PROCESSOR-SDK-AM64X: mmc1 : error -110 whilst initialising SD card
Part Number: PROCESSOR-SDK-AM64X
Hi TI experts,
I am using SK-AM64x board for Linux development. To begin with I installed the TI SDK 11.01.05.03 and used the create-sdcard.sh script to set up my SD card (https://software-dl.ti.com/processor-sdk-linux/esd/AM64X/latest/exports/docs/linux/Overview/Processor_SDK_Linux_create_SD_card.html#create-sd-card-with-default-images-using-script).
After successful SD card creation using the script, I try to boot the AM64x. I get the error stating there was error initialising SD card.
U-Boot SPL 2025.01-00527-gd2a72467939e (Jul 01 2025 - 21:23:47 +0000)
Resetting on cold boot to workaround ErrataID:i2331
Please resend tiboot3.bin in case of UART/DFU boot
resetting ...
SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.2--v11.01.02 (Fancy Rat)')
EEPROM not available at 0x50, trying to read at 0x51
SPL initial stack usage: 13504 bytes
Trying to boot from MMC2
Authentication passed
Loading Environment from nowhere... OK
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.13.0(release):v2.13.0-240-gd90bb650fe-dirty
NOTICE:  BL31: Built : 21:37:18, Jun 23 2025
I/TC:
I/TC: OP-TEE version: 4.6.0-dev (gcc version 13.4.0 (GCC)) #1 Fri Apr 25 11:17:53 UTC 2025 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: GIC redistributor base address not provided
I/TC: Assuming default GIC group status and modifier
I/TC: SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.2--v11.01.02 (Fancy Rat)')
I/TC: Activated SA2UL device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: HUK Initialized
I/TC: Primary CPU switching to normal world boot
U-Boot 2025.01-00527-gd2a72467939e (Jul 01 2025 - 21:23:47 +0000)
SoC:   AM64X SR2.0 HS-FS
Model: Texas Instruments AM642 SK
Board: AM64B-SKEVM rev A
DRAM:  2 GiB
Core:  96 devices, 33 uclasses, devicetree: separate
MMC:   mmc@fa00000: 1
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Failed to probe prueth driver
Net:   eth0: ethernet@8000000port@1, eth1: ethernet@8000000port@2
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
574 bytes read in 3 ms (186.5 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
22323712 bytes read in 932 ms (22.8 MiB/s)
63024 bytes read in 6 ms (10 MiB/s)
Working FDT set to 88000000
   Loading Device Tree to 000000008feed000, end 000000008fffffff ... OK
Working FDT set to 8feed000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.12.35-ti-00915-ge3e551586dfa (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.4.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Tue Jul  1 21:17:52 UTC 2025
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Texas Instruments AM642 SK
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: legacy bootconsole [ns16550a0] enabled
[    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a0000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable r5f-memory@a0100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a1000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable r5f-memory@a1100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a2000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a2ffffff (15360 KiB) nomap non-reusable r5f-memory@a2100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000a30fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a3000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a3100000..0x00000000a3ffffff (15360 KiB) nomap non-reusable r5f-memory@a3100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node m4f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a40fffff (1024 KiB) nomap non-reusable m4f-dma-memory@a4000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node m4f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a4100000..0x00000000a4ffffff (15360 KiB) nomap non-reusable m4f-memory@a4100000
[    0.000000] OF: reserved mem: 0x00000000a5000000..0x00000000a57fffff (8192 KiB) nomap non-reusable ipc-memories@a5000000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a57fffff]
[    0.000000]   node   0: [mem 0x00000000a5800000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000] cma: Reserved 32 MiB at 0x00000000fba00000 on node -1
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.5
[    0.000000] percpu: Embedded 22 pages/cpu s51672 r8192 d30248 u90112
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=38151d3c-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 524288
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 2MB
[    0.000000] software IO TLB: area num 2.
[    0.000000] software IO TLB: mapped [mem 0x00000000fb600000-0x00000000fb800000] (2MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=2.
[    0.000000] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=2.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001840000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000080040000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008845] Console: colour dummy device 80x25
[    0.013471] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.024152] pid_max: default: 32768 minimum: 301
[    0.028995] LSM: initializing lsm=capability,selinux
[    0.034141] SELinux:  Initializing.
[    0.038294] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.045879] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.056908] rcu: Hierarchical SRCU implementation.
[    0.061891] rcu:     Max phase no-delay instances is 1000.
[    0.067496] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.076456] EFI services will not be available.
[    0.081431] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[    0.095119] Detected VIPT I-cache on CPU1
[    0.095241] GICv3: CPU1: found redistributor 1 region 0:0x0000000001860000
[    0.095261] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000
[    0.095324] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.095562] smp: Brought up 1 node, 2 CPUs
[    0.124954] SMP: Total of 2 processors activated.
[    0.129764] CPU: All CPU(s) started at EL2
[    0.133972] CPU features: detected: 32-bit EL0 Support
[    0.139231] CPU features: detected: CRC32 instructions
[    0.144532] alternatives: applying system-wide alternatives
[    0.150990] Memory: 1876876K/2097152K available (12992K kernel code, 1256K rwdata, 4668K rodata, 2752K init, 642K bss, 179536K reserved, 32768K cma-reserved)
[    0.166893] devtmpfs: initialized
[    0.181597] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.191608] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.199821] 27136 pages in range for non-PLT usage
[    0.199851] 518656 pages in range for PLT usage
[    0.205254] pinctrl core: initialized pinctrl subsystem
[    0.215978] DMI not present or invalid.
[    0.222676] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.230618] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.238921] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.248240] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.256482] audit: initializing netlink subsys (disabled)
[    0.262581] audit: type=2000 audit(0.196:1): state=initialized audit_enabled=0 res=1
[    0.263273] thermal_sys: Registered thermal governor 'step_wise'
[    0.270525] thermal_sys: Registered thermal governor 'power_allocator'
[    0.276750] cpuidle: using governor menu
[    0.287707] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.294746] ASID allocator initialised with 65536 entries
[    0.307978] /bus@f4000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f4000/interrupt-controller@1800000
[    0.331501] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.338483] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.344895] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.351833] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.358240] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.365177] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.371584] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.378530] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.388310] k3-chipinfo 43000014.chipid: Family:AM64X rev:SR2.0 JTAGID[0x1bb3802f] Detected
[    0.397724] iommu: Default domain type: Translated
[    0.402684] iommu: DMA domain TLB invalidation policy: strict mode
[    0.409798] SCSI subsystem initialized
[    0.414357] usbcore: registered new interface driver usbfs
[    0.420001] usbcore: registered new interface driver hub
[    0.425521] usbcore: registered new device driver usb
[    0.431359] pps_core: LinuxPPS API ver. 1 registered
[    0.436452] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.445803] PTP clock support registered
[    0.449855] EDAC MC: Ver: 3.0.0
[    0.453631] scmi_core: SCMI protocol bus registered
[    0.459188] FPGA manager framework
[    0.462827] Advanced Linux Sound Architecture Driver Initialized.
[    0.470372] vgaarb: loaded
[    0.473753] clocksource: Switched to clocksource arch_sys_counter
[    0.480474] VFS: Disk quotas dquot_6.6.0
[    0.484558] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.501139] NET: Registered PF_INET protocol family
[    0.506508] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.516191] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.525060] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.533032] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.541261] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.549377] TCP: Hash tables configured (established 16384 bind 16384)
[    0.556349] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.563313] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.570863] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.577393] RPC: Registered named UNIX socket transport module.
[    0.583521] RPC: Registered udp transport module.
[    0.588333] RPC: Registered tcp transport module.
[    0.593157] RPC: Registered tcp-with-tls transport module.
[    0.598768] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.605362] NET: Registered PF_XDP protocol family
[    0.610284] PCI: CLS 0 bytes, default 64
[    0.615981] Initialise system trusted keyrings
[    0.620950] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    0.628072] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.634568] NFS: Registering the id_resolver key type
[    0.639809] Key type id_resolver registered
[    0.644092] Key type id_legacy registered
[    0.648222] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.655078] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.729173] Key type asymmetric registered
[    0.733402] Asymmetric key parser 'x509' registered
[    0.738519] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.746390] io scheduler mq-deadline registered
[    0.751055] io scheduler kyber registered
[    0.755216] io scheduler bfq registered
[    0.763008] pinctrl-single 4084000.pinctrl: 33 pins, size 132
[    0.769560] pinctrl-single f4000.pinctrl: 180 pins, size 720
[    0.777557] ledtrig-cpu: registered to indicate activity on CPUs
[    0.791664] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.810352] loop: module loaded
[    0.815080] megasas: 07.727.03.00-rc1
[    0.824463] tun: Universal TUN/TAP device driver, 1.6
[    0.831391] VFIO - User Level meta-driver version: 0.3
[    0.838407] usbcore: registered new interface driver usb-storage
[    0.845389] i2c_dev: i2c /dev entries driver
[    0.851248] sdhci: Secure Digital Host Controller Interface driver
[    0.857664] sdhci: Copyright(c) Pierre Ossman
[    0.862455] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.869117] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.876981] usbcore: registered new interface driver usbhid
[    0.882777] usbhid: USB HID core driver
[    0.888651] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
[    0.899137] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[    0.903762] optee: revision 4.6 (71785645fa6ce42d)
[    0.920609] optee: dynamic shared memory is enabled
[    0.931598] optee: initialized driver
[    0.931696] random: crng init done
[    0.938643] Initializing XFRM netlink socket
[    0.943351] NET: Registered PF_PACKET protocol family
[    0.948666] Key type dns_resolver registered
[    0.964277] registered taskstats version 1
[    0.968920] Loading compiled-in X.509 certificates
[    0.990162] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.1.2--v11.01.02 (Fancy Rat)')
[    1.121438] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    1.129535] pca953x 1-0070: supply vcc not found, using dummy regulator
[    1.136560] pca953x 1-0070: using no AI
[    1.155139] omap_i2c 20010000.i2c: bus 1 rev0.12 at 400 kHz
[    1.161347] ti-sci-intr bus@f4000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    1.170827] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    1.183773] ti-udma 485c0100.dma-controller: Number of rings: 68
[    1.191840] ti-udma 485c0100.dma-controller: Channels: 24 (bchan: 12, tchan: 6, rchan: 6)
[    1.202390] ti-udma 485c0000.dma-controller: Number of rings: 288
[    1.220572] ti-udma 485c0000.dma-controller: Channels: 44 (tchan: 29, rchan: 15)
[    1.232335] printk: legacy console [ttyS2] disabled
[    1.237916] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 310, base_baud = 3000000) is a 8250
[    1.247061] printk: legacy console [ttyS2] enabled
[    1.256768] printk: legacy bootconsole [ns16550a0] disabled
[    1.275442] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[    1.282488] Creating 7 MTD partitions on "fc40000.spi.0":
[    1.287913] 0x000000000000-0x000000100000 : "ospi.tiboot3"
[    1.295319] 0x000000100000-0x000000300000 : "ospi.tispl"
[    1.302471] 0x000000300000-0x000000700000 : "ospi.u-boot"
[    1.309687] 0x000000700000-0x000000740000 : "ospi.env"
[    1.316556] 0x000000740000-0x000000780000 : "ospi.env.backup"
[    1.324136] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    1.331373] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    1.478246] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00903, cpsw version 0x6BA80903 Ports: 3 quirks:00000006
[    1.492030] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[    1.533772] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.546199] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[    1.554320] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[    1.562624] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.4
[    1.569765] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
[    1.578356] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[    1.604839] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 16
[    1.619212] am65-cpts 39000000.cpts: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
[    1.644658] clk: Disabling unused clocks
[    1.645696] mmc1: CQHCI version 5.10
[    1.673904] PM: genpd: Disabling unused power domains
[    1.674693] mmc0: CQHCI version 5.10
[    1.679237] ALSA device list:
[    1.685611]   No soundcards found.
[    1.693793] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[    1.729773] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    1.738324] Waiting for root device PARTUUID=38151d3c-02...
[    1.747356] sdhci-am654 fa10000.mmc: card claims to support voltages below defined range
[    1.760503] mmc1: error -110 whilst initialising SD card
[    1.772505] mmc0: new SDIO card at address 0001
[    2.023954] mmc1: error -110 whilst initialising SD card
[    2.330903] mmc1: error -110 whilst initialising SD card
[    2.617350] mmc1: error -110 whilst initialising SD card
I am using SanDisk Ultra 128GB Class 10 SD card to do this, To avoid the ambiguity, i tried with a different SanDisk Ultra 32GB Class 10 SD card but the error remains the same.
Can you please help me with this issue?
Solomon
