Part Number: AM62L
Hi TI Team,
On AM62Lx running Linux (Processor SDK), I am using a UART interface to communicate with an external controller. Initially, the UART generates interrupts at the expected rate (about once per second), but after running for some time, the UART starts generating too many interrupts (interrupt storm), causing high CPU usage.
I suspect this is because the UART is operating in interrupt mode instead of DMA mode for RX.
I would like to know:
How to enable DMA support for a UART instance on AM62Lx in the device tree
Which DMA controller and DMA request IDs should be used
Whether the 8250_omap driver supports UART DMA on AM62Lx and if any kernel config is required
I could not find a clear AM62Lx-specific example for UART DMA configuration.
Parv
