Part Number: SK-AM62A-LP
I am using SK-AM62A-LP board with SDK 9.2 for 4K@30fps streaming.
Resolution: 3840 x 2160
Framerate: 30 fps
Sensor: IMX334
For my network streaming, I need to downscale my 4K image to 1080p, for that I am using tiovxmultiscaler element. But I have noticed that using that element causing framerate reduction. My framerate reduced into half (30fps -> 15fps).
I also noticed one fascinating thing. Regardless of downscaling, framerate reduction is there for simple passthrough also. Isn't tiovxmultiscaler element is DMA backed?
Here is the normal pipeline for 4K@30fps without tiovxmultiscaler:
root@am62axx-evm:~# gst-launch-1.0 v4l2src device=/dev/video3 io-mode=5 ! queue leaky=2 ! video/x-bayer, width=3840, height=2160, format=rggb12, framerate=30/1, pixel-aspect-ratio=16/9 ! tiovxisp sink_0::device=/dev/v4l-subdev2 sensor-name=SENSOR_SONY_IMX334 dcc-isp-file=/opt/imaging/imx334/linear/dcc_viss.bin sink_0::dcc-2a-file=/opt/imaging/imx334/linear/dcc_2a.bin format-msb=11 ! video/x-raw,format=NV12,width=3840,height=2160,framerate=30/1,pixel-aspect-ratio=16/9,interlace-mode=progressive,colorimetry=bt601 ! v4l2h264enc output-io-mode=5 name=encoder extra-controls="controls,video_bitrate_mode=1,video_bitrate=10000000,h264_i_frame_period=60,h264_minimum_qp_value=8,h264_maximum_qp_value=51,h264_i_frame_qp_value=30,vbv_buffer_size=2000,h264_entropy_mode=1,video_gop_size=5,frame_level_rate_control_enable=1,h264_loop_filter_mode=0,prepend_sps_and_pps_to_idr=1;" ! fpsdisplaysink video-sink=fakesink text-overlay=false -v
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=6) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
249455.473347 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
249455.473497 s: VX_ZONE_INIT:Enabled
249455.473524 s: VX_ZONE_ERROR:Enabled
249455.473540 s: VX_ZONE_WARNING:Enabled
249455.474494 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-0
249455.474808 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-1
249455.475058 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-2
249455.475254 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-3
249455.475418 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
249455.476133 s: VX_ZONE_INIT:[tivxHostInitLocal:101] Initialization Done for HOST !!!
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0: sync = true
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-bayer, width=(int)3840, height=(int)2160, format=(string)rggb12, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)2:4:7:1
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = video/x-bayer, width=(int)3840, height=(int)2160, format=(string)rggb12, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)2:4:7:1
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:src: caps = video/x-bayer, width=(int)3840, height=(int)2160, format=(string)rggb12, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)2:4:7:1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-bayer, width=(int)3840, height=(int)2160, format=(string)rggb12, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)2:4:7:1
/GstPipeline:pipeline0/GstTIOVXISP:tiovxisp0.GstTIOVXIspPad:sink_0: caps = video/x-bayer, width=(int)3840, height=(int)2160, format=(string)rggb12, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)2:4:7:1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-bayer, width=(int)3840, height=(int)2160, format=(string)rggb12, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)2:4:7:1
New clock: GstSystemClock
/GstPipeline:pipeline0/GstTIOVXISP:tiovxisp0.GstTIOVXMisoPad:src: caps = video/x-raw, format=(string)NV12, width=(int)3840, height=(int)2160, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)3840, height=(int)2160, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/v4l2h264enc:encoder.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)1, profile=(string)baseline, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)16/9, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)1, profile=(string)baseline, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)16/9, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)1, profile=(string)baseline, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)16/9, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)1, profile=(string)baseline, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)16/9, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
Redistribute latency...
/GstPipeline:pipeline0/v4l2h264enc:encoder.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)3840, height=(int)2160, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)3840, height=(int)2160, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)bt601
IttCtrl_registerHandler: command echo registered at location 0
IttCtrl_registerHandler: command iss_read_2a_params registered at location 1
IttCtrl_registerHandler: command iss_write_2a_params registered at location 2
IttCtrl_registerHandler: command iss_raw_save registered at location 3
IttCtrl_registerHandler: command iss_yuv_save registered at location 4
IttCtrl_registerHandler: command iss_read_sensor_reg registered at location 5
IttCtrl_registerHandler: command iss_write_sensor_reg registered at location 6
IttCtrl_registerHandler: command dev_ctrl registered at location 7
IttCtrl_registerHandler: command iss_send_dcc_file registered at location 8
Error: failed to open i2c bus at /dev/i2c-9
Warning: Failed to initialize i2c bus. Register read/write will not work !!!
NETWORK: Opened at IP Addr = 192.168.241.122, socket port=5000!!!
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 19, dropped: 0, current: 36.47, average: 36.47
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 35, dropped: 0, current: 30.20, average: 33.31
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 51, dropped: 0, current: 30.06, average: 32.22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 66, dropped: 0, current: 29.15, average: 31.46
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 82, dropped: 0, current: 30.59, average: 31.29
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 98, dropped: 0, current: 29.91, average: 31.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 114, dropped: 0, current: 29.89, average: 30.89
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 130, dropped: 0, current: 30.19, average: 30.80
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 146, dropped: 0, current: 29.78, average: 30.68
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 161, dropped: 0, current: 29.99, average: 30.62
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 177, dropped: 0, current: 30.34, average: 30.59
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 192, dropped: 0, current: 29.71, average: 30.52
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 208, dropped: 0, current: 30.19, average: 30.50
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 224, dropped: 0, current: 29.91, average: 30.45
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 239, dropped: 0, current: 30.00, average: 30.42
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 255, dropped: 0, current: 30.18, average: 30.41
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 270, dropped: 0, current: 29.69, average: 30.37
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 286, dropped: 0, current: 30.06, average: 30.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 301, dropped: 0, current: 29.99, average: 30.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 316, dropped: 0, current: 30.00, average: 30.32
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 332, dropped: 0, current: 30.05, average: 30.30
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 348, dropped: 0, current: 29.90, average: 30.29
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 364, dropped: 0, current: 30.20, average: 30.28
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 379, dropped: 0, current: 30.00, average: 30.27
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 395, dropped: 0, current: 29.91, average: 30.26
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 410, dropped: 0, current: 30.00, average: 30.25
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 426, dropped: 0, current: 29.51, average: 30.22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 442, dropped: 0, current: 30.60, average: 30.23
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 457, dropped: 0, current: 29.45, average: 30.21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 473, dropped: 0, current: 30.44, average: 30.21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 489, dropped: 0, current: 30.18, average: 30.21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 504, dropped: 0, current: 29.71, average: 30.20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 520, dropped: 0, current: 30.46, average: 30.20
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:17.688391910
Setting pipeline to NULL ...
Freeing pipeline ...
249473.385234 s: VX_ZONE_INIT:[tivxHostDeInitLocal:115] De-Initialization Done for HOST !!!
249473.390215 s: VX_ZONE_INIT:[tivxDeInitLocal:204] De-Initialization Done !!!
APP: Deinit ... !!!
REMOTE_SERVICE: Deinit ... !!!
REMOTE_SERVICE: Deinit ... Done !!!
IPC: Deinit ... !!!
IPC: DeInit ... Done !!!
MEM: Deinit ... !!!
DDR_SHARED_MEM: Alloc's: 25 alloc's of 153891058 bytes
DDR_SHARED_MEM: Free's : 25 free's of 153891058 bytes
DDR_SHARED_MEM: Open's : 0 allocs of 0 bytes
MEM: Deinit ... Done !!!
APP: Deinit ... Done !!!
Here is the pipeline for 4K with tiovxmultiscaler (No downscaling, just passthrough)
root@am62axx-evm:~# gst-launch-1.0 v4l2src device=/dev/video3 io-mode=5 ! queue leaky=2 ! video/x-bayer, width=3840, height=2160, format=rggb12, framerate=30/1, pixel-aspect-ratio=16/9 ! tiovxisp sink_0::device=/dev/v4l-subdev2 sensor-name=SENSOR_SONY_IMX334 dcc-isp-file=/opt/imaging/imx334/linear/dcc_viss.bin sink_0::dcc-2a-file=/opt/imaging/imx334/linear/dcc_2a.bin format-msb=11 ! video/x-raw,format=NV12,width=3840,height=2160,framerate=30/1,pixel-aspect-ratio=16/9 ! tiovxmultiscaler ! video/x-raw,format=NV12,width=3840,height=2160,framerate=30/1,pixel-aspect-ratio=16/9,interlace-mode=progressive,colorimetry=bt601 ! v4l2h264enc output-io-mode=5 name=encoder extra-controls="controls,video_bitrate_mode=1,video_bitrate=10000000,h264_i_frame_period=60,h264_minimum_qp_value=8,h264_maximum_qp_value=51,h264_i_frame_qp_value=30,vbv_buffer_size=2000,h264_entropy_mode=1,video_gop_size=5,frame_level_rate_control_enable=1,h264_loop_filter_mode=0,prepend_sps_and_pps_to_idr=1;" ! fpsdisplaysink video-sink=fakesink text-overlay=false -v
APP: Init ... !!!
MEM: Init ... !!!
IPC: Init ... !!!
250230.329615 s: GTC Frequency = 200 MHz
250230.329756 s: VX_ZONE_INIT:Enabled
250230.329784 s: VX_ZONE_ERROR:Enabled
250230.329838 s: VX_ZONE_WARNING:Enabled
250230.330735 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-0
250230.331349 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-1
250230.331982 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-2
250230.332361 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-3
250230.332403 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
250230.333001 s: VX_ZONE_INIT:[tivxHostInitLocal:101] Initialization Done for HOST !!!
/GstPipeline:pipeline0/GstTIOVXMultiScaler:tiovxmultiscaler0.GstTIOVXMultiScalerPad:src_0: caps = video/x-raw, format=(string)NV12, width=(int)3840, height=(int)2160, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)3840, height=(int)2160, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)3840, height=(int)2160, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstTIOVXMultiScaler:tiovxmultiscaler0.GstTIOVXMultiScalerPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)3840, height=(int)2160, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 9, dropped: 0, current: 17.46, average: 17.46
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 17, dropped: 0, current: 15.23, average: 16.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 25, dropped: 0, current: 15.23, average: 15.96
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 33, dropped: 0, current: 15.24, average: 15.78
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 41, dropped: 0, current: 15.28, average: 15.68
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 49, dropped: 0, current: 15.34, average: 15.62
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 57, dropped: 0, current: 15.24, average: 15.57
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 65, dropped: 0, current: 15.24, average: 15.53
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 73, dropped: 0, current: 15.38, average: 15.51
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 81, dropped: 0, current: 15.18, average: 15.48
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 89, dropped: 0, current: 15.44, average: 15.48
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 97, dropped: 0, current: 15.40, average: 15.47
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 105, dropped: 0, current: 15.23, average: 15.45
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 113, dropped: 0, current: 15.38, average: 15.45
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 121, dropped: 0, current: 15.17, average: 15.43
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 129, dropped: 0, current: 15.30, average: 15.42
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 137, dropped: 0, current: 15.38, average: 15.42
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 145, dropped: 0, current: 15.23, average: 15.41
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 153, dropped: 0, current: 15.24, average: 15.40
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 161, dropped: 0, current: 15.34, average: 15.40
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 169, dropped: 0, current: 15.44, average: 15.40
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 177, dropped: 0, current: 15.24, average: 15.39
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 185, dropped: 0, current: 15.24, average: 15.38
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 193, dropped: 0, current: 15.53, average: 15.39
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 201, dropped: 0, current: 15.17, average: 15.38
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 209, dropped: 0, current: 15.30, average: 15.38
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 217, dropped: 0, current: 15.53, average: 15.38
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 225, dropped: 0, current: 15.54, average: 15.39
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 233, dropped: 0, current: 15.24, average: 15.38
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 241, dropped: 0, current: 15.32, average: 15.38
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 249, dropped: 0, current: 15.45, average: 15.38
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 257, dropped: 0, current: 15.38, average: 15.38
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 265, dropped: 0, current: 15.25, average: 15.38
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 273, dropped: 0, current: 15.38, average: 15.38
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 281, dropped: 0, current: 15.19, average: 15.37
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 289, dropped: 0, current: 15.59, average: 15.38
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 297, dropped: 0, current: 15.24, average: 15.38
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 305, dropped: 0, current: 15.23, average: 15.37
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 313, dropped: 0, current: 15.41, average: 15.37
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 321, dropped: 0, current: 15.16, average: 15.37
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 329, dropped: 0, current: 15.45, average: 15.37
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 337, dropped: 0, current: 15.24, average: 15.37
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 345, dropped: 0, current: 15.39, average: 15.37
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 353, dropped: 0, current: 15.24, average: 15.36
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 361, dropped: 0, current: 15.31, average: 15.36
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 369, dropped: 0, current: 15.31, average: 15.36
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 377, dropped: 0, current: 15.38, average: 15.36
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 385, dropped: 0, current: 15.39, average: 15.36
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 393, dropped: 0, current: 15.23, average: 15.36
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 401, dropped: 0, current: 15.19, average: 15.36
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 409, dropped: 0, current: 15.59, average: 15.36
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 417, dropped: 0, current: 15.24, average: 15.36
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 425, dropped: 0, current: 15.24, average: 15.36
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 433, dropped: 0, current: 15.23, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 441, dropped: 0, current: 15.33, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 449, dropped: 0, current: 15.44, average: 15.36
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 457, dropped: 0, current: 15.23, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 465, dropped: 0, current: 15.39, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 473, dropped: 0, current: 15.38, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 481, dropped: 0, current: 15.32, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 489, dropped: 0, current: 15.31, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 497, dropped: 0, current: 15.24, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 505, dropped: 0, current: 15.39, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 513, dropped: 0, current: 15.38, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 521, dropped: 0, current: 15.18, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 529, dropped: 0, current: 15.45, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 537, dropped: 0, current: 15.38, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 545, dropped: 0, current: 15.24, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 553, dropped: 0, current: 15.38, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 561, dropped: 0, current: 15.31, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 569, dropped: 0, current: 15.31, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 577, dropped: 0, current: 15.24, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 585, dropped: 0, current: 15.25, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 593, dropped: 0, current: 15.38, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 601, dropped: 0, current: 15.19, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 609, dropped: 0, current: 15.44, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 617, dropped: 0, current: 15.24, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 625, dropped: 0, current: 15.53, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 633, dropped: 0, current: 15.24, average: 15.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 641, dropped: 0, current: 15.16, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 649, dropped: 0, current: 15.47, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 657, dropped: 0, current: 15.38, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 665, dropped: 0, current: 15.23, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 673, dropped: 0, current: 15.39, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 681, dropped: 0, current: 15.17, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 689, dropped: 0, current: 15.45, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 697, dropped: 0, current: 15.23, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 705, dropped: 0, current: 15.39, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 713, dropped: 0, current: 15.23, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 721, dropped: 0, current: 15.48, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 729, dropped: 0, current: 15.30, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 737, dropped: 0, current: 15.24, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 745, dropped: 0, current: 15.39, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 753, dropped: 0, current: 15.38, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 761, dropped: 0, current: 15.18, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 769, dropped: 0, current: 15.30, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 777, dropped: 0, current: 15.37, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 785, dropped: 0, current: 15.39, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 793, dropped: 0, current: 15.42, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 801, dropped: 0, current: 15.30, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 809, dropped: 0, current: 15.59, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 817, dropped: 0, current: 15.38, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 825, dropped: 0, current: 15.40, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 833, dropped: 0, current: 15.24, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 841, dropped: 0, current: 15.33, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 849, dropped: 0, current: 15.30, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 857, dropped: 0, current: 15.24, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 865, dropped: 0, current: 15.39, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 873, dropped: 0, current: 15.38, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 881, dropped: 0, current: 15.17, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 889, dropped: 0, current: 15.45, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 897, dropped: 0, current: 15.23, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 905, dropped: 0, current: 15.25, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 913, dropped: 0, current: 15.38, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 921, dropped: 0, current: 15.18, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 929, dropped: 0, current: 15.44, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 937, dropped: 0, current: 15.24, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 945, dropped: 0, current: 15.39, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 953, dropped: 0, current: 15.24, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 961, dropped: 0, current: 15.32, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 969, dropped: 0, current: 15.60, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 977, dropped: 0, current: 15.37, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 985, dropped: 0, current: 15.24, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 993, dropped: 0, current: 15.24, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1001, dropped: 0, current: 15.17, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1009, dropped: 0, current: 15.46, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1017, dropped: 0, current: 15.23, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1025, dropped: 0, current: 15.38, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1033, dropped: 0, current: 15.38, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1041, dropped: 0, current: 15.19, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1049, dropped: 0, current: 15.45, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1057, dropped: 0, current: 15.38, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1065, dropped: 0, current: 15.24, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1073, dropped: 0, current: 15.24, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1081, dropped: 0, current: 15.32, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1089, dropped: 0, current: 15.45, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1097, dropped: 0, current: 15.23, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1105, dropped: 0, current: 15.24, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1113, dropped: 0, current: 15.38, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1121, dropped: 0, current: 15.36, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1129, dropped: 0, current: 15.27, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1137, dropped: 0, current: 15.38, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1145, dropped: 0, current: 15.24, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1153, dropped: 0, current: 15.38, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1161, dropped: 0, current: 15.32, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1169, dropped: 0, current: 15.30, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1177, dropped: 0, current: 15.24, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1185, dropped: 0, current: 15.38, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1193, dropped: 0, current: 15.23, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1201, dropped: 0, current: 15.18, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1209, dropped: 0, current: 15.48, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1217, dropped: 0, current: 15.36, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1225, dropped: 0, current: 15.24, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1233, dropped: 0, current: 15.23, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1241, dropped: 0, current: 15.32, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1249, dropped: 0, current: 15.46, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1257, dropped: 0, current: 15.24, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1265, dropped: 0, current: 15.38, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1273, dropped: 0, current: 15.39, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1281, dropped: 0, current: 15.17, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1289, dropped: 0, current: 15.46, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1297, dropped: 0, current: 15.22, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1305, dropped: 0, current: 15.40, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1313, dropped: 0, current: 15.38, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1321, dropped: 0, current: 15.19, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1329, dropped: 0, current: 15.44, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1337, dropped: 0, current: 15.53, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1345, dropped: 0, current: 15.38, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1353, dropped: 0, current: 15.24, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1361, dropped: 0, current: 15.20, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1369, dropped: 0, current: 15.56, average: 15.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1377, dropped: 0, current: 15.25, average: 15.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1385, dropped: 0, current: 15.39, average: 15.34
Execution ended after 0:01:30.952103955
250321.560606 s: VX_ZONE_INIT:[tivxHostDeInitLocal:115] De-Initialization Done for HOST !!!
250321.565477 s: VX_ZONE_INIT:[tivxDeInitLocal:204] De-Initialization Done !!!
APP: Deinit ... !!!
IPC: Deinit ... !!!
MEM: Deinit ... !!!
DDR_SHARED_MEM: Alloc's: 33 alloc's of 228543274 bytes
DDR_SHARED_MEM: Free's : 33 free's of 228543274 bytes
Here is the pipeline for 1080p with tiovxmultiscaler downscaling:
root@am62axx-evm:~# gst-launch-1.0 v4l2src device=/dev/video3 io-mode=5 ! queue leaky=2 ! video/x-bayer, width=3840, height=2160, format=rggb12, framerate=30/1, pixel-aspect-ratio=16/9 ! tiovxisp sink_0::device=/dev/v4l-subdev2 sensor-name=SENSOR_SONY_IMX334 dcc-isp-file=/opt/imaging/imx334/linear/dcc_viss.bin sink_0::dcc-2a-file=/opt/imaging/imx334/linear/dcc_2a.bin format-msb=11 ! video/x-raw,format=NV12,width=3840,height=2160,framerate=30/1,pixel-aspect-ratio=16/9 ! tiovxmultiscaler ! video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1,pixel-aspect-ratio=16/9,interlace-mode=progressive,colorimetry=bt601 ! v4l2h264enc output-io-mode=5 name=encoder extra-controls="controls,video_bitrate_mode=1,video_bitrate=10000000,h264_i_frame_period=60,h264_minimum_qp_value=8,h264_maximum_qp_value=51,h264_i_frame_qp_value=30,vbv_buffer_size=2000,h264_entropy_mode=1,video_gop_size=5,frame_level_rate_control_enable=1,h264_loop_filter_mode=0,prepend_sps_and_pps_to_idr=1;" ! fpsdisplaysink video-sink=fakesink text-overlay=false -v
APP: Init ... !!!
MEM: Init ... !!!
IPC: Init ... !!!
250370.352573 s: GTC Frequency = 200 MHz
250370.352717 s: VX_ZONE_INIT:Enabled
250370.352742 s: VX_ZONE_ERROR:Enabled
250370.352787 s: VX_ZONE_WARNING:Enabled
250370.353649 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-0
250370.354379 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-1
250370.355054 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-2
250370.355625 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-3
250370.355674 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
250370.356913 s: VX_ZONE_INIT:[tivxHostInitLocal:101] Initialization Done for HOST !!!
/GstPipeline:pipeline0/GstTIOVXMultiScaler:tiovxmultiscaler0.GstTIOVXMultiScalerPad:src_0: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/v4l2h264enc:encoder.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)1, profile=(string)baseline, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)16/9, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)1, profile=(string)baseline, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)16/9, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)1, profile=(string)baseline, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)16/9, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)1, profile=(string)baseline, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)16/9, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/v4l2h264enc:encoder.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)16/9, interlace-mode=(string)progressive, colorimetry=(string)bt601
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 9, dropped: 0, current: 17.98, average: 17.98
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 18, dropped: 0, current: 16.21, average: 17.05
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 27, dropped: 0, current: 16.37, average: 16.82
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 36, dropped: 0, current: 16.14, average: 16.64
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 45, dropped: 0, current: 16.44, average: 16.60
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 54, dropped: 0, current: 16.21, average: 16.53
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 62, dropped: 0, current: 15.98, average: 16.46
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 71, dropped: 0, current: 16.17, average: 16.42
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 80, dropped: 0, current: 16.57, average: 16.44
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 89, dropped: 0, current: 16.36, average: 16.43
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 98, dropped: 0, current: 16.21, average: 16.41
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 107, dropped: 0, current: 16.37, average: 16.41
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 116, dropped: 0, current: 16.17, average: 16.39
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 125, dropped: 0, current: 16.57, average: 16.40
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 134, dropped: 0, current: 16.22, average: 16.39
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 143, dropped: 0, current: 16.35, average: 16.39
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 152, dropped: 0, current: 16.37, average: 16.39
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 161, dropped: 0, current: 16.17, average: 16.37
Execution ended after 0:00:10.198767585
250380.771176 s: VX_ZONE_INIT:[tivxHostDeInitLocal:115] De-Initialization Done for HOST !!!
250380.776094 s: VX_ZONE_INIT:[tivxDeInitLocal:204] De-Initialization Done !!!
APP: Deinit ... !!!
IPC: Deinit ... !!!
MEM: Deinit ... !!!
DDR_SHARED_MEM: Alloc's: 33 alloc's of 200549674 bytes
DDR_SHARED_MEM: Free's : 33 free's of 200549674 bytes
Please let me know how to enable direct memory access for tiovxmultiscaler to unlock 1080p 30fps.
