SK-AM62-LP: In the MIPI-CSI2 camera pipeline, camera frames are dropped at higher frame rates.
Part Number: SK-AM62-LP
Hi Team,
We are testing a MIPI-CSI2 camera and encountered the following warning, and the video is not smooth when running the pipeline with format GRAY8, resolution 1120x1360, and framerate 30/1.
/usr/src/debug/gstreamer1.0/1.22.12/libs/gst/base/gstbasesink.c(3147): gst_base_sink_is_too_late (): /GstPipeline:pipeline0/GstKMSSink:kmssink0:
There may be a timestamping problem, or this computer is too slow.
root@am62xx-lp-evm:~# gst-launch-1.0 v4l2src device=/dev/video0 !     video/x-raw,format=GRAY8,width=1120,height=1360,framerate=30/1 !     queue max-size-buffers=4 ! videoconvert ! kmssink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Redistribute latency...
WARNING: from element /GstPipeline:pipeline0/GstKMSSink:kmssink0: A lot of buffers are being dropped.
Additional debug info:
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:08.584579289
Setting pipeline to NULL ...
Freeing pipeline ...
The pipeline runs smoothly with format GRAY8, resolution 1120x1360, and framerate 10/1 frame rate decrease 30 to 10.
root@am62xx-lp-evm:~# gst-launch-1.0 v4l2src device=/dev/video0 !     video/x-raw,format=GRAY8,width=1120,height=1360,framerate=10/1 !     queue max-size-buffers=4 ! videoconvert ! kmssink
Execution ended after 0:00:14.391994109
It also works fine with format GRAY8, resolution 680x480, and framerate 60/1.
Could you please suggest where the issue might be and how it can be resolved?
Gopal sharma
  • Hi Gopal,
    Videoconvert is a Software based plugin and would definitely be taking a lot of CPU on AM62x. Does adding a queue element in the pipeline help improve the FPS?
    Also can you share what camera are you testing with and the media-ctl -p /dev/media0 output when camera is connected on to the EVM.
    Suren
  • Hi Suren,
    No
    Pipeline with queue:-
    root@am62xx-lp-evm:~# gst-launch-1.0 v4l2src device=/dev/video0 ! \
    >     queue max-size-buffers=4 ! \
    >     video/x-raw,format=GRAY8,width=1120,height=1360,framerate=60/1 ! \
    >     videoconvert ! \
    >     kmssink
    Execution ended after 0:00:05.738267740
    Media controller API version 6.12.17
    Media device information
    driver          j721e-csi2rx
    model           TI-CSI2RX
    serial
    bus info        platform:30102000.ticsi2rx
    hw revision     0x1
    driver version  6.12.17
    Device topology
    - entity 1: 30102000.ticsi2rx (5 pads, 5 links, 1 route)
                type V4L2 subdev subtype Unknown flags 0
                device node name /dev/v4l-subdev0
            routes:
                    0/0 -> 1/0 [ACTIVE]
            pad0: SINK
                    [stream:0 fmt:Y8_1X8/1120x1360 field:none]
                    <- "cdns_csi2rx.30101000.csi-bridge":1 [ENABLED,IMMUTABLE]
            pad1: SOURCE
                    -> "30102000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE]
            pad2: SOURCE
                    -> "30102000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE]
            pad3: SOURCE
                    -> "30102000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE]
            pad4: SOURCE
                    -> "30102000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE]
    - entity 7: cdns_csi2rx.30101000.csi-bridge (5 pads, 2 links, 1 route)
                device node name /dev/v4l-subdev1
            routes:
                    0/0 -> 1/0 [ACTIVE]
            pad0: SINK
                    <- "vd56g3_iil 4-0010":0 [ENABLED,IMMUTABLE]
            pad1: SOURCE
                    -> "30102000.ticsi2rx":0 [ENABLED,IMMUTABLE]
            pad2: SOURCE
            pad3: SOURCE
            pad4: SOURCE
    - entity 13: vd56g3_iil 4-0010 (1 pad, 1 link, 0 routes)
                 type V4L2 subdev subtype Sensor flags 0
                 device node name /dev/v4l-subdev2
            pad0: SOURCE
                    [stream:0 fmt:Y8_1X8/1120x1360 field:none colorspace:raw xfer:none quantization:full-range
                     crop.bounds:(0,0)/1124x1364
                     crop:(2,2)/1120x1360]
                    -> "cdns_csi2rx.30101000.csi-bridge":0 [ENABLED,IMMUTABLE]
    - entity 19: 30102000.ticsi2rx context 0 (1 pad, 1 link)
                 type Node subtype V4L flags 0
                 device node name /dev/video0
            pad0: SINK
                    <- "30102000.ticsi2rx":1 [ENABLED,IMMUTABLE]
    - entity 25: 30102000.ticsi2rx context 1 (1 pad, 1 link)
                 device node name /dev/video1
            pad0: SINK
                    <- "30102000.ticsi2rx":2 [ENABLED,IMMUTABLE]
    - entity 31: 30102000.ticsi2rx context 2 (1 pad, 1 link)
                 device node name /dev/video2
            pad0: SINK
                    <- "30102000.ticsi2rx":3 [ENABLED,IMMUTABLE]
    - entity 37: 30102000.ticsi2rx context 3 (1 pad, 1 link)
                 device node name /dev/video3
            pad0: SINK
                    <- "30102000.ticsi2rx":4 [ENABLED,IMMUTABLE]
    Gopal Sharma
  • Hi Gopal,
    I have assigned your query to our camera expert for further support. Expect a response soon.
    Also can you add kmssink driver-name=tidss sync=false on the kmssink element.
    What framerates are supported with your camera sensor?
    You can refer the AM62 Academy on dumping the framesizes  and frameintervals supported with your camera
    https://dev.ti.com/tirex/explore/node?node=A__Afvqyi8mUm05676JZJ-UlQ__AM62-ACADEMY__uiYMDcq__LATEST
    Linux->Develop Linux on TI EVM ->Use Camera section in the above link.
    Suren
