Hi all,
now i have the error in running the run_gui.sh, my software version is 01.08.00.15 , the error is this:
numid=1,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
: values=127,127
| dBscale-min=-63.50dB,step=0.50dB,mute=0
[c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[m3video] Remote Debug Shared Memory @ 0xbff05020
[m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
SysLink version : 2.00.04.83
SysLink module created on Date:Jan 3 2012 Time:22:28:02
Trace enabled
Trace SetFailureReason enabled
Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 )
Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss.xem3 on slave procId 2.
Started slave procId 2.
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 250000000
[m3vpss ] notify_attach rtnVal 0
[m3vpss ] initProxyServer rtnVal 0
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 500000 Khz ***
[m3vpss ]
[m3vpss ] 73: SYSTEM : System Common Init in progress !!!
[m3vpss ] 73: SYSTEM: IPC init in progress !!!
[m3vpss ] 73: SYSTEM: Attaching to [HOST] ...
After Ipc_loadcallback status [0x00000000]
[m3vpss ] 1073: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1075: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 1075: SYSTEM: Attaching to [DSP] ...
After Ipc_startcallback status [0x097d2000]
Attached to slave procId 1.
Loaded file ../firmware/dvr_rdk_fw_m3video.xem3 on slave procId 1.
Started slave procId 1.
[m3video] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 250000000
[m3vpss ] 2075: SYSTEM: Attaching to [DSP] ...
[m3video]
[m3video] *** UTILS: CPU KHz = 500000 Khz ***
[m3video]
[m3video] 1303: SYSTEM : System Common Init in progress !!!
[m3video] 1303: SYSTEM: IPC init in progress !!!
[m3video] 1303: SYSTEM: Attaching to [HOST] ...
[m3video] 2303: SYSTEM: Attaching to [HOST] ...
[m3video] 2306: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3video] 2306: SYSTEM: Attaching to [DSP] ...
After Ipc_startcallback status [0x00000000]
Attached to slave procId 0.
Loaded file ../firmware/dvr_rdk_fw_c6xdsp.xe674 on slave procId 0.
Started slave procId 0.
[c6xdsp ] ***** SYSTEM : Frequency <ORG> - 800000000, <NEW> - 800000000
[m3video] 3305: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 3075: SYSTEM: Attaching to [DSP] ...
[c6xdsp ]
[c6xdsp ] *** UTILS: CPU KHz = 800000 Khz ***
[c6xdsp ]
[c6xdsp ] 5: SYSTEM : System Common Init in progress !!!
[c6xdsp ] 5: SYSTEM: IPC init in progress !!!
[c6xdsp ] 5: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1029: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1031: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 1031: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 4075: SYSTEM: Attaching to [DSP] ...
[m3video] 4305: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2055: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 5075: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2532: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 5305: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2532: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 5306: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3video] 5306: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 6075: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 3555: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 6305: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 4354: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 7075: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 4354: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 7076: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 7076: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 7305: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 5377: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 8076: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 8075: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 8076: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 8076: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 8076: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 8076: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 8076: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 8076: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[m3video] 8078: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3vpss ] 8076: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[m3video] 8078: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3vpss ] 8078: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3video] 8078: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[m3vpss ] 8078: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3video] 8079: SYSTEM: IPC init DONE !!!
[m3vpss ] 8078: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[m3vpss ] 8078: SYSTEM: IPC init DONE !!!
[m3video] 8086: MEM: Shared Region 3: Base = 0xa0000000, Length = 0x1e900000 (489 MB)
[m3vpss ] 8086: MEM: Shared Region 3: Base = 0xa0000000, Length = 0x1e900000 (489 MB)
[m3video] 8086: MEM: ERROR: SharedRegion_setEntry (3, 0x8e031260) FAILED !!! (status=-1)
[m3vpss ] 8087: MEM: Shared Region 1: Base = 0x88000000, Length = 0x05780000 (87 MB)
[m3vpss ] 8087: MEM: Shared Region 2: Base = 0x90000000, Length = 0x10000000 (256 MB)
[m3vpss ] 8089: SYSTEM : System Common Init Done !!!
[m3vpss ] 8089: SYSTEM : System VPSS Init in progress !!!
[m3vpss ] === HDVPSS Clocks are enabled ===
[m3vpss ] === HDVPSS is fully functional ===
[m3vpss ] === HDVPSS module is not in standby ===
[m3vpss ] === I2C1 Clk is active ===
[m3vpss ] 8093: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_33
[m3vpss ] 8094: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[m3vpss ] 8094: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3video] 8095: MEM: Shared Region 1: Base = 0x88000000, Length = 0x05780000 (87 MB)
[m3vpss ] 8094: SYSTEM: ListElem Shared Addr = 0xbeb0b280
[m3video] 8096: MEM: Shared Region 2: Base = 0x90000000, Length = 0x10000000 (256 MB)
[m3vpss ] 8096: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3video] 8098: SYSTEM : System Common Init Done !!!
[m3vpss ] 8096: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3video] 8098: SYSTEM : System Video Init in progress !!!
[m3vpss ] 8096: SYSTEM: ListElem Shared Addr = 0xbeb0e380
[m3video] 8098: SYSTEM : System Video Init Done !!!
[m3video] 8098: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3video] 8098: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[m3video] 8099: SYSTEM: ListElem Shared Addr = 0xbeb11480
[m3video] 8101: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 8101: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 8101: SYSTEM: ListElem Shared Addr = 0xbeb14580
[m3video] 8110: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ...
[m3vpss ] 8108: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[m3video] 8110: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ...
[m3vpss ] 8108: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[m3video] 8110: SYSTEM: ListElem Shared Addr = 0xbeb36c80
[m3vpss ] 8108: SYSTEM: ListElem Shared Addr = 0xbeb17680
[m3video] 8112: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 8111: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[m3video] 8113: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 8111: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[m3video] 8113: SYSTEM: ListElem Shared Addr = 0xbeb6db80
[m3vpss ] 8111: SYSTEM: ListElem Shared Addr = 0xbeb4e580
[m3video] 8114: HDVICP: Doing PRCM for IVAHD[0] ...
[m3video] 8121: HDVICP: WARNING: RM_IVAHD_RSTST Timed OUT [0x7]
[m3video] 8121: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3video] 8121: HDVICP: Doing PRCM for IVAHD[1] ...
[m3video] 8128: HDVICP: WARNING: RM_IVAHD_RSTST Timed OUT [0x7]
[m3video] 8128: HDVICP: PRCM for IVAHD[1] ... DONE.
[m3video] 8128: HDVICP: Doing PRCM for IVAHD[2] ...
[m3video] 8135: HDVICP: WARNING: RM_IVAHD_RSTST Timed OUT [0x7]
[m3video] 8135: HDVICP: PRCM for IVAHD[2] ... DONE.
[m3video] 8136: SYSTEM : Initializing Links !!!
[m3video] 8136: SYSTEM : Heap Free Space (System = 2087936 bytes, FrmBuf = 512753536 bytes,
[m3video] BitBuf = 91750272 bytes, Mbx = 10240 msgs)
[m3video] 8180: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 8196: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 8196: SYSTEM : Initializing Links !!!
[m3vpss ] 8196: SYSTEM : Heap Free Space (System = 26488 bytes, FrmBuf = 508443520 bytes,
[m3vpss ] BitBuf = 91750272 bytes, Mbx = 10240 msgs)
[m3vpss ] 8307: SYSTEM : Initializing AVsync ********************** !!!
[m3vpss ] Received character 's'
[m3vpss ] AVsync AVSYNC_M3_Init********************** !!!
[m3vpss ] 8236 : AVsync AVSYNC_Init_WallTimer********************** !!!
[m3vpss ] 8308: SYSTEM : Initializing Links ... DONE !!!
[m3video] Received character 's'
[c6xdsp ] 6401: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[c6xdsp ] 6401: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[c6xdsp ] 6401: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[c6xdsp ] 6402: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[c6xdsp ] 6402: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[c6xdsp ] 6402: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[c6xdsp ] 6402: SYSTEM: IPC init DONE !!!
[c6xdsp ] 6404: MEM: Shared Region 3: Base = 0xa0000000, Length = 0x1e900000 (489 MB)
[c6xdsp ] 6404: MEM: SVPSS_FVID2: M3 firmware version 0x1000133 is newer,driver may not work properly.
[c6xdsp ] 6404: MEM: Shared Region 2: Base = 0x90000000, Length = 0x10000000 (256 MB)
[c6xdsp ] 6405: SYSTEM : System Common Init Done !!!
[c6xdsp ] 6251: SYSTEM : System DSP Init in progress !!!
[c6xdsp ] 6251: SYSTEM : System DSP Init Done !!!
[c6xdsp ] 6407: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[c6xdsp ] 6407: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[c6xdsp ] 6407: SYSTEM: ListElem Shared Addr = 0xbeb86880
[c6xdsp ] 6408: SYSTEM: Creating ListMP [DSP_IPC_OU[module] vpss probe done.
[c6xdsp ] 6408: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[c6xdsp ] 6408: SYSTEM: ListElem Shared Addr = 0xbeba5e80
[c6xdsp ] !!WARNING.Resource already registered:2
[c6xdsp ] 6255: SYSTEM : Initializing Links !!!
[c6xdsp ] Received character 's'
/opt/dvr_rdk/ti816x
[c6xdsp ] 6409: SYSTEM : Heap Free Space (System = 2089832 bytes, FrmBuf = 505333120 bytes,
[c6xdsp ] BitBuf = 91[module] ti81xxfb probe done.
[c6xdsp ] 6264: SYSTEM : Initializing Links ... DONE !!!
HDMI W1 rev 2.0
[module] ti81xx_hdmi probe done.
ORG 0x46c00524: 0
NEW 0x46c00524: 2
root@dvr:/opt/dvr_rdk/ti816x#
[dvrmain info]
main: HDMI0, sub: HDMI1, video_in: NTSC, video_out: 1080p60gVIDEOMOTION_ctrl.bufSize = 21120
gVIDEOMOTION_ctrl.bufNum = 16
app_pb: app_playback_init ... success
[host] APP_WRITER:WRITER_videoRecvFxn:Entered...
[host] APP_WRITER:WRITER_recordFxn:Entered... 0: SYSTEM: System Common Init in progress !!!
0: SYSTEM: IPC init in progress !!!
9: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
10: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
12: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
13: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
14: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
14: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
15: SYSTEM: Notify register to [DSP] line 0, event 12 ...
16: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
16: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
16: SYSTEM: IPC init DONE !!!
17: STemp_hsync = 280, temp_vsync = 280, timing_hsync = 280, timing_vsync = 45YSTEM: Creating Hdmi_code = 16 mode = 1
ListMP [HOST_IPCTiming Info:
_OUT_28] in regi pixel_clk = 148500
on 0 ...
19: S x_res = 1920
YSTEM: Creating y_res = 1080
ListMP [HOST_IPC hfp = 88
_IN_28] in regio hsw = 44
n 0 ...
21: SY hbp = 148
STEM: ListElem S vfp = 4
hared Addr = 0x4 vsw = 5
83ab480
22: SY vbp = 36
STEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
24: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
25: SYSTEM: ListElem Shared Addr = 0x483c2d80
27: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
29: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
30: SYSTEM: ListElem Shared Addr = 0x483da680
31: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
33: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
35: SYSTEM: ListElem Shared Addr = 0x483f9c80
35: SYSTEM: System Common Init Done !!!
********* Entered usecase 16CH Progressive <816x> Cap/Enc/Dec/Dis
36: MCFW : CPU Revision [ES1.1] !!!
36: MCFW : Detected [(null)] Board !!!
36: MCFW : Base Board Revision [DVR] !!!
36: MCFW : Daughter Card Revision [DVR] !!!
[m3vpss ] 14171: HDMI: Starting HDMI Transmitter ... !!!
[m3vpss ] System_hdmiCreate: Error 0 @ line 135
[m3vpss ] System_hdmiStart: Error -2 @ line 159
[m3vpss ] 14171: CAPTURE: Create in progress !!!
[m3vpss ] 14171: CAPTURE: VIP 0: VID DEC 1024 (0x5c): Video Standard Detect in Progress !!!
[m3vpss ] 14271: Assertion @ Line: 1800 in links_m3vpss/capture/captureLink_drv.c: status == FVID2_SOK : failed !!!
who can help me ?
