hello, I have a question. Can DM8168 encode B frame of H.264?the demos of OMTB in the sdk support encoding P and I frame,but has no B frame ,and I want to know how to configure the OMTB and OMX that can support B frame?
the script of 'omx getp 0 h264venc' get the useful data, but I don't kwon how to configure it ,could anybody help me?
OMTB> omx getp 0 h264venc
Template 0:
H264 Video Encoder Config Parameters:
OMX Component name............................OMX.TI.DUCATI.VIDENC
Input File name.............................../usr/share/ti/data/videos/CrowdRun_1080i25_420sp.yuv
Output File name............................../usr/share/ti/data/videos/CrowdRun_1080i25_420sp.264
Input Frame Width.............................1920
Input Frame Height............................1080
I/P Chroma Format.............................420SP
Data O/P Mode.................................file
Data I/P Mode.................................file
I/P Buffer allocation Mode....................allocate
Number of i/p buffer..........................6
I/p buffer alignment..........................0
Contiguous i/p buffer memory..................enable
I/P buffer size input from user...............enable
I/p buffer size...............................3110400
O/P Buffer allocation Mode....................allocate
Number of o/p buffer..........................6
O/p buffer alignment..........................0
Contiguous o/p buffer memory..................enable
O/P buffer size input from user...............enable
O/p buffer size...............................3110400
O/P Compression Format........................avc
I/P Stride (# of bytes per span of image).....0
Bitrate.......................................10485760
Frame rate....................................3932160
Max file size for OMTB demo...................536870912
File Reset Flag...............................enable
OMX_IndexConfigVideoFramerate Index Parameters:
OMX_IndexConfigVideoBitrate Index Parameters:
OMX_TI_IndexConfigVideoMESearchRange Index Parameters:
Motion vector accuracy........................quarterpel
ME Horizontal Search Range for P Frames.......16
ME Vertical Search Range for P Frames.........16
ME Horizontal Search Range for B Frames.......16
ME Vertical Search Range for B Frames.........16
OMX_IndexConfigVideoIntraVOPRefresh Index Parameters:
Intra Refresh VOP.............................disable
OMX_TI_IndexConfigVideoQPSettings Index Parameters:
QP for I frames...............................25
QP Max for I frames...........................51
QP Min for I frames...........................0
QP for P frames...............................25
QP Max for P frames...........................51
QP Min for P frames...........................0
QP offset for B frames........................4
QP Max for B frames...........................51
QP Min for B frames...........................0
OMX_IndexConfigVideoAVCIntraPeriod Index Parameters:
IDR period....................................128
P frames period...............................0
OMX_TI_IndexConfigSliceSettings Index Parameters:
Slice Mode Type...............................default
Slice Size....................................0
OMX_TI_IndexConfigVideoPixelInfo Index Parameters:
Input Pixel Width.............................0
Input Pixel Height............................0
OMX_TI_IndexParamVideoNALUsettings Index Parameters:
NALU Start of Sequence........................0
NALU End of Sequence..........................0
NALU IDR Frame #..............................0
NALU Intra Picture #..........................0
NALU Non Intra Picture #......................0
OMX_TI_IndexParamVideoAdvancedFMO Index Parameters:
FMO Num Slice Groups..........................0
FMO Slice Groups Map Type.....................0
FMO Slice Groups Change Direction.............raster
FMO Slice Groups Change Rate..................0
FMO Slice Groups Change Cycle.................0
FMO Slice Groups Param 0......................0
FMO Slice Groups Param 1......................0
OMX_TI_IndexParamVideoMEBlockSize Index Parameters:
ME Min Block Size - P Frame...................16x16
ME Min Block Size - B Frame...................16x16
OMX_IndexParamVideoIntraRefresh Index Parameters:
Intra Refresh Mode............................cyclic
# of Intra MBs to be Refreshed................0
# of times Motion marked MB be Intra Coded....0
# of Consecutive MBs to be Intra Coded........0
OMX_TI_IndexParamVideoVUIsettings Index Parameters:
VUI Aspect Ratio Present Flag.................disable
VUI Pixel Aspect Ratio........................none
VUI Pixel Value Full Range Flag...............disable
OMX_TI_IndexParamVideoIntraPredictionSettings Index Parameters:
Luma Intra 4x4 Pred Modes Enabled.............0
Luma Intra 8x8 Pred Modes Enabled.............0
Luma Intra 16x16 Pred Modes Enabled...........0
Chroma Intra 8x8 Pred Modes Enabled...........0
Chroma Intra Component........................cr_only
OMX_TI_IndexParamVideoDataSyncMode Index Parameters:
Video Data Mode...............................fixed_length
Video Num Data Units..........................0
OMX_IndexConfigVideoNalSize Index Parameters:
NAL bytes .....................................0
OMX_IndexParamVideoAvc Index Parameters:
Num MBs Between Slice Header..................0
Max # of P Frames between each I Frames.......1
Max # of B Frames between each I Frames.......1
Hadamard Transform............................disable
# of Refrence Frames..........................0
Refrence Index in Bwd Frames list.............0
Refrence Index in Fwd Frames list.............0
Unequal Error Protection......................disable
Flexible Macroblock Ordering..................disable
Arbitrary Slice Ordering......................disable
Redundant Slices..............................disable
AVC Profile...................................high
AVC Level.....................................4.1
Picture Types Allowed In Bitstream............0
Frame MBs Only................................disable
Frame Field MB Switching......................disable
CABAC.........................................disable
Weighted Prediction for P frames..............disable
Weighted Biprediciton Mode....................0
Constrained Intra Prediction..................disable
Luma Motion Vector Method for B Frames........disable
Spatial/Temporal mode for B Frame Coding......disable
CABAC Context Init Index......................0
Loop Filter Mode..............................enable
OMX_IndexParamVideoBitrate Index Parameters:
Param Bitrate.................................30000000
Param Rate Control Algorithm..................variable
OMX_IndexParamVideoProfileLevelCurrent Index Parameters:
Profile.......................................high
Level.........................................4.1
OMX_TI_IndexParamVideoBitStreamFormatSelect Index Parameters:
Bitstream Format..............................byte
OMX_TI_IndexParamVideoEncoderPreset Index Parameters:
Encoder Preset................................userdef
Rate Control Preset...........................msmq
OMX_TI_IndexParamVideoFrameDataContentSettings Index Parameters:
Input Content Type............................progressive
Interlace Coding Type.........................picaff
OMX_TI_IndexParamVideoTransformBlockSize Index Parameters:
Transform Block Size..........................8x8
OMX_IndexParamVideoSliceFMO Index Parameters:
Num Slice Group...............................0
Slice Group map type..........................0
OMX_IndexParamVideoMotionVector Index Parameters:
Unrestricted Motion Vector....................disable
Four Motion Vectors...........................disable
Motion Vector X Search Range .................16
Motion Vector Y Search Range .................16
OMX_TI_IndexParamBuffMemType Index Parameters:
Buffer Memory Type............................default
OMX_IndexParamCompBufferSupplier Index Parameters:
Buffer Supplier Type..........................unspecified
OMX_IndexParamVideoInit Index Parameters:
Number of i/p + o/p Ports ....................2
Start Port Number ............................0
OMX_IndexParamVideoPortFormat Index Parameters:
Compression Format............................avc
Color Format..................................420SP
OMX_IndexParamVideoQuantization Index Parameters:
QP for B frames...............................4
OMX_TI_IndexParamCompPortNotifyType Index Parameters:
Comp Port Notify Type.........................always
OMX_IndexParamPortDefinition Index Parameters:
Port Direction................................input
Buffer Count Actual...........................6
Buffer Count Min..............................1
Buffer Size...................................3110400
Port Default Status...........................enable
Port Populated................................disable
Domain........................................video
Buffers Contiguous............................disable
Buffer Alignment..............................128
MIME Type.....................................¤
Native Render.................................0
Frame Width...................................1920
Frame Height..................................1080
Stride........................................1920
Slice Height..................................0
Bit Rate......................................10000000
Frame Rate....................................60000
Flag Error Concealment........................disable
Compression Format............................unused
Native Window.................................0
OMX_TI_IndexConfigChannelName Index Parameters:
Frame Queue Channel name......................NULL
OK
