Ran into issues fetching edgeai-gst-plugins in my Yocto SDK build. The build failed when attempting to fetch the source (log appended). Some notes:
- meta-edgeai is pulled via oe-layertool-setup.sh, with config line
meta-edgeai,git.ti.com/.../meta-edgeai.git,scarthgap,81d1b80b2a314814c6d900e82ea2da93eee3f57d,layers= - Log indicates the board is pulling its repo config from ref
refs/tags/REL.PSDK.ANALYTICS.11.00.00.06on repo https://git.ti.com/git/processor-sdk/psdk_repo_manifests.git - Both logs and that repo indicate that the code is attempting (and failing) to pull from tag
REL.PSDK.ANALYTICS.11.00.00.06on repo https://git.ti.com/git/processor-sdk/imaging.git - cgit indicates that this tag doesn't exist on the repo
Pinging to ask if this is a known issue, and if the missing tag(s) can be pushed publicly
Full fetch log follows:
DEBUG: Executing python function extend_recipe_sysroot
NOTE: Direct dependencies are ['virtual:native:/work/sources/oe-core/meta/recipes-devtools/repo/repo_2.42.bb:do_populate_sysroot']
NOTE: Installed into sysroot: []
NOTE: Skipping as already exists in sysroot: ['gettext-minimal-native', 'cmake-native', 'libtool-native', 'texinfo-dummy-native', 'openssl-native', 'expat-native', 'ncurses-native', 'util-linux-libuuid-native', 'zlib-native', 'libedit-native', 'make-native', 'perl-native', 'python3-native', 'repo-native', 'bzip2-native', 'libnsl2-native', 'libtirpc-native', 'xz-native', 'zstd-native', 'gdbm-native', 'libffi-native', 'sqlite3-native']
DEBUG: Python function extend_recipe_sysroot finished
DEBUG: Executing python function fetcher_hashes_dummyfunc
DEBUG: Python function fetcher_hashes_dummyfunc finished
DEBUG: Executing python function do_fetch
DEBUG: Executing python function base_do_fetch
DEBUG: Trying PREMIRRORS
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', 'sourceware.org', '/git/glibc.git', '', '', OrderedDict()] to ['https', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', 'sourceware.org', '/git/binutils-gdb.git', '', '', OrderedDict()] to ['https', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()]
DEBUG: Trying Upstream
DEBUG: Fetcher accessed the network with the command /usr/bin/env repo sync repo://git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.11.00.00.06;manifest=vision_apps_yocto.xml
DEBUG: Running 'export PSEUDO_DISABLED=1; export PATH="/work/sources/oe-core/scripts:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot/usr/bin/crossscripts:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/usr/sbin:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/usr/bin:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/sbin:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/bin:/work/sources/bitbake/bin:/work/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/d3"; /usr/bin/env repo sync' in /work/local/downloads/repo/git.ti.com.git.processor-sdk.psdk_repo_manifests.git/vision_apps_yocto.xml/repo
WARNING: Failed to fetch URL repo://git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.11.00.00.06;manifest=vision_apps_yocto.xml, attempting MIRRORS if available
DEBUG: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export PATH="/work/sources/oe-core/scripts:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot/usr/bin/crossscripts:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/usr/sbin:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/usr/bin:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/sbin:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/bin:/work/sources/bitbake/bin:/work/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/d3"; /usr/bin/env repo sync failed with exit code 1, output:
fatal: couldn't find remote ref refs/tags/REL.PSDK.ANALYTICS.11.00.00.06
processor-sdk/imaging:
processor-sdk/imaging: sleeping 4.0 seconds before retrying
warning: repo is not tracking a remote branch, so it will not receive updates; run `repo init --repo-rev=stable` to fix.
error: Cannot fetch processor-sdk/imaging from git.ti.com/.../imaging
error: Cannot checkout processor-sdk/imaging: ManifestInvalidRevisionError: revision refs/tags/REL.PSDK.ANALYTICS.11.00.00.06 in processor-sdk/imaging not found
error: in `sync`: revision refs/tags/REL.PSDK.ANALYTICS.11.00.00.06 in processor-sdk/imaging not found
DEBUG: Trying MIRRORS
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['npm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https?$', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'software-dl.ti.com', '/processor-sdk-mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian/20180310T215105Z/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20120328T092752Z/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20110127T084257Z/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'snapshot.debian.org', '/archive/debian-archive/20090802T004153Z/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.de.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.au.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.cl.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hr.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.fi.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hk.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.hu.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.ie.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.it.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.jp.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.no.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.pl.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.ro.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.si.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.es.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.se.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.debian.org', '/debian/pool', '', '', OrderedDict()] to ['http', 'ftp.tr.debian.org', '/debian/pool', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'ftp.gnu.org', '/gnu', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/gnu', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'cdn.kernel.org', '/pub', '', '', OrderedDict()] to ['http', 'www.kernel.org', '/pub', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'ftp.gnupg.org', '/gcrypt', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'ftp.franken.de', '/pub/crypt/mirror/ftp.gnupg.org/gcrypt', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'www.gnupg.org', '/ftp/gcrypt', '', '', OrderedDict()] to ['ftp', 'mirrors.dotsrc.org', '/gcrypt', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['ftp', 'ftp.fu-berlin.de', '/tex/CTAN', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['http', 'sunsite.sut.ac.jp', '/pub/archives/ctan/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', 'dante.ctan.org', '/tex-archive', '', '', OrderedDict()] to ['http', 'ctan.unsw.edu.au', '/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', 'ftp.gnutls.org', '/gcrypt/gnutls', '', '', OrderedDict()] to ['https', 'www.gnupg.org', '/ftp/gcrypt/gnutls', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'ftp.info-zip.org', '/pub/infozip/src/', '', '', OrderedDict()] to ['ftp', 'sunsite.icm.edu.pl', '/pub/unix/archiving/info-zip/src/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'www.mirrorservice.org', '/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/', '', '', OrderedDict()] to ['http', 'www.mirrorservice.org', '/sites/lsof.itap.purdue.edu/pub/tools/unix/lsof/OLD/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'archive.apache.org', '/dist', '', '', OrderedDict()] to ['http', 'www.us.apache.org', '/dist', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'archive.apache.org', '/dist', '', '', OrderedDict()] to ['http', 'archive.apache.org', '/dist', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['http', 'downloads.sourceforge.net', '/watchdog/', '', '', OrderedDict()] to ['http', 'fossies.org', '/linux/misc/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'download.savannah.gnu.org', '/releases', '', '', OrderedDict()] to ['http', 'download-mirror.savannah.gnu.org', '/releases', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'download.savannah.nongnu.org', '/releases', '', '', OrderedDict()] to ['http', 'download-mirror.savannah.nongnu.org', '/releases', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'mirrors.kernel.org', '/sourceware', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'gd.tuwien.ac.at', '/gnu/sourceware', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', 'sourceware.org', '/pub', '', '', OrderedDict()] to ['http', 'ftp.gwdg.de', '/pub/linux/sources.redhat.com/sourceware', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https?', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['npm', '.*', '/?.*', '', '', OrderedDict()] to ['http', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['cvs', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['svn', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['gitsm', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['hg', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['bzr', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['p4', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['osc', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https?', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['ftp', '.*', '/.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['npm', '.*', '/?.*', '', '', OrderedDict()] to ['http', 'sources.openembedded.org', '/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https', 'search.cpan.org', '/CPAN', '', '', OrderedDict()] to ['https', 'cpan.metacpan.org', '/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https?', 'downloads.yoctoproject.org', '/releases/uninative/', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/yocto/uninative/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['https?', 'downloads.yoctoproject.org', '/mirror/sources/', '', '', OrderedDict()] to ['https', 'mirrors.kernel.org', '/yocto-sources/', '', '', OrderedDict()]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', 'salsa.debian.org', '/.*', '', '', OrderedDict()] to ['git', 'salsa.debian.org', '/PATH', '', '', OrderedDict([('protocol', 'https')])]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', 'git.gnome.org', '/.*', '', '', OrderedDict()] to ['git', 'gitlab.gnome.org', '/GNOME/PATH', '', '', OrderedDict([('protocol', 'https')])]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', 'git.infradead.org', '/.*', '', '', OrderedDict()] to ['git', 'git.infraroot.at', '/PATH', '', '', OrderedDict([('protocol', 'https')])]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['git', 'HOST', '/PATH', '', '', OrderedDict([('protocol', 'https')])]
DEBUG: For url ['repo', 'git.ti.com', '/git/processor-sdk/psdk_repo_manifests.git', '', '', OrderedDict([('protocol', 'https'), ('branch', 'refs/tags/REL.PSDK.ANALYTICS.11.00.00.06'), ('manifest', 'vision_apps_yocto.xml')])] comparing ['git', '.*', '/.*', '', '', OrderedDict()] to ['git', 'HOST', '/git/PATH', '', '', OrderedDict([('protocol', 'https')])]
ERROR: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export PATH="/work/sources/oe-core/scripts:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot/usr/bin/crossscripts:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/usr/sbin:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/usr/bin:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/sbin:/work/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/bin:/work/sources/bitbake/bin:/work/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/d3"; /usr/bin/env repo sync failed with exit code 1, output:
ERROR: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'repo://git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.11.00.00.06;manifest=vision_apps_yocto.xml')
DEBUG: Python function base_do_fetch finished
DEBUG: Python function do_fetch finished
