Part Number: SM320VC5421-EP
Other Parts Discussed in Thread: CCSTUDIO
Which version of code composer studio supports the programming of the SM320VC5421-EP using a Blackhawk USB560 v2 System trace emulator?
The sequence below lists the procedure that I am trying to reproduce. This was written for CCS version 3.1 (I have v3.3 as only one available) running on Windows XP, with a Spectrum Digital XDS510USB (I have a TI XDS510-USB2.0 as Spectrum not available). When I try to run I get an error 0x80002240/-1047 :-
**Emulator Test **
$$ EmuProductName=XDS510USB
$$ EmuPortAddr=0x510
$$ EmuPortMode=USB
$$ ProductId=510
$$ ProductVersion=84
If it does not work you will see something like:
XDS510-USB Emulator not connected/enumerated
(because we're using a dual-core part)
I see several references to Flashburn, which was an old tool for programming external flash on older TI DSPs.
Looking at the Flashburn website it looks like there is a version that supports CCS version 4-6:
https://teamsds.com/flashburn/
CCS v5.5 is the last version of CCS to support C54x. It also has support the Blackhawk XDS560v2 debug probe. That is likely your best bet.
https://www.ti.com/tool/download/CCSTUDIO/5.5.0.00077
While the latest version of Windows supported by the version is Windows 7, I have successfully used it with WIndows 10.
ki
