What is the minimum line width supported by CSI2Rx? We are using the the driver from J721S Linux SDK for a custom TDA4VL-Q1 board.
Thank you,
Jin
The CSI2-RX is a MIPI D-PHY interface meaning its impedance requirements are 100-ohm differential (loosely) and 50-ohm single-ended. The required trace width for that impedance is driven by the PCB stack-up and PCB manufacturer. Minimum trace width is controlled by the PCB manufacturer.
Hi Robert,
Sorry for confusion I meant in the context of the CSI2 frame - i.e. the minimum number of bytes per line.
