SK-AM62P-LP: Adding 'quiet' bootargs doesn't seem to be making a difference in boot time
Part Number: SK-AM62P-LP
I have tried adding the bootargs that supposedly reduce the boot time by 8+ seconds from the SDK AM62Px Linux Developer's Guide:
U-Boot=> setenv bootargs 'console=ttyS2,115200n8 fsck.mode=skip sysrq_always_enabled quiet'
And there seems to be no difference between the boot time with or without the bootargs. I am using the default image, and I have also tried this with the device tree method too, getting the same result.
Is there something I'm missing?
  • Hi Oliver,
    please attach the two boot logs with console message timestamps.
  • Without bootargs:
    U-Boot SPL 2025.01-gc779c758475c (Nov 13 2025 - 16:35:00 +0000)
    SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.5--v11.01.05d (Fancy Rat)')
    SPL initial stack usage: 17088 bytes
    Trying to boot from MMC2
    Authentication passed
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.13.0(release):v2.13.0-259-ge0c4d3903b-dirty
    NOTICE:  BL31: Built : 07:01:36, Jul  1 2025
    U-Boot SPL 2025.01-gc779c758475c (Nov 13 2025 - 16:35:21 +0000)
    DM ABI: 3.0 (firmware ver 0x000b 'MSDK.11.01.01.04-dirty--v11.01.02' patch_ver: 2)
    SPL initial stack usage: 1984 bytes
    U-Boot 2025.01-gc779c758475c (Nov 13 2025 - 16:35:21 +0000)
    SoC:   AM62PX SR1.0 HS-FS
    Model: Texas Instruments AM62P5 SK
    DRAM:  2 GiB (total 8 GiB)
    Core:  99 devices, 32 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth0: ethernet@8000000port@1
    Warning: ethernet@8000000port@2 (eth1) using random MAC address - ae:13:f0:82:7c:e7
    , eth1: ethernet@8000000port@2
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    574 bytes read in 1 ms (560.5 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    17066496 bytes read in 172 ms (94.6 MiB/s)
    66318 bytes read in 4 ms (15.8 MiB/s)
    Working FDT set to 88000000
       Loading Device Tree to 000000008feec000, end 000000008fffffff ... OK
    Working FDT set to 8feec000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.12.43-ti-rt-01064-g3a3f87d0bf70 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.4.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT_RT Wed Sep 24 19:09:07 UTC 2025
    [    0.000000] Machine model: Texas Instruments AM62P5 SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: legacy bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000009dc000000, size 576 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000009dc000000..0x00000009ffffffff (589824 KiB) map reusable linux,cma
    [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
    [    0.000000] OF: reserved mem: 0x00000000ff700000..0x00000000ffffffff (9216 KiB) nomap non-reusable framebuffer@ff700000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b500000, size 3 MiB
    [    0.000000] OF: reserved mem: initialized node rtos-ipc-memory@9b500000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b500000..0x000000009b7fffff (3072 KiB) nomap non-reusable rtos-ipc-memory@9b500000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node mcu-r5fss-dma-memory-region@9b800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable mcu-r5fss-dma-memory-region@9b800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node mcu-r5fss-memory-region@9b900000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable mcu-r5fss-memory-region@9b900000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@9c900000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-memory@9c900000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000009ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
    [    0.000000]   node   0: [mem 0x0000000080080000-0x000000009b4fffff]
    [    0.000000]   node   0: [mem 0x000000009b500000-0x000000009e6fffff]
    [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x000000009fffffff]
    [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ff6fffff]
    [    0.000000]   node   0: [mem 0x00000000ff700000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000009ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.5
    [    0.000000] percpu: Embedded 23 pages/cpu s54640 r8192 d31376 u94208
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: kernel page table isolation disabled by kernel configuration
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=076c4a2a-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2097152
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 4.
    [    0.000000] software IO TLB: mapped [mem 0x00000000fb700000-0x00000000ff700000] (64MB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
    [    0.000000] rcu:     RCU_SOFTIRQ processing moved to rcuc kthreads.
    [    0.000000]  No expedited grace period (rcu_normal_after_boot).
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: 0xffff8000800100bc
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880040000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.000376] Console: colour dummy device 80x25
    [    0.000429] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=200000)
    [    0.000440] pid_max: default: 32768 minimum: 301
    [    0.000500] LSM: initializing lsm=capability
    [    0.000638] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.000666] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.008857] rcu: Hierarchical SRCU implementation.
    [    0.008864] rcu:     Max phase no-delay instances is 400.
    [    0.009043] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.009188] EFI services will not be available.
    [    0.009313] smp: Bringing up secondary CPUs ...
    [    0.009951] Detected VIPT I-cache on CPU1
    [    0.010035] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.010051] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
    [    0.010098] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.033956] Detected VIPT I-cache on CPU2
    [    0.034022] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.034035] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000
    [    0.034071] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.087035] Detected VIPT I-cache on CPU3
    [    0.087099] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.087112] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000
    [    0.087142] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.108253] smp: Brought up 1 node, 4 CPUs
    [    0.108259] SMP: Total of 4 processors activated.
    [    0.108262] CPU: All CPU(s) started at EL2
    [    0.108266] CPU features: detected: 32-bit EL0 Support
    [    0.108269] CPU features: detected: CRC32 instructions
    [    0.108318] alternatives: applying system-wide alternatives
    [    0.108708] Memory: 7476808K/8388608K available (10368K kernel code, 1178K rwdata, 2736K rodata, 2240K init, 531K bss, 313252K reserved, 589824K cma-reserved)
    [    0.109697] devtmpfs: initialized
    [    0.124913] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
    [    0.124935] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.140745] 28448 pages in range for non-PLT usage
    [    0.140760] 519968 pages in range for PLT usage
    [    0.140978] pinctrl core: initialized pinctrl subsystem
    [    0.141563] DMI not present or invalid.
    [    0.142909] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.144125] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [    0.144252] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.144361] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.144426] audit: initializing netlink subsys (disabled)
    [    0.144598] audit: type=2000 audit(0.143:1): state=initialized audit_enabled=0 res=1
    [    0.145178] thermal_sys: Registered thermal governor 'step_wise'
    [    0.145366] ASID allocator initialised with 65536 entries
    [    0.151265] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
    [    0.151378] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.151409] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.151461] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.151572] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.157732] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.157887] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.158912] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.161326] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.161411] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.163171] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    0.163258] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.163938] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.163949] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.163953] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.163956] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.163960] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.163963] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.163967] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.163970] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    1.091114] debugfs: Directory '43000014.chipid' with parent 'regmap' already present!
    [    1.091204] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.0 JTAGID[0x0bb9d02f] Detected
    [    1.091943] iommu: Default domain type: Translated
    [    1.091952] iommu: DMA domain TLB invalidation policy: strict mode
    [    1.094859] SCSI subsystem initialized
    [    1.095248] usbcore: registered new interface driver usbfs
    [    1.095287] usbcore: registered new interface driver hub
    [    1.095321] usbcore: registered new device driver usb
    [    1.095850] pps_core: LinuxPPS API ver. 1 registered
    [    1.095855] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    1.095868] PTP clock support registered
    [    1.095966] EDAC MC: Ver: 3.0.0
    [    1.096283] scmi_core: SCMI protocol bus registered
    [    1.096597] FPGA manager framework
    [    1.096703] Advanced Linux Sound Architecture Driver Initialized.
    [    1.098138] clocksource: Switched to clocksource arch_sys_counter
    [    1.098346] VFS: Disk quotas dquot_6.6.0
    [    1.098364] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    1.105478] NET: Registered PF_INET protocol family
    [    1.105772] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    1.111118] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear)
    [    1.111230] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    1.111247] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    1.111740] TCP bind hash table entries: 65536 (order: 10, 5242880 bytes, vmalloc hugepage)
    [    1.115575] TCP: Hash tables configured (established 65536 bind 65536)
    [    1.115749] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear)
    [    1.116034] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear)
    [    1.116550] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    1.117008] RPC: Registered named UNIX socket transport module.
    [    1.117017] RPC: Registered udp transport module.
    [    1.117020] RPC: Registered tcp transport module.
    [    1.117023] RPC: Registered tcp-with-tls transport module.
    [    1.117025] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.117037] PCI: CLS 0 bytes, default 64
    [    1.119050] Initialise system trusted keyrings
    [    1.119289] workingset: timestamp_bits=62 max_order=21 bucket_order=0
    [    1.119588] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    1.119815] NFS: Registering the id_resolver key type
    [    1.119844] Key type id_resolver registered
    [    1.119848] Key type id_legacy registered
    [    1.119869] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    1.119874] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    1.173371] Key type asymmetric registered
    [    1.173379] Asymmetric key parser 'x509' registered
    [    1.173450] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    1.173456] io scheduler mq-deadline registered
    [    1.173460] io scheduler kyber registered
    [    1.173481] io scheduler bfq registered
    [    1.177301] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    1.177984] pinctrl-single f4000.pinctrl: 172 pins, size 688
    [    1.187011] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    1.197522] loop: module loaded
    [    1.198726] megasas: 07.727.03.00-rc1
    [    1.203728] tun: Universal TUN/TAP device driver, 1.6
    [    1.204760] VFIO - User Level meta-driver version: 0.3
    [    1.206198] usbcore: registered new interface driver usb-storage
    [    1.206903] i2c_dev: i2c /dev entries driver
    [    1.207628] sdhci: Secure Digital Host Controller Interface driver
    [    1.207632] sdhci: Copyright(c) Pierre Ossman
    [    1.207855] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.208570] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.209685] usbcore: registered new interface driver usbhid
    [    1.209692] usbhid: USB HID core driver
    [    1.210644] optee: probing for conduit method.
    [    1.210677] optee: revision 4.7 (a9690ae39995af36)
    [    1.211032] optee: dynamic shared memory is enabled
    [    1.211781] optee: initialized driver
    [    1.211897] random: crng init done
    [    1.213574] NET: Registered PF_PACKET protocol family
    [    1.213655] Key type dns_resolver registered
    [    1.223792] Loading compiled-in X.509 certificates
    [    1.235463] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.1.5--v11.01.05d (Fancy Rat)')
    [    1.288199] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    1.288348] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.289837] pca953x 1-0023: supply vcc not found, using dummy regulator
    [    1.289977] pca953x 1-0023: using AI
    [    1.303363] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.303447] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.303524] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    1.303593] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    1.303836] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.305187] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.305417] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.305672] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.305960] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
    [    1.307271] simple-framebuffer ff700000.framebuffer: framebuffer at 0xff700000, 0x8ca000 bytes
    [    1.307285] simple-framebuffer ff700000.framebuffer: format=a8r8g8b8, mode=1920x1200x32, linelength=7680
    [    1.631279] Console: switching to colour frame buffer device 240x75
    [    1.641596] simple-framebuffer ff700000.framebuffer: fb0: simplefb registered!
    [    1.641979] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.645339] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.648693] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.654921] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.657476] ti-udma 4e230000.dma-controller: Number of rings: 6
    [    1.658183] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
    [    1.659714] printk: legacy console [ttyS2] disabled
    [    1.703017] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 249, base_baud = 3000000) is a 8250
    [    1.711909] printk: legacy console [ttyS2] enabled
    [    1.711915] printk: legacy bootconsole [ns16550a0] disabled
    [    1.740159] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.740176] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.740183] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.744662] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.747290] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.748572] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.749887] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.751189] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.752473] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.753848] cadence-qspi fc40000.spi: Pattern not found. Skipping calibration.
    [    1.754609] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
    [    1.788134] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
    [    1.795116] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.795129] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    1.795282] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.795290] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
    [    1.795993] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
    [    1.867180] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.873363] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    1.873541] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    1.878261] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.878288] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    1.878412] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
    [    1.878420] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000808020000010
    [    1.878613] xhci-hcd xhci-hcd.0.auto: irq 263, io mem 0x31100000
    [    1.879473] hub 1-0:1.0: USB hub found
    [    1.879508] hub 1-0:1.0: 1 port detected
    [    1.881730] mmc0: CQHCI version 5.10
    [    1.881765] sdhci-am654 fa10000.mmc: Disable descoped HS400 mode for this silicon revision
    [    1.889498] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.889778] pca953x 1-0022: using AI
    [    1.900634] clk: Disabling unused clocks
    [    1.906298] PM: genpd: Disabling unused power domains
    [    1.906477] ALSA device list:
    [    1.906484]   No soundcards found.
    [    1.906966] mmc1: CQHCI version 5.10
    [    1.927747] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.945795] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.997405] Waiting for root device PARTUUID=076c4a2a-02...
    [    2.000246] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
    [    2.000881] mmcblk1: mmc1:59b4 SN32G 29.7 GiB
    [    2.002892]  mmcblk1: p1 p2
    [    2.014822] mmc0: Command Queue Engine enabled
    [    2.014844] mmc0: new HS200 MMC card at address 0001
    [    2.015733] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    2.017669]  mmcblk0: p1 p2
    [    2.018409] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    2.019941] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    2.021571] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
    [    2.277999] EXT4-fs (mmcblk1p2): recovery complete
    [    2.281689] EXT4-fs (mmcblk1p2): mounted filesystem a7cdcc95-d133-4ffc-9a89-0eccd2483259 r/w with ordered data mode. Quota mode: none.
    [    2.281789] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    2.282595] devtmpfs: mounted
    [    2.283430] Freeing unused kernel memory: 2240K
    [    2.283531] Run /sbin/init as init process
    [    2.468482] systemd[1]: System time before build time, advancing clock.
    [    2.513893] NET: Registered PF_INET6 protocol family
    [    2.514970] Segment Routing with IPv6
    [    2.515005] In-situ OAM (IOAM) with IPv6
    [    2.530357] systemd[1]: systemd 255.21^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.530385] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2025.01!
    [    2.574351] systemd[1]: Hostname set to <am62pxx-evm>.
    [    2.792473] systemd[1]: Configuration file /usr/lib/systemd/system/seva-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    2.817558] systemd[1]: Configuration file /etc/systemd/system/qtdemo.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    3.049613] systemd[1]: Queued start job for default target Graphical Interface.
    [  OK  ] Created slice Slice /system/getty    3.065550] systemd[1]: Created slice Slice /system/getty.
    0m.
    [  OK  ] Created slice Slice /system/modprob[    3.079593] systemd[1]: Created slice Slice /system/modprobe.
    e.
    [  OK  ] Created slice Slice /system/serial-[    3.093462] systemd[1]: Created slice Slice /system/serial-getty.
    getty.
    [  OK  ] Created slice User and Session Slic[    3.107901] systemd[1]: Created slice User and Session Slice.
    e.
    [  OK  ] Started Dispatch Password Requests [    3.121584] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Forward Password Requests t[    3.139491] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
             Expecting device /dev/ttyS2...
    [    3.156348] systemd[1]: Expecting device /dev/ttyS2...
    [  OK  ] Reached target Path Units.
    [    3.166627] systemd[1]: Reached target Path Units.
    [    3.177070] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [  OK  ] Reached target Slice Units.
    [    3.190265] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Swaps.
    [    3.200873] systemd[1]: Reached target Swaps.
    [  OK  ] Listening on RPCbind Server Activat[    3.213669] systemd[1]: Listening on RPCbind Server Activation Socket.
    ion Socket.
    [  OK  ] Reached target RPC Port Mapper.[    3.229365] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Listening on Process Core Dump Sock[    3.249621] systemd[1]: Listening on Process Core Dump Socket.
    et.
    [  OK  ] Listening on initctl Compatibility [    3.263680] systemd[1]: Listening on initctl Compatibility Named Pipe.
    Named Pipe.
    [  OK  ] Listening on Journal Audit Socket    3.280421] systemd[1]: Listening on Journal Audit Socket.
    0m.
    [  OK  ] Listening on Journal Socket (/dev/l[    3.293896] systemd[1]: Listening on Journal Socket (/dev/log).
    og).
    [    3.308010] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    3.320087] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [  OK  ] Listening on udev Control Socket    3.337910] systemd[1]: Listening on udev Control Socket.
    m.
    [  OK  ] Listening on udev Kernel Socket[    3.350837] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on User Database Manager [    3.363854] systemd[1]: Listening on User Database Manager Socket.
    Socket.
             Mounting Huge Pages File System...
    [    3.396479] systemd[1]: Mounting Huge Pages File System...
    [    3.399319] systemd[1]: Mounting POSIX Message Queue File System...
             Mounting POSIX Message Queue File System..[    3.416828] systemd[1]: Mounting Kernel Debug File System...
    [    3.432810] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.439223] systemd[1]: Mounting Temporary Directory /tmp...
             Starting Create List of Static Device Nodes    3.461249] systemd[1]: Starting Create List of Static Device Nodes...
    m...
             Starting Load Kernel Module configfs...
    [    3.478899] systemd[1]: Starting Load Kernel Module configfs...
             Starting Load Kernel Module drm...
    [    3.494693] systemd[1]: Starting Load Kernel Module drm...
             Starting Load Kernel Module fuse...
    [    3.509771] systemd[1]: Starting Load Kernel Module fuse...
    [    3.514461] systemd[1]: Starting Start psplash boot splash screen...
    [    3.532884] systemd[1]: Starting RPC Bind...
    [    3.538670] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    3.539855] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    3.539881] systemd[1]: systemd-journald.service: (This warning is only shown for the first unit using IP firewalling.)
    [    3.543711] systemd[1]: Starting Journal Service...
    [    3.556681] fuse: init (API version 7.41)
    [    3.592779] systemd[1]: Starting Load Kernel Modules...
    [    3.619762] systemd[1]: Starting Generate network units from Kernel command line...
    [    3.628735] systemd-journald[151]: Collecting audit messages is enabled.
    [    3.660063] cryptodev: loading out-of-tree module taints kernel.
    [    3.663315] sysctl table check failed: ioctl/(null) procname is null
    [    3.663330] sysctl table check failed: ioctl/(null) No proc_handler
    [    3.663335] cryptodev: driver 1.14 loaded.
    [    3.665778] systemd[1]: Starting Remount Root and Kernel File Systems...
             Starting Coldplug All udev Devices...
    [    3.702805] systemd[1]: Starting Coldplug All udev Devices...
    [    3.722697] systemd[1]: Started RPC Bind.
    [  OK  ] Started Start psplash boot splash s[    3.735761] systemd[1]: Started Start psplash boot splash screen.
    creen.
    [    3.748817] EXT4-fs (mmcblk1p2): re-mounted a7cdcc95-d133-4ffc-9a89-0eccd2483259.
    [  OK  ] Started Journal Service.
    [    3.759193] systemd[1]: Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
    [  OK  ] Started Start psplash-systemd progress communication helper.
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev gracefully...
    [  OK  ] Mounted FUSE Control File System    3.996625] systemd-journald[151]: Received client request to flush runtime journal.
    m.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Create Static Device Nodes in /dev gracefully.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /var/volatile...
             Starting Rule-based Manager for Device Events and Files...
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save OS Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create System Files and Directories...
    [  OK  ] Finished Load/Save OS Random Seed.
             Starting User Database Manager...
    [  OK  ] Finished Create System Files and Directories.
    [  OK  ] Finished Coldplug All udev Devices.
             Starting Network Name Resolution...
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Started User Database Manager.
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [  OK  ] Found device /dev/ttyS2.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API...
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
             Starting D-Bus System Message Bus...
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Finished Reboot and dump vmcore via kexec.
    [    5.615520] tlv320aic3x 1-001b: supply IOVDD not found, using dummy regulator
    [    5.615757] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
    [    5.615811] tlv320aic3x 1-001b: supply AVDD not found, using dummy regulator
    [    5.616009] tlv320aic3x 1-001b: supply DRVDD not found, using dummy regulator
    [    5.616097] tlv320aic3x 1-001b: Invalid supply voltage(s) AVDD: -22, DVDD: -22
    [    5.641049] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    5.647473] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [  OK  ] Started D-Bus System Message Bus.
    [    5.672591] tps6598x 0-003f: Unable to find the interrupt, switching to polling
    [    5.704491] mc: Linux media interface: v0.10
    [    5.739431] videodev: Linux video capture interface: v2.00
    [    5.869762] platform 79000000.r5f: configured R5F for remoteproc mode
    [    5.876649] platform 79000000.r5f: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [    5.913606] remoteproc remoteproc0: 79000000.r5f is available
    [    5.917731] remoteproc remoteproc0: powering up 79000000.r5f
    [    5.917754] remoteproc remoteproc0: Booting fw image am62p-mcu-r5f0_0-fw, size 59336
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
    [    6.017378] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    6.021659] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [    6.041420] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    6.041474] rproc-virtio rproc-virtio.1.auto: registered virtio0 (type 7)
    [    6.041482] remoteproc remoteproc0: remote processor 79000000.r5f is now up
    [    6.041775] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    6.042039] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    6.048160] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    6.051163] platform 78000000.r5f: configured R5F for IPC-only mode
    [    6.051324] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
    [    6.063570] remoteproc remoteproc1: 78000000.r5f is available
    [    6.063746] remoteproc remoteproc1: attaching to 78000000.r5f
    [    6.064249] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@9c800000
    [    6.064824] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    6.064862] rproc-virtio rproc-virtio.3.auto: registered virtio1 (type 7)
    [    6.064870] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
    [    6.065683] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    6.065927] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    6.066778] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    [    6.066794] vdec 30210000.video-codec: Product Code:      0x521c
    [    6.066801] vdec 30210000.video-codec: Firmware Revision: 363254
    [    6.123765] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    6.124013] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    6.141837] i2c i2c-1: Added multiplexed i2c bus 3
    [    6.162944] [drm] Initialized tidss 1.0.0 for 30200000.dss on minor 0
    [    6.193617] PVR_K:  216: Device: fd80000.gpu
    [    6.200869] PVR_K:  216: Read BVNC 36.53.104.796 from HW device registers
    [    6.200897] PVR_K:  216: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    6.204974] [drm] Initialized pvr 24.2.6643903 for fd80000.gpu on minor 1
             Starting Avahi mDNS/DNS-SD Stack...
    [    6.240871] tidss 30200000.dss: [drm] fb1: tidssdrmfb frame buffer device
    [  OK  ] Started Periodic Command Scheduler.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
    [  OK  ] Started Multiple Spanning Tree Protocol Daemon.
             Starting Telephony service...
             Starting PulseAudio Sound System...
             Starting QT Demo...
             Starting Expand the rootfs partiti…to full size of the boot device....
    [  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
             Starting User Login Management...
             Starting Telnet Server...
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [  OK  ] Finished Telnet Server.
    [  OK  ] Started Telephony service.
    [    6.879752] Bluetooth: Core ver 2.22
    [    6.879892] NET: Registered PF_BLUETOOTH protocol family
    [    6.879899] Bluetooth: HCI device and connection manager initialized
    [    6.879922] Bluetooth: HCI socket layer initialized
    [    6.879932] Bluetooth: L2CAP socket layer initialized
    [    6.879958] Bluetooth: SCO socket layer initialized
    [  OK  ] Started User Login Management.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Finished Expand the rootfs partition to full size of the boot device..
    [  OK  ] Created slice Slice /system/systemd-fsck.
    [  OK  ] Created slice Slice /system/tee-supplicant.
             Expecting device /dev/mmcblk0p1...
             Expecting device /dev/mmcblk0p2...
    [  OK  ] Reached target Preparation for Network.
    [  OK  ] Reached target Hardware activated USB gadget.
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
             Starting Save/Restore Sound Card State...
             Starting Network Configuration...
             Starting Virtual Console Setup...
    [  OK  ] Started TEE Supplicant on teepriv0.
    [  OK  ] Finished Save/Restore Sound Card State.
    [  OK  ] Found device /dev/mmcblk0p1.
    [  OK  ] Found device /dev/mmcblk0p2.
             Expecting device /dev/mmcblk1p1...
    [  OK  ] Reached target Sound Card.
             Starting File System Check on /dev/mmcblk0p1...
             Starting File System Check on /dev/mmcblk0p2...
    [  OK  ] Started PulseAudio Sound System.
    [  OK  ] Found device /dev/mmcblk1p1.
    [  OK  ] Finished Virtual Console Setup.
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Finished File System Check on /dev/mmcblk0p1.
             Mounting /run/media/boot-mmcblk0p1...
    [    7.863416] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    7.901861] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    7.904649] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [  OK  ] Mounted /run/media/boot-mmcblk0p1.
    [  OK  ] Finished File System Check on /dev/mmcblk1p1.
             Mounting /run/media/boot-mmcblk1p1...
    [  OK  ] Started Network Configuration.
    [  OK  ] Reached target Network.
             Starting containerd container runtime...
    [    8.040669] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    8.040695] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
             Starting LLDP daemon...
    [  OK  ] Started Netperf Benchmark Server.
    [    8.084260] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
    [    8.084287] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
             Starting Simple Network Management Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Mounted /run/media/boot-mmcblk1p1.
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
    [  OK  ] Started LLDP daemon.
    [  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
    [    9.673596] PVR_K:  544: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [    9.685854] PVR_K:  544: Shader binary image 'rgx.sh.36.53.104.796' loaded
    [  OK  ] Started containerd container runtime.
    [  OK  ] Finished File System Check on /dev/mmcblk0p2.
             Mounting /run/media/root-mmcblk0p2...
    [  OK  ] Started QT Demo.
    [   10.621802] EXT4-fs (mmcblk0p2): mounted filesystem eb49b298-5415-45e1-ba7b-df773dcc36e7 r/w with ordered data mode. Quota mode: none.
    [  OK  ] Mounted /run/media/root-mmcblk0p2.
    NOTICE: This file system contains the following GPL-3.0 packages:
            adwaita-icon-theme-symbolic
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils-dev
            elfutils
            findutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            hidapi
            kbd-dev
            kbd-keymaps-pine
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libgnutls-dev
            libgnutls-openssl27
            libgomp1
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libopcodes
            libqt6core5compat-plugins
            libqt6core5compat-qmlplugins
            libqt6core5compat6
            libqt6shadertools-dev
            libqt6shadertools-plugins
            libqt6shadertools-qmlplugins
            libqt6shadertools6
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libtasn1-dev
            libunistring-dev
            libunistring5
            m4
            make
            nettle-dev
            nettle
            parted
            piglit
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-dev
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase-staticdev
            qtbase
            qtdeclarative-dev
            qtdeclarative-plugins
            qtdeclarative-qmlplugins
            qtdeclarative-staticdev
            qtdeclarative-tools
            qtdeclarative
            qtlanguageserver-dev
            qtlanguageserver-plugins
            qtlanguageserver-qmlplugins
            qtlanguageserver-staticdev
            qtlanguageserver
            qtmultimedia-plugins
            qtmultimedia-qmlplugins
            qtmultimedia
            qtquick3d-plugins
            qtquick3d-qmlplugins
            qtquick3d
            qtquicktimeline-plugins
            qtquicktimeline-qmlplugins
            qtquicktimeline
            qtsvg-dev
            qtsvg-plugins
            qtsvg-qmlplugins
            qtsvg
            qttools-plugins
            qttools-qmlplugins
            qttools
            qtwayland-dev
            qtwayland-plugins
            qtwayland-qmlplugins
            qtwayland
            tar
            which
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Finished Print notice about GPLv3 packages.
    [  OK  ] Reached target Multi-User System.
    [  OK  ] Reached target Graphical Interface.
             Starting Record Runlevel Change in UTMP...
    [  OK  ] Finished Record Runlevel Change in UTMP.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am62pxx-evm ttyS2
    Arago 2025.01 am62pxx-evm ttyS2
    am62pxx-evm login: [   13.158549] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    With bootargs:
    Starting kernel ...
    [    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.000377] Console: colour dummy device 80x25
    [    0.000432] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=200000)
    [    0.000442] pid_max: default: 32768 minimum: 301
    [    0.000501] LSM: initializing lsm=capability
    [    0.000641] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.000669] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.026976] rcu: Hierarchical SRCU implementation.
    [    0.026985] rcu:     Max phase no-delay instances is 400.
    [    0.044931] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.056700] EFI services will not be available.
    [    0.065008] smp: Bringing up secondary CPUs ...
    [    0.144231] Detected VIPT I-cache on CPU1
    [    0.144313] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.144328] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
    [    0.144374] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.273560] Detected VIPT I-cache on CPU2
    [    0.273628] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.273642] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000
    [    0.273677] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.375736] Detected VIPT I-cache on CPU3
    [    0.375800] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.375813] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000
    [    0.375848] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.390360] smp: Brought up 1 node, 4 CPUs
    [    0.390366] SMP: Total of 4 processors activated.
    [    0.390370] CPU: All CPU(s) started at EL2
    [    0.390374] CPU features: detected: 32-bit EL0 Support
    [    0.390378] CPU features: detected: CRC32 instructions
    [    0.414037] alternatives: applying system-wide alternatives
    [    0.414437] Memory: 7476808K/8388608K available (10368K kernel code, 1178K rwdata, 2736K rodata, 2240K init, 531K bss, 313252K reserved, 589824K cma-reserved)
    [    0.415437] devtmpfs: initialized
    [    0.430569] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
    [    0.430590] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.446069] 28448 pages in range for non-PLT usage
    [    0.446085] 519968 pages in range for PLT usage
    [    0.446306] pinctrl core: initialized pinctrl subsystem
    [    0.446957] DMI not present or invalid.
    [    0.447741] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.448958] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [    0.449087] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.449195] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.449263] audit: initializing netlink subsys (disabled)
    [    0.449431] audit: type=2000 audit(0.447:1): state=initialized audit_enabled=0 res=1
    [    0.450007] thermal_sys: Registered thermal governor 'step_wise'
    [    0.450203] ASID allocator initialised with 65536 entries
    [    0.456129] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
    [    0.456241] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.456273] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.456325] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.456437] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.462626] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.462782] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.463826] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.466254] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.466341] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.468105] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    0.468214] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.468865] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.468872] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.468877] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.468880] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.468884] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.468886] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.468891] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.468893] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    1.091492] debugfs: Directory '43000014.chipid' with parent 'regmap' already present!
    [    1.091580] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.0 JTAGID[0x0bb9d02f] Detected
    [    1.093044] iommu: Default domain type: Translated
    [    1.093055] iommu: DMA domain TLB invalidation policy: strict mode
    [    1.095151] SCSI subsystem initialized
    [    1.095680] usbcore: registered new interface driver usbfs
    [    1.095722] usbcore: registered new interface driver hub
    [    1.095756] usbcore: registered new device driver usb
    [    1.096291] pps_core: LinuxPPS API ver. 1 registered
    [    1.096294] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    1.096308] PTP clock support registered
    [    1.096344] EDAC MC: Ver: 3.0.0
    [    1.096714] scmi_core: SCMI protocol bus registered
    [    1.097004] FPGA manager framework
    [    1.097111] Advanced Linux Sound Architecture Driver Initialized.
    [    1.100820] clocksource: Switched to clocksource arch_sys_counter
    [    1.101045] VFS: Disk quotas dquot_6.6.0
    [    1.101066] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    1.108885] NET: Registered PF_INET protocol family
    [    1.109175] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    1.114484] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear)
    [    1.114628] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    1.114646] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    1.115170] TCP bind hash table entries: 65536 (order: 10, 5242880 bytes, vmalloc hugepage)
    [    1.119024] TCP: Hash tables configured (established 65536 bind 65536)
    [    1.119202] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear)
    [    1.119488] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear)
    [    1.120030] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    1.120463] RPC: Registered named UNIX socket transport module.
    [    1.120470] RPC: Registered udp transport module.
    [    1.120473] RPC: Registered tcp transport module.
    [    1.120476] RPC: Registered tcp-with-tls transport module.
    [    1.120478] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.120492] PCI: CLS 0 bytes, default 64
    [    1.121672] Initialise system trusted keyrings
    [    1.121888] workingset: timestamp_bits=62 max_order=21 bucket_order=0
    [    1.122208] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    1.122454] NFS: Registering the id_resolver key type
    [    1.122490] Key type id_resolver registered
    [    1.122494] Key type id_legacy registered
    [    1.122513] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    1.122518] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    1.176037] Key type asymmetric registered
    [    1.176045] Asymmetric key parser 'x509' registered
    [    1.176117] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    1.176124] io scheduler mq-deadline registered
    [    1.176127] io scheduler kyber registered
    [    1.176147] io scheduler bfq registered
    [    1.179969] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    1.180649] pinctrl-single f4000.pinctrl: 172 pins, size 688
    [    1.189734] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    1.201981] loop: module loaded
    [    1.203175] megasas: 07.727.03.00-rc1
    [    1.208209] tun: Universal TUN/TAP device driver, 1.6
    [    1.209269] VFIO - User Level meta-driver version: 0.3
    [    1.210698] usbcore: registered new interface driver usb-storage
    [    1.211443] i2c_dev: i2c /dev entries driver
    [    1.212149] sdhci: Secure Digital Host Controller Interface driver
    [    1.212153] sdhci: Copyright(c) Pierre Ossman
    [    1.212378] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.213083] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.214194] usbcore: registered new interface driver usbhid
    [    1.214199] usbhid: USB HID core driver
    [    1.215152] optee: probing for conduit method.
    [    1.215187] optee: revision 4.7 (a9690ae39995af36)
    [    1.215535] optee: dynamic shared memory is enabled
    [    1.216273] optee: initialized driver
    [    1.216388] random: crng init done
    [    1.217996] NET: Registered PF_PACKET protocol family
    [    1.218079] Key type dns_resolver registered
    [    1.228197] Loading compiled-in X.509 certificates
    [    1.239546] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.1.5--v11.01.05d (Fancy Rat)')
    [    1.292333] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    1.292479] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.294059] pca953x 1-0023: supply vcc not found, using dummy regulator
    [    1.294201] pca953x 1-0023: using AI
    [    1.308068] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.308163] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.308234] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    1.308300] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    1.308545] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.309928] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.310161] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.310425] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.310722] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
    [    1.312045] simple-framebuffer ff700000.framebuffer: framebuffer at 0xff700000, 0x8ca000 bytes
    [    1.312057] simple-framebuffer ff700000.framebuffer: format=a8r8g8b8, mode=1920x1200x32, linelength=7680
    [    1.631185] Console: switching to colour frame buffer device 240x75
    [    1.641518] simple-framebuffer ff700000.framebuffer: fb0: simplefb registered!
    [    1.641937] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.645294] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.648611] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.654770] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.657348] ti-udma 4e230000.dma-controller: Number of rings: 6
    [    1.658050] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
    [    1.659557] printk: legacy console [ttyS2] disabled
    [    1.702941] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 249, base_baud = 3000000) is a 8250
    [    1.711857] printk: legacy console [ttyS2] enabled
    [    1.711862] printk: legacy bootconsole [ns16550a0] disabled
    [    1.740749] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.740766] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.740772] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.742329] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.743651] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.745164] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.746473] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.747744] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.749110] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.750484] cadence-qspi fc40000.spi: Pattern not found. Skipping calibration.
    [    1.751290] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
    [    1.784832] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
    [    1.791825] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.791836] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    1.791987] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.791996] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
    [    1.792674] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
    [    1.866921] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.872215] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    1.872375] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    1.877667] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.877697] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    1.877901] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
    [    1.877910] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000808020000010
    [    1.878098] xhci-hcd xhci-hcd.0.auto: irq 263, io mem 0x31100000
    [    1.878940] hub 1-0:1.0: USB hub found
    [    1.878970] hub 1-0:1.0: 1 port detected
    [    1.881016] mmc0: CQHCI version 5.10
    [    1.881052] sdhci-am654 fa10000.mmc: Disable descoped HS400 mode for this silicon revision
    [    1.888986] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.889244] pca953x 1-0022: using AI
    [    1.900257] clk: Disabling unused clocks
    [    1.906289] PM: genpd: Disabling unused power domains
    [    1.906469] ALSA device list:
    [    1.906478]   No soundcards found.
    [    1.906995] mmc1: CQHCI version 5.10
    [    1.927311] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.952760] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.997152] Waiting for root device PARTUUID=076c4a2a-02...
    [    2.001234] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
    [    2.002023] mmcblk1: mmc1:59b4 SN32G 29.7 GiB
    [    2.005303]  mmcblk1: p1 p2
    [    2.010145] mmc0: Command Queue Engine enabled
    [    2.010160] mmc0: new HS200 MMC card at address 0001
    [    2.010747] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    2.012293]  mmcblk0: p1 p2
    [    2.012885] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    2.014357] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    2.015778] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
    [    2.228105] EXT4-fs (mmcblk1p2): mounted filesystem a7cdcc95-d133-4ffc-9a89-0eccd2483259 r/w with ordered data mode. Quota mode: none.
    [    2.228203] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    2.228759] devtmpfs: mounted
    [    2.229624] Freeing unused kernel memory: 2240K
    [    2.229729] Run /sbin/init as init process
    [    2.416446] systemd[1]: System time before build time, advancing clock.
    [    2.462009] NET: Registered PF_INET6 protocol family
    [    2.463024] Segment Routing with IPv6
    [    2.463057] In-situ OAM (IOAM) with IPv6
    [    2.478447] systemd[1]: systemd 255.21^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.478479] systemd[1]: Detected architecture arm64.
    [    2.522124] systemd[1]: Hostname set to <am62pxx-evm>.
    [    2.724136] systemd[1]: Configuration file /usr/lib/systemd/system/seva-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    2.748937] systemd[1]: Configuration file /etc/systemd/system/qtdemo.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    2.984258] systemd[1]: Queued start job for default target Graphical Interface.
    [    3.000359] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/modprob[    3.015269] systemd[1]: Created slice Slice /system/modprobe.
    e.
    [  OK  ] Created slice Slice /system/serial-[    3.030199] systemd[1]: Created slice Slice /system/serial-getty.
    getty.
    [  OK  ] Created slice User and Session Slic[    3.044628] systemd[1]: Created slice User and Session Slice.
    e.
    [  OK  ] Started Dispatch Password Requests [    3.058283] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Forward Password Requests t[    3.076217] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    3.093071] systemd[1]: Expecting device /dev/ttyS2...
    [    3.103417] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Remote File Systems systemd[1]: Reached target Remote File Systems.
    [0m.
    [    3.126969] systemd[1]: Reached target Slice Units.
    [    3.137575] systemd[1]: Reached target Swaps.
    [  OK  ] Listening on RPCbind Server Activat[    3.150408] systemd[1]: Listening on RPCbind Server Activation Socket.
    ion Socket.
    [  OK  ] Reached target RPC Port Mapper.[    3.166051] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Listening on Process Core Dump Sock[    3.186273] systemd[1]: Listening on Process Core Dump Socket.
    et.
    [  OK  ] Listening on initctl Compatibility [    3.200352] systemd[1]: Listening on initctl Compatibility Named Pipe.
    Named Pipe.
    [  OK  ] Listening on Journal Audit Socket    3.217122] systemd[1]: Listening on Journal Audit Socket.
    0m.
    [  OK  ] Listening on Journal Socket (/dev/l[    3.230622] systemd[1]: Listening on Journal Socket (/dev/log).
    og).
    [    3.244677] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Network Service Netlin[    3.257840] systemd[1]: Listening on Network Service Netlink Socket.
    k Socket.
    [  OK  ] Listening on udev Control Socket    3.275617] systemd[1]: Listening on udev Control Socket.
    m.
    [  OK  ] Listening on udev Kernel Socket[    3.288524] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on User Database Manager [    3.301560] systemd[1]: Listening on User Database Manager Socket.
    Socket.
    [    3.334186] systemd[1]: Mounting Huge Pages File System...
    [    3.337213] systemd[1]: Mounting POSIX Message Queue File System...
             Mounting POSIX Message Queue File System..[    3.354609] systemd[1]: Mounting Kernel Debug File System...
    [    3.372499] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.376268] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.395413] systemd[1]: Starting Create List of Static Device Nodes...
    [    3.417652] systemd[1]: Starting Load Kernel Module configfs...
    [    3.441496] systemd[1]: Starting Load Kernel Module drm...
    [    3.456238] systemd[1]: Starting Load Kernel Module fuse...
             Starting Start psplash boot splash screen.[    3.478238] systemd[1]: Starting Start psplash boot splash screen...
    [    3.489012] fuse: init (API version 7.41)
    [    3.509596] systemd[1]: Starting RPC Bind...
    [    3.518337] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    3.519645] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    3.519667] systemd[1]: systemd-journald.service: (This warning is only shown for the first unit using IP firewalling.)
    [    3.522895] systemd[1]: Starting Journal Service...
    [    3.565294] systemd[1]: Starting Load Kernel Modules...
             Starting Generate network units from Kernel co[    3.593343] systemd[1]: Starting Generate network units from Kernel command line...
    mmand line...
             Starting Remount Root and Kernel File Systems systemd[1]: Starting Remount Root and Kernel File Systems...
    [0m...
    [    3.617457] systemd-journald[151]: Collecting audit messages is enabled.
    [    3.620951] cryptodev: loading out-of-tree module taints kernel.
    [    3.627026] sysctl table check failed: ioctl/(null) procname is null
    [    3.627044] sysctl table check failed: ioctl/(null) No proc_handler
    [    3.627049] cryptodev: driver 1.14 loaded.
    [    3.665409] systemd[1]: Starting Coldplug All udev Devices...
    [    3.684946] systemd[1]: Started RPC Bind.
    [    3.696682] systemd[1]: Started Start psplash boot splash screen.
    [  OK  ] Started Start psplash boot splash s[    3.706475] EXT4-fs (mmcblk1p2): re-mounted a7cdcc95-d133-4ffc-9a89-0eccd2483259.
    creen.
    [    3.720582] systemd[1]: Started Journal Service.
    [  OK  ] Mounted FUSE Control File System.
    [    3.951256] systemd-journald[151]: Received client request to flush runtime journal.
    [    5.394704] tlv320aic3x 1-001b: supply IOVDD not found, using dummy regulator
    [    5.451627] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
    [    5.453281] tlv320aic3x 1-001b: supply AVDD not found, using dummy regulator
    [    5.465941] tlv320aic3x 1-001b: supply DRVDD not found, using dummy regulator
    [    5.476866] tlv320aic3x 1-001b: Invalid supply voltage(s) AVDD: -22, DVDD: -22
    [    5.514969] mc: Linux media interface: v0.10
    [    5.566771] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    5.567534] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    5.620288] tps6598x 0-003f: Unable to find the interrupt, switching to polling
    [    5.627306] platform 79000000.r5f: configured R5F for remoteproc mode
    [    5.628999] platform 79000000.r5f: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [    5.631949] videodev: Linux video capture interface: v2.00
    [    5.634930] remoteproc remoteproc0: 79000000.r5f is available
    [    5.639948] remoteproc remoteproc0: powering up 79000000.r5f
    [    5.639976] remoteproc remoteproc0: Booting fw image am62p-mcu-r5f0_0-fw, size 59336
    [    5.700279] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [    5.831948] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    5.831992] rproc-virtio rproc-virtio.1.auto: registered virtio0 (type 7)
    [    5.832000] remoteproc remoteproc0: remote processor 79000000.r5f is now up
    [    5.832840] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    5.833044] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    5.833947] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    5.834865] platform 78000000.r5f: configured R5F for IPC-only mode
    [    5.835004] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
    [    5.836025] remoteproc remoteproc1: 78000000.r5f is available
    [    5.836098] remoteproc remoteproc1: attaching to 78000000.r5f
    [    5.840206] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node r5f-dma-memory@9c800000
    [    5.840698] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    5.840727] rproc-virtio rproc-virtio.2.auto: registered virtio1 (type 7)
    [    5.840735] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
    [    5.840983] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    5.841217] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    5.850786] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    5.925965] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    5.926212] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    5.949760] i2c i2c-1: Added multiplexed i2c bus 3
    [    5.968742] [drm] Initialized tidss 1.0.0 for 30200000.dss on minor 0
    [    6.039667] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    [    6.039687] vdec 30210000.video-codec: Product Code:      0x521c
    [    6.039693] vdec 30210000.video-codec: Firmware Revision: 363254
    [    6.065323] tidss 30200000.dss: [drm] fb1: tidssdrmfb frame buffer device
    [    6.075529] PVR_K:  232: Device: fd80000.gpu
    [    6.085577] PVR_K:  232: Read BVNC 36.53.104.796 from HW device registers
    [    6.085718] PVR_K:  232: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    6.090530] [drm] Initialized pvr 24.2.6643903 for fd80000.gpu on minor 1
    [  OK  ] Started Job spooling tools.
             Starting QT Demo...
    [    6.714144] Bluetooth: Core ver 2.22
    [    6.714231] NET: Registered PF_BLUETOOTH protocol family
    [    6.714236] Bluetooth: HCI device and connection manager initialized
    [    6.714255] Bluetooth: HCI socket layer initialized
    [    6.714264] Bluetooth: L2CAP socket layer initialized
    [    6.714280] Bluetooth: SCO socket layer initialized
    [    7.502725] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [  OK  ] Created slice Slice /system/systemd[    7.531514] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    -fsck.
             Expecting device /dev/mmcblk0p1    7.533255] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    0m...
    [    7.700356] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    7.700383] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [    7.730838] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
    [    7.730866] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [    8.418501] EXT4-fs (mmcblk0p2): mounted filesystem eb49b298-5415-45e1-ba7b-df773dcc36e7 r/w with ordered data mode. Quota mode: none.
    [    9.455184] PVR_K:  544: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [    9.461110] PVR_K:  544: Shader binary image 'rgx.sh.36.53.104.796' loaded
    [   10.793873] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
             Starting Hostname Service...
    [  OK  ] Started Hostname Service.
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils-dev
            elfutils
            findutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            hidapi
            kbd-dev
            kbd-keymaps-pine
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libgnutls-dev
            libgnutls-openssl27
            libgomp1
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libopcodes
            libqt6core5compat6
            libqt6shadertools6
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libtasn1-dev
            libunistring-dev
            libunistring5
            m4
            make
            nettle-dev
            nettle
            parted
            piglit
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-dev
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase-staticdev
            qtbase
            qtdeclarative-dev
            qtdeclarative-tools
            qtdeclarative
            qtlanguageserver
            qtmultimedia
            qtquick3d-plugins
            qtquick3d
            qtquicktimeline
            qtsvg-dev
            qtsvg-plugins
            qtsvg-qmlplugins
            qtsvg
            qttools-plugins
            qttools-qmlplugins
            qttools
            qtwayland-dev
            qtwayland-plugins
            qtwayland
            tar
            which
     _____                    _____           _         _
                  |___|                    |___|
    am62pxx-evm login:
  • Hi Oliver,
    Your both boot logs have the same message about the kernel cmdline, as shown below. It doesn't have the "quiet" flag in there. So both boot in the same way.
    [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=076c4a2a-02 rw rootfstype=ext4 rootwait
    There are many ways to modify the kernel cmdline parameters, but if you boot the board from a sdcard, you can add the following line to the file uEnv.txt on the sdcard boot partition.
    optargs="quiet"
  • Hi Bin,
    I previously tried using
    optargs="quiet"
    and it worked successfully, however I am now using Falcon Mode in U-Boot to directly load the kernel from the R5 SPL and adding the parameter to the uEnv.txt file doesnt seem to work anymore.
    Here are my boot logs:
    U-Boot SPL 2025.01-gc779c758475c-dirty (Nov 20 2025 - 16:16:03 +0000)
    SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.5--v11.01.05d (Fancy Rat)')
    SPL initial stack usage: 17128 bytes
    Trying to boot from MMC2
    Authentication passed
    Loading falcon payload from MMC2
    Loading Environment from nowhere... OK
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.13.0(release):v2.13.0-259-ge0c4d3903
    NOTICE:  BL31: Built : 11:29:48, Nov 18 2025
    I/TC:
    I/TC: OP-TEE version: 4.7.0-47-ga9690ae39 (gcc version 8.2.1 20180802 (GNU Toolchain for the A-profile Architecture 8.2-2019.01 (arm-rel-8.28))) #2 Tue Nov 18 11:22:38 UTC 2025 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: GIC redistributor base address not provided
    I/TC: Assuming default GIC group status and modifier
    I/TC: SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.5--v11.01.05d (Fancy Rat)')
    I/TC: Activated SA2UL device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: EIP76D TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: HUK Initialized
    I/TC: Primary CPU switching to normal world boot
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    I/TC: Secondary CPU 2 initializing
    I/TC: Secondary CPU 2 switching to normal world boot
    I/TC: Secondary CPU 3 initializing
    I/TC: Secondary CPU 3 switching to normal world boot
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.12.43-g3a3f87d0bf70-dirty (pcuser@pcuser-desktop) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.2-2019.01 (arm-rel-8.28)) 8.2.1 20180802, GNU ld (GNU Toolchain for the A-profile Architecture 8.2-2019.01 (arm-rel-8.28)) 2.30.0.20180625) #1 SMP PREEMPT_RT Thu Nov 20 14:32:11 GMT 2025
    [    0.000000] Machine model: Texas Instruments AM62P5 SK
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000009dc000000, size 576 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000009dc000000..0x00000009ffffffff (589824 KiB) map reusable linux,cma
    [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b500000, size 3 MiB
    [    0.000000] OF: reserved mem: initialized node rtos-ipc-memory@9b500000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b500000..0x000000009b7fffff (3072 KiB) nomap non-reusable rtos-ipc-memory@9b500000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node mcu-r5fss-dma-memory-region@9b800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable mcu-r5fss-dma-memory-region@9b800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node mcu-r5fss-memory-region@9b900000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable mcu-r5fss-memory-region@9b900000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@9c900000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-memory@9c900000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000009ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
    [    0.000000]   node   0: [mem 0x0000000080080000-0x000000009b4fffff]
    [    0.000000]   node   0: [mem 0x000000009b500000-0x000000009e6fffff]
    [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x000000009fffffff]
    [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000009ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.5
    [    0.000000] percpu: Embedded 23 pages/cpu s54576 r8192 d31440 u94208
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: kernel page table isolation disabled by kernel configuration
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyS2,115200n8 root=PARTUUID=076c4a2a-02 rootwait
    [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2097152
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 4.
    [    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
    [    0.000000] rcu:     RCU_SOFTIRQ processing moved to rcuc kthreads.
    [    0.000000]  No expedited grace period (rcu_normal_after_boot).
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: 0xffff8000800100c0
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880040000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.000417] Console: colour dummy device 80x25
    [    0.000475] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=200000)
    [    0.000484] pid_max: default: 32768 minimum: 301
    [    0.000546] LSM: initializing lsm=capability
    [    0.000684] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.000713] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.002382] rcu: Hierarchical SRCU implementation.
    [    0.002391] rcu:     Max phase no-delay instances is 400.
    [    0.002591] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.002730] EFI services will not be available.
    [    0.002859] smp: Bringing up secondary CPUs ...
    [    0.011522] Detected VIPT I-cache on CPU1
    [    0.011603] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.011619] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
    [    0.011663] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.020366] Detected VIPT I-cache on CPU2
    [    0.020428] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.020441] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000
    [    0.020473] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.029177] Detected VIPT I-cache on CPU3
    [    0.029235] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.029248] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000
    [    0.029278] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.029409] smp: Brought up 1 node, 4 CPUs
    [    0.029416] SMP: Total of 4 processors activated.
    [    0.029419] CPU: All CPU(s) started at EL2
    [    0.029423] CPU features: detected: 32-bit EL0 Support
    [    0.029426] CPU features: detected: CRC32 instructions
    [    0.029456] alternatives: applying system-wide alternatives
    [    0.029845] Memory: 7490428K/8388608K available (7872K kernel code, 922K rwdata, 1760K rodata, 1536K init, 564K bss, 299628K reserved, 589824K cma-reserved)
    [    0.030825] devtmpfs: initialized
    [    0.042515] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
    [    0.042539] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.080130] 29552 pages in range for non-PLT usage
    [    0.080146] 521072 pages in range for PLT usage
    [    0.080351] pinctrl core: initialized pinctrl subsystem
    [    0.080849] DMI not present or invalid.
    [    0.081419] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.082632] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [    0.082756] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.082866] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.082893] audit: initializing netlink subsys (disabled)
    [    0.083047] audit: type=2000 audit(0.082:1): state=initialized audit_enabled=0 res=1
    [    0.083528] ASID allocator initialised with 65536 entries
    [    0.088368] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
    [    0.088482] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.088514] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.088568] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.088695] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.094386] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.094533] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.095516] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.097830] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.097918] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.099566] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    0.099656] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.100285] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.100294] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.100299] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.100302] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.100306] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.100309] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.100313] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.100316] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.101203] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.0 JTAGID[0x0bb9d02f] Detected
    [    0.101700] iommu: Default domain type: Translated
    [    0.101707] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.102663] EDAC MC: Ver: 3.0.0
    [    0.103027] scmi_core: SCMI protocol bus registered
    [    0.104611] clocksource: Switched to clocksource arch_sys_counter
    [    0.112997] NET: Registered PF_INET protocol family
    [    0.113276] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.118658] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear)
    [    0.118765] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.118781] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.119276] TCP bind hash table entries: 65536 (order: 10, 5242880 bytes, vmalloc hugepage)
    [    0.122841] TCP: Hash tables configured (established 65536 bind 65536)
    [    0.123014] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear)
    [    0.123283] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear)
    [    0.123740] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.124189] RPC: Registered named UNIX socket transport module.
    [    0.124197] RPC: Registered udp transport module.
    [    0.124199] RPC: Registered tcp transport module.
    [    0.124202] RPC: Registered tcp-with-tls transport module.
    [    0.124205] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.125349] Initialise system trusted keyrings
    [    0.125497] workingset: timestamp_bits=62 max_order=21 bucket_order=0
    [    0.126115] NFS: Registering the id_resolver key type
    [    0.126150] Key type id_resolver registered
    [    0.126154] Key type id_legacy registered
    [    0.126177] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.126181] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.169455] Key type asymmetric registered
    [    0.169463] Asymmetric key parser 'x509' registered
    [    0.169531] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [    0.169537] io scheduler mq-deadline registered
    [    0.169541] io scheduler kyber registered
    [    0.169560] io scheduler bfq registered
    [    0.172113] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.172839] pinctrl-single f4000.pinctrl: 172 pins, size 688
    [    0.179118] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.190345] loop: module loaded
    [    0.192769] i2c_dev: i2c /dev entries driver
    [    0.193419] sdhci: Secure Digital Host Controller Interface driver
    [    0.193423] sdhci: Copyright(c) Pierre Ossman
    [    0.193658] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.194333] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.195359] optee: probing for conduit method.
    [    0.195393] optee: revision 4.7 (a9690ae39995af36)
    [    0.212057] optee: dynamic shared memory is enabled
    [    0.212762] optee: initialized driver
    [    0.212863] random: crng init done
    [    0.213317] NET: Registered PF_PACKET protocol family
    [    0.213392] Key type dns_resolver registered
    [    0.219885] Loading compiled-in X.509 certificates
    [    0.231983] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.1.5--v11.01.05d (Fancy Rat)')
    [    0.270546] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.270716] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.272380] pca953x 1-0023: supply vcc not found, using dummy regulator
    [    0.272475] pca953x 1-0023: using AI
    [    0.285855] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.285949] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.286022] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    0.286098] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.286311] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.287559] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    0.287830] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    0.288088] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    0.288381] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
    [    0.288990] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    0.292489] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    0.295874] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    0.302326] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    0.304924] ti-udma 4e230000.dma-controller: Number of rings: 6
    [    0.305598] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
    [    0.307074] printk: legacy console [ttyS2] disabled
    [    0.307469] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 249, base_baud = 3000000) is a 8250
    [    0.307544] printk: legacy console [ttyS2] enabled
    [    0.318116] mmc0: CQHCI version 5.10
    [    0.318153] sdhci-am654 fa10000.mmc: Disable descoped HS400 mode for this silicon revision
    [    0.325965] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    0.326136] pca953x 1-0022: using AI
    [    0.335696] mmc1: CQHCI version 5.10
    [    0.337506] clk: Disabling unused clocks
    [    0.343085] PM: genpd: Disabling unused power domains
    [    0.359389] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    0.376853] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    0.434076] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
    [    0.434670] mmcblk1: mmc1:59b4 SN32G 29.7 GiB
    [    0.436360]  mmcblk1: p1 p2
    [    0.456528] mmc0: Command Queue Engine enabled
    [    0.456548] mmc0: new HS200 MMC card at address 0001
    [    0.457159] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    0.458439]  mmcblk0: p1 p2
    [    0.459057] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    0.459873] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    0.460724] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (248:0)
    [    2.009320] EXT4-fs (mmcblk1p2): orphan cleanup on readonly fs
    [    2.012813] EXT4-fs (mmcblk1p2): mounted filesystem a7cdcc95-d133-4ffc-9a89-0eccd2483259 ro with ordered data mode. Quota mode: disabled.
    [    2.012910] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    2.013492] devtmpfs: mounted
    [    2.014113] Freeing unused kernel memory: 1536K
    [    2.014205] Run /sbin/init as init process
    [    2.198459] systemd[1]: System time before build time, advancing clock.
    [    2.309553] NET: Registered PF_INET6 protocol family
    [    2.310517] Segment Routing with IPv6
    [    2.310554] In-situ OAM (IOAM) with IPv6
    [    2.324547] systemd[1]: systemd 255.21^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.324578] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2025.01!
    [    2.367869] systemd[1]: Hostname set to <am62pxx-evm>.
    [    2.574462] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    2.609060] systemd[1]: Configuration file /usr/lib/systemd/system/seva-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    2.830551] systemd[1]: Queued start job for default target Graphical Interface.
    [  OK  ] Created slice Slice /system/getty    2.845985] systemd[1]: Created slice Slice /system/getty.
    0m.
    [  OK  ] Created slice Slice /system/modprob[    2.860037] systemd[1]: Created slice Slice /system/modprobe.
    e.
    [  OK  ] Created slice Slice /system/serial-[    2.874011] systemd[1]: Created slice Slice /system/serial-getty.
    getty.
    [  OK  ] Created slice User and Session Slic[    2.888410] systemd[1]: Created slice User and Session Slice.
    e.
    [  OK  ] Started Dispatch Password Requests [    2.902052] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Forward Password Requests t[    2.919979] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    2.936838] systemd[1]: Expecting device /dev/ttyS2...
    [  OK  ] Reached target Path Units.
    [    2.947155] systemd[1]: Reached target Path Units.
    [0m.
    [  OK  ] Reached target Slice Units.
    [    2.970770] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Swaps.
    [    2.981375] systemd[1]: Reached target Swaps.
    [  OK  ] Listening on RPCbind Server Activat[    2.994142] systemd[1]: Listening on RPCbind Server Activation Socket.
    ion Socket.
    [  OK  ] Reached target RPC Port Mapper.[    3.009856] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Listening on Process Core Dump Sock[    3.029892] systemd[1]: Listening on Process Core Dump Socket.
    et.
    [  OK  ] Listening on initctl Compatibility [    3.043156] systemd[1]: Listening on initctl Compatibility Named Pipe.
    Named Pipe.
    [  OK  ] Listening on Journal Audit Socket    3.059844] systemd[1]: Listening on Journal Audit Socket.
    0m.
    [  OK  ] Listening on Journal Socket (/dev/l[    3.073386] systemd[1]: Listening on Journal Socket (/dev/log).
    og).
    [  OK  ] Listening on Journal Socket.
    [    3.087439] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Network Service Netlin[    3.099142] systemd[1]: Listening on Network Service Netlink Socket.
    k Socket.
    [  OK  ] Listening on udev Control Socket    3.116395] systemd[1]: Listening on udev Control Socket.
    m.
    [  OK  ] Listening on udev Kernel Socket[    3.130313] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on User Database Manager [    3.143338] systemd[1]: Listening on User Database Manager Socket.
    Socket.
    [    3.182942] systemd[1]: Mounting Huge Pages File System...
    [    3.194416] systemd[1]: POSIX Message Queue File System was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/mqueue).
    [    3.194982] systemd[1]: Kernel Debug File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/debug).
    [    3.195316] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.198739] systemd[1]: Mounting Temporary Directory /tmp...
             Starting Create List of Static Device Nodes    3.249289] systemd[1]: Starting Create List of Static Device Nodes...
    m...
    [    3.267335] systemd[1]: Starting Load Kernel Module configfs...
    [    3.282874] systemd[1]: Starting Load Kernel Module drm...
    [    3.297517] systemd[1]: Starting Load Kernel Module fuse...
    [    3.302213] systemd[1]: Starting Start psplash boot splash screen...
    [    3.328108] systemd[1]: Starting RPC Bind...
    [    3.340447] systemd[1]: Starting File System Check on Root Device...
             Starting File System Check on Root Device.[    3.348325] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    3.348351] systemd[1]: systemd-journald.service: (This warning is only shown for the first unit using IP firewalling.)
    [    3.360038] fuse: init (API version 7.41)
    [    3.380240] systemd[1]: Starting Journal Service...
    [    3.396356] systemd[1]: Starting Load Kernel Modules...
             Starting Generate network units from Kernel co[    3.420253] systemd[1]: Starting Generate network units from Kernel command line...
    mmand line...
    [    3.426068] systemd[1]: Starting Coldplug All udev Devices...
    [  OK  ] Started RPC Bind.
    [    3.448175] systemd[1]: Started RPC Bind.
    [    3.449253] systemd[1]: Mounted Huge Pages File System.
    [    3.454726] systemd-journald[136]: Collecting audit messages is enabled.
    [  OK  ] Mounted Huge Pages File System.[    3.470475] systemd[1]: Mounted Temporary Directory /tmp.
    [  OK  ] Mounted Temporary Directory /tmp[    3.474773] systemd[1]: Finished Create List of Static Device Nodes.
    [  OK  ] Finished Create List of Static Device Nodes.
    [    3.506306] systemd[1]: modprobe@configfs.service: Deactivated successfully.
    [    3.506921] systemd[1]: Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Started Journal Service.
    [    3.527327] systemd[1]: Started Journal Service.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Start psplas…temd progress communication helper.
    [  OK  ] Finished File System Check on Root Device.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev gracefully...
    [  OK  ] Mounted Kernel Configuration File System.
    [    3.821821] EXT4-fs (mmcblk1p2): re-mounted a7cdcc95-d133-4ffc-9a89-0eccd2483259 r/w.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Starting Flush Journal to Persistent Storage...
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Create Static Device Nodes in /dev gracefully.
    [    3.892567] systemd-journald[136]: Received client request to flush runtime journal.
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Finished Flush Journal to Persistent Storage.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /var/volatile...
             Starting Rule-based Manager for Device Events and Files...
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save OS Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create System Files and Directories...
    [  OK  ] Finished Load/Save OS Random Seed.
             Starting User Database Manager...
    [  OK  ] Finished Create System Files and Directories.
             Starting Network Name Resolution...
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Started User Database Manager.
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [    4.469523] mmc_core: exports duplicate symbol __mmc_claim_host (owned by kernel)
    [  OK  ] Found device /dev/ttyS2.
    [    4.532135] mmc_core: exports duplicate symbol __mmc_claim_host (owned by kernel)
    [    4.603157] mmc_core: exports duplicate symbol __mmc_claim_host (owned by kernel)
    [    4.650792] mmc_core: exports duplicate symbol __mmc_claim_host (owned by kernel)
    [    4.784580] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    4.803830] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    4.815801] mc: Linux media interface: v0.10
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.[    4.857904] pps_core: LinuxPPS API ver. 1 registered
    [    4.857920] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    4.930118] PTP clock support registered
    [    4.932355] videodev: Linux video capture interface: v2.00
    [    4.951461] platform 79000000.r5f: configured R5F for remoteproc mode
    [    4.959906] platform 79000000.r5f: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [  OK  ] Started Network Name Resolution.
    [    4.992710] remoteproc remoteproc0: 79000000.r5f is available
    [    5.003043] remoteproc remoteproc0: powering up 79000000.r5f
    [    5.003072] remoteproc remoteproc0: Booting fw image am62p-mcu-r5f0_0-fw, size 59336
    [    5.014975] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    5.020784] platform 78000000.r5f: configured R5F for IPC-only mode
    [    5.020963] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
    [    5.021516] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [    5.021750] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
    [    5.021764] remoteproc remoteproc0: remote processor 79000000.r5f is now up
    [    5.023639] remoteproc remoteproc1: 78000000.r5f is available
    [    5.023657] remoteproc remoteproc1: attaching to 78000000.r5f
    [    5.041025] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node r5f-dma-memory@9c800000
    [    5.041180] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7)
    [    5.041192] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
    [    5.060594] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
    [    5.089293] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
    [    5.104562] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    5.104793] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    5.121453] i2c i2c-1: Added multiplexed i2c bus 3
    [    5.139142] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
    [  OK  ] Reached target Host and Network Nam[    5.152088] [drm] Initialized tidss 1.0.0 for 30200000.dss on minor 0
    [    5.155215] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    5.155851] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    e Lookups.
    [    5.155869] vdec 30210000.video-codec: Product Code:      0x521c
    [    5.155877] vdec 30210000.video-codec: Firmware Revision: 363254
    [    5.157518] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    5.200158] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    5.200174] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    5.200318] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    5.200326] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
    [    5.203064] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API...
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
             Starting D-Bus System Message Bus...
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Finished Reboot and dump vmcore via kexec.
    [  OK  ] Started D-Bus System Message Bus.
    [  OK  ] Created slice Slice /system/tee-supplicant.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started Periodic Command Scheduler.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
    [  OK  ] Started Multiple Spanning Tree Protocol Daemon.
             Starting Telephony service...
             Starting PulseAudio Sound System...
             Starting Expand the rootfs partiti…to full size of the boot device....
    [  OK  ] Started Seva Launcher Service.
    [  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
             Starting User Login Management...
             Starting Virtual Console Setup...
    [  OK  ] Started TEE Supplicant on teepriv0.
             Starting Telnet Server...
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [  OK  ] Finished Telnet Server.
    [  OK  ] Started Telephony service.
    [    6.372076] Bluetooth: Core ver 2.22
    [    6.372176] NET: Registered PF_BLUETOOTH protocol family
    [    6.372180] Bluetooth: HCI device and connection manager initialized
    [    6.372198] Bluetooth: HCI socket layer initialized
    [    6.372206] Bluetooth: L2CAP socket layer initialized
    [    6.372213] Bluetooth: SCO socket layer initialized
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Finished Expand the rootfs partition to full size of the boot device..
    [  OK  ] Created slice Slice /system/systemd-fsck.
    [  OK  ] Reached target Preparation for Network.
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
             Starting File System Check on /dev/mmcblk0p2...
             Starting Network Configuration...
    [  OK  ] Finished Virtual Console Setup.
    [  OK  ] Started PulseAudio Sound System.
    [    6.853966] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    6.872097] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    6.873935] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [  OK  ] Started Network Configuration.
    [  OK  ] Reached target Network.
             Starting containerd container runtime...
             Starting LLDP daemon...
    [  OK  ] Started Netperf Benchmark Server.
             Starting Simple Network Management Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started emptty display manager.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting ti-apps-launcher service...
    [  OK  ] Started LLDP daemon.
    [  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
    [  OK  ] Finished File System Check on /dev/mmcblk0p2.
    [  OK  ] Started containerd container runtime.
             Mounting /run/media/root-mmcblk0p2...
    [    9.225468] EXT4-fs (mmcblk0p2): mounted filesystem eb49b298-5415-45e1-ba7b-df773dcc36e7 r/w with ordered data mode. Quota mode: disabled.
    [  OK  ] Mounted /run/media/root-mmcblk0p2.
    NOTICE: This file system contains the following GPL-3.0 packages:
            adwaita-icon-theme-symbolic
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils-dev
            elfutils
            findutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            hidapi
            kbd-dev
            kbd-keymaps-pine
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libgnutls-dev
            libgnutls-openssl27
            libgomp1
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libopcodes
            libqt6core5compat-plugins
            libqt6core5compat-qmlplugins
            libqt6core5compat6
            libqt6shadertools-dev
            libqt6shadertools-plugins
            libqt6shadertools-qmlplugins
            libqt6shadertools6
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libtasn1-dev
            libunistring-dev
            libunistring5
            m4
            make
            nettle-dev
            nettle
            parted
            piglit
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-dev
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase-staticdev
            qtbase
            qtdeclarative-dev
            qtdeclarative-plugins
            qtdeclarative-qmlplugins
            qtdeclarative-staticdev
            qtdeclarative-tools
            qtdeclarative
            qtlanguageserver-dev
            qtlanguageserver-plugins
            qtlanguageserver-qmlplugins
            qtlanguageserver-staticdev
            qtlanguageserver
            qtmultimedia-plugins
            qtmultimedia-qmlplugins
            qtmultimedia
            qtquick3d-plugins
            qtquick3d-qmlplugins
            qtquick3d
            qtquicktimeline-plugins
            qtquicktimeline-qmlplugins
            qtquicktimeline
            qtsvg-dev
            qtsvg-plugins
            qtsvg-qmlplugins
            qtsvg
            qttools-plugins
            qttools-qmlplugins
            qttools
            qtwayland-dev
            qtwayland-plugins
            qtwayland-qmlplugins
            qtwayland
            tar
            which
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Finished Print notice about GPLv3 packages.
    [   13.034241] audit: type=1006 audit(1748553654.967:2): pid=1085 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [   13.034266] audit: type=1300 audit(1748553654.967:2): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffffa4e2228 a2=4 a3=1 items=0 ppid=1 pid=1085 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
    [   13.034280] audit: type=1327 audit(1748553654.967:2): proctitle="(systemd)"
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am62pxx-evm ttyS2
    Arago 2025.01 am62pxx-evm ttyS2
  • Hi Oliver,
    Please try to add the following inside the "chosen" node in kernel devicetree file k3-am62p5-sk.dts:
    bootargs = "console=ttyS2,115200n8 quiet";
  • I have added
    to the kernel devicetree
    // SPDX-License-Identifier: GPL-2.0-only OR MIT
     * Device Tree file for the AM62P5-SK
     * Copyright (C) 2023-2024 Texas Instruments Incorporated - https://www.ti.com/
     * Schematics: https://www.ti.com/lit/zip/sprr487
    /dts-v1/;
    #include <dt-bindings/leds/common.h>
    #include <dt-bindings/gpio/gpio.h>
    #include <dt-bindings/net/ti-dp83867.h>
    #include "k3-am62p5.dtsi"
    	compatible = "ti,am62p5-sk", "ti,am62p5";
    	model = "Texas Instruments AM62P5 SK";
    	aliases {
    		serial0 = &wkup_uart0;
    		serial1 = &mcu_uart0;
    		serial2 = &main_uart0;
    		serial3 = &main_uart1;
    		mmc0 = &sdhci0;
    		mmc1 = &sdhci1;
    		mmc2 = &sdhci2;
    		spi0 = &ospi0;
    		ethernet0 = &cpsw_port1;
    		ethernet1 = &cpsw_port2;
    		usb0 = &usb0;
    		usb1 = &usb1;
    	chosen {
    		#address-cells = <2>;
    		#size-cells = <2>;
    		ranges;
    		stdout-path = &main_uart0;
    		framebuffer0: framebuffer@0 {
    			compatible = "simple-framebuffer";
    			power-domains = <&k3_pds 186 TI_SCI_PD_EXCLUSIVE>;
    			clocks = <&k3_clks 186 6>,
    				 <&dss0_vp1_clk>,
    				 <&k3_clks 186 2>;
    			display = <&dss0>;
    			status = "disabled";
    	memory@80000000 {
    		/* 8G RAM */
    		reg = <0x00000000 0x80000000 0x00000000 0x80000000>,
    		      <0x00000008 0x80000000 0x00000001 0x80000000>;
    		device_type = "memory";
    		bootph-pre-ram;
    	reserved_memory: reserved-memory {
    		#size-cells = <2>;
    		ranges;
    		linux,cma {
    			compatible = "shared-dma-pool";
    			reusable;
    			size = <0x00 0x24000000>;
    			linux,cma-default;
    		rtos_ipc_memory_region: rtos-ipc-memory@9b500000 {
    			reg = <0x00 0x9b500000 0x00 0x00300000>;
    			no-map;
    		mcu_r5fss0_core0_dma_memory_region: mcu-r5fss-dma-memory-region@9b800000 {
    			reg = <0x00 0x9b800000 0x00 0x100000>;
    			no-map;
    		mcu_r5fss0_core0_memory_region: mcu-r5fss-memory-region@9b900000 {
    			reg = <0x00 0x9b900000 0x00 0xf00000>;
    			no-map;
    		wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9c800000 {
    			reg = <0x00 0x9c800000 0x00 0x100000>;
    			no-map;
    		wkup_r5fss0_core0_memory_region: r5f-memory@9c900000 {
    			reg = <0x00 0x9c900000 0x00 0x1e00000>;
    			no-map;
    		secure_tfa_ddr: tfa@9e780000 {
    			reg = <0x00 0x9e780000 0x00 0x80000>;
    			no-map;
    		secure_ddr: optee@9e800000 {
    			reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */
    			no-map;
    	vmain_pd: regulator-0 {
    		/* TPS65988 PD CONTROLLER OUTPUT */
    		compatible = "regulator-fixed";
    		regulator-name = "vmain_pd";
    		regulator-min-microvolt = <5000000>;
    		regulator-max-microvolt = <5000000>;
    		regulator-always-on;
    		regulator-boot-on;
    		bootph-all;
    	vcc_5v0: regulator-1 {
    		/* Output of TPS630702RNMR */
    		regulator-name = "vcc_5v0";
    		vin-supply = <&vmain_pd>;
    		regulator-boot-on;
    		bootph-all;
    	vdd_mmc1: regulator-2 {
    		/* TPS22918DBVR */
    		regulator-name = "vdd_mmc1";
    		regulator-min-microvolt = <3300000>;
    		regulator-max-microvolt = <3300000>;
    		regulator-boot-on;
    		enable-active-high;
    		gpio = <&exp1 3 GPIO_ACTIVE_HIGH>;
    		bootph-all;
    	vddshv_sdio: regulator-3 {
    		compatible = "regulator-gpio";
    		regulator-name = "vddshv_sdio";
    		pinctrl-names = "default";
    		pinctrl-0 = <&vddshv_sdio_pins_default>;
    		regulator-min-microvolt = <1800000>;
    		regulator-boot-on;
    		gpios = <&main_gpio0 31 GPIO_ACTIVE_HIGH>;
    		states = <1800000 0x0>,
    			 <3300000 0x1>;
    		bootph-all;
    	leds {
    		compatible = "gpio-leds";
    		pinctrl-0 = <&usr_led_pins_default>;
    		led-0 {
    			label = "am62-sk:green:heartbeat";
    			gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>;
    			linux,default-trigger = "heartbeat";
    			function = LED_FUNCTION_HEARTBEAT;
    			default-state = "off";
    	opp-table {
    		/* Requires VDD_CORE at 0v85 */
    		opp-1400000000 {
    			opp-hz = /bits/ 64 <1400000000>;
    			opp-supported-hw = <0x01 0x0004>;
    			clock-latency-ns = <6000000>;
    	tlv320_mclk: clk-0 {
    		#clock-cells = <0>;
    		compatible = "fixed-clock";
    		clock-frequency = <12288000>;
    	codec_audio: sound {
    		compatible = "simple-audio-card";
    		simple-audio-card,name = "AM62x-SKEVM";
    		simple-audio-card,widgets =
    			"Headphone",	"Headphone Jack",
    			"Line",		"Line In",
    			"Microphone",	"Microphone Jack";
    		simple-audio-card,routing =
    			"Headphone Jack",	"HPLOUT",
    			"Headphone Jack",	"HPROUT",
    			"LINE1L",		"Line In",
    			"LINE1R",		"Line In",
    			"MIC3R",		"Microphone Jack",
    			"Microphone Jack",	"Mic Bias";
    		simple-audio-card,format = "dsp_b";
    		simple-audio-card,bitclock-master = <&sound_master>;
    		simple-audio-card,frame-master = <&sound_master>;
    		simple-audio-card,bitclock-inversion;
    		simple-audio-card,cpu {
    			sound-dai = <&mcasp1>;
    		sound_master: simple-audio-card,codec {
    			sound-dai = <&tlv320aic3106>;
    			clocks = <&tlv320_mclk>;
    	hdmi0: connector-hdmi {
    		compatible = "hdmi-connector";
    		label = "hdmi";
    		type = "a";
    		port {
    			hdmi_connector_in: endpoint {
    				remote-endpoint = <&sii9022_out>;
    &main_gpio0 {
    	bootph-all;
    &main_gpio1 {
    	bootph-all;
    &main_pmx0 {
    	bootph-all;
    	main_i2c0_pins_default: main-i2c0-default-pins {
    		pinctrl-single,pins = <
    			AM62PX_IOPAD(0x01e0, PIN_INPUT_PULLUP, 0) /* (B25) I2C0_SCL */
    			AM62PX_IOPAD(0x01e4, PIN_INPUT_PULLUP, 0) /* (A24) I2C0_SDA */
    	main_i2c1_pins_default: main-i2c1-default-pins {
    			AM62PX_IOPAD(0x01e8, PIN_INPUT_PULLUP, 0) /* (C24) I2C1_SCL */
    			AM62PX_IOPAD(0x01ec, PIN_INPUT_PULLUP, 0) /* (B24) I2C1_SDA */
    		bootph-all;
    	main_i2c2_pins_default: main-i2c2-default-pins {
    			AM62PX_IOPAD(0x00b0, PIN_INPUT_PULLUP, 1) /* (T22) GPMC0_CSn2.I2C2_SCL */
    			AM62PX_IOPAD(0x00b4, PIN_INPUT_PULLUP, 1) /* (U25) GPMC0_CSn3.I2C2_SDA */
    	main_gpio1_ioexp_intr_pins_default: main-gpio1-ioexp-intr-default-pins {
    			AM62PX_IOPAD(0x01d4, PIN_INPUT, 7) /* (C22) UART0_RTSn.GPIO1_23 */
    	main_mcasp1_pins_default: main-mcasp1-default-pins {
    			AM62PX_IOPAD(0x0090, PIN_INPUT, 2) /* (U24) GPMC0_BE0n_CLE.MCASP1_ACLKX */
    			AM62PX_IOPAD(0x0098, PIN_INPUT, 2) /* (AA24) GPMC0_WAIT0.MCASP1_AFSX */
    			AM62PX_IOPAD(0x008c, PIN_OUTPUT, 2) /* (T25) GPMC0_WEn.MCASP1_AXR0 */
    			AM62PX_IOPAD(0x0084, PIN_INPUT, 2) /* (R25) GPMC0_ADVn_ALE.MCASP1_AXR2 */
    	main_mdio1_pins_default: main-mdio1-default-pins {
    			AM62PX_IOPAD(0x0160, PIN_OUTPUT, 0) /* (F17) MDIO0_MDC */
    			AM62PX_IOPAD(0x015c, PIN_INPUT, 0) /* (F16) MDIO0_MDIO */
    		bootph-all;
    	main_mmc1_pins_default: main-mmc1-default-pins {
    			AM62PX_IOPAD(0x023c, PIN_INPUT, 0) /* (H20) MMC1_CMD */
    			AM62PX_IOPAD(0x0234, PIN_OUTPUT, 0) /* (J24) MMC1_CLK */
    			AM62PX_IOPAD(0x0230, PIN_INPUT, 0) /* (H21) MMC1_DAT0 */
    			AM62PX_IOPAD(0x022c, PIN_INPUT, 0) /* (H23) MMC1_DAT1 */
    			AM62PX_IOPAD(0x0228, PIN_INPUT, 0) /* (H22) MMC1_DAT2 */
    			AM62PX_IOPAD(0x0224, PIN_INPUT, 0) /* (H25) MMC1_DAT3 */
    			AM62PX_IOPAD(0x0240, PIN_INPUT, 0) /* (D23) MMC1_SDCD */
    		bootph-all;
    	main_mmc2_pins_default: main-mmc2-default-pins {
    			AM62PX_IOPAD(0x0120, PIN_INPUT, 0) /* (K24) MMC2_CMD */
    			AM62PX_IOPAD(0x0118, PIN_OUTPUT, 0) /* (K21) MMC2_CLK */
    			AM62PX_IOPAD(0x011C, PIN_INPUT, 0) /* () MMC2_CLKLB */
    			AM62PX_IOPAD(0x0114, PIN_INPUT, 0) /* (K23) MMC2_DAT0 */
    			AM62PX_IOPAD(0x0110, PIN_INPUT_PULLUP, 0) /* (K22) MMC2_DAT1 */
    			AM62PX_IOPAD(0x010c, PIN_INPUT_PULLUP, 0) /* (L20) MMC2_DAT2 */
    			AM62PX_IOPAD(0x0108, PIN_INPUT_PULLUP, 0) /* (L21) MMC2_DAT3 */
    		bootph-all;
    	main_rgmii1_pins_default: main-rgmii1-default-pins {
    			AM62PX_IOPAD(0x014c, PIN_INPUT, 0) /* (B15) RGMII1_RD0 */
    			AM62PX_IOPAD(0x0150, PIN_INPUT, 0) /* (B16) RGMII1_RD1 */
    			AM62PX_IOPAD(0x0154, PIN_INPUT, 0) /* (A14) RGMII1_RD2 */
    			AM62PX_IOPAD(0x0158, PIN_INPUT, 0) /* (B14) RGMII1_RD3 */
    			AM62PX_IOPAD(0x0148, PIN_INPUT, 0) /* (A16) RGMII1_RXC */
    			AM62PX_IOPAD(0x0144, PIN_INPUT, 0) /* (A15) RGMII1_RX_CTL */
    			AM62PX_IOPAD(0x0134, PIN_INPUT, 0) /* (A18) RGMII1_TD0 */
    			AM62PX_IOPAD(0x0138, PIN_INPUT, 0) /* (C17) RGMII1_TD1 */
    			AM62PX_IOPAD(0x013c, PIN_INPUT, 0) /* (A17) RGMII1_TD2 */
    			AM62PX_IOPAD(0x0140, PIN_INPUT, 0) /* (C16) RGMII1_TD3 */
    			AM62PX_IOPAD(0x0130, PIN_INPUT, 0) /* (B17) RGMII1_TXC */
    			AM62PX_IOPAD(0x012c, PIN_INPUT, 0) /* (B18) RGMII1_TX_CTL */
    		bootph-all;
    	main_rgmii2_pins_default: main-rgmii2-default-pins {
    			AM62PX_IOPAD(0x0184, PIN_INPUT, 0) /* (E19) RGMII2_RD0 */
    			AM62PX_IOPAD(0x0188, PIN_INPUT, 0) /* (E16) RGMII2_RD1 */
    			AM62PX_IOPAD(0x018c, PIN_INPUT, 0) /* (E17) RGMII2_RD2 */
    			AM62PX_IOPAD(0x0190, PIN_INPUT, 0) /* (C19) RGMII2_RD3 */
    			AM62PX_IOPAD(0x0180, PIN_INPUT, 0) /* (D19) RGMII2_RXC */
    			AM62PX_IOPAD(0x017c, PIN_INPUT, 0) /* (F19) RGMII2_RX_CTL */
    			AM62PX_IOPAD(0x016c, PIN_INPUT, 0) /* (B19) RGMII2_TD0 */
    			AM62PX_IOPAD(0x0170, PIN_INPUT, 0) /* (A21) RGMII2_TD1 */
    			AM62PX_IOPAD(0x0174, PIN_INPUT, 0) /* (D17) RGMII2_TD2 */
    			AM62PX_IOPAD(0x0178, PIN_INPUT, 0) /* (A19) RGMII2_TD3 */
    			AM62PX_IOPAD(0x0168, PIN_INPUT, 0) /* (D16) RGMII2_TXC */
    			AM62PX_IOPAD(0x0164, PIN_INPUT, 0) /* (A20) RGMII2_TX_CTL */
    		bootph-all;
    	main_uart0_tx_pins_default: main-uart0-tx-default-pins {
    			AM62PX_IOPAD(0x1cc, PIN_OUTPUT, 0)	/* (B22) UART0_TXD */
    		bootph-all;
    	main_uart0_rx_pins_default: main-uart0-rx-default-pins {
    			AM62PX_IOPAD(0x1c8, PIN_INPUT, 0)	/* (A22) UART0_RXD */
    		bootph-all;
    	main_uart0_rx_pins_wakeup: main-uart0-rx-wakeup-pins {
    			AM62PX_IOPAD(0x1c8, PIN_INPUT | PIN_WKUP_EN, 0)	/* (A22) UART0_RXD */
    	main_uart1_pins_default: main-uart1-default-pins {
    			AM62PX_IOPAD(0x0194, PIN_INPUT, 2) /* (D25) MCASP0_AXR3.UART1_CTSn */
    			AM62PX_IOPAD(0x0198, PIN_OUTPUT, 2) /* (E25) MCASP0_AXR2.UART1_RTSn */
    			AM62PX_IOPAD(0x01ac, PIN_INPUT, 2) /* (G23) MCASP0_AFSR.UART1_RXD */
    			AM62PX_IOPAD(0x01b0, PIN_OUTPUT, 2) /* (G20) MCASP0_ACLKR.UART1_TXD */
    		bootph-all;
    	main_usb1_pins_default: main-usb1-default-pins {
    			AM62PX_IOPAD(0x0258, PIN_INPUT | PIN_DS_PULLUD_ENABLE | PIN_DS_PULL_UP, 0) /* (G21) USB1_DRVVBUS */
    	main_wlirq_pins_default: main-wlirq-default-pins {
    			AM62PX_IOPAD(0x0128, PIN_INPUT, 7) /* (K25) MMC2_SDWP.GPIO0_72 */
    	ospi0_pins_default: ospi0-default-pins {
    			AM62PX_IOPAD(0x0000, PIN_OUTPUT, 0) /* (P23) OSPI0_CLK */
    			AM62PX_IOPAD(0x002c, PIN_OUTPUT, 0) /* (M25) OSPI0_CSn0 */
    			AM62PX_IOPAD(0x000c, PIN_INPUT, 0) /* (L25) OSPI0_D0 */
    			AM62PX_IOPAD(0x0010, PIN_INPUT, 0) /* (N24) OSPI0_D1 */
    			AM62PX_IOPAD(0x0014, PIN_INPUT, 0) /* (N25) OSPI0_D2 */
    			AM62PX_IOPAD(0x0018, PIN_INPUT, 0) /* (M24) OSPI0_D3 */
    			AM62PX_IOPAD(0x001c, PIN_INPUT, 0) /* (N21) OSPI0_D4 */
    			AM62PX_IOPAD(0x0020, PIN_INPUT, 0) /* (N22) OSPI0_D5 */
    			AM62PX_IOPAD(0x0024, PIN_INPUT, 0) /* (P21) OSPI0_D6 */
    			AM62PX_IOPAD(0x0028, PIN_INPUT, 0) /* (N20) OSPI0_D7 */
    			AM62PX_IOPAD(0x0008, PIN_INPUT, 0) /* (P22) OSPI0_DQS */
    		bootph-all;
    	usr_led_pins_default: usr-led-default-pins {
    			AM62PX_IOPAD(0x0244, PIN_INPUT, 7) /* (D24) MMC1_SDWP.GPIO1_49 */
    	vddshv_sdio_pins_default: vddshvr-sdio-default-pins {
    			AM62PX_IOPAD(0x007c, PIN_INPUT, 7) /* (Y25) GPMC0_CLK.GPIO0_31 */
    		bootph-all;
    	wlan_en_pins_default: wlan-en-default-pins {
    			AM62PX_IOPAD(0x0124, PIN_INPUT, 7) /* (J25) MMC2_SDCD.GPIO0_71 */
    	main_dpi_pins_default: main-dpi-default-pins {
    			AM62PX_IOPAD(0x0100, PIN_OUTPUT, 0) /* (W20) VOUT0_VSYNC */
    			AM62PX_IOPAD(0x00f8, PIN_OUTPUT, 0) /* (AC20) VOUT0_HSYNC */
    			AM62PX_IOPAD(0x0104, PIN_OUTPUT, 0) /* (Y21) VOUT0_PCLK */
    			AM62PX_IOPAD(0x00fc, PIN_OUTPUT, 0) /* (W21) VOUT0_DE */
    			AM62PX_IOPAD(0x00b8, PIN_OUTPUT, 0) /* (AE24) VOUT0_DATA0 */
    			AM62PX_IOPAD(0x00bc, PIN_OUTPUT, 0) /* (W23) VOUT0_DATA1 */
    			AM62PX_IOPAD(0x00c0, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA2 */
    			AM62PX_IOPAD(0x00c4, PIN_OUTPUT, 0) /* (Y23) VOUT0_DATA3 */
    			AM62PX_IOPAD(0x00c8, PIN_OUTPUT, 0) /* (AB23) VOUT0_DATA4 */
    			AM62PX_IOPAD(0x00cc, PIN_OUTPUT, 0) /* (AD23) VOUT0_DATA5 */
    			AM62PX_IOPAD(0x00d0, PIN_OUTPUT, 0) /* (AC23) VOUT0_DATA6 */
    			AM62PX_IOPAD(0x00d4, PIN_OUTPUT, 0) /* (AE23) VOUT0_DATA7 */
    			AM62PX_IOPAD(0x00d8, PIN_OUTPUT, 0) /* (AE22) VOUT0_DATA8 */
    			AM62PX_IOPAD(0x00dc, PIN_OUTPUT, 0) /* (AC22) VOUT0_DATA9 */
    			AM62PX_IOPAD(0x00e0, PIN_OUTPUT, 0) /* (W22) VOUT0_DATA10 */
    			AM62PX_IOPAD(0x00e4, PIN_OUTPUT, 0) /* (AE21) VOUT0_DATA11 */
    			AM62PX_IOPAD(0x00e8, PIN_OUTPUT, 0) /* (AD21) VOUT0_DATA12 */
    			AM62PX_IOPAD(0x00ec, PIN_OUTPUT, 0) /* (AC21) VOUT0_DATA13 */
    			AM62PX_IOPAD(0x00f0, PIN_OUTPUT, 0) /* (AA20) VOUT0_DATA14 */
    			AM62PX_IOPAD(0x00f4, PIN_OUTPUT, 0) /* (Y20) VOUT0_DATA15 */
    			AM62PX_IOPAD(0x005c, PIN_OUTPUT, 1) /* (AC25) GPMC0_AD8.VOUT0_DATA16 */
    			AM62PX_IOPAD(0x0060, PIN_OUTPUT, 1) /* (AB25) GPMC0_AD9.VOUT0_DATA17 */
    			AM62PX_IOPAD(0x0064, PIN_OUTPUT, 1) /* (AA25) GPMC0_AD10.VOUT0_DATA18 */
    			AM62PX_IOPAD(0x0068, PIN_OUTPUT, 1) /* (W24) GPMC0_AD11.VOUT0_DATA19 */
    			AM62PX_IOPAD(0x006c, PIN_OUTPUT, 1) /* (Y24) GPMC0_AD12.VOUT0_DATA20 */
    			AM62PX_IOPAD(0x0070, PIN_OUTPUT, 1) /* (AD25) GPMC0_AD13.VOUT0_DATA21 */
    			AM62PX_IOPAD(0x0074, PIN_OUTPUT, 1) /* (AB24) GPMC0_AD14.VOUT0_DATA22 */
    			AM62PX_IOPAD(0x0078, PIN_OUTPUT, 1) /* (AC24) GPMC0_AD15.VOUT0_DATA23 */
    			AM62PX_IOPAD(0x009c, PIN_OUTPUT, 1) /* (AD24) GPMC0_WAIT1.VOUT0_EXTPCLKIN */
    	main_epwm0_pins_default: main_epwm0-default-pins {
    			AM62PX_IOPAD(0x01b4, PIN_OUTPUT, 2) /* (D20) SPI0_CS0.EHRPWM0_A */
    			AM62PX_IOPAD(0x01b8, PIN_OUTPUT, 2) /* (E20) SPI0_CS1.EHRPWM0_B */
    	main_epwm1_pins_default: main_epwm1-default-pins {
    			AM62PX_IOPAD(0x01bc, PIN_OUTPUT, 2) /* (B21) SPI0_CLK.EHRPWM1_A */
    			AM62PX_IOPAD(0x01c0, PIN_OUTPUT, 2) /* (B20) SPI0_D0.EHRPWM1_B */
    	main_ecap1_pins_default: main_ecap1-default-pins {
    			AM62PX_IOPAD(0x019c, PIN_OUTPUT, 2) /* (E24) MCASP0_AXR1.ECAP1_IN_APWM_OUT */
    	main_ecap2_pins_default: main-ecap2-default-pins {
    			AM62PX_IOPAD(0x01a4, PIN_OUTPUT, 2) /* (F24) MCASP0_ACLKX.ECAP2_IN_APWM_OUT */
    &main_i2c0 {
    	status = "okay";
    	pinctrl-0 = <&main_i2c0_pins_default>;
    	clock-frequency = <400000>;
    	typec_pd0: usb-power-controller@3f {
    		compatible = "ti,tps6598x";
    		reg = <0x3f>;
    		connector {
    			compatible = "usb-c-connector";
    			label = "USB-C";
    			self-powered;
    			data-role = "dual";
    			power-role = "sink";
    			port {
    				usb_con_hs: endpoint {
    				remote-endpoint = <&usb0_hs_ep>;
    &main_i2c1 {
    	status = "okay";
    	pinctrl-0 = <&main_i2c1_pins_default>;
    	clock-frequency = <100000>;
    	bootph-all;
    	tlv320aic3106: audio-codec@1b {
    		#sound-dai-cells = <0>;
    		compatible = "ti,tlv320aic3106";
    		reg = <0x1b>;
    		ai3x-micbias-vg = <1>;  /* 2.0V */
    	exp1: gpio@22 {
    		compatible = "ti,tca6424";
    		reg = <0x22>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		gpio-line-names = "OLDI_INT#", "x8_NAND_DETECT",
    				   "UART1_FET_SEL", "MMC1_SD_EN",
    				   "VPP_EN", "EXP_PS_3V3_EN",
    				   "UART1_FET_BUF_EN", "EXP_HAT_DETECT",
    				   "DSI_GPIO0", "DSI_GPIO1",
    				   "OLDI_EDID", "BT_UART_WAKE_SOC_3V3",
    				   "USB_TYPEA_OC_INDICATION", "CSI_GPIO0",
    				   "CSI_GPIO1", "WLAN_ALERTn",
    				   "HDMI_INTn", "TEST_GPIO2",
    				   "MCASP1_FET_EN", "MCASP1_BUF_BT_EN",
    				   "MCASP1_FET_SEL", "DSI_EDID",
    				   "PD_I2C_IRQ", "IO_EXP_TEST_LED";
    		interrupt-parent = <&main_gpio1>;
    		interrupts = <23 IRQ_TYPE_EDGE_FALLING>;
    		interrupt-controller;
    		#interrupt-cells = <2>;
    		pinctrl-0 = <&main_gpio1_ioexp_intr_pins_default>;
    		bootph-all;
    	exp2: gpio@23 {
    		reg = <0x23>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		gpio-line-names = "BT_EN_SOC", "EXP_PS_5V0_EN",
    				   "WL_LT_EN", "",
    				   "TP3", "TP6",
    				   "TP4", "TP7",
    				   "TP5", "TP8",
    				   "SoC_I2C2_MCAN_SEL", "GPIO_HDMI_RSTn",
    				   "GPIO_CPSW2_RST", "GPIO_CPSW1_RST",
    				   "GPIO_OLDI_RSTn", "GPIO_AUD_RSTn",
    				   "GPIO_eMMC_RSTn", "SoC_WLAN_SDIO_RST";
    	sii9022: bridge-hdmi@3b {
    		compatible = "sil,sii9022";
    		reg = <0x3b>;
    		interrupt-parent = <&exp1>;
    		interrupts = <16 IRQ_TYPE_EDGE_FALLING>;
    		sil,i2s-data-lanes = < 0 >;
    		hdmi_tx_ports: ports {
    			#address-cells = <1>;
    			#size-cells = <0>;
    			 * HDMI can be serviced with 3 potential VPs -
    			 * (DSS0 VP1 / DSS1 VP0 / DSS1 VP1).
    			 * For now, we will service it with DSS0 VP1.
    			port@0 {
    				reg = <0>;
    				sii9022_in: endpoint {
    					remote-endpoint = <&dss0_dpi1_out>;
    			port@1 {
    				reg = <1>;
    				sii9022_out: endpoint {
    					remote-endpoint = <&hdmi_connector_in>;
    &main_i2c2 {
    	status = "okay";
    	pinctrl-0 = <&main_i2c2_pins_default>;
    &sdhci0 {
    	status = "okay";
    	ti,driver-strength-ohm = <50>;
    	disable-wp;
    	bootph-all;
    &sdhci1 {
    	/* SD/MMC */
    	status = "okay";
    	vmmc-supply = <&vdd_mmc1>;
    	vqmmc-supply = <&vddshv_sdio>;
    	pinctrl-0 = <&main_mmc1_pins_default>;
    	disable-wp;
    	bootph-all;
    &cpsw3g {
    	pinctrl-0 = <&main_rgmii1_pins_default>,
    		    <&main_rgmii2_pins_default>;
    	status = "okay";
    &cpsw_port1 {
    	phy-mode = "rgmii-rxid";
    	phy-handle = <&cpsw3g_phy0>;
    	status = "okay";
    &cpsw_port2 {
    	phy-handle = <&cpsw3g_phy1>;
    	status = "okay";
    &cpsw3g_mdio {
    	pinctrl-0 = <&main_mdio1_pins_default>;
    	status = "okay";
    	cpsw3g_phy0: ethernet-phy@0 {
    		reg = <0>;
    		bootph-all;
    		ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
    		ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
    		ti,min-output-impedance;
    	cpsw3g_phy1: ethernet-phy@1 {
    		reg = <1>;
    &usbss0 {
    	status = "okay";
    	ti,vbus-divider;
    &usbss1 {
    	status = "okay";
    	ti,vbus-divider;
    &usb0 {
    	usb-role-switch;
    	port {
    		usb0_hs_ep: endpoint {
    			remote-endpoint = <&usb_con_hs>;
    &usb0_phy_ctrl {
    	bootph-all;
    &usb1 {
    	dr_mode = "host";
    	pinctrl-0 = <&main_usb1_pins_default>;
    &mcasp1 {
    	status = "okay";
    	pinctrl-0 = <&main_mcasp1_pins_default>;
    	op-mode = <0>;          /* MCASP_IIS_MODE */
    	tdm-slots = <2>;
    	serial-dir = <  /* 0: INACTIVE, 1: TX, 2: RX */
    	       1 0 2 0
    	       0 0 0 0
    	       0 0 0 0
    	       0 0 0 0
    &fss {
    	bootph-all;
    &ospi0 {
    	status = "okay";
    	pinctrl-0 = <&ospi0_pins_default>;
    	bootph-all;
    	flash@0 {
    		compatible = "jedec,spi-nor";
    		reg = <0x0>;
    		spi-tx-bus-width = <8>;
    		spi-rx-bus-width = <8>;
    		spi-max-frequency = <25000000>;
    		cdns,tshsl-ns = <60>;
    		cdns,tsd2d-ns = <60>;
    		cdns,tchsh-ns = <60>;
    		cdns,tslch-ns = <60>;
    		cdns,read-delay = <4>;
    		cdns,phy-mode;
    		bootph-all;
    		partitions {
    			compatible = "fixed-partitions";
    			#size-cells = <1>;
    			bootph-all;
    			partition@0 {
    				label = "ospi.tiboot3";
    				reg = <0x00 0x80000>;
    			partition@80000 {
    				label = "ospi.tispl";
    				reg = <0x80000 0x200000>;
    			partition@280000 {
    				label = "ospi.u-boot";
    				reg = <0x280000 0x400000>;
    			partition@680000 {
    				label = "ospi.env";
    				reg = <0x680000 0x40000>;
    			partition@6c0000 {
    				label = "ospi.env.backup";
    				reg = <0x6c0000 0x40000>;
    			partition@800000 {
    				label = "ospi.rootfs";
    				reg = <0x800000 0x37c0000>;
    			partition@3fc0000 {
    				label = "ospi.phypattern";
    				reg = <0x3fc0000 0x40000>;
    				bootph-all;
    &mailbox0_cluster0 {
    	status = "okay";
    	mbox_r5_0: mbox-r5-0 {
    		ti,mbox-rx = <0 0 0>;
    		ti,mbox-tx = <1 0 0>;
    &mailbox0_cluster1 {
    	status = "okay";
    	mbox_mcu_r5_0: mbox-mcu-r5-0 {
    &wkup_r5fss0 {
    	status = "okay";
    &wkup_r5fss0_core0 {
    	mboxes = <&mailbox0_cluster0 &mbox_r5_0>;
    	memory-region = <&wkup_r5fss0_core0_dma_memory_region>,
    			<&wkup_r5fss0_core0_memory_region>;
    &mcu_r5fss0 {
    	status = "okay";
    &mcu_r5fss0_core0 {
    	mboxes = <&mailbox0_cluster1 &mbox_mcu_r5_0>;
    	memory-region = <&mcu_r5fss0_core0_dma_memory_region>,
    			<&mcu_r5fss0_core0_memory_region>;
    &main_uart0 {
    	pinctrl-names = "default", "wakeup";
    	pinctrl-0 = <&main_uart0_tx_pins_default>, <&main_uart0_rx_pins_default>;
    	pinctrl-1 = <&main_uart0_tx_pins_default>, <&main_uart0_rx_pins_wakeup>;
    	wakeup-source = <&system_deep_sleep>,
    			<&system_mcu_only>,
    			<&system_standby>;
    	status = "okay";
    	bootph-all;
    &main_uart1 {
    	pinctrl-0 = <&main_uart1_pins_default>;
    	/* Main UART1 is used by TIFS firmware */
    	status = "reserved";
    	bootph-all;
    &mcu_pmx0 {
    	bootph-all;
    	wkup_uart0_pins_default: wkup-uart0-default-pins {
    			AM62PX_MCU_IOPAD(0x024, PIN_INPUT, 0)	/* (D8) WKUP_UART0_RXD */
    			AM62PX_MCU_IOPAD(0x028, PIN_OUTPUT, 0)	/* (D7) WKUP_UART0_TXD */
    		bootph-all;
    &wkup_uart0 {
    	/* WKUP UART0 is used by DM firmware */
    	pinctrl-0 = <&wkup_uart0_pins_default>;
    	bootph-all;
    /* mcu_gpio0 and mcu_gpio_intr are reserved for mcu firmware usage */
    &mcu_gpio0 {
    &mcu_gpio_intr {
    &dss_oldi_io_ctrl {
    	bootph-all;
    &dss0 {
    	bootph-all;
    	status = "okay";
    	pinctrl-0 = <&main_dpi_pins_default>;
    &dss0_ports {
    	/* DSS0-VP2: DPI/HDMI Output */
    	hdmi0_dss: port@1 {
    		reg = <1>;
    		dss0_dpi1_out: endpoint {
    			remote-endpoint = <&sii9022_in>;
    &epwm0 {
    	/* Pin 24/26 of J4 */
    	pinctrl-0 = <&main_epwm0_pins_default>;
    	status = "okay";
    &epwm1 {
    	/* Pin 23/19 of J4 */
    	pinctrl-0 = <&main_epwm1_pins_default>;
    	status = "okay";
    &ecap1 {
    	/* ECAP1 in APWM mode */
    	/* Pin 36 of J4 */
    	pinctrl-0 = <&main_ecap1_pins_default>;
    	status = "okay";
    &ecap2 {
    	/* ECAP2 in APWM mode */
    	/* Pin 11 of J4 */
    	pinctrl-0 = <&main_ecap2_pins_default>;
    	status = "okay";
    compiled it using
    make DTC_FLAGS=-@ ARCH=arm64 CROSS_COMPILE="$CROSS_COMPILE_64" ti/k3-am62p5-sk.dtb
    and then created the fitImage with the new dtb for falcon mode and added it to my /rootfs/boot directory.
    I get the following boot log:
    U-Boot SPL 2025.01-gc779c758475c-dirty (Nov 21 2025 - 12:04:03 +0000)
    I/TC:
    [    0.000420] Console: colour dummy device 80x25
    [    0.000477] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=200000)
    [    0.000487] pid_max: default: 32768 minimum: 301
    [    0.000550] LSM: initializing lsm=capability
    [    0.000691] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.000720] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.002405] rcu: Hierarchical SRCU implementation.
    [    0.002414] rcu:     Max phase no-delay instances is 400.
    [    0.002629] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.002766] EFI services will not be available.
    [    0.002898] smp: Bringing up secondary CPUs ...
    [    0.011552] Detected VIPT I-cache on CPU1
    [    0.011633] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.011649] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
    [    0.011694] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.020410] Detected VIPT I-cache on CPU2
    [    0.020469] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.020482] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000
    [    0.020516] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.029199] Detected VIPT I-cache on CPU3
    [    0.029258] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.029271] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000
    [    0.029301] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.029444] smp: Brought up 1 node, 4 CPUs
    [    0.029451] SMP: Total of 4 processors activated.
    [    0.029454] CPU: All CPU(s) started at EL2
    [    0.029458] CPU features: detected: 32-bit EL0 Support
    [    0.029461] CPU features: detected: CRC32 instructions
    [    0.029491] alternatives: applying system-wide alternatives
    [    0.029877] Memory: 7490428K/8388608K available (7872K kernel code, 922K rwdata, 1760K rodata, 1536K init, 564K bss, 299628K reserved, 589824K cma-reserved)
    [    0.030860] devtmpfs: initialized
    [    0.042559] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
    [    0.042582] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.080177] 29552 pages in range for non-PLT usage
    [    0.080192] 521072 pages in range for PLT usage
    [    0.080429] pinctrl core: initialized pinctrl subsystem
    [    0.080887] DMI not present or invalid.
    [    0.081504] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.082686] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [    0.082811] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.082922] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.082951] audit: initializing netlink subsys (disabled)
    [    0.083107] audit: type=2000 audit(0.082:1): state=initialized audit_enabled=0 res=1
    [    0.083617] ASID allocator initialised with 65536 entries
    [    0.088415] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
    [    0.088540] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.088574] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.088631] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.088750] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.094468] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.094643] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.095608] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.097908] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.097993] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.099657] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    0.099747] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.100377] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.100384] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.100390] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.100393] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.100397] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.100400] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.100404] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.100407] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.101293] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.0 JTAGID[0x0bb9d02f] Detected
    [    0.101853] iommu: Default domain type: Translated
    [    0.101860] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.102838] EDAC MC: Ver: 3.0.0
    [    0.103171] scmi_core: SCMI protocol bus registered
    [    0.104768] clocksource: Switched to clocksource arch_sys_counter
    [    0.113108] NET: Registered PF_INET protocol family
    [    0.113393] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.118735] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear)
    [    0.118854] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.118871] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.119366] TCP bind hash table entries: 65536 (order: 10, 5242880 bytes, vmalloc hugepage)
    [    0.122954] TCP: Hash tables configured (established 65536 bind 65536)
    [    0.123129] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear)
    [    0.123395] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear)
    [    0.123850] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.124300] RPC: Registered named UNIX socket transport module.
    [    0.124307] RPC: Registered udp transport module.
    [    0.124310] RPC: Registered tcp transport module.
    [    0.124312] RPC: Registered tcp-with-tls transport module.
    [    0.124315] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.125381] Initialise system trusted keyrings
    [    0.125514] workingset: timestamp_bits=62 max_order=21 bucket_order=0
    [    0.126138] NFS: Registering the id_resolver key type
    [    0.126177] Key type id_resolver registered
    [    0.126181] Key type id_legacy registered
    [    0.126205] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.126210] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.169463] Key type asymmetric registered
    [    0.169471] Asymmetric key parser 'x509' registered
    [    0.169540] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [    0.169546] io scheduler mq-deadline registered
    [    0.169550] io scheduler kyber registered
    [    0.169570] io scheduler bfq registered
    [    0.172157] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.172889] pinctrl-single f4000.pinctrl: 172 pins, size 688
    [    0.179183] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.190323] loop: module loaded
    [    0.192593] i2c_dev: i2c /dev entries driver
    [    0.193259] sdhci: Secure Digital Host Controller Interface driver
    [    0.193263] sdhci: Copyright(c) Pierre Ossman
    [    0.193479] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.194191] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.195222] optee: probing for conduit method.
    [    0.195256] optee: revision 4.7 (a9690ae39995af36)
    [    0.211927] optee: dynamic shared memory is enabled
    [    0.212611] optee: initialized driver
    [    0.212721] random: crng init done
    [    0.213177] NET: Registered PF_PACKET protocol family
    [    0.213256] Key type dns_resolver registered
    [    0.219725] Loading compiled-in X.509 certificates
    [    0.231754] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.1.5--v11.01.05d (Fancy Rat)')
    [    0.270893] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.271001] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.272671] pca953x 1-0023: supply vcc not found, using dummy regulator
    [    0.272786] pca953x 1-0023: using AI
    [    0.287272] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.287366] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.287445] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    0.287517] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.287745] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.288999] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    0.289235] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    0.289493] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    0.289807] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
    [    0.290395] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    0.293877] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    0.297336] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    0.303800] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    0.306293] ti-udma 4e230000.dma-controller: Number of rings: 6
    [    0.307046] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
    [    0.308565] printk: legacy console [ttyS2] disabled
    [    0.308996] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 249, base_baud = 3000000) is a 8250
    [    0.309072] printk: legacy console [ttyS2] enabled
    [    0.319115] mmc0: CQHCI version 5.10
    [    0.319154] sdhci-am654 fa10000.mmc: Disable descoped HS400 mode for this silicon revision
    [    0.327228] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    0.327419] pca953x 1-0022: using AI
    [    0.337169] mmc1: CQHCI version 5.10
    [    0.339047] clk: Disabling unused clocks
    [    0.344612] PM: genpd: Disabling unused power domains
    [    0.360278] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    0.376377] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    0.424079] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
    [    0.424650] mmcblk1: mmc1:59b4 SN32G 29.7 GiB
    [    0.426359]  mmcblk1: p1 p2
    [    0.445912] mmc0: Command Queue Engine enabled
    [    0.445933] mmc0: new HS200 MMC card at address 0001
    [    0.446482] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    0.447677]  mmcblk0: p1 p2
    [    0.448239] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    0.449062] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    0.449944] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (248:0)
    [    2.009814] EXT4-fs (mmcblk1p2): orphan cleanup on readonly fs
    [    2.013046] EXT4-fs (mmcblk1p2): mounted filesystem a7cdcc95-d133-4ffc-9a89-0eccd2483259 ro with ordered data mode. Quota mode: disabled.
    [    2.013148] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    2.013732] devtmpfs: mounted
    [    2.014339] Freeing unused kernel memory: 1536K
    [    2.014429] Run /sbin/init as init process
    [    2.200455] systemd[1]: System time before build time, advancing clock.
    [    2.311204] NET: Registered PF_INET6 protocol family
    [    2.312141] Segment Routing with IPv6
    [    2.312176] In-situ OAM (IOAM) with IPv6
    [    2.326565] systemd[1]: systemd 255.21^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.326594] systemd[1]: Detected architecture arm64.
    [    2.370009] systemd[1]: Hostname set to <am62pxx-evm>.
    [    2.568525] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    2.602235] systemd[1]: Configuration file /usr/lib/systemd/system/seva-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    2.823571] systemd[1]: Queued start job for default target Graphical Interface.
    [  OK  ] Created slice Slice /system/getty    2.839975] systemd[1]: Created slice Slice /system/getty.
    0m.
    [  OK  ] Created slice Slice /system/modprob[    2.854218] systemd[1]: Created slice Slice /system/modprobe.
    e.
    [  OK  ] Created slice Slice /system/serial-[    2.868187] systemd[1]: Created slice Slice /system/serial-getty.
    getty.
    [  OK  ] Created slice User and Session Slic[    2.882574] systemd[1]: Created slice User and Session Slice.
    e.
    [  OK  ] Started Dispatch Password Requests [    2.896226] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Forward Password Requests t[    2.914145] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    2.930981] systemd[1]: Expecting device /dev/ttyS2...
    [    2.941270] systemd[1]: Reached target Path Units.
    [    2.951715] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    2.964911] systemd[1]: Reached target Slice Units.
    [    2.975505] systemd[1]: Reached target Swaps.
    [  OK  ] Listening on RPCbind Server Activat[    2.988493] systemd[1]: Listening on RPCbind Server Activation Socket.
    ion Socket.
    [  OK  ] Reached target RPC Port Mapper.[    3.003025] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Listening on Process Core Dump Sock[    3.023034] systemd[1]: Listening on Process Core Dump Socket.
    et.
    [  OK  ] Listening on initctl Compatibility [    3.036304] systemd[1]: Listening on initctl Compatibility Named Pipe.
    Named Pipe.
    [  OK  ] Listening on Journal Audit Socket    3.052988] systemd[1]: Listening on Journal Audit Socket.
    0m.
    [  OK  ] Listening on Journal Socket (/dev/l[    3.067531] systemd[1]: Listening on Journal Socket (/dev/log).
    og).
    [    3.082588] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Network Service Netlin[    3.094207] systemd[1]: Listening on Network Service Netlink Socket.
    k Socket.
    [  OK  ] Listening on udev Control Socket    3.111577] systemd[1]: Listening on udev Control Socket.
    m.
    [  OK  ] Listening on udev Kernel Socket[    3.125466] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on User Database Manager [    3.138479] systemd[1]: Listening on User Database Manager Socket.
    Socket.
    [    3.172061] systemd[1]: Mounting Huge Pages File System...
    [    3.183517] systemd[1]: POSIX Message Queue File System was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/mqueue).
    [    3.184311] systemd[1]: Kernel Debug File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/debug).
    [    3.184683] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.188026] systemd[1]: Mounting Temporary Directory /tmp...
             Starting Create List of Static Device Nodes    3.253358] systemd[1]: Starting Create List of Static Device Nodes...
    m...
    [    3.271389] systemd[1]: Starting Load Kernel Module configfs...
    [    3.286924] systemd[1]: Starting Load Kernel Module drm...
    [    3.301666] systemd[1]: Starting Load Kernel Module fuse...
             Starting Start psplash boot splash screen.[    3.318109] systemd[1]: Starting Start psplash boot splash screen...
    [    3.346404] systemd[1]: Starting RPC Bind...
    [    3.349061] fuse: init (API version 7.41)
             Starting File System Check on Root Device.[    3.369436] systemd[1]: Starting File System Check on Root Device...
    [    3.383949] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    3.383970] systemd[1]: systemd-journald.service: (This warning is only shown for the first unit using IP firewalling.)
    [    3.386999] systemd[1]: Starting Journal Service...
    [    3.427398] systemd[1]: Starting Load Kernel Modules...
    [    3.431504] systemd[1]: Starting Generate network units from Kernel command line...
             Starting Generate network units from Kernel co[    3.449852] systemd[1]: Starting Coldplug All udev Devices...
    mmand line...
             Starting Coldplug All udev[    3.456120] systemd-journald[132]: Collecting audit messages is enabled.
     Devices...
    [    3.460676] systemd[1]: Started RPC Bind.
    [    3.476502] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System    3.477345] systemd[1]: Mounted Temporary Directory /tmp.
    m.
    [  OK  ] Mounted Temporary Directory /tmp    3.498555] systemd[1]: Finished Create List of Static Device Nodes.
    m.
    [    3.520596] systemd[1]: Started Journal Service.
             Starting Remount Root and Kernel File Systems...
    [  OK  ] Mounted FUSE Control File System.
    [    3.792565] EXT4-fs (mmcblk1p2): re-mounted a7cdcc95-d133-4ffc-9a89-0eccd2483259 r/w.
    [  OK  ] Finished Apply Kernel Variables[    3.865939] systemd-journald[132]: Received client request to flush runtime journal.
    [    4.496401] mmc_core: exports duplicate symbol __mmc_claim_host (owned by kernel)
    [    4.612631] mmc_core: exports duplicate symbol __mmc_claim_host (owned by kernel)
    [    4.661622] mmc_core: exports duplicate symbol __mmc_claim_host (owned by kernel)
    [    4.696619] mmc_core: exports duplicate symbol __mmc_claim_host (owned by kernel)
    [    4.874465] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    4.876287] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    5.001030] pps_core: LinuxPPS API ver. 1 registered
    [    5.001048] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    5.001447] mc: Linux media interface: v0.10
    [  OK  ] Started Network Name Resolution[    5.024906] platform 79000000.r5f: configured R5F for remoteproc mode
    [    5.026099] platform 79000000.r5f: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [    5.032556] remoteproc remoteproc0: 79000000.r5f is available
    [    5.034624] PTP clock support registered
    [    5.055056] remoteproc remoteproc0: powering up 79000000.r5f
    [    5.055086] remoteproc remoteproc0: Booting fw image am62p-mcu-r5f0_0-fw, size 59336
    [    5.110444] videodev: Linux video capture interface: v2.00
    [    5.120473] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [    5.120643] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
    [    5.120655] remoteproc remoteproc0: remote processor 79000000.r5f is now up
    [    5.135031] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    5.135182] platform 78000000.r5f: configured R5F for IPC-only mode
    [    5.135327] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
    [    5.219583] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    5.219731] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    5.221235] remoteproc remoteproc1: 78000000.r5f is available
    [    5.221253] remoteproc remoteproc1: attaching to 78000000.r5f
    [    5.230546] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node r5f-dma-memory@9c800000
    [    5.230686] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7)
    [    5.230696] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
    [    5.253018] i2c i2c-1: Added multiplexed i2c bus 3
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Reached target System Initializatio[    5.288749] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
    n.
    [    5.289361] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
    [    5.300263] [drm] Initialized tidss 1.0.0 for 30200000.dss on minor 0
    [  OK  ] Started Daily Cleanup of Temporary [    5.335505] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
    Directories.
    [    5.401260] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    5.401280] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    5.401437] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    5.401449] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
    [    5.408967] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
    [    5.420337] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    [    5.420355] vdec 30210000.video-codec: Product Code:      0x521c
    [    5.420362] vdec 30210000.video-codec: Firmware Revision: 363254
    [    5.423435] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device
             Expecting device /dev/mmcblk0p2...
    [  OK  ] Started Job spooling tools.
    [  OK  ] Found device /dev/mmcblk0p2.
    [    6.397495] Bluetooth: Core ver 2.22
    [    6.397593] NET: Registered PF_BLUETOOTH protocol family
    [    6.397597] Bluetooth: HCI device and connection manager initialized
    [    6.397614] Bluetooth: HCI socket layer initialized
    [    6.397623] Bluetooth: L2CAP socket layer initialized
    [    6.397631] Bluetooth: SCO socket layer initialized
    [  OK  ] Started User Login Management.
    [    6.759752] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    6.777700] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    6.779057] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [    9.208073] EXT4-fs (mmcblk0p2): mounted filesystem eb49b298-5415-45e1-ba7b-df773dcc36e7 r/w with ordered data mode. Quota mode: disabled.
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils-dev
            elfutils
            findutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            hidapi
            kbd-dev
            kbd-keymaps-pine
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libgnutls-dev
            libgnutls-openssl27
            libgomp1
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libopcodes
            libqt6core5compat6
            libqt6shadertools6
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libtasn1-dev
            libunistring-dev
            libunistring5
            m4
            make
            nettle-dev
            nettle
            parted
            piglit
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-dev
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase-staticdev
            qtbase
            qtdeclarative-dev
            qtdeclarative-tools
            qtdeclarative
            qtlanguageserver
            qtmultimedia
            qtquick3d-plugins
            qtquick3d
            qtquicktimeline
            qtsvg-dev
            qtsvg-plugins
            qtsvg-qmlplugins
            qtsvg
            qttools-plugins
            qttools-qmlplugins
            qttools
            qtwayland-dev
            qtwayland-plugins
            qtwayland
            tar
            which
    [   12.917987] audit: type=1006 audit(1748554075.207:2): pid=1081 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [   12.918012] audit: type=1300 audit(1748554075.207:2): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffff23437c8 a2=4 a3=1 items=0 ppid=1 pid=1081 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
    [   12.918027] audit: type=1327 audit(1748554075.207:2): proctitle="(systemd)"
     _____                    _____           _         _
                  |___|                    |___|
    am62pxx-evm login:
  • Hi Oliver,
    From the logs that you have shared, the bootargs with quiet has not taken effect.
    Can you check the below link:
    https://software-dl.ti.com/processor-sdk-linux/esd/AM62PX/11_01_16_13/exports/docs/linux/How_to_Guides/Target/How_to_boot_quickly.html#reducing-linux-kernel-boot-time
    And add the bootargs as specified or add in CONFIG_CMDLINE and give it a try.
    Let me know how it goes.
    Suren
