Part Number: AM6442
Hi expert,
Part Number: AM6442
Hi expert,
Hi Thomas,
ROM code locks PLLs that are only needed for the selected boot peripherals like USB, SD card, etc.) ROM does not lock PLLs that are not needed for its function.
Stan
thank you for your reply.
I would like to know what is the minimum and maximum admissible input frequency range (FREF) for the PLLs of the AM64 (MCU_PLL0) ?
thomas
thomas
Hi Thomas,
You can refer to the Sysconfig tool where you can play with hsdivider values.
Stan
Hi Thomas,
The supported external crystal frequency is 25 MHz. 12.5 MHz internal oscillator is a fail-safe oscillator turning on if external clock loss was detected. PLLs will continue to work, however this is an emergency situation that needs to handled accordingly.
Stan
