linear assembly - copy routine not working for C6713
I'm hoping someone can tell me what's wrong with the small linear assembly function I wrote for a C6713 below, to copy integers from one buffer to another (with variable increment size).  When used for 1024 samples, only about 380 get copied correctly.  If using the C memcpy() call, all 1024 are copied correctly.
Robert
    .global _cp_i2i
_cp_i2i: .cproc dst, src, d_inc, s_inc, size
     .reg aa
     .no_mdep
lp_0: .trip size
     ldh *src++[s_inc], aa
     sth aa, *dst++[d_inc]
[size] sub size, 1, size
[size] b lp_0
     .return
     .endproc
  • Robert,
    Why are you writing in assembly instead of C? The C compiler is pretty good.
    Which versions of tools are you using? CCSv?, CodeGen ?, emulator (board?) or simulator (which?)
    How do you go about debugging something like this? Since this must be an exercise to learn to write in assembly, you will not gain anything by someone telling you what's wrong, even if we could do that.
    Have you tried passing smaller arguments, like size=8 and the inc values being reasonably small like 2, 3, 4, etc? Does it work right in those cases?
    When you are debugging, you have to find out exact numbers, not "about 380". Run it for 379 and look at memory, then run it for 380 and look at memory, then 381, or wherever you need to be to know the boundary between working and failing.
    What you learn from those starting tests will lead you to the next set of tests, and somewhere along the way you may notice odd behavior in memory or in the registers as you single-step through the assembly code.
    You can look into more advanced breakpoints than just "stop here". You can associate counters with breakpoints and make different things happen when you reach a breakpoint other than just Halt.
    Please post back with what you try, what results you get, and what new insights you have that can lead to some additional steps.
    Your function name implies copying integers (i2i) and your text says you are copying integers, but your function is copying shorts. The C function memcpy copies bytes.
    RandyP
  • Randy,
    CCSV5.1, 7.3 compiler tools, 5.41.11.38 BIOS, 6713DSK.
    I debug by stepping over the function and dumping the source and destination, and comparing the two offline.  It’s consistently good until 372 (out of 1024 requested).
    I am passing in shorts (Int16), so ldh, sth is correct.
    This code was ported from CCSV3.3, where it (and other) linear assembly was working fine.
    Robert
  • Robert,
    With the added history of your code, my statement above about "an exercise" sounds patronizing and rude. Sorry.
    Can you please post the assembly output for just this function from the CCS 3.3 version and the assembly output for this new version? The -k compiler switch will tell the compiler to keep a copy of the .asm file in your output folder, usually .\Debug or .\Release.
    RandyP
  • Randy,
    I'm not able to compile under CCS 3.3 anymore, but attached is the latest, 5.1 version.
    Robert
    ;* TMS320C6x C/C++ Codegen PC v7.3.0 *
    ;* Date/Time created: Sat Jan 14 21:01:48 2012 *
    .compiler_opts --abi=coffabi --c64p_l1d_workaround=default --endian=little --hll_source=linasm --long_precision_bits=40 --mem_model:code=near --mem_model:const=data --mem_model:data=far_aggregates --object_format=coff --silicon_version=6700 --symdebug:dwarf
    ;* GLOBAL FILE PARAMETERS *
    ;* Architecture : TMS320C670x *
    ;* Optimization : Disabled *
    ;* Optimizing for : Compile time, Ease of Development *
    ;* Based on options: no -o, no -ms *
    ;* Endian : Little *
    ;* Interrupt Thrshld : Disabled *
    ;* Data Access Model : Far Aggregate Data *
    ;* Pipelining : Disabled *
    ;* Memory Aliases : Presume are aliases (pessimistic) *
    ;* Debug Info : DWARF Debug *
    .asg A15, FP
    .asg B14, DP
    .asg B15, SP
    .global $bss
    $C$DW$CU .dwtag DW_TAG_compile_unit
    .dwattr $C$DW$CU, DW_AT_name("../util/cp_i2i.sa")
    .dwattr $C$DW$CU, DW_AT_producer("TMS320C6x C/C++ Codegen PC v7.3.0 Copyright (c) 1996-2011 Texas Instruments Incorporated")
    .dwattr $C$DW$CU, DW_AT_TI_version(0x01)
    .dwattr $C$DW$CU, DW_AT_comp_dir("C:\work\dsp\Debug")
    .sect ".text"
    .sect "int_prog"
    .global _cp_i2i
    .sect "int_prog"
    .clink
    $C$DW$1 .dwtag DW_TAG_subprogram, DW_AT_name("cp_i2i")
    .dwattr $C$DW$1, DW_AT_low_pc(_cp_i2i)
    .dwattr $C$DW$1, DW_AT_high_pc(0x00)
    .dwattr $C$DW$1, DW_AT_TI_symbol_name("_cp_i2i")
    .dwattr $C$DW$1, DW_AT_TI_begin_file("../util/cp_i2i.sa")
    .dwattr $C$DW$1, DW_AT_TI_begin_line(0x05)
    .dwattr $C$DW$1, DW_AT_TI_begin_column(0x01)
    .dwattr $C$DW$1, DW_AT_TI_max_frame_size(0x00)
    .dwpsn file "../util/cp_i2i.sa",line 5,column 1,is_stmt,address _cp_i2i
    .dwfde $C$DW$CIE, _cp_i2i
    ;* FUNCTION NAME: cp_i2i *
    ;* Regs Modified : A3,A4,A5,A7,B0 *
    ;* Regs Used : A3,A4,A5,A6,A7,A8,B0,B3,B4,B6 *
    _cp_i2i:
    .map src/A3
    .map src'/B4
    .map aa/A5
    .map s_inc/A7
    .map s_inc'/B6
    .map dst/A4
    .map size/B0
    .map size'/A8
    .map d_inc/A6
    ; _cp_i2i: .cproc dst, src, d_inc, s_inc, size
    ; .reg aa
    ; .no_mdep
    .dwcfi cfa_offset, 0
    .dwcfi save_reg_to_reg, 228, 19
    $C$DW$2 .dwtag DW_TAG_variable, DW_AT_name("src")
    .dwattr $C$DW$2, DW_AT_TI_symbol_name("src")
    .dwattr $C$DW$2, DW_AT_type(*$C$DW$T$10)
    .dwattr $C$DW$2, DW_AT_location[DW_OP_reg3]
    $C$DW$3 .dwtag DW_TAG_variable, DW_AT_name("src")
    .dwattr $C$DW$3, DW_AT_TI_symbol_name("src")
    .dwattr $C$DW$3, DW_AT_type(*$C$DW$T$10)
    .dwattr $C$DW$3, DW_AT_location[DW_OP_reg20]
    $C$DW$4 .dwtag DW_TAG_variable, DW_AT_name("aa")
    .dwattr $C$DW$4, DW_AT_TI_symbol_name("aa")
    .dwattr $C$DW$4, DW_AT_type(*$C$DW$T$10)
    .dwattr $C$DW$4, DW_AT_location[DW_OP_reg5]
    $C$DW$5 .dwtag DW_TAG_variable, DW_AT_name("s_inc")
    .dwattr $C$DW$5, DW_AT_TI_symbol_name("s_inc")
    .dwattr $C$DW$5, DW_AT_type(*$C$DW$T$10)
    .dwattr $C$DW$5, DW_AT_location[DW_OP_reg7]
    $C$DW$6 .dwtag DW_TAG_variable, DW_AT_name("s_inc")
    .dwattr $C$DW$6, DW_AT_TI_symbol_name("s_inc")
    .dwattr $C$DW$6, DW_AT_type(*$C$DW$T$10)
    .dwattr $C$DW$6, DW_AT_location[DW_OP_reg22]
    $C$DW$7 .dwtag DW_TAG_variable, DW_AT_name("dst")
    .dwattr $C$DW$7, DW_AT_TI_symbol_name("dst")
    .dwattr $C$DW$7, DW_AT_type(*$C$DW$T$10)
    .dwattr $C$DW$7, DW_AT_location[DW_OP_reg4]
    $C$DW$8 .dwtag DW_TAG_variable, DW_AT_name("size")
    .dwattr $C$DW$8, DW_AT_TI_symbol_name("size")
    .dwattr $C$DW$8, DW_AT_type(*$C$DW$T$10)
    .dwattr $C$DW$8, DW_AT_location[DW_OP_reg16]
    $C$DW$9 .dwtag DW_TAG_variable, DW_AT_name("size")
    .dwattr $C$DW$9, DW_AT_TI_symbol_name("size")
    .dwattr $C$DW$9, DW_AT_type(*$C$DW$T$10)
    .dwattr $C$DW$9, DW_AT_location[DW_OP_reg8]
    $C$DW$10 .dwtag DW_TAG_variable, DW_AT_name("d_inc")
    .dwattr $C$DW$10, DW_AT_TI_symbol_name("d_inc")
    .dwattr $C$DW$10, DW_AT_type(*$C$DW$T$10)
    .dwattr $C$DW$10, DW_AT_location[DW_OP_reg6]
    MV .L1X s_inc',s_inc ; |5|
    MV .L1X src',src ; |5|
    || MV .L2X size',size ; |5|
    .dwpsn file "../util/cp_i2i.sa",line 4,column 1,is_stmt
    .dwpsn file "../util/cp_i2i.sa",line 11,column 1,is_stmt
    ;* SOFTWARE PIPELINE INFORMATION
    ;* Disqualified loop: Software pipelining disabled
    $C$L1:
    $C$DW$L$_cp_i2i$2$B:
    ; lp_0: .trip size
    .dwpsn file "../util/cp_i2i.sa",line 13,column 1,is_stmt
    LDH .D1T1 *src++[s_inc],aa ; |13|
    NOP 4
    .dwpsn file "../util/cp_i2i.sa",line 14,column 1,is_stmt
    STH .D1T1 aa,*dst++[d_inc] ; |14|
    .dwpsn file "../util/cp_i2i.sa",line 16,column 1,is_stmt
    [ size] ADD .L2 0xffffffff,size,size ; |16|
    .dwpsn file "../util/cp_i2i.sa",line 17,column 1,is_stmt
    [ size] B .S1 $C$L1 ; |17|
    NOP 5
    ; BRANCHCC OCCURS {$C$L1} ; |17|
    $C$DW$L$_cp_i2i$2$E:
    ; .return
    .dwpsn file "../util/cp_i2i.sa",line 19,column 1,is_stmt
    .dwpsn file "../util/cp_i2i.sa",line 20,column 1,is_stmt
    $C$DW$11 .dwtag DW_TAG_TI_branch
    .dwattr $C$DW$11, DW_AT_low_pc(0x00)
    .dwattr $C$DW$11, DW_AT_TI_return
    RET .S2 B3 ; |20|
    NOP 5
    ; BRANCH OCCURS {B3} ; |20|
    $C$DW$12 .dwtag DW_TAG_TI_loop
    .dwattr $C$DW$12, DW_AT_name("C:\work\dsp\Debug\cp_i2i.asm:$C$L1:1:1326596508")
    .dwattr $C$DW$12, DW_AT_TI_begin_file("../util/cp_i2i.sa")
    .dwattr $C$DW$12, DW_AT_TI_begin_line(0x0b)
    .dwattr $C$DW$12, DW_AT_TI_end_line(0x11)
    $C$DW$13 .dwtag DW_TAG_TI_loop_range
    .dwattr $C$DW$13, DW_AT_low_pc($C$DW$L$_cp_i2i$2$B)
    .dwattr $C$DW$13, DW_AT_high_pc($C$DW$L$_cp_i2i$2$E)
    .dwendtag $C$DW$12
    .dwattr $C$DW$1, DW_AT_TI_end_file("../util/cp_i2i.sa")
    .dwattr $C$DW$1, DW_AT_TI_end_line(0x14)
    .dwattr $C$DW$1, DW_AT_TI_end_column(0x01)
    .dwendentry
    .dwendtag $C$DW$1
    .clearmap
    ; .endproc
    ;* BUILD ATTRIBUTES *
    .battr "TI", Tag_File, 1, Tag_ABI_stack_align_needed(0)
    .battr "TI", Tag_File, 1, Tag_ABI_stack_align_preserved(0)
    .battr "TI", Tag_File, 1, Tag_Tramps_Use_SOC(0)
    ;* TYPE INFORMATION *
    $C$DW$T$4 .dwtag DW_TAG_base_type
    .dwattr $C$DW$T$4, DW_AT_encoding(DW_ATE_boolean)
    .dwattr $C$DW$T$4, DW_AT_name("bool")
    .dwattr $C$DW$T$4, DW_AT_byte_size(0x01)
    $C$DW$T$5 .dwtag DW_TAG_base_type
    .dwattr $C$DW$T$5, DW_AT_encoding(DW_ATE_signed_char)
    .dwattr $C$DW$T$5, DW_AT_name("signed char")
    .dwattr $C$DW$T$5, DW_AT_byte_size(0x01)
    $C$DW$T$6 .dwtag DW_TAG_base_type
    .dwattr $C$DW$T$6, DW_AT_encoding(DW_ATE_unsigned_char)
    .dwattr $C$DW$T$6, DW_AT_name("unsigned char")
    .dwattr $C$DW$T$6, DW_AT_byte_size(0x01)
    $C$DW$T$7 .dwtag DW_TAG_base_type
    .dwattr $C$DW$T$7, DW_AT_encoding(DW_ATE_signed_char)
    .dwattr $C$DW$T$7, DW_AT_name("wchar_t")
    .dwattr $C$DW$T$7, DW_AT_byte_size(0x02)
    $C$DW$T$8 .dwtag DW_TAG_base_type
    .dwattr $C$DW$T$8, DW_AT_encoding(DW_ATE_signed)
    .dwattr $C$DW$T$8, DW_AT_name("short")
    .dwattr $C$DW$T$8, DW_AT_byte_size(0x02)
    $C$DW$T$9 .dwtag DW_TAG_base_type
    .dwattr $C$DW$T$9, DW_AT_encoding(DW_ATE_unsigned)
    .dwattr $C$DW$T$9, DW_AT_name("unsigned short")
    .dwattr $C$DW$T$9, DW_AT_byte_size(0x02)
    $C$DW$T$10 .dwtag DW_TAG_base_type
    .dwattr $C$DW$T$10, DW_AT_encoding(DW_ATE_signed)
    .dwattr $C$DW$T$10, DW_AT_name("int")
    .dwattr $C$DW$T$10, DW_AT_byte_size(0x04)
    $C$DW$T$11 .dwtag DW_TAG_base_type
    .dwattr $C$DW$T$11, DW_AT_encoding(DW_ATE_unsigned)
    .dwattr $C$DW$T$11, DW_AT_name("unsigned int")
    .dwattr $C$DW$T$11, DW_AT_byte_size(0x04)
    $C$DW$T$12 .dwtag DW_TAG_base_type
    .dwattr $C$DW$T$12, DW_AT_encoding(DW_ATE_signed)
    .dwattr $C$DW$T$12, DW_AT_name("long")
    .dwattr $C$DW$T$12, DW_AT_byte_size(0x08)
    .dwattr $C$DW$T$12, DW_AT_bit_size(0x28)
    .dwattr $C$DW$T$12, DW_AT_bit_offset(0x18)
    $C$DW$T$13 .dwtag DW_TAG_base_type
    .dwattr $C$DW$T$13, DW_AT_encoding(DW_ATE_unsigned)
    .dwattr $C$DW$T$13, DW_AT_name("unsigned long")
    .dwattr $C$DW$T$13, DW_AT_byte_size(0x08)
    .dwattr $C$DW$T$13, DW_AT_bit_size(0x28)
    .dwattr $C$DW$T$13, DW_AT_bit_offset(0x18)
    $C$DW$T$14 .dwtag DW_TAG_base_type
    .dwattr $C$DW$T$14, DW_AT_encoding(DW_ATE_signed)
    .dwattr $C$DW$T$14, DW_AT_name("long long")
    .dwattr $C$DW$T$14, DW_AT_byte_size(0x08)
    $C$DW$T$15 .dwtag DW_TAG_base_type
    .dwattr $C$DW$T$15, DW_AT_encoding(DW_ATE_unsigned)
    .dwattr $C$DW$T$15, DW_AT_name("unsigned long long")
    .dwattr $C$DW$T$15, DW_AT_byte_size(0x08)
    $C$DW$T$16 .dwtag DW_TAG_base_type
    .dwattr $C$DW$T$16, DW_AT_encoding(DW_ATE_float)
    .dwattr $C$DW$T$16, DW_AT_name("float")
    .dwattr $C$DW$T$16, DW_AT_byte_size(0x04)
    $C$DW$T$17 .dwtag DW_TAG_base_type
    .dwattr $C$DW$T$17, DW_AT_encoding(DW_ATE_float)
    .dwattr $C$DW$T$17, DW_AT_name("double")
    .dwattr $C$DW$T$17, DW_AT_byte_size(0x08)
    $C$DW$T$18 .dwtag DW_TAG_base_type
    .dwattr $C$DW$T$18, DW_AT_encoding(DW_ATE_float)
    .dwattr $C$DW$T$18, DW_AT_name("long double")
    .dwattr $C$DW$T$18, DW_AT_byte_size(0x08)
    .dwattr $C$DW$CU, DW_AT_language(DW_LANG_C)
    ;* DWARF CIE ENTRIES *
    $C$DW$CIE .dwcie 228
    .dwcfi cfa_register, 31
    .dwcfi undefined, 0
    .dwcfi undefined, 1
    .dwcfi undefined, 2
    .dwcfi undefined, 3
    .dwcfi undefined, 4
    .dwcfi undefined, 5
    .dwcfi undefined, 6
    .dwcfi undefined, 7
    .dwcfi undefined, 8
    .dwcfi undefined, 9
    .dwcfi same_value, 10
    .dwcfi same_value, 11
    .dwcfi same_value, 12
    .dwcfi same_value, 13
    .dwcfi same_value, 14
    .dwcfi same_value, 15
    .dwcfi undefined, 16
    .dwcfi undefined, 17
    .dwcfi undefined, 18
    .dwcfi undefined, 19
    .dwcfi undefined, 20
    .dwcfi undefined, 21
    .dwcfi undefined, 22
    .dwcfi undefined, 23
    .dwcfi undefined, 24
    .dwcfi undefined, 25
    .dwcfi same_value, 26
    .dwcfi same_value, 27
    .dwcfi same_value, 28
    .dwcfi same_value, 29
    .dwcfi same_value, 30
    .dwcfi same_value, 31
    .dwcfi same_value, 32
    .dwcfi undefined, 33
    .dwcfi undefined, 34
    .dwcfi undefined, 35
    .dwcfi undefined, 36
    .dwcfi undefined, 37
    .dwcfi undefined, 38
    .dwcfi undefined, 39
    .dwcfi undefined, 40
    .dwcfi undefined, 41
    .dwcfi undefined, 42
    .dwcfi undefined, 43
    .dwcfi undefined, 44
    .dwcfi undefined, 45
    .dwcfi undefined, 46
    .dwcfi undefined, 47
    .dwcfi undefined, 48
    .dwcfi undefined, 49
    .dwcfi undefined, 50
    .dwcfi undefined, 51
    .dwcfi undefined, 52
    .dwcfi undefined, 53
    .dwcfi undefined, 54
    .dwcfi undefined, 55
    .dwcfi undefined, 56
    .dwcfi undefined, 57
    .dwcfi undefined, 58
    .dwcfi undefined, 59
    .dwcfi undefined, 60
    .dwcfi undefined, 61
    .dwcfi undefined, 62
    .dwcfi undefined, 63
    .dwcfi undefined, 64
    .dwcfi undefined, 65
    .dwcfi undefined, 66
    .dwcfi undefined, 67
    .dwcfi undefined, 68
    .dwcfi undefined, 69
    .dwcfi undefined, 70
    .dwcfi undefined, 71
    .dwcfi undefined, 72
    .dwcfi undefined, 73
    .dwcfi undefined, 74
    .dwcfi undefined, 75
    .dwcfi undefined, 76
    .dwcfi undefined, 77
    .dwcfi undefined, 78
    .dwcfi undefined, 79
    .dwcfi undefined, 80
    .dwcfi undefined, 81
    .dwcfi undefined, 82
    .dwcfi undefined, 83
    .dwcfi undefined, 84
    .dwcfi undefined, 85
    .dwcfi undefined, 86
    .dwcfi undefined, 87
    .dwcfi undefined, 88
    .dwcfi undefined, 89
    .dwcfi undefined, 90
    .dwcfi undefined, 91
    .dwcfi undefined, 92
    .dwcfi undefined, 93
    .dwcfi undefined, 94
    .dwcfi undefined, 95
    .dwcfi undefined, 96
    .dwcfi undefined, 97
    .dwcfi undefined, 98
    .dwcfi undefined, 99
    .dwcfi undefined, 100
    .dwcfi undefined, 101
    .dwcfi undefined, 102
    .dwcfi undefined, 103
    .dwcfi undefined, 104
    .dwcfi undefined, 105
    .dwcfi undefined, 106
    .dwcfi undefined, 107
    .dwcfi undefined, 108
    .dwcfi undefined, 109
    .dwcfi undefined, 110
    .dwcfi undefined, 111
    .dwcfi undefined, 112
    .dwcfi undefined, 113
    .dwcfi undefined, 114
    .dwcfi undefined, 115
    .dwcfi undefined, 116
    .dwcfi undefined, 117
    .dwcfi undefined, 118
    .dwcfi undefined, 119
    .dwcfi undefined, 120
    .dwcfi undefined, 121
    .dwcfi undefined, 122
    .dwcfi undefined, 123
    .dwcfi undefined, 124
    .dwcfi undefined, 125
    .dwcfi undefined, 126
    .dwcfi undefined, 127
    .dwcfi undefined, 128
    .dwcfi undefined, 129
    .dwcfi undefined, 130
    .dwcfi undefined, 131
    .dwcfi undefined, 132
    .dwcfi undefined, 133
    .dwcfi undefined, 134
    .dwcfi undefined, 135
    .dwcfi undefined, 136
    .dwcfi undefined, 137
    .dwcfi undefined, 138
    .dwcfi undefined, 139
    .dwcfi undefined, 140
    .dwcfi undefined, 141
    .dwcfi undefined, 142
    .dwcfi undefined, 143
    .dwcfi undefined, 144
    .dwcfi undefined, 145
    .dwcfi undefined, 146
    .dwcfi undefined, 147
    .dwcfi undefined, 148
    .dwcfi undefined, 149
    .dwcfi undefined, 150
    .dwcfi undefined, 151
    .dwcfi undefined, 152
    .dwcfi undefined, 153
    .dwcfi undefined, 154
    .dwcfi undefined, 155
    .dwcfi undefined, 156
    .dwcfi undefined, 157
    .dwcfi undefined, 158
    .dwcfi undefined, 159
    .dwcfi undefined, 160
    .dwcfi undefined, 161
    .dwcfi undefined, 162
    .dwcfi undefined, 163
    .dwcfi undefined, 164
    .dwcfi undefined, 165
    .dwcfi undefined, 166
    .dwcfi undefined, 167
    .dwcfi undefined, 168
    .dwcfi undefined, 169
    .dwcfi undefined, 170
    .dwcfi undefined, 171
    .dwcfi undefined, 172
    .dwcfi undefined, 173
    .dwcfi undefined, 174
    .dwcfi undefined, 175
    .dwcfi undefined, 176
    .dwcfi undefined, 177
    .dwcfi undefined, 178
    .dwcfi undefined, 179
    .dwcfi undefined, 180
    .dwcfi undefined, 181
    .dwcfi undefined, 182
    .dwcfi undefined, 183
    .dwcfi undefined, 184
    .dwcfi undefined, 185
    .dwcfi undefined, 186
    .dwcfi undefined, 187
    .dwcfi undefined, 188
    .dwcfi undefined, 189
    .dwcfi undefined, 190
    .dwcfi undefined, 191
    .dwcfi undefined, 192
    .dwcfi undefined, 193
    .dwcfi undefined, 194
    .dwcfi undefined, 195
    .dwcfi undefined, 196
    .dwcfi undefined, 197
    .dwcfi undefined, 198
    .dwcfi undefined, 199
    .dwcfi undefined, 200
    .dwcfi undefined, 201
    .dwcfi undefined, 202
    .dwcfi undefined, 203
    .dwcfi undefined, 204
    .dwcfi undefined, 205
    .dwcfi undefined, 206
    .dwcfi undefined, 207
    .dwcfi undefined, 208
    .dwcfi undefined, 209
    .dwcfi undefined, 210
    .dwcfi undefined, 211
    .dwcfi undefined, 212
    .dwcfi undefined, 213
    .dwcfi undefined, 214
    .dwcfi undefined, 215
    .dwcfi undefined, 216
    .dwcfi undefined, 217
    .dwcfi undefined, 218
    .dwcfi undefined, 219
    .dwcfi undefined, 220
    .dwcfi undefined, 221
    .dwcfi undefined, 222
    .dwcfi undefined, 223
    .dwcfi undefined, 224
    .dwcfi undefined, 225
    .dwcfi undefined, 226
    .dwcfi undefined, 227
    .dwcfi undefined, 228
    .dwendentry
    ;* DWARF REGISTER MAP *
    $C$DW$14 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A0")
    .dwattr $C$DW$14, DW_AT_location[DW_OP_reg0]
    $C$DW$15 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A1")
    .dwattr $C$DW$15, DW_AT_location[DW_OP_reg1]
    $C$DW$16 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A2")
    .dwattr $C$DW$16, DW_AT_location[DW_OP_reg2]
    $C$DW$17 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A3")
    .dwattr $C$DW$17, DW_AT_location[DW_OP_reg3]
    $C$DW$18 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A4")
    .dwattr $C$DW$18, DW_AT_location[DW_OP_reg4]
    $C$DW$19 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A5")
    .dwattr $C$DW$19, DW_AT_location[DW_OP_reg5]
    $C$DW$20 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A6")
    .dwattr $C$DW$20, DW_AT_location[DW_OP_reg6]
    $C$DW$21 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A7")
    .dwattr $C$DW$21, DW_AT_location[DW_OP_reg7]
    $C$DW$22 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A8")
    .dwattr $C$DW$22, DW_AT_location[DW_OP_reg8]
    $C$DW$23 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A9")
    .dwattr $C$DW$23, DW_AT_location[DW_OP_reg9]
    $C$DW$24 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A10")
    .dwattr $C$DW$24, DW_AT_location[DW_OP_reg10]
    $C$DW$25 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A11")
    .dwattr $C$DW$25, DW_AT_location[DW_OP_reg11]
    $C$DW$26 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A12")
    .dwattr $C$DW$26, DW_AT_location[DW_OP_reg12]
    $C$DW$27 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A13")
    .dwattr $C$DW$27, DW_AT_location[DW_OP_reg13]
    $C$DW$28 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A14")
    .dwattr $C$DW$28, DW_AT_location[DW_OP_reg14]
    $C$DW$29 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A15")
    .dwattr $C$DW$29, DW_AT_location[DW_OP_reg15]
    $C$DW$30 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B0")
    .dwattr $C$DW$30, DW_AT_location[DW_OP_reg16]
    $C$DW$31 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B1")
    .dwattr $C$DW$31, DW_AT_location[DW_OP_reg17]
    $C$DW$32 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B2")
    .dwattr $C$DW$32, DW_AT_location[DW_OP_reg18]
    $C$DW$33 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B3")
    .dwattr $C$DW$33, DW_AT_location[DW_OP_reg19]
    $C$DW$34 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B4")
    .dwattr $C$DW$34, DW_AT_location[DW_OP_reg20]
    $C$DW$35 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B5")
    .dwattr $C$DW$35, DW_AT_location[DW_OP_reg21]
    $C$DW$36 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B6")
    .dwattr $C$DW$36, DW_AT_location[DW_OP_reg22]
    $C$DW$37 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B7")
    .dwattr $C$DW$37, DW_AT_location[DW_OP_reg23]
    $C$DW$38 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B8")
    .dwattr $C$DW$38, DW_AT_location[DW_OP_reg24]
    $C$DW$39 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B9")
    .dwattr $C$DW$39, DW_AT_location[DW_OP_reg25]
    $C$DW$40 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B10")
    .dwattr $C$DW$40, DW_AT_location[DW_OP_reg26]
    $C$DW$41 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B11")
    .dwattr $C$DW$41, DW_AT_location[DW_OP_reg27]
    $C$DW$42 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B12")
    .dwattr $C$DW$42, DW_AT_location[DW_OP_reg28]
    $C$DW$43 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B13")
    .dwattr $C$DW$43, DW_AT_location[DW_OP_reg29]
    $C$DW$44 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DP")
    .dwattr $C$DW$44, DW_AT_location[DW_OP_reg30]
    $C$DW$45 .dwtag DW_TAG_TI_assign_register, DW_AT_name("SP")
    .dwattr $C$DW$45, DW_AT_location[DW_OP_reg31]
    $C$DW$46 .dwtag DW_TAG_TI_assign_register, DW_AT_name("FP")
    .dwattr $C$DW$46, DW_AT_location[DW_OP_regx 0x20]
    $C$DW$47 .dwtag DW_TAG_TI_assign_register, DW_AT_name("PC")
    .dwattr $C$DW$47, DW_AT_location[DW_OP_regx 0x21]
    $C$DW$48 .dwtag DW_TAG_TI_assign_register, DW_AT_name("IRP")
    .dwattr $C$DW$48, DW_AT_location[DW_OP_regx 0x22]
    $C$DW$49 .dwtag DW_TAG_TI_assign_register, DW_AT_name("IFR")
    .dwattr $C$DW$49, DW_AT_location[DW_OP_regx 0x23]
    $C$DW$50 .dwtag DW_TAG_TI_assign_register, DW_AT_name("NRP")
    .dwattr $C$DW$50, DW_AT_location[DW_OP_regx 0x24]
    $C$DW$51 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A16")
    .dwattr $C$DW$51, DW_AT_location[DW_OP_regx 0x25]
    $C$DW$52 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A17")
    .dwattr $C$DW$52, DW_AT_location[DW_OP_regx 0x26]
    $C$DW$53 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A18")
    .dwattr $C$DW$53, DW_AT_location[DW_OP_regx 0x27]
    $C$DW$54 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A19")
    .dwattr $C$DW$54, DW_AT_location[DW_OP_regx 0x28]
    $C$DW$55 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A20")
    .dwattr $C$DW$55, DW_AT_location[DW_OP_regx 0x29]
    $C$DW$56 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A21")
    .dwattr $C$DW$56, DW_AT_location[DW_OP_regx 0x2a]
    $C$DW$57 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A22")
    .dwattr $C$DW$57, DW_AT_location[DW_OP_regx 0x2b]
    $C$DW$58 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A23")
    .dwattr $C$DW$58, DW_AT_location[DW_OP_regx 0x2c]
    $C$DW$59 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A24")
    .dwattr $C$DW$59, DW_AT_location[DW_OP_regx 0x2d]
    $C$DW$60 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A25")
    .dwattr $C$DW$60, DW_AT_location[DW_OP_regx 0x2e]
    $C$DW$61 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A26")
    .dwattr $C$DW$61, DW_AT_location[DW_OP_regx 0x2f]
    $C$DW$62 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A27")
    .dwattr $C$DW$62, DW_AT_location[DW_OP_regx 0x30]
    $C$DW$63 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A28")
    .dwattr $C$DW$63, DW_AT_location[DW_OP_regx 0x31]
    $C$DW$64 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A29")
    .dwattr $C$DW$64, DW_AT_location[DW_OP_regx 0x32]
    $C$DW$65 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A30")
    .dwattr $C$DW$65, DW_AT_location[DW_OP_regx 0x33]
    $C$DW$66 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A31")
    .dwattr $C$DW$66, DW_AT_location[DW_OP_regx 0x34]
    $C$DW$67 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B16")
    .dwattr $C$DW$67, DW_AT_location[DW_OP_regx 0x35]
    $C$DW$68 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B17")
    .dwattr $C$DW$68, DW_AT_location[DW_OP_regx 0x36]
    $C$DW$69 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B18")
    .dwattr $C$DW$69, DW_AT_location[DW_OP_regx 0x37]
    $C$DW$70 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B19")
    .dwattr $C$DW$70, DW_AT_location[DW_OP_regx 0x38]
    $C$DW$71 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B20")
    .dwattr $C$DW$71, DW_AT_location[DW_OP_regx 0x39]
    $C$DW$72 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B21")
    .dwattr $C$DW$72, DW_AT_location[DW_OP_regx 0x3a]
    $C$DW$73 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B22")
    .dwattr $C$DW$73, DW_AT_location[DW_OP_regx 0x3b]
    $C$DW$74 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B23")
    .dwattr $C$DW$74, DW_AT_location[DW_OP_regx 0x3c]
    $C$DW$75 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B24")
    .dwattr $C$DW$75, DW_AT_location[DW_OP_regx 0x3d]
    $C$DW$76 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B25")
    .dwattr $C$DW$76, DW_AT_location[DW_OP_regx 0x3e]
    $C$DW$77 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B26")
    .dwattr $C$DW$77, DW_AT_location[DW_OP_regx 0x3f]
    $C$DW$78 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B27")
    .dwattr $C$DW$78, DW_AT_location[DW_OP_regx 0x40]
    $C$DW$79 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B28")
    .dwattr $C$DW$79, DW_AT_location[DW_OP_regx 0x41]
    $C$DW$80 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B29")
    .dwattr $C$DW$80, DW_AT_location[DW_OP_regx 0x42]
    $C$DW$81 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B30")
    .dwattr $C$DW$81, DW_AT_location[DW_OP_regx 0x43]
    $C$DW$82 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B31")
    .dwattr $C$DW$82, DW_AT_location[DW_OP_regx 0x44]
    $C$DW$83 .dwtag DW_TAG_TI_assign_register, DW_AT_name("AMR")
    .dwattr $C$DW$83, DW_AT_location[DW_OP_regx 0x45]
    $C$DW$84 .dwtag DW_TAG_TI_assign_register, DW_AT_name("CSR")
    .dwattr $C$DW$84, DW_AT_location[DW_OP_regx 0x46]
    $C$DW$85 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ISR")
    .dwattr $C$DW$85, DW_AT_location[DW_OP_regx 0x47]
    $C$DW$86 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ICR")
    .dwattr $C$DW$86, DW_AT_location[DW_OP_regx 0x48]
    $C$DW$87 .dwtag DW_TAG_TI_assign_register, DW_AT_name("IER")
    .dwattr $C$DW$87, DW_AT_location[DW_OP_regx 0x49]
    $C$DW$88 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ISTP")
    .dwattr $C$DW$88, DW_AT_location[DW_OP_regx 0x4a]
    $C$DW$89 .dwtag DW_TAG_TI_assign_register, DW_AT_name("IN")
    .dwattr $C$DW$89, DW_AT_location[DW_OP_regx 0x4b]
    $C$DW$90 .dwtag DW_TAG_TI_assign_register, DW_AT_name("OUT")
    .dwattr $C$DW$90, DW_AT_location[DW_OP_regx 0x4c]
    $C$DW$91 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ACR")
    .dwattr $C$DW$91, DW_AT_location[DW_OP_regx 0x4d]
    $C$DW$92 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ADR")
    .dwattr $C$DW$92, DW_AT_location[DW_OP_regx 0x4e]
    $C$DW$93 .dwtag DW_TAG_TI_assign_register, DW_AT_name("FADCR")
    .dwattr $C$DW$93, DW_AT_location[DW_OP_regx 0x4f]
    $C$DW$94 .dwtag DW_TAG_TI_assign_register, DW_AT_name("FAUCR")
    .dwattr $C$DW$94, DW_AT_location[DW_OP_regx 0x50]
    $C$DW$95 .dwtag DW_TAG_TI_assign_register, DW_AT_name("FMCR")
    .dwattr $C$DW$95, DW_AT_location[DW_OP_regx 0x51]
    $C$DW$96 .dwtag DW_TAG_TI_assign_register, DW_AT_name("GFPGFR")
    .dwattr $C$DW$96, DW_AT_location[DW_OP_regx 0x52]
    $C$DW$97 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DIER")
    .dwattr $C$DW$97, DW_AT_location[DW_OP_regx 0x53]
    $C$DW$98 .dwtag DW_TAG_TI_assign_register, DW_AT_name("REP")
    .dwattr $C$DW$98, DW_AT_location[DW_OP_regx 0x54]
    $C$DW$99 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TSCL")
    .dwattr $C$DW$99, DW_AT_location[DW_OP_regx 0x55]
    $C$DW$100 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TSCH")
    .dwattr $C$DW$100, DW_AT_location[DW_OP_regx 0x56]
    $C$DW$101 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ARP")
    .dwattr $C$DW$101, DW_AT_location[DW_OP_regx 0x57]
    $C$DW$102 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ILC")
    .dwattr $C$DW$102, DW_AT_location[DW_OP_regx 0x58]
    $C$DW$103 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RILC")
    .dwattr $C$DW$103, DW_AT_location[DW_OP_regx 0x59]
    $C$DW$104 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DNUM")
    .dwattr $C$DW$104, DW_AT_location[DW_OP_regx 0x5a]
    $C$DW$105 .dwtag DW_TAG_TI_assign_register, DW_AT_name("SSR")
    .dwattr $C$DW$105, DW_AT_location[DW_OP_regx 0x5b]
    $C$DW$106 .dwtag DW_TAG_TI_assign_register, DW_AT_name("GPLYA")
    .dwattr $C$DW$106, DW_AT_location[DW_OP_regx 0x5c]
    $C$DW$107 .dwtag DW_TAG_TI_assign_register, DW_AT_name("GPLYB")
    .dwattr $C$DW$107, DW_AT_location[DW_OP_regx 0x5d]
    $C$DW$108 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TSR")
    .dwattr $C$DW$108, DW_AT_location[DW_OP_regx 0x5e]
    $C$DW$109 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ITSR")
    .dwattr $C$DW$109, DW_AT_location[DW_OP_regx 0x5f]
    $C$DW$110 .dwtag DW_TAG_TI_assign_register, DW_AT_name("NTSR")
    .dwattr $C$DW$110, DW_AT_location[DW_OP_regx 0x60]
    $C$DW$111 .dwtag DW_TAG_TI_assign_register, DW_AT_name("EFR")
    .dwattr $C$DW$111, DW_AT_location[DW_OP_regx 0x61]
    $C$DW$112 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ECR")
    .dwattr $C$DW$112, DW_AT_location[DW_OP_regx 0x62]
    $C$DW$113 .dwtag DW_TAG_TI_assign_register, DW_AT_name("IERR")
    .dwattr $C$DW$113, DW_AT_location[DW_OP_regx 0x63]
    $C$DW$114 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DMSG")
    .dwattr $C$DW$114, DW_AT_location[DW_OP_regx 0x64]
    $C$DW$115 .dwtag DW_TAG_TI_assign_register, DW_AT_name("CMSG")
    .dwattr $C$DW$115, DW_AT_location[DW_OP_regx 0x65]
    $C$DW$116 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DT_DMA_ADDR")
    .dwattr $C$DW$116, DW_AT_location[DW_OP_regx 0x66]
    $C$DW$117 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DT_DMA_DATA")
    .dwattr $C$DW$117, DW_AT_location[DW_OP_regx 0x67]
    $C$DW$118 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DT_DMA_CNTL")
    .dwattr $C$DW$118, DW_AT_location[DW_OP_regx 0x68]
    $C$DW$119 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TCU_CNTL")
    .dwattr $C$DW$119, DW_AT_location[DW_OP_regx 0x69]
    $C$DW$120 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_REC_CNTL")
    .dwattr $C$DW$120, DW_AT_location[DW_OP_regx 0x6a]
    $C$DW$121 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_XMT_CNTL")
    .dwattr $C$DW$121, DW_AT_location[DW_OP_regx 0x6b]
    $C$DW$122 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_CFG")
    .dwattr $C$DW$122, DW_AT_location[DW_OP_regx 0x6c]
    $C$DW$123 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_RDATA")
    .dwattr $C$DW$123, DW_AT_location[DW_OP_regx 0x6d]
    $C$DW$124 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_WDATA")
    .dwattr $C$DW$124, DW_AT_location[DW_OP_regx 0x6e]
    $C$DW$125 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_RADDR")
    .dwattr $C$DW$125, DW_AT_location[DW_OP_regx 0x6f]
    $C$DW$126 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_WADDR")
    .dwattr $C$DW$126, DW_AT_location[DW_OP_regx 0x70]
    $C$DW$127 .dwtag DW_TAG_TI_assign_register, DW_AT_name("MFREG0")
    .dwattr $C$DW$127, DW_AT_location[DW_OP_regx 0x71]
    $C$DW$128 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DBG_STAT")
    .dwattr $C$DW$128, DW_AT_location[DW_OP_regx 0x72]
    $C$DW$129 .dwtag DW_TAG_TI_assign_register, DW_AT_name("BRK_EN")
    .dwattr $C$DW$129, DW_AT_location[DW_OP_regx 0x73]
    $C$DW$130 .dwtag DW_TAG_TI_assign_register, DW_AT_name("HWBP0_CNT")
    .dwattr $C$DW$130, DW_AT_location[DW_OP_regx 0x74]
    $C$DW$131 .dwtag DW_TAG_TI_assign_register, DW_AT_name("HWBP0")
    .dwattr $C$DW$131, DW_AT_location[DW_OP_regx 0x75]
    $C$DW$132 .dwtag DW_TAG_TI_assign_register, DW_AT_name("HWBP1")
    .dwattr $C$DW$132, DW_AT_location[DW_OP_regx 0x76]
    $C$DW$133 .dwtag DW_TAG_TI_assign_register, DW_AT_name("HWBP2")
    .dwattr $C$DW$133, DW_AT_location[DW_OP_regx 0x77]
    $C$DW$134 .dwtag DW_TAG_TI_assign_register, DW_AT_name("HWBP3")
    .dwattr $C$DW$134, DW_AT_location[DW_OP_regx 0x78]
    $C$DW$135 .dwtag DW_TAG_TI_assign_register, DW_AT_name("OVERLAY")
    .dwattr $C$DW$135, DW_AT_location[DW_OP_regx 0x79]
    $C$DW$136 .dwtag DW_TAG_TI_assign_register, DW_AT_name("PC_PROF")
    .dwattr $C$DW$136, DW_AT_location[DW_OP_regx 0x7a]
    $C$DW$137 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ATSR")
    .dwattr $C$DW$137, DW_AT_location[DW_OP_regx 0x7b]
    $C$DW$138 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TRR")
    .dwattr $C$DW$138, DW_AT_location[DW_OP_regx 0x7c]
    $C$DW$139 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TCRR")
    .dwattr $C$DW$139, DW_AT_location[DW_OP_regx 0x7d]
    $C$DW$140 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DESR")
    .dwattr $C$DW$140, DW_AT_location[DW_OP_regx 0x7e]
    $C$DW$141 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DETR")
    .dwattr $C$DW$141, DW_AT_location[DW_OP_regx 0x7f]
    $C$DW$142 .dwtag DW_TAG_TI_assign_register, DW_AT_name("CIE_RETA")
    .dwattr $C$DW$142, DW_AT_location[DW_OP_regx 0xe4]
    .dwendtag $C$DW$CU
  • Find a way to get the assembly code for the version you said worked. There is no reason I can see for this to not work. Try loading the old one and looking in the Disassembly window.
    You will also need to go back to my first post and report back on your results using the debug techniques I mentioned.
    RandyP
    As it turns out, my cp_i2i() linear assembly is working properly now, after removing some separate, preceding functions that were causing havoc, i.e. all requested samples are consistently being transferred from source to destination properly.
    Something has changed during my port from CCS V3.3, related to the preceding logic, which I’ll hunt down.  But this thread can be closed.
    Robert
