Part Number: AM2754-Q1
Other Parts Discussed in Thread: AUDIO-AM275-EVM, AUDIO-AM62D-EVM, SK-AM62A-LP
Can you let me know the steps I can use to reduce the CAN response time using MCU+SDK/FreeRTOS SDK and the method to measure this time?
This FAQ describes various steps to optimize the CAN response time when using OSPI NOR boot mode, It is assumed that the CAN application will be running on R5F0-0 core and all the testing is done on am275-evm
- For AM275 FreeRTOS SDK, SBL and Device Manager firmware are combined in to a single freertos application which runs on the WKUP_R5 core.
| Stage | Description |
| T1 | The duration from ECU power-on until the PMIC completes power rail ramp-up and releases the SOC from reset. This timing varies by board design. |
| T2 | ROM execution Time |
| T3 | Time taken by SBL to boot R5F0-0 core |
| T4 | Time taken by R5F0-0 application to transmit the first CAN frame |
1. Disable the SBL print:
In sbl_ospi.c file, remove calls to the following functions
2. Call to App_runCpus API in sbl_ospi.c can be reordered to improve R5F0-0 boot time:
By default in SBL all the appimages are loaded first (using App_loadImages) and then in the end App_runCpus is called to take all CPUs out of reset, this can lead to increase in the CAN response time. To avoid this, App_runCpus should be moved immediately after App_loadImages.
The following patch includes all the changes required in sbl_ospi.c to reduce the SBL timing:https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/optimized_5F00_sbl.patch
3. Enable Time Slicing for r5 freertos kernel:
diff --git a/source/kernel/freertos/config/am275x/r5f/FreeRTOSConfig.h b/source/kernel/freertos/config/am275x/r5f/FreeRTOSConfig.h
index 1158af46..29b36a9a 100644
--- a/source/kernel/freertos/config/am275x/r5f/FreeRTOSConfig.h
+++ b/source/kernel/freertos/config/am275x/r5f/FreeRTOSConfig.h
@@ -95,7 +95,7 @@
#endif
#define configQUEUE_REGISTRY_SIZE (32)
#define configUSE_QUEUE_SETS (0)
-#define configUSE_TIME_SLICING (0) /* keep as 0 to get same functionality as SysBIOS6 */
+#define configUSE_TIME_SLICING (1) /* keep as 0 to get same functionality as SysBIOS6 */
#define configUSE_NEWLIB_REENTRANT (0)
#define configENABLE_BACKWARD_COMPATIBILITY (1)
#define configNUM_THREAD_LOCAL_STORAGE_POINTERS (10)
4. Change the priority of sciserver task:
The priority of Sciserver task is set to a lower value(3) compared to boot thread by default in the SDK, this is done by Sciserver_tirtosInitPrms_Init API in sciserver_init.c file. Due to this any sciclient request from MCAN app running on will not be serviced by Sciserver until the boot thread completes its execution. The following change will increase this task's priority to match the boot thread, this will allow sciserver task and boot task to execute concurrently as the time slicing is enabled now:
diff --git a/source/drivers/device_manager/sciserver/sciserver_init.c b/source/drivers/device_manager/sciserver/sciserver_init.c
index 704ddc5e..b3025b52 100644
--- a/source/drivers/device_manager/sciserver/sciserver_init.c
+++ b/source/drivers/device_manager/sciserver/sciserver_init.c
@@ -83,7 +83,7 @@ int32_t Sciserver_tirtosInitPrms_Init(Sciserver_TirtosCfgPrms_t *pPrms)
int32_t ret = SystemP_SUCCESS;
if (pPrms != NULL)
-#if defined (SOC_AM62PX)
+#if defined (SOC_AM62PX)|| defined (SOC_AM275X)
pPrms->taskPriority[SCISERVER_TASK_USER_LO] = 30U;
pPrms->taskPriority[SCISERVER_TASK_USER_HI] = 31U;
#elif defined (SOC_J722S)
5. Remove sciserver get version API call:
This can be done by defining DEBUG_LOG_DISABLE Macro in sciserver_init.c file.
After the above changes are done, you will have to rebuild the libraries: https://software-dl.ti.com/mcu-plus-sdk/esd/AM275X/11_01_00_16/exports/docs/api_guide_am275x/MAKEFILE_BUILD_PAGE.html#autotoc_md106 and you will also have to rebuild the SBL OSPI example.
FreeRTOS SDK version: 11_01_00_16
EVM: AUDIO-AM275-EVM
Bootmode Pin settings (OSPI NOR):
This FAQ only focuses on measuring the time for stages T2,T3,T4 mentioned previously. Approximate PMIC start-up time for the EVM is 16 ms, it is dependent on the hardware to provide the power to the PMIC quickly so this number might be different on a custom board.
MCU_PORz is the Power-On-Reset pin that is set HIGH as soon as the PMIC powers the voltage rail, you can probe Pin #1 on J32 connector on the EVM to get this.
Then you can use a GPIO pin like PIN_SPI0_CLK (Pin #17 on Audio expansion connector J12) and toggle it at the start of the SBL, you can add following code in the main.c of SBL OSPI to do this:
#include <drivers/gpio.h>
/* GPIO PIN Macros */
#define CONFIG_GPIO1_BASE_ADDR (CSL_GPIO1_BASE)
#define CONFIG_GPIO1_PIN (17)
#define CONFIG_GPIO1_DIR (GPIO_DIRECTION_OUTPUT)
#define CONFIG_GPIO1_TRIG_TYPE (GPIO_TRIG_TYPE_NONE)
#define CONFIG_GPIO_NUM_INSTANCES (1U)
static Pinmux_PerCfg_t gPinMuxMainCfg[] = {
/* MCU_GPIO1 pin config MCU_GPIO1_17 -> PIN_SPI0_CLK */
PIN_SPI0_CLK,
( PIN_MODE(7) | PIN_INPUT_ENABLE | PIN_PULL_DISABLE )
{PINMUX_END, PINMUX_END}
int main()
Pinmux_config(gPinMuxMainCfg, PINMUX_DOMAIN_ID_MAIN); // Configure PinMux
GPIO_setDirMode(CONFIG_GPIO1_BASE_ADDR, CONFIG_GPIO1_PIN, CONFIG_GPIO1_DIR); //Set GPIO direction
GPIO_pinWriteHigh(CONFIG_GPIO1_BASE_ADDR, CONFIG_GPIO1_PIN); // Set GPIO state to HIGH
Measuring the time between MCU_PORz and PIN_SPI0_CLK going HIGH indicates the approximate ROM execution time. This is around 20ms in the current testing.
We can use another GPIO pin to mark the start of R5F0-0 application, here PIN_SPI0_D0(Pin #19 on Audio expansion connector J12) is used and is set to high at the very start of R5F0-0 MCAN application, you can add the following code in main.c of your modified mcan_external_read_write application for this:
#include <drivers/pinmux.h>
#define CONFIG_GPIO1_PIN (18)
/* MCU_GPIO1 pin config MCU_GPIO1_18 -> PIN_SPI0_D0 */
PIN_SPI0_D0,
int main()
Measure the time from PIN_SPI0_CLK going HIGH to PIN_SPI0_D0 going HIGH to get this time. This is around 27ms in the current testing.
Please note that the time T4 (time to send the first CAN message after R5F0-0 is booted) is dependent upon AUTOSAR/CAN stack, here a modified application from FreeRTOS SDK is used for testing and to provide a reference.
mcan_external_read_write uses MCAN0 instance, to monitor the first CAN message MCAN0_CANL (#1 pin of J9 connector) can be probed.
The time from PIN_SPI0_D0 going high to receiving the first message on MCAN0_CANL indicates T4. This is around 17ms when using the modified mcan_external_read_write.
This will give a total CAN response time of 80ms (T1+T2+T3+T4).
| Stage | Description | Time(ms) |
| T1 | PMIC | 16 |
| T2 | ROM execution Time | 20 |
| T3 | Time taken by SBL to boot R5F0-0 core | 27 |
| T4 | Time taken by R5F0-0 application to transmit the first CAN frame | 17 |
| Total CAN response time |
80 |
This section describes steps to optimize the CAN response time for AM62D when using OSPI NOR boot mode, The CAN application runs on MCU R5 core and am62d-evm is used for the testing. The basic approach and some of the steps will remain same as what is already discussed for AM275.
- In FreeRTOS SDK for AM62D Stage-2 SBL and the Device manager application are combined as a single appimage that runs on the WKUP R5 core.
The above bootflow can be modified to start the MCU R5 application during SBL Stage-1, so It can initialize CAN once SBL Stage-2+DM application starts running on WKUP-R5.
| T3 | Time taken by SBL Stage-1 to boot MCU R5 core |
| T4 | Time taken by MCU R5 CAN application to transmit the first CAN frame |
1. Start MCU R5 in SBL Stage-1 instead of Stage-2:
As mentioned above the bootflow can be modified to start MCU R5 core in Stage-1 itself instead of starting it later in SBL stage-2. For this calls to App_loadMCUImage and App_runMCUCpu functions have to be moved to Stage-1 from Stage-2, you will also need to move definitions of these function from sbl_stage2_common.c to main.c of SBL Stage-1 application.
2. Disable the SBL print:
You can add this Macro: DEBUG_LOG_DISABLE in both SBL stages to disable the print logs.
The following patch includes all the changes required in SBL Stage-1 and Stage-2 to reduce the SBL timing:https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/0001_2D00_SBL_2D00_OSPI_2D00_changes_2D00_for_2D00_early_2D00_CAN.patch
diff --git a/source/kernel/freertos/config/am62dx/r5f/FreeRTOSConfig.h b/source/kernel/freertos/config/am62dx/r5f/FreeRTOSConfig.h
index d5e671c2..893c02a9 100644
--- a/source/kernel/freertos/config/am62dx/r5f/FreeRTOSConfig.h
+++ b/source/kernel/freertos/config/am62dx/r5f/FreeRTOSConfig.h
@@ -95,7 +95,7 @@
#endif
#define configNUM_THREAD_LOCAL_STORAGE_POINTERS (10) /* Minimun requirement for FreeRTOS FATFS to work */
index 704ddc5e..8d890d93 100644
if (pPrms != NULL)
+#if defined (SOC_AM62PX) || defined (SOC_AM62DX)
After the above changes are done, you will have to rebuild the libraries and you will also have to rebuild the SBL OSPI Stage-1 and Stage-2 examples.
FreeRTOS SDK version: 11_02_00_17
EVM: AUDIO-AM62D-EVM
The measurement method for AM62D remains same as mentioned for AM275.
This FAQ only focuses on measuring the time for stages T2,T3,T4 mentioned previously. Approximate PMIC start-up time for the EVM is 17.5 ms, it is dependent on the hardware to provide the power to the PMIC quickly so this number might be different on a custom board.
You can use the GPIO pin PIN_I2C1_SCL(Pin #18 on Audio expansion connector J13) in the SBL Stage-1 for this. As this pin is set to HIGH at the power-on measuring the time between MCU_PORz (you can probe TP49 on the EVM) to set to HIGH and PIN_I2C1_SCL to set to LOW indicates the approximate ROM execution time. Please note that you have to set this GPIO pin LOW instead of HIGH which was done in case of AM275.
This is around 32ms in the current testing for AM62D.
mcan_external_read_write uses MCU_MCAN0 instance, to monitor the first CAN message MCU_MCAN0_CANL (#3 pin of J15 connector) can be probed.
The time from when PIN_I2C1_SDA goes LOW to receiving the first message on MCU_MCAN0_CANL indicates T4. This is around 21.5ms when using the modified mcan_external_read_write.
This will give a total CAN response time of 100.5ms (T1+T2+T3+T4).
| T1 | PMIC | 17.5 |
| T2 | ROM execution Time | 32 |
| T3 | Time taken by SBL to boot MCU R5 core | 29.5 |
| T4 | Time taken by MCU R5 application to transmit the first CAN frame | 21.5 |
100.5 |
This section describes steps to optimize the CAN response time for AM62A when using OSPI NAND boot mode, The CAN application runs on MCU R5 core and SK-AM62A-LP EVM is used for the testing.
Initialize MCAN module in SBL Stage-1 to avoid any dependency on DM firmware from MCU R5 application.
1. Disable SBL prints.
2. Enable MCAN clock in SBL Stage-1.
Add following code in SBL Stage-1:
/* To enable MAIN domain MCAN */ SOC_moduleClockEnable(TISCI_DEV_MCAN0, 1); SOC_moduleSetClockFrequency(TISCI_DEV_MCAN0,TISCI_DEV_MCAN0_MCANSS_CCLK_CLK,AM62AX_MCAN_CLOCK_FREQUENCY); /* To enable MCU domain MCAN*/ SOC_moduleClockEnable(TISCI_DEV_MCU_MCAN0, 1); SOC_moduleSetClockFrequency(TISCI_DEV_MCU_MCAN0,TISCI_DEV_MCU_MCAN0_MCANSS_CCLK_CLK,AM62AX_MCAN_CLOCK_FREQUENCY);
3. Changes in clock.c to avoid resetting CAN clock when pminit() is called
Apply following patch to avoid resetting the CAN clock for both MAIN and MCU domain MCAN:
diff --git a/source/drivers/device_manager/rm_pm_hal/rm_pm_hal_src/pm/soc/am62ax/clocks.c b/source/drivers/device_manager/rm_pm_hal/rm_pm_hal_src/pm/
soc/am62ax/clocks.c
index 086b1f05..73712ae5 100644
--- a/source/drivers/device_manager/rm_pm_hal/rm_pm_hal_src/pm/soc/am62ax/clocks.c
+++ b/source/drivers/device_manager/rm_pm_hal/rm_pm_hal_src/pm/soc/am62ax/clocks.c
@@ -3662,7 +3662,7 @@ const struct clk_data soc_clock_data[260] = {
.drv = &clk_drv_pll_16fft,
.freq_idx = AM62AX_FREQ_VALUE_PLLFRACF2_SSMOD_16FFT_MAIN_0,
.data = &clk_data_pllfracf2_ssmod_16fft_main_0.data_pll.data,
- .flags = 0,
+ .flags = CLK_DATA_FLAG_NO_HW_REINIT,
[CLK_AM62AX_PLLFRACF2_SSMOD_16FFT_MAIN_0_FOUTPOSTDIV_CLK] = {
.parent = {
@@ -3782,7 +3782,7 @@ const struct clk_data soc_clock_data[260] = {
.freq_idx = AM62AX_FREQ_VALUE_PLLFRACF2_SSMOD_16FFT_MCU_0,
.data = &clk_data_pllfracf2_ssmod_16fft_mcu_0.data_pll.data,
- .flags = 0,
[CLK_AM62AX_POSTDIV1_16FFT_MAIN_1_HSDIVOUT5_CLK] = {
.parent = {
@@ -4264,7 +4264,7 @@ const struct clk_data soc_clock_data[260] = {
1,
.drv = &clk_drv_div_pll_16fft_hsdiv.drv,
- .flags = 0,
.type = CLK_TYPE_DIV,
.data = &clk_data_hsdiv4_16fft_main_0_hsdiv4.data_div.data,
@@ -4374,7 +4374,7 @@ const struct clk_data soc_clock_data[260] = {
1,
- .flags = 0,
.data = &clk_data_hsdiv4_16fft_mcu_0_hsdiv4.data_div.data,
4. Call to App_runCpus API in main.c of SBL S1 can be reordered to improve R5F0-0 boot time:
App_runCpus should be moved immediately after App_loadImages API.
5. Remove SCI Server call from the image running on MCU R5 for MCAN
Use modified System init:
diff --git a/examples/drivers/mcan/mcan_loopback_interrupt/am62ax-sk/mcu-r5fss0-0_freertos/main.c b/examples/drivers/mcan/mcan_loopback_interrupt/am62ax-sk/mcu-r5fss0-0_freertos/main.c
index 126b1737..a4623dea 100644
--- a/examples/drivers/mcan/mcan_loopback_interrupt/am62ax-sk/mcu-r5fss0-0_freertos/main.c
+++ b/examples/drivers/mcan/mcan_loopback_interrupt/am62ax-sk/mcu-r5fss0-0_freertos/main.c
@@ -69,11 +69,20 @@ void freertos_main(void *args)
vTaskDelete(NULL);
+void modSysInit(){
+ /* DPL init sets up address transalation unit, on some CPUs this is needed
+ * to access SCICLIENT services, hence this needs to happen first
+ Dpl_init();
+ /* Now we can do pinmux */
+ Pinmux_init();
int main()
/* init SOC specific modules */
- System_init();
+ modSysInit();
Board_init();
/* This task is created at highest priority, it should create more tasks and then delete itself */
Please note here any API call that might need SCI server services from system_init is removes, so CycleCounterP_init as well as Drivers_uartInit is also removed. If customer doesn't utilize CycleCounterP then it should be fine to remove it, UART has been removed as well, if UART or any other module is required in the MCU application then it also needs to be initialized in SBL for this.
After the above changes are done, you will have to rebuild the libraries, SBL and other applications.
MCU+SDK version: 11_01_00_16
EVM: SK-AM62A-LP
Bootmode Pin settings (OSPI NAND):
For measurement method please refer to AM275/AM62D section, following pins can be used for measurements;
MCU_PORz: #28 on J8
MCU_I2C0_SCL #24 on J8
MCU_I2C0_SDA #21 on J8
Approximate PMIC start-up time for the EVM is 22.5 ms, this is hardware dependent so this number might be different on a custom board.
| T1 | PMIC | 22.5 |
| T2 | ROM execution Time | 48.2 |
| T3 | Time taken by SBL to boot MCU R5 core | 56 |
| T4 | Time taken by MCU R5 application to transmit the first CAN frame | 0.3 |
127 |
