Part Number: AM620-Q1
Other Parts Discussed in Thread: AM625-Q1,
Hi, Expert
I create this thread for Spec. double checking.
(1) Does PPS (Pulse-Per-Second) need a dedicated HW module in SoC to generated precise time synchronization (clock) output?
(2) I saw few discussion between gPTP and PPS, I feel a little bit confuse. Does it mean AM6202 got time synchronization from TSN (CPSW3G) gPTP protocol, and then generate PPS output. this PPS output could be an GPIO, is it corretc?
(3) Base on item2, Does gPTP is necessary item for PPS? Can PPS generated gpio output signal w/o gPTP?
(4) Does AM620x sdk support PPS source?
example like.
$ ls /sys/class/pps/
pps0/ pps1/ pps2/
(5) Can AM62x generate PPS by itself?
Thank You.
Gibbs
Ref.
https://docs.kernel.org/driver-api/pps.html
