TDA4VM: Kernel crash
Part Number: TDA4VM
I have loaded the UART example UART_TestApp_freertos_mcu2_1_release_strip.xer5f to my main r5f0_1 when i load it my kernel gets crashed.
Can you please help me in sorting this out.
U-Boot 2025.01-00410-g70667128cb5b-dirty (Apr 04 2025 - 18:20:14 +0000)
SoC:   J721E SR1.1 GP
Model: Texas Instruments J721e EVM
Board: J721EX-PM2-SOM rev A
DRAM:  2 GiB (total 4 GiB)
Core:  149 devices, 36 uclasses, devicetree: separate
Flash: 0 Bytes
MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
Loading Environment from nowhere... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1
Detected: J7X-BASE-CPB rev A
Detected: J7X-VSC8514-ETH rev E2
Net:   eth0: ethernet@46000000port@1
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
917 bytes read in 1 ms (895.5 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
gpio: pin gpio@22_17 (gpio 281) value is 1
gpio: pin gpio@22_16 (gpio 280) value is 0
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
Failed to load '/lib/firmware/j7-mcu-r5f0_1-fw'
96856 bytes read in 90 ms (1 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 96856 bytes: Success!
112712 bytes read in 86 ms (1.2 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 112712 bytes: Success!
 UART UT 1
 UART non-DMA read write test in block mode
Failed to load '/lib/firmware/j7-main-r5f1_0-fw'
 enter the data of 16 character
Failed to load '/lib/firmware/j7-main-r5f1_1-fw'
Failed to load '/lib/firmware/j7-c66_0-fw'
Failed to load '/lib/firmware/j7-c66_1-fw'
Failed to load '/lib/firmware/j7-c71_0-fw'
22256128 bytes read in 473 ms (44.9 MiB/s)
123937 bytes read in 7 ms (16.9 MiB/s)
Working FDT set to 88000000
1783 bytes read in 4 ms (434.6 KiB/s)
4285 bytes read in 4 ms (1 MiB/s)
   Loading Device Tree to 000000008fede000, end 000000008fffffff ... OK
Working FDT set to 8fede000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 6.12.17-ti-00773-gcdcaeac783e3-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Thu Apr  3 17:42:36 UTC 2025
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Texas Instruments J721e EVM
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: legacy bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created CMA memory pool at 0x00000008e0000000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000008e0000000..0x00000008ffffffff (524288 KiB) map reusable linux,cma
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
[    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000ac200000..0x00000000adffffff (30720 KiB) nomap non-reusable r5f-virtual-eth-buffers@ac200000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
[    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000ac000000..0x00000000ac1fffff (2048 KiB) nomap non-reusable r5f-virtual-eth-queues@ac000000
[    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a0000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable r5f-memory@a0100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a1000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable r5f-memory@a1100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a2000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a2ffffff (15360 KiB) nomap non-reusable r5f-memory@a2100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000a30fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a3000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a3100000..0x00000000a3ffffff (15360 KiB) nomap non-reusable r5f-memory@a3100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a40fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a4000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a4100000..0x00000000a4ffffff (15360 KiB) nomap non-reusable r5f-memory@a4100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a5000000..0x00000000a50fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a5000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a5100000..0x00000000a5ffffff (15360 KiB) nomap non-reusable r5f-memory@a5100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a6000000..0x00000000a60fffff (1024 KiB) nomap non-reusable c66-dma-memory@a6000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a6100000..0x00000000a6ffffff (15360 KiB) nomap non-reusable c66-memory@a6100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a7000000..0x00000000a70fffff (1024 KiB) nomap non-reusable c66-dma-memory@a7000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a7100000..0x00000000a7ffffff (15360 KiB) nomap non-reusable c66-memory@a7100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a8000000..0x00000000a80fffff (1024 KiB) nomap non-reusable c71-dma-memory@a8000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a8100000..0x00000000a8ffffff (15360 KiB) nomap non-reusable c71-memory@a8100000
[    0.000000] OF: reserved mem: 0x00000000aa000000..0x00000000abbfffff (28672 KiB) nomap non-reusable ipc-memories@aa000000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000008db00000, size 20 MiB
[    0.000000] OF: reserved mem: initialized node shared-mem@abc00000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000008db00000..0x000000008eefffff (20480 KiB) nomap non-reusable shared-mem@abc00000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000008dafffff]
[    0.000000]   node   0: [mem 0x000000008db00000-0x000000008eefffff]
[    0.000000]   node   0: [mem 0x000000008ef00000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
[    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
[    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000abffffff]
[    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000adffffff]
[    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.5
[    0.000000] percpu: Embedded 22 pages/cpu s51672 r8192 d30248 u90112
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Spectre-v3a
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: ARM erratum 1742098
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57344k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=0041d71a-02 rw rootfstype=ext4 rootwait
[    0.000000] Unknown kernel command line parameters "mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57344k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs)", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1048576
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 2.
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=2.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=2.
[    0.000000] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=2.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000880040000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008555] Console: colour dummy device 80x25
[    0.013125] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023797] pid_max: default: 32768 minimum: 301
[    0.028558] LSM: initializing lsm=capability,selinux
[    0.033666] SELinux:  Initializing.
[    0.037523] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.045095] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.065391] rcu: Hierarchical SRCU implementation.
[    0.070300] rcu: 	Max phase no-delay instances is 1000.
[    0.075762] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.084447] EFI services will not be available.
[    0.089198] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[    0.102430] Detected PIPT I-cache on CPU1
[    0.102482] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.102495] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
[    0.102526] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.102607] smp: Brought up 1 node, 2 CPUs
[    0.131957] SMP: Total of 2 processors activated.
[    0.136761] CPU: All CPU(s) started at EL2
[    0.140949] CPU features: detected: 32-bit EL0 Support
[    0.146199] CPU features: detected: CRC32 instructions
[    0.151464] alternatives: applying system-wide alternatives
[    0.157417] Memory: 3238920K/4194304K available (12928K kernel code, 1254K rwdata, 4644K rodata, 2752K init, 639K bss, 422996K reserved, 524288K cma-reserved)
[    0.172425] devtmpfs: initialized
[    0.183123] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.193098] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.206158] 27152 pages in range for non-PLT usage
[    0.206170] 518672 pages in range for PLT usage
[    0.211301] pinctrl core: initialized pinctrl subsystem
[    0.221511] DMI not present or invalid.
[    0.226712] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.233366] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.240665] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.248662] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.256795] audit: initializing netlink subsys (disabled)
[    0.262504] audit: type=2000 audit(0.200:1): state=initialized audit_enabled=0 res=1
[    0.262731] thermal_sys: Registered thermal governor 'step_wise'
[    0.270428] thermal_sys: Registered thermal governor 'power_allocator'
[    0.276590] cpuidle: using governor menu
[    0.287372] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.294340] ASID allocator initialised with 65536 entries
[    0.305749] /bus@100000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@100000/interrupt-controller@1800000
[    0.317674] /bus@100000/dp-bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.326764] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/dp-bridge@a000000
[    0.342166] /bus@100000/dp-bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.351477] /bus@100000/dp-bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.360581] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/dp-bridge@a000000
[    0.371635] /bus@100000/dp-bridge@a000000: Fixed dependency cycle(s) with /connector
[    0.379608] /connector: Fixed dependency cycle(s) with /bus@100000/dp-bridge@a000000
[    0.388036] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.394981] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.401385] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.408320] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.414722] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.421657] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.428059] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.434993] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.442474] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.1 JTAGID[0x1bb6402f] Detected
[    0.455043] iommu: Default domain type: Translated
[    0.459947] iommu: DMA domain TLB invalidation policy: strict mode
[    0.466433] SCSI subsystem initialized
[    0.470458] usbcore: registered new interface driver usbfs
[    0.476085] usbcore: registered new interface driver hub
[    0.481531] usbcore: registered new device driver usb
[    0.487009] pps_core: LinuxPPS API ver. 1 registered
[    0.492082] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.501421] PTP clock support registered
[    0.505443] EDAC MC: Ver: 3.0.0
[    0.508804] scmi_core: SCMI protocol bus registered
[    0.513945] FPGA manager framework
[    0.517456] Advanced Linux Sound Architecture Driver Initialized.
[    0.524108] vgaarb: loaded
[    0.527046] clocksource: Switched to clocksource arch_sys_counter
[    0.533419] VFS: Disk quotas dquot_6.6.0
[    0.537441] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.548205] NET: Registered PF_INET protocol family
[    0.553340] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.562318] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.571087] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.579011] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.587218] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.595707] TCP: Hash tables configured (established 32768 bind 32768)
[    0.602480] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.609394] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.616826] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.622934] RPC: Registered named UNIX socket transport module.
[    0.628996] RPC: Registered udp transport module.
[    0.633801] RPC: Registered tcp transport module.
[    0.638604] RPC: Registered tcp-with-tls transport module.
[    0.644208] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.650792] NET: Registered PF_XDP protocol family
[    0.655696] PCI: CLS 0 bytes, default 64
[    0.660370] Initialise system trusted keyrings
[    0.665036] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.671798] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.677896] NFS: Registering the id_resolver key type
[    0.683076] Key type id_resolver registered
[    0.687351] Key type id_legacy registered
[    0.691454] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.698304] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.727371] Key type asymmetric registered
[    0.731560] Asymmetric key parser 'x509' registered
[    0.736569] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.744228] io scheduler mq-deadline registered
[    0.748864] io scheduler kyber registered
[    0.752977] io scheduler bfq registered
[    0.759257] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.765674] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.771999] pinctrl-single 104200.pinctrl: 20 pins, size 80
[    0.777769] pinctrl-single 104280.pinctrl: 8 pins, size 32
[    0.783973] ledtrig-cpu: registered to indicate activity on CPUs
[    0.793738] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.801990] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00101faf)
[    0.810661] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[    0.817783] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[    0.824940] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.836276] loop: module loaded
[    0.840138] megasas: 07.727.03.00-rc1
[    0.845826] tun: Universal TUN/TAP device driver, 1.6
[    0.851653] VFIO - User Level meta-driver version: 0.3
[    0.857651] usbcore: registered new interface driver usb-storage
[    0.864183] i2c_dev: i2c /dev entries driver
[    0.869262] sdhci: Secure Digital Host Controller Interface driver
[    0.875589] sdhci: Copyright(c) Pierre Ossman
[    0.880184] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.886408] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.893421] usbcore: registered new interface driver usbhid
[    0.899125] usbhid: USB HID core driver
[    0.903685] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 (0,8000003f) counters available
[    0.913596] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[    0.918157] optee: revision 4.5 (ef1ebdc23034a804)
[    0.934619] optee: dynamic shared memory is enabled
[    0.944909] optee: initialized driver
[    0.944993] random: crng init done
[    0.950173] Initializing XFRM netlink socket
[    0.956535] NET: Registered PF_PACKET protocol family
[    0.961740] Key type dns_resolver registered
[    0.969972] registered taskstats version 1
[    0.974358] Loading compiled-in X.509 certificates
[    0.986212] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)')
[    1.108017] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[    1.114499] pca953x 1-0020: supply vcc not found, using dummy regulator
[    1.121331] pca953x 1-0020: using no AI
[    1.139809] pca953x 1-0022: supply vcc not found, using dummy regulator
[    1.146628] pca953x 1-0022: using AI
[    1.151791] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz
[    1.158031] omap_i2c 2010000.i2c: bus 2 rev0.12 at 400 kHz
[    1.164290] pca953x 3-0020: supply vcc not found, using dummy regulator
[    1.171121] pca953x 3-0020: using no AI
[    1.191394] omap_i2c 2030000.i2c: bus 3 rev0.12 at 400 kHz
[    1.197562] pca953x 4-0020: supply vcc not found, using dummy regulator
[    1.204387] pca953x 4-0020: using no AI
[    1.223389] omap_i2c 2060000.i2c: bus 4 rev0.12 at 400 kHz
[    1.229150] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
[    1.237711] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
[    1.247069] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
[    1.255694] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    1.270527] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    1.280424] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    1.287189] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.296959] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    1.307135] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.313896] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.322072] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 206, base_baud = 6000000) is a 8250
[    1.331830] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 207, base_baud = 3000000) is a 8250
[    1.340705] printk: legacy console [ttyS2] enabled
[    1.350464] printk: legacy bootconsole [ns16550a0] disabled
[    1.365202] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[    1.407057] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.416491] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    1.424767] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    1.437627] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    1.444839] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64, Policers 8
[    1.452279] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1
[    1.463093] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    1.472264] mmc0: CQHCI version 5.10
[    1.479959] pca953x 2-0020: supply vcc not found, using dummy regulator
[    1.486727] pca953x 2-0020: using no AI
[    1.511368] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    1.515081] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    1.529489] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[    1.544392] 8 fixed-partitions partitions found on MTD device 47040000.spi.0
[    1.551565] Creating 8 MTD partitions on "47040000.spi.0":
[    1.557105] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    1.563413] 0x000000080000-0x000000280000 : "ospi.tispl"
[    1.569272] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    1.575203] 0x000000680000-0x0000006a0000 : "ospi.env"
[    1.580863] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[    1.587134] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    1.593020] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    1.598932] 0x000003fe0000-0x000004000000 : "ospi.phypattern"
[    1.605292] cadence-qspi 47040000.spi: Pattern not found. Skipping calibration.
[    1.615764] 8 fixed-partitions partitions found on MTD device 47050000.spi.0
[    1.622813] Creating 8 MTD partitions on "47050000.spi.0":
[    1.628292] 0x000000000000-0x000000080000 : "qspi.tiboot3"
[    1.634373] 0x000000080000-0x000000280000 : "qspi.tispl"
[    1.640211] 0x000000280000-0x000000680000 : "qspi.u-boot"
[    1.646123] 0x000000680000-0x0000006a0000 : "qspi.env"
[    1.651384] mmc0: Command Queue Engine enabled
[    1.651914] 0x0000006a0000-0x0000006c0000 : "qspi.env.backup"
[    1.655845] mmc0: new HS200 MMC card at address 0001
[    1.662078] 0x0000006c0000-0x0000007c0000 : "qspi.sysfw"
[    1.666915] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    1.672385] 0x000000800000-0x000003fc0000 : "qspi.rootfs"
[    1.677169]  mmcblk0: p1 p2 p3
[    1.682230] 0x000003fe0000-0x000004000000 : "qspi.phypattern"
[    1.685063] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[    1.695682] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[    1.696055] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[    1.707756] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
[    1.735059] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.744508] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    1.752784] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    1.765658] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    1.772867] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64, Policers 8
[    1.780267] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1
[    1.799433] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    1.811801] mmc1: CQHCI version 5.10
[    1.818023] clk: Disabling unused clocks
[    1.843751] PM: genpd: Disabling unused power domains
[    1.848949] ALSA device list:
[    1.851914]   No soundcards found.
[    1.859601] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    1.867268] Waiting for root device PARTUUID=0041d71a-02...
[    1.926778] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
[    1.937681] mmcblk1: mmc1:aaaa SK32G 29.7 GiB
[    1.943476]  mmcblk1: p1 p2
[    1.970401] EXT4-fs (mmcblk1p2): mounted filesystem ac8d66a5-246a-4c64-bb2d-923121e522b6 r/w with ordered data mode. Quota mode: none.
[    1.982512] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    1.992745] devtmpfs: mounted
[    1.996872] Freeing unused kernel memory: 2752K
[    2.001486] Run /sbin/init as init process
[    2.322741] systemd[1]: System time before build time, advancing clock.
[    2.387087] NET: Registered PF_INET6 protocol family
[    2.392604] Segment Routing with IPv6
[    2.396290] In-situ OAM (IOAM) with IPv6
[    2.433240] systemd[1]: systemd 255.18^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    2.465112] systemd[1]: Detected architecture arm64.
Welcome to Arago 2025.01!
[    2.486543] systemd[1]: Hostname set to <j721e-evm>.
[    2.699395] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    2.799907] systemd[1]: Queued start job for default target Graphical Interface.
[    2.842123] systemd[1]: Created slice Slice /system/getty.
 UART UT 1 FAILED
 Some tests have failed.
Thankyou
    What is your boot mode?
    Do you only have this issue when using the UART example?
    Neehar
    SD card boot mode
    yes, this issue is only with UART.
    Thankyou
    SD card boot mode
    Have you made any changes to the default Linux or RTOS SDK image that is flashed?
    Does the issue only occur on MCU2_1 core?
    Neehar
  • Have you made any changes to the default Linux or RTOS SDK image that is flashed?
    No, its with the default RTOS SDK.
    we have checked it with the all four main R5F cores.
    is there any update for this issue.
    Could you confirm what SDK version this is?
    Are you able to boot other apps via SD card? You are booting with SPL bootflow correct?
    Neehar
    version:11.0.0.1
    Yes, I'm able to boot other app via SD-card the other cores are failed due to, i have not loaded or created the softlink in the remoteproc.
    Let me look into this further and get back to you tomorrow.
    Neehar
    Could you please confirm which cores fail and which are running? You must have MCU1_0 running as it acts as the device manager core running SYSFW. It is required to run sciserver, resource management, and power management.
    Neehar
  • U-Boot 2025.01-00410-g70667128cb5b-dirty (Apr 04 2025 - 18:20:14 +0000)
    SoC:   J721E SR1.1 GP
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    917 bytes read in 4 ms (223.6 KiB/s)
    Running uenvcmd ...
    112712 bytes read in 89 ms (1.2 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 112712 bytes: Success!
     UART UT 1
    Failed to load '/lib/firmware/j7-main-r5f0_1-fw'
    96728 bytes read in 89 ms (1 MiB/s)
    Load Remote Processor 4 with data@addr=0x82000000 96728 bytes: Success!
    96728 bytes read in 90 ms (1 MiB/s)
    Load Remote Processor 5 with data@addr=0x82000000 96728 bytes: Success!
    22256128 bytes read in 475 ms (44.7 MiB/s)
    123798 bytes read in 7 ms (16.9 MiB/s)
    Starting kernel ...
    [    0.008495] Console: colour dummy device 80x25
    [    0.013065] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023737] pid_max: default: 32768 minimum: 301
    [    0.028498] LSM: initializing lsm=capability,selinux
    [    0.033606] SELinux:  Initializing.
    [    0.037466] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.045037] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.069334] rcu: Hierarchical SRCU implementation.
    [    0.074241] rcu: 	Max phase no-delay instances is 1000.
    [    0.079701] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.088352] EFI services will not be available.
    [    0.093102] smp: Bringing up secondary CPUs ...
    [    0.106327] Detected PIPT I-cache on CPU1
    [    0.106379] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.106392] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
    [    0.106423] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.106509] smp: Brought up 1 node, 2 CPUs
    [    0.135856] SMP: Total of 2 processors activated.
    [    0.140660] CPU: All CPU(s) started at EL2
    [    0.144849] CPU features: detected: 32-bit EL0 Support
    [    0.150099] CPU features: detected: CRC32 instructions
    [    0.155363] alternatives: applying system-wide alternatives
    [    0.161317] Memory: 3238924K/4194304K available (12928K kernel code, 1254K rwdata, 4644K rodata, 2752K init, 639K bss, 422992K reserved, 524288K cma-reserved)
    [    0.176327] devtmpfs: initialized
    [    0.187012] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.196987] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.210138] 27152 pages in range for non-PLT usage
    [    0.210151] 518672 pages in range for PLT usage
    [    0.215285] pinctrl core: initialized pinctrl subsystem
    [    0.225499] DMI not present or invalid.
    [    0.230700] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.237377] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.244676] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.252673] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.260808] audit: initializing netlink subsys (disabled)
    [    0.266513] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
    [    0.266736] thermal_sys: Registered thermal governor 'step_wise'
    [    0.274437] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.280600] cpuidle: using governor menu
    [    0.291381] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.298349] ASID allocator initialised with 65536 entries
    [    0.309412] /bus@100000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@100000/interrupt-controller@1800000
    [    0.321336] /bus@100000/dp-bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
    [    0.330424] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/dp-bridge@a000000
    [    0.345725] /bus@100000/dp-bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
    [    0.355025] /bus@100000/dp-bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
    [    0.364128] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/dp-bridge@a000000
    [    0.375157] /bus@100000/dp-bridge@a000000: Fixed dependency cycle(s) with /connector
    [    0.383128] /connector: Fixed dependency cycle(s) with /bus@100000/dp-bridge@a000000
    [    0.391566] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.398511] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.404915] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.411850] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.418253] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.425188] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.431591] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.438525] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.446011] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.1 JTAGID[0x1bb6402f] Detected
    [    0.458585] iommu: Default domain type: Translated
    [    0.463488] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.469981] SCSI subsystem initialized
    [    0.474013] usbcore: registered new interface driver usbfs
    [    0.479635] usbcore: registered new interface driver hub
    [    0.485076] usbcore: registered new device driver usb
    [    0.490556] pps_core: LinuxPPS API ver. 1 registered
    [    0.495630] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.504969] PTP clock support registered
    [    0.508990] EDAC MC: Ver: 3.0.0
    [    0.512359] scmi_core: SCMI protocol bus registered
    [    0.517497] FPGA manager framework
    [    0.521010] Advanced Linux Sound Architecture Driver Initialized.
    [    0.527667] vgaarb: loaded
    [    0.530604] clocksource: Switched to clocksource arch_sys_counter
    [    0.536977] VFS: Disk quotas dquot_6.6.0
    [    0.540999] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.551765] NET: Registered PF_INET protocol family
    [    0.556899] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.565919] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.574688] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.582611] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.590816] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
    [    0.599305] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.606078] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.612994] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.620428] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.626544] RPC: Registered named UNIX socket transport module.
    [    0.632608] RPC: Registered udp transport module.
    [    0.637415] RPC: Registered tcp transport module.
    [    0.642218] RPC: Registered tcp-with-tls transport module.
    [    0.647822] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.654406] NET: Registered PF_XDP protocol family
    [    0.659311] PCI: CLS 0 bytes, default 64
    [    0.663985] Initialise system trusted keyrings
    [    0.668658] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.675424] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.681526] NFS: Registering the id_resolver key type
    [    0.686705] Key type id_resolver registered
    [    0.690980] Key type id_legacy registered
    [    0.695083] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.701933] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.731001] Key type asymmetric registered
    [    0.735190] Asymmetric key parser 'x509' registered
    [    0.740201] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.747868] io scheduler mq-deadline registered
    [    0.752503] io scheduler kyber registered
    [    0.756616] io scheduler bfq registered
    [    0.762844] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.769247] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.775564] pinctrl-single 104200.pinctrl: 20 pins, size 80
    [    0.781333] pinctrl-single 104280.pinctrl: 8 pins, size 32
    [    0.787522] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.797249] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.805389] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00101faf)
    [    0.814074] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.821201] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.828354] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.839722] loop: module loaded
    [    0.843582] megasas: 07.727.03.00-rc1
    [    0.849286] tun: Universal TUN/TAP device driver, 1.6
    [    0.855114] VFIO - User Level meta-driver version: 0.3
    [    0.861082] usbcore: registered new interface driver usb-storage
    [    0.867610] i2c_dev: i2c /dev entries driver
    [    0.872665] sdhci: Secure Digital Host Controller Interface driver
    [    0.878990] sdhci: Copyright(c) Pierre Ossman
    [    0.883577] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.889763] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.896760] usbcore: registered new interface driver usbhid
    [    0.902459] usbhid: USB HID core driver
    [    0.907018] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 (0,8000003f) counters available
    [    0.916851] optee: probing for conduit method.
    [    0.921407] optee: revision 4.5 (ef1ebdc23034a804)
    [    0.937894] optee: dynamic shared memory is enabled
    [    0.948187] optee: initialized driver
    [    0.948268] random: crng init done
    [    0.953493] Initializing XFRM netlink socket
    [    0.959811] NET: Registered PF_PACKET protocol family
    [    0.965014] Key type dns_resolver registered
    [    0.973239] registered taskstats version 1
    [    0.977621] Loading compiled-in X.509 certificates
    [    0.989444] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)')
    [    1.110527] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.117018] pca953x 1-0020: supply vcc not found, using dummy regulator
    [    1.123849] pca953x 1-0020: using no AI
    [    1.143366] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.150186] pca953x 1-0022: using AI
    [    1.155343] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.161582] omap_i2c 2010000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.167848] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    1.174677] pca953x 3-0020: using no AI
    [    1.194955] omap_i2c 2030000.i2c: bus 3 rev0.12 at 400 kHz
    [    1.201127] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    1.207952] pca953x 4-0020: using no AI
    [    1.226956] omap_i2c 2060000.i2c: bus 4 rev0.12 at 400 kHz
    [    1.232724] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
    [    1.241287] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
    [    1.250645] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
    [    1.259277] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.274153] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    1.284053] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.290818] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.300609] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    1.310787] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.317549] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.325753] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 206, base_baud = 6000000) is a 8250
    [    1.335512] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 207, base_baud = 3000000) is a 8250
    [    1.344382] printk: legacy console [ttyS2] enabled
    [    1.354147] printk: legacy bootconsole [ns16550a0] disabled
    [    1.368687] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.410616] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.420052] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.428329] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.441191] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.448408] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64, Policers 8
    [    1.455849] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1
    [    1.466675] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    1.475755] mmc0: CQHCI version 5.10
    [    1.479917] pca953x 2-0020: supply vcc not found, using dummy regulator
    [    1.486771] pca953x 2-0020: using no AI
    [    1.518914] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.526617] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.530240] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    1.549927] 8 fixed-partitions partitions found on MTD device 47040000.spi.0
    [    1.557038] Creating 8 MTD partitions on "47040000.spi.0":
    [    1.562566] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.568793] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.574656] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.580559] 0x000000680000-0x0000006a0000 : "ospi.env"
    [    1.586196] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
    [    1.592470] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    1.598279] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.604195] 0x000003fe0000-0x000004000000 : "ospi.phypattern"
    [    1.610479] cadence-qspi 47040000.spi: Pattern not found. Skipping calibration.
    [    1.620944] 8 fixed-partitions partitions found on MTD device 47050000.spi.0
    [    1.627996] Creating 8 MTD partitions on "47050000.spi.0":
    [    1.633477] 0x000000000000-0x000000080000 : "qspi.tiboot3"
    [    1.639582] 0x000000080000-0x000000280000 : "qspi.tispl"
    [    1.645414] 0x000000280000-0x000000680000 : "qspi.u-boot"
    [    1.651309] 0x000000680000-0x0000006a0000 : "qspi.env"
    [    1.656985] 0x0000006a0000-0x0000006c0000 : "qspi.env.backup"
    [    1.663239] 0x0000006c0000-0x0000007c0000 : "qspi.sysfw"
    [    1.669071] 0x000000800000-0x000003fc0000 : "qspi.rootfs"
    [    1.675013] 0x000003fe0000-0x000004000000 : "qspi.phypattern"
    [    1.681869] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.692231] mmc0: Command Queue Engine enabled
    [    1.696687] mmc0: new HS200 MMC card at address 0001
    [    1.702013] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    1.707404]  mmcblk0: p1 p2
    [    1.710479] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    1.716004] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    1.721489] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
    [    1.727777] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.737286] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.745568] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.758498] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.765714] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64, Policers 8
    [    1.773147] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1
    [    1.793015] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    1.805322] mmc1: CQHCI version 5.10
    [    1.808511] clk: Disabling unused clocks
    [    1.834291] PM: genpd: Disabling unused power domains
    [    1.839425] ALSA device list:
    [    1.842382]   No soundcards found.
    [    1.850616] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    1.858352] Waiting for root device PARTUUID=0041d71a-02...
    [    1.923068] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    1.929940] mmcblk1: mmc1:aaaa SK32G 29.7 GiB
    [    1.935734]  mmcblk1: p1 p2
    [    1.963917] EXT4-fs (mmcblk1p2): mounted filesystem ac8d66a5-246a-4c64-bb2d-923121e522b6 r/w with ordered data mode. Quota mode: none.
    [    1.976028] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    1.986597] devtmpfs: mounted
    [    1.990785] Freeing unused kernel memory: 2752K
    [    1.995380] Run /sbin/init as init process
    [    2.314557] systemd[1]: System time before build time, advancing clock.
    [    2.377852] NET: Registered PF_INET6 protocol family
    [    2.383384] Segment Routing with IPv6
    [    2.387064] In-situ OAM (IOAM) with IPv6
    [    2.424043] systemd[1]: systemd 255.18^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.455960] systemd[1]: Detected architecture arm64.
    [    2.482377] systemd[1]: Hostname set to <j721e-evm>.
    [    2.690792] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    2.793291] systemd[1]: Queued start job for default target Graphical Interface.
    [    2.837652] systemd[1]: Created slice Slice /system/getty.
    [   11.880040] platform bus@100000:wiz@5050000: deferred probe pending: (reason unknown)
    [   11.887883] platform 2900000.pcie: deferred probe pending: (reason unknown)
    [   11.894837] platform 2910000.pcie: deferred probe pending: (reason unknown)
    [   11.901784] platform 2920000.pcie: deferred probe pending: (reason unknown)
    [   11.908732] platform c000000.ethernet: deferred probe pending: (reason unknown)
    [   11.916028] i2c 0-0048: deferred probe pending: (reason unknown)
    [   11.922021] i2c 0-004c: deferred probe pending: (reason unknown)
    [   11.928015] platform gpio-keys: deferred probe pending: gpio-keys: failed to get gpio
    [   33.895975] systemd[1]: Created slice Slice /system/modprobe.
    [   64.615883] systemd[1]: Created slice Slice /system/serial-getty.
    [   95.335598] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/m
     UART UT 1 FAILED
    In this log if you check the only core which gets failed is MCU1_1 is only getting failed MCU1_0 is in running state. all other cores are also running.
    Thanks for the logs, I will need to discuss this with the team and get back to you.
    Neehar
  • hi,
    Is there any update on the issue?
    Sorry for the delays, I will follow up by the end of the week.
    Neehar
    Is there any update
    Does the UART example run properly and pass all test cases on the R5 core? Are you able to see the logs from the test?
    Neehar
    Im testing it actually with the UART example code, Its the log which i have provided earlier.
    Can you please test disabling the UART instance, used for the UART TestApp, within the Linux device tree? Could you provide the logs after these changes?
    Additionally, is this a TI EVM or a custom board? Which UART port do the logs show on?
    Neehar
    yes, Sure i will test and share you the logs.
    im working on EVM Board, UART port is main UART0.
  • Thanks, I will wait for your results.
  • U-Boot SPL 2025.01-g70667128cb5b-dirty (Oct 24 2025 - 14:39:30 +0530)
    SYSFW ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)')
    Trying to boot from MMC2
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.12.0(release):11.00.09-dirty
    NOTICE:  BL31: Built : 12:35:58, Mar 24 2025
    I/TC:
    I/TC: OP-TEE version: 4.5.0-73-gef1ebdc23-dev (gcc version 13.3.0 (GCC)) #1 Tue Feb  4 11:33:18 UTC 2025 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: GIC redistributor base address not provided
    I/TC: Assuming default GIC group status and modifier
    I/TC: SYSFW ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)')
    I/TC: Activated SA2UL device
    I/TC: Fixing SA2UL firewall owner for GP device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: HUK Initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot SPL 2025.01-g70667128cb5b-dirty (Oct 24 2025 - 14:40:07 +0530)
    U-Boot 2025.01-g70667128cb5b-dirty (Oct 24 2025 - 14:40:07 +0530)
    SoC:   J721E SR1.1 GP
    Core:  147 devices, 36 uclasses, devicetree: separate
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    907 bytes read in 1 ms (885.7 KiB/s)
    Running uenvcmd ...
    112712 bytes read in 42 ms (2.6 MiB/s)
     UART UT 1
    351412 bytes read in 48 ms (7 MiB/s)
    Load Remote Processor 3 with data@addr=0x82000000 351412 bytes: Success!
    1014576 bytes read in 61 ms (15.9 MiB/s)
    Load Remote Processor 6 with data@addr=0x82000000 1014576 bytes: Success!
    1014576 bytes read in 62 ms (15.6 MiB/s)
    Load Remote Processor 7 with data@addr=0x82000000 1014576 bytes: Success!
    13234320 bytes read in 317 ms (39.8 MiB/s)
    Load Remote Processor 8 with data@addr=0x82000000 13234320 bytes: Success!
    22256128 bytes read in 464 ms (45.7 MiB/s)
    123980 bytes read in 7 ms (16.9 MiB/s)
    1783 bytes read in 3 ms (580.1 KiB/s)
    11521 bytes read in 4 ms (2.7 MiB/s)
    Starting kernel ...
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x0000000880000000..0x00000008a6ffffff (638976 KiB) nomap non-reusable vision-apps-core-heap-memory-hi@880000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000e4800000..0x00000000e5ffffff (24576 KiB) nomap non-reusable vision-apps-r5f-virtual-eth-buffers@e4800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000e4000000..0x00000000e47fffff (8192 KiB) nomap non-reusable vision-apps-r5f-virtual-eth-queues@e4000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000d8000000..0x00000000e3ffffff (196608 KiB) nomap non-reusable vision-apps-core-heap-memory-lo@d8000000
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] OF: reserved mem: 0x00000000b8000000..0x00000000d7ffffff (524288 KiB) map non-reusable vision_apps_shared-memories
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000b2100000..0x00000000b7ffffff (97280 KiB) nomap non-reusable vision-apps-c71-memory@b2100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000b2000000..0x00000000b20fffff (1024 KiB) nomap non-reusable vision-apps-c71-dma-memory@b2000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000ac000000..0x00000000b1ffffff (98304 KiB) nomap non-reusable vision-apps-dma-memory@ac000000
    [    0.000000] OF: reserved mem: 0x00000000aa000000..0x00000000abffffff (32768 KiB) nomap non-reusable vision-apps-rtos-ipc-memory-region
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a9100000..0x00000000a9ffffff (15360 KiB) nomap non-reusable vision-apps-c66-memory@a9100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a9000000..0x00000000a90fffff (1024 KiB) nomap non-reusable vision-apps-c66-dma-memory@a9000000
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a8100000..0x00000000a8ffffff (15360 KiB) nomap non-reusable vision-apps-c66-memory@a8100000
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a8000000..0x00000000a80fffff (1024 KiB) nomap non-reusable vision-apps-c66-dma-memory@a8000000
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a7100000..0x00000000a7ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a7100000
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a7000000..0x00000000a70fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a7000000
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a6100000..0x00000000a6ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a6100000
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a6000000..0x00000000a60fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a6000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a4100000..0x00000000a5ffffff (31744 KiB) nomap non-reusable vision-apps-r5f-memory@a4100000
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a40fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a4000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a3ffffff (31744 KiB) nomap non-reusable vision-apps-r5f-memory@a2100000
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a2000000
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a1100000
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a1000000
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a0100000
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a0000000
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000b7ffffff]
    [    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
    [    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000e5ffffff]
    [    0.000000]   node   0: [mem 0x00000000e6000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008a6ffffff]
    [    0.000000]   node   0: [mem 0x00000008a7000000-0x00000008ffffffff]
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57344k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=0726f891-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a7800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] GICv3: using LPI property table @0x00000008a7040000
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a7050000
    [    0.008510] Console: colour dummy device 80x25
    [    0.013082] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023754] pid_max: default: 32768 minimum: 301
    [    0.028514] LSM: initializing lsm=capability,selinux
    [    0.033625] SELinux:  Initializing.
    [    0.037488] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.045055] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.065454] rcu: Hierarchical SRCU implementation.
    [    0.070363] rcu: 	Max phase no-delay instances is 1000.
    [    0.075824] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.084519] EFI services will not be available.
    [    0.089280] smp: Bringing up secondary CPUs ...
    [    0.102538] Detected PIPT I-cache on CPU1
    [    0.102590] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.102603] GICv3: CPU1: using allocated LPI pending table @0x00000008a7060000
    [    0.102636] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.102729] smp: Brought up 1 node, 2 CPUs
    [    0.132079] SMP: Total of 2 processors activated.
    [    0.136883] CPU: All CPU(s) started at EL2
    [    0.141072] CPU features: detected: 32-bit EL0 Support
    [    0.146321] CPU features: detected: CRC32 instructions
    [    0.151587] alternatives: applying system-wide alternatives
    [    0.157549] Memory: 1667196K/4194304K available (12928K kernel code, 1254K rwdata, 4644K rodata, 2752K init, 639K bss, 1994848K reserved, 524288K cma-reserved)
    [    0.172703] devtmpfs: initialized
    [    0.183795] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.193771] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.207678] 27152 pages in range for non-PLT usage
    [    0.207691] 518672 pages in range for PLT usage
    [    0.212835] pinctrl core: initialized pinctrl subsystem
    [    0.223065] DMI not present or invalid.
    [    0.228283] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.234969] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.242276] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.250274] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.258409] audit: initializing netlink subsys (disabled)
    [    0.264117] audit: type=2000 audit(0.200:1): state=initialized audit_enabled=0 res=1
    [    0.264352] thermal_sys: Registered thermal governor 'step_wise'
    [    0.272036] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.278198] cpuidle: using governor menu
    [    0.288978] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.295947] ASID allocator initialised with 65536 entries
    [    0.306875] /bus@100000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@100000/interrupt-controller@1800000
    [    0.327308] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.334258] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.340665] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.347602] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.354005] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.360939] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.367341] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.374276] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.381788] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.1 JTAGID[0x1bb6402f] Detected
    [    0.394360] iommu: Default domain type: Translated
    [    0.399264] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.405751] SCSI subsystem initialized
    [    0.409784] usbcore: registered new interface driver usbfs
    [    0.415412] usbcore: registered new interface driver hub
    [    0.420859] usbcore: registered new device driver usb
    [    0.426325] pps_core: LinuxPPS API ver. 1 registered
    [    0.431398] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.440736] PTP clock support registered
    [    0.444759] EDAC MC: Ver: 3.0.0
    [    0.448131] scmi_core: SCMI protocol bus registered
    [    0.453275] FPGA manager framework
    [    0.456786] Advanced Linux Sound Architecture Driver Initialized.
    [    0.463449] vgaarb: loaded
    [    0.466395] clocksource: Switched to clocksource arch_sys_counter
    [    0.472772] VFS: Disk quotas dquot_6.6.0
    [    0.476793] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.487653] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
    [    0.493950] NET: Registered PF_INET protocol family
    [    0.499042] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.507442] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.516202] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.524128] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.532277] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.540237] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.546978] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.553863] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.561248] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.567325] RPC: Registered named UNIX socket transport module.
    [    0.573386] RPC: Registered udp transport module.
    [    0.578192] RPC: Registered tcp transport module.
    [    0.583002] RPC: Registered tcp-with-tls transport module.
    [    0.588606] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.595190] NET: Registered PF_XDP protocol family
    [    0.600093] PCI: CLS 0 bytes, default 64
    [    0.604771] Initialise system trusted keyrings
    [    0.609443] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.616200] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.622301] NFS: Registering the id_resolver key type
    [    0.627485] Key type id_resolver registered
    [    0.631760] Key type id_legacy registered
    [    0.635863] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.642716] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.672085] Key type asymmetric registered
    [    0.676274] Asymmetric key parser 'x509' registered
    [    0.681290] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.688952] io scheduler mq-deadline registered
    [    0.693588] io scheduler kyber registered
    [    0.697701] io scheduler bfq registered
    [    0.703931] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.710346] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.716606] pinctrl-single 104200.pinctrl: 20 pins, size 80
    [    0.722370] pinctrl-single 104280.pinctrl: 8 pins, size 32
    [    0.728546] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.738167] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.746210] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00101faf)
    [    0.754904] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.762043] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.769221] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.780709] loop: module loaded
    [    0.784572] megasas: 07.727.03.00-rc1
    [    0.790252] tun: Universal TUN/TAP device driver, 1.6
    [    0.796035] VFIO - User Level meta-driver version: 0.3
    [    0.801999] usbcore: registered new interface driver usb-storage
    [    0.808511] i2c_dev: i2c /dev entries driver
    [    0.813570] sdhci: Secure Digital Host Controller Interface driver
    [    0.819901] sdhci: Copyright(c) Pierre Ossman
    [    0.824478] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.830668] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.837658] usbcore: registered new interface driver usbhid
    [    0.843365] usbhid: USB HID core driver
    [    0.847916] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 (0,8000003f) counters available
    [    0.857754] optee: probing for conduit method.
    [    0.862317] optee: revision 4.5 (ef1ebdc23034a804)
    [    0.878791] optee: dynamic shared memory is enabled
    [    0.889078] optee: initialized driver
    [    0.889159] random: crng init done
    [    0.894426] Initializing XFRM netlink socket
    [    0.900681] NET: Registered PF_PACKET protocol family
    [    0.905886] Key type dns_resolver registered
    [    0.914120] registered taskstats version 1
    [    0.918534] Loading compiled-in X.509 certificates
    [    0.930382] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)')
    [    1.053115] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.059723] pca953x 1-0020: supply vcc not found, using dummy regulator
    [    1.066585] pca953x 1-0020: using no AI
    [    1.091132] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.097951] pca953x 1-0022: using AI
    [    1.102787] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.109006] pca953x 2-0020: supply vcc not found, using dummy regulator
    [    1.115834] pca953x 2-0020: using no AI
    [    1.134762] omap_i2c 2030000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.140660] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
    [    1.149230] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
    [    1.158588] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
    [    1.167235] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.182032] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    1.191929] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.198700] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.208511] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    1.218699] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.225460] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.233675] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 204, base_baud = 6000000) is a 8250
    [    1.243455] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 205, base_baud = 3000000) is a 8250
    [    1.252317] printk: legacy console [ttyS2] enabled
    [    1.262088] printk: legacy bootconsole [ns16550a0] disabled
    [    1.276681] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.318402] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.327852] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.336127] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.349005] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.356215] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64, Policers 8
    [    1.363672] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1
    [    1.374357] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    1.383613] mmc0: CQHCI version 5.10
    [    1.395902] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.407435] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    1.422184] 8 fixed-partitions partitions found on MTD device 47040000.spi.0
    [    1.426404] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.429241] Creating 8 MTD partitions on "47040000.spi.0":
    [    1.442227] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.448404] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.454334] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.460388] 0x000000680000-0x0000006a0000 : "ospi.env"
    [    1.466133] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
    [    1.472501] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    1.478444] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.484431] 0x000003fe0000-0x000004000000 : "ospi.phypattern"
    [    1.490767] cadence-qspi 47040000.spi: Pattern not found. Skipping calibration.
    [    1.501377] 8 fixed-partitions partitions found on MTD device 47050000.spi.0
    [    1.508430] Creating 8 MTD partitions on "47050000.spi.0":
    [    1.513913] 0x000000000000-0x000000080000 : "qspi.tiboot3"
    [    1.519991] 0x000000080000-0x000000280000 : "qspi.tispl"
    [    1.525871] 0x000000280000-0x000000680000 : "qspi.u-boot"
    [    1.531771] 0x000000680000-0x0000006a0000 : "qspi.env"
    [    1.537437] 0x0000006a0000-0x0000006c0000 : "qspi.env.backup"
    [    1.543702] 0x0000006c0000-0x0000007c0000 : "qspi.sysfw"
    [    1.549543] 0x000000800000-0x000003fc0000 : "qspi.rootfs"
    [    1.555479] 0x000003fe0000-0x000004000000 : "qspi.phypattern"
    [    1.562340] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.582284] mmc0: Command Queue Engine enabled
    [    1.586744] mmc0: new HS200 MMC card at address 0001
    [    1.592111] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    1.597528]  mmcblk0: p1 p2
    [    1.600628] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    1.602414] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.606187] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    1.615214] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.618648] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
    [    1.626301] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.645423] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.652642] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64, Policers 8
    [    1.660099] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1
    [    1.679826] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    1.692270] mmc1: CQHCI version 5.10
    [    1.695021] clk: Disabling unused clocks
    [    1.722039] PM: genpd: Disabling unused power domains
    [    1.727178] ALSA device list:
    [    1.730135]   No soundcards found.
    [    1.738939] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    1.746541] Waiting for root device PARTUUID=0726f891-02...
    [    1.811405] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    1.818298] mmcblk1: mmc1:aaaa SK32G 29.7 GiB
    [    1.824123]  mmcblk1: p1 p2
    [    1.842594] EXT4-fs (mmcblk1p2): mounted filesystem 242c12bc-c882-4ae8-9df8-127d6fc853f9 r/w with ordered data mode. Quota mode: none.
    [    1.854708] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    1.861763] devtmpfs: mounted
    [    1.866039] Freeing unused kernel memory: 2752K
    [    1.870671] Run /sbin/init as init process
    [    2.185676] systemd[1]: System time before build time, advancing clock.
    [    2.268196] NET: Registered PF_INET6 protocol family
    [    2.273788] Segment Routing with IPv6
    [    2.277473] In-situ OAM (IOAM) with IPv6
    [    2.322518] systemd[1]: systemd 255.18^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.354374] systemd[1]: Detected architecture arm64.
    [    2.374181] systemd[1]: Hostname set to <j721e-evm>.
    [    2.613668] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    2.735354] systemd[1]: Queued start job for default target Graphical Interface.
    [    2.781470] systemd[1]: Created slice Slice /system/getty.
     UART UT 1 FAILED
    Yes, I have tested with removing the instances of UART 1 from U-Boot and kernel device trees, but then too my kernel gets crashed.
    2.by changing the variable value uint32_t uartTestInstance=1; will be changed in /home/balaji/Documents/TDA4VM/ti-processor-sdk-rtos-j721e-evm-11_00_00_06/pdk_jacinto_11_00_00_21/packages/ti/drv/uart/test/src/main_uart_test.c
    I am trying to reproduce the issue on the EVM. Are you simply running the UART TestApp example on MCU2_1 with SDK 11.0? Booting with SD Card?
    Is there any other specific configuration I would need to reproduce this?
    Neehar
  • hi,
    Yes you are right its just the UART_Test_Freertos application built with any of the R5F in SDK 11.0, with SDcard boot.
    I have looked into it deeper and it seems the device tree is setting up the following UART ports:
    	aliases {
    		serial0 = &wkup_uart0;
    		serial1 = &mcu_uart0;
    		serial2 = &main_uart0;
    		serial3 = &main_uart1;
    		serial4 = &main_uart2;
    		serial6 = &main_uart4;
    What UART instance are you using for the UART TestApp? You will need to prevent resource conflict by either using a separate instance for the TestApp example or disabling the UART instance in Linux. However, you cannot disable just any instance as it may be required for boot.
    Neehar
