PROCESSOR-SDK-AM69A: I’m having an issue building the image for the AM69A.
Part Number: PROCESSOR-SDK-AM69A
Other Parts Discussed in Thread: AM69
  • When I build version 10, it fails because it can’t clone the files from meta-qt5 — the Qt repository seems to have problems. I tried checking the clone link manually, but it also returns a 404 error.
  • When I build version 11, it immediately fails because meta-qt6 cannot be downloaded due to a timeout.
    - VERSION 11.:
    cloning repo meta-qt6
    Cloning into '/home/tung/yocto-build/sources/meta-qt6'...
    fatal: unable to access 'https://code.qt.io/yocto/meta-qt6.git/': Failed to connect to code.qt.io port 443: Connection timed out
    git failed... remaining attempts: 4    sleeping 15 seconds
    git failed... remaining attempts: 3    sleeping 30 seconds
    git failed... remaining attempts: 2    sleeping 45 seconds
    -VERSION 10.:
    ERROR: qtxmlpatterns-5.15.13+git-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtxmlpatterns/5.15.13+git/recipe-sysroot-native/usr/bin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/sources/oe-core/scripts:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtxmlpatterns/5.15.13+git/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtxmlpatterns/5.15.13+git/recipe-sysroot/usr/bin/crossscripts:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtxmlpatterns/5.15.13+git/recipe-sysroot-native/usr/sbin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtxmlpatterns/5.15.13+git/recipe-sysroot-native/usr/bin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtxmlpatterns/5.15.13+git/recipe-sysroot-native/sbin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtxmlpatterns/5.15.13+git/recipe-sysroot-native/bin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/sources/bitbake/bin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/minhduc"; LANG=C git -c gc.autoDetach=false -c core.pager=cat -c safe.bareRepository=all clone --bare --mirror git://code.qt.io/qt/qtxmlpatterns.git /media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/../downloads/git2/code.qt.io.qt.qtxmlpatterns.git --progress failed with exit code 128, see logfile for output
    ERROR: qtxmlpatterns-5.15.13+git-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://code.qt.io/qt/qtxmlpatterns.git;name=qtxmlpatterns;branch=5.15;protocol=git')
    ERROR: Logfile of failure stored in: /media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtxmlpatterns/5.15.13+git/temp/log.do_fetch.728801
    ERROR: Task (/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtxmlpatterns_git.bb:do_fetch) failed with exit code '1'
    ERROR: qtquickcontrols-5.15.13+git-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtquickcontrols/5.15.13+git/recipe-sysroot-native/usr/bin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/sources/oe-core/scripts:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtquickcontrols/5.15.13+git/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtquickcontrols/5.15.13+git/recipe-sysroot/usr/bin/crossscripts:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtquickcontrols/5.15.13+git/recipe-sysroot-native/usr/sbin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtquickcontrols/5.15.13+git/recipe-sysroot-native/usr/bin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtquickcontrols/5.15.13+git/recipe-sysroot-native/sbin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtquickcontrols/5.15.13+git/recipe-sysroot-native/bin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/sources/bitbake/bin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/minhduc"; LANG=C git -c gc.autoDetach=false -c core.pager=cat -c safe.bareRepository=all clone --bare --mirror git://code.qt.io/qt/qtquickcontrols.git /media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/../downloads/git2/code.qt.io.qt.qtquickcontrols.git --progress failed with exit code 128, see logfile for output
    ERROR: qtquickcontrols-5.15.13+git-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://code.qt.io/qt/qtquickcontrols.git;name=qtquickcontrols;branch=5.15;protocol=git')
    ERROR: Logfile of failure stored in: /media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtquickcontrols/5.15.13+git/temp/log.do_fetch.728718
    ERROR: Task (/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtquickcontrols_git.bb:do_fetch) failed with exit code '1'
    ERROR: qtmultimedia-5.15.13+git-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtmultimedia/5.15.13+git/recipe-sysroot-native/usr/bin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/sources/oe-core/scripts:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtmultimedia/5.15.13+git/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtmultimedia/5.15.13+git/recipe-sysroot/usr/bin/crossscripts:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtmultimedia/5.15.13+git/recipe-sysroot-native/usr/sbin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtmultimedia/5.15.13+git/recipe-sysroot-native/usr/bin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtmultimedia/5.15.13+git/recipe-sysroot-native/sbin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtmultimedia/5.15.13+git/recipe-sysroot-native/bin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/sources/bitbake/bin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/minhduc"; LANG=C git -c gc.autoDetach=false -c core.pager=cat -c safe.bareRepository=all clone --bare --mirror git://code.qt.io/qt/qtmultimedia.git /media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/../downloads/git2/code.qt.io.qt.qtmultimedia.git --progress failed with exit code 128, see logfile for output
    ERROR: qtmultimedia-5.15.13+git-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://code.qt.io/qt/qtmultimedia.git;name=qtmultimedia;branch=5.15;protocol=git')
    ERROR: Logfile of failure stored in: /media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/qtmultimedia/5.15.13+git/temp/log.do_fetch.728888
    ERROR: Task (/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtmultimedia_git.bb:do_fetch) failed with exit code '1'
  • i have check proxy but my internet not have proxy
  • Hi ,
    I am not seeing this issue currently. Can you try again or check your internet connection settings?
    $ git clone https://code.qt.io/yocto/meta-qt6.git
    Cloning into 'meta-qt6'...
    remote: Enumerating objects: 16610, done.
    remote: Counting objects: 100% (16610/16610), done.
    remote: Compressing objects: 100% (6076/6076), done.
    remote: Total 16610 (delta 12556), reused 13452 (delta 10357), pack-reused 0
    Receiving objects: 100% (16610/16610), 3.61 MiB | 4.14 MiB/s, done.
    Resolving deltas: 100% (12556/12556), done.
    Jared
  • i have retry with ethernet 4g but not connect to code.qt.io/.../meta-qt6.git
  • i have try not firewall , proxy , ethernet4g and at another location on a different PC
  • Hi ,
    Are you able to clone the repository outside of the Yocto build?
    Can you clone a mirror? For example: GitHub - YoeDistro/meta-qt6: Mirror of https://code.qt.io/cgit/yocto/meta-qt6.git/
    Jared
  • thanks , i will try it
  • I’ve already downloaded the meta-qt6 layer from Git, but during the build process it still tries to clone from Qt’s server, which causes an error. Do you have any solution for this?
    minhduc@minhduc:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build$ bitbake tisdk-edgeai-image
    NOTE: Started PRServer with DBfile: /media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/cache/prserv.sqlite3, Address: 127.0.0.1:37439, PID: 2423934
    Loading cache: 100% |        | ETA:  --:--:--
    Loaded 0 entries from dependency cache.
    Parsing recipes: 100% |######################################################################################################################################################################| Time: 0:01:28
    Parsing of 6976 .bb files complete (0 cached, 6976 parsed). 11094 targets, 1643 skipped, 0 masked, 0 errors.
    NOTE: Resolving any missing task queue dependencies
    Build Configuration (mc:default):
    BB_VERSION           = "2.8.0"
    BUILD_SYS            = "x86_64-linux"
    NATIVELSBSTRING      = "ubuntu-22.04"
    TARGET_SYS           = "aarch64-oe-linux"
    MACHINE              = "j784s4-evm"
    DISTRO               = "arago"
    DISTRO_VERSION       = "2025.01"
    TUNE_FEATURES        = "aarch64"
    TARGET_FPU           = ""
    meta-arago-distro
    meta-arago-extras
    meta-arago-test      = "HEAD:c04e85dd207dd24387edac10526b9ec971df9496"
    meta-virtualization  = "HEAD:9e040ee8dd6025558ea60ac9db60c41bfeddf221"
    meta-networking
    meta-python
    meta-oe
    meta-gnome
    meta-filesystems
    meta-multimedia      = "HEAD:e92d0173a80ea7592c866618ef5293203c50544c"
    meta-ti-extras
    meta-ti-bsp          = "HEAD:a98a2e1029870b25e117d4c9410e75bfd955f35a"
    meta-arm
    meta-arm-toolchain   = "HEAD:8e0f8af90fefb03f08cd2228cde7a89902a6b37c"
    meta-clang           = "HEAD:eaa08939eaec9f620b14742ff3ac568553683034"
    meta                 = "HEAD:b214cc84a922f7a3fb7ebbc501189ce25e8bd2bd"
    meta-ti-foundational = "HEAD:1f96dccc01f10c73295e0bac6a15a97d3d4562fd"
    meta-edgeai          = "HEAD:81d1b80b2a314814c6d900e82ea2da93eee3f57d"
    meta-qt6             = "yoe/6.10:5cb74001e72de0be9f9d753601c55b6eb5c9b728"
    Build Configuration:
    TARGET_SYS           = "arm-oe-eabi"
    MACHINE              = "j784s4-evm-k3r5"
    DISTRO               = "arago"
    TUNE_FEATURES        = "arm armv7a vfp thumb callconvention-hard"
    TARGET_FPU           = "hard"
    meta-arago-distro
    meta-arago-extras
    meta-networking
    meta-python
    meta-oe
    meta-gnome
    meta-filesystems
    meta-ti-extras
    meta-arm
    Sstate summary: Wanted 5954 Local 78 Mirrors 0 Missed 5876 Current 1014 (1% match, 15% complete)############################################################################                 | ETA:  0:00:03
    Removing 57 stale sstate objects for arch allarch: 100% |####################################################################################################################################| Time: 0:00:02
    Removing 264 stale sstate objects for arch j784s4_evm: 100% |################################################################################################################################| Time: 0:00:40
    Removing 602 stale sstate objects for arch x86_64: 100% |####################################################################################################################################| Time: 0:00:51
    Removing 1082 stale sstate objects for arch aarch64: 100% |##################################################################################################################################| Time: 0:01:03
    Removing 4 stale sstate objects for arch j784s4_evm_k3r5: 100% |#############################################################################################################################| Time: 0:00:00
    Removing 123 stale sstate objects for arch x86_64: 100% |####################################################################################################################################| Time: 0:00:13
    NOTE: Executing Tasks
    WARNING: gcc-source-13.3.0-13.3.0-r0 do_fetch: Failed to fetch URL https://ftp.gnu.org/gnu/gcc/gcc-13.3.0/gcc-13.3.0.tar.xz, attempting MIRRORS if available
    WARNING: qtbase-native-6.10.1-r0 do_fetch: Failed to fetch URL git://code.qt.io/qt/qtbase.git;name=qtbase;branch=6.10;nobranch=1;protocol=git;destsuffix=qtbase-6.10.1, attempting MIRRORS if available
    WARNING: qtshadertools-native-6.10.1-r0 do_fetch: Failed to fetch URL git://code.qt.io/qt/qtshadertools.git;name=qtshadertools;branch=6.10;nobranch=1;protocol=git;destsuffix=qtshadertools-6.10.1, attempting MIRRORS if available
    ERROR: qtshadertools-native-6.10.1-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/sources/oe-core/scripts/native-intercept:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/x86_64-linux/qtshadertools-native/6.10.1/recipe-sysroot-native/usr/bin/python3-native:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/x86_64-linux/qtshadertools-native/6.10.1/recipe-sysroot-native/usr/bin/perl-native:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/sources/oe-core/scripts:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/x86_64-linux/qtshadertools-native/6.10.1/recipe-sysroot-native/usr/bin/x86_64-linux:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/x86_64-linux/qtshadertools-native/6.10.1/recipe-sysroot-native/usr/bin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/x86_64-linux/qtshadertools-native/6.10.1/recipe-sysroot-native/usr/sbin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/x86_64-linux/qtshadertools-native/6.10.1/recipe-sysroot-native/usr/bin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/x86_64-linux/qtshadertools-native/6.10.1/recipe-sysroot-native/sbin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/x86_64-linux/qtshadertools-native/6.10.1/recipe-sysroot-native/bin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/sources/bitbake/bin:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/minhduc"; LANG=C git -c gc.autoDetach=false -c core.pager=cat -c safe.bareRepository=all clone --bare --mirror git://code.qt.io/qt/qtshadertools.git /media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/../downloads/git2/code.qt.io.qt.qtshadertools.git --progress failed with exit code 128, see logfile for output
    ERROR: qtshadertools-native-6.10.1-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://code.qt.io/qt/qtshadertools.git;name=qtshadertools;branch=6.10;nobranch=1;protocol=git;destsuffix=qtshadertools-6.10.1')
    ERROR: Logfile of failure stored in: /media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/x86_64-linux/qtshadertools-native/6.10.1/temp/log.do_fetch.3121129
    ERROR: Task (virtual:native:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/sources/meta-qt6/recipes-qt/qt6/qtshadertools_git.bb:do_fetch) failed with exit code '1'
    Waiting for 2 running tasks to finish:
    0: qtbase-native-6.10.1-r0 do_fetch - 17m25s (pid 3021595) |                                    <=>        |
    1: qtbase-6.10.1-r0 do_fetch - 14m50s (pid 3094989)
  • Hi ,
    You can try changing the QT_GIT_PROTOCOL to https in the meta-qt6/conf/layer.conf
    I was unable to clone that repository using the git transport protocol, but https worked fine.
    Jared
  • i have changing the QT_GIT_PROTOCOL to https in the meta-qt6/conf/layer.conf now , this issue with patch apply
    ERROR: qtbase-native-6.9-r0 do_patch: Applying patch '0001-Add-linux-oe-g-platform.patch' on target directory '/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/x86_64-linux/qtbase-native/6.9/qtbase-6.9'
    CmdError('quilt --quiltrc /media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/x86_64-linux/qtbase-native/6.9/recipe-sysroot-native/etc/quiltrc push', 0, "stdout: Applying patch 0001-Add-linux-oe-g-platform.patch
    can't find file to patch at input line 31
    Perhaps you used the wrong -p or --strip option?
    The text leading up to this was:
    |From a08e167d51c33f91009ba27adaa083c783c1ac54 Mon Sep 17 00:00:00 2001
    |Date: Mon, 15 Apr 2013 04:29:32 +0200
    |Subject: [PATCH] Add linux-oe-g++ platform
    |* This qmake.conf unlike other platforms reads most variables from
    | shell environment, because it's easier for qt recipes to export
    | *FLAGS or CC specific for given recipe
    |Upstream-Status: Inappropriate [embedded specific]
    | too OE specific, probably cannot be upstreamed
    |Change-Id: I0591ed5da0d61d7cf1509d420e6b293582f1863c
    |Signed-off-by: Martin Jansa <Martin.Jansa@gmail.com>
    | mkspecs/features/qt.prf | 6 ++---
    | mkspecs/features/qt_functions.prf | 4 +--
    | mkspecs/linux-oe-g++/qmake.conf | 38 ++++++++++++++++++++++++++++
    | mkspecs/linux-oe-g++/qplatformdefs.h | 1 +
    | mkspecs/oe-device-extra.pri | 0
    | 5 files changed, 44 insertions(+), 5 deletions(-)
    | create mode 100644 mkspecs/linux-oe-g++/qmake.conf
    | create mode 100644 mkspecs/linux-oe-g++/qplatformdefs.h
    | create mode 100644 mkspecs/oe-device-extra.pri
    |diff --git a/mkspecs/features/qt.prf b/mkspecs/features/qt.prf
    |index 3c4b284b68..a7545ace5c 100644
    |--- a/mkspecs/features/qt.prf
    |+++ b/mkspecs/features/qt.prf
    No file to patch. Skipping patch.
    2 out of 2 hunks ignored
    can't find file to patch at input line 55
    |diff --git a/mkspecs/features/qt_functions.prf b/mkspecs/features/qt_functions.prf
    |index f1371c8cc6..84cbf4a476 100644
    |--- a/mkspecs/features/qt_functions.prf
    |+++ b/mkspecs/features/qt_functions.prf
    patching file mkspecs/linux-oe-g++/qmake.conf
    patching file mkspecs/linux-oe-g++/qplatformdefs.h
    patching file mkspecs/oe-device-extra.pri
    Patch 0001-Add-linux-oe-g-platform.patch does not apply (enforce with -f)
    stderr: ")
    ERROR: Logfile of failure stored in: /media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/build/arago-tmp-default-glibc/work/x86_64-linux/qtbase-native/6.9/temp/log.do_patch.3721640
    ERROR: Task (virtual:native:/media/minhduc/a30d1df8-0961-4f96-b355-1df77c1b938e/am69/yocto-build/sources/meta-qt6/recipes-qt/qt6/qtbase_git.bb:do_patch) failed with exit code '1'
    NOTE: Tasks Summary: Attempted 1697 tasks of which 1686 didn't need to be rerun and 1 failed.
    NOTE: Writing buildhistory
    NOTE: Writing buildhistory took: 3 seconds
    Summary: 1 task failed:
  • Hi ,
    I have tested building the qtbase recipe, and I did not see your original issue of fetching the repository(ies).
    Can you try cleaning and rebuilding the qtbase recipe?
    Jared
  • I’ve tried, but it seems that the Qt server is blocking connections from Vietnam or something like that. I traced the logs and saw that my request reached the server in London, but it stopped there.
  • Hi ,
    I see. I unfortunately can't help with that. Maybe you can try a VPN?
    You can also try asking the Qt forum for help: https://forum.qt.io/
    Closing this thread, as I am unable to provide further support.
    Jared
