Part Number: TDA4VH-Q1
Hello TI Expert,
My application is currently running fine and streaming at a stable 30 FPS over the DisplayPort (DP) using a Display Node. Now, I want to add Pause and Resume functionality.
Expected Behavior:
- When paused, the display should go blank.
- When resumed, the video stream should continue on the DP port.
What I Tried:
I attempted to use TI Display-related deinit and init functions to stop and restart the display. However:
- This approach does not work at runtime.
- Re-initialization takes noticeable time, which is not practical for a smooth pause/resume experience.
My Question:
- Is there a way to blank the DP screen and then re-render the stream when needed, without full reinitialization?
If you have any example or reference, please share.
OR
- Should I create a black color-filled
vx_imageand render it during pause?
thanks,
Sai.
