Question about capture-display?
Hi, all:
I try to evm the EVM board by testing it function capture-display loopback.
After reading
http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/t/153145.aspx#554472
I known I should use v4l2 driver to run the saLoopBack, but it fail
root@dm816x-evm:/usr/share/videobin# ./saLoopBack
VPSS_GRPX : please stop grpx0 before continue.
failed to open capture device
Error in opening capture device for channel 0
root@dm816x-evm:/usr/share/videobin# lsmod
Module Size Used by
bufferclass_ti 4946 0
omaplfb 10794 0
pvrsrvkm 155450 2 bufferclass_ti,omaplfb
ti81xxhdmi 14478 0
ti81xxvin 20364 0
tvp7002 6405 0
ti81xxvo 20143 0
ti81xxfb 21771 1
vpss 72346 5 omaplfb,ti81xxhdmi,ti81xxvin,ti81xxvo,ti81xxfb
syslink 1113011 0
ipv6 209855 12
root@dm816x-evm:/usr/share/videobin# ls /dev/video*
/dev/video1 /dev/video2 /dev/video3
It seem there is no file "/dev/video0"
Should I use the mknod command to create the file by hand?
Anthoer question is how to demo the capture-display function by open-max ?
I try a omtb script but it seems not work, it is below:
#omx omtb_dbg_lvl 0x00
#omx omtb_dbg_lvl 0x04
#omx omtb_dbg_lvl 0x08
#omx omtb_dbg_lvl 0x10
#omx omtb_dbg_lvl 0x80
omx api init
omx setp 0 vfcc compname OMX.TI.VPSSM3.VFCC
omx setp 0 tvp compname OMX.TI.VPSSM3.CTRL.TVP
omx setp 0 dc insmod_hdmi disable
#I/P Port or O/P Port Params for VFCC
omx setp 0 vfcc numoutbuf 6
omx setp 0 vfcc frame_width 1920
omx setp 0 vfcc frame_height 1080
omx setp 0 vfcc op_chromat_format 420SP
omx setp 0 vfcc outbufalign 0
omx setp 0 vfcc outbuf_contig disable
omx setp 0 vfcc outbufsize 3110400
omx setp 0 vfcc data_opmode driver
omx setp 0 vfcc outbuf allocate
omx setp 0 vfcc outbufsize_flag disable
omx setp 0 dei frame_width 1920
omx setp 0 dei frame_height 1080
omx setp 0 dei op_chromat_format 420SP
omx setp 0 dei ip_chromat_format 420SP
omx setp 0 dei numinbuf 6
omx setp 0 dei inbufalign 0
omx setp 0 dei inbuf_contig disable
omx setp 0 dei inbufsize_flag disable
omx setp 0 dei inbufsize 3110400
omx setp 0 dei numoutbuf 8
omx setp 0 dei outbufalign 0
omx setp 0 dei outbuf_contig disable
omx setp 0 dei outbufsize_flag enable
omx setp 0 dei outbufsize 4147200
omx setp 0 dei data_opmode driver
omx setp 0 dei inbuf use
omx setp 0 dei outbuf allocate
omx setp 0 vfdc frame_width 1920
omx setp 0 vfdc frame_height 1080
omx setp 0 vfdc ip_chromat_format 422YUYV
omx setp 0 vfdc numinbuf 8
omx setp 0 vfdc inbufalign 0
omx setp 0 vfdc inbuf_contig disable
omx setp 0 vfdc inbufsize 4147200
omx setp 0 vfdc inbuf use
omx setp 0 vfdc graphics_flag disable
#omx setp 0 vfdc vcdemo_flag enable
omx setp 0 vfdc mosaic_window_config vs
omx api gethandle tvp 0 0
omx api gethandle vfcc 0 0
omx api gethandle dei 0 0
omx api gethandle vfdc 0 0
omx api gethandle dc 0 0
#SET ALL THE PARAMS FOR TVP
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortID eHwPortId vip1_porta
omx api setparam tvp 0 0 0 OMX_TI_IndexParamVFCCHwPortID
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties eCaptMode sc_non_mux
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties eVifMode 16_bit
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties eInColorFormat 422YUYV
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties eScanType progressive
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties nMaxWidth 1920
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties nMaxHeight 1080
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties nMaxChnlsPerHwPort 1
omx api setparam tvp 0 0 0 OMX_TI_IndexParamVFCCHwPortProperties
omx setp 0 tvp OMX_TI_IndexParamCTRLVidDecInfo videoStandard 1080P60
omx setp 0 tvp OMX_TI_IndexParamCTRLVidDecInfo videoDecoderId tvp7002
omx setp 0 tvp OMX_TI_IndexParamCTRLVidDecInfo videoSystemId auto_detect
omx api setparam tvp 0 0 0 OMX_TI_IndexParamCTRLVidDecInfo
#SET ALL THE PARAMS FOR VFCC
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortID eHwPortId vip1_porta
omx api setparam vfcc 0 0 0 OMX_TI_IndexParamVFCCHwPortID
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties eCaptMode sc_non_mux
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties eVifMode 16_bit
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties eInColorFormat 422YUYV
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties eScanType progressive
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties nMaxWidth 1920
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties nMaxHeight 1080
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties nMaxChnlsPerHwPort 1
omx api setparam vfcc 0 0 0 OMX_TI_IndexParamVFCCHwPortProperties
omx setp 0 vfcc OMX_TI_IndexParamBuffMemType eBufMemoryType default
omx api setparam vfcc 0 0 0 OMX_TI_IndexParamBuffMemType
omx setp 0 vfcc OMX_IndexParamCompBufferSupplier eBufferSupplier unspecified
#omx api setparam vfcc 0 0 0 OMX_IndexParamCompBufferSupplier
omx setp 0 vfcc OMX_TI_IndexConfigVFCCFrameSkip frameSkipMask 0
#omx api setconfig vfcc 0 0 0 OMX_TI_IndexConfigVFCCFrameSkip
omx setp 0 vfcc OMX_IndexParamVideoInit nPorts 16
omx setp 0 vfcc OMX_IndexParamVideoInit nStartPortNumber 0
#omx api setparam vfcc 0 0 0 OMX_IndexParamVideoInit
omx setp 0 dei OMX_TI_IndexParamVFPCNumChPerHandle nNumChannelsPerHandle 1
omx api setparam dei 0 0 0 OMX_TI_IndexParamVFPCNumChPerHandle
omx setp 0 dei OMX_TI_IndexConfigAlgEnable bAlgBypass enable
omx setp 0 dei OMX_TI_IndexConfigAlgEnable nChId 0
omx api setconfig dei 0 0 0 OMX_TI_IndexConfigAlgEnable
omx setp 0 dei OMX_TI_IndexConfigSubSamplingFactor nSubSamplingFactor 1
omx api setconfig dei 0 0 0 OMX_TI_IndexConfigSubSamplingFactor
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm0Width 1920
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm0Height 1080
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm0Pitch 1920
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Width 0
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Height 0
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Pitch 0
omx setp 0 dei OMX_TI_IndexConfigVidChResolution FrmStartX 0
omx setp 0 dei OMX_TI_IndexConfigVidChResolution FrmStartY 0
omx setp 0 dei OMX_TI_IndexConfigVidChResolution FrmCropWidth 1920
omx setp 0 dei OMX_TI_IndexConfigVidChResolution FrmCropHeight 1080
omx setp 0 dei OMX_TI_IndexConfigVidChResolution eDir input
omx setp 0 dei OMX_TI_IndexConfigVidChResolution nChId 0
omx api setconfig dei 0 0 0 OMX_TI_IndexConfigVidChResolution
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm0Pitch 3840
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Width 1920
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Height 1080
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Pitch 1920
omx setp 0 dei OMX_TI_IndexConfigVidChResolution eDir output
omx api setconfig dei 0 0 16 OMX_TI_IndexConfigVidChResolution
omx setp 0 dei OMX_TI_IndexParamBuffMemType eBufMemoryType default
omx api setparam dei 0 0 0 OMX_TI_IndexParamBuffMemType
omx api setparam dei 0 0 16 OMX_TI_IndexParamBuffMemType
omx api setparam dei 0 0 17 OMX_TI_IndexParamBuffMemType
omx setp 0 dei OMX_TI_IndexParamCompPortNotifyType eNotifyType always
#omx api setparam dei 0 0 0 OMX_TI_IndexParamCompPortNotifyType
#omx api setparam dei 0 0 16 OMX_TI_IndexParamCompPortNotifyType
#omx api setparam dei 0 0 17 OMX_TI_IndexParamCompPortNotifyType
omx setp 0 dei OMX_IndexParamCompBufferSupplier eBufferSupplier unspecified
omx setp 0 dei OMX_IndexParamVideoInit nPorts 3
omx setp 0 dei OMX_IndexParamVideoInit nStartPortNumber 0
omx api getparam dei 0 0 0 OMX_IndexParamPortDefinition
omx setp 0 dei OMX_IndexParamPortDefinition video.nStride 1920
omx api setparam dei 0 0 0 OMX_IndexParamPortDefinition
omx setp 0 vfdc OMX_TI_IndexParamVFDCDriverInstId nDrvInstID 0
omx setp 0 vfdc OMX_TI_IndexParamVFDCDriverInstId eDispVencMode 1080p60
omx api setparam vfdc 0 0 0 OMX_TI_IndexParamVFDCDriverInstId
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout winStartX 0
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout winStartY 0
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout winWidth 1920
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout winHeight 1080
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout pitch.VFDC_YUV_INT_ADDR_IDX 3840
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout pitch.VFDC_YUV_SP_Y_ADDR_IDX 3840
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout pitch.VFDC_YUV_SP_CBCR_ADDR_IDX 3840
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout dataFormat 422I_YUYV
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout bpp bits16
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout priority 0
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout nLayoutId 0
omx setp 0 vfdc mosaicNumRows 1
omx setp 0 vfdc mosaicNumCols 1
omx setp 0 vfdc mosaicDispWindowWidth 1920
omx setp 0 vfdc mosaicDispWindowHeight 1080
omx api setparam vfdc 0 0 0 OMX_TI_IndexParamVFDCCreateMosaicLayout
omx setp 0 vfdc OMX_TI_IndexConfigVFDCMosaicPort2WinMap nLayoutId 0
omx api setconfig vfdc 0 0 0 OMX_TI_IndexConfigVFDCMosaicPort2WinMap 1 0
omx setp 0 vfdc OMX_TI_IndexParamBuffMemType eBufMemoryType default
omx setp 0 vfdc OMX_IndexParamCompBufferSupplier eBufferSupplier unspecified
omx setp 0 vfdc OMX_IndexParamVideoInit nPorts 1
omx setp 0 vfdc OMX_IndexParamVideoInit nStartPortNumber 0
omx api getparam vfdc 0 0 0 OMX_IndexParamPortDefinition
omx setp 0 vfdc OMX_IndexParamPortDefinition video.nStride 3840
omx api setparam vfdc 0 0 0 OMX_IndexParamPortDefinition
#SET ALL THE PARAMS FOR DC#0
omx setp 0 dc OMX_TI_IndexParamVFDCDriverInstId nDrvInstID 0
omx setp 0 dc OMX_TI_IndexParamVFDCDriverInstId eDispVencMode 1080p60
omx api setparam dc 0 0 0 OMX_TI_IndexParamVFDCDriverInstId
omx api sendcommand port vfcc 0 enable 0
omx api sendcommand port vfcc 0 waitforsem 0
omx api sendcommand port dei 0 enable 0
omx api sendcommand port dei 0 waitforsem 0
omx api sendcommand port dei 0 enable 16
omx api sendcommand port dei 0 waitforsem 16
omx api sendcommand port dei 0 enable 17
omx api sendcommand port dei 0 waitforsem 17
omx api sendcommand port vfdc 0 enable 0
omx api sendcommand port vfdc 0 waitforsem 0
omx api connect vfcc 0 0 dei 0 0
omx api connect dei 0 16 vfdc 0 0
omx api sendcommand state vfcc 0 idle
omx api sendcommand state vfcc 0 waitforsem
omx api sendcommand state tvp 0 idle
omx api sendcommand state tvp 0 waitforsem
omx api sendcommand state dei 0 idle
omx api sendcommand state dei 0 waitforsem
omx api sendcommand state dc 0 idle
omx api sendcommand state dc 0 waitforsem
omx api sendcommand state vfdc 0 idle
omx api sendcommand state vfdc 0 waitforsem
omx api sendcommand state dc 0 exec
omx api sendcommand state vfdc 0 exec
omx api sendcommand state vfcc 0 exec
omx api sendcommand state dei 0 exec
omx api sendcommand state tvp 0 exec
sleep 900000
omx api sendcommand state vfcc 0 loaded
omx api sendcommand state tvp 0 loaded
omx api sendcommand state dei 0 loaded
omx api sendcommand state dc 0 loaded
omx api sendcommand state vfdc 0 loaded
omx api freehandle vfcc 0
omx api freehandle tvp 0
omx api freehandle dei 0
omx api freehandle dc 0
omx api freehandle vfdc 0
omx api freehandle h264venc 0
omx api uninit
I need your help!Thanks.
