Oops in ti81xxvid_main.c in vidioc_streamon()
I am on a 8148 EVM using Linux PSP 04.01.00.07.
If one opens /dev/video1 as a display device and neglects to do a VIDIOC_REQBUFS ioctl before performing a VIDIOC_STREAMON ioctl, one gets an Oops from the kernel.
The ti81xxvo module should be more robust than this.
Specifically, the value of (&vout->dma_queue)->next is NULL when VIDIOC_REQBUFS has not been invoked and this expression should be checked for validity before it is used in vidioc_streamon().
bob
  • Bob,
    without calling VIDIOC_REQBUFS, v4l2 display will not work. but driver should not cause Oops.
    It is a very good capture, driver should have taken care this. we will fix this in the next release.
    yihe
  • Yihe,
    Thanks for the quick response. Thanks for pointing out that a STREAMON without a REQBUFS is pretty useless...I should have saved you the trouble of pointing that out in my original note as I knew I was being a Bad Dog in doing so.
    bob
