Hpw can I use INTC function in SYS/BIOS?
Demon,
What type of information you are looking for?
Have you seen the 'cdoc' documentation for the CpIntc module? You can find this by clicking on the "SYS/BIOS APIs (cdoc) (Indexed and Searchable within CCS/Eclipse Help)" link in the SYS/BIOS release notes, and then navigating to the "ti.sysbios.family.c66.tci66xx.CpIntc" module.
Scott
Thank tou for your reply.
If I wanted to used C:\Program Files \Texas Instruments\pdk_C6670_1_0_0_17\packages\ti\csl\example\aif2 example change to BIOS(BIOS_start ()) interrupt, how can I do?
Demon,
I don’t know anything about the “pdk” product you’re referencing. But from the path, it looks like you’re using a CSL-based example. Typically CSL interrupt control mechanisms are incompatible with SYS/BIOS interrupt handling. To convert that example to use SYS/BIOS, you’ll need to remove the CSL interrupt code, and replace with the appropriate SYS/BIOS configuration and code.
Scott
Thank you for your reply.
I think must change the Intc_config(void),is right?
But how can I rewrite this Intc_config()?
I would suggest you take a look at the BIOS training here:
http://focus.ti.com/docs/training/catalog/events/event.jhtml?sku=OLT110026
Look at the HW and SW interrupt sections.
Travis
