Part Number: TDA4VE-Q1
I have modified the surround view app by adding a camera image mask node before going to the surround view node. I would like to mask the front camera image to a black image, i.e., memset to 0, and remain the other 3 camera images (right, rear, left). Then, send these 4 images into surround view node. I used memset to provide black image, and memcpy to remain the same images. But, I found that the frame rate will drop from 30fps to about 26fps.
Any suggestion?
Here is my code below:
// vx_kernels_3way_mask_target.h
#ifndef __VX_KERNELS_3WAY_MASK_TARGET_H__ #define __VX_KERNELS_3WAY_MASK_TARGET_H__ #include <stdio.h> #include <VX/vx.h> #include <VX/vx_compatibility.h> vx_status vxMaskCameraImagesKernel(vx_node node, const vx_reference *parameters, vx_uint32 num); vx_status tivxMaskLoadKernels(vx_context context); vx_status tivxMaskUnloadKernels(vx_context context); #endif
// vx_kernels_3way_mask_target.c
#include "vx_kernels_3way_mask_target.h"
vx_object_array input_images = (vx_object_array)parameters[0];
vx_uint32 width, height, cam_num; // [1], [2], [3]
vx_array flags = (vx_array)parameters[4];
vx_object_array output_images = (vx_object_array)parameters[5];
// Get the parameters
vxCopyScalar((vx_scalar)parameters[1], &width, VX_READ_ONLY, VX_MEMORY_TYPE_HOST);
vxCopyScalar((vx_scalar)parameters[2], &height, VX_READ_ONLY, VX_MEMORY_TYPE_HOST);
vxCopyScalar((vx_scalar)parameters[3], &cam_num, VX_READ_ONLY, VX_MEMORY_TYPE_HOST);
vx_status status = VX_SUCCESS;
// Get is_mask_cam array
vx_uint8 is_mask_cam_flags[32] = {0}; // Support up to 32 channels
vx_size num_items = 0;
vxQueryArray(flags, VX_ARRAY_ATTRIBUTE_NUMITEMS, &num_items, sizeof(num_items));
if(num_items > 32) num_items = 32;
vxCopyArrayRange(flags, 0, num_items, sizeof(vx_uint8), is_mask_cam_flags, VX_READ_ONLY, VX_MEMORY_TYPE_HOST);
vx_rectangle_t rect_y = {0, 0, width, height};
vx_rectangle_t rect_uv = {0, 0, width, height / 2};
for (vx_uint32 i = 0; i < cam_num; i++) {
vx_image dst = (vx_image)vxGetObjectArrayItem(output_images, i);
if (!dst || vxGetStatus((vx_reference)dst) != VX_SUCCESS) {
printf("dst image invalid at cam %d\n", i);
continue;
uint8_t mask_this_cam = (i < num_items) ? is_mask_cam_flags[i] : 0;
if (mask_this_cam) {
vx_imagepatch_addressing_t dst_addr;
void *dst_ptr = NULL;
vx_map_id map_id;
// Y plane = 0
status = vxMapImagePatch(dst, &rect_y, 0, &map_id, &dst_addr, &dst_ptr, VX_WRITE_ONLY, VX_MEMORY_TYPE_HOST, 0);
if (status == VX_SUCCESS) {
memset(dst_ptr, 0x00, dst_addr.stride_y * dst_addr.dim_y);
vxUnmapImagePatch(dst, map_id);
// UV plane = 128
status = vxMapImagePatch(dst, &rect_uv, 1, &map_id, &dst_addr, &dst_ptr, VX_WRITE_ONLY, VX_MEMORY_TYPE_HOST, 0);
memset(dst_ptr, 0x80, dst_addr.stride_y * dst_addr.dim_y);
vxReleaseImage(&dst);
} else {
vx_image src = (vx_image)vxGetObjectArrayItem(input_images, i);
if (!src || vxGetStatus((vx_reference)src) != VX_SUCCESS) {
printf("src image invalid at cam %d\n", i);
continue;
vx_imagepatch_addressing_t src_addr, dst_addr;
void *src_ptr = NULL, *dst_ptr = NULL;
vx_map_id map_id_src, map_id_dst;
// Copy Y plane
status = vxMapImagePatch(src, &rect_y, 0, &map_id_src, &src_addr, &src_ptr, VX_READ_ONLY, VX_MEMORY_TYPE_HOST, 0);
status = vxMapImagePatch(dst, &rect_y, 0, &map_id_dst, &dst_addr, &dst_ptr, VX_WRITE_ONLY, VX_MEMORY_TYPE_HOST, 0);
memcpy(dst_ptr, src_ptr, src_addr.stride_y * src_addr.dim_y);
vxUnmapImagePatch(dst, map_id_dst);
vxUnmapImagePatch(src, map_id_src);
// Copy UV plane
src_ptr = dst_ptr = NULL;
status = vxMapImagePatch(src, &rect_uv, 1, &map_id_src, &src_addr, &src_ptr, VX_READ_ONLY, VX_MEMORY_TYPE_HOST, 0);
status = vxMapImagePatch(dst, &rect_uv, 1, &map_id_dst, &dst_addr, &dst_ptr, VX_WRITE_ONLY, VX_MEMORY_TYPE_HOST, 0);
vxReleaseImage(&src);
return VX_SUCCESS;
vx_kernel kernel = vxAddUserKernel(
context,
"mask_node",
0x1001, // kernel id, please use a bigger and unique number
vxMaskCameraImagesKernel,
6, // 6 parameters
NULL, NULL, NULL); // validate, input, output function, => NULL
if (kernel == NULL) {
printf("[MASK_KERNEL] vxAddUserKernel failed!\n");
return VX_FAILURE;
} else {
printf("[MASK_KERNEL] vxAddUserKernel success!\n");
vxAddParameterToKernel(kernel, 0, VX_INPUT, VX_TYPE_OBJECT_ARRAY, VX_PARAMETER_STATE_REQUIRED); // input_images
vxAddParameterToKernel(kernel, 1, VX_INPUT, VX_TYPE_SCALAR, VX_PARAMETER_STATE_REQUIRED); // width
vxAddParameterToKernel(kernel, 2, VX_INPUT, VX_TYPE_SCALAR, VX_PARAMETER_STATE_REQUIRED); // height
vxAddParameterToKernel(kernel, 3, VX_INPUT, VX_TYPE_SCALAR, VX_PARAMETER_STATE_REQUIRED); // cam_num
vxAddParameterToKernel(kernel, 4, VX_INPUT, VX_TYPE_ARRAY, VX_PARAMETER_STATE_REQUIRED); // is_mask_cam_array
vxAddParameterToKernel(kernel, 5, VX_OUTPUT, VX_TYPE_OBJECT_ARRAY, VX_PARAMETER_STATE_REQUIRED); // output_images
vxFinalizeKernel(kernel);
vxReleaseKernel(&kernel);
return VX_SUCCESS;
vx_kernel kernel = vxGetKernelByName(context, "mask_node");
if (kernel) {
vx_status s = vxRemoveKernel(kernel);
if (s == VX_SUCCESS) {
printf("[MASK_KERNEL] vxRemoveKernel success!\n");
return VX_SUCCESS;
} else {
printf("[MASK_KERNEL] vxRemoveKernel failed with status: %d\n", s);
return s;
} else {
printf("[MASK_KERNEL] vxGetKernelByName failed, kernel not found!\n");
return VX_FAILURE;
// app_3way_mask_module.h
#ifndef _APP_3WAY_MASK_MODULE
#define _APP_3WAY_MASK_MODULE
#include <stdio.h>
#include "app_modules.h"
typedef struct {
vx_node mask_node;
vx_scalar s_width, s_height, s_camnum;
vx_array flags;
vx_object_array masked_images;
uint8_t en_mask_overlay;
uint8_t en_mask_node;
uint8_t is_mask;
vx_uint8 is_mask_cam0, is_mask_cam1, is_mask_cam2, is_mask_cam3;
vx_image black_image;
} MaskObj;
vx_status app_init_3way_mask(vx_context context, MaskObj *maskObj, vx_uint32 width, vx_uint32 height, vx_uint32 cam_num);
vx_status app_create_graph_3way_mask(vx_graph graph, MaskObj *maskObj, vx_object_array input_images);
vx_status app_deinit_3way_mask(MaskObj *maskObj);
void app_delete_3way_mask(MaskObj *maskObj);
#endif
// app_3way_mask_module.c
#include "app_3way_mask_module.h"
if (!maskObj->black_image)
maskObj->black_image = vxCreateImage(context, width, height, VX_DF_IMAGE_NV12);
maskObj->masked_images = vxCreateObjectArray(context, (vx_reference)maskObj->black_image, cam_num);
maskObj->flags = vxCreateArray(context, VX_TYPE_UINT8, cam_num);
vx_uint8 cam_flags[4] = {maskObj->is_mask_cam0, maskObj->is_mask_cam1, maskObj->is_mask_cam2, maskObj->is_mask_cam3};
vxAddArrayItems(maskObj->flags, cam_num, cam_flags, sizeof(vx_uint8));
maskObj->s_width = vxCreateScalar(context, VX_TYPE_UINT32, &width);
maskObj->s_height = vxCreateScalar(context, VX_TYPE_UINT32, &height);
maskObj->s_camnum = vxCreateScalar(context, VX_TYPE_UINT32, &cam_num);
return VX_SUCCESS;
vx_kernel mask_kernel = vxGetKernelByName(vxGetContext((vx_reference)graph), "mask_node");
maskObj->mask_node = vxCreateGenericNode(graph, mask_kernel);
vxReleaseKernel(&mask_kernel);
vxSetParameterByIndex(maskObj->mask_node, 0, (vx_reference)input_images);
vxSetParameterByIndex(maskObj->mask_node, 1, (vx_reference)maskObj->s_width);
vxSetParameterByIndex(maskObj->mask_node, 2, (vx_reference)maskObj->s_height);
vxSetParameterByIndex(maskObj->mask_node, 3, (vx_reference)maskObj->s_camnum);
vxSetParameterByIndex(maskObj->mask_node, 4, (vx_reference)maskObj->flags);
vxSetParameterByIndex(maskObj->mask_node, 5, (vx_reference)maskObj->masked_images);
if (vxGetStatus((vx_reference)maskObj->mask_node) != VX_SUCCESS) {
APP_PRINTF("maskObj.mask_node create failed\n");
return VX_FAILURE;
return VX_SUCCESS;
// get cam_num integer
vx_uint32 cam_num = 0;
vxCopyScalar(maskObj->s_camnum, &cam_num, VX_READ_ONLY, VX_MEMORY_TYPE_HOST);
if (cam_num == 0) {
APP_PRINTF("cam_num is zero, nothing to deinit\n");
return VX_SUCCESS;
vxReleaseScalar(&maskObj->s_width);
vxReleaseScalar(&maskObj->s_height);
vxReleaseScalar(&maskObj->s_camnum);
vx_image masked_image = (vx_image)vxGetObjectArrayItem(maskObj->masked_images, i);
if (masked_image) {
vxReleaseImage(&masked_image);
vxReleaseObjectArray(&maskObj->masked_images);
if (maskObj->black_image) {
vxReleaseImage(&maskObj->black_image);
maskObj->black_image = NULL;
return VX_SUCCESS;
if(maskObj->mask_node != NULL)
vxReleaseNode(&maskObj->mask_node);
status = app_create_graph_3way_mask(obj->graph, &obj->maskObj, obj->ldcObj.output_arr); status = app_create_graph_srv_proc( obj->graph, &obj->srvObj, obj->maskObj.masked_images, NULL, NULL);
