Part Number: AM6422
Other Parts Discussed in Thread: AM6442, SYSCONFIG
Hi all, working on a custom board based on the AM6442 with LPDDR4 (ISSI IS43LQ16512B-053BLI 8Gb -> 1GB RAM). Right now, I'm having difficulties getting the LPDDR4 to initialize/work correctly - I've applied the patch for dumping the memory as well, in the attached file.
SDK: ti-processor-sdk-linux-am64xx-evm-11.01.05.03
note: k3-am642-sk.dts includes "k3-am642.dtsi" -> this is not present in SDK, but from 2024.04 ?? pulled it from there. diff between this and the k3-am64.dtsi has no difference between the files. assuming this is an error in the k3-am642-sk.dts
I've renamed the .dtsi to .dtsi.txt to attach it here (otherwise it is rejected).
I'm guessing that something is not configured correclty, because the register information does not match what is in the .dtsi file
k3-am64-muu-lp4-1600MTs.dtsi.txt
U-Boot SPL 2025.01-gd2a72467939e-dirty (Oct 10 2025 - 10:17:28 +0200) SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.2--v11.01.02 (Fancy Rat)') EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -121 === About to init DDR via UCLASS_RAM === k3_ddrss_probe(dev=) k3_ddrss_ofdata_to_priv(dev=) k3_ddrss memorycontroller@f300000: ddr freq0 not populated, using bypass frequency. k3_ddrss_power_on(ddrss=) k3_ddrss memorycontroller@f300000: vtt-supply not found. k3_lpddr4_probe: PASS k3_lpddr4_init: PASS --->>> LPDDR4 Initialization is in progress ... <<<--- k3_lpddr4_start: Post start PASS Begin DDR Register Dump 0x0f308000 0x10460a01 //DDRSS_CTL_0_DATA 0x0f308004 0x5d1af3c3 //DDRSS_CTL_1_DATA 0x0f308008 0x0171a610 //DDRSS_CTL_2_DATA 0x0f30800c 0x40020a11 //DDRSS_CTL_3_DATA 0x0f308010 0x00052006 //DDRSS_CTL_4_DATA 0x0f308014 0x02050020 //DDRSS_CTL_5_DATA 0x0f308018 0x03070101 //DDRSS_CTL_6_DATA 0x0f30801c 0x000890b8 //DDRSS_CTL_7_DATA 0x0f308020 0x00000000 //DDRSS_CTL_8_DATA 0x0f308024 0x00000000 //DDRSS_CTL_9_DATA 0x0f308028 0x00000000 //DDRSS_CTL_10_DATA 0x0f30802c 0x000890b8 //DDRSS_CTL_11_DATA 0x0f308030 0x00000000 //DDRSS_CTL_12_DATA 0x0f308034 0x00000000 //DDRSS_CTL_13_DATA 0x0f308038 0x00000000 //DDRSS_CTL_14_DATA 0x0f30803c 0x000890b8 //DDRSS_CTL_15_DATA 0x0f308040 0x00000000 //DDRSS_CTL_16_DATA 0x0f308044 0x00000000 //DDRSS_CTL_17_DATA 0x0f308048 0x00000000 //DDRSS_CTL_18_DATA 0x0f30804c 0x01010100 //DDRSS_CTL_19_DATA 0x0f308050 0x01000101 //DDRSS_CTL_20_DATA 0x0f308054 0x01000110 //DDRSS_CTL_21_DATA 0x0f308058 0x02010002 //DDRSS_CTL_22_DATA 0x0f30805c 0x00027100 //DDRSS_CTL_23_DATA 0x0f308060 0x00061a80 //DDRSS_CTL_24_DATA 0x0f308064 0x02550255 //DDRSS_CTL_25_DATA 0x0f308068 0x00000255 //DDRSS_CTL_26_DATA 0x0f30806c 0x00000000 //DDRSS_CTL_27_DATA 0x0f308070 0x00000000 //DDRSS_CTL_28_DATA 0x0f308074 0x00000000 //DDRSS_CTL_29_DATA 0x0f308078 0x00000000 //DDRSS_CTL_30_DATA 0x0f30807c 0x00000000 //DDRSS_CTL_31_DATA 0x0f308080 0x00000000 //DDRSS_CTL_32_DATA 0x0f308084 0x00000000 //DDRSS_CTL_33_DATA 0x0f308088 0x00000000 //DDRSS_CTL_34_DATA 0x0f30808c 0x00000000 //DDRSS_CTL_35_DATA 0x0f308090 0x00000000 //DDRSS_CTL_36_DATA 0x0f308094 0x00000000 //DDRSS_CTL_37_DATA 0x0f308098 0x0400091c //DDRSS_CTL_38_DATA 0x0f30809c 0x1c1c1c1c //DDRSS_CTL_39_DATA 0x0f3080a0 0x0400091c //DDRSS_CTL_40_DATA 0x0f3080a4 0x1c1c1c1c //DDRSS_CTL_41_DATA 0x0f3080a8 0x0400091c //DDRSS_CTL_42_DATA 0x0f3080ac 0x1c1c1c1c //DDRSS_CTL_43_DATA 0x0f3080b0 0x05050404 //DDRSS_CTL_44_DATA 0x0f3080b4 0x00002706 //DDRSS_CTL_45_DATA 0x0f3080b8 0x0602001d //DDRSS_CTL_46_DATA 0x0f3080bc 0x05001d0b //DDRSS_CTL_47_DATA 0x0f3080c0 0x00270605 //DDRSS_CTL_48_DATA 0x0f3080c4 0x0602001d //DDRSS_CTL_49_DATA 0x0f3080c8 0x05001d0b //DDRSS_CTL_50_DATA 0x0f3080cc 0x00270605 //DDRSS_CTL_51_DATA 0x0f3080d0 0x0602001d //DDRSS_CTL_52_DATA 0x0f3080d4 0x07001d0b //DDRSS_CTL_53_DATA 0x0f3080d8 0x00180807 //DDRSS_CTL_54_DATA 0x0f3080dc 0x0400db60 //DDRSS_CTL_55_DATA 0x0f3080e0 0x07070009 //DDRSS_CTL_56_DATA 0x0f3080e4 0x00001808 //DDRSS_CTL_57_DATA 0x0f3080e8 0x0400db60 //DDRSS_CTL_58_DATA 0x0f3080ec 0x07070009 //DDRSS_CTL_59_DATA 0x0f3080f0 0x00001808 //DDRSS_CTL_60_DATA 0x0f3080f4 0x0400db60 //DDRSS_CTL_61_DATA 0x0f3080f8 0x03000009 //DDRSS_CTL_62_DATA 0x0f3080fc 0x0d0c0002 //DDRSS_CTL_63_DATA 0x0f308100 0x0d0c0d0c //DDRSS_CTL_64_DATA 0x0f308104 0x01010000 //DDRSS_CTL_65_DATA 0x0f308108 0x03191919 //DDRSS_CTL_66_DATA 0x0f30810c 0x0b0b0b0b //DDRSS_CTL_67_DATA 0x0f308110 0x00000b0b //DDRSS_CTL_68_DATA 0x0f308114 0x00000101 //DDRSS_CTL_69_DATA 0x0f308118 0x00000000 //DDRSS_CTL_70_DATA 0x0f30811c 0x01000000 //DDRSS_CTL_71_DATA 0x0f308120 0x01180803 //DDRSS_CTL_72_DATA 0x0f308124 0x00001860 //DDRSS_CTL_73_DATA 0x0f308128 0x00000118 //DDRSS_CTL_74_DATA 0x0f30812c 0x00001860 //DDRSS_CTL_75_DATA 0x0f308130 0x00000118 //DDRSS_CTL_76_DATA 0x0f308134 0x00001860 //DDRSS_CTL_77_DATA 0x0f308138 0x00000005 //DDRSS_CTL_78_DATA 0x0f30813c 0x00000000 //DDRSS_CTL_79_DATA 0x0f308140 0x00000000 //DDRSS_CTL_80_DATA 0x0f308144 0x00000000 //DDRSS_CTL_81_DATA 0x0f308148 0x00000000 //DDRSS_CTL_82_DATA 0x0f30814c 0x00000000 //DDRSS_CTL_83_DATA 0x0f308150 0x00000000 //DDRSS_CTL_84_DATA 0x0f308154 0x00000000 //DDRSS_CTL_85_DATA 0x0f308158 0x00000000 //DDRSS_CTL_86_DATA 0x0f30815c 0x00090009 //DDRSS_CTL_87_DATA 0x0f308160 0x00000009 //DDRSS_CTL_88_DATA 0x0f308164 0x00000000 //DDRSS_CTL_89_DATA 0x0f308168 0x00000000 //DDRSS_CTL_90_DATA 0x0f30816c 0x00000000 //DDRSS_CTL_91_DATA 0x0f308000000 //DDRSS_CTL_348_DATA 0x0f308574 0x00000000 //DDRSS_CTL_349_DATA 0x0f308578 0x00000000 //DDRSS_CTL_350_DATA 0x0f30857c 0x00000000 //DDRSS_CTL_351_DATA 0x0f308580 0x00000000 //DDRSS_CTL_352_DATA 0x0f308584 0x00000000 //DDRSS_CTL_353_DATA 0x0f308588 0x00000000 //DDRSS_CTL_354_DATA 0x0f30858c 0x00000000 //DDRSS_CTL_355_DATA 0x0f308590 0x00000000 //DDRSS_CTL_356_DATA 0x0f308594 0x00000000 //DDRSS_CTL_357_DATA 0x0f308598 0x00000000 //DDRSS_CTL_358_DATA 0x0f30859c 0x00000000 //DDRSS_CTL_359_DATA 0x0f3085a0 0x00000000 //DDRSS_CTL_360_DATA 0x0f3085a4 0x00000000 //DDRSS_CTL_361_DATA 0x0f3085a8 0x00000000 //DDRSS_CTL_362_DATA 0x0f3085ac 0x00000000 //DDRSS_CTL_363_DATA 0x0f3085b0 0x00000000 //DDRSS_CTL_364_DATA 0x0f3085b4 0x00000000 //DDRSS_CTL_365_DATA 0x0f3085b8 0x00000000 //DDRSS_CTL_366_DATA 0x0f3085bc 0x00000000 //DDRSS_CTL_367_DATA 0x0f3085c0 0x00000000 //DDRSS_CTL_368_DATA 0x0f3085c4 0x00000000 //DDRSS_CTL_369_DATA 0x0f3085c8 0x0c000000 //DDRSS_CTL_370_DATA 0x0f3085cc 0x060c0606 //DDRSS_CTL_371_DATA 0x0f3085d0 0x06060c06 //DDRSS_CTL_372_DATA 0x0f3085d4 0x00010101 //DDRSS_CTL_373_DATA 0x0f3085d8 0x02000000 //DDRSS_CTL_374_DATA 0x0f3085dc 0x05020101 //DDRSS_CTL_375_DATA 0x0f3085e0 0x00000505 //DDRSS_CTL_376_DATA 0x0f3085e4 0x02020200 //DDRSS_CTL_377_DATA 0x0f3085e8 0x02020202 //DDRSS_CTL_378_DATA 0x0f3085ec 0x02020202 //DDRSS_CTL_379_DATA 0x0f3085f0 0x02020202 //DDRSS_CTL_380_DATA 0x0f3085f4 0x00000000 //DDRSS_CTL_381_DATA 0x0f3085f8 0x00000000 //DDRSS_CTL_382_DATA 0x0f3085fc 0x04000100 //DDRSS_CTL_383_DATA 0x0f308600 0x1e000304 //DDRSS_CTL_384_DATA 0x0f308604 0x000030c0 //DDRSS_CTL_385_DATA 0x0f308608 0x00000200 //DDRSS_CTL_386_DATA 0x0f30860c 0x00000200 //DDRSS_CTL_387_DATA 0x0f308610 0x00000200 //DDRSS_CTL_388_DATA 0x0f308614 0x00000200 //DDRSS_CTL_389_DATA 0x0f308618 0x0000db60 //DDRSS_CTL_390_DATA 0x0f30861c 0x0001e780 //DDRSS_CTL_391_DATA 0x0f308620 0x0c0d0302 //DDRSS_CTL_392_DATA 0x0f308624 0x001e090a //DDRSS_CTL_393_DATA 0x0f308628 0x000030c0 //DDRSS_CTL_394_DATA 0x0f30862c 0x00000200 //DDRSS_CTL_395_DATA 0x0f308630 0x00000200 //DDRSS_CTL_396_DATA 0x0f308634 0x00000200 //DDRSS_CTL_397_DATA 0x0f308638 0x00000200 //DDRSS_CTL_398_DATA 0x0f30863c 0x0000db60 //DDRSS_CTL_399_DATA 0x0f308640 0x0001e780 //DDRSS_CTL_400_DATA 0x0f308644 0x0c0d0302 //DDRSS_CTL_401_DATA 0x0f308648 0x001e090a //DDRSS_CTL_402_DATA 0x0f30864c 0x000030c0 //DDRSS_CTL_403_DATA 0x0f308650 0x00000200 //DDRSS_CTL_404_DATA 0x0f308654 0x00000200 //DDRSS_CTL_405_DATA 0x0f308658 0x00000200 //DDRSS_CTL_406_DATA 0x0f30865c 0x00000200 //DDRSS_CTL_407_DATA 0x0f308660 0x0000db60 //DDRSS_CTL_408_DATA 0x0f308664 0x0001e780 //DDRSS_CTL_409_DATA 0x0f308668 0x0c0d0302 //DDRSS_CTL_410_DATA 0x0f30866c 0x0000090a //DDRSS_CTL_411_DATA 0x0f308670 0x00000000 //DDRSS_CTL_412_DATA 0x0f308674 0x0302000a //DDRSS_CTL_413_DATA 0x0f308678 0x01000500 //DDRSS_CTL_414_DATA 0x0f30867c 0x01010001 //DDRSS_CTL_415_DATA 0x0f308680 0x00010001 //DDRSS_CTL_416_DATA 0x0f308684 0x01010001 //DDRSS_CTL_417_DATA 0x0f308688 0x02010000 //DDRSS_CTL_418_DATA 0x0f30868c 0x00000200 //DDRSS_CTL_419_DATA 0x0f308690 0x02000201 //DDRSS_CTL_420_DATA 0x0f308694 0x00000000 //DDRSS_CTL_421_DATA 0x0f308698 0x00202020 //DDRSS_CTL_422_DATA 0x0f30a000 0x00000a01 //DDRSS_PI_0_DATA 0x0f30a004 0xae8d79e2 //DDRSS_PI_1_DATA 0x0f30a008 0x0714b570 //DDRSS_PI_2_DATA 0x0f30a00c 0x01011387 //DDRSS_PI_3_DATA 0x0f30a010 0x00000001 //DDRSS_PI_4_DATA 0x0f30a014 0x00010064 //DDRSS_PI_5_DATA 0x0f30a018 0x00000000 //DDRSS_PI_6_DATA 0x0f30a01c 0x00000000 //DDRSS_PI_7_DATA 0x0f30a020 0x00000000 //DDRSS_PI_8_DATA 0x0f30a024 0x00000003 //DDRSS_PI_9_DATA 0x0f30a028 0x0000000f //DDRSS_PI_10_DATA 0x0f30a02c 0x00000000 //DDRSS_PI_11_DATA 0x0f30a030 0x00000000 //DDRSS_PI_12_DATA 0x0f30a034 0x00010001 //DDRSS_PI_13_DATA 0x0f30a038 0x00000000 //DDRSS_PI_14_DATA 0x0f30a03c 0x00010001 //DDRSS_PI_15_DATA 0x0f30a040 0x00000005 //DDRSS_PI_16_DATA 0x0f30a044 0x00010000 //DDRSS_PI_17_DATA 0x0f30a048 0x00000000 //DDRSS_PI_18_DATA 0x0f30a04c 0x00000000 //DDRSS_PI_19_DATA 0x0f30a050 0x00000000 //DDRSS_PI_20_DATA 0x0f30a054 0x00000000 //DDRSS_PI_21_DATA 0x0f30a058 0x00000000 //DDRSS_PI_22_DATA 0x0f30a05c 0x00000000 //DDRSS_PI_23_DATA 0x0f30a060 0x280d0001 //DDRSS_PI_24_DATA 0x0f30a064 0x00000000 //DDRSS_PI_25_DATA 0x0f30a068 0x00010000 //DDRSS_PI_26_DATA 0x0f30a06c 0x00003200 //DDRSS_PI_27_DATA 0x0f30a070 0x00000000 //DDRSS_PI_28_DATA 0x0f30a074 0x00000000 //DDRSS_PI_29_DATA 0x0f30a078 0x00060602 //DDRSS_PI_30_DATA 0x0f30a07c 0x00000000 //DDRSS_PI_31_DATA 0x0f30a080 0x00000000 //DDRSS_PI_32_DATA 0x0f30a084 0x00000000 //DDRSS_PI_33_DATA 0x0f30a088 0x00000001 //DDRSS_PI_34_DATA 0x0f30a08c 0x00000055 //DDRSS_PI_35_DATA 0x0f30a090 0x000000aa //DDRSS_PI_36_DATA 0x0f30a094 0x000000ad //DDRSS_PI_37_DATA 0x0f30a098 0x00000052 //DDRSS_PI_38_DATA 0x0f30a09c 0x0000006a //DDRSS_PI_39_DATA 0x0f30a0a0 0x00000095 //DDRSS_PI_40_DATA 0x0f30a0a4 0x00000095 //DDRSS_PI_41_DATA 0x0f30a0a8 0x000000ad //DDRSS_PI_42_DATA 0x0f30a0ac 0x00000000 //DDRSS_PI_43_DATA 0x0f30a0b0 0x00000000 //DDRSS_PI_44_DATA 0x0f30a0b4 0x00010100 //DDRSS_PI_45_DATA 0x0f30a0b8 0x00000014 //DDRSS_PI_46_DATA 0x0f30a0bc 0x000007d0 //DDRSS_PI_47_DATA 0x0f30a0c0 0x00000300 //DDRSS_PI_48_DATA 0x0f30a0c4 0x00000000 //DDRSS_PI_49_DATA 0x0f30a0c8 0x00000000 //DDRSS_PI_50_DATA 0x0f30a0cc 0x01000000 //DDRSS_PI_51_DATA 0x0f30a0d0 0x00010101 //DDRSS_PI_52_DATA 0x0f30a0d4 0x0100090c //DDRSS_PI_53_DATA 0x0f30a0d8 0x00000000 //DDRSS_PI_54_DATA 0x0f30a0dc 0x00010000 //DDRSS_PI_55_DATA 0x0f30a0e0 0x00000000 //DDRSS_PI_56_DATA 0x0f30a0e4 0x00000000 //DDRSS_PI_57_DATA 0x0f30a0e8 0x00000000 //DDRSS_PI_58_DATA 0x0f30a0ec 0x00000000 //DDRSS_PI_59_DATA 0x0f30a0f0 0x00001400 //DDRSS_PI_60_DATA 0x0f30a0f4 0x00000000 //DDRSS_PI_61_DATA 0x0f30a0f8 0x01000000 //DDRSS_PI_62_DATA 0x0f30a0fc 0x00000404 //DDRSS_PI_63_DATA 0x0f30a100 0x00000001 //DDRSS_PI_64_DATA 0x0f30a104 0x0001010e //DDRSS_PI_65_DATA 0x0f30a108 0x02040100 //DDRSS_PI_66_DATA 0x0f30a10c 0x00010000 //DDRSS_PI_67_DATA 0x0f30a110 0x00000034 //DDRSS_PI_68_DATA 0x0f30a114 0x00000000 //DDRSS_PI_69_DATA 0x0f30a118 0x00000000 //DDRSS_PI_70_DATA 0x0f30a11c 0x00000000 //DDRSS_PI_71_DATA 0x0f30a120 0x00000000 //DDRSS_PI_72_DATA 0x0f30a124 0x00000000 //DDRSS_PI_73_DATA 0x0f30a128 0x00000000 //DDRSS_PI_74_DATA 0x0f30a12c 0x00000005 //DDRSS_PI_75_DATA 0x0f30a130 0x01000000 //DDRSS_PI_76_DATA 0x0f30a134 0x04000100 //DDRSS_PI_77_DATA 0x0f30a138 0x00020000 //DDRSS_PI_78_DATA 0x0f30a13c 0x00010002 //DDRSS_PI_79_DATA 0x0f30a140 0x00000001 //DDRSS_PI_80_DATA 0x0f30a144 0x00020001 //DDRSS_PI_81_DATA 0x0f30a148 0x00020002 //DDRSS_PI_82_DATA 0x0f30a14c 0x29c02000 //DDRSS_PI_83_DATA 0x0f30a150 0x00000000 //DDRSS_PI_84_DATA 0x0f30a154 0x00000000 //DDRSS_PI_85_DATA 0x0f30a158 0x00000000 //DDRSS_PI_86_DATA 0x0f30a15c 0x00000000 //DDRSS_PI_87_DATA 0x0f30a160 0x00000000 //DDRSS_PI_88_DATA 0x0f30a164 0x00000000 //DDRSS_PI_89_DATA 0x0f30a168 0x00000000 //DDRSS_PI_90_DATA 0x0f30a16c 0x00000300 //DDRSS_PI_91_DATA 0x0f30a170 0x0a090b0c //DDRSS_PI_92_DATA 0x0f30a174 0x04060708 //DDRSS_PI_93_DATA 0x0f30a178 0x01000005 //DDRSS_PI_94_DATA 0x0f30a17c 0x00000800 //DDRSS_PI_95_DATA 0x0f30a180 0x00000000 //DDRSS_PI_96_DATA 0x0f30a184 0x00010008 //DDRSS_PI_97_DATA 0x0f30a188 0x00000000 //DDRSS_PI_98_DATA 0x0f30a18c 0x0000aa00 //DDRSS_PI_99_DATA 0x0f30a190 0x00000000 //DDRSS_PI_100_DATA 0x0f30a194 0x00010000 //DDRSS_PI_101_DATA 0x0f30a198 0x00000000 //DDRSS_PI_102_DATA 0x0f30a19c 0x00000000 //DDRSS_PI_103_DATA 0x0f30a1a0 0x00000000 //DDRSS_PI_104_DATA 0x0f30a1a4 0x00000000 //DDRSS_PI_105_DATA 0x0f30a1a8 0x00000000 //DDRSS_PI_106_DATA 0x0f30a1ac 0x00000000 //DDRSS_PI_107_DATA 0x0f30a1b0 0x00000000 //DDRSS_PI_108_DATA 0x0f30a1b4 0x00000000 //DDRSS_PI_109_DATA 0x0f30a1b8 0x00000000 //DDRSS_PI_110_DATA 0x0f30a1bc 0x00000000 //DDRSS_PI_111_DATA 0x0f30a1c0 0x00000000 //DDRSS_PI_112_DATA 0x0f30a1c4 0x00000000 //DDRSS_PI_113_DATA 0x0f30a1c8 0x00000000 //DDRSS_PI_114_DATA 0x0f30a1cc 0x00000000 //DDRSS_PI_115_DATA 0x0f30a1d0 0x00000000 //DDRSS_PI_116_DATA 0x0f30a1d4 0x00000000 //DDRSS_PI_117_DATA 0x0f30a1d8 0x00000000 //DDRSS_PI_118_DATA 0x0f30a1dc 0x00000000 //DDRSS_PI_119_DATA 0x0f30a1e0 0x00000000 //DDRSS_PI_120_DATA 0x0f30a1e4 0x00000000 //DDRSS_PI_121_DATA 0x0f30a1e8 0x00000000 //DDRSS_PI_122_DATA 0x0f30a1ec 0x00000000 //DDRSS_PI_123_DATA 0x0f30a1f0 0x00000008 //DDRSS_PI_124_DATA 0x0f30a1f4 0x00000000 //DDRSS_PI_125_DATA 0x0f30a1f8 0x00000000 //DDRSS_PI_126_DATA 0x0f30a1fc 0x00000000 //DDRSS_PI_127_DATA 0x0f30a200 0x00000000 //DDRSS_PI_128_DATA 0x0f30a204 0x00000000 //DDRSS_PI_129_DATA 0x0f30a208 0x00000000 //DDRSS_PI_130_DATA 0x0f30a20c 0x00000000 //DDRSS_PI_131_DATA 0x0f30a210 0x00000000 //DDRSS_PI_132_DATA 0x0f30a214 0x00010100 //DDRSS_PI_133_DATA 0x0f30a218 0x00000000 //DDRSS_PI_134_DATA 0x0f30a21c 0x00000000 //DDRSS_PI_135_DATA 0x0f30a220 0x00027100 //DDRSS_PI_136_DATA 0x0f30a224 0x00061a80 //DDRSS_PI_137_DATA 0x0f30a228 0x00000100 //DDRSS_PI_138_DATA 0x0f30a22c 0x00000000 //DDRSS_PI_139_DATA 0x0f30a230 0x00000000 //DDRSS_PI_140_DATA 0x0f30a234 0x00000000 //DDRSS_PI_141_DATA 0x0f30a238 0x00000000 //DDRSS_PI_142_DATA 0x0f30a23c 0x00000000 //DDRSS_PI_143_DATA 0x0f30a240 0x01000000 //DDRSS_PI_144_DATA 0x0f30a244 0xc1010003 //DDRSS_PI_145_DATA 0x0f30a248 0x02000101 //DDRSS_PI_146_DATA 0x0f30a24c 0x01030101 //DDRSS_PI_147_DATA 0x0f30a250 0x00010400 //DDRSS_PI_148_DATA 0x0f30a254 0x06000105 //DDRSS_PI_149_DATA 0x0f30a258 0x01070001 //DDRSS_PI_150_DATA 0x0f30a25c 0x00000000 //DDRSS_PI_151_DATA 0x0f30a260 0x00000000 //DDRSS_PI_152_DATA 0x0f30a264 0x00000001 //DDRSS_PI_153_DATA 0x0f30a268 0x00010000 //DDRSS_PI_154_DATA 0x0f30a26c 0x00000000 //DDRSS_PI_155_DATA 0x0f30a270 0x00000000 //DDRSS_PI_156_DATA 0x0f30a274 0x00000000 //DDRSS_PI_157_DATA 0x0f30a278 0x00000000 //DDRSS_PI_158_DATA 0x0f30a27c 0x00010000 //DDRSS_PI_159_DATA 0x0f30a280 0x00000004 //DDRSS_PI_160_DATA 0x0f30a284 0x00000000 //DDRSS_PI_161_DATA 0x0f30a288 0x00000000 //DDRSS_PI_162_DATA 0x0f30a28c 0x00000000 //DDRSS_PI_163_DATA 0x0f30a290 0x00007800 //DDRSS_PI_164_DATA 0x0f30a294 0x00780078 //DDRSS_PI_165_DATA 0x0f30a298 0x00141414 //DDRSS_PI_166_DATA 0x0f30a29c 0x0000003a //DDRSS_PI_167_DATA 0x0f30a2a0 0x0000003a //DDRSS_PI_168_DATA 0x0f30a2a4 0x0004003a //DDRSS_PI_169_DATA 0x0f30a2a8 0x04000400 //DDRSS_PI_170_DATA 0x0f30a2ac 0xc8040009 //DDRSS_PI_171_DATA 0x0f30a2b0 0x0400091c //DDRSS_PI_172_DATA 0x0f30a2b4 0x00091cc8 //DDRSS_PI_173_DATA 0x0f30a2b8 0x001cc804 //DDRSS_PI_174_DATA 0x0f30a2bc 0x00000118 //DDRSS_PI_175_DATA 0x0f30a2c0 0x00001860 //DDRSS_PI_176_DATA 0x0f30a2c4 0x00000118 //DDRSS_PI_177_DATA 0x0f30a2c8 0x00001860 //DDRSS_PI_178_DATA 0x0f30a2cc 0x00000118 //DDRSS_PI_179_DATA 0x0f30a2d0 0x04001860 //DDRSS_PI_180_DATA 0x0f30a2d4 0x01010404 //DDRSS_PI_181_DATA 0x0f30a2d8 0x00001901 //DDRSS_PI_182_DATA 0x0f30a2dc 0x00190019 //DDRSS_PI_183_DATA 0x0f30a2e0 0x010c010c //DDRSS_PI_184_DATA 0x0f30a2e4 0x0000010c //DDRSS_PI_185_DATA 0x0f30a2e8 0x00000000 //DDRSS_PI_186_DATA 0x0f30a2ec 0x05000000 //DDRSS_PI_187_DATA 0x0f30a2f0 0x01010505 //DDRSS_PI_188_DATA 0x0f30a2f4 0x01010101 //DDRSS_PI_189_DATA 0x0f30a2f8 0x00181818 //DDRSS_PI_190_DATA 0x0f30a2fc 0x00000000 //DDRSS_PI_191_DATA 0x0f30a300 0x00000000 //DDRSS_PI_192_DATA 0x0f30a304 0x0d000000 //DDRSS_PI_193_DATA 0x0f30a308 0x0a0a0d0d //DDRSS_PI_194_DATA 0x0f30a30c 0x0303030a //DDRSS_PI_195_DATA 0x0f30a310 0x00000000 //DDRSS_PI_196_DATA 0x0f30a314 0x00000000 //DDRSS_PI_197_DATA 0x0f30a318 0x00000000 //DDRSS_PI_198_DATA 0x0f30a31c 0x00000000 //DDRSS_PI_199_DATA 0x0f30a320 0x00000000 //DDRSS_PI_200_DATA 0x0f30a324 0x00000000 //DDRSS_PI_201_DATA 0x0f30a328 0x00000000 //DDRSS_PI_202_DATA 0x0f30a32c 0x00000000 //DDRSS_PI_203_DATA 0x0f30a330 0x00000000 //DDRSS_PI_204_DATA 0x0f30a334 0x00000000 //DDRSS_PI_205_DATA 0x0f30a338 0x00000000 //DDRSS_PI_206_DATA 0x0f30a33c 0x00000000 //DDRSS_PI_207_DATA 0x0f30a340 0x00000000 //DDRSS_PI_208_DATA 0x0f30a344 0x0d090000 //DDRSS_PI_209_DATA 0x0f30a348 0x0d09000d //DDRSS_PI_210_DATA 0x0f30a34c 0x0d09000d //DDRSS_PI_211_DATA 0x0f30a350 0x0000000d //DDRSS_PI_212_DATA 0x0f30a354 0x00000000 //DDRSS_PI_213_DATA 0x0f30a358 0x00000000 //DDRSS_PI_214_DATA 0x0f30a35c 0x00000000 //DDRSS_PI_215_DATA 0x0f30a360 0x00000000 //DDRSS_PI_216_DATA 0x0f30a364 0x16000000 //DDRSS_PI_217_DATA 0x0f30a368 0x001600c8 //DDRSS_PI_218_DATA 0x0f30a36c 0x001600c8 //DDRSS_PI_219_DATA 0x0f30a370 0x010100c8 //DDRSS_PI_220_DATA 0x0f30a374 0x00001b01 //DDRSS_PI_221_DATA 0x0f30a378 0x1f0f0053 //DDRSS_PI_222_DATA 0x0f30a37c 0x05000001 //DDRSS_PI_223_DATA 0x0f30a380 0x001b0a0d //DDRSS_PI_224_DATA 0x0f30a384 0x1f0f0053 //DDRSS_PI_225_DATA 0x0f30a388 0x05000001 //DDRSS_PI_226_DATA 0x0f30a38c 0x001b0a0d //DDRSS_PI_227_DATA 0x0f30a390 0x1f0f0053 //DDRSS_PI_228_DATA 0x0f30a394 0x05000001 //DDRSS_PI_229_DATA 0x0f30a398 0x00010a0d //DDRSS_PI_230_DATA 0x0f30a39c 0x0c0b0700 //DDRSS_PI_231_DATA 0x0f30a3a0 0x000d0605 //DDRSS_PI_232_DATA 0x0f30a3a4 0x0000c570 //DDRSS_PI_233_DATA 0x0f30a3a8 0x0000001d //DDRSS_PI_234_DATA 0x0f30a3ac 0x180a0800 //DDRSS_PI_235_DATA 0x0f30a3b0 0x0b071c1c //DDRSS_PI_236_DATA 0x0f30a3b4 0x0d06050c //DDRSS_PI_237_DATA 0x0f30a3b8 0x0000c570 //DDRSS_PI_238_DATA 0x0f30a3bc 0x0000001d //DDRSS_PI_239_DATA 0x0f30a3c0 0x180a0800 //DDRSS_PI_240_DATA 0x0f30a3c4 0x0b071c1c //DDRSS_PI_241_DATA 0x0f30a3c8 0x0d06050c //DDRSS_PI_242_DATA 0x0f30a3cc 0x0000c570 //DDRSS_PI_243_DATA 0x0f30a3d0 0x0000001d //DDRSS_PI_244_DATA 0x0f30a3d4 0x180a0800 //DDRSS_PI_245_DATA 0x0f30a3d8 0x00001c1c //DDRSS_PI_246_DATA 0x0f30a3dc 0x000030c0 //DDRSS_PI_247_DATA 0x0f30a3e0 0x0001e780 //DDRSS_PI_248_DATA 0x0f30a3e4 0x000030c0 //DDRSS_PI_249_DATA 0x0f30a3e8 0x0001e780 //DDRSS_PI_250_DATA 0x0f30a3ec 0x000030c0 //DDRSS_PI_251_DATA 0x0f30a3f0 0x0001e780 //DDRSS_PI_252_DATA 0x0f30a3f4 0x02550255 //DDRSS_PI_253_DATA 0x0f30a3f8 0x03030255 //DDRSS_PI_254_DATA 0x0f30a3fc 0x00025503 //DDRSS_PI_255_DATA 0x0f30a400 0x02550255 //DDRSS_PI_256_DATA 0x0f30a404 0x0c080c08 //DDRSS_PI_257_DATA 0x0f30a408 0x00000c08 //DDRSS_PI_258_DATA 0x0f30a40c 0x000890b8 //DDRSS_PI_259_DATA 0x0f30a410 0x00000000 //DDRSS_PI_260_DATA 0x0f30a414 0x00000000 //DDRSS_PI_261_DATA 0x0f30a418 0x00000000 //DDRSS_PI_262_DATA 0x0f30a41c 0x00000120 //DDRSS_PI_263_DATA 0x0f30a420 0x000890b8 //DDRSS_PI_264_DATA 0x0f30a424 0x00000000 //DDRSS_PI_265_DATA 0x0f30a428 0x00000000 //DDRSS_PI_266_DATA 0x0f30a42c 0x00000000 //DDRSS_PI_267_DATA 0x0f30a430 0x00000120 //DDRSS_PI_268_DATA 0x0f30a434 0x000890b8 //DDRSS_PI_269_DATA 0x0f30a438 0x00000000 //DDRSS_PI_270_DATA 0x0f30a43c 0x00000000 //DDRSS_PI_271_DATA 0x0f30a440 0x00000000 //DDRSS_PI_272_DATA 0x0f30a444 0x02000120 //DDRSS_PI_273_DATA 0x0f30a448 0x00000080 //DDRSS_PI_274_DATA 0x0f30a44c 0x00020000 //DDRSS_PI_275_DATA 0x0f30a450 0x00000080 //DDRSS_PI_276_DATA 0x0f30a454 0x00020000 //DDRSS_PI_277_DATA 0x0f30a458 0x00000080 //DDRSS_PI_278_DATA 0x0f30a45c 0x00000000 //DDRSS_PI_279_DATA 0x0f30a460 0x00000000 //DDRSS_PI_280_DATA 0x0f30a464 0x00040404 //DDRSS_PI_281_DATA 0x0f30a468 0x00000000 //DDRSS_PI_282_DATA 0x0f30a46c 0x02010102 //DDRSS_PI_283_DATA 0x0f30a470 0x67676767 //DDRSS_PI_284_DATA 0x0f30a474 0x00000202 //DDRSS_PI_285_DATA 0x0f30a478 0x00000000 //DDRSS_PI_286_DATA 0x0f30a47c 0x00000000 //DDRSS_PI_287_DATA 0x0f30a480 0x00000000 //DDRSS_PI_288_DATA 0x0f30a484 0x00000000 //DDRSS_PI_289_DATA 0x0f30a488 0x00000000 //DDRSS_PI_290_DATA 0x0f30a48c 0x0d100f00 //DDRSS_PI_291_DATA 0x0f30a490 0x0003020e //DDRSS_PI_292_DATA 0x0f30a494 0x00000001 //DDRSS_PI_293_DATA 0x0f30a498 0x01000000 //DDRSS_PI_294_DATA 0x0f30a49c 0x00020201 //DDRSS_PI_295_DATA 0x0f30a4a0 0x00000000 //DDRSS_PI_296_DATA 0x0f30a4a4 0x00000424 //DDRSS_PI_297_DATA 0x0f30a4a8 0x00000301 //DDRSS_PI_298_DATA 0x0f30a4ac 0x00000000 //DDRSS_PI_299_DATA 0x0f30a4b0 0x00000000 //DDRSS_PI_300_DATA 0x0f30a4b4 0x00000000 //DDRSS_PI_301_DATA 0x0f30a4b8 0x00001401 //DDRSS_PI_302_DATA 0x0f30a4bc 0x00000493 //DDRSS_PI_303_DATA 0x0f30a4c0 0x00000000 //DDRSS_PI_304_DATA 0x0f30a4c4 0x00000424 //DDRSS_PI_305_DATA 0x0f30a4c8 0x00000301 //DDRSS_PI_306_DATA 0x0f30a4cc 0x00000000 //DDRSS_PI_307_DATA 0x0f30a4d0 0x00000000 //DDRSS_PI_308_DATA 0x0f30a4d4 0x00000000 //DDRSS_PI_309_DATA 0x0f30a4d8 0x00001401 //DDRSS_PI_310_DATA 0x0f30a4dc 0x00000493 //DDRSS_PI_311_DATA 0x0f30a4e0 0x00000000 //DDRSS_PI_312_DATA 0x0f30a4e4 0x00000424 //DDRSS_PI_313_DATA 0x0f30a4e8 0x00000301 //DDRSS_PI_314_DATA 0x0f30a4ec 0x00000000 //DDRSS_PI_315_DATA 0x0f30a4f0 0x00000000 //DDRSS_PI_316_DATA 0x0f30a4f4 0x00000000 //DDRSS_PI_317_DATA 0x0f30a4f8 0x00001401 //DDRSS_PI_318_DATA 0x0f30a4fc 0x00000493 //DDRSS_PI_319_DATA 0x0f30a500 0x00000000 //DDRSS_PI_320_DATA 0x0f30a504 0x00000424 //DDRSS_PI_321_DATA 0x0f30a508 0x00000301 //DDRSS_PI_322_DATA 0x0f30a50c 0x00000000 //DDRSS_PI_323_DATA 0x0f30a510 0x00000000 //DDRSS_PI_324_DATA 0x0f30a514 0x00000000 //DDRSS_PI_325_DATA 0x0f30a518 0x00001401 //DDRSS_PI_326_DATA 0x0f30a51c 0x00000493 //DDRSS_PI_327_DATA 0x0f30a520 0x00000000 //DDRSS_PI_328_DATA 0x0f30a524 0x00000424 //DDRSS_PI_329_DATA 0x0f30a528 0x00000301 //DDRSS_PI_330_DATA 0x0f30a52c 0x00000000 //DDRSS_PI_331_DATA 0x0f30a530 0x00000000 //DDRSS_PI_332_DATA 0x0f30a534 0x00000000 //DDRSS_PI_333_DATA 0x0f30a538 0x00001401 //DDRSS_PI_334_DATA 0x0f30a53c 0x00000493 //DDRSS_PI_335_DATA 0x0f30a540 0x00000000 //DDRSS_PI_336_DATA 0x0f30a544 0x00000424 //DDRSS_PI_337_DATA 0x0f30a548 0x00000301 //DDRSS_PI_338_DATA 0x0f30a54c 0x00000000 //DDRSS_PI_339_DATA 0x0f30a550 0x00000000 //DDRSS_PI_340_DATA 0x0f30a554 0x00000000 //DDRSS_PI_341_DATA 0x0f30a558 0x00001401 //DDRSS_PI_342_DATA 0x0f30a55c 0x00000493 //DDRSS_PI_343_DATA 0x0f30a560 0x00000000 //DDRSS_PI_344_DATA data slice 0 0x0f30c000 0x04c00000 //DDRSS_PHY_0_DATA_F0_R0 0x0f30c004 0x00000000 //DDRSS_PHY_1_DATA_F0_R0 0x0f30c008 0x00000200 //DDRSS_PHY_2_DATA_F0_R0 0x0f30c00c 0x00000000 //DDRSS_PHY_3_DATA_F0_R0 0x0f30c010 0x00000000 //DDRSS_PHY_4_DATA_F0_R0 0x0f30c014 0x00000000 //DDRSS_PHY_5_DATA_F0_R0 0x0f30c018 0x00000000 //DDRSS_PHY_6_DATA_F0_R0 0x0f30c01c 0x00000000 //DDRSS_PHY_7_DATA_F0_R0 0x0f30c020 0x00000001 //DDRSS_PHY_8_DATA_F0_R0 0x0f30c024 0x00000000 //DDRSS_PHY_9_DATA_F0_R0 0x0f30c028 0x00000000 //DDRSS_PHY_10_DATA_F0_R0 0x0f30c02c 0x010101ff //DDRSS_PHY_11_DATA_F0_R0 0x0f30c030 0x00010000 //DDRSS_PHY_12_DATA_F0_R0 0x0f30c034 0x00c00004 //DDRSS_PHY_13_DATA_F0_R0 0x0f30c038 0x00cc0008 //DDRSS_PHY_14_DATA_F0_R0 0x0f30c03c 0x00660201 //DDRSS_PHY_15_DATA_F0_R0 0x0f30c040 0x00000000 //DDRSS_PHY_16_DATA_F0_R0 0x0f30c044 0x00000000 //DDRSS_PHY_17_DATA_F0_R0 0x0f30c048 0x00000000 //DDRSS_PHY_18_DATA_F0_R0 0x0f30c04c 0x0000aaaa //DDRSS_PHY_19_DATA_F0_R0 0x0f30c050 0x00005555 //DDRSS_PHY_20_DATA_F0_R0 0x0f30c054 0x0000b5b5 //DDRSS_PHY_21_DATA_F0_R0 0x0f30c058 0x00004a4a //DDRSS_PHY_22_DATA_F0_R0 0x0f30c05c 0x00005656 //DDRSS_PHY_23_DATA_F0_R0 0x0f30c060 0x0000a9a9 //DDRSS_PHY_24_DATA_F0_R0 0x0f30c064 0x0000b7b7 //DDRSS_PHY_25_DATA_F0_R0 0x0f30c068 0x00004848 //DDRSS_PHY_26_DATA_F0_R0 0x0f30c06c 0x00000000 //DDRSS_PHY_27_DATA_F0_R0 0x0f30c070 0x00000000 //DDRSS_PHY_28_DATA_F0_R0 0x0f30c074 0x08000000 //DDRSS_PHY_29_DATA_F0_R0 0x0f30c078 0x0f000008 //DDRSS_PHY_30_DATA_F0_R0 0x0f30c07c 0x00000f0f //DDRSS_PHY_31_DATA_F0_R0 0x0f30c080 0x00e4e400 //DDRSS_PHY_32_DATA_F0_R0 0x0f30c084 0x00070820 //DDRSS_PHY_33_DATA_F0_R0 0x0f30c088 0x000c0020 //DDRSS_PHY_34_DATA_F0_R0 0x0f30c08c 0x00062000 //DDRSS_PHY_35_DATA_F0_R0 0x0f30c090 0x00000000 //DDRSS_PHY_36_DATA_F0_R0 0x0f30c094 0x55555555 //DDRSS_PHY_37_DATA_F0_R0 0x0f30c098 0xaaaaaaaa //DDRSS_PHY_38_DATA_F0_R0 0x0f30c09c 0x55555555 //DDRSS_PHY_39_DATA_F0_R0 0x0f30c0a0 0xaaaaaaaa //DDRSS_PHY_40_DATA_F0_R0 0x0f30c0a4 0x00005555 //DDRSS_PHY_41_DATA_F0_R0 0x0f30c0a8 0x01000100 //DDRSS_PHY_42_DATA_F0_R0 0x0f30c0ac 0x00800180 //DDRSS_PHY_43_DATA_F0_R0 0x0f30c0b0 0x00000000 //DDRSS_PHY_44_DATA_F0_R0 0x0f30c0b4 0x00100000 //DDRSS_PHY_45_DATA_F0_R0 0x0f30c0b8 0x00000000 //DDRSS_PHY_46_DATA_F0_R0 0x0f30c0bc 0xc009000d //DDRSS_PHY_47_DATA_F0_R0 0x0f30c0c0 0x00000000 //DDRSS_PHY_48_DATA_F0_R0 0x0f30c0c4 0x00010500 //DDRSS_PHY_49_DATA_F0_R0 0x0f30c0c8 0x00000000 //DDRSS_PHY_50_DATA_F0_R0 0x0f30c0cc 0x00021cff //DDRSS_PHY_51_DATA_F0_R0 0x0f30c0d0 0x00000000 //DDRSS_PHY_52_DATA_F0_R0 0x0f30c0d4 0x00000000 //DDRSS_PHY_53_DATA_F0_R0 0x0f30c0d8 0x000000b1 //DDRSS_PHY_54_DATA_F0_R0 0x0f30c0dc 0x01cc0000 //DDRSS_PHY_55_DATA_F0_R0 0x0f30c0e0 0x00000000 //DDRSS_PHY_56_DATA_F0_R0 0x0f30c0e4 0x0c000000 //DDRSS_PHY_57_DATA_F0_R0 0x0f30c0e8 0x07ff0000 //DDRSS_PHY_58_DATA_F0_R0 0x0f30c0ec 0x00000000 //DDRSS_PHY_59_DATA_F0_R0 0x0f30c0f0 0x00000000 //DDRSS_PHY_60_DATA_F0_R0 0x0f30c0f4 0x00000000 //DDRSS_PHY_61_DATA_F0_R0 0x0f30c0f8 0x00000000 //DDRSS_PHY_62_DATA_F0_R0 0x0f30c0fc 0x00000000 //DDRSS_PHY_63_DATA_F0_R0 0x0f30c100 0x00000000 //DDRSS_PHY_64_DATA_F0_R0 0x0f30c104 0x00000004 //DDRSS_PHY_65_DATA_F0_R0 0x0f30c108 0x00000000 //DDRSS_PHY_66_DATA_F0_R0 0x0f30c10c 0x00000000 //DDRSS_PHY_67_DATA_F0_R0 0x0f30c110 0x00000000 //DDRSS_PHY_68_DATA_F0_R0 0x0f30c114 0x00000000 //DDRSS_PHY_69_DATA_F0_R0 0x0f30c118 0x00000000 //DDRSS_PHY_70_DATA_F0_R0 0x0f30c11c 0x00000000 //DDRSS_PHY_71_DATA_F0_R0 0x0f30c120 0x041f07ff //DDRSS_PHY_72_DATA_F0_R0 0x0f30c124 0x00000000 //DDRSS_PHY_73_DATA_F0_R0 0x0f30c128 0x01ccb001 //DDRSS_PHY_74_DATA_F0_R0 0x0f30c12c 0x2000ccb0 //DDRSS_PHY_75_DATA_F0_R0 0x0f30c130 0x20000140 //DDRSS_PHY_76_DATA_F0_R0 0x0f30c134 0x07ff0200 //DDRSS_PHY_77_DATA_F0_R0 0x0f30c138 0x0000dd01 //DDRSS_PHY_78_DATA_F0_R0 0x0f30c13c 0x10100303 //DDRSS_PHY_79_DATA_F0_R0 0x0f30c140 0x10101010 //DDRSS_PHY_80_DATA_F0_R0 0x0f30c144 0x10101010 //DDRSS_PHY_81_DATA_F0_R0 0x0f30c148 0x00021010 //DDRSS_PHY_82_DATA_F0_R0 0x0f30c14c 0x00100010 //DDRSS_PHY_83_DATA_F0_R0 0x0f30c150 0x00100010 //DDRSS_PHY_84_DATA_F0_R0 0x0f30c154 0x00100010 //DDRSS_PHY_85_DATA_F0_R0 0x0f30c158 0x00100010 //DDRSS_PHY_86_DATA_F0_R0 0x0f30c15c 0x02020010 //DDRSS_PHY_87_DATA_F0_R0 0x0f30c160 0x51515041 //DDRSS_PHY_88_DATA_F0_R0 0x0f30c164 0x31804000 //DDRSS_PHY_89_DATA_F0_R0 0x0f30c168 0x04800340 //DDRSS_PHY_90_DATA_F0_R0 0x0f30c16c 0x01008080 //DDRSS_PHY_91_DATA_F0_R0 0x0f30c170 0x04050001 //DDRSS_PHY_92_DATA_F0_R0 0x0f30c174 0x00000504 //DDRSS_PHY_93_DATA_F0_R0 0x0f30c178 0x42100010 //DDRSS_PHY_94_DATA_F0_R0 0x0f30c17c 0x010c053e //DDRSS_PHY_95_DATA_F0_R0 0x0f30c180 0x000f0c14 //DDRSS_PHY_96_DATA_F0_R0 0x0f30c184 0x01000140 //DDRSS_PHY_97_DATA_F0_R0 0x0f30c188 0x007a0120 //DDRSS_PHY_98_DATA_F0_R0 0x0f30c18c 0x00000c00 //DDRSS_PHY_99_DATA_F0_R0 0x0f30c190 0x000001cc //DDRSS_PHY_100_DATA_F0_R0 0x0f30c194 0x20100200 //DDRSS_PHY_101_DATA_F0_R0 0x0f30c198 0x00000005 //DDRSS_PHY_102_DATA_F0_R0 0x0f30c19c 0x76543210 //DDRSS_PHY_103_DATA_F0_R0 0x0f30c1a0 0x00000008 //DDRSS_PHY_104_DATA_F0_R0 0x0f30c1a4 0x02800280 //DDRSS_PHY_105_DATA_F0_R0 0x0f30c1a8 0x02800280 //DDRSS_PHY_106_DATA_F0_R0 0x0f30c1ac 0x02800280 //DDRSS_PHY_107_DATA_F0_R0 0x0f30c1b0 0x02800280 //DDRSS_PHY_108_DATA_F0_R0 0x0f30c1b4 0x00900280 //DDRSS_PHY_109_DATA_F0_R0 0x0f30c1b8 0x0000e600 //DDRSS_PHY_110_DATA_F0_R0 0x0f30c1bc 0x00e60000 //DDRSS_PHY_111_DATA_F0_R0 0x0f30c1c0 0x00e60000 //DDRSS_PHY_112_DATA_F0_R0 0x0f30c1c4 0x00e60000 //DDRSS_PHY_113_DATA_F0_R0 0x0f30c1c8 0x00e60000 //DDRSS_PHY_114_DATA_F0_R0 0x0f30c1cc 0x00e60000 //DDRSS_PHY_115_DATA_F0_R0 0x0f30c1d0 0x00e60000 //DDRSS_PHY_116_DATA_F0_R0 0x0f30c1d4 0x00e60000 //DDRSS_PHY_117_DATA_F0_R0 0x0f30c1d8 0x00e60000 //DDRSS_PHY_118_DATA_F0_R0 0x0f30c1dc 0x00000000 //DDRSS_PHY_119_DATA_F0_R0 0x0f30c1e0 0x01000000 //DDRSS_PHY_120_DATA_F0_R0 0x0f30c1e4 0x00000000 //DDRSS_PHY_121_DATA_F0_R0 0x0f30c1e8 0x00000000 //DDRSS_PHY_122_DATA_F0_R0 0x0f30c1ec 0x00080200 //DDRSS_PHY_123_DATA_F0_R0 0x0f30c1f0 0x00000000 //DDRSS_PHY_124_DATA_F0_R0 0x0f30c1f4 0x00000000 //DDRSS_PHY_125_DATA_F0_R0 data slice 1 0x0f30c400 0x04c00000 //DDRSS_PHY_256_DATA_F0_R0 0x0f30c404 0x00000000 //DDRSS_PHY_257_DATA_F0_R0 0x0f30c408 0x00000200 //DDRSS_PHY_258_DATA_F0_R0 0x0f30c40c 0x00000000 //DDRSS_PHY_259_DATA_F0_R0 0x0f30c410 0x00000000 //DDRSS_PHY_260_DATA_F0_R0 0x0f30c414 0x00000000 //DDRSS_PHY_261_DATA_F0_R0 0x0f30c418 0x00000000 //DDRSS_PHY_262_DATA_F0_R0 0x0f30c41c 0x00000000 //DDRSS_PHY_263_DATA_F0_R0 0x0f30c420 0x00000001 //DDRSS_PHY_264_DATA_F0_R0 0x0f30c424 0x00000000 //DDRSS_PHY_265_DATA_F0_R0 0x0f30c428 0x00000000 //DDRSS_PHY_266_DATA_F0_R0 0x0f30c42c 0x010101ff //DDRSS_PHY_267_DATA_F0_R0 0x0f30c430 0x00010000 //DDRSS_PHY_268_DATA_F0_R0 0x0f30c434 0x00c00004 //DDRSS_PHY_269_DATA_F0_R0 0x0f30c438 0x00cc0008 //DDRSS_PHY_270_DATA_F0_R0 0x0f30c43c 0x00660201 //DDRSS_PHY_271_DATA_F0_R0 0x0f30c440 0x00000000 //DDRSS_PHY_272_DATA_F0_R0 0x0f30c444 0x00000000 //DDRSS_PHY_273_DATA_F0_R0 0x0f30c448 0x00000000 //DDRSS_PHY_274_DATA_F0_R0 0x0f30c44c 0x0000aaaa //DDRSS_PHY_275_DATA_F0_R0 0x0f30c450 0x00005555 //DDRSS_PHY_276_DATA_F0_R0 0x0f30c454 0x0000b5b5 //DDRSS_PHY_277_DATA_F0_R0 0x0f30c458 0x00004a4a //DDRSS_PHY_278_DATA_F0_R0 0x0f30c45c 0x00005656 //DDRSS_PHY_279_DATA_F0_R0 0x0f30c460 0x0000a9a9 //DDRSS_PHY_280_DATA_F0_R0 0x0f30c464 0x0000b7b7 //DDRSS_PHY_281_DATA_F0_R0 0x0f30c468 0x00004848 //DDRSS_PHY_282_DATA_F0_R0 0x0f30c46c 0x00000000 //DDRSS_PHY_283_DATA_F0_R0 0x0f30c470 0x00000000 //DDRSS_PHY_284_DATA_F0_R0 0x0f30c474 0x08000000 //DDRSS_PHY_285_DATA_F0_R0 0x0f30c478 0x0f000008 //DDRSS_PHY_286_DATA_F0_R0 0x0f30c47c 0x00000f0f //DDRSS_PHY_287_DATA_F0_R0 0x0f30c480 0x00e4e400 //DDRSS_PHY_288_DATA_F0_R0 0x0f30c484 0x00070820 //DDRSS_PHY_289_DATA_F0_R0 0x0f30c488 0x000c0020 //DDRSS_PHY_290_DATA_F0_R0 0x0f30c48c 0x00062000 //DDRSS_PHY_291_DATA_F0_R0 0x0f30c490 0x00000000 //DDRSS_PHY_292_DATA_F0_R0 0x0f30c494 0x55555555 //DDRSS_PHY_293_DATA_F0_R0 0x0f30c498 0xaaaaaaaa //DDRSS_PHY_294_DATA_F0_R0 0x0f30c49c 0x55555555 //DDRSS_PHY_295_DATA_F0_R0 0x0f30c4a0 0xaaaaaaaa //DDRSS_PHY_296_DATA_F0_R0 0x0f30c4a4 0x00005555 //DDRSS_PHY_297_DATA_F0_R0 0x0f30c4a8 0x01000100 //DDRSS_PHY_298_DATA_F0_R0 0x0f30c4ac 0x00800180 //DDRSS_PHY_299_DATA_F0_R0 0x0f30c4b0 0x00000000 //DDRSS_PHY_300_DATA_F0_R0 0x0f30c4b4 0x00100000 //DDRSS_PHY_301_DATA_F0_R0 0x0f30c4b8 0x00000000 //DDRSS_PHY_302_DATA_F0_R0 0x0f30c4bc 0xc009000d //DDRSS_PHY_303_DATA_F0_R0 0x0f30c4c0 0x00000000 //DDRSS_PHY_304_DATA_F0_R0 0x0f30c4c4 0x00010500 //DDRSS_PHY_305_DATA_F0_R0 0x0f30c4c8 0x00000000 //DDRSS_PHY_306_DATA_F0_R0 0x0f30c4cc 0x00021cff //DDRSS_PHY_307_DATA_F0_R0 0x0f30c4d0 0x00000000 //DDRSS_PHY_308_DATA_F0_R0 0x0f30c4d4 0x00000000 //DDRSS_PHY_309_DATA_F0_R0 0x0f30c4d8 0x000000b1 //DDRSS_PHY_310_DATA_F0_R0 0x0f30c4dc 0x01cc0000 //DDRSS_PHY_311_DATA_F0_R0 0x0f30c4e0 0x00000000 //DDRSS_PHY_312_DATA_F0_R0 0x0f30c4e4 0x0c000000 //DDRSS_PHY_313_DATA_F0_R0 0x0f30c4e8 0x07ff0000 //DDRSS_PHY_314_DATA_F0_R0 0x0f30c4ec 0x00000000 //DDRSS_PHY_315_DATA_F0_R0 0x0f30c4f0 0x00000000 //DDRSS_PHY_316_DATA_F0_R0 0x0f30c4f4 0x00000000 //DDRSS_PHY_317_DATA_F0_R0 0x0f30c4f8 0x00000000 //DDRSS_PHY_318_DATA_F0_R0 0x0f30c4fc 0x00000000 //DDRSS_PHY_319_DATA_F0_R0 0x0f30c500 0x00000000 //DDRSS_PHY_320_DATA_F0_R0 0x0f30c504 0x00000004 //DDRSS_PHY_321_DATA_F0_R0 0x0f30c508 0x00000000 //DDRSS_PHY_322_DATA_F0_R0 0x0f30c50c 0x00000000 //DDRSS_PHY_323_DATA_F0_R0 0x0f30c510 0x00000000 //DDRSS_PHY_324_DATA_F0_R0 0x0f30c514 0x00000000 //DDRSS_PHY_325_DATA_F0_R0 0x0f30c518 0x00000000 //DDRSS_PHY_326_DATA_F0_R0 0x0f30c51c 0x00000000 //DDRSS_PHY_327_DATA_F0_R0 0x0f30c520 0x041f07ff //DDRSS_PHY_328_DATA_F0_R0 0x0f30c524 0x00000000 //DDRSS_PHY_329_DATA_F0_R0 0x0f30c528 0x01ccb001 //DDRSS_PHY_330_DATA_F0_R0 0x0f30c52c 0x2000ccb0 //DDRSS_PHY_331_DATA_F0_R0 0x0f30c530 0x20000140 //DDRSS_PHY_332_DATA_F0_R0 0x0f30c534 0x07ff0200 //DDRSS_PHY_333_DATA_F0_R0 0x0f30c538 0x0000dd01 //DDRSS_PHY_334_DATA_F0_R0 0x0f30c53c 0x10100303 //DDRSS_PHY_335_DATA_F0_R0 0x0f30c540 0x10101010 //DDRSS_PHY_336_DATA_F0_R0 0x0f30c544 0x10101010 //DDRSS_PHY_337_DATA_F0_R0 0x0f30c548 0x00021010 //DDRSS_PHY_338_DATA_F0_R0 0x0f30c54c 0x00100010 //DDRSS_PHY_339_DATA_F0_R0 0x0f30c550 0x00100010 //DDRSS_PHY_340_DATA_F0_R0 0x0f30c554 0x00100010 //DDRSS_PHY_341_DATA_F0_R0 0x0f30c558 0x00100010 //DDRSS_PHY_342_DATA_F0_R0 0x0f30c55c 0x02020010 //DDRSS_PHY_343_DATA_F0_R0 0x0f30c560 0x51515041 //DDRSS_PHY_344_DATA_F0_R0 0x0f30c564 0x31804000 //DDRSS_PHY_345_DATA_F0_R0 0x0f30c568 0x04800340 //DDRSS_PHY_346_DATA_F0_R0 0x0f30c56c 0x01008080 //DDRSS_PHY_347_DATA_F0_R0 0x0f30c570 0x04050001 //DDRSS_PHY_348_DATA_F0_R0 0x0f30c574 0x00000504 //DDRSS_PHY_349_DATA_F0_R0 0x0f30c578 0x42100010 //DDRSS_PHY_350_DATA_F0_R0 0x0f30c57c 0x010c053e //DDRSS_PHY_351_DATA_F0_R0 0x0f30c580 0x000f0c14 //DDRSS_PHY_352_DATA_F0_R0 0x0f30c584 0x01000140 //DDRSS_PHY_353_DATA_F0_R0 0x0f30c588 0x007a0120 //DDRSS_PHY_354_DATA_F0_R0 0x0f30c58c 0x00000c00 //DDRSS_PHY_355_DATA_F0_R0 0x0f30c590 0x000001cc //DDRSS_PHY_356_DATA_F0_R0 0x0f30c594 0x20100200 //DDRSS_PHY_357_DATA_F0_R0 0x0f30c598 0x00000005 //DDRSS_PHY_358_DATA_F0_R0 0x0f30c59c 0x76543210 //DDRSS_PHY_359_DATA_F0_R0 0x0f30c5a0 0x00000008 //DDRSS_PHY_360_DATA_F0_R0 0x0f30c5a4 0x02800280 //DDRSS_PHY_361_DATA_F0_R0 0x0f30c5a8 0x02800280 //DDRSS_PHY_362_DATA_F0_R0 0x0f30c5ac 0x02800280 //DDRSS_PHY_363_DATA_F0_R0 0x0f30c5b0 0x02800280 //DDRSS_PHY_364_DATA_F0_R0 0x0f30c5b4 0x00900280 //DDRSS_PHY_365_DATA_F0_R0 0x0f30c5b8 0x0000e600 //DDRSS_PHY_366_DATA_F0_R0 0x0f30c5bc 0x00e60000 //DDRSS_PHY_367_DATA_F0_R0 0x0f30c5c0 0x00e60000 //DDRSS_PHY_368_DATA_F0_R0 0x0f30c5c4 0x00e60000 //DDRSS_PHY_369_DATA_F0_R0 0x0f30c5c8 0x00e60000 //DDRSS_PHY_370_DATA_F0_R0 0x0f30c5cc 0x00e60000 //DDRSS_PHY_371_DATA_F0_R0 0x0f30c5d0 0x00e60000 //DDRSS_PHY_372_DATA_F0_R0 0x0f30c5d4 0x00e60000 //DDRSS_PHY_373_DATA_F0_R0 0x0f30c5d8 0x00e60000 //DDRSS_PHY_374_DATA_F0_R0 0x0f30c5dc 0x00000000 //DDRSS_PHY_375_DATA_F0_R0 0x0f30c5e0 0x01000000 //DDRSS_PHY_376_DATA_F0_R0 0x0f30c5e4 0x00000000 //DDRSS_PHY_377_DATA_F0_R0 0x0f30c5e8 0x00000000 //DDRSS_PHY_378_DATA_F0_R0 0x0f30c5ec 0x00080200 //DDRSS_PHY_379_DATA_F0_R0 0x0f30c5f0 0x00000000 //DDRSS_PHY_380_DATA_F0_R0 0x0f30c5f4 0x00000000 //DDRSS_PHY_381_DATA_F0_R0 addr slice 0 0x0f30c800 0x00000100 //DDRSS_PHY_512_DATA_F0 0x0f30c804 0x00001000 //DDRSS_PHY_513_DATA_F0 0x0f30c808 0x00090000 //DDRSS_PHY_514_DATA_F0 0x0f30c80c 0x00000000 //DDRSS_PHY_515_DATA_F0 0x0f30c810 0x00000000 //DDRSS_PHY_516_DATA_F0 0x0f30c814 0x00000100 //DDRSS_PHY_517_DATA_F0 0x0f30c818 0x00000000 //DDRSS_PHY_518_DATA_F0 0x0f30c81c 0x00000000 //DDRSS_PHY_519_DATA_F0 0x0f30c820 0x00000000 //DDRSS_PHY_520_DATA_F0 0x0f30c824 0x00000000 //DDRSS_PHY_521_DATA_F0 0x0f30c828 0x00000000 //DDRSS_PHY_522_DATA_F0 0x0f30c82c 0x00000000 //DDRSS_PHY_523_DATA_F0 0x0f30c830 0x00000000 //DDRSS_PHY_524_DATA_F0 0x0f30c834 0x00dcba98 //DDRSS_PHY_525_DATA_F0 0x0f30c838 0x00000000 //DDRSS_PHY_526_DATA_F0 0x0f30c83c 0x00000000 //DDRSS_PHY_527_DATA_F0 0x0f30c840 0x00000000 //DDRSS_PHY_528_DATA_F0 0x0f30c844 0x00000000 //DDRSS_PHY_529_DATA_F0 0x0f30c848 0x00000000 //DDRSS_PHY_530_DATA_F0 0x0f30c84c 0x00000100 //DDRSS_PHY_531_DATA_F0 0x0f30c850 0x00000000 //DDRSS_PHY_532_DATA_F0 0x0f30c854 0x00000000 //DDRSS_PHY_533_DATA_F0 0x0f30c858 0x00000000 //DDRSS_PHY_534_DATA_F0 0x0f30c85c 0x00000000 //DDRSS_PHY_535_DATA_F0 0x0f30c860 0x00000000 //DDRSS_PHY_536_DATA_F0 0x0f30c864 0x00000000 //DDRSS_PHY_537_DATA_F0 0x0f30c868 0x00000000 //DDRSS_PHY_538_DATA_F0 0x0f30c86c 0x00000000 //DDRSS_PHY_539_DATA_F0 0x0f30c870 0x0a418820 //DDRSS_PHY_540_DATA_F0 0x0f30c874 0x103f0000 //DDRSS_PHY_541_DATA_F0 0x0f30c878 0x000f0100 //DDRSS_PHY_542_DATA_F0 0x0f30c87c 0x0000000f //DDRSS_PHY_543_DATA_F0 0x0f30c880 0x020002cc //DDRSS_PHY_544_DATA_F0 0x0f30c884 0x00030000 //DDRSS_PHY_545_DATA_F0 0x0f30c888 0x00000300 //DDRSS_PHY_546_DATA_F0 0x0f30c88c 0x00000300 //DDRSS_PHY_547_DATA_F0 0x0f30c890 0x00000300 //DDRSS_PHY_548_DATA_F0 0x0f30c894 0x00000300 //DDRSS_PHY_549_DATA_F0 0x0f30c898 0x00000300 //DDRSS_PHY_550_DATA_F0 0x0f30c89c 0x42080010 //DDRSS_PHY_551_DATA_F0 0x0f30c8a0 0x0000003e //DDRSS_PHY_552_DATA_F0 0x0f30c8a4 0x00000000 //DDRSS_PHY_553_DATA_F0 0x0f30c8a8 0x00000000 //DDRSS_PHY_554_DATA_F0 data slice 1 0x0f30c900 0x00000000 //DDRSS_PHY_768_DATA_F0 0x0f30c904 0x00000000 //DDRSS_PHY_769_DATA_F0 0x0f30c908 0x00000000 //DDRSS_PHY_770_DATA_F0 0x0f30c90c 0x00000000 //DDRSS_PHY_771_DATA_F0 0x0f30c910 0x00000000 //DDRSS_PHY_772_DATA_F0 0x0f30c914 0x00000000 //DDRSS_PHY_773_DATA_F0 0x0f30c918 0x00000000 //DDRSS_PHY_774_DATA_F0 0x0f30c91c 0x00000000 //DDRSS_PHY_775_DATA_F0 0x0f30c920 0x00000000 //DDRSS_PHY_776_DATA_F0 0x0f30c924 0x00000000 //DDRSS_PHY_777_DATA_F0 0x0f30c928 0x00000000 //DDRSS_PHY_778_DATA_F0 0x0f30c92c 0x00000000 //DDRSS_PHY_779_DATA_F0 0x0f30c930 0x00000000 //DDRSS_PHY_780_DATA_F0 0x0f30c934 0x00000000 //DDRSS_PHY_781_DATA_F0 0x0f30c938 0x00000000 //DDRSS_PHY_782_DATA_F0 0x0f30c93c 0x00000000 //DDRSS_PHY_783_DATA_F0 0x0f30c940 0x00000000 //DDRSS_PHY_784_DATA_F0 0x0f30c944 0x00000000 //DDRSS_PHY_785_DATA_F0 0x0f30c948 0x00000000 //DDRSS_PHY_786_DATA_F0 0x0f30c94c 0x00000000 //DDRSS_PHY_787_DATA_F0 0x0f30c950 0x00000000 //DDRSS_PHY_788_DATA_F0 0x0f30c954 0x00000000 //DDRSS_PHY_789_DATA_F0 0x0f30c958 0x00000000 //DDRSS_PHY_790_DATA_F0 0x0f30c95c 0x00000000 //DDRSS_PHY_791_DATA_F0 0x0f30c960 0x00000000 //DDRSS_PHY_792_DATA_F0 0x0f30c964 0x00000000 //DDRSS_PHY_793_DATA_F0 0x0f30c968 0x00000000 //DDRSS_PHY_794_DATA_F0 0x0f30c96c 0x00000000 //DDRSS_PHY_795_DATA_F0 0x0f30c970 0x00000000 //DDRSS_PHY_796_DATA_F0 0x0f30c974 0x00000000 //DDRSS_PHY_797_DATA_F0 0x0f30c978 0x00000000 //DDRSS_PHY_798_DATA_F0 0x0f30c97c 0x00000000 //DDRSS_PHY_799_DATA_F0 0x0f30c980 0x00000000 //DDRSS_PHY_800_DATA_F0 0x0f30c984 0x00000000 //DDRSS_PHY_801_DATA_F0 0x0f30c988 0x00000000 //DDRSS_PHY_802_DATA_F0 0x0f30c98c 0x00000000 //DDRSS_PHY_803_DATA_F0 0x0f30c990 0x00000000 //DDRSS_PHY_804_DATA_F0 0x0f30c994 0x00000000 //DDRSS_PHY_805_DATA_F0 0x0f30c998 0x00000000 //DDRSS_PHY_806_DATA_F0 0x0f30c99c 0x00000000 //DDRSS_PHY_807_DATA_F0 0x0f30c9a0 0x00000000 //DDRSS_PHY_808_DATA_F0 0x0f30c9a4 0x00000000 //DDRSS_PHY_809_DATA_F0 0x0f30c9a8 0x00000000 //DDRSS_PHY_810_DATA_F0 data slice 2 0x0f30ca00 0x00000000 //DDRSS_PHY_1024_DATA_F0 0x0f30ca04 0x00000000 //DDRSS_PHY_1025_DATA_F0 0x0f30ca08 0x00000000 //DDRSS_PHY_1026_DATA_F0 0x0f30ca0c 0x00000000 //DDRSS_PHY_1027_DATA_F0 0x0f30ca10 0x00000000 //DDRSS_PHY_1028_DATA_F0 0x0f30ca14 0x00000000 //DDRSS_PHY_1029_DATA_F0 0x0f30ca18 0x00000000 //DDRSS_PHY_1030_DATA_F0 0x0f30ca1c 0x00000000 //DDRSS_PHY_1031_DATA_F0 0x0f30ca20 0x00000000 //DDRSS_PHY_1032_DATA_F0 0x0f30ca24 0x00000000 //DDRSS_PHY_1033_DATA_F0 0x0f30ca28 0x00000000 //DDRSS_PHY_1034_DATA_F0 0x0f30ca2c 0x00000000 //DDRSS_PHY_1035_DATA_F0 0x0f30ca30 0x00000000 //DDRSS_PHY_1036_DATA_F0 0x0f30ca34 0x00000000 //DDRSS_PHY_1037_DATA_F0 0x0f30ca38 0x00000000 //DDRSS_PHY_1038_DATA_F0 0x0f30ca3c 0x00000000 //DDRSS_PHY_1039_DATA_F0 0x0f30ca40 0x00000000 //DDRSS_PHY_1040_DATA_F0 0x0f30ca44 0x00000000 //DDRSS_PHY_1041_DATA_F0 0x0f30ca48 0x00000000 //DDRSS_PHY_1042_DATA_F0 0x0f30ca4c 0x00000000 //DDRSS_PHY_1043_DATA_F0 0x0f30ca50 0x00000000 //DDRSS_PHY_1044_DATA_F0 0x0f30ca54 0x00000000 //DDRSS_PHY_1045_DATA_F0 0x0f30ca58 0x00000000 //DDRSS_PHY_1046_DATA_F0 0x0f30ca5c 0x00000000 //DDRSS_PHY_1047_DATA_F0 0x0f30ca60 0x00000000 //DDRSS_PHY_1048_DATA_F0 0x0f30ca64 0x00000000 //DDRSS_PHY_1049_DATA_F0 0x0f30ca68 0x00000000 //DDRSS_PHY_1050_DATA_F0 0x0f30ca6c 0x00000000 //DDRSS_PHY_1051_DATA_F0 0x0f30ca70 0x00000000 //DDRSS_PHY_1052_DATA_F0 0x0f30ca74 0x00000000 //DDRSS_PHY_1053_DATA_F0 0x0f30ca78 0x00000000 //DDRSS_PHY_1054_DATA_F0 0x0f30ca7c 0x00000000 //DDRSS_PHY_1055_DATA_F0 0x0f30ca80 0x00000000 //DDRSS_PHY_1056_DATA_F0 0x0f30ca84 0x00000000 //DDRSS_PHY_1057_DATA_F0 0x0f30ca88 0x00000000 //DDRSS_PHY_1058_DATA_F0 0x0f30ca8c 0x00000000 //DDRSS_PHY_1059_DATA_F0 0x0f30ca90 0x00000000 //DDRSS_PHY_1060_DATA_F0 0x0f30ca94 0x00000000 //DDRSS_PHY_1061_DATA_F0 0x0f30ca98 0x00000000 //DDRSS_PHY_1062_DATA_F0 0x0f30ca9c 0x00000000 //DDRSS_PHY_1063_DATA_F0 0x0f30caa0 0x00000000 //DDRSS_PHY_1064_DATA_F0 0x0f30caa4 0x00000000 //DDRSS_PHY_1065_DATA_F0 0x0f30caa8 0x00000000 //DDRSS_PHY_1066_DATA_F0 0x0f30d400 0x00000000 //DDRSS_PHY_1280_DATA_F0 0x0f30d404 0x00000000 //DDRSS_PHY_1281_DATA_F0 0x0f30d408 0x00000000 //DDRSS_PHY_1282_DATA_F0 0x0f30d40c 0x00000000 //DDRSS_PHY_1283_DATA_F0 0x0f30d410 0x00000000 //DDRSS_PHY_1284_DATA_F0 0x0f30d414 0x00000000 //DDRSS_PHY_1285_DATA_F0 0x0f30d418 0x00050000 //DDRSS_PHY_1286_DATA_F0 0x0f30d41c 0x04000100 //DDRSS_PHY_1287_DATA_F0 0x0f30d420 0x00000055 //DDRSS_PHY_1288_DATA_F0 0x0f30d424 0x00000000 //DDRSS_PHY_1289_DATA_F0 0x0f30d428 0x06800000 //DDRSS_PHY_1290_DATA_F0 0x0f30d42c 0x00000000 //DDRSS_PHY_1291_DATA_F0 0x0f30d430 0x00000000 //DDRSS_PHY_1292_DATA_F0 0x0f30d434 0x01002000 //DDRSS_PHY_1293_DATA_F0 0x0f30d438 0x00004001 //DDRSS_PHY_1294_DATA_F0 0x0f30d43c 0x00020028 //DDRSS_PHY_1295_DATA_F0 0x0f30d440 0x00010100 //DDRSS_PHY_1296_DATA_F0 0x0f30d444 0x00000001 //DDRSS_PHY_1297_DATA_F0 0x0f30d448 0x00000000 //DDRSS_PHY_1298_DATA_F0 0x0f30d44c 0x0f0f0e06 //DDRSS_PHY_1299_DATA_F0 0x0f30d450 0x00010101 //DDRSS_PHY_1300_DATA_F0 0x0f30d454 0x010f0004 //DDRSS_PHY_1301_DATA_F0 0x0f30d458 0x00000000 //DDRSS_PHY_1302_DATA_F0 0x0f30d45c 0x20125770 //DDRSS_PHY_1303_DATA_F0 0x0f30d460 0x00000064 //DDRSS_PHY_1304_DATA_F0 0x0f30d464 0x00000000 //DDRSS_PHY_1305_DATA_F0 0x0f30d468 0x00000000 //DDRSS_PHY_1306_DATA_F0 0x0f30d46c 0x01020103 //DDRSS_PHY_1307_DATA_F0 0x0f30d470 0x03020102 //DDRSS_PHY_1308_DATA_F0 0x0f30d474 0x03030303 //DDRSS_PHY_1309_DATA_F0 0x0f30d478 0x03030303 //DDRSS_PHY_1310_DATA_F0 0x0f30d47c 0x00040000 //DDRSS_PHY_1311_DATA_F0 0x0f30d480 0x00005201 //DDRSS_PHY_1312_DATA_F0 0x0f30d484 0x00000003 //DDRSS_PHY_1313_DATA_F0 0x0f30d488 0x00010000 //DDRSS_PHY_1314_DATA_F0 0x0f30d48c 0x00000000 //DDRSS_PHY_1315_DATA_F0 0x0f30d490 0x00000003 //DDRSS_PHY_1316_DATA_F0 0x0f30d494 0x00010000 //DDRSS_PHY_1317_DATA_F0 0x0f30d498 0x00000000 //DDRSS_PHY_1318_DATA_F0 0x0f30d49c 0x07070001 //DDRSS_PHY_1319_DATA_F0 0x0f30d4a0 0x00005400 //DDRSS_PHY_1320_DATA_F0 0x0f30d4a4 0x000040a2 //DDRSS_PHY_1321_DATA_F0 0x0f30d4a8 0x00035991 //DDRSS_PHY_1322_DATA_F0 0x0f30d4ac 0x00015991 //DDRSS_PHY_1323_DATA_F0 0x0f30d4b0 0x00015991 //DDRSS_PHY_1324_DATA_F0 0x0f30d4b4 0x00015991 //DDRSS_PHY_1325_DATA_F0 0x0f30d4b8 0x00015991 //DDRSS_PHY_1326_DATA_F0 0x0f30d4bc 0x00015991 //DDRSS_PHY_1327_DATA_F0 0x0f30d4c0 0x0001591e //DDRSS_PHY_1328_DATA_F0 0x0f30d4c4 0x0001591e //DDRSS_PHY_1329_DATA_F0 0x0f30d4c8 0x00015991 //DDRSS_PHY_1330_DATA_F0 0x0f30d4cc 0x00015991 //DDRSS_PHY_1331_DATA_F0 0x0f30d4d0 0x00000000 //DDRSS_PHY_1332_DATA_F0 0x0f30d4d4 0x00000046 //DDRSS_PHY_1333_DATA_F0 0x0f30d4d8 0x00000400 //DDRSS_PHY_1334_DATA_F0 0x0f30d4dc 0x00000008 //DDRSS_PHY_1335_DATA_F0 0x0f30d4e0 0x00815991 //DDRSS_PHY_1336_DATA_F0 0x0f30d4e4 0x0081591e //DDRSS_PHY_1337_DATA_F0 0x0f30d4e8 0x00159910 //DDRSS_PHY_1338_DATA_F0 0x0f30d4ec 0x001591e8 //DDRSS_PHY_1339_DATA_F0 0x0f30d4f0 0x00f5991f //DDRSS_PHY_1340_DATA_F0 0x0f30d4f4 0x03f591ef //DDRSS_PHY_1341_DATA_F0 0x0f30d4f8 0x00000000 //DDRSS_PHY_1342_DATA_F0 0x0f30d4fc 0x00000000 //DDRSS_PHY_1343_DATA_F0 0x0f30d500 0xb3000000 //DDRSS_PHY_1344_DATA_F0 0x0f30d504 0x04102006 //DDRSS_PHY_1345_DATA_F0 0x0f30d508 0x00041020 //DDRSS_PHY_1346_DATA_F0 0x0f30d50c 0x01c98c98 //DDRSS_PHY_1347_DATA_F0 0x0f30d510 0x3f400000 //DDRSS_PHY_1348_DATA_F0 0x0f30d514 0x3f3f1f3f //DDRSS_PHY_1349_DATA_F0 0x0f30d518 0x0000001f //DDRSS_PHY_1350_DATA_F0 0x0f30d51c 0x00000000 //DDRSS_PHY_1351_DATA_F0 0x0f30d520 0x00000000 //DDRSS_PHY_1352_DATA_F0 0x0f30d524 0x00000000 //DDRSS_PHY_1353_DATA_F0 0x0f30d528 0x00000001 //DDRSS_PHY_1354_DATA_F0 0x0f30d52c 0x00000000 //DDRSS_PHY_1355_DATA_F0 0x0f30d530 0x00000000 //DDRSS_PHY_1356_DATA_F0 0x0f30d534 0x00000000 //DDRSS_PHY_1357_DATA_F0 0x0f30d538 0x00000000 //DDRSS_PHY_1358_DATA_F0 0x0f30d53c 0x76543210 //DDRSS_PHY_1359_DATA_F0 0x0f30d540 0x00000098 //DDRSS_PHY_1360_DATA_F0 0x0f30d544 0x00000000 //DDRSS_PHY_1361_DATA_F0 0x0f30d548 0x00000000 //DDRSS_PHY_1362_DATA_F0 0x0f30d54c 0x00000000 //DDRSS_PHY_1363_DATA_F0 0x0f30d550 0x00040700 //DDRSS_PHY_1364_DATA_F0 0x0f30d554 0x00000000 //DDRSS_PHY_1365_DATA_F0 0x0f30d558 0x00005898 //DDRSS_PHY_1366_DATA_F0 0x0f30d55c 0x00005898 //DDRSS_PHY_1367_DATA_F0 0x0f30d560 0x030f7102 //DDRSS_PHY_1368_DATA_F0 0x0f30d564 0x00000100 //DDRSS_PHY_1369_DATA_F0 0x0f30d568 0x00000000 //DDRSS_PHY_1370_DATA_F0 0x0f30d56c 0x0001f7c2 //DDRSS_PHY_1371_DATA_F0 0x0f30d570 0x00020002 //DDRSS_PHY_1372_DATA_F0 0x0f30d574 0x00000000 //DDRSS_PHY_1373_DATA_F0 0x0f30d578 0x00001142 //DDRSS_PHY_1374_DATA_F0 0x0f30d57c 0x03020400 //DDRSS_PHY_1375_DATA_F0 0x0f30d580 0x00000080 //DDRSS_PHY_1376_DATA_F0 0x0f30d584 0x03900390 //DDRSS_PHY_1377_DATA_F0 0x0f30d588 0x03900390 //DDRSS_PHY_1378_DATA_F0 0x0f30d58c 0x03900390 //DDRSS_PHY_1379_DATA_F0 0x0f30d590 0x03900390 //DDRSS_PHY_1380_DATA_F0 0x0f30d594 0x03900390 //DDRSS_PHY_1381_DATA_F0 0x0f30d598 0x03900390 //DDRSS_PHY_1382_DATA_F0 0x0f30d59c 0x00000300 //DDRSS_PHY_1383_DATA_F0 0x0f30d5a0 0x00000300 //DDRSS_PHY_1384_DATA_F0 0x0f30d5a4 0x00000300 //DDRSS_PHY_1385_DATA_F0 0x0f30d5a8 0x00000300 //DDRSS_PHY_1386_DATA_F0 0x0f30d5ac 0x31823fc7 //DDRSS_PHY_1387_DATA_F0 0x0f30d5b0 0x00000000 //DDRSS_PHY_1388_DATA_F0 0x0f30d5b4 0x0c000d3f //DDRSS_PHY_1389_DATA_F0 0x0f30d5b8 0x30000d3f //DDRSS_PHY_1390_DATA_F0 0x0f30d5bc 0x300d3f11 //DDRSS_PHY_1391_DATA_F0 0x0f30d5c0 0x01990000 //DDRSS_PHY_1392_DATA_F0 0x0f30d5c4 0x000d3fcc //DDRSS_PHY_1393_DATA_F0 0x0f30d5c8 0x00000c11 //DDRSS_PHY_1394_DATA_F0 0x0f30d5cc 0x300d3f11 //DDRSS_PHY_1395_DATA_F0 0x0f30d5d0 0x01990000 //DDRSS_PHY_1396_DATA_F0 0x0f30d5d4 0x300c3f11 //DDRSS_PHY_1397_DATA_F0 0x0f30d5d8 0x01990000 //DDRSS_PHY_1398_DATA_F0 0x0f30d5dc 0x300c3f11 //DDRSS_PHY_1399_DATA_F0 0x0f30d5e0 0x01990000 //DDRSS_PHY_1400_DATA_F0 0x0f30d5e4 0x300d3f11 //DDRSS_PHY_1401_DATA_F0 0x0f30d5e8 0x01990000 //DDRSS_PHY_1402_DATA_F0 0x0f30d5ec 0x300d3f11 //DDRSS_PHY_1403_DATA_F0 0x0f30d5f0 0x01990000 //DDRSS_PHY_1404_DATA_F0 0x0f30d5f4 0x20040004 //DDRSS_PHY_1405_DATA_F0 End of DDR Register Dump === DDR init returned success === === Checking get_ram_size() === Detected RAM: 0 MB === Comprehensive DDR Test === @0x80000000: wrote 0xa5a50000, read 0xa5a50000 PASS @0x81000000: wrote 0xa5a50001, read 0xa5a50001 PASS @0x82000000: wrote 0xa5a50002, read 0xa5a50002 PASS @0x84000000: wrote 0xa5a50003, read 0xa5a50003 PASS @0x88000000: wrote 0xa5a50004, read 0xa5a50004 PASS === Walking bits test @0x82000000 === Walking bits PASS === Address uniqueness test === Address 0x88000000 FAIL: expected 0x88000000, got 0xffffffff DDR test failed! resetting ...
