3,0x94,0x01,0x99,0xf3,0x97,0x01,0x81,0xf3,0x9a,0x01,0x6a,0xf3,0x9e,0x01,0x52,0xf3,0xa1,0x01,0x3a,0xf3,0xa4,0x01,0x22,0xf3,  \
    0xa7,0x01,0x0a,0xf3,0xaa,0x01,0xf2,0xf2,0xae,0x01,0xda,0xf2,0xb1,0x01,0xc1,0xf2,0xb4,0x01,0xa9,0xf2,0xb7,0x01,0x90,0xf2,0xba,0x01,0x77,0xf2,0xbd,0x01,0x5e,0xf2,0xc0,0x01,0x45,0xf2,0xc3,0x01,0x2c,0xf2,0xc6,0x01,0x13,0xf2,0xc8,0x01,0xf9,0xf1,0xcb,0x01,0xdf,0xf1,0xce,0x01,0xc6,0xf1,0xd1,0x01,0xac,0xf1,0xd3,0x01,0x92,0xf1,0xd6,0x01,0x78,0xf1,0xd8,0x01,0x5e,0xf1,0xdb,0x01,0x43,0xf1,0xdd,0x01,0x29,0xf1,0xe0,0x01,0x0e,0xf1,0xe2,0x01,0xf3,0xf0,0xe4,0x01,  \
    0xd8,0xf0,0xe7,0x01,0xbd,0xf0,0xe9,0x01,0xa2,0xf0,0xeb,0x01,0x87,0xf0,0xed,0x01,0x6b,0xf0,0xef,0x01,0x4f,0xf0,0xf1,0x01,0x34,0xf0,0xf3,0x01,0x18,0xf0,0xf4,0x01,0xfc,0xef,0xf6,0x01,0xdf,0xef,0xf8,0x01,0xc3,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x02,0x42,0x10,0x03,0x02,0x25,0x10,0x01,0x02,0x09,0x10,0xff,0x01,0xed,0x0f,0xfd,0x01,0xd0,0x0f,0xfb,0x01,0xb4,0x0f,0xf9,0x01,0x99,0x0f,0xf7,0x01,0x7d,0x0f,0xf5,0x01,0x61,0x0f,0xf3,0x01,0x46,0x0f,0xf1,0x01,0x2a,0x0f,0xef,0x01,0x0f,0x0f,0xed,0x01,0xf4,0x0e,0xea,0x01,0xd9,0x0e,0xe8,0x01,0xbe,0x0e,0xe6,0x01,0xa3,0x0e,0xe3,0x01,0x88,0x0e,0xe1,0x01,0x6e,0x0e,0xde,0x01,0x53,0x0e,0xdc,0x01,  \
    0x39,0x0e,0xd9,0x01,0x1f,0x0e,0xd6,0x01,0x05,0x0e,0xd4,0x01,0xeb,0x0d,0xd1,0x01,0xd1,0x0d,0xce,0x01,0xb8,0x0d,0xcb,0x01,0x9e,0x0d,0xc8,0x01,0x85,0x0d,0xc5,0x01,0x6c,0x0d,0xc2,0x01,0x53,0x0d,0xc0,0x01,0x3a,0x0d,0xbc,0x01,0x21,0x0d,0xb9,0x01,0x08,0x0d,0xb6,0x01,0xef,0x0c,0xb3,0x01,0xd7,0x0c,0xb0,0x01,0xbe,0x0c,0xad,0x01,0xa6,0x0c,0xaa,0x01,0x8e,0x0c,0xa6,0x01,0x76,0x0c,0xa3,0x01,0x5e,0x0c,0xa0,0x01,0x46,0x0c,0x9d,0x01,0x2e,0x0c,0x99,0x01,0x17,0x0c,  \
    0x96,0x01,0xff,0x0b,0x92,0x01,0xe8,0x0b,0x8f,0x01,0xd1,0x0b,0x8b,0x01,0xba,0x0b,0x88,0x01,0xa3,0x0b,0x84,0x01,0x8c,0x0b,0x81,0x01,0x75,0x0b,0x7d,0x01,0x5f,0x0b,0x7a,0x01,0x48,0x0b,0x76,0x01,0x32,0x0b,0x72,0x01,0x1c,0x0b,0x6f,0x01,0x06,0x0b,0x6b,0x01,0xf0,0x0a,0x67,0x01,0xda,0x0a,0x64,0x01,0xc4,0x0a,0x60,0x01,0xae,0x0a,0x5c,0x01,0x98,0x0a,0x59,0x01,0x83,0x0a,0x55,0x01,0x6d,0x0a,0x52,0x01,0x58,0x0a,0x4e,0x01,0x42,0x0a,0x4a,0x01,0x2d,0x0a,0x47,0x01,  \
    0x18,0x0a,0x43,0x01,0x02,0x0a,0x3f,0x01,0xed,0x09,0x3b,0x01,0xd9,0x09,0x38,0x01,0xc4,0x09,0x34,0x01,0xaf,0x09,0x30,0x01,0x9a,0x09,0x2d,0x01,0x86,0x09,0x29,0x01,0x71,0x09,0x25,0x01,0x5d,0x09,0x21,0x01,0x49,0x09,0x1e,0x01,0x35,0x09,0x1a,0x01,0x21,0x09,0x16,0x01,0x0d,0x09,0x12,0x01,0xf9,0x08,0x0f,0x01,0xe5,0x08,0x0b,0x01,0xd2,0x08,0x07,0x01,0xbe,0x08,0x04,0x01,0xab,0x08,0x00,0x01,0x97,0x08,0xfc,0x00,0x84,0x08,0xf8,0x00,0x71,0x08,0xf5,0x00,0x5e,0x08,  \
    0xf1,0x00,0x4b,0x08,0xed,0x00,0x38,0x08,0xe9,0x00,0x25,0x08,0xe6,0x00,0x12,0x08,0xe2,0x00,0x00,0x08,0xde,0x00,0xed,0x07,0xdb,0x00,0xdb,0x07,0xd7,0x00,0xc9,0x07,0xd3,0x00,0xb7,0x07,0xcf,0x00,0xa5,0x07,0xcc,0x00,0x93,0x07,0xc8,0x00,0x81,0x07,0xc4,0x00,0x6f,0x07,0xc1,0x00,0x5e,0x07,0xbd,0x00,0x4c,0x07,0xb9,0x00,0x3b,0x07,0xb5,0x00,0x2a,0x07,0xb2,0x00,0x18,0x07,0xae,0x00,0x07,0x07,0xab,0x00,0xf6,0x06,0xa7,0x00,0xe5,0x06,0xa3,0x00,0xd4,0x06,0xa0,0x00,  \
    0xc3,0x06,0x9c,0x00,0xb3,0x06,0x99,0x00,0xa2,0x06,0x95,0x00,0x91,0x06,0x91,0x00,0x81,0x06,0x8e,0x00,0x70,0x06,0x8a,0x00,0x60,0x06,0x87,0x00,0x50,0x06,0x84,0x00,0x3f,0x06,0x80,0x00,0x2f,0x06,0x7d,0x00,0x1f,0x06,0x79,0x00,0x0f,0x06,0x76,0x00,0xff,0x05,0x72,0x00,0xef,0x05,0x6f,0x00,0xdf,0x05,0x6c,0x00,0xd0,0x05,0x68,0x00,0xc0,0x05,0x65,0x00,0xb0,0x05,0x62,0x00,0xa1,0x05,0x5f,0x00,0x91,0x05,0x5b,0x00,0x82,0x05,0x58,0x00,0x72,0x05,0x55,0x00,0x63,0x05,  \
    0x52,0x00,0x54,0x05,0x4f,0x00,0x45,0x05,0x4c,0x00,0x36,0x05,0x48,0x00,0x27,0x05,0x45,0x00,0x18,0x05,0x42,0x00,0x08,0x05,0x3f,0x00,0xf9,0x04,0x3c,0x00,0xea,0x04,0x39,0x00,0xdc,0x04,0x36,0x00,0xcd,0x04,0x33,0x00,0xbe,0x04,0x31,0x00,0xaf,0x04,0x2e,0x00,0xa0,0x04,0x2b,0x00,0x92,0x04,0x28,0x00,0x83,0x04,0x25,0x00,0x75,0x04,0x22,0x00,0x66,0x04,0x20,0x00,0x58,0x04,0x1d,0x00,0x49,0x04,0x1a,0x00,0x3b,0x04,0x18,0x00,0x2d,0x04,0x15,0x00,0x1f,0x04,0x12,0x00,  \
    0x11,0x04,0x10,0x00,0x03,0x04,0x0d,0x00,0xf4,0x03,0x0a,0x00,0xe6,0x03,0x08,0x00,0xd9,0x03,0x05,0x00,0xcb,0x03,0x03,0x00,0xbd,0x03,0x00,0x00,0xaf,0x03,0xfe,0xff,0xa2,0x03,0xfc,0xff,0x94,0x03,0xf9,0xff,0x87,0x03,0xf7,0xff,0x79,0x03,0xf4,0xff,0x6c,0x03,0xf2,0xff,0x5e,0x03,0xf0,0xff,0x51,0x03,0xee,0xff,0x44,0x03,0xeb,0xff,0x36,0x03,0xe9,0xff,0x29,0x03,0xe7,0xff,0x1c,0x03,0xe5,0xff,0x0f,0x03,0xe3,0xff,0x02,0x03,0xe1,0xff,0xf5,0x02,0xdf,0xff,0xe8,0x02,  \
    0xdc,0xff,0xdb,0x02,0xda,0xff,0xce,0x02,0xd8,0xff,0xc1,0x02,0xd7,0xff,0xb4,0x02,0xd5,0xff,0xa7,0x02,0xd3,0xff,0x9b,0x02,0xd1,0xff,0x8e,0x02,0xcf,0xff,0x81,0x02,0xcd,0xff,0x74,0x02,0xcb,0xff,0x68,0x02,0xca,0xff,0x5b,0x02,0xc8,0xff,0x4f,0x02,0xc6,0xff,0x42,0x02,0xc5,0xff,0x36,0x02,0xc3,0xff,0x29,0x02,0xc1,0xff,0x1d,0x02,0xc0,0xff,0x11,0x02,0xbe,0xff,0x04,0x02,0xbd,0xff,0xf8,0x01,0xbb,0xff,0xec,0x01,0xba,0xff,0xe0,0x01,0xb8,0xff,0xd3,0x01,0xb7,0xff,  \
    0xc7,0x01,0xb6,0xff,0xbb,0x01,0xb4,0xff,0xaf,0x01,0xb3,0xff,0xa3,0x01,0xb2,0xff,0x97,0x01,0xb1,0xff,0x8a,0x01,0xaf,0xff,0x7e,0x01,0xae,0xff,0x72,0x01,0xad,0xff,0x66,0x01,0xac,0xff,0x5a,0x01,0xab,0xff,0x4e,0x01,0xaa,0xff,0x42,0x01,0xa9,0xff,0x36,0x01,0xa8,0xff,0x2a,0x01,0xa7,0xff,0x1e,0x01,0xa6,0xff,0x12,0x01,0xa5,0xff,0x06,0x01,0xa4,0xff,0xfa,0x00,0xa3,0xff,0xee,0x00,0xa3,0xff,0xe2,0x00,0xa2,0xff,0xd6,0x00,0xa1,0xff,0xca,0x00,0xa0,0xff,0xbe,0x00,  \
    0xa0,0xff,0xb2,0x00,0x9f,0xff,0xa6,0x00,0x9f,0xff,0x9b,0x00,0x9e,0xff,0x8f,0x00,0x9d,0xff,0x83,0x00,0x9d,0xff,0x77,0x00,0x9c,0xff,0x6b,0x00,0x9c,0xff,0x5f,0x00,0x9c,0xff,0x53,0x00,0x9b,0xff,0x48,0x00,0x9b,0xff,0x3c,0x00,0x9b,0xff,0x30,0x00,0x9a,0xff,0x24,0x00,0x9a,0xff,0x18,0x00,0x9a,0xff,0x0c,0x00,0x9a,0xff,0x01,0x00,0x9a,0xff,0xf5,0xff,0x99,0xff,0xe9,0xff,0x99,0xff,0xdd,0xff,0x99,0xff,0xd1,0xff,0x99,0xff,0xc6,0xff,0x99,0xff,0xba,0xff,0x99,0xff,  \
    0xae,0xff,0x99,0xff,0xa2,0xff,0x99,0xff,0x97,0xff,0x9a,0xff,0x8b,0xff,0x9a,0xff,0x7f,0xff,0x9a,0xff,0x73,0xff,0x9a,0xff,0x67,0xff,0x9a,0xff,0x5c,0xff,0x9b,0xff,0x50,0xff,0x9b,0xff,0x44,0xff,0x9b,0xff,0x38,0xff,0x9c,0xff,0x2c,0xff,0x9c,0xff,0x21,0xff,0x9d,0xff,0x15,0xff,0x9d,0xff,0x09,0xff,0x9e,0xff,0xfd,0xfe,0x9e,0xff,0xf1,0xfe,0x9f,0xff,0xe5,0xfe,0x9f,0xff,0xd9,0xfe,0xa0,0xff,0xce,0xfe,0xa1,0xff,0xc2,0xfe,0xa1,0xff,0xb6,0xfe,0xa2,0xff,0xaa,0xfe,  \
    0xa3,0xff,0x9e,0xfe,0xa4,0xff,0x92,0xfe,0xa4,0xff,0x86,0xfe,0xa5,0xff,0x7a,0xfe,0xa6,0xff,0x6e,0xfe,0xa7,0xff,0x62,0xfe,0xa8,0xff,0x56,0xfe,0xa9,0xff,0x4a,0xfe,0xaa,0xff,0x3e,0xfe,0xab,0xff,0x32,0xfe,0xac,0xff,0x26,0xfe,0xad,0xff,0x1a,0xfe,0xae,0xff,0x0d,0xfe,0xaf,0xff,0x01,0xfe,0xb0,0xff,0xf5,0xfd,0xb2,0xff,0xe9,0xfd,0xb3,0xff,0xdd,0xfd,0xb4,0xff,0xd0,0xfd,0xb6,0xff,0xc4,0xfd,0xb7,0xff,0xb8,0xfd,0xb8,0xff,0xab,0xfd,0xba,0xff,0x9f,0xfd,0xbb,0xff,  \
    0x93,0xfd,0xbc,0xff,0x86,0xfd,0xbe,0xff,0x7a,0xfd,0xbf,0xff,0x6d,0xfd,0xc1,0xff,0x61,0xfd,0xc3,0xff,0x54,0xfd,0xc4,0xff,0x48,0xfd,0xc6,0xff,0x3b,0xfd,0xc7,0xff,0x2e,0xfd,0xc9,0xff,0x22,0xfd,0xcb,0xff,0x15,0xfd,0xcd,0xff,0x09,0xfd,0xce,0xff,0xfc,0xfc,0xd0,0xff,0xef,0xfc,0xd2,0xff,0xe3,0xfc,0xd4,0xff,0xd6,0xfc,0xd6,0xff,0xc9,0xfc,0xd8,0xff,0xbc,0xfc,0xda,0xff,0xb0,0xfc,0xdc,0xff,0xa3,0xfc,0xde,0xff,0x96,0xfc,0xe0,0xff,0x89,0xfc,0xe2,0xff,0x7c,0xfc,  \
    0xe4,0xff,0x6f,0xfc,0xe6,0xff,0x62,0xfc,0xe8,0xff,0x55,0xfc,0xea,0xff,0x48,0xfc,0xed,0xff,0x3b,0xfc,0xef,0xff,0x2d,0xfc,0xf1,0xff,0x20,0xfc,0xf3,0xff,0x13,0xfc,0xf6,0xff,0x06,0xfc,0xf8,0xff,0xf8,0xfb,0xfa,0xff,0xeb,0xfb,0xfd,0xff,0xdd,0xfb,0xff,0xff,0xd0,0xfb,0x02,0x00,0xc2,0xfb,0x04,0x00,0xb4,0xfb,0x07,0x00,0xa7,0xfb,0x09,0x00,0x99,0xfb,0x0c,0x00,0x8b,0xfb,0x0e,0x00,0x7d,0xfb,0x11,0x00,0x6f,0xfb,0x14,0x00,0x61,0xfb,0x16,0x00,0x53,0xfb,0x19,0x00,  \
    0x45,0xfb,0x1c,0x00,0x37,0xfb,0x1e,0x00,0x29,0xfb,0x21,0x00,0x1b,0xfb,0x24,0x00,0x0d,0xfb,0x27,0x00,0xfe,0xfa,0x29,0x00,0xf0,0xfa,0x2c,0x00,0xe1,0xfa,0x2f,0x00,0xd3,0xfa,0x32,0x00,0xc4,0xfa,0x35,0x00,0xb6,0xfa,0x38,0x00,0xa7,0xfa,0x3b,0x00,0x98,0xfa,0x3e,0x00,0x8a,0xfa,0x41,0x00,0x7b,0xfa,0x44,0x00,0x6c,0xfa,0x47,0x00,0x5d,0xfa,0x4a,0x00,0x4e,0xfa,0x4d,0x00,0x3f,0xfa,0x50,0x00,0x30,0xfa,0x53,0x00,0x21,0xfa,0x56,0x00,0x11,0xfa,0x5a,0x00,0x02,0xfa,  \
    0x5d,0x00,0xf3,0xf9,0x60,0x00,0xe3,0xf9,0x63,0x00,0xd4,0xf9,0x67,0x00,0xc4,0xf9,0x6a,0x00,0xb5,0xf9,0x6d,0x00,0xa5,0xf9,0x70,0x00,0x95,0xf9,0x74,0x00,0x85,0xf9,0x77,0x00,0x75,0xf9,0x7a,0x00,0x65,0xf9,0x7e,0x00,0x55,0xf9,0x81,0x00,0x45,0xf9,0x85,0x00,0x35,0xf9,0x88,0x00,0x25,0xf9,0x8c,0x00,0x14,0xf9,0x8f,0x00,0x04,0xf9,0x93,0x00,0xf3,0xf8,0x96,0x00,0xe3,0xf8,0x99,0x00,0xd2,0xf8,0x9d,0x00,0xc1,0xf8,0xa1,0x00,0xb0,0xf8,0xa4,0x00,0x9f,0xf8,0xa8,0x00,  \
    0x8e,0xf8,0xab,0x00,0x7d,0xf8,0xaf,0x00,0x6c,0xf8,0xb2,0x00,0x5b,0xf8,0xb6,0x00,0x49,0xf8,0xba,0x00,0x38,0xf8,0xbd,0x00,0x26,0xf8,0xc1,0x00,0x15,0xf8,0xc4,0x00,0x03,0xf8,0xc8,0x00,0xf1,0xf7,0xcc,0x00,0xdf,0xf7,0xcf,0x00,0xcd,0xf7,0xd3,0x00,0xbb,0xf7,0xd7,0x00,0xa9,0xf7,0xda,0x00,0x97,0xf7,0xde,0x00,0x84,0xf7,0xe2,0x00,0x72,0xf7,0xe6,0x00,0x60,0xf7,0xe9,0x00,0x4d,0xf7,0xed,0x00,0x3a,0xf7,0xf1,0x00,0x28,0xf7,0xf4,0x00,0x15,0xf7,0xf8,0x00,0x02,0xf7,  \
    0xfc,0x00,0xef,0xf6,0x00,0x01,0xdc,0xf6,0x03,0x01,0xc9,0xf6,0x07,0x01,0xb5,0xf6,0x0b,0x01,0xa2,0xf6,0x0f,0x01,0x8e,0xf6,0x12,0x01,0x7b,0xf6,0x16,0x01,0x67,0xf6,0x1a,0x01,0x53,0xf6,0x1e,0x01,0x3f,0xf6,0x21,0x01,0x2b,0xf6,0x25,0x01,0x17,0xf6,0x29,0x01,0x03,0xf6,0x2c,0x01,0xee,0xf5,0x30,0x01,0xd9,0xf5,0x34,0x01,0xc5,0xf5,0x37,0x01,0xb0,0xf5,0x3b,0x01,0x9b,0xf5,0x3f,0x01,0x86,0xf5,0x42,0x01,0x71,0xf5,0x46,0x01,0x5c,0xf5,0x49,0x01,0x46,0xf5,0x4d,0x01,  \
    0x31,0xf5,0x51,0x01,0x1b,0xf5,0x54,0x01,0x06,0xf5,0x58,0x01,0xf0,0xf4,0x5b,0x01,0xda,0xf4,0x5f,0x01,0xc4,0xf4,0x62,0x01,0xae,0xf4,0x66,0x01,0x98,0xf4,0x69,0x01,0x82,0xf4,0x6d,0x01,0x6b,0xf4,0x70,0x01,0x55,0xf4,0x74,0x01,0x3e,0xf4,0x77,0x01,0x28,0xf4,0x7b,0x01,0x11,0xf4,0x7e,0x01,0xfa,0xf3,0x81,0x01,0xe3,0xf3,0x85,0x01,0xcc,0xf3,0x88,0x01,0xb5,0xf3,0x8b,0x01,0x9d,0xf3,0x8f,0x01,0x86,0xf3,0x92,0x01,0x6e,0xf3,0x95,0x01,0x56,0xf3,0x98,0x01,0x3f,0xf3,  \
    0x9b,0x01,0x27,0xf3,0x9f,0x01,0x0e,0xf3,0xa2,0x01,0xf6,0xf2,0xa5,0x01,0xde,0xf2,0xa8,0x01,0xc5,0xf2,0xab,0x01,0xad,0xf2,0xae,0x01,0x94,0xf2,0xb1,0x01,0x7b,0xf2,0xb4,0x01,0x62,0xf2,0xb6,0x01,0x49,0xf2,0xb9,0x01,0x30,0xf2,0xbc,0x01,0x17,0xf2,0xbf,0x01,0xfd,0xf1,0xc1,0x01,0xe4,0xf1,0xc4,0x01,0xca,0xf1,0xc7,0x01,0xb0,0xf1,0xc9,0x01,0x96,0xf1,0xcc,0x01,0x7c,0xf1,0xce,0x01,0x62,0xf1,0xd1,0x01,0x47,0xf1,0xd3,0x01,0x2d,0xf1,0xd5,0x01,0x12,0xf1,0xd8,0x01,  \
    0xf7,0xf0,0xda,0x01,0xdc,0xf0,0xdc,0x01,0xc1,0xf0,0xde,0x01,0xa6,0xf0,0xe0,0x01,0x8a,0xf0,0xe2,0x01,0x6f,0xf0,0xe4,0x01,0x53,0xf0,0xe6,0x01,0x37,0xf0,0xe8,0x01,0x1c,0xf0,0xea,0x01,0xff,0xef,0xeb,0x01,0xe3,0xef,0xed,0x01,0xc7,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf7,0x01,0x3f,0x10,0xf5,0x01,0x22,0x10,0xf4,0x01,0x06,0x10,0xf2,0x01,0xe9,0x0f,0xf0,0x01,0xcd,0x0f,0xee,0x01,0xb1,0x0f,0xec,0x01,0x95,0x0f,0xea,0x01,0x7a,0x0f,0xe8,0x01,0x5e,0x0f,0xe6,0x01,0x42,0x0f,0xe4,0x01,0x27,0x0f,0xe2,0x01,0x0c,0x0f,0xe0,0x01,0xf1,0x0e,0xde,0x01,0xd6,0x0e,0xdc,0x01,0xbb,0x0e,0xd9,0x01,0xa0,0x0e,0xd7,0x01,0x85,0x0e,0xd4,0x01,0x6b,0x0e,0xd2,0x01,  \
    0x50,0x0e,0xcf,0x01,0x36,0x0e,0xcd,0x01,0x1c,0x0e,0xca,0x01,0x02,0x0e,0xc8,0x01,0xe8,0x0d,0xc5,0x01,0xce,0x0d,0xc2,0x01,0xb4,0x0d,0xc0,0x01,0x9b,0x0d,0xbd,0x01,0x82,0x0d,0xba,0x01,0x68,0x0d,0xb7,0x01,0x4f,0x0d,0xb4,0x01,0x36,0x0d,0xb1,0x01,0x1d,0x0d,0xae,0x01,0x04,0x0d,0xab,0x01,0xec,0x0c,0xa8,0x01,0xd3,0x0c,0xa5,0x01,0xbb,0x0c,0xa2,0x01,0xa2,0x0c,0x9f,0x01,0x8a,0x0c,0x9c,0x01,0x72,0x0c,0x99,0x01,0x5a,0x0c,0x96,0x01,0x42,0x0c,0x92,0x01,0x2b,0x0c,  \
    0x8f,0x01,0x13,0x0c,0x8c,0x01,0xfc,0x0b,0x88,0x01,0xe4,0x0b,0x85,0x01,0xcd,0x0b,0x82,0x01,0xb6,0x0b,0x7e,0x01,0x9f,0x0b,0x7b,0x01,0x88,0x0b,0x77,0x01,0x72,0x0b,0x74,0x01,0x5b,0x0b,0x70,0x01,0x44,0x0b,0x6d,0x01,0x2e,0x0b,0x69,0x01,0x18,0x0b,0x66,0x01,0x02,0x0b,0x62,0x01,0xec,0x0a,0x5f,0x01,0xd6,0x0a,0x5b,0x01,0xc0,0x0a,0x58,0x01,0xaa,0x0a,0x54,0x01,0x94,0x0a,0x51,0x01,0x7e,0x0a,0x4d,0x01,0x69,0x0a,0x49,0x01,0x53,0x0a,0x46,0x01,0x3e,0x0a,0x42,0x01,  \
    0x29,0x0a,0x3f,0x01,0x13,0x0a,0x3b,0x01,0xfe,0x09,0x38,0x01,0xe9,0x09,0x34,0x01,0xd4,0x09,0x30,0x01,0xbf,0x09,0x2d,0x01,0xab,0x09,0x29,0x01,0x96,0x09,0x25,0x01,0x82,0x09,0x22,0x01,0x6d,0x09,0x1e,0x01,0x59,0x09,0x1b,0x01,0x45,0x09,0x17,0x01,0x30,0x09,0x13,0x01,0x1c,0x09,0x10,0x01,0x08,0x09,0x0c,0x01,0xf5,0x08,0x08,0x01,0xe1,0x08,0x05,0x01,0xcd,0x08,0x01,0x01,0xba,0x08,0xfd,0x00,0xa6,0x08,0xfa,0x00,0x93,0x08,0xf6,0x00,0x80,0x08,0xf3,0x00,0x6c,0x08,  \
    0xef,0x00,0x59,0x08,0xeb,0x00,0x46,0x08,0xe8,0x00,0x33,0x08,0xe4,0x00,0x21,0x08,0xe0,0x00,0x0e,0x08,0xdd,0x00,0xfb,0x07,0xd9,0x00,0xe9,0x07,0xd6,0x00,0xd6,0x07,0xd2,0x00,0xc4,0x07,0xce,0x00,0xb2,0x07,0xcb,0x00,0xa0,0x07,0xc7,0x00,0x8e,0x07,0xc3,0x00,0x7d,0x07,0xc0,0x00,0x6b,0x07,0xbc,0x00,0x59,0x07,0xb9,0x00,0x48,0x07,0xb5,0x00,0x36,0x07,0xb1,0x00,0x25,0x07,0xae,0x00,0x14,0x07,0xaa,0x00,0x03,0x07,0xa7,0x00,0xf2,0x06,0xa3,0x00,0xe1,0x06,0xa0,0x00,  \
    0xd0,0x06,0x9c,0x00,0xbf,0x06,0x99,0x00,0xae,0x06,0x95,0x00,0x9d,0x06,0x92,0x00,0x8d,0x06,0x8e,0x00,0x7c,0x06,0x8b,0x00,0x6c,0x06,0x87,0x00,0x5b,0x06,0x84,0x00,0x4b,0x06,0x81,0x00,0x3b,0x06,0x7d,0x00,0x2b,0x06,0x7a,0x00,0x1a,0x06,0x77,0x00,0x0a,0x06,0x73,0x00,0xfa,0x05,0x70,0x00,0xeb,0x05,0x6d,0x00,0xdb,0x05,0x6a,0x00,0xcb,0x05,0x66,0x00,0xbb,0x05,0x63,0x00,0xac,0x05,0x60,0x00,0x9c,0x05,0x5d,0x00,0x8d,0x05,0x5a,0x00,0x7d,0x05,0x56,0x00,0x6e,0x05,  \
    0x53,0x00,0x5f,0x05,0x50,0x00,0x4f,0x05,0x4d,0x00,0x40,0x05,0x4a,0x00,0x31,0x05,0x47,0x00,0x22,0x05,0x44,0x00,0x13,0x05,0x41,0x00,0x04,0x05,0x3e,0x00,0xf5,0x04,0x3b,0x00,0xe6,0x04,0x38,0x00,0xd7,0x04,0x35,0x00,0xc8,0x04,0x33,0x00,0xb9,0x04,0x30,0x00,0xab,0x04,0x2d,0x00,0x9c,0x04,0x2a,0x00,0x8d,0x04,0x27,0x00,0x7f,0x04,0x25,0x00,0x70,0x04,0x22,0x00,0x62,0x04,0x1f,0x00,0x54,0x04,0x1d,0x00,0x45,0x04,0x1a,0x00,0x37,0x04,0x17,0x00,0x29,0x04,0x15,0x00,  \
    0x1b,0x04,0x12,0x00,0x0d,0x04,0x10,0x00,0xfe,0x03,0x0d,0x00,0xf0,0x03,0x0b,0x00,0xe3,0x03,0x08,0x00,0xd5,0x03,0x06,0x00,0xc7,0x03,0x03,0x00,0xb9,0x03,0x01,0x00,0xab,0x03,0xfe,0xff,0x9e,0x03,0xfc,0xff,0x90,0x03,0xfa,0xff,0x83,0x03,0xf7,0xff,0x75,0x03,0xf5,0xff,0x68,0x03,0xf3,0xff,0x5b,0x03,0xf1,0xff,0x4d,0x03,0xee,0xff,0x40,0x03,0xec,0xff,0x33,0x03,0xea,0xff,0x26,0x03,0xe8,0xff,0x19,0x03,0xe6,0xff,0x0c,0x03,0xe4,0xff,0xfe,0x02,0xe2,0xff,0xf1,0x02,  \
    0xe0,0xff,0xe4,0x02,0xde,0xff,0xd8,0x02,0xdc,0xff,0xcb,0x02,0xda,0xff,0xbe,0x02,0xd8,0xff,0xb1,0x02,0xd6,0xff,0xa4,0x02,0xd4,0xff,0x97,0x02,0xd2,0xff,0x8b,0x02,0xd0,0xff,0x7e,0x02,0xcf,0xff,0x71,0x02,0xcd,0xff,0x65,0x02,0xcb,0xff,0x58,0x02,0xca,0xff,0x4c,0x02,0xc8,0xff,0x40,0x02,0xc6,0xff,0x33,0x02,0xc5,0xff,0x27,0x02,0xc3,0xff,0x1a,0x02,0xc2,0xff,0x0e,0x02,0xc0,0xff,0x02,0x02,0xbf,0xff,0xf6,0x01,0xbd,0xff,0xe9,0x01,0xbc,0xff,0xdd,0x01,0xba,0xff,  \
    0xd1,0x01,0xb9,0xff,0xc5,0x01,0xb8,0xff,0xb9,0x01,0xb6,0xff,0xad,0x01,0xb5,0xff,0xa0,0x01,0xb4,0xff,0x94,0x01,0xb3,0xff,0x88,0x01,0xb1,0xff,0x7c,0x01,0xb0,0xff,0x70,0x01,0xaf,0xff,0x64,0x01,0xae,0xff,0x58,0x01,0xad,0xff,0x4c,0x01,0xac,0xff,0x40,0x01,0xab,0xff,0x34,0x01,0xaa,0xff,0x28,0x01,0xa9,0xff,0x1c,0x01,0xa8,0xff,0x10,0x01,0xa7,0xff,0x05,0x01,0xa7,0xff,0xf9,0x00,0xa6,0xff,0xed,0x00,0xa5,0xff,0xe1,0x00,0xa4,0xff,0xd5,0x00,0xa4,0xff,0xc9,0x00,  \
    0xa3,0xff,0xbd,0x00,0xa2,0xff,0xb1,0x00,0xa2,0xff,0xa5,0x00,0xa1,0xff,0x99,0x00,0xa0,0xff,0x8e,0x00,0xa0,0xff,0x82,0x00,0x9f,0xff,0x76,0x00,0x9f,0xff,0x6a,0x00,0x9f,0xff,0x5e,0x00,0x9e,0xff,0x53,0x00,0x9e,0xff,0x47,0x00,0x9d,0xff,0x3b,0x00,0x9d,0xff,0x2f,0x00,0x9d,0xff,0x24,0x00,0x9d,0xff,0x18,0x00,0x9c,0xff,0x0c,0x00,0x9c,0xff,0x00,0x00,0x9c,0xff,0xf5,0xff,0x9c,0xff,0xe9,0xff,0x9c,0xff,0xdd,0xff,0x9c,0xff,0xd1,0xff,0x9c,0xff,0xc6,0xff,0x9c,0xff,  \
    0xba,0xff,0x9c,0xff,0xae,0xff,0x9c,0xff,0xa2,0xff,0x9c,0xff,0x97,0xff,0x9c,0xff,0x8b,0xff,0x9c,0xff,0x7f,0xff,0x9c,0xff,0x74,0xff,0x9d,0xff,0x68,0xff,0x9d,0xff,0x5c,0xff,0x9d,0xff,0x50,0xff,0x9e,0xff,0x45,0xff,0x9e,0xff,0x39,0xff,0x9e,0xff,0x2d,0xff,0x9f,0xff,0x21,0xff,0x9f,0xff,0x16,0xff,0xa0,0xff,0x0a,0xff,0xa0,0xff,0xfe,0xfe,0xa1,0xff,0xf2,0xfe,0xa1,0xff,0xe6,0xfe,0xa2,0xff,0xdb,0xfe,0xa2,0xff,0xcf,0xfe,0xa3,0xff,0xc3,0xfe,0xa4,0xff,0xb7,0xfe,  \
    0xa4,0xff,0xab,0xfe,0xa5,0xff,0x9f,0xfe,0xa6,0xff,0x94,0xfe,0xa7,0xff,0x88,0xfe,0xa8,0xff,0x7c,0xfe,0xa8,0xff,0x70,0xfe,0xa9,0xff,0x64,0xfe,0xaa,0xff,0x58,0xfe,0xab,0xff,0x4c,0xfe,0xac,0xff,0x40,0xfe,0xad,0xff,0x34,0xfe,0xae,0xff,0x28,0xfe,0xaf,0xff,0x1c,0xfe,0xb0,0xff,0x10,0xfe,0xb1,0xff,0x03,0xfe,0xb3,0xff,0xf7,0xfd,0xb4,0xff,0xeb,0xfd,0xb5,0xff,0xdf,0xfd,0xb6,0xff,0xd3,0xfd,0xb8,0xff,0xc6,0xfd,0xb9,0xff,0xba,0xfd,0xba,0xff,0xae,0xfd,0xbc,0xff,  \
    0xa2,0xfd,0xbd,0xff,0x95,0xfd,0xbe,0xff,0x89,0xfd,0xc0,0xff,0x7c,0xfd,0xc1,0xff,0x70,0xfd,0xc3,0xff,0x64,0xfd,0xc4,0xff,0x57,0xfd,0xc6,0xff,0x4b,0xfd,0xc8,0xff,0x3e,0xfd,0xc9,0xff,0x32,0xfd,0xcb,0xff,0x25,0xfd,0xcc,0xff,0x18,0xfd,0xce,0xff,0x0c,0xfd,0xd0,0xff,0xff,0xfc,0xd2,0xff,0xf3,0xfc,0xd4,0xff,0xe6,0xfc,0xd5,0xff,0xd9,0xfc,0xd7,0xff,0xcd,0xfc,0xd9,0xff,0xc0,0xfc,0xdb,0xff,0xb3,0xfc,0xdd,0xff,0xa6,0xfc,0xdf,0xff,0x99,0xfc,0xe1,0xff,0x8d,0xfc,  \
    0xe3,0xff,0x80,0xfc,0xe5,0xff,0x73,0xfc,0xe7,0xff,0x66,0xfc,0xe9,0xff,0x59,0xfc,0xeb,0xff,0x4c,0xfc,0xee,0xff,0x3e,0xfc,0xf0,0xff,0x31,0xfc,0xf2,0xff,0x24,0xfc,0xf4,0xff,0x17,0xfc,0xf6,0xff,0x0a,0xfc,0xf9,0xff,0xfc,0xfb,0xfb,0xff,0xef,0xfb,0xfd,0xff,0xe1,0xfb,0x00,0x00,0xd4,0xfb,0x02,0x00,0xc6,0xfb,0x05,0x00,0xb9,0xfb,0x07,0x00,0xab,0xfb,0x0a,0x00,0x9d,0xfb,0x0c,0x00,0x90,0xfb,0x0f,0x00,0x82,0xfb,0x11,0x00,0x74,0xfb,0x14,0x00,0x66,0xfb,0x16,0x00,  \
    0x58,0xfb,0x19,0x00,0x4a,0xfb,0x1c,0x00,0x3c,0xfb,0x1e,0x00,0x2e,0xfb,0x21,0x00,0x1f,0xfb,0x24,0x00,0x11,0xfb,0x26,0x00,0x03,0xfb,0x29,0x00,0xf4,0xfa,0x2c,0x00,0xe6,0xfa,0x2f,0x00,0xd8,0xfa,0x32,0x00,0xc9,0xfa,0x34,0x00,0xba,0xfa,0x37,0x00,0xac,0xfa,0x3a,0x00,0x9d,0xfa,0x3d,0x00,0x8e,0xfa,0x40,0x00,0x80,0xfa,0x43,0x00,0x71,0xfa,0x46,0x00,0x62,0xfa,0x49,0x00,0x53,0xfa,0x4c,0x00,0x44,0xfa,0x4f,0x00,0x35,0xfa,0x52,0x00,0x26,0xfa,0x55,0x00,0x16,0xfa,  \
    0x58,0x00,0x07,0xfa,0x5b,0x00,0xf8,0xf9,0x5f,0x00,0xe8,0xf9,0x62,0x00,0xd9,0xf9,0x65,0x00,0xc9,0xf9,0x68,0x00,0xba,0xf9,0x6b,0x00,0xaa,0xf9,0x6f,0x00,0x9a,0xf9,0x72,0x00,0x8a,0xf9,0x75,0x00,0x7a,0xf9,0x78,0x00,0x6a,0xf9,0x7c,0x00,0x5a,0xf9,0x7f,0x00,0x4a,0xf9,0x82,0x00,0x3a,0xf9,0x86,0x00,0x2a,0xf9,0x89,0x00,0x19,0xf9,0x8d,0x00,0x09,0xf9,0x90,0x00,0xf8,0xf8,0x93,0x00,0xe8,0xf8,0x97,0x00,0xd7,0xf8,0x9a,0x00,0xc6,0xf8,0x9e,0x00,0xb5,0xf8,0xa1,0x00,  \
    0xa4,0xf8,0xa5,0x00,0x93,0xf8,0xa8,0x00,0x82,0xf8,0xac,0x00,0x71,0xf8,0xaf,0x00,0x60,0xf8,0xb3,0x00,0x4e,0xf8,0xb6,0x00,0x3d,0xf8,0xba,0x00,0x2b,0xf8,0xbd,0x00,0x1a,0xf8,0xc1,0x00,0x08,0xf8,0xc4,0x00,0xf6,0xf7,0xc8,0x00,0xe4,0xf7,0xcb,0x00,0xd2,0xf7,0xcf,0x00,0xc0,0xf7,0xd3,0x00,0xae,0xf7,0xd6,0x00,0x9c,0xf7,0xda,0x00,0x8a,0xf7,0xde,0x00,0x77,0xf7,0xe1,0x00,0x65,0xf7,0xe5,0x00,0x52,0xf7,0xe8,0x00,0x3f,0xf7,0xec,0x00,0x2d,0xf7,0xf0,0x00,0x1a,0xf7,  \
    0xf3,0x00,0x07,0xf7,0xf7,0x00,0xf4,0xf6,0xfb,0x00,0xe1,0xf6,0xfe,0x00,0xcd,0xf6,0x02,0x01,0xba,0xf6,0x06,0x01,0xa7,0xf6,0x09,0x01,0x93,0xf6,0x0d,0x01,0x80,0xf6,0x11,0x01,0x6c,0xf6,0x14,0x01,0x58,0xf6,0x18,0x01,0x44,0xf6,0x1c,0x01,0x30,0xf6,0x1f,0x01,0x1c,0xf6,0x23,0x01,0x07,0xf6,0x26,0x01,0xf3,0xf5,0x2a,0x01,0xde,0xf5,0x2d,0x01,0xca,0xf5,0x31,0x01,0xb5,0xf5,0x35,0x01,0xa0,0xf5,0x38,0x01,0x8b,0xf5,0x3c,0x01,0x76,0xf5,0x3f,0x01,0x60,0xf5,0x43,0x01,  \
    0x4b,0xf5,0x46,0x01,0x36,0xf5,0x4a,0x01,0x20,0xf5,0x4d,0x01,0x0a,0xf5,0x51,0x01,0xf5,0xf4,0x54,0x01,0xdf,0xf4,0x57,0x01,0xc9,0xf4,0x5b,0x01,0xb3,0xf4,0x5e,0x01,0x9c,0xf4,0x62,0x01,0x86,0xf4,0x65,0x01,0x70,0xf4,0x69,0x01,0x59,0xf4,0x6c,0x01,0x43,0xf4,0x6f,0x01,0x2c,0xf4,0x73,0x01,0x15,0xf4,0x76,0x01,0xff,0xf3,0x79,0x01,0xe7,0xf3,0x7d,0x01,0xd0,0xf3,0x80,0x01,0xb9,0xf3,0x83,0x01,0xa2,0xf3,0x86,0x01,0x8a,0xf3,0x89,0x01,0x73,0xf3,0x8c,0x01,0x5b,0xf3,  \
    0x90,0x01,0x43,0xf3,0x93,0x01,0x2b,0xf3,0x96,0x01,0x13,0xf3,0x99,0x01,0xfb,0xf2,0x9c,0x01,0xe2,0xf2,0x9f,0x01,0xca,0xf2,0xa2,0x01,0xb1,0xf2,0xa5,0x01,0x98,0xf2,0xa7,0x01,0x80,0xf2,0xaa,0x01,0x67,0xf2,0xad,0x01,0x4d,0xf2,0xb0,0x01,0x34,0xf2,0xb2,0x01,0x1b,0xf2,0xb5,0x01,0x01,0xf2,0xb8,0x01,0xe8,0xf1,0xba,0x01,0xce,0xf1,0xbd,0x01,0xb4,0xf1,0xbf,0x01,0x9a,0xf1,0xc2,0x01,0x80,0xf1,0xc4,0x01,0x66,0xf1,0xc7,0x01,0x4b,0xf1,0xc9,0x01,0x31,0xf1,0xcb,0x01,  \
    0x16,0xf1,0xcd,0x01,0xfb,0xf0,0xd0,0x01,0xe0,0xf0,0xd2,0x01,0xc5,0xf0,0xd4,0x01,0xaa,0xf0,0xd6,0x01,0x8e,0xf0,0xd8,0x01,0x73,0xf0,0xda,0x01,0x57,0xf0,0xdc,0x01,0x3b,0xf0,0xdd,0x01,0x1f,0xf0,0xdf,0x01,0x03,0xf0,0xe1,0x01,0xe7,0xef,0xe2,0x01,0xcb,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xea,0x01,0x3c,0x10,0xe8,0x01,0x1f,0x10,0xe6,0x01,0x03,0x10,0xe5,0x01,0xe6,0x0f,0xe3,0x01,0xca,0x0f,0xe1,0x01,0xae,0x0f,0xdf,0x01,0x92,0x0f,0xde,0x01,0x77,0x0f,0xdc,0x01,0x5b,0x0f,0xda,0x01,0x3f,0x0f,0xd8,0x01,0x24,0x0f,0xd6,0x01,0x09,0x0f,0xd3,0x01,0xed,0x0e,0xd1,0x01,0xd2,0x0e,0xcf,0x01,0xb7,0x0e,0xcd,0x01,0x9d,0x0e,0xcb,0x01,0x82,0x0e,0xc8,0x01,  \
    0x67,0x0e,0xc6,0x01,0x4d,0x0e,0xc3,0x01,0x33,0x0e,0xc1,0x01,0x18,0x0e,0xbe,0x01,0xfe,0x0d,0xbc,0x01,0xe5,0x0d,0xb9,0x01,0xcb,0x0d,0xb7,0x01,0xb1,0x0d,0xb4,0x01,0x98,0x0d,0xb1,0x01,0x7e,0x0d,0xaf,0x01,0x65,0x0d,0xac,0x01,0x4c,0x0d,0xa9,0x01,0x33,0x0d,0xa6,0x01,0x1a,0x0d,0xa3,0x01,0x01,0x0d,0xa0,0x01,0xe8,0x0c,0x9d,0x01,0xd0,0x0c,0x9a,0x01,0xb7,0x0c,0x98,0x01,0x9f,0x0c,0x94,0x01,0x87,0x0c,0x91,0x01,0x6e,0x0c,0x8e,0x01,0x56,0x0c,0x8b,0x01,0x3f,0x0c,  \
    0x88,0x01,0x27,0x0c,0x85,0x01,0x0f,0x0c,0x82,0x01,0xf8,0x0b,0x7e,0x01,0xe1,0x0b,0x7b,0x01,0xc9,0x0b,0x78,0x01,0xb2,0x0b,0x75,0x01,0x9b,0x0b,0x71,0x01,0x84,0x0b,0x6e,0x01,0x6e,0x0b,0x6b,0x01,0x57,0x0b,0x67,0x01,0x41,0x0b,0x64,0x01,0x2a,0x0b,0x60,0x01,0x14,0x0b,0x5d,0x01,0xfe,0x0a,0x5a,0x01,0xe8,0x0a,0x56,0x01,0xd2,0x0a,0x53,0x01,0xbc,0x0a,0x4f,0x01,0xa6,0x0a,0x4c,0x01,0x90,0x0a,0x48,0x01,0x7a,0x0a,0x45,0x01,0x65,0x0a,0x41,0x01,0x4f,0x0a,0x3e,0x01,  \
    0x3a,0x0a,0x3a,0x01,0x24,0x0a,0x37,0x01,0x0f,0x0a,0x33,0x01,0xfa,0x09,0x30,0x01,0xe5,0x09,0x2c,0x01,0xd0,0x09,0x29,0x01,0xbb,0x09,0x25,0x01,0xa6,0x09,0x22,0x01,0x92,0x09,0x1e,0x01,0x7d,0x09,0x1b,0x01,0x69,0x09,0x17,0x01,0x55,0x09,0x14,0x01,0x40,0x09,0x10,0x01,0x2c,0x09,0x0d,0x01,0x18,0x09,0x09,0x01,0x04,0x09,0x06,0x01,0xf0,0x08,0x02,0x01,0xdd,0x08,0xff,0x00,0xc9,0x08,0xfb,0x00,0xb5,0x08,0xf7,0x00,0xa2,0x08,0xf4,0x00,0x8f,0x08,0xf0,0x00,0x7b,0x08,  \
    0xed,0x00,0x68,0x08,0xe9,0x00,0x55,0x08,0xe6,0x00,0x42,0x08,0xe2,0x00,0x2f,0x08,0xdf,0x00,0x1c,0x08,0xdb,0x00,0x09,0x08,0xd8,0x00,0xf7,0x07,0xd4,0x00,0xe4,0x07,0xd1,0x00,0xd2,0x07,0xcd,0x00,0xc0,0x07,0xca,0x00,0xae,0x07,0xc6,0x00,0x9c,0x07,0xc2,0x00,0x8a,0x07,0xbf,0x00,0x78,0x07,0xbb,0x00,0x66,0x07,0xb8,0x00,0x55,0x07,0xb4,0x00,0x43,0x07,0xb1,0x00,0x32,0x07,0xad,0x00,0x21,0x07,0xaa,0x00,0x0f,0x07,0xa6,0x00,0xfe,0x06,0xa3,0x00,0xed,0x06,0xa0,0x00,  \
    0xdc,0x06,0x9c,0x00,0xcb,0x06,0x99,0x00,0xba,0x06,0x95,0x00,0xaa,0x06,0x92,0x00,0x99,0x06,0x8f,0x00,0x88,0x06,0x8b,0x00,0x78,0x06,0x88,0x00,0x67,0x06,0x85,0x00,0x57,0x06,0x81,0x00,0x46,0x06,0x7e,0x00,0x36,0x06,0x7b,0x00,0x26,0x06,0x77,0x00,0x16,0x06,0x74,0x00,0x06,0x06,0x71,0x00,0xf6,0x05,0x6e,0x00,0xe6,0x05,0x6b,0x00,0xd6,0x05,0x67,0x00,0xc6,0x05,0x64,0x00,0xb7,0x05,0x61,0x00,0xa7,0x05,0x5e,0x00,0x98,0x05,0x5b,0x00,0x88,0x05,0x58,0x00,0x79,0x05,  \
    0x55,0x00,0x69,0x05,0x52,0x00,0x5a,0x05,0x4f,0x00,0x4b,0x05,0x4c,0x00,0x3c,0x05,0x49,0x00,0x2d,0x05,0x46,0x00,0x1e,0x05,0x43,0x00,0x0f,0x05,0x40,0x00,0x00,0x05,0x3d,0x00,0xf1,0x04,0x3a,0x00,0xe2,0x04,0x37,0x00,0xd3,0x04,0x35,0x00,0xc4,0x04,0x32,0x00,0xb5,0x04,0x2f,0x00,0xa6,0x04,0x2c,0x00,0x98,0x04,0x2a,0x00,0x89,0x04,0x27,0x00,0x7b,0x04,0x24,0x00,0x6c,0x04,0x22,0x00,0x5e,0x04,0x1f,0x00,0x50,0x04,0x1c,0x00,0x41,0x04,0x1a,0x00,0x33,0x04,0x17,0x00,  \
    0x25,0x04,0x15,0x00,0x17,0x04,0x12,0x00,0x09,0x04,0x10,0x00,0xfb,0x03,0x0d,0x00,0xed,0x03,0x0b,0x00,0xdf,0x03,0x08,0x00,0xd1,0x03,0x06,0x00,0xc3,0x03,0x04,0x00,0xb5,0x03,0x01,0x00,0xa8,0x03,0xff,0xff,0x9a,0x03,0xfd,0xff,0x8d,0x03,0xfa,0xff,0x7f,0x03,0xf8,0xff,0x72,0x03,0xf6,0xff,0x64,0x03,0xf3,0xff,0x57,0x03,0xf1,0xff,0x4a,0x03,0xef,0xff,0x3d,0x03,0xed,0xff,0x2f,0x03,0xeb,0xff,0x22,0x03,0xe9,0xff,0x15,0x03,0xe7,0xff,0x08,0x03,0xe5,0xff,0xfb,0x02,  \
    0xe3,0xff,0xee,0x02,0xe1,0xff,0xe1,0x02,0xdf,0xff,0xd4,0x02,0xdd,0xff,0xc7,0x02,0xdb,0xff,0xbb,0x02,0xd9,0xff,0xae,0x02,0xd7,0xff,0xa1,0x02,0xd6,0xff,0x94,0x02,0xd4,0xff,0x88,0x02,0xd2,0xff,0x7b,0x02,0xd0,0xff,0x6f,0x02,0xcf,0xff,0x62,0x02,0xcd,0xff,0x56,0x02,0xcb,0xff,0x49,0x02,0xca,0xff,0x3d,0x02,0xc8,0xff,0x30,0x02,0xc6,0xff,0x24,0x02,0xc5,0xff,0x18,0x02,0xc3,0xff,0x0c,0x02,0xc2,0xff,0xff,0x01,0xc1,0xff,0xf3,0x01,0xbf,0xff,0xe7,0x01,0xbe,0xff,  \
    0xdb,0x01,0xbc,0xff,0xcf,0x01,0xbb,0xff,0xc2,0x01,0xba,0xff,0xb6,0x01,0xb8,0xff,0xaa,0x01,0xb7,0xff,0x9e,0x01,0xb6,0xff,0x92,0x01,0xb5,0xff,0x86,0x01,0xb4,0xff,0x7a,0x01,0xb3,0xff,0x6e,0x01,0xb2,0xff,0x62,0x01,0xb0,0xff,0x56,0x01,0xaf,0xff,0x4a,0x01,0xae,0xff,0x3e,0x01,0xad,0xff,0x33,0x01,0xad,0xff,0x27,0x01,0xac,0xff,0x1b,0x01,0xab,0xff,0x0f,0x01,0xaa,0xff,0x03,0x01,0xa9,0xff,0xf7,0x00,0xa8,0xff,0xeb,0x00,0xa8,0xff,0xdf,0x00,0xa7,0xff,0xd3,0x00,  \
    0xa6,0xff,0xc8,0x00,0xa5,0xff,0xbc,0x00,0xa5,0xff,0xb0,0x00,0xa4,0xff,0xa4,0x00,0xa4,0xff,0x98,0x00,0xa3,0xff,0x8d,0x00,0xa3,0xff,0x81,0x00,0xa2,0xff,0x75,0x00,0xa2,0xff,0x69,0x00,0xa1,0xff,0x5e,0x00,0xa1,0xff,0x52,0x00,0xa1,0xff,0x46,0x00,0xa0,0xff,0x3a,0x00,0xa0,0xff,0x2f,0x00,0xa0,0xff,0x23,0x00,0x9f,0xff,0x17,0x00,0x9f,0xff,0x0c,0x00,0x9f,0xff,0x00,0x00,0x9f,0xff,0xf4,0xff,0x9f,0xff,0xe9,0xff,0x9f,0xff,0xdd,0xff,0x9f,0xff,0xd1,0xff,0x9f,0xff,  \
    0xc6,0xff,0x9f,0xff,0xba,0xff,0x9f,0xff,0xae,0xff,0x9f,0xff,0xa3,0xff,0x9f,0xff,0x97,0xff,0x9f,0xff,0x8b,0xff,0x9f,0xff,0x80,0xff,0x9f,0xff,0x74,0xff,0x9f,0xff,0x68,0xff,0xa0,0xff,0x5d,0xff,0xa0,0xff,0x51,0xff,0xa0,0xff,0x45,0xff,0xa1,0xff,0x3a,0xff,0xa1,0xff,0x2e,0xff,0xa1,0xff,0x22,0xff,0xa2,0xff,0x16,0xff,0xa2,0xff,0x0b,0xff,0xa3,0xff,0xff,0xfe,0xa3,0xff,0xf3,0xfe,0xa4,0xff,0xe8,0xfe,0xa4,0xff,0xdc,0xfe,0xa5,0xff,0xd0,0xfe,0xa6,0xff,0xc4,0xfe,  \
    0xa6,0xff,0xb8,0xfe,0xa7,0xff,0xad,0xfe,0xa8,0xff,0xa1,0xfe,0xa8,0xff,0x95,0xfe,0xa9,0xff,0x89,0xfe,0xaa,0xff,0x7d,0xfe,0xab,0xff,0x71,0xfe,0xac,0xff,0x66,0xfe,0xad,0xff,0x5a,0xfe,0xae,0xff,0x4e,0xfe,0xaf,0xff,0x42,0xfe,0xb0,0xff,0x36,0xfe,0xb1,0xff,0x2a,0xfe,0xb2,0xff,0x1e,0xfe,0xb3,0xff,0x12,0xfe,0xb4,0xff,0x06,0xfe,0xb5,0xff,0xf9,0xfd,0xb6,0xff,0xed,0xfd,0xb7,0xff,0xe1,0xfd,0xb8,0xff,0xd5,0xfd,0xba,0xff,0xc9,0xfd,0xbb,0xff,0xbd,0xfd,0xbc,0xff,  \
    0xb0,0xfd,0xbe,0xff,0xa4,0xfd,0xbf,0xff,0x98,0xfd,0xc0,0xff,0x8c,0xfd,0xc2,0xff,0x7f,0xfd,0xc3,0xff,0x73,0xfd,0xc5,0xff,0x66,0xfd,0xc6,0xff,0x5a,0xfd,0xc8,0xff,0x4e,0xfd,0xc9,0xff,0x41,0xfd,0xcb,0xff,0x35,0xfd,0xcd,0xff,0x28,0xfd,0xce,0xff,0x1c,0xfd,0xd0,0xff,0x0f,0xfd,0xd2,0xff,0x03,0xfd,0xd3,0xff,0xf6,0xfc,0xd5,0xff,0xe9,0xfc,0xd7,0xff,0xdd,0xfc,0xd9,0xff,0xd0,0xfc,0xdb,0xff,0xc3,0xfc,0xdc,0xff,0xb7,0xfc,0xde,0xff,0xaa,0xfc,0xe0,0xff,0x9d,0xfc,  \
    0xe2,0xff,0x90,0xfc,0xe4,0xff,0x83,0xfc,0xe6,0xff,0x76,0xfc,0xe8,0xff,0x69,0xfc,0xea,0xff,0x5c,0xfc,0xec,0xff,0x4f,0xfc,0xef,0xff,0x42,0xfc,0xf1,0xff,0x35,0xfc,0xf3,0xff,0x28,0xfc,0xf5,0xff,0x1b,0xfc,0xf7,0xff,0x0e,0xfc,0xfa,0xff,0x00,0xfc,0xfc,0xff,0xf3,0xfb,0xfe,0xff,0xe6,0xfb,0x01,0x00,0xd8,0xfb,0x03,0x00,0xca,0xfb,0x05,0x00,0xbd,0xfb,0x08,0x00,0xaf,0xfb,0x0a,0x00,0xa2,0xfb,0x0c,0x00,0x94,0xfb,0x0f,0x00,0x86,0xfb,0x11,0x00,0x78,0xfb,0x14,0x00,  \
    0x6a,0xfb,0x17,0x00,0x5c,0xfb,0x19,0x00,0x4e,0xfb,0x1c,0x00,0x40,0xfb,0x1e,0x00,0x32,0xfb,0x21,0x00,0x24,0xfb,0x24,0x00,0x16,0xfb,0x26,0x00,0x07,0xfb,0x29,0x00,0xf9,0xfa,0x2c,0x00,0xeb,0xfa,0x2e,0x00,0xdc,0xfa,0x31,0x00,0xce,0xfa,0x34,0x00,0xbf,0xfa,0x37,0x00,0xb0,0xfa,0x3a,0x00,0xa2,0xfa,0x3c,0x00,0x93,0xfa,0x3f,0x00,0x84,0xfa,0x42,0x00,0x75,0xfa,0x45,0x00,0x67,0xfa,0x48,0x00,0x58,0xfa,0x4b,0x00,0x49,0xfa,0x4e,0x00,0x39,0xfa,0x51,0x00,0x2a,0xfa,  \
    0x54,0x00,0x1b,0xfa,0x57,0x00,0x0c,0xfa,0x5a,0x00,0xfd,0xf9,0x5d,0x00,0xed,0xf9,0x60,0x00,0xde,0xf9,0x63,0x00,0xce,0xf9,0x67,0x00,0xbe,0xf9,0x6a,0x00,0xaf,0xf9,0x6d,0x00,0x9f,0xf9,0x70,0x00,0x8f,0xf9,0x73,0x00,0x7f,0xf9,0x77,0x00,0x6f,0xf9,0x7a,0x00,0x5f,0xf9,0x7d,0x00,0x4f,0xf9,0x80,0x00,0x3f,0xf9,0x84,0x00,0x2f,0xf9,0x87,0x00,0x1e,0xf9,0x8a,0x00,0x0e,0xf9,0x8e,0x00,0xfd,0xf8,0x91,0x00,0xed,0xf8,0x94,0x00,0xdc,0xf8,0x98,0x00,0xcb,0xf8,0x9b,0x00,  \
    0xba,0xf8,0x9e,0x00,0xa9,0xf8,0xa2,0x00,0x98,0xf8,0xa5,0x00,0x87,0xf8,0xa8,0x00,0x76,0xf8,0xac,0x00,0x65,0xf8,0xaf,0x00,0x53,0xf8,0xb3,0x00,0x42,0xf8,0xb6,0x00,0x30,0xf8,0xba,0x00,0x1f,0xf8,0xbd,0x00,0x0d,0xf8,0xc1,0x00,0xfb,0xf7,0xc4,0x00,0xe9,0xf7,0xc8,0x00,0xd7,0xf7,0xcb,0x00,0xc5,0xf7,0xcf,0x00,0xb3,0xf7,0xd2,0x00,0xa1,0xf7,0xd6,0x00,0x8e,0xf7,0xd9,0x00,0x7c,0xf7,0xdd,0x00,0x6a,0xf7,0xe0,0x00,0x57,0xf7,0xe4,0x00,0x44,0xf7,0xe7,0x00,0x32,0xf7,  \
    0xeb,0x00,0x1f,0xf7,0xef,0x00,0x0c,0xf7,0xf2,0x00,0xf9,0xf6,0xf6,0x00,0xe6,0xf6,0xf9,0x00,0xd2,0xf6,0xfd,0x00,0xbf,0xf6,0x00,0x01,0xac,0xf6,0x04,0x01,0x98,0xf6,0x08,0x01,0x84,0xf6,0x0b,0x01,0x71,0xf6,0x0f,0x01,0x5d,0xf6,0x12,0x01,0x49,0xf6,0x16,0x01,0x35,0xf6,0x19,0x01,0x20,0xf6,0x1d,0x01,0x0c,0xf6,0x20,0x01,0xf8,0xf5,0x24,0x01,0xe3,0xf5,0x27,0x01,0xce,0xf5,0x2b,0x01,0xb9,0xf5,0x2e,0x01,0xa4,0xf5,0x32,0x01,0x8f,0xf5,0x35,0x01,0x7a,0xf5,0x39,0x01,  \
    0x65,0xf5,0x3c,0x01,0x50,0xf5,0x3f,0x01,0x3a,0xf5,0x43,0x01,0x25,0xf5,0x46,0x01,0x0f,0xf5,0x4a,0x01,0xf9,0xf4,0x4d,0x01,0xe3,0xf4,0x50,0x01,0xcd,0xf4,0x54,0x01,0xb7,0xf4,0x57,0x01,0xa1,0xf4,0x5a,0x01,0x8b,0xf4,0x5e,0x01,0x74,0xf4,0x61,0x01,0x5e,0xf4,0x64,0x01,0x47,0xf4,0x68,0x01,0x31,0xf4,0x6b,0x01,0x1a,0xf4,0x6e,0x01,0x03,0xf4,0x71,0x01,0xec,0xf3,0x74,0x01,0xd5,0xf3,0x78,0x01,0xbd,0xf3,0x7b,0x01,0xa6,0xf3,0x7e,0x01,0x8e,0xf3,0x81,0x01,0x77,0xf3,  \
    0x84,0x01,0x5f,0xf3,0x87,0x01,0x47,0xf3,0x8a,0x01,0x2f,0xf3,0x8d,0x01,0x17,0xf3,0x90,0x01,0xff,0xf2,0x93,0x01,0xe6,0xf2,0x96,0x01,0xce,0xf2,0x99,0x01,0xb5,0xf2,0x9b,0x01,0x9c,0xf2,0x9e,0x01,0x84,0xf2,0xa1,0x01,0x6b,0xf2,0xa4,0x01,0x51,0xf2,0xa6,0x01,0x38,0xf2,0xa9,0x01,0x1f,0xf2,0xac,0x01,0x05,0xf2,0xae,0x01,0xec,0xf1,0xb1,0x01,0xd2,0xf1,0xb3,0x01,0xb8,0xf1,0xb6,0x01,0x9e,0xf1,0xb8,0x01,0x84,0xf1,0xba,0x01,0x69,0xf1,0xbd,0x01,0x4f,0xf1,0xbf,0x01,  \
    0x34,0xf1,0xc1,0x01,0x1a,0xf1,0xc3,0x01,0xff,0xf0,0xc5,0x01,0xe4,0xf0,0xc7,0x01,0xc9,0xf0,0xc9,0x01,0xad,0xf0,0xcb,0x01,0x92,0xf0,0xcd,0x01,0x76,0xf0,0xcf,0x01,0x5b,0xf0,0xd1,0x01,0x3f,0xf0,0xd3,0x01,0x23,0xf0,0xd4,0x01,0x07,0xf0,0xd6,0x01,0xeb,0xef,0xd8,0x01,0xce,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xdd,0x01,0x39,0x10,0xdb,0x01,0x1c,0x10,0xd9,0x01,0x00,0x10,0xd8,0x01,0xe3,0x0f,0xd6,0x01,0xc7,0x0f,0xd4,0x01,0xab,0x0f,0xd3,0x01,0x8f,0x0f,0xd1,0x01,0x74,0x0f,0xcf,0x01,0x58,0x0f,0xcd,0x01,0x3c,0x0f,0xcb,0x01,0x21,0x0f,0xc9,0x01,0x06,0x0f,0xc7,0x01,0xea,0x0e,0xc5,0x01,0xcf,0x0e,0xc3,0x01,0xb4,0x0e,0xc1,0x01,0x9a,0x0e,0xbe,0x01,  \
    0x7f,0x0e,0xbc,0x01,0x64,0x0e,0xba,0x01,0x4a,0x0e,0xb8,0x01,0x2f,0x0e,0xb5,0x01,0x15,0x0e,0xb3,0x01,0xfb,0x0d,0xb0,0x01,0xe1,0x0d,0xae,0x01,0xc8,0x0d,0xab,0x01,0xae,0x0d,0xa9,0x01,0x94,0x0d,0xa6,0x01,0x7b,0x0d,0xa3,0x01,0x62,0x0d,0xa1,0x01,0x48,0x0d,0x9e,0x01,0x2f,0x0d,0x9b,0x01,0x16,0x0d,0x98,0x01,0xfd,0x0c,0x96,0x01,0xe5,0x0c,0x93,0x01,0xcc,0x0c,0x90,0x01,0xb4,0x0c,0x8d,0x01,0x9b,0x0c,0x8a,0x01,0x83,0x0c,0x87,0x01,0x6b,0x0c,0x84,0x01,0x53,0x0c,  \
    0x81,0x01,0x3b,0x0c,0x7e,0x01,0x23,0x0c,0x7b,0x01,0x0c,0x0c,0x78,0x01,0xf4,0x0b,0x75,0x01,0xdd,0x0b,0x72,0x01,0xc6,0x0b,0x6e,0x01,0xaf,0x0b,0x6b,0x01,0x98,0x0b,0x68,0x01,0x81,0x0b,0x65,0x01,0x6a,0x0b,0x61,0x01,0x53,0x0b,0x5e,0x01,0x3d,0x0b,0x5b,0x01,0x26,0x0b,0x58,0x01,0x10,0x0b,0x54,0x01,0xfa,0x0a,0x51,0x01,0xe4,0x0a,0x4e,0x01,0xce,0x0a,0x4a,0x01,0xb8,0x0a,0x47,0x01,0xa2,0x0a,0x43,0x01,0x8c,0x0a,0x40,0x01,0x76,0x0a,0x3d,0x01,0x61,0x0a,0x39,0x01,  \
    0x4b,0x0a,0x36,0x01,0x36,0x0a,0x33,0x01,0x20,0x0a,0x2f,0x01,0x0b,0x0a,0x2c,0x01,0xf6,0x09,0x29,0x01,0xe1,0x09,0x25,0x01,0xcc,0x09,0x22,0x01,0xb7,0x09,0x1e,0x01,0xa2,0x09,0x1b,0x01,0x8e,0x09,0x17,0x01,0x79,0x09,0x14,0x01,0x65,0x09,0x11,0x01,0x50,0x09,0x0d,0x01,0x3c,0x09,0x0a,0x01,0x28,0x09,0x06,0x01,0x14,0x09,0x03,0x01,0x00,0x09,0xff,0x00,0xec,0x08,0xfc,0x00,0xd8,0x08,0xf8,0x00,0xc5,0x08,0xf5,0x00,0xb1,0x08,0xf2,0x00,0x9e,0x08,0xee,0x00,0x8a,0x08,  \
    0xeb,0x00,0x77,0x08,0xe7,0x00,0x64,0x08,0xe4,0x00,0x51,0x08,0xe0,0x00,0x3e,0x08,0xdd,0x00,0x2b,0x08,0xd9,0x00,0x18,0x08,0xd6,0x00,0x05,0x08,0xd3,0x00,0xf3,0x07,0xcf,0x00,0xe0,0x07,0xcc,0x00,0xce,0x07,0xc8,0x00,0xbb,0x07,0xc5,0x00,0xa9,0x07,0xc1,0x00,0x97,0x07,0xbe,0x00,0x86,0x07,0xbb,0x00,0x74,0x07,0xb7,0x00,0x62,0x07,0xb4,0x00,0x51,0x07,0xb0,0x00,0x3f,0x07,0xad,0x00,0x2e,0x07,0xaa,0x00,0x1c,0x07,0xa6,0x00,0x0b,0x07,0xa3,0x00,0xfa,0x06,0x9f,0x00,  \
    0xe9,0x06,0x9c,0x00,0xd8,0x06,0x99,0x00,0xc7,0x06,0x95,0x00,0xb6,0x06,0x92,0x00,0xa5,0x06,0x8f,0x00,0x94,0x06,0x8c,0x00,0x84,0x06,0x88,0x00,0x73,0x06,0x85,0x00,0x63,0x06,0x82,0x00,0x52,0x06,0x7f,0x00,0x42,0x06,0x7b,0x00,0x32,0x06,0x78,0x00,0x22,0x06,0x75,0x00,0x12,0x06,0x72,0x00,0x01,0x06,0x6f,0x00,0xf1,0x05,0x6c,0x00,0xe2,0x05,0x69,0x00,0xd2,0x05,0x65,0x00,0xc2,0x05,0x62,0x00,0xb2,0x05,0x5f,0x00,0xa3,0x05,0x5c,0x00,0x93,0x05,0x59,0x00,0x84,0x05,  \
    0x56,0x00,0x74,0x05,0x53,0x00,0x65,0x05,0x50,0x00,0x56,0x05,0x4d,0x00,0x46,0x05,0x4a,0x00,0x37,0x05,0x48,0x00,0x28,0x05,0x45,0x00,0x19,0x05,0x42,0x00,0x0a,0x05,0x3f,0x00,0xfb,0x04,0x3c,0x00,0xec,0x04,0x39,0x00,0xdd,0x04,0x37,0x00,0xcf,0x04,0x34,0x00,0xc0,0x04,0x31,0x00,0xb1,0x04,0x2e,0x00,0xa2,0x04,0x2c,0x00,0x94,0x04,0x29,0x00,0x85,0x04,0x27,0x00,0x77,0x04,0x24,0x00,0x68,0x04,0x21,0x00,0x5a,0x04,0x1f,0x00,0x4c,0x04,0x1c,0x00,0x3d,0x04,0x1a,0x00,  \
    0x2f,0x04,0x17,0x00,0x21,0x04,0x15,0x00,0x13,0x04,0x12,0x00,0x05,0x04,0x10,0x00,0xf7,0x03,0x0d,0x00,0xe9,0x03,0x0b,0x00,0xdb,0x03,0x09,0x00,0xcd,0x03,0x06,0x00,0xbf,0x03,0x04,0x00,0xb2,0x03,0x02,0x00,0xa4,0x03,0xff,0xff,0x97,0x03,0xfd,0xff,0x89,0x03,0xfb,0xff,0x7c,0x03,0xf9,0xff,0x6e,0x03,0xf7,0xff,0x61,0x03,0xf4,0xff,0x54,0x03,0xf2,0xff,0x46,0x03,0xf0,0xff,0x39,0x03,0xee,0xff,0x2c,0x03,0xec,0xff,0x1f,0x03,0xea,0xff,0x12,0x03,0xe8,0xff,0x05,0x03,  \
    0xe6,0xff,0xf8,0x02,0xe4,0xff,0xeb,0x02,0xe2,0xff,0xde,0x02,0xe0,0xff,0xd1,0x02,0xde,0xff,0xc4,0x02,0xdc,0xff,0xb8,0x02,0xdb,0xff,0xab,0x02,0xd9,0xff,0x9e,0x02,0xd7,0xff,0x92,0x02,0xd5,0xff,0x85,0x02,0xd4,0xff,0x78,0x02,0xd2,0xff,0x6c,0x02,0xd0,0xff,0x5f,0x02,0xcf,0xff,0x53,0x02,0xcd,0xff,0x46,0x02,0xcb,0xff,0x3a,0x02,0xca,0xff,0x2e,0x02,0xc8,0xff,0x21,0x02,0xc7,0xff,0x15,0x02,0xc5,0xff,0x09,0x02,0xc4,0xff,0xfd,0x01,0xc3,0xff,0xf1,0x01,0xc1,0xff,  \
    0xe4,0x01,0xc0,0xff,0xd8,0x01,0xbf,0xff,0xcc,0x01,0xbd,0xff,0xc0,0x01,0xbc,0xff,0xb4,0x01,0xbb,0xff,0xa8,0x01,0xba,0xff,0x9c,0x01,0xb8,0xff,0x90,0x01,0xb7,0xff,0x84,0x01,0xb6,0xff,0x78,0x01,0xb5,0xff,0x6c,0x01,0xb4,0xff,0x60,0x01,0xb3,0xff,0x54,0x01,0xb2,0xff,0x49,0x01,0xb1,0xff,0x3d,0x01,0xb0,0xff,0x31,0x01,0xaf,0xff,0x25,0x01,0xae,0xff,0x19,0x01,0xad,0xff,0x0d,0x01,0xad,0xff,0x01,0x01,0xac,0xff,0xf6,0x00,0xab,0xff,0xea,0x00,0xaa,0xff,0xde,0x00,  \
    0xaa,0xff,0xd2,0x00,0xa9,0xff,0xc6,0x00,0xa8,0xff,0xbb,0x00,0xa8,0xff,0xaf,0x00,0xa7,0xff,0xa3,0x00,0xa6,0xff,0x97,0x00,0xa6,0xff,0x8c,0x00,0xa5,0xff,0x80,0x00,0xa5,0xff,0x74,0x00,0xa4,0xff,0x69,0x00,0xa4,0xff,0x5d,0x00,0xa4,0xff,0x51,0x00,0xa3,0xff,0x46,0x00,0xa3,0xff,0x3a,0x00,0xa3,0xff,0x2e,0x00,0xa2,0xff,0x23,0x00,0xa2,0xff,0x17,0x00,0xa2,0xff,0x0b,0x00,0xa2,0xff,0x00,0x00,0xa2,0xff,0xf4,0xff,0xa2,0xff,0xe8,0xff,0xa2,0xff,0xdd,0xff,0xa1,0xff,  \
    0xd1,0xff,0xa1,0xff,0xc6,0xff,0xa1,0xff,0xba,0xff,0xa1,0xff,0xae,0xff,0xa2,0xff,0xa3,0xff,0xa2,0xff,0x97,0xff,0xa2,0xff,0x8c,0xff,0xa2,0xff,0x80,0xff,0xa2,0xff,0x74,0xff,0xa2,0xff,0x69,0xff,0xa3,0xff,0x5d,0xff,0xa3,0xff,0x51,0xff,0xa3,0xff,0x46,0xff,0xa3,0xff,0x3a,0xff,0xa4,0xff,0x2f,0xff,0xa4,0xff,0x23,0xff,0xa5,0xff,0x17,0xff,0xa5,0xff,0x0c,0xff,0xa6,0xff,0x00,0xff,0xa6,0xff,0xf4,0xfe,0xa7,0xff,0xe9,0xfe,0xa7,0xff,0xdd,0xfe,0xa8,0xff,0xd1,0xfe,  \
    0xa8,0xff,0xc5,0xfe,0xa9,0xff,0xba,0xfe,0xaa,0xff,0xae,0xfe,0xaa,0xff,0xa2,0xfe,0xab,0xff,0x96,0xfe,0xac,0xff,0x8b,0xfe,0xad,0xff,0x7f,0xfe,0xae,0xff,0x73,0xfe,0xae,0xff,0x67,0xfe,0xaf,0xff,0x5b,0xfe,0xb0,0xff,0x4f,0xfe,0xb1,0xff,0x44,0xfe,0xb2,0xff,0x38,0xfe,0xb3,0xff,0x2c,0xfe,0xb4,0xff,0x20,0xfe,0xb5,0xff,0x14,0xfe,0xb6,0xff,0x08,0xfe,0xb7,0xff,0xfc,0xfd,0xb8,0xff,0xf0,0xfd,0xba,0xff,0xe3,0xfd,0xbb,0xff,0xd7,0xfd,0xbc,0xff,0xcb,0xfd,0xbd,0xff,  \
    0xbf,0xfd,0xbf,0xff,0xb3,0xfd,0xc0,0xff,0xa7,0xfd,0xc1,0xff,0x9a,0xfd,0xc3,0xff,0x8e,0xfd,0xc4,0xff,0x82,0xfd,0xc5,0xff,0x76,0xfd,0xc7,0xff,0x69,0xfd,0xc8,0xff,0x5d,0xfd,0xca,0xff,0x50,0xfd,0xcb,0xff,0x44,0xfd,0xcd,0xff,0x38,0xfd,0xcf,0xff,0x2b,0xfd,0xd0,0xff,0x1f,0xfd,0xd2,0xff,0x12,0xfd,0xd3,0xff,0x06,0xfd,0xd5,0xff,0xf9,0xfc,0xd7,0xff,0xed,0xfc,0xd9,0xff,0xe0,0xfc,0xda,0xff,0xd3,0xfc,0xdc,0xff,0xc7,0xfc,0xde,0xff,0xba,0xfc,0xe0,0xff,0xad,0xfc,  \
    0xe2,0xff,0xa0,0xfc,0xe4,0xff,0x94,0xfc,0xe6,0xff,0x87,0xfc,0xe8,0xff,0x7a,0xfc,0xea,0xff,0x6d,0xfc,0xec,0xff,0x60,0xfc,0xee,0xff,0x53,0xfc,0xf0,0xff,0x46,0xfc,0xf2,0xff,0x39,0xfc,0xf4,0xff,0x2c,0xfc,0xf6,0xff,0x1f,0xfc,0xf8,0xff,0x11,0xfc,0xfb,0xff,0x04,0xfc,0xfd,0xff,0xf7,0xfb,0xff,0xff,0xe9,0xfb,0x01,0x00,0xdc,0xfb,0x04,0x00,0xce,0xfb,0x06,0x00,0xc1,0xfb,0x08,0x00,0xb3,0xfb,0x0b,0x00,0xa6,0xfb,0x0d,0x00,0x98,0xfb,0x0f,0x00,0x8a,0xfb,0x12,0x00,  \
    0x7c,0xfb,0x14,0x00,0x6e,0xfb,0x17,0x00,0x60,0xfb,0x19,0x00,0x52,0xfb,0x1c,0x00,0x44,0xfb,0x1e,0x00,0x36,0xfb,0x21,0x00,0x28,0xfb,0x24,0x00,0x1a,0xfb,0x26,0x00,0x0c,0xfb,0x29,0x00,0xfd,0xfa,0x2b,0x00,0xef,0xfa,0x2e,0x00,0xe1,0xfa,0x31,0x00,0xd2,0xfa,0x34,0x00,0xc4,0xfa,0x36,0x00,0xb5,0xfa,0x39,0x00,0xa6,0xfa,0x3c,0x00,0x98,0xfa,0x3f,0x00,0x89,0xfa,0x42,0x00,0x7a,0xfa,0x44,0x00,0x6b,0xfa,0x47,0x00,0x5c,0xfa,0x4a,0x00,0x4d,0xfa,0x4d,0x00,0x3e,0xfa,  \
    0x50,0x00,0x2f,0xfa,0x53,0x00,0x20,0xfa,0x56,0x00,0x11,0xfa,0x59,0x00,0x01,0xfa,0x5c,0x00,0xf2,0xf9,0x5f,0x00,0xe2,0xf9,0x62,0x00,0xd3,0xf9,0x65,0x00,0xc3,0xf9,0x68,0x00,0xb4,0xf9,0x6b,0x00,0xa4,0xf9,0x6e,0x00,0x94,0xf9,0x72,0x00,0x84,0xf9,0x75,0x00,0x74,0xf9,0x78,0x00,0x64,0xf9,0x7b,0x00,0x54,0xf9,0x7e,0x00,0x44,0xf9,0x81,0x00,0x34,0xf9,0x85,0x00,0x23,0xf9,0x88,0x00,0x13,0xf9,0x8b,0x00,0x02,0xf9,0x8e,0x00,0xf2,0xf8,0x92,0x00,0xe1,0xf8,0x95,0x00,  \
    0xd0,0xf8,0x98,0x00,0xbf,0xf8,0x9b,0x00,0xae,0xf8,0x9f,0x00,0x9d,0xf8,0xa2,0x00,0x8c,0xf8,0xa5,0x00,0x7b,0xf8,0xa9,0x00,0x69,0xf8,0xac,0x00,0x58,0xf8,0xaf,0x00,0x47,0xf8,0xb3,0x00,0x35,0xf8,0xb6,0x00,0x23,0xf8,0xba,0x00,0x12,0xf8,0xbd,0x00,0x00,0xf8,0xc0,0x00,0xee,0xf7,0xc4,0x00,0xdc,0xf7,0xc7,0x00,0xca,0xf7,0xcb,0x00,0xb8,0xf7,0xce,0x00,0xa6,0xf7,0xd2,0x00,0x93,0xf7,0xd5,0x00,0x81,0xf7,0xd8,0x00,0x6e,0xf7,0xdc,0x00,0x5c,0xf7,0xdf,0x00,0x49,0xf7,  \
    0xe3,0x00,0x36,0xf7,0xe6,0x00,0x23,0xf7,0xea,0x00,0x11,0xf7,0xed,0x00,0xfd,0xf6,0xf1,0x00,0xea,0xf6,0xf4,0x00,0xd7,0xf6,0xf8,0x00,0xc4,0xf6,0xfb,0x00,0xb0,0xf6,0xff,0x00,0x9d,0xf6,0x02,0x01,0x89,0xf6,0x06,0x01,0x75,0xf6,0x09,0x01,0x61,0xf6,0x0d,0x01,0x4d,0xf6,0x10,0x01,0x39,0xf6,0x13,0x01,0x25,0xf6,0x17,0x01,0x11,0xf6,0x1a,0x01,0xfc,0xf5,0x1e,0x01,0xe7,0xf5,0x21,0x01,0xd3,0xf5,0x24,0x01,0xbe,0xf5,0x28,0x01,0xa9,0xf5,0x2b,0x01,0x94,0xf5,0x2f,0x01,  \
    0x7f,0xf5,0x32,0x01,0x6a,0xf5,0x35,0x01,0x54,0xf5,0x39,0x01,0x3f,0xf5,0x3c,0x01,0x29,0xf5,0x3f,0x01,0x13,0xf5,0x43,0x01,0xfe,0xf4,0x46,0x01,0xe8,0xf4,0x49,0x01,0xd2,0xf4,0x4c,0x01,0xbc,0xf4,0x50,0x01,0xa5,0xf4,0x53,0x01,0x8f,0xf4,0x56,0x01,0x79,0xf4,0x59,0x01,0x62,0xf4,0x5d,0x01,0x4c,0xf4,0x60,0x01,0x35,0xf4,0x63,0x01,0x1e,0xf4,0x66,0x01,0x07,0xf4,0x69,0x01,0xf0,0xf3,0x6c,0x01,0xd9,0xf3,0x6f,0x01,0xc2,0xf3,0x72,0x01,0xaa,0xf3,0x75,0x01,0x93,0xf3,  \
    0x78,0x01,0x7b,0xf3,0x7b,0x01,0x63,0xf3,0x7e,0x01,0x4b,0xf3,0x81,0x01,0x33,0xf3,0x84,0x01,0x1b,0xf3,0x87,0x01,0x03,0xf3,0x8a,0x01,0xea,0xf2,0x8d,0x01,0xd2,0xf2,0x8f,0x01,0xb9,0xf2,0x92,0x01,0xa0,0xf2,0x95,0x01,0x88,0xf2,0x98,0x01,0x6e,0xf2,0x9a,0x01,0x55,0xf2,0x9d,0x01,0x3c,0xf2,0x9f,0x01,0x23,0xf2,0xa2,0x01,0x09,0xf2,0xa4,0x01,0xef,0xf1,0xa7,0x01,0xd6,0xf1,0xa9,0x01,0xbc,0xf1,0xac,0x01,0xa2,0xf1,0xae,0x01,0x87,0xf1,0xb0,0x01,0x6d,0xf1,0xb2,0x01,  \
    0x53,0xf1,0xb5,0x01,0x38,0xf1,0xb7,0x01,0x1d,0xf1,0xb9,0x01,0x03,0xf1,0xbb,0x01,0xe8,0xf0,0xbd,0x01,0xcc,0xf0,0xbf,0x01,0xb1,0xf0,0xc1,0x01,0x96,0xf0,0xc3,0x01,0x7a,0xf0,0xc4,0x01,0x5e,0xf0,0xc6,0x01,0x43,0xf0,0xc8,0x01,0x27,0xf0,0xca,0x01,0x0a,0xf0,0xcb,0x01,0xee,0xef,0xcd,0x01,0xd2,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xd0,0x01,0x36,0x10,0xce,0x01,0x19,0x10,0xcd,0x01,0xfd,0x0f,0xcb,0x01,0xe1,0x0f,0xc9,0x01,0xc4,0x0f,0xc8,0x01,0xa8,0x0f,0xc6,0x01,0x8c,0x0f,0xc4,0x01,0x71,0x0f,0xc2,0x01,0x55,0x0f,0xc1,0x01,0x39,0x0f,0xbf,0x01,0x1e,0x0f,0xbd,0x01,0x03,0x0f,0xbb,0x01,0xe7,0x0e,0xb9,0x01,0xcc,0x0e,0xb7,0x01,0xb1,0x0e,0xb5,0x01,  \
    0x96,0x0e,0xb2,0x01,0x7c,0x0e,0xb0,0x01,0x61,0x0e,0xae,0x01,0x47,0x0e,0xac,0x01,0x2c,0x0e,0xa9,0x01,0x12,0x0e,0xa7,0x01,0xf8,0x0d,0xa5,0x01,0xde,0x0d,0xa2,0x01,0xc4,0x0d,0xa0,0x01,0xab,0x0d,0x9d,0x01,0x91,0x0d,0x9b,0x01,0x78,0x0d,0x98,0x01,0x5e,0x0d,0x96,0x01,0x45,0x0d,0x93,0x01,0x2c,0x0d,0x90,0x01,0x13,0x0d,0x8e,0x01,0xfa,0x0c,0x8b,0x01,0xe1,0x0c,0x88,0x01,0xc9,0x0c,0x85,0x01,0xb0,0x0c,0x82,0x01,0x98,0x0c,0x80,0x01,0x80,0x0c,0x7d,0x01,0x67,0x0c,  \
    0x7a,0x01,0x4f,0x0c,0x77,0x01,0x38,0x0c,0x74,0x01,0x20,0x0c,0x71,0x01,0x08,0x0c,0x6e,0x01,0xf1,0x0b,0x6b,0x01,0xd9,0x0b,0x68,0x01,0xc2,0x0b,0x65,0x01,0xab,0x0b,0x62,0x01,0x94,0x0b,0x5f,0x01,0x7d,0x0b,0x5b,0x01,0x66,0x0b,0x58,0x01,0x50,0x0b,0x55,0x01,0x39,0x0b,0x52,0x01,0x22,0x0b,0x4f,0x01,0x0c,0x0b,0x4c,0x01,0xf6,0x0a,0x48,0x01,0xe0,0x0a,0x45,0x01,0xca,0x0a,0x42,0x01,0xb4,0x0a,0x3e,0x01,0x9e,0x0a,0x3b,0x01,0x88,0x0a,0x38,0x01,0x72,0x0a,0x35,0x01,  \
    0x5d,0x0a,0x32,0x01,0x47,0x0a,0x2e,0x01,0x32,0x0a,0x2b,0x01,0x1c,0x0a,0x28,0x01,0x07,0x0a,0x24,0x01,0xf2,0x09,0x21,0x01,0xdd,0x09,0x1e,0x01,0xc8,0x09,0x1a,0x01,0xb3,0x09,0x17,0x01,0x9e,0x09,0x14,0x01,0x8a,0x09,0x11,0x01,0x75,0x09,0x0d,0x01,0x61,0x09,0x0a,0x01,0x4c,0x09,0x06,0x01,0x38,0x09,0x03,0x01,0x24,0x09,0x00,0x01,0x10,0x09,0xfc,0x00,0xfc,0x08,0xf9,0x00,0xe8,0x08,0xf6,0x00,0xd4,0x08,0xf2,0x00,0xc1,0x08,0xef,0x00,0xad,0x08,0xec,0x00,0x9a,0x08,  \
    0xe8,0x00,0x86,0x08,0xe5,0x00,0x73,0x08,0xe2,0x00,0x60,0x08,0xde,0x00,0x4d,0x08,0xdb,0x00,0x3a,0x08,0xd8,0x00,0x27,0x08,0xd4,0x00,0x14,0x08,0xd1,0x00,0x01,0x08,0xce,0x00,0xee,0x07,0xca,0x00,0xdc,0x07,0xc7,0x00,0xc9,0x07,0xc4,0x00,0xb7,0x07,0xc0,0x00,0xa5,0x07,0xbd,0x00,0x93,0x07,0xba,0x00,0x81,0x07,0xb6,0x00,0x70,0x07,0xb3,0x00,0x5e,0x07,0xb0,0x00,0x4c,0x07,0xac,0x00,0x3b,0x07,0xa9,0x00,0x29,0x07,0xa6,0x00,0x18,0x07,0xa2,0x00,0x07,0x07,0x9f,0x00,  \
    0xf6,0x06,0x9c,0x00,0xe4,0x06,0x99,0x00,0xd3,0x06,0x95,0x00,0xc2,0x06,0x92,0x00,0xb2,0x06,0x8f,0x00,0xa1,0x06,0x8c,0x00,0x90,0x06,0x89,0x00,0x80,0x06,0x85,0x00,0x6f,0x06,0x82,0x00,0x5f,0x06,0x7f,0x00,0x4e,0x06,0x7c,0x00,0x3e,0x06,0x79,0x00,0x2d,0x06,0x76,0x00,0x1d,0x06,0x73,0x00,0x0d,0x06,0x70,0x00,0xfd,0x05,0x6d,0x00,0xed,0x05,0x6a,0x00,0xdd,0x05,0x66,0x00,0xcd,0x05,0x63,0x00,0xbe,0x05,0x60,0x00,0xae,0x05,0x5e,0x00,0x9e,0x05,0x5b,0x00,0x8f,0x05,  \
    0x58,0x00,0x7f,0x05,0x55,0x00,0x70,0x05,0x52,0x00,0x61,0x05,0x4f,0x00,0x51,0x05,0x4c,0x00,0x42,0x05,0x49,0x00,0x33,0x05,0x46,0x00,0x24,0x05,0x44,0x00,0x15,0x05,0x41,0x00,0x06,0x05,0x3e,0x00,0xf7,0x04,0x3b,0x00,0xe8,0x04,0x39,0x00,0xd9,0x04,0x36,0x00,0xca,0x04,0x33,0x00,0xbc,0x04,0x31,0x00,0xad,0x04,0x2e,0x00,0x9e,0x04,0x2b,0x00,0x90,0x04,0x29,0x00,0x81,0x04,0x26,0x00,0x73,0x04,0x24,0x00,0x64,0x04,0x21,0x00,0x56,0x04,0x1f,0x00,0x48,0x04,0x1c,0x00,  \
    0x39,0x04,0x1a,0x00,0x2b,0x04,0x17,0x00,0x1d,0x04,0x15,0x00,0x0f,0x04,0x12,0x00,0x01,0x04,0x10,0x00,0xf3,0x03,0x0e,0x00,0xe5,0x03,0x0b,0x00,0xd7,0x03,0x09,0x00,0xc9,0x03,0x07,0x00,0xbc,0x03,0x05,0x00,0xae,0x03,0x02,0x00,0xa1,0x03,0x00,0x00,0x93,0x03,0xfe,0xff,0x86,0x03,0xfc,0xff,0x78,0x03,0xfa,0xff,0x6b,0x03,0xf7,0xff,0x5e,0x03,0xf5,0xff,0x50,0x03,0xf3,0xff,0x43,0x03,0xf1,0xff,0x36,0x03,0xef,0xff,0x29,0x03,0xed,0xff,0x1c,0x03,0xeb,0xff,0x0f,0x03,  \
    0xe9,0xff,0x02,0x03,0xe7,0xff,0xf5,0x02,0xe5,0xff,0xe8,0x02,0xe4,0xff,0xdb,0x02,0xe2,0xff,0xce,0x02,0xe0,0xff,0xc1,0x02,0xde,0xff,0xb5,0x02,0xdc,0xff,0xa8,0x02,0xdb,0xff,0x9b,0x02,0xd9,0xff,0x8f,0x02,0xd7,0xff,0x82,0x02,0xd5,0xff,0x75,0x02,0xd4,0xff,0x69,0x02,0xd2,0xff,0x5c,0x02,0xd1,0xff,0x50,0x02,0xcf,0xff,0x44,0x02,0xcd,0xff,0x37,0x02,0xcc,0xff,0x2b,0x02,0xca,0xff,0x1f,0x02,0xc9,0xff,0x13,0x02,0xc8,0xff,0x07,0x02,0xc6,0xff,0xfa,0x01,0xc5,0xff,  \
    0xee,0x01,0xc3,0xff,0xe2,0x01,0xc2,0xff,0xd6,0x01,0xc1,0xff,0xca,0x01,0xc0,0xff,0xbe,0x01,0xbe,0xff,0xb2,0x01,0xbd,0xff,0xa6,0x01,0xbc,0xff,0x9a,0x01,0xbb,0xff,0x8e,0x01,0xba,0xff,0x82,0x01,0xb9,0xff,0x76,0x01,0xb8,0xff,0x6a,0x01,0xb7,0xff,0x5e,0x01,0xb6,0xff,0x53,0x01,0xb5,0xff,0x47,0x01,0xb4,0xff,0x3b,0x01,0xb3,0xff,0x2f,0x01,0xb2,0xff,0x23,0x01,0xb1,0xff,0x18,0x01,0xb0,0xff,0x0c,0x01,0xaf,0xff,0x00,0x01,0xaf,0xff,0xf4,0x00,0xae,0xff,0xe8,0x00,  \
    0xad,0xff,0xdd,0x00,0xac,0xff,0xd1,0x00,0xac,0xff,0xc5,0x00,0xab,0xff,0xb9,0x00,0xaa,0xff,0xae,0x00,0xaa,0xff,0xa2,0x00,0xa9,0xff,0x96,0x00,0xa9,0xff,0x8b,0x00,0xa8,0xff,0x7f,0x00,0xa8,0xff,0x73,0x00,0xa7,0xff,0x68,0x00,0xa7,0xff,0x5c,0x00,0xa7,0xff,0x51,0x00,0xa6,0xff,0x45,0x00,0xa6,0xff,0x39,0x00,0xa6,0xff,0x2e,0x00,0xa5,0xff,0x22,0x00,0xa5,0xff,0x17,0x00,0xa5,0xff,0x0b,0x00,0xa5,0xff,0xff,0xff,0xa5,0xff,0xf4,0xff,0xa5,0xff,0xe8,0xff,0xa5,0xff,  \
    0xdd,0xff,0xa4,0xff,0xd1,0xff,0xa4,0xff,0xc6,0xff,0xa4,0xff,0xba,0xff,0xa4,0xff,0xaf,0xff,0xa5,0xff,0xa3,0xff,0xa5,0xff,0x97,0xff,0xa5,0xff,0x8c,0xff,0xa5,0xff,0x80,0xff,0xa5,0xff,0x75,0xff,0xa5,0xff,0x69,0xff,0xa6,0xff,0x5e,0xff,0xa6,0xff,0x52,0xff,0xa6,0xff,0x46,0xff,0xa6,0xff,0x3b,0xff,0xa7,0xff,0x2f,0xff,0xa7,0xff,0x24,0xff,0xa8,0xff,0x18,0xff,0xa8,0xff,0x0c,0xff,0xa8,0xff,0x01,0xff,0xa9,0xff,0xf5,0xfe,0xa9,0xff,0xea,0xfe,0xaa,0xff,0xde,0xfe,  \
    0xab,0xff,0xd2,0xfe,0xab,0xff,0xc7,0xfe,0xac,0xff,0xbb,0xfe,0xad,0xff,0xaf,0xfe,0xad,0xff,0xa4,0xfe,0xae,0xff,0x98,0xfe,0xaf,0xff,0x8c,0xfe,0xaf,0xff,0x80,0xfe,0xb0,0xff,0x75,0xfe,0xb1,0xff,0x69,0xfe,0xb2,0xff,0x5d,0xfe,0xb3,0xff,0x51,0xfe,0xb4,0xff,0x45,0xfe,0xb5,0xff,0x39,0xfe,0xb6,0xff,0x2e,0xfe,0xb7,0xff,0x22,0xfe,0xb8,0xff,0x16,0xfe,0xb9,0xff,0x0a,0xfe,0xba,0xff,0xfe,0xfd,0xbb,0xff,0xf2,0xfd,0xbc,0xff,0xe6,0xfd,0xbd,0xff,0xda,0xfd,0xbf,0xff,  \
    0xce,0xfd,0xc0,0xff,0xc1,0xfd,0xc1,0xff,0xb5,0xfd,0xc2,0xff,0xa9,0xfd,0xc4,0xff,0x9d,0xfd,0xc5,0xff,0x91,0xfd,0xc6,0xff,0x85,0xfd,0xc8,0xff,0x78,0xfd,0xc9,0xff,0x6c,0xfd,0xcb,0xff,0x60,0xfd,0xcc,0xff,0x53,0xfd,0xcd,0xff,0x47,0xfd,0xcf,0xff,0x3a,0xfd,0xd1,0xff,0x2e,0xfd,0xd2,0xff,0x22,0xfd,0xd4,0xff,0x15,0xfd,0xd5,0xff,0x09,0xfd,0xd7,0xff,0xfc,0xfc,0xd9,0xff,0xf0,0xfc,0xda,0xff,0xe3,0xfc,0xdc,0xff,0xd7,0xfc,0xde,0xff,0xca,0xfc,0xe0,0xff,0xbd,0xfc,  \
    0xe2,0xff,0xb1,0xfc,0xe3,0xff,0xa4,0xfc,0xe5,0xff,0x97,0xfc,0xe7,0xff,0x8a,0xfc,0xe9,0xff,0x7d,0xfc,0xeb,0xff,0x71,0xfc,0xed,0xff,0x64,0xfc,0xef,0xff,0x57,0xfc,0xf1,0xff,0x4a,0xfc,0xf3,0xff,0x3d,0xfc,0xf5,0xff,0x2f,0xfc,0xf7,0xff,0x22,0xfc,0xf9,0xff,0x15,0xfc,0xfc,0xff,0x08,0xfc,0xfe,0xff,0xfb,0xfb,0x00,0x00,0xed,0xfb,0x02,0x00,0xe0,0xfb,0x04,0x00,0xd2,0xfb,0x07,0x00,0xc5,0xfb,0x09,0x00,0xb7,0xfb,0x0b,0x00,0xaa,0xfb,0x0e,0x00,0x9c,0xfb,0x10,0x00,  \
    0x8e,0xfb,0x12,0x00,0x80,0xfb,0x15,0x00,0x73,0xfb,0x17,0x00,0x65,0xfb,0x1a,0x00,0x57,0xfb,0x1c,0x00,0x49,0xfb,0x1f,0x00,0x3b,0xfb,0x21,0x00,0x2c,0xfb,0x24,0x00,0x1e,0xfb,0x26,0x00,0x10,0xfb,0x29,0x00,0x02,0xfb,0x2b,0x00,0xf3,0xfa,0x2e,0x00,0xe5,0xfa,0x31,0x00,0xd7,0xfa,0x33,0x00,0xc8,0xfa,0x36,0x00,0xb9,0xfa,0x39,0x00,0xab,0xfa,0x3b,0x00,0x9c,0xfa,0x3e,0x00,0x8d,0xfa,0x41,0x00,0x7e,0xfa,0x44,0x00,0x70,0xfa,0x47,0x00,0x61,0xfa,0x49,0x00,0x52,0xfa,  \
    0x4c,0x00,0x43,0xfa,0x4f,0x00,0x34,0xfa,0x52,0x00,0x24,0xfa,0x55,0x00,0x15,0xfa,0x58,0x00,0x06,0xfa,0x5b,0x00,0xf6,0xf9,0x5e,0x00,0xe7,0xf9,0x61,0x00,0xd7,0xf9,0x64,0x00,0xc8,0xf9,0x67,0x00,0xb8,0xf9,0x6a,0x00,0xa8,0xf9,0x6d,0x00,0x99,0xf9,0x70,0x00,0x89,0xf9,0x73,0x00,0x79,0xf9,0x76,0x00,0x69,0xf9,0x79,0x00,0x59,0xf9,0x7c,0x00,0x48,0xf9,0x7f,0x00,0x38,0xf9,0x82,0x00,0x28,0xf9,0x86,0x00,0x17,0xf9,0x89,0x00,0x07,0xf9,0x8c,0x00,0xf6,0xf8,0x8f,0x00,  \
    0xe6,0xf8,0x92,0x00,0xd5,0xf8,0x95,0x00,0xc4,0xf8,0x99,0x00,0xb3,0xf8,0x9c,0x00,0xa2,0xf8,0x9f,0x00,0x91,0xf8,0xa2,0x00,0x80,0xf8,0xa6,0x00,0x6e,0xf8,0xa9,0x00,0x5d,0xf8,0xac,0x00,0x4b,0xf8,0xaf,0x00,0x3a,0xf8,0xb3,0x00,0x28,0xf8,0xb6,0x00,0x16,0xf8,0xb9,0x00,0x05,0xf8,0xbd,0x00,0xf3,0xf7,0xc0,0x00,0xe1,0xf7,0xc3,0x00,0xcf,0xf7,0xc7,0x00,0xbc,0xf7,0xca,0x00,0xaa,0xf7,0xcd,0x00,0x98,0xf7,0xd1,0x00,0x86,0xf7,0xd4,0x00,0x73,0xf7,0xd8,0x00,0x60,0xf7,  \
    0xdb,0x00,0x4e,0xf7,0xde,0x00,0x3b,0xf7,0xe2,0x00,0x28,0xf7,0xe5,0x00,0x15,0xf7,0xe8,0x00,0x02,0xf7,0xec,0x00,0xef,0xf6,0xef,0x00,0xdc,0xf6,0xf3,0x00,0xc8,0xf6,0xf6,0x00,0xb5,0xf6,0xf9,0x00,0xa1,0xf6,0xfd,0x00,0x8e,0xf6,0x00,0x01,0x7a,0xf6,0x04,0x01,0x66,0xf6,0x07,0x01,0x52,0xf6,0x0a,0x01,0x3e,0xf6,0x0e,0x01,0x29,0xf6,0x11,0x01,0x15,0xf6,0x14,0x01,0x01,0xf6,0x18,0x01,0xec,0xf5,0x1b,0x01,0xd7,0xf5,0x1e,0x01,0xc2,0xf5,0x21,0x01,0xad,0xf5,0x25,0x01,  \
    0x98,0xf5,0x28,0x01,0x83,0xf5,0x2b,0x01,0x6e,0xf5,0x2f,0x01,0x59,0xf5,0x32,0x01,0x43,0xf5,0x35,0x01,0x2d,0xf5,0x38,0x01,0x18,0xf5,0x3b,0x01,0x02,0xf5,0x3f,0x01,0xec,0xf4,0x42,0x01,0xd6,0xf4,0x45,0x01,0xc0,0xf4,0x48,0x01,0xaa,0xf4,0x4b,0x01,0x93,0xf4,0x4f,0x01,0x7d,0xf4,0x52,0x01,0x66,0xf4,0x55,0x01,0x50,0xf4,0x58,0x01,0x39,0xf4,0x5b,0x01,0x22,0xf4,0x5e,0x01,0x0b,0xf4,0x61,0x01,0xf4,0xf3,0x64,0x01,0xdd,0xf3,0x67,0x01,0xc6,0xf3,0x6a,0x01,0xae,0xf3,  \
    0x6d,0x01,0x97,0xf3,0x70,0x01,0x7f,0xf3,0x73,0x01,0x67,0xf3,0x76,0x01,0x4f,0xf3,0x79,0x01,0x37,0xf3,0x7b,0x01,0x1f,0xf3,0x7e,0x01,0x07,0xf3,0x81,0x01,0xee,0xf2,0x84,0x01,0xd6,0xf2,0x86,0x01,0xbd,0xf2,0x89,0x01,0xa4,0xf2,0x8c,0x01,0x8b,0xf2,0x8e,0x01,0x72,0xf2,0x91,0x01,0x59,0xf2,0x93,0x01,0x40,0xf2,0x96,0x01,0x26,0xf2,0x98,0x01,0x0d,0xf2,0x9b,0x01,0xf3,0xf1,0x9d,0x01,0xd9,0xf1,0x9f,0x01,0xbf,0xf1,0xa2,0x01,0xa5,0xf1,0xa4,0x01,0x8b,0xf1,0xa6,0x01,  \
    0x71,0xf1,0xa8,0x01,0x56,0xf1,0xab,0x01,0x3c,0xf1,0xad,0x01,0x21,0xf1,0xaf,0x01,0x06,0xf1,0xb1,0x01,0xeb,0xf0,0xb3,0x01,0xd0,0xf0,0xb5,0x01,0xb5,0xf0,0xb6,0x01,0x99,0xf0,0xb8,0x01,0x7e,0xf0,0xba,0x01,0x62,0xf0,0xbc,0x01,0x46,0xf0,0xbd,0x01,0x2a,0xf0,0xbf,0x01,0x0e,0xf0,0xc0,0x01,0xf2,0xef,0xc2,0x01,0xd5,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0x01,0x33,0x10,0xc1,0x01,0x16,0x10,0xc0,0x01,0xfa,0x0f,0xbe,0x01,0xde,0x0f,0xbd,0x01,0xc2,0x0f,0xbb,0x01,0xa5,0x0f,0xb9,0x01,0x8a,0x0f,0xb8,0x01,0x6e,0x0f,0xb6,0x01,0x52,0x0f,0xb4,0x01,0x36,0x0f,0xb2,0x01,0x1b,0x0f,0xb0,0x01,0x00,0x0f,0xae,0x01,0xe4,0x0e,0xad,0x01,0xc9,0x0e,0xab,0x01,  \
    0xae,0x0e,0xa9,0x01,0x93,0x0e,0xa6,0x01,0x79,0x0e,0xa4,0x01,0x5e,0x0e,0xa2,0x01,0x44,0x0e,0xa0,0x01,0x29,0x0e,0x9e,0x01,0x0f,0x0e,0x9b,0x01,0xf5,0x0d,0x99,0x01,0xdb,0x0d,0x97,0x01,0xc1,0x0d,0x94,0x01,0xa8,0x0d,0x92,0x01,0x8e,0x0d,0x90,0x01,0x74,0x0d,0x8d,0x01,0x5b,0x0d,0x8b,0x01,0x42,0x0d,0x88,0x01,0x29,0x0d,0x85,0x01,0x10,0x0d,0x83,0x01,0xf7,0x0c,0x80,0x01,0xde,0x0c,0x7d,0x01,0xc6,0x0c,0x7b,0x01,0xad,0x0c,0x78,0x01,0x95,0x0c,0x75,0x01,0x7c,0x0c,  \
    0x73,0x01,0x64,0x0c,0x70,0x01,0x4c,0x0c,0x6d,0x01,0x34,0x0c,0x6a,0x01,0x1c,0x0c,0x67,0x01,0x05,0x0c,0x64,0x01,0xed,0x0b,0x61,0x01,0xd6,0x0b,0x5e,0x01,0xbf,0x0b,0x5b,0x01,0xa7,0x0b,0x58,0x01,0x90,0x0b,0x55,0x01,0x79,0x0b,0x52,0x01,0x63,0x0b,0x4f,0x01,0x4c,0x0b,0x4c,0x01,0x35,0x0b,0x49,0x01,0x1f,0x0b,0x46,0x01,0x08,0x0b,0x43,0x01,0xf2,0x0a,0x40,0x01,0xdc,0x0a,0x3d,0x01,0xc6,0x0a,0x39,0x01,0xb0,0x0a,0x36,0x01,0x9a,0x0a,0x33,0x01,0x84,0x0a,0x30,0x01,  \
    0x6f,0x0a,0x2d,0x01,0x59,0x0a,0x2a,0x01,0x43,0x0a,0x27,0x01,0x2e,0x0a,0x23,0x01,0x18,0x0a,0x20,0x01,0x03,0x0a,0x1d,0x01,0xee,0x09,0x1a,0x01,0xd9,0x09,0x17,0x01,0xc4,0x09,0x13,0x01,0xaf,0x09,0x10,0x01,0x9a,0x09,0x0d,0x01,0x86,0x09,0x0a,0x01,0x71,0x09,0x06,0x01,0x5d,0x09,0x03,0x01,0x48,0x09,0x00,0x01,0x34,0x09,0xfd,0x00,0x20,0x09,0xf9,0x00,0x0c,0x09,0xf6,0x00,0xf8,0x08,0xf3,0x00,0xe4,0x08,0xf0,0x00,0xd0,0x08,0xec,0x00,0xbd,0x08,0xe9,0x00,0xa9,0x08,  \
    0xe6,0x00,0x96,0x08,0xe3,0x00,0x82,0x08,0xdf,0x00,0x6f,0x08,0xdc,0x00,0x5c,0x08,0xd9,0x00,0x49,0x08,0xd6,0x00,0x36,0x08,0xd2,0x00,0x23,0x08,0xcf,0x00,0x10,0x08,0xcc,0x00,0xfd,0x07,0xc9,0x00,0xea,0x07,0xc6,0x00,0xd8,0x07,0xc2,0x00,0xc5,0x07,0xbf,0x00,0xb3,0x07,0xbc,0x00,0xa1,0x07,0xb9,0x00,0x8f,0x07,0xb5,0x00,0x7d,0x07,0xb2,0x00,0x6c,0x07,0xaf,0x00,0x5a,0x07,0xac,0x00,0x48,0x07,0xa8,0x00,0x37,0x07,0xa5,0x00,0x25,0x07,0xa2,0x00,0x14,0x07,0x9f,0x00,  \
    0x03,0x07,0x9c,0x00,0xf1,0x06,0x98,0x00,0xe0,0x06,0x95,0x00,0xcf,0x06,0x92,0x00,0xbe,0x06,0x8f,0x00,0xad,0x06,0x8c,0x00,0x9d,0x06,0x89,0x00,0x8c,0x06,0x86,0x00,0x7b,0x06,0x83,0x00,0x6b,0x06,0x7f,0x00,0x5a,0x06,0x7c,0x00,0x4a,0x06,0x79,0x00,0x3a,0x06,0x76,0x00,0x29,0x06,0x73,0x00,0x19,0x06,0x70,0x00,0x09,0x06,0x6d,0x00,0xf9,0x05,0x6a,0x00,0xe9,0x05,0x67,0x00,0xd9,0x05,0x65,0x00,0xc9,0x05,0x62,0x00,0xba,0x05,0x5f,0x00,0xaa,0x05,0x5c,0x00,0x9a,0x05,  \
    0x59,0x00,0x8b,0x05,0x56,0x00,0x7b,0x05,0x53,0x00,0x6c,0x05,0x50,0x00,0x5d,0x05,0x4e,0x00,0x4d,0x05,0x4b,0x00,0x3e,0x05,0x48,0x00,0x2f,0x05,0x45,0x00,0x20,0x05,0x43,0x00,0x11,0x05,0x40,0x00,0x02,0x05,0x3d,0x00,0xf3,0x04,0x3b,0x00,0xe4,0x04,0x38,0x00,0xd5,0x04,0x35,0x00,0xc6,0x04,0x33,0x00,0xb8,0x04,0x30,0x00,0xa9,0x04,0x2e,0x00,0x9a,0x04,0x2b,0x00,0x8c,0x04,0x29,0x00,0x7d,0x04,0x26,0x00,0x6f,0x04,0x24,0x00,0x60,0x04,0x21,0x00,0x52,0x04,0x1f,0x00,  \
    0x44,0x04,0x1c,0x00,0x36,0x04,0x1a,0x00,0x27,0x04,0x17,0x00,0x19,0x04,0x15,0x00,0x0b,0x04,0x13,0x00,0xfd,0x03,0x10,0x00,0xef,0x03,0x0e,0x00,0xe2,0x03,0x0c,0x00,0xd4,0x03,0x0a,0x00,0xc6,0x03,0x07,0x00,0xb8,0x03,0x05,0x00,0xab,0x03,0x03,0x00,0x9d,0x03,0x01,0x00,0x90,0x03,0xff,0xff,0x82,0x03,0xfd,0xff,0x75,0x03,0xfb,0xff,0x68,0x03,0xf8,0xff,0x5a,0x03,0xf6,0xff,0x4d,0x03,0xf4,0xff,0x40,0x03,0xf2,0xff,0x33,0x03,0xf0,0xff,0x26,0x03,0xee,0xff,0x19,0x03,  \
    0xed,0xff,0x0c,0x03,0xeb,0xff,0xff,0x02,0xe9,0xff,0xf2,0x02,0xe7,0xff,0xe5,0x02,0xe5,0xff,0xd8,0x02,0xe3,0xff,0xcb,0x02,0xe2,0xff,0xbe,0x02,0xe0,0xff,0xb2,0x02,0xde,0xff,0xa5,0x02,0xdc,0xff,0x98,0x02,0xdb,0xff,0x8c,0x02,0xd9,0xff,0x7f,0x02,0xd7,0xff,0x73,0x02,0xd6,0xff,0x66,0x02,0xd4,0xff,0x5a,0x02,0xd3,0xff,0x4e,0x02,0xd1,0xff,0x41,0x02,0xd0,0xff,0x35,0x02,0xce,0xff,0x29,0x02,0xcd,0xff,0x1c,0x02,0xcb,0xff,0x10,0x02,0xca,0xff,0x04,0x02,0xc9,0xff,  \
    0xf8,0x01,0xc7,0xff,0xec,0x01,0xc6,0xff,0xe0,0x01,0xc5,0xff,0xd4,0x01,0xc3,0xff,0xc8,0x01,0xc2,0xff,0xbc,0x01,0xc1,0xff,0xb0,0x01,0xc0,0xff,0xa4,0x01,0xbf,0xff,0x98,0x01,0xbd,0xff,0x8c,0x01,0xbc,0xff,0x80,0x01,0xbb,0xff,0x74,0x01,0xba,0xff,0x68,0x01,0xb9,0xff,0x5d,0x01,0xb8,0xff,0x51,0x01,0xb7,0xff,0x45,0x01,0xb6,0xff,0x39,0x01,0xb5,0xff,0x2d,0x01,0xb5,0xff,0x22,0x01,0xb4,0xff,0x16,0x01,0xb3,0xff,0x0a,0x01,0xb2,0xff,0xfe,0x00,0xb1,0xff,0xf3,0x00,  \
    0xb1,0xff,0xe7,0x00,0xb0,0xff,0xdb,0x00,0xaf,0xff,0xd0,0x00,0xaf,0xff,0xc4,0x00,0xae,0xff,0xb8,0x00,0xad,0xff,0xad,0x00,0xad,0xff,0xa1,0x00,0xac,0xff,0x95,0x00,0xac,0xff,0x8a,0x00,0xab,0xff,0x7e,0x00,0xab,0xff,0x73,0x00,0xab,0xff,0x67,0x00,0xaa,0xff,0x5b,0x00,0xaa,0xff,0x50,0x00,0xa9,0xff,0x44,0x00,0xa9,0xff,0x39,0x00,0xa9,0xff,0x2d,0x00,0xa9,0xff,0x22,0x00,0xa8,0xff,0x16,0x00,0xa8,0xff,0x0b,0x00,0xa8,0xff,0xff,0xff,0xa8,0xff,0xf4,0xff,0xa8,0xff,  \
    0xe8,0xff,0xa8,0xff,0xdd,0xff,0xa8,0xff,0xd1,0xff,0xa8,0xff,0xc6,0xff,0xa8,0xff,0xba,0xff,0xa8,0xff,0xaf,0xff,0xa8,0xff,0xa3,0xff,0xa8,0xff,0x98,0xff,0xa8,0xff,0x8c,0xff,0xa8,0xff,0x81,0xff,0xa8,0xff,0x75,0xff,0xa8,0xff,0x6a,0xff,0xa9,0xff,0x5e,0xff,0xa9,0xff,0x53,0xff,0xa9,0xff,0x47,0xff,0xaa,0xff,0x3c,0xff,0xaa,0xff,0x30,0xff,0xaa,0xff,0x24,0xff,0xab,0xff,0x19,0xff,0xab,0xff,0x0d,0xff,0xac,0xff,0x02,0xff,0xac,0xff,0xf6,0xfe,0xad,0xff,0xeb,0xfe,  \
    0xad,0xff,0xdf,0xfe,0xae,0xff,0xd3,0xfe,0xae,0xff,0xc8,0xfe,0xaf,0xff,0xbc,0xfe,0xaf,0xff,0xb1,0xfe,0xb0,0xff,0xa5,0xfe,0xb1,0xff,0x99,0xfe,0xb2,0xff,0x8e,0xfe,0xb2,0xff,0x82,0xfe,0xb3,0xff,0x76,0xfe,0xb4,0xff,0x6a,0xfe,0xb5,0xff,0x5f,0xfe,0xb6,0xff,0x53,0xfe,0xb7,0xff,0x47,0xfe,0xb8,0xff,0x3b,0xfe,0xb8,0xff,0x2f,0xfe,0xb9,0xff,0x24,0xfe,0xba,0xff,0x18,0xfe,0xbb,0xff,0x0c,0xfe,0xbd,0xff,0x00,0xfe,0xbe,0xff,0xf4,0xfd,0xbf,0xff,0xe8,0xfd,0xc0,0xff,  \
    0xdc,0xfd,0xc1,0xff,0xd0,0xfd,0xc2,0xff,0xc4,0xfd,0xc3,0xff,0xb8,0xfd,0xc5,0xff,0xac,0xfd,0xc6,0xff,0x9f,0xfd,0xc7,0xff,0x93,0xfd,0xc9,0xff,0x87,0xfd,0xca,0xff,0x7b,0xfd,0xcb,0xff,0x6f,0xfd,0xcd,0xff,0x62,0xfd,0xce,0xff,0x56,0xfd,0xd0,0xff,0x4a,0xfd,0xd1,0xff,0x3d,0xfd,0xd3,0xff,0x31,0xfd,0xd4,0xff,0x25,0xfd,0xd6,0xff,0x18,0xfd,0xd7,0xff,0x0c,0xfd,0xd9,0xff,0xff,0xfc,0xdb,0xff,0xf3,0xfc,0xdc,0xff,0xe6,0xfc,0xde,0xff,0xda,0xfc,0xe0,0xff,0xcd,0xfc,  \
    0xe2,0xff,0xc1,0xfc,0xe3,0xff,0xb4,0xfc,0xe5,0xff,0xa7,0xfc,0xe7,0xff,0x9a,0xfc,0xe9,0xff,0x8e,0xfc,0xeb,0xff,0x81,0xfc,0xed,0xff,0x74,0xfc,0xef,0xff,0x67,0xfc,0xf0,0xff,0x5a,0xfc,0xf2,0xff,0x4d,0xfc,0xf4,0xff,0x40,0xfc,0xf7,0xff,0x33,0xfc,0xf9,0xff,0x26,0xfc,0xfb,0xff,0x19,0xfc,0xfd,0xff,0x0c,0xfc,0xff,0xff,0xfe,0xfb,0x01,0x00,0xf1,0xfb,0x03,0x00,0xe4,0xfb,0x05,0x00,0xd6,0xfb,0x08,0x00,0xc9,0xfb,0x0a,0x00,0xbb,0xfb,0x0c,0x00,0xad,0xfb,0x0e,0x00,  \
    0xa0,0xfb,0x11,0x00,0x92,0xfb,0x13,0x00,0x84,0xfb,0x15,0x00,0x77,0xfb,0x18,0x00,0x69,0xfb,0x1a,0x00,0x5b,0xfb,0x1c,0x00,0x4d,0xfb,0x1f,0x00,0x3f,0xfb,0x21,0x00,0x31,0xfb,0x24,0x00,0x22,0xfb,0x26,0x00,0x14,0xfb,0x29,0x00,0x06,0xfb,0x2b,0x00,0xf8,0xfa,0x2e,0x00,0xe9,0xfa,0x31,0x00,0xdb,0xfa,0x33,0x00,0xcc,0xfa,0x36,0x00,0xbe,0xfa,0x38,0x00,0xaf,0xfa,0x3b,0x00,0xa0,0xfa,0x3e,0x00,0x92,0xfa,0x40,0x00,0x83,0xfa,0x43,0x00,0x74,0xfa,0x46,0x00,0x65,0xfa,  \
    0x49,0x00,0x56,0xfa,0x4b,0x00,0x47,0xfa,0x4e,0x00,0x38,0xfa,0x51,0x00,0x29,0xfa,0x54,0x00,0x1a,0xfa,0x57,0x00,0x0a,0xfa,0x5a,0x00,0xfb,0xf9,0x5c,0x00,0xeb,0xf9,0x5f,0x00,0xdc,0xf9,0x62,0x00,0xcc,0xf9,0x65,0x00,0xbd,0xf9,0x68,0x00,0xad,0xf9,0x6b,0x00,0x9d,0xf9,0x6e,0x00,0x8d,0xf9,0x71,0x00,0x7d,0xf9,0x74,0x00,0x6d,0xf9,0x77,0x00,0x5d,0xf9,0x7a,0x00,0x4d,0xf9,0x7d,0x00,0x3d,0xf9,0x80,0x00,0x2c,0xf9,0x83,0x00,0x1c,0xf9,0x86,0x00,0x0b,0xf9,0x89,0x00,  \
    0xfb,0xf8,0x8d,0x00,0xea,0xf8,0x90,0x00,0xd9,0xf8,0x93,0x00,0xc8,0xf8,0x96,0x00,0xb7,0xf8,0x99,0x00,0xa6,0xf8,0x9c,0x00,0x95,0xf8,0x9f,0x00,0x84,0xf8,0xa3,0x00,0x73,0xf8,0xa6,0x00,0x61,0xf8,0xa9,0x00,0x50,0xf8,0xac,0x00,0x3e,0xf8,0xaf,0x00,0x2d,0xf8,0xb3,0x00,0x1b,0xf8,0xb6,0x00,0x09,0xf8,0xb9,0x00,0xf7,0xf7,0xbc,0x00,0xe5,0xf7,0xc0,0x00,0xd3,0xf7,0xc3,0x00,0xc1,0xf7,0xc6,0x00,0xaf,0xf7,0xc9,0x00,0x9c,0xf7,0xcd,0x00,0x8a,0xf7,0xd0,0x00,0x78,0xf7,  \
    0xd3,0x00,0x65,0xf7,0xd6,0x00,0x52,0xf7,0xda,0x00,0x3f,0xf7,0xdd,0x00,0x2d,0xf7,0xe0,0x00,0x1a,0xf7,0xe4,0x00,0x06,0xf7,0xe7,0x00,0xf3,0xf6,0xea,0x00,0xe0,0xf6,0xee,0x00,0xcd,0xf6,0xf1,0x00,0xb9,0xf6,0xf4,0x00,0xa6,0xf6,0xf7,0x00,0x92,0xf6,0xfb,0x00,0x7e,0xf6,0xfe,0x00,0x6a,0xf6,0x01,0x01,0x56,0xf6,0x05,0x01,0x42,0xf6,0x08,0x01,0x2e,0xf6,0x0b,0x01,0x19,0xf6,0x0e,0x01,0x05,0xf6,0x12,0x01,0xf0,0xf5,0x15,0x01,0xdb,0xf5,0x18,0x01,0xc7,0xf5,0x1b,0x01,  \
    0xb2,0xf5,0x1e,0x01,0x9d,0xf5,0x22,0x01,0x87,0xf5,0x25,0x01,0x72,0xf5,0x28,0x01,0x5d,0xf5,0x2b,0x01,0x47,0xf5,0x2e,0x01,0x32,0xf5,0x31,0x01,0x1c,0xf5,0x34,0x01,0x06,0xf5,0x38,0x01,0xf0,0xf4,0x3b,0x01,0xda,0xf4,0x3e,0x01,0xc4,0xf4,0x41,0x01,0xae,0xf4,0x44,0x01,0x97,0xf4,0x47,0x01,0x81,0xf4,0x4a,0x01,0x6b,0xf4,0x4d,0x01,0x54,0xf4,0x50,0x01,0x3d,0xf4,0x53,0x01,0x26,0xf4,0x56,0x01,0x0f,0xf4,0x59,0x01,0xf8,0xf3,0x5c,0x01,0xe1,0xf3,0x5f,0x01,0xca,0xf3,  \
    0x62,0x01,0xb2,0xf3,0x65,0x01,0x9b,0xf3,0x67,0x01,0x83,0xf3,0x6a,0x01,0x6b,0xf3,0x6d,0x01,0x53,0xf3,0x70,0x01,0x3b,0xf3,0x73,0x01,0x23,0xf3,0x75,0x01,0x0a,0xf3,0x78,0x01,0xf2,0xf2,0x7b,0x01,0xd9,0xf2,0x7d,0x01,0xc1,0xf2,0x80,0x01,0xa8,0xf2,0x82,0x01,0x8f,0xf2,0x85,0x01,0x76,0xf2,0x87,0x01,0x5d,0xf2,0x8a,0x01,0x44,0xf2,0x8c,0x01,0x2a,0xf2,0x8f,0x01,0x10,0xf2,0x91,0x01,0xf7,0xf1,0x93,0x01,0xdd,0xf1,0x96,0x01,0xc3,0xf1,0x98,0x01,0xa9,0xf1,0x9a,0x01,  \
    0x8f,0xf1,0x9c,0x01,0x74,0xf1,0x9e,0x01,0x5a,0xf1,0xa0,0x01,0x3f,0xf1,0xa2,0x01,0x25,0xf1,0xa4,0x01,0x0a,0xf1,0xa6,0x01,0xef,0xf0,0xa8,0x01,0xd3,0xf0,0xaa,0x01,0xb8,0xf0,0xac,0x01,0x9d,0xf0,0xae,0x01,0x81,0xf0,0xaf,0x01,0x65,0xf0,0xb1,0x01,0x49,0xf0,0xb3,0x01,0x2d,0xf0,0xb4,0x01,0x11,0xf0,0xb6,0x01,0xf5,0xef,0xb7,0x01,0xd9,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xb6,0x01,0x30,0x10,0xb4,0x01,0x14,0x10,0xb3,0x01,0xf7,0x0f,0xb2,0x01,0xdb,0x0f,0xb0,0x01,0xbf,0x0f,0xae,0x01,0xa3,0x0f,0xad,0x01,0x87,0x0f,0xab,0x01,0x6b,0x0f,0xaa,0x01,0x4f,0x0f,0xa8,0x01,0x34,0x0f,0xa6,0x01,0x18,0x0f,0xa4,0x01,0xfd,0x0e,0xa2,0x01,0xe1,0x0e,0xa0,0x01,  \
    0xc6,0x0e,0x9f,0x01,0xab,0x0e,0x9d,0x01,0x91,0x0e,0x9b,0x01,0x76,0x0e,0x99,0x01,0x5b,0x0e,0x96,0x01,0x41,0x0e,0x94,0x01,0x26,0x0e,0x92,0x01,0x0c,0x0e,0x90,0x01,0xf2,0x0d,0x8e,0x01,0xd8,0x0d,0x8b,0x01,0xbe,0x0d,0x89,0x01,0xa4,0x0d,0x87,0x01,0x8b,0x0d,0x84,0x01,0x71,0x0d,0x82,0x01,0x58,0x0d,0x80,0x01,0x3f,0x0d,0x7d,0x01,0x26,0x0d,0x7b,0x01,0x0d,0x0d,0x78,0x01,0xf4,0x0c,0x76,0x01,0xdb,0x0c,0x73,0x01,0xc2,0x0c,0x70,0x01,0xaa,0x0c,0x6e,0x01,0x91,0x0c,  \
    0x6b,0x01,0x79,0x0c,0x68,0x01,0x61,0x0c,0x66,0x01,0x49,0x0c,0x63,0x01,0x31,0x0c,0x60,0x01,0x19,0x0c,0x5d,0x01,0x01,0x0c,0x5b,0x01,0xea,0x0b,0x58,0x01,0xd2,0x0b,0x55,0x01,0xbb,0x0b,0x52,0x01,0xa4,0x0b,0x4f,0x01,0x8d,0x0b,0x4c,0x01,0x76,0x0b,0x49,0x01,0x5f,0x0b,0x46,0x01,0x48,0x0b,0x43,0x01,0x32,0x0b,0x40,0x01,0x1b,0x0b,0x3d,0x01,0x05,0x0b,0x3a,0x01,0xef,0x0a,0x37,0x01,0xd8,0x0a,0x34,0x01,0xc2,0x0a,0x31,0x01,0xac,0x0a,0x2e,0x01,0x97,0x0a,0x2b,0x01,  \
    0x81,0x0a,0x28,0x01,0x6b,0x0a,0x25,0x01,0x55,0x0a,0x22,0x01,0x40,0x0a,0x1f,0x01,0x2a,0x0a,0x1c,0x01,0x15,0x0a,0x19,0x01,0xff,0x09,0x16,0x01,0xea,0x09,0x13,0x01,0xd5,0x09,0x0f,0x01,0xc0,0x09,0x0c,0x01,0xab,0x09,0x09,0x01,0x97,0x09,0x06,0x01,0x82,0x09,0x03,0x01,0x6d,0x09,0x00,0x01,0x59,0x09,0xfd,0x00,0x44,0x09,0xf9,0x00,0x30,0x09,0xf6,0x00,0x1c,0x09,0xf3,0x00,0x08,0x09,0xf0,0x00,0xf4,0x08,0xed,0x00,0xe0,0x08,0xea,0x00,0xcc,0x08,0xe7,0x00,0xb9,0x08,  \
    0xe3,0x00,0xa5,0x08,0xe0,0x00,0x92,0x08,0xdd,0x00,0x7e,0x08,0xda,0x00,0x6b,0x08,0xd7,0x00,0x58,0x08,0xd4,0x00,0x45,0x08,0xd0,0x00,0x32,0x08,0xcd,0x00,0x1f,0x08,0xca,0x00,0x0c,0x08,0xc7,0x00,0xf9,0x07,0xc4,0x00,0xe6,0x07,0xc1,0x00,0xd4,0x07,0xbe,0x00,0xc1,0x07,0xba,0x00,0xaf,0x07,0xb7,0x00,0x9d,0x07,0xb4,0x00,0x8b,0x07,0xb1,0x00,0x79,0x07,0xae,0x00,0x68,0x07,0xab,0x00,0x56,0x07,0xa8,0x00,0x44,0x07,0xa5,0x00,0x33,0x07,0xa1,0x00,0x21,0x07,0x9e,0x00,  \
    0x10,0x07,0x9b,0x00,0xff,0x06,0x98,0x00,0xed,0x06,0x95,0x00,0xdc,0x06,0x92,0x00,0xcb,0x06,0x8f,0x00,0xba,0x06,0x8c,0x00,0xa9,0x06,0x89,0x00,0x99,0x06,0x86,0x00,0x88,0x06,0x83,0x00,0x77,0x06,0x80,0x00,0x67,0x06,0x7d,0x00,0x56,0x06,0x7a,0x00,0x46,0x06,0x77,0x00,0x35,0x06,0x74,0x00,0x25,0x06,0x71,0x00,0x15,0x06,0x6e,0x00,0x05,0x06,0x6b,0x00,0xf5,0x05,0x68,0x00,0xe5,0x05,0x66,0x00,0xd5,0x05,0x63,0x00,0xc5,0x05,0x60,0x00,0xb5,0x05,0x5d,0x00,0xa6,0x05,  \
    0x5a,0x00,0x96,0x05,0x57,0x00,0x87,0x05,0x55,0x00,0x77,0x05,0x52,0x00,0x68,0x05,0x4f,0x00,0x59,0x05,0x4c,0x00,0x49,0x05,0x4a,0x00,0x3a,0x05,0x47,0x00,0x2b,0x05,0x44,0x00,0x1c,0x05,0x42,0x00,0x0d,0x05,0x3f,0x00,0xfe,0x04,0x3c,0x00,0xef,0x04,0x3a,0x00,0xe0,0x04,0x37,0x00,0xd1,0x04,0x35,0x00,0xc2,0x04,0x32,0x00,0xb4,0x04,0x30,0x00,0xa5,0x04,0x2d,0x00,0x96,0x04,0x2b,0x00,0x88,0x04,0x28,0x00,0x79,0x04,0x26,0x00,0x6b,0x04,0x24,0x00,0x5d,0x04,0x21,0x00,  \
    0x4e,0x04,0x1f,0x00,0x40,0x04,0x1c,0x00,0x32,0x04,0x1a,0x00,0x24,0x04,0x18,0x00,0x16,0x04,0x15,0x00,0x08,0x04,0x13,0x00,0xfa,0x03,0x11,0x00,0xec,0x03,0x0f,0x00,0xde,0x03,0x0d,0x00,0xd0,0x03,0x0a,0x00,0xc2,0x03,0x08,0x00,0xb5,0x03,0x06,0x00,0xa7,0x03,0x04,0x00,0x9a,0x03,0x02,0x00,0x8c,0x03,0x00,0x00,0x7f,0x03,0xfe,0xff,0x72,0x03,0xfc,0xff,0x64,0x03,0xfa,0xff,0x57,0x03,0xf8,0xff,0x4a,0x03,0xf6,0xff,0x3d,0x03,0xf4,0xff,0x30,0x03,0xf2,0xff,0x23,0x03,  \
    0xf0,0xff,0x16,0x03,0xee,0xff,0x09,0x03,0xec,0xff,0xfc,0x02,0xea,0xff,0xef,0x02,0xe9,0xff,0xe2,0x02,0xe7,0xff,0xd5,0x02,0xe5,0xff,0xc8,0x02,0xe3,0xff,0xbc,0x02,0xe2,0xff,0xaf,0x02,0xe0,0xff,0xa2,0x02,0xde,0xff,0x96,0x02,0xdd,0xff,0x89,0x02,0xdb,0xff,0x7d,0x02,0xd9,0xff,0x70,0x02,0xd8,0xff,0x64,0x02,0xd6,0xff,0x57,0x02,0xd5,0xff,0x4b,0x02,0xd3,0xff,0x3f,0x02,0xd2,0xff,0x32,0x02,0xd0,0xff,0x26,0x02,0xcf,0xff,0x1a,0x02,0xce,0xff,0x0e,0x02,0xcc,0xff,  \
    0x02,0x02,0xcb,0xff,0xf6,0x01,0xca,0xff,0xea,0x01,0xc8,0xff,0xde,0x01,0xc7,0xff,0xd2,0x01,0xc6,0xff,0xc6,0x01,0xc5,0xff,0xba,0x01,0xc4,0xff,0xae,0x01,0xc2,0xff,0xa2,0x01,0xc1,0xff,0x96,0x01,0xc0,0xff,0x8a,0x01,0xbf,0xff,0x7e,0x01,0xbe,0xff,0x72,0x01,0xbd,0xff,0x67,0x01,0xbc,0xff,0x5b,0x01,0xbb,0xff,0x4f,0x01,0xba,0xff,0x43,0x01,0xb9,0xff,0x38,0x01,0xb8,0xff,0x2c,0x01,0xb8,0xff,0x20,0x01,0xb7,0xff,0x14,0x01,0xb6,0xff,0x09,0x01,0xb5,0xff,0xfd,0x00,  \
    0xb4,0xff,0xf1,0x00,0xb4,0xff,0xe6,0x00,0xb3,0xff,0xda,0x00,0xb2,0xff,0xce,0x00,0xb2,0xff,0xc3,0x00,0xb1,0xff,0xb7,0x00,0xb1,0xff,0xac,0x00,0xb0,0xff,0xa0,0x00,0xb0,0xff,0x94,0x00,0xaf,0xff,0x89,0x00,0xaf,0xff,0x7d,0x00,0xae,0xff,0x72,0x00,0xae,0xff,0x66,0x00,0xad,0xff,0x5b,0x00,0xad,0xff,0x4f,0x00,0xad,0xff,0x44,0x00,0xac,0xff,0x38,0x00,0xac,0xff,0x2d,0x00,0xac,0xff,0x21,0x00,0xac,0xff,0x16,0x00,0xab,0xff,0x0a,0x00,0xab,0xff,0xff,0xff,0xab,0xff,  \
    0xf3,0xff,0xab,0xff,0xe8,0xff,0xab,0xff,0xdc,0xff,0xab,0xff,0xd1,0xff,0xab,0xff,0xc6,0xff,0xab,0xff,0xba,0xff,0xab,0xff,0xaf,0xff,0xab,0xff,0xa3,0xff,0xab,0xff,0x98,0xff,0xab,0xff,0x8c,0xff,0xab,0xff,0x81,0xff,0xac,0xff,0x75,0xff,0xac,0xff,0x6a,0xff,0xac,0xff,0x5f,0xff,0xac,0xff,0x53,0xff,0xac,0xff,0x48,0xff,0xad,0xff,0x3c,0xff,0xad,0xff,0x31,0xff,0xad,0xff,0x25,0xff,0xae,0xff,0x1a,0xff,0xae,0xff,0x0e,0xff,0xaf,0xff,0x03,0xff,0xaf,0xff,0xf7,0xfe,  \
    0xb0,0xff,0xec,0xfe,0xb0,0xff,0xe0,0xfe,0xb1,0xff,0xd5,0xfe,0xb1,0xff,0xc9,0xfe,0xb2,0xff,0xbd,0xfe,0xb3,0xff,0xb2,0xfe,0xb3,0xff,0xa6,0xfe,0xb4,0xff,0x9b,0xfe,0xb5,0xff,0x8f,0xfe,0xb5,0xff,0x83,0xfe,0xb6,0xff,0x78,0xfe,0xb7,0xff,0x6c,0xfe,0xb8,0xff,0x60,0xfe,0xb9,0xff,0x55,0xfe,0xba,0xff,0x49,0xfe,0xba,0xff,0x3d,0xfe,0xbb,0xff,0x31,0xfe,0xbc,0xff,0x25,0xfe,0xbd,0xff,0x1a,0xfe,0xbe,0xff,0x0e,0xfe,0xbf,0xff,0x02,0xfe,0xc0,0xff,0xf6,0xfd,0xc1,0xff,  \
    0xea,0xfd,0xc3,0xff,0xde,0xfd,0xc4,0xff,0xd2,0xfd,0xc5,0xff,0xc6,0xfd,0xc6,0xff,0xba,0xfd,0xc7,0xff,0xae,0xfd,0xc9,0xff,0xa2,0xfd,0xca,0xff,0x96,0xfd,0xcb,0xff,0x8a,0xfd,0xcc,0xff,0x7d,0xfd,0xce,0xff,0x71,0xfd,0xcf,0xff,0x65,0xfd,0xd1,0xff,0x59,0xfd,0xd2,0xff,0x4c,0xfd,0xd3,0xff,0x40,0xfd,0xd5,0xff,0x34,0xfd,0xd6,0xff,0x27,0xfd,0xd8,0xff,0x1b,0xfd,0xda,0xff,0x0f,0xfd,0xdb,0xff,0x02,0xfd,0xdd,0xff,0xf6,0xfc,0xde,0xff,0xe9,0xfc,0xe0,0xff,0xdd,0xfc,  \
    0xe2,0xff,0xd0,0xfc,0xe3,0xff,0xc4,0xfc,0xe5,0xff,0xb7,0xfc,0xe7,0xff,0xaa,0xfc,0xe9,0xff,0x9e,0xfc,0xeb,0xff,0x91,0xfc,0xec,0xff,0x84,0xfc,0xee,0xff,0x77,0xfc,0xf0,0xff,0x6a,0xfc,0xf2,0xff,0x5e,0xfc,0xf4,0xff,0x51,0xfc,0xf6,0xff,0x44,0xfc,0xf8,0xff,0x37,0xfc,0xfa,0xff,0x29,0xfc,0xfc,0xff,0x1c,0xfc,0xfe,0xff,0x0f,0xfc,0x00,0x00,0x02,0xfc,0x02,0x00,0xf5,0xfb,0x04,0x00,0xe7,0xfb,0x06,0x00,0xda,0xfb,0x09,0x00,0xcc,0xfb,0x0b,0x00,0xbf,0xfb,0x0d,0x00,  \
    0xb1,0xfb,0x0f,0x00,0xa4,0xfb,0x11,0x00,0x96,0xfb,0x14,0x00,0x88,0xfb,0x16,0x00,0x7a,0xfb,0x18,0x00,0x6d,0xfb,0x1b,0x00,0x5f,0xfb,0x1d,0x00,0x51,0xfb,0x1f,0x00,0x43,0xfb,0x22,0x00,0x35,0xfb,0x24,0x00,0x26,0xfb,0x27,0x00,0x18,0xfb,0x29,0x00,0x0a,0xfb,0x2b,0x00,0xfc,0xfa,0x2e,0x00,0xed,0xfa,0x30,0x00,0xdf,0xfa,0x33,0x00,0xd0,0xfa,0x36,0x00,0xc2,0xfa,0x38,0x00,0xb3,0xfa,0x3b,0x00,0xa5,0xfa,0x3d,0x00,0x96,0xfa,0x40,0x00,0x87,0xfa,0x43,0x00,0x78,0xfa,  \
    0x45,0x00,0x69,0xfa,0x48,0x00,0x5a,0xfa,0x4b,0x00,0x4b,0xfa,0x4d,0x00,0x3c,0xfa,0x50,0x00,0x2d,0xfa,0x53,0x00,0x1e,0xfa,0x56,0x00,0x0f,0xfa,0x58,0x00,0xff,0xf9,0x5b,0x00,0xf0,0xf9,0x5e,0x00,0xe0,0xf9,0x61,0x00,0xd1,0xf9,0x64,0x00,0xc1,0xf9,0x67,0x00,0xb1,0xf9,0x69,0x00,0xa2,0xf9,0x6c,0x00,0x92,0xf9,0x6f,0x00,0x82,0xf9,0x72,0x00,0x72,0xf9,0x75,0x00,0x62,0xf9,0x78,0x00,0x51,0xf9,0x7b,0x00,0x41,0xf9,0x7e,0x00,0x31,0xf9,0x81,0x00,0x20,0xf9,0x84,0x00,  \
    0x10,0xf9,0x87,0x00,0xff,0xf8,0x8a,0x00,0xef,0xf8,0x8d,0x00,0xde,0xf8,0x90,0x00,0xcd,0xf8,0x93,0x00,0xbc,0xf8,0x96,0x00,0xab,0xf8,0x99,0x00,0x9a,0xf8,0x9c,0x00,0x89,0xf8,0xa0,0x00,0x77,0xf8,0xa3,0x00,0x66,0xf8,0xa6,0x00,0x54,0xf8,0xa9,0x00,0x43,0xf8,0xac,0x00,0x31,0xf8,0xaf,0x00,0x1f,0xf8,0xb2,0x00,0x0e,0xf8,0xb5,0x00,0xfc,0xf7,0xb9,0x00,0xea,0xf7,0xbc,0x00,0xd8,0xf7,0xbf,0x00,0xc5,0xf7,0xc2,0x00,0xb3,0xf7,0xc5,0x00,0xa1,0xf7,0xc8,0x00,0x8e,0xf7,  \
    0xcc,0x00,0x7c,0xf7,0xcf,0x00,0x69,0xf7,0xd2,0x00,0x57,0xf7,0xd5,0x00,0x44,0xf7,0xd8,0x00,0x31,0xf7,0xdc,0x00,0x1e,0xf7,0xdf,0x00,0x0b,0xf7,0xe2,0x00,0xf8,0xf6,0xe5,0x00,0xe4,0xf6,0xe8,0x00,0xd1,0xf6,0xec,0x00,0xbd,0xf6,0xef,0x00,0xaa,0xf6,0xf2,0x00,0x96,0xf6,0xf5,0x00,0x82,0xf6,0xf8,0x00,0x6e,0xf6,0xfc,0x00,0x5a,0xf6,0xff,0x00,0x46,0xf6,0x02,0x01,0x32,0xf6,0x05,0x01,0x1e,0xf6,0x08,0x01,0x09,0xf6,0x0b,0x01,0xf4,0xf5,0x0f,0x01,0xe0,0xf5,0x12,0x01,  \
    0xcb,0xf5,0x15,0x01,0xb6,0xf5,0x18,0x01,0xa1,0xf5,0x1b,0x01,0x8c,0xf5,0x1e,0x01,0x76,0xf5,0x21,0x01,0x61,0xf5,0x24,0x01,0x4b,0xf5,0x27,0x01,0x36,0xf5,0x2a,0x01,0x20,0xf5,0x2d,0x01,0x0a,0xf5,0x30,0x01,0xf4,0xf4,0x34,0x01,0xde,0xf4,0x36,0x01,0xc8,0xf4,0x39,0x01,0xb2,0xf4,0x3c,0x01,0x9b,0xf4,0x3f,0x01,0x85,0xf4,0x42,0x01,0x6f,0xf4,0x45,0x01,0x58,0xf4,0x48,0x01,0x41,0xf4,0x4b,0x01,0x2a,0xf4,0x4e,0x01,0x13,0xf4,0x51,0x01,0xfc,0xf3,0x54,0x01,0xe5,0xf3,  \
    0x57,0x01,0xcd,0xf3,0x59,0x01,0xb6,0xf3,0x5c,0x01,0x9e,0xf3,0x5f,0x01,0x87,0xf3,0x62,0x01,0x6f,0xf3,0x64,0x01,0x57,0xf3,0x67,0x01,0x3f,0xf3,0x6a,0x01,0x27,0xf3,0x6c,0x01,0x0e,0xf3,0x6f,0x01,0xf6,0xf2,0x72,0x01,0xdd,0xf2,0x74,0x01,0xc4,0xf2,0x77,0x01,0xac,0xf2,0x79,0x01,0x93,0xf2,0x7c,0x01,0x7a,0xf2,0x7e,0x01,0x60,0xf2,0x80,0x01,0x47,0xf2,0x83,0x01,0x2e,0xf2,0x85,0x01,0x14,0xf2,0x87,0x01,0xfa,0xf1,0x8a,0x01,0xe0,0xf1,0x8c,0x01,0xc6,0xf1,0x8e,0x01,  \
    0xac,0xf1,0x90,0x01,0x92,0xf1,0x92,0x01,0x78,0xf1,0x94,0x01,0x5d,0xf1,0x96,0x01,0x43,0xf1,0x98,0x01,0x28,0xf1,0x9a,0x01,0x0d,0xf1,0x9c,0x01,0xf2,0xf0,0x9e,0x01,0xd7,0xf0,0xa0,0x01,0xbb,0xf0,0xa1,0x01,0xa0,0xf0,0xa3,0x01,0x84,0xf0,0xa5,0x01,0x69,0xf0,0xa6,0x01,0x4d,0xf0,0xa8,0x01,0x31,0xf0,0xa9,0x01,0x15,0xf0,0xab,0x01,0xf8,0xef,0xac,0x01,0xdc,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa9,0x01,0x2e,0x10,0xa8,0x01,0x11,0x10,0xa6,0x01,0xf5,0x0f,0xa5,0x01,0xd8,0x0f,0xa4,0x01,0xbc,0x0f,0xa2,0x01,0xa0,0x0f,0xa0,0x01,0x84,0x0f,0x9f,0x01,0x68,0x0f,0x9d,0x01,0x4c,0x0f,0x9c,0x01,0x31,0x0f,0x9a,0x01,0x15,0x0f,0x98,0x01,0xfa,0x0e,0x96,0x01,  \
    0xdf,0x0e,0x95,0x01,0xc4,0x0e,0x93,0x01,0xa9,0x0e,0x91,0x01,0x8e,0x0e,0x8f,0x01,0x73,0x0e,0x8d,0x01,0x58,0x0e,0x8b,0x01,0x3e,0x0e,0x89,0x01,0x23,0x0e,0x87,0x01,0x09,0x0e,0x85,0x01,0xef,0x0d,0x82,0x01,0xd5,0x0d,0x80,0x01,0xbb,0x0d,0x7e,0x01,0xa1,0x0d,0x7c,0x01,0x88,0x0d,0x79,0x01,0x6e,0x0d,0x77,0x01,0x55,0x0d,0x75,0x01,0x3c,0x0d,0x72,0x01,0x23,0x0d,0x70,0x01,0x0a,0x0d,0x6e,0x01,0xf1,0x0c,0x6b,0x01,0xd8,0x0c,0x69,0x01,0xbf,0x0c,0x66,0x01,0xa7,0x0c,  \
    0x64,0x01,0x8e,0x0c,0x61,0x01,0x76,0x0c,0x5e,0x01,0x5e,0x0c,0x5c,0x01,0x46,0x0c,0x59,0x01,0x2e,0x0c,0x56,0x01,0x16,0x0c,0x54,0x01,0xfe,0x0b,0x51,0x01,0xe7,0x0b,0x4e,0x01,0xcf,0x0b,0x4c,0x01,0xb8,0x0b,0x49,0x01,0xa1,0x0b,0x46,0x01,0x8a,0x0b,0x43,0x01,0x73,0x0b,0x40,0x01,0x5c,0x0b,0x3d,0x01,0x45,0x0b,0x3b,0x01,0x2e,0x0b,0x38,0x01,0x18,0x0b,0x35,0x01,0x01,0x0b,0x32,0x01,0xeb,0x0a,0x2f,0x01,0xd5,0x0a,0x2c,0x01,0xbf,0x0a,0x29,0x01,0xa9,0x0a,0x26,0x01,  \
    0x93,0x0a,0x23,0x01,0x7d,0x0a,0x20,0x01,0x67,0x0a,0x1d,0x01,0x51,0x0a,0x1a,0x01,0x3c,0x0a,0x17,0x01,0x26,0x0a,0x14,0x01,0x11,0x0a,0x11,0x01,0xfc,0x09,0x0e,0x01,0xe7,0x09,0x0b,0x01,0xd1,0x09,0x08,0x01,0xbc,0x09,0x05,0x01,0xa8,0x09,0x02,0x01,0x93,0x09,0xff,0x00,0x7e,0x09,0xfc,0x00,0x6a,0x09,0xf9,0x00,0x55,0x09,0xf6,0x00,0x41,0x09,0xf3,0x00,0x2c,0x09,0xf0,0x00,0x18,0x09,0xed,0x00,0x04,0x09,0xea,0x00,0xf0,0x08,0xe7,0x00,0xdc,0x08,0xe4,0x00,0xc9,0x08,  \
    0xe1,0x00,0xb5,0x08,0xde,0x00,0xa1,0x08,0xdb,0x00,0x8e,0x08,0xd8,0x00,0x7a,0x08,0xd5,0x00,0x67,0x08,0xd1,0x00,0x54,0x08,0xce,0x00,0x41,0x08,0xcb,0x00,0x2e,0x08,0xc8,0x00,0x1b,0x08,0xc5,0x00,0x08,0x08,0xc2,0x00,0xf5,0x07,0xbf,0x00,0xe3,0x07,0xbc,0x00,0xd0,0x07,0xb9,0x00,0xbe,0x07,0xb6,0x00,0xab,0x07,0xb3,0x00,0x99,0x07,0xb0,0x00,0x87,0x07,0xad,0x00,0x75,0x07,0xaa,0x00,0x64,0x07,0xa7,0x00,0x52,0x07,0xa4,0x00,0x40,0x07,0xa1,0x00,0x2f,0x07,0x9e,0x00,  \
    0x1d,0x07,0x9b,0x00,0x0c,0x07,0x98,0x00,0xfb,0x06,0x95,0x00,0xe9,0x06,0x92,0x00,0xd8,0x06,0x8f,0x00,0xc7,0x06,0x8c,0x00,0xb6,0x06,0x89,0x00,0xa5,0x06,0x86,0x00,0x95,0x06,0x83,0x00,0x84,0x06,0x80,0x00,0x73,0x06,0x7d,0x00,0x63,0x06,0x7a,0x00,0x52,0x06,0x77,0x00,0x42,0x06,0x75,0x00,0x31,0x06,0x72,0x00,0x21,0x06,0x6f,0x00,0x11,0x06,0x6c,0x00,0x01,0x06,0x69,0x00,0xf1,0x05,0x66,0x00,0xe1,0x05,0x64,0x00,0xd1,0x05,0x61,0x00,0xc1,0x05,0x5e,0x00,0xb1,0x05,  \
    0x5b,0x00,0xa2,0x05,0x59,0x00,0x92,0x05,0x56,0x00,0x83,0x05,0x53,0x00,0x73,0x05,0x51,0x00,0x64,0x05,0x4e,0x00,0x55,0x05,0x4b,0x00,0x45,0x05,0x49,0x00,0x36,0x05,0x46,0x00,0x27,0x05,0x43,0x00,0x18,0x05,0x41,0x00,0x09,0x05,0x3e,0x00,0xfa,0x04,0x3c,0x00,0xeb,0x04,0x39,0x00,0xdc,0x04,0x37,0x00,0xcd,0x04,0x34,0x00,0xbf,0x04,0x32,0x00,0xb0,0x04,0x2f,0x00,0xa1,0x04,0x2d,0x00,0x93,0x04,0x2b,0x00,0x84,0x04,0x28,0x00,0x76,0x04,0x26,0x00,0x67,0x04,0x24,0x00,  \
    0x59,0x04,0x21,0x00,0x4b,0x04,0x1f,0x00,0x3d,0x04,0x1d,0x00,0x2e,0x04,0x1a,0x00,0x20,0x04,0x18,0x00,0x12,0x04,0x16,0x00,0x04,0x04,0x14,0x00,0xf6,0x03,0x12,0x00,0xe8,0x03,0x0f,0x00,0xdb,0x03,0x0d,0x00,0xcd,0x03,0x0b,0x00,0xbf,0x03,0x09,0x00,0xb1,0x03,0x07,0x00,0xa4,0x03,0x05,0x00,0x96,0x03,0x03,0x00,0x89,0x03,0x01,0x00,0x7c,0x03,0xff,0xff,0x6e,0x03,0xfd,0xff,0x61,0x03,0xfb,0xff,0x54,0x03,0xf9,0xff,0x47,0x03,0xf7,0xff,0x3a,0x03,0xf5,0xff,0x2d,0x03,  \
    0xf3,0xff,0x1f,0x03,0xf1,0xff,0x13,0x03,0xf0,0xff,0x06,0x03,0xee,0xff,0xf9,0x02,0xec,0xff,0xec,0x02,0xea,0xff,0xdf,0x02,0xe9,0xff,0xd2,0x02,0xe7,0xff,0xc6,0x02,0xe5,0xff,0xb9,0x02,0xe3,0xff,0xac,0x02,0xe2,0xff,0xa0,0x02,0xe0,0xff,0x93,0x02,0xdf,0xff,0x86,0x02,0xdd,0xff,0x7a,0x02,0xdc,0xff,0x6e,0x02,0xda,0xff,0x61,0x02,0xd9,0xff,0x55,0x02,0xd7,0xff,0x48,0x02,0xd6,0xff,0x3c,0x02,0xd4,0xff,0x30,0x02,0xd3,0xff,0x24,0x02,0xd1,0xff,0x18,0x02,0xd0,0xff,  \
    0x0c,0x02,0xcf,0xff,0x00,0x02,0xcd,0xff,0xf3,0x01,0xcc,0xff,0xe7,0x01,0xcb,0xff,0xdb,0x01,0xca,0xff,0xcf,0x01,0xc9,0xff,0xc4,0x01,0xc7,0xff,0xb8,0x01,0xc6,0xff,0xac,0x01,0xc5,0xff,0xa0,0x01,0xc4,0xff,0x94,0x01,0xc3,0xff,0x88,0x01,0xc2,0xff,0x7c,0x01,0xc1,0xff,0x71,0x01,0xc0,0xff,0x65,0x01,0xbf,0xff,0x59,0x01,0xbe,0xff,0x4d,0x01,0xbd,0xff,0x42,0x01,0xbc,0xff,0x36,0x01,0xbb,0xff,0x2a,0x01,0xbb,0xff,0x1f,0x01,0xba,0xff,0x13,0x01,0xb9,0xff,0x07,0x01,  \
    0xb8,0xff,0xfc,0x00,0xb8,0xff,0xf0,0x00,0xb7,0xff,0xe4,0x00,0xb6,0xff,0xd9,0x00,0xb6,0xff,0xcd,0x00,0xb5,0xff,0xc2,0x00,0xb4,0xff,0xb6,0x00,0xb4,0xff,0xab,0x00,0xb3,0xff,0x9f,0x00,0xb3,0xff,0x93,0x00,0xb2,0xff,0x88,0x00,0xb2,0xff,0x7c,0x00,0xb1,0xff,0x71,0x00,0xb1,0xff,0x65,0x00,0xb1,0xff,0x5a,0x00,0xb0,0xff,0x4f,0x00,0xb0,0xff,0x43,0x00,0xb0,0xff,0x38,0x00,0xb0,0xff,0x2c,0x00,0xaf,0xff,0x21,0x00,0xaf,0xff,0x15,0x00,0xaf,0xff,0x0a,0x00,0xaf,0xff,  \
    0xff,0xff,0xaf,0xff,0xf3,0xff,0xae,0xff,0xe8,0xff,0xae,0xff,0xdc,0xff,0xae,0xff,0xd1,0xff,0xae,0xff,0xc6,0xff,0xae,0xff,0xba,0xff,0xae,0xff,0xaf,0xff,0xae,0xff,0xa3,0xff,0xaf,0xff,0x98,0xff,0xaf,0xff,0x8d,0xff,0xaf,0xff,0x81,0xff,0xaf,0xff,0x76,0xff,0xaf,0xff,0x6a,0xff,0xaf,0xff,0x5f,0xff,0xb0,0xff,0x54,0xff,0xb0,0xff,0x48,0xff,0xb0,0xff,0x3d,0xff,0xb0,0xff,0x31,0xff,0xb1,0xff,0x26,0xff,0xb1,0xff,0x1a,0xff,0xb2,0xff,0x0f,0xff,0xb2,0xff,0x04,0xff,  \
    0xb3,0xff,0xf8,0xfe,0xb3,0xff,0xed,0xfe,0xb4,0xff,0xe1,0xfe,0xb4,0xff,0xd6,0xfe,0xb5,0xff,0xca,0xfe,0xb5,0xff,0xbf,0xfe,0xb6,0xff,0xb3,0xfe,0xb6,0xff,0xa7,0xfe,0xb7,0xff,0x9c,0xfe,0xb8,0xff,0x90,0xfe,0xb9,0xff,0x85,0xfe,0xb9,0xff,0x79,0xfe,0xba,0xff,0x6d,0xfe,0xbb,0xff,0x62,0xfe,0xbc,0xff,0x56,0xfe,0xbd,0xff,0x4a,0xfe,0xbd,0xff,0x3f,0xfe,0xbe,0xff,0x33,0xfe,0xbf,0xff,0x27,0xfe,0xc0,0xff,0x1b,0xfe,0xc1,0xff,0x10,0xfe,0xc2,0xff,0x04,0xfe,0xc3,0xff,  \
    0xf8,0xfd,0xc4,0xff,0xec,0xfd,0xc5,0xff,0xe0,0xfd,0xc7,0xff,0xd4,0xfd,0xc8,0xff,0xc8,0xfd,0xc9,0xff,0xbc,0xfd,0xca,0xff,0xb0,0xfd,0xcb,0xff,0xa4,0xfd,0xcd,0xff,0x98,0xfd,0xce,0xff,0x8c,0xfd,0xcf,0xff,0x80,0xfd,0xd0,0xff,0x74,0xfd,0xd2,0xff,0x67,0xfd,0xd3,0xff,0x5b,0xfd,0xd4,0xff,0x4f,0xfd,0xd6,0xff,0x43,0xfd,0xd7,0xff,0x36,0xfd,0xd9,0xff,0x2a,0xfd,0xda,0xff,0x1e,0xfd,0xdc,0xff,0x12,0xfd,0xdd,0xff,0x05,0xfd,0xdf,0xff,0xf9,0xfc,0xe1,0xff,0xec,0xfc,  \
    0xe2,0xff,0xe0,0xfc,0xe4,0xff,0xd3,0xfc,0xe5,0xff,0xc7,0xfc,0xe7,0xff,0xba,0xfc,0xe9,0xff,0xad,0xfc,0xeb,0xff,0xa1,0xfc,0xec,0xff,0x94,0xfc,0xee,0xff,0x87,0xfc,0xf0,0xff,0x7b,0xfc,0xf2,0xff,0x6e,0xfc,0xf4,0xff,0x61,0xfc,0xf6,0xff,0x54,0xfc,0xf7,0xff,0x47,0xfc,0xf9,0xff,0x3a,0xfc,0xfb,0xff,0x2d,0xfc,0xfd,0xff,0x20,0xfc,0xff,0xff,0x13,0xfc,0x01,0x00,0x05,0xfc,0x03,0x00,0xf8,0xfb,0x05,0x00,0xeb,0xfb,0x07,0x00,0xdd,0xfb,0x0a,0x00,0xd0,0xfb,0x0c,0x00,  \
    0xc2,0xfb,0x0e,0x00,0xb5,0xfb,0x10,0x00,0xa7,0xfb,0x12,0x00,0x9a,0xfb,0x14,0x00,0x8c,0xfb,0x17,0x00,0x7e,0xfb,0x19,0x00,0x70,0xfb,0x1b,0x00,0x62,0xfb,0x1d,0x00,0x55,0xfb,0x20,0x00,0x47,0xfb,0x22,0x00,0x39,0xfb,0x24,0x00,0x2a,0xfb,0x27,0x00,0x1c,0xfb,0x29,0x00,0x0e,0xfb,0x2c,0x00,0x00,0xfb,0x2e,0x00,0xf1,0xfa,0x30,0x00,0xe3,0xfa,0x33,0x00,0xd5,0xfa,0x35,0x00,0xc6,0xfa,0x38,0x00,0xb7,0xfa,0x3a,0x00,0xa9,0xfa,0x3d,0x00,0x9a,0xfa,0x40,0x00,0x8b,0xfa,  \
    0x42,0x00,0x7c,0xfa,0x45,0x00,0x6e,0xfa,0x47,0x00,0x5f,0xfa,0x4a,0x00,0x50,0xfa,0x4d,0x00,0x41,0xfa,0x4f,0x00,0x31,0xfa,0x52,0x00,0x22,0xfa,0x55,0x00,0x13,0xfa,0x57,0x00,0x04,0xfa,0x5a,0x00,0xf4,0xf9,0x5d,0x00,0xe5,0xf9,0x60,0x00,0xd5,0xf9,0x62,0x00,0xc5,0xf9,0x65,0x00,0xb6,0xf9,0x68,0x00,0xa6,0xf9,0x6b,0x00,0x96,0xf9,0x6e,0x00,0x86,0xf9,0x70,0x00,0x76,0xf9,0x73,0x00,0x66,0xf9,0x76,0x00,0x56,0xf9,0x79,0x00,0x45,0xf9,0x7c,0x00,0x35,0xf9,0x7f,0x00,  \
    0x25,0xf9,0x82,0x00,0x14,0xf9,0x85,0x00,0x04,0xf9,0x88,0x00,0xf3,0xf8,0x8b,0x00,0xe2,0xf8,0x8e,0x00,0xd1,0xf8,0x91,0x00,0xc0,0xf8,0x94,0x00,0xaf,0xf8,0x97,0x00,0x9e,0xf8,0x9a,0x00,0x8d,0xf8,0x9d,0x00,0x7c,0xf8,0xa0,0x00,0x6a,0xf8,0xa3,0x00,0x59,0xf8,0xa6,0x00,0x47,0xf8,0xa9,0x00,0x36,0xf8,0xac,0x00,0x24,0xf8,0xaf,0x00,0x12,0xf8,0xb2,0x00,0x00,0xf8,0xb5,0x00,0xee,0xf7,0xb8,0x00,0xdc,0xf7,0xbb,0x00,0xca,0xf7,0xbe,0x00,0xb8,0xf7,0xc1,0x00,0xa5,0xf7,  \
    0xc4,0x00,0x93,0xf7,0xc7,0x00,0x80,0xf7,0xcb,0x00,0x6e,0xf7,0xce,0x00,0x5b,0xf7,0xd1,0x00,0x48,0xf7,0xd4,0x00,0x35,0xf7,0xd7,0x00,0x22,0xf7,0xda,0x00,0x0f,0xf7,0xdd,0x00,0xfc,0xf6,0xe0,0x00,0xe9,0xf6,0xe3,0x00,0xd5,0xf6,0xe7,0x00,0xc2,0xf6,0xea,0x00,0xae,0xf6,0xed,0x00,0x9a,0xf6,0xf0,0x00,0x86,0xf6,0xf3,0x00,0x73,0xf6,0xf6,0x00,0x5f,0xf6,0xf9,0x00,0x4a,0xf6,0xfc,0x00,0x36,0xf6,0xff,0x00,0x22,0xf6,0x02,0x01,0x0d,0xf6,0x05,0x01,0xf8,0xf5,0x08,0x01,  \
    0xe4,0xf5,0x0c,0x01,0xcf,0xf5,0x0f,0x01,0xba,0xf5,0x12,0x01,0xa5,0xf5,0x15,0x01,0x90,0xf5,0x18,0x01,0x7a,0xf5,0x1b,0x01,0x65,0xf5,0x1e,0x01,0x4f,0xf5,0x21,0x01,0x3a,0xf5,0x24,0x01,0x24,0xf5,0x26,0x01,0x0e,0xf5,0x29,0x01,0xf8,0xf4,0x2c,0x01,0xe2,0xf4,0x2f,0x01,0xcc,0xf4,0x32,0x01,0xb6,0xf4,0x35,0x01,0x9f,0xf4,0x38,0x01,0x89,0xf4,0x3b,0x01,0x72,0xf4,0x3e,0x01,0x5c,0xf4,0x41,0x01,0x45,0xf4,0x43,0x01,0x2e,0xf4,0x46,0x01,0x17,0xf4,0x49,0x01,0x00,0xf4,  \
    0x4c,0x01,0xe9,0xf3,0x4e,0x01,0xd1,0xf3,0x51,0x01,0xba,0xf3,0x54,0x01,0xa2,0xf3,0x57,0x01,0x8a,0xf3,0x59,0x01,0x72,0xf3,0x5c,0x01,0x5a,0xf3,0x5e,0x01,0x42,0xf3,0x61,0x01,0x2a,0xf3,0x64,0x01,0x12,0xf3,0x66,0x01,0xf9,0xf2,0x69,0x01,0xe1,0xf2,0x6b,0x01,0xc8,0xf2,0x6d,0x01,0xaf,0xf2,0x70,0x01,0x96,0xf2,0x72,0x01,0x7d,0xf2,0x75,0x01,0x64,0xf2,0x77,0x01,0x4b,0xf2,0x79,0x01,0x31,0xf2,0x7b,0x01,0x17,0xf2,0x7e,0x01,0xfe,0xf1,0x80,0x01,0xe4,0xf1,0x82,0x01,  \
    0xca,0xf1,0x84,0x01,0xb0,0xf1,0x86,0x01,0x95,0xf1,0x88,0x01,0x7b,0xf1,0x8a,0x01,0x61,0xf1,0x8c,0x01,0x46,0xf1,0x8e,0x01,0x2b,0xf1,0x90,0x01,0x10,0xf1,0x92,0x01,0xf5,0xf0,0x94,0x01,0xda,0xf0,0x95,0x01,0xbf,0xf0,0x97,0x01,0xa3,0xf0,0x99,0x01,0x88,0xf0,0x9a,0x01,0x6c,0xf0,0x9c,0x01,0x50,0xf0,0x9d,0x01,0x34,0xf0,0x9f,0x01,0x18,0xf0,0xa0,0x01,0xfc,0xef,0xa1,0x01,0xdf,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x9d,0x01,0x2b,0x10,0x9b,0x01,0x0e,0x10,0x9a,0x01,0xf2,0x0f,0x99,0x01,0xd6,0x0f,0x97,0x01,0xb9,0x0f,0x96,0x01,0x9d,0x0f,0x94,0x01,0x81,0x0f,0x93,0x01,0x65,0x0f,0x91,0x01,0x4a,0x0f,0x90,0x01,0x2e,0x0f,0x8e,0x01,0x13,0x0f,0x8c,0x01,  \
    0xf7,0x0e,0x8a,0x01,0xdc,0x0e,0x89,0x01,0xc1,0x0e,0x87,0x01,0xa6,0x0e,0x85,0x01,0x8b,0x0e,0x83,0x01,0x70,0x0e,0x81,0x01,0x56,0x0e,0x7f,0x01,0x3b,0x0e,0x7d,0x01,0x21,0x0e,0x7b,0x01,0x06,0x0e,0x79,0x01,0xec,0x0d,0x77,0x01,0xd2,0x0d,0x75,0x01,0xb8,0x0d,0x73,0x01,0x9f,0x0d,0x71,0x01,0x85,0x0d,0x6f,0x01,0x6b,0x0d,0x6c,0x01,0x52,0x0d,0x6a,0x01,0x39,0x0d,0x68,0x01,0x20,0x0d,0x65,0x01,0x07,0x0d,0x63,0x01,0xee,0x0c,0x61,0x01,0xd5,0x0c,0x5e,0x01,0xbc,0x0c,  \
    0x5c,0x01,0xa4,0x0c,0x59,0x01,0x8b,0x0c,0x57,0x01,0x73,0x0c,0x54,0x01,0x5b,0x0c,0x52,0x01,0x42,0x0c,0x4f,0x01,0x2a,0x0c,0x4d,0x01,0x13,0x0c,0x4a,0x01,0xfb,0x0b,0x48,0x01,0xe3,0x0b,0x45,0x01,0xcc,0x0b,0x42,0x01,0xb5,0x0b,0x40,0x01,0x9d,0x0b,0x3d,0x01,0x86,0x0b,0x3a,0x01,0x6f,0x0b,0x37,0x01,0x58,0x0b,0x35,0x01,0x42,0x0b,0x32,0x01,0x2b,0x0b,0x2f,0x01,0x14,0x0b,0x2c,0x01,0xfe,0x0a,0x29,0x01,0xe8,0x0a,0x27,0x01,0xd1,0x0a,0x24,0x01,0xbb,0x0a,0x21,0x01,  \
    0xa5,0x0a,0x1e,0x01,0x8f,0x0a,0x1b,0x01,0x79,0x0a,0x18,0x01,0x64,0x0a,0x16,0x01,0x4e,0x0a,0x13,0x01,0x38,0x0a,0x10,0x01,0x23,0x0a,0x0d,0x01,0x0d,0x0a,0x0a,0x01,0xf8,0x09,0x07,0x01,0xe3,0x09,0x04,0x01,0xce,0x09,0x01,0x01,0xb9,0x09,0xfe,0x00,0xa4,0x09,0xfb,0x00,0x8f,0x09,0xf9,0x00,0x7a,0x09,0xf6,0x00,0x66,0x09,0xf3,0x00,0x51,0x09,0xf0,0x00,0x3d,0x09,0xed,0x00,0x29,0x09,0xea,0x00,0x15,0x09,0xe7,0x00,0x01,0x09,0xe4,0x00,0xed,0x08,0xe1,0x00,0xd9,0x08,  \
    0xde,0x00,0xc5,0x08,0xdb,0x00,0xb1,0x08,0xd8,0x00,0x9e,0x08,0xd5,0x00,0x8a,0x08,0xd2,0x00,0x77,0x08,0xcf,0x00,0x63,0x08,0xcc,0x00,0x50,0x08,0xc9,0x00,0x3d,0x08,0xc6,0x00,0x2a,0x08,0xc3,0x00,0x17,0x08,0xc0,0x00,0x04,0x08,0xbd,0x00,0xf2,0x07,0xbb,0x00,0xdf,0x07,0xb8,0x00,0xcc,0x07,0xb5,0x00,0xba,0x07,0xb2,0x00,0xa8,0x07,0xaf,0x00,0x96,0x07,0xac,0x00,0x84,0x07,0xa9,0x00,0x72,0x07,0xa6,0x00,0x60,0x07,0xa3,0x00,0x4e,0x07,0xa0,0x00,0x3d,0x07,0x9d,0x00,  \
    0x2b,0x07,0x9a,0x00,0x19,0x07,0x97,0x00,0x08,0x07,0x94,0x00,0xf7,0x06,0x91,0x00,0xe6,0x06,0x8f,0x00,0xd4,0x06,0x8c,0x00,0xc3,0x06,0x89,0x00,0xb2,0x06,0x86,0x00,0xa2,0x06,0x83,0x00,0x91,0x06,0x80,0x00,0x80,0x06,0x7d,0x00,0x6f,0x06,0x7b,0x00,0x5f,0x06,0x78,0x00,0x4e,0x06,0x75,0x00,0x3e,0x06,0x72,0x00,0x2e,0x06,0x6f,0x00,0x1d,0x06,0x6d,0x00,0x0d,0x06,0x6a,0x00,0xfd,0x05,0x67,0x00,0xed,0x05,0x65,0x00,0xdd,0x05,0x62,0x00,0xcd,0x05,0x5f,0x00,0xbd,0x05,  \
    0x5d,0x00,0xae,0x05,0x5a,0x00,0x9e,0x05,0x57,0x00,0x8e,0x05,0x55,0x00,0x7f,0x05,0x52,0x00,0x6f,0x05,0x4f,0x00,0x60,0x05,0x4d,0x00,0x51,0x05,0x4a,0x00,0x42,0x05,0x48,0x00,0x32,0x05,0x45,0x00,0x23,0x05,0x43,0x00,0x14,0x05,0x40,0x00,0x05,0x05,0x3e,0x00,0xf6,0x04,0x3b,0x00,0xe7,0x04,0x39,0x00,0xd9,0x04,0x36,0x00,0xca,0x04,0x34,0x00,0xbb,0x04,0x32,0x00,0xac,0x04,0x2f,0x00,0x9e,0x04,0x2d,0x00,0x8f,0x04,0x2b,0x00,0x81,0x04,0x28,0x00,0x72,0x04,0x26,0x00,  \
    0x64,0x04,0x24,0x00,0x55,0x04,0x21,0x00,0x47,0x04,0x1f,0x00,0x39,0x04,0x1d,0x00,0x2b,0x04,0x1b,0x00,0x1d,0x04,0x19,0x00,0x0f,0x04,0x16,0x00,0x01,0x04,0x14,0x00,0xf3,0x03,0x12,0x00,0xe5,0x03,0x10,0x00,0xd7,0x03,0x0e,0x00,0xca,0x03,0x0c,0x00,0xbc,0x03,0x0a,0x00,0xae,0x03,0x08,0x00,0xa1,0x03,0x06,0x00,0x93,0x03,0x04,0x00,0x86,0x03,0x02,0x00,0x79,0x03,0x00,0x00,0x6b,0x03,0xfe,0xff,0x5e,0x03,0xfc,0xff,0x51,0x03,0xfa,0xff,0x44,0x03,0xf8,0xff,0x37,0x03,  \
    0xf7,0xff,0x2a,0x03,0xf5,0xff,0x1d,0x03,0xf3,0xff,0x10,0x03,0xf1,0xff,0x03,0x03,0xef,0xff,0xf6,0x02,0xee,0xff,0xe9,0x02,0xec,0xff,0xdc,0x02,0xea,0xff,0xcf,0x02,0xe9,0xff,0xc3,0x02,0xe7,0xff,0xb6,0x02,0xe5,0xff,0xaa,0x02,0xe4,0xff,0x9d,0x02,0xe2,0xff,0x90,0x02,0xe1,0xff,0x84,0x02,0xdf,0xff,0x77,0x02,0xde,0xff,0x6b,0x02,0xdc,0xff,0x5f,0x02,0xdb,0xff,0x52,0x02,0xd9,0xff,0x46,0x02,0xd8,0xff,0x3a,0x02,0xd7,0xff,0x2e,0x02,0xd5,0xff,0x22,0x02,0xd4,0xff,  \
    0x15,0x02,0xd3,0xff,0x09,0x02,0xd1,0xff,0xfd,0x01,0xd0,0xff,0xf1,0x01,0xcf,0xff,0xe5,0x01,0xce,0xff,0xd9,0x01,0xcd,0xff,0xcd,0x01,0xcb,0xff,0xc1,0x01,0xca,0xff,0xb6,0x01,0xc9,0xff,0xaa,0x01,0xc8,0xff,0x9e,0x01,0xc7,0xff,0x92,0x01,0xc6,0xff,0x86,0x01,0xc5,0xff,0x7b,0x01,0xc4,0xff,0x6f,0x01,0xc3,0xff,0x63,0x01,0xc2,0xff,0x57,0x01,0xc1,0xff,0x4c,0x01,0xc0,0xff,0x40,0x01,0xbf,0xff,0x34,0x01,0xbf,0xff,0x29,0x01,0xbe,0xff,0x1d,0x01,0xbd,0xff,0x12,0x01,  \
    0xbc,0xff,0x06,0x01,0xbc,0xff,0xfa,0x00,0xbb,0xff,0xef,0x00,0xba,0xff,0xe3,0x00,0xba,0xff,0xd8,0x00,0xb9,0xff,0xcc,0x00,0xb8,0xff,0xc1,0x00,0xb8,0xff,0xb5,0x00,0xb7,0xff,0xaa,0x00,0xb7,0xff,0x9e,0x00,0xb6,0xff,0x93,0x00,0xb6,0xff,0x87,0x00,0xb5,0xff,0x7c,0x00,0xb5,0xff,0x70,0x00,0xb5,0xff,0x65,0x00,0xb4,0xff,0x59,0x00,0xb4,0xff,0x4e,0x00,0xb4,0xff,0x43,0x00,0xb3,0xff,0x37,0x00,0xb3,0xff,0x2c,0x00,0xb3,0xff,0x20,0x00,0xb3,0xff,0x15,0x00,0xb2,0xff,  \
    0x0a,0x00,0xb2,0xff,0xfe,0xff,0xb2,0xff,0xf3,0xff,0xb2,0xff,0xe8,0xff,0xb2,0xff,0xdc,0xff,0xb2,0xff,0xd1,0xff,0xb2,0xff,0xc6,0xff,0xb2,0xff,0xba,0xff,0xb2,0xff,0xaf,0xff,0xb2,0xff,0xa4,0xff,0xb2,0xff,0x98,0xff,0xb2,0xff,0x8d,0xff,0xb2,0xff,0x81,0xff,0xb2,0xff,0x76,0xff,0xb3,0xff,0x6b,0xff,0xb3,0xff,0x5f,0xff,0xb3,0xff,0x54,0xff,0xb3,0xff,0x49,0xff,0xb4,0xff,0x3d,0xff,0xb4,0xff,0x32,0xff,0xb4,0xff,0x27,0xff,0xb5,0xff,0x1b,0xff,0xb5,0xff,0x10,0xff,  \
    0xb5,0xff,0x04,0xff,0xb6,0xff,0xf9,0xfe,0xb6,0xff,0xed,0xfe,0xb7,0xff,0xe2,0xfe,0xb7,0xff,0xd7,0xfe,0xb8,0xff,0xcb,0xfe,0xb9,0xff,0xc0,0xfe,0xb9,0xff,0xb4,0xfe,0xba,0xff,0xa9,0xfe,0xba,0xff,0x9d,0xfe,0xbb,0xff,0x92,0xfe,0xbc,0xff,0x86,0xfe,0xbd,0xff,0x7b,0xfe,0xbd,0xff,0x6f,0xfe,0xbe,0xff,0x63,0xfe,0xbf,0xff,0x58,0xfe,0xc0,0xff,0x4c,0xfe,0xc1,0xff,0x40,0xfe,0xc1,0xff,0x35,0xfe,0xc2,0xff,0x29,0xfe,0xc3,0xff,0x1d,0xfe,0xc4,0xff,0x11,0xfe,0xc5,0xff,  \
    0x06,0xfe,0xc6,0xff,0xfa,0xfd,0xc7,0xff,0xee,0xfd,0xc8,0xff,0xe2,0xfd,0xc9,0xff,0xd6,0xfd,0xcb,0xff,0xca,0xfd,0xcc,0xff,0xbe,0xfd,0xcd,0xff,0xb2,0xfd,0xce,0xff,0xa6,0xfd,0xcf,0xff,0x9a,0xfd,0xd0,0xff,0x8e,0xfd,0xd2,0xff,0x82,0xfd,0xd3,0xff,0x76,0xfd,0xd4,0xff,0x6a,0xfd,0xd6,0xff,0x5e,0xfd,0xd7,0xff,0x52,0xfd,0xd8,0xff,0x45,0xfd,0xda,0xff,0x39,0xfd,0xdb,0xff,0x2d,0xfd,0xdd,0xff,0x21,0xfd,0xde,0xff,0x14,0xfd,0xe0,0xff,0x08,0xfd,0xe1,0xff,0xfc,0xfc,  \
    0xe3,0xff,0xef,0xfc,0xe4,0xff,0xe3,0xfc,0xe6,0xff,0xd6,0xfc,0xe8,0xff,0xca,0xfc,0xe9,0xff,0xbd,0xfc,0xeb,0xff,0xb1,0xfc,0xed,0xff,0xa4,0xfc,0xee,0xff,0x97,0xfc,0xf0,0xff,0x8a,0xfc,0xf2,0xff,0x7e,0xfc,0xf4,0xff,0x71,0xfc,0xf5,0xff,0x64,0xfc,0xf7,0xff,0x57,0xfc,0xf9,0xff,0x4a,0xfc,0xfb,0xff,0x3d,0xfc,0xfd,0xff,0x30,0xfc,0xff,0xff,0x23,0xfc,0x01,0x00,0x16,0xfc,0x03,0x00,0x09,0xfc,0x05,0x00,0xfc,0xfb,0x07,0x00,0xee,0xfb,0x09,0x00,0xe1,0xfb,0x0b,0x00,  \
    0xd4,0xfb,0x0d,0x00,0xc6,0xfb,0x0f,0x00,0xb9,0xfb,0x11,0x00,0xab,0xfb,0x13,0x00,0x9d,0xfb,0x15,0x00,0x90,0xfb,0x17,0x00,0x82,0xfb,0x1a,0x00,0x74,0xfb,0x1c,0x00,0x66,0xfb,0x1e,0x00,0x58,0xfb,0x20,0x00,0x4a,0xfb,0x23,0x00,0x3c,0xfb,0x25,0x00,0x2e,0xfb,0x27,0x00,0x20,0xfb,0x29,0x00,0x12,0xfb,0x2c,0x00,0x04,0xfb,0x2e,0x00,0xf5,0xfa,0x31,0x00,0xe7,0xfa,0x33,0x00,0xd8,0xfa,0x35,0x00,0xca,0xfa,0x38,0x00,0xbb,0xfa,0x3a,0x00,0xad,0xfa,0x3d,0x00,0x9e,0xfa,  \
    0x3f,0x00,0x8f,0xfa,0x42,0x00,0x80,0xfa,0x44,0x00,0x72,0xfa,0x47,0x00,0x63,0xfa,0x49,0x00,0x54,0xfa,0x4c,0x00,0x45,0xfa,0x4e,0x00,0x35,0xfa,0x51,0x00,0x26,0xfa,0x54,0x00,0x17,0xfa,0x56,0x00,0x08,0xfa,0x59,0x00,0xf8,0xf9,0x5c,0x00,0xe9,0xf9,0x5e,0x00,0xd9,0xf9,0x61,0x00,0xca,0xf9,0x64,0x00,0xba,0xf9,0x67,0x00,0xaa,0xf9,0x69,0x00,0x9a,0xf9,0x6c,0x00,0x8a,0xf9,0x6f,0x00,0x7a,0xf9,0x72,0x00,0x6a,0xf9,0x74,0x00,0x5a,0xf9,0x77,0x00,0x4a,0xf9,0x7a,0x00,  \
    0x39,0xf9,0x7d,0x00,0x29,0xf9,0x80,0x00,0x18,0xf9,0x82,0x00,0x08,0xf9,0x85,0x00,0xf7,0xf8,0x88,0x00,0xe6,0xf8,0x8b,0x00,0xd5,0xf8,0x8e,0x00,0xc4,0xf8,0x91,0x00,0xb3,0xf8,0x94,0x00,0xa2,0xf8,0x97,0x00,0x91,0xf8,0x9a,0x00,0x80,0xf8,0x9d,0x00,0x6e,0xf8,0x9f,0x00,0x5d,0xf8,0xa2,0x00,0x4b,0xf8,0xa5,0x00,0x3a,0xf8,0xa8,0x00,0x28,0xf8,0xab,0x00,0x16,0xf8,0xae,0x00,0x04,0xf8,0xb1,0x00,0xf2,0xf7,0xb4,0x00,0xe0,0xf7,0xb7,0x00,0xce,0xf7,0xba,0x00,0xbc,0xf7,  \
    0xbd,0x00,0xa9,0xf7,0xc0,0x00,0x97,0xf7,0xc3,0x00,0x84,0xf7,0xc6,0x00,0x72,0xf7,0xc9,0x00,0x5f,0xf7,0xcc,0x00,0x4c,0xf7,0xcf,0x00,0x39,0xf7,0xd2,0x00,0x26,0xf7,0xd5,0x00,0x13,0xf7,0xd8,0x00,0x00,0xf7,0xdb,0x00,0xed,0xf6,0xde,0x00,0xd9,0xf6,0xe1,0x00,0xc6,0xf6,0xe4,0x00,0xb2,0xf6,0xe7,0x00,0x9e,0xf6,0xeb,0x00,0x8a,0xf6,0xee,0x00,0x77,0xf6,0xf1,0x00,0x63,0xf6,0xf4,0x00,0x4e,0xf6,0xf7,0x00,0x3a,0xf6,0xf9,0x00,0x26,0xf6,0xfc,0x00,0x11,0xf6,0xff,0x00,  \
    0xfc,0xf5,0x02,0x01,0xe8,0xf5,0x05,0x01,0xd3,0xf5,0x08,0x01,0xbe,0xf5,0x0b,0x01,0xa9,0xf5,0x0e,0x01,0x93,0xf5,0x11,0x01,0x7e,0xf5,0x14,0x01,0x69,0xf5,0x17,0x01,0x53,0xf5,0x1a,0x01,0x3e,0xf5,0x1d,0x01,0x28,0xf5,0x1f,0x01,0x12,0xf5,0x22,0x01,0xfc,0xf4,0x25,0x01,0xe6,0xf4,0x28,0x01,0xd0,0xf4,0x2b,0x01,0xb9,0xf4,0x2e,0x01,0xa3,0xf4,0x30,0x01,0x8d,0xf4,0x33,0x01,0x76,0xf4,0x36,0x01,0x5f,0xf4,0x39,0x01,0x49,0xf4,0x3b,0x01,0x32,0xf4,0x3e,0x01,0x1b,0xf4,  \
    0x41,0x01,0x04,0xf4,0x44,0x01,0xec,0xf3,0x46,0x01,0xd5,0xf3,0x49,0x01,0xbd,0xf3,0x4b,0x01,0xa6,0xf3,0x4e,0x01,0x8e,0xf3,0x51,0x01,0x76,0xf3,0x53,0x01,0x5e,0xf3,0x56,0x01,0x46,0xf3,0x58,0x01,0x2e,0xf3,0x5b,0x01,0x15,0xf3,0x5d,0x01,0xfd,0xf2,0x60,0x01,0xe4,0xf2,0x62,0x01,0xcb,0xf2,0x64,0x01,0xb3,0xf2,0x67,0x01,0x9a,0xf2,0x69,0x01,0x80,0xf2,0x6b,0x01,0x67,0xf2,0x6d,0x01,0x4e,0xf2,0x70,0x01,0x34,0xf2,0x72,0x01,0x1b,0xf2,0x74,0x01,0x01,0xf2,0x76,0x01,  \
    0xe7,0xf1,0x78,0x01,0xcd,0xf1,0x7a,0x01,0xb3,0xf1,0x7c,0x01,0x99,0xf1,0x7e,0x01,0x7e,0xf1,0x80,0x01,0x64,0xf1,0x82,0x01,0x49,0xf1,0x84,0x01,0x2e,0xf1,0x86,0x01,0x13,0xf1,0x87,0x01,0xf8,0xf0,0x89,0x01,0xdd,0xf0,0x8b,0x01,0xc2,0xf0,0x8c,0x01,0xa6,0xf0,0x8e,0x01,0x8b,0xf0,0x90,0x01,0x6f,0xf0,0x91,0x01,0x53,0xf0,0x93,0x01,0x37,0xf0,0x94,0x01,0x1b,0xf0,0x95,0x01,0xff,0xef,0x97,0x01,0xe2,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x90,0x01,0x28,0x10,0x8f,0x01,0x0c,0x10,0x8e,0x01,0xef,0x0f,0x8c,0x01,0xd3,0x0f,0x8b,0x01,0xb7,0x0f,0x8a,0x01,0x9b,0x0f,0x88,0x01,0x7f,0x0f,0x87,0x01,0x63,0x0f,0x85,0x01,0x47,0x0f,0x84,0x01,0x2b,0x0f,0x82,0x01,  \
    0x10,0x0f,0x80,0x01,0xf4,0x0e,0x7f,0x01,0xd9,0x0e,0x7d,0x01,0xbe,0x0e,0x7b,0x01,0xa3,0x0e,0x79,0x01,0x88,0x0e,0x78,0x01,0x6d,0x0e,0x76,0x01,0x53,0x0e,0x74,0x01,0x38,0x0e,0x72,0x01,0x1e,0x0e,0x70,0x01,0x04,0x0e,0x6e,0x01,0xe9,0x0d,0x6c,0x01,0xcf,0x0d,0x6a,0x01,0xb6,0x0d,0x68,0x01,0x9c,0x0d,0x66,0x01,0x82,0x0d,0x64,0x01,0x69,0x0d,0x62,0x01,0x4f,0x0d,0x5f,0x01,0x36,0x0d,0x5d,0x01,0x1d,0x0d,0x5b,0x01,0x04,0x0d,0x59,0x01,0xeb,0x0c,0x56,0x01,0xd2,0x0c,  \
    0x54,0x01,0xb9,0x0c,0x52,0x01,0xa1,0x0c,0x4f,0x01,0x88,0x0c,0x4d,0x01,0x70,0x0c,0x4b,0x01,0x58,0x0c,0x48,0x01,0x3f,0x0c,0x46,0x01,0x27,0x0c,0x43,0x01,0x10,0x0c,0x41,0x01,0xf8,0x0b,0x3e,0x01,0xe0,0x0b,0x3c,0x01,0xc9,0x0b,0x39,0x01,0xb1,0x0b,0x36,0x01,0x9a,0x0b,0x34,0x01,0x83,0x0b,0x31,0x01,0x6c,0x0b,0x2f,0x01,0x55,0x0b,0x2c,0x01,0x3e,0x0b,0x29,0x01,0x28,0x0b,0x27,0x01,0x11,0x0b,0x24,0x01,0xfb,0x0a,0x21,0x01,0xe4,0x0a,0x1e,0x01,0xce,0x0a,0x1c,0x01,  \
    0xb8,0x0a,0x19,0x01,0xa2,0x0a,0x16,0x01,0x8c,0x0a,0x13,0x01,0x76,0x0a,0x11,0x01,0x60,0x0a,0x0e,0x01,0x4a,0x0a,0x0b,0x01,0x35,0x0a,0x08,0x01,0x1f,0x0a,0x06,0x01,0x0a,0x0a,0x03,0x01,0xf5,0x09,0x00,0x01,0xdf,0x09,0xfd,0x00,0xca,0x09,0xfa,0x00,0xb5,0x09,0xf8,0x00,0xa0,0x09,0xf5,0x00,0x8c,0x09,0xf2,0x00,0x77,0x09,0xef,0x00,0x62,0x09,0xec,0x00,0x4e,0x09,0xe9,0x00,0x39,0x09,0xe6,0x00,0x25,0x09,0xe4,0x00,0x11,0x09,0xe1,0x00,0xfd,0x08,0xde,0x00,0xe9,0x08,  \
    0xdb,0x00,0xd5,0x08,0xd8,0x00,0xc1,0x08,0xd5,0x00,0xae,0x08,0xd2,0x00,0x9a,0x08,0xd0,0x00,0x87,0x08,0xcd,0x00,0x73,0x08,0xca,0x00,0x60,0x08,0xc7,0x00,0x4d,0x08,0xc4,0x00,0x39,0x08,0xc1,0x00,0x26,0x08,0xbe,0x00,0x14,0x08,0xbc,0x00,0x01,0x08,0xb9,0x00,0xee,0x07,0xb6,0x00,0xdb,0x07,0xb3,0x00,0xc9,0x07,0xb0,0x00,0xb6,0x07,0xad,0x00,0xa4,0x07,0xaa,0x00,0x92,0x07,0xa8,0x00,0x80,0x07,0xa5,0x00,0x6e,0x07,0xa2,0x00,0x5c,0x07,0x9f,0x00,0x4b,0x07,0x9c,0x00,  \
    0x39,0x07,0x99,0x00,0x27,0x07,0x97,0x00,0x16,0x07,0x94,0x00,0x04,0x07,0x91,0x00,0xf3,0x06,0x8e,0x00,0xe2,0x06,0x8b,0x00,0xd1,0x06,0x89,0x00,0xc0,0x06,0x86,0x00,0xaf,0x06,0x83,0x00,0x9e,0x06,0x80,0x00,0x8d,0x06,0x7e,0x00,0x7c,0x06,0x7b,0x00,0x6c,0x06,0x78,0x00,0x5b,0x06,0x75,0x00,0x4b,0x06,0x73,0x00,0x3a,0x06,0x70,0x00,0x2a,0x06,0x6d,0x00,0x1a,0x06,0x6b,0x00,0x09,0x06,0x68,0x00,0xf9,0x05,0x65,0x00,0xe9,0x05,0x63,0x00,0xd9,0x05,0x60,0x00,0xc9,0x05,  \
    0x5e,0x00,0xba,0x05,0x5b,0x00,0xaa,0x05,0x58,0x00,0x9a,0x05,0x56,0x00,0x8b,0x05,0x53,0x00,0x7b,0x05,0x51,0x00,0x6c,0x05,0x4e,0x00,0x5c,0x05,0x4c,0x00,0x4d,0x05,0x49,0x00,0x3e,0x05,0x47,0x00,0x2f,0x05,0x44,0x00,0x20,0x05,0x42,0x00,0x11,0x05,0x40,0x00,0x02,0x05,0x3d,0x00,0xf3,0x04,0x3b,0x00,0xe4,0x04,0x38,0x00,0xd5,0x04,0x36,0x00,0xc6,0x04,0x34,0x00,0xb7,0x04,0x31,0x00,0xa9,0x04,0x2f,0x00,0x9a,0x04,0x2d,0x00,0x8c,0x04,0x2b,0x00,0x7d,0x04,0x28,0x00,  \
    0x6f,0x04,0x26,0x00,0x60,0x04,0x24,0x00,0x52,0x04,0x22,0x00,0x44,0x04,0x20,0x00,0x36,0x04,0x1d,0x00,0x28,0x04,0x1b,0x00,0x19,0x04,0x19,0x00,0x0b,0x04,0x17,0x00,0xfe,0x03,0x15,0x00,0xf0,0x03,0x13,0x00,0xe2,0x03,0x11,0x00,0xd4,0x03,0x0f,0x00,0xc6,0x03,0x0d,0x00,0xb9,0x03,0x0b,0x00,0xab,0x03,0x09,0x00,0x9e,0x03,0x07,0x00,0x90,0x03,0x05,0x00,0x83,0x03,0x03,0x00,0x75,0x03,0x01,0x00,0x68,0x03,0xff,0xff,0x5b,0x03,0xfe,0xff,0x4e,0x03,0xfc,0xff,0x41,0x03,  \
    0xfa,0xff,0x34,0x03,0xf8,0xff,0x27,0x03,0xf6,0xff,0x1a,0x03,0xf5,0xff,0x0d,0x03,0xf3,0xff,0x00,0x03,0xf1,0xff,0xf3,0x02,0xf0,0xff,0xe6,0x02,0xee,0xff,0xd9,0x02,0xec,0xff,0xcd,0x02,0xeb,0xff,0xc0,0x02,0xe9,0xff,0xb4,0x02,0xe8,0xff,0xa7,0x02,0xe6,0xff,0x9a,0x02,0xe5,0xff,0x8e,0x02,0xe3,0xff,0x81,0x02,0xe2,0xff,0x75,0x02,0xe0,0xff,0x69,0x02,0xdf,0xff,0x5c,0x02,0xdd,0xff,0x50,0x02,0xdc,0xff,0x44,0x02,0xdb,0xff,0x38,0x02,0xd9,0xff,0x2b,0x02,0xd8,0xff,  \
    0x1f,0x02,0xd7,0xff,0x13,0x02,0xd5,0xff,0x07,0x02,0xd4,0xff,0xfb,0x01,0xd3,0xff,0xef,0x01,0xd2,0xff,0xe3,0x01,0xd1,0xff,0xd7,0x01,0xcf,0xff,0xcb,0x01,0xce,0xff,0xc0,0x01,0xcd,0xff,0xb4,0x01,0xcc,0xff,0xa8,0x01,0xcb,0xff,0x9c,0x01,0xca,0xff,0x90,0x01,0xc9,0xff,0x85,0x01,0xc8,0xff,0x79,0x01,0xc7,0xff,0x6d,0x01,0xc6,0xff,0x61,0x01,0xc5,0xff,0x56,0x01,0xc4,0xff,0x4a,0x01,0xc4,0xff,0x3e,0x01,0xc3,0xff,0x33,0x01,0xc2,0xff,0x27,0x01,0xc1,0xff,0x1c,0x01,  \
    0xc0,0xff,0x10,0x01,0xc0,0xff,0x05,0x01,0xbf,0xff,0xf9,0x00,0xbe,0xff,0xed,0x00,0xbe,0xff,0xe2,0x00,0xbd,0xff,0xd6,0x00,0xbc,0xff,0xcb,0x00,0xbc,0xff,0xbf,0x00,0xbb,0xff,0xb4,0x00,0xbb,0xff,0xa9,0x00,0xba,0xff,0x9d,0x00,0xba,0xff,0x92,0x00,0xb9,0xff,0x86,0x00,0xb9,0xff,0x7b,0x00,0xb9,0xff,0x6f,0x00,0xb8,0xff,0x64,0x00,0xb8,0xff,0x59,0x00,0xb7,0xff,0x4d,0x00,0xb7,0xff,0x42,0x00,0xb7,0xff,0x37,0x00,0xb7,0xff,0x2b,0x00,0xb6,0xff,0x20,0x00,0xb6,0xff,  \
    0x15,0x00,0xb6,0xff,0x09,0x00,0xb6,0xff,0xfe,0xff,0xb6,0xff,0xf3,0xff,0xb6,0xff,0xe7,0xff,0xb6,0xff,0xdc,0xff,0xb6,0xff,0xd1,0xff,0xb6,0xff,0xc6,0xff,0xb6,0xff,0xba,0xff,0xb6,0xff,0xaf,0xff,0xb6,0xff,0xa4,0xff,0xb6,0xff,0x98,0xff,0xb6,0xff,0x8d,0xff,0xb6,0xff,0x82,0xff,0xb6,0xff,0x76,0xff,0xb6,0xff,0x6b,0xff,0xb6,0xff,0x60,0xff,0xb7,0xff,0x55,0xff,0xb7,0xff,0x49,0xff,0xb7,0xff,0x3e,0xff,0xb8,0xff,0x33,0xff,0xb8,0xff,0x27,0xff,0xb8,0xff,0x1c,0xff,  \
    0xb9,0xff,0x11,0xff,0xb9,0xff,0x05,0xff,0xb9,0xff,0xfa,0xfe,0xba,0xff,0xee,0xfe,0xba,0xff,0xe3,0xfe,0xbb,0xff,0xd8,0xfe,0xbb,0xff,0xcc,0xfe,0xbc,0xff,0xc1,0xfe,0xbd,0xff,0xb5,0xfe,0xbd,0xff,0xaa,0xfe,0xbe,0xff,0x9e,0xfe,0xbf,0xff,0x93,0xfe,0xbf,0xff,0x87,0xfe,0xc0,0xff,0x7c,0xfe,0xc1,0xff,0x70,0xfe,0xc1,0xff,0x65,0xfe,0xc2,0xff,0x59,0xfe,0xc3,0xff,0x4e,0xfe,0xc4,0xff,0x42,0xfe,0xc5,0xff,0x36,0xfe,0xc6,0xff,0x2b,0xfe,0xc7,0xff,0x1f,0xfe,0xc7,0xff,  \
    0x13,0xfe,0xc8,0xff,0x07,0xfe,0xc9,0xff,0xfc,0xfd,0xca,0xff,0xf0,0xfd,0xcb,0xff,0xe4,0xfd,0xcc,0xff,0xd8,0xfd,0xce,0xff,0xcc,0xfd,0xcf,0xff,0xc0,0xfd,0xd0,0xff,0xb5,0xfd,0xd1,0xff,0xa9,0xfd,0xd2,0xff,0x9d,0xfd,0xd3,0xff,0x91,0xfd,0xd5,0xff,0x85,0xfd,0xd6,0xff,0x78,0xfd,0xd7,0xff,0x6c,0xfd,0xd8,0xff,0x60,0xfd,0xda,0xff,0x54,0xfd,0xdb,0xff,0x48,0xfd,0xdc,0xff,0x3c,0xfd,0xde,0xff,0x2f,0xfd,0xdf,0xff,0x23,0xfd,0xe1,0xff,0x17,0xfd,0xe2,0xff,0x0b,0xfd,  \
    0xe4,0xff,0xfe,0xfc,0xe5,0xff,0xf2,0xfc,0xe7,0xff,0xe6,0xfc,0xe8,0xff,0xd9,0xfc,0xea,0xff,0xcd,0xfc,0xeb,0xff,0xc0,0xfc,0xed,0xff,0xb3,0xfc,0xef,0xff,0xa7,0xfc,0xf0,0xff,0x9a,0xfc,0xf2,0xff,0x8d,0xfc,0xf4,0xff,0x81,0xfc,0xf5,0xff,0x74,0xfc,0xf7,0xff,0x67,0xfc,0xf9,0xff,0x5a,0xfc,0xfb,0xff,0x4d,0xfc,0xfd,0xff,0x40,0xfc,0xfe,0xff,0x33,0xfc,0x00,0x00,0x26,0xfc,0x02,0x00,0x19,0xfc,0x04,0x00,0x0c,0xfc,0x06,0x00,0xff,0xfb,0x08,0x00,0xf2,0xfb,0x0a,0x00,  \
    0xe4,0xfb,0x0c,0x00,0xd7,0xfb,0x0e,0x00,0xc9,0xfb,0x10,0x00,0xbc,0xfb,0x12,0x00,0xae,0xfb,0x14,0x00,0xa1,0xfb,0x16,0x00,0x93,0xfb,0x18,0x00,0x85,0xfb,0x1a,0x00,0x78,0xfb,0x1d,0x00,0x6a,0xfb,0x1f,0x00,0x5c,0xfb,0x21,0x00,0x4e,0xfb,0x23,0x00,0x40,0xfb,0x25,0x00,0x32,0xfb,0x28,0x00,0x24,0xfb,0x2a,0x00,0x16,0xfb,0x2c,0x00,0x07,0xfb,0x2e,0x00,0xf9,0xfa,0x31,0x00,0xeb,0xfa,0x33,0x00,0xdc,0xfa,0x35,0x00,0xce,0xfa,0x38,0x00,0xbf,0xfa,0x3a,0x00,0xb1,0xfa,  \
    0x3c,0x00,0xa2,0xfa,0x3f,0x00,0x93,0xfa,0x41,0x00,0x84,0xfa,0x44,0x00,0x76,0xfa,0x46,0x00,0x67,0xfa,0x49,0x00,0x58,0xfa,0x4b,0x00,0x49,0xfa,0x4e,0x00,0x39,0xfa,0x50,0x00,0x2a,0xfa,0x53,0x00,0x1b,0xfa,0x55,0x00,0x0c,0xfa,0x58,0x00,0xfc,0xf9,0x5b,0x00,0xed,0xf9,0x5d,0x00,0xdd,0xf9,0x60,0x00,0xce,0xf9,0x62,0x00,0xbe,0xf9,0x65,0x00,0xae,0xf9,0x68,0x00,0x9e,0xf9,0x6a,0x00,0x8e,0xf9,0x6d,0x00,0x7e,0xf9,0x70,0x00,0x6e,0xf9,0x73,0x00,0x5e,0xf9,0x75,0x00,  \
    0x4e,0xf9,0x78,0x00,0x3d,0xf9,0x7b,0x00,0x2d,0xf9,0x7d,0x00,0x1c,0xf9,0x80,0x00,0x0c,0xf9,0x83,0x00,0xfb,0xf8,0x86,0x00,0xea,0xf8,0x89,0x00,0xd9,0xf8,0x8b,0x00,0xc8,0xf8,0x8e,0x00,0xb7,0xf8,0x91,0x00,0xa6,0xf8,0x94,0x00,0x95,0xf8,0x97,0x00,0x84,0xf8,0x9a,0x00,0x72,0xf8,0x9c,0x00,0x61,0xf8,0x9f,0x00,0x4f,0xf8,0xa2,0x00,0x3e,0xf8,0xa5,0x00,0x2c,0xf8,0xa8,0x00,0x1a,0xf8,0xab,0x00,0x08,0xf8,0xae,0x00,0xf6,0xf7,0xb1,0x00,0xe4,0xf7,0xb3,0x00,0xd2,0xf7,  \
    0xb6,0x00,0xc0,0xf7,0xb9,0x00,0xad,0xf7,0xbc,0x00,0x9b,0xf7,0xbf,0x00,0x88,0xf7,0xc2,0x00,0x76,0xf7,0xc5,0x00,0x63,0xf7,0xc8,0x00,0x50,0xf7,0xcb,0x00,0x3d,0xf7,0xce,0x00,0x2a,0xf7,0xd1,0x00,0x17,0xf7,0xd4,0x00,0x04,0xf7,0xd7,0x00,0xf1,0xf6,0xd9,0x00,0xdd,0xf6,0xdc,0x00,0xca,0xf6,0xdf,0x00,0xb6,0xf6,0xe2,0x00,0xa2,0xf6,0xe5,0x00,0x8e,0xf6,0xe8,0x00,0x7a,0xf6,0xeb,0x00,0x66,0xf6,0xee,0x00,0x52,0xf6,0xf1,0x00,0x3e,0xf6,0xf4,0x00,0x29,0xf6,0xf7,0x00,  \
    0x15,0xf6,0xf9,0x00,0x00,0xf6,0xfc,0x00,0xeb,0xf5,0xff,0x00,0xd7,0xf5,0x02,0x01,0xc2,0xf5,0x05,0x01,0xac,0xf5,0x08,0x01,0x97,0xf5,0x0b,0x01,0x82,0xf5,0x0d,0x01,0x6d,0xf5,0x10,0x01,0x57,0xf5,0x13,0x01,0x41,0xf5,0x16,0x01,0x2c,0xf5,0x18,0x01,0x16,0xf5,0x1b,0x01,0x00,0xf5,0x1e,0x01,0xea,0xf4,0x21,0x01,0xd3,0xf4,0x23,0x01,0xbd,0xf4,0x26,0x01,0xa7,0xf4,0x29,0x01,0x90,0xf4,0x2c,0x01,0x7a,0xf4,0x2e,0x01,0x63,0xf4,0x31,0x01,0x4c,0xf4,0x34,0x01,0x35,0xf4,  \
    0x36,0x01,0x1e,0xf4,0x39,0x01,0x07,0xf4,0x3b,0x01,0xf0,0xf3,0x3e,0x01,0xd8,0xf3,0x41,0x01,0xc1,0xf3,0x43,0x01,0xa9,0xf3,0x46,0x01,0x91,0xf3,0x48,0x01,0x79,0xf3,0x4b,0x01,0x61,0xf3,0x4d,0x01,0x49,0xf3,0x4f,0x01,0x31,0xf3,0x52,0x01,0x19,0xf3,0x54,0x01,0x00,0xf3,0x57,0x01,0xe8,0xf2,0x59,0x01,0xcf,0xf2,0x5b,0x01,0xb6,0xf2,0x5d,0x01,0x9d,0xf2,0x60,0x01,0x84,0xf2,0x62,0x01,0x6b,0xf2,0x64,0x01,0x51,0xf2,0x66,0x01,0x38,0xf2,0x68,0x01,0x1e,0xf2,0x6a,0x01,  \
    0x04,0xf2,0x6c,0x01,0xea,0xf1,0x6e,0x01,0xd0,0xf1,0x70,0x01,0xb6,0xf1,0x72,0x01,0x9c,0xf1,0x74,0x01,0x81,0xf1,0x76,0x01,0x67,0xf1,0x78,0x01,0x4c,0xf1,0x7a,0x01,0x31,0xf1,0x7b,0x01,0x17,0xf1,0x7d,0x01,0xfb,0xf0,0x7f,0x01,0xe0,0xf0,0x80,0x01,0xc5,0xf0,0x82,0x01,0xa9,0xf0,0x84,0x01,0x8e,0xf0,0x85,0x01,0x72,0xf0,0x86,0x01,0x56,0xf0,0x88,0x01,0x3a,0xf0,0x89,0x01,0x1e,0xf0,0x8b,0x01,0x02,0xf0,0x8c,0x01,0xe5,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x85,0x01,0x26,0x10,0x84,0x01,0x09,0x10,0x83,0x01,0xed,0x0f,0x81,0x01,0xd0,0x0f,0x80,0x01,0xb4,0x0f,0x7f,0x01,0x98,0x0f,0x7d,0x01,0x7c,0x0f,0x7c,0x01,0x60,0x0f,0x7b,0x01,0x44,0x0f,0x79,0x01,  \
    0x29,0x0f,0x77,0x01,0x0d,0x0f,0x76,0x01,0xf2,0x0e,0x74,0x01,0xd6,0x0e,0x73,0x01,0xbb,0x0e,0x71,0x01,0xa0,0x0e,0x6f,0x01,0x85,0x0e,0x6e,0x01,0x6b,0x0e,0x6c,0x01,0x50,0x0e,0x6a,0x01,0x35,0x0e,0x68,0x01,0x1b,0x0e,0x66,0x01,0x01,0x0e,0x64,0x01,0xe7,0x0d,0x62,0x01,0xcd,0x0d,0x60,0x01,0xb3,0x0d,0x5e,0x01,0x99,0x0d,0x5c,0x01,0x7f,0x0d,0x5a,0x01,0x66,0x0d,0x58,0x01,0x4c,0x0d,0x56,0x01,0x33,0x0d,0x54,0x01,0x1a,0x0d,0x52,0x01,0x01,0x0d,0x50,0x01,0xe8,0x0c,  \
    0x4d,0x01,0xcf,0x0c,0x4b,0x01,0xb6,0x0c,0x49,0x01,0x9e,0x0c,0x47,0x01,0x85,0x0c,0x44,0x01,0x6d,0x0c,0x42,0x01,0x54,0x0c,0x40,0x01,0x3c,0x0c,0x3d,0x01,0x24,0x0c,0x3b,0x01,0x0c,0x0c,0x38,0x01,0xf5,0x0b,0x36,0x01,0xdd,0x0b,0x33,0x01,0xc6,0x0b,0x31,0x01,0xae,0x0b,0x2e,0x01,0x97,0x0b,0x2c,0x01,0x80,0x0b,0x29,0x01,0x69,0x0b,0x27,0x01,0x52,0x0b,0x24,0x01,0x3b,0x0b,0x22,0x01,0x24,0x0b,0x1f,0x01,0x0e,0x0b,0x1c,0x01,0xf7,0x0a,0x1a,0x01,0xe1,0x0a,0x17,0x01,  \
    0xcb,0x0a,0x15,0x01,0xb4,0x0a,0x12,0x01,0x9e,0x0a,0x0f,0x01,0x89,0x0a,0x0d,0x01,0x73,0x0a,0x0a,0x01,0x5d,0x0a,0x07,0x01,0x47,0x0a,0x05,0x01,0x31,0x0a,0x02,0x01,0x1c,0x0a,0xff,0x00,0x06,0x0a,0xfc,0x00,0xf1,0x09,0xfa,0x00,0xdc,0x09,0xf7,0x00,0xc7,0x09,0xf4,0x00,0xb2,0x09,0xf2,0x00,0x9d,0x09,0xef,0x00,0x88,0x09,0xec,0x00,0x73,0x09,0xe9,0x00,0x5f,0x09,0xe7,0x00,0x4a,0x09,0xe4,0x00,0x36,0x09,0xe1,0x00,0x22,0x09,0xde,0x00,0x0d,0x09,0xdc,0x00,0xf9,0x08,  \
    0xd9,0x00,0xe5,0x08,0xd6,0x00,0xd1,0x08,0xd3,0x00,0xbe,0x08,0xd0,0x00,0xaa,0x08,0xce,0x00,0x96,0x08,0xcb,0x00,0x83,0x08,0xc8,0x00,0x70,0x08,0xc5,0x00,0x5c,0x08,0xc3,0x00,0x49,0x08,0xc0,0x00,0x36,0x08,0xbd,0x00,0x23,0x08,0xba,0x00,0x10,0x08,0xb8,0x00,0xfd,0x07,0xb5,0x00,0xea,0x07,0xb2,0x00,0xd8,0x07,0xaf,0x00,0xc5,0x07,0xac,0x00,0xb3,0x07,0xaa,0x00,0xa1,0x07,0xa7,0x00,0x8e,0x07,0xa4,0x00,0x7c,0x07,0xa1,0x00,0x6a,0x07,0x9f,0x00,0x59,0x07,0x9c,0x00,  \
    0x47,0x07,0x99,0x00,0x35,0x07,0x96,0x00,0x24,0x07,0x94,0x00,0x12,0x07,0x91,0x00,0x01,0x07,0x8e,0x00,0xef,0x06,0x8b,0x00,0xde,0x06,0x89,0x00,0xcd,0x06,0x86,0x00,0xbc,0x06,0x83,0x00,0xab,0x06,0x81,0x00,0x9a,0x06,0x7e,0x00,0x89,0x06,0x7b,0x00,0x79,0x06,0x79,0x00,0x68,0x06,0x76,0x00,0x57,0x06,0x73,0x00,0x47,0x06,0x71,0x00,0x37,0x06,0x6e,0x00,0x26,0x06,0x6c,0x00,0x16,0x06,0x69,0x00,0x06,0x06,0x67,0x00,0xf6,0x05,0x64,0x00,0xe6,0x05,0x61,0x00,0xd6,0x05,  \
    0x5f,0x00,0xc6,0x05,0x5c,0x00,0xb6,0x05,0x5a,0x00,0xa6,0x05,0x57,0x00,0x97,0x05,0x55,0x00,0x87,0x05,0x52,0x00,0x78,0x05,0x50,0x00,0x68,0x05,0x4e,0x00,0x59,0x05,0x4b,0x00,0x49,0x05,0x49,0x00,0x3a,0x05,0x46,0x00,0x2b,0x05,0x44,0x00,0x1c,0x05,0x42,0x00,0x0d,0x05,0x3f,0x00,0xfe,0x04,0x3d,0x00,0xef,0x04,0x3b,0x00,0xe0,0x04,0x38,0x00,0xd1,0x04,0x36,0x00,0xc3,0x04,0x34,0x00,0xb4,0x04,0x32,0x00,0xa5,0x04,0x2f,0x00,0x97,0x04,0x2d,0x00,0x88,0x04,0x2b,0x00,  \
    0x7a,0x04,0x29,0x00,0x6b,0x04,0x27,0x00,0x5d,0x04,0x25,0x00,0x4f,0x04,0x22,0x00,0x40,0x04,0x20,0x00,0x32,0x04,0x1e,0x00,0x24,0x04,0x1c,0x00,0x16,0x04,0x1a,0x00,0x08,0x04,0x18,0x00,0xfa,0x03,0x16,0x00,0xec,0x03,0x14,0x00,0xdf,0x03,0x12,0x00,0xd1,0x03,0x10,0x00,0xc3,0x03,0x0e,0x00,0xb6,0x03,0x0c,0x00,0xa8,0x03,0x0a,0x00,0x9b,0x03,0x08,0x00,0x8d,0x03,0x07,0x00,0x80,0x03,0x05,0x00,0x73,0x03,0x03,0x00,0x65,0x03,0x01,0x00,0x58,0x03,0xff,0xff,0x4b,0x03,  \
    0xfe,0xff,0x3e,0x03,0xfc,0xff,0x31,0x03,0xfa,0xff,0x24,0x03,0xf8,0xff,0x17,0x03,0xf7,0xff,0x0a,0x03,0xf5,0xff,0xfd,0x02,0xf3,0xff,0xf0,0x02,0xf2,0xff,0xe4,0x02,0xf0,0xff,0xd7,0x02,0xef,0xff,0xca,0x02,0xed,0xff,0xbe,0x02,0xeb,0xff,0xb1,0x02,0xea,0xff,0xa4,0x02,0xe8,0xff,0x98,0x02,0xe7,0xff,0x8b,0x02,0xe6,0xff,0x7f,0x02,0xe4,0xff,0x73,0x02,0xe3,0xff,0x66,0x02,0xe1,0xff,0x5a,0x02,0xe0,0xff,0x4e,0x02,0xdf,0xff,0x41,0x02,0xdd,0xff,0x35,0x02,0xdc,0xff,  \
    0x29,0x02,0xdb,0xff,0x1d,0x02,0xd9,0xff,0x11,0x02,0xd8,0xff,0x05,0x02,0xd7,0xff,0xf9,0x01,0xd6,0xff,0xed,0x01,0xd5,0xff,0xe1,0x01,0xd4,0xff,0xd5,0x01,0xd2,0xff,0xc9,0x01,0xd1,0xff,0xbe,0x01,0xd0,0xff,0xb2,0x01,0xcf,0xff,0xa6,0x01,0xce,0xff,0x9a,0x01,0xcd,0xff,0x8e,0x01,0xcc,0xff,0x83,0x01,0xcb,0xff,0x77,0x01,0xca,0xff,0x6b,0x01,0xca,0xff,0x60,0x01,0xc9,0xff,0x54,0x01,0xc8,0xff,0x49,0x01,0xc7,0xff,0x3d,0x01,0xc6,0xff,0x31,0x01,0xc5,0xff,0x26,0x01,  \
    0xc5,0xff,0x1a,0x01,0xc4,0xff,0x0f,0x01,0xc3,0xff,0x03,0x01,0xc2,0xff,0xf8,0x00,0xc2,0xff,0xec,0x00,0xc1,0xff,0xe1,0x00,0xc1,0xff,0xd5,0x00,0xc0,0xff,0xca,0x00,0xbf,0xff,0xbe,0x00,0xbf,0xff,0xb3,0x00,0xbe,0xff,0xa8,0x00,0xbe,0xff,0x9c,0x00,0xbd,0xff,0x91,0x00,0xbd,0xff,0x85,0x00,0xbd,0xff,0x7a,0x00,0xbc,0xff,0x6f,0x00,0xbc,0xff,0x63,0x00,0xbc,0xff,0x58,0x00,0xbb,0xff,0x4d,0x00,0xbb,0xff,0x41,0x00,0xbb,0xff,0x36,0x00,0xba,0xff,0x2b,0x00,0xba,0xff,  \
    0x20,0x00,0xba,0xff,0x14,0x00,0xba,0xff,0x09,0x00,0xba,0xff,0xfe,0xff,0xba,0xff,0xf3,0xff,0xb9,0xff,0xe7,0xff,0xb9,0xff,0xdc,0xff,0xb9,0xff,0xd1,0xff,0xb9,0xff,0xc6,0xff,0xb9,0xff,0xba,0xff,0xb9,0xff,0xaf,0xff,0xb9,0xff,0xa4,0xff,0xb9,0xff,0x99,0xff,0xba,0xff,0x8d,0xff,0xba,0xff,0x82,0xff,0xba,0xff,0x77,0xff,0xba,0xff,0x6b,0xff,0xba,0xff,0x60,0xff,0xba,0xff,0x55,0xff,0xbb,0xff,0x4a,0xff,0xbb,0xff,0x3e,0xff,0xbb,0xff,0x33,0xff,0xbc,0xff,0x28,0xff,  \
    0xbc,0xff,0x1d,0xff,0xbc,0xff,0x11,0xff,0xbd,0xff,0x06,0xff,0xbd,0xff,0xfb,0xfe,0xbe,0xff,0xef,0xfe,0xbe,0xff,0xe4,0xfe,0xbf,0xff,0xd9,0xfe,0xbf,0xff,0xcd,0xfe,0xc0,0xff,0xc2,0xfe,0xc0,0xff,0xb6,0xfe,0xc1,0xff,0xab,0xfe,0xc1,0xff,0xa0,0xfe,0xc2,0xff,0x94,0xfe,0xc3,0xff,0x89,0xfe,0xc3,0xff,0x7d,0xfe,0xc4,0xff,0x72,0xfe,0xc5,0xff,0x66,0xfe,0xc6,0xff,0x5b,0xfe,0xc6,0xff,0x4f,0xfe,0xc7,0xff,0x43,0xfe,0xc8,0xff,0x38,0xfe,0xc9,0xff,0x2c,0xfe,0xca,0xff,  \
    0x21,0xfe,0xcb,0xff,0x15,0xfe,0xcc,0xff,0x09,0xfe,0xcd,0xff,0xfe,0xfd,0xce,0xff,0xf2,0xfd,0xcf,0xff,0xe6,0xfd,0xd0,0xff,0xda,0xfd,0xd1,0xff,0xce,0xfd,0xd2,0xff,0xc2,0xfd,0xd3,0xff,0xb7,0xfd,0xd4,0xff,0xab,0xfd,0xd5,0xff,0x9f,0xfd,0xd6,0xff,0x93,0xfd,0xd7,0xff,0x87,0xfd,0xd9,0xff,0x7b,0xfd,0xda,0xff,0x6f,0xfd,0xdb,0xff,0x63,0xfd,0xdc,0xff,0x56,0xfd,0xde,0xff,0x4a,0xfd,0xdf,0xff,0x3e,0xfd,0xe0,0xff,0x32,0xfd,0xe2,0xff,0x26,0xfd,0xe3,0xff,0x1a,0xfd,  \
    0xe5,0xff,0x0d,0xfd,0xe6,0xff,0x01,0xfd,0xe7,0xff,0xf5,0xfc,0xe9,0xff,0xe8,0xfc,0xea,0xff,0xdc,0xfc,0xec,0xff,0xcf,0xfc,0xee,0xff,0xc3,0xfc,0xef,0xff,0xb6,0xfc,0xf1,0xff,0xaa,0xfc,0xf2,0xff,0x9d,0xfc,0xf4,0xff,0x90,0xfc,0xf6,0xff,0x84,0xfc,0xf7,0xff,0x77,0xfc,0xf9,0xff,0x6a,0xfc,0xfb,0xff,0x5d,0xfc,0xfd,0xff,0x50,0xfc,0xfe,0xff,0x44,0xfc,0x00,0x00,0x37,0xfc,0x02,0x00,0x2a,0xfc,0x04,0x00,0x1c,0xfc,0x06,0x00,0x0f,0xfc,0x07,0x00,0x02,0xfc,0x09,0x00,  \
    0xf5,0xfb,0x0b,0x00,0xe8,0xfb,0x0d,0x00,0xda,0xfb,0x0f,0x00,0xcd,0xfb,0x11,0x00,0xbf,0xfb,0x13,0x00,0xb2,0xfb,0x15,0x00,0xa4,0xfb,0x17,0x00,0x97,0xfb,0x19,0x00,0x89,0xfb,0x1b,0x00,0x7b,0xfb,0x1d,0x00,0x6d,0xfb,0x1f,0x00,0x5f,0xfb,0x21,0x00,0x51,0xfb,0x24,0x00,0x44,0xfb,0x26,0x00,0x35,0xfb,0x28,0x00,0x27,0xfb,0x2a,0x00,0x19,0xfb,0x2c,0x00,0x0b,0xfb,0x2f,0x00,0xfd,0xfa,0x31,0x00,0xee,0xfa,0x33,0x00,0xe0,0xfa,0x35,0x00,0xd1,0xfa,0x38,0x00,0xc3,0xfa,  \
    0x3a,0x00,0xb4,0xfa,0x3c,0x00,0xa6,0xfa,0x3f,0x00,0x97,0xfa,0x41,0x00,0x88,0xfa,0x43,0x00,0x79,0xfa,0x46,0x00,0x6a,0xfa,0x48,0x00,0x5b,0xfa,0x4b,0x00,0x4c,0xfa,0x4d,0x00,0x3d,0xfa,0x4f,0x00,0x2e,0xfa,0x52,0x00,0x1f,0xfa,0x54,0x00,0x0f,0xfa,0x57,0x00,0x00,0xfa,0x59,0x00,0xf1,0xf9,0x5c,0x00,0xe1,0xf9,0x5e,0x00,0xd1,0xf9,0x61,0x00,0xc2,0xf9,0x64,0x00,0xb2,0xf9,0x66,0x00,0xa2,0xf9,0x69,0x00,0x92,0xf9,0x6b,0x00,0x82,0xf9,0x6e,0x00,0x72,0xf9,0x71,0x00,  \
    0x62,0xf9,0x73,0x00,0x52,0xf9,0x76,0x00,0x41,0xf9,0x79,0x00,0x31,0xf9,0x7b,0x00,0x20,0xf9,0x7e,0x00,0x10,0xf9,0x81,0x00,0xff,0xf8,0x83,0x00,0xee,0xf8,0x86,0x00,0xdd,0xf8,0x89,0x00,0xcc,0xf8,0x8b,0x00,0xbb,0xf8,0x8e,0x00,0xaa,0xf8,0x91,0x00,0x99,0xf8,0x94,0x00,0x88,0xf8,0x96,0x00,0x76,0xf8,0x99,0x00,0x65,0xf8,0x9c,0x00,0x53,0xf8,0x9f,0x00,0x42,0xf8,0xa1,0x00,0x30,0xf8,0xa4,0x00,0x1e,0xf8,0xa7,0x00,0x0c,0xf8,0xaa,0x00,0xfa,0xf7,0xad,0x00,0xe8,0xf7,  \
    0xaf,0x00,0xd6,0xf7,0xb2,0x00,0xc4,0xf7,0xb5,0x00,0xb1,0xf7,0xb8,0x00,0x9f,0xf7,0xbb,0x00,0x8c,0xf7,0xbe,0x00,0x7a,0xf7,0xc0,0x00,0x67,0xf7,0xc3,0x00,0x54,0xf7,0xc6,0x00,0x41,0xf7,0xc9,0x00,0x2e,0xf7,0xcc,0x00,0x1b,0xf7,0xcf,0x00,0x08,0xf7,0xd1,0x00,0xf4,0xf6,0xd4,0x00,0xe1,0xf6,0xd7,0x00,0xcd,0xf6,0xda,0x00,0xba,0xf6,0xdd,0x00,0xa6,0xf6,0xe0,0x00,0x92,0xf6,0xe2,0x00,0x7e,0xf6,0xe5,0x00,0x6a,0xf6,0xe8,0x00,0x56,0xf6,0xeb,0x00,0x42,0xf6,0xee,0x00,  \
    0x2d,0xf6,0xf0,0x00,0x19,0xf6,0xf3,0x00,0x04,0xf6,0xf6,0x00,0xef,0xf5,0xf9,0x00,0xda,0xf5,0xfb,0x00,0xc5,0xf5,0xfe,0x00,0xb0,0xf5,0x01,0x01,0x9b,0xf5,0x04,0x01,0x86,0xf5,0x06,0x01,0x70,0xf5,0x09,0x01,0x5b,0xf5,0x0c,0x01,0x45,0xf5,0x0e,0x01,0x2f,0xf5,0x11,0x01,0x19,0xf5,0x14,0x01,0x03,0xf5,0x16,0x01,0xed,0xf4,0x19,0x01,0xd7,0xf4,0x1c,0x01,0xc1,0xf4,0x1e,0x01,0xaa,0xf4,0x21,0x01,0x94,0xf4,0x24,0x01,0x7d,0xf4,0x26,0x01,0x66,0xf4,0x29,0x01,0x50,0xf4,  \
    0x2b,0x01,0x39,0xf4,0x2e,0x01,0x22,0xf4,0x30,0x01,0x0a,0xf4,0x33,0x01,0xf3,0xf3,0x35,0x01,0xdc,0xf3,0x38,0x01,0xc4,0xf3,0x3a,0x01,0xac,0xf3,0x3d,0x01,0x95,0xf3,0x3f,0x01,0x7d,0xf3,0x42,0x01,0x65,0xf3,0x44,0x01,0x4d,0xf3,0x46,0x01,0x34,0xf3,0x49,0x01,0x1c,0xf3,0x4b,0x01,0x03,0xf3,0x4d,0x01,0xeb,0xf2,0x4f,0x01,0xd2,0xf2,0x52,0x01,0xb9,0xf2,0x54,0x01,0xa0,0xf2,0x56,0x01,0x87,0xf2,0x58,0x01,0x6e,0xf2,0x5a,0x01,0x54,0xf2,0x5c,0x01,0x3b,0xf2,0x5e,0x01,  \
    0x21,0xf2,0x60,0x01,0x07,0xf2,0x62,0x01,0xed,0xf1,0x64,0x01,0xd3,0xf1,0x66,0x01,0xb9,0xf1,0x68,0x01,0x9f,0xf1,0x6a,0x01,0x84,0xf1,0x6b,0x01,0x6a,0xf1,0x6d,0x01,0x4f,0xf1,0x6f,0x01,0x34,0xf1,0x71,0x01,0x19,0xf1,0x72,0x01,0xfe,0xf0,0x74,0x01,0xe3,0xf0,0x75,0x01,0xc8,0xf0,0x77,0x01,0xac,0xf0,0x78,0x01,0x91,0xf0,0x7a,0x01,0x75,0xf0,0x7b,0x01,0x59,0xf0,0x7d,0x01,0x3d,0xf0,0x7e,0x01,0x21,0xf0,0x7f,0x01,0x04,0xf0,0x81,0x01,0xe8,0xef,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7a,0x01,0x23,0x10,0x79,0x01,0x06,0x10,0x78,0x01,0xea,0x0f,0x77,0x01,0xce,0x0f,0x75,0x01,0xb1,0x0f,0x74,0x01,0x95,0x0f,0x73,0x01,0x79,0x0f,0x71,0x01,0x5d,0x0f,0x70,0x01,  \
    0x42,0x0f,0x6f,0x01,0x26,0x0f,0x6d,0x01,0x0a,0x0f,0x6c,0x01,0xef,0x0e,0x6a,0x01,0xd4,0x0e,0x68,0x01,0xb9,0x0e,0x67,0x01,0x9e,0x0e,0x65,0x01,0x83,0x0e,0x63,0x01,0x68,0x0e,0x62,0x01,0x4d,0x0e,0x60,0x01,0x33,0x0e,0x5e,0x01,0x18,0x0e,0x5c,0x01,0xfe,0x0d,0x5b,0x01,0xe4,0x0d,0x59,0x01,0xca,0x0d,0x57,0x01,0xb0,0x0d,0x55,0x01,0x96,0x0d,0x53,0x01,0x7c,0x0d,0x51,0x01,0x63,0x0d,0x4f,0x01,0x49,0x0d,0x4d,0x01,0x30,0x0d,0x4b,0x01,0x17,0x0d,0x49,0x01,0xfe,0x0c,  \
    0x47,0x01,0xe5,0x0c,0x44,0x01,0xcc,0x0c,0x42,0x01,0xb3,0x0c,0x40,0x01,0x9b,0x0c,0x3e,0x01,0x82,0x0c,0x3c,0x01,0x6a,0x0c,0x39,0x01,0x51,0x0c,0x37,0x01,0x39,0x0c,0x35,0x01,0x21,0x0c,0x32,0x01,0x09,0x0c,0x30,0x01,0xf2,0x0b,0x2e,0x01,0xda,0x0b,0x2b,0x01,0xc2,0x0b,0x29,0x01,0xab,0x0b,0x27,0x01,0x94,0x0b,0x24,0x01,0x7d,0x0b,0x22,0x01,0x66,0x0b,0x1f,0x01,0x4f,0x0b,0x1d,0x01,0x38,0x0b,0x1a,0x01,0x21,0x0b,0x18,0x01,0x0a,0x0b,0x15,0x01,0xf4,0x0a,0x13,0x01,  \
    0xde,0x0a,0x10,0x01,0xc7,0x0a,0x0e,0x01,0xb1,0x0a,0x0b,0x01,0x9b,0x0a,0x08,0x01,0x85,0x0a,0x06,0x01,0x6f,0x0a,0x03,0x01,0x59,0x0a,0x01,0x01,0x44,0x0a,0xfe,0x00,0x2e,0x0a,0xfb,0x00,0x18,0x0a,0xf9,0x00,0x03,0x0a,0xf6,0x00,0xee,0x09,0xf4,0x00,0xd8,0x09,0xf1,0x00,0xc3,0x09,0xee,0x00,0xae,0x09,0xec,0x00,0x99,0x09,0xe9,0x00,0x85,0x09,0xe6,0x00,0x70,0x09,0xe4,0x00,0x5b,0x09,0xe1,0x00,0x47,0x09,0xde,0x00,0x32,0x09,0xdc,0x00,0x1e,0x09,0xd9,0x00,0x0a,0x09,  \
    0xd6,0x00,0xf6,0x08,0xd4,0x00,0xe2,0x08,0xd1,0x00,0xce,0x08,0xce,0x00,0xba,0x08,0xcc,0x00,0xa7,0x08,0xc9,0x00,0x93,0x08,0xc6,0x00,0x7f,0x08,0xc4,0x00,0x6c,0x08,0xc1,0x00,0x59,0x08,0xbe,0x00,0x46,0x08,0xbc,0x00,0x32,0x08,0xb9,0x00,0x1f,0x08,0xb6,0x00,0x0c,0x08,0xb3,0x00,0xfa,0x07,0xb1,0x00,0xe7,0x07,0xae,0x00,0xd4,0x07,0xab,0x00,0xc2,0x07,0xa9,0x00,0xaf,0x07,0xa6,0x00,0x9d,0x07,0xa3,0x00,0x8b,0x07,0xa1,0x00,0x79,0x07,0x9e,0x00,0x67,0x07,0x9b,0x00,  \
    0x55,0x07,0x99,0x00,0x43,0x07,0x96,0x00,0x32,0x07,0x93,0x00,0x20,0x07,0x91,0x00,0x0f,0x07,0x8e,0x00,0xfd,0x06,0x8c,0x00,0xec,0x06,0x89,0x00,0xdb,0x06,0x86,0x00,0xca,0x06,0x84,0x00,0xb8,0x06,0x81,0x00,0xa7,0x06,0x7e,0x00,0x97,0x06,0x7c,0x00,0x86,0x06,0x79,0x00,0x75,0x06,0x77,0x00,0x64,0x06,0x74,0x00,0x54,0x06,0x72,0x00,0x43,0x06,0x6f,0x00,0x33,0x06,0x6d,0x00,0x23,0x06,0x6a,0x00,0x12,0x06,0x68,0x00,0x02,0x06,0x65,0x00,0xf2,0x05,0x63,0x00,0xe2,0x05,  \
    0x60,0x00,0xd2,0x05,0x5e,0x00,0xc2,0x05,0x5b,0x00,0xb2,0x05,0x59,0x00,0xa3,0x05,0x56,0x00,0x93,0x05,0x54,0x00,0x83,0x05,0x52,0x00,0x74,0x05,0x4f,0x00,0x65,0x05,0x4d,0x00,0x55,0x05,0x4b,0x00,0x46,0x05,0x48,0x00,0x37,0x05,0x46,0x00,0x28,0x05,0x44,0x00,0x18,0x05,0x41,0x00,0x09,0x05,0x3f,0x00,0xfb,0x04,0x3d,0x00,0xec,0x04,0x3b,0x00,0xdd,0x04,0x38,0x00,0xce,0x04,0x36,0x00,0xbf,0x04,0x34,0x00,0xb1,0x04,0x32,0x00,0xa2,0x04,0x30,0x00,0x93,0x04,0x2e,0x00,  \
    0x85,0x04,0x2b,0x00,0x76,0x04,0x29,0x00,0x68,0x04,0x27,0x00,0x5a,0x04,0x25,0x00,0x4b,0x04,0x23,0x00,0x3d,0x04,0x21,0x00,0x2f,0x04,0x1f,0x00,0x21,0x04,0x1d,0x00,0x13,0x04,0x1b,0x00,0x05,0x04,0x19,0x00,0xf7,0x03,0x17,0x00,0xe9,0x03,0x15,0x00,0xdc,0x03,0x13,0x00,0xce,0x03,0x11,0x00,0xc0,0x03,0x10,0x00,0xb3,0x03,0x0e,0x00,0xa5,0x03,0x0c,0x00,0x98,0x03,0x0a,0x00,0x8a,0x03,0x08,0x00,0x7d,0x03,0x06,0x00,0x70,0x03,0x05,0x00,0x62,0x03,0x03,0x00,0x55,0x03,  \
    0x01,0x00,0x48,0x03,0xff,0xff,0x3b,0x03,0xfe,0xff,0x2e,0x03,0xfc,0xff,0x21,0x03,0xfa,0xff,0x14,0x03,0xf9,0xff,0x07,0x03,0xf7,0xff,0xfb,0x02,0xf6,0xff,0xee,0x02,0xf4,0xff,0xe1,0x02,0xf2,0xff,0xd4,0x02,0xf1,0xff,0xc8,0x02,0xef,0xff,0xbb,0x02,0xee,0xff,0xae,0x02,0xec,0xff,0xa2,0x02,0xeb,0xff,0x95,0x02,0xea,0xff,0x89,0x02,0xe8,0xff,0x7d,0x02,0xe7,0xff,0x70,0x02,0xe5,0xff,0x64,0x02,0xe4,0xff,0x58,0x02,0xe3,0xff,0x4b,0x02,0xe1,0xff,0x3f,0x02,0xe0,0xff,  \
    0x33,0x02,0xdf,0xff,0x27,0x02,0xde,0xff,0x1b,0x02,0xdc,0xff,0x0f,0x02,0xdb,0xff,0x03,0x02,0xda,0xff,0xf7,0x01,0xd9,0xff,0xeb,0x01,0xd8,0xff,0xdf,0x01,0xd7,0xff,0xd3,0x01,0xd6,0xff,0xc8,0x01,0xd5,0xff,0xbc,0x01,0xd4,0xff,0xb0,0x01,0xd2,0xff,0xa4,0x01,0xd2,0xff,0x98,0x01,0xd1,0xff,0x8d,0x01,0xd0,0xff,0x81,0x01,0xcf,0xff,0x75,0x01,0xce,0xff,0x6a,0x01,0xcd,0xff,0x5e,0x01,0xcc,0xff,0x53,0x01,0xcb,0xff,0x47,0x01,0xca,0xff,0x3b,0x01,0xca,0xff,0x30,0x01,  \
    0xc9,0xff,0x24,0x01,0xc8,0xff,0x19,0x01,0xc7,0xff,0x0d,0x01,0xc7,0xff,0x02,0x01,0xc6,0xff,0xf7,0x00,0xc5,0xff,0xeb,0x00,0xc5,0xff,0xe0,0x00,0xc4,0xff,0xd4,0x00,0xc4,0xff,0xc9,0x00,0xc3,0xff,0xbd,0x00,0xc3,0xff,0xb2,0x00,0xc2,0xff,0xa7,0x00,0xc2,0xff,0x9b,0x00,0xc1,0xff,0x90,0x00,0xc1,0xff,0x85,0x00,0xc0,0xff,0x79,0x00,0xc0,0xff,0x6e,0x00,0xc0,0xff,0x63,0x00,0xbf,0xff,0x57,0x00,0xbf,0xff,0x4c,0x00,0xbf,0xff,0x41,0x00,0xbe,0xff,0x36,0x00,0xbe,0xff,  \
    0x2a,0x00,0xbe,0xff,0x1f,0x00,0xbe,0xff,0x14,0x00,0xbe,0xff,0x09,0x00,0xbe,0xff,0xfe,0xff,0xbd,0xff,0xf2,0xff,0xbd,0xff,0xe7,0xff,0xbd,0xff,0xdc,0xff,0xbd,0xff,0xd1,0xff,0xbd,0xff,0xc5,0xff,0xbd,0xff,0xba,0xff,0xbd,0xff,0xaf,0xff,0xbd,0xff,0xa4,0xff,0xbd,0xff,0x99,0xff,0xbd,0xff,0x8d,0xff,0xbe,0xff,0x82,0xff,0xbe,0xff,0x77,0xff,0xbe,0xff,0x6c,0xff,0xbe,0xff,0x61,0xff,0xbe,0xff,0x55,0xff,0xbf,0xff,0x4a,0xff,0xbf,0xff,0x3f,0xff,0xbf,0xff,0x34,0xff,  \
    0xbf,0xff,0x28,0xff,0xc0,0xff,0x1d,0xff,0xc0,0xff,0x12,0xff,0xc1,0xff,0x07,0xff,0xc1,0xff,0xfb,0xfe,0xc1,0xff,0xf0,0xfe,0xc2,0xff,0xe5,0xfe,0xc2,0xff,0xda,0xfe,0xc3,0xff,0xce,0xfe,0xc3,0xff,0xc3,0xfe,0xc4,0xff,0xb8,0xfe,0xc4,0xff,0xac,0xfe,0xc5,0xff,0xa1,0xfe,0xc6,0xff,0x95,0xfe,0xc6,0xff,0x8a,0xfe,0xc7,0xff,0x7f,0xfe,0xc8,0xff,0x73,0xfe,0xc8,0xff,0x68,0xfe,0xc9,0xff,0x5c,0xfe,0xca,0xff,0x51,0xfe,0xcb,0xff,0x45,0xfe,0xcc,0xff,0x39,0xfe,0xcc,0xff,  \
    0x2e,0xfe,0xcd,0xff,0x22,0xfe,0xce,0xff,0x17,0xfe,0xcf,0xff,0x0b,0xfe,0xd0,0xff,0xff,0xfd,0xd1,0xff,0xf4,0xfd,0xd2,0xff,0xe8,0xfd,0xd3,0xff,0xdc,0xfd,0xd4,0xff,0xd0,0xfd,0xd5,0xff,0xc4,0xfd,0xd6,0xff,0xb9,0xfd,0xd7,0xff,0xad,0xfd,0xd8,0xff,0xa1,0xfd,0xd9,0xff,0x95,0xfd,0xda,0xff,0x89,0xfd,0xdc,0xff,0x7d,0xfd,0xdd,0xff,0x71,0xfd,0xde,0xff,0x65,0xfd,0xdf,0xff,0x59,0xfd,0xe0,0xff,0x4d,0xfd,0xe2,0xff,0x41,0xfd,0xe3,0xff,0x34,0xfd,0xe4,0xff,0x28,0xfd,  \
    0xe6,0xff,0x1c,0xfd,0xe7,0xff,0x10,0xfd,0xe9,0xff,0x04,0xfd,0xea,0xff,0xf7,0xfc,0xeb,0xff,0xeb,0xfc,0xed,0xff,0xde,0xfc,0xee,0xff,0xd2,0xfc,0xf0,0xff,0xc6,0xfc,0xf1,0xff,0xb9,0xfc,0xf3,0xff,0xac,0xfc,0xf4,0xff,0xa0,0xfc,0xf6,0xff,0x93,0xfc,0xf8,0xff,0x87,0xfc,0xf9,0xff,0x7a,0xfc,0xfb,0xff,0x6d,0xfc,0xfd,0xff,0x60,0xfc,0xfe,0xff,0x53,0xfc,0x00,0x00,0x47,0xfc,0x02,0x00,0x3a,0xfc,0x04,0x00,0x2d,0xfc,0x05,0x00,0x20,0xfc,0x07,0x00,0x12,0xfc,0x09,0x00,  \
    0x05,0xfc,0x0b,0x00,0xf8,0xfb,0x0d,0x00,0xeb,0xfb,0x0e,0x00,0xdd,0xfb,0x10,0x00,0xd0,0xfb,0x12,0x00,0xc3,0xfb,0x14,0x00,0xb5,0xfb,0x16,0x00,0xa7,0xfb,0x18,0x00,0x9a,0xfb,0x1a,0x00,0x8c,0xfb,0x1c,0x00,0x7e,0xfb,0x1e,0x00,0x71,0xfb,0x20,0x00,0x63,0xfb,0x22,0x00,0x55,0xfb,0x24,0x00,0x47,0xfb,0x26,0x00,0x39,0xfb,0x28,0x00,0x2b,0xfb,0x2a,0x00,0x1d,0xfb,0x2d,0x00,0x0e,0xfb,0x2f,0x00,0x00,0xfb,0x31,0x00,0xf2,0xfa,0x33,0x00,0xe3,0xfa,0x35,0x00,0xd5,0xfa,  \
    0x38,0x00,0xc6,0xfa,0x3a,0x00,0xb8,0xfa,0x3c,0x00,0xa9,0xfa,0x3e,0x00,0x9b,0xfa,0x41,0x00,0x8c,0xfa,0x43,0x00,0x7d,0xfa,0x45,0x00,0x6e,0xfa,0x48,0x00,0x5f,0xfa,0x4a,0x00,0x50,0xfa,0x4c,0x00,0x41,0xfa,0x4f,0x00,0x32,0xfa,0x51,0x00,0x22,0xfa,0x53,0x00,0x13,0xfa,0x56,0x00,0x04,0xfa,0x58,0x00,0xf4,0xf9,0x5b,0x00,0xe5,0xf9,0x5d,0x00,0xd5,0xf9,0x60,0x00,0xc5,0xf9,0x62,0x00,0xb6,0xf9,0x65,0x00,0xa6,0xf9,0x67,0x00,0x96,0xf9,0x6a,0x00,0x86,0xf9,0x6c,0x00,  \
    0x76,0xf9,0x6f,0x00,0x66,0xf9,0x71,0x00,0x55,0xf9,0x74,0x00,0x45,0xf9,0x76,0x00,0x35,0xf9,0x79,0x00,0x24,0xf9,0x7c,0x00,0x13,0xf9,0x7e,0x00,0x03,0xf9,0x81,0x00,0xf2,0xf8,0x83,0x00,0xe1,0xf8,0x86,0x00,0xd0,0xf8,0x89,0x00,0xbf,0xf8,0x8b,0x00,0xae,0xf8,0x8e,0x00,0x9d,0xf8,0x91,0x00,0x8b,0xf8,0x93,0x00,0x7a,0xf8,0x96,0x00,0x69,0xf8,0x99,0x00,0x57,0xf8,0x9b,0x00,0x45,0xf8,0x9e,0x00,0x34,0xf8,0xa1,0x00,0x22,0xf8,0xa3,0x00,0x10,0xf8,0xa6,0x00,0xfe,0xf7,  \
    0xa9,0x00,0xec,0xf7,0xab,0x00,0xda,0xf7,0xae,0x00,0xc7,0xf7,0xb1,0x00,0xb5,0xf7,0xb4,0x00,0xa2,0xf7,0xb6,0x00,0x90,0xf7,0xb9,0x00,0x7d,0xf7,0xbc,0x00,0x6b,0xf7,0xbf,0x00,0x58,0xf7,0xc1,0x00,0x45,0xf7,0xc4,0x00,0x32,0xf7,0xc7,0x00,0x1f,0xf7,0xc9,0x00,0x0b,0xf7,0xcc,0x00,0xf8,0xf6,0xcf,0x00,0xe4,0xf6,0xd2,0x00,0xd1,0xf6,0xd4,0x00,0xbd,0xf6,0xd7,0x00,0xaa,0xf6,0xda,0x00,0x96,0xf6,0xdd,0x00,0x82,0xf6,0xdf,0x00,0x6e,0xf6,0xe2,0x00,0x59,0xf6,0xe5,0x00,  \
    0x45,0xf6,0xe7,0x00,0x31,0xf6,0xea,0x00,0x1c,0xf6,0xed,0x00,0x07,0xf6,0xf0,0x00,0xf3,0xf5,0xf2,0x00,0xde,0xf5,0xf5,0x00,0xc9,0xf5,0xf8,0x00,0xb4,0xf5,0xfa,0x00,0x9e,0xf5,0xfd,0x00,0x89,0xf5,0xff,0x00,0x74,0xf5,0x02,0x01,0x5e,0xf5,0x05,0x01,0x48,0xf5,0x07,0x01,0x33,0xf5,0x0a,0x01,0x1d,0xf5,0x0c,0x01,0x07,0xf5,0x0f,0x01,0xf1,0xf4,0x12,0x01,0xda,0xf4,0x14,0x01,0xc4,0xf4,0x17,0x01,0xae,0xf4,0x19,0x01,0x97,0xf4,0x1c,0x01,0x81,0xf4,0x1e,0x01,0x6a,0xf4,  \
    0x21,0x01,0x53,0xf4,0x23,0x01,0x3c,0xf4,0x26,0x01,0x25,0xf4,0x28,0x01,0x0e,0xf4,0x2a,0x01,0xf6,0xf3,0x2d,0x01,0xdf,0xf3,0x2f,0x01,0xc7,0xf3,0x32,0x01,0xb0,0xf3,0x34,0x01,0x98,0xf3,0x36,0x01,0x80,0xf3,0x39,0x01,0x68,0xf3,0x3b,0x01,0x50,0xf3,0x3d,0x01,0x37,0xf3,0x3f,0x01,0x1f,0xf3,0x41,0x01,0x06,0xf3,0x44,0x01,0xee,0xf2,0x46,0x01,0xd5,0xf2,0x48,0x01,0xbc,0xf2,0x4a,0x01,0xa3,0xf2,0x4c,0x01,0x8a,0xf2,0x4e,0x01,0x71,0xf2,0x50,0x01,0x57,0xf2,0x52,0x01,  \
    0x3e,0xf2,0x54,0x01,0x24,0xf2,0x56,0x01,0x0a,0xf2,0x58,0x01,0xf0,0xf1,0x5a,0x01,0xd6,0xf1,0x5c,0x01,0xbc,0xf1,0x5d,0x01,0xa2,0xf1,0x5f,0x01,0x87,0xf1,0x61,0x01,0x6d,0xf1,0x63,0x01,0x52,0xf1,0x64,0x01,0x37,0xf1,0x66,0x01,0x1c,0xf1,0x68,0x01,0x01,0xf1,0x69,0x01,0xe6,0xf0,0x6b,0x01,0xcb,0xf0,0x6c,0x01,0xaf,0xf0,0x6d,0x01,0x93,0xf0,0x6f,0x01,0x78,0xf0,0x70,0x01,0x5c,0xf0,0x72,0x01,0x40,0xf0,0x73,0x01,0x23,0xf0,0x74,0x01,0x07,0xf0,0x75,0x01,0xeb,0xef,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6f,0x01,0x21,0x10,0x6e,0x01,0x04,0x10,0x6d,0x01,0xe7,0x0f,0x6c,0x01,0xcb,0x0f,0x6b,0x01,0xaf,0x0f,0x69,0x01,0x93,0x0f,0x68,0x01,0x77,0x0f,0x67,0x01,  \
    0x5b,0x0f,0x65,0x01,0x3f,0x0f,0x64,0x01,0x23,0x0f,0x63,0x01,0x08,0x0f,0x61,0x01,0xec,0x0e,0x60,0x01,0xd1,0x0e,0x5e,0x01,0xb6,0x0e,0x5d,0x01,0x9b,0x0e,0x5b,0x01,0x80,0x0e,0x59,0x01,0x65,0x0e,0x58,0x01,0x4b,0x0e,0x56,0x01,0x30,0x0e,0x54,0x01,0x16,0x0e,0x53,0x01,0xfb,0x0d,0x51,0x01,0xe1,0x0d,0x4f,0x01,0xc7,0x0d,0x4d,0x01,0xad,0x0d,0x4b,0x01,0x93,0x0d,0x49,0x01,0x7a,0x0d,0x47,0x01,0x60,0x0d,0x46,0x01,0x47,0x0d,0x44,0x01,0x2d,0x0d,0x42,0x01,0x14,0x0d,  \
    0x40,0x01,0xfb,0x0c,0x3d,0x01,0xe2,0x0c,0x3b,0x01,0xc9,0x0c,0x39,0x01,0xb0,0x0c,0x37,0x01,0x98,0x0c,0x35,0x01,0x7f,0x0c,0x33,0x01,0x67,0x0c,0x31,0x01,0x4f,0x0c,0x2f,0x01,0x36,0x0c,0x2c,0x01,0x1e,0x0c,0x2a,0x01,0x06,0x0c,0x28,0x01,0xef,0x0b,0x26,0x01,0xd7,0x0b,0x23,0x01,0xbf,0x0b,0x21,0x01,0xa8,0x0b,0x1f,0x01,0x91,0x0b,0x1c,0x01,0x7a,0x0b,0x1a,0x01,0x63,0x0b,0x18,0x01,0x4c,0x0b,0x15,0x01,0x35,0x0b,0x13,0x01,0x1e,0x0b,0x10,0x01,0x07,0x0b,0x0e,0x01,  \
    0xf1,0x0a,0x0b,0x01,0xda,0x0a,0x09,0x01,0xc4,0x0a,0x06,0x01,0xae,0x0a,0x04,0x01,0x98,0x0a,0x01,0x01,0x82,0x0a,0xff,0x00,0x6c,0x0a,0xfd,0x00,0x56,0x0a,0xfa,0x00,0x40,0x0a,0xf8,0x00,0x2b,0x0a,0xf5,0x00,0x15,0x0a,0xf2,0x00,0x00,0x0a,0xf0,0x00,0xea,0x09,0xed,0x00,0xd5,0x09,0xeb,0x00,0xc0,0x09,0xe8,0x00,0xab,0x09,0xe6,0x00,0x96,0x09,0xe3,0x00,0x81,0x09,0xe1,0x00,0x6d,0x09,0xde,0x00,0x58,0x09,0xdc,0x00,0x44,0x09,0xd9,0x00,0x2f,0x09,0xd6,0x00,0x1b,0x09,  \
    0xd4,0x00,0x07,0x09,0xd1,0x00,0xf3,0x08,0xcf,0x00,0xdf,0x08,0xcc,0x00,0xcb,0x08,0xc9,0x00,0xb7,0x08,0xc7,0x00,0xa3,0x08,0xc4,0x00,0x90,0x08,0xc2,0x00,0x7c,0x08,0xbf,0x00,0x69,0x08,0xbc,0x00,0x55,0x08,0xba,0x00,0x42,0x08,0xb7,0x00,0x2f,0x08,0xb5,0x00,0x1c,0x08,0xb2,0x00,0x09,0x08,0xaf,0x00,0xf6,0x07,0xad,0x00,0xe4,0x07,0xaa,0x00,0xd1,0x07,0xa8,0x00,0xbe,0x07,0xa5,0x00,0xac,0x07,0xa3,0x00,0x9a,0x07,0xa0,0x00,0x88,0x07,0x9d,0x00,0x76,0x07,0x9b,0x00,  \
    0x64,0x07,0x98,0x00,0x52,0x07,0x96,0x00,0x40,0x07,0x93,0x00,0x2e,0x07,0x91,0x00,0x1d,0x07,0x8e,0x00,0x0b,0x07,0x8b,0x00,0xfa,0x06,0x89,0x00,0xe8,0x06,0x86,0x00,0xd7,0x06,0x84,0x00,0xc6,0x06,0x81,0x00,0xb5,0x06,0x7f,0x00,0xa4,0x06,0x7c,0x00,0x93,0x06,0x7a,0x00,0x82,0x06,0x77,0x00,0x72,0x06,0x75,0x00,0x61,0x06,0x72,0x00,0x50,0x06,0x70,0x00,0x40,0x06,0x6d,0x00,0x2f,0x06,0x6b,0x00,0x1f,0x06,0x69,0x00,0x0f,0x06,0x66,0x00,0xff,0x05,0x64,0x00,0xef,0x05,  \
    0x61,0x00,0xdf,0x05,0x5f,0x00,0xcf,0x05,0x5d,0x00,0xbf,0x05,0x5a,0x00,0xaf,0x05,0x58,0x00,0x9f,0x05,0x56,0x00,0x90,0x05,0x53,0x00,0x80,0x05,0x51,0x00,0x71,0x05,0x4f,0x00,0x61,0x05,0x4c,0x00,0x52,0x05,0x4a,0x00,0x43,0x05,0x48,0x00,0x33,0x05,0x46,0x00,0x24,0x05,0x43,0x00,0x15,0x05,0x41,0x00,0x06,0x05,0x3f,0x00,0xf7,0x04,0x3d,0x00,0xe8,0x04,0x3b,0x00,0xd9,0x04,0x38,0x00,0xcb,0x04,0x36,0x00,0xbc,0x04,0x34,0x00,0xad,0x04,0x32,0x00,0x9f,0x04,0x30,0x00,  \
    0x90,0x04,0x2e,0x00,0x82,0x04,0x2c,0x00,0x73,0x04,0x2a,0x00,0x65,0x04,0x28,0x00,0x57,0x04,0x26,0x00,0x48,0x04,0x24,0x00,0x3a,0x04,0x22,0x00,0x2c,0x04,0x20,0x00,0x1e,0x04,0x1e,0x00,0x10,0x04,0x1c,0x00,0x02,0x04,0x1a,0x00,0xf4,0x03,0x18,0x00,0xe6,0x03,0x16,0x00,0xd9,0x03,0x15,0x00,0xcb,0x03,0x13,0x00,0xbd,0x03,0x11,0x00,0xb0,0x03,0x0f,0x00,0xa2,0x03,0x0d,0x00,0x95,0x03,0x0c,0x00,0x87,0x03,0x0a,0x00,0x7a,0x03,0x08,0x00,0x6d,0x03,0x06,0x00,0x60,0x03,  \
    0x05,0x00,0x53,0x03,0x03,0x00,0x45,0x03,0x01,0x00,0x38,0x03,0x00,0x00,0x2b,0x03,0xfe,0xff,0x1f,0x03,0xfc,0xff,0x12,0x03,0xfb,0xff,0x05,0x03,0xf9,0xff,0xf8,0x02,0xf8,0xff,0xeb,0x02,0xf6,0xff,0xde,0x02,0xf5,0xff,0xd2,0x02,0xf3,0xff,0xc5,0x02,0xf2,0xff,0xb9,0x02,0xf0,0xff,0xac,0x02,0xef,0xff,0xa0,0x02,0xee,0xff,0x93,0x02,0xec,0xff,0x87,0x02,0xeb,0xff,0x7a,0x02,0xe9,0xff,0x6e,0x02,0xe8,0xff,0x62,0x02,0xe7,0xff,0x55,0x02,0xe6,0xff,0x49,0x02,0xe4,0xff,  \
    0x3d,0x02,0xe3,0xff,0x31,0x02,0xe2,0xff,0x25,0x02,0xe1,0xff,0x19,0x02,0xdf,0xff,0x0d,0x02,0xde,0xff,0x01,0x02,0xdd,0xff,0xf5,0x01,0xdc,0xff,0xe9,0x01,0xdb,0xff,0xdd,0x01,0xda,0xff,0xd2,0x01,0xd9,0xff,0xc6,0x01,0xd8,0xff,0xba,0x01,0xd7,0xff,0xae,0x01,0xd6,0xff,0xa2,0x01,0xd5,0xff,0x97,0x01,0xd4,0xff,0x8b,0x01,0xd3,0xff,0x7f,0x01,0xd2,0xff,0x74,0x01,0xd1,0xff,0x68,0x01,0xd0,0xff,0x5d,0x01,0xd0,0xff,0x51,0x01,0xcf,0xff,0x46,0x01,0xce,0xff,0x3a,0x01,  \
    0xcd,0xff,0x2f,0x01,0xcd,0xff,0x23,0x01,0xcc,0xff,0x18,0x01,0xcb,0xff,0x0c,0x01,0xca,0xff,0x01,0x01,0xca,0xff,0xf5,0x00,0xc9,0xff,0xea,0x00,0xc9,0xff,0xdf,0x00,0xc8,0xff,0xd3,0x00,0xc8,0xff,0xc8,0x00,0xc7,0xff,0xbc,0x00,0xc6,0xff,0xb1,0x00,0xc6,0xff,0xa6,0x00,0xc6,0xff,0x9a,0x00,0xc5,0xff,0x8f,0x00,0xc5,0xff,0x84,0x00,0xc4,0xff,0x79,0x00,0xc4,0xff,0x6d,0x00,0xc4,0xff,0x62,0x00,0xc3,0xff,0x57,0x00,0xc3,0xff,0x4c,0x00,0xc3,0xff,0x40,0x00,0xc2,0xff,  \
    0x35,0x00,0xc2,0xff,0x2a,0x00,0xc2,0xff,0x1f,0x00,0xc2,0xff,0x14,0x00,0xc2,0xff,0x08,0x00,0xc2,0xff,0xfd,0xff,0xc1,0xff,0xf2,0xff,0xc1,0xff,0xe7,0xff,0xc1,0xff,0xdc,0xff,0xc1,0xff,0xd1,0xff,0xc1,0xff,0xc5,0xff,0xc1,0xff,0xba,0xff,0xc1,0xff,0xaf,0xff,0xc1,0xff,0xa4,0xff,0xc1,0xff,0x99,0xff,0xc1,0xff,0x8e,0xff,0xc2,0xff,0x83,0xff,0xc2,0xff,0x77,0xff,0xc2,0xff,0x6c,0xff,0xc2,0xff,0x61,0xff,0xc2,0xff,0x56,0xff,0xc3,0xff,0x4b,0xff,0xc3,0xff,0x3f,0xff,  \
    0xc3,0xff,0x34,0xff,0xc3,0xff,0x29,0xff,0xc4,0xff,0x1e,0xff,0xc4,0xff,0x13,0xff,0xc4,0xff,0x07,0xff,0xc5,0xff,0xfc,0xfe,0xc5,0xff,0xf1,0xfe,0xc6,0xff,0xe6,0xfe,0xc6,0xff,0xda,0xfe,0xc7,0xff,0xcf,0xfe,0xc7,0xff,0xc4,0xfe,0xc8,0xff,0xb9,0xfe,0xc8,0xff,0xad,0xfe,0xc9,0xff,0xa2,0xfe,0xc9,0xff,0x97,0xfe,0xca,0xff,0x8b,0xfe,0xcb,0xff,0x80,0xfe,0xcb,0xff,0x74,0xfe,0xcc,0xff,0x69,0xfe,0xcd,0xff,0x5d,0xfe,0xce,0xff,0x52,0xfe,0xce,0xff,0x46,0xfe,0xcf,0xff,  \
    0x3b,0xfe,0xd0,0xff,0x2f,0xfe,0xd1,0xff,0x24,0xfe,0xd2,0xff,0x18,0xfe,0xd2,0xff,0x0d,0xfe,0xd3,0xff,0x01,0xfe,0xd4,0xff,0xf5,0xfd,0xd5,0xff,0xea,0xfd,0xd6,0xff,0xde,0xfd,0xd7,0xff,0xd2,0xfd,0xd8,0xff,0xc6,0xfd,0xd9,0xff,0xbb,0xfd,0xda,0xff,0xaf,0xfd,0xdb,0xff,0xa3,0xfd,0xdc,0xff,0x97,0xfd,0xdd,0xff,0x8b,0xfd,0xdf,0xff,0x7f,0xfd,0xe0,0xff,0x73,0xfd,0xe1,0xff,0x67,0xfd,0xe2,0xff,0x5b,0xfd,0xe3,0xff,0x4f,0xfd,0xe5,0xff,0x43,0xfd,0xe6,0xff,0x37,0xfd,  \
    0xe7,0xff,0x2b,0xfd,0xe8,0xff,0x1e,0xfd,0xea,0xff,0x12,0xfd,0xeb,0xff,0x06,0xfd,0xed,0xff,0xfa,0xfc,0xee,0xff,0xed,0xfc,0xef,0xff,0xe1,0xfc,0xf1,0xff,0xd5,0xfc,0xf2,0xff,0xc8,0xfc,0xf4,0xff,0xbc,0xfc,0xf5,0xff,0xaf,0xfc,0xf7,0xff,0xa3,0xfc,0xf8,0xff,0x96,0xfc,0xfa,0xff,0x89,0xfc,0xfb,0xff,0x7d,0xfc,0xfd,0xff,0x70,0xfc,0xff,0xff,0x63,0xfc,0x00,0x00,0x56,0xfc,0x02,0x00,0x49,0xfc,0x04,0x00,0x3c,0xfc,0x05,0x00,0x30,0xfc,0x07,0x00,0x22,0xfc,0x09,0x00,  \
    0x15,0xfc,0x0a,0x00,0x08,0xfc,0x0c,0x00,0xfb,0xfb,0x0e,0x00,0xee,0xfb,0x10,0x00,0xe0,0xfb,0x12,0x00,0xd3,0xfb,0x13,0x00,0xc6,0xfb,0x15,0x00,0xb8,0xfb,0x17,0x00,0xab,0xfb,0x19,0x00,0x9d,0xfb,0x1b,0x00,0x8f,0xfb,0x1d,0x00,0x82,0xfb,0x1f,0x00,0x74,0xfb,0x21,0x00,0x66,0xfb,0x23,0x00,0x58,0xfb,0x25,0x00,0x4a,0xfb,0x27,0x00,0x3c,0xfb,0x29,0x00,0x2e,0xfb,0x2b,0x00,0x20,0xfb,0x2d,0x00,0x12,0xfb,0x2f,0x00,0x04,0xfb,0x31,0x00,0xf5,0xfa,0x33,0x00,0xe7,0xfa,  \
    0x35,0x00,0xd8,0xfa,0x38,0x00,0xca,0xfa,0x3a,0x00,0xbb,0xfa,0x3c,0x00,0xad,0xfa,0x3e,0x00,0x9e,0xfa,0x40,0x00,0x8f,0xfa,0x43,0x00,0x80,0xfa,0x45,0x00,0x72,0xfa,0x47,0x00,0x63,0xfa,0x49,0x00,0x54,0xfa,0x4c,0x00,0x44,0xfa,0x4e,0x00,0x35,0xfa,0x50,0x00,0x26,0xfa,0x52,0x00,0x17,0xfa,0x55,0x00,0x07,0xfa,0x57,0x00,0xf8,0xf9,0x5a,0x00,0xe8,0xf9,0x5c,0x00,0xd9,0xf9,0x5e,0x00,0xc9,0xf9,0x61,0x00,0xb9,0xf9,0x63,0x00,0xa9,0xf9,0x66,0x00,0x99,0xf9,0x68,0x00,  \
    0x89,0xf9,0x6a,0x00,0x79,0xf9,0x6d,0x00,0x69,0xf9,0x6f,0x00,0x59,0xf9,0x72,0x00,0x49,0xf9,0x74,0x00,0x38,0xf9,0x77,0x00,0x28,0xf9,0x79,0x00,0x17,0xf9,0x7c,0x00,0x06,0xf9,0x7e,0x00,0xf6,0xf8,0x81,0x00,0xe5,0xf8,0x83,0x00,0xd4,0xf8,0x86,0x00,0xc3,0xf8,0x88,0x00,0xb2,0xf8,0x8b,0x00,0xa0,0xf8,0x8e,0x00,0x8f,0xf8,0x90,0x00,0x7e,0xf8,0x93,0x00,0x6c,0xf8,0x95,0x00,0x5b,0xf8,0x98,0x00,0x49,0xf8,0x9a,0x00,0x37,0xf8,0x9d,0x00,0x25,0xf8,0xa0,0x00,0x14,0xf8,  \
    0xa2,0x00,0x02,0xf8,0xa5,0x00,0xef,0xf7,0xa7,0x00,0xdd,0xf7,0xaa,0x00,0xcb,0xf7,0xad,0x00,0xb9,0xf7,0xaf,0x00,0xa6,0xf7,0xb2,0x00,0x94,0xf7,0xb5,0x00,0x81,0xf7,0xb7,0x00,0x6e,0xf7,0xba,0x00,0x5b,0xf7,0xbd,0x00,0x48,0xf7,0xbf,0x00,0x35,0xf7,0xc2,0x00,0x22,0xf7,0xc4,0x00,0x0f,0xf7,0xc7,0x00,0xfb,0xf6,0xca,0x00,0xe8,0xf6,0xcc,0x00,0xd4,0xf6,0xcf,0x00,0xc1,0xf6,0xd2,0x00,0xad,0xf6,0xd4,0x00,0x99,0xf6,0xd7,0x00,0x85,0xf6,0xda,0x00,0x71,0xf6,0xdc,0x00,  \
    0x5d,0xf6,0xdf,0x00,0x49,0xf6,0xe1,0x00,0x34,0xf6,0xe4,0x00,0x1f,0xf6,0xe7,0x00,0x0b,0xf6,0xe9,0x00,0xf6,0xf5,0xec,0x00,0xe1,0xf5,0xee,0x00,0xcc,0xf5,0xf1,0x00,0xb7,0xf5,0xf3,0x00,0xa2,0xf5,0xf6,0x00,0x8c,0xf5,0xf9,0x00,0x77,0xf5,0xfb,0x00,0x61,0xf5,0xfe,0x00,0x4c,0xf5,0x00,0x01,0x36,0xf5,0x03,0x01,0x20,0xf5,0x05,0x01,0x0a,0xf5,0x08,0x01,0xf4,0xf4,0x0a,0x01,0xde,0xf4,0x0c,0x01,0xc7,0xf4,0x0f,0x01,0xb1,0xf4,0x11,0x01,0x9a,0xf4,0x14,0x01,0x84,0xf4,  \
    0x16,0x01,0x6d,0xf4,0x19,0x01,0x56,0xf4,0x1b,0x01,0x3f,0xf4,0x1d,0x01,0x28,0xf4,0x20,0x01,0x11,0xf4,0x22,0x01,0xf9,0xf3,0x24,0x01,0xe2,0xf3,0x27,0x01,0xca,0xf3,0x29,0x01,0xb3,0xf3,0x2b,0x01,0x9b,0xf3,0x2d,0x01,0x83,0xf3,0x30,0x01,0x6b,0xf3,0x32,0x01,0x53,0xf3,0x34,0x01,0x3a,0xf3,0x36,0x01,0x22,0xf3,0x38,0x01,0x09,0xf3,0x3a,0x01,0xf1,0xf2,0x3c,0x01,0xd8,0xf2,0x3e,0x01,0xbf,0xf2,0x40,0x01,0xa6,0xf2,0x42,0x01,0x8d,0xf2,0x44,0x01,0x74,0xf2,0x46,0x01,  \
    0x5a,0xf2,0x48,0x01,0x41,0xf2,0x4a,0x01,0x27,0xf2,0x4c,0x01,0x0d,0xf2,0x4e,0x01,0xf3,0xf1,0x50,0x01,0xd9,0xf1,0x51,0x01,0xbf,0xf1,0x53,0x01,0xa5,0xf1,0x55,0x01,0x8a,0xf1,0x56,0x01,0x70,0xf1,0x58,0x01,0x55,0xf1,0x5a,0x01,0x3a,0xf1,0x5b,0x01,0x1f,0xf1,0x5d,0x01,0x04,0xf1,0x5e,0x01,0xe9,0xf0,0x60,0x01,0xcd,0xf0,0x61,0x01,0xb2,0xf0,0x63,0x01,0x96,0xf0,0x64,0x01,0x7a,0xf0,0x65,0x01,0x5e,0xf0,0x66,0x01,0x42,0xf0,0x68,0x01,0x26,0xf0,0x69,0x01,0x0a,0xf0,  \
    0x6a,0x01,0xed,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x64,0x01,0x1e,0x10,0x63,0x01,0x01,0x10,0x62,0x01,0xe5,0x0f,0x61,0x01,0xc9,0x0f,0x60,0x01,0xac,0x0f,0x5f,0x01,0x90,0x0f,0x5d,0x01,  \
    0x74,0x0f,0x5c,0x01,0x58,0x0f,0x5b,0x01,0x3c,0x0f,0x5a,0x01,0x21,0x0f,0x58,0x01,0x05,0x0f,0x57,0x01,0xea,0x0e,0x55,0x01,0xcf,0x0e,0x54,0x01,0xb3,0x0e,0x52,0x01,0x98,0x0e,0x51,0x01,0x7d,0x0e,0x4f,0x01,0x63,0x0e,0x4e,0x01,0x48,0x0e,0x4c,0x01,0x2d,0x0e,0x4a,0x01,0x13,0x0e,0x49,0x01,0xf9,0x0d,0x47,0x01,0xde,0x0d,0x45,0x01,0xc4,0x0d,0x43,0x01,0xaa,0x0d,0x42,0x01,0x91,0x0d,0x40,0x01,0x77,0x0d,0x3e,0x01,0x5d,0x0d,0x3c,0x01,0x44,0x0d,0x3a,0x01,0x2b,0x0d,  \
    0x38,0x01,0x11,0x0d,0x36,0x01,0xf8,0x0c,0x34,0x01,0xdf,0x0c,0x32,0x01,0xc6,0x0c,0x30,0x01,0xae,0x0c,0x2e,0x01,0x95,0x0c,0x2c,0x01,0x7c,0x0c,0x2a,0x01,0x64,0x0c,0x28,0x01,0x4c,0x0c,0x26,0x01,0x34,0x0c,0x24,0x01,0x1c,0x0c,0x22,0x01,0x04,0x0c,0x20,0x01,0xec,0x0b,0x1d,0x01,0xd4,0x0b,0x1b,0x01,0xbd,0x0b,0x19,0x01,0xa5,0x0b,0x17,0x01,0x8e,0x0b,0x14,0x01,0x77,0x0b,0x12,0x01,0x60,0x0b,0x10,0x01,0x49,0x0b,0x0e,0x01,0x32,0x0b,0x0b,0x01,0x1b,0x0b,0x09,0x01,  \
    0x04,0x0b,0x07,0x01,0xee,0x0a,0x04,0x01,0xd7,0x0a,0x02,0x01,0xc1,0x0a,0xff,0x00,0xab,0x0a,0xfd,0x00,0x95,0x0a,0xfb,0x00,0x7f,0x0a,0xf8,0x00,0x69,0x0a,0xf6,0x00,0x53,0x0a,0xf3,0x00,0x3d,0x0a,0xf1,0x00,0x28,0x0a,0xef,0x00,0x12,0x0a,0xec,0x00,0xfd,0x09,0xea,0x00,0xe7,0x09,0xe7,0x00,0xd2,0x09,0xe5,0x00,0xbd,0x09,0xe2,0x00,0xa8,0x09,0xe0,0x00,0x93,0x09,0xdd,0x00,0x7e,0x09,0xdb,0x00,0x69,0x09,0xd8,0x00,0x55,0x09,0xd6,0x00,0x40,0x09,0xd4,0x00,0x2c,0x09,  \
    0xd1,0x00,0x18,0x09,0xcf,0x00,0x03,0x09,0xcc,0x00,0xef,0x08,0xca,0x00,0xdb,0x08,0xc7,0x00,0xc7,0x08,0xc5,0x00,0xb4,0x08,0xc2,0x00,0xa0,0x08,0xc0,0x00,0x8c,0x08,0xbd,0x00,0x79,0x08,0xbb,0x00,0x65,0x08,0xb8,0x00,0x52,0x08,0xb6,0x00,0x3f,0x08,0xb3,0x00,0x2c,0x08,0xb1,0x00,0x19,0x08,0xae,0x00,0x06,0x08,0xac,0x00,0xf3,0x07,0xa9,0x00,0xe0,0x07,0xa7,0x00,0xce,0x07,0xa4,0x00,0xbb,0x07,0xa2,0x00,0xa9,0x07,0x9f,0x00,0x96,0x07,0x9d,0x00,0x84,0x07,0x9a,0x00,  \
    0x72,0x07,0x98,0x00,0x60,0x07,0x95,0x00,0x4e,0x07,0x93,0x00,0x3d,0x07,0x90,0x00,0x2b,0x07,0x8e,0x00,0x19,0x07,0x8b,0x00,0x08,0x07,0x89,0x00,0xf6,0x06,0x86,0x00,0xe5,0x06,0x84,0x00,0xd4,0x06,0x81,0x00,0xc3,0x06,0x7f,0x00,0xb2,0x06,0x7c,0x00,0xa1,0x06,0x7a,0x00,0x90,0x06,0x78,0x00,0x7f,0x06,0x75,0x00,0x6e,0x06,0x73,0x00,0x5e,0x06,0x71,0x00,0x4d,0x06,0x6e,0x00,0x3d,0x06,0x6c,0x00,0x2c,0x06,0x69,0x00,0x1c,0x06,0x67,0x00,0x0c,0x06,0x65,0x00,0xfb,0x05,  \
    0x62,0x00,0xeb,0x05,0x60,0x00,0xdb,0x05,0x5e,0x00,0xcb,0x05,0x5c,0x00,0xbb,0x05,0x59,0x00,0xac,0x05,0x57,0x00,0x9c,0x05,0x55,0x00,0x8c,0x05,0x52,0x00,0x7d,0x05,0x50,0x00,0x6d,0x05,0x4e,0x00,0x5e,0x05,0x4c,0x00,0x4e,0x05,0x4a,0x00,0x3f,0x05,0x47,0x00,0x30,0x05,0x45,0x00,0x21,0x05,0x43,0x00,0x12,0x05,0x41,0x00,0x03,0x05,0x3f,0x00,0xf4,0x04,0x3d,0x00,0xe5,0x04,0x3b,0x00,0xd6,0x04,0x39,0x00,0xc7,0x04,0x37,0x00,0xb9,0x04,0x35,0x00,0xaa,0x04,0x33,0x00,  \
    0x9b,0x04,0x30,0x00,0x8d,0x04,0x2e,0x00,0x7e,0x04,0x2d,0x00,0x70,0x04,0x2b,0x00,0x62,0x04,0x29,0x00,0x53,0x04,0x27,0x00,0x45,0x04,0x25,0x00,0x37,0x04,0x23,0x00,0x29,0x04,0x21,0x00,0x1b,0x04,0x1f,0x00,0x0d,0x04,0x1d,0x00,0xff,0x03,0x1b,0x00,0xf1,0x03,0x1a,0x00,0xe4,0x03,0x18,0x00,0xd6,0x03,0x16,0x00,0xc8,0x03,0x14,0x00,0xbb,0x03,0x12,0x00,0xad,0x03,0x11,0x00,0x9f,0x03,0x0f,0x00,0x92,0x03,0x0d,0x00,0x85,0x03,0x0b,0x00,0x77,0x03,0x0a,0x00,0x6a,0x03,  \
    0x08,0x00,0x5d,0x03,0x07,0x00,0x50,0x03,0x05,0x00,0x43,0x03,0x03,0x00,0x36,0x03,0x02,0x00,0x29,0x03,0x00,0x00,0x1c,0x03,0xff,0xff,0x0f,0x03,0xfd,0xff,0x02,0x03,0xfc,0xff,0xf5,0x02,0xfa,0xff,0xe9,0x02,0xf9,0xff,0xdc,0x02,0xf7,0xff,0xcf,0x02,0xf6,0xff,0xc3,0x02,0xf4,0xff,0xb6,0x02,0xf3,0xff,0xaa,0x02,0xf2,0xff,0x9d,0x02,0xf0,0xff,0x91,0x02,0xef,0xff,0x85,0x02,0xee,0xff,0x78,0x02,0xec,0xff,0x6c,0x02,0xeb,0xff,0x60,0x02,0xea,0xff,0x53,0x02,0xe8,0xff,  \
    0x47,0x02,0xe7,0xff,0x3b,0x02,0xe6,0xff,0x2f,0x02,0xe5,0xff,0x23,0x02,0xe4,0xff,0x17,0x02,0xe3,0xff,0x0b,0x02,0xe1,0xff,0xff,0x01,0xe0,0xff,0xf3,0x01,0xdf,0xff,0xe7,0x01,0xde,0xff,0xdc,0x01,0xdd,0xff,0xd0,0x01,0xdc,0xff,0xc4,0x01,0xdb,0xff,0xb8,0x01,0xda,0xff,0xac,0x01,0xd9,0xff,0xa1,0x01,0xd8,0xff,0x95,0x01,0xd7,0xff,0x8a,0x01,0xd7,0xff,0x7e,0x01,0xd6,0xff,0x72,0x01,0xd5,0xff,0x67,0x01,0xd4,0xff,0x5b,0x01,0xd3,0xff,0x50,0x01,0xd2,0xff,0x44,0x01,  \
    0xd2,0xff,0x39,0x01,0xd1,0xff,0x2d,0x01,0xd0,0xff,0x22,0x01,0xd0,0xff,0x16,0x01,0xcf,0xff,0x0b,0x01,0xce,0xff,0x00,0x01,0xce,0xff,0xf4,0x00,0xcd,0xff,0xe9,0x00,0xcc,0xff,0xdd,0x00,0xcc,0xff,0xd2,0x00,0xcb,0xff,0xc7,0x00,0xcb,0xff,0xbb,0x00,0xca,0xff,0xb0,0x00,0xca,0xff,0xa5,0x00,0xca,0xff,0x9a,0x00,0xc9,0xff,0x8e,0x00,0xc9,0xff,0x83,0x00,0xc8,0xff,0x78,0x00,0xc8,0xff,0x6d,0x00,0xc8,0xff,0x62,0x00,0xc7,0xff,0x56,0x00,0xc7,0xff,0x4b,0x00,0xc7,0xff,  \
    0x40,0x00,0xc7,0xff,0x35,0x00,0xc6,0xff,0x2a,0x00,0xc6,0xff,0x1e,0x00,0xc6,0xff,0x13,0x00,0xc6,0xff,0x08,0x00,0xc6,0xff,0xfd,0xff,0xc6,0xff,0xf2,0xff,0xc5,0xff,0xe7,0xff,0xc5,0xff,0xdc,0xff,0xc5,0xff,0xd1,0xff,0xc5,0xff,0xc5,0xff,0xc5,0xff,0xba,0xff,0xc5,0xff,0xaf,0xff,0xc5,0xff,0xa4,0xff,0xc5,0xff,0x99,0xff,0xc6,0xff,0x8e,0xff,0xc6,0xff,0x83,0xff,0xc6,0xff,0x78,0xff,0xc6,0xff,0x6d,0xff,0xc6,0xff,0x61,0xff,0xc6,0xff,0x56,0xff,0xc7,0xff,0x4b,0xff,  \
    0xc7,0xff,0x40,0xff,0xc7,0xff,0x35,0xff,0xc7,0xff,0x2a,0xff,0xc8,0xff,0x1e,0xff,0xc8,0xff,0x13,0xff,0xc8,0xff,0x08,0xff,0xc9,0xff,0xfd,0xfe,0xc9,0xff,0xf2,0xfe,0xca,0xff,0xe7,0xfe,0xca,0xff,0xdb,0xfe,0xcb,0xff,0xd0,0xfe,0xcb,0xff,0xc5,0xfe,0xcc,0xff,0xba,0xfe,0xcc,0xff,0xae,0xfe,0xcd,0xff,0xa3,0xfe,0xcd,0xff,0x98,0xfe,0xce,0xff,0x8c,0xfe,0xce,0xff,0x81,0xfe,0xcf,0xff,0x76,0xfe,0xd0,0xff,0x6a,0xfe,0xd0,0xff,0x5f,0xfe,0xd1,0xff,0x53,0xfe,0xd2,0xff,  \
    0x48,0xfe,0xd3,0xff,0x3c,0xfe,0xd3,0xff,0x31,0xfe,0xd4,0xff,0x25,0xfe,0xd5,0xff,0x1a,0xfe,0xd6,0xff,0x0e,0xfe,0xd7,0xff,0x03,0xfe,0xd8,0xff,0xf7,0xfd,0xd9,0xff,0xeb,0xfd,0xda,0xff,0xe0,0xfd,0xda,0xff,0xd4,0xfd,0xdb,0xff,0xc8,0xfd,0xdc,0xff,0xbc,0xfd,0xdd,0xff,0xb1,0xfd,0xde,0xff,0xa5,0xfd,0xe0,0xff,0x99,0xfd,0xe1,0xff,0x8d,0xfd,0xe2,0xff,0x81,0xfd,0xe3,0xff,0x75,0xfd,0xe4,0xff,0x69,0xfd,0xe5,0xff,0x5d,0xfd,0xe6,0xff,0x51,0xfd,0xe8,0xff,0x45,0xfd,  \
    0xe9,0xff,0x39,0xfd,0xea,0xff,0x2d,0xfd,0xeb,0xff,0x21,0xfd,0xed,0xff,0x15,0xfd,0xee,0xff,0x08,0xfd,0xef,0xff,0xfc,0xfc,0xf1,0xff,0xf0,0xfc,0xf2,0xff,0xe4,0xfc,0xf3,0xff,0xd7,0xfc,0xf5,0xff,0xcb,0xfc,0xf6,0xff,0xbe,0xfc,0xf8,0xff,0xb2,0xfc,0xf9,0xff,0xa5,0xfc,0xfa,0xff,0x99,0xfc,0xfc,0xff,0x8c,0xfc,0xfe,0xff,0x7f,0xfc,0xff,0xff,0x73,0xfc,0x01,0x00,0x66,0xfc,0x02,0x00,0x59,0xfc,0x04,0x00,0x4c,0xfc,0x05,0x00,0x3f,0xfc,0x07,0x00,0x32,0xfc,0x09,0x00,  \
    0x25,0xfc,0x0a,0x00,0x18,0xfc,0x0c,0x00,0x0b,0xfc,0x0e,0x00,0xfe,0xfb,0x10,0x00,0xf1,0xfb,0x11,0x00,0xe3,0xfb,0x13,0x00,0xd6,0xfb,0x15,0x00,0xc9,0xfb,0x17,0x00,0xbb,0xfb,0x18,0x00,0xae,0xfb,0x1a,0x00,0xa0,0xfb,0x1c,0x00,0x93,0xfb,0x1e,0x00,0x85,0xfb,0x20,0x00,0x77,0xfb,0x22,0x00,0x69,0xfb,0x24,0x00,0x5b,0xfb,0x26,0x00,0x4d,0xfb,0x28,0x00,0x3f,0xfb,0x29,0x00,0x31,0xfb,0x2b,0x00,0x23,0xfb,0x2d,0x00,0x15,0xfb,0x2f,0x00,0x07,0xfb,0x31,0x00,0xf9,0xfa,  \
    0x34,0x00,0xea,0xfa,0x36,0x00,0xdc,0xfa,0x38,0x00,0xcd,0xfa,0x3a,0x00,0xbf,0xfa,0x3c,0x00,0xb0,0xfa,0x3e,0x00,0xa1,0xfa,0x40,0x00,0x93,0xfa,0x42,0x00,0x84,0xfa,0x44,0x00,0x75,0xfa,0x47,0x00,0x66,0xfa,0x49,0x00,0x57,0xfa,0x4b,0x00,0x48,0xfa,0x4d,0x00,0x39,0xfa,0x4f,0x00,0x2a,0xfa,0x52,0x00,0x1a,0xfa,0x54,0x00,0x0b,0xfa,0x56,0x00,0xfb,0xf9,0x58,0x00,0xec,0xf9,0x5b,0x00,0xdc,0xf9,0x5d,0x00,0xcd,0xf9,0x5f,0x00,0xbd,0xf9,0x62,0x00,0xad,0xf9,0x64,0x00,  \
    0x9d,0xf9,0x66,0x00,0x8d,0xf9,0x69,0x00,0x7d,0xf9,0x6b,0x00,0x6d,0xf9,0x6d,0x00,0x5c,0xf9,0x70,0x00,0x4c,0xf9,0x72,0x00,0x3c,0xf9,0x75,0x00,0x2b,0xf9,0x77,0x00,0x1b,0xf9,0x79,0x00,0x0a,0xf9,0x7c,0x00,0xf9,0xf8,0x7e,0x00,0xe8,0xf8,0x81,0x00,0xd7,0xf8,0x83,0x00,0xc6,0xf8,0x86,0x00,0xb5,0xf8,0x88,0x00,0xa4,0xf8,0x8b,0x00,0x93,0xf8,0x8d,0x00,0x81,0xf8,0x90,0x00,0x70,0xf8,0x92,0x00,0x5e,0xf8,0x95,0x00,0x4d,0xf8,0x97,0x00,0x3b,0xf8,0x9a,0x00,0x29,0xf8,  \
    0x9c,0x00,0x17,0xf8,0x9f,0x00,0x05,0xf8,0xa1,0x00,0xf3,0xf7,0xa4,0x00,0xe1,0xf7,0xa6,0x00,0xce,0xf7,0xa9,0x00,0xbc,0xf7,0xab,0x00,0xaa,0xf7,0xae,0x00,0x97,0xf7,0xb0,0x00,0x84,0xf7,0xb3,0x00,0x72,0xf7,0xb5,0x00,0x5f,0xf7,0xb8,0x00,0x4c,0xf7,0xba,0x00,0x39,0xf7,0xbd,0x00,0x25,0xf7,0xc0,0x00,0x12,0xf7,0xc2,0x00,0xff,0xf6,0xc5,0x00,0xeb,0xf6,0xc7,0x00,0xd8,0xf6,0xca,0x00,0xc4,0xf6,0xcc,0x00,0xb0,0xf6,0xcf,0x00,0x9c,0xf6,0xd1,0x00,0x88,0xf6,0xd4,0x00,  \
    0x74,0xf6,0xd6,0x00,0x60,0xf6,0xd9,0x00,0x4c,0xf6,0xdb,0x00,0x37,0xf6,0xde,0x00,0x23,0xf6,0xe0,0x00,0x0e,0xf6,0xe3,0x00,0xf9,0xf5,0xe5,0x00,0xe4,0xf5,0xe8,0x00,0xcf,0xf5,0xea,0x00,0xba,0xf5,0xed,0x00,0xa5,0xf5,0xef,0x00,0x90,0xf5,0xf2,0x00,0x7a,0xf5,0xf4,0x00,0x65,0xf5,0xf7,0x00,0x4f,0xf5,0xf9,0x00,0x39,0xf5,0xfb,0x00,0x23,0xf5,0xfe,0x00,0x0d,0xf5,0x00,0x01,0xf7,0xf4,0x02,0x01,0xe1,0xf4,0x05,0x01,0xca,0xf4,0x07,0x01,0xb4,0xf4,0x0a,0x01,0x9e,0xf4,  \
    0x0c,0x01,0x87,0xf4,0x0e,0x01,0x70,0xf4,0x11,0x01,0x59,0xf4,0x13,0x01,0x42,0xf4,0x15,0x01,0x2b,0xf4,0x17,0x01,0x14,0xf4,0x1a,0x01,0xfd,0xf3,0x1c,0x01,0xe5,0xf3,0x1e,0x01,0xcd,0xf3,0x20,0x01,0xb6,0xf3,0x22,0x01,0x9e,0xf3,0x24,0x01,0x86,0xf3,0x27,0x01,0x6e,0xf3,0x29,0x01,0x56,0xf3,0x2b,0x01,0x3d,0xf3,0x2d,0x01,0x25,0xf3,0x2f,0x01,0x0c,0xf3,0x31,0x01,0xf4,0xf2,0x33,0x01,0xdb,0xf2,0x35,0x01,0xc2,0xf2,0x37,0x01,0xa9,0xf2,0x39,0x01,0x90,0xf2,0x3b,0x01,  \
    0x76,0xf2,0x3d,0x01,0x5d,0xf2,0x3e,0x01,0x43,0xf2,0x40,0x01,0x2a,0xf2,0x42,0x01,0x10,0xf2,0x44,0x01,0xf6,0xf1,0x45,0x01,0xdc,0xf1,0x47,0x01,0xc2,0xf1,0x49,0x01,0xa7,0xf1,0x4a,0x01,0x8d,0xf1,0x4c,0x01,0x72,0xf1,0x4e,0x01,0x57,0xf1,0x4f,0x01,0x3d,0xf1,0x51,0x01,0x22,0xf1,0x52,0x01,0x07,0xf1,0x54,0x01,0xeb,0xf0,0x55,0x01,0xd0,0xf0,0x56,0x01,0xb4,0xf0,0x58,0x01,0x99,0xf0,0x59,0x01,0x7d,0xf0,0x5a,0x01,0x61,0xf0,0x5b,0x01,0x45,0xf0,0x5d,0x01,0x29,0xf0,  \
    0x5e,0x01,0x0c,0xf0,0x5f,0x01,0xf0,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x5a,0x01,0x1c,0x10,0x59,0x01,0xff,0x0f,0x57,0x01,0xe3,0x0f,0x56,0x01,0xc6,0x0f,0x55,0x01,0xaa,0x0f,0x54,0x01,  \
    0x8e,0x0f,0x53,0x01,0x72,0x0f,0x52,0x01,0x56,0x0f,0x50,0x01,0x3a,0x0f,0x4f,0x01,0x1e,0x0f,0x4e,0x01,0x03,0x0f,0x4c,0x01,0xe7,0x0e,0x4b,0x01,0xcc,0x0e,0x4a,0x01,0xb1,0x0e,0x48,0x01,0x96,0x0e,0x47,0x01,0x7b,0x0e,0x45,0x01,0x60,0x0e,0x44,0x01,0x46,0x0e,0x42,0x01,0x2b,0x0e,0x41,0x01,0x10,0x0e,0x3f,0x01,0xf6,0x0d,0x3d,0x01,0xdc,0x0d,0x3c,0x01,0xc2,0x0d,0x3a,0x01,0xa8,0x0d,0x38,0x01,0x8e,0x0d,0x36,0x01,0x74,0x0d,0x35,0x01,0x5b,0x0d,0x33,0x01,0x41,0x0d,  \
    0x31,0x01,0x28,0x0d,0x2f,0x01,0x0f,0x0d,0x2d,0x01,0xf6,0x0c,0x2b,0x01,0xdd,0x0c,0x29,0x01,0xc4,0x0c,0x28,0x01,0xab,0x0c,0x26,0x01,0x92,0x0c,0x24,0x01,0x7a,0x0c,0x22,0x01,0x61,0x0c,0x20,0x01,0x49,0x0c,0x1e,0x01,0x31,0x0c,0x1c,0x01,0x19,0x0c,0x19,0x01,0x01,0x0c,0x17,0x01,0xe9,0x0b,0x15,0x01,0xd1,0x0b,0x13,0x01,0xba,0x0b,0x11,0x01,0xa2,0x0b,0x0f,0x01,0x8b,0x0b,0x0d,0x01,0x74,0x0b,0x0a,0x01,0x5d,0x0b,0x08,0x01,0x46,0x0b,0x06,0x01,0x2f,0x0b,0x04,0x01,  \
    0x18,0x0b,0x02,0x01,0x01,0x0b,0xff,0x00,0xeb,0x0a,0xfd,0x00,0xd4,0x0a,0xfb,0x00,0xbe,0x0a,0xf8,0x00,0xa8,0x0a,0xf6,0x00,0x92,0x0a,0xf4,0x00,0x7c,0x0a,0xf2,0x00,0x66,0x0a,0xef,0x00,0x50,0x0a,0xed,0x00,0x3a,0x0a,0xeb,0x00,0x25,0x0a,0xe8,0x00,0x0f,0x0a,0xe6,0x00,0xfa,0x09,0xe4,0x00,0xe4,0x09,0xe1,0x00,0xcf,0x09,0xdf,0x00,0xba,0x09,0xdc,0x00,0xa5,0x09,0xda,0x00,0x90,0x09,0xd8,0x00,0x7b,0x09,0xd5,0x00,0x66,0x09,0xd3,0x00,0x52,0x09,0xd1,0x00,0x3d,0x09,  \
    0xce,0x00,0x29,0x09,0xcc,0x00,0x15,0x09,0xc9,0x00,0x00,0x09,0xc7,0x00,0xec,0x08,0xc5,0x00,0xd8,0x08,0xc2,0x00,0xc4,0x08,0xc0,0x00,0xb1,0x08,0xbd,0x00,0x9d,0x08,0xbb,0x00,0x89,0x08,0xb8,0x00,0x76,0x08,0xb6,0x00,0x62,0x08,0xb4,0x00,0x4f,0x08,0xb1,0x00,0x3c,0x08,0xaf,0x00,0x29,0x08,0xac,0x00,0x16,0x08,0xaa,0x00,0x03,0x08,0xa8,0x00,0xf0,0x07,0xa5,0x00,0xdd,0x07,0xa3,0x00,0xcb,0x07,0xa0,0x00,0xb8,0x07,0x9e,0x00,0xa6,0x07,0x9c,0x00,0x93,0x07,0x99,0x00,  \
    0x81,0x07,0x97,0x00,0x6f,0x07,0x94,0x00,0x5d,0x07,0x92,0x00,0x4b,0x07,0x90,0x00,0x3a,0x07,0x8d,0x00,0x28,0x07,0x8b,0x00,0x16,0x07,0x88,0x00,0x05,0x07,0x86,0x00,0xf3,0x06,0x84,0x00,0xe2,0x06,0x81,0x00,0xd1,0x06,0x7f,0x00,0xc0,0x06,0x7d,0x00,0xaf,0x06,0x7a,0x00,0x9e,0x06,0x78,0x00,0x8d,0x06,0x76,0x00,0x7c,0x06,0x73,0x00,0x6b,0x06,0x71,0x00,0x5a,0x06,0x6f,0x00,0x4a,0x06,0x6c,0x00,0x39,0x06,0x6a,0x00,0x29,0x06,0x68,0x00,0x19,0x06,0x66,0x00,0x08,0x06,  \
    0x63,0x00,0xf8,0x05,0x61,0x00,0xe8,0x05,0x5f,0x00,0xd8,0x05,0x5d,0x00,0xc8,0x05,0x5a,0x00,0xb8,0x05,0x58,0x00,0xa8,0x05,0x56,0x00,0x99,0x05,0x54,0x00,0x89,0x05,0x52,0x00,0x7a,0x05,0x50,0x00,0x6a,0x05,0x4d,0x00,0x5b,0x05,0x4b,0x00,0x4b,0x05,0x49,0x00,0x3c,0x05,0x47,0x00,0x2d,0x05,0x45,0x00,0x1e,0x05,0x43,0x00,0x0f,0x05,0x41,0x00,0x00,0x05,0x3f,0x00,0xf1,0x04,0x3d,0x00,0xe2,0x04,0x3b,0x00,0xd3,0x04,0x39,0x00,0xc4,0x04,0x37,0x00,0xb6,0x04,0x35,0x00,  \
    0xa7,0x04,0x33,0x00,0x98,0x04,0x31,0x00,0x8a,0x04,0x2f,0x00,0x7b,0x04,0x2d,0x00,0x6d,0x04,0x2b,0x00,0x5f,0x04,0x29,0x00,0x51,0x04,0x27,0x00,0x42,0x04,0x26,0x00,0x34,0x04,0x24,0x00,0x26,0x04,0x22,0x00,0x18,0x04,0x20,0x00,0x0a,0x04,0x1e,0x00,0xfc,0x03,0x1d,0x00,0xef,0x03,0x1b,0x00,0xe1,0x03,0x19,0x00,0xd3,0x03,0x17,0x00,0xc5,0x03,0x16,0x00,0xb8,0x03,0x14,0x00,0xaa,0x03,0x12,0x00,0x9d,0x03,0x11,0x00,0x8f,0x03,0x0f,0x00,0x82,0x03,0x0d,0x00,0x75,0x03,  \
    0x0c,0x00,0x68,0x03,0x0a,0x00,0x5b,0x03,0x08,0x00,0x4d,0x03,0x07,0x00,0x40,0x03,0x05,0x00,0x33,0x03,0x04,0x00,0x26,0x03,0x02,0x00,0x1a,0x03,0x01,0x00,0x0d,0x03,0xff,0xff,0x00,0x03,0xfe,0xff,0xf3,0x02,0xfc,0xff,0xe6,0x02,0xfb,0xff,0xda,0x02,0xfa,0xff,0xcd,0x02,0xf8,0xff,0xc1,0x02,0xf7,0xff,0xb4,0x02,0xf6,0xff,0xa8,0x02,0xf4,0xff,0x9b,0x02,0xf3,0xff,0x8f,0x02,0xf2,0xff,0x82,0x02,0xf0,0xff,0x76,0x02,0xef,0xff,0x6a,0x02,0xee,0xff,0x5e,0x02,0xed,0xff,  \
    0x51,0x02,0xeb,0xff,0x45,0x02,0xea,0xff,0x39,0x02,0xe9,0xff,0x2d,0x02,0xe8,0xff,0x21,0x02,0xe7,0xff,0x15,0x02,0xe6,0xff,0x09,0x02,0xe5,0xff,0xfd,0x01,0xe4,0xff,0xf1,0x01,0xe3,0xff,0xe6,0x01,0xe2,0xff,0xda,0x01,0xe1,0xff,0xce,0x01,0xe0,0xff,0xc2,0x01,0xdf,0xff,0xb7,0x01,0xde,0xff,0xab,0x01,0xdd,0xff,0x9f,0x01,0xdc,0xff,0x94,0x01,0xdb,0xff,0x88,0x01,0xda,0xff,0x7c,0x01,0xd9,0xff,0x71,0x01,0xd9,0xff,0x65,0x01,0xd8,0xff,0x5a,0x01,0xd7,0xff,0x4e,0x01,  \
    0xd6,0xff,0x43,0x01,0xd6,0xff,0x37,0x01,0xd5,0xff,0x2c,0x01,0xd4,0xff,0x21,0x01,0xd3,0xff,0x15,0x01,0xd3,0xff,0x0a,0x01,0xd2,0xff,0xfe,0x00,0xd2,0xff,0xf3,0x00,0xd1,0xff,0xe8,0x00,0xd0,0xff,0xdc,0x00,0xd0,0xff,0xd1,0x00,0xcf,0xff,0xc6,0x00,0xcf,0xff,0xbb,0x00,0xce,0xff,0xaf,0x00,0xce,0xff,0xa4,0x00,0xce,0xff,0x99,0x00,0xcd,0xff,0x8e,0x00,0xcd,0xff,0x82,0x00,0xcc,0xff,0x77,0x00,0xcc,0xff,0x6c,0x00,0xcc,0xff,0x61,0x00,0xcb,0xff,0x56,0x00,0xcb,0xff,  \
    0x4b,0x00,0xcb,0xff,0x40,0x00,0xcb,0xff,0x34,0x00,0xca,0xff,0x29,0x00,0xca,0xff,0x1e,0x00,0xca,0xff,0x13,0x00,0xca,0xff,0x08,0x00,0xca,0xff,0xfd,0xff,0xca,0xff,0xf2,0xff,0xca,0xff,0xe7,0xff,0xca,0xff,0xdc,0xff,0xca,0xff,0xd1,0xff,0xca,0xff,0xc5,0xff,0xca,0xff,0xba,0xff,0xca,0xff,0xaf,0xff,0xca,0xff,0xa4,0xff,0xca,0xff,0x99,0xff,0xca,0xff,0x8e,0xff,0xca,0xff,0x83,0xff,0xca,0xff,0x78,0xff,0xca,0xff,0x6d,0xff,0xca,0xff,0x62,0xff,0xcb,0xff,0x57,0xff,  \
    0xcb,0xff,0x4c,0xff,0xcb,0xff,0x40,0xff,0xcb,0xff,0x35,0xff,0xcc,0xff,0x2a,0xff,0xcc,0xff,0x1f,0xff,0xcc,0xff,0x14,0xff,0xcd,0xff,0x09,0xff,0xcd,0xff,0xfe,0xfe,0xcd,0xff,0xf2,0xfe,0xce,0xff,0xe7,0xfe,0xce,0xff,0xdc,0xfe,0xcf,0xff,0xd1,0xfe,0xcf,0xff,0xc6,0xfe,0xd0,0xff,0xba,0xfe,0xd0,0xff,0xaf,0xfe,0xd1,0xff,0xa4,0xfe,0xd1,0xff,0x99,0xfe,0xd2,0xff,0x8d,0xfe,0xd2,0xff,0x82,0xfe,0xd3,0xff,0x77,0xfe,0xd4,0xff,0x6b,0xfe,0xd4,0xff,0x60,0xfe,0xd5,0xff,  \
    0x55,0xfe,0xd6,0xff,0x49,0xfe,0xd6,0xff,0x3e,0xfe,0xd7,0xff,0x32,0xfe,0xd8,0xff,0x27,0xfe,0xd9,0xff,0x1b,0xfe,0xda,0xff,0x10,0xfe,0xda,0xff,0x04,0xfe,0xdb,0xff,0xf9,0xfd,0xdc,0xff,0xed,0xfd,0xdd,0xff,0xe1,0xfd,0xde,0xff,0xd6,0xfd,0xdf,0xff,0xca,0xfd,0xe0,0xff,0xbe,0xfd,0xe1,0xff,0xb3,0xfd,0xe2,0xff,0xa7,0xfd,0xe3,0xff,0x9b,0xfd,0xe4,0xff,0x8f,0xfd,0xe5,0xff,0x83,0xfd,0xe6,0xff,0x77,0xfd,0xe7,0xff,0x6b,0xfd,0xe8,0xff,0x5f,0xfd,0xe9,0xff,0x53,0xfd,  \
    0xeb,0xff,0x47,0xfd,0xec,0xff,0x3b,0xfd,0xed,0xff,0x2f,0xfd,0xee,0xff,0x23,0xfd,0xef,0xff,0x17,0xfd,0xf1,0xff,0x0b,0xfd,0xf2,0xff,0xfe,0xfc,0xf3,0xff,0xf2,0xfc,0xf5,0xff,0xe6,0xfc,0xf6,0xff,0xda,0xfc,0xf7,0xff,0xcd,0xfc,0xf9,0xff,0xc1,0xfc,0xfa,0xff,0xb4,0xfc,0xfb,0xff,0xa8,0xfc,0xfd,0xff,0x9b,0xfc,0xfe,0xff,0x8f,0xfc,0x00,0x00,0x82,0xfc,0x01,0x00,0x75,0xfc,0x03,0x00,0x69,0xfc,0x04,0x00,0x5c,0xfc,0x06,0x00,0x4f,0xfc,0x07,0x00,0x42,0xfc,0x09,0x00,  \
    0x35,0xfc,0x0b,0x00,0x28,0xfc,0x0c,0x00,0x1b,0xfc,0x0e,0x00,0x0e,0xfc,0x0f,0x00,0x01,0xfc,0x11,0x00,0xf4,0xfb,0x13,0x00,0xe6,0xfb,0x14,0x00,0xd9,0xfb,0x16,0x00,0xcc,0xfb,0x18,0x00,0xbe,0xfb,0x1a,0x00,0xb1,0xfb,0x1b,0x00,0xa3,0xfb,0x1d,0x00,0x96,0xfb,0x1f,0x00,0x88,0xfb,0x21,0x00,0x7a,0xfb,0x23,0x00,0x6c,0xfb,0x25,0x00,0x5e,0xfb,0x26,0x00,0x51,0xfb,0x28,0x00,0x43,0xfb,0x2a,0x00,0x35,0xfb,0x2c,0x00,0x26,0xfb,0x2e,0x00,0x18,0xfb,0x30,0x00,0x0a,0xfb,  \
    0x32,0x00,0xfc,0xfa,0x34,0x00,0xed,0xfa,0x36,0x00,0xdf,0xfa,0x38,0x00,0xd1,0xfa,0x3a,0x00,0xc2,0xfa,0x3c,0x00,0xb3,0xfa,0x3e,0x00,0xa5,0xfa,0x40,0x00,0x96,0xfa,0x42,0x00,0x87,0xfa,0x44,0x00,0x78,0xfa,0x46,0x00,0x69,0xfa,0x48,0x00,0x5a,0xfa,0x4a,0x00,0x4b,0xfa,0x4d,0x00,0x3c,0xfa,0x4f,0x00,0x2d,0xfa,0x51,0x00,0x1e,0xfa,0x53,0x00,0x0e,0xfa,0x55,0x00,0xff,0xf9,0x57,0x00,0xef,0xf9,0x5a,0x00,0xe0,0xf9,0x5c,0x00,0xd0,0xf9,0x5e,0x00,0xc0,0xf9,0x60,0x00,  \
    0xb0,0xf9,0x63,0x00,0xa0,0xf9,0x65,0x00,0x90,0xf9,0x67,0x00,0x80,0xf9,0x69,0x00,0x70,0xf9,0x6c,0x00,0x60,0xf9,0x6e,0x00,0x50,0xf9,0x70,0x00,0x3f,0xf9,0x73,0x00,0x2f,0xf9,0x75,0x00,0x1e,0xf9,0x77,0x00,0x0d,0xf9,0x79,0x00,0xfd,0xf8,0x7c,0x00,0xec,0xf8,0x7e,0x00,0xdb,0xf8,0x81,0x00,0xca,0xf8,0x83,0x00,0xb9,0xf8,0x85,0x00,0xa7,0xf8,0x88,0x00,0x96,0xf8,0x8a,0x00,0x85,0xf8,0x8c,0x00,0x73,0xf8,0x8f,0x00,0x62,0xf8,0x91,0x00,0x50,0xf8,0x94,0x00,0x3e,0xf8,  \
    0x96,0x00,0x2c,0xf8,0x98,0x00,0x1a,0xf8,0x9b,0x00,0x08,0xf8,0x9d,0x00,0xf6,0xf7,0xa0,0x00,0xe4,0xf7,0xa2,0x00,0xd2,0xf7,0xa5,0x00,0xbf,0xf7,0xa7,0x00,0xad,0xf7,0xaa,0x00,0x9a,0xf7,0xac,0x00,0x88,0xf7,0xae,0x00,0x75,0xf7,0xb1,0x00,0x62,0xf7,0xb3,0x00,0x4f,0xf7,0xb6,0x00,0x3c,0xf7,0xb8,0x00,0x29,0xf7,0xbb,0x00,0x16,0xf7,0xbd,0x00,0x02,0xf7,0xc0,0x00,0xef,0xf6,0xc2,0x00,0xdb,0xf6,0xc4,0x00,0xc7,0xf6,0xc7,0x00,0xb4,0xf6,0xc9,0x00,0xa0,0xf6,0xcc,0x00,  \
    0x8c,0xf6,0xce,0x00,0x78,0xf6,0xd1,0x00,0x63,0xf6,0xd3,0x00,0x4f,0xf6,0xd5,0x00,0x3b,0xf6,0xd8,0x00,0x26,0xf6,0xda,0x00,0x11,0xf6,0xdd,0x00,0xfc,0xf5,0xdf,0x00,0xe7,0xf5,0xe1,0x00,0xd2,0xf5,0xe4,0x00,0xbd,0xf5,0xe6,0x00,0xa8,0xf5,0xe8,0x00,0x93,0xf5,0xeb,0x00,0x7d,0xf5,0xed,0x00,0x68,0xf5,0xf0,0x00,0x52,0xf5,0xf2,0x00,0x3c,0xf5,0xf4,0x00,0x26,0xf5,0xf6,0x00,0x10,0xf5,0xf9,0x00,0xfa,0xf4,0xfb,0x00,0xe4,0xf4,0xfd,0x00,0xce,0xf4,0x00,0x01,0xb7,0xf4,  \
    0x02,0x01,0xa1,0xf4,0x04,0x01,0x8a,0xf4,0x06,0x01,0x73,0xf4,0x09,0x01,0x5c,0xf4,0x0b,0x01,0x45,0xf4,0x0d,0x01,0x2e,0xf4,0x0f,0x01,0x17,0xf4,0x11,0x01,0xff,0xf3,0x13,0x01,0xe8,0xf3,0x15,0x01,0xd0,0xf3,0x18,0x01,0xb9,0xf3,0x1a,0x01,0xa1,0xf3,0x1c,0x01,0x89,0xf3,0x1e,0x01,0x71,0xf3,0x20,0x01,0x58,0xf3,0x22,0x01,0x40,0xf3,0x24,0x01,0x28,0xf3,0x26,0x01,0x0f,0xf3,0x28,0x01,0xf6,0xf2,0x2a,0x01,0xde,0xf2,0x2b,0x01,0xc5,0xf2,0x2d,0x01,0xac,0xf2,0x2f,0x01,  \
    0x92,0xf2,0x31,0x01,0x79,0xf2,0x33,0x01,0x60,0xf2,0x35,0x01,0x46,0xf2,0x36,0x01,0x2c,0xf2,0x38,0x01,0x12,0xf2,0x3a,0x01,0xf8,0xf1,0x3b,0x01,0xde,0xf1,0x3d,0x01,0xc4,0xf1,0x3f,0x01,0xaa,0xf1,0x40,0x01,0x8f,0xf1,0x42,0x01,0x75,0xf1,0x43,0x01,0x5a,0xf1,0x45,0x01,0x3f,0xf1,0x46,0x01,0x24,0xf1,0x47,0x01,0x09,0xf1,0x49,0x01,0xee,0xf0,0x4a,0x01,0xd2,0xf0,0x4c,0x01,0xb7,0xf0,0x4d,0x01,0x9b,0xf0,0x4e,0x01,0x7f,0xf0,0x4f,0x01,0x63,0xf0,0x50,0x01,0x47,0xf0,  \
    0x52,0x01,0x2b,0xf0,0x53,0x01,0x0f,0xf0,0x54,0x01,0xf2,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x4f,0x01,0x1a,0x10,0x4e,0x01,0xfd,0x0f,0x4d,0x01,0xe0,0x0f,0x4c,0x01,0xc4,0x0f,0x4b,0x01,  \
    0xa8,0x0f,0x49,0x01,0x8c,0x0f,0x48,0x01,0x6f,0x0f,0x47,0x01,0x54,0x0f,0x46,0x01,0x38,0x0f,0x45,0x01,0x1c,0x0f,0x43,0x01,0x01,0x0f,0x42,0x01,0xe5,0x0e,0x41,0x01,0xca,0x0e,0x3f,0x01,0xaf,0x0e,0x3e,0x01,0x94,0x0e,0x3d,0x01,0x79,0x0e,0x3b,0x01,0x5e,0x0e,0x3a,0x01,0x43,0x0e,0x38,0x01,0x29,0x0e,0x37,0x01,0x0e,0x0e,0x35,0x01,0xf4,0x0d,0x34,0x01,0xda,0x0d,0x32,0x01,0xbf,0x0d,0x30,0x01,0xa6,0x0d,0x2f,0x01,0x8c,0x0d,0x2d,0x01,0x72,0x0d,0x2b,0x01,0x58,0x0d,  \
    0x2a,0x01,0x3f,0x0d,0x28,0x01,0x25,0x0d,0x26,0x01,0x0c,0x0d,0x24,0x01,0xf3,0x0c,0x22,0x01,0xda,0x0c,0x21,0x01,0xc1,0x0c,0x1f,0x01,0xa8,0x0c,0x1d,0x01,0x90,0x0c,0x1b,0x01,0x77,0x0c,0x19,0x01,0x5f,0x0c,0x17,0x01,0x46,0x0c,0x15,0x01,0x2e,0x0c,0x13,0x01,0x16,0x0c,0x11,0x01,0xfe,0x0b,0x0f,0x01,0xe6,0x0b,0x0d,0x01,0xcf,0x0b,0x0b,0x01,0xb7,0x0b,0x09,0x01,0xa0,0x0b,0x07,0x01,0x88,0x0b,0x05,0x01,0x71,0x0b,0x03,0x01,0x5a,0x0b,0x01,0x01,0x43,0x0b,0xfe,0x00,  \
    0x2c,0x0b,0xfc,0x00,0x15,0x0b,0xfa,0x00,0xff,0x0a,0xf8,0x00,0xe8,0x0a,0xf6,0x00,0xd2,0x0a,0xf4,0x00,0xbb,0x0a,0xf1,0x00,0xa5,0x0a,0xef,0x00,0x8f,0x0a,0xed,0x00,0x79,0x0a,0xeb,0x00,0x63,0x0a,0xe9,0x00,0x4d,0x0a,0xe6,0x00,0x37,0x0a,0xe4,0x00,0x22,0x0a,0xe2,0x00,0x0c,0x0a,0xe0,0x00,0xf7,0x09,0xdd,0x00,0xe1,0x09,0xdb,0x00,0xcc,0x09,0xd9,0x00,0xb7,0x09,0xd7,0x00,0xa2,0x09,0xd4,0x00,0x8d,0x09,0xd2,0x00,0x78,0x09,0xd0,0x00,0x63,0x09,0xcd,0x00,0x4f,0x09,  \
    0xcb,0x00,0x3a,0x09,0xc9,0x00,0x26,0x09,0xc6,0x00,0x12,0x09,0xc4,0x00,0xfd,0x08,0xc2,0x00,0xe9,0x08,0xc0,0x00,0xd5,0x08,0xbd,0x00,0xc1,0x08,0xbb,0x00,0xae,0x08,0xb9,0x00,0x9a,0x08,0xb6,0x00,0x86,0x08,0xb4,0x00,0x73,0x08,0xb2,0x00,0x5f,0x08,0xaf,0x00,0x4c,0x08,0xad,0x00,0x39,0x08,0xab,0x00,0x26,0x08,0xa8,0x00,0x13,0x08,0xa6,0x00,0x00,0x08,0xa4,0x00,0xed,0x07,0xa1,0x00,0xda,0x07,0x9f,0x00,0xc8,0x07,0x9d,0x00,0xb5,0x07,0x9a,0x00,0xa3,0x07,0x98,0x00,  \
    0x90,0x07,0x96,0x00,0x7e,0x07,0x93,0x00,0x6c,0x07,0x91,0x00,0x5a,0x07,0x8f,0x00,0x48,0x07,0x8d,0x00,0x37,0x07,0x8a,0x00,0x25,0x07,0x88,0x00,0x13,0x07,0x86,0x00,0x02,0x07,0x83,0x00,0xf0,0x06,0x81,0x00,0xdf,0x06,0x7f,0x00,0xce,0x06,0x7d,0x00,0xbd,0x06,0x7a,0x00,0xab,0x06,0x78,0x00,0x9a,0x06,0x76,0x00,0x8a,0x06,0x74,0x00,0x79,0x06,0x71,0x00,0x68,0x06,0x6f,0x00,0x57,0x06,0x6d,0x00,0x47,0x06,0x6b,0x00,0x36,0x06,0x69,0x00,0x26,0x06,0x66,0x00,0x16,0x06,  \
    0x64,0x00,0x05,0x06,0x62,0x00,0xf5,0x05,0x60,0x00,0xe5,0x05,0x5e,0x00,0xd5,0x05,0x5c,0x00,0xc5,0x05,0x5a,0x00,0xb5,0x05,0x57,0x00,0xa5,0x05,0x55,0x00,0x96,0x05,0x53,0x00,0x86,0x05,0x51,0x00,0x76,0x05,0x4f,0x00,0x67,0x05,0x4d,0x00,0x58,0x05,0x4b,0x00,0x48,0x05,0x49,0x00,0x39,0x05,0x47,0x00,0x2a,0x05,0x45,0x00,0x1b,0x05,0x43,0x00,0x0c,0x05,0x41,0x00,0xfd,0x04,0x3f,0x00,0xee,0x04,0x3d,0x00,0xdf,0x04,0x3b,0x00,0xd0,0x04,0x39,0x00,0xc1,0x04,0x37,0x00,  \
    0xb3,0x04,0x35,0x00,0xa4,0x04,0x33,0x00,0x96,0x04,0x32,0x00,0x87,0x04,0x30,0x00,0x79,0x04,0x2e,0x00,0x6a,0x04,0x2c,0x00,0x5c,0x04,0x2a,0x00,0x4e,0x04,0x28,0x00,0x40,0x04,0x27,0x00,0x31,0x04,0x25,0x00,0x23,0x04,0x23,0x00,0x15,0x04,0x21,0x00,0x07,0x04,0x20,0x00,0xfa,0x03,0x1e,0x00,0xec,0x03,0x1c,0x00,0xde,0x03,0x1a,0x00,0xd0,0x03,0x19,0x00,0xc3,0x03,0x17,0x00,0xb5,0x03,0x16,0x00,0xa8,0x03,0x14,0x00,0x9a,0x03,0x12,0x00,0x8d,0x03,0x11,0x00,0x80,0x03,  \
    0x0f,0x00,0x72,0x03,0x0e,0x00,0x65,0x03,0x0c,0x00,0x58,0x03,0x0b,0x00,0x4b,0x03,0x09,0x00,0x3e,0x03,0x08,0x00,0x31,0x03,0x06,0x00,0x24,0x03,0x05,0x00,0x17,0x03,0x03,0x00,0x0a,0x03,0x02,0x00,0xfe,0x02,0x00,0x00,0xf1,0x02,0xff,0xff,0xe4,0x02,0xfe,0xff,0xd8,0x02,0xfc,0xff,0xcb,0x02,0xfb,0xff,0xbe,0x02,0xfa,0xff,0xb2,0x02,0xf8,0xff,0xa5,0x02,0xf7,0xff,0x99,0x02,0xf6,0xff,0x8d,0x02,0xf4,0xff,0x80,0x02,0xf3,0xff,0x74,0x02,0xf2,0xff,0x68,0x02,0xf1,0xff,  \
    0x5c,0x02,0xf0,0xff,0x4f,0x02,0xef,0xff,0x43,0x02,0xed,0xff,0x37,0x02,0xec,0xff,0x2b,0x02,0xeb,0xff,0x1f,0x02,0xea,0xff,0x13,0x02,0xe9,0xff,0x07,0x02,0xe8,0xff,0xfc,0x01,0xe7,0xff,0xf0,0x01,0xe6,0xff,0xe4,0x01,0xe5,0xff,0xd8,0x01,0xe4,0xff,0xcc,0x01,0xe3,0xff,0xc1,0x01,0xe2,0xff,0xb5,0x01,0xe1,0xff,0xa9,0x01,0xe0,0xff,0x9e,0x01,0xe0,0xff,0x92,0x01,0xdf,0xff,0x86,0x01,0xde,0xff,0x7b,0x01,0xdd,0xff,0x6f,0x01,0xdc,0xff,0x64,0x01,0xdc,0xff,0x58,0x01,  \
    0xdb,0xff,0x4d,0x01,0xda,0xff,0x42,0x01,0xd9,0xff,0x36,0x01,0xd9,0xff,0x2b,0x01,0xd8,0xff,0x1f,0x01,0xd7,0xff,0x14,0x01,0xd7,0xff,0x09,0x01,0xd6,0xff,0xfd,0x00,0xd6,0xff,0xf2,0x00,0xd5,0xff,0xe7,0x00,0xd5,0xff,0xdb,0x00,0xd4,0xff,0xd0,0x00,0xd3,0xff,0xc5,0x00,0xd3,0xff,0xba,0x00,0xd3,0xff,0xae,0x00,0xd2,0xff,0xa3,0x00,0xd2,0xff,0x98,0x00,0xd1,0xff,0x8d,0x00,0xd1,0xff,0x82,0x00,0xd1,0xff,0x77,0x00,0xd0,0xff,0x6b,0x00,0xd0,0xff,0x60,0x00,0xd0,0xff,  \
    0x55,0x00,0xcf,0xff,0x4a,0x00,0xcf,0xff,0x3f,0x00,0xcf,0xff,0x34,0x00,0xcf,0xff,0x29,0x00,0xcf,0xff,0x1e,0x00,0xce,0xff,0x13,0x00,0xce,0xff,0x08,0x00,0xce,0xff,0xfd,0xff,0xce,0xff,0xf2,0xff,0xce,0xff,0xe7,0xff,0xce,0xff,0xdc,0xff,0xce,0xff,0xd0,0xff,0xce,0xff,0xc5,0xff,0xce,0xff,0xba,0xff,0xce,0xff,0xaf,0xff,0xce,0xff,0xa4,0xff,0xce,0xff,0x99,0xff,0xce,0xff,0x8e,0xff,0xce,0xff,0x83,0xff,0xce,0xff,0x78,0xff,0xce,0xff,0x6d,0xff,0xcf,0xff,0x62,0xff,  \
    0xcf,0xff,0x57,0xff,0xcf,0xff,0x4c,0xff,0xcf,0xff,0x41,0xff,0xcf,0xff,0x36,0xff,0xd0,0xff,0x2b,0xff,0xd0,0xff,0x20,0xff,0xd0,0xff,0x15,0xff,0xd1,0xff,0x09,0xff,0xd1,0xff,0xfe,0xfe,0xd1,0xff,0xf3,0xfe,0xd2,0xff,0xe8,0xfe,0xd2,0xff,0xdd,0xfe,0xd3,0xff,0xd2,0xfe,0xd3,0xff,0xc7,0xfe,0xd4,0xff,0xbb,0xfe,0xd4,0xff,0xb0,0xfe,0xd5,0xff,0xa5,0xfe,0xd5,0xff,0x9a,0xfe,0xd6,0xff,0x8e,0xfe,0xd6,0xff,0x83,0xfe,0xd7,0xff,0x78,0xfe,0xd8,0xff,0x6d,0xfe,0xd8,0xff,  \
    0x61,0xfe,0xd9,0xff,0x56,0xfe,0xda,0xff,0x4b,0xfe,0xda,0xff,0x3f,0xfe,0xdb,0xff,0x34,0xfe,0xdc,0xff,0x28,0xfe,0xdd,0xff,0x1d,0xfe,0xdd,0xff,0x11,0xfe,0xde,0xff,0x06,0xfe,0xdf,0xff,0xfa,0xfd,0xe0,0xff,0xef,0xfd,0xe1,0xff,0xe3,0xfd,0xe2,0xff,0xd7,0xfd,0xe2,0xff,0xcc,0xfd,0xe3,0xff,0xc0,0xfd,0xe4,0xff,0xb4,0xfd,0xe5,0xff,0xa9,0xfd,0xe6,0xff,0x9d,0xfd,0xe7,0xff,0x91,0xfd,0xe8,0xff,0x85,0xfd,0xe9,0xff,0x79,0xfd,0xea,0xff,0x6d,0xfd,0xeb,0xff,0x61,0xfd,  \
    0xed,0xff,0x55,0xfd,0xee,0xff,0x49,0xfd,0xef,0xff,0x3d,0xfd,0xf0,0xff,0x31,0xfd,0xf1,0xff,0x25,0xfd,0xf2,0xff,0x19,0xfd,0xf4,0xff,0x0d,0xfd,0xf5,0xff,0x01,0xfd,0xf6,0xff,0xf5,0xfc,0xf7,0xff,0xe8,0xfc,0xf9,0xff,0xdc,0xfc,0xfa,0xff,0xd0,0xfc,0xfb,0xff,0xc3,0xfc,0xfd,0xff,0xb7,0xfc,0xfe,0xff,0xaa,0xfc,0xff,0xff,0x9e,0xfc,0x01,0x00,0x91,0xfc,0x02,0x00,0x84,0xfc,0x03,0x00,0x78,0xfc,0x05,0x00,0x6b,0xfc,0x06,0x00,0x5e,0xfc,0x08,0x00,0x52,0xfc,0x09,0x00,  \
    0x45,0xfc,0x0b,0x00,0x38,0xfc,0x0c,0x00,0x2b,0xfc,0x0e,0x00,0x1e,0xfc,0x10,0x00,0x11,0xfc,0x11,0x00,0x04,0xfc,0x13,0x00,0xf6,0xfb,0x14,0x00,0xe9,0xfb,0x16,0x00,0xdc,0xfb,0x18,0x00,0xce,0xfb,0x19,0x00,0xc1,0xfb,0x1b,0x00,0xb4,0xfb,0x1d,0x00,0xa6,0xfb,0x1e,0x00,0x98,0xfb,0x20,0x00,0x8b,0xfb,0x22,0x00,0x7d,0xfb,0x24,0x00,0x6f,0xfb,0x25,0x00,0x61,0xfb,0x27,0x00,0x54,0xfb,0x29,0x00,0x46,0xfb,0x2b,0x00,0x38,0xfb,0x2d,0x00,0x29,0xfb,0x2f,0x00,0x1b,0xfb,  \
    0x30,0x00,0x0d,0xfb,0x32,0x00,0xff,0xfa,0x34,0x00,0xf1,0xfa,0x36,0x00,0xe2,0xfa,0x38,0x00,0xd4,0xfa,0x3a,0x00,0xc5,0xfa,0x3c,0x00,0xb6,0xfa,0x3e,0x00,0xa8,0xfa,0x40,0x00,0x99,0xfa,0x42,0x00,0x8a,0xfa,0x44,0x00,0x7b,0xfa,0x46,0x00,0x6d,0xfa,0x48,0x00,0x5e,0xfa,0x4a,0x00,0x4e,0xfa,0x4c,0x00,0x3f,0xfa,0x4e,0x00,0x30,0xfa,0x50,0x00,0x21,0xfa,0x52,0x00,0x11,0xfa,0x54,0x00,0x02,0xfa,0x56,0x00,0xf2,0xf9,0x58,0x00,0xe3,0xf9,0x5b,0x00,0xd3,0xf9,0x5d,0x00,  \
    0xc3,0xf9,0x5f,0x00,0xb4,0xf9,0x61,0x00,0xa4,0xf9,0x63,0x00,0x94,0xf9,0x65,0x00,0x84,0xf9,0x68,0x00,0x73,0xf9,0x6a,0x00,0x63,0xf9,0x6c,0x00,0x53,0xf9,0x6e,0x00,0x42,0xf9,0x70,0x00,0x32,0xf9,0x73,0x00,0x21,0xf9,0x75,0x00,0x11,0xf9,0x77,0x00,0x00,0xf9,0x79,0x00,0xef,0xf8,0x7c,0x00,0xde,0xf8,0x7e,0x00,0xcd,0xf8,0x80,0x00,0xbc,0xf8,0x83,0x00,0xab,0xf8,0x85,0x00,0x99,0xf8,0x87,0x00,0x88,0xf8,0x89,0x00,0x76,0xf8,0x8c,0x00,0x65,0xf8,0x8e,0x00,0x53,0xf8,  \
    0x90,0x00,0x41,0xf8,0x93,0x00,0x30,0xf8,0x95,0x00,0x1e,0xf8,0x97,0x00,0x0c,0xf8,0x9a,0x00,0xfa,0xf7,0x9c,0x00,0xe7,0xf7,0x9e,0x00,0xd5,0xf7,0xa1,0x00,0xc3,0xf7,0xa3,0x00,0xb0,0xf7,0xa5,0x00,0x9e,0xf7,0xa8,0x00,0x8b,0xf7,0xaa,0x00,0x78,0xf7,0xac,0x00,0x65,0xf7,0xaf,0x00,0x52,0xf7,0xb1,0x00,0x3f,0xf7,0xb3,0x00,0x2c,0xf7,0xb6,0x00,0x19,0xf7,0xb8,0x00,0x05,0xf7,0xba,0x00,0xf2,0xf6,0xbd,0x00,0xde,0xf6,0xbf,0x00,0xcb,0xf6,0xc2,0x00,0xb7,0xf6,0xc4,0x00,  \
    0xa3,0xf6,0xc6,0x00,0x8f,0xf6,0xc9,0x00,0x7b,0xf6,0xcb,0x00,0x66,0xf6,0xcd,0x00,0x52,0xf6,0xd0,0x00,0x3e,0xf6,0xd2,0x00,0x29,0xf6,0xd4,0x00,0x14,0xf6,0xd6,0x00,0xff,0xf5,0xd9,0x00,0xeb,0xf5,0xdb,0x00,0xd5,0xf5,0xdd,0x00,0xc0,0xf5,0xe0,0x00,0xab,0xf5,0xe2,0x00,0x96,0xf5,0xe4,0x00,0x80,0xf5,0xe6,0x00,0x6b,0xf5,0xe9,0x00,0x55,0xf5,0xeb,0x00,0x3f,0xf5,0xed,0x00,0x29,0xf5,0xef,0x00,0x13,0xf5,0xf1,0x00,0xfd,0xf4,0xf4,0x00,0xe7,0xf4,0xf6,0x00,0xd0,0xf4,  \
    0xf8,0x00,0xba,0xf4,0xfa,0x00,0xa3,0xf4,0xfc,0x00,0x8d,0xf4,0xfe,0x00,0x76,0xf4,0x01,0x01,0x5f,0xf4,0x03,0x01,0x48,0xf4,0x05,0x01,0x31,0xf4,0x07,0x01,0x1a,0xf4,0x09,0x01,0x02,0xf4,0x0b,0x01,0xeb,0xf3,0x0d,0x01,0xd3,0xf3,0x0f,0x01,0xbb,0xf3,0x11,0x01,0xa4,0xf3,0x13,0x01,0x8c,0xf3,0x15,0x01,0x73,0xf3,0x17,0x01,0x5b,0xf3,0x19,0x01,0x43,0xf3,0x1b,0x01,0x2a,0xf3,0x1c,0x01,0x12,0xf3,0x1e,0x01,0xf9,0xf2,0x20,0x01,0xe0,0xf2,0x22,0x01,0xc7,0xf2,0x24,0x01,  \
    0xae,0xf2,0x26,0x01,0x95,0xf2,0x27,0x01,0x7c,0xf2,0x29,0x01,0x62,0xf2,0x2b,0x01,0x49,0xf2,0x2c,0x01,0x2f,0xf2,0x2e,0x01,0x15,0xf2,0x30,0x01,0xfb,0xf1,0x31,0x01,0xe1,0xf1,0x33,0x01,0xc7,0xf1,0x34,0x01,0xac,0xf1,0x36,0x01,0x92,0xf1,0x37,0x01,0x77,0xf1,0x39,0x01,0x5d,0xf1,0x3a,0x01,0x42,0xf1,0x3c,0x01,0x27,0xf1,0x3d,0x01,0x0b,0xf1,0x3e,0x01,0xf0,0xf0,0x3f,0x01,0xd5,0xf0,0x41,0x01,0xb9,0xf0,0x42,0x01,0x9e,0xf0,0x43,0x01,0x82,0xf0,0x44,0x01,0x66,0xf0,  \
    0x45,0x01,0x4a,0xf0,0x47,0x01,0x2e,0xf0,0x48,0x01,0x11,0xf0,0x49,0x01,0xf5,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x44,0x01,0x17,0x10,0x43,0x01,0xfb,0x0f,0x42,0x01,0xde,0x0f,0x41,0x01,  \
    0xc2,0x0f,0x40,0x01,0xa5,0x0f,0x3f,0x01,0x89,0x0f,0x3e,0x01,0x6d,0x0f,0x3d,0x01,0x51,0x0f,0x3b,0x01,0x36,0x0f,0x3a,0x01,0x1a,0x0f,0x39,0x01,0xfe,0x0e,0x38,0x01,0xe3,0x0e,0x36,0x01,0xc8,0x0e,0x35,0x01,0xac,0x0e,0x34,0x01,0x91,0x0e,0x33,0x01,0x76,0x0e,0x31,0x01,0x5c,0x0e,0x30,0x01,0x41,0x0e,0x2e,0x01,0x26,0x0e,0x2d,0x01,0x0c,0x0e,0x2b,0x01,0xf1,0x0d,0x2a,0x01,0xd7,0x0d,0x28,0x01,0xbd,0x0d,0x27,0x01,0xa3,0x0d,0x25,0x01,0x89,0x0d,0x24,0x01,0x70,0x0d,  \
    0x22,0x01,0x56,0x0d,0x20,0x01,0x3c,0x0d,0x1f,0x01,0x23,0x0d,0x1d,0x01,0x0a,0x0d,0x1b,0x01,0xf1,0x0c,0x19,0x01,0xd8,0x0c,0x18,0x01,0xbf,0x0c,0x16,0x01,0xa6,0x0c,0x14,0x01,0x8d,0x0c,0x12,0x01,0x75,0x0c,0x10,0x01,0x5c,0x0c,0x0f,0x01,0x44,0x0c,0x0d,0x01,0x2c,0x0c,0x0b,0x01,0x14,0x0c,0x09,0x01,0xfc,0x0b,0x07,0x01,0xe4,0x0b,0x05,0x01,0xcc,0x0b,0x03,0x01,0xb5,0x0b,0x01,0x01,0x9d,0x0b,0xff,0x00,0x86,0x0b,0xfd,0x00,0x6f,0x0b,0xfb,0x00,0x57,0x0b,0xf9,0x00,  \
    0x40,0x0b,0xf7,0x00,0x29,0x0b,0xf5,0x00,0x13,0x0b,0xf3,0x00,0xfc,0x0a,0xf1,0x00,0xe5,0x0a,0xef,0x00,0xcf,0x0a,0xed,0x00,0xb9,0x0a,0xea,0x00,0xa2,0x0a,0xe8,0x00,0x8c,0x0a,0xe6,0x00,0x76,0x0a,0xe4,0x00,0x60,0x0a,0xe2,0x00,0x4a,0x0a,0xe0,0x00,0x35,0x0a,0xde,0x00,0x1f,0x0a,0xdb,0x00,0x09,0x0a,0xd9,0x00,0xf4,0x09,0xd7,0x00,0xde,0x09,0xd5,0x00,0xc9,0x09,0xd3,0x00,0xb4,0x09,0xd1,0x00,0x9f,0x09,0xce,0x00,0x8a,0x09,0xcc,0x00,0x75,0x09,0xca,0x00,0x61,0x09,  \
    0xc8,0x00,0x4c,0x09,0xc6,0x00,0x37,0x09,0xc3,0x00,0x23,0x09,0xc1,0x00,0x0f,0x09,0xbf,0x00,0xfb,0x08,0xbd,0x00,0xe6,0x08,0xbb,0x00,0xd2,0x08,0xb8,0x00,0xbf,0x08,0xb6,0x00,0xab,0x08,0xb4,0x00,0x97,0x08,0xb2,0x00,0x83,0x08,0xaf,0x00,0x70,0x08,0xad,0x00,0x5c,0x08,0xab,0x00,0x49,0x08,0xa9,0x00,0x36,0x08,0xa6,0x00,0x23,0x08,0xa4,0x00,0x10,0x08,0xa2,0x00,0xfd,0x07,0xa0,0x00,0xea,0x07,0x9e,0x00,0xd7,0x07,0x9b,0x00,0xc5,0x07,0x99,0x00,0xb2,0x07,0x97,0x00,  \
    0xa0,0x07,0x95,0x00,0x8d,0x07,0x92,0x00,0x7b,0x07,0x90,0x00,0x69,0x07,0x8e,0x00,0x57,0x07,0x8c,0x00,0x45,0x07,0x8a,0x00,0x34,0x07,0x87,0x00,0x22,0x07,0x85,0x00,0x10,0x07,0x83,0x00,0xff,0x06,0x81,0x00,0xed,0x06,0x7f,0x00,0xdc,0x06,0x7c,0x00,0xcb,0x06,0x7a,0x00,0xba,0x06,0x78,0x00,0xa8,0x06,0x76,0x00,0x97,0x06,0x74,0x00,0x87,0x06,0x72,0x00,0x76,0x06,0x6f,0x00,0x65,0x06,0x6d,0x00,0x54,0x06,0x6b,0x00,0x44,0x06,0x69,0x00,0x33,0x06,0x67,0x00,0x23,0x06,  \
    0x65,0x00,0x13,0x06,0x63,0x00,0x02,0x06,0x61,0x00,0xf2,0x05,0x5f,0x00,0xe2,0x05,0x5d,0x00,0xd2,0x05,0x5b,0x00,0xc2,0x05,0x59,0x00,0xb2,0x05,0x57,0x00,0xa2,0x05,0x54,0x00,0x93,0x05,0x52,0x00,0x83,0x05,0x50,0x00,0x74,0x05,0x4f,0x00,0x64,0x05,0x4d,0x00,0x55,0x05,0x4b,0x00,0x45,0x05,0x49,0x00,0x36,0x05,0x47,0x00,0x27,0x05,0x45,0x00,0x18,0x05,0x43,0x00,0x09,0x05,0x41,0x00,0xfa,0x04,0x3f,0x00,0xeb,0x04,0x3d,0x00,0xdc,0x04,0x3b,0x00,0xcd,0x04,0x39,0x00,  \
    0xbf,0x04,0x38,0x00,0xb0,0x04,0x36,0x00,0xa1,0x04,0x34,0x00,0x93,0x04,0x32,0x00,0x84,0x04,0x30,0x00,0x76,0x04,0x2f,0x00,0x67,0x04,0x2d,0x00,0x59,0x04,0x2b,0x00,0x4b,0x04,0x29,0x00,0x3d,0x04,0x28,0x00,0x2f,0x04,0x26,0x00,0x21,0x04,0x24,0x00,0x13,0x04,0x23,0x00,0x05,0x04,0x21,0x00,0xf7,0x03,0x1f,0x00,0xe9,0x03,0x1e,0x00,0xdc,0x03,0x1c,0x00,0xce,0x03,0x1a,0x00,0xc0,0x03,0x19,0x00,0xb3,0x03,0x17,0x00,0xa5,0x03,0x16,0x00,0x98,0x03,0x14,0x00,0x8a,0x03,  \
    0x13,0x00,0x7d,0x03,0x11,0x00,0x70,0x03,0x10,0x00,0x63,0x03,0x0e,0x00,0x56,0x03,0x0d,0x00,0x49,0x03,0x0b,0x00,0x3c,0x03,0x0a,0x00,0x2f,0x03,0x08,0x00,0x22,0x03,0x07,0x00,0x15,0x03,0x06,0x00,0x08,0x03,0x04,0x00,0xfb,0x02,0x03,0x00,0xef,0x02,0x01,0x00,0xe2,0x02,0x00,0x00,0xd5,0x02,0xff,0xff,0xc9,0x02,0xfe,0xff,0xbc,0x02,0xfc,0xff,0xb0,0x02,0xfb,0xff,0xa3,0x02,0xfa,0xff,0x97,0x02,0xf9,0xff,0x8b,0x02,0xf7,0xff,0x7e,0x02,0xf6,0xff,0x72,0x02,0xf5,0xff,  \
    0x66,0x02,0xf4,0xff,0x5a,0x02,0xf3,0xff,0x4e,0x02,0xf2,0xff,0x41,0x02,0xf1,0xff,0x35,0x02,0xf0,0xff,0x29,0x02,0xee,0xff,0x1d,0x02,0xed,0xff,0x12,0x02,0xec,0xff,0x06,0x02,0xeb,0xff,0xfa,0x01,0xea,0xff,0xee,0x01,0xe9,0xff,0xe2,0x01,0xe9,0xff,0xd6,0x01,0xe8,0xff,0xcb,0x01,0xe7,0xff,0xbf,0x01,0xe6,0xff,0xb3,0x01,0xe5,0xff,0xa8,0x01,0xe4,0xff,0x9c,0x01,0xe3,0xff,0x91,0x01,0xe2,0xff,0x85,0x01,0xe2,0xff,0x7a,0x01,0xe1,0xff,0x6e,0x01,0xe0,0xff,0x63,0x01,  \
    0xdf,0xff,0x57,0x01,0xdf,0xff,0x4c,0x01,0xde,0xff,0x40,0x01,0xdd,0xff,0x35,0x01,0xdd,0xff,0x2a,0x01,0xdc,0xff,0x1e,0x01,0xdb,0xff,0x13,0x01,0xdb,0xff,0x08,0x01,0xda,0xff,0xfc,0x00,0xda,0xff,0xf1,0x00,0xd9,0xff,0xe6,0x00,0xd9,0xff,0xda,0x00,0xd8,0xff,0xcf,0x00,0xd8,0xff,0xc4,0x00,0xd7,0xff,0xb9,0x00,0xd7,0xff,0xae,0x00,0xd6,0xff,0xa3,0x00,0xd6,0xff,0x97,0x00,0xd6,0xff,0x8c,0x00,0xd5,0xff,0x81,0x00,0xd5,0xff,0x76,0x00,0xd5,0xff,0x6b,0x00,0xd4,0xff,  \
    0x60,0x00,0xd4,0xff,0x55,0x00,0xd4,0xff,0x4a,0x00,0xd4,0xff,0x3f,0x00,0xd3,0xff,0x34,0x00,0xd3,0xff,0x29,0x00,0xd3,0xff,0x1e,0x00,0xd3,0xff,0x12,0x00,0xd3,0xff,0x07,0x00,0xd2,0xff,0xfc,0xff,0xd2,0xff,0xf1,0xff,0xd2,0xff,0xe6,0xff,0xd2,0xff,0xdb,0xff,0xd2,0xff,0xd0,0xff,0xd2,0xff,0xc5,0xff,0xd2,0xff,0xba,0xff,0xd2,0xff,0xaf,0xff,0xd2,0xff,0xa4,0xff,0xd2,0xff,0x99,0xff,0xd2,0xff,0x8e,0xff,0xd3,0xff,0x83,0xff,0xd3,0xff,0x78,0xff,0xd3,0xff,0x6d,0xff,  \
    0xd3,0xff,0x62,0xff,0xd3,0xff,0x57,0xff,0xd3,0xff,0x4c,0xff,0xd4,0xff,0x41,0xff,0xd4,0xff,0x36,0xff,0xd4,0xff,0x2b,0xff,0xd4,0xff,0x20,0xff,0xd5,0xff,0x15,0xff,0xd5,0xff,0x0a,0xff,0xd5,0xff,0xff,0xfe,0xd6,0xff,0xf4,0xfe,0xd6,0xff,0xe9,0xfe,0xd6,0xff,0xde,0xfe,0xd7,0xff,0xd3,0xfe,0xd7,0xff,0xc7,0xfe,0xd8,0xff,0xbc,0xfe,0xd8,0xff,0xb1,0xfe,0xd9,0xff,0xa6,0xfe,0xd9,0xff,0x9b,0xfe,0xda,0xff,0x90,0xfe,0xda,0xff,0x84,0xfe,0xdb,0xff,0x79,0xfe,0xdc,0xff,  \
    0x6e,0xfe,0xdc,0xff,0x62,0xfe,0xdd,0xff,0x57,0xfe,0xde,0xff,0x4c,0xfe,0xde,0xff,0x40,0xfe,0xdf,0xff,0x35,0xfe,0xe0,0xff,0x2a,0xfe,0xe0,0xff,0x1e,0xfe,0xe1,0xff,0x13,0xfe,0xe2,0xff,0x07,0xfe,0xe3,0xff,0xfc,0xfd,0xe3,0xff,0xf0,0xfd,0xe4,0xff,0xe5,0xfd,0xe5,0xff,0xd9,0xfd,0xe6,0xff,0xcd,0xfd,0xe7,0xff,0xc2,0xfd,0xe8,0xff,0xb6,0xfd,0xe9,0xff,0xaa,0xfd,0xea,0xff,0x9f,0xfd,0xeb,0xff,0x93,0xfd,0xec,0xff,0x87,0xfd,0xed,0xff,0x7b,0xfd,0xee,0xff,0x6f,0xfd,  \
    0xef,0xff,0x63,0xfd,0xf0,0xff,0x57,0xfd,0xf1,0xff,0x4b,0xfd,0xf2,0xff,0x3f,0xfd,0xf3,0xff,0x33,0xfd,0xf4,0xff,0x27,0xfd,0xf5,0xff,0x1b,0xfd,0xf6,0xff,0x0f,0xfd,0xf8,0xff,0x03,0xfd,0xf9,0xff,0xf7,0xfc,0xfa,0xff,0xea,0xfc,0xfb,0xff,0xde,0xfc,0xfd,0xff,0xd2,0xfc,0xfe,0xff,0xc5,0xfc,0xff,0xff,0xb9,0xfc,0x00,0x00,0xad,0xfc,0x02,0x00,0xa0,0xfc,0x03,0x00,0x93,0xfc,0x04,0x00,0x87,0xfc,0x06,0x00,0x7a,0xfc,0x07,0x00,0x6e,0xfc,0x09,0x00,0x61,0xfc,0x0a,0x00,  \
    0x54,0xfc,0x0b,0x00,0x47,0xfc,0x0d,0x00,0x3a,0xfc,0x0e,0x00,0x2d,0xfc,0x10,0x00,0x20,0xfc,0x11,0x00,0x13,0xfc,0x13,0x00,0x06,0xfc,0x14,0x00,0xf9,0xfb,0x16,0x00,0xec,0xfb,0x18,0x00,0xde,0xfb,0x19,0x00,0xd1,0xfb,0x1b,0x00,0xc4,0xfb,0x1c,0x00,0xb6,0xfb,0x1e,0x00,0xa9,0xfb,0x20,0x00,0x9b,0xfb,0x21,0x00,0x8e,0xfb,0x23,0x00,0x80,0xfb,0x25,0x00,0x72,0xfb,0x26,0x00,0x64,0xfb,0x28,0x00,0x56,0xfb,0x2a,0x00,0x48,0xfb,0x2c,0x00,0x3a,0xfb,0x2d,0x00,0x2c,0xfb,  \
    0x2f,0x00,0x1e,0xfb,0x31,0x00,0x10,0xfb,0x33,0x00,0x02,0xfb,0x35,0x00,0xf3,0xfa,0x36,0x00,0xe5,0xfa,0x38,0x00,0xd7,0xfa,0x3a,0x00,0xc8,0xfa,0x3c,0x00,0xba,0xfa,0x3e,0x00,0xab,0xfa,0x40,0x00,0x9c,0xfa,0x42,0x00,0x8d,0xfa,0x44,0x00,0x7f,0xfa,0x46,0x00,0x70,0xfa,0x47,0x00,0x61,0xfa,0x49,0x00,0x52,0xfa,0x4b,0x00,0x42,0xfa,0x4d,0x00,0x33,0xfa,0x4f,0x00,0x24,0xfa,0x51,0x00,0x14,0xfa,0x53,0x00,0x05,0xfa,0x55,0x00,0xf6,0xf9,0x57,0x00,0xe6,0xf9,0x5a,0x00,  \
    0xd6,0xf9,0x5c,0x00,0xc6,0xf9,0x5e,0x00,0xb7,0xf9,0x60,0x00,0xa7,0xf9,0x62,0x00,0x97,0xf9,0x64,0x00,0x87,0xf9,0x66,0x00,0x77,0xf9,0x68,0x00,0x66,0xf9,0x6a,0x00,0x56,0xf9,0x6c,0x00,0x46,0xf9,0x6e,0x00,0x35,0xf9,0x71,0x00,0x24,0xf9,0x73,0x00,0x14,0xf9,0x75,0x00,0x03,0xf9,0x77,0x00,0xf2,0xf8,0x79,0x00,0xe1,0xf8,0x7b,0x00,0xd0,0xf8,0x7e,0x00,0xbf,0xf8,0x80,0x00,0xae,0xf8,0x82,0x00,0x9c,0xf8,0x84,0x00,0x8b,0xf8,0x86,0x00,0x7a,0xf8,0x89,0x00,0x68,0xf8,  \
    0x8b,0x00,0x56,0xf8,0x8d,0x00,0x45,0xf8,0x8f,0x00,0x33,0xf8,0x91,0x00,0x21,0xf8,0x94,0x00,0x0f,0xf8,0x96,0x00,0xfd,0xf7,0x98,0x00,0xea,0xf7,0x9a,0x00,0xd8,0xf7,0x9d,0x00,0xc6,0xf7,0x9f,0x00,0xb3,0xf7,0xa1,0x00,0xa1,0xf7,0xa3,0x00,0x8e,0xf7,0xa6,0x00,0x7b,0xf7,0xa8,0x00,0x68,0xf7,0xaa,0x00,0x55,0xf7,0xac,0x00,0x42,0xf7,0xaf,0x00,0x2f,0xf7,0xb1,0x00,0x1c,0xf7,0xb3,0x00,0x08,0xf7,0xb5,0x00,0xf5,0xf6,0xb8,0x00,0xe1,0xf6,0xba,0x00,0xce,0xf6,0xbc,0x00,  \
    0xba,0xf6,0xbe,0x00,0xa6,0xf6,0xc1,0x00,0x92,0xf6,0xc3,0x00,0x7e,0xf6,0xc5,0x00,0x69,0xf6,0xc7,0x00,0x55,0xf6,0xca,0x00,0x41,0xf6,0xcc,0x00,0x2c,0xf6,0xce,0x00,0x17,0xf6,0xd0,0x00,0x02,0xf6,0xd2,0x00,0xed,0xf5,0xd5,0x00,0xd8,0xf5,0xd7,0x00,0xc3,0xf5,0xd9,0x00,0xae,0xf5,0xdb,0x00,0x99,0xf5,0xdd,0x00,0x83,0xf5,0xdf,0x00,0x6e,0xf5,0xe2,0x00,0x58,0xf5,0xe4,0x00,0x42,0xf5,0xe6,0x00,0x2c,0xf5,0xe8,0x00,0x16,0xf5,0xea,0x00,0x00,0xf5,0xec,0x00,0xea,0xf4,  \
    0xee,0x00,0xd3,0xf4,0xf0,0x00,0xbd,0xf4,0xf2,0x00,0xa6,0xf4,0xf5,0x00,0x90,0xf4,0xf7,0x00,0x79,0xf4,0xf9,0x00,0x62,0xf4,0xfb,0x00,0x4b,0xf4,0xfd,0x00,0x34,0xf4,0xff,0x00,0x1c,0xf4,0x01,0x01,0x05,0xf4,0x03,0x01,0xed,0xf3,0x04,0x01,0xd6,0xf3,0x06,0x01,0xbe,0xf3,0x08,0x01,0xa6,0xf3,0x0a,0x01,0x8e,0xf3,0x0c,0x01,0x76,0xf3,0x0e,0x01,0x5e,0xf3,0x10,0x01,0x45,0xf3,0x12,0x01,0x2d,0xf3,0x13,0x01,0x14,0xf3,0x15,0x01,0xfc,0xf2,0x17,0x01,0xe3,0xf2,0x19,0x01,  \
    0xca,0xf2,0x1a,0x01,0xb1,0xf2,0x1c,0x01,0x97,0xf2,0x1e,0x01,0x7e,0xf2,0x1f,0x01,0x65,0xf2,0x21,0x01,0x4b,0xf2,0x23,0x01,0x31,0xf2,0x24,0x01,0x17,0xf2,0x26,0x01,0xfd,0xf1,0x27,0x01,0xe3,0xf1,0x29,0x01,0xc9,0xf1,0x2a,0x01,0xaf,0xf1,0x2c,0x01,0x94,0xf1,0x2d,0x01,0x7a,0xf1,0x2e,0x01,0x5f,0xf1,0x30,0x01,0x44,0xf1,0x31,0x01,0x29,0xf1,0x32,0x01,0x0e,0xf1,0x34,0x01,0xf3,0xf0,0x35,0x01,0xd7,0xf0,0x36,0x01,0xbc,0xf0,0x37,0x01,0xa0,0xf0,0x38,0x01,0x84,0xf0,  \
    0x39,0x01,0x68,0xf0,0x3b,0x01,0x4c,0xf0,0x3c,0x01,0x30,0xf0,0x3d,0x01,0x14,0xf0,0x3e,0x01,0xf7,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x39,0x01,0x15,0x10,0x38,0x01,0xf9,0x0f,0x37,0x01,  \
    0xdc,0x0f,0x36,0x01,0xc0,0x0f,0x35,0x01,0xa3,0x0f,0x34,0x01,0x87,0x0f,0x33,0x01,0x6b,0x0f,0x32,0x01,0x4f,0x0f,0x31,0x01,0x33,0x0f,0x30,0x01,0x18,0x0f,0x2f,0x01,0xfc,0x0e,0x2d,0x01,0xe1,0x0e,0x2c,0x01,0xc5,0x0e,0x2b,0x01,0xaa,0x0e,0x2a,0x01,0x8f,0x0e,0x28,0x01,0x74,0x0e,0x27,0x01,0x59,0x0e,0x26,0x01,0x3f,0x0e,0x24,0x01,0x24,0x0e,0x23,0x01,0x0a,0x0e,0x22,0x01,0xef,0x0d,0x20,0x01,0xd5,0x0d,0x1f,0x01,0xbb,0x0d,0x1d,0x01,0xa1,0x0d,0x1c,0x01,0x87,0x0d,  \
    0x1a,0x01,0x6d,0x0d,0x19,0x01,0x54,0x0d,0x17,0x01,0x3a,0x0d,0x15,0x01,0x21,0x0d,0x14,0x01,0x08,0x0d,0x12,0x01,0xee,0x0c,0x10,0x01,0xd5,0x0c,0x0f,0x01,0xbc,0x0c,0x0d,0x01,0xa4,0x0c,0x0b,0x01,0x8b,0x0c,0x0a,0x01,0x72,0x0c,0x08,0x01,0x5a,0x0c,0x06,0x01,0x42,0x0c,0x04,0x01,0x29,0x0c,0x02,0x01,0x11,0x0c,0x01,0x01,0xf9,0x0b,0xff,0x00,0xe1,0x0b,0xfd,0x00,0xca,0x0b,0xfb,0x00,0xb2,0x0b,0xf9,0x00,0x9b,0x0b,0xf7,0x00,0x83,0x0b,0xf5,0x00,0x6c,0x0b,0xf3,0x00,  \
    0x55,0x0b,0xf1,0x00,0x3e,0x0b,0xef,0x00,0x27,0x0b,0xed,0x00,0x10,0x0b,0xeb,0x00,0xf9,0x0a,0xe9,0x00,0xe3,0x0a,0xe7,0x00,0xcc,0x0a,0xe5,0x00,0xb6,0x0a,0xe3,0x00,0xa0,0x0a,0xe1,0x00,0x8a,0x0a,0xdf,0x00,0x74,0x0a,0xdd,0x00,0x5e,0x0a,0xdb,0x00,0x48,0x0a,0xd9,0x00,0x32,0x0a,0xd7,0x00,0x1c,0x0a,0xd5,0x00,0x07,0x0a,0xd3,0x00,0xf1,0x09,0xd1,0x00,0xdc,0x09,0xcf,0x00,0xc7,0x09,0xcd,0x00,0xb1,0x09,0xcb,0x00,0x9c,0x09,0xc9,0x00,0x87,0x09,0xc7,0x00,0x73,0x09,  \
    0xc4,0x00,0x5e,0x09,0xc2,0x00,0x49,0x09,0xc0,0x00,0x35,0x09,0xbe,0x00,0x20,0x09,0xbc,0x00,0x0c,0x09,0xba,0x00,0xf8,0x08,0xb8,0x00,0xe4,0x08,0xb6,0x00,0xd0,0x08,0xb3,0x00,0xbc,0x08,0xb1,0x00,0xa8,0x08,0xaf,0x00,0x94,0x08,0xad,0x00,0x81,0x08,0xab,0x00,0x6d,0x08,0xa9,0x00,0x5a,0x08,0xa7,0x00,0x46,0x08,0xa4,0x00,0x33,0x08,0xa2,0x00,0x20,0x08,0xa0,0x00,0x0d,0x08,0x9e,0x00,0xfa,0x07,0x9c,0x00,0xe7,0x07,0x9a,0x00,0xd5,0x07,0x98,0x00,0xc2,0x07,0x96,0x00,  \
    0xaf,0x07,0x93,0x00,0x9d,0x07,0x91,0x00,0x8b,0x07,0x8f,0x00,0x79,0x07,0x8d,0x00,0x66,0x07,0x8b,0x00,0x54,0x07,0x89,0x00,0x43,0x07,0x87,0x00,0x31,0x07,0x85,0x00,0x1f,0x07,0x82,0x00,0x0d,0x07,0x80,0x00,0xfc,0x06,0x7e,0x00,0xeb,0x06,0x7c,0x00,0xd9,0x06,0x7a,0x00,0xc8,0x06,0x78,0x00,0xb7,0x06,0x76,0x00,0xa6,0x06,0x74,0x00,0x95,0x06,0x72,0x00,0x84,0x06,0x70,0x00,0x73,0x06,0x6e,0x00,0x62,0x06,0x6c,0x00,0x52,0x06,0x6a,0x00,0x41,0x06,0x68,0x00,0x30,0x06,  \
    0x66,0x00,0x20,0x06,0x64,0x00,0x10,0x06,0x62,0x00,0xff,0x05,0x60,0x00,0xef,0x05,0x5e,0x00,0xdf,0x05,0x5c,0x00,0xcf,0x05,0x5a,0x00,0xbf,0x05,0x58,0x00,0xaf,0x05,0x56,0x00,0xa0,0x05,0x54,0x00,0x90,0x05,0x52,0x00,0x80,0x05,0x50,0x00,0x71,0x05,0x4e,0x00,0x61,0x05,0x4c,0x00,0x52,0x05,0x4a,0x00,0x43,0x05,0x48,0x00,0x33,0x05,0x46,0x00,0x24,0x05,0x45,0x00,0x15,0x05,0x43,0x00,0x06,0x05,0x41,0x00,0xf7,0x04,0x3f,0x00,0xe8,0x04,0x3d,0x00,0xd9,0x04,0x3c,0x00,  \
    0xcb,0x04,0x3a,0x00,0xbc,0x04,0x38,0x00,0xad,0x04,0x36,0x00,0x9f,0x04,0x35,0x00,0x90,0x04,0x33,0x00,0x82,0x04,0x31,0x00,0x73,0x04,0x2f,0x00,0x65,0x04,0x2e,0x00,0x57,0x04,0x2c,0x00,0x48,0x04,0x2a,0x00,0x3a,0x04,0x29,0x00,0x2c,0x04,0x27,0x00,0x1e,0x04,0x25,0x00,0x10,0x04,0x24,0x00,0x02,0x04,0x22,0x00,0xf5,0x03,0x21,0x00,0xe7,0x03,0x1f,0x00,0xd9,0x03,0x1e,0x00,0xcb,0x03,0x1c,0x00,0xbe,0x03,0x1a,0x00,0xb0,0x03,0x19,0x00,0xa3,0x03,0x17,0x00,0x95,0x03,  \
    0x16,0x00,0x88,0x03,0x14,0x00,0x7b,0x03,0x13,0x00,0x6e,0x03,0x12,0x00,0x60,0x03,0x10,0x00,0x53,0x03,0x0f,0x00,0x46,0x03,0x0d,0x00,0x39,0x03,0x0c,0x00,0x2c,0x03,0x0b,0x00,0x20,0x03,0x09,0x00,0x13,0x03,0x08,0x00,0x06,0x03,0x07,0x00,0xf9,0x02,0x05,0x00,0xed,0x02,0x04,0x00,0xe0,0x02,0x03,0x00,0xd3,0x02,0x02,0x00,0xc7,0x02,0x00,0x00,0xba,0x02,0xff,0xff,0xae,0x02,0xfe,0xff,0xa1,0x02,0xfd,0xff,0x95,0x02,0xfc,0xff,0x89,0x02,0xfa,0xff,0x7c,0x02,0xf9,0xff,  \
    0x70,0x02,0xf8,0xff,0x64,0x02,0xf7,0xff,0x58,0x02,0xf6,0xff,0x4c,0x02,0xf5,0xff,0x40,0x02,0xf4,0xff,0x34,0x02,0xf3,0xff,0x28,0x02,0xf2,0xff,0x1c,0x02,0xf1,0xff,0x10,0x02,0xf0,0xff,0x04,0x02,0xef,0xff,0xf8,0x01,0xee,0xff,0xec,0x01,0xed,0xff,0xe1,0x01,0xec,0xff,0xd5,0x01,0xeb,0xff,0xc9,0x01,0xea,0xff,0xbe,0x01,0xea,0xff,0xb2,0x01,0xe9,0xff,0xa6,0x01,0xe8,0xff,0x9b,0x01,0xe7,0xff,0x8f,0x01,0xe6,0xff,0x84,0x01,0xe6,0xff,0x78,0x01,0xe5,0xff,0x6d,0x01,  \
    0xe4,0xff,0x61,0x01,0xe3,0xff,0x56,0x01,0xe3,0xff,0x4a,0x01,0xe2,0xff,0x3f,0x01,0xe1,0xff,0x34,0x01,0xe1,0xff,0x28,0x01,0xe0,0xff,0x1d,0x01,0xe0,0xff,0x12,0x01,0xdf,0xff,0x07,0x01,0xde,0xff,0xfb,0x00,0xde,0xff,0xf0,0x00,0xdd,0xff,0xe5,0x00,0xdd,0xff,0xda,0x00,0xdc,0xff,0xce,0x00,0xdc,0xff,0xc3,0x00,0xdc,0xff,0xb8,0x00,0xdb,0xff,0xad,0x00,0xdb,0xff,0xa2,0x00,0xda,0xff,0x97,0x00,0xda,0xff,0x8c,0x00,0xda,0xff,0x80,0x00,0xd9,0xff,0x75,0x00,0xd9,0xff,  \
    0x6a,0x00,0xd9,0xff,0x5f,0x00,0xd8,0xff,0x54,0x00,0xd8,0xff,0x49,0x00,0xd8,0xff,0x3e,0x00,0xd8,0xff,0x33,0x00,0xd8,0xff,0x28,0x00,0xd7,0xff,0x1d,0x00,0xd7,0xff,0x12,0x00,0xd7,0xff,0x07,0x00,0xd7,0xff,0xfc,0xff,0xd7,0xff,0xf1,0xff,0xd7,0xff,0xe6,0xff,0xd7,0xff,0xdb,0xff,0xd7,0xff,0xd0,0xff,0xd7,0xff,0xc5,0xff,0xd7,0xff,0xba,0xff,0xd7,0xff,0xaf,0xff,0xd7,0xff,0xa5,0xff,0xd7,0xff,0x9a,0xff,0xd7,0xff,0x8f,0xff,0xd7,0xff,0x84,0xff,0xd7,0xff,0x79,0xff,  \
    0xd7,0xff,0x6e,0xff,0xd7,0xff,0x63,0xff,0xd8,0xff,0x58,0xff,0xd8,0xff,0x4d,0xff,0xd8,0xff,0x42,0xff,0xd8,0xff,0x37,0xff,0xd8,0xff,0x2c,0xff,0xd9,0xff,0x21,0xff,0xd9,0xff,0x16,0xff,0xd9,0xff,0x0b,0xff,0xda,0xff,0x00,0xff,0xda,0xff,0xf5,0xfe,0xda,0xff,0xea,0xfe,0xdb,0xff,0xde,0xfe,0xdb,0xff,0xd3,0xfe,0xdc,0xff,0xc8,0xfe,0xdc,0xff,0xbd,0xfe,0xdd,0xff,0xb2,0xfe,0xdd,0xff,0xa7,0xfe,0xde,0xff,0x9c,0xfe,0xde,0xff,0x91,0xfe,0xdf,0xff,0x85,0xfe,0xdf,0xff,  \
    0x7a,0xfe,0xe0,0xff,0x6f,0xfe,0xe0,0xff,0x64,0xfe,0xe1,0xff,0x58,0xfe,0xe2,0xff,0x4d,0xfe,0xe2,0xff,0x42,0xfe,0xe3,0xff,0x36,0xfe,0xe4,0xff,0x2b,0xfe,0xe4,0xff,0x1f,0xfe,0xe5,0xff,0x14,0xfe,0xe6,0xff,0x09,0xfe,0xe6,0xff,0xfd,0xfd,0xe7,0xff,0xf2,0xfd,0xe8,0xff,0xe6,0xfd,0xe9,0xff,0xdb,0xfd,0xea,0xff,0xcf,0xfd,0xeb,0xff,0xc3,0xfd,0xeb,0xff,0xb8,0xfd,0xec,0xff,0xac,0xfd,0xed,0xff,0xa0,0xfd,0xee,0xff,0x94,0xfd,0xef,0xff,0x89,0xfd,0xf0,0xff,0x7d,0xfd,  \
    0xf1,0xff,0x71,0xfd,0xf2,0xff,0x65,0xfd,0xf3,0xff,0x59,0xfd,0xf4,0xff,0x4d,0xfd,0xf5,0xff,0x41,0xfd,0xf6,0xff,0x35,0xfd,0xf7,0xff,0x29,0xfd,0xf8,0xff,0x1d,0xfd,0xf9,0xff,0x11,0xfd,0xfb,0xff,0x05,0xfd,0xfc,0xff,0xf9,0xfc,0xfd,0xff,0xed,0xfc,0xfe,0xff,0xe0,0xfc,0xff,0xff,0xd4,0xfc,0x01,0x00,0xc8,0xfc,0x02,0x00,0xbb,0xfc,0x03,0x00,0xaf,0xfc,0x04,0x00,0xa2,0xfc,0x06,0x00,0x96,0xfc,0x07,0x00,0x89,0xfc,0x08,0x00,0x7d,0xfc,0x0a,0x00,0x70,0xfc,0x0b,0x00,  \
    0x63,0xfc,0x0c,0x00,0x56,0xfc,0x0e,0x00,0x4a,0xfc,0x0f,0x00,0x3d,0xfc,0x10,0x00,0x30,0xfc,0x12,0x00,0x23,0xfc,0x13,0x00,0x16,0xfc,0x15,0x00,0x09,0xfc,0x16,0x00,0xfc,0xfb,0x18,0x00,0xee,0xfb,0x19,0x00,0xe1,0xfb,0x1b,0x00,0xd4,0xfb,0x1c,0x00,0xc6,0xfb,0x1e,0x00,0xb9,0xfb,0x1f,0x00,0xab,0xfb,0x21,0x00,0x9e,0xfb,0x23,0x00,0x90,0xfb,0x24,0x00,0x83,0xfb,0x26,0x00,0x75,0xfb,0x27,0x00,0x67,0xfb,0x29,0x00,0x59,0xfb,0x2b,0x00,0x4b,0xfb,0x2c,0x00,0x3d,0xfb,  \
    0x2e,0x00,0x2f,0xfb,0x30,0x00,0x21,0xfb,0x32,0x00,0x13,0xfb,0x33,0x00,0x05,0xfb,0x35,0x00,0xf6,0xfa,0x37,0x00,0xe8,0xfa,0x39,0x00,0xd9,0xfa,0x3a,0x00,0xcb,0xfa,0x3c,0x00,0xbc,0xfa,0x3e,0x00,0xae,0xfa,0x40,0x00,0x9f,0xfa,0x42,0x00,0x90,0xfa,0x43,0x00,0x81,0xfa,0x45,0x00,0x73,0xfa,0x47,0x00,0x64,0xfa,0x49,0x00,0x54,0xfa,0x4b,0x00,0x45,0xfa,0x4d,0x00,0x36,0xfa,0x4f,0x00,0x27,0xfa,0x51,0x00,0x17,0xfa,0x53,0x00,0x08,0xfa,0x55,0x00,0xf8,0xf9,0x56,0x00,  \
    0xe9,0xf9,0x58,0x00,0xd9,0xf9,0x5a,0x00,0xc9,0xf9,0x5c,0x00,0xba,0xf9,0x5e,0x00,0xaa,0xf9,0x60,0x00,0x9a,0xf9,0x62,0x00,0x8a,0xf9,0x64,0x00,0x7a,0xf9,0x66,0x00,0x69,0xf9,0x68,0x00,0x59,0xf9,0x6a,0x00,0x49,0xf9,0x6d,0x00,0x38,0xf9,0x6f,0x00,0x27,0xf9,0x71,0x00,0x17,0xf9,0x73,0x00,0x06,0xf9,0x75,0x00,0xf5,0xf8,0x77,0x00,0xe4,0xf8,0x79,0x00,0xd3,0xf8,0x7b,0x00,0xc2,0xf8,0x7d,0x00,0xb1,0xf8,0x7f,0x00,0x9f,0xf8,0x81,0x00,0x8e,0xf8,0x83,0x00,0x7d,0xf8,  \
    0x86,0x00,0x6b,0xf8,0x88,0x00,0x59,0xf8,0x8a,0x00,0x48,0xf8,0x8c,0x00,0x36,0xf8,0x8e,0x00,0x24,0xf8,0x90,0x00,0x12,0xf8,0x92,0x00,0x00,0xf8,0x94,0x00,0xed,0xf7,0x97,0x00,0xdb,0xf7,0x99,0x00,0xc9,0xf7,0x9b,0x00,0xb6,0xf7,0x9d,0x00,0xa4,0xf7,0x9f,0x00,0x91,0xf7,0xa1,0x00,0x7e,0xf7,0xa4,0x00,0x6b,0xf7,0xa6,0x00,0x58,0xf7,0xa8,0x00,0x45,0xf7,0xaa,0x00,0x32,0xf7,0xac,0x00,0x1f,0xf7,0xae,0x00,0x0b,0xf7,0xb0,0x00,0xf8,0xf6,0xb3,0x00,0xe4,0xf6,0xb5,0x00,  \
    0xd0,0xf6,0xb7,0x00,0xbd,0xf6,0xb9,0x00,0xa9,0xf6,0xbb,0x00,0x95,0xf6,0xbd,0x00,0x80,0xf6,0xc0,0x00,0x6c,0xf6,0xc2,0x00,0x58,0xf6,0xc4,0x00,0x43,0xf6,0xc6,0x00,0x2f,0xf6,0xc8,0x00,0x1a,0xf6,0xca,0x00,0x05,0xf6,0xcc,0x00,0xf0,0xf5,0xce,0x00,0xdb,0xf5,0xd0,0x00,0xc6,0xf5,0xd2,0x00,0xb1,0xf5,0xd5,0x00,0x9b,0xf5,0xd7,0x00,0x86,0xf5,0xd9,0x00,0x70,0xf5,0xdb,0x00,0x5b,0xf5,0xdd,0x00,0x45,0xf5,0xdf,0x00,0x2f,0xf5,0xe1,0x00,0x19,0xf5,0xe3,0x00,0x03,0xf5,  \
    0xe5,0x00,0xec,0xf4,0xe7,0x00,0xd6,0xf4,0xe9,0x00,0xc0,0xf4,0xeb,0x00,0xa9,0xf4,0xed,0x00,0x92,0xf4,0xef,0x00,0x7b,0xf4,0xf1,0x00,0x64,0xf4,0xf3,0x00,0x4d,0xf4,0xf5,0x00,0x36,0xf4,0xf6,0x00,0x1f,0xf4,0xf8,0x00,0x08,0xf4,0xfa,0x00,0xf0,0xf3,0xfc,0x00,0xd8,0xf3,0xfe,0x00,0xc1,0xf3,0x00,0x01,0xa9,0xf3,0x02,0x01,0x91,0xf3,0x03,0x01,0x79,0xf3,0x05,0x01,0x60,0xf3,0x07,0x01,0x48,0xf3,0x09,0x01,0x2f,0xf3,0x0a,0x01,0x17,0xf3,0x0c,0x01,0xfe,0xf2,0x0e,0x01,  \
    0xe5,0xf2,0x0f,0x01,0xcc,0xf2,0x11,0x01,0xb3,0xf2,0x13,0x01,0x9a,0xf2,0x14,0x01,0x81,0xf2,0x16,0x01,0x67,0xf2,0x17,0x01,0x4d,0xf2,0x19,0x01,0x34,0xf2,0x1a,0x01,0x1a,0xf2,0x1c,0x01,0x00,0xf2,0x1d,0x01,0xe6,0xf1,0x1f,0x01,0xcb,0xf1,0x20,0x01,0xb1,0xf1,0x21,0x01,0x97,0xf1,0x23,0x01,0x7c,0xf1,0x24,0x01,0x61,0xf1,0x25,0x01,0x46,0xf1,0x27,0x01,0x2b,0xf1,0x28,0x01,0x10,0xf1,0x29,0x01,0xf5,0xf0,0x2a,0x01,0xd9,0xf0,0x2b,0x01,0xbe,0xf0,0x2d,0x01,0xa2,0xf0,  \
    0x2e,0x01,0x86,0xf0,0x2f,0x01,0x6a,0xf0,0x30,0x01,0x4e,0xf0,0x31,0x01,0x32,0xf0,0x32,0x01,0x16,0xf0,0x33,0x01,0xf9,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2e,0x01,0x13,0x10,0x2d,0x01,  \
    0xf7,0x0f,0x2c,0x01,0xda,0x0f,0x2c,0x01,0xbe,0x0f,0x2b,0x01,0xa1,0x0f,0x2a,0x01,0x85,0x0f,0x29,0x01,0x69,0x0f,0x28,0x01,0x4d,0x0f,0x27,0x01,0x31,0x0f,0x25,0x01,0x16,0x0f,0x24,0x01,0xfa,0x0e,0x23,0x01,0xdf,0x0e,0x22,0x01,0xc3,0x0e,0x21,0x01,0xa8,0x0e,0x20,0x01,0x8d,0x0e,0x1e,0x01,0x72,0x0e,0x1d,0x01,0x57,0x0e,0x1c,0x01,0x3d,0x0e,0x1a,0x01,0x22,0x0e,0x19,0x01,0x07,0x0e,0x18,0x01,0xed,0x0d,0x16,0x01,0xd3,0x0d,0x15,0x01,0xb9,0x0d,0x14,0x01,0x9f,0x0d,  \
    0x12,0x01,0x85,0x0d,0x11,0x01,0x6b,0x0d,0x0f,0x01,0x52,0x0d,0x0e,0x01,0x38,0x0d,0x0c,0x01,0x1f,0x0d,0x0b,0x01,0x05,0x0d,0x09,0x01,0xec,0x0c,0x07,0x01,0xd3,0x0c,0x06,0x01,0xba,0x0c,0x04,0x01,0xa1,0x0c,0x03,0x01,0x89,0x0c,0x01,0x01,0x70,0x0c,0xff,0x00,0x58,0x0c,0xfd,0x00,0x3f,0x0c,0xfc,0x00,0x27,0x0c,0xfa,0x00,0x0f,0x0c,0xf8,0x00,0xf7,0x0b,0xf7,0x00,0xdf,0x0b,0xf5,0x00,0xc7,0x0b,0xf3,0x00,0xb0,0x0b,0xf1,0x00,0x98,0x0b,0xef,0x00,0x81,0x0b,0xee,0x00,  \
    0x6a,0x0b,0xec,0x00,0x52,0x0b,0xea,0x00,0x3b,0x0b,0xe8,0x00,0x24,0x0b,0xe6,0x00,0x0e,0x0b,0xe4,0x00,0xf7,0x0a,0xe2,0x00,0xe0,0x0a,0xe0,0x00,0xca,0x0a,0xde,0x00,0xb3,0x0a,0xdc,0x00,0x9d,0x0a,0xdb,0x00,0x87,0x0a,0xd9,0x00,0x71,0x0a,0xd7,0x00,0x5b,0x0a,0xd5,0x00,0x45,0x0a,0xd3,0x00,0x2f,0x0a,0xd1,0x00,0x1a,0x0a,0xcf,0x00,0x04,0x0a,0xcd,0x00,0xef,0x09,0xcb,0x00,0xd9,0x09,0xc9,0x00,0xc4,0x09,0xc7,0x00,0xaf,0x09,0xc5,0x00,0x9a,0x09,0xc3,0x00,0x85,0x09,  \
    0xc1,0x00,0x70,0x09,0xbf,0x00,0x5b,0x09,0xbd,0x00,0x47,0x09,0xbb,0x00,0x32,0x09,0xb9,0x00,0x1e,0x09,0xb7,0x00,0x09,0x09,0xb5,0x00,0xf5,0x08,0xb3,0x00,0xe1,0x08,0xb1,0x00,0xcd,0x08,0xaf,0x00,0xb9,0x08,0xad,0x00,0xa5,0x08,0xaa,0x00,0x92,0x08,0xa8,0x00,0x7e,0x08,0xa6,0x00,0x6b,0x08,0xa4,0x00,0x57,0x08,0xa2,0x00,0x44,0x08,0xa0,0x00,0x31,0x08,0x9e,0x00,0x1d,0x08,0x9c,0x00,0x0a,0x08,0x9a,0x00,0xf8,0x07,0x98,0x00,0xe5,0x07,0x96,0x00,0xd2,0x07,0x94,0x00,  \
    0xbf,0x07,0x92,0x00,0xad,0x07,0x90,0x00,0x9a,0x07,0x8e,0x00,0x88,0x07,0x8c,0x00,0x76,0x07,0x8a,0x00,0x64,0x07,0x88,0x00,0x52,0x07,0x86,0x00,0x40,0x07,0x84,0x00,0x2e,0x07,0x82,0x00,0x1c,0x07,0x80,0x00,0x0b,0x07,0x7e,0x00,0xf9,0x06,0x7c,0x00,0xe8,0x06,0x7a,0x00,0xd6,0x06,0x78,0x00,0xc5,0x06,0x76,0x00,0xb4,0x06,0x74,0x00,0xa3,0x06,0x72,0x00,0x92,0x06,0x70,0x00,0x81,0x06,0x6e,0x00,0x70,0x06,0x6c,0x00,0x5f,0x06,0x6a,0x00,0x4f,0x06,0x68,0x00,0x3e,0x06,  \
    0x66,0x00,0x2e,0x06,0x64,0x00,0x1d,0x06,0x62,0x00,0x0d,0x06,0x60,0x00,0xfd,0x05,0x5e,0x00,0xed,0x05,0x5c,0x00,0xdc,0x05,0x5b,0x00,0xcc,0x05,0x59,0x00,0xbd,0x05,0x57,0x00,0xad,0x05,0x55,0x00,0x9d,0x05,0x53,0x00,0x8d,0x05,0x51,0x00,0x7e,0x05,0x4f,0x00,0x6e,0x05,0x4e,0x00,0x5f,0x05,0x4c,0x00,0x4f,0x05,0x4a,0x00,0x40,0x05,0x48,0x00,0x31,0x05,0x46,0x00,0x21,0x05,0x45,0x00,0x12,0x05,0x43,0x00,0x03,0x05,0x41,0x00,0xf4,0x04,0x3f,0x00,0xe6,0x04,0x3e,0x00,  \
    0xd7,0x04,0x3c,0x00,0xc8,0x04,0x3a,0x00,0xb9,0x04,0x38,0x00,0xab,0x04,0x37,0x00,0x9c,0x04,0x35,0x00,0x8d,0x04,0x33,0x00,0x7f,0x04,0x32,0x00,0x71,0x04,0x30,0x00,0x62,0x04,0x2f,0x00,0x54,0x04,0x2d,0x00,0x46,0x04,0x2b,0x00,0x38,0x04,0x2a,0x00,0x2a,0x04,0x28,0x00,0x1c,0x04,0x27,0x00,0x0e,0x04,0x25,0x00,0x00,0x04,0x24,0x00,0xf2,0x03,0x22,0x00,0xe4,0x03,0x21,0x00,0xd7,0x03,0x1f,0x00,0xc9,0x03,0x1e,0x00,0xbc,0x03,0x1c,0x00,0xae,0x03,0x1b,0x00,0xa1,0x03,  \
    0x19,0x00,0x93,0x03,0x18,0x00,0x86,0x03,0x16,0x00,0x79,0x03,0x15,0x00,0x6b,0x03,0x14,0x00,0x5e,0x03,0x12,0x00,0x51,0x03,0x11,0x00,0x44,0x03,0x10,0x00,0x37,0x03,0x0e,0x00,0x2a,0x03,0x0d,0x00,0x1d,0x03,0x0c,0x00,0x11,0x03,0x0a,0x00,0x04,0x03,0x09,0x00,0xf7,0x02,0x08,0x00,0xea,0x02,0x07,0x00,0xde,0x02,0x06,0x00,0xd1,0x02,0x04,0x00,0xc5,0x02,0x03,0x00,0xb8,0x02,0x02,0x00,0xac,0x02,0x01,0x00,0x9f,0x02,0x00,0x00,0x93,0x02,0xff,0xff,0x87,0x02,0xfd,0xff,  \
    0x7b,0x02,0xfc,0xff,0x6e,0x02,0xfb,0xff,0x62,0x02,0xfa,0xff,0x56,0x02,0xf9,0xff,0x4a,0x02,0xf8,0xff,0x3e,0x02,0xf7,0xff,0x32,0x02,0xf6,0xff,0x26,0x02,0xf5,0xff,0x1a,0x02,0xf4,0xff,0x0e,0x02,0xf3,0xff,0x02,0x02,0xf2,0xff,0xf7,0x01,0xf2,0xff,0xeb,0x01,0xf1,0xff,0xdf,0x01,0xf0,0xff,0xd3,0x01,0xef,0xff,0xc8,0x01,0xee,0xff,0xbc,0x01,0xed,0xff,0xb0,0x01,0xed,0xff,0xa5,0x01,0xec,0xff,0x99,0x01,0xeb,0xff,0x8e,0x01,0xea,0xff,0x82,0x01,0xe9,0xff,0x77,0x01,  \
    0xe9,0xff,0x6b,0x01,0xe8,0xff,0x60,0x01,0xe7,0xff,0x55,0x01,0xe7,0xff,0x49,0x01,0xe6,0xff,0x3e,0x01,0xe6,0xff,0x33,0x01,0xe5,0xff,0x27,0x01,0xe4,0xff,0x1c,0x01,0xe4,0xff,0x11,0x01,0xe3,0xff,0x06,0x01,0xe3,0xff,0xfa,0x00,0xe2,0xff,0xef,0x00,0xe2,0xff,0xe4,0x00,0xe1,0xff,0xd9,0x00,0xe1,0xff,0xce,0x00,0xe0,0xff,0xc2,0x00,0xe0,0xff,0xb7,0x00,0xdf,0xff,0xac,0x00,0xdf,0xff,0xa1,0x00,0xdf,0xff,0x96,0x00,0xde,0xff,0x8b,0x00,0xde,0xff,0x80,0x00,0xde,0xff,  \
    0x75,0x00,0xdd,0xff,0x6a,0x00,0xdd,0xff,0x5f,0x00,0xdd,0xff,0x54,0x00,0xdd,0xff,0x49,0x00,0xdc,0xff,0x3e,0x00,0xdc,0xff,0x33,0x00,0xdc,0xff,0x28,0x00,0xdc,0xff,0x1d,0x00,0xdc,0xff,0x12,0x00,0xdc,0xff,0x07,0x00,0xdc,0xff,0xfc,0xff,0xdb,0xff,0xf1,0xff,0xdb,0xff,0xe6,0xff,0xdb,0xff,0xdb,0xff,0xdb,0xff,0xd0,0xff,0xdb,0xff,0xc5,0xff,0xdb,0xff,0xba,0xff,0xdb,0xff,0xb0,0xff,0xdb,0xff,0xa5,0xff,0xdb,0xff,0x9a,0xff,0xdb,0xff,0x8f,0xff,0xdc,0xff,0x84,0xff,  \
    0xdc,0xff,0x79,0xff,0xdc,0xff,0x6e,0xff,0xdc,0xff,0x63,0xff,0xdc,0xff,0x58,0xff,0xdc,0xff,0x4d,0xff,0xdd,0xff,0x42,0xff,0xdd,0xff,0x37,0xff,0xdd,0xff,0x2c,0xff,0xdd,0xff,0x21,0xff,0xde,0xff,0x16,0xff,0xde,0xff,0x0b,0xff,0xde,0xff,0x00,0xff,0xde,0xff,0xf5,0xfe,0xdf,0xff,0xea,0xfe,0xdf,0xff,0xdf,0xfe,0xe0,0xff,0xd4,0xfe,0xe0,0xff,0xc9,0xfe,0xe0,0xff,0xbe,0xfe,0xe1,0xff,0xb3,0xfe,0xe1,0xff,0xa8,0xfe,0xe2,0xff,0x9d,0xfe,0xe2,0xff,0x91,0xfe,0xe3,0xff,  \
    0x86,0xfe,0xe3,0xff,0x7b,0xfe,0xe4,0xff,0x70,0xfe,0xe4,0xff,0x65,0xfe,0xe5,0xff,0x59,0xfe,0xe6,0xff,0x4e,0xfe,0xe6,0xff,0x43,0xfe,0xe7,0xff,0x37,0xfe,0xe8,0xff,0x2c,0xfe,0xe8,0xff,0x21,0xfe,0xe9,0xff,0x15,0xfe,0xea,0xff,0x0a,0xfe,0xea,0xff,0xff,0xfd,0xeb,0xff,0xf3,0xfd,0xec,0xff,0xe8,0xfd,0xed,0xff,0xdc,0xfd,0xed,0xff,0xd0,0xfd,0xee,0xff,0xc5,0xfd,0xef,0xff,0xb9,0xfd,0xf0,0xff,0xae,0xfd,0xf1,0xff,0xa2,0xfd,0xf2,0xff,0x96,0xfd,0xf3,0xff,0x8a,0xfd,  \
    0xf4,0xff,0x7f,0xfd,0xf4,0xff,0x73,0xfd,0xf5,0xff,0x67,0xfd,0xf6,0xff,0x5b,0xfd,0xf7,0xff,0x4f,0xfd,0xf8,0xff,0x43,0xfd,0xf9,0xff,0x37,0xfd,0xfa,0xff,0x2b,0xfd,0xfb,0xff,0x1f,0xfd,0xfd,0xff,0x13,0xfd,0xfe,0xff,0x07,0xfd,0xff,0xff,0xfb,0xfc,0x00,0x00,0xef,0xfc,0x01,0x00,0xe2,0xfc,0x02,0x00,0xd6,0xfc,0x03,0x00,0xca,0xfc,0x05,0x00,0xbd,0xfc,0x06,0x00,0xb1,0xfc,0x07,0x00,0xa4,0xfc,0x08,0x00,0x98,0xfc,0x09,0x00,0x8b,0xfc,0x0b,0x00,0x7f,0xfc,0x0c,0x00,  \
    0x72,0xfc,0x0d,0x00,0x65,0xfc,0x0f,0x00,0x59,0xfc,0x10,0x00,0x4c,0xfc,0x11,0x00,0x3f,0xfc,0x13,0x00,0x32,0xfc,0x14,0x00,0x25,0xfc,0x15,0x00,0x18,0xfc,0x17,0x00,0x0b,0xfc,0x18,0x00,0xfe,0xfb,0x1a,0x00,0xf1,0xfb,0x1b,0x00,0xe3,0xfb,0x1c,0x00,0xd6,0xfb,0x1e,0x00,0xc9,0xfb,0x1f,0x00,0xbb,0xfb,0x21,0x00,0xae,0xfb,0x22,0x00,0xa0,0xfb,0x24,0x00,0x93,0xfb,0x25,0x00,0x85,0xfb,0x27,0x00,0x77,0xfb,0x29,0x00,0x6a,0xfb,0x2a,0x00,0x5c,0xfb,0x2c,0x00,0x4e,0xfb,  \
    0x2d,0x00,0x40,0xfb,0x2f,0x00,0x32,0xfb,0x31,0x00,0x24,0xfb,0x32,0x00,0x16,0xfb,0x34,0x00,0x07,0xfb,0x36,0x00,0xf9,0xfa,0x37,0x00,0xeb,0xfa,0x39,0x00,0xdc,0xfa,0x3b,0x00,0xce,0xfa,0x3c,0x00,0xbf,0xfa,0x3e,0x00,0xb1,0xfa,0x40,0x00,0xa2,0xfa,0x42,0x00,0x93,0xfa,0x43,0x00,0x84,0xfa,0x45,0x00,0x75,0xfa,0x47,0x00,0x66,0xfa,0x49,0x00,0x57,0xfa,0x4b,0x00,0x48,0xfa,0x4c,0x00,0x39,0xfa,0x4e,0x00,0x2a,0xfa,0x50,0x00,0x1a,0xfa,0x52,0x00,0x0b,0xfa,0x54,0x00,  \
    0xfb,0xf9,0x56,0x00,0xec,0xf9,0x57,0x00,0xdc,0xf9,0x59,0x00,0xcc,0xf9,0x5b,0x00,0xbd,0xf9,0x5d,0x00,0xad,0xf9,0x5f,0x00,0x9d,0xf9,0x61,0x00,0x8d,0xf9,0x63,0x00,0x7c,0xf9,0x65,0x00,0x6c,0xf9,0x67,0x00,0x5c,0xf9,0x69,0x00,0x4b,0xf9,0x6b,0x00,0x3b,0xf9,0x6d,0x00,0x2a,0xf9,0x6f,0x00,0x1a,0xf9,0x71,0x00,0x09,0xf9,0x72,0x00,0xf8,0xf8,0x74,0x00,0xe7,0xf8,0x76,0x00,0xd6,0xf8,0x78,0x00,0xc5,0xf8,0x7a,0x00,0xb4,0xf8,0x7c,0x00,0xa2,0xf8,0x7e,0x00,0x91,0xf8,  \
    0x80,0x00,0x80,0xf8,0x83,0x00,0x6e,0xf8,0x85,0x00,0x5c,0xf8,0x87,0x00,0x4b,0xf8,0x89,0x00,0x39,0xf8,0x8b,0x00,0x27,0xf8,0x8d,0x00,0x15,0xf8,0x8f,0x00,0x03,0xf8,0x91,0x00,0xf0,0xf7,0x93,0x00,0xde,0xf7,0x95,0x00,0xcc,0xf7,0x97,0x00,0xb9,0xf7,0x99,0x00,0xa6,0xf7,0x9b,0x00,0x94,0xf7,0x9d,0x00,0x81,0xf7,0x9f,0x00,0x6e,0xf7,0xa1,0x00,0x5b,0xf7,0xa3,0x00,0x48,0xf7,0xa5,0x00,0x35,0xf7,0xa7,0x00,0x21,0xf7,0xa9,0x00,0x0e,0xf7,0xac,0x00,0xfa,0xf6,0xae,0x00,  \
    0xe7,0xf6,0xb0,0x00,0xd3,0xf6,0xb2,0x00,0xbf,0xf6,0xb4,0x00,0xab,0xf6,0xb6,0x00,0x97,0xf6,0xb8,0x00,0x83,0xf6,0xba,0x00,0x6f,0xf6,0xbc,0x00,0x5b,0xf6,0xbe,0x00,0x46,0xf6,0xc0,0x00,0x31,0xf6,0xc2,0x00,0x1d,0xf6,0xc4,0x00,0x08,0xf6,0xc6,0x00,0xf3,0xf5,0xc8,0x00,0xde,0xf5,0xca,0x00,0xc9,0xf5,0xcc,0x00,0xb3,0xf5,0xce,0x00,0x9e,0xf5,0xd0,0x00,0x89,0xf5,0xd2,0x00,0x73,0xf5,0xd4,0x00,0x5d,0xf5,0xd6,0x00,0x47,0xf5,0xd8,0x00,0x31,0xf5,0xda,0x00,0x1b,0xf5,  \
    0xdc,0x00,0x05,0xf5,0xde,0x00,0xef,0xf4,0xdf,0x00,0xd9,0xf4,0xe1,0x00,0xc2,0xf4,0xe3,0x00,0xac,0xf4,0xe5,0x00,0x95,0xf4,0xe7,0x00,0x7e,0xf4,0xe9,0x00,0x67,0xf4,0xeb,0x00,0x50,0xf4,0xec,0x00,0x39,0xf4,0xee,0x00,0x21,0xf4,0xf0,0x00,0x0a,0xf4,0xf2,0x00,0xf3,0xf3,0xf4,0x00,0xdb,0xf3,0xf5,0x00,0xc3,0xf3,0xf7,0x00,0xab,0xf3,0xf9,0x00,0x93,0xf3,0xfb,0x00,0x7b,0xf3,0xfc,0x00,0x63,0xf3,0xfe,0x00,0x4a,0xf3,0x00,0x01,0x32,0xf3,0x01,0x01,0x19,0xf3,0x03,0x01,  \
    0x00,0xf3,0x04,0x01,0xe8,0xf2,0x06,0x01,0xcf,0xf2,0x08,0x01,0xb5,0xf2,0x09,0x01,0x9c,0xf2,0x0b,0x01,0x83,0xf2,0x0c,0x01,0x69,0xf2,0x0e,0x01,0x50,0xf2,0x0f,0x01,0x36,0xf2,0x10,0x01,0x1c,0xf2,0x12,0x01,0x02,0xf2,0x13,0x01,0xe8,0xf1,0x15,0x01,0xce,0xf1,0x16,0x01,0xb3,0xf1,0x17,0x01,0x99,0xf1,0x19,0x01,0x7e,0xf1,0x1a,0x01,0x63,0xf1,0x1b,0x01,0x48,0xf1,0x1c,0x01,0x2d,0xf1,0x1d,0x01,0x12,0xf1,0x1f,0x01,0xf7,0xf0,0x20,0x01,0xdc,0xf0,0x21,0x01,0xc0,0xf0,  \
    0x22,0x01,0xa4,0xf0,0x23,0x01,0x88,0xf0,0x24,0x01,0x6c,0xf0,0x25,0x01,0x50,0xf0,0x26,0x01,0x34,0xf0,0x27,0x01,0x18,0xf0,0x28,0x01,0xfb,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x23,0x01,  \
    0x11,0x10,0x23,0x01,0xf5,0x0f,0x22,0x01,0xd8,0x0f,0x21,0x01,0xbc,0x0f,0x20,0x01,0x9f,0x0f,0x1f,0x01,0x83,0x0f,0x1e,0x01,0x67,0x0f,0x1d,0x01,0x4b,0x0f,0x1c,0x01,0x2f,0x0f,0x1b,0x01,0x14,0x0f,0x1a,0x01,0xf8,0x0e,0x19,0x01,0xdd,0x0e,0x18,0x01,0xc1,0x0e,0x17,0x01,0xa6,0x0e,0x15,0x01,0x8b,0x0e,0x14,0x01,0x70,0x0e,0x13,0x01,0x55,0x0e,0x12,0x01,0x3b,0x0e,0x11,0x01,0x20,0x0e,0x0f,0x01,0x05,0x0e,0x0e,0x01,0xeb,0x0d,0x0d,0x01,0xd1,0x0d,0x0b,0x01,0xb7,0x0d,  \
    0x0a,0x01,0x9d,0x0d,0x09,0x01,0x83,0x0d,0x07,0x01,0x69,0x0d,0x06,0x01,0x4f,0x0d,0x04,0x01,0x36,0x0d,0x03,0x01,0x1d,0x0d,0x01,0x01,0x03,0x0d,0x00,0x01,0xea,0x0c,0xfe,0x00,0xd1,0x0c,0xfd,0x00,0xb8,0x0c,0xfb,0x00,0x9f,0x0c,0xfa,0x00,0x87,0x0c,0xf8,0x00,0x6e,0x0c,0xf7,0x00,0x56,0x0c,0xf5,0x00,0x3d,0x0c,0xf3,0x00,0x25,0x0c,0xf2,0x00,0x0d,0x0c,0xf0,0x00,0xf5,0x0b,0xee,0x00,0xdd,0x0b,0xed,0x00,0xc5,0x0b,0xeb,0x00,0xae,0x0b,0xe9,0x00,0x96,0x0b,0xe8,0x00,  \
    0x7f,0x0b,0xe6,0x00,0x67,0x0b,0xe4,0x00,0x50,0x0b,0xe2,0x00,0x39,0x0b,0xe0,0x00,0x22,0x0b,0xdf,0x00,0x0b,0x0b,0xdd,0x00,0xf5,0x0a,0xdb,0x00,0xde,0x0a,0xd9,0x00,0xc7,0x0a,0xd7,0x00,0xb1,0x0a,0xd6,0x00,0x9b,0x0a,0xd4,0x00,0x85,0x0a,0xd2,0x00,0x6f,0x0a,0xd0,0x00,0x59,0x0a,0xce,0x00,0x43,0x0a,0xcc,0x00,0x2d,0x0a,0xca,0x00,0x17,0x0a,0xc8,0x00,0x02,0x0a,0xc7,0x00,0xec,0x09,0xc5,0x00,0xd7,0x09,0xc3,0x00,0xc2,0x09,0xc1,0x00,0xac,0x09,0xbf,0x00,0x97,0x09,  \
    0xbd,0x00,0x82,0x09,0xbb,0x00,0x6e,0x09,0xb9,0x00,0x59,0x09,0xb7,0x00,0x44,0x09,0xb5,0x00,0x30,0x09,0xb3,0x00,0x1b,0x09,0xb2,0x00,0x07,0x09,0xb0,0x00,0xf3,0x08,0xae,0x00,0xdf,0x08,0xac,0x00,0xcb,0x08,0xaa,0x00,0xb7,0x08,0xa8,0x00,0xa3,0x08,0xa6,0x00,0x8f,0x08,0xa4,0x00,0x7b,0x08,0xa2,0x00,0x68,0x08,0xa0,0x00,0x55,0x08,0x9e,0x00,0x41,0x08,0x9c,0x00,0x2e,0x08,0x9a,0x00,0x1b,0x08,0x98,0x00,0x08,0x08,0x96,0x00,0xf5,0x07,0x94,0x00,0xe2,0x07,0x92,0x00,  \
    0xcf,0x07,0x90,0x00,0xbd,0x07,0x8e,0x00,0xaa,0x07,0x8c,0x00,0x98,0x07,0x8b,0x00,0x86,0x07,0x89,0x00,0x73,0x07,0x87,0x00,0x61,0x07,0x85,0x00,0x4f,0x07,0x83,0x00,0x3d,0x07,0x81,0x00,0x2c,0x07,0x7f,0x00,0x1a,0x07,0x7d,0x00,0x08,0x07,0x7b,0x00,0xf7,0x06,0x79,0x00,0xe5,0x06,0x77,0x00,0xd4,0x06,0x75,0x00,0xc3,0x06,0x73,0x00,0xb1,0x06,0x72,0x00,0xa0,0x06,0x70,0x00,0x8f,0x06,0x6e,0x00,0x7e,0x06,0x6c,0x00,0x6e,0x06,0x6a,0x00,0x5d,0x06,0x68,0x00,0x4c,0x06,  \
    0x66,0x00,0x3c,0x06,0x64,0x00,0x2b,0x06,0x63,0x00,0x1b,0x06,0x61,0x00,0x0a,0x06,0x5f,0x00,0xfa,0x05,0x5d,0x00,0xea,0x05,0x5b,0x00,0xda,0x05,0x5a,0x00,0xca,0x05,0x58,0x00,0xba,0x05,0x56,0x00,0xaa,0x05,0x54,0x00,0x9a,0x05,0x52,0x00,0x8b,0x05,0x51,0x00,0x7b,0x05,0x4f,0x00,0x6b,0x05,0x4d,0x00,0x5c,0x05,0x4b,0x00,0x4d,0x05,0x4a,0x00,0x3d,0x05,0x48,0x00,0x2e,0x05,0x46,0x00,0x1f,0x05,0x45,0x00,0x10,0x05,0x43,0x00,0x01,0x05,0x41,0x00,0xf2,0x04,0x40,0x00,  \
    0xe3,0x04,0x3e,0x00,0xd4,0x04,0x3c,0x00,0xc5,0x04,0x3b,0x00,0xb7,0x04,0x39,0x00,0xa8,0x04,0x37,0x00,0x99,0x04,0x36,0x00,0x8b,0x04,0x34,0x00,0x7d,0x04,0x33,0x00,0x6e,0x04,0x31,0x00,0x60,0x04,0x30,0x00,0x52,0x04,0x2e,0x00,0x43,0x04,0x2c,0x00,0x35,0x04,0x2b,0x00,0x27,0x04,0x29,0x00,0x19,0x04,0x28,0x00,0x0b,0x04,0x27,0x00,0xfe,0x03,0x25,0x00,0xf0,0x03,0x24,0x00,0xe2,0x03,0x22,0x00,0xd4,0x03,0x21,0x00,0xc7,0x03,0x1f,0x00,0xb9,0x03,0x1e,0x00,0xac,0x03,  \
    0x1d,0x00,0x9e,0x03,0x1b,0x00,0x91,0x03,0x1a,0x00,0x84,0x03,0x18,0x00,0x76,0x03,0x17,0x00,0x69,0x03,0x16,0x00,0x5c,0x03,0x15,0x00,0x4f,0x03,0x13,0x00,0x42,0x03,0x12,0x00,0x35,0x03,0x11,0x00,0x28,0x03,0x0f,0x00,0x1b,0x03,0x0e,0x00,0x0f,0x03,0x0d,0x00,0x02,0x03,0x0c,0x00,0xf5,0x02,0x0b,0x00,0xe9,0x02,0x09,0x00,0xdc,0x02,0x08,0x00,0xcf,0x02,0x07,0x00,0xc3,0x02,0x06,0x00,0xb6,0x02,0x05,0x00,0xaa,0x02,0x04,0x00,0x9e,0x02,0x03,0x00,0x91,0x02,0x02,0x00,  \
    0x85,0x02,0x01,0x00,0x79,0x02,0x00,0x00,0x6d,0x02,0xff,0xff,0x60,0x02,0xfe,0xff,0x54,0x02,0xfd,0xff,0x48,0x02,0xfc,0xff,0x3c,0x02,0xfb,0xff,0x30,0x02,0xfa,0xff,0x24,0x02,0xf9,0xff,0x19,0x02,0xf8,0xff,0x0d,0x02,0xf7,0xff,0x01,0x02,0xf6,0xff,0xf5,0x01,0xf5,0xff,0xe9,0x01,0xf4,0xff,0xde,0x01,0xf4,0xff,0xd2,0x01,0xf3,0xff,0xc6,0x01,0xf2,0xff,0xbb,0x01,0xf1,0xff,0xaf,0x01,0xf0,0xff,0xa4,0x01,0xf0,0xff,0x98,0x01,0xef,0xff,0x8d,0x01,0xee,0xff,0x81,0x01,  \
    0xee,0xff,0x76,0x01,0xed,0xff,0x6a,0x01,0xec,0xff,0x5f,0x01,0xec,0xff,0x53,0x01,0xeb,0xff,0x48,0x01,0xea,0xff,0x3d,0x01,0xea,0xff,0x32,0x01,0xe9,0xff,0x26,0x01,0xe9,0xff,0x1b,0x01,0xe8,0xff,0x10,0x01,0xe7,0xff,0x05,0x01,0xe7,0xff,0xf9,0x00,0xe7,0xff,0xee,0x00,0xe6,0xff,0xe3,0x00,0xe6,0xff,0xd8,0x00,0xe5,0xff,0xcd,0x00,0xe5,0xff,0xc2,0x00,0xe4,0xff,0xb7,0x00,0xe4,0xff,0xab,0x00,0xe4,0xff,0xa0,0x00,0xe3,0xff,0x95,0x00,0xe3,0xff,0x8a,0x00,0xe3,0xff,  \
    0x7f,0x00,0xe2,0xff,0x74,0x00,0xe2,0xff,0x69,0x00,0xe2,0xff,0x5e,0x00,0xe1,0xff,0x53,0x00,0xe1,0xff,0x48,0x00,0xe1,0xff,0x3d,0x00,0xe1,0xff,0x32,0x00,0xe1,0xff,0x28,0x00,0xe1,0xff,0x1d,0x00,0xe0,0xff,0x12,0x00,0xe0,0xff,0x07,0x00,0xe0,0xff,0xfc,0xff,0xe0,0xff,0xf1,0xff,0xe0,0xff,0xe6,0xff,0xe0,0xff,0xdb,0xff,0xe0,0xff,0xd0,0xff,0xe0,0xff,0xc5,0xff,0xe0,0xff,0xba,0xff,0xe0,0xff,0xb0,0xff,0xe0,0xff,0xa5,0xff,0xe0,0xff,0x9a,0xff,0xe0,0xff,0x8f,0xff,  \
    0xe0,0xff,0x84,0xff,0xe0,0xff,0x79,0xff,0xe0,0xff,0x6e,0xff,0xe1,0xff,0x63,0xff,0xe1,0xff,0x58,0xff,0xe1,0xff,0x4d,0xff,0xe1,0xff,0x43,0xff,0xe1,0xff,0x38,0xff,0xe2,0xff,0x2d,0xff,0xe2,0xff,0x22,0xff,0xe2,0xff,0x17,0xff,0xe2,0xff,0x0c,0xff,0xe3,0xff,0x01,0xff,0xe3,0xff,0xf6,0xfe,0xe3,0xff,0xeb,0xfe,0xe4,0xff,0xe0,0xfe,0xe4,0xff,0xd5,0xfe,0xe4,0xff,0xca,0xfe,0xe5,0xff,0xbf,0xfe,0xe5,0xff,0xb4,0xfe,0xe6,0xff,0xa9,0xfe,0xe6,0xff,0x9e,0xfe,0xe7,0xff,  \
    0x92,0xfe,0xe7,0xff,0x87,0xfe,0xe8,0xff,0x7c,0xfe,0xe8,0xff,0x71,0xfe,0xe9,0xff,0x66,0xfe,0xe9,0xff,0x5a,0xfe,0xea,0xff,0x4f,0xfe,0xea,0xff,0x44,0xfe,0xeb,0xff,0x39,0xfe,0xec,0xff,0x2d,0xfe,0xec,0xff,0x22,0xfe,0xed,0xff,0x17,0xfe,0xee,0xff,0x0b,0xfe,0xee,0xff,0x00,0xfe,0xef,0xff,0xf4,0xfd,0xf0,0xff,0xe9,0xfd,0xf1,0xff,0xdd,0xfd,0xf1,0xff,0xd2,0xfd,0xf2,0xff,0xc6,0xfd,0xf3,0xff,0xbb,0xfd,0xf4,0xff,0xaf,0xfd,0xf5,0xff,0xa3,0xfd,0xf5,0xff,0x98,0xfd,  \
    0xf6,0xff,0x8c,0xfd,0xf7,0xff,0x80,0xfd,0xf8,0xff,0x74,0xfd,0xf9,0xff,0x69,0xfd,0xfa,0xff,0x5d,0xfd,0xfb,0xff,0x51,0xfd,0xfc,0xff,0x45,0xfd,0xfd,0xff,0x39,0xfd,0xfe,0xff,0x2d,0xfd,0xff,0xff,0x21,0xfd,0x00,0x00,0x15,0xfd,0x01,0x00,0x09,0xfd,0x02,0x00,0xfd,0xfc,0x03,0x00,0xf1,0xfc,0x04,0x00,0xe4,0xfc,0x05,0x00,0xd8,0xfc,0x06,0x00,0xcc,0xfc,0x07,0x00,0xbf,0xfc,0x08,0x00,0xb3,0xfc,0x0a,0x00,0xa7,0xfc,0x0b,0x00,0x9a,0xfc,0x0c,0x00,0x8e,0xfc,0x0d,0x00,  \
    0x81,0xfc,0x0e,0x00,0x74,0xfc,0x10,0x00,0x68,0xfc,0x11,0x00,0x5b,0xfc,0x12,0x00,0x4e,0xfc,0x13,0x00,0x41,0xfc,0x15,0x00,0x34,0xfc,0x16,0x00,0x27,0xfc,0x17,0x00,0x1a,0xfc,0x19,0x00,0x0d,0xfc,0x1a,0x00,0x00,0xfc,0x1b,0x00,0xf3,0xfb,0x1d,0x00,0xe6,0xfb,0x1e,0x00,0xd9,0xfb,0x20,0x00,0xcb,0xfb,0x21,0x00,0xbe,0xfb,0x22,0x00,0xb0,0xfb,0x24,0x00,0xa3,0xfb,0x25,0x00,0x95,0xfb,0x27,0x00,0x88,0xfb,0x28,0x00,0x7a,0xfb,0x2a,0x00,0x6c,0xfb,0x2b,0x00,0x5e,0xfb,  \
    0x2d,0x00,0x50,0xfb,0x2e,0x00,0x42,0xfb,0x30,0x00,0x34,0xfb,0x31,0x00,0x26,0xfb,0x33,0x00,0x18,0xfb,0x35,0x00,0x0a,0xfb,0x36,0x00,0xfc,0xfa,0x38,0x00,0xed,0xfa,0x39,0x00,0xdf,0xfa,0x3b,0x00,0xd0,0xfa,0x3d,0x00,0xc2,0xfa,0x3e,0x00,0xb3,0xfa,0x40,0x00,0xa4,0xfa,0x42,0x00,0x96,0xfa,0x43,0x00,0x87,0xfa,0x45,0x00,0x78,0xfa,0x47,0x00,0x69,0xfa,0x48,0x00,0x5a,0xfa,0x4a,0x00,0x4b,0xfa,0x4c,0x00,0x3c,0xfa,0x4e,0x00,0x2c,0xfa,0x4f,0x00,0x1d,0xfa,0x51,0x00,  \
    0x0e,0xfa,0x53,0x00,0xfe,0xf9,0x55,0x00,0xee,0xf9,0x56,0x00,0xdf,0xf9,0x58,0x00,0xcf,0xf9,0x5a,0x00,0xbf,0xf9,0x5c,0x00,0xaf,0xf9,0x5e,0x00,0x9f,0xf9,0x5f,0x00,0x8f,0xf9,0x61,0x00,0x7f,0xf9,0x63,0x00,0x6f,0xf9,0x65,0x00,0x5f,0xf9,0x67,0x00,0x4e,0xf9,0x69,0x00,0x3e,0xf9,0x6b,0x00,0x2d,0xf9,0x6c,0x00,0x1c,0xf9,0x6e,0x00,0x0c,0xf9,0x70,0x00,0xfb,0xf8,0x72,0x00,0xea,0xf8,0x74,0x00,0xd9,0xf8,0x76,0x00,0xc8,0xf8,0x78,0x00,0xb6,0xf8,0x7a,0x00,0xa5,0xf8,  \
    0x7c,0x00,0x94,0xf8,0x7e,0x00,0x82,0xf8,0x80,0x00,0x71,0xf8,0x81,0x00,0x5f,0xf8,0x83,0x00,0x4d,0xf8,0x85,0x00,0x3b,0xf8,0x87,0x00,0x29,0xf8,0x89,0x00,0x17,0xf8,0x8b,0x00,0x05,0xf8,0x8d,0x00,0xf3,0xf7,0x8f,0x00,0xe1,0xf7,0x91,0x00,0xce,0xf7,0x93,0x00,0xbc,0xf7,0x95,0x00,0xa9,0xf7,0x97,0x00,0x96,0xf7,0x99,0x00,0x84,0xf7,0x9b,0x00,0x71,0xf7,0x9d,0x00,0x5e,0xf7,0x9f,0x00,0x4b,0xf7,0xa1,0x00,0x37,0xf7,0xa3,0x00,0x24,0xf7,0xa5,0x00,0x11,0xf7,0xa7,0x00,  \
    0xfd,0xf6,0xa9,0x00,0xea,0xf6,0xab,0x00,0xd6,0xf6,0xad,0x00,0xc2,0xf6,0xae,0x00,0xae,0xf6,0xb0,0x00,0x9a,0xf6,0xb2,0x00,0x86,0xf6,0xb4,0x00,0x72,0xf6,0xb6,0x00,0x5d,0xf6,0xb8,0x00,0x49,0xf6,0xba,0x00,0x34,0xf6,0xbc,0x00,0x1f,0xf6,0xbe,0x00,0x0a,0xf6,0xc0,0x00,0xf6,0xf5,0xc2,0x00,0xe0,0xf5,0xc4,0x00,0xcb,0xf5,0xc6,0x00,0xb6,0xf5,0xc7,0x00,0xa1,0xf5,0xc9,0x00,0x8b,0xf5,0xcb,0x00,0x76,0xf5,0xcd,0x00,0x60,0xf5,0xcf,0x00,0x4a,0xf5,0xd1,0x00,0x34,0xf5,  \
    0xd3,0x00,0x1e,0xf5,0xd4,0x00,0x08,0xf5,0xd6,0x00,0xf1,0xf4,0xd8,0x00,0xdb,0xf4,0xda,0x00,0xc5,0xf4,0xdc,0x00,0xae,0xf4,0xdd,0x00,0x97,0xf4,0xdf,0x00,0x80,0xf4,0xe1,0x00,0x69,0xf4,0xe3,0x00,0x52,0xf4,0xe4,0x00,0x3b,0xf4,0xe6,0x00,0x24,0xf4,0xe8,0x00,0x0c,0xf4,0xea,0x00,0xf5,0xf3,0xeb,0x00,0xdd,0xf3,0xed,0x00,0xc5,0xf3,0xef,0x00,0xae,0xf3,0xf0,0x00,0x95,0xf3,0xf2,0x00,0x7d,0xf3,0xf4,0x00,0x65,0xf3,0xf5,0x00,0x4d,0xf3,0xf7,0x00,0x34,0xf3,0xf8,0x00,  \
    0x1b,0xf3,0xfa,0x00,0x03,0xf3,0xfb,0x00,0xea,0xf2,0xfd,0x00,0xd1,0xf2,0xfe,0x00,0xb8,0xf2,0x00,0x01,0x9e,0xf2,0x01,0x01,0x85,0xf2,0x03,0x01,0x6c,0xf2,0x04,0x01,0x52,0xf2,0x05,0x01,0x38,0xf2,0x07,0x01,0x1e,0xf2,0x08,0x01,0x04,0xf2,0x09,0x01,0xea,0xf1,0x0b,0x01,0xd0,0xf1,0x0c,0x01,0xb5,0xf1,0x0d,0x01,0x9b,0xf1,0x0e,0x01,0x80,0xf1,0x10,0x01,0x65,0xf1,0x11,0x01,0x4b,0xf1,0x12,0x01,0x30,0xf1,0x13,0x01,0x14,0xf1,0x14,0x01,0xf9,0xf0,0x15,0x01,0xde,0xf0,  \
    0x16,0x01,0xc2,0xf0,0x17,0x01,0xa6,0xf0,0x18,0x01,0x8b,0xf0,0x19,0x01,0x6f,0xf0,0x1a,0x01,0x52,0xf0,0x1b,0x01,0x36,0xf0,0x1c,0x01,0x1a,0xf0,0x1d,0x01,0xfd,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x19,0x01,0x10,0x10,0x18,0x01,0xf3,0x0f,0x17,0x01,0xd6,0x0f,0x16,0x01,0xba,0x0f,0x15,0x01,0x9e,0x0f,0x14,0x01,0x81,0x0f,0x14,0x01,0x65,0x0f,0x13,0x01,0x49,0x0f,0x12,0x01,0x2e,0x0f,0x11,0x01,0x12,0x0f,0x10,0x01,0xf6,0x0e,0x0f,0x01,0xdb,0x0e,0x0e,0x01,0xc0,0x0e,0x0d,0x01,0xa4,0x0e,0x0b,0x01,0x89,0x0e,0x0a,0x01,0x6e,0x0e,0x09,0x01,0x53,0x0e,0x08,0x01,0x39,0x0e,0x07,0x01,0x1e,0x0e,0x06,0x01,0x04,0x0e,0x04,0x01,0xe9,0x0d,0x03,0x01,0xcf,0x0d,  \
    0x02,0x01,0xb5,0x0d,0x01,0x01,0x9b,0x0d,0xff,0x00,0x81,0x0d,0xfe,0x00,0x67,0x0d,0xfd,0x00,0x4d,0x0d,0xfb,0x00,0x34,0x0d,0xfa,0x00,0x1b,0x0d,0xf8,0x00,0x01,0x0d,0xf7,0x00,0xe8,0x0c,0xf5,0x00,0xcf,0x0c,0xf4,0x00,0xb6,0x0c,0xf3,0x00,0x9d,0x0c,0xf1,0x00,0x85,0x0c,0xf0,0x00,0x6c,0x0c,0xee,0x00,0x53,0x0c,0xed,0x00,0x3b,0x0c,0xeb,0x00,0x23,0x0c,0xe9,0x00,0x0b,0x0c,0xe8,0x00,0xf3,0x0b,0xe6,0x00,0xdb,0x0b,0xe5,0x00,0xc3,0x0b,0xe3,0x00,0xab,0x0b,0xe1,0x00,  \
    0x94,0x0b,0xe0,0x00,0x7c,0x0b,0xde,0x00,0x65,0x0b,0xdc,0x00,0x4e,0x0b,0xdb,0x00,0x37,0x0b,0xd9,0x00,0x20,0x0b,0xd7,0x00,0x09,0x0b,0xd6,0x00,0xf2,0x0a,0xd4,0x00,0xdc,0x0a,0xd2,0x00,0xc5,0x0a,0xd0,0x00,0xaf,0x0a,0xcf,0x00,0x99,0x0a,0xcd,0x00,0x82,0x0a,0xcb,0x00,0x6c,0x0a,0xc9,0x00,0x56,0x0a,0xc8,0x00,0x40,0x0a,0xc6,0x00,0x2b,0x0a,0xc4,0x00,0x15,0x0a,0xc2,0x00,0xff,0x09,0xc0,0x00,0xea,0x09,0xbf,0x00,0xd4,0x09,0xbd,0x00,0xbf,0x09,0xbb,0x00,0xaa,0x09,  \
    0xb9,0x00,0x95,0x09,0xb7,0x00,0x80,0x09,0xb6,0x00,0x6b,0x09,0xb4,0x00,0x56,0x09,0xb2,0x00,0x42,0x09,0xb0,0x00,0x2d,0x09,0xae,0x00,0x19,0x09,0xac,0x00,0x05,0x09,0xaa,0x00,0xf0,0x08,0xa9,0x00,0xdc,0x08,0xa7,0x00,0xc8,0x08,0xa5,0x00,0xb4,0x08,0xa3,0x00,0xa0,0x08,0xa1,0x00,0x8d,0x08,0x9f,0x00,0x79,0x08,0x9d,0x00,0x66,0x08,0x9c,0x00,0x52,0x08,0x9a,0x00,0x3f,0x08,0x98,0x00,0x2c,0x08,0x96,0x00,0x19,0x08,0x94,0x00,0x06,0x08,0x92,0x00,0xf3,0x07,0x90,0x00,  \
    0xe0,0x07,0x8f,0x00,0xcd,0x07,0x8d,0x00,0xba,0x07,0x8b,0x00,0xa8,0x07,0x89,0x00,0x95,0x07,0x87,0x00,0x83,0x07,0x85,0x00,0x71,0x07,0x84,0x00,0x5f,0x07,0x82,0x00,0x4d,0x07,0x80,0x00,0x3b,0x07,0x7e,0x00,0x29,0x07,0x7c,0x00,0x17,0x07,0x7a,0x00,0x06,0x07,0x78,0x00,0xf4,0x06,0x77,0x00,0xe3,0x06,0x75,0x00,0xd1,0x06,0x73,0x00,0xc0,0x06,0x71,0x00,0xaf,0x06,0x6f,0x00,0x9e,0x06,0x6e,0x00,0x8d,0x06,0x6c,0x00,0x7c,0x06,0x6a,0x00,0x6b,0x06,0x68,0x00,0x5a,0x06,  \
    0x66,0x00,0x4a,0x06,0x65,0x00,0x39,0x06,0x63,0x00,0x29,0x06,0x61,0x00,0x18,0x06,0x5f,0x00,0x08,0x06,0x5e,0x00,0xf8,0x05,0x5c,0x00,0xe7,0x05,0x5a,0x00,0xd7,0x05,0x59,0x00,0xc7,0x05,0x57,0x00,0xb7,0x05,0x55,0x00,0xa8,0x05,0x53,0x00,0x98,0x05,0x52,0x00,0x88,0x05,0x50,0x00,0x79,0x05,0x4e,0x00,0x69,0x05,0x4d,0x00,0x5a,0x05,0x4b,0x00,0x4a,0x05,0x49,0x00,0x3b,0x05,0x48,0x00,0x2c,0x05,0x46,0x00,0x1c,0x05,0x45,0x00,0x0d,0x05,0x43,0x00,0xfe,0x04,0x41,0x00,  \
    0xef,0x04,0x40,0x00,0xe1,0x04,0x3e,0x00,0xd2,0x04,0x3d,0x00,0xc3,0x04,0x3b,0x00,0xb4,0x04,0x3a,0x00,0xa6,0x04,0x38,0x00,0x97,0x04,0x37,0x00,0x89,0x04,0x35,0x00,0x7a,0x04,0x34,0x00,0x6c,0x04,0x32,0x00,0x5e,0x04,0x31,0x00,0x4f,0x04,0x2f,0x00,0x41,0x04,0x2e,0x00,0x33,0x04,0x2c,0x00,0x25,0x04,0x2b,0x00,0x17,0x04,0x29,0x00,0x09,0x04,0x28,0x00,0xfb,0x03,0x27,0x00,0xee,0x03,0x25,0x00,0xe0,0x03,0x24,0x00,0xd2,0x03,0x22,0x00,0xc5,0x03,0x21,0x00,0xb7,0x03,  \
    0x20,0x00,0xaa,0x03,0x1e,0x00,0x9c,0x03,0x1d,0x00,0x8f,0x03,0x1c,0x00,0x82,0x03,0x1b,0x00,0x74,0x03,0x19,0x00,0x67,0x03,0x18,0x00,0x5a,0x03,0x17,0x00,0x4d,0x03,0x16,0x00,0x40,0x03,0x14,0x00,0x33,0x03,0x13,0x00,0x26,0x03,0x12,0x00,0x1a,0x03,0x11,0x00,0x0d,0x03,0x10,0x00,0x00,0x03,0x0e,0x00,0xf3,0x02,0x0d,0x00,0xe7,0x02,0x0c,0x00,0xda,0x02,0x0b,0x00,0xce,0x02,0x0a,0x00,0xc1,0x02,0x09,0x00,0xb5,0x02,0x08,0x00,0xa8,0x02,0x07,0x00,0x9c,0x02,0x06,0x00,  \
    0x90,0x02,0x05,0x00,0x83,0x02,0x04,0x00,0x77,0x02,0x03,0x00,0x6b,0x02,0x02,0x00,0x5f,0x02,0x01,0x00,0x53,0x02,0x00,0x00,0x47,0x02,0xff,0xff,0x3b,0x02,0xfe,0xff,0x2f,0x02,0xfd,0xff,0x23,0x02,0xfc,0xff,0x17,0x02,0xfb,0xff,0x0b,0x02,0xfb,0xff,0xff,0x01,0xfa,0xff,0xf4,0x01,0xf9,0xff,0xe8,0x01,0xf8,0xff,0xdc,0x01,0xf7,0xff,0xd1,0x01,0xf7,0xff,0xc5,0x01,0xf6,0xff,0xb9,0x01,0xf5,0xff,0xae,0x01,0xf4,0xff,0xa2,0x01,0xf4,0xff,0x97,0x01,0xf3,0xff,0x8b,0x01,  \
    0xf2,0xff,0x80,0x01,0xf2,0xff,0x74,0x01,0xf1,0xff,0x69,0x01,0xf0,0xff,0x5e,0x01,0xf0,0xff,0x52,0x01,0xef,0xff,0x47,0x01,0xef,0xff,0x3c,0x01,0xee,0xff,0x30,0x01,0xed,0xff,0x25,0x01,0xed,0xff,0x1a,0x01,0xec,0xff,0x0f,0x01,0xec,0xff,0x04,0x01,0xeb,0xff,0xf8,0x00,0xeb,0xff,0xed,0x00,0xea,0xff,0xe2,0x00,0xea,0xff,0xd7,0x00,0xea,0xff,0xcc,0x00,0xe9,0xff,0xc1,0x00,0xe9,0xff,0xb6,0x00,0xe8,0xff,0xab,0x00,0xe8,0xff,0xa0,0x00,0xe8,0xff,0x95,0x00,0xe7,0xff,  \
    0x8a,0x00,0xe7,0xff,0x7f,0x00,0xe7,0xff,0x74,0x00,0xe7,0xff,0x69,0x00,0xe6,0xff,0x5e,0x00,0xe6,0xff,0x53,0x00,0xe6,0xff,0x48,0x00,0xe6,0xff,0x3d,0x00,0xe6,0xff,0x32,0x00,0xe5,0xff,0x27,0x00,0xe5,0xff,0x1c,0x00,0xe5,0xff,0x11,0x00,0xe5,0xff,0x07,0x00,0xe5,0xff,0xfc,0xff,0xe5,0xff,0xf1,0xff,0xe5,0xff,0xe6,0xff,0xe5,0xff,0xdb,0xff,0xe5,0xff,0xd0,0xff,0xe5,0xff,0xc5,0xff,0xe5,0xff,0xbb,0xff,0xe5,0xff,0xb0,0xff,0xe5,0xff,0xa5,0xff,0xe5,0xff,0x9a,0xff,  \
    0xe5,0xff,0x8f,0xff,0xe5,0xff,0x84,0xff,0xe5,0xff,0x79,0xff,0xe5,0xff,0x6e,0xff,0xe5,0xff,0x64,0xff,0xe5,0xff,0x59,0xff,0xe6,0xff,0x4e,0xff,0xe6,0xff,0x43,0xff,0xe6,0xff,0x38,0xff,0xe6,0xff,0x2d,0xff,0xe6,0xff,0x22,0xff,0xe7,0xff,0x17,0xff,0xe7,0xff,0x0c,0xff,0xe7,0xff,0x01,0xff,0xe8,0xff,0xf6,0xfe,0xe8,0xff,0xec,0xfe,0xe8,0xff,0xe1,0xfe,0xe9,0xff,0xd6,0xfe,0xe9,0xff,0xcb,0xfe,0xe9,0xff,0xc0,0xfe,0xea,0xff,0xb4,0xfe,0xea,0xff,0xa9,0xfe,0xeb,0xff,  \
    0x9e,0xfe,0xeb,0xff,0x93,0xfe,0xeb,0xff,0x88,0xfe,0xec,0xff,0x7d,0xfe,0xec,0xff,0x72,0xfe,0xed,0xff,0x67,0xfe,0xee,0xff,0x5b,0xfe,0xee,0xff,0x50,0xfe,0xef,0xff,0x45,0xfe,0xef,0xff,0x3a,0xfe,0xf0,0xff,0x2e,0xfe,0xf0,0xff,0x23,0xfe,0xf1,0xff,0x18,0xfe,0xf2,0xff,0x0c,0xfe,0xf2,0xff,0x01,0xfe,0xf3,0xff,0xf6,0xfd,0xf4,0xff,0xea,0xfd,0xf4,0xff,0xdf,0xfd,0xf5,0xff,0xd3,0xfd,0xf6,0xff,0xc8,0xfd,0xf7,0xff,0xbc,0xfd,0xf7,0xff,0xb1,0xfd,0xf8,0xff,0xa5,0xfd,  \
    0xf9,0xff,0x99,0xfd,0xfa,0xff,0x8e,0xfd,0xfb,0xff,0x82,0xfd,0xfc,0xff,0x76,0xfd,0xfc,0xff,0x6a,0xfd,0xfd,0xff,0x5e,0xfd,0xfe,0xff,0x53,0xfd,0xff,0xff,0x47,0xfd,0x00,0x00,0x3b,0xfd,0x01,0x00,0x2f,0xfd,0x02,0x00,0x23,0xfd,0x03,0x00,0x17,0xfd,0x04,0x00,0x0b,0xfd,0x05,0x00,0xff,0xfc,0x06,0x00,0xf2,0xfc,0x07,0x00,0xe6,0xfc,0x08,0x00,0xda,0xfc,0x09,0x00,0xce,0xfc,0x0a,0x00,0xc1,0xfc,0x0b,0x00,0xb5,0xfc,0x0c,0x00,0xa9,0xfc,0x0d,0x00,0x9c,0xfc,0x0f,0x00,  \
    0x90,0xfc,0x10,0x00,0x83,0xfc,0x11,0x00,0x76,0xfc,0x12,0x00,0x6a,0xfc,0x13,0x00,0x5d,0xfc,0x15,0x00,0x50,0xfc,0x16,0x00,0x43,0xfc,0x17,0x00,0x37,0xfc,0x18,0x00,0x2a,0xfc,0x19,0x00,0x1d,0xfc,0x1b,0x00,0x10,0xfc,0x1c,0x00,0x02,0xfc,0x1d,0x00,0xf5,0xfb,0x1f,0x00,0xe8,0xfb,0x20,0x00,0xdb,0xfb,0x21,0x00,0xcd,0xfb,0x23,0x00,0xc0,0xfb,0x24,0x00,0xb3,0xfb,0x25,0x00,0xa5,0xfb,0x27,0x00,0x98,0xfb,0x28,0x00,0x8a,0xfb,0x2a,0x00,0x7c,0xfb,0x2b,0x00,0x6e,0xfb,  \
    0x2c,0x00,0x61,0xfb,0x2e,0x00,0x53,0xfb,0x2f,0x00,0x45,0xfb,0x31,0x00,0x37,0xfb,0x32,0x00,0x29,0xfb,0x34,0x00,0x1b,0xfb,0x35,0x00,0x0c,0xfb,0x37,0x00,0xfe,0xfa,0x38,0x00,0xf0,0xfa,0x3a,0x00,0xe1,0xfa,0x3b,0x00,0xd3,0xfa,0x3d,0x00,0xc4,0xfa,0x3f,0x00,0xb6,0xfa,0x40,0x00,0xa7,0xfa,0x42,0x00,0x98,0xfa,0x43,0x00,0x89,0xfa,0x45,0x00,0x7b,0xfa,0x47,0x00,0x6c,0xfa,0x48,0x00,0x5d,0xfa,0x4a,0x00,0x4d,0xfa,0x4b,0x00,0x3e,0xfa,0x4d,0x00,0x2f,0xfa,0x4f,0x00,  \
    0x20,0xfa,0x50,0x00,0x10,0xfa,0x52,0x00,0x01,0xfa,0x54,0x00,0xf1,0xf9,0x56,0x00,0xe1,0xf9,0x57,0x00,0xd2,0xf9,0x59,0x00,0xc2,0xf9,0x5b,0x00,0xb2,0xf9,0x5c,0x00,0xa2,0xf9,0x5e,0x00,0x92,0xf9,0x60,0x00,0x82,0xf9,0x62,0x00,0x72,0xf9,0x63,0x00,0x61,0xf9,0x65,0x00,0x51,0xf9,0x67,0x00,0x40,0xf9,0x69,0x00,0x30,0xf9,0x6a,0x00,0x1f,0xf9,0x6c,0x00,0x0e,0xf9,0x6e,0x00,0xfd,0xf8,0x70,0x00,0xec,0xf8,0x72,0x00,0xdb,0xf8,0x73,0x00,0xca,0xf8,0x75,0x00,0xb9,0xf8,  \
    0x77,0x00,0xa8,0xf8,0x79,0x00,0x96,0xf8,0x7b,0x00,0x85,0xf8,0x7d,0x00,0x73,0xf8,0x7e,0x00,0x62,0xf8,0x80,0x00,0x50,0xf8,0x82,0x00,0x3e,0xf8,0x84,0x00,0x2c,0xf8,0x86,0x00,0x1a,0xf8,0x88,0x00,0x08,0xf8,0x8a,0x00,0xf6,0xf7,0x8b,0x00,0xe3,0xf7,0x8d,0x00,0xd1,0xf7,0x8f,0x00,0xbe,0xf7,0x91,0x00,0xac,0xf7,0x93,0x00,0x99,0xf7,0x95,0x00,0x86,0xf7,0x97,0x00,0x73,0xf7,0x98,0x00,0x60,0xf7,0x9a,0x00,0x4d,0xf7,0x9c,0x00,0x3a,0xf7,0x9e,0x00,0x27,0xf7,0xa0,0x00,  \
    0x13,0xf7,0xa2,0x00,0x00,0xf7,0xa4,0x00,0xec,0xf6,0xa5,0x00,0xd8,0xf6,0xa7,0x00,0xc4,0xf6,0xa9,0x00,0xb1,0xf6,0xab,0x00,0x9c,0xf6,0xad,0x00,0x88,0xf6,0xaf,0x00,0x74,0xf6,0xb1,0x00,0x60,0xf6,0xb2,0x00,0x4b,0xf6,0xb4,0x00,0x37,0xf6,0xb6,0x00,0x22,0xf6,0xb8,0x00,0x0d,0xf6,0xba,0x00,0xf8,0xf5,0xbc,0x00,0xe3,0xf5,0xbd,0x00,0xce,0xf5,0xbf,0x00,0xb8,0xf5,0xc1,0x00,0xa3,0xf5,0xc3,0x00,0x8e,0xf5,0xc5,0x00,0x78,0xf5,0xc6,0x00,0x62,0xf5,0xc8,0x00,0x4c,0xf5,  \
    0xca,0x00,0x36,0xf5,0xcc,0x00,0x20,0xf5,0xcd,0x00,0x0a,0xf5,0xcf,0x00,0xf4,0xf4,0xd1,0x00,0xdd,0xf4,0xd2,0x00,0xc7,0xf4,0xd4,0x00,0xb0,0xf4,0xd6,0x00,0x9a,0xf4,0xd8,0x00,0x83,0xf4,0xd9,0x00,0x6c,0xf4,0xdb,0x00,0x55,0xf4,0xdd,0x00,0x3d,0xf4,0xde,0x00,0x26,0xf4,0xe0,0x00,0x0f,0xf4,0xe1,0x00,0xf7,0xf3,0xe3,0x00,0xdf,0xf3,0xe5,0x00,0xc8,0xf3,0xe6,0x00,0xb0,0xf3,0xe8,0x00,0x98,0xf3,0xe9,0x00,0x80,0xf3,0xeb,0x00,0x67,0xf3,0xec,0x00,0x4f,0xf3,0xee,0x00,  \
    0x36,0xf3,0xef,0x00,0x1e,0xf3,0xf1,0x00,0x05,0xf3,0xf2,0x00,0xec,0xf2,0xf4,0x00,0xd3,0xf2,0xf5,0x00,0xba,0xf2,0xf6,0x00,0xa1,0xf2,0xf8,0x00,0x87,0xf2,0xf9,0x00,0x6e,0xf2,0xfa,0x00,0x54,0xf2,0xfc,0x00,0x3a,0xf2,0xfd,0x00,0x20,0xf2,0xfe,0x00,0x06,0xf2,0x00,0x01,0xec,0xf1,0x01,0x01,0xd2,0xf1,0x02,0x01,0xb7,0xf1,0x03,0x01,0x9d,0xf1,0x04,0x01,0x82,0xf1,0x05,0x01,0x68,0xf1,0x07,0x01,0x4d,0xf1,0x08,0x01,0x32,0xf1,0x09,0x01,0x16,0xf1,0x0a,0x01,0xfb,0xf0,  \
    0x0b,0x01,0xe0,0xf0,0x0c,0x01,0xc4,0xf0,0x0d,0x01,0xa8,0xf0,0x0e,0x01,0x8c,0xf0,0x0f,0x01,0x71,0xf0,0x0f,0x01,0x54,0xf0,0x10,0x01,0x38,0xf0,0x11,0x01,0x1c,0xf0,0x12,0x01,0xff,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x0e,0x01,0x0e,0x10,0x0d,0x01,0xf1,0x0f,0x0c,0x01,0xd5,0x0f,0x0c,0x01,0xb8,0x0f,0x0b,0x01,0x9c,0x0f,0x0a,0x01,0x80,0x0f,0x09,0x01,0x64,0x0f,0x08,0x01,0x48,0x0f,0x07,0x01,0x2c,0x0f,0x06,0x01,0x10,0x0f,0x05,0x01,0xf5,0x0e,0x04,0x01,0xd9,0x0e,0x03,0x01,0xbe,0x0e,0x02,0x01,0xa3,0x0e,0x01,0x01,0x87,0x0e,0x00,0x01,0x6c,0x0e,0xff,0x00,0x52,0x0e,0xfe,0x00,0x37,0x0e,0xfd,0x00,0x1c,0x0e,0xfc,0x00,0x02,0x0e,0xfb,0x00,0xe7,0x0d,  \
    0xf9,0x00,0xcd,0x0d,0xf8,0x00,0xb3,0x0d,0xf7,0x00,0x99,0x0d,0xf6,0x00,0x7f,0x0d,0xf5,0x00,0x65,0x0d,0xf3,0x00,0x4c,0x0d,0xf2,0x00,0x32,0x0d,0xf1,0x00,0x19,0x0d,0xef,0x00,0xff,0x0c,0xee,0x00,0xe6,0x0c,0xed,0x00,0xcd,0x0c,0xeb,0x00,0xb4,0x0c,0xea,0x00,0x9b,0x0c,0xe8,0x00,0x83,0x0c,0xe7,0x00,0x6a,0x0c,0xe5,0x00,0x51,0x0c,0xe4,0x00,0x39,0x0c,0xe3,0x00,0x21,0x0c,0xe1,0x00,0x09,0x0c,0xe0,0x00,0xf1,0x0b,0xde,0x00,0xd9,0x0b,0xdd,0x00,0xc1,0x0b,0xdb,0x00,  \
    0xa9,0x0b,0xd9,0x00,0x92,0x0b,0xd8,0x00,0x7a,0x0b,0xd6,0x00,0x63,0x0b,0xd5,0x00,0x4c,0x0b,0xd3,0x00,0x35,0x0b,0xd2,0x00,0x1e,0x0b,0xd0,0x00,0x07,0x0b,0xce,0x00,0xf0,0x0a,0xcd,0x00,0xda,0x0a,0xcb,0x00,0xc3,0x0a,0xc9,0x00,0xad,0x0a,0xc8,0x00,0x96,0x0a,0xc6,0x00,0x80,0x0a,0xc4,0x00,0x6a,0x0a,0xc3,0x00,0x54,0x0a,0xc1,0x00,0x3e,0x0a,0xbf,0x00,0x28,0x0a,0xbe,0x00,0x13,0x0a,0xbc,0x00,0xfd,0x09,0xba,0x00,0xe8,0x09,0xb9,0x00,0xd2,0x09,0xb7,0x00,0xbd,0x09,  \
    0xb5,0x00,0xa8,0x09,0xb3,0x00,0x93,0x09,0xb2,0x00,0x7e,0x09,0xb0,0x00,0x69,0x09,0xae,0x00,0x54,0x09,0xac,0x00,0x40,0x09,0xab,0x00,0x2b,0x09,0xa9,0x00,0x17,0x09,0xa7,0x00,0x02,0x09,0xa5,0x00,0xee,0x08,0xa4,0x00,0xda,0x08,0xa2,0x00,0xc6,0x08,0xa0,0x00,0xb2,0x08,0x9e,0x00,0x9e,0x08,0x9d,0x00,0x8a,0x08,0x9b,0x00,0x77,0x08,0x99,0x00,0x63,0x08,0x97,0x00,0x50,0x08,0x96,0x00,0x3d,0x08,0x94,0x00,0x29,0x08,0x92,0x00,0x16,0x08,0x90,0x00,0x03,0x08,0x8e,0x00,  \
    0xf0,0x07,0x8d,0x00,0xdd,0x07,0x8b,0x00,0xcb,0x07,0x89,0x00,0xb8,0x07,0x87,0x00,0xa6,0x07,0x86,0x00,0x93,0x07,0x84,0x00,0x81,0x07,0x82,0x00,0x6f,0x07,0x80,0x00,0x5d,0x07,0x7f,0x00,0x4b,0x07,0x7d,0x00,0x39,0x07,0x7b,0x00,0x27,0x07,0x79,0x00,0x15,0x07,0x78,0x00,0x03,0x07,0x76,0x00,0xf2,0x06,0x74,0x00,0xe0,0x06,0x72,0x00,0xcf,0x06,0x71,0x00,0xbe,0x06,0x6f,0x00,0xad,0x06,0x6d,0x00,0x9c,0x06,0x6c,0x00,0x8b,0x06,0x6a,0x00,0x7a,0x06,0x68,0x00,0x69,0x06,  \
    0x67,0x00,0x58,0x06,0x65,0x00,0x47,0x06,0x63,0x00,0x37,0x06,0x62,0x00,0x26,0x06,0x60,0x00,0x16,0x06,0x5e,0x00,0x06,0x06,0x5d,0x00,0xf5,0x05,0x5b,0x00,0xe5,0x05,0x59,0x00,0xd5,0x05,0x58,0x00,0xc5,0x05,0x56,0x00,0xb5,0x05,0x54,0x00,0xa5,0x05,0x53,0x00,0x95,0x05,0x51,0x00,0x86,0x05,0x50,0x00,0x76,0x05,0x4e,0x00,0x67,0x05,0x4c,0x00,0x57,0x05,0x4b,0x00,0x48,0x05,0x49,0x00,0x39,0x05,0x48,0x00,0x29,0x05,0x46,0x00,0x1a,0x05,0x45,0x00,0x0b,0x05,0x43,0x00,  \
    0xfc,0x04,0x42,0x00,0xed,0x04,0x40,0x00,0xde,0x04,0x3f,0x00,0xcf,0x04,0x3d,0x00,0xc1,0x04,0x3c,0x00,0xb2,0x04,0x3a,0x00,0xa3,0x04,0x39,0x00,0x95,0x04,0x37,0x00,0x86,0x04,0x36,0x00,0x78,0x04,0x34,0x00,0x6a,0x04,0x33,0x00,0x5b,0x04,0x32,0x00,0x4d,0x04,0x30,0x00,0x3f,0x04,0x2f,0x00,0x31,0x04,0x2d,0x00,0x23,0x04,0x2c,0x00,0x15,0x04,0x2b,0x00,0x07,0x04,0x29,0x00,0xf9,0x03,0x28,0x00,0xec,0x03,0x27,0x00,0xde,0x03,0x25,0x00,0xd0,0x03,0x24,0x00,0xc3,0x03,  \
    0x23,0x00,0xb5,0x03,0x22,0x00,0xa8,0x03,0x20,0x00,0x9a,0x03,0x1f,0x00,0x8d,0x03,0x1e,0x00,0x80,0x03,0x1d,0x00,0x73,0x03,0x1c,0x00,0x65,0x03,0x1a,0x00,0x58,0x03,0x19,0x00,0x4b,0x03,0x18,0x00,0x3e,0x03,0x17,0x00,0x31,0x03,0x16,0x00,0x25,0x03,0x15,0x00,0x18,0x03,0x13,0x00,0x0b,0x03,0x12,0x00,0xfe,0x02,0x11,0x00,0xf2,0x02,0x10,0x00,0xe5,0x02,0x0f,0x00,0xd8,0x02,0x0e,0x00,0xcc,0x02,0x0d,0x00,0xbf,0x02,0x0c,0x00,0xb3,0x02,0x0b,0x00,0xa7,0x02,0x0a,0x00,  \
    0x9a,0x02,0x09,0x00,0x8e,0x02,0x08,0x00,0x82,0x02,0x07,0x00,0x76,0x02,0x06,0x00,0x69,0x02,0x05,0x00,0x5d,0x02,0x04,0x00,0x51,0x02,0x03,0x00,0x45,0x02,0x03,0x00,0x39,0x02,0x02,0x00,0x2d,0x02,0x01,0x00,0x21,0x02,0x00,0x00,0x16,0x02,0xff,0xff,0x0a,0x02,0xfe,0xff,0xfe,0x01,0xfe,0xff,0xf2,0x01,0xfd,0xff,0xe7,0x01,0xfc,0xff,0xdb,0x01,0xfb,0xff,0xcf,0x01,0xfa,0xff,0xc4,0x01,0xfa,0xff,0xb8,0x01,0xf9,0xff,0xad,0x01,0xf8,0xff,0xa1,0x01,0xf8,0xff,0x96,0x01,  \
    0xf7,0xff,0x8a,0x01,0xf6,0xff,0x7f,0x01,0xf6,0xff,0x73,0x01,0xf5,0xff,0x68,0x01,0xf5,0xff,0x5d,0x01,0xf4,0xff,0x51,0x01,0xf3,0xff,0x46,0x01,0xf3,0xff,0x3b,0x01,0xf2,0xff,0x30,0x01,0xf2,0xff,0x24,0x01,0xf1,0xff,0x19,0x01,0xf1,0xff,0x0e,0x01,0xf0,0xff,0x03,0x01,0xf0,0xff,0xf8,0x00,0xef,0xff,0xed,0x00,0xef,0xff,0xe1,0x00,0xef,0xff,0xd6,0x00,0xee,0xff,0xcb,0x00,0xee,0xff,0xc0,0x00,0xed,0xff,0xb5,0x00,0xed,0xff,0xaa,0x00,0xed,0xff,0x9f,0x00,0xec,0xff,  \
    0x94,0x00,0xec,0xff,0x89,0x00,0xec,0xff,0x7e,0x00,0xec,0xff,0x73,0x00,0xeb,0xff,0x68,0x00,0xeb,0xff,0x5d,0x00,0xeb,0xff,0x53,0x00,0xeb,0xff,0x48,0x00,0xea,0xff,0x3d,0x00,0xea,0xff,0x32,0x00,0xea,0xff,0x27,0x00,0xea,0xff,0x1c,0x00,0xea,0xff,0x11,0x00,0xea,0xff,0x06,0x00,0xea,0xff,0xfc,0xff,0xea,0xff,0xf1,0xff,0xea,0xff,0xe6,0xff,0xe9,0xff,0xdb,0xff,0xe9,0xff,0xd0,0xff,0xe9,0xff,0xc5,0xff,0xe9,0xff,0xbb,0xff,0xe9,0xff,0xb0,0xff,0xe9,0xff,0xa5,0xff,  \
    0xea,0xff,0x9a,0xff,0xea,0xff,0x8f,0xff,0xea,0xff,0x84,0xff,0xea,0xff,0x7a,0xff,0xea,0xff,0x6f,0xff,0xea,0xff,0x64,0xff,0xea,0xff,0x59,0xff,0xea,0xff,0x4e,0xff,0xea,0xff,0x43,0xff,0xeb,0xff,0x38,0xff,0xeb,0xff,0x2e,0xff,0xeb,0xff,0x23,0xff,0xeb,0xff,0x18,0xff,0xec,0xff,0x0d,0xff,0xec,0xff,0x02,0xff,0xec,0xff,0xf7,0xfe,0xec,0xff,0xec,0xfe,0xed,0xff,0xe1,0xfe,0xed,0xff,0xd6,0xfe,0xed,0xff,0xcb,0xfe,0xee,0xff,0xc0,0xfe,0xee,0xff,0xb5,0xfe,0xef,0xff,  \
    0xaa,0xfe,0xef,0xff,0x9f,0xfe,0xef,0xff,0x94,0xfe,0xf0,0xff,0x89,0xfe,0xf0,0xff,0x7e,0xfe,0xf1,0xff,0x73,0xfe,0xf1,0xff,0x68,0xfe,0xf2,0xff,0x5c,0xfe,0xf2,0xff,0x51,0xfe,0xf3,0xff,0x46,0xfe,0xf3,0xff,0x3b,0xfe,0xf4,0xff,0x30,0xfe,0xf5,0xff,0x24,0xfe,0xf5,0xff,0x19,0xfe,0xf6,0xff,0x0e,0xfe,0xf6,0xff,0x02,0xfe,0xf7,0xff,0xf7,0xfd,0xf8,0xff,0xeb,0xfd,0xf8,0xff,0xe0,0xfd,0xf9,0xff,0xd5,0xfd,0xfa,0xff,0xc9,0xfd,0xfb,0xff,0xbe,0xfd,0xfb,0xff,0xb2,0xfd,  \
    0xfc,0xff,0xa6,0xfd,0xfd,0xff,0x9b,0xfd,0xfe,0xff,0x8f,0xfd,0xfe,0xff,0x83,0xfd,0xff,0xff,0x78,0xfd,0x00,0x00,0x6c,0xfd,0x01,0x00,0x60,0xfd,0x02,0x00,0x54,0xfd,0x03,0x00,0x48,0xfd,0x03,0x00,0x3c,0xfd,0x04,0x00,0x30,0xfd,0x05,0x00,0x25,0xfd,0x06,0x00,0x18,0xfd,0x07,0x00,0x0c,0xfd,0x08,0x00,0x00,0xfd,0x09,0x00,0xf4,0xfc,0x0a,0x00,0xe8,0xfc,0x0b,0x00,0xdc,0xfc,0x0c,0x00,0xd0,0xfc,0x0d,0x00,0xc3,0xfc,0x0e,0x00,0xb7,0xfc,0x0f,0x00,0xaa,0xfc,0x10,0x00,  \
    0x9e,0xfc,0x11,0x00,0x91,0xfc,0x12,0x00,0x85,0xfc,0x14,0x00,0x78,0xfc,0x15,0x00,0x6c,0xfc,0x16,0x00,0x5f,0xfc,0x17,0x00,0x52,0xfc,0x18,0x00,0x45,0xfc,0x19,0x00,0x39,0xfc,0x1a,0x00,0x2c,0xfc,0x1c,0x00,0x1f,0xfc,0x1d,0x00,0x12,0xfc,0x1e,0x00,0x05,0xfc,0x1f,0x00,0xf7,0xfb,0x21,0x00,0xea,0xfb,0x22,0x00,0xdd,0xfb,0x23,0x00,0xd0,0xfb,0x24,0x00,0xc2,0xfb,0x26,0x00,0xb5,0xfb,0x27,0x00,0xa7,0xfb,0x28,0x00,0x9a,0xfb,0x2a,0x00,0x8c,0xfb,0x2b,0x00,0x7e,0xfb,  \
    0x2c,0x00,0x71,0xfb,0x2e,0x00,0x63,0xfb,0x2f,0x00,0x55,0xfb,0x30,0x00,0x47,0xfb,0x32,0x00,0x39,0xfb,0x33,0x00,0x2b,0xfb,0x35,0x00,0x1d,0xfb,0x36,0x00,0x0f,0xfb,0x37,0x00,0x00,0xfb,0x39,0x00,0xf2,0xfa,0x3a,0x00,0xe4,0xfa,0x3c,0x00,0xd5,0xfa,0x3d,0x00,0xc7,0xfa,0x3f,0x00,0xb8,0xfa,0x40,0x00,0xa9,0xfa,0x42,0x00,0x9b,0xfa,0x43,0x00,0x8c,0xfa,0x45,0x00,0x7d,0xfa,0x46,0x00,0x6e,0xfa,0x48,0x00,0x5f,0xfa,0x49,0x00,0x50,0xfa,0x4b,0x00,0x41,0xfa,0x4d,0x00,  \
    0x31,0xfa,0x4e,0x00,0x22,0xfa,0x50,0x00,0x13,0xfa,0x51,0x00,0x03,0xfa,0x53,0x00,0xf4,0xf9,0x55,0x00,0xe4,0xf9,0x56,0x00,0xd4,0xf9,0x58,0x00,0xc4,0xf9,0x5a,0x00,0xb4,0xf9,0x5b,0x00,0xa4,0xf9,0x5d,0x00,0x94,0xf9,0x5e,0x00,0x84,0xf9,0x60,0x00,0x74,0xf9,0x62,0x00,0x64,0xf9,0x63,0x00,0x53,0xf9,0x65,0x00,0x43,0xf9,0x67,0x00,0x32,0xf9,0x69,0x00,0x22,0xf9,0x6a,0x00,0x11,0xf9,0x6c,0x00,0x00,0xf9,0x6e,0x00,0xef,0xf8,0x6f,0x00,0xde,0xf8,0x71,0x00,0xcd,0xf8,  \
    0x73,0x00,0xbc,0xf8,0x75,0x00,0xaa,0xf8,0x76,0x00,0x99,0xf8,0x78,0x00,0x87,0xf8,0x7a,0x00,0x76,0xf8,0x7b,0x00,0x64,0xf8,0x7d,0x00,0x52,0xf8,0x7f,0x00,0x41,0xf8,0x81,0x00,0x2f,0xf8,0x82,0x00,0x1d,0xf8,0x84,0x00,0x0a,0xf8,0x86,0x00,0xf8,0xf7,0x88,0x00,0xe6,0xf7,0x8a,0x00,0xd3,0xf7,0x8b,0x00,0xc1,0xf7,0x8d,0x00,0xae,0xf7,0x8f,0x00,0x9c,0xf7,0x91,0x00,0x89,0xf7,0x92,0x00,0x76,0xf7,0x94,0x00,0x63,0xf7,0x96,0x00,0x50,0xf7,0x98,0x00,0x3c,0xf7,0x99,0x00,  \
    0x29,0xf7,0x9b,0x00,0x16,0xf7,0x9d,0x00,0x02,0xf7,0x9f,0x00,0xee,0xf6,0xa0,0x00,0xdb,0xf6,0xa2,0x00,0xc7,0xf6,0xa4,0x00,0xb3,0xf6,0xa6,0x00,0x9f,0xf6,0xa8,0x00,0x8b,0xf6,0xa9,0x00,0x76,0xf6,0xab,0x00,0x62,0xf6,0xad,0x00,0x4d,0xf6,0xae,0x00,0x39,0xf6,0xb0,0x00,0x24,0xf6,0xb2,0x00,0x0f,0xf6,0xb4,0x00,0xfa,0xf5,0xb5,0x00,0xe5,0xf5,0xb7,0x00,0xd0,0xf5,0xb9,0x00,0xbb,0xf5,0xbb,0x00,0xa5,0xf5,0xbc,0x00,0x90,0xf5,0xbe,0x00,0x7a,0xf5,0xc0,0x00,0x64,0xf5,  \
    0xc1,0x00,0x4f,0xf5,0xc3,0x00,0x39,0xf5,0xc5,0x00,0x23,0xf5,0xc6,0x00,0x0c,0xf5,0xc8,0x00,0xf6,0xf4,0xc9,0x00,0xe0,0xf4,0xcb,0x00,0xc9,0xf4,0xcd,0x00,0xb3,0xf4,0xce,0x00,0x9c,0xf4,0xd0,0x00,0x85,0xf4,0xd2,0x00,0x6e,0xf4,0xd3,0x00,0x57,0xf4,0xd5,0x00,0x40,0xf4,0xd6,0x00,0x28,0xf4,0xd8,0x00,0x11,0xf4,0xd9,0x00,0xf9,0xf3,0xdb,0x00,0xe2,0xf3,0xdc,0x00,0xca,0xf3,0xde,0x00,0xb2,0xf3,0xdf,0x00,0x9a,0xf3,0xe1,0x00,0x82,0xf3,0xe2,0x00,0x69,0xf3,0xe4,0x00,  \
    0x51,0xf3,0xe5,0x00,0x38,0xf3,0xe6,0x00,0x20,0xf3,0xe8,0x00,0x07,0xf3,0xe9,0x00,0xee,0xf2,0xea,0x00,0xd5,0xf2,0xec,0x00,0xbc,0xf2,0xed,0x00,0xa3,0xf2,0xee,0x00,0x89,0xf2,0xf0,0x00,0x70,0xf2,0xf1,0x00,0x56,0xf2,0xf2,0x00,0x3c,0xf2,0xf3,0x00,0x22,0xf2,0xf5,0x00,0x08,0xf2,0xf6,0x00,0xee,0xf1,0xf7,0x00,0xd4,0xf1,0xf8,0x00,0xb9,0xf1,0xf9,0x00,0x9f,0xf1,0xfa,0x00,0x84,0xf1,0xfb,0x00,0x69,0xf1,0xfc,0x00,0x4e,0xf1,0xfd,0x00,0x33,0xf1,0xfe,0x00,0x18,0xf1,  \
    0xff,0x00,0xfd,0xf0,0x00,0x01,0xe1,0xf0,0x01,0x01,0xc6,0xf0,0x02,0x01,0xaa,0xf0,0x03,0x01,0x8e,0xf0,0x04,0x01,0x72,0xf0,0x05,0x01,0x56,0xf0,0x06,0x01,0x3a,0xf0,0x06,0x01,0x1e,0xf0,0x07,0x01,0x01,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x01,0x0c,0x10,0x02,0x01,0xf0,0x0f,0x02,0x01,0xd3,0x0f,0x01,0x01,0xb7,0x0f,0x00,0x01,0x9a,0x0f,0xff,0x00,0x7e,0x0f,0xff,0x00,0x62,0x0f,0xfe,0x00,0x46,0x0f,0xfd,0x00,0x2a,0x0f,0xfc,0x00,0x0e,0x0f,0xfb,0x00,0xf3,0x0e,0xfa,0x00,0xd7,0x0e,0xf9,0x00,0xbc,0x0e,0xf8,0x00,0xa1,0x0e,0xf7,0x00,0x86,0x0e,0xf6,0x00,0x6b,0x0e,0xf5,0x00,0x50,0x0e,0xf4,0x00,0x35,0x0e,0xf3,0x00,0x1b,0x0e,0xf2,0x00,0x00,0x0e,  \
    0xf1,0x00,0xe6,0x0d,0xf0,0x00,0xcb,0x0d,0xef,0x00,0xb1,0x0d,0xee,0x00,0x97,0x0d,0xec,0x00,0x7d,0x0d,0xeb,0x00,0x64,0x0d,0xea,0x00,0x4a,0x0d,0xe9,0x00,0x30,0x0d,0xe7,0x00,0x17,0x0d,0xe6,0x00,0xfe,0x0c,0xe5,0x00,0xe4,0x0c,0xe4,0x00,0xcb,0x0c,0xe2,0x00,0xb2,0x0c,0xe1,0x00,0x99,0x0c,0xe0,0x00,0x81,0x0c,0xde,0x00,0x68,0x0c,0xdd,0x00,0x50,0x0c,0xdc,0x00,0x37,0x0c,0xda,0x00,0x1f,0x0c,0xd9,0x00,0x07,0x0c,0xd7,0x00,0xef,0x0b,0xd6,0x00,0xd7,0x0b,0xd5,0x00,  \
    0xbf,0x0b,0xd3,0x00,0xa7,0x0b,0xd2,0x00,0x90,0x0b,0xd0,0x00,0x78,0x0b,0xcf,0x00,0x61,0x0b,0xcd,0x00,0x4a,0x0b,0xcc,0x00,0x33,0x0b,0xca,0x00,0x1c,0x0b,0xc9,0x00,0x05,0x0b,0xc7,0x00,0xee,0x0a,0xc5,0x00,0xd8,0x0a,0xc4,0x00,0xc1,0x0a,0xc2,0x00,0xab,0x0a,0xc1,0x00,0x94,0x0a,0xbf,0x00,0x7e,0x0a,0xbe,0x00,0x68,0x0a,0xbc,0x00,0x52,0x0a,0xba,0x00,0x3c,0x0a,0xb9,0x00,0x26,0x0a,0xb7,0x00,0x11,0x0a,0xb6,0x00,0xfb,0x09,0xb4,0x00,0xe5,0x09,0xb2,0x00,0xd0,0x09,  \
    0xb1,0x00,0xbb,0x09,0xaf,0x00,0xa6,0x09,0xae,0x00,0x91,0x09,0xac,0x00,0x7c,0x09,0xaa,0x00,0x67,0x09,0xa9,0x00,0x52,0x09,0xa7,0x00,0x3d,0x09,0xa5,0x00,0x29,0x09,0xa4,0x00,0x14,0x09,0xa2,0x00,0x00,0x09,0xa0,0x00,0xec,0x08,0x9f,0x00,0xd8,0x08,0x9d,0x00,0xc4,0x08,0x9b,0x00,0xb0,0x08,0x9a,0x00,0x9c,0x08,0x98,0x00,0x88,0x08,0x96,0x00,0x75,0x08,0x95,0x00,0x61,0x08,0x93,0x00,0x4e,0x08,0x91,0x00,0x3a,0x08,0x90,0x00,0x27,0x08,0x8e,0x00,0x14,0x08,0x8c,0x00,  \
    0x01,0x08,0x8b,0x00,0xee,0x07,0x89,0x00,0xdb,0x07,0x87,0x00,0xc9,0x07,0x86,0x00,0xb6,0x07,0x84,0x00,0xa3,0x07,0x82,0x00,0x91,0x07,0x81,0x00,0x7f,0x07,0x7f,0x00,0x6c,0x07,0x7d,0x00,0x5a,0x07,0x7c,0x00,0x48,0x07,0x7a,0x00,0x36,0x07,0x78,0x00,0x25,0x07,0x77,0x00,0x13,0x07,0x75,0x00,0x01,0x07,0x73,0x00,0xf0,0x06,0x72,0x00,0xde,0x06,0x70,0x00,0xcd,0x06,0x6f,0x00,0xbc,0x06,0x6d,0x00,0xaa,0x06,0x6b,0x00,0x99,0x06,0x6a,0x00,0x88,0x06,0x68,0x00,0x77,0x06,  \
    0x66,0x00,0x67,0x06,0x65,0x00,0x56,0x06,0x63,0x00,0x45,0x06,0x62,0x00,0x35,0x06,0x60,0x00,0x24,0x06,0x5e,0x00,0x14,0x06,0x5d,0x00,0x03,0x06,0x5b,0x00,0xf3,0x05,0x5a,0x00,0xe3,0x05,0x58,0x00,0xd3,0x05,0x57,0x00,0xc3,0x05,0x55,0x00,0xb3,0x05,0x54,0x00,0xa3,0x05,0x52,0x00,0x93,0x05,0x51,0x00,0x84,0x05,0x4f,0x00,0x74,0x05,0x4e,0x00,0x64,0x05,0x4c,0x00,0x55,0x05,0x4b,0x00,0x46,0x05,0x49,0x00,0x36,0x05,0x48,0x00,0x27,0x05,0x46,0x00,0x18,0x05,0x45,0x00,  \
    0x09,0x05,0x43,0x00,0xfa,0x04,0x42,0x00,0xeb,0x04,0x40,0x00,0xdc,0x04,0x3f,0x00,0xcd,0x04,0x3e,0x00,0xbf,0x04,0x3c,0x00,0xb0,0x04,0x3b,0x00,0xa1,0x04,0x39,0x00,0x93,0x04,0x38,0x00,0x84,0x04,0x37,0x00,0x76,0x04,0x35,0x00,0x68,0x04,0x34,0x00,0x59,0x04,0x33,0x00,0x4b,0x04,0x31,0x00,0x3d,0x04,0x30,0x00,0x2f,0x04,0x2f,0x00,0x21,0x04,0x2e,0x00,0x13,0x04,0x2c,0x00,0x05,0x04,0x2b,0x00,0xf7,0x03,0x2a,0x00,0xea,0x03,0x28,0x00,0xdc,0x03,0x27,0x00,0xce,0x03,  \
    0x26,0x00,0xc1,0x03,0x25,0x00,0xb3,0x03,0x24,0x00,0xa6,0x03,0x22,0x00,0x98,0x03,0x21,0x00,0x8b,0x03,0x20,0x00,0x7e,0x03,0x1f,0x00,0x71,0x03,0x1e,0x00,0x64,0x03,0x1d,0x00,0x56,0x03,0x1c,0x00,0x49,0x03,0x1a,0x00,0x3d,0x03,0x19,0x00,0x30,0x03,0x18,0x00,0x23,0x03,0x17,0x00,0x16,0x03,0x16,0x00,0x09,0x03,0x15,0x00,0xfd,0x02,0x14,0x00,0xf0,0x02,0x13,0x00,0xe3,0x02,0x12,0x00,0xd7,0x02,0x11,0x00,0xca,0x02,0x10,0x00,0xbe,0x02,0x0f,0x00,0xb1,0x02,0x0e,0x00,  \
    0xa5,0x02,0x0d,0x00,0x99,0x02,0x0c,0x00,0x8c,0x02,0x0b,0x00,0x80,0x02,0x0a,0x00,0x74,0x02,0x0a,0x00,0x68,0x02,0x09,0x00,0x5c,0x02,0x08,0x00,0x50,0x02,0x07,0x00,0x44,0x02,0x06,0x00,0x38,0x02,0x05,0x00,0x2c,0x02,0x04,0x00,0x20,0x02,0x04,0x00,0x14,0x02,0x03,0x00,0x08,0x02,0x02,0x00,0xfd,0x01,0x01,0x00,0xf1,0x01,0x01,0x00,0xe5,0x01,0x00,0x00,0xda,0x01,0xff,0xff,0xce,0x01,0xfe,0xff,0xc2,0x01,0xfe,0xff,0xb7,0x01,0xfd,0xff,0xab,0x01,0xfc,0xff,0xa0,0x01,  \
    0xfc,0xff,0x94,0x01,0xfb,0xff,0x89,0x01,0xfb,0xff,0x7e,0x01,0xfa,0xff,0x72,0x01,0xf9,0xff,0x67,0x01,0xf9,0xff,0x5c,0x01,0xf8,0xff,0x50,0x01,0xf8,0xff,0x45,0x01,0xf7,0xff,0x3a,0x01,0xf7,0xff,0x2f,0x01,0xf6,0xff,0x23,0x01,0xf6,0xff,0x18,0x01,0xf5,0xff,0x0d,0x01,0xf5,0xff,0x02,0x01,0xf4,0xff,0xf7,0x00,0xf4,0xff,0xec,0x00,0xf4,0xff,0xe1,0x00,0xf3,0xff,0xd6,0x00,0xf3,0xff,0xcb,0x00,0xf2,0xff,0xc0,0x00,0xf2,0xff,0xb5,0x00,0xf2,0xff,0xaa,0x00,0xf1,0xff,  \
    0x9f,0x00,0xf1,0xff,0x94,0x00,0xf1,0xff,0x89,0x00,0xf1,0xff,0x7e,0x00,0xf0,0xff,0x73,0x00,0xf0,0xff,0x68,0x00,0xf0,0xff,0x5d,0x00,0xf0,0xff,0x52,0x00,0xef,0xff,0x47,0x00,0xef,0xff,0x3c,0x00,0xef,0xff,0x32,0x00,0xef,0xff,0x27,0x00,0xef,0xff,0x1c,0x00,0xef,0xff,0x11,0x00,0xef,0xff,0x06,0x00,0xee,0xff,0xfb,0xff,0xee,0xff,0xf1,0xff,0xee,0xff,0xe6,0xff,0xee,0xff,0xdb,0xff,0xee,0xff,0xd0,0xff,0xee,0xff,0xc5,0xff,0xee,0xff,0xbb,0xff,0xee,0xff,0xb0,0xff,  \
    0xee,0xff,0xa5,0xff,0xee,0xff,0x9a,0xff,0xee,0xff,0x8f,0xff,0xef,0xff,0x85,0xff,0xef,0xff,0x7a,0xff,0xef,0xff,0x6f,0xff,0xef,0xff,0x64,0xff,0xef,0xff,0x59,0xff,0xef,0xff,0x4e,0xff,0xef,0xff,0x44,0xff,0xef,0xff,0x39,0xff,0xf0,0xff,0x2e,0xff,0xf0,0xff,0x23,0xff,0xf0,0xff,0x18,0xff,0xf0,0xff,0x0d,0xff,0xf1,0xff,0x02,0xff,0xf1,0xff,0xf8,0xfe,0xf1,0xff,0xed,0xfe,0xf1,0xff,0xe2,0xfe,0xf2,0xff,0xd7,0xfe,0xf2,0xff,0xcc,0xfe,0xf2,0xff,0xc1,0xfe,0xf3,0xff,  \
    0xb6,0xfe,0xf3,0xff,0xab,0xfe,0xf4,0xff,0xa0,0xfe,0xf4,0xff,0x95,0xfe,0xf4,0xff,0x8a,0xfe,0xf5,0xff,0x7f,0xfe,0xf5,0xff,0x74,0xfe,0xf6,0xff,0x69,0xfe,0xf6,0xff,0x5d,0xfe,0xf7,0xff,0x52,0xfe,0xf7,0xff,0x47,0xfe,0xf8,0xff,0x3c,0xfe,0xf8,0xff,0x31,0xfe,0xf9,0xff,0x25,0xfe,0xf9,0xff,0x1a,0xfe,0xfa,0xff,0x0f,0xfe,0xfb,0xff,0x03,0xfe,0xfb,0xff,0xf8,0xfd,0xfc,0xff,0xed,0xfd,0xfd,0xff,0xe1,0xfd,0xfd,0xff,0xd6,0xfd,0xfe,0xff,0xca,0xfd,0xff,0xff,0xbf,0xfd,  \
    0xff,0xff,0xb3,0xfd,0x00,0x00,0xa8,0xfd,0x01,0x00,0x9c,0xfd,0x01,0x00,0x90,0xfd,0x02,0x00,0x85,0xfd,0x03,0x00,0x79,0xfd,0x04,0x00,0x6d,0xfd,0x05,0x00,0x62,0xfd,0x05,0x00,0x56,0xfd,0x06,0x00,0x4a,0xfd,0x07,0x00,0x3e,0xfd,0x08,0x00,0x32,0xfd,0x09,0x00,0x26,0xfd,0x0a,0x00,0x1a,0xfd,0x0a,0x00,0x0e,0xfd,0x0b,0x00,0x02,0xfd,0x0c,0x00,0xf6,0xfc,0x0d,0x00,0xea,0xfc,0x0e,0x00,0xdd,0xfc,0x0f,0x00,0xd1,0xfc,0x10,0x00,0xc5,0xfc,0x11,0x00,0xb9,0xfc,0x12,0x00,  \
    0xac,0xfc,0x13,0x00,0xa0,0xfc,0x14,0x00,0x93,0xfc,0x15,0x00,0x87,0xfc,0x16,0x00,0x7a,0xfc,0x17,0x00,0x6e,0xfc,0x18,0x00,0x61,0xfc,0x19,0x00,0x54,0xfc,0x1a,0x00,0x47,0xfc,0x1c,0x00,0x3a,0xfc,0x1d,0x00,0x2e,0xfc,0x1e,0x00,0x21,0xfc,0x1f,0x00,0x14,0xfc,0x20,0x00,0x07,0xfc,0x21,0x00,0xf9,0xfb,0x22,0x00,0xec,0xfb,0x24,0x00,0xdf,0xfb,0x25,0x00,0xd2,0xfb,0x26,0x00,0xc4,0xfb,0x27,0x00,0xb7,0xfb,0x29,0x00,0xa9,0xfb,0x2a,0x00,0x9c,0xfb,0x2b,0x00,0x8e,0xfb,  \
    0x2c,0x00,0x81,0xfb,0x2e,0x00,0x73,0xfb,0x2f,0x00,0x65,0xfb,0x30,0x00,0x57,0xfb,0x31,0x00,0x49,0xfb,0x33,0x00,0x3b,0xfb,0x34,0x00,0x2d,0xfb,0x35,0x00,0x1f,0xfb,0x37,0x00,0x11,0xfb,0x38,0x00,0x03,0xfb,0x3a,0x00,0xf4,0xfa,0x3b,0x00,0xe6,0xfa,0x3c,0x00,0xd8,0xfa,0x3e,0x00,0xc9,0xfa,0x3f,0x00,0xba,0xfa,0x41,0x00,0xac,0xfa,0x42,0x00,0x9d,0xfa,0x43,0x00,0x8e,0xfa,0x45,0x00,0x7f,0xfa,0x46,0x00,0x70,0xfa,0x48,0x00,0x61,0xfa,0x49,0x00,0x52,0xfa,0x4b,0x00,  \
    0x43,0xfa,0x4c,0x00,0x34,0xfa,0x4e,0x00,0x24,0xfa,0x4f,0x00,0x15,0xfa,0x51,0x00,0x05,0xfa,0x52,0x00,0xf6,0xf9,0x54,0x00,0xe6,0xf9,0x55,0x00,0xd7,0xf9,0x57,0x00,0xc7,0xf9,0x58,0x00,0xb7,0xf9,0x5a,0x00,0xa7,0xf9,0x5c,0x00,0x97,0xf9,0x5d,0x00,0x87,0xf9,0x5f,0x00,0x76,0xf9,0x60,0x00,0x66,0xf9,0x62,0x00,0x56,0xf9,0x63,0x00,0x45,0xf9,0x65,0x00,0x35,0xf9,0x67,0x00,0x24,0xf9,0x68,0x00,0x13,0xf9,0x6a,0x00,0x02,0xf9,0x6b,0x00,0xf1,0xf8,0x6d,0x00,0xe0,0xf8,  \
    0x6f,0x00,0xcf,0xf8,0x70,0x00,0xbe,0xf8,0x72,0x00,0xad,0xf8,0x74,0x00,0x9b,0xf8,0x75,0x00,0x8a,0xf8,0x77,0x00,0x78,0xf8,0x79,0x00,0x67,0xf8,0x7a,0x00,0x55,0xf8,0x7c,0x00,0x43,0xf8,0x7d,0x00,0x31,0xf8,0x7f,0x00,0x1f,0xf8,0x81,0x00,0x0d,0xf8,0x82,0x00,0xfa,0xf7,0x84,0x00,0xe8,0xf7,0x86,0x00,0xd6,0xf7,0x87,0x00,0xc3,0xf7,0x89,0x00,0xb1,0xf7,0x8b,0x00,0x9e,0xf7,0x8c,0x00,0x8b,0xf7,0x8e,0x00,0x78,0xf7,0x90,0x00,0x65,0xf7,0x91,0x00,0x52,0xf7,0x93,0x00,  \
    0x3f,0xf7,0x95,0x00,0x2b,0xf7,0x97,0x00,0x18,0xf7,0x98,0x00,0x04,0xf7,0x9a,0x00,0xf1,0xf6,0x9c,0x00,0xdd,0xf6,0x9d,0x00,0xc9,0xf6,0x9f,0x00,0xb5,0xf6,0xa0,0x00,0xa1,0xf6,0xa2,0x00,0x8d,0xf6,0xa4,0x00,0x79,0xf6,0xa5,0x00,0x64,0xf6,0xa7,0x00,0x50,0xf6,0xa9,0x00,0x3b,0xf6,0xaa,0x00,0x26,0xf6,0xac,0x00,0x11,0xf6,0xae,0x00,0xfd,0xf5,0xaf,0x00,0xe7,0xf5,0xb1,0x00,0xd2,0xf5,0xb2,0x00,0xbd,0xf5,0xb4,0x00,0xa8,0xf5,0xb6,0x00,0x92,0xf5,0xb7,0x00,0x7c,0xf5,  \
    0xb9,0x00,0x67,0xf5,0xba,0x00,0x51,0xf5,0xbc,0x00,0x3b,0xf5,0xbe,0x00,0x25,0xf5,0xbf,0x00,0x0f,0xf5,0xc1,0x00,0xf8,0xf4,0xc2,0x00,0xe2,0xf4,0xc4,0x00,0xcb,0xf4,0xc5,0x00,0xb5,0xf4,0xc7,0x00,0x9e,0xf4,0xc8,0x00,0x87,0xf4,0xca,0x00,0x70,0xf4,0xcb,0x00,0x59,0xf4,0xcd,0x00,0x42,0xf4,0xce,0x00,0x2a,0xf4,0xd0,0x00,0x13,0xf4,0xd1,0x00,0xfb,0xf3,0xd3,0x00,0xe4,0xf3,0xd4,0x00,0xcc,0xf3,0xd5,0x00,0xb4,0xf3,0xd7,0x00,0x9c,0xf3,0xd8,0x00,0x84,0xf3,0xda,0x00,  \
    0x6b,0xf3,0xdb,0x00,0x53,0xf3,0xdc,0x00,0x3a,0xf3,0xde,0x00,0x22,0xf3,0xdf,0x00,0x09,0xf3,0xe0,0x00,0xf0,0xf2,0xe1,0x00,0xd7,0xf2,0xe3,0x00,0xbe,0xf2,0xe4,0x00,0xa5,0xf2,0xe5,0x00,0x8b,0xf2,0xe6,0x00,0x72,0xf2,0xe8,0x00,0x58,0xf2,0xe9,0x00,0x3e,0xf2,0xea,0x00,0x24,0xf2,0xeb,0x00,0x0a,0xf2,0xec,0x00,0xf0,0xf1,0xed,0x00,0xd6,0xf1,0xee,0x00,0xbb,0xf1,0xef,0x00,0xa1,0xf1,0xf0,0x00,0x86,0xf1,0xf1,0x00,0x6b,0xf1,0xf2,0x00,0x50,0xf1,0xf3,0x00,0x35,0xf1,  \
    0xf4,0x00,0x1a,0xf1,0xf5,0x00,0xff,0xf0,0xf6,0x00,0xe3,0xf0,0xf7,0x00,0xc8,0xf0,0xf8,0x00,0xac,0xf0,0xf9,0x00,0x90,0xf0,0xf9,0x00,0x74,0xf0,0xfa,0x00,0x58,0xf0,0xfb,0x00,0x3c,0xf0,0xfc,0x00,0x1f,0xf0,0xfc,0x00,0x03,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf8,0x00,0x0b,0x10,0xf8,0x00,0xee,0x0f,0xf7,0x00,0xd1,0x0f,0xf6,0x00,0xb5,0x0f,0xf6,0x00,0x99,0x0f,0xf5,0x00,0x7c,0x0f,0xf4,0x00,0x60,0x0f,0xf3,0x00,0x44,0x0f,0xf3,0x00,0x29,0x0f,0xf2,0x00,0x0d,0x0f,0xf1,0x00,0xf1,0x0e,0xf0,0x00,0xd6,0x0e,0xef,0x00,0xba,0x0e,0xee,0x00,0x9f,0x0e,0xed,0x00,0x84,0x0e,0xec,0x00,0x69,0x0e,0xeb,0x00,0x4e,0x0e,0xea,0x00,0x34,0x0e,0xe9,0x00,0x19,0x0e,  \
    0xe8,0x00,0xfe,0x0d,0xe7,0x00,0xe4,0x0d,0xe6,0x00,0xca,0x0d,0xe5,0x00,0xb0,0x0d,0xe4,0x00,0x96,0x0d,0xe3,0x00,0x7c,0x0d,0xe2,0x00,0x62,0x0d,0xe1,0x00,0x48,0x0d,0xe0,0x00,0x2f,0x0d,0xde,0x00,0x15,0x0d,0xdd,0x00,0xfc,0x0c,0xdc,0x00,0xe3,0x0c,0xdb,0x00,0xca,0x0c,0xda,0x00,0xb1,0x0c,0xd8,0x00,0x98,0x0c,0xd7,0x00,0x7f,0x0c,0xd6,0x00,0x66,0x0c,0xd4,0x00,0x4e,0x0c,0xd3,0x00,0x35,0x0c,0xd2,0x00,0x1d,0x0c,0xd1,0x00,0x05,0x0c,0xcf,0x00,0xed,0x0b,0xce,0x00,  \
    0xd5,0x0b,0xcc,0x00,0xbd,0x0b,0xcb,0x00,0xa6,0x0b,0xca,0x00,0x8e,0x0b,0xc8,0x00,0x77,0x0b,0xc7,0x00,0x5f,0x0b,0xc6,0x00,0x48,0x0b,0xc4,0x00,0x31,0x0b,0xc3,0x00,0x1a,0x0b,0xc1,0x00,0x03,0x0b,0xc0,0x00,0xec,0x0a,0xbe,0x00,0xd6,0x0a,0xbd,0x00,0xbf,0x0a,0xbb,0x00,0xa9,0x0a,0xba,0x00,0x92,0x0a,0xb8,0x00,0x7c,0x0a,0xb7,0x00,0x66,0x0a,0xb5,0x00,0x50,0x0a,0xb4,0x00,0x3a,0x0a,0xb2,0x00,0x24,0x0a,0xb1,0x00,0x0f,0x0a,0xaf,0x00,0xf9,0x09,0xae,0x00,0xe3,0x09,  \
    0xac,0x00,0xce,0x09,0xab,0x00,0xb9,0x09,0xa9,0x00,0xa4,0x09,0xa8,0x00,0x8f,0x09,0xa6,0x00,0x7a,0x09,0xa5,0x00,0x65,0x09,0xa3,0x00,0x50,0x09,0xa2,0x00,0x3b,0x09,0xa0,0x00,0x27,0x09,0x9e,0x00,0x12,0x09,0x9d,0x00,0xfe,0x08,0x9b,0x00,0xea,0x08,0x9a,0x00,0xd6,0x08,0x98,0x00,0xc2,0x08,0x97,0x00,0xae,0x08,0x95,0x00,0x9a,0x08,0x93,0x00,0x86,0x08,0x92,0x00,0x73,0x08,0x90,0x00,0x5f,0x08,0x8f,0x00,0x4c,0x08,0x8d,0x00,0x38,0x08,0x8c,0x00,0x25,0x08,0x8a,0x00,  \
    0x12,0x08,0x88,0x00,0xff,0x07,0x87,0x00,0xec,0x07,0x85,0x00,0xd9,0x07,0x84,0x00,0xc7,0x07,0x82,0x00,0xb4,0x07,0x81,0x00,0xa1,0x07,0x7f,0x00,0x8f,0x07,0x7d,0x00,0x7d,0x07,0x7c,0x00,0x6a,0x07,0x7a,0x00,0x58,0x07,0x79,0x00,0x46,0x07,0x77,0x00,0x34,0x07,0x76,0x00,0x23,0x07,0x74,0x00,0x11,0x07,0x72,0x00,0xff,0x06,0x71,0x00,0xee,0x06,0x6f,0x00,0xdc,0x06,0x6e,0x00,0xcb,0x06,0x6c,0x00,0xba,0x06,0x6b,0x00,0xa8,0x06,0x69,0x00,0x97,0x06,0x68,0x00,0x86,0x06,  \
    0x66,0x00,0x75,0x06,0x65,0x00,0x64,0x06,0x63,0x00,0x54,0x06,0x62,0x00,0x43,0x06,0x60,0x00,0x32,0x06,0x5f,0x00,0x22,0x06,0x5d,0x00,0x12,0x06,0x5c,0x00,0x01,0x06,0x5a,0x00,0xf1,0x05,0x59,0x00,0xe1,0x05,0x57,0x00,0xd1,0x05,0x56,0x00,0xc1,0x05,0x54,0x00,0xb1,0x05,0x53,0x00,0xa1,0x05,0x51,0x00,0x91,0x05,0x50,0x00,0x81,0x05,0x4f,0x00,0x72,0x05,0x4d,0x00,0x62,0x05,0x4c,0x00,0x53,0x05,0x4a,0x00,0x44,0x05,0x49,0x00,0x34,0x05,0x48,0x00,0x25,0x05,0x46,0x00,  \
    0x16,0x05,0x45,0x00,0x07,0x05,0x44,0x00,0xf8,0x04,0x42,0x00,0xe9,0x04,0x41,0x00,0xda,0x04,0x3f,0x00,0xcb,0x04,0x3e,0x00,0xbd,0x04,0x3d,0x00,0xae,0x04,0x3c,0x00,0x9f,0x04,0x3a,0x00,0x91,0x04,0x39,0x00,0x82,0x04,0x38,0x00,0x74,0x04,0x36,0x00,0x66,0x04,0x35,0x00,0x57,0x04,0x34,0x00,0x49,0x04,0x33,0x00,0x3b,0x04,0x31,0x00,0x2d,0x04,0x30,0x00,0x1f,0x04,0x2f,0x00,0x11,0x04,0x2e,0x00,0x03,0x04,0x2d,0x00,0xf5,0x03,0x2b,0x00,0xe8,0x03,0x2a,0x00,0xda,0x03,  \
    0x29,0x00,0xcc,0x03,0x28,0x00,0xbf,0x03,0x27,0x00,0xb1,0x03,0x26,0x00,0xa4,0x03,0x24,0x00,0x97,0x03,0x23,0x00,0x89,0x03,0x22,0x00,0x7c,0x03,0x21,0x00,0x6f,0x03,0x20,0x00,0x62,0x03,0x1f,0x00,0x55,0x03,0x1e,0x00,0x48,0x03,0x1d,0x00,0x3b,0x03,0x1c,0x00,0x2e,0x03,0x1b,0x00,0x21,0x03,0x1a,0x00,0x14,0x03,0x19,0x00,0x08,0x03,0x18,0x00,0xfb,0x02,0x17,0x00,0xee,0x02,0x16,0x00,0xe2,0x02,0x15,0x00,0xd5,0x02,0x14,0x00,0xc9,0x02,0x13,0x00,0xbc,0x02,0x12,0x00,  \
    0xb0,0x02,0x11,0x00,0xa4,0x02,0x10,0x00,0x97,0x02,0x0f,0x00,0x8b,0x02,0x0f,0x00,0x7f,0x02,0x0e,0x00,0x73,0x02,0x0d,0x00,0x67,0x02,0x0c,0x00,0x5a,0x02,0x0b,0x00,0x4e,0x02,0x0a,0x00,0x42,0x02,0x0a,0x00,0x37,0x02,0x09,0x00,0x2b,0x02,0x08,0x00,0x1f,0x02,0x07,0x00,0x13,0x02,0x07,0x00,0x07,0x02,0x06,0x00,0xfb,0x01,0x05,0x00,0xf0,0x01,0x05,0x00,0xe4,0x01,0x04,0x00,0xd8,0x01,0x03,0x00,0xcd,0x01,0x03,0x00,0xc1,0x01,0x02,0x00,0xb6,0x01,0x01,0x00,0xaa,0x01,  \
    0x01,0x00,0x9f,0x01,0x00,0x00,0x93,0x01,0xff,0xff,0x88,0x01,0xff,0xff,0x7d,0x01,0xfe,0xff,0x71,0x01,0xfe,0xff,0x66,0x01,0xfd,0xff,0x5b,0x01,0xfd,0xff,0x4f,0x01,0xfc,0xff,0x44,0x01,0xfc,0xff,0x39,0x01,0xfb,0xff,0x2e,0x01,0xfb,0xff,0x23,0x01,0xfa,0xff,0x17,0x01,0xfa,0xff,0x0c,0x01,0xf9,0xff,0x01,0x01,0xf9,0xff,0xf6,0x00,0xf9,0xff,0xeb,0x00,0xf8,0xff,0xe0,0x00,0xf8,0xff,0xd5,0x00,0xf7,0xff,0xca,0x00,0xf7,0xff,0xbf,0x00,0xf7,0xff,0xb4,0x00,0xf6,0xff,  \
    0xa9,0x00,0xf6,0xff,0x9e,0x00,0xf6,0xff,0x93,0x00,0xf6,0xff,0x88,0x00,0xf5,0xff,0x7d,0x00,0xf5,0xff,0x72,0x00,0xf5,0xff,0x67,0x00,0xf5,0xff,0x5d,0x00,0xf4,0xff,0x52,0x00,0xf4,0xff,0x47,0x00,0xf4,0xff,0x3c,0x00,0xf4,0xff,0x31,0x00,0xf4,0xff,0x26,0x00,0xf4,0xff,0x1c,0x00,0xf4,0xff,0x11,0x00,0xf3,0xff,0x06,0x00,0xf3,0xff,0xfb,0xff,0xf3,0xff,0xf0,0xff,0xf3,0xff,0xe6,0xff,0xf3,0xff,0xdb,0xff,0xf3,0xff,0xd0,0xff,0xf3,0xff,0xc5,0xff,0xf3,0xff,0xbb,0xff,  \
    0xf3,0xff,0xb0,0xff,0xf3,0xff,0xa5,0xff,0xf3,0xff,0x9a,0xff,0xf3,0xff,0x8f,0xff,0xf3,0xff,0x85,0xff,0xf4,0xff,0x7a,0xff,0xf4,0xff,0x6f,0xff,0xf4,0xff,0x64,0xff,0xf4,0xff,0x5a,0xff,0xf4,0xff,0x4f,0xff,0xf4,0xff,0x44,0xff,0xf4,0xff,0x39,0xff,0xf5,0xff,0x2e,0xff,0xf5,0xff,0x23,0xff,0xf5,0xff,0x19,0xff,0xf5,0xff,0x0e,0xff,0xf5,0xff,0x03,0xff,0xf6,0xff,0xf8,0xfe,0xf6,0xff,0xed,0xfe,0xf6,0xff,0xe2,0xfe,0xf7,0xff,0xd7,0xfe,0xf7,0xff,0xcc,0xfe,0xf7,0xff,  \
    0xc2,0xfe,0xf8,0xff,0xb7,0xfe,0xf8,0xff,0xac,0xfe,0xf8,0xff,0xa1,0xfe,0xf9,0xff,0x96,0xfe,0xf9,0xff,0x8b,0xfe,0xf9,0xff,0x80,0xfe,0xfa,0xff,0x74,0xfe,0xfa,0xff,0x69,0xfe,0xfb,0xff,0x5e,0xfe,0xfb,0xff,0x53,0xfe,0xfc,0xff,0x48,0xfe,0xfc,0xff,0x3d,0xfe,0xfd,0xff,0x32,0xfe,0xfd,0xff,0x26,0xfe,0xfe,0xff,0x1b,0xfe,0xfe,0xff,0x10,0xfe,0xff,0xff,0x05,0xfe,0xff,0xff,0xf9,0xfd,0x00,0x00,0xee,0xfd,0x01,0x00,0xe2,0xfd,0x01,0x00,0xd7,0xfd,0x02,0x00,0xcc,0xfd,  \
    0x03,0x00,0xc0,0xfd,0x03,0x00,0xb5,0xfd,0x04,0x00,0xa9,0xfd,0x05,0x00,0x9d,0xfd,0x05,0x00,0x92,0xfd,0x06,0x00,0x86,0xfd,0x07,0x00,0x7a,0xfd,0x07,0x00,0x6f,0xfd,0x08,0x00,0x63,0xfd,0x09,0x00,0x57,0xfd,0x0a,0x00,0x4b,0xfd,0x0b,0x00,0x3f,0xfd,0x0b,0x00,0x34,0xfd,0x0c,0x00,0x28,0xfd,0x0d,0x00,0x1c,0xfd,0x0e,0x00,0x10,0xfd,0x0f,0x00,0x04,0xfd,0x10,0x00,0xf7,0xfc,0x10,0x00,0xeb,0xfc,0x11,0x00,0xdf,0xfc,0x12,0x00,0xd3,0xfc,0x13,0x00,0xc7,0xfc,0x14,0x00,  \
    0xba,0xfc,0x15,0x00,0xae,0xfc,0x16,0x00,0xa1,0xfc,0x17,0x00,0x95,0xfc,0x18,0x00,0x88,0xfc,0x19,0x00,0x7c,0xfc,0x1a,0x00,0x6f,0xfc,0x1b,0x00,0x63,0xfc,0x1c,0x00,0x56,0xfc,0x1d,0x00,0x49,0xfc,0x1e,0x00,0x3c,0xfc,0x1f,0x00,0x2f,0xfc,0x20,0x00,0x23,0xfc,0x21,0x00,0x16,0xfc,0x22,0x00,0x08,0xfc,0x23,0x00,0xfb,0xfb,0x24,0x00,0xee,0xfb,0x26,0x00,0xe1,0xfb,0x27,0x00,0xd4,0xfb,0x28,0x00,0xc6,0xfb,0x29,0x00,0xb9,0xfb,0x2a,0x00,0xab,0xfb,0x2b,0x00,0x9e,0xfb,  \
    0x2d,0x00,0x90,0xfb,0x2e,0x00,0x83,0xfb,0x2f,0x00,0x75,0xfb,0x30,0x00,0x67,0xfb,0x31,0x00,0x59,0xfb,0x33,0x00,0x4b,0xfb,0x34,0x00,0x3d,0xfb,0x35,0x00,0x2f,0xfb,0x36,0x00,0x21,0xfb,0x38,0x00,0x13,0xfb,0x39,0x00,0x05,0xfb,0x3a,0x00,0xf7,0xfa,0x3c,0x00,0xe8,0xfa,0x3d,0x00,0xda,0xfa,0x3e,0x00,0xcb,0xfa,0x40,0x00,0xbd,0xfa,0x41,0x00,0xae,0xfa,0x42,0x00,0x9f,0xfa,0x44,0x00,0x90,0xfa,0x45,0x00,0x81,0xfa,0x46,0x00,0x73,0xfa,0x48,0x00,0x63,0xfa,0x49,0x00,  \
    0x54,0xfa,0x4a,0x00,0x45,0xfa,0x4c,0x00,0x36,0xfa,0x4d,0x00,0x27,0xfa,0x4f,0x00,0x17,0xfa,0x50,0x00,0x08,0xfa,0x52,0x00,0xf8,0xf9,0x53,0x00,0xe8,0xf9,0x54,0x00,0xd9,0xf9,0x56,0x00,0xc9,0xf9,0x57,0x00,0xb9,0xf9,0x59,0x00,0xa9,0xf9,0x5a,0x00,0x99,0xf9,0x5c,0x00,0x89,0xf9,0x5d,0x00,0x79,0xf9,0x5f,0x00,0x68,0xf9,0x60,0x00,0x58,0xf9,0x62,0x00,0x47,0xf9,0x63,0x00,0x37,0xf9,0x65,0x00,0x26,0xf9,0x66,0x00,0x15,0xf9,0x68,0x00,0x05,0xf9,0x69,0x00,0xf4,0xf8,  \
    0x6b,0x00,0xe3,0xf8,0x6c,0x00,0xd1,0xf8,0x6e,0x00,0xc0,0xf8,0x6f,0x00,0xaf,0xf8,0x71,0x00,0x9e,0xf8,0x73,0x00,0x8c,0xf8,0x74,0x00,0x7a,0xf8,0x76,0x00,0x69,0xf8,0x77,0x00,0x57,0xf8,0x79,0x00,0x45,0xf8,0x7a,0x00,0x33,0xf8,0x7c,0x00,0x21,0xf8,0x7d,0x00,0x0f,0xf8,0x7f,0x00,0xfd,0xf7,0x81,0x00,0xea,0xf7,0x82,0x00,0xd8,0xf7,0x84,0x00,0xc5,0xf7,0x85,0x00,0xb3,0xf7,0x87,0x00,0xa0,0xf7,0x88,0x00,0x8d,0xf7,0x8a,0x00,0x7a,0xf7,0x8c,0x00,0x67,0xf7,0x8d,0x00,  \
    0x54,0xf7,0x8f,0x00,0x41,0xf7,0x90,0x00,0x2e,0xf7,0x92,0x00,0x1a,0xf7,0x93,0x00,0x07,0xf7,0x95,0x00,0xf3,0xf6,0x97,0x00,0xdf,0xf6,0x98,0x00,0xcb,0xf6,0x9a,0x00,0xb7,0xf6,0x9b,0x00,0xa3,0xf6,0x9d,0x00,0x8f,0xf6,0x9e,0x00,0x7b,0xf6,0xa0,0x00,0x66,0xf6,0xa1,0x00,0x52,0xf6,0xa3,0x00,0x3d,0xf6,0xa5,0x00,0x28,0xf6,0xa6,0x00,0x14,0xf6,0xa8,0x00,0xff,0xf5,0xa9,0x00,0xea,0xf5,0xab,0x00,0xd4,0xf5,0xac,0x00,0xbf,0xf5,0xae,0x00,0xaa,0xf5,0xaf,0x00,0x94,0xf5,  \
    0xb1,0x00,0x7e,0xf5,0xb2,0x00,0x69,0xf5,0xb4,0x00,0x53,0xf5,0xb5,0x00,0x3d,0xf5,0xb7,0x00,0x27,0xf5,0xb8,0x00,0x11,0xf5,0xba,0x00,0xfa,0xf4,0xbb,0x00,0xe4,0xf4,0xbc,0x00,0xcd,0xf4,0xbe,0x00,0xb7,0xf4,0xbf,0x00,0xa0,0xf4,0xc1,0x00,0x89,0xf4,0xc2,0x00,0x72,0xf4,0xc4,0x00,0x5b,0xf4,0xc5,0x00,0x44,0xf4,0xc6,0x00,0x2c,0xf4,0xc8,0x00,0x15,0xf4,0xc9,0x00,0xfd,0xf3,0xca,0x00,0xe6,0xf3,0xcc,0x00,0xce,0xf3,0xcd,0x00,0xb6,0xf3,0xce,0x00,0x9e,0xf3,0xd0,0x00,  \
    0x86,0xf3,0xd1,0x00,0x6d,0xf3,0xd2,0x00,0x55,0xf3,0xd3,0x00,0x3c,0xf3,0xd5,0x00,0x24,0xf3,0xd6,0x00,0x0b,0xf3,0xd7,0x00,0xf2,0xf2,0xd8,0x00,0xd9,0xf2,0xda,0x00,0xc0,0xf2,0xdb,0x00,0xa6,0xf2,0xdc,0x00,0x8d,0xf2,0xdd,0x00,0x73,0xf2,0xde,0x00,0x5a,0xf2,0xdf,0x00,0x40,0xf2,0xe0,0x00,0x26,0xf2,0xe1,0x00,0x0c,0xf2,0xe2,0x00,0xf2,0xf1,0xe3,0x00,0xd7,0xf1,0xe4,0x00,0xbd,0xf1,0xe5,0x00,0xa2,0xf1,0xe6,0x00,0x88,0xf1,0xe7,0x00,0x6d,0xf1,0xe8,0x00,0x52,0xf1,  \
    0xe9,0x00,0x37,0xf1,0xea,0x00,0x1c,0xf1,0xeb,0x00,0x00,0xf1,0xec,0x00,0xe5,0xf0,0xed,0x00,0xc9,0xf0,0xed,0x00,0xae,0xf0,0xee,0x00,0x92,0xf0,0xef,0x00,0x76,0xf0,0xf0,0x00,0x5a,0xf0,0xf0,0x00,0x3d,0xf0,0xf1,0x00,0x21,0xf0,0xf2,0x00,0x05,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xee,0x00,0x09,0x10,0xed,0x00,0xed,0x0f,0xec,0x00,0xd0,0x0f,0xec,0x00,0xb4,0x0f,0xeb,0x00,0x97,0x0f,0xea,0x00,0x7b,0x0f,0xea,0x00,0x5f,0x0f,0xe9,0x00,0x43,0x0f,0xe8,0x00,0x27,0x0f,0xe7,0x00,0x0b,0x0f,0xe7,0x00,0xf0,0x0e,0xe6,0x00,0xd4,0x0e,0xe5,0x00,0xb9,0x0e,0xe4,0x00,0x9e,0x0e,0xe3,0x00,0x83,0x0e,0xe2,0x00,0x68,0x0e,0xe1,0x00,0x4d,0x0e,0xe1,0x00,0x32,0x0e,  \
    0xe0,0x00,0x17,0x0e,0xdf,0x00,0xfd,0x0d,0xde,0x00,0xe2,0x0d,0xdd,0x00,0xc8,0x0d,0xdc,0x00,0xae,0x0d,0xdb,0x00,0x94,0x0d,0xda,0x00,0x7a,0x0d,0xd9,0x00,0x60,0x0d,0xd7,0x00,0x47,0x0d,0xd6,0x00,0x2d,0x0d,0xd5,0x00,0x14,0x0d,0xd4,0x00,0xfa,0x0c,0xd3,0x00,0xe1,0x0c,0xd2,0x00,0xc8,0x0c,0xd1,0x00,0xaf,0x0c,0xd0,0x00,0x96,0x0c,0xce,0x00,0x7d,0x0c,0xcd,0x00,0x65,0x0c,0xcc,0x00,0x4c,0x0c,0xcb,0x00,0x34,0x0c,0xca,0x00,0x1c,0x0c,0xc8,0x00,0x03,0x0c,0xc7,0x00,  \
    0xeb,0x0b,0xc6,0x00,0xd3,0x0b,0xc4,0x00,0xbc,0x0b,0xc3,0x00,0xa4,0x0b,0xc2,0x00,0x8c,0x0b,0xc1,0x00,0x75,0x0b,0xbf,0x00,0x5e,0x0b,0xbe,0x00,0x46,0x0b,0xbd,0x00,0x2f,0x0b,0xbb,0x00,0x18,0x0b,0xba,0x00,0x01,0x0b,0xb9,0x00,0xeb,0x0a,0xb7,0x00,0xd4,0x0a,0xb6,0x00,0xbd,0x0a,0xb4,0x00,0xa7,0x0a,0xb3,0x00,0x91,0x0a,0xb2,0x00,0x7a,0x0a,0xb0,0x00,0x64,0x0a,0xaf,0x00,0x4e,0x0a,0xad,0x00,0x38,0x0a,0xac,0x00,0x22,0x0a,0xab,0x00,0x0d,0x0a,0xa9,0x00,0xf7,0x09,  \
    0xa8,0x00,0xe2,0x09,0xa6,0x00,0xcc,0x09,0xa5,0x00,0xb7,0x09,0xa3,0x00,0xa2,0x09,0xa2,0x00,0x8d,0x09,0xa1,0x00,0x78,0x09,0x9f,0x00,0x63,0x09,0x9e,0x00,0x4e,0x09,0x9c,0x00,0x39,0x09,0x9b,0x00,0x25,0x09,0x99,0x00,0x10,0x09,0x98,0x00,0xfc,0x08,0x96,0x00,0xe8,0x08,0x95,0x00,0xd4,0x08,0x93,0x00,0xc0,0x08,0x92,0x00,0xac,0x08,0x90,0x00,0x98,0x08,0x8f,0x00,0x84,0x08,0x8d,0x00,0x71,0x08,0x8c,0x00,0x5d,0x08,0x8a,0x00,0x4a,0x08,0x89,0x00,0x36,0x08,0x88,0x00,  \
    0x23,0x08,0x86,0x00,0x10,0x08,0x85,0x00,0xfd,0x07,0x83,0x00,0xea,0x07,0x82,0x00,0xd7,0x07,0x80,0x00,0xc5,0x07,0x7f,0x00,0xb2,0x07,0x7d,0x00,0x9f,0x07,0x7c,0x00,0x8d,0x07,0x7a,0x00,0x7b,0x07,0x79,0x00,0x68,0x07,0x77,0x00,0x56,0x07,0x76,0x00,0x44,0x07,0x74,0x00,0x32,0x07,0x73,0x00,0x21,0x07,0x71,0x00,0x0f,0x07,0x70,0x00,0xfd,0x06,0x6e,0x00,0xec,0x06,0x6d,0x00,0xda,0x06,0x6c,0x00,0xc9,0x06,0x6a,0x00,0xb8,0x06,0x69,0x00,0xa6,0x06,0x67,0x00,0x95,0x06,  \
    0x66,0x00,0x84,0x06,0x64,0x00,0x73,0x06,0x63,0x00,0x62,0x06,0x62,0x00,0x52,0x06,0x60,0x00,0x41,0x06,0x5f,0x00,0x30,0x06,0x5d,0x00,0x20,0x06,0x5c,0x00,0x10,0x06,0x5b,0x00,0xff,0x05,0x59,0x00,0xef,0x05,0x58,0x00,0xdf,0x05,0x56,0x00,0xcf,0x05,0x55,0x00,0xbf,0x05,0x54,0x00,0xaf,0x05,0x52,0x00,0x9f,0x05,0x51,0x00,0x8f,0x05,0x50,0x00,0x7f,0x05,0x4e,0x00,0x70,0x05,0x4d,0x00,0x60,0x05,0x4c,0x00,0x51,0x05,0x4a,0x00,0x42,0x05,0x49,0x00,0x32,0x05,0x48,0x00,  \
    0x23,0x05,0x46,0x00,0x14,0x05,0x45,0x00,0x05,0x05,0x44,0x00,0xf6,0x04,0x42,0x00,0xe7,0x04,0x41,0x00,0xd8,0x04,0x40,0x00,0xc9,0x04,0x3f,0x00,0xbb,0x04,0x3d,0x00,0xac,0x04,0x3c,0x00,0x9d,0x04,0x3b,0x00,0x8f,0x04,0x3a,0x00,0x80,0x04,0x39,0x00,0x72,0x04,0x37,0x00,0x64,0x04,0x36,0x00,0x55,0x04,0x35,0x00,0x47,0x04,0x34,0x00,0x39,0x04,0x33,0x00,0x2b,0x04,0x32,0x00,0x1d,0x04,0x30,0x00,0x0f,0x04,0x2f,0x00,0x01,0x04,0x2e,0x00,0xf4,0x03,0x2d,0x00,0xe6,0x03,  \
    0x2c,0x00,0xd8,0x03,0x2b,0x00,0xcb,0x03,0x2a,0x00,0xbd,0x03,0x29,0x00,0xb0,0x03,0x28,0x00,0xa2,0x03,0x27,0x00,0x95,0x03,0x25,0x00,0x88,0x03,0x24,0x00,0x7a,0x03,0x23,0x00,0x6d,0x03,0x22,0x00,0x60,0x03,0x21,0x00,0x53,0x03,0x20,0x00,0x46,0x03,0x1f,0x00,0x39,0x03,0x1e,0x00,0x2c,0x03,0x1d,0x00,0x20,0x03,0x1d,0x00,0x13,0x03,0x1c,0x00,0x06,0x03,0x1b,0x00,0xf9,0x02,0x1a,0x00,0xed,0x02,0x19,0x00,0xe0,0x02,0x18,0x00,0xd4,0x02,0x17,0x00,0xc7,0x02,0x16,0x00,  \
    0xbb,0x02,0x15,0x00,0xae,0x02,0x14,0x00,0xa2,0x02,0x14,0x00,0x96,0x02,0x13,0x00,0x8a,0x02,0x12,0x00,0x7d,0x02,0x11,0x00,0x71,0x02,0x10,0x00,0x65,0x02,0x10,0x00,0x59,0x02,0x0f,0x00,0x4d,0x02,0x0e,0x00,0x41,0x02,0x0d,0x00,0x35,0x02,0x0d,0x00,0x29,0x02,0x0c,0x00,0x1e,0x02,0x0b,0x00,0x12,0x02,0x0b,0x00,0x06,0x02,0x0a,0x00,0xfa,0x01,0x09,0x00,0xef,0x01,0x08,0x00,0xe3,0x01,0x08,0x00,0xd7,0x01,0x07,0x00,0xcc,0x01,0x07,0x00,0xc0,0x01,0x06,0x00,0xb5,0x01,  \
    0x05,0x00,0xa9,0x01,0x05,0x00,0x9e,0x01,0x04,0x00,0x92,0x01,0x04,0x00,0x87,0x01,0x03,0x00,0x7c,0x01,0x03,0x00,0x70,0x01,0x02,0x00,0x65,0x01,0x02,0x00,0x5a,0x01,0x01,0x00,0x4e,0x01,0x01,0x00,0x43,0x01,0x00,0x00,0x38,0x01,0x00,0x00,0x2d,0x01,0xff,0xff,0x22,0x01,0xff,0xff,0x17,0x01,0xfe,0xff,0x0c,0x01,0xfe,0xff,0x00,0x01,0xfe,0xff,0xf5,0x00,0xfd,0xff,0xea,0x00,0xfd,0xff,0xdf,0x00,0xfd,0xff,0xd4,0x00,0xfc,0xff,0xc9,0x00,0xfc,0xff,0xbe,0x00,0xfc,0xff,  \
    0xb3,0x00,0xfb,0xff,0xa8,0x00,0xfb,0xff,0x9e,0x00,0xfb,0xff,0x93,0x00,0xfa,0xff,0x88,0x00,0xfa,0xff,0x7d,0x00,0xfa,0xff,0x72,0x00,0xfa,0xff,0x67,0x00,0xfa,0xff,0x5c,0x00,0xf9,0xff,0x51,0x00,0xf9,0xff,0x47,0x00,0xf9,0xff,0x3c,0x00,0xf9,0xff,0x31,0x00,0xf9,0xff,0x26,0x00,0xf9,0xff,0x1b,0x00,0xf9,0xff,0x11,0x00,0xf8,0xff,0x06,0x00,0xf8,0xff,0xfb,0xff,0xf8,0xff,0xf0,0xff,0xf8,0xff,0xe6,0xff,0xf8,0xff,0xdb,0xff,0xf8,0xff,0xd0,0xff,0xf8,0xff,0xc5,0xff,  \
    0xf8,0xff,0xbb,0xff,0xf8,0xff,0xb0,0xff,0xf8,0xff,0xa5,0xff,0xf8,0xff,0x9a,0xff,0xf8,0xff,0x90,0xff,0xf8,0xff,0x85,0xff,0xf8,0xff,0x7a,0xff,0xf9,0xff,0x6f,0xff,0xf9,0xff,0x65,0xff,0xf9,0xff,0x5a,0xff,0xf9,0xff,0x4f,0xff,0xf9,0xff,0x44,0xff,0xf9,0xff,0x39,0xff,0xf9,0xff,0x2f,0xff,0xfa,0xff,0x24,0xff,0xfa,0xff,0x19,0xff,0xfa,0xff,0x0e,0xff,0xfa,0xff,0x03,0xff,0xfb,0xff,0xf9,0xfe,0xfb,0xff,0xee,0xfe,0xfb,0xff,0xe3,0xfe,0xfb,0xff,0xd8,0xfe,0xfc,0xff,  \
    0xcd,0xfe,0xfc,0xff,0xc2,0xfe,0xfc,0xff,0xb7,0xfe,0xfd,0xff,0xac,0xfe,0xfd,0xff,0xa1,0xfe,0xfd,0xff,0x96,0xfe,0xfe,0xff,0x8b,0xfe,0xfe,0xff,0x80,0xfe,0xfe,0xff,0x75,0xfe,0xff,0xff,0x6a,0xfe,0xff,0xff,0x5f,0xfe,0x00,0x00,0x54,0xfe,0x00,0x00,0x49,0xfe,0x01,0x00,0x3e,0xfe,0x01,0x00,0x32,0xfe,0x02,0x00,0x27,0xfe,0x02,0x00,0x1c,0xfe,0x03,0x00,0x11,0xfe,0x03,0x00,0x06,0xfe,0x04,0x00,0xfa,0xfd,0x04,0x00,0xef,0xfd,0x05,0x00,0xe3,0xfd,0x05,0x00,0xd8,0xfd,  \
    0x06,0x00,0xcd,0xfd,0x07,0x00,0xc1,0xfd,0x07,0x00,0xb6,0xfd,0x08,0x00,0xaa,0xfd,0x09,0x00,0x9f,0xfd,0x09,0x00,0x93,0xfd,0x0a,0x00,0x87,0xfd,0x0b,0x00,0x7c,0xfd,0x0b,0x00,0x70,0xfd,0x0c,0x00,0x64,0xfd,0x0d,0x00,0x58,0xfd,0x0d,0x00,0x4d,0xfd,0x0e,0x00,0x41,0xfd,0x0f,0x00,0x35,0xfd,0x10,0x00,0x29,0xfd,0x10,0x00,0x1d,0xfd,0x11,0x00,0x11,0xfd,0x12,0x00,0x05,0xfd,0x13,0x00,0xf9,0xfc,0x14,0x00,0xed,0xfc,0x14,0x00,0xe1,0xfc,0x15,0x00,0xd4,0xfc,0x16,0x00,  \
    0xc8,0xfc,0x17,0x00,0xbc,0xfc,0x18,0x00,0xaf,0xfc,0x19,0x00,0xa3,0xfc,0x1a,0x00,0x97,0xfc,0x1b,0x00,0x8a,0xfc,0x1c,0x00,0x7e,0xfc,0x1d,0x00,0x71,0xfc,0x1d,0x00,0x64,0xfc,0x1e,0x00,0x58,0xfc,0x1f,0x00,0x4b,0xfc,0x20,0x00,0x3e,0xfc,0x21,0x00,0x31,0xfc,0x22,0x00,0x24,0xfc,0x23,0x00,0x17,0xfc,0x24,0x00,0x0a,0xfc,0x25,0x00,0xfd,0xfb,0x27,0x00,0xf0,0xfb,0x28,0x00,0xe3,0xfb,0x29,0x00,0xd5,0xfb,0x2a,0x00,0xc8,0xfb,0x2b,0x00,0xbb,0xfb,0x2c,0x00,0xad,0xfb,  \
    0x2d,0x00,0xa0,0xfb,0x2e,0x00,0x92,0xfb,0x2f,0x00,0x85,0xfb,0x30,0x00,0x77,0xfb,0x32,0x00,0x69,0xfb,0x33,0x00,0x5b,0xfb,0x34,0x00,0x4d,0xfb,0x35,0x00,0x3f,0xfb,0x36,0x00,0x31,0xfb,0x37,0x00,0x23,0xfb,0x39,0x00,0x15,0xfb,0x3a,0x00,0x07,0xfb,0x3b,0x00,0xf9,0xfa,0x3c,0x00,0xea,0xfa,0x3d,0x00,0xdc,0xfa,0x3f,0x00,0xcd,0xfa,0x40,0x00,0xbf,0xfa,0x41,0x00,0xb0,0xfa,0x42,0x00,0xa1,0xfa,0x44,0x00,0x92,0xfa,0x45,0x00,0x84,0xfa,0x46,0x00,0x75,0xfa,0x48,0x00,  \
    0x66,0xfa,0x49,0x00,0x56,0xfa,0x4a,0x00,0x47,0xfa,0x4c,0x00,0x38,0xfa,0x4d,0x00,0x29,0xfa,0x4e,0x00,0x19,0xfa,0x50,0x00,0x0a,0xfa,0x51,0x00,0xfa,0xf9,0x52,0x00,0xeb,0xf9,0x54,0x00,0xdb,0xf9,0x55,0x00,0xcb,0xf9,0x56,0x00,0xbb,0xf9,0x58,0x00,0xab,0xf9,0x59,0x00,0x9b,0xf9,0x5a,0x00,0x8b,0xf9,0x5c,0x00,0x7b,0xf9,0x5d,0x00,0x6a,0xf9,0x5f,0x00,0x5a,0xf9,0x60,0x00,0x49,0xf9,0x61,0x00,0x39,0xf9,0x63,0x00,0x28,0xf9,0x64,0x00,0x17,0xf9,0x66,0x00,0x07,0xf9,  \
    0x67,0x00,0xf6,0xf8,0x69,0x00,0xe5,0xf8,0x6a,0x00,0xd4,0xf8,0x6b,0x00,0xc2,0xf8,0x6d,0x00,0xb1,0xf8,0x6e,0x00,0xa0,0xf8,0x70,0x00,0x8e,0xf8,0x71,0x00,0x7d,0xf8,0x73,0x00,0x6b,0xf8,0x74,0x00,0x59,0xf8,0x76,0x00,0x47,0xf8,0x77,0x00,0x35,0xf8,0x79,0x00,0x23,0xf8,0x7a,0x00,0x11,0xf8,0x7c,0x00,0xff,0xf7,0x7d,0x00,0xec,0xf7,0x7e,0x00,0xda,0xf7,0x80,0x00,0xc8,0xf7,0x81,0x00,0xb5,0xf7,0x83,0x00,0xa2,0xf7,0x84,0x00,0x8f,0xf7,0x86,0x00,0x7c,0xf7,0x87,0x00,  \
    0x69,0xf7,0x89,0x00,0x56,0xf7,0x8a,0x00,0x43,0xf7,0x8c,0x00,0x30,0xf7,0x8d,0x00,0x1c,0xf7,0x8f,0x00,0x09,0xf7,0x90,0x00,0xf5,0xf6,0x92,0x00,0xe1,0xf6,0x93,0x00,0xcd,0xf6,0x95,0x00,0xb9,0xf6,0x96,0x00,0xa5,0xf6,0x98,0x00,0x91,0xf6,0x99,0x00,0x7d,0xf6,0x9a,0x00,0x68,0xf6,0x9c,0x00,0x54,0xf6,0x9d,0x00,0x3f,0xf6,0x9f,0x00,0x2a,0xf6,0xa0,0x00,0x16,0xf6,0xa2,0x00,0x01,0xf6,0xa3,0x00,0xec,0xf5,0xa5,0x00,0xd6,0xf5,0xa6,0x00,0xc1,0xf5,0xa7,0x00,0xac,0xf5,  \
    0xa9,0x00,0x96,0xf5,0xaa,0x00,0x80,0xf5,0xac,0x00,0x6b,0xf5,0xad,0x00,0x55,0xf5,0xae,0x00,0x3f,0xf5,0xb0,0x00,0x29,0xf5,0xb1,0x00,0x13,0xf5,0xb3,0x00,0xfc,0xf4,0xb4,0x00,0xe6,0xf4,0xb5,0x00,0xcf,0xf4,0xb7,0x00,0xb9,0xf4,0xb8,0x00,0xa2,0xf4,0xb9,0x00,0x8b,0xf4,0xbb,0x00,0x74,0xf4,0xbc,0x00,0x5d,0xf4,0xbd,0x00,0x46,0xf4,0xbf,0x00,0x2e,0xf4,0xc0,0x00,0x17,0xf4,0xc1,0x00,0xff,0xf3,0xc2,0x00,0xe7,0xf3,0xc4,0x00,0xd0,0xf3,0xc5,0x00,0xb8,0xf3,0xc6,0x00,  \
    0xa0,0xf3,0xc7,0x00,0x87,0xf3,0xc8,0x00,0x6f,0xf3,0xca,0x00,0x57,0xf3,0xcb,0x00,0x3e,0xf3,0xcc,0x00,0x25,0xf3,0xcd,0x00,0x0d,0xf3,0xce,0x00,0xf4,0xf2,0xcf,0x00,0xdb,0xf2,0xd0,0x00,0xc1,0xf2,0xd2,0x00,0xa8,0xf2,0xd3,0x00,0x8f,0xf2,0xd4,0x00,0x75,0xf2,0xd5,0x00,0x5b,0xf2,0xd6,0x00,0x42,0xf2,0xd7,0x00,0x28,0xf2,0xd8,0x00,0x0e,0xf2,0xd9,0x00,0xf3,0xf1,0xda,0x00,0xd9,0xf1,0xdb,0x00,0xbf,0xf1,0xdc,0x00,0xa4,0xf1,0xdd,0x00,0x89,0xf1,0xdd,0x00,0x6f,0xf1,  \
    0xde,0x00,0x54,0xf1,0xdf,0x00,0x39,0xf1,0xe0,0x00,0x1d,0xf1,0xe1,0x00,0x02,0xf1,0xe2,0x00,0xe7,0xf0,0xe2,0x00,0xcb,0xf0,0xe3,0x00,0xaf,0xf0,0xe4,0x00,0x93,0xf0,0xe5,0x00,0x77,0xf0,0xe5,0x00,0x5b,0xf0,0xe6,0x00,0x3f,0xf0,0xe7,0x00,0x23,0xf0,0xe7,0x00,0x06,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe3,0x00,0x08,0x10,0xe2,0x00,0xeb,0x0f,0xe2,0x00,0xcf,0x0f,0xe1,0x00,0xb2,0x0f,0xe1,0x00,0x96,0x0f,0xe0,0x00,0x7a,0x0f,0xdf,0x00,0x5e,0x0f,0xdf,0x00,0x42,0x0f,0xde,0x00,0x26,0x0f,0xdd,0x00,0x0a,0x0f,0xdc,0x00,0xee,0x0e,0xdc,0x00,0xd3,0x0e,0xdb,0x00,0xb8,0x0e,0xda,0x00,0x9c,0x0e,0xd9,0x00,0x81,0x0e,0xd8,0x00,0x66,0x0e,0xd8,0x00,0x4b,0x0e,  \
    0xd7,0x00,0x31,0x0e,0xd6,0x00,0x16,0x0e,0xd5,0x00,0xfb,0x0d,0xd4,0x00,0xe1,0x0d,0xd3,0x00,0xc7,0x0d,0xd2,0x00,0xad,0x0d,0xd1,0x00,0x93,0x0d,0xd0,0x00,0x79,0x0d,0xcf,0x00,0x5f,0x0d,0xce,0x00,0x45,0x0d,0xcd,0x00,0x2c,0x0d,0xcc,0x00,0x12,0x0d,0xcb,0x00,0xf9,0x0c,0xca,0x00,0xe0,0x0c,0xc9,0x00,0xc6,0x0c,0xc8,0x00,0xad,0x0c,0xc7,0x00,0x95,0x0c,0xc6,0x00,0x7c,0x0c,0xc5,0x00,0x63,0x0c,0xc3,0x00,0x4b,0x0c,0xc2,0x00,0x32,0x0c,0xc1,0x00,0x1a,0x0c,0xc0,0x00,  \
    0x02,0x0c,0xbf,0x00,0xea,0x0b,0xbe,0x00,0xd2,0x0b,0xbc,0x00,0xba,0x0b,0xbb,0x00,0xa2,0x0b,0xba,0x00,0x8b,0x0b,0xb9,0x00,0x73,0x0b,0xb8,0x00,0x5c,0x0b,0xb6,0x00,0x45,0x0b,0xb5,0x00,0x2e,0x0b,0xb4,0x00,0x17,0x0b,0xb3,0x00,0x00,0x0b,0xb1,0x00,0xe9,0x0a,0xb0,0x00,0xd2,0x0a,0xaf,0x00,0xbc,0x0a,0xad,0x00,0xa5,0x0a,0xac,0x00,0x8f,0x0a,0xab,0x00,0x79,0x0a,0xaa,0x00,0x62,0x0a,0xa8,0x00,0x4c,0x0a,0xa7,0x00,0x36,0x0a,0xa6,0x00,0x21,0x0a,0xa4,0x00,0x0b,0x0a,  \
    0xa3,0x00,0xf5,0x09,0xa2,0x00,0xe0,0x09,0xa0,0x00,0xca,0x09,0x9f,0x00,0xb5,0x09,0x9e,0x00,0xa0,0x09,0x9c,0x00,0x8b,0x09,0x9b,0x00,0x76,0x09,0x99,0x00,0x61,0x09,0x98,0x00,0x4c,0x09,0x97,0x00,0x38,0x09,0x95,0x00,0x23,0x09,0x94,0x00,0x0f,0x09,0x93,0x00,0xfa,0x08,0x91,0x00,0xe6,0x08,0x90,0x00,0xd2,0x08,0x8e,0x00,0xbe,0x08,0x8d,0x00,0xaa,0x08,0x8c,0x00,0x96,0x08,0x8a,0x00,0x83,0x08,0x89,0x00,0x6f,0x08,0x88,0x00,0x5b,0x08,0x86,0x00,0x48,0x08,0x85,0x00,  \
    0x35,0x08,0x83,0x00,0x21,0x08,0x82,0x00,0x0e,0x08,0x81,0x00,0xfb,0x07,0x7f,0x00,0xe8,0x07,0x7e,0x00,0xd6,0x07,0x7c,0x00,0xc3,0x07,0x7b,0x00,0xb0,0x07,0x7a,0x00,0x9e,0x07,0x78,0x00,0x8b,0x07,0x77,0x00,0x79,0x07,0x76,0x00,0x67,0x07,0x74,0x00,0x55,0x07,0x73,0x00,0x43,0x07,0x71,0x00,0x31,0x07,0x70,0x00,0x1f,0x07,0x6f,0x00,0x0d,0x07,0x6d,0x00,0xfb,0x06,0x6c,0x00,0xea,0x06,0x6b,0x00,0xd8,0x06,0x69,0x00,0xc7,0x06,0x68,0x00,0xb6,0x06,0x67,0x00,0xa4,0x06,  \
    0x65,0x00,0x93,0x06,0x64,0x00,0x82,0x06,0x63,0x00,0x71,0x06,0x61,0x00,0x61,0x06,0x60,0x00,0x50,0x06,0x5f,0x00,0x3f,0x06,0x5d,0x00,0x2f,0x06,0x5c,0x00,0x1e,0x06,0x5b,0x00,0x0e,0x06,0x59,0x00,0xfd,0x05,0x58,0x00,0xed,0x05,0x57,0x00,0xdd,0x05,0x55,0x00,0xcd,0x05,0x54,0x00,0xbd,0x05,0x53,0x00,0xad,0x05,0x52,0x00,0x9d,0x05,0x50,0x00,0x8d,0x05,0x4f,0x00,0x7e,0x05,0x4e,0x00,0x6e,0x05,0x4d,0x00,0x5f,0x05,0x4b,0x00,0x4f,0x05,0x4a,0x00,0x40,0x05,0x49,0x00,  \
    0x30,0x05,0x48,0x00,0x21,0x05,0x46,0x00,0x12,0x05,0x45,0x00,0x03,0x05,0x44,0x00,0xf4,0x04,0x43,0x00,0xe5,0x04,0x42,0x00,0xd6,0x04,0x40,0x00,0xc8,0x04,0x3f,0x00,0xb9,0x04,0x3e,0x00,0xaa,0x04,0x3d,0x00,0x9c,0x04,0x3c,0x00,0x8d,0x04,0x3b,0x00,0x7f,0x04,0x3a,0x00,0x70,0x04,0x38,0x00,0x62,0x04,0x37,0x00,0x54,0x04,0x36,0x00,0x46,0x04,0x35,0x00,0x38,0x04,0x34,0x00,0x29,0x04,0x33,0x00,0x1c,0x04,0x32,0x00,0x0e,0x04,0x31,0x00,0x00,0x04,0x30,0x00,0xf2,0x03,  \
    0x2f,0x00,0xe4,0x03,0x2e,0x00,0xd7,0x03,0x2d,0x00,0xc9,0x03,0x2c,0x00,0xbc,0x03,0x2b,0x00,0xae,0x03,0x2a,0x00,0xa1,0x03,0x29,0x00,0x93,0x03,0x28,0x00,0x86,0x03,0x27,0x00,0x79,0x03,0x26,0x00,0x6c,0x03,0x25,0x00,0x5f,0x03,0x24,0x00,0x52,0x03,0x23,0x00,0x45,0x03,0x22,0x00,0x38,0x03,0x21,0x00,0x2b,0x03,0x20,0x00,0x1e,0x03,0x1f,0x00,0x11,0x03,0x1e,0x00,0x05,0x03,0x1e,0x00,0xf8,0x02,0x1d,0x00,0xeb,0x02,0x1c,0x00,0xdf,0x02,0x1b,0x00,0xd2,0x02,0x1a,0x00,  \
    0xc6,0x02,0x19,0x00,0xba,0x02,0x19,0x00,0xad,0x02,0x18,0x00,0xa1,0x02,0x17,0x00,0x95,0x02,0x16,0x00,0x88,0x02,0x15,0x00,0x7c,0x02,0x15,0x00,0x70,0x02,0x14,0x00,0x64,0x02,0x13,0x00,0x58,0x02,0x12,0x00,0x4c,0x02,0x12,0x00,0x40,0x02,0x11,0x00,0x34,0x02,0x10,0x00,0x28,0x02,0x10,0x00,0x1c,0x02,0x0f,0x00,0x11,0x02,0x0e,0x00,0x05,0x02,0x0e,0x00,0xf9,0x01,0x0d,0x00,0xee,0x01,0x0d,0x00,0xe2,0x01,0x0c,0x00,0xd6,0x01,0x0b,0x00,0xcb,0x01,0x0b,0x00,0xbf,0x01,  \
    0x0a,0x00,0xb4,0x01,0x0a,0x00,0xa8,0x01,0x09,0x00,0x9d,0x01,0x09,0x00,0x91,0x01,0x08,0x00,0x86,0x01,0x07,0x00,0x7b,0x01,0x07,0x00,0x6f,0x01,0x07,0x00,0x64,0x01,0x06,0x00,0x59,0x01,0x06,0x00,0x4e,0x01,0x05,0x00,0x42,0x01,0x05,0x00,0x37,0x01,0x04,0x00,0x2c,0x01,0x04,0x00,0x21,0x01,0x03,0x00,0x16,0x01,0x03,0x00,0x0b,0x01,0x03,0x00,0x00,0x01,0x02,0x00,0xf5,0x00,0x02,0x00,0xea,0x00,0x02,0x00,0xdf,0x00,0x01,0x00,0xd4,0x00,0x01,0x00,0xc9,0x00,0x01,0x00,  \
    0xbe,0x00,0x00,0x00,0xb3,0x00,0x00,0x00,0xa8,0x00,0x00,0x00,0x9d,0x00,0x00,0x00,0x92,0x00,0xff,0xff,0x87,0x00,0xff,0xff,0x7c,0x00,0xff,0xff,0x72,0x00,0xff,0xff,0x67,0x00,0xff,0xff,0x5c,0x00,0xfe,0xff,0x51,0x00,0xfe,0xff,0x46,0x00,0xfe,0xff,0x3c,0x00,0xfe,0xff,0x31,0x00,0xfe,0xff,0x26,0x00,0xfe,0xff,0x1b,0x00,0xfe,0xff,0x10,0x00,0xfd,0xff,0x06,0x00,0xfd,0xff,0xfb,0xff,0xfd,0xff,0xf0,0xff,0xfd,0xff,0xe6,0xff,0xfd,0xff,0xdb,0xff,0xfd,0xff,0xd0,0xff,  \
    0xfd,0xff,0xc5,0xff,0xfd,0xff,0xbb,0xff,0xfd,0xff,0xb0,0xff,0xfd,0xff,0xa5,0xff,0xfd,0xff,0x9a,0xff,0xfd,0xff,0x90,0xff,0xfd,0xff,0x85,0xff,0xfe,0xff,0x7a,0xff,0xfe,0xff,0x70,0xff,0xfe,0xff,0x65,0xff,0xfe,0xff,0x5a,0xff,0xfe,0xff,0x4f,0xff,0xfe,0xff,0x45,0xff,0xfe,0xff,0x3a,0xff,0xfe,0xff,0x2f,0xff,0xff,0xff,0x24,0xff,0xff,0xff,0x19,0xff,0xff,0xff,0x0f,0xff,0xff,0xff,0x04,0xff,0xff,0xff,0xf9,0xfe,0x00,0x00,0xee,0xfe,0x00,0x00,0xe3,0xfe,0x00,0x00,  \
    0xd8,0xfe,0x00,0x00,0xce,0xfe,0x01,0x00,0xc3,0xfe,0x01,0x00,0xb8,0xfe,0x01,0x00,0xad,0xfe,0x02,0x00,0xa2,0xfe,0x02,0x00,0x97,0xfe,0x02,0x00,0x8c,0xfe,0x03,0x00,0x81,0xfe,0x03,0x00,0x76,0xfe,0x03,0x00,0x6b,0xfe,0x04,0x00,0x60,0xfe,0x04,0x00,0x55,0xfe,0x05,0x00,0x4a,0xfe,0x05,0x00,0x3f,0xfe,0x06,0x00,0x33,0xfe,0x06,0x00,0x28,0xfe,0x07,0x00,0x1d,0xfe,0x07,0x00,0x12,0xfe,0x08,0x00,0x06,0xfe,0x08,0x00,0xfb,0xfd,0x09,0x00,0xf0,0xfd,0x09,0x00,0xe5,0xfd,  \
    0x0a,0x00,0xd9,0xfd,0x0a,0x00,0xce,0xfd,0x0b,0x00,0xc2,0xfd,0x0b,0x00,0xb7,0xfd,0x0c,0x00,0xab,0xfd,0x0d,0x00,0xa0,0xfd,0x0d,0x00,0x94,0xfd,0x0e,0x00,0x89,0xfd,0x0e,0x00,0x7d,0xfd,0x0f,0x00,0x71,0xfd,0x10,0x00,0x65,0xfd,0x10,0x00,0x5a,0xfd,0x11,0x00,0x4e,0xfd,0x12,0x00,0x42,0xfd,0x12,0x00,0x36,0xfd,0x13,0x00,0x2a,0xfd,0x14,0x00,0x1e,0xfd,0x15,0x00,0x12,0xfd,0x15,0x00,0x06,0xfd,0x16,0x00,0xfa,0xfc,0x17,0x00,0xee,0xfc,0x18,0x00,0xe2,0xfc,0x19,0x00,  \
    0xd6,0xfc,0x19,0x00,0xca,0xfc,0x1a,0x00,0xbd,0xfc,0x1b,0x00,0xb1,0xfc,0x1c,0x00,0xa5,0xfc,0x1d,0x00,0x98,0xfc,0x1e,0x00,0x8c,0xfc,0x1e,0x00,0x7f,0xfc,0x1f,0x00,0x73,0xfc,0x20,0x00,0x66,0xfc,0x21,0x00,0x59,0xfc,0x22,0x00,0x4c,0xfc,0x23,0x00,0x40,0xfc,0x24,0x00,0x33,0xfc,0x25,0x00,0x26,0xfc,0x26,0x00,0x19,0xfc,0x27,0x00,0x0c,0xfc,0x28,0x00,0xff,0xfb,0x29,0x00,0xf2,0xfb,0x2a,0x00,0xe4,0xfb,0x2b,0x00,0xd7,0xfb,0x2c,0x00,0xca,0xfb,0x2d,0x00,0xbc,0xfb,  \
    0x2e,0x00,0xaf,0xfb,0x2f,0x00,0xa2,0xfb,0x30,0x00,0x94,0xfb,0x31,0x00,0x86,0xfb,0x32,0x00,0x79,0xfb,0x33,0x00,0x6b,0xfb,0x34,0x00,0x5d,0xfb,0x35,0x00,0x4f,0xfb,0x36,0x00,0x41,0xfb,0x37,0x00,0x33,0xfb,0x38,0x00,0x25,0xfb,0x39,0x00,0x17,0xfb,0x3b,0x00,0x09,0xfb,0x3c,0x00,0xfa,0xfa,0x3d,0x00,0xec,0xfa,0x3e,0x00,0xde,0xfa,0x3f,0x00,0xcf,0xfa,0x40,0x00,0xc0,0xfa,0x42,0x00,0xb2,0xfa,0x43,0x00,0xa3,0xfa,0x44,0x00,0x94,0xfa,0x45,0x00,0x85,0xfa,0x46,0x00,  \
    0x77,0xfa,0x48,0x00,0x67,0xfa,0x49,0x00,0x58,0xfa,0x4a,0x00,0x49,0xfa,0x4b,0x00,0x3a,0xfa,0x4c,0x00,0x2b,0xfa,0x4e,0x00,0x1b,0xfa,0x4f,0x00,0x0c,0xfa,0x50,0x00,0xfc,0xf9,0x51,0x00,0xed,0xf9,0x53,0x00,0xdd,0xf9,0x54,0x00,0xcd,0xf9,0x55,0x00,0xbd,0xf9,0x57,0x00,0xad,0xf9,0x58,0x00,0x9d,0xf9,0x59,0x00,0x8d,0xf9,0x5b,0x00,0x7d,0xf9,0x5c,0x00,0x6c,0xf9,0x5d,0x00,0x5c,0xf9,0x5e,0x00,0x4b,0xf9,0x60,0x00,0x3b,0xf9,0x61,0x00,0x2a,0xf9,0x62,0x00,0x19,0xf9,  \
    0x64,0x00,0x09,0xf9,0x65,0x00,0xf8,0xf8,0x66,0x00,0xe7,0xf8,0x68,0x00,0xd6,0xf8,0x69,0x00,0xc4,0xf8,0x6a,0x00,0xb3,0xf8,0x6c,0x00,0xa2,0xf8,0x6d,0x00,0x90,0xf8,0x6f,0x00,0x7f,0xf8,0x70,0x00,0x6d,0xf8,0x71,0x00,0x5b,0xf8,0x73,0x00,0x49,0xf8,0x74,0x00,0x37,0xf8,0x75,0x00,0x25,0xf8,0x77,0x00,0x13,0xf8,0x78,0x00,0x01,0xf8,0x7a,0x00,0xee,0xf7,0x7b,0x00,0xdc,0xf7,0x7c,0x00,0xc9,0xf7,0x7e,0x00,0xb7,0xf7,0x7f,0x00,0xa4,0xf7,0x80,0x00,0x91,0xf7,0x82,0x00,  \
    0x7e,0xf7,0x83,0x00,0x6b,0xf7,0x85,0x00,0x58,0xf7,0x86,0x00,0x45,0xf7,0x87,0x00,0x32,0xf7,0x89,0x00,0x1e,0xf7,0x8a,0x00,0x0b,0xf7,0x8b,0x00,0xf7,0xf6,0x8d,0x00,0xe3,0xf6,0x8e,0x00,0xcf,0xf6,0x90,0x00,0xbb,0xf6,0x91,0x00,0xa7,0xf6,0x92,0x00,0x93,0xf6,0x94,0x00,0x7f,0xf6,0x95,0x00,0x6a,0xf6,0x96,0x00,0x56,0xf6,0x98,0x00,0x41,0xf6,0x99,0x00,0x2c,0xf6,0x9a,0x00,0x17,0xf6,0x9c,0x00,0x02,0xf6,0x9d,0x00,0xed,0xf5,0x9e,0x00,0xd8,0xf5,0xa0,0x00,0xc3,0xf5,  \
    0xa1,0x00,0xad,0xf5,0xa2,0x00,0x98,0xf5,0xa4,0x00,0x82,0xf5,0xa5,0x00,0x6d,0xf5,0xa6,0x00,0x57,0xf5,0xa8,0x00,0x41,0xf5,0xa9,0x00,0x2b,0xf5,0xaa,0x00,0x14,0xf5,0xac,0x00,0xfe,0xf4,0xad,0x00,0xe8,0xf4,0xae,0x00,0xd1,0xf4,0xaf,0x00,0xba,0xf4,0xb1,0x00,0xa4,0xf4,0xb2,0x00,0x8d,0xf4,0xb3,0x00,0x76,0xf4,0xb4,0x00,0x5f,0xf4,0xb6,0x00,0x47,0xf4,0xb7,0x00,0x30,0xf4,0xb8,0x00,0x18,0xf4,0xb9,0x00,0x01,0xf4,0xba,0x00,0xe9,0xf3,0xbb,0x00,0xd1,0xf3,0xbd,0x00,  \
    0xb9,0xf3,0xbe,0x00,0xa1,0xf3,0xbf,0x00,0x89,0xf3,0xc0,0x00,0x71,0xf3,0xc1,0x00,0x58,0xf3,0xc2,0x00,0x40,0xf3,0xc3,0x00,0x27,0xf3,0xc4,0x00,0x0e,0xf3,0xc5,0x00,0xf5,0xf2,0xc6,0x00,0xdc,0xf2,0xc7,0x00,0xc3,0xf2,0xc9,0x00,0xaa,0xf2,0xca,0x00,0x90,0xf2,0xcb,0x00,0x77,0xf2,0xcb,0x00,0x5d,0xf2,0xcc,0x00,0x43,0xf2,0xcd,0x00,0x29,0xf2,0xce,0x00,0x0f,0xf2,0xcf,0x00,0xf5,0xf1,0xd0,0x00,0xdb,0xf1,0xd1,0x00,0xc0,0xf1,0xd2,0x00,0xa6,0xf1,0xd3,0x00,0x8b,0xf1,  \
    0xd4,0x00,0x70,0xf1,0xd4,0x00,0x55,0xf1,0xd5,0x00,0x3a,0xf1,0xd6,0x00,0x1f,0xf1,0xd7,0x00,0x04,0xf1,0xd7,0x00,0xe8,0xf0,0xd8,0x00,0xcc,0xf0,0xd9,0x00,0xb1,0xf0,0xda,0x00,0x95,0xf0,0xda,0x00,0x79,0xf0,0xdb,0x00,0x5d,0xf0,0xdc,0x00,0x41,0xf0,0xdc,0x00,0x24,0xf0,0xdd,0x00,0x08,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xd8,0x00,0x07,0x10,0xd7,0x00,0xea,0x0f,0xd7,0x00,0xcd,0x0f,0xd6,0x00,0xb1,0x0f,0xd6,0x00,0x95,0x0f,0xd5,0x00,0x78,0x0f,0xd4,0x00,0x5c,0x0f,0xd4,0x00,0x40,0x0f,0xd3,0x00,0x24,0x0f,0xd2,0x00,0x09,0x0f,0xd2,0x00,0xed,0x0e,0xd1,0x00,0xd2,0x0e,0xd0,0x00,0xb6,0x0e,0xcf,0x00,0x9b,0x0e,0xcf,0x00,0x80,0x0e,0xce,0x00,0x65,0x0e,  \
    0xcd,0x00,0x4a,0x0e,0xcc,0x00,0x2f,0x0e,0xcc,0x00,0x15,0x0e,0xcb,0x00,0xfa,0x0d,0xca,0x00,0xe0,0x0d,0xc9,0x00,0xc5,0x0d,0xc8,0x00,0xab,0x0d,0xc7,0x00,0x91,0x0d,0xc6,0x00,0x77,0x0d,0xc5,0x00,0x5d,0x0d,0xc5,0x00,0x44,0x0d,0xc4,0x00,0x2a,0x0d,0xc3,0x00,0x11,0x0d,0xc2,0x00,0xf7,0x0c,0xc1,0x00,0xde,0x0c,0xc0,0x00,0xc5,0x0c,0xbf,0x00,0xac,0x0c,0xbe,0x00,0x93,0x0c,0xbd,0x00,0x7a,0x0c,0xbc,0x00,0x62,0x0c,0xbb,0x00,0x49,0x0c,0xba,0x00,0x31,0x0c,0xb8,0x00,  \
    0x19,0x0c,0xb7,0x00,0x00,0x0c,0xb6,0x00,0xe8,0x0b,0xb5,0x00,0xd0,0x0b,0xb4,0x00,0xb9,0x0b,0xb3,0x00,0xa1,0x0b,0xb2,0x00,0x89,0x0b,0xb1,0x00,0x72,0x0b,0xb0,0x00,0x5a,0x0b,0xae,0x00,0x43,0x0b,0xad,0x00,0x2c,0x0b,0xac,0x00,0x15,0x0b,0xab,0x00,0xfe,0x0a,0xaa,0x00,0xe7,0x0a,0xa9,0x00,0xd1,0x0a,0xa7,0x00,0xba,0x0a,0xa6,0x00,0xa4,0x0a,0xa5,0x00,0x8d,0x0a,0xa4,0x00,0x77,0x0a,0xa3,0x00,0x61,0x0a,0xa1,0x00,0x4b,0x0a,0xa0,0x00,0x35,0x0a,0x9f,0x00,0x1f,0x0a,  \
    0x9e,0x00,0x09,0x0a,0x9c,0x00,0xf4,0x09,0x9b,0x00,0xde,0x09,0x9a,0x00,0xc9,0x09,0x99,0x00,0xb4,0x09,0x97,0x00,0x9e,0x09,0x96,0x00,0x89,0x09,0x95,0x00,0x74,0x09,0x94,0x00,0x5f,0x09,0x92,0x00,0x4b,0x09,0x91,0x00,0x36,0x09,0x90,0x00,0x21,0x09,0x8f,0x00,0x0d,0x09,0x8d,0x00,0xf9,0x08,0x8c,0x00,0xe4,0x08,0x8b,0x00,0xd0,0x08,0x89,0x00,0xbc,0x08,0x88,0x00,0xa8,0x08,0x87,0x00,0x95,0x08,0x86,0x00,0x81,0x08,0x84,0x00,0x6d,0x08,0x83,0x00,0x5a,0x08,0x82,0x00,  \
    0x46,0x08,0x80,0x00,0x33,0x08,0x7f,0x00,0x20,0x08,0x7e,0x00,0x0d,0x08,0x7d,0x00,0xfa,0x07,0x7b,0x00,0xe7,0x07,0x7a,0x00,0xd4,0x07,0x79,0x00,0xc1,0x07,0x77,0x00,0xae,0x07,0x76,0x00,0x9c,0x07,0x75,0x00,0x8a,0x07,0x74,0x00,0x77,0x07,0x72,0x00,0x65,0x07,0x71,0x00,0x53,0x07,0x70,0x00,0x41,0x07,0x6e,0x00,0x2f,0x07,0x6d,0x00,0x1d,0x07,0x6c,0x00,0x0b,0x07,0x6b,0x00,0xfa,0x06,0x69,0x00,0xe8,0x06,0x68,0x00,0xd7,0x06,0x67,0x00,0xc5,0x06,0x66,0x00,0xb4,0x06,  \
    0x64,0x00,0xa3,0x06,0x63,0x00,0x92,0x06,0x62,0x00,0x81,0x06,0x61,0x00,0x70,0x06,0x5f,0x00,0x5f,0x06,0x5e,0x00,0x4e,0x06,0x5d,0x00,0x3d,0x06,0x5c,0x00,0x2d,0x06,0x5a,0x00,0x1c,0x06,0x59,0x00,0x0c,0x06,0x58,0x00,0xfc,0x05,0x57,0x00,0xeb,0x05,0x56,0x00,0xdb,0x05,0x54,0x00,0xcb,0x05,0x53,0x00,0xbb,0x05,0x52,0x00,0xab,0x05,0x51,0x00,0x9b,0x05,0x50,0x00,0x8c,0x05,0x4e,0x00,0x7c,0x05,0x4d,0x00,0x6c,0x05,0x4c,0x00,0x5d,0x05,0x4b,0x00,0x4d,0x05,0x4a,0x00,  \
    0x3e,0x05,0x49,0x00,0x2f,0x05,0x48,0x00,0x20,0x05,0x46,0x00,0x10,0x05,0x45,0x00,0x01,0x05,0x44,0x00,0xf2,0x04,0x43,0x00,0xe3,0x04,0x42,0x00,0xd5,0x04,0x41,0x00,0xc6,0x04,0x40,0x00,0xb7,0x04,0x3f,0x00,0xa8,0x04,0x3e,0x00,0x9a,0x04,0x3d,0x00,0x8b,0x04,0x3c,0x00,0x7d,0x04,0x3a,0x00,0x6f,0x04,0x39,0x00,0x60,0x04,0x38,0x00,0x52,0x04,0x37,0x00,0x44,0x04,0x36,0x00,0x36,0x04,0x35,0x00,0x28,0x04,0x34,0x00,0x1a,0x04,0x33,0x00,0x0c,0x04,0x32,0x00,0xfe,0x03,  \
    0x31,0x00,0xf0,0x03,0x30,0x00,0xe3,0x03,0x2f,0x00,0xd5,0x03,0x2e,0x00,0xc8,0x03,0x2e,0x00,0xba,0x03,0x2d,0x00,0xad,0x03,0x2c,0x00,0x9f,0x03,0x2b,0x00,0x92,0x03,0x2a,0x00,0x85,0x03,0x29,0x00,0x77,0x03,0x28,0x00,0x6a,0x03,0x27,0x00,0x5d,0x03,0x26,0x00,0x50,0x03,0x25,0x00,0x43,0x03,0x25,0x00,0x36,0x03,0x24,0x00,0x2a,0x03,0x23,0x00,0x1d,0x03,0x22,0x00,0x10,0x03,0x21,0x00,0x03,0x03,0x20,0x00,0xf7,0x02,0x20,0x00,0xea,0x02,0x1f,0x00,0xde,0x02,0x1e,0x00,  \
    0xd1,0x02,0x1d,0x00,0xc5,0x02,0x1c,0x00,0xb8,0x02,0x1c,0x00,0xac,0x02,0x1b,0x00,0xa0,0x02,0x1a,0x00,0x93,0x02,0x1a,0x00,0x87,0x02,0x19,0x00,0x7b,0x02,0x18,0x00,0x6f,0x02,0x17,0x00,0x63,0x02,0x17,0x00,0x57,0x02,0x16,0x00,0x4b,0x02,0x15,0x00,0x3f,0x02,0x15,0x00,0x33,0x02,0x14,0x00,0x27,0x02,0x14,0x00,0x1b,0x02,0x13,0x00,0x10,0x02,0x12,0x00,0x04,0x02,0x12,0x00,0xf8,0x01,0x11,0x00,0xed,0x01,0x11,0x00,0xe1,0x01,0x10,0x00,0xd5,0x01,0x0f,0x00,0xca,0x01,  \
    0x0f,0x00,0xbe,0x01,0x0e,0x00,0xb3,0x01,0x0e,0x00,0xa7,0x01,0x0d,0x00,0x9c,0x01,0x0d,0x00,0x91,0x01,0x0c,0x00,0x85,0x01,0x0c,0x00,0x7a,0x01,0x0b,0x00,0x6f,0x01,0x0b,0x00,0x63,0x01,0x0b,0x00,0x58,0x01,0x0a,0x00,0x4d,0x01,0x0a,0x00,0x42,0x01,0x09,0x00,0x37,0x01,0x09,0x00,0x2b,0x01,0x08,0x00,0x20,0x01,0x08,0x00,0x15,0x01,0x08,0x00,0x0a,0x01,0x07,0x00,0xff,0x00,0x07,0x00,0xf4,0x00,0x07,0x00,0xe9,0x00,0x06,0x00,0xde,0x00,0x06,0x00,0xd3,0x00,0x06,0x00,  \
    0xc8,0x00,0x06,0x00,0xbd,0x00,0x05,0x00,0xb2,0x00,0x05,0x00,0xa7,0x00,0x05,0x00,0x9d,0x00,0x05,0x00,0x92,0x00,0x04,0x00,0x87,0x00,0x04,0x00,0x7c,0x00,0x04,0x00,0x71,0x00,0x04,0x00,0x66,0x00,0x04,0x00,0x5c,0x00,0x03,0x00,0x51,0x00,0x03,0x00,0x46,0x00,0x03,0x00,0x3b,0x00,0x03,0x00,0x31,0x00,0x03,0x00,0x26,0x00,0x03,0x00,0x1b,0x00,0x03,0x00,0x10,0x00,0x03,0x00,0x06,0x00,0x02,0x00,0xfb,0xff,0x02,0x00,0xf0,0xff,0x02,0x00,0xe5,0xff,0x02,0x00,0xdb,0xff,  \
    0x02,0x00,0xd0,0xff,0x02,0x00,0xc5,0xff,0x02,0x00,0xbb,0xff,0x02,0x00,0xb0,0xff,0x02,0x00,0xa5,0xff,0x02,0x00,0x9b,0xff,0x02,0x00,0x90,0xff,0x03,0x00,0x85,0xff,0x03,0x00,0x7a,0xff,0x03,0x00,0x70,0xff,0x03,0x00,0x65,0xff,0x03,0x00,0x5a,0xff,0x03,0x00,0x50,0xff,0x03,0x00,0x45,0xff,0x03,0x00,0x3a,0xff,0x03,0x00,0x2f,0xff,0x04,0x00,0x25,0xff,0x04,0x00,0x1a,0xff,0x04,0x00,0x0f,0xff,0x04,0x00,0x04,0xff,0x04,0x00,0xf9,0xfe,0x05,0x00,0xef,0xfe,0x05,0x00,  \
    0xe4,0xfe,0x05,0x00,0xd9,0xfe,0x05,0x00,0xce,0xfe,0x06,0x00,0xc3,0xfe,0x06,0x00,0xb8,0xfe,0x06,0x00,0xad,0xfe,0x06,0x00,0xa3,0xfe,0x07,0x00,0x98,0xfe,0x07,0x00,0x8d,0xfe,0x07,0x00,0x82,0xfe,0x08,0x00,0x77,0xfe,0x08,0x00,0x6c,0xfe,0x09,0x00,0x61,0xfe,0x09,0x00,0x56,0xfe,0x09,0x00,0x4a,0xfe,0x0a,0x00,0x3f,0xfe,0x0a,0x00,0x34,0xfe,0x0b,0x00,0x29,0xfe,0x0b,0x00,0x1e,0xfe,0x0b,0x00,0x13,0xfe,0x0c,0x00,0x07,0xfe,0x0c,0x00,0xfc,0xfd,0x0d,0x00,0xf1,0xfd,  \
    0x0d,0x00,0xe5,0xfd,0x0e,0x00,0xda,0xfd,0x0e,0x00,0xcf,0xfd,0x0f,0x00,0xc3,0xfd,0x0f,0x00,0xb8,0xfd,0x10,0x00,0xac,0xfd,0x11,0x00,0xa1,0xfd,0x11,0x00,0x95,0xfd,0x12,0x00,0x8a,0xfd,0x12,0x00,0x7e,0xfd,0x13,0x00,0x72,0xfd,0x14,0x00,0x67,0xfd,0x14,0x00,0x5b,0xfd,0x15,0x00,0x4f,0xfd,0x15,0x00,0x43,0xfd,0x16,0x00,0x38,0xfd,0x17,0x00,0x2c,0xfd,0x17,0x00,0x20,0xfd,0x18,0x00,0x14,0xfd,0x19,0x00,0x08,0xfd,0x1a,0x00,0xfc,0xfc,0x1a,0x00,0xf0,0xfc,0x1b,0x00,  \
    0xe3,0xfc,0x1c,0x00,0xd7,0xfc,0x1d,0x00,0xcb,0xfc,0x1d,0x00,0xbf,0xfc,0x1e,0x00,0xb2,0xfc,0x1f,0x00,0xa6,0xfc,0x20,0x00,0x9a,0xfc,0x20,0x00,0x8d,0xfc,0x21,0x00,0x81,0xfc,0x22,0x00,0x74,0xfc,0x23,0x00,0x67,0xfc,0x24,0x00,0x5b,0xfc,0x25,0x00,0x4e,0xfc,0x25,0x00,0x41,0xfc,0x26,0x00,0x34,0xfc,0x27,0x00,0x27,0xfc,0x28,0x00,0x1a,0xfc,0x29,0x00,0x0d,0xfc,0x2a,0x00,0x00,0xfc,0x2b,0x00,0xf3,0xfb,0x2c,0x00,0xe6,0xfb,0x2d,0x00,0xd9,0xfb,0x2e,0x00,0xcb,0xfb,  \
    0x2e,0x00,0xbe,0xfb,0x2f,0x00,0xb1,0xfb,0x30,0x00,0xa3,0xfb,0x31,0x00,0x96,0xfb,0x32,0x00,0x88,0xfb,0x33,0x00,0x7a,0xfb,0x34,0x00,0x6d,0xfb,0x35,0x00,0x5f,0xfb,0x36,0x00,0x51,0xfb,0x37,0x00,0x43,0xfb,0x38,0x00,0x35,0xfb,0x39,0x00,0x27,0xfb,0x3a,0x00,0x19,0xfb,0x3c,0x00,0x0a,0xfb,0x3d,0x00,0xfc,0xfa,0x3e,0x00,0xee,0xfa,0x3f,0x00,0xdf,0xfa,0x40,0x00,0xd1,0xfa,0x41,0x00,0xc2,0xfa,0x42,0x00,0xb4,0xfa,0x43,0x00,0xa5,0xfa,0x44,0x00,0x96,0xfa,0x45,0x00,  \
    0x87,0xfa,0x46,0x00,0x78,0xfa,0x48,0x00,0x69,0xfa,0x49,0x00,0x5a,0xfa,0x4a,0x00,0x4b,0xfa,0x4b,0x00,0x3c,0xfa,0x4c,0x00,0x2c,0xfa,0x4d,0x00,0x1d,0xfa,0x4e,0x00,0x0e,0xfa,0x50,0x00,0xfe,0xf9,0x51,0x00,0xee,0xf9,0x52,0x00,0xdf,0xf9,0x53,0x00,0xcf,0xf9,0x54,0x00,0xbf,0xf9,0x56,0x00,0xaf,0xf9,0x57,0x00,0x9f,0xf9,0x58,0x00,0x8f,0xf9,0x59,0x00,0x7f,0xf9,0x5a,0x00,0x6e,0xf9,0x5c,0x00,0x5e,0xf9,0x5d,0x00,0x4d,0xf9,0x5e,0x00,0x3d,0xf9,0x5f,0x00,0x2c,0xf9,  \
    0x61,0x00,0x1b,0xf9,0x62,0x00,0x0a,0xf9,0x63,0x00,0xfa,0xf8,0x64,0x00,0xe8,0xf8,0x66,0x00,0xd7,0xf8,0x67,0x00,0xc6,0xf8,0x68,0x00,0xb5,0xf8,0x69,0x00,0xa3,0xf8,0x6b,0x00,0x92,0xf8,0x6c,0x00,0x80,0xf8,0x6d,0x00,0x6f,0xf8,0x6e,0x00,0x5d,0xf8,0x70,0x00,0x4b,0xf8,0x71,0x00,0x39,0xf8,0x72,0x00,0x27,0xf8,0x74,0x00,0x15,0xf8,0x75,0x00,0x03,0xf8,0x76,0x00,0xf0,0xf7,0x77,0x00,0xde,0xf7,0x79,0x00,0xcb,0xf7,0x7a,0x00,0xb9,0xf7,0x7b,0x00,0xa6,0xf7,0x7c,0x00,  \
    0x93,0xf7,0x7e,0x00,0x80,0xf7,0x7f,0x00,0x6d,0xf7,0x80,0x00,0x5a,0xf7,0x82,0x00,0x47,0xf7,0x83,0x00,0x33,0xf7,0x84,0x00,0x20,0xf7,0x85,0x00,0x0c,0xf7,0x87,0x00,0xf9,0xf6,0x88,0x00,0xe5,0xf6,0x89,0x00,0xd1,0xf6,0x8b,0x00,0xbd,0xf6,0x8c,0x00,0xa9,0xf6,0x8d,0x00,0x95,0xf6,0x8e,0x00,0x80,0xf6,0x90,0x00,0x6c,0xf6,0x91,0x00,0x57,0xf6,0x92,0x00,0x43,0xf6,0x93,0x00,0x2e,0xf6,0x95,0x00,0x19,0xf6,0x96,0x00,0x04,0xf6,0x97,0x00,0xef,0xf5,0x98,0x00,0xda,0xf5,  \
    0x9a,0x00,0xc5,0xf5,0x9b,0x00,0xaf,0xf5,0x9c,0x00,0x9a,0xf5,0x9d,0x00,0x84,0xf5,0x9f,0x00,0x6e,0xf5,0xa0,0x00,0x58,0xf5,0xa1,0x00,0x42,0xf5,0xa2,0x00,0x2c,0xf5,0xa3,0x00,0x16,0xf5,0xa5,0x00,0x00,0xf5,0xa6,0x00,0xe9,0xf4,0xa7,0x00,0xd3,0xf4,0xa8,0x00,0xbc,0xf4,0xa9,0x00,0xa5,0xf4,0xaa,0x00,0x8e,0xf4,0xac,0x00,0x77,0xf4,0xad,0x00,0x60,0xf4,0xae,0x00,0x49,0xf4,0xaf,0x00,0x32,0xf4,0xb0,0x00,0x1a,0xf4,0xb1,0x00,0x02,0xf4,0xb2,0x00,0xeb,0xf3,0xb3,0x00,  \
    0xd3,0xf3,0xb4,0x00,0xbb,0xf3,0xb6,0x00,0xa3,0xf3,0xb7,0x00,0x8b,0xf3,0xb8,0x00,0x72,0xf3,0xb9,0x00,0x5a,0xf3,0xba,0x00,0x41,0xf3,0xbb,0x00,0x29,0xf3,0xbc,0x00,0x10,0xf3,0xbd,0x00,0xf7,0xf2,0xbe,0x00,0xde,0xf2,0xbf,0x00,0xc5,0xf2,0xc0,0x00,0xab,0xf2,0xc0,0x00,0x92,0xf2,0xc1,0x00,0x78,0xf2,0xc2,0x00,0x5e,0xf2,0xc3,0x00,0x45,0xf2,0xc4,0x00,0x2b,0xf2,0xc5,0x00,0x11,0xf2,0xc6,0x00,0xf6,0xf1,0xc7,0x00,0xdc,0xf1,0xc7,0x00,0xc2,0xf1,0xc8,0x00,0xa7,0xf1,  \
    0xc9,0x00,0x8c,0xf1,0xca,0x00,0x72,0xf1,0xcb,0x00,0x57,0xf1,0xcb,0x00,0x3c,0xf1,0xcc,0x00,0x20,0xf1,0xcd,0x00,0x05,0xf1,0xcd,0x00,0xea,0xf0,0xce,0x00,0xce,0xf0,0xcf,0x00,0xb2,0xf0,0xcf,0x00,0x96,0xf0,0xd0,0x00,0x7a,0xf0,0xd1,0x00,0x5e,0xf0,0xd1,0x00,0x42,0xf0,0xd2,0x00,0x26,0xf0,0xd2,0x00,0x09,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcd,0x00,0x05,0x10,0xcc,0x00,0xe9,0x0f,0xcc,0x00,0xcc,0x0f,0xcb,0x00,0xb0,0x0f,0xcb,0x00,0x93,0x0f,0xca,0x00,0x77,0x0f,0xca,0x00,0x5b,0x0f,0xc9,0x00,0x3f,0x0f,0xc8,0x00,0x23,0x0f,0xc8,0x00,0x08,0x0f,0xc7,0x00,0xec,0x0e,0xc6,0x00,0xd0,0x0e,0xc6,0x00,0xb5,0x0e,0xc5,0x00,0x9a,0x0e,0xc4,0x00,0x7f,0x0e,  \
    0xc4,0x00,0x64,0x0e,0xc3,0x00,0x49,0x0e,0xc2,0x00,0x2e,0x0e,0xc1,0x00,0x13,0x0e,0xc1,0x00,0xf9,0x0d,0xc0,0x00,0xde,0x0d,0xbf,0x00,0xc4,0x0d,0xbe,0x00,0xaa,0x0d,0xbd,0x00,0x90,0x0d,0xbd,0x00,0x76,0x0d,0xbc,0x00,0x5c,0x0d,0xbb,0x00,0x42,0x0d,0xba,0x00,0x29,0x0d,0xb9,0x00,0x0f,0x0d,0xb8,0x00,0xf6,0x0c,0xb7,0x00,0xdd,0x0c,0xb6,0x00,0xc4,0x0c,0xb6,0x00,0xab,0x0c,0xb5,0x00,0x92,0x0c,0xb4,0x00,0x79,0x0c,0xb3,0x00,0x60,0x0c,0xb2,0x00,0x48,0x0c,0xb1,0x00,  \
    0x2f,0x0c,0xb0,0x00,0x17,0x0c,0xaf,0x00,0xff,0x0b,0xae,0x00,0xe7,0x0b,0xad,0x00,0xcf,0x0b,0xac,0x00,0xb7,0x0b,0xab,0x00,0x9f,0x0b,0xaa,0x00,0x88,0x0b,0xa9,0x00,0x70,0x0b,0xa8,0x00,0x59,0x0b,0xa7,0x00,0x42,0x0b,0xa6,0x00,0x2b,0x0b,0xa4,0x00,0x14,0x0b,0xa3,0x00,0xfd,0x0a,0xa2,0x00,0xe6,0x0a,0xa1,0x00,0xcf,0x0a,0xa0,0x00,0xb9,0x0a,0x9f,0x00,0xa2,0x0a,0x9e,0x00,0x8c,0x0a,0x9d,0x00,0x76,0x0a,0x9c,0x00,0x5f,0x0a,0x9a,0x00,0x49,0x0a,0x99,0x00,0x33,0x0a,  \
    0x98,0x00,0x1e,0x0a,0x97,0x00,0x08,0x0a,0x96,0x00,0xf2,0x09,0x95,0x00,0xdd,0x09,0x94,0x00,0xc7,0x09,0x92,0x00,0xb2,0x09,0x91,0x00,0x9d,0x09,0x90,0x00,0x88,0x09,0x8f,0x00,0x73,0x09,0x8e,0x00,0x5e,0x09,0x8d,0x00,0x49,0x09,0x8b,0x00,0x34,0x09,0x8a,0x00,0x20,0x09,0x89,0x00,0x0b,0x09,0x88,0x00,0xf7,0x08,0x87,0x00,0xe3,0x08,0x86,0x00,0xcf,0x08,0x84,0x00,0xbb,0x08,0x83,0x00,0xa7,0x08,0x82,0x00,0x93,0x08,0x81,0x00,0x7f,0x08,0x80,0x00,0x6c,0x08,0x7e,0x00,  \
    0x58,0x08,0x7d,0x00,0x45,0x08,0x7c,0x00,0x31,0x08,0x7b,0x00,0x1e,0x08,0x7a,0x00,0x0b,0x08,0x79,0x00,0xf8,0x07,0x77,0x00,0xe5,0x07,0x76,0x00,0xd2,0x07,0x75,0x00,0xc0,0x07,0x74,0x00,0xad,0x07,0x73,0x00,0x9a,0x07,0x71,0x00,0x88,0x07,0x70,0x00,0x76,0x07,0x6f,0x00,0x63,0x07,0x6e,0x00,0x51,0x07,0x6d,0x00,0x3f,0x07,0x6b,0x00,0x2d,0x07,0x6a,0x00,0x1b,0x07,0x69,0x00,0x0a,0x07,0x68,0x00,0xf8,0x06,0x67,0x00,0xe7,0x06,0x66,0x00,0xd5,0x06,0x64,0x00,0xc4,0x06,  \
    0x63,0x00,0xb2,0x06,0x62,0x00,0xa1,0x06,0x61,0x00,0x90,0x06,0x60,0x00,0x7f,0x06,0x5f,0x00,0x6e,0x06,0x5e,0x00,0x5d,0x06,0x5c,0x00,0x4d,0x06,0x5b,0x00,0x3c,0x06,0x5a,0x00,0x2b,0x06,0x59,0x00,0x1b,0x06,0x58,0x00,0x0a,0x06,0x57,0x00,0xfa,0x05,0x56,0x00,0xea,0x05,0x55,0x00,0xda,0x05,0x53,0x00,0xc9,0x05,0x52,0x00,0xb9,0x05,0x51,0x00,0xaa,0x05,0x50,0x00,0x9a,0x05,0x4f,0x00,0x8a,0x05,0x4e,0x00,0x7a,0x05,0x4d,0x00,0x6b,0x05,0x4c,0x00,0x5b,0x05,0x4b,0x00,  \
    0x4c,0x05,0x4a,0x00,0x3c,0x05,0x49,0x00,0x2d,0x05,0x48,0x00,0x1e,0x05,0x47,0x00,0x0f,0x05,0x45,0x00,0x00,0x05,0x44,0x00,0xf1,0x04,0x43,0x00,0xe2,0x04,0x42,0x00,0xd3,0x04,0x41,0x00,0xc4,0x04,0x40,0x00,0xb6,0x04,0x3f,0x00,0xa7,0x04,0x3e,0x00,0x98,0x04,0x3d,0x00,0x8a,0x04,0x3c,0x00,0x7b,0x04,0x3b,0x00,0x6d,0x04,0x3a,0x00,0x5f,0x04,0x3a,0x00,0x51,0x04,0x39,0x00,0x43,0x04,0x38,0x00,0x34,0x04,0x37,0x00,0x26,0x04,0x36,0x00,0x18,0x04,0x35,0x00,0x0b,0x04,  \
    0x34,0x00,0xfd,0x03,0x33,0x00,0xef,0x03,0x32,0x00,0xe1,0x03,0x31,0x00,0xd4,0x03,0x30,0x00,0xc6,0x03,0x2f,0x00,0xb9,0x03,0x2f,0x00,0xab,0x03,0x2e,0x00,0x9e,0x03,0x2d,0x00,0x91,0x03,0x2c,0x00,0x83,0x03,0x2b,0x00,0x76,0x03,0x2a,0x00,0x69,0x03,0x2a,0x00,0x5c,0x03,0x29,0x00,0x4f,0x03,0x28,0x00,0x42,0x03,0x27,0x00,0x35,0x03,0x26,0x00,0x28,0x03,0x26,0x00,0x1c,0x03,0x25,0x00,0x0f,0x03,0x24,0x00,0x02,0x03,0x23,0x00,0xf5,0x02,0x23,0x00,0xe9,0x02,0x22,0x00,  \
    0xdc,0x02,0x21,0x00,0xd0,0x02,0x20,0x00,0xc3,0x02,0x20,0x00,0xb7,0x02,0x1f,0x00,0xab,0x02,0x1e,0x00,0x9e,0x02,0x1e,0x00,0x92,0x02,0x1d,0x00,0x86,0x02,0x1c,0x00,0x7a,0x02,0x1c,0x00,0x6e,0x02,0x1b,0x00,0x62,0x02,0x1a,0x00,0x56,0x02,0x1a,0x00,0x4a,0x02,0x19,0x00,0x3e,0x02,0x19,0x00,0x32,0x02,0x18,0x00,0x26,0x02,0x17,0x00,0x1a,0x02,0x17,0x00,0x0f,0x02,0x16,0x00,0x03,0x02,0x16,0x00,0xf7,0x01,0x15,0x00,0xec,0x01,0x15,0x00,0xe0,0x01,0x14,0x00,0xd4,0x01,  \
    0x14,0x00,0xc9,0x01,0x13,0x00,0xbd,0x01,0x13,0x00,0xb2,0x01,0x12,0x00,0xa7,0x01,0x12,0x00,0x9b,0x01,0x11,0x00,0x90,0x01,0x11,0x00,0x84,0x01,0x10,0x00,0x79,0x01,0x10,0x00,0x6e,0x01,0x0f,0x00,0x63,0x01,0x0f,0x00,0x57,0x01,0x0f,0x00,0x4c,0x01,0x0e,0x00,0x41,0x01,0x0e,0x00,0x36,0x01,0x0e,0x00,0x2b,0x01,0x0d,0x00,0x20,0x01,0x0d,0x00,0x15,0x01,0x0c,0x00,0x0a,0x01,0x0c,0x00,0xff,0x00,0x0c,0x00,0xf4,0x00,0x0c,0x00,0xe9,0x00,0x0b,0x00,0xde,0x00,0x0b,0x00,  \
    0xd3,0x00,0x0b,0x00,0xc8,0x00,0x0a,0x00,0xbd,0x00,0x0a,0x00,0xb2,0x00,0x0a,0x00,0xa7,0x00,0x0a,0x00,0x9c,0x00,0x0a,0x00,0x91,0x00,0x09,0x00,0x86,0x00,0x09,0x00,0x7c,0x00,0x09,0x00,0x71,0x00,0x09,0x00,0x66,0x00,0x09,0x00,0x5b,0x00,0x08,0x00,0x51,0x00,0x08,0x00,0x46,0x00,0x08,0x00,0x3b,0x00,0x08,0x00,0x30,0x00,0x08,0x00,0x26,0x00,0x08,0x00,0x1b,0x00,0x08,0x00,0x10,0x00,0x08,0x00,0x05,0x00,0x08,0x00,0xfb,0xff,0x08,0x00,0xf0,0xff,0x08,0x00,0xe5,0xff,  \
    0x07,0x00,0xdb,0xff,0x07,0x00,0xd0,0xff,0x07,0x00,0xc5,0xff,0x07,0x00,0xbb,0xff,0x07,0x00,0xb0,0xff,0x07,0x00,0xa5,0xff,0x08,0x00,0x9b,0xff,0x08,0x00,0x90,0xff,0x08,0x00,0x85,0xff,0x08,0x00,0x7b,0xff,0x08,0x00,0x70,0xff,0x08,0x00,0x65,0xff,0x08,0x00,0x5a,0xff,0x08,0x00,0x50,0xff,0x08,0x00,0x45,0xff,0x08,0x00,0x3a,0xff,0x08,0x00,0x30,0xff,0x09,0x00,0x25,0xff,0x09,0x00,0x1a,0xff,0x09,0x00,0x0f,0xff,0x09,0x00,0x05,0xff,0x09,0x00,0xfa,0xfe,0x0a,0x00,  \
    0xef,0xfe,0x0a,0x00,0xe4,0xfe,0x0a,0x00,0xd9,0xfe,0x0a,0x00,0xcf,0xfe,0x0a,0x00,0xc4,0xfe,0x0b,0x00,0xb9,0xfe,0x0b,0x00,0xae,0xfe,0x0b,0x00,0xa3,0xfe,0x0c,0x00,0x98,0xfe,0x0c,0x00,0x8d,0xfe,0x0c,0x00,0x82,0xfe,0x0d,0x00,0x77,0xfe,0x0d,0x00,0x6c,0xfe,0x0d,0x00,0x61,0xfe,0x0e,0x00,0x56,0xfe,0x0e,0x00,0x4b,0xfe,0x0e,0x00,0x40,0xfe,0x0f,0x00,0x35,0xfe,0x0f,0x00,0x2a,0xfe,0x10,0x00,0x1f,0xfe,0x10,0x00,0x13,0xfe,0x10,0x00,0x08,0xfe,0x11,0x00,0xfd,0xfd,  \
    0x11,0x00,0xf2,0xfd,0x12,0x00,0xe6,0xfd,0x12,0x00,0xdb,0xfd,0x13,0x00,0xd0,0xfd,0x13,0x00,0xc4,0xfd,0x14,0x00,0xb9,0xfd,0x14,0x00,0xad,0xfd,0x15,0x00,0xa2,0xfd,0x15,0x00,0x96,0xfd,0x16,0x00,0x8b,0xfd,0x16,0x00,0x7f,0xfd,0x17,0x00,0x73,0xfd,0x17,0x00,0x68,0xfd,0x18,0x00,0x5c,0xfd,0x19,0x00,0x50,0xfd,0x19,0x00,0x44,0xfd,0x1a,0x00,0x39,0xfd,0x1a,0x00,0x2d,0xfd,0x1b,0x00,0x21,0xfd,0x1c,0x00,0x15,0xfd,0x1c,0x00,0x09,0xfd,0x1d,0x00,0xfd,0xfc,0x1e,0x00,  \
    0xf1,0xfc,0x1e,0x00,0xe5,0xfc,0x1f,0x00,0xd8,0xfc,0x20,0x00,0xcc,0xfc,0x20,0x00,0xc0,0xfc,0x21,0x00,0xb4,0xfc,0x22,0x00,0xa7,0xfc,0x23,0x00,0x9b,0xfc,0x23,0x00,0x8e,0xfc,0x24,0x00,0x82,0xfc,0x25,0x00,0x75,0xfc,0x26,0x00,0x69,0xfc,0x26,0x00,0x5c,0xfc,0x27,0x00,0x4f,0xfc,0x28,0x00,0x43,0xfc,0x29,0x00,0x36,0xfc,0x2a,0x00,0x29,0xfc,0x2a,0x00,0x1c,0xfc,0x2b,0x00,0x0f,0xfc,0x2c,0x00,0x02,0xfc,0x2d,0x00,0xf5,0xfb,0x2e,0x00,0xe8,0xfb,0x2f,0x00,0xda,0xfb,  \
    0x2f,0x00,0xcd,0xfb,0x30,0x00,0xc0,0xfb,0x31,0x00,0xb2,0xfb,0x32,0x00,0xa5,0xfb,0x33,0x00,0x97,0xfb,0x34,0x00,0x8a,0xfb,0x35,0x00,0x7c,0xfb,0x36,0x00,0x6e,0xfb,0x37,0x00,0x60,0xfb,0x38,0x00,0x52,0xfb,0x39,0x00,0x44,0xfb,0x3a,0x00,0x36,0xfb,0x3b,0x00,0x28,0xfb,0x3b,0x00,0x1a,0xfb,0x3c,0x00,0x0c,0xfb,0x3d,0x00,0xfe,0xfa,0x3e,0x00,0xef,0xfa,0x3f,0x00,0xe1,0xfa,0x40,0x00,0xd2,0xfa,0x41,0x00,0xc4,0xfa,0x42,0x00,0xb5,0xfa,0x43,0x00,0xa7,0xfa,0x44,0x00,  \
    0x98,0xfa,0x46,0x00,0x89,0xfa,0x47,0x00,0x7a,0xfa,0x48,0x00,0x6b,0xfa,0x49,0x00,0x5c,0xfa,0x4a,0x00,0x4d,0xfa,0x4b,0x00,0x3d,0xfa,0x4c,0x00,0x2e,0xfa,0x4d,0x00,0x1f,0xfa,0x4e,0x00,0x0f,0xfa,0x4f,0x00,0x00,0xfa,0x50,0x00,0xf0,0xf9,0x51,0x00,0xe0,0xf9,0x52,0x00,0xd1,0xf9,0x53,0x00,0xc1,0xf9,0x55,0x00,0xb1,0xf9,0x56,0x00,0xa1,0xf9,0x57,0x00,0x90,0xf9,0x58,0x00,0x80,0xf9,0x59,0x00,0x70,0xf9,0x5a,0x00,0x60,0xf9,0x5b,0x00,0x4f,0xf9,0x5c,0x00,0x3e,0xf9,  \
    0x5e,0x00,0x2e,0xf9,0x5f,0x00,0x1d,0xf9,0x60,0x00,0x0c,0xf9,0x61,0x00,0xfb,0xf8,0x62,0x00,0xea,0xf8,0x63,0x00,0xd9,0xf8,0x65,0x00,0xc8,0xf8,0x66,0x00,0xb7,0xf8,0x67,0x00,0xa5,0xf8,0x68,0x00,0x94,0xf8,0x69,0x00,0x82,0xf8,0x6a,0x00,0x70,0xf8,0x6c,0x00,0x5f,0xf8,0x6d,0x00,0x4d,0xf8,0x6e,0x00,0x3b,0xf8,0x6f,0x00,0x29,0xf8,0x70,0x00,0x17,0xf8,0x71,0x00,0x04,0xf8,0x73,0x00,0xf2,0xf7,0x74,0x00,0xe0,0xf7,0x75,0x00,0xcd,0xf7,0x76,0x00,0xba,0xf7,0x77,0x00,  \
    0xa8,0xf7,0x79,0x00,0x95,0xf7,0x7a,0x00,0x82,0xf7,0x7b,0x00,0x6f,0xf7,0x7c,0x00,0x5c,0xf7,0x7d,0x00,0x48,0xf7,0x7f,0x00,0x35,0xf7,0x80,0x00,0x22,0xf7,0x81,0x00,0x0e,0xf7,0x82,0x00,0xfa,0xf6,0x83,0x00,0xe7,0xf6,0x84,0x00,0xd3,0xf6,0x86,0x00,0xbf,0xf6,0x87,0x00,0xab,0xf6,0x88,0x00,0x96,0xf6,0x89,0x00,0x82,0xf6,0x8a,0x00,0x6e,0xf6,0x8c,0x00,0x59,0xf6,0x8d,0x00,0x44,0xf6,0x8e,0x00,0x30,0xf6,0x8f,0x00,0x1b,0xf6,0x90,0x00,0x06,0xf6,0x91,0x00,0xf1,0xf5,  \
    0x92,0x00,0xdc,0xf5,0x94,0x00,0xc6,0xf5,0x95,0x00,0xb1,0xf5,0x96,0x00,0x9b,0xf5,0x97,0x00,0x86,0xf5,0x98,0x00,0x70,0xf5,0x99,0x00,0x5a,0xf5,0x9a,0x00,0x44,0xf5,0x9b,0x00,0x2e,0xf5,0x9d,0x00,0x18,0xf5,0x9e,0x00,0x01,0xf5,0x9f,0x00,0xeb,0xf4,0xa0,0x00,0xd4,0xf4,0xa1,0x00,0xbe,0xf4,0xa2,0x00,0xa7,0xf4,0xa3,0x00,0x90,0xf4,0xa4,0x00,0x79,0xf4,0xa5,0x00,0x62,0xf4,0xa6,0x00,0x4a,0xf4,0xa7,0x00,0x33,0xf4,0xa8,0x00,0x1c,0xf4,0xa9,0x00,0x04,0xf4,0xaa,0x00,  \
    0xec,0xf3,0xab,0x00,0xd4,0xf3,0xac,0x00,0xbc,0xf3,0xad,0x00,0xa4,0xf3,0xae,0x00,0x8c,0xf3,0xaf,0x00,0x74,0xf3,0xb0,0x00,0x5b,0xf3,0xb1,0x00,0x43,0xf3,0xb2,0x00,0x2a,0xf3,0xb3,0x00,0x11,0xf3,0xb4,0x00,0xf8,0xf2,0xb5,0x00,0xdf,0xf2,0xb6,0x00,0xc6,0xf2,0xb7,0x00,0xad,0xf2,0xb7,0x00,0x93,0xf2,0xb8,0x00,0x7a,0xf2,0xb9,0x00,0x60,0xf2,0xba,0x00,0x46,0xf2,0xbb,0x00,0x2c,0xf2,0xbc,0x00,0x12,0xf2,0xbc,0x00,0xf8,0xf1,0xbd,0x00,0xde,0xf1,0xbe,0x00,0xc3,0xf1,  \
    0xbf,0x00,0xa8,0xf1,0xbf,0x00,0x8e,0xf1,0xc0,0x00,0x73,0xf1,0xc1,0x00,0x58,0xf1,0xc1,0x00,0x3d,0xf1,0xc2,0x00,0x22,0xf1,0xc3,0x00,0x06,0xf1,0xc3,0x00,0xeb,0xf0,0xc4,0x00,0xcf,0xf0,0xc5,0x00,0xb3,0xf0,0xc5,0x00,0x98,0xf0,0xc6,0x00,0x7c,0xf0,0xc6,0x00,0x60,0xf0,0xc7,0x00,0x43,0xf0,0xc7,0x00,0x27,0xf0,0xc8,0x00,0x0a,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc2,0x00,0x04,0x10,0xc1,0x00,0xe8,0x0f,0xc1,0x00,0xcb,0x0f,0xc0,0x00,0xaf,0x0f,0xc0,0x00,0x92,0x0f,0xbf,0x00,0x76,0x0f,0xbf,0x00,0x5a,0x0f,0xbe,0x00,0x3e,0x0f,0xbe,0x00,0x22,0x0f,0xbd,0x00,0x06,0x0f,0xbd,0x00,0xeb,0x0e,0xbc,0x00,0xcf,0x0e,0xbb,0x00,0xb4,0x0e,0xbb,0x00,0x99,0x0e,  \
    0xba,0x00,0x7e,0x0e,0xb9,0x00,0x63,0x0e,0xb9,0x00,0x48,0x0e,0xb8,0x00,0x2d,0x0e,0xb7,0x00,0x12,0x0e,0xb7,0x00,0xf8,0x0d,0xb6,0x00,0xdd,0x0d,0xb5,0x00,0xc3,0x0d,0xb5,0x00,0xa9,0x0d,0xb4,0x00,0x8f,0x0d,0xb3,0x00,0x75,0x0d,0xb2,0x00,0x5b,0x0d,0xb1,0x00,0x41,0x0d,0xb1,0x00,0x28,0x0d,0xb0,0x00,0x0e,0x0d,0xaf,0x00,0xf5,0x0c,0xae,0x00,0xdc,0x0c,0xad,0x00,0xc2,0x0c,0xad,0x00,0xa9,0x0c,0xac,0x00,0x91,0x0c,0xab,0x00,0x78,0x0c,0xaa,0x00,0x5f,0x0c,0xa9,0x00,  \
    0x47,0x0c,0xa8,0x00,0x2e,0x0c,0xa7,0x00,0x16,0x0c,0xa6,0x00,0xfe,0x0b,0xa5,0x00,0xe6,0x0b,0xa5,0x00,0xce,0x0b,0xa4,0x00,0xb6,0x0b,0xa3,0x00,0x9e,0x0b,0xa2,0x00,0x87,0x0b,0xa1,0x00,0x6f,0x0b,0xa0,0x00,0x58,0x0b,0x9f,0x00,0x40,0x0b,0x9e,0x00,0x29,0x0b,0x9d,0x00,0x12,0x0b,0x9c,0x00,0xfb,0x0a,0x9b,0x00,0xe5,0x0a,0x9a,0x00,0xce,0x0a,0x99,0x00,0xb7,0x0a,0x98,0x00,0xa1,0x0a,0x97,0x00,0x8a,0x0a,0x96,0x00,0x74,0x0a,0x95,0x00,0x5e,0x0a,0x94,0x00,0x48,0x0a,  \
    0x93,0x00,0x32,0x0a,0x92,0x00,0x1c,0x0a,0x91,0x00,0x06,0x0a,0x90,0x00,0xf1,0x09,0x8e,0x00,0xdb,0x09,0x8d,0x00,0xc6,0x09,0x8c,0x00,0xb1,0x09,0x8b,0x00,0x9b,0x09,0x8a,0x00,0x86,0x09,0x89,0x00,0x71,0x09,0x88,0x00,0x5c,0x09,0x87,0x00,0x48,0x09,0x86,0x00,0x33,0x09,0x85,0x00,0x1f,0x09,0x84,0x00,0x0a,0x09,0x83,0x00,0xf6,0x08,0x82,0x00,0xe1,0x08,0x81,0x00,0xcd,0x08,0x7f,0x00,0xb9,0x08,0x7e,0x00,0xa5,0x08,0x7d,0x00,0x92,0x08,0x7c,0x00,0x7e,0x08,0x7b,0x00,  \
    0x6a,0x08,0x7a,0x00,0x57,0x08,0x79,0x00,0x43,0x08,0x78,0x00,0x30,0x08,0x77,0x00,0x1d,0x08,0x76,0x00,0x0a,0x08,0x75,0x00,0xf7,0x07,0x73,0x00,0xe4,0x07,0x72,0x00,0xd1,0x07,0x71,0x00,0xbe,0x07,0x70,0x00,0xab,0x07,0x6f,0x00,0x99,0x07,0x6e,0x00,0x87,0x07,0x6d,0x00,0x74,0x07,0x6c,0x00,0x62,0x07,0x6b,0x00,0x50,0x07,0x6a,0x00,0x3e,0x07,0x69,0x00,0x2c,0x07,0x67,0x00,0x1a,0x07,0x66,0x00,0x08,0x07,0x65,0x00,0xf7,0x06,0x64,0x00,0xe5,0x06,0x63,0x00,0xd4,0x06,  \
    0x62,0x00,0xc2,0x06,0x61,0x00,0xb1,0x06,0x60,0x00,0xa0,0x06,0x5f,0x00,0x8f,0x06,0x5e,0x00,0x7e,0x06,0x5d,0x00,0x6d,0x06,0x5c,0x00,0x5c,0x06,0x5b,0x00,0x4b,0x06,0x5a,0x00,0x3a,0x06,0x59,0x00,0x2a,0x06,0x58,0x00,0x19,0x06,0x57,0x00,0x09,0x06,0x56,0x00,0xf9,0x05,0x54,0x00,0xe8,0x05,0x53,0x00,0xd8,0x05,0x52,0x00,0xc8,0x05,0x51,0x00,0xb8,0x05,0x50,0x00,0xa8,0x05,0x4f,0x00,0x98,0x05,0x4e,0x00,0x88,0x05,0x4d,0x00,0x79,0x05,0x4c,0x00,0x69,0x05,0x4b,0x00,  \
    0x5a,0x05,0x4a,0x00,0x4a,0x05,0x4a,0x00,0x3b,0x05,0x49,0x00,0x2c,0x05,0x48,0x00,0x1c,0x05,0x47,0x00,0x0d,0x05,0x46,0x00,0xfe,0x04,0x45,0x00,0xef,0x04,0x44,0x00,0xe0,0x04,0x43,0x00,0xd2,0x04,0x42,0x00,0xc3,0x04,0x41,0x00,0xb4,0x04,0x40,0x00,0xa5,0x04,0x3f,0x00,0x97,0x04,0x3e,0x00,0x88,0x04,0x3d,0x00,0x7a,0x04,0x3c,0x00,0x6c,0x04,0x3c,0x00,0x5d,0x04,0x3b,0x00,0x4f,0x04,0x3a,0x00,0x41,0x04,0x39,0x00,0x33,0x04,0x38,0x00,0x25,0x04,0x37,0x00,0x17,0x04,  \
    0x36,0x00,0x09,0x04,0x36,0x00,0xfb,0x03,0x35,0x00,0xee,0x03,0x34,0x00,0xe0,0x03,0x33,0x00,0xd2,0x03,0x32,0x00,0xc5,0x03,0x31,0x00,0xb7,0x03,0x31,0x00,0xaa,0x03,0x30,0x00,0x9d,0x03,0x2f,0x00,0x8f,0x03,0x2e,0x00,0x82,0x03,0x2e,0x00,0x75,0x03,0x2d,0x00,0x68,0x03,0x2c,0x00,0x5b,0x03,0x2b,0x00,0x4e,0x03,0x2b,0x00,0x41,0x03,0x2a,0x00,0x34,0x03,0x29,0x00,0x27,0x03,0x28,0x00,0x1a,0x03,0x28,0x00,0x0e,0x03,0x27,0x00,0x01,0x03,0x26,0x00,0xf4,0x02,0x26,0x00,  \
    0xe8,0x02,0x25,0x00,0xdb,0x02,0x24,0x00,0xcf,0x02,0x24,0x00,0xc2,0x02,0x23,0x00,0xb6,0x02,0x22,0x00,0xaa,0x02,0x22,0x00,0x9d,0x02,0x21,0x00,0x91,0x02,0x20,0x00,0x85,0x02,0x20,0x00,0x79,0x02,0x1f,0x00,0x6d,0x02,0x1f,0x00,0x61,0x02,0x1e,0x00,0x55,0x02,0x1d,0x00,0x49,0x02,0x1d,0x00,0x3d,0x02,0x1c,0x00,0x31,0x02,0x1c,0x00,0x25,0x02,0x1b,0x00,0x19,0x02,0x1b,0x00,0x0e,0x02,0x1a,0x00,0x02,0x02,0x1a,0x00,0xf6,0x01,0x19,0x00,0xeb,0x01,0x19,0x00,0xdf,0x01,  \
    0x18,0x00,0xd4,0x01,0x18,0x00,0xc8,0x01,0x17,0x00,0xbd,0x01,0x17,0x00,0xb1,0x01,0x16,0x00,0xa6,0x01,0x16,0x00,0x9a,0x01,0x16,0x00,0x8f,0x01,0x15,0x00,0x84,0x01,0x15,0x00,0x78,0x01,0x14,0x00,0x6d,0x01,0x14,0x00,0x62,0x01,0x14,0x00,0x57,0x01,0x13,0x00,0x4b,0x01,0x13,0x00,0x40,0x01,0x13,0x00,0x35,0x01,0x12,0x00,0x2a,0x01,0x12,0x00,0x1f,0x01,0x12,0x00,0x14,0x01,0x11,0x00,0x09,0x01,0x11,0x00,0xfe,0x00,0x11,0x00,0xf3,0x00,0x10,0x00,0xe8,0x00,0x10,0x00,  \
    0xdd,0x00,0x10,0x00,0xd2,0x00,0x10,0x00,0xc7,0x00,0x0f,0x00,0xbc,0x00,0x0f,0x00,0xb1,0x00,0x0f,0x00,0xa7,0x00,0x0f,0x00,0x9c,0x00,0x0f,0x00,0x91,0x00,0x0e,0x00,0x86,0x00,0x0e,0x00,0x7b,0x00,0x0e,0x00,0x71,0x00,0x0e,0x00,0x66,0x00,0x0e,0x00,0x5b,0x00,0x0e,0x00,0x50,0x00,0x0d,0x00,0x46,0x00,0x0d,0x00,0x3b,0x00,0x0d,0x00,0x30,0x00,0x0d,0x00,0x25,0x00,0x0d,0x00,0x1b,0x00,0x0d,0x00,0x10,0x00,0x0d,0x00,0x05,0x00,0x0d,0x00,0xfb,0xff,0x0d,0x00,0xf0,0xff,  \
    0x0d,0x00,0xe5,0xff,0x0d,0x00,0xdb,0xff,0x0d,0x00,0xd0,0xff,0x0d,0x00,0xc5,0xff,0x0d,0x00,0xbb,0xff,0x0d,0x00,0xb0,0xff,0x0d,0x00,0xa5,0xff,0x0d,0x00,0x9b,0xff,0x0d,0x00,0x90,0xff,0x0d,0x00,0x85,0xff,0x0d,0x00,0x7b,0xff,0x0d,0x00,0x70,0xff,0x0d,0x00,0x65,0xff,0x0d,0x00,0x5b,0xff,0x0d,0x00,0x50,0xff,0x0d,0x00,0x45,0xff,0x0d,0x00,0x3b,0xff,0x0e,0x00,0x30,0xff,0x0e,0x00,0x25,0xff,0x0e,0x00,0x1a,0xff,0x0e,0x00,0x10,0xff,0x0e,0x00,0x05,0xff,0x0e,0x00,  \
    0xfa,0xfe,0x0f,0x00,0xef,0xfe,0x0f,0x00,0xe5,0xfe,0x0f,0x00,0xda,0xfe,0x0f,0x00,0xcf,0xfe,0x0f,0x00,0xc4,0xfe,0x10,0x00,0xb9,0xfe,0x10,0x00,0xae,0xfe,0x10,0x00,0xa4,0xfe,0x10,0x00,0x99,0xfe,0x11,0x00,0x8e,0xfe,0x11,0x00,0x83,0xfe,0x11,0x00,0x78,0xfe,0x12,0x00,0x6d,0xfe,0x12,0x00,0x62,0xfe,0x12,0x00,0x57,0xfe,0x13,0x00,0x4c,0xfe,0x13,0x00,0x41,0xfe,0x13,0x00,0x36,0xfe,0x14,0x00,0x2a,0xfe,0x14,0x00,0x1f,0xfe,0x14,0x00,0x14,0xfe,0x15,0x00,0x09,0xfe,  \
    0x15,0x00,0xfe,0xfd,0x16,0x00,0xf2,0xfd,0x16,0x00,0xe7,0xfd,0x17,0x00,0xdc,0xfd,0x17,0x00,0xd0,0xfd,0x17,0x00,0xc5,0xfd,0x18,0x00,0xba,0xfd,0x18,0x00,0xae,0xfd,0x19,0x00,0xa3,0xfd,0x19,0x00,0x97,0xfd,0x1a,0x00,0x8c,0xfd,0x1a,0x00,0x80,0xfd,0x1b,0x00,0x74,0xfd,0x1b,0x00,0x69,0xfd,0x1c,0x00,0x5d,0xfd,0x1c,0x00,0x51,0xfd,0x1d,0x00,0x46,0xfd,0x1e,0x00,0x3a,0xfd,0x1e,0x00,0x2e,0xfd,0x1f,0x00,0x22,0xfd,0x1f,0x00,0x16,0xfd,0x20,0x00,0x0a,0xfd,0x20,0x00,  \
    0xfe,0xfc,0x21,0x00,0xf2,0xfc,0x22,0x00,0xe6,0xfc,0x22,0x00,0xda,0xfc,0x23,0x00,0xcd,0xfc,0x24,0x00,0xc1,0xfc,0x24,0x00,0xb5,0xfc,0x25,0x00,0xa9,0xfc,0x26,0x00,0x9c,0xfc,0x26,0x00,0x90,0xfc,0x27,0x00,0x83,0xfc,0x28,0x00,0x77,0xfc,0x28,0x00,0x6a,0xfc,0x29,0x00,0x5d,0xfc,0x2a,0x00,0x51,0xfc,0x2b,0x00,0x44,0xfc,0x2b,0x00,0x37,0xfc,0x2c,0x00,0x2a,0xfc,0x2d,0x00,0x1d,0xfc,0x2e,0x00,0x10,0xfc,0x2e,0x00,0x03,0xfc,0x2f,0x00,0xf6,0xfb,0x30,0x00,0xe9,0xfb,  \
    0x31,0x00,0xdc,0xfb,0x32,0x00,0xce,0xfb,0x32,0x00,0xc1,0xfb,0x33,0x00,0xb4,0xfb,0x34,0x00,0xa6,0xfb,0x35,0x00,0x99,0xfb,0x36,0x00,0x8b,0xfb,0x36,0x00,0x7d,0xfb,0x37,0x00,0x70,0xfb,0x38,0x00,0x62,0xfb,0x39,0x00,0x54,0xfb,0x3a,0x00,0x46,0xfb,0x3b,0x00,0x38,0xfb,0x3c,0x00,0x2a,0xfb,0x3d,0x00,0x1c,0xfb,0x3d,0x00,0x0e,0xfb,0x3e,0x00,0xff,0xfa,0x3f,0x00,0xf1,0xfa,0x40,0x00,0xe3,0xfa,0x41,0x00,0xd4,0xfa,0x42,0x00,0xc5,0xfa,0x43,0x00,0xb7,0xfa,0x44,0x00,  \
    0xa8,0xfa,0x45,0x00,0x99,0xfa,0x46,0x00,0x8a,0xfa,0x47,0x00,0x7c,0xfa,0x48,0x00,0x6d,0xfa,0x49,0x00,0x5d,0xfa,0x4a,0x00,0x4e,0xfa,0x4b,0x00,0x3f,0xfa,0x4c,0x00,0x30,0xfa,0x4d,0x00,0x20,0xfa,0x4e,0x00,0x11,0xfa,0x4f,0x00,0x01,0xfa,0x50,0x00,0xf2,0xf9,0x51,0x00,0xe2,0xf9,0x52,0x00,0xd2,0xf9,0x53,0x00,0xc2,0xf9,0x54,0x00,0xb2,0xf9,0x55,0x00,0xa2,0xf9,0x56,0x00,0x92,0xf9,0x57,0x00,0x82,0xf9,0x58,0x00,0x72,0xf9,0x59,0x00,0x61,0xf9,0x5a,0x00,0x51,0xf9,  \
    0x5b,0x00,0x40,0xf9,0x5c,0x00,0x2f,0xf9,0x5d,0x00,0x1f,0xf9,0x5e,0x00,0x0e,0xf9,0x5f,0x00,0xfd,0xf8,0x60,0x00,0xec,0xf8,0x61,0x00,0xdb,0xf8,0x62,0x00,0xc9,0xf8,0x63,0x00,0xb8,0xf8,0x64,0x00,0xa7,0xf8,0x66,0x00,0x95,0xf8,0x67,0x00,0x84,0xf8,0x68,0x00,0x72,0xf8,0x69,0x00,0x60,0xf8,0x6a,0x00,0x4e,0xf8,0x6b,0x00,0x3c,0xf8,0x6c,0x00,0x2a,0xf8,0x6d,0x00,0x18,0xf8,0x6e,0x00,0x06,0xf8,0x6f,0x00,0xf4,0xf7,0x70,0x00,0xe1,0xf7,0x71,0x00,0xcf,0xf7,0x73,0x00,  \
    0xbc,0xf7,0x74,0x00,0xa9,0xf7,0x75,0x00,0x96,0xf7,0x76,0x00,0x83,0xf7,0x77,0x00,0x70,0xf7,0x78,0x00,0x5d,0xf7,0x79,0x00,0x4a,0xf7,0x7a,0x00,0x37,0xf7,0x7b,0x00,0x23,0xf7,0x7c,0x00,0x10,0xf7,0x7d,0x00,0xfc,0xf6,0x7f,0x00,0xe8,0xf6,0x80,0x00,0xd4,0xf6,0x81,0x00,0xc0,0xf6,0x82,0x00,0xac,0xf6,0x83,0x00,0x98,0xf6,0x84,0x00,0x84,0xf6,0x85,0x00,0x6f,0xf6,0x86,0x00,0x5b,0xf6,0x87,0x00,0x46,0xf6,0x88,0x00,0x31,0xf6,0x89,0x00,0x1c,0xf6,0x8a,0x00,0x07,0xf6,  \
    0x8b,0x00,0xf2,0xf5,0x8d,0x00,0xdd,0xf5,0x8e,0x00,0xc8,0xf5,0x8f,0x00,0xb2,0xf5,0x90,0x00,0x9d,0xf5,0x91,0x00,0x87,0xf5,0x92,0x00,0x71,0xf5,0x93,0x00,0x5b,0xf5,0x94,0x00,0x45,0xf5,0x95,0x00,0x2f,0xf5,0x96,0x00,0x19,0xf5,0x97,0x00,0x03,0xf5,0x98,0x00,0xec,0xf4,0x99,0x00,0xd6,0xf4,0x9a,0x00,0xbf,0xf4,0x9b,0x00,0xa8,0xf4,0x9c,0x00,0x91,0xf4,0x9d,0x00,0x7a,0xf4,0x9e,0x00,0x63,0xf4,0x9f,0x00,0x4c,0xf4,0xa0,0x00,0x35,0xf4,0xa1,0x00,0x1d,0xf4,0xa2,0x00,  \
    0x05,0xf4,0xa2,0x00,0xee,0xf3,0xa3,0x00,0xd6,0xf3,0xa4,0x00,0xbe,0xf3,0xa5,0x00,0xa6,0xf3,0xa6,0x00,0x8d,0xf3,0xa7,0x00,0x75,0xf3,0xa8,0x00,0x5d,0xf3,0xa9,0x00,0x44,0xf3,0xaa,0x00,0x2b,0xf3,0xaa,0x00,0x13,0xf3,0xab,0x00,0xfa,0xf2,0xac,0x00,0xe0,0xf2,0xad,0x00,0xc7,0xf2,0xae,0x00,0xae,0xf2,0xae,0x00,0x94,0xf2,0xaf,0x00,0x7b,0xf2,0xb0,0x00,0x61,0xf2,0xb1,0x00,0x47,0xf2,0xb2,0x00,0x2d,0xf2,0xb2,0x00,0x13,0xf2,0xb3,0x00,0xf9,0xf1,0xb4,0x00,0xdf,0xf1,  \
    0xb4,0x00,0xc4,0xf1,0xb5,0x00,0xaa,0xf1,0xb6,0x00,0x8f,0xf1,0xb6,0x00,0x74,0xf1,0xb7,0x00,0x59,0xf1,0xb8,0x00,0x3e,0xf1,0xb8,0x00,0x23,0xf1,0xb9,0x00,0x08,0xf1,0xb9,0x00,0xec,0xf0,0xba,0x00,0xd0,0xf0,0xbb,0x00,0xb5,0xf0,0xbb,0x00,0x99,0xf0,0xbc,0x00,0x7d,0xf0,0xbc,0x00,0x61,0xf0,0xbd,0x00,0x44,0xf0,0xbd,0x00,0x28,0xf0,0xbe,0x00,0x0c,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xb7,0x00,0x03,0x10,0xb7,0x00,0xe7,0x0f,0xb6,0x00,0xca,0x0f,0xb6,0x00,0xae,0x0f,0xb5,0x00,0x91,0x0f,0xb5,0x00,0x75,0x0f,0xb4,0x00,0x59,0x0f,0xb4,0x00,0x3d,0x0f,0xb3,0x00,0x21,0x0f,0xb3,0x00,0x05,0x0f,0xb2,0x00,0xea,0x0e,0xb2,0x00,0xce,0x0e,0xb1,0x00,0xb3,0x0e,  \
    0xb1,0x00,0x98,0x0e,0xb0,0x00,0x7d,0x0e,0xaf,0x00,0x61,0x0e,0xaf,0x00,0x47,0x0e,0xae,0x00,0x2c,0x0e,0xae,0x00,0x11,0x0e,0xad,0x00,0xf7,0x0d,0xac,0x00,0xdc,0x0d,0xac,0x00,0xc2,0x0d,0xab,0x00,0xa8,0x0d,0xaa,0x00,0x8e,0x0d,0xaa,0x00,0x74,0x0d,0xa9,0x00,0x5a,0x0d,0xa8,0x00,0x40,0x0d,0xa7,0x00,0x27,0x0d,0xa7,0x00,0x0d,0x0d,0xa6,0x00,0xf4,0x0c,0xa5,0x00,0xda,0x0c,0xa4,0x00,0xc1,0x0c,0xa4,0x00,0xa8,0x0c,0xa3,0x00,0x8f,0x0c,0xa2,0x00,0x77,0x0c,0xa1,0x00,  \
    0x5e,0x0c,0xa0,0x00,0x46,0x0c,0xa0,0x00,0x2d,0x0c,0x9f,0x00,0x15,0x0c,0x9e,0x00,0xfd,0x0b,0x9d,0x00,0xe5,0x0b,0x9c,0x00,0xcd,0x0b,0x9b,0x00,0xb5,0x0b,0x9b,0x00,0x9d,0x0b,0x9a,0x00,0x85,0x0b,0x99,0x00,0x6e,0x0b,0x98,0x00,0x56,0x0b,0x97,0x00,0x3f,0x0b,0x96,0x00,0x28,0x0b,0x95,0x00,0x11,0x0b,0x94,0x00,0xfa,0x0a,0x94,0x00,0xe3,0x0a,0x93,0x00,0xcd,0x0a,0x92,0x00,0xb6,0x0a,0x91,0x00,0x9f,0x0a,0x90,0x00,0x89,0x0a,0x8f,0x00,0x73,0x0a,0x8e,0x00,0x5d,0x0a,  \
    0x8d,0x00,0x47,0x0a,0x8c,0x00,0x31,0x0a,0x8b,0x00,0x1b,0x0a,0x8a,0x00,0x05,0x0a,0x89,0x00,0xf0,0x09,0x88,0x00,0xda,0x09,0x87,0x00,0xc5,0x09,0x86,0x00,0xaf,0x09,0x85,0x00,0x9a,0x09,0x84,0x00,0x85,0x09,0x83,0x00,0x70,0x09,0x82,0x00,0x5b,0x09,0x81,0x00,0x46,0x09,0x81,0x00,0x32,0x09,0x80,0x00,0x1d,0x09,0x7f,0x00,0x09,0x09,0x7e,0x00,0xf4,0x08,0x7d,0x00,0xe0,0x08,0x7c,0x00,0xcc,0x08,0x7b,0x00,0xb8,0x08,0x7a,0x00,0xa4,0x08,0x79,0x00,0x90,0x08,0x78,0x00,  \
    0x7d,0x08,0x77,0x00,0x69,0x08,0x76,0x00,0x55,0x08,0x75,0x00,0x42,0x08,0x74,0x00,0x2f,0x08,0x73,0x00,0x1b,0x08,0x72,0x00,0x08,0x08,0x71,0x00,0xf5,0x07,0x70,0x00,0xe2,0x07,0x6f,0x00,0xd0,0x07,0x6e,0x00,0xbd,0x07,0x6d,0x00,0xaa,0x07,0x6c,0x00,0x98,0x07,0x6b,0x00,0x85,0x07,0x6a,0x00,0x73,0x07,0x69,0x00,0x61,0x07,0x68,0x00,0x4f,0x07,0x67,0x00,0x3c,0x07,0x66,0x00,0x2b,0x07,0x65,0x00,0x19,0x07,0x64,0x00,0x07,0x07,0x63,0x00,0xf5,0x06,0x62,0x00,0xe4,0x06,  \
    0x61,0x00,0xd2,0x06,0x60,0x00,0xc1,0x06,0x5f,0x00,0xb0,0x06,0x5e,0x00,0x9e,0x06,0x5d,0x00,0x8d,0x06,0x5c,0x00,0x7c,0x06,0x5b,0x00,0x6b,0x06,0x5a,0x00,0x5a,0x06,0x59,0x00,0x4a,0x06,0x58,0x00,0x39,0x06,0x57,0x00,0x28,0x06,0x56,0x00,0x18,0x06,0x55,0x00,0x07,0x06,0x54,0x00,0xf7,0x05,0x53,0x00,0xe7,0x05,0x52,0x00,0xd7,0x05,0x52,0x00,0xc7,0x05,0x51,0x00,0xb7,0x05,0x50,0x00,0xa7,0x05,0x4f,0x00,0x97,0x05,0x4e,0x00,0x87,0x05,0x4d,0x00,0x77,0x05,0x4c,0x00,  \
    0x68,0x05,0x4b,0x00,0x58,0x05,0x4a,0x00,0x49,0x05,0x49,0x00,0x3a,0x05,0x49,0x00,0x2a,0x05,0x48,0x00,0x1b,0x05,0x47,0x00,0x0c,0x05,0x46,0x00,0xfd,0x04,0x45,0x00,0xee,0x04,0x44,0x00,0xdf,0x04,0x43,0x00,0xd0,0x04,0x42,0x00,0xc1,0x04,0x42,0x00,0xb3,0x04,0x41,0x00,0xa4,0x04,0x40,0x00,0x96,0x04,0x3f,0x00,0x87,0x04,0x3e,0x00,0x79,0x04,0x3d,0x00,0x6a,0x04,0x3d,0x00,0x5c,0x04,0x3c,0x00,0x4e,0x04,0x3b,0x00,0x40,0x04,0x3a,0x00,0x32,0x04,0x39,0x00,0x24,0x04,  \
    0x39,0x00,0x16,0x04,0x38,0x00,0x08,0x04,0x37,0x00,0xfa,0x03,0x36,0x00,0xed,0x03,0x36,0x00,0xdf,0x03,0x35,0x00,0xd1,0x03,0x34,0x00,0xc4,0x03,0x33,0x00,0xb6,0x03,0x33,0x00,0xa9,0x03,0x32,0x00,0x9b,0x03,0x31,0x00,0x8e,0x03,0x31,0x00,0x81,0x03,0x30,0x00,0x74,0x03,0x2f,0x00,0x67,0x03,0x2e,0x00,0x5a,0x03,0x2e,0x00,0x4d,0x03,0x2d,0x00,0x40,0x03,0x2c,0x00,0x33,0x03,0x2c,0x00,0x26,0x03,0x2b,0x00,0x19,0x03,0x2b,0x00,0x0d,0x03,0x2a,0x00,0x00,0x03,0x29,0x00,  \
    0xf3,0x02,0x29,0x00,0xe7,0x02,0x28,0x00,0xda,0x02,0x27,0x00,0xce,0x02,0x27,0x00,0xc1,0x02,0x26,0x00,0xb5,0x02,0x26,0x00,0xa9,0x02,0x25,0x00,0x9c,0x02,0x24,0x00,0x90,0x02,0x24,0x00,0x84,0x02,0x23,0x00,0x78,0x02,0x23,0x00,0x6c,0x02,0x22,0x00,0x60,0x02,0x22,0x00,0x54,0x02,0x21,0x00,0x48,0x02,0x21,0x00,0x3c,0x02,0x20,0x00,0x30,0x02,0x20,0x00,0x24,0x02,0x1f,0x00,0x19,0x02,0x1f,0x00,0x0d,0x02,0x1e,0x00,0x01,0x02,0x1e,0x00,0xf6,0x01,0x1d,0x00,0xea,0x01,  \
    0x1d,0x00,0xde,0x01,0x1c,0x00,0xd3,0x01,0x1c,0x00,0xc7,0x01,0x1c,0x00,0xbc,0x01,0x1b,0x00,0xb0,0x01,0x1b,0x00,0xa5,0x01,0x1a,0x00,0x9a,0x01,0x1a,0x00,0x8e,0x01,0x1a,0x00,0x83,0x01,0x19,0x00,0x78,0x01,0x19,0x00,0x6c,0x01,0x19,0x00,0x61,0x01,0x18,0x00,0x56,0x01,0x18,0x00,0x4b,0x01,0x18,0x00,0x40,0x01,0x17,0x00,0x35,0x01,0x17,0x00,0x2a,0x01,0x17,0x00,0x1e,0x01,0x16,0x00,0x13,0x01,0x16,0x00,0x08,0x01,0x16,0x00,0xfd,0x00,0x16,0x00,0xf2,0x00,0x15,0x00,  \
    0xe8,0x00,0x15,0x00,0xdd,0x00,0x15,0x00,0xd2,0x00,0x15,0x00,0xc7,0x00,0x14,0x00,0xbc,0x00,0x14,0x00,0xb1,0x00,0x14,0x00,0xa6,0x00,0x14,0x00,0x9b,0x00,0x14,0x00,0x91,0x00,0x13,0x00,0x86,0x00,0x13,0x00,0x7b,0x00,0x13,0x00,0x70,0x00,0x13,0x00,0x66,0x00,0x13,0x00,0x5b,0x00,0x13,0x00,0x50,0x00,0x13,0x00,0x45,0x00,0x12,0x00,0x3b,0x00,0x12,0x00,0x30,0x00,0x12,0x00,0x25,0x00,0x12,0x00,0x1b,0x00,0x12,0x00,0x10,0x00,0x12,0x00,0x05,0x00,0x12,0x00,0xfb,0xff,  \
    0x12,0x00,0xf0,0xff,0x12,0x00,0xe5,0xff,0x12,0x00,0xdb,0xff,0x12,0x00,0xd0,0xff,0x12,0x00,0xc5,0xff,0x12,0x00,0xbb,0xff,0x12,0x00,0xb0,0xff,0x12,0x00,0xa5,0xff,0x12,0x00,0x9b,0xff,0x12,0x00,0x90,0xff,0x12,0x00,0x85,0xff,0x12,0x00,0x7b,0xff,0x12,0x00,0x70,0xff,0x12,0x00,0x65,0xff,0x12,0x00,0x5b,0xff,0x12,0x00,0x50,0xff,0x12,0x00,0x45,0xff,0x13,0x00,0x3b,0xff,0x13,0x00,0x30,0xff,0x13,0x00,0x25,0xff,0x13,0x00,0x1b,0xff,0x13,0x00,0x10,0xff,0x13,0x00,  \
    0x05,0xff,0x13,0x00,0xfa,0xfe,0x14,0x00,0xf0,0xfe,0x14,0x00,0xe5,0xfe,0x14,0x00,0xda,0xfe,0x14,0x00,0xcf,0xfe,0x14,0x00,0xc5,0xfe,0x15,0x00,0xba,0xfe,0x15,0x00,0xaf,0xfe,0x15,0x00,0xa4,0xfe,0x15,0x00,0x99,0xfe,0x16,0x00,0x8e,0xfe,0x16,0x00,0x83,0xfe,0x16,0x00,0x78,0xfe,0x16,0x00,0x6d,0xfe,0x17,0x00,0x62,0xfe,0x17,0x00,0x57,0xfe,0x17,0x00,0x4c,0xfe,0x18,0x00,0x41,0xfe,0x18,0x00,0x36,0xfe,0x18,0x00,0x2b,0xfe,0x19,0x00,0x20,0xfe,0x19,0x00,0x15,0xfe,  \
    0x19,0x00,0x0a,0xfe,0x1a,0x00,0xfe,0xfd,0x1a,0x00,0xf3,0xfd,0x1a,0x00,0xe8,0xfd,0x1b,0x00,0xdd,0xfd,0x1b,0x00,0xd1,0xfd,0x1c,0x00,0xc6,0xfd,0x1c,0x00,0xba,0xfd,0x1d,0x00,0xaf,0xfd,0x1d,0x00,0xa4,0xfd,0x1d,0x00,0x98,0xfd,0x1e,0x00,0x8d,0xfd,0x1e,0x00,0x81,0xfd,0x1f,0x00,0x75,0xfd,0x1f,0x00,0x6a,0xfd,0x20,0x00,0x5e,0xfd,0x20,0x00,0x52,0xfd,0x21,0x00,0x46,0xfd,0x21,0x00,0x3b,0xfd,0x22,0x00,0x2f,0xfd,0x22,0x00,0x23,0xfd,0x23,0x00,0x17,0xfd,0x23,0x00,  \
    0x0b,0xfd,0x24,0x00,0xff,0xfc,0x25,0x00,0xf3,0xfc,0x25,0x00,0xe7,0xfc,0x26,0x00,0xdb,0xfc,0x26,0x00,0xcf,0xfc,0x27,0x00,0xc2,0xfc,0x27,0x00,0xb6,0xfc,0x28,0x00,0xaa,0xfc,0x29,0x00,0x9d,0xfc,0x29,0x00,0x91,0xfc,0x2a,0x00,0x84,0xfc,0x2b,0x00,0x78,0xfc,0x2b,0x00,0x6b,0xfc,0x2c,0x00,0x5f,0xfc,0x2d,0x00,0x52,0xfc,0x2d,0x00,0x45,0xfc,0x2e,0x00,0x38,0xfc,0x2f,0x00,0x2b,0xfc,0x2f,0x00,0x1e,0xfc,0x30,0x00,0x11,0xfc,0x31,0x00,0x04,0xfc,0x31,0x00,0xf7,0xfb,  \
    0x32,0x00,0xea,0xfb,0x33,0x00,0xdd,0xfb,0x34,0x00,0xd0,0xfb,0x34,0x00,0xc2,0xfb,0x35,0x00,0xb5,0xfb,0x36,0x00,0xa7,0xfb,0x37,0x00,0x9a,0xfb,0x37,0x00,0x8c,0xfb,0x38,0x00,0x7f,0xfb,0x39,0x00,0x71,0xfb,0x3a,0x00,0x63,0xfb,0x3a,0x00,0x55,0xfb,0x3b,0x00,0x47,0xfb,0x3c,0x00,0x39,0xfb,0x3d,0x00,0x2b,0xfb,0x3e,0x00,0x1d,0xfb,0x3e,0x00,0x0f,0xfb,0x3f,0x00,0x01,0xfb,0x40,0x00,0xf2,0xfa,0x41,0x00,0xe4,0xfa,0x42,0x00,0xd5,0xfa,0x43,0x00,0xc7,0xfa,0x43,0x00,  \
    0xb8,0xfa,0x44,0x00,0xaa,0xfa,0x45,0x00,0x9b,0xfa,0x46,0x00,0x8c,0xfa,0x47,0x00,0x7d,0xfa,0x48,0x00,0x6e,0xfa,0x49,0x00,0x5f,0xfa,0x4a,0x00,0x50,0xfa,0x4a,0x00,0x40,0xfa,0x4b,0x00,0x31,0xfa,0x4c,0x00,0x22,0xfa,0x4d,0x00,0x12,0xfa,0x4e,0x00,0x03,0xfa,0x4f,0x00,0xf3,0xf9,0x50,0x00,0xe3,0xf9,0x51,0x00,0xd4,0xf9,0x52,0x00,0xc4,0xf9,0x53,0x00,0xb4,0xf9,0x54,0x00,0xa4,0xf9,0x55,0x00,0x94,0xf9,0x56,0x00,0x83,0xf9,0x56,0x00,0x73,0xf9,0x57,0x00,0x63,0xf9,  \
    0x58,0x00,0x52,0xf9,0x59,0x00,0x42,0xf9,0x5a,0x00,0x31,0xf9,0x5b,0x00,0x20,0xf9,0x5c,0x00,0x0f,0xf9,0x5d,0x00,0xfe,0xf8,0x5e,0x00,0xed,0xf8,0x5f,0x00,0xdc,0xf8,0x60,0x00,0xcb,0xf8,0x61,0x00,0xba,0xf8,0x62,0x00,0xa8,0xf8,0x63,0x00,0x97,0xf8,0x64,0x00,0x85,0xf8,0x65,0x00,0x74,0xf8,0x66,0x00,0x62,0xf8,0x67,0x00,0x50,0xf8,0x68,0x00,0x3e,0xf8,0x69,0x00,0x2c,0xf8,0x6a,0x00,0x1a,0xf8,0x6b,0x00,0x07,0xf8,0x6c,0x00,0xf5,0xf7,0x6d,0x00,0xe3,0xf7,0x6e,0x00,  \
    0xd0,0xf7,0x6f,0x00,0xbd,0xf7,0x70,0x00,0xab,0xf7,0x71,0x00,0x98,0xf7,0x72,0x00,0x85,0xf7,0x73,0x00,0x72,0xf7,0x74,0x00,0x5f,0xf7,0x75,0x00,0x4b,0xf7,0x76,0x00,0x38,0xf7,0x77,0x00,0x25,0xf7,0x78,0x00,0x11,0xf7,0x79,0x00,0xfd,0xf6,0x7a,0x00,0xe9,0xf6,0x7b,0x00,0xd6,0xf6,0x7c,0x00,0xc2,0xf6,0x7d,0x00,0xad,0xf6,0x7e,0x00,0x99,0xf6,0x7f,0x00,0x85,0xf6,0x80,0x00,0x71,0xf6,0x81,0x00,0x5c,0xf6,0x82,0x00,0x47,0xf6,0x83,0x00,0x33,0xf6,0x84,0x00,0x1e,0xf6,  \
    0x85,0x00,0x09,0xf6,0x86,0x00,0xf4,0xf5,0x87,0x00,0xde,0xf5,0x88,0x00,0xc9,0xf5,0x89,0x00,0xb4,0xf5,0x89,0x00,0x9e,0xf5,0x8a,0x00,0x88,0xf5,0x8b,0x00,0x73,0xf5,0x8c,0x00,0x5d,0xf5,0x8d,0x00,0x47,0xf5,0x8e,0x00,0x31,0xf5,0x8f,0x00,0x1a,0xf5,0x90,0x00,0x04,0xf5,0x91,0x00,0xee,0xf4,0x92,0x00,0xd7,0xf4,0x93,0x00,0xc0,0xf4,0x94,0x00,0xaa,0xf4,0x95,0x00,0x93,0xf4,0x95,0x00,0x7c,0xf4,0x96,0x00,0x64,0xf4,0x97,0x00,0x4d,0xf4,0x98,0x00,0x36,0xf4,0x99,0x00,  \
    0x1e,0xf4,0x9a,0x00,0x07,0xf4,0x9b,0x00,0xef,0xf3,0x9b,0x00,0xd7,0xf3,0x9c,0x00,0xbf,0xf3,0x9d,0x00,0xa7,0xf3,0x9e,0x00,0x8f,0xf3,0x9f,0x00,0x76,0xf3,0xa0,0x00,0x5e,0xf3,0xa0,0x00,0x45,0xf3,0xa1,0x00,0x2d,0xf3,0xa2,0x00,0x14,0xf3,0xa3,0x00,0xfb,0xf2,0xa3,0x00,0xe2,0xf2,0xa4,0x00,0xc8,0xf2,0xa5,0x00,0xaf,0xf2,0xa6,0x00,0x96,0xf2,0xa6,0x00,0x7c,0xf2,0xa7,0x00,0x62,0xf2,0xa8,0x00,0x49,0xf2,0xa8,0x00,0x2f,0xf2,0xa9,0x00,0x14,0xf2,0xaa,0x00,0xfa,0xf1,  \
    0xaa,0x00,0xe0,0xf1,0xab,0x00,0xc5,0xf1,0xac,0x00,0xab,0xf1,0xac,0x00,0x90,0xf1,0xad,0x00,0x75,0xf1,0xad,0x00,0x5a,0xf1,0xae,0x00,0x3f,0xf1,0xae,0x00,0x24,0xf1,0xaf,0x00,0x09,0xf1,0xb0,0x00,0xed,0xf0,0xb0,0x00,0xd2,0xf0,0xb1,0x00,0xb6,0xf0,0xb1,0x00,0x9a,0xf0,0xb2,0x00,0x7e,0xf0,0xb2,0x00,0x62,0xf0,0xb2,0x00,0x46,0xf0,0xb3,0x00,0x29,0xf0,0xb3,0x00,0x0d,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xac,0x00,0x02,0x10,0xac,0x00,0xe6,0x0f,0xab,0x00,0xc9,0x0f,0xab,0x00,0xad,0x0f,0xab,0x00,0x90,0x0f,0xaa,0x00,0x74,0x0f,0xaa,0x00,0x58,0x0f,0xa9,0x00,0x3c,0x0f,0xa9,0x00,0x20,0x0f,0xa8,0x00,0x04,0x0f,0xa8,0x00,0xe9,0x0e,0xa7,0x00,0xcd,0x0e,  \
    0xa7,0x00,0xb2,0x0e,0xa6,0x00,0x97,0x0e,0xa6,0x00,0x7c,0x0e,0xa5,0x00,0x61,0x0e,0xa5,0x00,0x46,0x0e,0xa4,0x00,0x2b,0x0e,0xa4,0x00,0x10,0x0e,0xa3,0x00,0xf6,0x0d,0xa3,0x00,0xdb,0x0d,0xa2,0x00,0xc1,0x0d,0xa1,0x00,0xa7,0x0d,0xa1,0x00,0x8d,0x0d,0xa0,0x00,0x73,0x0d,0x9f,0x00,0x59,0x0d,0x9f,0x00,0x3f,0x0d,0x9e,0x00,0x26,0x0d,0x9e,0x00,0x0c,0x0d,0x9d,0x00,0xf3,0x0c,0x9c,0x00,0xd9,0x0c,0x9b,0x00,0xc0,0x0c,0x9b,0x00,0xa7,0x0c,0x9a,0x00,0x8e,0x0c,0x99,0x00,  \
    0x76,0x0c,0x99,0x00,0x5d,0x0c,0x98,0x00,0x44,0x0c,0x97,0x00,0x2c,0x0c,0x96,0x00,0x14,0x0c,0x96,0x00,0xfc,0x0b,0x95,0x00,0xe3,0x0b,0x94,0x00,0xcb,0x0b,0x93,0x00,0xb4,0x0b,0x93,0x00,0x9c,0x0b,0x92,0x00,0x84,0x0b,0x91,0x00,0x6d,0x0b,0x90,0x00,0x55,0x0b,0x90,0x00,0x3e,0x0b,0x8f,0x00,0x27,0x0b,0x8e,0x00,0x10,0x0b,0x8d,0x00,0xf9,0x0a,0x8c,0x00,0xe2,0x0a,0x8b,0x00,0xcb,0x0a,0x8b,0x00,0xb5,0x0a,0x8a,0x00,0x9e,0x0a,0x89,0x00,0x88,0x0a,0x88,0x00,0x72,0x0a,  \
    0x87,0x00,0x5c,0x0a,0x86,0x00,0x45,0x0a,0x86,0x00,0x30,0x0a,0x85,0x00,0x1a,0x0a,0x84,0x00,0x04,0x0a,0x83,0x00,0xee,0x09,0x82,0x00,0xd9,0x09,0x81,0x00,0xc3,0x09,0x80,0x00,0xae,0x09,0x80,0x00,0x99,0x09,0x7f,0x00,0x84,0x09,0x7e,0x00,0x6f,0x09,0x7d,0x00,0x5a,0x09,0x7c,0x00,0x45,0x09,0x7b,0x00,0x31,0x09,0x7a,0x00,0x1c,0x09,0x79,0x00,0x08,0x09,0x78,0x00,0xf3,0x08,0x78,0x00,0xdf,0x08,0x77,0x00,0xcb,0x08,0x76,0x00,0xb7,0x08,0x75,0x00,0xa3,0x08,0x74,0x00,  \
    0x8f,0x08,0x73,0x00,0x7b,0x08,0x72,0x00,0x68,0x08,0x71,0x00,0x54,0x08,0x70,0x00,0x41,0x08,0x6f,0x00,0x2d,0x08,0x6f,0x00,0x1a,0x08,0x6e,0x00,0x07,0x08,0x6d,0x00,0xf4,0x07,0x6c,0x00,0xe1,0x07,0x6b,0x00,0xce,0x07,0x6a,0x00,0xbc,0x07,0x69,0x00,0xa9,0x07,0x68,0x00,0x96,0x07,0x67,0x00,0x84,0x07,0x67,0x00,0x72,0x07,0x66,0x00,0x5f,0x07,0x65,0x00,0x4d,0x07,0x64,0x00,0x3b,0x07,0x63,0x00,0x29,0x07,0x62,0x00,0x17,0x07,0x61,0x00,0x06,0x07,0x60,0x00,0xf4,0x06,  \
    0x5f,0x00,0xe2,0x06,0x5e,0x00,0xd1,0x06,0x5e,0x00,0xc0,0x06,0x5d,0x00,0xae,0x06,0x5c,0x00,0x9d,0x06,0x5b,0x00,0x8c,0x06,0x5a,0x00,0x7b,0x06,0x59,0x00,0x6a,0x06,0x58,0x00,0x59,0x06,0x58,0x00,0x48,0x06,0x57,0x00,0x38,0x06,0x56,0x00,0x27,0x06,0x55,0x00,0x17,0x06,0x54,0x00,0x06,0x06,0x53,0x00,0xf6,0x05,0x52,0x00,0xe6,0x05,0x52,0x00,0xd5,0x05,0x51,0x00,0xc5,0x05,0x50,0x00,0xb5,0x05,0x4f,0x00,0xa5,0x05,0x4e,0x00,0x96,0x05,0x4d,0x00,0x86,0x05,0x4d,0x00,  \
    0x76,0x05,0x4c,0x00,0x67,0x05,0x4b,0x00,0x57,0x05,0x4a,0x00,0x48,0x05,0x49,0x00,0x38,0x05,0x49,0x00,0x29,0x05,0x48,0x00,0x1a,0x05,0x47,0x00,0x0b,0x05,0x46,0x00,0xfc,0x04,0x45,0x00,0xed,0x04,0x45,0x00,0xde,0x04,0x44,0x00,0xcf,0x04,0x43,0x00,0xc0,0x04,0x42,0x00,0xb2,0x04,0x42,0x00,0xa3,0x04,0x41,0x00,0x94,0x04,0x40,0x00,0x86,0x04,0x3f,0x00,0x78,0x04,0x3f,0x00,0x69,0x04,0x3e,0x00,0x5b,0x04,0x3d,0x00,0x4d,0x04,0x3c,0x00,0x3f,0x04,0x3c,0x00,0x31,0x04,  \
    0x3b,0x00,0x23,0x04,0x3a,0x00,0x15,0x04,0x3a,0x00,0x07,0x04,0x39,0x00,0xf9,0x03,0x38,0x00,0xeb,0x03,0x37,0x00,0xde,0x03,0x37,0x00,0xd0,0x03,0x36,0x00,0xc3,0x03,0x35,0x00,0xb5,0x03,0x35,0x00,0xa8,0x03,0x34,0x00,0x9a,0x03,0x34,0x00,0x8d,0x03,0x33,0x00,0x80,0x03,0x32,0x00,0x73,0x03,0x32,0x00,0x66,0x03,0x31,0x00,0x59,0x03,0x30,0x00,0x4c,0x03,0x30,0x00,0x3f,0x03,0x2f,0x00,0x32,0x03,0x2f,0x00,0x25,0x03,0x2e,0x00,0x18,0x03,0x2d,0x00,0x0c,0x03,0x2d,0x00,  \
    0xff,0x02,0x2c,0x00,0xf2,0x02,0x2c,0x00,0xe6,0x02,0x2b,0x00,0xd9,0x02,0x2b,0x00,0xcd,0x02,0x2a,0x00,0xc0,0x02,0x2a,0x00,0xb4,0x02,0x29,0x00,0xa8,0x02,0x28,0x00,0x9c,0x02,0x28,0x00,0x8f,0x02,0x27,0x00,0x83,0x02,0x27,0x00,0x77,0x02,0x26,0x00,0x6b,0x02,0x26,0x00,0x5f,0x02,0x26,0x00,0x53,0x02,0x25,0x00,0x47,0x02,0x25,0x00,0x3b,0x02,0x24,0x00,0x2f,0x02,0x24,0x00,0x24,0x02,0x23,0x00,0x18,0x02,0x23,0x00,0x0c,0x02,0x22,0x00,0x00,0x02,0x22,0x00,0xf5,0x01,  \
    0x22,0x00,0xe9,0x01,0x21,0x00,0xde,0x01,0x21,0x00,0xd2,0x01,0x20,0x00,0xc7,0x01,0x20,0x00,0xbb,0x01,0x20,0x00,0xb0,0x01,0x1f,0x00,0xa4,0x01,0x1f,0x00,0x99,0x01,0x1f,0x00,0x8e,0x01,0x1e,0x00,0x82,0x01,0x1e,0x00,0x77,0x01,0x1e,0x00,0x6c,0x01,0x1d,0x00,0x61,0x01,0x1d,0x00,0x55,0x01,0x1d,0x00,0x4a,0x01,0x1c,0x00,0x3f,0x01,0x1c,0x00,0x34,0x01,0x1c,0x00,0x29,0x01,0x1b,0x00,0x1e,0x01,0x1b,0x00,0x13,0x01,0x1b,0x00,0x08,0x01,0x1b,0x00,0xfd,0x00,0x1a,0x00,  \
    0xf2,0x00,0x1a,0x00,0xe7,0x00,0x1a,0x00,0xdc,0x00,0x1a,0x00,0xd1,0x00,0x1a,0x00,0xc6,0x00,0x19,0x00,0xbc,0x00,0x19,0x00,0xb1,0x00,0x19,0x00,0xa6,0x00,0x19,0x00,0x9b,0x00,0x19,0x00,0x90,0x00,0x19,0x00,0x86,0x00,0x18,0x00,0x7b,0x00,0x18,0x00,0x70,0x00,0x18,0x00,0x65,0x00,0x18,0x00,0x5b,0x00,0x18,0x00,0x50,0x00,0x18,0x00,0x45,0x00,0x18,0x00,0x3a,0x00,0x18,0x00,0x30,0x00,0x17,0x00,0x25,0x00,0x17,0x00,0x1a,0x00,0x17,0x00,0x10,0x00,0x17,0x00,0x05,0x00,  \
    0x17,0x00,0xfa,0xff,0x17,0x00,0xf0,0xff,0x17,0x00,0xe5,0xff,0x17,0x00,0xdb,0xff,0x17,0x00,0xd0,0xff,0x17,0x00,0xc5,0xff,0x17,0x00,0xbb,0xff,0x17,0x00,0xb0,0xff,0x17,0x00,0xa5,0xff,0x17,0x00,0x9b,0xff,0x17,0x00,0x90,0xff,0x17,0x00,0x86,0xff,0x17,0x00,0x7b,0xff,0x17,0x00,0x70,0xff,0x17,0x00,0x66,0xff,0x18,0x00,0x5b,0xff,0x18,0x00,0x50,0xff,0x18,0x00,0x46,0xff,0x18,0x00,0x3b,0xff,0x18,0x00,0x30,0xff,0x18,0x00,0x26,0xff,0x18,0x00,0x1b,0xff,0x18,0x00,  \
    0x10,0xff,0x18,0x00,0x06,0xff,0x19,0x00,0xfb,0xfe,0x19,0x00,0xf0,0xfe,0x19,0x00,0xe5,0xfe,0x19,0x00,0xdb,0xfe,0x19,0x00,0xd0,0xfe,0x19,0x00,0xc5,0xfe,0x1a,0x00,0xba,0xfe,0x1a,0x00,0xaf,0xfe,0x1a,0x00,0xa4,0xfe,0x1a,0x00,0x9a,0xfe,0x1b,0x00,0x8f,0xfe,0x1b,0x00,0x84,0xfe,0x1b,0x00,0x79,0xfe,0x1b,0x00,0x6e,0xfe,0x1c,0x00,0x63,0xfe,0x1c,0x00,0x58,0xfe,0x1c,0x00,0x4d,0xfe,0x1c,0x00,0x42,0xfe,0x1d,0x00,0x37,0xfe,0x1d,0x00,0x2c,0xfe,0x1d,0x00,0x21,0xfe,  \
    0x1e,0x00,0x15,0xfe,0x1e,0x00,0x0a,0xfe,0x1e,0x00,0xff,0xfd,0x1f,0x00,0xf4,0xfd,0x1f,0x00,0xe9,0xfd,0x1f,0x00,0xdd,0xfd,0x20,0x00,0xd2,0xfd,0x20,0x00,0xc7,0xfd,0x20,0x00,0xbb,0xfd,0x21,0x00,0xb0,0xfd,0x21,0x00,0xa4,0xfd,0x22,0x00,0x99,0xfd,0x22,0x00,0x8d,0xfd,0x22,0x00,0x82,0xfd,0x23,0x00,0x76,0xfd,0x23,0x00,0x6b,0xfd,0x24,0x00,0x5f,0xfd,0x24,0x00,0x53,0xfd,0x25,0x00,0x47,0xfd,0x25,0x00,0x3c,0xfd,0x26,0x00,0x30,0xfd,0x26,0x00,0x24,0xfd,0x27,0x00,  \
    0x18,0xfd,0x27,0x00,0x0c,0xfd,0x28,0x00,0x00,0xfd,0x28,0x00,0xf4,0xfc,0x29,0x00,0xe8,0xfc,0x29,0x00,0xdc,0xfc,0x2a,0x00,0xd0,0xfc,0x2a,0x00,0xc3,0xfc,0x2b,0x00,0xb7,0xfc,0x2b,0x00,0xab,0xfc,0x2c,0x00,0x9e,0xfc,0x2c,0x00,0x92,0xfc,0x2d,0x00,0x85,0xfc,0x2e,0x00,0x79,0xfc,0x2e,0x00,0x6c,0xfc,0x2f,0x00,0x60,0xfc,0x2f,0x00,0x53,0xfc,0x30,0x00,0x46,0xfc,0x31,0x00,0x39,0xfc,0x31,0x00,0x2c,0xfc,0x32,0x00,0x20,0xfc,0x32,0x00,0x13,0xfc,0x33,0x00,0x06,0xfc,  \
    0x34,0x00,0xf8,0xfb,0x34,0x00,0xeb,0xfb,0x35,0x00,0xde,0xfb,0x36,0x00,0xd1,0xfb,0x36,0x00,0xc3,0xfb,0x37,0x00,0xb6,0xfb,0x38,0x00,0xa9,0xfb,0x38,0x00,0x9b,0xfb,0x39,0x00,0x8d,0xfb,0x3a,0x00,0x80,0xfb,0x3a,0x00,0x72,0xfb,0x3b,0x00,0x64,0xfb,0x3c,0x00,0x56,0xfb,0x3d,0x00,0x49,0xfb,0x3d,0x00,0x3b,0xfb,0x3e,0x00,0x2d,0xfb,0x3f,0x00,0x1e,0xfb,0x3f,0x00,0x10,0xfb,0x40,0x00,0x02,0xfb,0x41,0x00,0xf4,0xfa,0x42,0x00,0xe5,0xfa,0x42,0x00,0xd7,0xfa,0x43,0x00,  \
    0xc8,0xfa,0x44,0x00,0xba,0xfa,0x45,0x00,0xab,0xfa,0x46,0x00,0x9c,0xfa,0x46,0x00,0x8d,0xfa,0x47,0x00,0x7e,0xfa,0x48,0x00,0x6f,0xfa,0x49,0x00,0x60,0xfa,0x4a,0x00,0x51,0xfa,0x4a,0x00,0x42,0xfa,0x4b,0x00,0x32,0xfa,0x4c,0x00,0x23,0xfa,0x4d,0x00,0x14,0xfa,0x4e,0x00,0x04,0xfa,0x4e,0x00,0xf4,0xf9,0x4f,0x00,0xe5,0xf9,0x50,0x00,0xd5,0xf9,0x51,0x00,0xc5,0xf9,0x52,0x00,0xb5,0xf9,0x53,0x00,0xa5,0xf9,0x54,0x00,0x95,0xf9,0x54,0x00,0x85,0xf9,0x55,0x00,0x74,0xf9,  \
    0x56,0x00,0x64,0xf9,0x57,0x00,0x53,0xf9,0x58,0x00,0x43,0xf9,0x59,0x00,0x32,0xf9,0x5a,0x00,0x21,0xf9,0x5a,0x00,0x11,0xf9,0x5b,0x00,0x00,0xf9,0x5c,0x00,0xef,0xf8,0x5d,0x00,0xde,0xf8,0x5e,0x00,0xcc,0xf8,0x5f,0x00,0xbb,0xf8,0x60,0x00,0xaa,0xf8,0x61,0x00,0x98,0xf8,0x61,0x00,0x87,0xf8,0x62,0x00,0x75,0xf8,0x63,0x00,0x63,0xf8,0x64,0x00,0x51,0xf8,0x65,0x00,0x3f,0xf8,0x66,0x00,0x2d,0xf8,0x67,0x00,0x1b,0xf8,0x68,0x00,0x09,0xf8,0x69,0x00,0xf6,0xf7,0x6a,0x00,  \
    0xe4,0xf7,0x6a,0x00,0xd1,0xf7,0x6b,0x00,0xbf,0xf7,0x6c,0x00,0xac,0xf7,0x6d,0x00,0x99,0xf7,0x6e,0x00,0x86,0xf7,0x6f,0x00,0x73,0xf7,0x70,0x00,0x60,0xf7,0x71,0x00,0x4d,0xf7,0x72,0x00,0x39,0xf7,0x73,0x00,0x26,0xf7,0x73,0x00,0x12,0xf7,0x74,0x00,0xff,0xf6,0x75,0x00,0xeb,0xf6,0x76,0x00,0xd7,0xf6,0x77,0x00,0xc3,0xf6,0x78,0x00,0xaf,0xf6,0x79,0x00,0x9b,0xf6,0x7a,0x00,0x86,0xf6,0x7b,0x00,0x72,0xf6,0x7b,0x00,0x5d,0xf6,0x7c,0x00,0x49,0xf6,0x7d,0x00,0x34,0xf6,  \
    0x7e,0x00,0x1f,0xf6,0x7f,0x00,0x0a,0xf6,0x80,0x00,0xf5,0xf5,0x81,0x00,0xe0,0xf5,0x82,0x00,0xca,0xf5,0x82,0x00,0xb5,0xf5,0x83,0x00,0x9f,0xf5,0x84,0x00,0x8a,0xf5,0x85,0x00,0x74,0xf5,0x86,0x00,0x5e,0xf5,0x87,0x00,0x48,0xf5,0x88,0x00,0x32,0xf5,0x88,0x00,0x1c,0xf5,0x89,0x00,0x05,0xf5,0x8a,0x00,0xef,0xf4,0x8b,0x00,0xd8,0xf4,0x8c,0x00,0xc2,0xf4,0x8d,0x00,0xab,0xf4,0x8d,0x00,0x94,0xf4,0x8e,0x00,0x7d,0xf4,0x8f,0x00,0x66,0xf4,0x90,0x00,0x4e,0xf4,0x91,0x00,  \
    0x37,0xf4,0x91,0x00,0x1f,0xf4,0x92,0x00,0x08,0xf4,0x93,0x00,0xf0,0xf3,0x94,0x00,0xd8,0xf3,0x94,0x00,0xc0,0xf3,0x95,0x00,0xa8,0xf3,0x96,0x00,0x90,0xf3,0x97,0x00,0x78,0xf3,0x97,0x00,0x5f,0xf3,0x98,0x00,0x46,0xf3,0x99,0x00,0x2e,0xf3,0x99,0x00,0x15,0xf3,0x9a,0x00,0xfc,0xf2,0x9b,0x00,0xe3,0xf2,0x9b,0x00,0xca,0xf2,0x9c,0x00,0xb0,0xf2,0x9d,0x00,0x97,0xf2,0x9d,0x00,0x7d,0xf2,0x9e,0x00,0x63,0xf2,0x9f,0x00,0x4a,0xf2,0x9f,0x00,0x30,0xf2,0xa0,0x00,0x16,0xf2,  \
    0xa0,0x00,0xfb,0xf1,0xa1,0x00,0xe1,0xf1,0xa2,0x00,0xc7,0xf1,0xa2,0x00,0xac,0xf1,0xa3,0x00,0x91,0xf1,0xa3,0x00,0x76,0xf1,0xa4,0x00,0x5b,0xf1,0xa4,0x00,0x40,0xf1,0xa5,0x00,0x25,0xf1,0xa5,0x00,0x0a,0xf1,0xa6,0x00,0xee,0xf0,0xa6,0x00,0xd3,0xf0,0xa7,0x00,0xb7,0xf0,0xa7,0x00,0x9b,0xf0,0xa8,0x00,0x7f,0xf0,0xa8,0x00,0x63,0xf0,0xa8,0x00,0x47,0xf0,0xa9,0x00,0x2a,0xf0,0xa9,0x00,0x0e,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa2,0x00,0x02,0x10,0xa1,0x00,0xe5,0x0f,0xa1,0x00,0xc8,0x0f,0xa1,0x00,0xac,0x0f,0xa0,0x00,0x8f,0x0f,0xa0,0x00,0x73,0x0f,0x9f,0x00,0x57,0x0f,0x9f,0x00,0x3b,0x0f,0x9f,0x00,0x1f,0x0f,0x9e,0x00,0x04,0x0f,0x9e,0x00,0xe8,0x0e,  \
    0x9d,0x00,0xcc,0x0e,0x9d,0x00,0xb1,0x0e,0x9c,0x00,0x96,0x0e,0x9c,0x00,0x7b,0x0e,0x9b,0x00,0x60,0x0e,0x9b,0x00,0x45,0x0e,0x9b,0x00,0x2a,0x0e,0x9a,0x00,0x0f,0x0e,0x99,0x00,0xf5,0x0d,0x99,0x00,0xda,0x0d,0x98,0x00,0xc0,0x0d,0x98,0x00,0xa6,0x0d,0x97,0x00,0x8c,0x0d,0x97,0x00,0x72,0x0d,0x96,0x00,0x58,0x0d,0x96,0x00,0x3e,0x0d,0x95,0x00,0x25,0x0d,0x94,0x00,0x0b,0x0d,0x94,0x00,0xf2,0x0c,0x93,0x00,0xd9,0x0c,0x93,0x00,0xbf,0x0c,0x92,0x00,0xa6,0x0c,0x91,0x00,  \
    0x8e,0x0c,0x91,0x00,0x75,0x0c,0x90,0x00,0x5c,0x0c,0x90,0x00,0x44,0x0c,0x8f,0x00,0x2b,0x0c,0x8e,0x00,0x13,0x0c,0x8e,0x00,0xfb,0x0b,0x8d,0x00,0xe2,0x0b,0x8c,0x00,0xcb,0x0b,0x8b,0x00,0xb3,0x0b,0x8b,0x00,0x9b,0x0b,0x8a,0x00,0x83,0x0b,0x89,0x00,0x6c,0x0b,0x89,0x00,0x54,0x0b,0x88,0x00,0x3d,0x0b,0x87,0x00,0x26,0x0b,0x87,0x00,0x0f,0x0b,0x86,0x00,0xf8,0x0a,0x85,0x00,0xe1,0x0a,0x84,0x00,0xca,0x0a,0x84,0x00,0xb4,0x0a,0x83,0x00,0x9d,0x0a,0x82,0x00,0x87,0x0a,  \
    0x81,0x00,0x71,0x0a,0x81,0x00,0x5a,0x0a,0x80,0x00,0x44,0x0a,0x7f,0x00,0x2e,0x0a,0x7e,0x00,0x19,0x0a,0x7e,0x00,0x03,0x0a,0x7d,0x00,0xed,0x09,0x7c,0x00,0xd8,0x09,0x7b,0x00,0xc2,0x09,0x7a,0x00,0xad,0x09,0x7a,0x00,0x98,0x09,0x79,0x00,0x83,0x09,0x78,0x00,0x6e,0x09,0x77,0x00,0x59,0x09,0x77,0x00,0x44,0x09,0x76,0x00,0x2f,0x09,0x75,0x00,0x1b,0x09,0x74,0x00,0x06,0x09,0x73,0x00,0xf2,0x08,0x73,0x00,0xde,0x08,0x72,0x00,0xca,0x08,0x71,0x00,0xb6,0x08,0x70,0x00,  \
    0xa2,0x08,0x6f,0x00,0x8e,0x08,0x6f,0x00,0x7a,0x08,0x6e,0x00,0x67,0x08,0x6d,0x00,0x53,0x08,0x6c,0x00,0x40,0x08,0x6b,0x00,0x2c,0x08,0x6b,0x00,0x19,0x08,0x6a,0x00,0x06,0x08,0x69,0x00,0xf3,0x07,0x68,0x00,0xe0,0x07,0x67,0x00,0xcd,0x07,0x67,0x00,0xba,0x07,0x66,0x00,0xa8,0x07,0x65,0x00,0x95,0x07,0x64,0x00,0x83,0x07,0x63,0x00,0x71,0x07,0x63,0x00,0x5e,0x07,0x62,0x00,0x4c,0x07,0x61,0x00,0x3a,0x07,0x60,0x00,0x28,0x07,0x5f,0x00,0x16,0x07,0x5f,0x00,0x05,0x07,  \
    0x5e,0x00,0xf3,0x06,0x5d,0x00,0xe1,0x06,0x5c,0x00,0xd0,0x06,0x5b,0x00,0xbe,0x06,0x5b,0x00,0xad,0x06,0x5a,0x00,0x9c,0x06,0x59,0x00,0x8b,0x06,0x58,0x00,0x7a,0x06,0x58,0x00,0x69,0x06,0x57,0x00,0x58,0x06,0x56,0x00,0x47,0x06,0x55,0x00,0x37,0x06,0x54,0x00,0x26,0x06,0x54,0x00,0x16,0x06,0x53,0x00,0x05,0x06,0x52,0x00,0xf5,0x05,0x51,0x00,0xe5,0x05,0x51,0x00,0xd4,0x05,0x50,0x00,0xc4,0x05,0x4f,0x00,0xb4,0x05,0x4e,0x00,0xa4,0x05,0x4e,0x00,0x95,0x05,0x4d,0x00,  \
    0x85,0x05,0x4c,0x00,0x75,0x05,0x4b,0x00,0x66,0x05,0x4b,0x00,0x56,0x05,0x4a,0x00,0x47,0x05,0x49,0x00,0x37,0x05,0x49,0x00,0x28,0x05,0x48,0x00,0x19,0x05,0x47,0x00,0x0a,0x05,0x46,0x00,0xfb,0x04,0x46,0x00,0xec,0x04,0x45,0x00,0xdd,0x04,0x44,0x00,0xce,0x04,0x44,0x00,0xbf,0x04,0x43,0x00,0xb0,0x04,0x42,0x00,0xa2,0x04,0x42,0x00,0x93,0x04,0x41,0x00,0x85,0x04,0x40,0x00,0x77,0x04,0x40,0x00,0x68,0x04,0x3f,0x00,0x5a,0x04,0x3e,0x00,0x4c,0x04,0x3e,0x00,0x3e,0x04,  \
    0x3d,0x00,0x30,0x04,0x3c,0x00,0x22,0x04,0x3c,0x00,0x14,0x04,0x3b,0x00,0x06,0x04,0x3b,0x00,0xf8,0x03,0x3a,0x00,0xea,0x03,0x39,0x00,0xdd,0x03,0x39,0x00,0xcf,0x03,0x38,0x00,0xc2,0x03,0x38,0x00,0xb4,0x03,0x37,0x00,0xa7,0x03,0x36,0x00,0x99,0x03,0x36,0x00,0x8c,0x03,0x35,0x00,0x7f,0x03,0x35,0x00,0x72,0x03,0x34,0x00,0x65,0x03,0x34,0x00,0x58,0x03,0x33,0x00,0x4b,0x03,0x32,0x00,0x3e,0x03,0x32,0x00,0x31,0x03,0x31,0x00,0x24,0x03,0x31,0x00,0x17,0x03,0x30,0x00,  \
    0x0b,0x03,0x30,0x00,0xfe,0x02,0x2f,0x00,0xf1,0x02,0x2f,0x00,0xe5,0x02,0x2e,0x00,0xd8,0x02,0x2e,0x00,0xcc,0x02,0x2d,0x00,0xc0,0x02,0x2d,0x00,0xb3,0x02,0x2c,0x00,0xa7,0x02,0x2c,0x00,0x9b,0x02,0x2b,0x00,0x8f,0x02,0x2b,0x00,0x82,0x02,0x2b,0x00,0x76,0x02,0x2a,0x00,0x6a,0x02,0x2a,0x00,0x5e,0x02,0x29,0x00,0x52,0x02,0x29,0x00,0x46,0x02,0x28,0x00,0x3b,0x02,0x28,0x00,0x2f,0x02,0x28,0x00,0x23,0x02,0x27,0x00,0x17,0x02,0x27,0x00,0x0b,0x02,0x26,0x00,0x00,0x02,  \
    0x26,0x00,0xf4,0x01,0x26,0x00,0xe9,0x01,0x25,0x00,0xdd,0x01,0x25,0x00,0xd1,0x01,0x25,0x00,0xc6,0x01,0x24,0x00,0xbb,0x01,0x24,0x00,0xaf,0x01,0x24,0x00,0xa4,0x01,0x23,0x00,0x98,0x01,0x23,0x00,0x8d,0x01,0x23,0x00,0x82,0x01,0x22,0x00,0x77,0x01,0x22,0x00,0x6b,0x01,0x22,0x00,0x60,0x01,0x22,0x00,0x55,0x01,0x21,0x00,0x4a,0x01,0x21,0x00,0x3f,0x01,0x21,0x00,0x34,0x01,0x21,0x00,0x29,0x01,0x20,0x00,0x1e,0x01,0x20,0x00,0x13,0x01,0x20,0x00,0x08,0x01,0x20,0x00,  \
    0xfd,0x00,0x1f,0x00,0xf2,0x00,0x1f,0x00,0xe7,0x00,0x1f,0x00,0xdc,0x00,0x1f,0x00,0xd1,0x00,0x1f,0x00,0xc6,0x00,0x1e,0x00,0xbb,0x00,0x1e,0x00,0xb0,0x00,0x1e,0x00,0xa6,0x00,0x1e,0x00,0x9b,0x00,0x1e,0x00,0x90,0x00,0x1e,0x00,0x85,0x00,0x1e,0x00,0x7a,0x00,0x1d,0x00,0x70,0x00,0x1d,0x00,0x65,0x00,0x1d,0x00,0x5a,0x00,0x1d,0x00,0x50,0x00,0x1d,0x00,0x45,0x00,0x1d,0x00,0x3a,0x00,0x1d,0x00,0x30,0x00,0x1d,0x00,0x25,0x00,0x1d,0x00,0x1a,0x00,0x1d,0x00,0x10,0x00,  \
    0x1d,0x00,0x05,0x00,0x1d,0x00,0xfa,0xff,0x1c,0x00,0xf0,0xff,0x1c,0x00,0xe5,0xff,0x1c,0x00,0xdb,0xff,0x1c,0x00,0xd0,0xff,0x1c,0x00,0xc5,0xff,0x1c,0x00,0xbb,0xff,0x1c,0x00,0xb0,0xff,0x1c,0x00,0xa5,0xff,0x1c,0x00,0x9b,0xff,0x1c,0x00,0x90,0xff,0x1d,0x00,0x86,0xff,0x1d,0x00,0x7b,0xff,0x1d,0x00,0x70,0xff,0x1d,0x00,0x66,0xff,0x1d,0x00,0x5b,0xff,0x1d,0x00,0x50,0xff,0x1d,0x00,0x46,0xff,0x1d,0x00,0x3b,0xff,0x1d,0x00,0x31,0xff,0x1d,0x00,0x26,0xff,0x1d,0x00,  \
    0x1b,0xff,0x1d,0x00,0x10,0xff,0x1e,0x00,0x06,0xff,0x1e,0x00,0xfb,0xfe,0x1e,0x00,0xf0,0xfe,0x1e,0x00,0xe6,0xfe,0x1e,0x00,0xdb,0xfe,0x1e,0x00,0xd0,0xfe,0x1e,0x00,0xc5,0xfe,0x1f,0x00,0xba,0xfe,0x1f,0x00,0xb0,0xfe,0x1f,0x00,0xa5,0xfe,0x1f,0x00,0x9a,0xfe,0x1f,0x00,0x8f,0xfe,0x20,0x00,0x84,0xfe,0x20,0x00,0x79,0xfe,0x20,0x00,0x6e,0xfe,0x20,0x00,0x63,0xfe,0x21,0x00,0x58,0xfe,0x21,0x00,0x4d,0xfe,0x21,0x00,0x42,0xfe,0x21,0x00,0x37,0xfe,0x22,0x00,0x2c,0xfe,  \
    0x22,0x00,0x21,0xfe,0x22,0x00,0x16,0xfe,0x22,0x00,0x0b,0xfe,0x23,0x00,0x00,0xfe,0x23,0x00,0xf4,0xfd,0x23,0x00,0xe9,0xfd,0x24,0x00,0xde,0xfd,0x24,0x00,0xd3,0xfd,0x24,0x00,0xc7,0xfd,0x25,0x00,0xbc,0xfd,0x25,0x00,0xb0,0xfd,0x25,0x00,0xa5,0xfd,0x26,0x00,0x9a,0xfd,0x26,0x00,0x8e,0xfd,0x27,0x00,0x82,0xfd,0x27,0x00,0x77,0xfd,0x27,0x00,0x6b,0xfd,0x28,0x00,0x60,0xfd,0x28,0x00,0x54,0xfd,0x29,0x00,0x48,0xfd,0x29,0x00,0x3c,0xfd,0x29,0x00,0x31,0xfd,0x2a,0x00,  \
    0x25,0xfd,0x2a,0x00,0x19,0xfd,0x2b,0x00,0x0d,0xfd,0x2b,0x00,0x01,0xfd,0x2c,0x00,0xf5,0xfc,0x2c,0x00,0xe9,0xfc,0x2d,0x00,0xdd,0xfc,0x2d,0x00,0xd0,0xfc,0x2d,0x00,0xc4,0xfc,0x2e,0x00,0xb8,0xfc,0x2e,0x00,0xac,0xfc,0x2f,0x00,0x9f,0xfc,0x2f,0x00,0x93,0xfc,0x30,0x00,0x86,0xfc,0x30,0x00,0x7a,0xfc,0x31,0x00,0x6d,0xfc,0x32,0x00,0x61,0xfc,0x32,0x00,0x54,0xfc,0x33,0x00,0x47,0xfc,0x33,0x00,0x3a,0xfc,0x34,0x00,0x2d,0xfc,0x34,0x00,0x21,0xfc,0x35,0x00,0x14,0xfc,  \
    0x35,0x00,0x07,0xfc,0x36,0x00,0xf9,0xfb,0x37,0x00,0xec,0xfb,0x37,0x00,0xdf,0xfb,0x38,0x00,0xd2,0xfb,0x38,0x00,0xc5,0xfb,0x39,0x00,0xb7,0xfb,0x3a,0x00,0xaa,0xfb,0x3a,0x00,0x9c,0xfb,0x3b,0x00,0x8f,0xfb,0x3b,0x00,0x81,0xfb,0x3c,0x00,0x73,0xfb,0x3d,0x00,0x65,0xfb,0x3d,0x00,0x58,0xfb,0x3e,0x00,0x4a,0xfb,0x3f,0x00,0x3c,0xfb,0x3f,0x00,0x2e,0xfb,0x40,0x00,0x20,0xfb,0x41,0x00,0x11,0xfb,0x41,0x00,0x03,0xfb,0x42,0x00,0xf5,0xfa,0x43,0x00,0xe6,0xfa,0x43,0x00,  \
    0xd8,0xfa,0x44,0x00,0xc9,0xfa,0x45,0x00,0xbb,0xfa,0x45,0x00,0xac,0xfa,0x46,0x00,0x9d,0xfa,0x47,0x00,0x8e,0xfa,0x47,0x00,0x7f,0xfa,0x48,0x00,0x70,0xfa,0x49,0x00,0x61,0xfa,0x4a,0x00,0x52,0xfa,0x4a,0x00,0x43,0xfa,0x4b,0x00,0x34,0xfa,0x4c,0x00,0x24,0xfa,0x4c,0x00,0x15,0xfa,0x4d,0x00,0x05,0xfa,0x4e,0x00,0xf6,0xf9,0x4f,0x00,0xe6,0xf9,0x4f,0x00,0xd6,0xf9,0x50,0x00,0xc6,0xf9,0x51,0x00,0xb6,0xf9,0x52,0x00,0xa6,0xf9,0x52,0x00,0x96,0xf9,0x53,0x00,0x86,0xf9,  \
    0x54,0x00,0x76,0xf9,0x55,0x00,0x65,0xf9,0x56,0x00,0x55,0xf9,0x56,0x00,0x44,0xf9,0x57,0x00,0x33,0xf9,0x58,0x00,0x23,0xf9,0x59,0x00,0x12,0xf9,0x59,0x00,0x01,0xf9,0x5a,0x00,0xf0,0xf8,0x5b,0x00,0xdf,0xf8,0x5c,0x00,0xce,0xf8,0x5d,0x00,0xbc,0xf8,0x5d,0x00,0xab,0xf8,0x5e,0x00,0x99,0xf8,0x5f,0x00,0x88,0xf8,0x60,0x00,0x76,0xf8,0x61,0x00,0x64,0xf8,0x61,0x00,0x52,0xf8,0x62,0x00,0x40,0xf8,0x63,0x00,0x2e,0xf8,0x64,0x00,0x1c,0xf8,0x65,0x00,0x0a,0xf8,0x65,0x00,  \
    0xf8,0xf7,0x66,0x00,0xe5,0xf7,0x67,0x00,0xd3,0xf7,0x68,0x00,0xc0,0xf7,0x69,0x00,0xad,0xf7,0x69,0x00,0x9a,0xf7,0x6a,0x00,0x87,0xf7,0x6b,0x00,0x74,0xf7,0x6c,0x00,0x61,0xf7,0x6d,0x00,0x4e,0xf7,0x6d,0x00,0x3a,0xf7,0x6e,0x00,0x27,0xf7,0x6f,0x00,0x13,0xf7,0x70,0x00,0x00,0xf7,0x71,0x00,0xec,0xf6,0x71,0x00,0xd8,0xf6,0x72,0x00,0xc4,0xf6,0x73,0x00,0xb0,0xf6,0x74,0x00,0x9c,0xf6,0x75,0x00,0x87,0xf6,0x75,0x00,0x73,0xf6,0x76,0x00,0x5e,0xf6,0x77,0x00,0x4a,0xf6,  \
    0x78,0x00,0x35,0xf6,0x79,0x00,0x20,0xf6,0x79,0x00,0x0b,0xf6,0x7a,0x00,0xf6,0xf5,0x7b,0x00,0xe1,0xf5,0x7c,0x00,0xcb,0xf5,0x7c,0x00,0xb6,0xf5,0x7d,0x00,0xa0,0xf5,0x7e,0x00,0x8b,0xf5,0x7f,0x00,0x75,0xf5,0x80,0x00,0x5f,0xf5,0x80,0x00,0x49,0xf5,0x81,0x00,0x33,0xf5,0x82,0x00,0x1d,0xf5,0x83,0x00,0x06,0xf5,0x83,0x00,0xf0,0xf4,0x84,0x00,0xd9,0xf4,0x85,0x00,0xc3,0xf4,0x85,0x00,0xac,0xf4,0x86,0x00,0x95,0xf4,0x87,0x00,0x7e,0xf4,0x88,0x00,0x67,0xf4,0x88,0x00,  \
    0x4f,0xf4,0x89,0x00,0x38,0xf4,0x8a,0x00,0x21,0xf4,0x8a,0x00,0x09,0xf4,0x8b,0x00,0xf1,0xf3,0x8c,0x00,0xd9,0xf3,0x8c,0x00,0xc1,0xf3,0x8d,0x00,0xa9,0xf3,0x8e,0x00,0x91,0xf3,0x8e,0x00,0x79,0xf3,0x8f,0x00,0x60,0xf3,0x90,0x00,0x47,0xf3,0x90,0x00,0x2f,0xf3,0x91,0x00,0x16,0xf3,0x92,0x00,0xfd,0xf2,0x92,0x00,0xe4,0xf2,0x93,0x00,0xcb,0xf2,0x93,0x00,0xb1,0xf2,0x94,0x00,0x98,0xf2,0x94,0x00,0x7e,0xf2,0x95,0x00,0x64,0xf2,0x96,0x00,0x4b,0xf2,0x96,0x00,0x31,0xf2,  \
    0x97,0x00,0x17,0xf2,0x97,0x00,0xfc,0xf1,0x98,0x00,0xe2,0xf1,0x98,0x00,0xc8,0xf1,0x99,0x00,0xad,0xf1,0x99,0x00,0x92,0xf1,0x9a,0x00,0x77,0xf1,0x9a,0x00,0x5c,0xf1,0x9b,0x00,0x41,0xf1,0x9b,0x00,0x26,0xf1,0x9c,0x00,0x0b,0xf1,0x9c,0x00,0xef,0xf0,0x9c,0x00,0xd4,0xf0,0x9d,0x00,0xb8,0xf0,0x9d,0x00,0x9c,0xf0,0x9e,0x00,0x80,0xf0,0x9e,0x00,0x64,0xf0,0x9e,0x00,0x48,0xf0,0x9f,0x00,0x2b,0xf0,0x9f,0x00,0x0f,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x97,0x00,0x01,0x10,0x97,0x00,0xe4,0x0f,0x96,0x00,0xc8,0x0f,0x96,0x00,0xab,0x0f,0x96,0x00,0x8f,0x0f,0x95,0x00,0x73,0x0f,0x95,0x00,0x56,0x0f,0x95,0x00,0x3a,0x0f,0x94,0x00,0x1f,0x0f,0x94,0x00,0x03,0x0f,  \
    0x94,0x00,0xe7,0x0e,0x93,0x00,0xcc,0x0e,0x93,0x00,0xb0,0x0e,0x93,0x00,0x95,0x0e,0x92,0x00,0x7a,0x0e,0x92,0x00,0x5f,0x0e,0x91,0x00,0x44,0x0e,0x91,0x00,0x29,0x0e,0x90,0x00,0x0f,0x0e,0x90,0x00,0xf4,0x0d,0x8f,0x00,0xda,0x0d,0x8f,0x00,0xbf,0x0d,0x8f,0x00,0xa5,0x0d,0x8e,0x00,0x8b,0x0d,0x8e,0x00,0x71,0x0d,0x8d,0x00,0x57,0x0d,0x8d,0x00,0x3d,0x0d,0x8c,0x00,0x24,0x0d,0x8c,0x00,0x0a,0x0d,0x8b,0x00,0xf1,0x0c,0x8a,0x00,0xd8,0x0c,0x8a,0x00,0xbf,0x0c,0x89,0x00,  \
    0xa6,0x0c,0x89,0x00,0x8d,0x0c,0x88,0x00,0x74,0x0c,0x88,0x00,0x5b,0x0c,0x87,0x00,0x43,0x0c,0x87,0x00,0x2a,0x0c,0x86,0x00,0x12,0x0c,0x85,0x00,0xfa,0x0b,0x85,0x00,0xe2,0x0b,0x84,0x00,0xca,0x0b,0x84,0x00,0xb2,0x0b,0x83,0x00,0x9a,0x0b,0x82,0x00,0x82,0x0b,0x82,0x00,0x6b,0x0b,0x81,0x00,0x54,0x0b,0x81,0x00,0x3c,0x0b,0x80,0x00,0x25,0x0b,0x7f,0x00,0x0e,0x0b,0x7f,0x00,0xf7,0x0a,0x7e,0x00,0xe0,0x0a,0x7d,0x00,0xc9,0x0a,0x7d,0x00,0xb3,0x0a,0x7c,0x00,0x9c,0x0a,  \
    0x7b,0x00,0x86,0x0a,0x7b,0x00,0x70,0x0a,0x7a,0x00,0x5a,0x0a,0x79,0x00,0x43,0x0a,0x79,0x00,0x2e,0x0a,0x78,0x00,0x18,0x0a,0x77,0x00,0x02,0x0a,0x77,0x00,0xec,0x09,0x76,0x00,0xd7,0x09,0x75,0x00,0xc1,0x09,0x75,0x00,0xac,0x09,0x74,0x00,0x97,0x09,0x73,0x00,0x82,0x09,0x73,0x00,0x6d,0x09,0x72,0x00,0x58,0x09,0x71,0x00,0x43,0x09,0x71,0x00,0x2f,0x09,0x70,0x00,0x1a,0x09,0x6f,0x00,0x05,0x09,0x6e,0x00,0xf1,0x08,0x6e,0x00,0xdd,0x08,0x6d,0x00,0xc9,0x08,0x6c,0x00,  \
    0xb5,0x08,0x6c,0x00,0xa1,0x08,0x6b,0x00,0x8d,0x08,0x6a,0x00,0x79,0x08,0x69,0x00,0x66,0x08,0x69,0x00,0x52,0x08,0x68,0x00,0x3f,0x08,0x67,0x00,0x2b,0x08,0x67,0x00,0x18,0x08,0x66,0x00,0x05,0x08,0x65,0x00,0xf2,0x07,0x65,0x00,0xdf,0x07,0x64,0x00,0xcc,0x07,0x63,0x00,0xb9,0x07,0x62,0x00,0xa7,0x07,0x62,0x00,0x94,0x07,0x61,0x00,0x82,0x07,0x60,0x00,0x70,0x07,0x60,0x00,0x5d,0x07,0x5f,0x00,0x4b,0x07,0x5e,0x00,0x39,0x07,0x5d,0x00,0x27,0x07,0x5d,0x00,0x15,0x07,  \
    0x5c,0x00,0x04,0x07,0x5b,0x00,0xf2,0x06,0x5b,0x00,0xe0,0x06,0x5a,0x00,0xcf,0x06,0x59,0x00,0xbd,0x06,0x59,0x00,0xac,0x06,0x58,0x00,0x9b,0x06,0x57,0x00,0x8a,0x06,0x57,0x00,0x79,0x06,0x56,0x00,0x68,0x06,0x55,0x00,0x57,0x06,0x55,0x00,0x46,0x06,0x54,0x00,0x36,0x06,0x53,0x00,0x25,0x06,0x52,0x00,0x14,0x06,0x52,0x00,0x04,0x06,0x51,0x00,0xf4,0x05,0x50,0x00,0xe3,0x05,0x50,0x00,0xd3,0x05,0x4f,0x00,0xc3,0x05,0x4f,0x00,0xb3,0x05,0x4e,0x00,0xa3,0x05,0x4d,0x00,  \
    0x94,0x05,0x4d,0x00,0x84,0x05,0x4c,0x00,0x74,0x05,0x4b,0x00,0x65,0x05,0x4b,0x00,0x55,0x05,0x4a,0x00,0x46,0x05,0x49,0x00,0x36,0x05,0x49,0x00,0x27,0x05,0x48,0x00,0x18,0x05,0x47,0x00,0x09,0x05,0x47,0x00,0xfa,0x04,0x46,0x00,0xeb,0x04,0x46,0x00,0xdc,0x04,0x45,0x00,0xcd,0x04,0x44,0x00,0xbe,0x04,0x44,0x00,0xb0,0x04,0x43,0x00,0xa1,0x04,0x43,0x00,0x92,0x04,0x42,0x00,0x84,0x04,0x41,0x00,0x76,0x04,0x41,0x00,0x67,0x04,0x40,0x00,0x59,0x04,0x40,0x00,0x4b,0x04,  \
    0x3f,0x00,0x3d,0x04,0x3f,0x00,0x2f,0x04,0x3e,0x00,0x21,0x04,0x3d,0x00,0x13,0x04,0x3d,0x00,0x05,0x04,0x3c,0x00,0xf7,0x03,0x3c,0x00,0xea,0x03,0x3b,0x00,0xdc,0x03,0x3b,0x00,0xce,0x03,0x3a,0x00,0xc1,0x03,0x3a,0x00,0xb3,0x03,0x39,0x00,0xa6,0x03,0x39,0x00,0x99,0x03,0x38,0x00,0x8b,0x03,0x38,0x00,0x7e,0x03,0x37,0x00,0x71,0x03,0x37,0x00,0x64,0x03,0x36,0x00,0x57,0x03,0x36,0x00,0x4a,0x03,0x35,0x00,0x3d,0x03,0x35,0x00,0x30,0x03,0x34,0x00,0x23,0x03,0x34,0x00,  \
    0x17,0x03,0x33,0x00,0x0a,0x03,0x33,0x00,0xfd,0x02,0x32,0x00,0xf1,0x02,0x32,0x00,0xe4,0x02,0x32,0x00,0xd8,0x02,0x31,0x00,0xcb,0x02,0x31,0x00,0xbf,0x02,0x30,0x00,0xb3,0x02,0x30,0x00,0xa6,0x02,0x2f,0x00,0x9a,0x02,0x2f,0x00,0x8e,0x02,0x2f,0x00,0x82,0x02,0x2e,0x00,0x76,0x02,0x2e,0x00,0x6a,0x02,0x2d,0x00,0x5e,0x02,0x2d,0x00,0x52,0x02,0x2d,0x00,0x46,0x02,0x2c,0x00,0x3a,0x02,0x2c,0x00,0x2e,0x02,0x2c,0x00,0x22,0x02,0x2b,0x00,0x17,0x02,0x2b,0x00,0x0b,0x02,  \
    0x2b,0x00,0xff,0x01,0x2a,0x00,0xf4,0x01,0x2a,0x00,0xe8,0x01,0x2a,0x00,0xdc,0x01,0x29,0x00,0xd1,0x01,0x29,0x00,0xc5,0x01,0x29,0x00,0xba,0x01,0x28,0x00,0xaf,0x01,0x28,0x00,0xa3,0x01,0x28,0x00,0x98,0x01,0x28,0x00,0x8d,0x01,0x27,0x00,0x81,0x01,0x27,0x00,0x76,0x01,0x27,0x00,0x6b,0x01,0x27,0x00,0x60,0x01,0x26,0x00,0x54,0x01,0x26,0x00,0x49,0x01,0x26,0x00,0x3e,0x01,0x26,0x00,0x33,0x01,0x25,0x00,0x28,0x01,0x25,0x00,0x1d,0x01,0x25,0x00,0x12,0x01,0x25,0x00,  \
    0x07,0x01,0x25,0x00,0xfc,0x00,0x24,0x00,0xf1,0x00,0x24,0x00,0xe6,0x00,0x24,0x00,0xdb,0x00,0x24,0x00,0xd1,0x00,0x24,0x00,0xc6,0x00,0x24,0x00,0xbb,0x00,0x23,0x00,0xb0,0x00,0x23,0x00,0xa5,0x00,0x23,0x00,0x9b,0x00,0x23,0x00,0x90,0x00,0x23,0x00,0x85,0x00,0x23,0x00,0x7a,0x00,0x23,0x00,0x70,0x00,0x23,0x00,0x65,0x00,0x22,0x00,0x5a,0x00,0x22,0x00,0x4f,0x00,0x22,0x00,0x45,0x00,0x22,0x00,0x3a,0x00,0x22,0x00,0x2f,0x00,0x22,0x00,0x25,0x00,0x22,0x00,0x1a,0x00,  \
    0x22,0x00,0x10,0x00,0x22,0x00,0x05,0x00,0x22,0x00,0xfa,0xff,0x22,0x00,0xf0,0xff,0x22,0x00,0xe5,0xff,0x22,0x00,0xda,0xff,0x22,0x00,0xd0,0xff,0x22,0x00,0xc5,0xff,0x22,0x00,0xbb,0xff,0x22,0x00,0xb0,0xff,0x22,0x00,0xa5,0xff,0x22,0x00,0x9b,0xff,0x22,0x00,0x90,0xff,0x22,0x00,0x86,0xff,0x22,0x00,0x7b,0xff,0x22,0x00,0x70,0xff,0x22,0x00,0x66,0xff,0x22,0x00,0x5b,0xff,0x22,0x00,0x51,0xff,0x22,0x00,0x46,0xff,0x22,0x00,0x3b,0xff,0x22,0x00,0x31,0xff,0x22,0x00,  \
    0x26,0xff,0x23,0x00,0x1b,0xff,0x23,0x00,0x11,0xff,0x23,0x00,0x06,0xff,0x23,0x00,0xfb,0xfe,0x23,0x00,0xf1,0xfe,0x23,0x00,0xe6,0xfe,0x23,0x00,0xdb,0xfe,0x23,0x00,0xd0,0xfe,0x24,0x00,0xc6,0xfe,0x24,0x00,0xbb,0xfe,0x24,0x00,0xb0,0xfe,0x24,0x00,0xa5,0xfe,0x24,0x00,0x9a,0xfe,0x24,0x00,0x8f,0xfe,0x25,0x00,0x85,0xfe,0x25,0x00,0x7a,0xfe,0x25,0x00,0x6f,0xfe,0x25,0x00,0x64,0xfe,0x25,0x00,0x59,0xfe,0x26,0x00,0x4e,0xfe,0x26,0x00,0x43,0xfe,0x26,0x00,0x38,0xfe,  \
    0x26,0x00,0x2d,0xfe,0x27,0x00,0x22,0xfe,0x27,0x00,0x17,0xfe,0x27,0x00,0x0b,0xfe,0x27,0x00,0x00,0xfe,0x28,0x00,0xf5,0xfd,0x28,0x00,0xea,0xfd,0x28,0x00,0xde,0xfd,0x28,0x00,0xd3,0xfd,0x29,0x00,0xc8,0xfd,0x29,0x00,0xbc,0xfd,0x29,0x00,0xb1,0xfd,0x2a,0x00,0xa6,0xfd,0x2a,0x00,0x9a,0xfd,0x2a,0x00,0x8f,0xfd,0x2b,0x00,0x83,0xfd,0x2b,0x00,0x78,0xfd,0x2b,0x00,0x6c,0xfd,0x2c,0x00,0x60,0xfd,0x2c,0x00,0x55,0xfd,0x2c,0x00,0x49,0xfd,0x2d,0x00,0x3d,0xfd,0x2d,0x00,  \
    0x31,0xfd,0x2e,0x00,0x25,0xfd,0x2e,0x00,0x1a,0xfd,0x2e,0x00,0x0e,0xfd,0x2f,0x00,0x02,0xfd,0x2f,0x00,0xf6,0xfc,0x30,0x00,0xe9,0xfc,0x30,0x00,0xdd,0xfc,0x30,0x00,0xd1,0xfc,0x31,0x00,0xc5,0xfc,0x31,0x00,0xb9,0xfc,0x32,0x00,0xac,0xfc,0x32,0x00,0xa0,0xfc,0x33,0x00,0x94,0xfc,0x33,0x00,0x87,0xfc,0x33,0x00,0x7b,0xfc,0x34,0x00,0x6e,0xfc,0x34,0x00,0x61,0xfc,0x35,0x00,0x55,0xfc,0x35,0x00,0x48,0xfc,0x36,0x00,0x3b,0xfc,0x36,0x00,0x2e,0xfc,0x37,0x00,0x21,0xfc,  \
    0x37,0x00,0x14,0xfc,0x38,0x00,0x07,0xfc,0x38,0x00,0xfa,0xfb,0x39,0x00,0xed,0xfb,0x39,0x00,0xe0,0xfb,0x3a,0x00,0xd3,0xfb,0x3a,0x00,0xc5,0xfb,0x3b,0x00,0xb8,0xfb,0x3b,0x00,0xab,0xfb,0x3c,0x00,0x9d,0xfb,0x3d,0x00,0x90,0xfb,0x3d,0x00,0x82,0xfb,0x3e,0x00,0x74,0xfb,0x3e,0x00,0x66,0xfb,0x3f,0x00,0x59,0xfb,0x3f,0x00,0x4b,0xfb,0x40,0x00,0x3d,0xfb,0x40,0x00,0x2f,0xfb,0x41,0x00,0x21,0xfb,0x42,0x00,0x12,0xfb,0x42,0x00,0x04,0xfb,0x43,0x00,0xf6,0xfa,0x43,0x00,  \
    0xe7,0xfa,0x44,0x00,0xd9,0xfa,0x45,0x00,0xca,0xfa,0x45,0x00,0xbc,0xfa,0x46,0x00,0xad,0xfa,0x46,0x00,0x9e,0xfa,0x47,0x00,0x8f,0xfa,0x48,0x00,0x80,0xfa,0x48,0x00,0x71,0xfa,0x49,0x00,0x62,0xfa,0x4a,0x00,0x53,0xfa,0x4a,0x00,0x44,0xfa,0x4b,0x00,0x35,0xfa,0x4c,0x00,0x25,0xfa,0x4c,0x00,0x16,0xfa,0x4d,0x00,0x06,0xfa,0x4d,0x00,0xf7,0xf9,0x4e,0x00,0xe7,0xf9,0x4f,0x00,0xd7,0xf9,0x4f,0x00,0xc7,0xf9,0x50,0x00,0xb7,0xf9,0x51,0x00,0xa7,0xf9,0x51,0x00,0x97,0xf9,  \
    0x52,0x00,0x87,0xf9,0x53,0x00,0x77,0xf9,0x53,0x00,0x66,0xf9,0x54,0x00,0x56,0xf9,0x55,0x00,0x45,0xf9,0x56,0x00,0x34,0xf9,0x56,0x00,0x24,0xf9,0x57,0x00,0x13,0xf9,0x58,0x00,0x02,0xf9,0x58,0x00,0xf1,0xf8,0x59,0x00,0xe0,0xf8,0x5a,0x00,0xcf,0xf8,0x5a,0x00,0xbd,0xf8,0x5b,0x00,0xac,0xf8,0x5c,0x00,0x9a,0xf8,0x5c,0x00,0x89,0xf8,0x5d,0x00,0x77,0xf8,0x5e,0x00,0x65,0xf8,0x5f,0x00,0x53,0xf8,0x5f,0x00,0x42,0xf8,0x60,0x00,0x2f,0xf8,0x61,0x00,0x1d,0xf8,0x61,0x00,  \
    0x0b,0xf8,0x62,0x00,0xf9,0xf7,0x63,0x00,0xe6,0xf7,0x64,0x00,0xd4,0xf7,0x64,0x00,0xc1,0xf7,0x65,0x00,0xae,0xf7,0x66,0x00,0x9b,0xf7,0x66,0x00,0x88,0xf7,0x67,0x00,0x75,0xf7,0x68,0x00,0x62,0xf7,0x69,0x00,0x4f,0xf7,0x69,0x00,0x3c,0xf7,0x6a,0x00,0x28,0xf7,0x6b,0x00,0x14,0xf7,0x6b,0x00,0x01,0xf7,0x6c,0x00,0xed,0xf6,0x6d,0x00,0xd9,0xf6,0x6d,0x00,0xc5,0xf6,0x6e,0x00,0xb1,0xf6,0x6f,0x00,0x9d,0xf6,0x70,0x00,0x88,0xf6,0x70,0x00,0x74,0xf6,0x71,0x00,0x5f,0xf6,  \
    0x72,0x00,0x4b,0xf6,0x72,0x00,0x36,0xf6,0x73,0x00,0x21,0xf6,0x74,0x00,0x0c,0xf6,0x74,0x00,0xf7,0xf5,0x75,0x00,0xe2,0xf5,0x76,0x00,0xcc,0xf5,0x77,0x00,0xb7,0xf5,0x77,0x00,0xa1,0xf5,0x78,0x00,0x8c,0xf5,0x79,0x00,0x76,0xf5,0x79,0x00,0x60,0xf5,0x7a,0x00,0x4a,0xf5,0x7b,0x00,0x34,0xf5,0x7b,0x00,0x1e,0xf5,0x7c,0x00,0x07,0xf5,0x7c,0x00,0xf1,0xf4,0x7d,0x00,0xda,0xf4,0x7e,0x00,0xc4,0xf4,0x7e,0x00,0xad,0xf4,0x7f,0x00,0x96,0xf4,0x80,0x00,0x7f,0xf4,0x80,0x00,  \
    0x68,0xf4,0x81,0x00,0x50,0xf4,0x82,0x00,0x39,0xf4,0x82,0x00,0x21,0xf4,0x83,0x00,0x0a,0xf4,0x83,0x00,0xf2,0xf3,0x84,0x00,0xda,0xf3,0x85,0x00,0xc2,0xf3,0x85,0x00,0xaa,0xf3,0x86,0x00,0x92,0xf3,0x86,0x00,0x79,0xf3,0x87,0x00,0x61,0xf3,0x87,0x00,0x48,0xf3,0x88,0x00,0x30,0xf3,0x89,0x00,0x17,0xf3,0x89,0x00,0xfe,0xf2,0x8a,0x00,0xe5,0xf2,0x8a,0x00,0xcb,0xf2,0x8b,0x00,0xb2,0xf2,0x8b,0x00,0x99,0xf2,0x8c,0x00,0x7f,0xf2,0x8c,0x00,0x65,0xf2,0x8d,0x00,0x4b,0xf2,  \
    0x8d,0x00,0x32,0xf2,0x8e,0x00,0x17,0xf2,0x8e,0x00,0xfd,0xf1,0x8f,0x00,0xe3,0xf1,0x8f,0x00,0xc8,0xf1,0x8f,0x00,0xae,0xf1,0x90,0x00,0x93,0xf1,0x90,0x00,0x78,0xf1,0x91,0x00,0x5d,0xf1,0x91,0x00,0x42,0xf1,0x92,0x00,0x27,0xf1,0x92,0x00,0x0b,0xf1,0x92,0x00,0xf0,0xf0,0x93,0x00,0xd4,0xf0,0x93,0x00,0xb9,0xf0,0x93,0x00,0x9d,0xf0,0x94,0x00,0x81,0xf0,0x94,0x00,0x65,0xf0,0x94,0x00,0x48,0xf0,0x95,0x00,0x2c,0xf0,0x95,0x00,0x0f,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x8d,0x00,0x00,0x10,0x8c,0x00,0xe3,0x0f,0x8c,0x00,0xc7,0x0f,0x8c,0x00,0xaa,0x0f,0x8c,0x00,0x8e,0x0f,0x8b,0x00,0x72,0x0f,0x8b,0x00,0x56,0x0f,0x8b,0x00,0x3a,0x0f,0x8a,0x00,0x1e,0x0f,  \
    0x8a,0x00,0x02,0x0f,0x8a,0x00,0xe7,0x0e,0x89,0x00,0xcb,0x0e,0x89,0x00,0xb0,0x0e,0x89,0x00,0x94,0x0e,0x88,0x00,0x79,0x0e,0x88,0x00,0x5e,0x0e,0x88,0x00,0x43,0x0e,0x87,0x00,0x28,0x0e,0x87,0x00,0x0e,0x0e,0x86,0x00,0xf3,0x0d,0x86,0x00,0xd9,0x0d,0x86,0x00,0xbf,0x0d,0x85,0x00,0xa4,0x0d,0x85,0x00,0x8a,0x0d,0x84,0x00,0x70,0x0d,0x84,0x00,0x56,0x0d,0x84,0x00,0x3d,0x0d,0x83,0x00,0x23,0x0d,0x83,0x00,0x0a,0x0d,0x82,0x00,0xf0,0x0c,0x82,0x00,0xd7,0x0c,0x81,0x00,  \
    0xbe,0x0c,0x81,0x00,0xa5,0x0c,0x80,0x00,0x8c,0x0c,0x80,0x00,0x73,0x0c,0x7f,0x00,0x5a,0x0c,0x7f,0x00,0x42,0x0c,0x7e,0x00,0x29,0x0c,0x7e,0x00,0x11,0x0c,0x7d,0x00,0xf9,0x0b,0x7d,0x00,0xe1,0x0b,0x7c,0x00,0xc9,0x0b,0x7c,0x00,0xb1,0x0b,0x7b,0x00,0x99,0x0b,0x7b,0x00,0x82,0x0b,0x7a,0x00,0x6a,0x0b,0x7a,0x00,0x53,0x0b,0x79,0x00,0x3b,0x0b,0x79,0x00,0x24,0x0b,0x78,0x00,0x0d,0x0b,0x78,0x00,0xf6,0x0a,0x77,0x00,0xdf,0x0a,0x76,0x00,0xc9,0x0a,0x76,0x00,0xb2,0x0a,  \
    0x75,0x00,0x9c,0x0a,0x75,0x00,0x85,0x0a,0x74,0x00,0x6f,0x0a,0x74,0x00,0x59,0x0a,0x73,0x00,0x43,0x0a,0x72,0x00,0x2d,0x0a,0x72,0x00,0x17,0x0a,0x71,0x00,0x01,0x0a,0x71,0x00,0xeb,0x09,0x70,0x00,0xd6,0x09,0x70,0x00,0xc1,0x09,0x6f,0x00,0xab,0x09,0x6e,0x00,0x96,0x09,0x6e,0x00,0x81,0x09,0x6d,0x00,0x6c,0x09,0x6d,0x00,0x57,0x09,0x6c,0x00,0x42,0x09,0x6b,0x00,0x2e,0x09,0x6b,0x00,0x19,0x09,0x6a,0x00,0x05,0x09,0x6a,0x00,0xf0,0x08,0x69,0x00,0xdc,0x08,0x68,0x00,  \
    0xc8,0x08,0x68,0x00,0xb4,0x08,0x67,0x00,0xa0,0x08,0x66,0x00,0x8c,0x08,0x66,0x00,0x78,0x08,0x65,0x00,0x65,0x08,0x65,0x00,0x51,0x08,0x64,0x00,0x3e,0x08,0x63,0x00,0x2a,0x08,0x63,0x00,0x17,0x08,0x62,0x00,0x04,0x08,0x62,0x00,0xf1,0x07,0x61,0x00,0xde,0x07,0x60,0x00,0xcb,0x07,0x60,0x00,0xb9,0x07,0x5f,0x00,0xa6,0x07,0x5f,0x00,0x93,0x07,0x5e,0x00,0x81,0x07,0x5d,0x00,0x6f,0x07,0x5d,0x00,0x5c,0x07,0x5c,0x00,0x4a,0x07,0x5b,0x00,0x38,0x07,0x5b,0x00,0x26,0x07,  \
    0x5a,0x00,0x14,0x07,0x5a,0x00,0x03,0x07,0x59,0x00,0xf1,0x06,0x58,0x00,0xdf,0x06,0x58,0x00,0xce,0x06,0x57,0x00,0xbd,0x06,0x57,0x00,0xab,0x06,0x56,0x00,0x9a,0x06,0x55,0x00,0x89,0x06,0x55,0x00,0x78,0x06,0x54,0x00,0x67,0x06,0x54,0x00,0x56,0x06,0x53,0x00,0x45,0x06,0x52,0x00,0x35,0x06,0x52,0x00,0x24,0x06,0x51,0x00,0x14,0x06,0x51,0x00,0x03,0x06,0x50,0x00,0xf3,0x05,0x50,0x00,0xe3,0x05,0x4f,0x00,0xd2,0x05,0x4e,0x00,0xc2,0x05,0x4e,0x00,0xb2,0x05,0x4d,0x00,  \
    0xa2,0x05,0x4d,0x00,0x93,0x05,0x4c,0x00,0x83,0x05,0x4c,0x00,0x73,0x05,0x4b,0x00,0x64,0x05,0x4b,0x00,0x54,0x05,0x4a,0x00,0x45,0x05,0x49,0x00,0x35,0x05,0x49,0x00,0x26,0x05,0x48,0x00,0x17,0x05,0x48,0x00,0x08,0x05,0x47,0x00,0xf9,0x04,0x47,0x00,0xea,0x04,0x46,0x00,0xdb,0x04,0x46,0x00,0xcc,0x04,0x45,0x00,0xbd,0x04,0x45,0x00,0xaf,0x04,0x44,0x00,0xa0,0x04,0x44,0x00,0x92,0x04,0x43,0x00,0x83,0x04,0x43,0x00,0x75,0x04,0x42,0x00,0x66,0x04,0x42,0x00,0x58,0x04,  \
    0x41,0x00,0x4a,0x04,0x41,0x00,0x3c,0x04,0x40,0x00,0x2e,0x04,0x40,0x00,0x20,0x04,0x3f,0x00,0x12,0x04,0x3f,0x00,0x04,0x04,0x3e,0x00,0xf6,0x03,0x3e,0x00,0xe9,0x03,0x3d,0x00,0xdb,0x03,0x3d,0x00,0xce,0x03,0x3c,0x00,0xc0,0x03,0x3c,0x00,0xb3,0x03,0x3b,0x00,0xa5,0x03,0x3b,0x00,0x98,0x03,0x3b,0x00,0x8b,0x03,0x3a,0x00,0x7d,0x03,0x3a,0x00,0x70,0x03,0x39,0x00,0x63,0x03,0x39,0x00,0x56,0x03,0x38,0x00,0x49,0x03,0x38,0x00,0x3c,0x03,0x38,0x00,0x2f,0x03,0x37,0x00,  \
    0x23,0x03,0x37,0x00,0x16,0x03,0x36,0x00,0x09,0x03,0x36,0x00,0xfd,0x02,0x36,0x00,0xf0,0x02,0x35,0x00,0xe4,0x02,0x35,0x00,0xd7,0x02,0x34,0x00,0xcb,0x02,0x34,0x00,0xbe,0x02,0x34,0x00,0xb2,0x02,0x33,0x00,0xa6,0x02,0x33,0x00,0x99,0x02,0x33,0x00,0x8d,0x02,0x32,0x00,0x81,0x02,0x32,0x00,0x75,0x02,0x32,0x00,0x69,0x02,0x31,0x00,0x5d,0x02,0x31,0x00,0x51,0x02,0x31,0x00,0x45,0x02,0x30,0x00,0x39,0x02,0x30,0x00,0x2e,0x02,0x30,0x00,0x22,0x02,0x2f,0x00,0x16,0x02,  \
    0x2f,0x00,0x0a,0x02,0x2f,0x00,0xff,0x01,0x2e,0x00,0xf3,0x01,0x2e,0x00,0xe7,0x01,0x2e,0x00,0xdc,0x01,0x2e,0x00,0xd0,0x01,0x2d,0x00,0xc5,0x01,0x2d,0x00,0xba,0x01,0x2d,0x00,0xae,0x01,0x2d,0x00,0xa3,0x01,0x2c,0x00,0x97,0x01,0x2c,0x00,0x8c,0x01,0x2c,0x00,0x81,0x01,0x2c,0x00,0x76,0x01,0x2b,0x00,0x6a,0x01,0x2b,0x00,0x5f,0x01,0x2b,0x00,0x54,0x01,0x2b,0x00,0x49,0x01,0x2b,0x00,0x3e,0x01,0x2a,0x00,0x33,0x01,0x2a,0x00,0x28,0x01,0x2a,0x00,0x1d,0x01,0x2a,0x00,  \
    0x12,0x01,0x2a,0x00,0x07,0x01,0x2a,0x00,0xfc,0x00,0x29,0x00,0xf1,0x00,0x29,0x00,0xe6,0x00,0x29,0x00,0xdb,0x00,0x29,0x00,0xd0,0x00,0x29,0x00,0xc5,0x00,0x29,0x00,0xbb,0x00,0x29,0x00,0xb0,0x00,0x28,0x00,0xa5,0x00,0x28,0x00,0x9a,0x00,0x28,0x00,0x90,0x00,0x28,0x00,0x85,0x00,0x28,0x00,0x7a,0x00,0x28,0x00,0x6f,0x00,0x28,0x00,0x65,0x00,0x28,0x00,0x5a,0x00,0x28,0x00,0x4f,0x00,0x28,0x00,0x45,0x00,0x27,0x00,0x3a,0x00,0x27,0x00,0x2f,0x00,0x27,0x00,0x25,0x00,  \
    0x27,0x00,0x1a,0x00,0x27,0x00,0x0f,0x00,0x27,0x00,0x05,0x00,0x27,0x00,0xfa,0xff,0x27,0x00,0xf0,0xff,0x27,0x00,0xe5,0xff,0x27,0x00,0xda,0xff,0x27,0x00,0xd0,0xff,0x27,0x00,0xc5,0xff,0x27,0x00,0xbb,0xff,0x27,0x00,0xb0,0xff,0x27,0x00,0xa6,0xff,0x27,0x00,0x9b,0xff,0x27,0x00,0x90,0xff,0x27,0x00,0x86,0xff,0x27,0x00,0x7b,0xff,0x27,0x00,0x71,0xff,0x27,0x00,0x66,0xff,0x27,0x00,0x5b,0xff,0x27,0x00,0x51,0xff,0x27,0x00,0x46,0xff,0x28,0x00,0x3b,0xff,0x28,0x00,  \
    0x31,0xff,0x28,0x00,0x26,0xff,0x28,0x00,0x1c,0xff,0x28,0x00,0x11,0xff,0x28,0x00,0x06,0xff,0x28,0x00,0xfc,0xfe,0x28,0x00,0xf1,0xfe,0x28,0x00,0xe6,0xfe,0x28,0x00,0xdb,0xfe,0x29,0x00,0xd1,0xfe,0x29,0x00,0xc6,0xfe,0x29,0x00,0xbb,0xfe,0x29,0x00,0xb0,0xfe,0x29,0x00,0xa5,0xfe,0x29,0x00,0x9b,0xfe,0x29,0x00,0x90,0xfe,0x2a,0x00,0x85,0xfe,0x2a,0x00,0x7a,0xfe,0x2a,0x00,0x6f,0xfe,0x2a,0x00,0x64,0xfe,0x2a,0x00,0x59,0xfe,0x2a,0x00,0x4e,0xfe,0x2b,0x00,0x43,0xfe,  \
    0x2b,0x00,0x38,0xfe,0x2b,0x00,0x2d,0xfe,0x2b,0x00,0x22,0xfe,0x2c,0x00,0x17,0xfe,0x2c,0x00,0x0c,0xfe,0x2c,0x00,0x01,0xfe,0x2c,0x00,0xf5,0xfd,0x2c,0x00,0xea,0xfd,0x2d,0x00,0xdf,0xfd,0x2d,0x00,0xd4,0xfd,0x2d,0x00,0xc8,0xfd,0x2d,0x00,0xbd,0xfd,0x2e,0x00,0xb2,0xfd,0x2e,0x00,0xa6,0xfd,0x2e,0x00,0x9b,0xfd,0x2f,0x00,0x8f,0xfd,0x2f,0x00,0x84,0xfd,0x2f,0x00,0x78,0xfd,0x2f,0x00,0x6d,0xfd,0x30,0x00,0x61,0xfd,0x30,0x00,0x55,0xfd,0x30,0x00,0x49,0xfd,0x31,0x00,  \
    0x3e,0xfd,0x31,0x00,0x32,0xfd,0x31,0x00,0x26,0xfd,0x32,0x00,0x1a,0xfd,0x32,0x00,0x0e,0xfd,0x32,0x00,0x02,0xfd,0x33,0x00,0xf6,0xfc,0x33,0x00,0xea,0xfc,0x33,0x00,0xde,0xfc,0x34,0x00,0xd2,0xfc,0x34,0x00,0xc6,0xfc,0x35,0x00,0xb9,0xfc,0x35,0x00,0xad,0xfc,0x35,0x00,0xa1,0xfc,0x36,0x00,0x94,0xfc,0x36,0x00,0x88,0xfc,0x36,0x00,0x7b,0xfc,0x37,0x00,0x6f,0xfc,0x37,0x00,0x62,0xfc,0x38,0x00,0x55,0xfc,0x38,0x00,0x49,0xfc,0x38,0x00,0x3c,0xfc,0x39,0x00,0x2f,0xfc,  \
    0x39,0x00,0x22,0xfc,0x3a,0x00,0x15,0xfc,0x3a,0x00,0x08,0xfc,0x3b,0x00,0xfb,0xfb,0x3b,0x00,0xee,0xfb,0x3c,0x00,0xe1,0xfb,0x3c,0x00,0xd4,0xfb,0x3c,0x00,0xc6,0xfb,0x3d,0x00,0xb9,0xfb,0x3d,0x00,0xab,0xfb,0x3e,0x00,0x9e,0xfb,0x3e,0x00,0x90,0xfb,0x3f,0x00,0x83,0xfb,0x3f,0x00,0x75,0xfb,0x40,0x00,0x67,0xfb,0x40,0x00,0x59,0xfb,0x41,0x00,0x4c,0xfb,0x41,0x00,0x3e,0xfb,0x42,0x00,0x2f,0xfb,0x42,0x00,0x21,0xfb,0x43,0x00,0x13,0xfb,0x43,0x00,0x05,0xfb,0x44,0x00,  \
    0xf7,0xfa,0x44,0x00,0xe8,0xfa,0x45,0x00,0xda,0xfa,0x45,0x00,0xcb,0xfa,0x46,0x00,0xbd,0xfa,0x46,0x00,0xae,0xfa,0x47,0x00,0x9f,0xfa,0x47,0x00,0x90,0xfa,0x48,0x00,0x81,0xfa,0x49,0x00,0x72,0xfa,0x49,0x00,0x63,0xfa,0x4a,0x00,0x54,0xfa,0x4a,0x00,0x45,0xfa,0x4b,0x00,0x36,0xfa,0x4b,0x00,0x26,0xfa,0x4c,0x00,0x17,0xfa,0x4c,0x00,0x07,0xfa,0x4d,0x00,0xf8,0xf9,0x4e,0x00,0xe8,0xf9,0x4e,0x00,0xd8,0xf9,0x4f,0x00,0xc8,0xf9,0x4f,0x00,0xb8,0xf9,0x50,0x00,0xa8,0xf9,  \
    0x50,0x00,0x98,0xf9,0x51,0x00,0x88,0xf9,0x52,0x00,0x78,0xf9,0x52,0x00,0x67,0xf9,0x53,0x00,0x57,0xf9,0x53,0x00,0x46,0xf9,0x54,0x00,0x35,0xf9,0x55,0x00,0x25,0xf9,0x55,0x00,0x14,0xf9,0x56,0x00,0x03,0xf9,0x56,0x00,0xf2,0xf8,0x57,0x00,0xe1,0xf8,0x58,0x00,0xd0,0xf8,0x58,0x00,0xbe,0xf8,0x59,0x00,0xad,0xf8,0x59,0x00,0x9b,0xf8,0x5a,0x00,0x8a,0xf8,0x5b,0x00,0x78,0xf8,0x5b,0x00,0x66,0xf8,0x5c,0x00,0x54,0xf8,0x5c,0x00,0x42,0xf8,0x5d,0x00,0x30,0xf8,0x5e,0x00,  \
    0x1e,0xf8,0x5e,0x00,0x0c,0xf8,0x5f,0x00,0xfa,0xf7,0x60,0x00,0xe7,0xf7,0x60,0x00,0xd5,0xf7,0x61,0x00,0xc2,0xf7,0x61,0x00,0xaf,0xf7,0x62,0x00,0x9c,0xf7,0x63,0x00,0x89,0xf7,0x63,0x00,0x76,0xf7,0x64,0x00,0x63,0xf7,0x64,0x00,0x50,0xf7,0x65,0x00,0x3c,0xf7,0x66,0x00,0x29,0xf7,0x66,0x00,0x15,0xf7,0x67,0x00,0x02,0xf7,0x68,0x00,0xee,0xf6,0x68,0x00,0xda,0xf6,0x69,0x00,0xc6,0xf6,0x69,0x00,0xb2,0xf6,0x6a,0x00,0x9e,0xf6,0x6b,0x00,0x89,0xf6,0x6b,0x00,0x75,0xf6,  \
    0x6c,0x00,0x60,0xf6,0x6c,0x00,0x4c,0xf6,0x6d,0x00,0x37,0xf6,0x6e,0x00,0x22,0xf6,0x6e,0x00,0x0d,0xf6,0x6f,0x00,0xf8,0xf5,0x6f,0x00,0xe3,0xf5,0x70,0x00,0xcd,0xf5,0x71,0x00,0xb8,0xf5,0x71,0x00,0xa2,0xf5,0x72,0x00,0x8d,0xf5,0x72,0x00,0x77,0xf5,0x73,0x00,0x61,0xf5,0x73,0x00,0x4b,0xf5,0x74,0x00,0x35,0xf5,0x75,0x00,0x1f,0xf5,0x75,0x00,0x08,0xf5,0x76,0x00,0xf2,0xf4,0x76,0x00,0xdb,0xf4,0x77,0x00,0xc5,0xf4,0x77,0x00,0xae,0xf4,0x78,0x00,0x97,0xf4,0x79,0x00,  \
    0x80,0xf4,0x79,0x00,0x69,0xf4,0x7a,0x00,0x51,0xf4,0x7a,0x00,0x3a,0xf4,0x7b,0x00,0x22,0xf4,0x7b,0x00,0x0b,0xf4,0x7c,0x00,0xf3,0xf3,0x7c,0x00,0xdb,0xf3,0x7d,0x00,0xc3,0xf3,0x7d,0x00,0xab,0xf3,0x7e,0x00,0x93,0xf3,0x7e,0x00,0x7a,0xf3,0x7f,0x00,0x62,0xf3,0x7f,0x00,0x49,0xf3,0x80,0x00,0x30,0xf3,0x80,0x00,0x18,0xf3,0x81,0x00,0xff,0xf2,0x81,0x00,0xe5,0xf2,0x82,0x00,0xcc,0xf2,0x82,0x00,0xb3,0xf2,0x82,0x00,0x99,0xf2,0x83,0x00,0x80,0xf2,0x83,0x00,0x66,0xf2,  \
    0x84,0x00,0x4c,0xf2,0x84,0x00,0x32,0xf2,0x85,0x00,0x18,0xf2,0x85,0x00,0xfe,0xf1,0x85,0x00,0xe4,0xf1,0x86,0x00,0xc9,0xf1,0x86,0x00,0xaf,0xf1,0x87,0x00,0x94,0xf1,0x87,0x00,0x79,0xf1,0x87,0x00,0x5e,0xf1,0x88,0x00,0x43,0xf1,0x88,0x00,0x28,0xf1,0x88,0x00,0x0c,0xf1,0x89,0x00,0xf1,0xf0,0x89,0x00,0xd5,0xf0,0x89,0x00,0xb9,0xf0,0x8a,0x00,0x9d,0xf0,0x8a,0x00,0x81,0xf0,0x8a,0x00,0x65,0xf0,0x8a,0x00,0x49,0xf0,0x8b,0x00,0x2d,0xf0,0x8b,0x00,0x10,0xf0,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x82,0x00,0x00,0x10,0x82,0x00,0xe3,0x0f,0x82,0x00,0xc6,0x0f,0x82,0x00,0xaa,0x0f,0x81,0x00,0x8d,0x0f,0x81,0x00,0x71,0x0f,0x81,0x00,0x55,0x0f,0x81,0x00,0x39,0x0f,  \
    0x80,0x00,0x1d,0x0f,0x80,0x00,0x02,0x0f,0x80,0x00,0xe6,0x0e,0x80,0x00,0xca,0x0e,0x7f,0x00,0xaf,0x0e,0x7f,0x00,0x94,0x0e,0x7f,0x00,0x79,0x0e,0x7e,0x00,0x5e,0x0e,0x7e,0x00,0x43,0x0e,0x7e,0x00,0x28,0x0e,0x7d,0x00,0x0d,0x0e,0x7d,0x00,0xf3,0x0d,0x7d,0x00,0xd8,0x0d,0x7c,0x00,0xbe,0x0d,0x7c,0x00,0xa4,0x0d,0x7c,0x00,0x8a,0x0d,0x7b,0x00,0x70,0x0d,0x7b,0x00,0x56,0x0d,0x7b,0x00,0x3c,0x0d,0x7a,0x00,0x22,0x0d,0x7a,0x00,0x09,0x0d,0x7a,0x00,0xf0,0x0c,0x79,0x00,  \
    0xd6,0x0c,0x79,0x00,0xbd,0x0c,0x78,0x00,0xa4,0x0c,0x78,0x00,0x8b,0x0c,0x78,0x00,0x73,0x0c,0x77,0x00,0x5a,0x0c,0x77,0x00,0x41,0x0c,0x76,0x00,0x29,0x0c,0x76,0x00,0x11,0x0c,0x75,0x00,0xf8,0x0b,0x75,0x00,0xe0,0x0b,0x75,0x00,0xc8,0x0b,0x74,0x00,0xb0,0x0b,0x74,0x00,0x99,0x0b,0x73,0x00,0x81,0x0b,0x73,0x00,0x69,0x0b,0x72,0x00,0x52,0x0b,0x72,0x00,0x3b,0x0b,0x71,0x00,0x24,0x0b,0x71,0x00,0x0d,0x0b,0x71,0x00,0xf6,0x0a,0x70,0x00,0xdf,0x0a,0x70,0x00,0xc8,0x0a,  \
    0x6f,0x00,0xb1,0x0a,0x6f,0x00,0x9b,0x0a,0x6e,0x00,0x84,0x0a,0x6e,0x00,0x6e,0x0a,0x6d,0x00,0x58,0x0a,0x6d,0x00,0x42,0x0a,0x6c,0x00,0x2c,0x0a,0x6c,0x00,0x16,0x0a,0x6b,0x00,0x00,0x0a,0x6b,0x00,0xeb,0x09,0x6a,0x00,0xd5,0x09,0x6a,0x00,0xc0,0x09,0x69,0x00,0xab,0x09,0x69,0x00,0x95,0x09,0x68,0x00,0x80,0x09,0x68,0x00,0x6b,0x09,0x67,0x00,0x56,0x09,0x67,0x00,0x42,0x09,0x66,0x00,0x2d,0x09,0x66,0x00,0x18,0x09,0x65,0x00,0x04,0x09,0x65,0x00,0xf0,0x08,0x64,0x00,  \
    0xdb,0x08,0x64,0x00,0xc7,0x08,0x63,0x00,0xb3,0x08,0x63,0x00,0x9f,0x08,0x62,0x00,0x8b,0x08,0x62,0x00,0x78,0x08,0x61,0x00,0x64,0x08,0x61,0x00,0x50,0x08,0x60,0x00,0x3d,0x08,0x5f,0x00,0x2a,0x08,0x5f,0x00,0x17,0x08,0x5e,0x00,0x03,0x08,0x5e,0x00,0xf0,0x07,0x5d,0x00,0xdd,0x07,0x5d,0x00,0xcb,0x07,0x5c,0x00,0xb8,0x07,0x5c,0x00,0xa5,0x07,0x5b,0x00,0x93,0x07,0x5b,0x00,0x80,0x07,0x5a,0x00,0x6e,0x07,0x5a,0x00,0x5c,0x07,0x59,0x00,0x4a,0x07,0x59,0x00,0x38,0x07,  \
    0x58,0x00,0x26,0x07,0x58,0x00,0x14,0x07,0x57,0x00,0x02,0x07,0x57,0x00,0xf0,0x06,0x56,0x00,0xdf,0x06,0x56,0x00,0xcd,0x06,0x55,0x00,0xbc,0x06,0x55,0x00,0xab,0x06,0x54,0x00,0x99,0x06,0x54,0x00,0x88,0x06,0x53,0x00,0x77,0x06,0x53,0x00,0x66,0x06,0x52,0x00,0x55,0x06,0x52,0x00,0x45,0x06,0x51,0x00,0x34,0x06,0x51,0x00,0x23,0x06,0x50,0x00,0x13,0x06,0x50,0x00,0x02,0x06,0x4f,0x00,0xf2,0x05,0x4f,0x00,0xe2,0x05,0x4e,0x00,0xd2,0x05,0x4e,0x00,0xc2,0x05,0x4d,0x00,  \
    0xb2,0x05,0x4d,0x00,0xa2,0x05,0x4c,0x00,0x92,0x05,0x4c,0x00,0x82,0x05,0x4b,0x00,0x72,0x05,0x4b,0x00,0x63,0x05,0x4a,0x00,0x53,0x05,0x4a,0x00,0x44,0x05,0x4a,0x00,0x35,0x05,0x49,0x00,0x25,0x05,0x49,0x00,0x16,0x05,0x48,0x00,0x07,0x05,0x48,0x00,0xf8,0x04,0x47,0x00,0xe9,0x04,0x47,0x00,0xda,0x04,0x46,0x00,0xcb,0x04,0x46,0x00,0xbd,0x04,0x45,0x00,0xae,0x04,0x45,0x00,0x9f,0x04,0x45,0x00,0x91,0x04,0x44,0x00,0x82,0x04,0x44,0x00,0x74,0x04,0x43,0x00,0x66,0x04,  \
    0x43,0x00,0x57,0x04,0x42,0x00,0x49,0x04,0x42,0x00,0x3b,0x04,0x42,0x00,0x2d,0x04,0x41,0x00,0x1f,0x04,0x41,0x00,0x11,0x04,0x40,0x00,0x03,0x04,0x40,0x00,0xf6,0x03,0x40,0x00,0xe8,0x03,0x3f,0x00,0xda,0x03,0x3f,0x00,0xcd,0x03,0x3e,0x00,0xbf,0x03,0x3e,0x00,0xb2,0x03,0x3e,0x00,0xa5,0x03,0x3d,0x00,0x97,0x03,0x3d,0x00,0x8a,0x03,0x3d,0x00,0x7d,0x03,0x3c,0x00,0x70,0x03,0x3c,0x00,0x63,0x03,0x3b,0x00,0x56,0x03,0x3b,0x00,0x49,0x03,0x3b,0x00,0x3c,0x03,0x3a,0x00,  \
    0x2f,0x03,0x3a,0x00,0x22,0x03,0x3a,0x00,0x15,0x03,0x39,0x00,0x09,0x03,0x39,0x00,0xfc,0x02,0x39,0x00,0xef,0x02,0x38,0x00,0xe3,0x02,0x38,0x00,0xd6,0x02,0x38,0x00,0xca,0x02,0x37,0x00,0xbe,0x02,0x37,0x00,0xb1,0x02,0x37,0x00,0xa5,0x02,0x36,0x00,0x99,0x02,0x36,0x00,0x8d,0x02,0x36,0x00,0x81,0x02,0x36,0x00,0x75,0x02,0x35,0x00,0x69,0x02,0x35,0x00,0x5d,0x02,0x35,0x00,0x51,0x02,0x35,0x00,0x45,0x02,0x34,0x00,0x39,0x02,0x34,0x00,0x2d,0x02,0x34,0x00,0x21,0x02,  \
    0x33,0x00,0x16,0x02,0x33,0x00,0x0a,0x02,0x33,0x00,0xfe,0x01,0x33,0x00,0xf3,0x01,0x32,0x00,0xe7,0x01,0x32,0x00,0xdb,0x01,0x32,0x00,0xd0,0x01,0x32,0x00,0xc5,0x01,0x32,0x00,0xb9,0x01,0x31,0x00,0xae,0x01,0x31,0x00,0xa2,0x01,0x31,0x00,0x97,0x01,0x31,0x00,0x8c,0x01,0x31,0x00,0x80,0x01,0x30,0x00,0x75,0x01,0x30,0x00,0x6a,0x01,0x30,0x00,0x5f,0x01,0x30,0x00,0x54,0x01,0x30,0x00,0x49,0x01,0x2f,0x00,0x3e,0x01,0x2f,0x00,0x32,0x01,0x2f,0x00,0x27,0x01,0x2f,0x00,  \
    0x1c,0x01,0x2f,0x00,0x11,0x01,0x2f,0x00,0x07,0x01,0x2f,0x00,0xfc,0x00,0x2e,0x00,0xf1,0x00,0x2e,0x00,0xe6,0x00,0x2e,0x00,0xdb,0x00,0x2e,0x00,0xd0,0x00,0x2e,0x00,0xc5,0x00,0x2e,0x00,0xba,0x00,0x2e,0x00,0xb0,0x00,0x2e,0x00,0xa5,0x00,0x2d,0x00,0x9a,0x00,0x2d,0x00,0x8f,0x00,0x2d,0x00,0x85,0x00,0x2d,0x00,0x7a,0x00,0x2d,0x00,0x6f,0x00,0x2d,0x00,0x65,0x00,0x2d,0x00,0x5a,0x00,0x2d,0x00,0x4f,0x00,0x2d,0x00,0x45,0x00,0x2d,0x00,0x3a,0x00,0x2d,0x00,0x2f,0x00,  \
    0x2d,0x00,0x25,0x00,0x2d,0x00,0x1a,0x00,0x2d,0x00,0x0f,0x00,0x2d,0x00,0x05,0x00,0x2d,0x00,0xfa,0xff,0x2c,0x00,0xf0,0xff,0x2c,0x00,0xe5,0xff,0x2c,0x00,0xda,0xff,0x2c,0x00,0xd0,0xff,0x2c,0x00,0xc5,0xff,0x2c,0x00,0xbb,0xff,0x2c,0x00,0xb0,0xff,0x2c,0x00,0xa6,0xff,0x2c,0x00,0x9b,0xff,0x2d,0x00,0x90,0xff,0x2d,0x00,0x86,0xff,0x2d,0x00,0x7b,0xff,0x2d,0x00,0x71,0xff,0x2d,0x00,0x66,0xff,0x2d,0x00,0x5b,0xff,0x2d,0x00,0x51,0xff,0x2d,0x00,0x46,0xff,0x2d,0x00,  \
    0x3c,0xff,0x2d,0x00,0x31,0xff,0x2d,0x00,0x26,0xff,0x2d,0x00,0x1c,0xff,0x2d,0x00,0x11,0xff,0x2d,0x00,0x06,0xff,0x2d,0x00,0xfc,0xfe,0x2d,0x00,0xf1,0xfe,0x2d,0x00,0xe6,0xfe,0x2e,0x00,0xdc,0xfe,0x2e,0x00,0xd1,0xfe,0x2e,0x00,0xc6,0xfe,0x2e,0x00,0xbb,0xfe,0x2e,0x00,0xb1,0xfe,0x2e,0x00,0xa6,0xfe,0x2e,0x00,0x9b,0xfe,0x2e,0x00,0x90,0xfe,0x2f,0x00,0x85,0xfe,0x2f,0x00,0x7a,0xfe,0x2f,0x00,0x6f,0xfe,0x2f,0x00,0x65,0xfe,0x2f,0x00,0x5a,0xfe,0x2f,0x00,0x4f,0xfe,  \
    0x2f,0x00,0x44,0xfe,0x30,0x00,0x39,0xfe,0x30,0x00,0x2e,0xfe,0x30,0x00,0x22,0xfe,0x30,0x00,0x17,0xfe,0x30,0x00,0x0c,0xfe,0x31,0x00,0x01,0xfe,0x31,0x00,0xf6,0xfd,0x31,0x00,0xeb,0xfd,0x31,0x00,0xdf,0xfd,0x31,0x00,0xd4,0xfd,0x32,0x00,0xc9,0xfd,0x32,0x00,0xbd,0xfd,0x32,0x00,0xb2,0xfd,0x32,0x00,0xa7,0xfd,0x33,0x00,0x9b,0xfd,0x33,0x00,0x90,0xfd,0x33,0x00,0x84,0xfd,0x33,0x00,0x79,0xfd,0x34,0x00,0x6d,0xfd,0x34,0x00,0x61,0xfd,0x34,0x00,0x56,0xfd,0x34,0x00,  \
    0x4a,0xfd,0x35,0x00,0x3e,0xfd,0x35,0x00,0x32,0xfd,0x35,0x00,0x27,0xfd,0x35,0x00,0x1b,0xfd,0x36,0x00,0x0f,0xfd,0x36,0x00,0x03,0xfd,0x36,0x00,0xf7,0xfc,0x37,0x00,0xeb,0xfc,0x37,0x00,0xdf,0xfc,0x37,0x00,0xd2,0xfc,0x38,0x00,0xc6,0xfc,0x38,0x00,0xba,0xfc,0x38,0x00,0xae,0xfc,0x38,0x00,0xa1,0xfc,0x39,0x00,0x95,0xfc,0x39,0x00,0x88,0xfc,0x39,0x00,0x7c,0xfc,0x3a,0x00,0x6f,0xfc,0x3a,0x00,0x63,0xfc,0x3a,0x00,0x56,0xfc,0x3b,0x00,0x49,0xfc,0x3b,0x00,0x3d,0xfc,  \
    0x3c,0x00,0x30,0xfc,0x3c,0x00,0x23,0xfc,0x3c,0x00,0x16,0xfc,0x3d,0x00,0x09,0xfc,0x3d,0x00,0xfc,0xfb,0x3d,0x00,0xef,0xfb,0x3e,0x00,0xe2,0xfb,0x3e,0x00,0xd4,0xfb,0x3f,0x00,0xc7,0xfb,0x3f,0x00,0xba,0xfb,0x3f,0x00,0xac,0xfb,0x40,0x00,0x9f,0xfb,0x40,0x00,0x91,0xfb,0x41,0x00,0x83,0xfb,0x41,0x00,0x76,0xfb,0x41,0x00,0x68,0xfb,0x42,0x00,0x5a,0xfb,0x42,0x00,0x4c,0xfb,0x43,0x00,0x3e,0xfb,0x43,0x00,0x30,0xfb,0x43,0x00,0x22,0xfb,0x44,0x00,0x14,0xfb,0x44,0x00,  \
    0x06,0xfb,0x45,0x00,0xf7,0xfa,0x45,0x00,0xe9,0xfa,0x46,0x00,0xdb,0xfa,0x46,0x00,0xcc,0xfa,0x47,0x00,0xbd,0xfa,0x47,0x00,0xaf,0xfa,0x47,0x00,0xa0,0xfa,0x48,0x00,0x91,0xfa,0x48,0x00,0x82,0xfa,0x49,0x00,0x73,0xfa,0x49,0x00,0x64,0xfa,0x4a,0x00,0x55,0xfa,0x4a,0x00,0x46,0xfa,0x4b,0x00,0x36,0xfa,0x4b,0x00,0x27,0xfa,0x4c,0x00,0x18,0xfa,0x4c,0x00,0x08,0xfa,0x4d,0x00,0xf8,0xf9,0x4d,0x00,0xe9,0xf9,0x4e,0x00,0xd9,0xf9,0x4e,0x00,0xc9,0xf9,0x4f,0x00,0xb9,0xf9,  \
    0x4f,0x00,0xa9,0xf9,0x50,0x00,0x99,0xf9,0x50,0x00,0x89,0xf9,0x51,0x00,0x78,0xf9,0x51,0x00,0x68,0xf9,0x52,0x00,0x57,0xf9,0x52,0x00,0x47,0xf9,0x53,0x00,0x36,0xf9,0x53,0x00,0x25,0xf9,0x54,0x00,0x15,0xf9,0x54,0x00,0x04,0xf9,0x55,0x00,0xf3,0xf8,0x55,0x00,0xe2,0xf8,0x56,0x00,0xd0,0xf8,0x56,0x00,0xbf,0xf8,0x57,0x00,0xae,0xf8,0x57,0x00,0x9c,0xf8,0x58,0x00,0x8b,0xf8,0x58,0x00,0x79,0xf8,0x59,0x00,0x67,0xf8,0x59,0x00,0x55,0xf8,0x5a,0x00,0x43,0xf8,0x5a,0x00,  \
    0x31,0xf8,0x5b,0x00,0x1f,0xf8,0x5b,0x00,0x0d,0xf8,0x5c,0x00,0xfa,0xf7,0x5c,0x00,0xe8,0xf7,0x5d,0x00,0xd5,0xf7,0x5d,0x00,0xc3,0xf7,0x5e,0x00,0xb0,0xf7,0x5e,0x00,0x9d,0xf7,0x5f,0x00,0x8a,0xf7,0x5f,0x00,0x77,0xf7,0x60,0x00,0x64,0xf7,0x60,0x00,0x51,0xf7,0x61,0x00,0x3d,0xf7,0x62,0x00,0x2a,0xf7,0x62,0x00,0x16,0xf7,0x63,0x00,0x02,0xf7,0x63,0x00,0xef,0xf6,0x64,0x00,0xdb,0xf6,0x64,0x00,0xc7,0xf6,0x65,0x00,0xb3,0xf6,0x65,0x00,0x9e,0xf6,0x66,0x00,0x8a,0xf6,  \
    0x66,0x00,0x76,0xf6,0x67,0x00,0x61,0xf6,0x67,0x00,0x4c,0xf6,0x68,0x00,0x38,0xf6,0x68,0x00,0x23,0xf6,0x69,0x00,0x0e,0xf6,0x69,0x00,0xf9,0xf5,0x6a,0x00,0xe3,0xf5,0x6a,0x00,0xce,0xf5,0x6b,0x00,0xb9,0xf5,0x6b,0x00,0xa3,0xf5,0x6c,0x00,0x8d,0xf5,0x6c,0x00,0x78,0xf5,0x6d,0x00,0x62,0xf5,0x6d,0x00,0x4c,0xf5,0x6e,0x00,0x36,0xf5,0x6e,0x00,0x1f,0xf5,0x6f,0x00,0x09,0xf5,0x6f,0x00,0xf3,0xf4,0x70,0x00,0xdc,0xf4,0x70,0x00,0xc5,0xf4,0x71,0x00,0xae,0xf4,0x71,0x00,  \
    0x97,0xf4,0x71,0x00,0x80,0xf4,0x72,0x00,0x69,0xf4,0x72,0x00,0x52,0xf4,0x73,0x00,0x3b,0xf4,0x73,0x00,0x23,0xf4,0x74,0x00,0x0b,0xf4,0x74,0x00,0xf4,0xf3,0x75,0x00,0xdc,0xf3,0x75,0x00,0xc4,0xf3,0x75,0x00,0xac,0xf3,0x76,0x00,0x93,0xf3,0x76,0x00,0x7b,0xf3,0x77,0x00,0x62,0xf3,0x77,0x00,0x4a,0xf3,0x78,0x00,0x31,0xf3,0x78,0x00,0x18,0xf3,0x78,0x00,0xff,0xf2,0x79,0x00,0xe6,0xf2,0x79,0x00,0xcd,0xf2,0x79,0x00,0xb4,0xf2,0x7a,0x00,0x9a,0xf2,0x7a,0x00,0x80,0xf2,  \
    0x7b,0x00,0x67,0xf2,0x7b,0x00,0x4d,0xf2,0x7b,0x00,0x33,0xf2,0x7c,0x00,0x19,0xf2,0x7c,0x00,0xff,0xf1,0x7c,0x00,0xe4,0xf1,0x7d,0x00,0xca,0xf1,0x7d,0x00,0xaf,0xf1,0x7d,0x00,0x94,0xf1,0x7e,0x00,0x7a,0xf1,0x7e,0x00,0x5f,0xf1,0x7e,0x00,0x43,0xf1,0x7e,0x00,0x28,0xf1,0x7f,0x00,0x0d,0xf1,0x7f,0x00,0xf1,0xf0,0x7f,0x00,0xd6,0xf0,0x80,0x00,0xba,0xf0,0x80,0x00,0x9e,0xf0,0x80,0x00,0x82,0xf0,0x80,0x00,0x66,0xf0,0x81,0x00,0x4a,0xf0,0x81,0x00,0x2d,0xf0,0x81,0x00,  \
    0x11,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x78,0x00,0xff,0x0f,0x78,0x00,0xe2,0x0f,0x78,0x00,0xc6,0x0f,0x78,0x00,0xa9,0x0f,0x77,0x00,0x8d,0x0f,0x77,0x00,0x71,0x0f,0x77,0x00,0x55,0x0f,  \
    0x77,0x00,0x39,0x0f,0x77,0x00,0x1d,0x0f,0x76,0x00,0x01,0x0f,0x76,0x00,0xe5,0x0e,0x76,0x00,0xca,0x0e,0x76,0x00,0xaf,0x0e,0x75,0x00,0x93,0x0e,0x75,0x00,0x78,0x0e,0x75,0x00,0x5d,0x0e,0x75,0x00,0x42,0x0e,0x74,0x00,0x27,0x0e,0x74,0x00,0x0d,0x0e,0x74,0x00,0xf2,0x0d,0x74,0x00,0xd8,0x0d,0x73,0x00,0xbd,0x0d,0x73,0x00,0xa3,0x0d,0x73,0x00,0x89,0x0d,0x72,0x00,0x6f,0x0d,0x72,0x00,0x55,0x0d,0x72,0x00,0x3c,0x0d,0x72,0x00,0x22,0x0d,0x71,0x00,0x08,0x0d,0x71,0x00,  \
    0xef,0x0c,0x71,0x00,0xd6,0x0c,0x70,0x00,0xbd,0x0c,0x70,0x00,0xa4,0x0c,0x70,0x00,0x8b,0x0c,0x6f,0x00,0x72,0x0c,0x6f,0x00,0x59,0x0c,0x6f,0x00,0x41,0x0c,0x6e,0x00,0x28,0x0c,0x6e,0x00,0x10,0x0c,0x6e,0x00,0xf8,0x0b,0x6d,0x00,0xe0,0x0b,0x6d,0x00,0xc8,0x0b,0x6d,0x00,0xb0,0x0b,0x6c,0x00,0x98,0x0b,0x6c,0x00,0x80,0x0b,0x6b,0x00,0x69,0x0b,0x6b,0x00,0x51,0x0b,0x6b,0x00,0x3a,0x0b,0x6a,0x00,0x23,0x0b,0x6a,0x00,0x0c,0x0b,0x6a,0x00,0xf5,0x0a,0x69,0x00,0xde,0x0a,  \
    0x69,0x00,0xc7,0x0a,0x68,0x00,0xb1,0x0a,0x68,0x00,0x9a,0x0a,0x68,0x00,0x84,0x0a,0x67,0x00,0x6e,0x0a,0x67,0x00,0x57,0x0a,0x66,0x00,0x41,0x0a,0x66,0x00,0x2b,0x0a,0x66,0x00,0x16,0x0a,0x65,0x00,0x00,0x0a,0x65,0x00,0xea,0x09,0x64,0x00,0xd5,0x09,0x64,0x00,0xbf,0x09,0x64,0x00,0xaa,0x09,0x63,0x00,0x95,0x09,0x63,0x00,0x80,0x09,0x62,0x00,0x6b,0x09,0x62,0x00,0x56,0x09,0x62,0x00,0x41,0x09,0x61,0x00,0x2c,0x09,0x61,0x00,0x18,0x09,0x60,0x00,0x03,0x09,0x60,0x00,  \
    0xef,0x08,0x5f,0x00,0xdb,0x08,0x5f,0x00,0xc7,0x08,0x5f,0x00,0xb3,0x08,0x5e,0x00,0x9f,0x08,0x5e,0x00,0x8b,0x08,0x5d,0x00,0x77,0x08,0x5d,0x00,0x63,0x08,0x5c,0x00,0x50,0x08,0x5c,0x00,0x3c,0x08,0x5c,0x00,0x29,0x08,0x5b,0x00,0x16,0x08,0x5b,0x00,0x03,0x08,0x5a,0x00,0xf0,0x07,0x5a,0x00,0xdd,0x07,0x5a,0x00,0xca,0x07,0x59,0x00,0xb7,0x07,0x59,0x00,0xa5,0x07,0x58,0x00,0x92,0x07,0x58,0x00,0x80,0x07,0x57,0x00,0x6d,0x07,0x57,0x00,0x5b,0x07,0x57,0x00,0x49,0x07,  \
    0x56,0x00,0x37,0x07,0x56,0x00,0x25,0x07,0x55,0x00,0x13,0x07,0x55,0x00,0x01,0x07,0x54,0x00,0xf0,0x06,0x54,0x00,0xde,0x06,0x54,0x00,0xcd,0x06,0x53,0x00,0xbb,0x06,0x53,0x00,0xaa,0x06,0x52,0x00,0x99,0x06,0x52,0x00,0x88,0x06,0x52,0x00,0x77,0x06,0x51,0x00,0x66,0x06,0x51,0x00,0x55,0x06,0x50,0x00,0x44,0x06,0x50,0x00,0x33,0x06,0x50,0x00,0x23,0x06,0x4f,0x00,0x12,0x06,0x4f,0x00,0x02,0x06,0x4e,0x00,0xf1,0x05,0x4e,0x00,0xe1,0x05,0x4e,0x00,0xd1,0x05,0x4d,0x00,  \
    0xc1,0x05,0x4d,0x00,0xb1,0x05,0x4c,0x00,0xa1,0x05,0x4c,0x00,0x91,0x05,0x4c,0x00,0x81,0x05,0x4b,0x00,0x72,0x05,0x4b,0x00,0x62,0x05,0x4a,0x00,0x53,0x05,0x4a,0x00,0x43,0x05,0x4a,0x00,0x34,0x05,0x49,0x00,0x25,0x05,0x49,0x00,0x16,0x05,0x49,0x00,0x06,0x05,0x48,0x00,0xf7,0x04,0x48,0x00,0xe8,0x04,0x47,0x00,0xda,0x04,0x47,0x00,0xcb,0x04,0x47,0x00,0xbc,0x04,0x46,0x00,0xad,0x04,0x46,0x00,0x9f,0x04,0x46,0x00,0x90,0x04,0x45,0x00,0x82,0x04,0x45,0x00,0x73,0x04,  \
    0x45,0x00,0x65,0x04,0x44,0x00,0x57,0x04,0x44,0x00,0x49,0x04,0x44,0x00,0x3b,0x04,0x43,0x00,0x2d,0x04,0x43,0x00,0x1f,0x04,0x42,0x00,0x11,0x04,0x42,0x00,0x03,0x04,0x42,0x00,0xf5,0x03,0x42,0x00,0xe7,0x03,0x41,0x00,0xda,0x03,0x41,0x00,0xcc,0x03,0x41,0x00,0xbf,0x03,0x40,0x00,0xb1,0x03,0x40,0x00,0xa4,0x03,0x40,0x00,0x97,0x03,0x3f,0x00,0x89,0x03,0x3f,0x00,0x7c,0x03,0x3f,0x00,0x6f,0x03,0x3e,0x00,0x62,0x03,0x3e,0x00,0x55,0x03,0x3e,0x00,0x48,0x03,0x3e,0x00,  \
    0x3b,0x03,0x3d,0x00,0x2e,0x03,0x3d,0x00,0x22,0x03,0x3d,0x00,0x15,0x03,0x3c,0x00,0x08,0x03,0x3c,0x00,0xfc,0x02,0x3c,0x00,0xef,0x02,0x3c,0x00,0xe2,0x02,0x3b,0x00,0xd6,0x02,0x3b,0x00,0xca,0x02,0x3b,0x00,0xbd,0x02,0x3b,0x00,0xb1,0x02,0x3a,0x00,0xa5,0x02,0x3a,0x00,0x98,0x02,0x3a,0x00,0x8c,0x02,0x3a,0x00,0x80,0x02,0x39,0x00,0x74,0x02,0x39,0x00,0x68,0x02,0x39,0x00,0x5c,0x02,0x39,0x00,0x50,0x02,0x38,0x00,0x44,0x02,0x38,0x00,0x38,0x02,0x38,0x00,0x2d,0x02,  \
    0x38,0x00,0x21,0x02,0x38,0x00,0x15,0x02,0x37,0x00,0x09,0x02,0x37,0x00,0xfe,0x01,0x37,0x00,0xf2,0x01,0x37,0x00,0xe7,0x01,0x37,0x00,0xdb,0x01,0x36,0x00,0xd0,0x01,0x36,0x00,0xc4,0x01,0x36,0x00,0xb9,0x01,0x36,0x00,0xad,0x01,0x36,0x00,0xa2,0x01,0x36,0x00,0x97,0x01,0x35,0x00,0x8b,0x01,0x35,0x00,0x80,0x01,0x35,0x00,0x75,0x01,0x35,0x00,0x6a,0x01,0x35,0x00,0x5f,0x01,0x35,0x00,0x53,0x01,0x34,0x00,0x48,0x01,0x34,0x00,0x3d,0x01,0x34,0x00,0x32,0x01,0x34,0x00,  \
    0x27,0x01,0x34,0x00,0x1c,0x01,0x34,0x00,0x11,0x01,0x34,0x00,0x06,0x01,0x34,0x00,0xfb,0x00,0x33,0x00,0xf0,0x00,0x33,0x00,0xe6,0x00,0x33,0x00,0xdb,0x00,0x33,0x00,0xd0,0x00,0x33,0x00,0xc5,0x00,0x33,0x00,0xba,0x00,0x33,0x00,0xaf,0x00,0x33,0x00,0xa5,0x00,0x33,0x00,0x9a,0x00,0x33,0x00,0x8f,0x00,0x32,0x00,0x84,0x00,0x32,0x00,0x7a,0x00,0x32,0x00,0x6f,0x00,0x32,0x00,0x64,0x00,0x32,0x00,0x5a,0x00,0x32,0x00,0x4f,0x00,0x32,0x00,0x44,0x00,0x32,0x00,0x3a,0x00,  \
    0x32,0x00,0x2f,0x00,0x32,0x00,0x25,0x00,0x32,0x00,0x1a,0x00,0x32,0x00,0x0f,0x00,0x32,0x00,0x05,0x00,0x32,0x00,0xfa,0xff,0x32,0x00,0xf0,0xff,0x32,0x00,0xe5,0xff,0x32,0x00,0xda,0xff,0x32,0x00,0xd0,0xff,0x32,0x00,0xc5,0xff,0x32,0x00,0xbb,0xff,0x32,0x00,0xb0,0xff,0x32,0x00,0xa6,0xff,0x32,0x00,0x9b,0xff,0x32,0x00,0x90,0xff,0x32,0x00,0x86,0xff,0x32,0x00,0x7b,0xff,0x32,0x00,0x71,0xff,0x32,0x00,0x66,0xff,0x32,0x00,0x5c,0xff,0x32,0x00,0x51,0xff,0x32,0x00,  \
    0x46,0xff,0x32,0x00,0x3c,0xff,0x32,0x00,0x31,0xff,0x32,0x00,0x26,0xff,0x32,0x00,0x1c,0xff,0x32,0x00,0x11,0xff,0x32,0x00,0x07,0xff,0x33,0x00,0xfc,0xfe,0x33,0x00,0xf1,0xfe,0x33,0x00,0xe6,0xfe,0x33,0x00,0xdc,0xfe,0x33,0x00,0xd1,0xfe,0x33,0x00,0xc6,0xfe,0x33,0x00,0xbc,0xfe,0x33,0x00,0xb1,0xfe,0x33,0x00,0xa6,0xfe,0x33,0x00,0x9b,0xfe,0x33,0x00,0x90,0xfe,0x34,0x00,0x85,0xfe,0x34,0x00,0x7b,0xfe,0x34,0x00,0x70,0xfe,0x34,0x00,0x65,0xfe,0x34,0x00,0x5a,0xfe,  \
    0x34,0x00,0x4f,0xfe,0x34,0x00,0x44,0xfe,0x34,0x00,0x39,0xfe,0x35,0x00,0x2e,0xfe,0x35,0x00,0x23,0xfe,0x35,0x00,0x18,0xfe,0x35,0x00,0x0d,0xfe,0x35,0x00,0x01,0xfe,0x35,0x00,0xf6,0xfd,0x36,0x00,0xeb,0xfd,0x36,0x00,0xe0,0xfd,0x36,0x00,0xd4,0xfd,0x36,0x00,0xc9,0xfd,0x36,0x00,0xbe,0xfd,0x36,0x00,0xb2,0xfd,0x37,0x00,0xa7,0xfd,0x37,0x00,0x9c,0xfd,0x37,0x00,0x90,0xfd,0x37,0x00,0x85,0xfd,0x37,0x00,0x79,0xfd,0x38,0x00,0x6d,0xfd,0x38,0x00,0x62,0xfd,0x38,0x00,  \
    0x56,0xfd,0x38,0x00,0x4a,0xfd,0x39,0x00,0x3f,0xfd,0x39,0x00,0x33,0xfd,0x39,0x00,0x27,0xfd,0x39,0x00,0x1b,0xfd,0x39,0x00,0x0f,0xfd,0x3a,0x00,0x03,0xfd,0x3a,0x00,0xf7,0xfc,0x3a,0x00,0xeb,0xfc,0x3a,0x00,0xdf,0xfc,0x3b,0x00,0xd3,0xfc,0x3b,0x00,0xc7,0xfc,0x3b,0x00,0xbb,0xfc,0x3b,0x00,0xae,0xfc,0x3c,0x00,0xa2,0xfc,0x3c,0x00,0x95,0xfc,0x3c,0x00,0x89,0xfc,0x3d,0x00,0x7d,0xfc,0x3d,0x00,0x70,0xfc,0x3d,0x00,0x63,0xfc,0x3d,0x00,0x57,0xfc,0x3e,0x00,0x4a,0xfc,  \
    0x3e,0x00,0x3d,0xfc,0x3e,0x00,0x30,0xfc,0x3f,0x00,0x23,0xfc,0x3f,0x00,0x17,0xfc,0x3f,0x00,0x09,0xfc,0x3f,0x00,0xfc,0xfb,0x40,0x00,0xef,0xfb,0x40,0x00,0xe2,0xfb,0x40,0x00,0xd5,0xfb,0x41,0x00,0xc8,0xfb,0x41,0x00,0xba,0xfb,0x41,0x00,0xad,0xfb,0x42,0x00,0x9f,0xfb,0x42,0x00,0x92,0xfb,0x42,0x00,0x84,0xfb,0x43,0x00,0x76,0xfb,0x43,0x00,0x69,0xfb,0x43,0x00,0x5b,0xfb,0x44,0x00,0x4d,0xfb,0x44,0x00,0x3f,0xfb,0x44,0x00,0x31,0xfb,0x45,0x00,0x23,0xfb,0x45,0x00,  \
    0x15,0xfb,0x45,0x00,0x06,0xfb,0x46,0x00,0xf8,0xfa,0x46,0x00,0xea,0xfa,0x47,0x00,0xdb,0xfa,0x47,0x00,0xcd,0xfa,0x47,0x00,0xbe,0xfa,0x48,0x00,0xaf,0xfa,0x48,0x00,0xa1,0xfa,0x48,0x00,0x92,0xfa,0x49,0x00,0x83,0xfa,0x49,0x00,0x74,0xfa,0x49,0x00,0x65,0xfa,0x4a,0x00,0x56,0xfa,0x4a,0x00,0x46,0xfa,0x4b,0x00,0x37,0xfa,0x4b,0x00,0x28,0xfa,0x4b,0x00,0x18,0xfa,0x4c,0x00,0x09,0xfa,0x4c,0x00,0xf9,0xf9,0x4d,0x00,0xe9,0xf9,0x4d,0x00,0xda,0xf9,0x4d,0x00,0xca,0xf9,  \
    0x4e,0x00,0xba,0xf9,0x4e,0x00,0xaa,0xf9,0x4f,0x00,0x9a,0xf9,0x4f,0x00,0x89,0xf9,0x4f,0x00,0x79,0xf9,0x50,0x00,0x69,0xf9,0x50,0x00,0x58,0xf9,0x51,0x00,0x48,0xf9,0x51,0x00,0x37,0xf9,0x51,0x00,0x26,0xf9,0x52,0x00,0x15,0xf9,0x52,0x00,0x04,0xf9,0x53,0x00,0xf3,0xf8,0x53,0x00,0xe2,0xf8,0x54,0x00,0xd1,0xf8,0x54,0x00,0xc0,0xf8,0x54,0x00,0xae,0xf8,0x55,0x00,0x9d,0xf8,0x55,0x00,0x8b,0xf8,0x56,0x00,0x7a,0xf8,0x56,0x00,0x68,0xf8,0x57,0x00,0x56,0xf8,0x57,0x00,  \
    0x44,0xf8,0x57,0x00,0x32,0xf8,0x58,0x00,0x20,0xf8,0x58,0x00,0x0d,0xf8,0x59,0x00,0xfb,0xf7,0x59,0x00,0xe9,0xf7,0x59,0x00,0xd6,0xf7,0x5a,0x00,0xc3,0xf7,0x5a,0x00,0xb1,0xf7,0x5b,0x00,0x9e,0xf7,0x5b,0x00,0x8b,0xf7,0x5c,0x00,0x78,0xf7,0x5c,0x00,0x65,0xf7,0x5c,0x00,0x51,0xf7,0x5d,0x00,0x3e,0xf7,0x5d,0x00,0x2a,0xf7,0x5e,0x00,0x17,0xf7,0x5e,0x00,0x03,0xf7,0x5f,0x00,0xef,0xf6,0x5f,0x00,0xdb,0xf6,0x5f,0x00,0xc7,0xf6,0x60,0x00,0xb3,0xf6,0x60,0x00,0x9f,0xf6,  \
    0x61,0x00,0x8b,0xf6,0x61,0x00,0x76,0xf6,0x62,0x00,0x62,0xf6,0x62,0x00,0x4d,0xf6,0x62,0x00,0x38,0xf6,0x63,0x00,0x23,0xf6,0x63,0x00,0x0e,0xf6,0x64,0x00,0xf9,0xf5,0x64,0x00,0xe4,0xf5,0x64,0x00,0xcf,0xf5,0x65,0x00,0xb9,0xf5,0x65,0x00,0xa4,0xf5,0x66,0x00,0x8e,0xf5,0x66,0x00,0x78,0xf5,0x66,0x00,0x62,0xf5,0x67,0x00,0x4c,0xf5,0x67,0x00,0x36,0xf5,0x68,0x00,0x20,0xf5,0x68,0x00,0x0a,0xf5,0x68,0x00,0xf3,0xf4,0x69,0x00,0xdd,0xf4,0x69,0x00,0xc6,0xf4,0x6a,0x00,  \
    0xaf,0xf4,0x6a,0x00,0x98,0xf4,0x6a,0x00,0x81,0xf4,0x6b,0x00,0x6a,0xf4,0x6b,0x00,0x53,0xf4,0x6c,0x00,0x3b,0xf4,0x6c,0x00,0x24,0xf4,0x6c,0x00,0x0c,0xf4,0x6d,0x00,0xf4,0xf3,0x6d,0x00,0xdc,0xf3,0x6d,0x00,0xc4,0xf3,0x6e,0x00,0xac,0xf3,0x6e,0x00,0x94,0xf3,0x6e,0x00,0x7c,0xf3,0x6f,0x00,0x63,0xf3,0x6f,0x00,0x4a,0xf3,0x6f,0x00,0x32,0xf3,0x70,0x00,0x19,0xf3,0x70,0x00,0x00,0xf3,0x70,0x00,0xe7,0xf2,0x71,0x00,0xcd,0xf2,0x71,0x00,0xb4,0xf2,0x71,0x00,0x9b,0xf2,  \
    0x72,0x00,0x81,0xf2,0x72,0x00,0x67,0xf2,0x72,0x00,0x4d,0xf2,0x72,0x00,0x33,0xf2,0x73,0x00,0x19,0xf2,0x73,0x00,0xff,0xf1,0x73,0x00,0xe5,0xf1,0x74,0x00,0xca,0xf1,0x74,0x00,0xb0,0xf1,0x74,0x00,0x95,0xf1,0x74,0x00,0x7a,0xf1,0x75,0x00,0x5f,0xf1,0x75,0x00,0x44,0xf1,0x75,0x00,0x29,0xf1,0x75,0x00,0x0d,0xf1,0x76,0x00,0xf2,0xf0,0x76,0x00,0xd6,0xf0,0x76,0x00,0xbb,0xf0,0x76,0x00,0x9f,0xf0,0x76,0x00,0x83,0xf0,0x77,0x00,0x66,0xf0,0x77,0x00,0x4a,0xf0,0x77,0x00,  \
    0x2e,0xf0,0x77,0x00,0x11,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6e,0x00,0xff,0x0f,0x6e,0x00,0xe2,0x0f,0x6e,0x00,0xc5,0x0f,0x6e,0x00,0xa9,0x0f,0x6d,0x00,0x8d,0x0f,0x6d,0x00,0x70,0x0f,  \
    0x6d,0x00,0x54,0x0f,0x6d,0x00,0x38,0x0f,0x6d,0x00,0x1c,0x0f,0x6d,0x00,0x01,0x0f,0x6c,0x00,0xe5,0x0e,0x6c,0x00,0xca,0x0e,0x6c,0x00,0xae,0x0e,0x6c,0x00,0x93,0x0e,0x6c,0x00,0x78,0x0e,0x6c,0x00,0x5d,0x0e,0x6b,0x00,0x42,0x0e,0x6b,0x00,0x27,0x0e,0x6b,0x00,0x0c,0x0e,0x6b,0x00,0xf2,0x0d,0x6b,0x00,0xd7,0x0d,0x6a,0x00,0xbd,0x0d,0x6a,0x00,0xa3,0x0d,0x6a,0x00,0x89,0x0d,0x6a,0x00,0x6f,0x0d,0x69,0x00,0x55,0x0d,0x69,0x00,0x3b,0x0d,0x69,0x00,0x22,0x0d,0x69,0x00,  \
    0x08,0x0d,0x68,0x00,0xef,0x0c,0x68,0x00,0xd5,0x0c,0x68,0x00,0xbc,0x0c,0x68,0x00,0xa3,0x0c,0x67,0x00,0x8a,0x0c,0x67,0x00,0x72,0x0c,0x67,0x00,0x59,0x0c,0x67,0x00,0x40,0x0c,0x66,0x00,0x28,0x0c,0x66,0x00,0x10,0x0c,0x66,0x00,0xf7,0x0b,0x66,0x00,0xdf,0x0b,0x65,0x00,0xc7,0x0b,0x65,0x00,0xaf,0x0b,0x65,0x00,0x98,0x0b,0x64,0x00,0x80,0x0b,0x64,0x00,0x68,0x0b,0x64,0x00,0x51,0x0b,0x64,0x00,0x3a,0x0b,0x63,0x00,0x23,0x0b,0x63,0x00,0x0b,0x0b,0x63,0x00,0xf5,0x0a,  \
    0x62,0x00,0xde,0x0a,0x62,0x00,0xc7,0x0a,0x62,0x00,0xb0,0x0a,0x61,0x00,0x9a,0x0a,0x61,0x00,0x83,0x0a,0x61,0x00,0x6d,0x0a,0x61,0x00,0x57,0x0a,0x60,0x00,0x41,0x0a,0x60,0x00,0x2b,0x0a,0x60,0x00,0x15,0x0a,0x5f,0x00,0xff,0x09,0x5f,0x00,0xea,0x09,0x5f,0x00,0xd4,0x09,0x5e,0x00,0xbf,0x09,0x5e,0x00,0xa9,0x09,0x5e,0x00,0x94,0x09,0x5d,0x00,0x7f,0x09,0x5d,0x00,0x6a,0x09,0x5d,0x00,0x55,0x09,0x5c,0x00,0x40,0x09,0x5c,0x00,0x2c,0x09,0x5c,0x00,0x17,0x09,0x5b,0x00,  \
    0x03,0x09,0x5b,0x00,0xee,0x08,0x5b,0x00,0xda,0x08,0x5a,0x00,0xc6,0x08,0x5a,0x00,0xb2,0x08,0x5a,0x00,0x9e,0x08,0x59,0x00,0x8a,0x08,0x59,0x00,0x77,0x08,0x59,0x00,0x63,0x08,0x59,0x00,0x4f,0x08,0x58,0x00,0x3c,0x08,0x58,0x00,0x29,0x08,0x58,0x00,0x15,0x08,0x57,0x00,0x02,0x08,0x57,0x00,0xef,0x07,0x57,0x00,0xdc,0x07,0x56,0x00,0xca,0x07,0x56,0x00,0xb7,0x07,0x56,0x00,0xa4,0x07,0x55,0x00,0x92,0x07,0x55,0x00,0x7f,0x07,0x55,0x00,0x6d,0x07,0x54,0x00,0x5b,0x07,  \
    0x54,0x00,0x48,0x07,0x54,0x00,0x36,0x07,0x53,0x00,0x24,0x07,0x53,0x00,0x13,0x07,0x53,0x00,0x01,0x07,0x52,0x00,0xef,0x06,0x52,0x00,0xde,0x06,0x52,0x00,0xcc,0x06,0x51,0x00,0xbb,0x06,0x51,0x00,0xa9,0x06,0x51,0x00,0x98,0x06,0x50,0x00,0x87,0x06,0x50,0x00,0x76,0x06,0x50,0x00,0x65,0x06,0x4f,0x00,0x54,0x06,0x4f,0x00,0x43,0x06,0x4f,0x00,0x33,0x06,0x4e,0x00,0x22,0x06,0x4e,0x00,0x12,0x06,0x4e,0x00,0x01,0x06,0x4d,0x00,0xf1,0x05,0x4d,0x00,0xe1,0x05,0x4d,0x00,  \
    0xd1,0x05,0x4d,0x00,0xc0,0x05,0x4c,0x00,0xb0,0x05,0x4c,0x00,0xa1,0x05,0x4c,0x00,0x91,0x05,0x4b,0x00,0x81,0x05,0x4b,0x00,0x71,0x05,0x4b,0x00,0x62,0x05,0x4a,0x00,0x52,0x05,0x4a,0x00,0x43,0x05,0x4a,0x00,0x33,0x05,0x4a,0x00,0x24,0x05,0x49,0x00,0x15,0x05,0x49,0x00,0x06,0x05,0x49,0x00,0xf7,0x04,0x48,0x00,0xe8,0x04,0x48,0x00,0xd9,0x04,0x48,0x00,0xca,0x04,0x47,0x00,0xbb,0x04,0x47,0x00,0xad,0x04,0x47,0x00,0x9e,0x04,0x47,0x00,0x90,0x04,0x46,0x00,0x81,0x04,  \
    0x46,0x00,0x73,0x04,0x46,0x00,0x65,0x04,0x46,0x00,0x56,0x04,0x45,0x00,0x48,0x04,0x45,0x00,0x3a,0x04,0x45,0x00,0x2c,0x04,0x44,0x00,0x1e,0x04,0x44,0x00,0x10,0x04,0x44,0x00,0x02,0x04,0x44,0x00,0xf5,0x03,0x43,0x00,0xe7,0x03,0x43,0x00,0xd9,0x03,0x43,0x00,0xcc,0x03,0x43,0x00,0xbe,0x03,0x42,0x00,0xb1,0x03,0x42,0x00,0xa4,0x03,0x42,0x00,0x96,0x03,0x42,0x00,0x89,0x03,0x42,0x00,0x7c,0x03,0x41,0x00,0x6f,0x03,0x41,0x00,0x62,0x03,0x41,0x00,0x55,0x03,0x41,0x00,  \
    0x48,0x03,0x40,0x00,0x3b,0x03,0x40,0x00,0x2e,0x03,0x40,0x00,0x21,0x03,0x40,0x00,0x14,0x03,0x3f,0x00,0x08,0x03,0x3f,0x00,0xfb,0x02,0x3f,0x00,0xef,0x02,0x3f,0x00,0xe2,0x02,0x3f,0x00,0xd6,0x02,0x3e,0x00,0xc9,0x02,0x3e,0x00,0xbd,0x02,0x3e,0x00,0xb1,0x02,0x3e,0x00,0xa4,0x02,0x3e,0x00,0x98,0x02,0x3d,0x00,0x8c,0x02,0x3d,0x00,0x80,0x02,0x3d,0x00,0x74,0x02,0x3d,0x00,0x68,0x02,0x3d,0x00,0x5c,0x02,0x3d,0x00,0x50,0x02,0x3c,0x00,0x44,0x02,0x3c,0x00,0x38,0x02,  \
    0x3c,0x00,0x2c,0x02,0x3c,0x00,0x21,0x02,0x3c,0x00,0x15,0x02,0x3c,0x00,0x09,0x02,0x3b,0x00,0xfe,0x01,0x3b,0x00,0xf2,0x01,0x3b,0x00,0xe6,0x01,0x3b,0x00,0xdb,0x01,0x3b,0x00,0xcf,0x01,0x3b,0x00,0xc4,0x01,0x3a,0x00,0xb8,0x01,0x3a,0x00,0xad,0x01,0x3a,0x00,0xa2,0x01,0x3a,0x00,0x96,0x01,0x3a,0x00,0x8b,0x01,0x3a,0x00,0x80,0x01,0x3a,0x00,0x75,0x01,0x3a,0x00,0x6a,0x01,0x39,0x00,0x5e,0x01,0x39,0x00,0x53,0x01,0x39,0x00,0x48,0x01,0x39,0x00,0x3d,0x01,0x39,0x00,  \
    0x32,0x01,0x39,0x00,0x27,0x01,0x39,0x00,0x1c,0x01,0x39,0x00,0x11,0x01,0x39,0x00,0x06,0x01,0x39,0x00,0xfb,0x00,0x38,0x00,0xf0,0x00,0x38,0x00,0xe5,0x00,0x38,0x00,0xdb,0x00,0x38,0x00,0xd0,0x00,0x38,0x00,0xc5,0x00,0x38,0x00,0xba,0x00,0x38,0x00,0xaf,0x00,0x38,0x00,0xa5,0x00,0x38,0x00,0x9a,0x00,0x38,0x00,0x8f,0x00,0x38,0x00,0x84,0x00,0x38,0x00,0x7a,0x00,0x38,0x00,0x6f,0x00,0x38,0x00,0x64,0x00,0x38,0x00,0x5a,0x00,0x37,0x00,0x4f,0x00,0x37,0x00,0x44,0x00,  \
    0x37,0x00,0x3a,0x00,0x37,0x00,0x2f,0x00,0x37,0x00,0x24,0x00,0x37,0x00,0x1a,0x00,0x37,0x00,0x0f,0x00,0x37,0x00,0x05,0x00,0x37,0x00,0xfa,0xff,0x37,0x00,0xf0,0xff,0x37,0x00,0xe5,0xff,0x37,0x00,0xda,0xff,0x37,0x00,0xd0,0xff,0x37,0x00,0xc5,0xff,0x37,0x00,0xbb,0xff,0x37,0x00,0xb0,0xff,0x37,0x00,0xa6,0xff,0x37,0x00,0x9b,0xff,0x37,0x00,0x90,0xff,0x37,0x00,0x86,0xff,0x37,0x00,0x7b,0xff,0x37,0x00,0x71,0xff,0x37,0x00,0x66,0xff,0x37,0x00,0x5c,0xff,0x37,0x00,  \
    0x51,0xff,0x37,0x00,0x46,0xff,0x37,0x00,0x3c,0xff,0x38,0x00,0x31,0xff,0x38,0x00,0x27,0xff,0x38,0x00,0x1c,0xff,0x38,0x00,0x11,0xff,0x38,0x00,0x07,0xff,0x38,0x00,0xfc,0xfe,0x38,0x00,0xf1,0xfe,0x38,0x00,0xe7,0xfe,0x38,0x00,0xdc,0xfe,0x38,0x00,0xd1,0xfe,0x38,0x00,0xc6,0xfe,0x38,0x00,0xbc,0xfe,0x38,0x00,0xb1,0xfe,0x38,0x00,0xa6,0xfe,0x38,0x00,0x9b,0xfe,0x38,0x00,0x90,0xfe,0x39,0x00,0x86,0xfe,0x39,0x00,0x7b,0xfe,0x39,0x00,0x70,0xfe,0x39,0x00,0x65,0xfe,  \
    0x39,0x00,0x5a,0xfe,0x39,0x00,0x4f,0xfe,0x39,0x00,0x44,0xfe,0x39,0x00,0x39,0xfe,0x39,0x00,0x2e,0xfe,0x3a,0x00,0x23,0xfe,0x3a,0x00,0x18,0xfe,0x3a,0x00,0x0d,0xfe,0x3a,0x00,0x02,0xfe,0x3a,0x00,0xf6,0xfd,0x3a,0x00,0xeb,0xfd,0x3a,0x00,0xe0,0xfd,0x3a,0x00,0xd5,0xfd,0x3b,0x00,0xc9,0xfd,0x3b,0x00,0xbe,0xfd,0x3b,0x00,0xb3,0xfd,0x3b,0x00,0xa7,0xfd,0x3b,0x00,0x9c,0xfd,0x3b,0x00,0x90,0xfd,0x3b,0x00,0x85,0xfd,0x3c,0x00,0x79,0xfd,0x3c,0x00,0x6e,0xfd,0x3c,0x00,  \
    0x62,0xfd,0x3c,0x00,0x57,0xfd,0x3c,0x00,0x4b,0xfd,0x3c,0x00,0x3f,0xfd,0x3d,0x00,0x33,0xfd,0x3d,0x00,0x27,0xfd,0x3d,0x00,0x1c,0xfd,0x3d,0x00,0x10,0xfd,0x3d,0x00,0x04,0xfd,0x3e,0x00,0xf8,0xfc,0x3e,0x00,0xec,0xfc,0x3e,0x00,0xe0,0xfc,0x3e,0x00,0xd3,0xfc,0x3e,0x00,0xc7,0xfc,0x3f,0x00,0xbb,0xfc,0x3f,0x00,0xaf,0xfc,0x3f,0x00,0xa2,0xfc,0x3f,0x00,0x96,0xfc,0x3f,0x00,0x89,0xfc,0x40,0x00,0x7d,0xfc,0x40,0x00,0x70,0xfc,0x40,0x00,0x64,0xfc,0x40,0x00,0x57,0xfc,  \
    0x40,0x00,0x4a,0xfc,0x41,0x00,0x3e,0xfc,0x41,0x00,0x31,0xfc,0x41,0x00,0x24,0xfc,0x41,0x00,0x17,0xfc,0x42,0x00,0x0a,0xfc,0x42,0x00,0xfd,0xfb,0x42,0x00,0xf0,0xfb,0x42,0x00,0xe3,0xfb,0x43,0x00,0xd5,0xfb,0x43,0x00,0xc8,0xfb,0x43,0x00,0xbb,0xfb,0x43,0x00,0xad,0xfb,0x44,0x00,0xa0,0xfb,0x44,0x00,0x92,0xfb,0x44,0x00,0x85,0xfb,0x44,0x00,0x77,0xfb,0x45,0x00,0x69,0xfb,0x45,0x00,0x5b,0xfb,0x45,0x00,0x4d,0xfb,0x45,0x00,0x3f,0xfb,0x46,0x00,0x31,0xfb,0x46,0x00,  \
    0x23,0xfb,0x46,0x00,0x15,0xfb,0x47,0x00,0x07,0xfb,0x47,0x00,0xf9,0xfa,0x47,0x00,0xea,0xfa,0x47,0x00,0xdc,0xfa,0x48,0x00,0xcd,0xfa,0x48,0x00,0xbf,0xfa,0x48,0x00,0xb0,0xfa,0x49,0x00,0xa1,0xfa,0x49,0x00,0x92,0xfa,0x49,0x00,0x83,0xfa,0x49,0x00,0x74,0xfa,0x4a,0x00,0x65,0xfa,0x4a,0x00,0x56,0xfa,0x4a,0x00,0x47,0xfa,0x4b,0x00,0x38,0xfa,0x4b,0x00,0x28,0xfa,0x4b,0x00,0x19,0xfa,0x4c,0x00,0x09,0xfa,0x4c,0x00,0xfa,0xf9,0x4c,0x00,0xea,0xf9,0x4c,0x00,0xda,0xf9,  \
    0x4d,0x00,0xca,0xf9,0x4d,0x00,0xba,0xf9,0x4d,0x00,0xaa,0xf9,0x4e,0x00,0x9a,0xf9,0x4e,0x00,0x8a,0xf9,0x4e,0x00,0x7a,0xf9,0x4f,0x00,0x69,0xf9,0x4f,0x00,0x59,0xf9,0x4f,0x00,0x48,0xf9,0x50,0x00,0x37,0xf9,0x50,0x00,0x27,0xf9,0x50,0x00,0x16,0xf9,0x51,0x00,0x05,0xf9,0x51,0x00,0xf4,0xf8,0x51,0x00,0xe3,0xf8,0x52,0x00,0xd2,0xf8,0x52,0x00,0xc0,0xf8,0x52,0x00,0xaf,0xf8,0x53,0x00,0x9d,0xf8,0x53,0x00,0x8c,0xf8,0x53,0x00,0x7a,0xf8,0x54,0x00,0x68,0xf8,0x54,0x00,  \
    0x56,0xf8,0x54,0x00,0x44,0xf8,0x55,0x00,0x32,0xf8,0x55,0x00,0x20,0xf8,0x55,0x00,0x0e,0xf8,0x56,0x00,0xfc,0xf7,0x56,0x00,0xe9,0xf7,0x56,0x00,0xd7,0xf7,0x57,0x00,0xc4,0xf7,0x57,0x00,0xb1,0xf7,0x57,0x00,0x9e,0xf7,0x58,0x00,0x8b,0xf7,0x58,0x00,0x78,0xf7,0x58,0x00,0x65,0xf7,0x59,0x00,0x52,0xf7,0x59,0x00,0x3e,0xf7,0x59,0x00,0x2b,0xf7,0x5a,0x00,0x17,0xf7,0x5a,0x00,0x04,0xf7,0x5a,0x00,0xf0,0xf6,0x5b,0x00,0xdc,0xf6,0x5b,0x00,0xc8,0xf6,0x5b,0x00,0xb4,0xf6,  \
    0x5c,0x00,0xa0,0xf6,0x5c,0x00,0x8b,0xf6,0x5c,0x00,0x77,0xf6,0x5d,0x00,0x62,0xf6,0x5d,0x00,0x4e,0xf6,0x5d,0x00,0x39,0xf6,0x5d,0x00,0x24,0xf6,0x5e,0x00,0x0f,0xf6,0x5e,0x00,0xfa,0xf5,0x5e,0x00,0xe5,0xf5,0x5f,0x00,0xcf,0xf5,0x5f,0x00,0xba,0xf5,0x5f,0x00,0xa4,0xf5,0x60,0x00,0x8f,0xf5,0x60,0x00,0x79,0xf5,0x60,0x00,0x63,0xf5,0x61,0x00,0x4d,0xf5,0x61,0x00,0x37,0xf5,0x61,0x00,0x20,0xf5,0x62,0x00,0x0a,0xf5,0x62,0x00,0xf4,0xf4,0x62,0x00,0xdd,0xf4,0x63,0x00,  \
    0xc6,0xf4,0x63,0x00,0xb0,0xf4,0x63,0x00,0x99,0xf4,0x63,0x00,0x82,0xf4,0x64,0x00,0x6a,0xf4,0x64,0x00,0x53,0xf4,0x64,0x00,0x3c,0xf4,0x65,0x00,0x24,0xf4,0x65,0x00,0x0c,0xf4,0x65,0x00,0xf5,0xf3,0x65,0x00,0xdd,0xf3,0x66,0x00,0xc5,0xf3,0x66,0x00,0xad,0xf3,0x66,0x00,0x94,0xf3,0x66,0x00,0x7c,0xf3,0x67,0x00,0x64,0xf3,0x67,0x00,0x4b,0xf3,0x67,0x00,0x32,0xf3,0x68,0x00,0x19,0xf3,0x68,0x00,0x00,0xf3,0x68,0x00,0xe7,0xf2,0x68,0x00,0xce,0xf2,0x69,0x00,0xb5,0xf2,  \
    0x69,0x00,0x9b,0xf2,0x69,0x00,0x82,0xf2,0x69,0x00,0x68,0xf2,0x69,0x00,0x4e,0xf2,0x6a,0x00,0x34,0xf2,0x6a,0x00,0x1a,0xf2,0x6a,0x00,0x00,0xf2,0x6a,0x00,0xe5,0xf1,0x6b,0x00,0xcb,0xf1,0x6b,0x00,0xb0,0xf1,0x6b,0x00,0x95,0xf1,0x6b,0x00,0x7b,0xf1,0x6b,0x00,0x60,0xf1,0x6c,0x00,0x44,0xf1,0x6c,0x00,0x29,0xf1,0x6c,0x00,0x0e,0xf1,0x6c,0x00,0xf2,0xf0,0x6c,0x00,0xd7,0xf0,0x6c,0x00,0xbb,0xf0,0x6d,0x00,0x9f,0xf0,0x6d,0x00,0x83,0xf0,0x6d,0x00,0x67,0xf0,0x6d,0x00,  \
    0x4b,0xf0,0x6d,0x00,0x2e,0xf0,0x6d,0x00,0x12,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x64,0x00,0xfe,0x0f,0x64,0x00,0xe2,0x0f,0x64,0x00,0xc5,0x0f,0x64,0x00,0xa9,0x0f,0x64,0x00,0x8c,0x0f,  \
    0x64,0x00,0x70,0x0f,0x63,0x00,0x54,0x0f,0x63,0x00,0x38,0x0f,0x63,0x00,0x1c,0x0f,0x63,0x00,0x00,0x0f,0x63,0x00,0xe5,0x0e,0x63,0x00,0xc9,0x0e,0x63,0x00,0xae,0x0e,0x63,0x00,0x93,0x0e,0x62,0x00,0x77,0x0e,0x62,0x00,0x5c,0x0e,0x62,0x00,0x41,0x0e,0x62,0x00,0x27,0x0e,0x62,0x00,0x0c,0x0e,0x62,0x00,0xf1,0x0d,0x62,0x00,0xd7,0x0d,0x61,0x00,0xbd,0x0d,0x61,0x00,0xa2,0x0d,0x61,0x00,0x88,0x0d,0x61,0x00,0x6e,0x0d,0x61,0x00,0x55,0x0d,0x61,0x00,0x3b,0x0d,0x60,0x00,  \
    0x21,0x0d,0x60,0x00,0x08,0x0d,0x60,0x00,0xee,0x0c,0x60,0x00,0xd5,0x0c,0x60,0x00,0xbc,0x0c,0x60,0x00,0xa3,0x0c,0x5f,0x00,0x8a,0x0c,0x5f,0x00,0x71,0x0c,0x5f,0x00,0x59,0x0c,0x5f,0x00,0x40,0x0c,0x5f,0x00,0x28,0x0c,0x5e,0x00,0x0f,0x0c,0x5e,0x00,0xf7,0x0b,0x5e,0x00,0xdf,0x0b,0x5e,0x00,0xc7,0x0b,0x5e,0x00,0xaf,0x0b,0x5d,0x00,0x97,0x0b,0x5d,0x00,0x80,0x0b,0x5d,0x00,0x68,0x0b,0x5d,0x00,0x51,0x0b,0x5d,0x00,0x39,0x0b,0x5c,0x00,0x22,0x0b,0x5c,0x00,0x0b,0x0b,  \
    0x5c,0x00,0xf4,0x0a,0x5c,0x00,0xdd,0x0a,0x5b,0x00,0xc7,0x0a,0x5b,0x00,0xb0,0x0a,0x5b,0x00,0x99,0x0a,0x5b,0x00,0x83,0x0a,0x5b,0x00,0x6d,0x0a,0x5a,0x00,0x57,0x0a,0x5a,0x00,0x40,0x0a,0x5a,0x00,0x2b,0x0a,0x5a,0x00,0x15,0x0a,0x59,0x00,0xff,0x09,0x59,0x00,0xe9,0x09,0x59,0x00,0xd4,0x09,0x59,0x00,0xbe,0x09,0x59,0x00,0xa9,0x09,0x58,0x00,0x94,0x09,0x58,0x00,0x7f,0x09,0x58,0x00,0x6a,0x09,0x58,0x00,0x55,0x09,0x57,0x00,0x40,0x09,0x57,0x00,0x2b,0x09,0x57,0x00,  \
    0x17,0x09,0x57,0x00,0x02,0x09,0x56,0x00,0xee,0x08,0x56,0x00,0xda,0x08,0x56,0x00,0xc6,0x08,0x56,0x00,0xb2,0x08,0x56,0x00,0x9e,0x08,0x55,0x00,0x8a,0x08,0x55,0x00,0x76,0x08,0x55,0x00,0x63,0x08,0x55,0x00,0x4f,0x08,0x54,0x00,0x3c,0x08,0x54,0x00,0x28,0x08,0x54,0x00,0x15,0x08,0x54,0x00,0x02,0x08,0x53,0x00,0xef,0x07,0x53,0x00,0xdc,0x07,0x53,0x00,0xc9,0x07,0x53,0x00,0xb6,0x07,0x52,0x00,0xa4,0x07,0x52,0x00,0x91,0x07,0x52,0x00,0x7f,0x07,0x52,0x00,0x6c,0x07,  \
    0x51,0x00,0x5a,0x07,0x51,0x00,0x48,0x07,0x51,0x00,0x36,0x07,0x51,0x00,0x24,0x07,0x51,0x00,0x12,0x07,0x50,0x00,0x00,0x07,0x50,0x00,0xef,0x06,0x50,0x00,0xdd,0x06,0x50,0x00,0xcc,0x06,0x4f,0x00,0xba,0x06,0x4f,0x00,0xa9,0x06,0x4f,0x00,0x98,0x06,0x4f,0x00,0x87,0x06,0x4e,0x00,0x76,0x06,0x4e,0x00,0x65,0x06,0x4e,0x00,0x54,0x06,0x4e,0x00,0x43,0x06,0x4e,0x00,0x32,0x06,0x4d,0x00,0x22,0x06,0x4d,0x00,0x11,0x06,0x4d,0x00,0x01,0x06,0x4d,0x00,0xf1,0x05,0x4c,0x00,  \
    0xe0,0x05,0x4c,0x00,0xd0,0x05,0x4c,0x00,0xc0,0x05,0x4c,0x00,0xb0,0x05,0x4c,0x00,0xa0,0x05,0x4b,0x00,0x90,0x05,0x4b,0x00,0x81,0x05,0x4b,0x00,0x71,0x05,0x4b,0x00,0x61,0x05,0x4a,0x00,0x52,0x05,0x4a,0x00,0x42,0x05,0x4a,0x00,0x33,0x05,0x4a,0x00,0x24,0x05,0x4a,0x00,0x15,0x05,0x49,0x00,0x06,0x05,0x49,0x00,0xf6,0x04,0x49,0x00,0xe8,0x04,0x49,0x00,0xd9,0x04,0x49,0x00,0xca,0x04,0x48,0x00,0xbb,0x04,0x48,0x00,0xac,0x04,0x48,0x00,0x9e,0x04,0x48,0x00,0x8f,0x04,  \
    0x48,0x00,0x81,0x04,0x47,0x00,0x73,0x04,0x47,0x00,0x64,0x04,0x47,0x00,0x56,0x04,0x47,0x00,0x48,0x04,0x47,0x00,0x3a,0x04,0x46,0x00,0x2c,0x04,0x46,0x00,0x1e,0x04,0x46,0x00,0x10,0x04,0x46,0x00,0x02,0x04,0x46,0x00,0xf4,0x03,0x45,0x00,0xe7,0x03,0x45,0x00,0xd9,0x03,0x45,0x00,0xcc,0x03,0x45,0x00,0xbe,0x03,0x45,0x00,0xb1,0x03,0x45,0x00,0xa3,0x03,0x44,0x00,0x96,0x03,0x44,0x00,0x89,0x03,0x44,0x00,0x7b,0x03,0x44,0x00,0x6e,0x03,0x44,0x00,0x61,0x03,0x44,0x00,  \
    0x54,0x03,0x43,0x00,0x47,0x03,0x43,0x00,0x3a,0x03,0x43,0x00,0x2e,0x03,0x43,0x00,0x21,0x03,0x43,0x00,0x14,0x03,0x43,0x00,0x07,0x03,0x42,0x00,0xfb,0x02,0x42,0x00,0xee,0x02,0x42,0x00,0xe2,0x02,0x42,0x00,0xd5,0x02,0x42,0x00,0xc9,0x02,0x42,0x00,0xbd,0x02,0x42,0x00,0xb0,0x02,0x41,0x00,0xa4,0x02,0x41,0x00,0x98,0x02,0x41,0x00,0x8c,0x02,0x41,0x00,0x80,0x02,0x41,0x00,0x74,0x02,0x41,0x00,0x67,0x02,0x41,0x00,0x5c,0x02,0x40,0x00,0x50,0x02,0x40,0x00,0x44,0x02,  \
    0x40,0x00,0x38,0x02,0x40,0x00,0x2c,0x02,0x40,0x00,0x20,0x02,0x40,0x00,0x15,0x02,0x40,0x00,0x09,0x02,0x40,0x00,0xfd,0x01,0x40,0x00,0xf2,0x01,0x3f,0x00,0xe6,0x01,0x3f,0x00,0xdb,0x01,0x3f,0x00,0xcf,0x01,0x3f,0x00,0xc4,0x01,0x3f,0x00,0xb8,0x01,0x3f,0x00,0xad,0x01,0x3f,0x00,0xa2,0x01,0x3f,0x00,0x96,0x01,0x3f,0x00,0x8b,0x01,0x3f,0x00,0x80,0x01,0x3e,0x00,0x75,0x01,0x3e,0x00,0x69,0x01,0x3e,0x00,0x5e,0x01,0x3e,0x00,0x53,0x01,0x3e,0x00,0x48,0x01,0x3e,0x00,  \
    0x3d,0x01,0x3e,0x00,0x32,0x01,0x3e,0x00,0x27,0x01,0x3e,0x00,0x1c,0x01,0x3e,0x00,0x11,0x01,0x3e,0x00,0x06,0x01,0x3e,0x00,0xfb,0x00,0x3e,0x00,0xf0,0x00,0x3d,0x00,0xe5,0x00,0x3d,0x00,0xda,0x00,0x3d,0x00,0xd0,0x00,0x3d,0x00,0xc5,0x00,0x3d,0x00,0xba,0x00,0x3d,0x00,0xaf,0x00,0x3d,0x00,0xa4,0x00,0x3d,0x00,0x9a,0x00,0x3d,0x00,0x8f,0x00,0x3d,0x00,0x84,0x00,0x3d,0x00,0x7a,0x00,0x3d,0x00,0x6f,0x00,0x3d,0x00,0x64,0x00,0x3d,0x00,0x5a,0x00,0x3d,0x00,0x4f,0x00,  \
    0x3d,0x00,0x44,0x00,0x3d,0x00,0x3a,0x00,0x3d,0x00,0x2f,0x00,0x3d,0x00,0x24,0x00,0x3d,0x00,0x1a,0x00,0x3d,0x00,0x0f,0x00,0x3d,0x00,0x05,0x00,0x3d,0x00,0xfa,0xff,0x3d,0x00,0xf0,0xff,0x3d,0x00,0xe5,0xff,0x3d,0x00,0xda,0xff,0x3d,0x00,0xd0,0xff,0x3d,0x00,0xc5,0xff,0x3d,0x00,0xbb,0xff,0x3d,0x00,0xb0,0xff,0x3d,0x00,0xa6,0xff,0x3d,0x00,0x9b,0xff,0x3d,0x00,0x90,0xff,0x3d,0x00,0x86,0xff,0x3d,0x00,0x7b,0xff,0x3d,0x00,0x71,0xff,0x3d,0x00,0x66,0xff,0x3d,0x00,  \
    0x5c,0xff,0x3d,0x00,0x51,0xff,0x3d,0x00,0x46,0xff,0x3d,0x00,0x3c,0xff,0x3d,0x00,0x31,0xff,0x3d,0x00,0x27,0xff,0x3d,0x00,0x1c,0xff,0x3d,0x00,0x11,0xff,0x3d,0x00,0x07,0xff,0x3d,0x00,0xfc,0xfe,0x3d,0x00,0xf1,0xfe,0x3d,0x00,0xe7,0xfe,0x3d,0x00,0xdc,0xfe,0x3d,0x00,0xd1,0xfe,0x3d,0x00,0xc7,0xfe,0x3d,0x00,0xbc,0xfe,0x3d,0x00,0xb1,0xfe,0x3d,0x00,0xa6,0xfe,0x3d,0x00,0x9b,0xfe,0x3e,0x00,0x91,0xfe,0x3e,0x00,0x86,0xfe,0x3e,0x00,0x7b,0xfe,0x3e,0x00,0x70,0xfe,  \
    0x3e,0x00,0x65,0xfe,0x3e,0x00,0x5a,0xfe,0x3e,0x00,0x4f,0xfe,0x3e,0x00,0x44,0xfe,0x3e,0x00,0x39,0xfe,0x3e,0x00,0x2e,0xfe,0x3e,0x00,0x23,0xfe,0x3e,0x00,0x18,0xfe,0x3e,0x00,0x0d,0xfe,0x3f,0x00,0x02,0xfe,0x3f,0x00,0xf7,0xfd,0x3f,0x00,0xeb,0xfd,0x3f,0x00,0xe0,0xfd,0x3f,0x00,0xd5,0xfd,0x3f,0x00,0xca,0xfd,0x3f,0x00,0xbe,0xfd,0x3f,0x00,0xb3,0xfd,0x3f,0x00,0xa8,0xfd,0x3f,0x00,0x9c,0xfd,0x40,0x00,0x91,0xfd,0x40,0x00,0x85,0xfd,0x40,0x00,0x7a,0xfd,0x40,0x00,  \
    0x6e,0xfd,0x40,0x00,0x62,0xfd,0x40,0x00,0x57,0xfd,0x40,0x00,0x4b,0xfd,0x40,0x00,0x3f,0xfd,0x41,0x00,0x34,0xfd,0x41,0x00,0x28,0xfd,0x41,0x00,0x1c,0xfd,0x41,0x00,0x10,0xfd,0x41,0x00,0x04,0xfd,0x41,0x00,0xf8,0xfc,0x41,0x00,0xec,0xfc,0x41,0x00,0xe0,0xfc,0x42,0x00,0xd4,0xfc,0x42,0x00,0xc7,0xfc,0x42,0x00,0xbb,0xfc,0x42,0x00,0xaf,0xfc,0x42,0x00,0xa3,0xfc,0x42,0x00,0x96,0xfc,0x42,0x00,0x8a,0xfc,0x43,0x00,0x7d,0xfc,0x43,0x00,0x71,0xfc,0x43,0x00,0x64,0xfc,  \
    0x43,0x00,0x57,0xfc,0x43,0x00,0x4b,0xfc,0x43,0x00,0x3e,0xfc,0x44,0x00,0x31,0xfc,0x44,0x00,0x24,0xfc,0x44,0x00,0x17,0xfc,0x44,0x00,0x0a,0xfc,0x44,0x00,0xfd,0xfb,0x44,0x00,0xf0,0xfb,0x45,0x00,0xe3,0xfb,0x45,0x00,0xd6,0xfb,0x45,0x00,0xc8,0xfb,0x45,0x00,0xbb,0xfb,0x45,0x00,0xae,0xfb,0x46,0x00,0xa0,0xfb,0x46,0x00,0x93,0xfb,0x46,0x00,0x85,0xfb,0x46,0x00,0x77,0xfb,0x46,0x00,0x69,0xfb,0x46,0x00,0x5c,0xfb,0x47,0x00,0x4e,0xfb,0x47,0x00,0x40,0xfb,0x47,0x00,  \
    0x32,0xfb,0x47,0x00,0x24,0xfb,0x47,0x00,0x15,0xfb,0x48,0x00,0x07,0xfb,0x48,0x00,0xf9,0xfa,0x48,0x00,0xeb,0xfa,0x48,0x00,0xdc,0xfa,0x48,0x00,0xce,0xfa,0x49,0x00,0xbf,0xfa,0x49,0x00,0xb0,0xfa,0x49,0x00,0xa2,0xfa,0x49,0x00,0x93,0xfa,0x4a,0x00,0x84,0xfa,0x4a,0x00,0x75,0xfa,0x4a,0x00,0x66,0xfa,0x4a,0x00,0x57,0xfa,0x4a,0x00,0x47,0xfa,0x4b,0x00,0x38,0xfa,0x4b,0x00,0x29,0xfa,0x4b,0x00,0x19,0xfa,0x4b,0x00,0x0a,0xfa,0x4b,0x00,0xfa,0xf9,0x4c,0x00,0xea,0xf9,  \
    0x4c,0x00,0xdb,0xf9,0x4c,0x00,0xcb,0xf9,0x4c,0x00,0xbb,0xf9,0x4d,0x00,0xab,0xf9,0x4d,0x00,0x9b,0xf9,0x4d,0x00,0x8a,0xf9,0x4d,0x00,0x7a,0xf9,0x4e,0x00,0x6a,0xf9,0x4e,0x00,0x59,0xf9,0x4e,0x00,0x49,0xf9,0x4e,0x00,0x38,0xf9,0x4e,0x00,0x27,0xf9,0x4f,0x00,0x16,0xf9,0x4f,0x00,0x05,0xf9,0x4f,0x00,0xf4,0xf8,0x4f,0x00,0xe3,0xf8,0x50,0x00,0xd2,0xf8,0x50,0x00,0xc1,0xf8,0x50,0x00,0xaf,0xf8,0x50,0x00,0x9e,0xf8,0x51,0x00,0x8c,0xf8,0x51,0x00,0x7b,0xf8,0x51,0x00,  \
    0x69,0xf8,0x51,0x00,0x57,0xf8,0x52,0x00,0x45,0xf8,0x52,0x00,0x33,0xf8,0x52,0x00,0x21,0xf8,0x52,0x00,0x0e,0xf8,0x52,0x00,0xfc,0xf7,0x53,0x00,0xea,0xf7,0x53,0x00,0xd7,0xf7,0x53,0x00,0xc4,0xf7,0x53,0x00,0xb2,0xf7,0x54,0x00,0x9f,0xf7,0x54,0x00,0x8c,0xf7,0x54,0x00,0x79,0xf7,0x54,0x00,0x65,0xf7,0x55,0x00,0x52,0xf7,0x55,0x00,0x3f,0xf7,0x55,0x00,0x2b,0xf7,0x55,0x00,0x18,0xf7,0x56,0x00,0x04,0xf7,0x56,0x00,0xf0,0xf6,0x56,0x00,0xdc,0xf6,0x56,0x00,0xc8,0xf6,  \
    0x57,0x00,0xb4,0xf6,0x57,0x00,0xa0,0xf6,0x57,0x00,0x8c,0xf6,0x57,0x00,0x77,0xf6,0x57,0x00,0x63,0xf6,0x58,0x00,0x4e,0xf6,0x58,0x00,0x39,0xf6,0x58,0x00,0x24,0xf6,0x58,0x00,0x0f,0xf6,0x59,0x00,0xfa,0xf5,0x59,0x00,0xe5,0xf5,0x59,0x00,0xd0,0xf5,0x59,0x00,0xba,0xf5,0x5a,0x00,0xa5,0xf5,0x5a,0x00,0x8f,0xf5,0x5a,0x00,0x79,0xf5,0x5a,0x00,0x63,0xf5,0x5a,0x00,0x4d,0xf5,0x5b,0x00,0x37,0xf5,0x5b,0x00,0x21,0xf5,0x5b,0x00,0x0b,0xf5,0x5b,0x00,0xf4,0xf4,0x5c,0x00,  \
    0xdd,0xf4,0x5c,0x00,0xc7,0xf4,0x5c,0x00,0xb0,0xf4,0x5c,0x00,0x99,0xf4,0x5c,0x00,0x82,0xf4,0x5d,0x00,0x6b,0xf4,0x5d,0x00,0x53,0xf4,0x5d,0x00,0x3c,0xf4,0x5d,0x00,0x24,0xf4,0x5d,0x00,0x0d,0xf4,0x5e,0x00,0xf5,0xf3,0x5e,0x00,0xdd,0xf3,0x5e,0x00,0xc5,0xf3,0x5e,0x00,0xad,0xf3,0x5e,0x00,0x95,0xf3,0x5f,0x00,0x7c,0xf3,0x5f,0x00,0x64,0xf3,0x5f,0x00,0x4b,0xf3,0x5f,0x00,0x33,0xf3,0x5f,0x00,0x1a,0xf3,0x60,0x00,0x01,0xf3,0x60,0x00,0xe8,0xf2,0x60,0x00,0xce,0xf2,  \
    0x60,0x00,0xb5,0xf2,0x60,0x00,0x9b,0xf2,0x60,0x00,0x82,0xf2,0x61,0x00,0x68,0xf2,0x61,0x00,0x4e,0xf2,0x61,0x00,0x34,0xf2,0x61,0x00,0x1a,0xf2,0x61,0x00,0x00,0xf2,0x61,0x00,0xe6,0xf1,0x62,0x00,0xcb,0xf1,0x62,0x00,0xb0,0xf1,0x62,0x00,0x96,0xf1,0x62,0x00,0x7b,0xf1,0x62,0x00,0x60,0xf1,0x62,0x00,0x45,0xf1,0x62,0x00,0x2a,0xf1,0x63,0x00,0x0e,0xf1,0x63,0x00,0xf3,0xf0,0x63,0x00,0xd7,0xf0,0x63,0x00,0xbb,0xf0,0x63,0x00,0x9f,0xf0,0x63,0x00,0x83,0xf0,0x63,0x00,  \
    0x67,0xf0,0x63,0x00,0x4b,0xf0,0x64,0x00,0x2f,0xf0,0x64,0x00,0x12,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x5a,0x00,0xfe,0x0f,0x5a,0x00,0xe1,0x0f,0x5a,0x00,0xc5,0x0f,0x5a,0x00,0xa8,0x0f,  \
    0x5a,0x00,0x8c,0x0f,0x5a,0x00,0x70,0x0f,0x5a,0x00,0x54,0x0f,0x5a,0x00,0x38,0x0f,0x5a,0x00,0x1c,0x0f,0x5a,0x00,0x00,0x0f,0x5a,0x00,0xe5,0x0e,0x59,0x00,0xc9,0x0e,0x59,0x00,0xae,0x0e,0x59,0x00,0x92,0x0e,0x59,0x00,0x77,0x0e,0x59,0x00,0x5c,0x0e,0x59,0x00,0x41,0x0e,0x59,0x00,0x26,0x0e,0x59,0x00,0x0c,0x0e,0x59,0x00,0xf1,0x0d,0x59,0x00,0xd7,0x0d,0x59,0x00,0xbc,0x0d,0x58,0x00,0xa2,0x0d,0x58,0x00,0x88,0x0d,0x58,0x00,0x6e,0x0d,0x58,0x00,0x54,0x0d,0x58,0x00,  \
    0x3b,0x0d,0x58,0x00,0x21,0x0d,0x58,0x00,0x08,0x0d,0x58,0x00,0xee,0x0c,0x58,0x00,0xd5,0x0c,0x58,0x00,0xbc,0x0c,0x57,0x00,0xa3,0x0c,0x57,0x00,0x8a,0x0c,0x57,0x00,0x71,0x0c,0x57,0x00,0x58,0x0c,0x57,0x00,0x40,0x0c,0x57,0x00,0x27,0x0c,0x57,0x00,0x0f,0x0c,0x57,0x00,0xf7,0x0b,0x56,0x00,0xdf,0x0b,0x56,0x00,0xc7,0x0b,0x56,0x00,0xaf,0x0b,0x56,0x00,0x97,0x0b,0x56,0x00,0x7f,0x0b,0x56,0x00,0x68,0x0b,0x56,0x00,0x50,0x0b,0x56,0x00,0x39,0x0b,0x55,0x00,0x22,0x0b,  \
    0x55,0x00,0x0b,0x0b,0x55,0x00,0xf4,0x0a,0x55,0x00,0xdd,0x0a,0x55,0x00,0xc6,0x0a,0x55,0x00,0xb0,0x0a,0x55,0x00,0x99,0x0a,0x55,0x00,0x83,0x0a,0x54,0x00,0x6c,0x0a,0x54,0x00,0x56,0x0a,0x54,0x00,0x40,0x0a,0x54,0x00,0x2a,0x0a,0x54,0x00,0x14,0x0a,0x54,0x00,0xff,0x09,0x54,0x00,0xe9,0x09,0x53,0x00,0xd4,0x09,0x53,0x00,0xbe,0x09,0x53,0x00,0xa9,0x09,0x53,0x00,0x94,0x09,0x53,0x00,0x7e,0x09,0x53,0x00,0x69,0x09,0x53,0x00,0x55,0x09,0x52,0x00,0x40,0x09,0x52,0x00,  \
    0x2b,0x09,0x52,0x00,0x17,0x09,0x52,0x00,0x02,0x09,0x52,0x00,0xee,0x08,0x52,0x00,0xda,0x08,0x52,0x00,0xc5,0x08,0x51,0x00,0xb1,0x08,0x51,0x00,0x9d,0x08,0x51,0x00,0x8a,0x08,0x51,0x00,0x76,0x08,0x51,0x00,0x62,0x08,0x51,0x00,0x4f,0x08,0x51,0x00,0x3b,0x08,0x50,0x00,0x28,0x08,0x50,0x00,0x15,0x08,0x50,0x00,0x02,0x08,0x50,0x00,0xef,0x07,0x50,0x00,0xdc,0x07,0x50,0x00,0xc9,0x07,0x50,0x00,0xb6,0x07,0x4f,0x00,0xa4,0x07,0x4f,0x00,0x91,0x07,0x4f,0x00,0x7f,0x07,  \
    0x4f,0x00,0x6c,0x07,0x4f,0x00,0x5a,0x07,0x4f,0x00,0x48,0x07,0x4f,0x00,0x36,0x07,0x4e,0x00,0x24,0x07,0x4e,0x00,0x12,0x07,0x4e,0x00,0x00,0x07,0x4e,0x00,0xef,0x06,0x4e,0x00,0xdd,0x06,0x4e,0x00,0xcb,0x06,0x4e,0x00,0xba,0x06,0x4d,0x00,0xa9,0x06,0x4d,0x00,0x98,0x06,0x4d,0x00,0x86,0x06,0x4d,0x00,0x75,0x06,0x4d,0x00,0x64,0x06,0x4d,0x00,0x54,0x06,0x4d,0x00,0x43,0x06,0x4c,0x00,0x32,0x06,0x4c,0x00,0x22,0x06,0x4c,0x00,0x11,0x06,0x4c,0x00,0x01,0x06,0x4c,0x00,  \
    0xf0,0x05,0x4c,0x00,0xe0,0x05,0x4c,0x00,0xd0,0x05,0x4b,0x00,0xc0,0x05,0x4b,0x00,0xb0,0x05,0x4b,0x00,0xa0,0x05,0x4b,0x00,0x90,0x05,0x4b,0x00,0x80,0x05,0x4b,0x00,0x71,0x05,0x4b,0x00,0x61,0x05,0x4a,0x00,0x52,0x05,0x4a,0x00,0x42,0x05,0x4a,0x00,0x33,0x05,0x4a,0x00,0x24,0x05,0x4a,0x00,0x14,0x05,0x4a,0x00,0x05,0x05,0x4a,0x00,0xf6,0x04,0x4a,0x00,0xe7,0x04,0x49,0x00,0xd8,0x04,0x49,0x00,0xca,0x04,0x49,0x00,0xbb,0x04,0x49,0x00,0xac,0x04,0x49,0x00,0x9e,0x04,  \
    0x49,0x00,0x8f,0x04,0x49,0x00,0x81,0x04,0x49,0x00,0x72,0x04,0x48,0x00,0x64,0x04,0x48,0x00,0x56,0x04,0x48,0x00,0x48,0x04,0x48,0x00,0x3a,0x04,0x48,0x00,0x2c,0x04,0x48,0x00,0x1e,0x04,0x48,0x00,0x10,0x04,0x48,0x00,0x02,0x04,0x48,0x00,0xf4,0x03,0x47,0x00,0xe6,0x03,0x47,0x00,0xd9,0x03,0x47,0x00,0xcb,0x03,0x47,0x00,0xbe,0x03,0x47,0x00,0xb0,0x03,0x47,0x00,0xa3,0x03,0x47,0x00,0x96,0x03,0x47,0x00,0x88,0x03,0x47,0x00,0x7b,0x03,0x46,0x00,0x6e,0x03,0x46,0x00,  \
    0x61,0x03,0x46,0x00,0x54,0x03,0x46,0x00,0x47,0x03,0x46,0x00,0x3a,0x03,0x46,0x00,0x2d,0x03,0x46,0x00,0x21,0x03,0x46,0x00,0x14,0x03,0x46,0x00,0x07,0x03,0x46,0x00,0xfb,0x02,0x45,0x00,0xee,0x02,0x45,0x00,0xe2,0x02,0x45,0x00,0xd5,0x02,0x45,0x00,0xc9,0x02,0x45,0x00,0xbc,0x02,0x45,0x00,0xb0,0x02,0x45,0x00,0xa4,0x02,0x45,0x00,0x98,0x02,0x45,0x00,0x8b,0x02,0x45,0x00,0x7f,0x02,0x45,0x00,0x73,0x02,0x45,0x00,0x67,0x02,0x44,0x00,0x5b,0x02,0x44,0x00,0x4f,0x02,  \
    0x44,0x00,0x44,0x02,0x44,0x00,0x38,0x02,0x44,0x00,0x2c,0x02,0x44,0x00,0x20,0x02,0x44,0x00,0x14,0x02,0x44,0x00,0x09,0x02,0x44,0x00,0xfd,0x01,0x44,0x00,0xf2,0x01,0x44,0x00,0xe6,0x01,0x44,0x00,0xda,0x01,0x44,0x00,0xcf,0x01,0x44,0x00,0xc4,0x01,0x43,0x00,0xb8,0x01,0x43,0x00,0xad,0x01,0x43,0x00,0xa1,0x01,0x43,0x00,0x96,0x01,0x43,0x00,0x8b,0x01,0x43,0x00,0x80,0x01,0x43,0x00,0x74,0x01,0x43,0x00,0x69,0x01,0x43,0x00,0x5e,0x01,0x43,0x00,0x53,0x01,0x43,0x00,  \
    0x48,0x01,0x43,0x00,0x3d,0x01,0x43,0x00,0x32,0x01,0x43,0x00,0x27,0x01,0x43,0x00,0x1c,0x01,0x43,0x00,0x11,0x01,0x43,0x00,0x06,0x01,0x43,0x00,0xfb,0x00,0x43,0x00,0xf0,0x00,0x43,0x00,0xe5,0x00,0x42,0x00,0xda,0x00,0x42,0x00,0xcf,0x00,0x42,0x00,0xc5,0x00,0x42,0x00,0xba,0x00,0x42,0x00,0xaf,0x00,0x42,0x00,0xa4,0x00,0x42,0x00,0x9a,0x00,0x42,0x00,0x8f,0x00,0x42,0x00,0x84,0x00,0x42,0x00,0x7a,0x00,0x42,0x00,0x6f,0x00,0x42,0x00,0x64,0x00,0x42,0x00,0x5a,0x00,  \
    0x42,0x00,0x4f,0x00,0x42,0x00,0x44,0x00,0x42,0x00,0x3a,0x00,0x42,0x00,0x2f,0x00,0x42,0x00,0x24,0x00,0x42,0x00,0x1a,0x00,0x42,0x00,0x0f,0x00,0x42,0x00,0x05,0x00,0x42,0x00,0xfa,0xff,0x42,0x00,0xf0,0xff,0x42,0x00,0xe5,0xff,0x42,0x00,0xda,0xff,0x42,0x00,0xd0,0xff,0x42,0x00,0xc5,0xff,0x42,0x00,0xbb,0xff,0x42,0x00,0xb0,0xff,0x42,0x00,0xa6,0xff,0x42,0x00,0x9b,0xff,0x42,0x00,0x91,0xff,0x42,0x00,0x86,0xff,0x42,0x00,0x7b,0xff,0x42,0x00,0x71,0xff,0x42,0x00,  \
    0x66,0xff,0x42,0x00,0x5c,0xff,0x42,0x00,0x51,0xff,0x42,0x00,0x46,0xff,0x42,0x00,0x3c,0xff,0x42,0x00,0x31,0xff,0x42,0x00,0x27,0xff,0x42,0x00,0x1c,0xff,0x42,0x00,0x11,0xff,0x42,0x00,0x07,0xff,0x42,0x00,0xfc,0xfe,0x42,0x00,0xf1,0xfe,0x42,0x00,0xe7,0xfe,0x42,0x00,0xdc,0xfe,0x42,0x00,0xd1,0xfe,0x42,0x00,0xc7,0xfe,0x42,0x00,0xbc,0xfe,0x42,0x00,0xb1,0xfe,0x43,0x00,0xa6,0xfe,0x43,0x00,0x9c,0xfe,0x43,0x00,0x91,0xfe,0x43,0x00,0x86,0xfe,0x43,0x00,0x7b,0xfe,  \
    0x43,0x00,0x70,0xfe,0x43,0x00,0x65,0xfe,0x43,0x00,0x5a,0xfe,0x43,0x00,0x4f,0xfe,0x43,0x00,0x44,0xfe,0x43,0x00,0x39,0xfe,0x43,0x00,0x2e,0xfe,0x43,0x00,0x23,0xfe,0x43,0x00,0x18,0xfe,0x43,0x00,0x0d,0xfe,0x43,0x00,0x02,0xfe,0x43,0x00,0xf7,0xfd,0x43,0x00,0xec,0xfd,0x43,0x00,0xe0,0xfd,0x43,0x00,0xd5,0xfd,0x43,0x00,0xca,0xfd,0x44,0x00,0xbf,0xfd,0x44,0x00,0xb3,0xfd,0x44,0x00,0xa8,0xfd,0x44,0x00,0x9c,0xfd,0x44,0x00,0x91,0xfd,0x44,0x00,0x85,0xfd,0x44,0x00,  \
    0x7a,0xfd,0x44,0x00,0x6e,0xfd,0x44,0x00,0x63,0xfd,0x44,0x00,0x57,0xfd,0x44,0x00,0x4b,0xfd,0x44,0x00,0x40,0xfd,0x44,0x00,0x34,0xfd,0x44,0x00,0x28,0xfd,0x45,0x00,0x1c,0xfd,0x45,0x00,0x10,0xfd,0x45,0x00,0x04,0xfd,0x45,0x00,0xf8,0xfc,0x45,0x00,0xec,0xfc,0x45,0x00,0xe0,0xfc,0x45,0x00,0xd4,0xfc,0x45,0x00,0xc8,0xfc,0x45,0x00,0xbb,0xfc,0x45,0x00,0xaf,0xfc,0x45,0x00,0xa3,0xfc,0x46,0x00,0x96,0xfc,0x46,0x00,0x8a,0xfc,0x46,0x00,0x7d,0xfc,0x46,0x00,0x71,0xfc,  \
    0x46,0x00,0x64,0xfc,0x46,0x00,0x58,0xfc,0x46,0x00,0x4b,0xfc,0x46,0x00,0x3e,0xfc,0x46,0x00,0x31,0xfc,0x46,0x00,0x24,0xfc,0x47,0x00,0x18,0xfc,0x47,0x00,0x0b,0xfc,0x47,0x00,0xfd,0xfb,0x47,0x00,0xf0,0xfb,0x47,0x00,0xe3,0xfb,0x47,0x00,0xd6,0xfb,0x47,0x00,0xc9,0xfb,0x47,0x00,0xbb,0xfb,0x47,0x00,0xae,0xfb,0x47,0x00,0xa0,0xfb,0x48,0x00,0x93,0xfb,0x48,0x00,0x85,0xfb,0x48,0x00,0x77,0xfb,0x48,0x00,0x6a,0xfb,0x48,0x00,0x5c,0xfb,0x48,0x00,0x4e,0xfb,0x48,0x00,  \
    0x40,0xfb,0x48,0x00,0x32,0xfb,0x49,0x00,0x24,0xfb,0x49,0x00,0x16,0xfb,0x49,0x00,0x08,0xfb,0x49,0x00,0xf9,0xfa,0x49,0x00,0xeb,0xfa,0x49,0x00,0xdc,0xfa,0x49,0x00,0xce,0xfa,0x49,0x00,0xbf,0xfa,0x4a,0x00,0xb1,0xfa,0x4a,0x00,0xa2,0xfa,0x4a,0x00,0x93,0xfa,0x4a,0x00,0x84,0xfa,0x4a,0x00,0x75,0xfa,0x4a,0x00,0x66,0xfa,0x4a,0x00,0x57,0xfa,0x4a,0x00,0x48,0xfa,0x4b,0x00,0x38,0xfa,0x4b,0x00,0x29,0xfa,0x4b,0x00,0x19,0xfa,0x4b,0x00,0x0a,0xfa,0x4b,0x00,0xfa,0xf9,  \
    0x4b,0x00,0xeb,0xf9,0x4b,0x00,0xdb,0xf9,0x4c,0x00,0xcb,0xf9,0x4c,0x00,0xbb,0xf9,0x4c,0x00,0xab,0xf9,0x4c,0x00,0x9b,0xf9,0x4c,0x00,0x8b,0xf9,0x4c,0x00,0x7a,0xf9,0x4c,0x00,0x6a,0xf9,0x4d,0x00,0x59,0xf9,0x4d,0x00,0x49,0xf9,0x4d,0x00,0x38,0xf9,0x4d,0x00,0x27,0xf9,0x4d,0x00,0x17,0xf9,0x4d,0x00,0x06,0xf9,0x4d,0x00,0xf5,0xf8,0x4e,0x00,0xe3,0xf8,0x4e,0x00,0xd2,0xf8,0x4e,0x00,0xc1,0xf8,0x4e,0x00,0xb0,0xf8,0x4e,0x00,0x9e,0xf8,0x4e,0x00,0x8c,0xf8,0x4e,0x00,  \
    0x7b,0xf8,0x4f,0x00,0x69,0xf8,0x4f,0x00,0x57,0xf8,0x4f,0x00,0x45,0xf8,0x4f,0x00,0x33,0xf8,0x4f,0x00,0x21,0xf8,0x4f,0x00,0x0f,0xf8,0x4f,0x00,0xfc,0xf7,0x50,0x00,0xea,0xf7,0x50,0x00,0xd7,0xf7,0x50,0x00,0xc5,0xf7,0x50,0x00,0xb2,0xf7,0x50,0x00,0x9f,0xf7,0x50,0x00,0x8c,0xf7,0x50,0x00,0x79,0xf7,0x51,0x00,0x66,0xf7,0x51,0x00,0x52,0xf7,0x51,0x00,0x3f,0xf7,0x51,0x00,0x2c,0xf7,0x51,0x00,0x18,0xf7,0x51,0x00,0x04,0xf7,0x51,0x00,0xf1,0xf6,0x52,0x00,0xdd,0xf6,  \
    0x52,0x00,0xc9,0xf6,0x52,0x00,0xb4,0xf6,0x52,0x00,0xa0,0xf6,0x52,0x00,0x8c,0xf6,0x52,0x00,0x77,0xf6,0x53,0x00,0x63,0xf6,0x53,0x00,0x4e,0xf6,0x53,0x00,0x39,0xf6,0x53,0x00,0x25,0xf6,0x53,0x00,0x10,0xf6,0x53,0x00,0xfa,0xf5,0x53,0x00,0xe5,0xf5,0x54,0x00,0xd0,0xf5,0x54,0x00,0xba,0xf5,0x54,0x00,0xa5,0xf5,0x54,0x00,0x8f,0xf5,0x54,0x00,0x79,0xf5,0x54,0x00,0x64,0xf5,0x54,0x00,0x4e,0xf5,0x54,0x00,0x37,0xf5,0x55,0x00,0x21,0xf5,0x55,0x00,0x0b,0xf5,0x55,0x00,  \
    0xf4,0xf4,0x55,0x00,0xde,0xf4,0x55,0x00,0xc7,0xf4,0x55,0x00,0xb0,0xf4,0x55,0x00,0x99,0xf4,0x56,0x00,0x82,0xf4,0x56,0x00,0x6b,0xf4,0x56,0x00,0x54,0xf4,0x56,0x00,0x3c,0xf4,0x56,0x00,0x25,0xf4,0x56,0x00,0x0d,0xf4,0x56,0x00,0xf5,0xf3,0x56,0x00,0xdd,0xf3,0x57,0x00,0xc5,0xf3,0x57,0x00,0xad,0xf3,0x57,0x00,0x95,0xf3,0x57,0x00,0x7d,0xf3,0x57,0x00,0x64,0xf3,0x57,0x00,0x4b,0xf3,0x57,0x00,0x33,0xf3,0x57,0x00,0x1a,0xf3,0x57,0x00,0x01,0xf3,0x58,0x00,0xe8,0xf2,  \
    0x58,0x00,0xcf,0xf2,0x58,0x00,0xb5,0xf2,0x58,0x00,0x9c,0xf2,0x58,0x00,0x82,0xf2,0x58,0x00,0x68,0xf2,0x58,0x00,0x4e,0xf2,0x58,0x00,0x35,0xf2,0x58,0x00,0x1a,0xf2,0x59,0x00,0x00,0xf2,0x59,0x00,0xe6,0xf1,0x59,0x00,0xcb,0xf1,0x59,0x00,0xb1,0xf1,0x59,0x00,0x96,0xf1,0x59,0x00,0x7b,0xf1,0x59,0x00,0x60,0xf1,0x59,0x00,0x45,0xf1,0x59,0x00,0x2a,0xf1,0x59,0x00,0x0e,0xf1,0x59,0x00,0xf3,0xf0,0x59,0x00,0xd7,0xf0,0x5a,0x00,0xbb,0xf0,0x5a,0x00,0xa0,0xf0,0x5a,0x00,  \
    0x84,0xf0,0x5a,0x00,0x67,0xf0,0x5a,0x00,0x4b,0xf0,0x5a,0x00,0x2f,0xf0,0x5a,0x00,0x12,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x50,0x00,0xfe,0x0f,0x50,0x00,0xe1,0x0f,0x50,0x00,0xc5,0x0f,  \
    0x50,0x00,0xa8,0x0f,0x50,0x00,0x8c,0x0f,0x50,0x00,0x70,0x0f,0x50,0x00,0x54,0x0f,0x50,0x00,0x38,0x0f,0x50,0x00,0x1c,0x0f,0x50,0x00,0x00,0x0f,0x50,0x00,0xe4,0x0e,0x50,0x00,0xc9,0x0e,0x50,0x00,0xae,0x0e,0x50,0x00,0x92,0x0e,0x50,0x00,0x77,0x0e,0x50,0x00,0x5c,0x0e,0x50,0x00,0x41,0x0e,0x50,0x00,0x26,0x0e,0x50,0x00,0x0c,0x0e,0x50,0x00,0xf1,0x0d,0x50,0x00,0xd7,0x0d,0x50,0x00,0xbc,0x0d,0x50,0x00,0xa2,0x0d,0x50,0x00,0x88,0x0d,0x50,0x00,0x6e,0x0d,0x50,0x00,  \
    0x54,0x0d,0x50,0x00,0x3b,0x0d,0x50,0x00,0x21,0x0d,0x50,0x00,0x07,0x0d,0x50,0x00,0xee,0x0c,0x4f,0x00,0xd5,0x0c,0x4f,0x00,0xbc,0x0c,0x4f,0x00,0xa3,0x0c,0x4f,0x00,0x8a,0x0c,0x4f,0x00,0x71,0x0c,0x4f,0x00,0x58,0x0c,0x4f,0x00,0x40,0x0c,0x4f,0x00,0x27,0x0c,0x4f,0x00,0x0f,0x0c,0x4f,0x00,0xf7,0x0b,0x4f,0x00,0xdf,0x0b,0x4f,0x00,0xc7,0x0b,0x4f,0x00,0xaf,0x0b,0x4f,0x00,0x97,0x0b,0x4f,0x00,0x7f,0x0b,0x4f,0x00,0x68,0x0b,0x4f,0x00,0x50,0x0b,0x4f,0x00,0x39,0x0b,  \
    0x4f,0x00,0x22,0x0b,0x4f,0x00,0x0b,0x0b,0x4f,0x00,0xf4,0x0a,0x4f,0x00,0xdd,0x0a,0x4e,0x00,0xc6,0x0a,0x4e,0x00,0xb0,0x0a,0x4e,0x00,0x99,0x0a,0x4e,0x00,0x83,0x0a,0x4e,0x00,0x6c,0x0a,0x4e,0x00,0x56,0x0a,0x4e,0x00,0x40,0x0a,0x4e,0x00,0x2a,0x0a,0x4e,0x00,0x14,0x0a,0x4e,0x00,0xff,0x09,0x4e,0x00,0xe9,0x09,0x4e,0x00,0xd3,0x09,0x4e,0x00,0xbe,0x09,0x4e,0x00,0xa9,0x09,0x4e,0x00,0x93,0x09,0x4e,0x00,0x7e,0x09,0x4e,0x00,0x69,0x09,0x4e,0x00,0x54,0x09,0x4e,0x00,  \
    0x40,0x09,0x4d,0x00,0x2b,0x09,0x4d,0x00,0x16,0x09,0x4d,0x00,0x02,0x09,0x4d,0x00,0xee,0x08,0x4d,0x00,0xd9,0x08,0x4d,0x00,0xc5,0x08,0x4d,0x00,0xb1,0x08,0x4d,0x00,0x9d,0x08,0x4d,0x00,0x89,0x08,0x4d,0x00,0x76,0x08,0x4d,0x00,0x62,0x08,0x4d,0x00,0x4f,0x08,0x4d,0x00,0x3b,0x08,0x4d,0x00,0x28,0x08,0x4d,0x00,0x15,0x08,0x4d,0x00,0x02,0x08,0x4d,0x00,0xee,0x07,0x4d,0x00,0xdc,0x07,0x4d,0x00,0xc9,0x07,0x4c,0x00,0xb6,0x07,0x4c,0x00,0xa3,0x07,0x4c,0x00,0x91,0x07,  \
    0x4c,0x00,0x7e,0x07,0x4c,0x00,0x6c,0x07,0x4c,0x00,0x5a,0x07,0x4c,0x00,0x48,0x07,0x4c,0x00,0x36,0x07,0x4c,0x00,0x24,0x07,0x4c,0x00,0x12,0x07,0x4c,0x00,0x00,0x07,0x4c,0x00,0xee,0x06,0x4c,0x00,0xdd,0x06,0x4c,0x00,0xcb,0x06,0x4c,0x00,0xba,0x06,0x4c,0x00,0xa9,0x06,0x4c,0x00,0x97,0x06,0x4c,0x00,0x86,0x06,0x4b,0x00,0x75,0x06,0x4b,0x00,0x64,0x06,0x4b,0x00,0x53,0x06,0x4b,0x00,0x43,0x06,0x4b,0x00,0x32,0x06,0x4b,0x00,0x21,0x06,0x4b,0x00,0x11,0x06,0x4b,0x00,  \
    0x00,0x06,0x4b,0x00,0xf0,0x05,0x4b,0x00,0xe0,0x05,0x4b,0x00,0xd0,0x05,0x4b,0x00,0xc0,0x05,0x4b,0x00,0xb0,0x05,0x4b,0x00,0xa0,0x05,0x4b,0x00,0x90,0x05,0x4b,0x00,0x80,0x05,0x4b,0x00,0x71,0x05,0x4b,0x00,0x61,0x05,0x4b,0x00,0x51,0x05,0x4b,0x00,0x42,0x05,0x4a,0x00,0x33,0x05,0x4a,0x00,0x23,0x05,0x4a,0x00,0x14,0x05,0x4a,0x00,0x05,0x05,0x4a,0x00,0xf6,0x04,0x4a,0x00,0xe7,0x04,0x4a,0x00,0xd8,0x04,0x4a,0x00,0xc9,0x04,0x4a,0x00,0xbb,0x04,0x4a,0x00,0xac,0x04,  \
    0x4a,0x00,0x9d,0x04,0x4a,0x00,0x8f,0x04,0x4a,0x00,0x81,0x04,0x4a,0x00,0x72,0x04,0x4a,0x00,0x64,0x04,0x4a,0x00,0x56,0x04,0x4a,0x00,0x48,0x04,0x4a,0x00,0x39,0x04,0x4a,0x00,0x2b,0x04,0x4a,0x00,0x1d,0x04,0x4a,0x00,0x10,0x04,0x4a,0x00,0x02,0x04,0x49,0x00,0xf4,0x03,0x49,0x00,0xe6,0x03,0x49,0x00,0xd9,0x03,0x49,0x00,0xcb,0x03,0x49,0x00,0xbe,0x03,0x49,0x00,0xb0,0x03,0x49,0x00,0xa3,0x03,0x49,0x00,0x96,0x03,0x49,0x00,0x88,0x03,0x49,0x00,0x7b,0x03,0x49,0x00,  \
    0x6e,0x03,0x49,0x00,0x61,0x03,0x49,0x00,0x54,0x03,0x49,0x00,0x47,0x03,0x49,0x00,0x3a,0x03,0x49,0x00,0x2d,0x03,0x49,0x00,0x21,0x03,0x49,0x00,0x14,0x03,0x49,0x00,0x07,0x03,0x49,0x00,0xfb,0x02,0x49,0x00,0xee,0x02,0x49,0x00,0xe2,0x02,0x49,0x00,0xd5,0x02,0x49,0x00,0xc9,0x02,0x49,0x00,0xbc,0x02,0x49,0x00,0xb0,0x02,0x49,0x00,0xa4,0x02,0x48,0x00,0x98,0x02,0x48,0x00,0x8b,0x02,0x48,0x00,0x7f,0x02,0x48,0x00,0x73,0x02,0x48,0x00,0x67,0x02,0x48,0x00,0x5b,0x02,  \
    0x48,0x00,0x4f,0x02,0x48,0x00,0x43,0x02,0x48,0x00,0x38,0x02,0x48,0x00,0x2c,0x02,0x48,0x00,0x20,0x02,0x48,0x00,0x14,0x02,0x48,0x00,0x09,0x02,0x48,0x00,0xfd,0x01,0x48,0x00,0xf1,0x01,0x48,0x00,0xe6,0x01,0x48,0x00,0xda,0x01,0x48,0x00,0xcf,0x01,0x48,0x00,0xc3,0x01,0x48,0x00,0xb8,0x01,0x48,0x00,0xad,0x01,0x48,0x00,0xa1,0x01,0x48,0x00,0x96,0x01,0x48,0x00,0x8b,0x01,0x48,0x00,0x80,0x01,0x48,0x00,0x74,0x01,0x48,0x00,0x69,0x01,0x48,0x00,0x5e,0x01,0x48,0x00,  \
    0x53,0x01,0x48,0x00,0x48,0x01,0x48,0x00,0x3d,0x01,0x48,0x00,0x32,0x01,0x48,0x00,0x27,0x01,0x48,0x00,0x1c,0x01,0x48,0x00,0x11,0x01,0x48,0x00,0x06,0x01,0x48,0x00,0xfb,0x00,0x48,0x00,0xf0,0x00,0x48,0x00,0xe5,0x00,0x48,0x00,0xda,0x00,0x48,0x00,0xcf,0x00,0x48,0x00,0xc5,0x00,0x48,0x00,0xba,0x00,0x48,0x00,0xaf,0x00,0x48,0x00,0xa4,0x00,0x48,0x00,0x9a,0x00,0x48,0x00,0x8f,0x00,0x48,0x00,0x84,0x00,0x48,0x00,0x79,0x00,0x47,0x00,0x6f,0x00,0x47,0x00,0x64,0x00,  \
    0x47,0x00,0x59,0x00,0x47,0x00,0x4f,0x00,0x47,0x00,0x44,0x00,0x47,0x00,0x3a,0x00,0x47,0x00,0x2f,0x00,0x47,0x00,0x24,0x00,0x47,0x00,0x1a,0x00,0x47,0x00,0x0f,0x00,0x47,0x00,0x05,0x00,0x47,0x00,0xfa,0xff,0x47,0x00,0xf0,0xff,0x47,0x00,0xe5,0xff,0x47,0x00,0xda,0xff,0x47,0x00,0xd0,0xff,0x47,0x00,0xc5,0xff,0x47,0x00,0xbb,0xff,0x47,0x00,0xb0,0xff,0x47,0x00,0xa6,0xff,0x47,0x00,0x9b,0xff,0x47,0x00,0x91,0xff,0x47,0x00,0x86,0xff,0x47,0x00,0x7b,0xff,0x47,0x00,  \
    0x71,0xff,0x47,0x00,0x66,0xff,0x47,0x00,0x5c,0xff,0x47,0x00,0x51,0xff,0x47,0x00,0x47,0xff,0x47,0x00,0x3c,0xff,0x47,0x00,0x31,0xff,0x47,0x00,0x27,0xff,0x47,0x00,0x1c,0xff,0x48,0x00,0x11,0xff,0x48,0x00,0x07,0xff,0x48,0x00,0xfc,0xfe,0x48,0x00,0xf1,0xfe,0x48,0x00,0xe7,0xfe,0x48,0x00,0xdc,0xfe,0x48,0x00,0xd1,0xfe,0x48,0x00,0xc7,0xfe,0x48,0x00,0xbc,0xfe,0x48,0x00,0xb1,0xfe,0x48,0x00,0xa6,0xfe,0x48,0x00,0x9c,0xfe,0x48,0x00,0x91,0xfe,0x48,0x00,0x86,0xfe,  \
    0x48,0x00,0x7b,0xfe,0x48,0x00,0x70,0xfe,0x48,0x00,0x65,0xfe,0x48,0x00,0x5a,0xfe,0x48,0x00,0x4f,0xfe,0x48,0x00,0x44,0xfe,0x48,0x00,0x39,0xfe,0x48,0x00,0x2e,0xfe,0x48,0x00,0x23,0xfe,0x48,0x00,0x18,0xfe,0x48,0x00,0x0d,0xfe,0x48,0x00,0x02,0xfe,0x48,0x00,0xf7,0xfd,0x48,0x00,0xec,0xfd,0x48,0x00,0xe0,0xfd,0x48,0x00,0xd5,0xfd,0x48,0x00,0xca,0xfd,0x48,0x00,0xbf,0xfd,0x48,0x00,0xb3,0xfd,0x48,0x00,0xa8,0xfd,0x48,0x00,0x9c,0xfd,0x48,0x00,0x91,0xfd,0x48,0x00,  \
    0x85,0xfd,0x48,0x00,0x7a,0xfd,0x48,0x00,0x6e,0xfd,0x48,0x00,0x63,0xfd,0x48,0x00,0x57,0xfd,0x48,0x00,0x4b,0xfd,0x48,0x00,0x40,0xfd,0x48,0x00,0x34,0xfd,0x48,0x00,0x28,0xfd,0x48,0x00,0x1c,0xfd,0x48,0x00,0x10,0xfd,0x48,0x00,0x04,0xfd,0x48,0x00,0xf8,0xfc,0x49,0x00,0xec,0xfc,0x49,0x00,0xe0,0xfc,0x49,0x00,0xd4,0xfc,0x49,0x00,0xc8,0xfc,0x49,0x00,0xbc,0xfc,0x49,0x00,0xaf,0xfc,0x49,0x00,0xa3,0xfc,0x49,0x00,0x97,0xfc,0x49,0x00,0x8a,0xfc,0x49,0x00,0x7e,0xfc,  \
    0x49,0x00,0x71,0xfc,0x49,0x00,0x64,0xfc,0x49,0x00,0x58,0xfc,0x49,0x00,0x4b,0xfc,0x49,0x00,0x3e,0xfc,0x49,0x00,0x31,0xfc,0x49,0x00,0x25,0xfc,0x49,0x00,0x18,0xfc,0x49,0x00,0x0b,0xfc,0x49,0x00,0xfe,0xfb,0x49,0x00,0xf0,0xfb,0x49,0x00,0xe3,0xfb,0x49,0x00,0xd6,0xfb,0x49,0x00,0xc9,0xfb,0x49,0x00,0xbb,0xfb,0x49,0x00,0xae,0xfb,0x49,0x00,0xa0,0xfb,0x4a,0x00,0x93,0xfb,0x4a,0x00,0x85,0xfb,0x4a,0x00,0x78,0xfb,0x4a,0x00,0x6a,0xfb,0x4a,0x00,0x5c,0xfb,0x4a,0x00,  \
    0x4e,0xfb,0x4a,0x00,0x40,0xfb,0x4a,0x00,0x32,0xfb,0x4a,0x00,0x24,0xfb,0x4a,0x00,0x16,0xfb,0x4a,0x00,0x08,0xfb,0x4a,0x00,0xf9,0xfa,0x4a,0x00,0xeb,0xfa,0x4a,0x00,0xdd,0xfa,0x4a,0x00,0xce,0xfa,0x4a,0x00,0xbf,0xfa,0x4a,0x00,0xb1,0xfa,0x4a,0x00,0xa2,0xfa,0x4a,0x00,0x93,0xfa,0x4a,0x00,0x84,0xfa,0x4a,0x00,0x75,0xfa,0x4a,0x00,0x66,0xfa,0x4b,0x00,0x57,0xfa,0x4b,0x00,0x48,0xfa,0x4b,0x00,0x38,0xfa,0x4b,0x00,0x29,0xfa,0x4b,0x00,0x1a,0xfa,0x4b,0x00,0x0a,0xfa,  \
    0x4b,0x00,0xfa,0xf9,0x4b,0x00,0xeb,0xf9,0x4b,0x00,0xdb,0xf9,0x4b,0x00,0xcb,0xf9,0x4b,0x00,0xbb,0xf9,0x4b,0x00,0xab,0xf9,0x4b,0x00,0x9b,0xf9,0x4b,0x00,0x8b,0xf9,0x4b,0x00,0x7a,0xf9,0x4b,0x00,0x6a,0xf9,0x4b,0x00,0x5a,0xf9,0x4b,0x00,0x49,0xf9,0x4b,0x00,0x38,0xf9,0x4c,0x00,0x28,0xf9,0x4c,0x00,0x17,0xf9,0x4c,0x00,0x06,0xf9,0x4c,0x00,0xf5,0xf8,0x4c,0x00,0xe4,0xf8,0x4c,0x00,0xd2,0xf8,0x4c,0x00,0xc1,0xf8,0x4c,0x00,0xb0,0xf8,0x4c,0x00,0x9e,0xf8,0x4c,0x00,  \
    0x8d,0xf8,0x4c,0x00,0x7b,0xf8,0x4c,0x00,0x69,0xf8,0x4c,0x00,0x57,0xf8,0x4c,0x00,0x45,0xf8,0x4c,0x00,0x33,0xf8,0x4c,0x00,0x21,0xf8,0x4c,0x00,0x0f,0xf8,0x4c,0x00,0xfc,0xf7,0x4c,0x00,0xea,0xf7,0x4d,0x00,0xd7,0xf7,0x4d,0x00,0xc5,0xf7,0x4d,0x00,0xb2,0xf7,0x4d,0x00,0x9f,0xf7,0x4d,0x00,0x8c,0xf7,0x4d,0x00,0x79,0xf7,0x4d,0x00,0x66,0xf7,0x4d,0x00,0x53,0xf7,0x4d,0x00,0x3f,0xf7,0x4d,0x00,0x2c,0xf7,0x4d,0x00,0x18,0xf7,0x4d,0x00,0x04,0xf7,0x4d,0x00,0xf1,0xf6,  \
    0x4d,0x00,0xdd,0xf6,0x4d,0x00,0xc9,0xf6,0x4d,0x00,0xb5,0xf6,0x4d,0x00,0xa0,0xf6,0x4d,0x00,0x8c,0xf6,0x4e,0x00,0x78,0xf6,0x4e,0x00,0x63,0xf6,0x4e,0x00,0x4e,0xf6,0x4e,0x00,0x3a,0xf6,0x4e,0x00,0x25,0xf6,0x4e,0x00,0x10,0xf6,0x4e,0x00,0xfb,0xf5,0x4e,0x00,0xe5,0xf5,0x4e,0x00,0xd0,0xf5,0x4e,0x00,0xbb,0xf5,0x4e,0x00,0xa5,0xf5,0x4e,0x00,0x8f,0xf5,0x4e,0x00,0x7a,0xf5,0x4e,0x00,0x64,0xf5,0x4e,0x00,0x4e,0xf5,0x4e,0x00,0x38,0xf5,0x4e,0x00,0x21,0xf5,0x4e,0x00,  \
    0x0b,0xf5,0x4e,0x00,0xf4,0xf4,0x4f,0x00,0xde,0xf4,0x4f,0x00,0xc7,0xf4,0x4f,0x00,0xb0,0xf4,0x4f,0x00,0x99,0xf4,0x4f,0x00,0x82,0xf4,0x4f,0x00,0x6b,0xf4,0x4f,0x00,0x54,0xf4,0x4f,0x00,0x3c,0xf4,0x4f,0x00,0x25,0xf4,0x4f,0x00,0x0d,0xf4,0x4f,0x00,0xf5,0xf3,0x4f,0x00,0xde,0xf3,0x4f,0x00,0xc6,0xf3,0x4f,0x00,0xad,0xf3,0x4f,0x00,0x95,0xf3,0x4f,0x00,0x7d,0xf3,0x4f,0x00,0x64,0xf3,0x4f,0x00,0x4c,0xf3,0x4f,0x00,0x33,0xf3,0x4f,0x00,0x1a,0xf3,0x4f,0x00,0x01,0xf3,  \
    0x4f,0x00,0xe8,0xf2,0x50,0x00,0xcf,0xf2,0x50,0x00,0xb5,0xf2,0x50,0x00,0x9c,0xf2,0x50,0x00,0x82,0xf2,0x50,0x00,0x68,0xf2,0x50,0x00,0x4f,0xf2,0x50,0x00,0x35,0xf2,0x50,0x00,0x1b,0xf2,0x50,0x00,0x00,0xf2,0x50,0x00,0xe6,0xf1,0x50,0x00,0xcb,0xf1,0x50,0x00,0xb1,0xf1,0x50,0x00,0x96,0xf1,0x50,0x00,0x7b,0xf1,0x50,0x00,0x60,0xf1,0x50,0x00,0x45,0xf1,0x50,0x00,0x2a,0xf1,0x50,0x00,0x0e,0xf1,0x50,0x00,0xf3,0xf0,0x50,0x00,0xd7,0xf0,0x50,0x00,0xbc,0xf0,0x50,0x00,  \
    0xa0,0xf0,0x50,0x00,0x84,0xf0,0x50,0x00,0x68,0xf0,0x50,0x00,0x4b,0xf0,0x50,0x00,0x2f,0xf0,0x50,0x00,0x12,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x47,0x00,0xfe,0x0f,0x47,0x00,0xe1,0x0f,  \
    0x47,0x00,0xc5,0x0f,0x47,0x00,0xa8,0x0f,0x47,0x00,0x8c,0x0f,0x47,0x00,0x70,0x0f,0x47,0x00,0x54,0x0f,0x47,0x00,0x38,0x0f,0x47,0x00,0x1c,0x0f,0x47,0x00,0x00,0x0f,0x47,0x00,0xe4,0x0e,0x47,0x00,0xc9,0x0e,0x47,0x00,0xae,0x0e,0x47,0x00,0x92,0x0e,0x47,0x00,0x77,0x0e,0x47,0x00,0x5c,0x0e,0x47,0x00,0x41,0x0e,0x47,0x00,0x26,0x0e,0x47,0x00,0x0c,0x0e,0x47,0x00,0xf1,0x0d,0x47,0x00,0xd7,0x0d,0x47,0x00,0xbc,0x0d,0x47,0x00,0xa2,0x0d,0x47,0x00,0x88,0x0d,0x47,0x00,  \
    0x6e,0x0d,0x47,0x00,0x54,0x0d,0x47,0x00,0x3a,0x0d,0x47,0x00,0x21,0x0d,0x47,0x00,0x07,0x0d,0x47,0x00,0xee,0x0c,0x47,0x00,0xd5,0x0c,0x47,0x00,0xbc,0x0c,0x47,0x00,0xa3,0x0c,0x47,0x00,0x8a,0x0c,0x48,0x00,0x71,0x0c,0x48,0x00,0x58,0x0c,0x48,0x00,0x40,0x0c,0x48,0x00,0x27,0x0c,0x48,0x00,0x0f,0x0c,0x48,0x00,0xf7,0x0b,0x48,0x00,0xdf,0x0b,0x48,0x00,0xc7,0x0b,0x48,0x00,0xaf,0x0b,0x48,0x00,0x97,0x0b,0x48,0x00,0x7f,0x0b,0x48,0x00,0x68,0x0b,0x48,0x00,0x50,0x0b,  \
    0x48,0x00,0x39,0x0b,0x48,0x00,0x22,0x0b,0x48,0x00,0x0b,0x0b,0x48,0x00,0xf4,0x0a,0x48,0x00,0xdd,0x0a,0x48,0x00,0xc6,0x0a,0x48,0x00,0xb0,0x0a,0x48,0x00,0x99,0x0a,0x48,0x00,0x83,0x0a,0x48,0x00,0x6c,0x0a,0x48,0x00,0x56,0x0a,0x48,0x00,0x40,0x0a,0x48,0x00,0x2a,0x0a,0x48,0x00,0x14,0x0a,0x48,0x00,0xff,0x09,0x48,0x00,0xe9,0x09,0x48,0x00,0xd3,0x09,0x48,0x00,0xbe,0x09,0x49,0x00,0xa9,0x09,0x49,0x00,0x93,0x09,0x49,0x00,0x7e,0x09,0x49,0x00,0x69,0x09,0x49,0x00,  \
    0x54,0x09,0x49,0x00,0x40,0x09,0x49,0x00,0x2b,0x09,0x49,0x00,0x16,0x09,0x49,0x00,0x02,0x09,0x49,0x00,0xee,0x08,0x49,0x00,0xd9,0x08,0x49,0x00,0xc5,0x08,0x49,0x00,0xb1,0x08,0x49,0x00,0x9d,0x08,0x49,0x00,0x89,0x08,0x49,0x00,0x76,0x08,0x49,0x00,0x62,0x08,0x49,0x00,0x4f,0x08,0x49,0x00,0x3b,0x08,0x49,0x00,0x28,0x08,0x49,0x00,0x15,0x08,0x49,0x00,0x01,0x08,0x49,0x00,0xee,0x07,0x49,0x00,0xdc,0x07,0x49,0x00,0xc9,0x07,0x49,0x00,0xb6,0x07,0x49,0x00,0xa3,0x07,  \
    0x4a,0x00,0x91,0x07,0x4a,0x00,0x7e,0x07,0x4a,0x00,0x6c,0x07,0x4a,0x00,0x5a,0x07,0x4a,0x00,0x48,0x07,0x4a,0x00,0x36,0x07,0x4a,0x00,0x24,0x07,0x4a,0x00,0x12,0x07,0x4a,0x00,0x00,0x07,0x4a,0x00,0xee,0x06,0x4a,0x00,0xdd,0x06,0x4a,0x00,0xcb,0x06,0x4a,0x00,0xba,0x06,0x4a,0x00,0xa9,0x06,0x4a,0x00,0x97,0x06,0x4a,0x00,0x86,0x06,0x4a,0x00,0x75,0x06,0x4a,0x00,0x64,0x06,0x4a,0x00,0x53,0x06,0x4a,0x00,0x43,0x06,0x4a,0x00,0x32,0x06,0x4a,0x00,0x21,0x06,0x4a,0x00,  \
    0x11,0x06,0x4a,0x00,0x00,0x06,0x4a,0x00,0xf0,0x05,0x4a,0x00,0xe0,0x05,0x4a,0x00,0xd0,0x05,0x4a,0x00,0xc0,0x05,0x4a,0x00,0xb0,0x05,0x4b,0x00,0xa0,0x05,0x4b,0x00,0x90,0x05,0x4b,0x00,0x80,0x05,0x4b,0x00,0x71,0x05,0x4b,0x00,0x61,0x05,0x4b,0x00,0x51,0x05,0x4b,0x00,0x42,0x05,0x4b,0x00,0x33,0x05,0x4b,0x00,0x23,0x05,0x4b,0x00,0x14,0x05,0x4b,0x00,0x05,0x05,0x4b,0x00,0xf6,0x04,0x4b,0x00,0xe7,0x04,0x4b,0x00,0xd8,0x04,0x4b,0x00,0xc9,0x04,0x4b,0x00,0xbb,0x04,  \
    0x4b,0x00,0xac,0x04,0x4b,0x00,0x9d,0x04,0x4b,0x00,0x8f,0x04,0x4b,0x00,0x81,0x04,0x4b,0x00,0x72,0x04,0x4b,0x00,0x64,0x04,0x4b,0x00,0x56,0x04,0x4b,0x00,0x47,0x04,0x4b,0x00,0x39,0x04,0x4b,0x00,0x2b,0x04,0x4b,0x00,0x1d,0x04,0x4b,0x00,0x10,0x04,0x4b,0x00,0x02,0x04,0x4b,0x00,0xf4,0x03,0x4b,0x00,0xe6,0x03,0x4b,0x00,0xd9,0x03,0x4c,0x00,0xcb,0x03,0x4c,0x00,0xbe,0x03,0x4c,0x00,0xb0,0x03,0x4c,0x00,0xa3,0x03,0x4c,0x00,0x96,0x03,0x4c,0x00,0x88,0x03,0x4c,0x00,  \
    0x7b,0x03,0x4c,0x00,0x6e,0x03,0x4c,0x00,0x61,0x03,0x4c,0x00,0x54,0x03,0x4c,0x00,0x47,0x03,0x4c,0x00,0x3a,0x03,0x4c,0x00,0x2d,0x03,0x4c,0x00,0x21,0x03,0x4c,0x00,0x14,0x03,0x4c,0x00,0x07,0x03,0x4c,0x00,0xfb,0x02,0x4c,0x00,0xee,0x02,0x4c,0x00,0xe1,0x02,0x4c,0x00,0xd5,0x02,0x4c,0x00,0xc9,0x02,0x4c,0x00,0xbc,0x02,0x4c,0x00,0xb0,0x02,0x4c,0x00,0xa4,0x02,0x4c,0x00,0x98,0x02,0x4c,0x00,0x8b,0x02,0x4c,0x00,0x7f,0x02,0x4c,0x00,0x73,0x02,0x4c,0x00,0x67,0x02,  \
    0x4c,0x00,0x5b,0x02,0x4c,0x00,0x4f,0x02,0x4c,0x00,0x43,0x02,0x4c,0x00,0x38,0x02,0x4c,0x00,0x2c,0x02,0x4c,0x00,0x20,0x02,0x4c,0x00,0x14,0x02,0x4c,0x00,0x09,0x02,0x4c,0x00,0xfd,0x01,0x4c,0x00,0xf1,0x01,0x4c,0x00,0xe6,0x01,0x4c,0x00,0xda,0x01,0x4c,0x00,0xcf,0x01,0x4c,0x00,0xc3,0x01,0x4c,0x00,0xb8,0x01,0x4c,0x00,0xad,0x01,0x4c,0x00,0xa1,0x01,0x4d,0x00,0x96,0x01,0x4d,0x00,0x8b,0x01,0x4d,0x00,0x80,0x01,0x4d,0x00,0x74,0x01,0x4d,0x00,0x69,0x01,0x4d,0x00,  \
    0x5e,0x01,0x4d,0x00,0x53,0x01,0x4d,0x00,0x48,0x01,0x4d,0x00,0x3d,0x01,0x4d,0x00,0x32,0x01,0x4d,0x00,0x27,0x01,0x4d,0x00,0x1c,0x01,0x4d,0x00,0x11,0x01,0x4d,0x00,0x06,0x01,0x4d,0x00,0xfb,0x00,0x4d,0x00,0xf0,0x00,0x4d,0x00,0xe5,0x00,0x4d,0x00,0xda,0x00,0x4d,0x00,0xcf,0x00,0x4d,0x00,0xc5,0x00,0x4d,0x00,0xba,0x00,0x4d,0x00,0xaf,0x00,0x4d,0x00,0xa4,0x00,0x4d,0x00,0x9a,0x00,0x4d,0x00,0x8f,0x00,0x4d,0x00,0x84,0x00,0x4d,0x00,0x79,0x00,0x4d,0x00,0x6f,0x00,  \
    0x4d,0x00,0x64,0x00,0x4d,0x00,0x59,0x00,0x4d,0x00,0x4f,0x00,0x4d,0x00,0x44,0x00,0x4d,0x00,0x3a,0x00,0x4d,0x00,0x2f,0x00,0x4d,0x00,0x24,0x00,0x4d,0x00,0x1a,0x00,0x4d,0x00,0x0f,0x00,0x4d,0x00,0x05,0x00,0x4d,0x00,0xfa,0xff,0x4d,0x00,0xf0,0xff,0x4d,0x00,0xe5,0xff,0x4d,0x00,0xda,0xff,0x4d,0x00,0xd0,0xff,0x4d,0x00,0xc5,0xff,0x4d,0x00,0xbb,0xff,0x4d,0x00,0xb0,0xff,0x4d,0x00,0xa6,0xff,0x4d,0x00,0x9b,0xff,0x4d,0x00,0x91,0xff,0x4d,0x00,0x86,0xff,0x4d,0x00,  \
    0x7b,0xff,0x4d,0x00,0x71,0xff,0x4d,0x00,0x66,0xff,0x4d,0x00,0x5c,0xff,0x4d,0x00,0x51,0xff,0x4d,0x00,0x47,0xff,0x4d,0x00,0x3c,0xff,0x4d,0x00,0x31,0xff,0x4d,0x00,0x27,0xff,0x4d,0x00,0x1c,0xff,0x4d,0x00,0x11,0xff,0x4d,0x00,0x07,0xff,0x4d,0x00,0xfc,0xfe,0x4d,0x00,0xf1,0xfe,0x4d,0x00,0xe7,0xfe,0x4d,0x00,0xdc,0xfe,0x4d,0x00,0xd1,0xfe,0x4d,0x00,0xc7,0xfe,0x4d,0x00,0xbc,0xfe,0x4d,0x00,0xb1,0xfe,0x4d,0x00,0xa6,0xfe,0x4d,0x00,0x9c,0xfe,0x4d,0x00,0x91,0xfe,  \
    0x4d,0x00,0x86,0xfe,0x4d,0x00,0x7b,0xfe,0x4d,0x00,0x70,0xfe,0x4d,0x00,0x65,0xfe,0x4d,0x00,0x5a,0xfe,0x4d,0x00,0x4f,0xfe,0x4d,0x00,0x44,0xfe,0x4d,0x00,0x39,0xfe,0x4d,0x00,0x2e,0xfe,0x4d,0x00,0x23,0xfe,0x4d,0x00,0x18,0xfe,0x4d,0x00,0x0d,0xfe,0x4d,0x00,0x02,0xfe,0x4d,0x00,0xf7,0xfd,0x4d,0x00,0xec,0xfd,0x4c,0x00,0xe0,0xfd,0x4c,0x00,0xd5,0xfd,0x4c,0x00,0xca,0xfd,0x4c,0x00,0xbf,0xfd,0x4c,0x00,0xb3,0xfd,0x4c,0x00,0xa8,0xfd,0x4c,0x00,0x9c,0xfd,0x4c,0x00,  \
    0x91,0xfd,0x4c,0x00,0x85,0xfd,0x4c,0x00,0x7a,0xfd,0x4c,0x00,0x6e,0xfd,0x4c,0x00,0x63,0xfd,0x4c,0x00,0x57,0xfd,0x4c,0x00,0x4b,0xfd,0x4c,0x00,0x40,0xfd,0x4c,0x00,0x34,0xfd,0x4c,0x00,0x28,0xfd,0x4c,0x00,0x1c,0xfd,0x4c,0x00,0x10,0xfd,0x4c,0x00,0x04,0xfd,0x4c,0x00,0xf8,0xfc,0x4c,0x00,0xec,0xfc,0x4c,0x00,0xe0,0xfc,0x4c,0x00,0xd4,0xfc,0x4c,0x00,0xc8,0xfc,0x4c,0x00,0xbc,0xfc,0x4c,0x00,0xaf,0xfc,0x4c,0x00,0xa3,0xfc,0x4c,0x00,0x97,0xfc,0x4c,0x00,0x8a,0xfc,  \
    0x4c,0x00,0x7e,0xfc,0x4c,0x00,0x71,0xfc,0x4c,0x00,0x64,0xfc,0x4c,0x00,0x58,0xfc,0x4c,0x00,0x4b,0xfc,0x4c,0x00,0x3e,0xfc,0x4c,0x00,0x31,0xfc,0x4c,0x00,0x25,0xfc,0x4c,0x00,0x18,0xfc,0x4c,0x00,0x0b,0xfc,0x4c,0x00,0xfe,0xfb,0x4c,0x00,0xf0,0xfb,0x4c,0x00,0xe3,0xfb,0x4c,0x00,0xd6,0xfb,0x4c,0x00,0xc9,0xfb,0x4c,0x00,0xbb,0xfb,0x4b,0x00,0xae,0xfb,0x4b,0x00,0xa0,0xfb,0x4b,0x00,0x93,0xfb,0x4b,0x00,0x85,0xfb,0x4b,0x00,0x78,0xfb,0x4b,0x00,0x6a,0xfb,0x4b,0x00,  \
    0x5c,0xfb,0x4b,0x00,0x4e,0xfb,0x4b,0x00,0x40,0xfb,0x4b,0x00,0x32,0xfb,0x4b,0x00,0x24,0xfb,0x4b,0x00,0x16,0xfb,0x4b,0x00,0x08,0xfb,0x4b,0x00,0xf9,0xfa,0x4b,0x00,0xeb,0xfa,0x4b,0x00,0xdd,0xfa,0x4b,0x00,0xce,0xfa,0x4b,0x00,0xbf,0xfa,0x4b,0x00,0xb1,0xfa,0x4b,0x00,0xa2,0xfa,0x4b,0x00,0x93,0xfa,0x4b,0x00,0x84,0xfa,0x4b,0x00,0x75,0xfa,0x4b,0x00,0x66,0xfa,0x4b,0x00,0x57,0xfa,0x4b,0x00,0x48,0xfa,0x4b,0x00,0x38,0xfa,0x4b,0x00,0x29,0xfa,0x4b,0x00,0x1a,0xfa,  \
    0x4b,0x00,0x0a,0xfa,0x4b,0x00,0xfa,0xf9,0x4a,0x00,0xeb,0xf9,0x4a,0x00,0xdb,0xf9,0x4a,0x00,0xcb,0xf9,0x4a,0x00,0xbb,0xf9,0x4a,0x00,0xab,0xf9,0x4a,0x00,0x9b,0xf9,0x4a,0x00,0x8b,0xf9,0x4a,0x00,0x7a,0xf9,0x4a,0x00,0x6a,0xf9,0x4a,0x00,0x5a,0xf9,0x4a,0x00,0x49,0xf9,0x4a,0x00,0x38,0xf9,0x4a,0x00,0x28,0xf9,0x4a,0x00,0x17,0xf9,0x4a,0x00,0x06,0xf9,0x4a,0x00,0xf5,0xf8,0x4a,0x00,0xe4,0xf8,0x4a,0x00,0xd2,0xf8,0x4a,0x00,0xc1,0xf8,0x4a,0x00,0xb0,0xf8,0x4a,0x00,  \
    0x9e,0xf8,0x4a,0x00,0x8d,0xf8,0x4a,0x00,0x7b,0xf8,0x4a,0x00,0x69,0xf8,0x4a,0x00,0x57,0xf8,0x4a,0x00,0x45,0xf8,0x4a,0x00,0x33,0xf8,0x4a,0x00,0x21,0xf8,0x49,0x00,0x0f,0xf8,0x49,0x00,0xfc,0xf7,0x49,0x00,0xea,0xf7,0x49,0x00,0xd7,0xf7,0x49,0x00,0xc5,0xf7,0x49,0x00,0xb2,0xf7,0x49,0x00,0x9f,0xf7,0x49,0x00,0x8c,0xf7,0x49,0x00,0x79,0xf7,0x49,0x00,0x66,0xf7,0x49,0x00,0x53,0xf7,0x49,0x00,0x3f,0xf7,0x49,0x00,0x2c,0xf7,0x49,0x00,0x18,0xf7,0x49,0x00,0x04,0xf7,  \
    0x49,0x00,0xf1,0xf6,0x49,0x00,0xdd,0xf6,0x49,0x00,0xc9,0xf6,0x49,0x00,0xb5,0xf6,0x49,0x00,0xa0,0xf6,0x49,0x00,0x8c,0xf6,0x49,0x00,0x78,0xf6,0x49,0x00,0x63,0xf6,0x49,0x00,0x4e,0xf6,0x49,0x00,0x3a,0xf6,0x49,0x00,0x25,0xf6,0x49,0x00,0x10,0xf6,0x48,0x00,0xfb,0xf5,0x48,0x00,0xe5,0xf5,0x48,0x00,0xd0,0xf5,0x48,0x00,0xbb,0xf5,0x48,0x00,0xa5,0xf5,0x48,0x00,0x8f,0xf5,0x48,0x00,0x7a,0xf5,0x48,0x00,0x64,0xf5,0x48,0x00,0x4e,0xf5,0x48,0x00,0x38,0xf5,0x48,0x00,  \
    0x21,0xf5,0x48,0x00,0x0b,0xf5,0x48,0x00,0xf4,0xf4,0x48,0x00,0xde,0xf4,0x48,0x00,0xc7,0xf4,0x48,0x00,0xb0,0xf4,0x48,0x00,0x99,0xf4,0x48,0x00,0x82,0xf4,0x48,0x00,0x6b,0xf4,0x48,0x00,0x54,0xf4,0x48,0x00,0x3c,0xf4,0x48,0x00,0x25,0xf4,0x48,0x00,0x0d,0xf4,0x48,0x00,0xf5,0xf3,0x48,0x00,0xde,0xf3,0x48,0x00,0xc6,0xf3,0x48,0x00,0xad,0xf3,0x48,0x00,0x95,0xf3,0x48,0x00,0x7d,0xf3,0x48,0x00,0x64,0xf3,0x48,0x00,0x4c,0xf3,0x47,0x00,0x33,0xf3,0x47,0x00,0x1a,0xf3,  \
    0x47,0x00,0x01,0xf3,0x47,0x00,0xe8,0xf2,0x47,0x00,0xcf,0xf2,0x47,0x00,0xb5,0xf2,0x47,0x00,0x9c,0xf2,0x47,0x00,0x82,0xf2,0x47,0x00,0x68,0xf2,0x47,0x00,0x4f,0xf2,0x47,0x00,0x35,0xf2,0x47,0x00,0x1b,0xf2,0x47,0x00,0x00,0xf2,0x47,0x00,0xe6,0xf1,0x47,0x00,0xcb,0xf1,0x47,0x00,0xb1,0xf1,0x47,0x00,0x96,0xf1,0x47,0x00,0x7b,0xf1,0x47,0x00,0x60,0xf1,0x47,0x00,0x45,0xf1,0x47,0x00,0x2a,0xf1,0x47,0x00,0x0e,0xf1,0x47,0x00,0xf3,0xf0,0x47,0x00,0xd7,0xf0,0x47,0x00,  \
    0xbc,0xf0,0x47,0x00,0xa0,0xf0,0x47,0x00,0x84,0xf0,0x47,0x00,0x68,0xf0,0x47,0x00,0x4b,0xf0,0x47,0x00,0x2f,0xf0,0x47,0x00,0x12,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3d,0x00,0xfe,0x0f,  \
    0x3d,0x00,0xe1,0x0f,0x3d,0x00,0xc5,0x0f,0x3d,0x00,0xa8,0x0f,0x3d,0x00,0x8c,0x0f,0x3d,0x00,0x70,0x0f,0x3e,0x00,0x54,0x0f,0x3e,0x00,0x38,0x0f,0x3e,0x00,0x1c,0x0f,0x3e,0x00,0x00,0x0f,0x3e,0x00,0xe4,0x0e,0x3e,0x00,0xc9,0x0e,0x3e,0x00,0xae,0x0e,0x3e,0x00,0x92,0x0e,0x3e,0x00,0x77,0x0e,0x3e,0x00,0x5c,0x0e,0x3e,0x00,0x41,0x0e,0x3e,0x00,0x26,0x0e,0x3e,0x00,0x0c,0x0e,0x3e,0x00,0xf1,0x0d,0x3f,0x00,0xd7,0x0d,0x3f,0x00,0xbc,0x0d,0x3f,0x00,0xa2,0x0d,0x3f,0x00,  \
    0x88,0x0d,0x3f,0x00,0x6e,0x0d,0x3f,0x00,0x54,0x0d,0x3f,0x00,0x3b,0x0d,0x3f,0x00,0x21,0x0d,0x3f,0x00,0x07,0x0d,0x3f,0x00,0xee,0x0c,0x3f,0x00,0xd5,0x0c,0x40,0x00,0xbc,0x0c,0x40,0x00,0xa3,0x0c,0x40,0x00,0x8a,0x0c,0x40,0x00,0x71,0x0c,0x40,0x00,0x58,0x0c,0x40,0x00,0x40,0x0c,0x40,0x00,0x27,0x0c,0x40,0x00,0x0f,0x0c,0x40,0x00,0xf7,0x0b,0x40,0x00,0xdf,0x0b,0x41,0x00,0xc7,0x0b,0x41,0x00,0xaf,0x0b,0x41,0x00,0x97,0x0b,0x41,0x00,0x7f,0x0b,0x41,0x00,0x68,0x0b,  \
    0x41,0x00,0x50,0x0b,0x41,0x00,0x39,0x0b,0x41,0x00,0x22,0x0b,0x41,0x00,0x0b,0x0b,0x42,0x00,0xf4,0x0a,0x42,0x00,0xdd,0x0a,0x42,0x00,0xc6,0x0a,0x42,0x00,0xb0,0x0a,0x42,0x00,0x99,0x0a,0x42,0x00,0x83,0x0a,0x42,0x00,0x6c,0x0a,0x42,0x00,0x56,0x0a,0x42,0x00,0x40,0x0a,0x43,0x00,0x2a,0x0a,0x43,0x00,0x14,0x0a,0x43,0x00,0xff,0x09,0x43,0x00,0xe9,0x09,0x43,0x00,0xd3,0x09,0x43,0x00,0xbe,0x09,0x43,0x00,0xa9,0x09,0x43,0x00,0x94,0x09,0x44,0x00,0x7e,0x09,0x44,0x00,  \
    0x69,0x09,0x44,0x00,0x55,0x09,0x44,0x00,0x40,0x09,0x44,0x00,0x2b,0x09,0x44,0x00,0x17,0x09,0x44,0x00,0x02,0x09,0x44,0x00,0xee,0x08,0x45,0x00,0xda,0x08,0x45,0x00,0xc5,0x08,0x45,0x00,0xb1,0x08,0x45,0x00,0x9d,0x08,0x45,0x00,0x8a,0x08,0x45,0x00,0x76,0x08,0x45,0x00,0x62,0x08,0x45,0x00,0x4f,0x08,0x46,0x00,0x3b,0x08,0x46,0x00,0x28,0x08,0x46,0x00,0x15,0x08,0x46,0x00,0x02,0x08,0x46,0x00,0xef,0x07,0x46,0x00,0xdc,0x07,0x46,0x00,0xc9,0x07,0x46,0x00,0xb6,0x07,  \
    0x47,0x00,0xa3,0x07,0x47,0x00,0x91,0x07,0x47,0x00,0x7f,0x07,0x47,0x00,0x6c,0x07,0x47,0x00,0x5a,0x07,0x47,0x00,0x48,0x07,0x47,0x00,0x36,0x07,0x47,0x00,0x24,0x07,0x48,0x00,0x12,0x07,0x48,0x00,0x00,0x07,0x48,0x00,0xee,0x06,0x48,0x00,0xdd,0x06,0x48,0x00,0xcb,0x06,0x48,0x00,0xba,0x06,0x48,0x00,0xa9,0x06,0x48,0x00,0x98,0x06,0x49,0x00,0x86,0x06,0x49,0x00,0x75,0x06,0x49,0x00,0x64,0x06,0x49,0x00,0x54,0x06,0x49,0x00,0x43,0x06,0x49,0x00,0x32,0x06,0x49,0x00,  \
    0x22,0x06,0x49,0x00,0x11,0x06,0x4a,0x00,0x01,0x06,0x4a,0x00,0xf0,0x05,0x4a,0x00,0xe0,0x05,0x4a,0x00,0xd0,0x05,0x4a,0x00,0xc0,0x05,0x4a,0x00,0xb0,0x05,0x4a,0x00,0xa0,0x05,0x4a,0x00,0x90,0x05,0x4a,0x00,0x80,0x05,0x4b,0x00,0x71,0x05,0x4b,0x00,0x61,0x05,0x4b,0x00,0x52,0x05,0x4b,0x00,0x42,0x05,0x4b,0x00,0x33,0x05,0x4b,0x00,0x24,0x05,0x4b,0x00,0x14,0x05,0x4b,0x00,0x05,0x05,0x4c,0x00,0xf6,0x04,0x4c,0x00,0xe7,0x04,0x4c,0x00,0xd8,0x04,0x4c,0x00,0xca,0x04,  \
    0x4c,0x00,0xbb,0x04,0x4c,0x00,0xac,0x04,0x4c,0x00,0x9e,0x04,0x4c,0x00,0x8f,0x04,0x4c,0x00,0x81,0x04,0x4c,0x00,0x72,0x04,0x4d,0x00,0x64,0x04,0x4d,0x00,0x56,0x04,0x4d,0x00,0x48,0x04,0x4d,0x00,0x3a,0x04,0x4d,0x00,0x2c,0x04,0x4d,0x00,0x1e,0x04,0x4d,0x00,0x10,0x04,0x4d,0x00,0x02,0x04,0x4d,0x00,0xf4,0x03,0x4e,0x00,0xe6,0x03,0x4e,0x00,0xd9,0x03,0x4e,0x00,0xcb,0x03,0x4e,0x00,0xbe,0x03,0x4e,0x00,0xb0,0x03,0x4e,0x00,0xa3,0x03,0x4e,0x00,0x96,0x03,0x4e,0x00,  \
    0x88,0x03,0x4e,0x00,0x7b,0x03,0x4e,0x00,0x6e,0x03,0x4e,0x00,0x61,0x03,0x4f,0x00,0x54,0x03,0x4f,0x00,0x47,0x03,0x4f,0x00,0x3a,0x03,0x4f,0x00,0x2d,0x03,0x4f,0x00,0x21,0x03,0x4f,0x00,0x14,0x03,0x4f,0x00,0x07,0x03,0x4f,0x00,0xfb,0x02,0x4f,0x00,0xee,0x02,0x4f,0x00,0xe2,0x02,0x4f,0x00,0xd5,0x02,0x4f,0x00,0xc9,0x02,0x50,0x00,0xbc,0x02,0x50,0x00,0xb0,0x02,0x50,0x00,0xa4,0x02,0x50,0x00,0x98,0x02,0x50,0x00,0x8b,0x02,0x50,0x00,0x7f,0x02,0x50,0x00,0x73,0x02,  \
    0x50,0x00,0x67,0x02,0x50,0x00,0x5b,0x02,0x50,0x00,0x4f,0x02,0x50,0x00,0x44,0x02,0x50,0x00,0x38,0x02,0x50,0x00,0x2c,0x02,0x50,0x00,0x20,0x02,0x50,0x00,0x14,0x02,0x51,0x00,0x09,0x02,0x51,0x00,0xfd,0x01,0x51,0x00,0xf2,0x01,0x51,0x00,0xe6,0x01,0x51,0x00,0xda,0x01,0x51,0x00,0xcf,0x01,0x51,0x00,0xc4,0x01,0x51,0x00,0xb8,0x01,0x51,0x00,0xad,0x01,0x51,0x00,0xa1,0x01,0x51,0x00,0x96,0x01,0x51,0x00,0x8b,0x01,0x51,0x00,0x80,0x01,0x51,0x00,0x74,0x01,0x51,0x00,  \
    0x69,0x01,0x51,0x00,0x5e,0x01,0x51,0x00,0x53,0x01,0x51,0x00,0x48,0x01,0x51,0x00,0x3d,0x01,0x52,0x00,0x32,0x01,0x52,0x00,0x27,0x01,0x52,0x00,0x1c,0x01,0x52,0x00,0x11,0x01,0x52,0x00,0x06,0x01,0x52,0x00,0xfb,0x00,0x52,0x00,0xf0,0x00,0x52,0x00,0xe5,0x00,0x52,0x00,0xda,0x00,0x52,0x00,0xcf,0x00,0x52,0x00,0xc5,0x00,0x52,0x00,0xba,0x00,0x52,0x00,0xaf,0x00,0x52,0x00,0xa4,0x00,0x52,0x00,0x9a,0x00,0x52,0x00,0x8f,0x00,0x52,0x00,0x84,0x00,0x52,0x00,0x7a,0x00,  \
    0x52,0x00,0x6f,0x00,0x52,0x00,0x64,0x00,0x52,0x00,0x5a,0x00,0x52,0x00,0x4f,0x00,0x52,0x00,0x44,0x00,0x52,0x00,0x3a,0x00,0x52,0x00,0x2f,0x00,0x52,0x00,0x24,0x00,0x52,0x00,0x1a,0x00,0x52,0x00,0x0f,0x00,0x52,0x00,0x05,0x00,0x52,0x00,0xfa,0xff,0x52,0x00,0xf0,0xff,0x52,0x00,0xe5,0xff,0x52,0x00,0xda,0xff,0x52,0x00,0xd0,0xff,0x52,0x00,0xc5,0xff,0x52,0x00,0xbb,0xff,0x52,0x00,0xb0,0xff,0x52,0x00,0xa6,0xff,0x52,0x00,0x9b,0xff,0x52,0x00,0x91,0xff,0x52,0x00,  \
    0x86,0xff,0x52,0x00,0x7b,0xff,0x52,0x00,0x71,0xff,0x52,0x00,0x66,0xff,0x52,0x00,0x5c,0xff,0x52,0x00,0x51,0xff,0x52,0x00,0x47,0xff,0x52,0x00,0x3c,0xff,0x52,0x00,0x31,0xff,0x52,0x00,0x27,0xff,0x52,0x00,0x1c,0xff,0x52,0x00,0x11,0xff,0x52,0x00,0x07,0xff,0x52,0x00,0xfc,0xfe,0x52,0x00,0xf1,0xfe,0x52,0x00,0xe7,0xfe,0x52,0x00,0xdc,0xfe,0x52,0x00,0xd1,0xfe,0x52,0x00,0xc7,0xfe,0x52,0x00,0xbc,0xfe,0x52,0x00,0xb1,0xfe,0x52,0x00,0xa6,0xfe,0x52,0x00,0x9c,0xfe,  \
    0x52,0x00,0x91,0xfe,0x52,0x00,0x86,0xfe,0x52,0x00,0x7b,0xfe,0x52,0x00,0x70,0xfe,0x52,0x00,0x65,0xfe,0x52,0x00,0x5a,0xfe,0x52,0x00,0x4f,0xfe,0x51,0x00,0x44,0xfe,0x51,0x00,0x39,0xfe,0x51,0x00,0x2e,0xfe,0x51,0x00,0x23,0xfe,0x51,0x00,0x18,0xfe,0x51,0x00,0x0d,0xfe,0x51,0x00,0x02,0xfe,0x51,0x00,0xf7,0xfd,0x51,0x00,0xec,0xfd,0x51,0x00,0xe0,0xfd,0x51,0x00,0xd5,0xfd,0x51,0x00,0xca,0xfd,0x51,0x00,0xbf,0xfd,0x51,0x00,0xb3,0xfd,0x51,0x00,0xa8,0xfd,0x51,0x00,  \
    0x9c,0xfd,0x51,0x00,0x91,0xfd,0x51,0x00,0x85,0xfd,0x51,0x00,0x7a,0xfd,0x50,0x00,0x6e,0xfd,0x50,0x00,0x63,0xfd,0x50,0x00,0x57,0xfd,0x50,0x00,0x4b,0xfd,0x50,0x00,0x40,0xfd,0x50,0x00,0x34,0xfd,0x50,0x00,0x28,0xfd,0x50,0x00,0x1c,0xfd,0x50,0x00,0x10,0xfd,0x50,0x00,0x04,0xfd,0x50,0x00,0xf8,0xfc,0x50,0x00,0xec,0xfc,0x50,0x00,0xe0,0xfc,0x50,0x00,0xd4,0xfc,0x4f,0x00,0xc8,0xfc,0x4f,0x00,0xbb,0xfc,0x4f,0x00,0xaf,0xfc,0x4f,0x00,0xa3,0xfc,0x4f,0x00,0x96,0xfc,  \
    0x4f,0x00,0x8a,0xfc,0x4f,0x00,0x7e,0xfc,0x4f,0x00,0x71,0xfc,0x4f,0x00,0x64,0xfc,0x4f,0x00,0x58,0xfc,0x4f,0x00,0x4b,0xfc,0x4f,0x00,0x3e,0xfc,0x4e,0x00,0x31,0xfc,0x4e,0x00,0x25,0xfc,0x4e,0x00,0x18,0xfc,0x4e,0x00,0x0b,0xfc,0x4e,0x00,0xfe,0xfb,0x4e,0x00,0xf0,0xfb,0x4e,0x00,0xe3,0xfb,0x4e,0x00,0xd6,0xfb,0x4e,0x00,0xc9,0xfb,0x4e,0x00,0xbb,0xfb,0x4e,0x00,0xae,0xfb,0x4d,0x00,0xa0,0xfb,0x4d,0x00,0x93,0xfb,0x4d,0x00,0x85,0xfb,0x4d,0x00,0x78,0xfb,0x4d,0x00,  \
    0x6a,0xfb,0x4d,0x00,0x5c,0xfb,0x4d,0x00,0x4e,0xfb,0x4d,0x00,0x40,0xfb,0x4d,0x00,0x32,0xfb,0x4d,0x00,0x24,0xfb,0x4c,0x00,0x16,0xfb,0x4c,0x00,0x08,0xfb,0x4c,0x00,0xf9,0xfa,0x4c,0x00,0xeb,0xfa,0x4c,0x00,0xdc,0xfa,0x4c,0x00,0xce,0xfa,0x4c,0x00,0xbf,0xfa,0x4c,0x00,0xb1,0xfa,0x4c,0x00,0xa2,0xfa,0x4b,0x00,0x93,0xfa,0x4b,0x00,0x84,0xfa,0x4b,0x00,0x75,0xfa,0x4b,0x00,0x66,0xfa,0x4b,0x00,0x57,0xfa,0x4b,0x00,0x48,0xfa,0x4b,0x00,0x38,0xfa,0x4b,0x00,0x29,0xfa,  \
    0x4a,0x00,0x1a,0xfa,0x4a,0x00,0x0a,0xfa,0x4a,0x00,0xfa,0xf9,0x4a,0x00,0xeb,0xf9,0x4a,0x00,0xdb,0xf9,0x4a,0x00,0xcb,0xf9,0x4a,0x00,0xbb,0xf9,0x4a,0x00,0xab,0xf9,0x4a,0x00,0x9b,0xf9,0x49,0x00,0x8b,0xf9,0x49,0x00,0x7a,0xf9,0x49,0x00,0x6a,0xf9,0x49,0x00,0x59,0xf9,0x49,0x00,0x49,0xf9,0x49,0x00,0x38,0xf9,0x49,0x00,0x27,0xf9,0x49,0x00,0x17,0xf9,0x48,0x00,0x06,0xf9,0x48,0x00,0xf5,0xf8,0x48,0x00,0xe3,0xf8,0x48,0x00,0xd2,0xf8,0x48,0x00,0xc1,0xf8,0x48,0x00,  \
    0xb0,0xf8,0x48,0x00,0x9e,0xf8,0x48,0x00,0x8d,0xf8,0x47,0x00,0x7b,0xf8,0x47,0x00,0x69,0xf8,0x47,0x00,0x57,0xf8,0x47,0x00,0x45,0xf8,0x47,0x00,0x33,0xf8,0x47,0x00,0x21,0xf8,0x47,0x00,0x0f,0xf8,0x47,0x00,0xfc,0xf7,0x46,0x00,0xea,0xf7,0x46,0x00,0xd7,0xf7,0x46,0x00,0xc5,0xf7,0x46,0x00,0xb2,0xf7,0x46,0x00,0x9f,0xf7,0x46,0x00,0x8c,0xf7,0x46,0x00,0x79,0xf7,0x45,0x00,0x66,0xf7,0x45,0x00,0x53,0xf7,0x45,0x00,0x3f,0xf7,0x45,0x00,0x2c,0xf7,0x45,0x00,0x18,0xf7,  \
    0x45,0x00,0x04,0xf7,0x45,0x00,0xf1,0xf6,0x45,0x00,0xdd,0xf6,0x44,0x00,0xc9,0xf6,0x44,0x00,0xb4,0xf6,0x44,0x00,0xa0,0xf6,0x44,0x00,0x8c,0xf6,0x44,0x00,0x77,0xf6,0x44,0x00,0x63,0xf6,0x44,0x00,0x4e,0xf6,0x44,0x00,0x39,0xf6,0x43,0x00,0x25,0xf6,0x43,0x00,0x10,0xf6,0x43,0x00,0xfa,0xf5,0x43,0x00,0xe5,0xf5,0x43,0x00,0xd0,0xf5,0x43,0x00,0xba,0xf5,0x43,0x00,0xa5,0xf5,0x43,0x00,0x8f,0xf5,0x42,0x00,0x79,0xf5,0x42,0x00,0x64,0xf5,0x42,0x00,0x4e,0xf5,0x42,0x00,  \
    0x37,0xf5,0x42,0x00,0x21,0xf5,0x42,0x00,0x0b,0xf5,0x42,0x00,0xf4,0xf4,0x42,0x00,0xde,0xf4,0x42,0x00,0xc7,0xf4,0x41,0x00,0xb0,0xf4,0x41,0x00,0x99,0xf4,0x41,0x00,0x82,0xf4,0x41,0x00,0x6b,0xf4,0x41,0x00,0x54,0xf4,0x41,0x00,0x3c,0xf4,0x41,0x00,0x25,0xf4,0x41,0x00,0x0d,0xf4,0x40,0x00,0xf5,0xf3,0x40,0x00,0xdd,0xf3,0x40,0x00,0xc5,0xf3,0x40,0x00,0xad,0xf3,0x40,0x00,0x95,0xf3,0x40,0x00,0x7d,0xf3,0x40,0x00,0x64,0xf3,0x40,0x00,0x4c,0xf3,0x40,0x00,0x33,0xf3,  \
    0x40,0x00,0x1a,0xf3,0x3f,0x00,0x01,0xf3,0x3f,0x00,0xe8,0xf2,0x3f,0x00,0xcf,0xf2,0x3f,0x00,0xb5,0xf2,0x3f,0x00,0x9c,0xf2,0x3f,0x00,0x82,0xf2,0x3f,0x00,0x68,0xf2,0x3f,0x00,0x4f,0xf2,0x3f,0x00,0x35,0xf2,0x3f,0x00,0x1a,0xf2,0x3f,0x00,0x00,0xf2,0x3e,0x00,0xe6,0xf1,0x3e,0x00,0xcb,0xf1,0x3e,0x00,0xb1,0xf1,0x3e,0x00,0x96,0xf1,0x3e,0x00,0x7b,0xf1,0x3e,0x00,0x60,0xf1,0x3e,0x00,0x45,0xf1,0x3e,0x00,0x2a,0xf1,0x3e,0x00,0x0e,0xf1,0x3e,0x00,0xf3,0xf0,0x3e,0x00,  \
    0xd7,0xf0,0x3e,0x00,0xbc,0xf0,0x3e,0x00,0xa0,0xf0,0x3e,0x00,0x84,0xf0,0x3e,0x00,0x67,0xf0,0x3d,0x00,0x4b,0xf0,0x3d,0x00,0x2f,0xf0,0x3d,0x00,0x12,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x33,0x00,0xfe,0x0f,0x33,0x00,0xe2,0x0f,0x34,0x00,0xc5,0x0f,0x34,0x00,0xa9,0x0f,0x34,0x00,0x8c,0x0f,0x34,0x00,0x70,0x0f,0x34,0x00,0x54,0x0f,0x34,0x00,0x38,0x0f,0x34,0x00,0x1c,0x0f,0x34,0x00,0x00,0x0f,0x34,0x00,0xe5,0x0e,0x34,0x00,0xc9,0x0e,0x35,0x00,0xae,0x0e,0x35,0x00,0x93,0x0e,0x35,0x00,0x77,0x0e,0x35,0x00,0x5c,0x0e,0x35,0x00,0x41,0x0e,0x35,0x00,0x27,0x0e,0x35,0x00,0x0c,0x0e,0x35,0x00,0xf1,0x0d,0x36,0x00,0xd7,0x0d,0x36,0x00,0xbd,0x0d,0x36,0x00,  \
    0xa2,0x0d,0x36,0x00,0x88,0x0d,0x36,0x00,0x6e,0x0d,0x36,0x00,0x55,0x0d,0x37,0x00,0x3b,0x0d,0x37,0x00,0x21,0x0d,0x37,0x00,0x08,0x0d,0x37,0x00,0xee,0x0c,0x37,0x00,0xd5,0x0c,0x37,0x00,0xbc,0x0c,0x37,0x00,0xa3,0x0c,0x38,0x00,0x8a,0x0c,0x38,0x00,0x71,0x0c,0x38,0x00,0x58,0x0c,0x38,0x00,0x40,0x0c,0x38,0x00,0x27,0x0c,0x39,0x00,0x0f,0x0c,0x39,0x00,0xf7,0x0b,0x39,0x00,0xdf,0x0b,0x39,0x00,0xc7,0x0b,0x39,0x00,0xaf,0x0b,0x39,0x00,0x97,0x0b,0x3a,0x00,0x80,0x0b,  \
    0x3a,0x00,0x68,0x0b,0x3a,0x00,0x51,0x0b,0x3a,0x00,0x39,0x0b,0x3a,0x00,0x22,0x0b,0x3b,0x00,0x0b,0x0b,0x3b,0x00,0xf4,0x0a,0x3b,0x00,0xdd,0x0a,0x3b,0x00,0xc7,0x0a,0x3b,0x00,0xb0,0x0a,0x3c,0x00,0x99,0x0a,0x3c,0x00,0x83,0x0a,0x3c,0x00,0x6d,0x0a,0x3c,0x00,0x56,0x0a,0x3c,0x00,0x40,0x0a,0x3d,0x00,0x2a,0x0a,0x3d,0x00,0x15,0x0a,0x3d,0x00,0xff,0x09,0x3d,0x00,0xe9,0x09,0x3d,0x00,0xd4,0x09,0x3e,0x00,0xbe,0x09,0x3e,0x00,0xa9,0x09,0x3e,0x00,0x94,0x09,0x3e,0x00,  \
    0x7f,0x09,0x3f,0x00,0x6a,0x09,0x3f,0x00,0x55,0x09,0x3f,0x00,0x40,0x09,0x3f,0x00,0x2b,0x09,0x3f,0x00,0x17,0x09,0x40,0x00,0x02,0x09,0x40,0x00,0xee,0x08,0x40,0x00,0xda,0x08,0x40,0x00,0xc6,0x08,0x40,0x00,0xb2,0x08,0x41,0x00,0x9e,0x08,0x41,0x00,0x8a,0x08,0x41,0x00,0x76,0x08,0x41,0x00,0x62,0x08,0x42,0x00,0x4f,0x08,0x42,0x00,0x3c,0x08,0x42,0x00,0x28,0x08,0x42,0x00,0x15,0x08,0x42,0x00,0x02,0x08,0x43,0x00,0xef,0x07,0x43,0x00,0xdc,0x07,0x43,0x00,0xc9,0x07,  \
    0x43,0x00,0xb6,0x07,0x44,0x00,0xa4,0x07,0x44,0x00,0x91,0x07,0x44,0x00,0x7f,0x07,0x44,0x00,0x6c,0x07,0x44,0x00,0x5a,0x07,0x45,0x00,0x48,0x07,0x45,0x00,0x36,0x07,0x45,0x00,0x24,0x07,0x45,0x00,0x12,0x07,0x45,0x00,0x00,0x07,0x46,0x00,0xef,0x06,0x46,0x00,0xdd,0x06,0x46,0x00,0xcc,0x06,0x46,0x00,0xba,0x06,0x47,0x00,0xa9,0x06,0x47,0x00,0x98,0x06,0x47,0x00,0x87,0x06,0x47,0x00,0x76,0x06,0x47,0x00,0x65,0x06,0x48,0x00,0x54,0x06,0x48,0x00,0x43,0x06,0x48,0x00,  \
    0x32,0x06,0x48,0x00,0x22,0x06,0x48,0x00,0x11,0x06,0x49,0x00,0x01,0x06,0x49,0x00,0xf1,0x05,0x49,0x00,0xe0,0x05,0x49,0x00,0xd0,0x05,0x49,0x00,0xc0,0x05,0x4a,0x00,0xb0,0x05,0x4a,0x00,0xa0,0x05,0x4a,0x00,0x90,0x05,0x4a,0x00,0x81,0x05,0x4a,0x00,0x71,0x05,0x4b,0x00,0x61,0x05,0x4b,0x00,0x52,0x05,0x4b,0x00,0x42,0x05,0x4b,0x00,0x33,0x05,0x4b,0x00,0x24,0x05,0x4c,0x00,0x15,0x05,0x4c,0x00,0x05,0x05,0x4c,0x00,0xf6,0x04,0x4c,0x00,0xe7,0x04,0x4c,0x00,0xd9,0x04,  \
    0x4d,0x00,0xca,0x04,0x4d,0x00,0xbb,0x04,0x4d,0x00,0xac,0x04,0x4d,0x00,0x9e,0x04,0x4d,0x00,0x8f,0x04,0x4e,0x00,0x81,0x04,0x4e,0x00,0x73,0x04,0x4e,0x00,0x64,0x04,0x4e,0x00,0x56,0x04,0x4e,0x00,0x48,0x04,0x4e,0x00,0x3a,0x04,0x4f,0x00,0x2c,0x04,0x4f,0x00,0x1e,0x04,0x4f,0x00,0x10,0x04,0x4f,0x00,0x02,0x04,0x4f,0x00,0xf4,0x03,0x4f,0x00,0xe7,0x03,0x50,0x00,0xd9,0x03,0x50,0x00,0xcb,0x03,0x50,0x00,0xbe,0x03,0x50,0x00,0xb1,0x03,0x50,0x00,0xa3,0x03,0x50,0x00,  \
    0x96,0x03,0x51,0x00,0x89,0x03,0x51,0x00,0x7b,0x03,0x51,0x00,0x6e,0x03,0x51,0x00,0x61,0x03,0x51,0x00,0x54,0x03,0x51,0x00,0x47,0x03,0x52,0x00,0x3a,0x03,0x52,0x00,0x2e,0x03,0x52,0x00,0x21,0x03,0x52,0x00,0x14,0x03,0x52,0x00,0x07,0x03,0x52,0x00,0xfb,0x02,0x52,0x00,0xee,0x02,0x53,0x00,0xe2,0x02,0x53,0x00,0xd5,0x02,0x53,0x00,0xc9,0x02,0x53,0x00,0xbd,0x02,0x53,0x00,0xb0,0x02,0x53,0x00,0xa4,0x02,0x53,0x00,0x98,0x02,0x53,0x00,0x8c,0x02,0x54,0x00,0x80,0x02,  \
    0x54,0x00,0x73,0x02,0x54,0x00,0x67,0x02,0x54,0x00,0x5b,0x02,0x54,0x00,0x50,0x02,0x54,0x00,0x44,0x02,0x54,0x00,0x38,0x02,0x54,0x00,0x2c,0x02,0x55,0x00,0x20,0x02,0x55,0x00,0x15,0x02,0x55,0x00,0x09,0x02,0x55,0x00,0xfd,0x01,0x55,0x00,0xf2,0x01,0x55,0x00,0xe6,0x01,0x55,0x00,0xdb,0x01,0x55,0x00,0xcf,0x01,0x55,0x00,0xc4,0x01,0x55,0x00,0xb8,0x01,0x56,0x00,0xad,0x01,0x56,0x00,0xa2,0x01,0x56,0x00,0x96,0x01,0x56,0x00,0x8b,0x01,0x56,0x00,0x80,0x01,0x56,0x00,  \
    0x74,0x01,0x56,0x00,0x69,0x01,0x56,0x00,0x5e,0x01,0x56,0x00,0x53,0x01,0x56,0x00,0x48,0x01,0x56,0x00,0x3d,0x01,0x56,0x00,0x32,0x01,0x56,0x00,0x27,0x01,0x57,0x00,0x1c,0x01,0x57,0x00,0x11,0x01,0x57,0x00,0x06,0x01,0x57,0x00,0xfb,0x00,0x57,0x00,0xf0,0x00,0x57,0x00,0xe5,0x00,0x57,0x00,0xda,0x00,0x57,0x00,0xd0,0x00,0x57,0x00,0xc5,0x00,0x57,0x00,0xba,0x00,0x57,0x00,0xaf,0x00,0x57,0x00,0xa4,0x00,0x57,0x00,0x9a,0x00,0x57,0x00,0x8f,0x00,0x57,0x00,0x84,0x00,  \
    0x57,0x00,0x7a,0x00,0x57,0x00,0x6f,0x00,0x57,0x00,0x64,0x00,0x57,0x00,0x5a,0x00,0x57,0x00,0x4f,0x00,0x57,0x00,0x44,0x00,0x57,0x00,0x3a,0x00,0x57,0x00,0x2f,0x00,0x58,0x00,0x24,0x00,0x58,0x00,0x1a,0x00,0x58,0x00,0x0f,0x00,0x58,0x00,0x05,0x00,0x58,0x00,0xfa,0xff,0x58,0x00,0xf0,0xff,0x58,0x00,0xe5,0xff,0x58,0x00,0xda,0xff,0x58,0x00,0xd0,0xff,0x58,0x00,0xc5,0xff,0x58,0x00,0xbb,0xff,0x58,0x00,0xb0,0xff,0x58,0x00,0xa6,0xff,0x58,0x00,0x9b,0xff,0x58,0x00,  \
    0x90,0xff,0x58,0x00,0x86,0xff,0x58,0x00,0x7b,0xff,0x58,0x00,0x71,0xff,0x58,0x00,0x66,0xff,0x58,0x00,0x5c,0xff,0x57,0x00,0x51,0xff,0x57,0x00,0x46,0xff,0x57,0x00,0x3c,0xff,0x57,0x00,0x31,0xff,0x57,0x00,0x27,0xff,0x57,0x00,0x1c,0xff,0x57,0x00,0x11,0xff,0x57,0x00,0x07,0xff,0x57,0x00,0xfc,0xfe,0x57,0x00,0xf1,0xfe,0x57,0x00,0xe7,0xfe,0x57,0x00,0xdc,0xfe,0x57,0x00,0xd1,0xfe,0x57,0x00,0xc7,0xfe,0x57,0x00,0xbc,0xfe,0x57,0x00,0xb1,0xfe,0x57,0x00,0xa6,0xfe,  \
    0x57,0x00,0x9b,0xfe,0x57,0x00,0x91,0xfe,0x57,0x00,0x86,0xfe,0x57,0x00,0x7b,0xfe,0x57,0x00,0x70,0xfe,0x57,0x00,0x65,0xfe,0x56,0x00,0x5a,0xfe,0x56,0x00,0x4f,0xfe,0x56,0x00,0x44,0xfe,0x56,0x00,0x39,0xfe,0x56,0x00,0x2e,0xfe,0x56,0x00,0x23,0xfe,0x56,0x00,0x18,0xfe,0x56,0x00,0x0d,0xfe,0x56,0x00,0x02,0xfe,0x56,0x00,0xf7,0xfd,0x56,0x00,0xec,0xfd,0x56,0x00,0xe0,0xfd,0x55,0x00,0xd5,0xfd,0x55,0x00,0xca,0xfd,0x55,0x00,0xbe,0xfd,0x55,0x00,0xb3,0xfd,0x55,0x00,  \
    0xa8,0xfd,0x55,0x00,0x9c,0xfd,0x55,0x00,0x91,0xfd,0x55,0x00,0x85,0xfd,0x55,0x00,0x7a,0xfd,0x55,0x00,0x6e,0xfd,0x54,0x00,0x62,0xfd,0x54,0x00,0x57,0xfd,0x54,0x00,0x4b,0xfd,0x54,0x00,0x3f,0xfd,0x54,0x00,0x34,0xfd,0x54,0x00,0x28,0xfd,0x54,0x00,0x1c,0xfd,0x54,0x00,0x10,0xfd,0x54,0x00,0x04,0xfd,0x53,0x00,0xf8,0xfc,0x53,0x00,0xec,0xfc,0x53,0x00,0xe0,0xfc,0x53,0x00,0xd4,0xfc,0x53,0x00,0xc8,0xfc,0x53,0x00,0xbb,0xfc,0x53,0x00,0xaf,0xfc,0x52,0x00,0xa3,0xfc,  \
    0x52,0x00,0x96,0xfc,0x52,0x00,0x8a,0xfc,0x52,0x00,0x7d,0xfc,0x52,0x00,0x71,0xfc,0x52,0x00,0x64,0xfc,0x52,0x00,0x57,0xfc,0x51,0x00,0x4b,0xfc,0x51,0x00,0x3e,0xfc,0x51,0x00,0x31,0xfc,0x51,0x00,0x24,0xfc,0x51,0x00,0x17,0xfc,0x51,0x00,0x0a,0xfc,0x51,0x00,0xfd,0xfb,0x50,0x00,0xf0,0xfb,0x50,0x00,0xe3,0xfb,0x50,0x00,0xd6,0xfb,0x50,0x00,0xc8,0xfb,0x50,0x00,0xbb,0xfb,0x50,0x00,0xae,0xfb,0x4f,0x00,0xa0,0xfb,0x4f,0x00,0x93,0xfb,0x4f,0x00,0x85,0xfb,0x4f,0x00,  \
    0x77,0xfb,0x4f,0x00,0x6a,0xfb,0x4f,0x00,0x5c,0xfb,0x4e,0x00,0x4e,0xfb,0x4e,0x00,0x40,0xfb,0x4e,0x00,0x32,0xfb,0x4e,0x00,0x24,0xfb,0x4e,0x00,0x16,0xfb,0x4d,0x00,0x07,0xfb,0x4d,0x00,0xf9,0xfa,0x4d,0x00,0xeb,0xfa,0x4d,0x00,0xdc,0xfa,0x4d,0x00,0xce,0xfa,0x4c,0x00,0xbf,0xfa,0x4c,0x00,0xb0,0xfa,0x4c,0x00,0xa2,0xfa,0x4c,0x00,0x93,0xfa,0x4c,0x00,0x84,0xfa,0x4c,0x00,0x75,0xfa,0x4b,0x00,0x66,0xfa,0x4b,0x00,0x57,0xfa,0x4b,0x00,0x47,0xfa,0x4b,0x00,0x38,0xfa,  \
    0x4b,0x00,0x29,0xfa,0x4a,0x00,0x19,0xfa,0x4a,0x00,0x0a,0xfa,0x4a,0x00,0xfa,0xf9,0x4a,0x00,0xea,0xf9,0x49,0x00,0xdb,0xf9,0x49,0x00,0xcb,0xf9,0x49,0x00,0xbb,0xf9,0x49,0x00,0xab,0xf9,0x49,0x00,0x9b,0xf9,0x48,0x00,0x8a,0xf9,0x48,0x00,0x7a,0xf9,0x48,0x00,0x6a,0xf9,0x48,0x00,0x59,0xf9,0x48,0x00,0x49,0xf9,0x47,0x00,0x38,0xf9,0x47,0x00,0x27,0xf9,0x47,0x00,0x16,0xf9,0x47,0x00,0x05,0xf9,0x47,0x00,0xf4,0xf8,0x46,0x00,0xe3,0xf8,0x46,0x00,0xd2,0xf8,0x46,0x00,  \
    0xc1,0xf8,0x46,0x00,0xaf,0xf8,0x45,0x00,0x9e,0xf8,0x45,0x00,0x8c,0xf8,0x45,0x00,0x7b,0xf8,0x45,0x00,0x69,0xf8,0x45,0x00,0x57,0xf8,0x44,0x00,0x45,0xf8,0x44,0x00,0x33,0xf8,0x44,0x00,0x21,0xf8,0x44,0x00,0x0e,0xf8,0x43,0x00,0xfc,0xf7,0x43,0x00,0xea,0xf7,0x43,0x00,0xd7,0xf7,0x43,0x00,0xc4,0xf7,0x43,0x00,0xb2,0xf7,0x42,0x00,0x9f,0xf7,0x42,0x00,0x8c,0xf7,0x42,0x00,0x79,0xf7,0x42,0x00,0x66,0xf7,0x41,0x00,0x52,0xf7,0x41,0x00,0x3f,0xf7,0x41,0x00,0x2b,0xf7,  \
    0x41,0x00,0x18,0xf7,0x41,0x00,0x04,0xf7,0x40,0x00,0xf0,0xf6,0x40,0x00,0xdc,0xf6,0x40,0x00,0xc8,0xf6,0x40,0x00,0xb4,0xf6,0x3f,0x00,0xa0,0xf6,0x3f,0x00,0x8c,0xf6,0x3f,0x00,0x77,0xf6,0x3f,0x00,0x63,0xf6,0x3f,0x00,0x4e,0xf6,0x3e,0x00,0x39,0xf6,0x3e,0x00,0x24,0xf6,0x3e,0x00,0x0f,0xf6,0x3e,0x00,0xfa,0xf5,0x3e,0x00,0xe5,0xf5,0x3d,0x00,0xd0,0xf5,0x3d,0x00,0xba,0xf5,0x3d,0x00,0xa5,0xf5,0x3d,0x00,0x8f,0xf5,0x3c,0x00,0x79,0xf5,0x3c,0x00,0x63,0xf5,0x3c,0x00,  \
    0x4d,0xf5,0x3c,0x00,0x37,0xf5,0x3c,0x00,0x21,0xf5,0x3b,0x00,0x0b,0xf5,0x3b,0x00,0xf4,0xf4,0x3b,0x00,0xde,0xf4,0x3b,0x00,0xc7,0xf4,0x3b,0x00,0xb0,0xf4,0x3a,0x00,0x99,0xf4,0x3a,0x00,0x82,0xf4,0x3a,0x00,0x6b,0xf4,0x3a,0x00,0x53,0xf4,0x3a,0x00,0x3c,0xf4,0x39,0x00,0x25,0xf4,0x39,0x00,0x0d,0xf4,0x39,0x00,0xf5,0xf3,0x39,0x00,0xdd,0xf3,0x39,0x00,0xc5,0xf3,0x39,0x00,0xad,0xf3,0x38,0x00,0x95,0xf3,0x38,0x00,0x7c,0xf3,0x38,0x00,0x64,0xf3,0x38,0x00,0x4b,0xf3,  \
    0x38,0x00,0x33,0xf3,0x37,0x00,0x1a,0xf3,0x37,0x00,0x01,0xf3,0x37,0x00,0xe8,0xf2,0x37,0x00,0xce,0xf2,0x37,0x00,0xb5,0xf2,0x37,0x00,0x9c,0xf2,0x37,0x00,0x82,0xf2,0x36,0x00,0x68,0xf2,0x36,0x00,0x4e,0xf2,0x36,0x00,0x34,0xf2,0x36,0x00,0x1a,0xf2,0x36,0x00,0x00,0xf2,0x36,0x00,0xe6,0xf1,0x35,0x00,0xcb,0xf1,0x35,0x00,0xb1,0xf1,0x35,0x00,0x96,0xf1,0x35,0x00,0x7b,0xf1,0x35,0x00,0x60,0xf1,0x35,0x00,0x45,0xf1,0x35,0x00,0x2a,0xf1,0x35,0x00,0x0e,0xf1,0x34,0x00,  \
    0xf3,0xf0,0x34,0x00,0xd7,0xf0,0x34,0x00,0xbb,0xf0,0x34,0x00,0x9f,0xf0,0x34,0x00,0x83,0xf0,0x34,0x00,0x67,0xf0,0x34,0x00,0x4b,0xf0,0x34,0x00,0x2f,0xf0,0x34,0x00,0x12,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x29,0x00,0xff,0x0f,0x29,0x00,0xe2,0x0f,0x29,0x00,0xc5,0x0f,0x2a,0x00,0xa9,0x0f,0x2a,0x00,0x8d,0x0f,0x2a,0x00,0x70,0x0f,0x2a,0x00,0x54,0x0f,0x2a,0x00,0x38,0x0f,0x2a,0x00,0x1c,0x0f,0x2a,0x00,0x01,0x0f,0x2b,0x00,0xe5,0x0e,0x2b,0x00,0xc9,0x0e,0x2b,0x00,0xae,0x0e,0x2b,0x00,0x93,0x0e,0x2b,0x00,0x78,0x0e,0x2b,0x00,0x5d,0x0e,0x2c,0x00,0x42,0x0e,0x2c,0x00,0x27,0x0e,0x2c,0x00,0x0c,0x0e,0x2c,0x00,0xf2,0x0d,0x2c,0x00,0xd7,0x0d,0x2d,0x00,  \
    0xbd,0x0d,0x2d,0x00,0xa3,0x0d,0x2d,0x00,0x89,0x0d,0x2d,0x00,0x6f,0x0d,0x2d,0x00,0x55,0x0d,0x2e,0x00,0x3b,0x0d,0x2e,0x00,0x21,0x0d,0x2e,0x00,0x08,0x0d,0x2e,0x00,0xef,0x0c,0x2f,0x00,0xd5,0x0c,0x2f,0x00,0xbc,0x0c,0x2f,0x00,0xa3,0x0c,0x2f,0x00,0x8a,0x0c,0x30,0x00,0x71,0x0c,0x30,0x00,0x59,0x0c,0x30,0x00,0x40,0x0c,0x30,0x00,0x28,0x0c,0x31,0x00,0x0f,0x0c,0x31,0x00,0xf7,0x0b,0x31,0x00,0xdf,0x0b,0x31,0x00,0xc7,0x0b,0x32,0x00,0xaf,0x0b,0x32,0x00,0x98,0x0b,  \
    0x32,0x00,0x80,0x0b,0x32,0x00,0x68,0x0b,0x33,0x00,0x51,0x0b,0x33,0x00,0x3a,0x0b,0x33,0x00,0x22,0x0b,0x34,0x00,0x0b,0x0b,0x34,0x00,0xf4,0x0a,0x34,0x00,0xde,0x0a,0x34,0x00,0xc7,0x0a,0x35,0x00,0xb0,0x0a,0x35,0x00,0x9a,0x0a,0x35,0x00,0x83,0x0a,0x36,0x00,0x6d,0x0a,0x36,0x00,0x57,0x0a,0x36,0x00,0x41,0x0a,0x36,0x00,0x2b,0x0a,0x37,0x00,0x15,0x0a,0x37,0x00,0xff,0x09,0x37,0x00,0xea,0x09,0x38,0x00,0xd4,0x09,0x38,0x00,0xbf,0x09,0x38,0x00,0xa9,0x09,0x39,0x00,  \
    0x94,0x09,0x39,0x00,0x7f,0x09,0x39,0x00,0x6a,0x09,0x39,0x00,0x55,0x09,0x3a,0x00,0x40,0x09,0x3a,0x00,0x2c,0x09,0x3a,0x00,0x17,0x09,0x3b,0x00,0x03,0x09,0x3b,0x00,0xee,0x08,0x3b,0x00,0xda,0x08,0x3c,0x00,0xc6,0x08,0x3c,0x00,0xb2,0x08,0x3c,0x00,0x9e,0x08,0x3d,0x00,0x8a,0x08,0x3d,0x00,0x76,0x08,0x3d,0x00,0x63,0x08,0x3d,0x00,0x4f,0x08,0x3e,0x00,0x3c,0x08,0x3e,0x00,0x29,0x08,0x3e,0x00,0x15,0x08,0x3f,0x00,0x02,0x08,0x3f,0x00,0xef,0x07,0x3f,0x00,0xdc,0x07,  \
    0x40,0x00,0xc9,0x07,0x40,0x00,0xb7,0x07,0x40,0x00,0xa4,0x07,0x41,0x00,0x92,0x07,0x41,0x00,0x7f,0x07,0x41,0x00,0x6d,0x07,0x42,0x00,0x5b,0x07,0x42,0x00,0x48,0x07,0x42,0x00,0x36,0x07,0x42,0x00,0x24,0x07,0x43,0x00,0x13,0x07,0x43,0x00,0x01,0x07,0x43,0x00,0xef,0x06,0x44,0x00,0xde,0x06,0x44,0x00,0xcc,0x06,0x44,0x00,0xbb,0x06,0x45,0x00,0xa9,0x06,0x45,0x00,0x98,0x06,0x45,0x00,0x87,0x06,0x46,0x00,0x76,0x06,0x46,0x00,0x65,0x06,0x46,0x00,0x54,0x06,0x46,0x00,  \
    0x43,0x06,0x47,0x00,0x33,0x06,0x47,0x00,0x22,0x06,0x47,0x00,0x12,0x06,0x48,0x00,0x01,0x06,0x48,0x00,0xf1,0x05,0x48,0x00,0xe1,0x05,0x49,0x00,0xd1,0x05,0x49,0x00,0xc0,0x05,0x49,0x00,0xb0,0x05,0x49,0x00,0xa1,0x05,0x4a,0x00,0x91,0x05,0x4a,0x00,0x81,0x05,0x4a,0x00,0x71,0x05,0x4b,0x00,0x62,0x05,0x4b,0x00,0x52,0x05,0x4b,0x00,0x43,0x05,0x4b,0x00,0x33,0x05,0x4c,0x00,0x24,0x05,0x4c,0x00,0x15,0x05,0x4c,0x00,0x06,0x05,0x4c,0x00,0xf7,0x04,0x4d,0x00,0xe8,0x04,  \
    0x4d,0x00,0xd9,0x04,0x4d,0x00,0xca,0x04,0x4e,0x00,0xbb,0x04,0x4e,0x00,0xad,0x04,0x4e,0x00,0x9e,0x04,0x4e,0x00,0x90,0x04,0x4f,0x00,0x81,0x04,0x4f,0x00,0x73,0x04,0x4f,0x00,0x65,0x04,0x4f,0x00,0x56,0x04,0x50,0x00,0x48,0x04,0x50,0x00,0x3a,0x04,0x50,0x00,0x2c,0x04,0x50,0x00,0x1e,0x04,0x51,0x00,0x10,0x04,0x51,0x00,0x02,0x04,0x51,0x00,0xf5,0x03,0x51,0x00,0xe7,0x03,0x52,0x00,0xd9,0x03,0x52,0x00,0xcc,0x03,0x52,0x00,0xbe,0x03,0x52,0x00,0xb1,0x03,0x53,0x00,  \
    0xa4,0x03,0x53,0x00,0x96,0x03,0x53,0x00,0x89,0x03,0x53,0x00,0x7c,0x03,0x53,0x00,0x6f,0x03,0x54,0x00,0x62,0x03,0x54,0x00,0x55,0x03,0x54,0x00,0x48,0x03,0x54,0x00,0x3b,0x03,0x55,0x00,0x2e,0x03,0x55,0x00,0x21,0x03,0x55,0x00,0x14,0x03,0x55,0x00,0x08,0x03,0x55,0x00,0xfb,0x02,0x56,0x00,0xef,0x02,0x56,0x00,0xe2,0x02,0x56,0x00,0xd6,0x02,0x56,0x00,0xc9,0x02,0x56,0x00,0xbd,0x02,0x57,0x00,0xb1,0x02,0x57,0x00,0xa4,0x02,0x57,0x00,0x98,0x02,0x57,0x00,0x8c,0x02,  \
    0x57,0x00,0x80,0x02,0x57,0x00,0x74,0x02,0x58,0x00,0x68,0x02,0x58,0x00,0x5c,0x02,0x58,0x00,0x50,0x02,0x58,0x00,0x44,0x02,0x58,0x00,0x38,0x02,0x58,0x00,0x2c,0x02,0x59,0x00,0x21,0x02,0x59,0x00,0x15,0x02,0x59,0x00,0x09,0x02,0x59,0x00,0xfd,0x01,0x59,0x00,0xf2,0x01,0x59,0x00,0xe6,0x01,0x59,0x00,0xdb,0x01,0x5a,0x00,0xcf,0x01,0x5a,0x00,0xc4,0x01,0x5a,0x00,0xb8,0x01,0x5a,0x00,0xad,0x01,0x5a,0x00,0xa2,0x01,0x5a,0x00,0x96,0x01,0x5a,0x00,0x8b,0x01,0x5a,0x00,  \
    0x80,0x01,0x5b,0x00,0x75,0x01,0x5b,0x00,0x69,0x01,0x5b,0x00,0x5e,0x01,0x5b,0x00,0x53,0x01,0x5b,0x00,0x48,0x01,0x5b,0x00,0x3d,0x01,0x5b,0x00,0x32,0x01,0x5b,0x00,0x27,0x01,0x5b,0x00,0x1c,0x01,0x5c,0x00,0x11,0x01,0x5c,0x00,0x06,0x01,0x5c,0x00,0xfb,0x00,0x5c,0x00,0xf0,0x00,0x5c,0x00,0xe5,0x00,0x5c,0x00,0xdb,0x00,0x5c,0x00,0xd0,0x00,0x5c,0x00,0xc5,0x00,0x5c,0x00,0xba,0x00,0x5c,0x00,0xaf,0x00,0x5c,0x00,0xa5,0x00,0x5c,0x00,0x9a,0x00,0x5c,0x00,0x8f,0x00,  \
    0x5c,0x00,0x84,0x00,0x5d,0x00,0x7a,0x00,0x5d,0x00,0x6f,0x00,0x5d,0x00,0x64,0x00,0x5d,0x00,0x5a,0x00,0x5d,0x00,0x4f,0x00,0x5d,0x00,0x44,0x00,0x5d,0x00,0x3a,0x00,0x5d,0x00,0x2f,0x00,0x5d,0x00,0x24,0x00,0x5d,0x00,0x1a,0x00,0x5d,0x00,0x0f,0x00,0x5d,0x00,0x05,0x00,0x5d,0x00,0xfa,0xff,0x5d,0x00,0xf0,0xff,0x5d,0x00,0xe5,0xff,0x5d,0x00,0xda,0xff,0x5d,0x00,0xd0,0xff,0x5d,0x00,0xc5,0xff,0x5d,0x00,0xbb,0xff,0x5d,0x00,0xb0,0xff,0x5d,0x00,0xa6,0xff,0x5d,0x00,  \
    0x9b,0xff,0x5d,0x00,0x90,0xff,0x5d,0x00,0x86,0xff,0x5d,0x00,0x7b,0xff,0x5d,0x00,0x71,0xff,0x5d,0x00,0x66,0xff,0x5d,0x00,0x5c,0xff,0x5d,0x00,0x51,0xff,0x5d,0x00,0x46,0xff,0x5d,0x00,0x3c,0xff,0x5d,0x00,0x31,0xff,0x5d,0x00,0x27,0xff,0x5d,0x00,0x1c,0xff,0x5d,0x00,0x11,0xff,0x5d,0x00,0x07,0xff,0x5c,0x00,0xfc,0xfe,0x5c,0x00,0xf1,0xfe,0x5c,0x00,0xe7,0xfe,0x5c,0x00,0xdc,0xfe,0x5c,0x00,0xd1,0xfe,0x5c,0x00,0xc6,0xfe,0x5c,0x00,0xbc,0xfe,0x5c,0x00,0xb1,0xfe,  \
    0x5c,0x00,0xa6,0xfe,0x5c,0x00,0x9b,0xfe,0x5c,0x00,0x91,0xfe,0x5c,0x00,0x86,0xfe,0x5c,0x00,0x7b,0xfe,0x5c,0x00,0x70,0xfe,0x5b,0x00,0x65,0xfe,0x5b,0x00,0x5a,0xfe,0x5b,0x00,0x4f,0xfe,0x5b,0x00,0x44,0xfe,0x5b,0x00,0x39,0xfe,0x5b,0x00,0x2e,0xfe,0x5b,0x00,0x23,0xfe,0x5b,0x00,0x18,0xfe,0x5b,0x00,0x0d,0xfe,0x5a,0x00,0x02,0xfe,0x5a,0x00,0xf7,0xfd,0x5a,0x00,0xeb,0xfd,0x5a,0x00,0xe0,0xfd,0x5a,0x00,0xd5,0xfd,0x5a,0x00,0xca,0xfd,0x5a,0x00,0xbe,0xfd,0x5a,0x00,  \
    0xb3,0xfd,0x59,0x00,0xa7,0xfd,0x59,0x00,0x9c,0xfd,0x59,0x00,0x91,0xfd,0x59,0x00,0x85,0xfd,0x59,0x00,0x79,0xfd,0x59,0x00,0x6e,0xfd,0x59,0x00,0x62,0xfd,0x58,0x00,0x57,0xfd,0x58,0x00,0x4b,0xfd,0x58,0x00,0x3f,0xfd,0x58,0x00,0x33,0xfd,0x58,0x00,0x28,0xfd,0x58,0x00,0x1c,0xfd,0x57,0x00,0x10,0xfd,0x57,0x00,0x04,0xfd,0x57,0x00,0xf8,0xfc,0x57,0x00,0xec,0xfc,0x57,0x00,0xe0,0xfc,0x56,0x00,0xd3,0xfc,0x56,0x00,0xc7,0xfc,0x56,0x00,0xbb,0xfc,0x56,0x00,0xaf,0xfc,  \
    0x56,0x00,0xa2,0xfc,0x55,0x00,0x96,0xfc,0x55,0x00,0x8a,0xfc,0x55,0x00,0x7d,0xfc,0x55,0x00,0x70,0xfc,0x55,0x00,0x64,0xfc,0x54,0x00,0x57,0xfc,0x54,0x00,0x4a,0xfc,0x54,0x00,0x3e,0xfc,0x54,0x00,0x31,0xfc,0x54,0x00,0x24,0xfc,0x53,0x00,0x17,0xfc,0x53,0x00,0x0a,0xfc,0x53,0x00,0xfd,0xfb,0x53,0x00,0xf0,0xfb,0x52,0x00,0xe3,0xfb,0x52,0x00,0xd5,0xfb,0x52,0x00,0xc8,0xfb,0x52,0x00,0xbb,0xfb,0x51,0x00,0xad,0xfb,0x51,0x00,0xa0,0xfb,0x51,0x00,0x92,0xfb,0x51,0x00,  \
    0x85,0xfb,0x51,0x00,0x77,0xfb,0x50,0x00,0x69,0xfb,0x50,0x00,0x5b,0xfb,0x50,0x00,0x4d,0xfb,0x50,0x00,0x3f,0xfb,0x4f,0x00,0x31,0xfb,0x4f,0x00,0x23,0xfb,0x4f,0x00,0x15,0xfb,0x4e,0x00,0x07,0xfb,0x4e,0x00,0xf9,0xfa,0x4e,0x00,0xea,0xfa,0x4e,0x00,0xdc,0xfa,0x4d,0x00,0xcd,0xfa,0x4d,0x00,0xbf,0xfa,0x4d,0x00,0xb0,0xfa,0x4d,0x00,0xa1,0xfa,0x4c,0x00,0x92,0xfa,0x4c,0x00,0x83,0xfa,0x4c,0x00,0x74,0xfa,0x4b,0x00,0x65,0xfa,0x4b,0x00,0x56,0xfa,0x4b,0x00,0x47,0xfa,  \
    0x4b,0x00,0x38,0xfa,0x4a,0x00,0x28,0xfa,0x4a,0x00,0x19,0xfa,0x4a,0x00,0x09,0xfa,0x49,0x00,0xfa,0xf9,0x49,0x00,0xea,0xf9,0x49,0x00,0xda,0xf9,0x49,0x00,0xca,0xf9,0x48,0x00,0xba,0xf9,0x48,0x00,0xaa,0xf9,0x48,0x00,0x9a,0xf9,0x47,0x00,0x8a,0xf9,0x47,0x00,0x7a,0xf9,0x47,0x00,0x69,0xf9,0x46,0x00,0x59,0xf9,0x46,0x00,0x48,0xf9,0x46,0x00,0x38,0xf9,0x46,0x00,0x27,0xf9,0x45,0x00,0x16,0xf9,0x45,0x00,0x05,0xf9,0x45,0x00,0xf4,0xf8,0x44,0x00,0xe3,0xf8,0x44,0x00,  \
    0xd2,0xf8,0x44,0x00,0xc0,0xf8,0x43,0x00,0xaf,0xf8,0x43,0x00,0x9d,0xf8,0x43,0x00,0x8c,0xf8,0x42,0x00,0x7a,0xf8,0x42,0x00,0x68,0xf8,0x42,0x00,0x57,0xf8,0x42,0x00,0x45,0xf8,0x41,0x00,0x32,0xf8,0x41,0x00,0x20,0xf8,0x41,0x00,0x0e,0xf8,0x40,0x00,0xfc,0xf7,0x40,0x00,0xe9,0xf7,0x40,0x00,0xd7,0xf7,0x3f,0x00,0xc4,0xf7,0x3f,0x00,0xb1,0xf7,0x3f,0x00,0x9e,0xf7,0x3e,0x00,0x8b,0xf7,0x3e,0x00,0x78,0xf7,0x3e,0x00,0x65,0xf7,0x3d,0x00,0x52,0xf7,0x3d,0x00,0x3f,0xf7,  \
    0x3d,0x00,0x2b,0xf7,0x3c,0x00,0x17,0xf7,0x3c,0x00,0x04,0xf7,0x3c,0x00,0xf0,0xf6,0x3c,0x00,0xdc,0xf6,0x3b,0x00,0xc8,0xf6,0x3b,0x00,0xb4,0xf6,0x3b,0x00,0xa0,0xf6,0x3a,0x00,0x8b,0xf6,0x3a,0x00,0x77,0xf6,0x3a,0x00,0x62,0xf6,0x39,0x00,0x4e,0xf6,0x39,0x00,0x39,0xf6,0x39,0x00,0x24,0xf6,0x38,0x00,0x0f,0xf6,0x38,0x00,0xfa,0xf5,0x38,0x00,0xe5,0xf5,0x37,0x00,0xcf,0xf5,0x37,0x00,0xba,0xf5,0x37,0x00,0xa4,0xf5,0x37,0x00,0x8f,0xf5,0x36,0x00,0x79,0xf5,0x36,0x00,  \
    0x63,0xf5,0x36,0x00,0x4d,0xf5,0x35,0x00,0x37,0xf5,0x35,0x00,0x21,0xf5,0x35,0x00,0x0a,0xf5,0x35,0x00,0xf4,0xf4,0x34,0x00,0xdd,0xf4,0x34,0x00,0xc6,0xf4,0x34,0x00,0xb0,0xf4,0x33,0x00,0x99,0xf4,0x33,0x00,0x82,0xf4,0x33,0x00,0x6a,0xf4,0x33,0x00,0x53,0xf4,0x32,0x00,0x3c,0xf4,0x32,0x00,0x24,0xf4,0x32,0x00,0x0d,0xf4,0x31,0x00,0xf5,0xf3,0x31,0x00,0xdd,0xf3,0x31,0x00,0xc5,0xf3,0x31,0x00,0xad,0xf3,0x30,0x00,0x94,0xf3,0x30,0x00,0x7c,0xf3,0x30,0x00,0x64,0xf3,  \
    0x30,0x00,0x4b,0xf3,0x2f,0x00,0x32,0xf3,0x2f,0x00,0x19,0xf3,0x2f,0x00,0x00,0xf3,0x2f,0x00,0xe7,0xf2,0x2e,0x00,0xce,0xf2,0x2e,0x00,0xb5,0xf2,0x2e,0x00,0x9b,0xf2,0x2e,0x00,0x82,0xf2,0x2e,0x00,0x68,0xf2,0x2d,0x00,0x4e,0xf2,0x2d,0x00,0x34,0xf2,0x2d,0x00,0x1a,0xf2,0x2d,0x00,0x00,0xf2,0x2d,0x00,0xe5,0xf1,0x2c,0x00,0xcb,0xf1,0x2c,0x00,0xb0,0xf1,0x2c,0x00,0x95,0xf1,0x2c,0x00,0x7b,0xf1,0x2c,0x00,0x60,0xf1,0x2b,0x00,0x45,0xf1,0x2b,0x00,0x29,0xf1,0x2b,0x00,  \
    0x0e,0xf1,0x2b,0x00,0xf2,0xf0,0x2b,0x00,0xd7,0xf0,0x2b,0x00,0xbb,0xf0,0x2a,0x00,0x9f,0xf0,0x2a,0x00,0x83,0xf0,0x2a,0x00,0x67,0xf0,0x2a,0x00,0x4b,0xf0,0x2a,0x00,0x2e,0xf0,0x2a,0x00,0x12,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1f,0x00,0xff,0x0f,0x1f,0x00,0xe2,0x0f,0x1f,0x00,0xc6,0x0f,0x1f,0x00,0xa9,0x0f,0x1f,0x00,0x8d,0x0f,0x1f,0x00,0x71,0x0f,0x20,0x00,0x55,0x0f,0x20,0x00,0x39,0x0f,0x20,0x00,0x1d,0x0f,0x20,0x00,0x01,0x0f,0x20,0x00,0xe5,0x0e,0x21,0x00,0xca,0x0e,0x21,0x00,0xae,0x0e,0x21,0x00,0x93,0x0e,0x21,0x00,0x78,0x0e,0x22,0x00,0x5d,0x0e,0x22,0x00,0x42,0x0e,0x22,0x00,0x27,0x0e,0x22,0x00,0x0d,0x0e,0x23,0x00,0xf2,0x0d,0x23,0x00,  \
    0xd8,0x0d,0x23,0x00,0xbd,0x0d,0x23,0x00,0xa3,0x0d,0x24,0x00,0x89,0x0d,0x24,0x00,0x6f,0x0d,0x24,0x00,0x55,0x0d,0x25,0x00,0x3b,0x0d,0x25,0x00,0x22,0x0d,0x25,0x00,0x08,0x0d,0x26,0x00,0xef,0x0c,0x26,0x00,0xd6,0x0c,0x26,0x00,0xbd,0x0c,0x26,0x00,0xa4,0x0c,0x27,0x00,0x8b,0x0c,0x27,0x00,0x72,0x0c,0x27,0x00,0x59,0x0c,0x28,0x00,0x41,0x0c,0x28,0x00,0x28,0x0c,0x28,0x00,0x10,0x0c,0x29,0x00,0xf8,0x0b,0x29,0x00,0xe0,0x0b,0x29,0x00,0xc8,0x0b,0x2a,0x00,0xb0,0x0b,  \
    0x2a,0x00,0x98,0x0b,0x2a,0x00,0x80,0x0b,0x2b,0x00,0x69,0x0b,0x2b,0x00,0x51,0x0b,0x2c,0x00,0x3a,0x0b,0x2c,0x00,0x23,0x0b,0x2c,0x00,0x0c,0x0b,0x2d,0x00,0xf5,0x0a,0x2d,0x00,0xde,0x0a,0x2d,0x00,0xc7,0x0a,0x2e,0x00,0xb1,0x0a,0x2e,0x00,0x9a,0x0a,0x2f,0x00,0x84,0x0a,0x2f,0x00,0x6d,0x0a,0x2f,0x00,0x57,0x0a,0x30,0x00,0x41,0x0a,0x30,0x00,0x2b,0x0a,0x30,0x00,0x15,0x0a,0x31,0x00,0x00,0x0a,0x31,0x00,0xea,0x09,0x32,0x00,0xd5,0x09,0x32,0x00,0xbf,0x09,0x32,0x00,  \
    0xaa,0x09,0x33,0x00,0x95,0x09,0x33,0x00,0x80,0x09,0x34,0x00,0x6b,0x09,0x34,0x00,0x56,0x09,0x34,0x00,0x41,0x09,0x35,0x00,0x2c,0x09,0x35,0x00,0x18,0x09,0x36,0x00,0x03,0x09,0x36,0x00,0xef,0x08,0x36,0x00,0xdb,0x08,0x37,0x00,0xc6,0x08,0x37,0x00,0xb2,0x08,0x38,0x00,0x9f,0x08,0x38,0x00,0x8b,0x08,0x38,0x00,0x77,0x08,0x39,0x00,0x63,0x08,0x39,0x00,0x50,0x08,0x3a,0x00,0x3c,0x08,0x3a,0x00,0x29,0x08,0x3a,0x00,0x16,0x08,0x3b,0x00,0x03,0x08,0x3b,0x00,0xf0,0x07,  \
    0x3c,0x00,0xdd,0x07,0x3c,0x00,0xca,0x07,0x3d,0x00,0xb7,0x07,0x3d,0x00,0xa5,0x07,0x3d,0x00,0x92,0x07,0x3e,0x00,0x80,0x07,0x3e,0x00,0x6d,0x07,0x3f,0x00,0x5b,0x07,0x3f,0x00,0x49,0x07,0x3f,0x00,0x37,0x07,0x40,0x00,0x25,0x07,0x40,0x00,0x13,0x07,0x41,0x00,0x01,0x07,0x41,0x00,0xf0,0x06,0x41,0x00,0xde,0x06,0x42,0x00,0xcd,0x06,0x42,0x00,0xbb,0x06,0x43,0x00,0xaa,0x06,0x43,0x00,0x99,0x06,0x43,0x00,0x88,0x06,0x44,0x00,0x77,0x06,0x44,0x00,0x66,0x06,0x45,0x00,  \
    0x55,0x06,0x45,0x00,0x44,0x06,0x45,0x00,0x33,0x06,0x46,0x00,0x23,0x06,0x46,0x00,0x12,0x06,0x47,0x00,0x02,0x06,0x47,0x00,0xf1,0x05,0x47,0x00,0xe1,0x05,0x48,0x00,0xd1,0x05,0x48,0x00,0xc1,0x05,0x48,0x00,0xb1,0x05,0x49,0x00,0xa1,0x05,0x49,0x00,0x91,0x05,0x4a,0x00,0x81,0x05,0x4a,0x00,0x72,0x05,0x4a,0x00,0x62,0x05,0x4b,0x00,0x53,0x05,0x4b,0x00,0x43,0x05,0x4b,0x00,0x34,0x05,0x4c,0x00,0x25,0x05,0x4c,0x00,0x15,0x05,0x4c,0x00,0x06,0x05,0x4d,0x00,0xf7,0x04,  \
    0x4d,0x00,0xe8,0x04,0x4e,0x00,0xd9,0x04,0x4e,0x00,0xcb,0x04,0x4e,0x00,0xbc,0x04,0x4f,0x00,0xad,0x04,0x4f,0x00,0x9f,0x04,0x4f,0x00,0x90,0x04,0x50,0x00,0x82,0x04,0x50,0x00,0x73,0x04,0x50,0x00,0x65,0x04,0x51,0x00,0x57,0x04,0x51,0x00,0x49,0x04,0x51,0x00,0x3b,0x04,0x52,0x00,0x2d,0x04,0x52,0x00,0x1f,0x04,0x52,0x00,0x11,0x04,0x53,0x00,0x03,0x04,0x53,0x00,0xf5,0x03,0x53,0x00,0xe7,0x03,0x54,0x00,0xda,0x03,0x54,0x00,0xcc,0x03,0x54,0x00,0xbf,0x03,0x54,0x00,  \
    0xb1,0x03,0x55,0x00,0xa4,0x03,0x55,0x00,0x97,0x03,0x55,0x00,0x89,0x03,0x56,0x00,0x7c,0x03,0x56,0x00,0x6f,0x03,0x56,0x00,0x62,0x03,0x56,0x00,0x55,0x03,0x57,0x00,0x48,0x03,0x57,0x00,0x3b,0x03,0x57,0x00,0x2e,0x03,0x58,0x00,0x22,0x03,0x58,0x00,0x15,0x03,0x58,0x00,0x08,0x03,0x58,0x00,0xfc,0x02,0x59,0x00,0xef,0x02,0x59,0x00,0xe2,0x02,0x59,0x00,0xd6,0x02,0x59,0x00,0xca,0x02,0x5a,0x00,0xbd,0x02,0x5a,0x00,0xb1,0x02,0x5a,0x00,0xa5,0x02,0x5a,0x00,0x98,0x02,  \
    0x5b,0x00,0x8c,0x02,0x5b,0x00,0x80,0x02,0x5b,0x00,0x74,0x02,0x5b,0x00,0x68,0x02,0x5c,0x00,0x5c,0x02,0x5c,0x00,0x50,0x02,0x5c,0x00,0x44,0x02,0x5c,0x00,0x38,0x02,0x5c,0x00,0x2d,0x02,0x5d,0x00,0x21,0x02,0x5d,0x00,0x15,0x02,0x5d,0x00,0x09,0x02,0x5d,0x00,0xfe,0x01,0x5d,0x00,0xf2,0x01,0x5e,0x00,0xe7,0x01,0x5e,0x00,0xdb,0x01,0x5e,0x00,0xd0,0x01,0x5e,0x00,0xc4,0x01,0x5e,0x00,0xb9,0x01,0x5e,0x00,0xad,0x01,0x5f,0x00,0xa2,0x01,0x5f,0x00,0x97,0x01,0x5f,0x00,  \
    0x8b,0x01,0x5f,0x00,0x80,0x01,0x5f,0x00,0x75,0x01,0x5f,0x00,0x6a,0x01,0x60,0x00,0x5f,0x01,0x60,0x00,0x53,0x01,0x60,0x00,0x48,0x01,0x60,0x00,0x3d,0x01,0x60,0x00,0x32,0x01,0x60,0x00,0x27,0x01,0x60,0x00,0x1c,0x01,0x60,0x00,0x11,0x01,0x61,0x00,0x06,0x01,0x61,0x00,0xfb,0x00,0x61,0x00,0xf0,0x00,0x61,0x00,0xe6,0x00,0x61,0x00,0xdb,0x00,0x61,0x00,0xd0,0x00,0x61,0x00,0xc5,0x00,0x61,0x00,0xba,0x00,0x61,0x00,0xaf,0x00,0x61,0x00,0xa5,0x00,0x62,0x00,0x9a,0x00,  \
    0x62,0x00,0x8f,0x00,0x62,0x00,0x84,0x00,0x62,0x00,0x7a,0x00,0x62,0x00,0x6f,0x00,0x62,0x00,0x64,0x00,0x62,0x00,0x5a,0x00,0x62,0x00,0x4f,0x00,0x62,0x00,0x44,0x00,0x62,0x00,0x3a,0x00,0x62,0x00,0x2f,0x00,0x62,0x00,0x25,0x00,0x62,0x00,0x1a,0x00,0x62,0x00,0x0f,0x00,0x62,0x00,0x05,0x00,0x62,0x00,0xfa,0xff,0x62,0x00,0xf0,0xff,0x62,0x00,0xe5,0xff,0x62,0x00,0xda,0xff,0x62,0x00,0xd0,0xff,0x62,0x00,0xc5,0xff,0x62,0x00,0xbb,0xff,0x62,0x00,0xb0,0xff,0x62,0x00,  \
    0xa6,0xff,0x62,0x00,0x9b,0xff,0x62,0x00,0x90,0xff,0x62,0x00,0x86,0xff,0x62,0x00,0x7b,0xff,0x62,0x00,0x71,0xff,0x62,0x00,0x66,0xff,0x62,0x00,0x5c,0xff,0x62,0x00,0x51,0xff,0x62,0x00,0x46,0xff,0x62,0x00,0x3c,0xff,0x62,0x00,0x31,0xff,0x62,0x00,0x26,0xff,0x62,0x00,0x1c,0xff,0x62,0x00,0x11,0xff,0x62,0x00,0x07,0xff,0x62,0x00,0xfc,0xfe,0x62,0x00,0xf1,0xfe,0x62,0x00,0xe6,0xfe,0x61,0x00,0xdc,0xfe,0x61,0x00,0xd1,0xfe,0x61,0x00,0xc6,0xfe,0x61,0x00,0xbc,0xfe,  \
    0x61,0x00,0xb1,0xfe,0x61,0x00,0xa6,0xfe,0x61,0x00,0x9b,0xfe,0x61,0x00,0x90,0xfe,0x61,0x00,0x85,0xfe,0x61,0x00,0x7b,0xfe,0x60,0x00,0x70,0xfe,0x60,0x00,0x65,0xfe,0x60,0x00,0x5a,0xfe,0x60,0x00,0x4f,0xfe,0x60,0x00,0x44,0xfe,0x60,0x00,0x39,0xfe,0x60,0x00,0x2e,0xfe,0x5f,0x00,0x23,0xfe,0x5f,0x00,0x18,0xfe,0x5f,0x00,0x0d,0xfe,0x5f,0x00,0x01,0xfe,0x5f,0x00,0xf6,0xfd,0x5f,0x00,0xeb,0xfd,0x5f,0x00,0xe0,0xfd,0x5e,0x00,0xd5,0xfd,0x5e,0x00,0xc9,0xfd,0x5e,0x00,  \
    0xbe,0xfd,0x5e,0x00,0xb3,0xfd,0x5e,0x00,0xa7,0xfd,0x5e,0x00,0x9c,0xfd,0x5d,0x00,0x90,0xfd,0x5d,0x00,0x85,0xfd,0x5d,0x00,0x79,0xfd,0x5d,0x00,0x6e,0xfd,0x5d,0x00,0x62,0xfd,0x5c,0x00,0x56,0xfd,0x5c,0x00,0x4b,0xfd,0x5c,0x00,0x3f,0xfd,0x5c,0x00,0x33,0xfd,0x5b,0x00,0x27,0xfd,0x5b,0x00,0x1b,0xfd,0x5b,0x00,0x0f,0xfd,0x5b,0x00,0x03,0xfd,0x5b,0x00,0xf7,0xfc,0x5a,0x00,0xeb,0xfc,0x5a,0x00,0xdf,0xfc,0x5a,0x00,0xd3,0xfc,0x5a,0x00,0xc7,0xfc,0x59,0x00,0xbb,0xfc,  \
    0x59,0x00,0xae,0xfc,0x59,0x00,0xa2,0xfc,0x59,0x00,0x96,0xfc,0x58,0x00,0x89,0xfc,0x58,0x00,0x7d,0xfc,0x58,0x00,0x70,0xfc,0x57,0x00,0x63,0xfc,0x57,0x00,0x57,0xfc,0x57,0x00,0x4a,0xfc,0x57,0x00,0x3d,0xfc,0x56,0x00,0x30,0xfc,0x56,0x00,0x24,0xfc,0x56,0x00,0x17,0xfc,0x56,0x00,0x0a,0xfc,0x55,0x00,0xfd,0xfb,0x55,0x00,0xef,0xfb,0x55,0x00,0xe2,0xfb,0x54,0x00,0xd5,0xfb,0x54,0x00,0xc8,0xfb,0x54,0x00,0xba,0xfb,0x53,0x00,0xad,0xfb,0x53,0x00,0x9f,0xfb,0x53,0x00,  \
    0x92,0xfb,0x52,0x00,0x84,0xfb,0x52,0x00,0x76,0xfb,0x52,0x00,0x69,0xfb,0x51,0x00,0x5b,0xfb,0x51,0x00,0x4d,0xfb,0x51,0x00,0x3f,0xfb,0x50,0x00,0x31,0xfb,0x50,0x00,0x23,0xfb,0x50,0x00,0x15,0xfb,0x4f,0x00,0x06,0xfb,0x4f,0x00,0xf8,0xfa,0x4f,0x00,0xea,0xfa,0x4e,0x00,0xdb,0xfa,0x4e,0x00,0xcd,0xfa,0x4e,0x00,0xbe,0xfa,0x4d,0x00,0xaf,0xfa,0x4d,0x00,0xa1,0xfa,0x4d,0x00,0x92,0xfa,0x4c,0x00,0x83,0xfa,0x4c,0x00,0x74,0xfa,0x4c,0x00,0x65,0xfa,0x4b,0x00,0x56,0xfa,  \
    0x4b,0x00,0x47,0xfa,0x4a,0x00,0x37,0xfa,0x4a,0x00,0x28,0xfa,0x4a,0x00,0x18,0xfa,0x49,0x00,0x09,0xfa,0x49,0x00,0xf9,0xf9,0x49,0x00,0xe9,0xf9,0x48,0x00,0xda,0xf9,0x48,0x00,0xca,0xf9,0x47,0x00,0xba,0xf9,0x47,0x00,0xaa,0xf9,0x47,0x00,0x9a,0xf9,0x46,0x00,0x89,0xf9,0x46,0x00,0x79,0xf9,0x45,0x00,0x69,0xf9,0x45,0x00,0x58,0xf9,0x45,0x00,0x48,0xf9,0x44,0x00,0x37,0xf9,0x44,0x00,0x26,0xf9,0x43,0x00,0x15,0xf9,0x43,0x00,0x04,0xf9,0x43,0x00,0xf3,0xf8,0x42,0x00,  \
    0xe2,0xf8,0x42,0x00,0xd1,0xf8,0x41,0x00,0xc0,0xf8,0x41,0x00,0xae,0xf8,0x41,0x00,0x9d,0xf8,0x40,0x00,0x8b,0xf8,0x40,0x00,0x7a,0xf8,0x3f,0x00,0x68,0xf8,0x3f,0x00,0x56,0xf8,0x3f,0x00,0x44,0xf8,0x3e,0x00,0x32,0xf8,0x3e,0x00,0x20,0xf8,0x3d,0x00,0x0e,0xf8,0x3d,0x00,0xfb,0xf7,0x3d,0x00,0xe9,0xf7,0x3c,0x00,0xd6,0xf7,0x3c,0x00,0xc3,0xf7,0x3b,0x00,0xb1,0xf7,0x3b,0x00,0x9e,0xf7,0x3a,0x00,0x8b,0xf7,0x3a,0x00,0x78,0xf7,0x3a,0x00,0x65,0xf7,0x39,0x00,0x51,0xf7,  \
    0x39,0x00,0x3e,0xf7,0x38,0x00,0x2b,0xf7,0x38,0x00,0x17,0xf7,0x38,0x00,0x03,0xf7,0x37,0x00,0xef,0xf6,0x37,0x00,0xdc,0xf6,0x36,0x00,0xc8,0xf6,0x36,0x00,0xb3,0xf6,0x36,0x00,0x9f,0xf6,0x35,0x00,0x8b,0xf6,0x35,0x00,0x76,0xf6,0x34,0x00,0x62,0xf6,0x34,0x00,0x4d,0xf6,0x34,0x00,0x38,0xf6,0x33,0x00,0x23,0xf6,0x33,0x00,0x0f,0xf6,0x32,0x00,0xf9,0xf5,0x32,0x00,0xe4,0xf5,0x32,0x00,0xcf,0xf5,0x31,0x00,0xb9,0xf5,0x31,0x00,0xa4,0xf5,0x30,0x00,0x8e,0xf5,0x30,0x00,  \
    0x78,0xf5,0x30,0x00,0x62,0xf5,0x2f,0x00,0x4c,0xf5,0x2f,0x00,0x36,0xf5,0x2e,0x00,0x20,0xf5,0x2e,0x00,0x0a,0xf5,0x2e,0x00,0xf3,0xf4,0x2d,0x00,0xdd,0xf4,0x2d,0x00,0xc6,0xf4,0x2d,0x00,0xaf,0xf4,0x2c,0x00,0x98,0xf4,0x2c,0x00,0x81,0xf4,0x2b,0x00,0x6a,0xf4,0x2b,0x00,0x53,0xf4,0x2b,0x00,0x3b,0xf4,0x2a,0x00,0x24,0xf4,0x2a,0x00,0x0c,0xf4,0x2a,0x00,0xf4,0xf3,0x29,0x00,0xdc,0xf3,0x29,0x00,0xc4,0xf3,0x29,0x00,0xac,0xf3,0x28,0x00,0x94,0xf3,0x28,0x00,0x7c,0xf3,  \
    0x28,0x00,0x63,0xf3,0x27,0x00,0x4b,0xf3,0x27,0x00,0x32,0xf3,0x27,0x00,0x19,0xf3,0x26,0x00,0x00,0xf3,0x26,0x00,0xe7,0xf2,0x26,0x00,0xce,0xf2,0x25,0x00,0xb4,0xf2,0x25,0x00,0x9b,0xf2,0x25,0x00,0x81,0xf2,0x25,0x00,0x67,0xf2,0x24,0x00,0x4e,0xf2,0x24,0x00,0x34,0xf2,0x24,0x00,0x19,0xf2,0x23,0x00,0xff,0xf1,0x23,0x00,0xe5,0xf1,0x23,0x00,0xca,0xf1,0x23,0x00,0xb0,0xf1,0x22,0x00,0x95,0xf1,0x22,0x00,0x7a,0xf1,0x22,0x00,0x5f,0xf1,0x22,0x00,0x44,0xf1,0x21,0x00,  \
    0x29,0xf1,0x21,0x00,0x0d,0xf1,0x21,0x00,0xf2,0xf0,0x21,0x00,0xd6,0xf0,0x21,0x00,0xbb,0xf0,0x20,0x00,0x9f,0xf0,0x20,0x00,0x83,0xf0,0x20,0x00,0x67,0xf0,0x20,0x00,0x4a,0xf0,0x20,0x00,0x2e,0xf0,0x1f,0x00,0x11,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0x00,0xff,0x0f,0x14,0x00,0xe3,0x0f,0x14,0x00,0xc6,0x0f,0x14,0x00,0xaa,0x0f,0x15,0x00,0x8d,0x0f,0x15,0x00,0x71,0x0f,0x15,0x00,0x55,0x0f,0x15,0x00,0x39,0x0f,0x16,0x00,0x1d,0x0f,0x16,0x00,0x01,0x0f,0x16,0x00,0xe6,0x0e,0x16,0x00,0xca,0x0e,0x17,0x00,0xaf,0x0e,0x17,0x00,0x94,0x0e,0x17,0x00,0x79,0x0e,0x18,0x00,0x5d,0x0e,0x18,0x00,0x43,0x0e,0x18,0x00,0x28,0x0e,0x18,0x00,0x0d,0x0e,0x19,0x00,  \
    0xf3,0x0d,0x19,0x00,0xd8,0x0d,0x19,0x00,0xbe,0x0d,0x1a,0x00,0xa4,0x0d,0x1a,0x00,0x8a,0x0d,0x1b,0x00,0x70,0x0d,0x1b,0x00,0x56,0x0d,0x1b,0x00,0x3c,0x0d,0x1c,0x00,0x22,0x0d,0x1c,0x00,0x09,0x0d,0x1c,0x00,0xf0,0x0c,0x1d,0x00,0xd6,0x0c,0x1d,0x00,0xbd,0x0c,0x1d,0x00,0xa4,0x0c,0x1e,0x00,0x8b,0x0c,0x1e,0x00,0x72,0x0c,0x1f,0x00,0x5a,0x0c,0x1f,0x00,0x41,0x0c,0x20,0x00,0x29,0x0c,0x20,0x00,0x10,0x0c,0x20,0x00,0xf8,0x0b,0x21,0x00,0xe0,0x0b,0x21,0x00,0xc8,0x0b,  \
    0x22,0x00,0xb0,0x0b,0x22,0x00,0x98,0x0b,0x22,0x00,0x81,0x0b,0x23,0x00,0x69,0x0b,0x23,0x00,0x52,0x0b,0x24,0x00,0x3b,0x0b,0x24,0x00,0x23,0x0b,0x25,0x00,0x0c,0x0b,0x25,0x00,0xf5,0x0a,0x26,0x00,0xdf,0x0a,0x26,0x00,0xc8,0x0a,0x27,0x00,0xb1,0x0a,0x27,0x00,0x9b,0x0a,0x28,0x00,0x84,0x0a,0x28,0x00,0x6e,0x0a,0x28,0x00,0x58,0x0a,0x29,0x00,0x42,0x0a,0x29,0x00,0x2c,0x0a,0x2a,0x00,0x16,0x0a,0x2a,0x00,0x00,0x0a,0x2b,0x00,0xeb,0x09,0x2b,0x00,0xd5,0x09,0x2c,0x00,  \
    0xc0,0x09,0x2c,0x00,0xaa,0x09,0x2d,0x00,0x95,0x09,0x2d,0x00,0x80,0x09,0x2e,0x00,0x6b,0x09,0x2e,0x00,0x56,0x09,0x2f,0x00,0x42,0x09,0x2f,0x00,0x2d,0x09,0x30,0x00,0x18,0x09,0x30,0x00,0x04,0x09,0x31,0x00,0xef,0x08,0x31,0x00,0xdb,0x08,0x32,0x00,0xc7,0x08,0x32,0x00,0xb3,0x08,0x33,0x00,0x9f,0x08,0x33,0x00,0x8b,0x08,0x34,0x00,0x78,0x08,0x34,0x00,0x64,0x08,0x35,0x00,0x50,0x08,0x35,0x00,0x3d,0x08,0x36,0x00,0x2a,0x08,0x36,0x00,0x16,0x08,0x37,0x00,0x03,0x08,  \
    0x37,0x00,0xf0,0x07,0x38,0x00,0xdd,0x07,0x38,0x00,0xcb,0x07,0x39,0x00,0xb8,0x07,0x39,0x00,0xa5,0x07,0x3a,0x00,0x93,0x07,0x3a,0x00,0x80,0x07,0x3b,0x00,0x6e,0x07,0x3b,0x00,0x5c,0x07,0x3c,0x00,0x4a,0x07,0x3c,0x00,0x38,0x07,0x3d,0x00,0x26,0x07,0x3d,0x00,0x14,0x07,0x3e,0x00,0x02,0x07,0x3e,0x00,0xf0,0x06,0x3f,0x00,0xdf,0x06,0x3f,0x00,0xcd,0x06,0x40,0x00,0xbc,0x06,0x40,0x00,0xab,0x06,0x41,0x00,0x99,0x06,0x41,0x00,0x88,0x06,0x42,0x00,0x77,0x06,0x42,0x00,  \
    0x66,0x06,0x43,0x00,0x55,0x06,0x43,0x00,0x45,0x06,0x44,0x00,0x34,0x06,0x44,0x00,0x23,0x06,0x45,0x00,0x13,0x06,0x45,0x00,0x02,0x06,0x46,0x00,0xf2,0x05,0x46,0x00,0xe2,0x05,0x47,0x00,0xd2,0x05,0x47,0x00,0xc2,0x05,0x48,0x00,0xb2,0x05,0x48,0x00,0xa2,0x05,0x49,0x00,0x92,0x05,0x49,0x00,0x82,0x05,0x49,0x00,0x72,0x05,0x4a,0x00,0x63,0x05,0x4a,0x00,0x53,0x05,0x4b,0x00,0x44,0x05,0x4b,0x00,0x35,0x05,0x4c,0x00,0x25,0x05,0x4c,0x00,0x16,0x05,0x4d,0x00,0x07,0x05,  \
    0x4d,0x00,0xf8,0x04,0x4e,0x00,0xe9,0x04,0x4e,0x00,0xda,0x04,0x4e,0x00,0xcb,0x04,0x4f,0x00,0xbd,0x04,0x4f,0x00,0xae,0x04,0x50,0x00,0x9f,0x04,0x50,0x00,0x91,0x04,0x51,0x00,0x82,0x04,0x51,0x00,0x74,0x04,0x51,0x00,0x66,0x04,0x52,0x00,0x57,0x04,0x52,0x00,0x49,0x04,0x53,0x00,0x3b,0x04,0x53,0x00,0x2d,0x04,0x53,0x00,0x1f,0x04,0x54,0x00,0x11,0x04,0x54,0x00,0x03,0x04,0x55,0x00,0xf6,0x03,0x55,0x00,0xe8,0x03,0x55,0x00,0xda,0x03,0x56,0x00,0xcd,0x03,0x56,0x00,  \
    0xbf,0x03,0x57,0x00,0xb2,0x03,0x57,0x00,0xa5,0x03,0x57,0x00,0x97,0x03,0x58,0x00,0x8a,0x03,0x58,0x00,0x7d,0x03,0x58,0x00,0x70,0x03,0x59,0x00,0x63,0x03,0x59,0x00,0x56,0x03,0x59,0x00,0x49,0x03,0x5a,0x00,0x3c,0x03,0x5a,0x00,0x2f,0x03,0x5a,0x00,0x22,0x03,0x5b,0x00,0x15,0x03,0x5b,0x00,0x09,0x03,0x5b,0x00,0xfc,0x02,0x5c,0x00,0xef,0x02,0x5c,0x00,0xe3,0x02,0x5c,0x00,0xd6,0x02,0x5d,0x00,0xca,0x02,0x5d,0x00,0xbe,0x02,0x5d,0x00,0xb1,0x02,0x5e,0x00,0xa5,0x02,  \
    0x5e,0x00,0x99,0x02,0x5e,0x00,0x8d,0x02,0x5e,0x00,0x81,0x02,0x5f,0x00,0x75,0x02,0x5f,0x00,0x68,0x02,0x5f,0x00,0x5c,0x02,0x60,0x00,0x51,0x02,0x60,0x00,0x45,0x02,0x60,0x00,0x39,0x02,0x60,0x00,0x2d,0x02,0x61,0x00,0x21,0x02,0x61,0x00,0x15,0x02,0x61,0x00,0x0a,0x02,0x61,0x00,0xfe,0x01,0x62,0x00,0xf3,0x01,0x62,0x00,0xe7,0x01,0x62,0x00,0xdb,0x01,0x62,0x00,0xd0,0x01,0x62,0x00,0xc4,0x01,0x63,0x00,0xb9,0x01,0x63,0x00,0xae,0x01,0x63,0x00,0xa2,0x01,0x63,0x00,  \
    0x97,0x01,0x63,0x00,0x8c,0x01,0x64,0x00,0x80,0x01,0x64,0x00,0x75,0x01,0x64,0x00,0x6a,0x01,0x64,0x00,0x5f,0x01,0x64,0x00,0x54,0x01,0x65,0x00,0x49,0x01,0x65,0x00,0x3e,0x01,0x65,0x00,0x32,0x01,0x65,0x00,0x27,0x01,0x65,0x00,0x1c,0x01,0x65,0x00,0x11,0x01,0x65,0x00,0x06,0x01,0x66,0x00,0xfc,0x00,0x66,0x00,0xf1,0x00,0x66,0x00,0xe6,0x00,0x66,0x00,0xdb,0x00,0x66,0x00,0xd0,0x00,0x66,0x00,0xc5,0x00,0x66,0x00,0xba,0x00,0x66,0x00,0xb0,0x00,0x67,0x00,0xa5,0x00,  \
    0x67,0x00,0x9a,0x00,0x67,0x00,0x8f,0x00,0x67,0x00,0x85,0x00,0x67,0x00,0x7a,0x00,0x67,0x00,0x6f,0x00,0x67,0x00,0x64,0x00,0x67,0x00,0x5a,0x00,0x67,0x00,0x4f,0x00,0x67,0x00,0x45,0x00,0x67,0x00,0x3a,0x00,0x67,0x00,0x2f,0x00,0x67,0x00,0x25,0x00,0x67,0x00,0x1a,0x00,0x68,0x00,0x0f,0x00,0x68,0x00,0x05,0x00,0x68,0x00,0xfa,0xff,0x68,0x00,0xf0,0xff,0x68,0x00,0xe5,0xff,0x68,0x00,0xda,0xff,0x68,0x00,0xd0,0xff,0x68,0x00,0xc5,0xff,0x68,0x00,0xbb,0xff,0x68,0x00,  \
    0xb0,0xff,0x68,0x00,0xa6,0xff,0x68,0x00,0x9b,0xff,0x68,0x00,0x90,0xff,0x68,0x00,0x86,0xff,0x68,0x00,0x7b,0xff,0x68,0x00,0x71,0xff,0x67,0x00,0x66,0xff,0x67,0x00,0x5b,0xff,0x67,0x00,0x51,0xff,0x67,0x00,0x46,0xff,0x67,0x00,0x3c,0xff,0x67,0x00,0x31,0xff,0x67,0x00,0x26,0xff,0x67,0x00,0x1c,0xff,0x67,0x00,0x11,0xff,0x67,0x00,0x06,0xff,0x67,0x00,0xfc,0xfe,0x67,0x00,0xf1,0xfe,0x67,0x00,0xe6,0xfe,0x67,0x00,0xdc,0xfe,0x66,0x00,0xd1,0xfe,0x66,0x00,0xc6,0xfe,  \
    0x66,0x00,0xbb,0xfe,0x66,0x00,0xb1,0xfe,0x66,0x00,0xa6,0xfe,0x66,0x00,0x9b,0xfe,0x66,0x00,0x90,0xfe,0x66,0x00,0x85,0xfe,0x65,0x00,0x7a,0xfe,0x65,0x00,0x6f,0xfe,0x65,0x00,0x65,0xfe,0x65,0x00,0x5a,0xfe,0x65,0x00,0x4f,0xfe,0x65,0x00,0x44,0xfe,0x65,0x00,0x39,0xfe,0x64,0x00,0x2e,0xfe,0x64,0x00,0x23,0xfe,0x64,0x00,0x17,0xfe,0x64,0x00,0x0c,0xfe,0x64,0x00,0x01,0xfe,0x63,0x00,0xf6,0xfd,0x63,0x00,0xeb,0xfd,0x63,0x00,0xdf,0xfd,0x63,0x00,0xd4,0xfd,0x63,0x00,  \
    0xc9,0xfd,0x62,0x00,0xbe,0xfd,0x62,0x00,0xb2,0xfd,0x62,0x00,0xa7,0xfd,0x62,0x00,0x9b,0xfd,0x61,0x00,0x90,0xfd,0x61,0x00,0x84,0xfd,0x61,0x00,0x79,0xfd,0x61,0x00,0x6d,0xfd,0x60,0x00,0x62,0xfd,0x60,0x00,0x56,0xfd,0x60,0x00,0x4a,0xfd,0x60,0x00,0x3e,0xfd,0x5f,0x00,0x33,0xfd,0x5f,0x00,0x27,0xfd,0x5f,0x00,0x1b,0xfd,0x5f,0x00,0x0f,0xfd,0x5e,0x00,0x03,0xfd,0x5e,0x00,0xf7,0xfc,0x5e,0x00,0xeb,0xfc,0x5d,0x00,0xdf,0xfc,0x5d,0x00,0xd3,0xfc,0x5d,0x00,0xc6,0xfc,  \
    0x5d,0x00,0xba,0xfc,0x5c,0x00,0xae,0xfc,0x5c,0x00,0xa1,0xfc,0x5c,0x00,0x95,0xfc,0x5b,0x00,0x89,0xfc,0x5b,0x00,0x7c,0xfc,0x5b,0x00,0x70,0xfc,0x5a,0x00,0x63,0xfc,0x5a,0x00,0x56,0xfc,0x5a,0x00,0x4a,0xfc,0x59,0x00,0x3d,0xfc,0x59,0x00,0x30,0xfc,0x59,0x00,0x23,0xfc,0x58,0x00,0x16,0xfc,0x58,0x00,0x09,0xfc,0x57,0x00,0xfc,0xfb,0x57,0x00,0xef,0xfb,0x57,0x00,0xe2,0xfb,0x56,0x00,0xd4,0xfb,0x56,0x00,0xc7,0xfb,0x56,0x00,0xba,0xfb,0x55,0x00,0xac,0xfb,0x55,0x00,  \
    0x9f,0xfb,0x54,0x00,0x91,0xfb,0x54,0x00,0x84,0xfb,0x54,0x00,0x76,0xfb,0x53,0x00,0x68,0xfb,0x53,0x00,0x5a,0xfb,0x52,0x00,0x4c,0xfb,0x52,0x00,0x3e,0xfb,0x52,0x00,0x30,0xfb,0x51,0x00,0x22,0xfb,0x51,0x00,0x14,0xfb,0x50,0x00,0x06,0xfb,0x50,0x00,0xf8,0xfa,0x50,0x00,0xe9,0xfa,0x4f,0x00,0xdb,0xfa,0x4f,0x00,0xcc,0xfa,0x4e,0x00,0xbe,0xfa,0x4e,0x00,0xaf,0xfa,0x4d,0x00,0xa0,0xfa,0x4d,0x00,0x91,0xfa,0x4c,0x00,0x82,0xfa,0x4c,0x00,0x73,0xfa,0x4c,0x00,0x64,0xfa,  \
    0x4b,0x00,0x55,0xfa,0x4b,0x00,0x46,0xfa,0x4a,0x00,0x37,0xfa,0x4a,0x00,0x27,0xfa,0x49,0x00,0x18,0xfa,0x49,0x00,0x08,0xfa,0x48,0x00,0xf9,0xf9,0x48,0x00,0xe9,0xf9,0x47,0x00,0xd9,0xf9,0x47,0x00,0xc9,0xf9,0x46,0x00,0xb9,0xf9,0x46,0x00,0xa9,0xf9,0x45,0x00,0x99,0xf9,0x45,0x00,0x89,0xf9,0x45,0x00,0x78,0xf9,0x44,0x00,0x68,0xf9,0x44,0x00,0x58,0xf9,0x43,0x00,0x47,0xf9,0x43,0x00,0x36,0xf9,0x42,0x00,0x26,0xf9,0x42,0x00,0x15,0xf9,0x41,0x00,0x04,0xf9,0x41,0x00,  \
    0xf3,0xf8,0x40,0x00,0xe2,0xf8,0x40,0x00,0xd0,0xf8,0x3f,0x00,0xbf,0xf8,0x3f,0x00,0xae,0xf8,0x3e,0x00,0x9c,0xf8,0x3e,0x00,0x8b,0xf8,0x3d,0x00,0x79,0xf8,0x3d,0x00,0x67,0xf8,0x3c,0x00,0x55,0xf8,0x3c,0x00,0x43,0xf8,0x3b,0x00,0x31,0xf8,0x3b,0x00,0x1f,0xf8,0x3a,0x00,0x0d,0xf8,0x3a,0x00,0xfb,0xf7,0x39,0x00,0xe8,0xf7,0x39,0x00,0xd6,0xf7,0x38,0x00,0xc3,0xf7,0x37,0x00,0xb0,0xf7,0x37,0x00,0x9d,0xf7,0x36,0x00,0x8a,0xf7,0x36,0x00,0x77,0xf7,0x35,0x00,0x64,0xf7,  \
    0x35,0x00,0x51,0xf7,0x34,0x00,0x3d,0xf7,0x34,0x00,0x2a,0xf7,0x33,0x00,0x16,0xf7,0x33,0x00,0x03,0xf7,0x32,0x00,0xef,0xf6,0x32,0x00,0xdb,0xf6,0x31,0x00,0xc7,0xf6,0x31,0x00,0xb3,0xf6,0x30,0x00,0x9f,0xf6,0x30,0x00,0x8a,0xf6,0x2f,0x00,0x76,0xf6,0x2f,0x00,0x61,0xf6,0x2e,0x00,0x4d,0xf6,0x2e,0x00,0x38,0xf6,0x2d,0x00,0x23,0xf6,0x2d,0x00,0x0e,0xf6,0x2c,0x00,0xf9,0xf5,0x2c,0x00,0xe4,0xf5,0x2b,0x00,0xce,0xf5,0x2b,0x00,0xb9,0xf5,0x2a,0x00,0xa3,0xf5,0x2a,0x00,  \
    0x8e,0xf5,0x29,0x00,0x78,0xf5,0x29,0x00,0x62,0xf5,0x29,0x00,0x4c,0xf5,0x28,0x00,0x36,0xf5,0x28,0x00,0x20,0xf5,0x27,0x00,0x09,0xf5,0x27,0x00,0xf3,0xf4,0x26,0x00,0xdc,0xf4,0x26,0x00,0xc5,0xf4,0x25,0x00,0xaf,0xf4,0x25,0x00,0x98,0xf4,0x24,0x00,0x81,0xf4,0x24,0x00,0x69,0xf4,0x23,0x00,0x52,0xf4,0x23,0x00,0x3b,0xf4,0x23,0x00,0x23,0xf4,0x22,0x00,0x0c,0xf4,0x22,0x00,0xf4,0xf3,0x21,0x00,0xdc,0xf3,0x21,0x00,0xc4,0xf3,0x20,0x00,0xac,0xf3,0x20,0x00,0x94,0xf3,  \
    0x20,0x00,0x7b,0xf3,0x1f,0x00,0x63,0xf3,0x1f,0x00,0x4a,0xf3,0x1e,0x00,0x31,0xf3,0x1e,0x00,0x18,0xf3,0x1e,0x00,0xff,0xf2,0x1d,0x00,0xe6,0xf2,0x1d,0x00,0xcd,0xf2,0x1c,0x00,0xb4,0xf2,0x1c,0x00,0x9a,0xf2,0x1c,0x00,0x81,0xf2,0x1b,0x00,0x67,0xf2,0x1b,0x00,0x4d,0xf2,0x1b,0x00,0x33,0xf2,0x1a,0x00,0x19,0xf2,0x1a,0x00,0xff,0xf1,0x1a,0x00,0xe4,0xf1,0x19,0x00,0xca,0xf1,0x19,0x00,0xaf,0xf1,0x19,0x00,0x95,0xf1,0x18,0x00,0x7a,0xf1,0x18,0x00,0x5f,0xf1,0x18,0x00,  \
    0x44,0xf1,0x18,0x00,0x28,0xf1,0x17,0x00,0x0d,0xf1,0x17,0x00,0xf2,0xf0,0x17,0x00,0xd6,0xf0,0x16,0x00,0xba,0xf0,0x16,0x00,0x9e,0xf0,0x16,0x00,0x82,0xf0,0x16,0x00,0x66,0xf0,0x16,0x00,0x4a,0xf0,0x15,0x00,0x2d,0xf0,0x15,0x00,0x11,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x09,0x00,0x00,0x10,0x09,0x00,0xe3,0x0f,0x09,0x00,0xc7,0x0f,0x09,0x00,0xaa,0x0f,0x0a,0x00,0x8e,0x0f,0x0a,0x00,0x72,0x0f,0x0a,0x00,0x56,0x0f,0x0a,0x00,0x3a,0x0f,0x0b,0x00,0x1e,0x0f,0x0b,0x00,0x02,0x0f,0x0b,0x00,0xe6,0x0e,0x0c,0x00,0xcb,0x0e,0x0c,0x00,0xaf,0x0e,0x0c,0x00,0x94,0x0e,0x0d,0x00,0x79,0x0e,0x0d,0x00,0x5e,0x0e,0x0e,0x00,0x43,0x0e,0x0e,0x00,0x28,0x0e,0x0e,0x00,  \
    0x0e,0x0e,0x0f,0x00,0xf3,0x0d,0x0f,0x00,0xd9,0x0d,0x0f,0x00,0xbe,0x0d,0x10,0x00,0xa4,0x0d,0x10,0x00,0x8a,0x0d,0x11,0x00,0x70,0x0d,0x11,0x00,0x56,0x0d,0x12,0x00,0x3d,0x0d,0x12,0x00,0x23,0x0d,0x12,0x00,0x09,0x0d,0x13,0x00,0xf0,0x0c,0x13,0x00,0xd7,0x0c,0x14,0x00,0xbe,0x0c,0x14,0x00,0xa5,0x0c,0x15,0x00,0x8c,0x0c,0x15,0x00,0x73,0x0c,0x16,0x00,0x5a,0x0c,0x16,0x00,0x42,0x0c,0x17,0x00,0x29,0x0c,0x17,0x00,0x11,0x0c,0x18,0x00,0xf9,0x0b,0x18,0x00,0xe1,0x0b,  \
    0x19,0x00,0xc9,0x0b,0x19,0x00,0xb1,0x0b,0x1a,0x00,0x99,0x0b,0x1a,0x00,0x81,0x0b,0x1b,0x00,0x6a,0x0b,0x1b,0x00,0x53,0x0b,0x1c,0x00,0x3b,0x0b,0x1c,0x00,0x24,0x0b,0x1d,0x00,0x0d,0x0b,0x1e,0x00,0xf6,0x0a,0x1e,0x00,0xdf,0x0a,0x1f,0x00,0xc9,0x0a,0x1f,0x00,0xb2,0x0a,0x20,0x00,0x9b,0x0a,0x20,0x00,0x85,0x0a,0x21,0x00,0x6f,0x0a,0x21,0x00,0x59,0x0a,0x22,0x00,0x43,0x0a,0x23,0x00,0x2d,0x0a,0x23,0x00,0x17,0x0a,0x24,0x00,0x01,0x0a,0x24,0x00,0xeb,0x09,0x25,0x00,  \
    0xd6,0x09,0x25,0x00,0xc0,0x09,0x26,0x00,0xab,0x09,0x27,0x00,0x96,0x09,0x27,0x00,0x81,0x09,0x28,0x00,0x6c,0x09,0x28,0x00,0x57,0x09,0x29,0x00,0x42,0x09,0x2a,0x00,0x2e,0x09,0x2a,0x00,0x19,0x09,0x2b,0x00,0x05,0x09,0x2b,0x00,0xf0,0x08,0x2c,0x00,0xdc,0x08,0x2d,0x00,0xc8,0x08,0x2d,0x00,0xb4,0x08,0x2e,0x00,0xa0,0x08,0x2e,0x00,0x8c,0x08,0x2f,0x00,0x78,0x08,0x30,0x00,0x65,0x08,0x30,0x00,0x51,0x08,0x31,0x00,0x3e,0x08,0x31,0x00,0x2a,0x08,0x32,0x00,0x17,0x08,  \
    0x33,0x00,0x04,0x08,0x33,0x00,0xf1,0x07,0x34,0x00,0xde,0x07,0x34,0x00,0xcb,0x07,0x35,0x00,0xb9,0x07,0x36,0x00,0xa6,0x07,0x36,0x00,0x93,0x07,0x37,0x00,0x81,0x07,0x38,0x00,0x6f,0x07,0x38,0x00,0x5c,0x07,0x39,0x00,0x4a,0x07,0x39,0x00,0x38,0x07,0x3a,0x00,0x26,0x07,0x3b,0x00,0x14,0x07,0x3b,0x00,0x03,0x07,0x3c,0x00,0xf1,0x06,0x3c,0x00,0xdf,0x06,0x3d,0x00,0xce,0x06,0x3d,0x00,0xbd,0x06,0x3e,0x00,0xab,0x06,0x3f,0x00,0x9a,0x06,0x3f,0x00,0x89,0x06,0x40,0x00,  \
    0x78,0x06,0x40,0x00,0x67,0x06,0x41,0x00,0x56,0x06,0x42,0x00,0x45,0x06,0x42,0x00,0x35,0x06,0x43,0x00,0x24,0x06,0x43,0x00,0x14,0x06,0x44,0x00,0x03,0x06,0x44,0x00,0xf3,0x05,0x45,0x00,0xe3,0x05,0x46,0x00,0xd2,0x05,0x46,0x00,0xc2,0x05,0x47,0x00,0xb2,0x05,0x47,0x00,0xa2,0x05,0x48,0x00,0x93,0x05,0x48,0x00,0x83,0x05,0x49,0x00,0x73,0x05,0x4a,0x00,0x64,0x05,0x4a,0x00,0x54,0x05,0x4b,0x00,0x45,0x05,0x4b,0x00,0x35,0x05,0x4c,0x00,0x26,0x05,0x4c,0x00,0x17,0x05,  \
    0x4d,0x00,0x08,0x05,0x4d,0x00,0xf9,0x04,0x4e,0x00,0xea,0x04,0x4e,0x00,0xdb,0x04,0x4f,0x00,0xcc,0x04,0x4f,0x00,0xbd,0x04,0x50,0x00,0xaf,0x04,0x50,0x00,0xa0,0x04,0x51,0x00,0x92,0x04,0x51,0x00,0x83,0x04,0x52,0x00,0x75,0x04,0x52,0x00,0x66,0x04,0x53,0x00,0x58,0x04,0x53,0x00,0x4a,0x04,0x54,0x00,0x3c,0x04,0x54,0x00,0x2e,0x04,0x55,0x00,0x20,0x04,0x55,0x00,0x12,0x04,0x56,0x00,0x04,0x04,0x56,0x00,0xf6,0x03,0x57,0x00,0xe9,0x03,0x57,0x00,0xdb,0x03,0x58,0x00,  \
    0xce,0x03,0x58,0x00,0xc0,0x03,0x59,0x00,0xb3,0x03,0x59,0x00,0xa5,0x03,0x59,0x00,0x98,0x03,0x5a,0x00,0x8b,0x03,0x5a,0x00,0x7d,0x03,0x5b,0x00,0x70,0x03,0x5b,0x00,0x63,0x03,0x5c,0x00,0x56,0x03,0x5c,0x00,0x49,0x03,0x5c,0x00,0x3c,0x03,0x5d,0x00,0x2f,0x03,0x5d,0x00,0x23,0x03,0x5e,0x00,0x16,0x03,0x5e,0x00,0x09,0x03,0x5e,0x00,0xfd,0x02,0x5f,0x00,0xf0,0x02,0x5f,0x00,0xe3,0x02,0x5f,0x00,0xd7,0x02,0x60,0x00,0xcb,0x02,0x60,0x00,0xbe,0x02,0x61,0x00,0xb2,0x02,  \
    0x61,0x00,0xa6,0x02,0x61,0x00,0x99,0x02,0x62,0x00,0x8d,0x02,0x62,0x00,0x81,0x02,0x62,0x00,0x75,0x02,0x63,0x00,0x69,0x02,0x63,0x00,0x5d,0x02,0x63,0x00,0x51,0x02,0x64,0x00,0x45,0x02,0x64,0x00,0x39,0x02,0x64,0x00,0x2d,0x02,0x64,0x00,0x22,0x02,0x65,0x00,0x16,0x02,0x65,0x00,0x0a,0x02,0x65,0x00,0xff,0x01,0x66,0x00,0xf3,0x01,0x66,0x00,0xe7,0x01,0x66,0x00,0xdc,0x01,0x66,0x00,0xd0,0x01,0x67,0x00,0xc5,0x01,0x67,0x00,0xb9,0x01,0x67,0x00,0xae,0x01,0x67,0x00,  \
    0xa3,0x01,0x68,0x00,0x97,0x01,0x68,0x00,0x8c,0x01,0x68,0x00,0x81,0x01,0x68,0x00,0x76,0x01,0x69,0x00,0x6a,0x01,0x69,0x00,0x5f,0x01,0x69,0x00,0x54,0x01,0x69,0x00,0x49,0x01,0x69,0x00,0x3e,0x01,0x6a,0x00,0x33,0x01,0x6a,0x00,0x28,0x01,0x6a,0x00,0x1d,0x01,0x6a,0x00,0x12,0x01,0x6a,0x00,0x07,0x01,0x6b,0x00,0xfc,0x00,0x6b,0x00,0xf1,0x00,0x6b,0x00,0xe6,0x00,0x6b,0x00,0xdb,0x00,0x6b,0x00,0xd0,0x00,0x6b,0x00,0xc5,0x00,0x6b,0x00,0xbb,0x00,0x6c,0x00,0xb0,0x00,  \
    0x6c,0x00,0xa5,0x00,0x6c,0x00,0x9a,0x00,0x6c,0x00,0x8f,0x00,0x6c,0x00,0x85,0x00,0x6c,0x00,0x7a,0x00,0x6c,0x00,0x6f,0x00,0x6c,0x00,0x65,0x00,0x6c,0x00,0x5a,0x00,0x6c,0x00,0x4f,0x00,0x6d,0x00,0x45,0x00,0x6d,0x00,0x3a,0x00,0x6d,0x00,0x2f,0x00,0x6d,0x00,0x25,0x00,0x6d,0x00,0x1a,0x00,0x6d,0x00,0x0f,0x00,0x6d,0x00,0x05,0x00,0x6d,0x00,0xfa,0xff,0x6d,0x00,0xf0,0xff,0x6d,0x00,0xe5,0xff,0x6d,0x00,0xda,0xff,0x6d,0x00,0xd0,0xff,0x6d,0x00,0xc5,0xff,0x6d,0x00,  \
    0xbb,0xff,0x6d,0x00,0xb0,0xff,0x6d,0x00,0xa6,0xff,0x6d,0x00,0x9b,0xff,0x6d,0x00,0x90,0xff,0x6d,0x00,0x86,0xff,0x6d,0x00,0x7b,0xff,0x6d,0x00,0x71,0xff,0x6d,0x00,0x66,0xff,0x6d,0x00,0x5b,0xff,0x6d,0x00,0x51,0xff,0x6d,0x00,0x46,0xff,0x6c,0x00,0x3b,0xff,0x6c,0x00,0x31,0xff,0x6c,0x00,0x26,0xff,0x6c,0x00,0x1c,0xff,0x6c,0x00,0x11,0xff,0x6c,0x00,0x06,0xff,0x6c,0x00,0xfc,0xfe,0x6c,0x00,0xf1,0xfe,0x6c,0x00,0xe6,0xfe,0x6c,0x00,0xdb,0xfe,0x6c,0x00,0xd1,0xfe,  \
    0x6b,0x00,0xc6,0xfe,0x6b,0x00,0xbb,0xfe,0x6b,0x00,0xb0,0xfe,0x6b,0x00,0xa5,0xfe,0x6b,0x00,0x9b,0xfe,0x6b,0x00,0x90,0xfe,0x6a,0x00,0x85,0xfe,0x6a,0x00,0x7a,0xfe,0x6a,0x00,0x6f,0xfe,0x6a,0x00,0x64,0xfe,0x6a,0x00,0x59,0xfe,0x6a,0x00,0x4e,0xfe,0x69,0x00,0x43,0xfe,0x69,0x00,0x38,0xfe,0x69,0x00,0x2d,0xfe,0x69,0x00,0x22,0xfe,0x69,0x00,0x17,0xfe,0x68,0x00,0x0c,0xfe,0x68,0x00,0x01,0xfe,0x68,0x00,0xf6,0xfd,0x68,0x00,0xea,0xfd,0x67,0x00,0xdf,0xfd,0x67,0x00,  \
    0xd4,0xfd,0x67,0x00,0xc9,0xfd,0x67,0x00,0xbd,0xfd,0x66,0x00,0xb2,0xfd,0x66,0x00,0xa6,0xfd,0x66,0x00,0x9b,0xfd,0x66,0x00,0x8f,0xfd,0x65,0x00,0x84,0xfd,0x65,0x00,0x78,0xfd,0x65,0x00,0x6d,0xfd,0x64,0x00,0x61,0xfd,0x64,0x00,0x55,0xfd,0x64,0x00,0x4a,0xfd,0x64,0x00,0x3e,0xfd,0x63,0x00,0x32,0xfd,0x63,0x00,0x26,0xfd,0x63,0x00,0x1a,0xfd,0x62,0x00,0x0e,0xfd,0x62,0x00,0x02,0xfd,0x62,0x00,0xf6,0xfc,0x61,0x00,0xea,0xfc,0x61,0x00,0xde,0xfc,0x60,0x00,0xd2,0xfc,  \
    0x60,0x00,0xc6,0xfc,0x60,0x00,0xba,0xfc,0x5f,0x00,0xad,0xfc,0x5f,0x00,0xa1,0xfc,0x5f,0x00,0x94,0xfc,0x5e,0x00,0x88,0xfc,0x5e,0x00,0x7b,0xfc,0x5d,0x00,0x6f,0xfc,0x5d,0x00,0x62,0xfc,0x5d,0x00,0x56,0xfc,0x5c,0x00,0x49,0xfc,0x5c,0x00,0x3c,0xfc,0x5b,0x00,0x2f,0xfc,0x5b,0x00,0x22,0xfc,0x5b,0x00,0x15,0xfc,0x5a,0x00,0x08,0xfc,0x5a,0x00,0xfb,0xfb,0x59,0x00,0xee,0xfb,0x59,0x00,0xe1,0xfb,0x58,0x00,0xd4,0xfb,0x58,0x00,0xc6,0xfb,0x57,0x00,0xb9,0xfb,0x57,0x00,  \
    0xac,0xfb,0x57,0x00,0x9e,0xfb,0x56,0x00,0x90,0xfb,0x56,0x00,0x83,0xfb,0x55,0x00,0x75,0xfb,0x55,0x00,0x67,0xfb,0x54,0x00,0x5a,0xfb,0x54,0x00,0x4c,0xfb,0x53,0x00,0x3e,0xfb,0x53,0x00,0x30,0xfb,0x52,0x00,0x22,0xfb,0x52,0x00,0x13,0xfb,0x51,0x00,0x05,0xfb,0x51,0x00,0xf7,0xfa,0x50,0x00,0xe8,0xfa,0x50,0x00,0xda,0xfa,0x4f,0x00,0xcb,0xfa,0x4f,0x00,0xbd,0xfa,0x4e,0x00,0xae,0xfa,0x4e,0x00,0x9f,0xfa,0x4d,0x00,0x90,0xfa,0x4d,0x00,0x82,0xfa,0x4c,0x00,0x73,0xfa,  \
    0x4b,0x00,0x63,0xfa,0x4b,0x00,0x54,0xfa,0x4a,0x00,0x45,0xfa,0x4a,0x00,0x36,0xfa,0x49,0x00,0x26,0xfa,0x49,0x00,0x17,0xfa,0x48,0x00,0x07,0xfa,0x48,0x00,0xf8,0xf9,0x47,0x00,0xe8,0xf9,0x47,0x00,0xd8,0xf9,0x46,0x00,0xc8,0xf9,0x45,0x00,0xb8,0xf9,0x45,0x00,0xa8,0xf9,0x44,0x00,0x98,0xf9,0x44,0x00,0x88,0xf9,0x43,0x00,0x78,0xf9,0x42,0x00,0x67,0xf9,0x42,0x00,0x57,0xf9,0x41,0x00,0x46,0xf9,0x41,0x00,0x36,0xf9,0x40,0x00,0x25,0xf9,0x40,0x00,0x14,0xf9,0x3f,0x00,  \
    0x03,0xf9,0x3e,0x00,0xf2,0xf8,0x3e,0x00,0xe1,0xf8,0x3d,0x00,0xd0,0xf8,0x3d,0x00,0xbe,0xf8,0x3c,0x00,0xad,0xf8,0x3b,0x00,0x9c,0xf8,0x3b,0x00,0x8a,0xf8,0x3a,0x00,0x78,0xf8,0x3a,0x00,0x66,0xf8,0x39,0x00,0x55,0xf8,0x38,0x00,0x43,0xf8,0x38,0x00,0x31,0xf8,0x37,0x00,0x1e,0xf8,0x37,0x00,0x0c,0xf8,0x36,0x00,0xfa,0xf7,0x35,0x00,0xe7,0xf7,0x35,0x00,0xd5,0xf7,0x34,0x00,0xc2,0xf7,0x34,0x00,0xaf,0xf7,0x33,0x00,0x9c,0xf7,0x32,0x00,0x8a,0xf7,0x32,0x00,0x76,0xf7,  \
    0x31,0x00,0x63,0xf7,0x31,0x00,0x50,0xf7,0x30,0x00,0x3d,0xf7,0x2f,0x00,0x29,0xf7,0x2f,0x00,0x16,0xf7,0x2e,0x00,0x02,0xf7,0x2d,0x00,0xee,0xf6,0x2d,0x00,0xda,0xf6,0x2c,0x00,0xc6,0xf6,0x2c,0x00,0xb2,0xf6,0x2b,0x00,0x9e,0xf6,0x2a,0x00,0x89,0xf6,0x2a,0x00,0x75,0xf6,0x29,0x00,0x60,0xf6,0x29,0x00,0x4c,0xf6,0x28,0x00,0x37,0xf6,0x27,0x00,0x22,0xf6,0x27,0x00,0x0d,0xf6,0x26,0x00,0xf8,0xf5,0x26,0x00,0xe3,0xf5,0x25,0x00,0xce,0xf5,0x25,0x00,0xb8,0xf5,0x24,0x00,  \
    0xa3,0xf5,0x23,0x00,0x8d,0xf5,0x23,0x00,0x77,0xf5,0x22,0x00,0x61,0xf5,0x22,0x00,0x4b,0xf5,0x21,0x00,0x35,0xf5,0x21,0x00,0x1f,0xf5,0x20,0x00,0x08,0xf5,0x1f,0x00,0xf2,0xf4,0x1f,0x00,0xdb,0xf4,0x1e,0x00,0xc5,0xf4,0x1e,0x00,0xae,0xf4,0x1d,0x00,0x97,0xf4,0x1d,0x00,0x80,0xf4,0x1c,0x00,0x69,0xf4,0x1c,0x00,0x51,0xf4,0x1b,0x00,0x3a,0xf4,0x1b,0x00,0x23,0xf4,0x1a,0x00,0x0b,0xf4,0x1a,0x00,0xf3,0xf3,0x19,0x00,0xdb,0xf3,0x19,0x00,0xc3,0xf3,0x18,0x00,0xab,0xf3,  \
    0x18,0x00,0x93,0xf3,0x17,0x00,0x7a,0xf3,0x17,0x00,0x62,0xf3,0x16,0x00,0x49,0xf3,0x16,0x00,0x31,0xf3,0x15,0x00,0x18,0xf3,0x15,0x00,0xff,0xf2,0x14,0x00,0xe6,0xf2,0x14,0x00,0xcc,0xf2,0x13,0x00,0xb3,0xf2,0x13,0x00,0x9a,0xf2,0x12,0x00,0x80,0xf2,0x12,0x00,0x66,0xf2,0x12,0x00,0x4c,0xf2,0x11,0x00,0x32,0xf2,0x11,0x00,0x18,0xf2,0x10,0x00,0xfe,0xf1,0x10,0x00,0xe4,0xf1,0x10,0x00,0xc9,0xf1,0x0f,0x00,0xaf,0xf1,0x0f,0x00,0x94,0xf1,0x0e,0x00,0x79,0xf1,0x0e,0x00,  \
    0x5e,0xf1,0x0e,0x00,0x43,0xf1,0x0d,0x00,0x28,0xf1,0x0d,0x00,0x0c,0xf1,0x0d,0x00,0xf1,0xf0,0x0c,0x00,0xd5,0xf0,0x0c,0x00,0xba,0xf0,0x0c,0x00,0x9e,0xf0,0x0c,0x00,0x82,0xf0,0x0b,0x00,0x66,0xf0,0x0b,0x00,0x49,0xf0,0x0b,0x00,0x2d,0xf0,0x0a,0x00,0x10,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfd,0xff,0x01,0x10,0xfd,0xff,0xe4,0x0f,0xfe,0xff,0xc7,0x0f,0xfe,0xff,0xab,0x0f,0xfe,0xff,0x8f,0x0f,0xff,0xff,0x72,0x0f,0xff,0xff,0x56,0x0f,0xff,0xff,0x3a,0x0f,0x00,0x00,0x1e,0x0f,0x00,0x00,0x03,0x0f,0x00,0x00,0xe7,0x0e,0x01,0x00,0xcc,0x0e,0x01,0x00,0xb0,0x0e,0x02,0x00,0x95,0x0e,0x02,0x00,0x7a,0x0e,0x02,0x00,0x5f,0x0e,0x03,0x00,0x44,0x0e,0x03,0x00,  \
    0x29,0x0e,0x04,0x00,0x0e,0x0e,0x04,0x00,0xf4,0x0d,0x05,0x00,0xd9,0x0d,0x05,0x00,0xbf,0x0d,0x06,0x00,0xa5,0x0d,0x06,0x00,0x8b,0x0d,0x07,0x00,0x71,0x0d,0x07,0x00,0x57,0x0d,0x08,0x00,0x3d,0x0d,0x08,0x00,0x24,0x0d,0x09,0x00,0x0a,0x0d,0x09,0x00,0xf1,0x0c,0x0a,0x00,0xd8,0x0c,0x0a,0x00,0xbe,0x0c,0x0b,0x00,0xa5,0x0c,0x0b,0x00,0x8c,0x0c,0x0c,0x00,0x74,0x0c,0x0c,0x00,0x5b,0x0c,0x0d,0x00,0x42,0x0c,0x0e,0x00,0x2a,0x0c,0x0e,0x00,0x12,0x0c,0x0f,0x00,0xf9,0x0b,  \
    0x0f,0x00,0xe1,0x0b,0x10,0x00,0xc9,0x0b,0x11,0x00,0xb2,0x0b,0x11,0x00,0x9a,0x0b,0x12,0x00,0x82,0x0b,0x12,0x00,0x6b,0x0b,0x13,0x00,0x53,0x0b,0x14,0x00,0x3c,0x0b,0x14,0x00,0x25,0x0b,0x15,0x00,0x0e,0x0b,0x16,0x00,0xf7,0x0a,0x16,0x00,0xe0,0x0a,0x17,0x00,0xc9,0x0a,0x18,0x00,0xb3,0x0a,0x18,0x00,0x9c,0x0a,0x19,0x00,0x86,0x0a,0x1a,0x00,0x70,0x0a,0x1a,0x00,0x59,0x0a,0x1b,0x00,0x43,0x0a,0x1c,0x00,0x2d,0x0a,0x1c,0x00,0x18,0x0a,0x1d,0x00,0x02,0x0a,0x1e,0x00,  \
    0xec,0x09,0x1e,0x00,0xd7,0x09,0x1f,0x00,0xc1,0x09,0x20,0x00,0xac,0x09,0x20,0x00,0x97,0x09,0x21,0x00,0x82,0x09,0x22,0x00,0x6d,0x09,0x22,0x00,0x58,0x09,0x23,0x00,0x43,0x09,0x24,0x00,0x2e,0x09,0x24,0x00,0x1a,0x09,0x25,0x00,0x05,0x09,0x26,0x00,0xf1,0x08,0x27,0x00,0xdd,0x08,0x27,0x00,0xc9,0x08,0x28,0x00,0xb5,0x08,0x29,0x00,0xa1,0x08,0x29,0x00,0x8d,0x08,0x2a,0x00,0x79,0x08,0x2b,0x00,0x66,0x08,0x2b,0x00,0x52,0x08,0x2c,0x00,0x3f,0x08,0x2d,0x00,0x2b,0x08,  \
    0x2e,0x00,0x18,0x08,0x2e,0x00,0x05,0x08,0x2f,0x00,0xf2,0x07,0x30,0x00,0xdf,0x07,0x30,0x00,0xcc,0x07,0x31,0x00,0xb9,0x07,0x32,0x00,0xa7,0x07,0x33,0x00,0x94,0x07,0x33,0x00,0x82,0x07,0x34,0x00,0x70,0x07,0x35,0x00,0x5d,0x07,0x35,0x00,0x4b,0x07,0x36,0x00,0x39,0x07,0x37,0x00,0x27,0x07,0x37,0x00,0x15,0x07,0x38,0x00,0x04,0x07,0x39,0x00,0xf2,0x06,0x3a,0x00,0xe0,0x06,0x3a,0x00,0xcf,0x06,0x3b,0x00,0xbd,0x06,0x3c,0x00,0xac,0x06,0x3c,0x00,0x9b,0x06,0x3d,0x00,  \
    0x8a,0x06,0x3e,0x00,0x79,0x06,0x3e,0x00,0x68,0x06,0x3f,0x00,0x57,0x06,0x40,0x00,0x46,0x06,0x40,0x00,0x36,0x06,0x41,0x00,0x25,0x06,0x42,0x00,0x15,0x06,0x42,0x00,0x04,0x06,0x43,0x00,0xf4,0x05,0x44,0x00,0xe4,0x05,0x44,0x00,0xd3,0x05,0x45,0x00,0xc3,0x05,0x46,0x00,0xb3,0x05,0x46,0x00,0xa3,0x05,0x47,0x00,0x94,0x05,0x48,0x00,0x84,0x05,0x48,0x00,0x74,0x05,0x49,0x00,0x65,0x05,0x4a,0x00,0x55,0x05,0x4a,0x00,0x46,0x05,0x4b,0x00,0x36,0x05,0x4b,0x00,0x27,0x05,  \
    0x4c,0x00,0x18,0x05,0x4d,0x00,0x09,0x05,0x4d,0x00,0xfa,0x04,0x4e,0x00,0xeb,0x04,0x4f,0x00,0xdc,0x04,0x4f,0x00,0xcd,0x04,0x50,0x00,0xbe,0x04,0x50,0x00,0xb0,0x04,0x51,0x00,0xa1,0x04,0x52,0x00,0x92,0x04,0x52,0x00,0x84,0x04,0x53,0x00,0x76,0x04,0x53,0x00,0x67,0x04,0x54,0x00,0x59,0x04,0x54,0x00,0x4b,0x04,0x55,0x00,0x3d,0x04,0x56,0x00,0x2f,0x04,0x56,0x00,0x21,0x04,0x57,0x00,0x13,0x04,0x57,0x00,0x05,0x04,0x58,0x00,0xf7,0x03,0x58,0x00,0xea,0x03,0x59,0x00,  \
    0xdc,0x03,0x59,0x00,0xce,0x03,0x5a,0x00,0xc1,0x03,0x5a,0x00,0xb3,0x03,0x5b,0x00,0xa6,0x03,0x5b,0x00,0x99,0x03,0x5c,0x00,0x8b,0x03,0x5c,0x00,0x7e,0x03,0x5d,0x00,0x71,0x03,0x5d,0x00,0x64,0x03,0x5e,0x00,0x57,0x03,0x5e,0x00,0x4a,0x03,0x5f,0x00,0x3d,0x03,0x5f,0x00,0x30,0x03,0x60,0x00,0x23,0x03,0x60,0x00,0x17,0x03,0x61,0x00,0x0a,0x03,0x61,0x00,0xfd,0x02,0x62,0x00,0xf1,0x02,0x62,0x00,0xe4,0x02,0x63,0x00,0xd8,0x02,0x63,0x00,0xcb,0x02,0x63,0x00,0xbf,0x02,  \
    0x64,0x00,0xb3,0x02,0x64,0x00,0xa6,0x02,0x65,0x00,0x9a,0x02,0x65,0x00,0x8e,0x02,0x65,0x00,0x82,0x02,0x66,0x00,0x76,0x02,0x66,0x00,0x6a,0x02,0x67,0x00,0x5e,0x02,0x67,0x00,0x52,0x02,0x67,0x00,0x46,0x02,0x68,0x00,0x3a,0x02,0x68,0x00,0x2e,0x02,0x68,0x00,0x22,0x02,0x69,0x00,0x16,0x02,0x69,0x00,0x0b,0x02,0x69,0x00,0xff,0x01,0x6a,0x00,0xf4,0x01,0x6a,0x00,0xe8,0x01,0x6a,0x00,0xdc,0x01,0x6b,0x00,0xd1,0x01,0x6b,0x00,0xc5,0x01,0x6b,0x00,0xba,0x01,0x6c,0x00,  \
    0xaf,0x01,0x6c,0x00,0xa3,0x01,0x6c,0x00,0x98,0x01,0x6c,0x00,0x8d,0x01,0x6d,0x00,0x81,0x01,0x6d,0x00,0x76,0x01,0x6d,0x00,0x6b,0x01,0x6d,0x00,0x60,0x01,0x6e,0x00,0x54,0x01,0x6e,0x00,0x49,0x01,0x6e,0x00,0x3e,0x01,0x6e,0x00,0x33,0x01,0x6f,0x00,0x28,0x01,0x6f,0x00,0x1d,0x01,0x6f,0x00,0x12,0x01,0x6f,0x00,0x07,0x01,0x6f,0x00,0xfc,0x00,0x70,0x00,0xf1,0x00,0x70,0x00,0xe6,0x00,0x70,0x00,0xdb,0x00,0x70,0x00,0xd1,0x00,0x70,0x00,0xc6,0x00,0x70,0x00,0xbb,0x00,  \
    0x71,0x00,0xb0,0x00,0x71,0x00,0xa5,0x00,0x71,0x00,0x9a,0x00,0x71,0x00,0x90,0x00,0x71,0x00,0x85,0x00,0x71,0x00,0x7a,0x00,0x71,0x00,0x70,0x00,0x71,0x00,0x65,0x00,0x72,0x00,0x5a,0x00,0x72,0x00,0x4f,0x00,0x72,0x00,0x45,0x00,0x72,0x00,0x3a,0x00,0x72,0x00,0x2f,0x00,0x72,0x00,0x25,0x00,0x72,0x00,0x1a,0x00,0x72,0x00,0x10,0x00,0x72,0x00,0x05,0x00,0x72,0x00,0xfa,0xff,0x72,0x00,0xf0,0xff,0x72,0x00,0xe5,0xff,0x72,0x00,0xda,0xff,0x72,0x00,0xd0,0xff,0x72,0x00,  \
    0xc5,0xff,0x72,0x00,0xbb,0xff,0x72,0x00,0xb0,0xff,0x72,0x00,0xa6,0xff,0x72,0x00,0x9b,0xff,0x72,0x00,0x90,0xff,0x72,0x00,0x86,0xff,0x72,0x00,0x7b,0xff,0x72,0x00,0x70,0xff,0x72,0x00,0x66,0xff,0x72,0x00,0x5b,0xff,0x72,0x00,0x51,0xff,0x72,0x00,0x46,0xff,0x72,0x00,0x3b,0xff,0x72,0x00,0x31,0xff,0x72,0x00,0x26,0xff,0x71,0x00,0x1b,0xff,0x71,0x00,0x11,0xff,0x71,0x00,0x06,0xff,0x71,0x00,0xfb,0xfe,0x71,0x00,0xf1,0xfe,0x71,0x00,0xe6,0xfe,0x71,0x00,0xdb,0xfe,  \
    0x71,0x00,0xd0,0xfe,0x70,0x00,0xc6,0xfe,0x70,0x00,0xbb,0xfe,0x70,0x00,0xb0,0xfe,0x70,0x00,0xa5,0xfe,0x70,0x00,0x9a,0xfe,0x70,0x00,0x8f,0xfe,0x6f,0x00,0x85,0xfe,0x6f,0x00,0x7a,0xfe,0x6f,0x00,0x6f,0xfe,0x6f,0x00,0x64,0xfe,0x6f,0x00,0x59,0xfe,0x6e,0x00,0x4e,0xfe,0x6e,0x00,0x43,0xfe,0x6e,0x00,0x38,0xfe,0x6e,0x00,0x2d,0xfe,0x6d,0x00,0x22,0xfe,0x6d,0x00,0x17,0xfe,0x6d,0x00,0x0b,0xfe,0x6d,0x00,0x00,0xfe,0x6c,0x00,0xf5,0xfd,0x6c,0x00,0xea,0xfd,0x6c,0x00,  \
    0xdf,0xfd,0x6c,0x00,0xd3,0xfd,0x6b,0x00,0xc8,0xfd,0x6b,0x00,0xbd,0xfd,0x6b,0x00,0xb1,0xfd,0x6a,0x00,0xa6,0xfd,0x6a,0x00,0x9a,0xfd,0x6a,0x00,0x8f,0xfd,0x69,0x00,0x83,0xfd,0x69,0x00,0x78,0xfd,0x69,0x00,0x6c,0xfd,0x68,0x00,0x61,0xfd,0x68,0x00,0x55,0xfd,0x68,0x00,0x49,0xfd,0x67,0x00,0x3d,0xfd,0x67,0x00,0x32,0xfd,0x67,0x00,0x26,0xfd,0x66,0x00,0x1a,0xfd,0x66,0x00,0x0e,0xfd,0x65,0x00,0x02,0xfd,0x65,0x00,0xf6,0xfc,0x65,0x00,0xea,0xfc,0x64,0x00,0xde,0xfc,  \
    0x64,0x00,0xd1,0xfc,0x63,0x00,0xc5,0xfc,0x63,0x00,0xb9,0xfc,0x62,0x00,0xad,0xfc,0x62,0x00,0xa0,0xfc,0x62,0x00,0x94,0xfc,0x61,0x00,0x87,0xfc,0x61,0x00,0x7b,0xfc,0x60,0x00,0x6e,0xfc,0x60,0x00,0x62,0xfc,0x5f,0x00,0x55,0xfc,0x5f,0x00,0x48,0xfc,0x5e,0x00,0x3b,0xfc,0x5e,0x00,0x2e,0xfc,0x5d,0x00,0x22,0xfc,0x5d,0x00,0x15,0xfc,0x5c,0x00,0x08,0xfc,0x5c,0x00,0xfb,0xfb,0x5b,0x00,0xed,0xfb,0x5b,0x00,0xe0,0xfb,0x5a,0x00,0xd3,0xfb,0x5a,0x00,0xc6,0xfb,0x59,0x00,  \
    0xb8,0xfb,0x59,0x00,0xab,0xfb,0x58,0x00,0x9d,0xfb,0x58,0x00,0x90,0xfb,0x57,0x00,0x82,0xfb,0x57,0x00,0x74,0xfb,0x56,0x00,0x67,0xfb,0x55,0x00,0x59,0xfb,0x55,0x00,0x4b,0xfb,0x54,0x00,0x3d,0xfb,0x54,0x00,0x2f,0xfb,0x53,0x00,0x21,0xfb,0x53,0x00,0x12,0xfb,0x52,0x00,0x04,0xfb,0x51,0x00,0xf6,0xfa,0x51,0x00,0xe7,0xfa,0x50,0x00,0xd9,0xfa,0x50,0x00,0xca,0xfa,0x4f,0x00,0xbc,0xfa,0x4e,0x00,0xad,0xfa,0x4e,0x00,0x9e,0xfa,0x4d,0x00,0x90,0xfa,0x4d,0x00,0x81,0xfa,  \
    0x4c,0x00,0x72,0xfa,0x4b,0x00,0x63,0xfa,0x4b,0x00,0x53,0xfa,0x4a,0x00,0x44,0xfa,0x49,0x00,0x35,0xfa,0x49,0x00,0x26,0xfa,0x48,0x00,0x16,0xfa,0x48,0x00,0x06,0xfa,0x47,0x00,0xf7,0xf9,0x46,0x00,0xe7,0xf9,0x46,0x00,0xd7,0xf9,0x45,0x00,0xc7,0xf9,0x44,0x00,0xb7,0xf9,0x44,0x00,0xa7,0xf9,0x43,0x00,0x97,0xf9,0x42,0x00,0x87,0xf9,0x42,0x00,0x77,0xf9,0x41,0x00,0x66,0xf9,0x40,0x00,0x56,0xf9,0x40,0x00,0x45,0xf9,0x3f,0x00,0x35,0xf9,0x3e,0x00,0x24,0xf9,0x3d,0x00,  \
    0x13,0xf9,0x3d,0x00,0x02,0xf9,0x3c,0x00,0xf1,0xf8,0x3b,0x00,0xe0,0xf8,0x3b,0x00,0xcf,0xf8,0x3a,0x00,0xbd,0xf8,0x39,0x00,0xac,0xf8,0x39,0x00,0x9b,0xf8,0x38,0x00,0x89,0xf8,0x37,0x00,0x77,0xf8,0x37,0x00,0x66,0xf8,0x36,0x00,0x54,0xf8,0x35,0x00,0x42,0xf8,0x34,0x00,0x30,0xf8,0x34,0x00,0x1e,0xf8,0x33,0x00,0x0b,0xf8,0x32,0x00,0xf9,0xf7,0x32,0x00,0xe6,0xf7,0x31,0x00,0xd4,0xf7,0x30,0x00,0xc1,0xf7,0x2f,0x00,0xae,0xf7,0x2f,0x00,0x9c,0xf7,0x2e,0x00,0x89,0xf7,  \
    0x2d,0x00,0x76,0xf7,0x2d,0x00,0x62,0xf7,0x2c,0x00,0x4f,0xf7,0x2b,0x00,0x3c,0xf7,0x2b,0x00,0x28,0xf7,0x2a,0x00,0x15,0xf7,0x29,0x00,0x01,0xf7,0x28,0x00,0xed,0xf6,0x28,0x00,0xd9,0xf6,0x27,0x00,0xc5,0xf6,0x26,0x00,0xb1,0xf6,0x26,0x00,0x9d,0xf6,0x25,0x00,0x89,0xf6,0x24,0x00,0x74,0xf6,0x24,0x00,0x60,0xf6,0x23,0x00,0x4b,0xf6,0x22,0x00,0x36,0xf6,0x21,0x00,0x21,0xf6,0x21,0x00,0x0c,0xf6,0x20,0x00,0xf7,0xf5,0x1f,0x00,0xe2,0xf5,0x1f,0x00,0xcd,0xf5,0x1e,0x00,  \
    0xb7,0xf5,0x1d,0x00,0xa2,0xf5,0x1d,0x00,0x8c,0xf5,0x1c,0x00,0x76,0xf5,0x1b,0x00,0x60,0xf5,0x1b,0x00,0x4a,0xf5,0x1a,0x00,0x34,0xf5,0x19,0x00,0x1e,0xf5,0x19,0x00,0x08,0xf5,0x18,0x00,0xf1,0xf4,0x17,0x00,0xdb,0xf4,0x17,0x00,0xc4,0xf4,0x16,0x00,0xad,0xf4,0x15,0x00,0x96,0xf4,0x15,0x00,0x7f,0xf4,0x14,0x00,0x68,0xf4,0x14,0x00,0x51,0xf4,0x13,0x00,0x39,0xf4,0x12,0x00,0x22,0xf4,0x12,0x00,0x0a,0xf4,0x11,0x00,0xf2,0xf3,0x11,0x00,0xda,0xf3,0x10,0x00,0xc2,0xf3,  \
    0x0f,0x00,0xaa,0xf3,0x0f,0x00,0x92,0xf3,0x0e,0x00,0x7a,0xf3,0x0e,0x00,0x61,0xf3,0x0d,0x00,0x49,0xf3,0x0d,0x00,0x30,0xf3,0x0c,0x00,0x17,0xf3,0x0b,0x00,0xfe,0xf2,0x0b,0x00,0xe5,0xf2,0x0a,0x00,0xcc,0xf2,0x0a,0x00,0xb2,0xf2,0x09,0x00,0x99,0xf2,0x09,0x00,0x7f,0xf2,0x08,0x00,0x66,0xf2,0x08,0x00,0x4c,0xf2,0x07,0x00,0x32,0xf2,0x07,0x00,0x18,0xf2,0x06,0x00,0xfd,0xf1,0x06,0x00,0xe3,0xf1,0x06,0x00,0xc9,0xf1,0x05,0x00,0xae,0xf1,0x05,0x00,0x93,0xf1,0x04,0x00,  \
    0x78,0xf1,0x04,0x00,0x5d,0xf1,0x03,0x00,0x42,0xf1,0x03,0x00,0x27,0xf1,0x03,0x00,0x0c,0xf1,0x02,0x00,0xf0,0xf0,0x02,0x00,0xd5,0xf0,0x02,0x00,0xb9,0xf0,0x01,0x00,0x9d,0xf0,0x01,0x00,0x81,0xf0,0x00,0x00,0x65,0xf0,0x00,0x00,0x49,0xf0,0x00,0x00,0x2c,0xf0,0x00,0x00,0x10,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf1,0xff,0x01,0x10,0xf2,0xff,0xe5,0x0f,0xf2,0xff,0xc8,0x0f,0xf2,0xff,0xac,0x0f,0xf3,0xff,0x8f,0x0f,0xf3,0xff,0x73,0x0f,0xf3,0xff,0x57,0x0f,0xf4,0xff,0x3b,0x0f,0xf4,0xff,0x1f,0x0f,0xf5,0xff,0x03,0x0f,0xf5,0xff,0xe8,0x0e,0xf6,0xff,0xcc,0x0e,0xf6,0xff,0xb1,0x0e,0xf6,0xff,0x96,0x0e,0xf7,0xff,0x7a,0x0e,0xf7,0xff,0x5f,0x0e,0xf8,0xff,  \
    0x45,0x0e,0xf8,0xff,0x2a,0x0e,0xf9,0xff,0x0f,0x0e,0xf9,0xff,0xf5,0x0d,0xfa,0xff,0xda,0x0d,0xfb,0xff,0xc0,0x0d,0xfb,0xff,0xa6,0x0d,0xfc,0xff,0x8b,0x0d,0xfc,0xff,0x72,0x0d,0xfd,0xff,0x58,0x0d,0xfd,0xff,0x3e,0x0d,0xfe,0xff,0x24,0x0d,0xff,0xff,0x0b,0x0d,0xff,0xff,0xf2,0x0c,0x00,0x00,0xd8,0x0c,0x00,0x00,0xbf,0x0c,0x01,0x00,0xa6,0x0c,0x02,0x00,0x8d,0x0c,0x02,0x00,0x74,0x0c,0x03,0x00,0x5c,0x0c,0x04,0x00,0x43,0x0c,0x04,0x00,0x2b,0x0c,0x05,0x00,0x12,0x0c,  \
    0x06,0x00,0xfa,0x0b,0x06,0x00,0xe2,0x0b,0x07,0x00,0xca,0x0b,0x08,0x00,0xb2,0x0b,0x08,0x00,0x9b,0x0b,0x09,0x00,0x83,0x0b,0x0a,0x00,0x6b,0x0b,0x0b,0x00,0x54,0x0b,0x0b,0x00,0x3d,0x0b,0x0c,0x00,0x26,0x0b,0x0d,0x00,0x0f,0x0b,0x0d,0x00,0xf8,0x0a,0x0e,0x00,0xe1,0x0a,0x0f,0x00,0xca,0x0a,0x10,0x00,0xb4,0x0a,0x10,0x00,0x9d,0x0a,0x11,0x00,0x87,0x0a,0x12,0x00,0x70,0x0a,0x13,0x00,0x5a,0x0a,0x13,0x00,0x44,0x0a,0x14,0x00,0x2e,0x0a,0x15,0x00,0x18,0x0a,0x16,0x00,  \
    0x03,0x0a,0x17,0x00,0xed,0x09,0x17,0x00,0xd8,0x09,0x18,0x00,0xc2,0x09,0x19,0x00,0xad,0x09,0x1a,0x00,0x98,0x09,0x1b,0x00,0x83,0x09,0x1b,0x00,0x6e,0x09,0x1c,0x00,0x59,0x09,0x1d,0x00,0x44,0x09,0x1e,0x00,0x2f,0x09,0x1e,0x00,0x1b,0x09,0x1f,0x00,0x06,0x09,0x20,0x00,0xf2,0x08,0x21,0x00,0xde,0x08,0x22,0x00,0xca,0x08,0x23,0x00,0xb6,0x08,0x23,0x00,0xa2,0x08,0x24,0x00,0x8e,0x08,0x25,0x00,0x7a,0x08,0x26,0x00,0x67,0x08,0x27,0x00,0x53,0x08,0x27,0x00,0x40,0x08,  \
    0x28,0x00,0x2c,0x08,0x29,0x00,0x19,0x08,0x2a,0x00,0x06,0x08,0x2b,0x00,0xf3,0x07,0x2b,0x00,0xe0,0x07,0x2c,0x00,0xcd,0x07,0x2d,0x00,0xba,0x07,0x2e,0x00,0xa8,0x07,0x2f,0x00,0x95,0x07,0x2f,0x00,0x83,0x07,0x30,0x00,0x71,0x07,0x31,0x00,0x5e,0x07,0x32,0x00,0x4c,0x07,0x33,0x00,0x3a,0x07,0x33,0x00,0x28,0x07,0x34,0x00,0x16,0x07,0x35,0x00,0x05,0x07,0x36,0x00,0xf3,0x06,0x37,0x00,0xe1,0x06,0x37,0x00,0xd0,0x06,0x38,0x00,0xbf,0x06,0x39,0x00,0xad,0x06,0x3a,0x00,  \
    0x9c,0x06,0x3b,0x00,0x8b,0x06,0x3b,0x00,0x7a,0x06,0x3c,0x00,0x69,0x06,0x3d,0x00,0x58,0x06,0x3e,0x00,0x47,0x06,0x3f,0x00,0x37,0x06,0x3f,0x00,0x26,0x06,0x40,0x00,0x16,0x06,0x41,0x00,0x05,0x06,0x42,0x00,0xf5,0x05,0x42,0x00,0xe5,0x05,0x43,0x00,0xd4,0x05,0x44,0x00,0xc4,0x05,0x45,0x00,0xb4,0x05,0x45,0x00,0xa4,0x05,0x46,0x00,0x95,0x05,0x47,0x00,0x85,0x05,0x48,0x00,0x75,0x05,0x48,0x00,0x66,0x05,0x49,0x00,0x56,0x05,0x4a,0x00,0x47,0x05,0x4a,0x00,0x37,0x05,  \
    0x4b,0x00,0x28,0x05,0x4c,0x00,0x19,0x05,0x4d,0x00,0x0a,0x05,0x4d,0x00,0xfb,0x04,0x4e,0x00,0xec,0x04,0x4f,0x00,0xdd,0x04,0x4f,0x00,0xce,0x04,0x50,0x00,0xbf,0x04,0x51,0x00,0xb1,0x04,0x51,0x00,0xa2,0x04,0x52,0x00,0x93,0x04,0x53,0x00,0x85,0x04,0x53,0x00,0x77,0x04,0x54,0x00,0x68,0x04,0x55,0x00,0x5a,0x04,0x55,0x00,0x4c,0x04,0x56,0x00,0x3e,0x04,0x57,0x00,0x30,0x04,0x57,0x00,0x22,0x04,0x58,0x00,0x14,0x04,0x59,0x00,0x06,0x04,0x59,0x00,0xf8,0x03,0x5a,0x00,  \
    0xea,0x03,0x5a,0x00,0xdd,0x03,0x5b,0x00,0xcf,0x03,0x5c,0x00,0xc2,0x03,0x5c,0x00,0xb4,0x03,0x5d,0x00,0xa7,0x03,0x5d,0x00,0x99,0x03,0x5e,0x00,0x8c,0x03,0x5f,0x00,0x7f,0x03,0x5f,0x00,0x72,0x03,0x60,0x00,0x65,0x03,0x60,0x00,0x58,0x03,0x61,0x00,0x4b,0x03,0x61,0x00,0x3e,0x03,0x62,0x00,0x31,0x03,0x62,0x00,0x24,0x03,0x63,0x00,0x17,0x03,0x63,0x00,0x0b,0x03,0x64,0x00,0xfe,0x02,0x65,0x00,0xf1,0x02,0x65,0x00,0xe5,0x02,0x66,0x00,0xd8,0x02,0x66,0x00,0xcc,0x02,  \
    0x66,0x00,0xc0,0x02,0x67,0x00,0xb3,0x02,0x67,0x00,0xa7,0x02,0x68,0x00,0x9b,0x02,0x68,0x00,0x8f,0x02,0x69,0x00,0x82,0x02,0x69,0x00,0x76,0x02,0x6a,0x00,0x6a,0x02,0x6a,0x00,0x5e,0x02,0x6b,0x00,0x52,0x02,0x6b,0x00,0x46,0x02,0x6b,0x00,0x3a,0x02,0x6c,0x00,0x2f,0x02,0x6c,0x00,0x23,0x02,0x6d,0x00,0x17,0x02,0x6d,0x00,0x0b,0x02,0x6d,0x00,0x00,0x02,0x6e,0x00,0xf4,0x01,0x6e,0x00,0xe9,0x01,0x6e,0x00,0xdd,0x01,0x6f,0x00,0xd1,0x01,0x6f,0x00,0xc6,0x01,0x70,0x00,  \
    0xba,0x01,0x70,0x00,0xaf,0x01,0x70,0x00,0xa4,0x01,0x70,0x00,0x98,0x01,0x71,0x00,0x8d,0x01,0x71,0x00,0x82,0x01,0x71,0x00,0x76,0x01,0x72,0x00,0x6b,0x01,0x72,0x00,0x60,0x01,0x72,0x00,0x55,0x01,0x73,0x00,0x4a,0x01,0x73,0x00,0x3f,0x01,0x73,0x00,0x34,0x01,0x73,0x00,0x28,0x01,0x74,0x00,0x1d,0x01,0x74,0x00,0x12,0x01,0x74,0x00,0x07,0x01,0x74,0x00,0xfc,0x00,0x74,0x00,0xf2,0x00,0x75,0x00,0xe7,0x00,0x75,0x00,0xdc,0x00,0x75,0x00,0xd1,0x00,0x75,0x00,0xc6,0x00,  \
    0x75,0x00,0xbb,0x00,0x76,0x00,0xb0,0x00,0x76,0x00,0xa6,0x00,0x76,0x00,0x9b,0x00,0x76,0x00,0x90,0x00,0x76,0x00,0x85,0x00,0x76,0x00,0x7a,0x00,0x76,0x00,0x70,0x00,0x77,0x00,0x65,0x00,0x77,0x00,0x5a,0x00,0x77,0x00,0x50,0x00,0x77,0x00,0x45,0x00,0x77,0x00,0x3a,0x00,0x77,0x00,0x30,0x00,0x77,0x00,0x25,0x00,0x77,0x00,0x1a,0x00,0x77,0x00,0x10,0x00,0x77,0x00,0x05,0x00,0x77,0x00,0xfa,0xff,0x77,0x00,0xf0,0xff,0x77,0x00,0xe5,0xff,0x77,0x00,0xdb,0xff,0x77,0x00,  \
    0xd0,0xff,0x77,0x00,0xc5,0xff,0x77,0x00,0xbb,0xff,0x77,0x00,0xb0,0xff,0x77,0x00,0xa5,0xff,0x77,0x00,0x9b,0xff,0x77,0x00,0x90,0xff,0x77,0x00,0x86,0xff,0x77,0x00,0x7b,0xff,0x77,0x00,0x70,0xff,0x77,0x00,0x66,0xff,0x77,0x00,0x5b,0xff,0x77,0x00,0x50,0xff,0x77,0x00,0x46,0xff,0x77,0x00,0x3b,0xff,0x77,0x00,0x31,0xff,0x77,0x00,0x26,0xff,0x77,0x00,0x1b,0xff,0x76,0x00,0x10,0xff,0x76,0x00,0x06,0xff,0x76,0x00,0xfb,0xfe,0x76,0x00,0xf0,0xfe,0x76,0x00,0xe6,0xfe,  \
    0x76,0x00,0xdb,0xfe,0x76,0x00,0xd0,0xfe,0x75,0x00,0xc5,0xfe,0x75,0x00,0xba,0xfe,0x75,0x00,0xb0,0xfe,0x75,0x00,0xa5,0xfe,0x75,0x00,0x9a,0xfe,0x74,0x00,0x8f,0xfe,0x74,0x00,0x84,0xfe,0x74,0x00,0x79,0xfe,0x74,0x00,0x6e,0xfe,0x74,0x00,0x63,0xfe,0x73,0x00,0x58,0xfe,0x73,0x00,0x4d,0xfe,0x73,0x00,0x42,0xfe,0x72,0x00,0x37,0xfe,0x72,0x00,0x2c,0xfe,0x72,0x00,0x21,0xfe,0x72,0x00,0x16,0xfe,0x71,0x00,0x0b,0xfe,0x71,0x00,0x00,0xfe,0x71,0x00,0xf5,0xfd,0x70,0x00,  \
    0xe9,0xfd,0x70,0x00,0xde,0xfd,0x70,0x00,0xd3,0xfd,0x6f,0x00,0xc7,0xfd,0x6f,0x00,0xbc,0xfd,0x6f,0x00,0xb1,0xfd,0x6e,0x00,0xa5,0xfd,0x6e,0x00,0x9a,0xfd,0x6e,0x00,0x8e,0xfd,0x6d,0x00,0x83,0xfd,0x6d,0x00,0x77,0xfd,0x6d,0x00,0x6c,0xfd,0x6c,0x00,0x60,0xfd,0x6c,0x00,0x54,0xfd,0x6b,0x00,0x49,0xfd,0x6b,0x00,0x3d,0xfd,0x6b,0x00,0x31,0xfd,0x6a,0x00,0x25,0xfd,0x6a,0x00,0x19,0xfd,0x69,0x00,0x0d,0xfd,0x69,0x00,0x01,0xfd,0x68,0x00,0xf5,0xfc,0x68,0x00,0xe9,0xfc,  \
    0x67,0x00,0xdd,0xfc,0x67,0x00,0xd1,0xfc,0x66,0x00,0xc4,0xfc,0x66,0x00,0xb8,0xfc,0x65,0x00,0xac,0xfc,0x65,0x00,0x9f,0xfc,0x64,0x00,0x93,0xfc,0x64,0x00,0x87,0xfc,0x63,0x00,0x7a,0xfc,0x63,0x00,0x6d,0xfc,0x62,0x00,0x61,0xfc,0x62,0x00,0x54,0xfc,0x61,0x00,0x47,0xfc,0x61,0x00,0x3a,0xfc,0x60,0x00,0x2e,0xfc,0x60,0x00,0x21,0xfc,0x5f,0x00,0x14,0xfc,0x5f,0x00,0x07,0xfc,0x5e,0x00,0xfa,0xfb,0x5d,0x00,0xec,0xfb,0x5d,0x00,0xdf,0xfb,0x5c,0x00,0xd2,0xfb,0x5c,0x00,  \
    0xc5,0xfb,0x5b,0x00,0xb7,0xfb,0x5a,0x00,0xaa,0xfb,0x5a,0x00,0x9c,0xfb,0x59,0x00,0x8f,0xfb,0x59,0x00,0x81,0xfb,0x58,0x00,0x73,0xfb,0x57,0x00,0x66,0xfb,0x57,0x00,0x58,0xfb,0x56,0x00,0x4a,0xfb,0x55,0x00,0x3c,0xfb,0x55,0x00,0x2e,0xfb,0x54,0x00,0x20,0xfb,0x53,0x00,0x11,0xfb,0x53,0x00,0x03,0xfb,0x52,0x00,0xf5,0xfa,0x51,0x00,0xe7,0xfa,0x51,0x00,0xd8,0xfa,0x50,0x00,0xc9,0xfa,0x4f,0x00,0xbb,0xfa,0x4f,0x00,0xac,0xfa,0x4e,0x00,0x9d,0xfa,0x4d,0x00,0x8f,0xfa,  \
    0x4d,0x00,0x80,0xfa,0x4c,0x00,0x71,0xfa,0x4b,0x00,0x62,0xfa,0x4a,0x00,0x52,0xfa,0x4a,0x00,0x43,0xfa,0x49,0x00,0x34,0xfa,0x48,0x00,0x24,0xfa,0x47,0x00,0x15,0xfa,0x47,0x00,0x05,0xfa,0x46,0x00,0xf6,0xf9,0x45,0x00,0xe6,0xf9,0x44,0x00,0xd6,0xf9,0x44,0x00,0xc6,0xf9,0x43,0x00,0xb6,0xf9,0x42,0x00,0xa6,0xf9,0x41,0x00,0x96,0xf9,0x41,0x00,0x86,0xf9,0x40,0x00,0x76,0xf9,0x3f,0x00,0x65,0xf9,0x3e,0x00,0x55,0xf9,0x3e,0x00,0x44,0xf9,0x3d,0x00,0x34,0xf9,0x3c,0x00,  \
    0x23,0xf9,0x3b,0x00,0x12,0xf9,0x3b,0x00,0x01,0xf9,0x3a,0x00,0xf0,0xf8,0x39,0x00,0xdf,0xf8,0x38,0x00,0xce,0xf8,0x37,0x00,0xbc,0xf8,0x37,0x00,0xab,0xf8,0x36,0x00,0x9a,0xf8,0x35,0x00,0x88,0xf8,0x34,0x00,0x76,0xf8,0x33,0x00,0x65,0xf8,0x33,0x00,0x53,0xf8,0x32,0x00,0x41,0xf8,0x31,0x00,0x2f,0xf8,0x30,0x00,0x1c,0xf8,0x2f,0x00,0x0a,0xf8,0x2f,0x00,0xf8,0xf7,0x2e,0x00,0xe5,0xf7,0x2d,0x00,0xd3,0xf7,0x2c,0x00,0xc0,0xf7,0x2b,0x00,0xad,0xf7,0x2b,0x00,0x9b,0xf7,  \
    0x2a,0x00,0x88,0xf7,0x29,0x00,0x75,0xf7,0x28,0x00,0x61,0xf7,0x27,0x00,0x4e,0xf7,0x26,0x00,0x3b,0xf7,0x26,0x00,0x27,0xf7,0x25,0x00,0x14,0xf7,0x24,0x00,0x00,0xf7,0x23,0x00,0xec,0xf6,0x22,0x00,0xd8,0xf6,0x22,0x00,0xc4,0xf6,0x21,0x00,0xb0,0xf6,0x20,0x00,0x9c,0xf6,0x1f,0x00,0x88,0xf6,0x1e,0x00,0x73,0xf6,0x1e,0x00,0x5f,0xf6,0x1d,0x00,0x4a,0xf6,0x1c,0x00,0x35,0xf6,0x1b,0x00,0x20,0xf6,0x1a,0x00,0x0b,0xf6,0x1a,0x00,0xf6,0xf5,0x19,0x00,0xe1,0xf5,0x18,0x00,  \
    0xcc,0xf5,0x17,0x00,0xb6,0xf5,0x17,0x00,0xa1,0xf5,0x16,0x00,0x8b,0xf5,0x15,0x00,0x75,0xf5,0x14,0x00,0x5f,0xf5,0x13,0x00,0x49,0xf5,0x13,0x00,0x33,0xf5,0x12,0x00,0x1d,0xf5,0x11,0x00,0x07,0xf5,0x10,0x00,0xf0,0xf4,0x10,0x00,0xda,0xf4,0x0f,0x00,0xc3,0xf4,0x0e,0x00,0xac,0xf4,0x0e,0x00,0x95,0xf4,0x0d,0x00,0x7e,0xf4,0x0c,0x00,0x67,0xf4,0x0b,0x00,0x50,0xf4,0x0b,0x00,0x38,0xf4,0x0a,0x00,0x21,0xf4,0x09,0x00,0x09,0xf4,0x09,0x00,0xf2,0xf3,0x08,0x00,0xda,0xf3,  \
    0x07,0x00,0xc2,0xf3,0x07,0x00,0xaa,0xf3,0x06,0x00,0x91,0xf3,0x05,0x00,0x79,0xf3,0x05,0x00,0x60,0xf3,0x04,0x00,0x48,0xf3,0x03,0x00,0x2f,0xf3,0x03,0x00,0x16,0xf3,0x02,0x00,0xfd,0xf2,0x01,0x00,0xe4,0xf2,0x01,0x00,0xcb,0xf2,0x00,0x00,0xb2,0xf2,0x00,0x00,0x98,0xf2,0xff,0xff,0x7f,0xf2,0xff,0xff,0x65,0xf2,0xfe,0xff,0x4b,0xf2,0xfd,0xff,0x31,0xf2,0xfd,0xff,0x17,0xf2,0xfc,0xff,0xfd,0xf1,0xfc,0xff,0xe2,0xf1,0xfb,0xff,0xc8,0xf1,0xfb,0xff,0xad,0xf1,0xfa,0xff,  \
    0x93,0xf1,0xfa,0xff,0x78,0xf1,0xf9,0xff,0x5d,0xf1,0xf9,0xff,0x42,0xf1,0xf8,0xff,0x26,0xf1,0xf8,0xff,0x0b,0xf1,0xf8,0xff,0xef,0xf0,0xf7,0xff,0xd4,0xf0,0xf7,0xff,0xb8,0xf0,0xf6,0xff,0x9c,0xf0,0xf6,0xff,0x80,0xf0,0xf5,0xff,0x64,0xf0,0xf5,0xff,0x48,0xf0,0xf5,0xff,0x2b,0xf0,0xf4,0xff,0x0f,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe5,0xff,0x02,0x10,0xe5,0xff,0xe5,0x0f,0xe6,0xff,0xc9,0x0f,0xe6,0xff,0xac,0x0f,0xe7,0xff,0x90,0x0f,0xe7,0xff,0x74,0x0f,0xe7,0xff,0x58,0x0f,0xe8,0xff,0x3c,0x0f,0xe8,0xff,0x20,0x0f,0xe9,0xff,0x04,0x0f,0xe9,0xff,0xe8,0x0e,0xea,0xff,0xcd,0x0e,0xea,0xff,0xb2,0x0e,0xeb,0xff,0x96,0x0e,0xeb,0xff,0x7b,0x0e,0xec,0xff,  \
    0x60,0x0e,0xed,0xff,0x45,0x0e,0xed,0xff,0x2b,0x0e,0xee,0xff,0x10,0x0e,0xee,0xff,0xf5,0x0d,0xef,0xff,0xdb,0x0d,0xf0,0xff,0xc1,0x0d,0xf0,0xff,0xa6,0x0d,0xf1,0xff,0x8c,0x0d,0xf1,0xff,0x72,0x0d,0xf2,0xff,0x59,0x0d,0xf3,0xff,0x3f,0x0d,0xf3,0xff,0x25,0x0d,0xf4,0xff,0x0c,0x0d,0xf5,0xff,0xf2,0x0c,0xf6,0xff,0xd9,0x0c,0xf6,0xff,0xc0,0x0c,0xf7,0xff,0xa7,0x0c,0xf8,0xff,0x8e,0x0c,0xf8,0xff,0x75,0x0c,0xf9,0xff,0x5d,0x0c,0xfa,0xff,0x44,0x0c,0xfb,0xff,0x2c,0x0c,  \
    0xfb,0xff,0x13,0x0c,0xfc,0xff,0xfb,0x0b,0xfd,0xff,0xe3,0x0b,0xfe,0xff,0xcb,0x0b,0xfe,0xff,0xb3,0x0b,0xff,0xff,0x9c,0x0b,0x00,0x00,0x84,0x0b,0x01,0x00,0x6c,0x0b,0x02,0x00,0x55,0x0b,0x03,0x00,0x3e,0x0b,0x03,0x00,0x27,0x0b,0x04,0x00,0x10,0x0b,0x05,0x00,0xf9,0x0a,0x06,0x00,0xe2,0x0a,0x07,0x00,0xcb,0x0a,0x08,0x00,0xb5,0x0a,0x08,0x00,0x9e,0x0a,0x09,0x00,0x88,0x0a,0x0a,0x00,0x71,0x0a,0x0b,0x00,0x5b,0x0a,0x0c,0x00,0x45,0x0a,0x0d,0x00,0x2f,0x0a,0x0e,0x00,  \
    0x19,0x0a,0x0e,0x00,0x04,0x0a,0x0f,0x00,0xee,0x09,0x10,0x00,0xd9,0x09,0x11,0x00,0xc3,0x09,0x12,0x00,0xae,0x09,0x13,0x00,0x99,0x09,0x14,0x00,0x84,0x09,0x15,0x00,0x6f,0x09,0x16,0x00,0x5a,0x09,0x17,0x00,0x45,0x09,0x17,0x00,0x30,0x09,0x18,0x00,0x1c,0x09,0x19,0x00,0x07,0x09,0x1a,0x00,0xf3,0x08,0x1b,0x00,0xdf,0x08,0x1c,0x00,0xcb,0x08,0x1d,0x00,0xb7,0x08,0x1e,0x00,0xa3,0x08,0x1f,0x00,0x8f,0x08,0x20,0x00,0x7b,0x08,0x21,0x00,0x68,0x08,0x21,0x00,0x54,0x08,  \
    0x22,0x00,0x41,0x08,0x23,0x00,0x2d,0x08,0x24,0x00,0x1a,0x08,0x25,0x00,0x07,0x08,0x26,0x00,0xf4,0x07,0x27,0x00,0xe1,0x07,0x28,0x00,0xce,0x07,0x29,0x00,0xbc,0x07,0x2a,0x00,0xa9,0x07,0x2b,0x00,0x96,0x07,0x2b,0x00,0x84,0x07,0x2c,0x00,0x72,0x07,0x2d,0x00,0x5f,0x07,0x2e,0x00,0x4d,0x07,0x2f,0x00,0x3b,0x07,0x30,0x00,0x29,0x07,0x31,0x00,0x18,0x07,0x32,0x00,0x06,0x07,0x33,0x00,0xf4,0x06,0x34,0x00,0xe3,0x06,0x35,0x00,0xd1,0x06,0x35,0x00,0xc0,0x06,0x36,0x00,  \
    0xae,0x06,0x37,0x00,0x9d,0x06,0x38,0x00,0x8c,0x06,0x39,0x00,0x7b,0x06,0x3a,0x00,0x6a,0x06,0x3b,0x00,0x59,0x06,0x3c,0x00,0x48,0x06,0x3c,0x00,0x38,0x06,0x3d,0x00,0x27,0x06,0x3e,0x00,0x17,0x06,0x3f,0x00,0x06,0x06,0x40,0x00,0xf6,0x05,0x41,0x00,0xe6,0x05,0x42,0x00,0xd6,0x05,0x42,0x00,0xc5,0x05,0x43,0x00,0xb5,0x05,0x44,0x00,0xa6,0x05,0x45,0x00,0x96,0x05,0x46,0x00,0x86,0x05,0x47,0x00,0x76,0x05,0x48,0x00,0x67,0x05,0x48,0x00,0x57,0x05,0x49,0x00,0x48,0x05,  \
    0x4a,0x00,0x38,0x05,0x4b,0x00,0x29,0x05,0x4c,0x00,0x1a,0x05,0x4c,0x00,0x0b,0x05,0x4d,0x00,0xfc,0x04,0x4e,0x00,0xed,0x04,0x4f,0x00,0xde,0x04,0x50,0x00,0xcf,0x04,0x50,0x00,0xc0,0x04,0x51,0x00,0xb2,0x04,0x52,0x00,0xa3,0x04,0x53,0x00,0x95,0x04,0x53,0x00,0x86,0x04,0x54,0x00,0x78,0x04,0x55,0x00,0x69,0x04,0x56,0x00,0x5b,0x04,0x56,0x00,0x4d,0x04,0x57,0x00,0x3f,0x04,0x58,0x00,0x31,0x04,0x58,0x00,0x23,0x04,0x59,0x00,0x15,0x04,0x5a,0x00,0x07,0x04,0x5b,0x00,  \
    0xf9,0x03,0x5b,0x00,0xeb,0x03,0x5c,0x00,0xde,0x03,0x5d,0x00,0xd0,0x03,0x5d,0x00,0xc3,0x03,0x5e,0x00,0xb5,0x03,0x5f,0x00,0xa8,0x03,0x5f,0x00,0x9a,0x03,0x60,0x00,0x8d,0x03,0x61,0x00,0x80,0x03,0x61,0x00,0x73,0x03,0x62,0x00,0x66,0x03,0x63,0x00,0x59,0x03,0x63,0x00,0x4c,0x03,0x64,0x00,0x3f,0x03,0x64,0x00,0x32,0x03,0x65,0x00,0x25,0x03,0x66,0x00,0x18,0x03,0x66,0x00,0x0c,0x03,0x67,0x00,0xff,0x02,0x67,0x00,0xf2,0x02,0x68,0x00,0xe6,0x02,0x68,0x00,0xd9,0x02,  \
    0x69,0x00,0xcd,0x02,0x6a,0x00,0xc0,0x02,0x6a,0x00,0xb4,0x02,0x6b,0x00,0xa8,0x02,0x6b,0x00,0x9c,0x02,0x6c,0x00,0x8f,0x02,0x6c,0x00,0x83,0x02,0x6d,0x00,0x77,0x02,0x6d,0x00,0x6b,0x02,0x6e,0x00,0x5f,0x02,0x6e,0x00,0x53,0x02,0x6f,0x00,0x47,0x02,0x6f,0x00,0x3b,0x02,0x70,0x00,0x2f,0x02,0x70,0x00,0x24,0x02,0x70,0x00,0x18,0x02,0x71,0x00,0x0c,0x02,0x71,0x00,0x00,0x02,0x72,0x00,0xf5,0x01,0x72,0x00,0xe9,0x01,0x73,0x00,0xde,0x01,0x73,0x00,0xd2,0x01,0x73,0x00,  \
    0xc7,0x01,0x74,0x00,0xbb,0x01,0x74,0x00,0xb0,0x01,0x74,0x00,0xa4,0x01,0x75,0x00,0x99,0x01,0x75,0x00,0x8e,0x01,0x76,0x00,0x82,0x01,0x76,0x00,0x77,0x01,0x76,0x00,0x6c,0x01,0x76,0x00,0x61,0x01,0x77,0x00,0x55,0x01,0x77,0x00,0x4a,0x01,0x77,0x00,0x3f,0x01,0x78,0x00,0x34,0x01,0x78,0x00,0x29,0x01,0x78,0x00,0x1e,0x01,0x79,0x00,0x13,0x01,0x79,0x00,0x08,0x01,0x79,0x00,0xfd,0x00,0x79,0x00,0xf2,0x00,0x79,0x00,0xe7,0x00,0x7a,0x00,0xdc,0x00,0x7a,0x00,0xd1,0x00,  \
    0x7a,0x00,0xc6,0x00,0x7a,0x00,0xbb,0x00,0x7b,0x00,0xb1,0x00,0x7b,0x00,0xa6,0x00,0x7b,0x00,0x9b,0x00,0x7b,0x00,0x90,0x00,0x7b,0x00,0x85,0x00,0x7b,0x00,0x7b,0x00,0x7b,0x00,0x70,0x00,0x7c,0x00,0x65,0x00,0x7c,0x00,0x5a,0x00,0x7c,0x00,0x50,0x00,0x7c,0x00,0x45,0x00,0x7c,0x00,0x3a,0x00,0x7c,0x00,0x30,0x00,0x7c,0x00,0x25,0x00,0x7c,0x00,0x1a,0x00,0x7c,0x00,0x10,0x00,0x7c,0x00,0x05,0x00,0x7c,0x00,0xfa,0xff,0x7d,0x00,0xf0,0xff,0x7d,0x00,0xe5,0xff,0x7d,0x00,  \
    0xdb,0xff,0x7d,0x00,0xd0,0xff,0x7d,0x00,0xc5,0xff,0x7d,0x00,0xbb,0xff,0x7d,0x00,0xb0,0xff,0x7d,0x00,0xa5,0xff,0x7d,0x00,0x9b,0xff,0x7d,0x00,0x90,0xff,0x7c,0x00,0x86,0xff,0x7c,0x00,0x7b,0xff,0x7c,0x00,0x70,0xff,0x7c,0x00,0x66,0xff,0x7c,0x00,0x5b,0xff,0x7c,0x00,0x50,0xff,0x7c,0x00,0x46,0xff,0x7c,0x00,0x3b,0xff,0x7c,0x00,0x30,0xff,0x7c,0x00,0x26,0xff,0x7c,0x00,0x1b,0xff,0x7b,0x00,0x10,0xff,0x7b,0x00,0x06,0xff,0x7b,0x00,0xfb,0xfe,0x7b,0x00,0xf0,0xfe,  \
    0x7b,0x00,0xe5,0xfe,0x7b,0x00,0xdb,0xfe,0x7a,0x00,0xd0,0xfe,0x7a,0x00,0xc5,0xfe,0x7a,0x00,0xba,0xfe,0x7a,0x00,0xaf,0xfe,0x7a,0x00,0xa4,0xfe,0x79,0x00,0x9a,0xfe,0x79,0x00,0x8f,0xfe,0x79,0x00,0x84,0xfe,0x79,0x00,0x79,0xfe,0x78,0x00,0x6e,0xfe,0x78,0x00,0x63,0xfe,0x78,0x00,0x58,0xfe,0x78,0x00,0x4d,0xfe,0x77,0x00,0x42,0xfe,0x77,0x00,0x37,0xfe,0x77,0x00,0x2c,0xfe,0x76,0x00,0x21,0xfe,0x76,0x00,0x16,0xfe,0x76,0x00,0x0a,0xfe,0x75,0x00,0xff,0xfd,0x75,0x00,  \
    0xf4,0xfd,0x75,0x00,0xe9,0xfd,0x74,0x00,0xde,0xfd,0x74,0x00,0xd2,0xfd,0x74,0x00,0xc7,0xfd,0x73,0x00,0xbc,0xfd,0x73,0x00,0xb0,0xfd,0x73,0x00,0xa5,0xfd,0x72,0x00,0x99,0xfd,0x72,0x00,0x8e,0xfd,0x71,0x00,0x82,0xfd,0x71,0x00,0x77,0xfd,0x70,0x00,0x6b,0xfd,0x70,0x00,0x5f,0xfd,0x70,0x00,0x54,0xfd,0x6f,0x00,0x48,0xfd,0x6f,0x00,0x3c,0xfd,0x6e,0x00,0x30,0xfd,0x6e,0x00,0x24,0xfd,0x6d,0x00,0x18,0xfd,0x6d,0x00,0x0c,0xfd,0x6c,0x00,0x00,0xfd,0x6c,0x00,0xf4,0xfc,  \
    0x6b,0x00,0xe8,0xfc,0x6b,0x00,0xdc,0xfc,0x6a,0x00,0xd0,0xfc,0x6a,0x00,0xc4,0xfc,0x69,0x00,0xb7,0xfc,0x68,0x00,0xab,0xfc,0x68,0x00,0x9f,0xfc,0x67,0x00,0x92,0xfc,0x67,0x00,0x86,0xfc,0x66,0x00,0x79,0xfc,0x66,0x00,0x6c,0xfc,0x65,0x00,0x60,0xfc,0x64,0x00,0x53,0xfc,0x64,0x00,0x46,0xfc,0x63,0x00,0x3a,0xfc,0x63,0x00,0x2d,0xfc,0x62,0x00,0x20,0xfc,0x61,0x00,0x13,0xfc,0x61,0x00,0x06,0xfc,0x60,0x00,0xf9,0xfb,0x5f,0x00,0xeb,0xfb,0x5f,0x00,0xde,0xfb,0x5e,0x00,  \
    0xd1,0xfb,0x5d,0x00,0xc4,0xfb,0x5d,0x00,0xb6,0xfb,0x5c,0x00,0xa9,0xfb,0x5b,0x00,0x9b,0xfb,0x5b,0x00,0x8e,0xfb,0x5a,0x00,0x80,0xfb,0x59,0x00,0x72,0xfb,0x59,0x00,0x65,0xfb,0x58,0x00,0x57,0xfb,0x57,0x00,0x49,0xfb,0x56,0x00,0x3b,0xfb,0x56,0x00,0x2d,0xfb,0x55,0x00,0x1f,0xfb,0x54,0x00,0x10,0xfb,0x53,0x00,0x02,0xfb,0x53,0x00,0xf4,0xfa,0x52,0x00,0xe5,0xfa,0x51,0x00,0xd7,0xfa,0x50,0x00,0xc8,0xfa,0x50,0x00,0xba,0xfa,0x4f,0x00,0xab,0xfa,0x4e,0x00,0x9c,0xfa,  \
    0x4d,0x00,0x8d,0xfa,0x4c,0x00,0x7e,0xfa,0x4c,0x00,0x6f,0xfa,0x4b,0x00,0x60,0xfa,0x4a,0x00,0x51,0xfa,0x49,0x00,0x42,0xfa,0x48,0x00,0x33,0xfa,0x48,0x00,0x23,0xfa,0x47,0x00,0x14,0xfa,0x46,0x00,0x04,0xfa,0x45,0x00,0xf5,0xf9,0x44,0x00,0xe5,0xf9,0x43,0x00,0xd5,0xf9,0x43,0x00,0xc5,0xf9,0x42,0x00,0xb5,0xf9,0x41,0x00,0xa5,0xf9,0x40,0x00,0x95,0xf9,0x3f,0x00,0x85,0xf9,0x3e,0x00,0x75,0xf9,0x3d,0x00,0x64,0xf9,0x3d,0x00,0x54,0xf9,0x3c,0x00,0x43,0xf9,0x3b,0x00,  \
    0x32,0xf9,0x3a,0x00,0x22,0xf9,0x39,0x00,0x11,0xf9,0x38,0x00,0x00,0xf9,0x37,0x00,0xef,0xf8,0x36,0x00,0xde,0xf8,0x35,0x00,0xcd,0xf8,0x35,0x00,0xbb,0xf8,0x34,0x00,0xaa,0xf8,0x33,0x00,0x98,0xf8,0x32,0x00,0x87,0xf8,0x31,0x00,0x75,0xf8,0x30,0x00,0x63,0xf8,0x2f,0x00,0x52,0xf8,0x2e,0x00,0x40,0xf8,0x2d,0x00,0x2e,0xf8,0x2c,0x00,0x1b,0xf8,0x2c,0x00,0x09,0xf8,0x2b,0x00,0xf7,0xf7,0x2a,0x00,0xe4,0xf7,0x29,0x00,0xd2,0xf7,0x28,0x00,0xbf,0xf7,0x27,0x00,0xac,0xf7,  \
    0x26,0x00,0x99,0xf7,0x25,0x00,0x87,0xf7,0x24,0x00,0x73,0xf7,0x23,0x00,0x60,0xf7,0x22,0x00,0x4d,0xf7,0x22,0x00,0x3a,0xf7,0x21,0x00,0x26,0xf7,0x20,0x00,0x13,0xf7,0x1f,0x00,0xff,0xf6,0x1e,0x00,0xeb,0xf6,0x1d,0x00,0xd7,0xf6,0x1c,0x00,0xc3,0xf6,0x1b,0x00,0xaf,0xf6,0x1a,0x00,0x9b,0xf6,0x19,0x00,0x87,0xf6,0x18,0x00,0x72,0xf6,0x18,0x00,0x5e,0xf6,0x17,0x00,0x49,0xf6,0x16,0x00,0x34,0xf6,0x15,0x00,0x1f,0xf6,0x14,0x00,0x0a,0xf6,0x13,0x00,0xf5,0xf5,0x12,0x00,  \
    0xe0,0xf5,0x11,0x00,0xcb,0xf5,0x10,0x00,0xb5,0xf5,0x10,0x00,0xa0,0xf5,0x0f,0x00,0x8a,0xf5,0x0e,0x00,0x74,0xf5,0x0d,0x00,0x5e,0xf5,0x0c,0x00,0x48,0xf5,0x0b,0x00,0x32,0xf5,0x0a,0x00,0x1c,0xf5,0x0a,0x00,0x06,0xf5,0x09,0x00,0xef,0xf4,0x08,0x00,0xd9,0xf4,0x07,0x00,0xc2,0xf4,0x06,0x00,0xab,0xf4,0x05,0x00,0x94,0xf4,0x05,0x00,0x7d,0xf4,0x04,0x00,0x66,0xf4,0x03,0x00,0x4f,0xf4,0x02,0x00,0x37,0xf4,0x01,0x00,0x20,0xf4,0x01,0x00,0x08,0xf4,0x00,0x00,0xf1,0xf3,  \
    0xff,0xff,0xd9,0xf3,0xfe,0xff,0xc1,0xf3,0xfe,0xff,0xa9,0xf3,0xfd,0xff,0x90,0xf3,0xfc,0xff,0x78,0xf3,0xfb,0xff,0x5f,0xf3,0xfb,0xff,0x47,0xf3,0xfa,0xff,0x2e,0xf3,0xf9,0xff,0x15,0xf3,0xf8,0xff,0xfc,0xf2,0xf8,0xff,0xe3,0xf2,0xf7,0xff,0xca,0xf2,0xf6,0xff,0xb1,0xf2,0xf6,0xff,0x97,0xf2,0xf5,0xff,0x7e,0xf2,0xf4,0xff,0x64,0xf2,0xf4,0xff,0x4a,0xf2,0xf3,0xff,0x30,0xf2,0xf3,0xff,0x16,0xf2,0xf2,0xff,0xfc,0xf1,0xf1,0xff,0xe1,0xf1,0xf1,0xff,0xc7,0xf1,0xf0,0xff,  \
    0xac,0xf1,0xf0,0xff,0x92,0xf1,0xef,0xff,0x77,0xf1,0xef,0xff,0x5c,0xf1,0xee,0xff,0x41,0xf1,0xee,0xff,0x25,0xf1,0xed,0xff,0x0a,0xf1,0xed,0xff,0xef,0xf0,0xec,0xff,0xd3,0xf0,0xec,0xff,0xb7,0xf0,0xeb,0xff,0x9b,0xf0,0xeb,0xff,0x7f,0xf0,0xea,0xff,0x63,0xf0,0xea,0xff,0x47,0xf0,0xe9,0xff,0x2b,0xf0,0xe9,0xff,0x0e,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xd8,0xff,0x03,0x10,0xd9,0xff,0xe6,0x0f,0xd9,0xff,0xca,0x0f,0xda,0xff,0xad,0x0f,0xda,0xff,0x91,0x0f,0xdb,0xff,0x75,0x0f,0xdb,0xff,0x58,0x0f,0xdc,0xff,0x3d,0x0f,0xdc,0xff,0x21,0x0f,0xdd,0xff,0x05,0x0f,0xdd,0xff,0xe9,0x0e,0xde,0xff,0xce,0x0e,0xdf,0xff,0xb2,0x0e,0xdf,0xff,0x97,0x0e,0xe0,0xff,  \
    0x7c,0x0e,0xe0,0xff,0x61,0x0e,0xe1,0xff,0x46,0x0e,0xe2,0xff,0x2b,0x0e,0xe2,0xff,0x11,0x0e,0xe3,0xff,0xf6,0x0d,0xe4,0xff,0xdc,0x0d,0xe4,0xff,0xc1,0x0d,0xe5,0xff,0xa7,0x0d,0xe6,0xff,0x8d,0x0d,0xe6,0xff,0x73,0x0d,0xe7,0xff,0x59,0x0d,0xe8,0xff,0x40,0x0d,0xe9,0xff,0x26,0x0d,0xe9,0xff,0x0d,0x0d,0xea,0xff,0xf3,0x0c,0xeb,0xff,0xda,0x0c,0xec,0xff,0xc1,0x0c,0xed,0xff,0xa8,0x0c,0xed,0xff,0x8f,0x0c,0xee,0xff,0x76,0x0c,0xef,0xff,0x5e,0x0c,0xf0,0xff,0x45,0x0c,  \
    0xf1,0xff,0x2d,0x0c,0xf2,0xff,0x14,0x0c,0xf2,0xff,0xfc,0x0b,0xf3,0xff,0xe4,0x0b,0xf4,0xff,0xcc,0x0b,0xf5,0xff,0xb4,0x0b,0xf6,0xff,0x9c,0x0b,0xf7,0xff,0x85,0x0b,0xf8,0xff,0x6d,0x0b,0xf9,0xff,0x56,0x0b,0xfa,0xff,0x3f,0x0b,0xfa,0xff,0x28,0x0b,0xfb,0xff,0x11,0x0b,0xfc,0xff,0xfa,0x0a,0xfd,0xff,0xe3,0x0a,0xfe,0xff,0xcc,0x0a,0xff,0xff,0xb6,0x0a,0x00,0x00,0x9f,0x0a,0x01,0x00,0x89,0x0a,0x02,0x00,0x73,0x0a,0x03,0x00,0x5c,0x0a,0x04,0x00,0x46,0x0a,0x05,0x00,  \
    0x30,0x0a,0x06,0x00,0x1b,0x0a,0x07,0x00,0x05,0x0a,0x08,0x00,0xef,0x09,0x09,0x00,0xda,0x09,0x0a,0x00,0xc4,0x09,0x0b,0x00,0xaf,0x09,0x0c,0x00,0x9a,0x09,0x0d,0x00,0x85,0x09,0x0e,0x00,0x70,0x09,0x0f,0x00,0x5b,0x09,0x10,0x00,0x46,0x09,0x11,0x00,0x32,0x09,0x12,0x00,0x1d,0x09,0x13,0x00,0x09,0x09,0x14,0x00,0xf4,0x08,0x15,0x00,0xe0,0x08,0x16,0x00,0xcc,0x08,0x17,0x00,0xb8,0x08,0x18,0x00,0xa4,0x08,0x19,0x00,0x90,0x08,0x1a,0x00,0x7c,0x08,0x1b,0x00,0x69,0x08,  \
    0x1c,0x00,0x55,0x08,0x1d,0x00,0x42,0x08,0x1e,0x00,0x2f,0x08,0x1f,0x00,0x1b,0x08,0x20,0x00,0x08,0x08,0x21,0x00,0xf5,0x07,0x22,0x00,0xe2,0x07,0x23,0x00,0xd0,0x07,0x24,0x00,0xbd,0x07,0x25,0x00,0xaa,0x07,0x26,0x00,0x98,0x07,0x27,0x00,0x85,0x07,0x28,0x00,0x73,0x07,0x29,0x00,0x61,0x07,0x2a,0x00,0x4f,0x07,0x2b,0x00,0x3d,0x07,0x2c,0x00,0x2b,0x07,0x2d,0x00,0x19,0x07,0x2e,0x00,0x07,0x07,0x2f,0x00,0xf5,0x06,0x30,0x00,0xe4,0x06,0x31,0x00,0xd2,0x06,0x32,0x00,  \
    0xc1,0x06,0x33,0x00,0xb0,0x06,0x34,0x00,0x9e,0x06,0x35,0x00,0x8d,0x06,0x36,0x00,0x7c,0x06,0x37,0x00,0x6b,0x06,0x38,0x00,0x5a,0x06,0x39,0x00,0x4a,0x06,0x3a,0x00,0x39,0x06,0x3b,0x00,0x28,0x06,0x3c,0x00,0x18,0x06,0x3d,0x00,0x08,0x06,0x3e,0x00,0xf7,0x05,0x3f,0x00,0xe7,0x05,0x40,0x00,0xd7,0x05,0x41,0x00,0xc7,0x05,0x42,0x00,0xb7,0x05,0x43,0x00,0xa7,0x05,0x44,0x00,0x97,0x05,0x45,0x00,0x87,0x05,0x46,0x00,0x78,0x05,0x47,0x00,0x68,0x05,0x48,0x00,0x58,0x05,  \
    0x48,0x00,0x49,0x05,0x49,0x00,0x3a,0x05,0x4a,0x00,0x2a,0x05,0x4b,0x00,0x1b,0x05,0x4c,0x00,0x0c,0x05,0x4d,0x00,0xfd,0x04,0x4e,0x00,0xee,0x04,0x4f,0x00,0xdf,0x04,0x50,0x00,0xd0,0x04,0x50,0x00,0xc2,0x04,0x51,0x00,0xb3,0x04,0x52,0x00,0xa4,0x04,0x53,0x00,0x96,0x04,0x54,0x00,0x87,0x04,0x55,0x00,0x79,0x04,0x55,0x00,0x6b,0x04,0x56,0x00,0x5c,0x04,0x57,0x00,0x4e,0x04,0x58,0x00,0x40,0x04,0x59,0x00,0x32,0x04,0x5a,0x00,0x24,0x04,0x5a,0x00,0x16,0x04,0x5b,0x00,  \
    0x08,0x04,0x5c,0x00,0xfa,0x03,0x5d,0x00,0xed,0x03,0x5d,0x00,0xdf,0x03,0x5e,0x00,0xd1,0x03,0x5f,0x00,0xc4,0x03,0x60,0x00,0xb6,0x03,0x60,0x00,0xa9,0x03,0x61,0x00,0x9c,0x03,0x62,0x00,0x8e,0x03,0x63,0x00,0x81,0x03,0x63,0x00,0x74,0x03,0x64,0x00,0x67,0x03,0x65,0x00,0x5a,0x03,0x65,0x00,0x4d,0x03,0x66,0x00,0x40,0x03,0x67,0x00,0x33,0x03,0x67,0x00,0x26,0x03,0x68,0x00,0x19,0x03,0x69,0x00,0x0d,0x03,0x69,0x00,0x00,0x03,0x6a,0x00,0xf3,0x02,0x6b,0x00,0xe7,0x02,  \
    0x6b,0x00,0xda,0x02,0x6c,0x00,0xce,0x02,0x6d,0x00,0xc1,0x02,0x6d,0x00,0xb5,0x02,0x6e,0x00,0xa9,0x02,0x6e,0x00,0x9c,0x02,0x6f,0x00,0x90,0x02,0x6f,0x00,0x84,0x02,0x70,0x00,0x78,0x02,0x71,0x00,0x6c,0x02,0x71,0x00,0x60,0x02,0x72,0x00,0x54,0x02,0x72,0x00,0x48,0x02,0x73,0x00,0x3c,0x02,0x73,0x00,0x30,0x02,0x74,0x00,0x24,0x02,0x74,0x00,0x19,0x02,0x75,0x00,0x0d,0x02,0x75,0x00,0x01,0x02,0x76,0x00,0xf6,0x01,0x76,0x00,0xea,0x01,0x77,0x00,0xde,0x01,0x77,0x00,  \
    0xd3,0x01,0x77,0x00,0xc7,0x01,0x78,0x00,0xbc,0x01,0x78,0x00,0xb0,0x01,0x79,0x00,0xa5,0x01,0x79,0x00,0x9a,0x01,0x79,0x00,0x8e,0x01,0x7a,0x00,0x83,0x01,0x7a,0x00,0x78,0x01,0x7b,0x00,0x6c,0x01,0x7b,0x00,0x61,0x01,0x7b,0x00,0x56,0x01,0x7c,0x00,0x4b,0x01,0x7c,0x00,0x40,0x01,0x7c,0x00,0x35,0x01,0x7d,0x00,0x29,0x01,0x7d,0x00,0x1e,0x01,0x7d,0x00,0x13,0x01,0x7d,0x00,0x08,0x01,0x7e,0x00,0xfd,0x00,0x7e,0x00,0xf2,0x00,0x7e,0x00,0xe7,0x00,0x7f,0x00,0xdc,0x00,  \
    0x7f,0x00,0xd2,0x00,0x7f,0x00,0xc7,0x00,0x7f,0x00,0xbc,0x00,0x7f,0x00,0xb1,0x00,0x80,0x00,0xa6,0x00,0x80,0x00,0x9b,0x00,0x80,0x00,0x91,0x00,0x80,0x00,0x86,0x00,0x80,0x00,0x7b,0x00,0x81,0x00,0x70,0x00,0x81,0x00,0x65,0x00,0x81,0x00,0x5b,0x00,0x81,0x00,0x50,0x00,0x81,0x00,0x45,0x00,0x81,0x00,0x3b,0x00,0x81,0x00,0x30,0x00,0x81,0x00,0x25,0x00,0x81,0x00,0x1b,0x00,0x82,0x00,0x10,0x00,0x82,0x00,0x05,0x00,0x82,0x00,0xfb,0xff,0x82,0x00,0xf0,0xff,0x82,0x00,  \
    0xe5,0xff,0x82,0x00,0xdb,0xff,0x82,0x00,0xd0,0xff,0x82,0x00,0xc5,0xff,0x82,0x00,0xbb,0xff,0x82,0x00,0xb0,0xff,0x82,0x00,0xa5,0xff,0x82,0x00,0x9b,0xff,0x82,0x00,0x90,0xff,0x82,0x00,0x85,0xff,0x82,0x00,0x7b,0xff,0x81,0x00,0x70,0xff,0x81,0x00,0x65,0xff,0x81,0x00,0x5b,0xff,0x81,0x00,0x50,0xff,0x81,0x00,0x45,0xff,0x81,0x00,0x3b,0xff,0x81,0x00,0x30,0xff,0x81,0x00,0x25,0xff,0x81,0x00,0x1b,0xff,0x80,0x00,0x10,0xff,0x80,0x00,0x05,0xff,0x80,0x00,0xfa,0xfe,  \
    0x80,0x00,0xf0,0xfe,0x80,0x00,0xe5,0xfe,0x80,0x00,0xda,0xfe,0x7f,0x00,0xcf,0xfe,0x7f,0x00,0xc5,0xfe,0x7f,0x00,0xba,0xfe,0x7f,0x00,0xaf,0xfe,0x7f,0x00,0xa4,0xfe,0x7e,0x00,0x99,0xfe,0x7e,0x00,0x8e,0xfe,0x7e,0x00,0x83,0xfe,0x7d,0x00,0x78,0xfe,0x7d,0x00,0x6d,0xfe,0x7d,0x00,0x62,0xfe,0x7d,0x00,0x57,0xfe,0x7c,0x00,0x4c,0xfe,0x7c,0x00,0x41,0xfe,0x7c,0x00,0x36,0xfe,0x7b,0x00,0x2b,0xfe,0x7b,0x00,0x20,0xfe,0x7b,0x00,0x15,0xfe,0x7a,0x00,0x0a,0xfe,0x7a,0x00,  \
    0xff,0xfd,0x79,0x00,0xf3,0xfd,0x79,0x00,0xe8,0xfd,0x79,0x00,0xdd,0xfd,0x78,0x00,0xd2,0xfd,0x78,0x00,0xc6,0xfd,0x77,0x00,0xbb,0xfd,0x77,0x00,0xaf,0xfd,0x77,0x00,0xa4,0xfd,0x76,0x00,0x98,0xfd,0x76,0x00,0x8d,0xfd,0x75,0x00,0x81,0xfd,0x75,0x00,0x76,0xfd,0x74,0x00,0x6a,0xfd,0x74,0x00,0x5f,0xfd,0x73,0x00,0x53,0xfd,0x73,0x00,0x47,0xfd,0x72,0x00,0x3b,0xfd,0x72,0x00,0x2f,0xfd,0x71,0x00,0x23,0xfd,0x71,0x00,0x18,0xfd,0x70,0x00,0x0c,0xfd,0x6f,0x00,0xff,0xfc,  \
    0x6f,0x00,0xf3,0xfc,0x6e,0x00,0xe7,0xfc,0x6e,0x00,0xdb,0xfc,0x6d,0x00,0xcf,0xfc,0x6d,0x00,0xc3,0xfc,0x6c,0x00,0xb6,0xfc,0x6b,0x00,0xaa,0xfc,0x6b,0x00,0x9e,0xfc,0x6a,0x00,0x91,0xfc,0x69,0x00,0x85,0xfc,0x69,0x00,0x78,0xfc,0x68,0x00,0x6b,0xfc,0x68,0x00,0x5f,0xfc,0x67,0x00,0x52,0xfc,0x66,0x00,0x45,0xfc,0x65,0x00,0x38,0xfc,0x65,0x00,0x2c,0xfc,0x64,0x00,0x1f,0xfc,0x63,0x00,0x12,0xfc,0x63,0x00,0x05,0xfc,0x62,0x00,0xf7,0xfb,0x61,0x00,0xea,0xfb,0x61,0x00,  \
    0xdd,0xfb,0x60,0x00,0xd0,0xfb,0x5f,0x00,0xc2,0xfb,0x5e,0x00,0xb5,0xfb,0x5e,0x00,0xa8,0xfb,0x5d,0x00,0x9a,0xfb,0x5c,0x00,0x8c,0xfb,0x5b,0x00,0x7f,0xfb,0x5a,0x00,0x71,0xfb,0x5a,0x00,0x63,0xfb,0x59,0x00,0x55,0xfb,0x58,0x00,0x48,0xfb,0x57,0x00,0x3a,0xfb,0x56,0x00,0x2b,0xfb,0x56,0x00,0x1d,0xfb,0x55,0x00,0x0f,0xfb,0x54,0x00,0x01,0xfb,0x53,0x00,0xf3,0xfa,0x52,0x00,0xe4,0xfa,0x51,0x00,0xd6,0xfa,0x51,0x00,0xc7,0xfa,0x50,0x00,0xb8,0xfa,0x4f,0x00,0xaa,0xfa,  \
    0x4e,0x00,0x9b,0xfa,0x4d,0x00,0x8c,0xfa,0x4c,0x00,0x7d,0xfa,0x4b,0x00,0x6e,0xfa,0x4a,0x00,0x5f,0xfa,0x49,0x00,0x50,0xfa,0x49,0x00,0x41,0xfa,0x48,0x00,0x31,0xfa,0x47,0x00,0x22,0xfa,0x46,0x00,0x13,0xfa,0x45,0x00,0x03,0xfa,0x44,0x00,0xf3,0xf9,0x43,0x00,0xe4,0xf9,0x42,0x00,0xd4,0xf9,0x41,0x00,0xc4,0xf9,0x40,0x00,0xb4,0xf9,0x3f,0x00,0xa4,0xf9,0x3e,0x00,0x94,0xf9,0x3d,0x00,0x84,0xf9,0x3c,0x00,0x73,0xf9,0x3b,0x00,0x63,0xf9,0x3a,0x00,0x52,0xf9,0x3a,0x00,  \
    0x42,0xf9,0x39,0x00,0x31,0xf9,0x38,0x00,0x20,0xf9,0x37,0x00,0x10,0xf9,0x36,0x00,0xff,0xf8,0x35,0x00,0xee,0xf8,0x34,0x00,0xdd,0xf8,0x33,0x00,0xcb,0xf8,0x32,0x00,0xba,0xf8,0x31,0x00,0xa9,0xf8,0x30,0x00,0x97,0xf8,0x2f,0x00,0x86,0xf8,0x2e,0x00,0x74,0xf8,0x2d,0x00,0x62,0xf8,0x2c,0x00,0x50,0xf8,0x2b,0x00,0x3e,0xf8,0x2a,0x00,0x2c,0xf8,0x29,0x00,0x1a,0xf8,0x28,0x00,0x08,0xf8,0x27,0x00,0xf5,0xf7,0x26,0x00,0xe3,0xf7,0x25,0x00,0xd0,0xf7,0x24,0x00,0xbe,0xf7,  \
    0x23,0x00,0xab,0xf7,0x22,0x00,0x98,0xf7,0x21,0x00,0x85,0xf7,0x20,0x00,0x72,0xf7,0x1e,0x00,0x5f,0xf7,0x1d,0x00,0x4c,0xf7,0x1c,0x00,0x38,0xf7,0x1b,0x00,0x25,0xf7,0x1a,0x00,0x11,0xf7,0x19,0x00,0xfe,0xf6,0x18,0x00,0xea,0xf6,0x17,0x00,0xd6,0xf6,0x16,0x00,0xc2,0xf6,0x15,0x00,0xae,0xf6,0x14,0x00,0x9a,0xf6,0x13,0x00,0x85,0xf6,0x12,0x00,0x71,0xf6,0x11,0x00,0x5c,0xf6,0x10,0x00,0x48,0xf6,0x0f,0x00,0x33,0xf6,0x0e,0x00,0x1e,0xf6,0x0d,0x00,0x09,0xf6,0x0c,0x00,  \
    0xf4,0xf5,0x0b,0x00,0xdf,0xf5,0x0a,0x00,0xca,0xf5,0x09,0x00,0xb4,0xf5,0x08,0x00,0x9f,0xf5,0x08,0x00,0x89,0xf5,0x07,0x00,0x73,0xf5,0x06,0x00,0x5d,0xf5,0x05,0x00,0x47,0xf5,0x04,0x00,0x31,0xf5,0x03,0x00,0x1b,0xf5,0x02,0x00,0x05,0xf5,0x01,0x00,0xee,0xf4,0x00,0x00,0xd8,0xf4,0xff,0xff,0xc1,0xf4,0xfe,0xff,0xaa,0xf4,0xfd,0xff,0x93,0xf4,0xfc,0xff,0x7c,0xf4,0xfb,0xff,0x65,0xf4,0xfa,0xff,0x4e,0xf4,0xfa,0xff,0x36,0xf4,0xf9,0xff,0x1f,0xf4,0xf8,0xff,0x07,0xf4,  \
    0xf7,0xff,0xf0,0xf3,0xf6,0xff,0xd8,0xf3,0xf5,0xff,0xc0,0xf3,0xf4,0xff,0xa8,0xf3,0xf4,0xff,0x8f,0xf3,0xf3,0xff,0x77,0xf3,0xf2,0xff,0x5e,0xf3,0xf1,0xff,0x46,0xf3,0xf0,0xff,0x2d,0xf3,0xef,0xff,0x14,0xf3,0xef,0xff,0xfb,0xf2,0xee,0xff,0xe2,0xf2,0xed,0xff,0xc9,0xf2,0xec,0xff,0xb0,0xf2,0xec,0xff,0x96,0xf2,0xeb,0xff,0x7d,0xf2,0xea,0xff,0x63,0xf2,0xe9,0xff,0x49,0xf2,0xe9,0xff,0x2f,0xf2,0xe8,0xff,0x15,0xf2,0xe7,0xff,0xfb,0xf1,0xe7,0xff,0xe0,0xf1,0xe6,0xff,  \
    0xc6,0xf1,0xe5,0xff,0xab,0xf1,0xe5,0xff,0x91,0xf1,0xe4,0xff,0x76,0xf1,0xe4,0xff,0x5b,0xf1,0xe3,0xff,0x40,0xf1,0xe2,0xff,0x25,0xf1,0xe2,0xff,0x09,0xf1,0xe1,0xff,0xee,0xf0,0xe1,0xff,0xd2,0xf0,0xe0,0xff,0xb6,0xf0,0xe0,0xff,0x9b,0xf0,0xdf,0xff,0x7f,0xf0,0xdf,0xff,0x62,0xf0,0xde,0xff,0x46,0xf0,0xde,0xff,0x2a,0xf0,0xdd,0xff,0x0d,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcb,0xff,0x04,0x10,0xcc,0xff,0xe7,0x0f,0xcc,0xff,0xca,0x0f,0xcd,0xff,0xae,0x0f,0xce,0xff,0x92,0x0f,0xce,0xff,0x75,0x0f,0xcf,0xff,0x59,0x0f,0xcf,0xff,0x3d,0x0f,0xd0,0xff,0x22,0x0f,0xd0,0xff,0x06,0x0f,0xd1,0xff,0xea,0x0e,0xd2,0xff,0xcf,0x0e,0xd2,0xff,0xb3,0x0e,0xd3,0xff,  \
    0x98,0x0e,0xd4,0xff,0x7d,0x0e,0xd4,0xff,0x62,0x0e,0xd5,0xff,0x47,0x0e,0xd6,0xff,0x2c,0x0e,0xd6,0xff,0x12,0x0e,0xd7,0xff,0xf7,0x0d,0xd8,0xff,0xdd,0x0d,0xd9,0xff,0xc2,0x0d,0xd9,0xff,0xa8,0x0d,0xda,0xff,0x8e,0x0d,0xdb,0xff,0x74,0x0d,0xdc,0xff,0x5a,0x0d,0xdd,0xff,0x41,0x0d,0xde,0xff,0x27,0x0d,0xde,0xff,0x0e,0x0d,0xdf,0xff,0xf4,0x0c,0xe0,0xff,0xdb,0x0c,0xe1,0xff,0xc2,0x0c,0xe2,0xff,0xa9,0x0c,0xe3,0xff,0x90,0x0c,0xe4,0xff,0x77,0x0c,0xe5,0xff,0x5f,0x0c,  \
    0xe6,0xff,0x46,0x0c,0xe6,0xff,0x2e,0x0c,0xe7,0xff,0x15,0x0c,0xe8,0xff,0xfd,0x0b,0xe9,0xff,0xe5,0x0b,0xea,0xff,0xcd,0x0b,0xeb,0xff,0xb5,0x0b,0xec,0xff,0x9e,0x0b,0xed,0xff,0x86,0x0b,0xee,0xff,0x6e,0x0b,0xef,0xff,0x57,0x0b,0xf0,0xff,0x40,0x0b,0xf1,0xff,0x29,0x0b,0xf2,0xff,0x12,0x0b,0xf3,0xff,0xfb,0x0a,0xf4,0xff,0xe4,0x0a,0xf6,0xff,0xcd,0x0a,0xf7,0xff,0xb7,0x0a,0xf8,0xff,0xa0,0x0a,0xf9,0xff,0x8a,0x0a,0xfa,0xff,0x74,0x0a,0xfb,0xff,0x5e,0x0a,0xfc,0xff,  \
    0x48,0x0a,0xfd,0xff,0x32,0x0a,0xfe,0xff,0x1c,0x0a,0xff,0xff,0x06,0x0a,0x00,0x00,0xf0,0x09,0x01,0x00,0xdb,0x09,0x02,0x00,0xc6,0x09,0x04,0x00,0xb0,0x09,0x05,0x00,0x9b,0x09,0x06,0x00,0x86,0x09,0x07,0x00,0x71,0x09,0x08,0x00,0x5c,0x09,0x09,0x00,0x47,0x09,0x0a,0x00,0x33,0x09,0x0b,0x00,0x1e,0x09,0x0c,0x00,0x0a,0x09,0x0e,0x00,0xf6,0x08,0x0f,0x00,0xe1,0x08,0x10,0x00,0xcd,0x08,0x11,0x00,0xb9,0x08,0x12,0x00,0xa5,0x08,0x13,0x00,0x91,0x08,0x14,0x00,0x7e,0x08,  \
    0x16,0x00,0x6a,0x08,0x17,0x00,0x57,0x08,0x18,0x00,0x43,0x08,0x19,0x00,0x30,0x08,0x1a,0x00,0x1d,0x08,0x1b,0x00,0x0a,0x08,0x1c,0x00,0xf7,0x07,0x1d,0x00,0xe4,0x07,0x1f,0x00,0xd1,0x07,0x20,0x00,0xbe,0x07,0x21,0x00,0xac,0x07,0x22,0x00,0x99,0x07,0x23,0x00,0x87,0x07,0x24,0x00,0x74,0x07,0x25,0x00,0x62,0x07,0x26,0x00,0x50,0x07,0x28,0x00,0x3e,0x07,0x29,0x00,0x2c,0x07,0x2a,0x00,0x1a,0x07,0x2b,0x00,0x08,0x07,0x2c,0x00,0xf7,0x06,0x2d,0x00,0xe5,0x06,0x2e,0x00,  \
    0xd4,0x06,0x2f,0x00,0xc2,0x06,0x30,0x00,0xb1,0x06,0x32,0x00,0xa0,0x06,0x33,0x00,0x8f,0x06,0x34,0x00,0x7e,0x06,0x35,0x00,0x6d,0x06,0x36,0x00,0x5c,0x06,0x37,0x00,0x4b,0x06,0x38,0x00,0x3a,0x06,0x39,0x00,0x2a,0x06,0x3a,0x00,0x19,0x06,0x3b,0x00,0x09,0x06,0x3c,0x00,0xf9,0x05,0x3d,0x00,0xe8,0x05,0x3e,0x00,0xd8,0x05,0x3f,0x00,0xc8,0x05,0x40,0x00,0xb8,0x05,0x42,0x00,0xa8,0x05,0x43,0x00,0x98,0x05,0x44,0x00,0x89,0x05,0x45,0x00,0x79,0x05,0x46,0x00,0x69,0x05,  \
    0x47,0x00,0x5a,0x05,0x48,0x00,0x4a,0x05,0x49,0x00,0x3b,0x05,0x4a,0x00,0x2c,0x05,0x4b,0x00,0x1d,0x05,0x4c,0x00,0x0d,0x05,0x4d,0x00,0xfe,0x04,0x4e,0x00,0xef,0x04,0x4f,0x00,0xe1,0x04,0x4f,0x00,0xd2,0x04,0x50,0x00,0xc3,0x04,0x51,0x00,0xb4,0x04,0x52,0x00,0xa6,0x04,0x53,0x00,0x97,0x04,0x54,0x00,0x89,0x04,0x55,0x00,0x7a,0x04,0x56,0x00,0x6c,0x04,0x57,0x00,0x5e,0x04,0x58,0x00,0x4f,0x04,0x59,0x00,0x41,0x04,0x5a,0x00,0x33,0x04,0x5b,0x00,0x25,0x04,0x5b,0x00,  \
    0x17,0x04,0x5c,0x00,0x09,0x04,0x5d,0x00,0xfc,0x03,0x5e,0x00,0xee,0x03,0x5f,0x00,0xe0,0x03,0x60,0x00,0xd3,0x03,0x60,0x00,0xc5,0x03,0x61,0x00,0xb8,0x03,0x62,0x00,0xaa,0x03,0x63,0x00,0x9d,0x03,0x64,0x00,0x8f,0x03,0x65,0x00,0x82,0x03,0x65,0x00,0x75,0x03,0x66,0x00,0x68,0x03,0x67,0x00,0x5b,0x03,0x68,0x00,0x4e,0x03,0x68,0x00,0x41,0x03,0x69,0x00,0x34,0x03,0x6a,0x00,0x27,0x03,0x6b,0x00,0x1a,0x03,0x6b,0x00,0x0e,0x03,0x6c,0x00,0x01,0x03,0x6d,0x00,0xf4,0x02,  \
    0x6d,0x00,0xe8,0x02,0x6e,0x00,0xdb,0x02,0x6f,0x00,0xcf,0x02,0x6f,0x00,0xc2,0x02,0x70,0x00,0xb6,0x02,0x71,0x00,0xaa,0x02,0x71,0x00,0x9d,0x02,0x72,0x00,0x91,0x02,0x73,0x00,0x85,0x02,0x73,0x00,0x79,0x02,0x74,0x00,0x6d,0x02,0x75,0x00,0x61,0x02,0x75,0x00,0x55,0x02,0x76,0x00,0x49,0x02,0x76,0x00,0x3d,0x02,0x77,0x00,0x31,0x02,0x77,0x00,0x25,0x02,0x78,0x00,0x19,0x02,0x78,0x00,0x0e,0x02,0x79,0x00,0x02,0x02,0x79,0x00,0xf6,0x01,0x7a,0x00,0xeb,0x01,0x7b,0x00,  \
    0xdf,0x01,0x7b,0x00,0xd4,0x01,0x7b,0x00,0xc8,0x01,0x7c,0x00,0xbd,0x01,0x7c,0x00,0xb1,0x01,0x7d,0x00,0xa6,0x01,0x7d,0x00,0x9a,0x01,0x7e,0x00,0x8f,0x01,0x7e,0x00,0x84,0x01,0x7f,0x00,0x78,0x01,0x7f,0x00,0x6d,0x01,0x7f,0x00,0x62,0x01,0x80,0x00,0x57,0x01,0x80,0x00,0x4b,0x01,0x80,0x00,0x40,0x01,0x81,0x00,0x35,0x01,0x81,0x00,0x2a,0x01,0x82,0x00,0x1f,0x01,0x82,0x00,0x14,0x01,0x82,0x00,0x09,0x01,0x82,0x00,0xfe,0x00,0x83,0x00,0xf3,0x00,0x83,0x00,0xe8,0x00,  \
    0x83,0x00,0xdd,0x00,0x84,0x00,0xd2,0x00,0x84,0x00,0xc7,0x00,0x84,0x00,0xbc,0x00,0x84,0x00,0xb1,0x00,0x85,0x00,0xa7,0x00,0x85,0x00,0x9c,0x00,0x85,0x00,0x91,0x00,0x85,0x00,0x86,0x00,0x85,0x00,0x7b,0x00,0x85,0x00,0x70,0x00,0x86,0x00,0x66,0x00,0x86,0x00,0x5b,0x00,0x86,0x00,0x50,0x00,0x86,0x00,0x45,0x00,0x86,0x00,0x3b,0x00,0x86,0x00,0x30,0x00,0x86,0x00,0x25,0x00,0x87,0x00,0x1b,0x00,0x87,0x00,0x10,0x00,0x87,0x00,0x05,0x00,0x87,0x00,0xfb,0xff,0x87,0x00,  \
    0xf0,0xff,0x87,0x00,0xe5,0xff,0x87,0x00,0xdb,0xff,0x87,0x00,0xd0,0xff,0x87,0x00,0xc5,0xff,0x87,0x00,0xbb,0xff,0x87,0x00,0xb0,0xff,0x87,0x00,0xa5,0xff,0x87,0x00,0x9b,0xff,0x87,0x00,0x90,0xff,0x87,0x00,0x85,0xff,0x87,0x00,0x7b,0xff,0x87,0x00,0x70,0xff,0x86,0x00,0x65,0xff,0x86,0x00,0x5b,0xff,0x86,0x00,0x50,0xff,0x86,0x00,0x45,0xff,0x86,0x00,0x3b,0xff,0x86,0x00,0x30,0xff,0x86,0x00,0x25,0xff,0x86,0x00,0x1a,0xff,0x85,0x00,0x10,0xff,0x85,0x00,0x05,0xff,  \
    0x85,0x00,0xfa,0xfe,0x85,0x00,0xef,0xfe,0x85,0x00,0xe5,0xfe,0x84,0x00,0xda,0xfe,0x84,0x00,0xcf,0xfe,0x84,0x00,0xc4,0xfe,0x84,0x00,0xb9,0xfe,0x84,0x00,0xae,0xfe,0x83,0x00,0xa4,0xfe,0x83,0x00,0x99,0xfe,0x83,0x00,0x8e,0xfe,0x82,0x00,0x83,0xfe,0x82,0x00,0x78,0xfe,0x82,0x00,0x6d,0xfe,0x81,0x00,0x62,0xfe,0x81,0x00,0x57,0xfe,0x81,0x00,0x4c,0xfe,0x80,0x00,0x41,0xfe,0x80,0x00,0x36,0xfe,0x80,0x00,0x2b,0xfe,0x7f,0x00,0x1f,0xfe,0x7f,0x00,0x14,0xfe,0x7f,0x00,  \
    0x09,0xfe,0x7e,0x00,0xfe,0xfd,0x7e,0x00,0xf3,0xfd,0x7d,0x00,0xe7,0xfd,0x7d,0x00,0xdc,0xfd,0x7c,0x00,0xd1,0xfd,0x7c,0x00,0xc5,0xfd,0x7b,0x00,0xba,0xfd,0x7b,0x00,0xaf,0xfd,0x7b,0x00,0xa3,0xfd,0x7a,0x00,0x98,0xfd,0x7a,0x00,0x8c,0xfd,0x79,0x00,0x81,0xfd,0x78,0x00,0x75,0xfd,0x78,0x00,0x69,0xfd,0x77,0x00,0x5e,0xfd,0x77,0x00,0x52,0xfd,0x76,0x00,0x46,0xfd,0x76,0x00,0x3a,0xfd,0x75,0x00,0x2e,0xfd,0x75,0x00,0x23,0xfd,0x74,0x00,0x17,0xfd,0x73,0x00,0x0b,0xfd,  \
    0x73,0x00,0xff,0xfc,0x72,0x00,0xf2,0xfc,0x71,0x00,0xe6,0xfc,0x71,0x00,0xda,0xfc,0x70,0x00,0xce,0xfc,0x70,0x00,0xc2,0xfc,0x6f,0x00,0xb5,0xfc,0x6e,0x00,0xa9,0xfc,0x6e,0x00,0x9d,0xfc,0x6d,0x00,0x90,0xfc,0x6c,0x00,0x84,0xfc,0x6b,0x00,0x77,0xfc,0x6b,0x00,0x6a,0xfc,0x6a,0x00,0x5e,0xfc,0x69,0x00,0x51,0xfc,0x69,0x00,0x44,0xfc,0x68,0x00,0x37,0xfc,0x67,0x00,0x2a,0xfc,0x66,0x00,0x1d,0xfc,0x65,0x00,0x10,0xfc,0x65,0x00,0x03,0xfc,0x64,0x00,0xf6,0xfb,0x63,0x00,  \
    0xe9,0xfb,0x62,0x00,0xdc,0xfb,0x61,0x00,0xcf,0xfb,0x61,0x00,0xc1,0xfb,0x60,0x00,0xb4,0xfb,0x5f,0x00,0xa6,0xfb,0x5e,0x00,0x99,0xfb,0x5d,0x00,0x8b,0xfb,0x5c,0x00,0x7e,0xfb,0x5c,0x00,0x70,0xfb,0x5b,0x00,0x62,0xfb,0x5a,0x00,0x54,0xfb,0x59,0x00,0x46,0xfb,0x58,0x00,0x38,0xfb,0x57,0x00,0x2a,0xfb,0x56,0x00,0x1c,0xfb,0x55,0x00,0x0e,0xfb,0x54,0x00,0x00,0xfb,0x53,0x00,0xf1,0xfa,0x53,0x00,0xe3,0xfa,0x52,0x00,0xd4,0xfa,0x51,0x00,0xc6,0xfa,0x50,0x00,0xb7,0xfa,  \
    0x4f,0x00,0xa8,0xfa,0x4e,0x00,0x9a,0xfa,0x4d,0x00,0x8b,0xfa,0x4c,0x00,0x7c,0xfa,0x4b,0x00,0x6d,0xfa,0x4a,0x00,0x5e,0xfa,0x49,0x00,0x4f,0xfa,0x48,0x00,0x3f,0xfa,0x47,0x00,0x30,0xfa,0x46,0x00,0x21,0xfa,0x45,0x00,0x11,0xfa,0x44,0x00,0x02,0xfa,0x43,0x00,0xf2,0xf9,0x42,0x00,0xe2,0xf9,0x41,0x00,0xd2,0xf9,0x40,0x00,0xc3,0xf9,0x3f,0x00,0xb3,0xf9,0x3e,0x00,0xa3,0xf9,0x3d,0x00,0x92,0xf9,0x3c,0x00,0x82,0xf9,0x3b,0x00,0x72,0xf9,0x39,0x00,0x61,0xf9,0x38,0x00,  \
    0x51,0xf9,0x37,0x00,0x40,0xf9,0x36,0x00,0x30,0xf9,0x35,0x00,0x1f,0xf9,0x34,0x00,0x0e,0xf9,0x33,0x00,0xfd,0xf8,0x32,0x00,0xec,0xf8,0x31,0x00,0xdb,0xf8,0x30,0x00,0xca,0xf8,0x2f,0x00,0xb9,0xf8,0x2e,0x00,0xa7,0xf8,0x2c,0x00,0x96,0xf8,0x2b,0x00,0x84,0xf8,0x2a,0x00,0x72,0xf8,0x29,0x00,0x61,0xf8,0x28,0x00,0x4f,0xf8,0x27,0x00,0x3d,0xf8,0x26,0x00,0x2b,0xf8,0x25,0x00,0x19,0xf8,0x24,0x00,0x06,0xf8,0x22,0x00,0xf4,0xf7,0x21,0x00,0xe2,0xf7,0x20,0x00,0xcf,0xf7,  \
    0x1f,0x00,0xbc,0xf7,0x1e,0x00,0xaa,0xf7,0x1d,0x00,0x97,0xf7,0x1c,0x00,0x84,0xf7,0x1b,0x00,0x71,0xf7,0x1a,0x00,0x5e,0xf7,0x18,0x00,0x4a,0xf7,0x17,0x00,0x37,0xf7,0x16,0x00,0x24,0xf7,0x15,0x00,0x10,0xf7,0x14,0x00,0xfc,0xf6,0x13,0x00,0xe9,0xf6,0x12,0x00,0xd5,0xf6,0x11,0x00,0xc1,0xf6,0x0f,0x00,0xad,0xf6,0x0e,0x00,0x98,0xf6,0x0d,0x00,0x84,0xf6,0x0c,0x00,0x70,0xf6,0x0b,0x00,0x5b,0xf6,0x0a,0x00,0x47,0xf6,0x09,0x00,0x32,0xf6,0x08,0x00,0x1d,0xf6,0x07,0x00,  \
    0x08,0xf6,0x06,0x00,0xf3,0xf5,0x04,0x00,0xde,0xf5,0x03,0x00,0xc8,0xf5,0x02,0x00,0xb3,0xf5,0x01,0x00,0x9d,0xf5,0x00,0x00,0x88,0xf5,0xff,0xff,0x72,0xf5,0xfe,0xff,0x5c,0xf5,0xfd,0xff,0x46,0xf5,0xfc,0xff,0x30,0xf5,0xfb,0xff,0x1a,0xf5,0xfa,0xff,0x03,0xf5,0xf9,0xff,0xed,0xf4,0xf8,0xff,0xd6,0xf4,0xf7,0xff,0xc0,0xf4,0xf6,0xff,0xa9,0xf4,0xf5,0xff,0x92,0xf4,0xf4,0xff,0x7b,0xf4,0xf3,0xff,0x64,0xf4,0xf2,0xff,0x4d,0xf4,0xf1,0xff,0x35,0xf4,0xf0,0xff,0x1e,0xf4,  \
    0xef,0xff,0x06,0xf4,0xee,0xff,0xee,0xf3,0xed,0xff,0xd7,0xf3,0xec,0xff,0xbf,0xf3,0xeb,0xff,0xa6,0xf3,0xea,0xff,0x8e,0xf3,0xe9,0xff,0x76,0xf3,0xe8,0xff,0x5d,0xf3,0xe7,0xff,0x45,0xf3,0xe6,0xff,0x2c,0xf3,0xe6,0xff,0x13,0xf3,0xe5,0xff,0xfa,0xf2,0xe4,0xff,0xe1,0xf2,0xe3,0xff,0xc8,0xf2,0xe2,0xff,0xaf,0xf2,0xe1,0xff,0x95,0xf2,0xe0,0xff,0x7c,0xf2,0xe0,0xff,0x62,0xf2,0xdf,0xff,0x48,0xf2,0xde,0xff,0x2e,0xf2,0xdd,0xff,0x14,0xf2,0xdd,0xff,0xfa,0xf1,0xdc,0xff,  \
    0xdf,0xf1,0xdb,0xff,0xc5,0xf1,0xda,0xff,0xaa,0xf1,0xda,0xff,0x90,0xf1,0xd9,0xff,0x75,0xf1,0xd8,0xff,0x5a,0xf1,0xd8,0xff,0x3f,0xf1,0xd7,0xff,0x24,0xf1,0xd6,0xff,0x08,0xf1,0xd6,0xff,0xed,0xf0,0xd5,0xff,0xd1,0xf0,0xd5,0xff,0xb5,0xf0,0xd4,0xff,0x9a,0xf0,0xd4,0xff,0x7e,0xf0,0xd3,0xff,0x61,0xf0,0xd3,0xff,0x45,0xf0,0xd2,0xff,0x29,0xf0,0xd2,0xff,0x0c,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xbe,0xff,0x05,0x10,0xbf,0xff,0xe8,0x0f,0xbf,0xff,0xcb,0x0f,0xc0,0xff,0xaf,0x0f,0xc0,0xff,0x93,0x0f,0xc1,0xff,0x76,0x0f,0xc2,0xff,0x5a,0x0f,0xc2,0xff,0x3e,0x0f,0xc3,0xff,0x23,0x0f,0xc4,0xff,0x07,0x0f,0xc4,0xff,0xeb,0x0e,0xc5,0xff,0xd0,0x0e,0xc6,0xff,  \
    0xb4,0x0e,0xc6,0xff,0x99,0x0e,0xc7,0xff,0x7e,0x0e,0xc8,0xff,0x63,0x0e,0xc9,0xff,0x48,0x0e,0xc9,0xff,0x2d,0x0e,0xca,0xff,0x13,0x0e,0xcb,0xff,0xf8,0x0d,0xcc,0xff,0xde,0x0d,0xcd,0xff,0xc3,0x0d,0xce,0xff,0xa9,0x0d,0xcf,0xff,0x8f,0x0d,0xcf,0xff,0x75,0x0d,0xd0,0xff,0x5b,0x0d,0xd1,0xff,0x42,0x0d,0xd2,0xff,0x28,0x0d,0xd3,0xff,0x0f,0x0d,0xd4,0xff,0xf5,0x0c,0xd5,0xff,0xdc,0x0c,0xd6,0xff,0xc3,0x0c,0xd7,0xff,0xaa,0x0c,0xd8,0xff,0x91,0x0c,0xd9,0xff,0x78,0x0c,  \
    0xda,0xff,0x60,0x0c,0xdb,0xff,0x47,0x0c,0xdc,0xff,0x2f,0x0c,0xdd,0xff,0x16,0x0c,0xde,0xff,0xfe,0x0b,0xdf,0xff,0xe6,0x0b,0xe0,0xff,0xce,0x0b,0xe1,0xff,0xb6,0x0b,0xe2,0xff,0x9f,0x0b,0xe3,0xff,0x87,0x0b,0xe5,0xff,0x70,0x0b,0xe6,0xff,0x58,0x0b,0xe7,0xff,0x41,0x0b,0xe8,0xff,0x2a,0x0b,0xe9,0xff,0x13,0x0b,0xea,0xff,0xfc,0x0a,0xeb,0xff,0xe5,0x0a,0xed,0xff,0xcf,0x0a,0xee,0xff,0xb8,0x0a,0xef,0xff,0xa2,0x0a,0xf0,0xff,0x8b,0x0a,0xf1,0xff,0x75,0x0a,0xf2,0xff,  \
    0x5f,0x0a,0xf4,0xff,0x49,0x0a,0xf5,0xff,0x33,0x0a,0xf6,0xff,0x1d,0x0a,0xf7,0xff,0x07,0x0a,0xf8,0xff,0xf2,0x09,0xfa,0xff,0xdc,0x09,0xfb,0xff,0xc7,0x09,0xfc,0xff,0xb2,0x09,0xfd,0xff,0x9c,0x09,0xfe,0xff,0x87,0x09,0x00,0x00,0x72,0x09,0x01,0x00,0x5e,0x09,0x02,0x00,0x49,0x09,0x03,0x00,0x34,0x09,0x05,0x00,0x20,0x09,0x06,0x00,0x0b,0x09,0x07,0x00,0xf7,0x08,0x08,0x00,0xe3,0x08,0x09,0x00,0xcf,0x08,0x0b,0x00,0xbb,0x08,0x0c,0x00,0xa7,0x08,0x0d,0x00,0x93,0x08,  \
    0x0e,0x00,0x7f,0x08,0x10,0x00,0x6c,0x08,0x11,0x00,0x58,0x08,0x12,0x00,0x45,0x08,0x13,0x00,0x31,0x08,0x15,0x00,0x1e,0x08,0x16,0x00,0x0b,0x08,0x17,0x00,0xf8,0x07,0x18,0x00,0xe5,0x07,0x1a,0x00,0xd2,0x07,0x1b,0x00,0xc0,0x07,0x1c,0x00,0xad,0x07,0x1d,0x00,0x9a,0x07,0x1f,0x00,0x88,0x07,0x20,0x00,0x76,0x07,0x21,0x00,0x63,0x07,0x22,0x00,0x51,0x07,0x24,0x00,0x3f,0x07,0x25,0x00,0x2d,0x07,0x26,0x00,0x1c,0x07,0x27,0x00,0x0a,0x07,0x28,0x00,0xf8,0x06,0x2a,0x00,  \
    0xe7,0x06,0x2b,0x00,0xd5,0x06,0x2c,0x00,0xc4,0x06,0x2d,0x00,0xb2,0x06,0x2e,0x00,0xa1,0x06,0x30,0x00,0x90,0x06,0x31,0x00,0x7f,0x06,0x32,0x00,0x6e,0x06,0x33,0x00,0x5d,0x06,0x34,0x00,0x4d,0x06,0x36,0x00,0x3c,0x06,0x37,0x00,0x2b,0x06,0x38,0x00,0x1b,0x06,0x39,0x00,0x0a,0x06,0x3a,0x00,0xfa,0x05,0x3b,0x00,0xea,0x05,0x3d,0x00,0xda,0x05,0x3e,0x00,0xca,0x05,0x3f,0x00,0xba,0x05,0x40,0x00,0xaa,0x05,0x41,0x00,0x9a,0x05,0x42,0x00,0x8a,0x05,0x43,0x00,0x7a,0x05,  \
    0x44,0x00,0x6b,0x05,0x46,0x00,0x5b,0x05,0x47,0x00,0x4c,0x05,0x48,0x00,0x3d,0x05,0x49,0x00,0x2d,0x05,0x4a,0x00,0x1e,0x05,0x4b,0x00,0x0f,0x05,0x4c,0x00,0x00,0x05,0x4d,0x00,0xf1,0x04,0x4e,0x00,0xe2,0x04,0x4f,0x00,0xd3,0x04,0x50,0x00,0xc4,0x04,0x51,0x00,0xb6,0x04,0x52,0x00,0xa7,0x04,0x53,0x00,0x99,0x04,0x54,0x00,0x8a,0x04,0x55,0x00,0x7c,0x04,0x56,0x00,0x6d,0x04,0x57,0x00,0x5f,0x04,0x58,0x00,0x51,0x04,0x59,0x00,0x43,0x04,0x5a,0x00,0x35,0x04,0x5b,0x00,  \
    0x27,0x04,0x5c,0x00,0x19,0x04,0x5d,0x00,0x0b,0x04,0x5e,0x00,0xfd,0x03,0x5f,0x00,0xef,0x03,0x60,0x00,0xe2,0x03,0x61,0x00,0xd4,0x03,0x62,0x00,0xc6,0x03,0x63,0x00,0xb9,0x03,0x64,0x00,0xab,0x03,0x65,0x00,0x9e,0x03,0x65,0x00,0x91,0x03,0x66,0x00,0x83,0x03,0x67,0x00,0x76,0x03,0x68,0x00,0x69,0x03,0x69,0x00,0x5c,0x03,0x6a,0x00,0x4f,0x03,0x6b,0x00,0x42,0x03,0x6b,0x00,0x35,0x03,0x6c,0x00,0x28,0x03,0x6d,0x00,0x1c,0x03,0x6e,0x00,0x0f,0x03,0x6f,0x00,0x02,0x03,  \
    0x6f,0x00,0xf6,0x02,0x70,0x00,0xe9,0x02,0x71,0x00,0xdc,0x02,0x72,0x00,0xd0,0x02,0x72,0x00,0xc4,0x02,0x73,0x00,0xb7,0x02,0x74,0x00,0xab,0x02,0x74,0x00,0x9f,0x02,0x75,0x00,0x92,0x02,0x76,0x00,0x86,0x02,0x77,0x00,0x7a,0x02,0x77,0x00,0x6e,0x02,0x78,0x00,0x62,0x02,0x78,0x00,0x56,0x02,0x79,0x00,0x4a,0x02,0x7a,0x00,0x3e,0x02,0x7a,0x00,0x32,0x02,0x7b,0x00,0x26,0x02,0x7c,0x00,0x1a,0x02,0x7c,0x00,0x0f,0x02,0x7d,0x00,0x03,0x02,0x7d,0x00,0xf7,0x01,0x7e,0x00,  \
    0xec,0x01,0x7e,0x00,0xe0,0x01,0x7f,0x00,0xd4,0x01,0x7f,0x00,0xc9,0x01,0x80,0x00,0xbd,0x01,0x80,0x00,0xb2,0x01,0x81,0x00,0xa6,0x01,0x81,0x00,0x9b,0x01,0x82,0x00,0x90,0x01,0x82,0x00,0x84,0x01,0x83,0x00,0x79,0x01,0x83,0x00,0x6e,0x01,0x84,0x00,0x62,0x01,0x84,0x00,0x57,0x01,0x85,0x00,0x4c,0x01,0x85,0x00,0x41,0x01,0x85,0x00,0x36,0x01,0x86,0x00,0x2b,0x01,0x86,0x00,0x20,0x01,0x86,0x00,0x14,0x01,0x87,0x00,0x09,0x01,0x87,0x00,0xfe,0x00,0x87,0x00,0xf3,0x00,  \
    0x88,0x00,0xe8,0x00,0x88,0x00,0xdd,0x00,0x88,0x00,0xd2,0x00,0x89,0x00,0xc8,0x00,0x89,0x00,0xbd,0x00,0x89,0x00,0xb2,0x00,0x89,0x00,0xa7,0x00,0x8a,0x00,0x9c,0x00,0x8a,0x00,0x91,0x00,0x8a,0x00,0x86,0x00,0x8a,0x00,0x7c,0x00,0x8a,0x00,0x71,0x00,0x8b,0x00,0x66,0x00,0x8b,0x00,0x5b,0x00,0x8b,0x00,0x50,0x00,0x8b,0x00,0x46,0x00,0x8b,0x00,0x3b,0x00,0x8b,0x00,0x30,0x00,0x8b,0x00,0x26,0x00,0x8c,0x00,0x1b,0x00,0x8c,0x00,0x10,0x00,0x8c,0x00,0x05,0x00,0x8c,0x00,  \
    0xfb,0xff,0x8c,0x00,0xf0,0xff,0x8c,0x00,0xe5,0xff,0x8c,0x00,0xdb,0xff,0x8c,0x00,0xd0,0xff,0x8c,0x00,0xc5,0xff,0x8c,0x00,0xbb,0xff,0x8c,0x00,0xb0,0xff,0x8c,0x00,0xa5,0xff,0x8c,0x00,0x9b,0xff,0x8c,0x00,0x90,0xff,0x8c,0x00,0x85,0xff,0x8c,0x00,0x7b,0xff,0x8c,0x00,0x70,0xff,0x8b,0x00,0x65,0xff,0x8b,0x00,0x5a,0xff,0x8b,0x00,0x50,0xff,0x8b,0x00,0x45,0xff,0x8b,0x00,0x3a,0xff,0x8b,0x00,0x30,0xff,0x8b,0x00,0x25,0xff,0x8b,0x00,0x1a,0xff,0x8a,0x00,0x0f,0xff,  \
    0x8a,0x00,0x05,0xff,0x8a,0x00,0xfa,0xfe,0x8a,0x00,0xef,0xfe,0x8a,0x00,0xe4,0xfe,0x89,0x00,0xd9,0xfe,0x89,0x00,0xcf,0xfe,0x89,0x00,0xc4,0xfe,0x89,0x00,0xb9,0xfe,0x88,0x00,0xae,0xfe,0x88,0x00,0xa3,0xfe,0x88,0x00,0x98,0xfe,0x87,0x00,0x8d,0xfe,0x87,0x00,0x82,0xfe,0x87,0x00,0x77,0xfe,0x86,0x00,0x6c,0xfe,0x86,0x00,0x61,0xfe,0x86,0x00,0x56,0xfe,0x85,0x00,0x4b,0xfe,0x85,0x00,0x40,0xfe,0x85,0x00,0x35,0xfe,0x84,0x00,0x2a,0xfe,0x84,0x00,0x1f,0xfe,0x83,0x00,  \
    0x14,0xfe,0x83,0x00,0x08,0xfe,0x82,0x00,0xfd,0xfd,0x82,0x00,0xf2,0xfd,0x81,0x00,0xe7,0xfd,0x81,0x00,0xdb,0xfd,0x80,0x00,0xd0,0xfd,0x80,0x00,0xc5,0xfd,0x7f,0x00,0xb9,0xfd,0x7f,0x00,0xae,0xfd,0x7e,0x00,0xa2,0xfd,0x7e,0x00,0x97,0xfd,0x7d,0x00,0x8b,0xfd,0x7d,0x00,0x80,0xfd,0x7c,0x00,0x74,0xfd,0x7c,0x00,0x68,0xfd,0x7b,0x00,0x5d,0xfd,0x7a,0x00,0x51,0xfd,0x7a,0x00,0x45,0xfd,0x79,0x00,0x39,0xfd,0x79,0x00,0x2d,0xfd,0x78,0x00,0x22,0xfd,0x77,0x00,0x16,0xfd,  \
    0x77,0x00,0x0a,0xfd,0x76,0x00,0xfd,0xfc,0x75,0x00,0xf1,0xfc,0x75,0x00,0xe5,0xfc,0x74,0x00,0xd9,0xfc,0x73,0x00,0xcd,0xfc,0x72,0x00,0xc1,0xfc,0x72,0x00,0xb4,0xfc,0x71,0x00,0xa8,0xfc,0x70,0x00,0x9b,0xfc,0x6f,0x00,0x8f,0xfc,0x6f,0x00,0x82,0xfc,0x6e,0x00,0x76,0xfc,0x6d,0x00,0x69,0xfc,0x6c,0x00,0x5c,0xfc,0x6c,0x00,0x50,0xfc,0x6b,0x00,0x43,0xfc,0x6a,0x00,0x36,0xfc,0x69,0x00,0x29,0xfc,0x68,0x00,0x1c,0xfc,0x67,0x00,0x0f,0xfc,0x67,0x00,0x02,0xfc,0x66,0x00,  \
    0xf5,0xfb,0x65,0x00,0xe8,0xfb,0x64,0x00,0xdb,0xfb,0x63,0x00,0xcd,0xfb,0x62,0x00,0xc0,0xfb,0x61,0x00,0xb2,0xfb,0x60,0x00,0xa5,0xfb,0x5f,0x00,0x97,0xfb,0x5f,0x00,0x8a,0xfb,0x5e,0x00,0x7c,0xfb,0x5d,0x00,0x6e,0xfb,0x5c,0x00,0x61,0xfb,0x5b,0x00,0x53,0xfb,0x5a,0x00,0x45,0xfb,0x59,0x00,0x37,0xfb,0x58,0x00,0x29,0xfb,0x57,0x00,0x1b,0xfb,0x56,0x00,0x0c,0xfb,0x55,0x00,0xfe,0xfa,0x54,0x00,0xf0,0xfa,0x53,0x00,0xe1,0xfa,0x52,0x00,0xd3,0xfa,0x51,0x00,0xc4,0xfa,  \
    0x50,0x00,0xb6,0xfa,0x4f,0x00,0xa7,0xfa,0x4e,0x00,0x98,0xfa,0x4d,0x00,0x89,0xfa,0x4b,0x00,0x7a,0xfa,0x4a,0x00,0x6b,0xfa,0x49,0x00,0x5c,0xfa,0x48,0x00,0x4d,0xfa,0x47,0x00,0x3e,0xfa,0x46,0x00,0x2f,0xfa,0x45,0x00,0x1f,0xfa,0x44,0x00,0x10,0xfa,0x43,0x00,0x00,0xfa,0x42,0x00,0xf0,0xf9,0x41,0x00,0xe1,0xf9,0x3f,0x00,0xd1,0xf9,0x3e,0x00,0xc1,0xf9,0x3d,0x00,0xb1,0xf9,0x3c,0x00,0xa1,0xf9,0x3b,0x00,0x91,0xf9,0x3a,0x00,0x81,0xf9,0x39,0x00,0x70,0xf9,0x37,0x00,  \
    0x60,0xf9,0x36,0x00,0x4f,0xf9,0x35,0x00,0x3f,0xf9,0x34,0x00,0x2e,0xf9,0x33,0x00,0x1d,0xf9,0x31,0x00,0x0d,0xf9,0x30,0x00,0xfc,0xf8,0x2f,0x00,0xeb,0xf8,0x2e,0x00,0xda,0xf8,0x2d,0x00,0xc8,0xf8,0x2c,0x00,0xb7,0xf8,0x2a,0x00,0xa6,0xf8,0x29,0x00,0x94,0xf8,0x28,0x00,0x83,0xf8,0x27,0x00,0x71,0xf8,0x25,0x00,0x5f,0xf8,0x24,0x00,0x4d,0xf8,0x23,0x00,0x3b,0xf8,0x22,0x00,0x29,0xf8,0x21,0x00,0x17,0xf8,0x1f,0x00,0x05,0xf8,0x1e,0x00,0xf3,0xf7,0x1d,0x00,0xe0,0xf7,  \
    0x1c,0x00,0xce,0xf7,0x1b,0x00,0xbb,0xf7,0x19,0x00,0xa8,0xf7,0x18,0x00,0x95,0xf7,0x17,0x00,0x82,0xf7,0x16,0x00,0x6f,0xf7,0x14,0x00,0x5c,0xf7,0x13,0x00,0x49,0xf7,0x12,0x00,0x36,0xf7,0x11,0x00,0x22,0xf7,0x0f,0x00,0x0f,0xf7,0x0e,0x00,0xfb,0xf6,0x0d,0x00,0xe7,0xf6,0x0c,0x00,0xd3,0xf6,0x0b,0x00,0xbf,0xf6,0x09,0x00,0xab,0xf6,0x08,0x00,0x97,0xf6,0x07,0x00,0x83,0xf6,0x06,0x00,0x6e,0xf6,0x04,0x00,0x5a,0xf6,0x03,0x00,0x45,0xf6,0x02,0x00,0x30,0xf6,0x01,0x00,  \
    0x1c,0xf6,0x00,0x00,0x07,0xf6,0xfe,0xff,0xf1,0xf5,0xfd,0xff,0xdc,0xf5,0xfc,0xff,0xc7,0xf5,0xfb,0xff,0xb2,0xf5,0xfa,0xff,0x9c,0xf5,0xf9,0xff,0x86,0xf5,0xf7,0xff,0x71,0xf5,0xf6,0xff,0x5b,0xf5,0xf5,0xff,0x45,0xf5,0xf4,0xff,0x2f,0xf5,0xf3,0xff,0x18,0xf5,0xf2,0xff,0x02,0xf5,0xf0,0xff,0xec,0xf4,0xef,0xff,0xd5,0xf4,0xee,0xff,0xbe,0xf4,0xed,0xff,0xa8,0xf4,0xec,0xff,0x91,0xf4,0xeb,0xff,0x7a,0xf4,0xea,0xff,0x63,0xf4,0xe9,0xff,0x4b,0xf4,0xe8,0xff,0x34,0xf4,  \
    0xe7,0xff,0x1c,0xf4,0xe5,0xff,0x05,0xf4,0xe4,0xff,0xed,0xf3,0xe3,0xff,0xd5,0xf3,0xe2,0xff,0xbd,0xf3,0xe1,0xff,0xa5,0xf3,0xe0,0xff,0x8d,0xf3,0xdf,0xff,0x75,0xf3,0xde,0xff,0x5c,0xf3,0xdd,0xff,0x44,0xf3,0xdc,0xff,0x2b,0xf3,0xdb,0xff,0x12,0xf3,0xda,0xff,0xf9,0xf2,0xd9,0xff,0xe0,0xf2,0xd9,0xff,0xc7,0xf2,0xd8,0xff,0xad,0xf2,0xd7,0xff,0x94,0xf2,0xd6,0xff,0x7a,0xf2,0xd5,0xff,0x61,0xf2,0xd4,0xff,0x47,0xf2,0xd3,0xff,0x2d,0xf2,0xd2,0xff,0x13,0xf2,0xd2,0xff,  \
    0xf9,0xf1,0xd1,0xff,0xde,0xf1,0xd0,0xff,0xc4,0xf1,0xcf,0xff,0xa9,0xf1,0xce,0xff,0x8f,0xf1,0xce,0xff,0x74,0xf1,0xcd,0xff,0x59,0xf1,0xcc,0xff,0x3e,0xf1,0xcc,0xff,0x22,0xf1,0xcb,0xff,0x07,0xf1,0xca,0xff,0xec,0xf0,0xca,0xff,0xd0,0xf0,0xc9,0xff,0xb4,0xf0,0xc8,0xff,0x98,0xf0,0xc8,0xff,0x7c,0xf0,0xc7,0xff,0x60,0xf0,0xc7,0xff,0x44,0xf0,0xc6,0xff,0x28,0xf0,0xc5,0xff,0x0b,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xb0,0xff,0x06,0x10,0xb1,0xff,0xe9,0x0f,0xb2,0xff,0xcc,0x0f,0xb2,0xff,0xb0,0x0f,0xb3,0xff,0x94,0x0f,0xb4,0xff,0x77,0x0f,0xb4,0xff,0x5b,0x0f,0xb5,0xff,0x3f,0x0f,0xb6,0xff,0x24,0x0f,0xb6,0xff,0x08,0x0f,0xb7,0xff,0xec,0x0e,0xb8,0xff,  \
    0xd1,0x0e,0xb9,0xff,0xb5,0x0e,0xba,0xff,0x9a,0x0e,0xba,0xff,0x7f,0x0e,0xbb,0xff,0x64,0x0e,0xbc,0xff,0x49,0x0e,0xbd,0xff,0x2e,0x0e,0xbe,0xff,0x14,0x0e,0xbf,0xff,0xf9,0x0d,0xc0,0xff,0xdf,0x0d,0xc1,0xff,0xc4,0x0d,0xc1,0xff,0xaa,0x0d,0xc2,0xff,0x90,0x0d,0xc3,0xff,0x76,0x0d,0xc4,0xff,0x5c,0x0d,0xc5,0xff,0x43,0x0d,0xc6,0xff,0x29,0x0d,0xc7,0xff,0x10,0x0d,0xc8,0xff,0xf6,0x0c,0xc9,0xff,0xdd,0x0c,0xcb,0xff,0xc4,0x0c,0xcc,0xff,0xab,0x0c,0xcd,0xff,0x92,0x0c,  \
    0xce,0xff,0x79,0x0c,0xcf,0xff,0x61,0x0c,0xd0,0xff,0x48,0x0c,0xd1,0xff,0x30,0x0c,0xd2,0xff,0x18,0x0c,0xd3,0xff,0xff,0x0b,0xd5,0xff,0xe7,0x0b,0xd6,0xff,0xcf,0x0b,0xd7,0xff,0xb8,0x0b,0xd8,0xff,0xa0,0x0b,0xd9,0xff,0x88,0x0b,0xdb,0xff,0x71,0x0b,0xdc,0xff,0x59,0x0b,0xdd,0xff,0x42,0x0b,0xde,0xff,0x2b,0x0b,0xdf,0xff,0x14,0x0b,0xe1,0xff,0xfd,0x0a,0xe2,0xff,0xe7,0x0a,0xe3,0xff,0xd0,0x0a,0xe5,0xff,0xb9,0x0a,0xe6,0xff,0xa3,0x0a,0xe7,0xff,0x8d,0x0a,0xe8,0xff,  \
    0x76,0x0a,0xea,0xff,0x60,0x0a,0xeb,0xff,0x4a,0x0a,0xec,0xff,0x34,0x0a,0xee,0xff,0x1e,0x0a,0xef,0xff,0x09,0x0a,0xf0,0xff,0xf3,0x09,0xf2,0xff,0xde,0x09,0xf3,0xff,0xc8,0x09,0xf4,0xff,0xb3,0x09,0xf5,0xff,0x9e,0x09,0xf7,0xff,0x89,0x09,0xf8,0xff,0x74,0x09,0xf9,0xff,0x5f,0x09,0xfb,0xff,0x4a,0x09,0xfc,0xff,0x36,0x09,0xfe,0xff,0x21,0x09,0xff,0xff,0x0d,0x09,0x00,0x00,0xf8,0x08,0x02,0x00,0xe4,0x08,0x03,0x00,0xd0,0x08,0x04,0x00,0xbc,0x08,0x06,0x00,0xa8,0x08,  \
    0x07,0x00,0x94,0x08,0x08,0x00,0x81,0x08,0x0a,0x00,0x6d,0x08,0x0b,0x00,0x5a,0x08,0x0c,0x00,0x46,0x08,0x0e,0x00,0x33,0x08,0x0f,0x00,0x20,0x08,0x10,0x00,0x0d,0x08,0x12,0x00,0xfa,0x07,0x13,0x00,0xe7,0x07,0x15,0x00,0xd4,0x07,0x16,0x00,0xc1,0x07,0x17,0x00,0xae,0x07,0x19,0x00,0x9c,0x07,0x1a,0x00,0x8a,0x07,0x1b,0x00,0x77,0x07,0x1d,0x00,0x65,0x07,0x1e,0x00,0x53,0x07,0x1f,0x00,0x41,0x07,0x21,0x00,0x2f,0x07,0x22,0x00,0x1d,0x07,0x23,0x00,0x0b,0x07,0x25,0x00,  \
    0xfa,0x06,0x26,0x00,0xe8,0x06,0x27,0x00,0xd7,0x06,0x29,0x00,0xc5,0x06,0x2a,0x00,0xb4,0x06,0x2b,0x00,0xa3,0x06,0x2d,0x00,0x92,0x06,0x2e,0x00,0x81,0x06,0x2f,0x00,0x70,0x06,0x30,0x00,0x5f,0x06,0x32,0x00,0x4e,0x06,0x33,0x00,0x3e,0x06,0x34,0x00,0x2d,0x06,0x36,0x00,0x1d,0x06,0x37,0x00,0x0c,0x06,0x38,0x00,0xfc,0x05,0x39,0x00,0xec,0x05,0x3b,0x00,0xdb,0x05,0x3c,0x00,0xcb,0x05,0x3d,0x00,0xbb,0x05,0x3e,0x00,0xab,0x05,0x40,0x00,0x9c,0x05,0x41,0x00,0x8c,0x05,  \
    0x42,0x00,0x7c,0x05,0x43,0x00,0x6d,0x05,0x44,0x00,0x5d,0x05,0x46,0x00,0x4e,0x05,0x47,0x00,0x3e,0x05,0x48,0x00,0x2f,0x05,0x49,0x00,0x20,0x05,0x4a,0x00,0x11,0x05,0x4c,0x00,0x02,0x05,0x4d,0x00,0xf3,0x04,0x4e,0x00,0xe4,0x04,0x4f,0x00,0xd5,0x04,0x50,0x00,0xc6,0x04,0x51,0x00,0xb7,0x04,0x52,0x00,0xa9,0x04,0x54,0x00,0x9a,0x04,0x55,0x00,0x8c,0x04,0x56,0x00,0x7d,0x04,0x57,0x00,0x6f,0x04,0x58,0x00,0x61,0x04,0x59,0x00,0x52,0x04,0x5a,0x00,0x44,0x04,0x5b,0x00,  \
    0x36,0x04,0x5c,0x00,0x28,0x04,0x5d,0x00,0x1a,0x04,0x5e,0x00,0x0c,0x04,0x5f,0x00,0xfe,0x03,0x60,0x00,0xf1,0x03,0x61,0x00,0xe3,0x03,0x62,0x00,0xd5,0x03,0x63,0x00,0xc8,0x03,0x64,0x00,0xba,0x03,0x65,0x00,0xad,0x03,0x66,0x00,0x9f,0x03,0x67,0x00,0x92,0x03,0x68,0x00,0x85,0x03,0x69,0x00,0x78,0x03,0x6a,0x00,0x6b,0x03,0x6b,0x00,0x5d,0x03,0x6c,0x00,0x50,0x03,0x6d,0x00,0x43,0x03,0x6e,0x00,0x37,0x03,0x6e,0x00,0x2a,0x03,0x6f,0x00,0x1d,0x03,0x70,0x00,0x10,0x03,  \
    0x71,0x00,0x03,0x03,0x72,0x00,0xf7,0x02,0x73,0x00,0xea,0x02,0x73,0x00,0xde,0x02,0x74,0x00,0xd1,0x02,0x75,0x00,0xc5,0x02,0x76,0x00,0xb8,0x02,0x77,0x00,0xac,0x02,0x77,0x00,0xa0,0x02,0x78,0x00,0x93,0x02,0x79,0x00,0x87,0x02,0x7a,0x00,0x7b,0x02,0x7a,0x00,0x6f,0x02,0x7b,0x00,0x63,0x02,0x7c,0x00,0x57,0x02,0x7c,0x00,0x4b,0x02,0x7d,0x00,0x3f,0x02,0x7e,0x00,0x33,0x02,0x7e,0x00,0x27,0x02,0x7f,0x00,0x1b,0x02,0x80,0x00,0x10,0x02,0x80,0x00,0x04,0x02,0x81,0x00,  \
    0xf8,0x01,0x82,0x00,0xed,0x01,0x82,0x00,0xe1,0x01,0x83,0x00,0xd5,0x01,0x83,0x00,0xca,0x01,0x84,0x00,0xbe,0x01,0x84,0x00,0xb3,0x01,0x85,0x00,0xa7,0x01,0x86,0x00,0x9c,0x01,0x86,0x00,0x90,0x01,0x87,0x00,0x85,0x01,0x87,0x00,0x7a,0x01,0x88,0x00,0x6e,0x01,0x88,0x00,0x63,0x01,0x88,0x00,0x58,0x01,0x89,0x00,0x4d,0x01,0x89,0x00,0x42,0x01,0x8a,0x00,0x36,0x01,0x8a,0x00,0x2b,0x01,0x8b,0x00,0x20,0x01,0x8b,0x00,0x15,0x01,0x8b,0x00,0x0a,0x01,0x8c,0x00,0xff,0x00,  \
    0x8c,0x00,0xf4,0x00,0x8c,0x00,0xe9,0x00,0x8d,0x00,0xde,0x00,0x8d,0x00,0xd3,0x00,0x8d,0x00,0xc8,0x00,0x8e,0x00,0xbd,0x00,0x8e,0x00,0xb2,0x00,0x8e,0x00,0xa7,0x00,0x8e,0x00,0x9c,0x00,0x8f,0x00,0x92,0x00,0x8f,0x00,0x87,0x00,0x8f,0x00,0x7c,0x00,0x8f,0x00,0x71,0x00,0x8f,0x00,0x66,0x00,0x90,0x00,0x5c,0x00,0x90,0x00,0x51,0x00,0x90,0x00,0x46,0x00,0x90,0x00,0x3b,0x00,0x90,0x00,0x30,0x00,0x90,0x00,0x26,0x00,0x90,0x00,0x1b,0x00,0x91,0x00,0x10,0x00,0x91,0x00,  \
    0x06,0x00,0x91,0x00,0xfb,0xff,0x91,0x00,0xf0,0xff,0x91,0x00,0xe5,0xff,0x91,0x00,0xdb,0xff,0x91,0x00,0xd0,0xff,0x91,0x00,0xc5,0xff,0x91,0x00,0xbb,0xff,0x91,0x00,0xb0,0xff,0x91,0x00,0xa5,0xff,0x91,0x00,0x9b,0xff,0x91,0x00,0x90,0xff,0x91,0x00,0x85,0xff,0x91,0x00,0x7a,0xff,0x91,0x00,0x70,0xff,0x90,0x00,0x65,0xff,0x90,0x00,0x5a,0xff,0x90,0x00,0x50,0xff,0x90,0x00,0x45,0xff,0x90,0x00,0x3a,0xff,0x90,0x00,0x2f,0xff,0x90,0x00,0x25,0xff,0x8f,0x00,0x1a,0xff,  \
    0x8f,0x00,0x0f,0xff,0x8f,0x00,0x04,0xff,0x8f,0x00,0xf9,0xfe,0x8f,0x00,0xef,0xfe,0x8e,0x00,0xe4,0xfe,0x8e,0x00,0xd9,0xfe,0x8e,0x00,0xce,0xfe,0x8e,0x00,0xc3,0xfe,0x8d,0x00,0xb8,0xfe,0x8d,0x00,0xad,0xfe,0x8d,0x00,0xa2,0xfe,0x8c,0x00,0x97,0xfe,0x8c,0x00,0x8d,0xfe,0x8c,0x00,0x82,0xfe,0x8b,0x00,0x77,0xfe,0x8b,0x00,0x6c,0xfe,0x8b,0x00,0x61,0xfe,0x8a,0x00,0x56,0xfe,0x8a,0x00,0x4a,0xfe,0x89,0x00,0x3f,0xfe,0x89,0x00,0x34,0xfe,0x88,0x00,0x29,0xfe,0x88,0x00,  \
    0x1e,0xfe,0x88,0x00,0x13,0xfe,0x87,0x00,0x08,0xfe,0x87,0x00,0xfc,0xfd,0x86,0x00,0xf1,0xfd,0x86,0x00,0xe6,0xfd,0x85,0x00,0xda,0xfd,0x85,0x00,0xcf,0xfd,0x84,0x00,0xc4,0xfd,0x83,0x00,0xb8,0xfd,0x83,0x00,0xad,0xfd,0x82,0x00,0xa1,0xfd,0x82,0x00,0x96,0xfd,0x81,0x00,0x8a,0xfd,0x80,0x00,0x7f,0xfd,0x80,0x00,0x73,0xfd,0x7f,0x00,0x67,0xfd,0x7f,0x00,0x5c,0xfd,0x7e,0x00,0x50,0xfd,0x7d,0x00,0x44,0xfd,0x7d,0x00,0x38,0xfd,0x7c,0x00,0x2c,0xfd,0x7b,0x00,0x20,0xfd,  \
    0x7b,0x00,0x14,0xfd,0x7a,0x00,0x08,0xfd,0x79,0x00,0xfc,0xfc,0x78,0x00,0xf0,0xfc,0x78,0x00,0xe4,0xfc,0x77,0x00,0xd8,0xfc,0x76,0x00,0xcc,0xfc,0x75,0x00,0xbf,0xfc,0x75,0x00,0xb3,0xfc,0x74,0x00,0xa7,0xfc,0x73,0x00,0x9a,0xfc,0x72,0x00,0x8e,0xfc,0x71,0x00,0x81,0xfc,0x70,0x00,0x74,0xfc,0x70,0x00,0x68,0xfc,0x6f,0x00,0x5b,0xfc,0x6e,0x00,0x4e,0xfc,0x6d,0x00,0x41,0xfc,0x6c,0x00,0x35,0xfc,0x6b,0x00,0x28,0xfc,0x6a,0x00,0x1b,0xfc,0x69,0x00,0x0e,0xfc,0x68,0x00,  \
    0x01,0xfc,0x67,0x00,0xf3,0xfb,0x67,0x00,0xe6,0xfb,0x66,0x00,0xd9,0xfb,0x65,0x00,0xcc,0xfb,0x64,0x00,0xbe,0xfb,0x63,0x00,0xb1,0xfb,0x62,0x00,0xa3,0xfb,0x61,0x00,0x96,0xfb,0x60,0x00,0x88,0xfb,0x5f,0x00,0x7b,0xfb,0x5e,0x00,0x6d,0xfb,0x5d,0x00,0x5f,0xfb,0x5c,0x00,0x51,0xfb,0x5b,0x00,0x43,0xfb,0x59,0x00,0x35,0xfb,0x58,0x00,0x27,0xfb,0x57,0x00,0x19,0xfb,0x56,0x00,0x0b,0xfb,0x55,0x00,0xfc,0xfa,0x54,0x00,0xee,0xfa,0x53,0x00,0xe0,0xfa,0x52,0x00,0xd1,0xfa,  \
    0x51,0x00,0xc3,0xfa,0x50,0x00,0xb4,0xfa,0x4e,0x00,0xa5,0xfa,0x4d,0x00,0x96,0xfa,0x4c,0x00,0x88,0xfa,0x4b,0x00,0x79,0xfa,0x4a,0x00,0x6a,0xfa,0x49,0x00,0x5b,0xfa,0x47,0x00,0x4b,0xfa,0x46,0x00,0x3c,0xfa,0x45,0x00,0x2d,0xfa,0x44,0x00,0x1d,0xfa,0x43,0x00,0x0e,0xfa,0x42,0x00,0xfe,0xf9,0x40,0x00,0xef,0xf9,0x3f,0x00,0xdf,0xf9,0x3e,0x00,0xcf,0xf9,0x3d,0x00,0xbf,0xf9,0x3b,0x00,0xaf,0xf9,0x3a,0x00,0x9f,0xf9,0x39,0x00,0x8f,0xf9,0x38,0x00,0x7f,0xf9,0x36,0x00,  \
    0x6f,0xf9,0x35,0x00,0x5e,0xf9,0x34,0x00,0x4e,0xf9,0x33,0x00,0x3d,0xf9,0x31,0x00,0x2d,0xf9,0x30,0x00,0x1c,0xf9,0x2f,0x00,0x0b,0xf9,0x2d,0x00,0xfa,0xf8,0x2c,0x00,0xe9,0xf8,0x2b,0x00,0xd8,0xf8,0x2a,0x00,0xc7,0xf8,0x28,0x00,0xb5,0xf8,0x27,0x00,0xa4,0xf8,0x26,0x00,0x93,0xf8,0x24,0x00,0x81,0xf8,0x23,0x00,0x6f,0xf8,0x22,0x00,0x5e,0xf8,0x20,0x00,0x4c,0xf8,0x1f,0x00,0x3a,0xf8,0x1e,0x00,0x28,0xf8,0x1c,0x00,0x16,0xf8,0x1b,0x00,0x03,0xf8,0x1a,0x00,0xf1,0xf7,  \
    0x18,0x00,0xdf,0xf7,0x17,0x00,0xcc,0xf7,0x16,0x00,0xb9,0xf7,0x14,0x00,0xa7,0xf7,0x13,0x00,0x94,0xf7,0x12,0x00,0x81,0xf7,0x10,0x00,0x6e,0xf7,0x0f,0x00,0x5b,0xf7,0x0e,0x00,0x47,0xf7,0x0c,0x00,0x34,0xf7,0x0b,0x00,0x21,0xf7,0x0a,0x00,0x0d,0xf7,0x08,0x00,0xf9,0xf6,0x07,0x00,0xe6,0xf6,0x06,0x00,0xd2,0xf6,0x04,0x00,0xbe,0xf6,0x03,0x00,0xaa,0xf6,0x02,0x00,0x96,0xf6,0x00,0x00,0x81,0xf6,0xff,0xff,0x6d,0xf6,0xfe,0xff,0x58,0xf6,0xfc,0xff,0x44,0xf6,0xfb,0xff,  \
    0x2f,0xf6,0xfa,0xff,0x1a,0xf6,0xf9,0xff,0x05,0xf6,0xf7,0xff,0xf0,0xf5,0xf6,0xff,0xdb,0xf5,0xf5,0xff,0xc6,0xf5,0xf3,0xff,0xb0,0xf5,0xf2,0xff,0x9b,0xf5,0xf1,0xff,0x85,0xf5,0xf0,0xff,0x6f,0xf5,0xee,0xff,0x59,0xf5,0xed,0xff,0x43,0xf5,0xec,0xff,0x2d,0xf5,0xeb,0xff,0x17,0xf5,0xe9,0xff,0x01,0xf5,0xe8,0xff,0xea,0xf4,0xe7,0xff,0xd4,0xf4,0xe6,0xff,0xbd,0xf4,0xe4,0xff,0xa6,0xf4,0xe3,0xff,0x8f,0xf4,0xe2,0xff,0x78,0xf4,0xe1,0xff,0x61,0xf4,0xe0,0xff,0x4a,0xf4,  \
    0xde,0xff,0x33,0xf4,0xdd,0xff,0x1b,0xf4,0xdc,0xff,0x04,0xf4,0xdb,0xff,0xec,0xf3,0xda,0xff,0xd4,0xf3,0xd9,0xff,0xbc,0xf3,0xd7,0xff,0xa4,0xf3,0xd6,0xff,0x8c,0xf3,0xd5,0xff,0x73,0xf3,0xd4,0xff,0x5b,0xf3,0xd3,0xff,0x42,0xf3,0xd2,0xff,0x2a,0xf3,0xd1,0xff,0x11,0xf3,0xd0,0xff,0xf8,0xf2,0xcf,0xff,0xdf,0xf2,0xce,0xff,0xc6,0xf2,0xcd,0xff,0xac,0xf2,0xcc,0xff,0x93,0xf2,0xcb,0xff,0x79,0xf2,0xca,0xff,0x60,0xf2,0xc9,0xff,0x46,0xf2,0xc8,0xff,0x2c,0xf2,0xc7,0xff,  \
    0x12,0xf2,0xc6,0xff,0xf7,0xf1,0xc5,0xff,0xdd,0xf1,0xc5,0xff,0xc3,0xf1,0xc4,0xff,0xa8,0xf1,0xc3,0xff,0x8d,0xf1,0xc2,0xff,0x73,0xf1,0xc1,0xff,0x58,0xf1,0xc0,0xff,0x3d,0xf1,0xc0,0xff,0x21,0xf1,0xbf,0xff,0x06,0xf1,0xbe,0xff,0xeb,0xf0,0xbe,0xff,0xcf,0xf0,0xbd,0xff,0xb3,0xf0,0xbc,0xff,0x97,0xf0,0xbb,0xff,0x7b,0xf0,0xbb,0xff,0x5f,0xf0,0xba,0xff,0x43,0xf0,0xba,0xff,0x27,0xf0,0xb9,0xff,0x0a,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa2,0xff,0x07,0x10,0xa3,0xff,0xea,0x0f,0xa4,0xff,0xcd,0x0f,0xa4,0xff,0xb1,0x0f,0xa5,0xff,0x95,0x0f,0xa6,0xff,0x78,0x0f,0xa7,0xff,0x5c,0x0f,0xa7,0xff,0x40,0x0f,0xa8,0xff,0x25,0x0f,0xa9,0xff,0x09,0x0f,0xaa,0xff,  \
    0xed,0x0e,0xab,0xff,0xd2,0x0e,0xab,0xff,0xb6,0x0e,0xac,0xff,0x9b,0x0e,0xad,0xff,0x80,0x0e,0xae,0xff,0x65,0x0e,0xaf,0xff,0x4a,0x0e,0xb0,0xff,0x2f,0x0e,0xb1,0xff,0x15,0x0e,0xb2,0xff,0xfa,0x0d,0xb3,0xff,0xe0,0x0d,0xb4,0xff,0xc6,0x0d,0xb5,0xff,0xab,0x0d,0xb6,0xff,0x91,0x0d,0xb7,0xff,0x77,0x0d,0xb8,0xff,0x5e,0x0d,0xb9,0xff,0x44,0x0d,0xba,0xff,0x2a,0x0d,0xbb,0xff,0x11,0x0d,0xbd,0xff,0xf8,0x0c,0xbe,0xff,0xde,0x0c,0xbf,0xff,0xc5,0x0c,0xc0,0xff,0xac,0x0c,  \
    0xc1,0xff,0x93,0x0c,0xc2,0xff,0x7b,0x0c,0xc4,0xff,0x62,0x0c,0xc5,0xff,0x49,0x0c,0xc6,0xff,0x31,0x0c,0xc7,0xff,0x19,0x0c,0xc9,0xff,0x01,0x0c,0xca,0xff,0xe9,0x0b,0xcb,0xff,0xd1,0x0b,0xcc,0xff,0xb9,0x0b,0xce,0xff,0xa1,0x0b,0xcf,0xff,0x8a,0x0b,0xd0,0xff,0x72,0x0b,0xd2,0xff,0x5b,0x0b,0xd3,0xff,0x44,0x0b,0xd4,0xff,0x2c,0x0b,0xd6,0xff,0x16,0x0b,0xd7,0xff,0xff,0x0a,0xd8,0xff,0xe8,0x0a,0xda,0xff,0xd1,0x0a,0xdb,0xff,0xbb,0x0a,0xdd,0xff,0xa4,0x0a,0xde,0xff,  \
    0x8e,0x0a,0xdf,0xff,0x78,0x0a,0xe1,0xff,0x62,0x0a,0xe2,0xff,0x4c,0x0a,0xe4,0xff,0x36,0x0a,0xe5,0xff,0x20,0x0a,0xe6,0xff,0x0a,0x0a,0xe8,0xff,0xf5,0x09,0xe9,0xff,0xdf,0x09,0xeb,0xff,0xca,0x09,0xec,0xff,0xb5,0x09,0xee,0xff,0x9f,0x09,0xef,0xff,0x8a,0x09,0xf0,0xff,0x75,0x09,0xf2,0xff,0x61,0x09,0xf3,0xff,0x4c,0x09,0xf5,0xff,0x37,0x09,0xf6,0xff,0x23,0x09,0xf8,0xff,0x0e,0x09,0xf9,0xff,0xfa,0x08,0xfb,0xff,0xe6,0x08,0xfc,0xff,0xd2,0x08,0xfe,0xff,0xbe,0x08,  \
    0xff,0xff,0xaa,0x08,0x01,0x00,0x96,0x08,0x02,0x00,0x82,0x08,0x04,0x00,0x6f,0x08,0x05,0x00,0x5b,0x08,0x06,0x00,0x48,0x08,0x08,0x00,0x34,0x08,0x09,0x00,0x21,0x08,0x0b,0x00,0x0e,0x08,0x0c,0x00,0xfb,0x07,0x0e,0x00,0xe8,0x07,0x0f,0x00,0xd5,0x07,0x11,0x00,0xc3,0x07,0x12,0x00,0xb0,0x07,0x14,0x00,0x9e,0x07,0x15,0x00,0x8b,0x07,0x17,0x00,0x79,0x07,0x18,0x00,0x67,0x07,0x19,0x00,0x55,0x07,0x1b,0x00,0x43,0x07,0x1c,0x00,0x31,0x07,0x1e,0x00,0x1f,0x07,0x1f,0x00,  \
    0x0d,0x07,0x21,0x00,0xfb,0x06,0x22,0x00,0xea,0x06,0x24,0x00,0xd8,0x06,0x25,0x00,0xc7,0x06,0x26,0x00,0xb6,0x06,0x28,0x00,0xa5,0x06,0x29,0x00,0x94,0x06,0x2b,0x00,0x82,0x06,0x2c,0x00,0x72,0x06,0x2e,0x00,0x61,0x06,0x2f,0x00,0x50,0x06,0x30,0x00,0x3f,0x06,0x32,0x00,0x2f,0x06,0x33,0x00,0x1e,0x06,0x34,0x00,0x0e,0x06,0x36,0x00,0xfe,0x05,0x37,0x00,0xed,0x05,0x39,0x00,0xdd,0x05,0x3a,0x00,0xcd,0x05,0x3b,0x00,0xbd,0x05,0x3d,0x00,0xad,0x05,0x3e,0x00,0x9d,0x05,  \
    0x3f,0x00,0x8e,0x05,0x41,0x00,0x7e,0x05,0x42,0x00,0x6e,0x05,0x43,0x00,0x5f,0x05,0x44,0x00,0x4f,0x05,0x46,0x00,0x40,0x05,0x47,0x00,0x31,0x05,0x48,0x00,0x21,0x05,0x4a,0x00,0x12,0x05,0x4b,0x00,0x03,0x05,0x4c,0x00,0xf4,0x04,0x4d,0x00,0xe5,0x04,0x4f,0x00,0xd7,0x04,0x50,0x00,0xc8,0x04,0x51,0x00,0xb9,0x04,0x52,0x00,0xaa,0x04,0x53,0x00,0x9c,0x04,0x55,0x00,0x8d,0x04,0x56,0x00,0x7f,0x04,0x57,0x00,0x71,0x04,0x58,0x00,0x62,0x04,0x59,0x00,0x54,0x04,0x5b,0x00,  \
    0x46,0x04,0x5c,0x00,0x38,0x04,0x5d,0x00,0x2a,0x04,0x5e,0x00,0x1c,0x04,0x5f,0x00,0x0e,0x04,0x60,0x00,0x00,0x04,0x61,0x00,0xf2,0x03,0x62,0x00,0xe5,0x03,0x63,0x00,0xd7,0x03,0x65,0x00,0xc9,0x03,0x66,0x00,0xbc,0x03,0x67,0x00,0xae,0x03,0x68,0x00,0xa1,0x03,0x69,0x00,0x94,0x03,0x6a,0x00,0x86,0x03,0x6b,0x00,0x79,0x03,0x6c,0x00,0x6c,0x03,0x6d,0x00,0x5f,0x03,0x6e,0x00,0x52,0x03,0x6f,0x00,0x45,0x03,0x70,0x00,0x38,0x03,0x71,0x00,0x2b,0x03,0x72,0x00,0x1e,0x03,  \
    0x72,0x00,0x12,0x03,0x73,0x00,0x05,0x03,0x74,0x00,0xf8,0x02,0x75,0x00,0xec,0x02,0x76,0x00,0xdf,0x02,0x77,0x00,0xd2,0x02,0x78,0x00,0xc6,0x02,0x79,0x00,0xba,0x02,0x79,0x00,0xad,0x02,0x7a,0x00,0xa1,0x02,0x7b,0x00,0x95,0x02,0x7c,0x00,0x88,0x02,0x7d,0x00,0x7c,0x02,0x7e,0x00,0x70,0x02,0x7e,0x00,0x64,0x02,0x7f,0x00,0x58,0x02,0x80,0x00,0x4c,0x02,0x81,0x00,0x40,0x02,0x81,0x00,0x34,0x02,0x82,0x00,0x28,0x02,0x83,0x00,0x1c,0x02,0x83,0x00,0x11,0x02,0x84,0x00,  \
    0x05,0x02,0x85,0x00,0xf9,0x01,0x85,0x00,0xee,0x01,0x86,0x00,0xe2,0x01,0x87,0x00,0xd6,0x01,0x87,0x00,0xcb,0x01,0x88,0x00,0xbf,0x01,0x88,0x00,0xb4,0x01,0x89,0x00,0xa8,0x01,0x8a,0x00,0x9d,0x01,0x8a,0x00,0x91,0x01,0x8b,0x00,0x86,0x01,0x8b,0x00,0x7b,0x01,0x8c,0x00,0x6f,0x01,0x8c,0x00,0x64,0x01,0x8d,0x00,0x59,0x01,0x8d,0x00,0x4e,0x01,0x8e,0x00,0x42,0x01,0x8e,0x00,0x37,0x01,0x8f,0x00,0x2c,0x01,0x8f,0x00,0x21,0x01,0x8f,0x00,0x16,0x01,0x90,0x00,0x0b,0x01,  \
    0x90,0x00,0x00,0x01,0x91,0x00,0xf5,0x00,0x91,0x00,0xea,0x00,0x91,0x00,0xdf,0x00,0x92,0x00,0xd4,0x00,0x92,0x00,0xc9,0x00,0x92,0x00,0xbe,0x00,0x93,0x00,0xb3,0x00,0x93,0x00,0xa8,0x00,0x93,0x00,0x9d,0x00,0x93,0x00,0x92,0x00,0x94,0x00,0x87,0x00,0x94,0x00,0x7c,0x00,0x94,0x00,0x71,0x00,0x94,0x00,0x67,0x00,0x94,0x00,0x5c,0x00,0x95,0x00,0x51,0x00,0x95,0x00,0x46,0x00,0x95,0x00,0x3b,0x00,0x95,0x00,0x31,0x00,0x95,0x00,0x26,0x00,0x95,0x00,0x1b,0x00,0x95,0x00,  \
    0x10,0x00,0x96,0x00,0x06,0x00,0x96,0x00,0xfb,0xff,0x96,0x00,0xf0,0xff,0x96,0x00,0xe5,0xff,0x96,0x00,0xdb,0xff,0x96,0x00,0xd0,0xff,0x96,0x00,0xc5,0xff,0x96,0x00,0xbb,0xff,0x96,0x00,0xb0,0xff,0x96,0x00,0xa5,0xff,0x96,0x00,0x9a,0xff,0x96,0x00,0x90,0xff,0x96,0x00,0x85,0xff,0x96,0x00,0x7a,0xff,0x95,0x00,0x70,0xff,0x95,0x00,0x65,0xff,0x95,0x00,0x5a,0xff,0x95,0x00,0x4f,0xff,0x95,0x00,0x45,0xff,0x95,0x00,0x3a,0xff,0x95,0x00,0x2f,0xff,0x94,0x00,0x24,0xff,  \
    0x94,0x00,0x19,0xff,0x94,0x00,0x0f,0xff,0x94,0x00,0x04,0xff,0x94,0x00,0xf9,0xfe,0x93,0x00,0xee,0xfe,0x93,0x00,0xe3,0xfe,0x93,0x00,0xd8,0xfe,0x93,0x00,0xce,0xfe,0x92,0x00,0xc3,0xfe,0x92,0x00,0xb8,0xfe,0x92,0x00,0xad,0xfe,0x91,0x00,0xa2,0xfe,0x91,0x00,0x97,0xfe,0x91,0x00,0x8c,0xfe,0x90,0x00,0x81,0xfe,0x90,0x00,0x76,0xfe,0x8f,0x00,0x6b,0xfe,0x8f,0x00,0x60,0xfe,0x8f,0x00,0x55,0xfe,0x8e,0x00,0x4a,0xfe,0x8e,0x00,0x3f,0xfe,0x8d,0x00,0x34,0xfe,0x8d,0x00,  \
    0x28,0xfe,0x8c,0x00,0x1d,0xfe,0x8c,0x00,0x12,0xfe,0x8b,0x00,0x07,0xfe,0x8b,0x00,0xfc,0xfd,0x8a,0x00,0xf0,0xfd,0x8a,0x00,0xe5,0xfd,0x89,0x00,0xda,0xfd,0x89,0x00,0xce,0xfd,0x88,0x00,0xc3,0xfd,0x87,0x00,0xb7,0xfd,0x87,0x00,0xac,0xfd,0x86,0x00,0xa0,0xfd,0x85,0x00,0x95,0xfd,0x85,0x00,0x89,0xfd,0x84,0x00,0x7e,0xfd,0x83,0x00,0x72,0xfd,0x83,0x00,0x66,0xfd,0x82,0x00,0x5b,0xfd,0x81,0x00,0x4f,0xfd,0x81,0x00,0x43,0xfd,0x80,0x00,0x37,0xfd,0x7f,0x00,0x2b,0xfd,  \
    0x7e,0x00,0x1f,0xfd,0x7e,0x00,0x13,0xfd,0x7d,0x00,0x07,0xfd,0x7c,0x00,0xfb,0xfc,0x7b,0x00,0xef,0xfc,0x7b,0x00,0xe3,0xfc,0x7a,0x00,0xd7,0xfc,0x79,0x00,0xca,0xfc,0x78,0x00,0xbe,0xfc,0x77,0x00,0xb2,0xfc,0x76,0x00,0xa5,0xfc,0x75,0x00,0x99,0xfc,0x75,0x00,0x8c,0xfc,0x74,0x00,0x80,0xfc,0x73,0x00,0x73,0xfc,0x72,0x00,0x66,0xfc,0x71,0x00,0x5a,0xfc,0x70,0x00,0x4d,0xfc,0x6f,0x00,0x40,0xfc,0x6e,0x00,0x33,0xfc,0x6d,0x00,0x26,0xfc,0x6c,0x00,0x19,0xfc,0x6b,0x00,  \
    0x0c,0xfc,0x6a,0x00,0xff,0xfb,0x69,0x00,0xf2,0xfb,0x68,0x00,0xe5,0xfb,0x67,0x00,0xd7,0xfb,0x66,0x00,0xca,0xfb,0x65,0x00,0xbd,0xfb,0x64,0x00,0xaf,0xfb,0x63,0x00,0xa2,0xfb,0x62,0x00,0x94,0xfb,0x61,0x00,0x87,0xfb,0x60,0x00,0x79,0xfb,0x5f,0x00,0x6b,0xfb,0x5d,0x00,0x5d,0xfb,0x5c,0x00,0x4f,0xfb,0x5b,0x00,0x42,0xfb,0x5a,0x00,0x34,0xfb,0x59,0x00,0x25,0xfb,0x58,0x00,0x17,0xfb,0x57,0x00,0x09,0xfb,0x55,0x00,0xfb,0xfa,0x54,0x00,0xec,0xfa,0x53,0x00,0xde,0xfa,  \
    0x52,0x00,0xcf,0xfa,0x51,0x00,0xc1,0xfa,0x4f,0x00,0xb2,0xfa,0x4e,0x00,0xa4,0xfa,0x4d,0x00,0x95,0xfa,0x4c,0x00,0x86,0xfa,0x4a,0x00,0x77,0xfa,0x49,0x00,0x68,0xfa,0x48,0x00,0x59,0xfa,0x47,0x00,0x4a,0xfa,0x45,0x00,0x3a,0xfa,0x44,0x00,0x2b,0xfa,0x43,0x00,0x1c,0xfa,0x41,0x00,0x0c,0xfa,0x40,0x00,0xfd,0xf9,0x3f,0x00,0xed,0xf9,0x3e,0x00,0xdd,0xf9,0x3c,0x00,0xcd,0xf9,0x3b,0x00,0xbe,0xf9,0x3a,0x00,0xae,0xf9,0x38,0x00,0x9e,0xf9,0x37,0x00,0x8d,0xf9,0x36,0x00,  \
    0x7d,0xf9,0x34,0x00,0x6d,0xf9,0x33,0x00,0x5c,0xf9,0x31,0x00,0x4c,0xf9,0x30,0x00,0x3b,0xf9,0x2f,0x00,0x2b,0xf9,0x2d,0x00,0x1a,0xf9,0x2c,0x00,0x09,0xf9,0x2b,0x00,0xf8,0xf8,0x29,0x00,0xe7,0xf8,0x28,0x00,0xd6,0xf8,0x26,0x00,0xc5,0xf8,0x25,0x00,0xb4,0xf8,0x24,0x00,0xa2,0xf8,0x22,0x00,0x91,0xf8,0x21,0x00,0x7f,0xf8,0x1f,0x00,0x6e,0xf8,0x1e,0x00,0x5c,0xf8,0x1c,0x00,0x4a,0xf8,0x1b,0x00,0x38,0xf8,0x1a,0x00,0x26,0xf8,0x18,0x00,0x14,0xf8,0x17,0x00,0x02,0xf8,  \
    0x15,0x00,0xef,0xf7,0x14,0x00,0xdd,0xf7,0x12,0x00,0xca,0xf7,0x11,0x00,0xb8,0xf7,0x0f,0x00,0xa5,0xf7,0x0e,0x00,0x92,0xf7,0x0d,0x00,0x7f,0xf7,0x0b,0x00,0x6c,0xf7,0x0a,0x00,0x59,0xf7,0x08,0x00,0x46,0xf7,0x07,0x00,0x32,0xf7,0x05,0x00,0x1f,0xf7,0x04,0x00,0x0b,0xf7,0x02,0x00,0xf8,0xf6,0x01,0x00,0xe4,0xf6,0x00,0x00,0xd0,0xf6,0xfe,0xff,0xbc,0xf6,0xfd,0xff,0xa8,0xf6,0xfb,0xff,0x94,0xf6,0xfa,0xff,0x80,0xf6,0xf8,0xff,0x6b,0xf6,0xf7,0xff,0x57,0xf6,0xf6,0xff,  \
    0x42,0xf6,0xf4,0xff,0x2d,0xf6,0xf3,0xff,0x18,0xf6,0xf1,0xff,0x04,0xf6,0xf0,0xff,0xee,0xf5,0xee,0xff,0xd9,0xf5,0xed,0xff,0xc4,0xf5,0xec,0xff,0xaf,0xf5,0xea,0xff,0x99,0xf5,0xe9,0xff,0x83,0xf5,0xe8,0xff,0x6e,0xf5,0xe6,0xff,0x58,0xf5,0xe5,0xff,0x42,0xf5,0xe3,0xff,0x2c,0xf5,0xe2,0xff,0x16,0xf5,0xe1,0xff,0xff,0xf4,0xdf,0xff,0xe9,0xf4,0xde,0xff,0xd2,0xf4,0xdd,0xff,0xbc,0xf4,0xdb,0xff,0xa5,0xf4,0xda,0xff,0x8e,0xf4,0xd9,0xff,0x77,0xf4,0xd7,0xff,0x60,0xf4,  \
    0xd6,0xff,0x49,0xf4,0xd5,0xff,0x31,0xf4,0xd4,0xff,0x1a,0xf4,0xd2,0xff,0x02,0xf4,0xd1,0xff,0xea,0xf3,0xd0,0xff,0xd3,0xf3,0xcf,0xff,0xbb,0xf3,0xcd,0xff,0xa3,0xf3,0xcc,0xff,0x8a,0xf3,0xcb,0xff,0x72,0xf3,0xca,0xff,0x5a,0xf3,0xc9,0xff,0x41,0xf3,0xc8,0xff,0x28,0xf3,0xc6,0xff,0x0f,0xf3,0xc5,0xff,0xf7,0xf2,0xc4,0xff,0xdd,0xf2,0xc3,0xff,0xc4,0xf2,0xc2,0xff,0xab,0xf2,0xc1,0xff,0x91,0xf2,0xc0,0xff,0x78,0xf2,0xbf,0xff,0x5e,0xf2,0xbe,0xff,0x44,0xf2,0xbd,0xff,  \
    0x2a,0xf2,0xbc,0xff,0x10,0xf2,0xbb,0xff,0xf6,0xf1,0xba,0xff,0xdc,0xf1,0xb9,0xff,0xc1,0xf1,0xb8,0xff,0xa7,0xf1,0xb7,0xff,0x8c,0xf1,0xb6,0xff,0x71,0xf1,0xb5,0xff,0x56,0xf1,0xb4,0xff,0x3b,0xf1,0xb4,0xff,0x20,0xf1,0xb3,0xff,0x05,0xf1,0xb2,0xff,0xe9,0xf0,0xb1,0xff,0xce,0xf0,0xb1,0xff,0xb2,0xf0,0xb0,0xff,0x96,0xf0,0xaf,0xff,0x7a,0xf0,0xae,0xff,0x5e,0xf0,0xae,0xff,0x42,0xf0,0xad,0xff,0x25,0xf0,0xac,0xff,0x09,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x94,0xff,0x08,0x10,0x95,0xff,0xeb,0x0f,0x95,0xff,0xce,0x0f,0x96,0xff,0xb2,0x0f,0x97,0xff,0x96,0x0f,0x98,0xff,0x7a,0x0f,0x98,0xff,0x5d,0x0f,0x99,0xff,0x42,0x0f,0x9a,0xff,0x26,0x0f,0x9b,0xff,  \
    0x0a,0x0f,0x9c,0xff,0xee,0x0e,0x9d,0xff,0xd3,0x0e,0x9e,0xff,0xb8,0x0e,0x9f,0xff,0x9c,0x0e,0xa0,0xff,0x81,0x0e,0xa1,0xff,0x66,0x0e,0xa2,0xff,0x4b,0x0e,0xa3,0xff,0x31,0x0e,0xa4,0xff,0x16,0x0e,0xa5,0xff,0xfb,0x0d,0xa6,0xff,0xe1,0x0d,0xa7,0xff,0xc7,0x0d,0xa8,0xff,0xad,0x0d,0xa9,0xff,0x93,0x0d,0xaa,0xff,0x79,0x0d,0xab,0xff,0x5f,0x0d,0xad,0xff,0x45,0x0d,0xae,0xff,0x2c,0x0d,0xaf,0xff,0x12,0x0d,0xb0,0xff,0xf9,0x0c,0xb2,0xff,0xe0,0x0c,0xb3,0xff,0xc6,0x0c,  \
    0xb4,0xff,0xad,0x0c,0xb5,0xff,0x95,0x0c,0xb7,0xff,0x7c,0x0c,0xb8,0xff,0x63,0x0c,0xb9,0xff,0x4b,0x0c,0xbb,0xff,0x32,0x0c,0xbc,0xff,0x1a,0x0c,0xbd,0xff,0x02,0x0c,0xbf,0xff,0xea,0x0b,0xc0,0xff,0xd2,0x0b,0xc1,0xff,0xba,0x0b,0xc3,0xff,0xa2,0x0b,0xc4,0xff,0x8b,0x0b,0xc6,0xff,0x73,0x0b,0xc7,0xff,0x5c,0x0b,0xc9,0xff,0x45,0x0b,0xca,0xff,0x2e,0x0b,0xcb,0xff,0x17,0x0b,0xcd,0xff,0x00,0x0b,0xce,0xff,0xe9,0x0a,0xd0,0xff,0xd3,0x0a,0xd1,0xff,0xbc,0x0a,0xd3,0xff,  \
    0xa6,0x0a,0xd4,0xff,0x8f,0x0a,0xd6,0xff,0x79,0x0a,0xd8,0xff,0x63,0x0a,0xd9,0xff,0x4d,0x0a,0xdb,0xff,0x37,0x0a,0xdc,0xff,0x21,0x0a,0xde,0xff,0x0c,0x0a,0xdf,0xff,0xf6,0x09,0xe1,0xff,0xe1,0x09,0xe2,0xff,0xcb,0x09,0xe4,0xff,0xb6,0x09,0xe5,0xff,0xa1,0x09,0xe7,0xff,0x8c,0x09,0xe9,0xff,0x77,0x09,0xea,0xff,0x62,0x09,0xec,0xff,0x4d,0x09,0xed,0xff,0x39,0x09,0xef,0xff,0x24,0x09,0xf0,0xff,0x10,0x09,0xf2,0xff,0xfc,0x08,0xf4,0xff,0xe7,0x08,0xf5,0xff,0xd3,0x08,  \
    0xf7,0xff,0xbf,0x08,0xf8,0xff,0xab,0x08,0xfa,0xff,0x98,0x08,0xfc,0xff,0x84,0x08,0xfd,0xff,0x70,0x08,0xff,0xff,0x5d,0x08,0x00,0x00,0x49,0x08,0x02,0x00,0x36,0x08,0x03,0x00,0x23,0x08,0x05,0x00,0x10,0x08,0x07,0x00,0xfd,0x07,0x08,0x00,0xea,0x07,0x0a,0x00,0xd7,0x07,0x0b,0x00,0xc4,0x07,0x0d,0x00,0xb2,0x07,0x0f,0x00,0x9f,0x07,0x10,0x00,0x8d,0x07,0x12,0x00,0x7b,0x07,0x13,0x00,0x68,0x07,0x15,0x00,0x56,0x07,0x16,0x00,0x44,0x07,0x18,0x00,0x32,0x07,0x1a,0x00,  \
    0x21,0x07,0x1b,0x00,0x0f,0x07,0x1d,0x00,0xfd,0x06,0x1e,0x00,0xec,0x06,0x20,0x00,0xda,0x06,0x21,0x00,0xc9,0x06,0x23,0x00,0xb8,0x06,0x24,0x00,0xa6,0x06,0x26,0x00,0x95,0x06,0x27,0x00,0x84,0x06,0x29,0x00,0x73,0x06,0x2a,0x00,0x63,0x06,0x2c,0x00,0x52,0x06,0x2d,0x00,0x41,0x06,0x2f,0x00,0x31,0x06,0x30,0x00,0x20,0x06,0x32,0x00,0x10,0x06,0x33,0x00,0xff,0x05,0x35,0x00,0xef,0x05,0x36,0x00,0xdf,0x05,0x38,0x00,0xcf,0x05,0x39,0x00,0xbf,0x05,0x3b,0x00,0xaf,0x05,  \
    0x3c,0x00,0x9f,0x05,0x3e,0x00,0x8f,0x05,0x3f,0x00,0x80,0x05,0x40,0x00,0x70,0x05,0x42,0x00,0x61,0x05,0x43,0x00,0x51,0x05,0x45,0x00,0x42,0x05,0x46,0x00,0x33,0x05,0x47,0x00,0x23,0x05,0x49,0x00,0x14,0x05,0x4a,0x00,0x05,0x05,0x4b,0x00,0xf6,0x04,0x4d,0x00,0xe7,0x04,0x4e,0x00,0xd8,0x04,0x4f,0x00,0xca,0x04,0x51,0x00,0xbb,0x04,0x52,0x00,0xac,0x04,0x53,0x00,0x9e,0x04,0x55,0x00,0x8f,0x04,0x56,0x00,0x81,0x04,0x57,0x00,0x72,0x04,0x58,0x00,0x64,0x04,0x5a,0x00,  \
    0x56,0x04,0x5b,0x00,0x48,0x04,0x5c,0x00,0x39,0x04,0x5d,0x00,0x2b,0x04,0x5f,0x00,0x1d,0x04,0x60,0x00,0x10,0x04,0x61,0x00,0x02,0x04,0x62,0x00,0xf4,0x03,0x63,0x00,0xe6,0x03,0x65,0x00,0xd9,0x03,0x66,0x00,0xcb,0x03,0x67,0x00,0xbd,0x03,0x68,0x00,0xb0,0x03,0x69,0x00,0xa3,0x03,0x6a,0x00,0x95,0x03,0x6b,0x00,0x88,0x03,0x6c,0x00,0x7b,0x03,0x6d,0x00,0x6e,0x03,0x6f,0x00,0x60,0x03,0x70,0x00,0x53,0x03,0x71,0x00,0x46,0x03,0x72,0x00,0x39,0x03,0x73,0x00,0x2d,0x03,  \
    0x74,0x00,0x20,0x03,0x75,0x00,0x13,0x03,0x76,0x00,0x06,0x03,0x77,0x00,0xfa,0x02,0x78,0x00,0xed,0x02,0x79,0x00,0xe0,0x02,0x79,0x00,0xd4,0x02,0x7a,0x00,0xc7,0x02,0x7b,0x00,0xbb,0x02,0x7c,0x00,0xaf,0x02,0x7d,0x00,0xa2,0x02,0x7e,0x00,0x96,0x02,0x7f,0x00,0x8a,0x02,0x80,0x00,0x7e,0x02,0x81,0x00,0x71,0x02,0x81,0x00,0x65,0x02,0x82,0x00,0x59,0x02,0x83,0x00,0x4d,0x02,0x84,0x00,0x41,0x02,0x85,0x00,0x35,0x02,0x85,0x00,0x29,0x02,0x86,0x00,0x1e,0x02,0x87,0x00,  \
    0x12,0x02,0x88,0x00,0x06,0x02,0x88,0x00,0xfa,0x01,0x89,0x00,0xef,0x01,0x8a,0x00,0xe3,0x01,0x8a,0x00,0xd7,0x01,0x8b,0x00,0xcc,0x01,0x8c,0x00,0xc0,0x01,0x8c,0x00,0xb5,0x01,0x8d,0x00,0xa9,0x01,0x8e,0x00,0x9e,0x01,0x8e,0x00,0x92,0x01,0x8f,0x00,0x87,0x01,0x8f,0x00,0x7c,0x01,0x90,0x00,0x70,0x01,0x90,0x00,0x65,0x01,0x91,0x00,0x5a,0x01,0x91,0x00,0x4e,0x01,0x92,0x00,0x43,0x01,0x92,0x00,0x38,0x01,0x93,0x00,0x2d,0x01,0x93,0x00,0x22,0x01,0x94,0x00,0x16,0x01,  \
    0x94,0x00,0x0b,0x01,0x95,0x00,0x00,0x01,0x95,0x00,0xf5,0x00,0x95,0x00,0xea,0x00,0x96,0x00,0xdf,0x00,0x96,0x00,0xd4,0x00,0x97,0x00,0xc9,0x00,0x97,0x00,0xbe,0x00,0x97,0x00,0xb3,0x00,0x97,0x00,0xa8,0x00,0x98,0x00,0x9d,0x00,0x98,0x00,0x92,0x00,0x98,0x00,0x88,0x00,0x99,0x00,0x7d,0x00,0x99,0x00,0x72,0x00,0x99,0x00,0x67,0x00,0x99,0x00,0x5c,0x00,0x99,0x00,0x51,0x00,0x9a,0x00,0x47,0x00,0x9a,0x00,0x3c,0x00,0x9a,0x00,0x31,0x00,0x9a,0x00,0x26,0x00,0x9a,0x00,  \
    0x1b,0x00,0x9a,0x00,0x11,0x00,0x9a,0x00,0x06,0x00,0x9b,0x00,0xfb,0xff,0x9b,0x00,0xf0,0xff,0x9b,0x00,0xe6,0xff,0x9b,0x00,0xdb,0xff,0x9b,0x00,0xd0,0xff,0x9b,0x00,0xc5,0xff,0x9b,0x00,0xbb,0xff,0x9b,0x00,0xb0,0xff,0x9b,0x00,0xa5,0xff,0x9b,0x00,0x9a,0xff,0x9b,0x00,0x90,0xff,0x9a,0x00,0x85,0xff,0x9a,0x00,0x7a,0xff,0x9a,0x00,0x6f,0xff,0x9a,0x00,0x65,0xff,0x9a,0x00,0x5a,0xff,0x9a,0x00,0x4f,0xff,0x9a,0x00,0x44,0xff,0x9a,0x00,0x39,0xff,0x99,0x00,0x2f,0xff,  \
    0x99,0x00,0x24,0xff,0x99,0x00,0x19,0xff,0x99,0x00,0x0e,0xff,0x99,0x00,0x03,0xff,0x98,0x00,0xf9,0xfe,0x98,0x00,0xee,0xfe,0x98,0x00,0xe3,0xfe,0x97,0x00,0xd8,0xfe,0x97,0x00,0xcd,0xfe,0x97,0x00,0xc2,0xfe,0x97,0x00,0xb7,0xfe,0x96,0x00,0xac,0xfe,0x96,0x00,0xa1,0xfe,0x95,0x00,0x96,0xfe,0x95,0x00,0x8b,0xfe,0x95,0x00,0x80,0xfe,0x94,0x00,0x75,0xfe,0x94,0x00,0x6a,0xfe,0x93,0x00,0x5f,0xfe,0x93,0x00,0x54,0xfe,0x92,0x00,0x49,0xfe,0x92,0x00,0x3e,0xfe,0x91,0x00,  \
    0x33,0xfe,0x91,0x00,0x27,0xfe,0x90,0x00,0x1c,0xfe,0x90,0x00,0x11,0xfe,0x8f,0x00,0x06,0xfe,0x8f,0x00,0xfb,0xfd,0x8e,0x00,0xef,0xfd,0x8e,0x00,0xe4,0xfd,0x8d,0x00,0xd9,0xfd,0x8c,0x00,0xcd,0xfd,0x8c,0x00,0xc2,0xfd,0x8b,0x00,0xb6,0xfd,0x8a,0x00,0xab,0xfd,0x8a,0x00,0x9f,0xfd,0x89,0x00,0x94,0xfd,0x88,0x00,0x88,0xfd,0x88,0x00,0x7d,0xfd,0x87,0x00,0x71,0xfd,0x86,0x00,0x65,0xfd,0x86,0x00,0x5a,0xfd,0x85,0x00,0x4e,0xfd,0x84,0x00,0x42,0xfd,0x83,0x00,0x36,0xfd,  \
    0x82,0x00,0x2a,0xfd,0x82,0x00,0x1e,0xfd,0x81,0x00,0x12,0xfd,0x80,0x00,0x06,0xfd,0x7f,0x00,0xfa,0xfc,0x7e,0x00,0xee,0xfc,0x7d,0x00,0xe1,0xfc,0x7d,0x00,0xd5,0xfc,0x7c,0x00,0xc9,0xfc,0x7b,0x00,0xbd,0xfc,0x7a,0x00,0xb0,0xfc,0x79,0x00,0xa4,0xfc,0x78,0x00,0x97,0xfc,0x77,0x00,0x8b,0xfc,0x76,0x00,0x7e,0xfc,0x75,0x00,0x72,0xfc,0x74,0x00,0x65,0xfc,0x73,0x00,0x58,0xfc,0x72,0x00,0x4b,0xfc,0x71,0x00,0x3e,0xfc,0x70,0x00,0x32,0xfc,0x6f,0x00,0x25,0xfc,0x6e,0x00,  \
    0x18,0xfc,0x6d,0x00,0x0b,0xfc,0x6c,0x00,0xfd,0xfb,0x6b,0x00,0xf0,0xfb,0x6a,0x00,0xe3,0xfb,0x69,0x00,0xd6,0xfb,0x67,0x00,0xc8,0xfb,0x66,0x00,0xbb,0xfb,0x65,0x00,0xae,0xfb,0x64,0x00,0xa0,0xfb,0x63,0x00,0x93,0xfb,0x62,0x00,0x85,0xfb,0x61,0x00,0x77,0xfb,0x5f,0x00,0x69,0xfb,0x5e,0x00,0x5c,0xfb,0x5d,0x00,0x4e,0xfb,0x5c,0x00,0x40,0xfb,0x5b,0x00,0x32,0xfb,0x59,0x00,0x24,0xfb,0x58,0x00,0x15,0xfb,0x57,0x00,0x07,0xfb,0x56,0x00,0xf9,0xfa,0x54,0x00,0xeb,0xfa,  \
    0x53,0x00,0xdc,0xfa,0x52,0x00,0xce,0xfa,0x50,0x00,0xbf,0xfa,0x4f,0x00,0xb0,0xfa,0x4e,0x00,0xa2,0xfa,0x4c,0x00,0x93,0xfa,0x4b,0x00,0x84,0xfa,0x4a,0x00,0x75,0xfa,0x48,0x00,0x66,0xfa,0x47,0x00,0x57,0xfa,0x46,0x00,0x48,0xfa,0x44,0x00,0x39,0xfa,0x43,0x00,0x29,0xfa,0x42,0x00,0x1a,0xfa,0x40,0x00,0x0a,0xfa,0x3f,0x00,0xfb,0xf9,0x3d,0x00,0xeb,0xf9,0x3c,0x00,0xdb,0xf9,0x3b,0x00,0xcc,0xf9,0x39,0x00,0xbc,0xf9,0x38,0x00,0xac,0xf9,0x36,0x00,0x9c,0xf9,0x35,0x00,  \
    0x8c,0xf9,0x33,0x00,0x7b,0xf9,0x32,0x00,0x6b,0xf9,0x30,0x00,0x5b,0xf9,0x2f,0x00,0x4a,0xf9,0x2d,0x00,0x3a,0xf9,0x2c,0x00,0x29,0xf9,0x2a,0x00,0x18,0xf9,0x29,0x00,0x07,0xf9,0x27,0x00,0xf6,0xf8,0x26,0x00,0xe5,0xf8,0x24,0x00,0xd4,0xf8,0x23,0x00,0xc3,0xf8,0x21,0x00,0xb2,0xf8,0x20,0x00,0xa0,0xf8,0x1e,0x00,0x8f,0xf8,0x1d,0x00,0x7d,0xf8,0x1b,0x00,0x6c,0xf8,0x1a,0x00,0x5a,0xf8,0x18,0x00,0x48,0xf8,0x17,0x00,0x36,0xf8,0x15,0x00,0x24,0xf8,0x14,0x00,0x12,0xf8,  \
    0x12,0x00,0x00,0xf8,0x11,0x00,0xed,0xf7,0x0f,0x00,0xdb,0xf7,0x0d,0x00,0xc9,0xf7,0x0c,0x00,0xb6,0xf7,0x0a,0x00,0xa3,0xf7,0x09,0x00,0x90,0xf7,0x07,0x00,0x7d,0xf7,0x06,0x00,0x6a,0xf7,0x04,0x00,0x57,0xf7,0x03,0x00,0x44,0xf7,0x01,0x00,0x31,0xf7,0xff,0xff,0x1d,0xf7,0xfe,0xff,0x0a,0xf7,0xfc,0xff,0xf6,0xf6,0xfb,0xff,0xe2,0xf6,0xf9,0xff,0xce,0xf6,0xf8,0xff,0xba,0xf6,0xf6,0xff,0xa6,0xf6,0xf5,0xff,0x92,0xf6,0xf3,0xff,0x7e,0xf6,0xf2,0xff,0x6a,0xf6,0xf0,0xff,  \
    0x55,0xf6,0xee,0xff,0x40,0xf6,0xed,0xff,0x2c,0xf6,0xeb,0xff,0x17,0xf6,0xea,0xff,0x02,0xf6,0xe8,0xff,0xed,0xf5,0xe7,0xff,0xd8,0xf5,0xe5,0xff,0xc2,0xf5,0xe4,0xff,0xad,0xf5,0xe2,0xff,0x97,0xf5,0xe1,0xff,0x82,0xf5,0xdf,0xff,0x6c,0xf5,0xde,0xff,0x56,0xf5,0xdc,0xff,0x40,0xf5,0xdb,0xff,0x2a,0xf5,0xd9,0xff,0x14,0xf5,0xd8,0xff,0xfe,0xf4,0xd7,0xff,0xe7,0xf4,0xd5,0xff,0xd1,0xf4,0xd4,0xff,0xba,0xf4,0xd2,0xff,0xa3,0xf4,0xd1,0xff,0x8c,0xf4,0xcf,0xff,0x75,0xf4,  \
    0xce,0xff,0x5e,0xf4,0xcd,0xff,0x47,0xf4,0xcb,0xff,0x30,0xf4,0xca,0xff,0x18,0xf4,0xc9,0xff,0x01,0xf4,0xc7,0xff,0xe9,0xf3,0xc6,0xff,0xd1,0xf3,0xc5,0xff,0xb9,0xf3,0xc3,0xff,0xa1,0xf3,0xc2,0xff,0x89,0xf3,0xc1,0xff,0x71,0xf3,0xbf,0xff,0x58,0xf3,0xbe,0xff,0x40,0xf3,0xbd,0xff,0x27,0xf3,0xbc,0xff,0x0e,0xf3,0xba,0xff,0xf5,0xf2,0xb9,0xff,0xdc,0xf2,0xb8,0xff,0xc3,0xf2,0xb7,0xff,0xaa,0xf2,0xb6,0xff,0x90,0xf2,0xb5,0xff,0x77,0xf2,0xb3,0xff,0x5d,0xf2,0xb2,0xff,  \
    0x43,0xf2,0xb1,0xff,0x29,0xf2,0xb0,0xff,0x0f,0xf2,0xaf,0xff,0xf5,0xf1,0xae,0xff,0xdb,0xf1,0xad,0xff,0xc0,0xf1,0xac,0xff,0xa6,0xf1,0xab,0xff,0x8b,0xf1,0xaa,0xff,0x70,0xf1,0xa9,0xff,0x55,0xf1,0xa8,0xff,0x3a,0xf1,0xa7,0xff,0x1f,0xf1,0xa6,0xff,0x03,0xf1,0xa6,0xff,0xe8,0xf0,0xa5,0xff,0xcc,0xf0,0xa4,0xff,0xb1,0xf0,0xa3,0xff,0x95,0xf0,0xa2,0xff,0x79,0xf0,0xa2,0xff,0x5d,0xf0,0xa1,0xff,0x41,0xf0,0xa0,0xff,0x24,0xf0,0x9f,0xff,0x08,0xf0,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x85,0xff,0x09,0x10,0x86,0xff,0xec,0x0f,0x87,0xff,0xd0,0x0f,0x87,0xff,0xb3,0x0f,0x88,0xff,0x97,0x0f,0x89,0xff,0x7b,0x0f,0x8a,0xff,0x5f,0x0f,0x8b,0xff,0x43,0x0f,0x8c,0xff,  \
    0x27,0x0f,0x8d,0xff,0x0b,0x0f,0x8e,0xff,0xf0,0x0e,0x8f,0xff,0xd4,0x0e,0x90,0xff,0xb9,0x0e,0x91,0xff,0x9d,0x0e,0x92,0xff,0x82,0x0e,0x93,0xff,0x67,0x0e,0x94,0xff,0x4d,0x0e,0x95,0xff,0x32,0x0e,0x96,0xff,0x17,0x0e,0x97,0xff,0xfd,0x0d,0x98,0xff,0xe2,0x0d,0x9a,0xff,0xc8,0x0d,0x9b,0xff,0xae,0x0d,0x9c,0xff,0x94,0x0d,0x9d,0xff,0x7a,0x0d,0x9e,0xff,0x60,0x0d,0xa0,0xff,0x46,0x0d,0xa1,0xff,0x2d,0x0d,0xa2,0xff,0x13,0x0d,0xa4,0xff,0xfa,0x0c,0xa5,0xff,0xe1,0x0c,  \
    0xa6,0xff,0xc8,0x0c,0xa8,0xff,0xaf,0x0c,0xa9,0xff,0x96,0x0c,0xab,0xff,0x7d,0x0c,0xac,0xff,0x65,0x0c,0xad,0xff,0x4c,0x0c,0xaf,0xff,0x34,0x0c,0xb0,0xff,0x1b,0x0c,0xb2,0xff,0x03,0x0c,0xb3,0xff,0xeb,0x0b,0xb5,0xff,0xd3,0x0b,0xb6,0xff,0xbc,0x0b,0xb8,0xff,0xa4,0x0b,0xb9,0xff,0x8c,0x0b,0xbb,0xff,0x75,0x0b,0xbc,0xff,0x5e,0x0b,0xbe,0xff,0x46,0x0b,0xbf,0xff,0x2f,0x0b,0xc1,0xff,0x18,0x0b,0xc3,0xff,0x02,0x0b,0xc4,0xff,0xeb,0x0a,0xc6,0xff,0xd4,0x0a,0xc7,0xff,  \
    0xbe,0x0a,0xc9,0xff,0xa7,0x0a,0xcb,0xff,0x91,0x0a,0xcc,0xff,0x7b,0x0a,0xce,0xff,0x65,0x0a,0xd0,0xff,0x4f,0x0a,0xd1,0xff,0x39,0x0a,0xd3,0xff,0x23,0x0a,0xd5,0xff,0x0d,0x0a,0xd6,0xff,0xf8,0x09,0xd8,0xff,0xe2,0x09,0xda,0xff,0xcd,0x09,0xdb,0xff,0xb8,0x09,0xdd,0xff,0xa3,0x09,0xdf,0xff,0x8e,0x09,0xe0,0xff,0x79,0x09,0xe2,0xff,0x64,0x09,0xe4,0xff,0x4f,0x09,0xe5,0xff,0x3b,0x09,0xe7,0xff,0x26,0x09,0xe9,0xff,0x12,0x09,0xeb,0xff,0xfd,0x08,0xec,0xff,0xe9,0x08,  \
    0xee,0xff,0xd5,0x08,0xf0,0xff,0xc1,0x08,0xf1,0xff,0xad,0x08,0xf3,0xff,0x99,0x08,0xf5,0xff,0x86,0x08,0xf6,0xff,0x72,0x08,0xf8,0xff,0x5f,0x08,0xfa,0xff,0x4b,0x08,0xfc,0xff,0x38,0x08,0xfd,0xff,0x25,0x08,0xff,0xff,0x12,0x08,0x01,0x00,0xff,0x07,0x02,0x00,0xec,0x07,0x04,0x00,0xd9,0x07,0x06,0x00,0xc6,0x07,0x08,0x00,0xb4,0x07,0x09,0x00,0xa1,0x07,0x0b,0x00,0x8f,0x07,0x0d,0x00,0x7d,0x07,0x0e,0x00,0x6a,0x07,0x10,0x00,0x58,0x07,0x12,0x00,0x46,0x07,0x13,0x00,  \
    0x34,0x07,0x15,0x00,0x23,0x07,0x17,0x00,0x11,0x07,0x18,0x00,0xff,0x06,0x1a,0x00,0xee,0x06,0x1c,0x00,0xdc,0x06,0x1d,0x00,0xcb,0x06,0x1f,0x00,0xba,0x06,0x21,0x00,0xa8,0x06,0x22,0x00,0x97,0x06,0x24,0x00,0x86,0x06,0x26,0x00,0x75,0x06,0x27,0x00,0x65,0x06,0x29,0x00,0x54,0x06,0x2a,0x00,0x43,0x06,0x2c,0x00,0x33,0x06,0x2e,0x00,0x22,0x06,0x2f,0x00,0x12,0x06,0x31,0x00,0x01,0x06,0x32,0x00,0xf1,0x05,0x34,0x00,0xe1,0x05,0x36,0x00,0xd1,0x05,0x37,0x00,0xc1,0x05,  \
    0x39,0x00,0xb1,0x05,0x3a,0x00,0xa1,0x05,0x3c,0x00,0x91,0x05,0x3d,0x00,0x82,0x05,0x3f,0x00,0x72,0x05,0x40,0x00,0x63,0x05,0x42,0x00,0x53,0x05,0x43,0x00,0x44,0x05,0x45,0x00,0x34,0x05,0x46,0x00,0x25,0x05,0x48,0x00,0x16,0x05,0x49,0x00,0x07,0x05,0x4b,0x00,0xf8,0x04,0x4c,0x00,0xe9,0x04,0x4d,0x00,0xda,0x04,0x4f,0x00,0xcc,0x04,0x50,0x00,0xbd,0x04,0x52,0x00,0xae,0x04,0x53,0x00,0xa0,0x04,0x54,0x00,0x91,0x04,0x56,0x00,0x83,0x04,0x57,0x00,0x74,0x04,0x59,0x00,  \
    0x66,0x04,0x5a,0x00,0x58,0x04,0x5b,0x00,0x49,0x04,0x5d,0x00,0x3b,0x04,0x5e,0x00,0x2d,0x04,0x5f,0x00,0x1f,0x04,0x60,0x00,0x11,0x04,0x62,0x00,0x04,0x04,0x63,0x00,0xf6,0x03,0x64,0x00,0xe8,0x03,0x66,0x00,0xda,0x03,0x67,0x00,0xcd,0x03,0x68,0x00,0xbf,0x03,0x69,0x00,0xb2,0x03,0x6a,0x00,0xa4,0x03,0x6c,0x00,0x97,0x03,0x6d,0x00,0x8a,0x03,0x6e,0x00,0x7c,0x03,0x6f,0x00,0x6f,0x03,0x70,0x00,0x62,0x03,0x71,0x00,0x55,0x03,0x72,0x00,0x48,0x03,0x74,0x00,0x3b,0x03,  \
    0x75,0x00,0x2e,0x03,0x76,0x00,0x21,0x03,0x77,0x00,0x15,0x03,0x78,0x00,0x08,0x03,0x79,0x00,0xfb,0x02,0x7a,0x00,0xee,0x02,0x7b,0x00,0xe2,0x02,0x7c,0x00,0xd5,0x02,0x7d,0x00,0xc9,0x02,0x7e,0x00,0xbc,0x02,0x7f,0x00,0xb0,0x02,0x80,0x00,0xa4,0x02,0x81,0x00,0x97,0x02,0x82,0x00,0x8b,0x02,0x83,0x00,0x7f,0x02,0x84,0x00,0x73,0x02,0x84,0x00,0x67,0x02,0x85,0x00,0x5b,0x02,0x86,0x00,0x4f,0x02,0x87,0x00,0x43,0x02,0x88,0x00,0x37,0x02,0x89,0x00,0x2b,0x02,0x89,0x00,  \
    0x1f,0x02,0x8a,0x00,0x13,0x02,0x8b,0x00,0x07,0x02,0x8c,0x00,0xfb,0x01,0x8d,0x00,0xf0,0x01,0x8d,0x00,0xe4,0x01,0x8e,0x00,0xd8,0x01,0x8f,0x00,0xcd,0x01,0x8f,0x00,0xc1,0x01,0x90,0x00,0xb6,0x01,0x91,0x00,0xaa,0x01,0x91,0x00,0x9f,0x01,0x92,0x00,0x93,0x01,0x93,0x00,0x88,0x01,0x93,0x00,0x7c,0x01,0x94,0x00,0x71,0x01,0x94,0x00,0x66,0x01,0x95,0x00,0x5b,0x01,0x96,0x00,0x4f,0x01,0x96,0x00,0x44,0x01,0x97,0x00,0x39,0x01,0x97,0x00,0x2e,0x01,0x98,0x00,0x22,0x01,  \
    0x98,0x00,0x17,0x01,0x99,0x00,0x0c,0x01,0x99,0x00,0x01,0x01,0x99,0x00,0xf6,0x00,0x9a,0x00,0xeb,0x00,0x9a,0x00,0xe0,0x00,0x9b,0x00,0xd5,0x00,0x9b,0x00,0xca,0x00,0x9b,0x00,0xbf,0x00,0x9c,0x00,0xb4,0x00,0x9c,0x00,0xa9,0x00,0x9c,0x00,0x9e,0x00,0x9d,0x00,0x93,0x00,0x9d,0x00,0x88,0x00,0x9d,0x00,0x7d,0x00,0x9d,0x00,0x72,0x00,0x9e,0x00,0x67,0x00,0x9e,0x00,0x5d,0x00,0x9e,0x00,0x52,0x00,0x9e,0x00,0x47,0x00,0x9f,0x00,0x3c,0x00,0x9f,0x00,0x31,0x00,0x9f,0x00,  \
    0x26,0x00,0x9f,0x00,0x1c,0x00,0x9f,0x00,0x11,0x00,0x9f,0x00,0x06,0x00,0x9f,0x00,0xfb,0xff,0x9f,0x00,0xf0,0xff,0x9f,0x00,0xe6,0xff,0x9f,0x00,0xdb,0xff,0xa0,0x00,0xd0,0xff,0xa0,0x00,0xc5,0xff,0xa0,0x00,0xbb,0xff,0xa0,0x00,0xb0,0xff,0x9f,0x00,0xa5,0xff,0x9f,0x00,0x9a,0xff,0x9f,0x00,0x8f,0xff,0x9f,0x00,0x85,0xff,0x9f,0x00,0x7a,0xff,0x9f,0x00,0x6f,0xff,0x9f,0x00,0x64,0xff,0x9f,0x00,0x5a,0xff,0x9f,0x00,0x4f,0xff,0x9f,0x00,0x44,0xff,0x9e,0x00,0x39,0xff,  \
    0x9e,0x00,0x2e,0xff,0x9e,0x00,0x23,0xff,0x9e,0x00,0x19,0xff,0x9d,0x00,0x0e,0xff,0x9d,0x00,0x03,0xff,0x9d,0x00,0xf8,0xfe,0x9d,0x00,0xed,0xfe,0x9c,0x00,0xe2,0xfe,0x9c,0x00,0xd7,0xfe,0x9c,0x00,0xcc,0xfe,0x9b,0x00,0xc1,0xfe,0x9b,0x00,0xb6,0xfe,0x9b,0x00,0xab,0xfe,0x9a,0x00,0xa0,0xfe,0x9a,0x00,0x95,0xfe,0x99,0x00,0x8a,0xfe,0x99,0x00,0x7f,0xfe,0x99,0x00,0x74,0xfe,0x98,0x00,0x69,0xfe,0x98,0x00,0x5e,0xfe,0x97,0x00,0x53,0xfe,0x97,0x00,0x48,0xfe,0x96,0x00,  \
    0x3d,0xfe,0x96,0x00,0x32,0xfe,0x95,0x00,0x27,0xfe,0x95,0x00,0x1b,0xfe,0x94,0x00,0x10,0xfe,0x93,0x00,0x05,0xfe,0x93,0x00,0xfa,0xfd,0x92,0x00,0xee,0xfd,0x92,0x00,0xe3,0xfd,0x91,0x00,0xd8,0xfd,0x90,0x00,0xcc,0xfd,0x90,0x00,0xc1,0xfd,0x8f,0x00,0xb5,0xfd,0x8e,0x00,0xaa,0xfd,0x8d,0x00,0x9e,0xfd,0x8d,0x00,0x93,0xfd,0x8c,0x00,0x87,0xfd,0x8b,0x00,0x7b,0xfd,0x8a,0x00,0x70,0xfd,0x8a,0x00,0x64,0xfd,0x89,0x00,0x58,0xfd,0x88,0x00,0x4c,0xfd,0x87,0x00,0x41,0xfd,  \
    0x86,0x00,0x35,0xfd,0x86,0x00,0x29,0xfd,0x85,0x00,0x1d,0xfd,0x84,0x00,0x11,0xfd,0x83,0x00,0x05,0xfd,0x82,0x00,0xf8,0xfc,0x81,0x00,0xec,0xfc,0x80,0x00,0xe0,0xfc,0x7f,0x00,0xd4,0xfc,0x7e,0x00,0xc7,0xfc,0x7d,0x00,0xbb,0xfc,0x7c,0x00,0xaf,0xfc,0x7b,0x00,0xa2,0xfc,0x7a,0x00,0x96,0xfc,0x79,0x00,0x89,0xfc,0x78,0x00,0x7d,0xfc,0x77,0x00,0x70,0xfc,0x76,0x00,0x63,0xfc,0x75,0x00,0x56,0xfc,0x74,0x00,0x4a,0xfc,0x73,0x00,0x3d,0xfc,0x72,0x00,0x30,0xfc,0x71,0x00,  \
    0x23,0xfc,0x70,0x00,0x16,0xfc,0x6f,0x00,0x09,0xfc,0x6d,0x00,0xfc,0xfb,0x6c,0x00,0xef,0xfb,0x6b,0x00,0xe1,0xfb,0x6a,0x00,0xd4,0xfb,0x69,0x00,0xc7,0xfb,0x68,0x00,0xb9,0xfb,0x66,0x00,0xac,0xfb,0x65,0x00,0x9e,0xfb,0x64,0x00,0x91,0xfb,0x63,0x00,0x83,0xfb,0x61,0x00,0x75,0xfb,0x60,0x00,0x68,0xfb,0x5f,0x00,0x5a,0xfb,0x5e,0x00,0x4c,0xfb,0x5c,0x00,0x3e,0xfb,0x5b,0x00,0x30,0xfb,0x5a,0x00,0x22,0xfb,0x58,0x00,0x14,0xfb,0x57,0x00,0x05,0xfb,0x56,0x00,0xf7,0xfa,  \
    0x54,0x00,0xe9,0xfa,0x53,0x00,0xda,0xfa,0x51,0x00,0xcc,0xfa,0x50,0x00,0xbd,0xfa,0x4f,0x00,0xae,0xfa,0x4d,0x00,0xa0,0xfa,0x4c,0x00,0x91,0xfa,0x4a,0x00,0x82,0xfa,0x49,0x00,0x73,0xfa,0x48,0x00,0x64,0xfa,0x46,0x00,0x55,0xfa,0x45,0x00,0x46,0xfa,0x43,0x00,0x37,0xfa,0x42,0x00,0x27,0xfa,0x40,0x00,0x18,0xfa,0x3f,0x00,0x08,0xfa,0x3d,0x00,0xf9,0xf9,0x3c,0x00,0xe9,0xf9,0x3a,0x00,0xd9,0xf9,0x39,0x00,0xca,0xf9,0x37,0x00,0xba,0xf9,0x36,0x00,0xaa,0xf9,0x34,0x00,  \
    0x9a,0xf9,0x33,0x00,0x8a,0xf9,0x31,0x00,0x79,0xf9,0x2f,0x00,0x69,0xf9,0x2e,0x00,0x59,0xf9,0x2c,0x00,0x48,0xf9,0x2b,0x00,0x38,0xf9,0x29,0x00,0x27,0xf9,0x28,0x00,0x16,0xf9,0x26,0x00,0x05,0xf9,0x24,0x00,0xf4,0xf8,0x23,0x00,0xe3,0xf8,0x21,0x00,0xd2,0xf8,0x1f,0x00,0xc1,0xf8,0x1e,0x00,0xb0,0xf8,0x1c,0x00,0x9e,0xf8,0x1b,0x00,0x8d,0xf8,0x19,0x00,0x7b,0xf8,0x17,0x00,0x6a,0xf8,0x16,0x00,0x58,0xf8,0x14,0x00,0x46,0xf8,0x12,0x00,0x34,0xf8,0x11,0x00,0x22,0xf8,  \
    0x0f,0x00,0x10,0xf8,0x0d,0x00,0xfe,0xf7,0x0c,0x00,0xec,0xf7,0x0a,0x00,0xd9,0xf7,0x08,0x00,0xc7,0xf7,0x07,0x00,0xb4,0xf7,0x05,0x00,0xa1,0xf7,0x03,0x00,0x8e,0xf7,0x02,0x00,0x7b,0xf7,0x00,0x00,0x68,0xf7,0xfe,0xff,0x55,0xf7,0xfd,0xff,0x42,0xf7,0xfb,0xff,0x2f,0xf7,0xf9,0xff,0x1b,0xf7,0xf8,0xff,0x08,0xf7,0xf6,0xff,0xf4,0xf6,0xf4,0xff,0xe0,0xf6,0xf3,0xff,0xcd,0xf6,0xf1,0xff,0xb9,0xf6,0xef,0xff,0xa5,0xf6,0xee,0xff,0x90,0xf6,0xec,0xff,0x7c,0xf6,0xea,0xff,  \
    0x68,0xf6,0xe9,0xff,0x53,0xf6,0xe7,0xff,0x3f,0xf6,0xe6,0xff,0x2a,0xf6,0xe4,0xff,0x15,0xf6,0xe2,0xff,0x00,0xf6,0xe1,0xff,0xeb,0xf5,0xdf,0xff,0xd6,0xf5,0xdd,0xff,0xc1,0xf5,0xdc,0xff,0xab,0xf5,0xda,0xff,0x96,0xf5,0xd9,0xff,0x80,0xf5,0xd7,0xff,0x6a,0xf5,0xd5,0xff,0x55,0xf5,0xd4,0xff,0x3f,0xf5,0xd2,0xff,0x28,0xf5,0xd1,0xff,0x12,0xf5,0xcf,0xff,0xfc,0xf4,0xce,0xff,0xe6,0xf4,0xcc,0xff,0xcf,0xf4,0xca,0xff,0xb8,0xf4,0xc9,0xff,0xa2,0xf4,0xc7,0xff,0x8b,0xf4,  \
    0xc6,0xff,0x74,0xf4,0xc4,0xff,0x5d,0xf4,0xc3,0xff,0x45,0xf4,0xc1,0xff,0x2e,0xf4,0xc0,0xff,0x17,0xf4,0xbe,0xff,0xff,0xf3,0xbd,0xff,0xe7,0xf3,0xbc,0xff,0xd0,0xf3,0xba,0xff,0xb8,0xf3,0xb9,0xff,0xa0,0xf3,0xb7,0xff,0x87,0xf3,0xb6,0xff,0x6f,0xf3,0xb5,0xff,0x57,0xf3,0xb3,0xff,0x3e,0xf3,0xb2,0xff,0x25,0xf3,0xb1,0xff,0x0d,0xf3,0xaf,0xff,0xf4,0xf2,0xae,0xff,0xdb,0xf2,0xad,0xff,0xc1,0xf2,0xab,0xff,0xa8,0xf2,0xaa,0xff,0x8f,0xf2,0xa9,0xff,0x75,0xf2,0xa8,0xff,  \
    0x5b,0xf2,0xa7,0xff,0x42,0xf2,0xa5,0xff,0x28,0xf2,0xa4,0xff,0x0e,0xf2,0xa3,0xff,0xf3,0xf1,0xa2,0xff,0xd9,0xf1,0xa1,0xff,0xbf,0xf1,0xa0,0xff,0xa4,0xf1,0x9f,0xff,0x89,0xf1,0x9e,0xff,0x6f,0xf1,0x9d,0xff,0x54,0xf1,0x9c,0xff,0x39,0xf1,0x9b,0xff,0x1d,0xf1,0x9a,0xff,0x02,0xf1,0x99,0xff,0xe7,0xf0,0x98,0xff,0xcb,0xf0,0x97,0xff,0xaf,0xf0,0x96,0xff,0x94,0xf0,0x95,0xff,0x78,0xf0,0x95,0xff,0x5c,0xf0,0x94,0xff,0x3f,0xf0,0x93,0xff,0x23,0xf0,0x92,0xff,0x07,0xf0,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x76,0xff,0x0a,0x10,0x77,0xff,0xed,0x0f,0x77,0xff,0xd1,0x0f,0x78,0xff,0xb4,0x0f,0x79,0xff,0x98,0x0f,0x7a,0xff,0x7c,0x0f,0x7b,0xff,0x60,0x0f,0x7c,0xff,  \
    0x44,0x0f,0x7d,0xff,0x28,0x0f,0x7e,0xff,0x0c,0x0f,0x7f,0xff,0xf1,0x0e,0x80,0xff,0xd5,0x0e,0x81,0xff,0xba,0x0e,0x82,0xff,0x9f,0x0e,0x83,0xff,0x84,0x0e,0x84,0xff,0x69,0x0e,0x86,0xff,0x4e,0x0e,0x87,0xff,0x33,0x0e,0x88,0xff,0x18,0x0e,0x89,0xff,0xfe,0x0d,0x8b,0xff,0xe4,0x0d,0x8c,0xff,0xc9,0x0d,0x8d,0xff,0xaf,0x0d,0x8e,0xff,0x95,0x0d,0x90,0xff,0x7b,0x0d,0x91,0xff,0x61,0x0d,0x93,0xff,0x48,0x0d,0x94,0xff,0x2e,0x0d,0x95,0xff,0x15,0x0d,0x97,0xff,0xfb,0x0c,  \
    0x98,0xff,0xe2,0x0c,0x9a,0xff,0xc9,0x0c,0x9b,0xff,0xb0,0x0c,0x9d,0xff,0x97,0x0c,0x9e,0xff,0x7f,0x0c,0xa0,0xff,0x66,0x0c,0xa1,0xff,0x4d,0x0c,0xa3,0xff,0x35,0x0c,0xa4,0xff,0x1d,0x0c,0xa6,0xff,0x05,0x0c,0xa7,0xff,0xed,0x0b,0xa9,0xff,0xd5,0x0b,0xab,0xff,0xbd,0x0b,0xac,0xff,0xa5,0x0b,0xae,0xff,0x8e,0x0b,0xb0,0xff,0x76,0x0b,0xb1,0xff,0x5f,0x0b,0xb3,0xff,0x48,0x0b,0xb5,0xff,0x31,0x0b,0xb6,0xff,0x1a,0x0b,0xb8,0xff,0x03,0x0b,0xba,0xff,0xec,0x0a,0xbc,0xff,  \
    0xd6,0x0a,0xbd,0xff,0xbf,0x0a,0xbf,0xff,0xa9,0x0a,0xc1,0xff,0x93,0x0a,0xc3,0xff,0x7d,0x0a,0xc4,0xff,0x66,0x0a,0xc6,0xff,0x50,0x0a,0xc8,0xff,0x3b,0x0a,0xca,0xff,0x25,0x0a,0xcb,0xff,0x0f,0x0a,0xcd,0xff,0xfa,0x09,0xcf,0xff,0xe4,0x09,0xd1,0xff,0xcf,0x09,0xd3,0xff,0xba,0x09,0xd4,0xff,0xa4,0x09,0xd6,0xff,0x8f,0x09,0xd8,0xff,0x7a,0x09,0xda,0xff,0x66,0x09,0xdc,0xff,0x51,0x09,0xdd,0xff,0x3c,0x09,0xdf,0xff,0x28,0x09,0xe1,0xff,0x13,0x09,0xe3,0xff,0xff,0x08,  \
    0xe5,0xff,0xeb,0x08,0xe7,0xff,0xd7,0x08,0xe8,0xff,0xc3,0x08,0xea,0xff,0xaf,0x08,0xec,0xff,0x9b,0x08,0xee,0xff,0x88,0x08,0xf0,0xff,0x74,0x08,0xf2,0xff,0x61,0x08,0xf3,0xff,0x4d,0x08,0xf5,0xff,0x3a,0x08,0xf7,0xff,0x27,0x08,0xf9,0xff,0x14,0x08,0xfb,0xff,0x01,0x08,0xfc,0xff,0xee,0x07,0xfe,0xff,0xdb,0x07,0x00,0x00,0xc8,0x07,0x02,0x00,0xb6,0x07,0x04,0x00,0xa3,0x07,0x06,0x00,0x91,0x07,0x07,0x00,0x7f,0x07,0x09,0x00,0x6c,0x07,0x0b,0x00,0x5a,0x07,0x0d,0x00,  \
    0x48,0x07,0x0f,0x00,0x36,0x07,0x10,0x00,0x25,0x07,0x12,0x00,0x13,0x07,0x14,0x00,0x01,0x07,0x16,0x00,0xf0,0x06,0x18,0x00,0xde,0x06,0x19,0x00,0xcd,0x06,0x1b,0x00,0xbc,0x06,0x1d,0x00,0xaa,0x06,0x1f,0x00,0x99,0x06,0x20,0x00,0x88,0x06,0x22,0x00,0x77,0x06,0x24,0x00,0x67,0x06,0x26,0x00,0x56,0x06,0x27,0x00,0x45,0x06,0x29,0x00,0x35,0x06,0x2b,0x00,0x24,0x06,0x2c,0x00,0x14,0x06,0x2e,0x00,0x03,0x06,0x30,0x00,0xf3,0x05,0x31,0x00,0xe3,0x05,0x33,0x00,0xd3,0x05,  \
    0x35,0x00,0xc3,0x05,0x36,0x00,0xb3,0x05,0x38,0x00,0xa3,0x05,0x3a,0x00,0x93,0x05,0x3b,0x00,0x84,0x05,0x3d,0x00,0x74,0x05,0x3f,0x00,0x65,0x05,0x40,0x00,0x55,0x05,0x42,0x00,0x46,0x05,0x43,0x00,0x37,0x05,0x45,0x00,0x27,0x05,0x47,0x00,0x18,0x05,0x48,0x00,0x09,0x05,0x4a,0x00,0xfa,0x04,0x4b,0x00,0xeb,0x04,0x4d,0x00,0xdc,0x04,0x4e,0x00,0xce,0x04,0x50,0x00,0xbf,0x04,0x51,0x00,0xb0,0x04,0x53,0x00,0xa2,0x04,0x54,0x00,0x93,0x04,0x56,0x00,0x85,0x04,0x57,0x00,  \
    0x76,0x04,0x59,0x00,0x68,0x04,0x5a,0x00,0x5a,0x04,0x5b,0x00,0x4b,0x04,0x5d,0x00,0x3d,0x04,0x5e,0x00,0x2f,0x04,0x60,0x00,0x21,0x04,0x61,0x00,0x13,0x04,0x62,0x00,0x05,0x04,0x64,0x00,0xf8,0x03,0x65,0x00,0xea,0x03,0x66,0x00,0xdc,0x03,0x68,0x00,0xcf,0x03,0x69,0x00,0xc1,0x03,0x6a,0x00,0xb4,0x03,0x6c,0x00,0xa6,0x03,0x6d,0x00,0x99,0x03,0x6e,0x00,0x8b,0x03,0x6f,0x00,0x7e,0x03,0x71,0x00,0x71,0x03,0x72,0x00,0x64,0x03,0x73,0x00,0x57,0x03,0x74,0x00,0x4a,0x03,  \
    0x75,0x00,0x3d,0x03,0x77,0x00,0x30,0x03,0x78,0x00,0x23,0x03,0x79,0x00,0x16,0x03,0x7a,0x00,0x09,0x03,0x7b,0x00,0xfd,0x02,0x7c,0x00,0xf0,0x02,0x7d,0x00,0xe3,0x02,0x7e,0x00,0xd7,0x02,0x7f,0x00,0xca,0x02,0x80,0x00,0xbe,0x02,0x81,0x00,0xb2,0x02,0x82,0x00,0xa5,0x02,0x83,0x00,0x99,0x02,0x84,0x00,0x8d,0x02,0x85,0x00,0x80,0x02,0x86,0x00,0x74,0x02,0x87,0x00,0x68,0x02,0x88,0x00,0x5c,0x02,0x89,0x00,0x50,0x02,0x8a,0x00,0x44,0x02,0x8b,0x00,0x38,0x02,0x8c,0x00,  \
    0x2c,0x02,0x8d,0x00,0x20,0x02,0x8e,0x00,0x14,0x02,0x8e,0x00,0x08,0x02,0x8f,0x00,0xfd,0x01,0x90,0x00,0xf1,0x01,0x91,0x00,0xe5,0x01,0x92,0x00,0xda,0x01,0x92,0x00,0xce,0x01,0x93,0x00,0xc2,0x01,0x94,0x00,0xb7,0x01,0x95,0x00,0xab,0x01,0x95,0x00,0xa0,0x01,0x96,0x00,0x94,0x01,0x97,0x00,0x89,0x01,0x97,0x00,0x7e,0x01,0x98,0x00,0x72,0x01,0x98,0x00,0x67,0x01,0x99,0x00,0x5b,0x01,0x9a,0x00,0x50,0x01,0x9a,0x00,0x45,0x01,0x9b,0x00,0x3a,0x01,0x9b,0x00,0x2e,0x01,  \
    0x9c,0x00,0x23,0x01,0x9c,0x00,0x18,0x01,0x9d,0x00,0x0d,0x01,0x9d,0x00,0x02,0x01,0x9e,0x00,0xf7,0x00,0x9e,0x00,0xec,0x00,0x9f,0x00,0xe0,0x00,0x9f,0x00,0xd5,0x00,0x9f,0x00,0xca,0x00,0xa0,0x00,0xbf,0x00,0xa0,0x00,0xb4,0x00,0xa1,0x00,0xa9,0x00,0xa1,0x00,0x9e,0x00,0xa1,0x00,0x93,0x00,0xa2,0x00,0x89,0x00,0xa2,0x00,0x7e,0x00,0xa2,0x00,0x73,0x00,0xa2,0x00,0x68,0x00,0xa3,0x00,0x5d,0x00,0xa3,0x00,0x52,0x00,0xa3,0x00,0x47,0x00,0xa3,0x00,0x3c,0x00,0xa3,0x00,  \
    0x31,0x00,0xa4,0x00,0x27,0x00,0xa4,0x00,0x1c,0x00,0xa4,0x00,0x11,0x00,0xa4,0x00,0x06,0x00,0xa4,0x00,0xfb,0xff,0xa4,0x00,0xf1,0xff,0xa4,0x00,0xe6,0xff,0xa4,0x00,0xdb,0xff,0xa4,0x00,0xd0,0xff,0xa4,0x00,0xc5,0xff,0xa4,0x00,0xbb,0xff,0xa4,0x00,0xb0,0xff,0xa4,0x00,0xa5,0xff,0xa4,0x00,0x9a,0xff,0xa4,0x00,0x8f,0xff,0xa4,0x00,0x85,0xff,0xa4,0x00,0x7a,0xff,0xa4,0x00,0x6f,0xff,0xa4,0x00,0x64,0xff,0xa4,0x00,0x59,0xff,0xa3,0x00,0x4e,0xff,0xa3,0x00,0x44,0xff,  \
    0xa3,0x00,0x39,0xff,0xa3,0x00,0x2e,0xff,0xa3,0x00,0x23,0xff,0xa2,0x00,0x18,0xff,0xa2,0x00,0x0d,0xff,0xa2,0x00,0x02,0xff,0xa2,0x00,0xf8,0xfe,0xa1,0x00,0xed,0xfe,0xa1,0x00,0xe2,0xfe,0xa1,0x00,0xd7,0xfe,0xa0,0x00,0xcc,0xfe,0xa0,0x00,0xc1,0xfe,0x9f,0x00,0xb6,0xfe,0x9f,0x00,0xab,0xfe,0x9f,0x00,0xa0,0xfe,0x9e,0x00,0x95,0xfe,0x9e,0x00,0x8a,0xfe,0x9d,0x00,0x7f,0xfe,0x9d,0x00,0x74,0xfe,0x9c,0x00,0x68,0xfe,0x9c,0x00,0x5d,0xfe,0x9b,0x00,0x52,0xfe,0x9b,0x00,  \
    0x47,0xfe,0x9a,0x00,0x3c,0xfe,0x9a,0x00,0x31,0xfe,0x99,0x00,0x26,0xfe,0x99,0x00,0x1a,0xfe,0x98,0x00,0x0f,0xfe,0x97,0x00,0x04,0xfe,0x97,0x00,0xf9,0xfd,0x96,0x00,0xed,0xfd,0x95,0x00,0xe2,0xfd,0x95,0x00,0xd6,0xfd,0x94,0x00,0xcb,0xfd,0x93,0x00,0xc0,0xfd,0x93,0x00,0xb4,0xfd,0x92,0x00,0xa9,0xfd,0x91,0x00,0x9d,0xfd,0x90,0x00,0x91,0xfd,0x8f,0x00,0x86,0xfd,0x8f,0x00,0x7a,0xfd,0x8e,0x00,0x6f,0xfd,0x8d,0x00,0x63,0xfd,0x8c,0x00,0x57,0xfd,0x8b,0x00,0x4b,0xfd,  \
    0x8a,0x00,0x3f,0xfd,0x8a,0x00,0x33,0xfd,0x89,0x00,0x27,0xfd,0x88,0x00,0x1b,0xfd,0x87,0x00,0x0f,0xfd,0x86,0x00,0x03,0xfd,0x85,0x00,0xf7,0xfc,0x84,0x00,0xeb,0xfc,0x83,0x00,0xdf,0xfc,0x82,0x00,0xd2,0xfc,0x81,0x00,0xc6,0xfc,0x80,0x00,0xba,0xfc,0x7f,0x00,0xad,0xfc,0x7e,0x00,0xa1,0xfc,0x7d,0x00,0x94,0xfc,0x7c,0x00,0x88,0xfc,0x7b,0x00,0x7b,0xfc,0x7a,0x00,0x6e,0xfc,0x78,0x00,0x61,0xfc,0x77,0x00,0x55,0xfc,0x76,0x00,0x48,0xfc,0x75,0x00,0x3b,0xfc,0x74,0x00,  \
    0x2e,0xfc,0x73,0x00,0x21,0xfc,0x71,0x00,0x14,0xfc,0x70,0x00,0x07,0xfc,0x6f,0x00,0xfa,0xfb,0x6e,0x00,0xed,0xfb,0x6d,0x00,0xdf,0xfb,0x6b,0x00,0xd2,0xfb,0x6a,0x00,0xc5,0xfb,0x69,0x00,0xb7,0xfb,0x67,0x00,0xaa,0xfb,0x66,0x00,0x9c,0xfb,0x65,0x00,0x8f,0xfb,0x63,0x00,0x81,0xfb,0x62,0x00,0x73,0xfb,0x61,0x00,0x66,0xfb,0x5f,0x00,0x58,0xfb,0x5e,0x00,0x4a,0xfb,0x5d,0x00,0x3c,0xfb,0x5b,0x00,0x2e,0xfb,0x5a,0x00,0x20,0xfb,0x58,0x00,0x11,0xfb,0x57,0x00,0x03,0xfb,  \
    0x56,0x00,0xf5,0xfa,0x54,0x00,0xe7,0xfa,0x53,0x00,0xd8,0xfa,0x51,0x00,0xca,0xfa,0x50,0x00,0xbb,0xfa,0x4e,0x00,0xac,0xfa,0x4d,0x00,0x9e,0xfa,0x4b,0x00,0x8f,0xfa,0x4a,0x00,0x80,0xfa,0x48,0x00,0x71,0xfa,0x47,0x00,0x62,0xfa,0x45,0x00,0x53,0xfa,0x44,0x00,0x44,0xfa,0x42,0x00,0x34,0xfa,0x40,0x00,0x25,0xfa,0x3f,0x00,0x16,0xfa,0x3d,0x00,0x06,0xfa,0x3c,0x00,0xf7,0xf9,0x3a,0x00,0xe7,0xf9,0x38,0x00,0xd7,0xf9,0x37,0x00,0xc7,0xf9,0x35,0x00,0xb8,0xf9,0x34,0x00,  \
    0xa8,0xf9,0x32,0x00,0x98,0xf9,0x30,0x00,0x87,0xf9,0x2f,0x00,0x77,0xf9,0x2d,0x00,0x67,0xf9,0x2b,0x00,0x56,0xf9,0x2a,0x00,0x46,0xf9,0x28,0x00,0x35,0xf9,0x26,0x00,0x25,0xf9,0x24,0x00,0x14,0xf9,0x23,0x00,0x03,0xf9,0x21,0x00,0xf2,0xf8,0x1f,0x00,0xe1,0xf8,0x1e,0x00,0xd0,0xf8,0x1c,0x00,0xbf,0xf8,0x1a,0x00,0xae,0xf8,0x18,0x00,0x9c,0xf8,0x17,0x00,0x8b,0xf8,0x15,0x00,0x79,0xf8,0x13,0x00,0x68,0xf8,0x11,0x00,0x56,0xf8,0x10,0x00,0x44,0xf8,0x0e,0x00,0x32,0xf8,  \
    0x0c,0x00,0x20,0xf8,0x0a,0x00,0x0e,0xf8,0x09,0x00,0xfc,0xf7,0x07,0x00,0xe9,0xf7,0x05,0x00,0xd7,0xf7,0x03,0x00,0xc5,0xf7,0x02,0x00,0xb2,0xf7,0x00,0x00,0x9f,0xf7,0xfe,0xff,0x8c,0xf7,0xfc,0xff,0x79,0xf7,0xfa,0xff,0x66,0xf7,0xf9,0xff,0x53,0xf7,0xf7,0xff,0x40,0xf7,0xf5,0xff,0x2d,0xf7,0xf3,0xff,0x19,0xf7,0xf1,0xff,0x06,0xf7,0xf0,0xff,0xf2,0xf6,0xee,0xff,0xde,0xf6,0xec,0xff,0xcb,0xf6,0xea,0xff,0xb7,0xf6,0xe9,0xff,0xa3,0xf6,0xe7,0xff,0x8e,0xf6,0xe5,0xff,  \
    0x7a,0xf6,0xe3,0xff,0x66,0xf6,0xe2,0xff,0x51,0xf6,0xe0,0xff,0x3d,0xf6,0xde,0xff,0x28,0xf6,0xdc,0xff,0x13,0xf6,0xdb,0xff,0xfe,0xf5,0xd9,0xff,0xe9,0xf5,0xd7,0xff,0xd4,0xf5,0xd5,0xff,0xbf,0xf5,0xd4,0xff,0xa9,0xf5,0xd2,0xff,0x94,0xf5,0xd0,0xff,0x7e,0xf5,0xce,0xff,0x69,0xf5,0xcd,0xff,0x53,0xf5,0xcb,0xff,0x3d,0xf5,0xc9,0xff,0x27,0xf5,0xc8,0xff,0x11,0xf5,0xc6,0xff,0xfa,0xf4,0xc4,0xff,0xe4,0xf4,0xc3,0xff,0xcd,0xf4,0xc1,0xff,0xb7,0xf4,0xbf,0xff,0xa0,0xf4,  \
    0xbe,0xff,0x89,0xf4,0xbc,0xff,0x72,0xf4,0xbb,0xff,0x5b,0xf4,0xb9,0xff,0x44,0xf4,0xb7,0xff,0x2c,0xf4,0xb6,0xff,0x15,0xf4,0xb4,0xff,0xfd,0xf3,0xb3,0xff,0xe6,0xf3,0xb1,0xff,0xce,0xf3,0xb0,0xff,0xb6,0xf3,0xae,0xff,0x9e,0xf3,0xad,0xff,0x86,0xf3,0xab,0xff,0x6d,0xf3,0xaa,0xff,0x55,0xf3,0xa8,0xff,0x3c,0xf3,0xa7,0xff,0x24,0xf3,0xa5,0xff,0x0b,0xf3,0xa4,0xff,0xf2,0xf2,0xa3,0xff,0xd9,0xf2,0xa1,0xff,0xc0,0xf2,0xa0,0xff,0xa7,0xf2,0x9e,0xff,0x8d,0xf2,0x9d,0xff,  \
    0x74,0xf2,0x9c,0xff,0x5a,0xf2,0x9b,0xff,0x40,0xf2,0x99,0xff,0x26,0xf2,0x98,0xff,0x0c,0xf2,0x97,0xff,0xf2,0xf1,0x96,0xff,0xd8,0xf1,0x95,0xff,0xbd,0xf1,0x93,0xff,0xa3,0xf1,0x92,0xff,0x88,0xf1,0x91,0xff,0x6d,0xf1,0x90,0xff,0x52,0xf1,0x8f,0xff,0x37,0xf1,0x8e,0xff,0x1c,0xf1,0x8d,0xff,0x01,0xf1,0x8c,0xff,0xe5,0xf0,0x8b,0xff,0xca,0xf0,0x8a,0xff,0xae,0xf0,0x89,0xff,0x92,0xf0,0x88,0xff,0x76,0xf0,0x87,0xff,0x5a,0xf0,0x86,0xff,0x3e,0xf0,0x86,0xff,0x22,0xf0,  \
    0x85,0xff,0x05,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x68,0xff,0x0b,0x10,0x69,0xff,0xef,0x0f,0x6a,0xff,0xd2,0x0f,0x6b,0xff,0xb6,0x0f,0x6c,0xff,0x99,0x0f,0x6d,0xff,0x7d,0x0f,0x6e,0xff,  \
    0x61,0x0f,0x6f,0xff,0x45,0x0f,0x70,0xff,0x29,0x0f,0x71,0xff,0x0e,0x0f,0x72,0xff,0xf2,0x0e,0x73,0xff,0xd7,0x0e,0x74,0xff,0xbb,0x0e,0x75,0xff,0xa0,0x0e,0x77,0xff,0x85,0x0e,0x78,0xff,0x6a,0x0e,0x79,0xff,0x4f,0x0e,0x7a,0xff,0x34,0x0e,0x7c,0xff,0x1a,0x0e,0x7d,0xff,0xff,0x0d,0x7e,0xff,0xe5,0x0d,0x80,0xff,0xcb,0x0d,0x81,0xff,0xb1,0x0d,0x82,0xff,0x97,0x0d,0x84,0xff,0x7d,0x0d,0x85,0xff,0x63,0x0d,0x87,0xff,0x49,0x0d,0x88,0xff,0x30,0x0d,0x8a,0xff,0x16,0x0d,  \
    0x8b,0xff,0xfd,0x0c,0x8d,0xff,0xe4,0x0c,0x8e,0xff,0xcb,0x0c,0x90,0xff,0xb2,0x0c,0x91,0xff,0x99,0x0c,0x93,0xff,0x80,0x0c,0x95,0xff,0x67,0x0c,0x96,0xff,0x4f,0x0c,0x98,0xff,0x37,0x0c,0x9a,0xff,0x1e,0x0c,0x9b,0xff,0x06,0x0c,0x9d,0xff,0xee,0x0b,0x9f,0xff,0xd6,0x0b,0xa0,0xff,0xbf,0x0b,0xa2,0xff,0xa7,0x0b,0xa4,0xff,0x8f,0x0b,0xa6,0xff,0x78,0x0b,0xa7,0xff,0x61,0x0b,0xa9,0xff,0x4a,0x0b,0xab,0xff,0x33,0x0b,0xad,0xff,0x1c,0x0b,0xaf,0xff,0x05,0x0b,0xb0,0xff,  \
    0xee,0x0a,0xb2,0xff,0xd8,0x0a,0xb4,0xff,0xc1,0x0a,0xb6,0xff,0xab,0x0a,0xb8,0xff,0x95,0x0a,0xba,0xff,0x7e,0x0a,0xbc,0xff,0x68,0x0a,0xbd,0xff,0x52,0x0a,0xbf,0xff,0x3c,0x0a,0xc1,0xff,0x27,0x0a,0xc3,0xff,0x11,0x0a,0xc5,0xff,0xfb,0x09,0xc7,0xff,0xe6,0x09,0xc9,0xff,0xd1,0x09,0xcb,0xff,0xbb,0x09,0xcd,0xff,0xa6,0x09,0xcf,0xff,0x91,0x09,0xd0,0xff,0x7c,0x09,0xd2,0xff,0x68,0x09,0xd4,0xff,0x53,0x09,0xd6,0xff,0x3e,0x09,0xd8,0xff,0x2a,0x09,0xda,0xff,0x15,0x09,  \
    0xdc,0xff,0x01,0x09,0xde,0xff,0xed,0x08,0xe0,0xff,0xd9,0x08,0xe2,0xff,0xc5,0x08,0xe4,0xff,0xb1,0x08,0xe6,0xff,0x9d,0x08,0xe8,0xff,0x8a,0x08,0xea,0xff,0x76,0x08,0xec,0xff,0x63,0x08,0xee,0xff,0x4f,0x08,0xef,0xff,0x3c,0x08,0xf1,0xff,0x29,0x08,0xf3,0xff,0x16,0x08,0xf5,0xff,0x03,0x08,0xf7,0xff,0xf0,0x07,0xf9,0xff,0xdd,0x07,0xfb,0xff,0xca,0x07,0xfd,0xff,0xb8,0x07,0xff,0xff,0xa5,0x07,0x01,0x00,0x93,0x07,0x03,0x00,0x81,0x07,0x05,0x00,0x6e,0x07,0x07,0x00,  \
    0x5c,0x07,0x09,0x00,0x4a,0x07,0x0a,0x00,0x39,0x07,0x0c,0x00,0x27,0x07,0x0e,0x00,0x15,0x07,0x10,0x00,0x03,0x07,0x12,0x00,0xf2,0x06,0x14,0x00,0xe0,0x06,0x16,0x00,0xcf,0x06,0x18,0x00,0xbe,0x06,0x1a,0x00,0xad,0x06,0x1b,0x00,0x9c,0x06,0x1d,0x00,0x8b,0x06,0x1f,0x00,0x7a,0x06,0x21,0x00,0x69,0x06,0x23,0x00,0x58,0x06,0x25,0x00,0x47,0x06,0x26,0x00,0x37,0x06,0x28,0x00,0x26,0x06,0x2a,0x00,0x16,0x06,0x2c,0x00,0x06,0x06,0x2e,0x00,0xf5,0x05,0x2f,0x00,0xe5,0x05,  \
    0x31,0x00,0xd5,0x05,0x33,0x00,0xc5,0x05,0x35,0x00,0xb5,0x05,0x36,0x00,0xa5,0x05,0x38,0x00,0x96,0x05,0x3a,0x00,0x86,0x05,0x3c,0x00,0x76,0x05,0x3d,0x00,0x67,0x05,0x3f,0x00,0x57,0x05,0x41,0x00,0x48,0x05,0x42,0x00,0x39,0x05,0x44,0x00,0x2a,0x05,0x46,0x00,0x1a,0x05,0x47,0x00,0x0b,0x05,0x49,0x00,0xfc,0x04,0x4b,0x00,0xed,0x04,0x4c,0x00,0xdf,0x04,0x4e,0x00,0xd0,0x04,0x50,0x00,0xc1,0x04,0x51,0x00,0xb2,0x04,0x53,0x00,0xa4,0x04,0x54,0x00,0x95,0x04,0x56,0x00,  \
    0x87,0x04,0x57,0x00,0x78,0x04,0x59,0x00,0x6a,0x04,0x5a,0x00,0x5c,0x04,0x5c,0x00,0x4e,0x04,0x5d,0x00,0x3f,0x04,0x5f,0x00,0x31,0x04,0x60,0x00,0x23,0x04,0x62,0x00,0x15,0x04,0x63,0x00,0x07,0x04,0x65,0x00,0xfa,0x03,0x66,0x00,0xec,0x03,0x67,0x00,0xde,0x03,0x69,0x00,0xd1,0x03,0x6a,0x00,0xc3,0x03,0x6c,0x00,0xb5,0x03,0x6d,0x00,0xa8,0x03,0x6e,0x00,0x9b,0x03,0x70,0x00,0x8d,0x03,0x71,0x00,0x80,0x03,0x72,0x00,0x73,0x03,0x74,0x00,0x66,0x03,0x75,0x00,0x59,0x03,  \
    0x76,0x00,0x4c,0x03,0x77,0x00,0x3f,0x03,0x79,0x00,0x32,0x03,0x7a,0x00,0x25,0x03,0x7b,0x00,0x18,0x03,0x7c,0x00,0x0b,0x03,0x7d,0x00,0xfe,0x02,0x7f,0x00,0xf2,0x02,0x80,0x00,0xe5,0x02,0x81,0x00,0xd9,0x02,0x82,0x00,0xcc,0x02,0x83,0x00,0xc0,0x02,0x84,0x00,0xb3,0x02,0x85,0x00,0xa7,0x02,0x86,0x00,0x9a,0x02,0x87,0x00,0x8e,0x02,0x88,0x00,0x82,0x02,0x89,0x00,0x76,0x02,0x8a,0x00,0x6a,0x02,0x8b,0x00,0x5d,0x02,0x8c,0x00,0x51,0x02,0x8d,0x00,0x45,0x02,0x8e,0x00,  \
    0x39,0x02,0x8f,0x00,0x2d,0x02,0x90,0x00,0x22,0x02,0x91,0x00,0x16,0x02,0x92,0x00,0x0a,0x02,0x93,0x00,0xfe,0x01,0x94,0x00,0xf2,0x01,0x94,0x00,0xe7,0x01,0x95,0x00,0xdb,0x01,0x96,0x00,0xcf,0x01,0x97,0x00,0xc4,0x01,0x98,0x00,0xb8,0x01,0x98,0x00,0xac,0x01,0x99,0x00,0xa1,0x01,0x9a,0x00,0x95,0x01,0x9a,0x00,0x8a,0x01,0x9b,0x00,0x7f,0x01,0x9c,0x00,0x73,0x01,0x9c,0x00,0x68,0x01,0x9d,0x00,0x5c,0x01,0x9e,0x00,0x51,0x01,0x9e,0x00,0x46,0x01,0x9f,0x00,0x3b,0x01,  \
    0x9f,0x00,0x2f,0x01,0xa0,0x00,0x24,0x01,0xa1,0x00,0x19,0x01,0xa1,0x00,0x0e,0x01,0xa2,0x00,0x03,0x01,0xa2,0x00,0xf7,0x00,0xa3,0x00,0xec,0x00,0xa3,0x00,0xe1,0x00,0xa3,0x00,0xd6,0x00,0xa4,0x00,0xcb,0x00,0xa4,0x00,0xc0,0x00,0xa5,0x00,0xb5,0x00,0xa5,0x00,0xaa,0x00,0xa5,0x00,0x9f,0x00,0xa6,0x00,0x94,0x00,0xa6,0x00,0x89,0x00,0xa6,0x00,0x7e,0x00,0xa7,0x00,0x73,0x00,0xa7,0x00,0x68,0x00,0xa7,0x00,0x5d,0x00,0xa7,0x00,0x52,0x00,0xa8,0x00,0x48,0x00,0xa8,0x00,  \
    0x3d,0x00,0xa8,0x00,0x32,0x00,0xa8,0x00,0x27,0x00,0xa8,0x00,0x1c,0x00,0xa8,0x00,0x11,0x00,0xa9,0x00,0x06,0x00,0xa9,0x00,0xfc,0xff,0xa9,0x00,0xf1,0xff,0xa9,0x00,0xe6,0xff,0xa9,0x00,0xdb,0xff,0xa9,0x00,0xd0,0xff,0xa9,0x00,0xc5,0xff,0xa9,0x00,0xbb,0xff,0xa9,0x00,0xb0,0xff,0xa9,0x00,0xa5,0xff,0xa9,0x00,0x9a,0xff,0xa9,0x00,0x8f,0xff,0xa9,0x00,0x84,0xff,0xa9,0x00,0x7a,0xff,0xa8,0x00,0x6f,0xff,0xa8,0x00,0x64,0xff,0xa8,0x00,0x59,0xff,0xa8,0x00,0x4e,0xff,  \
    0xa8,0x00,0x43,0xff,0xa8,0x00,0x38,0xff,0xa7,0x00,0x2e,0xff,0xa7,0x00,0x23,0xff,0xa7,0x00,0x18,0xff,0xa7,0x00,0x0d,0xff,0xa6,0x00,0x02,0xff,0xa6,0x00,0xf7,0xfe,0xa6,0x00,0xec,0xfe,0xa5,0x00,0xe1,0xfe,0xa5,0x00,0xd6,0xfe,0xa5,0x00,0xcb,0xfe,0xa4,0x00,0xc0,0xfe,0xa4,0x00,0xb5,0xfe,0xa3,0x00,0xaa,0xfe,0xa3,0x00,0x9f,0xfe,0xa3,0x00,0x94,0xfe,0xa2,0x00,0x89,0xfe,0xa2,0x00,0x7e,0xfe,0xa1,0x00,0x73,0xfe,0xa1,0x00,0x68,0xfe,0xa0,0x00,0x5c,0xfe,0xa0,0x00,  \
    0x51,0xfe,0x9f,0x00,0x46,0xfe,0x9e,0x00,0x3b,0xfe,0x9e,0x00,0x30,0xfe,0x9d,0x00,0x25,0xfe,0x9d,0x00,0x19,0xfe,0x9c,0x00,0x0e,0xfe,0x9b,0x00,0x03,0xfe,0x9b,0x00,0xf7,0xfd,0x9a,0x00,0xec,0xfd,0x99,0x00,0xe1,0xfd,0x99,0x00,0xd5,0xfd,0x98,0x00,0xca,0xfd,0x97,0x00,0xbe,0xfd,0x96,0x00,0xb3,0xfd,0x95,0x00,0xa7,0xfd,0x95,0x00,0x9c,0xfd,0x94,0x00,0x90,0xfd,0x93,0x00,0x85,0xfd,0x92,0x00,0x79,0xfd,0x91,0x00,0x6d,0xfd,0x90,0x00,0x62,0xfd,0x90,0x00,0x56,0xfd,  \
    0x8f,0x00,0x4a,0xfd,0x8e,0x00,0x3e,0xfd,0x8d,0x00,0x32,0xfd,0x8c,0x00,0x26,0xfd,0x8b,0x00,0x1a,0xfd,0x8a,0x00,0x0e,0xfd,0x89,0x00,0x02,0xfd,0x88,0x00,0xf5,0xfc,0x87,0x00,0xe9,0xfc,0x86,0x00,0xdd,0xfc,0x85,0x00,0xd1,0xfc,0x84,0x00,0xc4,0xfc,0x83,0x00,0xb8,0xfc,0x82,0x00,0xab,0xfc,0x80,0x00,0x9f,0xfc,0x7f,0x00,0x92,0xfc,0x7e,0x00,0x86,0xfc,0x7d,0x00,0x79,0xfc,0x7c,0x00,0x6c,0xfc,0x7b,0x00,0x60,0xfc,0x79,0x00,0x53,0xfc,0x78,0x00,0x46,0xfc,0x77,0x00,  \
    0x39,0xfc,0x76,0x00,0x2c,0xfc,0x75,0x00,0x1f,0xfc,0x73,0x00,0x12,0xfc,0x72,0x00,0x05,0xfc,0x71,0x00,0xf8,0xfb,0x6f,0x00,0xeb,0xfb,0x6e,0x00,0xdd,0xfb,0x6d,0x00,0xd0,0xfb,0x6b,0x00,0xc3,0xfb,0x6a,0x00,0xb5,0xfb,0x69,0x00,0xa8,0xfb,0x67,0x00,0x9a,0xfb,0x66,0x00,0x8d,0xfb,0x65,0x00,0x7f,0xfb,0x63,0x00,0x71,0xfb,0x62,0x00,0x63,0xfb,0x60,0x00,0x56,0xfb,0x5f,0x00,0x48,0xfb,0x5d,0x00,0x3a,0xfb,0x5c,0x00,0x2c,0xfb,0x5a,0x00,0x1d,0xfb,0x59,0x00,0x0f,0xfb,  \
    0x57,0x00,0x01,0xfb,0x56,0x00,0xf3,0xfa,0x54,0x00,0xe4,0xfa,0x53,0x00,0xd6,0xfa,0x51,0x00,0xc7,0xfa,0x50,0x00,0xb9,0xfa,0x4e,0x00,0xaa,0xfa,0x4d,0x00,0x9b,0xfa,0x4b,0x00,0x8d,0xfa,0x49,0x00,0x7e,0xfa,0x48,0x00,0x6f,0xfa,0x46,0x00,0x60,0xfa,0x44,0x00,0x51,0xfa,0x43,0x00,0x41,0xfa,0x41,0x00,0x32,0xfa,0x3f,0x00,0x23,0xfa,0x3e,0x00,0x13,0xfa,0x3c,0x00,0x04,0xfa,0x3a,0x00,0xf4,0xf9,0x39,0x00,0xe5,0xf9,0x37,0x00,0xd5,0xf9,0x35,0x00,0xc5,0xf9,0x34,0x00,  \
    0xb5,0xf9,0x32,0x00,0xa5,0xf9,0x30,0x00,0x95,0xf9,0x2e,0x00,0x85,0xf9,0x2d,0x00,0x75,0xf9,0x2b,0x00,0x65,0xf9,0x29,0x00,0x54,0xf9,0x27,0x00,0x44,0xf9,0x26,0x00,0x33,0xf9,0x24,0x00,0x22,0xf9,0x22,0x00,0x12,0xf9,0x20,0x00,0x01,0xf9,0x1e,0x00,0xf0,0xf8,0x1d,0x00,0xdf,0xf8,0x1b,0x00,0xce,0xf8,0x19,0x00,0xbd,0xf8,0x17,0x00,0xab,0xf8,0x15,0x00,0x9a,0xf8,0x13,0x00,0x89,0xf8,0x12,0x00,0x77,0xf8,0x10,0x00,0x65,0xf8,0x0e,0x00,0x54,0xf8,0x0c,0x00,0x42,0xf8,  \
    0x0a,0x00,0x30,0xf8,0x08,0x00,0x1e,0xf8,0x06,0x00,0x0c,0xf8,0x04,0x00,0xfa,0xf7,0x03,0x00,0xe7,0xf7,0x01,0x00,0xd5,0xf7,0xff,0xff,0xc2,0xf7,0xfd,0xff,0xb0,0xf7,0xfb,0xff,0x9d,0xf7,0xf9,0xff,0x8a,0xf7,0xf7,0xff,0x77,0xf7,0xf5,0xff,0x64,0xf7,0xf4,0xff,0x51,0xf7,0xf2,0xff,0x3e,0xf7,0xf0,0xff,0x2b,0xf7,0xee,0xff,0x17,0xf7,0xec,0xff,0x04,0xf7,0xea,0xff,0xf0,0xf6,0xe8,0xff,0xdc,0xf6,0xe6,0xff,0xc9,0xf6,0xe5,0xff,0xb5,0xf6,0xe3,0xff,0xa1,0xf6,0xe1,0xff,  \
    0x8c,0xf6,0xdf,0xff,0x78,0xf6,0xdd,0xff,0x64,0xf6,0xdb,0xff,0x4f,0xf6,0xd9,0xff,0x3b,0xf6,0xd7,0xff,0x26,0xf6,0xd6,0xff,0x11,0xf6,0xd4,0xff,0xfc,0xf5,0xd2,0xff,0xe7,0xf5,0xd0,0xff,0xd2,0xf5,0xce,0xff,0xbd,0xf5,0xcc,0xff,0xa7,0xf5,0xcb,0xff,0x92,0xf5,0xc9,0xff,0x7c,0xf5,0xc7,0xff,0x67,0xf5,0xc5,0xff,0x51,0xf5,0xc3,0xff,0x3b,0xf5,0xc2,0xff,0x25,0xf5,0xc0,0xff,0x0f,0xf5,0xbe,0xff,0xf8,0xf4,0xbc,0xff,0xe2,0xf4,0xba,0xff,0xcb,0xf4,0xb9,0xff,0xb5,0xf4,  \
    0xb7,0xff,0x9e,0xf4,0xb5,0xff,0x87,0xf4,0xb4,0xff,0x70,0xf4,0xb2,0xff,0x59,0xf4,0xb0,0xff,0x42,0xf4,0xae,0xff,0x2b,0xf4,0xad,0xff,0x13,0xf4,0xab,0xff,0xfc,0xf3,0xaa,0xff,0xe4,0xf3,0xa8,0xff,0xcc,0xf3,0xa6,0xff,0xb4,0xf3,0xa5,0xff,0x9c,0xf3,0xa3,0xff,0x84,0xf3,0xa2,0xff,0x6c,0xf3,0xa0,0xff,0x53,0xf3,0x9e,0xff,0x3b,0xf3,0x9d,0xff,0x22,0xf3,0x9b,0xff,0x09,0xf3,0x9a,0xff,0xf0,0xf2,0x98,0xff,0xd7,0xf2,0x97,0xff,0xbe,0xf2,0x96,0xff,0xa5,0xf2,0x94,0xff,  \
    0x8b,0xf2,0x93,0xff,0x72,0xf2,0x91,0xff,0x58,0xf2,0x90,0xff,0x3e,0xf2,0x8f,0xff,0x25,0xf2,0x8d,0xff,0x0b,0xf2,0x8c,0xff,0xf0,0xf1,0x8b,0xff,0xd6,0xf1,0x8a,0xff,0xbc,0xf1,0x88,0xff,0xa1,0xf1,0x87,0xff,0x86,0xf1,0x86,0xff,0x6c,0xf1,0x85,0xff,0x51,0xf1,0x84,0xff,0x36,0xf1,0x83,0xff,0x1a,0xf1,0x82,0xff,0xff,0xf0,0x81,0xff,0xe4,0xf0,0x7f,0xff,0xc8,0xf0,0x7e,0xff,0xad,0xf0,0x7e,0xff,0x91,0xf0,0x7d,0xff,0x75,0xf0,0x7c,0xff,0x59,0xf0,0x7b,0xff,0x3c,0xf0,  \
    0x7a,0xff,0x20,0xf0,0x79,0xff,0x04,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x5c,0xff,0x0d,0x10,0x5d,0xff,0xf0,0x0f,0x5e,0xff,0xd3,0x0f,0x5f,0xff,0xb7,0x0f,0x60,0xff,0x9b,0x0f,0x61,0xff,  \
    0x7f,0x0f,0x62,0xff,0x63,0x0f,0x63,0xff,0x47,0x0f,0x64,0xff,0x2b,0x0f,0x65,0xff,0x0f,0x0f,0x66,0xff,0xf4,0x0e,0x67,0xff,0xd8,0x0e,0x69,0xff,0xbd,0x0e,0x6a,0xff,0xa2,0x0e,0x6b,0xff,0x87,0x0e,0x6c,0xff,0x6c,0x0e,0x6e,0xff,0x51,0x0e,0x6f,0xff,0x36,0x0e,0x70,0xff,0x1b,0x0e,0x72,0xff,0x01,0x0e,0x73,0xff,0xe7,0x0d,0x75,0xff,0xcc,0x0d,0x76,0xff,0xb2,0x0d,0x78,0xff,0x98,0x0d,0x79,0xff,0x7e,0x0d,0x7b,0xff,0x64,0x0d,0x7c,0xff,0x4b,0x0d,0x7e,0xff,0x31,0x0d,  \
    0x7f,0xff,0x18,0x0d,0x81,0xff,0xff,0x0c,0x82,0xff,0xe5,0x0c,0x84,0xff,0xcc,0x0c,0x86,0xff,0xb3,0x0c,0x87,0xff,0x9a,0x0c,0x89,0xff,0x82,0x0c,0x8b,0xff,0x69,0x0c,0x8c,0xff,0x51,0x0c,0x8e,0xff,0x38,0x0c,0x90,0xff,0x20,0x0c,0x92,0xff,0x08,0x0c,0x94,0xff,0xf0,0x0b,0x95,0xff,0xd8,0x0b,0x97,0xff,0xc0,0x0b,0x99,0xff,0xa9,0x0b,0x9b,0xff,0x91,0x0b,0x9d,0xff,0x7a,0x0b,0x9f,0xff,0x63,0x0b,0xa0,0xff,0x4c,0x0b,0xa2,0xff,0x34,0x0b,0xa4,0xff,0x1e,0x0b,0xa6,0xff,  \
    0x07,0x0b,0xa8,0xff,0xf0,0x0a,0xaa,0xff,0xda,0x0a,0xac,0xff,0xc3,0x0a,0xae,0xff,0xad,0x0a,0xb0,0xff,0x97,0x0a,0xb2,0xff,0x80,0x0a,0xb4,0xff,0x6a,0x0a,0xb6,0xff,0x54,0x0a,0xb8,0xff,0x3f,0x0a,0xba,0xff,0x29,0x0a,0xbc,0xff,0x13,0x0a,0xbe,0xff,0xfe,0x09,0xc0,0xff,0xe8,0x09,0xc2,0xff,0xd3,0x09,0xc4,0xff,0xbe,0x09,0xc6,0xff,0xa8,0x09,0xc8,0xff,0x93,0x09,0xca,0xff,0x7f,0x09,0xcc,0xff,0x6a,0x09,0xce,0xff,0x55,0x09,0xd0,0xff,0x40,0x09,0xd2,0xff,0x2c,0x09,  \
    0xd4,0xff,0x18,0x09,0xd6,0xff,0x03,0x09,0xd8,0xff,0xef,0x08,0xda,0xff,0xdb,0x08,0xdc,0xff,0xc7,0x08,0xde,0xff,0xb3,0x08,0xe0,0xff,0xa0,0x08,0xe2,0xff,0x8c,0x08,0xe4,0xff,0x78,0x08,0xe6,0xff,0x65,0x08,0xe8,0xff,0x51,0x08,0xeb,0xff,0x3e,0x08,0xed,0xff,0x2b,0x08,0xef,0xff,0x18,0x08,0xf1,0xff,0x05,0x08,0xf3,0xff,0xf2,0x07,0xf5,0xff,0xdf,0x07,0xf7,0xff,0xcd,0x07,0xf9,0xff,0xba,0x07,0xfb,0xff,0xa8,0x07,0xfd,0xff,0x95,0x07,0xff,0xff,0x83,0x07,0x01,0x00,  \
    0x71,0x07,0x03,0x00,0x5f,0x07,0x05,0x00,0x4d,0x07,0x07,0x00,0x3b,0x07,0x09,0x00,0x29,0x07,0x0b,0x00,0x17,0x07,0x0d,0x00,0x06,0x07,0x0f,0x00,0xf4,0x06,0x11,0x00,0xe3,0x06,0x13,0x00,0xd1,0x06,0x15,0x00,0xc0,0x06,0x17,0x00,0xaf,0x06,0x19,0x00,0x9e,0x06,0x1b,0x00,0x8d,0x06,0x1d,0x00,0x7c,0x06,0x1f,0x00,0x6b,0x06,0x21,0x00,0x5a,0x06,0x22,0x00,0x4a,0x06,0x24,0x00,0x39,0x06,0x26,0x00,0x29,0x06,0x28,0x00,0x18,0x06,0x2a,0x00,0x08,0x06,0x2c,0x00,0xf8,0x05,  \
    0x2e,0x00,0xe8,0x05,0x30,0x00,0xd8,0x05,0x32,0x00,0xc8,0x05,0x33,0x00,0xb8,0x05,0x35,0x00,0xa8,0x05,0x37,0x00,0x98,0x05,0x39,0x00,0x88,0x05,0x3b,0x00,0x79,0x05,0x3c,0x00,0x69,0x05,0x3e,0x00,0x5a,0x05,0x40,0x00,0x4a,0x05,0x42,0x00,0x3b,0x05,0x44,0x00,0x2c,0x05,0x45,0x00,0x1d,0x05,0x47,0x00,0x0e,0x05,0x49,0x00,0xff,0x04,0x4a,0x00,0xf0,0x04,0x4c,0x00,0xe1,0x04,0x4e,0x00,0xd2,0x04,0x50,0x00,0xc3,0x04,0x51,0x00,0xb5,0x04,0x53,0x00,0xa6,0x04,0x55,0x00,  \
    0x98,0x04,0x56,0x00,0x89,0x04,0x58,0x00,0x7b,0x04,0x59,0x00,0x6c,0x04,0x5b,0x00,0x5e,0x04,0x5d,0x00,0x50,0x04,0x5e,0x00,0x42,0x04,0x60,0x00,0x34,0x04,0x61,0x00,0x25,0x04,0x63,0x00,0x18,0x04,0x64,0x00,0x0a,0x04,0x66,0x00,0xfc,0x03,0x67,0x00,0xee,0x03,0x69,0x00,0xe0,0x03,0x6a,0x00,0xd3,0x03,0x6c,0x00,0xc5,0x03,0x6d,0x00,0xb8,0x03,0x6e,0x00,0xaa,0x03,0x70,0x00,0x9d,0x03,0x71,0x00,0x8f,0x03,0x73,0x00,0x82,0x03,0x74,0x00,0x75,0x03,0x75,0x00,0x68,0x03,  \
    0x77,0x00,0x5b,0x03,0x78,0x00,0x4d,0x03,0x79,0x00,0x40,0x03,0x7b,0x00,0x34,0x03,0x7c,0x00,0x27,0x03,0x7d,0x00,0x1a,0x03,0x7e,0x00,0x0d,0x03,0x80,0x00,0x00,0x03,0x81,0x00,0xf4,0x02,0x82,0x00,0xe7,0x02,0x83,0x00,0xda,0x02,0x85,0x00,0xce,0x02,0x86,0x00,0xc1,0x02,0x87,0x00,0xb5,0x02,0x88,0x00,0xa9,0x02,0x89,0x00,0x9c,0x02,0x8a,0x00,0x90,0x02,0x8b,0x00,0x84,0x02,0x8c,0x00,0x77,0x02,0x8d,0x00,0x6b,0x02,0x8e,0x00,0x5f,0x02,0x8f,0x00,0x53,0x02,0x90,0x00,  \
    0x47,0x02,0x91,0x00,0x3b,0x02,0x92,0x00,0x2f,0x02,0x93,0x00,0x23,0x02,0x94,0x00,0x17,0x02,0x95,0x00,0x0b,0x02,0x96,0x00,0xff,0x01,0x97,0x00,0xf4,0x01,0x98,0x00,0xe8,0x01,0x99,0x00,0xdc,0x01,0x9a,0x00,0xd1,0x01,0x9a,0x00,0xc5,0x01,0x9b,0x00,0xb9,0x01,0x9c,0x00,0xae,0x01,0x9d,0x00,0xa2,0x01,0x9e,0x00,0x97,0x01,0x9e,0x00,0x8b,0x01,0x9f,0x00,0x80,0x01,0xa0,0x00,0x74,0x01,0xa0,0x00,0x69,0x01,0xa1,0x00,0x5e,0x01,0xa2,0x00,0x52,0x01,0xa2,0x00,0x47,0x01,  \
    0xa3,0x00,0x3c,0x01,0xa4,0x00,0x30,0x01,0xa4,0x00,0x25,0x01,0xa5,0x00,0x1a,0x01,0xa5,0x00,0x0f,0x01,0xa6,0x00,0x03,0x01,0xa6,0x00,0xf8,0x00,0xa7,0x00,0xed,0x00,0xa7,0x00,0xe2,0x00,0xa8,0x00,0xd7,0x00,0xa8,0x00,0xcc,0x00,0xa9,0x00,0xc1,0x00,0xa9,0x00,0xb6,0x00,0xa9,0x00,0xab,0x00,0xaa,0x00,0xa0,0x00,0xaa,0x00,0x95,0x00,0xaa,0x00,0x8a,0x00,0xab,0x00,0x7f,0x00,0xab,0x00,0x74,0x00,0xab,0x00,0x69,0x00,0xac,0x00,0x5e,0x00,0xac,0x00,0x53,0x00,0xac,0x00,  \
    0x48,0x00,0xac,0x00,0x3d,0x00,0xad,0x00,0x32,0x00,0xad,0x00,0x27,0x00,0xad,0x00,0x1c,0x00,0xad,0x00,0x11,0x00,0xad,0x00,0x07,0x00,0xad,0x00,0xfc,0xff,0xad,0x00,0xf1,0xff,0xad,0x00,0xe6,0xff,0xad,0x00,0xdb,0xff,0xad,0x00,0xd0,0xff,0xae,0x00,0xc5,0xff,0xae,0x00,0xbb,0xff,0xad,0x00,0xb0,0xff,0xad,0x00,0xa5,0xff,0xad,0x00,0x9a,0xff,0xad,0x00,0x8f,0xff,0xad,0x00,0x84,0xff,0xad,0x00,0x79,0xff,0xad,0x00,0x6e,0xff,0xad,0x00,0x64,0xff,0xad,0x00,0x59,0xff,  \
    0xad,0x00,0x4e,0xff,0xac,0x00,0x43,0xff,0xac,0x00,0x38,0xff,0xac,0x00,0x2d,0xff,0xac,0x00,0x22,0xff,0xab,0x00,0x17,0xff,0xab,0x00,0x0c,0xff,0xab,0x00,0x01,0xff,0xaa,0x00,0xf6,0xfe,0xaa,0x00,0xeb,0xfe,0xaa,0x00,0xe0,0xfe,0xa9,0x00,0xd5,0xfe,0xa9,0x00,0xca,0xfe,0xa9,0x00,0xbf,0xfe,0xa8,0x00,0xb4,0xfe,0xa8,0x00,0xa9,0xfe,0xa7,0x00,0x9e,0xfe,0xa7,0x00,0x93,0xfe,0xa6,0x00,0x88,0xfe,0xa6,0x00,0x7d,0xfe,0xa5,0x00,0x72,0xfe,0xa5,0x00,0x67,0xfe,0xa4,0x00,  \
    0x5b,0xfe,0xa4,0x00,0x50,0xfe,0xa3,0x00,0x45,0xfe,0xa3,0x00,0x3a,0xfe,0xa2,0x00,0x2f,0xfe,0xa1,0x00,0x23,0xfe,0xa1,0x00,0x18,0xfe,0xa0,0x00,0x0d,0xfe,0x9f,0x00,0x02,0xfe,0x9f,0x00,0xf6,0xfd,0x9e,0x00,0xeb,0xfd,0x9d,0x00,0xdf,0xfd,0x9c,0x00,0xd4,0xfd,0x9c,0x00,0xc9,0xfd,0x9b,0x00,0xbd,0xfd,0x9a,0x00,0xb2,0xfd,0x99,0x00,0xa6,0xfd,0x98,0x00,0x9a,0xfd,0x97,0x00,0x8f,0xfd,0x97,0x00,0x83,0xfd,0x96,0x00,0x78,0xfd,0x95,0x00,0x6c,0xfd,0x94,0x00,0x60,0xfd,  \
    0x93,0x00,0x54,0xfd,0x92,0x00,0x48,0xfd,0x91,0x00,0x3c,0xfd,0x90,0x00,0x30,0xfd,0x8f,0x00,0x24,0xfd,0x8e,0x00,0x18,0xfd,0x8d,0x00,0x0c,0xfd,0x8c,0x00,0x00,0xfd,0x8b,0x00,0xf4,0xfc,0x8a,0x00,0xe8,0xfc,0x89,0x00,0xdb,0xfc,0x88,0x00,0xcf,0xfc,0x86,0x00,0xc3,0xfc,0x85,0x00,0xb6,0xfc,0x84,0x00,0xaa,0xfc,0x83,0x00,0x9d,0xfc,0x82,0x00,0x91,0xfc,0x81,0x00,0x84,0xfc,0x7f,0x00,0x77,0xfc,0x7e,0x00,0x6a,0xfc,0x7d,0x00,0x5e,0xfc,0x7c,0x00,0x51,0xfc,0x7a,0x00,  \
    0x44,0xfc,0x79,0x00,0x37,0xfc,0x78,0x00,0x2a,0xfc,0x77,0x00,0x1d,0xfc,0x75,0x00,0x10,0xfc,0x74,0x00,0x03,0xfc,0x73,0x00,0xf6,0xfb,0x71,0x00,0xe9,0xfb,0x70,0x00,0xdb,0xfb,0x6e,0x00,0xce,0xfb,0x6d,0x00,0xc1,0xfb,0x6c,0x00,0xb3,0xfb,0x6a,0x00,0xa6,0xfb,0x69,0x00,0x98,0xfb,0x67,0x00,0x8a,0xfb,0x66,0x00,0x7d,0xfb,0x64,0x00,0x6f,0xfb,0x63,0x00,0x61,0xfb,0x61,0x00,0x53,0xfb,0x60,0x00,0x45,0xfb,0x5e,0x00,0x37,0xfb,0x5d,0x00,0x29,0xfb,0x5b,0x00,0x1b,0xfb,  \
    0x5a,0x00,0x0d,0xfb,0x58,0x00,0xff,0xfa,0x56,0x00,0xf0,0xfa,0x55,0x00,0xe2,0xfa,0x53,0x00,0xd3,0xfa,0x52,0x00,0xc5,0xfa,0x50,0x00,0xb6,0xfa,0x4e,0x00,0xa8,0xfa,0x4d,0x00,0x99,0xfa,0x4b,0x00,0x8a,0xfa,0x49,0x00,0x7b,0xfa,0x48,0x00,0x6c,0xfa,0x46,0x00,0x5d,0xfa,0x44,0x00,0x4e,0xfa,0x42,0x00,0x3f,0xfa,0x41,0x00,0x30,0xfa,0x3f,0x00,0x20,0xfa,0x3d,0x00,0x11,0xfa,0x3b,0x00,0x01,0xfa,0x3a,0x00,0xf2,0xf9,0x38,0x00,0xe2,0xf9,0x36,0x00,0xd2,0xf9,0x34,0x00,  \
    0xc3,0xf9,0x32,0x00,0xb3,0xf9,0x31,0x00,0xa3,0xf9,0x2f,0x00,0x93,0xf9,0x2d,0x00,0x83,0xf9,0x2b,0x00,0x72,0xf9,0x29,0x00,0x62,0xf9,0x27,0x00,0x52,0xf9,0x26,0x00,0x41,0xf9,0x24,0x00,0x31,0xf9,0x22,0x00,0x20,0xf9,0x20,0x00,0x0f,0xf9,0x1e,0x00,0xfe,0xf8,0x1c,0x00,0xee,0xf8,0x1a,0x00,0xdd,0xf8,0x18,0x00,0xcb,0xf8,0x16,0x00,0xba,0xf8,0x14,0x00,0xa9,0xf8,0x13,0x00,0x98,0xf8,0x11,0x00,0x86,0xf8,0x0f,0x00,0x75,0xf8,0x0d,0x00,0x63,0xf8,0x0b,0x00,0x51,0xf8,  \
    0x09,0x00,0x3f,0xf8,0x07,0x00,0x2d,0xf8,0x05,0x00,0x1b,0xf8,0x03,0x00,0x09,0xf8,0x01,0x00,0xf7,0xf7,0xff,0xff,0xe5,0xf7,0xfd,0xff,0xd2,0xf7,0xfb,0xff,0xc0,0xf7,0xf9,0xff,0xad,0xf7,0xf7,0xff,0x9b,0xf7,0xf5,0xff,0x88,0xf7,0xf3,0xff,0x75,0xf7,0xf1,0xff,0x62,0xf7,0xef,0xff,0x4f,0xf7,0xed,0xff,0x3c,0xf7,0xeb,0xff,0x28,0xf7,0xe9,0xff,0x15,0xf7,0xe7,0xff,0x01,0xf7,0xe5,0xff,0xee,0xf6,0xe3,0xff,0xda,0xf6,0xe1,0xff,0xc6,0xf6,0xdf,0xff,0xb2,0xf6,0xde,0xff,  \
    0x9e,0xf6,0xdc,0xff,0x8a,0xf6,0xda,0xff,0x76,0xf6,0xd8,0xff,0x61,0xf6,0xd6,0xff,0x4d,0xf6,0xd4,0xff,0x38,0xf6,0xd2,0xff,0x24,0xf6,0xd0,0xff,0x0f,0xf6,0xce,0xff,0xfa,0xf5,0xcc,0xff,0xe5,0xf5,0xca,0xff,0xd0,0xf5,0xc8,0xff,0xba,0xf5,0xc6,0xff,0xa5,0xf5,0xc4,0xff,0x90,0xf5,0xc2,0xff,0x7a,0xf5,0xc0,0xff,0x64,0xf5,0xbf,0xff,0x4f,0xf5,0xbd,0xff,0x39,0xf5,0xbb,0xff,0x23,0xf5,0xb9,0xff,0x0c,0xf5,0xb7,0xff,0xf6,0xf4,0xb5,0xff,0xe0,0xf4,0xb3,0xff,0xc9,0xf4,  \
    0xb2,0xff,0xb3,0xf4,0xb0,0xff,0x9c,0xf4,0xae,0xff,0x85,0xf4,0xac,0xff,0x6e,0xf4,0xaa,0xff,0x57,0xf4,0xa9,0xff,0x40,0xf4,0xa7,0xff,0x29,0xf4,0xa5,0xff,0x11,0xf4,0xa3,0xff,0xfa,0xf3,0xa2,0xff,0xe2,0xf3,0xa0,0xff,0xca,0xf3,0x9e,0xff,0xb2,0xf3,0x9d,0xff,0x9a,0xf3,0x9b,0xff,0x82,0xf3,0x99,0xff,0x6a,0xf3,0x98,0xff,0x51,0xf3,0x96,0xff,0x39,0xf3,0x94,0xff,0x20,0xf3,0x93,0xff,0x07,0xf3,0x91,0xff,0xee,0xf2,0x90,0xff,0xd5,0xf2,0x8e,0xff,0xbc,0xf2,0x8d,0xff,  \
    0xa3,0xf2,0x8b,0xff,0x8a,0xf2,0x8a,0xff,0x70,0xf2,0x88,0xff,0x56,0xf2,0x87,0xff,0x3d,0xf2,0x85,0xff,0x23,0xf2,0x84,0xff,0x09,0xf2,0x83,0xff,0xee,0xf1,0x81,0xff,0xd4,0xf1,0x80,0xff,0xba,0xf1,0x7f,0xff,0x9f,0xf1,0x7e,0xff,0x85,0xf1,0x7c,0xff,0x6a,0xf1,0x7b,0xff,0x4f,0xf1,0x7a,0xff,0x34,0xf1,0x79,0xff,0x19,0xf1,0x78,0xff,0xfd,0xf0,0x77,0xff,0xe2,0xf0,0x75,0xff,0xc6,0xf0,0x74,0xff,0xab,0xf0,0x73,0xff,0x8f,0xf0,0x72,0xff,0x73,0xf0,0x71,0xff,0x57,0xf0,  \
    0x70,0xff,0x3b,0xf0,0x70,0xff,0x1e,0xf0,0x6f,0xff,0x02,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x50,0xff,0x0e,0x10,0x51,0xff,0xf2,0x0f,0x52,0xff,0xd5,0x0f,0x53,0xff,0xb9,0x0f,0x54,0xff,  \
    0x9c,0x0f,0x55,0xff,0x80,0x0f,0x56,0xff,0x64,0x0f,0x57,0xff,0x48,0x0f,0x58,0xff,0x2c,0x0f,0x59,0xff,0x11,0x0f,0x5b,0xff,0xf5,0x0e,0x5c,0xff,0xda,0x0e,0x5d,0xff,0xbe,0x0e,0x5e,0xff,0xa3,0x0e,0x60,0xff,0x88,0x0e,0x61,0xff,0x6d,0x0e,0x62,0xff,0x52,0x0e,0x64,0xff,0x38,0x0e,0x65,0xff,0x1d,0x0e,0x67,0xff,0x03,0x0e,0x68,0xff,0xe8,0x0d,0x6a,0xff,0xce,0x0d,0x6b,0xff,0xb4,0x0d,0x6d,0xff,0x9a,0x0d,0x6e,0xff,0x80,0x0d,0x70,0xff,0x66,0x0d,0x72,0xff,0x4d,0x0d,  \
    0x73,0xff,0x33,0x0d,0x75,0xff,0x1a,0x0d,0x77,0xff,0x00,0x0d,0x78,0xff,0xe7,0x0c,0x7a,0xff,0xce,0x0c,0x7c,0xff,0xb5,0x0c,0x7d,0xff,0x9c,0x0c,0x7f,0xff,0x84,0x0c,0x81,0xff,0x6b,0x0c,0x83,0xff,0x52,0x0c,0x85,0xff,0x3a,0x0c,0x86,0xff,0x22,0x0c,0x88,0xff,0x0a,0x0c,0x8a,0xff,0xf2,0x0b,0x8c,0xff,0xda,0x0b,0x8e,0xff,0xc2,0x0b,0x90,0xff,0xab,0x0b,0x92,0xff,0x93,0x0b,0x94,0xff,0x7c,0x0b,0x96,0xff,0x65,0x0b,0x98,0xff,0x4d,0x0b,0x9a,0xff,0x36,0x0b,0x9c,0xff,  \
    0x20,0x0b,0x9e,0xff,0x09,0x0b,0xa0,0xff,0xf2,0x0a,0xa2,0xff,0xdc,0x0a,0xa4,0xff,0xc5,0x0a,0xa6,0xff,0xaf,0x0a,0xa8,0xff,0x99,0x0a,0xaa,0xff,0x83,0x0a,0xac,0xff,0x6d,0x0a,0xae,0xff,0x57,0x0a,0xb0,0xff,0x41,0x0a,0xb2,0xff,0x2b,0x0a,0xb4,0xff,0x15,0x0a,0xb7,0xff,0x00,0x0a,0xb9,0xff,0xea,0x09,0xbb,0xff,0xd5,0x09,0xbd,0xff,0xc0,0x09,0xbf,0xff,0xab,0x09,0xc1,0xff,0x96,0x09,0xc3,0xff,0x81,0x09,0xc5,0xff,0x6c,0x09,0xc8,0xff,0x57,0x09,0xca,0xff,0x43,0x09,  \
    0xcc,0xff,0x2e,0x09,0xce,0xff,0x1a,0x09,0xd0,0xff,0x06,0x09,0xd2,0xff,0xf1,0x08,0xd4,0xff,0xdd,0x08,0xd6,0xff,0xc9,0x08,0xd9,0xff,0xb6,0x08,0xdb,0xff,0xa2,0x08,0xdd,0xff,0x8e,0x08,0xdf,0xff,0x7b,0x08,0xe1,0xff,0x67,0x08,0xe3,0xff,0x54,0x08,0xe6,0xff,0x41,0x08,0xe8,0xff,0x2d,0x08,0xea,0xff,0x1a,0x08,0xec,0xff,0x07,0x08,0xee,0xff,0xf5,0x07,0xf0,0xff,0xe2,0x07,0xf2,0xff,0xcf,0x07,0xf4,0xff,0xbd,0x07,0xf7,0xff,0xaa,0x07,0xf9,0xff,0x98,0x07,0xfb,0xff,  \
    0x85,0x07,0xfd,0xff,0x73,0x07,0xff,0xff,0x61,0x07,0x01,0x00,0x4f,0x07,0x03,0x00,0x3d,0x07,0x05,0x00,0x2c,0x07,0x08,0x00,0x1a,0x07,0x0a,0x00,0x08,0x07,0x0c,0x00,0xf7,0x06,0x0e,0x00,0xe5,0x06,0x10,0x00,0xd4,0x06,0x12,0x00,0xc3,0x06,0x14,0x00,0xb2,0x06,0x16,0x00,0xa0,0x06,0x18,0x00,0x8f,0x06,0x1a,0x00,0x7f,0x06,0x1c,0x00,0x6e,0x06,0x1e,0x00,0x5d,0x06,0x20,0x00,0x4c,0x06,0x22,0x00,0x3c,0x06,0x24,0x00,0x2b,0x06,0x26,0x00,0x1b,0x06,0x28,0x00,0x0b,0x06,  \
    0x2a,0x00,0xfa,0x05,0x2c,0x00,0xea,0x05,0x2e,0x00,0xda,0x05,0x30,0x00,0xca,0x05,0x32,0x00,0xba,0x05,0x34,0x00,0xaa,0x05,0x36,0x00,0x9b,0x05,0x38,0x00,0x8b,0x05,0x3a,0x00,0x7b,0x05,0x3c,0x00,0x6c,0x05,0x3d,0x00,0x5c,0x05,0x3f,0x00,0x4d,0x05,0x41,0x00,0x3e,0x05,0x43,0x00,0x2e,0x05,0x45,0x00,0x1f,0x05,0x47,0x00,0x10,0x05,0x48,0x00,0x01,0x05,0x4a,0x00,0xf2,0x04,0x4c,0x00,0xe3,0x04,0x4e,0x00,0xd5,0x04,0x50,0x00,0xc6,0x04,0x51,0x00,0xb7,0x04,0x53,0x00,  \
    0xa9,0x04,0x55,0x00,0x9a,0x04,0x56,0x00,0x8b,0x04,0x58,0x00,0x7d,0x04,0x5a,0x00,0x6f,0x04,0x5b,0x00,0x60,0x04,0x5d,0x00,0x52,0x04,0x5f,0x00,0x44,0x04,0x60,0x00,0x36,0x04,0x62,0x00,0x28,0x04,0x64,0x00,0x1a,0x04,0x65,0x00,0x0c,0x04,0x67,0x00,0xfe,0x03,0x68,0x00,0xf0,0x03,0x6a,0x00,0xe3,0x03,0x6b,0x00,0xd5,0x03,0x6d,0x00,0xc7,0x03,0x6e,0x00,0xba,0x03,0x70,0x00,0xac,0x03,0x71,0x00,0x9f,0x03,0x73,0x00,0x91,0x03,0x74,0x00,0x84,0x03,0x76,0x00,0x77,0x03,  \
    0x77,0x00,0x6a,0x03,0x79,0x00,0x5d,0x03,0x7a,0x00,0x4f,0x03,0x7b,0x00,0x42,0x03,0x7d,0x00,0x36,0x03,0x7e,0x00,0x29,0x03,0x7f,0x00,0x1c,0x03,0x81,0x00,0x0f,0x03,0x82,0x00,0x02,0x03,0x83,0x00,0xf6,0x02,0x85,0x00,0xe9,0x02,0x86,0x00,0xdc,0x02,0x87,0x00,0xd0,0x02,0x88,0x00,0xc3,0x02,0x89,0x00,0xb7,0x02,0x8b,0x00,0xaa,0x02,0x8c,0x00,0x9e,0x02,0x8d,0x00,0x92,0x02,0x8e,0x00,0x85,0x02,0x8f,0x00,0x79,0x02,0x90,0x00,0x6d,0x02,0x91,0x00,0x61,0x02,0x93,0x00,  \
    0x55,0x02,0x94,0x00,0x48,0x02,0x95,0x00,0x3c,0x02,0x96,0x00,0x30,0x02,0x97,0x00,0x25,0x02,0x98,0x00,0x19,0x02,0x99,0x00,0x0d,0x02,0x9a,0x00,0x01,0x02,0x9a,0x00,0xf5,0x01,0x9b,0x00,0xe9,0x01,0x9c,0x00,0xde,0x01,0x9d,0x00,0xd2,0x01,0x9e,0x00,0xc6,0x01,0x9f,0x00,0xbb,0x01,0xa0,0x00,0xaf,0x01,0xa0,0x00,0xa3,0x01,0xa1,0x00,0x98,0x01,0xa2,0x00,0x8c,0x01,0xa3,0x00,0x81,0x01,0xa4,0x00,0x75,0x01,0xa4,0x00,0x6a,0x01,0xa5,0x00,0x5f,0x01,0xa6,0x00,0x53,0x01,  \
    0xa6,0x00,0x48,0x01,0xa7,0x00,0x3d,0x01,0xa8,0x00,0x31,0x01,0xa8,0x00,0x26,0x01,0xa9,0x00,0x1b,0x01,0xa9,0x00,0x10,0x01,0xaa,0x00,0x04,0x01,0xaa,0x00,0xf9,0x00,0xab,0x00,0xee,0x00,0xac,0x00,0xe3,0x00,0xac,0x00,0xd8,0x00,0xac,0x00,0xcd,0x00,0xad,0x00,0xc1,0x00,0xad,0x00,0xb6,0x00,0xae,0x00,0xab,0x00,0xae,0x00,0xa0,0x00,0xaf,0x00,0x95,0x00,0xaf,0x00,0x8a,0x00,0xaf,0x00,0x7f,0x00,0xb0,0x00,0x74,0x00,0xb0,0x00,0x69,0x00,0xb0,0x00,0x5e,0x00,0xb0,0x00,  \
    0x53,0x00,0xb1,0x00,0x48,0x00,0xb1,0x00,0x3d,0x00,0xb1,0x00,0x32,0x00,0xb1,0x00,0x27,0x00,0xb1,0x00,0x1d,0x00,0xb2,0x00,0x12,0x00,0xb2,0x00,0x07,0x00,0xb2,0x00,0xfc,0xff,0xb2,0x00,0xf1,0xff,0xb2,0x00,0xe6,0xff,0xb2,0x00,0xdb,0xff,0xb2,0x00,0xd0,0xff,0xb2,0x00,0xc5,0xff,0xb2,0x00,0xbb,0xff,0xb2,0x00,0xb0,0xff,0xb2,0x00,0xa5,0xff,0xb2,0x00,0x9a,0xff,0xb2,0x00,0x8f,0xff,0xb2,0x00,0x84,0xff,0xb2,0x00,0x79,0xff,0xb1,0x00,0x6e,0xff,0xb1,0x00,0x63,0xff,  \
    0xb1,0x00,0x58,0xff,0xb1,0x00,0x4e,0xff,0xb1,0x00,0x43,0xff,0xb1,0x00,0x38,0xff,0xb0,0x00,0x2d,0xff,0xb0,0x00,0x22,0xff,0xb0,0x00,0x17,0xff,0xaf,0x00,0x0c,0xff,0xaf,0x00,0x01,0xff,0xaf,0x00,0xf6,0xfe,0xaf,0x00,0xeb,0xfe,0xae,0x00,0xe0,0xfe,0xae,0x00,0xd5,0xfe,0xad,0x00,0xca,0xfe,0xad,0x00,0xbf,0xfe,0xad,0x00,0xb3,0xfe,0xac,0x00,0xa8,0xfe,0xac,0x00,0x9d,0xfe,0xab,0x00,0x92,0xfe,0xab,0x00,0x87,0xfe,0xaa,0x00,0x7c,0xfe,0xaa,0x00,0x71,0xfe,0xa9,0x00,  \
    0x66,0xfe,0xa8,0x00,0x5a,0xfe,0xa8,0x00,0x4f,0xfe,0xa7,0x00,0x44,0xfe,0xa7,0x00,0x39,0xfe,0xa6,0x00,0x2e,0xfe,0xa5,0x00,0x22,0xfe,0xa5,0x00,0x17,0xfe,0xa4,0x00,0x0c,0xfe,0xa3,0x00,0x00,0xfe,0xa2,0x00,0xf5,0xfd,0xa2,0x00,0xea,0xfd,0xa1,0x00,0xde,0xfd,0xa0,0x00,0xd3,0xfd,0x9f,0x00,0xc7,0xfd,0x9e,0x00,0xbc,0xfd,0x9e,0x00,0xb0,0xfd,0x9d,0x00,0xa5,0xfd,0x9c,0x00,0x99,0xfd,0x9b,0x00,0x8d,0xfd,0x9a,0x00,0x82,0xfd,0x99,0x00,0x76,0xfd,0x98,0x00,0x6a,0xfd,  \
    0x97,0x00,0x5f,0xfd,0x96,0x00,0x53,0xfd,0x95,0x00,0x47,0xfd,0x94,0x00,0x3b,0xfd,0x93,0x00,0x2f,0xfd,0x92,0x00,0x23,0xfd,0x91,0x00,0x17,0xfd,0x90,0x00,0x0a,0xfd,0x8f,0x00,0xfe,0xfc,0x8e,0x00,0xf2,0xfc,0x8d,0x00,0xe6,0xfc,0x8c,0x00,0xd9,0xfc,0x8a,0x00,0xcd,0xfc,0x89,0x00,0xc1,0xfc,0x88,0x00,0xb4,0xfc,0x87,0x00,0xa8,0xfc,0x86,0x00,0x9b,0xfc,0x84,0x00,0x8f,0xfc,0x83,0x00,0x82,0xfc,0x82,0x00,0x75,0xfc,0x81,0x00,0x68,0xfc,0x7f,0x00,0x5c,0xfc,0x7e,0x00,  \
    0x4f,0xfc,0x7d,0x00,0x42,0xfc,0x7b,0x00,0x35,0xfc,0x7a,0x00,0x28,0xfc,0x79,0x00,0x1b,0xfc,0x77,0x00,0x0e,0xfc,0x76,0x00,0x01,0xfc,0x74,0x00,0xf4,0xfb,0x73,0x00,0xe6,0xfb,0x72,0x00,0xd9,0xfb,0x70,0x00,0xcc,0xfb,0x6f,0x00,0xbe,0xfb,0x6d,0x00,0xb1,0xfb,0x6c,0x00,0xa3,0xfb,0x6a,0x00,0x96,0xfb,0x69,0x00,0x88,0xfb,0x67,0x00,0x7a,0xfb,0x65,0x00,0x6d,0xfb,0x64,0x00,0x5f,0xfb,0x62,0x00,0x51,0xfb,0x61,0x00,0x43,0xfb,0x5f,0x00,0x35,0xfb,0x5e,0x00,0x27,0xfb,  \
    0x5c,0x00,0x19,0xfb,0x5a,0x00,0x0b,0xfb,0x59,0x00,0xfc,0xfa,0x57,0x00,0xee,0xfa,0x55,0x00,0xdf,0xfa,0x54,0x00,0xd1,0xfa,0x52,0x00,0xc2,0xfa,0x50,0x00,0xb4,0xfa,0x4e,0x00,0xa5,0xfa,0x4d,0x00,0x96,0xfa,0x4b,0x00,0x88,0xfa,0x49,0x00,0x79,0xfa,0x47,0x00,0x6a,0xfa,0x46,0x00,0x5b,0xfa,0x44,0x00,0x4c,0xfa,0x42,0x00,0x3c,0xfa,0x40,0x00,0x2d,0xfa,0x3e,0x00,0x1e,0xfa,0x3d,0x00,0x0e,0xfa,0x3b,0x00,0xff,0xf9,0x39,0x00,0xef,0xf9,0x37,0x00,0xe0,0xf9,0x35,0x00,  \
    0xd0,0xf9,0x33,0x00,0xc0,0xf9,0x31,0x00,0xb0,0xf9,0x2f,0x00,0xa0,0xf9,0x2d,0x00,0x90,0xf9,0x2c,0x00,0x80,0xf9,0x2a,0x00,0x70,0xf9,0x28,0x00,0x5f,0xf9,0x26,0x00,0x4f,0xf9,0x24,0x00,0x3f,0xf9,0x22,0x00,0x2e,0xf9,0x20,0x00,0x1d,0xf9,0x1e,0x00,0x0d,0xf9,0x1c,0x00,0xfc,0xf8,0x1a,0x00,0xeb,0xf8,0x18,0x00,0xda,0xf8,0x16,0x00,0xc9,0xf8,0x14,0x00,0xb8,0xf8,0x12,0x00,0xa6,0xf8,0x10,0x00,0x95,0xf8,0x0e,0x00,0x84,0xf8,0x0c,0x00,0x72,0xf8,0x0a,0x00,0x60,0xf8,  \
    0x08,0x00,0x4f,0xf8,0x06,0x00,0x3d,0xf8,0x04,0x00,0x2b,0xf8,0x02,0x00,0x19,0xf8,0x00,0x00,0x07,0xf8,0xfe,0xff,0xf5,0xf7,0xfc,0xff,0xe2,0xf7,0xf9,0xff,0xd0,0xf7,0xf7,0xff,0xbd,0xf7,0xf5,0xff,0xab,0xf7,0xf3,0xff,0x98,0xf7,0xf1,0xff,0x85,0xf7,0xef,0xff,0x72,0xf7,0xed,0xff,0x5f,0xf7,0xeb,0xff,0x4c,0xf7,0xe9,0xff,0x39,0xf7,0xe7,0xff,0x26,0xf7,0xe5,0xff,0x12,0xf7,0xe3,0xff,0xff,0xf6,0xe1,0xff,0xeb,0xf6,0xdf,0xff,0xd8,0xf6,0xdd,0xff,0xc4,0xf6,0xda,0xff,  \
    0xb0,0xf6,0xd8,0xff,0x9c,0xf6,0xd6,0xff,0x88,0xf6,0xd4,0xff,0x73,0xf6,0xd2,0xff,0x5f,0xf6,0xd0,0xff,0x4b,0xf6,0xce,0xff,0x36,0xf6,0xcc,0xff,0x21,0xf6,0xca,0xff,0x0c,0xf6,0xc8,0xff,0xf8,0xf5,0xc6,0xff,0xe3,0xf5,0xc4,0xff,0xcd,0xf5,0xc2,0xff,0xb8,0xf5,0xc0,0xff,0xa3,0xf5,0xbe,0xff,0x8d,0xf5,0xbc,0xff,0x78,0xf5,0xba,0xff,0x62,0xf5,0xb8,0xff,0x4c,0xf5,0xb6,0xff,0x36,0xf5,0xb4,0xff,0x20,0xf5,0xb2,0xff,0x0a,0xf5,0xb0,0xff,0xf4,0xf4,0xae,0xff,0xdd,0xf4,  \
    0xac,0xff,0xc7,0xf4,0xaa,0xff,0xb0,0xf4,0xa9,0xff,0x9a,0xf4,0xa7,0xff,0x83,0xf4,0xa5,0xff,0x6c,0xf4,0xa3,0xff,0x55,0xf4,0xa1,0xff,0x3e,0xf4,0x9f,0xff,0x26,0xf4,0x9d,0xff,0x0f,0xf4,0x9c,0xff,0xf7,0xf3,0x9a,0xff,0xe0,0xf3,0x98,0xff,0xc8,0xf3,0x96,0xff,0xb0,0xf3,0x94,0xff,0x98,0xf3,0x93,0xff,0x80,0xf3,0x91,0xff,0x68,0xf3,0x8f,0xff,0x4f,0xf3,0x8e,0xff,0x37,0xf3,0x8c,0xff,0x1e,0xf3,0x8a,0xff,0x05,0xf3,0x89,0xff,0xec,0xf2,0x87,0xff,0xd3,0xf2,0x85,0xff,  \
    0xba,0xf2,0x84,0xff,0xa1,0xf2,0x82,0xff,0x88,0xf2,0x81,0xff,0x6e,0xf2,0x7f,0xff,0x54,0xf2,0x7e,0xff,0x3b,0xf2,0x7c,0xff,0x21,0xf2,0x7b,0xff,0x07,0xf2,0x79,0xff,0xed,0xf1,0x78,0xff,0xd2,0xf1,0x77,0xff,0xb8,0xf1,0x75,0xff,0x9d,0xf1,0x74,0xff,0x83,0xf1,0x73,0xff,0x68,0xf1,0x71,0xff,0x4d,0xf1,0x70,0xff,0x32,0xf1,0x6f,0xff,0x17,0xf1,0x6e,0xff,0xfb,0xf0,0x6d,0xff,0xe0,0xf0,0x6c,0xff,0xc5,0xf0,0x6a,0xff,0xa9,0xf0,0x69,0xff,0x8d,0xf0,0x68,0xff,0x71,0xf0,  \
    0x67,0xff,0x55,0xf0,0x66,0xff,0x39,0xf0,0x65,0xff,0x1d,0xf0,0x64,0xff,0x00,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x43,0xff,0x10,0x10,0x44,0xff,0xf3,0x0f,0x45,0xff,0xd7,0x0f,0x47,0xff,  \
    0xba,0x0f,0x48,0xff,0x9e,0x0f,0x49,0xff,0x82,0x0f,0x4a,0xff,0x66,0x0f,0x4b,0xff,0x4a,0x0f,0x4c,0xff,0x2e,0x0f,0x4e,0xff,0x12,0x0f,0x4f,0xff,0xf7,0x0e,0x50,0xff,0xdb,0x0e,0x52,0xff,0xc0,0x0e,0x53,0xff,0xa5,0x0e,0x54,0xff,0x8a,0x0e,0x56,0xff,0x6f,0x0e,0x57,0xff,0x54,0x0e,0x59,0xff,0x39,0x0e,0x5a,0xff,0x1f,0x0e,0x5c,0xff,0x04,0x0e,0x5d,0xff,0xea,0x0d,0x5f,0xff,0xd0,0x0d,0x60,0xff,0xb6,0x0d,0x62,0xff,0x9c,0x0d,0x64,0xff,0x82,0x0d,0x65,0xff,0x68,0x0d,  \
    0x67,0xff,0x4e,0x0d,0x69,0xff,0x35,0x0d,0x6a,0xff,0x1b,0x0d,0x6c,0xff,0x02,0x0d,0x6e,0xff,0xe9,0x0c,0x70,0xff,0xd0,0x0c,0x72,0xff,0xb7,0x0c,0x73,0xff,0x9e,0x0c,0x75,0xff,0x85,0x0c,0x77,0xff,0x6d,0x0c,0x79,0xff,0x54,0x0c,0x7b,0xff,0x3c,0x0c,0x7d,0xff,0x24,0x0c,0x7f,0xff,0x0c,0x0c,0x81,0xff,0xf4,0x0b,0x83,0xff,0xdc,0x0b,0x85,0xff,0xc4,0x0b,0x87,0xff,0xad,0x0b,0x89,0xff,0x95,0x0b,0x8b,0xff,0x7e,0x0b,0x8d,0xff,0x67,0x0b,0x8f,0xff,0x50,0x0b,0x91,0xff,  \
    0x39,0x0b,0x93,0xff,0x22,0x0b,0x95,0xff,0x0b,0x0b,0x97,0xff,0xf4,0x0a,0x9a,0xff,0xde,0x0a,0x9c,0xff,0xc7,0x0a,0x9e,0xff,0xb1,0x0a,0xa0,0xff,0x9b,0x0a,0xa2,0xff,0x85,0x0a,0xa4,0xff,0x6f,0x0a,0xa7,0xff,0x59,0x0a,0xa9,0xff,0x43,0x0a,0xab,0xff,0x2d,0x0a,0xad,0xff,0x18,0x0a,0xaf,0xff,0x02,0x0a,0xb2,0xff,0xed,0x09,0xb4,0xff,0xd7,0x09,0xb6,0xff,0xc2,0x09,0xb8,0xff,0xad,0x09,0xba,0xff,0x98,0x09,0xbd,0xff,0x83,0x09,0xbf,0xff,0x6e,0x09,0xc1,0xff,0x5a,0x09,  \
    0xc3,0xff,0x45,0x09,0xc6,0xff,0x31,0x09,0xc8,0xff,0x1c,0x09,0xca,0xff,0x08,0x09,0xcc,0xff,0xf4,0x08,0xcf,0xff,0xe0,0x08,0xd1,0xff,0xcc,0x08,0xd3,0xff,0xb8,0x08,0xd5,0xff,0xa4,0x08,0xd8,0xff,0x91,0x08,0xda,0xff,0x7d,0x08,0xdc,0xff,0x6a,0x08,0xde,0xff,0x56,0x08,0xe1,0xff,0x43,0x08,0xe3,0xff,0x30,0x08,0xe5,0xff,0x1d,0x08,0xe7,0xff,0x0a,0x08,0xe9,0xff,0xf7,0x07,0xec,0xff,0xe4,0x07,0xee,0xff,0xd2,0x07,0xf0,0xff,0xbf,0x07,0xf2,0xff,0xad,0x07,0xf5,0xff,  \
    0x9a,0x07,0xf7,0xff,0x88,0x07,0xf9,0xff,0x76,0x07,0xfb,0xff,0x64,0x07,0xfe,0xff,0x52,0x07,0x00,0x00,0x40,0x07,0x02,0x00,0x2e,0x07,0x04,0x00,0x1c,0x07,0x06,0x00,0x0b,0x07,0x09,0x00,0xf9,0x06,0x0b,0x00,0xe8,0x06,0x0d,0x00,0xd7,0x06,0x0f,0x00,0xc5,0x06,0x11,0x00,0xb4,0x06,0x13,0x00,0xa3,0x06,0x15,0x00,0x92,0x06,0x18,0x00,0x81,0x06,0x1a,0x00,0x70,0x06,0x1c,0x00,0x60,0x06,0x1e,0x00,0x4f,0x06,0x20,0x00,0x3e,0x06,0x22,0x00,0x2e,0x06,0x24,0x00,0x1e,0x06,  \
    0x26,0x00,0x0d,0x06,0x28,0x00,0xfd,0x05,0x2a,0x00,0xed,0x05,0x2c,0x00,0xdd,0x05,0x2f,0x00,0xcd,0x05,0x31,0x00,0xbd,0x05,0x33,0x00,0xad,0x05,0x35,0x00,0x9d,0x05,0x37,0x00,0x8e,0x05,0x39,0x00,0x7e,0x05,0x3b,0x00,0x6e,0x05,0x3d,0x00,0x5f,0x05,0x3e,0x00,0x50,0x05,0x40,0x00,0x40,0x05,0x42,0x00,0x31,0x05,0x44,0x00,0x22,0x05,0x46,0x00,0x13,0x05,0x48,0x00,0x04,0x05,0x4a,0x00,0xf5,0x04,0x4c,0x00,0xe6,0x04,0x4e,0x00,0xd7,0x04,0x4f,0x00,0xc8,0x04,0x51,0x00,  \
    0xba,0x04,0x53,0x00,0xab,0x04,0x55,0x00,0x9d,0x04,0x57,0x00,0x8e,0x04,0x58,0x00,0x80,0x04,0x5a,0x00,0x71,0x04,0x5c,0x00,0x63,0x04,0x5e,0x00,0x55,0x04,0x5f,0x00,0x46,0x04,0x61,0x00,0x38,0x04,0x63,0x00,0x2a,0x04,0x65,0x00,0x1c,0x04,0x66,0x00,0x0e,0x04,0x68,0x00,0x00,0x04,0x69,0x00,0xf3,0x03,0x6b,0x00,0xe5,0x03,0x6d,0x00,0xd7,0x03,0x6e,0x00,0xca,0x03,0x70,0x00,0xbc,0x03,0x71,0x00,0xae,0x03,0x73,0x00,0xa1,0x03,0x74,0x00,0x94,0x03,0x76,0x00,0x86,0x03,  \
    0x77,0x00,0x79,0x03,0x79,0x00,0x6c,0x03,0x7a,0x00,0x5f,0x03,0x7c,0x00,0x52,0x03,0x7d,0x00,0x45,0x03,0x7f,0x00,0x38,0x03,0x80,0x00,0x2b,0x03,0x82,0x00,0x1e,0x03,0x83,0x00,0x11,0x03,0x84,0x00,0x04,0x03,0x86,0x00,0xf8,0x02,0x87,0x00,0xeb,0x02,0x88,0x00,0xde,0x02,0x8a,0x00,0xd2,0x02,0x8b,0x00,0xc5,0x02,0x8c,0x00,0xb9,0x02,0x8d,0x00,0xac,0x02,0x8f,0x00,0xa0,0x02,0x90,0x00,0x93,0x02,0x91,0x00,0x87,0x02,0x92,0x00,0x7b,0x02,0x93,0x00,0x6f,0x02,0x94,0x00,  \
    0x62,0x02,0x96,0x00,0x56,0x02,0x97,0x00,0x4a,0x02,0x98,0x00,0x3e,0x02,0x99,0x00,0x32,0x02,0x9a,0x00,0x26,0x02,0x9b,0x00,0x1a,0x02,0x9c,0x00,0x0e,0x02,0x9d,0x00,0x02,0x02,0x9e,0x00,0xf7,0x01,0x9f,0x00,0xeb,0x01,0xa0,0x00,0xdf,0x01,0xa1,0x00,0xd3,0x01,0xa2,0x00,0xc8,0x01,0xa2,0x00,0xbc,0x01,0xa3,0x00,0xb0,0x01,0xa4,0x00,0xa5,0x01,0xa5,0x00,0x99,0x01,0xa6,0x00,0x8e,0x01,0xa7,0x00,0x82,0x01,0xa7,0x00,0x77,0x01,0xa8,0x00,0x6b,0x01,0xa9,0x00,0x60,0x01,  \
    0xaa,0x00,0x54,0x01,0xaa,0x00,0x49,0x01,0xab,0x00,0x3e,0x01,0xac,0x00,0x32,0x01,0xac,0x00,0x27,0x01,0xad,0x00,0x1c,0x01,0xad,0x00,0x11,0x01,0xae,0x00,0x05,0x01,0xaf,0x00,0xfa,0x00,0xaf,0x00,0xef,0x00,0xb0,0x00,0xe4,0x00,0xb0,0x00,0xd8,0x00,0xb1,0x00,0xcd,0x00,0xb1,0x00,0xc2,0x00,0xb2,0x00,0xb7,0x00,0xb2,0x00,0xac,0x00,0xb2,0x00,0xa1,0x00,0xb3,0x00,0x96,0x00,0xb3,0x00,0x8b,0x00,0xb3,0x00,0x80,0x00,0xb4,0x00,0x75,0x00,0xb4,0x00,0x6a,0x00,0xb4,0x00,  \
    0x5f,0x00,0xb5,0x00,0x54,0x00,0xb5,0x00,0x49,0x00,0xb5,0x00,0x3e,0x00,0xb5,0x00,0x33,0x00,0xb6,0x00,0x28,0x00,0xb6,0x00,0x1d,0x00,0xb6,0x00,0x12,0x00,0xb6,0x00,0x07,0x00,0xb6,0x00,0xfc,0xff,0xb6,0x00,0xf1,0xff,0xb6,0x00,0xe6,0xff,0xb6,0x00,0xdb,0xff,0xb6,0x00,0xd0,0xff,0xb6,0x00,0xc5,0xff,0xb6,0x00,0xba,0xff,0xb6,0x00,0xb0,0xff,0xb6,0x00,0xa5,0xff,0xb6,0x00,0x9a,0xff,0xb6,0x00,0x8f,0xff,0xb6,0x00,0x84,0xff,0xb6,0x00,0x79,0xff,0xb6,0x00,0x6e,0xff,  \
    0xb6,0x00,0x63,0xff,0xb6,0x00,0x58,0xff,0xb5,0x00,0x4d,0xff,0xb5,0x00,0x42,0xff,0xb5,0x00,0x37,0xff,0xb5,0x00,0x2c,0xff,0xb4,0x00,0x21,0xff,0xb4,0x00,0x16,0xff,0xb4,0x00,0x0b,0xff,0xb3,0x00,0x00,0xff,0xb3,0x00,0xf5,0xfe,0xb3,0x00,0xea,0xfe,0xb2,0x00,0xdf,0xfe,0xb2,0x00,0xd4,0xfe,0xb2,0x00,0xc9,0xfe,0xb1,0x00,0xbe,0xfe,0xb1,0x00,0xb3,0xfe,0xb0,0x00,0xa7,0xfe,0xb0,0x00,0x9c,0xfe,0xaf,0x00,0x91,0xfe,0xaf,0x00,0x86,0xfe,0xae,0x00,0x7b,0xfe,0xae,0x00,  \
    0x70,0xfe,0xad,0x00,0x65,0xfe,0xac,0x00,0x59,0xfe,0xac,0x00,0x4e,0xfe,0xab,0x00,0x43,0xfe,0xaa,0x00,0x38,0xfe,0xaa,0x00,0x2c,0xfe,0xa9,0x00,0x21,0xfe,0xa8,0x00,0x16,0xfe,0xa8,0x00,0x0a,0xfe,0xa7,0x00,0xff,0xfd,0xa6,0x00,0xf4,0xfd,0xa5,0x00,0xe8,0xfd,0xa4,0x00,0xdd,0xfd,0xa4,0x00,0xd1,0xfd,0xa3,0x00,0xc6,0xfd,0xa2,0x00,0xba,0xfd,0xa1,0x00,0xaf,0xfd,0xa0,0x00,0xa3,0xfd,0x9f,0x00,0x98,0xfd,0x9e,0x00,0x8c,0xfd,0x9d,0x00,0x80,0xfd,0x9c,0x00,0x75,0xfd,  \
    0x9b,0x00,0x69,0xfd,0x9a,0x00,0x5d,0xfd,0x99,0x00,0x51,0xfd,0x98,0x00,0x45,0xfd,0x97,0x00,0x39,0xfd,0x96,0x00,0x2d,0xfd,0x95,0x00,0x21,0xfd,0x94,0x00,0x15,0xfd,0x93,0x00,0x09,0xfd,0x92,0x00,0xfc,0xfc,0x91,0x00,0xf0,0xfc,0x8f,0x00,0xe4,0xfc,0x8e,0x00,0xd8,0xfc,0x8d,0x00,0xcb,0xfc,0x8c,0x00,0xbf,0xfc,0x8b,0x00,0xb2,0xfc,0x89,0x00,0xa6,0xfc,0x88,0x00,0x99,0xfc,0x87,0x00,0x8d,0xfc,0x86,0x00,0x80,0xfc,0x84,0x00,0x73,0xfc,0x83,0x00,0x66,0xfc,0x82,0x00,  \
    0x5a,0xfc,0x80,0x00,0x4d,0xfc,0x7f,0x00,0x40,0xfc,0x7d,0x00,0x33,0xfc,0x7c,0x00,0x26,0xfc,0x7b,0x00,0x19,0xfc,0x79,0x00,0x0c,0xfc,0x78,0x00,0xfe,0xfb,0x76,0x00,0xf1,0xfb,0x75,0x00,0xe4,0xfb,0x73,0x00,0xd7,0xfb,0x72,0x00,0xc9,0xfb,0x70,0x00,0xbc,0xfb,0x6f,0x00,0xae,0xfb,0x6d,0x00,0xa1,0xfb,0x6b,0x00,0x93,0xfb,0x6a,0x00,0x86,0xfb,0x68,0x00,0x78,0xfb,0x67,0x00,0x6a,0xfb,0x65,0x00,0x5c,0xfb,0x63,0x00,0x4e,0xfb,0x62,0x00,0x40,0xfb,0x60,0x00,0x32,0xfb,  \
    0x5e,0x00,0x24,0xfb,0x5d,0x00,0x16,0xfb,0x5b,0x00,0x08,0xfb,0x59,0x00,0xfa,0xfa,0x57,0x00,0xeb,0xfa,0x56,0x00,0xdd,0xfa,0x54,0x00,0xce,0xfa,0x52,0x00,0xc0,0xfa,0x50,0x00,0xb1,0xfa,0x4f,0x00,0xa3,0xfa,0x4d,0x00,0x94,0xfa,0x4b,0x00,0x85,0xfa,0x49,0x00,0x76,0xfa,0x47,0x00,0x67,0xfa,0x45,0x00,0x58,0xfa,0x43,0x00,0x49,0xfa,0x42,0x00,0x3a,0xfa,0x40,0x00,0x2a,0xfa,0x3e,0x00,0x1b,0xfa,0x3c,0x00,0x0c,0xfa,0x3a,0x00,0xfc,0xf9,0x38,0x00,0xed,0xf9,0x36,0x00,  \
    0xdd,0xf9,0x34,0x00,0xcd,0xf9,0x32,0x00,0xbd,0xf9,0x30,0x00,0xad,0xf9,0x2e,0x00,0x9d,0xf9,0x2c,0x00,0x8d,0xf9,0x2a,0x00,0x7d,0xf9,0x28,0x00,0x6d,0xf9,0x26,0x00,0x5d,0xf9,0x24,0x00,0x4c,0xf9,0x22,0x00,0x3c,0xf9,0x20,0x00,0x2b,0xf9,0x1e,0x00,0x1b,0xf9,0x1c,0x00,0x0a,0xf9,0x1a,0x00,0xf9,0xf8,0x18,0x00,0xe8,0xf8,0x16,0x00,0xd7,0xf8,0x14,0x00,0xc6,0xf8,0x12,0x00,0xb5,0xf8,0x0f,0x00,0xa4,0xf8,0x0d,0x00,0x92,0xf8,0x0b,0x00,0x81,0xf8,0x09,0x00,0x6f,0xf8,  \
    0x07,0x00,0x5e,0xf8,0x05,0x00,0x4c,0xf8,0x03,0x00,0x3a,0xf8,0x01,0x00,0x28,0xf8,0xfe,0xff,0x16,0xf8,0xfc,0xff,0x04,0xf8,0xfa,0xff,0xf2,0xf7,0xf8,0xff,0xe0,0xf7,0xf6,0xff,0xcd,0xf7,0xf4,0xff,0xbb,0xf7,0xf2,0xff,0xa8,0xf7,0xef,0xff,0x95,0xf7,0xed,0xff,0x83,0xf7,0xeb,0xff,0x70,0xf7,0xe9,0xff,0x5d,0xf7,0xe7,0xff,0x4a,0xf7,0xe5,0xff,0x36,0xf7,0xe2,0xff,0x23,0xf7,0xe0,0xff,0x10,0xf7,0xde,0xff,0xfc,0xf6,0xdc,0xff,0xe9,0xf6,0xda,0xff,0xd5,0xf6,0xd8,0xff,  \
    0xc1,0xf6,0xd6,0xff,0xad,0xf6,0xd3,0xff,0x99,0xf6,0xd1,0xff,0x85,0xf6,0xcf,0xff,0x71,0xf6,0xcd,0xff,0x5d,0xf6,0xcb,0xff,0x48,0xf6,0xc9,0xff,0x33,0xf6,0xc7,0xff,0x1f,0xf6,0xc4,0xff,0x0a,0xf6,0xc2,0xff,0xf5,0xf5,0xc0,0xff,0xe0,0xf5,0xbe,0xff,0xcb,0xf5,0xbc,0xff,0xb6,0xf5,0xba,0xff,0xa0,0xf5,0xb8,0xff,0x8b,0xf5,0xb6,0xff,0x75,0xf5,0xb4,0xff,0x60,0xf5,0xb2,0xff,0x4a,0xf5,0xb0,0xff,0x34,0xf5,0xad,0xff,0x1e,0xf5,0xab,0xff,0x08,0xf5,0xa9,0xff,0xf1,0xf4,  \
    0xa7,0xff,0xdb,0xf4,0xa5,0xff,0xc5,0xf4,0xa3,0xff,0xae,0xf4,0xa1,0xff,0x97,0xf4,0x9f,0xff,0x81,0xf4,0x9d,0xff,0x6a,0xf4,0x9b,0xff,0x53,0xf4,0x9a,0xff,0x3b,0xf4,0x98,0xff,0x24,0xf4,0x96,0xff,0x0d,0xf4,0x94,0xff,0xf5,0xf3,0x92,0xff,0xdd,0xf3,0x90,0xff,0xc6,0xf3,0x8e,0xff,0xae,0xf3,0x8c,0xff,0x96,0xf3,0x8b,0xff,0x7e,0xf3,0x89,0xff,0x65,0xf3,0x87,0xff,0x4d,0xf3,0x85,0xff,0x34,0xf3,0x83,0xff,0x1c,0xf3,0x82,0xff,0x03,0xf3,0x80,0xff,0xea,0xf2,0x7e,0xff,  \
    0xd1,0xf2,0x7d,0xff,0xb8,0xf2,0x7b,0xff,0x9f,0xf2,0x79,0xff,0x85,0xf2,0x78,0xff,0x6c,0xf2,0x76,0xff,0x52,0xf2,0x75,0xff,0x38,0xf2,0x73,0xff,0x1f,0xf2,0x72,0xff,0x05,0xf2,0x70,0xff,0xea,0xf1,0x6f,0xff,0xd0,0xf1,0x6d,0xff,0xb6,0xf1,0x6c,0xff,0x9b,0xf1,0x6b,0xff,0x81,0xf1,0x69,0xff,0x66,0xf1,0x68,0xff,0x4b,0xf1,0x67,0xff,0x30,0xf1,0x65,0xff,0x15,0xf1,0x64,0xff,0xf9,0xf0,0x63,0xff,0xde,0xf0,0x62,0xff,0xc3,0xf0,0x61,0xff,0xa7,0xf0,0x5f,0xff,0x8b,0xf0,  \
    0x5e,0xff,0x6f,0xf0,0x5d,0xff,0x53,0xf0,0x5c,0xff,0x37,0xf0,0x5b,0xff,0x1b,0xf0,0x5a,0xff,0xfe,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x37,0xff,0x12,0x10,0x38,0xff,0xf5,0x0f,0x39,0xff,  \
    0xd8,0x0f,0x3b,0xff,0xbc,0x0f,0x3c,0xff,0xa0,0x0f,0x3d,0xff,0x84,0x0f,0x3e,0xff,0x68,0x0f,0x3f,0xff,0x4c,0x0f,0x41,0xff,0x30,0x0f,0x42,0xff,0x14,0x0f,0x43,0xff,0xf9,0x0e,0x45,0xff,0xdd,0x0e,0x46,0xff,0xc2,0x0e,0x47,0xff,0xa7,0x0e,0x49,0xff,0x8c,0x0e,0x4a,0xff,0x71,0x0e,0x4c,0xff,0x56,0x0e,0x4d,0xff,0x3b,0x0e,0x4f,0xff,0x21,0x0e,0x51,0xff,0x06,0x0e,0x52,0xff,0xec,0x0d,0x54,0xff,0xd2,0x0d,0x56,0xff,0xb8,0x0d,0x57,0xff,0x9e,0x0d,0x59,0xff,0x84,0x0d,  \
    0x5b,0xff,0x6a,0x0d,0x5d,0xff,0x50,0x0d,0x5e,0xff,0x37,0x0d,0x60,0xff,0x1d,0x0d,0x62,0xff,0x04,0x0d,0x64,0xff,0xeb,0x0c,0x66,0xff,0xd2,0x0c,0x68,0xff,0xb9,0x0c,0x6a,0xff,0xa0,0x0c,0x6b,0xff,0x87,0x0c,0x6d,0xff,0x6f,0x0c,0x6f,0xff,0x56,0x0c,0x71,0xff,0x3e,0x0c,0x73,0xff,0x26,0x0c,0x75,0xff,0x0e,0x0c,0x77,0xff,0xf6,0x0b,0x7a,0xff,0xde,0x0b,0x7c,0xff,0xc6,0x0b,0x7e,0xff,0xaf,0x0b,0x80,0xff,0x97,0x0b,0x82,0xff,0x80,0x0b,0x84,0xff,0x69,0x0b,0x86,0xff,  \
    0x52,0x0b,0x89,0xff,0x3b,0x0b,0x8b,0xff,0x24,0x0b,0x8d,0xff,0x0d,0x0b,0x8f,0xff,0xf7,0x0a,0x91,0xff,0xe0,0x0a,0x94,0xff,0xca,0x0a,0x96,0xff,0xb3,0x0a,0x98,0xff,0x9d,0x0a,0x9a,0xff,0x87,0x0a,0x9d,0xff,0x71,0x0a,0x9f,0xff,0x5b,0x0a,0xa1,0xff,0x45,0x0a,0xa4,0xff,0x30,0x0a,0xa6,0xff,0x1a,0x0a,0xa8,0xff,0x05,0x0a,0xaa,0xff,0xef,0x09,0xad,0xff,0xda,0x09,0xaf,0xff,0xc5,0x09,0xb1,0xff,0xb0,0x09,0xb4,0xff,0x9b,0x09,0xb6,0xff,0x86,0x09,0xb8,0xff,0x71,0x09,  \
    0xbb,0xff,0x5c,0x09,0xbd,0xff,0x48,0x09,0xbf,0xff,0x33,0x09,0xc2,0xff,0x1f,0x09,0xc4,0xff,0x0b,0x09,0xc6,0xff,0xf6,0x08,0xc9,0xff,0xe2,0x08,0xcb,0xff,0xce,0x08,0xcd,0xff,0xbb,0x08,0xd0,0xff,0xa7,0x08,0xd2,0xff,0x93,0x08,0xd4,0xff,0x80,0x08,0xd7,0xff,0x6c,0x08,0xd9,0xff,0x59,0x08,0xdc,0xff,0x46,0x08,0xde,0xff,0x33,0x08,0xe0,0xff,0x1f,0x08,0xe3,0xff,0x0d,0x08,0xe5,0xff,0xfa,0x07,0xe7,0xff,0xe7,0x07,0xea,0xff,0xd4,0x07,0xec,0xff,0xc2,0x07,0xee,0xff,  \
    0xaf,0x07,0xf1,0xff,0x9d,0x07,0xf3,0xff,0x8b,0x07,0xf5,0xff,0x78,0x07,0xf8,0xff,0x66,0x07,0xfa,0xff,0x54,0x07,0xfc,0xff,0x43,0x07,0xfe,0xff,0x31,0x07,0x01,0x00,0x1f,0x07,0x03,0x00,0x0e,0x07,0x05,0x00,0xfc,0x06,0x08,0x00,0xeb,0x06,0x0a,0x00,0xd9,0x06,0x0c,0x00,0xc8,0x06,0x0e,0x00,0xb7,0x06,0x11,0x00,0xa6,0x06,0x13,0x00,0x95,0x06,0x15,0x00,0x84,0x06,0x17,0x00,0x73,0x06,0x1a,0x00,0x62,0x06,0x1c,0x00,0x52,0x06,0x1e,0x00,0x41,0x06,0x20,0x00,0x31,0x06,  \
    0x22,0x00,0x20,0x06,0x24,0x00,0x10,0x06,0x27,0x00,0x00,0x06,0x29,0x00,0xf0,0x05,0x2b,0x00,0xe0,0x05,0x2d,0x00,0xd0,0x05,0x2f,0x00,0xc0,0x05,0x31,0x00,0xb0,0x05,0x33,0x00,0xa0,0x05,0x35,0x00,0x90,0x05,0x37,0x00,0x81,0x05,0x3a,0x00,0x71,0x05,0x3c,0x00,0x62,0x05,0x3e,0x00,0x52,0x05,0x40,0x00,0x43,0x05,0x42,0x00,0x34,0x05,0x44,0x00,0x25,0x05,0x46,0x00,0x16,0x05,0x48,0x00,0x07,0x05,0x4a,0x00,0xf8,0x04,0x4c,0x00,0xe9,0x04,0x4d,0x00,0xda,0x04,0x4f,0x00,  \
    0xcb,0x04,0x51,0x00,0xbc,0x04,0x53,0x00,0xae,0x04,0x55,0x00,0x9f,0x04,0x57,0x00,0x91,0x04,0x59,0x00,0x82,0x04,0x5b,0x00,0x74,0x04,0x5c,0x00,0x65,0x04,0x5e,0x00,0x57,0x04,0x60,0x00,0x49,0x04,0x62,0x00,0x3b,0x04,0x64,0x00,0x2d,0x04,0x65,0x00,0x1f,0x04,0x67,0x00,0x11,0x04,0x69,0x00,0x03,0x04,0x6a,0x00,0xf5,0x03,0x6c,0x00,0xe7,0x03,0x6e,0x00,0xda,0x03,0x70,0x00,0xcc,0x03,0x71,0x00,0xbe,0x03,0x73,0x00,0xb1,0x03,0x74,0x00,0xa3,0x03,0x76,0x00,0x96,0x03,  \
    0x78,0x00,0x89,0x03,0x79,0x00,0x7b,0x03,0x7b,0x00,0x6e,0x03,0x7c,0x00,0x61,0x03,0x7e,0x00,0x54,0x03,0x7f,0x00,0x47,0x03,0x81,0x00,0x3a,0x03,0x82,0x00,0x2d,0x03,0x84,0x00,0x20,0x03,0x85,0x00,0x13,0x03,0x86,0x00,0x06,0x03,0x88,0x00,0xfa,0x02,0x89,0x00,0xed,0x02,0x8b,0x00,0xe0,0x02,0x8c,0x00,0xd4,0x02,0x8d,0x00,0xc7,0x02,0x8f,0x00,0xbb,0x02,0x90,0x00,0xae,0x02,0x91,0x00,0xa2,0x02,0x92,0x00,0x95,0x02,0x94,0x00,0x89,0x02,0x95,0x00,0x7d,0x02,0x96,0x00,  \
    0x70,0x02,0x97,0x00,0x64,0x02,0x98,0x00,0x58,0x02,0x9a,0x00,0x4c,0x02,0x9b,0x00,0x40,0x02,0x9c,0x00,0x34,0x02,0x9d,0x00,0x28,0x02,0x9e,0x00,0x1c,0x02,0x9f,0x00,0x10,0x02,0xa0,0x00,0x04,0x02,0xa1,0x00,0xf8,0x01,0xa2,0x00,0xec,0x01,0xa3,0x00,0xe1,0x01,0xa4,0x00,0xd5,0x01,0xa5,0x00,0xc9,0x01,0xa6,0x00,0xbd,0x01,0xa7,0x00,0xb2,0x01,0xa8,0x00,0xa6,0x01,0xa9,0x00,0x9b,0x01,0xa9,0x00,0x8f,0x01,0xaa,0x00,0x84,0x01,0xab,0x00,0x78,0x01,0xac,0x00,0x6d,0x01,  \
    0xad,0x00,0x61,0x01,0xad,0x00,0x56,0x01,0xae,0x00,0x4a,0x01,0xaf,0x00,0x3f,0x01,0xaf,0x00,0x33,0x01,0xb0,0x00,0x28,0x01,0xb1,0x00,0x1d,0x01,0xb1,0x00,0x12,0x01,0xb2,0x00,0x06,0x01,0xb3,0x00,0xfb,0x00,0xb3,0x00,0xf0,0x00,0xb4,0x00,0xe5,0x00,0xb4,0x00,0xd9,0x00,0xb5,0x00,0xce,0x00,0xb5,0x00,0xc3,0x00,0xb6,0x00,0xb8,0x00,0xb6,0x00,0xad,0x00,0xb7,0x00,0xa2,0x00,0xb7,0x00,0x96,0x00,0xb7,0x00,0x8b,0x00,0xb8,0x00,0x80,0x00,0xb8,0x00,0x75,0x00,0xb8,0x00,  \
    0x6a,0x00,0xb9,0x00,0x5f,0x00,0xb9,0x00,0x54,0x00,0xb9,0x00,0x49,0x00,0xb9,0x00,0x3e,0x00,0xba,0x00,0x33,0x00,0xba,0x00,0x28,0x00,0xba,0x00,0x1d,0x00,0xba,0x00,0x12,0x00,0xba,0x00,0x07,0x00,0xba,0x00,0xfc,0xff,0xbb,0x00,0xf1,0xff,0xbb,0x00,0xe6,0xff,0xbb,0x00,0xdb,0xff,0xbb,0x00,0xd0,0xff,0xbb,0x00,0xc5,0xff,0xbb,0x00,0xba,0xff,0xbb,0x00,0xb0,0xff,0xbb,0x00,0xa5,0xff,0xbb,0x00,0x9a,0xff,0xbb,0x00,0x8f,0xff,0xba,0x00,0x84,0xff,0xba,0x00,0x79,0xff,  \
    0xba,0x00,0x6e,0xff,0xba,0x00,0x63,0xff,0xba,0x00,0x58,0xff,0xba,0x00,0x4d,0xff,0xb9,0x00,0x42,0xff,0xb9,0x00,0x37,0xff,0xb9,0x00,0x2c,0xff,0xb9,0x00,0x21,0xff,0xb8,0x00,0x16,0xff,0xb8,0x00,0x0b,0xff,0xb8,0x00,0x00,0xff,0xb7,0x00,0xf4,0xfe,0xb7,0x00,0xe9,0xfe,0xb7,0x00,0xde,0xfe,0xb6,0x00,0xd3,0xfe,0xb6,0x00,0xc8,0xfe,0xb5,0x00,0xbd,0xfe,0xb5,0x00,0xb2,0xfe,0xb4,0x00,0xa7,0xfe,0xb4,0x00,0x9b,0xfe,0xb3,0x00,0x90,0xfe,0xb3,0x00,0x85,0xfe,0xb2,0x00,  \
    0x7a,0xfe,0xb2,0x00,0x6f,0xfe,0xb1,0x00,0x63,0xfe,0xb0,0x00,0x58,0xfe,0xb0,0x00,0x4d,0xfe,0xaf,0x00,0x42,0xfe,0xae,0x00,0x36,0xfe,0xae,0x00,0x2b,0xfe,0xad,0x00,0x20,0xfe,0xac,0x00,0x14,0xfe,0xab,0x00,0x09,0xfe,0xab,0x00,0xfe,0xfd,0xaa,0x00,0xf2,0xfd,0xa9,0x00,0xe7,0xfd,0xa8,0x00,0xdb,0xfd,0xa7,0x00,0xd0,0xfd,0xa6,0x00,0xc4,0xfd,0xa5,0x00,0xb9,0xfd,0xa5,0x00,0xad,0xfd,0xa4,0x00,0xa2,0xfd,0xa3,0x00,0x96,0xfd,0xa2,0x00,0x8a,0xfd,0xa1,0x00,0x7f,0xfd,  \
    0xa0,0x00,0x73,0xfd,0x9f,0x00,0x67,0xfd,0x9e,0x00,0x5b,0xfd,0x9d,0x00,0x4f,0xfd,0x9b,0x00,0x43,0xfd,0x9a,0x00,0x37,0xfd,0x99,0x00,0x2b,0xfd,0x98,0x00,0x1f,0xfd,0x97,0x00,0x13,0xfd,0x96,0x00,0x07,0xfd,0x95,0x00,0xfb,0xfc,0x93,0x00,0xee,0xfc,0x92,0x00,0xe2,0xfc,0x91,0x00,0xd6,0xfc,0x90,0x00,0xc9,0xfc,0x8e,0x00,0xbd,0xfc,0x8d,0x00,0xb0,0xfc,0x8c,0x00,0xa4,0xfc,0x8b,0x00,0x97,0xfc,0x89,0x00,0x8a,0xfc,0x88,0x00,0x7e,0xfc,0x86,0x00,0x71,0xfc,0x85,0x00,  \
    0x64,0xfc,0x84,0x00,0x57,0xfc,0x82,0x00,0x4a,0xfc,0x81,0x00,0x3d,0xfc,0x7f,0x00,0x30,0xfc,0x7e,0x00,0x23,0xfc,0x7c,0x00,0x16,0xfc,0x7b,0x00,0x09,0xfc,0x79,0x00,0xfc,0xfb,0x78,0x00,0xef,0xfb,0x76,0x00,0xe2,0xfb,0x75,0x00,0xd4,0xfb,0x73,0x00,0xc7,0xfb,0x72,0x00,0xb9,0xfb,0x70,0x00,0xac,0xfb,0x6e,0x00,0x9e,0xfb,0x6d,0x00,0x91,0xfb,0x6b,0x00,0x83,0xfb,0x69,0x00,0x75,0xfb,0x68,0x00,0x68,0xfb,0x66,0x00,0x5a,0xfb,0x64,0x00,0x4c,0xfb,0x63,0x00,0x3e,0xfb,  \
    0x61,0x00,0x30,0xfb,0x5f,0x00,0x22,0xfb,0x5d,0x00,0x13,0xfb,0x5c,0x00,0x05,0xfb,0x5a,0x00,0xf7,0xfa,0x58,0x00,0xe9,0xfa,0x56,0x00,0xda,0xfa,0x54,0x00,0xcc,0xfa,0x52,0x00,0xbd,0xfa,0x51,0x00,0xae,0xfa,0x4f,0x00,0xa0,0xfa,0x4d,0x00,0x91,0xfa,0x4b,0x00,0x82,0xfa,0x49,0x00,0x73,0xfa,0x47,0x00,0x64,0xfa,0x45,0x00,0x55,0xfa,0x43,0x00,0x46,0xfa,0x41,0x00,0x37,0xfa,0x3f,0x00,0x28,0xfa,0x3d,0x00,0x18,0xfa,0x3b,0x00,0x09,0xfa,0x39,0x00,0xf9,0xf9,0x37,0x00,  \
    0xea,0xf9,0x35,0x00,0xda,0xf9,0x33,0x00,0xca,0xf9,0x31,0x00,0xba,0xf9,0x2f,0x00,0xab,0xf9,0x2d,0x00,0x9b,0xf9,0x2b,0x00,0x8b,0xf9,0x29,0x00,0x7a,0xf9,0x27,0x00,0x6a,0xf9,0x25,0x00,0x5a,0xf9,0x22,0x00,0x49,0xf9,0x20,0x00,0x39,0xf9,0x1e,0x00,0x28,0xf9,0x1c,0x00,0x18,0xf9,0x1a,0x00,0x07,0xf9,0x18,0x00,0xf6,0xf8,0x16,0x00,0xe5,0xf8,0x13,0x00,0xd4,0xf8,0x11,0x00,0xc3,0xf8,0x0f,0x00,0xb2,0xf8,0x0d,0x00,0xa1,0xf8,0x0b,0x00,0x8f,0xf8,0x09,0x00,0x7e,0xf8,  \
    0x06,0x00,0x6c,0xf8,0x04,0x00,0x5b,0xf8,0x02,0x00,0x49,0xf8,0x00,0x00,0x37,0xf8,0xfe,0xff,0x25,0xf8,0xfb,0xff,0x13,0xf8,0xf9,0xff,0x01,0xf8,0xf7,0xff,0xef,0xf7,0xf5,0xff,0xdd,0xf7,0xf2,0xff,0xca,0xf7,0xf0,0xff,0xb8,0xf7,0xee,0xff,0xa5,0xf7,0xec,0xff,0x93,0xf7,0xe9,0xff,0x80,0xf7,0xe7,0xff,0x6d,0xf7,0xe5,0xff,0x5a,0xf7,0xe3,0xff,0x47,0xf7,0xe0,0xff,0x34,0xf7,0xde,0xff,0x20,0xf7,0xdc,0xff,0x0d,0xf7,0xda,0xff,0xfa,0xf6,0xd7,0xff,0xe6,0xf6,0xd5,0xff,  \
    0xd2,0xf6,0xd3,0xff,0xbe,0xf6,0xd1,0xff,0xab,0xf6,0xce,0xff,0x97,0xf6,0xcc,0xff,0x82,0xf6,0xca,0xff,0x6e,0xf6,0xc8,0xff,0x5a,0xf6,0xc5,0xff,0x45,0xf6,0xc3,0xff,0x31,0xf6,0xc1,0xff,0x1c,0xf6,0xbf,0xff,0x07,0xf6,0xbd,0xff,0xf2,0xf5,0xba,0xff,0xdd,0xf5,0xb8,0xff,0xc8,0xf5,0xb6,0xff,0xb3,0xf5,0xb4,0xff,0x9e,0xf5,0xb2,0xff,0x88,0xf5,0xaf,0xff,0x73,0xf5,0xad,0xff,0x5d,0xf5,0xab,0xff,0x47,0xf5,0xa9,0xff,0x31,0xf5,0xa7,0xff,0x1b,0xf5,0xa5,0xff,0x05,0xf5,  \
    0xa3,0xff,0xef,0xf4,0xa1,0xff,0xd9,0xf4,0x9e,0xff,0xc2,0xf4,0x9c,0xff,0xac,0xf4,0x9a,0xff,0x95,0xf4,0x98,0xff,0x7e,0xf4,0x96,0xff,0x67,0xf4,0x94,0xff,0x50,0xf4,0x92,0xff,0x39,0xf4,0x90,0xff,0x22,0xf4,0x8e,0xff,0x0a,0xf4,0x8c,0xff,0xf3,0xf3,0x8a,0xff,0xdb,0xf3,0x88,0xff,0xc3,0xf3,0x86,0xff,0xab,0xf3,0x84,0xff,0x93,0xf3,0x83,0xff,0x7b,0xf3,0x81,0xff,0x63,0xf3,0x7f,0xff,0x4b,0xf3,0x7d,0xff,0x32,0xf3,0x7b,0xff,0x1a,0xf3,0x79,0xff,0x01,0xf3,0x78,0xff,  \
    0xe8,0xf2,0x76,0xff,0xcf,0xf2,0x74,0xff,0xb6,0xf2,0x72,0xff,0x9d,0xf2,0x71,0xff,0x83,0xf2,0x6f,0xff,0x6a,0xf2,0x6d,0xff,0x50,0xf2,0x6c,0xff,0x36,0xf2,0x6a,0xff,0x1c,0xf2,0x69,0xff,0x02,0xf2,0x67,0xff,0xe8,0xf1,0x66,0xff,0xce,0xf1,0x64,0xff,0xb4,0xf1,0x63,0xff,0x99,0xf1,0x61,0xff,0x7e,0xf1,0x60,0xff,0x64,0xf1,0x5e,0xff,0x49,0xf1,0x5d,0xff,0x2e,0xf1,0x5c,0xff,0x13,0xf1,0x5b,0xff,0xf7,0xf0,0x59,0xff,0xdc,0xf0,0x58,0xff,0xc0,0xf0,0x57,0xff,0xa5,0xf0,  \
    0x56,0xff,0x89,0xf0,0x55,0xff,0x6d,0xf0,0x53,0xff,0x51,0xf0,0x52,0xff,0x35,0xf0,0x51,0xff,0x19,0xf0,0x50,0xff,0xfc,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2b,0xff,0x13,0x10,0x2c,0xff,  \
    0xf7,0x0f,0x2d,0xff,0xda,0x0f,0x2f,0xff,0xbe,0x0f,0x30,0xff,0xa2,0x0f,0x31,0xff,0x85,0x0f,0x32,0xff,0x69,0x0f,0x34,0xff,0x4e,0x0f,0x35,0xff,0x32,0x0f,0x36,0xff,0x16,0x0f,0x38,0xff,0xfb,0x0e,0x39,0xff,0xdf,0x0e,0x3b,0xff,0xc4,0x0e,0x3c,0xff,0xa9,0x0e,0x3e,0xff,0x8e,0x0e,0x3f,0xff,0x73,0x0e,0x41,0xff,0x58,0x0e,0x42,0xff,0x3d,0x0e,0x44,0xff,0x23,0x0e,0x46,0xff,0x08,0x0e,0x47,0xff,0xee,0x0d,0x49,0xff,0xd4,0x0d,0x4b,0xff,0xba,0x0d,0x4d,0xff,0xa0,0x0d,  \
    0x4e,0xff,0x86,0x0d,0x50,0xff,0x6c,0x0d,0x52,0xff,0x52,0x0d,0x54,0xff,0x39,0x0d,0x56,0xff,0x1f,0x0d,0x58,0xff,0x06,0x0d,0x5a,0xff,0xed,0x0c,0x5c,0xff,0xd4,0x0c,0x5e,0xff,0xbb,0x0c,0x60,0xff,0xa2,0x0c,0x62,0xff,0x8a,0x0c,0x64,0xff,0x71,0x0c,0x66,0xff,0x58,0x0c,0x68,0xff,0x40,0x0c,0x6a,0xff,0x28,0x0c,0x6c,0xff,0x10,0x0c,0x6e,0xff,0xf8,0x0b,0x70,0xff,0xe0,0x0b,0x73,0xff,0xc8,0x0b,0x75,0xff,0xb1,0x0b,0x77,0xff,0x9a,0x0b,0x79,0xff,0x82,0x0b,0x7b,0xff,  \
    0x6b,0x0b,0x7e,0xff,0x54,0x0b,0x80,0xff,0x3d,0x0b,0x82,0xff,0x26,0x0b,0x85,0xff,0x10,0x0b,0x87,0xff,0xf9,0x0a,0x89,0xff,0xe2,0x0a,0x8c,0xff,0xcc,0x0a,0x8e,0xff,0xb6,0x0a,0x90,0xff,0xa0,0x0a,0x93,0xff,0x8a,0x0a,0x95,0xff,0x74,0x0a,0x97,0xff,0x5e,0x0a,0x9a,0xff,0x48,0x0a,0x9c,0xff,0x32,0x0a,0x9f,0xff,0x1d,0x0a,0xa1,0xff,0x07,0x0a,0xa3,0xff,0xf2,0x09,0xa6,0xff,0xdc,0x09,0xa8,0xff,0xc7,0x09,0xab,0xff,0xb2,0x09,0xad,0xff,0x9d,0x09,0xaf,0xff,0x88,0x09,  \
    0xb2,0xff,0x74,0x09,0xb4,0xff,0x5f,0x09,0xb7,0xff,0x4a,0x09,0xb9,0xff,0x36,0x09,0xbc,0xff,0x22,0x09,0xbe,0xff,0x0d,0x09,0xc1,0xff,0xf9,0x08,0xc3,0xff,0xe5,0x08,0xc5,0xff,0xd1,0x08,0xc8,0xff,0xbd,0x08,0xca,0xff,0xaa,0x08,0xcd,0xff,0x96,0x08,0xcf,0xff,0x82,0x08,0xd2,0xff,0x6f,0x08,0xd4,0xff,0x5c,0x08,0xd7,0xff,0x48,0x08,0xd9,0xff,0x35,0x08,0xdb,0xff,0x22,0x08,0xde,0xff,0x0f,0x08,0xe0,0xff,0xfc,0x07,0xe3,0xff,0xea,0x07,0xe5,0xff,0xd7,0x07,0xe8,0xff,  \
    0xc4,0x07,0xea,0xff,0xb2,0x07,0xec,0xff,0xa0,0x07,0xef,0xff,0x8d,0x07,0xf1,0xff,0x7b,0x07,0xf4,0xff,0x69,0x07,0xf6,0xff,0x57,0x07,0xf9,0xff,0x45,0x07,0xfb,0xff,0x34,0x07,0xfd,0xff,0x22,0x07,0x00,0x00,0x10,0x07,0x02,0x00,0xff,0x06,0x04,0x00,0xed,0x06,0x07,0x00,0xdc,0x06,0x09,0x00,0xcb,0x06,0x0c,0x00,0xba,0x06,0x0e,0x00,0xa9,0x06,0x10,0x00,0x98,0x06,0x13,0x00,0x87,0x06,0x15,0x00,0x76,0x06,0x17,0x00,0x65,0x06,0x19,0x00,0x55,0x06,0x1c,0x00,0x44,0x06,  \
    0x1e,0x00,0x34,0x06,0x20,0x00,0x23,0x06,0x23,0x00,0x13,0x06,0x25,0x00,0x03,0x06,0x27,0x00,0xf3,0x05,0x29,0x00,0xe2,0x05,0x2b,0x00,0xd2,0x05,0x2e,0x00,0xc3,0x05,0x30,0x00,0xb3,0x05,0x32,0x00,0xa3,0x05,0x34,0x00,0x93,0x05,0x36,0x00,0x84,0x05,0x39,0x00,0x74,0x05,0x3b,0x00,0x65,0x05,0x3d,0x00,0x55,0x05,0x3f,0x00,0x46,0x05,0x41,0x00,0x37,0x05,0x43,0x00,0x28,0x05,0x45,0x00,0x18,0x05,0x47,0x00,0x09,0x05,0x49,0x00,0xfb,0x04,0x4b,0x00,0xec,0x04,0x4d,0x00,  \
    0xdd,0x04,0x4f,0x00,0xce,0x04,0x51,0x00,0xbf,0x04,0x53,0x00,0xb1,0x04,0x55,0x00,0xa2,0x04,0x57,0x00,0x93,0x04,0x59,0x00,0x85,0x04,0x5b,0x00,0x77,0x04,0x5d,0x00,0x68,0x04,0x5f,0x00,0x5a,0x04,0x61,0x00,0x4c,0x04,0x62,0x00,0x3e,0x04,0x64,0x00,0x2f,0x04,0x66,0x00,0x21,0x04,0x68,0x00,0x13,0x04,0x6a,0x00,0x06,0x04,0x6b,0x00,0xf8,0x03,0x6d,0x00,0xea,0x03,0x6f,0x00,0xdc,0x03,0x71,0x00,0xce,0x03,0x72,0x00,0xc1,0x03,0x74,0x00,0xb3,0x03,0x76,0x00,0xa6,0x03,  \
    0x77,0x00,0x98,0x03,0x79,0x00,0x8b,0x03,0x7b,0x00,0x7e,0x03,0x7c,0x00,0x70,0x03,0x7e,0x00,0x63,0x03,0x7f,0x00,0x56,0x03,0x81,0x00,0x49,0x03,0x83,0x00,0x3c,0x03,0x84,0x00,0x2f,0x03,0x86,0x00,0x22,0x03,0x87,0x00,0x15,0x03,0x89,0x00,0x09,0x03,0x8a,0x00,0xfc,0x02,0x8b,0x00,0xef,0x02,0x8d,0x00,0xe2,0x02,0x8e,0x00,0xd6,0x02,0x90,0x00,0xc9,0x02,0x91,0x00,0xbd,0x02,0x92,0x00,0xb0,0x02,0x94,0x00,0xa4,0x02,0x95,0x00,0x97,0x02,0x96,0x00,0x8b,0x02,0x98,0x00,  \
    0x7f,0x02,0x99,0x00,0x72,0x02,0x9a,0x00,0x66,0x02,0x9b,0x00,0x5a,0x02,0x9c,0x00,0x4e,0x02,0x9e,0x00,0x42,0x02,0x9f,0x00,0x36,0x02,0xa0,0x00,0x2a,0x02,0xa1,0x00,0x1e,0x02,0xa2,0x00,0x12,0x02,0xa3,0x00,0x06,0x02,0xa4,0x00,0xfa,0x01,0xa5,0x00,0xee,0x01,0xa6,0x00,0xe2,0x01,0xa7,0x00,0xd6,0x01,0xa8,0x00,0xcb,0x01,0xa9,0x00,0xbf,0x01,0xaa,0x00,0xb3,0x01,0xab,0x00,0xa8,0x01,0xac,0x00,0x9c,0x01,0xad,0x00,0x90,0x01,0xae,0x00,0x85,0x01,0xaf,0x00,0x79,0x01,  \
    0xaf,0x00,0x6e,0x01,0xb0,0x00,0x62,0x01,0xb1,0x00,0x57,0x01,0xb2,0x00,0x4b,0x01,0xb2,0x00,0x40,0x01,0xb3,0x00,0x35,0x01,0xb4,0x00,0x29,0x01,0xb5,0x00,0x1e,0x01,0xb5,0x00,0x13,0x01,0xb6,0x00,0x07,0x01,0xb6,0x00,0xfc,0x00,0xb7,0x00,0xf1,0x00,0xb8,0x00,0xe5,0x00,0xb8,0x00,0xda,0x00,0xb9,0x00,0xcf,0x00,0xb9,0x00,0xc4,0x00,0xba,0x00,0xb9,0x00,0xba,0x00,0xad,0x00,0xbb,0x00,0xa2,0x00,0xbb,0x00,0x97,0x00,0xbb,0x00,0x8c,0x00,0xbc,0x00,0x81,0x00,0xbc,0x00,  \
    0x76,0x00,0xbc,0x00,0x6b,0x00,0xbd,0x00,0x60,0x00,0xbd,0x00,0x55,0x00,0xbd,0x00,0x4a,0x00,0xbe,0x00,0x3f,0x00,0xbe,0x00,0x33,0x00,0xbe,0x00,0x28,0x00,0xbe,0x00,0x1d,0x00,0xbe,0x00,0x12,0x00,0xbf,0x00,0x07,0x00,0xbf,0x00,0xfc,0xff,0xbf,0x00,0xf1,0xff,0xbf,0x00,0xe6,0xff,0xbf,0x00,0xdb,0xff,0xbf,0x00,0xd0,0xff,0xbf,0x00,0xc5,0xff,0xbf,0x00,0xba,0xff,0xbf,0x00,0xaf,0xff,0xbf,0x00,0xa4,0xff,0xbf,0x00,0x99,0xff,0xbf,0x00,0x8e,0xff,0xbf,0x00,0x83,0xff,  \
    0xbf,0x00,0x78,0xff,0xbe,0x00,0x6d,0xff,0xbe,0x00,0x62,0xff,0xbe,0x00,0x57,0xff,0xbe,0x00,0x4c,0xff,0xbe,0x00,0x41,0xff,0xbd,0x00,0x36,0xff,0xbd,0x00,0x2b,0xff,0xbd,0x00,0x20,0xff,0xbd,0x00,0x15,0xff,0xbc,0x00,0x0a,0xff,0xbc,0x00,0xff,0xfe,0xbb,0x00,0xf4,0xfe,0xbb,0x00,0xe9,0xfe,0xbb,0x00,0xde,0xfe,0xba,0x00,0xd2,0xfe,0xba,0x00,0xc7,0xfe,0xb9,0x00,0xbc,0xfe,0xb9,0x00,0xb1,0xfe,0xb8,0x00,0xa6,0xfe,0xb8,0x00,0x9a,0xfe,0xb7,0x00,0x8f,0xfe,0xb7,0x00,  \
    0x84,0xfe,0xb6,0x00,0x79,0xfe,0xb5,0x00,0x6e,0xfe,0xb5,0x00,0x62,0xfe,0xb4,0x00,0x57,0xfe,0xb3,0x00,0x4c,0xfe,0xb3,0x00,0x40,0xfe,0xb2,0x00,0x35,0xfe,0xb1,0x00,0x2a,0xfe,0xb1,0x00,0x1f,0xfe,0xb0,0x00,0x13,0xfe,0xaf,0x00,0x08,0xfe,0xae,0x00,0xfc,0xfd,0xad,0x00,0xf1,0xfd,0xac,0x00,0xe5,0xfd,0xac,0x00,0xda,0xfd,0xab,0x00,0xce,0xfd,0xaa,0x00,0xc3,0xfd,0xa9,0x00,0xb7,0xfd,0xa8,0x00,0xac,0xfd,0xa7,0x00,0xa0,0xfd,0xa6,0x00,0x94,0xfd,0xa5,0x00,0x89,0xfd,  \
    0xa4,0x00,0x7d,0xfd,0xa3,0x00,0x71,0xfd,0xa2,0x00,0x65,0xfd,0xa1,0x00,0x5a,0xfd,0xa0,0x00,0x4e,0xfd,0x9f,0x00,0x42,0xfd,0x9d,0x00,0x36,0xfd,0x9c,0x00,0x29,0xfd,0x9b,0x00,0x1d,0xfd,0x9a,0x00,0x11,0xfd,0x99,0x00,0x05,0xfd,0x97,0x00,0xf9,0xfc,0x96,0x00,0xec,0xfc,0x95,0x00,0xe0,0xfc,0x94,0x00,0xd4,0xfc,0x92,0x00,0xc7,0xfc,0x91,0x00,0xbb,0xfc,0x90,0x00,0xae,0xfc,0x8e,0x00,0xa1,0xfc,0x8d,0x00,0x95,0xfc,0x8c,0x00,0x88,0xfc,0x8a,0x00,0x7b,0xfc,0x89,0x00,  \
    0x6f,0xfc,0x87,0x00,0x62,0xfc,0x86,0x00,0x55,0xfc,0x84,0x00,0x48,0xfc,0x83,0x00,0x3b,0xfc,0x81,0x00,0x2e,0xfc,0x80,0x00,0x21,0xfc,0x7e,0x00,0x14,0xfc,0x7d,0x00,0x07,0xfc,0x7b,0x00,0xf9,0xfb,0x7a,0x00,0xec,0xfb,0x78,0x00,0xdf,0xfb,0x76,0x00,0xd2,0xfb,0x75,0x00,0xc4,0xfb,0x73,0x00,0xb7,0xfb,0x71,0x00,0xa9,0xfb,0x70,0x00,0x9c,0xfb,0x6e,0x00,0x8e,0xfb,0x6c,0x00,0x80,0xfb,0x6b,0x00,0x73,0xfb,0x69,0x00,0x65,0xfb,0x67,0x00,0x57,0xfb,0x65,0x00,0x49,0xfb,  \
    0x63,0x00,0x3b,0xfb,0x62,0x00,0x2d,0xfb,0x60,0x00,0x1f,0xfb,0x5e,0x00,0x11,0xfb,0x5c,0x00,0x02,0xfb,0x5a,0x00,0xf4,0xfa,0x58,0x00,0xe6,0xfa,0x56,0x00,0xd7,0xfa,0x55,0x00,0xc9,0xfa,0x53,0x00,0xba,0xfa,0x51,0x00,0xac,0xfa,0x4f,0x00,0x9d,0xfa,0x4d,0x00,0x8e,0xfa,0x4b,0x00,0x7f,0xfa,0x49,0x00,0x70,0xfa,0x47,0x00,0x61,0xfa,0x45,0x00,0x52,0xfa,0x43,0x00,0x43,0xfa,0x41,0x00,0x34,0xfa,0x3f,0x00,0x25,0xfa,0x3d,0x00,0x15,0xfa,0x3b,0x00,0x06,0xfa,0x38,0x00,  \
    0xf6,0xf9,0x36,0x00,0xe7,0xf9,0x34,0x00,0xd7,0xf9,0x32,0x00,0xc7,0xf9,0x30,0x00,0xb8,0xf9,0x2e,0x00,0xa8,0xf9,0x2c,0x00,0x98,0xf9,0x2a,0x00,0x88,0xf9,0x27,0x00,0x77,0xf9,0x25,0x00,0x67,0xf9,0x23,0x00,0x57,0xf9,0x21,0x00,0x46,0xf9,0x1f,0x00,0x36,0xf9,0x1c,0x00,0x25,0xf9,0x1a,0x00,0x15,0xf9,0x18,0x00,0x04,0xf9,0x16,0x00,0xf3,0xf8,0x14,0x00,0xe2,0xf8,0x11,0x00,0xd1,0xf8,0x0f,0x00,0xc0,0xf8,0x0d,0x00,0xaf,0xf8,0x0a,0x00,0x9e,0xf8,0x08,0x00,0x8c,0xf8,  \
    0x06,0x00,0x7b,0xf8,0x04,0x00,0x69,0xf8,0x01,0x00,0x58,0xf8,0xff,0xff,0x46,0xf8,0xfd,0xff,0x34,0xf8,0xfa,0xff,0x22,0xf8,0xf8,0xff,0x10,0xf8,0xf6,0xff,0xfe,0xf7,0xf3,0xff,0xec,0xf7,0xf1,0xff,0xda,0xf7,0xef,0xff,0xc7,0xf7,0xed,0xff,0xb5,0xf7,0xea,0xff,0xa2,0xf7,0xe8,0xff,0x90,0xf7,0xe5,0xff,0x7d,0xf7,0xe3,0xff,0x6a,0xf7,0xe1,0xff,0x57,0xf7,0xde,0xff,0x44,0xf7,0xdc,0xff,0x31,0xf7,0xda,0xff,0x1e,0xf7,0xd7,0xff,0x0a,0xf7,0xd5,0xff,0xf7,0xf6,0xd3,0xff,  \
    0xe3,0xf6,0xd0,0xff,0xcf,0xf6,0xce,0xff,0xbc,0xf6,0xcc,0xff,0xa8,0xf6,0xc9,0xff,0x94,0xf6,0xc7,0xff,0x80,0xf6,0xc5,0xff,0x6b,0xf6,0xc2,0xff,0x57,0xf6,0xc0,0xff,0x43,0xf6,0xbe,0xff,0x2e,0xf6,0xbc,0xff,0x19,0xf6,0xb9,0xff,0x05,0xf6,0xb7,0xff,0xf0,0xf5,0xb5,0xff,0xdb,0xf5,0xb2,0xff,0xc6,0xf5,0xb0,0xff,0xb0,0xf5,0xae,0xff,0x9b,0xf5,0xac,0xff,0x86,0xf5,0xa9,0xff,0x70,0xf5,0xa7,0xff,0x5a,0xf5,0xa5,0xff,0x45,0xf5,0xa3,0xff,0x2f,0xf5,0xa0,0xff,0x19,0xf5,  \
    0x9e,0xff,0x03,0xf5,0x9c,0xff,0xec,0xf4,0x9a,0xff,0xd6,0xf4,0x98,0xff,0xbf,0xf4,0x95,0xff,0xa9,0xf4,0x93,0xff,0x92,0xf4,0x91,0xff,0x7b,0xf4,0x8f,0xff,0x65,0xf4,0x8d,0xff,0x4e,0xf4,0x8b,0xff,0x36,0xf4,0x89,0xff,0x1f,0xf4,0x87,0xff,0x08,0xf4,0x85,0xff,0xf0,0xf3,0x83,0xff,0xd9,0xf3,0x81,0xff,0xc1,0xf3,0x7f,0xff,0xa9,0xf3,0x7d,0xff,0x91,0xf3,0x7b,0xff,0x79,0xf3,0x79,0xff,0x61,0xf3,0x77,0xff,0x48,0xf3,0x75,0xff,0x30,0xf3,0x73,0xff,0x17,0xf3,0x71,0xff,  \
    0xfe,0xf2,0x6f,0xff,0xe5,0xf2,0x6d,0xff,0xcc,0xf2,0x6c,0xff,0xb3,0xf2,0x6a,0xff,0x9a,0xf2,0x68,0xff,0x81,0xf2,0x66,0xff,0x67,0xf2,0x65,0xff,0x4e,0xf2,0x63,0xff,0x34,0xf2,0x61,0xff,0x1a,0xf2,0x60,0xff,0x00,0xf2,0x5e,0xff,0xe6,0xf1,0x5d,0xff,0xcc,0xf1,0x5b,0xff,0xb1,0xf1,0x5a,0xff,0x97,0xf1,0x58,0xff,0x7c,0xf1,0x57,0xff,0x61,0xf1,0x55,0xff,0x46,0xf1,0x54,0xff,0x2b,0xf1,0x52,0xff,0x10,0xf1,0x51,0xff,0xf5,0xf0,0x50,0xff,0xda,0xf0,0x4e,0xff,0xbe,0xf0,  \
    0x4d,0xff,0xa3,0xf0,0x4c,0xff,0x87,0xf0,0x4b,0xff,0x6b,0xf0,0x4a,0xff,0x4f,0xf0,0x49,0xff,0x33,0xf0,0x47,0xff,0x16,0xf0,0x46,0xff,0xfa,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1f,0xff,  \
    0x15,0x10,0x20,0xff,0xf9,0x0f,0x21,0xff,0xdc,0x0f,0x23,0xff,0xc0,0x0f,0x24,0xff,0xa4,0x0f,0x25,0xff,0x87,0x0f,0x27,0xff,0x6b,0x0f,0x28,0xff,0x4f,0x0f,0x29,0xff,0x34,0x0f,0x2b,0xff,0x18,0x0f,0x2c,0xff,0xfd,0x0e,0x2e,0xff,0xe1,0x0e,0x2f,0xff,0xc6,0x0e,0x31,0xff,0xab,0x0e,0x32,0xff,0x90,0x0e,0x34,0xff,0x75,0x0e,0x36,0xff,0x5a,0x0e,0x37,0xff,0x3f,0x0e,0x39,0xff,0x25,0x0e,0x3b,0xff,0x0a,0x0e,0x3c,0xff,0xf0,0x0d,0x3e,0xff,0xd6,0x0d,0x40,0xff,0xbc,0x0d,  \
    0x42,0xff,0xa2,0x0d,0x44,0xff,0x88,0x0d,0x46,0xff,0x6e,0x0d,0x48,0xff,0x54,0x0d,0x4a,0xff,0x3b,0x0d,0x4b,0xff,0x22,0x0d,0x4d,0xff,0x08,0x0d,0x50,0xff,0xef,0x0c,0x52,0xff,0xd6,0x0c,0x54,0xff,0xbd,0x0c,0x56,0xff,0xa4,0x0c,0x58,0xff,0x8c,0x0c,0x5a,0xff,0x73,0x0c,0x5c,0xff,0x5b,0x0c,0x5e,0xff,0x42,0x0c,0x60,0xff,0x2a,0x0c,0x63,0xff,0x12,0x0c,0x65,0xff,0xfa,0x0b,0x67,0xff,0xe2,0x0b,0x69,0xff,0xcb,0x0b,0x6c,0xff,0xb3,0x0b,0x6e,0xff,0x9c,0x0b,0x70,0xff,  \
    0x85,0x0b,0x73,0xff,0x6d,0x0b,0x75,0xff,0x56,0x0b,0x77,0xff,0x3f,0x0b,0x7a,0xff,0x29,0x0b,0x7c,0xff,0x12,0x0b,0x7f,0xff,0xfb,0x0a,0x81,0xff,0xe5,0x0a,0x84,0xff,0xcf,0x0a,0x86,0xff,0xb8,0x0a,0x88,0xff,0xa2,0x0a,0x8b,0xff,0x8c,0x0a,0x8d,0xff,0x76,0x0a,0x90,0xff,0x60,0x0a,0x92,0xff,0x4b,0x0a,0x95,0xff,0x35,0x0a,0x97,0xff,0x1f,0x0a,0x9a,0xff,0x0a,0x0a,0x9c,0xff,0xf4,0x09,0x9f,0xff,0xdf,0x09,0xa1,0xff,0xca,0x09,0xa4,0xff,0xb5,0x09,0xa6,0xff,0xa0,0x09,  \
    0xa9,0xff,0x8b,0x09,0xab,0xff,0x76,0x09,0xae,0xff,0x62,0x09,0xb0,0xff,0x4d,0x09,0xb3,0xff,0x39,0x09,0xb6,0xff,0x24,0x09,0xb8,0xff,0x10,0x09,0xbb,0xff,0xfc,0x08,0xbd,0xff,0xe8,0x08,0xc0,0xff,0xd4,0x08,0xc2,0xff,0xc0,0x08,0xc5,0xff,0xac,0x08,0xc7,0xff,0x99,0x08,0xca,0xff,0x85,0x08,0xcc,0xff,0x72,0x08,0xcf,0xff,0x5f,0x08,0xd2,0xff,0x4b,0x08,0xd4,0xff,0x38,0x08,0xd7,0xff,0x25,0x08,0xd9,0xff,0x12,0x08,0xdc,0xff,0xff,0x07,0xde,0xff,0xed,0x07,0xe1,0xff,  \
    0xda,0x07,0xe3,0xff,0xc7,0x07,0xe6,0xff,0xb5,0x07,0xe8,0xff,0xa3,0x07,0xeb,0xff,0x90,0x07,0xed,0xff,0x7e,0x07,0xf0,0xff,0x6c,0x07,0xf2,0xff,0x5a,0x07,0xf5,0xff,0x48,0x07,0xf7,0xff,0x37,0x07,0xfa,0xff,0x25,0x07,0xfc,0xff,0x13,0x07,0xff,0xff,0x02,0x07,0x01,0x00,0xf0,0x06,0x04,0x00,0xdf,0x06,0x06,0x00,0xce,0x06,0x09,0x00,0xbd,0x06,0x0b,0x00,0xac,0x06,0x0e,0x00,0x9b,0x06,0x10,0x00,0x8a,0x06,0x12,0x00,0x79,0x06,0x15,0x00,0x68,0x06,0x17,0x00,0x58,0x06,  \
    0x1a,0x00,0x47,0x06,0x1c,0x00,0x37,0x06,0x1e,0x00,0x26,0x06,0x21,0x00,0x16,0x06,0x23,0x00,0x06,0x06,0x25,0x00,0xf6,0x05,0x28,0x00,0xe6,0x05,0x2a,0x00,0xd6,0x05,0x2c,0x00,0xc6,0x05,0x2e,0x00,0xb6,0x05,0x31,0x00,0xa6,0x05,0x33,0x00,0x96,0x05,0x35,0x00,0x87,0x05,0x37,0x00,0x77,0x05,0x3a,0x00,0x68,0x05,0x3c,0x00,0x58,0x05,0x3e,0x00,0x49,0x05,0x40,0x00,0x3a,0x05,0x42,0x00,0x2b,0x05,0x45,0x00,0x1b,0x05,0x47,0x00,0x0c,0x05,0x49,0x00,0xfe,0x04,0x4b,0x00,  \
    0xef,0x04,0x4d,0x00,0xe0,0x04,0x4f,0x00,0xd1,0x04,0x51,0x00,0xc2,0x04,0x53,0x00,0xb4,0x04,0x55,0x00,0xa5,0x04,0x57,0x00,0x96,0x04,0x59,0x00,0x88,0x04,0x5b,0x00,0x79,0x04,0x5d,0x00,0x6b,0x04,0x5f,0x00,0x5d,0x04,0x61,0x00,0x4e,0x04,0x63,0x00,0x40,0x04,0x65,0x00,0x32,0x04,0x67,0x00,0x24,0x04,0x69,0x00,0x16,0x04,0x6b,0x00,0x08,0x04,0x6c,0x00,0xfa,0x03,0x6e,0x00,0xed,0x03,0x70,0x00,0xdf,0x03,0x72,0x00,0xd1,0x03,0x74,0x00,0xc3,0x03,0x75,0x00,0xb6,0x03,  \
    0x77,0x00,0xa8,0x03,0x79,0x00,0x9b,0x03,0x7b,0x00,0x8e,0x03,0x7c,0x00,0x80,0x03,0x7e,0x00,0x73,0x03,0x80,0x00,0x66,0x03,0x81,0x00,0x59,0x03,0x83,0x00,0x4c,0x03,0x84,0x00,0x3f,0x03,0x86,0x00,0x32,0x03,0x88,0x00,0x25,0x03,0x89,0x00,0x18,0x03,0x8b,0x00,0x0b,0x03,0x8c,0x00,0xfe,0x02,0x8e,0x00,0xf1,0x02,0x8f,0x00,0xe5,0x02,0x91,0x00,0xd8,0x02,0x92,0x00,0xcb,0x02,0x93,0x00,0xbf,0x02,0x95,0x00,0xb2,0x02,0x96,0x00,0xa6,0x02,0x98,0x00,0x99,0x02,0x99,0x00,  \
    0x8d,0x02,0x9a,0x00,0x81,0x02,0x9c,0x00,0x74,0x02,0x9d,0x00,0x68,0x02,0x9e,0x00,0x5c,0x02,0x9f,0x00,0x50,0x02,0xa1,0x00,0x44,0x02,0xa2,0x00,0x37,0x02,0xa3,0x00,0x2b,0x02,0xa4,0x00,0x1f,0x02,0xa5,0x00,0x13,0x02,0xa6,0x00,0x08,0x02,0xa7,0x00,0xfc,0x01,0xa8,0x00,0xf0,0x01,0xaa,0x00,0xe4,0x01,0xab,0x00,0xd8,0x01,0xac,0x00,0xcc,0x01,0xad,0x00,0xc1,0x01,0xae,0x00,0xb5,0x01,0xaf,0x00,0xa9,0x01,0xaf,0x00,0x9e,0x01,0xb0,0x00,0x92,0x01,0xb1,0x00,0x86,0x01,  \
    0xb2,0x00,0x7b,0x01,0xb3,0x00,0x6f,0x01,0xb4,0x00,0x64,0x01,0xb5,0x00,0x58,0x01,0xb5,0x00,0x4d,0x01,0xb6,0x00,0x41,0x01,0xb7,0x00,0x36,0x01,0xb8,0x00,0x2a,0x01,0xb8,0x00,0x1f,0x01,0xb9,0x00,0x14,0x01,0xba,0x00,0x08,0x01,0xba,0x00,0xfd,0x00,0xbb,0x00,0xf2,0x00,0xbb,0x00,0xe6,0x00,0xbc,0x00,0xdb,0x00,0xbd,0x00,0xd0,0x00,0xbd,0x00,0xc5,0x00,0xbe,0x00,0xb9,0x00,0xbe,0x00,0xae,0x00,0xbf,0x00,0xa3,0x00,0xbf,0x00,0x98,0x00,0xbf,0x00,0x8d,0x00,0xc0,0x00,  \
    0x82,0x00,0xc0,0x00,0x76,0x00,0xc1,0x00,0x6b,0x00,0xc1,0x00,0x60,0x00,0xc1,0x00,0x55,0x00,0xc1,0x00,0x4a,0x00,0xc2,0x00,0x3f,0x00,0xc2,0x00,0x34,0x00,0xc2,0x00,0x29,0x00,0xc2,0x00,0x1e,0x00,0xc3,0x00,0x13,0x00,0xc3,0x00,0x08,0x00,0xc3,0x00,0xfd,0xff,0xc3,0x00,0xf2,0xff,0xc3,0x00,0xe7,0xff,0xc3,0x00,0xdb,0xff,0xc3,0x00,0xd0,0xff,0xc3,0x00,0xc5,0xff,0xc3,0x00,0xba,0xff,0xc3,0x00,0xaf,0xff,0xc3,0x00,0xa4,0xff,0xc3,0x00,0x99,0xff,0xc3,0x00,0x8e,0xff,  \
    0xc3,0x00,0x83,0xff,0xc3,0x00,0x78,0xff,0xc3,0x00,0x6d,0xff,0xc2,0x00,0x62,0xff,0xc2,0x00,0x57,0xff,0xc2,0x00,0x4c,0xff,0xc2,0x00,0x41,0xff,0xc1,0x00,0x36,0xff,0xc1,0x00,0x2b,0xff,0xc1,0x00,0x20,0xff,0xc1,0x00,0x14,0xff,0xc0,0x00,0x09,0xff,0xc0,0x00,0xfe,0xfe,0xbf,0x00,0xf3,0xfe,0xbf,0x00,0xe8,0xfe,0xbf,0x00,0xdd,0xfe,0xbe,0x00,0xd2,0xfe,0xbe,0x00,0xc6,0xfe,0xbd,0x00,0xbb,0xfe,0xbd,0x00,0xb0,0xfe,0xbc,0x00,0xa5,0xfe,0xbc,0x00,0x99,0xfe,0xbb,0x00,  \
    0x8e,0xfe,0xba,0x00,0x83,0xfe,0xba,0x00,0x78,0xfe,0xb9,0x00,0x6c,0xfe,0xb9,0x00,0x61,0xfe,0xb8,0x00,0x56,0xfe,0xb7,0x00,0x4b,0xfe,0xb6,0x00,0x3f,0xfe,0xb6,0x00,0x34,0xfe,0xb5,0x00,0x29,0xfe,0xb4,0x00,0x1d,0xfe,0xb3,0x00,0x12,0xfe,0xb3,0x00,0x06,0xfe,0xb2,0x00,0xfb,0xfd,0xb1,0x00,0xef,0xfd,0xb0,0x00,0xe4,0xfd,0xaf,0x00,0xd8,0xfd,0xae,0x00,0xcd,0xfd,0xad,0x00,0xc1,0xfd,0xac,0x00,0xb6,0xfd,0xab,0x00,0xaa,0xfd,0xaa,0x00,0x9e,0xfd,0xa9,0x00,0x93,0xfd,  \
    0xa8,0x00,0x87,0xfd,0xa7,0x00,0x7b,0xfd,0xa6,0x00,0x70,0xfd,0xa5,0x00,0x64,0xfd,0xa4,0x00,0x58,0xfd,0xa3,0x00,0x4c,0xfd,0xa1,0x00,0x40,0xfd,0xa0,0x00,0x34,0xfd,0x9f,0x00,0x28,0xfd,0x9e,0x00,0x1b,0xfd,0x9d,0x00,0x0f,0xfd,0x9b,0x00,0x03,0xfd,0x9a,0x00,0xf7,0xfc,0x99,0x00,0xea,0xfc,0x98,0x00,0xde,0xfc,0x96,0x00,0xd1,0xfc,0x95,0x00,0xc5,0xfc,0x93,0x00,0xb8,0xfc,0x92,0x00,0xac,0xfc,0x91,0x00,0x9f,0xfc,0x8f,0x00,0x93,0xfc,0x8e,0x00,0x86,0xfc,0x8c,0x00,  \
    0x79,0xfc,0x8b,0x00,0x6c,0xfc,0x89,0x00,0x5f,0xfc,0x88,0x00,0x53,0xfc,0x86,0x00,0x46,0xfc,0x85,0x00,0x39,0xfc,0x83,0x00,0x2b,0xfc,0x82,0x00,0x1e,0xfc,0x80,0x00,0x11,0xfc,0x7e,0x00,0x04,0xfc,0x7d,0x00,0xf7,0xfb,0x7b,0x00,0xea,0xfb,0x7a,0x00,0xdc,0xfb,0x78,0x00,0xcf,0xfb,0x76,0x00,0xc2,0xfb,0x74,0x00,0xb4,0xfb,0x73,0x00,0xa7,0xfb,0x71,0x00,0x99,0xfb,0x6f,0x00,0x8b,0xfb,0x6d,0x00,0x7e,0xfb,0x6c,0x00,0x70,0xfb,0x6a,0x00,0x62,0xfb,0x68,0x00,0x54,0xfb,  \
    0x66,0x00,0x46,0xfb,0x64,0x00,0x38,0xfb,0x62,0x00,0x2a,0xfb,0x60,0x00,0x1c,0xfb,0x5f,0x00,0x0e,0xfb,0x5d,0x00,0xff,0xfa,0x5b,0x00,0xf1,0xfa,0x59,0x00,0xe3,0xfa,0x57,0x00,0xd4,0xfa,0x55,0x00,0xc6,0xfa,0x53,0x00,0xb7,0xfa,0x51,0x00,0xa9,0xfa,0x4f,0x00,0x9a,0xfa,0x4d,0x00,0x8b,0xfa,0x4b,0x00,0x7c,0xfa,0x49,0x00,0x6d,0xfa,0x47,0x00,0x5e,0xfa,0x44,0x00,0x4f,0xfa,0x42,0x00,0x40,0xfa,0x40,0x00,0x31,0xfa,0x3e,0x00,0x22,0xfa,0x3c,0x00,0x12,0xfa,0x3a,0x00,  \
    0x03,0xfa,0x38,0x00,0xf3,0xf9,0x36,0x00,0xe4,0xf9,0x33,0x00,0xd4,0xf9,0x31,0x00,0xc4,0xf9,0x2f,0x00,0xb4,0xf9,0x2d,0x00,0xa4,0xf9,0x2b,0x00,0x94,0xf9,0x28,0x00,0x84,0xf9,0x26,0x00,0x74,0xf9,0x24,0x00,0x64,0xf9,0x21,0x00,0x54,0xf9,0x1f,0x00,0x43,0xf9,0x1d,0x00,0x33,0xf9,0x1b,0x00,0x22,0xf9,0x18,0x00,0x12,0xf9,0x16,0x00,0x01,0xf9,0x14,0x00,0xf0,0xf8,0x11,0x00,0xdf,0xf8,0x0f,0x00,0xce,0xf8,0x0d,0x00,0xbd,0xf8,0x0a,0x00,0xac,0xf8,0x08,0x00,0x9b,0xf8,  \
    0x06,0x00,0x89,0xf8,0x03,0x00,0x78,0xf8,0x01,0x00,0x66,0xf8,0xff,0xff,0x55,0xf8,0xfc,0xff,0x43,0xf8,0xfa,0xff,0x31,0xf8,0xf7,0xff,0x1f,0xf8,0xf5,0xff,0x0d,0xf8,0xf3,0xff,0xfb,0xf7,0xf0,0xff,0xe9,0xf7,0xee,0xff,0xd7,0xf7,0xeb,0xff,0xc4,0xf7,0xe9,0xff,0xb2,0xf7,0xe6,0xff,0x9f,0xf7,0xe4,0xff,0x8d,0xf7,0xe2,0xff,0x7a,0xf7,0xdf,0xff,0x67,0xf7,0xdd,0xff,0x54,0xf7,0xda,0xff,0x41,0xf7,0xd8,0xff,0x2e,0xf7,0xd6,0xff,0x1b,0xf7,0xd3,0xff,0x07,0xf7,0xd1,0xff,  \
    0xf4,0xf6,0xce,0xff,0xe0,0xf6,0xcc,0xff,0xcc,0xf6,0xc9,0xff,0xb9,0xf6,0xc7,0xff,0xa5,0xf6,0xc5,0xff,0x91,0xf6,0xc2,0xff,0x7d,0xf6,0xc0,0xff,0x68,0xf6,0xbd,0xff,0x54,0xf6,0xbb,0xff,0x40,0xf6,0xb9,0xff,0x2b,0xf6,0xb6,0xff,0x16,0xf6,0xb4,0xff,0x02,0xf6,0xb1,0xff,0xed,0xf5,0xaf,0xff,0xd8,0xf5,0xad,0xff,0xc3,0xf5,0xaa,0xff,0xad,0xf5,0xa8,0xff,0x98,0xf5,0xa6,0xff,0x83,0xf5,0xa3,0xff,0x6d,0xf5,0xa1,0xff,0x58,0xf5,0x9f,0xff,0x42,0xf5,0x9c,0xff,0x2c,0xf5,  \
    0x9a,0xff,0x16,0xf5,0x98,0xff,0x00,0xf5,0x95,0xff,0xea,0xf4,0x93,0xff,0xd3,0xf4,0x91,0xff,0xbd,0xf4,0x8f,0xff,0xa6,0xf4,0x8c,0xff,0x90,0xf4,0x8a,0xff,0x79,0xf4,0x88,0xff,0x62,0xf4,0x86,0xff,0x4b,0xf4,0x84,0xff,0x34,0xf4,0x81,0xff,0x1c,0xf4,0x7f,0xff,0x05,0xf4,0x7d,0xff,0xee,0xf3,0x7b,0xff,0xd6,0xf3,0x79,0xff,0xbe,0xf3,0x77,0xff,0xa6,0xf3,0x75,0xff,0x8e,0xf3,0x73,0xff,0x76,0xf3,0x71,0xff,0x5e,0xf3,0x6f,0xff,0x46,0xf3,0x6d,0xff,0x2d,0xf3,0x6b,0xff,  \
    0x15,0xf3,0x69,0xff,0xfc,0xf2,0x67,0xff,0xe3,0xf2,0x65,0xff,0xca,0xf2,0x63,0xff,0xb1,0xf2,0x61,0xff,0x98,0xf2,0x60,0xff,0x7e,0xf2,0x5e,0xff,0x65,0xf2,0x5c,0xff,0x4b,0xf2,0x5a,0xff,0x31,0xf2,0x59,0xff,0x18,0xf2,0x57,0xff,0xfe,0xf1,0x55,0xff,0xe3,0xf1,0x54,0xff,0xc9,0xf1,0x52,0xff,0xaf,0xf1,0x50,0xff,0x94,0xf1,0x4f,0xff,0x7a,0xf1,0x4d,0xff,0x5f,0xf1,0x4c,0xff,0x44,0xf1,0x4a,0xff,0x29,0xf1,0x49,0xff,0x0e,0xf1,0x48,0xff,0xf3,0xf0,0x46,0xff,0xd7,0xf0,  \
    0x45,0xff,0xbc,0xf0,0x44,0xff,0xa0,0xf0,0x42,0xff,0x84,0xf0,0x41,0xff,0x69,0xf0,0x40,0xff,0x4c,0xf0,0x3f,0xff,0x30,0xf0,0x3e,0xff,0x14,0xf0,0x3d,0xff,0xf8,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x13,0xff,0x17,0x10,0x14,0xff,0xfb,0x0f,0x15,0xff,0xde,0x0f,0x17,0xff,0xc2,0x0f,0x18,0xff,0xa6,0x0f,0x19,0xff,0x89,0x0f,0x1b,0xff,0x6d,0x0f,0x1c,0xff,0x52,0x0f,0x1e,0xff,0x36,0x0f,0x1f,0xff,0x1a,0x0f,0x21,0xff,0xff,0x0e,0x22,0xff,0xe3,0x0e,0x24,0xff,0xc8,0x0e,0x25,0xff,0xad,0x0e,0x27,0xff,0x92,0x0e,0x29,0xff,0x77,0x0e,0x2a,0xff,0x5c,0x0e,0x2c,0xff,0x41,0x0e,0x2e,0xff,0x27,0x0e,0x30,0xff,0x0c,0x0e,0x32,0xff,0xf2,0x0d,0x33,0xff,0xd8,0x0d,  \
    0x35,0xff,0xbe,0x0d,0x37,0xff,0xa4,0x0d,0x39,0xff,0x8a,0x0d,0x3b,0xff,0x70,0x0d,0x3d,0xff,0x57,0x0d,0x3f,0xff,0x3d,0x0d,0x41,0xff,0x24,0x0d,0x43,0xff,0x0b,0x0d,0x45,0xff,0xf1,0x0c,0x47,0xff,0xd8,0x0c,0x4a,0xff,0xbf,0x0c,0x4c,0xff,0xa7,0x0c,0x4e,0xff,0x8e,0x0c,0x50,0xff,0x75,0x0c,0x52,0xff,0x5d,0x0c,0x55,0xff,0x45,0x0c,0x57,0xff,0x2c,0x0c,0x59,0xff,0x14,0x0c,0x5c,0xff,0xfc,0x0b,0x5e,0xff,0xe5,0x0b,0x60,0xff,0xcd,0x0b,0x63,0xff,0xb6,0x0b,0x65,0xff,  \
    0x9e,0x0b,0x68,0xff,0x87,0x0b,0x6a,0xff,0x70,0x0b,0x6c,0xff,0x59,0x0b,0x6f,0xff,0x42,0x0b,0x71,0xff,0x2b,0x0b,0x74,0xff,0x15,0x0b,0x76,0xff,0xfe,0x0a,0x79,0xff,0xe8,0x0a,0x7c,0xff,0xd1,0x0a,0x7e,0xff,0xbb,0x0a,0x81,0xff,0xa5,0x0a,0x83,0xff,0x8f,0x0a,0x86,0xff,0x79,0x0a,0x88,0xff,0x63,0x0a,0x8b,0xff,0x4d,0x0a,0x8d,0xff,0x38,0x0a,0x90,0xff,0x22,0x0a,0x93,0xff,0x0d,0x0a,0x95,0xff,0xf7,0x09,0x98,0xff,0xe2,0x09,0x9a,0xff,0xcd,0x09,0x9d,0xff,0xb8,0x09,  \
    0xa0,0xff,0xa3,0x09,0xa2,0xff,0x8e,0x09,0xa5,0xff,0x79,0x09,0xa8,0xff,0x64,0x09,0xaa,0xff,0x50,0x09,0xad,0xff,0x3b,0x09,0xaf,0xff,0x27,0x09,0xb2,0xff,0x13,0x09,0xb5,0xff,0xff,0x08,0xb7,0xff,0xeb,0x08,0xba,0xff,0xd7,0x08,0xbd,0xff,0xc3,0x08,0xbf,0xff,0xaf,0x08,0xc2,0xff,0x9c,0x08,0xc5,0xff,0x88,0x08,0xc7,0xff,0x75,0x08,0xca,0xff,0x61,0x08,0xcd,0xff,0x4e,0x08,0xcf,0xff,0x3b,0x08,0xd2,0xff,0x28,0x08,0xd4,0xff,0x15,0x08,0xd7,0xff,0x02,0x08,0xda,0xff,  \
    0xf0,0x07,0xdc,0xff,0xdd,0x07,0xdf,0xff,0xca,0x07,0xe2,0xff,0xb8,0x07,0xe4,0xff,0xa6,0x07,0xe7,0xff,0x93,0x07,0xe9,0xff,0x81,0x07,0xec,0xff,0x6f,0x07,0xef,0xff,0x5d,0x07,0xf1,0xff,0x4b,0x07,0xf4,0xff,0x3a,0x07,0xf6,0xff,0x28,0x07,0xf9,0xff,0x16,0x07,0xfc,0xff,0x05,0x07,0xfe,0xff,0xf4,0x06,0x01,0x00,0xe2,0x06,0x03,0x00,0xd1,0x06,0x06,0x00,0xc0,0x06,0x08,0x00,0xaf,0x06,0x0b,0x00,0x9e,0x06,0x0d,0x00,0x8d,0x06,0x10,0x00,0x7c,0x06,0x12,0x00,0x6c,0x06,  \
    0x15,0x00,0x5b,0x06,0x17,0x00,0x4a,0x06,0x1a,0x00,0x3a,0x06,0x1c,0x00,0x29,0x06,0x1f,0x00,0x19,0x06,0x21,0x00,0x09,0x06,0x23,0x00,0xf9,0x05,0x26,0x00,0xe9,0x05,0x28,0x00,0xd9,0x05,0x2b,0x00,0xc9,0x05,0x2d,0x00,0xb9,0x05,0x2f,0x00,0xa9,0x05,0x32,0x00,0x99,0x05,0x34,0x00,0x8a,0x05,0x36,0x00,0x7a,0x05,0x39,0x00,0x6b,0x05,0x3b,0x00,0x5b,0x05,0x3d,0x00,0x4c,0x05,0x3f,0x00,0x3d,0x05,0x42,0x00,0x2e,0x05,0x44,0x00,0x1f,0x05,0x46,0x00,0x10,0x05,0x48,0x00,  \
    0x01,0x05,0x4b,0x00,0xf2,0x04,0x4d,0x00,0xe3,0x04,0x4f,0x00,0xd4,0x04,0x51,0x00,0xc5,0x04,0x53,0x00,0xb7,0x04,0x55,0x00,0xa8,0x04,0x57,0x00,0x99,0x04,0x59,0x00,0x8b,0x04,0x5b,0x00,0x7c,0x04,0x5e,0x00,0x6e,0x04,0x60,0x00,0x60,0x04,0x62,0x00,0x51,0x04,0x64,0x00,0x43,0x04,0x66,0x00,0x35,0x04,0x67,0x00,0x27,0x04,0x69,0x00,0x19,0x04,0x6b,0x00,0x0b,0x04,0x6d,0x00,0xfd,0x03,0x6f,0x00,0xef,0x03,0x71,0x00,0xe2,0x03,0x73,0x00,0xd4,0x03,0x75,0x00,0xc6,0x03,  \
    0x77,0x00,0xb9,0x03,0x78,0x00,0xab,0x03,0x7a,0x00,0x9e,0x03,0x7c,0x00,0x90,0x03,0x7e,0x00,0x83,0x03,0x7f,0x00,0x76,0x03,0x81,0x00,0x68,0x03,0x83,0x00,0x5b,0x03,0x85,0x00,0x4e,0x03,0x86,0x00,0x41,0x03,0x88,0x00,0x34,0x03,0x89,0x00,0x27,0x03,0x8b,0x00,0x1a,0x03,0x8d,0x00,0x0d,0x03,0x8e,0x00,0x00,0x03,0x90,0x00,0xf4,0x02,0x91,0x00,0xe7,0x02,0x93,0x00,0xda,0x02,0x94,0x00,0xce,0x02,0x96,0x00,0xc1,0x02,0x97,0x00,0xb5,0x02,0x99,0x00,0xa8,0x02,0x9a,0x00,  \
    0x9c,0x02,0x9b,0x00,0x8f,0x02,0x9d,0x00,0x83,0x02,0x9e,0x00,0x76,0x02,0x9f,0x00,0x6a,0x02,0xa1,0x00,0x5e,0x02,0xa2,0x00,0x52,0x02,0xa3,0x00,0x46,0x02,0xa5,0x00,0x39,0x02,0xa6,0x00,0x2d,0x02,0xa7,0x00,0x21,0x02,0xa8,0x00,0x15,0x02,0xa9,0x00,0x09,0x02,0xaa,0x00,0xfd,0x01,0xac,0x00,0xf2,0x01,0xad,0x00,0xe6,0x01,0xae,0x00,0xda,0x01,0xaf,0x00,0xce,0x01,0xb0,0x00,0xc2,0x01,0xb1,0x00,0xb6,0x01,0xb2,0x00,0xab,0x01,0xb3,0x00,0x9f,0x01,0xb4,0x00,0x93,0x01,  \
    0xb5,0x00,0x88,0x01,0xb6,0x00,0x7c,0x01,0xb6,0x00,0x71,0x01,0xb7,0x00,0x65,0x01,0xb8,0x00,0x5a,0x01,0xb9,0x00,0x4e,0x01,0xba,0x00,0x43,0x01,0xbb,0x00,0x37,0x01,0xbb,0x00,0x2c,0x01,0xbc,0x00,0x20,0x01,0xbd,0x00,0x15,0x01,0xbd,0x00,0x09,0x01,0xbe,0x00,0xfe,0x00,0xbf,0x00,0xf3,0x00,0xbf,0x00,0xe7,0x00,0xc0,0x00,0xdc,0x00,0xc0,0x00,0xd1,0x00,0xc1,0x00,0xc6,0x00,0xc1,0x00,0xba,0x00,0xc2,0x00,0xaf,0x00,0xc2,0x00,0xa4,0x00,0xc3,0x00,0x99,0x00,0xc3,0x00,  \
    0x8d,0x00,0xc4,0x00,0x82,0x00,0xc4,0x00,0x77,0x00,0xc4,0x00,0x6c,0x00,0xc5,0x00,0x61,0x00,0xc5,0x00,0x56,0x00,0xc5,0x00,0x4a,0x00,0xc6,0x00,0x3f,0x00,0xc6,0x00,0x34,0x00,0xc6,0x00,0x29,0x00,0xc6,0x00,0x1e,0x00,0xc7,0x00,0x13,0x00,0xc7,0x00,0x08,0x00,0xc7,0x00,0xfd,0xff,0xc7,0x00,0xf2,0xff,0xc7,0x00,0xe7,0xff,0xc7,0x00,0xdc,0xff,0xc7,0x00,0xd1,0xff,0xc7,0x00,0xc5,0xff,0xc7,0x00,0xba,0xff,0xc7,0x00,0xaf,0xff,0xc7,0x00,0xa4,0xff,0xc7,0x00,0x99,0xff,  \
    0xc7,0x00,0x8e,0xff,0xc7,0x00,0x83,0xff,0xc7,0x00,0x78,0xff,0xc7,0x00,0x6d,0xff,0xc6,0x00,0x62,0xff,0xc6,0x00,0x57,0xff,0xc6,0x00,0x4c,0xff,0xc6,0x00,0x40,0xff,0xc5,0x00,0x35,0xff,0xc5,0x00,0x2a,0xff,0xc5,0x00,0x1f,0xff,0xc5,0x00,0x14,0xff,0xc4,0x00,0x09,0xff,0xc4,0x00,0xfe,0xfe,0xc3,0x00,0xf2,0xfe,0xc3,0x00,0xe7,0xfe,0xc3,0x00,0xdc,0xfe,0xc2,0x00,0xd1,0xfe,0xc2,0x00,0xc5,0xfe,0xc1,0x00,0xba,0xfe,0xc1,0x00,0xaf,0xfe,0xc0,0x00,0xa4,0xfe,0xbf,0x00,  \
    0x98,0xfe,0xbf,0x00,0x8d,0xfe,0xbe,0x00,0x82,0xfe,0xbe,0x00,0x76,0xfe,0xbd,0x00,0x6b,0xfe,0xbc,0x00,0x60,0xfe,0xbc,0x00,0x55,0xfe,0xbb,0x00,0x49,0xfe,0xba,0x00,0x3e,0xfe,0xb9,0x00,0x32,0xfe,0xb9,0x00,0x27,0xfe,0xb8,0x00,0x1c,0xfe,0xb7,0x00,0x10,0xfe,0xb6,0x00,0x05,0xfe,0xb5,0x00,0xf9,0xfd,0xb4,0x00,0xee,0xfd,0xb3,0x00,0xe2,0xfd,0xb2,0x00,0xd7,0xfd,0xb1,0x00,0xcb,0xfd,0xb0,0x00,0xc0,0xfd,0xaf,0x00,0xb4,0xfd,0xae,0x00,0xa8,0xfd,0xad,0x00,0x9d,0xfd,  \
    0xac,0x00,0x91,0xfd,0xab,0x00,0x85,0xfd,0xaa,0x00,0x79,0xfd,0xa9,0x00,0x6e,0xfd,0xa8,0x00,0x62,0xfd,0xa7,0x00,0x56,0xfd,0xa6,0x00,0x4a,0xfd,0xa4,0x00,0x3e,0xfd,0xa3,0x00,0x32,0xfd,0xa2,0x00,0x26,0xfd,0xa1,0x00,0x19,0xfd,0x9f,0x00,0x0d,0xfd,0x9e,0x00,0x01,0xfd,0x9d,0x00,0xf4,0xfc,0x9b,0x00,0xe8,0xfc,0x9a,0x00,0xdc,0xfc,0x99,0x00,0xcf,0xfc,0x97,0x00,0xc3,0xfc,0x96,0x00,0xb6,0xfc,0x94,0x00,0xaa,0xfc,0x93,0x00,0x9d,0xfc,0x92,0x00,0x90,0xfc,0x90,0x00,  \
    0x83,0xfc,0x8f,0x00,0x77,0xfc,0x8d,0x00,0x6a,0xfc,0x8b,0x00,0x5d,0xfc,0x8a,0x00,0x50,0xfc,0x88,0x00,0x43,0xfc,0x87,0x00,0x36,0xfc,0x85,0x00,0x29,0xfc,0x84,0x00,0x1c,0xfc,0x82,0x00,0x0f,0xfc,0x80,0x00,0x01,0xfc,0x7e,0x00,0xf4,0xfb,0x7d,0x00,0xe7,0xfb,0x7b,0x00,0xd9,0xfb,0x79,0x00,0xcc,0xfb,0x78,0x00,0xbf,0xfb,0x76,0x00,0xb1,0xfb,0x74,0x00,0xa4,0xfb,0x72,0x00,0x96,0xfb,0x70,0x00,0x88,0xfb,0x6e,0x00,0x7b,0xfb,0x6d,0x00,0x6d,0xfb,0x6b,0x00,0x5f,0xfb,  \
    0x69,0x00,0x51,0xfb,0x67,0x00,0x43,0xfb,0x65,0x00,0x35,0xfb,0x63,0x00,0x27,0xfb,0x61,0x00,0x19,0xfb,0x5f,0x00,0x0b,0xfb,0x5d,0x00,0xfc,0xfa,0x5b,0x00,0xee,0xfa,0x59,0x00,0xe0,0xfa,0x57,0x00,0xd1,0xfa,0x55,0x00,0xc3,0xfa,0x53,0x00,0xb4,0xfa,0x51,0x00,0xa5,0xfa,0x4f,0x00,0x97,0xfa,0x4d,0x00,0x88,0xfa,0x4b,0x00,0x79,0xfa,0x48,0x00,0x6a,0xfa,0x46,0x00,0x5b,0xfa,0x44,0x00,0x4c,0xfa,0x42,0x00,0x3d,0xfa,0x40,0x00,0x2e,0xfa,0x3e,0x00,0x1e,0xfa,0x3b,0x00,  \
    0x0f,0xfa,0x39,0x00,0xff,0xf9,0x37,0x00,0xf0,0xf9,0x35,0x00,0xe0,0xf9,0x32,0x00,0xd1,0xf9,0x30,0x00,0xc1,0xf9,0x2e,0x00,0xb1,0xf9,0x2c,0x00,0xa1,0xf9,0x29,0x00,0x91,0xf9,0x27,0x00,0x81,0xf9,0x25,0x00,0x71,0xf9,0x22,0x00,0x61,0xf9,0x20,0x00,0x50,0xf9,0x1e,0x00,0x40,0xf9,0x1b,0x00,0x30,0xf9,0x19,0x00,0x1f,0xf9,0x16,0x00,0x0e,0xf9,0x14,0x00,0xfe,0xf8,0x12,0x00,0xed,0xf8,0x0f,0x00,0xdc,0xf8,0x0d,0x00,0xcb,0xf8,0x0a,0x00,0xba,0xf8,0x08,0x00,0xa9,0xf8,  \
    0x06,0x00,0x97,0xf8,0x03,0x00,0x86,0xf8,0x01,0x00,0x75,0xf8,0xfe,0xff,0x63,0xf8,0xfc,0xff,0x51,0xf8,0xf9,0xff,0x40,0xf8,0xf7,0xff,0x2e,0xf8,0xf4,0xff,0x1c,0xf8,0xf2,0xff,0x0a,0xf8,0xef,0xff,0xf8,0xf7,0xed,0xff,0xe6,0xf7,0xea,0xff,0xd4,0xf7,0xe8,0xff,0xc1,0xf7,0xe5,0xff,0xaf,0xf7,0xe3,0xff,0x9c,0xf7,0xe0,0xff,0x89,0xf7,0xde,0xff,0x77,0xf7,0xdb,0xff,0x64,0xf7,0xd9,0xff,0x51,0xf7,0xd6,0xff,0x3e,0xf7,0xd4,0xff,0x2b,0xf7,0xd1,0xff,0x17,0xf7,0xcf,0xff,  \
    0x04,0xf7,0xcc,0xff,0xf1,0xf6,0xca,0xff,0xdd,0xf6,0xc7,0xff,0xc9,0xf6,0xc5,0xff,0xb6,0xf6,0xc2,0xff,0xa2,0xf6,0xc0,0xff,0x8e,0xf6,0xbd,0xff,0x7a,0xf6,0xbb,0xff,0x65,0xf6,0xb8,0xff,0x51,0xf6,0xb6,0xff,0x3d,0xf6,0xb3,0xff,0x28,0xf6,0xb1,0xff,0x13,0xf6,0xae,0xff,0xff,0xf5,0xac,0xff,0xea,0xf5,0xa9,0xff,0xd5,0xf5,0xa7,0xff,0xc0,0xf5,0xa4,0xff,0xaa,0xf5,0xa2,0xff,0x95,0xf5,0xa0,0xff,0x80,0xf5,0x9d,0xff,0x6a,0xf5,0x9b,0xff,0x55,0xf5,0x98,0xff,0x3f,0xf5,  \
    0x96,0xff,0x29,0xf5,0x94,0xff,0x13,0xf5,0x91,0xff,0xfd,0xf4,0x8f,0xff,0xe7,0xf4,0x8d,0xff,0xd0,0xf4,0x8a,0xff,0xba,0xf4,0x88,0xff,0xa3,0xf4,0x86,0xff,0x8d,0xf4,0x83,0xff,0x76,0xf4,0x81,0xff,0x5f,0xf4,0x7f,0xff,0x48,0xf4,0x7c,0xff,0x31,0xf4,0x7a,0xff,0x1a,0xf4,0x78,0xff,0x02,0xf4,0x76,0xff,0xeb,0xf3,0x74,0xff,0xd3,0xf3,0x71,0xff,0xbb,0xf3,0x6f,0xff,0xa4,0xf3,0x6d,0xff,0x8c,0xf3,0x6b,0xff,0x73,0xf3,0x69,0xff,0x5b,0xf3,0x67,0xff,0x43,0xf3,0x65,0xff,  \
    0x2a,0xf3,0x63,0xff,0x12,0xf3,0x61,0xff,0xf9,0xf2,0x5f,0xff,0xe0,0xf2,0x5d,0xff,0xc7,0xf2,0x5b,0xff,0xae,0xf2,0x59,0xff,0x95,0xf2,0x57,0xff,0x7c,0xf2,0x55,0xff,0x62,0xf2,0x53,0xff,0x49,0xf2,0x52,0xff,0x2f,0xf2,0x50,0xff,0x15,0xf2,0x4e,0xff,0xfb,0xf1,0x4c,0xff,0xe1,0xf1,0x4b,0xff,0xc7,0xf1,0x49,0xff,0xac,0xf1,0x47,0xff,0x92,0xf1,0x46,0xff,0x77,0xf1,0x44,0xff,0x5c,0xf1,0x43,0xff,0x42,0xf1,0x41,0xff,0x27,0xf1,0x40,0xff,0x0b,0xf1,0x3e,0xff,0xf0,0xf0,  \
    0x3d,0xff,0xd5,0xf0,0x3c,0xff,0xb9,0xf0,0x3a,0xff,0x9e,0xf0,0x39,0xff,0x82,0xf0,0x38,0xff,0x66,0xf0,0x36,0xff,0x4a,0xf0,0x35,0xff,0x2e,0xf0,0x34,0xff,0x12,0xf0,0x33,0xff,0xf5,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xff,0x19,0x10,0x08,0xff,0xfd,0x0f,0x0a,0xff,0xe0,0x0f,0x0b,0xff,0xc4,0x0f,0x0c,0xff,0xa8,0x0f,0x0e,0xff,0x8b,0x0f,0x0f,0xff,0x6f,0x0f,0x10,0xff,0x54,0x0f,0x12,0xff,0x38,0x0f,0x14,0xff,0x1c,0x0f,0x15,0xff,0x01,0x0f,0x17,0xff,0xe5,0x0e,0x18,0xff,0xca,0x0e,0x1a,0xff,0xaf,0x0e,0x1c,0xff,0x94,0x0e,0x1d,0xff,0x79,0x0e,0x1f,0xff,0x5e,0x0e,0x21,0xff,0x44,0x0e,0x23,0xff,0x29,0x0e,0x25,0xff,0x0f,0x0e,0x27,0xff,0xf4,0x0d,  \
    0x29,0xff,0xda,0x0d,0x2b,0xff,0xc0,0x0d,0x2d,0xff,0xa6,0x0d,0x2f,0xff,0x8c,0x0d,0x31,0xff,0x73,0x0d,0x33,0xff,0x59,0x0d,0x35,0xff,0x3f,0x0d,0x37,0xff,0x26,0x0d,0x39,0xff,0x0d,0x0d,0x3b,0xff,0xf4,0x0c,0x3d,0xff,0xdb,0x0c,0x40,0xff,0xc2,0x0c,0x42,0xff,0xa9,0x0c,0x44,0xff,0x90,0x0c,0x46,0xff,0x78,0x0c,0x49,0xff,0x5f,0x0c,0x4b,0xff,0x47,0x0c,0x4d,0xff,0x2f,0x0c,0x50,0xff,0x17,0x0c,0x52,0xff,0xff,0x0b,0x55,0xff,0xe7,0x0b,0x57,0xff,0xd0,0x0b,0x5a,0xff,  \
    0xb8,0x0b,0x5c,0xff,0xa1,0x0b,0x5f,0xff,0x8a,0x0b,0x61,0xff,0x72,0x0b,0x64,0xff,0x5b,0x0b,0x66,0xff,0x45,0x0b,0x69,0xff,0x2e,0x0b,0x6c,0xff,0x17,0x0b,0x6e,0xff,0x01,0x0b,0x71,0xff,0xea,0x0a,0x73,0xff,0xd4,0x0a,0x76,0xff,0xbe,0x0a,0x79,0xff,0xa8,0x0a,0x7b,0xff,0x92,0x0a,0x7e,0xff,0x7c,0x0a,0x81,0xff,0x66,0x0a,0x83,0xff,0x50,0x0a,0x86,0xff,0x3a,0x0a,0x89,0xff,0x25,0x0a,0x8b,0xff,0x0f,0x0a,0x8e,0xff,0xfa,0x09,0x91,0xff,0xe5,0x09,0x94,0xff,0xd0,0x09,  \
    0x96,0xff,0xbb,0x09,0x99,0xff,0xa6,0x09,0x9c,0xff,0x91,0x09,0x9e,0xff,0x7c,0x09,0xa1,0xff,0x67,0x09,0xa4,0xff,0x53,0x09,0xa7,0xff,0x3e,0x09,0xa9,0xff,0x2a,0x09,0xac,0xff,0x16,0x09,0xaf,0xff,0x02,0x09,0xb2,0xff,0xee,0x08,0xb4,0xff,0xda,0x08,0xb7,0xff,0xc6,0x08,0xba,0xff,0xb2,0x08,0xbd,0xff,0x9f,0x08,0xbf,0xff,0x8b,0x08,0xc2,0xff,0x78,0x08,0xc5,0xff,0x65,0x08,0xc8,0xff,0x51,0x08,0xca,0xff,0x3e,0x08,0xcd,0xff,0x2b,0x08,0xd0,0xff,0x18,0x08,0xd2,0xff,  \
    0x05,0x08,0xd5,0xff,0xf3,0x07,0xd8,0xff,0xe0,0x07,0xdb,0xff,0xce,0x07,0xdd,0xff,0xbb,0x07,0xe0,0xff,0xa9,0x07,0xe3,0xff,0x97,0x07,0xe5,0xff,0x84,0x07,0xe8,0xff,0x72,0x07,0xeb,0xff,0x60,0x07,0xee,0xff,0x4f,0x07,0xf0,0xff,0x3d,0x07,0xf3,0xff,0x2b,0x07,0xf6,0xff,0x1a,0x07,0xf8,0xff,0x08,0x07,0xfb,0xff,0xf7,0x06,0xfe,0xff,0xe6,0x06,0x00,0x00,0xd4,0x06,0x03,0x00,0xc3,0x06,0x05,0x00,0xb2,0x06,0x08,0x00,0xa1,0x06,0x0b,0x00,0x90,0x06,0x0d,0x00,0x80,0x06,  \
    0x10,0x00,0x6f,0x06,0x12,0x00,0x5e,0x06,0x15,0x00,0x4e,0x06,0x18,0x00,0x3d,0x06,0x1a,0x00,0x2d,0x06,0x1d,0x00,0x1c,0x06,0x1f,0x00,0x0c,0x06,0x22,0x00,0xfc,0x05,0x24,0x00,0xec,0x05,0x27,0x00,0xdc,0x05,0x29,0x00,0xcc,0x05,0x2c,0x00,0xbc,0x05,0x2e,0x00,0xac,0x05,0x30,0x00,0x9d,0x05,0x33,0x00,0x8d,0x05,0x35,0x00,0x7e,0x05,0x38,0x00,0x6e,0x05,0x3a,0x00,0x5f,0x05,0x3c,0x00,0x4f,0x05,0x3f,0x00,0x40,0x05,0x41,0x00,0x31,0x05,0x43,0x00,0x22,0x05,0x46,0x00,  \
    0x13,0x05,0x48,0x00,0x04,0x05,0x4a,0x00,0xf5,0x04,0x4c,0x00,0xe6,0x04,0x4f,0x00,0xd7,0x04,0x51,0x00,0xc8,0x04,0x53,0x00,0xba,0x04,0x55,0x00,0xab,0x04,0x57,0x00,0x9c,0x04,0x5a,0x00,0x8e,0x04,0x5c,0x00,0x7f,0x04,0x5e,0x00,0x71,0x04,0x60,0x00,0x63,0x04,0x62,0x00,0x54,0x04,0x64,0x00,0x46,0x04,0x66,0x00,0x38,0x04,0x68,0x00,0x2a,0x04,0x6a,0x00,0x1c,0x04,0x6c,0x00,0x0e,0x04,0x6e,0x00,0x00,0x04,0x70,0x00,0xf2,0x03,0x72,0x00,0xe4,0x03,0x74,0x00,0xd7,0x03,  \
    0x76,0x00,0xc9,0x03,0x78,0x00,0xbb,0x03,0x7a,0x00,0xae,0x03,0x7b,0x00,0xa0,0x03,0x7d,0x00,0x93,0x03,0x7f,0x00,0x85,0x03,0x81,0x00,0x78,0x03,0x83,0x00,0x6b,0x03,0x84,0x00,0x5e,0x03,0x86,0x00,0x51,0x03,0x88,0x00,0x44,0x03,0x8a,0x00,0x37,0x03,0x8b,0x00,0x2a,0x03,0x8d,0x00,0x1d,0x03,0x8f,0x00,0x10,0x03,0x90,0x00,0x03,0x03,0x92,0x00,0xf6,0x02,0x93,0x00,0xe9,0x02,0x95,0x00,0xdd,0x02,0x96,0x00,0xd0,0x02,0x98,0x00,0xc3,0x02,0x99,0x00,0xb7,0x02,0x9b,0x00,  \
    0xaa,0x02,0x9c,0x00,0x9e,0x02,0x9e,0x00,0x91,0x02,0x9f,0x00,0x85,0x02,0xa1,0x00,0x79,0x02,0xa2,0x00,0x6c,0x02,0xa3,0x00,0x60,0x02,0xa5,0x00,0x54,0x02,0xa6,0x00,0x48,0x02,0xa7,0x00,0x3b,0x02,0xa9,0x00,0x2f,0x02,0xaa,0x00,0x23,0x02,0xab,0x00,0x17,0x02,0xac,0x00,0x0b,0x02,0xad,0x00,0xff,0x01,0xaf,0x00,0xf3,0x01,0xb0,0x00,0xe7,0x01,0xb1,0x00,0xdc,0x01,0xb2,0x00,0xd0,0x01,0xb3,0x00,0xc4,0x01,0xb4,0x00,0xb8,0x01,0xb5,0x00,0xac,0x01,0xb6,0x00,0xa1,0x01,  \
    0xb7,0x00,0x95,0x01,0xb8,0x00,0x89,0x01,0xb9,0x00,0x7e,0x01,0xba,0x00,0x72,0x01,0xbb,0x00,0x66,0x01,0xbc,0x00,0x5b,0x01,0xbc,0x00,0x4f,0x01,0xbd,0x00,0x44,0x01,0xbe,0x00,0x38,0x01,0xbf,0x00,0x2d,0x01,0xc0,0x00,0x21,0x01,0xc0,0x00,0x16,0x01,0xc1,0x00,0x0b,0x01,0xc2,0x00,0xff,0x00,0xc2,0x00,0xf4,0x00,0xc3,0x00,0xe8,0x00,0xc4,0x00,0xdd,0x00,0xc4,0x00,0xd2,0x00,0xc5,0x00,0xc6,0x00,0xc5,0x00,0xbb,0x00,0xc6,0x00,0xb0,0x00,0xc6,0x00,0xa5,0x00,0xc7,0x00,  \
    0x99,0x00,0xc7,0x00,0x8e,0x00,0xc8,0x00,0x83,0x00,0xc8,0x00,0x78,0x00,0xc8,0x00,0x6d,0x00,0xc9,0x00,0x61,0x00,0xc9,0x00,0x56,0x00,0xc9,0x00,0x4b,0x00,0xca,0x00,0x40,0x00,0xca,0x00,0x35,0x00,0xca,0x00,0x2a,0x00,0xca,0x00,0x1e,0x00,0xca,0x00,0x13,0x00,0xcb,0x00,0x08,0x00,0xcb,0x00,0xfd,0xff,0xcb,0x00,0xf2,0xff,0xcb,0x00,0xe7,0xff,0xcb,0x00,0xdc,0xff,0xcb,0x00,0xd1,0xff,0xcb,0x00,0xc5,0xff,0xcb,0x00,0xba,0xff,0xcb,0x00,0xaf,0xff,0xcb,0x00,0xa4,0xff,  \
    0xcb,0x00,0x99,0xff,0xcb,0x00,0x8e,0xff,0xcb,0x00,0x83,0xff,0xcb,0x00,0x78,0xff,0xca,0x00,0x6d,0xff,0xca,0x00,0x61,0xff,0xca,0x00,0x56,0xff,0xca,0x00,0x4b,0xff,0xca,0x00,0x40,0xff,0xc9,0x00,0x35,0xff,0xc9,0x00,0x2a,0xff,0xc9,0x00,0x1e,0xff,0xc8,0x00,0x13,0xff,0xc8,0x00,0x08,0xff,0xc8,0x00,0xfd,0xfe,0xc7,0x00,0xf2,0xfe,0xc7,0x00,0xe6,0xfe,0xc6,0x00,0xdb,0xfe,0xc6,0x00,0xd0,0xfe,0xc5,0x00,0xc4,0xfe,0xc5,0x00,0xb9,0xfe,0xc4,0x00,0xae,0xfe,0xc4,0x00,  \
    0xa2,0xfe,0xc3,0x00,0x97,0xfe,0xc3,0x00,0x8c,0xfe,0xc2,0x00,0x81,0xfe,0xc1,0x00,0x75,0xfe,0xc1,0x00,0x6a,0xfe,0xc0,0x00,0x5f,0xfe,0xbf,0x00,0x53,0xfe,0xbe,0x00,0x48,0xfe,0xbe,0x00,0x3c,0xfe,0xbd,0x00,0x31,0xfe,0xbc,0x00,0x26,0xfe,0xbb,0x00,0x1a,0xfe,0xba,0x00,0x0f,0xfe,0xb9,0x00,0x03,0xfe,0xb9,0x00,0xf8,0xfd,0xb8,0x00,0xec,0xfd,0xb7,0x00,0xe1,0xfd,0xb6,0x00,0xd5,0xfd,0xb5,0x00,0xca,0xfd,0xb4,0x00,0xbe,0xfd,0xb3,0x00,0xb2,0xfd,0xb2,0x00,0xa7,0xfd,  \
    0xb1,0x00,0x9b,0xfd,0xaf,0x00,0x8f,0xfd,0xae,0x00,0x83,0xfd,0xad,0x00,0x78,0xfd,0xac,0x00,0x6c,0xfd,0xab,0x00,0x60,0xfd,0xaa,0x00,0x54,0xfd,0xa8,0x00,0x48,0xfd,0xa7,0x00,0x3c,0xfd,0xa6,0x00,0x30,0xfd,0xa5,0x00,0x23,0xfd,0xa3,0x00,0x17,0xfd,0xa2,0x00,0x0b,0xfd,0xa1,0x00,0xff,0xfc,0x9f,0x00,0xf2,0xfc,0x9e,0x00,0xe6,0xfc,0x9d,0x00,0xd9,0xfc,0x9b,0x00,0xcd,0xfc,0x9a,0x00,0xc0,0xfc,0x98,0x00,0xb4,0xfc,0x97,0x00,0xa7,0xfc,0x95,0x00,0x9a,0xfc,0x94,0x00,  \
    0x8e,0xfc,0x92,0x00,0x81,0xfc,0x91,0x00,0x74,0xfc,0x8f,0x00,0x67,0xfc,0x8d,0x00,0x5a,0xfc,0x8c,0x00,0x4d,0xfc,0x8a,0x00,0x40,0xfc,0x89,0x00,0x33,0xfc,0x87,0x00,0x26,0xfc,0x85,0x00,0x19,0xfc,0x84,0x00,0x0c,0xfc,0x82,0x00,0xfe,0xfb,0x80,0x00,0xf1,0xfb,0x7e,0x00,0xe4,0xfb,0x7d,0x00,0xd7,0xfb,0x7b,0x00,0xc9,0xfb,0x79,0x00,0xbc,0xfb,0x77,0x00,0xae,0xfb,0x75,0x00,0xa1,0xfb,0x73,0x00,0x93,0xfb,0x71,0x00,0x85,0xfb,0x70,0x00,0x78,0xfb,0x6e,0x00,0x6a,0xfb,  \
    0x6c,0x00,0x5c,0xfb,0x6a,0x00,0x4e,0xfb,0x68,0x00,0x40,0xfb,0x66,0x00,0x32,0xfb,0x64,0x00,0x24,0xfb,0x62,0x00,0x16,0xfb,0x60,0x00,0x08,0xfb,0x5e,0x00,0xf9,0xfa,0x5c,0x00,0xeb,0xfa,0x59,0x00,0xdc,0xfa,0x57,0x00,0xce,0xfa,0x55,0x00,0xbf,0xfa,0x53,0x00,0xb1,0xfa,0x51,0x00,0xa2,0xfa,0x4f,0x00,0x93,0xfa,0x4d,0x00,0x85,0xfa,0x4a,0x00,0x76,0xfa,0x48,0x00,0x67,0xfa,0x46,0x00,0x58,0xfa,0x44,0x00,0x49,0xfa,0x42,0x00,0x39,0xfa,0x3f,0x00,0x2a,0xfa,0x3d,0x00,  \
    0x1b,0xfa,0x3b,0x00,0x0c,0xfa,0x38,0x00,0xfc,0xf9,0x36,0x00,0xed,0xf9,0x34,0x00,0xdd,0xf9,0x31,0x00,0xcd,0xf9,0x2f,0x00,0xbe,0xf9,0x2d,0x00,0xae,0xf9,0x2a,0x00,0x9e,0xf9,0x28,0x00,0x8e,0xf9,0x26,0x00,0x7e,0xf9,0x23,0x00,0x6e,0xf9,0x21,0x00,0x5d,0xf9,0x1e,0x00,0x4d,0xf9,0x1c,0x00,0x3d,0xf9,0x1a,0x00,0x2c,0xf9,0x17,0x00,0x1c,0xf9,0x15,0x00,0x0b,0xf9,0x12,0x00,0xfa,0xf8,0x10,0x00,0xe9,0xf8,0x0d,0x00,0xd8,0xf8,0x0b,0x00,0xc7,0xf8,0x08,0x00,0xb6,0xf8,  \
    0x06,0x00,0xa5,0xf8,0x03,0x00,0x94,0xf8,0x01,0x00,0x83,0xf8,0xfe,0xff,0x71,0xf8,0xfc,0xff,0x60,0xf8,0xf9,0xff,0x4e,0xf8,0xf6,0xff,0x3c,0xf8,0xf4,0xff,0x2b,0xf8,0xf1,0xff,0x19,0xf8,0xef,0xff,0x07,0xf8,0xec,0xff,0xf5,0xf7,0xea,0xff,0xe2,0xf7,0xe7,0xff,0xd0,0xf7,0xe4,0xff,0xbe,0xf7,0xe2,0xff,0xab,0xf7,0xdf,0xff,0x99,0xf7,0xdd,0xff,0x86,0xf7,0xda,0xff,0x73,0xf7,0xd7,0xff,0x61,0xf7,0xd5,0xff,0x4e,0xf7,0xd2,0xff,0x3a,0xf7,0xd0,0xff,0x27,0xf7,0xcd,0xff,  \
    0x14,0xf7,0xca,0xff,0x01,0xf7,0xc8,0xff,0xed,0xf6,0xc5,0xff,0xda,0xf6,0xc3,0xff,0xc6,0xf6,0xc0,0xff,0xb2,0xf6,0xbd,0xff,0x9e,0xf6,0xbb,0xff,0x8a,0xf6,0xb8,0xff,0x76,0xf6,0xb6,0xff,0x62,0xf6,0xb3,0xff,0x4e,0xf6,0xb1,0xff,0x39,0xf6,0xae,0xff,0x25,0xf6,0xab,0xff,0x10,0xf6,0xa9,0xff,0xfb,0xf5,0xa6,0xff,0xe7,0xf5,0xa4,0xff,0xd2,0xf5,0xa1,0xff,0xbd,0xf5,0x9f,0xff,0xa7,0xf5,0x9c,0xff,0x92,0xf5,0x9a,0xff,0x7d,0xf5,0x97,0xff,0x67,0xf5,0x95,0xff,0x51,0xf5,  \
    0x92,0xff,0x3c,0xf5,0x90,0xff,0x26,0xf5,0x8d,0xff,0x10,0xf5,0x8b,0xff,0xfa,0xf4,0x88,0xff,0xe4,0xf4,0x86,0xff,0xcd,0xf4,0x84,0xff,0xb7,0xf4,0x81,0xff,0xa0,0xf4,0x7f,0xff,0x8a,0xf4,0x7c,0xff,0x73,0xf4,0x7a,0xff,0x5c,0xf4,0x78,0xff,0x45,0xf4,0x75,0xff,0x2e,0xf4,0x73,0xff,0x17,0xf4,0x71,0xff,0xff,0xf3,0x6e,0xff,0xe8,0xf3,0x6c,0xff,0xd0,0xf3,0x6a,0xff,0xb9,0xf3,0x68,0xff,0xa1,0xf3,0x66,0xff,0x89,0xf3,0x63,0xff,0x71,0xf3,0x61,0xff,0x58,0xf3,0x5f,0xff,  \
    0x40,0xf3,0x5d,0xff,0x28,0xf3,0x5b,0xff,0x0f,0xf3,0x59,0xff,0xf6,0xf2,0x57,0xff,0xde,0xf2,0x55,0xff,0xc5,0xf2,0x53,0xff,0xab,0xf2,0x51,0xff,0x92,0xf2,0x4f,0xff,0x79,0xf2,0x4d,0xff,0x5f,0xf2,0x4b,0xff,0x46,0xf2,0x49,0xff,0x2c,0xf2,0x47,0xff,0x12,0xf2,0x45,0xff,0xf8,0xf1,0x44,0xff,0xde,0xf1,0x42,0xff,0xc4,0xf1,0x40,0xff,0xaa,0xf1,0x3f,0xff,0x8f,0xf1,0x3d,0xff,0x75,0xf1,0x3b,0xff,0x5a,0xf1,0x3a,0xff,0x3f,0xf1,0x38,0xff,0x24,0xf1,0x37,0xff,0x09,0xf1,  \
    0x35,0xff,0xee,0xf0,0x34,0xff,0xd2,0xf0,0x32,0xff,0xb7,0xf0,0x31,0xff,0x9b,0xf0,0x30,0xff,0x7f,0xf0,0x2e,0xff,0x64,0xf0,0x2d,0xff,0x48,0xf0,0x2c,0xff,0x2b,0xf0,0x2b,0xff,0x0f,0xf0,0x29,0xff,0xf3,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfb,0xfe,0x1b,0x10,0xfc,0xfe,0xff,0x0f,0xfe,0xfe,0xe2,0x0f,0xff,0xfe,0xc6,0x0f,0x00,0xff,0xaa,0x0f,0x02,0xff,0x8e,0x0f,0x03,0xff,0x72,0x0f,0x05,0xff,0x56,0x0f,0x06,0xff,0x3a,0x0f,0x08,0xff,0x1e,0x0f,0x0a,0xff,0x03,0x0f,0x0b,0xff,0xe8,0x0e,0x0d,0xff,0xcc,0x0e,0x0f,0xff,0xb1,0x0e,0x10,0xff,0x96,0x0e,0x12,0xff,0x7b,0x0e,0x14,0xff,0x61,0x0e,0x16,0xff,0x46,0x0e,0x18,0xff,0x2b,0x0e,0x1a,0xff,0x11,0x0e,  \
    0x1c,0xff,0xf7,0x0d,0x1e,0xff,0xdc,0x0d,0x20,0xff,0xc2,0x0d,0x22,0xff,0xa8,0x0d,0x24,0xff,0x8f,0x0d,0x26,0xff,0x75,0x0d,0x28,0xff,0x5b,0x0d,0x2a,0xff,0x42,0x0d,0x2d,0xff,0x28,0x0d,0x2f,0xff,0x0f,0x0d,0x31,0xff,0xf6,0x0c,0x33,0xff,0xdd,0x0c,0x36,0xff,0xc4,0x0c,0x38,0xff,0xab,0x0c,0x3a,0xff,0x93,0x0c,0x3d,0xff,0x7a,0x0c,0x3f,0xff,0x62,0x0c,0x42,0xff,0x4a,0x0c,0x44,0xff,0x31,0x0c,0x46,0xff,0x19,0x0c,0x49,0xff,0x01,0x0c,0x4c,0xff,0xea,0x0b,0x4e,0xff,  \
    0xd2,0x0b,0x51,0xff,0xbb,0x0b,0x53,0xff,0xa3,0x0b,0x56,0xff,0x8c,0x0b,0x59,0xff,0x75,0x0b,0x5b,0xff,0x5e,0x0b,0x5e,0xff,0x47,0x0b,0x61,0xff,0x31,0x0b,0x63,0xff,0x1a,0x0b,0x66,0xff,0x03,0x0b,0x69,0xff,0xed,0x0a,0x6b,0xff,0xd7,0x0a,0x6e,0xff,0xc1,0x0a,0x71,0xff,0xab,0x0a,0x74,0xff,0x95,0x0a,0x77,0xff,0x7f,0x0a,0x79,0xff,0x69,0x0a,0x7c,0xff,0x53,0x0a,0x7f,0xff,0x3d,0x0a,0x82,0xff,0x28,0x0a,0x84,0xff,0x12,0x0a,0x87,0xff,0xfd,0x09,0x8a,0xff,0xe8,0x09,  \
    0x8d,0xff,0xd3,0x09,0x90,0xff,0xbe,0x09,0x92,0xff,0xa9,0x09,0x95,0xff,0x94,0x09,0x98,0xff,0x7f,0x09,0x9b,0xff,0x6b,0x09,0x9e,0xff,0x56,0x09,0xa0,0xff,0x42,0x09,0xa3,0xff,0x2d,0x09,0xa6,0xff,0x19,0x09,0xa9,0xff,0x05,0x09,0xac,0xff,0xf1,0x08,0xaf,0xff,0xdd,0x08,0xb1,0xff,0xc9,0x08,0xb4,0xff,0xb6,0x08,0xb7,0xff,0xa2,0x08,0xba,0xff,0x8e,0x08,0xbd,0xff,0x7b,0x08,0xc0,0xff,0x68,0x08,0xc3,0xff,0x55,0x08,0xc5,0xff,0x41,0x08,0xc8,0xff,0x2e,0x08,0xcb,0xff,  \
    0x1c,0x08,0xce,0xff,0x09,0x08,0xd1,0xff,0xf6,0x07,0xd3,0xff,0xe3,0x07,0xd6,0xff,0xd1,0x07,0xd9,0xff,0xbe,0x07,0xdc,0xff,0xac,0x07,0xdf,0xff,0x9a,0x07,0xe2,0xff,0x88,0x07,0xe4,0xff,0x76,0x07,0xe7,0xff,0x64,0x07,0xea,0xff,0x52,0x07,0xed,0xff,0x40,0x07,0xef,0xff,0x2f,0x07,0xf2,0xff,0x1d,0x07,0xf5,0xff,0x0c,0x07,0xf8,0xff,0xfa,0x06,0xfa,0xff,0xe9,0x06,0xfd,0xff,0xd8,0x06,0x00,0x00,0xc7,0x06,0x03,0x00,0xb6,0x06,0x05,0x00,0xa5,0x06,0x08,0x00,0x94,0x06,  \
    0x0b,0x00,0x83,0x06,0x0d,0x00,0x72,0x06,0x10,0x00,0x62,0x06,0x13,0x00,0x51,0x06,0x15,0x00,0x41,0x06,0x18,0x00,0x30,0x06,0x1b,0x00,0x20,0x06,0x1d,0x00,0x10,0x06,0x20,0x00,0xff,0x05,0x22,0x00,0xef,0x05,0x25,0x00,0xdf,0x05,0x27,0x00,0xcf,0x05,0x2a,0x00,0xc0,0x05,0x2d,0x00,0xb0,0x05,0x2f,0x00,0xa0,0x05,0x32,0x00,0x91,0x05,0x34,0x00,0x81,0x05,0x36,0x00,0x72,0x05,0x39,0x00,0x62,0x05,0x3b,0x00,0x53,0x05,0x3e,0x00,0x44,0x05,0x40,0x00,0x34,0x05,0x43,0x00,  \
    0x25,0x05,0x45,0x00,0x16,0x05,0x47,0x00,0x07,0x05,0x4a,0x00,0xf8,0x04,0x4c,0x00,0xe9,0x04,0x4e,0x00,0xdb,0x04,0x51,0x00,0xcc,0x04,0x53,0x00,0xbd,0x04,0x55,0x00,0xae,0x04,0x57,0x00,0xa0,0x04,0x5a,0x00,0x91,0x04,0x5c,0x00,0x83,0x04,0x5e,0x00,0x74,0x04,0x60,0x00,0x66,0x04,0x62,0x00,0x58,0x04,0x64,0x00,0x49,0x04,0x67,0x00,0x3b,0x04,0x69,0x00,0x2d,0x04,0x6b,0x00,0x1f,0x04,0x6d,0x00,0x11,0x04,0x6f,0x00,0x03,0x04,0x71,0x00,0xf5,0x03,0x73,0x00,0xe7,0x03,  \
    0x75,0x00,0xda,0x03,0x77,0x00,0xcc,0x03,0x79,0x00,0xbe,0x03,0x7b,0x00,0xb1,0x03,0x7d,0x00,0xa3,0x03,0x7e,0x00,0x96,0x03,0x80,0x00,0x88,0x03,0x82,0x00,0x7b,0x03,0x84,0x00,0x6e,0x03,0x86,0x00,0x61,0x03,0x88,0x00,0x53,0x03,0x89,0x00,0x46,0x03,0x8b,0x00,0x39,0x03,0x8d,0x00,0x2c,0x03,0x8f,0x00,0x1f,0x03,0x90,0x00,0x12,0x03,0x92,0x00,0x05,0x03,0x94,0x00,0xf9,0x02,0x95,0x00,0xec,0x02,0x97,0x00,0xdf,0x02,0x99,0x00,0xd2,0x02,0x9a,0x00,0xc6,0x02,0x9c,0x00,  \
    0xb9,0x02,0x9d,0x00,0xad,0x02,0x9f,0x00,0xa0,0x02,0xa0,0x00,0x94,0x02,0xa2,0x00,0x87,0x02,0xa3,0x00,0x7b,0x02,0xa4,0x00,0x6e,0x02,0xa6,0x00,0x62,0x02,0xa7,0x00,0x56,0x02,0xa9,0x00,0x4a,0x02,0xaa,0x00,0x3e,0x02,0xab,0x00,0x31,0x02,0xad,0x00,0x25,0x02,0xae,0x00,0x19,0x02,0xaf,0x00,0x0d,0x02,0xb0,0x00,0x01,0x02,0xb1,0x00,0xf5,0x01,0xb3,0x00,0xe9,0x01,0xb4,0x00,0xdd,0x01,0xb5,0x00,0xd2,0x01,0xb6,0x00,0xc6,0x01,0xb7,0x00,0xba,0x01,0xb8,0x00,0xae,0x01,  \
    0xb9,0x00,0xa2,0x01,0xba,0x00,0x97,0x01,0xbb,0x00,0x8b,0x01,0xbc,0x00,0x7f,0x01,0xbd,0x00,0x74,0x01,0xbe,0x00,0x68,0x01,0xbf,0x00,0x5c,0x01,0xc0,0x00,0x51,0x01,0xc1,0x00,0x45,0x01,0xc1,0x00,0x3a,0x01,0xc2,0x00,0x2e,0x01,0xc3,0x00,0x23,0x01,0xc4,0x00,0x17,0x01,0xc4,0x00,0x0c,0x01,0xc5,0x00,0x00,0x01,0xc6,0x00,0xf5,0x00,0xc6,0x00,0xea,0x00,0xc7,0x00,0xde,0x00,0xc8,0x00,0xd3,0x00,0xc8,0x00,0xc7,0x00,0xc9,0x00,0xbc,0x00,0xc9,0x00,0xb1,0x00,0xca,0x00,  \
    0xa5,0x00,0xca,0x00,0x9a,0x00,0xcb,0x00,0x8f,0x00,0xcb,0x00,0x84,0x00,0xcc,0x00,0x78,0x00,0xcc,0x00,0x6d,0x00,0xcc,0x00,0x62,0x00,0xcd,0x00,0x57,0x00,0xcd,0x00,0x4c,0x00,0xcd,0x00,0x40,0x00,0xce,0x00,0x35,0x00,0xce,0x00,0x2a,0x00,0xce,0x00,0x1f,0x00,0xce,0x00,0x14,0x00,0xce,0x00,0x08,0x00,0xcf,0x00,0xfd,0xff,0xcf,0x00,0xf2,0xff,0xcf,0x00,0xe7,0xff,0xcf,0x00,0xdc,0xff,0xcf,0x00,0xd1,0xff,0xcf,0x00,0xc5,0xff,0xcf,0x00,0xba,0xff,0xcf,0x00,0xaf,0xff,  \
    0xcf,0x00,0xa4,0xff,0xcf,0x00,0x99,0xff,0xcf,0x00,0x8e,0xff,0xcf,0x00,0x83,0xff,0xce,0x00,0x77,0xff,0xce,0x00,0x6c,0xff,0xce,0x00,0x61,0xff,0xce,0x00,0x56,0xff,0xce,0x00,0x4b,0xff,0xcd,0x00,0x3f,0xff,0xcd,0x00,0x34,0xff,0xcd,0x00,0x29,0xff,0xcc,0x00,0x1e,0xff,0xcc,0x00,0x13,0xff,0xcc,0x00,0x07,0xff,0xcb,0x00,0xfc,0xfe,0xcb,0x00,0xf1,0xfe,0xca,0x00,0xe5,0xfe,0xca,0x00,0xda,0xfe,0xca,0x00,0xcf,0xfe,0xc9,0x00,0xc3,0xfe,0xc8,0x00,0xb8,0xfe,0xc8,0x00,  \
    0xad,0xfe,0xc7,0x00,0xa1,0xfe,0xc7,0x00,0x96,0xfe,0xc6,0x00,0x8b,0xfe,0xc5,0x00,0x7f,0xfe,0xc5,0x00,0x74,0xfe,0xc4,0x00,0x69,0xfe,0xc3,0x00,0x5d,0xfe,0xc3,0x00,0x52,0xfe,0xc2,0x00,0x46,0xfe,0xc1,0x00,0x3b,0xfe,0xc0,0x00,0x30,0xfe,0xbf,0x00,0x24,0xfe,0xbf,0x00,0x19,0xfe,0xbe,0x00,0x0d,0xfe,0xbd,0x00,0x02,0xfe,0xbc,0x00,0xf6,0xfd,0xbb,0x00,0xeb,0xfd,0xba,0x00,0xdf,0xfd,0xb9,0x00,0xd3,0xfd,0xb8,0x00,0xc8,0xfd,0xb7,0x00,0xbc,0xfd,0xb6,0x00,0xb0,0xfd,  \
    0xb5,0x00,0xa5,0xfd,0xb4,0x00,0x99,0xfd,0xb2,0x00,0x8d,0xfd,0xb1,0x00,0x81,0xfd,0xb0,0x00,0x76,0xfd,0xaf,0x00,0x6a,0xfd,0xae,0x00,0x5e,0xfd,0xac,0x00,0x52,0xfd,0xab,0x00,0x46,0xfd,0xaa,0x00,0x3a,0xfd,0xa9,0x00,0x2e,0xfd,0xa7,0x00,0x21,0xfd,0xa6,0x00,0x15,0xfd,0xa5,0x00,0x09,0xfd,0xa3,0x00,0xfc,0xfc,0xa2,0x00,0xf0,0xfc,0xa0,0x00,0xe3,0xfc,0x9f,0x00,0xd7,0xfc,0x9d,0x00,0xca,0xfc,0x9c,0x00,0xbe,0xfc,0x9a,0x00,0xb1,0xfc,0x99,0x00,0xa5,0xfc,0x97,0x00,  \
    0x98,0xfc,0x96,0x00,0x8b,0xfc,0x94,0x00,0x7e,0xfc,0x93,0x00,0x71,0xfc,0x91,0x00,0x65,0xfc,0x8f,0x00,0x58,0xfc,0x8e,0x00,0x4b,0xfc,0x8c,0x00,0x3e,0xfc,0x8a,0x00,0x30,0xfc,0x89,0x00,0x23,0xfc,0x87,0x00,0x16,0xfc,0x85,0x00,0x09,0xfc,0x83,0x00,0xfc,0xfb,0x82,0x00,0xee,0xfb,0x80,0x00,0xe1,0xfb,0x7e,0x00,0xd4,0xfb,0x7c,0x00,0xc6,0xfb,0x7a,0x00,0xb9,0xfb,0x78,0x00,0xab,0xfb,0x76,0x00,0x9e,0xfb,0x74,0x00,0x90,0xfb,0x73,0x00,0x82,0xfb,0x71,0x00,0x74,0xfb,  \
    0x6f,0x00,0x67,0xfb,0x6d,0x00,0x59,0xfb,0x6b,0x00,0x4b,0xfb,0x69,0x00,0x3d,0xfb,0x66,0x00,0x2f,0xfb,0x64,0x00,0x21,0xfb,0x62,0x00,0x12,0xfb,0x60,0x00,0x04,0xfb,0x5e,0x00,0xf6,0xfa,0x5c,0x00,0xe8,0xfa,0x5a,0x00,0xd9,0xfa,0x58,0x00,0xcb,0xfa,0x55,0x00,0xbc,0xfa,0x53,0x00,0xad,0xfa,0x51,0x00,0x9f,0xfa,0x4f,0x00,0x90,0xfa,0x4d,0x00,0x81,0xfa,0x4a,0x00,0x72,0xfa,0x48,0x00,0x63,0xfa,0x46,0x00,0x54,0xfa,0x43,0x00,0x45,0xfa,0x41,0x00,0x36,0xfa,0x3f,0x00,  \
    0x27,0xfa,0x3c,0x00,0x17,0xfa,0x3a,0x00,0x08,0xfa,0x38,0x00,0xf9,0xf9,0x35,0x00,0xe9,0xf9,0x33,0x00,0xd9,0xf9,0x31,0x00,0xca,0xf9,0x2e,0x00,0xba,0xf9,0x2c,0x00,0xaa,0xf9,0x29,0x00,0x9a,0xf9,0x27,0x00,0x8a,0xf9,0x24,0x00,0x7a,0xf9,0x22,0x00,0x6a,0xf9,0x1f,0x00,0x5a,0xf9,0x1d,0x00,0x49,0xf9,0x1a,0x00,0x39,0xf9,0x18,0x00,0x29,0xf9,0x15,0x00,0x18,0xf9,0x13,0x00,0x07,0xf9,0x10,0x00,0xf7,0xf8,0x0e,0x00,0xe6,0xf8,0x0b,0x00,0xd5,0xf8,0x08,0x00,0xc4,0xf8,  \
    0x06,0x00,0xb3,0xf8,0x03,0x00,0xa2,0xf8,0x01,0x00,0x90,0xf8,0xfe,0xff,0x7f,0xf8,0xfb,0xff,0x6e,0xf8,0xf9,0xff,0x5c,0xf8,0xf6,0xff,0x4b,0xf8,0xf4,0xff,0x39,0xf8,0xf1,0xff,0x27,0xf8,0xee,0xff,0x15,0xf8,0xec,0xff,0x03,0xf8,0xe9,0xff,0xf1,0xf7,0xe6,0xff,0xdf,0xf7,0xe4,0xff,0xcd,0xf7,0xe1,0xff,0xba,0xf7,0xde,0xff,0xa8,0xf7,0xdc,0xff,0x95,0xf7,0xd9,0xff,0x83,0xf7,0xd6,0xff,0x70,0xf7,0xd4,0xff,0x5d,0xf7,0xd1,0xff,0x4a,0xf7,0xce,0xff,0x37,0xf7,0xcc,0xff,  \
    0x24,0xf7,0xc9,0xff,0x11,0xf7,0xc6,0xff,0xfd,0xf6,0xc4,0xff,0xea,0xf6,0xc1,0xff,0xd6,0xf6,0xbe,0xff,0xc3,0xf6,0xbb,0xff,0xaf,0xf6,0xb9,0xff,0x9b,0xf6,0xb6,0xff,0x87,0xf6,0xb3,0xff,0x73,0xf6,0xb1,0xff,0x5f,0xf6,0xae,0xff,0x4b,0xf6,0xab,0xff,0x36,0xf6,0xa9,0xff,0x22,0xf6,0xa6,0xff,0x0d,0xf6,0xa4,0xff,0xf8,0xf5,0xa1,0xff,0xe3,0xf5,0x9e,0xff,0xce,0xf5,0x9c,0xff,0xb9,0xf5,0x99,0xff,0xa4,0xf5,0x96,0xff,0x8f,0xf5,0x94,0xff,0x79,0xf5,0x91,0xff,0x64,0xf5,  \
    0x8f,0xff,0x4e,0xf5,0x8c,0xff,0x38,0xf5,0x8a,0xff,0x23,0xf5,0x87,0xff,0x0d,0xf5,0x85,0xff,0xf7,0xf4,0x82,0xff,0xe0,0xf4,0x80,0xff,0xca,0xf4,0x7d,0xff,0xb4,0xf4,0x7b,0xff,0x9d,0xf4,0x78,0xff,0x87,0xf4,0x76,0xff,0x70,0xf4,0x73,0xff,0x59,0xf4,0x71,0xff,0x42,0xf4,0x6e,0xff,0x2b,0xf4,0x6c,0xff,0x14,0xf4,0x6a,0xff,0xfc,0xf3,0x67,0xff,0xe5,0xf3,0x65,0xff,0xcd,0xf3,0x63,0xff,0xb5,0xf3,0x60,0xff,0x9e,0xf3,0x5e,0xff,0x86,0xf3,0x5c,0xff,0x6e,0xf3,0x59,0xff,  \
    0x55,0xf3,0x57,0xff,0x3d,0xf3,0x55,0xff,0x25,0xf3,0x53,0xff,0x0c,0xf3,0x51,0xff,0xf3,0xf2,0x4f,0xff,0xdb,0xf2,0x4d,0xff,0xc2,0xf2,0x4b,0xff,0xa9,0xf2,0x49,0xff,0x8f,0xf2,0x47,0xff,0x76,0xf2,0x45,0xff,0x5d,0xf2,0x43,0xff,0x43,0xf2,0x41,0xff,0x29,0xf2,0x3f,0xff,0x0f,0xf2,0x3d,0xff,0xf5,0xf1,0x3b,0xff,0xdb,0xf1,0x39,0xff,0xc1,0xf1,0x38,0xff,0xa7,0xf1,0x36,0xff,0x8c,0xf1,0x34,0xff,0x72,0xf1,0x32,0xff,0x57,0xf1,0x31,0xff,0x3c,0xf1,0x2f,0xff,0x21,0xf1,  \
    0x2e,0xff,0x06,0xf1,0x2c,0xff,0xeb,0xf0,0x2b,0xff,0xd0,0xf0,0x29,0xff,0xb4,0xf0,0x28,0xff,0x98,0xf0,0x26,0xff,0x7d,0xf0,0x25,0xff,0x61,0xf0,0x24,0xff,0x45,0xf0,0x22,0xff,0x29,0xf0,0x21,0xff,0x0c,0xf0,0x20,0xff,0xf0,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xef,0xfe,0x1e,0x10,0xf0,0xfe,0x01,0x10,0xf2,0xfe,0xe5,0x0f,0xf3,0xfe,0xc8,0x0f,0xf5,0xfe,0xac,0x0f,0xf6,0xfe,0x90,0x0f,0xf8,0xfe,0x74,0x0f,0xf9,0xfe,0x58,0x0f,0xfb,0xfe,0x3c,0x0f,0xfc,0xfe,0x21,0x0f,0xfe,0xfe,0x05,0x0f,0x00,0xff,0xea,0x0e,0x02,0xff,0xcf,0x0e,0x03,0xff,0xb4,0x0e,0x05,0xff,0x99,0x0e,0x07,0xff,0x7e,0x0e,0x09,0xff,0x63,0x0e,0x0b,0xff,0x48,0x0e,0x0d,0xff,0x2e,0x0e,  \
    0x0f,0xff,0x13,0x0e,0x11,0xff,0xf9,0x0d,0x13,0xff,0xdf,0x0d,0x15,0xff,0xc5,0x0d,0x17,0xff,0xab,0x0d,0x1a,0xff,0x91,0x0d,0x1c,0xff,0x77,0x0d,0x1e,0xff,0x5e,0x0d,0x20,0xff,0x44,0x0d,0x22,0xff,0x2b,0x0d,0x25,0xff,0x12,0x0d,0x27,0xff,0xf9,0x0c,0x29,0xff,0xe0,0x0c,0x2c,0xff,0xc7,0x0c,0x2e,0xff,0xae,0x0c,0x31,0xff,0x95,0x0c,0x33,0xff,0x7d,0x0c,0x36,0xff,0x64,0x0c,0x38,0xff,0x4c,0x0c,0x3b,0xff,0x34,0x0c,0x3d,0xff,0x1c,0x0c,0x40,0xff,0x04,0x0c,0x42,0xff,  \
    0xec,0x0b,0x45,0xff,0xd5,0x0b,0x48,0xff,0xbd,0x0b,0x4a,0xff,0xa6,0x0b,0x4d,0xff,0x8f,0x0b,0x50,0xff,0x78,0x0b,0x53,0xff,0x61,0x0b,0x55,0xff,0x4a,0x0b,0x58,0xff,0x33,0x0b,0x5b,0xff,0x1d,0x0b,0x5e,0xff,0x06,0x0b,0x61,0xff,0xf0,0x0a,0x63,0xff,0xda,0x0a,0x66,0xff,0xc4,0x0a,0x69,0xff,0xae,0x0a,0x6c,0xff,0x98,0x0a,0x6f,0xff,0x82,0x0a,0x72,0xff,0x6c,0x0a,0x75,0xff,0x56,0x0a,0x77,0xff,0x41,0x0a,0x7a,0xff,0x2b,0x0a,0x7d,0xff,0x16,0x0a,0x80,0xff,0x00,0x0a,  \
    0x83,0xff,0xeb,0x09,0x86,0xff,0xd6,0x09,0x89,0xff,0xc1,0x09,0x8c,0xff,0xac,0x09,0x8f,0xff,0x97,0x09,0x92,0xff,0x82,0x09,0x94,0xff,0x6e,0x09,0x97,0xff,0x59,0x09,0x9a,0xff,0x45,0x09,0x9d,0xff,0x31,0x09,0xa0,0xff,0x1c,0x09,0xa3,0xff,0x08,0x09,0xa6,0xff,0xf4,0x08,0xa9,0xff,0xe0,0x08,0xac,0xff,0xcd,0x08,0xaf,0xff,0xb9,0x08,0xb2,0xff,0xa5,0x08,0xb5,0xff,0x92,0x08,0xb8,0xff,0x7e,0x08,0xbb,0xff,0x6b,0x08,0xbe,0xff,0x58,0x08,0xc0,0xff,0x45,0x08,0xc3,0xff,  \
    0x32,0x08,0xc6,0xff,0x1f,0x08,0xc9,0xff,0x0c,0x08,0xcc,0xff,0xf9,0x07,0xcf,0xff,0xe7,0x07,0xd2,0xff,0xd4,0x07,0xd5,0xff,0xc2,0x07,0xd8,0xff,0xaf,0x07,0xdb,0xff,0x9d,0x07,0xde,0xff,0x8b,0x07,0xe0,0xff,0x79,0x07,0xe3,0xff,0x67,0x07,0xe6,0xff,0x55,0x07,0xe9,0xff,0x44,0x07,0xec,0xff,0x32,0x07,0xef,0xff,0x21,0x07,0xf2,0xff,0x0f,0x07,0xf5,0xff,0xfe,0x06,0xf7,0xff,0xec,0x06,0xfa,0xff,0xdb,0x06,0xfd,0xff,0xca,0x06,0x00,0x00,0xb9,0x06,0x03,0x00,0xa8,0x06,  \
    0x05,0x00,0x97,0x06,0x08,0x00,0x86,0x06,0x0b,0x00,0x76,0x06,0x0e,0x00,0x65,0x06,0x10,0x00,0x55,0x06,0x13,0x00,0x44,0x06,0x16,0x00,0x34,0x06,0x19,0x00,0x23,0x06,0x1b,0x00,0x13,0x06,0x1e,0x00,0x03,0x06,0x21,0x00,0xf3,0x05,0x23,0x00,0xe3,0x05,0x26,0x00,0xd3,0x05,0x28,0x00,0xc3,0x05,0x2b,0x00,0xb3,0x05,0x2e,0x00,0xa4,0x05,0x30,0x00,0x94,0x05,0x33,0x00,0x85,0x05,0x35,0x00,0x75,0x05,0x38,0x00,0x66,0x05,0x3a,0x00,0x56,0x05,0x3d,0x00,0x47,0x05,0x3f,0x00,  \
    0x38,0x05,0x42,0x00,0x29,0x05,0x44,0x00,0x1a,0x05,0x47,0x00,0x0b,0x05,0x49,0x00,0xfc,0x04,0x4c,0x00,0xed,0x04,0x4e,0x00,0xde,0x04,0x50,0x00,0xcf,0x04,0x53,0x00,0xc0,0x04,0x55,0x00,0xb2,0x04,0x57,0x00,0xa3,0x04,0x5a,0x00,0x94,0x04,0x5c,0x00,0x86,0x04,0x5e,0x00,0x78,0x04,0x60,0x00,0x69,0x04,0x63,0x00,0x5b,0x04,0x65,0x00,0x4d,0x04,0x67,0x00,0x3e,0x04,0x69,0x00,0x30,0x04,0x6b,0x00,0x22,0x04,0x6d,0x00,0x14,0x04,0x6f,0x00,0x06,0x04,0x72,0x00,0xf8,0x03,  \
    0x74,0x00,0xea,0x03,0x76,0x00,0xdd,0x03,0x78,0x00,0xcf,0x03,0x7a,0x00,0xc1,0x03,0x7c,0x00,0xb4,0x03,0x7e,0x00,0xa6,0x03,0x80,0x00,0x99,0x03,0x82,0x00,0x8b,0x03,0x84,0x00,0x7e,0x03,0x85,0x00,0x71,0x03,0x87,0x00,0x63,0x03,0x89,0x00,0x56,0x03,0x8b,0x00,0x49,0x03,0x8d,0x00,0x3c,0x03,0x8f,0x00,0x2f,0x03,0x90,0x00,0x22,0x03,0x92,0x00,0x15,0x03,0x94,0x00,0x08,0x03,0x96,0x00,0xfb,0x02,0x97,0x00,0xee,0x02,0x99,0x00,0xe2,0x02,0x9b,0x00,0xd5,0x02,0x9c,0x00,  \
    0xc8,0x02,0x9e,0x00,0xbc,0x02,0x9f,0x00,0xaf,0x02,0xa1,0x00,0xa3,0x02,0xa2,0x00,0x96,0x02,0xa4,0x00,0x8a,0x02,0xa5,0x00,0x7d,0x02,0xa7,0x00,0x71,0x02,0xa8,0x00,0x64,0x02,0xaa,0x00,0x58,0x02,0xab,0x00,0x4c,0x02,0xac,0x00,0x40,0x02,0xae,0x00,0x34,0x02,0xaf,0x00,0x27,0x02,0xb0,0x00,0x1b,0x02,0xb2,0x00,0x0f,0x02,0xb3,0x00,0x03,0x02,0xb4,0x00,0xf7,0x01,0xb5,0x00,0xeb,0x01,0xb7,0x00,0xdf,0x01,0xb8,0x00,0xd3,0x01,0xb9,0x00,0xc8,0x01,0xba,0x00,0xbc,0x01,  \
    0xbb,0x00,0xb0,0x01,0xbc,0x00,0xa4,0x01,0xbd,0x00,0x98,0x01,0xbe,0x00,0x8d,0x01,0xbf,0x00,0x81,0x01,0xc0,0x00,0x75,0x01,0xc1,0x00,0x6a,0x01,0xc2,0x00,0x5e,0x01,0xc3,0x00,0x52,0x01,0xc4,0x00,0x47,0x01,0xc5,0x00,0x3b,0x01,0xc6,0x00,0x30,0x01,0xc6,0x00,0x24,0x01,0xc7,0x00,0x19,0x01,0xc8,0x00,0x0d,0x01,0xc9,0x00,0x02,0x01,0xc9,0x00,0xf6,0x00,0xca,0x00,0xeb,0x00,0xcb,0x00,0xdf,0x00,0xcb,0x00,0xd4,0x00,0xcc,0x00,0xc8,0x00,0xcc,0x00,0xbd,0x00,0xcd,0x00,  \
    0xb2,0x00,0xcd,0x00,0xa6,0x00,0xce,0x00,0x9b,0x00,0xce,0x00,0x90,0x00,0xcf,0x00,0x84,0x00,0xcf,0x00,0x79,0x00,0xd0,0x00,0x6e,0x00,0xd0,0x00,0x63,0x00,0xd0,0x00,0x57,0x00,0xd1,0x00,0x4c,0x00,0xd1,0x00,0x41,0x00,0xd1,0x00,0x36,0x00,0xd2,0x00,0x2a,0x00,0xd2,0x00,0x1f,0x00,0xd2,0x00,0x14,0x00,0xd2,0x00,0x09,0x00,0xd2,0x00,0xfd,0xff,0xd2,0x00,0xf2,0xff,0xd3,0x00,0xe7,0xff,0xd3,0x00,0xdc,0xff,0xd3,0x00,0xd1,0xff,0xd3,0x00,0xc5,0xff,0xd3,0x00,0xba,0xff,  \
    0xd3,0x00,0xaf,0xff,0xd3,0x00,0xa4,0xff,0xd3,0x00,0x99,0xff,0xd2,0x00,0x8e,0xff,0xd2,0x00,0x82,0xff,0xd2,0x00,0x77,0xff,0xd2,0x00,0x6c,0xff,0xd2,0x00,0x61,0xff,0xd2,0x00,0x55,0xff,0xd1,0x00,0x4a,0xff,0xd1,0x00,0x3f,0xff,0xd1,0x00,0x34,0xff,0xd0,0x00,0x28,0xff,0xd0,0x00,0x1d,0xff,0xd0,0x00,0x12,0xff,0xcf,0x00,0x07,0xff,0xcf,0x00,0xfb,0xfe,0xcf,0x00,0xf0,0xfe,0xce,0x00,0xe5,0xfe,0xce,0x00,0xd9,0xfe,0xcd,0x00,0xce,0xfe,0xcd,0x00,0xc2,0xfe,0xcc,0x00,  \
    0xb7,0xfe,0xcb,0x00,0xac,0xfe,0xcb,0x00,0xa0,0xfe,0xca,0x00,0x95,0xfe,0xca,0x00,0x89,0xfe,0xc9,0x00,0x7e,0xfe,0xc8,0x00,0x73,0xfe,0xc7,0x00,0x67,0xfe,0xc7,0x00,0x5c,0xfe,0xc6,0x00,0x50,0xfe,0xc5,0x00,0x45,0xfe,0xc4,0x00,0x3a,0xfe,0xc4,0x00,0x2e,0xfe,0xc3,0x00,0x23,0xfe,0xc2,0x00,0x17,0xfe,0xc1,0x00,0x0c,0xfe,0xc0,0x00,0x00,0xfe,0xbf,0x00,0xf4,0xfd,0xbe,0x00,0xe9,0xfd,0xbd,0x00,0xdd,0xfd,0xbc,0x00,0xd2,0xfd,0xbb,0x00,0xc6,0xfd,0xba,0x00,0xba,0xfd,  \
    0xb9,0x00,0xaf,0xfd,0xb8,0x00,0xa3,0xfd,0xb6,0x00,0x97,0xfd,0xb5,0x00,0x8b,0xfd,0xb4,0x00,0x80,0xfd,0xb3,0x00,0x74,0xfd,0xb2,0x00,0x68,0xfd,0xb0,0x00,0x5c,0xfd,0xaf,0x00,0x50,0xfd,0xae,0x00,0x44,0xfd,0xad,0x00,0x38,0xfd,0xab,0x00,0x2b,0xfd,0xaa,0x00,0x1f,0xfd,0xa8,0x00,0x13,0xfd,0xa7,0x00,0x06,0xfd,0xa6,0x00,0xfa,0xfc,0xa4,0x00,0xee,0xfc,0xa3,0x00,0xe1,0xfc,0xa1,0x00,0xd5,0xfc,0xa0,0x00,0xc8,0xfc,0x9e,0x00,0xbb,0xfc,0x9d,0x00,0xaf,0xfc,0x9b,0x00,  \
    0xa2,0xfc,0x9a,0x00,0x95,0xfc,0x98,0x00,0x88,0xfc,0x96,0x00,0x7c,0xfc,0x95,0x00,0x6f,0xfc,0x93,0x00,0x62,0xfc,0x91,0x00,0x55,0xfc,0x90,0x00,0x48,0xfc,0x8e,0x00,0x3b,0xfc,0x8c,0x00,0x2e,0xfc,0x8a,0x00,0x20,0xfc,0x89,0x00,0x13,0xfc,0x87,0x00,0x06,0xfc,0x85,0x00,0xf9,0xfb,0x83,0x00,0xeb,0xfb,0x81,0x00,0xde,0xfb,0x7f,0x00,0xd0,0xfb,0x7d,0x00,0xc3,0xfb,0x7b,0x00,0xb6,0xfb,0x79,0x00,0xa8,0xfb,0x78,0x00,0x9a,0xfb,0x76,0x00,0x8d,0xfb,0x74,0x00,0x7f,0xfb,  \
    0x71,0x00,0x71,0xfb,0x6f,0x00,0x63,0xfb,0x6d,0x00,0x55,0xfb,0x6b,0x00,0x47,0xfb,0x69,0x00,0x39,0xfb,0x67,0x00,0x2b,0xfb,0x65,0x00,0x1d,0xfb,0x63,0x00,0x0f,0xfb,0x61,0x00,0x01,0xfb,0x5e,0x00,0xf2,0xfa,0x5c,0x00,0xe4,0xfa,0x5a,0x00,0xd6,0xfa,0x58,0x00,0xc7,0xfa,0x56,0x00,0xb8,0xfa,0x53,0x00,0xaa,0xfa,0x51,0x00,0x9b,0xfa,0x4f,0x00,0x8c,0xfa,0x4c,0x00,0x7e,0xfa,0x4a,0x00,0x6f,0xfa,0x48,0x00,0x60,0xfa,0x45,0x00,0x51,0xfa,0x43,0x00,0x42,0xfa,0x41,0x00,  \
    0x32,0xfa,0x3e,0x00,0x23,0xfa,0x3c,0x00,0x14,0xfa,0x39,0x00,0x04,0xfa,0x37,0x00,0xf5,0xf9,0x35,0x00,0xe5,0xf9,0x32,0x00,0xd6,0xf9,0x30,0x00,0xc6,0xf9,0x2d,0x00,0xb6,0xf9,0x2b,0x00,0xa7,0xf9,0x28,0x00,0x97,0xf9,0x26,0x00,0x87,0xf9,0x23,0x00,0x77,0xf9,0x20,0x00,0x66,0xf9,0x1e,0x00,0x56,0xf9,0x1b,0x00,0x46,0xf9,0x19,0x00,0x35,0xf9,0x16,0x00,0x25,0xf9,0x13,0x00,0x14,0xf9,0x11,0x00,0x04,0xf9,0x0e,0x00,0xf3,0xf8,0x0c,0x00,0xe2,0xf8,0x09,0x00,0xd1,0xf8,  \
    0x06,0x00,0xc0,0xf8,0x04,0x00,0xaf,0xf8,0x01,0x00,0x9e,0xf8,0xfe,0xff,0x8d,0xf8,0xfc,0xff,0x7b,0xf8,0xf9,0xff,0x6a,0xf8,0xf6,0xff,0x58,0xf8,0xf3,0xff,0x47,0xf8,0xf1,0xff,0x35,0xf8,0xee,0xff,0x23,0xf8,0xeb,0xff,0x11,0xf8,0xe9,0xff,0xff,0xf7,0xe6,0xff,0xed,0xf7,0xe3,0xff,0xdb,0xf7,0xe0,0xff,0xc9,0xf7,0xde,0xff,0xb7,0xf7,0xdb,0xff,0xa4,0xf7,0xd8,0xff,0x92,0xf7,0xd5,0xff,0x7f,0xf7,0xd3,0xff,0x6c,0xf7,0xd0,0xff,0x59,0xf7,0xcd,0xff,0x46,0xf7,0xca,0xff,  \
    0x33,0xf7,0xc8,0xff,0x20,0xf7,0xc5,0xff,0x0d,0xf7,0xc2,0xff,0xfa,0xf6,0xbf,0xff,0xe6,0xf6,0xbc,0xff,0xd3,0xf6,0xba,0xff,0xbf,0xf6,0xb7,0xff,0xab,0xf6,0xb4,0xff,0x98,0xf6,0xb1,0xff,0x84,0xf6,0xaf,0xff,0x70,0xf6,0xac,0xff,0x5b,0xf6,0xa9,0xff,0x47,0xf6,0xa6,0xff,0x33,0xf6,0xa4,0xff,0x1e,0xf6,0xa1,0xff,0x09,0xf6,0x9e,0xff,0xf5,0xf5,0x9c,0xff,0xe0,0xf5,0x99,0xff,0xcb,0xf5,0x96,0xff,0xb6,0xf5,0x93,0xff,0xa1,0xf5,0x91,0xff,0x8b,0xf5,0x8e,0xff,0x76,0xf5,  \
    0x8b,0xff,0x60,0xf5,0x89,0xff,0x4b,0xf5,0x86,0xff,0x35,0xf5,0x84,0xff,0x1f,0xf5,0x81,0xff,0x09,0xf5,0x7e,0xff,0xf3,0xf4,0x7c,0xff,0xdd,0xf4,0x79,0xff,0xc7,0xf4,0x77,0xff,0xb0,0xf4,0x74,0xff,0x9a,0xf4,0x71,0xff,0x83,0xf4,0x6f,0xff,0x6d,0xf4,0x6c,0xff,0x56,0xf4,0x6a,0xff,0x3f,0xf4,0x67,0xff,0x28,0xf4,0x65,0xff,0x10,0xf4,0x62,0xff,0xf9,0xf3,0x60,0xff,0xe2,0xf3,0x5e,0xff,0xca,0xf3,0x5b,0xff,0xb2,0xf3,0x59,0xff,0x9b,0xf3,0x57,0xff,0x83,0xf3,0x54,0xff,  \
    0x6b,0xf3,0x52,0xff,0x52,0xf3,0x50,0xff,0x3a,0xf3,0x4d,0xff,0x22,0xf3,0x4b,0xff,0x09,0xf3,0x49,0xff,0xf0,0xf2,0x47,0xff,0xd8,0xf2,0x45,0xff,0xbf,0xf2,0x42,0xff,0xa6,0xf2,0x40,0xff,0x8c,0xf2,0x3e,0xff,0x73,0xf2,0x3c,0xff,0x5a,0xf2,0x3a,0xff,0x40,0xf2,0x38,0xff,0x26,0xf2,0x36,0xff,0x0c,0xf2,0x34,0xff,0xf3,0xf1,0x33,0xff,0xd8,0xf1,0x31,0xff,0xbe,0xf1,0x2f,0xff,0xa4,0xf1,0x2d,0xff,0x89,0xf1,0x2b,0xff,0x6f,0xf1,0x2a,0xff,0x54,0xf1,0x28,0xff,0x39,0xf1,  \
    0x26,0xff,0x1e,0xf1,0x25,0xff,0x03,0xf1,0x23,0xff,0xe8,0xf0,0x22,0xff,0xcd,0xf0,0x20,0xff,0xb1,0xf0,0x1f,0xff,0x96,0xf0,0x1d,0xff,0x7a,0xf0,0x1c,0xff,0x5e,0xf0,0x1a,0xff,0x42,0xf0,0x19,0xff,0x26,0xf0,0x18,0xff,0x0a,0xf0,0x16,0xff,0xed,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe3,0xfe,0x20,0x10,0xe4,0xfe,0x03,0x10,0xe6,0xfe,0xe7,0x0f,0xe7,0xfe,0xcb,0x0f,0xe9,0xfe,0xae,0x0f,0xea,0xfe,0x92,0x0f,0xec,0xfe,0x76,0x0f,0xee,0xfe,0x5a,0x0f,0xef,0xfe,0x3f,0x0f,0xf1,0xfe,0x23,0x0f,0xf3,0xfe,0x08,0x0f,0xf4,0xfe,0xec,0x0e,0xf6,0xfe,0xd1,0x0e,0xf8,0xfe,0xb6,0x0e,0xfa,0xfe,0x9b,0x0e,0xfc,0xfe,0x80,0x0e,0xfe,0xfe,0x65,0x0e,0x00,0xff,0x4b,0x0e,  \
    0x02,0xff,0x30,0x0e,0x04,0xff,0x16,0x0e,0x06,0xff,0xfc,0x0d,0x08,0xff,0xe1,0x0d,0x0b,0xff,0xc7,0x0d,0x0d,0xff,0xad,0x0d,0x0f,0xff,0x94,0x0d,0x11,0xff,0x7a,0x0d,0x14,0xff,0x60,0x0d,0x16,0xff,0x47,0x0d,0x18,0xff,0x2e,0x0d,0x1b,0xff,0x14,0x0d,0x1d,0xff,0xfb,0x0c,0x1f,0xff,0xe2,0x0c,0x22,0xff,0xc9,0x0c,0x24,0xff,0xb1,0x0c,0x27,0xff,0x98,0x0c,0x29,0xff,0x80,0x0c,0x2c,0xff,0x67,0x0c,0x2f,0xff,0x4f,0x0c,0x31,0xff,0x37,0x0c,0x34,0xff,0x1f,0x0c,0x37,0xff,  \
    0x07,0x0c,0x39,0xff,0xef,0x0b,0x3c,0xff,0xd8,0x0b,0x3f,0xff,0xc0,0x0b,0x42,0xff,0xa9,0x0b,0x44,0xff,0x92,0x0b,0x47,0xff,0x7b,0x0b,0x4a,0xff,0x64,0x0b,0x4d,0xff,0x4d,0x0b,0x50,0xff,0x36,0x0b,0x53,0xff,0x20,0x0b,0x56,0xff,0x09,0x0b,0x59,0xff,0xf3,0x0a,0x5b,0xff,0xdd,0x0a,0x5e,0xff,0xc7,0x0a,0x61,0xff,0xb1,0x0a,0x64,0xff,0x9b,0x0a,0x67,0xff,0x85,0x0a,0x6a,0xff,0x6f,0x0a,0x6d,0xff,0x59,0x0a,0x70,0xff,0x44,0x0a,0x73,0xff,0x2e,0x0a,0x76,0xff,0x19,0x0a,  \
    0x79,0xff,0x03,0x0a,0x7c,0xff,0xee,0x09,0x7f,0xff,0xd9,0x09,0x82,0xff,0xc4,0x09,0x85,0xff,0xaf,0x09,0x88,0xff,0x9a,0x09,0x8b,0xff,0x86,0x09,0x8e,0xff,0x71,0x09,0x91,0xff,0x5d,0x09,0x94,0xff,0x48,0x09,0x97,0xff,0x34,0x09,0x9a,0xff,0x20,0x09,0x9d,0xff,0x0c,0x09,0xa0,0xff,0xf8,0x08,0xa3,0xff,0xe4,0x08,0xa6,0xff,0xd0,0x08,0xa9,0xff,0xbc,0x08,0xac,0xff,0xa9,0x08,0xaf,0xff,0x95,0x08,0xb2,0xff,0x82,0x08,0xb5,0xff,0x6f,0x08,0xb8,0xff,0x5b,0x08,0xbc,0xff,  \
    0x48,0x08,0xbf,0xff,0x35,0x08,0xc2,0xff,0x22,0x08,0xc5,0xff,0x10,0x08,0xc8,0xff,0xfd,0x07,0xcb,0xff,0xea,0x07,0xce,0xff,0xd8,0x07,0xd1,0xff,0xc5,0x07,0xd4,0xff,0xb3,0x07,0xd7,0xff,0xa1,0x07,0xda,0xff,0x8f,0x07,0xdd,0xff,0x7d,0x07,0xe0,0xff,0x6b,0x07,0xe3,0xff,0x59,0x07,0xe5,0xff,0x47,0x07,0xe8,0xff,0x36,0x07,0xeb,0xff,0x24,0x07,0xee,0xff,0x13,0x07,0xf1,0xff,0x01,0x07,0xf4,0xff,0xf0,0x06,0xf7,0xff,0xdf,0x06,0xfa,0xff,0xce,0x06,0xfd,0xff,0xbd,0x06,  \
    0x00,0x00,0xac,0x06,0x03,0x00,0x9b,0x06,0x06,0x00,0x8a,0x06,0x08,0x00,0x79,0x06,0x0b,0x00,0x69,0x06,0x0e,0x00,0x58,0x06,0x11,0x00,0x48,0x06,0x14,0x00,0x37,0x06,0x16,0x00,0x27,0x06,0x19,0x00,0x17,0x06,0x1c,0x00,0x07,0x06,0x1f,0x00,0xf7,0x05,0x21,0x00,0xe7,0x05,0x24,0x00,0xd7,0x05,0x27,0x00,0xc7,0x05,0x2a,0x00,0xb7,0x05,0x2c,0x00,0xa7,0x05,0x2f,0x00,0x98,0x05,0x32,0x00,0x88,0x05,0x34,0x00,0x79,0x05,0x37,0x00,0x69,0x05,0x39,0x00,0x5a,0x05,0x3c,0x00,  \
    0x4b,0x05,0x3f,0x00,0x3b,0x05,0x41,0x00,0x2c,0x05,0x44,0x00,0x1d,0x05,0x46,0x00,0x0e,0x05,0x49,0x00,0xff,0x04,0x4b,0x00,0xf1,0x04,0x4e,0x00,0xe2,0x04,0x50,0x00,0xd3,0x04,0x52,0x00,0xc4,0x04,0x55,0x00,0xb5,0x04,0x57,0x00,0xa7,0x04,0x5a,0x00,0x98,0x04,0x5c,0x00,0x89,0x04,0x5e,0x00,0x7b,0x04,0x61,0x00,0x6d,0x04,0x63,0x00,0x5e,0x04,0x65,0x00,0x50,0x04,0x67,0x00,0x42,0x04,0x6a,0x00,0x34,0x04,0x6c,0x00,0x25,0x04,0x6e,0x00,0x17,0x04,0x70,0x00,0x09,0x04,  \
    0x72,0x00,0xfb,0x03,0x74,0x00,0xee,0x03,0x77,0x00,0xe0,0x03,0x79,0x00,0xd2,0x03,0x7b,0x00,0xc4,0x03,0x7d,0x00,0xb7,0x03,0x7f,0x00,0xa9,0x03,0x81,0x00,0x9c,0x03,0x83,0x00,0x8e,0x03,0x85,0x00,0x81,0x03,0x87,0x00,0x74,0x03,0x89,0x00,0x66,0x03,0x8b,0x00,0x59,0x03,0x8c,0x00,0x4c,0x03,0x8e,0x00,0x3f,0x03,0x90,0x00,0x32,0x03,0x92,0x00,0x25,0x03,0x94,0x00,0x18,0x03,0x96,0x00,0x0b,0x03,0x97,0x00,0xfe,0x02,0x99,0x00,0xf1,0x02,0x9b,0x00,0xe4,0x02,0x9c,0x00,  \
    0xd8,0x02,0x9e,0x00,0xcb,0x02,0xa0,0x00,0xbe,0x02,0xa1,0x00,0xb2,0x02,0xa3,0x00,0xa5,0x02,0xa5,0x00,0x99,0x02,0xa6,0x00,0x8c,0x02,0xa8,0x00,0x80,0x02,0xa9,0x00,0x73,0x02,0xab,0x00,0x67,0x02,0xac,0x00,0x5a,0x02,0xae,0x00,0x4e,0x02,0xaf,0x00,0x42,0x02,0xb0,0x00,0x36,0x02,0xb2,0x00,0x2a,0x02,0xb3,0x00,0x1d,0x02,0xb4,0x00,0x11,0x02,0xb6,0x00,0x05,0x02,0xb7,0x00,0xf9,0x01,0xb8,0x00,0xed,0x01,0xb9,0x00,0xe1,0x01,0xbb,0x00,0xd5,0x01,0xbc,0x00,0xc9,0x01,  \
    0xbd,0x00,0xbe,0x01,0xbe,0x00,0xb2,0x01,0xbf,0x00,0xa6,0x01,0xc0,0x00,0x9a,0x01,0xc1,0x00,0x8e,0x01,0xc2,0x00,0x83,0x01,0xc3,0x00,0x77,0x01,0xc4,0x00,0x6b,0x01,0xc5,0x00,0x5f,0x01,0xc6,0x00,0x54,0x01,0xc7,0x00,0x48,0x01,0xc8,0x00,0x3d,0x01,0xc9,0x00,0x31,0x01,0xca,0x00,0x25,0x01,0xca,0x00,0x1a,0x01,0xcb,0x00,0x0e,0x01,0xcc,0x00,0x03,0x01,0xcd,0x00,0xf7,0x00,0xcd,0x00,0xec,0x00,0xce,0x00,0xe0,0x00,0xcf,0x00,0xd5,0x00,0xcf,0x00,0xc9,0x00,0xd0,0x00,  \
    0xbe,0x00,0xd0,0x00,0xb3,0x00,0xd1,0x00,0xa7,0x00,0xd1,0x00,0x9c,0x00,0xd2,0x00,0x91,0x00,0xd2,0x00,0x85,0x00,0xd3,0x00,0x7a,0x00,0xd3,0x00,0x6f,0x00,0xd4,0x00,0x63,0x00,0xd4,0x00,0x58,0x00,0xd4,0x00,0x4d,0x00,0xd5,0x00,0x41,0x00,0xd5,0x00,0x36,0x00,0xd5,0x00,0x2b,0x00,0xd5,0x00,0x1f,0x00,0xd6,0x00,0x14,0x00,0xd6,0x00,0x09,0x00,0xd6,0x00,0xfe,0xff,0xd6,0x00,0xf2,0xff,0xd6,0x00,0xe7,0xff,0xd6,0x00,0xdc,0xff,0xd6,0x00,0xd1,0xff,0xd6,0x00,0xc6,0xff,  \
    0xd6,0x00,0xba,0xff,0xd6,0x00,0xaf,0xff,0xd6,0x00,0xa4,0xff,0xd6,0x00,0x99,0xff,0xd6,0x00,0x8d,0xff,0xd6,0x00,0x82,0xff,0xd6,0x00,0x77,0xff,0xd6,0x00,0x6c,0xff,0xd5,0x00,0x60,0xff,0xd5,0x00,0x55,0xff,0xd5,0x00,0x4a,0xff,0xd5,0x00,0x3e,0xff,0xd4,0x00,0x33,0xff,0xd4,0x00,0x28,0xff,0xd4,0x00,0x1c,0xff,0xd3,0x00,0x11,0xff,0xd3,0x00,0x06,0xff,0xd2,0x00,0xfa,0xfe,0xd2,0x00,0xef,0xfe,0xd2,0x00,0xe4,0xfe,0xd1,0x00,0xd8,0xfe,0xd1,0x00,0xcd,0xfe,0xd0,0x00,  \
    0xc1,0xfe,0xcf,0x00,0xb6,0xfe,0xcf,0x00,0xaa,0xfe,0xce,0x00,0x9f,0xfe,0xce,0x00,0x94,0xfe,0xcd,0x00,0x88,0xfe,0xcc,0x00,0x7d,0xfe,0xcc,0x00,0x71,0xfe,0xcb,0x00,0x66,0xfe,0xca,0x00,0x5a,0xfe,0xc9,0x00,0x4f,0xfe,0xc8,0x00,0x43,0xfe,0xc8,0x00,0x38,0xfe,0xc7,0x00,0x2c,0xfe,0xc6,0x00,0x21,0xfe,0xc5,0x00,0x15,0xfe,0xc4,0x00,0x0a,0xfe,0xc3,0x00,0xfe,0xfd,0xc2,0x00,0xf3,0xfd,0xc1,0x00,0xe7,0xfd,0xc0,0x00,0xdb,0xfd,0xbf,0x00,0xd0,0xfd,0xbe,0x00,0xc4,0xfd,  \
    0xbd,0x00,0xb8,0xfd,0xbc,0x00,0xad,0xfd,0xba,0x00,0xa1,0xfd,0xb9,0x00,0x95,0xfd,0xb8,0x00,0x89,0xfd,0xb7,0x00,0x7d,0xfd,0xb6,0x00,0x72,0xfd,0xb4,0x00,0x66,0xfd,0xb3,0x00,0x5a,0xfd,0xb2,0x00,0x4e,0xfd,0xb0,0x00,0x42,0xfd,0xaf,0x00,0x35,0xfd,0xae,0x00,0x29,0xfd,0xac,0x00,0x1d,0xfd,0xab,0x00,0x10,0xfd,0xa9,0x00,0x04,0xfd,0xa8,0x00,0xf8,0xfc,0xa6,0x00,0xeb,0xfc,0xa5,0x00,0xdf,0xfc,0xa3,0x00,0xd2,0xfc,0xa2,0x00,0xc5,0xfc,0xa0,0x00,0xb9,0xfc,0x9f,0x00,  \
    0xac,0xfc,0x9d,0x00,0x9f,0xfc,0x9c,0x00,0x93,0xfc,0x9a,0x00,0x86,0xfc,0x98,0x00,0x79,0xfc,0x96,0x00,0x6c,0xfc,0x95,0x00,0x5f,0xfc,0x93,0x00,0x52,0xfc,0x91,0x00,0x45,0xfc,0x90,0x00,0x38,0xfc,0x8e,0x00,0x2b,0xfc,0x8c,0x00,0x1d,0xfc,0x8a,0x00,0x10,0xfc,0x88,0x00,0x03,0xfc,0x86,0x00,0xf5,0xfb,0x84,0x00,0xe8,0xfb,0x83,0x00,0xdb,0xfb,0x81,0x00,0xcd,0xfb,0x7f,0x00,0xc0,0xfb,0x7d,0x00,0xb2,0xfb,0x7b,0x00,0xa5,0xfb,0x79,0x00,0x97,0xfb,0x77,0x00,0x89,0xfb,  \
    0x74,0x00,0x7c,0xfb,0x72,0x00,0x6e,0xfb,0x70,0x00,0x60,0xfb,0x6e,0x00,0x52,0xfb,0x6c,0x00,0x44,0xfb,0x6a,0x00,0x36,0xfb,0x68,0x00,0x28,0xfb,0x66,0x00,0x1a,0xfb,0x63,0x00,0x0c,0xfb,0x61,0x00,0xfd,0xfa,0x5f,0x00,0xef,0xfa,0x5d,0x00,0xe0,0xfa,0x5a,0x00,0xd2,0xfa,0x58,0x00,0xc3,0xfa,0x56,0x00,0xb5,0xfa,0x53,0x00,0xa6,0xfa,0x51,0x00,0x97,0xfa,0x4f,0x00,0x89,0xfa,0x4c,0x00,0x7a,0xfa,0x4a,0x00,0x6b,0xfa,0x47,0x00,0x5c,0xfa,0x45,0x00,0x4d,0xfa,0x43,0x00,  \
    0x3e,0xfa,0x40,0x00,0x2f,0xfa,0x3e,0x00,0x1f,0xfa,0x3b,0x00,0x10,0xfa,0x39,0x00,0x01,0xfa,0x36,0x00,0xf1,0xf9,0x34,0x00,0xe2,0xf9,0x31,0x00,0xd2,0xf9,0x2f,0x00,0xc2,0xf9,0x2c,0x00,0xb3,0xf9,0x29,0x00,0xa3,0xf9,0x27,0x00,0x93,0xf9,0x24,0x00,0x83,0xf9,0x22,0x00,0x73,0xf9,0x1f,0x00,0x63,0xf9,0x1c,0x00,0x52,0xf9,0x1a,0x00,0x42,0xf9,0x17,0x00,0x32,0xf9,0x14,0x00,0x21,0xf9,0x12,0x00,0x11,0xf9,0x0f,0x00,0x00,0xf9,0x0c,0x00,0xef,0xf8,0x0a,0x00,0xde,0xf8,  \
    0x07,0x00,0xcd,0xf8,0x04,0x00,0xbc,0xf8,0x01,0x00,0xab,0xf8,0xff,0xff,0x9a,0xf8,0xfc,0xff,0x89,0xf8,0xf9,0xff,0x78,0xf8,0xf6,0xff,0x66,0xf8,0xf4,0xff,0x55,0xf8,0xf1,0xff,0x43,0xf8,0xee,0xff,0x31,0xf8,0xeb,0xff,0x20,0xf8,0xe8,0xff,0x0e,0xf8,0xe6,0xff,0xfc,0xf7,0xe3,0xff,0xea,0xf7,0xe0,0xff,0xd7,0xf7,0xdd,0xff,0xc5,0xf7,0xda,0xff,0xb3,0xf7,0xd7,0xff,0xa0,0xf7,0xd5,0xff,0x8e,0xf7,0xd2,0xff,0x7b,0xf7,0xcf,0xff,0x69,0xf7,0xcc,0xff,0x56,0xf7,0xc9,0xff,  \
    0x43,0xf7,0xc6,0xff,0x30,0xf7,0xc3,0xff,0x1d,0xf7,0xc1,0xff,0x09,0xf7,0xbe,0xff,0xf6,0xf6,0xbb,0xff,0xe3,0xf6,0xb8,0xff,0xcf,0xf6,0xb5,0xff,0xbb,0xf6,0xb2,0xff,0xa8,0xf6,0xb0,0xff,0x94,0xf6,0xad,0xff,0x80,0xf6,0xaa,0xff,0x6c,0xf6,0xa7,0xff,0x58,0xf6,0xa4,0xff,0x43,0xf6,0xa1,0xff,0x2f,0xf6,0x9f,0xff,0x1a,0xf6,0x9c,0xff,0x06,0xf6,0x99,0xff,0xf1,0xf5,0x96,0xff,0xdc,0xf5,0x93,0xff,0xc7,0xf5,0x91,0xff,0xb2,0xf5,0x8e,0xff,0x9d,0xf5,0x8b,0xff,0x88,0xf5,  \
    0x88,0xff,0x72,0xf5,0x86,0xff,0x5d,0xf5,0x83,0xff,0x47,0xf5,0x80,0xff,0x32,0xf5,0x7d,0xff,0x1c,0xf5,0x7b,0xff,0x06,0xf5,0x78,0xff,0xf0,0xf4,0x75,0xff,0xda,0xf4,0x73,0xff,0xc3,0xf4,0x70,0xff,0xad,0xf4,0x6d,0xff,0x96,0xf4,0x6b,0xff,0x80,0xf4,0x68,0xff,0x69,0xf4,0x66,0xff,0x52,0xf4,0x63,0xff,0x3b,0xf4,0x61,0xff,0x24,0xf4,0x5e,0xff,0x0d,0xf4,0x5b,0xff,0xf6,0xf3,0x59,0xff,0xde,0xf3,0x56,0xff,0xc7,0xf3,0x54,0xff,0xaf,0xf3,0x52,0xff,0x97,0xf3,0x4f,0xff,  \
    0x7f,0xf3,0x4d,0xff,0x67,0xf3,0x4a,0xff,0x4f,0xf3,0x48,0xff,0x37,0xf3,0x46,0xff,0x1e,0xf3,0x43,0xff,0x06,0xf3,0x41,0xff,0xed,0xf2,0x3f,0xff,0xd4,0xf2,0x3d,0xff,0xbb,0xf2,0x3b,0xff,0xa2,0xf2,0x38,0xff,0x89,0xf2,0x36,0xff,0x70,0xf2,0x34,0xff,0x56,0xf2,0x32,0xff,0x3d,0xf2,0x30,0xff,0x23,0xf2,0x2e,0xff,0x09,0xf2,0x2c,0xff,0xef,0xf1,0x2a,0xff,0xd5,0xf1,0x28,0xff,0xbb,0xf1,0x26,0xff,0xa1,0xf1,0x24,0xff,0x86,0xf1,0x23,0xff,0x6c,0xf1,0x21,0xff,0x51,0xf1,  \
    0x1f,0xff,0x36,0xf1,0x1d,0xff,0x1b,0xf1,0x1c,0xff,0x00,0xf1,0x1a,0xff,0xe5,0xf0,0x19,0xff,0xca,0xf0,0x17,0xff,0xae,0xf0,0x15,0xff,0x93,0xf0,0x14,0xff,0x77,0xf0,0x13,0xff,0x5b,0xf0,0x11,0xff,0x3f,0xf0,0x10,0xff,0x23,0xf0,0x0e,0xff,0x07,0xf0,0x0d,0xff,0xea,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xd7,0xfe,0x22,0x10,0xd9,0xfe,0x06,0x10,0xda,0xfe,0xe9,0x0f,0xdc,0xfe,0xcd,0x0f,0xdd,0xfe,0xb1,0x0f,0xdf,0xfe,0x95,0x0f,0xe0,0xfe,0x79,0x0f,0xe2,0xfe,0x5d,0x0f,0xe4,0xfe,0x41,0x0f,0xe5,0xfe,0x26,0x0f,0xe7,0xfe,0x0a,0x0f,0xe9,0xfe,0xef,0x0e,0xeb,0xfe,0xd4,0x0e,0xed,0xfe,0xb8,0x0e,0xef,0xfe,0x9e,0x0e,0xf1,0xfe,0x83,0x0e,0xf3,0xfe,0x68,0x0e,  \
    0xf5,0xfe,0x4d,0x0e,0xf7,0xfe,0x33,0x0e,0xf9,0xfe,0x18,0x0e,0xfb,0xfe,0xfe,0x0d,0xfe,0xfe,0xe4,0x0d,0x00,0xff,0xca,0x0d,0x02,0xff,0xb0,0x0d,0x05,0xff,0x96,0x0d,0x07,0xff,0x7d,0x0d,0x09,0xff,0x63,0x0d,0x0c,0xff,0x4a,0x0d,0x0e,0xff,0x30,0x0d,0x11,0xff,0x17,0x0d,0x13,0xff,0xfe,0x0c,0x16,0xff,0xe5,0x0c,0x18,0xff,0xcc,0x0c,0x1b,0xff,0xb3,0x0c,0x1d,0xff,0x9b,0x0c,0x20,0xff,0x82,0x0c,0x22,0xff,0x6a,0x0c,0x25,0xff,0x52,0x0c,0x28,0xff,0x39,0x0c,0x2b,0xff,  \
    0x21,0x0c,0x2d,0xff,0x0a,0x0c,0x30,0xff,0xf2,0x0b,0x33,0xff,0xda,0x0b,0x36,0xff,0xc3,0x0b,0x39,0xff,0xac,0x0b,0x3c,0xff,0x95,0x0b,0x3f,0xff,0x7e,0x0b,0x41,0xff,0x67,0x0b,0x44,0xff,0x50,0x0b,0x47,0xff,0x39,0x0b,0x4a,0xff,0x23,0x0b,0x4d,0xff,0x0c,0x0b,0x50,0xff,0xf6,0x0a,0x53,0xff,0xe0,0x0a,0x57,0xff,0xca,0x0a,0x5a,0xff,0xb4,0x0a,0x5d,0xff,0x9e,0x0a,0x60,0xff,0x88,0x0a,0x63,0xff,0x72,0x0a,0x66,0xff,0x5d,0x0a,0x69,0xff,0x47,0x0a,0x6c,0xff,0x32,0x0a,  \
    0x6f,0xff,0x1c,0x0a,0x72,0xff,0x07,0x0a,0x75,0xff,0xf2,0x09,0x78,0xff,0xdc,0x09,0x7b,0xff,0xc7,0x09,0x7e,0xff,0xb3,0x09,0x81,0xff,0x9e,0x09,0x85,0xff,0x89,0x09,0x88,0xff,0x75,0x09,0x8b,0xff,0x60,0x09,0x8e,0xff,0x4c,0x09,0x91,0xff,0x37,0x09,0x94,0xff,0x23,0x09,0x97,0xff,0x0f,0x09,0x9a,0xff,0xfb,0x08,0x9e,0xff,0xe7,0x08,0xa1,0xff,0xd4,0x08,0xa4,0xff,0xc0,0x08,0xa7,0xff,0xac,0x08,0xaa,0xff,0x99,0x08,0xad,0xff,0x85,0x08,0xb0,0xff,0x72,0x08,0xb3,0xff,  \
    0x5f,0x08,0xb7,0xff,0x4c,0x08,0xba,0xff,0x39,0x08,0xbd,0xff,0x26,0x08,0xc0,0xff,0x13,0x08,0xc3,0xff,0x01,0x08,0xc6,0xff,0xee,0x07,0xc9,0xff,0xdb,0x07,0xcc,0xff,0xc9,0x07,0xcf,0xff,0xb7,0x07,0xd2,0xff,0xa4,0x07,0xd6,0xff,0x92,0x07,0xd9,0xff,0x80,0x07,0xdc,0xff,0x6f,0x07,0xdf,0xff,0x5d,0x07,0xe2,0xff,0x4b,0x07,0xe5,0xff,0x39,0x07,0xe8,0xff,0x28,0x07,0xeb,0xff,0x16,0x07,0xee,0xff,0x05,0x07,0xf1,0xff,0xf4,0x06,0xf4,0xff,0xe3,0x06,0xf7,0xff,0xd1,0x06,  \
    0xfa,0xff,0xc0,0x06,0xfd,0xff,0xb0,0x06,0x00,0x00,0x9f,0x06,0x03,0x00,0x8e,0x06,0x06,0x00,0x7d,0x06,0x09,0x00,0x6d,0x06,0x0c,0x00,0x5c,0x06,0x0f,0x00,0x4c,0x06,0x11,0x00,0x3b,0x06,0x14,0x00,0x2b,0x06,0x17,0x00,0x1b,0x06,0x1a,0x00,0x0b,0x06,0x1d,0x00,0xfa,0x05,0x20,0x00,0xea,0x05,0x22,0x00,0xdb,0x05,0x25,0x00,0xcb,0x05,0x28,0x00,0xbb,0x05,0x2b,0x00,0xab,0x05,0x2e,0x00,0x9c,0x05,0x30,0x00,0x8c,0x05,0x33,0x00,0x7c,0x05,0x36,0x00,0x6d,0x05,0x38,0x00,  \
    0x5e,0x05,0x3b,0x00,0x4e,0x05,0x3e,0x00,0x3f,0x05,0x40,0x00,0x30,0x05,0x43,0x00,0x21,0x05,0x45,0x00,0x12,0x05,0x48,0x00,0x03,0x05,0x4b,0x00,0xf4,0x04,0x4d,0x00,0xe5,0x04,0x50,0x00,0xd6,0x04,0x52,0x00,0xc8,0x04,0x55,0x00,0xb9,0x04,0x57,0x00,0xaa,0x04,0x59,0x00,0x9c,0x04,0x5c,0x00,0x8d,0x04,0x5e,0x00,0x7f,0x04,0x61,0x00,0x70,0x04,0x63,0x00,0x62,0x04,0x65,0x00,0x53,0x04,0x68,0x00,0x45,0x04,0x6a,0x00,0x37,0x04,0x6c,0x00,0x29,0x04,0x6e,0x00,0x1b,0x04,  \
    0x71,0x00,0x0d,0x04,0x73,0x00,0xff,0x03,0x75,0x00,0xf1,0x03,0x77,0x00,0xe3,0x03,0x79,0x00,0xd5,0x03,0x7c,0x00,0xc8,0x03,0x7e,0x00,0xba,0x03,0x80,0x00,0xac,0x03,0x82,0x00,0x9f,0x03,0x84,0x00,0x91,0x03,0x86,0x00,0x84,0x03,0x88,0x00,0x77,0x03,0x8a,0x00,0x69,0x03,0x8c,0x00,0x5c,0x03,0x8e,0x00,0x4f,0x03,0x90,0x00,0x42,0x03,0x92,0x00,0x35,0x03,0x94,0x00,0x28,0x03,0x95,0x00,0x1b,0x03,0x97,0x00,0x0e,0x03,0x99,0x00,0x01,0x03,0x9b,0x00,0xf4,0x02,0x9d,0x00,  \
    0xe7,0x02,0x9e,0x00,0xda,0x02,0xa0,0x00,0xce,0x02,0xa2,0x00,0xc1,0x02,0xa3,0x00,0xb4,0x02,0xa5,0x00,0xa8,0x02,0xa7,0x00,0x9b,0x02,0xa8,0x00,0x8f,0x02,0xaa,0x00,0x82,0x02,0xab,0x00,0x76,0x02,0xad,0x00,0x69,0x02,0xae,0x00,0x5d,0x02,0xb0,0x00,0x50,0x02,0xb1,0x00,0x44,0x02,0xb3,0x00,0x38,0x02,0xb4,0x00,0x2c,0x02,0xb6,0x00,0x20,0x02,0xb7,0x00,0x14,0x02,0xb8,0x00,0x07,0x02,0xba,0x00,0xfb,0x01,0xbb,0x00,0xef,0x01,0xbc,0x00,0xe3,0x01,0xbd,0x00,0xd7,0x01,  \
    0xbf,0x00,0xcb,0x01,0xc0,0x00,0xbf,0x01,0xc1,0x00,0xb4,0x01,0xc2,0x00,0xa8,0x01,0xc3,0x00,0x9c,0x01,0xc4,0x00,0x90,0x01,0xc5,0x00,0x84,0x01,0xc6,0x00,0x79,0x01,0xc7,0x00,0x6d,0x01,0xc8,0x00,0x61,0x01,0xc9,0x00,0x55,0x01,0xca,0x00,0x4a,0x01,0xcb,0x00,0x3e,0x01,0xcc,0x00,0x32,0x01,0xcd,0x00,0x27,0x01,0xce,0x00,0x1b,0x01,0xce,0x00,0x10,0x01,0xcf,0x00,0x04,0x01,0xd0,0x00,0xf9,0x00,0xd1,0x00,0xed,0x00,0xd1,0x00,0xe2,0x00,0xd2,0x00,0xd6,0x00,0xd3,0x00,  \
    0xcb,0x00,0xd3,0x00,0xbf,0x00,0xd4,0x00,0xb4,0x00,0xd4,0x00,0xa8,0x00,0xd5,0x00,0x9d,0x00,0xd5,0x00,0x91,0x00,0xd6,0x00,0x86,0x00,0xd6,0x00,0x7b,0x00,0xd7,0x00,0x6f,0x00,0xd7,0x00,0x64,0x00,0xd7,0x00,0x59,0x00,0xd8,0x00,0x4d,0x00,0xd8,0x00,0x42,0x00,0xd8,0x00,0x36,0x00,0xd9,0x00,0x2b,0x00,0xd9,0x00,0x20,0x00,0xd9,0x00,0x15,0x00,0xd9,0x00,0x09,0x00,0xd9,0x00,0xfe,0xff,0xda,0x00,0xf3,0xff,0xda,0x00,0xe7,0xff,0xda,0x00,0xdc,0xff,0xda,0x00,0xd1,0xff,  \
    0xda,0x00,0xc6,0xff,0xda,0x00,0xba,0xff,0xda,0x00,0xaf,0xff,0xda,0x00,0xa4,0xff,0xda,0x00,0x98,0xff,0xda,0x00,0x8d,0xff,0xd9,0x00,0x82,0xff,0xd9,0x00,0x76,0xff,0xd9,0x00,0x6b,0xff,0xd9,0x00,0x60,0xff,0xd9,0x00,0x55,0xff,0xd8,0x00,0x49,0xff,0xd8,0x00,0x3e,0xff,0xd8,0x00,0x32,0xff,0xd7,0x00,0x27,0xff,0xd7,0x00,0x1c,0xff,0xd7,0x00,0x10,0xff,0xd6,0x00,0x05,0xff,0xd6,0x00,0xfa,0xfe,0xd5,0x00,0xee,0xfe,0xd5,0x00,0xe3,0xfe,0xd4,0x00,0xd7,0xfe,0xd4,0x00,  \
    0xcc,0xfe,0xd3,0x00,0xc0,0xfe,0xd3,0x00,0xb5,0xfe,0xd2,0x00,0xa9,0xfe,0xd1,0x00,0x9e,0xfe,0xd1,0x00,0x92,0xfe,0xd0,0x00,0x87,0xfe,0xcf,0x00,0x7b,0xfe,0xcf,0x00,0x70,0xfe,0xce,0x00,0x64,0xfe,0xcd,0x00,0x59,0xfe,0xcc,0x00,0x4d,0xfe,0xcc,0x00,0x42,0xfe,0xcb,0x00,0x36,0xfe,0xca,0x00,0x2b,0xfe,0xc9,0x00,0x1f,0xfe,0xc8,0x00,0x14,0xfe,0xc7,0x00,0x08,0xfe,0xc6,0x00,0xfd,0xfd,0xc5,0x00,0xf1,0xfd,0xc4,0x00,0xe5,0xfd,0xc3,0x00,0xda,0xfd,0xc2,0x00,0xce,0xfd,  \
    0xc1,0x00,0xc2,0xfd,0xc0,0x00,0xb6,0xfd,0xbe,0x00,0xab,0xfd,0xbd,0x00,0x9f,0xfd,0xbc,0x00,0x93,0xfd,0xbb,0x00,0x87,0xfd,0xb9,0x00,0x7b,0xfd,0xb8,0x00,0x6f,0xfd,0xb7,0x00,0x64,0xfd,0xb6,0x00,0x58,0xfd,0xb4,0x00,0x4c,0xfd,0xb3,0x00,0x3f,0xfd,0xb1,0x00,0x33,0xfd,0xb0,0x00,0x27,0xfd,0xaf,0x00,0x1a,0xfd,0xad,0x00,0x0e,0xfd,0xac,0x00,0x02,0xfd,0xaa,0x00,0xf5,0xfc,0xa9,0x00,0xe9,0xfc,0xa7,0x00,0xdc,0xfc,0xa6,0x00,0xcf,0xfc,0xa4,0x00,0xc3,0xfc,0xa2,0x00,  \
    0xb6,0xfc,0xa1,0x00,0xa9,0xfc,0x9f,0x00,0x9d,0xfc,0x9d,0x00,0x90,0xfc,0x9c,0x00,0x83,0xfc,0x9a,0x00,0x76,0xfc,0x98,0x00,0x69,0xfc,0x97,0x00,0x5c,0xfc,0x95,0x00,0x4f,0xfc,0x93,0x00,0x42,0xfc,0x91,0x00,0x35,0xfc,0x8f,0x00,0x27,0xfc,0x8d,0x00,0x1a,0xfc,0x8c,0x00,0x0d,0xfc,0x8a,0x00,0xff,0xfb,0x88,0x00,0xf2,0xfb,0x86,0x00,0xe5,0xfb,0x84,0x00,0xd7,0xfb,0x82,0x00,0xca,0xfb,0x80,0x00,0xbc,0xfb,0x7e,0x00,0xaf,0xfb,0x7c,0x00,0xa1,0xfb,0x7a,0x00,0x94,0xfb,  \
    0x77,0x00,0x86,0xfb,0x75,0x00,0x78,0xfb,0x73,0x00,0x6a,0xfb,0x71,0x00,0x5c,0xfb,0x6f,0x00,0x4e,0xfb,0x6d,0x00,0x40,0xfb,0x6a,0x00,0x32,0xfb,0x68,0x00,0x24,0xfb,0x66,0x00,0x16,0xfb,0x64,0x00,0x08,0xfb,0x61,0x00,0xfa,0xfa,0x5f,0x00,0xeb,0xfa,0x5d,0x00,0xdd,0xfa,0x5a,0x00,0xce,0xfa,0x58,0x00,0xc0,0xfa,0x56,0x00,0xb1,0xfa,0x53,0x00,0xa2,0xfa,0x51,0x00,0x94,0xfa,0x4f,0x00,0x85,0xfa,0x4c,0x00,0x76,0xfa,0x4a,0x00,0x67,0xfa,0x47,0x00,0x58,0xfa,0x45,0x00,  \
    0x49,0xfa,0x42,0x00,0x3a,0xfa,0x40,0x00,0x2b,0xfa,0x3d,0x00,0x1c,0xfa,0x3b,0x00,0x0c,0xfa,0x38,0x00,0xfd,0xf9,0x35,0x00,0xed,0xf9,0x33,0x00,0xde,0xf9,0x30,0x00,0xce,0xf9,0x2e,0x00,0xbe,0xf9,0x2b,0x00,0xaf,0xf9,0x28,0x00,0x9f,0xf9,0x26,0x00,0x8f,0xf9,0x23,0x00,0x7f,0xf9,0x20,0x00,0x6f,0xf9,0x1e,0x00,0x5f,0xf9,0x1b,0x00,0x4e,0xf9,0x18,0x00,0x3e,0xf9,0x15,0x00,0x2e,0xf9,0x13,0x00,0x1d,0xf9,0x10,0x00,0x0d,0xf9,0x0d,0x00,0xfc,0xf8,0x0a,0x00,0xeb,0xf8,  \
    0x08,0x00,0xda,0xf8,0x05,0x00,0xc9,0xf8,0x02,0x00,0xb8,0xf8,0xff,0xff,0xa7,0xf8,0xfc,0xff,0x96,0xf8,0xf9,0xff,0x85,0xf8,0xf7,0xff,0x74,0xf8,0xf4,0xff,0x62,0xf8,0xf1,0xff,0x51,0xf8,0xee,0xff,0x3f,0xf8,0xeb,0xff,0x2d,0xf8,0xe8,0xff,0x1c,0xf8,0xe5,0xff,0x0a,0xf8,0xe2,0xff,0xf8,0xf7,0xe0,0xff,0xe6,0xf7,0xdd,0xff,0xd4,0xf7,0xda,0xff,0xc1,0xf7,0xd7,0xff,0xaf,0xf7,0xd4,0xff,0x9d,0xf7,0xd1,0xff,0x8a,0xf7,0xce,0xff,0x77,0xf7,0xcb,0xff,0x65,0xf7,0xc8,0xff,  \
    0x52,0xf7,0xc5,0xff,0x3f,0xf7,0xc2,0xff,0x2c,0xf7,0xbf,0xff,0x19,0xf7,0xbd,0xff,0x06,0xf7,0xba,0xff,0xf2,0xf6,0xb7,0xff,0xdf,0xf6,0xb4,0xff,0xcb,0xf6,0xb1,0xff,0xb8,0xf6,0xae,0xff,0xa4,0xf6,0xab,0xff,0x90,0xf6,0xa8,0xff,0x7c,0xf6,0xa5,0xff,0x68,0xf6,0xa2,0xff,0x54,0xf6,0x9f,0xff,0x40,0xf6,0x9c,0xff,0x2b,0xf6,0x9a,0xff,0x17,0xf6,0x97,0xff,0x02,0xf6,0x94,0xff,0xed,0xf5,0x91,0xff,0xd9,0xf5,0x8e,0xff,0xc4,0xf5,0x8b,0xff,0xaf,0xf5,0x88,0xff,0x99,0xf5,  \
    0x86,0xff,0x84,0xf5,0x83,0xff,0x6f,0xf5,0x80,0xff,0x59,0xf5,0x7d,0xff,0x44,0xf5,0x7a,0xff,0x2e,0xf5,0x77,0xff,0x18,0xf5,0x75,0xff,0x02,0xf5,0x72,0xff,0xec,0xf4,0x6f,0xff,0xd6,0xf4,0x6c,0xff,0xc0,0xf4,0x6a,0xff,0xa9,0xf4,0x67,0xff,0x93,0xf4,0x64,0xff,0x7c,0xf4,0x62,0xff,0x66,0xf4,0x5f,0xff,0x4f,0xf4,0x5c,0xff,0x38,0xf4,0x5a,0xff,0x21,0xf4,0x57,0xff,0x0a,0xf4,0x55,0xff,0xf2,0xf3,0x52,0xff,0xdb,0xf3,0x4f,0xff,0xc3,0xf3,0x4d,0xff,0xac,0xf3,0x4a,0xff,  \
    0x94,0xf3,0x48,0xff,0x7c,0xf3,0x45,0xff,0x64,0xf3,0x43,0xff,0x4c,0xf3,0x41,0xff,0x34,0xf3,0x3e,0xff,0x1b,0xf3,0x3c,0xff,0x03,0xf3,0x39,0xff,0xea,0xf2,0x37,0xff,0xd1,0xf2,0x35,0xff,0xb8,0xf2,0x33,0xff,0x9f,0xf2,0x30,0xff,0x86,0xf2,0x2e,0xff,0x6d,0xf2,0x2c,0xff,0x53,0xf2,0x2a,0xff,0x3a,0xf2,0x28,0xff,0x20,0xf2,0x26,0xff,0x06,0xf2,0x24,0xff,0xec,0xf1,0x22,0xff,0xd2,0xf1,0x20,0xff,0xb8,0xf1,0x1e,0xff,0x9e,0xf1,0x1c,0xff,0x83,0xf1,0x1a,0xff,0x69,0xf1,  \
    0x18,0xff,0x4e,0xf1,0x17,0xff,0x33,0xf1,0x15,0xff,0x18,0xf1,0x13,0xff,0xfd,0xf0,0x11,0xff,0xe2,0xf0,0x10,0xff,0xc7,0xf0,0x0e,0xff,0xab,0xf0,0x0d,0xff,0x90,0xf0,0x0b,0xff,0x74,0xf0,0x0a,0xff,0x58,0xf0,0x08,0xff,0x3c,0xf0,0x07,0xff,0x20,0xf0,0x05,0xff,0x04,0xf0,0x04,0xff,0xe7,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcb,0xfe,0x25,0x10,0xcd,0xfe,0x08,0x10,0xce,0xfe,0xec,0x0f,0xd0,0xfe,0xd0,0x0f,0xd1,0xfe,0xb3,0x0f,0xd3,0xfe,0x97,0x0f,0xd5,0xfe,0x7b,0x0f,0xd6,0xfe,0x5f,0x0f,0xd8,0xfe,0x44,0x0f,0xda,0xfe,0x28,0x0f,0xdc,0xfe,0x0d,0x0f,0xde,0xfe,0xf1,0x0e,0xe0,0xfe,0xd6,0x0e,0xe2,0xfe,0xbb,0x0e,0xe4,0xfe,0xa0,0x0e,0xe6,0xfe,0x85,0x0e,  \
    0xe8,0xfe,0x6b,0x0e,0xea,0xfe,0x50,0x0e,0xec,0xfe,0x35,0x0e,0xee,0xfe,0x1b,0x0e,0xf1,0xfe,0x01,0x0e,0xf3,0xfe,0xe7,0x0d,0xf5,0xfe,0xcd,0x0d,0xf8,0xfe,0xb3,0x0d,0xfa,0xfe,0x99,0x0d,0xfc,0xfe,0x7f,0x0d,0xff,0xfe,0x66,0x0d,0x01,0xff,0x4c,0x0d,0x04,0xff,0x33,0x0d,0x06,0xff,0x1a,0x0d,0x09,0xff,0x01,0x0d,0x0c,0xff,0xe8,0x0c,0x0e,0xff,0xcf,0x0c,0x11,0xff,0xb6,0x0c,0x14,0xff,0x9e,0x0c,0x16,0xff,0x85,0x0c,0x19,0xff,0x6d,0x0c,0x1c,0xff,0x54,0x0c,0x1e,0xff,  \
    0x3c,0x0c,0x21,0xff,0x24,0x0c,0x24,0xff,0x0d,0x0c,0x27,0xff,0xf5,0x0b,0x2a,0xff,0xdd,0x0b,0x2d,0xff,0xc6,0x0b,0x30,0xff,0xaf,0x0b,0x33,0xff,0x98,0x0b,0x36,0xff,0x81,0x0b,0x39,0xff,0x6a,0x0b,0x3c,0xff,0x53,0x0b,0x3f,0xff,0x3d,0x0b,0x42,0xff,0x26,0x0b,0x45,0xff,0x10,0x0b,0x48,0xff,0xf9,0x0a,0x4c,0xff,0xe3,0x0a,0x4f,0xff,0xcd,0x0a,0x52,0xff,0xb7,0x0a,0x55,0xff,0xa1,0x0a,0x58,0xff,0x8c,0x0a,0x5b,0xff,0x76,0x0a,0x5e,0xff,0x60,0x0a,0x62,0xff,0x4b,0x0a,  \
    0x65,0xff,0x35,0x0a,0x68,0xff,0x20,0x0a,0x6b,0xff,0x0a,0x0a,0x6e,0xff,0xf5,0x09,0x71,0xff,0xe0,0x09,0x75,0xff,0xcb,0x09,0x78,0xff,0xb6,0x09,0x7b,0xff,0xa1,0x09,0x7e,0xff,0x8d,0x09,0x81,0xff,0x78,0x09,0x85,0xff,0x64,0x09,0x88,0xff,0x4f,0x09,0x8b,0xff,0x3b,0x09,0x8e,0xff,0x27,0x09,0x91,0xff,0x13,0x09,0x95,0xff,0xff,0x08,0x98,0xff,0xeb,0x08,0x9b,0xff,0xd7,0x08,0x9e,0xff,0xc4,0x08,0xa2,0xff,0xb0,0x08,0xa5,0xff,0x9d,0x08,0xa8,0xff,0x89,0x08,0xab,0xff,  \
    0x76,0x08,0xae,0xff,0x63,0x08,0xb2,0xff,0x50,0x08,0xb5,0xff,0x3d,0x08,0xb8,0xff,0x2a,0x08,0xbb,0xff,0x17,0x08,0xbe,0xff,0x04,0x08,0xc2,0xff,0xf2,0x07,0xc5,0xff,0xdf,0x07,0xc8,0xff,0xcd,0x07,0xcb,0xff,0xba,0x07,0xce,0xff,0xa8,0x07,0xd2,0xff,0x96,0x07,0xd5,0xff,0x84,0x07,0xd8,0xff,0x72,0x07,0xdb,0xff,0x61,0x07,0xde,0xff,0x4f,0x07,0xe1,0xff,0x3d,0x07,0xe4,0xff,0x2c,0x07,0xe8,0xff,0x1a,0x07,0xeb,0xff,0x09,0x07,0xee,0xff,0xf8,0x06,0xf1,0xff,0xe6,0x06,  \
    0xf4,0xff,0xd5,0x06,0xf7,0xff,0xc4,0x06,0xfa,0xff,0xb3,0x06,0xfd,0xff,0xa3,0x06,0x00,0x00,0x92,0x06,0x03,0x00,0x81,0x06,0x06,0x00,0x71,0x06,0x09,0x00,0x60,0x06,0x0c,0x00,0x50,0x06,0x0f,0x00,0x3f,0x06,0x12,0x00,0x2f,0x06,0x15,0x00,0x1f,0x06,0x18,0x00,0x0e,0x06,0x1b,0x00,0xfe,0x05,0x1e,0x00,0xee,0x05,0x21,0x00,0xde,0x05,0x24,0x00,0xcf,0x05,0x26,0x00,0xbf,0x05,0x29,0x00,0xaf,0x05,0x2c,0x00,0x9f,0x05,0x2f,0x00,0x90,0x05,0x32,0x00,0x80,0x05,0x34,0x00,  \
    0x71,0x05,0x37,0x00,0x62,0x05,0x3a,0x00,0x52,0x05,0x3d,0x00,0x43,0x05,0x3f,0x00,0x34,0x05,0x42,0x00,0x25,0x05,0x45,0x00,0x16,0x05,0x47,0x00,0x07,0x05,0x4a,0x00,0xf8,0x04,0x4d,0x00,0xe9,0x04,0x4f,0x00,0xda,0x04,0x52,0x00,0xcb,0x04,0x54,0x00,0xbd,0x04,0x57,0x00,0xae,0x04,0x59,0x00,0x9f,0x04,0x5c,0x00,0x91,0x04,0x5e,0x00,0x82,0x04,0x61,0x00,0x74,0x04,0x63,0x00,0x65,0x04,0x65,0x00,0x57,0x04,0x68,0x00,0x49,0x04,0x6a,0x00,0x3b,0x04,0x6d,0x00,0x2c,0x04,  \
    0x6f,0x00,0x1e,0x04,0x71,0x00,0x10,0x04,0x73,0x00,0x02,0x04,0x76,0x00,0xf4,0x03,0x78,0x00,0xe6,0x03,0x7a,0x00,0xd9,0x03,0x7c,0x00,0xcb,0x03,0x7e,0x00,0xbd,0x03,0x81,0x00,0xb0,0x03,0x83,0x00,0xa2,0x03,0x85,0x00,0x94,0x03,0x87,0x00,0x87,0x03,0x89,0x00,0x7a,0x03,0x8b,0x00,0x6c,0x03,0x8d,0x00,0x5f,0x03,0x8f,0x00,0x52,0x03,0x91,0x00,0x45,0x03,0x93,0x00,0x38,0x03,0x95,0x00,0x2b,0x03,0x97,0x00,0x1e,0x03,0x99,0x00,0x11,0x03,0x9b,0x00,0x04,0x03,0x9c,0x00,  \
    0xf7,0x02,0x9e,0x00,0xea,0x02,0xa0,0x00,0xdd,0x02,0xa2,0x00,0xd0,0x02,0xa4,0x00,0xc4,0x02,0xa5,0x00,0xb7,0x02,0xa7,0x00,0xaa,0x02,0xa9,0x00,0x9e,0x02,0xaa,0x00,0x91,0x02,0xac,0x00,0x85,0x02,0xad,0x00,0x78,0x02,0xaf,0x00,0x6c,0x02,0xb1,0x00,0x5f,0x02,0xb2,0x00,0x53,0x02,0xb4,0x00,0x47,0x02,0xb5,0x00,0x3a,0x02,0xb7,0x00,0x2e,0x02,0xb8,0x00,0x22,0x02,0xb9,0x00,0x16,0x02,0xbb,0x00,0x0a,0x02,0xbc,0x00,0xfe,0x01,0xbd,0x00,0xf1,0x01,0xbf,0x00,0xe5,0x01,  \
    0xc0,0x00,0xd9,0x01,0xc1,0x00,0xcd,0x01,0xc2,0x00,0xc1,0x01,0xc4,0x00,0xb6,0x01,0xc5,0x00,0xaa,0x01,0xc6,0x00,0x9e,0x01,0xc7,0x00,0x92,0x01,0xc8,0x00,0x86,0x01,0xc9,0x00,0x7a,0x01,0xca,0x00,0x6e,0x01,0xcb,0x00,0x63,0x01,0xcc,0x00,0x57,0x01,0xcd,0x00,0x4b,0x01,0xce,0x00,0x40,0x01,0xcf,0x00,0x34,0x01,0xd0,0x00,0x28,0x01,0xd1,0x00,0x1d,0x01,0xd1,0x00,0x11,0x01,0xd2,0x00,0x05,0x01,0xd3,0x00,0xfa,0x00,0xd4,0x00,0xee,0x00,0xd4,0x00,0xe3,0x00,0xd5,0x00,  \
    0xd7,0x00,0xd6,0x00,0xcc,0x00,0xd6,0x00,0xc0,0x00,0xd7,0x00,0xb5,0x00,0xd7,0x00,0xa9,0x00,0xd8,0x00,0x9e,0x00,0xd9,0x00,0x92,0x00,0xd9,0x00,0x87,0x00,0xd9,0x00,0x7b,0x00,0xda,0x00,0x70,0x00,0xda,0x00,0x65,0x00,0xdb,0x00,0x59,0x00,0xdb,0x00,0x4e,0x00,0xdb,0x00,0x42,0x00,0xdc,0x00,0x37,0x00,0xdc,0x00,0x2c,0x00,0xdc,0x00,0x20,0x00,0xdc,0x00,0x15,0x00,0xdd,0x00,0x0a,0x00,0xdd,0x00,0xfe,0xff,0xdd,0x00,0xf3,0xff,0xdd,0x00,0xe8,0xff,0xdd,0x00,0xdc,0xff,  \
    0xdd,0x00,0xd1,0xff,0xdd,0x00,0xc6,0xff,0xdd,0x00,0xba,0xff,0xdd,0x00,0xaf,0xff,0xdd,0x00,0xa4,0xff,0xdd,0x00,0x98,0xff,0xdd,0x00,0x8d,0xff,0xdd,0x00,0x82,0xff,0xdd,0x00,0x76,0xff,0xdc,0x00,0x6b,0xff,0xdc,0x00,0x5f,0xff,0xdc,0x00,0x54,0xff,0xdc,0x00,0x49,0xff,0xdb,0x00,0x3d,0xff,0xdb,0x00,0x32,0xff,0xdb,0x00,0x26,0xff,0xda,0x00,0x1b,0xff,0xda,0x00,0x10,0xff,0xda,0x00,0x04,0xff,0xd9,0x00,0xf9,0xfe,0xd9,0x00,0xed,0xfe,0xd8,0x00,0xe2,0xfe,0xd8,0x00,  \
    0xd6,0xfe,0xd7,0x00,0xcb,0xfe,0xd7,0x00,0xbf,0xfe,0xd6,0x00,0xb4,0xfe,0xd5,0x00,0xa8,0xfe,0xd5,0x00,0x9d,0xfe,0xd4,0x00,0x91,0xfe,0xd3,0x00,0x85,0xfe,0xd3,0x00,0x7a,0xfe,0xd2,0x00,0x6e,0xfe,0xd1,0x00,0x63,0xfe,0xd0,0x00,0x57,0xfe,0xcf,0x00,0x4c,0xfe,0xcf,0x00,0x40,0xfe,0xce,0x00,0x35,0xfe,0xcd,0x00,0x29,0xfe,0xcc,0x00,0x1e,0xfe,0xcb,0x00,0x12,0xfe,0xca,0x00,0x06,0xfe,0xc9,0x00,0xfb,0xfd,0xc8,0x00,0xef,0xfd,0xc7,0x00,0xe3,0xfd,0xc6,0x00,0xd8,0xfd,  \
    0xc5,0x00,0xcc,0xfd,0xc3,0x00,0xc0,0xfd,0xc2,0x00,0xb4,0xfd,0xc1,0x00,0xa9,0xfd,0xc0,0x00,0x9d,0xfd,0xbf,0x00,0x91,0xfd,0xbd,0x00,0x85,0xfd,0xbc,0x00,0x79,0xfd,0xbb,0x00,0x6d,0xfd,0xb9,0x00,0x61,0xfd,0xb8,0x00,0x55,0xfd,0xb7,0x00,0x49,0xfd,0xb5,0x00,0x3d,0xfd,0xb4,0x00,0x31,0xfd,0xb2,0x00,0x24,0xfd,0xb1,0x00,0x18,0xfd,0xaf,0x00,0x0b,0xfd,0xae,0x00,0xff,0xfc,0xac,0x00,0xf2,0xfc,0xab,0x00,0xe6,0xfc,0xa9,0x00,0xd9,0xfc,0xa8,0x00,0xcd,0xfc,0xa6,0x00,  \
    0xc0,0xfc,0xa4,0x00,0xb3,0xfc,0xa3,0x00,0xa6,0xfc,0xa1,0x00,0x9a,0xfc,0x9f,0x00,0x8d,0xfc,0x9e,0x00,0x80,0xfc,0x9c,0x00,0x73,0xfc,0x9a,0x00,0x66,0xfc,0x98,0x00,0x59,0xfc,0x96,0x00,0x4c,0xfc,0x95,0x00,0x3f,0xfc,0x93,0x00,0x31,0xfc,0x91,0x00,0x24,0xfc,0x8f,0x00,0x17,0xfc,0x8d,0x00,0x0a,0xfc,0x8b,0x00,0xfc,0xfb,0x89,0x00,0xef,0xfb,0x87,0x00,0xe1,0xfb,0x85,0x00,0xd4,0xfb,0x83,0x00,0xc6,0xfb,0x81,0x00,0xb9,0xfb,0x7f,0x00,0xab,0xfb,0x7d,0x00,0x9e,0xfb,  \
    0x7b,0x00,0x90,0xfb,0x78,0x00,0x82,0xfb,0x76,0x00,0x75,0xfb,0x74,0x00,0x67,0xfb,0x72,0x00,0x59,0xfb,0x70,0x00,0x4b,0xfb,0x6d,0x00,0x3d,0xfb,0x6b,0x00,0x2f,0xfb,0x69,0x00,0x21,0xfb,0x66,0x00,0x12,0xfb,0x64,0x00,0x04,0xfb,0x62,0x00,0xf6,0xfa,0x5f,0x00,0xe7,0xfa,0x5d,0x00,0xd9,0xfa,0x5b,0x00,0xca,0xfa,0x58,0x00,0xbc,0xfa,0x56,0x00,0xad,0xfa,0x53,0x00,0x9f,0xfa,0x51,0x00,0x90,0xfa,0x4e,0x00,0x81,0xfa,0x4c,0x00,0x72,0xfa,0x49,0x00,0x63,0xfa,0x47,0x00,  \
    0x54,0xfa,0x44,0x00,0x45,0xfa,0x42,0x00,0x36,0xfa,0x3f,0x00,0x27,0xfa,0x3c,0x00,0x18,0xfa,0x3a,0x00,0x08,0xfa,0x37,0x00,0xf9,0xf9,0x35,0x00,0xe9,0xf9,0x32,0x00,0xda,0xf9,0x2f,0x00,0xca,0xf9,0x2d,0x00,0xba,0xf9,0x2a,0x00,0xab,0xf9,0x27,0x00,0x9b,0xf9,0x24,0x00,0x8b,0xf9,0x22,0x00,0x7b,0xf9,0x1f,0x00,0x6b,0xf9,0x1c,0x00,0x5a,0xf9,0x19,0x00,0x4a,0xf9,0x16,0x00,0x3a,0xf9,0x14,0x00,0x29,0xf9,0x11,0x00,0x19,0xf9,0x0e,0x00,0x08,0xf9,0x0b,0x00,0xf8,0xf8,  \
    0x08,0x00,0xe7,0xf8,0x05,0x00,0xd6,0xf8,0x03,0x00,0xc5,0xf8,0x00,0x00,0xb4,0xf8,0xfd,0xff,0xa3,0xf8,0xfa,0xff,0x92,0xf8,0xf7,0xff,0x81,0xf8,0xf4,0xff,0x70,0xf8,0xf1,0xff,0x5e,0xf8,0xee,0xff,0x4d,0xf8,0xeb,0xff,0x3b,0xf8,0xe8,0xff,0x29,0xf8,0xe5,0xff,0x18,0xf8,0xe2,0xff,0x06,0xf8,0xdf,0xff,0xf4,0xf7,0xdc,0xff,0xe2,0xf7,0xd9,0xff,0xcf,0xf7,0xd6,0xff,0xbd,0xf7,0xd4,0xff,0xab,0xf7,0xd1,0xff,0x98,0xf7,0xce,0xff,0x86,0xf7,0xcb,0xff,0x73,0xf7,0xc8,0xff,  \
    0x61,0xf7,0xc5,0xff,0x4e,0xf7,0xc2,0xff,0x3b,0xf7,0xbf,0xff,0x28,0xf7,0xbb,0xff,0x15,0xf7,0xb8,0xff,0x02,0xf7,0xb5,0xff,0xee,0xf6,0xb2,0xff,0xdb,0xf6,0xaf,0xff,0xc7,0xf6,0xac,0xff,0xb4,0xf6,0xa9,0xff,0xa0,0xf6,0xa6,0xff,0x8c,0xf6,0xa3,0xff,0x78,0xf6,0xa0,0xff,0x64,0xf6,0x9d,0xff,0x50,0xf6,0x9a,0xff,0x3c,0xf6,0x98,0xff,0x27,0xf6,0x95,0xff,0x13,0xf6,0x92,0xff,0xfe,0xf5,0x8f,0xff,0xea,0xf5,0x8c,0xff,0xd5,0xf5,0x89,0xff,0xc0,0xf5,0x86,0xff,0xab,0xf5,  \
    0x83,0xff,0x96,0xf5,0x80,0xff,0x80,0xf5,0x7d,0xff,0x6b,0xf5,0x7a,0xff,0x56,0xf5,0x77,0xff,0x40,0xf5,0x74,0xff,0x2a,0xf5,0x72,0xff,0x14,0xf5,0x6f,0xff,0xfe,0xf4,0x6c,0xff,0xe8,0xf4,0x69,0xff,0xd2,0xf4,0x66,0xff,0xbc,0xf4,0x63,0xff,0xa6,0xf4,0x61,0xff,0x8f,0xf4,0x5e,0xff,0x79,0xf4,0x5b,0xff,0x62,0xf4,0x58,0xff,0x4b,0xf4,0x56,0xff,0x34,0xf4,0x53,0xff,0x1d,0xf4,0x50,0xff,0x06,0xf4,0x4e,0xff,0xef,0xf3,0x4b,0xff,0xd7,0xf3,0x48,0xff,0xc0,0xf3,0x46,0xff,  \
    0xa8,0xf3,0x43,0xff,0x90,0xf3,0x41,0xff,0x78,0xf3,0x3e,0xff,0x60,0xf3,0x3c,0xff,0x48,0xf3,0x39,0xff,0x30,0xf3,0x37,0xff,0x18,0xf3,0x34,0xff,0xff,0xf2,0x32,0xff,0xe6,0xf2,0x2f,0xff,0xce,0xf2,0x2d,0xff,0xb5,0xf2,0x2b,0xff,0x9c,0xf2,0x29,0xff,0x83,0xf2,0x26,0xff,0x69,0xf2,0x24,0xff,0x50,0xf2,0x22,0xff,0x36,0xf2,0x20,0xff,0x1d,0xf2,0x1e,0xff,0x03,0xf2,0x1c,0xff,0xe9,0xf1,0x1a,0xff,0xcf,0xf1,0x17,0xff,0xb5,0xf1,0x16,0xff,0x9a,0xf1,0x14,0xff,0x80,0xf1,  \
    0x12,0xff,0x65,0xf1,0x10,0xff,0x4b,0xf1,0x0e,0xff,0x30,0xf1,0x0c,0xff,0x15,0xf1,0x0a,0xff,0xfa,0xf0,0x09,0xff,0xdf,0xf0,0x07,0xff,0xc3,0xf0,0x05,0xff,0xa8,0xf0,0x04,0xff,0x8c,0xf0,0x02,0xff,0x71,0xf0,0x01,0xff,0x55,0xf0,0xff,0xfe,0x39,0xf0,0xfe,0xfe,0x1d,0xf0,0xfc,0xfe,0x01,0xf0,0xfb,0xfe,0xe4,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xbf,0xfe,0x27,0x10,0xc1,0xfe,0x0b,0x10,0xc3,0xfe,0xee,0x0f,0xc4,0xfe,0xd2,0x0f,0xc6,0xfe,0xb6,0x0f,0xc7,0xfe,0x9a,0x0f,0xc9,0xfe,0x7e,0x0f,0xcb,0xfe,0x62,0x0f,0xcd,0xfe,0x46,0x0f,0xcf,0xfe,0x2b,0x0f,0xd1,0xfe,0x0f,0x0f,0xd3,0xfe,0xf4,0x0e,0xd5,0xfe,0xd9,0x0e,0xd7,0xfe,0xbe,0x0e,0xd9,0xfe,0xa3,0x0e,  \
    0xdb,0xfe,0x88,0x0e,0xdd,0xfe,0x6d,0x0e,0xdf,0xfe,0x53,0x0e,0xe1,0xfe,0x38,0x0e,0xe4,0xfe,0x1e,0x0e,0xe6,0xfe,0x04,0x0e,0xe8,0xfe,0xea,0x0d,0xeb,0xfe,0xd0,0x0d,0xed,0xfe,0xb6,0x0d,0xf0,0xfe,0x9c,0x0d,0xf2,0xfe,0x82,0x0d,0xf5,0xfe,0x69,0x0d,0xf7,0xfe,0x4f,0x0d,0xfa,0xfe,0x36,0x0d,0xfc,0xfe,0x1d,0x0d,0xff,0xfe,0x04,0x0d,0x02,0xff,0xeb,0x0c,0x04,0xff,0xd2,0x0c,0x07,0xff,0xb9,0x0c,0x0a,0xff,0xa1,0x0c,0x0d,0xff,0x88,0x0c,0x0f,0xff,0x70,0x0c,0x12,0xff,  \
    0x57,0x0c,0x15,0xff,0x3f,0x0c,0x18,0xff,0x27,0x0c,0x1b,0xff,0x10,0x0c,0x1e,0xff,0xf8,0x0b,0x21,0xff,0xe1,0x0b,0x24,0xff,0xc9,0x0b,0x27,0xff,0xb2,0x0b,0x2a,0xff,0x9b,0x0b,0x2d,0xff,0x84,0x0b,0x30,0xff,0x6d,0x0b,0x34,0xff,0x56,0x0b,0x37,0xff,0x40,0x0b,0x3a,0xff,0x29,0x0b,0x3d,0xff,0x13,0x0b,0x40,0xff,0xfd,0x0a,0x44,0xff,0xe7,0x0a,0x47,0xff,0xd1,0x0a,0x4a,0xff,0xbb,0x0a,0x4d,0xff,0xa5,0x0a,0x51,0xff,0x8f,0x0a,0x54,0xff,0x79,0x0a,0x57,0xff,0x64,0x0a,  \
    0x5a,0xff,0x4e,0x0a,0x5e,0xff,0x39,0x0a,0x61,0xff,0x23,0x0a,0x64,0xff,0x0e,0x0a,0x67,0xff,0xf9,0x09,0x6b,0xff,0xe4,0x09,0x6e,0xff,0xcf,0x09,0x71,0xff,0xba,0x09,0x74,0xff,0xa5,0x09,0x78,0xff,0x90,0x09,0x7b,0xff,0x7c,0x09,0x7e,0xff,0x67,0x09,0x82,0xff,0x53,0x09,0x85,0xff,0x3f,0x09,0x88,0xff,0x2b,0x09,0x8c,0xff,0x17,0x09,0x8f,0xff,0x03,0x09,0x92,0xff,0xef,0x08,0x96,0xff,0xdb,0x08,0x99,0xff,0xc7,0x08,0x9c,0xff,0xb4,0x08,0x9f,0xff,0xa0,0x08,0xa3,0xff,  \
    0x8d,0x08,0xa6,0xff,0x7a,0x08,0xa9,0xff,0x67,0x08,0xad,0xff,0x53,0x08,0xb0,0xff,0x41,0x08,0xb3,0xff,0x2e,0x08,0xb7,0xff,0x1b,0x08,0xba,0xff,0x08,0x08,0xbd,0xff,0xf6,0x07,0xc0,0xff,0xe3,0x07,0xc4,0xff,0xd1,0x07,0xc7,0xff,0xbe,0x07,0xca,0xff,0xac,0x07,0xce,0xff,0x9a,0x07,0xd1,0xff,0x88,0x07,0xd4,0xff,0x76,0x07,0xd7,0xff,0x65,0x07,0xdb,0xff,0x53,0x07,0xde,0xff,0x41,0x07,0xe1,0xff,0x30,0x07,0xe4,0xff,0x1e,0x07,0xe7,0xff,0x0d,0x07,0xeb,0xff,0xfc,0x06,  \
    0xee,0xff,0xeb,0x06,0xf1,0xff,0xd9,0x06,0xf4,0xff,0xc8,0x06,0xf7,0xff,0xb7,0x06,0xfa,0xff,0xa7,0x06,0xfe,0xff,0x96,0x06,0x01,0x00,0x85,0x06,0x04,0x00,0x75,0x06,0x07,0x00,0x64,0x06,0x0a,0x00,0x54,0x06,0x0d,0x00,0x43,0x06,0x10,0x00,0x33,0x06,0x13,0x00,0x23,0x06,0x16,0x00,0x13,0x06,0x19,0x00,0x02,0x06,0x1c,0x00,0xf2,0x05,0x1f,0x00,0xe2,0x05,0x22,0x00,0xd3,0x05,0x25,0x00,0xc3,0x05,0x28,0x00,0xb3,0x05,0x2b,0x00,0xa3,0x05,0x2e,0x00,0x94,0x05,0x30,0x00,  \
    0x84,0x05,0x33,0x00,0x75,0x05,0x36,0x00,0x66,0x05,0x39,0x00,0x56,0x05,0x3c,0x00,0x47,0x05,0x3e,0x00,0x38,0x05,0x41,0x00,0x29,0x05,0x44,0x00,0x1a,0x05,0x47,0x00,0x0b,0x05,0x49,0x00,0xfc,0x04,0x4c,0x00,0xed,0x04,0x4f,0x00,0xde,0x04,0x51,0x00,0xcf,0x04,0x54,0x00,0xc0,0x04,0x56,0x00,0xb2,0x04,0x59,0x00,0xa3,0x04,0x5c,0x00,0x94,0x04,0x5e,0x00,0x86,0x04,0x61,0x00,0x77,0x04,0x63,0x00,0x69,0x04,0x66,0x00,0x5b,0x04,0x68,0x00,0x4c,0x04,0x6a,0x00,0x3e,0x04,  \
    0x6d,0x00,0x30,0x04,0x6f,0x00,0x22,0x04,0x72,0x00,0x14,0x04,0x74,0x00,0x06,0x04,0x76,0x00,0xf8,0x03,0x78,0x00,0xea,0x03,0x7b,0x00,0xdc,0x03,0x7d,0x00,0xce,0x03,0x7f,0x00,0xc1,0x03,0x81,0x00,0xb3,0x03,0x84,0x00,0xa5,0x03,0x86,0x00,0x98,0x03,0x88,0x00,0x8a,0x03,0x8a,0x00,0x7d,0x03,0x8c,0x00,0x70,0x03,0x8e,0x00,0x62,0x03,0x90,0x00,0x55,0x03,0x92,0x00,0x48,0x03,0x94,0x00,0x3b,0x03,0x96,0x00,0x2e,0x03,0x98,0x00,0x21,0x03,0x9a,0x00,0x14,0x03,0x9c,0x00,  \
    0x07,0x03,0x9e,0x00,0xfa,0x02,0xa0,0x00,0xed,0x02,0xa2,0x00,0xe0,0x02,0xa3,0x00,0xd3,0x02,0xa5,0x00,0xc6,0x02,0xa7,0x00,0xba,0x02,0xa9,0x00,0xad,0x02,0xaa,0x00,0xa0,0x02,0xac,0x00,0x94,0x02,0xae,0x00,0x87,0x02,0xaf,0x00,0x7b,0x02,0xb1,0x00,0x6e,0x02,0xb3,0x00,0x62,0x02,0xb4,0x00,0x55,0x02,0xb6,0x00,0x49,0x02,0xb7,0x00,0x3d,0x02,0xb9,0x00,0x31,0x02,0xba,0x00,0x24,0x02,0xbc,0x00,0x18,0x02,0xbd,0x00,0x0c,0x02,0xbe,0x00,0x00,0x02,0xc0,0x00,0xf4,0x01,  \
    0xc1,0x00,0xe8,0x01,0xc2,0x00,0xdc,0x01,0xc4,0x00,0xd0,0x01,0xc5,0x00,0xc4,0x01,0xc6,0x00,0xb8,0x01,0xc7,0x00,0xac,0x01,0xc8,0x00,0xa0,0x01,0xca,0x00,0x94,0x01,0xcb,0x00,0x88,0x01,0xcc,0x00,0x7c,0x01,0xcd,0x00,0x70,0x01,0xce,0x00,0x64,0x01,0xcf,0x00,0x59,0x01,0xd0,0x00,0x4d,0x01,0xd1,0x00,0x41,0x01,0xd2,0x00,0x35,0x01,0xd3,0x00,0x2a,0x01,0xd3,0x00,0x1e,0x01,0xd4,0x00,0x12,0x01,0xd5,0x00,0x07,0x01,0xd6,0x00,0xfb,0x00,0xd7,0x00,0xf0,0x00,0xd7,0x00,  \
    0xe4,0x00,0xd8,0x00,0xd8,0x00,0xd9,0x00,0xcd,0x00,0xd9,0x00,0xc1,0x00,0xda,0x00,0xb6,0x00,0xdb,0x00,0xaa,0x00,0xdb,0x00,0x9f,0x00,0xdc,0x00,0x93,0x00,0xdc,0x00,0x88,0x00,0xdd,0x00,0x7c,0x00,0xdd,0x00,0x71,0x00,0xdd,0x00,0x65,0x00,0xde,0x00,0x5a,0x00,0xde,0x00,0x4e,0x00,0xdf,0x00,0x43,0x00,0xdf,0x00,0x37,0x00,0xdf,0x00,0x2c,0x00,0xdf,0x00,0x21,0x00,0xe0,0x00,0x15,0x00,0xe0,0x00,0x0a,0x00,0xe0,0x00,0xfe,0xff,0xe0,0x00,0xf3,0xff,0xe0,0x00,0xe8,0xff,  \
    0xe0,0x00,0xdc,0xff,0xe0,0x00,0xd1,0xff,0xe0,0x00,0xc6,0xff,0xe0,0x00,0xba,0xff,0xe0,0x00,0xaf,0xff,0xe0,0x00,0xa3,0xff,0xe0,0x00,0x98,0xff,0xe0,0x00,0x8d,0xff,0xe0,0x00,0x81,0xff,0xe0,0x00,0x76,0xff,0xe0,0x00,0x6a,0xff,0xdf,0x00,0x5f,0xff,0xdf,0x00,0x54,0xff,0xdf,0x00,0x48,0xff,0xdf,0x00,0x3d,0xff,0xde,0x00,0x31,0xff,0xde,0x00,0x26,0xff,0xde,0x00,0x1a,0xff,0xdd,0x00,0x0f,0xff,0xdd,0x00,0x03,0xff,0xdc,0x00,0xf8,0xfe,0xdc,0x00,0xec,0xfe,0xdb,0x00,  \
    0xe1,0xfe,0xdb,0x00,0xd5,0xfe,0xda,0x00,0xca,0xfe,0xda,0x00,0xbe,0xfe,0xd9,0x00,0xb2,0xfe,0xd8,0x00,0xa7,0xfe,0xd8,0x00,0x9b,0xfe,0xd7,0x00,0x90,0xfe,0xd6,0x00,0x84,0xfe,0xd6,0x00,0x78,0xfe,0xd5,0x00,0x6d,0xfe,0xd4,0x00,0x61,0xfe,0xd3,0x00,0x56,0xfe,0xd2,0x00,0x4a,0xfe,0xd1,0x00,0x3f,0xfe,0xd1,0x00,0x33,0xfe,0xd0,0x00,0x27,0xfe,0xcf,0x00,0x1c,0xfe,0xce,0x00,0x10,0xfe,0xcd,0x00,0x04,0xfe,0xcc,0x00,0xf9,0xfd,0xcb,0x00,0xed,0xfd,0xc9,0x00,0xe1,0xfd,  \
    0xc8,0x00,0xd6,0xfd,0xc7,0x00,0xca,0xfd,0xc6,0x00,0xbe,0xfd,0xc5,0x00,0xb2,0xfd,0xc4,0x00,0xa6,0xfd,0xc2,0x00,0x9b,0xfd,0xc1,0x00,0x8f,0xfd,0xc0,0x00,0x83,0xfd,0xbe,0x00,0x77,0xfd,0xbd,0x00,0x6b,0xfd,0xbc,0x00,0x5f,0xfd,0xba,0x00,0x53,0xfd,0xb9,0x00,0x47,0xfd,0xb8,0x00,0x3b,0xfd,0xb6,0x00,0x2e,0xfd,0xb5,0x00,0x22,0xfd,0xb3,0x00,0x15,0xfd,0xb2,0x00,0x09,0xfd,0xb0,0x00,0xfc,0xfc,0xae,0x00,0xf0,0xfc,0xad,0x00,0xe3,0xfc,0xab,0x00,0xd7,0xfc,0xaa,0x00,  \
    0xca,0xfc,0xa8,0x00,0xbd,0xfc,0xa6,0x00,0xb0,0xfc,0xa5,0x00,0xa4,0xfc,0xa3,0x00,0x97,0xfc,0xa1,0x00,0x8a,0xfc,0x9f,0x00,0x7d,0xfc,0x9d,0x00,0x70,0xfc,0x9c,0x00,0x63,0xfc,0x9a,0x00,0x56,0xfc,0x98,0x00,0x49,0xfc,0x96,0x00,0x3b,0xfc,0x94,0x00,0x2e,0xfc,0x92,0x00,0x21,0xfc,0x90,0x00,0x14,0xfc,0x8e,0x00,0x06,0xfc,0x8c,0x00,0xf9,0xfb,0x8a,0x00,0xeb,0xfb,0x88,0x00,0xde,0xfb,0x86,0x00,0xd0,0xfb,0x84,0x00,0xc3,0xfb,0x82,0x00,0xb5,0xfb,0x80,0x00,0xa8,0xfb,  \
    0x7e,0x00,0x9a,0xfb,0x7b,0x00,0x8c,0xfb,0x79,0x00,0x7f,0xfb,0x77,0x00,0x71,0xfb,0x75,0x00,0x63,0xfb,0x72,0x00,0x55,0xfb,0x70,0x00,0x47,0xfb,0x6e,0x00,0x39,0xfb,0x6c,0x00,0x2b,0xfb,0x69,0x00,0x1d,0xfb,0x67,0x00,0x0e,0xfb,0x64,0x00,0x00,0xfb,0x62,0x00,0xf2,0xfa,0x60,0x00,0xe3,0xfa,0x5d,0x00,0xd5,0xfa,0x5b,0x00,0xc6,0xfa,0x58,0x00,0xb8,0xfa,0x56,0x00,0xa9,0xfa,0x53,0x00,0x9a,0xfa,0x51,0x00,0x8c,0xfa,0x4e,0x00,0x7d,0xfa,0x4c,0x00,0x6e,0xfa,0x49,0x00,  \
    0x5f,0xfa,0x46,0x00,0x50,0xfa,0x44,0x00,0x41,0xfa,0x41,0x00,0x32,0xfa,0x3e,0x00,0x23,0xfa,0x3c,0x00,0x13,0xfa,0x39,0x00,0x04,0xfa,0x36,0x00,0xf5,0xf9,0x34,0x00,0xe5,0xf9,0x31,0x00,0xd6,0xf9,0x2e,0x00,0xc6,0xf9,0x2b,0x00,0xb6,0xf9,0x29,0x00,0xa6,0xf9,0x26,0x00,0x96,0xf9,0x23,0x00,0x87,0xf9,0x20,0x00,0x77,0xf9,0x1d,0x00,0x66,0xf9,0x1b,0x00,0x56,0xf9,0x18,0x00,0x46,0xf9,0x15,0x00,0x36,0xf9,0x12,0x00,0x25,0xf9,0x0f,0x00,0x15,0xf9,0x0c,0x00,0x04,0xf9,  \
    0x09,0x00,0xf4,0xf8,0x06,0x00,0xe3,0xf8,0x03,0x00,0xd2,0xf8,0x00,0x00,0xc1,0xf8,0xfe,0xff,0xb0,0xf8,0xfb,0xff,0x9f,0xf8,0xf8,0xff,0x8e,0xf8,0xf5,0xff,0x7d,0xf8,0xf2,0xff,0x6b,0xf8,0xef,0xff,0x5a,0xf8,0xec,0xff,0x48,0xf8,0xe9,0xff,0x37,0xf8,0xe6,0xff,0x25,0xf8,0xe2,0xff,0x13,0xf8,0xdf,0xff,0x01,0xf8,0xdc,0xff,0xef,0xf7,0xd9,0xff,0xdd,0xf7,0xd6,0xff,0xcb,0xf7,0xd3,0xff,0xb9,0xf7,0xd0,0xff,0xa7,0xf7,0xcd,0xff,0x94,0xf7,0xca,0xff,0x82,0xf7,0xc7,0xff,  \
    0x6f,0xf7,0xc4,0xff,0x5c,0xf7,0xc1,0xff,0x4a,0xf7,0xbe,0xff,0x37,0xf7,0xbb,0xff,0x24,0xf7,0xb8,0xff,0x11,0xf7,0xb4,0xff,0xfd,0xf6,0xb1,0xff,0xea,0xf6,0xae,0xff,0xd7,0xf6,0xab,0xff,0xc3,0xf6,0xa8,0xff,0xb0,0xf6,0xa5,0xff,0x9c,0xf6,0xa2,0xff,0x88,0xf6,0x9f,0xff,0x74,0xf6,0x9c,0xff,0x60,0xf6,0x99,0xff,0x4c,0xf6,0x96,0xff,0x38,0xf6,0x93,0xff,0x23,0xf6,0x90,0xff,0x0f,0xf6,0x8d,0xff,0xfa,0xf5,0x8a,0xff,0xe6,0xf5,0x87,0xff,0xd1,0xf5,0x84,0xff,0xbc,0xf5,  \
    0x80,0xff,0xa7,0xf5,0x7d,0xff,0x92,0xf5,0x7b,0xff,0x7c,0xf5,0x78,0xff,0x67,0xf5,0x75,0xff,0x52,0xf5,0x72,0xff,0x3c,0xf5,0x6f,0xff,0x26,0xf5,0x6c,0xff,0x10,0xf5,0x69,0xff,0xfb,0xf4,0x66,0xff,0xe5,0xf4,0x63,0xff,0xce,0xf4,0x60,0xff,0xb8,0xf4,0x5d,0xff,0xa2,0xf4,0x5a,0xff,0x8b,0xf4,0x58,0xff,0x75,0xf4,0x55,0xff,0x5e,0xf4,0x52,0xff,0x47,0xf4,0x4f,0xff,0x30,0xf4,0x4c,0xff,0x19,0xf4,0x4a,0xff,0x02,0xf4,0x47,0xff,0xeb,0xf3,0x44,0xff,0xd4,0xf3,0x41,0xff,  \
    0xbc,0xf3,0x3f,0xff,0xa4,0xf3,0x3c,0xff,0x8d,0xf3,0x3a,0xff,0x75,0xf3,0x37,0xff,0x5d,0xf3,0x34,0xff,0x45,0xf3,0x32,0xff,0x2c,0xf3,0x2f,0xff,0x14,0xf3,0x2d,0xff,0xfc,0xf2,0x2a,0xff,0xe3,0xf2,0x28,0xff,0xca,0xf2,0x26,0xff,0xb1,0xf2,0x23,0xff,0x98,0xf2,0x21,0xff,0x7f,0xf2,0x1e,0xff,0x66,0xf2,0x1c,0xff,0x4c,0xf2,0x1a,0xff,0x33,0xf2,0x18,0xff,0x19,0xf2,0x16,0xff,0xff,0xf1,0x13,0xff,0xe5,0xf1,0x11,0xff,0xcb,0xf1,0x0f,0xff,0xb1,0xf1,0x0d,0xff,0x97,0xf1,  \
    0x0b,0xff,0x7d,0xf1,0x09,0xff,0x62,0xf1,0x07,0xff,0x47,0xf1,0x06,0xff,0x2d,0xf1,0x04,0xff,0x12,0xf1,0x02,0xff,0xf7,0xf0,0x00,0xff,0xdb,0xf0,0xfe,0xfe,0xc0,0xf0,0xfd,0xfe,0xa5,0xf0,0xfb,0xfe,0x89,0xf0,0xf9,0xfe,0x6d,0xf0,0xf8,0xfe,0x52,0xf0,0xf6,0xfe,0x36,0xf0,0xf5,0xfe,0x1a,0xf0,0xf3,0xfe,0xfd,0xef,0xf2,0xfe,0xe1,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xb4,0xfe,0x2a,0x10,0xb5,0xfe,0x0e,0x10,0xb7,0xfe,0xf1,0x0f,0xb8,0xfe,0xd5,0x0f,0xba,0xfe,0xb9,0x0f,0xbc,0xfe,0x9d,0x0f,0xbe,0xfe,0x81,0x0f,0xbf,0xfe,0x65,0x0f,0xc1,0xfe,0x49,0x0f,0xc3,0xfe,0x2e,0x0f,0xc5,0xfe,0x12,0x0f,0xc7,0xfe,0xf7,0x0e,0xc9,0xfe,0xdc,0x0e,0xcb,0xfe,0xc1,0x0e,  \
    0xce,0xfe,0xa6,0x0e,0xd0,0xfe,0x8b,0x0e,0xd2,0xfe,0x70,0x0e,0xd4,0xfe,0x56,0x0e,0xd7,0xfe,0x3b,0x0e,0xd9,0xfe,0x21,0x0e,0xdb,0xfe,0x07,0x0e,0xde,0xfe,0xec,0x0d,0xe0,0xfe,0xd2,0x0d,0xe3,0xfe,0xb9,0x0d,0xe5,0xfe,0x9f,0x0d,0xe8,0xfe,0x85,0x0d,0xea,0xfe,0x6c,0x0d,0xed,0xfe,0x52,0x0d,0xf0,0xfe,0x39,0x0d,0xf2,0xfe,0x20,0x0d,0xf5,0xfe,0x07,0x0d,0xf8,0xfe,0xee,0x0c,0xfb,0xfe,0xd5,0x0c,0xfd,0xfe,0xbc,0x0c,0x00,0xff,0xa4,0x0c,0x03,0xff,0x8b,0x0c,0x06,0xff,  \
    0x73,0x0c,0x09,0xff,0x5b,0x0c,0x0c,0xff,0x42,0x0c,0x0f,0xff,0x2a,0x0c,0x12,0xff,0x13,0x0c,0x15,0xff,0xfb,0x0b,0x18,0xff,0xe4,0x0b,0x1b,0xff,0xcc,0x0b,0x1e,0xff,0xb5,0x0b,0x21,0xff,0x9e,0x0b,0x25,0xff,0x87,0x0b,0x28,0xff,0x71,0x0b,0x2b,0xff,0x5a,0x0b,0x2e,0xff,0x43,0x0b,0x32,0xff,0x2d,0x0b,0x35,0xff,0x16,0x0b,0x38,0xff,0x00,0x0b,0x3c,0xff,0xea,0x0a,0x3f,0xff,0xd4,0x0a,0x42,0xff,0xbe,0x0a,0x46,0xff,0xa9,0x0a,0x49,0xff,0x93,0x0a,0x4c,0xff,0x7d,0x0a,  \
    0x50,0xff,0x67,0x0a,0x53,0xff,0x52,0x0a,0x56,0xff,0x3c,0x0a,0x5a,0xff,0x27,0x0a,0x5d,0xff,0x12,0x0a,0x60,0xff,0xfc,0x09,0x64,0xff,0xe7,0x09,0x67,0xff,0xd2,0x09,0x6b,0xff,0xbe,0x09,0x6e,0xff,0xa9,0x09,0x71,0xff,0x94,0x09,0x75,0xff,0x80,0x09,0x78,0xff,0x6b,0x09,0x7b,0xff,0x57,0x09,0x7f,0xff,0x43,0x09,0x82,0xff,0x2e,0x09,0x86,0xff,0x1a,0x09,0x89,0xff,0x06,0x09,0x8d,0xff,0xf3,0x08,0x90,0xff,0xdf,0x08,0x93,0xff,0xcb,0x08,0x97,0xff,0xb8,0x08,0x9a,0xff,  \
    0xa4,0x08,0x9e,0xff,0x91,0x08,0xa1,0xff,0x7e,0x08,0xa4,0xff,0x6b,0x08,0xa8,0xff,0x57,0x08,0xab,0xff,0x45,0x08,0xaf,0xff,0x32,0x08,0xb2,0xff,0x1f,0x08,0xb5,0xff,0x0c,0x08,0xb9,0xff,0xfa,0x07,0xbc,0xff,0xe7,0x07,0xbf,0xff,0xd5,0x07,0xc3,0xff,0xc2,0x07,0xc6,0xff,0xb0,0x07,0xc9,0xff,0x9e,0x07,0xcd,0xff,0x8c,0x07,0xd0,0xff,0x7a,0x07,0xd4,0xff,0x69,0x07,0xd7,0xff,0x57,0x07,0xda,0xff,0x45,0x07,0xde,0xff,0x34,0x07,0xe1,0xff,0x22,0x07,0xe4,0xff,0x11,0x07,  \
    0xe7,0xff,0x00,0x07,0xeb,0xff,0xef,0x06,0xee,0xff,0xde,0x06,0xf1,0xff,0xcd,0x06,0xf4,0xff,0xbc,0x06,0xf8,0xff,0xab,0x06,0xfb,0xff,0x9a,0x06,0xfe,0xff,0x89,0x06,0x01,0x00,0x79,0x06,0x04,0x00,0x68,0x06,0x08,0x00,0x58,0x06,0x0b,0x00,0x47,0x06,0x0e,0x00,0x37,0x06,0x11,0x00,0x27,0x06,0x14,0x00,0x17,0x06,0x17,0x00,0x07,0x06,0x1a,0x00,0xf7,0x05,0x1d,0x00,0xe7,0x05,0x20,0x00,0xd7,0x05,0x23,0x00,0xc7,0x05,0x26,0x00,0xb7,0x05,0x29,0x00,0xa8,0x05,0x2c,0x00,  \
    0x98,0x05,0x2f,0x00,0x89,0x05,0x32,0x00,0x79,0x05,0x35,0x00,0x6a,0x05,0x38,0x00,0x5a,0x05,0x3b,0x00,0x4b,0x05,0x3d,0x00,0x3c,0x05,0x40,0x00,0x2d,0x05,0x43,0x00,0x1e,0x05,0x46,0x00,0x0f,0x05,0x49,0x00,0x00,0x05,0x4b,0x00,0xf1,0x04,0x4e,0x00,0xe2,0x04,0x51,0x00,0xd3,0x04,0x53,0x00,0xc4,0x04,0x56,0x00,0xb6,0x04,0x59,0x00,0xa7,0x04,0x5b,0x00,0x98,0x04,0x5e,0x00,0x8a,0x04,0x60,0x00,0x7b,0x04,0x63,0x00,0x6d,0x04,0x66,0x00,0x5e,0x04,0x68,0x00,0x50,0x04,  \
    0x6b,0x00,0x42,0x04,0x6d,0x00,0x34,0x04,0x6f,0x00,0x26,0x04,0x72,0x00,0x17,0x04,0x74,0x00,0x09,0x04,0x77,0x00,0xfb,0x03,0x79,0x00,0xed,0x03,0x7b,0x00,0xe0,0x03,0x7e,0x00,0xd2,0x03,0x80,0x00,0xc4,0x03,0x82,0x00,0xb6,0x03,0x84,0x00,0xa9,0x03,0x87,0x00,0x9b,0x03,0x89,0x00,0x8e,0x03,0x8b,0x00,0x80,0x03,0x8d,0x00,0x73,0x03,0x8f,0x00,0x66,0x03,0x91,0x00,0x58,0x03,0x93,0x00,0x4b,0x03,0x96,0x00,0x3e,0x03,0x98,0x00,0x31,0x03,0x9a,0x00,0x24,0x03,0x9c,0x00,  \
    0x17,0x03,0x9d,0x00,0x0a,0x03,0x9f,0x00,0xfd,0x02,0xa1,0x00,0xf0,0x02,0xa3,0x00,0xe3,0x02,0xa5,0x00,0xd6,0x02,0xa7,0x00,0xc9,0x02,0xa9,0x00,0xbd,0x02,0xaa,0x00,0xb0,0x02,0xac,0x00,0xa3,0x02,0xae,0x00,0x97,0x02,0xb0,0x00,0x8a,0x02,0xb1,0x00,0x7d,0x02,0xb3,0x00,0x71,0x02,0xb5,0x00,0x64,0x02,0xb6,0x00,0x58,0x02,0xb8,0x00,0x4c,0x02,0xb9,0x00,0x3f,0x02,0xbb,0x00,0x33,0x02,0xbc,0x00,0x27,0x02,0xbe,0x00,0x1a,0x02,0xbf,0x00,0x0e,0x02,0xc1,0x00,0x02,0x02,  \
    0xc2,0x00,0xf6,0x01,0xc3,0x00,0xea,0x01,0xc5,0x00,0xde,0x01,0xc6,0x00,0xd2,0x01,0xc7,0x00,0xc6,0x01,0xc9,0x00,0xba,0x01,0xca,0x00,0xae,0x01,0xcb,0x00,0xa2,0x01,0xcc,0x00,0x96,0x01,0xcd,0x00,0x8a,0x01,0xce,0x00,0x7e,0x01,0xcf,0x00,0x72,0x01,0xd1,0x00,0x66,0x01,0xd2,0x00,0x5a,0x01,0xd3,0x00,0x4f,0x01,0xd4,0x00,0x43,0x01,0xd4,0x00,0x37,0x01,0xd5,0x00,0x2b,0x01,0xd6,0x00,0x20,0x01,0xd7,0x00,0x14,0x01,0xd8,0x00,0x08,0x01,0xd9,0x00,0xfd,0x00,0xda,0x00,  \
    0xf1,0x00,0xda,0x00,0xe5,0x00,0xdb,0x00,0xda,0x00,0xdc,0x00,0xce,0x00,0xdc,0x00,0xc2,0x00,0xdd,0x00,0xb7,0x00,0xde,0x00,0xab,0x00,0xde,0x00,0xa0,0x00,0xdf,0x00,0x94,0x00,0xdf,0x00,0x89,0x00,0xe0,0x00,0x7d,0x00,0xe0,0x00,0x71,0x00,0xe1,0x00,0x66,0x00,0xe1,0x00,0x5a,0x00,0xe1,0x00,0x4f,0x00,0xe2,0x00,0x43,0x00,0xe2,0x00,0x38,0x00,0xe2,0x00,0x2d,0x00,0xe2,0x00,0x21,0x00,0xe3,0x00,0x16,0x00,0xe3,0x00,0x0a,0x00,0xe3,0x00,0xff,0xff,0xe3,0x00,0xf3,0xff,  \
    0xe3,0x00,0xe8,0xff,0xe3,0x00,0xdc,0xff,0xe3,0x00,0xd1,0xff,0xe3,0x00,0xc6,0xff,0xe3,0x00,0xba,0xff,0xe3,0x00,0xaf,0xff,0xe3,0x00,0xa3,0xff,0xe3,0x00,0x98,0xff,0xe3,0x00,0x8c,0xff,0xe3,0x00,0x81,0xff,0xe3,0x00,0x75,0xff,0xe3,0x00,0x6a,0xff,0xe2,0x00,0x5f,0xff,0xe2,0x00,0x53,0xff,0xe2,0x00,0x48,0xff,0xe2,0x00,0x3c,0xff,0xe1,0x00,0x31,0xff,0xe1,0x00,0x25,0xff,0xe1,0x00,0x1a,0xff,0xe0,0x00,0x0e,0xff,0xe0,0x00,0x02,0xff,0xdf,0x00,0xf7,0xfe,0xdf,0x00,  \
    0xeb,0xfe,0xde,0x00,0xe0,0xfe,0xde,0x00,0xd4,0xfe,0xdd,0x00,0xc8,0xfe,0xdd,0x00,0xbd,0xfe,0xdc,0x00,0xb1,0xfe,0xdb,0x00,0xa6,0xfe,0xdb,0x00,0x9a,0xfe,0xda,0x00,0x8e,0xfe,0xd9,0x00,0x83,0xfe,0xd8,0x00,0x77,0xfe,0xd8,0x00,0x6b,0xfe,0xd7,0x00,0x60,0xfe,0xd6,0x00,0x54,0xfe,0xd5,0x00,0x49,0xfe,0xd4,0x00,0x3d,0xfe,0xd3,0x00,0x31,0xfe,0xd2,0x00,0x26,0xfe,0xd1,0x00,0x1a,0xfe,0xd0,0x00,0x0e,0xfe,0xcf,0x00,0x03,0xfe,0xce,0x00,0xf7,0xfd,0xcd,0x00,0xeb,0xfd,  \
    0xcc,0x00,0xdf,0xfd,0xcb,0x00,0xd4,0xfd,0xca,0x00,0xc8,0xfd,0xc9,0x00,0xbc,0xfd,0xc7,0x00,0xb0,0xfd,0xc6,0x00,0xa4,0xfd,0xc5,0x00,0x98,0xfd,0xc3,0x00,0x8d,0xfd,0xc2,0x00,0x81,0xfd,0xc1,0x00,0x75,0xfd,0xbf,0x00,0x69,0xfd,0xbe,0x00,0x5d,0xfd,0xbd,0x00,0x51,0xfd,0xbb,0x00,0x45,0xfd,0xba,0x00,0x38,0xfd,0xb8,0x00,0x2c,0xfd,0xb7,0x00,0x1f,0xfd,0xb5,0x00,0x13,0xfd,0xb4,0x00,0x06,0xfd,0xb2,0x00,0xfa,0xfc,0xb0,0x00,0xed,0xfc,0xaf,0x00,0xe0,0xfc,0xad,0x00,  \
    0xd4,0xfc,0xab,0x00,0xc7,0xfc,0xaa,0x00,0xba,0xfc,0xa8,0x00,0xad,0xfc,0xa6,0x00,0xa1,0xfc,0xa4,0x00,0x94,0xfc,0xa3,0x00,0x87,0xfc,0xa1,0x00,0x7a,0xfc,0x9f,0x00,0x6d,0xfc,0x9d,0x00,0x60,0xfc,0x9b,0x00,0x52,0xfc,0x99,0x00,0x45,0xfc,0x97,0x00,0x38,0xfc,0x95,0x00,0x2b,0xfc,0x93,0x00,0x1d,0xfc,0x91,0x00,0x10,0xfc,0x8f,0x00,0x03,0xfc,0x8d,0x00,0xf5,0xfb,0x8b,0x00,0xe8,0xfb,0x89,0x00,0xda,0xfb,0x87,0x00,0xcd,0xfb,0x85,0x00,0xbf,0xfb,0x83,0x00,0xb2,0xfb,  \
    0x81,0x00,0xa4,0xfb,0x7e,0x00,0x96,0xfb,0x7c,0x00,0x89,0xfb,0x7a,0x00,0x7b,0xfb,0x78,0x00,0x6d,0xfb,0x75,0x00,0x5f,0xfb,0x73,0x00,0x51,0xfb,0x71,0x00,0x43,0xfb,0x6e,0x00,0x35,0xfb,0x6c,0x00,0x27,0xfb,0x6a,0x00,0x19,0xfb,0x67,0x00,0x0a,0xfb,0x65,0x00,0xfc,0xfa,0x62,0x00,0xee,0xfa,0x60,0x00,0xdf,0xfa,0x5d,0x00,0xd1,0xfa,0x5b,0x00,0xc2,0xfa,0x58,0x00,0xb4,0xfa,0x56,0x00,0xa5,0xfa,0x53,0x00,0x96,0xfa,0x50,0x00,0x88,0xfa,0x4e,0x00,0x79,0xfa,0x4b,0x00,  \
    0x6a,0xfa,0x49,0x00,0x5b,0xfa,0x46,0x00,0x4c,0xfa,0x43,0x00,0x3d,0xfa,0x40,0x00,0x2e,0xfa,0x3e,0x00,0x1e,0xfa,0x3b,0x00,0x0f,0xfa,0x38,0x00,0x00,0xfa,0x36,0x00,0xf0,0xf9,0x33,0x00,0xe1,0xf9,0x30,0x00,0xd1,0xf9,0x2d,0x00,0xc2,0xf9,0x2a,0x00,0xb2,0xf9,0x27,0x00,0xa2,0xf9,0x25,0x00,0x92,0xf9,0x22,0x00,0x82,0xf9,0x1f,0x00,0x72,0xf9,0x1c,0x00,0x62,0xf9,0x19,0x00,0x52,0xf9,0x16,0x00,0x42,0xf9,0x13,0x00,0x31,0xf9,0x10,0x00,0x21,0xf9,0x0d,0x00,0x10,0xf9,  \
    0x0a,0x00,0x00,0xf9,0x07,0x00,0xef,0xf8,0x04,0x00,0xde,0xf8,0x01,0x00,0xce,0xf8,0xfe,0xff,0xbd,0xf8,0xfb,0xff,0xac,0xf8,0xf8,0xff,0x9b,0xf8,0xf5,0xff,0x89,0xf8,0xf2,0xff,0x78,0xf8,0xef,0xff,0x67,0xf8,0xec,0xff,0x55,0xf8,0xe9,0xff,0x44,0xf8,0xe6,0xff,0x32,0xf8,0xe3,0xff,0x21,0xf8,0xe0,0xff,0x0f,0xf8,0xdc,0xff,0xfd,0xf7,0xd9,0xff,0xeb,0xf7,0xd6,0xff,0xd9,0xf7,0xd3,0xff,0xc7,0xf7,0xd0,0xff,0xb5,0xf7,0xcd,0xff,0xa2,0xf7,0xca,0xff,0x90,0xf7,0xc6,0xff,  \
    0x7d,0xf7,0xc3,0xff,0x6b,0xf7,0xc0,0xff,0x58,0xf7,0xbd,0xff,0x45,0xf7,0xba,0xff,0x32,0xf7,0xb7,0xff,0x1f,0xf7,0xb3,0xff,0x0c,0xf7,0xb0,0xff,0xf9,0xf6,0xad,0xff,0xe6,0xf6,0xaa,0xff,0xd2,0xf6,0xa7,0xff,0xbf,0xf6,0xa4,0xff,0xab,0xf6,0xa1,0xff,0x98,0xf6,0x9d,0xff,0x84,0xf6,0x9a,0xff,0x70,0xf6,0x97,0xff,0x5c,0xf6,0x94,0xff,0x48,0xf6,0x91,0xff,0x34,0xf6,0x8e,0xff,0x1f,0xf6,0x8b,0xff,0x0b,0xf6,0x87,0xff,0xf6,0xf5,0x84,0xff,0xe1,0xf5,0x81,0xff,0xcd,0xf5,  \
    0x7e,0xff,0xb8,0xf5,0x7b,0xff,0xa3,0xf5,0x78,0xff,0x8e,0xf5,0x75,0xff,0x78,0xf5,0x72,0xff,0x63,0xf5,0x6f,0xff,0x4e,0xf5,0x6c,0xff,0x38,0xf5,0x69,0xff,0x22,0xf5,0x66,0xff,0x0c,0xf5,0x63,0xff,0xf7,0xf4,0x60,0xff,0xe1,0xf4,0x5d,0xff,0xca,0xf4,0x5a,0xff,0xb4,0xf4,0x57,0xff,0x9e,0xf4,0x54,0xff,0x87,0xf4,0x51,0xff,0x71,0xf4,0x4e,0xff,0x5a,0xf4,0x4b,0xff,0x43,0xf4,0x48,0xff,0x2d,0xf4,0x46,0xff,0x16,0xf4,0x43,0xff,0xfe,0xf3,0x40,0xff,0xe7,0xf3,0x3d,0xff,  \
    0xd0,0xf3,0x3a,0xff,0xb8,0xf3,0x38,0xff,0xa1,0xf3,0x35,0xff,0x89,0xf3,0x32,0xff,0x71,0xf3,0x30,0xff,0x59,0xf3,0x2d,0xff,0x41,0xf3,0x2a,0xff,0x29,0xf3,0x28,0xff,0x10,0xf3,0x25,0xff,0xf8,0xf2,0x23,0xff,0xdf,0xf2,0x20,0xff,0xc6,0xf2,0x1e,0xff,0xae,0xf2,0x1b,0xff,0x95,0xf2,0x19,0xff,0x7b,0xf2,0x17,0xff,0x62,0xf2,0x14,0xff,0x49,0xf2,0x12,0xff,0x2f,0xf2,0x10,0xff,0x16,0xf2,0x0d,0xff,0xfc,0xf1,0x0b,0xff,0xe2,0xf1,0x09,0xff,0xc8,0xf1,0x07,0xff,0xae,0xf1,  \
    0x05,0xff,0x93,0xf1,0x03,0xff,0x79,0xf1,0x01,0xff,0x5f,0xf1,0xff,0xfe,0x44,0xf1,0xfd,0xfe,0x29,0xf1,0xfb,0xfe,0x0e,0xf1,0xf9,0xfe,0xf3,0xf0,0xf7,0xfe,0xd8,0xf0,0xf6,0xfe,0xbd,0xf0,0xf4,0xfe,0xa1,0xf0,0xf2,0xfe,0x86,0xf0,0xf0,0xfe,0x6a,0xf0,0xef,0xfe,0x4e,0xf0,0xed,0xfe,0x32,0xf0,0xec,0xfe,0x16,0xf0,0xea,0xfe,0xfa,0xef,0xe9,0xfe,0xde,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa8,0xfe,0x2d,0x10,0xa9,0xfe,0x10,0x10,0xab,0xfe,0xf4,0x0f,0xad,0xfe,0xd8,0x0f,0xaf,0xfe,0xbb,0x0f,0xb0,0xfe,0x9f,0x0f,0xb2,0xfe,0x83,0x0f,0xb4,0xfe,0x68,0x0f,0xb6,0xfe,0x4c,0x0f,0xb8,0xfe,0x30,0x0f,0xba,0xfe,0x15,0x0f,0xbc,0xfe,0xfa,0x0e,0xbe,0xfe,0xdf,0x0e,  \
    0xc0,0xfe,0xc3,0x0e,0xc3,0xfe,0xa9,0x0e,0xc5,0xfe,0x8e,0x0e,0xc7,0xfe,0x73,0x0e,0xc9,0xfe,0x59,0x0e,0xcc,0xfe,0x3e,0x0e,0xce,0xfe,0x24,0x0e,0xd1,0xfe,0x0a,0x0e,0xd3,0xfe,0xef,0x0d,0xd6,0xfe,0xd5,0x0d,0xd8,0xfe,0xbc,0x0d,0xdb,0xfe,0xa2,0x0d,0xdd,0xfe,0x88,0x0d,0xe0,0xfe,0x6f,0x0d,0xe3,0xfe,0x55,0x0d,0xe6,0xfe,0x3c,0x0d,0xe8,0xfe,0x23,0x0d,0xeb,0xfe,0x0a,0x0d,0xee,0xfe,0xf1,0x0c,0xf1,0xfe,0xd8,0x0c,0xf4,0xfe,0xbf,0x0c,0xf7,0xfe,0xa7,0x0c,0xfa,0xfe,  \
    0x8e,0x0c,0xfc,0xfe,0x76,0x0c,0xff,0xfe,0x5e,0x0c,0x02,0xff,0x46,0x0c,0x06,0xff,0x2e,0x0c,0x09,0xff,0x16,0x0c,0x0c,0xff,0xfe,0x0b,0x0f,0xff,0xe7,0x0b,0x12,0xff,0xd0,0x0b,0x16,0xff,0xb9,0x0b,0x19,0xff,0xa2,0x0b,0x1c,0xff,0x8b,0x0b,0x1f,0xff,0x74,0x0b,0x23,0xff,0x5d,0x0b,0x26,0xff,0x47,0x0b,0x2a,0xff,0x30,0x0b,0x2d,0xff,0x1a,0x0b,0x30,0xff,0x04,0x0b,0x34,0xff,0xee,0x0a,0x37,0xff,0xd8,0x0a,0x3b,0xff,0xc2,0x0a,0x3e,0xff,0xac,0x0a,0x42,0xff,0x97,0x0a,  \
    0x45,0xff,0x81,0x0a,0x48,0xff,0x6b,0x0a,0x4c,0xff,0x56,0x0a,0x4f,0xff,0x40,0x0a,0x53,0xff,0x2b,0x0a,0x56,0xff,0x15,0x0a,0x5a,0xff,0x00,0x0a,0x5d,0xff,0xeb,0x09,0x60,0xff,0xd6,0x09,0x64,0xff,0xc1,0x09,0x67,0xff,0xad,0x09,0x6b,0xff,0x98,0x09,0x6e,0xff,0x84,0x09,0x72,0xff,0x6f,0x09,0x75,0xff,0x5b,0x09,0x79,0xff,0x47,0x09,0x7c,0xff,0x32,0x09,0x80,0xff,0x1e,0x09,0x83,0xff,0x0a,0x09,0x87,0xff,0xf7,0x08,0x8a,0xff,0xe3,0x08,0x8e,0xff,0xcf,0x08,0x91,0xff,  \
    0xbc,0x08,0x95,0xff,0xa8,0x08,0x98,0xff,0x95,0x08,0x9c,0xff,0x82,0x08,0x9f,0xff,0x6f,0x08,0xa3,0xff,0x5c,0x08,0xa6,0xff,0x49,0x08,0xaa,0xff,0x36,0x08,0xad,0xff,0x23,0x08,0xb1,0xff,0x10,0x08,0xb4,0xff,0xfe,0x07,0xb8,0xff,0xeb,0x07,0xbb,0xff,0xd9,0x07,0xbf,0xff,0xc7,0x07,0xc2,0xff,0xb4,0x07,0xc5,0xff,0xa2,0x07,0xc9,0xff,0x90,0x07,0xcc,0xff,0x7f,0x07,0xd0,0xff,0x6d,0x07,0xd3,0xff,0x5b,0x07,0xd7,0xff,0x4a,0x07,0xda,0xff,0x38,0x07,0xdd,0xff,0x27,0x07,  \
    0xe1,0xff,0x15,0x07,0xe4,0xff,0x04,0x07,0xe7,0xff,0xf3,0x06,0xeb,0xff,0xe2,0x06,0xee,0xff,0xd1,0x06,0xf1,0xff,0xc0,0x06,0xf5,0xff,0xaf,0x06,0xf8,0xff,0x9e,0x06,0xfb,0xff,0x8e,0x06,0xff,0xff,0x7d,0x06,0x02,0x00,0x6d,0x06,0x05,0x00,0x5c,0x06,0x08,0x00,0x4c,0x06,0x0c,0x00,0x3b,0x06,0x0f,0x00,0x2b,0x06,0x12,0x00,0x1b,0x06,0x15,0x00,0x0b,0x06,0x18,0x00,0xfb,0x05,0x1b,0x00,0xeb,0x05,0x1e,0x00,0xdb,0x05,0x21,0x00,0xcb,0x05,0x25,0x00,0xbc,0x05,0x28,0x00,  \
    0xac,0x05,0x2b,0x00,0x9c,0x05,0x2e,0x00,0x8d,0x05,0x31,0x00,0x7d,0x05,0x34,0x00,0x6e,0x05,0x37,0x00,0x5f,0x05,0x39,0x00,0x4f,0x05,0x3c,0x00,0x40,0x05,0x3f,0x00,0x31,0x05,0x42,0x00,0x22,0x05,0x45,0x00,0x13,0x05,0x48,0x00,0x04,0x05,0x4b,0x00,0xf5,0x04,0x4d,0x00,0xe6,0x04,0x50,0x00,0xd7,0x04,0x53,0x00,0xc9,0x04,0x56,0x00,0xba,0x04,0x58,0x00,0xab,0x04,0x5b,0x00,0x9c,0x04,0x5e,0x00,0x8e,0x04,0x60,0x00,0x7f,0x04,0x63,0x00,0x71,0x04,0x65,0x00,0x62,0x04,  \
    0x68,0x00,0x54,0x04,0x6b,0x00,0x46,0x04,0x6d,0x00,0x38,0x04,0x70,0x00,0x29,0x04,0x72,0x00,0x1b,0x04,0x75,0x00,0x0d,0x04,0x77,0x00,0xff,0x03,0x79,0x00,0xf1,0x03,0x7c,0x00,0xe3,0x03,0x7e,0x00,0xd5,0x03,0x80,0x00,0xc8,0x03,0x83,0x00,0xba,0x03,0x85,0x00,0xac,0x03,0x87,0x00,0x9f,0x03,0x8a,0x00,0x91,0x03,0x8c,0x00,0x84,0x03,0x8e,0x00,0x76,0x03,0x90,0x00,0x69,0x03,0x92,0x00,0x5c,0x03,0x95,0x00,0x4e,0x03,0x97,0x00,0x41,0x03,0x99,0x00,0x34,0x03,0x9b,0x00,  \
    0x27,0x03,0x9d,0x00,0x1a,0x03,0x9f,0x00,0x0d,0x03,0xa1,0x00,0x00,0x03,0xa3,0x00,0xf3,0x02,0xa5,0x00,0xe6,0x02,0xa7,0x00,0xd9,0x02,0xa8,0x00,0xcc,0x02,0xaa,0x00,0xbf,0x02,0xac,0x00,0xb3,0x02,0xae,0x00,0xa6,0x02,0xb0,0x00,0x99,0x02,0xb1,0x00,0x8d,0x02,0xb3,0x00,0x80,0x02,0xb5,0x00,0x74,0x02,0xb6,0x00,0x67,0x02,0xb8,0x00,0x5b,0x02,0xba,0x00,0x4e,0x02,0xbb,0x00,0x42,0x02,0xbd,0x00,0x35,0x02,0xbe,0x00,0x29,0x02,0xc0,0x00,0x1d,0x02,0xc1,0x00,0x11,0x02,  \
    0xc3,0x00,0x04,0x02,0xc4,0x00,0xf8,0x01,0xc6,0x00,0xec,0x01,0xc7,0x00,0xe0,0x01,0xc8,0x00,0xd4,0x01,0xca,0x00,0xc8,0x01,0xcb,0x00,0xbc,0x01,0xcc,0x00,0xb0,0x01,0xcd,0x00,0xa4,0x01,0xcf,0x00,0x98,0x01,0xd0,0x00,0x8c,0x01,0xd1,0x00,0x80,0x01,0xd2,0x00,0x74,0x01,0xd3,0x00,0x68,0x01,0xd4,0x00,0x5c,0x01,0xd5,0x00,0x50,0x01,0xd6,0x00,0x44,0x01,0xd7,0x00,0x39,0x01,0xd8,0x00,0x2d,0x01,0xd9,0x00,0x21,0x01,0xda,0x00,0x15,0x01,0xdb,0x00,0x0a,0x01,0xdb,0x00,  \
    0xfe,0x00,0xdc,0x00,0xf2,0x00,0xdd,0x00,0xe6,0x00,0xde,0x00,0xdb,0x00,0xde,0x00,0xcf,0x00,0xdf,0x00,0xc3,0x00,0xe0,0x00,0xb8,0x00,0xe0,0x00,0xac,0x00,0xe1,0x00,0xa1,0x00,0xe2,0x00,0x95,0x00,0xe2,0x00,0x89,0x00,0xe3,0x00,0x7e,0x00,0xe3,0x00,0x72,0x00,0xe3,0x00,0x67,0x00,0xe4,0x00,0x5b,0x00,0xe4,0x00,0x50,0x00,0xe5,0x00,0x44,0x00,0xe5,0x00,0x39,0x00,0xe5,0x00,0x2d,0x00,0xe5,0x00,0x22,0x00,0xe6,0x00,0x16,0x00,0xe6,0x00,0x0b,0x00,0xe6,0x00,0xff,0xff,  \
    0xe6,0x00,0xf4,0xff,0xe6,0x00,0xe8,0xff,0xe6,0x00,0xdd,0xff,0xe6,0x00,0xd1,0xff,0xe6,0x00,0xc6,0xff,0xe6,0x00,0xba,0xff,0xe6,0x00,0xaf,0xff,0xe6,0x00,0xa3,0xff,0xe6,0x00,0x98,0xff,0xe6,0x00,0x8c,0xff,0xe6,0x00,0x81,0xff,0xe6,0x00,0x75,0xff,0xe6,0x00,0x6a,0xff,0xe5,0x00,0x5e,0xff,0xe5,0x00,0x53,0xff,0xe5,0x00,0x47,0xff,0xe5,0x00,0x3b,0xff,0xe4,0x00,0x30,0xff,0xe4,0x00,0x24,0xff,0xe3,0x00,0x19,0xff,0xe3,0x00,0x0d,0xff,0xe3,0x00,0x02,0xff,0xe2,0x00,  \
    0xf6,0xfe,0xe2,0x00,0xea,0xfe,0xe1,0x00,0xdf,0xfe,0xe1,0x00,0xd3,0xfe,0xe0,0x00,0xc7,0xfe,0xdf,0x00,0xbc,0xfe,0xdf,0x00,0xb0,0xfe,0xde,0x00,0xa4,0xfe,0xdd,0x00,0x98,0xfe,0xdd,0x00,0x8d,0xfe,0xdc,0x00,0x81,0xfe,0xdb,0x00,0x75,0xfe,0xda,0x00,0x6a,0xfe,0xd9,0x00,0x5e,0xfe,0xd9,0x00,0x53,0xfe,0xd8,0x00,0x47,0xfe,0xd7,0x00,0x3b,0xfe,0xd6,0x00,0x2f,0xfe,0xd5,0x00,0x24,0xfe,0xd4,0x00,0x18,0xfe,0xd3,0x00,0x0c,0xfe,0xd2,0x00,0x01,0xfe,0xd1,0x00,0xf5,0xfd,  \
    0xd0,0x00,0xe9,0xfd,0xce,0x00,0xdd,0xfd,0xcd,0x00,0xd1,0xfd,0xcc,0x00,0xc6,0xfd,0xcb,0x00,0xba,0xfd,0xca,0x00,0xae,0xfd,0xc8,0x00,0xa2,0xfd,0xc7,0x00,0x96,0xfd,0xc6,0x00,0x8a,0xfd,0xc4,0x00,0x7e,0xfd,0xc3,0x00,0x72,0xfd,0xc1,0x00,0x66,0xfd,0xc0,0x00,0x5a,0xfd,0xbf,0x00,0x4e,0xfd,0xbd,0x00,0x42,0xfd,0xbc,0x00,0x36,0xfd,0xba,0x00,0x29,0xfd,0xb8,0x00,0x1d,0xfd,0xb7,0x00,0x10,0xfd,0xb5,0x00,0x04,0xfd,0xb4,0x00,0xf7,0xfc,0xb2,0x00,0xea,0xfc,0xb0,0x00,  \
    0xde,0xfc,0xaf,0x00,0xd1,0xfc,0xad,0x00,0xc4,0xfc,0xab,0x00,0xb7,0xfc,0xa9,0x00,0xaa,0xfc,0xa8,0x00,0x9e,0xfc,0xa6,0x00,0x91,0xfc,0xa4,0x00,0x84,0xfc,0xa2,0x00,0x77,0xfc,0xa0,0x00,0x69,0xfc,0x9e,0x00,0x5c,0xfc,0x9c,0x00,0x4f,0xfc,0x9a,0x00,0x42,0xfc,0x98,0x00,0x35,0xfc,0x96,0x00,0x27,0xfc,0x94,0x00,0x1a,0xfc,0x92,0x00,0x0d,0xfc,0x90,0x00,0xff,0xfb,0x8e,0x00,0xf2,0xfb,0x8c,0x00,0xe4,0xfb,0x8a,0x00,0xd7,0xfb,0x88,0x00,0xc9,0xfb,0x85,0x00,0xbc,0xfb,  \
    0x83,0x00,0xae,0xfb,0x81,0x00,0xa0,0xfb,0x7f,0x00,0x93,0xfb,0x7c,0x00,0x85,0xfb,0x7a,0x00,0x77,0xfb,0x78,0x00,0x69,0xfb,0x75,0x00,0x5b,0xfb,0x73,0x00,0x4d,0xfb,0x70,0x00,0x3f,0xfb,0x6e,0x00,0x31,0xfb,0x6c,0x00,0x23,0xfb,0x69,0x00,0x15,0xfb,0x67,0x00,0x06,0xfb,0x64,0x00,0xf8,0xfa,0x62,0x00,0xea,0xfa,0x5f,0x00,0xdb,0xfa,0x5c,0x00,0xcd,0xfa,0x5a,0x00,0xbe,0xfa,0x57,0x00,0xb0,0xfa,0x55,0x00,0xa1,0xfa,0x52,0x00,0x92,0xfa,0x4f,0x00,0x83,0xfa,0x4d,0x00,  \
    0x75,0xfa,0x4a,0x00,0x66,0xfa,0x47,0x00,0x57,0xfa,0x44,0x00,0x48,0xfa,0x42,0x00,0x39,0xfa,0x3f,0x00,0x29,0xfa,0x3c,0x00,0x1a,0xfa,0x39,0x00,0x0b,0xfa,0x36,0x00,0xfb,0xf9,0x34,0x00,0xec,0xf9,0x31,0x00,0xdc,0xf9,0x2e,0x00,0xcd,0xf9,0x2b,0x00,0xbd,0xf9,0x28,0x00,0xae,0xf9,0x25,0x00,0x9e,0xf9,0x22,0x00,0x8e,0xf9,0x1f,0x00,0x7e,0xf9,0x1c,0x00,0x6e,0xf9,0x19,0x00,0x5e,0xf9,0x16,0x00,0x4e,0xf9,0x13,0x00,0x3d,0xf9,0x10,0x00,0x2d,0xf9,0x0d,0x00,0x1d,0xf9,  \
    0x0a,0x00,0x0c,0xf9,0x07,0x00,0xfb,0xf8,0x04,0x00,0xeb,0xf8,0x01,0x00,0xda,0xf8,0xfe,0xff,0xc9,0xf8,0xfb,0xff,0xb8,0xf8,0xf8,0xff,0xa7,0xf8,0xf4,0xff,0x96,0xf8,0xf1,0xff,0x85,0xf8,0xee,0xff,0x74,0xf8,0xeb,0xff,0x63,0xf8,0xe8,0xff,0x51,0xf8,0xe5,0xff,0x40,0xf8,0xe1,0xff,0x2e,0xf8,0xde,0xff,0x1c,0xf8,0xdb,0xff,0x0b,0xf8,0xd8,0xff,0xf9,0xf7,0xd5,0xff,0xe7,0xf7,0xd1,0xff,0xd5,0xf7,0xce,0xff,0xc3,0xf7,0xcb,0xff,0xb0,0xf7,0xc8,0xff,0x9e,0xf7,0xc4,0xff,  \
    0x8c,0xf7,0xc1,0xff,0x79,0xf7,0xbe,0xff,0x67,0xf7,0xbb,0xff,0x54,0xf7,0xb7,0xff,0x41,0xf7,0xb4,0xff,0x2e,0xf7,0xb1,0xff,0x1b,0xf7,0xae,0xff,0x08,0xf7,0xaa,0xff,0xf5,0xf6,0xa7,0xff,0xe2,0xf6,0xa4,0xff,0xce,0xf6,0xa1,0xff,0xbb,0xf6,0x9d,0xff,0xa7,0xf6,0x9a,0xff,0x94,0xf6,0x97,0xff,0x80,0xf6,0x94,0xff,0x6c,0xf6,0x90,0xff,0x58,0xf6,0x8d,0xff,0x44,0xf6,0x8a,0xff,0x30,0xf6,0x87,0xff,0x1b,0xf6,0x83,0xff,0x07,0xf6,0x80,0xff,0xf2,0xf5,0x7d,0xff,0xde,0xf5,  \
    0x7a,0xff,0xc9,0xf5,0x77,0xff,0xb4,0xf5,0x73,0xff,0x9f,0xf5,0x70,0xff,0x8a,0xf5,0x6d,0xff,0x74,0xf5,0x6a,0xff,0x5f,0xf5,0x67,0xff,0x4a,0xf5,0x64,0xff,0x34,0xf5,0x61,0xff,0x1e,0xf5,0x5d,0xff,0x09,0xf5,0x5a,0xff,0xf3,0xf4,0x57,0xff,0xdd,0xf4,0x54,0xff,0xc7,0xf4,0x51,0xff,0xb0,0xf4,0x4e,0xff,0x9a,0xf4,0x4b,0xff,0x84,0xf4,0x48,0xff,0x6d,0xf4,0x45,0xff,0x57,0xf4,0x42,0xff,0x40,0xf4,0x3f,0xff,0x29,0xf4,0x3c,0xff,0x12,0xf4,0x39,0xff,0xfb,0xf3,0x36,0xff,  \
    0xe4,0xf3,0x33,0xff,0xcc,0xf3,0x31,0xff,0xb5,0xf3,0x2e,0xff,0x9d,0xf3,0x2b,0xff,0x85,0xf3,0x28,0xff,0x6e,0xf3,0x25,0xff,0x56,0xf3,0x23,0xff,0x3e,0xf3,0x20,0xff,0x25,0xf3,0x1d,0xff,0x0d,0xf3,0x1b,0xff,0xf5,0xf2,0x18,0xff,0xdc,0xf2,0x15,0xff,0xc3,0xf2,0x13,0xff,0xaa,0xf2,0x10,0xff,0x91,0xf2,0x0e,0xff,0x78,0xf2,0x0c,0xff,0x5f,0xf2,0x09,0xff,0x46,0xf2,0x07,0xff,0x2c,0xf2,0x04,0xff,0x12,0xf2,0x02,0xff,0xf9,0xf1,0x00,0xff,0xdf,0xf1,0xfe,0xfe,0xc5,0xf1,  \
    0xfb,0xfe,0xab,0xf1,0xf9,0xfe,0x90,0xf1,0xf7,0xfe,0x76,0xf1,0xf5,0xfe,0x5b,0xf1,0xf3,0xfe,0x41,0xf1,0xf1,0xfe,0x26,0xf1,0xef,0xfe,0x0b,0xf1,0xed,0xfe,0xf0,0xf0,0xeb,0xfe,0xd5,0xf0,0xe9,0xfe,0xba,0xf0,0xe8,0xfe,0x9e,0xf0,0xe6,0xfe,0x83,0xf0,0xe4,0xfe,0x67,0xf0,0xe2,0xfe,0x4b,0xf0,0xe1,0xfe,0x2f,0xf0,0xdf,0xfe,0x13,0xf0,0xde,0xfe,0xf7,0xef,0xdc,0xfe,0xdb,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x9c,0xfe,0x30,0x10,0x9e,0xfe,0x13,0x10,0x9f,0xfe,0xf7,0x0f,0xa1,0xfe,0xda,0x0f,0xa3,0xfe,0xbe,0x0f,0xa5,0xfe,0xa2,0x0f,0xa7,0xfe,0x86,0x0f,0xa9,0xfe,0x6b,0x0f,0xab,0xfe,0x4f,0x0f,0xad,0xfe,0x33,0x0f,0xaf,0xfe,0x18,0x0f,0xb1,0xfe,0xfd,0x0e,  \
    0xb3,0xfe,0xe2,0x0e,0xb5,0xfe,0xc6,0x0e,0xb8,0xfe,0xac,0x0e,0xba,0xfe,0x91,0x0e,0xbc,0xfe,0x76,0x0e,0xbf,0xfe,0x5c,0x0e,0xc1,0xfe,0x41,0x0e,0xc4,0xfe,0x27,0x0e,0xc6,0xfe,0x0d,0x0e,0xc9,0xfe,0xf3,0x0d,0xcb,0xfe,0xd9,0x0d,0xce,0xfe,0xbf,0x0d,0xd1,0xfe,0xa5,0x0d,0xd3,0xfe,0x8b,0x0d,0xd6,0xfe,0x72,0x0d,0xd9,0xfe,0x58,0x0d,0xdc,0xfe,0x3f,0x0d,0xde,0xfe,0x26,0x0d,0xe1,0xfe,0x0d,0x0d,0xe4,0xfe,0xf4,0x0c,0xe7,0xfe,0xdb,0x0c,0xea,0xfe,0xc3,0x0c,0xed,0xfe,  \
    0xaa,0x0c,0xf0,0xfe,0x92,0x0c,0xf3,0xfe,0x79,0x0c,0xf6,0xfe,0x61,0x0c,0xf9,0xfe,0x49,0x0c,0xfc,0xfe,0x31,0x0c,0x00,0xff,0x19,0x0c,0x03,0xff,0x02,0x0c,0x06,0xff,0xea,0x0b,0x09,0xff,0xd3,0x0b,0x0d,0xff,0xbc,0x0b,0x10,0xff,0xa5,0x0b,0x14,0xff,0x8e,0x0b,0x17,0xff,0x77,0x0b,0x1a,0xff,0x61,0x0b,0x1e,0xff,0x4a,0x0b,0x21,0xff,0x34,0x0b,0x25,0xff,0x1e,0x0b,0x28,0xff,0x08,0x0b,0x2c,0xff,0xf2,0x0a,0x2f,0xff,0xdc,0x0a,0x33,0xff,0xc6,0x0a,0x37,0xff,0xb0,0x0a,  \
    0x3a,0xff,0x9b,0x0a,0x3e,0xff,0x85,0x0a,0x41,0xff,0x6f,0x0a,0x45,0xff,0x59,0x0a,0x48,0xff,0x44,0x0a,0x4c,0xff,0x2f,0x0a,0x4f,0xff,0x19,0x0a,0x53,0xff,0x04,0x0a,0x56,0xff,0xef,0x09,0x5a,0xff,0xda,0x09,0x5d,0xff,0xc5,0x09,0x61,0xff,0xb1,0x09,0x64,0xff,0x9c,0x09,0x68,0xff,0x88,0x09,0x6c,0xff,0x73,0x09,0x6f,0xff,0x5f,0x09,0x73,0xff,0x4b,0x09,0x76,0xff,0x37,0x09,0x7a,0xff,0x23,0x09,0x7e,0xff,0x0f,0x09,0x81,0xff,0xfb,0x08,0x85,0xff,0xe7,0x08,0x88,0xff,  \
    0xd3,0x08,0x8c,0xff,0xc0,0x08,0x8f,0xff,0xad,0x08,0x93,0xff,0x99,0x08,0x97,0xff,0x86,0x08,0x9a,0xff,0x73,0x08,0x9e,0xff,0x60,0x08,0xa1,0xff,0x4d,0x08,0xa5,0xff,0x3a,0x08,0xa9,0xff,0x27,0x08,0xac,0xff,0x15,0x08,0xb0,0xff,0x02,0x08,0xb3,0xff,0xef,0x07,0xb7,0xff,0xdd,0x07,0xba,0xff,0xcb,0x07,0xbe,0xff,0xb9,0x07,0xc1,0xff,0xa7,0x07,0xc5,0xff,0x95,0x07,0xc8,0xff,0x83,0x07,0xcc,0xff,0x71,0x07,0xcf,0xff,0x60,0x07,0xd3,0xff,0x4e,0x07,0xd6,0xff,0x3c,0x07,  \
    0xda,0xff,0x2b,0x07,0xdd,0xff,0x1a,0x07,0xe1,0xff,0x08,0x07,0xe4,0xff,0xf7,0x06,0xe8,0xff,0xe6,0x06,0xeb,0xff,0xd5,0x06,0xef,0xff,0xc4,0x06,0xf2,0xff,0xb4,0x06,0xf5,0xff,0xa3,0x06,0xf9,0xff,0x92,0x06,0xfc,0xff,0x82,0x06,0xff,0xff,0x71,0x06,0x03,0x00,0x61,0x06,0x06,0x00,0x50,0x06,0x09,0x00,0x40,0x06,0x0c,0x00,0x30,0x06,0x10,0x00,0x1f,0x06,0x13,0x00,0x0f,0x06,0x16,0x00,0xff,0x05,0x19,0x00,0xef,0x05,0x1d,0x00,0xe0,0x05,0x20,0x00,0xd0,0x05,0x23,0x00,  \
    0xc0,0x05,0x26,0x00,0xb0,0x05,0x29,0x00,0xa1,0x05,0x2c,0x00,0x91,0x05,0x2f,0x00,0x82,0x05,0x32,0x00,0x72,0x05,0x35,0x00,0x63,0x05,0x38,0x00,0x54,0x05,0x3b,0x00,0x45,0x05,0x3e,0x00,0x36,0x05,0x41,0x00,0x26,0x05,0x44,0x00,0x18,0x05,0x47,0x00,0x09,0x05,0x4a,0x00,0xfa,0x04,0x4d,0x00,0xeb,0x04,0x50,0x00,0xdc,0x04,0x52,0x00,0xcd,0x04,0x55,0x00,0xbe,0x04,0x58,0x00,0xaf,0x04,0x5b,0x00,0xa1,0x04,0x5d,0x00,0x92,0x04,0x60,0x00,0x83,0x04,0x63,0x00,0x75,0x04,  \
    0x65,0x00,0x66,0x04,0x68,0x00,0x58,0x04,0x6b,0x00,0x4a,0x04,0x6d,0x00,0x3b,0x04,0x70,0x00,0x2d,0x04,0x72,0x00,0x1f,0x04,0x75,0x00,0x11,0x04,0x77,0x00,0x03,0x04,0x7a,0x00,0xf5,0x03,0x7c,0x00,0xe7,0x03,0x7f,0x00,0xd9,0x03,0x81,0x00,0xcb,0x03,0x83,0x00,0xbe,0x03,0x86,0x00,0xb0,0x03,0x88,0x00,0xa2,0x03,0x8a,0x00,0x95,0x03,0x8d,0x00,0x87,0x03,0x8f,0x00,0x7a,0x03,0x91,0x00,0x6c,0x03,0x93,0x00,0x5f,0x03,0x95,0x00,0x52,0x03,0x98,0x00,0x45,0x03,0x9a,0x00,  \
    0x37,0x03,0x9c,0x00,0x2a,0x03,0x9e,0x00,0x1d,0x03,0xa0,0x00,0x10,0x03,0xa2,0x00,0x03,0x03,0xa4,0x00,0xf6,0x02,0xa6,0x00,0xe9,0x02,0xa8,0x00,0xdc,0x02,0xaa,0x00,0xcf,0x02,0xac,0x00,0xc3,0x02,0xae,0x00,0xb6,0x02,0xaf,0x00,0xa9,0x02,0xb1,0x00,0x9c,0x02,0xb3,0x00,0x90,0x02,0xb5,0x00,0x83,0x02,0xb7,0x00,0x76,0x02,0xb8,0x00,0x6a,0x02,0xba,0x00,0x5d,0x02,0xbc,0x00,0x51,0x02,0xbd,0x00,0x44,0x02,0xbf,0x00,0x38,0x02,0xc0,0x00,0x2c,0x02,0xc2,0x00,0x1f,0x02,  \
    0xc3,0x00,0x13,0x02,0xc5,0x00,0x07,0x02,0xc6,0x00,0xfb,0x01,0xc8,0x00,0xee,0x01,0xc9,0x00,0xe2,0x01,0xca,0x00,0xd6,0x01,0xcc,0x00,0xca,0x01,0xcd,0x00,0xbe,0x01,0xce,0x00,0xb2,0x01,0xd0,0x00,0xa6,0x01,0xd1,0x00,0x9a,0x01,0xd2,0x00,0x8e,0x01,0xd3,0x00,0x82,0x01,0xd4,0x00,0x76,0x01,0xd5,0x00,0x6a,0x01,0xd7,0x00,0x5e,0x01,0xd8,0x00,0x52,0x01,0xd9,0x00,0x46,0x01,0xda,0x00,0x3a,0x01,0xdb,0x00,0x2f,0x01,0xdb,0x00,0x23,0x01,0xdc,0x00,0x17,0x01,0xdd,0x00,  \
    0x0b,0x01,0xde,0x00,0xff,0x00,0xdf,0x00,0xf4,0x00,0xe0,0x00,0xe8,0x00,0xe0,0x00,0xdc,0x00,0xe1,0x00,0xd0,0x00,0xe2,0x00,0xc5,0x00,0xe2,0x00,0xb9,0x00,0xe3,0x00,0xad,0x00,0xe4,0x00,0xa2,0x00,0xe4,0x00,0x96,0x00,0xe5,0x00,0x8a,0x00,0xe5,0x00,0x7f,0x00,0xe6,0x00,0x73,0x00,0xe6,0x00,0x67,0x00,0xe7,0x00,0x5c,0x00,0xe7,0x00,0x50,0x00,0xe7,0x00,0x45,0x00,0xe8,0x00,0x39,0x00,0xe8,0x00,0x2e,0x00,0xe8,0x00,0x22,0x00,0xe9,0x00,0x16,0x00,0xe9,0x00,0x0b,0x00,  \
    0xe9,0x00,0xff,0xff,0xe9,0x00,0xf4,0xff,0xe9,0x00,0xe8,0xff,0xe9,0x00,0xdd,0xff,0xe9,0x00,0xd1,0xff,0xe9,0x00,0xc6,0xff,0xe9,0x00,0xba,0xff,0xe9,0x00,0xaf,0xff,0xe9,0x00,0xa3,0xff,0xe9,0x00,0x97,0xff,0xe9,0x00,0x8c,0xff,0xe9,0x00,0x80,0xff,0xe9,0x00,0x75,0xff,0xe8,0x00,0x69,0xff,0xe8,0x00,0x5e,0xff,0xe8,0x00,0x52,0xff,0xe8,0x00,0x46,0xff,0xe7,0x00,0x3b,0xff,0xe7,0x00,0x2f,0xff,0xe7,0x00,0x24,0xff,0xe6,0x00,0x18,0xff,0xe6,0x00,0x0c,0xff,0xe5,0x00,  \
    0x01,0xff,0xe5,0x00,0xf5,0xfe,0xe4,0x00,0xe9,0xfe,0xe4,0x00,0xde,0xfe,0xe3,0x00,0xd2,0xfe,0xe3,0x00,0xc6,0xfe,0xe2,0x00,0xba,0xfe,0xe1,0x00,0xaf,0xfe,0xe1,0x00,0xa3,0xfe,0xe0,0x00,0x97,0xfe,0xdf,0x00,0x8b,0xfe,0xde,0x00,0x80,0xfe,0xde,0x00,0x74,0xfe,0xdd,0x00,0x68,0xfe,0xdc,0x00,0x5c,0xfe,0xdb,0x00,0x51,0xfe,0xda,0x00,0x45,0xfe,0xd9,0x00,0x39,0xfe,0xd8,0x00,0x2e,0xfe,0xd7,0x00,0x22,0xfe,0xd6,0x00,0x16,0xfe,0xd5,0x00,0x0a,0xfe,0xd4,0x00,0xff,0xfd,  \
    0xd3,0x00,0xf3,0xfd,0xd2,0x00,0xe7,0xfd,0xd1,0x00,0xdb,0xfd,0xcf,0x00,0xcf,0xfd,0xce,0x00,0xc3,0xfd,0xcd,0x00,0xb8,0xfd,0xcc,0x00,0xac,0xfd,0xca,0x00,0xa0,0xfd,0xc9,0x00,0x94,0xfd,0xc8,0x00,0x88,0xfd,0xc6,0x00,0x7c,0xfd,0xc5,0x00,0x70,0xfd,0xc3,0x00,0x64,0xfd,0xc2,0x00,0x58,0xfd,0xc0,0x00,0x4c,0xfd,0xbf,0x00,0x40,0xfd,0xbd,0x00,0x33,0xfd,0xbc,0x00,0x27,0xfd,0xba,0x00,0x1a,0xfd,0xb8,0x00,0x0d,0xfd,0xb7,0x00,0x01,0xfd,0xb5,0x00,0xf4,0xfc,0xb3,0x00,  \
    0xe7,0xfc,0xb2,0x00,0xdb,0xfc,0xb0,0x00,0xce,0xfc,0xae,0x00,0xc1,0xfc,0xac,0x00,0xb4,0xfc,0xab,0x00,0xa7,0xfc,0xa9,0x00,0x9a,0xfc,0xa7,0x00,0x8d,0xfc,0xa5,0x00,0x80,0xfc,0xa3,0x00,0x73,0xfc,0xa1,0x00,0x66,0xfc,0x9f,0x00,0x59,0xfc,0x9d,0x00,0x4c,0xfc,0x9b,0x00,0x3e,0xfc,0x99,0x00,0x31,0xfc,0x97,0x00,0x24,0xfc,0x95,0x00,0x16,0xfc,0x93,0x00,0x09,0xfc,0x91,0x00,0xfb,0xfb,0x8f,0x00,0xee,0xfb,0x8c,0x00,0xe0,0xfb,0x8a,0x00,0xd3,0xfb,0x88,0x00,0xc5,0xfb,  \
    0x86,0x00,0xb8,0xfb,0x83,0x00,0xaa,0xfb,0x81,0x00,0x9c,0xfb,0x7f,0x00,0x8f,0xfb,0x7c,0x00,0x81,0xfb,0x7a,0x00,0x73,0xfb,0x78,0x00,0x65,0xfb,0x75,0x00,0x57,0xfb,0x73,0x00,0x49,0xfb,0x70,0x00,0x3b,0xfb,0x6e,0x00,0x2d,0xfb,0x6b,0x00,0x1f,0xfb,0x69,0x00,0x11,0xfb,0x66,0x00,0x02,0xfb,0x64,0x00,0xf4,0xfa,0x61,0x00,0xe6,0xfa,0x5e,0x00,0xd7,0xfa,0x5c,0x00,0xc9,0xfa,0x59,0x00,0xba,0xfa,0x56,0x00,0xab,0xfa,0x54,0x00,0x9d,0xfa,0x51,0x00,0x8e,0xfa,0x4e,0x00,  \
    0x7f,0xfa,0x4b,0x00,0x70,0xfa,0x49,0x00,0x61,0xfa,0x46,0x00,0x52,0xfa,0x43,0x00,0x43,0xfa,0x40,0x00,0x34,0xfa,0x3d,0x00,0x25,0xfa,0x3a,0x00,0x16,0xfa,0x38,0x00,0x06,0xfa,0x35,0x00,0xf7,0xf9,0x32,0x00,0xe8,0xf9,0x2f,0x00,0xd8,0xf9,0x2c,0x00,0xc8,0xf9,0x29,0x00,0xb9,0xf9,0x26,0x00,0xa9,0xf9,0x23,0x00,0x99,0xf9,0x20,0x00,0x89,0xf9,0x1d,0x00,0x79,0xf9,0x1a,0x00,0x69,0xf9,0x17,0x00,0x59,0xf9,0x13,0x00,0x49,0xf9,0x10,0x00,0x39,0xf9,0x0d,0x00,0x29,0xf9,  \
    0x0a,0x00,0x18,0xf9,0x07,0x00,0x08,0xf9,0x04,0x00,0xf7,0xf8,0x01,0x00,0xe6,0xf8,0xfd,0xff,0xd6,0xf8,0xfa,0xff,0xc5,0xf8,0xf7,0xff,0xb4,0xf8,0xf4,0xff,0xa3,0xf8,0xf1,0xff,0x92,0xf8,0xed,0xff,0x81,0xf8,0xea,0xff,0x6f,0xf8,0xe7,0xff,0x5e,0xf8,0xe4,0xff,0x4d,0xf8,0xe0,0xff,0x3b,0xf8,0xdd,0xff,0x2a,0xf8,0xda,0xff,0x18,0xf8,0xd7,0xff,0x06,0xf8,0xd3,0xff,0xf4,0xf7,0xd0,0xff,0xe2,0xf7,0xcd,0xff,0xd0,0xf7,0xc9,0xff,0xbe,0xf7,0xc6,0xff,0xac,0xf7,0xc3,0xff,  \
    0x9a,0xf7,0xbf,0xff,0x87,0xf7,0xbc,0xff,0x75,0xf7,0xb9,0xff,0x62,0xf7,0xb5,0xff,0x50,0xf7,0xb2,0xff,0x3d,0xf7,0xae,0xff,0x2a,0xf7,0xab,0xff,0x17,0xf7,0xa8,0xff,0x04,0xf7,0xa4,0xff,0xf1,0xf6,0xa1,0xff,0xde,0xf6,0x9e,0xff,0xca,0xf6,0x9a,0xff,0xb7,0xf6,0x97,0xff,0xa3,0xf6,0x94,0xff,0x90,0xf6,0x90,0xff,0x7c,0xf6,0x8d,0xff,0x68,0xf6,0x89,0xff,0x54,0xf6,0x86,0xff,0x40,0xf6,0x83,0xff,0x2c,0xf6,0x7f,0xff,0x17,0xf6,0x7c,0xff,0x03,0xf6,0x79,0xff,0xee,0xf5,  \
    0x76,0xff,0xda,0xf5,0x72,0xff,0xc5,0xf5,0x6f,0xff,0xb0,0xf5,0x6c,0xff,0x9b,0xf5,0x68,0xff,0x86,0xf5,0x65,0xff,0x71,0xf5,0x62,0xff,0x5b,0xf5,0x5f,0xff,0x46,0xf5,0x5b,0xff,0x30,0xf5,0x58,0xff,0x1b,0xf5,0x55,0xff,0x05,0xf5,0x52,0xff,0xef,0xf4,0x4f,0xff,0xd9,0xf4,0x4b,0xff,0xc3,0xf4,0x48,0xff,0xad,0xf4,0x45,0xff,0x96,0xf4,0x42,0xff,0x80,0xf4,0x3f,0xff,0x6a,0xf4,0x3c,0xff,0x53,0xf4,0x39,0xff,0x3c,0xf4,0x36,0xff,0x25,0xf4,0x33,0xff,0x0e,0xf4,0x30,0xff,  \
    0xf7,0xf3,0x2d,0xff,0xe0,0xf3,0x2a,0xff,0xc9,0xf3,0x27,0xff,0xb1,0xf3,0x24,0xff,0x9a,0xf3,0x21,0xff,0x82,0xf3,0x1e,0xff,0x6a,0xf3,0x1b,0xff,0x52,0xf3,0x18,0xff,0x3a,0xf3,0x16,0xff,0x22,0xf3,0x13,0xff,0x0a,0xf3,0x10,0xff,0xf1,0xf2,0x0d,0xff,0xd8,0xf2,0x0b,0xff,0xc0,0xf2,0x08,0xff,0xa7,0xf2,0x05,0xff,0x8e,0xf2,0x03,0xff,0x75,0xf2,0x00,0xff,0x5c,0xf2,0xfe,0xfe,0x42,0xf2,0xfb,0xfe,0x29,0xf2,0xf9,0xfe,0x0f,0xf2,0xf7,0xfe,0xf5,0xf1,0xf4,0xfe,0xdb,0xf1,  \
    0xf2,0xfe,0xc2,0xf1,0xf0,0xfe,0xa7,0xf1,0xed,0xfe,0x8d,0xf1,0xeb,0xfe,0x73,0xf1,0xe9,0xfe,0x58,0xf1,0xe7,0xfe,0x3e,0xf1,0xe5,0xfe,0x23,0xf1,0xe3,0xfe,0x08,0xf1,0xe1,0xfe,0xed,0xf0,0xdf,0xfe,0xd2,0xf0,0xdd,0xfe,0xb7,0xf0,0xdb,0xfe,0x9b,0xf0,0xd9,0xfe,0x80,0xf0,0xd8,0xfe,0x64,0xf0,0xd6,0xfe,0x48,0xf0,0xd4,0xfe,0x2c,0xf0,0xd3,0xfe,0x10,0xf0,0xd1,0xfe,0xf4,0xef,0xd0,0xfe,0xd8,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x90,0xfe,0x33,0x10,0x92,0xfe,0x16,0x10,0x94,0xfe,0xfa,0x0f,0x96,0xfe,0xdd,0x0f,0x97,0xfe,0xc1,0x0f,0x99,0xfe,0xa5,0x0f,0x9b,0xfe,0x89,0x0f,0x9d,0xfe,0x6e,0x0f,0x9f,0xfe,0x52,0x0f,0xa1,0xfe,0x36,0x0f,0xa4,0xfe,0x1b,0x0f,  \
    0xa6,0xfe,0x00,0x0f,0xa8,0xfe,0xe5,0x0e,0xaa,0xfe,0xca,0x0e,0xad,0xfe,0xaf,0x0e,0xaf,0xfe,0x94,0x0e,0xb1,0xfe,0x79,0x0e,0xb4,0xfe,0x5f,0x0e,0xb6,0xfe,0x44,0x0e,0xb9,0xfe,0x2a,0x0e,0xbb,0xfe,0x10,0x0e,0xbe,0xfe,0xf6,0x0d,0xc1,0xfe,0xdc,0x0d,0xc3,0xfe,0xc2,0x0d,0xc6,0xfe,0xa8,0x0d,0xc9,0xfe,0x8f,0x0d,0xcc,0xfe,0x75,0x0d,0xcf,0xfe,0x5c,0x0d,0xd1,0xfe,0x42,0x0d,0xd4,0xfe,0x29,0x0d,0xd7,0xfe,0x10,0x0d,0xda,0xfe,0xf7,0x0c,0xdd,0xfe,0xdf,0x0c,0xe0,0xfe,  \
    0xc6,0x0c,0xe3,0xfe,0xad,0x0c,0xe6,0xfe,0x95,0x0c,0xea,0xfe,0x7d,0x0c,0xed,0xfe,0x64,0x0c,0xf0,0xfe,0x4c,0x0c,0xf3,0xfe,0x34,0x0c,0xf6,0xfe,0x1d,0x0c,0xfa,0xfe,0x05,0x0c,0xfd,0xfe,0xee,0x0b,0x01,0xff,0xd7,0x0b,0x04,0xff,0xc0,0x0b,0x08,0xff,0xa9,0x0b,0x0b,0xff,0x92,0x0b,0x0f,0xff,0x7b,0x0b,0x12,0xff,0x65,0x0b,0x16,0xff,0x4e,0x0b,0x19,0xff,0x38,0x0b,0x1d,0xff,0x21,0x0b,0x20,0xff,0x0b,0x0b,0x24,0xff,0xf5,0x0a,0x28,0xff,0xdf,0x0a,0x2b,0xff,0xca,0x0a,  \
    0x2f,0xff,0xb4,0x0a,0x33,0xff,0x9e,0x0a,0x36,0xff,0x89,0x0a,0x3a,0xff,0x73,0x0a,0x3d,0xff,0x5e,0x0a,0x41,0xff,0x48,0x0a,0x45,0xff,0x33,0x0a,0x48,0xff,0x1e,0x0a,0x4c,0xff,0x08,0x0a,0x4f,0xff,0xf3,0x09,0x53,0xff,0xde,0x09,0x57,0xff,0xca,0x09,0x5a,0xff,0xb5,0x09,0x5e,0xff,0xa0,0x09,0x62,0xff,0x8c,0x09,0x65,0xff,0x77,0x09,0x69,0xff,0x63,0x09,0x6d,0xff,0x4f,0x09,0x70,0xff,0x3b,0x09,0x74,0xff,0x27,0x09,0x78,0xff,0x13,0x09,0x7b,0xff,0xff,0x08,0x7f,0xff,  \
    0xeb,0x08,0x83,0xff,0xd8,0x08,0x86,0xff,0xc4,0x08,0x8a,0xff,0xb1,0x08,0x8e,0xff,0x9e,0x08,0x92,0xff,0x8a,0x08,0x95,0xff,0x77,0x08,0x99,0xff,0x64,0x08,0x9c,0xff,0x51,0x08,0xa0,0xff,0x3e,0x08,0xa4,0xff,0x2c,0x08,0xa7,0xff,0x19,0x08,0xab,0xff,0x06,0x08,0xaf,0xff,0xf4,0x07,0xb2,0xff,0xe1,0x07,0xb6,0xff,0xcf,0x07,0xba,0xff,0xbd,0x07,0xbd,0xff,0xab,0x07,0xc1,0xff,0x99,0x07,0xc4,0xff,0x87,0x07,0xc8,0xff,0x76,0x07,0xcc,0xff,0x64,0x07,0xcf,0xff,0x52,0x07,  \
    0xd3,0xff,0x41,0x07,0xd6,0xff,0x30,0x07,0xda,0xff,0x1e,0x07,0xdd,0xff,0x0d,0x07,0xe1,0xff,0xfc,0x06,0xe5,0xff,0xeb,0x06,0xe8,0xff,0xda,0x06,0xec,0xff,0xc9,0x06,0xef,0xff,0xb8,0x06,0xf2,0xff,0xa7,0x06,0xf6,0xff,0x97,0x06,0xf9,0xff,0x86,0x06,0xfd,0xff,0x76,0x06,0x00,0x00,0x65,0x06,0x04,0x00,0x55,0x06,0x07,0x00,0x44,0x06,0x0a,0x00,0x34,0x06,0x0e,0x00,0x24,0x06,0x11,0x00,0x14,0x06,0x14,0x00,0x04,0x06,0x17,0x00,0xf4,0x05,0x1b,0x00,0xe4,0x05,0x1e,0x00,  \
    0xd4,0x05,0x21,0x00,0xc5,0x05,0x24,0x00,0xb5,0x05,0x27,0x00,0xa5,0x05,0x2b,0x00,0x96,0x05,0x2e,0x00,0x86,0x05,0x31,0x00,0x77,0x05,0x34,0x00,0x68,0x05,0x37,0x00,0x58,0x05,0x3a,0x00,0x49,0x05,0x3d,0x00,0x3a,0x05,0x40,0x00,0x2b,0x05,0x43,0x00,0x1c,0x05,0x46,0x00,0x0d,0x05,0x49,0x00,0xfe,0x04,0x4c,0x00,0xef,0x04,0x4f,0x00,0xe0,0x04,0x52,0x00,0xd1,0x04,0x55,0x00,0xc2,0x04,0x57,0x00,0xb4,0x04,0x5a,0x00,0xa5,0x04,0x5d,0x00,0x96,0x04,0x60,0x00,0x88,0x04,  \
    0x62,0x00,0x79,0x04,0x65,0x00,0x6b,0x04,0x68,0x00,0x5c,0x04,0x6b,0x00,0x4e,0x04,0x6d,0x00,0x40,0x04,0x70,0x00,0x31,0x04,0x72,0x00,0x23,0x04,0x75,0x00,0x15,0x04,0x77,0x00,0x07,0x04,0x7a,0x00,0xf9,0x03,0x7c,0x00,0xeb,0x03,0x7f,0x00,0xdd,0x03,0x81,0x00,0xcf,0x03,0x84,0x00,0xc1,0x03,0x86,0x00,0xb4,0x03,0x89,0x00,0xa6,0x03,0x8b,0x00,0x98,0x03,0x8d,0x00,0x8b,0x03,0x90,0x00,0x7d,0x03,0x92,0x00,0x70,0x03,0x94,0x00,0x63,0x03,0x96,0x00,0x55,0x03,0x99,0x00,  \
    0x48,0x03,0x9b,0x00,0x3b,0x03,0x9d,0x00,0x2e,0x03,0x9f,0x00,0x20,0x03,0xa1,0x00,0x13,0x03,0xa3,0x00,0x06,0x03,0xa5,0x00,0xf9,0x02,0xa7,0x00,0xec,0x02,0xa9,0x00,0xdf,0x02,0xab,0x00,0xd2,0x02,0xad,0x00,0xc6,0x02,0xaf,0x00,0xb9,0x02,0xb1,0x00,0xac,0x02,0xb3,0x00,0x9f,0x02,0xb5,0x00,0x93,0x02,0xb6,0x00,0x86,0x02,0xb8,0x00,0x79,0x02,0xba,0x00,0x6d,0x02,0xbc,0x00,0x60,0x02,0xbd,0x00,0x54,0x02,0xbf,0x00,0x47,0x02,0xc1,0x00,0x3b,0x02,0xc2,0x00,0x2e,0x02,  \
    0xc4,0x00,0x22,0x02,0xc5,0x00,0x16,0x02,0xc7,0x00,0x09,0x02,0xc8,0x00,0xfd,0x01,0xca,0x00,0xf1,0x01,0xcb,0x00,0xe5,0x01,0xcd,0x00,0xd8,0x01,0xce,0x00,0xcc,0x01,0xcf,0x00,0xc0,0x01,0xd1,0x00,0xb4,0x01,0xd2,0x00,0xa8,0x01,0xd3,0x00,0x9c,0x01,0xd4,0x00,0x90,0x01,0xd5,0x00,0x84,0x01,0xd7,0x00,0x78,0x01,0xd8,0x00,0x6c,0x01,0xd9,0x00,0x60,0x01,0xda,0x00,0x54,0x01,0xdb,0x00,0x48,0x01,0xdc,0x00,0x3c,0x01,0xdd,0x00,0x30,0x01,0xde,0x00,0x24,0x01,0xdf,0x00,  \
    0x18,0x01,0xe0,0x00,0x0d,0x01,0xe1,0x00,0x01,0x01,0xe1,0x00,0xf5,0x00,0xe2,0x00,0xe9,0x00,0xe3,0x00,0xdd,0x00,0xe4,0x00,0xd2,0x00,0xe4,0x00,0xc6,0x00,0xe5,0x00,0xba,0x00,0xe6,0x00,0xae,0x00,0xe6,0x00,0xa3,0x00,0xe7,0x00,0x97,0x00,0xe7,0x00,0x8b,0x00,0xe8,0x00,0x80,0x00,0xe8,0x00,0x74,0x00,0xe9,0x00,0x68,0x00,0xe9,0x00,0x5d,0x00,0xea,0x00,0x51,0x00,0xea,0x00,0x45,0x00,0xea,0x00,0x3a,0x00,0xeb,0x00,0x2e,0x00,0xeb,0x00,0x22,0x00,0xeb,0x00,0x17,0x00,  \
    0xeb,0x00,0x0b,0x00,0xec,0x00,0x00,0x00,0xec,0x00,0xf4,0xff,0xec,0x00,0xe8,0xff,0xec,0x00,0xdd,0xff,0xec,0x00,0xd1,0xff,0xec,0x00,0xc6,0xff,0xec,0x00,0xba,0xff,0xec,0x00,0xae,0xff,0xec,0x00,0xa3,0xff,0xec,0x00,0x97,0xff,0xec,0x00,0x8c,0xff,0xec,0x00,0x80,0xff,0xeb,0x00,0x74,0xff,0xeb,0x00,0x69,0xff,0xeb,0x00,0x5d,0xff,0xeb,0x00,0x51,0xff,0xea,0x00,0x46,0xff,0xea,0x00,0x3a,0xff,0xea,0x00,0x2e,0xff,0xe9,0x00,0x23,0xff,0xe9,0x00,0x17,0xff,0xe8,0x00,  \
    0x0b,0xff,0xe8,0x00,0x00,0xff,0xe7,0x00,0xf4,0xfe,0xe7,0x00,0xe8,0xfe,0xe6,0x00,0xdc,0xfe,0xe6,0x00,0xd1,0xfe,0xe5,0x00,0xc5,0xfe,0xe5,0x00,0xb9,0xfe,0xe4,0x00,0xad,0xfe,0xe3,0x00,0xa1,0xfe,0xe2,0x00,0x96,0xfe,0xe2,0x00,0x8a,0xfe,0xe1,0x00,0x7e,0xfe,0xe0,0x00,0x72,0xfe,0xdf,0x00,0x67,0xfe,0xde,0x00,0x5b,0xfe,0xdd,0x00,0x4f,0xfe,0xdc,0x00,0x43,0xfe,0xdc,0x00,0x38,0xfe,0xdb,0x00,0x2c,0xfe,0xd9,0x00,0x20,0xfe,0xd8,0x00,0x14,0xfe,0xd7,0x00,0x08,0xfe,  \
    0xd6,0x00,0xfd,0xfd,0xd5,0x00,0xf1,0xfd,0xd4,0x00,0xe5,0xfd,0xd3,0x00,0xd9,0xfd,0xd1,0x00,0xcd,0xfd,0xd0,0x00,0xc1,0xfd,0xcf,0x00,0xb5,0xfd,0xce,0x00,0xa9,0xfd,0xcc,0x00,0x9d,0xfd,0xcb,0x00,0x91,0xfd,0xc9,0x00,0x85,0xfd,0xc8,0x00,0x79,0xfd,0xc7,0x00,0x6d,0xfd,0xc5,0x00,0x61,0xfd,0xc4,0x00,0x55,0xfd,0xc2,0x00,0x49,0xfd,0xc0,0x00,0x3d,0xfd,0xbf,0x00,0x30,0xfd,0xbd,0x00,0x24,0xfd,0xbc,0x00,0x17,0xfd,0xba,0x00,0x0b,0xfd,0xb8,0x00,0xfe,0xfc,0xb7,0x00,  \
    0xf1,0xfc,0xb5,0x00,0xe4,0xfc,0xb3,0x00,0xd8,0xfc,0xb1,0x00,0xcb,0xfc,0xaf,0x00,0xbe,0xfc,0xae,0x00,0xb1,0xfc,0xac,0x00,0xa4,0xfc,0xaa,0x00,0x97,0xfc,0xa8,0x00,0x8a,0xfc,0xa6,0x00,0x7d,0xfc,0xa4,0x00,0x70,0xfc,0xa2,0x00,0x63,0xfc,0xa0,0x00,0x56,0xfc,0x9e,0x00,0x48,0xfc,0x9c,0x00,0x3b,0xfc,0x9a,0x00,0x2e,0xfc,0x98,0x00,0x20,0xfc,0x96,0x00,0x13,0xfc,0x93,0x00,0x05,0xfc,0x91,0x00,0xf8,0xfb,0x8f,0x00,0xea,0xfb,0x8d,0x00,0xdd,0xfb,0x8a,0x00,0xcf,0xfb,  \
    0x88,0x00,0xc1,0xfb,0x86,0x00,0xb4,0xfb,0x83,0x00,0xa6,0xfb,0x81,0x00,0x98,0xfb,0x7f,0x00,0x8b,0xfb,0x7c,0x00,0x7d,0xfb,0x7a,0x00,0x6f,0xfb,0x77,0x00,0x61,0xfb,0x75,0x00,0x53,0xfb,0x72,0x00,0x45,0xfb,0x70,0x00,0x37,0xfb,0x6d,0x00,0x29,0xfb,0x6b,0x00,0x1b,0xfb,0x68,0x00,0x0c,0xfb,0x65,0x00,0xfe,0xfa,0x63,0x00,0xf0,0xfa,0x60,0x00,0xe1,0xfa,0x5d,0x00,0xd3,0xfa,0x5b,0x00,0xc4,0xfa,0x58,0x00,0xb6,0xfa,0x55,0x00,0xa7,0xfa,0x53,0x00,0x98,0xfa,0x50,0x00,  \
    0x89,0xfa,0x4d,0x00,0x7b,0xfa,0x4a,0x00,0x6c,0xfa,0x47,0x00,0x5d,0xfa,0x44,0x00,0x4e,0xfa,0x41,0x00,0x3f,0xfa,0x3e,0x00,0x30,0xfa,0x3c,0x00,0x21,0xfa,0x39,0x00,0x11,0xfa,0x36,0x00,0x02,0xfa,0x33,0x00,0xf3,0xf9,0x30,0x00,0xe3,0xf9,0x2d,0x00,0xd4,0xf9,0x2a,0x00,0xc4,0xf9,0x26,0x00,0xb4,0xf9,0x23,0x00,0xa5,0xf9,0x20,0x00,0x95,0xf9,0x1d,0x00,0x85,0xf9,0x1a,0x00,0x75,0xf9,0x17,0x00,0x65,0xf9,0x14,0x00,0x55,0xf9,0x11,0x00,0x45,0xf9,0x0d,0x00,0x34,0xf9,  \
    0x0a,0x00,0x24,0xf9,0x07,0x00,0x14,0xf9,0x04,0x00,0x03,0xf9,0x01,0x00,0xf2,0xf8,0xfd,0xff,0xe2,0xf8,0xfa,0xff,0xd1,0xf8,0xf7,0xff,0xc0,0xf8,0xf3,0xff,0xaf,0xf8,0xf0,0xff,0x9e,0xf8,0xed,0xff,0x8d,0xf8,0xe9,0xff,0x7c,0xf8,0xe6,0xff,0x6b,0xf8,0xe3,0xff,0x5a,0xf8,0xdf,0xff,0x48,0xf8,0xdc,0xff,0x37,0xf8,0xd9,0xff,0x25,0xf8,0xd5,0xff,0x14,0xf8,0xd2,0xff,0x02,0xf8,0xce,0xff,0xf0,0xf7,0xcb,0xff,0xde,0xf7,0xc8,0xff,0xcc,0xf7,0xc4,0xff,0xba,0xf7,0xc1,0xff,  \
    0xa8,0xf7,0xbd,0xff,0x95,0xf7,0xba,0xff,0x83,0xf7,0xb6,0xff,0x71,0xf7,0xb3,0xff,0x5e,0xf7,0xb0,0xff,0x4b,0xf7,0xac,0xff,0x39,0xf7,0xa9,0xff,0x26,0xf7,0xa5,0xff,0x13,0xf7,0xa2,0xff,0x00,0xf7,0x9e,0xff,0xed,0xf6,0x9b,0xff,0xd9,0xf6,0x97,0xff,0xc6,0xf6,0x94,0xff,0xb2,0xf6,0x90,0xff,0x9f,0xf6,0x8d,0xff,0x8b,0xf6,0x89,0xff,0x78,0xf6,0x86,0xff,0x64,0xf6,0x83,0xff,0x50,0xf6,0x7f,0xff,0x3c,0xf6,0x7c,0xff,0x27,0xf6,0x78,0xff,0x13,0xf6,0x75,0xff,0xff,0xf5,  \
    0x71,0xff,0xea,0xf5,0x6e,0xff,0xd5,0xf5,0x6b,0xff,0xc1,0xf5,0x67,0xff,0xac,0xf5,0x64,0xff,0x97,0xf5,0x60,0xff,0x82,0xf5,0x5d,0xff,0x6d,0xf5,0x5a,0xff,0x57,0xf5,0x56,0xff,0x42,0xf5,0x53,0xff,0x2c,0xf5,0x50,0xff,0x17,0xf5,0x4c,0xff,0x01,0xf5,0x49,0xff,0xeb,0xf4,0x46,0xff,0xd5,0xf4,0x43,0xff,0xbf,0xf4,0x3f,0xff,0xa9,0xf4,0x3c,0xff,0x93,0xf4,0x39,0xff,0x7c,0xf4,0x36,0xff,0x66,0xf4,0x33,0xff,0x4f,0xf4,0x2f,0xff,0x38,0xf4,0x2c,0xff,0x22,0xf4,0x29,0xff,  \
    0x0b,0xf4,0x26,0xff,0xf3,0xf3,0x23,0xff,0xdc,0xf3,0x20,0xff,0xc5,0xf3,0x1d,0xff,0xae,0xf3,0x1a,0xff,0x96,0xf3,0x17,0xff,0x7e,0xf3,0x14,0xff,0x66,0xf3,0x11,0xff,0x4f,0xf3,0x0e,0xff,0x37,0xf3,0x0b,0xff,0x1e,0xf3,0x08,0xff,0x06,0xf3,0x05,0xff,0xee,0xf2,0x03,0xff,0xd5,0xf2,0x00,0xff,0xbc,0xf2,0xfd,0xfe,0xa3,0xf2,0xfa,0xfe,0x8a,0xf2,0xf8,0xfe,0x71,0xf2,0xf5,0xfe,0x58,0xf2,0xf3,0xfe,0x3f,0xf2,0xf0,0xfe,0x25,0xf2,0xee,0xfe,0x0c,0xf2,0xeb,0xfe,0xf2,0xf1,  \
    0xe9,0xfe,0xd8,0xf1,0xe6,0xfe,0xbe,0xf1,0xe4,0xfe,0xa4,0xf1,0xe2,0xfe,0x8a,0xf1,0xdf,0xfe,0x6f,0xf1,0xdd,0xfe,0x55,0xf1,0xdb,0xfe,0x3a,0xf1,0xd9,0xfe,0x20,0xf1,0xd7,0xfe,0x05,0xf1,0xd5,0xfe,0xea,0xf0,0xd3,0xfe,0xcf,0xf0,0xd1,0xfe,0xb3,0xf0,0xcf,0xfe,0x98,0xf0,0xcd,0xfe,0x7d,0xf0,0xcb,0xfe,0x61,0xf0,0xc9,0xfe,0x45,0xf0,0xc8,0xfe,0x29,0xf0,0xc6,0xfe,0x0d,0xf0,0xc4,0xfe,0xf1,0xef,0xc3,0xfe,0xd5,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x85,0xfe,0x36,0x10,0x86,0xfe,0x19,0x10,0x88,0xfe,0xfd,0x0f,0x8a,0xfe,0xe0,0x0f,0x8c,0xfe,0xc4,0x0f,0x8e,0xfe,0xa8,0x0f,0x90,0xfe,0x8c,0x0f,0x92,0xfe,0x71,0x0f,0x94,0xfe,0x55,0x0f,0x96,0xfe,0x3a,0x0f,  \
    0x98,0xfe,0x1e,0x0f,0x9b,0xfe,0x03,0x0f,0x9d,0xfe,0xe8,0x0e,0x9f,0xfe,0xcd,0x0e,0xa2,0xfe,0xb2,0x0e,0xa4,0xfe,0x97,0x0e,0xa7,0xfe,0x7c,0x0e,0xa9,0xfe,0x62,0x0e,0xac,0xfe,0x48,0x0e,0xae,0xfe,0x2d,0x0e,0xb1,0xfe,0x13,0x0e,0xb4,0xfe,0xf9,0x0d,0xb6,0xfe,0xdf,0x0d,0xb9,0xfe,0xc5,0x0d,0xbc,0xfe,0xab,0x0d,0xbf,0xfe,0x92,0x0d,0xc2,0xfe,0x78,0x0d,0xc5,0xfe,0x5f,0x0d,0xc7,0xfe,0x46,0x0d,0xca,0xfe,0x2d,0x0d,0xcd,0xfe,0x14,0x0d,0xd1,0xfe,0xfb,0x0c,0xd4,0xfe,  \
    0xe2,0x0c,0xd7,0xfe,0xc9,0x0c,0xda,0xfe,0xb1,0x0c,0xdd,0xfe,0x98,0x0c,0xe0,0xfe,0x80,0x0c,0xe3,0xfe,0x68,0x0c,0xe7,0xfe,0x50,0x0c,0xea,0xfe,0x38,0x0c,0xed,0xfe,0x20,0x0c,0xf1,0xfe,0x09,0x0c,0xf4,0xfe,0xf2,0x0b,0xf8,0xfe,0xda,0x0b,0xfb,0xfe,0xc3,0x0b,0xff,0xfe,0xac,0x0b,0x02,0xff,0x96,0x0b,0x06,0xff,0x7f,0x0b,0x0a,0xff,0x68,0x0b,0x0d,0xff,0x52,0x0b,0x11,0xff,0x3c,0x0b,0x15,0xff,0x25,0x0b,0x18,0xff,0x0f,0x0b,0x1c,0xff,0xf9,0x0a,0x20,0xff,0xe4,0x0a,  \
    0x24,0xff,0xce,0x0a,0x27,0xff,0xb8,0x0a,0x2b,0xff,0xa3,0x0a,0x2f,0xff,0x8d,0x0a,0x32,0xff,0x77,0x0a,0x36,0xff,0x62,0x0a,0x3a,0xff,0x4c,0x0a,0x3e,0xff,0x37,0x0a,0x41,0xff,0x22,0x0a,0x45,0xff,0x0d,0x0a,0x49,0xff,0xf8,0x09,0x4c,0xff,0xe3,0x09,0x50,0xff,0xce,0x09,0x54,0xff,0xb9,0x09,0x58,0xff,0xa5,0x09,0x5b,0xff,0x90,0x09,0x5f,0xff,0x7c,0x09,0x63,0xff,0x67,0x09,0x67,0xff,0x53,0x09,0x6a,0xff,0x3f,0x09,0x6e,0xff,0x2b,0x09,0x72,0xff,0x17,0x09,0x76,0xff,  \
    0x03,0x09,0x7a,0xff,0xf0,0x08,0x7d,0xff,0xdc,0x08,0x81,0xff,0xc9,0x08,0x85,0xff,0xb5,0x08,0x89,0xff,0xa2,0x08,0x8c,0xff,0x8f,0x08,0x90,0xff,0x7c,0x08,0x94,0xff,0x69,0x08,0x98,0xff,0x56,0x08,0x9b,0xff,0x43,0x08,0x9f,0xff,0x30,0x08,0xa3,0xff,0x1d,0x08,0xa7,0xff,0x0b,0x08,0xaa,0xff,0xf8,0x07,0xae,0xff,0xe6,0x07,0xb2,0xff,0xd4,0x07,0xb5,0xff,0xc2,0x07,0xb9,0xff,0xb0,0x07,0xbd,0xff,0x9e,0x07,0xc1,0xff,0x8c,0x07,0xc4,0xff,0x7a,0x07,0xc8,0xff,0x69,0x07,  \
    0xcc,0xff,0x57,0x07,0xcf,0xff,0x46,0x07,0xd3,0xff,0x34,0x07,0xd7,0xff,0x23,0x07,0xda,0xff,0x12,0x07,0xde,0xff,0x01,0x07,0xe1,0xff,0xef,0x06,0xe5,0xff,0xde,0x06,0xe8,0xff,0xce,0x06,0xec,0xff,0xbd,0x06,0xf0,0xff,0xac,0x06,0xf3,0xff,0x9b,0x06,0xf7,0xff,0x8b,0x06,0xfa,0xff,0x7a,0x06,0xfe,0xff,0x6a,0x06,0x01,0x00,0x59,0x06,0x04,0x00,0x49,0x06,0x08,0x00,0x39,0x06,0x0b,0x00,0x29,0x06,0x0f,0x00,0x19,0x06,0x12,0x00,0x09,0x06,0x15,0x00,0xf9,0x05,0x19,0x00,  \
    0xe9,0x05,0x1c,0x00,0xd9,0x05,0x1f,0x00,0xc9,0x05,0x23,0x00,0xba,0x05,0x26,0x00,0xaa,0x05,0x29,0x00,0x9a,0x05,0x2c,0x00,0x8b,0x05,0x2f,0x00,0x7c,0x05,0x33,0x00,0x6c,0x05,0x36,0x00,0x5d,0x05,0x39,0x00,0x4e,0x05,0x3c,0x00,0x3f,0x05,0x3f,0x00,0x30,0x05,0x42,0x00,0x21,0x05,0x45,0x00,0x12,0x05,0x48,0x00,0x02,0x05,0x4b,0x00,0xf3,0x04,0x4e,0x00,0xe4,0x04,0x51,0x00,0xd6,0x04,0x54,0x00,0xc7,0x04,0x57,0x00,0xb8,0x04,0x5a,0x00,0xa9,0x04,0x5d,0x00,0x9b,0x04,  \
    0x5f,0x00,0x8c,0x04,0x62,0x00,0x7d,0x04,0x65,0x00,0x6f,0x04,0x68,0x00,0x60,0x04,0x6a,0x00,0x52,0x04,0x6d,0x00,0x44,0x04,0x70,0x00,0x35,0x04,0x72,0x00,0x27,0x04,0x75,0x00,0x19,0x04,0x78,0x00,0x0b,0x04,0x7a,0x00,0xfd,0x03,0x7d,0x00,0xef,0x03,0x7f,0x00,0xe1,0x03,0x82,0x00,0xd3,0x03,0x84,0x00,0xc5,0x03,0x87,0x00,0xb7,0x03,0x89,0x00,0xaa,0x03,0x8b,0x00,0x9c,0x03,0x8e,0x00,0x8f,0x03,0x90,0x00,0x81,0x03,0x93,0x00,0x74,0x03,0x95,0x00,0x66,0x03,0x97,0x00,  \
    0x59,0x03,0x99,0x00,0x4c,0x03,0x9c,0x00,0x3e,0x03,0x9e,0x00,0x31,0x03,0xa0,0x00,0x24,0x03,0xa2,0x00,0x17,0x03,0xa4,0x00,0x0a,0x03,0xa6,0x00,0xfd,0x02,0xa8,0x00,0xf0,0x02,0xaa,0x00,0xe3,0x02,0xac,0x00,0xd6,0x02,0xae,0x00,0xc9,0x02,0xb0,0x00,0xbc,0x02,0xb2,0x00,0xaf,0x02,0xb4,0x00,0xa2,0x02,0xb6,0x00,0x96,0x02,0xb8,0x00,0x89,0x02,0xba,0x00,0x7c,0x02,0xbb,0x00,0x70,0x02,0xbd,0x00,0x63,0x02,0xbf,0x00,0x56,0x02,0xc1,0x00,0x4a,0x02,0xc2,0x00,0x3d,0x02,  \
    0xc4,0x00,0x31,0x02,0xc5,0x00,0x25,0x02,0xc7,0x00,0x18,0x02,0xc9,0x00,0x0c,0x02,0xca,0x00,0x00,0x02,0xcc,0x00,0xf3,0x01,0xcd,0x00,0xe7,0x01,0xce,0x00,0xdb,0x01,0xd0,0x00,0xcf,0x01,0xd1,0x00,0xc2,0x01,0xd3,0x00,0xb6,0x01,0xd4,0x00,0xaa,0x01,0xd5,0x00,0x9e,0x01,0xd6,0x00,0x92,0x01,0xd8,0x00,0x86,0x01,0xd9,0x00,0x7a,0x01,0xda,0x00,0x6e,0x01,0xdb,0x00,0x62,0x01,0xdc,0x00,0x56,0x01,0xdd,0x00,0x4a,0x01,0xde,0x00,0x3e,0x01,0xdf,0x00,0x32,0x01,0xe0,0x00,  \
    0x26,0x01,0xe1,0x00,0x1a,0x01,0xe2,0x00,0x0e,0x01,0xe3,0x00,0x02,0x01,0xe4,0x00,0xf6,0x00,0xe4,0x00,0xeb,0x00,0xe5,0x00,0xdf,0x00,0xe6,0x00,0xd3,0x00,0xe7,0x00,0xc7,0x00,0xe7,0x00,0xbb,0x00,0xe8,0x00,0xb0,0x00,0xe9,0x00,0xa4,0x00,0xe9,0x00,0x98,0x00,0xea,0x00,0x8c,0x00,0xea,0x00,0x80,0x00,0xeb,0x00,0x75,0x00,0xeb,0x00,0x69,0x00,0xec,0x00,0x5d,0x00,0xec,0x00,0x52,0x00,0xed,0x00,0x46,0x00,0xed,0x00,0x3a,0x00,0xed,0x00,0x2f,0x00,0xed,0x00,0x23,0x00,  \
    0xee,0x00,0x17,0x00,0xee,0x00,0x0c,0x00,0xee,0x00,0x00,0x00,0xee,0x00,0xf4,0xff,0xee,0x00,0xe9,0xff,0xee,0x00,0xdd,0xff,0xef,0x00,0xd1,0xff,0xef,0x00,0xc6,0xff,0xef,0x00,0xba,0xff,0xef,0x00,0xae,0xff,0xee,0x00,0xa3,0xff,0xee,0x00,0x97,0xff,0xee,0x00,0x8b,0xff,0xee,0x00,0x80,0xff,0xee,0x00,0x74,0xff,0xee,0x00,0x68,0xff,0xed,0x00,0x5d,0xff,0xed,0x00,0x51,0xff,0xed,0x00,0x45,0xff,0xed,0x00,0x39,0xff,0xec,0x00,0x2e,0xff,0xec,0x00,0x22,0xff,0xeb,0x00,  \
    0x16,0xff,0xeb,0x00,0x0a,0xff,0xea,0x00,0xff,0xfe,0xea,0x00,0xf3,0xfe,0xe9,0x00,0xe7,0xfe,0xe9,0x00,0xdb,0xfe,0xe8,0x00,0xcf,0xfe,0xe8,0x00,0xc4,0xfe,0xe7,0x00,0xb8,0xfe,0xe6,0x00,0xac,0xfe,0xe6,0x00,0xa0,0xfe,0xe5,0x00,0x94,0xfe,0xe4,0x00,0x88,0xfe,0xe3,0x00,0x7c,0xfe,0xe2,0x00,0x71,0xfe,0xe1,0x00,0x65,0xfe,0xe1,0x00,0x59,0xfe,0xe0,0x00,0x4d,0xfe,0xdf,0x00,0x41,0xfe,0xde,0x00,0x36,0xfe,0xdd,0x00,0x2a,0xfe,0xdc,0x00,0x1e,0xfe,0xdb,0x00,0x12,0xfe,  \
    0xd9,0x00,0x06,0xfe,0xd8,0x00,0xfa,0xfd,0xd7,0x00,0xef,0xfd,0xd6,0x00,0xe3,0xfd,0xd5,0x00,0xd7,0xfd,0xd3,0x00,0xcb,0xfd,0xd2,0x00,0xbf,0xfd,0xd1,0x00,0xb3,0xfd,0xcf,0x00,0xa7,0xfd,0xce,0x00,0x9b,0xfd,0xcd,0x00,0x8f,0xfd,0xcb,0x00,0x83,0xfd,0xca,0x00,0x77,0xfd,0xc8,0x00,0x6b,0xfd,0xc7,0x00,0x5f,0xfd,0xc5,0x00,0x53,0xfd,0xc4,0x00,0x46,0xfd,0xc2,0x00,0x3a,0xfd,0xc0,0x00,0x2e,0xfd,0xbf,0x00,0x21,0xfd,0xbd,0x00,0x14,0xfd,0xbb,0x00,0x08,0xfd,0xba,0x00,  \
    0xfb,0xfc,0xb8,0x00,0xee,0xfc,0xb6,0x00,0xe1,0xfc,0xb4,0x00,0xd5,0xfc,0xb2,0x00,0xc8,0xfc,0xb1,0x00,0xbb,0xfc,0xaf,0x00,0xae,0xfc,0xad,0x00,0xa1,0xfc,0xab,0x00,0x94,0xfc,0xa9,0x00,0x87,0xfc,0xa7,0x00,0x7a,0xfc,0xa5,0x00,0x6c,0xfc,0xa3,0x00,0x5f,0xfc,0xa1,0x00,0x52,0xfc,0x9f,0x00,0x45,0xfc,0x9c,0x00,0x37,0xfc,0x9a,0x00,0x2a,0xfc,0x98,0x00,0x1d,0xfc,0x96,0x00,0x0f,0xfc,0x94,0x00,0x01,0xfc,0x92,0x00,0xf4,0xfb,0x8f,0x00,0xe6,0xfb,0x8d,0x00,0xd9,0xfb,  \
    0x8b,0x00,0xcb,0xfb,0x88,0x00,0xbd,0xfb,0x86,0x00,0xb0,0xfb,0x83,0x00,0xa2,0xfb,0x81,0x00,0x94,0xfb,0x7f,0x00,0x87,0xfb,0x7c,0x00,0x79,0xfb,0x7a,0x00,0x6b,0xfb,0x77,0x00,0x5d,0xfb,0x75,0x00,0x4f,0xfb,0x72,0x00,0x41,0xfb,0x6f,0x00,0x33,0xfb,0x6d,0x00,0x25,0xfb,0x6a,0x00,0x16,0xfb,0x67,0x00,0x08,0xfb,0x65,0x00,0xfa,0xfa,0x62,0x00,0xeb,0xfa,0x5f,0x00,0xdd,0xfa,0x5d,0x00,0xce,0xfa,0x5a,0x00,0xc0,0xfa,0x57,0x00,0xb1,0xfa,0x54,0x00,0xa3,0xfa,0x51,0x00,  \
    0x94,0xfa,0x4e,0x00,0x85,0xfa,0x4c,0x00,0x76,0xfa,0x49,0x00,0x67,0xfa,0x46,0x00,0x58,0xfa,0x43,0x00,0x49,0xfa,0x40,0x00,0x3a,0xfa,0x3d,0x00,0x2b,0xfa,0x3a,0x00,0x1c,0xfa,0x37,0x00,0x0d,0xfa,0x34,0x00,0xfd,0xf9,0x31,0x00,0xee,0xf9,0x2d,0x00,0xde,0xf9,0x2a,0x00,0xcf,0xf9,0x27,0x00,0xbf,0xf9,0x24,0x00,0xb0,0xf9,0x21,0x00,0xa0,0xf9,0x1e,0x00,0x90,0xf9,0x1b,0x00,0x80,0xf9,0x17,0x00,0x70,0xf9,0x14,0x00,0x60,0xf9,0x11,0x00,0x50,0xf9,0x0e,0x00,0x40,0xf9,  \
    0x0a,0x00,0x30,0xf9,0x07,0x00,0x1f,0xf9,0x04,0x00,0x0f,0xf9,0x00,0x00,0xfe,0xf8,0xfd,0xff,0xee,0xf8,0xfa,0xff,0xdd,0xf8,0xf6,0xff,0xcc,0xf8,0xf3,0xff,0xbc,0xf8,0xf0,0xff,0xab,0xf8,0xec,0xff,0x9a,0xf8,0xe9,0xff,0x89,0xf8,0xe5,0xff,0x78,0xf8,0xe2,0xff,0x66,0xf8,0xdf,0xff,0x55,0xf8,0xdb,0xff,0x44,0xf8,0xd8,0xff,0x32,0xf8,0xd4,0xff,0x21,0xf8,0xd1,0xff,0x0f,0xf8,0xcd,0xff,0xfd,0xf7,0xca,0xff,0xeb,0xf7,0xc6,0xff,0xd9,0xf7,0xc3,0xff,0xc7,0xf7,0xbf,0xff,  \
    0xb5,0xf7,0xbc,0xff,0xa3,0xf7,0xb8,0xff,0x91,0xf7,0xb5,0xff,0x7e,0xf7,0xb1,0xff,0x6c,0xf7,0xad,0xff,0x59,0xf7,0xaa,0xff,0x47,0xf7,0xa6,0xff,0x34,0xf7,0xa3,0xff,0x21,0xf7,0x9f,0xff,0x0e,0xf7,0x9c,0xff,0xfb,0xf6,0x98,0xff,0xe8,0xf6,0x95,0xff,0xd5,0xf6,0x91,0xff,0xc2,0xf6,0x8d,0xff,0xae,0xf6,0x8a,0xff,0x9b,0xf6,0x86,0xff,0x87,0xf6,0x83,0xff,0x73,0xf6,0x7f,0xff,0x5f,0xf6,0x7c,0xff,0x4b,0xf6,0x78,0xff,0x37,0xf6,0x74,0xff,0x23,0xf6,0x71,0xff,0x0f,0xf6,  \
    0x6d,0xff,0xfa,0xf5,0x6a,0xff,0xe6,0xf5,0x66,0xff,0xd1,0xf5,0x63,0xff,0xbc,0xf5,0x5f,0xff,0xa8,0xf5,0x5c,0xff,0x93,0xf5,0x58,0xff,0x7e,0xf5,0x55,0xff,0x68,0xf5,0x52,0xff,0x53,0xf5,0x4e,0xff,0x3e,0xf5,0x4b,0xff,0x28,0xf5,0x47,0xff,0x13,0xf5,0x44,0xff,0xfd,0xf4,0x40,0xff,0xe7,0xf4,0x3d,0xff,0xd1,0xf4,0x3a,0xff,0xbb,0xf4,0x36,0xff,0xa5,0xf4,0x33,0xff,0x8f,0xf4,0x30,0xff,0x78,0xf4,0x2c,0xff,0x62,0xf4,0x29,0xff,0x4b,0xf4,0x26,0xff,0x34,0xf4,0x23,0xff,  \
    0x1e,0xf4,0x1f,0xff,0x07,0xf4,0x1c,0xff,0xf0,0xf3,0x19,0xff,0xd8,0xf3,0x16,0xff,0xc1,0xf3,0x13,0xff,0xaa,0xf3,0x10,0xff,0x92,0xf3,0x0c,0xff,0x7b,0xf3,0x09,0xff,0x63,0xf3,0x06,0xff,0x4b,0xf3,0x03,0xff,0x33,0xf3,0x00,0xff,0x1b,0xf3,0xfd,0xfe,0x02,0xf3,0xfb,0xfe,0xea,0xf2,0xf8,0xfe,0xd1,0xf2,0xf5,0xfe,0xb9,0xf2,0xf2,0xfe,0xa0,0xf2,0xef,0xfe,0x87,0xf2,0xed,0xfe,0x6e,0xf2,0xea,0xfe,0x55,0xf2,0xe7,0xfe,0x3b,0xf2,0xe5,0xfe,0x22,0xf2,0xe2,0xfe,0x08,0xf2,  \
    0xe0,0xfe,0xef,0xf1,0xdd,0xfe,0xd5,0xf1,0xdb,0xfe,0xbb,0xf1,0xd8,0xfe,0xa1,0xf1,0xd6,0xfe,0x86,0xf1,0xd3,0xfe,0x6c,0xf1,0xd1,0xfe,0x52,0xf1,0xcf,0xfe,0x37,0xf1,0xcd,0xfe,0x1c,0xf1,0xcb,0xfe,0x01,0xf1,0xc8,0xfe,0xe6,0xf0,0xc6,0xfe,0xcb,0xf0,0xc4,0xfe,0xb0,0xf0,0xc2,0xfe,0x95,0xf0,0xc0,0xfe,0x79,0xf0,0xbe,0xfe,0x5e,0xf0,0xbd,0xfe,0x42,0xf0,0xbb,0xfe,0x26,0xf0,0xb9,0xfe,0x0a,0xf0,0xb7,0xfe,0xee,0xef,0xb6,0xfe,0xd2,0xef,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x79,0xfe,0x39,0x10,0x7b,0xfe,0x1c,0x10,0x7d,0xfe,0x00,0x10,0x7f,0xfe,0xe4,0x0f,0x80,0xfe,0xc7,0x0f,0x82,0xfe,0xab,0x0f,0x85,0xfe,0x90,0x0f,0x87,0xfe,0x74,0x0f,0x89,0xfe,0x58,0x0f,  \
    0x8b,0xfe,0x3d,0x0f,0x8d,0xfe,0x21,0x0f,0x90,0xfe,0x06,0x0f,0x92,0xfe,0xeb,0x0e,0x94,0xfe,0xd0,0x0e,0x97,0xfe,0xb5,0x0e,0x99,0xfe,0x9a,0x0e,0x9c,0xfe,0x80,0x0e,0x9e,0xfe,0x65,0x0e,0xa1,0xfe,0x4b,0x0e,0xa4,0xfe,0x31,0x0e,0xa6,0xfe,0x16,0x0e,0xa9,0xfe,0xfc,0x0d,0xac,0xfe,0xe2,0x0d,0xaf,0xfe,0xc9,0x0d,0xb2,0xfe,0xaf,0x0d,0xb5,0xfe,0x95,0x0d,0xb7,0xfe,0x7c,0x0d,0xba,0xfe,0x63,0x0d,0xbd,0xfe,0x49,0x0d,0xc1,0xfe,0x30,0x0d,0xc4,0xfe,0x17,0x0d,0xc7,0xfe,  \
    0xfe,0x0c,0xca,0xfe,0xe6,0x0c,0xcd,0xfe,0xcd,0x0c,0xd0,0xfe,0xb4,0x0c,0xd4,0xfe,0x9c,0x0c,0xd7,0xfe,0x84,0x0c,0xda,0xfe,0x6b,0x0c,0xdd,0xfe,0x53,0x0c,0xe1,0xfe,0x3b,0x0c,0xe4,0xfe,0x24,0x0c,0xe8,0xfe,0x0c,0x0c,0xeb,0xfe,0xf5,0x0b,0xef,0xfe,0xde,0x0b,0xf3,0xfe,0xc7,0x0b,0xf6,0xfe,0xb0,0x0b,0xfa,0xfe,0x99,0x0b,0xfe,0xfe,0x83,0x0b,0x01,0xff,0x6c,0x0b,0x05,0xff,0x56,0x0b,0x09,0xff,0x40,0x0b,0x0d,0xff,0x29,0x0b,0x10,0xff,0x13,0x0b,0x14,0xff,0xfd,0x0a,  \
    0x18,0xff,0xe8,0x0a,0x1c,0xff,0xd2,0x0a,0x20,0xff,0xbc,0x0a,0x24,0xff,0xa7,0x0a,0x27,0xff,0x91,0x0a,0x2b,0xff,0x7c,0x0a,0x2f,0xff,0x66,0x0a,0x33,0xff,0x51,0x0a,0x37,0xff,0x3b,0x0a,0x3a,0xff,0x26,0x0a,0x3e,0xff,0x11,0x0a,0x42,0xff,0xfc,0x09,0x46,0xff,0xe7,0x09,0x4a,0xff,0xd2,0x09,0x4d,0xff,0xbe,0x09,0x51,0xff,0xa9,0x09,0x55,0xff,0x95,0x09,0x59,0xff,0x80,0x09,0x5d,0xff,0x6c,0x09,0x61,0xff,0x58,0x09,0x64,0xff,0x44,0x09,0x68,0xff,0x30,0x09,0x6c,0xff,  \
    0x1c,0x09,0x70,0xff,0x08,0x09,0x74,0xff,0xf4,0x08,0x78,0xff,0xe1,0x08,0x7c,0xff,0xcd,0x08,0x7f,0xff,0xba,0x08,0x83,0xff,0xa7,0x08,0x87,0xff,0x93,0x08,0x8b,0xff,0x80,0x08,0x8f,0xff,0x6d,0x08,0x93,0xff,0x5a,0x08,0x97,0xff,0x47,0x08,0x9a,0xff,0x35,0x08,0x9e,0xff,0x22,0x08,0xa2,0xff,0x10,0x08,0xa6,0xff,0xfd,0x07,0xaa,0xff,0xeb,0x07,0xad,0xff,0xd8,0x07,0xb1,0xff,0xc6,0x07,0xb5,0xff,0xb4,0x07,0xb9,0xff,0xa2,0x07,0xbd,0xff,0x91,0x07,0xc0,0xff,0x7f,0x07,  \
    0xc4,0xff,0x6d,0x07,0xc8,0xff,0x5c,0x07,0xcc,0xff,0x4a,0x07,0xcf,0xff,0x39,0x07,0xd3,0xff,0x28,0x07,0xd7,0xff,0x16,0x07,0xda,0xff,0x05,0x07,0xde,0xff,0xf4,0x06,0xe2,0xff,0xe3,0x06,0xe5,0xff,0xd2,0x06,0xe9,0xff,0xc2,0x06,0xed,0xff,0xb1,0x06,0xf0,0xff,0xa0,0x06,0xf4,0xff,0x90,0x06,0xf7,0xff,0x7f,0x06,0xfb,0xff,0x6f,0x06,0xff,0xff,0x5e,0x06,0x02,0x00,0x4e,0x06,0x06,0x00,0x3e,0x06,0x09,0x00,0x2e,0x06,0x0c,0x00,0x1d,0x06,0x10,0x00,0x0d,0x06,0x13,0x00,  \
    0xfd,0x05,0x17,0x00,0xee,0x05,0x1a,0x00,0xde,0x05,0x1d,0x00,0xce,0x05,0x21,0x00,0xbe,0x05,0x24,0x00,0xaf,0x05,0x27,0x00,0x9f,0x05,0x2b,0x00,0x90,0x05,0x2e,0x00,0x80,0x05,0x31,0x00,0x71,0x05,0x34,0x00,0x62,0x05,0x38,0x00,0x52,0x05,0x3b,0x00,0x43,0x05,0x3e,0x00,0x34,0x05,0x41,0x00,0x25,0x05,0x44,0x00,0x16,0x05,0x47,0x00,0x07,0x05,0x4a,0x00,0xf8,0x04,0x4d,0x00,0xe9,0x04,0x50,0x00,0xda,0x04,0x53,0x00,0xcb,0x04,0x56,0x00,0xbc,0x04,0x59,0x00,0xae,0x04,  \
    0x5c,0x00,0x9f,0x04,0x5f,0x00,0x90,0x04,0x62,0x00,0x82,0x04,0x65,0x00,0x73,0x04,0x67,0x00,0x65,0x04,0x6a,0x00,0x56,0x04,0x6d,0x00,0x48,0x04,0x70,0x00,0x3a,0x04,0x72,0x00,0x2b,0x04,0x75,0x00,0x1d,0x04,0x78,0x00,0x0f,0x04,0x7a,0x00,0x01,0x04,0x7d,0x00,0xf3,0x03,0x7f,0x00,0xe5,0x03,0x82,0x00,0xd7,0x03,0x84,0x00,0xc9,0x03,0x87,0x00,0xbb,0x03,0x89,0x00,0xae,0x03,0x8c,0x00,0xa0,0x03,0x8e,0x00,0x92,0x03,0x91,0x00,0x85,0x03,0x93,0x00,0x77,0x03,0x95,0x00,  \
    0x6a,0x03,0x98,0x00,0x5d,0x03,0x9a,0x00,0x4f,0x03,0x9c,0x00,0x42,0x03,0x9f,0x00,0x35,0x03,0xa1,0x00,0x27,0x03,0xa3,0x00,0x1a,0x03,0xa5,0x00,0x0d,0x03,0xa7,0x00,0x00,0x03,0xa9,0x00,0xf3,0x02,0xab,0x00,0xe6,0x02,0xad,0x00,0xd9,0x02,0xaf,0x00,0xcc,0x02,0xb1,0x00,0xbf,0x02,0xb3,0x00,0xb2,0x02,0xb5,0x00,0xa5,0x02,0xb7,0x00,0x99,0x02,0xb9,0x00,0x8c,0x02,0xbb,0x00,0x7f,0x02,0xbd,0x00,0x72,0x02,0xbf,0x00,0x66,0x02,0xc0,0x00,0x59,0x02,0xc2,0x00,0x4d,0x02,  \
    0xc4,0x00,0x40,0x02,0xc5,0x00,0x34,0x02,0xc7,0x00,0x27,0x02,0xc9,0x00,0x1b,0x02,0xca,0x00,0x0f,0x02,0xcc,0x00,0x02,0x02,0xcd,0x00,0xf6,0x01,0xcf,0x00,0xea,0x01,0xd0,0x00,0xdd,0x01,0xd2,0x00,0xd1,0x01,0xd3,0x00,0xc5,0x01,0xd4,0x00,0xb9,0x01,0xd6,0x00,0xac,0x01,0xd7,0x00,0xa0,0x01,0xd8,0x00,0x94,0x01,0xda,0x00,0x88,0x01,0xdb,0x00,0x7c,0x01,0xdc,0x00,0x70,0x01,0xdd,0x00,0x64,0x01,0xde,0x00,0x58,0x01,0xdf,0x00,0x4c,0x01,0xe0,0x00,0x40,0x01,0xe1,0x00,  \
    0x34,0x01,0xe2,0x00,0x28,0x01,0xe3,0x00,0x1c,0x01,0xe4,0x00,0x10,0x01,0xe5,0x00,0x04,0x01,0xe6,0x00,0xf8,0x00,0xe7,0x00,0xec,0x00,0xe8,0x00,0xe0,0x00,0xe8,0x00,0xd4,0x00,0xe9,0x00,0xc8,0x00,0xea,0x00,0xbd,0x00,0xea,0x00,0xb1,0x00,0xeb,0x00,0xa5,0x00,0xec,0x00,0x99,0x00,0xec,0x00,0x8d,0x00,0xed,0x00,0x81,0x00,0xed,0x00,0x76,0x00,0xee,0x00,0x6a,0x00,0xee,0x00,0x5e,0x00,0xef,0x00,0x52,0x00,0xef,0x00,0x47,0x00,0xef,0x00,0x3b,0x00,0xf0,0x00,0x2f,0x00,  \
    0xf0,0x00,0x23,0x00,0xf0,0x00,0x18,0x00,0xf0,0x00,0x0c,0x00,0xf1,0x00,0x00,0x00,0xf1,0x00,0xf4,0xff,0xf1,0x00,0xe9,0xff,0xf1,0x00,0xdd,0xff,0xf1,0x00,0xd1,0xff,0xf1,0x00,0xc6,0xff,0xf1,0x00,0xba,0xff,0xf1,0x00,0xae,0xff,0xf1,0x00,0xa3,0xff,0xf1,0x00,0x97,0xff,0xf1,0x00,0x8b,0xff,0xf1,0x00,0x7f,0xff,0xf0,0x00,0x74,0xff,0xf0,0x00,0x68,0xff,0xf0,0x00,0x5c,0xff,0xf0,0x00,0x50,0xff,0xef,0x00,0x45,0xff,0xef,0x00,0x39,0xff,0xef,0x00,0x2d,0xff,0xee,0x00,  \
    0x21,0xff,0xee,0x00,0x15,0xff,0xed,0x00,0x0a,0xff,0xed,0x00,0xfe,0xfe,0xec,0x00,0xf2,0xfe,0xec,0x00,0xe6,0xfe,0xeb,0x00,0xda,0xfe,0xea,0x00,0xce,0xfe,0xea,0x00,0xc2,0xfe,0xe9,0x00,0xb6,0xfe,0xe8,0x00,0xaa,0xfe,0xe8,0x00,0x9f,0xfe,0xe7,0x00,0x93,0xfe,0xe6,0x00,0x87,0xfe,0xe5,0x00,0x7b,0xfe,0xe4,0x00,0x6f,0xfe,0xe4,0x00,0x63,0xfe,0xe3,0x00,0x57,0xfe,0xe2,0x00,0x4b,0xfe,0xe1,0x00,0x40,0xfe,0xe0,0x00,0x34,0xfe,0xdf,0x00,0x28,0xfe,0xde,0x00,0x1c,0xfe,  \
    0xdc,0x00,0x10,0xfe,0xdb,0x00,0x04,0xfe,0xda,0x00,0xf8,0xfd,0xd9,0x00,0xec,0xfd,0xd8,0x00,0xe0,0xfd,0xd6,0x00,0xd5,0xfd,0xd5,0x00,0xc9,0xfd,0xd4,0x00,0xbd,0xfd,0xd2,0x00,0xb1,0xfd,0xd1,0x00,0xa5,0xfd,0xd0,0x00,0x99,0xfd,0xce,0x00,0x8c,0xfd,0xcd,0x00,0x80,0xfd,0xcb,0x00,0x74,0xfd,0xca,0x00,0x68,0xfd,0xc8,0x00,0x5c,0xfd,0xc7,0x00,0x50,0xfd,0xc5,0x00,0x44,0xfd,0xc3,0x00,0x37,0xfd,0xc2,0x00,0x2b,0xfd,0xc0,0x00,0x1e,0xfd,0xbe,0x00,0x12,0xfd,0xbc,0x00,  \
    0x05,0xfd,0xbb,0x00,0xf8,0xfc,0xb9,0x00,0xeb,0xfc,0xb7,0x00,0xde,0xfc,0xb5,0x00,0xd1,0xfc,0xb3,0x00,0xc5,0xfc,0xb1,0x00,0xb8,0xfc,0xb0,0x00,0xab,0xfc,0xae,0x00,0x9e,0xfc,0xac,0x00,0x90,0xfc,0xaa,0x00,0x83,0xfc,0xa8,0x00,0x76,0xfc,0xa6,0x00,0x69,0xfc,0xa3,0x00,0x5c,0xfc,0xa1,0x00,0x4e,0xfc,0x9f,0x00,0x41,0xfc,0x9d,0x00,0x34,0xfc,0x9b,0x00,0x26,0xfc,0x99,0x00,0x19,0xfc,0x96,0x00,0x0b,0xfc,0x94,0x00,0xfe,0xfb,0x92,0x00,0xf0,0xfb,0x8f,0x00,0xe2,0xfb,  \
    0x8d,0x00,0xd5,0xfb,0x8b,0x00,0xc7,0xfb,0x88,0x00,0xb9,0xfb,0x86,0x00,0xac,0xfb,0x83,0x00,0x9e,0xfb,0x81,0x00,0x90,0xfb,0x7e,0x00,0x82,0xfb,0x7c,0x00,0x75,0xfb,0x79,0x00,0x67,0xfb,0x77,0x00,0x59,0xfb,0x74,0x00,0x4b,0xfb,0x71,0x00,0x3d,0xfb,0x6f,0x00,0x2e,0xfb,0x6c,0x00,0x20,0xfb,0x69,0x00,0x12,0xfb,0x67,0x00,0x04,0xfb,0x64,0x00,0xf5,0xfa,0x61,0x00,0xe7,0xfa,0x5e,0x00,0xd8,0xfa,0x5b,0x00,0xca,0xfa,0x59,0x00,0xbb,0xfa,0x56,0x00,0xad,0xfa,0x53,0x00,  \
    0x9e,0xfa,0x50,0x00,0x8f,0xfa,0x4d,0x00,0x80,0xfa,0x4a,0x00,0x72,0xfa,0x47,0x00,0x63,0xfa,0x44,0x00,0x54,0xfa,0x41,0x00,0x45,0xfa,0x3e,0x00,0x36,0xfa,0x3b,0x00,0x26,0xfa,0x38,0x00,0x17,0xfa,0x35,0x00,0x08,0xfa,0x32,0x00,0xf9,0xf9,0x2e,0x00,0xe9,0xf9,0x2b,0x00,0xda,0xf9,0x28,0x00,0xca,0xf9,0x25,0x00,0xbb,0xf9,0x22,0x00,0xab,0xf9,0x1e,0x00,0x9b,0xf9,0x1b,0x00,0x8b,0xf9,0x18,0x00,0x7b,0xf9,0x15,0x00,0x6b,0xf9,0x11,0x00,0x5b,0xf9,0x0e,0x00,0x4b,0xf9,  \
    0x0b,0x00,0x3b,0xf9,0x07,0x00,0x2b,0xf9,0x04,0x00,0x1a,0xf9,0x00,0x00,0x0a,0xf9,0xfd,0xff,0xfa,0xf8,0xfa,0xff,0xe9,0xf8,0xf6,0xff,0xd8,0xf8,0xf3,0xff,0xc8,0xf8,0xef,0xff,0xb7,0xf8,0xec,0xff,0xa6,0xf8,0xe8,0xff,0x95,0xf8,0xe5,0xff,0x84,0xf8,0xe1,0xff,0x73,0xf8,0xde,0xff,0x62,0xf8,0xda,0xff,0x50,0xf8,0xd7,0xff,0x3f,0xf8,0xd3,0xff,0x2d,0xf8,0xd0,0xff,0x1c,0xf8,0xcc,0xff,0x0a,0xf8,0xc8,0xff,0xf8,0xf7,0xc5,0xff,0xe7,0xf7,0xc1,0xff,0xd5,0xf7,0xbe,0xff,  \
    0xc3,0xf7,0xba,0xff,0xb1,0xf7,0xb6,0xff,0x9e,0xf7,0xb3,0xff,0x8c,0xf7,0xaf,0xff,0x7a,0xf7,0xab,0xff,0x67,0xf7,0xa8,0xff,0x55,0xf7,0xa4,0xff,0x42,0xf7,0xa0,0xff,0x2f,0xf7,0x9d,0xff,0x1d,0xf7,0x99,0xff,0x0a,0xf7,0x96,0xff,0xf7,0xf6,0x92,0xff,0xe4,0xf6,0x8e,0xff,0xd0,0xf6,0x8b,0xff,0xbd,0xf6,0x87,0xff,0xaa,0xf6,0x83,0xff,0x96,0xf6,0x80,0xff,0x82,0xf6,0x7c,0xff,0x6f,0xf6,0x78,0xff,0x5b,0xf6,0x75,0xff,0x47,0xf6,0x71,0xff,0x33,0xf6,0x6d,0xff,0x1f,0xf6,  \
    0x6a,0xff,0x0a,0xf6,0x66,0xff,0xf6,0xf5,0x62,0xff,0xe2,0xf5,0x5f,0xff,0xcd,0xf5,0x5b,0xff,0xb8,0xf5,0x58,0xff,0xa3,0xf5,0x54,0xff,0x8e,0xf5,0x50,0xff,0x79,0xf5,0x4d,0xff,0x64,0xf5,0x49,0xff,0x4f,0xf5,0x46,0xff,0x3a,0xf5,0x42,0xff,0x24,0xf5,0x3f,0xff,0x0e,0xf5,0x3b,0xff,0xf9,0xf4,0x38,0xff,0xe3,0xf4,0x34,0xff,0xcd,0xf4,0x31,0xff,0xb7,0xf4,0x2d,0xff,0xa1,0xf4,0x2a,0xff,0x8b,0xf4,0x26,0xff,0x74,0xf4,0x23,0xff,0x5e,0xf4,0x20,0xff,0x47,0xf4,0x1c,0xff,  \
    0x31,0xf4,0x19,0xff,0x1a,0xf4,0x16,0xff,0x03,0xf4,0x12,0xff,0xec,0xf3,0x0f,0xff,0xd5,0xf3,0x0c,0xff,0xbd,0xf3,0x09,0xff,0xa6,0xf3,0x05,0xff,0x8e,0xf3,0x02,0xff,0x77,0xf3,0xff,0xfe,0x5f,0xf3,0xfc,0xfe,0x47,0xf3,0xf9,0xfe,0x2f,0xf3,0xf6,0xfe,0x17,0xf3,0xf3,0xfe,0xff,0xf2,0xf0,0xfe,0xe6,0xf2,0xed,0xfe,0xce,0xf2,0xea,0xfe,0xb5,0xf2,0xe7,0xfe,0x9c,0xf2,0xe4,0xfe,0x83,0xf2,0xe1,0xfe,0x6a,0xf2,0xdf,0xfe,0x51,0xf2,0xdc,0xfe,0x38,0xf2,0xd9,0xfe,0x1e,0xf2,  \
    0xd6,0xfe,0x05,0xf2,0xd4,0xfe,0xeb,0xf1,0xd1,0xfe,0xd1,0xf1,0xcf,0xfe,0xb7,0xf1,0xcc,0xfe,0x9d,0xf1,0xca,0xfe,0x83,0xf1,0xc7,0xfe,0x69,0xf1,0xc5,0xfe,0x4e,0xf1,0xc3,0xfe,0x34,0xf1,0xc0,0xfe,0x19,0xf1,0xbe,0xfe,0xfe,0xf0,0xbc,0xfe,0xe3,0xf0,0xba,0xfe,0xc8,0xf0,0xb8,0xfe,0xad,0xf0,0xb6,0xfe,0x92,0xf0,0xb4,0xfe,0x76,0xf0,0xb2,0xfe,0x5b,0xf0,0xb0,0xfe,0x3f,0xf0,0xae,0xfe,0x23,0xf0,0xac,0xfe,0x07,0xf0,0xaa,0xfe,0xeb,0xef,0xa9,0xfe,0xcf,0xef,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6d,0xfe,0x3c,0x10,0x6f,0xfe,0x1f,0x10,0x71,0xfe,0x03,0x10,0x73,0xfe,0xe7,0x0f,0x75,0xfe,0xcb,0x0f,0x77,0xfe,0xaf,0x0f,0x79,0xfe,0x93,0x0f,0x7b,0xfe,0x77,0x0f,  \
    0x7e,0xfe,0x5c,0x0f,0x80,0xfe,0x40,0x0f,0x82,0xfe,0x25,0x0f,0x84,0xfe,0x09,0x0f,0x87,0xfe,0xee,0x0e,0x89,0xfe,0xd3,0x0e,0x8c,0xfe,0xb9,0x0e,0x8e,0xfe,0x9e,0x0e,0x91,0xfe,0x83,0x0e,0x94,0xfe,0x69,0x0e,0x96,0xfe,0x4e,0x0e,0x99,0xfe,0x34,0x0e,0x9c,0xfe,0x1a,0x0e,0x9f,0xfe,0x00,0x0e,0xa2,0xfe,0xe6,0x0d,0xa4,0xfe,0xcc,0x0d,0xa7,0xfe,0xb2,0x0d,0xaa,0xfe,0x99,0x0d,0xad,0xfe,0x7f,0x0d,0xb0,0xfe,0x66,0x0d,0xb4,0xfe,0x4d,0x0d,0xb7,0xfe,0x34,0x0d,0xba,0xfe,  \
    0x1b,0x0d,0xbd,0xfe,0x02,0x0d,0xc0,0xfe,0xe9,0x0c,0xc4,0xfe,0xd1,0x0c,0xc7,0xfe,0xb8,0x0c,0xca,0xfe,0xa0,0x0c,0xcd,0xfe,0x87,0x0c,0xd1,0xfe,0x6f,0x0c,0xd4,0xfe,0x57,0x0c,0xd8,0xfe,0x3f,0x0c,0xdb,0xfe,0x28,0x0c,0xdf,0xfe,0x10,0x0c,0xe3,0xfe,0xf9,0x0b,0xe6,0xfe,0xe2,0x0b,0xea,0xfe,0xcb,0x0b,0xee,0xfe,0xb4,0x0b,0xf2,0xfe,0x9d,0x0b,0xf5,0xfe,0x87,0x0b,0xf9,0xfe,0x70,0x0b,0xfd,0xfe,0x5a,0x0b,0x01,0xff,0x44,0x0b,0x05,0xff,0x2e,0x0b,0x09,0xff,0x18,0x0b,  \
    0x0c,0xff,0x02,0x0b,0x10,0xff,0xec,0x0a,0x14,0xff,0xd6,0x0a,0x18,0xff,0xc1,0x0a,0x1c,0xff,0xab,0x0a,0x20,0xff,0x96,0x0a,0x24,0xff,0x80,0x0a,0x28,0xff,0x6a,0x0a,0x2c,0xff,0x55,0x0a,0x30,0xff,0x40,0x0a,0x33,0xff,0x2b,0x0a,0x37,0xff,0x15,0x0a,0x3b,0xff,0x00,0x0a,0x3f,0xff,0xec,0x09,0x43,0xff,0xd7,0x09,0x47,0xff,0xc2,0x09,0x4b,0xff,0xae,0x09,0x4f,0xff,0x99,0x09,0x53,0xff,0x85,0x09,0x57,0xff,0x70,0x09,0x5b,0xff,0x5c,0x09,0x5f,0xff,0x48,0x09,0x62,0xff,  \
    0x34,0x09,0x66,0xff,0x20,0x09,0x6a,0xff,0x0d,0x09,0x6e,0xff,0xf9,0x08,0x72,0xff,0xe5,0x08,0x76,0xff,0xd2,0x08,0x7a,0xff,0xbf,0x08,0x7e,0xff,0xab,0x08,0x82,0xff,0x98,0x08,0x86,0xff,0x85,0x08,0x8a,0xff,0x72,0x08,0x8e,0xff,0x5f,0x08,0x92,0xff,0x4c,0x08,0x96,0xff,0x39,0x08,0x99,0xff,0x27,0x08,0x9d,0xff,0x14,0x08,0xa1,0xff,0x02,0x08,0xa5,0xff,0xef,0x07,0xa9,0xff,0xdd,0x07,0xad,0xff,0xcb,0x07,0xb1,0xff,0xb9,0x07,0xb5,0xff,0xa7,0x07,0xb9,0xff,0x96,0x07,  \
    0xbc,0xff,0x84,0x07,0xc0,0xff,0x72,0x07,0xc4,0xff,0x61,0x07,0xc8,0xff,0x4f,0x07,0xcc,0xff,0x3e,0x07,0xd0,0xff,0x2d,0x07,0xd3,0xff,0x1b,0x07,0xd7,0xff,0x0a,0x07,0xdb,0xff,0xf9,0x06,0xdf,0xff,0xe8,0x06,0xe2,0xff,0xd7,0x06,0xe6,0xff,0xc7,0x06,0xea,0xff,0xb6,0x06,0xed,0xff,0xa5,0x06,0xf1,0xff,0x95,0x06,0xf5,0xff,0x84,0x06,0xf8,0xff,0x74,0x06,0xfc,0xff,0x63,0x06,0x00,0x00,0x53,0x06,0x03,0x00,0x43,0x06,0x07,0x00,0x32,0x06,0x0a,0x00,0x22,0x06,0x0e,0x00,  \
    0x12,0x06,0x11,0x00,0x02,0x06,0x15,0x00,0xf3,0x05,0x18,0x00,0xe3,0x05,0x1c,0x00,0xd3,0x05,0x1f,0x00,0xc3,0x05,0x22,0x00,0xb4,0x05,0x26,0x00,0xa4,0x05,0x29,0x00,0x95,0x05,0x2c,0x00,0x85,0x05,0x30,0x00,0x76,0x05,0x33,0x00,0x67,0x05,0x36,0x00,0x57,0x05,0x3a,0x00,0x48,0x05,0x3d,0x00,0x39,0x05,0x40,0x00,0x2a,0x05,0x43,0x00,0x1b,0x05,0x46,0x00,0x0c,0x05,0x49,0x00,0xfd,0x04,0x4c,0x00,0xee,0x04,0x4f,0x00,0xdf,0x04,0x52,0x00,0xd0,0x04,0x55,0x00,0xc1,0x04,  \
    0x58,0x00,0xb2,0x04,0x5b,0x00,0xa4,0x04,0x5e,0x00,0x95,0x04,0x61,0x00,0x86,0x04,0x64,0x00,0x78,0x04,0x67,0x00,0x69,0x04,0x6a,0x00,0x5b,0x04,0x6d,0x00,0x4c,0x04,0x6f,0x00,0x3e,0x04,0x72,0x00,0x30,0x04,0x75,0x00,0x21,0x04,0x77,0x00,0x13,0x04,0x7a,0x00,0x05,0x04,0x7d,0x00,0xf7,0x03,0x7f,0x00,0xe9,0x03,0x82,0x00,0xdb,0x03,0x85,0x00,0xcd,0x03,0x87,0x00,0xbf,0x03,0x8a,0x00,0xb2,0x03,0x8c,0x00,0xa4,0x03,0x8f,0x00,0x96,0x03,0x91,0x00,0x89,0x03,0x94,0x00,  \
    0x7b,0x03,0x96,0x00,0x6e,0x03,0x98,0x00,0x60,0x03,0x9b,0x00,0x53,0x03,0x9d,0x00,0x46,0x03,0x9f,0x00,0x38,0x03,0xa2,0x00,0x2b,0x03,0xa4,0x00,0x1e,0x03,0xa6,0x00,0x11,0x03,0xa8,0x00,0x04,0x03,0xaa,0x00,0xf6,0x02,0xac,0x00,0xe9,0x02,0xae,0x00,0xdc,0x02,0xb1,0x00,0xcf,0x02,0xb3,0x00,0xc2,0x02,0xb5,0x00,0xb6,0x02,0xb6,0x00,0xa9,0x02,0xb8,0x00,0x9c,0x02,0xba,0x00,0x8f,0x02,0xbc,0x00,0x82,0x02,0xbe,0x00,0x76,0x02,0xc0,0x00,0x69,0x02,0xc2,0x00,0x5c,0x02,  \
    0xc3,0x00,0x50,0x02,0xc5,0x00,0x43,0x02,0xc7,0x00,0x37,0x02,0xc9,0x00,0x2a,0x02,0xca,0x00,0x1e,0x02,0xcc,0x00,0x11,0x02,0xcd,0x00,0x05,0x02,0xcf,0x00,0xf8,0x01,0xd0,0x00,0xec,0x01,0xd2,0x00,0xe0,0x01,0xd3,0x00,0xd3,0x01,0xd5,0x00,0xc7,0x01,0xd6,0x00,0xbb,0x01,0xd7,0x00,0xaf,0x01,0xd9,0x00,0xa2,0x01,0xda,0x00,0x96,0x01,0xdb,0x00,0x8a,0x01,0xdd,0x00,0x7e,0x01,0xde,0x00,0x72,0x01,0xdf,0x00,0x66,0x01,0xe0,0x00,0x5a,0x01,0xe1,0x00,0x4e,0x01,0xe2,0x00,  \
    0x41,0x01,0xe3,0x00,0x35,0x01,0xe4,0x00,0x29,0x01,0xe5,0x00,0x1d,0x01,0xe6,0x00,0x11,0x01,0xe7,0x00,0x05,0x01,0xe8,0x00,0xf9,0x00,0xe9,0x00,0xed,0x00,0xea,0x00,0xe2,0x00,0xea,0x00,0xd6,0x00,0xeb,0x00,0xca,0x00,0xec,0x00,0xbe,0x00,0xed,0x00,0xb2,0x00,0xed,0x00,0xa6,0x00,0xee,0x00,0x9a,0x00,0xee,0x00,0x8e,0x00,0xef,0x00,0x82,0x00,0xef,0x00,0x77,0x00,0xf0,0x00,0x6b,0x00,0xf0,0x00,0x5f,0x00,0xf1,0x00,0x53,0x00,0xf1,0x00,0x47,0x00,0xf2,0x00,0x3b,0x00,  \
    0xf2,0x00,0x30,0x00,0xf2,0x00,0x24,0x00,0xf2,0x00,0x18,0x00,0xf3,0x00,0x0c,0x00,0xf3,0x00,0x01,0x00,0xf3,0x00,0xf5,0xff,0xf3,0x00,0xe9,0xff,0xf3,0x00,0xdd,0xff,0xf3,0x00,0xd1,0xff,0xf3,0x00,0xc6,0xff,0xf3,0x00,0xba,0xff,0xf3,0x00,0xae,0xff,0xf3,0x00,0xa2,0xff,0xf3,0x00,0x97,0xff,0xf3,0x00,0x8b,0xff,0xf3,0x00,0x7f,0xff,0xf3,0x00,0x73,0xff,0xf2,0x00,0x67,0xff,0xf2,0x00,0x5c,0xff,0xf2,0x00,0x50,0xff,0xf1,0x00,0x44,0xff,0xf1,0x00,0x38,0xff,0xf1,0x00,  \
    0x2c,0xff,0xf0,0x00,0x20,0xff,0xf0,0x00,0x15,0xff,0xef,0x00,0x09,0xff,0xef,0x00,0xfd,0xfe,0xee,0x00,0xf1,0xfe,0xee,0x00,0xe5,0xfe,0xed,0x00,0xd9,0xfe,0xed,0x00,0xcd,0xfe,0xec,0x00,0xc1,0xfe,0xeb,0x00,0xb5,0xfe,0xeb,0x00,0xa9,0xfe,0xea,0x00,0x9d,0xfe,0xe9,0x00,0x91,0xfe,0xe8,0x00,0x85,0xfe,0xe7,0x00,0x79,0xfe,0xe6,0x00,0x6d,0xfe,0xe6,0x00,0x61,0xfe,0xe5,0x00,0x55,0xfe,0xe4,0x00,0x4a,0xfe,0xe3,0x00,0x3e,0xfe,0xe2,0x00,0x32,0xfe,0xe1,0x00,0x26,0xfe,  \
    0xdf,0x00,0x1a,0xfe,0xde,0x00,0x0e,0xfe,0xdd,0x00,0x02,0xfe,0xdc,0x00,0xf6,0xfd,0xdb,0x00,0xea,0xfd,0xd9,0x00,0xde,0xfd,0xd8,0x00,0xd2,0xfd,0xd7,0x00,0xc6,0xfd,0xd5,0x00,0xba,0xfd,0xd4,0x00,0xae,0xfd,0xd3,0x00,0xa2,0xfd,0xd1,0x00,0x96,0xfd,0xd0,0x00,0x8a,0xfd,0xce,0x00,0x7e,0xfd,0xcd,0x00,0x72,0xfd,0xcb,0x00,0x66,0xfd,0xca,0x00,0x59,0xfd,0xc8,0x00,0x4d,0xfd,0xc6,0x00,0x41,0xfd,0xc5,0x00,0x35,0xfd,0xc3,0x00,0x28,0xfd,0xc1,0x00,0x1b,0xfd,0xbf,0x00,  \
    0x0f,0xfd,0xbe,0x00,0x02,0xfd,0xbc,0x00,0xf5,0xfc,0xba,0x00,0xe8,0xfc,0xb8,0x00,0xdb,0xfc,0xb6,0x00,0xce,0xfc,0xb4,0x00,0xc1,0xfc,0xb2,0x00,0xb4,0xfc,0xb0,0x00,0xa7,0xfc,0xae,0x00,0x9a,0xfc,0xac,0x00,0x8d,0xfc,0xaa,0x00,0x80,0xfc,0xa8,0x00,0x73,0xfc,0xa6,0x00,0x65,0xfc,0xa4,0x00,0x58,0xfc,0xa2,0x00,0x4b,0xfc,0xa0,0x00,0x3d,0xfc,0x9d,0x00,0x30,0xfc,0x9b,0x00,0x22,0xfc,0x99,0x00,0x15,0xfc,0x97,0x00,0x07,0xfc,0x94,0x00,0xfa,0xfb,0x92,0x00,0xec,0xfb,  \
    0x90,0x00,0xde,0xfb,0x8d,0x00,0xd1,0xfb,0x8b,0x00,0xc3,0xfb,0x88,0x00,0xb5,0xfb,0x86,0x00,0xa8,0xfb,0x83,0x00,0x9a,0xfb,0x81,0x00,0x8c,0xfb,0x7e,0x00,0x7e,0xfb,0x7b,0x00,0x70,0xfb,0x79,0x00,0x62,0xfb,0x76,0x00,0x54,0xfb,0x74,0x00,0x46,0xfb,0x71,0x00,0x38,0xfb,0x6e,0x00,0x2a,0xfb,0x6b,0x00,0x1c,0xfb,0x69,0x00,0x0d,0xfb,0x66,0x00,0xff,0xfa,0x63,0x00,0xf1,0xfa,0x60,0x00,0xe2,0xfa,0x5d,0x00,0xd4,0xfa,0x5a,0x00,0xc5,0xfa,0x57,0x00,0xb7,0xfa,0x54,0x00,  \
    0xa8,0xfa,0x52,0x00,0x99,0xfa,0x4f,0x00,0x8a,0xfa,0x4c,0x00,0x7c,0xfa,0x48,0x00,0x6d,0xfa,0x45,0x00,0x5e,0xfa,0x42,0x00,0x4f,0xfa,0x3f,0x00,0x40,0xfa,0x3c,0x00,0x31,0xfa,0x39,0x00,0x22,0xfa,0x36,0x00,0x12,0xfa,0x33,0x00,0x03,0xfa,0x2f,0x00,0xf4,0xf9,0x2c,0x00,0xe4,0xf9,0x29,0x00,0xd5,0xf9,0x26,0x00,0xc5,0xf9,0x22,0x00,0xb6,0xf9,0x1f,0x00,0xa6,0xf9,0x1c,0x00,0x96,0xf9,0x18,0x00,0x86,0xf9,0x15,0x00,0x77,0xf9,0x12,0x00,0x67,0xf9,0x0e,0x00,0x56,0xf9,  \
    0x0b,0x00,0x46,0xf9,0x07,0x00,0x36,0xf9,0x04,0x00,0x26,0xf9,0x01,0x00,0x16,0xf9,0xfd,0xff,0x05,0xf9,0xfa,0xff,0xf5,0xf8,0xf6,0xff,0xe4,0xf8,0xf3,0xff,0xd3,0xf8,0xef,0xff,0xc3,0xf8,0xeb,0xff,0xb2,0xf8,0xe8,0xff,0xa1,0xf8,0xe4,0xff,0x90,0xf8,0xe1,0xff,0x7f,0xf8,0xdd,0xff,0x6e,0xf8,0xd9,0xff,0x5d,0xf8,0xd6,0xff,0x4b,0xf8,0xd2,0xff,0x3a,0xf8,0xcf,0xff,0x29,0xf8,0xcb,0xff,0x17,0xf8,0xc7,0xff,0x05,0xf8,0xc4,0xff,0xf4,0xf7,0xc0,0xff,0xe2,0xf7,0xbc,0xff,  \
    0xd0,0xf7,0xb8,0xff,0xbe,0xf7,0xb5,0xff,0xac,0xf7,0xb1,0xff,0x9a,0xf7,0xad,0xff,0x87,0xf7,0xaa,0xff,0x75,0xf7,0xa6,0xff,0x63,0xf7,0xa2,0xff,0x50,0xf7,0x9e,0xff,0x3d,0xf7,0x9b,0xff,0x2b,0xf7,0x97,0xff,0x18,0xf7,0x93,0xff,0x05,0xf7,0x8f,0xff,0xf2,0xf6,0x8c,0xff,0xdf,0xf6,0x88,0xff,0xcc,0xf6,0x84,0xff,0xb8,0xf6,0x80,0xff,0xa5,0xf6,0x7c,0xff,0x92,0xf6,0x79,0xff,0x7e,0xf6,0x75,0xff,0x6a,0xf6,0x71,0xff,0x56,0xf6,0x6d,0xff,0x42,0xf6,0x6a,0xff,0x2e,0xf6,  \
    0x66,0xff,0x1a,0xf6,0x62,0xff,0x06,0xf6,0x5e,0xff,0xf2,0xf5,0x5b,0xff,0xdd,0xf5,0x57,0xff,0xc8,0xf5,0x53,0xff,0xb4,0xf5,0x50,0xff,0x9f,0xf5,0x4c,0xff,0x8a,0xf5,0x48,0xff,0x75,0xf5,0x45,0xff,0x60,0xf5,0x41,0xff,0x4b,0xf5,0x3d,0xff,0x35,0xf5,0x3a,0xff,0x20,0xf5,0x36,0xff,0x0a,0xf5,0x32,0xff,0xf4,0xf4,0x2f,0xff,0xdf,0xf4,0x2b,0xff,0xc9,0xf4,0x28,0xff,0xb3,0xf4,0x24,0xff,0x9d,0xf4,0x21,0xff,0x86,0xf4,0x1d,0xff,0x70,0xf4,0x1a,0xff,0x5a,0xf4,0x16,0xff,  \
    0x43,0xf4,0x13,0xff,0x2c,0xf4,0x0f,0xff,0x16,0xf4,0x0c,0xff,0xff,0xf3,0x08,0xff,0xe8,0xf3,0x05,0xff,0xd1,0xf3,0x02,0xff,0xb9,0xf3,0xfe,0xfe,0xa2,0xf3,0xfb,0xfe,0x8b,0xf3,0xf8,0xfe,0x73,0xf3,0xf4,0xfe,0x5b,0xf3,0xf1,0xfe,0x43,0xf3,0xee,0xfe,0x2b,0xf3,0xeb,0xfe,0x13,0xf3,0xe8,0xfe,0xfb,0xf2,0xe5,0xfe,0xe3,0xf2,0xe2,0xfe,0xca,0xf2,0xdf,0xfe,0xb1,0xf2,0xdc,0xfe,0x99,0xf2,0xd9,0xfe,0x80,0xf2,0xd6,0xfe,0x67,0xf2,0xd3,0xfe,0x4d,0xf2,0xd0,0xfe,0x34,0xf2,  \
    0xcd,0xfe,0x1b,0xf2,0xcb,0xfe,0x01,0xf2,0xc8,0xfe,0xe8,0xf1,0xc5,0xfe,0xce,0xf1,0xc3,0xfe,0xb4,0xf1,0xc0,0xfe,0x9a,0xf1,0xbe,0xfe,0x80,0xf1,0xbb,0xfe,0x65,0xf1,0xb9,0xfe,0x4b,0xf1,0xb6,0xfe,0x30,0xf1,0xb4,0xfe,0x16,0xf1,0xb2,0xfe,0xfb,0xf0,0xaf,0xfe,0xe0,0xf0,0xad,0xfe,0xc5,0xf0,0xab,0xfe,0xaa,0xf0,0xa9,0xfe,0x8e,0xf0,0xa7,0xfe,0x73,0xf0,0xa5,0xfe,0x57,0xf0,0xa3,0xfe,0x3c,0xf0,0xa1,0xfe,0x20,0xf0,0x9f,0xfe,0x04,0xf0,0x9d,0xfe,0xe8,0xef,0x9c,0xfe,  \
    0xcb,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x62,0xfe,0x3f,0x10,0x64,0xfe,0x23,0x10,0x66,0xfe,0x06,0x10,0x68,0xfe,0xea,0x0f,0x6a,0xfe,0xce,0x0f,0x6c,0xfe,0xb2,0x0f,0x6e,0xfe,0x96,0x0f,  \
    0x70,0xfe,0x7b,0x0f,0x72,0xfe,0x5f,0x0f,0x75,0xfe,0x43,0x0f,0x77,0xfe,0x28,0x0f,0x79,0xfe,0x0d,0x0f,0x7c,0xfe,0xf2,0x0e,0x7e,0xfe,0xd7,0x0e,0x81,0xfe,0xbc,0x0e,0x84,0xfe,0xa1,0x0e,0x86,0xfe,0x87,0x0e,0x89,0xfe,0x6c,0x0e,0x8c,0xfe,0x52,0x0e,0x8f,0xfe,0x38,0x0e,0x91,0xfe,0x1d,0x0e,0x94,0xfe,0x03,0x0e,0x97,0xfe,0xea,0x0d,0x9a,0xfe,0xd0,0x0d,0x9d,0xfe,0xb6,0x0d,0xa0,0xfe,0x9c,0x0d,0xa3,0xfe,0x83,0x0d,0xa6,0xfe,0x6a,0x0d,0xaa,0xfe,0x51,0x0d,0xad,0xfe,  \
    0x37,0x0d,0xb0,0xfe,0x1e,0x0d,0xb3,0xfe,0x06,0x0d,0xb7,0xfe,0xed,0x0c,0xba,0xfe,0xd4,0x0c,0xbd,0xfe,0xbc,0x0c,0xc1,0xfe,0xa3,0x0c,0xc4,0xfe,0x8b,0x0c,0xc8,0xfe,0x73,0x0c,0xcb,0xfe,0x5b,0x0c,0xcf,0xfe,0x43,0x0c,0xd2,0xfe,0x2b,0x0c,0xd6,0xfe,0x14,0x0c,0xda,0xfe,0xfd,0x0b,0xde,0xfe,0xe6,0x0b,0xe1,0xfe,0xcf,0x0b,0xe5,0xfe,0xb8,0x0b,0xe9,0xfe,0xa1,0x0b,0xed,0xfe,0x8b,0x0b,0xf1,0xfe,0x74,0x0b,0xf5,0xfe,0x5e,0x0b,0xf9,0xfe,0x48,0x0b,0xfd,0xfe,0x32,0x0b,  \
    0x01,0xff,0x1c,0x0b,0x05,0xff,0x06,0x0b,0x09,0xff,0xf0,0x0a,0x0d,0xff,0xdb,0x0a,0x11,0xff,0xc5,0x0a,0x15,0xff,0xb0,0x0a,0x19,0xff,0x9a,0x0a,0x1d,0xff,0x84,0x0a,0x21,0xff,0x6f,0x0a,0x25,0xff,0x5a,0x0a,0x29,0xff,0x44,0x0a,0x2d,0xff,0x2f,0x0a,0x30,0xff,0x1a,0x0a,0x34,0xff,0x05,0x0a,0x38,0xff,0xf0,0x09,0x3c,0xff,0xdb,0x09,0x40,0xff,0xc7,0x09,0x44,0xff,0xb2,0x09,0x48,0xff,0x9e,0x09,0x4d,0xff,0x89,0x09,0x51,0xff,0x75,0x09,0x55,0xff,0x61,0x09,0x59,0xff,  \
    0x4d,0x09,0x5d,0xff,0x39,0x09,0x61,0xff,0x25,0x09,0x65,0xff,0x11,0x09,0x69,0xff,0xfe,0x08,0x6d,0xff,0xea,0x08,0x71,0xff,0xd7,0x08,0x75,0xff,0xc3,0x08,0x79,0xff,0xb0,0x08,0x7d,0xff,0x9d,0x08,0x81,0xff,0x8a,0x08,0x85,0xff,0x77,0x08,0x89,0xff,0x64,0x08,0x8d,0xff,0x51,0x08,0x91,0xff,0x3e,0x08,0x95,0xff,0x2c,0x08,0x99,0xff,0x19,0x08,0x9d,0xff,0x07,0x08,0xa1,0xff,0xf4,0x07,0xa5,0xff,0xe2,0x07,0xa9,0xff,0xd0,0x07,0xad,0xff,0xbe,0x07,0xb1,0xff,0xac,0x07,  \
    0xb5,0xff,0x9a,0x07,0xb8,0xff,0x89,0x07,0xbc,0xff,0x77,0x07,0xc0,0xff,0x66,0x07,0xc4,0xff,0x54,0x07,0xc8,0xff,0x43,0x07,0xcc,0xff,0x32,0x07,0xd0,0xff,0x20,0x07,0xd4,0xff,0x0f,0x07,0xd8,0xff,0xfe,0x06,0xdb,0xff,0xed,0x06,0xdf,0xff,0xdc,0x06,0xe3,0xff,0xcc,0x06,0xe7,0xff,0xbb,0x06,0xeb,0xff,0xaa,0x06,0xee,0xff,0x9a,0x06,0xf2,0xff,0x89,0x06,0xf6,0xff,0x79,0x06,0xf9,0xff,0x68,0x06,0xfd,0xff,0x58,0x06,0x01,0x00,0x48,0x06,0x04,0x00,0x38,0x06,0x08,0x00,  \
    0x27,0x06,0x0c,0x00,0x17,0x06,0x0f,0x00,0x07,0x06,0x13,0x00,0xf8,0x05,0x16,0x00,0xe8,0x05,0x1a,0x00,0xd8,0x05,0x1d,0x00,0xc8,0x05,0x21,0x00,0xb9,0x05,0x24,0x00,0xa9,0x05,0x27,0x00,0x9a,0x05,0x2b,0x00,0x8a,0x05,0x2e,0x00,0x7b,0x05,0x32,0x00,0x6c,0x05,0x35,0x00,0x5c,0x05,0x38,0x00,0x4d,0x05,0x3b,0x00,0x3e,0x05,0x3f,0x00,0x2f,0x05,0x42,0x00,0x20,0x05,0x45,0x00,0x11,0x05,0x48,0x00,0x02,0x05,0x4b,0x00,0xf3,0x04,0x4f,0x00,0xe4,0x04,0x52,0x00,0xd5,0x04,  \
    0x55,0x00,0xc6,0x04,0x58,0x00,0xb7,0x04,0x5b,0x00,0xa8,0x04,0x5e,0x00,0x9a,0x04,0x61,0x00,0x8b,0x04,0x64,0x00,0x7c,0x04,0x66,0x00,0x6e,0x04,0x69,0x00,0x5f,0x04,0x6c,0x00,0x51,0x04,0x6f,0x00,0x42,0x04,0x72,0x00,0x34,0x04,0x75,0x00,0x26,0x04,0x77,0x00,0x18,0x04,0x7a,0x00,0x09,0x04,0x7d,0x00,0xfb,0x03,0x7f,0x00,0xed,0x03,0x82,0x00,0xdf,0x03,0x85,0x00,0xd1,0x03,0x87,0x00,0xc3,0x03,0x8a,0x00,0xb6,0x03,0x8c,0x00,0xa8,0x03,0x8f,0x00,0x9a,0x03,0x91,0x00,  \
    0x8d,0x03,0x94,0x00,0x7f,0x03,0x96,0x00,0x72,0x03,0x99,0x00,0x64,0x03,0x9b,0x00,0x57,0x03,0x9e,0x00,0x49,0x03,0xa0,0x00,0x3c,0x03,0xa2,0x00,0x2f,0x03,0xa4,0x00,0x22,0x03,0xa7,0x00,0x14,0x03,0xa9,0x00,0x07,0x03,0xab,0x00,0xfa,0x02,0xad,0x00,0xed,0x02,0xaf,0x00,0xe0,0x02,0xb1,0x00,0xd3,0x02,0xb3,0x00,0xc6,0x02,0xb5,0x00,0xb9,0x02,0xb7,0x00,0xac,0x02,0xb9,0x00,0x9f,0x02,0xbb,0x00,0x92,0x02,0xbd,0x00,0x85,0x02,0xbf,0x00,0x79,0x02,0xc1,0x00,0x6c,0x02,  \
    0xc3,0x00,0x5f,0x02,0xc5,0x00,0x53,0x02,0xc6,0x00,0x46,0x02,0xc8,0x00,0x39,0x02,0xca,0x00,0x2d,0x02,0xcc,0x00,0x20,0x02,0xcd,0x00,0x14,0x02,0xcf,0x00,0x08,0x02,0xd0,0x00,0xfb,0x01,0xd2,0x00,0xef,0x01,0xd3,0x00,0xe2,0x01,0xd5,0x00,0xd6,0x01,0xd6,0x00,0xca,0x01,0xd8,0x00,0xbd,0x01,0xd9,0x00,0xb1,0x01,0xda,0x00,0xa5,0x01,0xdc,0x00,0x99,0x01,0xdd,0x00,0x8c,0x01,0xde,0x00,0x80,0x01,0xdf,0x00,0x74,0x01,0xe1,0x00,0x68,0x01,0xe2,0x00,0x5c,0x01,0xe3,0x00,  \
    0x4f,0x01,0xe4,0x00,0x43,0x01,0xe5,0x00,0x37,0x01,0xe6,0x00,0x2b,0x01,0xe7,0x00,0x1f,0x01,0xe8,0x00,0x13,0x01,0xe9,0x00,0x07,0x01,0xea,0x00,0xfb,0x00,0xeb,0x00,0xef,0x00,0xec,0x00,0xe3,0x00,0xec,0x00,0xd7,0x00,0xed,0x00,0xcb,0x00,0xee,0x00,0xbf,0x00,0xee,0x00,0xb3,0x00,0xef,0x00,0xa7,0x00,0xf0,0x00,0x9b,0x00,0xf0,0x00,0x8f,0x00,0xf1,0x00,0x83,0x00,0xf1,0x00,0x77,0x00,0xf2,0x00,0x6c,0x00,0xf2,0x00,0x60,0x00,0xf3,0x00,0x54,0x00,0xf3,0x00,0x48,0x00,  \
    0xf4,0x00,0x3c,0x00,0xf4,0x00,0x30,0x00,0xf4,0x00,0x24,0x00,0xf4,0x00,0x19,0x00,0xf5,0x00,0x0d,0x00,0xf5,0x00,0x01,0x00,0xf5,0x00,0xf5,0xff,0xf5,0x00,0xe9,0xff,0xf5,0x00,0xdd,0xff,0xf5,0x00,0xd2,0xff,0xf5,0x00,0xc6,0xff,0xf5,0x00,0xba,0xff,0xf5,0x00,0xae,0xff,0xf5,0x00,0xa2,0xff,0xf5,0x00,0x96,0xff,0xf5,0x00,0x8b,0xff,0xf5,0x00,0x7f,0xff,0xf5,0x00,0x73,0xff,0xf4,0x00,0x67,0xff,0xf4,0x00,0x5b,0xff,0xf4,0x00,0x4f,0xff,0xf4,0x00,0x43,0xff,0xf3,0x00,  \
    0x37,0xff,0xf3,0x00,0x2b,0xff,0xf2,0x00,0x20,0xff,0xf2,0x00,0x14,0xff,0xf1,0x00,0x08,0xff,0xf1,0x00,0xfc,0xfe,0xf0,0x00,0xf0,0xfe,0xf0,0x00,0xe4,0xfe,0xef,0x00,0xd8,0xfe,0xef,0x00,0xcc,0xfe,0xee,0x00,0xc0,0xfe,0xed,0x00,0xb4,0xfe,0xec,0x00,0xa8,0xfe,0xec,0x00,0x9b,0xfe,0xeb,0x00,0x8f,0xfe,0xea,0x00,0x83,0xfe,0xe9,0x00,0x77,0xfe,0xe8,0x00,0x6b,0xfe,0xe7,0x00,0x5f,0xfe,0xe6,0x00,0x54,0xfe,0xe5,0x00,0x48,0xfe,0xe4,0x00,0x3c,0xfe,0xe3,0x00,0x30,0xfe,  \
    0xe2,0x00,0x24,0xfe,0xe1,0x00,0x18,0xfe,0xe0,0x00,0x0c,0xfe,0xdf,0x00,0x00,0xfe,0xde,0x00,0xf4,0xfd,0xdc,0x00,0xe8,0xfd,0xdb,0x00,0xdc,0xfd,0xda,0x00,0xd0,0xfd,0xd8,0x00,0xc4,0xfd,0xd7,0x00,0xb8,0xfd,0xd6,0x00,0xac,0xfd,0xd4,0x00,0xa0,0xfd,0xd3,0x00,0x93,0xfd,0xd1,0x00,0x87,0xfd,0xd0,0x00,0x7b,0xfd,0xce,0x00,0x6f,0xfd,0xcc,0x00,0x63,0xfd,0xcb,0x00,0x57,0xfd,0xc9,0x00,0x4a,0xfd,0xc7,0x00,0x3e,0xfd,0xc6,0x00,0x32,0xfd,0xc4,0x00,0x25,0xfd,0xc2,0x00,  \
    0x18,0xfd,0xc0,0x00,0x0c,0xfd,0xbf,0x00,0xff,0xfc,0xbd,0x00,0xf2,0xfc,0xbb,0x00,0xe5,0xfc,0xb9,0x00,0xd8,0xfc,0xb7,0x00,0xcb,0xfc,0xb5,0x00,0xbe,0xfc,0xb3,0x00,0xb1,0xfc,0xb1,0x00,0xa4,0xfc,0xaf,0x00,0x97,0xfc,0xad,0x00,0x89,0xfc,0xab,0x00,0x7c,0xfc,0xa9,0x00,0x6f,0xfc,0xa7,0x00,0x62,0xfc,0xa4,0x00,0x54,0xfc,0xa2,0x00,0x47,0xfc,0xa0,0x00,0x39,0xfc,0x9e,0x00,0x2c,0xfc,0x9b,0x00,0x1e,0xfc,0x99,0x00,0x11,0xfc,0x97,0x00,0x03,0xfc,0x94,0x00,0xf6,0xfb,  \
    0x92,0x00,0xe8,0xfb,0x8f,0x00,0xda,0xfb,0x8d,0x00,0xcc,0xfb,0x8b,0x00,0xbf,0xfb,0x88,0x00,0xb1,0xfb,0x85,0x00,0xa3,0xfb,0x83,0x00,0x95,0xfb,0x80,0x00,0x88,0xfb,0x7e,0x00,0x7a,0xfb,0x7b,0x00,0x6c,0xfb,0x78,0x00,0x5e,0xfb,0x76,0x00,0x50,0xfb,0x73,0x00,0x42,0xfb,0x70,0x00,0x34,0xfb,0x6d,0x00,0x25,0xfb,0x6a,0x00,0x17,0xfb,0x68,0x00,0x09,0xfb,0x65,0x00,0xfa,0xfa,0x62,0x00,0xec,0xfa,0x5f,0x00,0xde,0xfa,0x5c,0x00,0xcf,0xfa,0x59,0x00,0xc0,0xfa,0x56,0x00,  \
    0xb2,0xfa,0x53,0x00,0xa3,0xfa,0x50,0x00,0x94,0xfa,0x4d,0x00,0x86,0xfa,0x4a,0x00,0x77,0xfa,0x47,0x00,0x68,0xfa,0x44,0x00,0x59,0xfa,0x41,0x00,0x4a,0xfa,0x3d,0x00,0x3b,0xfa,0x3a,0x00,0x2c,0xfa,0x37,0x00,0x1d,0xfa,0x34,0x00,0x0d,0xfa,0x30,0x00,0xfe,0xf9,0x2d,0x00,0xef,0xf9,0x2a,0x00,0xdf,0xf9,0x27,0x00,0xd0,0xf9,0x23,0x00,0xc0,0xf9,0x20,0x00,0xb1,0xf9,0x1c,0x00,0xa1,0xf9,0x19,0x00,0x91,0xf9,0x16,0x00,0x81,0xf9,0x12,0x00,0x71,0xf9,0x0f,0x00,0x62,0xf9,  \
    0x0b,0x00,0x51,0xf9,0x08,0x00,0x41,0xf9,0x04,0x00,0x31,0xf9,0x01,0x00,0x21,0xf9,0xfd,0xff,0x11,0xf9,0xfa,0xff,0x00,0xf9,0xf6,0xff,0xf0,0xf8,0xf2,0xff,0xdf,0xf8,0xef,0xff,0xce,0xf8,0xeb,0xff,0xbe,0xf8,0xe8,0xff,0xad,0xf8,0xe4,0xff,0x9c,0xf8,0xe0,0xff,0x8b,0xf8,0xdc,0xff,0x7a,0xf8,0xd9,0xff,0x69,0xf8,0xd5,0xff,0x58,0xf8,0xd1,0xff,0x46,0xf8,0xce,0xff,0x35,0xf8,0xca,0xff,0x24,0xf8,0xc6,0xff,0x12,0xf8,0xc2,0xff,0x00,0xf8,0xbf,0xff,0xef,0xf7,0xbb,0xff,  \
    0xdd,0xf7,0xb7,0xff,0xcb,0xf7,0xb3,0xff,0xb9,0xf7,0xaf,0xff,0xa7,0xf7,0xac,0xff,0x95,0xf7,0xa8,0xff,0x83,0xf7,0xa4,0xff,0x70,0xf7,0xa0,0xff,0x5e,0xf7,0x9c,0xff,0x4b,0xf7,0x98,0xff,0x39,0xf7,0x95,0xff,0x26,0xf7,0x91,0xff,0x13,0xf7,0x8d,0xff,0x00,0xf7,0x89,0xff,0xed,0xf6,0x85,0xff,0xda,0xf6,0x81,0xff,0xc7,0xf6,0x7d,0xff,0xb4,0xf6,0x7a,0xff,0xa0,0xf6,0x76,0xff,0x8d,0xf6,0x72,0xff,0x79,0xf6,0x6e,0xff,0x66,0xf6,0x6a,0xff,0x52,0xf6,0x66,0xff,0x3e,0xf6,  \
    0x62,0xff,0x2a,0xf6,0x5e,0xff,0x16,0xf6,0x5b,0xff,0x01,0xf6,0x57,0xff,0xed,0xf5,0x53,0xff,0xd9,0xf5,0x4f,0xff,0xc4,0xf5,0x4b,0xff,0xaf,0xf5,0x48,0xff,0x9a,0xf5,0x44,0xff,0x86,0xf5,0x40,0xff,0x71,0xf5,0x3c,0xff,0x5b,0xf5,0x39,0xff,0x46,0xf5,0x35,0xff,0x31,0xf5,0x31,0xff,0x1b,0xf5,0x2d,0xff,0x06,0xf5,0x2a,0xff,0xf0,0xf4,0x26,0xff,0xda,0xf4,0x22,0xff,0xc4,0xf4,0x1f,0xff,0xae,0xf4,0x1b,0xff,0x98,0xf4,0x17,0xff,0x82,0xf4,0x14,0xff,0x6c,0xf4,0x10,0xff,  \
    0x55,0xf4,0x0d,0xff,0x3f,0xf4,0x09,0xff,0x28,0xf4,0x05,0xff,0x12,0xf4,0x02,0xff,0xfb,0xf3,0xfe,0xfe,0xe4,0xf3,0xfb,0xfe,0xcd,0xf3,0xf7,0xfe,0xb5,0xf3,0xf4,0xfe,0x9e,0xf3,0xf1,0xfe,0x87,0xf3,0xed,0xfe,0x6f,0xf3,0xea,0xfe,0x57,0xf3,0xe7,0xfe,0x3f,0xf3,0xe3,0xfe,0x27,0xf3,0xe0,0xfe,0x0f,0xf3,0xdd,0xfe,0xf7,0xf2,0xda,0xfe,0xdf,0xf2,0xd7,0xfe,0xc6,0xf2,0xd3,0xfe,0xae,0xf2,0xd0,0xfe,0x95,0xf2,0xcd,0xfe,0x7c,0xf2,0xca,0xfe,0x63,0xf2,0xc7,0xfe,0x4a,0xf2,  \
    0xc5,0xfe,0x31,0xf2,0xc2,0xfe,0x17,0xf2,0xbf,0xfe,0xfe,0xf1,0xbc,0xfe,0xe4,0xf1,0xb9,0xfe,0xca,0xf1,0xb7,0xfe,0xb0,0xf1,0xb4,0xfe,0x96,0xf1,0xb1,0xfe,0x7c,0xf1,0xaf,0xfe,0x62,0xf1,0xac,0xfe,0x47,0xf1,0xaa,0xfe,0x2d,0xf1,0xa7,0xfe,0x12,0xf1,0xa5,0xfe,0xf7,0xf0,0xa3,0xfe,0xdc,0xf0,0xa0,0xfe,0xc1,0xf0,0x9e,0xfe,0xa6,0xf0,0x9c,0xfe,0x8b,0xf0,0x9a,0xfe,0x6f,0xf0,0x98,0xfe,0x54,0xf0,0x96,0xfe,0x38,0xf0,0x94,0xfe,0x1c,0xf0,0x92,0xfe,0x00,0xf0,0x90,0xfe,  \
    0xe4,0xef,0x8e,0xfe,0xc8,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x56,0xfe,0x43,0x10,0x58,0xfe,0x26,0x10,0x5a,0xfe,0x0a,0x10,0x5c,0xfe,0xee,0x0f,0x5e,0xfe,0xd2,0x0f,0x60,0xfe,0xb6,0x0f,  \
    0x63,0xfe,0x9a,0x0f,0x65,0xfe,0x7e,0x0f,0x67,0xfe,0x62,0x0f,0x6a,0xfe,0x47,0x0f,0x6c,0xfe,0x2c,0x0f,0x6e,0xfe,0x10,0x0f,0x71,0xfe,0xf5,0x0e,0x74,0xfe,0xda,0x0e,0x76,0xfe,0xc0,0x0e,0x79,0xfe,0xa5,0x0e,0x7c,0xfe,0x8a,0x0e,0x7e,0xfe,0x70,0x0e,0x81,0xfe,0x55,0x0e,0x84,0xfe,0x3b,0x0e,0x87,0xfe,0x21,0x0e,0x8a,0xfe,0x07,0x0e,0x8d,0xfe,0xed,0x0d,0x90,0xfe,0xd3,0x0d,0x93,0xfe,0xba,0x0d,0x96,0xfe,0xa0,0x0d,0x99,0xfe,0x87,0x0d,0x9d,0xfe,0x6e,0x0d,0xa0,0xfe,  \
    0x54,0x0d,0xa3,0xfe,0x3b,0x0d,0xa6,0xfe,0x22,0x0d,0xaa,0xfe,0x09,0x0d,0xad,0xfe,0xf1,0x0c,0xb0,0xfe,0xd8,0x0c,0xb4,0xfe,0xc0,0x0c,0xb7,0xfe,0xa7,0x0c,0xbb,0xfe,0x8f,0x0c,0xbe,0xfe,0x77,0x0c,0xc2,0xfe,0x5f,0x0c,0xc6,0xfe,0x47,0x0c,0xc9,0xfe,0x2f,0x0c,0xcd,0xfe,0x18,0x0c,0xd1,0xfe,0x01,0x0c,0xd5,0xfe,0xea,0x0b,0xd9,0xfe,0xd3,0x0b,0xdd,0xfe,0xbc,0x0b,0xe1,0xfe,0xa6,0x0b,0xe5,0xfe,0x8f,0x0b,0xe9,0xfe,0x79,0x0b,0xed,0xfe,0x62,0x0b,0xf1,0xfe,0x4c,0x0b,  \
    0xf5,0xfe,0x36,0x0b,0xf9,0xfe,0x20,0x0b,0xfd,0xfe,0x0a,0x0b,0x01,0xff,0xf5,0x0a,0x05,0xff,0xdf,0x0a,0x09,0xff,0xca,0x0a,0x0d,0xff,0xb4,0x0a,0x11,0xff,0x9f,0x0a,0x15,0xff,0x89,0x0a,0x19,0xff,0x74,0x0a,0x1e,0xff,0x5e,0x0a,0x22,0xff,0x49,0x0a,0x26,0xff,0x34,0x0a,0x2a,0xff,0x1f,0x0a,0x2e,0xff,0x0a,0x0a,0x32,0xff,0xf5,0x09,0x36,0xff,0xe0,0x09,0x3a,0xff,0xcc,0x09,0x3e,0xff,0xb7,0x09,0x42,0xff,0xa3,0x09,0x46,0xff,0x8e,0x09,0x4a,0xff,0x7a,0x09,0x4f,0xff,  \
    0x66,0x09,0x53,0xff,0x52,0x09,0x57,0xff,0x3e,0x09,0x5b,0xff,0x2a,0x09,0x5f,0xff,0x16,0x09,0x63,0xff,0x03,0x09,0x67,0xff,0xef,0x08,0x6b,0xff,0xdc,0x08,0x6f,0xff,0xc8,0x08,0x74,0xff,0xb5,0x08,0x78,0xff,0xa2,0x08,0x7c,0xff,0x8f,0x08,0x80,0xff,0x7c,0x08,0x84,0xff,0x69,0x08,0x88,0xff,0x56,0x08,0x8c,0xff,0x43,0x08,0x90,0xff,0x31,0x08,0x94,0xff,0x1e,0x08,0x98,0xff,0x0c,0x08,0x9c,0xff,0xf9,0x07,0xa0,0xff,0xe7,0x07,0xa4,0xff,0xd5,0x07,0xa8,0xff,0xc3,0x07,  \
    0xac,0xff,0xb1,0x07,0xb0,0xff,0xa0,0x07,0xb5,0xff,0x8e,0x07,0xb9,0xff,0x7c,0x07,0xbd,0xff,0x6b,0x07,0xc1,0xff,0x59,0x07,0xc4,0xff,0x48,0x07,0xc8,0xff,0x37,0x07,0xcc,0xff,0x26,0x07,0xd0,0xff,0x14,0x07,0xd4,0xff,0x03,0x07,0xd8,0xff,0xf2,0x06,0xdc,0xff,0xe2,0x06,0xe0,0xff,0xd1,0x06,0xe4,0xff,0xc0,0x06,0xe8,0xff,0xaf,0x06,0xeb,0xff,0x9f,0x06,0xef,0xff,0x8e,0x06,0xf3,0xff,0x7e,0x06,0xf7,0xff,0x6e,0x06,0xfa,0xff,0x5d,0x06,0xfe,0xff,0x4d,0x06,0x02,0x00,  \
    0x3d,0x06,0x06,0x00,0x2d,0x06,0x09,0x00,0x1d,0x06,0x0d,0x00,0x0d,0x06,0x10,0x00,0xfd,0x05,0x14,0x00,0xed,0x05,0x18,0x00,0xdd,0x05,0x1b,0x00,0xcd,0x05,0x1f,0x00,0xbe,0x05,0x22,0x00,0xae,0x05,0x26,0x00,0x9f,0x05,0x29,0x00,0x8f,0x05,0x2d,0x00,0x80,0x05,0x30,0x00,0x71,0x05,0x33,0x00,0x61,0x05,0x37,0x00,0x52,0x05,0x3a,0x00,0x43,0x05,0x3d,0x00,0x34,0x05,0x41,0x00,0x25,0x05,0x44,0x00,0x16,0x05,0x47,0x00,0x07,0x05,0x4a,0x00,0xf8,0x04,0x4d,0x00,0xe9,0x04,  \
    0x51,0x00,0xda,0x04,0x54,0x00,0xcb,0x04,0x57,0x00,0xbc,0x04,0x5a,0x00,0xad,0x04,0x5d,0x00,0x9e,0x04,0x60,0x00,0x90,0x04,0x63,0x00,0x81,0x04,0x66,0x00,0x72,0x04,0x69,0x00,0x64,0x04,0x6c,0x00,0x55,0x04,0x6f,0x00,0x47,0x04,0x71,0x00,0x39,0x04,0x74,0x00,0x2a,0x04,0x77,0x00,0x1c,0x04,0x7a,0x00,0x0e,0x04,0x7d,0x00,0x00,0x04,0x7f,0x00,0xf2,0x03,0x82,0x00,0xe3,0x03,0x85,0x00,0xd5,0x03,0x87,0x00,0xc8,0x03,0x8a,0x00,0xba,0x03,0x8d,0x00,0xac,0x03,0x8f,0x00,  \
    0x9e,0x03,0x92,0x00,0x91,0x03,0x94,0x00,0x83,0x03,0x97,0x00,0x76,0x03,0x99,0x00,0x68,0x03,0x9c,0x00,0x5b,0x03,0x9e,0x00,0x4d,0x03,0xa0,0x00,0x40,0x03,0xa3,0x00,0x33,0x03,0xa5,0x00,0x25,0x03,0xa7,0x00,0x18,0x03,0xa9,0x00,0x0b,0x03,0xac,0x00,0xfe,0x02,0xae,0x00,0xf0,0x02,0xb0,0x00,0xe3,0x02,0xb2,0x00,0xd6,0x02,0xb4,0x00,0xc9,0x02,0xb6,0x00,0xbc,0x02,0xb8,0x00,0xaf,0x02,0xba,0x00,0xa2,0x02,0xbc,0x00,0x95,0x02,0xbe,0x00,0x89,0x02,0xc0,0x00,0x7c,0x02,  \
    0xc2,0x00,0x6f,0x02,0xc4,0x00,0x62,0x02,0xc6,0x00,0x56,0x02,0xc8,0x00,0x49,0x02,0xc9,0x00,0x3c,0x02,0xcb,0x00,0x30,0x02,0xcd,0x00,0x23,0x02,0xce,0x00,0x17,0x02,0xd0,0x00,0x0a,0x02,0xd2,0x00,0xfe,0x01,0xd3,0x00,0xf1,0x01,0xd5,0x00,0xe5,0x01,0xd6,0x00,0xd9,0x01,0xd8,0x00,0xcc,0x01,0xd9,0x00,0xc0,0x01,0xdb,0x00,0xb3,0x01,0xdc,0x00,0xa7,0x01,0xdd,0x00,0x9b,0x01,0xdf,0x00,0x8f,0x01,0xe0,0x00,0x82,0x01,0xe1,0x00,0x76,0x01,0xe2,0x00,0x6a,0x01,0xe3,0x00,  \
    0x5e,0x01,0xe5,0x00,0x51,0x01,0xe6,0x00,0x45,0x01,0xe7,0x00,0x39,0x01,0xe8,0x00,0x2d,0x01,0xe9,0x00,0x21,0x01,0xea,0x00,0x15,0x01,0xeb,0x00,0x09,0x01,0xec,0x00,0xfd,0x00,0xec,0x00,0xf0,0x00,0xed,0x00,0xe4,0x00,0xee,0x00,0xd8,0x00,0xef,0x00,0xcc,0x00,0xf0,0x00,0xc0,0x00,0xf0,0x00,0xb4,0x00,0xf1,0x00,0xa8,0x00,0xf2,0x00,0x9c,0x00,0xf2,0x00,0x90,0x00,0xf3,0x00,0x84,0x00,0xf3,0x00,0x78,0x00,0xf4,0x00,0x6c,0x00,0xf4,0x00,0x60,0x00,0xf5,0x00,0x55,0x00,  \
    0xf5,0x00,0x49,0x00,0xf6,0x00,0x3d,0x00,0xf6,0x00,0x31,0x00,0xf6,0x00,0x25,0x00,0xf6,0x00,0x19,0x00,0xf7,0x00,0x0d,0x00,0xf7,0x00,0x01,0x00,0xf7,0x00,0xf5,0xff,0xf7,0x00,0xe9,0xff,0xf7,0x00,0xdd,0xff,0xf7,0x00,0xd2,0xff,0xf7,0x00,0xc6,0xff,0xf7,0x00,0xba,0xff,0xf7,0x00,0xae,0xff,0xf7,0x00,0xa2,0xff,0xf7,0x00,0x96,0xff,0xf7,0x00,0x8a,0xff,0xf7,0x00,0x7e,0xff,0xf7,0x00,0x72,0xff,0xf6,0x00,0x66,0xff,0xf6,0x00,0x5b,0xff,0xf6,0x00,0x4f,0xff,0xf5,0x00,  \
    0x43,0xff,0xf5,0x00,0x37,0xff,0xf5,0x00,0x2b,0xff,0xf4,0x00,0x1f,0xff,0xf4,0x00,0x13,0xff,0xf3,0x00,0x07,0xff,0xf3,0x00,0xfb,0xfe,0xf2,0x00,0xef,0xfe,0xf2,0x00,0xe3,0xfe,0xf1,0x00,0xd6,0xfe,0xf0,0x00,0xca,0xfe,0xf0,0x00,0xbe,0xfe,0xef,0x00,0xb2,0xfe,0xee,0x00,0xa6,0xfe,0xed,0x00,0x9a,0xfe,0xed,0x00,0x8e,0xfe,0xec,0x00,0x82,0xfe,0xeb,0x00,0x76,0xfe,0xea,0x00,0x6a,0xfe,0xe9,0x00,0x5e,0xfe,0xe8,0x00,0x52,0xfe,0xe7,0x00,0x46,0xfe,0xe6,0x00,0x3a,0xfe,  \
    0xe5,0x00,0x2e,0xfe,0xe4,0x00,0x22,0xfe,0xe3,0x00,0x16,0xfe,0xe1,0x00,0x0a,0xfe,0xe0,0x00,0xfe,0xfd,0xdf,0x00,0xf2,0xfd,0xde,0x00,0xe5,0xfd,0xdc,0x00,0xd9,0xfd,0xdb,0x00,0xcd,0xfd,0xda,0x00,0xc1,0xfd,0xd8,0x00,0xb5,0xfd,0xd7,0x00,0xa9,0xfd,0xd5,0x00,0x9d,0xfd,0xd4,0x00,0x91,0xfd,0xd2,0x00,0x85,0xfd,0xd1,0x00,0x78,0xfd,0xcf,0x00,0x6c,0xfd,0xcd,0x00,0x60,0xfd,0xcc,0x00,0x54,0xfd,0xca,0x00,0x47,0xfd,0xc8,0x00,0x3b,0xfd,0xc7,0x00,0x2f,0xfd,0xc5,0x00,  \
    0x22,0xfd,0xc3,0x00,0x15,0xfd,0xc1,0x00,0x08,0xfd,0xbf,0x00,0xfc,0xfc,0xbd,0x00,0xef,0xfc,0xbc,0x00,0xe2,0xfc,0xba,0x00,0xd5,0xfc,0xb8,0x00,0xc8,0xfc,0xb6,0x00,0xbb,0xfc,0xb4,0x00,0xad,0xfc,0xb2,0x00,0xa0,0xfc,0xaf,0x00,0x93,0xfc,0xad,0x00,0x86,0xfc,0xab,0x00,0x79,0xfc,0xa9,0x00,0x6b,0xfc,0xa7,0x00,0x5e,0xfc,0xa5,0x00,0x50,0xfc,0xa2,0x00,0x43,0xfc,0xa0,0x00,0x36,0xfc,0x9e,0x00,0x28,0xfc,0x9b,0x00,0x1a,0xfc,0x99,0x00,0x0d,0xfc,0x97,0x00,0xff,0xfb,  \
    0x94,0x00,0xf1,0xfb,0x92,0x00,0xe4,0xfb,0x8f,0x00,0xd6,0xfb,0x8d,0x00,0xc8,0xfb,0x8a,0x00,0xba,0xfb,0x88,0x00,0xad,0xfb,0x85,0x00,0x9f,0xfb,0x82,0x00,0x91,0xfb,0x80,0x00,0x83,0xfb,0x7d,0x00,0x75,0xfb,0x7a,0x00,0x67,0xfb,0x78,0x00,0x59,0xfb,0x75,0x00,0x4b,0xfb,0x72,0x00,0x3d,0xfb,0x6f,0x00,0x2f,0xfb,0x6c,0x00,0x21,0xfb,0x69,0x00,0x12,0xfb,0x67,0x00,0x04,0xfb,0x64,0x00,0xf6,0xfa,0x61,0x00,0xe7,0xfa,0x5e,0x00,0xd9,0xfa,0x5b,0x00,0xca,0xfa,0x58,0x00,  \
    0xbc,0xfa,0x55,0x00,0xad,0xfa,0x52,0x00,0x9e,0xfa,0x4e,0x00,0x90,0xfa,0x4b,0x00,0x81,0xfa,0x48,0x00,0x72,0xfa,0x45,0x00,0x63,0xfa,0x42,0x00,0x54,0xfa,0x3f,0x00,0x45,0xfa,0x3b,0x00,0x36,0xfa,0x38,0x00,0x27,0xfa,0x35,0x00,0x18,0xfa,0x31,0x00,0x08,0xfa,0x2e,0x00,0xf9,0xf9,0x2b,0x00,0xea,0xf9,0x27,0x00,0xda,0xf9,0x24,0x00,0xcb,0xf9,0x21,0x00,0xbb,0xf9,0x1d,0x00,0xac,0xf9,0x1a,0x00,0x9c,0xf9,0x16,0x00,0x8c,0xf9,0x13,0x00,0x7c,0xf9,0x0f,0x00,0x6c,0xf9,  \
    0x0c,0x00,0x5c,0xf9,0x08,0x00,0x4c,0xf9,0x04,0x00,0x3c,0xf9,0x01,0x00,0x2c,0xf9,0xfd,0xff,0x1c,0xf9,0xfa,0xff,0x0b,0xf9,0xf6,0xff,0xfb,0xf8,0xf2,0xff,0xea,0xf8,0xef,0xff,0xda,0xf8,0xeb,0xff,0xc9,0xf8,0xe7,0xff,0xb9,0xf8,0xe3,0xff,0xa8,0xf8,0xe0,0xff,0x97,0xf8,0xdc,0xff,0x86,0xf8,0xd8,0xff,0x75,0xf8,0xd4,0xff,0x64,0xf8,0xd1,0xff,0x53,0xf8,0xcd,0xff,0x41,0xf8,0xc9,0xff,0x30,0xf8,0xc5,0xff,0x1e,0xf8,0xc1,0xff,0x0d,0xf8,0xbd,0xff,0xfb,0xf7,0xba,0xff,  \
    0xea,0xf7,0xb6,0xff,0xd8,0xf7,0xb2,0xff,0xc6,0xf7,0xae,0xff,0xb4,0xf7,0xaa,0xff,0xa2,0xf7,0xa6,0xff,0x90,0xf7,0xa2,0xff,0x7e,0xf7,0x9e,0xff,0x6b,0xf7,0x9a,0xff,0x59,0xf7,0x96,0xff,0x46,0xf7,0x92,0xff,0x34,0xf7,0x8e,0xff,0x21,0xf7,0x8b,0xff,0x0e,0xf7,0x87,0xff,0xfb,0xf6,0x83,0xff,0xe8,0xf6,0x7f,0xff,0xd5,0xf6,0x7b,0xff,0xc2,0xf6,0x77,0xff,0xaf,0xf6,0x73,0xff,0x9c,0xf6,0x6f,0xff,0x88,0xf6,0x6b,0xff,0x74,0xf6,0x67,0xff,0x61,0xf6,0x63,0xff,0x4d,0xf6,  \
    0x5f,0xff,0x39,0xf6,0x5b,0xff,0x25,0xf6,0x57,0xff,0x11,0xf6,0x53,0xff,0xfd,0xf5,0x4f,0xff,0xe8,0xf5,0x4b,0xff,0xd4,0xf5,0x47,0xff,0xbf,0xf5,0x43,0xff,0xab,0xf5,0x40,0xff,0x96,0xf5,0x3c,0xff,0x81,0xf5,0x38,0xff,0x6c,0xf5,0x34,0xff,0x57,0xf5,0x30,0xff,0x42,0xf5,0x2c,0xff,0x2c,0xf5,0x28,0xff,0x17,0xf5,0x25,0xff,0x01,0xf5,0x21,0xff,0xec,0xf4,0x1d,0xff,0xd6,0xf4,0x19,0xff,0xc0,0xf4,0x15,0xff,0xaa,0xf4,0x12,0xff,0x94,0xf4,0x0e,0xff,0x7e,0xf4,0x0a,0xff,  \
    0x68,0xf4,0x07,0xff,0x51,0xf4,0x03,0xff,0x3b,0xf4,0xff,0xfe,0x24,0xf4,0xfc,0xfe,0x0d,0xf4,0xf8,0xfe,0xf7,0xf3,0xf4,0xfe,0xe0,0xf3,0xf1,0xfe,0xc8,0xf3,0xed,0xfe,0xb1,0xf3,0xea,0xfe,0x9a,0xf3,0xe6,0xfe,0x83,0xf3,0xe3,0xfe,0x6b,0xf3,0xdf,0xfe,0x53,0xf3,0xdc,0xfe,0x3b,0xf3,0xd8,0xfe,0x23,0xf3,0xd5,0xfe,0x0b,0xf3,0xd2,0xfe,0xf3,0xf2,0xcf,0xfe,0xdb,0xf2,0xcb,0xfe,0xc2,0xf2,0xc8,0xfe,0xaa,0xf2,0xc5,0xfe,0x91,0xf2,0xc2,0xfe,0x78,0xf2,0xbf,0xfe,0x5f,0xf2,  \
    0xbc,0xfe,0x46,0xf2,0xb9,0xfe,0x2d,0xf2,0xb6,0xfe,0x13,0xf2,0xb3,0xfe,0xfa,0xf1,0xb0,0xfe,0xe0,0xf1,0xad,0xfe,0xc6,0xf1,0xaa,0xfe,0xad,0xf1,0xa8,0xfe,0x93,0xf1,0xa5,0xfe,0x78,0xf1,0xa2,0xfe,0x5e,0xf1,0xa0,0xfe,0x44,0xf1,0x9d,0xfe,0x29,0xf1,0x9b,0xfe,0x0e,0xf1,0x98,0xfe,0xf4,0xf0,0x96,0xfe,0xd9,0xf0,0x94,0xfe,0xbe,0xf0,0x91,0xfe,0xa3,0xf0,0x8f,0xfe,0x87,0xf0,0x8d,0xfe,0x6c,0xf0,0x8b,0xfe,0x50,0xf0,0x89,0xfe,0x35,0xf0,0x87,0xfe,0x19,0xf0,0x85,0xfe,  \
    0xfd,0xef,0x83,0xfe,0xe1,0xef,0x81,0xfe,0xc5,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x4b,0xfe,0x46,0x10,0x4d,0xfe,0x2a,0x10,0x4f,0xfe,0x0d,0x10,0x51,0xfe,0xf1,0x0f,0x53,0xfe,0xd5,0x0f,  \
    0x55,0xfe,0xb9,0x0f,0x57,0xfe,0x9d,0x0f,0x5a,0xfe,0x82,0x0f,0x5c,0xfe,0x66,0x0f,0x5f,0xfe,0x4b,0x0f,0x61,0xfe,0x2f,0x0f,0x64,0xfe,0x14,0x0f,0x66,0xfe,0xf9,0x0e,0x69,0xfe,0xde,0x0e,0x6b,0xfe,0xc3,0x0e,0x6e,0xfe,0xa9,0x0e,0x71,0xfe,0x8e,0x0e,0x74,0xfe,0x74,0x0e,0x77,0xfe,0x59,0x0e,0x7a,0xfe,0x3f,0x0e,0x7d,0xfe,0x25,0x0e,0x80,0xfe,0x0b,0x0e,0x83,0xfe,0xf1,0x0d,0x86,0xfe,0xd7,0x0d,0x89,0xfe,0xbe,0x0d,0x8c,0xfe,0xa4,0x0d,0x8f,0xfe,0x8b,0x0d,0x93,0xfe,  \
    0x71,0x0d,0x96,0xfe,0x58,0x0d,0x99,0xfe,0x3f,0x0d,0x9d,0xfe,0x26,0x0d,0xa0,0xfe,0x0d,0x0d,0xa3,0xfe,0xf5,0x0c,0xa7,0xfe,0xdc,0x0c,0xaa,0xfe,0xc4,0x0c,0xae,0xfe,0xab,0x0c,0xb2,0xfe,0x93,0x0c,0xb5,0xfe,0x7b,0x0c,0xb9,0xfe,0x63,0x0c,0xbc,0xfe,0x4b,0x0c,0xc0,0xfe,0x33,0x0c,0xc4,0xfe,0x1c,0x0c,0xc8,0xfe,0x05,0x0c,0xcc,0xfe,0xee,0x0b,0xd0,0xfe,0xd7,0x0b,0xd4,0xfe,0xc1,0x0b,0xd8,0xfe,0xaa,0x0b,0xdc,0xfe,0x93,0x0b,0xe0,0xfe,0x7d,0x0b,0xe4,0xfe,0x67,0x0b,  \
    0xe9,0xfe,0x51,0x0b,0xed,0xfe,0x3b,0x0b,0xf1,0xfe,0x25,0x0b,0xf5,0xfe,0x0f,0x0b,0xf9,0xfe,0xf9,0x0a,0xfe,0xfe,0xe4,0x0a,0x02,0xff,0xce,0x0a,0x06,0xff,0xb9,0x0a,0x0a,0xff,0xa3,0x0a,0x0e,0xff,0x8e,0x0a,0x12,0xff,0x78,0x0a,0x16,0xff,0x63,0x0a,0x1b,0xff,0x4e,0x0a,0x1f,0xff,0x39,0x0a,0x23,0xff,0x24,0x0a,0x27,0xff,0x0f,0x0a,0x2b,0xff,0xfa,0x09,0x2f,0xff,0xe5,0x09,0x34,0xff,0xd0,0x09,0x38,0xff,0xbc,0x09,0x3c,0xff,0xa8,0x09,0x40,0xff,0x93,0x09,0x44,0xff,  \
    0x7f,0x09,0x48,0xff,0x6b,0x09,0x4d,0xff,0x57,0x09,0x51,0xff,0x43,0x09,0x55,0xff,0x2f,0x09,0x59,0xff,0x1b,0x09,0x5d,0xff,0x08,0x09,0x62,0xff,0xf4,0x08,0x66,0xff,0xe1,0x08,0x6a,0xff,0xcd,0x08,0x6e,0xff,0xba,0x08,0x72,0xff,0xa7,0x08,0x77,0xff,0x94,0x08,0x7b,0xff,0x81,0x08,0x7f,0xff,0x6e,0x08,0x83,0xff,0x5b,0x08,0x87,0xff,0x49,0x08,0x8b,0xff,0x36,0x08,0x90,0xff,0x23,0x08,0x94,0xff,0x11,0x08,0x98,0xff,0xff,0x07,0x9c,0xff,0xec,0x07,0xa0,0xff,0xda,0x07,  \
    0xa4,0xff,0xc8,0x07,0xa8,0xff,0xb7,0x07,0xac,0xff,0xa5,0x07,0xb1,0xff,0x93,0x07,0xb5,0xff,0x82,0x07,0xb9,0xff,0x70,0x07,0xbd,0xff,0x5f,0x07,0xc1,0xff,0x4d,0x07,0xc5,0xff,0x3c,0x07,0xc9,0xff,0x2b,0x07,0xcd,0xff,0x1a,0x07,0xd1,0xff,0x09,0x07,0xd5,0xff,0xf8,0x06,0xd9,0xff,0xe7,0x06,0xdd,0xff,0xd6,0x06,0xe1,0xff,0xc5,0x06,0xe5,0xff,0xb5,0x06,0xe9,0xff,0xa4,0x06,0xec,0xff,0x94,0x06,0xf0,0xff,0x83,0x06,0xf4,0xff,0x73,0x06,0xf8,0xff,0x63,0x06,0xfc,0xff,  \
    0x52,0x06,0xff,0xff,0x42,0x06,0x03,0x00,0x32,0x06,0x07,0x00,0x22,0x06,0x0b,0x00,0x12,0x06,0x0e,0x00,0x02,0x06,0x12,0x00,0xf2,0x05,0x16,0x00,0xe2,0x05,0x19,0x00,0xd3,0x05,0x1d,0x00,0xc3,0x05,0x20,0x00,0xb4,0x05,0x24,0x00,0xa4,0x05,0x27,0x00,0x95,0x05,0x2b,0x00,0x85,0x05,0x2e,0x00,0x76,0x05,0x32,0x00,0x67,0x05,0x35,0x00,0x57,0x05,0x39,0x00,0x48,0x05,0x3c,0x00,0x39,0x05,0x3f,0x00,0x2a,0x05,0x43,0x00,0x1b,0x05,0x46,0x00,0x0c,0x05,0x49,0x00,0xfd,0x04,  \
    0x4c,0x00,0xee,0x04,0x50,0x00,0xdf,0x04,0x53,0x00,0xd0,0x04,0x56,0x00,0xc1,0x04,0x59,0x00,0xb2,0x04,0x5c,0x00,0xa3,0x04,0x5f,0x00,0x94,0x04,0x62,0x00,0x86,0x04,0x65,0x00,0x77,0x04,0x68,0x00,0x69,0x04,0x6b,0x00,0x5a,0x04,0x6e,0x00,0x4c,0x04,0x71,0x00,0x3d,0x04,0x74,0x00,0x2f,0x04,0x77,0x00,0x21,0x04,0x79,0x00,0x12,0x04,0x7c,0x00,0x04,0x04,0x7f,0x00,0xf6,0x03,0x82,0x00,0xe8,0x03,0x84,0x00,0xda,0x03,0x87,0x00,0xcc,0x03,0x8a,0x00,0xbe,0x03,0x8c,0x00,  \
    0xb0,0x03,0x8f,0x00,0xa3,0x03,0x92,0x00,0x95,0x03,0x94,0x00,0x87,0x03,0x97,0x00,0x7a,0x03,0x99,0x00,0x6c,0x03,0x9c,0x00,0x5f,0x03,0x9e,0x00,0x51,0x03,0xa1,0x00,0x44,0x03,0xa3,0x00,0x36,0x03,0xa5,0x00,0x29,0x03,0xa8,0x00,0x1c,0x03,0xaa,0x00,0x0f,0x03,0xac,0x00,0x01,0x03,0xae,0x00,0xf4,0x02,0xb1,0x00,0xe7,0x02,0xb3,0x00,0xda,0x02,0xb5,0x00,0xcd,0x02,0xb7,0x00,0xc0,0x02,0xb9,0x00,0xb3,0x02,0xbb,0x00,0xa6,0x02,0xbd,0x00,0x99,0x02,0xbf,0x00,0x8c,0x02,  \
    0xc1,0x00,0x7f,0x02,0xc3,0x00,0x72,0x02,0xc5,0x00,0x65,0x02,0xc7,0x00,0x59,0x02,0xc9,0x00,0x4c,0x02,0xca,0x00,0x3f,0x02,0xcc,0x00,0x33,0x02,0xce,0x00,0x26,0x02,0xd0,0x00,0x1a,0x02,0xd1,0x00,0x0d,0x02,0xd3,0x00,0x01,0x02,0xd4,0x00,0xf4,0x01,0xd6,0x00,0xe8,0x01,0xd7,0x00,0xdb,0x01,0xd9,0x00,0xcf,0x01,0xda,0x00,0xc2,0x01,0xdc,0x00,0xb6,0x01,0xdd,0x00,0xaa,0x01,0xdf,0x00,0x9d,0x01,0xe0,0x00,0x91,0x01,0xe1,0x00,0x85,0x01,0xe2,0x00,0x78,0x01,0xe4,0x00,  \
    0x6c,0x01,0xe5,0x00,0x60,0x01,0xe6,0x00,0x53,0x01,0xe7,0x00,0x47,0x01,0xe8,0x00,0x3b,0x01,0xe9,0x00,0x2f,0x01,0xea,0x00,0x23,0x01,0xeb,0x00,0x17,0x01,0xec,0x00,0x0a,0x01,0xed,0x00,0xfe,0x00,0xee,0x00,0xf2,0x00,0xef,0x00,0xe6,0x00,0xf0,0x00,0xda,0x00,0xf1,0x00,0xce,0x00,0xf1,0x00,0xc2,0x00,0xf2,0x00,0xb6,0x00,0xf3,0x00,0xa9,0x00,0xf3,0x00,0x9d,0x00,0xf4,0x00,0x91,0x00,0xf5,0x00,0x85,0x00,0xf5,0x00,0x79,0x00,0xf6,0x00,0x6d,0x00,0xf6,0x00,0x61,0x00,  \
    0xf6,0x00,0x55,0x00,0xf7,0x00,0x49,0x00,0xf7,0x00,0x3d,0x00,0xf8,0x00,0x31,0x00,0xf8,0x00,0x25,0x00,0xf8,0x00,0x19,0x00,0xf8,0x00,0x0d,0x00,0xf9,0x00,0x01,0x00,0xf9,0x00,0xf6,0xff,0xf9,0x00,0xea,0xff,0xf9,0x00,0xde,0xff,0xf9,0x00,0xd2,0xff,0xf9,0x00,0xc6,0xff,0xf9,0x00,0xba,0xff,0xf9,0x00,0xae,0xff,0xf9,0x00,0xa2,0xff,0xf9,0x00,0x96,0xff,0xf9,0x00,0x8a,0xff,0xf9,0x00,0x7e,0xff,0xf8,0x00,0x72,0xff,0xf8,0x00,0x66,0xff,0xf8,0x00,0x5a,0xff,0xf8,0x00,  \
    0x4e,0xff,0xf7,0x00,0x42,0xff,0xf7,0x00,0x36,0xff,0xf6,0x00,0x2a,0xff,0xf6,0x00,0x1e,0xff,0xf6,0x00,0x12,0xff,0xf5,0x00,0x06,0xff,0xf5,0x00,0xfa,0xfe,0xf4,0x00,0xed,0xfe,0xf3,0x00,0xe1,0xfe,0xf3,0x00,0xd5,0xfe,0xf2,0x00,0xc9,0xfe,0xf1,0x00,0xbd,0xfe,0xf1,0x00,0xb1,0xfe,0xf0,0x00,0xa4,0xfe,0xef,0x00,0x98,0xfe,0xee,0x00,0x8c,0xfe,0xed,0x00,0x80,0xfe,0xec,0x00,0x74,0xfe,0xec,0x00,0x68,0xfe,0xeb,0x00,0x5c,0xfe,0xea,0x00,0x50,0xfe,0xe9,0x00,0x44,0xfe,  \
    0xe7,0x00,0x38,0xfe,0xe6,0x00,0x2c,0xfe,0xe5,0x00,0x1f,0xfe,0xe4,0x00,0x13,0xfe,0xe3,0x00,0x07,0xfe,0xe2,0x00,0xfb,0xfd,0xe0,0x00,0xef,0xfd,0xdf,0x00,0xe3,0xfd,0xde,0x00,0xd7,0xfd,0xdc,0x00,0xcb,0xfd,0xdb,0x00,0xbf,0xfd,0xd9,0x00,0xb3,0xfd,0xd8,0x00,0xa6,0xfd,0xd6,0x00,0x9a,0xfd,0xd5,0x00,0x8e,0xfd,0xd3,0x00,0x82,0xfd,0xd2,0x00,0x76,0xfd,0xd0,0x00,0x69,0xfd,0xce,0x00,0x5d,0xfd,0xcd,0x00,0x51,0xfd,0xcb,0x00,0x45,0xfd,0xc9,0x00,0x38,0xfd,0xc7,0x00,  \
    0x2c,0xfd,0xc6,0x00,0x1f,0xfd,0xc4,0x00,0x12,0xfd,0xc2,0x00,0x05,0xfd,0xc0,0x00,0xf8,0xfc,0xbe,0x00,0xeb,0xfc,0xbc,0x00,0xde,0xfc,0xba,0x00,0xd1,0xfc,0xb8,0x00,0xc4,0xfc,0xb6,0x00,0xb7,0xfc,0xb4,0x00,0xaa,0xfc,0xb2,0x00,0x9d,0xfc,0xb0,0x00,0x8f,0xfc,0xae,0x00,0x82,0xfc,0xab,0x00,0x75,0xfc,0xa9,0x00,0x67,0xfc,0xa7,0x00,0x5a,0xfc,0xa5,0x00,0x4d,0xfc,0xa2,0x00,0x3f,0xfc,0xa0,0x00,0x32,0xfc,0x9e,0x00,0x24,0xfc,0x9b,0x00,0x16,0xfc,0x99,0x00,0x09,0xfc,  \
    0x97,0x00,0xfb,0xfb,0x94,0x00,0xed,0xfb,0x92,0x00,0xdf,0xfb,0x8f,0x00,0xd1,0xfb,0x8c,0x00,0xc4,0xfb,0x8a,0x00,0xb6,0xfb,0x87,0x00,0xa8,0xfb,0x85,0x00,0x9a,0xfb,0x82,0x00,0x8c,0xfb,0x7f,0x00,0x7f,0xfb,0x7c,0x00,0x71,0xfb,0x7a,0x00,0x63,0xfb,0x77,0x00,0x55,0xfb,0x74,0x00,0x46,0xfb,0x71,0x00,0x38,0xfb,0x6e,0x00,0x2a,0xfb,0x6b,0x00,0x1c,0xfb,0x68,0x00,0x0e,0xfb,0x65,0x00,0xff,0xfa,0x62,0x00,0xf1,0xfa,0x5f,0x00,0xe2,0xfa,0x5c,0x00,0xd4,0xfa,0x59,0x00,  \
    0xc5,0xfa,0x56,0x00,0xb7,0xfa,0x53,0x00,0xa8,0xfa,0x50,0x00,0x99,0xfa,0x4d,0x00,0x8b,0xfa,0x4a,0x00,0x7c,0xfa,0x46,0x00,0x6d,0xfa,0x43,0x00,0x5e,0xfa,0x40,0x00,0x4f,0xfa,0x3d,0x00,0x40,0xfa,0x39,0x00,0x31,0xfa,0x36,0x00,0x22,0xfa,0x33,0x00,0x12,0xfa,0x2f,0x00,0x03,0xfa,0x2c,0x00,0xf4,0xf9,0x28,0x00,0xe5,0xf9,0x25,0x00,0xd5,0xf9,0x21,0x00,0xc6,0xf9,0x1e,0x00,0xb6,0xf9,0x1a,0x00,0xa6,0xf9,0x17,0x00,0x97,0xf9,0x13,0x00,0x87,0xf9,0x10,0x00,0x77,0xf9,  \
    0x0c,0x00,0x67,0xf9,0x08,0x00,0x57,0xf9,0x05,0x00,0x47,0xf9,0x01,0x00,0x37,0xf9,0xfd,0xff,0x27,0xf9,0xfa,0xff,0x16,0xf9,0xf6,0xff,0x06,0xf9,0xf2,0xff,0xf6,0xf8,0xef,0xff,0xe5,0xf8,0xeb,0xff,0xd5,0xf8,0xe7,0xff,0xc4,0xf8,0xe3,0xff,0xb3,0xf8,0xdf,0xff,0xa3,0xf8,0xdc,0xff,0x92,0xf8,0xd8,0xff,0x81,0xf8,0xd4,0xff,0x70,0xf8,0xd0,0xff,0x5f,0xf8,0xcc,0xff,0x4d,0xf8,0xc8,0xff,0x3c,0xf8,0xc4,0xff,0x2b,0xf8,0xc0,0xff,0x19,0xf8,0xbc,0xff,0x08,0xf8,0xb8,0xff,  \
    0xf6,0xf7,0xb5,0xff,0xe4,0xf7,0xb1,0xff,0xd3,0xf7,0xad,0xff,0xc1,0xf7,0xa9,0xff,0xaf,0xf7,0xa5,0xff,0x9d,0xf7,0xa1,0xff,0x8b,0xf7,0x9d,0xff,0x78,0xf7,0x99,0xff,0x66,0xf7,0x94,0xff,0x54,0xf7,0x90,0xff,0x41,0xf7,0x8c,0xff,0x2f,0xf7,0x88,0xff,0x1c,0xf7,0x84,0xff,0x09,0xf7,0x80,0xff,0xf6,0xf6,0x7c,0xff,0xe3,0xf6,0x78,0xff,0xd0,0xf6,0x74,0xff,0xbd,0xf6,0x70,0xff,0xaa,0xf6,0x6c,0xff,0x97,0xf6,0x68,0xff,0x83,0xf6,0x64,0xff,0x70,0xf6,0x60,0xff,0x5c,0xf6,  \
    0x5c,0xff,0x48,0xf6,0x58,0xff,0x34,0xf6,0x53,0xff,0x20,0xf6,0x4f,0xff,0x0c,0xf6,0x4b,0xff,0xf8,0xf5,0x47,0xff,0xe4,0xf5,0x43,0xff,0xcf,0xf5,0x3f,0xff,0xbb,0xf5,0x3b,0xff,0xa6,0xf5,0x37,0xff,0x91,0xf5,0x33,0xff,0x7c,0xf5,0x2f,0xff,0x67,0xf5,0x2b,0xff,0x52,0xf5,0x28,0xff,0x3d,0xf5,0x24,0xff,0x28,0xf5,0x20,0xff,0x12,0xf5,0x1c,0xff,0xfd,0xf4,0x18,0xff,0xe7,0xf4,0x14,0xff,0xd1,0xf4,0x10,0xff,0xbc,0xf4,0x0c,0xff,0xa6,0xf4,0x08,0xff,0x90,0xf4,0x04,0xff,  \
    0x79,0xf4,0x01,0xff,0x63,0xf4,0xfd,0xfe,0x4d,0xf4,0xf9,0xfe,0x36,0xf4,0xf5,0xfe,0x20,0xf4,0xf2,0xfe,0x09,0xf4,0xee,0xfe,0xf2,0xf3,0xea,0xfe,0xdb,0xf3,0xe6,0xfe,0xc4,0xf3,0xe3,0xfe,0xad,0xf3,0xdf,0xfe,0x96,0xf3,0xdc,0xfe,0x7e,0xf3,0xd8,0xfe,0x67,0xf3,0xd4,0xfe,0x4f,0xf3,0xd1,0xfe,0x37,0xf3,0xcd,0xfe,0x1f,0xf3,0xca,0xfe,0x07,0xf3,0xc7,0xfe,0xef,0xf2,0xc3,0xfe,0xd7,0xf2,0xc0,0xfe,0xbe,0xf2,0xbd,0xfe,0xa6,0xf2,0xb9,0xfe,0x8d,0xf2,0xb6,0xfe,0x74,0xf2,  \
    0xb3,0xfe,0x5b,0xf2,0xb0,0xfe,0x42,0xf2,0xad,0xfe,0x29,0xf2,0xaa,0xfe,0x10,0xf2,0xa7,0xfe,0xf6,0xf1,0xa4,0xfe,0xdc,0xf1,0xa1,0xfe,0xc3,0xf1,0x9e,0xfe,0xa9,0xf1,0x9b,0xfe,0x8f,0xf1,0x99,0xfe,0x75,0xf1,0x96,0xfe,0x5a,0xf1,0x93,0xfe,0x40,0xf1,0x91,0xfe,0x26,0xf1,0x8e,0xfe,0x0b,0xf1,0x8c,0xfe,0xf0,0xf0,0x89,0xfe,0xd5,0xf0,0x87,0xfe,0xba,0xf0,0x84,0xfe,0x9f,0xf0,0x82,0xfe,0x84,0xf0,0x80,0xfe,0x68,0xf0,0x7e,0xfe,0x4d,0xf0,0x7b,0xfe,0x31,0xf0,0x79,0xfe,  \
    0x16,0xf0,0x77,0xfe,0xfa,0xef,0x75,0xfe,0xde,0xef,0x73,0xfe,0xc1,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3f,0xfe,0x4a,0x10,0x41,0xfe,0x2d,0x10,0x43,0xfe,0x11,0x10,0x46,0xfe,0xf5,0x0f,  \
    0x48,0xfe,0xd9,0x0f,0x4a,0xfe,0xbd,0x0f,0x4c,0xfe,0xa1,0x0f,0x4f,0xfe,0x85,0x0f,0x51,0xfe,0x6a,0x0f,0x54,0xfe,0x4e,0x0f,0x56,0xfe,0x33,0x0f,0x59,0xfe,0x18,0x0f,0x5b,0xfe,0xfd,0x0e,0x5e,0xfe,0xe2,0x0e,0x61,0xfe,0xc7,0x0e,0x64,0xfe,0xac,0x0e,0x66,0xfe,0x92,0x0e,0x69,0xfe,0x77,0x0e,0x6c,0xfe,0x5d,0x0e,0x6f,0xfe,0x43,0x0e,0x72,0xfe,0x29,0x0e,0x75,0xfe,0x0f,0x0e,0x78,0xfe,0xf5,0x0d,0x7c,0xfe,0xdb,0x0d,0x7f,0xfe,0xc2,0x0d,0x82,0xfe,0xa8,0x0d,0x85,0xfe,  \
    0x8f,0x0d,0x89,0xfe,0x75,0x0d,0x8c,0xfe,0x5c,0x0d,0x8f,0xfe,0x43,0x0d,0x93,0xfe,0x2a,0x0d,0x96,0xfe,0x11,0x0d,0x9a,0xfe,0xf9,0x0c,0x9d,0xfe,0xe0,0x0c,0xa1,0xfe,0xc8,0x0c,0xa5,0xfe,0xaf,0x0c,0xa8,0xfe,0x97,0x0c,0xac,0xfe,0x7f,0x0c,0xb0,0xfe,0x67,0x0c,0xb3,0xfe,0x4f,0x0c,0xb7,0xfe,0x38,0x0c,0xbb,0xfe,0x20,0x0c,0xbf,0xfe,0x09,0x0c,0xc3,0xfe,0xf2,0x0b,0xc7,0xfe,0xdc,0x0b,0xcc,0xfe,0xc5,0x0b,0xd0,0xfe,0xae,0x0b,0xd4,0xfe,0x98,0x0b,0xd8,0xfe,0x82,0x0b,  \
    0xdc,0xfe,0x6b,0x0b,0xe1,0xfe,0x55,0x0b,0xe5,0xfe,0x3f,0x0b,0xe9,0xfe,0x29,0x0b,0xed,0xfe,0x14,0x0b,0xf2,0xfe,0xfe,0x0a,0xf6,0xfe,0xe9,0x0a,0xfa,0xfe,0xd3,0x0a,0xff,0xfe,0xbe,0x0a,0x03,0xff,0xa8,0x0a,0x07,0xff,0x93,0x0a,0x0b,0xff,0x7d,0x0a,0x0f,0xff,0x68,0x0a,0x14,0xff,0x53,0x0a,0x18,0xff,0x3e,0x0a,0x1c,0xff,0x29,0x0a,0x20,0xff,0x14,0x0a,0x25,0xff,0xff,0x09,0x29,0xff,0xea,0x09,0x2d,0xff,0xd6,0x09,0x31,0xff,0xc1,0x09,0x36,0xff,0xad,0x09,0x3a,0xff,  \
    0x98,0x09,0x3e,0xff,0x84,0x09,0x42,0xff,0x70,0x09,0x47,0xff,0x5c,0x09,0x4b,0xff,0x48,0x09,0x4f,0xff,0x34,0x09,0x54,0xff,0x21,0x09,0x58,0xff,0x0d,0x09,0x5c,0xff,0xf9,0x08,0x60,0xff,0xe6,0x08,0x65,0xff,0xd3,0x08,0x69,0xff,0xbf,0x08,0x6d,0xff,0xac,0x08,0x71,0xff,0x99,0x08,0x76,0xff,0x86,0x08,0x7a,0xff,0x73,0x08,0x7e,0xff,0x61,0x08,0x82,0xff,0x4e,0x08,0x87,0xff,0x3b,0x08,0x8b,0xff,0x29,0x08,0x8f,0xff,0x16,0x08,0x93,0xff,0x04,0x08,0x97,0xff,0xf2,0x07,  \
    0x9c,0xff,0xe0,0x07,0xa0,0xff,0xce,0x07,0xa4,0xff,0xbc,0x07,0xa8,0xff,0xaa,0x07,0xac,0xff,0x98,0x07,0xb1,0xff,0x87,0x07,0xb5,0xff,0x75,0x07,0xb9,0xff,0x64,0x07,0xbd,0xff,0x53,0x07,0xc1,0xff,0x41,0x07,0xc5,0xff,0x30,0x07,0xc9,0xff,0x1f,0x07,0xcd,0xff,0x0e,0x07,0xd2,0xff,0xfd,0x06,0xd6,0xff,0xec,0x06,0xda,0xff,0xdc,0x06,0xde,0xff,0xcb,0x06,0xe2,0xff,0xba,0x06,0xe6,0xff,0xaa,0x06,0xe9,0xff,0x99,0x06,0xed,0xff,0x89,0x06,0xf1,0xff,0x78,0x06,0xf5,0xff,  \
    0x68,0x06,0xf9,0xff,0x58,0x06,0xfd,0xff,0x48,0x06,0x01,0x00,0x37,0x06,0x04,0x00,0x27,0x06,0x08,0x00,0x17,0x06,0x0c,0x00,0x08,0x06,0x10,0x00,0xf8,0x05,0x13,0x00,0xe8,0x05,0x17,0x00,0xd8,0x05,0x1b,0x00,0xc9,0x05,0x1e,0x00,0xb9,0x05,0x22,0x00,0xa9,0x05,0x26,0x00,0x9a,0x05,0x29,0x00,0x8b,0x05,0x2d,0x00,0x7b,0x05,0x30,0x00,0x6c,0x05,0x34,0x00,0x5d,0x05,0x37,0x00,0x4e,0x05,0x3b,0x00,0x3e,0x05,0x3e,0x00,0x2f,0x05,0x41,0x00,0x20,0x05,0x45,0x00,0x11,0x05,  \
    0x48,0x00,0x02,0x05,0x4b,0x00,0xf3,0x04,0x4e,0x00,0xe4,0x04,0x52,0x00,0xd5,0x04,0x55,0x00,0xc6,0x04,0x58,0x00,0xb7,0x04,0x5b,0x00,0xa8,0x04,0x5e,0x00,0x99,0x04,0x61,0x00,0x8b,0x04,0x64,0x00,0x7c,0x04,0x67,0x00,0x6d,0x04,0x6a,0x00,0x5f,0x04,0x6d,0x00,0x50,0x04,0x70,0x00,0x42,0x04,0x73,0x00,0x34,0x04,0x76,0x00,0x25,0x04,0x79,0x00,0x17,0x04,0x7c,0x00,0x09,0x04,0x7f,0x00,0xfa,0x03,0x81,0x00,0xec,0x03,0x84,0x00,0xde,0x03,0x87,0x00,0xd0,0x03,0x8a,0x00,  \
    0xc2,0x03,0x8c,0x00,0xb5,0x03,0x8f,0x00,0xa7,0x03,0x92,0x00,0x99,0x03,0x94,0x00,0x8b,0x03,0x97,0x00,0x7e,0x03,0x99,0x00,0x70,0x03,0x9c,0x00,0x63,0x03,0x9e,0x00,0x55,0x03,0xa1,0x00,0x48,0x03,0xa3,0x00,0x3a,0x03,0xa6,0x00,0x2d,0x03,0xa8,0x00,0x20,0x03,0xaa,0x00,0x12,0x03,0xad,0x00,0x05,0x03,0xaf,0x00,0xf8,0x02,0xb1,0x00,0xeb,0x02,0xb3,0x00,0xde,0x02,0xb5,0x00,0xd0,0x02,0xb8,0x00,0xc3,0x02,0xba,0x00,0xb6,0x02,0xbc,0x00,0xa9,0x02,0xbe,0x00,0x9c,0x02,  \
    0xc0,0x00,0x8f,0x02,0xc2,0x00,0x82,0x02,0xc4,0x00,0x75,0x02,0xc6,0x00,0x69,0x02,0xc8,0x00,0x5c,0x02,0xc9,0x00,0x4f,0x02,0xcb,0x00,0x43,0x02,0xcd,0x00,0x36,0x02,0xcf,0x00,0x29,0x02,0xd0,0x00,0x1d,0x02,0xd2,0x00,0x10,0x02,0xd4,0x00,0x03,0x02,0xd5,0x00,0xf7,0x01,0xd7,0x00,0xea,0x01,0xd9,0x00,0xde,0x01,0xda,0x00,0xd1,0x01,0xdc,0x00,0xc5,0x01,0xdd,0x00,0xb8,0x01,0xde,0x00,0xac,0x01,0xe0,0x00,0xa0,0x01,0xe1,0x00,0x93,0x01,0xe2,0x00,0x87,0x01,0xe4,0x00,  \
    0x7a,0x01,0xe5,0x00,0x6e,0x01,0xe6,0x00,0x62,0x01,0xe7,0x00,0x56,0x01,0xe9,0x00,0x49,0x01,0xea,0x00,0x3d,0x01,0xeb,0x00,0x31,0x01,0xec,0x00,0x25,0x01,0xed,0x00,0x18,0x01,0xee,0x00,0x0c,0x01,0xef,0x00,0x00,0x01,0xf0,0x00,0xf4,0x00,0xf0,0x00,0xe7,0x00,0xf1,0x00,0xdb,0x00,0xf2,0x00,0xcf,0x00,0xf3,0x00,0xc3,0x00,0xf4,0x00,0xb7,0x00,0xf4,0x00,0xab,0x00,0xf5,0x00,0x9f,0x00,0xf5,0x00,0x93,0x00,0xf6,0x00,0x86,0x00,0xf7,0x00,0x7a,0x00,0xf7,0x00,0x6e,0x00,  \
    0xf8,0x00,0x62,0x00,0xf8,0x00,0x56,0x00,0xf8,0x00,0x4a,0x00,0xf9,0x00,0x3e,0x00,0xf9,0x00,0x32,0x00,0xfa,0x00,0x26,0x00,0xfa,0x00,0x1a,0x00,0xfa,0x00,0x0e,0x00,0xfa,0x00,0x02,0x00,0xfa,0x00,0xf6,0xff,0xfb,0x00,0xea,0xff,0xfb,0x00,0xde,0xff,0xfb,0x00,0xd2,0xff,0xfb,0x00,0xc6,0xff,0xfb,0x00,0xba,0xff,0xfb,0x00,0xae,0xff,0xfb,0x00,0xa2,0xff,0xfb,0x00,0x96,0xff,0xfa,0x00,0x8a,0xff,0xfa,0x00,0x7e,0xff,0xfa,0x00,0x72,0xff,0xfa,0x00,0x65,0xff,0xf9,0x00,  \
    0x59,0xff,0xf9,0x00,0x4d,0xff,0xf9,0x00,0x41,0xff,0xf8,0x00,0x35,0xff,0xf8,0x00,0x29,0xff,0xf8,0x00,0x1d,0xff,0xf7,0x00,0x11,0xff,0xf7,0x00,0x05,0xff,0xf6,0x00,0xf8,0xfe,0xf5,0x00,0xec,0xfe,0xf5,0x00,0xe0,0xfe,0xf4,0x00,0xd4,0xfe,0xf4,0x00,0xc8,0xfe,0xf3,0x00,0xbb,0xfe,0xf2,0x00,0xaf,0xfe,0xf1,0x00,0xa3,0xfe,0xf1,0x00,0x97,0xfe,0xf0,0x00,0x8a,0xfe,0xef,0x00,0x7e,0xfe,0xee,0x00,0x72,0xfe,0xed,0x00,0x66,0xfe,0xec,0x00,0x5a,0xfe,0xeb,0x00,0x4e,0xfe,  \
    0xea,0x00,0x42,0xfe,0xe9,0x00,0x35,0xfe,0xe8,0x00,0x29,0xfe,0xe6,0x00,0x1d,0xfe,0xe5,0x00,0x11,0xfe,0xe4,0x00,0x05,0xfe,0xe3,0x00,0xf9,0xfd,0xe1,0x00,0xed,0xfd,0xe0,0x00,0xe1,0xfd,0xdf,0x00,0xd4,0xfd,0xdd,0x00,0xc8,0xfd,0xdc,0x00,0xbc,0xfd,0xda,0x00,0xb0,0xfd,0xd9,0x00,0xa4,0xfd,0xd7,0x00,0x98,0xfd,0xd6,0x00,0x8b,0xfd,0xd4,0x00,0x7f,0xfd,0xd3,0x00,0x73,0xfd,0xd1,0x00,0x67,0xfd,0xcf,0x00,0x5a,0xfd,0xcd,0x00,0x4e,0xfd,0xcc,0x00,0x42,0xfd,0xca,0x00,  \
    0x35,0xfd,0xc8,0x00,0x29,0xfd,0xc6,0x00,0x1c,0xfd,0xc4,0x00,0x0f,0xfd,0xc2,0x00,0x02,0xfd,0xc1,0x00,0xf5,0xfc,0xbf,0x00,0xe8,0xfc,0xbd,0x00,0xdb,0xfc,0xbb,0x00,0xce,0xfc,0xb8,0x00,0xc1,0xfc,0xb6,0x00,0xb4,0xfc,0xb4,0x00,0xa6,0xfc,0xb2,0x00,0x99,0xfc,0xb0,0x00,0x8c,0xfc,0xae,0x00,0x7e,0xfc,0xac,0x00,0x71,0xfc,0xa9,0x00,0x64,0xfc,0xa7,0x00,0x56,0xfc,0xa5,0x00,0x49,0xfc,0xa2,0x00,0x3b,0xfc,0xa0,0x00,0x2d,0xfc,0x9e,0x00,0x20,0xfc,0x9b,0x00,0x12,0xfc,  \
    0x99,0x00,0x04,0xfc,0x96,0x00,0xf7,0xfb,0x94,0x00,0xe9,0xfb,0x91,0x00,0xdb,0xfb,0x8f,0x00,0xcd,0xfb,0x8c,0x00,0xbf,0xfb,0x89,0x00,0xb1,0xfb,0x87,0x00,0xa4,0xfb,0x84,0x00,0x96,0xfb,0x81,0x00,0x88,0xfb,0x7e,0x00,0x7a,0xfb,0x7c,0x00,0x6c,0xfb,0x79,0x00,0x5e,0xfb,0x76,0x00,0x50,0xfb,0x73,0x00,0x42,0xfb,0x70,0x00,0x33,0xfb,0x6d,0x00,0x25,0xfb,0x6a,0x00,0x17,0xfb,0x67,0x00,0x09,0xfb,0x64,0x00,0xfa,0xfa,0x61,0x00,0xec,0xfa,0x5e,0x00,0xdd,0xfa,0x5b,0x00,  \
    0xcf,0xfa,0x58,0x00,0xc0,0xfa,0x55,0x00,0xb2,0xfa,0x52,0x00,0xa3,0xfa,0x4e,0x00,0x94,0xfa,0x4b,0x00,0x85,0xfa,0x48,0x00,0x77,0xfa,0x45,0x00,0x68,0xfa,0x41,0x00,0x59,0xfa,0x3e,0x00,0x4a,0xfa,0x3b,0x00,0x3b,0xfa,0x37,0x00,0x2c,0xfa,0x34,0x00,0x1c,0xfa,0x30,0x00,0x0d,0xfa,0x2d,0x00,0xfe,0xf9,0x29,0x00,0xef,0xf9,0x26,0x00,0xdf,0xf9,0x22,0x00,0xd0,0xf9,0x1f,0x00,0xc0,0xf9,0x1b,0x00,0xb1,0xf9,0x18,0x00,0xa1,0xf9,0x14,0x00,0x91,0xf9,0x10,0x00,0x82,0xf9,  \
    0x0d,0x00,0x72,0xf9,0x09,0x00,0x62,0xf9,0x05,0x00,0x52,0xf9,0x01,0x00,0x42,0xf9,0xfe,0xff,0x32,0xf9,0xfa,0xff,0x21,0xf9,0xf6,0xff,0x11,0xf9,0xf2,0xff,0x01,0xf9,0xef,0xff,0xf0,0xf8,0xeb,0xff,0xe0,0xf8,0xe7,0xff,0xcf,0xf8,0xe3,0xff,0xbf,0xf8,0xdf,0xff,0xae,0xf8,0xdb,0xff,0x9d,0xf8,0xd7,0xff,0x8c,0xf8,0xd3,0xff,0x7b,0xf8,0xcf,0xff,0x6a,0xf8,0xcb,0xff,0x59,0xf8,0xc7,0xff,0x48,0xf8,0xc3,0xff,0x37,0xf8,0xbf,0xff,0x25,0xf8,0xbb,0xff,0x14,0xf8,0xb7,0xff,  \
    0x02,0xf8,0xb3,0xff,0xf1,0xf7,0xaf,0xff,0xdf,0xf7,0xab,0xff,0xcd,0xf7,0xa7,0xff,0xbc,0xf7,0xa3,0xff,0xaa,0xf7,0x9f,0xff,0x98,0xf7,0x9b,0xff,0x85,0xf7,0x97,0xff,0x73,0xf7,0x93,0xff,0x61,0xf7,0x8f,0xff,0x4f,0xf7,0x8a,0xff,0x3c,0xf7,0x86,0xff,0x2a,0xf7,0x82,0xff,0x17,0xf7,0x7e,0xff,0x04,0xf7,0x7a,0xff,0xf1,0xf6,0x76,0xff,0xde,0xf6,0x71,0xff,0xcb,0xf6,0x6d,0xff,0xb8,0xf6,0x69,0xff,0xa5,0xf6,0x65,0xff,0x92,0xf6,0x61,0xff,0x7e,0xf6,0x5d,0xff,0x6b,0xf6,  \
    0x58,0xff,0x57,0xf6,0x54,0xff,0x43,0xf6,0x50,0xff,0x2f,0xf6,0x4c,0xff,0x1c,0xf6,0x48,0xff,0x07,0xf6,0x44,0xff,0xf3,0xf5,0x40,0xff,0xdf,0xf5,0x3b,0xff,0xca,0xf5,0x37,0xff,0xb6,0xf5,0x33,0xff,0xa1,0xf5,0x2f,0xff,0x8c,0xf5,0x2b,0xff,0x78,0xf5,0x27,0xff,0x63,0xf5,0x23,0xff,0x4e,0xf5,0x1f,0xff,0x38,0xf5,0x1b,0xff,0x23,0xf5,0x17,0xff,0x0e,0xf5,0x13,0xff,0xf8,0xf4,0x0f,0xff,0xe3,0xf4,0x0b,0xff,0xcd,0xf4,0x07,0xff,0xb7,0xf4,0x03,0xff,0xa1,0xf4,0xff,0xfe,  \
    0x8b,0xf4,0xfb,0xfe,0x75,0xf4,0xf7,0xfe,0x5f,0xf4,0xf3,0xfe,0x48,0xf4,0xef,0xfe,0x32,0xf4,0xeb,0xfe,0x1b,0xf4,0xe7,0xfe,0x05,0xf4,0xe4,0xfe,0xee,0xf3,0xe0,0xfe,0xd7,0xf3,0xdc,0xfe,0xc0,0xf3,0xd8,0xfe,0xa9,0xf3,0xd5,0xfe,0x92,0xf3,0xd1,0xfe,0x7a,0xf3,0xcd,0xfe,0x63,0xf3,0xca,0xfe,0x4b,0xf3,0xc6,0xfe,0x33,0xf3,0xc2,0xfe,0x1b,0xf3,0xbf,0xfe,0x03,0xf3,0xbb,0xfe,0xeb,0xf2,0xb8,0xfe,0xd3,0xf2,0xb5,0xfe,0xba,0xf2,0xb1,0xfe,0xa2,0xf2,0xae,0xfe,0x89,0xf2,  \
    0xab,0xfe,0x70,0xf2,0xa7,0xfe,0x57,0xf2,0xa4,0xfe,0x3e,0xf2,0xa1,0xfe,0x25,0xf2,0x9e,0xfe,0x0c,0xf2,0x9b,0xfe,0xf2,0xf1,0x98,0xfe,0xd9,0xf1,0x95,0xfe,0xbf,0xf1,0x92,0xfe,0xa5,0xf1,0x8f,0xfe,0x8b,0xf1,0x8c,0xfe,0x71,0xf1,0x89,0xfe,0x57,0xf1,0x87,0xfe,0x3c,0xf1,0x84,0xfe,0x22,0xf1,0x81,0xfe,0x07,0xf1,0x7f,0xfe,0xec,0xf0,0x7c,0xfe,0xd2,0xf0,0x7a,0xfe,0xb7,0xf0,0x77,0xfe,0x9c,0xf0,0x75,0xfe,0x80,0xf0,0x73,0xfe,0x65,0xf0,0x70,0xfe,0x49,0xf0,0x6e,0xfe,  \
    0x2e,0xf0,0x6c,0xfe,0x12,0xf0,0x6a,0xfe,0xf6,0xef,0x68,0xfe,0xda,0xef,0x66,0xfe,0xbe,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xfe,0x4d,0x10,0x36,0xfe,0x31,0x10,0x38,0xfe,0x15,0x10,  \
    0x3a,0xfe,0xf8,0x0f,0x3d,0xfe,0xdc,0x0f,0x3f,0xfe,0xc0,0x0f,0x41,0xfe,0xa5,0x0f,0x44,0xfe,0x89,0x0f,0x46,0xfe,0x6d,0x0f,0x49,0xfe,0x52,0x0f,0x4b,0xfe,0x37,0x0f,0x4e,0xfe,0x1c,0x0f,0x50,0xfe,0x01,0x0f,0x53,0xfe,0xe6,0x0e,0x56,0xfe,0xcb,0x0e,0x59,0xfe,0xb0,0x0e,0x5c,0xfe,0x96,0x0e,0x5f,0xfe,0x7b,0x0e,0x62,0xfe,0x61,0x0e,0x65,0xfe,0x47,0x0e,0x68,0xfe,0x2d,0x0e,0x6b,0xfe,0x13,0x0e,0x6e,0xfe,0xf9,0x0d,0x71,0xfe,0xdf,0x0d,0x75,0xfe,0xc6,0x0d,0x78,0xfe,  \
    0xac,0x0d,0x7b,0xfe,0x93,0x0d,0x7f,0xfe,0x79,0x0d,0x82,0xfe,0x60,0x0d,0x86,0xfe,0x47,0x0d,0x89,0xfe,0x2e,0x0d,0x8d,0xfe,0x16,0x0d,0x90,0xfe,0xfd,0x0c,0x94,0xfe,0xe4,0x0c,0x98,0xfe,0xcc,0x0c,0x9b,0xfe,0xb4,0x0c,0x9f,0xfe,0x9b,0x0c,0xa3,0xfe,0x83,0x0c,0xa7,0xfe,0x6b,0x0c,0xaa,0xfe,0x53,0x0c,0xae,0xfe,0x3c,0x0c,0xb2,0xfe,0x25,0x0c,0xb7,0xfe,0x0e,0x0c,0xbb,0xfe,0xf7,0x0b,0xbf,0xfe,0xe0,0x0b,0xc3,0xfe,0xc9,0x0b,0xc7,0xfe,0xb3,0x0b,0xcc,0xfe,0x9c,0x0b,  \
    0xd0,0xfe,0x86,0x0b,0xd4,0xfe,0x70,0x0b,0xd9,0xfe,0x5a,0x0b,0xdd,0xfe,0x44,0x0b,0xe1,0xfe,0x2e,0x0b,0xe6,0xfe,0x18,0x0b,0xea,0xfe,0x03,0x0b,0xee,0xfe,0xed,0x0a,0xf3,0xfe,0xd8,0x0a,0xf7,0xfe,0xc3,0x0a,0xfc,0xfe,0xad,0x0a,0x00,0xff,0x98,0x0a,0x04,0xff,0x82,0x0a,0x08,0xff,0x6d,0x0a,0x0d,0xff,0x58,0x0a,0x11,0xff,0x43,0x0a,0x15,0xff,0x2e,0x0a,0x1a,0xff,0x19,0x0a,0x1e,0xff,0x04,0x0a,0x22,0xff,0xef,0x09,0x27,0xff,0xdb,0x09,0x2b,0xff,0xc6,0x09,0x2f,0xff,  \
    0xb2,0x09,0x34,0xff,0x9e,0x09,0x38,0xff,0x89,0x09,0x3c,0xff,0x75,0x09,0x41,0xff,0x61,0x09,0x45,0xff,0x4d,0x09,0x49,0xff,0x39,0x09,0x4e,0xff,0x26,0x09,0x52,0xff,0x12,0x09,0x57,0xff,0xff,0x08,0x5b,0xff,0xeb,0x08,0x5f,0xff,0xd8,0x08,0x64,0xff,0xc5,0x08,0x68,0xff,0xb2,0x08,0x6c,0xff,0x9f,0x08,0x71,0xff,0x8c,0x08,0x75,0xff,0x79,0x08,0x79,0xff,0x66,0x08,0x7e,0xff,0x53,0x08,0x82,0xff,0x41,0x08,0x86,0xff,0x2e,0x08,0x8a,0xff,0x1c,0x08,0x8f,0xff,0x09,0x08,  \
    0x93,0xff,0xf7,0x07,0x97,0xff,0xe5,0x07,0x9c,0xff,0xd3,0x07,0xa0,0xff,0xc1,0x07,0xa4,0xff,0xb0,0x07,0xa8,0xff,0x9e,0x07,0xad,0xff,0x8c,0x07,0xb1,0xff,0x7b,0x07,0xb5,0xff,0x6a,0x07,0xb9,0xff,0x58,0x07,0xbe,0xff,0x47,0x07,0xc2,0xff,0x36,0x07,0xc6,0xff,0x25,0x07,0xca,0xff,0x14,0x07,0xce,0xff,0x03,0x07,0xd2,0xff,0xf2,0x06,0xd6,0xff,0xe1,0x06,0xda,0xff,0xd0,0x06,0xde,0xff,0xc0,0x06,0xe3,0xff,0xaf,0x06,0xe7,0xff,0x9f,0x06,0xeb,0xff,0x8e,0x06,0xef,0xff,  \
    0x7e,0x06,0xf2,0xff,0x6e,0x06,0xf6,0xff,0x5d,0x06,0xfa,0xff,0x4d,0x06,0xfe,0xff,0x3d,0x06,0x02,0x00,0x2d,0x06,0x06,0x00,0x1d,0x06,0x0a,0x00,0x0d,0x06,0x0d,0x00,0xfd,0x05,0x11,0x00,0xed,0x05,0x15,0x00,0xde,0x05,0x19,0x00,0xce,0x05,0x1c,0x00,0xbe,0x05,0x20,0x00,0xaf,0x05,0x24,0x00,0x9f,0x05,0x27,0x00,0x90,0x05,0x2b,0x00,0x81,0x05,0x2f,0x00,0x71,0x05,0x32,0x00,0x62,0x05,0x36,0x00,0x53,0x05,0x39,0x00,0x44,0x05,0x3d,0x00,0x35,0x05,0x40,0x00,0x26,0x05,  \
    0x43,0x00,0x16,0x05,0x47,0x00,0x07,0x05,0x4a,0x00,0xf8,0x04,0x4d,0x00,0xe9,0x04,0x51,0x00,0xda,0x04,0x54,0x00,0xcb,0x04,0x57,0x00,0xbc,0x04,0x5a,0x00,0xad,0x04,0x5d,0x00,0x9e,0x04,0x60,0x00,0x90,0x04,0x64,0x00,0x81,0x04,0x67,0x00,0x72,0x04,0x6a,0x00,0x64,0x04,0x6d,0x00,0x55,0x04,0x70,0x00,0x47,0x04,0x73,0x00,0x38,0x04,0x76,0x00,0x2a,0x04,0x78,0x00,0x1c,0x04,0x7b,0x00,0x0d,0x04,0x7e,0x00,0xff,0x03,0x81,0x00,0xf1,0x03,0x84,0x00,0xe3,0x03,0x87,0x00,  \
    0xd5,0x03,0x89,0x00,0xc7,0x03,0x8c,0x00,0xb9,0x03,0x8f,0x00,0xab,0x03,0x92,0x00,0x9d,0x03,0x94,0x00,0x90,0x03,0x97,0x00,0x82,0x03,0x99,0x00,0x74,0x03,0x9c,0x00,0x67,0x03,0x9e,0x00,0x59,0x03,0xa1,0x00,0x4c,0x03,0xa3,0x00,0x3e,0x03,0xa6,0x00,0x31,0x03,0xa8,0x00,0x24,0x03,0xab,0x00,0x16,0x03,0xad,0x00,0x09,0x03,0xaf,0x00,0xfc,0x02,0xb1,0x00,0xee,0x02,0xb4,0x00,0xe1,0x02,0xb6,0x00,0xd4,0x02,0xb8,0x00,0xc7,0x02,0xba,0x00,0xba,0x02,0xbc,0x00,0xad,0x02,  \
    0xbe,0x00,0xa0,0x02,0xc0,0x00,0x93,0x02,0xc2,0x00,0x86,0x02,0xc4,0x00,0x79,0x02,0xc6,0x00,0x6c,0x02,0xc8,0x00,0x5f,0x02,0xca,0x00,0x52,0x02,0xcc,0x00,0x46,0x02,0xce,0x00,0x39,0x02,0xd0,0x00,0x2c,0x02,0xd1,0x00,0x20,0x02,0xd3,0x00,0x13,0x02,0xd5,0x00,0x06,0x02,0xd6,0x00,0xfa,0x01,0xd8,0x00,0xed,0x01,0xda,0x00,0xe1,0x01,0xdb,0x00,0xd4,0x01,0xdd,0x00,0xc7,0x01,0xde,0x00,0xbb,0x01,0xdf,0x00,0xae,0x01,0xe1,0x00,0xa2,0x01,0xe2,0x00,0x96,0x01,0xe4,0x00,  \
    0x89,0x01,0xe5,0x00,0x7d,0x01,0xe6,0x00,0x70,0x01,0xe7,0x00,0x64,0x01,0xe9,0x00,0x58,0x01,0xea,0x00,0x4b,0x01,0xeb,0x00,0x3f,0x01,0xec,0x00,0x33,0x01,0xed,0x00,0x26,0x01,0xee,0x00,0x1a,0x01,0xef,0x00,0x0e,0x01,0xf0,0x00,0x02,0x01,0xf1,0x00,0xf5,0x00,0xf2,0x00,0xe9,0x00,0xf3,0x00,0xdd,0x00,0xf3,0x00,0xd1,0x00,0xf4,0x00,0xc4,0x00,0xf5,0x00,0xb8,0x00,0xf6,0x00,0xac,0x00,0xf6,0x00,0xa0,0x00,0xf7,0x00,0x94,0x00,0xf7,0x00,0x87,0x00,0xf8,0x00,0x7b,0x00,  \
    0xf9,0x00,0x6f,0x00,0xf9,0x00,0x63,0x00,0xfa,0x00,0x57,0x00,0xfa,0x00,0x4b,0x00,0xfa,0x00,0x3f,0x00,0xfb,0x00,0x33,0x00,0xfb,0x00,0x26,0x00,0xfb,0x00,0x1a,0x00,0xfb,0x00,0x0e,0x00,0xfc,0x00,0x02,0x00,0xfc,0x00,0xf6,0xff,0xfc,0x00,0xea,0xff,0xfc,0x00,0xde,0xff,0xfc,0x00,0xd2,0xff,0xfc,0x00,0xc6,0xff,0xfc,0x00,0xba,0xff,0xfc,0x00,0xae,0xff,0xfc,0x00,0xa2,0xff,0xfc,0x00,0x95,0xff,0xfc,0x00,0x89,0xff,0xfc,0x00,0x7d,0xff,0xfb,0x00,0x71,0xff,0xfb,0x00,  \
    0x65,0xff,0xfb,0x00,0x59,0xff,0xfb,0x00,0x4d,0xff,0xfa,0x00,0x41,0xff,0xfa,0x00,0x34,0xff,0xf9,0x00,0x28,0xff,0xf9,0x00,0x1c,0xff,0xf9,0x00,0x10,0xff,0xf8,0x00,0x04,0xff,0xf7,0x00,0xf7,0xfe,0xf7,0x00,0xeb,0xfe,0xf6,0x00,0xdf,0xfe,0xf6,0x00,0xd3,0xfe,0xf5,0x00,0xc6,0xfe,0xf4,0x00,0xba,0xfe,0xf3,0x00,0xae,0xfe,0xf3,0x00,0xa1,0xfe,0xf2,0x00,0x95,0xfe,0xf1,0x00,0x89,0xfe,0xf0,0x00,0x7c,0xfe,0xef,0x00,0x70,0xfe,0xee,0x00,0x64,0xfe,0xed,0x00,0x58,0xfe,  \
    0xec,0x00,0x4c,0xfe,0xeb,0x00,0x3f,0xfe,0xea,0x00,0x33,0xfe,0xe9,0x00,0x27,0xfe,0xe8,0x00,0x1b,0xfe,0xe6,0x00,0x0f,0xfe,0xe5,0x00,0x03,0xfe,0xe4,0x00,0xf6,0xfd,0xe3,0x00,0xea,0xfd,0xe1,0x00,0xde,0xfd,0xe0,0x00,0xd2,0xfd,0xde,0x00,0xc6,0xfd,0xdd,0x00,0xb9,0xfd,0xdb,0x00,0xad,0xfd,0xda,0x00,0xa1,0xfd,0xd8,0x00,0x95,0xfd,0xd7,0x00,0x88,0xfd,0xd5,0x00,0x7c,0xfd,0xd3,0x00,0x70,0xfd,0xd2,0x00,0x64,0xfd,0xd0,0x00,0x57,0xfd,0xce,0x00,0x4b,0xfd,0xcc,0x00,  \
    0x3f,0xfd,0xca,0x00,0x32,0xfd,0xc9,0x00,0x26,0xfd,0xc7,0x00,0x19,0xfd,0xc5,0x00,0x0c,0xfd,0xc3,0x00,0xff,0xfc,0xc1,0x00,0xf2,0xfc,0xbf,0x00,0xe5,0xfc,0xbd,0x00,0xd7,0xfc,0xbb,0x00,0xca,0xfc,0xb9,0x00,0xbd,0xfc,0xb7,0x00,0xb0,0xfc,0xb4,0x00,0xa3,0xfc,0xb2,0x00,0x95,0xfc,0xb0,0x00,0x88,0xfc,0xae,0x00,0x7b,0xfc,0xac,0x00,0x6d,0xfc,0xa9,0x00,0x60,0xfc,0xa7,0x00,0x52,0xfc,0xa5,0x00,0x45,0xfc,0xa2,0x00,0x37,0xfc,0xa0,0x00,0x29,0xfc,0x9d,0x00,0x1c,0xfc,  \
    0x9b,0x00,0x0e,0xfc,0x98,0x00,0x00,0xfc,0x96,0x00,0xf2,0xfb,0x93,0x00,0xe4,0xfb,0x91,0x00,0xd6,0xfb,0x8e,0x00,0xc8,0xfb,0x8b,0x00,0xbb,0xfb,0x89,0x00,0xad,0xfb,0x86,0x00,0x9f,0xfb,0x83,0x00,0x91,0xfb,0x80,0x00,0x83,0xfb,0x7e,0x00,0x75,0xfb,0x7b,0x00,0x67,0xfb,0x78,0x00,0x59,0xfb,0x75,0x00,0x4b,0xfb,0x72,0x00,0x3d,0xfb,0x6f,0x00,0x2f,0xfb,0x6c,0x00,0x20,0xfb,0x69,0x00,0x12,0xfb,0x66,0x00,0x04,0xfb,0x63,0x00,0xf5,0xfa,0x60,0x00,0xe7,0xfa,0x5d,0x00,  \
    0xd8,0xfa,0x59,0x00,0xca,0xfa,0x56,0x00,0xbb,0xfa,0x53,0x00,0xac,0xfa,0x50,0x00,0x9e,0xfa,0x4c,0x00,0x8f,0xfa,0x49,0x00,0x80,0xfa,0x46,0x00,0x71,0xfa,0x43,0x00,0x62,0xfa,0x3f,0x00,0x53,0xfa,0x3c,0x00,0x44,0xfa,0x38,0x00,0x35,0xfa,0x35,0x00,0x26,0xfa,0x31,0x00,0x17,0xfa,0x2e,0x00,0x08,0xfa,0x2a,0x00,0xf9,0xf9,0x27,0x00,0xe9,0xf9,0x23,0x00,0xda,0xf9,0x20,0x00,0xca,0xf9,0x1c,0x00,0xbb,0xf9,0x18,0x00,0xab,0xf9,0x15,0x00,0x9c,0xf9,0x11,0x00,0x8c,0xf9,  \
    0x0d,0x00,0x7c,0xf9,0x09,0x00,0x6c,0xf9,0x06,0x00,0x5c,0xf9,0x02,0x00,0x4c,0xf9,0xfe,0xff,0x3c,0xf9,0xfa,0xff,0x2c,0xf9,0xf6,0xff,0x1c,0xf9,0xf3,0xff,0x0c,0xf9,0xef,0xff,0xfb,0xf8,0xeb,0xff,0xeb,0xf8,0xe7,0xff,0xda,0xf8,0xe3,0xff,0xca,0xf8,0xdf,0xff,0xb9,0xf8,0xdb,0xff,0xa8,0xf8,0xd7,0xff,0x98,0xf8,0xd3,0xff,0x87,0xf8,0xcf,0xff,0x76,0xf8,0xcb,0xff,0x65,0xf8,0xc7,0xff,0x54,0xf8,0xc3,0xff,0x43,0xf8,0xbf,0xff,0x31,0xf8,0xbb,0xff,0x20,0xf8,0xb6,0xff,  \
    0x0f,0xf8,0xb2,0xff,0xfd,0xf7,0xae,0xff,0xeb,0xf7,0xaa,0xff,0xda,0xf7,0xa6,0xff,0xc8,0xf7,0xa2,0xff,0xb6,0xf7,0x9e,0xff,0xa4,0xf7,0x99,0xff,0x92,0xf7,0x95,0xff,0x80,0xf7,0x91,0xff,0x6e,0xf7,0x8d,0xff,0x5c,0xf7,0x89,0xff,0x49,0xf7,0x84,0xff,0x37,0xf7,0x80,0xff,0x24,0xf7,0x7c,0xff,0x12,0xf7,0x78,0xff,0xff,0xf6,0x73,0xff,0xec,0xf6,0x6f,0xff,0xd9,0xf6,0x6b,0xff,0xc6,0xf6,0x67,0xff,0xb3,0xf6,0x62,0xff,0xa0,0xf6,0x5e,0xff,0x8c,0xf6,0x5a,0xff,0x79,0xf6,  \
    0x55,0xff,0x66,0xf6,0x51,0xff,0x52,0xf6,0x4d,0xff,0x3e,0xf6,0x49,0xff,0x2a,0xf6,0x44,0xff,0x17,0xf6,0x40,0xff,0x02,0xf6,0x3c,0xff,0xee,0xf5,0x38,0xff,0xda,0xf5,0x33,0xff,0xc5,0xf5,0x2f,0xff,0xb1,0xf5,0x2b,0xff,0x9c,0xf5,0x27,0xff,0x88,0xf5,0x23,0xff,0x73,0xf5,0x1e,0xff,0x5e,0xf5,0x1a,0xff,0x49,0xf5,0x16,0xff,0x34,0xf5,0x12,0xff,0x1e,0xf5,0x0e,0xff,0x09,0xf5,0x0a,0xff,0xf3,0xf4,0x06,0xff,0xde,0xf4,0x02,0xff,0xc8,0xf4,0xfd,0xfe,0xb2,0xf4,0xf9,0xfe,  \
    0x9c,0xf4,0xf5,0xfe,0x86,0xf4,0xf1,0xfe,0x70,0xf4,0xed,0xfe,0x5a,0xf4,0xe9,0xfe,0x44,0xf4,0xe5,0xfe,0x2d,0xf4,0xe1,0xfe,0x17,0xf4,0xdd,0xfe,0x00,0xf4,0xd9,0xfe,0xea,0xf3,0xd6,0xfe,0xd3,0xf3,0xd2,0xfe,0xbc,0xf3,0xce,0xfe,0xa4,0xf3,0xca,0xfe,0x8d,0xf3,0xc6,0xfe,0x76,0xf3,0xc2,0xfe,0x5e,0xf3,0xbf,0xfe,0x47,0xf3,0xbb,0xfe,0x2f,0xf3,0xb7,0xfe,0x17,0xf3,0xb4,0xfe,0xff,0xf2,0xb0,0xfe,0xe7,0xf2,0xad,0xfe,0xcf,0xf2,0xa9,0xfe,0xb6,0xf2,0xa6,0xfe,0x9e,0xf2,  \
    0xa2,0xfe,0x85,0xf2,0x9f,0xfe,0x6c,0xf2,0x9c,0xfe,0x53,0xf2,0x98,0xfe,0x3a,0xf2,0x95,0xfe,0x21,0xf2,0x92,0xfe,0x08,0xf2,0x8f,0xfe,0xee,0xf1,0x8c,0xfe,0xd5,0xf1,0x88,0xfe,0xbb,0xf1,0x85,0xfe,0xa1,0xf1,0x83,0xfe,0x87,0xf1,0x80,0xfe,0x6d,0xf1,0x7d,0xfe,0x53,0xf1,0x7a,0xfe,0x39,0xf1,0x77,0xfe,0x1e,0xf1,0x74,0xfe,0x03,0xf1,0x72,0xfe,0xe9,0xf0,0x6f,0xfe,0xce,0xf0,0x6d,0xfe,0xb3,0xf0,0x6a,0xfe,0x98,0xf0,0x68,0xfe,0x7d,0xf0,0x65,0xfe,0x61,0xf0,0x63,0xfe,  \
    0x46,0xf0,0x61,0xfe,0x2a,0xf0,0x5e,0xfe,0x0e,0xf0,0x5c,0xfe,0xf3,0xef,0x5a,0xfe,0xd7,0xef,0x58,0xfe,0xba,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x29,0xfe,0x51,0x10,0x2b,0xfe,0x35,0x10,  \
    0x2d,0xfe,0x18,0x10,0x2f,0xfe,0xfc,0x0f,0x31,0xfe,0xe0,0x0f,0x34,0xfe,0xc4,0x0f,0x36,0xfe,0xa9,0x0f,0x39,0xfe,0x8d,0x0f,0x3b,0xfe,0x71,0x0f,0x3e,0xfe,0x56,0x0f,0x40,0xfe,0x3b,0x0f,0x43,0xfe,0x20,0x0f,0x46,0xfe,0x05,0x0f,0x49,0xfe,0xea,0x0e,0x4b,0xfe,0xcf,0x0e,0x4e,0xfe,0xb4,0x0e,0x51,0xfe,0x9a,0x0e,0x54,0xfe,0x7f,0x0e,0x57,0xfe,0x65,0x0e,0x5b,0xfe,0x4b,0x0e,0x5e,0xfe,0x31,0x0e,0x61,0xfe,0x17,0x0e,0x64,0xfe,0xfd,0x0d,0x67,0xfe,0xe3,0x0d,0x6b,0xfe,  \
    0xca,0x0d,0x6e,0xfe,0xb0,0x0d,0x71,0xfe,0x97,0x0d,0x75,0xfe,0x7e,0x0d,0x78,0xfe,0x64,0x0d,0x7c,0xfe,0x4b,0x0d,0x80,0xfe,0x33,0x0d,0x83,0xfe,0x1a,0x0d,0x87,0xfe,0x01,0x0d,0x8b,0xfe,0xe9,0x0c,0x8e,0xfe,0xd0,0x0c,0x92,0xfe,0xb8,0x0c,0x96,0xfe,0xa0,0x0c,0x9a,0xfe,0x88,0x0c,0x9e,0xfe,0x70,0x0c,0xa1,0xfe,0x58,0x0c,0xa5,0xfe,0x40,0x0c,0xaa,0xfe,0x29,0x0c,0xae,0xfe,0x12,0x0c,0xb2,0xfe,0xfb,0x0b,0xb6,0xfe,0xe5,0x0b,0xbb,0xfe,0xce,0x0b,0xbf,0xfe,0xb7,0x0b,  \
    0xc3,0xfe,0xa1,0x0b,0xc8,0xfe,0x8b,0x0b,0xcc,0xfe,0x75,0x0b,0xd1,0xfe,0x5f,0x0b,0xd5,0xfe,0x49,0x0b,0xd9,0xfe,0x33,0x0b,0xde,0xfe,0x1d,0x0b,0xe2,0xfe,0x08,0x0b,0xe7,0xfe,0xf2,0x0a,0xeb,0xfe,0xdd,0x0a,0xf0,0xfe,0xc8,0x0a,0xf4,0xfe,0xb2,0x0a,0xf9,0xfe,0x9d,0x0a,0xfd,0xfe,0x87,0x0a,0x01,0xff,0x72,0x0a,0x06,0xff,0x5d,0x0a,0x0a,0xff,0x48,0x0a,0x0f,0xff,0x33,0x0a,0x13,0xff,0x1e,0x0a,0x17,0xff,0x09,0x0a,0x1c,0xff,0xf5,0x09,0x20,0xff,0xe0,0x09,0x25,0xff,  \
    0xcc,0x09,0x29,0xff,0xb7,0x09,0x2d,0xff,0xa3,0x09,0x32,0xff,0x8f,0x09,0x36,0xff,0x7b,0x09,0x3b,0xff,0x67,0x09,0x3f,0xff,0x53,0x09,0x44,0xff,0x3f,0x09,0x48,0xff,0x2b,0x09,0x4d,0xff,0x18,0x09,0x51,0xff,0x04,0x09,0x55,0xff,0xf1,0x08,0x5a,0xff,0xdd,0x08,0x5e,0xff,0xca,0x08,0x63,0xff,0xb7,0x08,0x67,0xff,0xa4,0x08,0x6c,0xff,0x91,0x08,0x70,0xff,0x7e,0x08,0x74,0xff,0x6b,0x08,0x79,0xff,0x59,0x08,0x7d,0xff,0x46,0x08,0x81,0xff,0x34,0x08,0x86,0xff,0x21,0x08,  \
    0x8a,0xff,0x0f,0x08,0x8f,0xff,0xfd,0x07,0x93,0xff,0xeb,0x07,0x97,0xff,0xd9,0x07,0x9c,0xff,0xc7,0x07,0xa0,0xff,0xb5,0x07,0xa4,0xff,0xa4,0x07,0xa9,0xff,0x92,0x07,0xad,0xff,0x81,0x07,0xb1,0xff,0x6f,0x07,0xb6,0xff,0x5e,0x07,0xba,0xff,0x4d,0x07,0xbe,0xff,0x3b,0x07,0xc2,0xff,0x2a,0x07,0xc7,0xff,0x19,0x07,0xcb,0xff,0x08,0x07,0xcf,0xff,0xf8,0x06,0xd3,0xff,0xe7,0x06,0xd7,0xff,0xd6,0x06,0xdb,0xff,0xc6,0x06,0xdf,0xff,0xb5,0x06,0xe4,0xff,0xa4,0x06,0xe8,0xff,  \
    0x94,0x06,0xec,0xff,0x84,0x06,0xf0,0xff,0x73,0x06,0xf4,0xff,0x63,0x06,0xf8,0xff,0x53,0x06,0xfc,0xff,0x43,0x06,0xff,0xff,0x33,0x06,0x03,0x00,0x23,0x06,0x07,0x00,0x13,0x06,0x0b,0x00,0x03,0x06,0x0f,0x00,0xf3,0x05,0x13,0x00,0xe3,0x05,0x17,0x00,0xd4,0x05,0x1a,0x00,0xc4,0x05,0x1e,0x00,0xb5,0x05,0x22,0x00,0xa5,0x05,0x25,0x00,0x96,0x05,0x29,0x00,0x86,0x05,0x2d,0x00,0x77,0x05,0x30,0x00,0x68,0x05,0x34,0x00,0x59,0x05,0x37,0x00,0x49,0x05,0x3b,0x00,0x3a,0x05,  \
    0x3e,0x00,0x2b,0x05,0x42,0x00,0x1c,0x05,0x45,0x00,0x0d,0x05,0x49,0x00,0xfd,0x04,0x4c,0x00,0xee,0x04,0x4f,0x00,0xdf,0x04,0x53,0x00,0xd0,0x04,0x56,0x00,0xc1,0x04,0x59,0x00,0xb2,0x04,0x5c,0x00,0xa4,0x04,0x5f,0x00,0x95,0x04,0x63,0x00,0x86,0x04,0x66,0x00,0x77,0x04,0x69,0x00,0x69,0x04,0x6c,0x00,0x5a,0x04,0x6f,0x00,0x4c,0x04,0x72,0x00,0x3d,0x04,0x75,0x00,0x2f,0x04,0x78,0x00,0x20,0x04,0x7b,0x00,0x12,0x04,0x7e,0x00,0x04,0x04,0x81,0x00,0xf6,0x03,0x83,0x00,  \
    0xe7,0x03,0x86,0x00,0xd9,0x03,0x89,0x00,0xcb,0x03,0x8c,0x00,0xbd,0x03,0x8f,0x00,0xb0,0x03,0x91,0x00,0xa2,0x03,0x94,0x00,0x94,0x03,0x97,0x00,0x86,0x03,0x99,0x00,0x79,0x03,0x9c,0x00,0x6b,0x03,0x9e,0x00,0x5e,0x03,0xa1,0x00,0x50,0x03,0xa3,0x00,0x43,0x03,0xa6,0x00,0x35,0x03,0xa8,0x00,0x28,0x03,0xab,0x00,0x1a,0x03,0xad,0x00,0x0d,0x03,0xaf,0x00,0x00,0x03,0xb2,0x00,0xf2,0x02,0xb4,0x00,0xe5,0x02,0xb6,0x00,0xd8,0x02,0xb8,0x00,0xcb,0x02,0xbb,0x00,0xbd,0x02,  \
    0xbd,0x00,0xb0,0x02,0xbf,0x00,0xa3,0x02,0xc1,0x00,0x96,0x02,0xc3,0x00,0x89,0x02,0xc5,0x00,0x7c,0x02,0xc7,0x00,0x6f,0x02,0xc9,0x00,0x62,0x02,0xcb,0x00,0x56,0x02,0xcd,0x00,0x49,0x02,0xce,0x00,0x3c,0x02,0xd0,0x00,0x2f,0x02,0xd2,0x00,0x23,0x02,0xd4,0x00,0x16,0x02,0xd5,0x00,0x09,0x02,0xd7,0x00,0xfd,0x01,0xd9,0x00,0xf0,0x01,0xda,0x00,0xe3,0x01,0xdc,0x00,0xd7,0x01,0xdd,0x00,0xca,0x01,0xdf,0x00,0xbe,0x01,0xe0,0x00,0xb1,0x01,0xe2,0x00,0xa5,0x01,0xe3,0x00,  \
    0x98,0x01,0xe5,0x00,0x8c,0x01,0xe6,0x00,0x7f,0x01,0xe7,0x00,0x73,0x01,0xe8,0x00,0x66,0x01,0xea,0x00,0x5a,0x01,0xeb,0x00,0x4d,0x01,0xec,0x00,0x41,0x01,0xed,0x00,0x35,0x01,0xee,0x00,0x28,0x01,0xef,0x00,0x1c,0x01,0xf0,0x00,0x10,0x01,0xf1,0x00,0x03,0x01,0xf2,0x00,0xf7,0x00,0xf3,0x00,0xeb,0x00,0xf4,0x00,0xde,0x00,0xf5,0x00,0xd2,0x00,0xf5,0x00,0xc6,0x00,0xf6,0x00,0xba,0x00,0xf7,0x00,0xad,0x00,0xf7,0x00,0xa1,0x00,0xf8,0x00,0x95,0x00,0xf9,0x00,0x89,0x00,  \
    0xf9,0x00,0x7c,0x00,0xfa,0x00,0x70,0x00,0xfa,0x00,0x64,0x00,0xfb,0x00,0x58,0x00,0xfb,0x00,0x4c,0x00,0xfc,0x00,0x3f,0x00,0xfc,0x00,0x33,0x00,0xfc,0x00,0x27,0x00,0xfd,0x00,0x1b,0x00,0xfd,0x00,0x0f,0x00,0xfd,0x00,0x03,0x00,0xfd,0x00,0xf6,0xff,0xfd,0x00,0xea,0xff,0xfd,0x00,0xde,0xff,0xfd,0x00,0xd2,0xff,0xfd,0x00,0xc6,0xff,0xfd,0x00,0xba,0xff,0xfd,0x00,0xae,0xff,0xfd,0x00,0xa1,0xff,0xfd,0x00,0x95,0xff,0xfd,0x00,0x89,0xff,0xfd,0x00,0x7d,0xff,0xfd,0x00,  \
    0x71,0xff,0xfc,0x00,0x64,0xff,0xfc,0x00,0x58,0xff,0xfc,0x00,0x4c,0xff,0xfc,0x00,0x40,0xff,0xfb,0x00,0x34,0xff,0xfb,0x00,0x27,0xff,0xfa,0x00,0x1b,0xff,0xfa,0x00,0x0f,0xff,0xf9,0x00,0x02,0xff,0xf9,0x00,0xf6,0xfe,0xf8,0x00,0xea,0xfe,0xf7,0x00,0xde,0xfe,0xf7,0x00,0xd1,0xfe,0xf6,0x00,0xc5,0xfe,0xf5,0x00,0xb8,0xfe,0xf5,0x00,0xac,0xfe,0xf4,0x00,0xa0,0xfe,0xf3,0x00,0x93,0xfe,0xf2,0x00,0x87,0xfe,0xf1,0x00,0x7a,0xfe,0xf0,0x00,0x6e,0xfe,0xef,0x00,0x62,0xfe,  \
    0xee,0x00,0x56,0xfe,0xed,0x00,0x49,0xfe,0xec,0x00,0x3d,0xfe,0xeb,0x00,0x31,0xfe,0xea,0x00,0x25,0xfe,0xe9,0x00,0x19,0xfe,0xe7,0x00,0x0c,0xfe,0xe6,0x00,0x00,0xfe,0xe5,0x00,0xf4,0xfd,0xe3,0x00,0xe8,0xfd,0xe2,0x00,0xdc,0xfd,0xe1,0x00,0xcf,0xfd,0xdf,0x00,0xc3,0xfd,0xde,0x00,0xb7,0xfd,0xdc,0x00,0xab,0xfd,0xdb,0x00,0x9e,0xfd,0xd9,0x00,0x92,0xfd,0xd7,0x00,0x86,0xfd,0xd6,0x00,0x79,0xfd,0xd4,0x00,0x6d,0xfd,0xd2,0x00,0x61,0xfd,0xd0,0x00,0x54,0xfd,0xcf,0x00,  \
    0x48,0xfd,0xcd,0x00,0x3b,0xfd,0xcb,0x00,0x2f,0xfd,0xc9,0x00,0x23,0xfd,0xc7,0x00,0x16,0xfd,0xc5,0x00,0x08,0xfd,0xc3,0x00,0xfb,0xfc,0xc1,0x00,0xee,0xfc,0xbf,0x00,0xe1,0xfc,0xbd,0x00,0xd4,0xfc,0xbb,0x00,0xc7,0xfc,0xb9,0x00,0xb9,0xfc,0xb7,0x00,0xac,0xfc,0xb4,0x00,0x9f,0xfc,0xb2,0x00,0x91,0xfc,0xb0,0x00,0x84,0xfc,0xae,0x00,0x77,0xfc,0xab,0x00,0x69,0xfc,0xa9,0x00,0x5c,0xfc,0xa7,0x00,0x4e,0xfc,0xa4,0x00,0x40,0xfc,0xa2,0x00,0x33,0xfc,0x9f,0x00,0x25,0xfc,  \
    0x9d,0x00,0x17,0xfc,0x9a,0x00,0x09,0xfc,0x98,0x00,0xfc,0xfb,0x95,0x00,0xee,0xfb,0x93,0x00,0xe0,0xfb,0x90,0x00,0xd2,0xfb,0x8d,0x00,0xc4,0xfb,0x8b,0x00,0xb6,0xfb,0x88,0x00,0xa8,0xfb,0x85,0x00,0x9a,0xfb,0x82,0x00,0x8c,0xfb,0x7f,0x00,0x7e,0xfb,0x7d,0x00,0x70,0xfb,0x7a,0x00,0x62,0xfb,0x77,0x00,0x54,0xfb,0x74,0x00,0x46,0xfb,0x71,0x00,0x38,0xfb,0x6e,0x00,0x2a,0xfb,0x6b,0x00,0x1b,0xfb,0x68,0x00,0x0d,0xfb,0x64,0x00,0xff,0xfa,0x61,0x00,0xf0,0xfa,0x5e,0x00,  \
    0xe2,0xfa,0x5b,0x00,0xd3,0xfa,0x58,0x00,0xc5,0xfa,0x54,0x00,0xb6,0xfa,0x51,0x00,0xa7,0xfa,0x4e,0x00,0x98,0xfa,0x4b,0x00,0x8a,0xfa,0x47,0x00,0x7b,0xfa,0x44,0x00,0x6c,0xfa,0x40,0x00,0x5d,0xfa,0x3d,0x00,0x4e,0xfa,0x39,0x00,0x3f,0xfa,0x36,0x00,0x30,0xfa,0x32,0x00,0x21,0xfa,0x2f,0x00,0x12,0xfa,0x2b,0x00,0x02,0xfa,0x28,0x00,0xf3,0xf9,0x24,0x00,0xe4,0xf9,0x20,0x00,0xd4,0xf9,0x1d,0x00,0xc5,0xf9,0x19,0x00,0xb5,0xf9,0x15,0x00,0xa6,0xf9,0x12,0x00,0x96,0xf9,  \
    0x0e,0x00,0x86,0xf9,0x0a,0x00,0x76,0xf9,0x06,0x00,0x67,0xf9,0x02,0x00,0x57,0xf9,0xfe,0xff,0x47,0xf9,0xfb,0xff,0x37,0xf9,0xf7,0xff,0x27,0xf9,0xf3,0xff,0x16,0xf9,0xef,0xff,0x06,0xf9,0xeb,0xff,0xf6,0xf8,0xe7,0xff,0xe5,0xf8,0xe3,0xff,0xd5,0xf8,0xdf,0xff,0xc4,0xf8,0xdb,0xff,0xb4,0xf8,0xd7,0xff,0xa3,0xf8,0xd3,0xff,0x92,0xf8,0xcf,0xff,0x81,0xf8,0xca,0xff,0x70,0xf8,0xc6,0xff,0x5f,0xf8,0xc2,0xff,0x4e,0xf8,0xbe,0xff,0x3d,0xf8,0xba,0xff,0x2c,0xf8,0xb6,0xff,  \
    0x1a,0xf8,0xb1,0xff,0x09,0xf8,0xad,0xff,0xf8,0xf7,0xa9,0xff,0xe6,0xf7,0xa5,0xff,0xd4,0xf7,0xa1,0xff,0xc3,0xf7,0x9c,0xff,0xb1,0xf7,0x98,0xff,0x9f,0xf7,0x94,0xff,0x8d,0xf7,0x8f,0xff,0x7b,0xf7,0x8b,0xff,0x69,0xf7,0x87,0xff,0x56,0xf7,0x82,0xff,0x44,0xf7,0x7e,0xff,0x31,0xf7,0x7a,0xff,0x1f,0xf7,0x75,0xff,0x0c,0xf7,0x71,0xff,0xfa,0xf6,0x6d,0xff,0xe7,0xf6,0x68,0xff,0xd4,0xf6,0x64,0xff,0xc1,0xf6,0x60,0xff,0xae,0xf6,0x5b,0xff,0x9b,0xf6,0x57,0xff,0x87,0xf6,  \
    0x53,0xff,0x74,0xf6,0x4e,0xff,0x60,0xf6,0x4a,0xff,0x4d,0xf6,0x45,0xff,0x39,0xf6,0x41,0xff,0x25,0xf6,0x3d,0xff,0x11,0xf6,0x38,0xff,0xfd,0xf5,0x34,0xff,0xe9,0xf5,0x30,0xff,0xd5,0xf5,0x2b,0xff,0xc0,0xf5,0x27,0xff,0xac,0xf5,0x23,0xff,0x97,0xf5,0x1e,0xff,0x83,0xf5,0x1a,0xff,0x6e,0xf5,0x16,0xff,0x59,0xf5,0x12,0xff,0x44,0xf5,0x0d,0xff,0x2f,0xf5,0x09,0xff,0x19,0xf5,0x05,0xff,0x04,0xf5,0x01,0xff,0xef,0xf4,0xfc,0xfe,0xd9,0xf4,0xf8,0xfe,0xc3,0xf4,0xf4,0xfe,  \
    0xae,0xf4,0xf0,0xfe,0x98,0xf4,0xec,0xfe,0x82,0xf4,0xe8,0xfe,0x6c,0xf4,0xe3,0xfe,0x56,0xf4,0xdf,0xfe,0x3f,0xf4,0xdb,0xfe,0x29,0xf4,0xd7,0xfe,0x12,0xf4,0xd3,0xfe,0xfc,0xf3,0xcf,0xfe,0xe5,0xf3,0xcb,0xfe,0xce,0xf3,0xc7,0xfe,0xb7,0xf3,0xc3,0xfe,0xa0,0xf3,0xbf,0xfe,0x89,0xf3,0xbb,0xfe,0x72,0xf3,0xb8,0xfe,0x5a,0xf3,0xb4,0xfe,0x42,0xf3,0xb0,0xfe,0x2b,0xf3,0xac,0xfe,0x13,0xf3,0xa8,0xfe,0xfb,0xf2,0xa5,0xfe,0xe3,0xf2,0xa1,0xfe,0xcb,0xf2,0x9e,0xfe,0xb2,0xf2,  \
    0x9a,0xfe,0x9a,0xf2,0x96,0xfe,0x81,0xf2,0x93,0xfe,0x68,0xf2,0x90,0xfe,0x4f,0xf2,0x8c,0xfe,0x36,0xf2,0x89,0xfe,0x1d,0xf2,0x86,0xfe,0x04,0xf2,0x82,0xfe,0xea,0xf1,0x7f,0xfe,0xd1,0xf1,0x7c,0xfe,0xb7,0xf1,0x79,0xfe,0x9d,0xf1,0x76,0xfe,0x83,0xf1,0x73,0xfe,0x69,0xf1,0x70,0xfe,0x4f,0xf1,0x6d,0xfe,0x35,0xf1,0x6a,0xfe,0x1a,0xf1,0x67,0xfe,0x00,0xf1,0x65,0xfe,0xe5,0xf0,0x62,0xfe,0xca,0xf0,0x5f,0xfe,0xaf,0xf0,0x5d,0xfe,0x94,0xf0,0x5a,0xfe,0x79,0xf0,0x58,0xfe,  \
    0x5e,0xf0,0x55,0xfe,0x42,0xf0,0x53,0xfe,0x27,0xf0,0x51,0xfe,0x0b,0xf0,0x4f,0xfe,0xef,0xef,0x4c,0xfe,0xd3,0xef,0x4a,0xfe,0xb7,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1d,0xfe,0x55,0x10,  \
    0x20,0xfe,0x39,0x10,0x22,0xfe,0x1c,0x10,0x24,0xfe,0x00,0x10,0x26,0xfe,0xe4,0x0f,0x29,0xfe,0xc8,0x0f,0x2b,0xfe,0xad,0x0f,0x2e,0xfe,0x91,0x0f,0x30,0xfe,0x75,0x0f,0x33,0xfe,0x5a,0x0f,0x35,0xfe,0x3f,0x0f,0x38,0xfe,0x24,0x0f,0x3b,0xfe,0x09,0x0f,0x3e,0xfe,0xee,0x0e,0x41,0xfe,0xd3,0x0e,0x44,0xfe,0xb8,0x0e,0x47,0xfe,0x9e,0x0e,0x4a,0xfe,0x83,0x0e,0x4d,0xfe,0x69,0x0e,0x50,0xfe,0x4f,0x0e,0x53,0xfe,0x35,0x0e,0x57,0xfe,0x1b,0x0e,0x5a,0xfe,0x01,0x0e,0x5d,0xfe,  \
    0xe8,0x0d,0x61,0xfe,0xce,0x0d,0x64,0xfe,0xb5,0x0d,0x68,0xfe,0x9b,0x0d,0x6b,0xfe,0x82,0x0d,0x6f,0xfe,0x69,0x0d,0x72,0xfe,0x50,0x0d,0x76,0xfe,0x37,0x0d,0x7a,0xfe,0x1e,0x0d,0x7d,0xfe,0x06,0x0d,0x81,0xfe,0xed,0x0c,0x85,0xfe,0xd5,0x0c,0x89,0xfe,0xbc,0x0c,0x8d,0xfe,0xa4,0x0c,0x91,0xfe,0x8c,0x0c,0x94,0xfe,0x74,0x0c,0x98,0xfe,0x5c,0x0c,0x9d,0xfe,0x45,0x0c,0xa1,0xfe,0x2e,0x0c,0xa5,0xfe,0x17,0x0c,0xa9,0xfe,0x00,0x0c,0xae,0xfe,0xe9,0x0b,0xb2,0xfe,0xd3,0x0b,  \
    0xb7,0xfe,0xbc,0x0b,0xbb,0xfe,0xa6,0x0b,0xc0,0xfe,0x90,0x0b,0xc4,0xfe,0x7a,0x0b,0xc9,0xfe,0x64,0x0b,0xcd,0xfe,0x4e,0x0b,0xd2,0xfe,0x38,0x0b,0xd6,0xfe,0x22,0x0b,0xdb,0xfe,0x0d,0x0b,0xdf,0xfe,0xf8,0x0a,0xe4,0xfe,0xe2,0x0a,0xe9,0xfe,0xcd,0x0a,0xed,0xfe,0xb8,0x0a,0xf2,0xfe,0xa2,0x0a,0xf6,0xfe,0x8d,0x0a,0xfa,0xfe,0x77,0x0a,0xff,0xfe,0x62,0x0a,0x03,0xff,0x4d,0x0a,0x08,0xff,0x38,0x0a,0x0c,0xff,0x23,0x0a,0x11,0xff,0x0f,0x0a,0x15,0xff,0xfa,0x09,0x1a,0xff,  \
    0xe5,0x09,0x1e,0xff,0xd1,0x09,0x23,0xff,0xbd,0x09,0x27,0xff,0xa8,0x09,0x2c,0xff,0x94,0x09,0x30,0xff,0x80,0x09,0x35,0xff,0x6c,0x09,0x39,0xff,0x58,0x09,0x3e,0xff,0x44,0x09,0x42,0xff,0x31,0x09,0x47,0xff,0x1d,0x09,0x4b,0xff,0x0a,0x09,0x50,0xff,0xf6,0x08,0x54,0xff,0xe3,0x08,0x59,0xff,0xd0,0x08,0x5d,0xff,0xbd,0x08,0x62,0xff,0xaa,0x08,0x66,0xff,0x97,0x08,0x6b,0xff,0x84,0x08,0x6f,0xff,0x71,0x08,0x74,0xff,0x5e,0x08,0x78,0xff,0x4c,0x08,0x7d,0xff,0x39,0x08,  \
    0x81,0xff,0x27,0x08,0x86,0xff,0x15,0x08,0x8a,0xff,0x02,0x08,0x8e,0xff,0xf0,0x07,0x93,0xff,0xde,0x07,0x97,0xff,0xcd,0x07,0x9c,0xff,0xbb,0x07,0xa0,0xff,0xa9,0x07,0xa5,0xff,0x98,0x07,0xa9,0xff,0x86,0x07,0xad,0xff,0x75,0x07,0xb2,0xff,0x64,0x07,0xb6,0xff,0x52,0x07,0xba,0xff,0x41,0x07,0xbf,0xff,0x30,0x07,0xc3,0xff,0x1f,0x07,0xc7,0xff,0x0e,0x07,0xcc,0xff,0xfd,0x06,0xd0,0xff,0xed,0x06,0xd4,0xff,0xdc,0x06,0xd8,0xff,0xcb,0x06,0xdc,0xff,0xbb,0x06,0xe1,0xff,  \
    0xaa,0x06,0xe5,0xff,0x9a,0x06,0xe9,0xff,0x89,0x06,0xed,0xff,0x79,0x06,0xf1,0xff,0x69,0x06,0xf5,0xff,0x59,0x06,0xf9,0xff,0x49,0x06,0xfd,0xff,0x38,0x06,0x01,0x00,0x28,0x06,0x05,0x00,0x19,0x06,0x09,0x00,0x09,0x06,0x0d,0x00,0xf9,0x05,0x10,0x00,0xe9,0x05,0x14,0x00,0xd9,0x05,0x18,0x00,0xca,0x05,0x1c,0x00,0xba,0x05,0x20,0x00,0xab,0x05,0x23,0x00,0x9b,0x05,0x27,0x00,0x8c,0x05,0x2b,0x00,0x7d,0x05,0x2f,0x00,0x6d,0x05,0x32,0x00,0x5e,0x05,0x36,0x00,0x4f,0x05,  \
    0x39,0x00,0x40,0x05,0x3d,0x00,0x31,0x05,0x40,0x00,0x21,0x05,0x44,0x00,0x12,0x05,0x47,0x00,0x03,0x05,0x4b,0x00,0xf4,0x04,0x4e,0x00,0xe5,0x04,0x51,0x00,0xd6,0x04,0x55,0x00,0xc7,0x04,0x58,0x00,0xb8,0x04,0x5b,0x00,0xa9,0x04,0x5e,0x00,0x9a,0x04,0x61,0x00,0x8b,0x04,0x65,0x00,0x7d,0x04,0x68,0x00,0x6e,0x04,0x6b,0x00,0x5f,0x04,0x6e,0x00,0x51,0x04,0x71,0x00,0x42,0x04,0x74,0x00,0x34,0x04,0x77,0x00,0x25,0x04,0x7a,0x00,0x17,0x04,0x7d,0x00,0x09,0x04,0x80,0x00,  \
    0xfa,0x03,0x83,0x00,0xec,0x03,0x86,0x00,0xde,0x03,0x88,0x00,0xd0,0x03,0x8b,0x00,0xc2,0x03,0x8e,0x00,0xb4,0x03,0x91,0x00,0xa6,0x03,0x94,0x00,0x99,0x03,0x96,0x00,0x8b,0x03,0x99,0x00,0x7d,0x03,0x9c,0x00,0x70,0x03,0x9e,0x00,0x62,0x03,0xa1,0x00,0x54,0x03,0xa3,0x00,0x47,0x03,0xa6,0x00,0x39,0x03,0xa8,0x00,0x2c,0x03,0xab,0x00,0x1e,0x03,0xad,0x00,0x11,0x03,0xaf,0x00,0x04,0x03,0xb2,0x00,0xf6,0x02,0xb4,0x00,0xe9,0x02,0xb6,0x00,0xdc,0x02,0xb9,0x00,0xce,0x02,  \
    0xbb,0x00,0xc1,0x02,0xbd,0x00,0xb4,0x02,0xbf,0x00,0xa7,0x02,0xc1,0x00,0x9a,0x02,0xc3,0x00,0x8d,0x02,0xc5,0x00,0x80,0x02,0xc7,0x00,0x73,0x02,0xc9,0x00,0x66,0x02,0xcb,0x00,0x59,0x02,0xcd,0x00,0x4c,0x02,0xcf,0x00,0x3f,0x02,0xd1,0x00,0x32,0x02,0xd3,0x00,0x26,0x02,0xd4,0x00,0x19,0x02,0xd6,0x00,0x0c,0x02,0xd8,0x00,0xff,0x01,0xd9,0x00,0xf3,0x01,0xdb,0x00,0xe6,0x01,0xdd,0x00,0xd9,0x01,0xde,0x00,0xcd,0x01,0xe0,0x00,0xc0,0x01,0xe1,0x00,0xb4,0x01,0xe3,0x00,  \
    0xa7,0x01,0xe4,0x00,0x9b,0x01,0xe5,0x00,0x8e,0x01,0xe7,0x00,0x81,0x01,0xe8,0x00,0x75,0x01,0xe9,0x00,0x68,0x01,0xea,0x00,0x5c,0x01,0xec,0x00,0x50,0x01,0xed,0x00,0x43,0x01,0xee,0x00,0x37,0x01,0xef,0x00,0x2a,0x01,0xf0,0x00,0x1e,0x01,0xf1,0x00,0x11,0x01,0xf2,0x00,0x05,0x01,0xf3,0x00,0xf9,0x00,0xf4,0x00,0xec,0x00,0xf5,0x00,0xe0,0x00,0xf6,0x00,0xd4,0x00,0xf6,0x00,0xc7,0x00,0xf7,0x00,0xbb,0x00,0xf8,0x00,0xaf,0x00,0xf8,0x00,0xa2,0x00,0xf9,0x00,0x96,0x00,  \
    0xfa,0x00,0x8a,0x00,0xfa,0x00,0x7d,0x00,0xfb,0x00,0x71,0x00,0xfb,0x00,0x65,0x00,0xfc,0x00,0x59,0x00,0xfc,0x00,0x4c,0x00,0xfd,0x00,0x40,0x00,0xfd,0x00,0x34,0x00,0xfd,0x00,0x28,0x00,0xfe,0x00,0x1b,0x00,0xfe,0x00,0x0f,0x00,0xfe,0x00,0x03,0x00,0xfe,0x00,0xf7,0xff,0xfe,0x00,0xea,0xff,0xff,0x00,0xde,0xff,0xff,0x00,0xd2,0xff,0xff,0x00,0xc6,0xff,0xff,0x00,0xba,0xff,0xff,0x00,0xad,0xff,0xfe,0x00,0xa1,0xff,0xfe,0x00,0x95,0xff,0xfe,0x00,0x89,0xff,0xfe,0x00,  \
    0x7c,0xff,0xfe,0x00,0x70,0xff,0xfe,0x00,0x64,0xff,0xfd,0x00,0x58,0xff,0xfd,0x00,0x4b,0xff,0xfd,0x00,0x3f,0xff,0xfc,0x00,0x33,0xff,0xfc,0x00,0x26,0xff,0xfb,0x00,0x1a,0xff,0xfb,0x00,0x0e,0xff,0xfa,0x00,0x01,0xff,0xfa,0x00,0xf5,0xfe,0xf9,0x00,0xe9,0xfe,0xf8,0x00,0xdc,0xfe,0xf8,0x00,0xd0,0xfe,0xf7,0x00,0xc3,0xfe,0xf6,0x00,0xb7,0xfe,0xf6,0x00,0xaa,0xfe,0xf5,0x00,0x9e,0xfe,0xf4,0x00,0x91,0xfe,0xf3,0x00,0x85,0xfe,0xf2,0x00,0x78,0xfe,0xf1,0x00,0x6c,0xfe,  \
    0xf0,0x00,0x60,0xfe,0xef,0x00,0x54,0xfe,0xee,0x00,0x47,0xfe,0xed,0x00,0x3b,0xfe,0xec,0x00,0x2f,0xfe,0xeb,0x00,0x23,0xfe,0xe9,0x00,0x16,0xfe,0xe8,0x00,0x0a,0xfe,0xe7,0x00,0xfe,0xfd,0xe5,0x00,0xf2,0xfd,0xe4,0x00,0xe5,0xfd,0xe3,0x00,0xd9,0xfd,0xe1,0x00,0xcd,0xfd,0xe0,0x00,0xc0,0xfd,0xde,0x00,0xb4,0xfd,0xdd,0x00,0xa8,0xfd,0xdb,0x00,0x9b,0xfd,0xd9,0x00,0x8f,0xfd,0xd8,0x00,0x83,0xfd,0xd6,0x00,0x76,0xfd,0xd4,0x00,0x6a,0xfd,0xd3,0x00,0x5e,0xfd,0xd1,0x00,  \
    0x51,0xfd,0xcf,0x00,0x45,0xfd,0xcd,0x00,0x38,0xfd,0xcb,0x00,0x2c,0xfd,0xc9,0x00,0x1f,0xfd,0xc7,0x00,0x12,0xfd,0xc5,0x00,0x05,0xfd,0xc3,0x00,0xf8,0xfc,0xc1,0x00,0xeb,0xfc,0xbf,0x00,0xde,0xfc,0xbd,0x00,0xd0,0xfc,0xbb,0x00,0xc3,0xfc,0xb9,0x00,0xb6,0xfc,0xb7,0x00,0xa8,0xfc,0xb4,0x00,0x9b,0xfc,0xb2,0x00,0x8e,0xfc,0xb0,0x00,0x80,0xfc,0xad,0x00,0x73,0xfc,0xab,0x00,0x65,0xfc,0xa9,0x00,0x57,0xfc,0xa6,0x00,0x4a,0xfc,0xa4,0x00,0x3c,0xfc,0xa1,0x00,0x2e,0xfc,  \
    0x9f,0x00,0x21,0xfc,0x9c,0x00,0x13,0xfc,0x9a,0x00,0x05,0xfc,0x97,0x00,0xf7,0xfb,0x95,0x00,0xe9,0xfb,0x92,0x00,0xdb,0xfb,0x8f,0x00,0xcd,0xfb,0x8d,0x00,0xbf,0xfb,0x8a,0x00,0xb1,0xfb,0x87,0x00,0xa3,0xfb,0x84,0x00,0x95,0xfb,0x81,0x00,0x87,0xfb,0x7e,0x00,0x79,0xfb,0x7b,0x00,0x6b,0xfb,0x79,0x00,0x5d,0xfb,0x76,0x00,0x4f,0xfb,0x72,0x00,0x41,0xfb,0x6f,0x00,0x33,0xfb,0x6c,0x00,0x24,0xfb,0x69,0x00,0x16,0xfb,0x66,0x00,0x08,0xfb,0x63,0x00,0xf9,0xfa,0x60,0x00,  \
    0xeb,0xfa,0x5c,0x00,0xdc,0xfa,0x59,0x00,0xce,0xfa,0x56,0x00,0xbf,0xfa,0x53,0x00,0xb1,0xfa,0x4f,0x00,0xa2,0xfa,0x4c,0x00,0x93,0xfa,0x49,0x00,0x84,0xfa,0x45,0x00,0x75,0xfa,0x42,0x00,0x66,0xfa,0x3e,0x00,0x57,0xfa,0x3b,0x00,0x48,0xfa,0x37,0x00,0x39,0xfa,0x34,0x00,0x2a,0xfa,0x30,0x00,0x1b,0xfa,0x2c,0x00,0x0c,0xfa,0x29,0x00,0xfd,0xf9,0x25,0x00,0xed,0xf9,0x21,0x00,0xde,0xf9,0x1e,0x00,0xcf,0xf9,0x1a,0x00,0xbf,0xf9,0x16,0x00,0xb0,0xf9,0x12,0x00,0xa0,0xf9,  \
    0x0e,0x00,0x90,0xf9,0x0b,0x00,0x81,0xf9,0x07,0x00,0x71,0xf9,0x03,0x00,0x61,0xf9,0xff,0xff,0x51,0xf9,0xfb,0xff,0x41,0xf9,0xf7,0xff,0x31,0xf9,0xf3,0xff,0x21,0xf9,0xef,0xff,0x11,0xf9,0xeb,0xff,0x00,0xf9,0xe7,0xff,0xf0,0xf8,0xe3,0xff,0xe0,0xf8,0xdf,0xff,0xcf,0xf8,0xdb,0xff,0xbf,0xf8,0xd7,0xff,0xae,0xf8,0xd2,0xff,0x9d,0xf8,0xce,0xff,0x8c,0xf8,0xca,0xff,0x7c,0xf8,0xc6,0xff,0x6b,0xf8,0xc2,0xff,0x5a,0xf8,0xbd,0xff,0x49,0xf8,0xb9,0xff,0x37,0xf8,0xb5,0xff,  \
    0x26,0xf8,0xb1,0xff,0x15,0xf8,0xac,0xff,0x03,0xf8,0xa8,0xff,0xf2,0xf7,0xa4,0xff,0xe0,0xf7,0x9f,0xff,0xcf,0xf7,0x9b,0xff,0xbd,0xf7,0x97,0xff,0xab,0xf7,0x92,0xff,0x99,0xf7,0x8e,0xff,0x87,0xf7,0x8a,0xff,0x75,0xf7,0x85,0xff,0x63,0xf7,0x81,0xff,0x51,0xf7,0x7c,0xff,0x3e,0xf7,0x78,0xff,0x2c,0xf7,0x73,0xff,0x19,0xf7,0x6f,0xff,0x07,0xf7,0x6b,0xff,0xf4,0xf6,0x66,0xff,0xe1,0xf6,0x62,0xff,0xce,0xf6,0x5d,0xff,0xbb,0xf6,0x59,0xff,0xa8,0xf6,0x54,0xff,0x95,0xf6,  \
    0x50,0xff,0x82,0xf6,0x4b,0xff,0x6f,0xf6,0x47,0xff,0x5b,0xf6,0x42,0xff,0x48,0xf6,0x3e,0xff,0x34,0xf6,0x39,0xff,0x20,0xf6,0x35,0xff,0x0c,0xf6,0x30,0xff,0xf8,0xf5,0x2c,0xff,0xe4,0xf5,0x28,0xff,0xd0,0xf5,0x23,0xff,0xbb,0xf5,0x1f,0xff,0xa7,0xf5,0x1a,0xff,0x92,0xf5,0x16,0xff,0x7e,0xf5,0x12,0xff,0x69,0xf5,0x0d,0xff,0x54,0xf5,0x09,0xff,0x3f,0xf5,0x05,0xff,0x2a,0xf5,0x00,0xff,0x15,0xf5,0xfc,0xfe,0xff,0xf4,0xf8,0xfe,0xea,0xf4,0xf3,0xfe,0xd4,0xf4,0xef,0xfe,  \
    0xbf,0xf4,0xeb,0xfe,0xa9,0xf4,0xe6,0xfe,0x93,0xf4,0xe2,0xfe,0x7d,0xf4,0xde,0xfe,0x67,0xf4,0xda,0xfe,0x51,0xf4,0xd5,0xfe,0x3b,0xf4,0xd1,0xfe,0x24,0xf4,0xcd,0xfe,0x0e,0xf4,0xc9,0xfe,0xf7,0xf3,0xc5,0xfe,0xe0,0xf3,0xc1,0xfe,0xca,0xf3,0xbd,0xfe,0xb3,0xf3,0xb9,0xfe,0x9c,0xf3,0xb4,0xfe,0x84,0xf3,0xb1,0xfe,0x6d,0xf3,0xad,0xfe,0x56,0xf3,0xa9,0xfe,0x3e,0xf3,0xa5,0xfe,0x26,0xf3,0xa1,0xfe,0x0f,0xf3,0x9d,0xfe,0xf7,0xf2,0x99,0xfe,0xdf,0xf2,0x96,0xfe,0xc6,0xf2,  \
    0x92,0xfe,0xae,0xf2,0x8e,0xfe,0x95,0xf2,0x8b,0xfe,0x7d,0xf2,0x87,0xfe,0x64,0xf2,0x84,0xfe,0x4b,0xf2,0x80,0xfe,0x32,0xf2,0x7d,0xfe,0x19,0xf2,0x79,0xfe,0x00,0xf2,0x76,0xfe,0xe6,0xf1,0x73,0xfe,0xcd,0xf1,0x70,0xfe,0xb3,0xf1,0x6c,0xfe,0x99,0xf1,0x69,0xfe,0x7f,0xf1,0x66,0xfe,0x65,0xf1,0x63,0xfe,0x4b,0xf1,0x60,0xfe,0x31,0xf1,0x5d,0xfe,0x16,0xf1,0x5a,0xfe,0xfc,0xf0,0x58,0xfe,0xe1,0xf0,0x55,0xfe,0xc6,0xf0,0x52,0xfe,0xab,0xf0,0x4f,0xfe,0x90,0xf0,0x4d,0xfe,  \
    0x75,0xf0,0x4a,0xfe,0x5a,0xf0,0x48,0xfe,0x3e,0xf0,0x45,0xfe,0x23,0xf0,0x43,0xfe,0x07,0xf0,0x41,0xfe,0xeb,0xef,0x3f,0xfe,0xcf,0xef,0x3c,0xfe,0xb3,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x12,0xfe,0x59,0x10,0x14,0xfe,0x3d,0x10,0x17,0xfe,0x20,0x10,0x19,0xfe,0x04,0x10,0x1b,0xfe,0xe8,0x0f,0x1e,0xfe,0xcc,0x0f,0x20,0xfe,0xb1,0x0f,0x23,0xfe,0x95,0x0f,0x25,0xfe,0x79,0x0f,0x28,0xfe,0x5e,0x0f,0x2b,0xfe,0x43,0x0f,0x2d,0xfe,0x28,0x0f,0x30,0xfe,0x0d,0x0f,0x33,0xfe,0xf2,0x0e,0x36,0xfe,0xd7,0x0e,0x39,0xfe,0xbd,0x0e,0x3c,0xfe,0xa2,0x0e,0x3f,0xfe,0x88,0x0e,0x43,0xfe,0x6e,0x0e,0x46,0xfe,0x53,0x0e,0x49,0xfe,0x39,0x0e,0x4c,0xfe,0x1f,0x0e,0x50,0xfe,  \
    0x06,0x0e,0x53,0xfe,0xec,0x0d,0x57,0xfe,0xd2,0x0d,0x5a,0xfe,0xb9,0x0d,0x5e,0xfe,0xa0,0x0d,0x61,0xfe,0x86,0x0d,0x65,0xfe,0x6d,0x0d,0x69,0xfe,0x54,0x0d,0x6c,0xfe,0x3b,0x0d,0x70,0xfe,0x23,0x0d,0x74,0xfe,0x0a,0x0d,0x78,0xfe,0xf1,0x0c,0x7c,0xfe,0xd9,0x0c,0x80,0xfe,0xc1,0x0c,0x83,0xfe,0xa9,0x0c,0x87,0xfe,0x91,0x0c,0x8b,0xfe,0x79,0x0c,0x8f,0xfe,0x61,0x0c,0x94,0xfe,0x49,0x0c,0x98,0xfe,0x32,0x0c,0x9c,0xfe,0x1b,0x0c,0xa1,0xfe,0x05,0x0c,0xa5,0xfe,0xee,0x0b,  \
    0xaa,0xfe,0xd7,0x0b,0xae,0xfe,0xc1,0x0b,0xb3,0xfe,0xab,0x0b,0xb7,0xfe,0x95,0x0b,0xbc,0xfe,0x7f,0x0b,0xc1,0xfe,0x69,0x0b,0xc5,0xfe,0x53,0x0b,0xca,0xfe,0x3d,0x0b,0xcf,0xfe,0x28,0x0b,0xd3,0xfe,0x12,0x0b,0xd8,0xfe,0xfd,0x0a,0xdd,0xfe,0xe8,0x0a,0xe1,0xfe,0xd3,0x0a,0xe6,0xfe,0xbd,0x0a,0xea,0xfe,0xa8,0x0a,0xef,0xfe,0x92,0x0a,0xf3,0xfe,0x7d,0x0a,0xf8,0xfe,0x68,0x0a,0xfd,0xfe,0x53,0x0a,0x01,0xff,0x3e,0x0a,0x06,0xff,0x29,0x0a,0x0a,0xff,0x14,0x0a,0x0f,0xff,  \
    0x00,0x0a,0x13,0xff,0xeb,0x09,0x18,0xff,0xd7,0x09,0x1c,0xff,0xc2,0x09,0x21,0xff,0xae,0x09,0x26,0xff,0x9a,0x09,0x2a,0xff,0x86,0x09,0x2f,0xff,0x72,0x09,0x33,0xff,0x5e,0x09,0x38,0xff,0x4a,0x09,0x3d,0xff,0x36,0x09,0x41,0xff,0x23,0x09,0x46,0xff,0x0f,0x09,0x4a,0xff,0xfc,0x08,0x4f,0xff,0xe9,0x08,0x54,0xff,0xd6,0x08,0x58,0xff,0xc2,0x08,0x5d,0xff,0xaf,0x08,0x61,0xff,0x9c,0x08,0x66,0xff,0x8a,0x08,0x6a,0xff,0x77,0x08,0x6f,0xff,0x64,0x08,0x73,0xff,0x52,0x08,  \
    0x78,0xff,0x3f,0x08,0x7c,0xff,0x2d,0x08,0x81,0xff,0x1a,0x08,0x85,0xff,0x08,0x08,0x8a,0xff,0xf6,0x07,0x8f,0xff,0xe4,0x07,0x93,0xff,0xd3,0x07,0x98,0xff,0xc1,0x07,0x9c,0xff,0xaf,0x07,0xa1,0xff,0x9e,0x07,0xa5,0xff,0x8c,0x07,0xa9,0xff,0x7b,0x07,0xae,0xff,0x6a,0x07,0xb2,0xff,0x58,0x07,0xb7,0xff,0x47,0x07,0xbb,0xff,0x36,0x07,0xbf,0xff,0x25,0x07,0xc4,0xff,0x14,0x07,0xc8,0xff,0x03,0x07,0xcc,0xff,0xf3,0x06,0xd1,0xff,0xe2,0x06,0xd5,0xff,0xd1,0x06,0xd9,0xff,  \
    0xc1,0x06,0xdd,0xff,0xb0,0x06,0xe2,0xff,0xa0,0x06,0xe6,0xff,0x8f,0x06,0xea,0xff,0x7f,0x06,0xee,0xff,0x6f,0x06,0xf2,0xff,0x5f,0x06,0xf6,0xff,0x4f,0x06,0xfa,0xff,0x3e,0x06,0xfe,0xff,0x2e,0x06,0x02,0x00,0x1f,0x06,0x06,0x00,0x0f,0x06,0x0a,0x00,0xff,0x05,0x0e,0x00,0xef,0x05,0x12,0x00,0xdf,0x05,0x16,0x00,0xd0,0x05,0x1a,0x00,0xc0,0x05,0x1e,0x00,0xb1,0x05,0x21,0x00,0xa1,0x05,0x25,0x00,0x92,0x05,0x29,0x00,0x83,0x05,0x2d,0x00,0x73,0x05,0x30,0x00,0x64,0x05,  \
    0x34,0x00,0x55,0x05,0x38,0x00,0x46,0x05,0x3b,0x00,0x36,0x05,0x3f,0x00,0x27,0x05,0x42,0x00,0x18,0x05,0x46,0x00,0x08,0x05,0x49,0x00,0xf9,0x04,0x4c,0x00,0xea,0x04,0x50,0x00,0xdb,0x04,0x53,0x00,0xcc,0x04,0x57,0x00,0xbd,0x04,0x5a,0x00,0xae,0x04,0x5d,0x00,0x9f,0x04,0x60,0x00,0x91,0x04,0x64,0x00,0x82,0x04,0x67,0x00,0x73,0x04,0x6a,0x00,0x64,0x04,0x6d,0x00,0x56,0x04,0x70,0x00,0x47,0x04,0x73,0x00,0x39,0x04,0x76,0x00,0x2a,0x04,0x79,0x00,0x1c,0x04,0x7c,0x00,  \
    0x0d,0x04,0x7f,0x00,0xff,0x03,0x82,0x00,0xf1,0x03,0x85,0x00,0xe3,0x03,0x88,0x00,0xd5,0x03,0x8b,0x00,0xc7,0x03,0x8e,0x00,0xb9,0x03,0x90,0x00,0xab,0x03,0x93,0x00,0x9d,0x03,0x96,0x00,0x8f,0x03,0x98,0x00,0x82,0x03,0x9b,0x00,0x74,0x03,0x9e,0x00,0x66,0x03,0xa0,0x00,0x59,0x03,0xa3,0x00,0x4b,0x03,0xa5,0x00,0x3d,0x03,0xa8,0x00,0x30,0x03,0xaa,0x00,0x22,0x03,0xad,0x00,0x15,0x03,0xaf,0x00,0x08,0x03,0xb2,0x00,0xfa,0x02,0xb4,0x00,0xed,0x02,0xb6,0x00,0xe0,0x02,  \
    0xb9,0x00,0xd2,0x02,0xbb,0x00,0xc5,0x02,0xbd,0x00,0xb8,0x02,0xbf,0x00,0xab,0x02,0xc1,0x00,0x9d,0x02,0xc3,0x00,0x90,0x02,0xc5,0x00,0x83,0x02,0xc7,0x00,0x76,0x02,0xc9,0x00,0x69,0x02,0xcb,0x00,0x5c,0x02,0xcd,0x00,0x4f,0x02,0xcf,0x00,0x43,0x02,0xd1,0x00,0x36,0x02,0xd3,0x00,0x29,0x02,0xd5,0x00,0x1c,0x02,0xd6,0x00,0x0f,0x02,0xd8,0x00,0x02,0x02,0xda,0x00,0xf6,0x01,0xdb,0x00,0xe9,0x01,0xdd,0x00,0xdc,0x01,0xdf,0x00,0xd0,0x01,0xe0,0x00,0xc3,0x01,0xe2,0x00,  \
    0xb6,0x01,0xe3,0x00,0xaa,0x01,0xe5,0x00,0x9d,0x01,0xe6,0x00,0x90,0x01,0xe7,0x00,0x84,0x01,0xe9,0x00,0x77,0x01,0xea,0x00,0x6b,0x01,0xeb,0x00,0x5e,0x01,0xec,0x00,0x52,0x01,0xed,0x00,0x45,0x01,0xef,0x00,0x39,0x01,0xf0,0x00,0x2c,0x01,0xf1,0x00,0x20,0x01,0xf2,0x00,0x13,0x01,0xf3,0x00,0x07,0x01,0xf4,0x00,0xfa,0x00,0xf5,0x00,0xee,0x00,0xf6,0x00,0xe1,0x00,0xf6,0x00,0xd5,0x00,0xf7,0x00,0xc9,0x00,0xf8,0x00,0xbc,0x00,0xf9,0x00,0xb0,0x00,0xf9,0x00,0xa3,0x00,  \
    0xfa,0x00,0x97,0x00,0xfb,0x00,0x8b,0x00,0xfb,0x00,0x7e,0x00,0xfc,0x00,0x72,0x00,0xfc,0x00,0x66,0x00,0xfd,0x00,0x59,0x00,0xfd,0x00,0x4d,0x00,0xfe,0x00,0x41,0x00,0xfe,0x00,0x34,0x00,0xfe,0x00,0x28,0x00,0xff,0x00,0x1c,0x00,0xff,0x00,0x10,0x00,0xff,0x00,0x03,0x00,0xff,0x00,0xf7,0xff,0xff,0x00,0xeb,0xff,0xff,0x00,0xde,0xff,0x00,0x01,0xd2,0xff,0x00,0x01,0xc6,0xff,0x00,0x01,0xba,0xff,0xff,0x00,0xad,0xff,0xff,0x00,0xa1,0xff,0xff,0x00,0x95,0xff,0xff,0x00,  \
    0x88,0xff,0xff,0x00,0x7c,0xff,0xff,0x00,0x70,0xff,0xfe,0x00,0x63,0xff,0xfe,0x00,0x57,0xff,0xfe,0x00,0x4b,0xff,0xfd,0x00,0x3e,0xff,0xfd,0x00,0x32,0xff,0xfd,0x00,0x26,0xff,0xfc,0x00,0x19,0xff,0xfc,0x00,0x0d,0xff,0xfb,0x00,0x00,0xff,0xfb,0x00,0xf4,0xfe,0xfa,0x00,0xe7,0xfe,0xf9,0x00,0xdb,0xfe,0xf9,0x00,0xce,0xfe,0xf8,0x00,0xc2,0xfe,0xf7,0x00,0xb5,0xfe,0xf6,0x00,0xa9,0xfe,0xf5,0x00,0x9c,0xfe,0xf5,0x00,0x90,0xfe,0xf4,0x00,0x83,0xfe,0xf3,0x00,0x77,0xfe,  \
    0xf2,0x00,0x6a,0xfe,0xf1,0x00,0x5e,0xfe,0xf0,0x00,0x52,0xfe,0xef,0x00,0x45,0xfe,0xee,0x00,0x39,0xfe,0xec,0x00,0x2d,0xfe,0xeb,0x00,0x20,0xfe,0xea,0x00,0x14,0xfe,0xe9,0x00,0x08,0xfe,0xe7,0x00,0xfb,0xfd,0xe6,0x00,0xef,0xfd,0xe5,0x00,0xe3,0xfd,0xe3,0x00,0xd6,0xfd,0xe2,0x00,0xca,0xfd,0xe0,0x00,0xbe,0xfd,0xdf,0x00,0xb1,0xfd,0xdd,0x00,0xa5,0xfd,0xdb,0x00,0x99,0xfd,0xda,0x00,0x8c,0xfd,0xd8,0x00,0x80,0xfd,0xd6,0x00,0x73,0xfd,0xd5,0x00,0x67,0xfd,0xd3,0x00,  \
    0x5a,0xfd,0xd1,0x00,0x4e,0xfd,0xcf,0x00,0x42,0xfd,0xcd,0x00,0x35,0xfd,0xcb,0x00,0x29,0xfd,0xc9,0x00,0x1c,0xfd,0xc7,0x00,0x0f,0xfd,0xc5,0x00,0x02,0xfd,0xc3,0x00,0xf5,0xfc,0xc1,0x00,0xe7,0xfc,0xbf,0x00,0xda,0xfc,0xbd,0x00,0xcd,0xfc,0xbb,0x00,0xbf,0xfc,0xb9,0x00,0xb2,0xfc,0xb6,0x00,0xa5,0xfc,0xb4,0x00,0x97,0xfc,0xb2,0x00,0x8a,0xfc,0xaf,0x00,0x7c,0xfc,0xad,0x00,0x6f,0xfc,0xab,0x00,0x61,0xfc,0xa8,0x00,0x53,0xfc,0xa6,0x00,0x46,0xfc,0xa3,0x00,0x38,0xfc,  \
    0xa1,0x00,0x2a,0xfc,0x9e,0x00,0x1c,0xfc,0x9c,0x00,0x0e,0xfc,0x99,0x00,0x00,0xfc,0x96,0x00,0xf3,0xfb,0x94,0x00,0xe5,0xfb,0x91,0x00,0xd7,0xfb,0x8e,0x00,0xc8,0xfb,0x8c,0x00,0xba,0xfb,0x89,0x00,0xac,0xfb,0x86,0x00,0x9e,0xfb,0x83,0x00,0x90,0xfb,0x80,0x00,0x82,0xfb,0x7d,0x00,0x74,0xfb,0x7a,0x00,0x66,0xfb,0x77,0x00,0x58,0xfb,0x74,0x00,0x4a,0xfb,0x71,0x00,0x3c,0xfb,0x6e,0x00,0x2e,0xfb,0x6b,0x00,0x1f,0xfb,0x68,0x00,0x11,0xfb,0x64,0x00,0x02,0xfb,0x61,0x00,  \
    0xf4,0xfa,0x5e,0x00,0xe6,0xfa,0x5b,0x00,0xd7,0xfa,0x57,0x00,0xc8,0xfa,0x54,0x00,0xba,0xfa,0x51,0x00,0xab,0xfa,0x4d,0x00,0x9c,0xfa,0x4a,0x00,0x8e,0xfa,0x46,0x00,0x7f,0xfa,0x43,0x00,0x70,0xfa,0x3f,0x00,0x61,0xfa,0x3c,0x00,0x52,0xfa,0x38,0x00,0x43,0xfa,0x35,0x00,0x34,0xfa,0x31,0x00,0x25,0xfa,0x2d,0x00,0x16,0xfa,0x2a,0x00,0x06,0xfa,0x26,0x00,0xf7,0xf9,0x22,0x00,0xe8,0xf9,0x1e,0x00,0xd8,0xf9,0x1b,0x00,0xc9,0xf9,0x17,0x00,0xb9,0xf9,0x13,0x00,0xaa,0xf9,  \
    0x0f,0x00,0x9a,0xf9,0x0b,0x00,0x8b,0xf9,0x07,0x00,0x7b,0xf9,0x03,0x00,0x6b,0xf9,0xff,0xff,0x5b,0xf9,0xfb,0xff,0x4b,0xf9,0xf7,0xff,0x3b,0xf9,0xf3,0xff,0x2b,0xf9,0xef,0xff,0x1b,0xf9,0xeb,0xff,0x0b,0xf9,0xe7,0xff,0xfb,0xf8,0xe3,0xff,0xea,0xf8,0xdf,0xff,0xda,0xf8,0xdb,0xff,0xc9,0xf8,0xd6,0xff,0xb9,0xf8,0xd2,0xff,0xa8,0xf8,0xce,0xff,0x97,0xf8,0xca,0xff,0x87,0xf8,0xc5,0xff,0x76,0xf8,0xc1,0xff,0x65,0xf8,0xbd,0xff,0x54,0xf8,0xb9,0xff,0x43,0xf8,0xb4,0xff,  \
    0x32,0xf8,0xb0,0xff,0x20,0xf8,0xab,0xff,0x0f,0xf8,0xa7,0xff,0xfe,0xf7,0xa3,0xff,0xec,0xf7,0x9e,0xff,0xdb,0xf7,0x9a,0xff,0xc9,0xf7,0x95,0xff,0xb7,0xf7,0x91,0xff,0xa5,0xf7,0x8d,0xff,0x94,0xf7,0x88,0xff,0x82,0xf7,0x84,0xff,0x6f,0xf7,0x7f,0xff,0x5d,0xf7,0x7b,0xff,0x4b,0xf7,0x76,0xff,0x39,0xf7,0x72,0xff,0x26,0xf7,0x6d,0xff,0x14,0xf7,0x68,0xff,0x01,0xf7,0x64,0xff,0xef,0xf6,0x5f,0xff,0xdc,0xf6,0x5b,0xff,0xc9,0xf6,0x56,0xff,0xb6,0xf6,0x52,0xff,0xa3,0xf6,  \
    0x4d,0xff,0x90,0xf6,0x49,0xff,0x7d,0xf6,0x44,0xff,0x69,0xf6,0x3f,0xff,0x56,0xf6,0x3b,0xff,0x42,0xf6,0x36,0xff,0x2f,0xf6,0x32,0xff,0x1b,0xf6,0x2d,0xff,0x07,0xf6,0x29,0xff,0xf3,0xf5,0x24,0xff,0xdf,0xf5,0x20,0xff,0xcb,0xf5,0x1b,0xff,0xb6,0xf5,0x16,0xff,0xa2,0xf5,0x12,0xff,0x8d,0xf5,0x0d,0xff,0x78,0xf5,0x09,0xff,0x64,0xf5,0x05,0xff,0x4f,0xf5,0x00,0xff,0x3a,0xf5,0xfc,0xfe,0x25,0xf5,0xf7,0xfe,0x10,0xf5,0xf3,0xfe,0xfa,0xf4,0xee,0xfe,0xe5,0xf4,0xea,0xfe,  \
    0xcf,0xf4,0xe5,0xfe,0xba,0xf4,0xe1,0xfe,0xa4,0xf4,0xdd,0xfe,0x8e,0xf4,0xd8,0xfe,0x78,0xf4,0xd4,0xfe,0x62,0xf4,0xd0,0xfe,0x4c,0xf4,0xcb,0xfe,0x36,0xf4,0xc7,0xfe,0x1f,0xf4,0xc3,0xfe,0x09,0xf4,0xbf,0xfe,0xf2,0xf3,0xba,0xfe,0xdc,0xf3,0xb6,0xfe,0xc5,0xf3,0xb2,0xfe,0xae,0xf3,0xae,0xfe,0x97,0xf3,0xaa,0xfe,0x80,0xf3,0xa6,0xfe,0x69,0xf3,0xa1,0xfe,0x51,0xf3,0x9d,0xfe,0x3a,0xf3,0x99,0xfe,0x22,0xf3,0x96,0xfe,0x0a,0xf3,0x92,0xfe,0xf2,0xf2,0x8e,0xfe,0xda,0xf2,  \
    0x8a,0xfe,0xc2,0xf2,0x86,0xfe,0xaa,0xf2,0x82,0xfe,0x91,0xf2,0x7f,0xfe,0x79,0xf2,0x7b,0xfe,0x60,0xf2,0x78,0xfe,0x47,0xf2,0x74,0xfe,0x2e,0xf2,0x70,0xfe,0x15,0xf2,0x6d,0xfe,0xfc,0xf1,0x6a,0xfe,0xe2,0xf1,0x66,0xfe,0xc9,0xf1,0x63,0xfe,0xaf,0xf1,0x60,0xfe,0x95,0xf1,0x5c,0xfe,0x7b,0xf1,0x59,0xfe,0x61,0xf1,0x56,0xfe,0x47,0xf1,0x53,0xfe,0x2d,0xf1,0x50,0xfe,0x12,0xf1,0x4d,0xfe,0xf8,0xf0,0x4a,0xfe,0xdd,0xf0,0x48,0xfe,0xc2,0xf0,0x45,0xfe,0xa8,0xf0,0x42,0xfe,  \
    0x8d,0xf0,0x3f,0xfe,0x71,0xf0,0x3d,0xfe,0x56,0xf0,0x3a,0xfe,0x3b,0xf0,0x38,0xfe,0x1f,0xf0,0x35,0xfe,0x03,0xf0,0x33,0xfe,0xe8,0xef,0x31,0xfe,0xcc,0xef,0x2e,0xfe,0xb0,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x07,0xfe,0x5d,0x10,0x09,0xfe,0x41,0x10,0x0b,0xfe,0x24,0x10,0x0e,0xfe,0x08,0x10,0x10,0xfe,0xec,0x0f,0x12,0xfe,0xd0,0x0f,0x15,0xfe,0xb5,0x0f,0x17,0xfe,0x99,0x0f,0x1a,0xfe,0x7e,0x0f,0x1d,0xfe,0x62,0x0f,0x20,0xfe,0x47,0x0f,0x23,0xfe,0x2c,0x0f,0x25,0xfe,0x11,0x0f,0x28,0xfe,0xf6,0x0e,0x2b,0xfe,0xdb,0x0e,0x2f,0xfe,0xc1,0x0e,0x32,0xfe,0xa6,0x0e,0x35,0xfe,0x8c,0x0e,0x38,0xfe,0x72,0x0e,0x3b,0xfe,0x58,0x0e,0x3f,0xfe,0x3e,0x0e,0x42,0xfe,  \
    0x24,0x0e,0x46,0xfe,0x0a,0x0e,0x49,0xfe,0xf0,0x0d,0x4d,0xfe,0xd7,0x0d,0x50,0xfe,0xbd,0x0d,0x54,0xfe,0xa4,0x0d,0x57,0xfe,0x8b,0x0d,0x5b,0xfe,0x72,0x0d,0x5f,0xfe,0x59,0x0d,0x63,0xfe,0x40,0x0d,0x66,0xfe,0x27,0x0d,0x6a,0xfe,0x0f,0x0d,0x6e,0xfe,0xf6,0x0c,0x72,0xfe,0xde,0x0c,0x76,0xfe,0xc5,0x0c,0x7a,0xfe,0xad,0x0c,0x7e,0xfe,0x95,0x0c,0x82,0xfe,0x7d,0x0c,0x86,0xfe,0x65,0x0c,0x8b,0xfe,0x4e,0x0c,0x8f,0xfe,0x37,0x0c,0x94,0xfe,0x20,0x0c,0x98,0xfe,0x09,0x0c,  \
    0x9d,0xfe,0xf3,0x0b,0xa1,0xfe,0xdc,0x0b,0xa6,0xfe,0xc6,0x0b,0xaa,0xfe,0xb0,0x0b,0xaf,0xfe,0x9a,0x0b,0xb4,0xfe,0x84,0x0b,0xb9,0xfe,0x6e,0x0b,0xbd,0xfe,0x58,0x0b,0xc2,0xfe,0x42,0x0b,0xc7,0xfe,0x2d,0x0b,0xcc,0xfe,0x18,0x0b,0xd0,0xfe,0x02,0x0b,0xd5,0xfe,0xed,0x0a,0xda,0xfe,0xd8,0x0a,0xdf,0xfe,0xc2,0x0a,0xe3,0xfe,0xad,0x0a,0xe8,0xfe,0x98,0x0a,0xec,0xfe,0x82,0x0a,0xf1,0xfe,0x6d,0x0a,0xf6,0xfe,0x58,0x0a,0xfa,0xfe,0x43,0x0a,0xff,0xfe,0x2f,0x0a,0x03,0xff,  \
    0x1a,0x0a,0x08,0xff,0x05,0x0a,0x0d,0xff,0xf1,0x09,0x11,0xff,0xdc,0x09,0x16,0xff,0xc8,0x09,0x1b,0xff,0xb4,0x09,0x1f,0xff,0x9f,0x09,0x24,0xff,0x8b,0x09,0x29,0xff,0x77,0x09,0x2d,0xff,0x64,0x09,0x32,0xff,0x50,0x09,0x37,0xff,0x3c,0x09,0x3b,0xff,0x29,0x09,0x40,0xff,0x15,0x09,0x45,0xff,0x02,0x09,0x49,0xff,0xef,0x08,0x4e,0xff,0xdb,0x08,0x53,0xff,0xc8,0x08,0x57,0xff,0xb5,0x08,0x5c,0xff,0xa2,0x08,0x61,0xff,0x8f,0x08,0x65,0xff,0x7d,0x08,0x6a,0xff,0x6a,0x08,  \
    0x6e,0xff,0x57,0x08,0x73,0xff,0x45,0x08,0x78,0xff,0x33,0x08,0x7c,0xff,0x20,0x08,0x81,0xff,0x0e,0x08,0x85,0xff,0xfc,0x07,0x8a,0xff,0xea,0x07,0x8f,0xff,0xd8,0x07,0x93,0xff,0xc7,0x07,0x98,0xff,0xb5,0x07,0x9c,0xff,0xa4,0x07,0xa1,0xff,0x92,0x07,0xa5,0xff,0x81,0x07,0xaa,0xff,0x70,0x07,0xae,0xff,0x5e,0x07,0xb3,0xff,0x4d,0x07,0xb7,0xff,0x3c,0x07,0xbc,0xff,0x2b,0x07,0xc0,0xff,0x1a,0x07,0xc5,0xff,0x09,0x07,0xc9,0xff,0xf9,0x06,0xcd,0xff,0xe8,0x06,0xd2,0xff,  \
    0xd7,0x06,0xd6,0xff,0xc7,0x06,0xda,0xff,0xb6,0x06,0xde,0xff,0xa6,0x06,0xe3,0xff,0x96,0x06,0xe7,0xff,0x85,0x06,0xeb,0xff,0x75,0x06,0xef,0xff,0x65,0x06,0xf3,0xff,0x55,0x06,0xf7,0xff,0x45,0x06,0xfc,0xff,0x34,0x06,0x00,0x00,0x25,0x06,0x04,0x00,0x15,0x06,0x08,0x00,0x05,0x06,0x0c,0x00,0xf5,0x05,0x10,0x00,0xe5,0x05,0x14,0x00,0xd6,0x05,0x17,0x00,0xc6,0x05,0x1b,0x00,0xb7,0x05,0x1f,0x00,0xa7,0x05,0x23,0x00,0x98,0x05,0x27,0x00,0x88,0x05,0x2b,0x00,0x79,0x05,  \
    0x2e,0x00,0x6a,0x05,0x32,0x00,0x5b,0x05,0x36,0x00,0x4c,0x05,0x39,0x00,0x3c,0x05,0x3d,0x00,0x2d,0x05,0x40,0x00,0x1d,0x05,0x44,0x00,0x0e,0x05,0x47,0x00,0xff,0x04,0x4b,0x00,0xf0,0x04,0x4e,0x00,0xe1,0x04,0x52,0x00,0xd2,0x04,0x55,0x00,0xc3,0x04,0x58,0x00,0xb4,0x04,0x5c,0x00,0xa5,0x04,0x5f,0x00,0x96,0x04,0x62,0x00,0x87,0x04,0x65,0x00,0x78,0x04,0x69,0x00,0x6a,0x04,0x6c,0x00,0x5b,0x04,0x6f,0x00,0x4c,0x04,0x72,0x00,0x3e,0x04,0x75,0x00,0x2f,0x04,0x78,0x00,  \
    0x21,0x04,0x7b,0x00,0x12,0x04,0x7e,0x00,0x04,0x04,0x81,0x00,0xf6,0x03,0x84,0x00,0xe8,0x03,0x87,0x00,0xda,0x03,0x8a,0x00,0xcc,0x03,0x8d,0x00,0xbe,0x03,0x90,0x00,0xb0,0x03,0x92,0x00,0xa2,0x03,0x95,0x00,0x94,0x03,0x98,0x00,0x86,0x03,0x9b,0x00,0x78,0x03,0x9d,0x00,0x6b,0x03,0xa0,0x00,0x5d,0x03,0xa3,0x00,0x4f,0x03,0xa5,0x00,0x42,0x03,0xa8,0x00,0x34,0x03,0xaa,0x00,0x27,0x03,0xad,0x00,0x19,0x03,0xaf,0x00,0x0c,0x03,0xb1,0x00,0xfe,0x02,0xb4,0x00,0xf1,0x02,  \
    0xb6,0x00,0xe3,0x02,0xb8,0x00,0xd6,0x02,0xbb,0x00,0xc9,0x02,0xbd,0x00,0xbc,0x02,0xbf,0x00,0xae,0x02,0xc1,0x00,0xa1,0x02,0xc3,0x00,0x94,0x02,0xc5,0x00,0x87,0x02,0xc7,0x00,0x7a,0x02,0xc9,0x00,0x6d,0x02,0xcb,0x00,0x60,0x02,0xcd,0x00,0x53,0x02,0xcf,0x00,0x46,0x02,0xd1,0x00,0x39,0x02,0xd3,0x00,0x2c,0x02,0xd5,0x00,0x1f,0x02,0xd7,0x00,0x12,0x02,0xd8,0x00,0x06,0x02,0xda,0x00,0xf9,0x01,0xdc,0x00,0xec,0x01,0xdd,0x00,0xdf,0x01,0xdf,0x00,0xd2,0x01,0xe1,0x00,  \
    0xc6,0x01,0xe2,0x00,0xb9,0x01,0xe3,0x00,0xac,0x01,0xe5,0x00,0xa0,0x01,0xe6,0x00,0x93,0x01,0xe8,0x00,0x86,0x01,0xe9,0x00,0x7a,0x01,0xea,0x00,0x6d,0x01,0xec,0x00,0x61,0x01,0xed,0x00,0x54,0x01,0xee,0x00,0x47,0x01,0xef,0x00,0x3b,0x01,0xf0,0x00,0x2e,0x01,0xf1,0x00,0x22,0x01,0xf2,0x00,0x15,0x01,0xf3,0x00,0x09,0x01,0xf4,0x00,0xfc,0x00,0xf5,0x00,0xf0,0x00,0xf6,0x00,0xe3,0x00,0xf7,0x00,0xd7,0x00,0xf8,0x00,0xca,0x00,0xf9,0x00,0xbe,0x00,0xf9,0x00,0xb1,0x00,  \
    0xfa,0x00,0xa5,0x00,0xfb,0x00,0x98,0x00,0xfb,0x00,0x8c,0x00,0xfc,0x00,0x7f,0x00,0xfc,0x00,0x73,0x00,0xfd,0x00,0x67,0x00,0xfd,0x00,0x5a,0x00,0xfe,0x00,0x4e,0x00,0xfe,0x00,0x42,0x00,0xff,0x00,0x35,0x00,0xff,0x00,0x29,0x00,0xff,0x00,0x1c,0x00,0x00,0x01,0x10,0x00,0x00,0x01,0x04,0x00,0x00,0x01,0xf7,0xff,0x00,0x01,0xeb,0xff,0x00,0x01,0xdf,0xff,0x00,0x01,0xd2,0xff,0x00,0x01,0xc6,0xff,0x00,0x01,0xba,0xff,0x00,0x01,0xad,0xff,0x00,0x01,0xa1,0xff,0x00,0x01,  \
    0x94,0xff,0x00,0x01,0x88,0xff,0x00,0x01,0x7c,0xff,0xff,0x00,0x6f,0xff,0xff,0x00,0x63,0xff,0xff,0x00,0x56,0xff,0xff,0x00,0x4a,0xff,0xfe,0x00,0x3e,0xff,0xfe,0x00,0x31,0xff,0xfd,0x00,0x25,0xff,0xfd,0x00,0x18,0xff,0xfc,0x00,0x0c,0xff,0xfc,0x00,0xff,0xfe,0xfb,0x00,0xf3,0xfe,0xfb,0x00,0xe6,0xfe,0xfa,0x00,0xda,0xfe,0xf9,0x00,0xcd,0xfe,0xf9,0x00,0xc0,0xfe,0xf8,0x00,0xb4,0xfe,0xf7,0x00,0xa7,0xfe,0xf6,0x00,0x9b,0xfe,0xf5,0x00,0x8e,0xfe,0xf4,0x00,0x81,0xfe,  \
    0xf3,0x00,0x75,0xfe,0xf2,0x00,0x68,0xfe,0xf1,0x00,0x5c,0xfe,0xf0,0x00,0x4f,0xfe,0xef,0x00,0x43,0xfe,0xee,0x00,0x37,0xfe,0xed,0x00,0x2a,0xfe,0xec,0x00,0x1e,0xfe,0xea,0x00,0x12,0xfe,0xe9,0x00,0x05,0xfe,0xe8,0x00,0xf9,0xfd,0xe6,0x00,0xec,0xfd,0xe5,0x00,0xe0,0xfd,0xe3,0x00,0xd4,0xfd,0xe2,0x00,0xc7,0xfd,0xe0,0x00,0xbb,0xfd,0xdf,0x00,0xae,0xfd,0xdd,0x00,0xa2,0xfd,0xdc,0x00,0x96,0xfd,0xda,0x00,0x89,0xfd,0xd8,0x00,0x7d,0xfd,0xd6,0x00,0x70,0xfd,0xd5,0x00,  \
    0x64,0xfd,0xd3,0x00,0x57,0xfd,0xd1,0x00,0x4b,0xfd,0xcf,0x00,0x3e,0xfd,0xcd,0x00,0x32,0xfd,0xcb,0x00,0x25,0xfd,0xc9,0x00,0x19,0xfd,0xc7,0x00,0x0b,0xfd,0xc5,0x00,0xfe,0xfc,0xc3,0x00,0xf1,0xfc,0xc1,0x00,0xe4,0xfc,0xbf,0x00,0xd6,0xfc,0xbd,0x00,0xc9,0xfc,0xba,0x00,0xbc,0xfc,0xb8,0x00,0xae,0xfc,0xb6,0x00,0xa1,0xfc,0xb4,0x00,0x93,0xfc,0xb1,0x00,0x86,0xfc,0xaf,0x00,0x78,0xfc,0xad,0x00,0x6a,0xfc,0xaa,0x00,0x5d,0xfc,0xa8,0x00,0x4f,0xfc,0xa5,0x00,0x41,0xfc,  \
    0xa3,0x00,0x33,0xfc,0xa0,0x00,0x26,0xfc,0x9e,0x00,0x18,0xfc,0x9b,0x00,0x0a,0xfc,0x98,0x00,0xfc,0xfb,0x96,0x00,0xee,0xfb,0x93,0x00,0xe0,0xfb,0x90,0x00,0xd2,0xfb,0x8d,0x00,0xc4,0xfb,0x8b,0x00,0xb5,0xfb,0x88,0x00,0xa7,0xfb,0x85,0x00,0x99,0xfb,0x82,0x00,0x8b,0xfb,0x7f,0x00,0x7d,0xfb,0x7c,0x00,0x6f,0xfb,0x79,0x00,0x61,0xfb,0x76,0x00,0x53,0xfb,0x73,0x00,0x45,0xfb,0x70,0x00,0x37,0xfb,0x6c,0x00,0x28,0xfb,0x69,0x00,0x1a,0xfb,0x66,0x00,0x0b,0xfb,0x63,0x00,  \
    0xfd,0xfa,0x60,0x00,0xef,0xfa,0x5c,0x00,0xe0,0xfa,0x59,0x00,0xd1,0xfa,0x56,0x00,0xc3,0xfa,0x52,0x00,0xb4,0xfa,0x4f,0x00,0xa5,0xfa,0x4b,0x00,0x97,0xfa,0x48,0x00,0x88,0xfa,0x44,0x00,0x79,0xfa,0x41,0x00,0x6a,0xfa,0x3d,0x00,0x5b,0xfa,0x3a,0x00,0x4c,0xfa,0x36,0x00,0x3d,0xfa,0x32,0x00,0x2e,0xfa,0x2e,0x00,0x1f,0xfa,0x2b,0x00,0x10,0xfa,0x27,0x00,0x01,0xfa,0x23,0x00,0xf1,0xf9,0x1f,0x00,0xe2,0xf9,0x1c,0x00,0xd3,0xf9,0x18,0x00,0xc3,0xf9,0x14,0x00,0xb4,0xf9,  \
    0x10,0x00,0xa4,0xf9,0x0c,0x00,0x94,0xf9,0x08,0x00,0x85,0xf9,0x04,0x00,0x75,0xf9,0x00,0x00,0x65,0xf9,0xfc,0xff,0x55,0xf9,0xf8,0xff,0x45,0xf9,0xf4,0xff,0x35,0xf9,0xf0,0xff,0x25,0xf9,0xec,0xff,0x15,0xf9,0xe7,0xff,0x05,0xf9,0xe3,0xff,0xf5,0xf8,0xdf,0xff,0xe4,0xf8,0xdb,0xff,0xd4,0xf8,0xd6,0xff,0xc3,0xf8,0xd2,0xff,0xb3,0xf8,0xce,0xff,0xa2,0xf8,0xca,0xff,0x91,0xf8,0xc5,0xff,0x81,0xf8,0xc1,0xff,0x70,0xf8,0xbd,0xff,0x5f,0xf8,0xb8,0xff,0x4e,0xf8,0xb4,0xff,  \
    0x3d,0xf8,0xaf,0xff,0x2c,0xf8,0xab,0xff,0x1a,0xf8,0xa7,0xff,0x09,0xf8,0xa2,0xff,0xf8,0xf7,0x9e,0xff,0xe6,0xf7,0x99,0xff,0xd5,0xf7,0x95,0xff,0xc3,0xf7,0x90,0xff,0xb1,0xf7,0x8b,0xff,0xa0,0xf7,0x87,0xff,0x8e,0xf7,0x82,0xff,0x7c,0xf7,0x7e,0xff,0x6a,0xf7,0x79,0xff,0x58,0xf7,0x75,0xff,0x45,0xf7,0x70,0xff,0x33,0xf7,0x6b,0xff,0x21,0xf7,0x67,0xff,0x0e,0xf7,0x62,0xff,0xfc,0xf6,0x5e,0xff,0xe9,0xf6,0x59,0xff,0xd6,0xf6,0x54,0xff,0xc3,0xf6,0x50,0xff,0xb0,0xf6,  \
    0x4b,0xff,0x9d,0xf6,0x46,0xff,0x8a,0xf6,0x42,0xff,0x77,0xf6,0x3d,0xff,0x64,0xf6,0x38,0xff,0x50,0xf6,0x34,0xff,0x3d,0xf6,0x2f,0xff,0x29,0xf6,0x2a,0xff,0x15,0xf6,0x26,0xff,0x02,0xf6,0x21,0xff,0xed,0xf5,0x1c,0xff,0xd9,0xf5,0x18,0xff,0xc5,0xf5,0x13,0xff,0xb1,0xf5,0x0e,0xff,0x9c,0xf5,0x0a,0xff,0x88,0xf5,0x05,0xff,0x73,0xf5,0x01,0xff,0x5e,0xf5,0xfc,0xfe,0x4a,0xf5,0xf8,0xfe,0x35,0xf5,0xf3,0xfe,0x1f,0xf5,0xee,0xfe,0x0a,0xf5,0xea,0xfe,0xf5,0xf4,0xe5,0xfe,  \
    0xe0,0xf4,0xe1,0xfe,0xca,0xf4,0xdc,0xfe,0xb4,0xf4,0xd8,0xfe,0x9f,0xf4,0xd3,0xfe,0x89,0xf4,0xcf,0xfe,0x73,0xf4,0xcb,0xfe,0x5d,0xf4,0xc6,0xfe,0x47,0xf4,0xc2,0xfe,0x31,0xf4,0xbd,0xfe,0x1b,0xf4,0xb9,0xfe,0x04,0xf4,0xb5,0xfe,0xee,0xf3,0xb0,0xfe,0xd7,0xf3,0xac,0xfe,0xc0,0xf3,0xa8,0xfe,0xa9,0xf3,0xa3,0xfe,0x92,0xf3,0x9f,0xfe,0x7b,0xf3,0x9b,0xfe,0x64,0xf3,0x97,0xfe,0x4c,0xf3,0x93,0xfe,0x35,0xf3,0x8f,0xfe,0x1d,0xf3,0x8b,0xfe,0x06,0xf3,0x87,0xfe,0xee,0xf2,  \
    0x83,0xfe,0xd6,0xf2,0x7f,0xfe,0xbd,0xf2,0x7b,0xfe,0xa5,0xf2,0x77,0xfe,0x8d,0xf2,0x73,0xfe,0x74,0xf2,0x70,0xfe,0x5b,0xf2,0x6c,0xfe,0x43,0xf2,0x68,0xfe,0x2a,0xf2,0x65,0xfe,0x10,0xf2,0x61,0xfe,0xf7,0xf1,0x5e,0xfe,0xde,0xf1,0x5a,0xfe,0xc4,0xf1,0x57,0xfe,0xab,0xf1,0x53,0xfe,0x91,0xf1,0x50,0xfe,0x77,0xf1,0x4d,0xfe,0x5d,0xf1,0x4a,0xfe,0x43,0xf1,0x47,0xfe,0x29,0xf1,0x44,0xfe,0x0e,0xf1,0x41,0xfe,0xf4,0xf0,0x3e,0xfe,0xd9,0xf0,0x3b,0xfe,0xbe,0xf0,0x38,0xfe,  \
    0xa3,0xf0,0x35,0xfe,0x89,0xf0,0x32,0xfe,0x6d,0xf0,0x30,0xfe,0x52,0xf0,0x2d,0xfe,0x37,0xf0,0x2a,0xfe,0x1b,0xf0,0x28,0xfe,0x00,0xf0,0x26,0xfe,0xe4,0xef,0x23,0xfe,0xc8,0xef,0x21,0xfe,0xac,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfa,0xfd,0x61,0x10,0xfc,0xfd,0x45,0x10,0xff,0xfd,0x28,0x10,0x01,0xfe,0x0c,0x10,0x03,0xfe,0xf0,0x0f,0x06,0xfe,0xd4,0x0f,0x09,0xfe,0xb9,0x0f,0x0b,0xfe,0x9d,0x0f,0x0e,0xfe,0x82,0x0f,0x11,0xfe,0x66,0x0f,0x14,0xfe,0x4b,0x0f,0x16,0xfe,0x30,0x0f,0x19,0xfe,0x15,0x0f,0x1d,0xfe,0xfa,0x0e,0x20,0xfe,0xe0,0x0e,0x23,0xfe,0xc5,0x0e,0x26,0xfe,0xab,0x0e,0x29,0xfe,0x90,0x0e,0x2d,0xfe,0x76,0x0e,0x30,0xfe,0x5c,0x0e,0x33,0xfe,  \
    0x42,0x0e,0x37,0xfe,0x28,0x0e,0x3a,0xfe,0x0e,0x0e,0x3e,0xfe,0xf5,0x0d,0x41,0xfe,0xdb,0x0d,0x45,0xfe,0xc2,0x0d,0x49,0xfe,0xa8,0x0d,0x4d,0xfe,0x8f,0x0d,0x50,0xfe,0x76,0x0d,0x54,0xfe,0x5d,0x0d,0x58,0xfe,0x44,0x0d,0x5c,0xfe,0x2c,0x0d,0x60,0xfe,0x13,0x0d,0x64,0xfe,0xfb,0x0c,0x68,0xfe,0xe2,0x0c,0x6c,0xfe,0xca,0x0c,0x70,0xfe,0xb2,0x0c,0x74,0xfe,0x9a,0x0c,0x78,0xfe,0x82,0x0c,0x7c,0xfe,0x6a,0x0c,0x81,0xfe,0x53,0x0c,0x85,0xfe,0x3c,0x0c,0x8a,0xfe,0x25,0x0c,  \
    0x8f,0xfe,0x0e,0x0c,0x93,0xfe,0xf8,0x0b,0x98,0xfe,0xe1,0x0b,0x9d,0xfe,0xcb,0x0b,0xa1,0xfe,0xb5,0x0b,0xa6,0xfe,0x9f,0x0b,0xab,0xfe,0x89,0x0b,0xb0,0xfe,0x73,0x0b,0xb4,0xfe,0x5d,0x0b,0xb9,0xfe,0x48,0x0b,0xbe,0xfe,0x32,0x0b,0xc3,0xfe,0x1d,0x0b,0xc8,0xfe,0x08,0x0b,0xcd,0xfe,0xf3,0x0a,0xd2,0xfe,0xdd,0x0a,0xd6,0xfe,0xc8,0x0a,0xdb,0xfe,0xb2,0x0a,0xe0,0xfe,0x9d,0x0a,0xe4,0xfe,0x88,0x0a,0xe9,0xfe,0x73,0x0a,0xee,0xfe,0x5e,0x0a,0xf3,0xfe,0x49,0x0a,0xf7,0xfe,  \
    0x34,0x0a,0xfc,0xfe,0x1f,0x0a,0x01,0xff,0x0b,0x0a,0x06,0xff,0xf6,0x09,0x0a,0xff,0xe2,0x09,0x0f,0xff,0xce,0x09,0x14,0xff,0xb9,0x09,0x19,0xff,0xa5,0x09,0x1d,0xff,0x91,0x09,0x22,0xff,0x7d,0x09,0x27,0xff,0x69,0x09,0x2c,0xff,0x56,0x09,0x30,0xff,0x42,0x09,0x35,0xff,0x2e,0x09,0x3a,0xff,0x1b,0x09,0x3f,0xff,0x08,0x09,0x43,0xff,0xf4,0x08,0x48,0xff,0xe1,0x08,0x4d,0xff,0xce,0x08,0x51,0xff,0xbb,0x08,0x56,0xff,0xa8,0x08,0x5b,0xff,0x95,0x08,0x60,0xff,0x83,0x08,  \
    0x64,0xff,0x70,0x08,0x69,0xff,0x5d,0x08,0x6e,0xff,0x4b,0x08,0x72,0xff,0x38,0x08,0x77,0xff,0x26,0x08,0x7c,0xff,0x14,0x08,0x80,0xff,0x02,0x08,0x85,0xff,0xf0,0x07,0x8a,0xff,0xde,0x07,0x8e,0xff,0xcd,0x07,0x93,0xff,0xbb,0x07,0x98,0xff,0xaa,0x07,0x9c,0xff,0x98,0x07,0xa1,0xff,0x87,0x07,0xa5,0xff,0x76,0x07,0xaa,0xff,0x64,0x07,0xaf,0xff,0x53,0x07,0xb3,0xff,0x42,0x07,0xb8,0xff,0x31,0x07,0xbc,0xff,0x20,0x07,0xc1,0xff,0x10,0x07,0xc5,0xff,0xff,0x06,0xc9,0xff,  \
    0xee,0x06,0xce,0xff,0xde,0x06,0xd2,0xff,0xcd,0x06,0xd7,0xff,0xbd,0x06,0xdb,0xff,0xac,0x06,0xdf,0xff,0x9c,0x06,0xe3,0xff,0x8b,0x06,0xe8,0xff,0x7b,0x06,0xec,0xff,0x6b,0x06,0xf0,0xff,0x5b,0x06,0xf4,0xff,0x4b,0x06,0xf8,0xff,0x3b,0x06,0xfd,0xff,0x2b,0x06,0x01,0x00,0x1b,0x06,0x05,0x00,0x0b,0x06,0x09,0x00,0xfb,0x05,0x0d,0x00,0xeb,0x05,0x11,0x00,0xdc,0x05,0x15,0x00,0xcc,0x05,0x19,0x00,0xbd,0x05,0x1d,0x00,0xad,0x05,0x21,0x00,0x9e,0x05,0x24,0x00,0x8e,0x05,  \
    0x28,0x00,0x7f,0x05,0x2c,0x00,0x70,0x05,0x30,0x00,0x61,0x05,0x34,0x00,0x52,0x05,0x37,0x00,0x42,0x05,0x3b,0x00,0x33,0x05,0x3e,0x00,0x23,0x05,0x42,0x00,0x14,0x05,0x45,0x00,0x05,0x05,0x49,0x00,0xf6,0x04,0x4c,0x00,0xe6,0x04,0x50,0x00,0xd7,0x04,0x53,0x00,0xc8,0x04,0x57,0x00,0xb9,0x04,0x5a,0x00,0xaa,0x04,0x5d,0x00,0x9b,0x04,0x61,0x00,0x8d,0x04,0x64,0x00,0x7e,0x04,0x67,0x00,0x6f,0x04,0x6a,0x00,0x60,0x04,0x6e,0x00,0x52,0x04,0x71,0x00,0x43,0x04,0x74,0x00,  \
    0x35,0x04,0x77,0x00,0x26,0x04,0x7a,0x00,0x18,0x04,0x7d,0x00,0x09,0x04,0x80,0x00,0xfb,0x03,0x83,0x00,0xec,0x03,0x86,0x00,0xde,0x03,0x89,0x00,0xd0,0x03,0x8c,0x00,0xc2,0x03,0x8f,0x00,0xb4,0x03,0x92,0x00,0xa6,0x03,0x94,0x00,0x99,0x03,0x97,0x00,0x8b,0x03,0x9a,0x00,0x7d,0x03,0x9d,0x00,0x6f,0x03,0x9f,0x00,0x61,0x03,0xa2,0x00,0x54,0x03,0xa4,0x00,0x46,0x03,0xa7,0x00,0x39,0x03,0xaa,0x00,0x2b,0x03,0xac,0x00,0x1d,0x03,0xae,0x00,0x10,0x03,0xb1,0x00,0x02,0x03,  \
    0xb3,0x00,0xf5,0x02,0xb6,0x00,0xe8,0x02,0xb8,0x00,0xda,0x02,0xba,0x00,0xcd,0x02,0xbd,0x00,0xbf,0x02,0xbf,0x00,0xb2,0x02,0xc1,0x00,0xa5,0x02,0xc3,0x00,0x98,0x02,0xc5,0x00,0x8a,0x02,0xc7,0x00,0x7d,0x02,0xc9,0x00,0x70,0x02,0xcb,0x00,0x63,0x02,0xcd,0x00,0x56,0x02,0xcf,0x00,0x49,0x02,0xd1,0x00,0x3c,0x02,0xd3,0x00,0x2f,0x02,0xd5,0x00,0x22,0x02,0xd7,0x00,0x16,0x02,0xd8,0x00,0x09,0x02,0xda,0x00,0xfc,0x01,0xdc,0x00,0xef,0x01,0xdd,0x00,0xe2,0x01,0xdf,0x00,  \
    0xd5,0x01,0xe1,0x00,0xc9,0x01,0xe2,0x00,0xbc,0x01,0xe4,0x00,0xaf,0x01,0xe5,0x00,0xa2,0x01,0xe7,0x00,0x96,0x01,0xe8,0x00,0x89,0x01,0xe9,0x00,0x7c,0x01,0xeb,0x00,0x6f,0x01,0xec,0x00,0x63,0x01,0xed,0x00,0x56,0x01,0xee,0x00,0x4a,0x01,0xf0,0x00,0x3d,0x01,0xf1,0x00,0x30,0x01,0xf2,0x00,0x24,0x01,0xf3,0x00,0x17,0x01,0xf4,0x00,0x0a,0x01,0xf5,0x00,0xfe,0x00,0xf6,0x00,0xf1,0x00,0xf7,0x00,0xe5,0x00,0xf7,0x00,0xd8,0x00,0xf8,0x00,0xcc,0x00,0xf9,0x00,0xbf,0x00,  \
    0xfa,0x00,0xb3,0x00,0xfb,0x00,0xa6,0x00,0xfb,0x00,0x9a,0x00,0xfc,0x00,0x8d,0x00,0xfc,0x00,0x81,0x00,0xfd,0x00,0x74,0x00,0xfe,0x00,0x68,0x00,0xfe,0x00,0x5b,0x00,0xfe,0x00,0x4f,0x00,0xff,0x00,0x42,0x00,0xff,0x00,0x36,0x00,0x00,0x01,0x29,0x00,0x00,0x01,0x1d,0x00,0x00,0x01,0x10,0x00,0x00,0x01,0x04,0x00,0x01,0x01,0xf8,0xff,0x01,0x01,0xeb,0xff,0x01,0x01,0xdf,0xff,0x01,0x01,0xd2,0xff,0x01,0x01,0xc6,0xff,0x01,0x01,0xb9,0xff,0x01,0x01,0xad,0xff,0x01,0x01,  \
    0xa1,0xff,0x01,0x01,0x94,0xff,0x00,0x01,0x88,0xff,0x00,0x01,0x7b,0xff,0x00,0x01,0x6f,0xff,0x00,0x01,0x62,0xff,0xff,0x00,0x56,0xff,0xff,0x00,0x49,0xff,0xff,0x00,0x3d,0xff,0xfe,0x00,0x30,0xff,0xfe,0x00,0x24,0xff,0xfd,0x00,0x17,0xff,0xfd,0x00,0x0b,0xff,0xfc,0x00,0xfe,0xfe,0xfc,0x00,0xf1,0xfe,0xfb,0x00,0xe5,0xfe,0xfa,0x00,0xd8,0xfe,0xfa,0x00,0xcc,0xfe,0xf9,0x00,0xbf,0xfe,0xf8,0x00,0xb2,0xfe,0xf7,0x00,0xa5,0xfe,0xf7,0x00,0x99,0xfe,0xf6,0x00,0x8c,0xfe,  \
    0xf5,0x00,0x7f,0xfe,0xf4,0x00,0x73,0xfe,0xf3,0x00,0x66,0xfe,0xf2,0x00,0x5a,0xfe,0xf1,0x00,0x4d,0xfe,0xf0,0x00,0x41,0xfe,0xee,0x00,0x34,0xfe,0xed,0x00,0x28,0xfe,0xec,0x00,0x1b,0xfe,0xeb,0x00,0x0f,0xfe,0xe9,0x00,0x03,0xfe,0xe8,0x00,0xf6,0xfd,0xe7,0x00,0xea,0xfd,0xe5,0x00,0xdd,0xfd,0xe4,0x00,0xd1,0xfd,0xe2,0x00,0xc4,0xfd,0xe1,0x00,0xb8,0xfd,0xdf,0x00,0xac,0xfd,0xdd,0x00,0x9f,0xfd,0xdc,0x00,0x93,0xfd,0xda,0x00,0x86,0xfd,0xd8,0x00,0x7a,0xfd,0xd7,0x00,  \
    0x6d,0xfd,0xd5,0x00,0x61,0xfd,0xd3,0x00,0x54,0xfd,0xd1,0x00,0x48,0xfd,0xcf,0x00,0x3b,0xfd,0xcd,0x00,0x2e,0xfd,0xcb,0x00,0x22,0xfd,0xc9,0x00,0x15,0xfd,0xc7,0x00,0x08,0xfd,0xc5,0x00,0xfb,0xfc,0xc3,0x00,0xed,0xfc,0xc1,0x00,0xe0,0xfc,0xbf,0x00,0xd3,0xfc,0xbc,0x00,0xc5,0xfc,0xba,0x00,0xb8,0xfc,0xb8,0x00,0xaa,0xfc,0xb6,0x00,0x9d,0xfc,0xb3,0x00,0x8f,0xfc,0xb1,0x00,0x81,0xfc,0xaf,0x00,0x74,0xfc,0xac,0x00,0x66,0xfc,0xaa,0x00,0x58,0xfc,0xa7,0x00,0x4b,0xfc,  \
    0xa5,0x00,0x3d,0xfc,0xa2,0x00,0x2f,0xfc,0xa0,0x00,0x21,0xfc,0x9d,0x00,0x13,0xfc,0x9a,0x00,0x05,0xfc,0x98,0x00,0xf7,0xfb,0x95,0x00,0xe9,0xfb,0x92,0x00,0xdb,0xfb,0x90,0x00,0xcd,0xfb,0x8d,0x00,0xbf,0xfb,0x8a,0x00,0xb0,0xfb,0x87,0x00,0xa2,0xfb,0x84,0x00,0x94,0xfb,0x81,0x00,0x86,0xfb,0x7e,0x00,0x78,0xfb,0x7b,0x00,0x6a,0xfb,0x78,0x00,0x5c,0xfb,0x75,0x00,0x4e,0xfb,0x72,0x00,0x3f,0xfb,0x6f,0x00,0x31,0xfb,0x6b,0x00,0x23,0xfb,0x68,0x00,0x14,0xfb,0x65,0x00,  \
    0x06,0xfb,0x62,0x00,0xf7,0xfa,0x5e,0x00,0xe9,0xfa,0x5b,0x00,0xda,0xfa,0x58,0x00,0xcc,0xfa,0x54,0x00,0xbd,0xfa,0x51,0x00,0xae,0xfa,0x4d,0x00,0xa0,0xfa,0x4a,0x00,0x91,0xfa,0x46,0x00,0x82,0xfa,0x43,0x00,0x73,0xfa,0x3f,0x00,0x64,0xfa,0x3c,0x00,0x55,0xfa,0x38,0x00,0x46,0xfa,0x34,0x00,0x37,0xfa,0x30,0x00,0x28,0xfa,0x2d,0x00,0x19,0xfa,0x29,0x00,0x0a,0xfa,0x25,0x00,0xfa,0xf9,0x21,0x00,0xeb,0xf9,0x1d,0x00,0xdc,0xf9,0x1a,0x00,0xcc,0xf9,0x16,0x00,0xbd,0xf9,  \
    0x12,0x00,0xad,0xf9,0x0e,0x00,0x9e,0xf9,0x0a,0x00,0x8e,0xf9,0x06,0x00,0x7e,0xf9,0x02,0x00,0x6f,0xf9,0xfe,0xff,0x5f,0xf9,0xfa,0xff,0x4f,0xf9,0xf5,0xff,0x3f,0xf9,0xf1,0xff,0x2f,0xf9,0xed,0xff,0x1f,0xf9,0xe9,0xff,0x0f,0xf9,0xe5,0xff,0xfe,0xf8,0xe0,0xff,0xee,0xf8,0xdc,0xff,0xde,0xf8,0xd8,0xff,0xcd,0xf8,0xd4,0xff,0xbd,0xf8,0xcf,0xff,0xac,0xf8,0xcb,0xff,0x9c,0xf8,0xc7,0xff,0x8b,0xf8,0xc2,0xff,0x7a,0xf8,0xbe,0xff,0x69,0xf8,0xb9,0xff,0x58,0xf8,0xb5,0xff,  \
    0x47,0xf8,0xb0,0xff,0x36,0xf8,0xac,0xff,0x25,0xf8,0xa8,0xff,0x14,0xf8,0xa3,0xff,0x03,0xf8,0x9e,0xff,0xf1,0xf7,0x9a,0xff,0xe0,0xf7,0x95,0xff,0xce,0xf7,0x91,0xff,0xbd,0xf7,0x8c,0xff,0xab,0xf7,0x88,0xff,0x99,0xf7,0x83,0xff,0x87,0xf7,0x7e,0xff,0x75,0xf7,0x7a,0xff,0x63,0xf7,0x75,0xff,0x51,0xf7,0x70,0xff,0x3f,0xf7,0x6c,0xff,0x2d,0xf7,0x67,0xff,0x1a,0xf7,0x62,0xff,0x08,0xf7,0x5e,0xff,0xf5,0xf6,0x59,0xff,0xe3,0xf6,0x54,0xff,0xd0,0xf6,0x50,0xff,0xbd,0xf6,  \
    0x4b,0xff,0xaa,0xf6,0x46,0xff,0x97,0xf6,0x41,0xff,0x84,0xf6,0x3d,0xff,0x71,0xf6,0x38,0xff,0x5d,0xf6,0x33,0xff,0x4a,0xf6,0x2e,0xff,0x37,0xf6,0x2a,0xff,0x23,0xf6,0x25,0xff,0x0f,0xf6,0x20,0xff,0xfb,0xf5,0x1c,0xff,0xe7,0xf5,0x17,0xff,0xd3,0xf5,0x12,0xff,0xbf,0xf5,0x0d,0xff,0xab,0xf5,0x09,0xff,0x96,0xf5,0x04,0xff,0x82,0xf5,0xff,0xfe,0x6d,0xf5,0xfb,0xfe,0x58,0xf5,0xf6,0xfe,0x44,0xf5,0xf2,0xfe,0x2f,0xf5,0xed,0xfe,0x1a,0xf5,0xe8,0xfe,0x04,0xf5,0xe4,0xfe,  \
    0xef,0xf4,0xdf,0xfe,0xda,0xf4,0xdb,0xfe,0xc4,0xf4,0xd6,0xfe,0xaf,0xf4,0xd2,0xfe,0x99,0xf4,0xcd,0xfe,0x83,0xf4,0xc8,0xfe,0x6d,0xf4,0xc4,0xfe,0x57,0xf4,0xbf,0xfe,0x41,0xf4,0xbb,0xfe,0x2b,0xf4,0xb6,0xfe,0x15,0xf4,0xb2,0xfe,0xfe,0xf3,0xae,0xfe,0xe8,0xf3,0xa9,0xfe,0xd1,0xf3,0xa5,0xfe,0xba,0xf3,0xa0,0xfe,0xa4,0xf3,0x9c,0xfe,0x8d,0xf3,0x98,0xfe,0x76,0xf3,0x94,0xfe,0x5e,0xf3,0x8f,0xfe,0x47,0xf3,0x8b,0xfe,0x2f,0xf3,0x87,0xfe,0x18,0xf3,0x83,0xfe,0x00,0xf3,  \
    0x7f,0xfe,0xe8,0xf2,0x7b,0xfe,0xd0,0xf2,0x77,0xfe,0xb8,0xf2,0x73,0xfe,0xa0,0xf2,0x6f,0xfe,0x87,0xf2,0x6b,0xfe,0x6f,0xf2,0x68,0xfe,0x56,0xf2,0x64,0xfe,0x3d,0xf2,0x60,0xfe,0x24,0xf2,0x5c,0xfe,0x0b,0xf2,0x59,0xfe,0xf2,0xf1,0x55,0xfe,0xd9,0xf1,0x52,0xfe,0xbf,0xf1,0x4e,0xfe,0xa6,0xf1,0x4b,0xfe,0x8c,0xf1,0x48,0xfe,0x72,0xf1,0x44,0xfe,0x58,0xf1,0x41,0xfe,0x3e,0xf1,0x3e,0xfe,0x24,0xf1,0x3b,0xfe,0x09,0xf1,0x38,0xfe,0xef,0xf0,0x35,0xfe,0xd4,0xf0,0x32,0xfe,  \
    0xb9,0xf0,0x2f,0xfe,0x9e,0xf0,0x2c,0xfe,0x84,0xf0,0x29,0xfe,0x68,0xf0,0x27,0xfe,0x4d,0xf0,0x24,0xfe,0x32,0xf0,0x21,0xfe,0x16,0xf0,0x1f,0xfe,0xfb,0xef,0x1c,0xfe,0xdf,0xef,0x1a,0xfe,0xc3,0xef,0x18,0xfe,0xa7,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xed,0xfd,0x65,0x10,0xf0,0xfd,0x49,0x10,0xf2,0xfd,0x2c,0x10,0xf5,0xfd,0x10,0x10,0xf7,0xfd,0xf4,0x0f,0xfa,0xfd,0xd8,0x0f,0xfc,0xfd,0xbd,0x0f,0xff,0xfd,0xa1,0x0f,0x02,0xfe,0x86,0x0f,0x05,0xfe,0x6a,0x0f,0x07,0xfe,0x4f,0x0f,0x0a,0xfe,0x34,0x0f,0x0d,0xfe,0x19,0x0f,0x11,0xfe,0xfe,0x0e,0x14,0xfe,0xe4,0x0e,0x17,0xfe,0xc9,0x0e,0x1a,0xfe,0xaf,0x0e,0x1e,0xfe,0x95,0x0e,0x21,0xfe,0x7a,0x0e,0x24,0xfe,  \
    0x60,0x0e,0x28,0xfe,0x46,0x0e,0x2b,0xfe,0x2c,0x0e,0x2f,0xfe,0x13,0x0e,0x33,0xfe,0xf9,0x0d,0x36,0xfe,0xdf,0x0d,0x3a,0xfe,0xc6,0x0d,0x3e,0xfe,0xad,0x0d,0x42,0xfe,0x94,0x0d,0x45,0xfe,0x7b,0x0d,0x49,0xfe,0x62,0x0d,0x4d,0xfe,0x49,0x0d,0x51,0xfe,0x30,0x0d,0x55,0xfe,0x18,0x0d,0x59,0xfe,0xff,0x0c,0x5d,0xfe,0xe7,0x0c,0x61,0xfe,0xce,0x0c,0x66,0xfe,0xb6,0x0c,0x6a,0xfe,0x9e,0x0c,0x6e,0xfe,0x86,0x0c,0x72,0xfe,0x6f,0x0c,0x77,0xfe,0x57,0x0c,0x7b,0xfe,0x40,0x0c,  \
    0x80,0xfe,0x2a,0x0c,0x85,0xfe,0x13,0x0c,0x8a,0xfe,0xfd,0x0b,0x8e,0xfe,0xe6,0x0b,0x93,0xfe,0xd0,0x0b,0x98,0xfe,0xba,0x0b,0x9d,0xfe,0xa4,0x0b,0xa2,0xfe,0x8e,0x0b,0xa7,0xfe,0x78,0x0b,0xac,0xfe,0x62,0x0b,0xb1,0xfe,0x4d,0x0b,0xb6,0xfe,0x37,0x0b,0xbb,0xfe,0x22,0x0b,0xc0,0xfe,0x0d,0x0b,0xc5,0xfe,0xf8,0x0a,0xca,0xfe,0xe3,0x0a,0xce,0xfe,0xcd,0x0a,0xd3,0xfe,0xb8,0x0a,0xd8,0xfe,0xa3,0x0a,0xdd,0xfe,0x8e,0x0a,0xe1,0xfe,0x78,0x0a,0xe6,0xfe,0x63,0x0a,0xeb,0xfe,  \
    0x4f,0x0a,0xf0,0xfe,0x3a,0x0a,0xf5,0xfe,0x25,0x0a,0xf9,0xfe,0x10,0x0a,0xfe,0xfe,0xfc,0x09,0x03,0xff,0xe8,0x09,0x08,0xff,0xd3,0x09,0x0d,0xff,0xbf,0x09,0x12,0xff,0xab,0x09,0x16,0xff,0x97,0x09,0x1b,0xff,0x83,0x09,0x20,0xff,0x6f,0x09,0x25,0xff,0x5b,0x09,0x2a,0xff,0x48,0x09,0x2f,0xff,0x34,0x09,0x33,0xff,0x21,0x09,0x38,0xff,0x0e,0x09,0x3d,0xff,0xfa,0x08,0x42,0xff,0xe7,0x08,0x47,0xff,0xd4,0x08,0x4c,0xff,0xc1,0x08,0x50,0xff,0xae,0x08,0x55,0xff,0x9b,0x08,  \
    0x5a,0xff,0x89,0x08,0x5f,0xff,0x76,0x08,0x63,0xff,0x63,0x08,0x68,0xff,0x51,0x08,0x6d,0xff,0x3f,0x08,0x72,0xff,0x2c,0x08,0x76,0xff,0x1a,0x08,0x7b,0xff,0x08,0x08,0x80,0xff,0xf6,0x07,0x85,0xff,0xe5,0x07,0x89,0xff,0xd3,0x07,0x8e,0xff,0xc1,0x07,0x93,0xff,0xb0,0x07,0x98,0xff,0x9e,0x07,0x9c,0xff,0x8d,0x07,0xa1,0xff,0x7c,0x07,0xa6,0xff,0x6b,0x07,0xaa,0xff,0x5a,0x07,0xaf,0xff,0x48,0x07,0xb3,0xff,0x38,0x07,0xb8,0xff,0x27,0x07,0xbc,0xff,0x16,0x07,0xc1,0xff,  \
    0x05,0x07,0xc5,0xff,0xf4,0x06,0xca,0xff,0xe4,0x06,0xce,0xff,0xd3,0x06,0xd3,0xff,0xc3,0x06,0xd7,0xff,0xb2,0x06,0xdc,0xff,0xa2,0x06,0xe0,0xff,0x92,0x06,0xe4,0xff,0x81,0x06,0xe9,0xff,0x71,0x06,0xed,0xff,0x61,0x06,0xf1,0xff,0x51,0x06,0xf5,0xff,0x41,0x06,0xf9,0xff,0x31,0x06,0xfe,0xff,0x21,0x06,0x02,0x00,0x11,0x06,0x06,0x00,0x01,0x06,0x0a,0x00,0xf2,0x05,0x0e,0x00,0xe2,0x05,0x12,0x00,0xd2,0x05,0x16,0x00,0xc3,0x05,0x1a,0x00,0xb3,0x05,0x1e,0x00,0xa4,0x05,  \
    0x22,0x00,0x95,0x05,0x26,0x00,0x85,0x05,0x2a,0x00,0x76,0x05,0x2d,0x00,0x67,0x05,0x31,0x00,0x58,0x05,0x35,0x00,0x48,0x05,0x39,0x00,0x39,0x05,0x3c,0x00,0x29,0x05,0x40,0x00,0x1a,0x05,0x43,0x00,0x0b,0x05,0x47,0x00,0xfb,0x04,0x4b,0x00,0xec,0x04,0x4e,0x00,0xdd,0x04,0x51,0x00,0xce,0x04,0x55,0x00,0xbf,0x04,0x58,0x00,0xb0,0x04,0x5c,0x00,0xa1,0x04,0x5f,0x00,0x92,0x04,0x62,0x00,0x83,0x04,0x66,0x00,0x74,0x04,0x69,0x00,0x66,0x04,0x6c,0x00,0x57,0x04,0x6f,0x00,  \
    0x48,0x04,0x72,0x00,0x3a,0x04,0x76,0x00,0x2b,0x04,0x79,0x00,0x1d,0x04,0x7c,0x00,0x0e,0x04,0x7f,0x00,0x00,0x04,0x82,0x00,0xf1,0x03,0x85,0x00,0xe3,0x03,0x88,0x00,0xd5,0x03,0x8b,0x00,0xc7,0x03,0x8e,0x00,0xb9,0x03,0x90,0x00,0xab,0x03,0x93,0x00,0x9d,0x03,0x96,0x00,0x8f,0x03,0x99,0x00,0x82,0x03,0x9c,0x00,0x74,0x03,0x9e,0x00,0x66,0x03,0xa1,0x00,0x58,0x03,0xa4,0x00,0x4b,0x03,0xa6,0x00,0x3d,0x03,0xa9,0x00,0x2f,0x03,0xab,0x00,0x22,0x03,0xae,0x00,0x14,0x03,  \
    0xb0,0x00,0x07,0x03,0xb3,0x00,0xf9,0x02,0xb5,0x00,0xec,0x02,0xb7,0x00,0xde,0x02,0xba,0x00,0xd1,0x02,0xbc,0x00,0xc3,0x02,0xbe,0x00,0xb6,0x02,0xc1,0x00,0xa9,0x02,0xc3,0x00,0x9b,0x02,0xc5,0x00,0x8e,0x02,0xc7,0x00,0x81,0x02,0xc9,0x00,0x74,0x02,0xcb,0x00,0x67,0x02,0xcd,0x00,0x5a,0x02,0xcf,0x00,0x4d,0x02,0xd1,0x00,0x40,0x02,0xd3,0x00,0x33,0x02,0xd5,0x00,0x26,0x02,0xd7,0x00,0x19,0x02,0xd8,0x00,0x0c,0x02,0xda,0x00,0xff,0x01,0xdc,0x00,0xf2,0x01,0xdd,0x00,  \
    0xe5,0x01,0xdf,0x00,0xd8,0x01,0xe1,0x00,0xcb,0x01,0xe2,0x00,0xbf,0x01,0xe4,0x00,0xb2,0x01,0xe5,0x00,0xa5,0x01,0xe7,0x00,0x98,0x01,0xe8,0x00,0x8b,0x01,0xe9,0x00,0x7f,0x01,0xeb,0x00,0x72,0x01,0xec,0x00,0x65,0x01,0xed,0x00,0x58,0x01,0xef,0x00,0x4c,0x01,0xf0,0x00,0x3f,0x01,0xf1,0x00,0x32,0x01,0xf2,0x00,0x26,0x01,0xf3,0x00,0x19,0x01,0xf4,0x00,0x0c,0x01,0xf5,0x00,0x00,0x01,0xf6,0x00,0xf3,0x00,0xf7,0x00,0xe6,0x00,0xf8,0x00,0xda,0x00,0xf9,0x00,0xcd,0x00,  \
    0xf9,0x00,0xc1,0x00,0xfa,0x00,0xb4,0x00,0xfb,0x00,0xa7,0x00,0xfc,0x00,0x9b,0x00,0xfc,0x00,0x8e,0x00,0xfd,0x00,0x82,0x00,0xfd,0x00,0x75,0x00,0xfe,0x00,0x69,0x00,0xfe,0x00,0x5c,0x00,0xff,0x00,0x50,0x00,0xff,0x00,0x43,0x00,0x00,0x01,0x36,0x00,0x00,0x01,0x2a,0x00,0x00,0x01,0x1d,0x00,0x00,0x01,0x11,0x00,0x01,0x01,0x04,0x00,0x01,0x01,0xf8,0xff,0x01,0x01,0xeb,0xff,0x01,0x01,0xdf,0xff,0x01,0x01,0xd2,0xff,0x01,0x01,0xc6,0xff,0x01,0x01,0xb9,0xff,0x01,0x01,  \
    0xad,0xff,0x01,0x01,0xa0,0xff,0x01,0x01,0x94,0xff,0x01,0x01,0x87,0xff,0x01,0x01,0x7b,0xff,0x00,0x01,0x6e,0xff,0x00,0x01,0x62,0xff,0x00,0x01,0x55,0xff,0x00,0x01,0x49,0xff,0xff,0x00,0x3c,0xff,0xff,0x00,0x2f,0xff,0xfe,0x00,0x23,0xff,0xfe,0x00,0x16,0xff,0xfd,0x00,0x09,0xff,0xfd,0x00,0xfd,0xfe,0xfc,0x00,0xf0,0xfe,0xfb,0x00,0xe3,0xfe,0xfb,0x00,0xd7,0xfe,0xfa,0x00,0xca,0xfe,0xf9,0x00,0xbd,0xfe,0xf9,0x00,0xb1,0xfe,0xf8,0x00,0xa4,0xfe,0xf7,0x00,0x97,0xfe,  \
    0xf6,0x00,0x8a,0xfe,0xf5,0x00,0x7d,0xfe,0xf4,0x00,0x71,0xfe,0xf3,0x00,0x64,0xfe,0xf2,0x00,0x57,0xfe,0xf1,0x00,0x4b,0xfe,0xf0,0x00,0x3e,0xfe,0xef,0x00,0x32,0xfe,0xed,0x00,0x26,0xfe,0xec,0x00,0x19,0xfe,0xeb,0x00,0x0d,0xfe,0xea,0x00,0x00,0xfe,0xe8,0x00,0xf4,0xfd,0xe7,0x00,0xe7,0xfd,0xe5,0x00,0xdb,0xfd,0xe4,0x00,0xce,0xfd,0xe2,0x00,0xc2,0xfd,0xe1,0x00,0xb5,0xfd,0xdf,0x00,0xa9,0xfd,0xdd,0x00,0x9c,0xfd,0xdc,0x00,0x90,0xfd,0xda,0x00,0x83,0xfd,0xd8,0x00,  \
    0x76,0xfd,0xd7,0x00,0x6a,0xfd,0xd5,0x00,0x5d,0xfd,0xd3,0x00,0x51,0xfd,0xd1,0x00,0x44,0xfd,0xcf,0x00,0x38,0xfd,0xcd,0x00,0x2b,0xfd,0xcb,0x00,0x1e,0xfd,0xc9,0x00,0x12,0xfd,0xc7,0x00,0x04,0xfd,0xc5,0x00,0xf7,0xfc,0xc3,0x00,0xea,0xfc,0xc1,0x00,0xdc,0xfc,0xbe,0x00,0xcf,0xfc,0xbc,0x00,0xc1,0xfc,0xba,0x00,0xb4,0xfc,0xb8,0x00,0xa6,0xfc,0xb5,0x00,0x99,0xfc,0xb3,0x00,0x8b,0xfc,0xb1,0x00,0x7d,0xfc,0xae,0x00,0x70,0xfc,0xac,0x00,0x62,0xfc,0xa9,0x00,0x54,0xfc,  \
    0xa7,0x00,0x46,0xfc,0xa4,0x00,0x38,0xfc,0xa2,0x00,0x2a,0xfc,0x9f,0x00,0x1c,0xfc,0x9c,0x00,0x0e,0xfc,0x9a,0x00,0x00,0xfc,0x97,0x00,0xf2,0xfb,0x94,0x00,0xe4,0xfb,0x92,0x00,0xd6,0xfb,0x8f,0x00,0xc8,0xfb,0x8c,0x00,0xb9,0xfb,0x89,0x00,0xab,0xfb,0x86,0x00,0x9d,0xfb,0x83,0x00,0x8f,0xfb,0x80,0x00,0x81,0xfb,0x7d,0x00,0x73,0xfb,0x7a,0x00,0x65,0xfb,0x77,0x00,0x56,0xfb,0x74,0x00,0x48,0xfb,0x71,0x00,0x3a,0xfb,0x6e,0x00,0x2b,0xfb,0x6a,0x00,0x1d,0xfb,0x67,0x00,  \
    0x0f,0xfb,0x64,0x00,0x00,0xfb,0x60,0x00,0xf2,0xfa,0x5d,0x00,0xe3,0xfa,0x5a,0x00,0xd5,0xfa,0x56,0x00,0xc6,0xfa,0x53,0x00,0xb7,0xfa,0x4f,0x00,0xa8,0xfa,0x4c,0x00,0x9a,0xfa,0x48,0x00,0x8b,0xfa,0x45,0x00,0x7c,0xfa,0x41,0x00,0x6d,0xfa,0x3e,0x00,0x5e,0xfa,0x3a,0x00,0x4f,0xfa,0x36,0x00,0x40,0xfa,0x32,0x00,0x31,0xfa,0x2f,0x00,0x22,0xfa,0x2b,0x00,0x13,0xfa,0x27,0x00,0x03,0xfa,0x23,0x00,0xf4,0xf9,0x1f,0x00,0xe5,0xf9,0x1b,0x00,0xd5,0xf9,0x18,0x00,0xc6,0xf9,  \
    0x14,0x00,0xb7,0xf9,0x10,0x00,0xa7,0xf9,0x0c,0x00,0x97,0xf9,0x08,0x00,0x88,0xf9,0x03,0x00,0x78,0xf9,0xff,0xff,0x68,0xf9,0xfb,0xff,0x58,0xf9,0xf7,0xff,0x48,0xf9,0xf3,0xff,0x39,0xf9,0xef,0xff,0x28,0xf9,0xeb,0xff,0x18,0xf9,0xe6,0xff,0x08,0xf9,0xe2,0xff,0xf8,0xf8,0xde,0xff,0xe8,0xf8,0xd9,0xff,0xd7,0xf8,0xd5,0xff,0xc7,0xf8,0xd1,0xff,0xb6,0xf8,0xcc,0xff,0xa6,0xf8,0xc8,0xff,0x95,0xf8,0xc4,0xff,0x84,0xf8,0xbf,0xff,0x74,0xf8,0xbb,0xff,0x63,0xf8,0xb6,0xff,  \
    0x52,0xf8,0xb2,0xff,0x41,0xf8,0xad,0xff,0x30,0xf8,0xa9,0xff,0x1f,0xf8,0xa4,0xff,0x0d,0xf8,0x9f,0xff,0xfc,0xf7,0x9b,0xff,0xeb,0xf7,0x96,0xff,0xd9,0xf7,0x92,0xff,0xc8,0xf7,0x8d,0xff,0xb6,0xf7,0x88,0xff,0xa4,0xf7,0x84,0xff,0x93,0xf7,0x7f,0xff,0x81,0xf7,0x7a,0xff,0x6f,0xf7,0x76,0xff,0x5d,0xf7,0x71,0xff,0x4b,0xf7,0x6c,0xff,0x38,0xf7,0x68,0xff,0x26,0xf7,0x63,0xff,0x14,0xf7,0x5e,0xff,0x01,0xf7,0x59,0xff,0xef,0xf6,0x54,0xff,0xdc,0xf6,0x50,0xff,0xc9,0xf6,  \
    0x4b,0xff,0xb7,0xf6,0x46,0xff,0xa4,0xf6,0x41,0xff,0x91,0xf6,0x3d,0xff,0x7e,0xf6,0x38,0xff,0x6a,0xf6,0x33,0xff,0x57,0xf6,0x2e,0xff,0x44,0xf6,0x29,0xff,0x30,0xf6,0x25,0xff,0x1d,0xf6,0x20,0xff,0x09,0xf6,0x1b,0xff,0xf5,0xf5,0x16,0xff,0xe1,0xf5,0x11,0xff,0xcd,0xf5,0x0d,0xff,0xb9,0xf5,0x08,0xff,0xa5,0xf5,0x03,0xff,0x90,0xf5,0xfe,0xfe,0x7c,0xf5,0xfa,0xfe,0x67,0xf5,0xf5,0xfe,0x52,0xf5,0xf0,0xfe,0x3d,0xf5,0xec,0xfe,0x28,0xf5,0xe7,0xfe,0x13,0xf5,0xe2,0xfe,  \
    0xfe,0xf4,0xde,0xfe,0xe9,0xf4,0xd9,0xfe,0xd4,0xf4,0xd4,0xfe,0xbe,0xf4,0xd0,0xfe,0xa9,0xf4,0xcb,0xfe,0x93,0xf4,0xc7,0xfe,0x7d,0xf4,0xc2,0xfe,0x67,0xf4,0xbd,0xfe,0x51,0xf4,0xb9,0xfe,0x3b,0xf4,0xb4,0xfe,0x25,0xf4,0xb0,0xfe,0x0f,0xf4,0xab,0xfe,0xf9,0xf3,0xa7,0xfe,0xe2,0xf3,0xa2,0xfe,0xcb,0xf3,0x9e,0xfe,0xb5,0xf3,0x99,0xfe,0x9e,0xf3,0x95,0xfe,0x87,0xf3,0x91,0xfe,0x70,0xf3,0x8c,0xfe,0x59,0xf3,0x88,0xfe,0x41,0xf3,0x84,0xfe,0x2a,0xf3,0x80,0xfe,0x12,0xf3,  \
    0x7b,0xfe,0xfb,0xf2,0x77,0xfe,0xe3,0xf2,0x73,0xfe,0xcb,0xf2,0x6f,0xfe,0xb3,0xf2,0x6b,0xfe,0x9a,0xf2,0x67,0xfe,0x82,0xf2,0x63,0xfe,0x69,0xf2,0x60,0xfe,0x51,0xf2,0x5c,0xfe,0x38,0xf2,0x58,0xfe,0x1f,0xf2,0x54,0xfe,0x06,0xf2,0x51,0xfe,0xed,0xf1,0x4d,0xfe,0xd3,0xf1,0x4a,0xfe,0xba,0xf1,0x46,0xfe,0xa0,0xf1,0x43,0xfe,0x87,0xf1,0x3f,0xfe,0x6d,0xf1,0x3c,0xfe,0x53,0xf1,0x39,0xfe,0x39,0xf1,0x35,0xfe,0x1e,0xf1,0x32,0xfe,0x04,0xf1,0x2f,0xfe,0xe9,0xf0,0x2c,0xfe,  \
    0xcf,0xf0,0x29,0xfe,0xb4,0xf0,0x26,0xfe,0x99,0xf0,0x23,0xfe,0x7e,0xf0,0x20,0xfe,0x63,0xf0,0x1e,0xfe,0x48,0xf0,0x1b,0xfe,0x2d,0xf0,0x18,0xfe,0x11,0xf0,0x16,0xfe,0xf6,0xef,0x13,0xfe,0xda,0xef,0x11,0xfe,0xbe,0xef,0x0f,0xfe,0xa2,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe1,0xfd,0x69,0x10,0xe3,0xfd,0x4d,0x10,0xe6,0xfd,0x30,0x10,0xe8,0xfd,0x14,0x10,0xeb,0xfd,0xf8,0x0f,0xed,0xfd,0xdd,0x0f,0xf0,0xfd,0xc1,0x0f,0xf3,0xfd,0xa5,0x0f,0xf5,0xfd,0x8a,0x0f,0xf8,0xfd,0x6f,0x0f,0xfb,0xfd,0x53,0x0f,0xfe,0xfd,0x38,0x0f,0x01,0xfe,0x1e,0x0f,0x05,0xfe,0x03,0x0f,0x08,0xfe,0xe8,0x0e,0x0b,0xfe,0xce,0x0e,0x0f,0xfe,0xb3,0x0e,0x12,0xfe,0x99,0x0e,0x15,0xfe,  \
    0x7f,0x0e,0x19,0xfe,0x65,0x0e,0x1c,0xfe,0x4b,0x0e,0x20,0xfe,0x31,0x0e,0x24,0xfe,0x17,0x0e,0x27,0xfe,0xfd,0x0d,0x2b,0xfe,0xe4,0x0d,0x2f,0xfe,0xcb,0x0d,0x33,0xfe,0xb1,0x0d,0x37,0xfe,0x98,0x0d,0x3b,0xfe,0x7f,0x0d,0x3e,0xfe,0x66,0x0d,0x42,0xfe,0x4d,0x0d,0x47,0xfe,0x35,0x0d,0x4b,0xfe,0x1c,0x0d,0x4f,0xfe,0x04,0x0d,0x53,0xfe,0xeb,0x0c,0x57,0xfe,0xd3,0x0c,0x5b,0xfe,0xbb,0x0c,0x60,0xfe,0xa3,0x0c,0x64,0xfe,0x8b,0x0c,0x68,0xfe,0x73,0x0c,0x6d,0xfe,0x5c,0x0c,  \
    0x72,0xfe,0x45,0x0c,0x76,0xfe,0x2f,0x0c,0x7b,0xfe,0x18,0x0c,0x80,0xfe,0x01,0x0c,0x85,0xfe,0xeb,0x0b,0x8a,0xfe,0xd5,0x0b,0x8f,0xfe,0xbf,0x0b,0x94,0xfe,0xa9,0x0b,0x99,0xfe,0x93,0x0b,0x9e,0xfe,0x7d,0x0b,0xa3,0xfe,0x68,0x0b,0xa8,0xfe,0x52,0x0b,0xad,0xfe,0x3d,0x0b,0xb2,0xfe,0x28,0x0b,0xb7,0xfe,0x13,0x0b,0xbc,0xfe,0xfe,0x0a,0xc1,0xfe,0xe9,0x0a,0xc6,0xfe,0xd3,0x0a,0xcb,0xfe,0xbe,0x0a,0xd0,0xfe,0xa8,0x0a,0xd5,0xfe,0x93,0x0a,0xda,0xfe,0x7e,0x0a,0xdf,0xfe,  \
    0x69,0x0a,0xe3,0xfe,0x54,0x0a,0xe8,0xfe,0x40,0x0a,0xed,0xfe,0x2b,0x0a,0xf2,0xfe,0x16,0x0a,0xf7,0xfe,0x02,0x0a,0xfc,0xfe,0xed,0x09,0x01,0xff,0xd9,0x09,0x06,0xff,0xc5,0x09,0x0b,0xff,0xb1,0x09,0x10,0xff,0x9d,0x09,0x14,0xff,0x89,0x09,0x19,0xff,0x75,0x09,0x1e,0xff,0x61,0x09,0x23,0xff,0x4e,0x09,0x28,0xff,0x3a,0x09,0x2d,0xff,0x27,0x09,0x32,0xff,0x14,0x09,0x37,0xff,0x00,0x09,0x3c,0xff,0xed,0x08,0x41,0xff,0xda,0x08,0x46,0xff,0xc7,0x08,0x4a,0xff,0xb4,0x08,  \
    0x4f,0xff,0xa1,0x08,0x54,0xff,0x8f,0x08,0x59,0xff,0x7c,0x08,0x5e,0xff,0x6a,0x08,0x63,0xff,0x57,0x08,0x68,0xff,0x45,0x08,0x6c,0xff,0x32,0x08,0x71,0xff,0x20,0x08,0x76,0xff,0x0e,0x08,0x7b,0xff,0xfd,0x07,0x80,0xff,0xeb,0x07,0x84,0xff,0xd9,0x07,0x89,0xff,0xc8,0x07,0x8e,0xff,0xb6,0x07,0x93,0xff,0xa5,0x07,0x98,0xff,0x93,0x07,0x9c,0xff,0x82,0x07,0xa1,0xff,0x71,0x07,0xa6,0xff,0x60,0x07,0xaa,0xff,0x4f,0x07,0xaf,0xff,0x3e,0x07,0xb4,0xff,0x2d,0x07,0xb8,0xff,  \
    0x1c,0x07,0xbd,0xff,0x0b,0x07,0xc1,0xff,0xfb,0x06,0xc6,0xff,0xea,0x06,0xcb,0xff,0xda,0x06,0xcf,0xff,0xc9,0x06,0xd4,0xff,0xb9,0x06,0xd8,0xff,0xa8,0x06,0xdc,0xff,0x98,0x06,0xe1,0xff,0x88,0x06,0xe5,0xff,0x77,0x06,0xe9,0xff,0x67,0x06,0xee,0xff,0x57,0x06,0xf2,0xff,0x47,0x06,0xf6,0xff,0x37,0x06,0xfb,0xff,0x27,0x06,0xff,0xff,0x17,0x06,0x03,0x00,0x08,0x06,0x07,0x00,0xf8,0x05,0x0b,0x00,0xe8,0x05,0x0f,0x00,0xd9,0x05,0x13,0x00,0xc9,0x05,0x17,0x00,0xba,0x05,  \
    0x1b,0x00,0xaa,0x05,0x1f,0x00,0x9b,0x05,0x23,0x00,0x8b,0x05,0x27,0x00,0x7c,0x05,0x2b,0x00,0x6d,0x05,0x2f,0x00,0x5e,0x05,0x33,0x00,0x4e,0x05,0x36,0x00,0x3f,0x05,0x3a,0x00,0x2f,0x05,0x3e,0x00,0x20,0x05,0x41,0x00,0x11,0x05,0x45,0x00,0x01,0x05,0x48,0x00,0xf2,0x04,0x4c,0x00,0xe3,0x04,0x4f,0x00,0xd4,0x04,0x53,0x00,0xc5,0x04,0x56,0x00,0xb6,0x04,0x5a,0x00,0xa7,0x04,0x5d,0x00,0x98,0x04,0x61,0x00,0x89,0x04,0x64,0x00,0x7a,0x04,0x67,0x00,0x6b,0x04,0x6a,0x00,  \
    0x5c,0x04,0x6e,0x00,0x4e,0x04,0x71,0x00,0x3f,0x04,0x74,0x00,0x30,0x04,0x77,0x00,0x22,0x04,0x7a,0x00,0x13,0x04,0x7d,0x00,0x05,0x04,0x80,0x00,0xf7,0x03,0x83,0x00,0xe8,0x03,0x86,0x00,0xda,0x03,0x89,0x00,0xcc,0x03,0x8c,0x00,0xbe,0x03,0x8f,0x00,0xb0,0x03,0x92,0x00,0xa2,0x03,0x95,0x00,0x94,0x03,0x98,0x00,0x86,0x03,0x9b,0x00,0x78,0x03,0x9d,0x00,0x6b,0x03,0xa0,0x00,0x5d,0x03,0xa3,0x00,0x4f,0x03,0xa5,0x00,0x41,0x03,0xa8,0x00,0x34,0x03,0xaa,0x00,0x26,0x03,  \
    0xad,0x00,0x18,0x03,0xb0,0x00,0x0b,0x03,0xb2,0x00,0xfd,0x02,0xb4,0x00,0xf0,0x02,0xb7,0x00,0xe2,0x02,0xb9,0x00,0xd5,0x02,0xbb,0x00,0xc7,0x02,0xbe,0x00,0xba,0x02,0xc0,0x00,0xad,0x02,0xc2,0x00,0x9f,0x02,0xc4,0x00,0x92,0x02,0xc6,0x00,0x85,0x02,0xc9,0x00,0x78,0x02,0xcb,0x00,0x6a,0x02,0xcd,0x00,0x5d,0x02,0xcf,0x00,0x50,0x02,0xd1,0x00,0x43,0x02,0xd3,0x00,0x36,0x02,0xd4,0x00,0x29,0x02,0xd6,0x00,0x1c,0x02,0xd8,0x00,0x0f,0x02,0xda,0x00,0x02,0x02,0xdc,0x00,  \
    0xf5,0x01,0xdd,0x00,0xe8,0x01,0xdf,0x00,0xdb,0x01,0xe0,0x00,0xce,0x01,0xe2,0x00,0xc1,0x01,0xe4,0x00,0xb4,0x01,0xe5,0x00,0xa8,0x01,0xe7,0x00,0x9b,0x01,0xe8,0x00,0x8e,0x01,0xe9,0x00,0x81,0x01,0xeb,0x00,0x74,0x01,0xec,0x00,0x68,0x01,0xed,0x00,0x5b,0x01,0xee,0x00,0x4e,0x01,0xf0,0x00,0x41,0x01,0xf1,0x00,0x35,0x01,0xf2,0x00,0x28,0x01,0xf3,0x00,0x1b,0x01,0xf4,0x00,0x0e,0x01,0xf5,0x00,0x02,0x01,0xf6,0x00,0xf5,0x00,0xf7,0x00,0xe8,0x00,0xf8,0x00,0xdb,0x00,  \
    0xf9,0x00,0xcf,0x00,0xf9,0x00,0xc2,0x00,0xfa,0x00,0xb5,0x00,0xfb,0x00,0xa9,0x00,0xfc,0x00,0x9c,0x00,0xfc,0x00,0x8f,0x00,0xfd,0x00,0x83,0x00,0xfd,0x00,0x76,0x00,0xfe,0x00,0x6a,0x00,0xfe,0x00,0x5d,0x00,0xff,0x00,0x50,0x00,0xff,0x00,0x44,0x00,0x00,0x01,0x37,0x00,0x00,0x01,0x2b,0x00,0x00,0x01,0x1e,0x00,0x01,0x01,0x11,0x00,0x01,0x01,0x05,0x00,0x01,0x01,0xf8,0xff,0x01,0x01,0xec,0xff,0x01,0x01,0xdf,0xff,0x01,0x01,0xd3,0xff,0x01,0x01,0xc6,0xff,0x01,0x01,  \
    0xb9,0xff,0x01,0x01,0xad,0xff,0x01,0x01,0xa0,0xff,0x01,0x01,0x94,0xff,0x01,0x01,0x87,0xff,0x01,0x01,0x7a,0xff,0x01,0x01,0x6e,0xff,0x00,0x01,0x61,0xff,0x00,0x01,0x54,0xff,0x00,0x01,0x48,0xff,0xff,0x00,0x3b,0xff,0xff,0x00,0x2e,0xff,0xfe,0x00,0x22,0xff,0xfe,0x00,0x15,0xff,0xfd,0x00,0x08,0xff,0xfd,0x00,0xfc,0xfe,0xfc,0x00,0xef,0xfe,0xfc,0x00,0xe2,0xfe,0xfb,0x00,0xd5,0xfe,0xfa,0x00,0xc9,0xfe,0xf9,0x00,0xbc,0xfe,0xf9,0x00,0xaf,0xfe,0xf8,0x00,0xa2,0xfe,  \
    0xf7,0x00,0x95,0xfe,0xf6,0x00,0x88,0xfe,0xf5,0x00,0x7b,0xfe,0xf4,0x00,0x6e,0xfe,0xf3,0x00,0x62,0xfe,0xf2,0x00,0x55,0xfe,0xf1,0x00,0x49,0xfe,0xf0,0x00,0x3c,0xfe,0xef,0x00,0x30,0xfe,0xed,0x00,0x23,0xfe,0xec,0x00,0x17,0xfe,0xeb,0x00,0x0a,0xfe,0xea,0x00,0xfd,0xfd,0xe8,0x00,0xf1,0xfd,0xe7,0x00,0xe4,0xfd,0xe5,0x00,0xd8,0xfd,0xe4,0x00,0xcb,0xfd,0xe2,0x00,0xbf,0xfd,0xe1,0x00,0xb2,0xfd,0xdf,0x00,0xa6,0xfd,0xdd,0x00,0x99,0xfd,0xdc,0x00,0x8c,0xfd,0xda,0x00,  \
    0x80,0xfd,0xd8,0x00,0x73,0xfd,0xd6,0x00,0x67,0xfd,0xd4,0x00,0x5a,0xfd,0xd3,0x00,0x4d,0xfd,0xd1,0x00,0x41,0xfd,0xcf,0x00,0x34,0xfd,0xcd,0x00,0x28,0xfd,0xcb,0x00,0x1b,0xfd,0xc9,0x00,0x0e,0xfd,0xc6,0x00,0x01,0xfd,0xc4,0x00,0xf3,0xfc,0xc2,0x00,0xe6,0xfc,0xc0,0x00,0xd8,0xfc,0xbe,0x00,0xcb,0xfc,0xbc,0x00,0xbd,0xfc,0xb9,0x00,0xb0,0xfc,0xb7,0x00,0xa2,0xfc,0xb5,0x00,0x94,0xfc,0xb2,0x00,0x87,0xfc,0xb0,0x00,0x79,0xfc,0xae,0x00,0x6b,0xfc,0xab,0x00,0x5d,0xfc,  \
    0xa9,0x00,0x4f,0xfc,0xa6,0x00,0x42,0xfc,0xa4,0x00,0x34,0xfc,0xa1,0x00,0x26,0xfc,0x9e,0x00,0x18,0xfc,0x9c,0x00,0x0a,0xfc,0x99,0x00,0xfb,0xfb,0x96,0x00,0xed,0xfb,0x94,0x00,0xdf,0xfb,0x91,0x00,0xd1,0xfb,0x8e,0x00,0xc3,0xfb,0x8b,0x00,0xb4,0xfb,0x88,0x00,0xa6,0xfb,0x85,0x00,0x98,0xfb,0x82,0x00,0x8a,0xfb,0x7f,0x00,0x7b,0xfb,0x7c,0x00,0x6d,0xfb,0x79,0x00,0x5f,0xfb,0x76,0x00,0x51,0xfb,0x73,0x00,0x43,0xfb,0x70,0x00,0x34,0xfb,0x6c,0x00,0x26,0xfb,0x69,0x00,  \
    0x17,0xfb,0x66,0x00,0x09,0xfb,0x62,0x00,0xfa,0xfa,0x5f,0x00,0xec,0xfa,0x5c,0x00,0xdd,0xfa,0x58,0x00,0xcf,0xfa,0x55,0x00,0xc0,0xfa,0x51,0x00,0xb1,0xfa,0x4e,0x00,0xa2,0xfa,0x4a,0x00,0x94,0xfa,0x47,0x00,0x85,0xfa,0x43,0x00,0x76,0xfa,0x3f,0x00,0x67,0xfa,0x3c,0x00,0x58,0xfa,0x38,0x00,0x49,0xfa,0x34,0x00,0x3a,0xfa,0x31,0x00,0x2b,0xfa,0x2d,0x00,0x1b,0xfa,0x29,0x00,0x0c,0xfa,0x25,0x00,0xfd,0xf9,0x21,0x00,0xee,0xf9,0x1d,0x00,0xde,0xf9,0x19,0x00,0xcf,0xf9,  \
    0x15,0x00,0xc0,0xf9,0x11,0x00,0xb0,0xf9,0x0d,0x00,0xa1,0xf9,0x09,0x00,0x91,0xf9,0x05,0x00,0x81,0xf9,0x01,0x00,0x71,0xf9,0xfd,0xff,0x62,0xf9,0xf9,0xff,0x52,0xf9,0xf5,0xff,0x42,0xf9,0xf0,0xff,0x32,0xf9,0xec,0xff,0x22,0xf9,0xe8,0xff,0x12,0xf9,0xe4,0xff,0x02,0xf9,0xdf,0xff,0xf1,0xf8,0xdb,0xff,0xe1,0xf8,0xd7,0xff,0xd1,0xf8,0xd2,0xff,0xc0,0xf8,0xce,0xff,0xb0,0xf8,0xc9,0xff,0x9f,0xf8,0xc5,0xff,0x8f,0xf8,0xc0,0xff,0x7e,0xf8,0xbc,0xff,0x6d,0xf8,0xb7,0xff,  \
    0x5c,0xf8,0xb3,0xff,0x4b,0xf8,0xae,0xff,0x3a,0xf8,0xaa,0xff,0x29,0xf8,0xa5,0xff,0x18,0xf8,0xa1,0xff,0x07,0xf8,0x9c,0xff,0xf5,0xf7,0x97,0xff,0xe4,0xf7,0x93,0xff,0xd3,0xf7,0x8e,0xff,0xc1,0xf7,0x89,0xff,0xaf,0xf7,0x85,0xff,0x9e,0xf7,0x80,0xff,0x8c,0xf7,0x7b,0xff,0x7a,0xf7,0x76,0xff,0x68,0xf7,0x72,0xff,0x56,0xf7,0x6d,0xff,0x44,0xf7,0x68,0xff,0x32,0xf7,0x63,0xff,0x20,0xf7,0x5e,0xff,0x0d,0xf7,0x5a,0xff,0xfb,0xf6,0x55,0xff,0xe8,0xf6,0x50,0xff,0xd6,0xf6,  \
    0x4b,0xff,0xc3,0xf6,0x46,0xff,0xb0,0xf6,0x41,0xff,0x9d,0xf6,0x3d,0xff,0x8a,0xf6,0x38,0xff,0x77,0xf6,0x33,0xff,0x64,0xf6,0x2e,0xff,0x51,0xf6,0x29,0xff,0x3d,0xf6,0x24,0xff,0x2a,0xf6,0x1f,0xff,0x16,0xf6,0x1a,0xff,0x03,0xf6,0x16,0xff,0xef,0xf5,0x11,0xff,0xdb,0xf5,0x0c,0xff,0xc7,0xf5,0x07,0xff,0xb2,0xf5,0x02,0xff,0x9e,0xf5,0xfe,0xfe,0x8a,0xf5,0xf9,0xfe,0x75,0xf5,0xf4,0xfe,0x61,0xf5,0xef,0xfe,0x4c,0xf5,0xea,0xfe,0x37,0xf5,0xe6,0xfe,0x22,0xf5,0xe1,0xfe,  \
    0x0d,0xf5,0xdc,0xfe,0xf8,0xf4,0xd8,0xfe,0xe3,0xf4,0xd3,0xfe,0xcd,0xf4,0xce,0xfe,0xb8,0xf4,0xc9,0xfe,0xa2,0xf4,0xc5,0xfe,0x8d,0xf4,0xc0,0xfe,0x77,0xf4,0xbb,0xfe,0x61,0xf4,0xb7,0xfe,0x4b,0xf4,0xb2,0xfe,0x35,0xf4,0xae,0xfe,0x1f,0xf4,0xa9,0xfe,0x09,0xf4,0xa4,0xfe,0xf3,0xf3,0xa0,0xfe,0xdc,0xf3,0x9b,0xfe,0xc5,0xf3,0x97,0xfe,0xaf,0xf3,0x92,0xfe,0x98,0xf3,0x8e,0xfe,0x81,0xf3,0x8a,0xfe,0x6a,0xf3,0x85,0xfe,0x53,0xf3,0x81,0xfe,0x3b,0xf3,0x7c,0xfe,0x24,0xf3,  \
    0x78,0xfe,0x0c,0xf3,0x74,0xfe,0xf5,0xf2,0x70,0xfe,0xdd,0xf2,0x6c,0xfe,0xc5,0xf2,0x68,0xfe,0xad,0xf2,0x64,0xfe,0x95,0xf2,0x60,0xfe,0x7c,0xf2,0x5c,0xfe,0x64,0xf2,0x58,0xfe,0x4b,0xf2,0x54,0xfe,0x32,0xf2,0x50,0xfe,0x19,0xf2,0x4c,0xfe,0x00,0xf2,0x49,0xfe,0xe7,0xf1,0x45,0xfe,0xce,0xf1,0x41,0xfe,0xb4,0xf1,0x3e,0xfe,0x9b,0xf1,0x3a,0xfe,0x81,0xf1,0x37,0xfe,0x67,0xf1,0x34,0xfe,0x4d,0xf1,0x30,0xfe,0x33,0xf1,0x2d,0xfe,0x19,0xf1,0x2a,0xfe,0xff,0xf0,0x27,0xfe,  \
    0xe4,0xf0,0x24,0xfe,0xca,0xf0,0x21,0xfe,0xaf,0xf0,0x1e,0xfe,0x94,0xf0,0x1b,0xfe,0x79,0xf0,0x18,0xfe,0x5e,0xf0,0x15,0xfe,0x43,0xf0,0x12,0xfe,0x28,0xf0,0x0f,0xfe,0x0c,0xf0,0x0d,0xfe,0xf1,0xef,0x0a,0xfe,0xd5,0xef,0x08,0xfe,0xb9,0xef,0x06,0xfe,0x9d,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xd4,0xfd,0x6d,0x10,0xd7,0xfd,0x51,0x10,0xd9,0xfd,0x35,0x10,0xdb,0xfd,0x19,0x10,0xde,0xfd,0xfd,0x0f,0xe1,0xfd,0xe1,0x0f,0xe4,0xfd,0xc5,0x0f,0xe6,0xfd,0xaa,0x0f,0xe9,0xfd,0x8e,0x0f,0xec,0xfd,0x73,0x0f,0xef,0xfd,0x58,0x0f,0xf2,0xfd,0x3d,0x0f,0xf5,0xfd,0x22,0x0f,0xf9,0xfd,0x07,0x0f,0xfc,0xfd,0xec,0x0e,0xff,0xfd,0xd2,0x0e,0x03,0xfe,0xb8,0x0e,0x06,0xfe,  \
    0x9d,0x0e,0x0a,0xfe,0x83,0x0e,0x0d,0xfe,0x69,0x0e,0x11,0xfe,0x4f,0x0e,0x15,0xfe,0x35,0x0e,0x18,0xfe,0x1c,0x0e,0x1c,0xfe,0x02,0x0e,0x20,0xfe,0xe9,0x0d,0x24,0xfe,0xcf,0x0d,0x28,0xfe,0xb6,0x0d,0x2c,0xfe,0x9d,0x0d,0x30,0xfe,0x84,0x0d,0x34,0xfe,0x6b,0x0d,0x38,0xfe,0x52,0x0d,0x3c,0xfe,0x39,0x0d,0x40,0xfe,0x21,0x0d,0x44,0xfe,0x08,0x0d,0x48,0xfe,0xf0,0x0c,0x4d,0xfe,0xd8,0x0c,0x51,0xfe,0xc0,0x0c,0x55,0xfe,0xa8,0x0c,0x5a,0xfe,0x90,0x0c,0x5e,0xfe,0x78,0x0c,  \
    0x63,0xfe,0x61,0x0c,0x68,0xfe,0x4a,0x0c,0x6d,0xfe,0x34,0x0c,0x72,0xfe,0x1d,0x0c,0x76,0xfe,0x07,0x0c,0x7b,0xfe,0xf0,0x0b,0x80,0xfe,0xda,0x0b,0x86,0xfe,0xc4,0x0b,0x8b,0xfe,0xae,0x0b,0x90,0xfe,0x98,0x0b,0x95,0xfe,0x83,0x0b,0x9a,0xfe,0x6d,0x0b,0x9f,0xfe,0x58,0x0b,0xa4,0xfe,0x42,0x0b,0xa9,0xfe,0x2d,0x0b,0xaf,0xfe,0x18,0x0b,0xb4,0xfe,0x03,0x0b,0xb9,0xfe,0xee,0x0a,0xbe,0xfe,0xd9,0x0a,0xc3,0xfe,0xc4,0x0a,0xc8,0xfe,0xae,0x0a,0xcd,0xfe,0x99,0x0a,0xd2,0xfe,  \
    0x84,0x0a,0xd7,0xfe,0x6f,0x0a,0xdc,0xfe,0x5a,0x0a,0xe1,0xfe,0x46,0x0a,0xe6,0xfe,0x31,0x0a,0xeb,0xfe,0x1c,0x0a,0xf0,0xfe,0x08,0x0a,0xf5,0xfe,0xf3,0x09,0xfa,0xfe,0xdf,0x09,0xff,0xfe,0xcb,0x09,0x04,0xff,0xb7,0x09,0x09,0xff,0xa3,0x09,0x0e,0xff,0x8f,0x09,0x13,0xff,0x7b,0x09,0x18,0xff,0x68,0x09,0x1d,0xff,0x54,0x09,0x22,0xff,0x41,0x09,0x27,0xff,0x2d,0x09,0x2c,0xff,0x1a,0x09,0x31,0xff,0x07,0x09,0x36,0xff,0xf3,0x08,0x3b,0xff,0xe0,0x08,0x40,0xff,0xcd,0x08,  \
    0x45,0xff,0xbb,0x08,0x49,0xff,0xa8,0x08,0x4e,0xff,0x95,0x08,0x53,0xff,0x82,0x08,0x58,0xff,0x70,0x08,0x5d,0xff,0x5d,0x08,0x62,0xff,0x4b,0x08,0x67,0xff,0x39,0x08,0x6c,0xff,0x26,0x08,0x71,0xff,0x15,0x08,0x76,0xff,0x03,0x08,0x7b,0xff,0xf1,0x07,0x7f,0xff,0xe0,0x07,0x84,0xff,0xce,0x07,0x89,0xff,0xbc,0x07,0x8e,0xff,0xab,0x07,0x93,0xff,0x9a,0x07,0x98,0xff,0x89,0x07,0x9c,0xff,0x77,0x07,0xa1,0xff,0x66,0x07,0xa6,0xff,0x55,0x07,0xab,0xff,0x44,0x07,0xaf,0xff,  \
    0x33,0x07,0xb4,0xff,0x23,0x07,0xb9,0xff,0x12,0x07,0xbd,0xff,0x01,0x07,0xc2,0xff,0xf1,0x06,0xc7,0xff,0xe0,0x06,0xcb,0xff,0xd0,0x06,0xd0,0xff,0xbf,0x06,0xd4,0xff,0xaf,0x06,0xd9,0xff,0x9e,0x06,0xdd,0xff,0x8e,0x06,0xe2,0xff,0x7e,0x06,0xe6,0xff,0x6e,0x06,0xea,0xff,0x5e,0x06,0xef,0xff,0x4e,0x06,0xf3,0xff,0x3e,0x06,0xf7,0xff,0x2e,0x06,0xfc,0xff,0x1e,0x06,0x00,0x00,0x0e,0x06,0x04,0x00,0xfe,0x05,0x08,0x00,0xef,0x05,0x0c,0x00,0xdf,0x05,0x10,0x00,0xcf,0x05,  \
    0x14,0x00,0xc0,0x05,0x19,0x00,0xb1,0x05,0x1d,0x00,0xa1,0x05,0x21,0x00,0x92,0x05,0x25,0x00,0x82,0x05,0x28,0x00,0x73,0x05,0x2c,0x00,0x64,0x05,0x30,0x00,0x54,0x05,0x34,0x00,0x45,0x05,0x38,0x00,0x35,0x05,0x3b,0x00,0x26,0x05,0x3f,0x00,0x17,0x05,0x43,0x00,0x07,0x05,0x46,0x00,0xf8,0x04,0x4a,0x00,0xe9,0x04,0x4d,0x00,0xda,0x04,0x51,0x00,0xca,0x04,0x54,0x00,0xbb,0x04,0x58,0x00,0xac,0x04,0x5b,0x00,0x9d,0x04,0x5f,0x00,0x8e,0x04,0x62,0x00,0x80,0x04,0x65,0x00,  \
    0x71,0x04,0x69,0x00,0x62,0x04,0x6c,0x00,0x53,0x04,0x6f,0x00,0x45,0x04,0x72,0x00,0x36,0x04,0x76,0x00,0x27,0x04,0x79,0x00,0x19,0x04,0x7c,0x00,0x0a,0x04,0x7f,0x00,0xfc,0x03,0x82,0x00,0xed,0x03,0x85,0x00,0xdf,0x03,0x88,0x00,0xd1,0x03,0x8b,0x00,0xc3,0x03,0x8e,0x00,0xb5,0x03,0x91,0x00,0xa7,0x03,0x94,0x00,0x99,0x03,0x97,0x00,0x8b,0x03,0x99,0x00,0x7d,0x03,0x9c,0x00,0x6f,0x03,0x9f,0x00,0x62,0x03,0xa2,0x00,0x54,0x03,0xa4,0x00,0x46,0x03,0xa7,0x00,0x38,0x03,  \
    0xa9,0x00,0x2b,0x03,0xac,0x00,0x1d,0x03,0xaf,0x00,0x0f,0x03,0xb1,0x00,0x02,0x03,0xb3,0x00,0xf4,0x02,0xb6,0x00,0xe6,0x02,0xb8,0x00,0xd9,0x02,0xbb,0x00,0xcb,0x02,0xbd,0x00,0xbe,0x02,0xbf,0x00,0xb0,0x02,0xc1,0x00,0xa3,0x02,0xc4,0x00,0x96,0x02,0xc6,0x00,0x88,0x02,0xc8,0x00,0x7b,0x02,0xca,0x00,0x6e,0x02,0xcc,0x00,0x61,0x02,0xce,0x00,0x54,0x02,0xd0,0x00,0x47,0x02,0xd2,0x00,0x39,0x02,0xd4,0x00,0x2c,0x02,0xd6,0x00,0x1f,0x02,0xd8,0x00,0x12,0x02,0xd9,0x00,  \
    0x05,0x02,0xdb,0x00,0xf8,0x01,0xdd,0x00,0xeb,0x01,0xde,0x00,0xde,0x01,0xe0,0x00,0xd1,0x01,0xe2,0x00,0xc4,0x01,0xe3,0x00,0xb7,0x01,0xe5,0x00,0xaa,0x01,0xe6,0x00,0x9d,0x01,0xe8,0x00,0x91,0x01,0xe9,0x00,0x84,0x01,0xea,0x00,0x77,0x01,0xec,0x00,0x6a,0x01,0xed,0x00,0x5d,0x01,0xee,0x00,0x50,0x01,0xef,0x00,0x43,0x01,0xf1,0x00,0x37,0x01,0xf2,0x00,0x2a,0x01,0xf3,0x00,0x1d,0x01,0xf4,0x00,0x10,0x01,0xf5,0x00,0x03,0x01,0xf6,0x00,0xf7,0x00,0xf7,0x00,0xea,0x00,  \
    0xf8,0x00,0xdd,0x00,0xf9,0x00,0xd0,0x00,0xf9,0x00,0xc4,0x00,0xfa,0x00,0xb7,0x00,0xfb,0x00,0xaa,0x00,0xfc,0x00,0x9d,0x00,0xfc,0x00,0x91,0x00,0xfd,0x00,0x84,0x00,0xfd,0x00,0x77,0x00,0xfe,0x00,0x6b,0x00,0xfe,0x00,0x5e,0x00,0xff,0x00,0x51,0x00,0xff,0x00,0x45,0x00,0x00,0x01,0x38,0x00,0x00,0x01,0x2b,0x00,0x00,0x01,0x1f,0x00,0x01,0x01,0x12,0x00,0x01,0x01,0x05,0x00,0x01,0x01,0xf9,0xff,0x01,0x01,0xec,0xff,0x01,0x01,0xdf,0xff,0x01,0x01,0xd3,0xff,0x01,0x01,  \
    0xc6,0xff,0x01,0x01,0xb9,0xff,0x01,0x01,0xad,0xff,0x01,0x01,0xa0,0xff,0x01,0x01,0x93,0xff,0x01,0x01,0x87,0xff,0x01,0x01,0x7a,0xff,0x01,0x01,0x6d,0xff,0x00,0x01,0x61,0xff,0x00,0x01,0x54,0xff,0x00,0x01,0x47,0xff,0xff,0x00,0x3a,0xff,0xff,0x00,0x2e,0xff,0xfe,0x00,0x21,0xff,0xfe,0x00,0x14,0xff,0xfd,0x00,0x07,0xff,0xfd,0x00,0xfa,0xfe,0xfc,0x00,0xee,0xfe,0xfc,0x00,0xe1,0xfe,0xfb,0x00,0xd4,0xfe,0xfa,0x00,0xc7,0xfe,0xf9,0x00,0xba,0xfe,0xf9,0x00,0xad,0xfe,  \
    0xf8,0x00,0xa0,0xfe,0xf7,0x00,0x93,0xfe,0xf6,0x00,0x86,0xfe,0xf5,0x00,0x79,0xfe,0xf4,0x00,0x6c,0xfe,0xf3,0x00,0x60,0xfe,0xf2,0x00,0x53,0xfe,0xf1,0x00,0x46,0xfe,0xf0,0x00,0x3a,0xfe,0xee,0x00,0x2d,0xfe,0xed,0x00,0x21,0xfe,0xec,0x00,0x14,0xfe,0xeb,0x00,0x07,0xfe,0xe9,0x00,0xfb,0xfd,0xe8,0x00,0xee,0xfd,0xe6,0x00,0xe2,0xfd,0xe5,0x00,0xd5,0xfd,0xe3,0x00,0xc8,0xfd,0xe2,0x00,0xbc,0xfd,0xe0,0x00,0xaf,0xfd,0xdf,0x00,0xa3,0xfd,0xdd,0x00,0x96,0xfd,0xdb,0x00,  \
    0x89,0xfd,0xda,0x00,0x7d,0xfd,0xd8,0x00,0x70,0xfd,0xd6,0x00,0x63,0xfd,0xd4,0x00,0x57,0xfd,0xd2,0x00,0x4a,0xfd,0xd0,0x00,0x3d,0xfd,0xce,0x00,0x31,0xfd,0xcc,0x00,0x24,0xfd,0xca,0x00,0x17,0xfd,0xc8,0x00,0x0b,0xfd,0xc6,0x00,0xfd,0xfc,0xc4,0x00,0xf0,0xfc,0xc2,0x00,0xe2,0xfc,0xbf,0x00,0xd4,0xfc,0xbd,0x00,0xc7,0xfc,0xbb,0x00,0xb9,0xfc,0xb9,0x00,0xac,0xfc,0xb6,0x00,0x9e,0xfc,0xb4,0x00,0x90,0xfc,0xb2,0x00,0x82,0xfc,0xaf,0x00,0x75,0xfc,0xad,0x00,0x67,0xfc,  \
    0xaa,0x00,0x59,0xfc,0xa8,0x00,0x4b,0xfc,0xa5,0x00,0x3d,0xfc,0xa3,0x00,0x2f,0xfc,0xa0,0x00,0x21,0xfc,0x9d,0x00,0x13,0xfc,0x9b,0x00,0x05,0xfc,0x98,0x00,0xf6,0xfb,0x95,0x00,0xe8,0xfb,0x93,0x00,0xda,0xfb,0x90,0x00,0xcc,0xfb,0x8d,0x00,0xbd,0xfb,0x8a,0x00,0xaf,0xfb,0x87,0x00,0xa1,0xfb,0x84,0x00,0x92,0xfb,0x81,0x00,0x84,0xfb,0x7e,0x00,0x76,0xfb,0x7b,0x00,0x68,0xfb,0x78,0x00,0x59,0xfb,0x75,0x00,0x4b,0xfb,0x71,0x00,0x3d,0xfb,0x6e,0x00,0x2e,0xfb,0x6b,0x00,  \
    0x20,0xfb,0x68,0x00,0x12,0xfb,0x64,0x00,0x03,0xfb,0x61,0x00,0xf5,0xfa,0x5e,0x00,0xe6,0xfa,0x5a,0x00,0xd7,0xfa,0x57,0x00,0xc9,0xfa,0x53,0x00,0xba,0xfa,0x50,0x00,0xab,0xfa,0x4c,0x00,0x9c,0xfa,0x49,0x00,0x8d,0xfa,0x45,0x00,0x7f,0xfa,0x41,0x00,0x70,0xfa,0x3e,0x00,0x61,0xfa,0x3a,0x00,0x52,0xfa,0x36,0x00,0x42,0xfa,0x32,0x00,0x33,0xfa,0x2f,0x00,0x24,0xfa,0x2b,0x00,0x15,0xfa,0x27,0x00,0x06,0xfa,0x23,0x00,0xf7,0xf9,0x1f,0x00,0xe7,0xf9,0x1b,0x00,0xd8,0xf9,  \
    0x17,0x00,0xc9,0xf9,0x13,0x00,0xb9,0xf9,0x0f,0x00,0xaa,0xf9,0x0b,0x00,0x9a,0xf9,0x07,0x00,0x8a,0xf9,0x03,0x00,0x7b,0xf9,0xff,0xff,0x6b,0xf9,0xfa,0xff,0x5b,0xf9,0xf6,0xff,0x4b,0xf9,0xf2,0xff,0x3b,0xf9,0xee,0xff,0x2b,0xf9,0xe9,0xff,0x1b,0xf9,0xe5,0xff,0x0b,0xf9,0xe1,0xff,0xfb,0xf8,0xdc,0xff,0xeb,0xf8,0xd8,0xff,0xda,0xf8,0xd4,0xff,0xca,0xf8,0xcf,0xff,0xb9,0xf8,0xcb,0xff,0xa9,0xf8,0xc6,0xff,0x98,0xf8,0xc2,0xff,0x88,0xf8,0xbd,0xff,0x77,0xf8,0xb9,0xff,  \
    0x66,0xf8,0xb4,0xff,0x55,0xf8,0xb0,0xff,0x44,0xf8,0xab,0xff,0x33,0xf8,0xa6,0xff,0x22,0xf8,0xa2,0xff,0x11,0xf8,0x9d,0xff,0x00,0xf8,0x98,0xff,0xef,0xf7,0x94,0xff,0xdd,0xf7,0x8f,0xff,0xcc,0xf7,0x8a,0xff,0xba,0xf7,0x85,0xff,0xa9,0xf7,0x81,0xff,0x97,0xf7,0x7c,0xff,0x85,0xf7,0x77,0xff,0x73,0xf7,0x72,0xff,0x61,0xf7,0x6d,0xff,0x4f,0xf7,0x69,0xff,0x3d,0xf7,0x64,0xff,0x2b,0xf7,0x5f,0xff,0x19,0xf7,0x5a,0xff,0x06,0xf7,0x55,0xff,0xf4,0xf6,0x50,0xff,0xe2,0xf6,  \
    0x4b,0xff,0xcf,0xf6,0x47,0xff,0xbc,0xf6,0x42,0xff,0xa9,0xf6,0x3d,0xff,0x97,0xf6,0x38,0xff,0x84,0xf6,0x33,0xff,0x70,0xf6,0x2e,0xff,0x5d,0xf6,0x29,0xff,0x4a,0xf6,0x24,0xff,0x37,0xf6,0x1f,0xff,0x23,0xf6,0x1a,0xff,0x10,0xf6,0x15,0xff,0xfc,0xf5,0x10,0xff,0xe8,0xf5,0x0b,0xff,0xd4,0xf5,0x07,0xff,0xc0,0xf5,0x02,0xff,0xac,0xf5,0xfd,0xfe,0x98,0xf5,0xf8,0xfe,0x83,0xf5,0xf3,0xfe,0x6f,0xf5,0xee,0xfe,0x5a,0xf5,0xe9,0xfe,0x45,0xf5,0xe5,0xfe,0x31,0xf5,0xe0,0xfe,  \
    0x1c,0xf5,0xdb,0xfe,0x07,0xf5,0xd6,0xfe,0xf2,0xf4,0xd1,0xfe,0xdc,0xf4,0xcd,0xfe,0xc7,0xf4,0xc8,0xfe,0xb2,0xf4,0xc3,0xfe,0x9c,0xf4,0xbe,0xfe,0x86,0xf4,0xba,0xfe,0x71,0xf4,0xb5,0xfe,0x5b,0xf4,0xb0,0xfe,0x45,0xf4,0xac,0xfe,0x2f,0xf4,0xa7,0xfe,0x19,0xf4,0xa2,0xfe,0x03,0xf4,0x9e,0xfe,0xec,0xf3,0x99,0xfe,0xd6,0xf3,0x94,0xfe,0xbf,0xf3,0x90,0xfe,0xa9,0xf3,0x8b,0xfe,0x92,0xf3,0x87,0xfe,0x7b,0xf3,0x82,0xfe,0x64,0xf3,0x7e,0xfe,0x4d,0xf3,0x7a,0xfe,0x36,0xf3,  \
    0x75,0xfe,0x1e,0xf3,0x71,0xfe,0x07,0xf3,0x6d,0xfe,0xef,0xf2,0x68,0xfe,0xd7,0xf2,0x64,0xfe,0xbf,0xf2,0x60,0xfe,0xa7,0xf2,0x5c,0xfe,0x8f,0xf2,0x58,0xfe,0x76,0xf2,0x54,0xfe,0x5e,0xf2,0x50,0xfe,0x45,0xf2,0x4c,0xfe,0x2d,0xf2,0x48,0xfe,0x14,0xf2,0x44,0xfe,0xfb,0xf1,0x41,0xfe,0xe1,0xf1,0x3d,0xfe,0xc8,0xf1,0x39,0xfe,0xaf,0xf1,0x36,0xfe,0x95,0xf1,0x32,0xfe,0x7c,0xf1,0x2f,0xfe,0x62,0xf1,0x2b,0xfe,0x48,0xf1,0x28,0xfe,0x2e,0xf1,0x25,0xfe,0x13,0xf1,0x21,0xfe,  \
    0xf9,0xf0,0x1e,0xfe,0xdf,0xf0,0x1b,0xfe,0xc4,0xf0,0x18,0xfe,0xa9,0xf0,0x15,0xfe,0x8f,0xf0,0x12,0xfe,0x74,0xf0,0x0f,0xfe,0x59,0xf0,0x0c,0xfe,0x3e,0xf0,0x09,0xfe,0x22,0xf0,0x07,0xfe,0x07,0xf0,0x04,0xfe,0xeb,0xef,0x01,0xfe,0xd0,0xef,0xff,0xfd,0xb4,0xef,0xfd,0xfd,0x98,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc7,0xfd,0x71,0x10,0xca,0xfd,0x55,0x10,0xcc,0xfd,0x39,0x10,0xcf,0xfd,0x1d,0x10,0xd2,0xfd,0x01,0x10,0xd4,0xfd,0xe5,0x0f,0xd7,0xfd,0xc9,0x0f,0xda,0xfd,0xae,0x0f,0xdd,0xfd,0x93,0x0f,0xe0,0xfd,0x77,0x0f,0xe3,0xfd,0x5c,0x0f,0xe6,0xfd,0x41,0x0f,0xe9,0xfd,0x26,0x0f,0xed,0xfd,0x0c,0x0f,0xf0,0xfd,0xf1,0x0e,0xf4,0xfd,0xd6,0x0e,0xf7,0xfd,  \
    0xbc,0x0e,0xfb,0xfd,0xa2,0x0e,0xfe,0xfd,0x88,0x0e,0x02,0xfe,0x6e,0x0e,0x06,0xfe,0x54,0x0e,0x09,0xfe,0x3a,0x0e,0x0d,0xfe,0x20,0x0e,0x11,0xfe,0x07,0x0e,0x15,0xfe,0xed,0x0d,0x19,0xfe,0xd4,0x0d,0x1d,0xfe,0xbb,0x0d,0x21,0xfe,0xa2,0x0d,0x25,0xfe,0x89,0x0d,0x29,0xfe,0x70,0x0d,0x2d,0xfe,0x57,0x0d,0x31,0xfe,0x3e,0x0d,0x35,0xfe,0x26,0x0d,0x3a,0xfe,0x0d,0x0d,0x3e,0xfe,0xf5,0x0c,0x42,0xfe,0xdd,0x0c,0x47,0xfe,0xc5,0x0c,0x4b,0xfe,0xad,0x0c,0x50,0xfe,0x95,0x0c,  \
    0x54,0xfe,0x7d,0x0c,0x59,0xfe,0x66,0x0c,0x5e,0xfe,0x4f,0x0c,0x63,0xfe,0x39,0x0c,0x68,0xfe,0x22,0x0c,0x6d,0xfe,0x0c,0x0c,0x72,0xfe,0xf5,0x0b,0x77,0xfe,0xdf,0x0b,0x7c,0xfe,0xc9,0x0b,0x81,0xfe,0xb4,0x0b,0x87,0xfe,0x9e,0x0b,0x8c,0xfe,0x88,0x0b,0x91,0xfe,0x73,0x0b,0x96,0xfe,0x5d,0x0b,0x9c,0xfe,0x48,0x0b,0xa1,0xfe,0x33,0x0b,0xa6,0xfe,0x1e,0x0b,0xac,0xfe,0x09,0x0b,0xb1,0xfe,0xf4,0x0a,0xb6,0xfe,0xdf,0x0a,0xbb,0xfe,0xc9,0x0a,0xc0,0xfe,0xb4,0x0a,0xc5,0xfe,  \
    0x9f,0x0a,0xca,0xfe,0x8a,0x0a,0xcf,0xfe,0x75,0x0a,0xd4,0xfe,0x60,0x0a,0xd9,0xfe,0x4c,0x0a,0xde,0xfe,0x37,0x0a,0xe3,0xfe,0x22,0x0a,0xe8,0xfe,0x0e,0x0a,0xed,0xfe,0xfa,0x09,0xf3,0xfe,0xe5,0x09,0xf8,0xfe,0xd1,0x09,0xfd,0xfe,0xbd,0x09,0x02,0xff,0xa9,0x09,0x07,0xff,0x95,0x09,0x0c,0xff,0x82,0x09,0x11,0xff,0x6e,0x09,0x16,0xff,0x5a,0x09,0x1b,0xff,0x47,0x09,0x20,0xff,0x33,0x09,0x25,0xff,0x20,0x09,0x2a,0xff,0x0d,0x09,0x2f,0xff,0xfa,0x08,0x34,0xff,0xe7,0x08,  \
    0x3a,0xff,0xd4,0x08,0x3f,0xff,0xc1,0x08,0x44,0xff,0xae,0x08,0x49,0xff,0x9b,0x08,0x4e,0xff,0x89,0x08,0x53,0xff,0x76,0x08,0x58,0xff,0x64,0x08,0x5c,0xff,0x51,0x08,0x61,0xff,0x3f,0x08,0x66,0xff,0x2d,0x08,0x6b,0xff,0x1b,0x08,0x70,0xff,0x09,0x08,0x75,0xff,0xf8,0x07,0x7a,0xff,0xe6,0x07,0x7f,0xff,0xd4,0x07,0x84,0xff,0xc3,0x07,0x89,0xff,0xb2,0x07,0x8e,0xff,0xa0,0x07,0x93,0xff,0x8f,0x07,0x98,0xff,0x7e,0x07,0x9d,0xff,0x6d,0x07,0xa2,0xff,0x5c,0x07,0xa6,0xff,  \
    0x4b,0x07,0xab,0xff,0x3a,0x07,0xb0,0xff,0x29,0x07,0xb5,0xff,0x19,0x07,0xb9,0xff,0x08,0x07,0xbe,0xff,0xf7,0x06,0xc3,0xff,0xe7,0x06,0xc7,0xff,0xd6,0x06,0xcc,0xff,0xc6,0x06,0xd0,0xff,0xb5,0x06,0xd5,0xff,0xa5,0x06,0xd9,0xff,0x95,0x06,0xde,0xff,0x85,0x06,0xe2,0xff,0x74,0x06,0xe7,0xff,0x64,0x06,0xeb,0xff,0x54,0x06,0xf0,0xff,0x44,0x06,0xf4,0xff,0x34,0x06,0xf8,0xff,0x24,0x06,0xfd,0xff,0x15,0x06,0x01,0x00,0x05,0x06,0x05,0x00,0xf5,0x05,0x09,0x00,0xe6,0x05,  \
    0x0d,0x00,0xd6,0x05,0x12,0x00,0xc6,0x05,0x16,0x00,0xb7,0x05,0x1a,0x00,0xa8,0x05,0x1e,0x00,0x98,0x05,0x22,0x00,0x89,0x05,0x26,0x00,0x7a,0x05,0x2a,0x00,0x6a,0x05,0x2e,0x00,0x5b,0x05,0x31,0x00,0x4b,0x05,0x35,0x00,0x3c,0x05,0x39,0x00,0x2c,0x05,0x3d,0x00,0x1d,0x05,0x40,0x00,0x0d,0x05,0x44,0x00,0xfe,0x04,0x48,0x00,0xef,0x04,0x4b,0x00,0xe0,0x04,0x4f,0x00,0xd0,0x04,0x52,0x00,0xc1,0x04,0x56,0x00,0xb2,0x04,0x59,0x00,0xa3,0x04,0x5d,0x00,0x94,0x04,0x60,0x00,  \
    0x85,0x04,0x63,0x00,0x76,0x04,0x67,0x00,0x68,0x04,0x6a,0x00,0x59,0x04,0x6d,0x00,0x4a,0x04,0x71,0x00,0x3b,0x04,0x74,0x00,0x2d,0x04,0x77,0x00,0x1e,0x04,0x7a,0x00,0x0f,0x04,0x7d,0x00,0x01,0x04,0x80,0x00,0xf3,0x03,0x83,0x00,0xe4,0x03,0x86,0x00,0xd6,0x03,0x89,0x00,0xc8,0x03,0x8c,0x00,0xba,0x03,0x8f,0x00,0xac,0x03,0x92,0x00,0x9e,0x03,0x95,0x00,0x90,0x03,0x98,0x00,0x82,0x03,0x9b,0x00,0x74,0x03,0x9e,0x00,0x66,0x03,0xa0,0x00,0x58,0x03,0xa3,0x00,0x4b,0x03,  \
    0xa6,0x00,0x3d,0x03,0xa8,0x00,0x2f,0x03,0xab,0x00,0x21,0x03,0xad,0x00,0x14,0x03,0xb0,0x00,0x06,0x03,0xb2,0x00,0xf8,0x02,0xb5,0x00,0xeb,0x02,0xb7,0x00,0xdd,0x02,0xba,0x00,0xd0,0x02,0xbc,0x00,0xc2,0x02,0xbe,0x00,0xb5,0x02,0xc1,0x00,0xa7,0x02,0xc3,0x00,0x9a,0x02,0xc5,0x00,0x8c,0x02,0xc7,0x00,0x7f,0x02,0xc9,0x00,0x72,0x02,0xcb,0x00,0x65,0x02,0xcd,0x00,0x57,0x02,0xcf,0x00,0x4a,0x02,0xd1,0x00,0x3d,0x02,0xd3,0x00,0x30,0x02,0xd5,0x00,0x23,0x02,0xd7,0x00,  \
    0x16,0x02,0xd9,0x00,0x08,0x02,0xda,0x00,0xfb,0x01,0xdc,0x00,0xee,0x01,0xde,0x00,0xe1,0x01,0xe0,0x00,0xd4,0x01,0xe1,0x00,0xc7,0x01,0xe3,0x00,0xba,0x01,0xe4,0x00,0xad,0x01,0xe6,0x00,0xa0,0x01,0xe7,0x00,0x93,0x01,0xe9,0x00,0x86,0x01,0xea,0x00,0x79,0x01,0xeb,0x00,0x6c,0x01,0xed,0x00,0x60,0x01,0xee,0x00,0x53,0x01,0xef,0x00,0x46,0x01,0xf0,0x00,0x39,0x01,0xf1,0x00,0x2c,0x01,0xf2,0x00,0x1f,0x01,0xf4,0x00,0x12,0x01,0xf5,0x00,0x05,0x01,0xf6,0x00,0xf8,0x00,  \
    0xf6,0x00,0xec,0x00,0xf7,0x00,0xdf,0x00,0xf8,0x00,0xd2,0x00,0xf9,0x00,0xc5,0x00,0xfa,0x00,0xb8,0x00,0xfb,0x00,0xab,0x00,0xfb,0x00,0x9f,0x00,0xfc,0x00,0x92,0x00,0xfd,0x00,0x85,0x00,0xfd,0x00,0x78,0x00,0xfe,0x00,0x6c,0x00,0xfe,0x00,0x5f,0x00,0xff,0x00,0x52,0x00,0xff,0x00,0x45,0x00,0x00,0x01,0x39,0x00,0x00,0x01,0x2c,0x00,0x00,0x01,0x1f,0x00,0x00,0x01,0x12,0x00,0x01,0x01,0x06,0x00,0x01,0x01,0xf9,0xff,0x01,0x01,0xec,0xff,0x01,0x01,0xdf,0xff,0x01,0x01,  \
    0xd3,0xff,0x01,0x01,0xc6,0xff,0x01,0x01,0xb9,0xff,0x01,0x01,0xad,0xff,0x01,0x01,0xa0,0xff,0x01,0x01,0x93,0xff,0x01,0x01,0x86,0xff,0x01,0x01,0x7a,0xff,0x00,0x01,0x6d,0xff,0x00,0x01,0x60,0xff,0x00,0x01,0x53,0xff,0xff,0x00,0x46,0xff,0xff,0x00,0x3a,0xff,0xff,0x00,0x2d,0xff,0xfe,0x00,0x20,0xff,0xfe,0x00,0x13,0xff,0xfd,0x00,0x06,0xff,0xfd,0x00,0xf9,0xfe,0xfc,0x00,0xec,0xfe,0xfb,0x00,0xdf,0xfe,0xfb,0x00,0xd2,0xfe,0xfa,0x00,0xc5,0xfe,0xf9,0x00,0xb8,0xfe,  \
    0xf8,0x00,0xab,0xfe,0xf7,0x00,0x9e,0xfe,0xf7,0x00,0x91,0xfe,0xf6,0x00,0x84,0xfe,0xf5,0x00,0x77,0xfe,0xf4,0x00,0x6a,0xfe,0xf3,0x00,0x5d,0xfe,0xf2,0x00,0x51,0xfe,0xf1,0x00,0x44,0xfe,0xef,0x00,0x37,0xfe,0xee,0x00,0x2b,0xfe,0xed,0x00,0x1e,0xfe,0xec,0x00,0x11,0xfe,0xea,0x00,0x05,0xfe,0xe9,0x00,0xf8,0xfd,0xe8,0x00,0xeb,0xfd,0xe6,0x00,0xdf,0xfd,0xe5,0x00,0xd2,0xfd,0xe3,0x00,0xc5,0xfd,0xe1,0x00,0xb9,0xfd,0xe0,0x00,0xac,0xfd,0xde,0x00,0x9f,0xfd,0xdd,0x00,  \
    0x93,0xfd,0xdb,0x00,0x86,0xfd,0xd9,0x00,0x79,0xfd,0xd7,0x00,0x6d,0xfd,0xd5,0x00,0x60,0xfd,0xd3,0x00,0x53,0xfd,0xd2,0x00,0x47,0xfd,0xd0,0x00,0x3a,0xfd,0xce,0x00,0x2d,0xfd,0xcb,0x00,0x20,0xfd,0xc9,0x00,0x14,0xfd,0xc7,0x00,0x07,0xfd,0xc5,0x00,0xf9,0xfc,0xc3,0x00,0xec,0xfc,0xc1,0x00,0xde,0xfc,0xbf,0x00,0xd1,0xfc,0xbc,0x00,0xc3,0xfc,0xba,0x00,0xb5,0xfc,0xb8,0x00,0xa7,0xfc,0xb6,0x00,0x9a,0xfc,0xb3,0x00,0x8c,0xfc,0xb1,0x00,0x7e,0xfc,0xae,0x00,0x70,0xfc,  \
    0xac,0x00,0x62,0xfc,0xa9,0x00,0x54,0xfc,0xa7,0x00,0x46,0xfc,0xa4,0x00,0x38,0xfc,0xa2,0x00,0x2a,0xfc,0x9f,0x00,0x1c,0xfc,0x9c,0x00,0x0e,0xfc,0x9a,0x00,0x00,0xfc,0x97,0x00,0xf1,0xfb,0x94,0x00,0xe3,0xfb,0x91,0x00,0xd5,0xfb,0x8f,0x00,0xc6,0xfb,0x8c,0x00,0xb8,0xfb,0x89,0x00,0xaa,0xfb,0x86,0x00,0x9b,0xfb,0x83,0x00,0x8d,0xfb,0x80,0x00,0x7f,0xfb,0x7d,0x00,0x70,0xfb,0x7a,0x00,0x62,0xfb,0x76,0x00,0x54,0xfb,0x73,0x00,0x45,0xfb,0x70,0x00,0x37,0xfb,0x6d,0x00,  \
    0x29,0xfb,0x6a,0x00,0x1a,0xfb,0x66,0x00,0x0c,0xfb,0x63,0x00,0xfd,0xfa,0x5f,0x00,0xef,0xfa,0x5c,0x00,0xe0,0xfa,0x59,0x00,0xd1,0xfa,0x55,0x00,0xc3,0xfa,0x52,0x00,0xb4,0xfa,0x4e,0x00,0xa5,0xfa,0x4a,0x00,0x96,0xfa,0x47,0x00,0x87,0xfa,0x43,0x00,0x78,0xfa,0x3f,0x00,0x69,0xfa,0x3c,0x00,0x5a,0xfa,0x38,0x00,0x4b,0xfa,0x34,0x00,0x3c,0xfa,0x30,0x00,0x2d,0xfa,0x2d,0x00,0x1e,0xfa,0x29,0x00,0x0f,0xfa,0x25,0x00,0xff,0xf9,0x21,0x00,0xf0,0xf9,0x1d,0x00,0xe1,0xf9,  \
    0x19,0x00,0xd1,0xf9,0x15,0x00,0xc2,0xf9,0x11,0x00,0xb2,0xf9,0x0d,0x00,0xa3,0xf9,0x09,0x00,0x93,0xf9,0x04,0x00,0x84,0xf9,0x00,0x00,0x74,0xf9,0xfc,0xff,0x64,0xf9,0xf8,0xff,0x54,0xf9,0xf4,0xff,0x44,0xf9,0xef,0xff,0x34,0xf9,0xeb,0xff,0x24,0xf9,0xe7,0xff,0x14,0xf9,0xe2,0xff,0x04,0xf9,0xde,0xff,0xf4,0xf8,0xda,0xff,0xe4,0xf8,0xd5,0xff,0xd3,0xf8,0xd1,0xff,0xc3,0xf8,0xcc,0xff,0xb3,0xf8,0xc8,0xff,0xa2,0xf8,0xc3,0xff,0x91,0xf8,0xbf,0xff,0x81,0xf8,0xba,0xff,  \
    0x70,0xf8,0xb5,0xff,0x5f,0xf8,0xb1,0xff,0x4e,0xf8,0xac,0xff,0x3d,0xf8,0xa7,0xff,0x2c,0xf8,0xa3,0xff,0x1b,0xf8,0x9e,0xff,0x0a,0xf8,0x99,0xff,0xf9,0xf7,0x95,0xff,0xe8,0xf7,0x90,0xff,0xd6,0xf7,0x8b,0xff,0xc5,0xf7,0x86,0xff,0xb3,0xf7,0x82,0xff,0xa2,0xf7,0x7d,0xff,0x90,0xf7,0x78,0xff,0x7e,0xf7,0x73,0xff,0x6c,0xf7,0x6e,0xff,0x5b,0xf7,0x69,0xff,0x49,0xf7,0x64,0xff,0x36,0xf7,0x60,0xff,0x24,0xf7,0x5b,0xff,0x12,0xf7,0x56,0xff,0x00,0xf7,0x51,0xff,0xed,0xf6,  \
    0x4c,0xff,0xdb,0xf6,0x47,0xff,0xc8,0xf6,0x42,0xff,0xb5,0xf6,0x3d,0xff,0xa3,0xf6,0x38,0xff,0x90,0xf6,0x33,0xff,0x7d,0xf6,0x2e,0xff,0x6a,0xf6,0x29,0xff,0x57,0xf6,0x24,0xff,0x43,0xf6,0x1f,0xff,0x30,0xf6,0x1a,0xff,0x1c,0xf6,0x15,0xff,0x09,0xf6,0x10,0xff,0xf5,0xf5,0x0b,0xff,0xe2,0xf5,0x06,0xff,0xce,0xf5,0x01,0xff,0xba,0xf5,0xfc,0xfe,0xa5,0xf5,0xf7,0xfe,0x91,0xf5,0xf2,0xfe,0x7d,0xf5,0xee,0xfe,0x68,0xf5,0xe9,0xfe,0x54,0xf5,0xe4,0xfe,0x3f,0xf5,0xdf,0xfe,  \
    0x2a,0xf5,0xda,0xfe,0x15,0xf5,0xd5,0xfe,0x00,0xf5,0xd0,0xfe,0xeb,0xf4,0xcb,0xfe,0xd6,0xf4,0xc7,0xfe,0xc1,0xf4,0xc2,0xfe,0xab,0xf4,0xbd,0xfe,0x96,0xf4,0xb8,0xfe,0x80,0xf4,0xb3,0xfe,0x6a,0xf4,0xaf,0xfe,0x54,0xf4,0xaa,0xfe,0x3f,0xf4,0xa5,0xfe,0x29,0xf4,0xa0,0xfe,0x13,0xf4,0x9c,0xfe,0xfc,0xf3,0x97,0xfe,0xe6,0xf3,0x92,0xfe,0xd0,0xf3,0x8e,0xfe,0xb9,0xf3,0x89,0xfe,0xa3,0xf3,0x84,0xfe,0x8c,0xf3,0x80,0xfe,0x75,0xf3,0x7b,0xfe,0x5e,0xf3,0x77,0xfe,0x47,0xf3,  \
    0x72,0xfe,0x2f,0xf3,0x6e,0xfe,0x18,0xf3,0x6a,0xfe,0x01,0xf3,0x65,0xfe,0xe9,0xf2,0x61,0xfe,0xd1,0xf2,0x5d,0xfe,0xb9,0xf2,0x58,0xfe,0xa1,0xf2,0x54,0xfe,0x89,0xf2,0x50,0xfe,0x71,0xf2,0x4c,0xfe,0x58,0xf2,0x48,0xfe,0x3f,0xf2,0x44,0xfe,0x27,0xf2,0x40,0xfe,0x0e,0xf2,0x3c,0xfe,0xf5,0xf1,0x39,0xfe,0xdc,0xf1,0x35,0xfe,0xc2,0xf1,0x31,0xfe,0xa9,0xf1,0x2e,0xfe,0x8f,0xf1,0x2a,0xfe,0x76,0xf1,0x26,0xfe,0x5c,0xf1,0x23,0xfe,0x42,0xf1,0x20,0xfe,0x28,0xf1,0x1c,0xfe,  \
    0x0e,0xf1,0x19,0xfe,0xf3,0xf0,0x16,0xfe,0xd9,0xf0,0x13,0xfe,0xbe,0xf0,0x0f,0xfe,0xa4,0xf0,0x0c,0xfe,0x89,0xf0,0x09,0xfe,0x6e,0xf0,0x06,0xfe,0x53,0xf0,0x03,0xfe,0x38,0xf0,0x01,0xfe,0x1d,0xf0,0xfe,0xfd,0x01,0xf0,0xfb,0xfd,0xe6,0xef,0xf9,0xfd,0xca,0xef,0xf6,0xfd,0xae,0xef,0xf4,0xfd,0x92,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xbb,0xfd,0x76,0x10,0xbd,0xfd,0x59,0x10,0xc0,0xfd,0x3d,0x10,0xc2,0xfd,0x21,0x10,0xc5,0xfd,0x05,0x10,0xc8,0xfd,0xe9,0x0f,0xcb,0xfd,0xce,0x0f,0xce,0xfd,0xb2,0x0f,0xd1,0xfd,0x97,0x0f,0xd4,0xfd,0x7c,0x0f,0xd7,0xfd,0x61,0x0f,0xda,0xfd,0x46,0x0f,0xdd,0xfd,0x2b,0x0f,0xe1,0xfd,0x10,0x0f,0xe4,0xfd,0xf5,0x0e,0xe8,0xfd,  \
    0xdb,0x0e,0xeb,0xfd,0xc1,0x0e,0xef,0xfd,0xa6,0x0e,0xf3,0xfd,0x8c,0x0e,0xf6,0xfd,0x72,0x0e,0xfa,0xfd,0x59,0x0e,0xfe,0xfd,0x3f,0x0e,0x02,0xfe,0x25,0x0e,0x06,0xfe,0x0b,0x0e,0x0a,0xfe,0xf2,0x0d,0x0d,0xfe,0xd9,0x0d,0x12,0xfe,0xbf,0x0d,0x16,0xfe,0xa6,0x0d,0x1a,0xfe,0x8d,0x0d,0x1e,0xfe,0x74,0x0d,0x22,0xfe,0x5c,0x0d,0x26,0xfe,0x43,0x0d,0x2b,0xfe,0x2b,0x0d,0x2f,0xfe,0x12,0x0d,0x34,0xfe,0xfa,0x0c,0x38,0xfe,0xe2,0x0c,0x3c,0xfe,0xca,0x0c,0x41,0xfe,0xb2,0x0c,  \
    0x45,0xfe,0x9a,0x0c,0x4a,0xfe,0x82,0x0c,0x4f,0xfe,0x6b,0x0c,0x54,0xfe,0x54,0x0c,0x59,0xfe,0x3e,0x0c,0x5e,0xfe,0x27,0x0c,0x63,0xfe,0x11,0x0c,0x68,0xfe,0xfb,0x0b,0x6e,0xfe,0xe5,0x0b,0x73,0xfe,0xcf,0x0b,0x78,0xfe,0xb9,0x0b,0x7d,0xfe,0xa3,0x0b,0x83,0xfe,0x8e,0x0b,0x88,0xfe,0x78,0x0b,0x8e,0xfe,0x63,0x0b,0x93,0xfe,0x4e,0x0b,0x98,0xfe,0x39,0x0b,0x9e,0xfe,0x24,0x0b,0xa3,0xfe,0x0f,0x0b,0xa9,0xfe,0xfa,0x0a,0xae,0xfe,0xe5,0x0a,0xb3,0xfe,0xcf,0x0a,0xb8,0xfe,  \
    0xba,0x0a,0xbd,0xfe,0xa5,0x0a,0xc2,0xfe,0x90,0x0a,0xc7,0xfe,0x7b,0x0a,0xcc,0xfe,0x66,0x0a,0xd2,0xfe,0x52,0x0a,0xd7,0xfe,0x3d,0x0a,0xdc,0xfe,0x29,0x0a,0xe1,0xfe,0x14,0x0a,0xe6,0xfe,0x00,0x0a,0xeb,0xfe,0xec,0x09,0xf0,0xfe,0xd7,0x09,0xf6,0xfe,0xc3,0x09,0xfb,0xfe,0xaf,0x09,0x00,0xff,0x9c,0x09,0x05,0xff,0x88,0x09,0x0a,0xff,0x74,0x09,0x0f,0xff,0x61,0x09,0x15,0xff,0x4d,0x09,0x1a,0xff,0x3a,0x09,0x1f,0xff,0x27,0x09,0x24,0xff,0x13,0x09,0x29,0xff,0x00,0x09,  \
    0x2e,0xff,0xed,0x08,0x33,0xff,0xda,0x08,0x39,0xff,0xc7,0x08,0x3e,0xff,0xb5,0x08,0x43,0xff,0xa2,0x08,0x48,0xff,0x8f,0x08,0x4d,0xff,0x7d,0x08,0x52,0xff,0x6a,0x08,0x57,0xff,0x58,0x08,0x5c,0xff,0x46,0x08,0x61,0xff,0x33,0x08,0x66,0xff,0x22,0x08,0x6b,0xff,0x10,0x08,0x70,0xff,0xfe,0x07,0x75,0xff,0xed,0x07,0x7a,0xff,0xdb,0x07,0x7f,0xff,0xca,0x07,0x84,0xff,0xb8,0x07,0x89,0xff,0xa7,0x07,0x8e,0xff,0x96,0x07,0x93,0xff,0x85,0x07,0x98,0xff,0x74,0x07,0x9d,0xff,  \
    0x63,0x07,0xa2,0xff,0x52,0x07,0xa7,0xff,0x41,0x07,0xac,0xff,0x30,0x07,0xb0,0xff,0x1f,0x07,0xb5,0xff,0x0f,0x07,0xba,0xff,0xfe,0x06,0xbf,0xff,0xed,0x06,0xc3,0xff,0xdd,0x06,0xc8,0xff,0xcd,0x06,0xcd,0xff,0xbc,0x06,0xd1,0xff,0xac,0x06,0xd6,0xff,0x9c,0x06,0xda,0xff,0x8b,0x06,0xdf,0xff,0x7b,0x06,0xe3,0xff,0x6b,0x06,0xe8,0xff,0x5b,0x06,0xec,0xff,0x4b,0x06,0xf1,0xff,0x3b,0x06,0xf5,0xff,0x2b,0x06,0xf9,0xff,0x1b,0x06,0xfe,0xff,0x0c,0x06,0x02,0x00,0xfc,0x05,  \
    0x06,0x00,0xec,0x05,0x0a,0x00,0xdd,0x05,0x0f,0x00,0xcd,0x05,0x13,0x00,0xbe,0x05,0x17,0x00,0xae,0x05,0x1b,0x00,0x9f,0x05,0x1f,0x00,0x8f,0x05,0x23,0x00,0x80,0x05,0x27,0x00,0x71,0x05,0x2b,0x00,0x61,0x05,0x2f,0x00,0x52,0x05,0x33,0x00,0x42,0x05,0x36,0x00,0x32,0x05,0x3a,0x00,0x23,0x05,0x3e,0x00,0x14,0x05,0x42,0x00,0x04,0x05,0x45,0x00,0xf5,0x04,0x49,0x00,0xe6,0x04,0x4c,0x00,0xd6,0x04,0x50,0x00,0xc7,0x04,0x53,0x00,0xb8,0x04,0x57,0x00,0xa9,0x04,0x5a,0x00,  \
    0x9a,0x04,0x5e,0x00,0x8b,0x04,0x61,0x00,0x7c,0x04,0x65,0x00,0x6d,0x04,0x68,0x00,0x5e,0x04,0x6b,0x00,0x50,0x04,0x6f,0x00,0x41,0x04,0x72,0x00,0x32,0x04,0x75,0x00,0x23,0x04,0x78,0x00,0x15,0x04,0x7b,0x00,0x06,0x04,0x7f,0x00,0xf8,0x03,0x82,0x00,0xea,0x03,0x85,0x00,0xdc,0x03,0x88,0x00,0xcd,0x03,0x8b,0x00,0xbf,0x03,0x8e,0x00,0xb1,0x03,0x91,0x00,0xa3,0x03,0x94,0x00,0x95,0x03,0x97,0x00,0x87,0x03,0x99,0x00,0x79,0x03,0x9c,0x00,0x6b,0x03,0x9f,0x00,0x5d,0x03,  \
    0xa2,0x00,0x4f,0x03,0xa4,0x00,0x41,0x03,0xa7,0x00,0x34,0x03,0xaa,0x00,0x26,0x03,0xac,0x00,0x18,0x03,0xaf,0x00,0x0a,0x03,0xb1,0x00,0xfd,0x02,0xb4,0x00,0xef,0x02,0xb6,0x00,0xe1,0x02,0xb9,0x00,0xd4,0x02,0xbb,0x00,0xc6,0x02,0xbd,0x00,0xb9,0x02,0xbf,0x00,0xab,0x02,0xc2,0x00,0x9e,0x02,0xc4,0x00,0x90,0x02,0xc6,0x00,0x83,0x02,0xc8,0x00,0x76,0x02,0xca,0x00,0x68,0x02,0xcc,0x00,0x5b,0x02,0xce,0x00,0x4e,0x02,0xd0,0x00,0x40,0x02,0xd2,0x00,0x33,0x02,0xd4,0x00,  \
    0x26,0x02,0xd6,0x00,0x19,0x02,0xd8,0x00,0x0c,0x02,0xda,0x00,0xff,0x01,0xdb,0x00,0xf1,0x01,0xdd,0x00,0xe4,0x01,0xdf,0x00,0xd7,0x01,0xe0,0x00,0xca,0x01,0xe2,0x00,0xbd,0x01,0xe4,0x00,0xb0,0x01,0xe5,0x00,0xa3,0x01,0xe7,0x00,0x96,0x01,0xe8,0x00,0x89,0x01,0xe9,0x00,0x7c,0x01,0xeb,0x00,0x6f,0x01,0xec,0x00,0x62,0x01,0xed,0x00,0x55,0x01,0xef,0x00,0x48,0x01,0xf0,0x00,0x3b,0x01,0xf1,0x00,0x2e,0x01,0xf2,0x00,0x21,0x01,0xf3,0x00,0x14,0x01,0xf4,0x00,0x07,0x01,  \
    0xf5,0x00,0xfa,0x00,0xf6,0x00,0xed,0x00,0xf7,0x00,0xe0,0x00,0xf8,0x00,0xd4,0x00,0xf9,0x00,0xc7,0x00,0xf9,0x00,0xba,0x00,0xfa,0x00,0xad,0x00,0xfb,0x00,0xa0,0x00,0xfc,0x00,0x93,0x00,0xfc,0x00,0x86,0x00,0xfd,0x00,0x79,0x00,0xfd,0x00,0x6d,0x00,0xfe,0x00,0x60,0x00,0xfe,0x00,0x53,0x00,0xff,0x00,0x46,0x00,0xff,0x00,0x39,0x00,0xff,0x00,0x2c,0x00,0x00,0x01,0x20,0x00,0x00,0x01,0x13,0x00,0x00,0x01,0x06,0x00,0x00,0x01,0xf9,0xff,0x01,0x01,0xec,0xff,0x01,0x01,  \
    0xe0,0xff,0x01,0x01,0xd3,0xff,0x01,0x01,0xc6,0xff,0x01,0x01,0xb9,0xff,0x01,0x01,0xac,0xff,0x01,0x01,0xa0,0xff,0x01,0x01,0x93,0xff,0x00,0x01,0x86,0xff,0x00,0x01,0x79,0xff,0x00,0x01,0x6c,0xff,0x00,0x01,0x5f,0xff,0xff,0x00,0x52,0xff,0xff,0x00,0x46,0xff,0xff,0x00,0x39,0xff,0xfe,0x00,0x2c,0xff,0xfe,0x00,0x1f,0xff,0xfd,0x00,0x12,0xff,0xfd,0x00,0x05,0xff,0xfc,0x00,0xf8,0xfe,0xfc,0x00,0xeb,0xfe,0xfb,0x00,0xde,0xfe,0xfa,0x00,0xd1,0xfe,0xf9,0x00,0xc4,0xfe,  \
    0xf9,0x00,0xb7,0xfe,0xf8,0x00,0xaa,0xfe,0xf7,0x00,0x9d,0xfe,0xf6,0x00,0x90,0xfe,0xf5,0x00,0x82,0xfe,0xf4,0x00,0x75,0xfe,0xf3,0x00,0x68,0xfe,0xf2,0x00,0x5b,0xfe,0xf1,0x00,0x4e,0xfe,0xf0,0x00,0x42,0xfe,0xef,0x00,0x35,0xfe,0xee,0x00,0x28,0xfe,0xec,0x00,0x1b,0xfe,0xeb,0x00,0x0f,0xfe,0xea,0x00,0x02,0xfe,0xe8,0x00,0xf5,0xfd,0xe7,0x00,0xe9,0xfd,0xe5,0x00,0xdc,0xfd,0xe4,0x00,0xcf,0xfd,0xe2,0x00,0xc2,0xfd,0xe1,0x00,0xb6,0xfd,0xdf,0x00,0xa9,0xfd,0xde,0x00,  \
    0x9c,0xfd,0xdc,0x00,0x90,0xfd,0xda,0x00,0x83,0xfd,0xd8,0x00,0x76,0xfd,0xd6,0x00,0x69,0xfd,0xd5,0x00,0x5d,0xfd,0xd3,0x00,0x50,0xfd,0xd1,0x00,0x43,0xfd,0xcf,0x00,0x36,0xfd,0xcd,0x00,0x2a,0xfd,0xcb,0x00,0x1d,0xfd,0xc9,0x00,0x10,0xfd,0xc6,0x00,0x03,0xfd,0xc4,0x00,0xf6,0xfc,0xc2,0x00,0xe8,0xfc,0xc0,0x00,0xda,0xfc,0xbe,0x00,0xcd,0xfc,0xbc,0x00,0xbf,0xfc,0xb9,0x00,0xb1,0xfc,0xb7,0x00,0xa3,0xfc,0xb5,0x00,0x95,0xfc,0xb2,0x00,0x88,0xfc,0xb0,0x00,0x7a,0xfc,  \
    0xad,0x00,0x6c,0xfc,0xab,0x00,0x5e,0xfc,0xa8,0x00,0x50,0xfc,0xa6,0x00,0x42,0xfc,0xa3,0x00,0x33,0xfc,0xa1,0x00,0x25,0xfc,0x9e,0x00,0x17,0xfc,0x9b,0x00,0x09,0xfc,0x98,0x00,0xfb,0xfb,0x96,0x00,0xec,0xfb,0x93,0x00,0xde,0xfb,0x90,0x00,0xd0,0xfb,0x8d,0x00,0xc1,0xfb,0x8a,0x00,0xb3,0xfb,0x87,0x00,0xa4,0xfb,0x85,0x00,0x96,0xfb,0x81,0x00,0x87,0xfb,0x7e,0x00,0x79,0xfb,0x7b,0x00,0x6b,0xfb,0x78,0x00,0x5c,0xfb,0x75,0x00,0x4e,0xfb,0x72,0x00,0x40,0xfb,0x6f,0x00,  \
    0x31,0xfb,0x6b,0x00,0x23,0xfb,0x68,0x00,0x14,0xfb,0x65,0x00,0x06,0xfb,0x61,0x00,0xf7,0xfa,0x5e,0x00,0xe8,0xfa,0x5a,0x00,0xda,0xfa,0x57,0x00,0xcb,0xfa,0x53,0x00,0xbc,0xfa,0x50,0x00,0xae,0xfa,0x4c,0x00,0x9f,0xfa,0x49,0x00,0x90,0xfa,0x45,0x00,0x81,0xfa,0x41,0x00,0x72,0xfa,0x3e,0x00,0x63,0xfa,0x3a,0x00,0x54,0xfa,0x36,0x00,0x45,0xfa,0x32,0x00,0x35,0xfa,0x2e,0x00,0x26,0xfa,0x2a,0x00,0x17,0xfa,0x27,0x00,0x08,0xfa,0x23,0x00,0xf9,0xf9,0x1f,0x00,0xe9,0xf9,  \
    0x1b,0x00,0xda,0xf9,0x17,0x00,0xcb,0xf9,0x13,0x00,0xbb,0xf9,0x0e,0x00,0xac,0xf9,0x0a,0x00,0x9c,0xf9,0x06,0x00,0x8c,0xf9,0x02,0x00,0x7d,0xf9,0xfe,0xff,0x6d,0xf9,0xf9,0xff,0x5d,0xf9,0xf5,0xff,0x4d,0xf9,0xf1,0xff,0x3d,0xf9,0xed,0xff,0x2d,0xf9,0xe8,0xff,0x1d,0xf9,0xe4,0xff,0x0d,0xf9,0xdf,0xff,0xfd,0xf8,0xdb,0xff,0xed,0xf8,0xd7,0xff,0xdd,0xf8,0xd2,0xff,0xcc,0xf8,0xce,0xff,0xbc,0xf8,0xc9,0xff,0xac,0xf8,0xc4,0xff,0x9b,0xf8,0xc0,0xff,0x8a,0xf8,0xbb,0xff,  \
    0x7a,0xf8,0xb7,0xff,0x69,0xf8,0xb2,0xff,0x58,0xf8,0xad,0xff,0x47,0xf8,0xa9,0xff,0x36,0xf8,0xa4,0xff,0x25,0xf8,0x9f,0xff,0x14,0xf8,0x9b,0xff,0x03,0xf8,0x96,0xff,0xf2,0xf7,0x91,0xff,0xe1,0xf7,0x8c,0xff,0xcf,0xf7,0x87,0xff,0xbe,0xf7,0x82,0xff,0xac,0xf7,0x7e,0xff,0x9b,0xf7,0x79,0xff,0x89,0xf7,0x74,0xff,0x77,0xf7,0x6f,0xff,0x65,0xf7,0x6a,0xff,0x53,0xf7,0x65,0xff,0x41,0xf7,0x60,0xff,0x2f,0xf7,0x5b,0xff,0x1d,0xf7,0x56,0xff,0x0b,0xf7,0x51,0xff,0xf9,0xf6,  \
    0x4c,0xff,0xe6,0xf6,0x47,0xff,0xd4,0xf6,0x42,0xff,0xc1,0xf6,0x3d,0xff,0xae,0xf6,0x38,0xff,0x9c,0xf6,0x33,0xff,0x89,0xf6,0x2e,0xff,0x76,0xf6,0x29,0xff,0x63,0xf6,0x24,0xff,0x50,0xf6,0x1f,0xff,0x3c,0xf6,0x1a,0xff,0x29,0xf6,0x15,0xff,0x16,0xf6,0x10,0xff,0x02,0xf6,0x0b,0xff,0xee,0xf5,0x06,0xff,0xdb,0xf5,0x01,0xff,0xc7,0xf5,0xfc,0xfe,0xb3,0xf5,0xf7,0xfe,0x9f,0xf5,0xf2,0xfe,0x8a,0xf5,0xed,0xfe,0x76,0xf5,0xe8,0xfe,0x61,0xf5,0xe3,0xfe,0x4d,0xf5,0xde,0xfe,  \
    0x38,0xf5,0xd9,0xfe,0x23,0xf5,0xd4,0xfe,0x0f,0xf5,0xcf,0xfe,0xfa,0xf4,0xca,0xfe,0xe4,0xf4,0xc5,0xfe,0xcf,0xf4,0xc0,0xfe,0xba,0xf4,0xbc,0xfe,0xa5,0xf4,0xb7,0xfe,0x8f,0xf4,0xb2,0xfe,0x79,0xf4,0xad,0xfe,0x64,0xf4,0xa8,0xfe,0x4e,0xf4,0xa3,0xfe,0x38,0xf4,0x9f,0xfe,0x22,0xf4,0x9a,0xfe,0x0c,0xf4,0x95,0xfe,0xf6,0xf3,0x90,0xfe,0xe0,0xf3,0x8c,0xfe,0xc9,0xf3,0x87,0xfe,0xb3,0xf3,0x82,0xfe,0x9c,0xf3,0x7d,0xfe,0x85,0xf3,0x79,0xfe,0x6f,0xf3,0x74,0xfe,0x58,0xf3,  \
    0x70,0xfe,0x40,0xf3,0x6b,0xfe,0x29,0xf3,0x67,0xfe,0x12,0xf3,0x62,0xfe,0xfa,0xf2,0x5e,0xfe,0xe3,0xf2,0x5a,0xfe,0xcb,0xf2,0x55,0xfe,0xb3,0xf2,0x51,0xfe,0x9b,0xf2,0x4d,0xfe,0x83,0xf2,0x49,0xfe,0x6a,0xf2,0x45,0xfe,0x52,0xf2,0x40,0xfe,0x39,0xf2,0x3c,0xfe,0x21,0xf2,0x39,0xfe,0x08,0xf2,0x35,0xfe,0xef,0xf1,0x31,0xfe,0xd6,0xf1,0x2d,0xfe,0xbc,0xf1,0x29,0xfe,0xa3,0xf1,0x26,0xfe,0x8a,0xf1,0x22,0xfe,0x70,0xf1,0x1e,0xfe,0x56,0xf1,0x1b,0xfe,0x3c,0xf1,0x17,0xfe,  \
    0x22,0xf1,0x14,0xfe,0x08,0xf1,0x11,0xfe,0xee,0xf0,0x0d,0xfe,0xd3,0xf0,0x0a,0xfe,0xb9,0xf0,0x07,0xfe,0x9e,0xf0,0x04,0xfe,0x83,0xf0,0x01,0xfe,0x69,0xf0,0xfe,0xfd,0x4e,0xf0,0xfb,0xfd,0x32,0xf0,0xf8,0xfd,0x17,0xf0,0xf5,0xfd,0xfc,0xef,0xf2,0xfd,0xe0,0xef,0xf0,0xfd,0xc5,0xef,0xed,0xfd,0xa9,0xef,0xeb,0xfd,0x8d,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xae,0xfd,0x7a,0x10,0xb1,0xfd,0x5e,0x10,0xb3,0xfd,0x42,0x10,0xb6,0xfd,0x26,0x10,0xb9,0xfd,0x0a,0x10,0xbc,0xfd,0xee,0x0f,0xbe,0xfd,0xd2,0x0f,0xc1,0xfd,0xb7,0x0f,0xc4,0xfd,0x9b,0x0f,0xc8,0xfd,0x80,0x0f,0xcb,0xfd,0x65,0x0f,0xce,0xfd,0x4a,0x0f,0xd1,0xfd,0x2f,0x0f,0xd5,0xfd,0x15,0x0f,0xd8,0xfd,  \
    0xfa,0x0e,0xdc,0xfd,0xe0,0x0e,0xe0,0xfd,0xc5,0x0e,0xe3,0xfd,0xab,0x0e,0xe7,0xfd,0x91,0x0e,0xeb,0xfd,0x77,0x0e,0xef,0xfd,0x5d,0x0e,0xf2,0xfd,0x43,0x0e,0xf6,0xfd,0x2a,0x0e,0xfa,0xfd,0x10,0x0e,0xfe,0xfd,0xf7,0x0d,0x02,0xfe,0xde,0x0d,0x06,0xfe,0xc4,0x0d,0x0b,0xfe,0xab,0x0d,0x0f,0xfe,0x92,0x0d,0x13,0xfe,0x79,0x0d,0x17,0xfe,0x61,0x0d,0x1c,0xfe,0x48,0x0d,0x20,0xfe,0x30,0x0d,0x25,0xfe,0x17,0x0d,0x29,0xfe,0xff,0x0c,0x2e,0xfe,0xe7,0x0c,0x32,0xfe,0xcf,0x0c,  \
    0x37,0xfe,0xb7,0x0c,0x3b,0xfe,0x9f,0x0c,0x40,0xfe,0x87,0x0c,0x45,0xfe,0x70,0x0c,0x4a,0xfe,0x5a,0x0c,0x4f,0xfe,0x43,0x0c,0x54,0xfe,0x2d,0x0c,0x5a,0xfe,0x16,0x0c,0x5f,0xfe,0x00,0x0c,0x64,0xfe,0xea,0x0b,0x6a,0xfe,0xd4,0x0b,0x6f,0xfe,0xbf,0x0b,0x74,0xfe,0xa9,0x0b,0x7a,0xfe,0x93,0x0b,0x7f,0xfe,0x7e,0x0b,0x85,0xfe,0x69,0x0b,0x8a,0xfe,0x54,0x0b,0x90,0xfe,0x3f,0x0b,0x95,0xfe,0x2a,0x0b,0x9b,0xfe,0x15,0x0b,0xa0,0xfe,0x00,0x0b,0xa6,0xfe,0xeb,0x0a,0xab,0xfe,  \
    0xd6,0x0a,0xb0,0xfe,0xc0,0x0a,0xb5,0xfe,0xab,0x0a,0xba,0xfe,0x96,0x0a,0xbf,0xfe,0x81,0x0a,0xc5,0xfe,0x6d,0x0a,0xca,0xfe,0x58,0x0a,0xcf,0xfe,0x43,0x0a,0xd4,0xfe,0x2f,0x0a,0xda,0xfe,0x1a,0x0a,0xdf,0xfe,0x06,0x0a,0xe4,0xfe,0xf2,0x09,0xe9,0xfe,0xde,0x09,0xef,0xfe,0xca,0x09,0xf4,0xfe,0xb6,0x09,0xf9,0xfe,0xa2,0x09,0xfe,0xfe,0x8e,0x09,0x04,0xff,0x7b,0x09,0x09,0xff,0x67,0x09,0x0e,0xff,0x54,0x09,0x13,0xff,0x40,0x09,0x18,0xff,0x2d,0x09,0x1e,0xff,0x1a,0x09,  \
    0x23,0xff,0x07,0x09,0x28,0xff,0xf4,0x08,0x2d,0xff,0xe1,0x08,0x32,0xff,0xce,0x08,0x38,0xff,0xbb,0x08,0x3d,0xff,0xa8,0x08,0x42,0xff,0x96,0x08,0x47,0xff,0x83,0x08,0x4c,0xff,0x71,0x08,0x51,0xff,0x5f,0x08,0x56,0xff,0x4c,0x08,0x5b,0xff,0x3a,0x08,0x61,0xff,0x28,0x08,0x66,0xff,0x17,0x08,0x6b,0xff,0x05,0x08,0x70,0xff,0xf3,0x07,0x75,0xff,0xe2,0x07,0x7a,0xff,0xd0,0x07,0x7f,0xff,0xbf,0x07,0x84,0xff,0xae,0x07,0x89,0xff,0x9d,0x07,0x8e,0xff,0x8b,0x07,0x93,0xff,  \
    0x7a,0x07,0x98,0xff,0x69,0x07,0x9d,0xff,0x58,0x07,0xa2,0xff,0x48,0x07,0xa7,0xff,0x37,0x07,0xac,0xff,0x26,0x07,0xb1,0xff,0x15,0x07,0xb6,0xff,0x05,0x07,0xba,0xff,0xf4,0x06,0xbf,0xff,0xe4,0x06,0xc4,0xff,0xd3,0x06,0xc9,0xff,0xc3,0x06,0xcd,0xff,0xb3,0x06,0xd2,0xff,0xa2,0x06,0xd6,0xff,0x92,0x06,0xdb,0xff,0x82,0x06,0xe0,0xff,0x72,0x06,0xe4,0xff,0x62,0x06,0xe9,0xff,0x52,0x06,0xed,0xff,0x42,0x06,0xf1,0xff,0x32,0x06,0xf6,0xff,0x22,0x06,0xfa,0xff,0x12,0x06,  \
    0xff,0xff,0x03,0x06,0x03,0x00,0xf3,0x05,0x07,0x00,0xe3,0x05,0x0b,0x00,0xd4,0x05,0x10,0x00,0xc4,0x05,0x14,0x00,0xb5,0x05,0x18,0x00,0xa5,0x05,0x1c,0x00,0x96,0x05,0x20,0x00,0x87,0x05,0x24,0x00,0x77,0x05,0x28,0x00,0x68,0x05,0x2c,0x00,0x58,0x05,0x30,0x00,0x48,0x05,0x34,0x00,0x39,0x05,0x37,0x00,0x29,0x05,0x3b,0x00,0x1a,0x05,0x3f,0x00,0x0b,0x05,0x43,0x00,0xfb,0x04,0x46,0x00,0xec,0x04,0x4a,0x00,0xdd,0x04,0x4e,0x00,0xcd,0x04,0x51,0x00,0xbe,0x04,0x55,0x00,  \
    0xaf,0x04,0x58,0x00,0xa0,0x04,0x5c,0x00,0x91,0x04,0x5f,0x00,0x82,0x04,0x63,0x00,0x73,0x04,0x66,0x00,0x64,0x04,0x69,0x00,0x55,0x04,0x6d,0x00,0x46,0x04,0x70,0x00,0x38,0x04,0x73,0x00,0x29,0x04,0x76,0x00,0x1a,0x04,0x79,0x00,0x0c,0x04,0x7d,0x00,0xfd,0x03,0x80,0x00,0xef,0x03,0x83,0x00,0xe1,0x03,0x86,0x00,0xd3,0x03,0x89,0x00,0xc4,0x03,0x8c,0x00,0xb6,0x03,0x8f,0x00,0xa8,0x03,0x92,0x00,0x9a,0x03,0x95,0x00,0x8c,0x03,0x98,0x00,0x7e,0x03,0x9b,0x00,0x70,0x03,  \
    0x9d,0x00,0x62,0x03,0xa0,0x00,0x54,0x03,0xa3,0x00,0x46,0x03,0xa6,0x00,0x38,0x03,0xa8,0x00,0x2a,0x03,0xab,0x00,0x1d,0x03,0xad,0x00,0x0f,0x03,0xb0,0x00,0x01,0x03,0xb2,0x00,0xf3,0x02,0xb5,0x00,0xe6,0x02,0xb7,0x00,0xd8,0x02,0xba,0x00,0xca,0x02,0xbc,0x00,0xbd,0x02,0xbe,0x00,0xaf,0x02,0xc0,0x00,0xa2,0x02,0xc3,0x00,0x94,0x02,0xc5,0x00,0x87,0x02,0xc7,0x00,0x79,0x02,0xc9,0x00,0x6c,0x02,0xcb,0x00,0x5f,0x02,0xcd,0x00,0x51,0x02,0xcf,0x00,0x44,0x02,0xd1,0x00,  \
    0x37,0x02,0xd3,0x00,0x2a,0x02,0xd5,0x00,0x1c,0x02,0xd7,0x00,0x0f,0x02,0xd9,0x00,0x02,0x02,0xda,0x00,0xf5,0x01,0xdc,0x00,0xe7,0x01,0xde,0x00,0xda,0x01,0xe0,0x00,0xcd,0x01,0xe1,0x00,0xc0,0x01,0xe3,0x00,0xb3,0x01,0xe4,0x00,0xa6,0x01,0xe6,0x00,0x99,0x01,0xe7,0x00,0x8c,0x01,0xe9,0x00,0x7f,0x01,0xea,0x00,0x71,0x01,0xeb,0x00,0x64,0x01,0xec,0x00,0x57,0x01,0xee,0x00,0x4a,0x01,0xef,0x00,0x3d,0x01,0xf0,0x00,0x30,0x01,0xf1,0x00,0x23,0x01,0xf2,0x00,0x16,0x01,  \
    0xf3,0x00,0x09,0x01,0xf4,0x00,0xfc,0x00,0xf5,0x00,0xef,0x00,0xf6,0x00,0xe2,0x00,0xf7,0x00,0xd5,0x00,0xf8,0x00,0xc8,0x00,0xf9,0x00,0xbb,0x00,0xf9,0x00,0xae,0x00,0xfa,0x00,0xa1,0x00,0xfb,0x00,0x94,0x00,0xfc,0x00,0x87,0x00,0xfc,0x00,0x7b,0x00,0xfd,0x00,0x6e,0x00,0xfd,0x00,0x61,0x00,0xfe,0x00,0x54,0x00,0xfe,0x00,0x47,0x00,0xfe,0x00,0x3a,0x00,0xff,0x00,0x2d,0x00,0xff,0x00,0x20,0x00,0xff,0x00,0x13,0x00,0x00,0x01,0x06,0x00,0x00,0x01,0xfa,0xff,0x00,0x01,  \
    0xed,0xff,0x00,0x01,0xe0,0xff,0x00,0x01,0xd3,0xff,0x00,0x01,0xc6,0xff,0x00,0x01,0xb9,0xff,0x00,0x01,0xac,0xff,0x00,0x01,0x9f,0xff,0x00,0x01,0x92,0xff,0x00,0x01,0x86,0xff,0x00,0x01,0x79,0xff,0xff,0x00,0x6c,0xff,0xff,0x00,0x5f,0xff,0xff,0x00,0x52,0xff,0xfe,0x00,0x45,0xff,0xfe,0x00,0x38,0xff,0xfe,0x00,0x2b,0xff,0xfd,0x00,0x1e,0xff,0xfd,0x00,0x11,0xff,0xfc,0x00,0x04,0xff,0xfb,0x00,0xf7,0xfe,0xfb,0x00,0xea,0xfe,0xfa,0x00,0xdc,0xfe,0xfa,0x00,0xcf,0xfe,  \
    0xf9,0x00,0xc2,0xfe,0xf8,0x00,0xb5,0xfe,0xf7,0x00,0xa8,0xfe,0xf6,0x00,0x9b,0xfe,0xf5,0x00,0x8e,0xfe,0xf5,0x00,0x80,0xfe,0xf4,0x00,0x73,0xfe,0xf3,0x00,0x66,0xfe,0xf2,0x00,0x59,0xfe,0xf0,0x00,0x4c,0xfe,0xef,0x00,0x3f,0xfe,0xee,0x00,0x33,0xfe,0xed,0x00,0x26,0xfe,0xec,0x00,0x19,0xfe,0xea,0x00,0x0c,0xfe,0xe9,0x00,0xff,0xfd,0xe8,0x00,0xf3,0xfd,0xe6,0x00,0xe6,0xfd,0xe5,0x00,0xd9,0xfd,0xe3,0x00,0xcc,0xfd,0xe2,0x00,0xbf,0xfd,0xe0,0x00,0xb3,0xfd,0xde,0x00,  \
    0xa6,0xfd,0xdd,0x00,0x99,0xfd,0xdb,0x00,0x8c,0xfd,0xd9,0x00,0x80,0xfd,0xd7,0x00,0x73,0xfd,0xd6,0x00,0x66,0xfd,0xd4,0x00,0x59,0xfd,0xd2,0x00,0x4c,0xfd,0xd0,0x00,0x40,0xfd,0xce,0x00,0x33,0xfd,0xcc,0x00,0x26,0xfd,0xca,0x00,0x19,0xfd,0xc8,0x00,0x0c,0xfd,0xc5,0x00,0xff,0xfc,0xc3,0x00,0xf2,0xfc,0xc1,0x00,0xe4,0xfc,0xbf,0x00,0xd6,0xfc,0xbd,0x00,0xc8,0xfc,0xba,0x00,0xbb,0xfc,0xb8,0x00,0xad,0xfc,0xb6,0x00,0x9f,0xfc,0xb3,0x00,0x91,0xfc,0xb1,0x00,0x83,0xfc,  \
    0xaf,0x00,0x75,0xfc,0xac,0x00,0x67,0xfc,0xaa,0x00,0x59,0xfc,0xa7,0x00,0x4b,0xfc,0xa4,0x00,0x3d,0xfc,0xa2,0x00,0x2f,0xfc,0x9f,0x00,0x20,0xfc,0x9d,0x00,0x12,0xfc,0x9a,0x00,0x04,0xfc,0x97,0x00,0xf6,0xfb,0x94,0x00,0xe7,0xfb,0x92,0x00,0xd9,0xfb,0x8f,0x00,0xca,0xfb,0x8c,0x00,0xbc,0xfb,0x89,0x00,0xad,0xfb,0x86,0x00,0x9f,0xfb,0x83,0x00,0x90,0xfb,0x80,0x00,0x82,0xfb,0x7d,0x00,0x73,0xfb,0x7a,0x00,0x65,0xfb,0x77,0x00,0x57,0xfb,0x73,0x00,0x48,0xfb,0x70,0x00,  \
    0x3a,0xfb,0x6d,0x00,0x2b,0xfb,0x6a,0x00,0x1d,0xfb,0x66,0x00,0x0e,0xfb,0x63,0x00,0x00,0xfb,0x5f,0x00,0xf1,0xfa,0x5c,0x00,0xe2,0xfa,0x58,0x00,0xd4,0xfa,0x55,0x00,0xc5,0xfa,0x51,0x00,0xb6,0xfa,0x4e,0x00,0xa7,0xfa,0x4a,0x00,0x98,0xfa,0x47,0x00,0x89,0xfa,0x43,0x00,0x7a,0xfa,0x3f,0x00,0x6b,0xfa,0x3b,0x00,0x5c,0xfa,0x38,0x00,0x4d,0xfa,0x34,0x00,0x3e,0xfa,0x30,0x00,0x2f,0xfa,0x2c,0x00,0x20,0xfa,0x28,0x00,0x10,0xfa,0x24,0x00,0x01,0xfa,0x20,0x00,0xf2,0xf9,  \
    0x1c,0x00,0xe3,0xf9,0x18,0x00,0xd3,0xf9,0x14,0x00,0xc4,0xf9,0x10,0x00,0xb4,0xf9,0x0c,0x00,0xa5,0xf9,0x08,0x00,0x95,0xf9,0x04,0x00,0x85,0xf9,0xff,0xff,0x76,0xf9,0xfb,0xff,0x66,0xf9,0xf7,0xff,0x56,0xf9,0xf2,0xff,0x46,0xf9,0xee,0xff,0x36,0xf9,0xea,0xff,0x26,0xf9,0xe5,0xff,0x16,0xf9,0xe1,0xff,0x06,0xf9,0xdc,0xff,0xf6,0xf8,0xd8,0xff,0xe6,0xf8,0xd4,0xff,0xd6,0xf8,0xcf,0xff,0xc5,0xf8,0xca,0xff,0xb5,0xf8,0xc6,0xff,0xa4,0xf8,0xc1,0xff,0x94,0xf8,0xbd,0xff,  \
    0x83,0xf8,0xb8,0xff,0x73,0xf8,0xb3,0xff,0x62,0xf8,0xaf,0xff,0x51,0xf8,0xaa,0xff,0x40,0xf8,0xa5,0xff,0x2f,0xf8,0xa0,0xff,0x1e,0xf8,0x9c,0xff,0x0d,0xf8,0x97,0xff,0xfc,0xf7,0x92,0xff,0xeb,0xf7,0x8d,0xff,0xd9,0xf7,0x88,0xff,0xc8,0xf7,0x83,0xff,0xb7,0xf7,0x7f,0xff,0xa5,0xf7,0x7a,0xff,0x93,0xf7,0x75,0xff,0x82,0xf7,0x70,0xff,0x70,0xf7,0x6b,0xff,0x5e,0xf7,0x66,0xff,0x4c,0xf7,0x61,0xff,0x3a,0xf7,0x5c,0xff,0x28,0xf7,0x57,0xff,0x16,0xf7,0x52,0xff,0x04,0xf7,  \
    0x4d,0xff,0xf1,0xf6,0x48,0xff,0xdf,0xf6,0x43,0xff,0xcd,0xf6,0x3e,0xff,0xba,0xf6,0x39,0xff,0xa7,0xf6,0x34,0xff,0x94,0xf6,0x2e,0xff,0x82,0xf6,0x29,0xff,0x6f,0xf6,0x24,0xff,0x5c,0xf6,0x1f,0xff,0x49,0xf6,0x1a,0xff,0x35,0xf6,0x15,0xff,0x22,0xf6,0x10,0xff,0x0f,0xf6,0x0b,0xff,0xfb,0xf5,0x06,0xff,0xe7,0xf5,0x00,0xff,0xd4,0xf5,0xfb,0xfe,0xc0,0xf5,0xf6,0xfe,0xac,0xf5,0xf1,0xfe,0x98,0xf5,0xec,0xfe,0x83,0xf5,0xe7,0xfe,0x6f,0xf5,0xe2,0xfe,0x5b,0xf5,0xdd,0xfe,  \
    0x46,0xf5,0xd8,0xfe,0x31,0xf5,0xd3,0xfe,0x1d,0xf5,0xce,0xfe,0x08,0xf5,0xc9,0xfe,0xf3,0xf4,0xc4,0xfe,0xde,0xf4,0xbf,0xfe,0xc8,0xf4,0xba,0xfe,0xb3,0xf4,0xb6,0xfe,0x9e,0xf4,0xb1,0xfe,0x88,0xf4,0xac,0xfe,0x73,0xf4,0xa7,0xfe,0x5d,0xf4,0xa2,0xfe,0x47,0xf4,0x9d,0xfe,0x31,0xf4,0x98,0xfe,0x1c,0xf4,0x93,0xfe,0x05,0xf4,0x8e,0xfe,0xef,0xf3,0x8a,0xfe,0xd9,0xf3,0x85,0xfe,0xc3,0xf3,0x80,0xfe,0xac,0xf3,0x7b,0xfe,0x96,0xf3,0x77,0xfe,0x7f,0xf3,0x72,0xfe,0x68,0xf3,  \
    0x6d,0xfe,0x51,0xf3,0x69,0xfe,0x3a,0xf3,0x64,0xfe,0x23,0xf3,0x60,0xfe,0x0b,0xf3,0x5b,0xfe,0xf4,0xf2,0x57,0xfe,0xdc,0xf2,0x52,0xfe,0xc5,0xf2,0x4e,0xfe,0xad,0xf2,0x4a,0xfe,0x95,0xf2,0x45,0xfe,0x7d,0xf2,0x41,0xfe,0x64,0xf2,0x3d,0xfe,0x4c,0xf2,0x39,0xfe,0x33,0xf2,0x35,0xfe,0x1b,0xf2,0x31,0xfe,0x02,0xf2,0x2d,0xfe,0xe9,0xf1,0x29,0xfe,0xd0,0xf1,0x25,0xfe,0xb6,0xf1,0x21,0xfe,0x9d,0xf1,0x1e,0xfe,0x84,0xf1,0x1a,0xfe,0x6a,0xf1,0x16,0xfe,0x50,0xf1,0x13,0xfe,  \
    0x36,0xf1,0x0f,0xfe,0x1c,0xf1,0x0c,0xfe,0x02,0xf1,0x08,0xfe,0xe8,0xf0,0x05,0xfe,0xcd,0xf0,0x02,0xfe,0xb3,0xf0,0xff,0xfd,0x98,0xf0,0xfb,0xfd,0x7e,0xf0,0xf8,0xfd,0x63,0xf0,0xf5,0xfd,0x48,0xf0,0xf2,0xfd,0x2d,0xf0,0xef,0xfd,0x11,0xf0,0xed,0xfd,0xf6,0xef,0xea,0xfd,0xdb,0xef,0xe7,0xfd,0xbf,0xef,0xe5,0xfd,0xa3,0xef,0xe2,0xfd,0x87,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa1,0xfd,0x7e,0x10,0xa4,0xfd,0x62,0x10,0xa7,0xfd,0x46,0x10,0xa9,0xfd,0x2a,0x10,0xac,0xfd,0x0e,0x10,0xaf,0xfd,0xf2,0x0f,0xb2,0xfd,0xd7,0x0f,0xb5,0xfd,0xbb,0x0f,0xb8,0xfd,0xa0,0x0f,0xbb,0xfd,0x85,0x0f,0xbf,0xfd,0x6a,0x0f,0xc2,0xfd,0x4f,0x0f,0xc5,0xfd,0x34,0x0f,0xc9,0xfd,  \
    0x19,0x0f,0xcc,0xfd,0xff,0x0e,0xd0,0xfd,0xe4,0x0e,0xd4,0xfd,0xca,0x0e,0xd8,0xfd,0xb0,0x0e,0xdb,0xfd,0x96,0x0e,0xdf,0xfd,0x7c,0x0e,0xe3,0xfd,0x62,0x0e,0xe7,0xfd,0x48,0x0e,0xeb,0xfd,0x2f,0x0e,0xef,0xfd,0x15,0x0e,0xf3,0xfd,0xfc,0x0d,0xf7,0xfd,0xe2,0x0d,0xfb,0xfd,0xc9,0x0d,0x00,0xfe,0xb0,0x0d,0x04,0xfe,0x97,0x0d,0x08,0xfe,0x7e,0x0d,0x0d,0xfe,0x66,0x0d,0x11,0xfe,0x4d,0x0d,0x15,0xfe,0x35,0x0d,0x1a,0xfe,0x1c,0x0d,0x1f,0xfe,0x04,0x0d,0x23,0xfe,0xec,0x0c,  \
    0x28,0xfe,0xd4,0x0c,0x2c,0xfe,0xbc,0x0c,0x31,0xfe,0xa4,0x0c,0x36,0xfe,0x8d,0x0c,0x3b,0xfe,0x76,0x0c,0x40,0xfe,0x5f,0x0c,0x45,0xfe,0x48,0x0c,0x4b,0xfe,0x32,0x0c,0x50,0xfe,0x1c,0x0c,0x55,0xfe,0x06,0x0c,0x5b,0xfe,0xf0,0x0b,0x60,0xfe,0xda,0x0b,0x66,0xfe,0xc4,0x0b,0x6b,0xfe,0xaf,0x0b,0x71,0xfe,0x99,0x0b,0x76,0xfe,0x84,0x0b,0x7c,0xfe,0x6f,0x0b,0x82,0xfe,0x5a,0x0b,0x87,0xfe,0x45,0x0b,0x8d,0xfe,0x30,0x0b,0x92,0xfe,0x1b,0x0b,0x98,0xfe,0x07,0x0b,0x9d,0xfe,  \
    0xf1,0x0a,0xa3,0xfe,0xdc,0x0a,0xa8,0xfe,0xc7,0x0a,0xad,0xfe,0xb2,0x0a,0xb2,0xfe,0x9d,0x0a,0xb8,0xfe,0x88,0x0a,0xbd,0xfe,0x73,0x0a,0xc2,0xfe,0x5e,0x0a,0xc8,0xfe,0x4a,0x0a,0xcd,0xfe,0x35,0x0a,0xd2,0xfe,0x21,0x0a,0xd8,0xfe,0x0d,0x0a,0xdd,0xfe,0xf8,0x09,0xe2,0xfe,0xe4,0x09,0xe7,0xfe,0xd0,0x09,0xed,0xfe,0xbc,0x09,0xf2,0xfe,0xa9,0x09,0xf7,0xfe,0x95,0x09,0xfd,0xfe,0x81,0x09,0x02,0xff,0x6e,0x09,0x07,0xff,0x5a,0x09,0x0d,0xff,0x47,0x09,0x12,0xff,0x34,0x09,  \
    0x17,0xff,0x21,0x09,0x1d,0xff,0x0d,0x09,0x22,0xff,0xfa,0x08,0x27,0xff,0xe7,0x08,0x2c,0xff,0xd5,0x08,0x32,0xff,0xc2,0x08,0x37,0xff,0xaf,0x08,0x3c,0xff,0x9d,0x08,0x41,0xff,0x8a,0x08,0x46,0xff,0x78,0x08,0x4c,0xff,0x65,0x08,0x51,0xff,0x53,0x08,0x56,0xff,0x41,0x08,0x5b,0xff,0x2f,0x08,0x60,0xff,0x1d,0x08,0x66,0xff,0x0c,0x08,0x6b,0xff,0xfa,0x07,0x70,0xff,0xe9,0x07,0x75,0xff,0xd7,0x07,0x7a,0xff,0xc6,0x07,0x7f,0xff,0xb5,0x07,0x84,0xff,0xa3,0x07,0x8a,0xff,  \
    0x92,0x07,0x8f,0xff,0x81,0x07,0x94,0xff,0x70,0x07,0x99,0xff,0x5f,0x07,0x9e,0xff,0x4f,0x07,0xa3,0xff,0x3e,0x07,0xa8,0xff,0x2d,0x07,0xac,0xff,0x1c,0x07,0xb1,0xff,0x0c,0x07,0xb6,0xff,0xfb,0x06,0xbb,0xff,0xeb,0x06,0xc0,0xff,0xda,0x06,0xc4,0xff,0xca,0x06,0xc9,0xff,0xba,0x06,0xce,0xff,0xa9,0x06,0xd3,0xff,0x99,0x06,0xd7,0xff,0x89,0x06,0xdc,0xff,0x79,0x06,0xe0,0xff,0x69,0x06,0xe5,0xff,0x59,0x06,0xe9,0xff,0x49,0x06,0xee,0xff,0x39,0x06,0xf2,0xff,0x29,0x06,  \
    0xf7,0xff,0x19,0x06,0xfb,0xff,0x09,0x06,0x00,0x00,0xfa,0x05,0x04,0x00,0xea,0x05,0x08,0x00,0xdb,0x05,0x0c,0x00,0xcb,0x05,0x11,0x00,0xbc,0x05,0x15,0x00,0xac,0x05,0x19,0x00,0x9d,0x05,0x1d,0x00,0x8d,0x05,0x21,0x00,0x7e,0x05,0x25,0x00,0x6e,0x05,0x29,0x00,0x5f,0x05,0x2d,0x00,0x4f,0x05,0x31,0x00,0x3f,0x05,0x35,0x00,0x30,0x05,0x39,0x00,0x20,0x05,0x3c,0x00,0x11,0x05,0x40,0x00,0x02,0x05,0x44,0x00,0xf2,0x04,0x47,0x00,0xe3,0x04,0x4b,0x00,0xd4,0x04,0x4f,0x00,  \
    0xc4,0x04,0x52,0x00,0xb5,0x04,0x56,0x00,0xa6,0x04,0x59,0x00,0x97,0x04,0x5d,0x00,0x88,0x04,0x60,0x00,0x79,0x04,0x64,0x00,0x6a,0x04,0x67,0x00,0x5b,0x04,0x6a,0x00,0x4c,0x04,0x6e,0x00,0x3d,0x04,0x71,0x00,0x2f,0x04,0x74,0x00,0x20,0x04,0x77,0x00,0x11,0x04,0x7b,0x00,0x03,0x04,0x7e,0x00,0xf4,0x03,0x81,0x00,0xe6,0x03,0x84,0x00,0xd8,0x03,0x87,0x00,0xca,0x03,0x8a,0x00,0xbb,0x03,0x8d,0x00,0xad,0x03,0x90,0x00,0x9f,0x03,0x93,0x00,0x91,0x03,0x96,0x00,0x83,0x03,  \
    0x99,0x00,0x75,0x03,0x9c,0x00,0x67,0x03,0x9e,0x00,0x59,0x03,0xa1,0x00,0x4b,0x03,0xa4,0x00,0x3d,0x03,0xa7,0x00,0x2f,0x03,0xa9,0x00,0x21,0x03,0xac,0x00,0x13,0x03,0xae,0x00,0x06,0x03,0xb1,0x00,0xf8,0x02,0xb3,0x00,0xea,0x02,0xb6,0x00,0xdc,0x02,0xb8,0x00,0xcf,0x02,0xba,0x00,0xc1,0x02,0xbd,0x00,0xb3,0x02,0xbf,0x00,0xa6,0x02,0xc1,0x00,0x98,0x02,0xc4,0x00,0x8b,0x02,0xc6,0x00,0x7d,0x02,0xc8,0x00,0x70,0x02,0xca,0x00,0x62,0x02,0xcc,0x00,0x55,0x02,0xce,0x00,  \
    0x48,0x02,0xd0,0x00,0x3a,0x02,0xd2,0x00,0x2d,0x02,0xd4,0x00,0x20,0x02,0xd6,0x00,0x12,0x02,0xd8,0x00,0x05,0x02,0xd9,0x00,0xf8,0x01,0xdb,0x00,0xeb,0x01,0xdd,0x00,0xdd,0x01,0xde,0x00,0xd0,0x01,0xe0,0x00,0xc3,0x01,0xe2,0x00,0xb6,0x01,0xe3,0x00,0xa9,0x01,0xe5,0x00,0x9b,0x01,0xe6,0x00,0x8e,0x01,0xe8,0x00,0x81,0x01,0xe9,0x00,0x74,0x01,0xea,0x00,0x67,0x01,0xec,0x00,0x5a,0x01,0xed,0x00,0x4d,0x01,0xee,0x00,0x40,0x01,0xef,0x00,0x32,0x01,0xf0,0x00,0x25,0x01,  \
    0xf1,0x00,0x18,0x01,0xf2,0x00,0x0b,0x01,0xf3,0x00,0xfe,0x00,0xf4,0x00,0xf1,0x00,0xf5,0x00,0xe4,0x00,0xf6,0x00,0xd7,0x00,0xf7,0x00,0xca,0x00,0xf8,0x00,0xbd,0x00,0xf9,0x00,0xb0,0x00,0xf9,0x00,0xa3,0x00,0xfa,0x00,0x96,0x00,0xfb,0x00,0x89,0x00,0xfb,0x00,0x7c,0x00,0xfc,0x00,0x6f,0x00,0xfc,0x00,0x62,0x00,0xfd,0x00,0x55,0x00,0xfd,0x00,0x48,0x00,0xfe,0x00,0x3b,0x00,0xfe,0x00,0x2e,0x00,0xfe,0x00,0x21,0x00,0xff,0x00,0x14,0x00,0xff,0x00,0x07,0x00,0xff,0x00,  \
    0xfa,0xff,0xff,0x00,0xed,0xff,0xff,0x00,0xe0,0xff,0xff,0x00,0xd3,0xff,0xff,0x00,0xc6,0xff,0xff,0x00,0xb9,0xff,0xff,0x00,0xac,0xff,0xff,0x00,0x9f,0xff,0xff,0x00,0x92,0xff,0xff,0x00,0x85,0xff,0xff,0x00,0x78,0xff,0xff,0x00,0x6b,0xff,0xfe,0x00,0x5e,0xff,0xfe,0x00,0x51,0xff,0xfe,0x00,0x44,0xff,0xfd,0x00,0x37,0xff,0xfd,0x00,0x2a,0xff,0xfc,0x00,0x1d,0xff,0xfc,0x00,0x10,0xff,0xfb,0x00,0x03,0xff,0xfb,0x00,0xf5,0xfe,0xfa,0x00,0xe8,0xfe,0xf9,0x00,0xdb,0xfe,  \
    0xf9,0x00,0xce,0xfe,0xf8,0x00,0xc1,0xfe,0xf7,0x00,0xb3,0xfe,0xf6,0x00,0xa6,0xfe,0xf5,0x00,0x99,0xfe,0xf5,0x00,0x8c,0xfe,0xf4,0x00,0x7e,0xfe,0xf3,0x00,0x71,0xfe,0xf2,0x00,0x64,0xfe,0xf1,0x00,0x57,0xfe,0xf0,0x00,0x4a,0xfe,0xee,0x00,0x3d,0xfe,0xed,0x00,0x30,0xfe,0xec,0x00,0x23,0xfe,0xeb,0x00,0x16,0xfe,0xe9,0x00,0x09,0xfe,0xe8,0x00,0xfd,0xfd,0xe7,0x00,0xf0,0xfd,0xe5,0x00,0xe3,0xfd,0xe4,0x00,0xd6,0xfd,0xe2,0x00,0xc9,0xfd,0xe1,0x00,0xbc,0xfd,0xdf,0x00,  \
    0xb0,0xfd,0xdd,0x00,0xa3,0xfd,0xdc,0x00,0x96,0xfd,0xda,0x00,0x89,0xfd,0xd8,0x00,0x7c,0xfd,0xd6,0x00,0x6f,0xfd,0xd4,0x00,0x63,0xfd,0xd3,0x00,0x56,0xfd,0xd1,0x00,0x49,0xfd,0xcf,0x00,0x3c,0xfd,0xcd,0x00,0x2f,0xfd,0xcb,0x00,0x22,0xfd,0xc8,0x00,0x15,0xfd,0xc6,0x00,0x08,0xfd,0xc4,0x00,0xfc,0xfc,0xc2,0x00,0xee,0xfc,0xc0,0x00,0xe0,0xfc,0xbe,0x00,0xd2,0xfc,0xbb,0x00,0xc4,0xfc,0xb9,0x00,0xb6,0xfc,0xb7,0x00,0xa9,0xfc,0xb4,0x00,0x9b,0xfc,0xb2,0x00,0x8d,0xfc,  \
    0xb0,0x00,0x7f,0xfc,0xad,0x00,0x71,0xfc,0xab,0x00,0x62,0xfc,0xa8,0x00,0x54,0xfc,0xa6,0x00,0x46,0xfc,0xa3,0x00,0x38,0xfc,0xa0,0x00,0x2a,0xfc,0x9e,0x00,0x1b,0xfc,0x9b,0x00,0x0d,0xfc,0x98,0x00,0xff,0xfb,0x96,0x00,0xf0,0xfb,0x93,0x00,0xe2,0xfb,0x90,0x00,0xd3,0xfb,0x8d,0x00,0xc5,0xfb,0x8a,0x00,0xb6,0xfb,0x87,0x00,0xa8,0xfb,0x84,0x00,0x99,0xfb,0x81,0x00,0x8a,0xfb,0x7e,0x00,0x7c,0xfb,0x7b,0x00,0x6d,0xfb,0x78,0x00,0x5f,0xfb,0x75,0x00,0x51,0xfb,0x72,0x00,  \
    0x42,0xfb,0x6e,0x00,0x34,0xfb,0x6b,0x00,0x25,0xfb,0x68,0x00,0x17,0xfb,0x64,0x00,0x08,0xfb,0x61,0x00,0xf9,0xfa,0x5d,0x00,0xeb,0xfa,0x5a,0x00,0xdc,0xfa,0x56,0x00,0xcd,0xfa,0x53,0x00,0xbe,0xfa,0x4f,0x00,0xb0,0xfa,0x4c,0x00,0xa1,0xfa,0x48,0x00,0x92,0xfa,0x44,0x00,0x83,0xfa,0x41,0x00,0x74,0xfa,0x3d,0x00,0x65,0xfa,0x39,0x00,0x56,0xfa,0x35,0x00,0x46,0xfa,0x32,0x00,0x37,0xfa,0x2e,0x00,0x28,0xfa,0x2a,0x00,0x19,0xfa,0x26,0x00,0x0a,0xfa,0x22,0x00,0xfa,0xf9,  \
    0x1e,0x00,0xeb,0xf9,0x1a,0x00,0xdc,0xf9,0x16,0x00,0xcc,0xf9,0x12,0x00,0xbd,0xf9,0x0d,0x00,0xad,0xf9,0x09,0x00,0x9e,0xf9,0x05,0x00,0x8e,0xf9,0x01,0x00,0x7e,0xf9,0xfd,0xff,0x6f,0xf9,0xf8,0xff,0x5f,0xf9,0xf4,0xff,0x4f,0xf9,0xf0,0xff,0x3f,0xf9,0xeb,0xff,0x2f,0xf9,0xe7,0xff,0x1f,0xf9,0xe2,0xff,0x0f,0xf9,0xde,0xff,0xff,0xf8,0xd9,0xff,0xef,0xf8,0xd5,0xff,0xdf,0xf8,0xd0,0xff,0xce,0xf8,0xcc,0xff,0xbe,0xf8,0xc7,0xff,0xae,0xf8,0xc3,0xff,0x9d,0xf8,0xbe,0xff,  \
    0x8d,0xf8,0xb9,0xff,0x7c,0xf8,0xb5,0xff,0x6b,0xf8,0xb0,0xff,0x5a,0xf8,0xab,0xff,0x4a,0xf8,0xa6,0xff,0x39,0xf8,0xa2,0xff,0x28,0xf8,0x9d,0xff,0x17,0xf8,0x98,0xff,0x06,0xf8,0x93,0xff,0xf5,0xf7,0x8e,0xff,0xe3,0xf7,0x89,0xff,0xd2,0xf7,0x85,0xff,0xc1,0xf7,0x80,0xff,0xaf,0xf7,0x7b,0xff,0x9e,0xf7,0x76,0xff,0x8c,0xf7,0x71,0xff,0x7a,0xf7,0x6c,0xff,0x69,0xf7,0x67,0xff,0x57,0xf7,0x62,0xff,0x45,0xf7,0x5d,0xff,0x33,0xf7,0x58,0xff,0x21,0xf7,0x53,0xff,0x0f,0xf7,  \
    0x4d,0xff,0xfc,0xf6,0x48,0xff,0xea,0xf6,0x43,0xff,0xd8,0xf6,0x3e,0xff,0xc5,0xf6,0x39,0xff,0xb3,0xf6,0x34,0xff,0xa0,0xf6,0x2f,0xff,0x8d,0xf6,0x2a,0xff,0x7a,0xf6,0x25,0xff,0x67,0xf6,0x1f,0xff,0x54,0xf6,0x1a,0xff,0x41,0xf6,0x15,0xff,0x2e,0xf6,0x10,0xff,0x1b,0xf6,0x0b,0xff,0x07,0xf6,0x06,0xff,0xf4,0xf5,0x00,0xff,0xe0,0xf5,0xfb,0xfe,0xcd,0xf5,0xf6,0xfe,0xb9,0xf5,0xf1,0xfe,0xa5,0xf5,0xec,0xfe,0x91,0xf5,0xe7,0xfe,0x7c,0xf5,0xe2,0xfe,0x68,0xf5,0xdd,0xfe,  \
    0x53,0xf5,0xd8,0xfe,0x3f,0xf5,0xd3,0xfe,0x2a,0xf5,0xce,0xfe,0x16,0xf5,0xc8,0xfe,0x01,0xf5,0xc3,0xfe,0xec,0xf4,0xbe,0xfe,0xd7,0xf4,0xb9,0xfe,0xc2,0xf4,0xb4,0xfe,0xac,0xf4,0xaf,0xfe,0x97,0xf4,0xaa,0xfe,0x81,0xf4,0xa5,0xfe,0x6c,0xf4,0xa1,0xfe,0x56,0xf4,0x9c,0xfe,0x40,0xf4,0x97,0xfe,0x2b,0xf4,0x92,0xfe,0x15,0xf4,0x8d,0xfe,0xff,0xf3,0x88,0xfe,0xe9,0xf3,0x83,0xfe,0xd2,0xf3,0x7e,0xfe,0xbc,0xf3,0x79,0xfe,0xa6,0xf3,0x75,0xfe,0x8f,0xf3,0x70,0xfe,0x78,0xf3,  \
    0x6b,0xfe,0x61,0xf3,0x66,0xfe,0x4a,0xf3,0x62,0xfe,0x33,0xf3,0x5d,0xfe,0x1c,0xf3,0x58,0xfe,0x05,0xf3,0x54,0xfe,0xed,0xf2,0x4f,0xfe,0xd6,0xf2,0x4b,0xfe,0xbe,0xf2,0x46,0xfe,0xa6,0xf2,0x42,0xfe,0x8e,0xf2,0x3e,0xfe,0x76,0xf2,0x3a,0xfe,0x5e,0xf2,0x35,0xfe,0x45,0xf2,0x31,0xfe,0x2d,0xf2,0x2d,0xfe,0x14,0xf2,0x29,0xfe,0xfb,0xf1,0x25,0xfe,0xe2,0xf1,0x21,0xfe,0xc9,0xf1,0x1d,0xfe,0xb0,0xf1,0x19,0xfe,0x97,0xf1,0x16,0xfe,0x7d,0xf1,0x12,0xfe,0x64,0xf1,0x0e,0xfe,  \
    0x4a,0xf1,0x0b,0xfe,0x30,0xf1,0x07,0xfe,0x16,0xf1,0x04,0xfe,0xfc,0xf0,0x00,0xfe,0xe2,0xf0,0xfd,0xfd,0xc7,0xf0,0xfa,0xfd,0xad,0xf0,0xf6,0xfd,0x92,0xf0,0xf3,0xfd,0x78,0xf0,0xf0,0xfd,0x5d,0xf0,0xed,0xfd,0x42,0xf0,0xea,0xfd,0x27,0xf0,0xe7,0xfd,0x0c,0xf0,0xe4,0xfd,0xf0,0xef,0xe1,0xfd,0xd5,0xef,0xdf,0xfd,0xb9,0xef,0xdc,0xfd,0x9d,0xef,0xd9,0xfd,0x81,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x95,0xfd,0x83,0x10,0x97,0xfd,0x67,0x10,0x9a,0xfd,0x4b,0x10,0x9d,0xfd,0x2f,0x10,0xa0,0xfd,0x13,0x10,0xa3,0xfd,0xf7,0x0f,0xa6,0xfd,0xdc,0x0f,0xa9,0xfd,0xc0,0x0f,0xac,0xfd,0xa5,0x0f,0xaf,0xfd,0x8a,0x0f,0xb3,0xfd,0x6f,0x0f,0xb6,0xfd,0x54,0x0f,0xb9,0xfd,  \
    0x39,0x0f,0xbd,0xfd,0x1e,0x0f,0xc1,0xfd,0x04,0x0f,0xc4,0xfd,0xe9,0x0e,0xc8,0xfd,0xcf,0x0e,0xcc,0xfd,0xb5,0x0e,0xd0,0xfd,0x9b,0x0e,0xd4,0xfd,0x81,0x0e,0xd8,0xfd,0x67,0x0e,0xdc,0xfd,0x4d,0x0e,0xe0,0xfd,0x34,0x0e,0xe4,0xfd,0x1a,0x0e,0xe8,0xfd,0x01,0x0e,0xec,0xfd,0xe8,0x0d,0xf0,0xfd,0xce,0x0d,0xf5,0xfd,0xb5,0x0d,0xf9,0xfd,0x9c,0x0d,0xfd,0xfd,0x84,0x0d,0x02,0xfe,0x6b,0x0d,0x06,0xfe,0x52,0x0d,0x0b,0xfe,0x3a,0x0d,0x0f,0xfe,0x22,0x0d,0x14,0xfe,0x09,0x0d,  \
    0x19,0xfe,0xf1,0x0c,0x1d,0xfe,0xd9,0x0c,0x22,0xfe,0xc1,0x0c,0x27,0xfe,0xaa,0x0c,0x2c,0xfe,0x92,0x0c,0x31,0xfe,0x7b,0x0c,0x36,0xfe,0x64,0x0c,0x3b,0xfe,0x4e,0x0c,0x41,0xfe,0x38,0x0c,0x46,0xfe,0x21,0x0c,0x4c,0xfe,0x0b,0x0c,0x51,0xfe,0xf6,0x0b,0x57,0xfe,0xe0,0x0b,0x5d,0xfe,0xca,0x0b,0x62,0xfe,0xb5,0x0b,0x68,0xfe,0x9f,0x0b,0x6d,0xfe,0x8a,0x0b,0x73,0xfe,0x75,0x0b,0x79,0xfe,0x60,0x0b,0x7f,0xfe,0x4b,0x0b,0x84,0xfe,0x36,0x0b,0x8a,0xfe,0x22,0x0b,0x90,0xfe,  \
    0x0d,0x0b,0x95,0xfe,0xf8,0x0a,0x9a,0xfe,0xe2,0x0a,0xa0,0xfe,0xcd,0x0a,0xa5,0xfe,0xb8,0x0a,0xaa,0xfe,0xa3,0x0a,0xb0,0xfe,0x8e,0x0a,0xb5,0xfe,0x7a,0x0a,0xbb,0xfe,0x65,0x0a,0xc0,0xfe,0x50,0x0a,0xc5,0xfe,0x3c,0x0a,0xcb,0xfe,0x28,0x0a,0xd0,0xfe,0x13,0x0a,0xd6,0xfe,0xff,0x09,0xdb,0xfe,0xeb,0x09,0xe0,0xfe,0xd7,0x09,0xe6,0xfe,0xc3,0x09,0xeb,0xfe,0xaf,0x09,0xf0,0xfe,0x9c,0x09,0xf6,0xfe,0x88,0x09,0xfb,0xfe,0x74,0x09,0x01,0xff,0x61,0x09,0x06,0xff,0x4e,0x09,  \
    0x0b,0xff,0x3a,0x09,0x11,0xff,0x27,0x09,0x16,0xff,0x14,0x09,0x1b,0xff,0x01,0x09,0x21,0xff,0xee,0x08,0x26,0xff,0xdb,0x08,0x2b,0xff,0xc9,0x08,0x31,0xff,0xb6,0x08,0x36,0xff,0xa3,0x08,0x3b,0xff,0x91,0x08,0x41,0xff,0x7f,0x08,0x46,0xff,0x6c,0x08,0x4b,0xff,0x5a,0x08,0x50,0xff,0x48,0x08,0x56,0xff,0x36,0x08,0x5b,0xff,0x24,0x08,0x60,0xff,0x13,0x08,0x65,0xff,0x01,0x08,0x6b,0xff,0xf0,0x07,0x70,0xff,0xde,0x07,0x75,0xff,0xcd,0x07,0x7a,0xff,0xbc,0x07,0x7f,0xff,  \
    0xaa,0x07,0x85,0xff,0x99,0x07,0x8a,0xff,0x88,0x07,0x8f,0xff,0x77,0x07,0x94,0xff,0x66,0x07,0x99,0xff,0x56,0x07,0x9e,0xff,0x45,0x07,0xa3,0xff,0x34,0x07,0xa8,0xff,0x23,0x07,0xad,0xff,0x13,0x07,0xb2,0xff,0x02,0x07,0xb7,0xff,0xf2,0x06,0xbc,0xff,0xe1,0x06,0xc0,0xff,0xd1,0x06,0xc5,0xff,0xc1,0x06,0xca,0xff,0xb0,0x06,0xcf,0xff,0xa0,0x06,0xd3,0xff,0x90,0x06,0xd8,0xff,0x80,0x06,0xdd,0xff,0x70,0x06,0xe1,0xff,0x60,0x06,0xe6,0xff,0x50,0x06,0xea,0xff,0x40,0x06,  \
    0xef,0xff,0x30,0x06,0xf3,0xff,0x20,0x06,0xf8,0xff,0x10,0x06,0xfc,0xff,0x01,0x06,0x00,0x00,0xf1,0x05,0x05,0x00,0xe1,0x05,0x09,0x00,0xd2,0x05,0x0d,0x00,0xc2,0x05,0x12,0x00,0xb3,0x05,0x16,0x00,0xa4,0x05,0x1a,0x00,0x94,0x05,0x1e,0x00,0x85,0x05,0x22,0x00,0x75,0x05,0x26,0x00,0x65,0x05,0x2a,0x00,0x56,0x05,0x2e,0x00,0x46,0x05,0x32,0x00,0x36,0x05,0x36,0x00,0x27,0x05,0x39,0x00,0x17,0x05,0x3d,0x00,0x08,0x05,0x41,0x00,0xf9,0x04,0x45,0x00,0xe9,0x04,0x48,0x00,  \
    0xda,0x04,0x4c,0x00,0xcb,0x04,0x50,0x00,0xbb,0x04,0x53,0x00,0xac,0x04,0x57,0x00,0x9d,0x04,0x5a,0x00,0x8e,0x04,0x5e,0x00,0x7f,0x04,0x61,0x00,0x70,0x04,0x65,0x00,0x61,0x04,0x68,0x00,0x52,0x04,0x6b,0x00,0x43,0x04,0x6f,0x00,0x34,0x04,0x72,0x00,0x26,0x04,0x75,0x00,0x17,0x04,0x78,0x00,0x08,0x04,0x7c,0x00,0xfa,0x03,0x7f,0x00,0xec,0x03,0x82,0x00,0xdd,0x03,0x85,0x00,0xcf,0x03,0x88,0x00,0xc1,0x03,0x8b,0x00,0xb2,0x03,0x8e,0x00,0xa4,0x03,0x91,0x00,0x96,0x03,  \
    0x94,0x00,0x88,0x03,0x97,0x00,0x7a,0x03,0x9a,0x00,0x6c,0x03,0x9d,0x00,0x5e,0x03,0x9f,0x00,0x50,0x03,0xa2,0x00,0x42,0x03,0xa5,0x00,0x34,0x03,0xa7,0x00,0x26,0x03,0xaa,0x00,0x18,0x03,0xad,0x00,0x0a,0x03,0xaf,0x00,0xfc,0x02,0xb2,0x00,0xee,0x02,0xb4,0x00,0xe1,0x02,0xb6,0x00,0xd3,0x02,0xb9,0x00,0xc5,0x02,0xbb,0x00,0xb7,0x02,0xbd,0x00,0xaa,0x02,0xc0,0x00,0x9c,0x02,0xc2,0x00,0x8f,0x02,0xc4,0x00,0x81,0x02,0xc6,0x00,0x74,0x02,0xc8,0x00,0x66,0x02,0xcb,0x00,  \
    0x59,0x02,0xcd,0x00,0x4b,0x02,0xcf,0x00,0x3e,0x02,0xd1,0x00,0x31,0x02,0xd2,0x00,0x23,0x02,0xd4,0x00,0x16,0x02,0xd6,0x00,0x09,0x02,0xd8,0x00,0xfb,0x01,0xda,0x00,0xee,0x01,0xdb,0x00,0xe1,0x01,0xdd,0x00,0xd3,0x01,0xdf,0x00,0xc6,0x01,0xe0,0x00,0xb9,0x01,0xe2,0x00,0xac,0x01,0xe3,0x00,0x9e,0x01,0xe5,0x00,0x91,0x01,0xe6,0x00,0x84,0x01,0xe8,0x00,0x77,0x01,0xe9,0x00,0x69,0x01,0xea,0x00,0x5c,0x01,0xec,0x00,0x4f,0x01,0xed,0x00,0x42,0x01,0xee,0x00,0x35,0x01,  \
    0xef,0x00,0x27,0x01,0xf0,0x00,0x1a,0x01,0xf1,0x00,0x0d,0x01,0xf2,0x00,0x00,0x01,0xf3,0x00,0xf3,0x00,0xf4,0x00,0xe6,0x00,0xf5,0x00,0xd9,0x00,0xf6,0x00,0xcb,0x00,0xf7,0x00,0xbe,0x00,0xf8,0x00,0xb1,0x00,0xf8,0x00,0xa4,0x00,0xf9,0x00,0x97,0x00,0xfa,0x00,0x8a,0x00,0xfa,0x00,0x7d,0x00,0xfb,0x00,0x70,0x00,0xfb,0x00,0x63,0x00,0xfc,0x00,0x56,0x00,0xfc,0x00,0x49,0x00,0xfd,0x00,0x3b,0x00,0xfd,0x00,0x2e,0x00,0xfd,0x00,0x21,0x00,0xfe,0x00,0x14,0x00,0xfe,0x00,  \
    0x07,0x00,0xfe,0x00,0xfa,0xff,0xfe,0x00,0xed,0xff,0xfe,0x00,0xe0,0xff,0xfe,0x00,0xd3,0xff,0xfe,0x00,0xc6,0xff,0xfe,0x00,0xb9,0xff,0xfe,0x00,0xac,0xff,0xfe,0x00,0x9f,0xff,0xfe,0x00,0x92,0xff,0xfe,0x00,0x85,0xff,0xfe,0x00,0x78,0xff,0xfe,0x00,0x6b,0xff,0xfd,0x00,0x5d,0xff,0xfd,0x00,0x50,0xff,0xfd,0x00,0x43,0xff,0xfc,0x00,0x36,0xff,0xfc,0x00,0x29,0xff,0xfb,0x00,0x1c,0xff,0xfb,0x00,0x0e,0xff,0xfa,0x00,0x01,0xff,0xfa,0x00,0xf4,0xfe,0xf9,0x00,0xe7,0xfe,  \
    0xf8,0x00,0xda,0xfe,0xf8,0x00,0xcc,0xfe,0xf7,0x00,0xbf,0xfe,0xf6,0x00,0xb2,0xfe,0xf5,0x00,0xa4,0xfe,0xf4,0x00,0x97,0xfe,0xf4,0x00,0x8a,0xfe,0xf3,0x00,0x7c,0xfe,0xf2,0x00,0x6f,0xfe,0xf1,0x00,0x61,0xfe,0xf0,0x00,0x54,0xfe,0xee,0x00,0x47,0xfe,0xed,0x00,0x3a,0xfe,0xec,0x00,0x2d,0xfe,0xeb,0x00,0x21,0xfe,0xea,0x00,0x14,0xfe,0xe8,0x00,0x07,0xfe,0xe7,0x00,0xfa,0xfd,0xe5,0x00,0xed,0xfd,0xe4,0x00,0xe0,0xfd,0xe2,0x00,0xd3,0xfd,0xe1,0x00,0xc6,0xfd,0xdf,0x00,  \
    0xb9,0xfd,0xde,0x00,0xac,0xfd,0xdc,0x00,0x9f,0xfd,0xda,0x00,0x93,0xfd,0xd9,0x00,0x86,0xfd,0xd7,0x00,0x79,0xfd,0xd5,0x00,0x6c,0xfd,0xd3,0x00,0x5f,0xfd,0xd1,0x00,0x52,0xfd,0xcf,0x00,0x45,0xfd,0xcd,0x00,0x38,0xfd,0xcb,0x00,0x2b,0xfd,0xc9,0x00,0x1e,0xfd,0xc7,0x00,0x12,0xfd,0xc5,0x00,0x05,0xfd,0xc3,0x00,0xf8,0xfc,0xc1,0x00,0xea,0xfc,0xbe,0x00,0xdc,0xfc,0xbc,0x00,0xce,0xfc,0xba,0x00,0xc0,0xfc,0xb8,0x00,0xb2,0xfc,0xb5,0x00,0xa4,0xfc,0xb3,0x00,0x96,0xfc,  \
    0xb0,0x00,0x88,0xfc,0xae,0x00,0x7a,0xfc,0xac,0x00,0x6c,0xfc,0xa9,0x00,0x5e,0xfc,0xa7,0x00,0x50,0xfc,0xa4,0x00,0x41,0xfc,0xa1,0x00,0x33,0xfc,0x9f,0x00,0x25,0xfc,0x9c,0x00,0x16,0xfc,0x99,0x00,0x08,0xfc,0x97,0x00,0xf9,0xfb,0x94,0x00,0xeb,0xfb,0x91,0x00,0xdc,0xfb,0x8e,0x00,0xce,0xfb,0x8b,0x00,0xbf,0xfb,0x88,0x00,0xb1,0xfb,0x85,0x00,0xa2,0xfb,0x82,0x00,0x93,0xfb,0x7f,0x00,0x85,0xfb,0x7c,0x00,0x76,0xfb,0x79,0x00,0x68,0xfb,0x76,0x00,0x59,0xfb,0x73,0x00,  \
    0x4b,0xfb,0x70,0x00,0x3c,0xfb,0x6c,0x00,0x2e,0xfb,0x69,0x00,0x1f,0xfb,0x66,0x00,0x10,0xfb,0x62,0x00,0x02,0xfb,0x5f,0x00,0xf3,0xfa,0x5b,0x00,0xe4,0xfa,0x58,0x00,0xd6,0xfa,0x54,0x00,0xc7,0xfa,0x51,0x00,0xb8,0xfa,0x4d,0x00,0xa9,0xfa,0x4a,0x00,0x9a,0xfa,0x46,0x00,0x8b,0xfa,0x42,0x00,0x7c,0xfa,0x3e,0x00,0x6d,0xfa,0x3b,0x00,0x5e,0xfa,0x37,0x00,0x4f,0xfa,0x33,0x00,0x40,0xfa,0x2f,0x00,0x30,0xfa,0x2b,0x00,0x21,0xfa,0x27,0x00,0x12,0xfa,0x23,0x00,0x03,0xfa,  \
    0x1f,0x00,0xf3,0xf9,0x1b,0x00,0xe4,0xf9,0x17,0x00,0xd5,0xf9,0x13,0x00,0xc5,0xf9,0x0f,0x00,0xb6,0xf9,0x0b,0x00,0xa6,0xf9,0x07,0x00,0x96,0xf9,0x02,0x00,0x87,0xf9,0xfe,0xff,0x77,0xf9,0xfa,0xff,0x67,0xf9,0xf5,0xff,0x58,0xf9,0xf1,0xff,0x48,0xf9,0xed,0xff,0x38,0xf9,0xe8,0xff,0x28,0xf9,0xe4,0xff,0x18,0xf9,0xdf,0xff,0x08,0xf9,0xdb,0xff,0xf8,0xf8,0xd6,0xff,0xe8,0xf8,0xd2,0xff,0xd7,0xf8,0xcd,0xff,0xc7,0xf8,0xc9,0xff,0xb7,0xf8,0xc4,0xff,0xa6,0xf8,0xbf,0xff,  \
    0x96,0xf8,0xbb,0xff,0x85,0xf8,0xb6,0xff,0x74,0xf8,0xb1,0xff,0x64,0xf8,0xac,0xff,0x53,0xf8,0xa8,0xff,0x42,0xf8,0xa3,0xff,0x31,0xf8,0x9e,0xff,0x20,0xf8,0x99,0xff,0x0f,0xf8,0x94,0xff,0xfe,0xf7,0x8f,0xff,0xed,0xf7,0x8a,0xff,0xdc,0xf7,0x86,0xff,0xcb,0xf7,0x81,0xff,0xb9,0xf7,0x7c,0xff,0xa8,0xf7,0x77,0xff,0x96,0xf7,0x72,0xff,0x85,0xf7,0x6d,0xff,0x73,0xf7,0x68,0xff,0x61,0xf7,0x63,0xff,0x4f,0xf7,0x5d,0xff,0x3d,0xf7,0x58,0xff,0x2b,0xf7,0x53,0xff,0x19,0xf7,  \
    0x4e,0xff,0x07,0xf7,0x49,0xff,0xf5,0xf6,0x44,0xff,0xe3,0xf6,0x3f,0xff,0xd0,0xf6,0x3a,0xff,0xbe,0xf6,0x34,0xff,0xab,0xf6,0x2f,0xff,0x99,0xf6,0x2a,0xff,0x86,0xf6,0x25,0xff,0x73,0xf6,0x20,0xff,0x60,0xf6,0x1a,0xff,0x4d,0xf6,0x15,0xff,0x3a,0xf6,0x10,0xff,0x27,0xf6,0x0b,0xff,0x13,0xf6,0x06,0xff,0x00,0xf6,0x00,0xff,0xed,0xf5,0xfb,0xfe,0xd9,0xf5,0xf6,0xfe,0xc5,0xf5,0xf1,0xfe,0xb1,0xf5,0xec,0xfe,0x9d,0xf5,0xe6,0xfe,0x89,0xf5,0xe1,0xfe,0x75,0xf5,0xdc,0xfe,  \
    0x61,0xf5,0xd7,0xfe,0x4c,0xf5,0xd2,0xfe,0x38,0xf5,0xcd,0xfe,0x23,0xf5,0xc8,0xfe,0x0e,0xf5,0xc3,0xfe,0xfa,0xf4,0xbe,0xfe,0xe5,0xf4,0xb8,0xfe,0xd0,0xf4,0xb3,0xfe,0xba,0xf4,0xae,0xfe,0xa5,0xf4,0xa9,0xfe,0x90,0xf4,0xa4,0xfe,0x7a,0xf4,0x9f,0xfe,0x65,0xf4,0x9a,0xfe,0x4f,0xf4,0x95,0xfe,0x39,0xf4,0x90,0xfe,0x24,0xf4,0x8b,0xfe,0x0e,0xf4,0x86,0xfe,0xf8,0xf3,0x81,0xfe,0xe2,0xf3,0x7c,0xfe,0xcb,0xf3,0x78,0xfe,0xb5,0xf3,0x73,0xfe,0x9f,0xf3,0x6e,0xfe,0x88,0xf3,  \
    0x69,0xfe,0x71,0xf3,0x64,0xfe,0x5b,0xf3,0x5f,0xfe,0x44,0xf3,0x5b,0xfe,0x2d,0xf3,0x56,0xfe,0x16,0xf3,0x51,0xfe,0xfe,0xf2,0x4d,0xfe,0xe7,0xf2,0x48,0xfe,0xcf,0xf2,0x44,0xfe,0xb8,0xf2,0x3f,0xfe,0xa0,0xf2,0x3b,0xfe,0x88,0xf2,0x36,0xfe,0x70,0xf2,0x32,0xfe,0x57,0xf2,0x2e,0xfe,0x3f,0xf2,0x2a,0xfe,0x26,0xf2,0x26,0xfe,0x0e,0xf2,0x21,0xfe,0xf5,0xf1,0x1d,0xfe,0xdc,0xf1,0x19,0xfe,0xc3,0xf1,0x16,0xfe,0xaa,0xf1,0x12,0xfe,0x90,0xf1,0x0e,0xfe,0x77,0xf1,0x0a,0xfe,  \
    0x5d,0xf1,0x06,0xfe,0x44,0xf1,0x03,0xfe,0x2a,0xf1,0xff,0xfd,0x10,0xf1,0xfc,0xfd,0xf6,0xf0,0xf8,0xfd,0xdb,0xf0,0xf5,0xfd,0xc1,0xf0,0xf1,0xfd,0xa7,0xf0,0xee,0xfd,0x8c,0xf0,0xeb,0xfd,0x71,0xf0,0xe8,0xfd,0x57,0xf0,0xe5,0xfd,0x3c,0xf0,0xe1,0xfd,0x21,0xf0,0xde,0xfd,0x06,0xf0,0xdc,0xfd,0xea,0xef,0xd9,0xfd,0xcf,0xef,0xd6,0xfd,0xb3,0xef,0xd3,0xfd,0x97,0xef,0xd1,0xfd,0x7b,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x88,0xfd,0x88,0x10,0x8b,0xfd,0x6b,0x10,0x8e,0xfd,0x4f,0x10,0x90,0xfd,0x33,0x10,0x93,0xfd,0x18,0x10,0x96,0xfd,0xfc,0x0f,0x99,0xfd,0xe0,0x0f,0x9c,0xfd,0xc5,0x0f,0xa0,0xfd,0xaa,0x0f,0xa3,0xfd,0x8e,0x0f,0xa6,0xfd,0x73,0x0f,0xaa,0xfd,  \
    0x58,0x0f,0xad,0xfd,0x3e,0x0f,0xb1,0xfd,0x23,0x0f,0xb5,0xfd,0x09,0x0f,0xb8,0xfd,0xee,0x0e,0xbc,0xfd,0xd4,0x0e,0xc0,0xfd,0xba,0x0e,0xc4,0xfd,0xa0,0x0e,0xc8,0xfd,0x86,0x0e,0xcc,0xfd,0x6c,0x0e,0xd0,0xfd,0x52,0x0e,0xd4,0xfd,0x39,0x0e,0xd8,0xfd,0x1f,0x0e,0xdd,0xfd,0x06,0x0e,0xe1,0xfd,0xed,0x0d,0xe5,0xfd,0xd4,0x0d,0xea,0xfd,0xbb,0x0d,0xee,0xfd,0xa2,0x0d,0xf2,0xfd,0x89,0x0d,0xf7,0xfd,0x70,0x0d,0xfc,0xfd,0x58,0x0d,0x00,0xfe,0x3f,0x0d,0x05,0xfe,0x27,0x0d,  \
    0x09,0xfe,0x0f,0x0d,0x0e,0xfe,0xf7,0x0c,0x13,0xfe,0xdf,0x0c,0x18,0xfe,0xc7,0x0c,0x1d,0xfe,0xaf,0x0c,0x21,0xfe,0x97,0x0c,0x27,0xfe,0x80,0x0c,0x2c,0xfe,0x6a,0x0c,0x32,0xfe,0x54,0x0c,0x37,0xfe,0x3d,0x0c,0x3d,0xfe,0x27,0x0c,0x42,0xfe,0x11,0x0c,0x48,0xfe,0xfb,0x0b,0x4e,0xfe,0xe6,0x0b,0x53,0xfe,0xd0,0x0b,0x59,0xfe,0xbb,0x0b,0x5f,0xfe,0xa5,0x0b,0x64,0xfe,0x90,0x0b,0x6a,0xfe,0x7b,0x0b,0x70,0xfe,0x66,0x0b,0x76,0xfe,0x51,0x0b,0x7c,0xfe,0x3c,0x0b,0x82,0xfe,  \
    0x28,0x0b,0x87,0xfe,0x13,0x0b,0x8d,0xfe,0xfe,0x0a,0x92,0xfe,0xe9,0x0a,0x98,0xfe,0xd4,0x0a,0x9d,0xfe,0xbf,0x0a,0xa3,0xfe,0xaa,0x0a,0xa8,0xfe,0x95,0x0a,0xad,0xfe,0x80,0x0a,0xb3,0xfe,0x6c,0x0a,0xb8,0xfe,0x57,0x0a,0xbe,0xfe,0x43,0x0a,0xc3,0xfe,0x2e,0x0a,0xc9,0xfe,0x1a,0x0a,0xce,0xfe,0x06,0x0a,0xd4,0xfe,0xf2,0x09,0xd9,0xfe,0xde,0x09,0xdf,0xfe,0xca,0x09,0xe4,0xfe,0xb6,0x09,0xea,0xfe,0xa2,0x09,0xef,0xfe,0x8f,0x09,0xf4,0xfe,0x7b,0x09,0xfa,0xfe,0x68,0x09,  \
    0xff,0xfe,0x55,0x09,0x05,0xff,0x41,0x09,0x0a,0xff,0x2e,0x09,0x10,0xff,0x1b,0x09,0x15,0xff,0x08,0x09,0x1b,0xff,0xf5,0x08,0x20,0xff,0xe2,0x08,0x25,0xff,0xd0,0x08,0x2b,0xff,0xbd,0x08,0x30,0xff,0xaa,0x08,0x35,0xff,0x98,0x08,0x3b,0xff,0x86,0x08,0x40,0xff,0x73,0x08,0x45,0xff,0x61,0x08,0x4b,0xff,0x4f,0x08,0x50,0xff,0x3d,0x08,0x55,0xff,0x2b,0x08,0x5b,0xff,0x1a,0x08,0x60,0xff,0x08,0x08,0x65,0xff,0xf7,0x07,0x6b,0xff,0xe5,0x07,0x70,0xff,0xd4,0x07,0x75,0xff,  \
    0xc3,0x07,0x7a,0xff,0xb2,0x07,0x80,0xff,0xa0,0x07,0x85,0xff,0x8f,0x07,0x8a,0xff,0x7e,0x07,0x8f,0xff,0x6e,0x07,0x94,0xff,0x5d,0x07,0x99,0xff,0x4c,0x07,0x9e,0xff,0x3b,0x07,0xa3,0xff,0x2b,0x07,0xa8,0xff,0x1a,0x07,0xad,0xff,0x0a,0x07,0xb2,0xff,0xf9,0x06,0xb7,0xff,0xe9,0x06,0xbc,0xff,0xd8,0x06,0xc1,0xff,0xc8,0x06,0xc6,0xff,0xb8,0x06,0xcb,0xff,0xa7,0x06,0xcf,0xff,0x97,0x06,0xd4,0xff,0x87,0x06,0xd9,0xff,0x77,0x06,0xdd,0xff,0x67,0x06,0xe2,0xff,0x57,0x06,  \
    0xe6,0xff,0x47,0x06,0xeb,0xff,0x37,0x06,0xf0,0xff,0x27,0x06,0xf4,0xff,0x18,0x06,0xf9,0xff,0x08,0x06,0xfd,0xff,0xf8,0x05,0x01,0x00,0xe9,0x05,0x06,0x00,0xd9,0x05,0x0a,0x00,0xc9,0x05,0x0e,0x00,0xba,0x05,0x13,0x00,0xab,0x05,0x17,0x00,0x9b,0x05,0x1b,0x00,0x8c,0x05,0x1f,0x00,0x7c,0x05,0x23,0x00,0x6c,0x05,0x27,0x00,0x5c,0x05,0x2b,0x00,0x4d,0x05,0x2f,0x00,0x3d,0x05,0x33,0x00,0x2e,0x05,0x37,0x00,0x1e,0x05,0x3a,0x00,0x0f,0x05,0x3e,0x00,0xff,0x04,0x42,0x00,  \
    0xf0,0x04,0x46,0x00,0xe0,0x04,0x49,0x00,0xd1,0x04,0x4d,0x00,0xc2,0x04,0x50,0x00,0xb2,0x04,0x54,0x00,0xa3,0x04,0x58,0x00,0x94,0x04,0x5b,0x00,0x85,0x04,0x5f,0x00,0x76,0x04,0x62,0x00,0x67,0x04,0x65,0x00,0x58,0x04,0x69,0x00,0x49,0x04,0x6c,0x00,0x3a,0x04,0x6f,0x00,0x2b,0x04,0x73,0x00,0x1c,0x04,0x76,0x00,0x0e,0x04,0x79,0x00,0x00,0x04,0x7c,0x00,0xf1,0x03,0x80,0x00,0xe3,0x03,0x83,0x00,0xd4,0x03,0x86,0x00,0xc6,0x03,0x89,0x00,0xb8,0x03,0x8c,0x00,0xaa,0x03,  \
    0x8f,0x00,0x9b,0x03,0x92,0x00,0x8d,0x03,0x95,0x00,0x7f,0x03,0x98,0x00,0x71,0x03,0x9a,0x00,0x63,0x03,0x9d,0x00,0x55,0x03,0xa0,0x00,0x47,0x03,0xa3,0x00,0x39,0x03,0xa5,0x00,0x2b,0x03,0xa8,0x00,0x1d,0x03,0xab,0x00,0x0f,0x03,0xad,0x00,0x01,0x03,0xb0,0x00,0xf3,0x02,0xb2,0x00,0xe5,0x02,0xb5,0x00,0xd7,0x02,0xb7,0x00,0xc9,0x02,0xb9,0x00,0xbc,0x02,0xbc,0x00,0xae,0x02,0xbe,0x00,0xa0,0x02,0xc0,0x00,0x93,0x02,0xc3,0x00,0x85,0x02,0xc5,0x00,0x78,0x02,0xc7,0x00,  \
    0x6a,0x02,0xc9,0x00,0x5d,0x02,0xcb,0x00,0x4f,0x02,0xcd,0x00,0x42,0x02,0xcf,0x00,0x34,0x02,0xd1,0x00,0x27,0x02,0xd3,0x00,0x19,0x02,0xd5,0x00,0x0c,0x02,0xd6,0x00,0xff,0x01,0xd8,0x00,0xf1,0x01,0xda,0x00,0xe4,0x01,0xdc,0x00,0xd6,0x01,0xdd,0x00,0xc9,0x01,0xdf,0x00,0xbc,0x01,0xe0,0x00,0xae,0x01,0xe2,0x00,0xa1,0x01,0xe3,0x00,0x94,0x01,0xe5,0x00,0x87,0x01,0xe6,0x00,0x79,0x01,0xe8,0x00,0x6c,0x01,0xe9,0x00,0x5f,0x01,0xea,0x00,0x51,0x01,0xeb,0x00,0x44,0x01,  \
    0xed,0x00,0x37,0x01,0xee,0x00,0x2a,0x01,0xef,0x00,0x1c,0x01,0xf0,0x00,0x0f,0x01,0xf1,0x00,0x02,0x01,0xf2,0x00,0xf5,0x00,0xf3,0x00,0xe7,0x00,0xf4,0x00,0xda,0x00,0xf5,0x00,0xcd,0x00,0xf5,0x00,0xc0,0x00,0xf6,0x00,0xb3,0x00,0xf7,0x00,0xa6,0x00,0xf8,0x00,0x98,0x00,0xf8,0x00,0x8b,0x00,0xf9,0x00,0x7e,0x00,0xfa,0x00,0x71,0x00,0xfa,0x00,0x64,0x00,0xfb,0x00,0x57,0x00,0xfb,0x00,0x49,0x00,0xfb,0x00,0x3c,0x00,0xfc,0x00,0x2f,0x00,0xfc,0x00,0x22,0x00,0xfc,0x00,  \
    0x15,0x00,0xfd,0x00,0x08,0x00,0xfd,0x00,0xfb,0xff,0xfd,0x00,0xed,0xff,0xfd,0x00,0xe0,0xff,0xfd,0x00,0xd3,0xff,0xfd,0x00,0xc6,0xff,0xfd,0x00,0xb9,0xff,0xfd,0x00,0xac,0xff,0xfd,0x00,0x9f,0xff,0xfd,0x00,0x92,0xff,0xfd,0x00,0x84,0xff,0xfd,0x00,0x77,0xff,0xfc,0x00,0x6a,0xff,0xfc,0x00,0x5d,0xff,0xfc,0x00,0x50,0xff,0xfb,0x00,0x42,0xff,0xfb,0x00,0x35,0xff,0xfa,0x00,0x28,0xff,0xfa,0x00,0x1b,0xff,0xfa,0x00,0x0d,0xff,0xf9,0x00,0x00,0xff,0xf8,0x00,0xf3,0xfe,  \
    0xf8,0x00,0xe5,0xfe,0xf7,0x00,0xd8,0xfe,0xf6,0x00,0xcb,0xfe,0xf6,0x00,0xbd,0xfe,0xf5,0x00,0xb0,0xfe,0xf4,0x00,0xa2,0xfe,0xf3,0x00,0x95,0xfe,0xf2,0x00,0x88,0xfe,0xf1,0x00,0x7a,0xfe,0xf0,0x00,0x6d,0xfe,0xef,0x00,0x5f,0xfe,0xee,0x00,0x52,0xfe,0xed,0x00,0x45,0xfe,0xec,0x00,0x38,0xfe,0xeb,0x00,0x2b,0xfe,0xe9,0x00,0x1e,0xfe,0xe8,0x00,0x11,0xfe,0xe7,0x00,0x04,0xfe,0xe5,0x00,0xf7,0xfd,0xe4,0x00,0xea,0xfd,0xe3,0x00,0xdd,0xfd,0xe1,0x00,0xd0,0xfd,0xe0,0x00,  \
    0xc3,0xfd,0xde,0x00,0xb6,0xfd,0xdc,0x00,0xa9,0xfd,0xdb,0x00,0x9c,0xfd,0xd9,0x00,0x8f,0xfd,0xd7,0x00,0x82,0xfd,0xd5,0x00,0x75,0xfd,0xd4,0x00,0x68,0xfd,0xd2,0x00,0x5b,0xfd,0xd0,0x00,0x4f,0xfd,0xce,0x00,0x42,0xfd,0xcc,0x00,0x35,0xfd,0xca,0x00,0x28,0xfd,0xc8,0x00,0x1b,0xfd,0xc5,0x00,0x0e,0xfd,0xc3,0x00,0x01,0xfd,0xc1,0x00,0xf4,0xfc,0xbf,0x00,0xe6,0xfc,0xbd,0x00,0xd8,0xfc,0xba,0x00,0xca,0xfc,0xb8,0x00,0xbc,0xfc,0xb6,0x00,0xae,0xfc,0xb4,0x00,0xa0,0xfc,  \
    0xb1,0x00,0x92,0xfc,0xaf,0x00,0x84,0xfc,0xac,0x00,0x75,0xfc,0xaa,0x00,0x67,0xfc,0xa7,0x00,0x59,0xfc,0xa5,0x00,0x4b,0xfc,0xa2,0x00,0x3c,0xfc,0xa0,0x00,0x2e,0xfc,0x9d,0x00,0x20,0xfc,0x9a,0x00,0x11,0xfc,0x98,0x00,0x03,0xfc,0x95,0x00,0xf4,0xfb,0x92,0x00,0xe6,0xfb,0x8f,0x00,0xd7,0xfb,0x8c,0x00,0xc8,0xfb,0x89,0x00,0xba,0xfb,0x86,0x00,0xab,0xfb,0x84,0x00,0x9c,0xfb,0x81,0x00,0x8d,0xfb,0x7e,0x00,0x7f,0xfb,0x7a,0x00,0x70,0xfb,0x77,0x00,0x62,0xfb,0x74,0x00,  \
    0x53,0xfb,0x71,0x00,0x45,0xfb,0x6e,0x00,0x36,0xfb,0x6a,0x00,0x27,0xfb,0x67,0x00,0x19,0xfb,0x63,0x00,0x0a,0xfb,0x60,0x00,0xfb,0xfa,0x5d,0x00,0xed,0xfa,0x59,0x00,0xde,0xfa,0x56,0x00,0xcf,0xfa,0x52,0x00,0xc0,0xfa,0x4e,0x00,0xb1,0xfa,0x4b,0x00,0xa2,0xfa,0x47,0x00,0x93,0xfa,0x44,0x00,0x84,0xfa,0x40,0x00,0x75,0xfa,0x3c,0x00,0x66,0xfa,0x38,0x00,0x57,0xfa,0x34,0x00,0x48,0xfa,0x31,0x00,0x39,0xfa,0x2d,0x00,0x29,0xfa,0x29,0x00,0x1a,0xfa,0x25,0x00,0x0b,0xfa,  \
    0x21,0x00,0xfb,0xf9,0x1d,0x00,0xec,0xf9,0x19,0x00,0xdd,0xf9,0x15,0x00,0xcd,0xf9,0x10,0x00,0xbe,0xf9,0x0c,0x00,0xae,0xf9,0x08,0x00,0x9f,0xf9,0x04,0x00,0x8f,0xf9,0xff,0xff,0x80,0xf9,0xfb,0xff,0x70,0xf9,0xf7,0xff,0x60,0xf9,0xf2,0xff,0x50,0xf9,0xee,0xff,0x40,0xf9,0xea,0xff,0x30,0xf9,0xe5,0xff,0x20,0xf9,0xe1,0xff,0x10,0xf9,0xdc,0xff,0x00,0xf9,0xd8,0xff,0xf0,0xf8,0xd3,0xff,0xe0,0xf8,0xcf,0xff,0xd0,0xf8,0xca,0xff,0xbf,0xf8,0xc5,0xff,0xaf,0xf8,0xc1,0xff,  \
    0x9f,0xf8,0xbc,0xff,0x8e,0xf8,0xb7,0xff,0x7e,0xf8,0xb2,0xff,0x6d,0xf8,0xae,0xff,0x5c,0xf8,0xa9,0xff,0x4b,0xf8,0xa4,0xff,0x3b,0xf8,0x9f,0xff,0x2a,0xf8,0x9a,0xff,0x19,0xf8,0x95,0xff,0x08,0xf8,0x91,0xff,0xf7,0xf7,0x8c,0xff,0xe5,0xf7,0x87,0xff,0xd4,0xf7,0x82,0xff,0xc3,0xf7,0x7d,0xff,0xb2,0xf7,0x78,0xff,0xa0,0xf7,0x73,0xff,0x8f,0xf7,0x6e,0xff,0x7d,0xf7,0x68,0xff,0x6b,0xf7,0x63,0xff,0x5a,0xf7,0x5e,0xff,0x48,0xf7,0x59,0xff,0x36,0xf7,0x54,0xff,0x24,0xf7,  \
    0x4f,0xff,0x12,0xf7,0x4a,0xff,0x00,0xf7,0x45,0xff,0xed,0xf6,0x3f,0xff,0xdb,0xf6,0x3a,0xff,0xc9,0xf6,0x35,0xff,0xb6,0xf6,0x30,0xff,0xa4,0xf6,0x2b,0xff,0x91,0xf6,0x25,0xff,0x7e,0xf6,0x20,0xff,0x6b,0xf6,0x1b,0xff,0x59,0xf6,0x16,0xff,0x46,0xf6,0x10,0xff,0x32,0xf6,0x0b,0xff,0x1f,0xf6,0x06,0xff,0x0c,0xf6,0x00,0xff,0xf9,0xf5,0xfb,0xfe,0xe5,0xf5,0xf6,0xfe,0xd2,0xf5,0xf1,0xfe,0xbe,0xf5,0xeb,0xfe,0xaa,0xf5,0xe6,0xfe,0x96,0xf5,0xe1,0xfe,0x82,0xf5,0xdc,0xfe,  \
    0x6e,0xf5,0xd7,0xfe,0x59,0xf5,0xd1,0xfe,0x45,0xf5,0xcc,0xfe,0x30,0xf5,0xc7,0xfe,0x1c,0xf5,0xc2,0xfe,0x07,0xf5,0xbd,0xfe,0xf2,0xf4,0xb8,0xfe,0xdd,0xf4,0xb3,0xfe,0xc8,0xf4,0xad,0xfe,0xb3,0xf4,0xa8,0xfe,0x9e,0xf4,0xa3,0xfe,0x89,0xf4,0x9e,0xfe,0x73,0xf4,0x99,0xfe,0x5e,0xf4,0x94,0xfe,0x48,0xf4,0x8f,0xfe,0x32,0xf4,0x8a,0xfe,0x1c,0xf4,0x85,0xfe,0x07,0xf4,0x80,0xfe,0xf1,0xf3,0x7b,0xfe,0xdb,0xf3,0x76,0xfe,0xc4,0xf3,0x71,0xfe,0xae,0xf3,0x6c,0xfe,0x98,0xf3,  \
    0x67,0xfe,0x81,0xf3,0x62,0xfe,0x6b,0xf3,0x5d,0xfe,0x54,0xf3,0x59,0xfe,0x3d,0xf3,0x54,0xfe,0x26,0xf3,0x4f,0xfe,0x0f,0xf3,0x4a,0xfe,0xf7,0xf2,0x46,0xfe,0xe0,0xf2,0x41,0xfe,0xc9,0xf2,0x3c,0xfe,0xb1,0xf2,0x38,0xfe,0x99,0xf2,0x34,0xfe,0x81,0xf2,0x2f,0xfe,0x69,0xf2,0x2b,0xfe,0x51,0xf2,0x26,0xfe,0x38,0xf2,0x22,0xfe,0x20,0xf2,0x1e,0xfe,0x07,0xf2,0x1a,0xfe,0xee,0xf1,0x16,0xfe,0xd5,0xf1,0x12,0xfe,0xbc,0xf1,0x0e,0xfe,0xa3,0xf1,0x0a,0xfe,0x8a,0xf1,0x06,0xfe,  \
    0x71,0xf1,0x02,0xfe,0x57,0xf1,0xfe,0xfd,0x3d,0xf1,0xfb,0xfd,0x23,0xf1,0xf7,0xfd,0x09,0xf1,0xf4,0xfd,0xef,0xf0,0xf0,0xfd,0xd5,0xf0,0xed,0xfd,0xbb,0xf0,0xe9,0xfd,0xa0,0xf0,0xe6,0xfd,0x86,0xf0,0xe3,0xfd,0x6b,0xf0,0xdf,0xfd,0x50,0xf0,0xdc,0xfd,0x35,0xf0,0xd9,0xfd,0x1a,0xf0,0xd6,0xfd,0xff,0xef,0xd3,0xfd,0xe4,0xef,0xd0,0xfd,0xc9,0xef,0xce,0xfd,0xad,0xef,0xcb,0xfd,0x91,0xef,0xc8,0xfd,0x75,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7b,0xfd,0x8c,0x10,0x7e,0xfd,0x70,0x10,0x81,0xfd,0x54,0x10,0x84,0xfd,0x38,0x10,0x87,0xfd,0x1c,0x10,0x8a,0xfd,0x01,0x10,0x8d,0xfd,0xe5,0x0f,0x90,0xfd,0xca,0x0f,0x93,0xfd,0xae,0x0f,0x97,0xfd,0x93,0x0f,0x9a,0xfd,  \
    0x78,0x0f,0x9e,0xfd,0x5d,0x0f,0xa1,0xfd,0x43,0x0f,0xa5,0xfd,0x28,0x0f,0xa9,0xfd,0x0e,0x0f,0xad,0xfd,0xf3,0x0e,0xb0,0xfd,0xd9,0x0e,0xb4,0xfd,0xbf,0x0e,0xb8,0xfd,0xa5,0x0e,0xbd,0xfd,0x8b,0x0e,0xc1,0xfd,0x71,0x0e,0xc5,0xfd,0x58,0x0e,0xc9,0xfd,0x3e,0x0e,0xcd,0xfd,0x25,0x0e,0xd1,0xfd,0x0b,0x0e,0xd6,0xfd,0xf2,0x0d,0xda,0xfd,0xd9,0x0d,0xdf,0xfd,0xc0,0x0d,0xe3,0xfd,0xa7,0x0d,0xe8,0xfd,0x8e,0x0d,0xec,0xfd,0x76,0x0d,0xf1,0xfd,0x5d,0x0d,0xf5,0xfd,0x45,0x0d,  \
    0xfa,0xfd,0x2c,0x0d,0xff,0xfd,0x14,0x0d,0x04,0xfe,0xfc,0x0c,0x09,0xfe,0xe4,0x0c,0x0d,0xfe,0xcc,0x0c,0x12,0xfe,0xb5,0x0c,0x17,0xfe,0x9d,0x0c,0x1d,0xfe,0x86,0x0c,0x22,0xfe,0x6f,0x0c,0x28,0xfe,0x59,0x0c,0x2d,0xfe,0x43,0x0c,0x33,0xfe,0x2d,0x0c,0x39,0xfe,0x17,0x0c,0x3e,0xfe,0x01,0x0c,0x44,0xfe,0xec,0x0b,0x4a,0xfe,0xd6,0x0b,0x50,0xfe,0xc1,0x0b,0x56,0xfe,0xab,0x0b,0x5c,0xfe,0x96,0x0b,0x61,0xfe,0x81,0x0b,0x67,0xfe,0x6c,0x0b,0x6d,0xfe,0x58,0x0b,0x73,0xfe,  \
    0x43,0x0b,0x79,0xfe,0x2e,0x0b,0x7f,0xfe,0x1a,0x0b,0x85,0xfe,0x05,0x0b,0x8a,0xfe,0xef,0x0a,0x90,0xfe,0xda,0x0a,0x95,0xfe,0xc5,0x0a,0x9b,0xfe,0xb0,0x0a,0xa0,0xfe,0x9c,0x0a,0xa6,0xfe,0x87,0x0a,0xab,0xfe,0x72,0x0a,0xb1,0xfe,0x5e,0x0a,0xb6,0xfe,0x49,0x0a,0xbc,0xfe,0x35,0x0a,0xc1,0xfe,0x21,0x0a,0xc7,0xfe,0x0d,0x0a,0xcc,0xfe,0xf9,0x09,0xd2,0xfe,0xe5,0x09,0xd7,0xfe,0xd1,0x09,0xdd,0xfe,0xbd,0x09,0xe3,0xfe,0xa9,0x09,0xe8,0xfe,0x96,0x09,0xee,0xfe,0x82,0x09,  \
    0xf3,0xfe,0x6f,0x09,0xf9,0xfe,0x5c,0x09,0xfe,0xfe,0x48,0x09,0x04,0xff,0x35,0x09,0x09,0xff,0x22,0x09,0x0f,0xff,0x0f,0x09,0x14,0xff,0xfc,0x08,0x1a,0xff,0xe9,0x08,0x1f,0xff,0xd7,0x08,0x25,0xff,0xc4,0x08,0x2a,0xff,0xb2,0x08,0x2f,0xff,0x9f,0x08,0x35,0xff,0x8d,0x08,0x3a,0xff,0x7a,0x08,0x3f,0xff,0x68,0x08,0x45,0xff,0x56,0x08,0x4a,0xff,0x44,0x08,0x50,0xff,0x32,0x08,0x55,0xff,0x21,0x08,0x5b,0xff,0x0f,0x08,0x60,0xff,0xfe,0x07,0x65,0xff,0xed,0x07,0x6b,0xff,  \
    0xdb,0x07,0x70,0xff,0xca,0x07,0x75,0xff,0xb9,0x07,0x7b,0xff,0xa8,0x07,0x80,0xff,0x97,0x07,0x85,0xff,0x86,0x07,0x8a,0xff,0x75,0x07,0x8f,0xff,0x64,0x07,0x95,0xff,0x53,0x07,0x9a,0xff,0x43,0x07,0x9f,0xff,0x32,0x07,0xa4,0xff,0x21,0x07,0xa9,0xff,0x11,0x07,0xae,0xff,0x00,0x07,0xb3,0xff,0xf0,0x06,0xb8,0xff,0xe0,0x06,0xbd,0xff,0xcf,0x06,0xc2,0xff,0xbf,0x06,0xc6,0xff,0xaf,0x06,0xcb,0xff,0x9e,0x06,0xd0,0xff,0x8e,0x06,0xd5,0xff,0x7e,0x06,0xd9,0xff,0x6e,0x06,  \
    0xde,0xff,0x5e,0x06,0xe3,0xff,0x4e,0x06,0xe7,0xff,0x3e,0x06,0xec,0xff,0x2e,0x06,0xf0,0xff,0x1f,0x06,0xf5,0xff,0x0f,0x06,0xf9,0xff,0xff,0x05,0xfe,0xff,0xf0,0x05,0x02,0x00,0xe0,0x05,0x07,0x00,0xd1,0x05,0x0b,0x00,0xc1,0x05,0x0f,0x00,0xb2,0x05,0x13,0x00,0xa2,0x05,0x18,0x00,0x93,0x05,0x1c,0x00,0x83,0x05,0x20,0x00,0x73,0x05,0x24,0x00,0x63,0x05,0x28,0x00,0x54,0x05,0x2c,0x00,0x44,0x05,0x30,0x00,0x34,0x05,0x33,0x00,0x25,0x05,0x37,0x00,0x15,0x05,0x3b,0x00,  \
    0x06,0x05,0x3f,0x00,0xf6,0x04,0x43,0x00,0xe7,0x04,0x46,0x00,0xd7,0x04,0x4a,0x00,0xc8,0x04,0x4e,0x00,0xb9,0x04,0x51,0x00,0xaa,0x04,0x55,0x00,0x9a,0x04,0x58,0x00,0x8b,0x04,0x5c,0x00,0x7c,0x04,0x5f,0x00,0x6d,0x04,0x63,0x00,0x5e,0x04,0x66,0x00,0x4f,0x04,0x69,0x00,0x40,0x04,0x6d,0x00,0x31,0x04,0x70,0x00,0x22,0x04,0x73,0x00,0x14,0x04,0x77,0x00,0x05,0x04,0x7a,0x00,0xf7,0x03,0x7d,0x00,0xe8,0x03,0x80,0x00,0xda,0x03,0x83,0x00,0xcc,0x03,0x87,0x00,0xbd,0x03,  \
    0x8a,0x00,0xaf,0x03,0x8d,0x00,0xa1,0x03,0x90,0x00,0x92,0x03,0x92,0x00,0x84,0x03,0x95,0x00,0x76,0x03,0x98,0x00,0x68,0x03,0x9b,0x00,0x5a,0x03,0x9e,0x00,0x4c,0x03,0xa1,0x00,0x3d,0x03,0xa3,0x00,0x2f,0x03,0xa6,0x00,0x21,0x03,0xa9,0x00,0x13,0x03,0xab,0x00,0x05,0x03,0xae,0x00,0xf7,0x02,0xb0,0x00,0xea,0x02,0xb3,0x00,0xdc,0x02,0xb5,0x00,0xce,0x02,0xb7,0x00,0xc0,0x02,0xba,0x00,0xb2,0x02,0xbc,0x00,0xa5,0x02,0xbe,0x00,0x97,0x02,0xc1,0x00,0x89,0x02,0xc3,0x00,  \
    0x7c,0x02,0xc5,0x00,0x6e,0x02,0xc7,0x00,0x60,0x02,0xc9,0x00,0x53,0x02,0xcb,0x00,0x45,0x02,0xcd,0x00,0x38,0x02,0xcf,0x00,0x2a,0x02,0xd1,0x00,0x1d,0x02,0xd3,0x00,0x0f,0x02,0xd5,0x00,0x02,0x02,0xd6,0x00,0xf4,0x01,0xd8,0x00,0xe7,0x01,0xda,0x00,0xda,0x01,0xdc,0x00,0xcc,0x01,0xdd,0x00,0xbf,0x01,0xdf,0x00,0xb1,0x01,0xe0,0x00,0xa4,0x01,0xe2,0x00,0x97,0x01,0xe3,0x00,0x89,0x01,0xe5,0x00,0x7c,0x01,0xe6,0x00,0x6f,0x01,0xe7,0x00,0x61,0x01,0xe9,0x00,0x54,0x01,  \
    0xea,0x00,0x47,0x01,0xeb,0x00,0x39,0x01,0xec,0x00,0x2c,0x01,0xed,0x00,0x1f,0x01,0xee,0x00,0x11,0x01,0xef,0x00,0x04,0x01,0xf0,0x00,0xf7,0x00,0xf1,0x00,0xe9,0x00,0xf2,0x00,0xdc,0x00,0xf3,0x00,0xcf,0x00,0xf4,0x00,0xc1,0x00,0xf5,0x00,0xb4,0x00,0xf5,0x00,0xa7,0x00,0xf6,0x00,0x9a,0x00,0xf7,0x00,0x8c,0x00,0xf7,0x00,0x7f,0x00,0xf8,0x00,0x72,0x00,0xf9,0x00,0x65,0x00,0xf9,0x00,0x57,0x00,0xfa,0x00,0x4a,0x00,0xfa,0x00,0x3d,0x00,0xfa,0x00,0x30,0x00,0xfb,0x00,  \
    0x23,0x00,0xfb,0x00,0x15,0x00,0xfb,0x00,0x08,0x00,0xfb,0x00,0xfb,0xff,0xfc,0x00,0xee,0xff,0xfc,0x00,0xe1,0xff,0xfc,0x00,0xd3,0xff,0xfc,0x00,0xc6,0xff,0xfc,0x00,0xb9,0xff,0xfc,0x00,0xac,0xff,0xfc,0x00,0x9f,0xff,0xfb,0x00,0x91,0xff,0xfb,0x00,0x84,0xff,0xfb,0x00,0x77,0xff,0xfb,0x00,0x69,0xff,0xfb,0x00,0x5c,0xff,0xfa,0x00,0x4f,0xff,0xfa,0x00,0x42,0xff,0xf9,0x00,0x34,0xff,0xf9,0x00,0x27,0xff,0xf9,0x00,0x1a,0xff,0xf8,0x00,0x0c,0xff,0xf7,0x00,0xff,0xfe,  \
    0xf7,0x00,0xf1,0xfe,0xf6,0x00,0xe4,0xfe,0xf6,0x00,0xd7,0xfe,0xf5,0x00,0xc9,0xfe,0xf4,0x00,0xbc,0xfe,0xf3,0x00,0xae,0xfe,0xf2,0x00,0xa1,0xfe,0xf2,0x00,0x93,0xfe,0xf1,0x00,0x86,0xfe,0xf0,0x00,0x78,0xfe,0xef,0x00,0x6a,0xfe,0xee,0x00,0x5d,0xfe,0xed,0x00,0x50,0xfe,0xec,0x00,0x42,0xfe,0xea,0x00,0x35,0xfe,0xe9,0x00,0x28,0xfe,0xe8,0x00,0x1b,0xfe,0xe7,0x00,0x0e,0xfe,0xe5,0x00,0x01,0xfe,0xe4,0x00,0xf4,0xfd,0xe2,0x00,0xe7,0xfd,0xe1,0x00,0xda,0xfd,0xe0,0x00,  \
    0xcd,0xfd,0xde,0x00,0xc0,0xfd,0xdc,0x00,0xb3,0xfd,0xdb,0x00,0xa6,0xfd,0xd9,0x00,0x99,0xfd,0xd7,0x00,0x8c,0xfd,0xd6,0x00,0x7f,0xfd,0xd4,0x00,0x72,0xfd,0xd2,0x00,0x65,0xfd,0xd0,0x00,0x58,0xfd,0xce,0x00,0x4b,0xfd,0xcc,0x00,0x3e,0xfd,0xca,0x00,0x31,0xfd,0xc8,0x00,0x24,0xfd,0xc6,0x00,0x17,0xfd,0xc4,0x00,0x0a,0xfd,0xc2,0x00,0xfd,0xfc,0xbf,0x00,0xf0,0xfc,0xbd,0x00,0xe2,0xfc,0xbb,0x00,0xd4,0xfc,0xb9,0x00,0xc6,0xfc,0xb6,0x00,0xb8,0xfc,0xb4,0x00,0xaa,0xfc,  \
    0xb2,0x00,0x9b,0xfc,0xaf,0x00,0x8d,0xfc,0xad,0x00,0x7f,0xfc,0xaa,0x00,0x71,0xfc,0xa8,0x00,0x62,0xfc,0xa5,0x00,0x54,0xfc,0xa3,0x00,0x46,0xfc,0xa0,0x00,0x37,0xfc,0x9e,0x00,0x29,0xfc,0x9b,0x00,0x1a,0xfc,0x98,0x00,0x0c,0xfc,0x95,0x00,0xfd,0xfb,0x93,0x00,0xef,0xfb,0x90,0x00,0xe0,0xfb,0x8d,0x00,0xd2,0xfb,0x8a,0x00,0xc3,0xfb,0x87,0x00,0xb4,0xfb,0x84,0x00,0xa5,0xfb,0x81,0x00,0x96,0xfb,0x7e,0x00,0x88,0xfb,0x7b,0x00,0x79,0xfb,0x78,0x00,0x6a,0xfb,0x75,0x00,  \
    0x5b,0xfb,0x72,0x00,0x4d,0xfb,0x6f,0x00,0x3e,0xfb,0x6b,0x00,0x30,0xfb,0x68,0x00,0x21,0xfb,0x65,0x00,0x12,0xfb,0x61,0x00,0x04,0xfb,0x5e,0x00,0xf5,0xfa,0x5a,0x00,0xe6,0xfa,0x57,0x00,0xd7,0xfa,0x53,0x00,0xc8,0xfa,0x50,0x00,0xba,0xfa,0x4c,0x00,0xab,0xfa,0x48,0x00,0x9c,0xfa,0x45,0x00,0x8d,0xfa,0x41,0x00,0x7e,0xfa,0x3d,0x00,0x6e,0xfa,0x39,0x00,0x5f,0xfa,0x36,0x00,0x50,0xfa,0x32,0x00,0x41,0xfa,0x2e,0x00,0x32,0xfa,0x2a,0x00,0x22,0xfa,0x26,0x00,0x13,0xfa,  \
    0x22,0x00,0x04,0xfa,0x1e,0x00,0xf4,0xf9,0x1a,0x00,0xe5,0xf9,0x16,0x00,0xd6,0xf9,0x12,0x00,0xc6,0xf9,0x0e,0x00,0xb7,0xf9,0x09,0x00,0xa7,0xf9,0x05,0x00,0x97,0xf9,0x01,0x00,0x88,0xf9,0xfd,0xff,0x78,0xf9,0xf8,0xff,0x68,0xf9,0xf4,0xff,0x59,0xf9,0xef,0xff,0x49,0xf9,0xeb,0xff,0x39,0xf9,0xe7,0xff,0x29,0xf9,0xe2,0xff,0x19,0xf9,0xde,0xff,0x09,0xf9,0xd9,0xff,0xf9,0xf8,0xd4,0xff,0xe9,0xf8,0xd0,0xff,0xd8,0xf8,0xcb,0xff,0xc8,0xf8,0xc7,0xff,0xb8,0xf8,0xc2,0xff,  \
    0xa7,0xf8,0xbd,0xff,0x97,0xf8,0xb8,0xff,0x86,0xf8,0xb4,0xff,0x76,0xf8,0xaf,0xff,0x65,0xf8,0xaa,0xff,0x54,0xf8,0xa5,0xff,0x44,0xf8,0xa0,0xff,0x33,0xf8,0x9b,0xff,0x22,0xf8,0x97,0xff,0x11,0xf8,0x92,0xff,0x00,0xf8,0x8d,0xff,0xef,0xf7,0x88,0xff,0xde,0xf7,0x83,0xff,0xcc,0xf7,0x7e,0xff,0xbb,0xf7,0x79,0xff,0xaa,0xf7,0x74,0xff,0x98,0xf7,0x6f,0xff,0x87,0xf7,0x69,0xff,0x75,0xf7,0x64,0xff,0x64,0xf7,0x5f,0xff,0x52,0xf7,0x5a,0xff,0x40,0xf7,0x55,0xff,0x2e,0xf7,  \
    0x50,0xff,0x1c,0xf7,0x4a,0xff,0x0a,0xf7,0x45,0xff,0xf8,0xf6,0x40,0xff,0xe6,0xf6,0x3b,0xff,0xd3,0xf6,0x36,0xff,0xc1,0xf6,0x30,0xff,0xae,0xf6,0x2b,0xff,0x9c,0xf6,0x26,0xff,0x89,0xf6,0x20,0xff,0x77,0xf6,0x1b,0xff,0x64,0xf6,0x16,0xff,0x51,0xf6,0x11,0xff,0x3e,0xf6,0x0b,0xff,0x2b,0xf6,0x06,0xff,0x18,0xf6,0x01,0xff,0x04,0xf6,0xfb,0xfe,0xf1,0xf5,0xf6,0xfe,0xde,0xf5,0xf1,0xfe,0xca,0xf5,0xeb,0xfe,0xb6,0xf5,0xe6,0xfe,0xa3,0xf5,0xe1,0xfe,0x8f,0xf5,0xdc,0xfe,  \
    0x7a,0xf5,0xd6,0xfe,0x66,0xf5,0xd1,0xfe,0x52,0xf5,0xcc,0xfe,0x3d,0xf5,0xc7,0xfe,0x29,0xf5,0xc1,0xfe,0x14,0xf5,0xbc,0xfe,0x00,0xf5,0xb7,0xfe,0xeb,0xf4,0xb2,0xfe,0xd6,0xf4,0xad,0xfe,0xc1,0xf4,0xa8,0xfe,0xac,0xf4,0xa2,0xfe,0x97,0xf4,0x9d,0xfe,0x81,0xf4,0x98,0xfe,0x6c,0xf4,0x93,0xfe,0x56,0xf4,0x8e,0xfe,0x41,0xf4,0x89,0xfe,0x2b,0xf4,0x84,0xfe,0x15,0xf4,0x7f,0xfe,0xff,0xf3,0x79,0xfe,0xe9,0xf3,0x74,0xfe,0xd3,0xf3,0x6f,0xfe,0xbd,0xf3,0x6a,0xfe,0xa7,0xf3,  \
    0x65,0xfe,0x91,0xf3,0x60,0xfe,0x7a,0xf3,0x5b,0xfe,0x63,0xf3,0x57,0xfe,0x4d,0xf3,0x52,0xfe,0x36,0xf3,0x4d,0xfe,0x1f,0xf3,0x48,0xfe,0x08,0xf3,0x43,0xfe,0xf0,0xf2,0x3f,0xfe,0xd9,0xf2,0x3a,0xfe,0xc2,0xf2,0x35,0xfe,0xaa,0xf2,0x31,0xfe,0x92,0xf2,0x2c,0xfe,0x7a,0xf2,0x28,0xfe,0x62,0xf2,0x23,0xfe,0x4a,0xf2,0x1f,0xfe,0x32,0xf2,0x1b,0xfe,0x19,0xf2,0x17,0xfe,0x00,0xf2,0x12,0xfe,0xe8,0xf1,0x0e,0xfe,0xcf,0xf1,0x0a,0xfe,0xb6,0xf1,0x06,0xfe,0x9d,0xf1,0x02,0xfe,  \
    0x83,0xf1,0xfe,0xfd,0x6a,0xf1,0xfa,0xfd,0x50,0xf1,0xf7,0xfd,0x37,0xf1,0xf3,0xfd,0x1d,0xf1,0xef,0xfd,0x03,0xf1,0xec,0xfd,0xe9,0xf0,0xe8,0xfd,0xcf,0xf0,0xe5,0xfd,0xb4,0xf0,0xe1,0xfd,0x9a,0xf0,0xde,0xfd,0x7f,0xf0,0xdb,0xfd,0x65,0xf0,0xd7,0xfd,0x4a,0xf0,0xd4,0xfd,0x2f,0xf0,0xd1,0xfd,0x14,0xf0,0xce,0xfd,0xf9,0xef,0xcb,0xfd,0xde,0xef,0xc8,0xfd,0xc2,0xef,0xc5,0xfd,0xa7,0xef,0xc2,0xfd,0x8b,0xef,0xc0,0xfd,0x6f,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6f,0xfd,0x91,0x10,0x72,0xfd,0x75,0x10,0x74,0xfd,0x59,0x10,0x77,0xfd,0x3d,0x10,0x7a,0xfd,0x21,0x10,0x7d,0xfd,0x06,0x10,0x81,0xfd,0xea,0x0f,0x84,0xfd,0xcf,0x0f,0x87,0xfd,0xb3,0x0f,0x8b,0xfd,  \
    0x98,0x0f,0x8e,0xfd,0x7d,0x0f,0x92,0xfd,0x62,0x0f,0x95,0xfd,0x48,0x0f,0x99,0xfd,0x2d,0x0f,0x9d,0xfd,0x13,0x0f,0xa1,0xfd,0xf8,0x0e,0xa5,0xfd,0xde,0x0e,0xa9,0xfd,0xc4,0x0e,0xad,0xfd,0xaa,0x0e,0xb1,0xfd,0x90,0x0e,0xb5,0xfd,0x77,0x0e,0xb9,0xfd,0x5d,0x0e,0xbe,0xfd,0x43,0x0e,0xc2,0xfd,0x2a,0x0e,0xc6,0xfd,0x10,0x0e,0xcb,0xfd,0xf7,0x0d,0xcf,0xfd,0xde,0x0d,0xd4,0xfd,0xc5,0x0d,0xd8,0xfd,0xac,0x0d,0xdd,0xfd,0x94,0x0d,0xe1,0xfd,0x7b,0x0d,0xe6,0xfd,0x62,0x0d,  \
    0xeb,0xfd,0x4a,0x0d,0xf0,0xfd,0x32,0x0d,0xf4,0xfd,0x1a,0x0d,0xf9,0xfd,0x02,0x0d,0xfe,0xfd,0xea,0x0c,0x03,0xfe,0xd2,0x0c,0x08,0xfe,0xba,0x0c,0x0d,0xfe,0xa3,0x0c,0x12,0xfe,0x8c,0x0c,0x18,0xfe,0x75,0x0c,0x1e,0xfe,0x5f,0x0c,0x24,0xfe,0x49,0x0c,0x29,0xfe,0x33,0x0c,0x2f,0xfe,0x1d,0x0c,0x35,0xfe,0x07,0x0c,0x3b,0xfe,0xf2,0x0b,0x41,0xfe,0xdc,0x0b,0x47,0xfe,0xc7,0x0b,0x4d,0xfe,0xb2,0x0b,0x53,0xfe,0x9d,0x0b,0x59,0xfe,0x88,0x0b,0x5f,0xfe,0x73,0x0b,0x65,0xfe,  \
    0x5e,0x0b,0x6b,0xfe,0x4a,0x0b,0x71,0xfe,0x35,0x0b,0x77,0xfe,0x21,0x0b,0x7c,0xfe,0x0b,0x0b,0x82,0xfe,0xf6,0x0a,0x87,0xfe,0xe1,0x0a,0x8d,0xfe,0xcc,0x0a,0x93,0xfe,0xb7,0x0a,0x98,0xfe,0xa2,0x0a,0x9e,0xfe,0x8e,0x0a,0xa3,0xfe,0x79,0x0a,0xa9,0xfe,0x65,0x0a,0xaf,0xfe,0x50,0x0a,0xb4,0xfe,0x3c,0x0a,0xba,0xfe,0x28,0x0a,0xbf,0xfe,0x14,0x0a,0xc5,0xfe,0x00,0x0a,0xcb,0xfe,0xec,0x09,0xd0,0xfe,0xd8,0x09,0xd6,0xfe,0xc4,0x09,0xdc,0xfe,0xb0,0x09,0xe1,0xfe,0x9d,0x09,  \
    0xe7,0xfe,0x89,0x09,0xec,0xfe,0x76,0x09,0xf2,0xfe,0x63,0x09,0xf8,0xfe,0x4f,0x09,0xfd,0xfe,0x3c,0x09,0x03,0xff,0x29,0x09,0x08,0xff,0x16,0x09,0x0e,0xff,0x03,0x09,0x13,0xff,0xf1,0x08,0x19,0xff,0xde,0x08,0x1e,0xff,0xcb,0x08,0x24,0xff,0xb9,0x08,0x29,0xff,0xa6,0x08,0x2f,0xff,0x94,0x08,0x34,0xff,0x82,0x08,0x3a,0xff,0x6f,0x08,0x3f,0xff,0x5d,0x08,0x45,0xff,0x4b,0x08,0x4a,0xff,0x3a,0x08,0x50,0xff,0x28,0x08,0x55,0xff,0x17,0x08,0x5b,0xff,0x05,0x08,0x60,0xff,  \
    0xf4,0x07,0x65,0xff,0xe3,0x07,0x6b,0xff,0xd1,0x07,0x70,0xff,0xc0,0x07,0x75,0xff,0xaf,0x07,0x7b,0xff,0x9e,0x07,0x80,0xff,0x8d,0x07,0x85,0xff,0x7c,0x07,0x8b,0xff,0x6b,0x07,0x90,0xff,0x5b,0x07,0x95,0xff,0x4a,0x07,0x9a,0xff,0x39,0x07,0x9f,0xff,0x29,0x07,0xa4,0xff,0x18,0x07,0xa9,0xff,0x08,0x07,0xae,0xff,0xf7,0x06,0xb3,0xff,0xe7,0x06,0xb8,0xff,0xd7,0x06,0xbd,0xff,0xc6,0x06,0xc2,0xff,0xb6,0x06,0xc7,0xff,0xa6,0x06,0xcc,0xff,0x96,0x06,0xd1,0xff,0x86,0x06,  \
    0xd5,0xff,0x75,0x06,0xda,0xff,0x65,0x06,0xdf,0xff,0x56,0x06,0xe3,0xff,0x46,0x06,0xe8,0xff,0x36,0x06,0xed,0xff,0x26,0x06,0xf1,0xff,0x16,0x06,0xf6,0xff,0x07,0x06,0xfa,0xff,0xf7,0x05,0xff,0xff,0xe7,0x05,0x03,0x00,0xd8,0x05,0x07,0x00,0xc8,0x05,0x0c,0x00,0xb9,0x05,0x10,0x00,0xa9,0x05,0x14,0x00,0x9a,0x05,0x18,0x00,0x8a,0x05,0x1c,0x00,0x7a,0x05,0x20,0x00,0x6a,0x05,0x24,0x00,0x5b,0x05,0x28,0x00,0x4b,0x05,0x2c,0x00,0x3b,0x05,0x30,0x00,0x2b,0x05,0x34,0x00,  \
    0x1c,0x05,0x38,0x00,0x0c,0x05,0x3c,0x00,0xfd,0x04,0x3f,0x00,0xed,0x04,0x43,0x00,0xde,0x04,0x47,0x00,0xce,0x04,0x4b,0x00,0xbf,0x04,0x4e,0x00,0xb0,0x04,0x52,0x00,0xa1,0x04,0x55,0x00,0x91,0x04,0x59,0x00,0x82,0x04,0x5c,0x00,0x73,0x04,0x60,0x00,0x64,0x04,0x63,0x00,0x55,0x04,0x67,0x00,0x46,0x04,0x6a,0x00,0x37,0x04,0x6d,0x00,0x28,0x04,0x71,0x00,0x19,0x04,0x74,0x00,0x0b,0x04,0x77,0x00,0xfc,0x03,0x7a,0x00,0xee,0x03,0x7e,0x00,0xdf,0x03,0x81,0x00,0xd1,0x03,  \
    0x84,0x00,0xc3,0x03,0x87,0x00,0xb4,0x03,0x8a,0x00,0xa6,0x03,0x8d,0x00,0x98,0x03,0x90,0x00,0x89,0x03,0x93,0x00,0x7b,0x03,0x96,0x00,0x6d,0x03,0x99,0x00,0x5f,0x03,0x9b,0x00,0x51,0x03,0x9e,0x00,0x42,0x03,0xa1,0x00,0x34,0x03,0xa4,0x00,0x26,0x03,0xa6,0x00,0x18,0x03,0xa9,0x00,0x0a,0x03,0xab,0x00,0xfc,0x02,0xae,0x00,0xee,0x02,0xb0,0x00,0xe0,0x02,0xb3,0x00,0xd2,0x02,0xb5,0x00,0xc4,0x02,0xb8,0x00,0xb6,0x02,0xba,0x00,0xa9,0x02,0xbc,0x00,0x9b,0x02,0xbe,0x00,  \
    0x8d,0x02,0xc1,0x00,0x80,0x02,0xc3,0x00,0x72,0x02,0xc5,0x00,0x64,0x02,0xc7,0x00,0x57,0x02,0xc9,0x00,0x49,0x02,0xcb,0x00,0x3c,0x02,0xcd,0x00,0x2e,0x02,0xcf,0x00,0x20,0x02,0xd1,0x00,0x13,0x02,0xd3,0x00,0x05,0x02,0xd5,0x00,0xf8,0x01,0xd6,0x00,0xea,0x01,0xd8,0x00,0xdd,0x01,0xda,0x00,0xcf,0x01,0xdb,0x00,0xc2,0x01,0xdd,0x00,0xb4,0x01,0xde,0x00,0xa7,0x01,0xe0,0x00,0x99,0x01,0xe1,0x00,0x8c,0x01,0xe3,0x00,0x7f,0x01,0xe4,0x00,0x71,0x01,0xe6,0x00,0x64,0x01,  \
    0xe7,0x00,0x56,0x01,0xe8,0x00,0x49,0x01,0xe9,0x00,0x3c,0x01,0xea,0x00,0x2e,0x01,0xec,0x00,0x21,0x01,0xed,0x00,0x13,0x01,0xee,0x00,0x06,0x01,0xef,0x00,0xf9,0x00,0xf0,0x00,0xeb,0x00,0xf1,0x00,0xde,0x00,0xf1,0x00,0xd0,0x00,0xf2,0x00,0xc3,0x00,0xf3,0x00,0xb6,0x00,0xf4,0x00,0xa8,0x00,0xf4,0x00,0x9b,0x00,0xf5,0x00,0x8e,0x00,0xf6,0x00,0x80,0x00,0xf6,0x00,0x73,0x00,0xf7,0x00,0x66,0x00,0xf7,0x00,0x58,0x00,0xf8,0x00,0x4b,0x00,0xf8,0x00,0x3e,0x00,0xf9,0x00,  \
    0x31,0x00,0xf9,0x00,0x23,0x00,0xf9,0x00,0x16,0x00,0xf9,0x00,0x09,0x00,0xfa,0x00,0xfb,0xff,0xfa,0x00,0xee,0xff,0xfa,0x00,0xe1,0xff,0xfa,0x00,0xd3,0xff,0xfa,0x00,0xc6,0xff,0xfa,0x00,0xb9,0xff,0xfa,0x00,0xac,0xff,0xfa,0x00,0x9e,0xff,0xfa,0x00,0x91,0xff,0xfa,0x00,0x84,0xff,0xf9,0x00,0x76,0xff,0xf9,0x00,0x69,0xff,0xf9,0x00,0x5c,0xff,0xf9,0x00,0x4e,0xff,0xf8,0x00,0x41,0xff,0xf8,0x00,0x33,0xff,0xf7,0x00,0x26,0xff,0xf7,0x00,0x18,0xff,0xf6,0x00,0x0b,0xff,  \
    0xf6,0x00,0xfe,0xfe,0xf5,0x00,0xf0,0xfe,0xf5,0x00,0xe3,0xfe,0xf4,0x00,0xd5,0xfe,0xf3,0x00,0xc7,0xfe,0xf2,0x00,0xba,0xfe,0xf2,0x00,0xac,0xfe,0xf1,0x00,0x9f,0xfe,0xf0,0x00,0x91,0xfe,0xef,0x00,0x83,0xfe,0xee,0x00,0x76,0xfe,0xed,0x00,0x68,0xfe,0xec,0x00,0x5a,0xfe,0xeb,0x00,0x4d,0xfe,0xea,0x00,0x40,0xfe,0xe9,0x00,0x33,0xfe,0xe7,0x00,0x26,0xfe,0xe6,0x00,0x19,0xfe,0xe5,0x00,0x0b,0xfe,0xe4,0x00,0xfe,0xfd,0xe2,0x00,0xf1,0xfd,0xe1,0x00,0xe4,0xfd,0xdf,0x00,  \
    0xd7,0xfd,0xde,0x00,0xca,0xfd,0xdc,0x00,0xbd,0xfd,0xdb,0x00,0xb0,0xfd,0xd9,0x00,0xa3,0xfd,0xd7,0x00,0x96,0xfd,0xd5,0x00,0x88,0xfd,0xd4,0x00,0x7b,0xfd,0xd2,0x00,0x6e,0xfd,0xd0,0x00,0x61,0xfd,0xce,0x00,0x54,0xfd,0xcc,0x00,0x47,0xfd,0xca,0x00,0x3a,0xfd,0xc8,0x00,0x2d,0xfd,0xc6,0x00,0x20,0xfd,0xc4,0x00,0x13,0xfd,0xc2,0x00,0x06,0xfd,0xc0,0x00,0xf9,0xfc,0xbd,0x00,0xec,0xfc,0xbb,0x00,0xde,0xfc,0xb9,0x00,0xd0,0xfc,0xb7,0x00,0xc1,0xfc,0xb4,0x00,0xb3,0xfc,  \
    0xb2,0x00,0xa5,0xfc,0xb0,0x00,0x97,0xfc,0xad,0x00,0x89,0xfc,0xab,0x00,0x7a,0xfc,0xa8,0x00,0x6c,0xfc,0xa6,0x00,0x5e,0xfc,0xa3,0x00,0x4f,0xfc,0xa1,0x00,0x41,0xfc,0x9e,0x00,0x32,0xfc,0x9b,0x00,0x24,0xfc,0x99,0x00,0x15,0xfc,0x96,0x00,0x07,0xfc,0x93,0x00,0xf8,0xfb,0x91,0x00,0xe9,0xfb,0x8e,0x00,0xdb,0xfb,0x8b,0x00,0xcc,0xfb,0x88,0x00,0xbd,0xfb,0x85,0x00,0xae,0xfb,0x82,0x00,0xa0,0xfb,0x7f,0x00,0x91,0xfb,0x7c,0x00,0x82,0xfb,0x79,0x00,0x73,0xfb,0x76,0x00,  \
    0x64,0xfb,0x73,0x00,0x55,0xfb,0x70,0x00,0x47,0xfb,0x6c,0x00,0x38,0xfb,0x69,0x00,0x29,0xfb,0x66,0x00,0x1b,0xfb,0x62,0x00,0x0c,0xfb,0x5f,0x00,0xfd,0xfa,0x5b,0x00,0xee,0xfa,0x58,0x00,0xe0,0xfa,0x54,0x00,0xd1,0xfa,0x51,0x00,0xc2,0xfa,0x4d,0x00,0xb3,0xfa,0x49,0x00,0xa4,0xfa,0x46,0x00,0x95,0xfa,0x42,0x00,0x86,0xfa,0x3e,0x00,0x77,0xfa,0x3b,0x00,0x68,0xfa,0x37,0x00,0x58,0xfa,0x33,0x00,0x49,0xfa,0x2f,0x00,0x3a,0xfa,0x2b,0x00,0x2b,0xfa,0x27,0x00,0x1b,0xfa,  \
    0x23,0x00,0x0c,0xfa,0x1f,0x00,0xfc,0xf9,0x1b,0x00,0xed,0xf9,0x17,0x00,0xde,0xf9,0x13,0x00,0xce,0xf9,0x0f,0x00,0xbf,0xf9,0x0b,0x00,0xaf,0xf9,0x06,0x00,0xa0,0xf9,0x02,0x00,0x90,0xf9,0xfe,0xff,0x80,0xf9,0xf9,0xff,0x71,0xf9,0xf5,0xff,0x61,0xf9,0xf1,0xff,0x51,0xf9,0xec,0xff,0x41,0xf9,0xe8,0xff,0x31,0xf9,0xe3,0xff,0x21,0xf9,0xdf,0xff,0x11,0xf9,0xda,0xff,0x01,0xf9,0xd6,0xff,0xf1,0xf8,0xd1,0xff,0xe1,0xf8,0xcc,0xff,0xd1,0xf8,0xc8,0xff,0xc0,0xf8,0xc3,0xff,  \
    0xb0,0xf8,0xbe,0xff,0xa0,0xf8,0xba,0xff,0x8f,0xf8,0xb5,0xff,0x7f,0xf8,0xb0,0xff,0x6e,0xf8,0xab,0xff,0x5d,0xf8,0xa6,0xff,0x4d,0xf8,0xa1,0xff,0x3c,0xf8,0x9d,0xff,0x2b,0xf8,0x98,0xff,0x1a,0xf8,0x93,0xff,0x09,0xf8,0x8e,0xff,0xf8,0xf7,0x89,0xff,0xe7,0xf7,0x84,0xff,0xd6,0xf7,0x7f,0xff,0xc5,0xf7,0x7a,0xff,0xb3,0xf7,0x75,0xff,0xa2,0xf7,0x6f,0xff,0x90,0xf7,0x6a,0xff,0x7f,0xf7,0x65,0xff,0x6d,0xf7,0x60,0xff,0x5c,0xf7,0x5b,0xff,0x4a,0xf7,0x56,0xff,0x38,0xf7,  \
    0x50,0xff,0x26,0xf7,0x4b,0xff,0x14,0xf7,0x46,0xff,0x02,0xf7,0x41,0xff,0xf0,0xf6,0x3c,0xff,0xde,0xf6,0x36,0xff,0xcb,0xf6,0x31,0xff,0xb9,0xf6,0x2c,0xff,0xa7,0xf6,0x26,0xff,0x94,0xf6,0x21,0xff,0x81,0xf6,0x1c,0xff,0x6f,0xf6,0x16,0xff,0x5c,0xf6,0x11,0xff,0x49,0xf6,0x0c,0xff,0x36,0xf6,0x06,0xff,0x23,0xf6,0x01,0xff,0x10,0xf6,0xfb,0xfe,0xfd,0xf5,0xf6,0xfe,0xe9,0xf5,0xf1,0xfe,0xd6,0xf5,0xeb,0xfe,0xc2,0xf5,0xe6,0xfe,0xaf,0xf5,0xe1,0xfe,0x9b,0xf5,0xdb,0xfe,  \
    0x87,0xf5,0xd6,0xfe,0x73,0xf5,0xd1,0xfe,0x5e,0xf5,0xcc,0xfe,0x4a,0xf5,0xc6,0xfe,0x36,0xf5,0xc1,0xfe,0x21,0xf5,0xbc,0xfe,0x0d,0xf5,0xb6,0xfe,0xf8,0xf4,0xb1,0xfe,0xe3,0xf4,0xac,0xfe,0xce,0xf4,0xa7,0xfe,0xb9,0xf4,0xa2,0xfe,0xa4,0xf4,0x9c,0xfe,0x8f,0xf4,0x97,0xfe,0x7a,0xf4,0x92,0xfe,0x64,0xf4,0x8d,0xfe,0x4f,0xf4,0x88,0xfe,0x39,0xf4,0x83,0xfe,0x23,0xf4,0x7d,0xfe,0x0e,0xf4,0x78,0xfe,0xf8,0xf3,0x73,0xfe,0xe2,0xf3,0x6e,0xfe,0xcc,0xf3,0x69,0xfe,0xb6,0xf3,  \
    0x64,0xfe,0xa0,0xf3,0x5f,0xfe,0x89,0xf3,0x5a,0xfe,0x73,0xf3,0x55,0xfe,0x5c,0xf3,0x50,0xfe,0x45,0xf3,0x4b,0xfe,0x2f,0xf3,0x46,0xfe,0x18,0xf3,0x41,0xfe,0x01,0xf3,0x3c,0xfe,0xe9,0xf2,0x38,0xfe,0xd2,0xf2,0x33,0xfe,0xbb,0xf2,0x2e,0xfe,0xa3,0xf2,0x2a,0xfe,0x8b,0xf2,0x25,0xfe,0x73,0xf2,0x21,0xfe,0x5b,0xf2,0x1c,0xfe,0x43,0xf2,0x18,0xfe,0x2b,0xf2,0x13,0xfe,0x12,0xf2,0x0f,0xfe,0xf9,0xf1,0x0b,0xfe,0xe1,0xf1,0x07,0xfe,0xc8,0xf1,0x03,0xfe,0xaf,0xf1,0xff,0xfd,  \
    0x96,0xf1,0xfb,0xfd,0x7c,0xf1,0xf7,0xfd,0x63,0xf1,0xf3,0xfd,0x4a,0xf1,0xef,0xfd,0x30,0xf1,0xeb,0xfd,0x16,0xf1,0xe7,0xfd,0xfc,0xf0,0xe4,0xfd,0xe2,0xf0,0xe0,0xfd,0xc8,0xf0,0xdd,0xfd,0xae,0xf0,0xd9,0xfd,0x93,0xf0,0xd6,0xfd,0x79,0xf0,0xd3,0xfd,0x5e,0xf0,0xcf,0xfd,0x43,0xf0,0xcc,0xfd,0x29,0xf0,0xc9,0xfd,0x0e,0xf0,0xc6,0xfd,0xf2,0xef,0xc3,0xfd,0xd7,0xef,0xc0,0xfd,0xbc,0xef,0xbd,0xfd,0xa0,0xef,0xba,0xfd,0x85,0xef,0xb7,0xfd,0x69,0xef,0x00,0x00,0x00,0x00,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x62,0xfd,0x96,0x10,0x65,0xfd,0x7a,0x10,0x68,0xfd,0x5e,0x10,0x6b,0xfd,0x42,0x10,0x6e,0xfd,0x26,0x10,0x71,0xfd,0x0a,0x10,0x74,0xfd,0xef,0x0f,0x78,0xfd,0xd4,0x0f,0x7b,0xfd,  \
    0xb8,0x0f,0x7e,0xfd,0x9d,0x0f,0x82,0xfd,0x82,0x0f,0x86,0xfd,0x68,0x0f,0x89,0xfd,0x4d,0x0f,0x8d,0xfd,0x32,0x0f,0x91,0xfd,0x18,0x0f,0x95,0xfd,0xfe,0x0e,0x99,0xfd,0xe3,0x0e,0x9d,0xfd,0xc9,0x0e,0xa1,0xfd,0xaf,0x0e,0xa5,0xfd,0x96,0x0e,0xaa,0xfd,0x7c,0x0e,0xae,0xfd,0x62,0x0e,0xb2,0xfd,0x49,0x0e,0xb6,0xfd,0x2f,0x0e,0xbb,0xfd,0x16,0x0e,0xbf,0xfd,0xfd,0x0d,0xc4,0xfd,0xe4,0x0d,0xc8,0xfd,0xcb,0x0d,0xcd,0xfd,0xb2,0x0d,0xd2,0xfd,0x99,0x0d,0xd6,0xfd,0x80,0x0d,  \
    0xdb,0xfd,0x68,0x0d,0xe0,0xfd,0x50,0x0d,0xe5,0xfd,0x37,0x0d,0xea,0xfd,0x1f,0x0d,0xef,0xfd,0x07,0x0d,0xf4,0xfd,0xef,0x0c,0xf9,0xfd,0xd7,0x0c,0xfe,0xfd,0xc0,0x0c,0x03,0xfe,0xa8,0x0c,0x08,0xfe,0x91,0x0c,0x0e,0xfe,0x7b,0x0c,0x14,0xfe,0x65,0x0c,0x1a,0xfe,0x4f,0x0c,0x20,0xfe,0x39,0x0c,0x26,0xfe,0x23,0x0c,0x2b,0xfe,0x0d,0x0c,0x31,0xfe,0xf8,0x0b,0x37,0xfe,0xe2,0x0b,0x3d,0xfe,0xcd,0x0b,0x43,0xfe,0xb8,0x0b,0x4a,0xfe,0xa3,0x0b,0x50,0xfe,0x8e,0x0b,0x56,0xfe,  \
    0x79,0x0b,0x5c,0xfe,0x65,0x0b,0x62,0xfe,0x50,0x0b,0x68,0xfe,0x3c,0x0b,0x6e,0xfe,0x27,0x0b,0x74,0xfe,0x12,0x0b,0x7a,0xfe,0xfd,0x0a,0x7f,0xfe,0xe8,0x0a,0x85,0xfe,0xd3,0x0a,0x8b,0xfe,0xbe,0x0a,0x90,0xfe,0xa9,0x0a,0x96,0xfe,0x95,0x0a,0x9c,0xfe,0x80,0x0a,0xa1,0xfe,0x6c,0x0a,0xa7,0xfe,0x57,0x0a,0xad,0xfe,0x43,0x0a,0xb2,0xfe,0x2f,0x0a,0xb8,0xfe,0x1b,0x0a,0xbe,0xfe,0x07,0x0a,0xc3,0xfe,0xf3,0x09,0xc9,0xfe,0xdf,0x09,0xcf,0xfe,0xcb,0x09,0xd4,0xfe,0xb8,0x09,  \
    0xda,0xfe,0xa4,0x09,0xe0,0xfe,0x91,0x09,0xe6,0xfe,0x7d,0x09,0xeb,0xfe,0x6a,0x09,0xf1,0xfe,0x57,0x09,0xf6,0xfe,0x44,0x09,0xfc,0xfe,0x31,0x09,0x02,0xff,0x1e,0x09,0x07,0xff,0x0b,0x09,0x0d,0xff,0xf8,0x08,0x13,0xff,0xe5,0x08,0x18,0xff,0xd3,0x08,0x1e,0xff,0xc0,0x08,0x23,0xff,0xae,0x08,0x29,0xff,0x9b,0x08,0x2e,0xff,0x89,0x08,0x34,0xff,0x77,0x08,0x39,0xff,0x65,0x08,0x3f,0xff,0x53,0x08,0x44,0xff,0x41,0x08,0x4a,0xff,0x30,0x08,0x4f,0xff,0x1e,0x08,0x55,0xff,  \
    0x0d,0x08,0x5a,0xff,0xfb,0x07,0x60,0xff,0xea,0x07,0x65,0xff,0xd9,0x07,0x6b,0xff,0xc8,0x07,0x70,0xff,0xb7,0x07,0x76,0xff,0xa6,0x07,0x7b,0xff,0x95,0x07,0x80,0xff,0x84,0x07,0x86,0xff,0x73,0x07,0x8b,0xff,0x62,0x07,0x90,0xff,0x52,0x07,0x95,0xff,0x41,0x07,0x9a,0xff,0x30,0x07,0xa0,0xff,0x20,0x07,0xa5,0xff,0x0f,0x07,0xaa,0xff,0xff,0x06,0xaf,0xff,0xef,0x06,0xb4,0xff,0xde,0x06,0xb9,0xff,0xce,0x06,0xbe,0xff,0xbe,0x06,0xc3,0xff,0xad,0x06,0xc7,0xff,0x9d,0x06,  \
    0xcc,0xff,0x8d,0x06,0xd1,0xff,0x7d,0x06,0xd6,0xff,0x6d,0x06,0xdb,0xff,0x5d,0x06,0xdf,0xff,0x4d,0x06,0xe4,0xff,0x3d,0x06,0xe9,0xff,0x2d,0x06,0xed,0xff,0x1e,0x06,0xf2,0xff,0x0e,0x06,0xf6,0xff,0xfe,0x05,0xfb,0xff,0xef,0x05,0xff,0xff,0xdf,0x05,0x04,0x00,0xd0,0x05,0x08,0x00,0xc0,0x05,0x0c,0x00,0xb1,0x05,0x11,0x00,0xa1,0x05,0x15,0x00,0x91,0x05,0x19,0x00,0x81,0x05,0x1d,0x00,0x71,0x05,0x21,0x00,0x62,0x05,0x25,0x00,0x52,0x05,0x29,0x00,0x42,0x05,0x2d,0x00,  \
    0x32,0x05,0x31,0x00,0x23,0x05,0x35,0x00,0x13,0x05,0x38,0x00,0x03,0x05,0x3c,0x00,0xf4,0x04,0x40,0x00,0xe4,0x04,0x44,0x00,0xd5,0x04,0x47,0x00,0xc6,0x04,0x4b,0x00,0xb6,0x04,0x4f,0x00,0xa7,0x04,0x52,0x00,0x98,0x04,0x56,0x00,0x88,0x04,0x59,0x00,0x79,0x04,0x5d,0x00,0x6a,0x04,0x60,0x00,0x5b,0x04,0x64,0x00,0x4c,0x04,0x67,0x00,0x3d,0x04,0x6a,0x00,0x2e,0x04,0x6e,0x00,0x1f,0x04,0x71,0x00,0x11,0x04,0x74,0x00,0x02,0x04,0x78,0x00,0xf4,0x03,0x7b,0x00,0xe5,0x03,  \
    0x7e,0x00,0xd7,0x03,0x81,0x00,0xc8,0x03,0x84,0x00,0xba,0x03,0x87,0x00,0xab,0x03,0x8a,0x00,0x9d,0x03,0x8d,0x00,0x8f,0x03,0x90,0x00,0x80,0x03,0x93,0x00,0x72,0x03,0x96,0x00,0x64,0x03,0x99,0x00,0x56,0x03,0x9c,0x00,0x47,0x03,0x9e,0x00,0x39,0x03,0xa1,0x00,0x2b,0x03,0xa4,0x00,0x1d,0x03,0xa6,0x00,0x0f,0x03,0xa9,0x00,0x01,0x03,0xac,0x00,0xf3,0x02,0xae,0x00,0xe5,0x02,0xb0,0x00,0xd7,0x02,0xb3,0x00,0xc9,0x02,0xb5,0x00,0xbb,0x02,0xb8,0x00,0xad,0x02,0xba,0x00,  \
    0x9f,0x02,0xbc,0x00,0x91,0x02,0xbe,0x00,0x84,0x02,0xc1,0x00,0x76,0x02,0xc3,0x00,0x68,0x02,0xc5,0x00,0x5b,0x02,0xc7,0x00,0x4d,0x02,0xc9,0x00,0x3f,0x02,0xcb,0x00,0x32,0x02,0xcd,0x00,0x24,0x02,0xcf,0x00,0x16,0x02,0xd1,0x00,0x09,0x02,0xd2,0x00,0xfb,0x01,0xd4,0x00,0xee,0x01,0xd6,0x00,0xe0,0x01,0xd8,0x00,0xd3,0x01,0xd9,0x00,0xc5,0x01,0xdb,0x00,0xb7,0x01,0xdc,0x00,0xaa,0x01,0xde,0x00,0x9c,0x01,0xdf,0x00,0x8f,0x01,0xe1,0x00,0x81,0x01,0xe2,0x00,0x74,0x01,  \
    0xe4,0x00,0x66,0x01,0xe5,0x00,0x59,0x01,0xe6,0x00,0x4b,0x01,0xe7,0x00,0x3e,0x01,0xe8,0x00,0x30,0x01,0xea,0x00,0x23,0x01,0xeb,0x00,0x15,0x01,0xec,0x00,0x08,0x01,0xed,0x00,0xfa,0x00,0xee,0x00,0xed,0x00,0xef,0x00,0xe0,0x00,0xef,0x00,0xd2,0x00,0xf0,0x00,0xc5,0x00,0xf1,0x00,0xb7,0x00,0xf2,0x00,0xaa,0x00,0xf3,0x00,0x9c,0x00,0xf3,0x00,0x8f,0x00,0xf4,0x00,0x82,0x00,0xf4,0x00,0x74,0x00,0xf5,0x00,0x67,0x00,0xf5,0x00,0x59,0x00,0xf6,0x00,0x4c,0x00,0xf6,0x00,  \
    0x3f,0x00,0xf7,0x00,0x31,0x00,0xf7,0x00,0x24,0x00,0xf7,0x00,0x16,0x00,0xf8,0x00,0x09,0x00,0xf8,0x00,0xfc,0xff,0xf8,0x00,0xee,0xff,0xf8,0x00,0xe1,0xff,0xf8,0x00,0xd4,0xff,0xf8,0x00,0xc6,0xff,0xf8,0x00,0xb9,0xff,0xf8,0x00,0xab,0xff,0xf8,0x00,0x9e,0xff,0xf8,0x00,0x91,0xff,0xf8,0x00,0x83,0xff,0xf8,0x00,0x76,0xff,0xf7,0x00,0x68,0xff,0xf7,0x00,0x5b,0xff,0xf7,0x00,0x4d,0xff,0xf6,0x00,0x40,0xff,0xf6,0x00,0x32,0xff,0xf5,0x00,0x25,0xff,0xf5,0x00,0x17,0xff,  \
    0xf4,0x00,0x0a,0xff,0xf4,0x00,0xfc,0xfe,0xf3,0x00,0xef,0xfe,0xf3,0x00,0xe1,0xfe,0xf2,0x00,0xd3,0xfe,0xf1,0x00,0xc6,0xfe,0xf0,0x00,0xb8,0xfe,0xf0,0x00,0xab,0xfe,0xef,0x00,0x9d,0xfe,0xee,0x00,0x8f,0xfe,0xed,0x00,0x81,0xfe,0xec,0x00,0x74,0xfe,0xeb,0x00,0x66,0xfe,0xea,0x00,0x58,0xfe,0xe9,0x00,0x4b,0xfe,0xe8,0x00,0x3d,0xfe,0xe7,0x00,0x30,0xfe,0xe5,0x00,0x23,0xfe,0xe4,0x00,0x16,0xfe,0xe3,0x00,0x09,0xfe,0xe2,0x00,0xfb,0xfd,0xe0,0x00,0xee,0xfd,0xdf,0x00,  \
    0xe1,0xfd,0xdd,0x00,0xd4,0xfd,0xdc,0x00,0xc7,0xfd,0xda,0x00,0xba,0xfd,0xd9,0x00,0xac,0xfd,0xd7,0x00,0x9f,0xfd,0xd5,0x00,0x92,0xfd,0xd3,0x00,0x85,0xfd,0xd2,0x00,0x78,0xfd,0xd0,0x00,0x6b,0xfd,0xce,0x00,0x5e,0xfd,0xcc,0x00,0x51,0xfd,0xca,0x00,0x43,0xfd,0xc8,0x00,0x36,0xfd,0xc6,0x00,0x29,0xfd,0xc4,0x00,0x1c,0xfd,0xc2,0x00,0x0f,0xfd,0xc0,0x00,0x02,0xfd,0xbd,0x00,0xf5,0xfc,0xbb,0x00,0xe8,0xfc,0xb9,0x00,0xd9,0xfc,0xb7,0x00,0xcb,0xfc,0xb4,0x00,0xbd,0xfc,  \
    0xb2,0x00,0xaf,0xfc,0xb0,0x00,0xa1,0xfc,0xad,0x00,0x92,0xfc,0xab,0x00,0x84,0xfc,0xa9,0x00,0x76,0xfc,0xa6,0x00,0x67,0xfc,0xa4,0x00,0x59,0xfc,0xa1,0x00,0x4a,0xfc,0x9e,0x00,0x3c,0xfc,0x9c,0x00,0x2d,0xfc,0x99,0x00,0x1f,0xfc,0x96,0x00,0x10,0xfc,0x94,0x00,0x01,0xfc,0x91,0x00,0xf3,0xfb,0x8e,0x00,0xe4,0xfb,0x8b,0x00,0xd5,0xfb,0x88,0x00,0xc6,0xfb,0x86,0x00,0xb7,0xfb,0x83,0x00,0xa9,0xfb,0x80,0x00,0x9a,0xfb,0x7d,0x00,0x8b,0xfb,0x7a,0x00,0x7c,0xfb,0x77,0x00,  \
    0x6d,0xfb,0x73,0x00,0x5e,0xfb,0x70,0x00,0x4f,0xfb,0x6d,0x00,0x40,0xfb,0x6a,0x00,0x32,0xfb,0x66,0x00,0x23,0xfb,0x63,0x00,0x14,0xfb,0x60,0x00,0x05,0xfb,0x5c,0x00,0xf7,0xfa,0x59,0x00,0xe8,0xfa,0x55,0x00,0xd9,0xfa,0x52,0x00,0xca,0xfa,0x4e,0x00,0xbb,0xfa,0x4a,0x00,0xac,0xfa,0x47,0x00,0x9d,0xfa,0x43,0x00,0x8e,0xfa,0x3f,0x00,0x7f,0xfa,0x3c,0x00,0x70,0xfa,0x38,0x00,0x60,0xfa,0x34,0x00,0x51,0xfa,0x30,0x00,0x42,0xfa,0x2c,0x00,0x33,0xfa,0x28,0x00,0x23,0xfa,  \
    0x24,0x00,0x14,0xfa,0x20,0x00,0x04,0xfa,0x1c,0x00,0xf5,0xf9,0x18,0x00,0xe6,0xf9,0x14,0x00,0xd6,0xf9,0x10,0x00,0xc7,0xf9,0x0c,0x00,0xb7,0xf9,0x07,0x00,0xa8,0xf9,0x03,0x00,0x98,0xf9,0xff,0xff,0x88,0xf9,0xfb,0xff,0x79,0xf9,0xf6,0xff,0x69,0xf9,0xf2,0xff,0x59,0xf9,0xed,0xff,0x49,0xf9,0xe9,0xff,0x39,0xf9,0xe4,0xff,0x2a,0xf9,0xe0,0xff,0x1a,0xf9,0xdb,0xff,0x09,0xf9,0xd7,0xff,0xf9,0xf8,0xd2,0xff,0xe9,0xf8,0xce,0xff,0xd9,0xf8,0xc9,0xff,0xc9,0xf8,0xc4,0xff,  \
    0xb8,0xf8,0xc0,0xff,0xa8,0xf8,0xbb,0xff,0x98,0xf8,0xb6,0xff,0x87,0xf8,0xb1,0xff,0x77,0xf8,0xac,0xff,0x66,0xf8,0xa7,0xff,0x55,0xf8,0xa3,0xff,0x45,0xf8,0x9e,0xff,0x34,0xf8,0x99,0xff,0x23,0xf8,0x94,0xff,0x12,0xf8,0x8f,0xff,0x01,0xf8,0x8a,0xff,0xf0,0xf7,0x85,0xff,0xdf,0xf7,0x80,0xff,0xce,0xf7,0x7b,0xff,0xbd,0xf7,0x76,0xff,0xab,0xf7,0x70,0xff,0x9a,0xf7,0x6b,0xff,0x88,0xf7,0x66,0xff,0x77,0xf7,0x61,0xff,0x65,0xf7,0x5c,0xff,0x54,0xf7,0x57,0xff,0x42,0xf7,  \
    0x51,0xff,0x30,0xf7,0x4c,0xff,0x1e,0xf7,0x47,0xff,0x0c,0xf7,0x42,0xff,0xfa,0xf6,0x3c,0xff,0xe8,0xf6,0x37,0xff,0xd6,0xf6,0x32,0xff,0xc3,0xf6,0x2c,0xff,0xb1,0xf6,0x27,0xff,0x9f,0xf6,0x22,0xff,0x8c,0xf6,0x1c,0xff,0x79,0xf6,0x17,0xff,0x67,0xf6,0x11,0xff,0x54,0xf6,0x0c,0xff,0x41,0xf6,0x07,0xff,0x2e,0xf6,0x01,0xff,0x1b,0xf6,0xfc,0xfe,0x08,0xf6,0xf6,0xfe,0xf5,0xf5,0xf1,0xfe,0xe1,0xf5,0xeb,0xfe,0xce,0xf5,0xe6,0xfe,0xba,0xf5,0xe1,0xfe,0xa7,0xf5,0xdb,0xfe,  \
    0x93,0xf5,0xd6,0xfe,0x7f,0xf5,0xd1,0xfe,0x6b,0xf5,0xcb,0xfe,0x57,0xf5,0xc6,0xfe,0x42,0xf5,0xc1,0xfe,0x2e,0xf5,0xbb,0xfe,0x19,0xf5,0xb6,0xfe,0x05,0xf5,0xb1,0xfe,0xf0,0xf4,0xab,0xfe,0xdb,0xf4,0xa6,0xfe,0xc7,0xf4,0xa1,0xfe,0xb2,0xf4,0x9c,0xfe,0x9c,0xf4,0x96,0xfe,0x87,0xf4,0x91,0xfe,0x72,0xf4,0x8c,0xfe,0x5d,0xf4,0x87,0xfe,0x47,0xf4,0x82,0xfe,0x31,0xf4,0x7c,0xfe,0x1c,0xf4,0x77,0xfe,0x06,0xf4,0x72,0xfe,0xf0,0xf3,0x6d,0xfe,0xda,0xf3,0x68,0xfe,0xc4,0xf3,  \
    0x62,0xfe,0xae,0xf3,0x5d,0xfe,0x98,0xf3,0x58,0xfe,0x82,0xf3,0x53,0xfe,0x6b,0xf3,0x4e,0xfe,0x55,0xf3,0x49,0xfe,0x3e,0xf3,0x44,0xfe,0x27,0xf3,0x3f,0xfe,0x10,0xf3,0x3a,0xfe,0xf9,0xf2,0x35,0xfe,0xe2,0xf2,0x31,0xfe,0xcb,0xf2,0x2c,0xfe,0xb3,0xf2,0x27,0xfe,0x9c,0xf2,0x22,0xfe,0x84,0xf2,0x1e,0xfe,0x6c,0xf2,0x19,0xfe,0x54,0xf2,0x15,0xfe,0x3c,0xf2,0x10,0xfe,0x23,0xf2,0x0c,0xfe,0x0b,0xf2,0x08,0xfe,0xf2,0xf1,0x04,0xfe,0xda,0xf1,0xff,0xfd,0xc1,0xf1,0xfb,0xfd,  \
    0xa8,0xf1,0xf7,0xfd,0x8f,0xf1,0xf3,0xfd,0x76,0xf1,0xef,0xfd,0x5c,0xf1,0xeb,0xfd,0x43,0xf1,0xe7,0xfd,0x29,0xf1,0xe3,0xfd,0x0f,0xf1,0xe0,0xfd,0xf5,0xf0,0xdc,0xfd,0xdb,0xf0,0xd8,0xfd,0xc1,0xf0,0xd5,0xfd,0xa7,0xf0,0xd1,0xfd,0x8c,0xf0,0xce,0xfd,0x72,0xf0,0xcb,0xfd,0x57,0xf0,0xc7,0xfd,0x3d,0xf0,0xc4,0xfd,0x22,0xf0,0xc1,0xfd,0x07,0xf0,0xbd,0xfd,0xec,0xef,0xba,0xfd,0xd1,0xef,0xb7,0xfd,0xb5,0xef,0xb5,0xfd,0x9a,0xef,0xb2,0xfd,0x7e,0xef,0xaf,0xfd,0x62,0xef,  \
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x56,0xfd,0x9b,0x10,0x59,0xfd,0x7f,0x10,0x5c,0xfd,0x63,0x10,0x5f,0xfd,0x47,0x10,0x62,0xfd,0x2b,0x10,0x65,0xfd,0x10,0x10,0x68,0xfd,0xf4,0x0f,0x6c,0xfd,  \
    0xd9,0x0f,0x6f,0xfd,0xbe,0x0f,0x73,0xfd,0xa3,0x0f,0x76,0xfd,0x88,0x0f,0x7a,0xfd,0x6d,0x0f,0x7e,0xfd,0x52,0x0f,0x81,0xfd,0x38,0x0f,0x85,0xfd,0x1d,0x0f,0x89,0xfd,0x03,0x0f,0x8d,0xfd,0xe9,0x0e,0x92,0xfd,0xcf,0x0e,0x96,0xfd,0xb5,0x0e,0x9a,0xfd,0x9b,0x0e,0x9e,0xfd,0x81,0x0e,0xa3,0xfd,0x68,0x0e,0xa7,0xfd,0x4e,0x0e,0xab,0xfd,0x35,0x0e,0xb0,0xfd,0x1b,0x0e,0xb4,0xfd,0x02,0x0e,0xb9,0xfd,0xe9,0x0d,0xbe,0xfd,0xd0,0x0d,0xc2,0xfd,0xb7,0x0d,0xc7,0xfd,0x9f,0x0d,  \
    0xcc,0xfd,0x86,0x0d,0xd1,0xfd,0x6e,0x0d,0xd6,0xfd,0x55,0x0d,0xda,0xfd,0x3d,0x0d,0xdf,0xfd,0x25,0x0d,0xe4,0xfd,0x0d,0x0d,0xe9,0xfd,0xf5,0x0c,0xef,0xfd,0xdd,0x0c,0xf4,0xfd,0xc6,0x0c,0xf9,0xfd,0xae,0x0c,0xfe,0xfd,0x97,0x0c,0x04,0xfe,0x81,0x0c,0x0a,0xfe,0x6b,0x0c,0x10,0xfe,0x55,0x0c,0x16,0xfe,0x3f,0x0c,0x1c,0xfe,0x29,0x0c,0x22,0xfe,0x14,0x0c,0x28,0xfe,0xfe,0x0b,0x2e,0xfe,0xe9,0x0b,0x34,0xfe,0xd4,0x0b,0x3b,0xfe,0xbe,0x0b,0x41,0xfe,0xaa,0x0b,0x47,0xfe,  \
    0x95,0x0b,0x4d,0xfe,0x80,0x0b,0x53,0xfe,0x6b,0x0b,0x5a,0xfe,0x57,0x0b,0x60,0xfe,0x43,0x0b,0x66,0xfe,0x2e,0x0b,0x6c,0xfe,0x19,0x0b,0x72,0xfe,0x04,0x0b,0x77,0xfe,0xef,0x0a,0x7d,0xfe,0xda,0x0a,0x83,0xfe,0xc5,0x0a,0x89,0xfe,0xb1,0x0a,0x8e,0xfe,0x9c,0x0a,0x94,0xfe,0x87,0x0a,0x9a,0xfe,0x73,0x0a,0xa0,0xfe,0x5f,0x0a,0xa5,0xfe,0x4a,0x0a,0xab,0xfe,0x36,0x0a,0xb1,0xfe,0x22,0x0a,0xb7,0xfe,0x0e,0x0a,0xbc,0xfe,0xfa,0x09,0xc2,0xfe,0xe6,0x09,0xc8,0xfe,0xd2,0x09,  \
    0xce,0xfe,0xbf,0x09,0xd3,0xfe,0xab,0x09,0xd9,0xfe,0x98,0x09,0xdf,0xfe,0x85,0x09,0xe4,0xfe,0x71,0x09,0xea,0xfe,0x5e,0x09,0xf0,0xfe,0x4b,0x09,0xf6,0xfe,0x38,0x09,0xfb,0xfe,0x25,0x09,0x01,0xff,0x12,0x09,0x07,0xff,0xff,0x08,0x0c,0xff,0xed,0x08,0x12,0xff,0xda,0x08,0x17,0xff,0xc8,0x08,0x1d,0xff,0xb5,0x08,0x23,0xff,0xa3,0x08,0x28,0xff,0x90,0x08,0x2e,0xff,0x7e,0x08,0x33,0xff,0x6c,0x08,0x39,0xff,0x5a,0x08,0x3f,0xff,0x49,0x08,0x44,0xff,0x37,0x08,0x4a,0xff,  \
    0x26,0x08,0x4f,0xff,0x14,0x08,0x55,0xff,0x03,0x08,0x5b,0xff,0xf2,0x07,0x60,0xff,0xe0,0x07,0x66,0xff,0xcf,0x07,0x6b,0xff,0xbe,0x07,0x70,0xff,0xad,0x07,0x76,0xff,0x9c,0x07,0x7b,0xff,0x8b,0x07,0x81,0xff,0x7b,0x07,0x86,0xff,0x6a,0x07,0x8b,0xff,0x59,0x07,0x90,0xff,0x49,0x07,0x96,0xff,0x38,0x07,0x9b,0xff,0x28,0x07,0xa0,0xff,0x17,0x07,0xa5,0xff,0x07,0x07,0xaa,0xff,0xf6,0x06,0xaf,0xff,0xe6,0x06,0xb4,0xff,0xd5,0x06,0xb9,0xff,0xc5,0x06,0xbe,0xff,0xb5,0x06,  \
    0xc3,0xff,0xa5,0x06,0xc8,0xff,0x95,0x06,0xcd,0xff,0x85,0x06,0xd2,0xff,0x75,0x06,0xd6,0xff,0x65,0x06,0xdb,0xff,0x55,0x06,0xe0,0xff,0x45,0x06,0xe5,0xff,0x35,0x06,0xe9,0xff,0x25,0x06,0xee,0xff,0x15,0x06,0xf2,0xff,0x06,0x06,0xf7,0xff,0xf6,0x05,0xfb,0xff,0xe6,0x05,0x00,0x00,0xd7,0x05,0x04,0x00,0xc7,0x05,0x09,0x00,0xb8,0x05,0x0d,0x00,0xa8,0x05,0x11,0x00,0x98,0x05,0x15,0x00,0x89,0x05,0x19,0x00,0x79,0x05,0x1d,0x00,0x69,0x05,0x21,0x00,0x59,0x05,0x25,0x00,  \
    0x49,0x05,0x29,0x00,0x39,0x05,0x2d,0x00,0x2a,0x05,0x31,0x00,0x1a,0x05,0x35,0x00,0x0a,0x05,0x39,0x00,0xfb,0x04,0x3d,0x00,0xeb,0x04,0x40,0x00,0xdc,0x04,0x44,0x00,0xcc,0x04,0x48,0x00,0xbd,0x04,0x4b,0x00,0xad,0x04,0x4f,0x00,0x9e,0x04,0x53,0x00,0x8f,0x04,0x56,0x00,0x80,0x04,0x5a,0x00,0x70,0x04,0x5d,0x00,0x61,0x04,0x61,0x00,0x52,0x04,0x64,0x00,0x43,0x04,0x67,0x00,0x34,0x04,0x6b,0x00,0x25,0x04,0x6e,0x00,0x17,0x04,0x71,0x00,0x08,0x04,0x75,0x00,0xf9,0x03,  \
    0x78,0x00,0xeb,0x03,0x7b,0x00,0xdc,0x03,0x7e,0x00,0xce,0x03,0x81,0x00,0xbf,0x03,0x85,0x00,0xb1,0x03,0x88,0x00,0xa2,0x03,0x8b,0x00,0x94,0x03,0x8e,0x00,0x86,0x03,0x90,0x00,0x77,0x03,0x93,0x00,0x69,0x03,0x96,0x00,0x5b,0x03,0x99,0x00,0x4c,0x03,0x9c,0x00,0x3e,0x03,0x9e,0x00,0x30,0x03,0xa1,0x00,0x22,0x03,0xa4,0x00,0x14,0x03,0xa6,0x00,0x05,0x03,0xa9,0x00,0xf7,0x02,0xab,0x00,0xe9,0x02,0xae,0x00,0xdb,0x02,0xb0,0x00,0xcd,0x02,0xb3,0x00,0xbf,0x02,0xb5,0x00,  \
    0xb1,0x02,0xb7,0x00,0xa3,0x02,0xba,0x00,0x96,0x02,0xbc,0x00,0x88,0x02,0xbe,0x00,0x7a,0x02,0xc0,0x00,0x6c,0x02,0xc2,0x00,0x5f,0x02,0xc5,0x00,0x51,0x02,0xc7,0x00,0x43,0x02,0xc9,0x00,0x35,0x02,0xca,0x00,0x28,0x02,0xcc,0x00,0x1a,0x02,0xce,0x00,0x0c,0x02,0xd0,0x00,0xff,0x01,0xd2,0x00,0xf1,0x01,0xd4,0x00,0xe3,0x01,0xd5,0x00,0xd6,0x01,0xd7,0x00,0xc8,0x01,0xd9,0x00,0xba,0x01,0xda,0x00,0xad,0x01,0xdc,0x00,0x9f,0x01,0xdd,0x00,0x92,0x01,0xdf,0x00,0x84,0x01,  \
    0xe0,0x00,0x77,0x01,0xe1,0x00,0x69,0x01,0xe3,0x00,0x5b,0x01,0xe4,0x00,0x4e,0x01,0xe5,0x00,0x40,0x01,0xe6,0x00,0x33,0x01,0xe7,0x00,0x25,0x01,0xe8,0x00,0x18,0x01,0xea,0x00,0x0a,0x01,0xeb,0x00,0xfc,0x00,0xeb,0x00,0xef,0x00,0xec,0x00,0xe1,0x00,0xed,0x00,0xd4,0x00,0xee,0x00,0xc6,0x00,0xef,0x00,0xb9,0x00,0xf0,0x00,0xab,0x00,0xf0,0x00,0x9e,0x00,0xf1,0x00,0x90,0x00,0xf2,0x00,0x83,0x00,0xf2,0x00,0x75,0x00,0xf3,0x00,0x68,0x00,0xf3,0x00,0x5a,0x00,0xf4,0x00,  \
    0x4d,0x00,0xf4,0x00,0x3f,0x00,0xf5,0x00,0x32,0x00,0xf5,0x00,0x24,0x00,0xf5,0x00,0x17,0x00,0xf5,0x00,0x0a,0x00,0xf6,0x00,0xfc,0xff,0xf6,0x00,0xef,0xff,0xf6,0x00,0xe1,0xff,0xf6,0x00,0xd4,0xff,0xf6,0x00,0xc6,0xff,0xf6,0x00,0xb9,0xff,0xf6,0x00,0xab,0xff,0xf6,0x00,0x9e,0xff,0xf6,0x00,0x90,0xff,0xf6,0x00,0x83,0xff,0xf5,0x00,0x75,0xff,0xf5,0x00,0x68,0xff,0xf5,0x00,0x5a,0xff,0xf5,0x00,0x4d,0xff,0xf4,0x00,0x3f,0xff,0xf4,0x00,0x31,0xff,0xf3,0x00,0x24,0xff,  \
    0xf3,0x00,0x16,0xff,0xf2,0x00,0x09,0xff,0xf2,0x00,0xfb,0xfe,0xf1,0x00,0xed,0xfe,0xf1,0x00,0xe0,0xfe,0xf0,0x00,0xd2,0xfe,0xef,0x00,0xc4,0xfe,0xee,0x00,0xb6,0xfe,0xee,0x00,0xa9,0xfe,0xed,0x00,0x9b,0xfe,0xec,0x00,0x8d,0xfe,0xeb,0x00,0x7f,0xfe,0xea,0x00,0x71,0xfe,0xe9,0x00,0x64,0xfe,0xe8,0x00,0x56,0xfe,0xe7,0x00,0x48,0xfe,0xe6,0x00,0x3b,0xfe,0xe5,0x00,0x2e,0xfe,0xe3,0x00,0x20,0xfe,0xe2,0x00,0x13,0xfe,0xe1,0x00,0x06,0xfe,0xdf,0x00,0xf8,0xfd,0xde,0x00,  \
    0xeb,0xfd,0xdd,0x00,0xde,0xfd,0xdb,0x00,0xd1,0xfd,0xd9,0x00,0xc4,0xfd,0xd8,0x00,0xb6,0xfd,0xd6,0x00,0xa9,0xfd,0xd5,0x00,0x9c,0xfd,0xd3,0x00,0x8f,0xfd,0xd1,0x00,0x82,0xfd,0xcf,0x00,0x74,0xfd,0xce,0x00,0x67,0xfd,0xcc,0x00,0x5a,0xfd,0xca,0x00,0x4d,0xfd,0xc8,0x00,0x40,0xfd,0xc6,0x00,0x33,0xfd,0xc4,0x00,0x25,0xfd,0xc2,0x00,0x18,0xfd,0xbf,0x00,0x0b,0xfd,0xbd,0x00,0xfe,0xfc,0xbb,0x00,0xf1,0xfc,0xb9,0x00,0xe3,0xfc,0xb6,0x00,0xd5,0xfc,0xb4,0x00,0xc7,0xfc,  \
    0xb2,0x00,0xb9,0xfc,0xb0,0x00,0xaa,0xfc,0xad,0x00,0x9c,0xfc,0xab,0x00,0x8e,0xfc,0xa8,0x00,0x7f,0xfc,0xa6,0x00,0x71,0xfc,0xa4,0x00,0x62,0xfc,0xa1,0x00,0x54,0xfc,0x9e,0x00,0x45,0xfc,0x9c,0x00,0x37,0xfc,0x99,0x00,0x28,0xfc,0x97,0x00,0x19,0xfc,0x94,0x00,0x0b,0xfc,0x91,0x00,0xfc,0xfb,0x8e,0x00,0xed,0xfb,0x8c,0x00,0xde,0xfb,0x89,0x00,0xcf,0xfb,0x86,0x00,0xc1,0xfb,0x83,0x00,0xb2,0xfb,0x80,0x00,0xa3,0xfb,0x7d,0x00,0x94,0xfb,0x7a,0x00,0x85,0xfb,0x77,0x00,  \
    0x76,0xfb,0x74,0x00,0x66,0xfb,0x71,0x00,0x57,0xfb,0x6e,0x00,0x49,0xfb,0x6a,0x00,0x3a,0xfb,0x67,0x00,0x2b,0xfb,0x64,0x00,0x1d,0xfb,0x60,0x00,0x0e,0xfb,0x5d,0x00,0xff,0xfa,0x59,0x00,0xf0,0xfa,0x56,0x00,0xe1,0xfa,0x52,0x00,0xd2,0xfa,0x4f,0x00,0xc3,0xfa,0x4b,0x00,0xb4,0xfa,0x47,0x00,0xa5,0xfa,0x44,0x00,0x96,0xfa,0x40,0x00,0x87,0xfa,0x3c,0x00,0x78,0xfa,0x39,0x00,0x69,0xfa,0x35,0x00,0x59,0xfa,0x31,0x00,0x4a,0xfa,0x2d,0x00,0x3b,0xfa,0x29,0x00,0x2b,0xfa,  \
    0x25,0x00,0x1c,0xfa,0x21,0x00,0x0d,0xfa,0x1d,0x00,0xfd,0xf9,0x19,0x00,0xee,0xf9,0x15,0x00,0xde,0xf9,0x11,0x00,0xcf,0xf9,0x0d,0x00,0xbf,0xf9,0x08,0x00,0xb0,0xf9,0x04,0x00,0xa0,0xf9,0x00,0x00,0x90,0xf9,0xfc,0xff,0x81,0xf9,0xf7,0xff,0x71,0xf9,0xf3,0xff,0x61,0xf9,0xee,0xff,0x51,0xf9,0xea,0xff,0x42,0xf9,0xe5,0xff,0x32,0xf9,0xe1,0xff,0x22,0xf9,0xdc,0xff,0x12,0xf9,0xd8,0xff,0x02,0xf9,0xd3,0xff,0xf2,0xf8,0xcf,0xff,0xe1,0xf8,0xca,0xff,0xd1,0xf8,0xc5,0xff,  \
    0xc1,0xf8,0xc0,0xff,0xb1,0xf8,0xbc,0xff,0xa0,0xf8,0xb7,0xff,0x90,0xf8,0xb2,0xff,0x7f,0xf8,0xad,0xff,0x6f,0xf8,0xa8,0xff,0x5e,0xf8,0xa4,0xff,0x4d,0xf8,0x9f,0xff,0x3d,0xf8,0x9a,0xff,0x2c,0xf8,0x95,0xff,0x1b,0xf8,0x90,0xff,0x0a,0xf8,0x8b,0xff,0xf9,0xf7,0x86,0xff,0xe8,0xf7,0x81,0xff,0xd7,0xf7,0x7b,0xff,0xc6,0xf7,0x76,0xff,0xb4,0xf7,0x71,0xff,0xa3,0xf7,0x6c,0xff,0x92,0xf7,0x67,0xff,0x80,0xf7,0x62,0xff,0x6f,0xf7,0x5c,0xff,0x5d,0xf7,0x57,0xff,0x4b,0xf7,  \
    0x52,0xff,0x3a,0xf7,0x4d,0xff,0x28,0xf7,0x47,0xff,0x16,0xf7,0x42,0xff,0x04,0xf7,0x3d,0xff,0xf2,0xf6,0x37,0xff,0xe0,0xf6,0x32,0xff,0xce,0xf6,0x2d,0xff,0xbb,0xf6,0x27,0xff,0xa9,0xf6,0x22,0xff,0x97,0xf6,0x1c,0xff,0x84,0xf6,0x17,0xff,0x71,0xf6,0x12,0xff,0x5f,0xf6,0x0c,0xff,0x4c,0xf6,0x07,0xff,0x39,0xf6,0x01,0xff,0x26,0xf6,0xfc,0xfe,0x13,0xf6,0xf6,0xfe,0x00,0xf6,0xf1,0xfe,0xed,0xf5,0xeb,0xfe,0xd9,0xf5,0xe6,0xfe,0xc6,0xf5,0xe0,0xfe,0xb3,0xf5,0xdb,0xfe,  \
    0x9f,0xf5,0xd6,0xfe,0x8b,0xf5,0xd0,0xfe,0x77,0xf5,0xcb,0xfe,0x63,0xf5,0xc5,0xfe,0x4f,0xf5,0xc0,0xfe,0x3b,0xf5,0xbb,0xfe,0x26,0xf5,0xb5,0xfe,0x12,0xf5,0xb0,0xfe,0xfd,0xf4,0xab,0xfe,0xe8,0xf4,0xa5,0xfe,0xd4,0xf4,0xa0,0xfe,0xbf,0xf4,0x9b,0xfe,0xaa,0xf4,0x95,0xfe,0x95,0xf4,0x90,0xfe,0x80,0xf4,0x8b,0xfe,0x6a,0xf4,0x86,0xfe,0x55,0xf4,0x80,0xfe,0x3f,0xf4,0x7b,0xfe,0x2a,0xf4,0x76,0xfe,0x14,0xf4,0x71,0xfe,0xfe,0xf3,0x6b,0xfe,0xe9,0xf3,0x66,0xfe,0xd3,0xf3,  \
    0x61,0xfe,0xbd,0xf3,0x5c,0xfe,0xa7,0xf3,0x56,0xfe,0x91,0xf3,0x51,0xfe,0x7a,0xf3,0x4c,0xfe,0x64,0xf3,0x47,0xfe,0x4d,0xf3,0x42,0xfe,0x37,0xf3,0x3d,0xfe,0x20,0xf3,0x38,0xfe,0x09,0xf3,0x33,0xfe,0xf2,0xf2,0x2e,0xfe,0xdb,0xf2,0x29,0xfe,0xc3,0xf2,0x25,0xfe,0xac,0xf2,0x20,0xfe,0x95,0xf2,0x1b,0xfe,0x7d,0xf2,0x16,0xfe,0x65,0xf2,0x12,0xfe,0x4d,0xf2,0x0d,0xfe,0x35,0xf2,0x09,0xfe,0x1c,0xf2,0x04,0xfe,0x04,0xf2,0x00,0xfe,0xeb,0xf1,0xfc,0xfd,0xd3,0xf1,0xf7,0xfd,  \
    0xba,0xf1,0xf3,0xfd,0xa1,0xf1,0xef,0xfd,0x88,0xf1,0xeb,0xfd,0x6f,0xf1,0xe7,0xfd,0x55,0xf1,0xe3,0xfd,0x3c,0xf1,0xdf,0xfd,0x22,0xf1,0xdb,0xfd,0x08,0xf1,0xd8,0xfd,0xee,0xf0,0xd4,0xfd,0xd4,0xf0,0xd0,0xfd,0xba,0xf0,0xcd,0xfd,0xa0,0xf0,0xc9,0xfd,0x85,0xf0,0xc6,0xfd,0x6b,0xf0,0xc2,0xfd,0x51,0xf0,0xbf,0xfd,0x36,0xf0,0xbb,0xfd,0x1b,0xf0,0xb8,0xfd,0x00,0xf0,0xb5,0xfd,0xe5,0xef,0xb2,0xfd,0xca,0xef,0xaf,0xfd,0xaf,0xef,0xac,0xfd,0x93,0xef,0xa9,0xfd,0x77,0xef,  \
    0xa6,0xfd,0x5c,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x4b,0xfd,0xa1,0x10,0x4e,0xfd,0x84,0x10,0x51,0xfd,0x68,0x10,0x54,0xfd,0x4d,0x10,0x57,0xfd,0x31,0x10,0x5a,0xfd,0x15,0x10,0x5d,0xfd,  \
    0xfa,0x0f,0x61,0xfd,0xde,0x0f,0x64,0xfd,0xc3,0x0f,0x68,0xfd,0xa8,0x0f,0x6c,0xfd,0x8d,0x0f,0x6f,0xfd,0x73,0x0f,0x73,0xfd,0x58,0x0f,0x77,0xfd,0x3d,0x0f,0x7b,0xfd,0x23,0x0f,0x7f,0xfd,0x09,0x0f,0x83,0xfd,0xef,0x0e,0x87,0xfd,0xd5,0x0e,0x8c,0xfd,0xbb,0x0e,0x90,0xfd,0xa1,0x0e,0x94,0xfd,0x87,0x0e,0x99,0xfd,0x6e,0x0e,0x9d,0xfd,0x54,0x0e,0xa2,0xfd,0x3b,0x0e,0xa6,0xfd,0x21,0x0e,0xab,0xfd,0x08,0x0e,0xaf,0xfd,0xef,0x0d,0xb4,0xfd,0xd6,0x0d,0xb9,0xfd,0xbe,0x0d,  \
    0xbe,0xfd,0xa5,0x0d,0xc2,0xfd,0x8c,0x0d,0xc7,0xfd,0x74,0x0d,0xcc,0xfd,0x5b,0x0d,0xd1,0xfd,0x43,0x0d,0xd6,0xfd,0x2b,0x0d,0xdb,0xfd,0x13,0x0d,0xe0,0xfd,0xfb,0x0c,0xe6,0xfd,0xe4,0x0c,0xeb,0xfd,0xcc,0x0c,0xf0,0xfd,0xb4,0x0c,0xf6,0xfd,0x9e,0x0c,0xfb,0xfd,0x87,0x0c,0x01,0xfe,0x71,0x0c,0x07,0xfe,0x5b,0x0c,0x0e,0xfe,0x45,0x0c,0x14,0xfe,0x30,0x0c,0x1a,0xfe,0x1a,0x0c,0x20,0xfe,0x05,0x0c,0x26,0xfe,0xf0,0x0b,0x2c,0xfe,0xda,0x0b,0x33,0xfe,0xc5,0x0b,0x39,0xfe,  \
    0xb0,0x0b,0x3f,0xfe,0x9c,0x0b,0x45,0xfe,0x87,0x0b,0x4c,0xfe,0x73,0x0b,0x52,0xfe,0x5e,0x0b,0x59,0xfe,0x4a,0x0b,0x5f,0xfe,0x36,0x0b,0x65,0xfe,0x21,0x0b,0x6a,0xfe,0x0b,0x0b,0x70,0xfe,0xf6,0x0a,0x76,0xfe,0xe2,0x0a,0x7c,0xfe,0xcd,0x0a,0x82,0xfe,0xb8,0x0a,0x87,0xfe,0xa3,0x0a,0x8d,0xfe,0x8f,0x0a,0x93,0xfe,0x7a,0x0a,0x99,0xfe,0x66,0x0a,0x9f,0xfe,0x52,0x0a,0xa4,0xfe,0x3e,0x0a,0xaa,0xfe,0x2a,0x0a,0xb0,0xfe,0x16,0x0a,0xb6,0xfe,0x02,0x0a,0xbc,0xfe,0xee,0x09,  \
    0xc1,0xfe,0xda,0x09,0xc7,0xfe,0xc7,0x09,0xcd,0xfe,0xb3,0x09,0xd3,0xfe,0xa0,0x09,0xd9,0xfe,0x8c,0x09,0xde,0xfe,0x79,0x09,0xe4,0xfe,0x66,0x09,0xea,0xfe,0x53,0x09,0xf0,0xfe,0x40,0x09,0xf5,0xfe,0x2d,0x09,0xfb,0xfe,0x1a,0x09,0x01,0xff,0x07,0x09,0x07,0xff,0xf5,0x08,0x0c,0xff,0xe2,0x08,0x12,0xff,0xcf,0x08,0x18,0xff,0xbd,0x08,0x1d,0xff,0xaa,0x08,0x23,0xff,0x98,0x08,0x28,0xff,0x86,0x08,0x2e,0xff,0x74,0x08,0x34,0xff,0x62,0x08,0x39,0xff,0x50,0x08,0x3f,0xff,  \
    0x3f,0x08,0x45,0xff,0x2d,0x08,0x4a,0xff,0x1c,0x08,0x50,0xff,0x0b,0x08,0x56,0xff,0xfa,0x07,0x5b,0xff,0xe8,0x07,0x61,0xff,0xd7,0x07,0x66,0xff,0xc6,0x07,0x6c,0xff,0xb5,0x07,0x71,0xff,0xa4,0x07,0x77,0xff,0x93,0x07,0x7c,0xff,0x83,0x07,0x81,0xff,0x72,0x07,0x87,0xff,0x61,0x07,0x8c,0xff,0x51,0x07,0x91,0xff,0x40,0x07,0x96,0xff,0x2f,0x07,0x9c,0xff,0x1f,0x07,0xa1,0xff,0x0f,0x07,0xa6,0xff,0xfe,0x06,0xab,0xff,0xee,0x06,0xb0,0xff,0xdd,0x06,0xb5,0xff,0xcd,0x06,  \
    0xba,0xff,0xbd,0x06,0xbf,0xff,0xad,0x06,0xc4,0xff,0x9c,0x06,0xc9,0xff,0x8c,0x06,0xce,0xff,0x7c,0x06,0xd2,0xff,0x6c,0x06,0xd7,0xff,0x5c,0x06,0xdc,0xff,0x4d,0x06,0xe1,0xff,0x3d,0x06,0xe5,0xff,0x2d,0x06,0xea,0xff,0x1d,0x06,0xef,0xff,0x0d,0x06,0xf3,0xff,0xfe,0x05,0xf8,0xff,0xee,0x05,0xfc,0xff,0xdf,0x05,0x01,0x00,0xcf,0x05,0x05,0x00,0xbf,0x05,0x09,0x00,0xb0,0x05,0x0e,0x00,0xa0,0x05,0x12,0x00,0x90,0x05,0x16,0x00,0x80,0x05,0x1a,0x00,0x70,0x05,0x1e,0x00,  \
    0x60,0x05,0x22,0x00,0x50,0x05,0x26,0x00,0x40,0x05,0x2a,0x00,0x31,0x05,0x2e,0x00,0x21,0x05,0x32,0x00,0x11,0x05,0x36,0x00,0x02,0x05,0x39,0x00,0xf2,0x04,0x3d,0x00,0xe2,0x04,0x41,0x00,0xd3,0x04,0x45,0x00,0xc3,0x04,0x48,0x00,0xb4,0x04,0x4c,0x00,0xa5,0x04,0x4f,0x00,0x95,0x04,0x53,0x00,0x86,0x04,0x57,0x00,0x77,0x04,0x5a,0x00,0x67,0x04,0x5d,0x00,0x58,0x04,0x61,0x00,0x49,0x04,0x64,0x00,0x3a,0x04,0x68,0x00,0x2b,0x04,0x6b,0x00,0x1c,0x04,0x6e,0x00,0x0e,0x04,  \
    0x72,0x00,0xff,0x03,0x75,0x00,0xf1,0x03,0x78,0x00,0xe2,0x03,0x7b,0x00,0xd3,0x03,0x7f,0x00,0xc5,0x03,0x82,0x00,0xb6,0x03,0x85,0x00,0xa8,0x03,0x88,0x00,0x99,0x03,0x8b,0x00,0x8b,0x03,0x8e,0x00,0x7d,0x03,0x90,0x00,0x6e,0x03,0x93,0x00,0x60,0x03,0x96,0x00,0x52,0x03,0x99,0x00,0x43,0x03,0x9c,0x00,0x35,0x03,0x9e,0x00,0x27,0x03,0xa1,0x00,0x18,0x03,0xa4,0x00,0x0a,0x03,0xa6,0x00,0xfc,0x02,0xa9,0x00,0xee,0x02,0xab,0x00,0xe0,0x02,0xae,0x00,0xd2,0x02,0xb0,0x00,  \
    0xc4,0x02,0xb2,0x00,0xb6,0x02,0xb5,0x00,0xa8,0x02,0xb7,0x00,0x9a,0x02,0xb9,0x00,0x8c,0x02,0xbc,0x00,0x7e,0x02,0xbe,0x00,0x70,0x02,0xc0,0x00,0x63,0x02,0xc2,0x00,0x55,0x02,0xc4,0x00,0x47,0x02,0xc6,0x00,0x39,0x02,0xc8,0x00,0x2b,0x02,0xca,0x00,0x1e,0x02,0xcc,0x00,0x10,0x02,0xce,0x00,0x02,0x02,0xcf,0x00,0xf4,0x01,0xd1,0x00,0xe7,0x01,0xd3,0x00,0xd9,0x01,0xd4,0x00,0xcb,0x01,0xd6,0x00,0xbe,0x01,0xd8,0x00,0xb0,0x01,0xd9,0x00,0xa2,0x01,0xdb,0x00,0x95,0x01,  \
    0xdc,0x00,0x87,0x01,0xdd,0x00,0x79,0x01,0xdf,0x00,0x6c,0x01,0xe0,0x00,0x5e,0x01,0xe1,0x00,0x50,0x01,0xe3,0x00,0x43,0x01,0xe4,0x00,0x35,0x01,0xe5,0x00,0x27,0x01,0xe6,0x00,0x1a,0x01,0xe7,0x00,0x0c,0x01,0xe8,0x00,0xfe,0x00,0xe9,0x00,0xf1,0x00,0xea,0x00,0xe3,0x00,0xeb,0x00,0xd6,0x00,0xec,0x00,0xc8,0x00,0xed,0x00,0xba,0x00,0xed,0x00,0xad,0x00,0xee,0x00,0x9f,0x00,0xef,0x00,0x92,0x00,0xef,0x00,0x84,0x00,0xf0,0x00,0x76,0x00,0xf0,0x00,0x69,0x00,0xf1,0x00,  \
    0x5b,0x00,0xf1,0x00,0x4e,0x00,0xf2,0x00,0x40,0x00,0xf2,0x00,0x33,0x00,0xf3,0x00,0x25,0x00,0xf3,0x00,0x18,0x00,0xf3,0x00,0x0a,0x00,0xf3,0x00,0xfc,0xff,0xf3,0x00,0xef,0xff,0xf4,0x00,0xe1,0xff,0xf4,0x00,0xd4,0xff,0xf4,0x00,0xc6,0xff,0xf4,0x00,0xb9,0xff,0xf4,0x00,0xab,0xff,0xf4,0x00,0x9e,0xff,0xf3,0x00,0x90,0xff,0xf3,0x00,0x82,0xff,0xf3,0x00,0x75,0xff,0xf3,0x00,0x67,0xff,0xf3,0x00,0x5a,0xff,0xf2,0x00,0x4c,0xff,0xf2,0x00,0x3e,0xff,0xf1,0x00,0x31,0xff,  \
    0xf1,0x00,0x23,0xff,0xf0,0x00,0x15,0xff,0xf0,0x00,0x07,0xff,0xef,0x00,0xfa,0xfe,0xef,0x00,0xec,0xfe,0xee,0x00,0xde,0xfe,0xed,0x00,0xd0,0xfe,0xed,0x00,0xc2,0xfe,0xec,0x00,0xb5,0xfe,0xeb,0x00,0xa7,0xfe,0xea,0x00,0x99,0xfe,0xe9,0x00,0x8b,0xfe,0xe9,0x00,0x7d,0xfe,0xe8,0x00,0x6f,0xfe,0xe7,0x00,0x61,0xfe,0xe6,0x00,0x53,0xfe,0xe4,0x00,0x46,0xfe,0xe3,0x00,0x38,0xfe,0xe2,0x00,0x2b,0xfe,0xe1,0x00,0x1e,0xfe,0xe0,0x00,0x10,0xfe,0xde,0x00,0x03,0xfe,0xdd,0x00,  \
    0xf6,0xfd,0xdb,0x00,0xe8,0xfd,0xda,0x00,0xdb,0xfd,0xd9,0x00,0xce,0xfd,0xd7,0x00,0xc0,0xfd,0xd5,0x00,0xb3,0xfd,0xd4,0x00,0xa6,0xfd,0xd2,0x00,0x99,0xfd,0xd0,0x00,0x8b,0xfd,0xcf,0x00,0x7e,0xfd,0xcd,0x00,0x71,0xfd,0xcb,0x00,0x64,0xfd,0xc9,0x00,0x56,0xfd,0xc7,0x00,0x49,0xfd,0xc5,0x00,0x3c,0xfd,0xc3,0x00,0x2f,0xfd,0xc1,0x00,0x21,0xfd,0xbf,0x00,0x14,0xfd,0xbd,0x00,0x07,0xfd,0xba,0x00,0xfa,0xfc,0xb8,0x00,0xed,0xfc,0xb6,0x00,0xdf,0xfc,0xb4,0x00,0xd1,0xfc,  \
    0xb1,0x00,0xc3,0xfc,0xaf,0x00,0xb4,0xfc,0xad,0x00,0xa6,0xfc,0xaa,0x00,0x98,0xfc,0xa8,0x00,0x89,0xfc,0xa6,0x00,0x7b,0xfc,0xa3,0x00,0x6c,0xfc,0xa1,0x00,0x5d,0xfc,0x9e,0x00,0x4f,0xfc,0x9c,0x00,0x40,0xfc,0x99,0x00,0x32,0xfc,0x96,0x00,0x23,0xfc,0x94,0x00,0x14,0xfc,0x91,0x00,0x05,0xfc,0x8e,0x00,0xf7,0xfb,0x8b,0x00,0xe8,0xfb,0x89,0x00,0xd9,0xfb,0x86,0x00,0xca,0xfb,0x83,0x00,0xbb,0xfb,0x80,0x00,0xac,0xfb,0x7d,0x00,0x9d,0xfb,0x7a,0x00,0x8e,0xfb,0x77,0x00,  \
    0x7f,0xfb,0x74,0x00,0x6f,0xfb,0x71,0x00,0x60,0xfb,0x6e,0x00,0x51,0xfb,0x6a,0x00,0x42,0xfb,0x67,0x00,0x34,0xfb,0x64,0x00,0x25,0xfb,0x60,0x00,0x16,0xfb,0x5d,0x00,0x07,0xfb,0x59,0x00,0xf8,0xfa,0x56,0x00,0xe9,0xfa,0x52,0x00,0xda,0xfa,0x4f,0x00,0xcb,0xfa,0x4b,0x00,0xbc,0xfa,0x48,0x00,0xad,0xfa,0x44,0x00,0x9e,0xfa,0x40,0x00,0x8f,0xfa,0x3d,0x00,0x80,0xfa,0x39,0x00,0x71,0xfa,0x35,0x00,0x61,0xfa,0x31,0x00,0x52,0xfa,0x2d,0x00,0x43,0xfa,0x29,0x00,0x33,0xfa,  \
    0x25,0x00,0x24,0xfa,0x21,0x00,0x15,0xfa,0x1d,0x00,0x05,0xfa,0x19,0x00,0xf6,0xf9,0x15,0x00,0xe6,0xf9,0x11,0x00,0xd7,0xf9,0x0d,0x00,0xc7,0xf9,0x09,0x00,0xb8,0xf9,0x05,0x00,0xa8,0xf9,0x00,0x00,0x98,0xf9,0xfc,0xff,0x89,0xf9,0xf8,0xff,0x79,0xf9,0xf3,0xff,0x69,0xf9,0xef,0xff,0x5a,0xf9,0xea,0xff,0x4a,0xf9,0xe6,0xff,0x3a,0xf9,0xe1,0xff,0x2a,0xf9,0xdd,0xff,0x1a,0xf9,0xd8,0xff,0x0a,0xf9,0xd3,0xff,0xfa,0xf8,0xcf,0xff,0xea,0xf8,0xca,0xff,0xd9,0xf8,0xc5,0xff,  \
    0xc9,0xf8,0xc1,0xff,0xb9,0xf8,0xbc,0xff,0xa9,0xf8,0xb7,0xff,0x98,0xf8,0xb2,0xff,0x88,0xf8,0xad,0xff,0x77,0xf8,0xa9,0xff,0x67,0xf8,0xa4,0xff,0x56,0xf8,0x9f,0xff,0x45,0xf8,0x9a,0xff,0x35,0xf8,0x95,0xff,0x24,0xf8,0x90,0xff,0x13,0xf8,0x8b,0xff,0x02,0xf8,0x86,0xff,0xf1,0xf7,0x80,0xff,0xe0,0xf7,0x7b,0xff,0xcf,0xf7,0x76,0xff,0xbe,0xf7,0x71,0xff,0xac,0xf7,0x6c,0xff,0x9b,0xf7,0x67,0xff,0x8a,0xf7,0x61,0xff,0x78,0xf7,0x5c,0xff,0x67,0xf7,0x57,0xff,0x55,0xf7,  \
    0x52,0xff,0x43,0xf7,0x4c,0xff,0x32,0xf7,0x47,0xff,0x20,0xf7,0x42,0xff,0x0e,0xf7,0x3c,0xff,0xfc,0xf6,0x37,0xff,0xea,0xf6,0x31,0xff,0xd8,0xf6,0x2c,0xff,0xc6,0xf6,0x27,0xff,0xb3,0xf6,0x21,0xff,0xa1,0xf6,0x1c,0xff,0x8f,0xf6,0x16,0xff,0x7c,0xf6,0x11,0xff,0x6a,0xf6,0x0b,0xff,0x57,0xf6,0x06,0xff,0x44,0xf6,0x00,0xff,0x31,0xf6,0xfb,0xfe,0x1e,0xf6,0xf5,0xfe,0x0b,0xf6,0xf0,0xfe,0xf8,0xf5,0xea,0xfe,0xe5,0xf5,0xe5,0xfe,0xd2,0xf5,0xdf,0xfe,0xbe,0xf5,0xd9,0xfe,  \
    0xab,0xf5,0xd4,0xfe,0x97,0xf5,0xce,0xfe,0x83,0xf5,0xc9,0xfe,0x6f,0xf5,0xc4,0xfe,0x5b,0xf5,0xbe,0xfe,0x47,0xf5,0xb9,0xfe,0x33,0xf5,0xb3,0xfe,0x1f,0xf5,0xae,0xfe,0x0a,0xf5,0xa8,0xfe,0xf6,0xf4,0xa3,0xfe,0xe1,0xf4,0x9e,0xfe,0xcc,0xf4,0x98,0xfe,0xb7,0xf4,0x93,0xfe,0xa2,0xf4,0x8d,0xfe,0x8d,0xf4,0x88,0xfe,0x78,0xf4,0x83,0xfe,0x63,0xf4,0x7d,0xfe,0x4d,0xf4,0x78,0xfe,0x38,0xf4,0x73,0xfe,0x22,0xf4,0x6e,0xfe,0x0d,0xf4,0x68,0xfe,0xf7,0xf3,0x63,0xfe,0xe2,0xf3,  \
    0x5d,0xfe,0xcc,0xf3,0x58,0xfe,0xb6,0xf3,0x53,0xfe,0xa0,0xf3,0x4e,0xfe,0x8a,0xf3,0x48,0xfe,0x73,0xf3,0x43,0xfe,0x5d,0xf3,0x3e,0xfe,0x46,0xf3,0x39,0xfe,0x30,0xf3,0x34,0xfe,0x19,0xf3,0x2f,0xfe,0x02,0xf3,0x2a,0xfe,0xeb,0xf2,0x25,0xfe,0xd4,0xf2,0x20,0xfe,0xbd,0xf2,0x1b,0xfe,0xa5,0xf2,0x16,0xfe,0x8e,0xf2,0x11,0xfe,0x76,0xf2,0x0d,0xfe,0x5e,0xf2,0x08,0xfe,0x46,0xf2,0x03,0xfe,0x2e,0xf2,0xff,0xfd,0x16,0xf2,0xfa,0xfd,0xfd,0xf1,0xf6,0xfd,0xe5,0xf1,0xf2,0xfd,  \
    0xcc,0xf1,0xed,0xfd,0xb3,0xf1,0xe9,0xfd,0x9a,0xf1,0xe5,0xfd,0x81,0xf1,0xe1,0xfd,0x68,0xf1,0xdd,0xfd,0x4f,0xf1,0xd9,0xfd,0x35,0xf1,0xd5,0xfd,0x1c,0xf1,0xd1,0xfd,0x02,0xf1,0xcd,0xfd,0xe8,0xf0,0xc9,0xfd,0xce,0xf0,0xc5,0xfd,0xb4,0xf0,0xc2,0xfd,0x9a,0xf0,0xbe,0xfd,0x7f,0xf0,0xbb,0xfd,0x65,0xf0,0xb7,0xfd,0x4a,0xf0,0xb4,0xfd,0x30,0xf0,0xb0,0xfd,0x15,0xf0,0xad,0xfd,0xfa,0xef,0xaa,0xfd,0xdf,0xef,0xa7,0xfd,0xc4,0xef,0xa4,0xfd,0xa9,0xef,0xa1,0xfd,0x8d,0xef,  \
    0x9e,0xfd,0x71,0xef,0x9b,0xfd,0x56,0xef,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0xfd,0xa6,0x10,0x43,0xfd,0x8a,0x10,0x46,0xfd,0x6e,0x10,0x49,0xfd,0x52,0x10,0x4c,0xfd,0x37,0x10,0x4f,0xfd,  \
    0x1b,0x10,0x53,0xfd,0xff,0x0f,0x56,0xfd,0xe4,0x0f,0x5a,0xfd,0xc9,0x0f,0x5d,0xfd,0xae,0x0f,0x61,0xfd,0x93,0x0f,0x65,0xfd,0x78,0x0f,0x69,0xfd,0x5e,0x0f,0x6d,0xfd,0x43,0x0f,0x71,0xfd,0x29,0x0f,0x75,0xfd,0x0f,0x0f,0x79,0xfd,0xf5,0x0e,0x7d,0xfd,0xdb,0x0e,0x82,0xfd,0xc1,0x0e,0x86,0xfd,0xa7,0x0e,0x8a,0xfd,0x8d,0x0e,0x8f,0xfd,0x74,0x0e,0x93,0xfd,0x5a,0x0e,0x98,0xfd,0x41,0x0e,0x9c,0xfd,0x28,0x0e,0xa1,0xfd,0x0e,0x0e,0xa6,0xfd,0xf5,0x0d,0xaa,0xfd,0xdc,0x0d,  \
    0xaf,0xfd,0xc4,0x0d,0xb4,0xfd,0xab,0x0d,0xb9,0xfd,0x92,0x0d,0xbe,0xfd,0x7a,0x0d,0xc3,0xfd,0x62,0x0d,0xc8,0xfd,0x4a,0x0d,0xcd,0xfd,0x31,0x0d,0xd2,0xfd,0x19,0x0d,0xd7,0xfd,0x02,0x0d,0xdc,0xfd,0xea,0x0c,0xe2,0xfd,0xd2,0x0c,0xe7,0xfd,0xbb,0x0c,0xed,0xfd,0xa4,0x0c,0xf3,0xfd,0x8e,0x0c,0xf9,0xfd,0x78,0x0c,0xff,0xfd,0x62,0x0c,0x05,0xfe,0x4c,0x0c,0x0b,0xfe,0x36,0x0c,0x11,0xfe,0x21,0x0c,0x18,0xfe,0x0c,0x0c,0x1e,0xfe,0xf6,0x0b,0x24,0xfe,0xe1,0x0b,0x2b,0xfe,  \
    0xcc,0x0b,0x31,0xfe,0xb8,0x0b,0x37,0xfe,0xa3,0x0b,0x3e,0xfe,0x8e,0x0b,0x44,0xfe,0x7a,0x0b,0x4b,0xfe,0x66,0x0b,0x51,0xfe,0x52,0x0b,0x57,0xfe,0x3d,0x0b,0x5d,0xfe,0x28,0x0b,0x63,0xfe,0x13,0x0b,0x69,0xfe,0xfe,0x0a,0x6f,0xfe,0xe9,0x0a,0x75,0xfe,0xd4,0x0a,0x7b,0xfe,0xc0,0x0a,0x80,0xfe,0xab,0x0a,0x86,0xfe,0x97,0x0a,0x8c,0xfe,0x82,0x0a,0x92,0xfe,0x6e,0x0a,0x98,0xfe,0x5a,0x0a,0x9e,0xfe,0x45,0x0a,0xa4,0xfe,0x31,0x0a,0xa9,0xfe,0x1d,0x0a,0xaf,0xfe,0x09,0x0a,  \
    0xb5,0xfe,0xf6,0x09,0xbb,0xfe,0xe2,0x09,0xc1,0xfe,0xce,0x09,0xc7,0xfe,0xbb,0x09,0xcd,0xfe,0xa7,0x09,0xd2,0xfe,0x94,0x09,0xd8,0xfe,0x81,0x09,0xde,0xfe,0x6e,0x09,0xe4,0xfe,0x5b,0x09,0xea,0xfe,0x48,0x09,0xef,0xfe,0x35,0x09,0xf5,0xfe,0x22,0x09,0xfb,0xfe,0x0f,0x09,0x01,0xff,0xfc,0x08,0x06,0xff,0xea,0x08,0x0c,0xff,0xd7,0x08,0x12,0xff,0xc5,0x08,0x18,0xff,0xb2,0x08,0x1d,0xff,0xa0,0x08,0x23,0xff,0x8e,0x08,0x29,0xff,0x7c,0x08,0x2e,0xff,0x6a,0x08,0x34,0xff,  \
    0x58,0x08,0x3a,0xff,0x47,0x08,0x40,0xff,0x35,0x08,0x45,0xff,0x24,0x08,0x4b,0xff,0x13,0x08,0x50,0xff,0x01,0x08,0x56,0xff,0xf0,0x07,0x5c,0xff,0xdf,0x07,0x61,0xff,0xce,0x07,0x67,0xff,0xbd,0x07,0x6c,0xff,0xac,0x07,0x72,0xff,0x9b,0x07,0x77,0xff,0x8b,0x07,0x7d,0xff,0x7a,0x07,0x82,0xff,0x69,0x07,0x87,0xff,0x59,0x07,0x8d,0xff,0x48,0x07,0x92,0xff,0x38,0x07,0x97,0xff,0x27,0x07,0x9c,0xff,0x17,0x07,0xa2,0xff,0x06,0x07,0xa7,0xff,0xf6,0x06,0xac,0xff,0xe5,0x06,  \
    0xb1,0xff,0xd5,0x06,0xb6,0xff,0xc5,0x06,0xbb,0xff,0xb5,0x06,0xc0,0xff,0xa4,0x06,0xc5,0xff,0x94,0x06,0xca,0xff,0x84,0x06,0xce,0xff,0x74,0x06,0xd3,0xff,0x64,0x06,0xd8,0xff,0x54,0x06,0xdd,0xff,0x44,0x06,0xe1,0xff,0x35,0x06,0xe6,0xff,0x25,0x06,0xeb,0xff,0x15,0x06,0xef,0xff,0x05,0x06,0xf4,0xff,0xf6,0x05,0xf8,0xff,0xe6,0x05,0xfd,0xff,0xd7,0x05,0x01,0x00,0xc7,0x05,0x06,0x00,0xb8,0x05,0x0a,0x00,0xa7,0x05,0x0e,0x00,0x97,0x05,0x12,0x00,0x87,0x05,0x16,0x00,  \
    0x77,0x05,0x1a,0x00,0x67,0x05,0x1e,0x00,0x58,0x05,0x22,0x00,0x48,0x05,0x26,0x00,0x38,0x05,0x2a,0x00,0x28,0x05,0x2e,0x00,0x18,0x05,0x32,0x00,0x09,0x05,0x36,0x00,0xf9,0x04,0x3a,0x00,0xe9,0x04,0x3d,0x00,0xda,0x04,0x41,0x00,0xca,0x04,0x45,0x00,0xbb,0x04,0x48,0x00,0xab,0x04,0x4c,0x00,0x9c,0x04,0x50,0x00,0x8c,0x04,0x53,0x00,0x7d,0x04,0x57,0x00,0x6e,0x04,0x5a,0x00,0x5e,0x04,0x5e,0x00,0x4f,0x04,0x61,0x00,0x40,0x04,0x64,0x00,0x31,0x04,0x68,0x00,0x23,0x04,  \
    0x6b,0x00,0x14,0x04,0x6f,0x00,0x05,0x04,0x72,0x00,0xf6,0x03,0x75,0x00,0xe8,0x03,0x78,0x00,0xd9,0x03,0x7b,0x00,0xcb,0x03,0x7e,0x00,0xbc,0x03,0x82,0x00,0xad,0x03,0x85,0x00,0x9f,0x03,0x88,0x00,0x90,0x03,0x8b,0x00,0x82,0x03,0x8d,0x00,0x74,0x03,0x90,0x00,0x65,0x03,0x93,0x00,0x57,0x03,0x96,0x00,0x48,0x03,0x99,0x00,0x3a,0x03,0x9b,0x00,0x2c,0x03,0x9e,0x00,0x1d,0x03,0xa1,0x00,0x0f,0x03,0xa3,0x00,0x01,0x03,0xa6,0x00,0xf3,0x02,0xa8,0x00,0xe4,0x02,0xab,0x00,  \
    0xd6,0x02,0xad,0x00,0xc8,0x02,0xb0,0x00,0xba,0x02,0xb2,0x00,0xac,0x02,0xb4,0x00,0x9e,0x02,0xb7,0x00,0x90,0x02,0xb9,0x00,0x82,0x02,0xbb,0x00,0x74,0x02,0xbd,0x00,0x67,0x02,0xbf,0x00,0x59,0x02,0xc1,0x00,0x4b,0x02,0xc3,0x00,0x3d,0x02,0xc5,0x00,0x2f,0x02,0xc7,0x00,0x21,0x02,0xc9,0x00,0x13,0x02,0xcb,0x00,0x06,0x02,0xcd,0x00,0xf8,0x01,0xce,0x00,0xea,0x01,0xd0,0x00,0xdc,0x01,0xd2,0x00,0xce,0x01,0xd3,0x00,0xc1,0x01,0xd5,0x00,0xb3,0x01,0xd6,0x00,0xa5,0x01,  \
    0xd8,0x00,0x97,0x01,0xd9,0x00,0x8a,0x01,0xdb,0x00,0x7c,0x01,0xdc,0x00,0x6e,0x01,0xdd,0x00,0x61,0x01,0xdf,0x00,0x53,0x01,0xe0,0x00,0x45,0x01,0xe1,0x00,0x37,0x01,0xe2,0x00,0x2a,0x01,0xe3,0x00,0x1c,0x01,0xe4,0x00,0x0e,0x01,0xe6,0x00,0x00,0x01,0xe6,0x00,0xf3,0x00,0xe7,0x00,0xe5,0x00,0xe8,0x00,0xd7,
