file sys in android GB was not built
after executing command
make TARGET_PRODUCT= <product name> OMAPES=5.x -j8
bin folder in out//host/linux-x86/ is not formed
what might be the problem
    Please make sure there are no spaces after the = sign
    eg:
    make TARGET_PRODUCT=omap3evm OMAPES=5.x
  • i had executed that command with out any space, just like you had given.
  • do i have to use this command
    make TARGET_PRODUCT=omap3evm OMAPES=5.x   or
    make TARGET_PRODUCT=omap3evm OMAPES=5.x -j4
    as i am trying to build for two core processor for am37X
    when i use 2nd command out/host/linux-x86/bin is not created
    and if i use the first command i get this error
    [out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/RefBase.o] Error 1
    how to solve this ??
  • Are you using the DevKit sources or the latest sources from gitorious.org/rowboat?
    In either case there should not be a build error irrespective of whether you are using -j4 option or not. Can you attach the full build log for us to analyze this?
  • I downloaded it from
    http://software-dl.ti.com/dsps/dsps_public_sw/sdo_tii/TI_Android_DevKit/TI_Android_GingerBread_2_3_4_DevKit_2_1/index_FDS.html
    and i am pasting complete log which is coming while building android file system
    *(I was not able to attach log file )
    PLATFORM_VERSION_CODENAME=REL
    PLATFORM_VERSION=2.3.4
    TARGET_BUILD_VARIANT=eng
    TARGET_SIMULATOR=
    TARGET_BUILD_TYPE=release
    TARGET_BUILD_APPS=
    TARGET_ARCH=arm
    HOST_ARCH=x86
    HOST_OS=linux
    HOST_BUILD_TYPE=release
    BUILD_ID=GRJ22
    Checking build tools versions...
    host Java: apicheck (out/host/common/obj/JAVA_LIBRARIES/apicheck_intermediates/classes)
    Header: out/host/linux-x86/obj/include/libexpat/expat.h
    Header: out/host/linux-x86/obj/include/libexpat/expat_external.h
    Header: out/target/product/omap3evm/obj/include/libexpat/expat.h
    Header: out/target/product/omap3evm/obj/include/libexpat/expat_external.h
    Header: out/host/linux-x86/obj/include/libpng/png.h
    Header: out/host/linux-x86/obj/include/libpng/pngconf.h
    Header: out/host/linux-x86/obj/include/libpng/pngusr.h
    Header: out/target/product/omap3evm/obj/include/libpng/png.h
    Header: out/target/product/omap3evm/obj/include/libpng/pngconf.h
    Header: out/target/product/omap3evm/obj/include/libpng/pngusr.h
    Header: out/target/product/omap3evm/obj/include/libwpa_client/wpa_ctrl.h
    Header: out/target/product/omap3evm/obj/include/libsonivox/eas.h
    Header: out/target/product/omap3evm/obj/include/libsonivox/eas_types.h
    Header: out/target/product/omap3evm/obj/include/libsonivox/eas_reverb.h
    Header: out/target/product/omap3evm/obj/include/libsonivox/jet.h
    Header: out/target/product/omap3evm/obj/include/libsonivox/ARM_synth_constants_gnu.inc
    host C: acp <= build/tools/acp/acp.c
    host C++: libhost <= build/libs/host/pseudolocalize.cpp
    host C: libhost <= build/libs/host/CopyFile.c
    host StaticLib: libhost (out/host/linux-x86/obj/STATIC_LIBRARIES/libhost_intermediates/libhost.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libhost_intermediates/pseudolocalize.o out/host/linux-x86/obj/STATIC_LIBRARIES/libhost_intermediates/CopyFile.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libhost_intermediates/libhost.a
    host Executable: acp (out/host/linux-x86/obj/EXECUTABLES/acp_intermediates/acp)
    true
    Install: out/host/linux-x86/bin/acp
    Install: out/host/linux-x86/framework/apicheck.jar
    host Java: clearsilver (out/host/common/obj/JAVA_LIBRARIES/clearsilver_intermediates/classes)
    Install: out/host/linux-x86/framework/clearsilver.jar
    host Java: droiddoc (out/host/common/obj/JAVA_LIBRARIES/droiddoc_intermediates/classes)
    Install: out/host/linux-x86/framework/droiddoc.jar
    target Generated: libclearsilver-jni <= out/host/common/obj/JAVA_LIBRARIES/clearsilver_intermediates/javalib.jar
    host C: libclearsilver-jni <= external/clearsilver/java-jni/j_neo_util.c
    host C: libclearsilver-jni <= external/clearsilver/java-jni/j_neo_cs.c
    host C: libneo_util <= external/clearsilver/util/neo_err.c
    host C: libneo_util <= external/clearsilver/util/neo_files.c
    host C: libneo_util <= external/clearsilver/util/neo_misc.c
    host C: libneo_util <= external/clearsilver/util/neo_rand.c
    host C: libneo_util <= external/clearsilver/util/ulist.c
    host C: libneo_util <= external/clearsilver/util/neo_hdf.c
    host C: libneo_util <= external/clearsilver/util/neo_str.c
    host C: libneo_util <= external/clearsilver/util/neo_date.c
    host C: libneo_util <= external/clearsilver/util/wildmat.c
    host C: libneo_util <= external/clearsilver/util/ulocks.c
    host C: libneo_util <= external/clearsilver/util/neo_hash.c
    host SharedLib: libneo_util (out/host/linux-x86/obj/lib/libneo_util.so)
    host C: libneo_cs <= external/clearsilver/cs/csparse.c
    host SharedLib: libneo_cs (out/host/linux-x86/obj/lib/libneo_cs.so)
    host C: libneo_cgi <= external/clearsilver/cgi/cgiwrap.c
    host C: libneo_cgi <= external/clearsilver/cgi/cgi.c
    host C: libneo_cgi <= external/clearsilver/cgi/html.c
    host C: libneo_cgi <= external/clearsilver/cgi/date.c
    host C: libneo_cgi <= external/clearsilver/cgi/rfc2388.c
    host SharedLib: libneo_cgi (out/host/linux-x86/obj/lib/libneo_cgi.so)
    host SharedLib: libclearsilver-jni (out/host/linux-x86/obj/lib/libclearsilver-jni.so)
    Install: out/host/linux-x86/lib/libneo_util.so
    Install: out/host/linux-x86/lib/libneo_cs.so
    Install: out/host/linux-x86/lib/libneo_cgi.so
    Install: out/host/linux-x86/lib/libclearsilver-jni.so
    target Java: core (out/target/common/obj/JAVA_LIBRARIES/core_intermediates/classes)
    Copying: out/target/common/obj/JAVA_LIBRARIES/core_intermediates/classes-jarjar.jar
    Copying: out/target/common/obj/JAVA_LIBRARIES/core_intermediates/emma_out/lib/classes-jarjar.jar
    Copying: out/target/common/obj/JAVA_LIBRARIES/core_intermediates/classes.jar
    Copying: out/target/common/obj/JAVA_LIBRARIES/core_intermediates/noproguard.classes.jar
    host Java: dx (out/host/common/obj/JAVA_LIBRARIES/dx_intermediates/classes)
    Install: out/host/linux-x86/framework/dx.jar
    Copy: dx (out/host/linux-x86/obj/EXECUTABLES/dx_intermediates/dx)
    Install: out/host/linux-x86/bin/dx
    target Dex: core
    Copying: out/target/common/obj/JAVA_LIBRARIES/core_intermediates/noproguard.classes.dex
    host C++: aapt <= frameworks/base/tools/aapt/AaptAssets.cpp
    host C++: aapt <= frameworks/base/tools/aapt/Command.cpp
    host C++: aapt <= frameworks/base/tools/aapt/Main.cpp
    host C++: aapt <= frameworks/base/tools/aapt/Package.cpp
    host C++: aapt <= frameworks/base/tools/aapt/StringPool.cpp
    host C++: aapt <= frameworks/base/tools/aapt/XMLNode.cpp
    host C++: aapt <= frameworks/base/tools/aapt/ResourceTable.cpp
    host C++: aapt <= frameworks/base/tools/aapt/Images.cpp
    host C++: aapt <= frameworks/base/tools/aapt/Resource.cpp
    host C++: aapt <= frameworks/base/tools/aapt/SourcePos.cpp
    host C++: aapt <= frameworks/base/tools/aapt/ZipEntry.cpp
    host C++: aapt <= frameworks/base/tools/aapt/ZipFile.cpp
    host C++: libutils <= frameworks/base/libs/utils/Asset.cpp
    host C++: libutils <= frameworks/base/libs/utils/AssetDir.cpp
    host C++: libutils <= frameworks/base/libs/utils/AssetManager.cpp
    host C++: libutils <= frameworks/base/libs/utils/BufferedTextOutput.cpp
    host C++: libutils <= frameworks/base/libs/utils/CallStack.cpp
    host C++: libutils <= frameworks/base/libs/utils/Debug.cpp
    host C++: libutils <= frameworks/base/libs/utils/FileMap.cpp
    host C++: libutils <= frameworks/base/libs/utils/Flattenable.cpp
    host C++: libutils <= frameworks/base/libs/utils/ObbFile.cpp
    host C++: libutils <= frameworks/base/libs/utils/Pool.cpp
    host C++: libutils <= frameworks/base/libs/utils/RefBase.cpp
    host C++: libutils <= frameworks/base/libs/utils/ResourceTypes.cpp
    host C++: libutils <= frameworks/base/libs/utils/SharedBuffer.cpp
    host C++: libutils <= frameworks/base/libs/utils/Static.cpp
    host C++: libutils <= frameworks/base/libs/utils/StopWatch.cpp
    host C++: libutils <= frameworks/base/libs/utils/StreamingZipInflater.cpp
    host C++: libutils <= frameworks/base/libs/utils/String8.cpp
    host C++: libutils <= frameworks/base/libs/utils/String16.cpp
    host C++: libutils <= frameworks/base/libs/utils/StringArray.cpp
    host C++: libutils <= frameworks/base/libs/utils/SystemClock.cpp
    host C++: libutils <= frameworks/base/libs/utils/TextOutput.cpp
    host C++: libutils <= frameworks/base/libs/utils/Threads.cpp
    host C++: libutils <= frameworks/base/libs/utils/Timers.cpp
    host C++: libutils <= frameworks/base/libs/utils/VectorImpl.cpp
    host C++: libutils <= frameworks/base/libs/utils/ZipFileCRO.cpp
    host C++: libutils <= frameworks/base/libs/utils/ZipFileRO.cpp
    host C++: libutils <= frameworks/base/libs/utils/ZipUtils.cpp
    host C++: libutils <= frameworks/base/libs/utils/misc.cpp
    host StaticLib: libutils (out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/libutils.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/Asset.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/AssetDir.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/AssetManager.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/BufferedTextOutput.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/CallStack.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/Debug.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/FileMap.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/Flattenable.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/ObbFile.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/Pool.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/RefBase.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/ResourceTypes.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/SharedBuffer.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/Static.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/StopWatch.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/StreamingZipInflater.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/String8.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/String16.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/StringArray.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/SystemClock.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/TextOutput.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/Threads.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/Timers.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/VectorImpl.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/ZipFileCRO.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/ZipFileRO.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/ZipUtils.o out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/misc.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libutils_intermediates/libutils.a
    host C: liblog <= system/core/liblog/logd_write.c
    host C: liblog <= system/core/liblog/logprint.c
    host C: liblog <= system/core/liblog/event_tag_map.c
    host C: liblog <= system/core/liblog/fake_log_device.c
    host StaticLib: liblog (out/host/linux-x86/obj/STATIC_LIBRARIES/liblog_intermediates/liblog.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/liblog_intermediates/logd_write.o out/host/linux-x86/obj/STATIC_LIBRARIES/liblog_intermediates/logprint.o out/host/linux-x86/obj/STATIC_LIBRARIES/liblog_intermediates/event_tag_map.o out/host/linux-x86/obj/STATIC_LIBRARIES/liblog_intermediates/fake_log_device.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/liblog_intermediates/liblog.a
    host C: libcutils <= system/core/libcutils/atomic.c
    host C: libcutils <= system/core/libcutils/array.c
    host C: libcutils <= system/core/libcutils/hashmap.c
    host C: libcutils <= system/core/libcutils/native_handle.c
    host C: libcutils <= system/core/libcutils/buffer.c
    host C: libcutils <= system/core/libcutils/socket_inaddr_any_server.c
    host C: libcutils <= system/core/libcutils/socket_local_client.c
    host C: libcutils <= system/core/libcutils/socket_local_server.c
    host C: libcutils <= system/core/libcutils/socket_loopback_client.c
    host C: libcutils <= system/core/libcutils/socket_loopback_server.c
    host C: libcutils <= system/core/libcutils/socket_network_client.c
    host C: libcutils <= system/core/libcutils/config_utils.c
    host C: libcutils <= system/core/libcutils/cpu_info.c
    host C: libcutils <= system/core/libcutils/load_file.c
    host C: libcutils <= system/core/libcutils/open_memstream.c
    host C: libcutils <= system/core/libcutils/strdup16to8.c
    host C: libcutils <= system/core/libcutils/strdup8to16.c
    host C: libcutils <= system/core/libcutils/record_stream.c
    host C: libcutils <= system/core/libcutils/process_name.c
    host C: libcutils <= system/core/libcutils/properties.c
    host C: libcutils <= system/core/libcutils/threads.c
    host C: libcutils <= system/core/libcutils/sched_policy.c
    host C: libcutils <= system/core/libcutils/iosched_policy.c
    host C: libcutils <= system/core/libcutils/abort_socket.c
    host C: libcutils <= system/core/libcutils/mspace.c
    host C: libcutils <= system/core/libcutils/selector.c
    host C: libcutils <= system/core/libcutils/tztime.c
    host C: libcutils <= system/core/libcutils/zygote.c
    host C: libcutils <= system/core/libcutils/ashmem-host.c
    host C: libcutils <= system/core/libcutils/tzstrftime.c
    host C: libcutils <= system/core/libcutils/dlmalloc_stubs.c
    host StaticLib: libcutils (out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/libcutils.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/atomic.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/array.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/hashmap.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/native_handle.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/buffer.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/socket_inaddr_any_server.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/socket_local_client.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/socket_local_server.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/socket_loopback_client.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/socket_loopback_server.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/socket_network_client.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/config_utils.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/cpu_info.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/load_file.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/open_memstream.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/strdup16to8.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/strdup8to16.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/record_stream.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/process_name.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/properties.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/threads.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/sched_policy.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/iosched_policy.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/abort_socket.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/mspace.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/selector.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/tztime.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/zygote.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/ashmem-host.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/tzstrftime.o out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/dlmalloc_stubs.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libcutils_intermediates/libcutils.a
    host C: libexpat <= external/expat/lib/xmlparse.c
    host C: libexpat <= external/expat/lib/xmlrole.c
    host C: libexpat <= external/expat/lib/xmltok.c
    host StaticLib: libexpat (out/host/linux-x86/obj/STATIC_LIBRARIES/libexpat_intermediates/libexpat.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libexpat_intermediates/lib/xmlparse.o out/host/linux-x86/obj/STATIC_LIBRARIES/libexpat_intermediates/lib/xmlrole.o out/host/linux-x86/obj/STATIC_LIBRARIES/libexpat_intermediates/lib/xmltok.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libexpat_intermediates/libexpat.a
    host C: libpng <= external/libpng/png.c
    host C: libpng <= external/libpng/pngerror.c
    host C: libpng <= external/libpng/pnggccrd.c
    host C: libpng <= external/libpng/pngget.c
    host C: libpng <= external/libpng/pngmem.c
    host C: libpng <= external/libpng/pngpread.c
    host C: libpng <= external/libpng/pngread.c
    host C: libpng <= external/libpng/pngrio.c
    host C: libpng <= external/libpng/pngrtran.c
    host C: libpng <= external/libpng/pngrutil.c
    host C: libpng <= external/libpng/pngset.c
    host C: libpng <= external/libpng/pngtrans.c
    host C: libpng <= external/libpng/pngvcrd.c
    host C: libpng <= external/libpng/pngwio.c
    host C: libpng <= external/libpng/pngwrite.c
    host C: libpng <= external/libpng/pngwtran.c
    host C: libpng <= external/libpng/pngwutil.c
    host StaticLib: libpng (out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/libpng.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/png.o out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/pngerror.o out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/pnggccrd.o out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/pngget.o out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/pngmem.o out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/pngpread.o out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/pngread.o out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/pngrio.o out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/pngrtran.o out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/pngrutil.o out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/pngset.o out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/pngtrans.o out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/pngvcrd.o out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/pngwio.o out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/pngwrite.o out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/pngwtran.o out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/pngwutil.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libpng_intermediates/libpng.a
    host Executable: aapt (out/host/linux-x86/obj/EXECUTABLES/aapt_intermediates/aapt)
    true
    Notice file: frameworks/base/libs/utils/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/libutils.a.txt
    Notice file: system/core/liblog/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/liblog.a.txt
    Notice file: system/core/libcutils/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/libcutils.a.txt
    Notice file: external/expat/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/libexpat.a.txt
    Notice file: external/libpng/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/libpng.a.txt
    Install: out/host/linux-x86/bin/aapt
    target Jar: core (out/target/common/obj/JAVA_LIBRARIES/core_intermediates/javalib.jar)
     'out/target/common/obj/JAVA_LIBRARIES/core_intermediates//classes.dex' as 'classes.dex'...
    target Java: bouncycastle (out/target/common/obj/JAVA_LIBRARIES/bouncycastle_intermediates/classes)
    Copying: out/target/common/obj/JAVA_LIBRARIES/bouncycastle_intermediates/classes-jarjar.jar
    Copying: out/target/common/obj/JAVA_LIBRARIES/bouncycastle_intermediates/emma_out/lib/classes-jarjar.jar
    Copying: out/target/common/obj/JAVA_LIBRARIES/bouncycastle_intermediates/classes.jar
    Copying: out/target/common/obj/JAVA_LIBRARIES/bouncycastle_intermediates/noproguard.classes.jar
    target Dex: bouncycastle
    Copying: out/target/common/obj/JAVA_LIBRARIES/bouncycastle_intermediates/noproguard.classes.dex
    target Jar: bouncycastle (out/target/common/obj/JAVA_LIBRARIES/bouncycastle_intermediates/javalib.jar)
     'out/target/common/obj/JAVA_LIBRARIES/bouncycastle_intermediates//classes.dex' as 'classes.dex'...
    target Java: ext (out/target/common/obj/JAVA_LIBRARIES/ext_intermediates/classes)
    Copying: out/target/common/obj/JAVA_LIBRARIES/ext_intermediates/classes-jarjar.jar
    Copying: out/target/common/obj/JAVA_LIBRARIES/ext_intermediates/emma_out/lib/classes-jarjar.jar
    Copying: out/target/common/obj/JAVA_LIBRARIES/ext_intermediates/classes.jar
    Copying: out/target/common/obj/JAVA_LIBRARIES/ext_intermediates/noproguard.classes.jar
    target Dex: ext
    Copying: out/target/common/obj/JAVA_LIBRARIES/ext_intermediates/noproguard.classes.dex
    target Jar: ext (out/target/common/obj/JAVA_LIBRARIES/ext_intermediates/javalib.jar)
     'out/target/common/obj/JAVA_LIBRARIES/ext_intermediates//classes.dex' as 'classes.dex'...
    Yacc: aidl <= frameworks/base/tools/aidl/aidl_language_y.y
    bison -d  -o out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_y.cpp frameworks/base/tools/aidl/aidl_language_y.y
    touch out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_y.hpp
    echo '#ifndef 'aidl_language_y_h > out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_y.h
    echo '#define 'aidl_language_y_h >> out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_y.h
    cat out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_y.hpp >> out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_y.h
    echo '#endif' >> out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_y.h
    rm -f out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_y.hpp
    host C++: aidl <= frameworks/base/tools/aidl/aidl.cpp
    host C++: aidl <= frameworks/base/tools/aidl/aidl_language.cpp
    host C++: aidl <= frameworks/base/tools/aidl/options.cpp
    host C++: aidl <= frameworks/base/tools/aidl/search_path.cpp
    host C++: aidl <= frameworks/base/tools/aidl/AST.cpp
    host C++: aidl <= frameworks/base/tools/aidl/Type.cpp
    host C++: aidl <= frameworks/base/tools/aidl/generate_java.cpp
    host C++: aidl <= out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_y.cpp
    Lex: aidl <= frameworks/base/tools/aidl/aidl_language_l.l
    host C++: aidl <= out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_l.cpp
    host Executable: aidl (out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl)
    true
    Install: out/host/linux-x86/bin/aidl
    Aidl: framework <= frameworks/base/core/java/android/accessibilityservice/IAccessibilityServiceConnection.aidl
    Aidl: framework <= frameworks/base/core/java/android/accessibilityservice/IEventListener.aidl
    Aidl: framework <= frameworks/base/core/java/android/accounts/IAccountManager.aidl
    Aidl: framework <= frameworks/base/core/java/android/accounts/IAccountManagerResponse.aidl
    Aidl: framework <= frameworks/base/core/java/android/accounts/IAccountAuthenticator.aidl
    Aidl: framework <= frameworks/base/core/java/android/accounts/IAccountAuthenticatorResponse.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/IActivityController.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/IActivityPendingResult.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/IActivityWatcher.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/IAlarmManager.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/IBackupAgent.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/IInstrumentationWatcher.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/INotificationManager.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/ISearchManager.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/ISearchManagerCallback.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/IServiceConnection.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/IThumbnailReceiver.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/ITransientNotification.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/IUiModeManager.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/IWallpaperManager.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/IWallpaperManagerCallback.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/admin/IDevicePolicyManager.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/backup/IBackupManager.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/backup/IRestoreObserver.aidl
    Aidl: framework <= frameworks/base/core/java/android/app/backup/IRestoreSession.aidl
    Aidl: framework <= frameworks/base/core/java/android/bluetooth/IBluetooth.aidl
    Aidl: framework <= frameworks/base/core/java/android/bluetooth/IBluetoothA2dp.aidl
    Aidl: framework <= frameworks/base/core/java/android/bluetooth/IBluetoothCallback.aidl
    Aidl: framework <= frameworks/base/core/java/android/bluetooth/IBluetoothHeadset.aidl
    Aidl: framework <= frameworks/base/core/java/android/bluetooth/IBluetoothPbap.aidl
    Aidl: framework <= frameworks/base/core/java/android/content/IContentService.aidl
    Aidl: framework <= frameworks/base/core/java/android/content/IIntentReceiver.aidl
    Aidl: framework <= frameworks/base/core/java/android/content/IIntentSender.aidl
    Aidl: framework <= frameworks/base/core/java/android/content/ISyncAdapter.aidl
    Aidl: framework <= frameworks/base/core/java/android/content/ISyncContext.aidl
    Aidl: framework <= frameworks/base/core/java/android/content/ISyncStatusObserver.aidl
    Aidl: framework <= frameworks/base/core/java/android/content/pm/IPackageDataObserver.aidl
    Aidl: framework <= frameworks/base/core/java/android/content/pm/IPackageDeleteObserver.aidl
    Aidl: framework <= frameworks/base/core/java/android/content/pm/IPackageInstallObserver.aidl
    Aidl: framework <= frameworks/base/core/java/android/content/pm/IPackageManager.aidl
    Aidl: framework <= frameworks/base/core/java/android/content/pm/IPackageMoveObserver.aidl
    Aidl: framework <= frameworks/base/core/java/android/content/pm/IPackageStatsObserver.aidl
    Aidl: framework <= frameworks/base/core/java/android/database/IContentObserver.aidl
    Aidl: framework <= frameworks/base/core/java/android/hardware/usb/IUsbManager.aidl
    Aidl: framework <= frameworks/base/core/java/android/net/IConnectivityManager.aidl
    Aidl: framework <= frameworks/base/core/java/android/net/INetworkManagementEventObserver.aidl
    Aidl: framework <= frameworks/base/core/java/android/net/IThrottleManager.aidl
    Aidl: framework <= frameworks/base/core/java/android/nfc/ILlcpConnectionlessSocket.aidl
    Aidl: framework <= frameworks/base/core/java/android/nfc/ILlcpServiceSocket.aidl
    Aidl: framework <= frameworks/base/core/java/android/nfc/ILlcpSocket.aidl
    Aidl: framework <= frameworks/base/core/java/android/nfc/INfcAdapter.aidl
    Aidl: framework <= frameworks/base/core/java/android/nfc/INfcAdapterExtras.aidl
    Aidl: framework <= frameworks/base/core/java/android/nfc/INfcTag.aidl
    Aidl: framework <= frameworks/base/core/java/android/nfc/IP2pInitiator.aidl
    Aidl: framework <= frameworks/base/core/java/android/nfc/IP2pTarget.aidl
    Aidl: framework <= frameworks/base/core/java/android/os/IHardwareService.aidl
    Aidl: framework <= frameworks/base/core/java/android/os/IMessenger.aidl
    Aidl: framework <= frameworks/base/core/java/android/os/INetworkManagementService.aidl
    Aidl: framework <= frameworks/base/core/java/android/os/INetStatService.aidl
    Aidl: framework <= frameworks/base/core/java/android/os/IPermissionController.aidl
    Aidl: framework <= frameworks/base/core/java/android/os/IPowerManager.aidl
    Aidl: framework <= frameworks/base/core/java/android/os/IRemoteCallback.aidl
    Aidl: framework <= frameworks/base/core/java/android/os/IVibratorService.aidl
    Aidl: framework <= frameworks/base/core/java/android/service/urlrenderer/IUrlRendererService.aidl
    Aidl: framework <= frameworks/base/core/java/android/service/urlrenderer/IUrlRendererCallback.aidl
    Aidl: framework <= frameworks/base/core/java/android/service/wallpaper/IWallpaperConnection.aidl
    Aidl: framework <= frameworks/base/core/java/android/service/wallpaper/IWallpaperEngine.aidl
    Aidl: framework <= frameworks/base/core/java/android/service/wallpaper/IWallpaperService.aidl
    Aidl: framework <= frameworks/base/core/java/android/text/IClipboard.aidl
    Aidl: framework <= frameworks/base/core/java/android/view/accessibility/IAccessibilityManager.aidl
    Aidl: framework <= frameworks/base/core/java/android/view/accessibility/IAccessibilityManagerClient.aidl
    Aidl: framework <= frameworks/base/core/java/android/view/IApplicationToken.aidl
    Aidl: framework <= frameworks/base/core/java/android/view/IOnKeyguardExitResult.aidl
    Aidl: framework <= frameworks/base/core/java/android/view/IRotationWatcher.aidl
    Aidl: framework <= frameworks/base/core/java/android/view/IWindow.aidl
    Aidl: framework <= frameworks/base/core/java/android/view/IWindowManager.aidl
    Aidl: framework <= frameworks/base/core/java/android/view/IWindowSession.aidl
    Aidl: framework <= frameworks/base/core/java/android/speech/IRecognitionListener.aidl
    Aidl: framework <= frameworks/base/core/java/android/speech/IRecognitionService.aidl
    Aidl: framework <= frameworks/base/core/java/android/speech/tts/ITts.aidl
    Aidl: framework <= frameworks/base/core/java/android/speech/tts/ITtsCallback.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/app/IBatteryStats.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/app/IUsageStats.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/app/IMediaContainerService.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/appwidget/IAppWidgetService.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/appwidget/IAppWidgetHost.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/backup/IBackupTransport.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/os/IDropBoxManagerService.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/os/IResultReceiver.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/statusbar/IStatusBar.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/statusbar/IStatusBarService.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/view/IInputContext.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/view/IInputContextCallback.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/view/IInputMethod.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/view/IInputMethodCallback.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/view/IInputMethodClient.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/view/IInputMethodManager.aidl
    Aidl: framework <= frameworks/base/core/java/com/android/internal/view/IInputMethodSession.aidl
    Aidl: framework <= frameworks/base/location/java/android/location/IGeocodeProvider.aidl
    Aidl: framework <= frameworks/base/location/java/android/location/IGpsStatusListener.aidl
    Aidl: framework <= frameworks/base/location/java/android/location/IGpsStatusProvider.aidl
    Aidl: framework <= frameworks/base/location/java/android/location/ILocationListener.aidl
    Aidl: framework <= frameworks/base/location/java/android/location/ILocationManager.aidl
    Aidl: framework <= frameworks/base/location/java/android/location/ILocationProvider.aidl
    Aidl: framework <= frameworks/base/location/java/android/location/INetInitiatedListener.aidl
    Aidl: framework <= frameworks/base/media/java/android/media/IAudioService.aidl
    Aidl: framework <= frameworks/base/media/java/android/media/IAudioFocusDispatcher.aidl
    Aidl: framework <= frameworks/base/media/java/android/media/IMediaScannerListener.aidl
    Aidl: framework <= frameworks/base/media/java/android/media/IMediaScannerService.aidl
    Aidl: framework <= frameworks/base/telephony/java/com/android/internal/telephony/IPhoneStateListener.aidl
    Aidl: framework <= frameworks/base/telephony/java/com/android/internal/telephony/IPhoneSubInfo.aidl
    Aidl: framework <= frameworks/base/telephony/java/com/android/internal/telephony/ITelephony.aidl
    Aidl: framework <= frameworks/base/telephony/java/com/android/internal/telephony/ITelephonyRegistry.aidl
    Aidl: framework <= frameworks/base/telephony/java/com/android/internal/telephony/IIccPhoneBook.aidl
    Aidl: framework <= frameworks/base/telephony/java/com/android/internal/telephony/ISms.aidl
    Aidl: framework <= frameworks/base/wifi/java/android/net/wifi/IWifiManager.aidl
    Aidl: framework <= frameworks/base/telephony/java/com/android/internal/telephony/IExtendedNetworkService.aidl
    Aidl: framework <= frameworks/base/vpn/java/android/net/vpn/IVpnService.aidl
    Aidl: framework <= frameworks/base/voip/java/android/net/sip/ISipSession.aidl
    Aidl: framework <= frameworks/base/voip/java/android/net/sip/ISipSessionListener.aidl
    Aidl: framework <= frameworks/base/voip/java/android/net/sip/ISipService.aidl
    Aidl: framework <= frameworks/base/core/java/android/bluetooth/IBluetoothHid.aidl
    logtags: out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/src/core/java/android/content/EventLogTags.java <= frameworks/base/core/java/android/content/EventLogTags.logtags
    logtags: out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/src/core/java/android/webkit/EventLogTags.java <= frameworks/base/core/java/android/webkit/EventLogTags.logtags
    logtags: out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/src/telephony/java/com/android/internal/telephony/EventLogTags.java <= frameworks/base/telephony/java/com/android/internal/telephony/EventLogTags.logtags
    target Java: core-junit (out/target/common/obj/JAVA_LIBRARIES/core-junit_intermediates/classes)
    Copying: out/target/common/obj/JAVA_LIBRARIES/core-junit_intermediates/classes-jarjar.jar
    Copying: out/target/common/obj/JAVA_LIBRARIES/core-junit_intermediates/emma_out/lib/classes-jarjar.jar
    Copying: out/target/common/obj/JAVA_LIBRARIES/core-junit_intermediates/classes.jar
    Copying: out/target/common/obj/JAVA_LIBRARIES/core-junit_intermediates/noproguard.classes.jar
    target Dex: core-junit
    Copying: out/target/common/obj/JAVA_LIBRARIES/core-junit_intermediates/noproguard.classes.dex
    target Jar: core-junit (out/target/common/obj/JAVA_LIBRARIES/core-junit_intermediates/javalib.jar)
     'out/target/common/obj/JAVA_LIBRARIES/core-junit_intermediates//classes.dex' as 'classes.dex'...
    target Export Resources: framework-res (out/target/common/obj/APPS/framework-res_intermediates/package-export.apk)
    target R.java/Manifest.java: framework-res (out/target/common/obj/APPS/framework-res_intermediates/src/R.stamp)
    target Java: framework (out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/classes)
    Copying: out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/classes-jarjar.jar
    Copying: out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/emma_out/lib/classes-jarjar.jar
    Copying: out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/classes.jar
    Copying: out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/noproguard.classes.jar
    target Dex: framework
    Copying: out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/noproguard.classes.dex
    target Jar: framework (out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/javalib.jar)
     'out/target/common/obj/JAVA_LIBRARIES/framework_intermediates//classes.dex' as 'classes.dex'...
    Aidl Preprocess: out/target/common/obj/framework.aidl
    Docs droiddoc: out/target/common/docs/doc-comment-check
    DroidDoc took 76 sec. to write docs to out/target/common/docs/doc-comment-check
    Docs droiddoc: out/target/common/docs/api-stubs
    Copy: apicheck (out/host/linux-x86/obj/EXECUTABLES/apicheck_intermediates/apicheck)
    Install: out/host/linux-x86/bin/apicheck
    Checking API: checkapi-last
    Checking API: checkapi-current
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/zoneinfo/zoneinfo.dat)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/zoneinfo/zoneinfo.idx)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/zoneinfo/zoneinfo.version)
    Copy: out/host/linux-x86/usr/share/zoneinfo/zoneinfo.dat
    Copy: out/host/linux-x86/usr/share/zoneinfo/zoneinfo.idx
    Copy: out/host/linux-x86/usr/share/zoneinfo/zoneinfo.version
    target Prebuilt:  (out/target/product/omap3evm/system/etc/security/cacerts.bks)
    target Prebuilt:  (out/target/product/omap3evm/root/init.rc)
    target Prebuilt:  (out/target/product/omap3evm/system/bin/am)
    target Prebuilt:  (out/target/product/omap3evm/system/bin/bmgr)
    target Prebuilt:  (out/target/product/omap3evm/system/bin/input)
    target Prebuilt:  (out/target/product/omap3evm/system/bin/svc)
    target Prebuilt:  (out/target/product/omap3evm/system/bin/ime)
    target Prebuilt:  (out/target/product/omap3evm/system/bin/pm)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/keylayout/qwerty.kl)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/keylayout/AVRCP.kl)
    target Prebuilt: bluetooth_etcdir (out/target/product/omap3evm/system/etc/bluetooth/audio.conf)
    target Prebuilt: bluetooth_etcdir (out/target/product/omap3evm/system/etc/bluetooth/input.conf)
    target Prebuilt: bluetooth_etcdir (out/target/product/omap3evm/system/etc/bluetooth/main.conf)
    target Prebuilt: bluetooth_etcdir (out/target/product/omap3evm/system/etc/bluetooth/blacklist.conf)
    target Prebuilt: bluetooth_etcdir (out/target/product/omap3evm/system/etc/bluetooth/auto_pairing.conf)
    target Prebuilt: system_etcdir (out/target/product/omap3evm/system/etc/dbus.conf)
    target Prebuilt: system_etcdir (out/target/product/omap3evm/system/etc/hosts)
    target Prebuilt: system_etcdir (out/target/product/omap3evm/system/etc/init.goldfish.sh)
    target Prebuilt:  (out/target/product/omap3evm/root/ueventd.rc)
    target Prebuilt:  (out/target/product/omap3evm/root/init.goldfish.rc)
    target Prebuilt:  (out/target/product/omap3evm/root/ueventd.goldfish.rc)
    Directory: out/target/product/omap3evm/root/sbin
    Directory: out/target/product/omap3evm/root/dev
    Directory: out/target/product/omap3evm/root/proc
    Directory: out/target/product/omap3evm/root/sys
    Directory: out/target/product/omap3evm/root/system
    Directory: out/target/product/omap3evm/root/data
    Directory: out/target/product/omap3evm/data
    target Prebuilt:  (out/target/product/omap3evm/system/usr/srec/config/en.us/baseline11k.par)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/srec/config/en.us/baseline8k.par)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/srec/config/en.us/baseline.par)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/srec/config/en.us/dictionary/basic.ok)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/srec/config/en.us/dictionary/enroll.ok)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/srec/config/en.us/dictionary/cmu6plus.ok.zip)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/srec/config/en.us/g2p/en-US-ttp.data)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/srec/config/en.us/models/generic.swiarb)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/srec/config/en.us/models/generic11.lda)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/srec/config/en.us/models/generic11_f.swimdl)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/srec/config/en.us/models/generic11_m.swimdl)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/srec/config/en.us/models/generic8.lda)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/srec/config/en.us/models/generic8_f.swimdl)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/srec/config/en.us/models/generic8_m.swimdl)
    host C++: grxmlcompile <= external/srec/tools/grxmlcompile/gr_iface.cpp
    host C++: grxmlcompile <= external/srec/tools/grxmlcompile/netw_dump.cpp
    host C++: grxmlcompile <= external/srec/tools/grxmlcompile/sub_base.cpp
    host C++: grxmlcompile <= external/srec/tools/grxmlcompile/sub_grph.cpp
    host C++: grxmlcompile <= external/srec/tools/grxmlcompile/sub_min.cpp
    host C++: grxmlcompile <= external/srec/tools/grxmlcompile/sub_supp.cpp
    host C++: grxmlcompile <= external/srec/tools/grxmlcompile/grxmlcompile.cpp
    host C++: grxmlcompile <= external/srec/tools/grxmlcompile/grxmldoc.cpp
    host C++: grxmlcompile <= external/srec/tools/grxmlcompile/hashmap.cpp
    host C: libESR_Shared <= external/srec/shared/src/CircularBuffer.c
    host C: libESR_Shared <= external/srec/shared/src/CommandLine.c
    host C: libESR_Shared <= external/srec/shared/src/ESR_Locale.c
    host C: libESR_Shared <= external/srec/shared/src/ESR_Session.c
    host C: libESR_Shared <= external/srec/shared/src/HashMap.c
    host C: libESR_Shared <= external/srec/shared/src/HashMapImpl.c
    host C: libESR_Shared <= external/srec/shared/src/Int8ArrayListImpl.c
    host C: libESR_Shared <= external/srec/shared/src/IntArrayList.c
    host C: libESR_Shared <= external/srec/shared/src/IntArrayListImpl.c
    host C: libESR_Shared <= external/srec/shared/src/lstring.c
    host C: libESR_Shared <= external/srec/shared/src/LStringImpl.c
    host C: libESR_Shared <= external/srec/shared/src/SessionTypeImpl.c
    host C: libESR_Portable <= external/srec/portable/src/ArrayList.c
    host C: libESR_Portable <= external/srec/portable/src/ArrayListImpl.c
    host C: libESR_Portable <= external/srec/portable/src/ESR_ReturnCode.c
    host C: libESR_Portable <= external/srec/portable/src/LCHAR.c
    host C: libESR_Portable <= external/srec/portable/src/pcputimer.c
    host C: libESR_Portable <= external/srec/portable/src/pcrc.c
    host C: libESR_Portable <= external/srec/portable/src/pendian.c
    host C: libESR_Portable <= external/srec/portable/src/PFileWrap.c
    host C: libESR_Portable <= external/srec/portable/src/UNIX/PFileWrapUNIX_OS_Specific.c
    host C: libESR_Portable <= external/srec/portable/src/phashtable.c
    host C: libESR_Portable <= external/srec/portable/src/pLastError.c
    host C: libESR_Portable <= external/srec/portable/src/plog.c
    host C: libESR_Portable <= external/srec/portable/src/pmalloc.c
    host C: libESR_Portable <= external/srec/portable/src/pmemory.c
    host C: libESR_Portable <= external/srec/portable/src/pmemory_ext.c
    host C: libESR_Portable <= external/srec/portable/src/PStackSize.c
    host C: libESR_Portable <= external/srec/portable/src/ptimestamp.c
    host C: libESR_Portable <= external/srec/portable/src/ptypes.c
    host SharedLib: libESR_Portable (out/host/linux-x86/obj/lib/libESR_Portable.so)
    host SharedLib: libESR_Shared (out/host/linux-x86/obj/lib/libESR_Shared.so)
    host C: libSR_AcousticModels <= external/srec/srec/AcousticModels/src/AcousticModels.c
    host C: libSR_AcousticModels <= external/srec/srec/AcousticModels/src/AcousticModelsImpl.c
    host C: libSR_EventLog <= external/srec/srec/EventLog/src/EventLog.c
    host C: libSR_EventLog <= external/srec/srec/EventLog/src/EventLogImpl.c
    host SharedLib: libSR_EventLog (out/host/linux-x86/obj/lib/libSR_EventLog.so)
    host C: libSR_Core <= external/srec/srec/ca/acc_basi.c
    host C: libSR_Core <= external/srec/srec/ca/cnfd_scr.c
    host C: libSR_Core <= external/srec/srec/ca/par_basi.c
    host C: libSR_Core <= external/srec/srec/ca/pat_basi.c
    host C: libSR_Core <= external/srec/srec/ca/rec_basi.c
    host C: libSR_Core <= external/srec/srec/ca/rec_load.c
    host C: libSR_Core <= external/srec/srec/ca/rec_nbes.c
    host C: libSR_Core <= external/srec/srec/ca/rec_resu.c
    host C: libSR_Core <= external/srec/srec/ca/syn_srec.c
    host C: libSR_Core <= external/srec/srec/ca/utt_basi.c
    host C: libSR_Core <= external/srec/srec/ca/utt_data.c
    host C: libSR_Core <= external/srec/srec/ca/utt_proc.c
    host C: libSR_Core <= external/srec/srec/ca/voc_basi.c
    host C: libSR_Core <= external/srec/srec/ca/../cfront/ca_cms.c
    host C: libSR_Core <= external/srec/srec/ca/../cfront/ca_front.c
    host C: libSR_Core <= external/srec/srec/ca/../cfront/ca_wave.c
    host C: libSR_Core <= external/srec/srec/ca/../cfront/cheldsp4.c
    host C: libSR_Core <= external/srec/srec/ca/../cfront/chelfep.c
    host C: libSR_Core <= external/srec/srec/ca/../cfront/chelmel4.c
    host C: libSR_Core <= external/srec/srec/ca/../cfront/frontobj.c
    host C: libSR_Core <= external/srec/srec/ca/../cfront/frontpar.c
    host C: libSR_Core <= external/srec/srec/ca/../cfront/log_tabl.c
    host C: libSR_Core <= external/srec/srec/ca/../cfront/sp_fft.c
    host C: libSR_Core <= external/srec/srec/ca/../cfront/spec_anl.c
    host C: libSR_Core <= external/srec/srec/ca/../cfront/wav_acc.c
    host C: libSR_Core <= external/srec/srec/ca/../clib/cnorm_tr.c
    host C: libSR_Core <= external/srec/srec/ca/../clib/fpi_tgt.c
    host C: libSR_Core <= external/srec/srec/ca/../clib/imeld_rd.c
    host C: libSR_Core <= external/srec/srec/ca/../clib/imeld_tr.c
    host C: libSR_Core <= external/srec/srec/ca/../clib/jacobi.c
    host C: libSR_Core <= external/srec/srec/ca/../clib/log_add.c
    host C: libSR_Core <= external/srec/srec/ca/../clib/matrix_i.c
    host C: libSR_Core <= external/srec/srec/ca/../clib/matx_ops.c
    host C: libSR_Core <= external/srec/srec/ca/../clib/specnorm.c
    host C: libSR_Core <= external/srec/srec/ca/../clib/srec_arb.c
    host C: libSR_Core <= external/srec/srec/ca/../clib/swicms.c
    host C: libSR_Core <= external/srec/srec/ca/../clib/swimodel.c
    host C: libSR_Core <= external/srec/srec/ca/../clib/voc_read.c
    host C: libSR_Core <= external/srec/srec/ca/../clib/voicing.c
    host C: libSR_Core <= external/srec/srec/ca/../crec/astar.c
    host C: libSR_Core <= external/srec/srec/ca/../crec/astar_pphash.c
    host C: libSR_Core <= external/srec/srec/ca/../crec/c47mulsp.c
    host C: libSR_Core <= external/srec/srec/ca/../crec/get_fram.c
    host C: libSR_Core <= external/srec/srec/ca/../crec/priority_q.c
    host C: libSR_Core <= external/srec/srec/ca/../crec/rec_norm.c
    host C: libSR_Core <= external/srec/srec/ca/../crec/srec.c
    host C: libSR_Core <= external/srec/srec/ca/../crec/srec_context.c
    host C: libSR_Core <= external/srec/srec/ca/../crec/srec_debug.c
    host C: libSR_Core <= external/srec/srec/ca/../crec/srec_eosd.c
    host C: libSR_Core <= external/srec/srec/ca/../crec/srec_initialize.c
    host C: libSR_Core <= external/srec/srec/ca/../crec/srec_results.c
    host C: libSR_Core <= external/srec/srec/ca/../crec/srec_stats.c
    host C: libSR_Core <= external/srec/srec/ca/../crec/srec_tokens.c
    host C: libSR_Core <= external/srec/srec/ca/../crec/text_parser.c
    host C: libSR_Core <= external/srec/srec/ca/../crec/word_lattice.c
    host C: libzipfile <= system/core/libzipfile/centraldir.c
    host C: libzipfile <= system/core/libzipfile/zipfile.c
    host StaticLib: libzipfile (out/host/linux-x86/obj/STATIC_LIBRARIES/libzipfile_intermediates/libzipfile.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libzipfile_intermediates/centraldir.o out/host/linux-x86/obj/STATIC_LIBRARIES/libzipfile_intermediates/zipfile.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libzipfile_intermediates/libzipfile.a
    host C: libunz <= external/zlib/adler32.c
    host C: libunz <= external/zlib/crc32.c
    host C: libunz <= external/zlib/zutil.c
    host C: libunz <= external/zlib/inflate.c
    host C: libunz <= external/zlib/inftrees.c
    host C: libunz <= external/zlib/inffast.c
    host StaticLib: libunz (out/host/linux-x86/obj/STATIC_LIBRARIES/libunz_intermediates/libunz.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libunz_intermediates/adler32.o out/host/linux-x86/obj/STATIC_LIBRARIES/libunz_intermediates/crc32.o out/host/linux-x86/obj/STATIC_LIBRARIES/libunz_intermediates/zutil.o out/host/linux-x86/obj/STATIC_LIBRARIES/libunz_intermediates/inflate.o out/host/linux-x86/obj/STATIC_LIBRARIES/libunz_intermediates/inftrees.o out/host/linux-x86/obj/STATIC_LIBRARIES/libunz_intermediates/inffast.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libunz_intermediates/libunz.a
    host SharedLib: libSR_Core (out/host/linux-x86/obj/lib/libSR_Core.so)
    host SharedLib: libSR_AcousticModels (out/host/linux-x86/obj/lib/libSR_AcousticModels.so)
    host C: libSR_AcousticState <= external/srec/srec/AcousticState/src/AcousticState.c
    host C: libSR_AcousticState <= external/srec/srec/AcousticState/src/AcousticStateImpl.c
    host SharedLib: libSR_AcousticState (out/host/linux-x86/obj/lib/libSR_AcousticState.so)
    host C: libSR_G2P <= external/srec/seti/sltsEngine/../setiUtils/src/platform_utils.c
    host C: libSR_G2P <= external/srec/seti/sltsEngine/src/linklist_impl.c
    host C: libSR_G2P <= external/srec/seti/sltsEngine/src/run_seq_lts.c
    host C: libSR_G2P <= external/srec/seti/sltsEngine/src/SWIslts.c
    host SharedLib: libSR_G2P (out/host/linux-x86/obj/lib/libSR_G2P.so)
    host C: libSR_Grammar <= external/srec/srec/Grammar/src/SR_Grammar.c
    host C: libSR_Grammar <= external/srec/srec/Grammar/src/SR_GrammarImpl.c
    host C: libSR_Semproc <= external/srec/srec/Semproc/src/ExpressionParser.c
    host C: libSR_Semproc <= external/srec/srec/Semproc/src/ExpressionEvaluator.c
    host C: libSR_Semproc <= external/srec/srec/Semproc/src/SymbolTable.c
    host C: libSR_Semproc <= external/srec/srec/Semproc/src/LexicalAnalyzer.c
    host C: libSR_Semproc <= external/srec/srec/Semproc/src/SemanticResult.c
    host C: libSR_Semproc <= external/srec/srec/Semproc/src/SemanticResultImpl.c
    host C: libSR_Semproc <= external/srec/srec/Semproc/src/SemanticGraph.c
    host C: libSR_Semproc <= external/srec/srec/Semproc/src/SemanticGraphImpl.c
    host C: libSR_Semproc <= external/srec/srec/Semproc/src/SemanticProcessor.c
    host C: libSR_Semproc <= external/srec/srec/Semproc/src/SemanticProcessorImpl.c
    host SharedLib: libSR_Semproc (out/host/linux-x86/obj/lib/libSR_Semproc.so)
    host C: libSR_Vocabulary <= external/srec/srec/Vocabulary/src/Vocabulary.c
    host C: libSR_Vocabulary <= external/srec/srec/Vocabulary/src/VocabularyImpl.c
    host SharedLib: libSR_Vocabulary (out/host/linux-x86/obj/lib/libSR_Vocabulary.so)
    host SharedLib: libSR_Grammar (out/host/linux-x86/obj/lib/libSR_Grammar.so)
    host C: libSR_Nametag <= external/srec/srec/Nametag/src/Nametag.c
    host C: libSR_Nametag <= external/srec/srec/Nametag/src/NametagImpl.c
    host C: libSR_Nametag <= external/srec/srec/Nametag/src/Nametags.c
    host C: libSR_Nametag <= external/srec/srec/Nametag/src/NametagsImpl.c
    host SharedLib: libSR_Nametag (out/host/linux-x86/obj/lib/libSR_Nametag.so)
    host C: libSR_Session <= external/srec/srec/Session/src/SR_Session.c
    host SharedLib: libSR_Session (out/host/linux-x86/obj/lib/libSR_Session.so)
    host C++: libfst <= external/srec/tools/thirdparty/OpenFst/fst/lib/fst.cpp
    host C++: libfst <= external/srec/tools/thirdparty/OpenFst/fst/lib/properties.cpp
    host C++: libfst <= external/srec/tools/thirdparty/OpenFst/fst/lib/symbol-table.cpp
    host C++: libfst <= external/srec/tools/thirdparty/OpenFst/fst/lib/compat.cpp
    host SharedLib: libfst (out/host/linux-x86/obj/lib/libfst.so)
    host C++: libtinyxml <= external/tinyxml/tinyxml.cpp
    host C++: libtinyxml <= external/tinyxml/tinyxmlparser.cpp
    host C++: libtinyxml <= external/tinyxml/tinyxmlerror.cpp
    host C++: libtinyxml <= external/tinyxml/tinystr.cpp
    host StaticLib: libtinyxml (out/host/linux-x86/obj/STATIC_LIBRARIES/libtinyxml_intermediates/libtinyxml.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libtinyxml_intermediates/tinyxml.o out/host/linux-x86/obj/STATIC_LIBRARIES/libtinyxml_intermediates/tinyxmlparser.o out/host/linux-x86/obj/STATIC_LIBRARIES/libtinyxml_intermediates/tinyxmlerror.o out/host/linux-x86/obj/STATIC_LIBRARIES/libtinyxml_intermediates/tinystr.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libtinyxml_intermediates/libtinyxml.a
    host Executable: grxmlcompile (out/host/linux-x86/obj/EXECUTABLES/grxmlcompile_intermediates/grxmlcompile)
    true
    Install: out/host/linux-x86/lib/libESR_Portable.so
    Install: out/host/linux-x86/lib/libESR_Shared.so
    Install: out/host/linux-x86/lib/libSR_EventLog.so
    Notice file: system/core/libzipfile/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/libzipfile.a.txt
    Notice file: external/zlib/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/libunz.a.txt
    Install: out/host/linux-x86/lib/libSR_Core.so
    Install: out/host/linux-x86/lib/libSR_AcousticModels.so
    Install: out/host/linux-x86/lib/libSR_AcousticState.so
    Install: out/host/linux-x86/lib/libSR_G2P.so
    Install: out/host/linux-x86/lib/libSR_Semproc.so
    Install: out/host/linux-x86/lib/libSR_Vocabulary.so
    Install: out/host/linux-x86/lib/libSR_Grammar.so
    Install: out/host/linux-x86/lib/libSR_Nametag.so
    Install: out/host/linux-x86/lib/libSR_Session.so
    Install: out/host/linux-x86/lib/libfst.so
    Notice file: external/tinyxml/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/libtinyxml.a.txt
    Install: out/host/linux-x86/bin/grxmlcompile
    host C: make_g2g <= external/srec/tools/make_g2g/make_g2g.c
    host C: libSR_Recognizer <= external/srec/srec/Recognizer/src/Recognizer.c
    host C: libSR_Recognizer <= external/srec/srec/Recognizer/src/RecognizerImpl.c
    host C: libSR_Recognizer <= external/srec/srec/Recognizer/src/RecognizerResult.c
    host C: libSR_Recognizer <= external/srec/srec/Recognizer/src/RecognizerResultImpl.c
    host SharedLib: libSR_Recognizer (out/host/linux-x86/obj/lib/libSR_Recognizer.so)
    host Executable: make_g2g (out/host/linux-x86/obj/EXECUTABLES/make_g2g_intermediates/make_g2g)
    true
    Install: out/host/linux-x86/lib/libSR_Recognizer.so
    Install: out/host/linux-x86/bin/make_g2g
    mkdir -p out/target/product/omap3evm/system/usr/srec/config/en.us/grammars
    out/host/linux-x86/bin/grxmlcompile -par external/srec/config/en.us/baseline11k.par -grxml external/srec/config/en.us/grammars/VoiceDialer.grxml -outdir out/target/product/omap3evm/system/usr/srec/config/en.us/grammars
    processing [external/srec/config/en.us/grammars/VoiceDialer.grxml] ...
    Creating semantic graph file
    Determinization
    found max_script_label 34
    info: Using parfile external/srec/config/en.us/baseline11k.par
    info: Using dictionary dictionary/cmu6plus.ok.zip
    info: reading word symbols out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/VoiceDialer.map
    info: reading parser symbols out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/VoiceDialer.omap
    info: reading model symbols external/srec/config/en.us/models/models128x.map
    SLOT>> VoiceDialer.grxml.Names@__Names__
    SLOT>> VoiceDialer.grxml.Opens@__Opens__
    -pau- : #
    -pau2- : #
    Call : k{l
    Voice : v<s
    Mail : mAl
    Redial : r/dI@l
    Exit : egz@t
    Exit : eks@t
    Cancel : kans@l
    Dial : dI@l
    Dial : dIl
    1 : 5F|
    thousand : T?z~
    thousand : T?z~d
    8 : H2
    hundred : hunPd
    hundred : hundPd
    hundred : hundr@d
    0 : 4
    0 : =Y07
    2 : 2K
    3 : B0Y
    4 : RX0
    5 : R>3
    6 : 1.\1
    7 : 1x3M
    9 : +>|
    Plus : plus
    at : at
    home : hOm
    on : on
    cell : sel
    mobile : mOb@l
    work : wVk
    other : uDP
    Open : Op~
    info: reading parser from text out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/VoiceDialer.P.txt
    info: creating helper fsts
    info: creating reverse g fst
    info: writing reverse G fst as text out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/VoiceDialer.Grev2.det.txt
    info: reading model fst external/srec/config/en.us/models/generic.C
    out/host/linux-x86/bin/make_g2g -base out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/VoiceDialer,addWords=0 -out out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/VoiceDialer.g2g
    Loading grammar out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/VoiceDialer,addWords=0 from text files...
    Saving grammar as binary image out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/VoiceDialer.g2g...
    SUCCESS!
    (cd out/target/product/omap3evm/system/usr/srec/config/en.us/grammars; rm -f VoiceDialer.Grev2.det.txt VoiceDialer.map VoiceDialer.omap VoiceDialer.P.txt VoiceDialer.params VoiceDialer.PCLG.txt VoiceDialer.script)
    out/host/linux-x86/bin/grxmlcompile -par external/srec/config/en.us/baseline11k.par -grxml external/srec/config/en.us/grammars/boolean.grxml -outdir out/target/product/omap3evm/system/usr/srec/config/en.us/grammars
    processing [external/srec/config/en.us/grammars/boolean.grxml] ...
    Determinization
    found max_script_label 1
    using word_penalty 40
    info: reading word symbols out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/boolean.map
    info: reading parser symbols out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/boolean.omap
    -pau- : #
    -pau2- : #
    yes : yes
    no : nO
    info: reading parser from text out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/boolean.P.txt
    info: writing reverse G fst as text out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/boolean.Grev2.det.txt
    out/host/linux-x86/bin/make_g2g -base out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/boolean,addWords=0 -out out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/boolean.g2g
    Loading grammar out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/boolean,addWords=0 from text files...
    Saving grammar as binary image out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/boolean.g2g...
    SUCCESS!
    (cd out/target/product/omap3evm/system/usr/srec/config/en.us/grammars; rm -f boolean.Grev2.det.txt boolean.map boolean.omap boolean.P.txt boolean.params boolean.PCLG.txt boolean.script)
    out/host/linux-x86/bin/grxmlcompile -par external/srec/config/en.us/baseline11k.par -grxml external/srec/config/en.us/grammars/phone_type_choice.grxml -outdir out/target/product/omap3evm/system/usr/srec/config/en.us/grammars
    processing [external/srec/config/en.us/grammars/phone_type_choice.grxml] ...
    Determinization
    found max_script_label 5
    info: reading word symbols out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/phone_type_choice.map
    info: reading parser symbols out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/phone_type_choice.omap
    -pau- : #
    -pau2- : #
    home : hOm
    mobile : mOb@l
    cell : sel
    work : wVk
    other : uDP
    exit : egz@t
    exit : eks@t
    cancel : kans@l
    try : trI
    again : @gAn
    again : @gen
    retry : r/trI
    info: reading parser from text out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/phone_type_choice.P.txt
    info: writing reverse G fst as text out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/phone_type_choice.Grev2.det.txt
    out/host/linux-x86/bin/make_g2g -base out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/phone_type_choice,addWords=0 -out out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/phone_type_choice.g2g
    Loading grammar out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/phone_type_choice,addWords=0 from text files...
    Saving grammar as binary image out/target/product/omap3evm/system/usr/srec/config/en.us/grammars/phone_type_choice.g2g...
    SUCCESS!
    (cd out/target/product/omap3evm/system/usr/srec/config/en.us/grammars; rm -f phone_type_choice.Grev2.det.txt phone_type_choice.map phone_type_choice.omap phone_type_choice.P.txt phone_type_choice.params phone_type_choice.PCLG.txt phone_type_choice.script)
    target Prebuilt:  (out/target/product/omap3evm/system/bin/monkey)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/alsa.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/pcm/dsnoop.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/pcm/modem.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/pcm/dpl.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/pcm/default.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/pcm/surround51.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/pcm/surround41.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/pcm/surround50.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/pcm/dmix.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/pcm/center_lfe.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/pcm/surround40.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/pcm/side.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/pcm/iec958.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/pcm/rear.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/pcm/surround71.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/pcm/front.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/alsa/cards/aliases.conf)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/bmd/RFFspeed_501.bmd)
    target Prebuilt:  (out/target/product/omap3evm/system/usr/share/bmd/RFFstd_501.bmd)
    host C: adb <= system/core/adb/adb.c
    host C: adb <= system/core/adb/console.c
    host C: adb <= system/core/adb/transport.c
    host C: adb <= system/core/adb/transport_local.c
    host C: adb <= system/core/adb/transport_usb.c
    host C: adb <= system/core/adb/commandline.c
    host C: adb <= system/core/adb/adb_client.c
    host C: adb <= system/core/adb/sockets.c
    host C: adb <= system/core/adb/services.c
    host C: adb <= system/core/adb/file_sync_client.c
    host C: adb <= system/core/adb/get_my_path_linux.c
    host C: adb <= system/core/adb/usb_linux.c
    host C: adb <= system/core/adb/utils.c
    host C: adb <= system/core/adb/usb_vendors.c
    host C: adb <= system/core/adb/fdevent.c
    host Executable: adb (out/host/linux-x86/obj/EXECUTABLES/adb_intermediates/adb)
    true
    Notice file: system/core/adb/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//bin/adb.txt
    Install: out/host/linux-x86/bin/adb
    host Prebuilt: android (out/host/linux-x86/obj/EXECUTABLES/android_intermediates/android)
    Install: out/host/linux-x86/bin/android
    host Java: apkcheck (out/host/common/obj/JAVA_LIBRARIES/apkcheck_intermediates/classes)
    Install: out/host/linux-x86/framework/apkcheck.jar
    Copy: apkcheck (out/host/linux-x86/obj/EXECUTABLES/apkcheck_intermediates/apkcheck)
    Install: out/host/linux-x86/bin/apkcheck
    host C: apriori <= build/tools/apriori/apriori.c
    host C: apriori <= build/tools/apriori/cmdline.c
    host C: apriori <= build/tools/apriori/debug.c
    host C: apriori <= build/tools/apriori/hash.c
    host C: apriori <= build/tools/apriori/main.c
    host C: apriori <= build/tools/apriori/prelink_info.c
    host C: apriori <= build/tools/apriori/rangesort.c
    host C: apriori <= build/tools/apriori/source.c
    host C: apriori <= build/tools/apriori/prelinkmap.c
    host C: libelfcopy <= external/elfcopy/common.c
    host C: libelfcopy <= external/elfcopy/debug.c
    host C: libelfcopy <= external/elfcopy/elfcopy.c
    host C: libelfcopy <= external/elfcopy/hash.c
    host C: libelfcopy <= external/elfcopy/rangesort.c
    host C: libelfcopy <= external/elfcopy/fixdwarf.c
    host C: libelfcopy <= external/elfcopy/dwarf.c
    host StaticLib: libelfcopy (out/host/linux-x86/obj/STATIC_LIBRARIES/libelfcopy_intermediates/libelfcopy.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libelfcopy_intermediates/common.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelfcopy_intermediates/debug.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelfcopy_intermediates/elfcopy.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelfcopy_intermediates/hash.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelfcopy_intermediates/rangesort.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelfcopy_intermediates/fixdwarf.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelfcopy_intermediates/dwarf.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libelfcopy_intermediates/libelfcopy.a
    host C: libelf <= external/elfutils/lib/xmalloc.c
    host C: libelf <= external/elfutils/lib/xstrdup.c
    host C: libelf <= external/elfutils/lib/xstrndup.c
    host C: libelf <= external/elfutils/libelf/elf32_checksum.c
    host C: libelf <= external/elfutils/libelf/elf32_fsize.c
    host C: libelf <= external/elfutils/libelf/elf32_getehdr.c
    host C: libelf <= external/elfutils/libelf/elf32_getphdr.c
    host C: libelf <= external/elfutils/libelf/elf32_getshdr.c
    host C: libelf <= external/elfutils/libelf/elf32_newehdr.c
    host C: libelf <= external/elfutils/libelf/elf32_newphdr.c
    host C: libelf <= external/elfutils/libelf/elf32_updatefile.c
    host C: libelf <= external/elfutils/libelf/elf32_updatenull.c
    host C: libelf <= external/elfutils/libelf/elf32_xlatetof.c
    host C: libelf <= external/elfutils/libelf/elf32_xlatetom.c
    host C: libelf <= external/elfutils/libelf/elf64_checksum.c
    host C: libelf <= external/elfutils/libelf/elf64_fsize.c
    host C: libelf <= external/elfutils/libelf/elf64_getehdr.c
    host C: libelf <= external/elfutils/libelf/elf64_getphdr.c
    host C: libelf <= external/elfutils/libelf/elf64_getshdr.c
    host C: libelf <= external/elfutils/libelf/elf64_newehdr.c
    host C: libelf <= external/elfutils/libelf/elf64_newphdr.c
    host C: libelf <= external/elfutils/libelf/elf64_updatefile.c
    host C: libelf <= external/elfutils/libelf/elf64_updatenull.c
    host C: libelf <= external/elfutils/libelf/elf64_xlatetof.c
    host C: libelf <= external/elfutils/libelf/elf64_xlatetom.c
    host C: libelf <= external/elfutils/libelf/elf_begin.c
    host C: libelf <= external/elfutils/libelf/elf_clone.c
    host C: libelf <= external/elfutils/libelf/elf_cntl.c
    host C: libelf <= external/elfutils/libelf/elf_end.c
    host C: libelf <= external/elfutils/libelf/elf_error.c
    host C: libelf <= external/elfutils/libelf/elf_fill.c
    host C: libelf <= external/elfutils/libelf/elf_flagdata.c
    host C: libelf <= external/elfutils/libelf/elf_flagehdr.c
    host C: libelf <= external/elfutils/libelf/elf_flagelf.c
    host C: libelf <= external/elfutils/libelf/elf_flagphdr.c
    host C: libelf <= external/elfutils/libelf/elf_flagscn.c
    host C: libelf <= external/elfutils/libelf/elf_flagshdr.c
    host C: libelf <= external/elfutils/libelf/elf_getarhdr.c
    host C: libelf <= external/elfutils/libelf/elf_getarsym.c
    host C: libelf <= external/elfutils/libelf/elf_getbase.c
    host C: libelf <= external/elfutils/libelf/elf_getdata.c
    host C: libelf <= external/elfutils/libelf/elf_getident.c
    host C: libelf <= external/elfutils/libelf/elf_getscn.c
    host C: libelf <= external/elfutils/libelf/elf_getshnum.c
    host C: libelf <= external/elfutils/libelf/elf_getshstrndx.c
    host C: libelf <= external/elfutils/libelf/elf_hash.c
    host C: libelf <= external/elfutils/libelf/elf_kind.c
    host C: libelf <= external/elfutils/libelf/elf_memory.c
    host C: libelf <= external/elfutils/libelf/elf_ndxscn.c
    host C: libelf <= external/elfutils/libelf/elf_newdata.c
    host C: libelf <= external/elfutils/libelf/elf_newscn.c
    host C: libelf <= external/elfutils/libelf/elf_next.c
    host C: libelf <= external/elfutils/libelf/elf_nextscn.c
    host C: libelf <= external/elfutils/libelf/elf_rand.c
    host C: libelf <= external/elfutils/libelf/elf_rawdata.c
    host C: libelf <= external/elfutils/libelf/elf_rawfile.c
    host C: libelf <= external/elfutils/libelf/elf_readall.c
    host C: libelf <= external/elfutils/libelf/elf_strptr.c
    host C: libelf <= external/elfutils/libelf/elf_update.c
    host C: libelf <= external/elfutils/libelf/elf_version.c
    host C: libelf <= external/elfutils/libelf/gelf_checksum.c
    host C: libelf <= external/elfutils/libelf/gelf_freechunk.c
    host C: libelf <= external/elfutils/libelf/gelf_fsize.c
    host C: libelf <= external/elfutils/libelf/gelf_getclass.c
    host C: libelf <= external/elfutils/libelf/gelf_getdyn.c
    host C: libelf <= external/elfutils/libelf/gelf_getehdr.c
    host C: libelf <= external/elfutils/libelf/gelf_getlib.c
    host C: libelf <= external/elfutils/libelf/gelf_getmove.c
    host C: libelf <= external/elfutils/libelf/gelf_getphdr.c
    host C: libelf <= external/elfutils/libelf/gelf_getrel.c
    host C: libelf <= external/elfutils/libelf/gelf_getrela.c
    host C: libelf <= external/elfutils/libelf/gelf_getshdr.c
    host C: libelf <= external/elfutils/libelf/gelf_getsym.c
    host C: libelf <= external/elfutils/libelf/gelf_getsyminfo.c
    host C: libelf <= external/elfutils/libelf/gelf_getsymshndx.c
    host C: libelf <= external/elfutils/libelf/gelf_getverdaux.c
    host C: libelf <= external/elfutils/libelf/gelf_getverdef.c
    host C: libelf <= external/elfutils/libelf/gelf_getvernaux.c
    host C: libelf <= external/elfutils/libelf/gelf_getverneed.c
    host C: libelf <= external/elfutils/libelf/gelf_getversym.c
    host C: libelf <= external/elfutils/libelf/gelf_newehdr.c
    host C: libelf <= external/elfutils/libelf/gelf_newphdr.c
    host C: libelf <= external/elfutils/libelf/gelf_rawchunk.c
    host C: libelf <= external/elfutils/libelf/gelf_update_dyn.c
    host C: libelf <= external/elfutils/libelf/gelf_update_ehdr.c
    host C: libelf <= external/elfutils/libelf/gelf_update_lib.c
    host C: libelf <= external/elfutils/libelf/gelf_update_move.c
    host C: libelf <= external/elfutils/libelf/gelf_update_phdr.c
    host C: libelf <= external/elfutils/libelf/gelf_update_rel.c
    host C: libelf <= external/elfutils/libelf/gelf_update_rela.c
    host C: libelf <= external/elfutils/libelf/gelf_update_shdr.c
    host C: libelf <= external/elfutils/libelf/gelf_update_sym.c
    host C: libelf <= external/elfutils/libelf/gelf_update_syminfo.c
    host C: libelf <= external/elfutils/libelf/gelf_update_symshndx.c
    host C: libelf <= external/elfutils/libelf/gelf_update_verdaux.c
    host C: libelf <= external/elfutils/libelf/gelf_update_verdef.c
    host C: libelf <= external/elfutils/libelf/gelf_update_vernaux.c
    host C: libelf <= external/elfutils/libelf/gelf_update_verneed.c
    host C: libelf <= external/elfutils/libelf/gelf_update_versym.c
    host C: libelf <= external/elfutils/libelf/gelf_xlate.c
    host C: libelf <= external/elfutils/libelf/gelf_xlatetof.c
    host C: libelf <= external/elfutils/libelf/gelf_xlatetom.c
    host C: libelf <= external/elfutils/libelf/libelf_crc32.c
    host C: libelf <= external/elfutils/libelf/libelf_next_prime.c
    host C: libelf <= external/elfutils/libelf/nlist.c
    host StaticLib: libelf (out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/lib/xmalloc.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/lib/xstrdup.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/lib/xstrndup.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf32_checksum.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf32_fsize.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf32_getehdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf32_getphdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf32_getshdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf32_newehdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf32_newphdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf32_updatefile.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf32_updatenull.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf32_xlatetof.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf32_xlatetom.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf64_checksum.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf64_fsize.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf64_getehdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf64_getphdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf64_getshdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf64_newehdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf64_newphdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf64_updatefile.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf64_updatenull.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf64_xlatetof.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf64_xlatetom.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_begin.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_clone.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_cntl.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_end.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_error.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_fill.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_flagdata.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_flagehdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_flagelf.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_flagphdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_flagscn.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_flagshdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_getarhdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_getarsym.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_getbase.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_getdata.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_getident.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_getscn.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_getshnum.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_getshstrndx.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_hash.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_kind.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_memory.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_ndxscn.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_newdata.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_newscn.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_next.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_nextscn.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_rand.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_rawdata.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_rawfile.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_readall.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_strptr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_update.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/elf_version.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_checksum.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_freechunk.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_fsize.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getclass.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getdyn.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getehdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getlib.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getmove.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getphdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getrel.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getrela.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getshdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getsym.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getsyminfo.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getsymshndx.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getverdaux.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getverdef.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getvernaux.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getverneed.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_getversym.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_newehdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_newphdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_rawchunk.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_update_dyn.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_update_ehdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_update_lib.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_update_move.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_update_phdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_update_rel.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_update_rela.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_update_shdr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_update_sym.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_update_syminfo.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_update_symshndx.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_update_verdaux.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_update_verdef.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_update_vernaux.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_update_verneed.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_update_versym.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_xlate.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_xlatetof.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/gelf_xlatetom.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/libelf_crc32.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/libelf_next_prime.o out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf/nlist.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libelf_intermediates/libelf.a
    host C: libebl <= external/elfutils/lib/xmalloc.c
    host C: libebl <= external/elfutils/lib/xstrdup.c
    host C: libebl <= external/elfutils/lib/xstrndup.c
    host C: libebl <= external/elfutils/libebl/eblbackendname.c
    host C: libebl <= external/elfutils/libebl/eblclosebackend.c
    host C: libebl <= external/elfutils/libebl/eblcorenote.c
    host C: libebl <= external/elfutils/libebl/eblcorenotetypename.c
    host C: libebl <= external/elfutils/libebl/ebldebugscnp.c
    host C: libebl <= external/elfutils/libebl/ebldynamictagcheck.c
    host C: libebl <= external/elfutils/libebl/ebldynamictagname.c
    host C: libebl <= external/elfutils/libebl/eblgotpcreloccheck.c
    host C: libebl <= external/elfutils/libebl/eblgstrtab.c
    host C: libebl <= external/elfutils/libebl/eblmachineflagcheck.c
    host C: libebl <= external/elfutils/libebl/eblmachineflagname.c
    host C: libebl <= external/elfutils/libebl/eblobjecttypename.c
    host C: libebl <= external/elfutils/libebl/eblobjnote.c
    host C: libebl <= external/elfutils/libebl/eblobjnotetypename.c
    host C: libebl <= external/elfutils/libebl/eblopenbackend.c
    host C: libebl <= external/elfutils/libebl/eblosabiname.c
    host C: libebl <= external/elfutils/libebl/eblreloctypecheck.c
    host C: libebl <= external/elfutils/libebl/eblreloctypename.c
    host C: libebl <= external/elfutils/libebl/eblrelocvaliduse.c
    host C: libebl <= external/elfutils/libebl/eblsectionname.c
    host C: libebl <= external/elfutils/libebl/eblsectiontypename.c
    host C: libebl <= external/elfutils/libebl/eblsegmenttypename.c
    host C: libebl <= external/elfutils/libebl/eblshflagscombine.c
    host C: libebl <= external/elfutils/libebl/eblstrtab.c
    host C: libebl <= external/elfutils/libebl/eblsymbolbindingname.c
    host C: libebl <= external/elfutils/libebl/eblsymboltypename.c
    host C: libebl <= external/elfutils/libebl/eblwstrtab.c
    host StaticLib: libebl (out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/lib/xmalloc.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/lib/xstrdup.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/lib/xstrndup.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblbackendname.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblclosebackend.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblcorenote.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblcorenotetypename.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/ebldebugscnp.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/ebldynamictagcheck.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/ebldynamictagname.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblgotpcreloccheck.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblgstrtab.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblmachineflagcheck.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblmachineflagname.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblobjecttypename.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblobjnote.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblobjnotetypename.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblopenbackend.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblosabiname.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblreloctypecheck.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblreloctypename.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblrelocvaliduse.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblsectionname.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblsectiontypename.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblsegmenttypename.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblshflagscombine.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblstrtab.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblsymbolbindingname.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblsymboltypename.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl/eblwstrtab.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_intermediates/libebl.a
    host C: libebl_arm <= external/elfutils/libebl/arm_destr.c
    host C: libebl_arm <= external/elfutils/libebl/arm_init.c
    host C: libebl_arm <= external/elfutils/libebl/arm_symbol.c
    host StaticLib: libebl_arm (out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_arm_intermediates/libebl_arm.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_arm_intermediates/libebl/arm_destr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_arm_intermediates/libebl/arm_init.o out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_arm_intermediates/libebl/arm_symbol.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libebl_arm_intermediates/libebl_arm.a
    host Executable: apriori (out/host/linux-x86/obj/EXECUTABLES/apriori_intermediates/apriori)
    true
    Notice file: external/elfcopy/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/libelfcopy.a.txt
    Install: out/host/linux-x86/bin/apriori
    host C++: atree <= build/tools/atree/atree.cpp
    host C++: atree <= build/tools/atree/files.cpp
    host C++: atree <= build/tools/atree/fs.cpp
    host Executable: atree (out/host/linux-x86/obj/EXECUTABLES/atree_intermediates/atree)
    true
    Install: out/host/linux-x86/bin/atree
    host C++: bb2sym <= sdk/emulator/qtools/bb2sym.cpp
    host C++: bb2sym <= sdk/emulator/qtools/trace_reader.cpp
    host C++: bb2sym <= sdk/emulator/qtools/decoder.cpp
    host C++: bb2sym <= sdk/emulator/qtools/read_elf.cpp
    host C++: bb2sym <= sdk/emulator/qtools/parse_options.cpp
    host Executable: bb2sym (out/host/linux-x86/obj/EXECUTABLES/bb2sym_intermediates/bb2sym)
    true
    Install: out/host/linux-x86/bin/bb2sym
    host C++: bb_dump <= sdk/emulator/qtools/bb_dump.cpp
    host C++: bb_dump <= sdk/emulator/qtools/trace_reader.cpp
    host C++: bb_dump <= sdk/emulator/qtools/decoder.cpp
    host C++: bb_dump <= sdk/emulator/qtools/read_elf.cpp
    host C++: bb_dump <= sdk/emulator/qtools/parse_options.cpp
    host Executable: bb_dump (out/host/linux-x86/obj/EXECUTABLES/bb_dump_intermediates/bb_dump)
    true
    Install: out/host/linux-x86/bin/bb_dump
    host C++: bbprof <= sdk/emulator/qtools/bbprof.cpp
    host C++: bbprof <= sdk/emulator/qtools/trace_reader.cpp
    host C++: bbprof <= sdk/emulator/qtools/decoder.cpp
    host C++: bbprof <= sdk/emulator/qtools/armdis.cpp
    host C++: bbprof <= sdk/emulator/qtools/thumbdis.cpp
    host C++: bbprof <= sdk/emulator/qtools/opcode.cpp
    host Executable: bbprof (out/host/linux-x86/obj/EXECUTABLES/bbprof_intermediates/bbprof)
    true
    Install: out/host/linux-x86/bin/bbprof
    host C: bison <= external/bison/lib/abitset.c
    host C: bison <= external/bison/lib/argmatch.c
    host C: bison <= external/bison/lib/basename.c
    host C: bison <= external/bison/lib/bitset.c
    host C: bison <= external/bison/lib/bitset_stats.c
    host C: bison <= external/bison/lib/bitsetv-print.c
    host C: bison <= external/bison/lib/bitsetv.c
    host C: bison <= external/bison/lib/dirname.c
    host C: bison <= external/bison/lib/dup-safer.c
    host C: bison <= external/bison/lib/ebitset.c
    host C: bison <= external/bison/lib/exitfail.c
    host C: bison <= external/bison/lib/fd-safer.c
    host C: bison <= external/bison/lib/fopen-safer.c
    host C: bison <= external/bison/lib/get-errno.c
    host C: bison <= external/bison/lib/hard-locale.c
    host C: bison <= external/bison/lib/hash.c
    host C: bison <= external/bison/lib/lbitset.c
    host C: bison <= external/bison/lib/mbswidth.c
    host C: bison <= external/bison/lib/pipe-safer.c
    host C: bison <= external/bison/lib/quote.c
    host C: bison <= external/bison/lib/quotearg.c
    host C: bison <= external/bison/lib/stripslash.c
    host C: bison <= external/bison/lib/subpipe.c
    host C: bison <= external/bison/lib/timevar.c
    host C: bison <= external/bison/lib/vbitset.c
    host C: bison <= external/bison/lib/xalloc-die.c
    host C: bison <= external/bison/lib/xmalloc.c
    host C: bison <= external/bison/lib/xstrndup.c
    host C: bison <= external/bison/src/LR0.c
    host C: bison <= external/bison/src/assoc.c
    host C: bison <= external/bison/src/closure.c
    host C: bison <= external/bison/src/complain.c
    host C: bison <= external/bison/src/conflicts.c
    host C: bison <= external/bison/src/derives.c
    host C: bison <= external/bison/src/files.c
    host C: bison <= external/bison/src/getargs.c
    host C: bison <= external/bison/src/gram.c
    host C: bison <= external/bison/src/lalr.c
    host C: bison <= external/bison/src/location.c
    host C: bison <= external/bison/src/main.c
    host C: bison <= external/bison/src/muscle_tab.c
    host C: bison <= external/bison/src/nullable.c
    host C: bison <= external/bison/src/output.c
    host C: bison <= external/bison/src/parse-gram.c
    host C: bison <= external/bison/src/print.c
    host C: bison <= external/bison/src/print_graph.c
    host C: bison <= external/bison/src/reader.c
    host C: bison <= external/bison/src/reduce.c
    host C: bison <= external/bison/src/relation.c
    host C: bison <= external/bison/src/scan-gram-c.c
    host C: bison <= external/bison/src/scan-skel-c.c
    host C: bison <= external/bison/src/state.c
    host C: bison <= external/bison/src/symlist.c
    host C: bison <= external/bison/src/symtab.c
    host C: bison <= external/bison/src/tables.c
    host C: bison <= external/bison/src/uniqstr.c
    host C: bison <= external/bison/src/vcg.c
    host Executable: bison (out/host/linux-x86/obj/EXECUTABLES/bison_intermediates/bison)
    true
    Install: out/host/linux-x86/bin/bison
    host C: brfpatch <= system/bluetooth/brfpatch/brfpatch.c
    host Executable: brfpatch (out/host/linux-x86/obj/EXECUTABLES/brfpatch_intermediates/brfpatch)
    true
    Install: out/host/linux-x86/bin/brfpatch
    host C: bsdiff <= external/bsdiff/bsdiff.c
    host C: libbz <= external/bzip2/blocksort.c
    host C: libbz <= external/bzip2/huffman.c
    host C: libbz <= external/bzip2/crctable.c
    host C: libbz <= external/bzip2/randtable.c
    host C: libbz <= external/bzip2/compress.c
    host C: libbz <= external/bzip2/decompress.c
    host C: libbz <= external/bzip2/bzlib.c
    host StaticLib: libbz (out/host/linux-x86/obj/STATIC_LIBRARIES/libbz_intermediates/libbz.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libbz_intermediates/blocksort.o out/host/linux-x86/obj/STATIC_LIBRARIES/libbz_intermediates/huffman.o out/host/linux-x86/obj/STATIC_LIBRARIES/libbz_intermediates/crctable.o out/host/linux-x86/obj/STATIC_LIBRARIES/libbz_intermediates/randtable.o out/host/linux-x86/obj/STATIC_LIBRARIES/libbz_intermediates/compress.o out/host/linux-x86/obj/STATIC_LIBRARIES/libbz_intermediates/decompress.o out/host/linux-x86/obj/STATIC_LIBRARIES/libbz_intermediates/bzlib.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libbz_intermediates/libbz.a
    host Executable: bsdiff (out/host/linux-x86/obj/EXECUTABLES/bsdiff_intermediates/bsdiff)
    true
    Notice file: external/bzip2/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/libbz.a.txt
    Install: out/host/linux-x86/bin/bsdiff
    host C: bspatch <= external/bsdiff/bspatch.c
    host Executable: bspatch (out/host/linux-x86/obj/EXECUTABLES/bspatch_intermediates/bspatch)
    true
    Install: out/host/linux-x86/bin/bspatch
    host Java: cfassembler (out/host/common/obj/JAVA_LIBRARIES/cfassembler_intermediates/classes)
    Install: out/host/linux-x86/framework/cfassembler.jar
    Copy: cfassembler (out/host/linux-x86/obj/EXECUTABLES/cfassembler_intermediates/cfassembler)
    Install: out/host/linux-x86/bin/cfassembler
    host C++: check_stack <= sdk/emulator/qtools/check_stack.cpp
    host C++: check_stack <= sdk/emulator/qtools/trace_reader.cpp
    host C++: check_stack <= sdk/emulator/qtools/decoder.cpp
    host C++: check_stack <= sdk/emulator/qtools/armdis.cpp
    host C++: check_stack <= sdk/emulator/qtools/thumbdis.cpp
    host C++: check_stack <= sdk/emulator/qtools/opcode.cpp
    host C++: check_stack <= sdk/emulator/qtools/read_elf.cpp
    host C++: check_stack <= sdk/emulator/qtools/parse_options.cpp
    host Executable: check_stack (out/host/linux-x86/obj/EXECUTABLES/check_stack_intermediates/check_stack)
    true
    Install: out/host/linux-x86/bin/check_stack
    host C++: check_trace <= sdk/emulator/qtools/check_trace.cpp
    host C++: check_trace <= sdk/emulator/qtools/trace_reader.cpp
    host C++: check_trace <= sdk/emulator/qtools/decoder.cpp
    host C++: check_trace <= sdk/emulator/qtools/opcode.cpp
    host C++: check_trace <= sdk/emulator/qtools/read_elf.cpp
    host C++: check_trace <= sdk/emulator/qtools/parse_options.cpp
    host Executable: check_trace (out/host/linux-x86/obj/EXECUTABLES/check_trace_intermediates/check_trace)
    true
    Install: out/host/linux-x86/bin/check_trace
    host C++: cmu2nuance <= external/srec/config/en.us/dictionary/cmu2nuance.cpp
    host Executable: cmu2nuance (out/host/linux-x86/obj/EXECUTABLES/cmu2nuance_intermediates/cmu2nuance)
    true
    Install: out/host/linux-x86/bin/cmu2nuance
    host C++: coverage <= sdk/emulator/qtools/coverage.cpp
    host C++: coverage <= sdk/emulator/qtools/trace_reader.cpp
    host C++: coverage <= sdk/emulator/qtools/decoder.cpp
    host C++: coverage <= sdk/emulator/qtools/armdis.cpp
    host C++: coverage <= sdk/emulator/qtools/thumbdis.cpp
    host C++: coverage <= sdk/emulator/qtools/opcode.cpp
    host C++: coverage <= sdk/emulator/qtools/read_elf.cpp
    host C++: coverage <= sdk/emulator/qtools/parse_options.cpp
    host Executable: coverage (out/host/linux-x86/obj/EXECUTABLES/coverage_intermediates/coverage)
    true
    Install: out/host/linux-x86/bin/coverage
    host C: create_test_dmtrace <= dalvik/tools/dmtracedump/CreateTestTrace.c
    host Executable: create_test_dmtrace (out/host/linux-x86/obj/EXECUTABLES/create_test_dmtrace_intermediates/create_test_dmtrace)
    true
    Install: out/host/linux-x86/bin/create_test_dmtrace
    host Prebuilt: cts (out/host/linux-x86/obj/EXECUTABLES/cts_intermediates/cts)
    Install: out/host/linux-x86/bin/cts
    host C: dalvikvm <= dalvik/dalvikvm/Main.c
    host asm: libdvm <= dalvik/vm/arch/x86/Call386ABI.S
    host asm: libdvm <= dalvik/vm/mterp/out/InterpAsm-x86.S
    host C: libdvm <= dalvik/vm/Atomic.c
    host C: libdvm <= dalvik/vm/IndirectRefTable.c
    host C: libdvm <= dalvik/vm/InlineNative.c
    host C: libdvm <= dalvik/vm/Misc.c
    host C: libdvm <= dalvik/vm/alloc/clz.c
    host C: libdvm <= dalvik/vm/alloc/HeapBitmap.c
    host C: libdvm <= dalvik/vm/alloc/Heap.c
    host C: libdvm <= dalvik/vm/interp/Interp.c
    host C: libdvm <= dalvik/vm/mterp/Mterp.c
    host C: libdvm <= dalvik/vm/mterp/out/InterpC-portstd.c
    host C: libdvm <= dalvik/vm/mterp/out/InterpC-portdbg.c
    host C: libdvm <= dalvik/vm/test/AtomicTest.c
    host C: libdvm <= dalvik/vm/alloc/MarkSweep.c
    host C: libdvm <= dalvik/vm/AllocTracker.c
    host C: libdvm <= dalvik/vm/AtomicCache.c
    host C: libdvm <= dalvik/vm/CheckJni.c
    host C: libdvm <= dalvik/vm/Ddm.c
    host C: libdvm <= dalvik/vm/Debugger.c
    host C: libdvm <= dalvik/vm/DvmDex.c
    host C: libdvm <= dalvik/vm/Exception.c
    host C: libdvm <= dalvik/vm/Hash.c
    host C: libdvm <= dalvik/vm/Init.c
    host C: libdvm <= dalvik/vm/Inlines.c
    host C: libdvm <= dalvik/vm/Intern.c
    host C: libdvm <= dalvik/vm/Jni.c
    host C: libdvm <= dalvik/vm/JarFile.c
    host C: libdvm <= dalvik/vm/LinearAlloc.c
    host C: libdvm <= dalvik/vm/Native.c
    host C: libdvm <= dalvik/vm/PointerSet.c
    host C: libdvm <= dalvik/vm/Profile.c
    host C: libdvm <= dalvik/vm/Properties.c
    host C: libdvm <= dalvik/vm/RawDexFile.c
    host C: libdvm <= dalvik/vm/ReferenceTable.c
    host C: libdvm <= dalvik/vm/SignalCatcher.c
    host C: libdvm <= dalvik/vm/StdioConverter.c
    host C: libdvm <= dalvik/vm/Sync.c
    host C: libdvm <= dalvik/vm/TestCompability.c
    host C: libdvm <= dalvik/vm/Thread.c
    host C: libdvm <= dalvik/vm/UtfString.c
    host C: libdvm <= dalvik/vm/alloc/Alloc.c
    host C: libdvm <= dalvik/vm/alloc/CardTable.c
    host C: libdvm <= dalvik/vm/alloc/HeapDebug.c
    host C: libdvm <= dalvik/vm/alloc/HeapTable.c
    host C: libdvm <= dalvik/vm/alloc/HeapWorker.c
    host C: libdvm <= dalvik/vm/alloc/DdmHeap.c
    host C: libdvm <= dalvik/vm/alloc/Verify.c
    host C: libdvm <= dalvik/vm/alloc/Visit.c
    host C: libdvm <= dalvik/vm/analysis/CodeVerify.c
    host C: libdvm <= dalvik/vm/analysis/DexPrepare.c
    host C: libdvm <= dalvik/vm/analysis/DexVerify.c
    host C: libdvm <= dalvik/vm/analysis/Optimize.c
    host C: libdvm <= dalvik/vm/analysis/RegisterMap.c
    host C: libdvm <= dalvik/vm/analysis/VerifySubs.c
    host C: libdvm <= dalvik/vm/interp/Stack.c
    host C: libdvm <= dalvik/vm/jdwp/ExpandBuf.c
    host C: libdvm <= dalvik/vm/jdwp/JdwpAdb.c
    host C: libdvm <= dalvik/vm/jdwp/JdwpConstants.c
    host C: libdvm <= dalvik/vm/jdwp/JdwpEvent.c
    host C: libdvm <= dalvik/vm/jdwp/JdwpHandler.c
    host C: libdvm <= dalvik/vm/jdwp/JdwpMain.c
    host C: libdvm <= dalvik/vm/jdwp/JdwpSocket.c
    host C: libdvm <= dalvik/vm/native/InternalNative.c
    host C: libdvm <= dalvik/vm/native/dalvik_system_DexFile.c
    host C: libdvm <= dalvik/vm/native/dalvik_system_VMDebug.c
    host C: libdvm <= dalvik/vm/native/dalvik_system_VMRuntime.c
    host C: libdvm <= dalvik/vm/native/dalvik_system_VMStack.c
    host C: libdvm <= dalvik/vm/native/dalvik_system_Zygote.c
    host C: libdvm <= dalvik/vm/native/java_lang_Class.c
    host C: libdvm <= dalvik/vm/native/java_lang_Object.c
    host C: libdvm <= dalvik/vm/native/java_lang_Runtime.c
    host C: libdvm <= dalvik/vm/native/java_lang_String.c
    host C: libdvm <= dalvik/vm/native/java_lang_System.c
    host C: libdvm <= dalvik/vm/native/java_lang_SystemProperties.c
    host C: libdvm <= dalvik/vm/native/java_lang_Throwable.c
    host C: libdvm <= dalvik/vm/native/java_lang_VMClassLoader.c
    host C: libdvm <= dalvik/vm/native/java_lang_VMThread.c
    host C: libdvm <= dalvik/vm/native/java_lang_reflect_AccessibleObject.c
    host C: libdvm <= dalvik/vm/native/java_lang_reflect_Array.c
    host C: libdvm <= dalvik/vm/native/java_lang_reflect_Constructor.c
    host C: libdvm <= dalvik/vm/native/java_lang_reflect_Field.c
    host C: libdvm <= dalvik/vm/native/java_lang_reflect_Method.c
    host C: libdvm <= dalvik/vm/native/java_lang_reflect_Proxy.c
    host C: libdvm <= dalvik/vm/native/java_security_AccessController.c
    host C: libdvm <= dalvik/vm/native/java_util_concurrent_atomic_AtomicLong.c
    host C: libdvm <= dalvik/vm/native/org_apache_harmony_dalvik_NativeTestTarget.c
    host C: libdvm <= dalvik/vm/native/org_apache_harmony_dalvik_ddmc_DdmServer.c
    host C: libdvm <= dalvik/vm/native/org_apache_harmony_dalvik_ddmc_DdmVmInternal.c
    host C: libdvm <= dalvik/vm/native/sun_misc_Unsafe.c
    host C: libdvm <= dalvik/vm/oo/AccessCheck.c
    host C: libdvm <= dalvik/vm/oo/Array.c
    host C: libdvm <= dalvik/vm/oo/Class.c
    host C: libdvm <= dalvik/vm/oo/Object.c
    host C: libdvm <= dalvik/vm/oo/Resolve.c
    host C: libdvm <= dalvik/vm/oo/TypeCheck.c
    host C: libdvm <= dalvik/vm/reflect/Annotation.c
    host C: libdvm <= dalvik/vm/reflect/Proxy.c
    host C: libdvm <= dalvik/vm/reflect/Reflect.c
    host C: libdvm <= dalvik/vm/test/TestHash.c
    host C: libdvm <= dalvik/vm/test/TestIndirectRefTable.c
    host C: libdvm <= dalvik/vm/alloc/HeapSource.c
    host C: libdvm <= dalvik/vm/hprof/Hprof.c
    host C: libdvm <= dalvik/vm/hprof/HprofClass.c
    host C: libdvm <= dalvik/vm/hprof/HprofHeap.c
    host C: libdvm <= dalvik/vm/hprof/HprofOutput.c
    host C: libdvm <= dalvik/vm/hprof/HprofString.c
    host C: libdvm <= dalvik/vm/arch/x86/Hints386ABI.c
    host C: libdvm <= dalvik/vm/mterp/out/InterpC-x86.c
    host C: libcrypto <= external/openssl/crypto/cryptlib.c
    host C: libcrypto <= external/openssl/crypto/mem.c
    host C: libcrypto <= external/openssl/crypto/mem_clr.c
    host C: libcrypto <= external/openssl/crypto/mem_dbg.c
    host C: libcrypto <= external/openssl/crypto/cversion.c
    host C: libcrypto <= external/openssl/crypto/ex_data.c
    host C: libcrypto <= external/openssl/crypto/cpt_err.c
    host C: libcrypto <= external/openssl/crypto/ebcdic.c
    host C: libcrypto <= external/openssl/crypto/uid.c
    host C: libcrypto <= external/openssl/crypto/o_time.c
    host C: libcrypto <= external/openssl/crypto/o_str.c
    host C: libcrypto <= external/openssl/crypto/o_dir.c
    host C: libcrypto <= external/openssl/crypto/aes/aes_cbc.c
    host C: libcrypto <= external/openssl/crypto/aes/aes_cfb.c
    host C: libcrypto <= external/openssl/crypto/aes/aes_ctr.c
    host C: libcrypto <= external/openssl/crypto/aes/aes_ecb.c
    host C: libcrypto <= external/openssl/crypto/aes/aes_misc.c
    host C: libcrypto <= external/openssl/crypto/aes/aes_ofb.c
    host C: libcrypto <= external/openssl/crypto/aes/aes_wrap.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_bitstr.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_bool.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_bytes.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_d2i_fp.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_digest.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_dup.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_enum.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_gentm.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_i2d_fp.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_int.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_mbstr.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_object.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_octet.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_print.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_set.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_sign.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_strex.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_strnid.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_time.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_type.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_utctm.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_utf8.c
    host C: libcrypto <= external/openssl/crypto/asn1/a_verify.c
    host C: libcrypto <= external/openssl/crypto/asn1/ameth_lib.c
    host C: libcrypto <= external/openssl/crypto/asn1/asn1_err.c
    host C: libcrypto <= external/openssl/crypto/asn1/asn1_gen.c
    host C: libcrypto <= external/openssl/crypto/asn1/asn1_lib.c
    host C: libcrypto <= external/openssl/crypto/asn1/asn1_par.c
    host C: libcrypto <= external/openssl/crypto/asn1/asn_mime.c
    host C: libcrypto <= external/openssl/crypto/asn1/asn_moid.c
    host C: libcrypto <= external/openssl/crypto/asn1/asn_pack.c
    host C: libcrypto <= external/openssl/crypto/asn1/bio_asn1.c
    host C: libcrypto <= external/openssl/crypto/asn1/bio_ndef.c
    host C: libcrypto <= external/openssl/crypto/asn1/d2i_pr.c
    host C: libcrypto <= external/openssl/crypto/asn1/d2i_pu.c
    host C: libcrypto <= external/openssl/crypto/asn1/evp_asn1.c
    host C: libcrypto <= external/openssl/crypto/asn1/f_enum.c
    host C: libcrypto <= external/openssl/crypto/asn1/f_int.c
    host C: libcrypto <= external/openssl/crypto/asn1/f_string.c
    host C: libcrypto <= external/openssl/crypto/asn1/i2d_pr.c
    host C: libcrypto <= external/openssl/crypto/asn1/i2d_pu.c
    host C: libcrypto <= external/openssl/crypto/asn1/n_pkey.c
    host C: libcrypto <= external/openssl/crypto/asn1/nsseq.c
    host C: libcrypto <= external/openssl/crypto/asn1/p5_pbe.c
    host C: libcrypto <= external/openssl/crypto/asn1/p5_pbev2.c
    host C: libcrypto <= external/openssl/crypto/asn1/p8_pkey.c
    host C: libcrypto <= external/openssl/crypto/asn1/t_bitst.c
    host C: libcrypto <= external/openssl/crypto/asn1/t_crl.c
    host C: libcrypto <= external/openssl/crypto/asn1/t_pkey.c
    host C: libcrypto <= external/openssl/crypto/asn1/t_req.c
    host C: libcrypto <= external/openssl/crypto/asn1/t_spki.c
    host C: libcrypto <= external/openssl/crypto/asn1/t_x509.c
    host C: libcrypto <= external/openssl/crypto/asn1/t_x509a.c
    host C: libcrypto <= external/openssl/crypto/asn1/tasn_dec.c
    host C: libcrypto <= external/openssl/crypto/asn1/tasn_enc.c
    host C: libcrypto <= external/openssl/crypto/asn1/tasn_fre.c
    host C: libcrypto <= external/openssl/crypto/asn1/tasn_new.c
    host C: libcrypto <= external/openssl/crypto/asn1/tasn_prn.c
    host C: libcrypto <= external/openssl/crypto/asn1/tasn_typ.c
    host C: libcrypto <= external/openssl/crypto/asn1/tasn_utl.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_algor.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_attrib.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_bignum.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_crl.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_exten.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_info.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_long.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_name.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_nx509.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_pkey.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_pubkey.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_req.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_sig.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_spki.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_val.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_x509.c
    host C: libcrypto <= external/openssl/crypto/asn1/x_x509a.c
    host C: libcrypto <= external/openssl/crypto/bf/bf_cfb64.c
    host C: libcrypto <= external/openssl/crypto/bf/bf_ecb.c
    host C: libcrypto <= external/openssl/crypto/bf/bf_enc.c
    host C: libcrypto <= external/openssl/crypto/bf/bf_ofb64.c
    host C: libcrypto <= external/openssl/crypto/bf/bf_skey.c
    host C: libcrypto <= external/openssl/crypto/bio/b_dump.c
    host C: libcrypto <= external/openssl/crypto/bio/b_print.c
    host C: libcrypto <= external/openssl/crypto/bio/b_sock.c
    host C: libcrypto <= external/openssl/crypto/bio/bf_buff.c
    host C: libcrypto <= external/openssl/crypto/bio/bf_nbio.c
    host C: libcrypto <= external/openssl/crypto/bio/bf_null.c
    host C: libcrypto <= external/openssl/crypto/bio/bio_cb.c
    host C: libcrypto <= external/openssl/crypto/bio/bio_err.c
    host C: libcrypto <= external/openssl/crypto/bio/bio_lib.c
    host C: libcrypto <= external/openssl/crypto/bio/bss_acpt.c
    host C: libcrypto <= external/openssl/crypto/bio/bss_bio.c
    host C: libcrypto <= external/openssl/crypto/bio/bss_conn.c
    host C: libcrypto <= external/openssl/crypto/bio/bss_dgram.c
    host C: libcrypto <= external/openssl/crypto/bio/bss_fd.c
    host C: libcrypto <= external/openssl/crypto/bio/bss_file.c
    host C: libcrypto <= external/openssl/crypto/bio/bss_log.c
    host C: libcrypto <= external/openssl/crypto/bio/bss_mem.c
    host C: libcrypto <= external/openssl/crypto/bio/bss_null.c
    host C: libcrypto <= external/openssl/crypto/bio/bss_sock.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_add.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_asm.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_blind.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_ctx.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_div.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_err.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_exp.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_exp2.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_gcd.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_gf2m.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_kron.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_lib.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_mod.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_mont.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_mpi.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_mul.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_nist.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_prime.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_print.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_rand.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_recp.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_shift.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_sqr.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_sqrt.c
    host C: libcrypto <= external/openssl/crypto/bn/bn_word.c
    host C: libcrypto <= external/openssl/crypto/buffer/buf_err.c
    host C: libcrypto <= external/openssl/crypto/buffer/buffer.c
    host C: libcrypto <= external/openssl/crypto/comp/c_rle.c
    host C: libcrypto <= external/openssl/crypto/comp/c_zlib.c
    host C: libcrypto <= external/openssl/crypto/comp/comp_err.c
    host C: libcrypto <= external/openssl/crypto/comp/comp_lib.c
    host C: libcrypto <= external/openssl/crypto/conf/conf_api.c
    host C: libcrypto <= external/openssl/crypto/conf/conf_def.c
    host C: libcrypto <= external/openssl/crypto/conf/conf_err.c
    host C: libcrypto <= external/openssl/crypto/conf/conf_lib.c
    host C: libcrypto <= external/openssl/crypto/conf/conf_mall.c
    host C: libcrypto <= external/openssl/crypto/conf/conf_mod.c
    host C: libcrypto <= external/openssl/crypto/conf/conf_sap.c
    host C: libcrypto <= external/openssl/crypto/des/cbc_cksm.c
    host C: libcrypto <= external/openssl/crypto/des/cbc_enc.c
    host C: libcrypto <= external/openssl/crypto/des/cfb64ede.c
    host C: libcrypto <= external/openssl/crypto/des/cfb64enc.c
    host C: libcrypto <= external/openssl/crypto/des/cfb_enc.c
    host C: libcrypto <= external/openssl/crypto/des/des_enc.c
    host C: libcrypto <= external/openssl/crypto/des/des_old.c
    host C: libcrypto <= external/openssl/crypto/des/des_old2.c
    host C: libcrypto <= external/openssl/crypto/des/ecb3_enc.c
    host C: libcrypto <= external/openssl/crypto/des/ecb_enc.c
    host C: libcrypto <= external/openssl/crypto/des/ede_cbcm_enc.c
    host C: libcrypto <= external/openssl/crypto/des/enc_read.c
    host C: libcrypto <= external/openssl/crypto/des/enc_writ.c
    host C: libcrypto <= external/openssl/crypto/des/fcrypt.c
    host C: libcrypto <= external/openssl/crypto/des/fcrypt_b.c
    host C: libcrypto <= external/openssl/crypto/des/ofb64ede.c
    host C: libcrypto <= external/openssl/crypto/des/ofb64enc.c
    host C: libcrypto <= external/openssl/crypto/des/ofb_enc.c
    host C: libcrypto <= external/openssl/crypto/des/pcbc_enc.c
    host C: libcrypto <= external/openssl/crypto/des/qud_cksm.c
    host C: libcrypto <= external/openssl/crypto/des/rand_key.c
    host C: libcrypto <= external/openssl/crypto/des/read2pwd.c
    host C: libcrypto <= external/openssl/crypto/des/rpc_enc.c
    host C: libcrypto <= external/openssl/crypto/des/set_key.c
    host C: libcrypto <= external/openssl/crypto/des/str2key.c
    host C: libcrypto <= external/openssl/crypto/des/xcbc_enc.c
    host C: libcrypto <= external/openssl/crypto/dh/dh_ameth.c
    host C: libcrypto <= external/openssl/crypto/dh/dh_asn1.c
    host C: libcrypto <= external/openssl/crypto/dh/dh_check.c
    host C: libcrypto <= external/openssl/crypto/dh/dh_depr.c
    host C: libcrypto <= external/openssl/crypto/dh/dh_err.c
    host C: libcrypto <= external/openssl/crypto/dh/dh_gen.c
    host C: libcrypto <= external/openssl/crypto/dh/dh_key.c
    host C: libcrypto <= external/openssl/crypto/dh/dh_lib.c
    host C: libcrypto <= external/openssl/crypto/dh/dh_pmeth.c
    host C: libcrypto <= external/openssl/crypto/dsa/dsa_ameth.c
    host C: libcrypto <= external/openssl/crypto/dsa/dsa_asn1.c
    host C: libcrypto <= external/openssl/crypto/dsa/dsa_depr.c
    host C: libcrypto <= external/openssl/crypto/dsa/dsa_err.c
    host C: libcrypto <= external/openssl/crypto/dsa/dsa_gen.c
    host C: libcrypto <= external/openssl/crypto/dsa/dsa_key.c
    host C: libcrypto <= external/openssl/crypto/dsa/dsa_lib.c
    host C: libcrypto <= external/openssl/crypto/dsa/dsa_ossl.c
    host C: libcrypto <= external/openssl/crypto/dsa/dsa_pmeth.c
    host C: libcrypto <= external/openssl/crypto/dsa/dsa_prn.c
    host C: libcrypto <= external/openssl/crypto/dsa/dsa_sign.c
    host C: libcrypto <= external/openssl/crypto/dsa/dsa_vrf.c
    host C: libcrypto <= external/openssl/crypto/dso/dso_dl.c
    host C: libcrypto <= external/openssl/crypto/dso/dso_dlfcn.c
    host C: libcrypto <= external/openssl/crypto/dso/dso_err.c
    host C: libcrypto <= external/openssl/crypto/dso/dso_lib.c
    host C: libcrypto <= external/openssl/crypto/dso/dso_null.c
    host C: libcrypto <= external/openssl/crypto/dso/dso_openssl.c
    host C: libcrypto <= external/openssl/crypto/dso/dso_vms.c
    host C: libcrypto <= external/openssl/crypto/dso/dso_win32.c
    host C: libcrypto <= external/openssl/crypto/ec/ec2_mult.c
    host C: libcrypto <= external/openssl/crypto/ec/ec2_smpl.c
    host C: libcrypto <= external/openssl/crypto/ec/ec_ameth.c
    host C: libcrypto <= external/openssl/crypto/ec/ec_asn1.c
    host C: libcrypto <= external/openssl/crypto/ec/ec_check.c
    host C: libcrypto <= external/openssl/crypto/ec/ec_curve.c
    host C: libcrypto <= external/openssl/crypto/ec/ec_cvt.c
    host C: libcrypto <= external/openssl/crypto/ec/ec_err.c
    host C: libcrypto <= external/openssl/crypto/ec/ec_key.c
    host C: libcrypto <= external/openssl/crypto/ec/ec_lib.c
    host C: libcrypto <= external/openssl/crypto/ec/ec_mult.c
    host C: libcrypto <= external/openssl/crypto/ec/ec_pmeth.c
    host C: libcrypto <= external/openssl/crypto/ec/ec_print.c
    host C: libcrypto <= external/openssl/crypto/ec/eck_prn.c
    host C: libcrypto <= external/openssl/crypto/ec/ecp_mont.c
    host C: libcrypto <= external/openssl/crypto/ec/ecp_nist.c
    host C: libcrypto <= external/openssl/crypto/ec/ecp_smpl.c
    host C: libcrypto <= external/openssl/crypto/ecdh/ech_err.c
    host C: libcrypto <= external/openssl/crypto/ecdh/ech_key.c
    host C: libcrypto <= external/openssl/crypto/ecdh/ech_lib.c
    host C: libcrypto <= external/openssl/crypto/ecdh/ech_ossl.c
    host C: libcrypto <= external/openssl/crypto/ecdsa/ecs_asn1.c
    host C: libcrypto <= external/openssl/crypto/ecdsa/ecs_err.c
    host C: libcrypto <= external/openssl/crypto/ecdsa/ecs_lib.c
    host C: libcrypto <= external/openssl/crypto/ecdsa/ecs_ossl.c
    host C: libcrypto <= external/openssl/crypto/ecdsa/ecs_sign.c
    host C: libcrypto <= external/openssl/crypto/ecdsa/ecs_vrf.c
    host C: libcrypto <= external/openssl/crypto/err/err.c
    host C: libcrypto <= external/openssl/crypto/err/err_all.c
    host C: libcrypto <= external/openssl/crypto/err/err_prn.c
    host C: libcrypto <= external/openssl/crypto/evp/bio_b64.c
    host C: libcrypto <= external/openssl/crypto/evp/bio_enc.c
    host C: libcrypto <= external/openssl/crypto/evp/bio_md.c
    host C: libcrypto <= external/openssl/crypto/evp/bio_ok.c
    host C: libcrypto <= external/openssl/crypto/evp/c_all.c
    host C: libcrypto <= external/openssl/crypto/evp/c_allc.c
    host C: libcrypto <= external/openssl/crypto/evp/c_alld.c
    host C: libcrypto <= external/openssl/crypto/evp/digest.c
    host C: libcrypto <= external/openssl/crypto/evp/e_aes.c
    host C: libcrypto <= external/openssl/crypto/evp/e_bf.c
    host C: libcrypto <= external/openssl/crypto/evp/e_des.c
    host C: libcrypto <= external/openssl/crypto/evp/e_des3.c
    host C: libcrypto <= external/openssl/crypto/evp/e_null.c
    host C: libcrypto <= external/openssl/crypto/evp/e_old.c
    host C: libcrypto <= external/openssl/crypto/evp/e_rc2.c
    host C: libcrypto <= external/openssl/crypto/evp/e_rc4.c
    host C: libcrypto <= external/openssl/crypto/evp/e_rc5.c
    host C: libcrypto <= external/openssl/crypto/evp/e_xcbc_d.c
    host C: libcrypto <= external/openssl/crypto/evp/encode.c
    host C: libcrypto <= external/openssl/crypto/evp/evp_acnf.c
    host C: libcrypto <= external/openssl/crypto/evp/evp_enc.c
    host C: libcrypto <= external/openssl/crypto/evp/evp_err.c
    host C: libcrypto <= external/openssl/crypto/evp/evp_key.c
    host C: libcrypto <= external/openssl/crypto/evp/evp_lib.c
    host C: libcrypto <= external/openssl/crypto/evp/evp_pbe.c
    host C: libcrypto <= external/openssl/crypto/evp/evp_pkey.c
    host C: libcrypto <= external/openssl/crypto/evp/m_dss.c
    host C: libcrypto <= external/openssl/crypto/evp/m_dss1.c
    host C: libcrypto <= external/openssl/crypto/evp/m_ecdsa.c
    host C: libcrypto <= external/openssl/crypto/evp/m_md4.c
    host C: libcrypto <= external/openssl/crypto/evp/m_md5.c
    host C: libcrypto <= external/openssl/crypto/evp/m_mdc2.c
    host C: libcrypto <= external/openssl/crypto/evp/m_null.c
    host C: libcrypto <= external/openssl/crypto/evp/m_ripemd.c
    host C: libcrypto <= external/openssl/crypto/evp/m_sha1.c
    host C: libcrypto <= external/openssl/crypto/evp/m_sigver.c
    host C: libcrypto <= external/openssl/crypto/evp/m_wp.c
    host C: libcrypto <= external/openssl/crypto/evp/names.c
    host C: libcrypto <= external/openssl/crypto/evp/p5_crpt.c
    host C: libcrypto <= external/openssl/crypto/evp/p5_crpt2.c
    host C: libcrypto <= external/openssl/crypto/evp/p_dec.c
    host C: libcrypto <= external/openssl/crypto/evp/p_enc.c
    host C: libcrypto <= external/openssl/crypto/evp/p_lib.c
    host C: libcrypto <= external/openssl/crypto/evp/p_open.c
    host C: libcrypto <= external/openssl/crypto/evp/p_seal.c
    host C: libcrypto <= external/openssl/crypto/evp/p_sign.c
    host C: libcrypto <= external/openssl/crypto/evp/p_verify.c
    host C: libcrypto <= external/openssl/crypto/evp/pmeth_fn.c
    host C: libcrypto <= external/openssl/crypto/evp/pmeth_gn.c
    host C: libcrypto <= external/openssl/crypto/evp/pmeth_lib.c
    host C: libcrypto <= external/openssl/crypto/hmac/hm_ameth.c
    host C: libcrypto <= external/openssl/crypto/hmac/hm_pmeth.c
    host C: libcrypto <= external/openssl/crypto/hmac/hmac.c
    host C: libcrypto <= external/openssl/crypto/krb5/krb5_asn.c
    host C: libcrypto <= external/openssl/crypto/lhash/lh_stats.c
    host C: libcrypto <= external/openssl/crypto/lhash/lhash.c
    host C: libcrypto <= external/openssl/crypto/md4/md4_dgst.c
    host C: libcrypto <= external/openssl/crypto/md4/md4_one.c
    host C: libcrypto <= external/openssl/crypto/md5/md5_dgst.c
    host C: libcrypto <= external/openssl/crypto/md5/md5_one.c
    host C: libcrypto <= external/openssl/crypto/modes/cbc128.c
    host C: libcrypto <= external/openssl/crypto/modes/cfb128.c
    host C: libcrypto <= external/openssl/crypto/modes/ctr128.c
    host C: libcrypto <= external/openssl/crypto/modes/ofb128.c
    host C: libcrypto <= external/openssl/crypto/objects/o_names.c
    host C: libcrypto <= external/openssl/crypto/objects/obj_dat.c
    host C: libcrypto <= external/openssl/crypto/objects/obj_err.c
    host C: libcrypto <= external/openssl/crypto/objects/obj_lib.c
    host C: libcrypto <= external/openssl/crypto/objects/obj_xref.c
    host C: libcrypto <= external/openssl/crypto/ocsp/ocsp_asn.c
    host C: libcrypto <= external/openssl/crypto/ocsp/ocsp_cl.c
    host C: libcrypto <= external/openssl/crypto/ocsp/ocsp_err.c
    host C: libcrypto <= external/openssl/crypto/ocsp/ocsp_ext.c
    host C: libcrypto <= external/openssl/crypto/ocsp/ocsp_ht.c
    host C: libcrypto <= external/openssl/crypto/ocsp/ocsp_lib.c
    host C: libcrypto <= external/openssl/crypto/ocsp/ocsp_prn.c
    host C: libcrypto <= external/openssl/crypto/ocsp/ocsp_srv.c
    host C: libcrypto <= external/openssl/crypto/ocsp/ocsp_vfy.c
    host C: libcrypto <= external/openssl/crypto/pem/pem_all.c
    host C: libcrypto <= external/openssl/crypto/pem/pem_err.c
    host C: libcrypto <= external/openssl/crypto/pem/pem_info.c
    host C: libcrypto <= external/openssl/crypto/pem/pem_lib.c
    host C: libcrypto <= external/openssl/crypto/pem/pem_oth.c
    host C: libcrypto <= external/openssl/crypto/pem/pem_pk8.c
    host C: libcrypto <= external/openssl/crypto/pem/pem_pkey.c
    host C: libcrypto <= external/openssl/crypto/pem/pem_seal.c
    host C: libcrypto <= external/openssl/crypto/pem/pem_sign.c
    host C: libcrypto <= external/openssl/crypto/pem/pem_x509.c
    host C: libcrypto <= external/openssl/crypto/pem/pem_xaux.c
    host C: libcrypto <= external/openssl/crypto/pem/pvkfmt.c
    host C: libcrypto <= external/openssl/crypto/pkcs12/p12_add.c
    host C: libcrypto <= external/openssl/crypto/pkcs12/p12_asn.c
    host C: libcrypto <= external/openssl/crypto/pkcs12/p12_attr.c
    host C: libcrypto <= external/openssl/crypto/pkcs12/p12_crpt.c
    host C: libcrypto <= external/openssl/crypto/pkcs12/p12_crt.c
    host C: libcrypto <= external/openssl/crypto/pkcs12/p12_decr.c
    host C: libcrypto <= external/openssl/crypto/pkcs12/p12_init.c
    host C: libcrypto <= external/openssl/crypto/pkcs12/p12_key.c
    host C: libcrypto <= external/openssl/crypto/pkcs12/p12_kiss.c
    host C: libcrypto <= external/openssl/crypto/pkcs12/p12_mutl.c
    host C: libcrypto <= external/openssl/crypto/pkcs12/p12_npas.c
    host C: libcrypto <= external/openssl/crypto/pkcs12/p12_p8d.c
    host C: libcrypto <= external/openssl/crypto/pkcs12/p12_p8e.c
    host C: libcrypto <= external/openssl/crypto/pkcs12/p12_utl.c
    host C: libcrypto <= external/openssl/crypto/pkcs12/pk12err.c
    host C: libcrypto <= external/openssl/crypto/pkcs7/pk7_asn1.c
    host C: libcrypto <= external/openssl/crypto/pkcs7/pk7_attr.c
    host C: libcrypto <= external/openssl/crypto/pkcs7/pk7_doit.c
    host C: libcrypto <= external/openssl/crypto/pkcs7/pk7_lib.c
    host C: libcrypto <= external/openssl/crypto/pkcs7/pk7_mime.c
    host C: libcrypto <= external/openssl/crypto/pkcs7/pk7_smime.c
    host C: libcrypto <= external/openssl/crypto/pkcs7/pkcs7err.c
    host C: libcrypto <= external/openssl/crypto/rand/md_rand.c
    host C: libcrypto <= external/openssl/crypto/rand/rand_egd.c
    host C: libcrypto <= external/openssl/crypto/rand/rand_err.c
    host C: libcrypto <= external/openssl/crypto/rand/rand_lib.c
    host C: libcrypto <= external/openssl/crypto/rand/rand_unix.c
    host C: libcrypto <= external/openssl/crypto/rand/randfile.c
    host C: libcrypto <= external/openssl/crypto/rc2/rc2_cbc.c
    host C: libcrypto <= external/openssl/crypto/rc2/rc2_ecb.c
    host C: libcrypto <= external/openssl/crypto/rc2/rc2_skey.c
    host C: libcrypto <= external/openssl/crypto/rc2/rc2cfb64.c
    host C: libcrypto <= external/openssl/crypto/rc2/rc2ofb64.c
    host C: libcrypto <= external/openssl/crypto/rc4/rc4_enc.c
    host C: libcrypto <= external/openssl/crypto/rc4/rc4_skey.c
    host C: libcrypto <= external/openssl/crypto/ripemd/rmd_dgst.c
    host C: libcrypto <= external/openssl/crypto/ripemd/rmd_one.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_ameth.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_asn1.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_chk.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_eay.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_err.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_gen.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_lib.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_none.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_null.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_oaep.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_pk1.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_pmeth.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_prn.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_pss.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_saos.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_sign.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_ssl.c
    host C: libcrypto <= external/openssl/crypto/rsa/rsa_x931.c
    host C: libcrypto <= external/openssl/crypto/sha/sha1_one.c
    host C: libcrypto <= external/openssl/crypto/sha/sha1dgst.c
    host C: libcrypto <= external/openssl/crypto/sha/sha256.c
    host C: libcrypto <= external/openssl/crypto/sha/sha512.c
    host C: libcrypto <= external/openssl/crypto/sha/sha_dgst.c
    host C: libcrypto <= external/openssl/crypto/stack/stack.c
    host C: libcrypto <= external/openssl/crypto/ts/ts_err.c
    host C: libcrypto <= external/openssl/crypto/txt_db/txt_db.c
    host C: libcrypto <= external/openssl/crypto/ui/ui_compat.c
    host C: libcrypto <= external/openssl/crypto/ui/ui_err.c
    host C: libcrypto <= external/openssl/crypto/ui/ui_lib.c
    host C: libcrypto <= external/openssl/crypto/ui/ui_openssl.c
    host C: libcrypto <= external/openssl/crypto/ui/ui_util.c
    host C: libcrypto <= external/openssl/crypto/x509/by_dir.c
    host C: libcrypto <= external/openssl/crypto/x509/by_file.c
    host C: libcrypto <= external/openssl/crypto/x509/x509_att.c
    host C: libcrypto <= external/openssl/crypto/x509/x509_cmp.c
    host C: libcrypto <= external/openssl/crypto/x509/x509_d2.c
    host C: libcrypto <= external/openssl/crypto/x509/x509_def.c
    host C: libcrypto <= external/openssl/crypto/x509/x509_err.c
    host C: libcrypto <= external/openssl/crypto/x509/x509_ext.c
    host C: libcrypto <= external/openssl/crypto/x509/x509_lu.c
    host C: libcrypto <= external/openssl/crypto/x509/x509_obj.c
    host C: libcrypto <= external/openssl/crypto/x509/x509_r2x.c
    host C: libcrypto <= external/openssl/crypto/x509/x509_req.c
    host C: libcrypto <= external/openssl/crypto/x509/x509_set.c
    host C: libcrypto <= external/openssl/crypto/x509/x509_trs.c
    host C: libcrypto <= external/openssl/crypto/x509/x509_txt.c
    host C: libcrypto <= external/openssl/crypto/x509/x509_v3.c
    host C: libcrypto <= external/openssl/crypto/x509/x509_vfy.c
    host C: libcrypto <= external/openssl/crypto/x509/x509_vpm.c
    host C: libcrypto <= external/openssl/crypto/x509/x509cset.c
    host C: libcrypto <= external/openssl/crypto/x509/x509name.c
    host C: libcrypto <= external/openssl/crypto/x509/x509rset.c
    host C: libcrypto <= external/openssl/crypto/x509/x509spki.c
    host C: libcrypto <= external/openssl/crypto/x509/x509type.c
    host C: libcrypto <= external/openssl/crypto/x509/x_all.c
    host C: libcrypto <= external/openssl/crypto/x509v3/pcy_cache.c
    host C: libcrypto <= external/openssl/crypto/x509v3/pcy_data.c
    host C: libcrypto <= external/openssl/crypto/x509v3/pcy_lib.c
    host C: libcrypto <= external/openssl/crypto/x509v3/pcy_map.c
    host C: libcrypto <= external/openssl/crypto/x509v3/pcy_node.c
    host C: libcrypto <= external/openssl/crypto/x509v3/pcy_tree.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_akey.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_akeya.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_alt.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_bcons.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_bitst.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_conf.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_cpols.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_crld.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_enum.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_extku.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_genn.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_ia5.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_info.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_int.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_lib.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_ncons.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_ocsp.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_pci.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_pcia.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_pcons.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_pku.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_pmaps.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_prn.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_purp.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_skey.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_sxnet.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3_utl.c
    host C: libcrypto <= external/openssl/crypto/x509v3/v3err.c
    host C: libcrypto <= external/openssl/crypto/aes/aes_core.c
    host C: libz <= external/zlib/adler32.c
    host C: libz <= external/zlib/compress.c
    host C: libz <= external/zlib/crc32.c
    host C: libz <= external/zlib/gzclose.c
    host C: libz <= external/zlib/gzlib.c
    host C: libz <= external/zlib/gzread.c
    host C: libz <= external/zlib/gzwrite.c
    host C: libz <= external/zlib/uncompr.c
    host C: libz <= external/zlib/deflate.c
    host C: libz <= external/zlib/trees.c
    host C: libz <= external/zlib/zutil.c
    host C: libz <= external/zlib/inflate.c
    host C: libz <= external/zlib/infback.c
    host C: libz <= external/zlib/inftrees.c
    host C: libz <= external/zlib/inffast.c
    host StaticLib: libz (out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/libz.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/adler32.o out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/compress.o out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/crc32.o out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/gzclose.o out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/gzlib.o out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/gzread.o out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/gzwrite.o out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/uncompr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/deflate.o out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/trees.o out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/zutil.o out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/inflate.o out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/infback.o out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/inftrees.o out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/inffast.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libz_intermediates/libz.a
    host SharedLib: libcrypto (out/host/linux-x86/obj/lib/libcrypto.so)
    host C: libssl <= external/openssl/ssl/s2_meth.c
    host C: libssl <= external/openssl/ssl/s2_srvr.c
    host C: libssl <= external/openssl/ssl/s2_clnt.c
    host C: libssl <= external/openssl/ssl/s2_lib.c
    host C: libssl <= external/openssl/ssl/s2_enc.c
    host C: libssl <= external/openssl/ssl/s2_pkt.c
    host C: libssl <= external/openssl/ssl/s3_meth.c
    host C: libssl <= external/openssl/ssl/s3_srvr.c
    host C: libssl <= external/openssl/ssl/s3_clnt.c
    host C: libssl <= external/openssl/ssl/s3_lib.c
    host C: libssl <= external/openssl/ssl/s3_enc.c
    host C: libssl <= external/openssl/ssl/s3_pkt.c
    host C: libssl <= external/openssl/ssl/s3_both.c
    host C: libssl <= external/openssl/ssl/s23_meth.c
    host C: libssl <= external/openssl/ssl/s23_srvr.c
    host C: libssl <= external/openssl/ssl/s23_clnt.c
    host C: libssl <= external/openssl/ssl/s23_lib.c
    host C: libssl <= external/openssl/ssl/s23_pkt.c
    host C: libssl <= external/openssl/ssl/t1_meth.c
    host C: libssl <= external/openssl/ssl/t1_srvr.c
    host C: libssl <= external/openssl/ssl/t1_clnt.c
    host C: libssl <= external/openssl/ssl/t1_lib.c
    host C: libssl <= external/openssl/ssl/t1_enc.c
    host C: libssl <= external/openssl/ssl/t1_reneg.c
    host C: libssl <= external/openssl/ssl/ssl_lib.c
    host C: libssl <= external/openssl/ssl/ssl_err2.c
    host C: libssl <= external/openssl/ssl/ssl_cert.c
    host C: libssl <= external/openssl/ssl/ssl_sess.c
    host C: libssl <= external/openssl/ssl/ssl_ciph.c
    host C: libssl <= external/openssl/ssl/ssl_stat.c
    host C: libssl <= external/openssl/ssl/ssl_rsa.c
    host C: libssl <= external/openssl/ssl/ssl_asn1.c
    host C: libssl <= external/openssl/ssl/ssl_txt.c
    host C: libssl <= external/openssl/ssl/ssl_algs.c
    host C: libssl <= external/openssl/ssl/bio_ssl.c
    host C: libssl <= external/openssl/ssl/ssl_err.c
    host C: libssl <= external/openssl/ssl/kssl.c
    host SharedLib: libssl (out/host/linux-x86/obj/lib/libssl.so)
    Copy: out/host/linux-x86/usr/icu/icudt44l.dat
    host C++: libicuuc <= external/icu4c/common/bmpset.cpp
    host C++: libicuuc <= external/icu4c/common/unisetspan.cpp
    host C++: libicuuc <= external/icu4c/common/brkeng.cpp
    host C++: libicuuc <= external/icu4c/common/brkiter.cpp
    host C++: libicuuc <= external/icu4c/common/caniter.cpp
    host C++: libicuuc <= external/icu4c/common/chariter.cpp
    host C++: libicuuc <= external/icu4c/common/dictbe.cpp
    host C++: libicuuc <= external/icu4c/common/locbased.cpp
    host C++: libicuuc <= external/icu4c/common/locid.cpp
    host C++: libicuuc <= external/icu4c/common/locutil.cpp
    host C++: libicuuc <= external/icu4c/common/normlzr.cpp
    host C++: libicuuc <= external/icu4c/common/parsepos.cpp
    host C++: libicuuc <= external/icu4c/common/propname.cpp
    host C++: libicuuc <= external/icu4c/common/rbbi.cpp
    host C++: libicuuc <= external/icu4c/common/rbbidata.cpp
    host C++: libicuuc <= external/icu4c/common/rbbinode.cpp
    host C++: libicuuc <= external/icu4c/common/rbbirb.cpp
    host C++: libicuuc <= external/icu4c/common/rbbiscan.cpp
    host C++: libicuuc <= external/icu4c/common/rbbisetb.cpp
    host C++: libicuuc <= external/icu4c/common/rbbistbl.cpp
    host C++: libicuuc <= external/icu4c/common/rbbitblb.cpp
    host C++: libicuuc <= external/icu4c/common/resbund_cnv.cpp
    host C++: libicuuc <= external/icu4c/common/resbund.cpp
    host C++: libicuuc <= external/icu4c/common/ruleiter.cpp
    host C++: libicuuc <= external/icu4c/common/schriter.cpp
    host C++: libicuuc <= external/icu4c/common/serv.cpp
    host C++: libicuuc <= external/icu4c/common/servlk.cpp
    host C++: libicuuc <= external/icu4c/common/servlkf.cpp
    host C++: libicuuc <= external/icu4c/common/servls.cpp
    host C++: libicuuc <= external/icu4c/common/servnotf.cpp
    host C++: libicuuc <= external/icu4c/common/servrbf.cpp
    host C++: libicuuc <= external/icu4c/common/servslkf.cpp
    host C++: libicuuc <= external/icu4c/common/triedict.cpp
    host C++: libicuuc <= external/icu4c/common/ubrk.cpp
    host C++: libicuuc <= external/icu4c/common/uchriter.cpp
    host C++: libicuuc <= external/icu4c/common/uhash_us.cpp
    host C++: libicuuc <= external/icu4c/common/uidna.cpp
    host C++: libicuuc <= external/icu4c/common/uiter.cpp
    host C++: libicuuc <= external/icu4c/common/unifilt.cpp
    host C++: libicuuc <= external/icu4c/common/unifunct.cpp
    host C++: libicuuc <= external/icu4c/common/uniset.cpp
    host C++: libicuuc <= external/icu4c/common/uniset_props.cpp
    host C++: libicuuc <= external/icu4c/common/unistr_case.cpp
    host C++: libicuuc <= external/icu4c/common/unistr_cnv.cpp
    host C++: libicuuc <= external/icu4c/common/unistr.cpp
    host C++: libicuuc <= external/icu4c/common/unistr_props.cpp
    host C++: libicuuc <= external/icu4c/common/unormcmp.cpp
    host C++: libicuuc <= external/icu4c/common/unorm.cpp
    host C++: libicuuc <= external/icu4c/common/uobject.cpp
    host C++: libicuuc <= external/icu4c/common/uset.cpp
    host C++: libicuuc <= external/icu4c/common/usetiter.cpp
    host C++: libicuuc <= external/icu4c/common/uset_props.cpp
    host C++: libicuuc <= external/icu4c/common/usprep.cpp
    host C++: libicuuc <= external/icu4c/common/ustack.cpp
    host C++: libicuuc <= external/icu4c/common/ustrenum.cpp
    host C++: libicuuc <= external/icu4c/common/utext.cpp
    host C++: libicuuc <= external/icu4c/common/util.cpp
    host C++: libicuuc <= external/icu4c/common/util_props.cpp
    host C++: libicuuc <= external/icu4c/common/uvector.cpp
    host C++: libicuuc <= external/icu4c/common/uvectr32.cpp
    host C++: libicuuc <= external/icu4c/common/errorcode.cpp
    host C++: libicuuc <= external/icu4c/common/bytestream.cpp
    host C++: libicuuc <= external/icu4c/common/stringpiece.cpp
    host C++: libicuuc <= external/icu4c/common/mutex.cpp
    host C++: libicuuc <= external/icu4c/common/dtintrv.cpp
    host C++: libicuuc <= external/icu4c/common/ucnvsel.cpp
    host C++: libicuuc <= external/icu4c/common/uvectr64.cpp
    host C++: libicuuc <= external/icu4c/common/locavailable.cpp
    host C++: libicuuc <= external/icu4c/common/locdispnames.cpp
    host C++: libicuuc <= external/icu4c/common/loclikely.cpp
    host C++: libicuuc <= external/icu4c/common/locresdata.cpp
    host C++: libicuuc <= external/icu4c/common/normalizer2impl.cpp
    host C++: libicuuc <= external/icu4c/common/normalizer2.cpp
    host C++: libicuuc <= external/icu4c/common/filterednormalizer2.cpp
    host C++: libicuuc <= external/icu4c/common/ucol_swp.cpp
    host C++: libicuuc <= external/icu4c/common/uprops.cpp
    host C++: libicuuc <= external/icu4c/common/utrie2.cpp
    host C: libicuuc <= external/icu4c/common/cmemory.c
    host C: libicuuc <= external/icu4c/common/cstring.c
    host C: libicuuc <= external/icu4c/common/cwchar.c
    host C: libicuuc <= external/icu4c/common/locmap.c
    host C: libicuuc <= external/icu4c/common/punycode.c
    host C: libicuuc <= external/icu4c/common/putil.c
    host C: libicuuc <= external/icu4c/common/uarrsort.c
    host C: libicuuc <= external/icu4c/common/ubidi.c
    host C: libicuuc <= external/icu4c/common/ubidiln.c
    host C: libicuuc <= external/icu4c/common/ubidi_props.c
    host C: libicuuc <= external/icu4c/common/ubidiwrt.c
    host C: libicuuc <= external/icu4c/common/ucase.c
    host C: libicuuc <= external/icu4c/common/ucasemap.c
    host C: libicuuc <= external/icu4c/common/ucat.c
    host C: libicuuc <= external/icu4c/common/uchar.c
    host C: libicuuc <= external/icu4c/common/ucln_cmn.c
    host C: libicuuc <= external/icu4c/common/ucmndata.c
    host C: libicuuc <= external/icu4c/common/ucnv2022.c
    host C: libicuuc <= external/icu4c/common/ucnv_bld.c
    host C: libicuuc <= external/icu4c/common/ucnvbocu.c
    host C: libicuuc <= external/icu4c/common/ucnv.c
    host C: libicuuc <= external/icu4c/common/ucnv_cb.c
    host C: libicuuc <= external/icu4c/common/ucnv_cnv.c
    host C: libicuuc <= external/icu4c/common/ucnvdisp.c
    host C: libicuuc <= external/icu4c/common/ucnv_err.c
    host C: libicuuc <= external/icu4c/common/ucnv_ext.c
    host C: libicuuc <= external/icu4c/common/ucnvhz.c
    host C: libicuuc <= external/icu4c/common/ucnv_io.c
    host C: libicuuc <= external/icu4c/common/ucnvisci.c
    host C: libicuuc <= external/icu4c/common/ucnvlat1.c
    host C: libicuuc <= external/icu4c/common/ucnv_lmb.c
    host C: libicuuc <= external/icu4c/common/ucnvmbcs.c
    host C: libicuuc <= external/icu4c/common/ucnvscsu.c
    host C: libicuuc <= external/icu4c/common/ucnv_set.c
    host C: libicuuc <= external/icu4c/common/ucnv_u16.c
    host C: libicuuc <= external/icu4c/common/ucnv_u32.c
    host C: libicuuc <= external/icu4c/common/ucnv_u7.c
    host C: libicuuc <= external/icu4c/common/ucnv_u8.c
    host C: libicuuc <= external/icu4c/common/udata.c
    host C: libicuuc <= external/icu4c/common/udatamem.c
    host C: libicuuc <= external/icu4c/common/udataswp.c
    host C: libicuuc <= external/icu4c/common/uenum.c
    host C: libicuuc <= external/icu4c/common/uhash.c
    host C: libicuuc <= external/icu4c/common/uinit.c
    host C: libicuuc <= external/icu4c/common/uinvchar.c
    host C: libicuuc <= external/icu4c/common/uloc.c
    host C: libicuuc <= external/icu4c/common/umapfile.c
    host C: libicuuc <= external/icu4c/common/umath.c
    host C: libicuuc <= external/icu4c/common/umutex.c
    host C: libicuuc <= external/icu4c/common/unames.c
    host C: libicuuc <= external/icu4c/common/unorm_it.c
    host C: libicuuc <= external/icu4c/common/uresbund.c
    host C: libicuuc <= external/icu4c/common/ures_cnv.c
    host C: libicuuc <= external/icu4c/common/uresdata.c
    host C: libicuuc <= external/icu4c/common/usc_impl.c
    host C: libicuuc <= external/icu4c/common/uscript.c
    host C: libicuuc <= external/icu4c/common/ushape.c
    host C: libicuuc <= external/icu4c/common/ustrcase.c
    host C: libicuuc <= external/icu4c/common/ustr_cnv.c
    host C: libicuuc <= external/icu4c/common/ustrfmt.c
    host C: libicuuc <= external/icu4c/common/ustring.c
    host C: libicuuc <= external/icu4c/common/ustrtrns.c
    host C: libicuuc <= external/icu4c/common/ustr_wcs.c
    host C: libicuuc <= external/icu4c/common/utf_impl.c
    host C: libicuuc <= external/icu4c/common/utrace.c
    host C: libicuuc <= external/icu4c/common/utrie.c
    host C: libicuuc <= external/icu4c/common/utypes.c
    host C: libicuuc <= external/icu4c/common/wintz.c
    host C: libicuuc <= external/icu4c/common/utrie2_builder.c
    host C: libicuuc <= external/icu4c/common/icuplug.c
    host C: libicuuc <= external/icu4c/common/propsvec.c
    host C: libicuuc <= external/icu4c/common/ulist.c
    host C: libicuuc <= external/icu4c/common/uloc_tag.c
    host C: libicuuc <= external/icu4c/common/../stubdata/stubdata.c
    host SharedLib: libicuuc (out/host/linux-x86/obj/lib/libicuuc.so)
    host C++: libicui18n <= external/icu4c/i18n/indiancal.cpp
    host C++: libicui18n <= external/icu4c/i18n/dtptngen.cpp
    host C++: libicui18n <= external/icu4c/i18n/dtrule.cpp
    host C++: libicui18n <= external/icu4c/i18n/persncal.cpp
    host C++: libicui18n <= external/icu4c/i18n/rbtz.cpp
    host C++: libicui18n <= external/icu4c/i18n/reldtfmt.cpp
    host C++: libicui18n <= external/icu4c/i18n/taiwncal.cpp
    host C++: libicui18n <= external/icu4c/i18n/tzrule.cpp
    host C++: libicui18n <= external/icu4c/i18n/tztrans.cpp
    host C++: libicui18n <= external/icu4c/i18n/udatpg.cpp
    host C++: libicui18n <= external/icu4c/i18n/vtzone.cpp
    host C++: libicui18n <= external/icu4c/i18n/anytrans.cpp
    host C++: libicui18n <= external/icu4c/i18n/astro.cpp
    host C++: libicui18n <= external/icu4c/i18n/buddhcal.cpp
    host C++: libicui18n <= external/icu4c/i18n/basictz.cpp
    host C++: libicui18n <= external/icu4c/i18n/calendar.cpp
    host C++: libicui18n <= external/icu4c/i18n/casetrn.cpp
    host C++: libicui18n <= external/icu4c/i18n/choicfmt.cpp
    host C++: libicui18n <= external/icu4c/i18n/coleitr.cpp
    host C++: libicui18n <= external/icu4c/i18n/coll.cpp
    host C++: libicui18n <= external/icu4c/i18n/cpdtrans.cpp
    host C++: libicui18n <= external/icu4c/i18n/csdetect.cpp
    host C++: libicui18n <= external/icu4c/i18n/csmatch.cpp
    host C++: libicui18n <= external/icu4c/i18n/csr2022.cpp
    host C++: libicui18n <= external/icu4c/i18n/csrecog.cpp
    host C++: libicui18n <= external/icu4c/i18n/csrmbcs.cpp
    host C++: libicui18n <= external/icu4c/i18n/csrsbcs.cpp
    host C++: libicui18n <= external/icu4c/i18n/csrucode.cpp
    host C++: libicui18n <= external/icu4c/i18n/csrutf8.cpp
    host C++: libicui18n <= external/icu4c/i18n/curramt.cpp
    host C++: libicui18n <= external/icu4c/i18n/currfmt.cpp
    host C++: libicui18n <= external/icu4c/i18n/currunit.cpp
    host C++: libicui18n <= external/icu4c/i18n/datefmt.cpp
    host C++: libicui18n <= external/icu4c/i18n/dcfmtsym.cpp
    host C++: libicui18n <= external/icu4c/i18n/decimfmt.cpp
    host C++: libicui18n <= external/icu4c/i18n/digitlst.cpp
    host C++: libicui18n <= external/icu4c/i18n/dtfmtsym.cpp
    host C++: libicui18n <= external/icu4c/i18n/esctrn.cpp
    host C++: libicui18n <= external/icu4c/i18n/fmtable_cnv.cpp
    host C++: libicui18n <= external/icu4c/i18n/fmtable.cpp
    host C++: libicui18n <= external/icu4c/i18n/format.cpp
    host C++: libicui18n <= external/icu4c/i18n/funcrepl.cpp
    host C++: libicui18n <= external/icu4c/i18n/gregocal.cpp
    host C++: libicui18n <= external/icu4c/i18n/gregoimp.cpp
    host C++: libicui18n <= external/icu4c/i18n/hebrwcal.cpp
    host C++: libicui18n <= external/icu4c/i18n/inputext.cpp
    host C++: libicui18n <= external/icu4c/i18n/islamcal.cpp
    host C++: libicui18n <= external/icu4c/i18n/japancal.cpp
    host C++: libicui18n <= external/icu4c/i18n/measfmt.cpp
    host C++: libicui18n <= external/icu4c/i18n/measure.cpp
    host C++: libicui18n <= external/icu4c/i18n/msgfmt.cpp
    host C++: libicui18n <= external/icu4c/i18n/name2uni.cpp
    host C++: libicui18n <= external/icu4c/i18n/nfrs.cpp
    host C++: libicui18n <= external/icu4c/i18n/nfrule.cpp
    host C++: libicui18n <= external/icu4c/i18n/nfsubs.cpp
    host C++: libicui18n <= external/icu4c/i18n/nortrans.cpp
    host C++: libicui18n <= external/icu4c/i18n/nultrans.cpp
    host C++: libicui18n <= external/icu4c/i18n/numfmt.cpp
    host C++: libicui18n <= external/icu4c/i18n/olsontz.cpp
    host C++: libicui18n <= external/icu4c/i18n/quant.cpp
    host C++: libicui18n <= external/icu4c/i18n/rbnf.cpp
    host C++: libicui18n <= external/icu4c/i18n/rbt.cpp
    host C++: libicui18n <= external/icu4c/i18n/rbt_data.cpp
    host C++: libicui18n <= external/icu4c/i18n/rbt_pars.cpp
    host C++: libicui18n <= external/icu4c/i18n/rbt_rule.cpp
    host C++: libicui18n <= external/icu4c/i18n/rbt_set.cpp
    host C++: libicui18n <= external/icu4c/i18n/regexcmp.cpp
    host C++: libicui18n <= external/icu4c/i18n/regexst.cpp
    host C++: libicui18n <= external/icu4c/i18n/rematch.cpp
    host C++: libicui18n <= external/icu4c/i18n/remtrans.cpp
    host C++: libicui18n <= external/icu4c/i18n/repattrn.cpp
    host C++: libicui18n <= external/icu4c/i18n/search.cpp
    host C++: libicui18n <= external/icu4c/i18n/simpletz.cpp
    host C++: libicui18n <= external/icu4c/i18n/smpdtfmt.cpp
    host C++: libicui18n <= external/icu4c/i18n/sortkey.cpp
    host C++: libicui18n <= external/icu4c/i18n/strmatch.cpp
    host C++: libicui18n <= external/icu4c/i18n/strrepl.cpp
    host C++: libicui18n <= external/icu4c/i18n/stsearch.cpp
    host C++: libicui18n <= external/icu4c/i18n/tblcoll.cpp
    host C++: libicui18n <= external/icu4c/i18n/timezone.cpp
    host C++: libicui18n <= external/icu4c/i18n/titletrn.cpp
    host C++: libicui18n <= external/icu4c/i18n/tolowtrn.cpp
    host C++: libicui18n <= external/icu4c/i18n/toupptrn.cpp
    host C++: libicui18n <= external/icu4c/i18n/translit.cpp
    host C++: libicui18n <= external/icu4c/i18n/transreg.cpp
    host C++: libicui18n <= external/icu4c/i18n/tridpars.cpp
    host C++: libicui18n <= external/icu4c/i18n/ucal.cpp
    host C++: libicui18n <= external/icu4c/i18n/ucol_bld.cpp
    host C++: libicui18n <= external/icu4c/i18n/ucol_cnt.cpp
    host C++: libicui18n <= external/icu4c/i18n/ucol.cpp
    host C++: libicui18n <= external/icu4c/i18n/ucoleitr.cpp
    host C++: libicui18n <= external/icu4c/i18n/ucol_elm.cpp
    host C++: libicui18n <= external/icu4c/i18n/ucol_res.cpp
    host C++: libicui18n <= external/icu4c/i18n/ucol_sit.cpp
    host C++: libicui18n <= external/icu4c/i18n/ucol_tok.cpp
    host C++: libicui18n <= external/icu4c/i18n/ucsdet.cpp
    host C++: libicui18n <= external/icu4c/i18n/ucurr.cpp
    host C++: libicui18n <= external/icu4c/i18n/udat.cpp
    host C++: libicui18n <= external/icu4c/i18n/umsg.cpp
    host C++: libicui18n <= external/icu4c/i18n/unesctrn.cpp
    host C++: libicui18n <= external/icu4c/i18n/uni2name.cpp
    host C++: libicui18n <= external/icu4c/i18n/unum.cpp
    host C++: libicui18n <= external/icu4c/i18n/uregexc.cpp
    host C++: libicui18n <= external/icu4c/i18n/uregex.cpp
    host C++: libicui18n <= external/icu4c/i18n/usearch.cpp
    host C++: libicui18n <= external/icu4c/i18n/utrans.cpp
    host C++: libicui18n <= external/icu4c/i18n/windtfmt.cpp
    host C++: libicui18n <= external/icu4c/i18n/winnmfmt.cpp
    host C++: libicui18n <= external/icu4c/i18n/zonemeta.cpp
    host C++: libicui18n <= external/icu4c/i18n/zstrfmt.cpp
    host C++: libicui18n <= external/icu4c/i18n/numsys.cpp
    host C++: libicui18n <= external/icu4c/i18n/chnsecal.cpp
    host C++: libicui18n <= external/icu4c/i18n/cecal.cpp
    host C++: libicui18n <= external/icu4c/i18n/coptccal.cpp
    host C++: libicui18n <= external/icu4c/i18n/ethpccal.cpp
    host C++: libicui18n <= external/icu4c/i18n/brktrans.cpp
    host C++: libicui18n <= external/icu4c/i18n/wintzimpl.cpp
    host C++: libicui18n <= external/icu4c/i18n/plurrule.cpp
    host C++: libicui18n <= external/icu4c/i18n/plurfmt.cpp
    host C++: libicui18n <= external/icu4c/i18n/dtitvfmt.cpp
    host C++: libicui18n <= external/icu4c/i18n/dtitvinf.cpp
    host C++: libicui18n <= external/icu4c/i18n/tmunit.cpp
    host C++: libicui18n <= external/icu4c/i18n/tmutamt.cpp
    host C++: libicui18n <= external/icu4c/i18n/tmutfmt.cpp
    host C++: libicui18n <= external/icu4c/i18n/colldata.cpp
    host C++: libicui18n <= external/icu4c/i18n/bmsearch.cpp
    host C++: libicui18n <= external/icu4c/i18n/bms.cpp
    host C++: libicui18n <= external/icu4c/i18n/currpinf.cpp
    host C++: libicui18n <= external/icu4c/i18n/uspoof.cpp
    host C++: libicui18n <= external/icu4c/i18n/uspoof_impl.cpp
    host C++: libicui18n <= external/icu4c/i18n/uspoof_build.cpp
    host C++: libicui18n <= external/icu4c/i18n/regextxt.cpp
    host C++: libicui18n <= external/icu4c/i18n/selfmt.cpp
    host C++: libicui18n <= external/icu4c/i18n/uspoof_conf.cpp
    host C++: libicui18n <= external/icu4c/i18n/uspoof_wsconf.cpp
    host C++: libicui18n <= external/icu4c/i18n/ztrans.cpp
    host C++: libicui18n <= external/icu4c/i18n/zrule.cpp
    host C++: libicui18n <= external/icu4c/i18n/vzone.cpp
    host C++: libicui18n <= external/icu4c/i18n/fphdlimp.cpp
    host C++: libicui18n <= external/icu4c/i18n/fpositer.cpp
    host C++: libicui18n <= external/icu4c/i18n/locdspnm.cpp
    host C++: libicui18n <= external/icu4c/i18n/decnumstr.cpp
    host C++: libicui18n <= external/icu4c/i18n/ucol_wgt.cpp
    host C: libicui18n <= external/icu4c/i18n/bocsu.c
    host C: libicui18n <= external/icu4c/i18n/ucln_in.c
    host C: libicui18n <= external/icu4c/i18n/decContext.c
    host C: libicui18n <= external/icu4c/i18n/ulocdata.c
    host C: libicui18n <= external/icu4c/i18n/utmscale.c
    host C: libicui18n <= external/icu4c/i18n/decNumber.c
    host SharedLib: libicui18n (out/host/linux-x86/obj/lib/libicui18n.so)
    host C: libdex <= dalvik/libdex/CmdUtils.c
    host C: libdex <= dalvik/libdex/DexCatch.c
    host C: libdex <= dalvik/libdex/DexClass.c
    host C: libdex <= dalvik/libdex/DexDataMap.c
    host C: libdex <= dalvik/libdex/DexFile.c
    host C: libdex <= dalvik/libdex/DexInlines.c
    host C: libdex <= dalvik/libdex/DexOptData.c
    host C: libdex <= dalvik/libdex/DexProto.c
    host C: libdex <= dalvik/libdex/DexSwapVerify.c
    host C: libdex <= dalvik/libdex/InstrUtils.c
    host C: libdex <= dalvik/libdex/Leb128.c
    host C: libdex <= dalvik/libdex/OpCodeNames.c
    host C: libdex <= dalvik/libdex/OptInvocation.c
    host C: libdex <= dalvik/libdex/sha1.c
    host C: libdex <= dalvik/libdex/SysUtil.c
    host C: libdex <= dalvik/libdex/ZipArchive.c
    host StaticLib: libdex (out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/libdex.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/CmdUtils.o out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/DexCatch.o out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/DexClass.o out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/DexDataMap.o out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/DexFile.o out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/DexInlines.o out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/DexOptData.o out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/DexProto.o out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/DexSwapVerify.o out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/InstrUtils.o out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/Leb128.o out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/OpCodeNames.o out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/OptInvocation.o out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/sha1.o out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/SysUtil.o out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/ZipArchive.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libdex_intermediates/libdex.a
    host C: libnativehelper <= dalvik/libnativehelper/JNIHelp.c
    host C: libnativehelper <= dalvik/libnativehelper/Register.c
    Copy: out/host/linux-x86/etc/security/cacerts.bks
    host C++: libjavacore-host <= libcore/dalvik/src/main/native/dalvik_system_TouchDex.cpp
    host C++: libjavacore-host <= libcore/dalvik/src/main/native/org_apache_harmony_dalvik_NativeTestTarget.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/AsynchronousSocketCloseMonitor.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/ErrorCode.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/ICU.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/JniConstants.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/JniException.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/NativeBN.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/NativeBidi.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/NativeBreakIterator.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/NativeCollation.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/NativeConverter.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/NativeCrypto.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/NativeDecimalFormat.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/NativeIDN.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/NativeNormalizer.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/NativePluralRules.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/NetworkUtilities.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/Register.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/TimeZones.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/cbigint.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_io_Console.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_io_File.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_io_FileDescriptor.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_io_ObjectInputStream.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_io_ObjectOutputStream.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_io_ObjectStreamClass.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_lang_Character.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_lang_Double.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_lang_Float.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_lang_Math.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_lang_ProcessManager.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_lang_RealToString.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_lang_StrictMath.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_lang_System.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_net_InetAddress.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_net_NetworkInterface.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_nio_ByteOrder.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_nio_charset_Charsets.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_util_regex_Matcher.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_util_regex_Pattern.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_util_zip_Adler32.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_util_zip_CRC32.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_util_zip_Deflater.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/java_util_zip_Inflater.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/libcore_io_IoUtils.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/org_apache_harmony_luni_platform_OSFileSystem.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/org_apache_harmony_luni_platform_OSMemory.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/org_apache_harmony_luni_platform_OSNetworkSystem.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/org_apache_harmony_luni_util_FloatingPointParser.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/org_apache_harmony_xml_ExpatParser.cpp
    host C++: libjavacore-host <= libcore/luni/src/main/native/valueOf.cpp
    host StaticLib: libjavacore-host (out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/libjavacore-host.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/dalvik/src/main/native/dalvik_system_TouchDex.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/dalvik/src/main/native/org_apache_harmony_dalvik_NativeTestTarget.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/AsynchronousSocketCloseMonitor.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/ErrorCode.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/ICU.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/JniConstants.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/JniException.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/NativeBN.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/NativeBidi.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/NativeBreakIterator.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/NativeCollation.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/NativeConverter.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/NativeCrypto.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/NativeDecimalFormat.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/NativeIDN.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/NativeNormalizer.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/NativePluralRules.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/NetworkUtilities.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/Register.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/TimeZones.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/cbigint.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_io_Console.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_io_File.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_io_FileDescriptor.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_io_ObjectInputStream.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_io_ObjectOutputStream.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_io_ObjectStreamClass.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_lang_Character.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_lang_Double.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_lang_Float.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_lang_Math.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_lang_ProcessManager.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_lang_RealToString.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_lang_StrictMath.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_lang_System.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_net_InetAddress.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_net_NetworkInterface.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_nio_ByteOrder.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_nio_charset_Charsets.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_util_regex_Matcher.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_util_regex_Pattern.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_util_zip_Adler32.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_util_zip_CRC32.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_util_zip_Deflater.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/java_util_zip_Inflater.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/libcore_io_IoUtils.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/org_apache_harmony_luni_platform_OSFileSystem.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/org_apache_harmony_luni_platform_OSMemory.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/org_apache_harmony_luni_platform_OSNetworkSystem.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/org_apache_harmony_luni_util_FloatingPointParser.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/org_apache_harmony_xml_ExpatParser.o out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/luni/src/main/native/valueOf.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/libjavacore-host.a
    host C: libfdlibm-host <= external/fdlibm/k_standard.c
    host C: libfdlibm-host <= external/fdlibm/k_rem_pio2.c
    host C: libfdlibm-host <= external/fdlibm/k_cos.c
    host C: libfdlibm-host <= external/fdlibm/k_sin.c
    host C: libfdlibm-host <= external/fdlibm/k_tan.c
    host C: libfdlibm-host <= external/fdlibm/e_acos.c
    host C: libfdlibm-host <= external/fdlibm/e_acosh.c
    host C: libfdlibm-host <= external/fdlibm/e_asin.c
    host C: libfdlibm-host <= external/fdlibm/e_atan2.c
    host C: libfdlibm-host <= external/fdlibm/e_atanh.c
    host C: libfdlibm-host <= external/fdlibm/e_cosh.c
    host C: libfdlibm-host <= external/fdlibm/e_exp.c
    host C: libfdlibm-host <= external/fdlibm/e_fmod.c
    host C: libfdlibm-host <= external/fdlibm/e_gamma.c
    host C: libfdlibm-host <= external/fdlibm/e_gamma_r.c
    host C: libfdlibm-host <= external/fdlibm/e_hypot.c
    host C: libfdlibm-host <= external/fdlibm/e_j0.c
    host C: libfdlibm-host <= external/fdlibm/e_j1.c
    host C: libfdlibm-host <= external/fdlibm/e_jn.c
    host C: libfdlibm-host <= external/fdlibm/e_lgamma.c
    host C: libfdlibm-host <= external/fdlibm/e_lgamma_r.c
    host C: libfdlibm-host <= external/fdlibm/e_log.c
    host C: libfdlibm-host <= external/fdlibm/e_log10.c
    host C: libfdlibm-host <= external/fdlibm/e_pow.c
    host C: libfdlibm-host <= external/fdlibm/e_rem_pio2.c
    host C: libfdlibm-host <= external/fdlibm/e_remainder.c
    host C: libfdlibm-host <= external/fdlibm/e_scalb.c
    host C: libfdlibm-host <= external/fdlibm/e_sinh.c
    host C: libfdlibm-host <= external/fdlibm/e_sqrt.c
    host C: libfdlibm-host <= external/fdlibm/w_acos.c
    host C: libfdlibm-host <= external/fdlibm/w_acosh.c
    host C: libfdlibm-host <= external/fdlibm/w_asin.c
    host C: libfdlibm-host <= external/fdlibm/w_atan2.c
    host C: libfdlibm-host <= external/fdlibm/w_atanh.c
    host C: libfdlibm-host <= external/fdlibm/w_cosh.c
    host C: libfdlibm-host <= external/fdlibm/w_exp.c
    host C: libfdlibm-host <= external/fdlibm/w_fmod.c
    host C: libfdlibm-host <= external/fdlibm/w_gamma.c
    host C: libfdlibm-host <= external/fdlibm/w_gamma_r.c
    host C: libfdlibm-host <= external/fdlibm/w_hypot.c
    host C: libfdlibm-host <= external/fdlibm/w_j0.c
    host C: libfdlibm-host <= external/fdlibm/w_j1.c
    host C: libfdlibm-host <= external/fdlibm/w_jn.c
    host C: libfdlibm-host <= external/fdlibm/w_lgamma.c
    host C: libfdlibm-host <= external/fdlibm/w_lgamma_r.c
    host C: libfdlibm-host <= external/fdlibm/w_log.c
    host C: libfdlibm-host <= external/fdlibm/w_log10.c
    host C: libfdlibm-host <= external/fdlibm/w_pow.c
    host C: libfdlibm-host <= external/fdlibm/w_remainder.c
    host C: libfdlibm-host <= external/fdlibm/w_scalb.c
    host C: libfdlibm-host <= external/fdlibm/w_sinh.c
    host C: libfdlibm-host <= external/fdlibm/w_sqrt.c
    host C: libfdlibm-host <= external/fdlibm/s_asinh.c
    host C: libfdlibm-host <= external/fdlibm/s_atan.c
    host C: libfdlibm-host <= external/fdlibm/s_cbrt.c
    host C: libfdlibm-host <= external/fdlibm/s_ceil.c
    host C: libfdlibm-host <= external/fdlibm/s_copysign.c
    host C: libfdlibm-host <= external/fdlibm/s_cos.c
    host C: libfdlibm-host <= external/fdlibm/s_erf.c
    host C: libfdlibm-host <= external/fdlibm/s_expm1.c
    host C: libfdlibm-host <= external/fdlibm/s_fabs.c
    host C: libfdlibm-host <= external/fdlibm/s_finite.c
    host C: libfdlibm-host <= external/fdlibm/s_floor.c
    host C: libfdlibm-host <= external/fdlibm/s_frexp.c
    host C: libfdlibm-host <= external/fdlibm/s_ilogb.c
    host C: libfdlibm-host <= external/fdlibm/s_isnan.c
    host C: libfdlibm-host <= external/fdlibm/s_ldexp.c
    host C: libfdlibm-host <= external/fdlibm/s_lib_version.c
    host C: libfdlibm-host <= external/fdlibm/s_log1p.c
    host C: libfdlibm-host <= external/fdlibm/s_logb.c
    host C: libfdlibm-host <= external/fdlibm/s_matherr.c
    host C: libfdlibm-host <= external/fdlibm/s_modf.c
    host C: libfdlibm-host <= external/fdlibm/s_nextafter.c
    host C: libfdlibm-host <= external/fdlibm/s_rint.c
    host C: libfdlibm-host <= external/fdlibm/s_scalbn.c
    host C: libfdlibm-host <= external/fdlibm/s_signgam.c
    host C: libfdlibm-host <= external/fdlibm/s_significand.c
    host C: libfdlibm-host <= external/fdlibm/s_sin.c
    host C: libfdlibm-host <= external/fdlibm/s_tan.c
    host C: libfdlibm-host <= external/fdlibm/s_tanh.c
    host StaticLib: libfdlibm-host (out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/libfdlibm-host.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/k_standard.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/k_rem_pio2.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/k_cos.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/k_sin.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/k_tan.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_acos.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_acosh.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_asin.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_atan2.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_atanh.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_cosh.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_exp.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_fmod.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_gamma.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_gamma_r.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_hypot.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_j0.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_j1.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_jn.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_lgamma.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_lgamma_r.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_log.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_log10.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_pow.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_rem_pio2.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_remainder.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_scalb.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_sinh.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/e_sqrt.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_acos.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_acosh.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_asin.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_atan2.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_atanh.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_cosh.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_exp.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_fmod.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_gamma.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_gamma_r.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_hypot.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_j0.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_j1.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_jn.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_lgamma.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_lgamma_r.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_log.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_log10.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_pow.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_remainder.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_scalb.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_sinh.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/w_sqrt.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_asinh.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_atan.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_cbrt.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_ceil.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_copysign.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_cos.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_erf.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_expm1.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_fabs.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_finite.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_floor.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_frexp.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_ilogb.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_isnan.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_ldexp.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_lib_version.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_log1p.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_logb.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_matherr.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_modf.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_nextafter.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_rint.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_scalbn.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_signgam.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_significand.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_sin.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_tan.o out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/s_tanh.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libfdlibm-host_intermediates/libfdlibm-host.a
    preparing StaticLib: libnativehelper [including out/host/linux-x86/obj/STATIC_LIBRARIES/libjavacore-host_intermediates/libjavacore-host.a]
    host StaticLib: libnativehelper (out/host/linux-x86/obj/STATIC_LIBRARIES/libnativehelper_intermediates/libnativehelper.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libnativehelper_intermediates/JNIHelp.o out/host/linux-x86/obj/STATIC_LIBRARIES/libnativehelper_intermediates/Register.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libnativehelper_intermediates/libnativehelper.a
    host SharedLib: libdvm (out/host/linux-x86/obj/lib/libdvm.so)
    host Executable: dalvikvm (out/host/linux-x86/obj/EXECUTABLES/dalvikvm_intermediates/dalvikvm)
    true
    Notice file: external/zlib/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/libz.a.txt
    Install: out/host/linux-x86/lib/libcrypto.so
    Install: out/host/linux-x86/lib/libssl.so
    Install: out/host/linux-x86/lib/libicuuc.so
    Install: out/host/linux-x86/lib/libicui18n.so
    Notice file: dalvik/libnativehelper/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/libnativehelper.a.txt
    Install: out/host/linux-x86/lib/libdvm.so
    Install: out/host/linux-x86/bin/dalvikvm
    host Java: dasm (out/host/common/obj/JAVA_LIBRARIES/dasm_intermediates/classes)
    Install: out/host/linux-x86/framework/dasm.jar
    Copy: dasm (out/host/linux-x86/obj/EXECUTABLES/dasm_intermediates/dasm)
    Install: out/host/linux-x86/bin/dasm
    host Prebuilt: ddms (out/host/linux-x86/obj/EXECUTABLES/ddms_intermediates/ddms)
    Install: out/host/linux-x86/bin/ddms
    host Java: dexdeps (out/host/common/obj/JAVA_LIBRARIES/dexdeps_intermediates/classes)
    Install: out/host/linux-x86/framework/dexdeps.jar
    Copy: dexdeps (out/host/linux-x86/obj/EXECUTABLES/dexdeps_intermediates/dexdeps)
    Install: out/host/linux-x86/bin/dexdeps
    host C: dexdump <= dalvik/dexdump/DexDump.c
    host Executable: dexdump (out/host/linux-x86/obj/EXECUTABLES/dexdump_intermediates/dexdump)
    true
    Install: out/host/linux-x86/bin/dexdump
    host C: dexlist <= dalvik/dexlist/DexList.c
    host Executable: dexlist (out/host/linux-x86/obj/EXECUTABLES/dexlist_intermediates/dexlist)
    true
    Install: out/host/linux-x86/bin/dexlist
    host C: dexopt <= dalvik/dexopt/OptMain.c
    host Executable: dexopt (out/host/linux-x86/obj/EXECUTABLES/dexopt_intermediates/dexopt)
    true
    Install: out/host/linux-x86/bin/dexopt
    host C: dictTest <= external/srec/tools/dictTest/dictTest.c
    host Executable: dictTest (out/host/linux-x86/obj/EXECUTABLES/dictTest_intermediates/dictTest)
    true
    Install: out/host/linux-x86/bin/dictTest
    host C: dmtracedump <= dalvik/tools/dmtracedump/TraceDump.c
    host Executable: dmtracedump (out/host/linux-x86/obj/EXECUTABLES/dmtracedump_intermediates/dmtracedump)
    true
    Install: out/host/linux-x86/bin/dmtracedump
    host Prebuilt: draw9patch (out/host/linux-x86/obj/EXECUTABLES/draw9patch_intermediates/draw9patch)
    Install: out/host/linux-x86/bin/draw9patch
    host C++: dump_regions <= sdk/emulator/qtools/dump_regions.cpp
    host C++: dump_regions <= sdk/emulator/qtools/trace_reader.cpp
    host C++: dump_regions <= sdk/emulator/qtools/decoder.cpp
    host C++: dump_regions <= sdk/emulator/qtools/read_elf.cpp
    host C++: dump_regions <= sdk/emulator/qtools/parse_options.cpp
    host Executable: dump_regions (out/host/linux-x86/obj/EXECUTABLES/dump_regions_intermediates/dump_regions)
    true
    Install: out/host/linux-x86/bin/dump_regions
    host Prebuilt: dumpeventlog (out/host/linux-x86/obj/EXECUTABLES/dumpeventlog_intermediates/dumpeventlog)
    Install: out/host/linux-x86/bin/dumpeventlog
    prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-gcc -mthumb-interwork -Ibionic/libc/private -o out/target/product/omap3evm/obj/lib/crtbegin_dynamic.o -c bionic/libc/arch-arm/bionic/crtbegin_dynamic.S
    target thumb C: dalvikvm <= dalvik/dalvikvm/Main.c
    target asm: libdvm <= dalvik/vm/arch/arm/CallOldABI.S
    target asm: libdvm <= dalvik/vm/arch/arm/CallEABI.S
    target asm: libdvm <= dalvik/vm/mterp/out/InterpAsm-armv7-a-neon.S
    target asm: libdvm <= dalvik/vm/compiler/codegen/arm/armv7-a-neon/CallingConvention.S
    target asm: libdvm <= dalvik/vm/compiler/template/out/CompilerTemplateAsm-armv7-a-neon.S
    target arm C: libdvm <= dalvik/vm/Atomic.c
    target arm C: libdvm <= dalvik/vm/IndirectRefTable.c
    target arm C: libdvm <= dalvik/vm/InlineNative.c
    target arm C: libdvm <= dalvik/vm/Misc.c
    target arm C: libdvm <= dalvik/vm/alloc/clz.c
    target arm C: libdvm <= dalvik/vm/alloc/HeapBitmap.c
    target arm C: libdvm <= dalvik/vm/alloc/Heap.c
    target arm C: libdvm <= dalvik/vm/interp/Interp.c
    target arm C: libdvm <= dalvik/vm/mterp/Mterp.c
    target arm C: libdvm <= dalvik/vm/mterp/out/InterpC-portstd.c
    target arm C: libdvm <= dalvik/vm/mterp/out/InterpC-portdbg.c
    target arm C: libdvm <= dalvik/vm/test/AtomicTest.c
    target arm C: libdvm <= dalvik/vm/alloc/MarkSweep.c
    target arm C: libdvm <= dalvik/vm/mterp/out/InterpC-armv7-a-neon.c
    target thumb C: libdvm <= dalvik/vm/AllocTracker.c
    target thumb C: libdvm <= dalvik/vm/AtomicCache.c
    target thumb C: libdvm <= dalvik/vm/CheckJni.c
    target thumb C: libdvm <= dalvik/vm/Ddm.c
    target thumb C: libdvm <= dalvik/vm/Debugger.c
    target thumb C: libdvm <= dalvik/vm/DvmDex.c
    target thumb C: libdvm <= dalvik/vm/Exception.c
    target thumb C: libdvm <= dalvik/vm/Hash.c
    target thumb C: libdvm <= dalvik/vm/Init.c
    target thumb C: libdvm <= dalvik/vm/Inlines.c
    target thumb C: libdvm <= dalvik/vm/Intern.c
    target thumb C: libdvm <= dalvik/vm/Jni.c
    target thumb C: libdvm <= dalvik/vm/JarFile.c
    target thumb C: libdvm <= dalvik/vm/LinearAlloc.c
    target thumb C: libdvm <= dalvik/vm/Native.c
    target thumb C: libdvm <= dalvik/vm/PointerSet.c
    target thumb C: libdvm <= dalvik/vm/Profile.c
    target thumb C: libdvm <= dalvik/vm/Properties.c
    target thumb C: libdvm <= dalvik/vm/RawDexFile.c
    target thumb C: libdvm <= dalvik/vm/ReferenceTable.c
    target thumb C: libdvm <= dalvik/vm/SignalCatcher.c
    target thumb C: libdvm <= dalvik/vm/StdioConverter.c
    target thumb C: libdvm <= dalvik/vm/Sync.c
    target thumb C: libdvm <= dalvik/vm/TestCompability.c
    target thumb C: libdvm <= dalvik/vm/Thread.c
    target thumb C: libdvm <= dalvik/vm/UtfString.c
    target thumb C: libdvm <= dalvik/vm/alloc/Alloc.c
    target thumb C: libdvm <= dalvik/vm/alloc/CardTable.c
    target thumb C: libdvm <= dalvik/vm/alloc/HeapDebug.c
    target thumb C: libdvm <= dalvik/vm/alloc/HeapTable.c
    target thumb C: libdvm <= dalvik/vm/alloc/HeapWorker.c
    target thumb C: libdvm <= dalvik/vm/alloc/DdmHeap.c
    target thumb C: libdvm <= dalvik/vm/alloc/Verify.c
    target thumb C: libdvm <= dalvik/vm/alloc/Visit.c
    target thumb C: libdvm <= dalvik/vm/analysis/CodeVerify.c
    target thumb C: libdvm <= dalvik/vm/analysis/DexPrepare.c
    target thumb C: libdvm <= dalvik/vm/analysis/DexVerify.c
    target thumb C: libdvm <= dalvik/vm/analysis/Optimize.c
    target thumb C: libdvm <= dalvik/vm/analysis/RegisterMap.c
    target thumb C: libdvm <= dalvik/vm/analysis/VerifySubs.c
    target thumb C: libdvm <= dalvik/vm/interp/Stack.c
    target thumb C: libdvm <= dalvik/vm/jdwp/ExpandBuf.c
    target thumb C: libdvm <= dalvik/vm/jdwp/JdwpAdb.c
    target thumb C: libdvm <= dalvik/vm/jdwp/JdwpConstants.c
    target thumb C: libdvm <= dalvik/vm/jdwp/JdwpEvent.c
    target thumb C: libdvm <= dalvik/vm/jdwp/JdwpHandler.c
    target thumb C: libdvm <= dalvik/vm/jdwp/JdwpMain.c
    target thumb C: libdvm <= dalvik/vm/jdwp/JdwpSocket.c
    target thumb C: libdvm <= dalvik/vm/native/InternalNative.c
    target thumb C: libdvm <= dalvik/vm/native/dalvik_system_DexFile.c
    target thumb C: libdvm <= dalvik/vm/native/dalvik_system_VMDebug.c
    target thumb C: libdvm <= dalvik/vm/native/dalvik_system_VMRuntime.c
    target thumb C: libdvm <= dalvik/vm/native/dalvik_system_VMStack.c
    target thumb C: libdvm <= dalvik/vm/native/dalvik_system_Zygote.c
    target thumb C: libdvm <= dalvik/vm/native/java_lang_Class.c
    target thumb C: libdvm <= dalvik/vm/native/java_lang_Object.c
    target thumb C: libdvm <= dalvik/vm/native/java_lang_Runtime.c
    target thumb C: libdvm <= dalvik/vm/native/java_lang_String.c
    target thumb C: libdvm <= dalvik/vm/native/java_lang_System.c
    target thumb C: libdvm <= dalvik/vm/native/java_lang_SystemProperties.c
    target thumb C: libdvm <= dalvik/vm/native/java_lang_Throwable.c
    target thumb C: libdvm <= dalvik/vm/native/java_lang_VMClassLoader.c
    target thumb C: libdvm <= dalvik/vm/native/java_lang_VMThread.c
    target thumb C: libdvm <= dalvik/vm/native/java_lang_reflect_AccessibleObject.c
    target thumb C: libdvm <= dalvik/vm/native/java_lang_reflect_Array.c
    target thumb C: libdvm <= dalvik/vm/native/java_lang_reflect_Constructor.c
    target thumb C: libdvm <= dalvik/vm/native/java_lang_reflect_Field.c
    target thumb C: libdvm <= dalvik/vm/native/java_lang_reflect_Method.c
    target thumb C: libdvm <= dalvik/vm/native/java_lang_reflect_Proxy.c
    target thumb C: libdvm <= dalvik/vm/native/java_security_AccessController.c
    target thumb C: libdvm <= dalvik/vm/native/java_util_concurrent_atomic_AtomicLong.c
    target thumb C: libdvm <= dalvik/vm/native/org_apache_harmony_dalvik_NativeTestTarget.c
    target thumb C: libdvm <= dalvik/vm/native/org_apache_harmony_dalvik_ddmc_DdmServer.c
    target thumb C: libdvm <= dalvik/vm/native/org_apache_harmony_dalvik_ddmc_DdmVmInternal.c
    target thumb C: libdvm <= dalvik/vm/native/sun_misc_Unsafe.c
    target thumb C: libdvm <= dalvik/vm/oo/AccessCheck.c
    target thumb C: libdvm <= dalvik/vm/oo/Array.c
    target thumb C: libdvm <= dalvik/vm/oo/Class.c
    target thumb C: libdvm <= dalvik/vm/oo/Object.c
    target thumb C: libdvm <= dalvik/vm/oo/Resolve.c
    target thumb C: libdvm <= dalvik/vm/oo/TypeCheck.c
    target thumb C: libdvm <= dalvik/vm/reflect/Annotation.c
    target thumb C: libdvm <= dalvik/vm/reflect/Proxy.c
    target thumb C: libdvm <= dalvik/vm/reflect/Reflect.c
    target thumb C: libdvm <= dalvik/vm/test/TestHash.c
    target thumb C: libdvm <= dalvik/vm/test/TestIndirectRefTable.c
    target thumb C: libdvm <= dalvik/vm/alloc/HeapSource.c
    target thumb C: libdvm <= dalvik/vm/compiler/Compiler.c
    target thumb C: libdvm <= dalvik/vm/compiler/Frontend.c
    target thumb C: libdvm <= dalvik/vm/compiler/Utility.c
    target thumb C: libdvm <= dalvik/vm/compiler/InlineTransformation.c
    target thumb C: libdvm <= dalvik/vm/compiler/IntermediateRep.c
    target thumb C: libdvm <= dalvik/vm/compiler/Dataflow.c
    target thumb C: libdvm <= dalvik/vm/compiler/Loop.c
    target thumb C: libdvm <= dalvik/vm/compiler/Ralloc.c
    target thumb C: libdvm <= dalvik/vm/interp/Jit.c
    target thumb C: libdvm <= dalvik/vm/hprof/Hprof.c
    target thumb C: libdvm <= dalvik/vm/hprof/HprofClass.c
    target thumb C: libdvm <= dalvik/vm/hprof/HprofHeap.c
    target thumb C: libdvm <= dalvik/vm/hprof/HprofOutput.c
    target thumb C: libdvm <= dalvik/vm/hprof/HprofString.c
    target thumb C: libdvm <= dalvik/vm/arch/arm/HintsEABI.c
    target thumb C: libdvm <= dalvik/vm/compiler/codegen/arm/RallocUtil.c
    target thumb C: libdvm <= dalvik/vm/compiler/codegen/arm/armv7-a-neon/Codegen.c
    target thumb C: libdvm <= dalvik/vm/compiler/codegen/arm/Assemble.c
    target thumb C: libdvm <= dalvik/vm/compiler/codegen/arm/ArchUtility.c
    target thumb C: libdvm <= dalvik/vm/compiler/codegen/arm/LocalOptimizations.c
    target thumb C: libdvm <= dalvik/vm/compiler/codegen/arm/GlobalOptimizations.c
    target arm C: libc <= bionic/libc/bionic/pthread.c
    target thumb C: libc <= bionic/libc/arch-arm/bionic/exidx_dynamic.c
    target thumb C: libc <= bionic/libc/unistd/sysconf.c
    target thumb C: libc <= bionic/libc/bionic/__errno.c
    target thumb C: libc <= bionic/libc/bionic/dlmalloc.c
    target thumb C: libc <= bionic/libc/bionic/malloc_debug_common.c
    target thumb C: libc <= bionic/libc/bionic/libc_init_dynamic.c
    target thumb C: libdl <= bionic/libdl/libdl.c
    prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-gcc -mthumb-interwork -Ibionic/libc/private -o out/target/product/omap3evm/obj/lib/crtbegin_so.o -c bionic/libc/arch-arm/bionic/crtbegin_so.S
    prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-gcc -mthumb-interwork -Ibionic/libc/private -o out/target/product/omap3evm/obj/lib/crtend_so.o -c bionic/libc/arch-arm/bionic/crtend_so.S
    target SharedLib: libdl (out/target/product/omap3evm/obj/SHARED_LIBRARIES/libdl_intermediates/LINKED/libdl.so)
    target Prelink: libdl (out/target/product/omap3evm/symbols/system/lib/libdl.so)
    host C: soslim <= build/tools/soslim/cmdline.c
    host C: soslim <= build/tools/soslim/common.c
    host C: soslim <= build/tools/soslim/debug.c
    host C: soslim <= build/tools/soslim/soslim.c
    host C: soslim <= build/tools/soslim/main.c
    host C: soslim <= build/tools/soslim/prelink_info.c
    host C: soslim <= build/tools/soslim/symfilter.c
    host Executable: soslim (out/host/linux-x86/obj/EXECUTABLES/soslim_intermediates/soslim)
    true
    Install: out/host/linux-x86/bin/soslim
    target Strip: libdl (out/target/product/omap3evm/obj/lib/libdl.so)
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/_exit.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/_exit_thread.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__fork.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__waitid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__sys_clone.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/execve.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__setuid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/getuid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/getgid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/geteuid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/getegid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/getresuid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/getresgid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/gettid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/getgroups.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/getpgid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/getppid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/setsid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/setgid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__setreuid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__setresuid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/setresgid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__brk.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__ptrace.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__getpriority.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/setpriority.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/setrlimit.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/getrlimit.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/getrusage.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/setgroups.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/setpgid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/vfork.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/setregid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/chroot.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/prctl.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/capget.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/capset.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sigaltstack.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/acct.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/read.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/write.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__pread64.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__pwrite64.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__open.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__openat.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/close.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/lseek.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__llseek.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/getpid.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__mmap2.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/munmap.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/mremap.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/msync.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/mprotect.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/madvise.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/mlock.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/munlock.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/mincore.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__ioctl.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/readv.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/writev.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__fcntl.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/flock.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/fchmod.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/dup.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/pipe.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/pipe2.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/dup2.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/select.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/ftruncate.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/getdents.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/fsync.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/fdatasync.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/fchown.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sync.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__fcntl64.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__fstatfs64.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sendfile.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/fstatat.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/mkdirat.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/fchownat.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/fchmodat.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/renameat.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/link.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/unlink.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/unlinkat.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/chdir.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/mknod.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/chmod.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/chown.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/lchown.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/mount.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/umount2.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/fstat.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/stat.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/lstat.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/mkdir.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/readlink.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/rmdir.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/rename.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__getcwd.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/access.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/symlink.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/fchdir.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/truncate.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__statfs64.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/pause.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/gettimeofday.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/settimeofday.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/times.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/nanosleep.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/clock_gettime.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/clock_settime.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/clock_getres.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/clock_nanosleep.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/getitimer.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/setitimer.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__timer_create.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__timer_settime.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__timer_gettime.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__timer_getoverrun.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__timer_delete.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/utimes.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sigaction.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sigprocmask.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__sigsuspend.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__rt_sigaction.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__rt_sigprocmask.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__rt_sigtimedwait.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sigpending.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/socket.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/socketpair.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/bind.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/connect.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/listen.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/accept.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/getsockname.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/getpeername.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sendto.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/recvfrom.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/shutdown.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/setsockopt.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/getsockopt.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sendmsg.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/recvmsg.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sched_setscheduler.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sched_getscheduler.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sched_yield.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sched_setparam.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sched_getparam.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sched_get_priority_max.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sched_get_priority_min.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sched_rr_get_interval.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/ioprio_set.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/ioprio_get.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/uname.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__wait4.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/umask.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__reboot.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__syslog.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/init_module.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/delete_module.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/klogctl.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/sysinfo.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/futex.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/epoll_create.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/epoll_ctl.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/epoll_wait.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/inotify_init.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/inotify_add_watch.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/inotify_rm_watch.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/poll.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/eventfd.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/__set_tls.S
    target asm: libc_common <= bionic/libc/arch-arm/syscalls/cacheflush.S
    target asm: libc_common <= bionic/libc/arch-arm/bionic/__get_pc.S
    target asm: libc_common <= bionic/libc/arch-arm/bionic/__get_sp.S
    target asm: libc_common <= bionic/libc/arch-arm/bionic/_exit_with_stack_teardown.S
    target asm: libc_common <= bionic/libc/arch-arm/bionic/_setjmp.S
    target asm: libc_common <= bionic/libc/arch-arm/bionic/atomics_arm.S
    target asm: libc_common <= bionic/libc/arch-arm/bionic/clone.S
    target asm: libc_common <= bionic/libc/arch-arm/bionic/ffs.S
    target asm: libc_common <= bionic/libc/arch-arm/bionic/kill.S
    target asm: libc_common <= bionic/libc/arch-arm/bionic/tkill.S
    target asm: libc_common <= bionic/libc/arch-arm/bionic/memcmp.S
    target asm: libc_common <= bionic/libc/arch-arm/bionic/memcmp16.S
    target asm: libc_common <= bionic/libc/arch-arm/bionic/memcpy.S
    target asm: libc_common <= bionic/libc/arch-arm/bionic/memset.S
    target asm: libc_common <= bionic/libc/arch-arm/bionic/setjmp.S
    target asm: libc_common <= bionic/libc/arch-arm/bionic/sigsetjmp.S
    target asm: libc_common <= bionic/libc/arch-arm/bionic/syscall.S
    target arm C: libc_common <= bionic/libc/arch-arm/bionic/strlen.c
    target arm C: libc_common <= bionic/libc/string/memmove.c
    target arm C: libc_common <= bionic/libc/bionic/pthread-rwlocks.c
    target arm C: libc_common <= bionic/libc/bionic/pthread-timers.c
    target arm C: libc_common <= bionic/libc/bionic/ptrace.c
    target thumb C: libc_common <= bionic/libc/unistd/abort.c
    target thumb C: libc_common <= bionic/libc/unistd/alarm.c
    target thumb C: libc_common <= bionic/libc/unistd/brk.c
    target thumb C: libc_common <= bionic/libc/unistd/creat.c
    target thumb C: libc_common <= bionic/libc/unistd/daemon.c
    target thumb C: libc_common <= bionic/libc/unistd/eventfd.c
    target thumb C: libc_common <= bionic/libc/unistd/exec.c
    target thumb C: libc_common <= bionic/libc/unistd/fcntl.c
    target thumb C: libc_common <= bionic/libc/unistd/fnmatch.c
    target thumb C: libc_common <= bionic/libc/unistd/fstatfs.c
    target thumb C: libc_common <= bionic/libc/unistd/ftime.c
    target thumb C: libc_common <= bionic/libc/unistd/ftok.c
    target thumb C: libc_common <= bionic/libc/unistd/getcwd.c
    target thumb C: libc_common <= bionic/libc/unistd/getdtablesize.c
    target thumb C: libc_common <= bionic/libc/unistd/gethostname.c
    target thumb C: libc_common <= bionic/libc/unistd/getopt_long.c
    target thumb C: libc_common <= bionic/libc/unistd/getpgrp.c
    target thumb C: libc_common <= bionic/libc/unistd/getpriority.c
    target thumb C: libc_common <= bionic/libc/unistd/getpt.c
    target thumb C: libc_common <= bionic/libc/unistd/initgroups.c
    target thumb C: libc_common <= bionic/libc/unistd/isatty.c
    target thumb C: libc_common <= bionic/libc/unistd/issetugid.c
    target thumb C: libc_common <= bionic/libc/unistd/killpg.c
    target thumb C: libc_common <= bionic/libc/unistd/lseek64.c
    target thumb C: libc_common <= bionic/libc/unistd/mmap.c
    target thumb C: libc_common <= bionic/libc/unistd/nice.c
    target thumb C: libc_common <= bionic/libc/unistd/open.c
    target thumb C: libc_common <= bionic/libc/unistd/openat.c
    target thumb C: libc_common <= bionic/libc/unistd/opendir.c
    target thumb C: libc_common <= bionic/libc/unistd/pathconf.c
    target thumb C: libc_common <= bionic/libc/unistd/perror.c
    target thumb C: libc_common <= bionic/libc/unistd/popen.c
    target thumb C: libc_common <= bionic/libc/unistd/pread.c
    target thumb C: libc_common <= bionic/libc/unistd/pselect.c
    target thumb C: libc_common <= bionic/libc/unistd/ptsname.c
    target thumb C: libc_common <= bionic/libc/unistd/ptsname_r.c
    target thumb C: libc_common <= bionic/libc/unistd/pwrite.c
    target thumb C: libc_common <= bionic/libc/unistd/raise.c
    target thumb C: libc_common <= bionic/libc/unistd/reboot.c
    target thumb C: libc_common <= bionic/libc/unistd/recv.c
    target thumb C: libc_common <= bionic/libc/unistd/sbrk.c
    target thumb C: libc_common <= bionic/libc/unistd/send.c
    target thumb C: libc_common <= bionic/libc/unistd/setegid.c
    target thumb C: libc_common <= bionic/libc/unistd/setuid.c
    target thumb C: libc_common <= bionic/libc/unistd/seteuid.c
    target thumb C: libc_common <= bionic/libc/unistd/setreuid.c
    target thumb C: libc_common <= bionic/libc/unistd/setresuid.c
    target thumb C: libc_common <= bionic/libc/unistd/setpgrp.c
    target thumb C: libc_common <= bionic/libc/unistd/sigblock.c
    target thumb C: libc_common <= bionic/libc/unistd/siginterrupt.c
    target thumb C: libc_common <= bionic/libc/unistd/siglist.c
    target thumb C: libc_common <= bionic/libc/unistd/signal.c
    target thumb C: libc_common <= bionic/libc/unistd/signame.c
    target thumb C: libc_common <= bionic/libc/unistd/sigsetmask.c
    target thumb C: libc_common <= bionic/libc/unistd/sigsuspend.c
    target thumb C: libc_common <= bionic/libc/unistd/sigwait.c
    target thumb C: libc_common <= bionic/libc/unistd/sleep.c
    target thumb C: libc_common <= bionic/libc/unistd/statfs.c
    target thumb C: libc_common <= bionic/libc/unistd/strsignal.c
    target thumb C: libc_common <= bionic/libc/unistd/syslog.c
    target thumb C: libc_common <= bionic/libc/unistd/system.c
    target thumb C: libc_common <= bionic/libc/unistd/tcgetpgrp.c
    target thumb C: libc_common <= bionic/libc/unistd/tcsetpgrp.c
    target thumb C: libc_common <= bionic/libc/unistd/time.c
    target thumb C: libc_common <= bionic/libc/unistd/umount.c
    target thumb C: libc_common <= bionic/libc/unistd/unlockpt.c
    target thumb C: libc_common <= bionic/libc/unistd/usleep.c
    target thumb C: libc_common <= bionic/libc/unistd/wait.c
    target thumb C: libc_common <= bionic/libc/stdio/asprintf.c
    target thumb C: libc_common <= bionic/libc/stdio/clrerr.c
    target thumb C: libc_common <= bionic/libc/stdio/fclose.c
    target thumb C: libc_common <= bionic/libc/stdio/fdopen.c
    target thumb C: libc_common <= bionic/libc/stdio/feof.c
    target thumb C: libc_common <= bionic/libc/stdio/ferror.c
    target thumb C: libc_common <= bionic/libc/stdio/fflush.c
    target thumb C: libc_common <= bionic/libc/stdio/fgetc.c
    target thumb C: libc_common <= bionic/libc/stdio/fgetln.c
    target thumb C: libc_common <= bionic/libc/stdio/fgetpos.c
    target thumb C: libc_common <= bionic/libc/stdio/fgets.c
    target thumb C: libc_common <= bionic/libc/stdio/fileno.c
    target thumb C: libc_common <= bionic/libc/stdio/findfp.c
    target thumb C: libc_common <= bionic/libc/stdio/flags.c
    target thumb C: libc_common <= bionic/libc/stdio/flockfile.c
    target thumb C: libc_common <= bionic/libc/stdio/fopen.c
    target thumb C: libc_common <= bionic/libc/stdio/fprintf.c
    target thumb C: libc_common <= bionic/libc/stdio/fpurge.c
    target thumb C: libc_common <= bionic/libc/stdio/fputc.c
    target thumb C: libc_common <= bionic/libc/stdio/fputs.c
    target thumb C: libc_common <= bionic/libc/stdio/fread.c
    target thumb C: libc_common <= bionic/libc/stdio/freopen.c
    target thumb C: libc_common <= bionic/libc/stdio/fscanf.c
    target thumb C: libc_common <= bionic/libc/stdio/fseek.c
    target thumb C: libc_common <= bionic/libc/stdio/fsetpos.c
    target thumb C: libc_common <= bionic/libc/stdio/ftell.c
    target thumb C: libc_common <= bionic/libc/stdio/funopen.c
    target thumb C: libc_common <= bionic/libc/stdio/fvwrite.c
    target thumb C: libc_common <= bionic/libc/stdio/fwalk.c
    target thumb C: libc_common <= bionic/libc/stdio/fwrite.c
    target thumb C: libc_common <= bionic/libc/stdio/getc.c
    target thumb C: libc_common <= bionic/libc/stdio/getchar.c
    target thumb C: libc_common <= bionic/libc/stdio/gets.c
    target thumb C: libc_common <= bionic/libc/stdio/makebuf.c
    target thumb C: libc_common <= bionic/libc/stdio/mktemp.c
    target thumb C: libc_common <= bionic/libc/stdio/printf.c
    target thumb C: libc_common <= bionic/libc/stdio/putc.c
    target thumb C: libc_common <= bionic/libc/stdio/putchar.c
    target thumb C: libc_common <= bionic/libc/stdio/puts.c
    target thumb C: libc_common <= bionic/libc/stdio/putw.c
    target thumb C: libc_common <= bionic/libc/stdio/refill.c
    target thumb C: libc_common <= bionic/libc/stdio/remove.c
    target thumb C: libc_common <= bionic/libc/stdio/rewind.c
    target thumb C: libc_common <= bionic/libc/stdio/rget.c
    target thumb C: libc_common <= bionic/libc/stdio/scanf.c
    target thumb C: libc_common <= bionic/libc/stdio/setbuf.c
    target thumb C: libc_common <= bionic/libc/stdio/setbuffer.c
    target thumb C: libc_common <= bionic/libc/stdio/setvbuf.c
    target thumb C: libc_common <= bionic/libc/stdio/snprintf.c
    target thumb C: libc_common <= bionic/libc/stdio/sprintf.c
    target thumb C: libc_common <= bionic/libc/stdio/sscanf.c
    target thumb C: libc_common <= bionic/libc/stdio/stdio.c
    target thumb C: libc_common <= bionic/libc/stdio/tempnam.c
    target thumb C: libc_common <= bionic/libc/stdio/tmpfile.c
    target thumb C: libc_common <= bionic/libc/stdio/tmpnam.c
    target thumb C: libc_common <= bionic/libc/stdio/ungetc.c
    target thumb C: libc_common <= bionic/libc/stdio/vasprintf.c
    target thumb C: libc_common <= bionic/libc/stdio/vfprintf.c
    target thumb C: libc_common <= bionic/libc/stdio/vfscanf.c
    target thumb C: libc_common <= bionic/libc/stdio/vprintf.c
    target thumb C: libc_common <= bionic/libc/stdio/vsnprintf.c
    target thumb C: libc_common <= bionic/libc/stdio/vsprintf.c
    target thumb C: libc_common <= bionic/libc/stdio/vscanf.c
    target thumb C: libc_common <= bionic/libc/stdio/vsscanf.c
    target thumb C: libc_common <= bionic/libc/stdio/wbuf.c
    target thumb C: libc_common <= bionic/libc/stdio/wsetup.c
    target thumb C: libc_common <= bionic/libc/stdlib/_rand48.c
    target thumb C: libc_common <= bionic/libc/stdlib/assert.c
    target thumb C: libc_common <= bionic/libc/stdlib/atexit.c
    target thumb C: libc_common <= bionic/libc/stdlib/atoi.c
    target thumb C: libc_common <= bionic/libc/stdlib/atol.c
    target thumb C: libc_common <= bionic/libc/stdlib/atoll.c
    target thumb C: libc_common <= bionic/libc/stdlib/bsearch.c
    target thumb C: libc_common <= bionic/libc/stdlib/ctype_.c
    target thumb C: libc_common <= bionic/libc/stdlib/div.c
    target thumb C: libc_common <= bionic/libc/stdlib/exit.c
    target thumb C: libc_common <= bionic/libc/stdlib/getenv.c
    target thumb C: libc_common <= bionic/libc/stdlib/jrand48.c
    target thumb C: libc_common <= bionic/libc/stdlib/ldiv.c
    target thumb C: libc_common <= bionic/libc/stdlib/lldiv.c
    target thumb C: libc_common <= bionic/libc/stdlib/locale.c
    target thumb C: libc_common <= bionic/libc/stdlib/lrand48.c
    target thumb C: libc_common <= bionic/libc/stdlib/mrand48.c
    target thumb C: libc_common <= bionic/libc/stdlib/nrand48.c
    target thumb C: libc_common <= bionic/libc/stdlib/putenv.c
    target thumb C: libc_common <= bionic/libc/stdlib/qsort.c
    target thumb C: libc_common <= bionic/libc/stdlib/seed48.c
    target thumb C: libc_common <= bionic/libc/stdlib/setenv.c
    target thumb C: libc_common <= bionic/libc/stdlib/setjmperr.c
    target thumb C: libc_common <= bionic/libc/stdlib/srand48.c
    target thumb C: libc_common <= bionic/libc/stdlib/strntoimax.c
    target thumb C: libc_common <= bionic/libc/stdlib/strntoumax.c
    target thumb C: libc_common <= bionic/libc/stdlib/strtod.c
    target thumb C: libc_common <= bionic/libc/stdlib/strtoimax.c
    target thumb C: libc_common <= bionic/libc/stdlib/strtol.c
    target thumb C: libc_common <= bionic/libc/stdlib/strtoll.c
    target thumb C: libc_common <= bionic/libc/stdlib/strtoul.c
    target thumb C: libc_common <= bionic/libc/stdlib/strtoull.c
    target thumb C: libc_common <= bionic/libc/stdlib/strtoumax.c
    target thumb C: libc_common <= bionic/libc/stdlib/tolower_.c
    target thumb C: libc_common <= bionic/libc/stdlib/toupper_.c
    target thumb C: libc_common <= bionic/libc/stdlib/wchar.c
    target thumb C: libc_common <= bionic/libc/string/index.c
    target thumb C: libc_common <= bionic/libc/string/memccpy.c
    target thumb C: libc_common <= bionic/libc/string/memchr.c
    target thumb C: libc_common <= bionic/libc/string/memmem.c
    target thumb C: libc_common <= bionic/libc/string/memrchr.c
    target thumb C: libc_common <= bionic/libc/string/memswap.c
    target thumb C: libc_common <= bionic/libc/string/strcasecmp.c
    target thumb C: libc_common <= bionic/libc/string/strcasestr.c
    target thumb C: libc_common <= bionic/libc/string/strcat.c
    target thumb C: libc_common <= bionic/libc/string/strchr.c
    target thumb C: libc_common <= bionic/libc/string/strcoll.c
    target thumb C: libc_common <= bionic/libc/string/strcpy.c
    target thumb C: libc_common <= bionic/libc/string/strcspn.c
    target thumb C: libc_common <= bionic/libc/string/strdup.c
    target thumb C: libc_common <= bionic/libc/string/strerror.c
    target thumb C: libc_common <= bionic/libc/string/strerror_r.c
    target thumb C: libc_common <= bionic/libc/string/strlcat.c
    target thumb C: libc_common <= bionic/libc/string/strlcpy.c
    target thumb C: libc_common <= bionic/libc/string/strncat.c
    target thumb C: libc_common <= bionic/libc/string/strncpy.c
    target thumb C: libc_common <= bionic/libc/string/strndup.c
    target thumb C: libc_common <= bionic/libc/string/strnlen.c
    target thumb C: libc_common <= bionic/libc/string/strpbrk.c
    target thumb C: libc_common <= bionic/libc/string/strrchr.c
    target thumb C: libc_common <= bionic/libc/string/strsep.c
    target thumb C: libc_common <= bionic/libc/string/strspn.c
    target thumb C: libc_common <= bionic/libc/string/strstr.c
    target thumb C: libc_common <= bionic/libc/string/strtok.c
    target thumb C: libc_common <= bionic/libc/string/strtotimeval.c
    target thumb C: libc_common <= bionic/libc/string/strxfrm.c
    target thumb C: libc_common <= bionic/libc/wchar/wcpcpy.c
    target thumb C: libc_common <= bionic/libc/wchar/wcpncpy.c
    target thumb C: libc_common <= bionic/libc/wchar/wcscasecmp.c
    target thumb C: libc_common <= bionic/libc/wchar/wcscat.c
    target thumb C: libc_common <= bionic/libc/wchar/wcschr.c
    target thumb C: libc_common <= bionic/libc/wchar/wcscmp.c
    target thumb C: libc_common <= bionic/libc/wchar/wcscoll.c
    target thumb C: libc_common <= bionic/libc/wchar/wcscpy.c
    target thumb C: libc_common <= bionic/libc/wchar/wcscspn.c
    target thumb C: libc_common <= bionic/libc/wchar/wcsdup.c
    target thumb C: libc_common <= bionic/libc/wchar/wcslcat.c
    target thumb C: libc_common <= bionic/libc/wchar/wcslcpy.c
    target thumb C: libc_common <= bionic/libc/wchar/wcslen.c
    target thumb C: libc_common <= bionic/libc/wchar/wcsncasecmp.c
    target thumb C: libc_common <= bionic/libc/wchar/wcsncat.c
    target thumb C: libc_common <= bionic/libc/wchar/wcsncmp.c
    target thumb C: libc_common <= bionic/libc/wchar/wcsncpy.c
    target thumb C: libc_common <= bionic/libc/wchar/wcsnlen.c
    target thumb C: libc_common <= bionic/libc/wchar/wcspbrk.c
    target thumb C: libc_common <= bionic/libc/wchar/wcsrchr.c
    target thumb C: libc_common <= bionic/libc/wchar/wcsspn.c
    target thumb C: libc_common <= bionic/libc/wchar/wcsstr.c
    target thumb C: libc_common <= bionic/libc/wchar/wcstok.c
    target thumb C: libc_common <= bionic/libc/wchar/wcswidth.c
    target thumb C: libc_common <= bionic/libc/wchar/wmemchr.c
    target thumb C: libc_common <= bionic/libc/wchar/wmemcmp.c
    target thumb C: libc_common <= bionic/libc/wchar/wmemcpy.c
    target thumb C: libc_common <= bionic/libc/wchar/wmemmove.c
    target thumb C: libc_common <= bionic/libc/wchar/wmemset.c
    target thumb C: libc_common <= bionic/libc/inet/bindresvport.c
    target thumb C: libc_common <= bionic/libc/inet/inet_addr.c
    target thumb C: libc_common <= bionic/libc/inet/inet_aton.c
    target thumb C: libc_common <= bionic/libc/inet/inet_ntoa.c
    target thumb C: libc_common <= bionic/libc/inet/inet_ntop.c
    target thumb C: libc_common <= bionic/libc/inet/inet_pton.c
    target thumb C: libc_common <= bionic/libc/tzcode/asctime.c
    target thumb C: libc_common <= bionic/libc/tzcode/difftime.c
    target thumb C: libc_common <= bionic/libc/tzcode/localtime.c
    target thumb C: libc_common <= bionic/libc/tzcode/strftime.c
    target thumb C: libc_common <= bionic/libc/tzcode/strptime.c
    target thumb C: libc_common <= bionic/libc/bionic/__set_errno.c
    target thumb C: libc_common <= bionic/libc/bionic/_rand48.c
    target thumb C: libc_common <= bionic/libc/bionic/cpuacct.c
    target thumb C: libc_common <= bionic/libc/bionic/arc4random.c
    target thumb C: libc_common <= bionic/libc/bionic/basename.c
    target thumb C: libc_common <= bionic/libc/bionic/basename_r.c
    target thumb C: libc_common <= bionic/libc/bionic/clearenv.c
    target thumb C: libc_common <= bionic/libc/bionic/dirname.c
    target thumb C: libc_common <= bionic/libc/bionic/dirname_r.c
    target thumb C: libc_common <= bionic/libc/bionic/drand48.c
    target thumb C: libc_common <= bionic/libc/bionic/erand48.c
    target thumb C: libc_common <= bionic/libc/bionic/err.c
    target thumb C: libc_common <= bionic/libc/bionic/fdprintf.c
    target thumb C: libc_common <= bionic/libc/bionic/fork.c
    target thumb C: libc_common <= bionic/libc/bionic/fts.c
    target thumb C: libc_common <= bionic/libc/bionic/if_nametoindex.c
    target thumb C: libc_common <= bionic/libc/bionic/if_indextoname.c
    target thumb C: libc_common <= bionic/libc/bionic/ioctl.c
    target thumb C: libc_common <= bionic/libc/bionic/ldexp.c
    target thumb C: libc_common <= bionic/libc/bionic/libc_init_common.c
    target thumb C: libc_common <= bionic/libc/bionic/logd_write.c
    target thumb C: libc_common <= bionic/libc/bionic/md5.c
    target thumb C: libc_common <= bionic/libc/bionic/pututline.c
    target thumb C: libc_common <= bionic/libc/bionic/realpath.c
    target thumb C: libc_common <= bionic/libc/bionic/semaphore.c
    target thumb C: libc_common <= bionic/libc/bionic/sha1.c
    target thumb C: libc_common <= bionic/libc/bionic/ssp.c
    target thumb C: libc_common <= bionic/libc/bionic/stubs.c
    target thumb C: libc_common <= bionic/libc/bionic/system_properties.c
    target thumb C: libc_common <= bionic/libc/bionic/time64.c
    target thumb C: libc_common <= bionic/libc/bionic/thread_atexit.c
    target thumb C: libc_common <= bionic/libc/bionic/utime.c
    target thumb C: libc_common <= bionic/libc/bionic/utmp.c
    target thumb C: libc_common <= bionic/libc/netbsd/gethnamaddr.c
    target thumb C: libc_common <= bionic/libc/netbsd/isc/ev_timers.c
    target thumb C: libc_common <= bionic/libc/netbsd/isc/ev_streams.c
    target thumb C: libc_common <= bionic/libc/netbsd/inet/nsap_addr.c
    target thumb C: libc_common <= bionic/libc/netbsd/resolv/__dn_comp.c
    target thumb C: libc_common <= bionic/libc/netbsd/resolv/__res_close.c
    target thumb C: libc_common <= bionic/libc/netbsd/resolv/__res_send.c
    target thumb C: libc_common <= bionic/libc/netbsd/resolv/herror.c
    target thumb C: libc_common <= bionic/libc/netbsd/resolv/res_comp.c
    target thumb C: libc_common <= bionic/libc/netbsd/resolv/res_data.c
    target thumb C: libc_common <= bionic/libc/netbsd/resolv/res_debug.c
    target thumb C: libc_common <= bionic/libc/netbsd/resolv/res_init.c
    target thumb C: libc_common <= bionic/libc/netbsd/resolv/res_mkquery.c
    target thumb C: libc_common <= bionic/libc/netbsd/resolv/res_query.c
    target thumb C: libc_common <= bionic/libc/netbsd/resolv/res_send.c
    target thumb C: libc_common <= bionic/libc/netbsd/resolv/res_state.c
    target thumb C: libc_common <= bionic/libc/netbsd/resolv/res_cache.c
    target thumb C: libc_common <= bionic/libc/netbsd/net/nsdispatch.c
    target thumb C: libc_common <= bionic/libc/netbsd/net/getaddrinfo.c
    target thumb C: libc_common <= bionic/libc/netbsd/net/getnameinfo.c
    target thumb C: libc_common <= bionic/libc/netbsd/net/getservbyname.c
    target thumb C: libc_common <= bionic/libc/netbsd/net/getservent.c
    target thumb C: libc_common <= bionic/libc/netbsd/net/base64.c
    target thumb C: libc_common <= bionic/libc/netbsd/net/getservbyport.c
    target thumb C: libc_common <= bionic/libc/netbsd/nameser/ns_name.c
    target thumb C: libc_common <= bionic/libc/netbsd/nameser/ns_parse.c
    target thumb C: libc_common <= bionic/libc/netbsd/nameser/ns_ttl.c
    target thumb C: libc_common <= bionic/libc/netbsd/nameser/ns_netint.c
    target thumb C: libc_common <= bionic/libc/netbsd/nameser/ns_print.c
    target thumb C: libc_common <= bionic/libc/netbsd/nameser/ns_samedomain.c
    target thumb C: libc_common <= bionic/libc/regex/regcomp.c
    target thumb C: libc_common <= bionic/libc/regex/regerror.c
    target thumb C: libc_common <= bionic/libc/regex/regexec.c
    target thumb C: libc_common <= bionic/libc/regex/regfree.c
    target thumb C: libc_common <= bionic/libc/bionic/bionic_clone.c
    target thumb C: libc_common <= bionic/libc/arch-arm/bionic/eabi.c
    target thumb C: libc_common <= bionic/libc/arch-arm/bionic/libgcc_compat.c
    target thumb C: libc_common <= bionic/libc/string/bcopy.c
    target thumb C: libc_common <= bionic/libc/string/strcmp.c
    target thumb C: libc_common <= bionic/libc/string/strncmp.c
    target thumb C: libc_common <= bionic/libc/unistd/socketcalls.c
    target StaticLib: libc_common (out/target/product/omap3evm/obj/STATIC_LIBRARIES/libc_common_intermediates/libc_common.a)
    target SharedLib: libc (out/target/product/omap3evm/obj/SHARED_LIBRARIES/libc_intermediates/LINKED/libc.so)
    target Prelink: libc (out/target/product/omap3evm/symbols/system/lib/libc.so)
    target Strip: libc (out/target/product/omap3evm/obj/lib/libc.so)
    target thumb C++: libstdc++ <= bionic/libstdc++/src/one_time_construction.cpp
    target thumb C++: libstdc++ <= bionic/libstdc++/src/new.cpp
    target thumb C++: libstdc++ <= bionic/libstdc++/src/pure_virtual.cpp
    target thumb C++: libstdc++ <= bionic/libstdc++/src/typeinfo.cpp
    target SharedLib: libstdc++ (out/target/product/omap3evm/obj/SHARED_LIBRARIES/libstdc++_intermediates/LINKED/libstdc++.so)
    target Prelink: libstdc++ (out/target/product/omap3evm/symbols/system/lib/libstdc++.so)
    target Strip: libstdc++ (out/target/product/omap3evm/obj/lib/libstdc++.so)
    target arm C: libm <= bionic/libm/isinf.c
    target arm C: libm <= bionic/libm/fpclassify.c
    target arm C: libm <= bionic/libm/sincos.c
    target arm C: libm <= bionic/libm/bsdsrc/b_exp.c
    target arm C: libm <= bionic/libm/bsdsrc/b_log.c
    target arm C: libm <= bionic/libm/bsdsrc/b_tgamma.c
    target arm C: libm <= bionic/libm/src/e_acos.c
    target arm C: libm <= bionic/libm/src/e_acosf.c
    target arm C: libm <= bionic/libm/src/e_acosh.c
    target arm C: libm <= bionic/libm/src/e_acoshf.c
    target arm C: libm <= bionic/libm/src/e_asin.c
    target arm C: libm <= bionic/libm/src/e_asinf.c
    target arm C: libm <= bionic/libm/src/e_atan2.c
    target arm C: libm <= bionic/libm/src/e_atan2f.c
    target arm C: libm <= bionic/libm/src/e_atanh.c
    target arm C: libm <= bionic/libm/src/e_atanhf.c
    target arm C: libm <= bionic/libm/src/e_cosh.c
    target arm C: libm <= bionic/libm/src/e_coshf.c
    target arm C: libm <= bionic/libm/src/e_exp.c
    target arm C: libm <= bionic/libm/src/e_expf.c
    target arm C: libm <= bionic/libm/src/e_fmod.c
    target arm C: libm <= bionic/libm/src/e_fmodf.c
    target arm C: libm <= bionic/libm/src/e_gamma.c
    target arm C: libm <= bionic/libm/src/e_gamma_r.c
    target arm C: libm <= bionic/libm/src/e_gammaf.c
    target arm C: libm <= bionic/libm/src/e_gammaf_r.c
    target arm C: libm <= bionic/libm/src/e_hypot.c
    target arm C: libm <= bionic/libm/src/e_hypotf.c
    target arm C: libm <= bionic/libm/src/e_j0.c
    target arm C: libm <= bionic/libm/src/e_j0f.c
    target arm C: libm <= bionic/libm/src/e_j1.c
    target arm C: libm <= bionic/libm/src/e_j1f.c
    target arm C: libm <= bionic/libm/src/e_jn.c
    target arm C: libm <= bionic/libm/src/e_jnf.c
    target arm C: libm <= bionic/libm/src/e_lgamma.c
    target arm C: libm <= bionic/libm/src/e_lgamma_r.c
    target arm C: libm <= bionic/libm/src/e_lgammaf.c
    target arm C: libm <= bionic/libm/src/e_lgammaf_r.c
    target arm C: libm <= bionic/libm/src/e_log.c
    target arm C: libm <= bionic/libm/src/e_log10.c
    target arm C: libm <= bionic/libm/src/e_log10f.c
    target arm C: libm <= bionic/libm/src/e_logf.c
    target arm C: libm <= bionic/libm/src/e_pow.c
    target arm C: libm <= bionic/libm/src/e_powf.c
    target arm C: libm <= bionic/libm/src/e_rem_pio2.c
    target arm C: libm <= bionic/libm/src/e_rem_pio2f.c
    target arm C: libm <= bionic/libm/src/e_remainder.c
    target arm C: libm <= bionic/libm/src/e_remainderf.c
    target arm C: libm <= bionic/libm/src/e_scalb.c
    target arm C: libm <= bionic/libm/src/e_scalbf.c
    target arm C: libm <= bionic/libm/src/e_sinh.c
    target arm C: libm <= bionic/libm/src/e_sinhf.c
    target arm C: libm <= bionic/libm/src/e_sqrt.c
    target arm C: libm <= bionic/libm/src/e_sqrtf.c
    target arm C: libm <= bionic/libm/src/k_cos.c
    target arm C: libm <= bionic/libm/src/k_cosf.c
    target arm C: libm <= bionic/libm/src/k_rem_pio2.c
    target arm C: libm <= bionic/libm/src/k_sin.c
    target arm C: libm <= bionic/libm/src/k_sinf.c
    target arm C: libm <= bionic/libm/src/k_tan.c
    target arm C: libm <= bionic/libm/src/k_tanf.c
    target arm C: libm <= bionic/libm/src/s_asinh.c
    target arm C: libm <= bionic/libm/src/s_asinhf.c
    target arm C: libm <= bionic/libm/src/s_atan.c
    target arm C: libm <= bionic/libm/src/s_atanf.c
    target arm C: libm <= bionic/libm/src/s_cbrt.c
    target arm C: libm <= bionic/libm/src/s_cbrtf.c
    target arm C: libm <= bionic/libm/src/s_ceil.c
    target arm C: libm <= bionic/libm/src/s_ceilf.c
    target arm C: libm <= bionic/libm/src/s_ceill.c
    target arm C: libm <= bionic/libm/src/s_copysign.c
    target arm C: libm <= bionic/libm/src/s_copysignf.c
    target arm C: libm <= bionic/libm/src/s_cos.c
    target arm C: libm <= bionic/libm/src/s_cosf.c
    target arm C: libm <= bionic/libm/src/s_erf.c
    target arm C: libm <= bionic/libm/src/s_erff.c
    target arm C: libm <= bionic/libm/src/s_exp2.c
    target arm C: libm <= bionic/libm/src/s_exp2f.c
    target arm C: libm <= bionic/libm/src/s_expm1.c
    target arm C: libm <= bionic/libm/src/s_expm1f.c
    target arm C: libm <= bionic/libm/src/s_fabsf.c
    target arm C: libm <= bionic/libm/src/s_fdim.c
    target arm C: libm <= bionic/libm/src/s_finite.c
    target arm C: libm <= bionic/libm/src/s_finitef.c
    target arm C: libm <= bionic/libm/src/s_floor.c
    target arm C: libm <= bionic/libm/src/s_floorf.c
    target arm C: libm <= bionic/libm/src/s_floorl.c
    target arm C: libm <= bionic/libm/src/s_fma.c
    target arm C: libm <= bionic/libm/src/s_fmaf.c
    target arm C: libm <= bionic/libm/src/s_fmax.c
    target arm C: libm <= bionic/libm/src/s_fmaxf.c
    target arm C: libm <= bionic/libm/src/s_fmaxl.c
    target arm C: libm <= bionic/libm/src/s_fmin.c
    target arm C: libm <= bionic/libm/src/s_fminf.c
    target arm C: libm <= bionic/libm/src/s_fminl.c
    target arm C: libm <= bionic/libm/src/s_frexpf.c
    target arm C: libm <= bionic/libm/src/s_ilogb.c
    target arm C: libm <= bionic/libm/src/s_ilogbf.c
    target arm C: libm <= bionic/libm/src/s_ilogbl.c
    target arm C: libm <= bionic/libm/src/s_isfinite.c
    target arm C: libm <= bionic/libm/src/s_isnormal.c
    target arm C: libm <= bionic/libm/src/s_llrint.c
    target arm C: libm <= bionic/libm/src/s_llrintf.c
    target arm C: libm <= bionic/libm/src/s_llround.c
    target arm C: libm <= bionic/libm/src/s_llroundf.c
    target arm C: libm <= bionic/libm/src/s_llroundl.c
    target arm C: libm <= bionic/libm/src/s_log1p.c
    target arm C: libm <= bionic/libm/src/s_log1pf.c
    target arm C: libm <= bionic/libm/src/s_logb.c
    target arm C: libm <= bionic/libm/src/s_logbf.c
    target arm C: libm <= bionic/libm/src/s_lrint.c
    target arm C: libm <= bionic/libm/src/s_lrintf.c
    target arm C: libm <= bionic/libm/src/s_lround.c
    target arm C: libm <= bionic/libm/src/s_lroundf.c
    target arm C: libm <= bionic/libm/src/s_lroundl.c
    target arm C: libm <= bionic/libm/src/s_modff.c
    target arm C: libm <= bionic/libm/src/s_nearbyint.c
    target arm C: libm <= bionic/libm/src/s_nextafter.c
    target arm C: libm <= bionic/libm/src/s_nextafterf.c
    target arm C: libm <= bionic/libm/src/s_nexttowardf.c
    target arm C: libm <= bionic/libm/src/s_remquo.c
    target arm C: libm <= bionic/libm/src/s_remquof.c
    target arm C: libm <= bionic/libm/src/s_rint.c
    target arm C: libm <= bionic/libm/src/s_rintf.c
    target arm C: libm <= bionic/libm/src/s_round.c
    target arm C: libm <= bionic/libm/src/s_roundf.c
    target arm C: libm <= bionic/libm/src/s_roundl.c
    target arm C: libm <= bionic/libm/src/s_signbit.c
    target arm C: libm <= bionic/libm/src/s_signgam.c
    target arm C: libm <= bionic/libm/src/s_significand.c
    target arm C: libm <= bionic/libm/src/s_significandf.c
    target arm C: libm <= bionic/libm/src/s_sin.c
    target arm C: libm <= bionic/libm/src/s_sinf.c
    target arm C: libm <= bionic/libm/src/s_tan.c
    target arm C: libm <= bionic/libm/src/s_tanf.c
    target arm C: libm <= bionic/libm/src/s_tanh.c
    target arm C: libm <= bionic/libm/src/s_tanhf.c
    target arm C: libm <= bionic/libm/src/s_trunc.c
    target arm C: libm <= bionic/libm/src/s_truncf.c
    target arm C: libm <= bionic/libm/src/s_truncl.c
    target arm C: libm <= bionic/libm/src/w_drem.c
    target arm C: libm <= bionic/libm/src/w_dremf.c
    target arm C: libm <= bionic/libm/src/s_copysignl.c
    target arm C: libm <= bionic/libm/src/s_fabsl.c
    target arm C: libm <= bionic/libm/src/s_fabs.c
    target arm C: libm <= bionic/libm/src/s_frexp.c
    target arm C: libm <= bionic/libm/src/s_isnan.c
    target arm C: libm <= bionic/libm/src/s_modf.c
    target arm C: libm <= bionic/libm/arm/fenv.c
    target arm C: libm <= bionic/libm/src/e_ldexpf.c
    target arm C: libm <= bionic/libm/src/s_scalbln.c
    target arm C: libm <= bionic/libm/src/s_scalbn.c
    target arm C: libm <= bionic/libm/src/s_scalbnf.c
    target SharedLib: libm (out/target/product/omap3evm/obj/SHARED_LIBRARIES/libm_intermediates/LINKED/libm.so)
    target Prelink: libm (out/target/product/omap3evm/symbols/system/lib/libm.so)
    target Strip: libm (out/target/product/omap3evm/obj/lib/libm.so)
    target thumb C: liblog <= system/core/liblog/logd_write.c
    target thumb C: liblog <= system/core/liblog/logprint.c
    target thumb C: liblog <= system/core/liblog/event_tag_map.c
    target StaticLib: liblog (out/target/product/omap3evm/obj/STATIC_LIBRARIES/liblog_intermediates/liblog.a)
    target SharedLib: liblog (out/target/product/omap3evm/obj/SHARED_LIBRARIES/liblog_intermediates/LINKED/liblog.so)
    target Prelink: liblog (out/target/product/omap3evm/symbols/system/lib/liblog.so)
    target Strip: liblog (out/target/product/omap3evm/obj/lib/liblog.so)
    target asm: libcutils <= system/core/libcutils/memset32.S
    target arm C: libcutils <= system/core/libcutils/atomic.c
    target thumb C: libcutils <= system/core/libcutils/array.c
    target thumb C: libcutils <= system/core/libcutils/hashmap.c
    target thumb C: libcutils <= system/core/libcutils/native_handle.c
    target thumb C: libcutils <= system/core/libcutils/buffer.c
    target thumb C: libcutils <= system/core/libcutils/socket_inaddr_any_server.c
    target thumb C: libcutils <= system/core/libcutils/socket_local_client.c
    target thumb C: libcutils <= system/core/libcutils/socket_local_server.c
    target thumb C: libcutils <= system/core/libcutils/socket_loopback_client.c
    target thumb C: libcutils <= system/core/libcutils/socket_loopback_server.c
    target thumb C: libcutils <= system/core/libcutils/socket_network_client.c
    target thumb C: libcutils <= system/core/libcutils/config_utils.c
    target thumb C: libcutils <= system/core/libcutils/cpu_info.c
    target thumb C: libcutils <= system/core/libcutils/load_file.c
    target thumb C: libcutils <= system/core/libcutils/open_memstream.c
    target thumb C: libcutils <= system/core/libcutils/strdup16to8.c
    target thumb C: libcutils <= system/core/libcutils/strdup8to16.c
    target thumb C: libcutils <= system/core/libcutils/record_stream.c
    target thumb C: libcutils <= system/core/libcutils/process_name.c
    target thumb C: libcutils <= system/core/libcutils/properties.c
    target thumb C: libcutils <= system/core/libcutils/threads.c
    target thumb C: libcutils <= system/core/libcutils/sched_policy.c
    target thumb C: libcutils <= system/core/libcutils/iosched_policy.c
    target thumb C: libcutils <= system/core/libcutils/abort_socket.c
    target thumb C: libcutils <= system/core/libcutils/mspace.c
    target thumb C: libcutils <= system/core/libcutils/selector.c
    target thumb C: libcutils <= system/core/libcutils/tztime.c
    target thumb C: libcutils <= system/core/libcutils/zygote.c
    target thumb C: libcutils <= system/core/libcutils/ashmem-dev.c
    target thumb C: libcutils <= system/core/libcutils/mq.c
    target StaticLib: libcutils (out/target/product/omap3evm/obj/STATIC_LIBRARIES/libcutils_intermediates/libcutils.a)
    target SharedLib: libcutils (out/target/product/omap3evm/obj/SHARED_LIBRARIES/libcutils_intermediates/LINKED/libcutils.so)
    target Prelink: libcutils (out/target/product/omap3evm/symbols/system/lib/libcutils.so)
    target Strip: libcutils (out/target/product/omap3evm/obj/lib/libcutils.so)
    target thumb C: libnativehelper <= dalvik/libnativehelper/JNIHelp.c
    target thumb C: libnativehelper <= dalvik/libnativehelper/Register.c
    target asm: libcrypto <= external/openssl/crypto/aes/asm/aes-armv4.s
    target asm: libcrypto <= external/openssl/crypto/bn/asm/armv4-mont.s
    target asm: libcrypto <= external/openssl/crypto/sha/asm/sha1-armv4-large.s
    target asm: libcrypto <= external/openssl/crypto/sha/asm/sha256-armv4.s
    target asm: libcrypto <= external/openssl/crypto/sha/asm/sha512-armv4.s
    target thumb C: libcrypto <= external/openssl/crypto/cryptlib.c
    target thumb C: libcrypto <= external/openssl/crypto/mem.c
    target thumb C: libcrypto <= external/openssl/crypto/mem_clr.c
    target thumb C: libcrypto <= external/openssl/crypto/mem_dbg.c
    target thumb C: libcrypto <= external/openssl/crypto/cversion.c
    target thumb C: libcrypto <= external/openssl/crypto/ex_data.c
    target thumb C: libcrypto <= external/openssl/crypto/cpt_err.c
    target thumb C: libcrypto <= external/openssl/crypto/ebcdic.c
    target thumb C: libcrypto <= external/openssl/crypto/uid.c
    target thumb C: libcrypto <= external/openssl/crypto/o_time.c
    target thumb C: libcrypto <= external/openssl/crypto/o_str.c
    target thumb C: libcrypto <= external/openssl/crypto/o_dir.c
    target thumb C: libcrypto <= external/openssl/crypto/aes/aes_cbc.c
    target thumb C: libcrypto <= external/openssl/crypto/aes/aes_cfb.c
    target thumb C: libcrypto <= external/openssl/crypto/aes/aes_ctr.c
    target thumb C: libcrypto <= external/openssl/crypto/aes/aes_ecb.c
    target thumb C: libcrypto <= external/openssl/crypto/aes/aes_misc.c
    target thumb C: libcrypto <= external/openssl/crypto/aes/aes_ofb.c
    target thumb C: libcrypto <= external/openssl/crypto/aes/aes_wrap.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_bitstr.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_bool.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_bytes.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_d2i_fp.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_digest.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_dup.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_enum.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_gentm.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_i2d_fp.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_int.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_mbstr.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_object.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_octet.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_print.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_set.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_sign.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_strex.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_strnid.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_time.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_type.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_utctm.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_utf8.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/a_verify.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/ameth_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/asn1_err.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/asn1_gen.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/asn1_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/asn1_par.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/asn_mime.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/asn_moid.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/asn_pack.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/bio_asn1.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/bio_ndef.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/d2i_pr.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/d2i_pu.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/evp_asn1.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/f_enum.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/f_int.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/f_string.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/i2d_pr.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/i2d_pu.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/n_pkey.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/nsseq.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/p5_pbe.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/p5_pbev2.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/p8_pkey.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/t_bitst.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/t_crl.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/t_pkey.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/t_req.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/t_spki.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/t_x509.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/t_x509a.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/tasn_dec.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/tasn_enc.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/tasn_fre.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/tasn_new.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/tasn_prn.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/tasn_typ.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/tasn_utl.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_algor.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_attrib.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_bignum.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_crl.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_exten.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_info.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_long.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_name.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_nx509.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_pkey.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_pubkey.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_req.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_sig.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_spki.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_val.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_x509.c
    target thumb C: libcrypto <= external/openssl/crypto/asn1/x_x509a.c
    target thumb C: libcrypto <= external/openssl/crypto/bf/bf_cfb64.c
    target thumb C: libcrypto <= external/openssl/crypto/bf/bf_ecb.c
    target thumb C: libcrypto <= external/openssl/crypto/bf/bf_enc.c
    target thumb C: libcrypto <= external/openssl/crypto/bf/bf_ofb64.c
    target thumb C: libcrypto <= external/openssl/crypto/bf/bf_skey.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/b_dump.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/b_print.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/b_sock.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/bf_buff.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/bf_nbio.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/bf_null.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/bio_cb.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/bio_err.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/bio_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/bss_acpt.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/bss_bio.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/bss_conn.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/bss_dgram.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/bss_fd.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/bss_file.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/bss_log.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/bss_mem.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/bss_null.c
    target thumb C: libcrypto <= external/openssl/crypto/bio/bss_sock.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_add.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_asm.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_blind.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_ctx.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_div.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_err.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_exp.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_exp2.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_gcd.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_gf2m.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_kron.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_mod.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_mont.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_mpi.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_mul.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_nist.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_prime.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_print.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_rand.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_recp.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_shift.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_sqr.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_sqrt.c
    target thumb C: libcrypto <= external/openssl/crypto/bn/bn_word.c
    target thumb C: libcrypto <= external/openssl/crypto/buffer/buf_err.c
    target thumb C: libcrypto <= external/openssl/crypto/buffer/buffer.c
    target thumb C: libcrypto <= external/openssl/crypto/comp/c_rle.c
    target thumb C: libcrypto <= external/openssl/crypto/comp/c_zlib.c
    target thumb C: libcrypto <= external/openssl/crypto/comp/comp_err.c
    target thumb C: libcrypto <= external/openssl/crypto/comp/comp_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/conf/conf_api.c
    target thumb C: libcrypto <= external/openssl/crypto/conf/conf_def.c
    target thumb C: libcrypto <= external/openssl/crypto/conf/conf_err.c
    target thumb C: libcrypto <= external/openssl/crypto/conf/conf_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/conf/conf_mall.c
    target thumb C: libcrypto <= external/openssl/crypto/conf/conf_mod.c
    target thumb C: libcrypto <= external/openssl/crypto/conf/conf_sap.c
    target thumb C: libcrypto <= external/openssl/crypto/des/cbc_cksm.c
    target thumb C: libcrypto <= external/openssl/crypto/des/cbc_enc.c
    target thumb C: libcrypto <= external/openssl/crypto/des/cfb64ede.c
    target thumb C: libcrypto <= external/openssl/crypto/des/cfb64enc.c
    target thumb C: libcrypto <= external/openssl/crypto/des/cfb_enc.c
    target thumb C: libcrypto <= external/openssl/crypto/des/des_enc.c
    target thumb C: libcrypto <= external/openssl/crypto/des/des_old.c
    target thumb C: libcrypto <= external/openssl/crypto/des/des_old2.c
    target thumb C: libcrypto <= external/openssl/crypto/des/ecb3_enc.c
    target thumb C: libcrypto <= external/openssl/crypto/des/ecb_enc.c
    target thumb C: libcrypto <= external/openssl/crypto/des/ede_cbcm_enc.c
    target thumb C: libcrypto <= external/openssl/crypto/des/enc_read.c
    target thumb C: libcrypto <= external/openssl/crypto/des/enc_writ.c
    target thumb C: libcrypto <= external/openssl/crypto/des/fcrypt.c
    target thumb C: libcrypto <= external/openssl/crypto/des/fcrypt_b.c
    target thumb C: libcrypto <= external/openssl/crypto/des/ofb64ede.c
    target thumb C: libcrypto <= external/openssl/crypto/des/ofb64enc.c
    target thumb C: libcrypto <= external/openssl/crypto/des/ofb_enc.c
    target thumb C: libcrypto <= external/openssl/crypto/des/pcbc_enc.c
    target thumb C: libcrypto <= external/openssl/crypto/des/qud_cksm.c
    target thumb C: libcrypto <= external/openssl/crypto/des/rand_key.c
    target thumb C: libcrypto <= external/openssl/crypto/des/read2pwd.c
    target thumb C: libcrypto <= external/openssl/crypto/des/rpc_enc.c
    target thumb C: libcrypto <= external/openssl/crypto/des/set_key.c
    target thumb C: libcrypto <= external/openssl/crypto/des/str2key.c
    target thumb C: libcrypto <= external/openssl/crypto/des/xcbc_enc.c
    target thumb C: libcrypto <= external/openssl/crypto/dh/dh_ameth.c
    target thumb C: libcrypto <= external/openssl/crypto/dh/dh_asn1.c
    target thumb C: libcrypto <= external/openssl/crypto/dh/dh_check.c
    target thumb C: libcrypto <= external/openssl/crypto/dh/dh_depr.c
    target thumb C: libcrypto <= external/openssl/crypto/dh/dh_err.c
    target thumb C: libcrypto <= external/openssl/crypto/dh/dh_gen.c
    target thumb C: libcrypto <= external/openssl/crypto/dh/dh_key.c
    target thumb C: libcrypto <= external/openssl/crypto/dh/dh_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/dh/dh_pmeth.c
    target thumb C: libcrypto <= external/openssl/crypto/dsa/dsa_ameth.c
    target thumb C: libcrypto <= external/openssl/crypto/dsa/dsa_asn1.c
    target thumb C: libcrypto <= external/openssl/crypto/dsa/dsa_depr.c
    target thumb C: libcrypto <= external/openssl/crypto/dsa/dsa_err.c
    target thumb C: libcrypto <= external/openssl/crypto/dsa/dsa_gen.c
    target thumb C: libcrypto <= external/openssl/crypto/dsa/dsa_key.c
    target thumb C: libcrypto <= external/openssl/crypto/dsa/dsa_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/dsa/dsa_ossl.c
    target thumb C: libcrypto <= external/openssl/crypto/dsa/dsa_pmeth.c
    target thumb C: libcrypto <= external/openssl/crypto/dsa/dsa_prn.c
    target thumb C: libcrypto <= external/openssl/crypto/dsa/dsa_sign.c
    target thumb C: libcrypto <= external/openssl/crypto/dsa/dsa_vrf.c
    target thumb C: libcrypto <= external/openssl/crypto/dso/dso_dl.c
    target thumb C: libcrypto <= external/openssl/crypto/dso/dso_dlfcn.c
    target thumb C: libcrypto <= external/openssl/crypto/dso/dso_err.c
    target thumb C: libcrypto <= external/openssl/crypto/dso/dso_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/dso/dso_null.c
    target thumb C: libcrypto <= external/openssl/crypto/dso/dso_openssl.c
    target thumb C: libcrypto <= external/openssl/crypto/dso/dso_vms.c
    target thumb C: libcrypto <= external/openssl/crypto/dso/dso_win32.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/ec2_mult.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/ec2_smpl.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/ec_ameth.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/ec_asn1.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/ec_check.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/ec_curve.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/ec_cvt.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/ec_err.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/ec_key.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/ec_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/ec_mult.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/ec_pmeth.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/ec_print.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/eck_prn.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/ecp_mont.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/ecp_nist.c
    target thumb C: libcrypto <= external/openssl/crypto/ec/ecp_smpl.c
    target thumb C: libcrypto <= external/openssl/crypto/ecdh/ech_err.c
    target thumb C: libcrypto <= external/openssl/crypto/ecdh/ech_key.c
    target thumb C: libcrypto <= external/openssl/crypto/ecdh/ech_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/ecdh/ech_ossl.c
    target thumb C: libcrypto <= external/openssl/crypto/ecdsa/ecs_asn1.c
    target thumb C: libcrypto <= external/openssl/crypto/ecdsa/ecs_err.c
    target thumb C: libcrypto <= external/openssl/crypto/ecdsa/ecs_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/ecdsa/ecs_ossl.c
    target thumb C: libcrypto <= external/openssl/crypto/ecdsa/ecs_sign.c
    target thumb C: libcrypto <= external/openssl/crypto/ecdsa/ecs_vrf.c
    target thumb C: libcrypto <= external/openssl/crypto/err/err.c
    target thumb C: libcrypto <= external/openssl/crypto/err/err_all.c
    target thumb C: libcrypto <= external/openssl/crypto/err/err_prn.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/bio_b64.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/bio_enc.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/bio_md.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/bio_ok.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/c_all.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/c_allc.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/c_alld.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/digest.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/e_aes.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/e_bf.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/e_des.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/e_des3.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/e_null.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/e_old.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/e_rc2.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/e_rc4.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/e_rc5.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/e_xcbc_d.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/encode.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/evp_acnf.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/evp_enc.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/evp_err.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/evp_key.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/evp_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/evp_pbe.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/evp_pkey.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/m_dss.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/m_dss1.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/m_ecdsa.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/m_md4.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/m_md5.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/m_mdc2.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/m_null.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/m_ripemd.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/m_sha1.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/m_sigver.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/m_wp.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/names.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/p5_crpt.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/p5_crpt2.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/p_dec.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/p_enc.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/p_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/p_open.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/p_seal.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/p_sign.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/p_verify.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/pmeth_fn.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/pmeth_gn.c
    target thumb C: libcrypto <= external/openssl/crypto/evp/pmeth_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/hmac/hm_ameth.c
    target thumb C: libcrypto <= external/openssl/crypto/hmac/hm_pmeth.c
    target thumb C: libcrypto <= external/openssl/crypto/hmac/hmac.c
    target thumb C: libcrypto <= external/openssl/crypto/krb5/krb5_asn.c
    target thumb C: libcrypto <= external/openssl/crypto/lhash/lh_stats.c
    target thumb C: libcrypto <= external/openssl/crypto/lhash/lhash.c
    target thumb C: libcrypto <= external/openssl/crypto/md4/md4_dgst.c
    target thumb C: libcrypto <= external/openssl/crypto/md4/md4_one.c
    target thumb C: libcrypto <= external/openssl/crypto/md5/md5_dgst.c
    target thumb C: libcrypto <= external/openssl/crypto/md5/md5_one.c
    target thumb C: libcrypto <= external/openssl/crypto/modes/cbc128.c
    target thumb C: libcrypto <= external/openssl/crypto/modes/cfb128.c
    target thumb C: libcrypto <= external/openssl/crypto/modes/ctr128.c
    target thumb C: libcrypto <= external/openssl/crypto/modes/ofb128.c
    target thumb C: libcrypto <= external/openssl/crypto/objects/o_names.c
    target thumb C: libcrypto <= external/openssl/crypto/objects/obj_dat.c
    target thumb C: libcrypto <= external/openssl/crypto/objects/obj_err.c
    target thumb C: libcrypto <= external/openssl/crypto/objects/obj_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/objects/obj_xref.c
    target thumb C: libcrypto <= external/openssl/crypto/ocsp/ocsp_asn.c
    target thumb C: libcrypto <= external/openssl/crypto/ocsp/ocsp_cl.c
    target thumb C: libcrypto <= external/openssl/crypto/ocsp/ocsp_err.c
    target thumb C: libcrypto <= external/openssl/crypto/ocsp/ocsp_ext.c
    target thumb C: libcrypto <= external/openssl/crypto/ocsp/ocsp_ht.c
    target thumb C: libcrypto <= external/openssl/crypto/ocsp/ocsp_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/ocsp/ocsp_prn.c
    target thumb C: libcrypto <= external/openssl/crypto/ocsp/ocsp_srv.c
    target thumb C: libcrypto <= external/openssl/crypto/ocsp/ocsp_vfy.c
    target thumb C: libcrypto <= external/openssl/crypto/pem/pem_all.c
    target thumb C: libcrypto <= external/openssl/crypto/pem/pem_err.c
    target thumb C: libcrypto <= external/openssl/crypto/pem/pem_info.c
    target thumb C: libcrypto <= external/openssl/crypto/pem/pem_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/pem/pem_oth.c
    target thumb C: libcrypto <= external/openssl/crypto/pem/pem_pk8.c
    target thumb C: libcrypto <= external/openssl/crypto/pem/pem_pkey.c
    target thumb C: libcrypto <= external/openssl/crypto/pem/pem_seal.c
    target thumb C: libcrypto <= external/openssl/crypto/pem/pem_sign.c
    target thumb C: libcrypto <= external/openssl/crypto/pem/pem_x509.c
    target thumb C: libcrypto <= external/openssl/crypto/pem/pem_xaux.c
    target thumb C: libcrypto <= external/openssl/crypto/pem/pvkfmt.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs12/p12_add.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs12/p12_asn.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs12/p12_attr.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs12/p12_crpt.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs12/p12_crt.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs12/p12_decr.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs12/p12_init.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs12/p12_key.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs12/p12_kiss.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs12/p12_mutl.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs12/p12_npas.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs12/p12_p8d.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs12/p12_p8e.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs12/p12_utl.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs12/pk12err.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs7/pk7_asn1.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs7/pk7_attr.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs7/pk7_doit.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs7/pk7_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs7/pk7_mime.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs7/pk7_smime.c
    target thumb C: libcrypto <= external/openssl/crypto/pkcs7/pkcs7err.c
    target thumb C: libcrypto <= external/openssl/crypto/rand/md_rand.c
    target thumb C: libcrypto <= external/openssl/crypto/rand/rand_egd.c
    target thumb C: libcrypto <= external/openssl/crypto/rand/rand_err.c
    target thumb C: libcrypto <= external/openssl/crypto/rand/rand_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/rand/rand_unix.c
    target thumb C: libcrypto <= external/openssl/crypto/rand/randfile.c
    target thumb C: libcrypto <= external/openssl/crypto/rc2/rc2_cbc.c
    target thumb C: libcrypto <= external/openssl/crypto/rc2/rc2_ecb.c
    target thumb C: libcrypto <= external/openssl/crypto/rc2/rc2_skey.c
    target thumb C: libcrypto <= external/openssl/crypto/rc2/rc2cfb64.c
    target thumb C: libcrypto <= external/openssl/crypto/rc2/rc2ofb64.c
    target thumb C: libcrypto <= external/openssl/crypto/rc4/rc4_enc.c
    target thumb C: libcrypto <= external/openssl/crypto/rc4/rc4_skey.c
    target thumb C: libcrypto <= external/openssl/crypto/ripemd/rmd_dgst.c
    target thumb C: libcrypto <= external/openssl/crypto/ripemd/rmd_one.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_ameth.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_asn1.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_chk.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_eay.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_err.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_gen.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_none.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_null.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_oaep.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_pk1.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_pmeth.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_prn.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_pss.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_saos.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_sign.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_ssl.c
    target thumb C: libcrypto <= external/openssl/crypto/rsa/rsa_x931.c
    target thumb C: libcrypto <= external/openssl/crypto/sha/sha1_one.c
    target thumb C: libcrypto <= external/openssl/crypto/sha/sha1dgst.c
    target thumb C: libcrypto <= external/openssl/crypto/sha/sha256.c
    target thumb C: libcrypto <= external/openssl/crypto/sha/sha512.c
    target thumb C: libcrypto <= external/openssl/crypto/sha/sha_dgst.c
    target thumb C: libcrypto <= external/openssl/crypto/stack/stack.c
    target thumb C: libcrypto <= external/openssl/crypto/ts/ts_err.c
    target thumb C: libcrypto <= external/openssl/crypto/txt_db/txt_db.c
    target thumb C: libcrypto <= external/openssl/crypto/ui/ui_compat.c
    target thumb C: libcrypto <= external/openssl/crypto/ui/ui_err.c
    target thumb C: libcrypto <= external/openssl/crypto/ui/ui_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/ui/ui_openssl.c
    target thumb C: libcrypto <= external/openssl/crypto/ui/ui_util.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/by_dir.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/by_file.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509_att.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509_cmp.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509_d2.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509_def.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509_err.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509_ext.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509_lu.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509_obj.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509_r2x.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509_req.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509_set.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509_trs.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509_txt.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509_v3.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509_vfy.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509_vpm.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509cset.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509name.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509rset.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509spki.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x509type.c
    target thumb C: libcrypto <= external/openssl/crypto/x509/x_all.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/pcy_cache.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/pcy_data.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/pcy_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/pcy_map.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/pcy_node.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/pcy_tree.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_akey.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_akeya.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_alt.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_bcons.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_bitst.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_conf.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_cpols.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_crld.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_enum.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_extku.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_genn.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_ia5.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_info.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_int.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_lib.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_ncons.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_ocsp.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_pci.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_pcia.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_pcons.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_pku.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_pmaps.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_prn.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_purp.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_skey.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_sxnet.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3_utl.c
    target thumb C: libcrypto <= external/openssl/crypto/x509v3/v3err.c
    target arm C: libz <= external/zlib/adler32.c
    target arm C: libz <= external/zlib/compress.c
    target arm C: libz <= external/zlib/crc32.c
    target arm C: libz <= external/zlib/gzclose.c
    target arm C: libz <= external/zlib/gzlib.c
    target arm C: libz <= external/zlib/gzread.c
    target arm C: libz <= external/zlib/gzwrite.c
    target arm C: libz <= external/zlib/uncompr.c
    target arm C: libz <= external/zlib/deflate.c
    target arm C: libz <= external/zlib/trees.c
    target arm C: libz <= external/zlib/zutil.c
    target arm C: libz <= external/zlib/inflate.c
    target arm C: libz <= external/zlib/infback.c
    target arm C: libz <= external/zlib/inftrees.c
    target arm C: libz <= external/zlib/inffast.c
    target SharedLib: libz (out/target/product/omap3evm/obj/SHARED_LIBRARIES/libz_intermediates/LINKED/libz.so)
    target Prelink: libz (out/target/product/omap3evm/symbols/system/lib/libz.so)
    target Strip: libz (out/target/product/omap3evm/obj/lib/libz.so)
    target SharedLib: libcrypto (out/target/product/omap3evm/obj/SHARED_LIBRARIES/libcrypto_intermediates/LINKED/libcrypto.so)
    target Prelink: libcrypto (out/target/product/omap3evm/symbols/system/lib/libcrypto.so)
    target Strip: libcrypto (out/target/product/omap3evm/obj/lib/libcrypto.so)
    target thumb C++: libicui18n <= external/icu4c/i18n/indiancal.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/dtptngen.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/dtrule.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/persncal.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/rbtz.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/reldtfmt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/taiwncal.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/tzrule.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/tztrans.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/udatpg.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/vtzone.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/anytrans.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/astro.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/buddhcal.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/basictz.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/calendar.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/casetrn.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/choicfmt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/coleitr.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/coll.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/cpdtrans.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/csdetect.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/csmatch.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/csr2022.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/csrecog.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/csrmbcs.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/csrsbcs.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/csrucode.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/csrutf8.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/curramt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/currfmt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/currunit.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/datefmt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/dcfmtsym.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/decimfmt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/digitlst.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/dtfmtsym.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/esctrn.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/fmtable_cnv.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/fmtable.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/format.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/funcrepl.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/gregocal.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/gregoimp.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/hebrwcal.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/inputext.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/islamcal.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/japancal.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/measfmt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/measure.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/msgfmt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/name2uni.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/nfrs.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/nfrule.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/nfsubs.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/nortrans.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/nultrans.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/numfmt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/olsontz.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/quant.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/rbnf.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/rbt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/rbt_data.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/rbt_pars.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/rbt_rule.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/rbt_set.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/regexcmp.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/regexst.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/rematch.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/remtrans.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/repattrn.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/search.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/simpletz.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/smpdtfmt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/sortkey.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/strmatch.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/strrepl.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/stsearch.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/tblcoll.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/timezone.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/titletrn.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/tolowtrn.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/toupptrn.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/translit.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/transreg.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/tridpars.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/ucal.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/ucol_bld.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/ucol_cnt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/ucol.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/ucoleitr.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/ucol_elm.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/ucol_res.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/ucol_sit.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/ucol_tok.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/ucsdet.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/ucurr.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/udat.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/umsg.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/unesctrn.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/uni2name.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/unum.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/uregexc.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/uregex.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/usearch.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/utrans.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/windtfmt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/winnmfmt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/zonemeta.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/zstrfmt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/numsys.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/chnsecal.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/cecal.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/coptccal.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/ethpccal.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/brktrans.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/wintzimpl.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/plurrule.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/plurfmt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/dtitvfmt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/dtitvinf.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/tmunit.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/tmutamt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/tmutfmt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/colldata.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/bmsearch.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/bms.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/currpinf.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/uspoof.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/uspoof_impl.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/uspoof_build.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/regextxt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/selfmt.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/uspoof_conf.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/uspoof_wsconf.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/ztrans.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/zrule.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/vzone.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/fphdlimp.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/fpositer.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/locdspnm.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/decnumstr.cpp
    target thumb C++: libicui18n <= external/icu4c/i18n/ucol_wgt.cpp
    target thumb C: libicui18n <= external/icu4c/i18n/bocsu.c
    target thumb C: libicui18n <= external/icu4c/i18n/ucln_in.c
    target thumb C: libicui18n <= external/icu4c/i18n/decContext.c
    target thumb C: libicui18n <= external/icu4c/i18n/ulocdata.c
    target thumb C: libicui18n <= external/icu4c/i18n/utmscale.c
    target thumb C: libicui18n <= external/icu4c/i18n/decNumber.c
    target thumb C++: libicuuc <= external/icu4c/common/bmpset.cpp
    target thumb C++: libicuuc <= external/icu4c/common/unisetspan.cpp
    target thumb C++: libicuuc <= external/icu4c/common/brkeng.cpp
    target thumb C++: libicuuc <= external/icu4c/common/brkiter.cpp
    target thumb C++: libicuuc <= external/icu4c/common/caniter.cpp
    target thumb C++: libicuuc <= external/icu4c/common/chariter.cpp
    target thumb C++: libicuuc <= external/icu4c/common/dictbe.cpp
    target thumb C++: libicuuc <= external/icu4c/common/locbased.cpp
    target thumb C++: libicuuc <= external/icu4c/common/locid.cpp
    target thumb C++: libicuuc <= external/icu4c/common/locutil.cpp
    target thumb C++: libicuuc <= external/icu4c/common/normlzr.cpp
    target thumb C++: libicuuc <= external/icu4c/common/parsepos.cpp
    target thumb C++: libicuuc <= external/icu4c/common/propname.cpp
    target thumb C++: libicuuc <= external/icu4c/common/rbbi.cpp
    target thumb C++: libicuuc <= external/icu4c/common/rbbidata.cpp
    target thumb C++: libicuuc <= external/icu4c/common/rbbinode.cpp
    target thumb C++: libicuuc <= external/icu4c/common/rbbirb.cpp
    target thumb C++: libicuuc <= external/icu4c/common/rbbiscan.cpp
    target thumb C++: libicuuc <= external/icu4c/common/rbbisetb.cpp
    target thumb C++: libicuuc <= external/icu4c/common/rbbistbl.cpp
    target thumb C++: libicuuc <= external/icu4c/common/rbbitblb.cpp
    target thumb C++: libicuuc <= external/icu4c/common/resbund_cnv.cpp
    target thumb C++: libicuuc <= external/icu4c/common/resbund.cpp
    target thumb C++: libicuuc <= external/icu4c/common/ruleiter.cpp
    target thumb C++: libicuuc <= external/icu4c/common/schriter.cpp
    target thumb C++: libicuuc <= external/icu4c/common/serv.cpp
    target thumb C++: libicuuc <= external/icu4c/common/servlk.cpp
    target thumb C++: libicuuc <= external/icu4c/common/servlkf.cpp
    target thumb C++: libicuuc <= external/icu4c/common/servls.cpp
    target thumb C++: libicuuc <= external/icu4c/common/servnotf.cpp
    target thumb C++: libicuuc <= external/icu4c/common/servrbf.cpp
    target thumb C++: libicuuc <= external/icu4c/common/servslkf.cpp
    target thumb C++: libicuuc <= external/icu4c/common/triedict.cpp
    target thumb C++: libicuuc <= external/icu4c/common/ubrk.cpp
    target thumb C++: libicuuc <= external/icu4c/common/uchriter.cpp
    target thumb C++: libicuuc <= external/icu4c/common/uhash_us.cpp
    target thumb C++: libicuuc <= external/icu4c/common/uidna.cpp
    target thumb C++: libicuuc <= external/icu4c/common/uiter.cpp
    target thumb C++: libicuuc <= external/icu4c/common/unifilt.cpp
    target thumb C++: libicuuc <= external/icu4c/common/unifunct.cpp
    target thumb C++: libicuuc <= external/icu4c/common/uniset.cpp
    target thumb C++: libicuuc <= external/icu4c/common/uniset_props.cpp
    target thumb C++: libicuuc <= external/icu4c/common/unistr_case.cpp
    target thumb C++: libicuuc <= external/icu4c/common/unistr_cnv.cpp
    target thumb C++: libicuuc <= external/icu4c/common/unistr.cpp
    target thumb C++: libicuuc <= external/icu4c/common/unistr_props.cpp
    target thumb C++: libicuuc <= external/icu4c/common/unormcmp.cpp
    target thumb C++: libicuuc <= external/icu4c/common/unorm.cpp
    target thumb C++: libicuuc <= external/icu4c/common/uobject.cpp
    target thumb C++: libicuuc <= external/icu4c/common/uset.cpp
    target thumb C++: libicuuc <= external/icu4c/common/usetiter.cpp
    target thumb C++: libicuuc <= external/icu4c/common/uset_props.cpp
    target thumb C++: libicuuc <= external/icu4c/common/usprep.cpp
    target thumb C++: libicuuc <= external/icu4c/common/ustack.cpp
    target thumb C++: libicuuc <= external/icu4c/common/ustrenum.cpp
    target thumb C++: libicuuc <= external/icu4c/common/utext.cpp
    target thumb C++: libicuuc <= external/icu4c/common/util.cpp
    target thumb C++: libicuuc <= external/icu4c/common/util_props.cpp
    target thumb C++: libicuuc <= external/icu4c/common/uvector.cpp
    target thumb C++: libicuuc <= external/icu4c/common/uvectr32.cpp
    target thumb C++: libicuuc <= external/icu4c/common/errorcode.cpp
    target thumb C++: libicuuc <= external/icu4c/common/bytestream.cpp
    target thumb C++: libicuuc <= external/icu4c/common/stringpiece.cpp
    target thumb C++: libicuuc <= external/icu4c/common/mutex.cpp
    target thumb C++: libicuuc <= external/icu4c/common/dtintrv.cpp
    target thumb C++: libicuuc <= external/icu4c/common/ucnvsel.cpp
    target thumb C++: libicuuc <= external/icu4c/common/uvectr64.cpp
    target thumb C++: libicuuc <= external/icu4c/common/locavailable.cpp
    target thumb C++: libicuuc <= external/icu4c/common/locdispnames.cpp
    target thumb C++: libicuuc <= external/icu4c/common/loclikely.cpp
    target thumb C++: libicuuc <= external/icu4c/common/locresdata.cpp
    target thumb C++: libicuuc <= external/icu4c/common/normalizer2impl.cpp
    target thumb C++: libicuuc <= external/icu4c/common/normalizer2.cpp
    target thumb C++: libicuuc <= external/icu4c/common/filterednormalizer2.cpp
    target thumb C++: libicuuc <= external/icu4c/common/ucol_swp.cpp
    target thumb C++: libicuuc <= external/icu4c/common/uprops.cpp
    target thumb C++: libicuuc <= external/icu4c/common/utrie2.cpp
    target thumb C: libicuuc <= external/icu4c/common/cmemory.c
    target thumb C: libicuuc <= external/icu4c/common/cstring.c
    target thumb C: libicuuc <= external/icu4c/common/cwchar.c
    target thumb C: libicuuc <= external/icu4c/common/locmap.c
    target thumb C: libicuuc <= external/icu4c/common/punycode.c
    target thumb C: libicuuc <= external/icu4c/common/putil.c
    target thumb C: libicuuc <= external/icu4c/common/uarrsort.c
    target thumb C: libicuuc <= external/icu4c/common/ubidi.c
    target thumb C: libicuuc <= external/icu4c/common/ubidiln.c
    target thumb C: libicuuc <= external/icu4c/common/ubidi_props.c
    target thumb C: libicuuc <= external/icu4c/common/ubidiwrt.c
    target thumb C: libicuuc <= external/icu4c/common/ucase.c
    target thumb C: libicuuc <= external/icu4c/common/ucasemap.c
    target thumb C: libicuuc <= external/icu4c/common/ucat.c
    target thumb C: libicuuc <= external/icu4c/common/uchar.c
    target thumb C: libicuuc <= external/icu4c/common/ucln_cmn.c
    target thumb C: libicuuc <= external/icu4c/common/ucmndata.c
    target thumb C: libicuuc <= external/icu4c/common/ucnv2022.c
    target thumb C: libicuuc <= external/icu4c/common/ucnv_bld.c
    target thumb C: libicuuc <= external/icu4c/common/ucnvbocu.c
    target thumb C: libicuuc <= external/icu4c/common/ucnv.c
    target thumb C: libicuuc <= external/icu4c/common/ucnv_cb.c
    target thumb C: libicuuc <= external/icu4c/common/ucnv_cnv.c
    target thumb C: libicuuc <= external/icu4c/common/ucnvdisp.c
    target thumb C: libicuuc <= external/icu4c/common/ucnv_err.c
    target thumb C: libicuuc <= external/icu4c/common/ucnv_ext.c
    target thumb C: libicuuc <= external/icu4c/common/ucnvhz.c
    target thumb C: libicuuc <= external/icu4c/common/ucnv_io.c
    target thumb C: libicuuc <= external/icu4c/common/ucnvisci.c
    target thumb C: libicuuc <= external/icu4c/common/ucnvlat1.c
    target thumb C: libicuuc <= external/icu4c/common/ucnv_lmb.c
    target thumb C: libicuuc <= external/icu4c/common/ucnvmbcs.c
    target thumb C: libicuuc <= external/icu4c/common/ucnvscsu.c
    target thumb C: libicuuc <= external/icu4c/common/ucnv_set.c
    target thumb C: libicuuc <= external/icu4c/common/ucnv_u16.c
    target thumb C: libicuuc <= external/icu4c/common/ucnv_u32.c
    target thumb C: libicuuc <= external/icu4c/common/ucnv_u7.c
    target thumb C: libicuuc <= external/icu4c/common/ucnv_u8.c
    target thumb C: libicuuc <= external/icu4c/common/udata.c
    target thumb C: libicuuc <= external/icu4c/common/udatamem.c
    target thumb C: libicuuc <= external/icu4c/common/udataswp.c
    target thumb C: libicuuc <= external/icu4c/common/uenum.c
    target thumb C: libicuuc <= external/icu4c/common/uhash.c
    target thumb C: libicuuc <= external/icu4c/common/uinit.c
    target thumb C: libicuuc <= external/icu4c/common/uinvchar.c
    target thumb C: libicuuc <= external/icu4c/common/uloc.c
    target thumb C: libicuuc <= external/icu4c/common/umapfile.c
    target thumb C: libicuuc <= external/icu4c/common/umath.c
    target thumb C: libicuuc <= external/icu4c/common/umutex.c
    target thumb C: libicuuc <= external/icu4c/common/unames.c
    target thumb C: libicuuc <= external/icu4c/common/unorm_it.c
    target thumb C: libicuuc <= external/icu4c/common/uresbund.c
    target thumb C: libicuuc <= external/icu4c/common/ures_cnv.c
    target thumb C: libicuuc <= external/icu4c/common/uresdata.c
    target thumb C: libicuuc <= external/icu4c/common/usc_impl.c
    target thumb C: libicuuc <= external/icu4c/common/uscript.c
    target thumb C: libicuuc <= external/icu4c/common/ushape.c
    target thumb C: libicuuc <= external/icu4c/common/ustrcase.c
    target thumb C: libicuuc <= external/icu4c/common/ustr_cnv.c
    target thumb C: libicuuc <= external/icu4c/common/ustrfmt.c
    target thumb C: libicuuc <= external/icu4c/common/ustring.c
    target thumb C: libicuuc <= external/icu4c/common/ustrtrns.c
    target thumb C: libicuuc <= external/icu4c/common/ustr_wcs.c
    target thumb C: libicuuc <= external/icu4c/common/utf_impl.c
    target thumb C: libicuuc <= external/icu4c/common/utrace.c
    target thumb C: libicuuc <= external/icu4c/common/utrie.c
    target thumb C: libicuuc <= external/icu4c/common/utypes.c
    target thumb C: libicuuc <= external/icu4c/common/wintz.c
    target thumb C: libicuuc <= external/icu4c/common/utrie2_builder.c
    target thumb C: libicuuc <= external/icu4c/common/icuplug.c
    target thumb C: libicuuc <= external/icu4c/common/propsvec.c
    target thumb C: libicuuc <= external/icu4c/common/ulist.c
    target thumb C: libicuuc <= external/icu4c/common/uloc_tag.c
    target thumb C: libicuuc <= external/icu4c/common/../stubdata/stubdata.c
    target SharedLib: libicuuc (out/target/product/omap3evm/obj/SHARED_LIBRARIES/libicuuc_intermediates/LINKED/libicuuc.so)
    target Prelink: libicuuc (out/target/product/omap3evm/symbols/system/lib/libicuuc.so)
    target Strip: libicuuc (out/target/product/omap3evm/obj/lib/libicuuc.so)
    target SharedLib: libicui18n (out/target/product/omap3evm/obj/SHARED_LIBRARIES/libicui18n_intermediates/LINKED/libicui18n.so)
    target Prelink: libicui18n (out/target/product/omap3evm/symbols/system/lib/libicui18n.so)
    target Strip: libicui18n (out/target/product/omap3evm/obj/lib/libicui18n.so)
    target thumb C: libsqlite <= external/sqlite/dist/sqlite3.c
    target thumb C++: libutils <= frameworks/base/libs/utils/Asset.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/AssetDir.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/AssetManager.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/BufferedTextOutput.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/CallStack.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/Debug.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/FileMap.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/Flattenable.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/ObbFile.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/Pool.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/RefBase.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/ResourceTypes.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/SharedBuffer.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/Static.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/StopWatch.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/StreamingZipInflater.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/String8.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/String16.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/StringArray.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/SystemClock.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/TextOutput.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/Threads.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/Timers.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/VectorImpl.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/ZipFileCRO.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/ZipFileRO.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/ZipUtils.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/misc.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/BackupData.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/BackupHelpers.cpp
    target thumb C++: libutils <= frameworks/base/libs/utils/Looper.cpp
    target SharedLib: libutils (out/target/product/omap3evm/obj/SHARED_LIBRARIES/libutils_intermediates/LINKED/libutils.so)
    target Prelink: libutils (out/target/product/omap3evm/symbols/system/lib/libutils.so)
    target Strip: libutils (out/target/product/omap3evm/obj/lib/libutils.so)
    target thumb C++: libsqlite3_android <= external/sqlite/android/PhoneNumberUtils.cpp
    target thumb C++: libsqlite3_android <= external/sqlite/android/PhoneticStringUtils.cpp
    target thumb C++: libsqlite3_android <= external/sqlite/android/OldPhoneNumberUtils.cpp
    target thumb C++: libsqlite3_android <= external/sqlite/android/PhonebookIndex.cpp
    target thumb C++: libsqlite3_android <= external/sqlite/android/sqlite3_android.cpp
    target StaticLib: libsqlite3_android (out/target/product/omap3evm/obj/STATIC_LIBRARIES/libsqlite3_android_intermediates/libsqlite3_android.a)
    target SharedLib: libsqlite (out/target/product/omap3evm/obj/SHARED_LIBRARIES/libsqlite_intermediates/LINKED/libsqlite.so)
    target Prelink: libsqlite (out/target/product/omap3evm/symbols/system/lib/libsqlite.so)
    target Strip: libsqlite (out/target/product/omap3evm/obj/lib/libsqlite.so)
    target thumb C: libssl <= external/openssl/ssl/s2_meth.c
    target thumb C: libssl <= external/openssl/ssl/s2_srvr.c
    target thumb C: libssl <= external/openssl/ssl/s2_clnt.c
    target thumb C: libssl <= external/openssl/ssl/s2_lib.c
    target thumb C: libssl <= external/openssl/ssl/s2_enc.c
    target thumb C: libssl <= external/openssl/ssl/s2_pkt.c
    target thumb C: libssl <= external/openssl/ssl/s3_meth.c
    target thumb C: libssl <= external/openssl/ssl/s3_srvr.c
    target thumb C: libssl <= external/openssl/ssl/s3_clnt.c
    target thumb C: libssl <= external/openssl/ssl/s3_lib.c
    target thumb C: libssl <= external/openssl/ssl/s3_enc.c
    target thumb C: libssl <= external/openssl/ssl/s3_pkt.c
    target thumb C: libssl <= external/openssl/ssl/s3_both.c
    target thumb C: libssl <= external/openssl/ssl/s23_meth.c
    target thumb C: libssl <= external/openssl/ssl/s23_srvr.c
    target thumb C: libssl <= external/openssl/ssl/s23_clnt.c
    target thumb C: libssl <= external/openssl/ssl/s23_lib.c
    target thumb C: libssl <= external/openssl/ssl/s23_pkt.c
    target thumb C: libssl <= external/openssl/ssl/t1_meth.c
    target thumb C: libssl <= external/openssl/ssl/t1_srvr.c
    target thumb C: libssl <= external/openssl/ssl/t1_clnt.c
    target thumb C: libssl <= external/openssl/ssl/t1_lib.c
    target thumb C: libssl <= external/openssl/ssl/t1_enc.c
    target thumb C: libssl <= external/openssl/ssl/t1_reneg.c
    target thumb C: libssl <= external/openssl/ssl/ssl_lib.c
    target thumb C: libssl <= external/openssl/ssl/ssl_err2.c
    target thumb C: libssl <= external/openssl/ssl/ssl_cert.c
    target thumb C: libssl <= external/openssl/ssl/ssl_sess.c
    target thumb C: libssl <= external/openssl/ssl/ssl_ciph.c
    target thumb C: libssl <= external/openssl/ssl/ssl_stat.c
    target thumb C: libssl <= external/openssl/ssl/ssl_rsa.c
    target thumb C: libssl <= external/openssl/ssl/ssl_asn1.c
    target thumb C: libssl <= external/openssl/ssl/ssl_txt.c
    target thumb C: libssl <= external/openssl/ssl/ssl_algs.c
    target thumb C: libssl <= external/openssl/ssl/bio_ssl.c
    target thumb C: libssl <= external/openssl/ssl/ssl_err.c
    target thumb C: libssl <= external/openssl/ssl/kssl.c
    target SharedLib: libssl (out/target/product/omap3evm/obj/SHARED_LIBRARIES/libssl_intermediates/LINKED/libssl.so)
    target Prelink: libssl (out/target/product/omap3evm/symbols/system/lib/libssl.so)
    target Strip: libssl (out/target/product/omap3evm/obj/lib/libssl.so)
    target thumb C: libexpat <= external/expat/lib/xmlparse.c
    target thumb C: libexpat <= external/expat/lib/xmlrole.c
    target thumb C: libexpat <= external/expat/lib/xmltok.c
    target SharedLib: libexpat (out/target/product/omap3evm/obj/SHARED_LIBRARIES/libexpat_intermediates/LINKED/libexpat.so)
    target Prelink: libexpat (out/target/product/omap3evm/symbols/system/lib/libexpat.so)
    target Strip: libexpat (out/target/product/omap3evm/obj/lib/libexpat.so)
    target thumb C++: libjavacore <= libcore/dalvik/src/main/native/dalvik_system_TouchDex.cpp
    target thumb C++: libjavacore <= libcore/dalvik/src/main/native/org_apache_harmony_dalvik_NativeTestTarget.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/AsynchronousSocketCloseMonitor.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/ErrorCode.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/ICU.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/JniConstants.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/JniException.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/NativeBN.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/NativeBidi.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/NativeBreakIterator.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/NativeCollation.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/NativeConverter.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/NativeCrypto.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/NativeDecimalFormat.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/NativeIDN.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/NativeNormalizer.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/NativePluralRules.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/NetworkUtilities.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/Register.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/TimeZones.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/cbigint.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_io_Console.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_io_File.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_io_FileDescriptor.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_io_ObjectInputStream.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_io_ObjectOutputStream.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_io_ObjectStreamClass.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_lang_Character.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_lang_Double.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_lang_Float.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_lang_Math.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_lang_ProcessManager.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_lang_RealToString.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_lang_StrictMath.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_lang_System.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_net_InetAddress.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_net_NetworkInterface.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_nio_ByteOrder.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_nio_charset_Charsets.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_util_regex_Matcher.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_util_regex_Pattern.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_util_zip_Adler32.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_util_zip_CRC32.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_util_zip_Deflater.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/java_util_zip_Inflater.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/libcore_io_IoUtils.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/org_apache_harmony_luni_platform_OSFileSystem.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/org_apache_harmony_luni_platform_OSMemory.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/org_apache_harmony_luni_platform_OSNetworkSystem.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/org_apache_harmony_luni_util_FloatingPointParser.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/org_apache_harmony_xml_ExpatParser.cpp
    target thumb C++: libjavacore <= libcore/luni/src/main/native/valueOf.cpp
    target StaticLib: libjavacore (out/target/product/omap3evm/obj/STATIC_LIBRARIES/libjavacore_intermediates/libjavacore.a)
    target thumb C: libfdlibm <= external/fdlibm/k_standard.c
    target thumb C: libfdlibm <= external/fdlibm/k_rem_pio2.c
    target thumb C: libfdlibm <= external/fdlibm/k_cos.c
    target thumb C: libfdlibm <= external/fdlibm/k_sin.c
    target thumb C: libfdlibm <= external/fdlibm/k_tan.c
    target thumb C: libfdlibm <= external/fdlibm/e_acos.c
    target thumb C: libfdlibm <= external/fdlibm/e_acosh.c
    target thumb C: libfdlibm <= external/fdlibm/e_asin.c
    target thumb C: libfdlibm <= external/fdlibm/e_atan2.c
    target thumb C: libfdlibm <= external/fdlibm/e_atanh.c
    target thumb C: libfdlibm <= external/fdlibm/e_cosh.c
    target thumb C: libfdlibm <= external/fdlibm/e_exp.c
    target thumb C: libfdlibm <= external/fdlibm/e_fmod.c
    target thumb C: libfdlibm <= external/fdlibm/e_gamma.c
    target thumb C: libfdlibm <= external/fdlibm/e_gamma_r.c
    target thumb C: libfdlibm <= external/fdlibm/e_hypot.c
    target thumb C: libfdlibm <= external/fdlibm/e_j0.c
    target thumb C: libfdlibm <= external/fdlibm/e_j1.c
    target thumb C: libfdlibm <= external/fdlibm/e_jn.c
    target thumb C: libfdlibm <= external/fdlibm/e_lgamma.c
    target thumb C: libfdlibm <= external/fdlibm/e_lgamma_r.c
    target thumb C: libfdlibm <= external/fdlibm/e_log.c
    target thumb C: libfdlibm <= external/fdlibm/e_log10.c
    target thumb C: libfdlibm <= external/fdlibm/e_pow.c
    target thumb C: libfdlibm <= external/fdlibm/e_rem_pio2.c
    target thumb C: libfdlibm <= external/fdlibm/e_remainder.c
    target thumb C: libfdlibm <= external/fdlibm/e_scalb.c
    target thumb C: libfdlibm <= external/fdlibm/e_sinh.c
    target thumb C: libfdlibm <= external/fdlibm/e_sqrt.c
    target thumb C: libfdlibm <= external/fdlibm/w_acos.c
    target thumb C: libfdlibm <= external/fdlibm/w_acosh.c
    target thumb C: libfdlibm <= external/fdlibm/w_asin.c
    target thumb C: libfdlibm <= external/fdlibm/w_atan2.c
    target thumb C: libfdlibm <= external/fdlibm/w_atanh.c
    target thumb C: libfdlibm <= external/fdlibm/w_cosh.c
    target thumb C: libfdlibm <= external/fdlibm/w_exp.c
    target thumb C: libfdlibm <= external/fdlibm/w_fmod.c
    target thumb C: libfdlibm <= external/fdlibm/w_gamma.c
    target thumb C: libfdlibm <= external/fdlibm/w_gamma_r.c
    target thumb C: libfdlibm <= external/fdlibm/w_hypot.c
    target thumb C: libfdlibm <= external/fdlibm/w_j0.c
    target thumb C: libfdlibm <= external/fdlibm/w_j1.c
    target thumb C: libfdlibm <= external/fdlibm/w_jn.c
    target thumb C: libfdlibm <= external/fdlibm/w_lgamma.c
    target thumb C: libfdlibm <= external/fdlibm/w_lgamma_r.c
    target thumb C: libfdlibm <= external/fdlibm/w_log.c
    target thumb C: libfdlibm <= external/fdlibm/w_log10.c
    target thumb C: libfdlibm <= external/fdlibm/w_pow.c
    target thumb C: libfdlibm <= external/fdlibm/w_remainder.c
    target thumb C: libfdlibm <= external/fdlibm/w_scalb.c
    target thumb C: libfdlibm <= external/fdlibm/w_sinh.c
    target thumb C: libfdlibm <= external/fdlibm/w_sqrt.c
    target thumb C: libfdlibm <= external/fdlibm/s_asinh.c
    target thumb C: libfdlibm <= external/fdlibm/s_atan.c
    target thumb C: libfdlibm <= external/fdlibm/s_cbrt.c
    target thumb C: libfdlibm <= external/fdlibm/s_ceil.c
    target thumb C: libfdlibm <= external/fdlibm/s_copysign.c
    target thumb C: libfdlibm <= external/fdlibm/s_cos.c
    target thumb C: libfdlibm <= external/fdlibm/s_erf.c
    target thumb C: libfdlibm <= external/fdlibm/s_expm1.c
    target thumb C: libfdlibm <= external/fdlibm/s_fabs.c
    target thumb C: libfdlibm <= external/fdlibm/s_finite.c
    target thumb C: libfdlibm <= external/fdlibm/s_floor.c
    target thumb C: libfdlibm <= external/fdlibm/s_frexp.c
    target thumb C: libfdlibm <= external/fdlibm/s_ilogb.c
    target thumb C: libfdlibm <= external/fdlibm/s_isnan.c
    target thumb C: libfdlibm <= external/fdlibm/s_ldexp.c
    target thumb C: libfdlibm <= external/fdlibm/s_lib_version.c
    target thumb C: libfdlibm <= external/fdlibm/s_log1p.c
    target thumb C: libfdlibm <= external/fdlibm/s_logb.c
    target thumb C: libfdlibm <= external/fdlibm/s_matherr.c
    target thumb C: libfdlibm <= external/fdlibm/s_modf.c
    target thumb C: libfdlibm <= external/fdlibm/s_nextafter.c
    target thumb C: libfdlibm <= external/fdlibm/s_rint.c
    target thumb C: libfdlibm <= external/fdlibm/s_scalbn.c
    target thumb C: libfdlibm <= external/fdlibm/s_signgam.c
    target thumb C: libfdlibm <= external/fdlibm/s_significand.c
    target thumb C: libfdlibm <= external/fdlibm/s_sin.c
    target thumb C: libfdlibm <= external/fdlibm/s_tan.c
    target thumb C: libfdlibm <= external/fdlibm/s_tanh.c
    target StaticLib: libfdlibm (out/target/product/omap3evm/obj/STATIC_LIBRARIES/libfdlibm_intermediates/libfdlibm.a)
    target SharedLib: libnativehelper (out/target/product/omap3evm/obj/SHARED_LIBRARIES/libnativehelper_intermediates/LINKED/libnativehelper.so)
    target Prelink: libnativehelper (out/target/product/omap3evm/symbols/system/lib/libnativehelper.so)
    target Strip: libnativehelper (out/target/product/omap3evm/obj/lib/libnativehelper.so)
    target thumb C: libdex <= dalvik/libdex/CmdUtils.c
    target thumb C: libdex <= dalvik/libdex/DexCatch.c
    target thumb C: libdex <= dalvik/libdex/DexClass.c
    target thumb C: libdex <= dalvik/libdex/DexDataMap.c
    target thumb C: libdex <= dalvik/libdex/DexFile.c
    target thumb C: libdex <= dalvik/libdex/DexInlines.c
    target thumb C: libdex <= dalvik/libdex/DexOptData.c
    target thumb C: libdex <= dalvik/libdex/DexProto.c
    target thumb C: libdex <= dalvik/libdex/DexSwapVerify.c
    target thumb C: libdex <= dalvik/libdex/InstrUtils.c
    target thumb C: libdex <= dalvik/libdex/Leb128.c
    target thumb C: libdex <= dalvik/libdex/OpCodeNames.c
    target thumb C: libdex <= dalvik/libdex/OptInvocation.c
    target thumb C: libdex <= dalvik/libdex/sha1.c
    target thumb C: libdex <= dalvik/libdex/SysUtil.c
    target thumb C: libdex <= dalvik/libdex/ZipArchive.c
    target StaticLib: libdex (out/target/product/omap3evm/obj/STATIC_LIBRARIES/libdex_intermediates/libdex.a)
    target SharedLib: libdvm (out/target/product/omap3evm/obj/SHARED_LIBRARIES/libdvm_intermediates/LINKED/libdvm.so)
    target Non-prelinked: libdvm (out/target/product/omap3evm/symbols/system/lib/libdvm.so)
    target Strip: libdvm (out/target/product/omap3evm/obj/lib/libdvm.so)
    prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-gcc -mthumb-interwork -Ibionic/libc/private -o out/target/product/omap3evm/obj/lib/crtend_android.o -c bionic/libc/arch-arm/bionic/crtend.S
    target Executable: dalvikvm (out/target/product/omap3evm/obj/EXECUTABLES/dalvikvm_intermediates/LINKED/dalvikvm)
    target Non-prelinked: dalvikvm (out/target/product/omap3evm/symbols/system/bin/dalvikvm)
    target Strip: dalvikvm (out/target/product/omap3evm/obj/EXECUTABLES/dalvikvm_intermediates/dalvikvm)
    Notice file: system/core/liblog/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/liblog.so.txt
    Notice file: bionic/libc/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/libc.so.txt
    Notice file: bionic/libdl/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/libdl.so.txt
    Install: out/target/product/omap3evm/system/lib/libdl.so
    Notice file: bionic/libc/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/libc_common.a.txt
    Install: out/target/product/omap3evm/system/lib/libc.so
    Notice file: bionic/libstdc++/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/libstdc++.so.txt
    Install: out/target/product/omap3evm/system/lib/libstdc++.so
    Notice file: bionic/libm/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/libm.so.txt
    Install: out/target/product/omap3evm/system/lib/libm.so
    Notice file: system/core/liblog/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/liblog.a.txt
    Install: out/target/product/omap3evm/system/lib/liblog.so
    Notice file: system/core/libcutils/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/libcutils.so.txt
    Notice file: system/core/libcutils/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/libcutils.a.txt
    Install: out/target/product/omap3evm/system/lib/libcutils.so
    Notice file: dalvik/libnativehelper/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/libnativehelper.so.txt
    Notice file: external/zlib/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/libz.so.txt
    Install: out/target/product/omap3evm/system/lib/libz.so
    Install: out/target/product/omap3evm/system/lib/libcrypto.so
    Install: out/target/product/omap3evm/system/lib/libicuuc.so
    Install: out/target/product/omap3evm/system/lib/libicui18n.so
    Notice file: external/sqlite/dist/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/libsqlite.so.txt
    Notice file: frameworks/base/libs/utils/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/libutils.so.txt
    Install: out/target/product/omap3evm/system/lib/libutils.so
    Notice file: external/sqlite/android/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/libsqlite3_android.a.txt
    Install: out/target/product/omap3evm/system/lib/libsqlite.so
    Install: out/target/product/omap3evm/system/lib/libssl.so
    Notice file: external/expat/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/libexpat.so.txt
    Install: out/target/product/omap3evm/system/lib/libexpat.so
    Notice file: libcore/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/libjavacore.a.txt
    Notice file: external/fdlibm/NOTICE -- out/target/product/omap3evm/obj/NOTICE_FILES/src//system/lib/libfdlibm.a.txt
    Install: out/target/product/omap3evm/system/lib/libnativehelper.so
    Install: out/target/product/omap3evm/system/lib/libdvm.so
    Install: out/target/product/omap3evm/system/bin/dalvikvm
    Copy: dx-tests (out/host/linux-x86/obj/EXECUTABLES/dx-tests_intermediates/dx-tests)
    building dx-test-suite
    tmp/intermediates dir (rel): out/host/linux-x86/obj/EXECUTABLES/dx-tests_intermediates
    compiling all java files (with package dxc.junit.**)
    compiling all jasmin (*.j)
    compiling all .cfh files into .class files
    generating Main_*.java files reading from cts/tools/dx-tests writing to out/host/linux-x86/obj/EXECUTABLES/dx-tests_intermediates/mainfiles
    using java src:cts/tools/dx-tests/src
    Collecting all junit tests...
    Time: 0.017
    OK (0 tests)
    collected 2048 test methods in 216 junit test classes
    compile the Main_*.java files
    dxconverter test suite sucessfully built!
    intermediate Main_*.java files (for stacktrace analysis) can be found under out/host/linux-x86/obj/EXECUTABLES/dx-tests_intermediates/mainfiles
    Install: out/host/linux-x86/bin/dx-tests
    Yacc: edify <= bootable/recovery/edify/parser.y
    bison -d -v -o out/host/linux-x86/obj/EXECUTABLES/edify_intermediates/parser.cpp bootable/recovery/edify/parser.y
    touch out/host/linux-x86/obj/EXECUTABLES/edify_intermediates/parser.hpp
    echo '#ifndef 'parser_h > out/host/linux-x86/obj/EXECUTABLES/edify_intermediates/parser.h
    echo '#define 'parser_h >> out/host/linux-x86/obj/EXECUTABLES/edify_intermediates/parser.h
    cat out/host/linux-x86/obj/EXECUTABLES/edify_intermediates/parser.hpp >> out/host/linux-x86/obj/EXECUTABLES/edify_intermediates/parser.h
    echo '#endif' >> out/host/linux-x86/obj/EXECUTABLES/edify_intermediates/parser.h
    rm -f out/host/linux-x86/obj/EXECUTABLES/edify_intermediates/parser.hpp
    host C: edify <= bootable/recovery/edify/expr.c
    host C: edify <= bootable/recovery/edify/main.c
    host C++: edify <= out/host/linux-x86/obj/EXECUTABLES/edify_intermediates/parser.cpp
    Lex: edify <= bootable/recovery/edify/lexer.l
    host C++: edify <= out/host/linux-x86/obj/EXECUTABLES/edify_intermediates/lexer.cpp
    host Executable: edify (out/host/linux-x86/obj/EXECUTABLES/edify_intermediates/edify)
    true
    Install: out/host/linux-x86/bin/edify
    target Generated: emulator <= external/qemu/qemu-options.hx
    target Generated: emulator <= external/qemu/qemu-monitor.hx
    target Generated: emulator <= external/qemu/gdb-xml/arm-core.xml
    host C: emulator <= external/qemu/distrib/zlib-1.2.3/adler32.c
    host C: emulator <= external/qemu/distrib/zlib-1.2.3/compress.c
    host C: emulator <= external/qemu/distrib/zlib-1.2.3/crc32.c
    host C: emulator <= external/qemu/distrib/zlib-1.2.3/deflate.c
    host C: emulator <= external/qemu/distrib/zlib-1.2.3/gzio.c
    host C: emulator <= external/qemu/distrib/zlib-1.2.3/infback.c
    host C: emulator <= external/qemu/distrib/zlib-1.2.3/inffast.c
    host C: emulator <= external/qemu/distrib/zlib-1.2.3/inflate.c
    host C: emulator <= external/qemu/distrib/zlib-1.2.3/inftrees.c
    host C: emulator <= external/qemu/distrib/zlib-1.2.3/trees.c
    host C: emulator <= external/qemu/distrib/zlib-1.2.3/uncompr.c
    host C: emulator <= external/qemu/distrib/zlib-1.2.3/zutil.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/png.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/pngerror.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/pngget.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/pngmem.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/pngpread.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/pngread.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/pngrio.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/pngrtran.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/pngrutil.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/pngset.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/pngtrans.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/pngvcrd.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/pngwio.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/pngwrite.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/pngwtran.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/pngwutil.c
    host C: emulator <= external/qemu/distrib/libpng-1.2.19/pnggccrd.c
    host C: emulator <= external/qemu/framebuffer.c
    host C: emulator <= external/qemu/user-events-qemu.c
    host C: emulator <= external/qemu/android/cmdline-option.c
    host C: emulator <= external/qemu/android/config.c
    host C: emulator <= external/qemu/android/hw-sensors.c
    host C: emulator <= external/qemu/android/main.c
    host C: emulator <= external/qemu/block.c
    host C: emulator <= external/qemu/block/qcow.c
    host C: emulator <= external/qemu/block/qcow2.c
    host C: emulator <= external/qemu/block/qcow2-refcount.c
    host C: emulator <= external/qemu/block/qcow2-snapshot.c
    host C: emulator <= external/qemu/block/qcow2-cluster.c
    host C: emulator <= external/qemu/block/cloop.c
    host C: emulator <= external/qemu/block/dmg.c
    host C: emulator <= external/qemu/block/vvfat.c
    host C: emulator <= external/qemu/block/raw-posix.c
    host C: emulator <= external/qemu/hw/arm_boot.c
    host C: emulator <= external/qemu/hw/android_arm.c
    host C: emulator <= external/qemu/iolooper-select.c
    host C: emulator <= external/qemu/migration.c
    host C: emulator <= external/qemu/migration-exec.c
    host C: emulator <= external/qemu/migration-tcp-android.c
    host C: emulator <= external/qemu/vl-android.c
    host C: emulator <= external/qemu/console.c
    host C: emulator <= external/qemu/loader.c
    host C: emulator <= external/qemu/monitor.c
    host C: emulator <= external/qemu/readline.c
    host C: emulator <= external/qemu/qemu-char-android.c
    host C: emulator <= external/qemu/disas.c
    host C: emulator <= external/qemu/arm-dis.c
    host C: emulator <= external/qemu/aes.c
    host C: emulator <= external/qemu/d3des.c
    host C: emulator <= external/qemu/vnc-android.c
    host C: emulator <= external/qemu/acl.c
    host C: emulator <= external/qemu/buffered_file.c
    host C: emulator <= external/qemu/cbuffer.c
    host C: emulator <= external/qemu/gdbstub.c
    host C: emulator <= external/qemu/ioport.c
    host C: emulator <= external/qemu/shaper.c
    host C: emulator <= external/qemu/charpipe.c
    host C: emulator <= external/qemu/tcpdump.c
    host C: emulator <= external/qemu/qemu-malloc.c
    host C: emulator <= external/qemu/qemu-option.c
    host C: emulator <= external/qemu/savevm.c
    host C: emulator <= external/qemu/net-android.c
    host C: emulator <= external/qemu/aio-android.c
    host C: emulator <= external/qemu/dma-helpers.c
    host C: emulator <= external/qemu/qemu-sockets-android.c
    host C: emulator <= external/qemu/bt-host.c
    host C: emulator <= external/qemu/bt-vhci.c
    host C: emulator <= external/qemu/module.c
    host C: emulator <= external/qemu/android/boot-properties.c
    host C: emulator <= external/qemu/android/hw-kmsg.c
    host C: emulator <= external/qemu/android/hw-lcd.c
    host C: emulator <= external/qemu/android/gps.c
    host C: emulator <= external/qemu/android/hw-events.c
    host C: emulator <= external/qemu/android/hw-control.c
    host C: emulator <= external/qemu/android/console.c
    host C: emulator <= external/qemu/android/avd/hw-config.c
    host C: emulator <= external/qemu/android/avd/info.c
    host C: emulator <= external/qemu/android/utils/ini.c
    host C: emulator <= external/qemu/i386-dis.c
    host C: emulator <= external/qemu/usb-linux.c
    host C: emulator <= external/qemu/qemu-thread.c
    host C: emulator <= external/qemu/json-lexer.c
    host C: emulator <= external/qemu/json-parser.c
    host C: emulator <= external/qemu/json-streamer.c
    host C: emulator <= external/qemu/qjson.c
    host C: emulator <= external/qemu/qbool.c
    host C: emulator <= external/qemu/qdict.c
    host C: emulator <= external/qemu/qfloat.c
    host C: emulator <= external/qemu/qint.c
    host C: emulator <= external/qemu/qlist.c
    host C: emulator <= external/qemu/qstring.c
    host C: emulator <= external/qemu/loadpng.c
    host C: emulator <= external/qemu/android/user-config.c
    host C: emulator <= external/qemu/android/resource.c
    host C: emulator <= external/qemu/android/qemulator.c
    host C: emulator <= external/qemu/android/keycode.c
    host C: emulator <= external/qemu/android/help.c
    host C: emulator <= external/qemu/osdep.c
    host C: emulator <= external/qemu/cutils.c
    host C: emulator <= external/qemu/sockets.c
    host C: emulator <= external/qemu/keymaps.c
    host C: emulator <= external/qemu/android/keycode-array.c
    host C: emulator <= external/qemu/android/charmap.c
    host C: emulator <= external/qemu/android/hw-qemud.c
    host C: emulator <= external/qemu/android/utils/bufprint.c
    host C: emulator <= external/qemu/android/utils/debug.c
    host C: emulator <= external/qemu/android/utils/path.c
    host C: emulator <= external/qemu/android/utils/dirscanner.c
    host C: emulator <= external/qemu/android/utils/filelock.c
    host C: emulator <= external/qemu/android/utils/misc.c
    host C: emulator <= external/qemu/android/utils/reflist.c
    host C: emulator <= external/qemu/android/utils/stralloc.c
    host C: emulator <= external/qemu/android/utils/system.c
    host C: emulator <= external/qemu/android/utils/tempfile.c
    host C: emulator <= external/qemu/android/utils/timezone.c
    host C: emulator <= external/qemu/android/utils/mapfile.c
    host C: emulator <= external/qemu/android/ui-core-protocol.c
    host C: emulator <= external/qemu/android/core-ui-protocol.c
    host C: emulator <= out/host/linux-x86/obj/EXECUTABLES/emulator_intermediates/gdbstub-xml.c
    host C: emulator-memcheck <= external/qemu/memcheck/memcheck.c
    host C: emulator-memcheck <= external/qemu/memcheck/memcheck_proc_management.c
    host C: emulator-memcheck <= external/qemu/memcheck/memcheck_malloc_map.c
    host C: emulator-memcheck <= external/qemu/memcheck/memcheck_mmrange_map.c
    host C: emulator-memcheck <= external/qemu/memcheck/memcheck_util.c
    host StaticLib: emulator-memcheck (out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-memcheck_intermediates/emulator-memcheck.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-memcheck_intermediates/memcheck/memcheck.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-memcheck_intermediates/memcheck/memcheck_proc_management.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-memcheck_intermediates/memcheck/memcheck_malloc_map.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-memcheck_intermediates/memcheck/memcheck_mmrange_map.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-memcheck_intermediates/memcheck/memcheck_util.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-memcheck_intermediates/emulator-memcheck.a
    host C: emulator-hw <= external/qemu/hw/android_arm.c
    host C: emulator-hw <= external/qemu/hw/arm_pic.c
    host C: emulator-hw <= external/qemu/hw/bt.c
    host C: emulator-hw <= external/qemu/hw/bt-hci.c
    host C: emulator-hw <= external/qemu/hw/bt-hid.c
    host C: emulator-hw <= external/qemu/hw/bt-l2cap.c
    host C: emulator-hw <= external/qemu/hw/bt-sdp.c
    host C: emulator-hw <= external/qemu/hw/cdrom.c
    host C: emulator-hw <= external/qemu/hw/dma.c
    host C: emulator-hw <= external/qemu/hw/irq.c
    host C: emulator-hw <= external/qemu/hw/goldfish_audio.c
    host C: emulator-hw <= external/qemu/hw/goldfish_battery.c
    host C: emulator-hw <= external/qemu/hw/goldfish_device.c
    host C: emulator-hw <= external/qemu/hw/goldfish_events_device.c
    host C: emulator-hw <= external/qemu/hw/goldfish_fb.c
    host C: emulator-hw <= external/qemu/hw/goldfish_interrupt.c
    host C: emulator-hw <= external/qemu/hw/goldfish_memlog.c
    host C: emulator-hw <= external/qemu/hw/goldfish_mmc.c
    host C: emulator-hw <= external/qemu/hw/goldfish_nand.c
    host C: emulator-hw <= external/qemu/hw/goldfish_switch.c
    host C: emulator-hw <= external/qemu/hw/goldfish_timer.c
    host C: emulator-hw <= external/qemu/hw/goldfish_trace.c
    host C: emulator-hw <= external/qemu/hw/goldfish_tty.c
    host C: emulator-hw <= external/qemu/hw/msmouse.c
    host C: emulator-hw <= external/qemu/hw/pci.c
    host C: emulator-hw <= external/qemu/hw/qdev.c
    host C: emulator-hw <= external/qemu/hw/scsi-disk.c
    host C: emulator-hw <= external/qemu/hw/smc91c111.c
    host C: emulator-hw <= external/qemu/hw/sysbus.c
    host C: emulator-hw <= external/qemu/hw/usb-hid.c
    host C: emulator-hw <= external/qemu/hw/usb-hub.c
    host C: emulator-hw <= external/qemu/hw/usb-msd.c
    host C: emulator-hw <= external/qemu/hw/usb-ohci.c
    host C: emulator-hw <= external/qemu/hw/usb.c
    host C: emulator-hw <= external/qemu/hw/watchdog.c
    host StaticLib: emulator-hw (out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/emulator-hw.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/android_arm.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/arm_pic.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/bt.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/bt-hci.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/bt-hid.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/bt-l2cap.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/bt-sdp.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/cdrom.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/dma.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/irq.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/goldfish_audio.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/goldfish_battery.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/goldfish_device.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/goldfish_events_device.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/goldfish_fb.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/goldfish_interrupt.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/goldfish_memlog.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/goldfish_mmc.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/goldfish_nand.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/goldfish_switch.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/goldfish_timer.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/goldfish_trace.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/goldfish_tty.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/msmouse.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/pci.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/qdev.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/scsi-disk.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/smc91c111.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/sysbus.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/usb-hid.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/usb-hub.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/usb-msd.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/usb-ohci.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/usb.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/hw/watchdog.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-hw_intermediates/emulator-hw.a
    host C: emulator-arm <= external/qemu/exec.c
    host C: emulator-arm <= external/qemu/cpu-exec.c
    host C: emulator-arm <= external/qemu/target-arm/op_helper.c
    host C: emulator-arm <= external/qemu/target-arm/iwmmxt_helper.c
    host C: emulator-arm <= external/qemu/target-arm/neon_helper.c
    host C: emulator-arm <= external/qemu/target-arm/helper.c
    host C: emulator-arm <= external/qemu/target-arm/translate.c
    host C: emulator-arm <= external/qemu/target-arm/machine.c
    host C: emulator-arm <= external/qemu/translate-all.c
    host C: emulator-arm <= external/qemu/hw/armv7m.c
    host C: emulator-arm <= external/qemu/hw/armv7m_nvic.c
    host C: emulator-arm <= external/qemu/arm-semi.c
    host C: emulator-arm <= external/qemu/trace.c
    host C: emulator-arm <= external/qemu/varint.c
    host C: emulator-arm <= external/qemu/dcache.c
    host C: emulator-arm <= external/qemu/softmmu_outside_jit.c
    host C: emulator-arm <= external/qemu/fpu/softfloat.c
    host StaticLib: emulator-arm (out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/emulator-arm.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/exec.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/cpu-exec.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/target-arm/op_helper.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/target-arm/iwmmxt_helper.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/target-arm/neon_helper.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/target-arm/helper.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/target-arm/translate.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/target-arm/machine.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/translate-all.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/hw/armv7m.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/hw/armv7m_nvic.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/arm-semi.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/trace.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/varint.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/dcache.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/softmmu_outside_jit.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/fpu/softfloat.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-arm_intermediates/emulator-arm.a
    host C: emulator-tcg <= external/qemu/tcg/tcg.c
    host StaticLib: emulator-tcg (out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-tcg_intermediates/emulator-tcg.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-tcg_intermediates/tcg/tcg.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-tcg_intermediates/emulator-tcg.a
    host C++: emulator-elff <= external/qemu/elff/dwarf_cu.cc
    host C++: emulator-elff <= external/qemu/elff/dwarf_die.cc
    host C++: emulator-elff <= external/qemu/elff/dwarf_utils.cc
    host C++: emulator-elff <= external/qemu/elff/elf_alloc.cc
    host C++: emulator-elff <= external/qemu/elff/elf_file.cc
    host C++: emulator-elff <= external/qemu/elff/elf_mapped_section.cc
    host C++: emulator-elff <= external/qemu/elff/elff_api.cc
    host StaticLib: emulator-elff (out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-elff_intermediates/emulator-elff.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-elff_intermediates/elff/dwarf_cu.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-elff_intermediates/elff/dwarf_die.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-elff_intermediates/elff/dwarf_utils.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-elff_intermediates/elff/elf_alloc.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-elff_intermediates/elff/elf_file.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-elff_intermediates/elff/elf_mapped_section.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-elff_intermediates/elff/elff_api.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-elff_intermediates/emulator-elff.a
    host C: emulator-core <= external/qemu/slirp-android/bootp.c
    host C: emulator-core <= external/qemu/slirp-android/cksum.c
    host C: emulator-core <= external/qemu/slirp-android/debug.c
    host C: emulator-core <= external/qemu/slirp-android/if.c
    host C: emulator-core <= external/qemu/slirp-android/ip_icmp.c
    host C: emulator-core <= external/qemu/slirp-android/ip_input.c
    host C: emulator-core <= external/qemu/slirp-android/ip_output.c
    host C: emulator-core <= external/qemu/slirp-android/mbuf.c
    host C: emulator-core <= external/qemu/slirp-android/misc.c
    host C: emulator-core <= external/qemu/slirp-android/sbuf.c
    host C: emulator-core <= external/qemu/slirp-android/slirp.c
    host C: emulator-core <= external/qemu/slirp-android/socket.c
    host C: emulator-core <= external/qemu/slirp-android/tcp_input.c
    host C: emulator-core <= external/qemu/slirp-android/tcp_output.c
    host C: emulator-core <= external/qemu/slirp-android/tcp_subr.c
    host C: emulator-core <= external/qemu/slirp-android/tcp_timer.c
    host C: emulator-core <= external/qemu/slirp-android/tftp.c
    host C: emulator-core <= external/qemu/slirp-android/udp.c
    host C: emulator-core <= external/qemu/proxy/proxy_common.c
    host C: emulator-core <= external/qemu/proxy/proxy_http.c
    host C: emulator-core <= external/qemu/proxy/proxy_http_connector.c
    host C: emulator-core <= external/qemu/proxy/proxy_http_rewriter.c
    host C: emulator-core <= external/qemu/telephony/android_modem.c
    host C: emulator-core <= external/qemu/telephony/modem_driver.c
    host C: emulator-core <= external/qemu/telephony/gsm.c
    host C: emulator-core <= external/qemu/telephony/sim_card.c
    host C: emulator-core <= external/qemu/telephony/sysdeps_qemu.c
    host C: emulator-core <= external/qemu/telephony/sms.c
    host C: emulator-core <= external/qemu/telephony/remote_call.c
    host C: emulator-core <= external/qemu/android/qemu-setup.c
    host StaticLib: emulator-core (out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/emulator-core.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/bootp.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/cksum.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/debug.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/if.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/ip_icmp.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/ip_input.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/ip_output.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/mbuf.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/misc.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/sbuf.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/slirp.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/socket.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/tcp_input.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/tcp_output.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/tcp_subr.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/tcp_timer.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/tftp.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/slirp-android/udp.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/proxy/proxy_common.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/proxy/proxy_http.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/proxy/proxy_http_connector.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/proxy/proxy_http_rewriter.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/telephony/android_modem.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/telephony/modem_driver.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/telephony/gsm.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/telephony/sim_card.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/telephony/sysdeps_qemu.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/telephony/sms.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/telephony/remote_call.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/android/qemu-setup.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-core_intermediates/emulator-core.a
    host C: emulator-ui <= external/qemu/android/skin/rect.c
    host C: emulator-ui <= external/qemu/android/skin/region.c
    host C: emulator-ui <= external/qemu/android/skin/image.c
    host C: emulator-ui <= external/qemu/android/skin/trackball.c
    host C: emulator-ui <= external/qemu/android/skin/keyboard.c
    host C: emulator-ui <= external/qemu/android/skin/keyset.c
    host C: emulator-ui <= external/qemu/android/skin/file.c
    host C: emulator-ui <= external/qemu/android/skin/window.c
    host C: emulator-ui <= external/qemu/android/skin/scaler.c
    host C: emulator-ui <= external/qemu/android/skin/composer.c
    host C: emulator-ui <= external/qemu/android/skin/surface.c
    host StaticLib: emulator-ui (out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-ui_intermediates/emulator-ui.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-ui_intermediates/android/skin/rect.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-ui_intermediates/android/skin/region.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-ui_intermediates/android/skin/image.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-ui_intermediates/android/skin/trackball.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-ui_intermediates/android/skin/keyboard.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-ui_intermediates/android/skin/keyset.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-ui_intermediates/android/skin/file.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-ui_intermediates/android/skin/window.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-ui_intermediates/android/skin/scaler.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-ui_intermediates/android/skin/composer.o out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-ui_intermediates/android/skin/surface.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/emulator-ui_intermediates/emulator-ui.a
    host Prebuilt: libSDL (out/host/linux-x86/obj/STATIC_LIBRARIES/libSDL_intermediates/libSDL.a)
    true
    host Prebuilt: libSDLmain (out/host/linux-x86/obj/STATIC_LIBRARIES/libSDLmain_intermediates/libSDLmain.a)
    true
    host Executable: emulator (out/host/linux-x86/obj/EXECUTABLES/emulator_intermediates/emulator)
    true
    Notice file: external/qemu/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//bin/emulator.txt
    Notice file: external/qemu/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/emulator-memcheck.a.txt
    Notice file: external/qemu/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/emulator-hw.a.txt
    Notice file: external/qemu/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/emulator-arm.a.txt
    Notice file: external/qemu/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/emulator-tcg.a.txt
    Notice file: external/qemu/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/emulator-elff.a.txt
    Notice file: external/qemu/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/emulator-core.a.txt
    Notice file: external/qemu/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/emulator-ui.a.txt
    Install: out/host/linux-x86/bin/emulator
    host C++: etc1tool <= development/tools/etc1tool/etc1tool.cpp
    host C++: libETC1 <= frameworks/base/opengl/libs/ETC1/etc1.cpp
    host StaticLib: libETC1 (out/host/linux-x86/obj/STATIC_LIBRARIES/libETC1_intermediates/libETC1.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libETC1_intermediates/ETC1/etc1.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libETC1_intermediates/libETC1.a
    host Executable: etc1tool (out/host/linux-x86/obj/EXECUTABLES/etc1tool_intermediates/etc1tool)
    true
    Install: out/host/linux-x86/bin/etc1tool
    host Prebuilt: eventanalyzer (out/host/linux-x86/obj/EXECUTABLES/eventanalyzer_intermediates/eventanalyzer)
    Install: out/host/linux-x86/bin/eventanalyzer
    host C++: exc_dump <= sdk/emulator/qtools/exc_dump.cpp
    host C++: exc_dump <= sdk/emulator/qtools/trace_reader.cpp
    host C++: exc_dump <= sdk/emulator/qtools/decoder.cpp
    host Executable: exc_dump (out/host/linux-x86/obj/EXECUTABLES/exc_dump_intermediates/exc_dump)
    true
    Install: out/host/linux-x86/bin/exc_dump
    host C: fastboot <= system/core/fastboot/protocol.c
    host C: fastboot <= system/core/fastboot/engine.c
    host C: fastboot <= system/core/fastboot/bootimg.c
    host C: fastboot <= system/core/fastboot/fastboot.c
    host C: fastboot <= system/core/fastboot/usb_linux.c
    host C: fastboot <= system/core/fastboot/util_linux.c
    host Executable: fastboot (out/host/linux-x86/obj/EXECUTABLES/fastboot_intermediates/fastboot)
    true
    Install: out/host/linux-x86/bin/fastboot
    host C: fs_config <= build/tools/fs_config/fs_config.c
    host Executable: fs_config (out/host/linux-x86/obj/EXECUTABLES/fs_config_intermediates/fs_config)
    true
    Install: out/host/linux-x86/bin/fs_config
    host C: fs_get_stats <= build/tools/fs_get_stats/fs_get_stats.c
    host Executable: fs_get_stats (out/host/linux-x86/obj/EXECUTABLES/fs_get_stats_intermediates/fs_get_stats)
    true
    Install: out/host/linux-x86/bin/fs_get_stats
    host C: genext2fs <= external/genext2fs/genext2fs.c
    host Executable: genext2fs (out/host/linux-x86/obj/EXECUTABLES/genext2fs_intermediates/genext2fs)
    true
    Install: out/host/linux-x86/bin/genext2fs
    host Prebuilt: hierarchyviewer (out/host/linux-x86/obj/EXECUTABLES/hierarchyviewer_intermediates/hierarchyviewer)
    Install: out/host/linux-x86/bin/hierarchyviewer
    host C++: hist_trace <= sdk/emulator/qtools/hist_trace.cpp
    host C++: hist_trace <= sdk/emulator/qtools/trace_reader.cpp
    host C++: hist_trace <= sdk/emulator/qtools/decoder.cpp
    host Executable: hist_trace (out/host/linux-x86/obj/EXECUTABLES/hist_trace_intermediates/hist_trace)
    true
    Install: out/host/linux-x86/bin/hist_trace
    host C: hprof-conv <= dalvik/tools/hprof-conv/HprofConv.c
    host Executable: hprof-conv (out/host/linux-x86/obj/EXECUTABLES/hprof-conv_intermediates/hprof-conv)
    true
    Install: out/host/linux-x86/bin/hprof-conv
    host C: icudata <= build/tools/bin2asm/icudata.c
    host Executable: icudata (out/host/linux-x86/obj/EXECUTABLES/icudata_intermediates/icudata)
    true
    Install: out/host/linux-x86/bin/icudata
    host C: imgdiff <= bootable/recovery/applypatch/imgdiff.c
    host C: imgdiff <= bootable/recovery/applypatch/utils.c
    host C: imgdiff <= bootable/recovery/applypatch/bsdiff.c
    host Executable: imgdiff (out/host/linux-x86/obj/EXECUTABLES/imgdiff_intermediates/imgdiff)
    true
    Install: out/host/linux-x86/bin/imgdiff
    host C: iself <= build/tools/iself/iself.c
    host Executable: iself (out/host/linux-x86/obj/EXECUTABLES/iself_intermediates/iself)
    true
    Install: out/host/linux-x86/bin/iself
    host C: isprelinked <= build/tools/isprelinked/isprelinked.c
    host C: isprelinked <= build/tools/isprelinked/debug.c
    host C: isprelinked <= build/tools/isprelinked/prelink_info.c
    host Executable: isprelinked (out/host/linux-x86/obj/EXECUTABLES/isprelinked_intermediates/isprelinked)
    true
    Install: out/host/linux-x86/bin/isprelinked
    Copy: jasmin.jar (out/host/common/obj/JAVA_LIBRARIES/jasmin.jar_intermediates/jasmin.jar)
    Install: out/host/linux-x86/framework/jasmin.jar
    Copy: jasmin (out/host/linux-x86/obj/EXECUTABLES/jasmin_intermediates/jasmin)
    Install: out/host/linux-x86/bin/jasmin
    host C: jdwpspy <= development/tools/jdwpspy/Main.c
    host C: jdwpspy <= development/tools/jdwpspy/Net.c
    host C: jdwpspy <= development/tools/jdwpspy/find_JdwpConstants.c
    host Executable: jdwpspy (out/host/linux-x86/obj/EXECUTABLES/jdwpspy_intermediates/jdwpspy)
    true
    Install: out/host/linux-x86/bin/jdwpspy
    host C++: kcm <= build/tools/kcm/kcm.cpp
    host Executable: kcm (out/host/linux-x86/obj/EXECUTABLES/kcm_intermediates/kcm)
    true
    Install: out/host/linux-x86/bin/kcm
    host Prebuilt: layoutopt (out/host/linux-x86/obj/EXECUTABLES/layoutopt_intermediates/layoutopt)
    Install: out/host/linux-x86/bin/layoutopt
    host C: line_endings <= development/tools/line_endings/line_endings.c
    host Executable: line_endings (out/host/linux-x86/obj/EXECUTABLES/line_endings_intermediates/line_endings)
    true
    Install: out/host/linux-x86/bin/line_endings
    host C++: localize <= frameworks/base/tools/localize/file_utils.cpp
    host C++: localize <= frameworks/base/tools/localize/localize.cpp
    host C++: localize <= frameworks/base/tools/localize/merge_res_and_xliff.cpp
    host C++: localize <= frameworks/base/tools/localize/res_check.cpp
    host C++: localize <= frameworks/base/tools/localize/xmb.cpp
    host C++: localize <= frameworks/base/tools/localize/Configuration.cpp
    host C++: localize <= frameworks/base/tools/localize/Perforce.cpp
    host C++: localize <= frameworks/base/tools/localize/SourcePos.cpp
    host C++: localize <= frameworks/base/tools/localize/Values.cpp
    host C++: localize <= frameworks/base/tools/localize/ValuesFile.cpp
    host C++: localize <= frameworks/base/tools/localize/XLIFFFile.cpp
    host C++: localize <= frameworks/base/tools/localize/XMLHandler.cpp
    host C++: localize <= frameworks/base/tools/localize/test.cpp
    host C++: localize <= frameworks/base/tools/localize/localize_test.cpp
    host C++: localize <= frameworks/base/tools/localize/merge_res_and_xliff_test.cpp
    host C++: localize <= frameworks/base/tools/localize/Perforce_test.cpp
    host C++: localize <= frameworks/base/tools/localize/ValuesFile_test.cpp
    host C++: localize <= frameworks/base/tools/localize/XLIFFFile_test.cpp
    host C++: localize <= frameworks/base/tools/localize/XMLHandler_test.cpp
    host Executable: localize (out/host/linux-x86/obj/EXECUTABLES/localize_intermediates/localize)
    true
    Install: out/host/linux-x86/bin/localize
    host C: lsd <= build/tools/lsd/cmdline.c
    host C: lsd <= build/tools/lsd/debug.c
    host C: lsd <= build/tools/lsd/hash.c
    host C: lsd <= build/tools/lsd/lsd.c
    host C: lsd <= build/tools/lsd/main.c
    host Executable: lsd (out/host/linux-x86/obj/EXECUTABLES/lsd_intermediates/lsd)
    true
    Install: out/host/linux-x86/bin/lsd
    host C++: make_cfst <= external/srec/tools/make_cfst/make_cfst.cpp
    host Executable: make_cfst (out/host/linux-x86/obj/EXECUTABLES/make_cfst_intermediates/make_cfst)
    true
    Install: out/host/linux-x86/bin/make_cfst
    host C: make_ext4fs <= system/extras/ext4_utils/make_ext4fs_main.c
    host C: libext4_utils <= system/extras/ext4_utils/make_ext4fs.c
    host C: libext4_utils <= system/extras/ext4_utils/ext4_utils.c
    host C: libext4_utils <= system/extras/ext4_utils/allocate.c
    host C: libext4_utils <= system/extras/ext4_utils/backed_block.c
    host C: libext4_utils <= system/extras/ext4_utils/output_file.c
    host C: libext4_utils <= system/extras/ext4_utils/contents.c
    host C: libext4_utils <= system/extras/ext4_utils/extent.c
    host C: libext4_utils <= system/extras/ext4_utils/indirect.c
    host C: libext4_utils <= system/extras/ext4_utils/uuid.c
    host C: libext4_utils <= system/extras/ext4_utils/sha1.c
    host C: libext4_utils <= system/extras/ext4_utils/sparse_crc32.c
    host StaticLib: libext4_utils (out/host/linux-x86/obj/STATIC_LIBRARIES/libext4_utils_intermediates/libext4_utils.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libext4_utils_intermediates/make_ext4fs.o out/host/linux-x86/obj/STATIC_LIBRARIES/libext4_utils_intermediates/ext4_utils.o out/host/linux-x86/obj/STATIC_LIBRARIES/libext4_utils_intermediates/allocate.o out/host/linux-x86/obj/STATIC_LIBRARIES/libext4_utils_intermediates/backed_block.o out/host/linux-x86/obj/STATIC_LIBRARIES/libext4_utils_intermediates/output_file.o out/host/linux-x86/obj/STATIC_LIBRARIES/libext4_utils_intermediates/contents.o out/host/linux-x86/obj/STATIC_LIBRARIES/libext4_utils_intermediates/extent.o out/host/linux-x86/obj/STATIC_LIBRARIES/libext4_utils_intermediates/indirect.o out/host/linux-x86/obj/STATIC_LIBRARIES/libext4_utils_intermediates/uuid.o out/host/linux-x86/obj/STATIC_LIBRARIES/libext4_utils_intermediates/sha1.o out/host/linux-x86/obj/STATIC_LIBRARIES/libext4_utils_intermediates/sparse_crc32.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libext4_utils_intermediates/libext4_utils.a
    host Executable: make_ext4fs (out/host/linux-x86/obj/EXECUTABLES/make_ext4fs_intermediates/make_ext4fs)
    true
    Notice file: system/extras/ext4_utils/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//bin/make_ext4fs.txt
    Notice file: system/extras/ext4_utils/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/libext4_utils.a.txt
    Install: out/host/linux-x86/bin/make_ext4fs
    host C: make_ve_grammar <= external/srec/tools/make_ve_grammar/make_ve_grammar.c
    host Executable: make_ve_grammar (out/host/linux-x86/obj/EXECUTABLES/make_ve_grammar_intermediates/make_ve_grammar)
    true
    Install: out/host/linux-x86/bin/make_ve_grammar
    host Prebuilt: makedict (out/host/linux-x86/obj/EXECUTABLES/makedict_intermediates/makedict)
    Install: out/host/linux-x86/bin/makedict
    host C++: makekeycodes <= frameworks/base/tools/makekeycodes/makekeycodes.cpp
    host Executable: makekeycodes (out/host/linux-x86/obj/EXECUTABLES/makekeycodes_intermediates/makekeycodes)
    true
    Install: out/host/linux-x86/bin/makekeycodes
    host C: minigzip <= external/zlib/minigzip.c
    host Executable: minigzip (out/host/linux-x86/obj/EXECUTABLES/minigzip_intermediates/minigzip)
    true
    Notice file: external/zlib/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//bin/minigzip.txt
    Install: out/host/linux-x86/bin/minigzip
    host C: mkbootfs <= system/core/cpio/mkbootfs.c
    host Executable: mkbootfs (out/host/linux-x86/obj/EXECUTABLES/mkbootfs_intermediates/mkbootfs)
    true
    Install: out/host/linux-x86/bin/mkbootfs
    host C: mkbootimg <= system/core/mkbootimg/mkbootimg.c
    host C: libmincrypt <= system/core/libmincrypt/rsa.c
    host C: libmincrypt <= system/core/libmincrypt/sha.c
    host StaticLib: libmincrypt (out/host/linux-x86/obj/STATIC_LIBRARIES/libmincrypt_intermediates/libmincrypt.a)
    echo out/host/linux-x86/obj/STATIC_LIBRARIES/libmincrypt_intermediates/rsa.o out/host/linux-x86/obj/STATIC_LIBRARIES/libmincrypt_intermediates/sha.o | xargs ar crsP  out/host/linux-x86/obj/STATIC_LIBRARIES/libmincrypt_intermediates/libmincrypt.a
    host Executable: mkbootimg (out/host/linux-x86/obj/EXECUTABLES/mkbootimg_intermediates/mkbootimg)
    true
    Notice file: system/core/libmincrypt/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/libmincrypt.a.txt
    Install: out/host/linux-x86/bin/mkbootimg
    host C: mksdcard <= sdk/emulator/mksdcard/mksdcard.c
    host Executable: mksdcard (out/host/linux-x86/obj/EXECUTABLES/mksdcard_intermediates/mksdcard)
    true
    Notice file: sdk/emulator/mksdcard/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//bin/mksdcard.txt
    Install: out/host/linux-x86/bin/mksdcard
    Copying out/host/linux-x86/obj/EXECUTABLES/mksnapshot_intermediates/js2c.py
    Copying out/host/linux-x86/obj/EXECUTABLES/mksnapshot_intermediates/jsmin.py
    Generating libraries.cc
    python out/host/linux-x86/obj/EXECUTABLES/mksnapshot_intermediates/js2c.py out/host/linux-x86/obj/EXECUTABLES/mksnapshot_intermediates/libraries.cc out/host/linux-x86/obj/EXECUTABLES/mksnapshot_intermediates/libraries-empty.cc CORE external/v8/src/runtime.js external/v8/src/v8natives.js external/v8/src/array.js external/v8/src/string.js external/v8/src/uri.js external/v8/src/math.js external/v8/src/messages.js external/v8/src/apinatives.js external/v8/src/date.js external/v8/src/regexp.js external/v8/src/json.js external/v8/src/mirror-debugger.js external/v8/src/debug-debugger.js external/v8/src/macros.py
    host C++: mksnapshot <= external/v8/src/accessors.cc
    host C++: mksnapshot <= external/v8/src/allocation.cc
    host C++: mksnapshot <= external/v8/src/api.cc
    host C++: mksnapshot <= external/v8/src/assembler.cc
    host C++: mksnapshot <= external/v8/src/ast.cc
    host C++: mksnapshot <= external/v8/src/bootstrapper.cc
    host C++: mksnapshot <= external/v8/src/builtins.cc
    host C++: mksnapshot <= external/v8/src/checks.cc
    host C++: mksnapshot <= external/v8/src/code-stubs.cc
    host C++: mksnapshot <= external/v8/src/codegen.cc
    host C++: mksnapshot <= external/v8/src/compilation-cache.cc
    host C++: mksnapshot <= external/v8/src/compiler.cc
    host C++: mksnapshot <= external/v8/src/contexts.cc
    host C++: mksnapshot <= external/v8/src/conversions.cc
    host C++: mksnapshot <= external/v8/src/counters.cc
    host C++: mksnapshot <= external/v8/src/data-flow.cc
    host C++: mksnapshot <= external/v8/src/dateparser.cc
    host C++: mksnapshot <= external/v8/src/debug.cc
    host C++: mksnapshot <= external/v8/src/debug-agent.cc
    host C++: mksnapshot <= external/v8/src/disassembler.cc
    host C++: mksnapshot <= external/v8/src/execution.cc
    host C++: mksnapshot <= external/v8/src/factory.cc
    host C++: mksnapshot <= external/v8/src/fast-codegen.cc
    host C++: mksnapshot <= external/v8/src/flags.cc
    host C++: mksnapshot <= external/v8/src/frame-element.cc
    host C++: mksnapshot <= external/v8/src/frames.cc
    host C++: mksnapshot <= external/v8/src/full-codegen.cc
    host C++: mksnapshot <= external/v8/src/func-name-inferrer.cc
    host C++: mksnapshot <= external/v8/src/global-handles.cc
    host C++: mksnapshot <= external/v8/src/handles.cc
    host C++: mksnapshot <= external/v8/src/hashmap.cc
    host C++: mksnapshot <= external/v8/src/heap.cc
    host C++: mksnapshot <= external/v8/src/heap-profiler.cc
    host C++: mksnapshot <= external/v8/src/ic.cc
    host C++: mksnapshot <= external/v8/src/interpreter-irregexp.cc
    host C++: mksnapshot <= external/v8/src/jsregexp.cc
    host C++: mksnapshot <= external/v8/src/jump-target.cc
    host C++: mksnapshot <= external/v8/src/liveedit.cc
    host C++: mksnapshot <= external/v8/src/log.cc
    host C++: mksnapshot <= external/v8/src/log-utils.cc
    host C++: mksnapshot <= external/v8/src/mark-compact.cc
    host C++: mksnapshot <= external/v8/src/messages.cc
    host C++: mksnapshot <= external/v8/src/objects.cc
    host C++: mksnapshot <= external/v8/src/oprofile-agent.cc
    host C++: mksnapshot <= external/v8/src/parser.cc
    host C++: mksnapshot <= external/v8/src/property.cc
    host C++: mksnapshot <= external/v8/src/regexp-macro-assembler.cc
    host C++: mksnapshot <= external/v8/src/regexp-macro-assembler-irregexp.cc
    host C++: mksnapshot <= external/v8/src/regexp-stack.cc
    host C++: mksnapshot <= external/v8/src/register-allocator.cc
    host C++: mksnapshot <= external/v8/src/rewriter.cc
    host C++: mksnapshot <= external/v8/src/runtime.cc
    host C++: mksnapshot <= external/v8/src/scanner.cc
    host C++: mksnapshot <= external/v8/src/scopeinfo.cc
    host C++: mksnapshot <= external/v8/src/scopes.cc
    host C++: mksnapshot <= external/v8/src/serialize.cc
    host C++: mksnapshot <= external/v8/src/snapshot-common.cc
    host C++: mksnapshot <= external/v8/src/spaces.cc
    host C++: mksnapshot <= external/v8/src/string-stream.cc
    host C++: mksnapshot <= external/v8/src/stub-cache.cc
    host C++: mksnapshot <= external/v8/src/token.cc
    host C++: mksnapshot <= external/v8/src/top.cc
    host C++: mksnapshot <= external/v8/src/unicode.cc
    host C++: mksnapshot <= external/v8/src/usage-analyzer.cc
    host C++: mksnapshot <= external/v8/src/utils.cc
    host C++: mksnapshot <= external/v8/src/v8-counters.cc
    host C++: mksnapshot <= external/v8/src/v8.cc
    host C++: mksnapshot <= external/v8/src/v8threads.cc
    host C++: mksnapshot <= external/v8/src/variables.cc
    host C++: mksnapshot <= external/v8/src/virtual-frame.cc
    host C++: mksnapshot <= external/v8/src/version.cc
    host C++: mksnapshot <= external/v8/src/zone.cc
    host C++: mksnapshot <= external/v8/src/arm/assembler-arm.cc
    host C++: mksnapshot <= external/v8/src/arm/builtins-arm.cc
    host C++: mksnapshot <= external/v8/src/arm/codegen-arm.cc
    host C++: mksnapshot <= external/v8/src/arm/constants-arm.cc
    host C++: mksnapshot <= external/v8/src/arm/cpu-arm.cc
    host C++: mksnapshot <= external/v8/src/arm/debug-arm.cc
    host C++: mksnapshot <= external/v8/src/arm/disasm-arm.cc
    host C++: mksnapshot <= external/v8/src/arm/frames-arm.cc
    host C++: mksnapshot <= external/v8/src/arm/fast-codegen-arm.cc
    host C++: mksnapshot <= external/v8/src/arm/full-codegen-arm.cc
    host C++: mksnapshot <= external/v8/src/arm/ic-arm.cc
    host C++: mksnapshot <= external/v8/src/arm/jump-target-arm.cc
    host C++: mksnapshot <= external/v8/src/arm/macro-assembler-arm.cc
    host C++: mksnapshot <= external/v8/src/arm/regexp-macro-assembler-arm.cc
    host C++: mksnapshot <= external/v8/src/arm/register-allocator-arm.cc
    host C++: mksnapshot <= external/v8/src/arm/stub-cache-arm.cc
    host C++: mksnapshot <= external/v8/src/arm/virtual-frame-arm.cc
    host C++: mksnapshot <= external/v8/src/mksnapshot.cc
    host C++: mksnapshot <= external/v8/src/arm/simulator-arm.cc
    host C++: mksnapshot <= external/v8/src/snapshot-empty.cc
    host C++: mksnapshot <= external/v8/src/platform-linux.cc
    host C++: mksnapshot <= external/v8/src/platform-posix.cc
    host C++: mksnapshot <= out/host/linux-x86/obj/EXECUTABLES/mksnapshot_intermediates/libraries.cc
    host C: mksnapshot <= external/v8/src/dtoa-config.c
    host Executable: mksnapshot (out/host/linux-x86/obj/EXECUTABLES/mksnapshot_intermediates/mksnapshot)
    true
    Install: out/host/linux-x86/bin/mksnapshot
    host Prebuilt: mkuserimg.sh (out/host/linux-x86/obj/EXECUTABLES/mkuserimg.sh_intermediates/mkuserimg.sh)
    Notice file: system/extras/ext4_utils/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//bin/mkuserimg.sh.txt
    Install: out/host/linux-x86/bin/mkuserimg.sh
    host C: mkyaffs2image <= external/yaffs2/yaffs2/utils/mkyaffs2image.c
    host C: mkyaffs2image <= external/yaffs2/yaffs2/yaffs_packedtags2.c
    host C: mkyaffs2image <= external/yaffs2/yaffs2/yaffs_ecc.c
    host C: mkyaffs2image <= external/yaffs2/yaffs2/yaffs_tagsvalidity.c
    host Executable: mkyaffs2image (out/host/linux-x86/obj/EXECUTABLES/mkyaffs2image_intermediates/mkyaffs2image)
    true
    Install: out/host/linux-x86/bin/mkyaffs2image
    host Prebuilt: monkeyrunner (out/host/linux-x86/obj/EXECUTABLES/monkeyrunner_intermediates/monkeyrunner)
    Install: out/host/linux-x86/bin/monkeyrunner
    host C++: obbtool <= frameworks/base/tools/obbtool/Main.cpp
    host Executable: obbtool (out/host/linux-x86/obj/EXECUTABLES/obbtool_intermediates/obbtool)
    true
    Install: out/host/linux-x86/bin/obbtool
    host C: parseStringTest <= external/srec/tools/parseStringTest/parseStringTest.c
    host Executable: parseStringTest (out/host/linux-x86/obj/EXECUTABLES/parseStringTest_intermediates/parseStringTest)
    true
    Install: out/host/linux-x86/bin/parseStringTest
    host C++: post_trace <= sdk/emulator/qtools/post_trace.cpp
    host C++: post_trace <= sdk/emulator/qtools/trace_reader.cpp
    host C++: post_trace <= sdk/emulator/qtools/decoder.cpp
    host Executable: post_trace (out/host/linux-x86/obj/EXECUTABLES/post_trace_intermediates/post_trace)
    true
    Install: out/host/linux-x86/bin/post_trace
    host C++: profile_pid <= sdk/emulator/qtools/profile_pid.cpp
    host C++: profile_pid <= sdk/emulator/qtools/trace_reader.cpp
    host C++: profile_pid <= sdk/emulator/qtools/decoder.cpp
    host C++: profile_pid <= sdk/emulator/qtools/read_elf.cpp
    host C++: profile_pid <= sdk/emulator/qtools/parse_options.cpp
    host Executable: profile_pid (out/host/linux-x86/obj/EXECUTABLES/profile_pid_intermediates/profile_pid)
    true
    Install: out/host/linux-x86/bin/profile_pid
    host C++: profile_trace <= sdk/emulator/qtools/profile_trace.cpp
    host C++: profile_trace <= sdk/emulator/qtools/trace_reader.cpp
    host C++: profile_trace <= sdk/emulator/qtools/decoder.cpp
    host C++: profile_trace <= sdk/emulator/qtools/opcode.cpp
    host C++: profile_trace <= sdk/emulator/qtools/read_elf.cpp
    host C++: profile_trace <= sdk/emulator/qtools/parse_options.cpp
    host Executable: profile_trace (out/host/linux-x86/obj/EXECUTABLES/profile_trace_intermediates/profile_trace)
    true
    Install: out/host/linux-x86/bin/profile_trace
    host C++: q2dm <= sdk/emulator/qtools/q2dm.cpp
    host C++: q2dm <= sdk/emulator/qtools/trace_reader.cpp
    host C++: q2dm <= sdk/emulator/qtools/decoder.cpp
    host C++: q2dm <= sdk/emulator/qtools/armdis.cpp
    host C++: q2dm <= sdk/emulator/qtools/thumbdis.cpp
    host C++: q2dm <= sdk/emulator/qtools/opcode.cpp
    host C++: q2dm <= sdk/emulator/qtools/read_elf.cpp
    host C++: q2dm <= sdk/emulator/qtools/parse_options.cpp
    host C++: q2dm <= sdk/emulator/qtools/dmtrace.cpp
    host Executable: q2dm (out/host/linux-x86/obj/EXECUTABLES/q2dm_intermediates/q2dm)
    true
    Install: out/host/linux-x86/bin/q2dm
    host C++: q2g <= sdk/emulator/qtools/q2g.cpp
    host C++: q2g <= sdk/emulator/qtools/trace_reader.cpp
    host C++: q2g <= sdk/emulator/qtools/decoder.cpp
    host C++: q2g <= sdk/emulator/qtools/opcode.cpp
    host C++: q2g <= sdk/emulator/qtools/read_elf.cpp
    host C++: q2g <= sdk/emulator/qtools/parse_options.cpp
    host C++: q2g <= sdk/emulator/qtools/gtrace.cpp
    host Executable: q2g (out/host/linux-x86/obj/EXECUTABLES/q2g_intermediates/q2g)
    true
    Install: out/host/linux-x86/bin/q2g
    host C++: read_addr <= sdk/emulator/qtools/read_addr.cpp
    host C++: read_addr <= sdk/emulator/qtools/trace_reader.cpp
    host C++: read_addr <= sdk/emulator/qtools/decoder.cpp
    host Executable: read_addr (out/host/linux-x86/obj/EXECUTABLES/read_addr_intermediates/read_addr)
    true
    Install: out/host/linux-x86/bin/read_addr
    host C++: read_method <= sdk/emulator/qtools/read_method.cpp
    host C++: read_method <= sdk/emulator/qtools/trace_reader.cpp
    host C++: read_method <= sdk/emulator/qtools/decoder.cpp
    host C++: read_method <= sdk/emulator/qtools/read_elf.cpp
    host C++: read_method <= sdk/emulator/qtools/parse_options.cpp
    host Executable: read_method (out/host/linux-x86/obj/EXECUTABLES/read_method_intermediates/read_method)
    true
    Install: out/host/linux-x86/bin/read_method
    host C++: read_pid <= sdk/emulator/qtools/read_pid.cpp
    host C++: read_pid <= sdk/emulator/qtools/trace_reader.cpp
    host C++: read_pid <= sdk/emulator/qtools/decoder.cpp
    host Executable: read_pid (out/host/linux-x86/obj/EXECUTABLES/read_pid_intermediates/read_pid)
    true
    Install: out/host/linux-x86/bin/read_pid
    host C++: read_trace <= sdk/emulator/qtools/read_trace.cpp
    host C++: read_trace <= sdk/emulator/qtools/trace_reader.cpp
    host C++: read_trace <= sdk/emulator/qtools/decoder.cpp
    host C++: read_trace <= sdk/emulator/qtools/armdis.cpp
    host C++: read_trace <= sdk/emulator/qtools/thumbdis.cpp
    host C++: read_trace <= sdk/emulator/qtools/opcode.cpp
    host C++: read_trace <= sdk/emulator/qtools/read_elf.cpp
    host C++: read_trace <= sdk/emulator/qtools/parse_options.cpp
    host Executable: read_trace (out/host/linux-x86/obj/EXECUTABLES/read_trace_intermediates/read_trace)
    true
    Install: out/host/linux-x86/bin/read_trace
    host C: rgb2565 <= build/tools/rgb2565/to565.c
    host Executable: rgb2565 (out/host/linux-x86/obj/EXECUTABLES/rgb2565_intermediates/rgb2565)
    true
    Install: out/host/linux-x86/bin/rgb2565
    host C: rsg-generator <= frameworks/base/libs/rs/rsg_generator.c
    Lex: rsg-generator <= frameworks/base/libs/rs/spec.l
    host C++: rsg-generator <= out/host/linux-x86/obj/EXECUTABLES/rsg-generator_intermediates/spec.cpp
    host Executable: rsg-generator (out/host/linux-x86/obj/EXECUTABLES/rsg-generator_intermediates/rsg-generator)
    true
    Install: out/host/linux-x86/bin/rsg-generator
    host Prebuilt: screenshot2 (out/host/linux-x86/obj/EXECUTABLES/screenshot2_intermediates/screenshot2)
    Install: out/host/linux-x86/bin/screenshot2
    host Prebuilt: sig (out/host/linux-x86/obj/EXECUTABLES/sig_intermediates/sig)
    Install: out/host/linux-x86/bin/sig
    host Prebuilt: sig-check (out/host/linux-x86/obj/EXECUTABLES/sig-check_intermediates/sig-check)
    Install: out/host/linux-x86/bin/sig-check
    host Prebuilt: sig-create (out/host/linux-x86/obj/EXECUTABLES/sig-create_intermediates/sig-create)
    Install: out/host/linux-x86/bin/sig-create
    host C: simg2img <= system/extras/ext4_utils/simg2img.c
    host C: simg2img <= system/extras/ext4_utils/sparse_crc32.c
    host Executable: simg2img (out/host/linux-x86/obj/EXECUTABLES/simg2img_intermediates/simg2img)
    true
    Notice file: system/extras/ext4_utils/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//bin/simg2img.txt
    Install: out/host/linux-x86/bin/simg2img
    Copy: spec-progress (out/host/linux-x86/obj/EXECUTABLES/spec-progress_intermediates/spec-progress)
    Install: out/host/linux-x86/bin/spec-progress
    host C: sqlite3 <= external/sqlite/dist/sqlite3.c
    host C: sqlite3 <= external/sqlite/dist/shell.c
    host Executable: sqlite3 (out/host/linux-x86/obj/EXECUTABLES/sqlite3_intermediates/sqlite3)
